Can't run Ubuntu with GTX 1060
I have an Windows 10 installation and I want to have a dual boot for Ubuntu.
I have an GTX 1060.
  1. I install Unbuntu 16.04
  2. I install driver for nvidia : nvidia-390
After that I have a problem with a login loop (when I correctly login, the login page show again!).
I do all the advices found on internet but no fix action works for me.
Example of fix solutions fond on internet that not works for me : Ubuntu 16 Stuck in Login Loop after Installing Nvidia 364 Drivers - Ask Ubuntu
Can you please attach nvidia bug report as soon as issue hit? I think you can get it via ssh session. Please try moving .Xauthority from home directory. This is Ubuntu issue and check with Canonical.
Also check : How to fix ubuntu login loop [ quick tutorial ] - YouTube
lightdm - Ubuntu gets stuck in a login loop - Ask Ubuntu
Yes I already did all the stuff recommended in the video and forums (askubuntu, stackoverflow and Nvidia forum).
I join the result of grep EE nvidia-bug-report.log :
(WW) warning, (EE) error, (NI) not implemented, (??) unknown.
[ 3.195] (EE) No devices detected.
[ 3.197] (EE) [drm] Failed to open DRM device for (null): -2
[ 3.197] (EE) Screen 0 deleted because of no matching config section.
[ 3.201] (EE) Failed to initialize GLX extension (Compatible NVIDIA X driver not found)
[ 1047.903] (EE) No devices detected.
[ 1047.904] (EE) [drm] Failed to open DRM device for (null): -2
[ 1047.904] (EE) Screen 0 deleted because of no matching config section.
[ 1047.907] (EE) Failed to initialize GLX extension (Compatible NVIDIA X driver not found)
[ 1.414101] ata2.00: ACPI cmd f5/00:00:00:00:00:00 (SECURITY FREEZE LOCK) filtered out
[ 1.416514] ata1.00: ACPI cmd f5/00:00:00:00:00:00 (SECURITY FREEZE LOCK) filtered out
[ 1.416779] ata2.00: ACPI cmd f5/00:00:00:00:00:00 (SECURITY FREEZE LOCK) filtered out
[ 1.420662] ata1.00: ACPI cmd f5/00:00:00:00:00:00 (SECURITY FREEZE LOCK) filtered out
Okay. Are you able to start X with startx or xinit or Xorg commands from the command line? Can you please attach nvidia bug report as soon as issue hit? I think you can get it via ssh session. Also test with 396 driver.
I run “startx --logverbose 6” and there is the nvidia-bug report :
Start of NVIDIA bug report log file. Please include this file, along
with a detailed description of your problem, when reporting a graphics
driver bug via the NVIDIA Linux forum (see devtalk.nvidia.com)
or by sending email to ‘linux-bugs@nvidia.com’.
nvidia-bug-report.sh Version: 23548097
Date: lundi 23 avril 2018, 11:00:04 (UTC+0200)
uname: Linux riwan-pc 4.13.0-38-generic #43~16.04.1-Ubuntu SMP Wed Mar 14 17:48:43 UTC 2018 x86_64 x86_64 x86_64 GNU/Linux
command line flags:
*** /etc/issue
*** ls: -rw-r–r-- 1 root root 26 2018-02-20 09:44:08.000000000 +0100 /etc/issue
Ubuntu 16.04.4 LTS \n \l
*** /etc/debian_version
*** ls: -rw-r–r-- 1 root root 12 2015-04-30 12:00:00.000000000 +0200 /etc/debian_version
stretch/sid
*** /var/log/nvidia-installer.log does not exist
journalctl -b -0 _COMM=Xorg
– No entries –
journalctl -b -1 _COMM=Xorg
journalctl -b -2 _COMM=Xorg
journalctl -b -0 _COMM=Xorg.bin
– No entries –
journalctl -b -1 _COMM=Xorg.bin
journalctl -b -2 _COMM=Xorg.bin
– No entries –
*** /var/log/Xorg.1.log
*** ls: -rw-r–r-- 1 root root 22914 2018-04-23 10:59:05.742240529 +0200 /var/log/Xorg.1.log
[ 1610.763]
X.Org X Server 1.19.5
Release Date: 2017-10-12
[ 1610.764] X Protocol Version 11, Revision 0
[ 1610.765] Build Operating System: Linux 4.4.0-101-generic x86_64 Ubuntu
[ 1610.765] Current Operating System: Linux riwan-pc 4.13.0-38-generic #43~16.04.1-Ubuntu SMP Wed Mar 14 17:48:43 UTC 2018 x86_64
[ 1610.765] Kernel command line: BOOT_IMAGE=/boot/vmlinuz-4.13.0-38-generic.efi.signed root=UUID=a896b58b-c60e-475c-80a4-7333e28146ae ro quiet splash vt.handoff=7
[ 1610.766] Build Date: 24 November 2017 09:44:25AM
[ 1610.766] xorg-server 2:1.19.5-0ubuntu2~16.04.1 (For technical support please see Enterprise open source support | Ubuntu)
[ 1610.767] Current version of pixman: 0.33.6
[ 1610.767] Before reporting problems, check http://wiki.x.org
to make sure that you have the latest version.
[ 1610.767] Markers: (–) probed, () from config file, (==) default setting,
(++) from command line, (!!) notice, (II) informational,
[ 1610.769] (==) Log file: “/var/log/Xorg.1.log”, Time: Mon Apr 23 10:59:05 2018
[ 1610.769] (==) Using system config directory “/usr/share/X11/xorg.conf.d”
[ 1610.769] (==) No Layout section. Using the first Screen section.
[ 1610.769] (==) No screen section available. Using defaults.
[ 1610.769] (
) |–>Screen “Default Screen Section” (0)
[ 1610.769] (**) | |–>Monitor “”
[ 1610.769] (==) No monitor specified for screen “Default Screen Section”.
Using a default monitor configuration.
[ 1610.769] (==) Automatically adding devices
[ 1610.769] (==) Automatically enabling devices
[ 1610.769] (==) Automatically adding GPU devices
[ 1610.769] (==) Automatically binding GPU devices
[ 1610.769] (==) Max clients allowed: 256, resource mask: 0x1fffff
[ 1610.769] (WW) The directory “/usr/share/fonts/X11/cyrillic” does not exist.
[ 1610.769] Entry deleted from font path.
[ 1610.769] (WW) The directory “/usr/share/fonts/X11/100dpi/” does not exist.
[ 1610.769] (WW) The directory “/usr/share/fonts/X11/75dpi/” does not exist.
[ 1610.769] (WW) The directory “/usr/share/fonts/X11/100dpi” does not exist.
[ 1610.769] (WW) The directory “/usr/share/fonts/X11/75dpi” does not exist.
[ 1610.769] (==) FontPath set to:
/usr/share/fonts/X11/misc,
/usr/share/fonts/X11/Type1,
built-ins
[ 1610.769] (==) ModulePath set to “/usr/lib/x86_64-linux-gnu/xorg/extra-modules,/usr/lib/xorg/extra-modules,/usr/lib/xorg/modules”
[ 1610.769] (II) The server relies on udev to provide the list of input devices.
If no devices become available, reconfigure udev or disable AutoAddDevices.
[ 1610.769] (II) Loader magic: 0x564a6a90ae00
[ 1610.769] (II) Module ABI versions:
[ 1610.769] X.Org ANSI C Emulation: 0.4
[ 1610.769] X.Org Video Driver: 23.0
[ 1610.769] X.Org XInput driver : 24.1
[ 1610.769] X.Org Server Extension : 10.0
[ 1610.770] (++) using VT number 2
[ 1610.771] (II) systemd-logind: took control of session /org/freedesktop/login1/session/_32
[ 1610.772] (II) xfree86: Adding drm device (/dev/dri/card0)
[ 1610.772] (II) systemd-logind: got fd for /dev/dri/card0 226:0 fd 11 paused 0
[ 1610.773] (–) PCI:*(0:0:2:0) 8086:3e92:1043:8694 rev 0, Mem @ 0xf5000000/16777216, 0xd0000000/268435456, I/O @ 0x0000f000/64, BIOS @ 0x???/131072
[ 1610.773] (–) PCI: (0:1:0:0) 10de:1c03:1043:85b6 rev 161, Mem @ 0xf6000000/16777216, 0xe0000000/268435456, 0xf0000000/33554432, I/O @ 0x0000e000/128, BIOS @ 0x???/524288
[ 1610.773] (WW) “glamoregl” will not be loaded unless you’ve specified it to be loaded elsewhere.
[ 1610.773] (II) “glx” will be loaded by default.
[ 1610.773] (II) LoadModule: “glx”
[ 1610.773] (II) Loading /usr/lib/x86_64-linux-gnu/xorg/extra-modules/libglx.so
[ 1610.775] (II) Module glx: vendor=“NVIDIA Corporation”
[ 1610.775] compiled for 4.0.2, module version = 1.0.0
[ 1610.775] Module class: X.Org Server Extension
[ 1610.775] (II) NVIDIA GLX Module 396.18 Thu Apr 5 22:58:58 PDT 2018
[ 1610.775] (==) Matched nvidia as autoconfigured driver 0
[ 1610.775] (==) Matched nouveau as autoconfigured driver 1
[ 1610.775] (==) Matched modesetting as autoconfigured driver 2
[ 1610.775] (==) Matched fbdev as autoconfigured driver 3
[ 1610.775] (==) Matched vesa as autoconfigured driver 4
[ 1610.775] (==) Assigned the driver to the xf86ConfigLayout
[ 1610.775] (II) LoadModule: “nvidia”
[ 1610.775] (II) Loading /usr/lib/x86_64-linux-gnu/xorg/extra-modules/nvidia_drv.so
[ 1610.775] (II) Module nvidia: vendor=“NVIDIA Corporation”
[ 1610.775] Module class: X.Org Video Driver
[ 1610.775] (II) LoadModule: “nouveau”
[ 1610.775] (II) Loading /usr/lib/xorg/modules/drivers/nouveau_drv.so
[ 1610.775] (II) Module nouveau: vendor=“X.Org Foundation”
[ 1610.775] compiled for 1.19.5, module version = 1.0.15
[ 1610.775] ABI class: X.Org Video Driver, version 23.0
[ 1610.775] (II) LoadModule: “modesetting”
[ 1610.775] (II) Loading /usr/lib/xorg/modules/drivers/modesetting_drv.so
[ 1610.775] (II) Module modesetting: vendor=“X.Org Foundation”
[ 1610.775] compiled for 1.19.5, module version = 1.19.5
[ 1610.775] (II) LoadModule: “fbdev”
[ 1610.775] (II) Loading /usr/lib/xorg/modules/drivers/fbdev_drv.so
[ 1610.775] (II) Module fbdev: vendor=“X.Org Foundation”
[ 1610.775] compiled for 1.19.3, module version = 0.4.4
[ 1610.775] (II) LoadModule: “vesa”
[ 1610.775] (II) Loading /usr/lib/xorg/modules/drivers/vesa_drv.so
[ 1610.775] (II) Module vesa: vendor=“X.Org Foundation”
[ 1610.775] compiled for 1.19.3, module version = 2.3.4
[ 1610.775] (II) NVIDIA dlloader X Driver 396.18 Thu Apr 5 22:35:01 PDT 2018
[ 1610.775] (II) NVIDIA Unified Driver for all Supported NVIDIA GPUs
[ 1610.775] (II) NOUVEAU driver Date: Fri Apr 21 14:41:17 2017 -0400
[ 1610.775] (II) NOUVEAU driver for NVIDIA chipset families :
[ 1610.775] RIVA TNT (NV04)
[ 1610.775] RIVA TNT2 (NV05)
[ 1610.775] GeForce 256 (NV10)
[ 1610.775] GeForce 2 (NV11, NV15)
[ 1610.775] GeForce 4MX (NV17, NV18)
[ 1610.775] GeForce 3 (NV20)
[ 1610.775] GeForce 4Ti (NV25, NV28)
[ 1610.775] GeForce FX (NV3x)
[ 1610.775] GeForce 6 (NV4x)
[ 1610.775] GeForce 7 (G7x)
[ 1610.775] GeForce 8 (G8x)
[ 1610.775] GeForce GTX 200 (NVA0)
[ 1610.775] GeForce GTX 400 (NVC0)
[ 1610.776] (II) modesetting: Driver for Modesetting Kernel Drivers: kms
[ 1610.776] (II) FBDEV: driver for framebuffer: fbdev
[ 1610.776] (II) VESA: driver for VESA chipsets: vesa
[ 1610.776] (II) systemd-logind: releasing fd for 226:0
[ 1610.776] (EE) [drm] Failed to open DRM device for (null): -2
[ 1610.776] (WW) Falling back to old probe method for modesetting
[ 1610.776] (II) Loading sub module “fbdevhw”
[ 1610.776] (II) LoadModule: “fbdevhw”
[ 1610.776] (II) Loading /usr/lib/xorg/modules/libfbdevhw.so
[ 1610.776] (II) Module fbdevhw: vendor=“X.Org Foundation”
[ 1610.776] compiled for 1.19.5, module version = 0.0.2
[ 1610.776] ABI class: X.Org Video Driver, version 23.0
[ 1610.776] () FBDEV(1): claimed PCI slot 0@0:2:0
[ 1610.776] (II) FBDEV(1): using default device
[ 1610.776] (WW) Falling back to old probe method for vesa
[ 1610.776] (EE) Screen 0 deleted because of no matching config section.
[ 1610.776] (II) UnloadModule: “modesetting”
[ 1610.776] (II) FBDEV(0): Creating default Display subsection in Screen section
“Default Screen Section” for depth/fbbpp 24/32
[ 1610.776] (==) FBDEV(0): Depth 24, (==) framebuffer bpp 32
[ 1610.776] (==) FBDEV(0): RGB weight 888
[ 1610.776] (==) FBDEV(0): Default visual is TrueColor
[ 1610.776] (==) FBDEV(0): Using gamma correction (1.0, 1.0, 1.0)
[ 1610.776] (II) FBDEV(0): hardware: EFI VGA (video memory: 3072kB)
[ 1610.776] (II) FBDEV(0): checking modes against framebuffer device…
[ 1610.776] (II) FBDEV(0): checking modes against monitor…
[ 1610.776] (–) FBDEV(0): Virtual size is 1024x768 (pitch 1024)
[ 1610.776] (
) FBDEV(0): Built-in mode “current”: 78.7 MHz, 59.9 kHz, 75.7 Hz
[ 1610.776] (II) FBDEV(0): Modeline "current"x0.0 78.65 1024 1056 1184 1312 768 772 776 792 -hsync -vsync -csync (59.9 kHz b)
[ 1610.776] (==) FBDEV(0): DPI set to (96, 96)
[ 1610.776] (II) Loading sub module “fb”
[ 1610.776] (II) LoadModule: “fb”
[ 1610.776] (II) Loading /usr/lib/xorg/modules/libfb.so
[ 1610.776] (II) Module fb: vendor=“X.Org Foundation”
[ 1610.776] compiled for 1.19.5, module version = 1.0.0
[ 1610.776] ABI class: X.Org ANSI C Emulation, version 0.4
[ 1610.776] () FBDEV(0): using shadow framebuffer
[ 1610.776] (II) Loading sub module “shadow”
[ 1610.776] (II) LoadModule: “shadow”
[ 1610.776] (II) Loading /usr/lib/xorg/modules/libshadow.so
[ 1610.776] (II) Module shadow: vendor=“X.Org Foundation”
[ 1610.776] compiled for 1.19.5, module version = 1.1.0
[ 1610.776] (II) UnloadModule: “vesa”
[ 1610.776] (II) Unloading vesa
[ 1610.776] (==) Depth 24 pixmap format is 32 bpp
[ 1610.776] (II) FBDEV(0): FBIOBLANK: Invalid argument (Screen blanking not supported by kernel - disabling)
[ 1610.776] (==) FBDEV(0): Backing store enabled
[ 1610.777] (==) FBDEV(0): DPMS enabled
[ 1610.777] (==) RandR enabled
[ 1610.778] (II) SELinux: Disabled on system
[ 1610.779] (EE) Failed to initialize GLX extension (Compatible NVIDIA X driver not found)
[ 1610.793] (II) config/udev: Adding input device Power Button (/dev/input/event2)
[ 1610.793] (
) Power Button: Applying InputClass “evdev keyboard catchall”
[ 1610.793] (II) LoadModule: “evdev”
[ 1610.793] (II) Loading /usr/lib/xorg/modules/input/evdev_drv.so
[ 1610.793] (II) Module evdev: vendor=“X.Org Foundation”
[ 1610.793] compiled for 1.19.3, module version = 2.10.5
[ 1610.793] Module class: X.Org XInput Driver
[ 1610.793] ABI class: X.Org XInput driver, version 24.1
[ 1610.793] (II) Using input driver ‘evdev’ for ‘Power Button’
[ 1610.793] (II) systemd-logind: got fd for /dev/input/event2 13:66 fd 21 paused 0
[ 1610.793] () Power Button: always reports core events
[ 1610.793] (
) evdev: Power Button: Device: “/dev/input/event2”
[ 1610.793] (–) evdev: Power Button: Vendor 0 Product 0x1
[ 1610.793] (–) evdev: Power Button: Found keys
[ 1610.793] (II) evdev: Power Button: Configuring as keyboard
[ 1610.793] () Option “config_info” “udev:/sys/devices/LNXSYSTM:00/LNXPWRBN:00/input/input2/event2”
[ 1610.793] (II) XINPUT: Adding extended input device “Power Button” (type: KEYBOARD, id 6)
[ 1610.793] (
) Option “xkb_rules” “evdev”
[ 1610.793] () Option “xkb_model” “pc105”
[ 1610.793] (
) Option “xkb_layout” “fr”
[ 1610.801] (II) config/udev: Adding input device Power Button (/dev/input/event1)
[ 1610.801] () Power Button: Applying InputClass “evdev keyboard catchall”
[ 1610.801] (II) Using input driver ‘evdev’ for ‘Power Button’
[ 1610.801] (II) systemd-logind: got fd for /dev/input/event1 13:65 fd 22 paused 0
[ 1610.801] (
[ 1610.801] () evdev: Power Button: Device: “/dev/input/event1”
[ 1610.801] (–) evdev: Power Button: Vendor 0 Product 0x1
[ 1610.801] (–) evdev: Power Button: Found keys
[ 1610.801] (II) evdev: Power Button: Configuring as keyboard
[ 1610.801] (
) Option “config_info” “udev:/sys/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0C:00/input/input1/event1”
[ 1610.801] (II) XINPUT: Adding extended input device “Power Button” (type: KEYBOARD, id 7)
[ 1610.801] () Option “xkb_rules” “evdev”
[ 1610.801] (
[ 1610.801] () Option “xkb_layout” “fr”
[ 1610.801] (II) config/udev: Adding input device Sleep Button (/dev/input/event0)
[ 1610.801] (
) Sleep Button: Applying InputClass “evdev keyboard catchall”
[ 1610.801] (II) Using input driver ‘evdev’ for ‘Sleep Button’
[ 1610.802] (II) systemd-logind: got fd for /dev/input/event0 13:64 fd 23 paused 0
[ 1610.802] () Sleep Button: always reports core events
[ 1610.802] (
) evdev: Sleep Button: Device: “/dev/input/event0”
[ 1610.802] (–) evdev: Sleep Button: Vendor 0 Product 0x3
[ 1610.802] (–) evdev: Sleep Button: Found keys
[ 1610.802] (II) evdev: Sleep Button: Configuring as keyboard
[ 1610.802] () Option “config_info” “udev:/sys/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0E:00/input/input0/event0”
[ 1610.802] (II) XINPUT: Adding extended input device “Sleep Button” (type: KEYBOARD, id 8)
[ 1610.802] (
[ 1610.802] () Option “xkb_model” “pc105”
[ 1610.802] (
[ 1610.802] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=3 (/dev/input/event12)
[ 1610.802] (II) No input driver specified, ignoring this device.
[ 1610.802] (II) This device may have been added with another device file.
[ 1610.802] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=7 (/dev/input/event13)
[ 1610.802] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=8 (/dev/input/event14)
[ 1610.802] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=9 (/dev/input/event15)
[ 1610.803] (II) config/udev: Adding input device Logitech USB Optical Mouse (/dev/input/event5)
[ 1610.803] () Logitech USB Optical Mouse: Applying InputClass “evdev pointer catchall”
[ 1610.803] (II) Using input driver ‘evdev’ for ‘Logitech USB Optical Mouse’
[ 1610.803] (II) systemd-logind: got fd for /dev/input/event5 13:69 fd 24 paused 0
[ 1610.803] (
) Logitech USB Optical Mouse: always reports core events
[ 1610.803] () evdev: Logitech USB Optical Mouse: Device: “/dev/input/event5”
[ 1610.803] (–) evdev: Logitech USB Optical Mouse: Vendor 0x46d Product 0xc077
[ 1610.803] (–) evdev: Logitech USB Optical Mouse: Found 12 mouse buttons
[ 1610.803] (–) evdev: Logitech USB Optical Mouse: Found scroll wheel(s)
[ 1610.803] (–) evdev: Logitech USB Optical Mouse: Found relative axes
[ 1610.803] (–) evdev: Logitech USB Optical Mouse: Found x and y relative axes
[ 1610.803] (II) evdev: Logitech USB Optical Mouse: Configuring as mouse
[ 1610.803] (II) evdev: Logitech USB Optical Mouse: Adding scrollwheel support
[ 1610.803] (
) evdev: Logitech USB Optical Mouse: YAxisMapping: buttons 4 and 5
[ 1610.803] () evdev: Logitech USB Optical Mouse: EmulateWheelButton: 4, EmulateWheelInertia: 10, EmulateWheelTimeout: 200
[ 1610.803] (
) Option “config_info” “udev:/sys/devices/pci0000:00/0000:00:14.0/usb1/1-10/1-10:1.0/0003:046D:C077.0004/input/input16/event5”
[ 1610.803] (II) XINPUT: Adding extended input device “Logitech USB Optical Mouse” (type: MOUSE, id 9)
[ 1610.803] (II) evdev: Logitech USB Optical Mouse: initialized for relative axes.
[ 1610.803] () Logitech USB Optical Mouse: (accel) keeping acceleration scheme 1
[ 1610.803] (
) Logitech USB Optical Mouse: (accel) acceleration profile 0
[ 1610.803] () Logitech USB Optical Mouse: (accel) acceleration factor: 2.000
[ 1610.803] (
) Logitech USB Optical Mouse: (accel) acceleration threshold: 4
[ 1610.803] (II) config/udev: Adding input device Logitech USB Optical Mouse (/dev/input/mouse0)
[ 1610.803] (II) No input driver specified, ignoring this device.
[ 1610.803] (II) This device may have been added with another device file.
[ 1610.804] (II) config/udev: Adding input device Logitech USB Keyboard (/dev/input/event3)
[ 1610.804] () Logitech USB Keyboard: Applying InputClass “evdev keyboard catchall”
[ 1610.804] (II) Using input driver ‘evdev’ for ‘Logitech USB Keyboard’
[ 1610.804] (II) systemd-logind: got fd for /dev/input/event3 13:67 fd 25 paused 0
[ 1610.804] (
) Logitech USB Keyboard: always reports core events
[ 1610.804] () evdev: Logitech USB Keyboard: Device: “/dev/input/event3”
[ 1610.804] (–) evdev: Logitech USB Keyboard: Vendor 0x46d Product 0xc328
[ 1610.804] (–) evdev: Logitech USB Keyboard: Found keys
[ 1610.804] (II) evdev: Logitech USB Keyboard: Configuring as keyboard
[ 1610.804] (
) Option “config_info” “udev:/sys/devices/pci0000:00/0000:00:14.0/usb1/1-9/1-9:1.0/0003:046D:C328.0001/input/input3/event3”
[ 1610.804] (II) XINPUT: Adding extended input device “Logitech USB Keyboard” (type: KEYBOARD, id 10)
[ 1610.804] () Option “xkb_rules” “evdev”
[ 1610.804] (
[ 1610.804] () Option “xkb_layout” “fr”
[ 1610.804] (II) config/udev: Adding input device Logitech USB Keyboard (/dev/input/event4)
[ 1610.804] (
[ 1610.805] (II) systemd-logind: got fd for /dev/input/event4 13:68 fd 26 paused 0
[ 1610.805] () Logitech USB Keyboard: always reports core events
[ 1610.805] (
) evdev: Logitech USB Keyboard: Device: “/dev/input/event4”
[ 1610.805] (–) evdev: Logitech USB Keyboard: Vendor 0x46d Product 0xc328
[ 1610.805] (–) evdev: Logitech USB Keyboard: Found 1 mouse buttons
[ 1610.805] (–) evdev: Logitech USB Keyboard: Found scroll wheel(s)
[ 1610.805] (–) evdev: Logitech USB Keyboard: Found relative axes
[ 1610.805] (II) evdev: Logitech USB Keyboard: Forcing relative x/y axes to exist.
[ 1610.805] (–) evdev: Logitech USB Keyboard: Found absolute axes
[ 1610.805] (II) evdev: Logitech USB Keyboard: Forcing absolute x/y axes to exist.
[ 1610.805] (–) evdev: Logitech USB Keyboard: Found keys
[ 1610.805] (II) evdev: Logitech USB Keyboard: Configuring as mouse
[ 1610.805] (II) evdev: Logitech USB Keyboard: Configuring as keyboard
[ 1610.805] (II) evdev: Logitech USB Keyboard: Adding scrollwheel support
[ 1610.805] () evdev: Logitech USB Keyboard: YAxisMapping: buttons 4 and 5
[ 1610.805] (
) evdev: Logitech USB Keyboard: EmulateWheelButton: 4, EmulateWheelInertia: 10, EmulateWheelTimeout: 200
[ 1610.805] () Option “config_info” “udev:/sys/devices/pci0000:00/0000:00:14.0/usb1/1-9/1-9:1.1/0003:046D:C328.0002/input/input4/event4”
[ 1610.805] (II) XINPUT: Adding extended input device “Logitech USB Keyboard” (type: KEYBOARD, id 11)
[ 1610.805] (
[ 1610.805] () Option “xkb_model” “pc105”
[ 1610.805] (
[ 1610.805] (II) evdev: Logitech USB Keyboard: initialized for relative axes.
[ 1610.805] (WW) evdev: Logitech USB Keyboard: ignoring absolute axes.
[ 1610.805] () Logitech USB Keyboard: (accel) keeping acceleration scheme 1
[ 1610.805] (
) Logitech USB Keyboard: (accel) acceleration profile 0
[ 1610.805] () Logitech USB Keyboard: (accel) acceleration factor: 2.000
[ 1610.805] (
) Logitech USB Keyboard: (accel) acceleration threshold: 4
[ 1610.805] (II) config/udev: Adding input device HDA Intel PCH Line Out (/dev/input/event10)
[ 1610.805] (II) No input driver specified, ignoring this device.
[ 1610.805] (II) This device may have been added with another device file.
[ 1610.805] (II) config/udev: Adding input device HDA Intel PCH Front Headphone (/dev/input/event11)
[ 1610.805] (II) config/udev: Adding input device HDA Intel PCH Front Mic (/dev/input/event7)
[ 1610.806] (II) config/udev: Adding input device HDA Intel PCH Rear Mic (/dev/input/event8)
[ 1610.806] (II) No input driver specified, ignoring this device.
[ 1610.806] (II) This device may have been added with another device file.
[ 1610.806] (II) config/udev: Adding input device HDA Intel PCH Line (/dev/input/event9)
[ 1610.806] (II) config/udev: Adding input device Eee PC WMI hotkeys (/dev/input/event6)
[ 1610.806] () Eee PC WMI hotkeys: Applying InputClass “evdev keyboard catchall”
[ 1610.806] (II) Using input driver ‘evdev’ for ‘Eee PC WMI hotkeys’
[ 1610.806] (II) systemd-logind: got fd for /dev/input/event6 13:70 fd 27 paused 0
[ 1610.806] (
) Eee PC WMI hotkeys: always reports core events
[ 1610.806] () evdev: Eee PC WMI hotkeys: Device: “/dev/input/event6”
[ 1610.806] (–) evdev: Eee PC WMI hotkeys: Vendor 0 Product 0
[ 1610.806] (–) evdev: Eee PC WMI hotkeys: Found keys
[ 1610.806] (II) evdev: Eee PC WMI hotkeys: Configuring as keyboard
[ 1610.806] (
) Option “config_info” “udev:/sys/devices/platform/eeepc-wmi/input/input6/event6”
[ 1610.806] (II) XINPUT: Adding extended input device “Eee PC WMI hotkeys” (type: KEYBOARD, id 12)
[ 1610.806] () Option “xkb_rules” “evdev”
[ 1610.806] (
[ 1610.806] (**) Option “xkb_layout” “fr”
[ 1610.820] (II) evdev: Eee PC WMI hotkeys: Close
[ 1610.820] (II) UnloadModule: “evdev”
[ 1610.820] (II) systemd-logind: releasing fd for 13:70
[ 1610.856] (II) evdev: Logitech USB Keyboard: Close
[ 1610.856] (II) UnloadModule: “evdev”
[ 1610.856] (II) systemd-logind: releasing fd for 13:68
[ 1610.876] (II) evdev: Logitech USB Keyboard: Close
[ 1610.876] (II) UnloadModule: “evdev”
[ 1610.876] (II) systemd-logind: releasing fd for 13:67
[ 1610.892] (II) evdev: Logitech USB Optical Mouse: Close
[ 1610.892] (II) UnloadModule: “evdev”
[ 1610.892] (II) systemd-logind: releasing fd for 13:69
[ 1610.908] (II) evdev: Sleep Button: Close
[ 1610.908] (II) UnloadModule: “evdev”
[ 1610.908] (II) systemd-logind: releasing fd for 13:64
[ 1610.924] (II) evdev: Power Button: Close
[ 1610.924] (II) UnloadModule: “evdev”
[ 1610.924] (II) systemd-logind: releasing fd for 13:65
[ 1610.940] (II) evdev: Power Button: Close
[ 1610.940] (II) UnloadModule: “evdev”
[ 1610.940] (II) systemd-logind: releasing fd for 13:66
[ 1610.957] (II) Server terminated successfully (0). Closing log file.
*** /usr/share/X11/xorg.conf.d/10-amdgpu.conf
*** ls: -rw-r–r-- 1 root root 92 2018-01-29 19:56:16.000000000 +0100 /usr/share/X11/xorg.conf.d/10-amdgpu.conf
Section “OutputClass”
Identifier “AMDgpu”
MatchDriver “amdgpu”
Driver “amdgpu”
EndSection
*** /usr/share/X11/xorg.conf.d/10-evdev.conf
*** ls: -rw-r–r-- 1 root root 1099 2017-07-06 23:11:07.000000000 +0200 /usr/share/X11/xorg.conf.d/10-evdev.conf
Catch-all evdev loader for udev-based systems
We don’t simply match on any device since that also adds accelerometers
and other devices that we don’t really want to use. The list below
matches everything but joysticks.
Section “InputClass”
Identifier “evdev pointer catchall”
MatchIsPointer “on”
MatchDevicePath “/dev/input/event*”
Driver “evdev”
EndSection
Identifier “evdev keyboard catchall”
MatchIsKeyboard “on”
Driver “evdev”
EndSection
Identifier “evdev touchpad catchall”
MatchIsTouchpad “on”
Driver “evdev”
EndSection
Identifier “evdev tablet catchall”
MatchIsTablet “on”
Driver “evdev”
EndSection
Identifier “evdev touchscreen catchall”
MatchIsTouchscreen “on”
Driver “evdev”
EndSection
*** /usr/share/X11/xorg.conf.d/10-quirks.conf
*** ls: -rw-r–r-- 1 root root 1350 2017-11-24 10:51:10.000000000 +0100 /usr/share/X11/xorg.conf.d/10-quirks.conf
Collection of quirks and blacklist/whitelists for specific devices.
Accelerometer device, posts data through ABS_X/ABS_Y, making X unusable
22442 – ThinkPad HDAPS accelerometer gets recognized as MOUSE and makes Xorg unusable
Identifier “ThinkPad HDAPS accelerometer blacklist”
MatchProduct “ThinkPad HDAPS accelerometer data”
Option “Ignore” “on”
EndSection
523914 – Mouse does not move in PV Xen guest under RHEL-5.4
Explicitly tell evdev to not ignore the absolute axes.
Identifier “Xen Virtual Pointer axis blacklist”
MatchProduct “Xen Virtual Pointer”
Option “IgnoreAbsoluteAxes” “off”
Option “IgnoreRelativeAxes” “off”
EndSection
55867 – Doesn't know how to tag XI_TRACKBALL
Bug 55867 - Doesn’t know how to tag XI_TRACKBALL
Identifier “Tag trackballs as XI_TRACKBALL”
MatchProduct “trackball”
MatchDriver “evdev”
Option “TypeName” “TRACKBALL”
EndSection
62831 – Mionix Naos 5000 mouse detected incorrectly
Bug 62831 - Mionix Naos 5000 mouse detected incorrectly
Identifier “Tag Mionix Naos 5000 mouse XI_MOUSE”
MatchProduct “La-VIEW Technology Naos 5000 Mouse”
MatchDriver “evdev”
Option “TypeName” “MOUSE”
EndSection
*** /usr/share/X11/xorg.conf.d/10-radeon.conf
*** ls: -rw-r–r-- 1 root root 92 2018-01-29 19:58:46.000000000 +0100 /usr/share/X11/xorg.conf.d/10-radeon.conf
Identifier “Radeon”
MatchDriver “radeon”
Driver “radeon”
EndSection
*** /usr/share/X11/xorg.conf.d/11-evdev-quirks.conf
*** ls: -rw-r–r-- 1 root root 590 2017-07-06 23:10:42.000000000 +0200 /usr/share/X11/xorg.conf.d/11-evdev-quirks.conf
Identifier “Avago Technologies mouse quirks (LP: #746639)”
MatchIsPointer “on”
Driver “evdev”
MatchUSBID “192f:0416”
Option “Emulate3Buttons” “True”
Option “Emulate3Timeout” “50”
EndSection
X/Y axis not working due to device reporting absolute axes
Bug #325581 “kensington pocket mouse model #72237 USB 0d62:1000 ...” : Bugs : xserver-xorg-input-evdev package : Ubuntu
32882 – kensington pocket mouse model #72237 USB 0d62:1000 not working
Identifier “Benq m310”
MatchProduct “HID 0d62:1000”
Driver “evdev”
Option “IgnoreAbsoluteAxes” “true”
EndSection
*** /usr/share/X11/xorg.conf.d/11-evdev-trackpoint.conf
*** ls: -rw-r–r-- 1 root root 364 2017-07-06 23:10:42.000000000 +0200 /usr/share/X11/xorg.conf.d/11-evdev-trackpoint.conf
trackpoint users want wheel emulation
Identifier “trackpoint catchall”
MatchIsPointer “true”
MatchProduct “TrackPoint|DualPoint Stick”
Option “Emulate3Buttons” “true”
Option “EmulateWheel” “true”
Option “EmulateWheelButton” “2”
Option “XAxisMapping” “6 7”
Option “YAxisMapping” “4 5”
EndSection
*** /usr/share/X11/xorg.conf.d/51-synaptics-quirks.conf
*** ls: -rw-r–r-- 1 root root 590 2017-07-06 23:10:21.000000000 +0200 /usr/share/X11/xorg.conf.d/51-synaptics-quirks.conf
Identifier “Dell Inspiron embedded buttons quirks”
MatchTag “inspiron_1011|inspiron_1012”
Driver “synaptics”
Option “JumpyCursorThreshold” “90”
EndSection
Identifier “Dell Inspiron quirks”
MatchTag “inspiron_1120”
Driver “synaptics”
Option “JumpyCursorThreshold” “250”
EndSection
Identifier “HP Mininote quirks”
MatchTag “mininote_1000”
Driver “synaptics”
Option “JumpyCursorThreshold” “20”
EndSection
*** /usr/share/X11/xorg.conf.d/70-synaptics.conf
*** ls: -rw-r–r-- 1 root root 1751 2017-07-06 23:10:46.000000000 +0200 /usr/share/X11/xorg.conf.d/70-synaptics.conf
Example xorg.conf.d snippet that assigns the touchpad driver
to all touchpads. See xorg.conf.d(5) for more information on
InputClass.
DO NOT EDIT THIS FILE, your distribution will likely overwrite
it when updating. Copy (and rename) this file into
/etc/X11/xorg.conf.d first.
Additional options may be added in the form of
Option “OptionName” “value”
Identifier “touchpad catchall”
Driver “synaptics”
This option is recommend on all Linux systems using evdev, but cannot be
enabled by default. See the following link for details:
Who-T: How to ignore configuration errors
  MatchDevicePath "/dev/input/event*"
EndSection
Identifier “touchpad ignore duplicates”
MatchOS “Linux”
MatchDevicePath “/dev/input/mouse*”
EndSection
This option enables the bottom right corner to be a right button on clickpads
and the right and middle top areas to be right / middle buttons on clickpads
with a top button area.
This option is only interpreted by clickpads.
Identifier “Default clickpad buttons”
MatchDriver “synaptics”
Option “SoftButtonAreas” “50% 0 82% 0 0 0 0 0”
Option “SecondarySoftButtonAreas” “58% 0 0 15% 42% 58% 0 15%”
EndSection
This option disables software buttons on Apple touchpads.
Identifier “Disable clickpad buttons on Apple touchpads”
MatchProduct “Apple|bcm5974”
Option “SoftButtonAreas” “0 0 0 0 0 0 0 0”
EndSection
*** /usr/share/X11/xorg.conf.d/70-wacom.conf
*** ls: -rw-r–r-- 1 root root 2747 2017-07-06 23:04:29.000000000 +0200 /usr/share/X11/xorg.conf.d/70-wacom.conf
Some of the below input classes appear 3x times, once for each of
“tablet”, “touchscreen”, and “touchpad” to ensure that the Wacom
driver is not accidentally bound to other types of hardware that
Wacom has made which are not handled by the wacom driver (e.g the
Wacom Bluetooth Keyboard)
Linux Wacom Tablet Project / Bugs / #294 Wacom Bluetooth Keyboard mistakenly bound to xf86-input-wacom driver
Identifier “Wacom USB tablet class”
MatchUSBID “056a:"
MatchIsTablet “true”
Driver “wacom”
EndSection
Identifier “Wacom USB touchscreen class”
MatchUSBID “056a:"
MatchIsTouchscreen “true”
Driver “wacom”
EndSection
Identifier “Wacom USB touchpad class”
MatchUSBID “056a:"
MatchIsTouchpad “true”
Driver “wacom”
EndSection
Identifier “Wacom tablet class”
MatchProduct “Wacom|WACOM|PTK-540WL|ISD-V4”
Driver “wacom”
EndSection
Identifier “Wacom touchscreen class”
Driver “wacom”
EndSection
Identifier “Wacom touchpad class”
Driver “wacom”
EndSection
Serial Wacom devices should always be one of tablet, touchscreen, or
touchpad so we can safely get away with just one match section in
these cases
Identifier “Wacom PnP device class”
MatchPnPID “WACf*|WCOM*|WACM*|FUJ02e5|FUJ02e7|FUJ02e9”
Driver “wacom”
EndSection
Identifier “Wacom serial class”
MatchProduct “Serial Wacom Tablet”
Driver “wacom”
EndSection
Identifier “Wacom serial class identifiers”
MatchProduct “WACf|FUJ02e5|FUJ02e7|FUJ02e9”
Driver “wacom”
EndSection
Hanwang tablets
Identifier “Hanwang class”
MatchProduct “Hanwang”
Driver “wacom”
EndSection
Waltop tablets
Identifier “Waltop class”
MatchProduct “WALTOP”
MatchIsTablet “on”
Driver “wacom”
EndSection
N-Trig Duosense Electromagnetic Digitizer
Identifier “Wacom N-Trig class”
MatchProduct “HID 1b96:0001|N-Trig Pen|N-Trig DuoSense”
Driver “wacom”
Option “Button2” “3”
EndSection
*** /usr/share/X11/xorg.conf.d/glamoregl.conf
*** ls: lrwxrwxrwx 1 root root 29 2018-04-13 12:26:39.495798640 +0200 /usr/share/X11/xorg.conf.d/glamoregl.conf → /etc/alternatives/glamor_conf
Section “Module”
Disable “glamoregl”
EndSection
*** /usr/share/X11/xorg.conf.d/50-nvidia-drm-outputclass.conf: does not exist
*** nvidia-drm-outputclass.conf does not exist
*** /usr/share/nvidia/nvidia-application-profiles-396.18-rc
*** ls: lrwxrwxrwx 1 root root 53 2018-04-13 12:26:39.467797770 +0200 /usr/share/nvidia/nvidia-application-profiles-396.18-rc → /etc/alternatives/x86_64-linux-gnu_nvidia_app_profile
Application profiles for the NVIDIA Linux graphics driver, version 396.18
Last modified: Thu Apr 5 23:35:01 PDT 2018
These profiles were provided by NVIDIA and should not be modified. If you
wish to change the defaults provided here, you can override them by creating
custom rules in /etc/nvidia/nvidia-application-profiles-rc (which will apply
system-wide) or, for a given user, $HOME/.nv/nvidia-application-profiles-rc
(which will apply to that particular user). See the "APPLICATION PROFILE
SEARCH PATH" section of the NVIDIA Linux Graphics Driver README for more
information.
“profiles” : [
“name” : “NonConformantBlitFramebufferScissor”,
“settings” : [ “GLConformantBlitFramebufferScissor”, false ]
“name” : “CL1C”,
“settings” : [ “0x528ab3”, 1 ]
“name” : “FA0”,
“settings” : [ “10572898”, 0 ]
“name” : “ExactGLESVersion”,
“settings” : [ “ForceRequestedESVersion”, 1 ]
“name” : “IgnoreGLSLExtensionRequirements”,
“settings” : [ “GLIgnoreGLSLExtReqs”, true ]
“name” : “No GSYNC”,
“settings” : [ “GLGSYNCAllowed”, false ]
“name” : “UseThreadedOptimizations”,
“settings” : [ “GLThreadedOptimizations”, true ]
“name” : “NoThreadedOptimizations”,
“settings” : [ “GLThreadedOptimizations”, false ]
“name” : “NoAniso”,
“settings” : [ “GLLogMaxAniso”, 0 ]
“name” : “NamedVertexAttributesApplyDivisor”,
“settings” : [ “GL23cd0e”, 1 ]
“name” : “NonStrictDrawRangeElements”,
“settings” : [ “GLStrictDrawRangeElements”, false ]
“name” : “NoEnforceShaderInputOutputMatching”,
“settings” : [ “GLShaderPortabilityWarnings”, false ]
“rules” : [
“pattern” : {
“feature” : “dso”,
“matches” : “libcogl.so”
“profile” : “NonConformantBlitFramebufferScissor”
“pattern” : {
“feature” : “dso”,
“matches” : “libMaya.so”
“profile” : “CL1C”
“pattern” : {
“feature” : “dso”,
“profile” : “NamedVertexAttributesApplyDivisor”
{ “pattern” : “SkullGirls.x86_64-pc-linux-gnu”, “profile” : “NoAniso” },
{ “pattern” : “SkullGirls.i686-pc-linux-gnu”, “profile” : “NoAniso” },
{ “pattern” : “Indivisible_Linux.i686-pc-linux-gnu”, “profile” : “NoAniso” },
{ “pattern” : “xsi”, “profile” : “CL1C” },
{ “pattern” : “HoudiniFX”, “profile” : “CL1C” },
{ “pattern” : “katana”, “profile” : “CL1C” },
{ “pattern” : “Autodesk Mudbox 2014 64-bit”, “profile” : “CL1C” },
{ “pattern” : “octane”, “profile” : “CL1C” },
{ “pattern” : “Fusion64_6.4”, “profile” : “CL1C” },
{ “pattern” : “Nuke7.0”, “profile” : “CL1C” },
{ “pattern” : “vray.exe”, “profile” : “CL1C” },
{ “pattern” : “vray.bin”, “profile” : “CL1C” },
{ “pattern” : “kwin_gles”, “profile” : “FA0” },
{ “pattern” : “kwin_gles”, “profile” : “ExactGLESVersion” },
“pattern” : [
{ “feature” : “procname”, “matches” : “heaven_x86”},
{ “op” : “not”, “sub” : { “feature” : “findfile”, “matches” : “browser_x86” } }
“profile” : “IgnoreGLSLExtensionRequirements”
“pattern” : [
{ “feature” : “procname”, “matches” : “heaven_x64”},
{ “op” : “not”, “sub” : { “feature” : “findfile”, “matches” : “browser_x64” } }
{ “pattern” : { “feature” : “procname”, “matches” : “cinnamon” }, “profile” : “No GSYNC” },
{ “pattern” : { “feature” : “procname”, “matches” : “compiz” }, “profile” : “No GSYNC” },
{ “pattern” : { “feature” : “procname”, “matches” : “compton” }, “profile” : “No GSYNC” },
{ “pattern” : { “feature” : “procname”, “matches” : “enlightenment” }, “profile” : “No GSYNC” },
{ “pattern” : { “feature” : “procname”, “matches” : “gnome-shell” }, “profile” : “No GSYNC” },
{ “pattern” : { “feature” : “procname”, “matches” : “kscreenlocker_greet” }, “profile” : “No GSYNC” },
{ “pattern” : { “feature” : “procname”, “matches” : “kwin” }, “profile” : “No GSYNC” },
{ “pattern” : { “feature” : “procname”, “matches” : “kwin_x11” }, “profile” : “No GSYNC” },
{ “pattern” : { “feature” : “procname”, “matches” : “muffin” }, “profile” : “No GSYNC” },
{ “pattern” : { “feature” : “dso”, “matches” : “libmutter” }, “profile” : “No GSYNC” },
{ “pattern” : { “feature” : “procname”, “matches” : “steam” }, “profile” : “No GSYNC” },
{ “pattern” : { “feature” : “procname”, “matches” : “steamcompmgr” }, “profile” : “No GSYNC” },
“pattern” : “Borderlands2”,
“profile” : “UseThreadedOptimizations”
“pattern” : “BorderlandsPreSequel”,
“pattern” : “GoatGame”,
“profile” : “NonStrictDrawRangeElements”
“pattern” : “ShadowOfMordor”,
“profile” : “NoEnforceShaderInputOutputMatching”
“pattern” : “shotcut”,
“profile” : “NoThreadedOptimizations”
“pattern” : “MetroLL”,
{ “pattern”: “AlienIsolation”, “profile” : “UseThreadedOptimizations” },
{ “pattern”: “Civ6”, “profile” : “UseThreadedOptimizations” },
{ “pattern”: “CivBE”, “profile” : “UseThreadedOptimizations” },
{ “pattern”: “overlord.i386”, “profile” : “UseThreadedOptimizations” }
Skipping ldd output (glxinfo not found)
Vulkan loader not found
/usr/bin/lspci -d “10de:*” -v -xxx
01:00.0 VGA compatible controller: NVIDIA Corporation Device 1c03 (rev a1) (prog-if 00 [VGA controller])
Subsystem: ASUSTeK Computer Inc. Device 85b6
Flags: bus master, fast devsel, latency 0, IRQ 16
Memory at f6000000 (32-bit, non-prefetchable)
Memory at e0000000 (64-bit, prefetchable)
Memory at f0000000 (64-bit, prefetchable)
I/O ports at e000
[virtual] Expansion ROM at f7000000 [disabled]
Capabilities: [60] Power Management version 3
Capabilities: [68] MSI: Enable- Count=1/1 Maskable- 64bit+
Capabilities: [78] Express Legacy Endpoint, MSI 00
Capabilities: [100] Virtual Channel
Capabilities: [250] Latency Tolerance Reporting
Capabilities: [128] Power Budgeting <?> Capabilities: [420] Advanced Error Reporting Capabilities: [600] Vendor Specific Information: ID=0001 Rev=1 Len=024 <?>
Capabilities: [900] #19
Kernel driver in use: nvidia
Kernel modules: nvidiafb, nouveau, nvidia_396, nvidia_396_drm
00: de 10 03 1c 07 00 10 00 a1 00 00 03 00 00 80 00
10: 00 00 00 f6 0c 00 00 e0 00 00 00 00 0c 00 00 f0
20: 00 00 00 00 01 e0 00 00 00 00 00 00 43 10 b6 85
30: 00 00 00 00 60 00 00 00 00 00 00 00 0b 01 00 00
40: 43 10 b6 85 00 00 00 00 00 00 00 00 00 00 00 00
50: 01 00 00 00 01 00 00 00 ce d6 23 00 00 00 00 00
60: 01 68 03 00 08 00 00 00 05 78 80 00 00 00 00 00
70: 00 00 00 00 00 00 00 00 10 00 12 00 e1 8d 2c 01
80: 30 21 00 00 03 3d 46 00 40 01 01 11 00 00 00 00
90: 00 00 00 00 00 00 00 00 00 00 00 00 13 08 04 00
a0: 00 04 00 00 0e 00 00 00 03 00 1f 00 00 00 00 00
b0: 00 00 00 00 09 00 14 01 00 00 00 00 00 00 00 00
c0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
d0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
e0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
f0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
01:00.1 Audio device: NVIDIA Corporation Device 10f1 (rev a1)
Flags: bus master, fast devsel, latency 0, IRQ 17
Memory at f7080000 (32-bit, non-prefetchable)
Capabilities: [78] Express Endpoint, MSI 00
Capabilities: [100] Advanced Error Reporting
Kernel driver in use: snd_hda_intel
Kernel modules: snd_hda_intel
00: de 10 f1 10 06 00 10 00 a1 00 03 04 10 00 80 00
10: 00 00 08 f7 00 00 00 00 00 00 00 00 00 00 00 00
20: 00 00 00 00 00 00 00 00 00 00 00 00 43 10 b6 85
30: 00 00 00 00 60 00 00 00 00 00 00 00 0a 02 00 00
50: 00 00 00 00 00 00 00 00 ce d6 23 00 00 00 00 00
70: 00 00 00 00 00 00 00 00 10 00 02 00 e1 8d 2c 01
80: 30 29 09 00 03 3d 45 00 43 01 01 11 00 00 00 00
a0: 00 00 00 00 0e 00 00 00 00 00 01 00 00 00 00 00
b0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
/usr/bin/lspci -d “10b5:*” -v -xxx
/usr/bin/lspci -t
-[0000:00]-±00.0
±01.0-[01]–±00.0
| -00.1
±02.0
±14.0
±16.0
±17.0
±1b.0-[02]–
±1c.0-[03]–
±1c.3-[04]----00.0
±1d.0-[05]–
±1f.0
±1f.2
±1f.3
-1f.4
/usr/bin/lspci -nn
00:00.0 Host bridge [0600]: Intel Corporation Device [8086:3ec2] (rev 07)
00:01.0 PCI bridge [0604]: Intel Corporation Sky Lake PCIe Controller (x16) [8086:1901] (rev 07)
00:02.0 VGA compatible controller [0300]: Intel Corporation Device [8086:3e92]
00:14.0 USB controller [0c03]: Intel Corporation Device [8086:a2af]
00:16.0 Communication controller [0780]: Intel Corporation Device [8086:a2ba]
00:17.0 SATA controller [0106]: Intel Corporation Device [8086:a282]
00:1b.0 PCI bridge [0604]: Intel Corporation Device [8086:a2e7] (rev f0)
00:1c.0 PCI bridge [0604]: Intel Corporation Device [8086:a290] (rev f0)
00:1c.3 PCI bridge [0604]: Intel Corporation Device [8086:a293] (rev f0)
00:1d.0 PCI bridge [0604]: Intel Corporation Device [8086:a298] (rev f0)
00:1f.0 ISA bridge [0601]: Intel Corporation Device [8086:a2c9]
00:1f.2 Memory controller [0580]: Intel Corporation Device [8086:a2a1]
00:1f.3 Audio device [0403]: Intel Corporation Device [8086:a2f0]
00:1f.4 SMBus [0c05]: Intel Corporation Device [8086:a2a3]
01:00.0 VGA compatible controller [0300]: NVIDIA Corporation Device [10de:1c03] (rev a1)
01:00.1 Audio device [0403]: NVIDIA Corporation Device [10de:10f1] (rev a1)
04:00.0 Ethernet controller [0200]: Realtek Semiconductor Co., Ltd. RTL8111/8168/8411 PCI Express Gigabit Ethernet Controller [10ec:8168] (rev 15)
/usr/bin/lsusb
Bus 002 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 001 Device 002: ID 046d:c328 Logitech, Inc.
Bus 001 Device 006: ID 8644:800a Intenso GmbG
Bus 001 Device 004: ID 046d:c077 Logitech, Inc. M105 Optical Mouse
Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
/usr/sbin/dmidecode
dmidecode 3.0
Getting SMBIOS data from sysfs.
SMBIOS 3.0.0 present.
Table at 0xB2E8B000.
Handle 0x0000, DMI type 0, 24 bytes
BIOS Information
Vendor: American Megatrends Inc.
Version: 0612
Release Date: 03/01/2018
Address: 0xF0000
Runtime Size: 64 kB
ROM Size: 16384 kB
Characteristics:
PCI is supported
APM is supported
BIOS is upgradeable
BIOS shadowing is allowed
Boot from CD is supported
Selectable boot is supported
BIOS ROM is socketed
EDD is supported
5.25"/1.2 MB floppy services are supported (int 13h)
3.5"/720 kB floppy services are supported (int 13h)
3.5"/2.88 MB floppy services are supported (int 13h)
Print screen service is supported (int 5h)
8042 keyboard services are supported (int 9h)
Serial services are supported (int 14h)
Printer services are supported (int 17h)
ACPI is supported
USB legacy is supported
BIOS boot specification is supported
Targeted content distribution is supported
UEFI is supported
BIOS Revision: 5.12
Handle 0x0001, DMI type 1, 27 bytes
System Information
Manufacturer: System manufacturer
Product Name: System Product Name
Version: System Version
Serial Number: System Serial Number
UUID: 160C635B-7E82-E81F-69C3-1831BF251DD5
Wake-up Type: Power Switch
SKU Number: SKU
Family: To be filled by O.E.M.
Handle 0x0002, DMI type 2, 15 bytes
Base Board Information
Manufacturer: ASUSTeK COMPUTER INC.
Product Name: PRIME Z370-P
Version: Rev X.0x
Serial Number: 171216566600276
Asset Tag: Default string
Features:
Board is a hosting board
Board is replaceable
Location In Chassis: Default string
Chassis Handle: 0x0003
Type: Motherboard
Contained Object Handles: 0
Handle 0x0003, DMI type 3, 22 bytes
Chassis Information
Manufacturer: Default string
Type: Desktop
Lock: Not Present
Version: Default string
Serial Number: Default string
Boot-up State: Safe
Power Supply State: Safe
Thermal State: Safe
Security Status: None
OEM Information: 0x00000000
Height: Unspecified
Number Of Power Cords: 1
Contained Elements: 0
SKU Number: Default string
Handle 0x0004, DMI type 8, 9 bytes
Port Connector Information
Internal Reference Designator: KBMS_USB910
Internal Connector Type: None
External Reference Designator: PS/2 Mouse/Keyboard
External Connector Type: PS/2
Port Type: Keyboard Port
Handle 0x0005, DMI type 8, 9 bytes
Internal Reference Designator: U31G1_78
External Reference Designator: U31G1_78
External Connector Type: Access Bus (USB)
Port Type: USB
Handle 0x0006, DMI type 8, 9 bytes
Internal Reference Designator: LAN_U31G1_56
External Reference Designator: LAN_U31G1_56
External Connector Type: RJ-45
Port Type: Network Port
Handle 0x0007, DMI type 8, 9 bytes
Internal Reference Designator: AUDIO
External Reference Designator: AUDIO
External Connector Type: Other
Port Type: Audio Port
Handle 0x0008, DMI type 8, 9 bytes
Internal Reference Designator: DVI
External Reference Designator: DVI port
Port Type: Other
Handle 0x0009, DMI type 8, 9 bytes
Internal Reference Designator: HDMI
External Reference Designator: HDMI port
Port Type: Other
Handle 0x000A, DMI type 8, 9 bytes
Internal Reference Designator: SATA6G_1
Internal Connector Type: SAS/SATA Plug Receptacle
External Reference Designator: Not Specified
External Connector Type: None
Port Type: SATA
Handle 0x000B, DMI type 8, 9 bytes
Internal Reference Designator: SATA6G_2
Port Type: SATA
Handle 0x000C, DMI type 8, 9 bytes
Internal Reference Designator: SATA6G_3
Port Type: SATA
Handle 0x000D, DMI type 8, 9 bytes
Internal Reference Designator: SATA6G_4
Port Type: SATA
Handle 0x000E, DMI type 8, 9 bytes
Internal Reference Designator: M.2_1(SOCKET3)
Internal Connector Type: Other
Port Type: Other
Handle 0x000F, DMI type 8, 9 bytes
Internal Reference Designator: M.2_2(SOCKET3)
Port Type: Other
Handle 0x0010, DMI type 8, 9 bytes
Internal Reference Designator: U31G1_12
Internal Connector Type: Access Bus (USB)
Port Type: USB
Handle 0x0011, DMI type 8, 9 bytes
Internal Reference Designator: U31G1_34
Port Type: USB
Handle 0x0012, DMI type 8, 9 bytes
Internal Reference Designator: USB1112
Port Type: USB
Handle 0x0013, DMI type 8, 9 bytes
Internal Reference Designator: USB1314
Port Type: USB
Handle 0x0014, DMI type 8, 9 bytes
Internal Reference Designator: CPU_FAN
Port Type: Other
Handle 0x0015, DMI type 8, 9 bytes
Internal Reference Designator: CHA_FAN1
Port Type: Other
Handle 0x0016, DMI type 8, 9 bytes
Internal Reference Designator: CHA_FAN2
Port Type: Other
Handle 0x0017, DMI type 8, 9 bytes
Internal Reference Designator: AAFP
Port Type: Other
Handle 0x0018, DMI type 8, 9 bytes
Internal Reference Designator: SPDIF_OUT
Port Type: Other
Handle 0x0019, DMI type 8, 9 bytes
Internal Reference Designator: PANEL
Port Type: Other
Handle 0x001A, DMI type 8, 9 bytes
Internal Reference Designator: AIO_PUMP
Port Type: Other
Handle 0x001B, DMI type 9, 17 bytes
System Slot Information
Designation: PCIEX16_1
Type: x16 PCI Express
Current Usage: In Use
Length: Long
Characteristics:
3.3 V is provided
Opening is shared
PME signal is supported
Bus Address: 0000:01:01.0
Handle 0x001C, DMI type 9, 17 bytes
Designation: PCIEX16_2
Current Usage: Available
Length: Short
Characteristics:
3.3 V is provided
Opening is shared
Bus Address: 0000:ff:1b.4
Handle 0x001D, DMI type 9, 17 bytes
Designation: PCIEX1_1
Type: x1 PCI Express
Length: Short
Characteristics:
3.3 V is provided
Opening is shared
Bus Address: 0000:ff:1c.4
Handle 0x001E, DMI type 9, 17 bytes
Designation: PCIEX1_2
Length: Short
Characteristics:
3.3 V is provided
Opening is shared
Bus Address: 0000:ff:1c.5
Handle 0x001F, DMI type 9, 17 bytes
Designation: PCIEX1_3
Length: Short
Characteristics:
3.3 V is provided
Opening is shared
Bus Address: 0000:ff:1c.6
Handle 0x0020, DMI type 9, 17 bytes
Designation: PCIEX1_4
Length: Short
Characteristics:
3.3 V is provided
Opening is shared
Bus Address: 0000:ff:1c.7
Handle 0x0021, DMI type 10, 6 bytes
On Board Device Information
Type: Video
Status: Enabled
Description: To Be Filled By O.E.M.
Handle 0x0022, DMI type 11, 5 bytes
OEM Strings
String 1: Default string
String 2: Default string
String 3: COD
String 4: Default string
String 5: FFFFFFFFFFFFF
String 6: FFFFFFFFFFFFF
String 7: FFFFFFFFFFFFF
String 8: Default string
Handle 0x0023, DMI type 12, 5 bytes
System Configuration Options
Option 1: SMI:00B29C05
Option 2: DSN: .
Option 3: DSN:
I didn’t see any nvidia related error in the log. I think some part in missing in logs like dmesg, journalctl and end of nvidia-bug-report. Please attach nvidia-bug-report to your existing post.
Also I think you have two VGA graphics devices. Please generate new xorg.conf for nvidia driver or add PCI bus id in Xorg configuration file. Option BusID “PCI:1:0:0” . or use comamnd nvidia-xconfig --busid=“PCI:1:0:0”
Thanks for your answer.
I added “PCI:1:0:0” to the Xorg configuration.
Now I have a purple screen when I launch Ubuntu :(
And I don’t have any errors in /var/log
As soon as issue hit, Can you please attach nvidia bug report log file to your existing post/comment?
[b]
I use nvidia-396 drivers.
I saw on forum that to fix the purple screen, we must resinstall graphics drivers…
Here is the report :
[/b]
nvidia-bug-report.log.gz (86.3 KB)
Do you see the problem ?
Processes
Process ID : 1098
Type : G
Used GPU Memory : 5 MiB
From log I see X server started without any issue.
[ 3.260] (**) NVIDIA(0): Option “AllowEmptyInitialConfiguration” “true”
Why are you using this option?
Just start lightdm or gdm whatever display manager you are using to login and see what happens.
Ok thanks I have no problem anymore !
