Just got a spiffy new GTX 750TI display card and it ain’t working, long story short. I get as far as where the drive should be loaded and end up with a black screen. I can do a ctl-alt-T to bring up a terminal and have tried loading the nvidia drivers from there, to no avail. I made a new Ubuntu install DVD and that ends up in a black screen that goes nowhere, odd since I’d think they used a vintage X server and not an accelerated server.
Maybe the 750 is really different?
Per the “…Read this first” the nvidia I’m including the text of nvidia-bug-report.log. This was done from safe mode because the script reported errors and told me to do so. Idon’t see an option to attach the .gz file, so:
Start of NVIDIA bug report log file. Please include this file, along
with a detailed description of your problem, when reporting a graphics
driver bug via the NVIDIA Linux forum (see devtalk.nvidia.com)
or by sending email to ‘linux-bugs@nvidia.com’.
nvidia-bug-report.sh Version: 14306482
Date: Fri Feb 21 10:54:45 EST 2014
uname: Linux Acomputer 3.11.0-17-generic #31-Ubuntu SMP Mon Feb 3 21:52:43 UTC 2014 x86_64 x86_64 x86_64 GNU/Linux
command line flags: --safe-mode
*** /etc/issue
*** ls: -rw-r–r-- 1 root root 20 2013-10-13 16:41:50.000000000 -0400 /etc/issue
Ubuntu 13.10 \n \l
*** /etc/debian_version
*** ls: -rw-r–r-- 1 root root 11 2012-10-27 23:43:19.000000000 -0400 /etc/debian_version
wheezy/sid
*** /var/log/nvidia-installer.log
*** ls: -rw-r–r-- 1 root root 861 2013-09-26 10:10:27.527694598 -0400 /var/log/nvidia-installer.log
nvidia-installer log file ‘/var/log/nvidia-installer.log’
creation time: Thu Sep 26 10:10:08 2013
installer version: 319.49
PATH: /usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin
nvidia-installer command line:
./nvidia-installer
Using: nvidia-installer ncurses user interface
→ The file ‘/tmp/.X0-lock’ exists and appears to contain the process ID ‘1235’ of a runnning X server.
ERROR: You appear to be running an X server; please exit X before installing. For further details, please see the section INSTALLING THE NVIDIA DRIVER in the README available on the Linux driver download page at www.nvidia.com.
ERROR: Installation has failed. Please see the file ‘/var/log/nvidia-installer.log’ for details. You may find suggestions on fixing installation problems in the README available on the Linux driver download page at www.nvidia.com.
*** /var/log/Xorg.0.log
*** ls: -rw-r–r-- 1 root root 72163 2014-02-21 10:53:34.310136200 -0500 /var/log/Xorg.0.log
[ 30.056]
X.Org X Server 1.14.5
Release Date: 2013-12-12
[ 30.056] X Protocol Version 11, Revision 0
[ 30.056] Build Operating System: Linux 3.2.0-37-generic x86_64 Ubuntu
[ 30.056] Current Operating System: Linux Acomputer 3.11.0-17-generic #31-Ubuntu SMP Mon Feb 3 21:52:43 UTC 2014 x86_64
[ 30.056] Kernel command line: BOOT_IMAGE=/boot/vmlinuz-3.11.0-17-generic root=UUID=944a6234-eec2-4b58-be56-66dea1e3dbb4 ro quiet splash
[ 30.056] Build Date: 17 December 2013 10:06:15AM
[ 30.056] xorg-server 2:1.14.5-1ubuntu2~saucy1 (For technical support please see Enterprise open source support | Ubuntu)
[ 30.056] Current version of pixman: 0.30.2
[ 30.056] Before reporting problems, check http://wiki.x.org
to make sure that you have the latest version.
[ 30.056] Markers: (–) probed, () from config file, (==) default setting,
(++) from command line, (!!) notice, (II) informational,
(WW) warning, (EE) error, (NI) not implemented, (??) unknown.
[ 30.056] (==) Log file: “/var/log/Xorg.0.log”, Time: Fri Feb 21 10:53:20 2014
[ 30.056] (==) Using system config directory “/usr/share/X11/xorg.conf.d”
[ 30.057] (==) No Layout section. Using the first Screen section.
[ 30.057] (==) No screen section available. Using defaults.
[ 30.057] () |–>Screen “Default Screen Section” (0)
[ 30.057] (**) | |–>Monitor “”
[ 30.057] (==) No monitor specified for screen “Default Screen Section”.
Using a default monitor configuration.
[ 30.057] (==) Automatically adding devices
[ 30.057] (==) Automatically enabling devices
[ 30.057] (==) Automatically adding GPU devices
[ 30.057] (WW) The directory “/usr/share/fonts/X11/cyrillic” does not exist.
[ 30.057] Entry deleted from font path.
[ 30.057] (WW) The directory “/usr/share/fonts/X11/100dpi/” does not exist.
[ 30.057] (WW) The directory “/usr/share/fonts/X11/75dpi/” does not exist.
[ 30.057] (WW) The directory “/usr/share/fonts/X11/100dpi” does not exist.
[ 30.057] (WW) The directory “/usr/share/fonts/X11/75dpi” does not exist.
[ 30.057] (==) FontPath set to:
/usr/share/fonts/X11/misc,
/usr/share/fonts/X11/Type1,
built-ins
[ 30.057] (==) ModulePath set to “/usr/lib/x86_64-linux-gnu/xorg/extra-modules,/usr/lib/xorg/extra-modules,/usr/lib/xorg/modules”
[ 30.057] (II) The server relies on udev to provide the list of input devices.
If no devices become available, reconfigure udev or disable AutoAddDevices.
[ 30.057] (II) Loader magic: 0x7fa66f324d20
[ 30.057] (II) Module ABI versions:
[ 30.057] X.Org ANSI C Emulation: 0.4
[ 30.057] X.Org Video Driver: 14.1
[ 30.057] X.Org XInput driver : 19.1
[ 30.057] X.Org Server Extension : 7.0
[ 30.060] (–) PCI:*(0:6:0:0) 10de:1380:1462:8a9b rev 162, Mem @ 0xfa000000/16777216, 0xd0000000/268435456, 0xce000000/33554432, I/O @ 0x0000ec00/128, BIOS @ 0x???/524288
[ 30.060] (II) Open ACPI successful (/var/run/acpid.socket)
[ 30.060] Initializing built-in extension Generic Event Extension
[ 30.060] Initializing built-in extension SHAPE
[ 30.060] Initializing built-in extension MIT-SHM
[ 30.060] Initializing built-in extension XInputExtension
[ 30.060] Initializing built-in extension XTEST
[ 30.060] Initializing built-in extension BIG-REQUESTS
[ 30.060] Initializing built-in extension SYNC
[ 30.060] Initializing built-in extension XKEYBOARD
[ 30.060] Initializing built-in extension XC-MISC
[ 30.060] Initializing built-in extension SECURITY
[ 30.060] Initializing built-in extension XINERAMA
[ 30.060] Initializing built-in extension XFIXES
[ 30.060] Initializing built-in extension RENDER
[ 30.060] Initializing built-in extension RANDR
[ 30.060] Initializing built-in extension COMPOSITE
[ 30.060] Initializing built-in extension DAMAGE
[ 30.060] Initializing built-in extension MIT-SCREEN-SAVER
[ 30.060] Initializing built-in extension DOUBLE-BUFFER
[ 30.060] Initializing built-in extension RECORD
[ 30.060] Initializing built-in extension DPMS
[ 30.060] Initializing built-in extension X-Resource
[ 30.060] Initializing built-in extension XVideo
[ 30.060] Initializing built-in extension XVideo-MotionCompensation
[ 30.060] Initializing built-in extension SELinux
[ 30.060] Initializing built-in extension XFree86-VidModeExtension
[ 30.060] Initializing built-in extension XFree86-DGA
[ 30.060] Initializing built-in extension XFree86-DRI
[ 30.060] Initializing built-in extension DRI2
[ 30.060] (II) “glx” will be loaded by default.
[ 30.060] (WW) “xmir” is not to be loaded by default. Skipping.
[ 30.060] (II) LoadModule: “dri2”
[ 30.060] (II) Module “dri2” already built-in
[ 30.060] (II) LoadModule: “glamoregl”
[ 30.186] (II) Loading /usr/lib/xorg/modules/libglamoregl.so
[ 31.467] (II) Module glamoregl: vendor=“X.Org Foundation”
[ 31.467] compiled for 1.14.3, module version = 0.5.1
[ 31.467] ABI class: X.Org ANSI C Emulation, version 0.4
[ 31.467] (II) LoadModule: “glx”
[ 31.467] (II) Loading /usr/lib/x86_64-linux-gnu/xorg/extra-modules/libglx.so
[ 31.596] (II) Module glx: vendor=“NVIDIA Corporation”
[ 31.596] compiled for 4.0.2, module version = 1.0.0
[ 31.596] Module class: X.Org Server Extension
[ 31.596] (II) NVIDIA GLX Module 304.116 Mon Oct 28 20:59:08 PDT 2013
[ 31.596] Loading extension GLX
[ 31.596] (==) Matched nvidia as autoconfigured driver 0
[ 31.596] (==) Matched nouveau as autoconfigured driver 1
[ 31.596] (==) Matched vesa as autoconfigured driver 2
[ 31.596] (==) Matched modesetting as autoconfigured driver 3
[ 31.596] (==) Matched fbdev as autoconfigured driver 4
[ 31.596] (==) Assigned the driver to the xf86ConfigLayout
[ 31.596] (II) LoadModule: “nvidia”
[ 31.596] (II) Loading /usr/lib/x86_64-linux-gnu/xorg/extra-modules/nvidia_drv.so
[ 31.652] (II) Module nvidia: vendor=“NVIDIA Corporation”
[ 31.652] compiled for 4.0.2, module version = 1.0.0
[ 31.652] Module class: X.Org Video Driver
[ 31.690] (EE) NVIDIA: Failed to load the NVIDIA kernel module. Please check your
[ 31.690] (EE) NVIDIA: system’s kernel log for additional error messages.
[ 31.690] (II) UnloadModule: “nvidia”
[ 31.690] (II) Unloading nvidia
[ 31.690] (EE) Failed to load module “nvidia” (module-specific error, 0)
[ 31.690] (II) LoadModule: “nouveau”
[ 31.690] (II) Loading /usr/lib/xorg/modules/drivers/nouveau_drv.so
[ 31.691] (II) Module nouveau: vendor=“X.Org Foundation”
[ 31.691] compiled for 1.14.2.901, module version = 1.0.9
[ 31.691] Module class: X.Org Video Driver
[ 31.691] ABI class: X.Org Video Driver, version 14.1
[ 31.691] (II) LoadModule: “vesa”
[ 31.692] (II) Loading /usr/lib/xorg/modules/drivers/vesa_drv.so
[ 31.692] (II) Module vesa: vendor=“X.Org Foundation”
[ 31.692] compiled for 1.14.1, module version = 2.3.2
[ 31.692] Module class: X.Org Video Driver
[ 31.692] ABI class: X.Org Video Driver, version 14.1
[ 31.692] (II) LoadModule: “modesetting”
[ 31.692] (II) Loading /usr/lib/xorg/modules/drivers/modesetting_drv.so
[ 31.693] (II) Module modesetting: vendor=“X.Org Foundation”
[ 31.693] compiled for 1.14.1, module version = 0.8.0
[ 31.693] Module class: X.Org Video Driver
[ 31.693] ABI class: X.Org Video Driver, version 14.1
[ 31.693] (II) LoadModule: “fbdev”
[ 31.693] (II) Loading /usr/lib/xorg/modules/drivers/fbdev_drv.so
[ 31.694] (II) Module fbdev: vendor=“X.Org Foundation”
[ 31.694] compiled for 1.14.1, module version = 0.4.3
[ 31.694] Module class: X.Org Video Driver
[ 31.694] ABI class: X.Org Video Driver, version 14.1
[ 31.694] (==) Matched nvidia as autoconfigured driver 0
[ 31.694] (==) Matched nouveau as autoconfigured driver 1
[ 31.694] (==) Matched vesa as autoconfigured driver 2
[ 31.694] (==) Matched modesetting as autoconfigured driver 3
[ 31.694] (==) Matched fbdev as autoconfigured driver 4
[ 31.694] (==) Assigned the driver to the xf86ConfigLayout
[ 31.694] (II) LoadModule: “nvidia”
[ 31.694] (II) Loading /usr/lib/x86_64-linux-gnu/xorg/extra-modules/nvidia_drv.so
[ 31.697] (II) Module nvidia: vendor=“NVIDIA Corporation”
[ 31.697] compiled for 4.0.2, module version = 1.0.0
[ 31.697] Module class: X.Org Video Driver
[ 31.730] (EE) NVIDIA: Failed to load the NVIDIA kernel module. Please check your
[ 31.730] (EE) NVIDIA: system’s kernel log for additional error messages.
[ 31.730] (II) UnloadModule: “nvidia”
[ 31.730] (II) Unloading nvidia
[ 31.730] (EE) Failed to load module “nvidia” (module-specific error, 0)
[ 31.730] (II) LoadModule: “nouveau”
[ 31.730] (II) Loading /usr/lib/xorg/modules/drivers/nouveau_drv.so
[ 31.730] (II) Module nouveau: vendor=“X.Org Foundation”
[ 31.730] compiled for 1.14.2.901, module version = 1.0.9
[ 31.730] Module class: X.Org Video Driver
[ 31.730] ABI class: X.Org Video Driver, version 14.1
[ 31.730] (II) UnloadModule: “nouveau”
[ 31.730] (II) Unloading nouveau
[ 31.730] (II) Failed to load module “nouveau” (already loaded, 0)
[ 31.730] (II) LoadModule: “vesa”
[ 31.731] (II) Loading /usr/lib/xorg/modules/drivers/vesa_drv.so
[ 31.731] (II) Module vesa: vendor=“X.Org Foundation”
[ 31.731] compiled for 1.14.1, module version = 2.3.2
[ 31.731] Module class: X.Org Video Driver
[ 31.731] ABI class: X.Org Video Driver, version 14.1
[ 31.731] (II) UnloadModule: “vesa”
[ 31.731] (II) Unloading vesa
[ 31.731] (II) Failed to load module “vesa” (already loaded, 0)
[ 31.731] (II) LoadModule: “modesetting”
[ 31.731] (II) Loading /usr/lib/xorg/modules/drivers/modesetting_drv.so
[ 31.731] (II) Module modesetting: vendor=“X.Org Foundation”
[ 31.731] compiled for 1.14.1, module version = 0.8.0
[ 31.731] (II) UnloadModule: “modesetting”
[ 31.731] (II) Unloading modesetting
[ 31.731] (II) Failed to load module “modesetting” (already loaded, 0)
[ 31.731] (II) LoadModule: “fbdev”
[ 31.731] (II) Loading /usr/lib/xorg/modules/drivers/fbdev_drv.so
[ 31.731] (II) Module fbdev: vendor=“X.Org Foundation”
[ 31.731] compiled for 1.14.1, module version = 0.4.3
[ 31.731] (II) UnloadModule: “fbdev”
[ 31.731] (II) Unloading fbdev
[ 31.731] (II) Failed to load module “fbdev” (already loaded, 0)
[ 31.731] (II) NOUVEAU driver Date: Wed Jul 31 10:51:03 2013 +1000
[ 31.731] (II) NOUVEAU driver for NVIDIA chipset families :
[ 31.731] RIVA TNT (NV04)
[ 31.731] RIVA TNT2 (NV05)
[ 31.731] GeForce 256 (NV10)
[ 31.731] GeForce 2 (NV11, NV15)
[ 31.731] GeForce 4MX (NV17, NV18)
[ 31.731] GeForce 3 (NV20)
[ 31.731] GeForce 4Ti (NV25, NV28)
[ 31.731] GeForce FX (NV3x)
[ 31.731] GeForce 6 (NV4x)
[ 31.731] GeForce 7 (G7x)
[ 31.731] GeForce 8 (G8x)
[ 31.731] GeForce GTX 200 (NVA0)
[ 31.731] GeForce GTX 400 (NVC0)
[ 31.731] (II) VESA: driver for VESA chipsets: vesa
[ 31.731] (II) modesetting: Driver for Modesetting Kernel Drivers: kms
[ 31.731] (II) FBDEV: driver for framebuffer: fbdev
[ 31.731] (++) using VT number 7
[ 31.732] (EE) [drm] KMS not enabled
[ 31.732] (WW) Falling back to old probe method for modesetting
[ 31.732] (EE) open /dev/dri/card0: No such file or directory
[ 31.732] (WW) Falling back to old probe method for fbdev
[ 31.732] (II) Loading sub module “fbdevhw”
[ 31.732] (II) LoadModule: “fbdevhw”
[ 31.733] (II) Loading /usr/lib/xorg/modules/libfbdevhw.so
[ 31.733] (II) Module fbdevhw: vendor=“X.Org Foundation”
[ 31.733] compiled for 1.14.5, module version = 0.0.2
[ 31.733] ABI class: X.Org Video Driver, version 14.1
[ 31.733] (EE) open /dev/fb0: No such file or directory
[ 31.733] (II) Loading sub module “vbe”
[ 31.733] (II) LoadModule: “vbe”
[ 31.734] (II) Loading /usr/lib/xorg/modules/libvbe.so
[ 31.743] (II) Module vbe: vendor=“X.Org Foundation”
[ 31.743] compiled for 1.14.5, module version = 1.1.0
[ 31.743] ABI class: X.Org Video Driver, version 14.1
[ 31.743] (II) Loading sub module “int10”
[ 31.743] (II) LoadModule: “int10”
[ 31.744] (II) Loading /usr/lib/xorg/modules/libint10.so
[ 31.757] (II) Module int10: vendor=“X.Org Foundation”
[ 31.757] compiled for 1.14.5, module version = 1.0.0
[ 31.757] ABI class: X.Org Video Driver, version 14.1
[ 31.757] (II) VESA(0): initializing int10
[ 31.762] (II) VESA(0): Primary V_BIOS segment is: 0xc000
[ 31.945] (II) VESA(0): VESA BIOS detected
[ 31.945] (II) VESA(0): VESA VBE Version 3.0
[ 31.945] (II) VESA(0): VESA VBE Total Mem: 14336 kB
[ 31.945] (II) VESA(0): VESA VBE OEM: NVIDIA
[ 31.945] (II) VESA(0): VESA VBE OEM Software Rev: 130.7
[ 31.945] (II) VESA(0): VESA VBE OEM Vendor: NVIDIA Corporation
[ 31.945] (II) VESA(0): VESA VBE OEM Product: GM107 Board - 20100050
[ 31.945] (II) VESA(0): VESA VBE OEM Product Rev: Chip Rev
[ 32.274] (II) VESA(0): Creating default Display subsection in Screen section
“Default Screen Section” for depth/fbbpp 24/32
[ 32.274] (==) VESA(0): Depth 24, (–) framebuffer bpp 32
[ 32.274] (==) VESA(0): RGB weight 888
[ 32.274] (==) VESA(0): Default visual is TrueColor
[ 32.274] (==) VESA(0): Using gamma correction (1.0, 1.0, 1.0)
[ 32.274] (II) Loading sub module “ddc”
[ 32.274] (II) LoadModule: “ddc”
[ 32.274] (II) Module “ddc” already built-in
[ 32.276] (II) VESA(0): VESA VBE DDC supported
[ 32.276] (II) VESA(0): VESA VBE DDC Level 2
[ 32.276] (II) VESA(0): VESA VBE DDC transfer in appr. 1 sec.
[ 32.337] (II) VESA(0): VESA VBE DDC read successfully
[ 32.337] (II) VESA(0): Manufacturer: GWY Model: b90b Serial#: 521
[ 32.337] (II) VESA(0): Year: 2008 Week: 12
[ 32.337] (II) VESA(0): EDID Version: 1.3
[ 32.337] (II) VESA(0): Digital Display Input
[ 32.337] (II) VESA(0): DFP 1.x compatible TMDS
[ 32.337] (II) VESA(0): Max Image Size [cm]: horiz.: 64 vert.: 40
[ 32.337] (II) VESA(0): Gamma: 1.00
[ 32.337] (II) VESA(0): DPMS capabilities: StandBy Suspend Off
[ 32.337] (II) VESA(0): Supported color encodings: RGB 4:4:4 YCrCb 4:4:4
[ 32.337] (II) VESA(0): Default color space is primary color space
[ 32.337] (II) VESA(0): First detailed timing is preferred mode
[ 32.337] (II) VESA(0): redX: 0.640 redY: 0.330 greenX: 0.300 greenY: 0.600
[ 32.337] (II) VESA(0): blueX: 0.150 blueY: 0.600 whiteX: 0.313 whiteY: 0.329
[ 32.337] (II) VESA(0): Supported established timings:
[ 32.337] (II) VESA(0): 640x480@60Hz
[ 32.337] (II) VESA(0): 800x600@60Hz
[ 32.337] (II) VESA(0): 1024x768@60Hz
[ 32.337] (II) VESA(0): Manufacturer’s mask: 0
[ 32.337] (II) VESA(0): Supported standard timings:
[ 32.337] (II) VESA(0): #0: hsize: 1920 vsize 1440 refresh: 60 vid: 16593
[ 32.337] (II) VESA(0): #1: hsize: 1856 vsize 1392 refresh: 60 vid: 16585
[ 32.337] (II) VESA(0): #2: hsize: 1792 vsize 1344 refresh: 60 vid: 16577
[ 32.337] (II) VESA(0): #3: hsize: 1600 vsize 1200 refresh: 60 vid: 16553
[ 32.337] (II) VESA(0): #4: hsize: 1400 vsize 1050 refresh: 60 vid: 16528
[ 32.337] (II) VESA(0): #5: hsize: 1280 vsize 960 refresh: 60 vid: 16513
[ 32.337] (II) VESA(0): #6: hsize: 1280 vsize 1024 refresh: 60 vid: 32897
[ 32.337] (II) VESA(0): #7: hsize: 1152 vsize 864 refresh: 60 vid: 16497
[ 32.337] (II) VESA(0): Supported detailed timing:
[ 32.337] (II) VESA(0): clock: 83.5 MHz Image Size: 640 x 400 mm
[ 32.337] (II) VESA(0): h_active: 1280 h_sync: 1352 h_sync_end 1480 h_blank_end 1680 h_border: 0
[ 32.337] (II) VESA(0): v_active: 800 v_sync: 803 v_sync_end 809 v_blanking: 831 v_border: 0
[ 32.337] (II) VESA(0): clock: 268.5 MHz Image Size: 640 x 400 mm
[ 32.337] (II) VESA(0): h_active: 2560 h_sync: 2608 h_sync_end 2640 h_blank_end 2720 h_border: 0
[ 32.337] (II) VESA(0): v_active: 1600 v_sync: 1603 v_sync_end 1609 v_blanking: 1646 v_border: 0
[ 32.337] (II) VESA(0): Monitor name: XHD3000
[ 32.337] (II) VESA(0): Ranges: V min: 59 V max: 61 Hz, H min: 30 H max: 110 kHz, PixClock max 275 MHz
[ 32.337] (II) VESA(0): Number of EDID sections to follow: 1
[ 32.337] (II) VESA(0): EDID (in hex):
[ 32.337] (II) VESA(0): 00ffffffffffff001ef90bb909020000
[ 32.337] (II) VESA(0): 0c12010381402800eeeea5a3544c9926
[ 32.337] (II) VESA(0): 995054210800d140c940c140a9409040
[ 32.337] (II) VESA(0): 8140818071409e20009051201f304880
[ 32.337] (II) VESA(0): 360080902100001ce26800a0a0402e60
[ 32.337] (II) VESA(0): 3020360080902100001a000000fc0058
[ 32.337] (II) VESA(0): 4844333030300a2020202020000000fd
[ 32.337] (II) VESA(0): 003b3d1e6e1b000a202020202020012f
[ 32.337] (II) VESA(0): EDID vendor “GWY”, prod id 47371
[ 32.337] (II) VESA(0): Using EDID range info for horizontal sync
[ 32.337] (II) VESA(0): Using EDID range info for vertical refresh
[ 32.337] (II) VESA(0): Printing DDC gathered Modelines:
[ 32.337] (II) VESA(0): Modeline "1280x800"x0.0 83.50 1280 1352 1480 1680 800 803 809 831 -hsync +vsync (49.7 kHz eP)
[ 32.337] (II) VESA(0): Modeline "2560x1600"x0.0 268.50 2560 2608 2640 2720 1600 1603 1609 1646 +hsync -vsync (98.7 kHz e)
[ 32.337] (II) VESA(0): Modeline "800x600"x0.0 40.00 800 840 968 1056 600 601 605 628 +hsync +vsync (37.9 kHz e)
[ 32.337] (II) VESA(0): Modeline "640x480"x0.0 25.18 640 656 752 800 480 490 492 525 -hsync -vsync (31.5 kHz e)
[ 32.337] (II) VESA(0): Modeline "1024x768"x0.0 65.00 1024 1048 1184 1344 768 771 777 806 -hsync -vsync (48.4 kHz e)
[ 32.337] (II) VESA(0): Modeline "1920x1440"x0.0 234.00 1920 2048 2256 2600 1440 1441 1444 1500 -hsync +vsync (90.0 kHz e)
[ 32.337] (II) VESA(0): Modeline "1856x1392"x0.0 218.25 1856 1952 2176 2528 1392 1393 1396 1439 -hsync +vsync (86.3 kHz e)
[ 32.337] (II) VESA(0): Modeline "1792x1344"x0.0 204.75 1792 1920 2120 2448 1344 1345 1348 1394 -hsync +vsync (83.6 kHz e)
[ 32.337] (II) VESA(0): Modeline "1600x1200"x0.0 162.00 1600 1664 1856 2160 1200 1201 1204 1250 +hsync +vsync (75.0 kHz e)
[ 32.337] (II) VESA(0): Modeline "1400x1050"x0.0 101.00 1400 1448 1480 1560 1050 1053 1057 1080 +hsync -vsync (64.7 kHz e)
[ 32.337] (II) VESA(0): Modeline "1280x960"x0.0 108.00 1280 1376 1488 1800 960 961 964 1000 +hsync +vsync (60.0 kHz e)
[ 32.337] (II) VESA(0): Modeline "1280x1024"x0.0 108.00 1280 1328 1440 1688 1024 1025 1028 1066 +hsync +vsync (64.0 kHz e)
[ 32.337] (II) VESA(0): Modeline "1152x864"x60.0 81.62 1152 1216 1336 1520 864 865 868 895 -hsync +vsync (53.7 kHz e)
[ 32.337] (II) VESA(0): Searching for matching VESA mode(s):
[ 32.342] Mode: 100 (640x400)
[ 32.342] ModeAttributes: 0x3bf
[ 32.342] WinAAttributes: 0x7
[ 32.342] WinBAttributes: 0x0
[ 32.342] WinGranularity: 64
[ 32.342] WinSize: 64
[ 32.342] WinASegment: 0xa000
[ 32.342] WinBSegment: 0x0
[ 32.342] WinFuncPtr: 0xc000808e
[ 32.342] BytesPerScanline: 640
[ 32.342] XResolution: 640
[ 32.342] YResolution: 400
[ 32.342] XCharSize: 8
[ 32.342] YCharSize: 16
[ 32.342] NumberOfPlanes: 1
[ 32.342] BitsPerPixel: 8
[ 32.342] NumberOfBanks: 1
[ 32.342] MemoryModel: 4
[ 32.342] BankSize: 0
[ 32.342] NumberOfImages: 14
[ 32.342] RedMaskSize: 0
[ 32.342] RedFieldPosition: 0
[ 32.342] GreenMaskSize: 0
[ 32.342] GreenFieldPosition: 0
[ 32.342] BlueMaskSize: 0
[ 32.342] BlueFieldPosition: 0
[ 32.342] RsvdMaskSize: 0
[ 32.342] RsvdFieldPosition: 0
[ 32.342] DirectColorModeInfo: 0
[ 32.342] PhysBasePtr: 0xcf000000
[ 32.342] LinBytesPerScanLine: 640
[ 32.342] BnkNumberOfImagePages: 14
[ 32.342] LinNumberOfImagePages: 14
[ 32.342] LinRedMaskSize: 0
[ 32.342] LinRedFieldPosition: 0
[ 32.342] LinGreenMaskSize: 0
[ 32.342] LinGreenFieldPosition: 0
[ 32.342] LinBlueMaskSize: 0
[ 32.342] LinBlueFieldPosition: 0
[ 32.342] LinRsvdMaskSize: 0
[ 32.342] LinRsvdFieldPosition: 0
[ 32.342] MaxPixelClock: 229500000
[ 32.348] Mode: 101 (640x480)
[ 32.348] ModeAttributes: 0x3bf
[ 32.348] WinAAttributes: 0x7
[ 32.348] WinBAttributes: 0x0
[ 32.348] WinGranularity: 64
[ 32.348] WinSize: 64
[ 32.348] WinASegment: 0xa000
[ 32.348] WinBSegment: 0x0
[ 32.348] WinFuncPtr: 0xc000808e
[ 32.348] BytesPerScanline: 640
[ 32.348] XResolution: 640
[ 32.348] YResolution: 480
[ 32.348] XCharSize: 8
[ 32.348] YCharSize: 16
[ 32.348] NumberOfPlanes: 1
[ 32.348] BitsPerPixel: 8
[ 32.348] NumberOfBanks: 1
[ 32.348] MemoryModel: 4
[ 32.348] BankSize: 0
[ 32.348] NumberOfImages: 10
[ 32.348] RedMaskSize: 0
[ 32.348] RedFieldPosition: 0
[ 32.348] GreenMaskSize: 0
[ 32.348] GreenFieldPosition: 0
[ 32.348] BlueMaskSize: 0
[ 32.348] BlueFieldPosition: 0
[ 32.348] RsvdMaskSize: 0
[ 32.348] RsvdFieldPosition: 0
[ 32.348] DirectColorModeInfo: 0
[ 32.348] PhysBasePtr: 0xcf000000
[ 32.348] LinBytesPerScanLine: 640
[ 32.348] BnkNumberOfImagePages: 10
[ 32.348] LinNumberOfImagePages: 10
[ 32.348] LinRedMaskSize: 0
[ 32.348] LinRedFieldPosition: 0
[ 32.348] LinGreenMaskSize: 0
[ 32.348] LinGreenFieldPosition: 0
[ 32.348] LinBlueMaskSize: 0
[ 32.348] LinBlueFieldPosition: 0
[ 32.348] LinRsvdMaskSize: 0
[ 32.348] LinRsvdFieldPosition: 0
[ 32.348] MaxPixelClock: 229500000
[ 32.353] Mode: 102 (800x600)
[ 32.353] ModeAttributes: 0x33f
[ 32.353] WinAAttributes: 0x7
[ 32.353] WinBAttributes: 0x0
[ 32.353] WinGranularity: 64
[ 32.353] WinSize: 64
[ 32.353] WinASegment: 0xa000
[ 32.353] WinBSegment: 0x0
[ 32.353] WinFuncPtr: 0xc000808e
[ 32.353] BytesPerScanline: 100
[ 32.353] XResolution: 800
[ 32.353] YResolution: 600
[ 32.353] XCharSize: 8
[ 32.353] YCharSize: 16
[ 32.353] NumberOfPlanes: 4
[ 32.353] BitsPerPixel: 4
[ 32.353] NumberOfBanks: 1
[ 32.353] MemoryModel: 3
[ 32.353] BankSize: 0
[ 32.353] NumberOfImages: 2
[ 32.353] RedMaskSize: 0
[ 32.353] RedFieldPosition: 0
[ 32.353] GreenMaskSize: 0
[ 32.353] GreenFieldPosition: 0
[ 32.353] BlueMaskSize: 0
[ 32.353] BlueFieldPosition: 0
[ 32.353] RsvdMaskSize: 0
[ 32.353] RsvdFieldPosition: 0
[ 32.353] DirectColorModeInfo: 0
[ 32.353] PhysBasePtr: 0x0
[ 32.353] LinBytesPerScanLine: 100
[ 32.353] BnkNumberOfImagePages: 2
[ 32.353] LinNumberOfImagePages: 2
[ 32.353] LinRedMaskSize: 0
[ 32.353] LinRedFieldPosition: 0
[ 32.353] LinGreenMaskSize: 0
[ 32.353] LinGreenFieldPosition: 0
[ 32.353] LinBlueMaskSize: 0
[ 32.353] LinBlueFieldPosition: 0
[ 32.353] LinRsvdMaskSize: 0
[ 32.353] LinRsvdFieldPosition: 0
[ 32.353] MaxPixelClock: 108500000
[ 32.358] Mode: 103 (800x600)
[ 32.358] ModeAttributes: 0x3bf
[ 32.358] WinAAttributes: 0x7
[ 32.358] WinBAttributes: 0x0
[ 32.358] WinGranularity: 64
[ 32.358] WinSize: 64
[ 32.358] WinASegment: 0xa000
[ 32.358] WinBSegment: 0x0
[ 32.358] WinFuncPtr: 0xc000808e
[ 32.358] BytesPerScanline: 800
[ 32.358] XResolution: 800
[ 32.358] YResolution: 600
[ 32.358] XCharSize: 8
[ 32.358] YCharSize: 16
[ 32.358] NumberOfPlanes: 1
[ 32.358] BitsPerPixel: 8
[ 32.358] NumberOfBanks: 1
[ 32.358] MemoryModel: 4
[ 32.358] BankSize: 0
[ 32.358] NumberOfImages: 6
[ 32.358] RedMaskSize: 0
[ 32.358] RedFieldPosition: 0
[ 32.358] GreenMaskSize: 0
[ 32.358] GreenFieldPosition: 0
[ 32.358] BlueMaskSize: 0
[ 32.358] BlueFieldPosition: 0
[ 32.358] RsvdMaskSize: 0
[ 32.358] RsvdFieldPosition: 0
[ 32.358] DirectColorModeInfo: 0
[ 32.358] PhysBasePtr: 0xcf000000
[ 32.358] LinBytesPerScanLine: 800
[ 32.359] BnkNumberOfImagePages: 6
[ 32.359] LinNumberOfImagePages: 6
[ 32.359] LinRedMaskSize: 0
[ 32.359] LinRedFieldPosition: 0
[ 32.359] LinGreenMaskSize: 0
[ 32.359] LinGreenFieldPosition: 0
[ 32.359] LinBlueMaskSize: 0
[ 32.359] LinBlueFieldPosition: 0
[ 32.359] LinRsvdMaskSize: 0
[ 32.359] LinRsvdFieldPosition: 0
[ 32.359] MaxPixelClock: 229500000
[ 32.364] Mode: 104 (1024x768)
[ 32.364] ModeAttributes: 0x33f
[ 32.364] WinAAttributes: 0x7
[ 32.364] WinBAttributes: 0x0
[ 32.364] WinGranularity: 64
[ 32.364] WinSize: 64
[ 32.364] WinASegment: 0xa000
[ 32.364] WinBSegment: 0x0
[ 32.364] WinFuncPtr: 0xc000808e
[ 32.364] BytesPerScanline: 128
[ 32.364] XResolution: 1024
[ 32.364] YResolution: 768
[ 32.364] XCharSize: 8
[ 32.364] YCharSize: 16
[ 32.364] NumberOfPlanes: 4
[ 32.364] BitsPerPixel: 4
[ 32.364] NumberOfBanks: 1
[ 32.364] MemoryModel: 3
[ 32.364] BankSize: 0
[ 32.364] NumberOfImages: 1
[ 32.364] RedMaskSize: 0
[ 32.364] RedFieldPosition: 0
[ 32.364] GreenMaskSize: 0
[ 32.364] GreenFieldPosition: 0
[ 32.364] BlueMaskSize: 0
[ 32.364] BlueFieldPosition: 0
[ 32.364] RsvdMaskSize: 0
[ 32.364] RsvdFieldPosition: 0
[ 32.364] DirectColorModeInfo: 0
[ 32.364] PhysBasePtr: 0x0
[ 32.364] LinBytesPerScanLine: 128
[ 32.364] BnkNumberOfImagePages: 1
[ 32.364] LinNumberOfImagePages: 1
[ 32.364] LinRedMaskSize: 0
[ 32.364] LinRedFieldPosition: 0
[ 32.364] LinGreenMaskSize: 0
[ 32.364] LinGreenFieldPosition: 0
[ 32.364] LinBlueMaskSize: 0
[ 32.364] LinBlueFieldPosition: 0
[ 32.364] LinRsvdMaskSize: 0
[ 32.364] LinRsvdFieldPosition: 0
[ 32.364] MaxPixelClock: 108500000
[ 32.369] Mode: 105 (1024x768)
[ 32.369] ModeAttributes: 0x3bf
[ 32.369] WinAAttributes: 0x7
[ 32.369] WinBAttributes: 0x0
[ 32.369] WinGranularity: 64
[ 32.369] WinSize: 64
[ 32.369] WinASegment: 0xa000
[ 32.369] WinBSegment: 0x0
[ 32.369] WinFuncPtr: 0xc000808e
[ 32.369] BytesPerScanline: 1024
[ 32.369] XResolution: 1024
[ 32.369] YResolution: 768
[ 32.369] XCharSize: 8
[ 32.369] YCharSize: 16
[ 32.369] NumberOfPlanes: 1
[ 32.369] BitsPerPixel: 8
[ 32.369] NumberOfBanks: 1
[ 32.369] MemoryModel: 4
[ 32.369] BankSize: 0
[ 32.369] NumberOfImages: 3
[ 32.369] RedMaskSize: 0
[ 32.369] RedFieldPosition: 0
[ 32.369] GreenMaskSize: 0
[ 32.369] GreenFieldPosition: 0
[ 32.369] BlueMaskSize: 0
[ 32.369] BlueFieldPosition: 0
[ 32.369] RsvdMaskSize: 0
[ 32.369] RsvdFieldPosition: 0
[ 32.369] DirectColorModeInfo: 0
[ 32.369] PhysBasePtr: 0xcf000000
[ 32.369] LinBytesPerScanLine: 1024
[ 32.369] BnkNumberOfImagePages: 3
[ 32.369] LinNumberOfImagePages: 3
[ 32.369] LinRedMaskSize: 0
[ 32.369] LinRedFieldPosition: 0
[ 32.369] LinGreenMaskSize: 0
[ 32.369] LinGreenFieldPosition: 0
[ 32.369] LinBlueMaskSize: 0
[ 32.369] LinBlueFieldPosition: 0
[ 32.369] LinRsvdMaskSize: 0
[ 32.369] LinRsvdFieldPosition: 0
[ 32.369] MaxPixelClock: 229500000
[ 32.375] Mode: 10e (320x200)
[ 32.375] ModeAttributes: 0x3bf
[ 32.375] WinAAttributes: 0x7
[ 32.375] WinBAttributes: 0x0
[ 32.375] WinGranularity: 64
[ 32.375] WinSize: 64
[ 32.375] WinASegment: 0xa000
[ 32.375] WinBSegment: 0x0
[ 32.375] WinFuncPtr: 0xc000808e
[ 32.375] BytesPerScanline: 640
[ 32.375] XResolution: 320
[ 32.375] YResolution: 200
[ 32.375] XCharSize: 8
[ 32.375] YCharSize: 8
[ 32.375] NumberOfPlanes: 1
[ 32.375] BitsPerPixel: 16
[ 32.375] NumberOfBanks: 1
[ 32.375] MemoryModel: 6
[ 32.375] BankSize: 0
[ 32.375] NumberOfImages: 30
[ 32.375] RedMaskSize: 5
[ 32.375] RedFieldPosition: 11
[ 32.375] GreenMaskSize: 6
[ 32.375] GreenFieldPosition: 5
[ 32.375] BlueMaskSize: 5
[ 32.375] BlueFieldPosition: 0
[ 32.375] RsvdMaskSize: 0
[ 32.375] RsvdFieldPosition: 0
[ 32.375] DirectColorModeInfo: 0
[ 32.375] PhysBasePtr: 0xcf000000
[ 32.375] LinBytesPerScanLine: 640
[ 32.375] BnkNumberOfImagePages: 30
[ 32.375] LinNumberOfImagePages: 30
[ 32.375] LinRedMaskSize: 5
[ 32.375] LinRedFieldPosition: 11
[ 32.375] LinGreenMaskSize: 6
[ 32.375] LinGreenFieldPosition: 5
[ 32.375] LinBlueMaskSize: 5
[ 32.375] LinBlueFieldPosition: 0
[ 32.375] LinRsvdMaskSize: 0
[ 32.375] LinRsvdFieldPosition: 0
[ 32.375] MaxPixelClock: 229500000
[ 32.380] *Mode: 10f (320x200)
[ 32.380] ModeAttributes: 0x3bf
[ 32.380] WinAAttributes: 0x7
[ 32.380] WinBAttributes: 0x0
[ 32.380] WinGranularity: 64
[ 32.380] WinSize: 64
[ 32.380] WinASegment: 0xa000
[ 32.380] WinBSegment: 0x0
[ 32.380] WinFuncPtr: 0xc000808e
[ 32.380] BytesPerScanline: 1280
[ 32.380] XResolution: 320
[ 32.380] YResolution: 200
[ 32.380] XCharSize: 8
[ 32.380] YCharSize: 8
[ 32.380] NumberOfPlanes: 1
[ 32.380] BitsPerPixel: 32
[ 32.380] NumberOfBanks: 1
[ 32.380] MemoryModel: 6
[ 32.380] BankSize: 0
[ 32.380] NumberOfImages: 14
[ 32.380] RedMaskSize: 8
[ 32.380] RedFieldPosition: 16
[ 32.380] GreenMaskSize: 8
[ 32.380] GreenFieldPosition: 8
[ 32.380] BlueMaskSize: 8
[ 32.380] BlueFieldPosition: 0
[ 32.380] RsvdMaskSize: 8
[ 32.380] RsvdFieldPosition: 24
[ 32.380] DirectColorModeInfo: 0
[ 32.380] PhysBasePtr: 0xcf000000
[ 32.380] LinBytesPerScanLine: 1280
[ 32.380] BnkNumberOfImagePages: 14
[ 32.380] LinNumberOfImagePages: 14
[ 32.380] LinRedMaskSize: 8
[ 32.380] LinRedFieldPosition: 16
[ 32.380] LinGreenMaskSize: 8
[ 32.380] LinGreenFieldPosition: 8
[ 32.380] LinBlueMaskSize: 8
[ 32.380] LinBlueFieldPosition: 0
[ 32.380] LinRsvdMaskSize: 8
[ 32.380] LinRsvdFieldPosition: 24
[ 32.380] MaxPixelClock: 229500000
[ 32.385] Mode: 111 (640x480)
[ 32.385] ModeAttributes: 0x3bf
[ 32.385] WinAAttributes: 0x7
[ 32.385] WinBAttributes: 0x0
[ 32.385] WinGranularity: 64
[ 32.385] WinSize: 64
[ 32.385] WinASegment: 0xa000
[ 32.385] WinBSegment: 0x0
[ 32.385] WinFuncPtr: 0xc000808e
[ 32.385] BytesPerScanline: 1280
[ 32.385] XResolution: 640
[ 32.385] YResolution: 480
[ 32.385] XCharSize: 8
[ 32.385] YCharSize: 16
[ 32.385] NumberOfPlanes: 1
[ 32.385] BitsPerPixel: 16
[ 32.385] NumberOfBanks: 1
[ 32.385] MemoryModel: 6
[ 32.385] BankSize: 0
[ 32.385] NumberOfImages: 4
[ 32.385] RedMaskSize: 5
[ 32.385] RedFieldPosition: 11
[ 32.385] GreenMaskSize: 6
[ 32.385] GreenFieldPosition: 5
[ 32.385] BlueMaskSize: 5
[ 32.385] BlueFieldPosition: 0
[ 32.385] RsvdMaskSize: 0
[ 32.385] RsvdFieldPosition: 0
[ 32.385] DirectColorModeInfo: 0
[ 32.385] PhysBasePtr: 0xcf000000
[ 32.385] LinBytesPerScanLine: 1280
[ 32.385] BnkNumberOfImagePages: 4
[ 32.385] LinNumberOfImagePages: 4
[ 32.385] LinRedMaskSize: 5
[ 32.385] LinRedFieldPosition: 11
[ 32.385] LinGreenMaskSize: 6
[ 32.385] LinGreenFieldPosition: 5
[ 32.385] LinBlueMaskSize: 5
[ 32.385] LinBlueFieldPosition: 0
[ 32.385] LinRsvdMaskSize: 0
[ 32.385] LinRsvdFieldPosition: 0
[ 32.385] MaxPixelClock: 229500000
[ 32.390] *Mode: 112 (640x480)
[ 32.390] ModeAttributes: 0x3bf
[ 32.390] WinAAttributes: 0x7
[ 32.390] WinBAttributes: 0x0
[ 32.390] WinGranularity: 64
[ 32.390] WinSize: 64
[ 32.390] WinASegment: 0xa000
[ 32.390] WinBSegment: 0x0
[ 32.390] WinFuncPtr: 0xc000808e
[ 32.390] BytesPerScanline: 2560
[ 32.390] XResolution: 640
[ 32.390] YResolution: 480
[ 32.390] XCharSize: 8
[ 32.390] YCharSize: 16
[ 32.390] NumberOfPlanes: 1
[ 32.390] BitsPerPixel: 32
[ 32.390] NumberOfBanks: 1
[ 32.390] MemoryModel: 6
[ 32.390] BankSize: 0
[ 32.390] NumberOfImages: 1
[ 32.390] RedMaskSize: 8
[ 32.390] RedFieldPosition: 16
[ 32.390] GreenMaskSize: 8
[ 32.390] GreenFieldPosition: 8
[ 32.390] BlueMaskSize: 8
[ 32.390] BlueFieldPosition: 0
[ 32.390] RsvdMaskSize: 8
[ 32.390] RsvdFieldPosition: 24
[ 32.390] DirectColorModeInfo: 0
[ 32.390] PhysBasePtr: 0xcf000000
[ 32.390] LinBytesPerScanLine: 2560
[ 32.390] BnkNumberOfImagePages: 1
[ 32.390] LinNumberOfImagePages: 1
[ 32.390] LinRedMaskSize: 8
[ 32.390] LinRedFieldPosition: 16
[ 32.390] LinGreenMaskSize: 8
[ 32.390] LinGreenFieldPosition: 8
[ 32.390] LinBlueMaskSize: 8
[ 32.390] LinBlueFieldPosition: 0
[ 32.390] LinRsvdMaskSize: 8
[ 32.390] LinRsvdFieldPosition: 24
[ 32.390] MaxPixelClock: 229500000
[ 32.396] Mode: 114 (800x600)
[ 32.396] ModeAttributes: 0x3bf
[ 32.396] WinAAttributes: 0x7
[ 32.396] WinBAttributes: 0x0
[ 32.396] WinGranularity: 64
[ 32.396] WinSize: 64
[ 32.396] WinASegment: 0xa000
[ 32.396] WinBSegment: 0x0
[ 32.396] WinFuncPtr: 0xc000808e
[ 32.396] BytesPerScanline: 1600
[ 32.396] XResolution: 800
[ 32.396] YResolution: 600
[ 32.396] XCharSize: 8
[ 32.396] YCharSize: 16
[ 32.396] NumberOfPlanes: 1
[ 32.396] BitsPerPixel: 16
[ 32.396] NumberOfBanks: 1
[ 32.396] MemoryModel: 6
[ 32.396] BankSize: 0
[ 32.396] NumberOfImages: 2
[ 32.396] RedMaskSize: 5
[ 32.396] RedFieldPosition: 11
[ 32.396] GreenMaskSize: 6
[ 32.396] GreenFieldPosition: 5
[ 32.396] BlueMaskSize: 5
[ 32.396] BlueFieldPosition: 0
[ 32.396] RsvdMaskSize: 0
[ 32.396] RsvdFieldPosition: 0
[ 32.396] DirectColorModeInfo: 0
[ 32.396] PhysBasePtr: 0xcf000000
[ 32.396] LinBytesPerScanLine: 1600
[ 32.396] BnkNumberOfImagePages: 2
[ 32.396] LinNumberOfImagePages: 2
[ 32.396] LinRedMaskSize: 5
[ 32.396] LinRedFieldPosition: 11
[ 32.396] LinGreenMaskSize: 6
[ 32.396] LinGreenFieldPosition: 5
[ 32.396] LinBlueMaskSize: 5
[ 32.396] LinBlueFieldPosition: 0
[ 32.396] LinRsvdMaskSize: 0
[ 32.396] LinRsvdFieldPosition: 0
[ 32.396] MaxPixelClock: 229500000
[ 32.401] *Mode: 115 (800x600)
[ 32.401] ModeAttributes: 0x3bf
[ 32.401] WinAAttributes: 0x7
[ 32.401] WinBAttributes: 0x0
[ 32.401] WinGranularity: 64
[ 32.401] WinSize: 64
[ 32.401] WinASegment: 0xa000
[ 32.401] WinBSegment: 0x0
[ 32.401] WinFuncPtr: 0xc000808e
[ 32.401] BytesPerScanline: 3200
[ 32.401] XResolution: 800
[ 32.401] YResolution: 600
[ 32.401] XCharSize: 8
[ 32.401] YCharSize: 16
[ 32.401] NumberOfPlanes: 1
[ 32.401] BitsPerPixel: 32
[ 32.401] NumberOfBanks: 1
[ 32.401] MemoryModel: 6
[ 32.401] BankSize: 0
[ 32.401] NumberOfImages: 1
[ 32.401] RedMaskSize: 8
[ 32.401] RedFieldPosition: 16
[ 32.401] GreenMaskSize: 8
[ 32.401] GreenFieldPosition: 8
[ 32.401] BlueMaskSize: 8
[ 32.401] BlueFieldPosition: 0
[ 32.401] RsvdMaskSize: 8
[ 32.401] RsvdFieldPosition: 24
[ 32.401] DirectColorModeInfo: 0
[ 32.401] PhysBasePtr: 0xcf000000
[ 32.401] LinBytesPerScanLine: 3200
[ 32.401] BnkNumberOfImagePages: 1
[ 32.401] LinNumberOfImagePages: 1
[ 32.401] LinRedMaskSize: 8
[ 32.401] LinRedFieldPosition: 16
[ 32.401] LinGreenMaskSize: 8
[ 32.401] LinGreenFieldPosition: 8
[ 32.401] LinBlueMaskSize: 8
[ 32.401] LinBlueFieldPosition: 0
[ 32.401] LinRsvdMaskSize: 8
[ 32.401] LinRsvdFieldPosition: 24
[ 32.401] MaxPixelClock: 229500000
[ 32.406] Mode: 117 (1024x768)
[ 32.406] ModeAttributes: 0x3bf
[ 32.406] WinAAttributes: 0x7
[ 32.406] WinBAttributes: 0x0
[ 32.406] WinGranularity: 64
[ 32.406] WinSize: 64
[ 32.406] WinASegment: 0xa000
[ 32.406] WinBSegment: 0x0
[ 32.406] WinFuncPtr: 0xc000808e
[ 32.406] BytesPerScanline: 2048
[ 32.406] XResolution: 1024
[ 32.406] YResolution: 768
[ 32.406] XCharSize: 8
[ 32.406] YCharSize: 16
[ 32.406] NumberOfPlanes: 1
[ 32.406] BitsPerPixel: 16
[ 32.406] NumberOfBanks: 1
[ 32.406] MemoryModel: 6
[ 32.406] BankSize: 0
[ 32.406] NumberOfImages: 1
[ 32.406] RedMaskSize: 5
[ 32.406] RedFieldPosition: 11
[ 32.406] GreenMaskSize: 6
[ 32.406] GreenFieldPosition: 5
[ 32.406] BlueMaskSize: 5
[ 32.406] BlueFieldPosition: 0
[ 32.406] RsvdMaskSize: 0
[ 32.406] RsvdFieldPosition: 0
[ 32.406] DirectColorModeInfo: 0
[ 32.406] PhysBasePtr: 0xcf000000
[ 32.406] LinBytesPerScanLine: 2048
[ 32.406] BnkNumberOfImagePages: 1
[ 32.406] LinNumberOfImagePages: 1
[ 32.406] LinRedMaskSize: 5
[ 32.406] LinRedFieldPosition: 11
[ 32.406] LinGreenMaskSize: 6
[ 32.406] LinGreenFieldPosition: 5
[ 32.406] LinBlueMaskSize: 5
[ 32.406] LinBlueFieldPosition: 0
[ 32.406] LinRsvdMaskSize: 0
[ 32.406] LinRsvdFieldPosition: 0
[ 32.406] MaxPixelClock: 229500000
[ 32.411] *Mode: 118 (1024x768)
[ 32.411] ModeAttributes: 0x3bf
[ 32.411] WinAAttributes: 0x7
[ 32.411] WinBAttributes: 0x0
[ 32.411] WinGranularity: 64
[ 32.411] WinSize: 64
[ 32.411] WinASegment: 0xa000
[ 32.411] WinBSegment: 0x0
[ 32.411] WinFuncPtr: 0xc000808e
[ 32.411] BytesPerScanline: 4096
[ 32.411] XResolution: 1024
[ 32.411] YResolution: 768
[ 32.411] XCharSize: 8
[ 32.411] YCharSize: 16
[ 32.411] NumberOfPlanes: 1
[ 32.411] BitsPerPixel: 32
[ 32.411] NumberOfBanks: 1
[ 32.411] MemoryModel: 6
[ 32.411] BankSize: 0
[ 32.411] NumberOfImages: 1
[ 32.411] RedMaskSize: 8
[ 32.411] RedFieldPosition: 16
[ 32.411] GreenMaskSize: 8
[ 32.411] GreenFieldPosition: 8
[ 32.411] BlueMaskSize: 8
[ 32.411] BlueFieldPosition: 0
[ 32.411] RsvdMaskSize: 8
[ 32.411] RsvdFieldPosition: 24
[ 32.411] DirectColorModeInfo: 0
[ 32.411] PhysBasePtr: 0xcf000000
[ 32.411] LinBytesPerScanLine: 4096
[ 32.411] BnkNumberOfImagePages: 1
[ 32.411] LinNumberOfImagePages: 1
[ 32.411] LinRedMaskSize: 8
[ 32.411] LinRedFieldPosition: 16
[ 32.411] LinGreenMaskSize: 8
[ 32.411] LinGreenFieldPosition: 8
[ 32.411] LinBlueMaskSize: 8
[ 32.411] LinBlueFieldPosition: 0
[ 32.412] LinRsvdMaskSize: 8
[ 32.412] LinRsvdFieldPosition: 24
[ 32.412] MaxPixelClock: 229500000
[ 32.417] Mode: 130 (320x200)
[ 32.417] ModeAttributes: 0x3bf
[ 32.417] WinAAttributes: 0x7
[ 32.417] WinBAttributes: 0x0
[ 32.417] WinGranularity: 64
[ 32.417] WinSize: 64
[ 32.417] WinASegment: 0xa000
[ 32.417] WinBSegment: 0x0
[ 32.417] WinFuncPtr: 0xc000808e
[ 32.417] BytesPerScanline: 320
[ 32.417] XResolution: 320
[ 32.417] YResolution: 200
[ 32.417] XCharSize: 8
[ 32.417] YCharSize: 8
[ 32.417] NumberOfPlanes: 1
[ 32.417] BitsPerPixel: 8
[ 32.417] NumberOfBanks: 1
[ 32.417] MemoryModel: 4
[ 32.417] BankSize: 0
[ 32.417] NumberOfImages: 62
[ 32.417] RedMaskSize: 0
[ 32.417] RedFieldPosition: 0
[ 32.417] GreenMaskSize: 0
[ 32.417] GreenFieldPosition: 0
[ 32.417] BlueMaskSize: 0
[ 32.417] BlueFieldPosition: 0
[ 32.417] RsvdMaskSize: 0
[ 32.417] RsvdFieldPosition: 0
[ 32.417] DirectColorModeInfo: 0
[ 32.417] PhysBasePtr: 0xcf000000
[ 32.417] LinBytesPerScanLine: 320
[ 32.417] BnkNumberOfImagePages: 62
[ 32.417] LinNumberOfImagePages: 62
[ 32.417] LinRedMaskSize: 0
[ 32.417] LinRedFieldPosition: 0
[ 32.417] LinGreenMaskSize: 0
[ 32.417] LinGreenFieldPosition: 0
[ 32.417] LinBlueMaskSize: 0
[ 32.417] LinBlueFieldPosition: 0
[ 32.417] LinRsvdMaskSize: 0
[ 32.417] LinRsvdFieldPosition: 0
[ 32.417] MaxPixelClock: 229500000
[ 32.422] Mode: 131 (320x400)
[ 32.422] ModeAttributes: 0x3bf
[ 32.422] WinAAttributes: 0x7
[ 32.422] WinBAttributes: 0x0
[ 32.422] WinGranularity: 64
[ 32.422] WinSize: 64
[ 32.422] WinASegment: 0xa000
[ 32.422] WinBSegment: 0x0
[ 32.422] WinFuncPtr: 0xc000808e
[ 32.422] BytesPerScanline: 320
[ 32.422] XResolution: 320
[ 32.422] YResolution: 400
[ 32.422] XCharSize: 8
[ 32.422] YCharSize: 16
[ 32.422] NumberOfPlanes: 1
[ 32.422] BitsPerPixel: 8
[ 32.422] NumberOfBanks: 1
[ 32.422] MemoryModel: 4
[ 32.422] BankSize: 0
[ 32.422] NumberOfImages: 30
[ 32.422] RedMaskSize: 0
[ 32.422] RedFieldPosition: 0
[ 32.422] GreenMaskSize: 0
[ 32.422] GreenFieldPosition: 0
[ 32.422] BlueMaskSize: 0
[ 32.422] BlueFieldPosition: 0
[ 32.422] RsvdMaskSize: 0
[ 32.422] RsvdFieldPosition: 0
[ 32.422] DirectColorModeInfo: 0
[ 32.422] PhysBasePtr: 0xcf000000
[ 32.422] LinBytesPerScanLine: 320
[ 32.422] BnkNumberOfImagePages: 30
[ 32.422] LinNumberOfImagePages: 30
[ 32.422] LinRedMaskSize: 0
[ 32.422] LinRedFieldPosition: 0
[ 32.422] LinGreenMaskSize: 0
[ 32.422] LinGreenFieldPosition: 0
[ 32.422] LinBlueMaskSize: 0
[ 32.422] LinBlueFieldPosition: 0
[ 32.422] LinRsvdMaskSize: 0
[ 32.422] LinRsvdFieldPosition: 0
[ 32.422] MaxPixelClock: 229500000
[ 32.427] Mode: 132 (320x400)
[ 32.427] ModeAttributes: 0x3bf
[ 32.427] WinAAttributes: 0x7
[ 32.427] WinBAttributes: 0x0
[ 32.427] WinGranularity: 64
[ 32.427] WinSize: 64
[ 32.427] WinASegment: 0xa000
[ 32.427] WinBSegment: 0x0
[ 32.427] WinFuncPtr: 0xc000808e
[ 32.427] BytesPerScanline: 640
[ 32.427] XResolution: 320
[ 32.427] YResolution: 400
[ 32.427] XCharSize: 8
[ 32.427] YCharSize: 16
[ 32.427] NumberOfPlanes: 1
[ 32.427] BitsPerPixel: 16
[ 32.427] NumberOfBanks: 1
[ 32.427] MemoryModel: 6
[ 32.427] BankSize: 0
[ 32.427] NumberOfImages: 14
[ 32.427] RedMaskSize: 5
[ 32.427] RedFieldPosition: 11
[ 32.427] GreenMaskSize: 6
[ 32.427] GreenFieldPosition: 5
[ 32.427] BlueMaskSize: 5
[ 32.427] BlueFieldPosition: 0
[ 32.427] RsvdMaskSize: 0
[ 32.427] RsvdFieldPosition: 0
[ 32.427] DirectColorModeInfo: 0
[ 32.427] PhysBasePtr: 0xcf000000
[ 32.427] LinBytesPerScanLine: 640
[ 32.427] BnkNumberOfImagePages: 14
[ 32.427] LinNumberOfImagePages: 14
[ 32.427] LinRedMaskSize: 5
[ 32.427] LinRedFieldPosition: 11
[ 32.427] LinGreenMaskSize: 6
[ 32.427] LinGreenFieldPosition: 5
[ 32.427] LinBlueMaskSize: 5
[ 32.427] LinBlueFieldPosition: 0
[ 32.427] LinRsvdMaskSize: 0
[ 32.427] LinRsvdFieldPosition: 0
[ 32.427] MaxPixelClock: 229500000
[ 32.432] *Mode: 133 (320x400)
[ 32.432] ModeAttributes: 0x3bf
[ 32.432] WinAAttributes: 0x7
[ 32.432] WinBAttributes: 0x0
[ 32.432] WinGranularity: 64
[ 32.432] WinSize: 64
[ 32.432] WinASegment: 0xa000
[ 32.432] WinBSegment: 0x0
[ 32.432] WinFuncPtr: 0xc000808e
[ 32.432] BytesPerScanline: 1280
[ 32.432] XResolution: 320
[ 32.432] YResolution: 400
[ 32.432] XCharSize: 8
[ 32.432] YCharSize: 16
[ 32.432] NumberOfPlanes: 1
[ 32.432] BitsPerPixel: 32
[ 32.432] NumberOfBanks: 1
[ 32.432] MemoryModel: 6
[ 32.432] BankSize: 0
[ 32.432] NumberOfImages: 6
[ 32.432] RedMaskSize: 8
[ 32.432] RedFieldPosition: 16
[ 32.432] GreenMaskSize: 8
[ 32.432] GreenFieldPosition: 8
[ 32.432] BlueMaskSize: 8
[ 32.432] BlueFieldPosition: 0
[ 32.432] RsvdMaskSize: 8
[ 32.432] RsvdFieldPosition: 24
[ 32.432] DirectColorModeInfo: 0
[ 32.432] PhysBasePtr: 0xcf000000
[ 32.432] LinBytesPerScanLine: 1280
[ 32.432] BnkNumberOfImagePages: 6
[ 32.432] LinNumberOfImagePages: 6
[ 32.432] LinRedMaskSize: 8
[ 32.432] LinRedFieldPosition: 16
[ 32.432] LinGreenMaskSize: 8
[ 32.432] LinGreenFieldPosition: 8
[ 32.432] LinBlueMaskSize: 8
[ 32.432] LinBlueFieldPosition: 0
[ 32.432] LinRsvdMaskSize: 8
[ 32.432] LinRsvdFieldPosition: 24
[ 32.432] MaxPixelClock: 229500000
[ 32.437] Mode: 134 (320x240)
[ 32.437] ModeAttributes: 0x3bf
[ 32.437] WinAAttributes: 0x7
[ 32.437] WinBAttributes: 0x0
[ 32.437] WinGranularity: 64
[ 32.437] WinSize: 64
[ 32.437] WinASegment: 0xa000
[ 32.437] WinBSegment: 0x0
[ 32.437] WinFuncPtr: 0xc000808e
[ 32.437] BytesPerScanline: 320
[ 32.437] XResolution: 320
[ 32.437] YResolution: 240
[ 32.437] XCharSize: 8
[ 32.437] YCharSize: 8
[ 32.437] NumberOfPlanes: 1
[ 32.437] BitsPerPixel: 8
[ 32.437] NumberOfBanks: 1
[ 32.437] MemoryModel: 4
[ 32.437] BankSize: 0
[ 32.437] NumberOfImages: 30
[ 32.437] RedMaskSize: 0
[ 32.437] RedFieldPosition: 0
[ 32.437] GreenMaskSize: 0
[ 32.437] GreenFieldPosition: 0
[ 32.437] BlueMaskSize: 0
[ 32.437] BlueFieldPosition: 0
[ 32.437] RsvdMaskSize: 0
[ 32.437] RsvdFieldPosition: 0
[ 32.437] DirectColorModeInfo: 0
[ 32.437] PhysBasePtr: 0xcf000000
[ 32.437] LinBytesPerScanLine: 320
[ 32.437] BnkNumberOfImagePages: 30
[ 32.437] LinNumberOfImagePages: 30
[ 32.437] LinRedMaskSize: 0
[ 32.437] LinRedFieldPosition: 0
[ 32.437] LinGreenMaskSize: 0
[ 32.437] LinGreenFieldPosition: 0
[ 32.437] LinBlueMaskSize: 0
[ 32.437] LinBlueFieldPosition: 0
[ 32.437] LinRsvdMaskSize: 0
[ 32.437] LinRsvdFieldPosition: 0
[ 32.437] MaxPixelClock: 229500000
[ 32.442] Mode: 135 (320x240)
[ 32.442] ModeAttributes: 0x3bf
[ 32.442] WinAAttributes: 0x7
[ 32.442] WinBAttributes: 0x0
[ 32.442] WinGranularity: 64
[ 32.442] WinSize: 64
[ 32.442] WinASegment: 0xa000
[ 32.442] WinBSegment: 0x0
[ 32.442] WinFuncPtr: 0xc000808e
[ 32.442] BytesPerScanline: 640
[ 32.442] XResolution: 320
[ 32.442] YResolution: 240
[ 32.442] XCharSize: 8
[ 32.442] YCharSize: 8
[ 32.442] NumberOfPlanes: 1
[ 32.442] BitsPerPixel: 16
[ 32.442] NumberOfBanks: 1
[ 32.442] MemoryModel: 6
[ 32.442] BankSize: 0
[ 32.442] NumberOfImages: 19
[ 32.442] RedMaskSize: 5
[ 32.442] RedFieldPosition: 11
[ 32.442] GreenMaskSize: 6
[ 32.442] GreenFieldPosition: 5
[ 32.442] BlueMaskSize: 5
[ 32.442] BlueFieldPosition: 0
[ 32.442] RsvdMaskSize: 0
[ 32.442] RsvdFieldPosition: 0
[ 32.442] DirectColorModeInfo: 0
[ 32.442] PhysBasePtr: 0xcf000000
[ 32.442] LinBytesPerScanLine: 640
[ 32.442] BnkNumberOfImagePages: 19
[ 32.442] LinNumberOfImagePages: 19
[ 32.442] LinRedMaskSize: 5
[ 32.442] LinRedFieldPosition: 11
[ 32.442] LinGreenMaskSize: 6
[ 32.442] LinGreenFieldPosition: 5
[ 32.442] LinBlueMaskSize: 5
[ 32.442] LinBlueFieldPosition: 0
[ 32.442] LinRsvdMaskSize: 0
[ 32.442] LinRsvdFieldPosition: 0
[ 32.442] MaxPixelClock: 229500000
[ 32.447] *Mode: 136 (320x240)
[ 32.448] ModeAttributes: 0x3bf
[ 32.448] WinAAttributes: 0x7
[ 32.448] WinBAttributes: 0x0
[ 32.448] WinGranularity: 64
[ 32.448] WinSize: 64
[ 32.448] WinASegment: 0xa000
[ 32.448] WinBSegment: 0x0
[ 32.448] WinFuncPtr: 0xc000808e
[ 32.448] BytesPerScanline: 1280
[ 32.448] XResolution: 320
[ 32.448] YResolution: 240
[ 32.448] XCharSize: 8
[ 32.448] YCharSize: 8
[ 32.448] NumberOfPlanes: 1
[ 32.448] BitsPerPixel: 32
[ 32.448] NumberOfBanks: 1
[ 32.448] MemoryModel: 6
[ 32.448] BankSize: 0
[ 32.448] NumberOfImages: 10
[ 32.448] RedMaskSize: 8
[ 32.448] RedFieldPosition: 16
[ 32.448] GreenMaskSize: 8
[ 32.448] GreenFieldPosition: 8
[ 32.448] BlueMaskSize: 8
[ 32.448] BlueFieldPosition: 0
[ 32.448] RsvdMaskSize: 8
[ 32.448] RsvdFieldPosition: 24
[ 32.448] DirectColorModeInfo: 0
[ 32.448] PhysBasePtr: 0xcf000000
[ 32.448] LinBytesPerScanLine: 1280
[ 32.448] BnkNumberOfImagePages: 10
[ 32.448] LinNumberOfImagePages: 10
[ 32.448] LinRedMaskSize: 8
[ 32.448] LinRedFieldPosition: 16
[ 32.448] LinGreenMaskSize: 8
[ 32.448] LinGreenFieldPosition: 8
[ 32.448] LinBlueMaskSize: 8
[ 32.448] LinBlueFieldPosition: 0
[ 32.448] LinRsvdMaskSize: 8
[ 32.448] LinRsvdFieldPosition: 24
[ 32.448] MaxPixelClock: 229500000
[ 32.453] Mode: 13d (640x400)
[ 32.453] ModeAttributes: 0x3bf
[ 32.453] WinAAttributes: 0x7
[ 32.453] WinBAttributes: 0x0
[ 32.453] WinGranularity: 64
[ 32.453] WinSize: 64
[ 32.453] WinASegment: 0xa000
[ 32.453] WinBSegment: 0x0
[ 32.453] WinFuncPtr: 0xc000808e
[ 32.453] BytesPerScanline: 1280
[ 32.453] XResolution: 640
[ 32.453] YResolution: 400
[ 32.453] XCharSize: 8
[ 32.453] YCharSize: 16
[ 32.453] NumberOfPlanes: 1
[ 32.453] BitsPerPixel: 16
[ 32.453] NumberOfBanks: 1
[ 32.453] MemoryModel: 6
[ 32.453] BankSize: 0
[ 32.453] NumberOfImages: 6
[ 32.453] RedMaskSize: 5
[ 32.453] RedFieldPosition: 11
[ 32.453] GreenMaskSize: 6
[ 32.453] GreenFieldPosition: 5
[ 32.453] BlueMaskSize: 5
[ 32.453] BlueFieldPosition: 0
[ 32.453] RsvdMaskSize: 0
[ 32.453] RsvdFieldPosition: 0
[ 32.453] DirectColorModeInfo: 0
[ 32.453] PhysBasePtr: 0xcf000000
[ 32.453] LinBytesPerScanLine: 1280
[ 32.453] BnkNumberOfImagePages: 6
[ 32.453] LinNumberOfImagePages: 6
[ 32.453] LinRedMaskSize: 5
[ 32.453] LinRedFieldPosition: 11
[ 32.453] LinGreenMaskSize: 6
[ 32.453] LinGreenFieldPosition: 5
[ 32.453] LinBlueMaskSize: 5
[ 32.453] LinBlueFieldPosition: 0
[ 32.453] LinRsvdMaskSize: 0
[ 32.453] LinRsvdFieldPosition: 0
[ 32.453] MaxPixelClock: 229500000
[ 32.458] *Mode: 13e (640x400)
[ 32.458] ModeAttributes: 0x3bf
[ 32.458] WinAAttributes: 0x7
[ 32.458] WinBAttributes: 0x0
[ 32.458] WinGranularity: 64
[ 32.458] WinSize: 64
[ 32.458] WinASegment: 0xa000
[ 32.458] WinBSegment: 0x0
[ 32.458] WinFuncPtr: 0xc000808e
[ 32.458] BytesPerScanline: 2560
[ 32.458] XResolution: 640
[ 32.458] YResolution: 400
[ 32.458] XCharSize: 8
[ 32.458] YCharSize: 16
[ 32.458] NumberOfPlanes: 1
[ 32.458] BitsPerPixel: 32
[ 32.458] NumberOfBanks: 1
[ 32.458] MemoryModel: 6
[ 32.458] BankSize: 0
[ 32.458] NumberOfImages: 2
[ 32.458] RedMaskSize: 8
[ 32.458] RedFieldPosition: 16
[ 32.458] GreenMaskSize: 8
[ 32.458] GreenFieldPosition: 8
[ 32.458] BlueMaskSize: 8
[ 32.458] BlueFieldPosition: 0
[ 32.458] RsvdMaskSize: 8
[ 32.458] RsvdFieldPosition: 24
[ 32.458] DirectColorModeInfo: 0
[ 32.458] PhysBasePtr: 0xcf000000
[ 32.458] LinBytesPerScanLine: 2560
[ 32.458] BnkNumberOfImagePages: 2
[ 32.458] LinNumberOfImagePages: 2
[ 32.458] LinRedMaskSize: 8
[ 32.458] LinRedFieldPosition: 16
[ 32.458] LinGreenMaskSize: 8
[ 32.458] LinGreenFieldPosition: 8
[ 32.458] LinBlueMaskSize: 8
[ 32.458] LinBlueFieldPosition: 0
[ 32.458] LinRsvdMaskSize: 8
[ 32.458] LinRsvdFieldPosition: 24
[ 32.458] MaxPixelClock: 229500000
[ 32.463] Mode: 14b (1280x800)
[ 32.463] ModeAttributes: 0x3bf
[ 32.463] WinAAttributes: 0x7
[ 32.463] WinBAttributes: 0x0
[ 32.463] WinGranularity: 64
[ 32.463] WinSize: 64
[ 32.463] WinASegment: 0xa000
[ 32.463] WinBSegment: 0x0
[ 32.463] WinFuncPtr: 0xc000808e
[ 32.463] BytesPerScanline: 1280
[ 32.463] XResolution: 1280
[ 32.463] YResolution: 800
[ 32.463] XCharSize: 8
[ 32.463] YCharSize: 16
[ 32.463] NumberOfPlanes: 1
[ 32.463] BitsPerPixel: 8
[ 32.463] NumberOfBanks: 1
[ 32.463] MemoryModel: 4
[ 32.463] BankSize: 0
[ 32.463] NumberOfImages: 1
[ 32.463] RedMaskSize: 0
[ 32.463] RedFieldPosition: 0
[ 32.463] GreenMaskSize: 0
[ 32.463] GreenFieldPosition: 0
[ 32.463] BlueMaskSize: 0
[ 32.463] BlueFieldPosition: 0
[ 32.463] RsvdMaskSize: 0
[ 32.463] RsvdFieldPosition: 0
[ 32.463] DirectColorModeInfo: 0
[ 32.463] PhysBasePtr: 0xcf000000
[ 32.463] LinBytesPerScanLine: 1280
[ 32.463] BnkNumberOfImagePages: 1
[ 32.463] LinNumberOfImagePages: 1
[ 32.463] LinRedMaskSize: 0
[ 32.463] LinRedFieldPosition: 0
[ 32.463] LinGreenMaskSize: 0
[ 32.463] LinGreenFieldPosition: 0
[ 32.463] LinBlueMaskSize: 0
[ 32.463] LinBlueFieldPosition: 0
[ 32.463] LinRsvdMaskSize: 0
[ 32.463] LinRsvdFieldPosition: 0
[ 32.463] MaxPixelClock: 229500000
[ 32.468] Mode: 14c (1280x800)
[ 32.468] ModeAttributes: 0x3bf
[ 32.468] WinAAttributes: 0x7
[ 32.469] WinBAttributes: 0x0
[ 32.469] WinGranularity: 64
[ 32.469] WinSize: 64
[ 32.469] WinASegment: 0xa000
[ 32.469] WinBSegment: 0x0
[ 32.469] WinFuncPtr: 0xc000808e
[ 32.469] BytesPerScanline: 2560
[ 32.469] XResolution: 1280
[ 32.469] YResolution: 800
[ 32.469] XCharSize: 8
[ 32.469] YCharSize: 16
[ 32.469] NumberOfPlanes: 1
[ 32.469] BitsPerPixel: 16
[ 32.469] NumberOfBanks: 1
[ 32.469] MemoryModel: 6
[ 32.469] BankSize: 0
[ 32.469] NumberOfImages: 1
[ 32.469] RedMaskSize: 5
[ 32.469] RedFieldPosition: 11
[ 32.469] GreenMaskSize: 6
[ 32.469] GreenFieldPosition: 5
[ 32.469] BlueMaskSize: 5
[ 32.469] BlueFieldPosition: 0
[ 32.469] RsvdMaskSize: 0
[ 32.469] RsvdFieldPosition: 0
[ 32.469] DirectColorModeInfo: 0
[ 32.469] PhysBasePtr: 0xcf000000
[ 32.469] LinBytesPerScanLine: 2560
[ 32.469] BnkNumberOfImagePages: 1
[ 32.469] LinNumberOfImagePages: 1
[ 32.469] LinRedMaskSize: 5
[ 32.469] LinRedFieldPosition: 11
[ 32.469] LinGreenMaskSize: 6
[ 32.469] LinGreenFieldPosition: 5
[ 32.469] LinBlueMaskSize: 5
[ 32.469] LinBlueFieldPosition: 0
[ 32.469] LinRsvdMaskSize: 0
[ 32.469] LinRsvdFieldPosition: 0
[ 32.469] MaxPixelClock: 229500000
[ 32.474] *Mode: 14d (1280x800)
[ 32.474] ModeAttributes: 0x3bf
[ 32.474] WinAAttributes: 0x7
[ 32.474] WinBAttributes: 0x0
[ 32.474] WinGranularity: 64
[ 32.474] WinSize: 64
[ 32.474] WinASegment: 0xa000
[ 32.474] WinBSegment: 0x0
[ 32.474] WinFuncPtr: 0xc000808e
[ 32.474] BytesPerScanline: 5120
[ 32.474] XResolution: 1280
[ 32.474] YResolution: 800
[ 32.474] XCharSize: 8
[ 32.474] YCharSize: 16
[ 32.474] NumberOfPlanes: 1
[ 32.474] BitsPerPixel: 32
[ 32.474] NumberOfBanks: 1
[ 32.474] MemoryModel: 6
[ 32.474] BankSize: 0
[ 32.474] NumberOfImages: 1
[ 32.474] RedMaskSize: 8
[ 32.474] RedFieldPosition: 16
[ 32.474] GreenMaskSize: 8
[ 32.474] GreenFieldPosition: 8
[ 32.474] BlueMaskSize: 8
[ 32.474] BlueFieldPosition: 0
[ 32.474] RsvdMaskSize: 8
[ 32.474] RsvdFieldPosition: 24
[ 32.474] DirectColorModeInfo: 0
[ 32.474] PhysBasePtr: 0xcf000000
[ 32.474] LinBytesPerScanLine: 5120
[ 32.474] BnkNumberOfImagePages: 1
[ 32.474] LinNumberOfImagePages: 1
[ 32.474] LinRedMaskSize: 8
[ 32.474] LinRedFieldPosition: 16
[ 32.474] LinGreenMaskSize: 8
[ 32.474] LinGreenFieldPosition: 8
[ 32.474] LinBlueMaskSize: 8
[ 32.474] LinBlueFieldPosition: 0
[ 32.474] LinRsvdMaskSize: 8
[ 32.474] LinRsvdFieldPosition: 24
[ 32.474] MaxPixelClock: 229500000
[ 32.479] Mode: 160 (1280x800)
[ 32.479] ModeAttributes: 0x3bf
[ 32.479] WinAAttributes: 0x7
[ 32.479] WinBAttributes: 0x0
[ 32.479] WinGranularity: 64
[ 32.479] WinSize: 64
[ 32.479] WinASegment: 0xa000
[ 32.479] WinBSegment: 0x0
[ 32.479] WinFuncPtr: 0xc000808e
[ 32.479] BytesPerScanline: 1280
[ 32.479] XResolution: 1280
[ 32.479] YResolution: 800
[ 32.479] XCharSize: 8
[ 32.479] YCharSize: 16
[ 32.479] NumberOfPlanes: 1
[ 32.479] BitsPerPixel: 8
[ 32.479] NumberOfBanks: 1
[ 32.479] MemoryModel: 4
[ 32.479] BankSize: 0
[ 32.479] NumberOfImages: 2
[ 32.479] RedMaskSize: 0
[ 32.479] RedFieldPosition: 0
[ 32.479] GreenMaskSize: 0
[ 32.479] GreenFieldPosition: 0
[ 32.479] BlueMaskSize: 0
[ 32.479] BlueFieldPosition: 0
[ 32.479] RsvdMaskSize: 0
[ 32.479] RsvdFieldPosition: 0
[ 32.479] DirectColorModeInfo: 0
[ 32.479] PhysBasePtr: 0xcf000000
[ 32.479] LinBytesPerScanLine: 1280
[ 32.479] BnkNumberOfImagePages: 2
[ 32.479] LinNumberOfImagePages: 2
[ 32.479] LinRedMaskSize: 0
[ 32.479] LinRedFieldPosition: 0
[ 32.479] LinGreenMaskSize: 0
[ 32.479] LinGreenFieldPosition: 0
[ 32.479] LinBlueMaskSize: 0
[ 32.479] LinBlueFieldPosition: 0
[ 32.479] LinRsvdMaskSize: 0
[ 32.479] LinRsvdFieldPosition: 0
[ 32.479] MaxPixelClock: 229500000
[ 32.485] *Mode: 161 (1280x800)
[ 32.485] ModeAttributes: 0x3bf
[ 32.485] WinAAttributes: 0x7
[ 32.485] WinBAttributes: 0x0
[ 32.485] WinGranularity: 64
[ 32.485] WinSize: 64
[ 32.485] WinASegment: 0xa000
[ 32.485] WinBSegment: 0x0
[ 32.485] WinFuncPtr: 0xc000808e
[ 32.485] BytesPerScanline: 5120
[ 32.485] XResolution: 1280
[ 32.485] YResolution: 800
[ 32.485] XCharSize: 8
[ 32.485] YCharSize: 16
[ 32.485] NumberOfPlanes: 1
[ 32.485] BitsPerPixel: 32
[ 32.485] NumberOfBanks: 1
[ 32.485] MemoryModel: 6
[ 32.485] BankSize: 0
[ 32.485] NumberOfImages: 1
[ 32.485] RedMaskSize: 8
[ 32.485] RedFieldPosition: 16
[ 32.485] GreenMaskSize: 8
[ 32.485] GreenFieldPosition: 8
[ 32.485] BlueMaskSize: 8
[ 32.485] BlueFieldPosition: 0
[ 32.485] RsvdMaskSize: 8
[ 32.485] RsvdFieldPosition: 24
[ 32.485] DirectColorModeInfo: 0
[ 32.485] PhysBasePtr: 0xcf000000
[ 32.485] LinBytesPerScanLine: 5120
[ 32.485] BnkNumberOfImagePages: 1
[ 32.485] LinNumberOfImagePages: 1
[ 32.485] LinRedMaskSize: 8
[ 32.485] LinRedFieldPosition: 16
[ 32.485] LinGreenMaskSize: 8
[ 32.485] LinGreenFieldPosition: 8
[ 32.485] LinBlueMaskSize: 8
[ 32.485] LinBlueFieldPosition: 0
[ 32.485] LinRsvdMaskSize: 8
[ 32.485] LinRsvdFieldPosition: 24
[ 32.485] MaxPixelClock: 229500000
[ 32.485]
[ 32.485] (II) VESA(0): Total Memory: 224 64KB banks (14336kB)
[ 32.485] (II) VESA(0): : Using hsync range of 30.00-110.00 kHz
[ 32.485] (II) VESA(0): : Using vrefresh range of 59.00-61.00 Hz
[ 32.485] (II) VESA(0): : Using maximum pixel clock of 275.00 MHz
[ 32.485] (WW) VESA(0): Unable to estimate virtual size
[ 32.493] (II) VESA(0): Not using built-in mode “640x400” (no mode of this name)
[ 32.493] (II) VESA(0): Not using built-in mode “320x400” (no mode of this name)
[ 32.493] (II) VESA(0): Not using built-in mode “320x240” (no mode of this name)
[ 32.493] (II) VESA(0): Not using built-in mode “320x200” (no mode of this name)
[ 32.493] (–) VESA(0): Virtual size is 1280x800 (pitch 1280)
[ 32.493] () VESA(0): *Built-in mode “1280x800”
[ 32.493] () VESA(0): *Built-in mode “1024x768”
[ 32.493] () VESA(0): *Built-in mode “800x600”
[ 32.493] () VESA(0): *Built-in mode “640x480”
[ 32.493] () VESA(0): Display dimensions: (640, 400) mm
[ 32.493] () VESA(0): DPI set to (50, 50)
[ 32.493] () VESA(0): Using “Shadow Framebuffer”
[ 32.493] (II) Loading sub module “shadow”
[ 32.493] (II) LoadModule: “shadow”
[ 32.494] (II) Loading /usr/lib/xorg/modules/libshadow.so
