Pascal Titan X's GPU's falling off the bus
We have a a four Pascal Titan X from Exxactcorp[url]404: Not Found | Exxact
Upon reboot the GPU’s only after a few min of use fall off the bus.
Below is the nvidia-bug-report.log
Start of NVIDIA bug report log file. Please include this file, along
with a detailed description of your problem, when reporting a graphics
driver bug via the NVIDIA Linux forum (see devtalk.nvidia.com)
or by sending email to ‘linux-bugs@nvidia.com’.
nvidia-bug-report.sh Version: 20867758
Date: Thu Dec 29 12:07:45 PST 2016
uname: Linux ubuntu 4.2.0-42-generic #49~14.04.1-Ubuntu SMP Wed Jun 29 20:22:11 UTC 2016 x86_64 x86_64 x86_64 GNU/Linux
command line flags:
*** /etc/issue
*** ls: -rw-r–r-- 1 root root 26 2016-08-01 07:05:01.000000000 -0700 /etc/issue
Ubuntu 14.04.5 LTS \n \l
*** /etc/debian_version
*** ls: -rw-r–r-- 1 root root 11 2014-02-19 18:43:56.000000000 -0800 /etc/debian_version
jessie/sid
*** /var/log/nvidia-installer.log
*** ls: -rw-r–r-- 1 root root 26046 2016-09-07 22:18:59.432111720 -0700 /var/log/nvidia-installer.log
nvidia-installer log file ‘/var/log/nvidia-installer.log’
creation time: Wed Sep 7 22:17:38 2016
installer version: 367.44
PATH: /usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin
nvidia-installer command line:
./nvidia-installer
Unable to load: nvidia-installer ncurses v6 user interface
Using: nvidia-installer ncurses user interface
→ Detected 12 CPUs online; setting concurrency level to 12.
→ License accepted.
→ Installing NVIDIA driver version 367.44.
→ Running distribution scripts
executing: ‘/usr/lib/nvidia/pre-install’…
→ done.
→ The distribution-provided pre-install script failed! Are you sure you want to continue? (Answer: Continue installation)
→ Performing CC sanity check with CC=“/usr/bin/cc”.
→ Kernel source path: ‘/lib/modules/4.2.0-42-generic/build’
→ Kernel output path: ‘/lib/modules/4.2.0-42-generic/build’
→ Performing rivafb check.
→ Performing nvidiafb check.
→ Performing Xen check.
→ Performing PREEMPT_RT check.
→ Cleaning kernel module build directory.
executing: ‘cd ./kernel; /usr/bin/make -k -j12 clean NV_EXCLUDE_KERNEL_MODULES=“” SYSSRC=“/lib/modules/4.2.0-42-generic/build” SYSOUT=“/lib/modules/4.2.0-42-generic/build”’…
rm -f -r conftest
/usr/bin/make “CC=cc” KBUILD_VERBOSE= -C /lib/modules/4.2.0-42-generic/build M=/tmp/selfgz2659/NVIDIA-Linux-x86_64-367.44/kernel ARCH=x86_64 NV_KERNEL_SOURCES=/lib/modules/4.2.0-42-generic/build NV_KERNEL_OUTPUT=/lib/modules/4.2.0-42-generic/build NV_KERNEL_MODULES=“nvidia nvidia-uvm nvidia-modeset nvidia-drm” INSTALL_MOD_DIR=kernel/drivers/video clean
make[1]: Entering directory /usr/src/linux-headers-4.2.0-42-generic' make[1]: Leaving directory /usr/src/linux-headers-4.2.0-42-generic’
→ Building kernel modules
executing: ‘cd ./kernel; /usr/bin/make -k -j12 NV_EXCLUDE_KERNEL_MODULES=“” SYSSRC=“/lib/modules/4.2.0-42-generic/build” SYSOUT=“/lib/modules/4.2.0-42-generic/build”’…
/usr/bin/make “CC=cc” KBUILD_VERBOSE= -C /lib/modules/4.2.0-42-generic/build M=/tmp/selfgz2659/NVIDIA-Linux-x86_64-367.44/kernel ARCH=x86_64 NV_KERNEL_SOURCES=/lib/modules/4.2.0-42-generic/build NV_KERNEL_OUTPUT=/lib/modules/4.2.0-42-generic/build NV_KERNEL_MODULES=“nvidia nvidia-uvm nvidia-modeset nvidia-drm” INSTALL_MOD_DIR=kernel/drivers/video modules
make[1]: Entering directory /usr/src/linux-headers-4.2.0-42-generic' SYMLINK /tmp/selfgz2659/NVIDIA-Linux-x86_64-367.44/kernel/nvidia/nv-kernel.o SYMLINK /tmp/selfgz2659/NVIDIA-Linux-x86_64-367.44/kernel/nvidia-modeset/nv-modeset-kernel.o CONFTEST: INIT_WORK CONFTEST: remap_pfn_range CONFTEST: follow_pfn CONFTEST: vmap CONFTEST: set_pages_uc CONFTEST: set_memory_uc CONFTEST: set_memory_array_uc CONFTEST: change_page_attr CONFTEST: pci_get_class CONFTEST: pci_choose_state CONFTEST: vm_insert_page CONFTEST: acpi_device_id CONFTEST: acquire_console_sem CONFTEST: console_lock CONFTEST: kmem_cache_create CONFTEST: on_each_cpu CONFTEST: smp_call_function CONFTEST: acpi_evaluate_integer CONFTEST: ioremap_cache CONFTEST: ioremap_wc CONFTEST: acpi_walk_namespace CONFTEST: pci_domain_nr CONFTEST: pci_dma_mapping_error CONFTEST: sg_alloc_table CONFTEST: sg_init_table CONFTEST: pci_get_domain_bus_and_slot CONFTEST: get_num_physpages CONFTEST: efi_enabled CONFTEST: proc_create_data CONFTEST: pde_data CONFTEST: proc_remove CONFTEST: pm_vt_switch_required CONFTEST: drm_driver_has_set_busid CONFTEST: xen_ioemu_inject_msi CONFTEST: phys_to_dma CONFTEST: write_cr4 CONFTEST: get_dma_ops CONFTEST: of_parse_phandle CONFTEST: for_each_online_node CONFTEST: node_end_pfn CONFTEST: pci_bus_address CONFTEST: request_threaded_irq CONFTEST: remap_page_range CONFTEST: address_space_init_once CONFTEST: kbasename CONFTEST: fatal_signal_pending CONFTEST: list_cut_position CONFTEST: vzalloc CONFTEST: wait_on_bit_lock_argument_count CONFTEST: bitmap_clear CONFTEST: radix_tree_empty CONFTEST: usleep_range CONFTEST: drm_dev_unref CONFTEST: drm_reinit_primary_mode_group CONFTEST: drm_atomic_set_mode_for_crtc CONFTEST: drm_atomic_clean_old_fb CONFTEST: get_user_pages_remote CONFTEST: drm_gem_object_lookup CONFTEST: i2c_adapter CONFTEST: pm_message_t CONFTEST: irq_handler_t CONFTEST: acpi_device_ops CONFTEST: acpi_op_remove CONFTEST: outer_flush_all CONFTEST: proc_dir_entry CONFTEST: scatterlist CONFTEST: sg_table CONFTEST: vm_operations_struct CONFTEST: file_operations CONFTEST: atomic_long_type CONFTEST: pci_save_state CONFTEST: file_inode CONFTEST: task_struct CONFTEST: kuid_t CONFTEST: dma_ops CONFTEST: dma_map_ops CONFTEST: noncoherent_swiotlb_dma_ops CONFTEST: fault_flags CONFTEST: atomic64_type CONFTEST: address_space CONFTEST: backing_dev_info CONFTEST: kernel_write CONFTEST: strnstr CONFTEST: iterate_dir CONFTEST: kstrtoull CONFTEST: mm_context_t CONFTEST: drm_bus_present CONFTEST: drm_bus_has_bus_type CONFTEST: drm_bus_has_get_irq CONFTEST: drm_bus_has_get_name CONFTEST: drm_driver_has_legacy_dev_list CONFTEST: drm_crtc_state_has_connectors_changed CONFTEST: drm_init_functions_have_name_arg CONFTEST: drm_mode_connector_list_update_has_merge_type_bits_arg CONFTEST: drm_helper_mode_fill_fb_struct_has_const_mode_cmd_arg CONFTEST: dom0_kernel_present CONFTEST: drm_available CONFTEST: nvidia_grid_build CONFTEST: drm_atomic_available CC [M] /tmp/selfgz2659/NVIDIA-Linux-x86_64-367.44/kernel/nvidia/nv-frontend.o CC [M] /tmp/selfgz2659/NVIDIA-Linux-x86_64-367.44/kernel/nvidia/nv-instance.o CC [M] /tmp/selfgz2659/NVIDIA-Linux-x86_64-367.44/kernel/nvidia/nv.o CC [M] /tmp/selfgz2659/NVIDIA-Linux-x86_64-367.44/kernel/nvidia/nv-acpi.o CC [M] /tmp/selfgz2659/NVIDIA-Linux-x86_64-367.44/kernel/nvidia/nv-chrdev.o CC [M] /tmp/selfgz2659/NVIDIA-Linux-x86_64-367.44/kernel/nvidia/nv-cray.o CC [M] /tmp/selfgz2659/NVIDIA-Linux-x86_64-367.44/kernel/nvidia/nv-dma.o CC [M] /tmp/selfgz2659/NVIDIA-Linux-x86_64-367.44/kernel/nvidia/nv-gvi.o CC [M] /tmp/selfgz2659/NVIDIA-Linux-x86_64-367.44/kernel/nvidia/nv-i2c.o CC [M] /tmp/selfgz2659/NVIDIA-Linux-x86_64-367.44/kernel/nvidia/nv-mempool.o CC [M] /tmp/selfgz2659/NVIDIA-Linux-x86_64-367.44/kernel/nvidia/nv-mmap.o CC [M] /tmp/selfgz2659/NVIDIA-Linux-x86_64-367.44/kernel/nvidia/nv-p2p.o CC [M] /tmp/selfgz2659/NVIDIA-Linux-x86_64-367.44/kernel/nvidia/nv-pat.o CC [M] /tmp/selfgz2659/NVIDIA-Linux-x86_64-367.44/kernel/nvidia/nv-procfs.o CC [M] /tmp/selfgz2659/NVIDIA-Linux-x86_64-367.44/kernel/nvidia/nv-usermap.o CC [M] /tmp/selfgz2659/NVIDIA-Linux-x86_64-367.44/kernel/nvidia/nv-vm.o CC [M] /tmp/selfgz2659/NVIDIA-Linux-x86_64-367.44/kernel/nvidia/nv-vtophys.o CC [M] /tmp/selfgz2659/NVIDIA-Linux-x86_64-367.44/kernel/nvidia/os-interface.o CC [M] /tmp/selfgz2659/NVIDIA-Linux-x86_64-367.44/kernel/nvidia/os-mlock.o CC [M] /tmp/selfgz2659/NVIDIA-Linux-x86_64-367.44/kernel/nvidia/os-pci.o CC [M] /tmp/selfgz2659/NVIDIA-Linux-x86_64-367.44/kernel/nvidia/os-registry.o CC [M] /tmp/selfgz2659/NVIDIA-Linux-x86_64-367.44/kernel/nvidia/os-usermap.o CC [M] /tmp/selfgz2659/NVIDIA-Linux-x86_64-367.44/kernel/nvidia/nv-modeset-interface.o CC [M] /tmp/selfgz2659/NVIDIA-Linux-x86_64-367.44/kernel/nvidia/nv-pci-table.o CC [M] /tmp/selfgz2659/NVIDIA-Linux-x86_64-367.44/kernel/nvidia/nv_uvm_interface.o CC [M] /tmp/selfgz2659/NVIDIA-Linux-x86_64-367.44/kernel/nvidia/nvlink_linux.o CC [M] /tmp/selfgz2659/NVIDIA-Linux-x86_64-367.44/kernel/nvidia/nvlink_pci.o CC [M] /tmp/selfgz2659/NVIDIA-Linux-x86_64-367.44/kernel/nvidia/ebridge_linux.o CC [M] /tmp/selfgz2659/NVIDIA-Linux-x86_64-367.44/kernel/nvidia/ibmnpu_linux.o CC [M] /tmp/selfgz2659/NVIDIA-Linux-x86_64-367.44/kernel/nvidia-uvm/uvm_common.o CC [M] /tmp/selfgz2659/NVIDIA-Linux-x86_64-367.44/kernel/nvidia-uvm/uvm_utils.o CC [M] /tmp/selfgz2659/NVIDIA-Linux-x86_64-367.44/kernel/nvidia-uvm/uvm_linux.o CC [M] /tmp/selfgz2659/NVIDIA-Linux-x86_64-367.44/kernel/nvidia-uvm/uvm_page_migration.o CC [M] /tmp/selfgz2659/NVIDIA-Linux-x86_64-367.44/kernel/nvidia-uvm/uvm_page_migration_stubs.o CC [M] /tmp/selfgz2659/NVIDIA-Linux-x86_64-367.44/kernel/nvidia-uvm/uvm_page_migration_maxwell.o CC [M] /tmp/selfgz2659/NVIDIA-Linux-x86_64-367.44/kernel/nvidia-uvm/uvm_page_migration_kepler.o CC [M] /tmp/selfgz2659/NVIDIA-Linux-x86_64-367.44/kernel/nvidia-uvm/uvm_page_migration_pascal.o CC [M] /tmp/selfgz2659/NVIDIA-Linux-x86_64-367.44/kernel/nvidia-uvm/uvm_channel_mgmt.o CC [M] /tmp/selfgz2659/NVIDIA-Linux-x86_64-367.44/kernel/nvidia-uvm/nvstatus.o CC [M] /tmp/selfgz2659/NVIDIA-Linux-x86_64-367.44/kernel/nvidia-uvm/nv-kthread-q.o CC [M] /tmp/selfgz2659/NVIDIA-Linux-x86_64-367.44/kernel/nvidia-uvm/nv-kthread-q-selftest.o CC [M] /tmp/selfgz2659/NVIDIA-Linux-x86_64-367.44/kernel/nvidia-uvm/uvm_common_test.o CC [M] /tmp/selfgz2659/NVIDIA-Linux-x86_64-367.44/kernel/nvidia-uvm/uvm_channel_directed_tests.o CC [M] /tmp/selfgz2659/NVIDIA-Linux-x86_64-367.44/kernel/nvidia-uvm/uvm_channel_basic_sanity_tests.o CC [M] /tmp/selfgz2659/NVIDIA-Linux-x86_64-367.44/kernel/nvidia-uvm/uvm_kernel_events.o CC [M] /tmp/selfgz2659/NVIDIA-Linux-x86_64-367.44/kernel/nvidia-uvm/uvm_kernel_counters.o CC [M] /tmp/selfgz2659/NVIDIA-Linux-x86_64-367.44/kernel/nvidia-uvm/uvm_debug_session.o CC [M] /tmp/selfgz2659/NVIDIA-Linux-x86_64-367.44/kernel/nvidia-uvm/uvm_gpu_ops_tests.o CC [M] /tmp/selfgz2659/NVIDIA-Linux-x86_64-367.44/kernel/nvidia-uvm/uvm_lite.o CC [M] /tmp/selfgz2659/NVIDIA-Linux-x86_64-367.44/kernel/nvidia-uvm/uvm_page_cache.o CC [M] /tmp/selfgz2659/NVIDIA-Linux-x86_64-367.44/kernel/nvidia-uvm/uvm_lite_api.o CC [M] /tmp/selfgz2659/NVIDIA-Linux-x86_64-367.44/kernel/nvidia-uvm/uvm_lite_prefetch.o CC [M] /tmp/selfgz2659/NVIDIA-Linux-x86_64-367.44/kernel/nvidia-uvm/uvm_lite_region_tracking.o CC [M] /tmp/selfgz2659/NVIDIA-Linux-x86_64-367.44/kernel/nvidia-uvm/uvm_mmu_mgmt_pascal.o CC [M] /tmp/selfgz2659/NVIDIA-Linux-x86_64-367.44/kernel/nvidia-uvm/uvm_mmu_mgmt.o CC [M] /tmp/selfgz2659/NVIDIA-Linux-x86_64-367.44/kernel/nvidia-uvm/uvm_mmu_mgmt_stubs.o CC [M] /tmp/selfgz2659/NVIDIA-Linux-x86_64-367.44/kernel/nvidia-uvm/uvm_full_fault_buffer.o CC [M] /tmp/selfgz2659/NVIDIA-Linux-x86_64-367.44/kernel/nvidia-uvm/uvm_full_fault_buffer_pascal.o CC [M] /tmp/selfgz2659/NVIDIA-Linux-x86_64-367.44/kernel/nvidia-uvm/mmu_fmt.o CC [M] /tmp/selfgz2659/NVIDIA-Linux-x86_64-367.44/kernel/nvidia-uvm/gmmu_fmt.o CC [M] /tmp/selfgz2659/NVIDIA-Linux-x86_64-367.44/kernel/nvidia-uvm/uvm8.o CC [M] /tmp/selfgz2659/NVIDIA-Linux-x86_64-367.44/kernel/nvidia-uvm/uvm8_tools.o CC [M] /tmp/selfgz2659/NVIDIA-Linux-x86_64-367.44/kernel/nvidia-uvm/uvm8_global.o CC [M] /tmp/selfgz2659/NVIDIA-Linux-x86_64-367.44/kernel/nvidia-uvm/uvm8_gpu.o CC [M] /tmp/selfgz2659/NVIDIA-Linux-x86_64-367.44/kernel/nvidia-uvm/uvm8_procfs.o CC [M] /tmp/selfgz2659/NVIDIA-Linux-x86_64-367.44/kernel/nvidia-uvm/uvm8_va_space.o CC [M] /tmp/selfgz2659/NVIDIA-Linux-x86_64-367.44/kernel/nvidia-uvm/uvm8_gpu_semaphore.o CC [M] /tmp/selfgz2659/NVIDIA-Linux-x86_64-367.44/kernel/nvidia-uvm/uvm8_mem.o CC [M] /tmp/selfgz2659/NVIDIA-Linux-x86_64-367.44/kernel/nvidia-uvm/uvm8_rm_mem.o CC [M] /tmp/selfgz2659/NVIDIA-Linux-x86_64-367.44/kernel/nvidia-uvm/uvm8_channel.o CC [M] /tmp/selfgz2659/NVIDIA-Linux-x86_64-367.44/kernel/nvidia-uvm/uvm8_lock.o CC [M] /tmp/selfgz2659/NVIDIA-Linux-x86_64-367.44/kernel/nvidia-uvm/uvm8_hal.o CC [M] /tmp/selfgz2659/NVIDIA-Linux-x86_64-367.44/kernel/nvidia-uvm/uvm8_range_tree.o CC [M] /tmp/selfgz2659/NVIDIA-Linux-x86_64-367.44/kernel/nvidia-uvm/uvm8_range_allocator.o CC [M] /tmp/selfgz2659/NVIDIA-Linux-x86_64-367.44/kernel/nvidia-uvm/uvm8_va_range.o CC [M] /tmp/selfgz2659/NVIDIA-Linux-x86_64-367.44/kernel/nvidia-uvm/uvm8_va_block.o CC [M] /tmp/selfgz2659/NVIDIA-Linux-x86_64-367.44/kernel/nvidia-uvm/uvm8_range_group.o CC [M] /tmp/selfgz2659/NVIDIA-Linux-x86_64-367.44/kernel/nvidia-uvm/uvm8_gpu_page_fault.o CC [M] /tmp/selfgz2659/NVIDIA-Linux-x86_64-367.44/kernel/nvidia-uvm/uvm8_perf_events.o CC [M] /tmp/selfgz2659/NVIDIA-Linux-x86_64-367.44/kernel/nvidia-uvm/uvm8_perf_module.o CC [M] /tmp/selfgz2659/NVIDIA-Linux-x86_64-367.44/kernel/nvidia-uvm/uvm8_mmu.o CC [M] /tmp/selfgz2659/NVIDIA-Linux-x86_64-367.44/kernel/nvidia-uvm/uvm8_pte_batch.o CC [M] /tmp/selfgz2659/NVIDIA-Linux-x86_64-367.44/kernel/nvidia-uvm/uvm8_tlb_batch.o CC [M] /tmp/selfgz2659/NVIDIA-Linux-x86_64-367.44/kernel/nvidia-uvm/uvm8_push.o CC [M] /tmp/selfgz2659/NVIDIA-Linux-x86_64-367.44/kernel/nvidia-uvm/uvm8_pushbuffer.o CC [M] /tmp/selfgz2659/NVIDIA-Linux-x86_64-367.44/kernel/nvidia-uvm/uvm8_thread_context.o CC [M] /tmp/selfgz2659/NVIDIA-Linux-x86_64-367.44/kernel/nvidia-uvm/uvm8_tracker.o CC [M] /tmp/selfgz2659/NVIDIA-Linux-x86_64-367.44/kernel/nvidia-uvm/uvm8_kepler.o CC [M] /tmp/selfgz2659/NVIDIA-Linux-x86_64-367.44/kernel/nvidia-uvm/uvm8_kepler_ce.o CC [M] /tmp/selfgz2659/NVIDIA-Linux-x86_64-367.44/kernel/nvidia-uvm/uvm8_kepler_host.o CC [M] /tmp/selfgz2659/NVIDIA-Linux-x86_64-367.44/kernel/nvidia-uvm/uvm8_kepler_mmu.o CC [M] /tmp/selfgz2659/NVIDIA-Linux-x86_64-367.44/kernel/nvidia-uvm/uvm8_maxwell.o CC [M] /tmp/selfgz2659/NVIDIA-Linux-x86_64-367.44/kernel/nvidia-uvm/uvm8_maxwell_host.o CC [M] /tmp/selfgz2659/NVIDIA-Linux-x86_64-367.44/kernel/nvidia-uvm/uvm8_pascal.o CC [M] /tmp/selfgz2659/NVIDIA-Linux-x86_64-367.44/kernel/nvidia-uvm/uvm8_pascal_ce.o CC [M] /tmp/selfgz2659/NVIDIA-Linux-x86_64-367.44/kernel/nvidia-uvm/uvm8_pascal_host.o CC [M] /tmp/selfgz2659/NVIDIA-Linux-x86_64-367.44/kernel/nvidia-uvm/uvm8_pascal_mmu.o CC [M] /tmp/selfgz2659/NVIDIA-Linux-x86_64-367.44/kernel/nvidia-uvm/uvm8_pascal_fault_buffer.o CC [M] /tmp/selfgz2659/NVIDIA-Linux-x86_64-367.44/kernel/nvidia-uvm/uvm8_policy.o CC [M] /tmp/selfgz2659/NVIDIA-Linux-x86_64-367.44/kernel/nvidia-uvm/uvm8_perf_utils.o CC [M] /tmp/selfgz2659/NVIDIA-Linux-x86_64-367.44/kernel/nvidia-uvm/uvm8_kvmalloc.o CC [M] /tmp/selfgz2659/NVIDIA-Linux-x86_64-367.44/kernel/nvidia-uvm/uvm8_pmm_gpu.o CC [M] /tmp/selfgz2659/NVIDIA-Linux-x86_64-367.44/kernel/nvidia-uvm/uvm8_migrate.o CC [M] /tmp/selfgz2659/NVIDIA-Linux-x86_64-367.44/kernel/nvidia-uvm/uvm8_map_external.o CC [M] /tmp/selfgz2659/NVIDIA-Linux-x86_64-367.44/kernel/nvidia-uvm/uvm8_user_channel.o CC [M] /tmp/selfgz2659/NVIDIA-Linux-x86_64-367.44/kernel/nvidia-uvm/uvm8_hmm.o CC [M] /tmp/selfgz2659/NVIDIA-Linux-x86_64-367.44/kernel/nvidia-uvm/uvm8_perf_heuristics.o CC [M] /tmp/selfgz2659/NVIDIA-Linux-x86_64-367.44/kernel/nvidia-uvm/uvm8_perf_thrashing.o CC [M] /tmp/selfgz2659/NVIDIA-Linux-x86_64-367.44/kernel/nvidia-uvm/uvm8_perf_prefetch.o CC [M] /tmp/selfgz2659/NVIDIA-Linux-x86_64-367.44/kernel/nvidia-uvm/uvm8_test.o CC [M] /tmp/selfgz2659/NVIDIA-Linux-x86_64-367.44/kernel/nvidia-uvm/uvm8_test_rng.o CC [M] /tmp/selfgz2659/NVIDIA-Linux-x86_64-367.44/kernel/nvidia-uvm/uvm8_range_tree_test.o CC [M] /tmp/selfgz2659/NVIDIA-Linux-x86_64-367.44/kernel/nvidia-uvm/uvm8_range_allocator_test.o CC [M] /tmp/selfgz2659/NVIDIA-Linux-x86_64-367.44/kernel/nvidia-uvm/uvm8_gpu_semaphore_test.o CC [M] /tmp/selfgz2659/NVIDIA-Linux-x86_64-367.44/kernel/nvidia-uvm/uvm8_mem_test.o CC [M] /tmp/selfgz2659/NVIDIA-Linux-x86_64-367.44/kernel/nvidia-uvm/uvm8_rm_mem_test.o CC [M] /tmp/selfgz2659/NVIDIA-Linux-x86_64-367.44/kernel/nvidia-uvm/uvm8_page_tree_test.o CC [M] /tmp/selfgz2659/NVIDIA-Linux-x86_64-367.44/kernel/nvidia-uvm/uvm8_tracker_test.o CC [M] /tmp/selfgz2659/NVIDIA-Linux-x86_64-367.44/kernel/nvidia-uvm/uvm8_push_test.o CC [M] /tmp/selfgz2659/NVIDIA-Linux-x86_64-367.44/kernel/nvidia-uvm/uvm8_channel_test.o CC [M] /tmp/selfgz2659/NVIDIA-Linux-x86_64-367.44/kernel/nvidia-uvm/uvm8_ce_test.o CC [M] /tmp/selfgz2659/NVIDIA-Linux-x86_64-367.44/kernel/nvidia-uvm/uvm8_lock_test.o CC [M] /tmp/selfgz2659/NVIDIA-Linux-x86_64-367.44/kernel/nvidia-uvm/uvm8_perf_utils_test.o CC [M] /tmp/selfgz2659/NVIDIA-Linux-x86_64-367.44/kernel/nvidia-uvm/uvm8_kvmalloc_test.o CC [M] /tmp/selfgz2659/NVIDIA-Linux-x86_64-367.44/kernel/nvidia-uvm/uvm8_pmm_test.o CC [M] /tmp/selfgz2659/NVIDIA-Linux-x86_64-367.44/kernel/nvidia-uvm/uvm8_perf_events_test.o CC [M] /tmp/selfgz2659/NVIDIA-Linux-x86_64-367.44/kernel/nvidia-uvm/uvm8_perf_module_test.o CC [M] /tmp/selfgz2659/NVIDIA-Linux-x86_64-367.44/kernel/nvidia-uvm/uvm8_get_rm_ptes_test.o CC [M] /tmp/selfgz2659/NVIDIA-Linux-x86_64-367.44/kernel/nvidia-uvm/uvm8_fault_buffer_flush_test.o CC [M] /tmp/selfgz2659/NVIDIA-Linux-x86_64-367.44/kernel/nvidia-uvm/uvm8_mmu_test.o CC [M] /tmp/selfgz2659/NVIDIA-Linux-x86_64-367.44/kernel/nvidia-uvm/uvm8_peer_identity_mappings_test.o CC [M] /tmp/selfgz2659/NVIDIA-Linux-x86_64-367.44/kernel/nvidia-uvm/uvm8_va_block_test.o CC [M] /tmp/selfgz2659/NVIDIA-Linux-x86_64-367.44/kernel/nvidia-uvm/uvm8_range_group_tree_test.o CC [M] /tmp/selfgz2659/NVIDIA-Linux-x86_64-367.44/kernel/nvidia-modeset/nvidia-modeset-linux.o CC [M] /tmp/selfgz2659/NVIDIA-Linux-x86_64-367.44/kernel/nvidia-drm/nvidia-drm.o CC [M] /tmp/selfgz2659/NVIDIA-Linux-x86_64-367.44/kernel/nvidia-drm/nvidia-drm-drv.o CC [M] /tmp/selfgz2659/NVIDIA-Linux-x86_64-367.44/kernel/nvidia-drm/nvidia-drm-utils.o CC [M] /tmp/selfgz2659/NVIDIA-Linux-x86_64-367.44/kernel/nvidia-drm/nvidia-drm-crtc.o CC [M] /tmp/selfgz2659/NVIDIA-Linux-x86_64-367.44/kernel/nvidia-drm/nvidia-drm-encoder.o CC [M] /tmp/selfgz2659/NVIDIA-Linux-x86_64-367.44/kernel/nvidia-drm/nvidia-drm-connector.o CC [M] /tmp/selfgz2659/NVIDIA-Linux-x86_64-367.44/kernel/nvidia-drm/nvidia-drm-gem.o CC [M] /tmp/selfgz2659/NVIDIA-Linux-x86_64-367.44/kernel/nvidia-drm/nvidia-drm-fb.o CC [M] /tmp/selfgz2659/NVIDIA-Linux-x86_64-367.44/kernel/nvidia-drm/nvidia-drm-modeset.o CC [M] /tmp/selfgz2659/NVIDIA-Linux-x86_64-367.44/kernel/nvidia-drm/nvidia-drm-mmap.o CC [M] /tmp/selfgz2659/NVIDIA-Linux-x86_64-367.44/kernel/nvidia-drm/nvidia-drm-linux.o CC [M] /tmp/selfgz2659/NVIDIA-Linux-x86_64-367.44/kernel/nvidia-drm/nv-pci-table.o ld -r -o /tmp/selfgz2659/NVIDIA-Linux-x86_64-367.44/kernel/nvidia/nv-interface.o /tmp/selfgz2659/NVIDIA-Linux-x86_64-367.44/kernel/nvidia/nv-frontend.o /tmp/selfgz2659/NVIDIA-Linux-x86_64-367.44/kernel/nvidia/nv-instance.o /tmp/selfgz2659/NVIDIA-Linux-x86_64-367.44/kernel/nvidia/nv.o /tmp/selfgz2659/NVIDIA-Linux-x86_64-367.44/kernel/nvidia/nv-acpi.o /tmp/selfgz2659/NVIDIA-Linux-x86_64-367.44/kernel/nvidia/nv-chrdev.o /tmp/selfgz2659/NVIDIA-Linux-x86_64-367.44/kernel/nvidia/nv-cray.o /tmp/selfgz2659/NVIDIA-Linux-x86_64-367.44/kernel/nvidia/nv-dma.o /tmp/selfgz2659/NVIDIA-Linux-x86_64-367.44/kernel/nvidia/nv-gvi.o /tmp/selfgz2659/NVIDIA-Linux-x86_64-367.44/kernel/nvidia/nv-i2c.o /tmp/selfgz2659/NVIDIA-Linux-x86_64-367.44/kernel/nvidia/nv-mempool.o /tmp/selfgz2659/NVIDIA-Linux-x86_64-367.44/kernel/nvidia/nv-mmap.o /tmp/selfgz2659/NVIDIA-Linux-x86_64-367.44/kernel/nvidia/nv-p2p.o /tmp/selfgz2659/NVIDIA-Linux-x86_64-367.44/kernel/nvidia/nv-pat.o /tmp/selfgz2659/NVIDIA-Linux-x86_64-367.44/kernel/nvidia/nv-procfs.o /tmp/selfgz2659/NVIDIA-Linux-x86_64-367.44/kernel/nvidia/nv-usermap.o /tmp/selfgz2659/NVIDIA-Linux-x86_64-367.44/kernel/nvidia/nv-vm.o /tmp/selfgz2659/NVIDIA-Lin ux-x86_64-367.44/kernel/nvidia/nv-vtophys.o /tmp/selfgz2659/NVIDIA-Linux-x86_64-367.44/kernel/nvidia/os-interface.o /tmp/selfgz2659/NVIDIA-Linux-x86_64-367.44/kernel/nvidia/os-mlock.o /tmp/selfgz2659/NVIDIA-Linux-x86_64-367.44/kernel/nvidia/os-pci.o /tmp/selfgz2659/NVIDIA-Linux-x86_64-367.44/kernel/nvidia/os-registry.o /tmp/selfgz2659/NVIDIA-Linux-x86_64-367.44/kernel/nvidia/os-usermap.o /tmp/selfgz2659/NVIDIA-Linux-x86_64-367.44/kernel/nvidia/nv-modeset-interface.o /tmp/selfgz2659/NVIDIA-Linux-x86_64-367.44/kernel/nvidia/nv-pci-table.o /tmp/selfgz2659/NVIDIA-Linux-x86_64-367.44/kernel/nvidia/nv_uvm_interface.o /tmp/selfgz2659/NVIDIA-Linux-x86_64-367.44/kernel/nvidia/nvlink_linux.o /tmp/selfgz2659/NVIDIA-Linux-x86_64-367.44/kernel/nvidia/nvlink_pci.o /tmp/selfgz2659/NVIDIA-Linux-x86_64-367.44/kernel/nvidia/ebridge_linux.o /tmp/selfgz2659/NVIDIA-Linux-x86_64-367.44/kernel/nvidia/ibmnpu_linux.o ld -r -o /tmp/selfgz2659/NVIDIA-Linux-x86_64-367.44/kernel/nvidia-modeset/nv-modeset-interface.o /tmp/selfgz2659/NVIDIA-Linux-x86_64-367.44/kernel/nvidia-modeset/nvidia-modeset-linux.o LD [M] /tmp/selfgz2659/NVIDIA-Linux-x86_64-367.44/kernel/nvidia.o LD [M] /tmp/selfgz2659/NVIDIA-Linux-x86_64-367.44/kernel/nvidia-modeset.o LD [M] /tmp/selfgz2659/NVIDIA-Linux-x86_64-367.44/kernel/nvidia-drm.o LD [M] /tmp/selfgz2659/NVIDIA-Linux-x86_64-367.44/kernel/nvidia-uvm.o Building modules, stage 2. MODPOST 4 modules CC /tmp/selfgz2659/NVIDIA-Linux-x86_64-367.44/kernel/nvidia-drm.mod.o CC /tmp/selfgz2659/NVIDIA-Linux-x86_64-367.44/kernel/nvidia-modeset.mod.o CC /tmp/selfgz2659/NVIDIA-Linux-x86_64-367.44/kernel/nvidia-uvm.mod.o CC /tmp/selfgz2659/NVIDIA-Linux-x86_64-367.44/kernel/nvidia.mod.o LD [M] /tmp/selfgz2659/NVIDIA-Linux-x86_64-367.44/kernel/nvidia.ko LD [M] /tmp/selfgz2659/NVIDIA-Linux-x86_64-367.44/kernel/nvidia-modeset.ko LD [M] /tmp/selfgz2659/NVIDIA-Linux-x86_64-367.44/kernel/nvidia-drm.ko LD [M] /tmp/selfgz2659/NVIDIA-Linux-x86_64-367.44/kernel/nvidia-uvm.ko make[1]: Leaving directory /usr/src/linux-headers-4.2.0-42-generic’
→ done.
→ Kernel module compilation complete.
→ Unable to determine if Secure Boot is enabled: No such file or directory
→ Kernel messages:
[ 396.549672] nvidia: module license ‘NVIDIA’ taints kernel.
[ 396.549677] Disabling lock debugging due to kernel taint
[ 396.554174] nvidia: module verification failed: signature and/or required key missing - tainting kernel
[ 396.562532] nvidia 0000:0a:00.0: enabling device (0100 → 0103)
[ 396.562657] vgaarb: device changed decodes: PCI:0000:0a:00.0,olddecodes=io+mem,decodes=none:owns=none
[ 396.562743] nvidia 0000:09:00.0: enabling device (0100 → 0103)
[ 396.562828] vgaarb: device changed decodes: PCI:0000:09:00.0,olddecodes=io+mem,decodes=none:owns=none
[ 396.562902] nvidia 0000:06:00.0: enabling device (0100 → 0103)
[ 396.562985] vgaarb: device changed decodes: PCI:0000:06:00.0,olddecodes=io+mem,decodes=none:owns=none
[ 396.563131] vgaarb: device changed decodes: PCI:0000:05:00.0,olddecodes=io+mem,decodes=none:owns=io+mem
[ 396.563209] nvidia-nvlink: Nvlink Core is being initialized, major device number 244
[ 396.563240] NVRM: loading NVIDIA UNIX x86_64 Kernel Module 367.44 Wed Aug 17 22:24:07 PDT 2016
[ 396.566069] nvidia-uvm: Loaded the UVM driver in 8 mode, major device number 243
[ 396.567465] nvidia-modeset: Loading NVIDIA Kernel Mode Setting Driver for UNIX platforms 367.44 Wed Aug 17 21:54:40 PDT 2016
[ 396.568386] [drm] [nvidia-drm] [GPU ID 0x00000a00] Loading driver
[ 396.568528] [drm] [nvidia-drm] [GPU ID 0x00000900] Loading driver
[ 396.568674] [drm] [nvidia-drm] [GPU ID 0x00000600] Loading driver
[ 396.568845] [drm] [nvidia-drm] [GPU ID 0x00000500] Loading driver
[ 396.570189] [drm] [nvidia-drm] [GPU ID 0x00000500] Unloading driver
[ 396.570303] [drm] [nvidia-drm] [GPU ID 0x00000600] Unloading driver
[ 396.570424] [drm] [nvidia-drm] [GPU ID 0x00000900] Unloading driver
[ 396.570579] [drm] [nvidia-drm] [GPU ID 0x00000a00] Unloading driver
[ 396.588934] nvidia-modeset: Unloading
[ 396.605413] nvidia-uvm: Unloaded the UVM driver in 8 mode
[ 396.621145] nvidia-nvlink: Unregistered the Nvlink Core, major device number 244
→ Installing both new and classic TLS OpenGL libraries.
→ Installing classic TLS 32bit OpenGL libraries.
WARNING: Unable to find a suitable destination to install 32-bit compatibility libraries. Your system may not be set up for 32-bit compatibility. 32-bit compatibility files will not be installed; if you wish to install them, re-run the installation and set a valid directory with the --compat32-libdir option.
→ Will install GLVND GLX client libraries.
Looking for install checker script at ./libglvnd_install_checker/check-libglvnd-install.sh
executing: ‘/bin/sh ./libglvnd_install_checker/check-libglvnd-install.sh’…
Checking for libglvnd installation.
Checking libGLdispatch…
Can’t load library libGLdispatch.so.0: libGLdispatch.so.0: cannot open shared object file: No such file or directory
Will install libglvnd libraries.
→ Searching for conflicting files:
→ done.
→ Installing ‘NVIDIA Accelerated Graphics Driver for Linux-x86_64’ (367.44):
executing: ‘/sbin/ldconfig’…
executing: '/sbin/depmod -a '…
→ done.
→ Driver file installation is complete.
→ Running post-install sanity check:
→ done.
→ Post-install sanity check passed.
→ Running runtime sanity check:
→ done.
→ Runtime sanity check passed.
→ Would you like to run the nvidia-xconfig utility to automatically update your X configuration file so that the NVIDIA X driver will be used when you restart X? Any pre-existing X configuration file will be backed up. (Answer: Yes)
→ Your X configuration file has been successfully updated. Installation of the NVIDIA Accelerated Graphics Driver for Linux-x86_64 (version: 367.44) is now complete.
*** /var/log/Xorg.0.log
*** ls: -rw-r–r-- 1 root root 39180 2016-12-29 10:30:01.712183167 -0800 /var/log/Xorg.0.log
[ 27.166]
X.Org X Server 1.15.1
Release Date: 2014-04-13
[ 27.166] X Protocol Version 11, Revision 0
[ 27.166] Build Operating System: Linux 3.2.0-76-generic x86_64 Ubuntu
[ 27.166] Current Operating System: Linux ubuntu 4.2.0-42-generic #49~14.04.1-Ubuntu SMP Wed Jun 29 20:22:11 UTC 2016 x86_64
[ 27.166] Kernel command line: BOOT_IMAGE=/vmlinuz-4.2.0-42-generic root=UUID=5fbdb4ac-c3d1-413e-978a-3a53ac9653d9 ro nomdmonddf nomdmonisw
[ 27.166] Build Date: 12 February 2015 02:49:29PM
[ 27.166] xorg-server 2:1.15.1-0ubuntu2.7 (For technical support please see Enterprise open source support | Ubuntu)
[ 27.166] Current version of pixman: 0.30.2
[ 27.166] Before reporting problems, check http://wiki.x.org
to make sure that you have the latest version.
[ 27.166] Markers: (–) probed, () from config file, (==) default setting,
(++) from command line, (!!) notice, (II) informational,
(WW) warning, (EE) error, (NI) not implemented, (??) unknown.
[ 27.166] (==) Log file: “/var/log/Xorg.0.log”, Time: Thu Dec 29 10:24:44 2016
[ 27.166] (==) Using config file: “/etc/X11/xorg.conf”
[ 27.166] (==) Using system config directory “/usr/share/X11/xorg.conf.d”
[ 27.166] (==) ServerLayout “Layout0”
[ 27.166] (
) |–>Screen “Screen0” (0)
[ 27.166] () | |–>Monitor “Monitor0”
[ 27.166] (
) | |–>Device “Device0”
[ 27.166] () |–>Input Device “Keyboard0”
[ 27.166] (
) |–>Input Device “Mouse0”
[ 27.166] (==) Automatically adding devices
[ 27.166] (==) Automatically enabling devices
[ 27.166] (==) Automatically adding GPU devices
[ 27.167] (WW) The directory “/usr/share/fonts/X11/cyrillic” does not exist.
[ 27.167] Entry deleted from font path.
[ 27.167] (WW) The directory “/usr/share/fonts/X11/100dpi/” does not exist.
[ 27.167] (WW) The directory “/usr/share/fonts/X11/75dpi/” does not exist.
[ 27.167] (WW) The directory “/usr/share/fonts/X11/100dpi” does not exist.
[ 27.167] (WW) The directory “/usr/share/fonts/X11/75dpi” does not exist.
[ 27.167] (==) FontPath set to:
/usr/share/fonts/X11/misc,
/usr/share/fonts/X11/Type1,
built-ins
[ 27.167] (==) ModulePath set to “/usr/lib/x86_64-linux-gnu/xorg/extra-modules,/usr/lib/xorg/extra-modules,/usr/lib/xorg/modules”
[ 27.167] (WW) Hotplugging is on, devices using drivers ‘kbd’, ‘mouse’ or ‘vmmouse’ will be disabled.
[ 27.167] (WW) Disabling Keyboard0
[ 27.167] (WW) Disabling Mouse0
[ 27.167] (II) Loader magic: 0x5650c6d40d40
[ 27.167] (II) Module ABI versions:
[ 27.167] X.Org ANSI C Emulation: 0.4
[ 27.167] X.Org Video Driver: 15.0
[ 27.167] X.Org XInput driver : 20.0
[ 27.167] X.Org Server Extension : 8.0
[ 27.167] (II) xfree86: Adding drm device (/dev/dri/card0)
[ 27.167] (II) xfree86: Adding drm device (/dev/dri/card1)
[ 27.167] (II) xfree86: Adding drm device (/dev/dri/card2)
[ 27.167] (II) xfree86: Adding drm device (/dev/dri/card3)
[ 27.169] (–) PCI:*(0:5:0:0) 10de:1b00:10de:119a rev 161, Mem @ 0xfa000000/16777216, 0xc0000000/268435456, 0xd0000000/33554432, I/O @ 0x0000d000/128, BIOS @ 0x???/524288
[ 27.169] (–) PCI: (0:6:0:0) 10de:1b00:10de:119a rev 161, Mem @ 0xf8000000/16777216, 0xa0000000/268435456, 0xb0000000/33554432, I/O @ 0x0000c000/128, BIOS @ 0x???/524288
[ 27.169] (–) PCI: (0:9:0:0) 10de:1b00:10de:119a rev 161, Mem @ 0xf6000000/16777216, 0x80000000/268435456, 0x90000000/33554432, I/O @ 0x0000b000/128, BIOS @ 0x???/524288
[ 27.169] (–) PCI: (0:10:0:0) 10de:1b00:10de:119a rev 161, Mem @ 0xf4000000/16777216, 0x60000000/268435456, 0x70000000/33554432, I/O @ 0x0000a000/128, BIOS @ 0x???/524288
[ 27.169] Initializing built-in extension Generic Event Extension
[ 27.169] Initializing built-in extension SHAPE
[ 27.169] Initializing built-in extension MIT-SHM
[ 27.169] Initializing built-in extension XInputExtension
[ 27.169] Initializing built-in extension XTEST
[ 27.169] Initializing built-in extension BIG-REQUESTS
[ 27.169] Initializing built-in extension SYNC
[ 27.169] Initializing built-in extension XKEYBOARD
[ 27.169] Initializing built-in extension XC-MISC
[ 27.169] Initializing built-in extension SECURITY
[ 27.169] Initializing built-in extension XINERAMA
[ 27.169] Initializing built-in extension XFIXES
[ 27.169] Initializing built-in extension RENDER
[ 27.169] Initializing built-in extension RANDR
[ 27.170] Initializing built-in extension COMPOSITE
[ 27.170] Initializing built-in extension DAMAGE
[ 27.170] Initializing built-in extension MIT-SCREEN-SAVER
[ 27.170] Initializing built-in extension DOUBLE-BUFFER
[ 27.170] Initializing built-in extension RECORD
[ 27.170] Initializing built-in extension DPMS
[ 27.170] Initializing built-in extension Present
[ 27.170] Initializing built-in extension DRI3
[ 27.170] Initializing built-in extension X-Resource
[ 27.170] Initializing built-in extension XVideo
[ 27.170] Initializing built-in extension XVideo-MotionCompensation
[ 27.170] Initializing built-in extension SELinux
[ 27.170] Initializing built-in extension XFree86-VidModeExtension
[ 27.170] Initializing built-in extension XFree86-DGA
[ 27.170] Initializing built-in extension XFree86-DRI
[ 27.170] Initializing built-in extension DRI2
[ 27.170] (II) LoadModule: “glx”
[ 27.170] (II) Loading /usr/lib/xorg/modules/extensions/libglx.so
[ 27.205] (II) Module glx: vendor=“NVIDIA Corporation”
[ 27.205] compiled for 4.0.2, module version = 1.0.0
[ 27.205] Module class: X.Org Server Extension
[ 27.206] (II) NVIDIA GLX Module 367.44 Wed Aug 17 21:50:26 PDT 2016
[ 27.206] Loading extension GLX
[ 27.206] (II) LoadModule: “nvidia”
[ 27.206] (II) Loading /usr/lib/xorg/modules/drivers/nvidia_drv.so
[ 27.206] (II) Module nvidia: vendor=“NVIDIA Corporation”
[ 27.206] compiled for 4.0.2, module version = 1.0.0
[ 27.207] Module class: X.Org Video Driver
[ 27.207] (II) NVIDIA dlloader X Driver 367.44 Wed Aug 17 21:28:13 PDT 2016
[ 27.207] (II) NVIDIA Unified Driver for all Supported NVIDIA GPUs
[ 27.207] (++) using VT number 7
[ 27.213] (II) Loading sub module “fb”
[ 27.213] (II) LoadModule: “fb”
[ 27.213] (II) Loading /usr/lib/xorg/modules/libfb.so
[ 27.213] (II) Module fb: vendor=“X.Org Foundation”
[ 27.213] compiled for 1.15.1, module version = 1.0.0
[ 27.213] ABI class: X.Org ANSI C Emulation, version 0.4
[ 27.213] (II) Loading sub module “wfb”
[ 27.213] (II) LoadModule: “wfb”
[ 27.213] (II) Loading /usr/lib/xorg/modules/libwfb.so
[ 27.213] (II) Module wfb: vendor=“X.Org Foundation”
[ 27.213] (II) Loading sub module “ramdac”
[ 27.213] (II) LoadModule: “ramdac”
[ 27.213] (II) Module “ramdac” already built-in
[ 27.889] () NVIDIA(0): Depth 24, (–) framebuffer bpp 32
[ 27.889] (==) NVIDIA(0): RGB weight 888
[ 27.889] (==) NVIDIA(0): Default visual is TrueColor
[ 27.889] (==) NVIDIA(0): Using gamma correction (1.0, 1.0, 1.0)
[ 27.889] (
) NVIDIA(0): Enabling 2D acceleration
[ 30.152] (–) NVIDIA(0): Valid display device(s) on GPU-0 at PCI:5:0:0
[ 30.152] (–) NVIDIA(0): DFP-0
[ 30.152] (–) NVIDIA(0): DFP-1 (boot)
[ 30.152] (–) NVIDIA(0): DFP-2
[ 30.152] (–) NVIDIA(0): DFP-3
[ 30.152] (–) NVIDIA(0): DFP-4
[ 30.152] (–) NVIDIA(0): DFP-5
[ 30.152] (–) NVIDIA(0): DFP-6
[ 30.152] (–) NVIDIA(0): DFP-7
[ 30.153] (–) NVIDIA(0): DFP-0: disconnected
[ 30.153] (–) NVIDIA(0): DFP-0: Internal TMDS
[ 30.153] (–) NVIDIA(0): DFP-0: 330.0 MHz maximum pixel clock
[ 30.185] (–) NVIDIA(0): DELL U2413 (DFP-1): connected
[ 30.185] (–) NVIDIA(0): DELL U2413 (DFP-1): Internal TMDS
[ 30.185] (–) NVIDIA(0): DELL U2413 (DFP-1): 600.0 MHz maximum pixel clock
[ 30.186] (–) NVIDIA(0): DFP-2: disconnected
[ 30.186] (–) NVIDIA(0): DFP-2: Internal DisplayPort
[ 30.186] (–) NVIDIA(0): DFP-2: 1440.0 MHz maximum pixel clock
[ 30.186] (–) NVIDIA(0): DFP-3: disconnected
[ 30.186] (–) NVIDIA(0): DFP-3: Internal TMDS
[ 30.186] (–) NVIDIA(0): DFP-3: 330.0 MHz maximum pixel clock
[ 30.187] (–) NVIDIA(0): DFP-4: disconnected
[ 30.187] (–) NVIDIA(0): DFP-4: Internal DisplayPort
[ 30.187] (–) NVIDIA(0): DFP-4: 1440.0 MHz maximum pixel clock
[ 30.190] (–) NVIDIA(0): DFP-5: disconnected
[ 30.190] (–) NVIDIA(0): DFP-5: Internal TMDS
[ 30.190] (–) NVIDIA(0): DFP-5: 330.0 MHz maximum pixel clock
[ 30.190] (–) NVIDIA(0): DFP-6: disconnected
[ 30.190] (–) NVIDIA(0): DFP-6: Internal DisplayPort
[ 30.190] (–) NVIDIA(0): DFP-6: 1440.0 MHz maximum pixel clock
[ 30.190] (–) NVIDIA(0): DFP-7: disconnected
[ 30.190] (–) NVIDIA(0): DFP-7: Internal TMDS
[ 30.190] (–) NVIDIA(0): DFP-7: 330.0 MHz maximum pixel clock
[ 30.202] (II) NVIDIA(0): NVIDIA GPU TITAN X (Pascal) (GP102-A) at PCI:5:0:0 (GPU-0)
[ 30.202] (–) NVIDIA(0): Memory: 12582912 kBytes
[ 30.202] (–) NVIDIA(0): VideoBIOS: 86.02.15.00.01
[ 30.202] (II) NVIDIA(0): Detected PCI Express Link width: 16X
[ 30.202] () NVIDIA(0): Using HorizSync/VertRefresh ranges from the EDID for display
[ 30.202] (
) NVIDIA(0): device DELL U2413 (DFP-1) (Using EDID frequencies has been
[ 30.202] () NVIDIA(0): enabled on all display devices.)
[ 30.207] (==) NVIDIA(0):
[ 30.207] (==) NVIDIA(0): No modes were requested; the default mode “nvidia-auto-select”
[ 30.207] (==) NVIDIA(0): will be used as the requested mode.
[ 30.207] (II) NVIDIA(0): Validated MetaModes:
[ 30.207] (II) NVIDIA(0): “DFP-1:nvidia-auto-select”
[ 30.207] (II) NVIDIA(0): Virtual screen size determined to be 1920 x 1200
[ 30.234] (–) NVIDIA(0): DPI set to (93, 95); computed from “UseEdidDpi” X config
[ 30.234] (–) NVIDIA(0): option
[ 30.234] (–) Depth 24 pixmap format is 32 bpp
[ 30.344] (–) NVIDIA(0): Valid display device(s) on GPU-1 at PCI:10:0:0
[ 30.344] (–) NVIDIA(0): DFP-0
[ 30.344] (–) NVIDIA(0): DFP-1
[ 30.344] (–) NVIDIA(0): DFP-2
[ 30.344] (–) NVIDIA(0): DFP-3
[ 30.344] (–) NVIDIA(0): DFP-4
[ 30.344] (–) NVIDIA(0): DFP-5
[ 30.344] (–) NVIDIA(0): DFP-6
[ 30.344] (–) NVIDIA(0): DFP-7
[ 30.344] (–) NVIDIA(0): DFP-0: disconnected
[ 30.344] (–) NVIDIA(0): DFP-0: Internal TMDS
[ 30.344] (–) NVIDIA(0): DFP-0: 330.0 MHz maximum pixel clock
[ 30.344] (–) NVIDIA(0): DFP-1: disconnected
[ 30.344] (–) NVIDIA(0): DFP-1: Internal TMDS
[ 30.344] (–) NVIDIA(0): DFP-1: 330.0 MHz maximum pixel clock
[ 30.344] (–) NVIDIA(0): DFP-2: disconnected
[ 30.344] (–) NVIDIA(0): DFP-2: Internal DisplayPort
[ 30.344] (–) NVIDIA(0): DFP-2: 1440.0 MHz maximum pixel clock
[ 30.344] (–) NVIDIA(0): DFP-3: disconnected
[ 30.344] (–) NVIDIA(0): DFP-3: Internal TMDS
[ 30.344] (–) NVIDIA(0): DFP-3: 330.0 MHz maximum pixel clock
[ 30.345] (–) NVIDIA(0): DFP-4: disconnected
[ 30.345] (–) NVIDIA(0): DFP-4: Internal DisplayPort
[ 30.345] (–) NVIDIA(0): DFP-4: 1440.0 MHz maximum pixel clock
[ 30.345] (–) NVIDIA(0): DFP-5: disconnected
[ 30.345] (–) NVIDIA(0): DFP-5: Internal TMDS
[ 30.345] (–) NVIDIA(0): DFP-5: 330.0 MHz maximum pixel clock
[ 30.345] (–) NVIDIA(0): DFP-6: disconnected
[ 30.345] (–) NVIDIA(0): DFP-6: Internal DisplayPort
[ 30.345] (–) NVIDIA(0): DFP-6: 1440.0 MHz maximum pixel clock
[ 30.345] (–) NVIDIA(0): DFP-7: disconnected
[ 30.345] (–) NVIDIA(0): DFP-7: Internal TMDS
[ 30.345] (–) NVIDIA(0): DFP-7: 330.0 MHz maximum pixel clock
[ 30.386] (II) NVIDIA(GPU-1): NVIDIA GPU TITAN X (Pascal) (GP102-A) at PCI:10:0:0 (GPU-1)
[ 30.386] (–) NVIDIA(GPU-1): Memory: 12582912 kBytes
[ 30.386] (–) NVIDIA(GPU-1): VideoBIOS: 86.02.15.00.01
[ 30.386] (II) NVIDIA(GPU-1): Detected PCI Express Link width: 16X
[ 30.410] (–) NVIDIA(0): Valid display device(s) on GPU-2 at PCI:9:0:0
[ 30.410] (–) NVIDIA(0): DFP-0
[ 30.410] (–) NVIDIA(0): DFP-1
[ 30.410] (–) NVIDIA(0): DFP-2
[ 30.410] (–) NVIDIA(0): DFP-3
[ 30.410] (–) NVIDIA(0): DFP-4
[ 30.410] (–) NVIDIA(0): DFP-5
[ 30.410] (–) NVIDIA(0): DFP-6
[ 30.410] (–) NVIDIA(0): DFP-7
[ 30.410] (–) NVIDIA(0): DFP-0: disconnected
[ 30.410] (–) NVIDIA(0): DFP-0: Internal TMDS
[ 30.410] (–) NVIDIA(0): DFP-0: 330.0 MHz maximum pixel clock
[ 30.411] (–) NVIDIA(0): DFP-1: disconnected
[ 30.411] (–) NVIDIA(0): DFP-1: Internal TMDS
[ 30.411] (–) NVIDIA(0): DFP-1: 330.0 MHz maximum pixel clock
[ 30.411] (–) NVIDIA(0): DFP-2: disconnected
[ 30.411] (–) NVIDIA(0): DFP-2: Internal DisplayPort
[ 30.411] (–) NVIDIA(0): DFP-2: 1440.0 MHz maximum pixel clock
[ 30.411] (–) NVIDIA(0): DFP-3: disconnected
[ 30.411] (–) NVIDIA(0): DFP-3: Internal TMDS
[ 30.411] (–) NVIDIA(0): DFP-3: 330.0 MHz maximum pixel clock
[ 30.411] (–) NVIDIA(0): DFP-4: disconnected
[ 30.411] (–) NVIDIA(0): DFP-4: Internal DisplayPort
[ 30.411] (–) NVIDIA(0): DFP-4: 1440.0 MHz maximum pixel clock
[ 30.411] (–) NVIDIA(0): DFP-5: disconnected
[ 30.411] (–) NVIDIA(0): DFP-5: Internal TMDS
[ 30.411] (–) NVIDIA(0): DFP-5: 330.0 MHz maximum pixel clock
[ 30.411] (–) NVIDIA(0): DFP-6: disconnected
[ 30.411] (–) NVIDIA(0): DFP-6: Internal DisplayPort
[ 30.411] (–) NVIDIA(0): DFP-6: 1440.0 MHz maximum pixel clock
[ 30.411] (–) NVIDIA(0): DFP-7: disconnected
[ 30.411] (–) NVIDIA(0): DFP-7: Internal TMDS
[ 30.411] (–) NVIDIA(0): DFP-7: 330.0 MHz maximum pixel clock
[ 30.445] (II) NVIDIA(GPU-2): NVIDIA GPU TITAN X (Pascal) (GP102-A) at PCI:9:0:0 (GPU-2)
[ 30.445] (–) NVIDIA(GPU-2): Memory: 12582912 kBytes
[ 30.445] (–) NVIDIA(GPU-2): VideoBIOS: 86.02.15.00.01
[ 30.445] (II) NVIDIA(GPU-2): Detected PCI Express Link width: 16X
[ 30.471] (–) NVIDIA(0): Valid display device(s) on GPU-3 at PCI:6:0:0
[ 30.471] (–) NVIDIA(0): DFP-0
[ 30.471] (–) NVIDIA(0): DFP-1
[ 30.471] (–) NVIDIA(0): DFP-2
[ 30.471] (–) NVIDIA(0): DFP-3
[ 30.471] (–) NVIDIA(0): DFP-4
[ 30.471] (–) NVIDIA(0): DFP-5
[ 30.471] (–) NVIDIA(0): DFP-6
[ 30.471] (–) NVIDIA(0): DFP-7
[ 30.471] (–) NVIDIA(0): DFP-0: disconnected
[ 30.471] (–) NVIDIA(0): DFP-0: Internal TMDS
[ 30.471] (–) NVIDIA(0): DFP-0: 330.0 MHz maximum pixel clock
[ 30.472] (–) NVIDIA(0): DFP-1: disconnected
[ 30.472] (–) NVIDIA(0): DFP-1: Internal TMDS
[ 30.472] (–) NVIDIA(0): DFP-1: 330.0 MHz maximum pixel clock
[ 30.472] (–) NVIDIA(0): DFP-2: disconnected
[ 30.472] (–) NVIDIA(0): DFP-2: Internal DisplayPort
[ 30.472] (–) NVIDIA(0): DFP-2: 1440.0 MHz maximum pixel clock
[ 30.472] (–) NVIDIA(0): DFP-3: disconnected
[ 30.472] (–) NVIDIA(0): DFP-3: Internal TMDS
[ 30.472] (–) NVIDIA(0): DFP-3: 330.0 MHz maximum pixel clock
[ 30.472] (–) NVIDIA(0): DFP-4: disconnected
[ 30.472] (–) NVIDIA(0): DFP-4: Internal DisplayPort
[ 30.472] (–) NVIDIA(0): DFP-4: 1440.0 MHz maximum pixel clock
[ 30.472] (–) NVIDIA(0): DFP-5: disconnected
[ 30.472] (–) NVIDIA(0): DFP-5: Internal TMDS
[ 30.472] (–) NVIDIA(0): DFP-5: 330.0 MHz maximum pixel clock
[ 30.472] (–) NVIDIA(0): DFP-6: disconnected
[ 30.472] (–) NVIDIA(0): DFP-6: Internal DisplayPort
[ 30.472] (–) NVIDIA(0): DFP-6: 1440.0 MHz maximum pixel clock
[ 30.472] (–) NVIDIA(0): DFP-7: disconnected
[ 30.472] (–) NVIDIA(0): DFP-7: Internal TMDS
[ 30.472] (–) NVIDIA(0): DFP-7: 330.0 MHz maximum pixel clock
[ 30.511] (II) NVIDIA(GPU-3): NVIDIA GPU TITAN X (Pascal) (GP102-A) at PCI:6:0:0 (GPU-3)
[ 30.511] (–) NVIDIA(GPU-3): Memory: 12582912 kBytes
[ 30.511] (–) NVIDIA(GPU-3): VideoBIOS: 86.02.15.00.01
[ 30.511] (II) NVIDIA(GPU-3): Detected PCI Express Link width: 16X
[ 30.513] (II) NVIDIA: Using 49152.00 MB of virtual memory for indirect memory
[ 30.513] (II) NVIDIA: access.
[ 30.543] (II) NVIDIA(0): Setting mode “DFP-1:nvidia-auto-select”
[ 30.582] Loading extension NV-GLX
[ 30.592] (==) NVIDIA(0): Disabling shared memory pixmaps
[ 30.592] (==) NVIDIA(0): Backing store enabled
[ 30.592] (==) NVIDIA(0): Silken mouse enabled
[ 30.593] (
) NVIDIA(0): DPMS enabled
[ 30.594] Loading extension NV-CONTROL
[ 30.594] Loading extension XINERAMA
[ 30.594] (II) Loading sub module “dri2”
[ 30.594] (II) LoadModule: “dri2”
[ 30.594] (II) Module “dri2” already built-in
[ 30.594] (II) NVIDIA(0): [DRI2] Setup complete
[ 30.594] (II) NVIDIA(0): [DRI2] VDPAU driver: nvidia
[ 30.594] (–) RandR disabled
[ 30.599] (II) SELinux: Disabled on system
[ 30.600] (II) Initializing extension GLX
[ 30.625] (II) XKB: reuse xkmfile /var/lib/xkb/server-B20D7FC79C7F597315E3E501AEF10E0D866E8E92.xkm
[ 30.627] (II) config/udev: Adding input device Power Button (/dev/input/event1)
[ 30.627] () Power Button: Applying InputClass “evdev keyboard catchall”
[ 30.627] (II) LoadModule: “evdev”
[ 30.627] (II) Loading /usr/lib/xorg/modules/input/evdev_drv.so
[ 30.628] (II) Module evdev: vendor=“X.Org Foundation”
[ 30.628] compiled for 1.15.0, module version = 2.8.2
[ 30.628] Module class: X.Org XInput Driver
[ 30.628] ABI class: X.Org XInput driver, version 20.0
[ 30.628] (II) Using input driver ‘evdev’ for ‘Power Button’
[ 30.628] (
) Power Button: always reports core events
[ 30.628] () evdev: Power Button: Device: “/dev/input/event1”
[ 30.628] (–) evdev: Power Button: Vendor 0 Product 0x1
[ 30.628] (–) evdev: Power Button: Found keys
[ 30.628] (II) evdev: Power Button: Configuring as keyboard
[ 30.628] (
) Option “config_info” “udev:/sys/devices/LNXSYSTM:00/LNXPWRBN:00/input/input1/event1”
[ 30.628] (II) XINPUT: Adding extended input device “Power Button” (type: KEYBOARD, id 6)
[ 30.628] () Option “xkb_rules” “evdev”
[ 30.628] (
) Option “xkb_model” “pc105”
[ 30.628] () Option “xkb_layout” “us”
[ 30.628] (II) config/udev: Adding input device Power Button (/dev/input/event0)
[ 30.628] (
[ 30.628] () Power Button: always reports core events
[ 30.628] (
) evdev: Power Button: Device: “/dev/input/event0”
[ 30.628] () Option “config_info” “udev:/sys/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0C:00/input/input0/event0”
[ 30.628] (II) XINPUT: Adding extended input device “Power Button” (type: KEYBOARD, id 7)
[ 30.628] (
[ 30.628] () Option “xkb_model” “pc105”
[ 30.628] (
[ 30.628] (II) config/udev: Adding drm device (/dev/dri/card0) card0 /sys/devices/pci0000:00/0000:00:02.0/0000:07:00.0/0000:08:08.0/0000:0a:00.0/drm/card0
[ 30.628] (II) config/udev: Ignoring already known drm device (/dev/dri/card0)
[ 30.628] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=3 (/dev/input/event13)
[ 30.629] (II) No input driver specified, ignoring this device.
[ 30.629] (II) This device may have been added with another device file.
[ 30.629] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=7 (/dev/input/event14)
[ 30.629] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=8 (/dev/input/event15)
[ 30.629] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=9 (/dev/input/event16)
[ 30.629] (II) config/udev: Adding drm device (/dev/dri/card1) card1 /sys/devices/pci0000:00/0000:00:02.0/0000:07:00.0/0000:08:10.0/0000:09:00.0/drm/card1
[ 30.629] (II) config/udev: Ignoring already known drm device (/dev/dri/card1)
[ 30.629] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=3 (/dev/input/event17)
[ 30.629] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=7 (/dev/input/event18)
[ 30.629] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=8 (/dev/input/event19)
[ 30.629] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=9 (/dev/input/event20)
[ 30.629] (II) config/udev: Adding drm device (/dev/dri/card2) card2 /sys/devices/pci0000:00/0000:00:03.0/0000:03:00.0/0000:04:08.0/0000:06:00.0/drm/card2
[ 30.629] (II) config/udev: Ignoring already known drm device (/dev/dri/card2)
[ 30.629] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=3 (/dev/input/event21)
[ 30.629] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=7 (/dev/input/event22)
[ 30.630] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=8 (/dev/input/event23)
[ 30.630] (II) No input driver specified, ignoring this device.
[ 30.630] (II) This device may have been added with another device file.
[ 30.630] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=9 (/dev/input/event24)
[ 30.630] (II) config/udev: Adding drm device (/dev/dri/card3) card3 /sys/devices/pci0000:00/0000:00:03.0/0000:03:00.0/0000:04:10.0/0000:05:00.0/drm/card3
[ 30.630] (II) config/udev: Ignoring already known drm device (/dev/dri/card3)
[ 30.630] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=3 (/dev/input/event25)
[ 30.630] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=7 (/dev/input/event26)
[ 30.630] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=8 (/dev/input/event27)
[ 30.630] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=9 (/dev/input/event28)
[ 30.630] (II) config/udev: Adding input device Microsoft Natural® Ergonomic Keyboard 4000 (/dev/input/event2)
[ 30.630] () Microsoft Natural® Ergonomic Keyboard 4000: Applying InputClass “evdev keyboard catchall”
[ 30.630] (II) Using input driver ‘evdev’ for ‘Microsoft Natural® Ergonomic Keyboard 4000’
[ 30.630] (
) Microsoft Natural® Ergonomic Keyboard 4000: always reports core events
[ 30.630] () evdev: Microsoft Natural® Ergonomic Keyboard 4000: Device: “/dev/input/event2”
[ 30.630] (–) evdev: Microsoft Natural® Ergonomic Keyboard 4000: Vendor 0x45e Product 0xdb
[ 30.630] (–) evdev: Microsoft Natural® Ergonomic Keyboard 4000: Found keys
[ 30.630] (II) evdev: Microsoft Natural® Ergonomic Keyboard 4000: Configuring as keyboard
[ 30.630] (
) Option “config_info” “udev:/sys/devices/pci0000:00/0000:00:14.0/usb1/1-10/1-10.3/1-10.3:1.0/0003:045E:00DB.0001/input/input5/event2”
[ 30.630] (II) XINPUT: Adding extended input device “Microsoft Natural® Ergonomic Keyboard 4000” (type: KEYBOARD, id 8)
[ 30.630] () Option “xkb_rules” “evdev”
[ 30.630] (
[ 30.630] () Option “xkb_layout” “us”
[ 30.631] (II) config/udev: Adding input device Microsoft Natural® Ergonomic Keyboard 4000 (/dev/input/event4)
[ 30.631] (
[ 30.631] (II) Using input driver ‘evdev’ for ‘Microsoft Natural® Ergonomic Keyboard 4000’
[ 30.631] () Microsoft Natural® Ergonomic Keyboard 4000: always reports core events
[ 30.631] (
) evdev: Microsoft Natural® Ergonomic Keyboard 4000: Device: “/dev/input/event4”
[ 30.631] (–) evdev: Microsoft Natural® Ergonomic Keyboard 4000: Vendor 0x45e Product 0xdb
[ 30.631] (–) evdev: Microsoft Natural® Ergonomic Keyboard 4000: Found 1 mouse buttons
[ 30.631] (–) evdev: Microsoft Natural® Ergonomic Keyboard 4000: Found scroll wheel(s)
[ 30.631] (–) evdev: Microsoft Natural® Ergonomic Keyboard 4000: Found relative axes
[ 30.631] (II) evdev: Microsoft Natural® Ergonomic Keyboard 4000: Forcing relative x/y axes to exist.
[ 30.631] (–) evdev: Microsoft Natural® Ergonomic Keyboard 4000: Found absolute axes
[ 30.631] (II) evdev: Microsoft Natural® Ergonomic Keyboard 4000: Forcing absolute x/y axes to exist.
[ 30.631] (–) evdev: Microsoft Natural® Ergonomic Keyboard 4000: Found keys
[ 30.631] (II) evdev: Microsoft Natural® Ergonomic Keyboard 4000: Configuring as mouse
[ 30.631] (II) evdev: Microsoft Natural® Ergonomic Keyboard 4000: Configuring as keyboard
[ 30.631] (II) evdev: Microsoft Natural® Ergonomic Keyboard 4000: Adding scrollwheel support
[ 30.631] () evdev: Microsoft Natural® Ergonomic Keyboard 4000: YAxisMapping: buttons 4 and 5
[ 30.631] (
) evdev: Microsoft Natural® Ergonomic Keyboard 4000: EmulateWheelButton: 4, EmulateWheelInertia: 10, EmulateWheelTimeout: 200
[ 30.631] () Option “config_info” “udev:/sys/devices/pci0000:00/0000:00:14.0/usb1/1-10/1-10.3/1-10.3:1.1/0003:045E:00DB.0002/input/input7/event4”
[ 30.631] (II) XINPUT: Adding extended input device “Microsoft Natural® Ergonomic Keyboard 4000” (type: KEYBOARD, id 9)
[ 30.631] (
[ 30.631] () Option “xkb_model” “pc105”
[ 30.631] (
[ 30.631] (II) evdev: Microsoft Natural® Ergonomic Keyboard 4000: initialized for relative axes.
[ 30.631] (WW) evdev: Microsoft Natural® Ergonomic Keyboard 4000: ignoring absolute axes.
[ 30.631] () Microsoft Natural® Ergonomic Keyboard 4000: (accel) keeping acceleration scheme 1
[ 30.631] (
) Microsoft Natural® Ergonomic Keyboard 4000: (accel) acceleration profile 0
[ 30.631] () Microsoft Natural® Ergonomic Keyboard 4000: (accel) acceleration factor: 2.000
[ 30.631] (
) Microsoft Natural® Ergonomic Keyboard 4000: (accel) acceleration threshold: 4
[ 30.631] (II) config/udev: Adding input device Logitech USB Optical Mouse (/dev/input/event3)
[ 30.631] () Logitech USB Optical Mouse: Applying InputClass “evdev pointer catchall”
[ 30.631] (II) Using input driver ‘evdev’ for ‘Logitech USB Optical Mouse’
[ 30.631] (
) Logitech USB Optical Mouse: always reports core events
[ 30.631] () evdev: Logitech USB Optical Mouse: Device: “/dev/input/event3”
[ 30.684] (–) evdev: Logitech USB Optical Mouse: Vendor 0x46d Product 0xc077
[ 30.684] (–) evdev: Logitech USB Optical Mouse: Found 12 mouse buttons
[ 30.684] (–) evdev: Logitech USB Optical Mouse: Found scroll wheel(s)
[ 30.684] (–) evdev: Logitech USB Optical Mouse: Found relative axes
[ 30.684] (–) evdev: Logitech USB Optical Mouse: Found x and y relative axes
[ 30.684] (II) evdev: Logitech USB Optical Mouse: Configuring as mouse
[ 30.684] (II) evdev: Logitech USB Optical Mouse: Adding scrollwheel support
[ 30.684] (
) evdev: Logitech USB Optical Mouse: YAxisMapping: buttons 4 and 5
[ 30.684] () evdev: Logitech USB Optical Mouse: EmulateWheelButton: 4, EmulateWheelInertia: 10, EmulateWheelTimeout: 200
[ 30.684] (
) Option “config_info” “udev:/sys/devices/pci0000:00/0000:00:14.0/usb1/1-10/1-10.4/1-10.4:1.0/0003:046D:C077.0003/input/input6/event3”
[ 30.684] (II) XINPUT: Adding extended input device “Logitech USB Optical Mouse” (type: MOUSE, id 10)
[ 30.684] (II) evdev: Logitech USB Optical Mouse: initialized for relative axes.
[ 30.684] () Logitech USB Optical Mouse: (accel) keeping acceleration scheme 1
[ 30.684] (
) Logitech USB Optical Mouse: (accel) acceleration profile 0
[ 30.684] () Logitech USB Optical Mouse: (accel) acceleration factor: 2.000
[ 30.684] (
) Logitech USB Optical Mouse: (accel) acceleration threshold: 4
[ 30.684] (II) config/udev: Adding input device Logitech USB Optical Mouse (/dev/input/mouse0)
[ 30.684] (II) No input driver specified, ignoring this device.
[ 30.684] (II) This device may have been added with another device file.
[ 30.684] (II) config/udev: Adding input device HDA Intel PCH Line (/dev/input/event7)
[ 30.684] (II) config/udev: Adding input device HDA Intel PCH Line Out Front (/dev/input/event8)
[ 30.684] (II) config/udev: Adding input device HDA Intel PCH Line Out Surround (/dev/input/event9)
[ 30.685] (II) No input driver specified, ignoring this device.
[ 30.685] (II) This device may have been added with another device file.
[ 30.685] (II) config/udev: Adding input device HDA Intel PCH Line Out CLFE (/dev/input/event10)
[ 30.685] (II) config/udev: Adding input device HDA Intel PCH Front Headphone (/dev/input/event11)
[ 30.685] (II) config/udev: Adding input device HDA Intel PCH Front Mic (/dev/input/event5)
[ 30.685] (II) config/udev: Adding input device HDA Intel PCH Rear Mic (/dev/input/event6)
[ 30.685] (II) config/udev: Adding input device Eee PC WMI hotkeys (/dev/input/event12)
[ 30.685] () Eee PC WMI hotkeys: Applying InputClass “evdev keyboard catchall”
[ 30.685] (II) Using input driver ‘evdev’ for ‘Eee PC WMI hotkeys’
[ 30.685] (
) Eee PC WMI hotkeys: always reports core events
[ 30.685] () evdev: Eee PC WMI hotkeys: Device: “/dev/input/event12”
[ 30.685] (–) evdev: Eee PC WMI hotkeys: Vendor 0 Product 0
[ 30.685] (–) evdev: Eee PC WMI hotkeys: Found keys
[ 30.685] (II) evdev: Eee PC WMI hotkeys: Configuring as keyboard
[ 30.685] (
) Option “config_info” “udev:/sys/devices/platform/eeepc-wmi/input/input15/event12”
[ 30.685] (II) XINPUT: Adding extended input device “Eee PC WMI hotkeys” (type: KEYBOARD, id 11)
[ 30.685] () Option “xkb_rules” “evdev”
[ 30.685] (
[ 30.685] (**) Option “xkb_layout” “us”
[ 31.043] (–) NVIDIA(GPU-0): DFP-0: disconnected
[ 31.043] (–) NVIDIA(GPU-0): DFP-0: Internal TMDS
[ 31.043] (–) NVIDIA(GPU-0): DFP-0: 330.0 MHz maximum pixel clock
[ 31.071] (–) NVIDIA(GPU-0): DELL U2413 (DFP-1): connected
[ 31.071] (–) NVIDIA(GPU-0): DELL U2413 (DFP-1): Internal TMDS
[ 31.071] (–) NVIDIA(GPU-0): DELL U2413 (DFP-1): 600.0 MHz maximum pixel clock
[ 31.072] (–) NVIDIA(GPU-0): DFP-2: disconnected
[ 31.072] (–) NVIDIA(GPU-0): DFP-2: Internal DisplayPort
[ 31.072] (–) NVIDIA(GPU-0): DFP-2: 1440.0 MHz maximum pixel clock
[ 31.072] (–) NVIDIA(GPU-0): DFP-3: disconnected
[ 31.072] (–) NVIDIA(GPU-0): DFP-3: Internal TMDS
[ 31.072] (–) NVIDIA(GPU-0): DFP-3: 330.0 MHz maximum pixel clock
[ 31.072] (–) NVIDIA(GPU-0): DFP-4: disconnected
[ 31.072] (–) NVIDIA(GPU-0): DFP-4: Internal DisplayPort
[ 31.072] (–) NVIDIA(GPU-0): DFP-4: 1440.0 MHz maximum pixel clock
[ 31.072] (–) NVIDIA(GPU-0): DFP-5: disconnected
[ 31.072] (–) NVIDIA(GPU-0): DFP-5: Internal TMDS
[ 31.072] (–) NVIDIA(GPU-0): DFP-5: 330.0 MHz maximum pixel clock
[ 31.072] (–) NVIDIA(GPU-0): DFP-6: disconnected
[ 31.072] (–) NVIDIA(GPU-0): DFP-6: Internal DisplayPort
[ 31.072] (–) NVIDIA(GPU-0): DFP-6: 1440.0 MHz maximum pixel clock
[ 31.072] (–) NVIDIA(GPU-0): DFP-7: disconnected
[ 31.072] (–) NVIDIA(GPU-0): DFP-7: Internal TMDS
[ 31.072] (–) NVIDIA(GPU-0): DFP-7: 330.0 MHz maximum pixel clock
[ 31.234] (–) NVIDIA(GPU-0): DFP-0: disconnected
[ 31.234] (–) NVIDIA(GPU-0): DFP-0: Internal TMDS
[ 31.234] (–) NVIDIA(GPU-0): DFP-0: 330.0 MHz maximum pixel clock
[ 31.262] (–) NVIDIA(GPU-0): DELL U2413 (DFP-1): connected
[ 31.262] (–) NVIDIA(GPU-0): DELL U2413 (DFP-1): Internal TM
