In May 2021 I purchased a Thinkpad Carbon X1 Extreme Gen 3 with what lspci reports as 01:00.0 VGA compatible controller: NVIDIA Corporation TU117M [GeForce GTX 1650 Ti Mobile] (rev a1).
Since purchase, I’ve had semi infrequent video hardlocks with a dmesg error of GPU has fallen off the bus.. I say video hardlock as CPU/network is still responsive and SSH works.
I experience this reasonably frequently, but it seems like the longer the system is running, the less likely the issue is to occur. I booted my system this morning and it locked up in about 20 minutes, I’ve had similar experiences where the system locked up 3-4 times in a number of hours. Conversely, sometimes the laptop is on for days without any stability issues. I use firefox (which afaik lacks hardware decoding) - it /seems/ like it’s more likely to freeze when youtube is playing something back in the foreground (often I’ll leave music streaming via youtube in the background) - I’m not sure if this is perception or if there’s actually a correlation.
I’m running Ubuntu 21.10, but also experienced the issues in 20.04. I was previously using nvidia-driver-460 & 470 via apt, I’ve since upgraded to 495 via the .run installer, and the issue still persists (albeit seems less frequent, but that could be standard deviation).
I’ve installed windows, run 4 x youtube streams and furmark for ~14 hours which was stable.
Is there anything else I should achieve before RMAing the laptop as faulty? I’m unable to reproducibly cause the issue, and I’m still not even sure if it’s a software or hardware bug. I’d also appreciate any tools that would reliably test all potential paths within the GPU which could be broken (I don’t know how furmark works, if it’s gpu-processor bound or if it also tests gpu memory).
Thanks for any responses!, GPU dmesg is as follows:
[ 7781.125093] usb 4-1: new SuperSpeed USB device number 5 using xhci_hcd
[ 7781.160293] usb 4-1: New USB device found, idVendor=0bda, idProduct=0411, bcdDevice= 1.17
[ 7781.160298] usb 4-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 7781.160299] usb 4-1: Product: 4-Port USB 3.0 Hub
[ 7781.160300] usb 4-1: Manufacturer: Generic
[ 7781.167808] hub 4-1:1.0: USB hub found
[ 7781.169117] hub 4-1:1.0: 4 ports detected
[ 7781.461319] usb 4-1.1: new SuperSpeed USB device number 6 using xhci_hcd
[ 7781.495907] usb 4-1.1: New USB device found, idVendor=0bda, idProduct=0411, bcdDevice= 1.17
[ 7781.495919] usb 4-1.1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 7781.495924] usb 4-1.1: Product: 4-Port USB 3.0 Hub
[ 7781.495928] usb 4-1.1: Manufacturer: Generic
[ 7781.504785] hub 4-1.1:1.0: USB hub found
[ 7781.506165] hub 4-1.1:1.0: 4 ports detected
[ 7781.593368] usb 4-1.2: new SuperSpeed USB device number 7 using xhci_hcd
[ 7781.616367] usb 4-1.2: New USB device found, idVendor=05e3, idProduct=0612, bcdDevice=92.26
[ 7781.616378] usb 4-1.2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 7781.616383] usb 4-1.2: Product: USB3.0 Hub
[ 7781.616387] usb 4-1.2: Manufacturer: GenesysLogic
[ 7781.617715] hub 4-1.2:1.0: USB hub found
[ 7781.618020] hub 4-1.2:1.0: 4 ports detected
[ 9465.656933] nvidia-modeset: WARNING: GPU:0: CSO (DP-2): G-SYNC Compatible: EDID min refresh rate invalid, disabling G-SYNC Compatible.
[ 9798.261245] nvidia-modeset: WARNING: GPU:0: CSO (DP-2): G-SYNC Compatible: EDID min refresh rate invalid, disabling G-SYNC Compatible.
[10367.446870] nvidia-modeset: WARNING: GPU:0: CSO (DP-2): G-SYNC Compatible: EDID min refresh rate invalid, disabling G-SYNC Compatible.
[11268.518670] nvidia-modeset: WARNING: GPU:0: CSO (DP-2): G-SYNC Compatible: EDID min refresh rate invalid, disabling G-SYNC Compatible.
[11952.492042] audit: type=1400 audit(1637553478.546:62): apparmor="ALLOWED" operation="open" profile="libreoffice-soffice" name="/proc/18534/comm" pid=18534 comm="soffice.bin" requested_mask="r" denied_mask="r" fsuid=1000 ouid=1000
[11952.493928] audit: type=1400 audit(1637553478.550:63): apparmor="ALLOWED" operation="open" profile="libreoffice-soffice" name="/usr/local/lib/libgtk-3.so.0.2404.26" pid=18533 comm="soffice.bin" requested_mask="r" denied_mask="r" fsuid=1000 ouid=0
[11952.493945] audit: type=1400 audit(1637553478.550:64): apparmor="ALLOWED" operation="file_mmap" profile="libreoffice-soffice" name="/usr/local/lib/libgtk-3.so.0.2404.26" pid=18533 comm="soffice.bin" requested_mask="rm" denied_mask="rm" fsuid=1000 ouid=0
[11952.493987] audit: type=1400 audit(1637553478.550:65): apparmor="ALLOWED" operation="open" profile="libreoffice-soffice" name="/usr/local/lib/libgdk-3.so.0.2404.26" pid=18533 comm="soffice.bin" requested_mask="r" denied_mask="r" fsuid=1000 ouid=0
[11952.494003] audit: type=1400 audit(1637553478.550:66): apparmor="ALLOWED" operation="file_mmap" profile="libreoffice-soffice" name="/usr/local/lib/libgdk-3.so.0.2404.26" pid=18533 comm="soffice.bin" requested_mask="rm" denied_mask="rm" fsuid=1000 ouid=0
[11952.499614] audit: type=1400 audit(1637553478.554:67): apparmor="ALLOWED" operation="sendmsg" profile="libreoffice-soffice" pid=18534 comm="soffice.bin" family="unix" sock_type="dgram" protocol=0 requested_mask="send" denied_mask="send" addr=none peer_addr="@7661722F72756E2F6E76696469612D786472697665722D34313562643738390000000000000000000000000000000000000000000000000000000000000000" peer="unconfined"
[11952.499803] audit: type=1400 audit(1637553478.554:68): apparmor="ALLOWED" operation="sendmsg" profile="libreoffice-soffice" pid=18534 comm="soffice.bin" family="unix" sock_type="dgram" protocol=0 requested_mask="send" denied_mask="send" addr=none peer_addr="@7661722F72756E2F6E76696469612D786472697665722D34313562643738390000000000000000000000000000000000000000000000000000000000000000" peer="unconfined"
[11952.500556] audit: type=1400 audit(1637553478.558:69): apparmor="ALLOWED" operation="open" profile="libreoffice-soffice" name="/proc/18534/comm" pid=18534 comm="soffice.bin" requested_mask="r" denied_mask="r" fsuid=1000 ouid=1000
[11952.505934] audit: type=1400 audit(1637553478.562:70): apparmor="ALLOWED" operation="open" profile="libreoffice-soffice" name="/home/redacted/.cache/nvidia/GLCache/f05ba6749fb3432b0cb5cac2710edf90/160b6486f2bf34a6/fd9ae88212ee1ec4.toc" pid=18534 comm="soffice.bin" requested_mask="wr" denied_mask="wr" fsuid=1000 ouid=1000
[11952.505937] audit: type=1400 audit(1637553478.562:71): apparmor="ALLOWED" operation="file_lock" profile="libreoffice-soffice" name="/home/redacted/.cache/nvidia/GLCache/f05ba6749fb3432b0cb5cac2710edf90/160b6486f2bf34a6/fd9ae88212ee1ec4.toc" pid=18534 comm="soffice.bin" requested_mask="wk" denied_mask="wk" fsuid=1000 ouid=1000
[11958.272860] kauditd_printk_skb: 7 callbacks suppressed
[11958.272862] audit: type=1400 audit(1637553484.330:79): apparmor="ALLOWED" operation="open" profile="libreoffice-soffice" name="/usr/share/zoneinfo-icu/44/le/zoneinfo64.res" pid=18533 comm="soffice.bin" requested_mask="r" denied_mask="r" fsuid=1000 ouid=0
[11958.273229] audit: type=1400 audit(1637553484.330:80): apparmor="ALLOWED" operation="open" profile="libreoffice-soffice" name="/usr/share/zoneinfo-icu/44/le/timezoneTypes.res" pid=18533 comm="soffice.bin" requested_mask="r" denied_mask="r" fsuid=1000 ouid=0
[11958.641887] audit: type=1400 audit(1637553484.698:81): apparmor="ALLOWED" operation="open" profile="libreoffice-soffice" name="/home/redacted/.thunderbird/profiles.ini" pid=18533 comm="soffice.bin" requested_mask="r" denied_mask="r" fsuid=1000 ouid=1000
[11958.644714] audit: type=1400 audit(1637553484.702:82): apparmor="ALLOWED" operation="open" profile="libreoffice-soffice" name="/home/redacted/.thunderbird/8riiqc1h.default-release/cert9.db" pid=18533 comm="soffice.bin" requested_mask="wrc" denied_mask="wrc" fsuid=1000 ouid=1000
[11958.645028] audit: type=1400 audit(1637553484.702:83): apparmor="ALLOWED" operation="file_lock" profile="libreoffice-soffice" name="/home/redacted/.thunderbird/8riiqc1h.default-release/cert9.db" pid=18533 comm="soffice.bin" requested_mask="k" denied_mask="k" fsuid=1000 ouid=1000
[11958.645662] audit: type=1400 audit(1637553484.702:84): apparmor="ALLOWED" operation="open" profile="libreoffice-soffice" name="/home/redacted/.thunderbird/8riiqc1h.default-release/key4.db" pid=18533 comm="soffice.bin" requested_mask="wrc" denied_mask="wrc" fsuid=1000 ouid=1000
[11958.645905] audit: type=1400 audit(1637553484.702:85): apparmor="ALLOWED" operation="file_lock" profile="libreoffice-soffice" name="/home/redacted/.thunderbird/8riiqc1h.default-release/key4.db" pid=18533 comm="soffice.bin" requested_mask="k" denied_mask="k" fsuid=1000 ouid=1000
[11958.880738] audit: type=1400 audit(1637553484.938:86): apparmor="ALLOWED" operation="open" profile="libreoffice-soffice" name="/proc/18533/mountinfo" pid=18533 comm="soffice.bin" requested_mask="r" denied_mask="r" fsuid=1000 ouid=1000
[11958.883202] audit: type=1400 audit(1637553484.938:87): apparmor="ALLOWED" operation="open" profile="libreoffice-soffice" name="/proc/18533/coredump_filter" pid=18533 comm="soffice.bin" requested_mask="wr" denied_mask="wr" fsuid=1000 ouid=1000
[11958.883206] audit: type=1400 audit(1637553484.938:88): apparmor="ALLOWED" operation="open" profile="libreoffice-soffice" name="/proc/18533/coredump_filter" pid=18533 comm="soffice.bin" requested_mask="wr" denied_mask="wr" fsuid=1000 ouid=1000
[12112.174389] kauditd_printk_skb: 1 callbacks suppressed
[12112.174393] audit: type=1400 audit(1637553638.232:90): apparmor="DENIED" operation="open" profile="/usr/bin/evince" name="/usr/local/lib/libgtk-3.so.0.2404.26" pid=19097 comm="evince" requested_mask="r" denied_mask="r" fsuid=1000 ouid=0
[12112.175163] audit: type=1400 audit(1637553638.232:91): apparmor="DENIED" operation="open" profile="/usr/bin/evince" name="/usr/local/lib/libgdk-3.so.0.2404.26" pid=19097 comm="evince" requested_mask="r" denied_mask="r" fsuid=1000 ouid=0
[12513.539636] nvidia-modeset: WARNING: GPU:0: CSO (DP-2): G-SYNC Compatible: EDID min refresh rate invalid, disabling G-SYNC Compatible.
[13642.195336] nvidia-modeset: WARNING: GPU:0: CSO (DP-2): G-SYNC Compatible: EDID min refresh rate invalid, disabling G-SYNC Compatible.
[16790.000232] audit: type=1400 audit(1637558316.126:92): apparmor="DENIED" operation="open" profile="virt-aa-helper" name="/vms/cyk-21h2.box" pid=28376 comm="virt-aa-helper" requested_mask="r" denied_mask="r" fsuid=0 ouid=1000
[16790.139099] audit: type=1400 audit(1637558316.266:93): apparmor="STATUS" operation="profile_load" profile="unconfined" name="libvirt-9dc4b046-327c-4755-8dd3-c454a2c08382" pid=28378 comm="apparmor_parser"
[16790.169174] audit: type=1400 audit(1637558316.298:94): apparmor="DENIED" operation="open" profile="virt-aa-helper" name="/vms/cyk-21h2.box" pid=28379 comm="virt-aa-helper" requested_mask="r" denied_mask="r" fsuid=0 ouid=1000
[16790.290989] audit: type=1400 audit(1637558316.418:95): apparmor="STATUS" operation="profile_replace" profile="unconfined" name="libvirt-9dc4b046-327c-4755-8dd3-c454a2c08382" pid=28381 comm="apparmor_parser"
[16790.303528] audit: type=1400 audit(1637558316.430:96): apparmor="DENIED" operation="open" profile="virt-aa-helper" name="/vms/cyk-21h2.box" pid=28383 comm="virt-aa-helper" requested_mask="r" denied_mask="r" fsuid=0 ouid=1000
[16790.424618] audit: type=1400 audit(1637558316.554:97): apparmor="STATUS" operation="profile_replace" profile="unconfined" name="libvirt-9dc4b046-327c-4755-8dd3-c454a2c08382" pid=28385 comm="apparmor_parser"
[16790.437015] audit: type=1400 audit(1637558316.566:98): apparmor="DENIED" operation="open" profile="virt-aa-helper" name="/vms/cyk-21h2.box" pid=28387 comm="virt-aa-helper" requested_mask="r" denied_mask="r" fsuid=0 ouid=1000
[16790.558568] audit: type=1400 audit(1637558316.686:99): apparmor="STATUS" operation="profile_replace" info="same as current profile, skipping" profile="unconfined" name="libvirt-9dc4b046-327c-4755-8dd3-c454a2c08382" pid=28389 comm="apparmor_parser"
[16790.604157] virbr0: port 1(vnet0) entered blocking state
[16790.604161] virbr0: port 1(vnet0) entered disabled state
[16790.604249] device vnet0 entered promiscuous mode
[16790.604521] virbr0: port 1(vnet0) entered blocking state
[16790.604524] virbr0: port 1(vnet0) entered listening state
[16790.739930] audit: type=1400 audit(1637558316.866:100): apparmor="STATUS" operation="profile_replace" profile="unconfined" name="libvirt-9dc4b046-327c-4755-8dd3-c454a2c08382" pid=28405 comm="apparmor_parser"
[16792.624581] virbr0: port 1(vnet0) entered learning state
[16794.640505] virbr0: port 1(vnet0) entered forwarding state
[16794.640515] virbr0: topology change detected, propagating
[16978.129623] virbr0: port 1(vnet0) entered disabled state
[16978.134066] device vnet0 left promiscuous mode
[16978.134076] virbr0: port 1(vnet0) entered disabled state
[16978.458475] audit: type=1400 audit(1637558504.588:101): apparmor="STATUS" operation="profile_remove" profile="unconfined" name="libvirt-9dc4b046-327c-4755-8dd3-c454a2c08382" pid=28730 comm="apparmor_parser"
[17040.609267] audit: type=1400 audit(1637558566.741:102): apparmor="DENIED" operation="open" profile="virt-aa-helper" name="/vms/cyk-21h2.box" pid=28935 comm="virt-aa-helper" requested_mask="r" denied_mask="r" fsuid=0 ouid=1000
[17040.730859] audit: type=1400 audit(1637558566.861:103): apparmor="STATUS" operation="profile_load" profile="unconfined" name="libvirt-9dc4b046-327c-4755-8dd3-c454a2c08382" pid=28937 comm="apparmor_parser"
[17040.751066] audit: type=1400 audit(1637558566.881:104): apparmor="DENIED" operation="open" profile="virt-aa-helper" name="/vms/cyk-21h2.box" pid=28938 comm="virt-aa-helper" requested_mask="r" denied_mask="r" fsuid=0 ouid=1000
[17040.875311] audit: type=1400 audit(1637558567.005:105): apparmor="STATUS" operation="profile_replace" profile="unconfined" name="libvirt-9dc4b046-327c-4755-8dd3-c454a2c08382" pid=28940 comm="apparmor_parser"
[17040.887964] audit: type=1400 audit(1637558567.017:106): apparmor="DENIED" operation="open" profile="virt-aa-helper" name="/vms/cyk-21h2.box" pid=28942 comm="virt-aa-helper" requested_mask="r" denied_mask="r" fsuid=0 ouid=1000
[17041.011586] audit: type=1400 audit(1637558567.141:107): apparmor="STATUS" operation="profile_replace" profile="unconfined" name="libvirt-9dc4b046-327c-4755-8dd3-c454a2c08382" pid=28944 comm="apparmor_parser"
[17041.024702] audit: type=1400 audit(1637558567.153:108): apparmor="DENIED" operation="open" profile="virt-aa-helper" name="/vms/cyk-21h2.box" pid=28946 comm="virt-aa-helper" requested_mask="r" denied_mask="r" fsuid=0 ouid=1000
[17041.148120] audit: type=1400 audit(1637558567.277:109): apparmor="STATUS" operation="profile_replace" info="same as current profile, skipping" profile="unconfined" name="libvirt-9dc4b046-327c-4755-8dd3-c454a2c08382" pid=28948 comm="apparmor_parser"
[17041.153936] virbr0: port 1(vnet1) entered blocking state
[17041.153939] virbr0: port 1(vnet1) entered disabled state
[17041.154030] device vnet1 entered promiscuous mode
[17041.154333] virbr0: port 1(vnet1) entered blocking state
[17041.154335] virbr0: port 1(vnet1) entered listening state
[17041.291684] audit: type=1400 audit(1637558567.421:110): apparmor="STATUS" operation="profile_replace" profile="unconfined" name="libvirt-9dc4b046-327c-4755-8dd3-c454a2c08382" pid=28964 comm="apparmor_parser"
[17043.180872] virbr0: port 1(vnet1) entered learning state
[17045.196854] virbr0: port 1(vnet1) entered forwarding state
[17045.196863] virbr0: topology change detected, propagating
[17276.603299] virbr0: port 1(vnet1) entered disabled state
[17276.606832] device vnet1 left promiscuous mode
[17276.606835] virbr0: port 1(vnet1) entered disabled state
[17276.926871] audit: type=1400 audit(1637558803.061:111): apparmor="STATUS" operation="profile_remove" profile="unconfined" name="libvirt-9dc4b046-327c-4755-8dd3-c454a2c08382" pid=29912 comm="apparmor_parser"
[17366.584413] audit: type=1400 audit(1637558892.722:112): apparmor="STATUS" operation="profile_load" profile="unconfined" name="libvirt-6c61fffa-48c7-4b55-be96-090adad77292" pid=30013 comm="apparmor_parser"
[17366.724329] audit: type=1400 audit(1637558892.862:113): apparmor="STATUS" operation="profile_replace" profile="unconfined" name="libvirt-6c61fffa-48c7-4b55-be96-090adad77292" pid=30016 comm="apparmor_parser"
[17366.858590] audit: type=1400 audit(1637558892.994:114): apparmor="STATUS" operation="profile_replace" profile="unconfined" name="libvirt-6c61fffa-48c7-4b55-be96-090adad77292" pid=30020 comm="apparmor_parser"
[17366.992399] audit: type=1400 audit(1637558893.130:115): apparmor="STATUS" operation="profile_replace" info="same as current profile, skipping" profile="unconfined" name="libvirt-6c61fffa-48c7-4b55-be96-090adad77292" pid=30024 comm="apparmor_parser"
[17366.999747] virbr0: port 1(vnet2) entered blocking state
[17366.999751] virbr0: port 1(vnet2) entered disabled state
[17366.999825] device vnet2 entered promiscuous mode
[17367.000114] virbr0: port 1(vnet2) entered blocking state
[17367.000116] virbr0: port 1(vnet2) entered listening state
[17367.134732] audit: type=1400 audit(1637558893.270:116): apparmor="STATUS" operation="profile_replace" profile="unconfined" name="libvirt-6c61fffa-48c7-4b55-be96-090adad77292" pid=30039 comm="apparmor_parser"
[17369.032123] virbr0: port 1(vnet2) entered learning state
[17371.048048] virbr0: port 1(vnet2) entered forwarding state
[17371.048052] virbr0: topology change detected, propagating
[17962.219875] nvidia-modeset: WARNING: GPU:0: CSO (DP-2): G-SYNC Compatible: EDID min refresh rate invalid, disabling G-SYNC Compatible.
[18863.667872] nvidia-modeset: WARNING: GPU:0: CSO (DP-2): G-SYNC Compatible: EDID min refresh rate invalid, disabling G-SYNC Compatible.
[19763.976138] nvidia-modeset: WARNING: GPU:0: CSO (DP-2): G-SYNC Compatible: EDID min refresh rate invalid, disabling G-SYNC Compatible.
[20942.471927] nvidia-modeset: WARNING: GPU:0: CSO (DP-2): G-SYNC Compatible: EDID min refresh rate invalid, disabling G-SYNC Compatible.
[23043.301354] audit: type=1400 audit(1637564569.522:117): apparmor="ALLOWED" operation="open" profile="libreoffice-soffice" name="/usr/local/lib/libgtk-3.so.0.2404.26" pid=46446 comm="soffice.bin" requested_mask="r" denied_mask="r" fsuid=1006 ouid=0
[23043.301362] audit: type=1400 audit(1637564569.522:118): apparmor="ALLOWED" operation="file_mmap" profile="libreoffice-soffice" name="/usr/local/lib/libgtk-3.so.0.2404.26" pid=46446 comm="soffice.bin" requested_mask="rm" denied_mask="rm" fsuid=1006 ouid=0
[23043.301406] audit: type=1400 audit(1637564569.522:119): apparmor="ALLOWED" operation="open" profile="libreoffice-soffice" name="/usr/local/lib/libgdk-3.so.0.2404.26" pid=46446 comm="soffice.bin" requested_mask="r" denied_mask="r" fsuid=1006 ouid=0
[23043.301421] audit: type=1400 audit(1637564569.522:120): apparmor="ALLOWED" operation="file_mmap" profile="libreoffice-soffice" name="/usr/local/lib/libgdk-3.so.0.2404.26" pid=46446 comm="soffice.bin" requested_mask="rm" denied_mask="rm" fsuid=1006 ouid=0
[23043.302724] audit: type=1400 audit(1637564569.522:121): apparmor="ALLOWED" operation="open" profile="libreoffice-soffice" name="/proc/46447/comm" pid=46447 comm="soffice.bin" requested_mask="r" denied_mask="r" fsuid=1006 ouid=1006
[23043.310275] audit: type=1400 audit(1637564569.530:122): apparmor="ALLOWED" operation="sendmsg" profile="libreoffice-soffice" pid=46447 comm="soffice.bin" family="unix" sock_type="dgram" protocol=0 requested_mask="send" denied_mask="send" addr=none peer_addr="@7661722F72756E2F6E76696469612D786472697665722D34313562643738390000000000000000000000000000000000000000000000000000000000000000" peer="unconfined"
[23043.310469] audit: type=1400 audit(1637564569.530:123): apparmor="ALLOWED" operation="sendmsg" profile="libreoffice-soffice" pid=46447 comm="soffice.bin" family="unix" sock_type="dgram" protocol=0 requested_mask="send" denied_mask="send" addr=none peer_addr="@7661722F72756E2F6E76696469612D786472697665722D34313562643738390000000000000000000000000000000000000000000000000000000000000000" peer="unconfined"
[23043.311201] audit: type=1400 audit(1637564569.530:124): apparmor="ALLOWED" operation="open" profile="libreoffice-soffice" name="/proc/46447/comm" pid=46447 comm="soffice.bin" requested_mask="r" denied_mask="r" fsuid=1006 ouid=1006
[23043.316483] audit: type=1400 audit(1637564569.538:125): apparmor="ALLOWED" operation="mknod" profile="libreoffice-soffice" name="/home/redacted-browser/.cache/nvidia/GLCache/f05ba6749fb3432b0cb5cac2710edf90/160b6486f2bf34a6/fd9ae88212ee1ec4.toc" pid=46447 comm="soffice.bin" requested_mask="c" denied_mask="c" fsuid=1006 ouid=1006
[23043.316498] audit: type=1400 audit(1637564569.538:126): apparmor="ALLOWED" operation="open" profile="libreoffice-soffice" name="/home/redacted-browser/.cache/nvidia/GLCache/f05ba6749fb3432b0cb5cac2710edf90/160b6486f2bf34a6/fd9ae88212ee1ec4.toc" pid=46447 comm="soffice.bin" requested_mask="rac" denied_mask="rac" fsuid=1006 ouid=1006
[23315.902427] kauditd_printk_skb: 38 callbacks suppressed
[23315.902429] audit: type=1400 audit(1637564842.126:165): apparmor="ALLOWED" operation="open" profile="libreoffice-soffice" name="/proc/46463/mountinfo" pid=46463 comm="gmain" requested_mask="r" denied_mask="r" fsuid=1006 ouid=1006
[23315.902572] audit: type=1400 audit(1637564842.126:166): apparmor="ALLOWED" operation="open" profile="libreoffice-soffice" name="/proc/46463/mountinfo" pid=46463 comm="soffice.bin" requested_mask="r" denied_mask="r" fsuid=1006 ouid=1006
[23315.935974] audit: type=1400 audit(1637564842.158:167): apparmor="ALLOWED" operation="open" profile="libreoffice-soffice" name="/home/redacted-browser/.cache/dconf/user" pid=46463 comm="soffice.bin" requested_mask="wrc" denied_mask="wrc" fsuid=1006 ouid=1006
[23316.027245] audit: type=1400 audit(1637564842.250:168): apparmor="ALLOWED" operation="open" profile="libreoffice-soffice" name="/proc/46463/mountinfo" pid=46463 comm="soffice.bin" requested_mask="r" denied_mask="r" fsuid=1006 ouid=1006
[23316.631707] audit: type=1400 audit(1637564842.854:169): apparmor="ALLOWED" operation="open" profile="libreoffice-soffice" name="/proc/46463/mountinfo" pid=46463 comm="soffice.bin" requested_mask="r" denied_mask="r" fsuid=1006 ouid=1006
[23323.247345] audit: type=1400 audit(1637564849.470:170): apparmor="ALLOWED" operation="connect" profile="libreoffice-oosplash" name="/tmp/OSL_PIPE_1006_SingleOfficeIPC_2f2c08986ff3868dfa809689e6522a" pid=46697 comm="oosplash" requested_mask="wr" denied_mask="wr" fsuid=1006 ouid=1006
[23323.247349] audit: type=1400 audit(1637564849.470:171): apparmor="ALLOWED" operation="file_perm" profile="libreoffice-oosplash" name="/tmp/OSL_PIPE_1006_SingleOfficeIPC_2f2c08986ff3868dfa809689e6522a" pid=46697 comm="oosplash" requested_mask="r" denied_mask="r" fsuid=1006 ouid=1006
[23323.247350] audit: type=1400 audit(1637564849.470:172): apparmor="ALLOWED" operation="file_perm" profile="libreoffice-oosplash" name="/tmp/OSL_PIPE_1006_SingleOfficeIPC_2f2c08986ff3868dfa809689e6522a" pid=46697 comm="oosplash" requested_mask="r" denied_mask="r" fsuid=1006 ouid=1006
[23323.247394] audit: type=1400 audit(1637564849.470:173): apparmor="ALLOWED" operation="file_perm" profile="libreoffice-oosplash" name="/tmp/OSL_PIPE_1006_SingleOfficeIPC_2f2c08986ff3868dfa809689e6522a" pid=46697 comm="oosplash" requested_mask="w" denied_mask="w" fsuid=1006 ouid=1006
[23323.247396] audit: type=1400 audit(1637564849.470:174): apparmor="ALLOWED" operation="file_perm" profile="libreoffice-oosplash" name="/tmp/OSL_PIPE_1006_SingleOfficeIPC_2f2c08986ff3868dfa809689e6522a" pid=46697 comm="oosplash" requested_mask="w" denied_mask="w" fsuid=1006 ouid=1006
[23577.874933] audit: type=1400 audit(1637565104.102:175): apparmor="ALLOWED" operation="open" profile="libreoffice-soffice" name="/proc/46463/mountinfo" pid=46463 comm="gmain" requested_mask="r" denied_mask="r" fsuid=1006 ouid=1006
[23577.875022] audit: type=1400 audit(1637565104.102:176): apparmor="ALLOWED" operation="open" profile="libreoffice-soffice" name="/proc/46463/mountinfo" pid=46463 comm="soffice.bin" requested_mask="r" denied_mask="r" fsuid=1006 ouid=1006
[23577.975254] audit: type=1400 audit(1637565104.202:177): apparmor="ALLOWED" operation="open" profile="libreoffice-soffice" name="/proc/46463/mountinfo" pid=46463 comm="soffice.bin" requested_mask="r" denied_mask="r" fsuid=1006 ouid=1006
[23581.648153] audit: type=1400 audit(1637565107.874:178): apparmor="ALLOWED" operation="open" profile="libreoffice-soffice" name="/proc/46463/mountinfo" pid=46463 comm="soffice.bin" requested_mask="r" denied_mask="r" fsuid=1006 ouid=1006
[23613.829854] audit: type=1400 audit(1637565140.058:179): apparmor="ALLOWED" operation="open" profile="libreoffice-soffice" name="/proc/46463/mountinfo" pid=46463 comm="gmain" requested_mask="r" denied_mask="r" fsuid=1006 ouid=1006
[23613.830000] audit: type=1400 audit(1637565140.058:180): apparmor="ALLOWED" operation="open" profile="libreoffice-soffice" name="/proc/46463/mountinfo" pid=46463 comm="soffice.bin" requested_mask="r" denied_mask="r" fsuid=1006 ouid=1006
[23613.939658] audit: type=1400 audit(1637565140.166:181): apparmor="ALLOWED" operation="open" profile="libreoffice-soffice" name="/proc/46463/mountinfo" pid=46463 comm="soffice.bin" requested_mask="r" denied_mask="r" fsuid=1006 ouid=1006
[23615.533282] audit: type=1400 audit(1637565141.762:182): apparmor="ALLOWED" operation="open" profile="libreoffice-soffice" name="/proc/46463/mountinfo" pid=46463 comm="soffice.bin" requested_mask="r" denied_mask="r" fsuid=1006 ouid=1006
[24180.492700] virbr0: port 1(vnet2) entered disabled state
[24180.494058] device vnet2 left promiscuous mode
[24180.494060] virbr0: port 1(vnet2) entered disabled state
[24180.999883] audit: type=1400 audit(1637565707.239:183): apparmor="STATUS" operation="profile_remove" profile="unconfined" name="libvirt-6c61fffa-48c7-4b55-be96-090adad77292" pid=47374 comm="apparmor_parser"
[24963.960009] nvidia-modeset: WARNING: GPU:0: CSO (DP-2): G-SYNC Compatible: EDID min refresh rate invalid, disabling G-SYNC Compatible.
[26029.674569] perf: interrupt took too long (2520 > 2500), lowering kernel.perf_event_max_sample_rate to 79250
[26062.694797] audit: type=1400 audit(1637567588.959:184): apparmor="ALLOWED" operation="open" profile="libreoffice-soffice" name="/proc/46463/mountinfo" pid=46463 comm="gmain" requested_mask="r" denied_mask="r" fsuid=1006 ouid=1006
[26062.695195] audit: type=1400 audit(1637567588.959:185): apparmor="ALLOWED" operation="open" profile="libreoffice-soffice" name="/proc/46463/mountinfo" pid=46463 comm="soffice.bin" requested_mask="r" denied_mask="r" fsuid=1006 ouid=1006
[26062.811903] audit: type=1400 audit(1637567589.079:186): apparmor="ALLOWED" operation="open" profile="libreoffice-soffice" name="/proc/46463/mountinfo" pid=46463 comm="soffice.bin" requested_mask="r" denied_mask="r" fsuid=1006 ouid=1006
[26062.860371] audit: type=1400 audit(1637567589.127:187): apparmor="ALLOWED" operation="mknod" profile="libreoffice-soffice" name="/home/redacted-browser/.cache/dconf/user" pid=46463 comm="soffice.bin" requested_mask="c" denied_mask="c" fsuid=1006 ouid=1006
[26062.860377] audit: type=1400 audit(1637567589.127:188): apparmor="ALLOWED" operation="open" profile="libreoffice-soffice" name="/home/redacted-browser/.cache/dconf/user" pid=46463 comm="soffice.bin" requested_mask="wrc" denied_mask="wrc" fsuid=1006 ouid=1006
[26064.386700] audit: type=1400 audit(1637567590.651:189): apparmor="ALLOWED" operation="open" profile="libreoffice-soffice" name="/proc/46463/mountinfo" pid=46463 comm="soffice.bin" requested_mask="r" denied_mask="r" fsuid=1006 ouid=1006
[26104.173103] audit: type=1400 audit(1637567630.440:190): apparmor="ALLOWED" operation="open" profile="libreoffice-soffice" name="/proc/46463/mountinfo" pid=46463 comm="gmain" requested_mask="r" denied_mask="r" fsuid=1006 ouid=1006
[26104.173275] audit: type=1400 audit(1637567630.440:191): apparmor="ALLOWED" operation="open" profile="libreoffice-soffice" name="/proc/46463/mountinfo" pid=46463 comm="soffice.bin" requested_mask="r" denied_mask="r" fsuid=1006 ouid=1006
[26104.283867] audit: type=1400 audit(1637567630.552:192): apparmor="ALLOWED" operation="open" profile="libreoffice-soffice" name="/proc/46463/mountinfo" pid=46463 comm="soffice.bin" requested_mask="r" denied_mask="r" fsuid=1006 ouid=1006
[26106.635163] audit: type=1400 audit(1637567632.904:193): apparmor="ALLOWED" operation="open" profile="libreoffice-soffice" name="/proc/46463/mountinfo" pid=46463 comm="soffice.bin" requested_mask="r" denied_mask="r" fsuid=1006 ouid=1006
[27206.519000] nvidia-modeset: WARNING: GPU:0: CSO (DP-2): G-SYNC Compatible: EDID min refresh rate invalid, disabling G-SYNC Compatible.
[28107.200174] nvidia-modeset: WARNING: GPU:0: CSO (DP-2): G-SYNC Compatible: EDID min refresh rate invalid, disabling G-SYNC Compatible.
[29007.783327] nvidia-modeset: WARNING: GPU:0: CSO (DP-2): G-SYNC Compatible: EDID min refresh rate invalid, disabling G-SYNC Compatible.
[29909.451919] nvidia-modeset: WARNING: GPU:0: CSO (DP-2): G-SYNC Compatible: EDID min refresh rate invalid, disabling G-SYNC Compatible.
[33104.733704] audit: type=1400 audit(1637574631.102:194): apparmor="ALLOWED" operation="open" profile="libreoffice-soffice" name="/proc/46463/mountinfo" pid=46463 comm="gmain" requested_mask="r" denied_mask="r" fsuid=1006 ouid=1006
[33104.734108] audit: type=1400 audit(1637574631.102:195): apparmor="ALLOWED" operation="open" profile="libreoffice-soffice" name="/proc/46463/mountinfo" pid=46463 comm="soffice.bin" requested_mask="r" denied_mask="r" fsuid=1006 ouid=1006
[33104.829564] audit: type=1400 audit(1637574631.198:196): apparmor="ALLOWED" operation="open" profile="libreoffice-soffice" name="/proc/46463/mountinfo" pid=46463 comm="soffice.bin" requested_mask="r" denied_mask="r" fsuid=1006 ouid=1006
[33104.903597] audit: type=1400 audit(1637574631.270:197): apparmor="ALLOWED" operation="mknod" profile="libreoffice-soffice" name="/home/redacted-browser/.cache/dconf/user" pid=46463 comm="soffice.bin" requested_mask="c" denied_mask="c" fsuid=1006 ouid=1006
[33104.903614] audit: type=1400 audit(1637574631.270:198): apparmor="ALLOWED" operation="open" profile="libreoffice-soffice" name="/home/redacted-browser/.cache/dconf/user" pid=46463 comm="soffice.bin" requested_mask="wrc" denied_mask="wrc" fsuid=1006 ouid=1006
[33106.138846] audit: type=1400 audit(1637574632.506:199): apparmor="ALLOWED" operation="open" profile="libreoffice-soffice" name="/proc/46463/mountinfo" pid=46463 comm="soffice.bin" requested_mask="r" denied_mask="r" fsuid=1006 ouid=1006
[33139.500877] audit: type=1400 audit(1637574665.871:200): apparmor="ALLOWED" operation="open" profile="libreoffice-soffice" name="/proc/46463/mountinfo" pid=46463 comm="gmain" requested_mask="r" denied_mask="r" fsuid=1006 ouid=1006
[33139.501033] audit: type=1400 audit(1637574665.871:201): apparmor="ALLOWED" operation="open" profile="libreoffice-soffice" name="/proc/46463/mountinfo" pid=46463 comm="soffice.bin" requested_mask="r" denied_mask="r" fsuid=1006 ouid=1006
[33139.560999] audit: type=1400 audit(1637574665.931:202): apparmor="ALLOWED" operation="open" profile="libreoffice-soffice" name="/proc/46463/mountinfo" pid=46463 comm="soffice.bin" requested_mask="r" denied_mask="r" fsuid=1006 ouid=1006
[33141.591735] audit: type=1400 audit(1637574667.963:203): apparmor="ALLOWED" operation="open" profile="libreoffice-soffice" name="/proc/46463/mountinfo" pid=46463 comm="soffice.bin" requested_mask="r" denied_mask="r" fsuid=1006 ouid=1006
[33199.861822] audit: type=1400 audit(1637574726.232:204): apparmor="ALLOWED" operation="open" profile="libreoffice-soffice" name="/usr/local/lib/libgtk-3.so.0.2404.26" pid=56700 comm="soffice.bin" requested_mask="r" denied_mask="r" fsuid=1006 ouid=0
[33199.861826] audit: type=1400 audit(1637574726.232:205): apparmor="ALLOWED" operation="file_mmap" profile="libreoffice-soffice" name="/usr/local/lib/libgtk-3.so.0.2404.26" pid=56700 comm="soffice.bin" requested_mask="rm" denied_mask="rm" fsuid=1006 ouid=0
[33199.861892] audit: type=1400 audit(1637574726.232:206): apparmor="ALLOWED" operation="open" profile="libreoffice-soffice" name="/usr/local/lib/libgdk-3.so.0.2404.26" pid=56700 comm="soffice.bin" requested_mask="r" denied_mask="r" fsuid=1006 ouid=0
[33199.861895] audit: type=1400 audit(1637574726.232:207): apparmor="ALLOWED" operation="file_mmap" profile="libreoffice-soffice" name="/usr/local/lib/libgdk-3.so.0.2404.26" pid=56700 comm="soffice.bin" requested_mask="rm" denied_mask="rm" fsuid=1006 ouid=0
[33199.862297] audit: type=1400 audit(1637574726.232:208): apparmor="ALLOWED" operation="open" profile="libreoffice-soffice" name="/proc/56701/comm" pid=56701 comm="soffice.bin" requested_mask="r" denied_mask="r" fsuid=1006 ouid=1006
[33199.869831] audit: type=1400 audit(1637574726.240:209): apparmor="ALLOWED" operation="sendmsg" profile="libreoffice-soffice" pid=56701 comm="soffice.bin" family="unix" sock_type="dgram" protocol=0 requested_mask="send" denied_mask="send" addr=none peer_addr="@7661722F72756E2F6E76696469612D786472697665722D34313562643738390000000000000000000000000000000000000000000000000000000000000000" peer="unconfined"
[33199.869961] audit: type=1400 audit(1637574726.240:210): apparmor="ALLOWED" operation="sendmsg" profile="libreoffice-soffice" pid=56701 comm="soffice.bin" family="unix" sock_type="dgram" protocol=0 requested_mask="send" denied_mask="send" addr=none peer_addr="@7661722F72756E2F6E76696469612D786472697665722D34313562643738390000000000000000000000000000000000000000000000000000000000000000" peer="unconfined"
[33199.870752] audit: type=1400 audit(1637574726.244:211): apparmor="ALLOWED" operation="open" profile="libreoffice-soffice" name="/proc/56701/comm" pid=56701 comm="soffice.bin" requested_mask="r" denied_mask="r" fsuid=1006 ouid=1006
[33199.876162] audit: type=1400 audit(1637574726.248:212): apparmor="ALLOWED" operation="open" profile="libreoffice-soffice" name="/home/redacted-browser/.cache/nvidia/GLCache/f05ba6749fb3432b0cb5cac2710edf90/160b6486f2bf34a6/fd9ae88212ee1ec4.toc" pid=56701 comm="soffice.bin" requested_mask="wr" denied_mask="wr" fsuid=1006 ouid=1006
[33199.876166] audit: type=1400 audit(1637574726.248:213): apparmor="ALLOWED" operation="file_lock" profile="libreoffice-soffice" name="/home/redacted-browser/.cache/nvidia/GLCache/f05ba6749fb3432b0cb5cac2710edf90/160b6486f2bf34a6/fd9ae88212ee1ec4.toc" pid=56701 comm="soffice.bin" requested_mask="wk" denied_mask="wk" fsuid=1006 ouid=1006
[33206.663917] kauditd_printk_skb: 9 callbacks suppressed
[33206.663920] audit: type=1400 audit(1637574733.036:223): apparmor="ALLOWED" operation="open" profile="libreoffice-soffice" name="/usr/local/lib/libgtk-3.so.0.2404.26" pid=56764 comm="soffice.bin" requested_mask="r" denied_mask="r" fsuid=1006 ouid=0
[33206.663923] audit: type=1400 audit(1637574733.036:224): apparmor="ALLOWED" operation="file_mmap" profile="libreoffice-soffice" name="/usr/local/lib/libgtk-3.so.0.2404.26" pid=56764 comm="soffice.bin" requested_mask="rm" denied_mask="rm" fsuid=1006 ouid=0
[33206.663993] audit: type=1400 audit(1637574733.036:225): apparmor="ALLOWED" operation="open" profile="libreoffice-soffice" name="/usr/local/lib/libgdk-3.so.0.2404.26" pid=56764 comm="soffice.bin" requested_mask="r" denied_mask="r" fsuid=1006 ouid=0
[33206.663996] audit: type=1400 audit(1637574733.036:226): apparmor="ALLOWED" operation="file_mmap" profile="libreoffice-soffice" name="/usr/local/lib/libgdk-3.so.0.2404.26" pid=56764 comm="soffice.bin" requested_mask="rm" denied_mask="rm" fsuid=1006 ouid=0
[33206.664895] audit: type=1400 audit(1637574733.036:227): apparmor="ALLOWED" operation="open" profile="libreoffice-soffice" name="/proc/56765/comm" pid=56765 comm="soffice.bin" requested_mask="r" denied_mask="r" fsuid=1006 ouid=1006
[33206.672579] audit: type=1400 audit(1637574733.044:228): apparmor="ALLOWED" operation="sendmsg" profile="libreoffice-soffice" pid=56765 comm="soffice.bin" family="unix" sock_type="dgram" protocol=0 requested_mask="send" denied_mask="send" addr=none peer_addr="@7661722F72756E2F6E76696469612D786472697665722D34313562643738390000000000000000000000000000000000000000000000000000000000000000" peer="unconfined"
[33206.672763] audit: type=1400 audit(1637574733.044:229): apparmor="ALLOWED" operation="sendmsg" profile="libreoffice-soffice" pid=56765 comm="soffice.bin" family="unix" sock_type="dgram" protocol=0 requested_mask="send" denied_mask="send" addr=none peer_addr="@7661722F72756E2F6E76696469612D786472697665722D34313562643738390000000000000000000000000000000000000000000000000000000000000000" peer="unconfined"
[33206.673497] audit: type=1400 audit(1637574733.044:230): apparmor="ALLOWED" operation="open" profile="libreoffice-soffice" name="/proc/56765/comm" pid=56765 comm="soffice.bin" requested_mask="r" denied_mask="r" fsuid=1006 ouid=1006
[33206.678788] audit: type=1400 audit(1637574733.052:231): apparmor="ALLOWED" operation="open" profile="libreoffice-soffice" name="/home/redacted-browser/.cache/nvidia/GLCache/f05ba6749fb3432b0cb5cac2710edf90/160b6486f2bf34a6/fd9ae88212ee1ec4.toc" pid=56765 comm="soffice.bin" requested_mask="wr" denied_mask="wr" fsuid=1006 ouid=1006
[33206.678792] audit: type=1400 audit(1637574733.052:232): apparmor="ALLOWED" operation="file_lock" profile="libreoffice-soffice" name="/home/redacted-browser/.cache/nvidia/GLCache/f05ba6749fb3432b0cb5cac2710edf90/160b6486f2bf34a6/fd9ae88212ee1ec4.toc" pid=56765 comm="soffice.bin" requested_mask="wk" denied_mask="wk" fsuid=1006 ouid=1006
[33231.480274] kauditd_printk_skb: 11 callbacks suppressed
[33231.480276] audit: type=1400 audit(1637574757.848:244): apparmor="ALLOWED" operation="capable" profile="libreoffice-soffice" pid=56980 comm="soffice.bin" capability=2 capname="dac_read_search"
[33231.480280] audit: type=1400 audit(1637574757.848:245): apparmor="ALLOWED" operation="open" profile="libreoffice-soffice" name="/home/redacted/.Xauthority" pid=56980 comm="soffice.bin" requested_mask="r" denied_mask="r" fsuid=0 ouid=1000
[33231.480861] audit: type=1400 audit(1637574757.848:246): apparmor="ALLOWED" operation="capable" profile="libreoffice-soffice" pid=56979 comm="soffice.bin" capability=2 capname="dac_read_search"
[33231.480865] audit: type=1400 audit(1637574757.848:247): apparmor="ALLOWED" operation="open" profile="libreoffice-soffice" name="/home/redacted/.Xauthority" pid=56979 comm="soffice.bin" requested_mask="r" denied_mask="r" fsuid=0 ouid=1000
[33231.484182] audit: type=1400 audit(1637574757.852:248): apparmor="ALLOWED" operation="open" profile="libreoffice-soffice" name="/usr/local/lib/libgtk-3.so.0.2404.26" pid=56979 comm="soffice.bin" requested_mask="r" denied_mask="r" fsuid=0 ouid=0
[33231.484186] audit: type=1400 audit(1637574757.852:249): apparmor="ALLOWED" operation="file_mmap" profile="libreoffice-soffice" name="/usr/local/lib/libgtk-3.so.0.2404.26" pid=56979 comm="soffice.bin" requested_mask="rm" denied_mask="rm" fsuid=0 ouid=0
[33231.484233] audit: type=1400 audit(1637574757.852:250): apparmor="ALLOWED" operation="open" profile="libreoffice-soffice" name="/usr/local/lib/libgdk-3.so.0.2404.26" pid=56979 comm="soffice.bin" requested_mask="r" denied_mask="r" fsuid=0 ouid=0
[33231.484236] audit: type=1400 audit(1637574757.852:251): apparmor="ALLOWED" operation="file_mmap" profile="libreoffice-soffice" name="/usr/local/lib/libgdk-3.so.0.2404.26" pid=56979 comm="soffice.bin" requested_mask="rm" denied_mask="rm" fsuid=0 ouid=0
[33231.493477] audit: type=1400 audit(1637574757.860:252): apparmor="ALLOWED" operation="open" profile="libreoffice-soffice" name="/proc/56980/comm" pid=56980 comm="soffice.bin" requested_mask="r" denied_mask="r" fsuid=0 ouid=0
[33231.501169] audit: type=1400 audit(1637574757.868:253): apparmor="ALLOWED" operation="sendmsg" profile="libreoffice-soffice" pid=56980 comm="soffice.bin" family="unix" sock_type="dgram" protocol=0 requested_mask="send" denied_mask="send" addr=none peer_addr="@7661722F72756E2F6E76696469612D786472697665722D34313562643738390000000000000000000000000000000000000000000000000000000000000000" peer="unconfined"
[33241.473824] kauditd_printk_skb: 222 callbacks suppressed
[33241.473826] audit: type=1400 audit(1637574767.840:476): apparmor="ALLOWED" operation="open" profile="libreoffice-soffice" name="/home/redacted/.Xauthority" pid=57090 comm="soffice.bin" requested_mask="r" denied_mask="r" fsuid=0 ouid=1000
[33241.474329] audit: type=1400 audit(1637574767.844:477): apparmor="ALLOWED" operation="capable" profile="libreoffice-soffice" pid=57089 comm="soffice.bin" capability=2 capname="dac_read_search"
[33241.474332] audit: type=1400 audit(1637574767.844:478): apparmor="ALLOWED" operation="open" profile="libreoffice-soffice" name="/home/redacted/.Xauthority" pid=57089 comm="soffice.bin" requested_mask="r" denied_mask="r" fsuid=0 ouid=1000
[33241.477683] audit: type=1400 audit(1637574767.844:479): apparmor="ALLOWED" operation="open" profile="libreoffice-soffice" name="/usr/local/lib/libgtk-3.so.0.2404.26" pid=57089 comm="soffice.bin" requested_mask="r" denied_mask="r" fsuid=0 ouid=0
[33241.477687] audit: type=1400 audit(1637574767.844:480): apparmor="ALLOWED" operation="file_mmap" profile="libreoffice-soffice" name="/usr/local/lib/libgtk-3.so.0.2404.26" pid=57089 comm="soffice.bin" requested_mask="rm" denied_mask="rm" fsuid=0 ouid=0
[33241.477702] audit: type=1400 audit(1637574767.844:481): apparmor="ALLOWED" operation="open" profile="libreoffice-soffice" name="/usr/local/lib/libgdk-3.so.0.2404.26" pid=57089 comm="soffice.bin" requested_mask="r" denied_mask="r" fsuid=0 ouid=0
[33241.477716] audit: type=1400 audit(1637574767.844:482): apparmor="ALLOWED" operation="file_mmap" profile="libreoffice-soffice" name="/usr/local/lib/libgdk-3.so.0.2404.26" pid=57089 comm="soffice.bin" requested_mask="rm" denied_mask="rm" fsuid=0 ouid=0
[33241.478512] audit: type=1400 audit(1637574767.848:483): apparmor="ALLOWED" operation="open" profile="libreoffice-soffice" name="/proc/57090/comm" pid=57090 comm="soffice.bin" requested_mask="r" denied_mask="r" fsuid=0 ouid=0
[33241.486089] audit: type=1400 audit(1637574767.856:484): apparmor="ALLOWED" operation="sendmsg" profile="libreoffice-soffice" pid=57090 comm="soffice.bin" family="unix" sock_type="dgram" protocol=0 requested_mask="send" denied_mask="send" addr=none peer_addr="@7661722F72756E2F6E76696469612D786472697665722D34313562643738390000000000000000000000000000000000000000000000000000000000000000" peer="unconfined"
[33241.486270] audit: type=1400 audit(1637574767.856:485): apparmor="ALLOWED" operation="sendmsg" profile="libreoffice-soffice" pid=57090 comm="soffice.bin" family="unix" sock_type="dgram" protocol=0 requested_mask="send" denied_mask="send" addr=none peer_addr="@7661722F72756E2F6E76696469612D786472697665722D34313562643738390000000000000000000000000000000000000000000000000000000000000000" peer="unconfined"
[33404.743975] kauditd_printk_skb: 34 callbacks suppressed
[33404.743978] audit: type=1400 audit(1637574931.119:520): apparmor="ALLOWED" operation="capable" profile="libreoffice-soffice" pid=57642 comm="soffice.bin" capability=2 capname="dac_read_search"
[33404.743981] audit: type=1400 audit(1637574931.119:521): apparmor="ALLOWED" operation="open" profile="libreoffice-soffice" name="/home/redacted/.Xauthority" pid=57642 comm="soffice.bin" requested_mask="r" denied_mask="r" fsuid=0 ouid=1000
[33404.744513] audit: type=1400 audit(1637574931.119:522): apparmor="ALLOWED" operation="open" profile="libreoffice-soffice" name="/home/redacted/.Xauthority" pid=57641 comm="soffice.bin" requested_mask="r" denied_mask="r" fsuid=0 ouid=1000
[33404.747626] audit: type=1400 audit(1637574931.123:523): apparmor="ALLOWED" operation="open" profile="libreoffice-soffice" name="/usr/local/lib/libgtk-3.so.0.2404.26" pid=57641 comm="soffice.bin" requested_mask="r" denied_mask="r" fsuid=0 ouid=0
[33404.747641] audit: type=1400 audit(1637574931.123:524): apparmor="ALLOWED" operation="file_mmap" profile="libreoffice-soffice" name="/usr/local/lib/libgtk-3.so.0.2404.26" pid=57641 comm="soffice.bin" requested_mask="rm" denied_mask="rm" fsuid=0 ouid=0
[33404.747684] audit: type=1400 audit(1637574931.123:525): apparmor="ALLOWED" operation="open" profile="libreoffice-soffice" name="/usr/local/lib/libgdk-3.so.0.2404.26" pid=57641 comm="soffice.bin" requested_mask="r" denied_mask="r" fsuid=0 ouid=0
[33404.747700] audit: type=1400 audit(1637574931.123:526): apparmor="ALLOWED" operation="file_mmap" profile="libreoffice-soffice" name="/usr/local/lib/libgdk-3.so.0.2404.26" pid=57641 comm="soffice.bin" requested_mask="rm" denied_mask="rm" fsuid=0 ouid=0
[33404.748867] audit: type=1400 audit(1637574931.123:527): apparmor="ALLOWED" operation="open" profile="libreoffice-soffice" name="/proc/57642/comm" pid=57642 comm="soffice.bin" requested_mask="r" denied_mask="r" fsuid=0 ouid=0
[33404.756706] audit: type=1400 audit(1637574931.131:528): apparmor="ALLOWED" operation="sendmsg" profile="libreoffice-soffice" pid=57642 comm="soffice.bin" family="unix" sock_type="dgram" protocol=0 requested_mask="send" denied_mask="send" addr=none peer_addr="@7661722F72756E2F6E76696469612D786472697665722D34313562643738390000000000000000000000000000000000000000000000000000000000000000" peer="unconfined"
[33404.756883] audit: type=1400 audit(1637574931.131:529): apparmor="ALLOWED" operation="sendmsg" profile="libreoffice-soffice" pid=57642 comm="soffice.bin" family="unix" sock_type="dgram" protocol=0 requested_mask="send" denied_mask="send" addr=none peer_addr="@7661722F72756E2F6E76696469612D786472697665722D34313562643738390000000000000000000000000000000000000000000000000000000000000000" peer="unconfined"
[33413.064274] kauditd_printk_skb: 34 callbacks suppressed
[33413.064283] audit: type=1400 audit(1637574939.439:564): apparmor="ALLOWED" operation="connect" profile="libreoffice-oosplash" name="/tmp/OSL_PIPE_0_SingleOfficeIPC_53bc4297d6d012e1a744f3977d159334" pid=57717 comm="oosplash" requested_mask="wr" denied_mask="wr" fsuid=0 ouid=0
[33413.064297] audit: type=1400 audit(1637574939.439:565): apparmor="ALLOWED" operation="file_perm" profile="libreoffice-oosplash" name="/tmp/OSL_PIPE_0_SingleOfficeIPC_53bc4297d6d012e1a744f3977d159334" pid=57717 comm="oosplash" requested_mask="r" denied_mask="r" fsuid=0 ouid=0
[33413.064307] audit: type=1400 audit(1637574939.439:566): apparmor="ALLOWED" operation="file_perm" profile="libreoffice-oosplash" name="/tmp/OSL_PIPE_0_SingleOfficeIPC_53bc4297d6d012e1a744f3977d159334" pid=57717 comm="oosplash" requested_mask="r" denied_mask="r" fsuid=0 ouid=0
[33413.064477] audit: type=1400 audit(1637574939.439:567): apparmor="ALLOWED" operation="file_perm" profile="libreoffice-oosplash" name="/tmp/OSL_PIPE_0_SingleOfficeIPC_53bc4297d6d012e1a744f3977d159334" pid=57717 comm="oosplash" requested_mask="w" denied_mask="w" fsuid=0 ouid=0
[33413.064490] audit: type=1400 audit(1637574939.439:568): apparmor="ALLOWED" operation="file_perm" profile="libreoffice-oosplash" name="/tmp/OSL_PIPE_0_SingleOfficeIPC_53bc4297d6d012e1a744f3977d159334" pid=57717 comm="oosplash" requested_mask="w" denied_mask="w" fsuid=0 ouid=0
[33413.070263] audit: type=1400 audit(1637574939.443:569): apparmor="ALLOWED" operation="capable" profile="libreoffice-soffice" pid=57641 comm="soffice.bin" capability=1 capname="dac_override"
[33413.070281] audit: type=1400 audit(1637574939.443:570): apparmor="ALLOWED" operation="open" profile="libreoffice-soffice" name="/tmp/tax-2021-07-until-2021-11-21/released/TransactionHistory.csv" pid=57641 comm="soffice.bin" requested_mask="wr" denied_mask="wr" fsuid=0 ouid=1006
[33413.070291] audit: type=1400 audit(1637574939.443:571): apparmor="ALLOWED" operation="file_lock" profile="libreoffice-soffice" name="/tmp/tax-2021-07-until-2021-11-21/released/TransactionHistory.csv" pid=57641 comm="soffice.bin" requested_mask="wk" denied_mask="wk" fsuid=0 ouid=1006
[33413.070535] audit: type=1400 audit(1637574939.443:572): apparmor="ALLOWED" operation="open" profile="libreoffice-soffice" name="/tmp/tax-2021-07-until-2021-11-21/released/TransactionHistory.csv" pid=57641 comm="soffice.bin" requested_mask="r" denied_mask="r" fsuid=0 ouid=1006
[33415.006352] audit: type=1400 audit(1637574941.379:573): apparmor="ALLOWED" operation="open" profile="libreoffice-soffice//null-/usr/bin/dbus-daemon" name="/sys/kernel/security/apparmor/.access" pid=56988 comm="dbus-daemon" requested_mask="wr" denied_mask="wr" fsuid=0 ouid=0
[33665.426218] kauditd_printk_skb: 1 callbacks suppressed
[33665.426221] audit: type=1400 audit(1637575191.802:575): apparmor="ALLOWED" operation="capable" profile="libreoffice-soffice" pid=57641 comm="soffice.bin" capability=23 capname="sys_nice"
[33666.307598] audit: type=1400 audit(1637575192.682:576): apparmor="ALLOWED" operation="open" profile="libreoffice-soffice//null-/usr/bin/dbus-daemon" name="/sys/kernel/security/apparmor/.access" pid=56988 comm="dbus-daemon" requested_mask="wr" denied_mask="wr" fsuid=0 ouid=0
[33666.307602] audit: type=1400 audit(1637575192.682:577): apparmor="ALLOWED" operation="open" profile="libreoffice-soffice//null-/usr/bin/dbus-daemon" name="/sys/kernel/security/apparmor/.access" pid=56988 comm="dbus-daemon" requested_mask="wr" denied_mask="wr" fsuid=0 ouid=0
[34484.645766] nvidia-modeset: WARNING: GPU:0: CSO (DP-2): G-SYNC Compatible: EDID min refresh rate invalid, disabling G-SYNC Compatible.
[35386.320870] nvidia-modeset: WARNING: GPU:0: CSO (DP-2): G-SYNC Compatible: EDID min refresh rate invalid, disabling G-SYNC Compatible.
[36287.991526] nvidia-modeset: WARNING: GPU:0: CSO (DP-2): G-SYNC Compatible: EDID min refresh rate invalid, disabling G-SYNC Compatible.
[37188.937538] nvidia-modeset: WARNING: GPU:0: CSO (DP-2): G-SYNC Compatible: EDID min refresh rate invalid, disabling G-SYNC Compatible.
[38089.859132] nvidia-modeset: WARNING: GPU:0: CSO (DP-2): G-SYNC Compatible: EDID min refresh rate invalid, disabling G-SYNC Compatible.
[38990.820051] nvidia-modeset: WARNING: GPU:0: CSO (DP-2): G-SYNC Compatible: EDID min refresh rate invalid, disabling G-SYNC Compatible.
[39891.784617] nvidia-modeset: WARNING: GPU:0: CSO (DP-2): G-SYNC Compatible: EDID min refresh rate invalid, disabling G-SYNC Compatible.
[40793.471507] nvidia-modeset: WARNING: GPU:0: CSO (DP-2): G-SYNC Compatible: EDID min refresh rate invalid, disabling G-SYNC Compatible.
[41695.340628] nvidia-modeset: WARNING: GPU:0: CSO (DP-2): G-SYNC Compatible: EDID min refresh rate invalid, disabling G-SYNC Compatible.
[42597.358098] nvidia-modeset: WARNING: GPU:0: CSO (DP-2): G-SYNC Compatible: EDID min refresh rate invalid, disabling G-SYNC Compatible.
[43368.380776] audit: type=1400 audit(1637584894.900:578): apparmor="DENIED" operation="open" profile="/usr/sbin/cupsd" name="/proc/sys/kernel/osrelease" pid=2144 comm="cupsd" requested_mask="r" denied_mask="r" fsuid=0 ouid=0
[43368.380964] audit: type=1400 audit(1637584894.900:579): apparmor="DENIED" operation="open" profile="/usr/sbin/cupsd" name="/proc/1/environ" pid=2144 comm="cupsd" requested_mask="r" denied_mask="r" fsuid=0 ouid=0
[43368.381017] audit: type=1400 audit(1637584894.900:580): apparmor="DENIED" operation="open" profile="/usr/sbin/cupsd" name="/proc/cmdline" pid=2144 comm="cupsd" requested_mask="r" denied_mask="r" fsuid=0 ouid=0
[43368.381411] audit: type=1400 audit(1637584894.900:581): apparmor="DENIED" operation="connect" profile="/usr/sbin/cupsd" name="/run/systemd/userdb/io.systemd.Machine" pid=2144 comm="cupsd" requested_mask="w" denied_mask="w" fsuid=0 ouid=0
[43368.382081] audit: type=1400 audit(1637584894.900:582): apparmor="DENIED" operation="connect" profile="/usr/sbin/cupsd" name="/run/systemd/userdb/io.systemd.Machine" pid=2144 comm="cupsd" requested_mask="w" denied_mask="w" fsuid=0 ouid=0
[43499.380847] nvidia-modeset: WARNING: GPU:0: CSO (DP-2): G-SYNC Compatible: EDID min refresh rate invalid, disabling G-SYNC Compatible.
[43505.124472] perf: interrupt took too long (3151 > 3150), lowering kernel.perf_event_max_sample_rate to 63250
[44401.417824] nvidia-modeset: WARNING: GPU:0: CSO (DP-2): G-SYNC Compatible: EDID min refresh rate invalid, disabling G-SYNC Compatible.
[45303.400788] nvidia-modeset: WARNING: GPU:0: CSO (DP-2): G-SYNC Compatible: EDID min refresh rate invalid, disabling G-SYNC Compatible.
[46203.518370] nvidia-modeset: WARNING: GPU:0: CSO (DP-2): G-SYNC Compatible: EDID min refresh rate invalid, disabling G-SYNC Compatible.
[47103.574391] nvidia-modeset: WARNING: GPU:0: CSO (DP-2): G-SYNC Compatible: EDID min refresh rate invalid, disabling G-SYNC Compatible.
[48003.664272] nvidia-modeset: WARNING: GPU:0: CSO (DP-2): G-SYNC Compatible: EDID min refresh rate invalid, disabling G-SYNC Compatible.
[48122.488227] audit: type=1400 audit(1637589649.070:583): apparmor="DENIED" operation="connect" profile="/usr/sbin/cupsd" name="/run/systemd/userdb/io.systemd.Machine" pid=2144 comm="cupsd" requested_mask="w" denied_mask="w" fsuid=0 ouid=0
[48122.488324] audit: type=1400 audit(1637589649.070:584): apparmor="DENIED" operation="connect" profile="/usr/sbin/cupsd" name="/run/systemd/userdb/io.systemd.Machine" pid=2144 comm="cupsd" requested_mask="w" denied_mask="w" fsuid=0 ouid=0
[48122.557176] audit: type=1400 audit(1637589649.142:585): apparmor="DENIED" operation="capable" profile="/usr/sbin/cupsd" pid=79113 comm="cupsd" capability=12 capname="net_admin"
[48122.603113] audit: type=1400 audit(1637589649.186:586): apparmor="DENIED" operation="capable" profile="/usr/sbin/cups-browsed" pid=79114 comm="cups-browsed" capability=23 capname="sys_nice"
[48903.722117] nvidia-modeset: WARNING: GPU:0: CSO (DP-2): G-SYNC Compatible: EDID min refresh rate invalid, disabling G-SYNC Compatible.
[49803.770869] nvidia-modeset: WARNING: GPU:0: CSO (DP-2): G-SYNC Compatible: EDID min refresh rate invalid, disabling G-SYNC Compatible.
[50704.828910] nvidia-modeset: WARNING: GPU:0: CSO (DP-2): G-SYNC Compatible: EDID min refresh rate invalid, disabling G-SYNC Compatible.
[51605.926622] nvidia-modeset: WARNING: GPU:0: CSO (DP-2): G-SYNC Compatible: EDID min refresh rate invalid, disabling G-SYNC Compatible.
[52506.942478] nvidia-modeset: WARNING: GPU:0: CSO (DP-2): G-SYNC Compatible: EDID min refresh rate invalid, disabling G-SYNC Compatible.
[53407.963956] nvidia-modeset: WARNING: GPU:0: CSO (DP-2): G-SYNC Compatible: EDID min refresh rate invalid, disabling G-SYNC Compatible.
[54309.040238] nvidia-modeset: WARNING: GPU:0: CSO (DP-2): G-SYNC Compatible: EDID min refresh rate invalid, disabling G-SYNC Compatible.
[55210.139769] nvidia-modeset: WARNING: GPU:0: CSO (DP-2): G-SYNC Compatible: EDID min refresh rate invalid, disabling G-SYNC Compatible.
[56111.264172] nvidia-modeset: WARNING: GPU:0: CSO (DP-2): G-SYNC Compatible: EDID min refresh rate invalid, disabling G-SYNC Compatible.
[57012.347763] nvidia-modeset: WARNING: GPU:0: CSO (DP-2): G-SYNC Compatible: EDID min refresh rate invalid, disabling G-SYNC Compatible.
[57913.369926] nvidia-modeset: WARNING: GPU:0: CSO (DP-2): G-SYNC Compatible: EDID min refresh rate invalid, disabling G-SYNC Compatible.
[58813.436076] nvidia-modeset: WARNING: GPU:0: CSO (DP-2): G-SYNC Compatible: EDID min refresh rate invalid, disabling G-SYNC Compatible.
[59714.473843] nvidia-modeset: WARNING: GPU:0: CSO (DP-2): G-SYNC Compatible: EDID min refresh rate invalid, disabling G-SYNC Compatible.
[60615.509651] nvidia-modeset: WARNING: GPU:0: CSO (DP-2): G-SYNC Compatible: EDID min refresh rate invalid, disabling G-SYNC Compatible.
[61516.585864] nvidia-modeset: WARNING: GPU:0: CSO (DP-2): G-SYNC Compatible: EDID min refresh rate invalid, disabling G-SYNC Compatible.
[62416.658188] nvidia-modeset: WARNING: GPU:0: CSO (DP-2): G-SYNC Compatible: EDID min refresh rate invalid, disabling G-SYNC Compatible.
[63317.700797] nvidia-modeset: WARNING: GPU:0: CSO (DP-2): G-SYNC Compatible: EDID min refresh rate invalid, disabling G-SYNC Compatible.
[64219.736099] nvidia-modeset: WARNING: GPU:0: CSO (DP-2): G-SYNC Compatible: EDID min refresh rate invalid, disabling G-SYNC Compatible.
[65120.769710] nvidia-modeset: WARNING: GPU:0: CSO (DP-2): G-SYNC Compatible: EDID min refresh rate invalid, disabling G-SYNC Compatible.
[66021.828728] nvidia-modeset: WARNING: GPU:0: CSO (DP-2): G-SYNC Compatible: EDID min refresh rate invalid, disabling G-SYNC Compatible.
[66922.885130] nvidia-modeset: WARNING: GPU:0: CSO (DP-2): G-SYNC Compatible: EDID min refresh rate invalid, disabling G-SYNC Compatible.
[67823.956722] nvidia-modeset: WARNING: GPU:0: CSO (DP-2): G-SYNC Compatible: EDID min refresh rate invalid, disabling G-SYNC Compatible.
[68725.006126] nvidia-modeset: WARNING: GPU:0: CSO (DP-2): G-SYNC Compatible: EDID min refresh rate invalid, disabling G-SYNC Compatible.
[69627.064727] nvidia-modeset: WARNING: GPU:0: CSO (DP-2): G-SYNC Compatible: EDID min refresh rate invalid, disabling G-SYNC Compatible.
[70528.119138] nvidia-modeset: WARNING: GPU:0: CSO (DP-2): G-SYNC Compatible: EDID min refresh rate invalid, disabling G-SYNC Compatible.
[71428.174878] nvidia-modeset: WARNING: GPU:0: CSO (DP-2): G-SYNC Compatible: EDID min refresh rate invalid, disabling G-SYNC Compatible.
[72329.217821] nvidia-modeset: WARNING: GPU:0: CSO (DP-2): G-SYNC Compatible: EDID min refresh rate invalid, disabling G-SYNC Compatible.
[73229.246557] nvidia-modeset: WARNING: GPU:0: CSO (DP-2): G-SYNC Compatible: EDID min refresh rate invalid, disabling G-SYNC Compatible.
[74129.301887] nvidia-modeset: WARNING: GPU:0: CSO (DP-2): G-SYNC Compatible: EDID min refresh rate invalid, disabling G-SYNC Compatible.
[75029.336787] nvidia-modeset: WARNING: GPU:0: CSO (DP-2): G-SYNC Compatible: EDID min refresh rate invalid, disabling G-SYNC Compatible.
[75930.323240] nvidia-modeset: WARNING: GPU:0: CSO (DP-2): G-SYNC Compatible: EDID min refresh rate invalid, disabling G-SYNC Compatible.
[76830.375015] nvidia-modeset: WARNING: GPU:0: CSO (DP-2): G-SYNC Compatible: EDID min refresh rate invalid, disabling G-SYNC Compatible.
[77731.451177] nvidia-modeset: WARNING: GPU:0: CSO (DP-2): G-SYNC Compatible: EDID min refresh rate invalid, disabling G-SYNC Compatible.
[78632.530416] nvidia-modeset: WARNING: GPU:0: CSO (DP-2): G-SYNC Compatible: EDID min refresh rate invalid, disabling G-SYNC Compatible.
[79533.639730] nvidia-modeset: WARNING: GPU:0: CSO (DP-2): G-SYNC Compatible: EDID min refresh rate invalid, disabling G-SYNC Compatible.
[80434.701001] nvidia-modeset: WARNING: GPU:0: CSO (DP-2): G-SYNC Compatible: EDID min refresh rate invalid, disabling G-SYNC Compatible.
[81336.712540] nvidia-modeset: WARNING: GPU:0: CSO (DP-2): G-SYNC Compatible: EDID min refresh rate invalid, disabling G-SYNC Compatible.
[82237.755006] nvidia-modeset: WARNING: GPU:0: CSO (DP-2): G-SYNC Compatible: EDID min refresh rate invalid, disabling G-SYNC Compatible.
[82480.276540] perf: interrupt took too long (3940 > 3938), lowering kernel.perf_event_max_sample_rate to 50750
[83139.754215] nvidia-modeset: WARNING: GPU:0: CSO (DP-2): G-SYNC Compatible: EDID min refresh rate invalid, disabling G-SYNC Compatible.
[85604.477883] nvidia-modeset: WARNING: GPU:0: CSO (DP-2): G-SYNC Compatible: EDID min refresh rate invalid, disabling G-SYNC Compatible.
[86506.604536] nvidia-modeset: WARNING: GPU:0: CSO (DP-2): G-SYNC Compatible: EDID min refresh rate invalid, disabling G-SYNC Compatible.
[87407.755562] nvidia-modeset: WARNING: GPU:0: CSO (DP-2): G-SYNC Compatible: EDID min refresh rate invalid, disabling G-SYNC Compatible.
[88308.890971] nvidia-modeset: WARNING: GPU:0: CSO (DP-2): G-SYNC Compatible: EDID min refresh rate invalid, disabling G-SYNC Compatible.
[88597.066481] audit: type=1400 audit(1637630124.196:587): apparmor="DENIED" operation="open" profile="virt-aa-helper" name="/vms/cyk-21h2.box" pid=132984 comm="virt-aa-helper" requested_mask="r" denied_mask="r" fsuid=0 ouid=1000
[88597.192896] audit: type=1400 audit(1637630124.320:588): apparmor="STATUS" operation="profile_load" profile="unconfined" name="libvirt-bef51711-d586-401c-a90b-df6fc183c30f" pid=132986 comm="apparmor_parser"
[88597.215230] audit: type=1400 audit(1637630124.344:589): apparmor="DENIED" operation="open" profile="virt-aa-helper" name="/vms/cyk-21h2.box" pid=132987 comm="virt-aa-helper" requested_mask="r" denied_mask="r" fsuid=0 ouid=1000
[88597.336663] audit: type=1400 audit(1637630124.464:590): apparmor="STATUS" operation="profile_replace" profile="unconfined" name="libvirt-bef51711-d586-401c-a90b-df6fc183c30f" pid=132989 comm="apparmor_parser"
[88597.349808] audit: type=1400 audit(1637630124.480:591): apparmor="DENIED" operation="open" profile="virt-aa-helper" name="/vms/cyk-21h2.box" pid=132991 comm="virt-aa-helper" requested_mask="r" denied_mask="r" fsuid=0 ouid=1000
[88597.473226] audit: type=1400 audit(1637630124.600:592): apparmor="STATUS" operation="profile_replace" profile="unconfined" name="libvirt-bef51711-d586-401c-a90b-df6fc183c30f" pid=132993 comm="apparmor_parser"
[88597.486121] audit: type=1400 audit(1637630124.616:593): apparmor="DENIED" operation="open" profile="virt-aa-helper" name="/vms/cyk-21h2.box" pid=132995 comm="virt-aa-helper" requested_mask="r" denied_mask="r" fsuid=0 ouid=1000
[88597.608506] audit: type=1400 audit(1637630124.736:594): apparmor="STATUS" operation="profile_replace" info="same as current profile, skipping" profile="unconfined" name="libvirt-bef51711-d586-401c-a90b-df6fc183c30f" pid=132997 comm="apparmor_parser"
[88597.620119] virbr0: port 1(vnet3) entered blocking state
[88597.620122] virbr0: port 1(vnet3) entered disabled state
[88597.620182] device vnet3 entered promiscuous mode
[88597.620415] virbr0: port 1(vnet3) entered blocking state
[88597.620417] virbr0: port 1(vnet3) entered listening state
[88597.759001] audit: type=1400 audit(1637630124.888:595): apparmor="STATUS" operation="profile_replace" profile="unconfined" name="libvirt-bef51711-d586-401c-a90b-df6fc183c30f" pid=133016 comm="apparmor_parser"
[88597.806397] virbr0: port 1(vnet3) entered disabled state
[88597.807495] device vnet3 left promiscuous mode
[88597.807498] virbr0: port 1(vnet3) entered disabled state
[88740.024495] audit: type=1400 audit(1637630267.158:596): apparmor="DENIED" operation="open" profile="virt-aa-helper" name="/vms/cyk-21h2-win.box" pid=133138 comm="virt-aa-helper" requested_mask="r" denied_mask="r" fsuid=0 ouid=1000
[88740.147911] audit: type=1400 audit(1637630267.282:597): apparmor="STATUS" operation="profile_load" profile="unconfined" name="libvirt-978eb24b-3bfd-418c-a959-857634152a47" pid=133140 comm="apparmor_parser"
[88740.179265] audit: type=1400 audit(1637630267.310:598): apparmor="DENIED" operation="open" profile="virt-aa-helper" name="/vms/cyk-21h2-win.box" pid=133141 comm="virt-aa-helper" requested_mask="r" denied_mask="r" fsuid=0 ouid=1000
[88740.300298] audit: type=1400 audit(1637630267.434:599): apparmor="STATUS" operation="profile_replace" profile="unconfined" name="libvirt-978eb24b-3bfd-418c-a959-857634152a47" pid=133143 comm="apparmor_parser"
[88740.313174] audit: type=1400 audit(1637630267.446:600): apparmor="DENIED" operation="open" profile="virt-aa-helper" name="/vms/cyk-21h2-win.box" pid=133145 comm="virt-aa-helper" requested_mask="r" denied_mask="r" fsuid=0 ouid=1000
[88740.438488] audit: type=1400 audit(1637630267.570:601): apparmor="STATUS" operation="profile_replace" profile="unconfined" name="libvirt-978eb24b-3bfd-418c-a959-857634152a47" pid=133147 comm="apparmor_parser"
[88740.451971] audit: type=1400 audit(1637630267.586:602): apparmor="DENIED" operation="open" profile="virt-aa-helper" name="/vms/cyk-21h2-win.box" pid=133149 comm="virt-aa-helper" requested_mask="r" denied_mask="r" fsuid=0 ouid=1000
[88740.574274] audit: type=1400 audit(1637630267.706:603): apparmor="STATUS" operation="profile_replace" info="same as current profile, skipping" profile="unconfined" name="libvirt-978eb24b-3bfd-418c-a959-857634152a47" pid=133151 comm="apparmor_parser"
[88740.581288] virbr0: port 1(vnet4) entered blocking state
[88740.581291] virbr0: port 1(vnet4) entered disabled state
[88740.581351] device vnet4 entered promiscuous mode
[88740.581574] virbr0: port 1(vnet4) entered blocking state
[88740.581576] virbr0: port 1(vnet4) entered listening state
[88740.718124] audit: type=1400 audit(1637630267.850:604): apparmor="STATUS" operation="profile_replace" profile="unconfined" name="libvirt-978eb24b-3bfd-418c-a959-857634152a47" pid=133167 comm="apparmor_parser"
[88740.749047] virbr0: port 1(vnet4) entered disabled state
[88740.750112] device vnet4 left promiscuous mode
[88740.750116] virbr0: port 1(vnet4) entered disabled state
[88854.362080] audit: type=1400 audit(1637630381.496:605): apparmor="DENIED" operation="open" profile="virt-aa-helper" name="/vms/cyk-21h2-win.box" pid=133290 comm="virt-aa-helper" requested_mask="r" denied_mask="r" fsuid=0 ouid=1000
[88854.487417] audit: type=1400 audit(1637630381.620:606): apparmor="STATUS" operation="profile_load" profile="unconfined" name="libvirt-2e560e5b-d1b7-44a4-869e-a6e3ea79ff47" pid=133292 comm="apparmor_parser"
[88854.533583] audit: type=1400 audit(1637630381.664:607): apparmor="DENIED" operation="open" profile="virt-aa-helper" name="/vms/cyk-21h2-win.box" pid=133293 comm="virt-aa-helper" requested_mask="r" denied_mask="r" fsuid=0 ouid=1000
[88854.659521] audit: type=1400 audit(1637630381.792:608): apparmor="STATUS" operation="profile_replace" profile="unconfined" name="libvirt-2e560e5b-d1b7-44a4-869e-a6e3ea79ff47" pid=133295 comm="apparmor_parser"
[88854.672325] audit: type=1400 audit(1637630381.804:609): apparmor="DENIED" operation="open" profile="virt-aa-helper" name="/vms/cyk-21h2-win.box" pid=133297 comm="virt-aa-helper" requested_mask="r" denied_mask="r" fsuid=0 ouid=1000
[88854.794371] audit: type=1400 audit(1637630381.928:610): apparmor="STATUS" operation="profile_replace" profile="unconfined" name="libvirt-2e560e5b-d1b7-44a4-869e-a6e3ea79ff47" pid=133299 comm="apparmor_parser"
[88854.807267] audit: type=1400 audit(1637630381.940:611): apparmor="DENIED" operation="open" profile="virt-aa-helper" name="/vms/cyk-21h2-win.box" pid=133301 comm="virt-aa-helper" requested_mask="r" denied_mask="r" fsuid=0 ouid=1000
[88854.931166] audit: type=1400 audit(1637630382.064:612): apparmor="STATUS" operation="profile_replace" info="same as current profile, skipping" profile="unconfined" name="libvirt-2e560e5b-d1b7-44a4-869e-a6e3ea79ff47" pid=133303 comm="apparmor_parser"
[88854.938589] virbr0: port 1(vnet5) entered blocking state
[88854.938592] virbr0: port 1(vnet5) entered disabled state
[88854.938651] device vnet5 entered promiscuous mode
[88854.938891] virbr0: port 1(vnet5) entered blocking state
[88854.938894] virbr0: port 1(vnet5) entered listening state
[88855.075392] audit: type=1400 audit(1637630382.208:613): apparmor="STATUS" operation="profile_replace" profile="unconfined" name="libvirt-2e560e5b-d1b7-44a4-869e-a6e3ea79ff47" pid=133319 comm="apparmor_parser"
[88855.161865] virbr0: port 1(vnet5) entered disabled state
[88855.165922] device vnet5 left promiscuous mode
[88855.165935] virbr0: port 1(vnet5) entered disabled state
[88995.100212] audit: type=1400 audit(1637630522.238:614): apparmor="DENIED" operation="open" profile="virt-aa-helper" name="/vms/cyk-21h2-win.box" pid=133472 comm="virt-aa-helper" requested_mask="r" denied_mask="r" fsuid=0 ouid=0
[88995.226064] audit: type=1400 audit(1637630522.362:615): apparmor="STATUS" operation="profile_replace" profile="unconfined" name="libvirt-2e560e5b-d1b7-44a4-869e-a6e3ea79ff47" pid=133474 comm="apparmor_parser"
[88995.254006] audit: type=1400 audit(1637630522.390:616): apparmor="DENIED" operation="open" profile="virt-aa-helper" name="/vms/cyk-21h2-win.box" pid=133475 comm="virt-aa-helper" requested_mask="r" denied_mask="r" fsuid=0 ouid=0
[88995.376424] audit: type=1400 audit(1637630522.514:617): apparmor="STATUS" operation="profile_replace" profile="unconfined" name="libvirt-2e560e5b-d1b7-44a4-869e-a6e3ea79ff47" pid=133477 comm="apparmor_parser"
[88995.389314] audit: type=1400 audit(1637630522.526:618): apparmor="DENIED" operation="open" profile="virt-aa-helper" name="/vms/cyk-21h2-win.box" pid=133479 comm="virt-aa-helper" requested_mask="r" denied_mask="r" fsuid=0 ouid=0
[88995.512584] audit: type=1400 audit(1637630522.650:619): apparmor="STATUS" operation="profile_replace" profile="unconfined" name="libvirt-2e560e5b-d1b7-44a4-869e-a6e3ea79ff47" pid=133481 comm="apparmor_parser"
[88995.525514] audit: type=1400 audit(1637630522.662:620): apparmor="DENIED" operation="open" profile="virt-aa-helper" name="/vms/cyk-21h2-win.box" pid=133483 comm="virt-aa-helper" requested_mask="r" denied_mask="r" fsuid=0 ouid=0
[88995.648254] audit: type=1400 audit(1637630522.786:621): apparmor="STATUS" operation="profile_replace" info="same as current profile, skipping" profile="unconfined" name="libvirt-2e560e5b-d1b7-44a4-869e-a6e3ea79ff47" pid=133485 comm="apparmor_parser"
[88995.655271] virbr0: port 1(vnet6) entered blocking state
[88995.655274] virbr0: port 1(vnet6) entered disabled state
[88995.655342] device vnet6 entered promiscuous mode
[88995.655574] virbr0: port 1(vnet6) entered blocking state
[88995.655577] virbr0: port 1(vnet6) entered listening state
[88995.794959] audit: type=1400 audit(1637630522.930:622): apparmor="STATUS" operation="profile_replace" profile="unconfined" name="libvirt-2e560e5b-d1b7-44a4-869e-a6e3ea79ff47" pid=133501 comm="apparmor_parser"
[88997.663993] virbr0: port 1(vnet6) entered learning state
[88999.679919] virbr0: port 1(vnet6) entered forwarding state
[88999.679923] virbr0: topology change detected, propagating
[89206.961962] virbr0: port 1(vnet6) entered disabled state
[89206.963024] device vnet6 left promiscuous mode
[89206.963028] virbr0: port 1(vnet6) entered disabled state
[89207.289145] audit: type=1400 audit(1637630734.429:623): apparmor="STATUS" operation="profile_remove" profile="unconfined" name="libvirt-2e560e5b-d1b7-44a4-869e-a6e3ea79ff47" pid=134222 comm="apparmor_parser"
[89229.824535] audit: type=1400 audit(1637630756.962:624): apparmor="STATUS" operation="profile_load" profile="unconfined" name="libvirt-2e560e5b-d1b7-44a4-869e-a6e3ea79ff47" pid=134261 comm="apparmor_parser"
[89229.973650] audit: type=1400 audit(1637630757.114:625): apparmor="STATUS" operation="profile_replace" profile="unconfined" name="libvirt-2e560e5b-d1b7-44a4-869e-a6e3ea79ff47" pid=134264 comm="apparmor_parser"
[89230.110038] audit: type=1400 audit(1637630757.250:626): apparmor="STATUS" operation="profile_replace" profile="unconfined" name="libvirt-2e560e5b-d1b7-44a4-869e-a6e3ea79ff47" pid=134268 comm="apparmor_parser"
[89230.249701] audit: type=1400 audit(1637630757.390:627): apparmor="STATUS" operation="profile_replace" info="same as current profile, skipping" profile="unconfined" name="libvirt-2e560e5b-d1b7-44a4-869e-a6e3ea79ff47" pid=134272 comm="apparmor_parser"
[89230.257339] virbr0: port 1(vnet7) entered blocking state
[89230.257343] virbr0: port 1(vnet7) entered disabled state
[89230.257418] device vnet7 entered promiscuous mode
[89230.257673] virbr0: port 1(vnet7) entered blocking state
[89230.257676] virbr0: port 1(vnet7) entered listening state
[89230.397720] audit: type=1400 audit(1637630757.538:628): apparmor="STATUS" operation="profile_replace" profile="unconfined" name="libvirt-2e560e5b-d1b7-44a4-869e-a6e3ea79ff47" pid=134286 comm="apparmor_parser"
[89230.457459] virbr0: port 1(vnet7) entered disabled state
[89230.461590] device vnet7 left promiscuous mode
[89230.461601] virbr0: port 1(vnet7) entered disabled state
[89231.508713] audit: type=1400 audit(1637630758.650:629): apparmor="STATUS" operation="profile_replace" profile="unconfined" name="libvirt-2e560e5b-d1b7-44a4-869e-a6e3ea79ff47" pid=134299 comm="apparmor_parser"
[89231.649677] audit: type=1400 audit(1637630758.790:630): apparmor="STATUS" operation="profile_replace" profile="unconfined" name="libvirt-2e560e5b-d1b7-44a4-869e-a6e3ea79ff47" pid=134302 comm="apparmor_parser"
[89231.786152] audit: type=1400 audit(1637630758.926:631): apparmor="STATUS" operation="profile_replace" profile="unconfined" name="libvirt-2e560e5b-d1b7-44a4-869e-a6e3ea79ff47" pid=134306 comm="apparmor_parser"
[89231.924429] audit: type=1400 audit(1637630759.062:632): apparmor="STATUS" operation="profile_replace" info="same as current profile, skipping" profile="unconfined" name="libvirt-2e560e5b-d1b7-44a4-869e-a6e3ea79ff47" pid=134310 comm="apparmor_parser"
[89231.931348] virbr0: port 1(vnet8) entered blocking state
[89231.931351] virbr0: port 1(vnet8) entered disabled state
[89231.931410] device vnet8 entered promiscuous mode
[89231.931646] virbr0: port 1(vnet8) entered blocking state
[89231.931649] virbr0: port 1(vnet8) entered listening state
[89232.070995] audit: type=1400 audit(1637630759.210:633): apparmor="STATUS" operation="profile_replace" profile="unconfined" name="libvirt-2e560e5b-d1b7-44a4-869e-a6e3ea79ff47" pid=134323 comm="apparmor_parser"
[89232.135598] virbr0: port 1(vnet8) entered disabled state
[89232.136625] device vnet8 left promiscuous mode
[89232.136627] virbr0: port 1(vnet8) entered disabled state
[89314.064332] audit: type=1400 audit(1637630841.207:634): apparmor="STATUS" operation="profile_replace" profile="unconfined" name="libvirt-2e560e5b-d1b7-44a4-869e-a6e3ea79ff47" pid=134379 comm="apparmor_parser"
[89314.211227] audit: type=1400 audit(1637630841.351:635): apparmor="STATUS" operation="profile_replace" profile="unconfined" name="libvirt-2e560e5b-d1b7-44a4-869e-a6e3ea79ff47" pid=134382 comm="apparmor_parser"
[89314.347101] audit: type=1400 audit(1637630841.487:636): apparmor="STATUS" operation="profile_replace" profile="unconfined" name="libvirt-2e560e5b-d1b7-44a4-869e-a6e3ea79ff47" pid=134386 comm="apparmor_parser"
[89314.483224] audit: type=1400 audit(1637630841.623:637): apparmor="STATUS" operation="profile_replace" info="same as current profile, skipping" profile="unconfined" name="libvirt-2e560e5b-d1b7-44a4-869e-a6e3ea79ff47" pid=134390 comm="apparmor_parser"
[89314.490262] virbr0: port 1(vnet9) entered blocking state
[89314.490266] virbr0: port 1(vnet9) entered disabled state
[89314.490339] device vnet9 entered promiscuous mode
[89314.490586] virbr0: port 1(vnet9) entered blocking state
[89314.490588] virbr0: port 1(vnet9) entered listening state
[89314.625807] audit: type=1400 audit(1637630841.767:638): apparmor="STATUS" operation="profile_replace" profile="unconfined" name="libvirt-2e560e5b-d1b7-44a4-869e-a6e3ea79ff47" pid=134408 comm="apparmor_parser"
[89314.668882] virbr0: port 1(vnet9) entered disabled state
[89314.669881] device vnet9 left promiscuous mode
[89314.669883] virbr0: port 1(vnet9) entered disabled state
[89333.012831] nvidia-modeset: WARNING: GPU:0: CSO (DP-2): G-SYNC Compatible: EDID min refresh rate invalid, disabling G-SYNC Compatible.
[89463.535614] audit: type=1400 audit(1637630990.677:639): apparmor="STATUS" operation="profile_replace" profile="unconfined" name="libvirt-2e560e5b-d1b7-44a4-869e-a6e3ea79ff47" pid=134856 comm="apparmor_parser"
[89463.676922] audit: type=1400 audit(1637630990.817:640): apparmor="STATUS" operation="profile_replace" profile="unconfined" name="libvirt-2e560e5b-d1b7-44a4-869e-a6e3ea79ff47" pid=134859 comm="apparmor_parser"
[89463.813016] audit: type=1400 audit(1637630990.953:641): apparmor="STATUS" operation="profile_replace" profile="unconfined" name="libvirt-2e560e5b-d1b7-44a4-869e-a6e3ea79ff47" pid=134863 comm="apparmor_parser"
[89463.948861] audit: type=1400 audit(1637630991.089:642): apparmor="STATUS" operation="profile_replace" info="same as current profile, skipping" profile="unconfined" name="libvirt-2e560e5b-d1b7-44a4-869e-a6e3ea79ff47" pid=134867 comm="apparmor_parser"
[89463.956115] virbr0: port 1(vnet10) entered blocking state
[89463.956118] virbr0: port 1(vnet10) entered disabled state
[89463.956177] device vnet10 entered promiscuous mode
[89463.956404] virbr0: port 1(vnet10) entered blocking state
[89463.956406] virbr0: port 1(vnet10) entered listening state
[89464.092389] audit: type=1400 audit(1637630991.233:643): apparmor="STATUS" operation="profile_replace" profile="unconfined" name="libvirt-2e560e5b-d1b7-44a4-869e-a6e3ea79ff47" pid=134883 comm="apparmor_parser"
[89465.977212] virbr0: port 1(vnet10) entered learning state
[89467.993144] virbr0: port 1(vnet10) entered forwarding state
[89467.993147] virbr0: topology change detected, propagating
[89811.798158] audit: type=1400 audit(1637631338.946:644): apparmor="ALLOWED" operation="open" profile="libreoffice-soffice" name="/usr/local/lib/libgtk-3.so.0.2404.26" pid=135442 comm="soffice.bin" requested_mask="r" denied_mask="r" fsuid=1000 ouid=0
[89811.798167] audit: type=1400 audit(1637631338.946:645): apparmor="ALLOWED" operation="file_mmap" profile="libreoffice-soffice" name="/usr/local/lib/libgtk-3.so.0.2404.26" pid=135442 comm="soffice.bin" requested_mask="rm" denied_mask="rm" fsuid=1000 ouid=0
[89811.798520] audit: type=1400 audit(1637631338.946:646): apparmor="ALLOWED" operation="open" profile="libreoffice-soffice" name="/usr/local/lib/libgdk-3.so.0.2404.26" pid=135442 comm="soffice.bin" requested_mask="r" denied_mask="r" fsuid=1000 ouid=0
[89811.798540] audit: type=1400 audit(1637631338.946:647): apparmor="ALLOWED" operation="file_mmap" profile="libreoffice-soffice" name="/usr/local/lib/libgdk-3.so.0.2404.26" pid=135442 comm="soffice.bin" requested_mask="rm" denied_mask="rm" fsuid=1000 ouid=0
[89811.800860] audit: type=1400 audit(1637631338.950:648): apparmor="ALLOWED" operation="open" profile="libreoffice-soffice" name="/proc/135443/comm" pid=135443 comm="soffice.bin" requested_mask="r" denied_mask="r" fsuid=1000 ouid=1000
[89811.810026] audit: type=1400 audit(1637631338.958:649): apparmor="ALLOWED" operation="sendmsg" profile="libreoffice-soffice" pid=135443 comm="soffice.bin" family="unix" sock_type="dgram" protocol=0 requested_mask="send" denied_mask="send" addr=none peer_addr="@7661722F72756E2F6E76696469612D786472697665722D34313562643738390000000000000000000000000000000000000000000000000000000000000000" peer="unconfined"
[89811.810230] audit: type=1400 audit(1637631338.958:650): apparmor="ALLOWED" operation="sendmsg" profile="libreoffice-soffice" pid=135443 comm="soffice.bin" family="unix" sock_type="dgram" protocol=0 requested_mask="send" denied_mask="send" addr=none peer_addr="@7661722F72756E2F6E76696469612D786472697665722D34313562643738390000000000000000000000000000000000000000000000000000000000000000" peer="unconfined"
[89811.811003] audit: type=1400 audit(1637631338.958:651): apparmor="ALLOWED" operation="open" profile="libreoffice-soffice" name="/proc/135443/comm" pid=135443 comm="soffice.bin" requested_mask="r" denied_mask="r" fsuid=1000 ouid=1000
[89811.816883] audit: type=1400 audit(1637631338.966:652): apparmor="ALLOWED" operation="open" profile="libreoffice-soffice" name="/home/redacted/.cache/nvidia/GLCache/f05ba6749fb3432b0cb5cac2710edf90/160b6486f2bf34a6/fd9ae88212ee1ec4.toc" pid=135443 comm="soffice.bin" requested_mask="wr" denied_mask="wr" fsuid=1000 ouid=1000
[89811.816887] audit: type=1400 audit(1637631338.966:653): apparmor="ALLOWED" operation="file_lock" profile="libreoffice-soffice" name="/home/redacted/.cache/nvidia/GLCache/f05ba6749fb3432b0cb5cac2710edf90/160b6486f2bf34a6/fd9ae88212ee1ec4.toc" pid=135443 comm="soffice.bin" requested_mask="wk" denied_mask="wk" fsuid=1000 ouid=1000
[89822.999608] kauditd_printk_skb: 14 callbacks suppressed
[89822.999610] audit: type=1400 audit(1637631350.146:668): apparmor="DENIED" operation="open" profile="/usr/bin/evince" name="/usr/local/lib/libgtk-3.so.0.2404.26" pid=135550 comm="evince" requested_mask="r" denied_mask="r" fsuid=1000 ouid=0
[89823.000313] audit: type=1400 audit(1637631350.150:669): apparmor="DENIED" operation="open" profile="/usr/bin/evince" name="/usr/local/lib/libgdk-3.so.0.2404.26" pid=135550 comm="evince" requested_mask="r" denied_mask="r" fsuid=1000 ouid=0
[91322.760532] audit: type=1400 audit(1637632849.932:670): apparmor="DENIED" operation="open" profile="/usr/sbin/cupsd" name="/proc/sys/kernel/osrelease" pid=79113 comm="cupsd" requested_mask="r" denied_mask="r" fsuid=0 ouid=0
[91322.760582] audit: type=1400 audit(1637632849.932:671): apparmor="DENIED" operation="open" profile="/usr/sbin/cupsd" name="/proc/1/environ" pid=79113 comm="cupsd" requested_mask="r" denied_mask="r" fsuid=0 ouid=0
[91322.760608] audit: type=1400 audit(1637632849.932:672): apparmor="DENIED" operation="open" profile="/usr/sbin/cupsd" name="/proc/cmdline" pid=79113 comm="cupsd" requested_mask="r" denied_mask="r" fsuid=0 ouid=0
[91322.760645] audit: type=1400 audit(1637632849.932:673): apparmor="DENIED" operation="connect" profile="/usr/sbin/cupsd" name="/run/systemd/userdb/io.systemd.Machine" pid=79113 comm="cupsd" requested_mask="w" denied_mask="w" fsuid=0 ouid=0
[91322.760773] audit: type=1400 audit(1637632849.932:674): apparmor="DENIED" operation="connect" profile="/usr/sbin/cupsd" name="/run/systemd/userdb/io.systemd.Machine" pid=79113 comm="cupsd" requested_mask="w" denied_mask="w" fsuid=0 ouid=0
[93008.127165] nvidia-modeset: WARNING: GPU:0: CSO (DP-2): G-SYNC Compatible: EDID min refresh rate invalid, disabling G-SYNC Compatible.
[94077.041858] NVRM: GPU at PCI:0000:01:00: GPU-77be50ee-6e62-aad1-c3a3-0010500122f6
[94077.041861] NVRM: Xid (PCI:0000:01:00): 79, pid=0, GPU has fallen off the bus.
[94077.041863] NVRM: GPU 0000:01:00.0: GPU has fallen off the bus.
[94077.041883] NVRM: GPU 0000:01:00.0: GPU serial number is \xff\xff\xff\xff\xff\xff\xff\xff\xff\xff\xff\xff\xff\xff\xff\xff\xff\xff\xff\xff\xff\xff\xff\xff\xff\xff\xff\xff\xff\xff\xff\xff\xff\xff\xff\xff\xff\xff\xff\xff\xff\xff\xff\xff\xff\xff\xff\xff\xff\xff\xff\xff\xff\xff\xff\xff\xff\xff\xff\xff\xff\xff\xff\xff\xff\xff\xff\xff\xff\xff\xff\xff\xff\xff\xff\xff\xff\xff\xff\xff\xff\xff\xff\xff\xff\xff\xff.
[94077.041891] NVRM: A GPU crash dump has been created. If possible, please run
NVRM: nvidia-bug-report.sh as root to collect this data before
NVRM: the NVIDIA kernel module is unloaded.
[94077.370177] nvidia-modeset: ERROR: GPU:0: Failed to query display engine channel state: 0x0000c57e:0:0:0x0000000f
[94078.683240] irq 16: nobody cared (try booting with the "irqpoll" option)
[94078.683244] CPU: 7 PID: 0 Comm: swapper/7 Tainted: P O 5.13.0-21-generic #21-Ubuntu
[94078.683246] Hardware name: LENOVO 20TKCTO1WW/20TKCTO1WW, BIOS N2VET26W (1.11 ) 11/16/2020
[94078.683247] Call Trace:
[94078.683249] <IRQ>
[94078.683251] show_stack+0x52/0x58
[94078.683254] dump_stack+0x7d/0x9c
[94078.683257] __report_bad_irq+0x3a/0xaf
[94078.683260] note_interrupt.cold+0xb/0x60
[94078.683262] handle_irq_event+0xaa/0xc0
[94078.683265] handle_fasteoi_irq+0x7d/0x1c0
[94078.683267] __common_interrupt+0x40/0xa0
[94078.683269] common_interrupt+0x88/0xa0
[94078.683272] </IRQ>
[94078.683272] asm_common_interrupt+0x1e/0x40
[94078.683274] RIP: 0010:cpuidle_enter_state+0xcc/0x360
[94078.683277] Code: 3d 71 76 a8 5d e8 64 d2 75 ff 49 89 c6 0f 1f 44 00 00 31 ff e8 05 de 75 ff 80 7d d7 00 0f 85 04 01 00 00 fb 66 0f 1f 44 00 00 <45> 85 ff 0f 88 10 01 00 00 49 63 d7 4c 89 f1 48 2b 4d c8 48 8d 04
[94078.683278] RSP: 0018:ffffb40080143e50 EFLAGS: 00000246
[94078.683280] RAX: ffff9a7701bece80 RBX: 0000000000000001 RCX: 000000000000001f
[94078.683281] RDX: 0000000000000000 RSI: 00000000355533d6 RDI: 0000000000000000
[94078.683282] RBP: ffffb40080143e88 R08: 00005590667eba86 R09: 0000000000000008
[94078.683283] R10: 0000000000000009 R11: ffffffffa3c50b60 R12: ffffd4007fbc0a50
[94078.683284] R13: ffffffffa3c50b60 R14: 00005590667eba86 R15: 0000000000000001
[94078.683286] cpuidle_enter+0x2e/0x40
[94078.683288] cpuidle_idle_call+0x132/0x1d0
[94078.683291] do_idle+0x83/0xf0
[94078.683292] cpu_startup_entry+0x20/0x30
[94078.683293] start_secondary+0x11f/0x160
[94078.683294] secondary_startup_64_no_verify+0xc2/0xcb
[94078.683297] handlers:
[94078.683298] [<000000007f167ca0>] i801_isr [i2c_i801]
[94078.683302] Disabling IRQ #16
[94082.378282] nvidia-modeset: ERROR: GPU:0: Failed to query display engine channel state: 0x0000c57e:0:0:0x0000000f
[94087.385382] nvidia-modeset: ERROR: GPU:0: Failed to query display engine channel state: 0x0000c57e:0:0:0x0000000f
[94087.385467] nvidia-modeset: ERROR: GPU:0: Failed to query display engine channel state: 0x0000c57e:0:0:0x0000000f
[94087.386592] nvidia-modeset: ERROR: GPU:0: Failed to query display engine channel state: 0x0000c57e:0:0:0x0000000f
[94087.386701] nvidia-modeset: ERROR: GPU:0: Failed to query display engine channel state: 0x0000c57e:0:0:0x0000000f
[94087.387834] nvidia-modeset: ERROR: GPU:0: Failed to query display engine channel state: 0x0000c57e:0:0:0x0000000f
[94087.387930] nvidia-modeset: ERROR: GPU:0: Failed to query display engine channel state: 0x0000c57e:0:0:0x0000000f
[94087.406227] nvidia-modeset: ERROR: GPU:0: Failed to query display engine channel state: 0x0000c57e:0:0:0x0000000f
[94092.409651] nvidia-modeset: ERROR: GPU:0: Failed to query display engine channel state: 0x0000c57e:0:0:0x0000000f
