System freezes dead (any distribution)
When I’m playing games or otherwise loading the computer, the system freezes dead at any kernel (only a reboot helps). There used to be a problem, such a problem (it appeared ± half a year ago). During such freezes, journalctl wrote: GPU has fallen off the bus (Nvidia). This problem went away (sometimes can be gpu has fallen of the bus, but sometimes even without it) after I wrote in the grub settings acpi=noirq thermal.off=1 And the error disappeared, but the freezes remained. Here are the kernel logs:
[    0.000000] Linux version 6.8.1-zen1-1-zen (linux-zen@archlinux) (gcc (GCC) 13.2.1 20230801, GNU ld (GNU Binutils) 2.42.0) #1 ZEN SMP PREEMPT_DYNAMIC Sat, 16 Mar 2024 17:15:23 +0000
[    0.000000] Command line: BOOT_IMAGE=/@/boot/vmlinuz-linux-zen root=UUID=63f0d3ca-84ab-482c-8b6a-e5009cdeb426 rw rootflags=subvol=@ nowatchdog nvme_load=YES resume=UUID=4d813d8e-ca07-4ab7-a959-6aed44d44e4e nvidia-drm.modeset=1 loglevel=3
[    0.000000] BIOS-provided physical RAM map:
[    0.000000] BIOS-e820: [mem 0x0000000000000000-0x000000000009efff] usable
[    0.000000] BIOS-e820: [mem 0x000000000009f000-0x00000000000fffff] reserved
[    0.000000] BIOS-e820: [mem 0x0000000000100000-0x0000000023563fff] usable
[    0.000000] BIOS-e820: [mem 0x0000000023564000-0x0000000023564fff] ACPI NVS
[    0.000000] BIOS-e820: [mem 0x0000000023565000-0x0000000023565fff] reserved
[    0.000000] BIOS-e820: [mem 0x0000000023566000-0x000000002daf5fff] usable
[    0.000000] BIOS-e820: [mem 0x000000002daf6000-0x000000002efa5fff] reserved
[    0.000000] BIOS-e820: [mem 0x000000002efa6000-0x000000002f022fff] ACPI data
[    0.000000] BIOS-e820: [mem 0x000000002f023000-0x000000002f519fff] ACPI NVS
[    0.000000] BIOS-e820: [mem 0x000000002f51a000-0x000000002fffefff] reserved
[    0.000000] BIOS-e820: [mem 0x000000002ffff000-0x000000002fffffff] usable
[    0.000000] BIOS-e820: [mem 0x0000000030000000-0x0000000038ffffff] reserved
[    0.000000] BIOS-e820: [mem 0x00000000e0000000-0x00000000efffffff] reserved
[    0.000000] BIOS-e820: [mem 0x00000000fe000000-0x00000000fe010fff] reserved
[    0.000000] BIOS-e820: [mem 0x00000000fec00000-0x00000000fec00fff] reserved
[    0.000000] BIOS-e820: [mem 0x00000000fee00000-0x00000000fee00fff] reserved
[    0.000000] BIOS-e820: [mem 0x00000000ff000000-0x00000000ffffffff] reserved
[    0.000000] BIOS-e820: [mem 0x0000000100000000-0x00000004c4ffffff] usable
[    0.000000] The simpledrm driver will not be probed
[    0.000000] NX (Execute Disable) protection: active
[    0.000000] APIC: Static calls initialized
[    0.000000] e820: update [mem 0x16b3a018-0x16b59c57] usable ==> usable
[    0.000000] e820: update [mem 0x16b1c018-0x16b39c57] usable ==> usable
[    0.000000] e820: update [mem 0x16b0d018-0x16b1b057] usable ==> usable
[    0.000000] extended physical RAM map:
[    0.000000] reserve setup_data: [mem 0x0000000000000000-0x000000000009efff] usable
[    0.000000] reserve setup_data: [mem 0x000000000009f000-0x00000000000fffff] reserved
[    0.000000] reserve setup_data: [mem 0x0000000000100000-0x0000000016b0d017] usable
[    0.000000] reserve setup_data: [mem 0x0000000016b0d018-0x0000000016b1b057] usable
[    0.000000] reserve setup_data: [mem 0x0000000016b1b058-0x0000000016b1c017] usable
[    0.000000] reserve setup_data: [mem 0x0000000016b1c018-0x0000000016b39c57] usable
[    0.000000] reserve setup_data: [mem 0x0000000016b39c58-0x0000000016b3a017] usable
[    0.000000] reserve setup_data: [mem 0x0000000016b3a018-0x0000000016b59c57] usable
[    0.000000] reserve setup_data: [mem 0x0000000016b59c58-0x0000000023563fff] usable
[    0.000000] reserve setup_data: [mem 0x0000000023564000-0x0000000023564fff] ACPI NVS
[    0.000000] reserve setup_data: [mem 0x0000000023565000-0x0000000023565fff] reserved
[    0.000000] reserve setup_data: [mem 0x0000000023566000-0x000000002daf5fff] usable
[    0.000000] reserve setup_data: [mem 0x000000002daf6000-0x000000002efa5fff] reserved
[    0.000000] reserve setup_data: [mem 0x000000002efa6000-0x000000002f022fff] ACPI data
[    0.000000] reserve setup_data: [mem 0x000000002f023000-0x000000002f519fff] ACPI NVS
[    0.000000] reserve setup_data: [mem 0x000000002f51a000-0x000000002fffefff] reserved
[    0.000000] reserve setup_data: [mem 0x000000002ffff000-0x000000002fffffff] usable
[    0.000000] reserve setup_data: [mem 0x0000000030000000-0x0000000038ffffff] reserved
[    0.000000] reserve setup_data: [mem 0x00000000e0000000-0x00000000efffffff] reserved
[    0.000000] reserve setup_data: [mem 0x00000000fe000000-0x00000000fe010fff] reserved
[    0.000000] reserve setup_data: [mem 0x00000000fec00000-0x00000000fec00fff] reserved
[    0.000000] reserve setup_data: [mem 0x00000000fee00000-0x00000000fee00fff] reserved
[    0.000000] reserve setup_data: [mem 0x00000000ff000000-0x00000000ffffffff] reserved
[    0.000000] reserve setup_data: [mem 0x0000000100000000-0x00000004c4ffffff] usable
[    0.000000] efi: EFI v2.7 by American Megatrends
[    0.000000] efi: ACPI 2.0=0x2f46e000 ACPI=0x2f46e000 SMBIOS=0x2fd39000 SMBIOS 3.0=0x2fd38000 ESRT=0x2998ae18 MEMATTR=0x2c050018 INITRD=0x2365ce98 RNG=0x2f022018
[    0.000000] random: crng init done
[    0.000000] efi: Remove mem35: MMIO range=[0xe0000000-0xefffffff] (256MB) from e820 map
[    0.000000] e820: remove [mem 0xe0000000-0xefffffff] reserved
[    0.000000] efi: Not removing mem36: MMIO range=[0xfe000000-0xfe010fff] (68KB) from e820 map
[    0.000000] efi: Not removing mem37: MMIO range=[0xfec00000-0xfec00fff] (4KB) from e820 map
[    0.000000] efi: Not removing mem38: MMIO range=[0xfee00000-0xfee00fff] (4KB) from e820 map
[    0.000000] efi: Remove mem39: MMIO range=[0xff000000-0xffffffff] (16MB) from e820 map
[    0.000000] e820: remove [mem 0xff000000-0xffffffff] reserved
[    0.000000] SMBIOS 3.1.1 present.
[    0.000000] DMI: Gigabyte Technology Co., Ltd. Z390 D/Z390 D, BIOS F3 11/05/2021
[    0.000000] tsc: Detected 3000.000 MHz processor
[    0.002703] e820: update [mem 0x00000000-0x00000fff] usable ==> reserved
[    0.002706] e820: remove [mem 0x000a0000-0x000fffff] usable
[    0.002715] last_pfn = 0x4c5000 max_arch_pfn = 0x400000000
[    0.002719] MTRR map: 4 entries (3 fixed + 1 variable; max 23), built from 10 variable MTRRs
[    0.002721] x86/PAT: Configuration [0-7]: WB  WC  UC- UC  WB  WP  UC- WT
[    0.002948] last_pfn = 0x30000 max_arch_pfn = 0x400000000
[    0.009888] esrt: Reserving ESRT space from 0x000000002998ae18 to 0x000000002998ae50.
[    0.009892] e820: update [mem 0x2998a000-0x2998afff] usable ==> reserved
[    0.009907] Using GB pages for direct mapping
[    0.010201] Secure boot disabled
[    0.010202] RAMDISK: [mem 0x1745a000-0x1dd48fff]
[    0.010207] ACPI: Early table checksum verification disabled
[    0.010209] ACPI: RSDP 0x000000002F46E000 000024 (v02 ALASKA)
[    0.010213] ACPI: XSDT 0x000000002F46E0B0 0000E4 (v01 ALASKA A M I    01072009 AMI  00010013)
[    0.010217] ACPI: FACP 0x000000002F4AEDB0 000114 (v06 ALASKA A M I    01072009 AMI  00010013)
[    0.010222] ACPI: DSDT 0x000000002F46E230 040B80 (v02 ALASKA A M I    01072009 INTL 20160527)
[    0.010225] ACPI: FACS 0x000000002F519080 000040
[    0.010227] ACPI: APIC 0x000000002F4AEEC8 0000BC (v04 ALASKA A M I    01072009 AMI  00010013)
[    0.010229] ACPI: FPDT 0x000000002F4AEF88 000044 (v01 ALASKA A M I    01072009 AMI  00010013)
[    0.010232] ACPI: FIDT 0x000000002F4AEFD0 00009C (v01 ALASKA A M I    01072009 AMI  00010013)
[    0.010234] ACPI: MCFG 0x000000002F4AF070 00003C (v01 ALASKA A M I    01072009 MSFT 00000097)
[    0.010237] ACPI: SSDT 0x000000002F4AF0B0 000204 (v01 ALASKA A M I    00001000 INTL 20160527)
[    0.010240] ACPI: SSDT 0x000000002F4AF2B8 0017D5 (v02 ALASKA A M I    00003000 INTL 20160527)
[    0.010242] ACPI: SSDT 0x000000002F4B0A90 008739 (v01 ALASKA A M I    00000001 INTL 20160527)
[    0.010245] ACPI: SSDT 0x000000002F4B91D0 0031C7 (v02 ALASKA A M I    00003000 INTL 20160527)
[    0.010247] ACPI: SSDT 0x000000002F4BC398 002358 (v02 ALASKA A M I    00001000 INTL 20160527)
[    0.010250] ACPI: HPET 0x000000002F4BE6F0 000038 (v01 ALASKA A M I    00000002      01000013)
[    0.010253] ACPI: SSDT 0x000000002F4BE728 000F9E (v02 ALASKA A M I    00001000 INTL 20160527)
[    0.010255] ACPI: SSDT 0x000000002F4BF6C8 002D1B (v02 ALASKA A M I    00000000 INTL 20160527)
[    0.010258] ACPI: UEFI 0x000000002F4C23E8 000042 (v01 ALASKA A M I    00000002      01000013)
[    0.010260] ACPI: LPIT 0x000000002F4C2430 00005C (v01 ALASKA A M I    00000002      01000013)
[    0.010263] ACPI: SSDT 0x000000002F4C2490 0027DE (v02 ALASKA A M I    00001000 INTL 20160527)
[    0.010265] ACPI: SSDT 0x000000002F4C4C70 000FFE (v02 ALASKA A M I    00000000 INTL 20160527)
[    0.010268] ACPI: DBGP 0x000000002F4C5C70 000034 (v01 ALASKA A M I    00000002      01000013)
[    0.010270] ACPI: DBG2 0x000000002F4C5CA8 000054 (v00 ALASKA A M I    00000002      01000013)
[    0.010273] ACPI: DMAR 0x000000002F4C5D00 000070 (v01 ALASKA A M I    00000002      01000013)
[    0.010276] ACPI: BGRT 0x000000002F4C5D70 000038 (v01 ALASKA A M I    01072009 AMI  00010013)
[    0.010278] ACPI: UEFI 0x000000002F4C5DA8 00063A (v01 ALASKA A M I    00000000 ??   00000000)
[    0.010281] ACPI: UEFI 0x000000002F4C63E8 00005C (v01 ALASKA A M I    00000000 ??   00000000)
[    0.010283] ACPI: WSMT 0x000000002F4C6448 000028 (v01 ALASKA A M I    01072009 AMI  00010013)
[    0.010286] ACPI: Reserving FACP table memory at [mem 0x2f4aedb0-0x2f4aeec3]
[    0.010287] ACPI: Reserving DSDT table memory at [mem 0x2f46e230-0x2f4aedaf]
[    0.010288] ACPI: Reserving FACS table memory at [mem 0x2f519080-0x2f5190bf]
[    0.010289] ACPI: Reserving APIC table memory at [mem 0x2f4aeec8-0x2f4aef83]
[    0.010290] ACPI: Reserving FPDT table memory at [mem 0x2f4aef88-0x2f4aefcb]
[    0.010290] ACPI: Reserving FIDT table memory at [mem 0x2f4aefd0-0x2f4af06b]
[    0.010291] ACPI: Reserving MCFG table memory at [mem 0x2f4af070-0x2f4af0ab]
[    0.010292] ACPI: Reserving SSDT table memory at [mem 0x2f4af0b0-0x2f4af2b3]
[    0.010293] ACPI: Reserving SSDT table memory at [mem 0x2f4af2b8-0x2f4b0a8c]
[    0.010293] ACPI: Reserving SSDT table memory at [mem 0x2f4b0a90-0x2f4b91c8]
[    0.010294] ACPI: Reserving SSDT table memory at [mem 0x2f4b91d0-0x2f4bc396]
[    0.010295] ACPI: Reserving SSDT table memory at [mem 0x2f4bc398-0x2f4be6ef]
[    0.010296] ACPI: Reserving HPET table memory at [mem 0x2f4be6f0-0x2f4be727]
[    0.010296] ACPI: Reserving SSDT table memory at [mem 0x2f4be728-0x2f4bf6c5]
[    0.010297] ACPI: Reserving SSDT table memory at [mem 0x2f4bf6c8-0x2f4c23e2]
[    0.010298] ACPI: Reserving UEFI table memory at [mem 0x2f4c23e8-0x2f4c2429]
[    0.010299] ACPI: Reserving LPIT table memory at [mem 0x2f4c2430-0x2f4c248b]
[    0.010299] ACPI: Reserving SSDT table memory at [mem 0x2f4c2490-0x2f4c4c6d]
[    0.010300] ACPI: Reserving SSDT table memory at [mem 0x2f4c4c70-0x2f4c5c6d]
[    0.010301] ACPI: Reserving DBGP table memory at [mem 0x2f4c5c70-0x2f4c5ca3]
[    0.010302] ACPI: Reserving DBG2 table memory at [mem 0x2f4c5ca8-0x2f4c5cfb]
[    0.010302] ACPI: Reserving DMAR table memory at [mem 0x2f4c5d00-0x2f4c5d6f]
[    0.010303] ACPI: Reserving BGRT table memory at [mem 0x2f4c5d70-0x2f4c5da7]
[    0.010304] ACPI: Reserving UEFI table memory at [mem 0x2f4c5da8-0x2f4c63e1]
[    0.010305] ACPI: Reserving UEFI table memory at [mem 0x2f4c63e8-0x2f4c6443]
[    0.010305] ACPI: Reserving WSMT table memory at [mem 0x2f4c6448-0x2f4c646f]
[    0.010562] No NUMA configuration found
[    0.010563] Faking a node at [mem 0x0000000000000000-0x00000004c4ffffff]
[    0.010565] NODE_DATA(0) allocated [mem 0x4c4ffb000-0x4c4ffffff]
[    0.010589] Zone ranges:
[    0.010590]   DMA      [mem 0x0000000000001000-0x0000000000ffffff]
[    0.010592]   DMA32    [mem 0x0000000001000000-0x00000000ffffffff]
[    0.010593]   Normal   [mem 0x0000000100000000-0x00000004c4ffffff]
[    0.010594]   Device   empty
[    0.010595] Movable zone start for each node
[    0.010596] Early memory node ranges
[    0.010596]   node   0: [mem 0x0000000000001000-0x000000000009efff]
[    0.010598]   node   0: [mem 0x0000000000100000-0x0000000023563fff]
[    0.010599]   node   0: [mem 0x0000000023566000-0x000000002daf5fff]
[    0.010599]   node   0: [mem 0x000000002ffff000-0x000000002fffffff]
[    0.010600]   node   0: [mem 0x0000000100000000-0x00000004c4ffffff]
[    0.010603] Initmem setup node 0 [mem 0x0000000000001000-0x00000004c4ffffff]
[    0.010606] On node 0, zone DMA: 1 pages in unavailable ranges
[    0.010622] On node 0, zone DMA: 97 pages in unavailable ranges
[    0.011334] On node 0, zone DMA32: 2 pages in unavailable ranges
[    0.011415] On node 0, zone DMA32: 9481 pages in unavailable ranges
[    0.027877] On node 0, zone Normal: 12288 pages in unavailable ranges
[    0.028458] ACPI: PM-Timer IO Port: 0x1808
[    0.028464] ACPI: LAPIC_NMI (acpi_id[0x01] high edge lint[0x1])
[    0.028465] ACPI: LAPIC_NMI (acpi_id[0x02] high edge lint[0x1])
[    0.028466] ACPI: LAPIC_NMI (acpi_id[0x03] high edge lint[0x1])
[    0.028467] ACPI: LAPIC_NMI (acpi_id[0x04] high edge lint[0x1])
[    0.028468] ACPI: LAPIC_NMI (acpi_id[0x05] high edge lint[0x1])
[    0.028468] ACPI: LAPIC_NMI (acpi_id[0x06] high edge lint[0x1])
[    0.028469] ACPI: LAPIC_NMI (acpi_id[0x07] high edge lint[0x1])
[    0.028470] ACPI: LAPIC_NMI (acpi_id[0x08] high edge lint[0x1])
[    0.028533] IOAPIC[0]: apic_id 2, version 32, address 0xfec00000, GSI 0-119
[    0.028535] ACPI: INT_SRC_OVR (bus 0 bus_irq 0 global_irq 2 dfl dfl)
[    0.028537] ACPI: INT_SRC_OVR (bus 0 bus_irq 9 global_irq 9 high level)
[    0.028541] ACPI: Using ACPI (MADT) for SMP configuration information
[    0.028542] ACPI: HPET id: 0x8086a201 base: 0xfed00000
[    0.028548] e820: update [mem 0x29f24000-0x29f68fff] usable ==> reserved
[    0.028562] TSC deadline timer available
[    0.028562] smpboot: Allowing 8 CPUs, 0 hotplug CPUs
[    0.028576] PM: hibernation: Registered nosave memory: [mem 0x00000000-0x00000fff]
[    0.028577] PM: hibernation: Registered nosave memory: [mem 0x0009f000-0x000fffff]
[    0.028579] PM: hibernation: Registered nosave memory: [mem 0x16b0d000-0x16b0dfff]
[    0.028581] PM: hibernation: Registered nosave memory: [mem 0x16b1b000-0x16b1bfff]
[    0.028581] PM: hibernation: Registered nosave memory: [mem 0x16b1c000-0x16b1cfff]
[    0.028583] PM: hibernation: Registered nosave memory: [mem 0x16b39000-0x16b39fff]
[    0.028584] PM: hibernation: Registered nosave memory: [mem 0x16b3a000-0x16b3afff]
[    0.028585] PM: hibernation: Registered nosave memory: [mem 0x16b59000-0x16b59fff]
[    0.028587] PM: hibernation: Registered nosave memory: [mem 0x23564000-0x23564fff]
[    0.028587] PM: hibernation: Registered nosave memory: [mem 0x23565000-0x23565fff]
[    0.028589] PM: hibernation: Registered nosave memory: [mem 0x2998a000-0x2998afff]
[    0.028590] PM: hibernation: Registered nosave memory: [mem 0x29f24000-0x29f68fff]
[    0.028592] PM: hibernation: Registered nosave memory: [mem 0x2daf6000-0x2efa5fff]
[    0.028593] PM: hibernation: Registered nosave memory: [mem 0x2efa6000-0x2f022fff]
[    0.028593] PM: hibernation: Registered nosave memory: [mem 0x2f023000-0x2f519fff]
[    0.028594] PM: hibernation: Registered nosave memory: [mem 0x2f51a000-0x2fffefff]
[    0.028596] PM: hibernation: Registered nosave memory: [mem 0x30000000-0x38ffffff]
[    0.028596] PM: hibernation: Registered nosave memory: [mem 0x39000000-0xfdffffff]
[    0.028597] PM: hibernation: Registered nosave memory: [mem 0xfe000000-0xfe010fff]
[    0.028598] PM: hibernation: Registered nosave memory: [mem 0xfe011000-0xfebfffff]
[    0.028599] PM: hibernation: Registered nosave memory: [mem 0xfec00000-0xfec00fff]
[    0.028599] PM: hibernation: Registered nosave memory: [mem 0xfec01000-0xfedfffff]
[    0.028600] PM: hibernation: Registered nosave memory: [mem 0xfee00000-0xfee00fff]
[    0.028601] PM: hibernation: Registered nosave memory: [mem 0xfee01000-0xffffffff]
[    0.028602] [mem 0x39000000-0xfdffffff] available for PCI devices
[    0.028604] Booting paravirtualized kernel on bare hardware
[    0.028605] clocksource: refined-jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 1910969940391419 ns
[    0.035003] setup_percpu: NR_CPUS:320 nr_cpumask_bits:8 nr_cpu_ids:8 nr_node_ids:1
[    0.035275] percpu: Embedded 64 pages/cpu s225280 r8192 d28672 u262144
[    0.035281] pcpu-alloc: s225280 r8192 d28672 u262144 alloc=1*2097152
[    0.035284] pcpu-alloc: [0] 0 1 2 3 4 5 6 7
[    0.035301] Kernel command line: BOOT_IMAGE=/@/boot/vmlinuz-linux-zen root=UUID=63f0d3ca-84ab-482c-8b6a-e5009cdeb426 rw rootflags=subvol=@ nowatchdog nvme_load=YES resume=UUID=4d813d8e-ca07-4ab7-a959-6aed44d44e4e nvidia-drm.modeset=1 loglevel=3
[    0.035410] Unknown kernel command line parameters "BOOT_IMAGE=/@/boot/vmlinuz-linux-zen nvme_load=YES", will be passed to user space.
[    0.036469] Dentry cache hash table entries: 2097152 (order: 12, 16777216 bytes, linear)
[    0.036995] Inode-cache hash table entries: 1048576 (order: 11, 8388608 bytes, linear)
[    0.037086] Fallback order for Node 0: 0
[    0.037088] Built 1 zonelists, mobility grouping on.  Total pages: 4074825
[    0.037090] Policy zone: Normal
[    0.037246] mem auto-init: stack:all(zero), heap alloc:on, heap free:off
[    0.037250] software IO TLB: area num 8.
[    0.077610] Memory: 15904004K/16558668K available (20480K kernel code, 2138K rwdata, 12752K rodata, 3628K init, 3440K bss, 654404K reserved, 0K cma-reserved)
[    0.077847] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=8, Nodes=1
[    0.077870] ftrace: allocating 46540 entries in 182 pages
[    0.085174] ftrace: allocated 182 pages with 5 groups
[    0.085237] Dynamic Preempt: full
[    0.085276] rcu: Preemptible hierarchical RCU implementation.
[    0.085276] rcu: 	RCU restricting CPUs from NR_CPUS=320 to nr_cpu_ids=8.
[    0.085277] rcu: 	RCU priority boosting: priority 1 delay 500 ms.
[    0.085278] 	Trampoline variant of Tasks RCU enabled.
[    0.085279] 	Rude variant of Tasks RCU enabled.
[    0.085279] 	Tracing variant of Tasks RCU enabled.
[    0.085280] rcu: RCU calculated value of scheduler-enlistment delay is 100 jiffies.
[    0.085281] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=8
[    0.088048] NR_IRQS: 20736, nr_irqs: 2048, preallocated irqs: 16
[    0.088330] rcu: srcu_init: Setting srcu_struct sizes based on contention.
[    0.088723] kfence: initialized - using 2097152 bytes for 255 objects at 0x(____ptrval____)-0x(____ptrval____)
[    0.088754] Console: colour dummy device 80x25
[    0.088756] printk: legacy console [tty0] enabled
[    0.088805] ACPI: Core revision 20230628
[    0.089324] clocksource: hpet: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 79635855245 ns
[    0.089468] APIC: Switch to symmetric I/O mode setup
[    0.089470] DMAR: Host address width 39
[    0.089471] DMAR: DRHD base: 0x000000fed91000 flags: 0x1
[    0.089477] DMAR: dmar0: reg_base_addr fed91000 ver 1:0 cap d2008c40660462 ecap f050da
[    0.089479] DMAR: RMRR base: 0x0000002f986000 end: 0x0000002fbcffff
[    0.089482] DMAR-IR: IOAPIC id 2 under DRHD base  0xfed91000 IOMMU 0
[    0.089483] DMAR-IR: HPET id 0 under DRHD base 0xfed91000
[    0.089485] DMAR-IR: Queued invalidation will be enabled to support x2apic and Intr-remapping.
[    0.092826] DMAR-IR: Enabled IRQ remapping in x2apic mode
[    0.092827] x2apic enabled
[    0.092898] APIC: Switched APIC routing to: cluster x2apic
[    0.102272] ..TIMER: vector=0x30 apic1=0 pin1=2 apic2=-1 pin2=-1
[    0.106418] clocksource: tsc-early: mask: 0xffffffffffffffff max_cycles: 0x2b3e459bf4c, max_idle_ns: 440795289890 ns
[    0.106422] Calibrating delay loop (skipped), value calculated using timer frequency.. 6000.00 BogoMIPS (lpj=3000000)
[    0.106444] CPU0: Thermal monitoring enabled (TM1)
[    0.106489] process: using mwait in idle threads
[    0.106491] Last level iTLB entries: 4KB 128, 2MB 8, 4MB 8
[    0.106492] Last level dTLB entries: 4KB 64, 2MB 0, 4MB 0, 1GB 4
[    0.106495] Spectre V1 : Mitigation: usercopy/swapgs barriers and __user pointer sanitization
[    0.106497] Spectre V2 : Mitigation: Enhanced / Automatic IBRS
[    0.106498] Spectre V2 : Spectre v2 / SpectreRSB mitigation: Filling RSB on context switch
[    0.106499] Spectre V2 : Spectre v2 / PBRSB-eIBRS: Retire a single CALL on VMEXIT
[    0.106499] RETBleed: Mitigation: Enhanced IBRS
[    0.106500] Spectre V2 : mitigation: Enabling conditional Indirect Branch Prediction Barrier
[    0.106502] Speculative Store Bypass: Mitigation: Speculative Store Bypass disabled via prctl
[    0.106506] TAA: Mitigation: TSX disabled
[    0.106507] MMIO Stale Data: Mitigation: Clear CPU buffers
[    0.106508] SRBDS: Mitigation: Microcode
[    0.106510] GDS: Mitigation: Microcode (locked)
[    0.106514] x86/fpu: Supporting XSAVE feature 0x001: 'x87 floating point registers'
[    0.106515] x86/fpu: Supporting XSAVE feature 0x002: 'SSE registers'
[    0.106516] x86/fpu: Supporting XSAVE feature 0x004: 'AVX registers'
[    0.106516] x86/fpu: Supporting XSAVE feature 0x008: 'MPX bounds registers'
[    0.106517] x86/fpu: Supporting XSAVE feature 0x010: 'MPX CSR'
[    0.106518] x86/fpu: xstate_offset[2]:  576, xstate_sizes[2]:  256
[    0.106519] x86/fpu: xstate_offset[3]:  832, xstate_sizes[3]:   64
[    0.106520] x86/fpu: xstate_offset[4]:  896, xstate_sizes[4]:   64
[    0.106521] x86/fpu: Enabled xstate features 0x1f, context size is 960 bytes, using 'compacted' format.
[    0.129104] Freeing SMP alternatives memory: 48K
[    0.129107] pid_max: default: 32768 minimum: 301
[    0.132472] LSM: initializing lsm=capability,landlock,lockdown,yama,bpf,integrity
[    0.132495] landlock: Up and running.
[    0.132496] Yama: becoming mindful.
[    0.132500] LSM support for eBPF active
[    0.132530] Mount-cache hash table entries: 32768 (order: 6, 262144 bytes, linear)
[    0.132545] Mountpoint-cache hash table entries: 32768 (order: 6, 262144 bytes, linear)
[    0.132990] smpboot: CPU0: Intel(R) Core(TM) i7-9700F CPU @ 3.00GHz (family: 0x6, model: 0x9e, stepping: 0xd)
[    0.133117] RCU Tasks: Setting shift to 3 and lim to 1 rcu_task_cb_adjust=1.
[    0.133127] RCU Tasks Rude: Setting shift to 3 and lim to 1 rcu_task_cb_adjust=1.
[    0.133140] RCU Tasks Trace: Setting shift to 3 and lim to 1 rcu_task_cb_adjust=1.
[    0.133151] Performance Events: PEBS fmt3+, Skylake events, 32-deep LBR, full-width counters, Intel PMU driver.
[    0.133172] ... version:                4
[    0.133173] ... bit width:              48
[    0.133173] ... generic registers:      8
[    0.133174] ... value mask:             0000ffffffffffff
[    0.133175] ... max period:             00007fffffffffff
[    0.133176] ... fixed-purpose events:   3
[    0.133176] ... event mask:             00000007000000ff
[    0.133261] signal: max sigframe size: 2032
[    0.133274] Estimated ratio of average max frequency by base frequency (times 1024): 1570
[    0.133724] rcu: Hierarchical SRCU implementation.
[    0.133725] rcu: 	Max phase no-delay instances is 400.
[    0.134149] smp: Bringing up secondary CPUs ...
[    0.134217] smpboot: x86: Booting SMP configuration:
[    0.134218] .... node  #0, CPUs:      #1 #2 #3 #4 #5 #6 #7
[    0.135449] smp: Brought up 1 node, 8 CPUs
[    0.135449] smpboot: Max logical packages: 1
[    0.135449] smpboot: Total of 8 processors activated (48000.00 BogoMIPS)
[    0.136799] devtmpfs: initialized
[    0.136799] x86/mm: Memory block size: 128MB
[    0.137954] ACPI: PM: Registering ACPI NVS region [mem 0x23564000-0x23564fff] (4096 bytes)
[    0.137954] ACPI: PM: Registering ACPI NVS region [mem 0x2f023000-0x2f519fff] (5206016 bytes)
[    0.137954] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 1911260446275000 ns
[    0.137954] futex hash table entries: 2048 (order: 5, 131072 bytes, linear)
[    0.137954] pinctrl core: initialized pinctrl subsystem
[    0.138422] PM: RTC time: 16:46:32, date: 2024-03-27
[    0.138816] NET: Registered PF_NETLINK/PF_ROUTE protocol family
[    0.139044] DMA: preallocated 2048 KiB GFP_KERNEL pool for atomic allocations
[    0.139148] DMA: preallocated 2048 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
[    0.139251] DMA: preallocated 2048 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
[    0.139256] audit: initializing netlink subsys (disabled)
[    0.139303] audit: type=2000 audit(1711557992.041:1): state=initialized audit_enabled=0 res=1
[    0.139303] thermal_sys: Registered thermal governor 'fair_share'
[    0.139303] thermal_sys: Registered thermal governor 'bang_bang'
[    0.139303] thermal_sys: Registered thermal governor 'step_wise'
[    0.139303] thermal_sys: Registered thermal governor 'user_space'
[    0.139303] thermal_sys: Registered thermal governor 'power_allocator'
[    0.139303] cpuidle: using governor ladder
[    0.139303] cpuidle: using governor menu
[    0.139445] ACPI FADT declares the system doesn't support PCIe ASPM, so disable it
[    0.139447] acpiphp: ACPI Hot Plug PCI Controller Driver version: 0.5
[    0.139539] PCI: ECAM [mem 0xe0000000-0xefffffff] (base 0xe0000000) for domain 0000 [bus 00-ff]
[    0.139543] PCI: not using ECAM ([mem 0xe0000000-0xefffffff] not reserved)
[    0.139544] PCI: Using configuration type 1 for base access
[    0.139651] kprobes: kprobe jump-optimization is enabled. All kprobes are optimized if possible.
[    0.141479] HugeTLB: registered 1.00 GiB page size, pre-allocated 0 pages
[    0.141479] HugeTLB: 16380 KiB vmemmap can be freed for a 1.00 GiB page
[    0.141479] HugeTLB: registered 2.00 MiB page size, pre-allocated 0 pages
[    0.141479] HugeTLB: 28 KiB vmemmap can be freed for a 2.00 MiB page
[    0.141608] ACPI: Added _OSI(Module Device)
[    0.141608] ACPI: Added _OSI(Processor Device)
[    0.141608] ACPI: Added _OSI(3.0 _SCP Extensions)
[    0.141608] ACPI: Added _OSI(Processor Aggregator Device)
[    0.209466] ACPI: 10 ACPI AML tables successfully acquired and loaded
[    0.770800] ACPI: Dynamic OEM Table Load:
[    0.770806] ACPI: SSDT 0xFFFF9EF4C13C0800 000400 (v02 PmRef  Cpu0Cst  00003001 INTL 20160527)
[    0.771985] ACPI: Dynamic OEM Table Load:
[    0.771990] ACPI: SSDT 0xFFFF9EF4C13D2000 0006C6 (v02 PmRef  Cpu0Ist  00003000 INTL 20160527)
[    0.773323] ACPI: Dynamic OEM Table Load:
[    0.773328] ACPI: SSDT 0xFFFF9EF4C13CB000 000EF1 (v02 PmRef  ApIst    00003000 INTL 20160527)
[    0.774952] ACPI: Dynamic OEM Table Load:
[    0.774957] ACPI: SSDT 0xFFFF9EF4C13C5400 00030A (v02 PmRef  ApCst    00003000 INTL 20160527)
[    0.778362] ACPI: _OSC evaluated successfully for all CPUs
[    0.779373] ACPI: Interpreter enabled
[    0.779411] ACPI: PM: (supports S0 S3 S4 S5)
[    0.779412] ACPI: Using IOAPIC for interrupt routing
[    0.780591] PCI: ECAM [mem 0xe0000000-0xefffffff] (base 0xe0000000) for domain 0000 [bus 00-ff]
[    0.781985] PCI: ECAM [mem 0xe0000000-0xefffffff] reserved as ACPI motherboard resource
[    0.781995] PCI: Using host bridge windows from ACPI; if necessary, use "pci=nocrs" and report a bug
[    0.781996] PCI: Using E820 reservations for host bridge windows
[    0.783117] ACPI: Enabled 7 GPEs in block 00 to 7F
[    0.798187] ACPI: \_SB_.PCI0.XDCI.USBC: New power resource
[    0.800762] ACPI: \_SB_.PCI0.SAT0.VOL0.V0PR: New power resource
[    0.800970] ACPI: \_SB_.PCI0.SAT0.VOL1.V1PR: New power resource
[    0.801169] ACPI: \_SB_.PCI0.SAT0.VOL2.V2PR: New power resource
[    0.814385] ACPI: \_SB_.PCI0.CNVW.WRST: New power resource
[    0.818808] ACPI: \_TZ_.FN00: New power resource
[    0.818877] ACPI: \_TZ_.FN01: New power resource
[    0.818942] ACPI: \_TZ_.FN02: New power resource
[    0.819005] ACPI: \_TZ_.FN03: New power resource
[    0.819069] ACPI: \_TZ_.FN04: New power resource
[    0.819537] ACPI: \PIN_: New power resource
[    0.820029] ACPI: PCI Root Bridge [PCI0] (domain 0000 [bus 00-fe])
[    0.820035] acpi PNP0A08:00: _OSC: OS supports [ExtendedConfig ASPM ClockPM Segments MSI EDR HPX-Type3]
[    0.820133] acpi PNP0A08:00: _OSC: platform does not support [PCIeHotplug SHPCHotplug PME]
[    0.820307] acpi PNP0A08:00: _OSC: OS now controls [AER PCIeCapability LTR DPC]
[    0.820308] acpi PNP0A08:00: FADT indicates ASPM is unsupported, using BIOS configuration
[    0.821327] PCI host bridge to bus 0000:00
[    0.821329] pci_bus 0000:00: root bus resource [io  0x0000-0x0cf7 window]
[    0.821331] pci_bus 0000:00: root bus resource [io  0x0d00-0xffff window]
[    0.821333] pci_bus 0000:00: root bus resource [mem 0x000a0000-0x000effff window]
[    0.821334] pci_bus 0000:00: root bus resource [mem 0x39000000-0xdfffffff window]
[    0.821336] pci_bus 0000:00: root bus resource [mem 0xfc800000-0xfe7fffff window]
[    0.821337] pci_bus 0000:00: root bus resource [bus 00-fe]
[    0.821423] pci 0000:00:00.0: [8086:3e30] type 00 class 0x060000 conventional PCI endpoint
[    0.821489] pci 0000:00:01.0: [8086:1901] type 01 class 0x060400 PCIe Root Port
[    0.821501] pci 0000:00:01.0: PCI bridge to [bus 01]
[    0.821504] pci 0000:00:01.0:   bridge window [io  0x4000-0x4fff]
[    0.821506] pci 0000:00:01.0:   bridge window [mem 0x39000000-0x3a0fffff]
[    0.821511] pci 0000:00:01.0:   bridge window [mem 0x40000000-0x520fffff 64bit pref]
[    0.821536] pci 0000:00:01.0: PME# supported from D0 D3hot D3cold
[    0.822270] pci 0000:00:12.0: [8086:a379] type 00 class 0x118000 conventional PCI endpoint
[    0.822307] pci 0000:00:12.0: BAR 0 [mem 0x3a31d000-0x3a31dfff 64bit]
[    0.822593] pci 0000:00:14.0: [8086:a36d] type 00 class 0x0c0330 conventional PCI endpoint
[    0.822629] pci 0000:00:14.0: BAR 0 [mem 0x3a300000-0x3a30ffff 64bit]
[    0.822769] pci 0000:00:14.0: PME# supported from D3hot D3cold
[    0.823391] pci 0000:00:14.2: [8086:a36f] type 00 class 0x050000 conventional PCI endpoint
[    0.823420] pci 0000:00:14.2: BAR 0 [mem 0x3a316000-0x3a317fff 64bit]
[    0.823440] pci 0000:00:14.2: BAR 2 [mem 0x3a31c000-0x3a31cfff 64bit]
[    0.823629] pci 0000:00:16.0: [8086:a360] type 00 class 0x078000 conventional PCI endpoint
[    0.823660] pci 0000:00:16.0: BAR 0 [mem 0x3a31b000-0x3a31bfff 64bit]
[    0.823777] pci 0000:00:16.0: PME# supported from D3hot
[    0.824348] pci 0000:00:17.0: [8086:2822] type 00 class 0x010400 conventional PCI endpoint
[    0.824376] pci 0000:00:17.0: BAR 0 [mem 0x3a314000-0x3a315fff]
[    0.824391] pci 0000:00:17.0: BAR 1 [mem 0x3a31a000-0x3a31a0ff]
[    0.824406] pci 0000:00:17.0: BAR 2 [io  0x5050-0x5057]
[    0.824420] pci 0000:00:17.0: BAR 3 [io  0x5040-0x5043]
[    0.824436] pci 0000:00:17.0: BAR 4 [io  0x5020-0x503f]
[    0.824451] pci 0000:00:17.0: BAR 5 [mem 0x3a319000-0x3a3197ff]
[    0.824533] pci 0000:00:17.0: PME# supported from D3hot
[    0.825165] pci 0000:00:1b.0: [8086:a340] type 01 class 0x060400 PCIe Root Port
[    0.825220] pci 0000:00:1b.0: PCI bridge to [bus 02]
[    0.825371] pci 0000:00:1b.0: PME# supported from D0 D3hot D3cold
[    0.826199] pci 0000:00:1c.0: [8086:a338] type 01 class 0x060400 PCIe Root Port
[    0.826255] pci 0000:00:1c.0: PCI bridge to [bus 03]
[    0.826392] pci 0000:00:1c.0: PME# supported from D0 D3hot D3cold
[    0.827145] pci 0000:00:1c.2: [8086:a33a] type 01 class 0x060400 PCIe Root Port
[    0.827203] pci 0000:00:1c.2: PCI bridge to [bus 04]
[    0.827210] pci 0000:00:1c.2:   bridge window [io  0x3000-0x3fff]
[    0.827215] pci 0000:00:1c.2:   bridge window [mem 0x3a200000-0x3a2fffff]
[    0.827359] pci 0000:00:1c.2: PME# supported from D0 D3hot D3cold
[    0.827403] pci 0000:00:1c.2: PTM enabled (root), 4ns granularity
[    0.828223] pci 0000:00:1d.0: [8086:a330] type 01 class 0x060400 PCIe Root Port
[    0.828278] pci 0000:00:1d.0: PCI bridge to [bus 05]
[    0.828428] pci 0000:00:1d.0: PME# supported from D0 D3hot D3cold
[    0.829232] pci 0000:00:1f.0: [8086:a305] type 00 class 0x060100 conventional PCI endpoint
[    0.829756] pci 0000:00:1f.3: [8086:a348] type 00 class 0x040300 conventional PCI endpoint
[    0.829815] pci 0000:00:1f.3: BAR 0 [mem 0x3a310000-0x3a313fff 64bit]
[    0.829889] pci 0000:00:1f.3: BAR 4 [mem 0x3a100000-0x3a1fffff 64bit]
[    0.830039] pci 0000:00:1f.3: PME# supported from D3hot D3cold
[    0.831263] pci 0000:00:1f.4: [8086:a323] type 00 class 0x0c0500 conventional PCI endpoint
[    0.831430] pci 0000:00:1f.4: BAR 0 [mem 0x3a318000-0x3a3180ff 64bit]
[    0.831638] pci 0000:00:1f.4: BAR 4 [io  0xefa0-0xefbf]
[    0.832084] pci 0000:00:1f.5: [8086:a324] type 00 class 0x0c8000 conventional PCI endpoint
[    0.832110] pci 0000:00:1f.5: BAR 0 [mem 0xfe010000-0xfe010fff]
[    0.832279] pci 0000:01:00.0: [10de:1f06] type 00 class 0x030000 PCIe Legacy Endpoint
[    0.832290] pci 0000:01:00.0: BAR 0 [mem 0x39000000-0x39ffffff]
[    0.832299] pci 0000:01:00.0: BAR 1 [mem 0x40000000-0x4fffffff 64bit pref]
[    0.832308] pci 0000:01:00.0: BAR 3 [mem 0x50000000-0x51ffffff 64bit pref]
[    0.832314] pci 0000:01:00.0: BAR 5 [io  0x4000-0x407f]
[    0.832319] pci 0000:01:00.0: ROM [mem 0x3a000000-0x3a07ffff pref]
[    0.832336] pci 0000:01:00.0: BAR 1: assigned to efifb
[    0.832340] pci 0000:01:00.0: Video device with shadowed ROM at [mem 0x000c0000-0x000dffff]
[    0.832374] pci 0000:01:00.0: PME# supported from D0 D3hot D3cold
[    0.832428] pci 0000:01:00.0: 32.000 Gb/s available PCIe bandwidth, limited by 2.5 GT/s PCIe x16 link at 0000:00:01.0 (capable of 126.016 Gb/s with 8.0 GT/s PCIe x16 link)
[    0.832522] pci 0000:01:00.1: [10de:10f9] type 00 class 0x040300 PCIe Endpoint
[    0.832531] pci 0000:01:00.1: BAR 0 [mem 0x3a080000-0x3a083fff]
[    0.832638] pci 0000:01:00.2: [10de:1ada] type 00 class 0x0c0330 PCIe Endpoint
[    0.832651] pci 0000:01:00.2: BAR 0 [mem 0x52000000-0x5203ffff 64bit pref]
[    0.832665] pci 0000:01:00.2: BAR 3 [mem 0x52040000-0x5204ffff 64bit pref]
[    0.832712] pci 0000:01:00.2: PME# supported from D0 D3hot D3cold
[    0.832761] pci 0000:01:00.3: [10de:1adb] type 00 class 0x0c8000 PCIe Endpoint
[    0.832770] pci 0000:01:00.3: BAR 0 [mem 0x3a084000-0x3a084fff]
[    0.832828] pci 0000:01:00.3: PME# supported from D0 D3hot D3cold
[    0.832891] pci 0000:00:01.0: PCI bridge to [bus 01]
[    0.833026] acpiphp: Slot [1] registered
[    0.833038] pci 0000:00:1b.0: PCI bridge to [bus 02]
[    0.833172] acpiphp: Slot [1-1] registered
[    0.833181] pci 0000:00:1c.0: PCI bridge to [bus 03]
[    0.833347] pci 0000:04:00.0: [10ec:8168] type 00 class 0x020000 PCIe Endpoint
[    0.833375] pci 0000:04:00.0: BAR 0 [io  0x3000-0x30ff]
[    0.833412] pci 0000:04:00.0: BAR 2 [mem 0x3a204000-0x3a204fff 64bit]
[    0.833433] pci 0000:04:00.0: BAR 4 [mem 0x3a200000-0x3a203fff 64bit]
[    0.833584] pci 0000:04:00.0: supports D1 D2
[    0.833585] pci 0000:04:00.0: PME# supported from D0 D1 D2 D3hot D3cold
[    0.833841] pci 0000:00:1c.2: PCI bridge to [bus 04]
[    0.833983] acpiphp: Slot [1-2] registered
[    0.834017] pci 0000:00:1d.0: PCI bridge to [bus 05]
[    0.835679] ACPI: PCI: Interrupt link LNKA configured for IRQ 0
[    0.835712] ACPI: PCI: Interrupt link LNKB configured for IRQ 1
[    0.835743] ACPI: PCI: Interrupt link LNKC configured for IRQ 0
[    0.835774] ACPI: PCI: Interrupt link LNKD configured for IRQ 0
[    0.835805] ACPI: PCI: Interrupt link LNKE configured for IRQ 0
[    0.835837] ACPI: PCI: Interrupt link LNKF configured for IRQ 0
[    0.835868] ACPI: PCI: Interrupt link LNKG configured for IRQ 0
[    0.835899] ACPI: PCI: Interrupt link LNKH configured for IRQ 0
[    0.839871] iommu: Default domain type: Translated
[    0.839871] iommu: DMA domain TLB invalidation policy: lazy mode
[    0.839871] SCSI subsystem initialized
[    0.839871] libata version 3.00 loaded.
[    0.839871] ACPI: bus type USB registered
[    0.839871] usbcore: registered new interface driver usbfs
[    0.839871] usbcore: registered new interface driver hub
[    0.839871] usbcore: registered new device driver usb
[    0.839871] EDAC MC: Ver: 3.0.0
[    0.840632] efivars: Registered efivars operations
[    0.840635] NetLabel: Initializing
[    0.840635] NetLabel:  domain hash size = 128
[    0.840635] NetLabel:  protocols = UNLABELED CIPSOv4 CALIPSO
[    0.840635] NetLabel:  unlabeled traffic allowed by default
[    0.840635] mctp: management component transport protocol core
[    0.840635] NET: Registered PF_MCTP protocol family
[    0.840635] PCI: Using ACPI for IRQ routing
[    0.926412] PCI: pci_cache_line_size set to 64 bytes
[    0.926513] e820: reserve RAM buffer [mem 0x0009f000-0x0009ffff]
[    0.926521] e820: reserve RAM buffer [mem 0x16b0d018-0x17ffffff]
[    0.926523] e820: reserve RAM buffer [mem 0x16b1c018-0x17ffffff]
[    0.926523] e820: reserve RAM buffer [mem 0x16b3a018-0x17ffffff]
[    0.926524] e820: reserve RAM buffer [mem 0x23564000-0x23ffffff]
[    0.926525] e820: reserve RAM buffer [mem 0x2998a000-0x2bffffff]
[    0.926526] e820: reserve RAM buffer [mem 0x29f24000-0x2bffffff]
[    0.926526] e820: reserve RAM buffer [mem 0x2daf6000-0x2fffffff]
[    0.926527] e820: reserve RAM buffer [mem 0x4c5000000-0x4c7ffffff]
[    0.926551] pci 0000:01:00.0: vgaarb: setting as boot VGA device
[    0.926551] pci 0000:01:00.0: vgaarb: bridge control possible
[    0.926551] pci 0000:01:00.0: vgaarb: VGA device added: decodes=io+mem,owns=io+mem,locks=none
[    0.926551] vgaarb: loaded
[    0.926551] hpet0: at MMIO 0xfed00000, IRQs 2, 8, 0, 0, 0, 0, 0, 0
[    0.926551] hpet0: 8 comparators, 64-bit 24.000000 MHz counter
[    0.928451] clocksource: Switched to clocksource tsc-early
[    0.928802] VFS: Disk quotas dquot_6.6.0
[    0.928810] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[    0.928853] pnp: PnP ACPI init
[    0.929078] system 00:00: [io  0x0a00-0x0a2f] has been reserved
[    0.929081] system 00:00: [io  0x0a30-0x0a3f] has been reserved
[    0.929082] system 00:00: [io  0x0a40-0x0a4f] has been reserved
[    0.929714] pnp 00:01: [dma 0 disabled]
[    0.929840] system 00:02: [io  0x0680-0x069f] has been reserved
[    0.929842] system 00:02: [io  0x164e-0x164f] has been reserved
[    0.929936] system 00:04: [io  0x1854-0x1857] has been reserved
[    0.930082] system 00:05: [mem 0xfed10000-0xfed17fff] has been reserved
[    0.930084] system 00:05: [mem 0xfed18000-0xfed18fff] has been reserved
[    0.930085] system 00:05: [mem 0xfed19000-0xfed19fff] has been reserved
[    0.930086] system 00:05: [mem 0xe0000000-0xefffffff] has been reserved
[    0.930088] system 00:05: [mem 0xfed20000-0xfed3ffff] has been reserved
[    0.930089] system 00:05: [mem 0xfed90000-0xfed93fff] could not be reserved
[    0.930090] system 00:05: [mem 0xfed45000-0xfed8ffff] has been reserved
[    0.930091] system 00:05: [mem 0xfee00000-0xfeefffff] could not be reserved
[    0.930291] system 00:06: [io  0x1800-0x18fe] could not be reserved
[    0.930293] system 00:06: [mem 0xfd000000-0xfd69ffff] has been reserved
[    0.930295] system 00:06: [mem 0xfd6c0000-0xfd6cffff] has been reserved
[    0.930296] system 00:06: [mem 0xfd6f0000-0xfdffffff] has been reserved
[    0.930297] system 00:06: [mem 0xfe000000-0xfe01ffff] could not be reserved
[    0.930299] system 00:06: [mem 0xfe200000-0xfe7fffff] has been reserved
[    0.930300] system 00:06: [mem 0xff000000-0xffffffff] has been reserved
[    0.930566] system 00:07: [io  0x2000-0x20fe] has been reserved
[    0.932132] pnp: PnP ACPI: found 9 devices
[    0.937446] clocksource: acpi_pm: mask: 0xffffff max_cycles: 0xffffff, max_idle_ns: 2085701024 ns
[    0.937540] NET: Registered PF_INET protocol family
[    0.937646] IP idents hash table entries: 262144 (order: 9, 2097152 bytes, linear)
[    0.950394] tcp_listen_portaddr_hash hash table entries: 8192 (order: 5, 131072 bytes, linear)
[    0.950411] Table-perturb hash table entries: 65536 (order: 6, 262144 bytes, linear)
[    0.950464] TCP established hash table entries: 131072 (order: 8, 1048576 bytes, linear)
[    0.950669] TCP bind hash table entries: 65536 (order: 9, 2097152 bytes, linear)
[    0.950877] TCP: Hash tables configured (established 131072 bind 65536)
[    0.950924] MPTCP token hash table entries: 16384 (order: 6, 393216 bytes, linear)
[    0.950963] UDP hash table entries: 8192 (order: 6, 262144 bytes, linear)
[    0.950996] UDP-Lite hash table entries: 8192 (order: 6, 262144 bytes, linear)
[    0.951036] NET: Registered PF_UNIX/PF_LOCAL protocol family
[    0.951042] NET: Registered PF_XDP protocol family
[    0.951048] pci 0000:00:1d.0: bridge window [io  0x1000-0x0fff] to [bus 05] add_size 1000
[    0.951050] pci 0000:00:1d.0: bridge window [mem 0x00100000-0x000fffff 64bit pref] to [bus 05] add_size 200000 add_align 100000
[    0.951052] pci 0000:00:1d.0: bridge window [mem 0x00100000-0x000fffff] to [bus 05] add_size 200000 add_align 100000
[    0.951059] pci 0000:00:1d.0: bridge window [mem 0x3a400000-0x3a5fffff]: assigned
[    0.951062] pci 0000:00:1d.0: bridge window [mem 0x3a600000-0x3a7fffff 64bit pref]: assigned
[    0.951064] pci 0000:00:1d.0: bridge window [io  0x6000-0x6fff]: assigned
[    0.951067] pci 0000:00:01.0: PCI bridge to [bus 01]
[    0.951069] pci 0000:00:01.0:   bridge window [io  0x4000-0x4fff]
[    0.951071] pci 0000:00:01.0:   bridge window [mem 0x39000000-0x3a0fffff]
[    0.951073] pci 0000:00:01.0:   bridge window [mem 0x40000000-0x520fffff 64bit pref]
[    0.951076] pci 0000:00:1b.0: PCI bridge to [bus 02]
[    0.951100] pci 0000:00:1c.0: PCI bridge to [bus 03]
[    0.951119] pci 0000:00:1c.2: PCI bridge to [bus 04]
[    0.951122] pci 0000:00:1c.2:   bridge window [io  0x3000-0x3fff]
[    0.951129] pci 0000:00:1c.2:   bridge window [mem 0x3a200000-0x3a2fffff]
[    0.951142] pci 0000:00:1d.0: PCI bridge to [bus 05]
[    0.951146] pci 0000:00:1d.0:   bridge window [io  0x6000-0x6fff]
[    0.951153] pci 0000:00:1d.0:   bridge window [mem 0x3a400000-0x3a5fffff]
[    0.951157] pci 0000:00:1d.0:   bridge window [mem 0x3a600000-0x3a7fffff 64bit pref]
[    0.951166] pci_bus 0000:00: resource 4 [io  0x0000-0x0cf7 window]
[    0.951168] pci_bus 0000:00: resource 5 [io  0x0d00-0xffff window]
[    0.951169] pci_bus 0000:00: resource 6 [mem 0x000a0000-0x000effff window]
[    0.951170] pci_bus 0000:00: resource 7 [mem 0x39000000-0xdfffffff window]
[    0.951171] pci_bus 0000:00: resource 8 [mem 0xfc800000-0xfe7fffff window]
[    0.951172] pci_bus 0000:01: resource 0 [io  0x4000-0x4fff]
[    0.951173] pci_bus 0000:01: resource 1 [mem 0x39000000-0x3a0fffff]
[    0.951174] pci_bus 0000:01: resource 2 [mem 0x40000000-0x520fffff 64bit pref]
[    0.951176] pci_bus 0000:04: resource 0 [io  0x3000-0x3fff]
[    0.951177] pci_bus 0000:04: resource 1 [mem 0x3a200000-0x3a2fffff]
[    0.951178] pci_bus 0000:05: resource 0 [io  0x6000-0x6fff]
[    0.951179] pci_bus 0000:05: resource 1 [mem 0x3a400000-0x3a5fffff]
[    0.951180] pci_bus 0000:05: resource 2 [mem 0x3a600000-0x3a7fffff 64bit pref]
[    0.951590] pci 0000:01:00.1: extending delay after power-on from D3hot to 20 msec
[    0.951610] pci 0000:01:00.1: D0 power state depends on 0000:01:00.0
[    0.951655] pci 0000:01:00.2: D0 power state depends on 0000:01:00.0
[    0.951879] pci 0000:01:00.3: D0 power state depends on 0000:01:00.0
[    0.951914] PCI: CLS 64 bytes, default 64
[    0.951924] PCI-DMA: Using software bounce buffering for IO (SWIOTLB)
[    0.951924] software IO TLB: mapped [mem 0x0000000012b0d000-0x0000000016b0d000] (64MB)
[    0.951946] Trying to unpack rootfs image as initramfs...
[    0.951987] sgx: EPC section 0x30200000-0x35f7ffff
[    0.956122] Initialise system trusted keyrings
[    0.956128] Key type blacklist registered
[    0.956148] workingset: timestamp_bits=41 max_order=22 bucket_order=0
[    0.956153] zbud: loaded
[    0.956250] integrity: Platform Keyring initialized
[    0.956253] integrity: Machine keyring initialized
[    0.967588] Key type asymmetric registered
[    0.967590] Asymmetric key parser 'x509' registered
[    0.967603] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 246)
[    0.967653] io scheduler mq-deadline registered
[    0.967654] io scheduler kyber registered
[    0.967663] io scheduler bfq registered
[    0.968417] pcieport 0000:00:1c.2: AER: enabled with IRQ 124
[    0.968455] pcieport 0000:00:1c.2: DPC: enabled with IRQ 124
[    0.968456] pcieport 0000:00:1c.2: DPC: error containment capabilities: Int Msg #0, RPExt+ PoisonedTLP+ SwTrigger+ RP PIO Log 4, DL_ActiveErr+
[    0.968719] shpchp: Standard Hot Plug PCI Controller Driver version: 0.4
[    0.969438] input: Sleep Button as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0E:00/input/input0
[    0.969458] ACPI: button: Sleep Button [SLPB]
[    0.969480] input: Power Button as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0C:00/input/input1
[    0.969493] ACPI: button: Power Button [PWRB]
[    0.969514] input: Power Button as /devices/LNXSYSTM:00/LNXPWRBN:00/input/input2
[    0.969827] ACPI: button: Power Button [PWRF]
[    1.149742] Freeing initrd memory: 107452K
[    1.984953] tsc: Refined TSC clocksource calibration: 2999.999 MHz
[    1.984956] clocksource: tsc: mask: 0xffffffffffffffff max_cycles: 0x2b3e44b2357, max_idle_ns: 440795324996 ns
[    1.985008] clocksource: Switched to clocksource tsc
[    3.011052] ACPI: \_TZ_.TZ10: _PSL evaluation failure
[    3.011229] thermal LNXTHERM:00: registered as thermal_zone0
[    3.011230] ACPI: thermal: Thermal Zone [TZ10] (17 C)
[    3.011407] thermal LNXTHERM:01: registered as thermal_zone1
[    3.011408] ACPI: thermal: Thermal Zone [TZ00] (28 C)
[    3.011578] Serial: 8250/16550 driver, 32 ports, IRQ sharing enabled
[    3.012429] 00:01: ttyS0 at I/O 0x3f8 (irq = 4, base_baud = 115200) is a 16550A
[    3.014545] Non-volatile memory driver v1.3
[    3.014546] Linux agpgart interface v0.103
[    3.014994] ahci 0000:00:17.0: version 3.0
[    3.015076] ahci 0000:00:17.0: controller can't do SNTF, turning off CAP_SNTF
[    3.015196] ahci 0000:00:17.0: AHCI 0001.0301 32 slots 6 ports 6 Gbps 0x3f impl RAID mode
[    3.015198] ahci 0000:00:17.0: flags: 64bit ncq clo only pio slum part ems deso sadm sds apst
[    3.030287] scsi host0: ahci
[    3.030527] scsi host1: ahci
[    3.030771] scsi host2: ahci
[    3.030952] scsi host3: ahci
[    3.031108] scsi host4: ahci
[    3.031322] scsi host5: ahci
[    3.031348] ata1: SATA max UDMA/133 abar m2048@0x3a319000 port 0x3a319100 irq 126 lpm-pol 0
[    3.031351] ata2: SATA max UDMA/133 abar m2048@0x3a319000 port 0x3a319180 irq 126 lpm-pol 0
[    3.031353] ata3: SATA max UDMA/133 abar m2048@0x3a319000 port 0x3a319200 irq 126 lpm-pol 0
[    3.031355] ata4: SATA max UDMA/133 abar m2048@0x3a319000 port 0x3a319280 irq 126 lpm-pol 0
[    3.031357] ata5: SATA max UDMA/133 abar m2048@0x3a319000 port 0x3a319300 irq 126 lpm-pol 0
[    3.031360] ata6: SATA max UDMA/133 abar m2048@0x3a319000 port 0x3a319380 irq 126 lpm-pol 0
[    3.031526] ACPI: bus type drm_connector registered
[    3.032446] usbcore: registered new interface driver usbserial_generic
[    3.032449] usbserial: USB Serial support registered for generic
[    3.032529] rtc_cmos 00:03: RTC can wake from S4
[    3.034179] rtc_cmos 00:03: registered as rtc0
[    3.034504] rtc_cmos 00:03: setting system clock to 2024-03-27T16:46:35 UTC (1711557995)
[    3.034535] rtc_cmos 00:03: alarms up to one month, y3k, 242 bytes nvram
[    3.034762] intel_pstate: Intel P-state driver initializing
[    3.035175] intel_pstate: Disabling energy efficiency optimization
[    3.035176] intel_pstate: HWP enabled
[    3.035349] ledtrig-cpu: registered to indicate activity on CPUs
[    3.035511] efifb: probing for efifb
[    3.035517] efifb: framebuffer at 0x40000000, using 3072k, total 3072k
[    3.035518] efifb: mode is 1024x768x32, linelength=4096, pages=1
[    3.035519] efifb: scrolling: redraw
[    3.035520] efifb: Truecolor: size=8:8:8:8, shift=24:16:8:0
[    3.035564] fbcon: Deferring console take-over
[    3.035564] fb0: EFI VGA frame buffer device
[    3.035578] hid: raw HID events driver (C) Jiri Kosina
[    3.035618] drop_monitor: Initializing network drop monitor service
[    3.035672] NET: Registered PF_INET6 protocol family
[    3.039372] Segment Routing with IPv6
[    3.039373] RPL Segment Routing with IPv6
[    3.039378] In-situ OAM (IOAM) with IPv6
[    3.039391] NET: Registered PF_PACKET protocol family
[    3.039946] microcode: Current revision: 0x000000fc
[    3.039947] microcode: Updated early from: 0x000000ea
[    3.040198] IPI shorthand broadcast: enabled
[    3.041269] sched_clock: Marking stable (3032000881, 8780147)->(3044379524, -3598496)
[    3.041454] registered taskstats version 1
[    3.041841] Loading compiled-in X.509 certificates
[    3.043476] Loaded X.509 cert 'Build time autogenerated kernel key: f9758786e4bbb1655e3fee0c89d9cf4e07ca51ff'
[    3.045704] zswap: loaded using pool zstd/zsmalloc
[    3.045980] Key type .fscrypt registered
[    3.045981] Key type fscrypt-provisioning registered
[    3.047985] PM:   Magic number: 0:943:793
[    3.050106] RAS: Correctable Errors collector initialized.
[    3.342877] ata6: SATA link down (SStatus 4 SControl 300)
[    3.342932] ata1: SATA link up 6.0 Gbps (SStatus 133 SControl 300)
[    3.342989] ata5: SATA link down (SStatus 4 SControl 300)
[    3.343051] ata4: SATA link down (SStatus 4 SControl 300)
[    3.343113] ata3: SATA link down (SStatus 4 SControl 300)
[    3.343179] ata2: SATA link up 6.0 Gbps (SStatus 133 SControl 300)
[    3.343399] ata1.00: supports DRM functions and may not be fully accessible
[    3.343406] ata1.00: ATA-11: KINGSTON SUV500240G, 003056RI, max UDMA/133
[    3.343627] ata1.00: 468862128 sectors, multi 1: LBA48 NCQ (depth 32), AA
[    3.343947] ata2.00: ATA-8: ST1000DM010-2EP102, CC43, max UDMA/133
[    3.344139] ata2.00: 1953525168 sectors, multi 16: LBA48 NCQ (depth 32), AA
[    3.345098] ata1.00: supports DRM functions and may not be fully accessible
[    3.345219] ata2.00: configured for UDMA/133
[    3.346505] ata1.00: configured for UDMA/133
[    3.346749] scsi 0:0:0:0: Direct-Access     ATA      KINGSTON SUV5002 56RI PQ: 0 ANSI: 5
[    3.347521] sd 0:0:0:0: [sda] 468862128 512-byte logical blocks: (240 GB/224 GiB)
[    3.347530] sd 0:0:0:0: [sda] 4096-byte physical blocks
[    3.347556] sd 0:0:0:0: [sda] Write Protect is off
[    3.347561] sd 0:0:0:0: [sda] Mode Sense: 00 3a 00 00
[    3.347587] sd 0:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[    3.347619] sd 0:0:0:0: [sda] Preferred minimum I/O size 4096 bytes
[    3.347675] scsi 1:0:0:0: Direct-Access     ATA      ST1000DM010-2EP1 CC43 PQ: 0 ANSI: 5
[    3.348305] sd 1:0:0:0: [sdb] 1953525168 512-byte logical blocks: (1.00 TB/932 GiB)
[    3.348314] sd 1:0:0:0: [sdb] 4096-byte physical blocks
[    3.348332] sd 1:0:0:0: [sdb] Write Protect is off
[    3.348337] sd 1:0:0:0: [sdb] Mode Sense: 00 3a 00 00
[    3.348361] sd 1:0:0:0: [sdb] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[    3.348396] sd 1:0:0:0: [sdb] Preferred minimum I/O size 4096 bytes
[    3.351798]  sda: sda1 sda2 sda3
[    3.352401] sd 0:0:0:0: [sda] Attached SCSI disk
[    3.387454]  sdb: sdb1
[    3.387710] sd 1:0:0:0: [sdb] Attached SCSI disk
[    3.387872] clk: Disabling unused clocks
[    3.390349] Freeing unused decrypted memory: 2028K
[    3.391543] Freeing unused kernel image (initmem) memory: 3628K
[    3.396883] Write protecting the kernel read-only data: 34816k
[    3.398428] Freeing unused kernel image (rodata/data gap) memory: 1584K
[    3.438738] x86/mm: Checked W+X mappings: passed, no W+X pages found.
[    3.438742] rodata_test: all tests were successful
[    3.438747] Run /init as init process
[    3.438748]   with arguments:
[    3.438750]     /init
[    3.438751]   with environment:
[    3.438752]     HOME=/
[    3.438753]     TERM=linux
[    3.438754]     BOOT_IMAGE=/@/boot/vmlinuz-linux-zen
[    3.438755]     nvme_load=YES
[    3.522631] systemd[1]: systemd 255.4-2-arch running in system mode (+PAM +AUDIT -SELINUX -APPARMOR -IMA +SMACK +SECCOMP +GCRYPT +GNUTLS +OPENSSL +ACL +BLKID +CURL +ELFUTILS +FIDO2 +IDN2 -IDN +IPTC +KMOD +LIBCRYPTSETUP +LIBFDISK +PCRE2 +PWQUALITY +P11KIT +QRENCODE +TPM2 +BZIP2 +LZ4 +XZ +ZLIB +ZSTD +BPF_FRAMEWORK +XKBCOMMON +UTMP -SYSVINIT default-hierarchy=unified)
[    3.522635] systemd[1]: Detected architecture x86-64.
[    3.522636] systemd[1]: Running in initrd.
[    3.522730] fbcon: Taking over console
[    3.522767] Console: switching to colour frame buffer device 128x48
[    3.523863] systemd[1]: Hostname set to <showex-zzz>.
[    3.570374] systemd[1]: Queued start job for default target Initrd Default Target.
[    3.587257] systemd[1]: Started Dispatch Password Requests to Console Directory Watch.
[    3.587342] systemd[1]: Expecting device /dev/disk/by-uuid/4d813d8e-ca07-4ab7-a959-6aed44d44e4e...
[    3.587383] systemd[1]: Expecting device /dev/disk/by-uuid/63f0d3ca-84ab-482c-8b6a-e5009cdeb426...
[    3.587430] systemd[1]: Reached target Initrd /usr File System.
[    3.587470] systemd[1]: Reached target Path Units.
[    3.587505] systemd[1]: Reached target Slice Units.
[    3.587539] systemd[1]: Reached target Swaps.
[    3.587570] systemd[1]: Reached target Timer Units.
[    3.587671] systemd[1]: Listening on Journal Socket (/dev/log).
[    3.587770] systemd[1]: Listening on Journal Socket.
[    3.587882] systemd[1]: Listening on udev Control Socket.
[    3.587969] systemd[1]: Listening on udev Kernel Socket.
[    3.588007] systemd[1]: Reached target Socket Units.
[    3.588695] systemd[1]: Starting Create List of Static Device Nodes...
[    3.589823] systemd[1]: Starting Journal Service...
[    3.590368] systemd[1]: Starting Load Kernel Modules...
[    3.590837] systemd[1]: Starting Create Static Device Nodes in /dev...
[    3.591341] systemd[1]: Starting Virtual Console Setup...
[    3.593233] systemd[1]: Finished Create List of Static Device Nodes.
[    3.601233] systemd[1]: Finished Virtual Console Setup.
[    3.601992] systemd[1]: Starting dracut ask for additional cmdline parameters...
[    3.603133] systemd-journald[171]: Collecting audit messages is disabled.
[    3.604003] systemd[1]: Finished Create Static Device Nodes in /dev.
[    3.619153] systemd[1]: Finished dracut ask for additional cmdline parameters.
[    3.619778] systemd[1]: Starting dracut cmdline hook...
[    3.622251] systemd[1]: Started Journal Service.
[    3.676939] raid6: skipped pq benchmark and selected avx2x4
[    3.676942] raid6: using avx2x2 recovery algorithm
[    3.680168] xor: automatically using best checksumming function   avx
[    3.816650] Btrfs loaded, zoned=yes, fsverity=yes
[    3.990897] xhci_hcd 0000:00:14.0: xHCI Host Controller
[    3.990904] xhci_hcd 0000:00:14.0: new USB bus registered, assigned bus number 1
[    3.992297] xhci_hcd 0000:00:14.0: hcc params 0x200077c1 hci version 0x110 quirks 0x0000000000009810
[    3.992884] xhci_hcd 0000:00:14.0: xHCI Host Controller
[    3.992888] xhci_hcd 0000:00:14.0: new USB bus registered, assigned bus number 2
[    3.992891] xhci_hcd 0000:00:14.0: Host supports USB 3.1 Enhanced SuperSpeed
[    3.992930] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 6.08
[    3.992933] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    3.992934] usb usb1: Product: xHCI Host Controller
[    3.992936] usb usb1: Manufacturer: Linux 6.8.1-zen1-1-zen xhci-hcd
[    3.992937] usb usb1: SerialNumber: 0000:00:14.0
[    3.995331] hub 1-0:1.0: USB hub found
[    3.995354] hub 1-0:1.0: 16 ports detected
[    4.007918] cryptd: max_cpu_qlen set to 1000
[    4.010842] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 6.08
[    4.010845] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    4.010847] usb usb2: Product: xHCI Host Controller
[    4.010849] usb usb2: Manufacturer: Linux 6.8.1-zen1-1-zen xhci-hcd
[    4.010850] usb usb2: SerialNumber: 0000:00:14.0
[    4.010996] hub 2-0:1.0: USB hub found
[    4.011014] hub 2-0:1.0: 10 ports detected
[    4.012969] xhci_hcd 0000:01:00.2: xHCI Host Controller
[    4.012974] xhci_hcd 0000:01:00.2: new USB bus registered, assigned bus number 3
[    4.013575] xhci_hcd 0000:01:00.2: hcc params 0x0180ff05 hci version 0x110 quirks 0x0000000000000010
[    4.013702] xhci_hcd 0000:01:00.2: xHCI Host Controller
[    4.013704] xhci_hcd 0000:01:00.2: new USB bus registered, assigned bus number 4
[    4.013706] xhci_hcd 0000:01:00.2: Host supports USB 3.1 Enhanced SuperSpeed
[    4.013745] usb usb3: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 6.08
[    4.013747] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    4.013748] usb usb3: Product: xHCI Host Controller
[    4.013749] usb usb3: Manufacturer: Linux 6.8.1-zen1-1-zen xhci-hcd
[    4.013751] usb usb3: SerialNumber: 0000:01:00.2
[    4.013867] hub 3-0:1.0: USB hub found
[    4.015080] hub 3-0:1.0: 2 ports detected
[    4.015179] usb usb4: We don't know the algorithms for LPM for this host, disabling LPM.
[    4.015197] usb usb4: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 6.08
[    4.015199] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    4.015201] usb usb4: Product: xHCI Host Controller
[    4.015202] usb usb4: Manufacturer: Linux 6.8.1-zen1-1-zen xhci-hcd
[    4.015203] usb usb4: SerialNumber: 0000:01:00.2
[    4.015318] hub 4-0:1.0: USB hub found
[    4.015326] hub 4-0:1.0: 4 ports detected
[    4.035676] AVX2 version of gcm_enc/dec engaged.
[    4.035770] AES CTR mode by8 optimization enabled
[    4.048150] nvidia: loading out-of-tree module taints kernel.
[    4.048159] nvidia: module license 'NVIDIA' taints kernel.
[    4.048160] Disabling lock debugging due to kernel taint
[    4.048164] nvidia: module verification failed: signature and/or required key missing - tainting kernel
[    4.048165] nvidia: module license taints kernel.
[    4.049155] PM: Image not found (code -22)
[    4.081142] BTRFS: device label endeavouros devid 1 transid 8180 /dev/sda2 scanned by mount (333)
[    4.081564] BTRFS info (device sda2): first mount of filesystem 63f0d3ca-84ab-482c-8b6a-e5009cdeb426
[    4.081574] BTRFS info (device sda2): using crc32c (crc32c-intel) checksum algorithm
[    4.081578] BTRFS info (device sda2): using free-space-tree
[    4.089985] BTRFS info (device sda2): start tree-log replay
[    4.250824] usb 1-1: new full-speed USB device number 2 using xhci_hcd
[    4.288230] BTRFS info (device sda2): checking UUID tree
[    4.346145] nvidia-nvlink: Nvlink Core is being initialized, major device number 241
[    4.347467] nvidia 0000:01:00.0: vgaarb: VGA decodes changed: olddecodes=io+mem,decodes=none:owns=io+mem
[    4.378564] usb 1-1: New USB device found, idVendor=1532, idProduct=021e, bcdDevice= 2.00
[    4.378567] usb 1-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[    4.378569] usb 1-1: Product: Razer Ornata Chroma
[    4.378570] usb 1-1: Manufacturer: Razer
[    4.386284] usbcore: registered new interface driver usbhid
[    4.386286] usbhid: USB HID core driver
[    4.388846] NVRM: loading NVIDIA UNIX x86_64 Kernel Module  550.67  Tue Mar 12 23:54:15 UTC 2024
[    4.390740] input: Razer Razer Ornata Chroma as /devices/pci0000:00/0000:00:14.0/usb1/1-1/1-1:1.0/0003:1532:021E.0001/input/input3
[    4.407237] nvidia-modeset: Loading NVIDIA Kernel Mode Setting Driver for UNIX platforms  550.67  Tue Mar 12 23:29:25 UTC 2024
[    4.410233] [drm] [nvidia-drm] [GPU ID 0x00000100] Loading driver
[    4.412768] nvidia_uvm: module uses symbols nvUvmInterfaceDisableAccessCntr from proprietary module nvidia, inheriting taint.
[    4.442024] hid-generic 0003:1532:021E.0001: input,hidraw0: USB HID v1.11 Keyboard [Razer Razer Ornata Chroma] on usb-0000:00:14.0-1/input0
[    4.442243] input: Razer Razer Ornata Chroma Keyboard as /devices/pci0000:00/0000:00:14.0/usb1/1-1/1-1:1.1/0003:1532:021E.0002/input/input4
[    4.493922] input: Razer Razer Ornata Chroma as /devices/pci0000:00/0000:00:14.0/usb1/1-1/1-1:1.1/0003:1532:021E.0002/input/input5
[    4.494071] hid-generic 0003:1532:021E.0002: input,hidraw1: USB HID v1.11 Keyboard [Razer Razer Ornata Chroma] on usb-0000:00:14.0-1/input1
[    4.494190] input: Razer Razer Ornata Chroma as /devices/pci0000:00/0000:00:14.0/usb1/1-1/1-1:1.2/0003:1532:021E.0003/input/input6
[    4.494336] hid-generic 0003:1532:021E.0003: input,hidraw2: USB HID v1.11 Mouse [Razer Razer Ornata Chroma] on usb-0000:00:14.0-1/input2
[    4.494821] usb 1-2: new full-speed USB device number 3 using xhci_hcd
[    4.622513] usb 1-2: New USB device found, idVendor=046d, idProduct=c092, bcdDevice=52.00
[    4.622516] usb 1-2: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[    4.622517] usb 1-2: Product: G102 LIGHTSYNC Gaming Mouse
[    4.622518] usb 1-2: Manufacturer: Logitech
[    4.622519] usb 1-2: SerialNumber: 206C36655841
[    4.624741] input: Logitech G102 LIGHTSYNC Gaming Mouse as /devices/pci0000:00/0000:00:14.0/usb1/1-2/1-2:1.0/0003:046D:C092.0004/input/input7
[    4.624844] hid-generic 0003:046D:C092.0004: input,hidraw3: USB HID v1.11 Mouse [Logitech G102 LIGHTSYNC Gaming Mouse] on usb-0000:00:14.0-2/input0
[    4.626185] input: Logitech G102 LIGHTSYNC Gaming Mouse Keyboard as /devices/pci0000:00/0000:00:14.0/usb1/1-2/1-2:1.1/0003:046D:C092.0005/input/input8
[    4.678049] hid-generic 0003:046D:C092.0005: input,hiddev96,hidraw4: USB HID v1.11 Keyboard [Logitech G102 LIGHTSYNC Gaming Mouse] on usb-0000:00:14.0-2/input1
[    4.791817] usb 1-4: new full-speed USB device number 4 using xhci_hcd
[    4.879767] nvidia-uvm: Loaded the UVM driver, major device number 239.
[    4.882306] Asymmetric key parser 'pkcs8' registered
[    5.021312] [drm] Initialized nvidia-drm 0.0.0 20160202 for 0000:01:00.0 on minor 0
[    5.082577] usb 1-4: New USB device found, idVendor=046d, idProduct=0aaa, bcdDevice= 0.31
[    5.082581] usb 1-4: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[    5.082582] usb 1-4: Product: PRO X
[    5.082584] usb 1-4: Manufacturer: Logitech
[    5.082585] usb 1-4: SerialNumber: 000000000000
[    5.093886] systemd-journald[171]: Received SIGTERM from PID 1 (systemd).
[    5.304388] systemd[1]: systemd 255.4-2-arch running in system mode (+PAM +AUDIT -SELINUX -APPARMOR -IMA +SMACK +SECCOMP +GCRYPT +GNUTLS +OPENSSL +ACL +BLKID +CURL +ELFUTILS +FIDO2 +IDN2 -IDN +IPTC +KMOD +LIBCRYPTSETUP +LIBFDISK +PCRE2 +PWQUALITY +P11KIT +QRENCODE +TPM2 +BZIP2 +LZ4 +XZ +ZLIB +ZSTD +BPF_FRAMEWORK +XKBCOMMON +UTMP -SYSVINIT default-hierarchy=unified)
[    5.304400] systemd[1]: Detected architecture x86-64.
[    5.375093] input: Logitech PRO X Consumer Control as /devices/pci0000:00/0000:00:14.0/usb1/1-4/1-4:1.3/0003:046D:0AAA.0006/input/input11
[    5.426974] input: Logitech PRO X as /devices/pci0000:00/0000:00:14.0/usb1/1-4/1-4:1.3/0003:046D:0AAA.0006/input/input12
[    5.427220] hid-generic 0003:046D:0AAA.0006: input,hiddev97,hidraw5: USB HID v1.11 Device [Logitech PRO X] on usb-0000:00:14.0-4/input3
[    5.540859] usb 1-7: new high-speed USB device number 5 using xhci_hcd
[    5.671738] usb 1-7: New USB device found, idVendor=18d1, idProduct=4ee1, bcdDevice= 4.04
[    5.671744] usb 1-7: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[    5.671747] usb 1-7: Product: SDM660-MTP _SN:B6D5D61E
[    5.671749] usb 1-7: Manufacturer: Xiaomi
[    5.671751] usb 1-7: SerialNumber: dc324e4
[    5.733947] systemd[1]: bpf-lsm: LSM BPF program attached
[    6.138423] systemd[1]: initrd-switch-root.service: Deactivated successfully.
[    6.138506] systemd[1]: Stopped Switch Root.
[    6.139150] systemd[1]: systemd-journald.service: Scheduled restart job, restart counter is at 1.
[    6.139411] systemd[1]: Created slice Slice /system/dirmngr.
[    6.139861] systemd[1]: Created slice Slice /system/getty.
[    6.140261] systemd[1]: Created slice Slice /system/gpg-agent.
[    6.140673] systemd[1]: Created slice Slice /system/gpg-agent-browser.
[    6.141076] systemd[1]: Created slice Slice /system/gpg-agent-extra.
[    6.141472] systemd[1]: Created slice Slice /system/gpg-agent-ssh.
[    6.141895] systemd[1]: Created slice Slice /system/keyboxd.
[    6.142298] systemd[1]: Created slice Slice /system/systemd-fsck.
[    6.142637] systemd[1]: Created slice User and Session Slice.
[    6.142883] systemd[1]: Started Dispatch Password Requests to Console Directory Watch.
[    6.143118] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[    6.143419] systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point.
[    6.143638] systemd[1]: Expecting device /dev/disk/by-uuid/4d813d8e-ca07-4ab7-a959-6aed44d44e4e...
[    6.143865] systemd[1]: Expecting device /dev/disk/by-uuid/5D1B-59BE...
[    6.144080] systemd[1]: Expecting device /dev/disk/by-uuid/63f0d3ca-84ab-482c-8b6a-e5009cdeb426...
[    6.144291] systemd[1]: Expecting device /dev/disk/by-uuid/b2dfa9ec-a593-4ffa-8cf7-b18ace6708cc...
[    6.144507] systemd[1]: Reached target Local Encrypted Volumes.
[    6.144726] systemd[1]: Reached target Login Prompts.
[    6.144957] systemd[1]: Stopped target Switch Root.
[    6.145175] systemd[1]: Stopped target Initrd File Systems.
[    6.145387] systemd[1]: Stopped target Initrd Root File System.
[    6.145604] systemd[1]: Reached target Local Integrity Protected Volumes.
[    6.145831] systemd[1]: Reached target Path Units.
[    6.146047] systemd[1]: Reached target Remote File Systems.
[    6.146260] systemd[1]: Reached target Slice Units.
[    6.146483] systemd[1]: Reached target Local Verity Protected Volumes.
[    6.146737] systemd[1]: Listening on Device-mapper event daemon FIFOs.
[    6.147585] systemd[1]: Listening on LVM2 poll daemon socket.
[    6.149037] systemd[1]: Listening on Process Core Dump Socket.
[    6.149269] systemd[1]: TPM2 PCR Extension (Varlink) was skipped because of an unmet condition check (ConditionSecurity=measured-uki).
[    6.149644] systemd[1]: Listening on udev Control Socket.
[    6.149939] systemd[1]: Listening on udev Kernel Socket.
[    6.150209] systemd[1]: Listening on User Database Manager Socket.
[    6.162019] systemd[1]: Mounting Huge Pages File System...
[    6.162618] systemd[1]: Mounting POSIX Message Queue File System...
[    6.163227] systemd[1]: Mounting Kernel Debug File System...
[    6.163792] systemd[1]: Mounting Kernel Trace File System...
[    6.164478] systemd[1]: Starting Create List of Static Device Nodes...
[    6.165130] systemd[1]: Starting Monitoring of LVM2 mirrors, snapshots etc. using dmeventd or progress polling...
[    6.165777] systemd[1]: Starting Load Kernel Module configfs...
[    6.166408] systemd[1]: Starting Load Kernel Module dm_mod...
[    6.167070] systemd[1]: Starting Load Kernel Module drm...
[    6.167694] systemd[1]: Starting Load Kernel Module fuse...
[    6.168346] systemd[1]: Starting Load Kernel Module loop...
[    6.168548] systemd[1]: systemd-fsck-root.service: Deactivated successfully.
[    6.168576] systemd[1]: Stopped File System Check on Root Device.
[    6.169721] systemd[1]: Starting Journal Service...
[    6.172512] systemd[1]: Starting Load Kernel Modules...
[    6.172739] systemd[1]: TPM2 PCR Machine ID Measurement was skipped because of an unmet condition check (ConditionSecurity=measured-uki).
[    6.173197] systemd[1]: Starting Remount Root and Kernel File Systems...
[    6.173425] systemd[1]: TPM2 SRK Setup (Early) was skipped because of an unmet condition check (ConditionSecurity=measured-uki).
[    6.173929] systemd[1]: Starting Coldplug All udev Devices...
[    6.174787] systemd[1]: Mounted Huge Pages File System.
[    6.175057] systemd[1]: Mounted POSIX Message Queue File System.
[    6.175311] systemd[1]: Mounted Kernel Debug File System.
[    6.175566] systemd[1]: Mounted Kernel Trace File System.
[    6.175986] systemd[1]: Finished Create List of Static Device Nodes.
[    6.176343] systemd[1]: modprobe@configfs.service: Deactivated successfully.
[    6.176426] systemd[1]: Finished Load Kernel Module configfs.
[    6.176812] systemd[1]: modprobe@drm.service: Deactivated successfully.
[    6.176893] systemd[1]: Finished Load Kernel Module drm.
[    6.178800] systemd[1]: Starting Create Static Device Nodes in /dev gracefully...
[    6.178884] loop: module loaded
[    6.178894] fuse: init (API version 7.39)
[    6.179284] systemd[1]: modprobe@loop.service: Deactivated successfully.
[    6.179374] systemd[1]: Finished Load Kernel Module loop.
[    6.179748] systemd[1]: Finished Load Kernel Modules.
[    6.180159] systemd[1]: modprobe@fuse.service: Deactivated successfully.
[    6.180242] systemd[1]: Finished Load Kernel Module fuse.
[    6.181018] systemd[1]: Mounting FUSE Control File System...
[    6.181378] device-mapper: uevent: version 1.0.3
[    6.181464] device-mapper: ioctl: 4.48.0-ioctl (2023-03-01) initialised: dm-devel@redhat.com
[    6.181759] systemd[1]: Starting Apply Kernel Variables...
[    6.182138] systemd[1]: modprobe@dm_mod.service: Deactivated successfully.
[    6.182224] systemd[1]: Finished Load Kernel Module dm_mod.
[    6.182527] systemd[1]: Repartition Root Disk was skipped because no trigger condition checks were met.
[    6.185065] systemd[1]: Mounted FUSE Control File System.
[    6.207276] systemd-journald[430]: Collecting audit messages is disabled.
[    6.207559] systemd[1]: Finished Apply Kernel Variables.
[    6.209871] systemd[1]: Started Journal Service.
[    6.239191] BTRFS info (device sda2: state M): use zstd compression, level 3
[    6.508263] EDAC ie31200: No ECC support
[    6.508302] EDAC ie31200: No ECC support
[    6.510827] nvidia-gpu 0000:01:00.3: enabling device (0000 -> 0002)
[    6.516909] intel_pmc_core INT33A1:00:  initialized
[    6.552316] mousedev: PS/2 mouse device common for all mice
[    6.560900] input: PC Speaker as /devices/platform/pcspkr/input/input15
[    6.568105] i801_smbus 0000:00:1f.4: SPD Write Disable is set
[    6.568175] i801_smbus 0000:00:1f.4: SMBus using PCI interrupt
[    6.568389] mei_me 0000:00:16.0: enabling device (0000 -> 0002)
[    6.577186] i2c i2c-6: 2/4 memory slots populated (from DMI)
[    6.578683] i2c i2c-6: Successfully instantiated SPD at 0x51
[    6.581115] i2c i2c-6: Successfully instantiated SPD at 0x53
[    6.593148] mc: Linux media interface: v0.10
[    6.606327] r8169 0000:04:00.0: can't disable ASPM; OS doesn't have ASPM control
[    6.614204] Adding 9227464k swap on /dev/sda3.  Priority:-2 extents:1 across:9227464k SS
[    6.628933] RAPL PMU: API unit is 2^-32 Joules, 2 fixed counters, 655360 ms ovfl timer
[    6.628936] RAPL PMU: hw unit of domain pp0-core 2^-14 Joules
[    6.628938] RAPL PMU: hw unit of domain package 2^-14 Joules
[    6.640512] r8169 0000:04:00.0 eth0: RTL8168h/8111h, b4:2e:99:88:07:cf, XID 541, IRQ 139
[    6.640517] r8169 0000:04:00.0 eth0: jumbo features [frames: 9194 bytes, tx checksumming: ko]
[    6.664865] iTCO_vendor_support: vendor-support=0
[    6.679070] ee1004 6-0051: 512 byte EE1004-compliant SPD EEPROM, read-only
[    6.681039] ee1004 6-0053: 512 byte EE1004-compliant SPD EEPROM, read-only
[    6.682009] r8169 0000:04:00.0 enp4s0: renamed from eth0
[    6.699990] systemd-journald[430]: Received client request to flush runtime journal.
[    6.701332] systemd-journald[430]: File /var/log/journal/7b0158f78d1943728e3dd9cd9b96ca08/system.journal corrupted or uncleanly shut down, renaming and replacing.
[    6.733649] snd_hda_intel 0000:00:1f.3: enabling device (0000 -> 0002)
[    6.734158] snd_hda_intel 0000:01:00.1: enabling device (0000 -> 0002)
[    6.734508] snd_hda_intel 0000:01:00.1: Disabling MSI
[    6.734514] snd_hda_intel 0000:01:00.1: Handle vga_switcheroo audio client
[    6.736282] Creating 1 MTD partitions on "0000:00:1f.5":
[    6.736285] 0x000000000000-0x000001000000 : "BIOS"
[    6.738195] iTCO_wdt iTCO_wdt: Found a Intel PCH TCO device (Version=6, TCOBASE=0x0400)
[    6.738380] iTCO_wdt iTCO_wdt: initialized. heartbeat=30 sec (nowayout=0)
[    6.768346] input: HDA NVidia HDMI/DP,pcm=3 as /devices/pci0000:00/0000:00:01.0/0000:01:00.1/sound/card2/input16
[    6.768388] input: HDA NVidia HDMI/DP,pcm=7 as /devices/pci0000:00/0000:00:01.0/0000:01:00.1/sound/card2/input17
[    6.768451] input: HDA NVidia HDMI/DP,pcm=8 as /devices/pci0000:00/0000:00:01.0/0000:01:00.1/sound/card2/input18
[    6.768501] input: HDA NVidia HDMI/DP,pcm=9 as /devices/pci0000:00/0000:00:01.0/0000:01:00.1/sound/card2/input19
[    6.777595] snd_hda_codec_realtek hdaudioC0D0: autoconfig for ALC887-VD: line_outs=1 (0x14/0x0/0x0/0x0/0x0) type:line
[    6.777599] snd_hda_codec_realtek hdaudioC0D0:    speaker_outs=0 (0x0/0x0/0x0/0x0/0x0)
[    6.777602] snd_hda_codec_realtek hdaudioC0D0:    hp_outs=1 (0x1b/0x0/0x0/0x0/0x0)
[    6.777603] snd_hda_codec_realtek hdaudioC0D0:    mono: mono_out=0x0
[    6.777605] snd_hda_codec_realtek hdaudioC0D0:    dig-out=0x11/0x0
[    6.777606] snd_hda_codec_realtek hdaudioC0D0:    inputs:
[    6.777607] snd_hda_codec_realtek hdaudioC0D0:      Front Mic=0x19
[    6.777608] snd_hda_codec_realtek hdaudioC0D0:      Rear Mic=0x18
[    6.777609] snd_hda_codec_realtek hdaudioC0D0:      Line=0x1a
[    6.789606] intel_tcc_cooling: Programmable TCC Offset detected
[    6.796342] input: HDA Intel PCH Front Mic as /devices/pci0000:00/0000:00:1f.3/sound/card0/input20
[    6.796377] input: HDA Intel PCH Rear Mic as /devices/pci0000:00/0000:00:1f.3/sound/card0/input21
[    6.796405] input: HDA Intel PCH Line as /devices/pci0000:00/0000:00:1f.3/sound/card0/input22
[    6.796443] input: HDA Intel PCH Line Out as /devices/pci0000:00/0000:00:1f.3/sound/card0/input23
[    6.796473] input: HDA Intel PCH Front Headphone as /devices/pci0000:00/0000:00:1f.3/sound/card0/input24
[    6.827422] intel_rapl_common: Found RAPL domain package
[    6.827424] intel_rapl_common: Found RAPL domain core
[    6.846086] usbcore: registered new interface driver snd-usb-audio
[    7.465923] Generic FE-GE Realtek PHY r8169-0-400:00: attached PHY driver (mii_bus:phy_addr=r8169-0-400:00, irq=MAC)
[    7.641131] r8169 0000:04:00.0 enp4s0: Link is Down
[    7.736815] nvidia-gpu 0000:01:00.3: i2c timeout error e0000000
[    7.736818] ucsi_ccg 5-0008: i2c_transfer failed -110
[    7.736820] ucsi_ccg 5-0008: ucsi_ccg_init failed - -110
[    7.736822] ucsi_ccg: probe of 5-0008 failed with error -110
[    7.756518] EXT4-fs (sdb1): recovery complete
[    7.776874] EXT4-fs (sdb1): mounted filesystem b2dfa9ec-a593-4ffa-8cf7-b18ace6708cc r/w with ordered data mode. Quota mode: none.
[    7.956442] systemd-journald[430]: File /var/log/journal/7b0158f78d1943728e3dd9cd9b96ca08/user-1000.journal corrupted or uncleanly shut down, renaming and replacing.
[   10.231323] rfkill: input handler disabled
[   10.531690] r8169 0000:04:00.0 enp4s0: Link is Up - 1Gbps/Full - flow control rx/tx
[  965.645712] usb 1-7: USB disconnect, device number 5
Here are the logs at the time of crash (sometimes can be gpu has fallen of the bus):
kernel: NVRM: GPU at PCI:0000:01:00: GPU-b6af4158-73>
kernel: NVRM: Xid (PCI:0000:01:00): 79, pid='<unknow>
kernel: NVRM: GPU 0000:01:00.0: GPU has fallen off t>
kernel: NVRM: A GPU crash dump has been created. If >
             NVRM: nvidia-bug-report.sh as root to col>
             NVRM: the NVIDIA kernel module is unloade>
gnome-shell[888]: Translated default ''24h'' for key>
kernel: irq 16: nobody cared (try booting with the ">
kernel: CPU: 6 PID: 0 Comm: swapper/6 Tainted: P    >
kernel: Hardware name: Gigabyte Technology Co., Ltd.>
kernel: Call Trace:
kernel:  <IRQ>
kernel:  dump_stack_lvl+0x47/0x60
kernel:  __report_bad_irq+0x2b/0xc0
kernel:  note_interrupt+0x2a6/0x2f0
kernel:  handle_irq_event+0x75/0x80
kernel:  handle_fasteoi_irq+0xba/0x220
kernel:  __common_interrupt+0x3f/0xb0
kernel:  common_interrupt+0x81/0xa0
kernel:  </IRQ>
kernel:  <TASK>
kernel:  asm_common_interrupt+0x26/0x40
kernel: RIP: 0010:cpuidle_enter_state+0xcc/0x830
kernel: Code: 7a 24 16 ff e8 f5 f0 ff ff 8b 53 04 49>
kernel: RSP: 0018:ffffb7f74015fe90 EFLAGS: 00000246
kernel: RAX: ffff9ef874fb4780 RBX: ffff9ef874fbe010 >
kernel: RDX: 0000000000000006 RSI: 000000002aaaab99 >
kernel: RBP: 0000000000000001 R08: 0000000000000002 >
kernel: R10: ffffffffa6d48c80 R11: 0000000000000008 >
kernel: R13: 0000000000000001 R14: 0000056ffd18b6de >
kernel:  cpuidle_enter+0x2d/0x40
kernel:  do_idle+0x1d8/0x230
kernel:  cpu_startup_entry+0x2a/0x30
kernel:  start_secondary+0x11e/0x140
kernel:  secondary_startup_64_no_verify+0x184/0x18b
kernel:  </TASK>
kernel: handlers:
kernel: [<000000004d4d879d>] i801_isr [i2c_i801]
kernel: Disabling IRQ #16
In Memtest86+ 0 errors
What you are reporting is confusing information initially. If you are crashing while playing games, or crashing while starting your computer, those are two distinct problems.
Looking at dmesg the freeze occurs after systemd starts to load, after the kernel goes through it’s typical startup procedure. Generally when the system freezes on bootup it is because of either the lack of an nvidia driver, which crashes the desktop environment, and it’s startup process, or it’s because the nvidia driver was not installed properly, which can happen for various reasons. Other than that you could have a problem with your hardware itself, which is the first place we should ideally look when troubleshooting any problem.
Here’s what I can identify based on the information
you have provided.
Youre using the Linux version 6.8.1-zen1-1-zen kernel
You’re using EndeavorOS based on the kernel command line, and you have an nvidia driver installed, and you
are using btrfs.
The kernel goes through it’s standard startup procedure
There are some errors I’ve never seen before reported,
and that have to do with nvidia
root@pc:~/Desktop# cat show3x_dmesg | grep error
root@pc:~/Desktop# cat show3x_dmesg | grep fail
[ 3.011052] ACPI: _TZ_.TZ10: _PSL evaluation failure
root@pc:~/Desktop# cat show3x_dmesg | grep warn
root@pc:~/Desktop#
That’s normal, and shouldn’t be a problem unless your using ubuntu’s latest features, and follow it’s security guidelines which prevent unregistered modules from being loaded.
Searching around a bit about some of your error messages, people are confirming that this is related to your hardware as opposed to issues in software.
Thing is, looking at google search results around “gpu has fallen off the bus” people are reporting information related to a hardware issue, but, you apparently installed linux using your nvidia card without issues, and on multiple distro’s, sometimes getting to do some gaming.
If you could provide more information about what hardware you are using, how you go about your basic installation, and anything else you can think of related to your overall setup, that would be helpful.
The standard workaround, to get past a crashed boot process and an nvidia card + innappropriate linux configuration (which is what typically crashes the boot process) is to append nomodeset to the kernel command line.
Either that, or, you can append the number 3 to your kernels command line, with a systemd based init system which tells systemd to boot into runlevel 3 instead of a graphical desktop environment. There you will have a terminal to interact with your system, where you can attempt to fix the problem as well.
Afterwards you are going to want to switch to the x11 display server, and if your problem still exists, then you revert to a different kernel, or reinstall the driver properly, checking it’s installation every step of the way to make sure there are no errors reported.
edit:
It could be the case that you have a problem, unrelated to nvidia actually, but without more information we have no way of knowing, barring literal experience with these issues.
In your last quoted section it states that the nvidia kernel module is unloaded, and an nvidia crash dump has been created. You can try to recreate the crash and grab the log to upload it here, or you can try to properly configure your system initially, and see if you can get it working.
Please check your psu and monitor temperatures.
I tried to install both via pacman (or another package depending on the distribution) sudo pacman -S nvidia-utils nvidia-settings xorg-server xorg-xinit mesa lib32-nvidia-utils lib32-mesa or with dkms depending on the kernel, as well as directly from the nvidia site. Here are the logs of the nvidia
Detailed Configuration:
 description: Desktop Computer
    product: Z390 D (Default string)
    vendor: Gigabyte Technology Co., Ltd.
    version: Default string
    serial: Default string
    width: 64 bits
    capabilities: smbios-3.1.1 dmi-3.1.1 smp vsyscall32
    configuration: boot=normal chassis=desktop family=Default string sku=Default string uuid=032e02b4-0499-0588-0706-cf0700080009
  *-core
       description: Motherboard
       product: Z390 D
       physical id: 0
       slot: Default string
     *-firmware
          description: BIOS
          vendor: American Megatrends Inc.
          physical id: 0
          version: F3
          date: 11/05/2021
          capacity: 16MiB
          capabilities: pci upgrade shadowing cdboot bootselect socketedrom edd int13floppy1200 int13floppy720 int13floppy2880 int5printscreen int14serial int17printer acpi usb biosbootspecification uefi
     *-memory
          description: System Memory
          physical id: 3a
          slot: System board or motherboard
        *-bank:0
             description: [empty]
             physical id: 0
             slot: ChannelA-DIMM0
        *-bank:1
             description: DIMM DDR4 Synchronous 3200 MHz (0,3 ns)
             product: KHX3200C16D4/8GX
             vendor: Kingston
             physical id: 1
             serial: 51E4D08A
             slot: ChannelA-DIMM1
             width: 64 bits
             clock: 3200MHz (0.3ns)
        *-bank:2
             physical id: 2
             slot: ChannelB-DIMM0
        *-bank:3
             vendor: Kingston
             physical id: 3
             serial: B74CF4E6
             slot: ChannelB-DIMM1
             width: 64 bits
     *-cache:0
          description: L1 cache
          physical id: 44
          slot: L1 Cache
          capacity: 512KiB
          capabilities: synchronous internal write-back unified
          configuration: level=1
     *-cache:1
          description: L2 cache
          physical id: 45
          slot: L2 Cache
          capacity: 2MiB
          configuration: level=2
     *-cache:2
          description: L3 cache
          physical id: 46
          slot: L3 Cache
          capacity: 12MiB
          configuration: level=3
     *-cpu
          description: CPU
          product: Intel(R) Core(TM) i7-9700F CPU @ 3.00GHz
          vendor: Intel Corp.
          physical id: 47
          bus info: cpu@0
          version: 6.158.13
          serial: To Be Filled By O.E.M.
          slot: U3E1
          capacity: 4700MHz
          width: 64 bits
          clock: 100MHz
          capabilities: lm fpu fpu_exception wp vme de pse tsc msr pae mce cx8 apic sep mtrr pge mca cmov pat pse36 clflush dts acpi mmx fxsr sse sse2 ss ht tm pbe syscall nx pdpe1gb rdtscp x86-64 constant_tsc art arch_perfmon pebs bts rep_good nopl xtopology nonstop_tsc cpuid aperfmperf pni pclmulqdq dtes64 monitor ds_cpl vmx est tm2 ssse3 sdbg fma cx16 xtpr pdcm pcid sse4_1 sse4_2 x2apic movbe popcnt tsc_deadline_timer aes xsave avx f16c rdrand lahf_lm abm 3dnowprefetch cpuid_fault ssbd ibrs ibpb stibp ibrs_enhanced tpr_shadow flexpriority ept vpid ept_ad fsgsbase tsc_adjust sgx bmi1 avx2 smep bmi2 erms invpcid mpx rdseed adx smap clflushopt intel_pt xsaveopt xsavec xgetbv1 xsaves dtherm ida arat pln pts hwp hwp_notify hwp_act_window hwp_epp vnmi sgx_lc md_clear flush_l1d arch_capabilities cpufreq
          configuration: cores=8 enabledcores=8 microcode=252 threads=8
     *-pci
          description: Host bridge
          product: 8th/9th Gen Core 8-core Desktop Processor Host Bridge/DRAM Registers [Coffee Lake S]
          vendor: Intel Corporation
          physical id: 100
          bus info: pci@0000:00:00.0
          version: 0d
          width: 32 bits
          clock: 33MHz
          configuration: driver=skl_uncore
          resources: irq:0
        *-pci:0
             description: PCI bridge
             product: 6th-10th Gen Core Processor PCIe Controller (x16)
             physical id: 1
             bus info: pci@0000:00:01.0
             version: 0d
             width: 32 bits
             clock: 33MHz
             capabilities: pci pm msi pciexpress normal_decode bus_master cap_list
             configuration: driver=pcieport
             resources: irq:121 ioport:4000(size=4096) memory:39000000-3a0fffff ioport:40000000(size=303038464)
           *-display
                description: VGA compatible controller
                product: TU106 [GeForce RTX 2060 SUPER]
                vendor: NVIDIA Corporation
                physical id: 0
                bus info: pci@0000:01:00.0
                version: a1
                width: 64 bits
                clock: 33MHz
                capabilities: pm msi pciexpress vga_controller bus_master cap_list rom
                configuration: driver=nvidia latency=0
                resources: irq:136 memory:39000000-39ffffff memory:40000000-4fffffff memory:50000000-51ffffff ioport:4000(size=128) memory:c0000-dffff
           *-multimedia
                description: Audio device
                product: TU106 High Definition Audio Controller
                physical id: 0.1
                bus info: pci@0000:01:00.1
                logical name: card1
                logical name: /dev/snd/controlC1
                logical name: /dev/snd/hwC1D0
                logical name: /dev/snd/pcmC1D3p
                logical name: /dev/snd/pcmC1D7p
                logical name: /dev/snd/pcmC1D8p
                logical name: /dev/snd/pcmC1D9p
                version: a1
                width: 32 bits
                clock: 33MHz
                capabilities: pm msi pciexpress bus_master cap_list
                configuration: driver=snd_hda_intel latency=0
                resources: irq:17 memory:3a080000-3a083fff
              *-input:0
                   product: HDA NVidia HDMI/DP,pcm=3
                   physical id: 0
                   logical name: input16
                   logical name: /dev/input/event12
              *-input:1
                   product: HDA NVidia HDMI/DP,pcm=7
                   physical id: 1
                   logical name: input17
                   logical name: /dev/input/event13
              *-input:2
                   product: HDA NVidia HDMI/DP,pcm=8
                   physical id: 2
                   logical name: input18
                   logical name: /dev/input/event14
              *-input:3
                   product: HDA NVidia HDMI/DP,pcm=9
                   physical id: 3
                   logical name: input19
                   logical name: /dev/input/event15
           *-usb
                description: USB controller
                product: TU106 USB 3.1 Host Controller
                physical id: 0.2
                bus info: pci@0000:01:00.2
                version: a1
                width: 64 bits
                clock: 33MHz
                capabilities: msi pciexpress pm xhci cap_list
                configuration: driver=xhci_hcd latency=0
                resources: irq:135 memory:52000000-5203ffff memory:52040000-5204ffff
              *-usbhost:0
                   product: xHCI Host Controller
                   vendor: Linux 6.8.1-zen1-1-zen xhci-hcd
                   physical id: 0
                   bus info: usb@3
                   logical name: usb3
                   version: 6.08
                   capabilities: usb-2.00
                   configuration: driver=hub slots=2 speed=480Mbit/s
              *-usbhost:1
                   physical id: 1
                   bus info: usb@4
                   logical name: usb4
                   version: 6.08
                   capabilities: usb-3.10
                   configuration: driver=hub slots=4 speed=10000Mbit/s
           *-serial
                description: Serial bus controller
                product: TU106 USB Type-C UCSI Controller
                physical id: 0.3
                bus info: pci@0000:01:00.3
                version: a1
                width: 32 bits
                clock: 33MHz
                capabilities: msi pciexpress pm bus_master cap_list
                configuration: driver=nvidia-gpu latency=0
                resources: irq:137 memory:3a084000-3a084fff
        *-generic
             description: Signal processing controller
             product: Cannon Lake PCH Thermal Controller
             physical id: 12
             bus info: pci@0000:00:12.0
             version: 10
             width: 64 bits
             clock: 33MHz
             capabilities: pm msi cap_list
             configuration: driver=intel_pch_thermal latency=0
             resources: irq:16 memory:3a31d000-3a31dfff
        *-usb
             product: Cannon Lake PCH USB 3.1 xHCI Host Controller
             physical id: 14
             bus info: pci@0000:00:14.0
             version: 10
             width: 64 bits
             clock: 33MHz
             capabilities: pm msi xhci bus_master cap_list
             resources: irq:127 memory:3a300000-3a30ffff
           *-usbhost:0
                physical id: 0
                bus info: usb@1
                logical name: usb1
                version: 6.08
                configuration: driver=hub slots=16 speed=480Mbit/s
              *-usb:0
                   description: Keyboard
                   product: Razer Razer Ornata Chroma
                   vendor: Razer
                   physical id: 1
                   bus info: usb@1:1
                   logical name: input3
                   logical name: /dev/input/event3
                   logical name: input3::capslock
                   logical name: input3::numlock
                   logical name: input3::scrolllock
                   logical name: input4
                   logical name: /dev/input/event4
                   logical name: input5
                   logical name: /dev/input/event5
                   logical name: input7
                   logical name: /dev/input/event7
                   logical name: /dev/input/mouse1
                   version: 2.00
                   capabilities: usb-2.00 usb
                   configuration: driver=usbhid maxpower=500mA speed=12Mbit/s
              *-usb:1
                   description: Mouse
                   product: Logitech G102 LIGHTSYNC Gaming Mouse Keyboard
                   vendor: Logitech
                   physical id: 2
                   bus info: usb@1:2
                   logical name: input6
                   logical name: /dev/input/event6
                   logical name: /dev/input/mouse0
                   logical name: input8
                   logical name: /dev/input/event8
                   version: 52.00
                   serial: 206C36655841
                   configuration: driver=usbhid maxpower=300mA speed=12Mbit/s
              *-usb:2
                   product: Logitech PRO X
                   vendor: Logitech
                   physical id: 4
                   bus info: usb@1:4
                   logical name: card2
                   logical name: /dev/snd/controlC2
                   logical name: /dev/snd/pcmC2D0c
                   logical name: /dev/snd/pcmC2D0p
                   logical name: input11
                   logical name: /dev/input/event9
                   logical name: input12
                   logical name: /dev/input/event10
                   logical name: input12::mute
                   version: 0.31
                   serial: 000000000000
                   capabilities: usb-2.00 audio-control usb
                   configuration: driver=usbhid maxpower=100mA speed=12Mbit/s
           *-usbhost:1
                physical id: 1
                bus info: usb@2
                logical name: usb2
                version: 6.08
                configuration: driver=hub slots=10 speed=10000Mbit/s
        *-memory UNCLAIMED
             description: RAM memory
             product: Cannon Lake PCH Shared SRAM
             physical id: 14.2
             bus info: pci@0000:00:14.2
             version: 10
             width: 64 bits
             clock: 33MHz (30.3ns)
             capabilities: pm cap_list
             configuration: latency=0
             resources: memory:3a316000-3a317fff memory:3a31c000-3a31cfff
        *-communication
             description: Communication controller
             product: Cannon Lake PCH HECI Controller
             physical id: 16
             bus info: pci@0000:00:16.0
             version: 10
             width: 64 bits
             clock: 33MHz
             capabilities: pm msi bus_master cap_list
             configuration: driver=mei_me latency=0
             resources: irq:138 memory:3a31b000-3a31bfff
        *-raid
             description: RAID bus controller
             product: SATA Controller [RAID mode]
             physical id: 17
             bus info: pci@0000:00:17.0
             version: 10
             width: 32 bits
             clock: 66MHz
             capabilities: raid msix pm bus_master cap_list
             configuration: driver=ahci latency=0
             resources: irq:16 memory:3a314000-3a315fff memory:3a31a000-3a31a0ff ioport:5050(size=8) ioport:5040(size=4) ioport:5020(size=32) memory:3a319000-3a3197ff
        *-pci:1
             product: Cannon Lake PCH PCI Express Root Port #17
             physical id: 1b
             bus info: pci@0000:00:1b.0
             version: f0
             width: 32 bits
             clock: 33MHz
             capabilities: pci pciexpress msi pm normal_decode bus_master cap_list
             resources: irq:122
        *-pci:2
             physical id: 1c
             bus info: pci@0000:00:1c.0
             version: f0
             width: 32 bits
             clock: 33MHz
             resources: irq:123
        *-pci:3
             product: Cannon Lake PCH PCI Express Root Port #3
             physical id: 1c.2
             bus info: pci@0000:00:1c.2
             version: f0
             width: 32 bits
             clock: 33MHz
             resources: irq:124 ioport:3000(size=4096) memory:3a200000-3a2fffff
           *-network
                description: Ethernet interface
                product: RTL8111/8168/8211/8411 PCI Express Gigabit Ethernet Controller
                vendor: Realtek Semiconductor Co., Ltd.
                physical id: 0
                bus info: pci@0000:04:00.0
                logical name: enp4s0
                version: 16
                serial: b4:2e:99:88:07:cf
                capacity: 1Gbit/s
                width: 64 bits
                clock: 33MHz
                capabilities: pm msi pciexpress msix bus_master cap_list ethernet physical tp mii 10bt 10bt-fd 100bt 100bt-fd 1000bt-fd autonegotiation
                configuration: autonegotiation=on broadcast=yes driver=r8169 driverversion=6.8.1-zen1-1-zen duplex=full firmware=rtl8168h-2_0.0.2 02/26/15 ip=192.168.0.103 latency=0 link=yes multicast=yes port=twisted pair speed=1Gbit/s
                resources: irq:18 ioport:3000(size=256) memory:3a204000-3a204fff memory:3a200000-3a203fff
        *-pci:4
             product: Cannon Lake PCH PCI Express Root Port #9
             physical id: 1d
             bus info: pci@0000:00:1d.0
             version: f0
             width: 32 bits
             clock: 33MHz
             resources: irq:125 ioport:6000(size=4096) memory:3a400000-3a5fffff ioport:3a600000(size=2097152)
        *-isa
             description: ISA bridge
             product: Z390 Chipset LPC/eSPI Controller
             physical id: 1f
             bus info: pci@0000:00:1f.0
             version: 10
             width: 32 bits
             clock: 33MHz
             capabilities: isa bus_master
           *-pnp00:00
                product: Motherboard registers
                physical id: 0
                capabilities: pnp
                configuration: driver=system
           *-pnp00:01
                product: 16550A-compatible COM port
                physical id: 1
                capabilities: pnp
                configuration: driver=serial
           *-pnp00:02
                physical id: 2
                capabilities: pnp
           *-pnp00:03
                product: AT Real-Time Clock
                physical id: 3
                capabilities: pnp
                configuration: driver=rtc_cmos
           *-pnp00:04
                product: PnP device INT3f0d
                vendor: Interphase Corporation
                physical id: 4
                capabilities: pnp
           *-pnp00:05
                physical id: 5
                capabilities: pnp
           *-pnp00:06
                physical id: 6
                capabilities: pnp
           *-pnp00:07
                physical id: 7
                capabilities: pnp
           *-pnp00:08
                physical id: 8
                capabilities: pnp
        *-multimedia
             product: Cannon Lake PCH cAVS
             physical id: 1f.3
             bus info: pci@0000:00:1f.3
             logical name: card0
             logical name: /dev/snd/controlC0
             logical name: /dev/snd/hwC0D0
             logical name: /dev/snd/pcmC0D0c
             logical name: /dev/snd/pcmC0D0p
             logical name: /dev/snd/pcmC0D1p
             logical name: /dev/snd/pcmC0D2c
             version: 10
             width: 64 bits
             clock: 33MHz
             configuration: driver=snd_hda_intel latency=32
             resources: irq:140 memory:3a310000-3a313fff memory:3a100000-3a1fffff
           *-input:0
                product: HDA Intel PCH Front Mic
                physical id: 0
                logical name: input20
                logical name: /dev/input/event16
           *-input:1
                product: HDA Intel PCH Rear Mic
                physical id: 1
                logical name: input21
                logical name: /dev/input/event17
           *-input:2
                product: HDA Intel PCH Line
                physical id: 2
                logical name: input22
                logical name: /dev/input/event18
           *-input:3
                product: HDA Intel PCH Line Out
                physical id: 3
                logical name: input23
                logical name: /dev/input/event19
           *-input:4
                product: HDA Intel PCH Front Headphone
                physical id: 4
                logical name: input24
                logical name: /dev/input/event20
        *-serial:0
             description: SMBus
             product: Cannon Lake PCH SMBus Controller
             physical id: 1f.4
             bus info: pci@0000:00:1f.4
             version: 10
             width: 64 bits
             clock: 33MHz
             configuration: driver=i801_smbus latency=0
             resources: irq:16 memory:3a318000-3a3180ff ioport:efa0(size=32)
        *-serial:1
             product: Cannon Lake PCH SPI Controller
             physical id: 1f.5
             bus info: pci@0000:00:1f.5
             version: 10
             width: 32 bits
             clock: 33MHz
             configuration: driver=intel-spi latency=0
             resources: irq:0 memory:fe010000-fe010fff
  *-power UNCLAIMED
       description: To Be Filled By O.E.M.
       product: To Be Filled By O.E.M.
       vendor: To Be Filled By O.E.M.
       physical id: 1
       version: To Be Filled By O.E.M.
       capacity: 32768mWh
  *-graphics
       product: EFI VGA
       physical id: 2
       logical name: /dev/fb0
       capabilities: fb
       configuration: depth=32 resolution=1024,768
  *-input:0
       product: Sleep Button
       physical id: 3
       logical name: input0
       logical name: /dev/input/event0
       capabilities: platform
  *-input:1
       product: Power Button
       physical id: 4
  *-input:2
       product: PC Speaker
       physical id: 5
       logical name: input15
       logical name: /dev/input/event11
       capabilities: isa
  *-input:3
       physical id: 6
nvidia-bug-report.log (19.4 MB)
pch_cannonlake-virtual-0
Adapter: Virtual device
temp1:        +39.0°C
acpitz-acpi-0
Adapter: ACPI interface
temp1:        +16.8°C
temp2:        +27.8°C
coretemp-isa-0000
Adapter: ISA adapter
Package id 0:  +95.0°C  (high = +86.0°C, crit = +100.0°C)
Core 0:        +90.0°C  (high = +86.0°C, crit = +100.0°C)
Core 1:        +92.0°C  (high = +86.0°C, crit = +100.0°C)
Core 2:        +90.0°C  (high = +86.0°C, crit = +100.0°C)
Core 3:        +89.0°C  (high = +86.0°C, crit = +100.0°C)
Core 4:        +96.0°C  (high = +86.0°C, crit = +100.0°C)
Core 5:        +89.0°C  (high = +86.0°C, crit = +100.0°C)
Core 6:        +90.0°C  (high = +86.0°C, crit = +100.0°C)
Core 7:        +88.0°C  (high = +86.0°C, crit = +100.0°C)
gigabyte_wmi-virtual-0
temp1:        +38.0°C
temp2:        +33.0°C
temp3:        +81.0°C
temp4:        +31.0°C
temp5:        +39.0°C
temp6:        +30.0°C
In general, everything is fine with the psu, it is not damaged and connected well.
Your system is misconfigured. I didn’t notice when I first responded to you that you say a reboot helps. That means that your system is working, but sometimes the line of processes’ based on your configuration can sometimes crash.
Your install should be very simple, to help you identify problems in the future.
You have to identify the main aspects of your overall configuration to discover what the conflict is.
What desktop environment are you using?
What’s your display server? (x11 or wayland)
What kind of games are you playing that crash?
What did you specifically do to your system, before the crashes started occuring?
How are you installing your driver? Are you using the distributions documented methods?
What kind of filesystem are you using? Partitioning scheme? Bios or Uefi?
How do you customize your system beyond the defaults they ship with?
I have played around with all of the distributions too, and customized them as heavily as I am able to, which produces crashes like you are describing, and that is how I solve the problem.
Usually the custom gaming kernels like liquorix, xanmod, tkg, maybe even zen, can break the boot process, and sometimes a reboot helps like you describe.
So I would attempt to use a standard kernel initially, to help you narrow down other problems with your overall configuration.
And a last point, reducing the amount of automatic processes’ helps deal with this problem too, and will help prevent the system from crashing. That means disabling unnecessary startup programs and services.
Defaults alone aren’t enough to prevent crashes and provide a stable environment in reality, since everyone uses computers differently. You actually have to customize your setup to make your own stable environment.
  1. Gnome or kde (The problem is on both)
  2. x11
  3. Apex legends, ready or not, Hoi4(Any games)
  4. The only thing I touched was mitigations=off, that’s all, but what I tried to clean up and what didn’t is the same. Not affected again
  5. Conditionally on void linux I use documented, on arch and its derivatives sudo pacman -S nvidia-utils nvidia-settings xorg-server xorg-xinit mesa lib32-nvidia-utils lib32-mesa but tried it through the site
  6. Btrfs and the separation is usually automatic, which is suggested by the distr sometimes /boot - 1024mb BTRFS /boot/efi - 256mb / - 30720mb BTRFS /home - the rest of the BTRFS remainder, uefi
  7. On the gnome, I just download the theme and icons, as well as from the add-ons blur my shell (But it also paints in the stock). I tried vanilla os at all, I didn’t touch the system at all, stupidly steamed to check, it still crashes and on opensuse the same
Bro
Use a stable distribution
Not rolling
Rolling distributions are going to routinely break, just like you describe. That’s the not-so-fine-print for all those arch based, and rolling distro’s.
Gnome and KDE are probably the most unstable desktop environments in general, and especially right now since they are having lots of dramatic changes pushed out onto everybody, that is breaking lots of people’s computers.
Use a stable distro, use a stable desktop environment.
Kde 5.23 (less than 6) is stable
Older gnome than the absolute newest should be stable.
I would recommend installing a new desktop environment besides the other ones you would rather use, that is stable, such as xfce, so you can switch to it, when the others pose problems.
(just want to point out this is the perfect example, what you are describing, of what unstable versus stable means)
But is opensuse leap considered unstable, or for example fedora 38, pop os or linux mint with xfce there is also this (
They can be, because what happens is -
Everyone has a different computer than each other,
and so their whole configuration is different ultimately.
You’ve got to understand that an operating system is a complex web of different programs and processes’
You really want to find yourself a stable system, and avoid the distributions that shove out the newest packages onto people. That is where, you will find systems breaking consistently, and wasting your time. I would recommend to you using debian or ubuntu, which don’t shove out the latest developments onto people.
A lot of times problems that people have with different distributions aren’t reported. So what may seem like a good pick from the outside looking in, may actually be a unstable-broken environment for you.
But the problem on them is the same as on the rolling(Exactly mine)
So youre saying that your system crashes using kde 6 and also kde 5.23? In the same way?
Exactly, although this was not the case before. And the last time everything was good, I sat on a clean arch with a zen kernel and kde
It’s like I said, a lot of things have changed since then. I can’t identify anything in your bug-report that looks like of order. It looks like you aren’t installing your driver appropriately. On endeavourOS they have an installer for nvidia that works well. I would rebuild your system from the ground up->
I.e. backup any files you want to save
reinstall the operating system
make sure to pick out x11 as your display server instead of wayland
try to clean your system as much as possible, reducing unnecessary automatic programs like services
use the nvidia-inst utility that endeavor provides to install your nvidia driver
or if you want an easier system to deal with, then you’re going to want to switch to a stable OS,
or attempt to avoid major upgrades on arch and work with what you got.
At the moment I’m sitting on endeavouros and I’ve already chosen the option with ready-made nvidia drivers and always sit on x11. I’ve tried the ustanipower clean system of endeavouros, for example, without a custom kernel only nvidia which was offered when installing which were out of the box and out of the package only steam. System still crashed.
So your system is working now
But steam crashes.
System still crashed. I mean, only the steam was downloaded
What have you tried doing so far to fix the problem?
Everything you are reporting is very confusing, so it’s going to be hard for anyone to help you.
Tried different startup options acpi=noirq, thermal.off=1, ahci.mobile_lpm_policy=1. More /usr/bin/nvidia-smi -pm 1. Custom kernels zen, xanmod, lts, as well as stock kernels are available. I tried different ways to install drivers. I checked, cleaned the computer itself
What made you choose these choices?
Please report, also, whether or not your system is working normally as you expect it should, with nomodeset appended to your kernel commandline.
