We have installed an A100 PCIe 80GB] (rev a1) on an MSI Z490-A Pro motherboard (latest BIOS version V2.E0) running Debian GNU/Linux 10 (buster) (kernel 4.19.289-2 (2023-08-08)) with NVIDIA driver 530.30.02, but cannot get it to be initialized. We’d welcome any advice you can offer.
At boot time the following messages appear indicating that the card cannot be initialized.
nvidia-nvlink: Nvlink Core is being initialized, major device number 243
nvidia 0000:01:00.0: enabling device (0000 -> 0002)
NVRM: This PCI I/O region assigned to your NVIDIA device is invalid:
NVRM: BAR0 is 0M @ 0x0 (PCI:0000:01:00.0)
nvidia: probe of 0000:01:00.0 failed with error -1
NVRM: The NVIDIA probe routine failed for 1 device(s).
NVRM: None of the NVIDIA devices were initialized.
nvidia-nvlink: Unregistered Nvlink Core, major device number 243
We have configured the BIOS settings as recommended in other posts:
- CSM disabled
- PCI above 4GB memory enabled (by default in the current BIOS version)
- Fast boot disabled
- Secure boot disabled
We also tried enabling “Resize BAR”, but this prevents the machine from booting. (The BIOS initialization stops with the EZ Debug LED for DRAM on.)
We have tried both the kernel pci=realloc=off and pci=realloc startup parameters.
The output of lspci -v is as follows.
01:00.0 3D controller: NVIDIA Corporation GA100 [A100 PCIe 80GB] (rev a1)
Subsystem: NVIDIA Corporation Device 1533
Flags: fast devsel, IRQ 16
Memory at <ignored> (32-bit, non-prefetchable)
Memory at <ignored> (64-bit, prefetchable)
Memory at 82000000 (64-bit, prefetchable) [size=32M]
Capabilities: [60] Power Management version 3
Capabilities: [68] #00 [0080]
Capabilities: [78] Express Endpoint, MSI 00
Capabilities: [b4] Vendor Specific Information: Len=14 <?>
Capabilities: [c8] MSI-X: Enable- Count=6 Masked-
Capabilities: [100] Virtual Channel
Capabilities: [250] Latency Tolerance Reporting
Capabilities: [258] L1 PM Substates
Capabilities: [128] Power Budgeting <?>
Capabilities: [420] Advanced Error Reporting
Capabilities: [600] Vendor Specific Information: ID=0001 Rev=1 Len=024 <?>
Capabilities: [900] #19
Capabilities: [bb0] #15
Capabilities: [bcc] Single Root I/O Virtualization (SR-IOV)
Capabilities: [c14] Alternative Routing-ID Interpretation (ARI)
Capabilities: [c1c] #26
Capabilities: [d00] #27
Capabilities: [e00] #25
Kernel modules: nvidia
The complete dmesg output is as follows:
[ 0.000000] microcode: microcode updated early to revision 0xf8, date = 2023-02-23
[ 0.000000] Linux version 4.19.0-25-amd64 (debian-kernel@lists.debian.org) (gcc version 8.3.0 (Debian 8.3.0-6)) #1 SMP Debian 4.19.289-2 (2023-08-08)
[ 0.000000] Command line: BOOT_IMAGE=/boot/vmlinuz-4.19.0-25-amd64 root=UUID=4e032d92-8422-4025-8ede-24048075943c ro splash pci=realloc
[ 0.000000] BIOS-provided physical RAM map:
[ 0.000000] BIOS-e820: [mem 0x0000000000000000-0x000000000009dfff] usable
[ 0.000000] BIOS-e820: [mem 0x000000000009e000-0x000000000009efff] reserved
[ 0.000000] BIOS-e820: [mem 0x000000000009f000-0x000000000009ffff] usable
[ 0.000000] BIOS-e820: [mem 0x00000000000a0000-0x00000000000fffff] reserved
[ 0.000000] BIOS-e820: [mem 0x0000000000100000-0x000000003fffffff] usable
[ 0.000000] BIOS-e820: [mem 0x0000000040000000-0x00000000403fffff] reserved
[ 0.000000] BIOS-e820: [mem 0x0000000040400000-0x0000000074b89fff] usable
[ 0.000000] BIOS-e820: [mem 0x0000000074b8a000-0x0000000074b8afff] ACPI NVS
[ 0.000000] BIOS-e820: [mem 0x0000000074b8b000-0x0000000074babfff] usable
[ 0.000000] BIOS-e820: [mem 0x0000000074bac000-0x0000000074bacfff] reserved
[ 0.000000] BIOS-e820: [mem 0x0000000074bad000-0x0000000078613fff] usable
[ 0.000000] BIOS-e820: [mem 0x0000000078614000-0x0000000078e13fff] reserved
[ 0.000000] BIOS-e820: [mem 0x0000000078e14000-0x0000000078f43fff] ACPI data
[ 0.000000] BIOS-e820: [mem 0x0000000078f44000-0x0000000079143fff] ACPI NVS
[ 0.000000] BIOS-e820: [mem 0x0000000079144000-0x0000000079d43fff] reserved
[ 0.000000] BIOS-e820: [mem 0x0000000079d44000-0x0000000079ffdfff] type 20
[ 0.000000] BIOS-e820: [mem 0x0000000079ffe000-0x0000000079ffefff] usable
[ 0.000000] BIOS-e820: [mem 0x0000000079fff000-0x000000007f7fffff] reserved
[ 0.000000] BIOS-e820: [mem 0x00000000e0000000-0x00000000efffffff] reserved
[ 0.000000] BIOS-e820: [mem 0x00000000fe000000-0x00000000fe010fff] reserved
[ 0.000000] BIOS-e820: [mem 0x00000000fec00000-0x00000000fec00fff] reserved
[ 0.000000] BIOS-e820: [mem 0x00000000fee00000-0x00000000fee00fff] reserved
[ 0.000000] BIOS-e820: [mem 0x00000000ff000000-0x00000000ffffffff] reserved
[ 0.000000] BIOS-e820: [mem 0x0000000100000000-0x000000087e7fffff] usable
[ 0.000000] NX (Execute Disable) protection: active
[ 0.000000] efi: EFI v2.70 by American Megatrends
[ 0.000000] efi: ACPI=0x7908a000 ACPI 2.0=0x7908a014 SMBIOS=0x79b5d000 SMBIOS 3.0=0x79b5c000 MEMATTR=0x72348018 ESRT=0x73c75d18
[ 0.000000] secureboot: Secure boot disabled
[ 0.000000] SMBIOS 3.2.0 present.
[ 0.000000] DMI: Micro-Star International Co., Ltd. MS-7C75/Z490-A PRO (MS-7C75), BIOS 2.E0 06/09/2022
[ 0.000000] tsc: Detected 2900.000 MHz processor
[ 0.000380] e820: update [mem 0x00000000-0x00000fff] usable ==> reserved
[ 0.000381] e820: remove [mem 0x000a0000-0x000fffff] usable
[ 0.000389] last_pfn = 0x87e800 max_arch_pfn = 0x400000000
[ 0.000392] MTRR default type: write-back
[ 0.000393] MTRR fixed ranges enabled:
[ 0.000394] 00000-9FFFF write-back
[ 0.000394] A0000-BFFFF uncachable
[ 0.000395] C0000-FFFFF write-protect
[ 0.000396] MTRR variable ranges enabled:
[ 0.000397] 0 base 0080000000 mask 7F80000000 uncachable
[ 0.000398] 1 base 007C000000 mask 7FFC000000 uncachable
[ 0.000398] 2 base 007B000000 mask 7FFF000000 uncachable
[ 0.000399] 3 base 2000000000 mask 6000000000 uncachable
[ 0.000400] 4 base 1000000000 mask 7000000000 uncachable
[ 0.000400] 5 base 4000000000 mask 4000000000 uncachable
[ 0.000401] 6 disabled
[ 0.000401] 7 disabled
[ 0.000401] 8 disabled
[ 0.000402] 9 disabled
[ 0.001657] x86/PAT: Configuration [0-7]: WB WC UC- UC WB WP UC- WT
[ 0.002304] last_pfn = 0x79fff max_arch_pfn = 0x400000000
[ 0.015091] esrt: Reserving ESRT space from 0x0000000073c75d18 to 0x0000000073c75d50.
[ 0.015097] e820: update [mem 0x73c75000-0x73c75fff] usable ==> reserved
[ 0.015117] Using GB pages for direct mapping
[ 0.015579] RAMDISK: [mem 0x2fe7f000-0x33f36fff]
[ 0.015583] ACPI: Early table checksum verification disabled
[ 0.015586] ACPI: RSDP 0x000000007908A014 000024 (v02 ALASKA)
[ 0.015589] ACPI: XSDT 0x0000000079089728 0000CC (v01 ALASKA A M I 01072009 AMI 01000013)
[ 0.015594] ACPI: FACP 0x0000000078F3D000 000114 (v06 ALASKA A M I 01072009 AMI 00010013)
[ 0.015598] ACPI: DSDT 0x0000000078EF6000 046DC9 (v02 ALASKA A M I 01072009 INTL 20160527)
[ 0.015601] ACPI: FACS 0x0000000079143000 000040
[ 0.015603] ACPI: MCFG 0x0000000078F41000 00003C (v01 ALASKA A M I 01072009 MSFT 00000097)
[ 0.015605] ACPI: SSDT 0x0000000078F3E000 00203B (v02 CpuRef CpuSsdt 00003000 INTL 20160527)
[ 0.015608] ACPI: FIDT 0x0000000078EF5000 00009C (v01 ALASKA A M I 01072009 AMI 00010013)
[ 0.015610] ACPI: SSDT 0x0000000078EF1000 0031F9 (v02 SaSsdt SaSsdt 00003000 INTL 20160527)
[ 0.015613] ACPI: SSDT 0x0000000078EED000 003F6C (v02 Intel PegSsdt 00001000 INTL 20160527)
[ 0.015615] ACPI: HPET 0x0000000078F43000 000038 (v01 ALASKA A M I 01072009 AMI 01000013)
[ 0.015617] ACPI: APIC 0x0000000078F42000 000164 (v04 ALASKA A M I 01072009 AMI 01000013)
[ 0.015620] ACPI: SSDT 0x0000000078EEB000 00147B (v02 ALASKA Ther_Rvp 00001000 INTL 20160527)
[ 0.015622] ACPI: SSDT 0x0000000078EE6000 00461A (v02 INTEL xh_cmsd4 00000000 INTL 20160527)
[ 0.015624] ACPI: NHLT 0x0000000078EE4000 001821 (v00 ALASKA A M I 01072009 AMI 01000013)
[ 0.015627] ACPI: LPIT 0x0000000078EE3000 000094 (v01 ALASKA A M I 01072009 AMI 01000013)
[ 0.015629] ACPI: SSDT 0x0000000078EDF000 002720 (v02 ALASKA PtidDevc 00001000 INTL 20160527)
[ 0.015631] ACPI: SSDT 0x0000000078EDC000 0027EC (v02 ALASKA TbtTypeC 00000000 INTL 20160527)
[ 0.015634] ACPI: DBGP 0x0000000078EDB000 000034 (v01 ALASKA A M I 01072009 AMI 01000013)
[ 0.015636] ACPI: DBG2 0x0000000078EDA000 000054 (v00 ALASKA A M I 01072009 AMI 01000013)
[ 0.015638] ACPI: SSDT 0x0000000078ED8000 001B93 (v02 ALASKA UsbCTabl 00001000 INTL 20160527)
[ 0.015640] ACPI: TPM2 0x0000000078ED7000 00004C (v04 ALASKA A M I 00000001 AMI 00000000)
[ 0.015643] ACPI: BGRT 0x0000000078ED6000 000038 (v01 ALASKA A M I 01072009 AMI 00010013)
[ 0.015645] ACPI: WSMT 0x0000000078EE2000 000028 (v01 ALASKA A M I 01072009 AMI 00010013)
[ 0.015647] ACPI: FPDT 0x0000000078ED5000 000044 (v01 ALASKA CML 01072009 AMI 01000013)
[ 0.015650] ACPI: Reserving FACP table memory at [mem 0x78f3d000-0x78f3d113]
[ 0.015651] ACPI: Reserving DSDT table memory at [mem 0x78ef6000-0x78f3cdc8]
[ 0.015652] ACPI: Reserving FACS table memory at [mem 0x79143000-0x7914303f]
[ 0.015653] ACPI: Reserving MCFG table memory at [mem 0x78f41000-0x78f4103b]
[ 0.015654] ACPI: Reserving SSDT table memory at [mem 0x78f3e000-0x78f4003a]
[ 0.015655] ACPI: Reserving FIDT table memory at [mem 0x78ef5000-0x78ef509b]
[ 0.015656] ACPI: Reserving SSDT table memory at [mem 0x78ef1000-0x78ef41f8]
[ 0.015657] ACPI: Reserving SSDT table memory at [mem 0x78eed000-0x78ef0f6b]
[ 0.015658] ACPI: Reserving HPET table memory at [mem 0x78f43000-0x78f43037]
[ 0.015659] ACPI: Reserving APIC table memory at [mem 0x78f42000-0x78f42163]
[ 0.015660] ACPI: Reserving SSDT table memory at [mem 0x78eeb000-0x78eec47a]
[ 0.015661] ACPI: Reserving SSDT table memory at [mem 0x78ee6000-0x78eea619]
[ 0.015662] ACPI: Reserving NHLT table memory at [mem 0x78ee4000-0x78ee5820]
[ 0.015663] ACPI: Reserving LPIT table memory at [mem 0x78ee3000-0x78ee3093]
[ 0.015664] ACPI: Reserving SSDT table memory at [mem 0x78edf000-0x78ee171f]
[ 0.015665] ACPI: Reserving SSDT table memory at [mem 0x78edc000-0x78ede7eb]
[ 0.015666] ACPI: Reserving DBGP table memory at [mem 0x78edb000-0x78edb033]
[ 0.015667] ACPI: Reserving DBG2 table memory at [mem 0x78eda000-0x78eda053]
[ 0.015668] ACPI: Reserving SSDT table memory at [mem 0x78ed8000-0x78ed9b92]
[ 0.015669] ACPI: Reserving TPM2 table memory at [mem 0x78ed7000-0x78ed704b]
[ 0.015670] ACPI: Reserving BGRT table memory at [mem 0x78ed6000-0x78ed6037]
[ 0.015671] ACPI: Reserving WSMT table memory at [mem 0x78ee2000-0x78ee2027]
[ 0.015672] ACPI: Reserving FPDT table memory at [mem 0x78ed5000-0x78ed5043]
[ 0.015688] ACPI: Local APIC address 0xfee00000
[ 0.015973] No NUMA configuration found
[ 0.015974] Faking a node at [mem 0x0000000000000000-0x000000087e7fffff]
[ 0.015978] NODE_DATA(0) allocated [mem 0x87e7fb000-0x87e7fffff]
[ 0.016018] Zone ranges:
[ 0.016019] DMA [mem 0x0000000000001000-0x0000000000ffffff]
[ 0.016021] DMA32 [mem 0x0000000001000000-0x00000000ffffffff]
[ 0.016022] Normal [mem 0x0000000100000000-0x000000087e7fffff]
[ 0.016023] Device empty
[ 0.016024] Movable zone start for each node
[ 0.016024] Early memory node ranges
[ 0.016025] node 0: [mem 0x0000000000001000-0x000000000009dfff]
[ 0.016026] node 0: [mem 0x000000000009f000-0x000000000009ffff]
[ 0.016027] node 0: [mem 0x0000000000100000-0x000000003fffffff]
[ 0.016028] node 0: [mem 0x0000000040400000-0x0000000074b89fff]
[ 0.016029] node 0: [mem 0x0000000074b8b000-0x0000000074babfff]
[ 0.016030] node 0: [mem 0x0000000074bad000-0x0000000078613fff]
[ 0.016030] node 0: [mem 0x0000000079ffe000-0x0000000079ffefff]
[ 0.016031] node 0: [mem 0x0000000100000000-0x000000087e7fffff]
[ 0.016537] Zeroed struct page in unavailable ranges: 38479 pages
[ 0.016538] Initmem setup node 0 [mem 0x0000000000001000-0x000000087e7fffff]
[ 0.016540] On node 0 totalpages: 8350129
[ 0.016541] DMA zone: 64 pages used for memmap
[ 0.016542] DMA zone: 24 pages reserved
[ 0.016542] DMA zone: 3998 pages, LIFO batch:0
[ 0.016624] DMA32 zone: 7625 pages used for memmap
[ 0.016625] DMA32 zone: 487955 pages, LIFO batch:63
[ 0.029222] Normal zone: 122784 pages used for memmap
[ 0.029222] Normal zone: 7858176 pages, LIFO batch:63
[ 0.183404] ACPI: PM-Timer IO Port: 0x1808
[ 0.183406] ACPI: Local APIC address 0xfee00000
[ 0.183412] ACPI: LAPIC_NMI (acpi_id[0x01] high edge lint[0x1])
[ 0.183413] ACPI: LAPIC_NMI (acpi_id[0x02] high edge lint[0x1])
[ 0.183414] ACPI: LAPIC_NMI (acpi_id[0x03] high edge lint[0x1])
[ 0.183414] ACPI: LAPIC_NMI (acpi_id[0x04] high edge lint[0x1])
[ 0.183415] ACPI: LAPIC_NMI (acpi_id[0x05] high edge lint[0x1])
[ 0.183416] ACPI: LAPIC_NMI (acpi_id[0x06] high edge lint[0x1])
[ 0.183417] ACPI: LAPIC_NMI (acpi_id[0x07] high edge lint[0x1])
[ 0.183417] ACPI: LAPIC_NMI (acpi_id[0x08] high edge lint[0x1])
[ 0.183418] ACPI: LAPIC_NMI (acpi_id[0x09] high edge lint[0x1])
[ 0.183419] ACPI: LAPIC_NMI (acpi_id[0x0a] high edge lint[0x1])
[ 0.183420] ACPI: LAPIC_NMI (acpi_id[0x0b] high edge lint[0x1])
[ 0.183420] ACPI: LAPIC_NMI (acpi_id[0x0c] high edge lint[0x1])
[ 0.183421] ACPI: LAPIC_NMI (acpi_id[0x0d] high edge lint[0x1])
[ 0.183422] ACPI: LAPIC_NMI (acpi_id[0x0e] high edge lint[0x1])
[ 0.183423] ACPI: LAPIC_NMI (acpi_id[0x0f] high edge lint[0x1])
[ 0.183424] ACPI: LAPIC_NMI (acpi_id[0x10] high edge lint[0x1])
[ 0.183424] ACPI: LAPIC_NMI (acpi_id[0x11] high edge lint[0x1])
[ 0.183425] ACPI: LAPIC_NMI (acpi_id[0x12] high edge lint[0x1])
[ 0.183426] ACPI: LAPIC_NMI (acpi_id[0x13] high edge lint[0x1])
[ 0.183427] ACPI: LAPIC_NMI (acpi_id[0x14] high edge lint[0x1])
[ 0.183466] IOAPIC[0]: apic_id 2, version 32, address 0xfec00000, GSI 0-119
[ 0.183468] ACPI: INT_SRC_OVR (bus 0 bus_irq 0 global_irq 2 dfl dfl)
[ 0.183470] ACPI: INT_SRC_OVR (bus 0 bus_irq 9 global_irq 9 high level)
[ 0.183471] ACPI: IRQ0 used by override.
[ 0.183472] ACPI: IRQ9 used by override.
[ 0.183473] Using ACPI (MADT) for SMP configuration information
[ 0.183475] ACPI: HPET id: 0x8086a201 base: 0xfed00000
[ 0.183481] e820: update [mem 0x722ae000-0x7230afff] usable ==> reserved
[ 0.183491] TSC deadline timer available
[ 0.183492] smpboot: Allowing 16 CPUs, 0 hotplug CPUs
[ 0.183516] PM: Registered nosave memory: [mem 0x00000000-0x00000fff]
[ 0.183518] PM: Registered nosave memory: [mem 0x0009e000-0x0009efff]
[ 0.183520] PM: Registered nosave memory: [mem 0x000a0000-0x000fffff]
[ 0.183522] PM: Registered nosave memory: [mem 0x40000000-0x403fffff]
[ 0.183524] PM: Registered nosave memory: [mem 0x722ae000-0x7230afff]
[ 0.183525] PM: Registered nosave memory: [mem 0x73c75000-0x73c75fff]
[ 0.183527] PM: Registered nosave memory: [mem 0x74b8a000-0x74b8afff]
[ 0.183529] PM: Registered nosave memory: [mem 0x74bac000-0x74bacfff]
[ 0.183531] PM: Registered nosave memory: [mem 0x78614000-0x78e13fff]
[ 0.183532] PM: Registered nosave memory: [mem 0x78e14000-0x78f43fff]
[ 0.183532] PM: Registered nosave memory: [mem 0x78f44000-0x79143fff]
[ 0.183533] PM: Registered nosave memory: [mem 0x79144000-0x79d43fff]
[ 0.183534] PM: Registered nosave memory: [mem 0x79d44000-0x79ffdfff]
[ 0.183536] PM: Registered nosave memory: [mem 0x79fff000-0x7f7fffff]
[ 0.183537] PM: Registered nosave memory: [mem 0x7f800000-0xdfffffff]
[ 0.183537] PM: Registered nosave memory: [mem 0xe0000000-0xefffffff]
[ 0.183538] PM: Registered nosave memory: [mem 0xf0000000-0xfdffffff]
[ 0.183539] PM: Registered nosave memory: [mem 0xfe000000-0xfe010fff]
[ 0.183540] PM: Registered nosave memory: [mem 0xfe011000-0xfebfffff]
[ 0.183540] PM: Registered nosave memory: [mem 0xfec00000-0xfec00fff]
[ 0.183541] PM: Registered nosave memory: [mem 0xfec01000-0xfedfffff]
[ 0.183542] PM: Registered nosave memory: [mem 0xfee00000-0xfee00fff]
[ 0.183543] PM: Registered nosave memory: [mem 0xfee01000-0xfeffffff]
[ 0.183543] PM: Registered nosave memory: [mem 0xff000000-0xffffffff]
[ 0.183545] [mem 0x7f800000-0xdfffffff] available for PCI devices
[ 0.183546] Booting paravirtualized kernel on bare hardware
[ 0.183548] clocksource: refined-jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645519600211568 ns
[ 0.272496] setup_percpu: NR_CPUS:512 nr_cpumask_bits:512 nr_cpu_ids:16 nr_node_ids:1
[ 0.272821] percpu: Embedded 50 pages/cpu s165208 r8192 d31400 u262144
[ 0.272828] pcpu-alloc: s165208 r8192 d31400 u262144 alloc=1*2097152
[ 0.272829] pcpu-alloc: [0] 00 01 02 03 04 05 06 07 [0] 08 09 10 11 12 13 14 15
[ 0.272852] Built 1 zonelists, mobility grouping on. Total pages: 8219632
[ 0.272853] Policy zone: Normal
[ 0.272855] Kernel command line: BOOT_IMAGE=/boot/vmlinuz-4.19.0-25-amd64 root=UUID=4e032d92-8422-4025-8ede-24048075943c ro splash pci=realloc
[ 0.276431] Calgary: detecting Calgary via BIOS EBDA area
[ 0.276433] Calgary: Unable to locate Rio Grande table in EBDA - bailing!
[ 0.337055] Memory: 32618640K/33400516K available (10252K kernel code, 1235K rwdata, 3188K rodata, 1620K init, 2220K bss, 781876K reserved, 0K cma-reserved)
[ 0.337453] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=16, Nodes=1
[ 0.337459] ftrace: allocating 32071 entries in 126 pages
[ 0.348684] rcu: Hierarchical RCU implementation.
[ 0.348686] rcu: RCU restricting CPUs from NR_CPUS=512 to nr_cpu_ids=16.
[ 0.348687] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=16
[ 0.351463] NR_IRQS: 33024, nr_irqs: 2184, preallocated irqs: 16
[ 0.351855] random: crng init done
[ 0.351876] Console: colour dummy device 80x25
[ 0.352116] console [tty0] enabled
[ 0.352133] ACPI: Core revision 20180810
[ 0.352530] clocksource: hpet: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 79635855245 ns
[ 0.352570] hpet clockevent registered
[ 0.352623] APIC: Switch to symmetric I/O mode setup
[ 0.354234] x2apic: IRQ remapping doesn't support X2APIC mode
[ 0.354511] Switched APIC routing to physical flat.
[ 0.360017] ..TIMER: vector=0x30 apic1=0 pin1=2 apic2=-1 pin2=-1
[ 0.376620] clocksource: tsc-early: mask: 0xffffffffffffffff max_cycles: 0x29cd42e80b2, max_idle_ns: 440795228349 ns
[ 0.376632] Calibrating delay loop (skipped), value calculated using timer frequency.. 5800.00 BogoMIPS (lpj=11600000)
[ 0.376677] CPU0: Thermal monitoring enabled (TM1)
[ 0.376703] process: using mwait in idle threads
[ 0.376706] Last level iTLB entries: 4KB 64, 2MB 8, 4MB 8
[ 0.376707] Last level dTLB entries: 4KB 64, 2MB 0, 4MB 0, 1GB 4
[ 0.376710] Spectre V1 : Mitigation: usercopy/swapgs barriers and __user pointer sanitization
[ 0.376712] Spectre V2 : Mitigation: Enhanced IBRS
[ 0.376714] Spectre V2 : Spectre v2 / SpectreRSB mitigation: Filling RSB on context switch
[ 0.376715] Spectre V2 : Spectre v2 / PBRSB-eIBRS: Retire a single CALL on VMEXIT
[ 0.376717] RETBleed: Mitigation: Enhanced IBRS
[ 0.376722] Spectre V2 : mitigation: Enabling conditional Indirect Branch Prediction Barrier
[ 0.376724] Speculative Store Bypass: Mitigation: Speculative Store Bypass disabled via prctl and seccomp
[ 0.376754] MMIO Stale Data: Mitigation: Clear CPU buffers
[ 0.376757] SRBDS: Mitigation: Microcode
[ 0.376759] GDS: Mitigation: Microcode
[ 0.376772] x86/fpu: Supporting XSAVE feature 0x001: 'x87 floating point registers'
[ 0.376774] x86/fpu: Supporting XSAVE feature 0x002: 'SSE registers'
[ 0.376776] x86/fpu: Supporting XSAVE feature 0x004: 'AVX registers'
[ 0.376777] x86/fpu: Supporting XSAVE feature 0x008: 'MPX bounds registers'
[ 0.376779] x86/fpu: Supporting XSAVE feature 0x010: 'MPX CSR'
[ 0.376780] x86/fpu: Supporting XSAVE feature 0x200: 'Protection Keys User registers'
[ 0.376784] x86/fpu: xstate_offset[2]: 576, xstate_sizes[2]: 256
[ 0.376785] x86/fpu: xstate_offset[3]: 832, xstate_sizes[3]: 64
[ 0.376787] x86/fpu: xstate_offset[4]: 896, xstate_sizes[4]: 64
[ 0.376789] x86/fpu: xstate_offset[9]: 960, xstate_sizes[9]: 8
[ 0.376790] x86/fpu: Enabled xstate features 0x21f, context size is 968 bytes, using 'compacted' format.
[ 0.379719] Freeing SMP alternatives memory: 24K
[ 0.381045] pid_max: default: 32768 minimum: 301
[ 0.381873] Security Framework initialized
[ 0.381875] Yama: disabled by default; enable with sysctl kernel.yama.*
[ 0.381891] AppArmor: AppArmor initialized
[ 0.384567] Dentry cache hash table entries: 4194304 (order: 13, 33554432 bytes)
[ 0.385892] Inode-cache hash table entries: 2097152 (order: 12, 16777216 bytes)
[ 0.385947] Mount-cache hash table entries: 65536 (order: 7, 524288 bytes)
[ 0.385991] Mountpoint-cache hash table entries: 65536 (order: 7, 524288 bytes)
[ 0.388677] smpboot: CPU0: Intel(R) Core(TM) i7-10700 CPU @ 2.90GHz (family: 0x6, model: 0xa5, stepping: 0x5)
[ 0.388749] Performance Events: PEBS fmt3+, generic architected perfmon, full-width counters, Intel PMU driver.
[ 0.388755] ... version: 4
[ 0.388756] ... bit width: 48
[ 0.388757] ... generic registers: 4
[ 0.388758] ... value mask: 0000ffffffffffff
[ 0.388760] ... max period: 00007fffffffffff
[ 0.388761] ... fixed-purpose events: 3
[ 0.388762] ... event mask: 000000070000000f
[ 0.388797] rcu: Hierarchical SRCU implementation.
[ 0.389621] NMI watchdog: Enabled. Permanently consumes one hw-PMU counter.
[ 0.389702] smp: Bringing up secondary CPUs ...
[ 0.389754] x86: Booting SMP configuration:
[ 0.389756] .... node #0, CPUs: #1 #2 #3 #4 #5 #6 #7 #8
[ 0.405484] MMIO Stale Data CPU bug present and SMT on, data leak possible. See https://www.kernel.org/doc/html/latest/admin-guide/hw-vuln/processor_mmio_stale_data.html for more details.
[ 0.405484] #9 #10 #11 #12 #13 #14 #15
[ 0.409304] smp: Brought up 1 node, 16 CPUs
[ 0.409304] smpboot: Max logical packages: 1
[ 0.409304] smpboot: Total of 16 processors activated (92800.00 BogoMIPS)
[ 0.413309] devtmpfs: initialized
[ 0.413309] x86/mm: Memory block size: 128MB
[ 0.416629] PM: Registering ACPI NVS region [mem 0x74b8a000-0x74b8afff] (4096 bytes)
[ 0.416632] PM: Registering ACPI NVS region [mem 0x78f44000-0x79143fff] (2097152 bytes)
[ 0.416687] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[ 0.416702] futex hash table entries: 4096 (order: 6, 262144 bytes)
[ 0.416752] pinctrl core: initialized pinctrl subsystem
[ 0.416873] NET: Registered protocol family 16
[ 0.416935] audit: initializing netlink subsys (disabled)
[ 0.416941] audit: type=2000 audit(1692894893.064:1): state=initialized audit_enabled=0 res=1
[ 0.416941] cpuidle: using governor ladder
[ 0.416941] cpuidle: using governor menu
[ 0.416941] ACPI FADT declares the system doesn't support PCIe ASPM, so disable it
[ 0.416941] ACPI: bus type PCI registered
[ 0.416941] acpiphp: ACPI Hot Plug PCI Controller Driver version: 0.5
[ 0.416941] PCI: MMCONFIG for domain 0000 [bus 00-ff] at [mem 0xe0000000-0xefffffff] (base 0xe0000000)
[ 0.416941] PCI: MMCONFIG at [mem 0xe0000000-0xefffffff] reserved in E820
[ 0.416941] PCI: Using configuration type 1 for base access
[ 0.417594] HugeTLB registered 1.00 GiB page size, pre-allocated 0 pages
[ 0.417594] HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages
[ 0.417594] ACPI: Added _OSI(Module Device)
[ 0.417594] ACPI: Added _OSI(Processor Device)
[ 0.417594] ACPI: Added _OSI(3.0 _SCP Extensions)
[ 0.417594] ACPI: Added _OSI(Processor Aggregator Device)
[ 0.417594] ACPI: Added _OSI(Linux-Dell-Video)
[ 0.417594] ACPI: Added _OSI(Linux-Lenovo-NV-HDMI-Audio)
[ 0.474972] ACPI: 9 ACPI AML tables successfully acquired and loaded
[ 0.481331] ACPI: Dynamic OEM Table Load:
[ 0.481343] ACPI: SSDT 0xFFFF8BB79A3A1000 0000FC (v02 PmRef Cpu0Psd 00003000 INTL 20160527)
[ 0.481565] ACPI: \_SB_.PR00: _OSC native thermal LVT Acked
[ 0.482411] ACPI: Dynamic OEM Table Load:
[ 0.482417] ACPI: SSDT 0xFFFF8BB79A316000 000444 (v02 PmRef Cpu0Cst 00003001 INTL 20160527)
[ 0.482733] ACPI: Dynamic OEM Table Load:
[ 0.482739] ACPI: SSDT 0xFFFF8BB79A311000 0005E4 (v02 PmRef Cpu0Ist 00003000 INTL 20160527)
[ 0.483107] ACPI: Dynamic OEM Table Load:
[ 0.483112] ACPI: SSDT 0xFFFF8BB79A3B9200 0001B2 (v02 PmRef Cpu0Hwp 00003000 INTL 20160527)
[ 0.483358] ACPI: Dynamic OEM Table Load:
[ 0.483364] ACPI: SSDT 0xFFFF8BB79DD21000 000BEA (v02 PmRef HwpLvt 00003000 INTL 20160527)
[ 0.483781] ACPI: Dynamic OEM Table Load:
[ 0.483787] ACPI: SSDT 0xFFFF8BB79A314800 000778 (v02 PmRef ApIst 00003000 INTL 20160527)
[ 0.484176] ACPI: Dynamic OEM Table Load:
[ 0.484181] ACPI: SSDT 0xFFFF8BB79A35DC00 0003D7 (v02 PmRef ApHwp 00003000 INTL 20160527)
[ 0.484541] ACPI: Dynamic OEM Table Load:
[ 0.484546] ACPI: SSDT 0xFFFF8BB79DD20000 000D22 (v02 PmRef ApPsd 00003000 INTL 20160527)
[ 0.485349] ACPI: Dynamic OEM Table Load:
[ 0.485355] ACPI: SSDT 0xFFFF8BB79A35BC00 0003CA (v02 PmRef ApCst 00003000 INTL 20160527)
[ 0.490499] ACPI: Interpreter enabled
[ 0.490538] ACPI: (supports S0 S3 S4 S5)
[ 0.490540] ACPI: Using IOAPIC for interrupt routing
[ 0.490573] PCI: Using host bridge windows from ACPI; if necessary, use "pci=nocrs" and report a bug
[ 0.491152] ACPI: Enabled 7 GPEs in block 00 to 7F
[ 0.491792] ACPI: Power Resource [PG02] (on)
[ 0.492250] ACPI: Power Resource [PG03] (on)
[ 0.503405] ACPI: Power Resource [USBC] (off)
[ 0.505805] ACPI: Power Resource [V0PR] (on)
[ 0.505968] ACPI: Power Resource [V1PR] (on)
[ 0.506122] ACPI: Power Resource [V2PR] (on)
[ 0.511974] ACPI: Power Resource [WRST] (on)
[ 0.517141] ACPI: Power Resource [FN00] (off)
[ 0.517205] ACPI: Power Resource [FN01] (off)
[ 0.517265] ACPI: Power Resource [FN02] (off)
[ 0.517323] ACPI: Power Resource [FN03] (off)
[ 0.517381] ACPI: Power Resource [FN04] (off)
[ 0.517887] ACPI: Power Resource [PIN] (off)
[ 0.518252] ACPI: PCI Root Bridge [PCI0] (domain 0000 [bus 00-fe])
[ 0.518258] acpi PNP0A08:00: _OSC: OS supports [ExtendedConfig ASPM ClockPM Segments MSI]
[ 0.518426] acpi PNP0A08:00: _OSC: platform does not support [PCIeHotplug SHPCHotplug PME AER]
[ 0.518584] acpi PNP0A08:00: _OSC: OS now controls [PCIeCapability LTR]
[ 0.518586] acpi PNP0A08:00: FADT indicates ASPM is unsupported, using BIOS configuration
[ 0.519438] PCI host bridge to bus 0000:00
[ 0.519441] pci_bus 0000:00: root bus resource [io 0x0000-0x0cf7 window]
[ 0.519443] pci_bus 0000:00: root bus resource [io 0x0d00-0xffff window]
[ 0.519445] pci_bus 0000:00: root bus resource [mem 0x000a0000-0x000bffff window]
[ 0.519447] pci_bus 0000:00: root bus resource [mem 0x000e0000-0x000e3fff window]
[ 0.519449] pci_bus 0000:00: root bus resource [mem 0x000e4000-0x000e7fff window]
[ 0.519450] pci_bus 0000:00: root bus resource [mem 0x000e8000-0x000ebfff window]
[ 0.519452] pci_bus 0000:00: root bus resource [mem 0x000ec000-0x000effff window]
[ 0.519454] pci_bus 0000:00: root bus resource [mem 0x000f0000-0x000fffff window]
[ 0.519456] pci_bus 0000:00: root bus resource [mem 0x7f800000-0xdfffffff window]
[ 0.519458] pci_bus 0000:00: root bus resource [mem 0x4000000000-0x7fffffffff window]
[ 0.519460] pci_bus 0000:00: root bus resource [mem 0xfc800000-0xfe7fffff window]
[ 0.519462] pci_bus 0000:00: root bus resource [bus 00-fe]
[ 0.519471] pci 0000:00:00.0: [8086:9b43] type 00 class 0x060000
[ 0.519811] pci 0000:00:01.0: [8086:1901] type 01 class 0x060400
[ 0.519849] pci 0000:00:01.0: PME# supported from D0 D3hot D3cold
[ 0.520050] pci 0000:00:02.0: [8086:9bc5] type 00 class 0x030000
[ 0.520059] pci 0000:00:02.0: reg 0x10: [mem 0x6002000000-0x6002ffffff 64bit]
[ 0.520063] pci 0000:00:02.0: reg 0x18: [mem 0x4000000000-0x400fffffff 64bit pref]
[ 0.520066] pci 0000:00:02.0: reg 0x20: [io 0x4000-0x403f]
[ 0.520080] pci 0000:00:02.0: BAR 2: assigned to efifb
[ 0.520229] pci 0000:00:08.0: [8086:1911] type 00 class 0x088000
[ 0.520238] pci 0000:00:08.0: reg 0x10: [mem 0x600312a000-0x600312afff 64bit]
[ 0.520410] pci 0000:00:12.0: [8086:06f9] type 00 class 0x118000
[ 0.520429] pci 0000:00:12.0: reg 0x10: [mem 0x6003129000-0x6003129fff 64bit]
[ 0.520613] pci 0000:00:12.6: [8086:06fb] type 00 class 0x0c8000
[ 0.520634] pci 0000:00:12.6: reg 0x10: [mem 0x6003128000-0x6003128fff 64bit]
[ 0.520645] pci 0000:00:12.6: reg 0x18: [mem 0x6003127000-0x6003127fff 64bit]
[ 0.520811] pci 0000:00:14.0: [8086:06ed] type 00 class 0x0c0330
[ 0.520828] pci 0000:00:14.0: reg 0x10: [mem 0x6003100000-0x600310ffff 64bit]
[ 0.520883] pci 0000:00:14.0: PME# supported from D3hot D3cold
[ 0.521074] pci 0000:00:14.2: [8086:06ef] type 00 class 0x050000
[ 0.521092] pci 0000:00:14.2: reg 0x10: [mem 0x6003114000-0x6003115fff 64bit]
[ 0.521102] pci 0000:00:14.2: reg 0x18: [mem 0x6003126000-0x6003126fff 64bit]
[ 0.521264] pci 0000:00:15.0: [8086:06e8] type 00 class 0x0c8000
[ 0.521283] pci 0000:00:15.0: reg 0x10: [mem 0x00000000-0x00000fff 64bit]
[ 0.521443] pci 0000:00:15.1: [8086:06e9] type 00 class 0x0c8000
[ 0.521464] pci 0000:00:15.1: reg 0x10: [mem 0x6003124000-0x6003124fff 64bit]
[ 0.521475] pci 0000:00:15.1: reg 0x18: [mem 0x6003123000-0x6003123fff 64bit]
[ 0.521628] pci 0000:00:15.2: [8086:06ea] type 00 class 0x0c8000
[ 0.521648] pci 0000:00:15.2: reg 0x10: [mem 0x6003122000-0x6003122fff 64bit]
[ 0.521659] pci 0000:00:15.2: reg 0x18: [mem 0x6003121000-0x6003121fff 64bit]
[ 0.521811] pci 0000:00:15.3: [8086:06eb] type 00 class 0x0c8000
[ 0.521831] pci 0000:00:15.3: reg 0x10: [mem 0x6003120000-0x6003120fff 64bit]
[ 0.521842] pci 0000:00:15.3: reg 0x18: [mem 0x600311f000-0x600311ffff 64bit]
[ 0.522015] pci 0000:00:16.0: [8086:06e0] type 00 class 0x078000
[ 0.522040] pci 0000:00:16.0: reg 0x10: [mem 0x600311e000-0x600311efff 64bit]
[ 0.522111] pci 0000:00:16.0: PME# supported from D3hot
[ 0.522325] pci 0000:00:17.0: [8086:06d2] type 00 class 0x010601
[ 0.522340] pci 0000:00:17.0: reg 0x10: [mem 0x81200000-0x81201fff]
[ 0.522346] pci 0000:00:17.0: reg 0x14: [mem 0x81203000-0x812030ff]
[ 0.522352] pci 0000:00:17.0: reg 0x18: [io 0x4090-0x4097]
[ 0.522358] pci 0000:00:17.0: reg 0x1c: [io 0x4080-0x4083]
[ 0.522364] pci 0000:00:17.0: reg 0x20: [io 0x4060-0x407f]
[ 0.522370] pci 0000:00:17.0: reg 0x24: [mem 0x81202000-0x812027ff]
[ 0.522405] pci 0000:00:17.0: PME# supported from D3hot
[ 0.522570] pci 0000:00:1c.0: [8086:06b8] type 01 class 0x060400
[ 0.522645] pci 0000:00:1c.0: PME# supported from D0 D3hot D3cold
[ 0.522832] pci 0000:00:1c.4: [8086:06bc] type 01 class 0x060400
[ 0.522905] pci 0000:00:1c.4: PME# supported from D0 D3hot D3cold
[ 0.522920] pci 0000:00:1c.4: PTM enabled (root), 4ns granularity
[ 0.523098] pci 0000:00:1d.0: [8086:06b0] type 01 class 0x060400
[ 0.523171] pci 0000:00:1d.0: PME# supported from D0 D3hot D3cold
[ 0.523185] pci 0000:00:1d.0: PTM enabled (root), 4ns granularity
[ 0.523386] pci 0000:00:1e.0: [8086:06a8] type 00 class 0x078000
[ 0.523406] pci 0000:00:1e.0: reg 0x10: [mem 0x00000000-0x00000fff 64bit]
[ 0.523596] pci 0000:00:1e.1: [8086:06a9] type 00 class 0x078000
[ 0.523615] pci 0000:00:1e.1: reg 0x10: [mem 0x600311c000-0x600311cfff 64bit]
[ 0.523624] pci 0000:00:1e.1: reg 0x18: [mem 0x600311b000-0x600311bfff 64bit]
[ 0.523803] pci 0000:00:1e.2: [8086:06aa] type 00 class 0x0c8000
[ 0.523823] pci 0000:00:1e.2: reg 0x10: [mem 0x600311a000-0x600311afff 64bit]
[ 0.523834] pci 0000:00:1e.2: reg 0x18: [mem 0x6003119000-0x6003119fff 64bit]
[ 0.523988] pci 0000:00:1e.3: [8086:06ab] type 00 class 0x0c8000
[ 0.524008] pci 0000:00:1e.3: reg 0x10: [mem 0x6003118000-0x6003118fff 64bit]
[ 0.524019] pci 0000:00:1e.3: reg 0x18: [mem 0x6003117000-0x6003117fff 64bit]
[ 0.524192] pci 0000:00:1f.0: [8086:0685] type 00 class 0x060100
[ 0.524400] pci 0000:00:1f.3: [8086:06c8] type 00 class 0x040300
[ 0.524439] pci 0000:00:1f.3: reg 0x10: [mem 0x6003110000-0x6003113fff 64bit]
[ 0.524475] pci 0000:00:1f.3: reg 0x20: [mem 0x6003000000-0x60030fffff 64bit]
[ 0.524552] pci 0000:00:1f.3: PME# supported from D3hot D3cold
[ 0.524841] pci 0000:00:1f.4: [8086:06a3] type 00 class 0x0c0500
[ 0.524859] pci 0000:00:1f.4: reg 0x10: [mem 0x6003116000-0x60031160ff 64bit]
[ 0.524886] pci 0000:00:1f.4: reg 0x20: [io 0xefa0-0xefbf]
[ 0.525049] pci 0000:00:1f.5: [8086:06a4] type 00 class 0x0c8000
[ 0.525063] pci 0000:00:1f.5: reg 0x10: [mem 0xfe010000-0xfe010fff]
[ 0.525245] pci 0000:01:00.0: [10de:20b5] type 00 class 0x030200
[ 0.525258] pci 0000:01:00.0: reg 0x10: [mem 0x80000000-0x80ffffff]
[ 0.525264] pci 0000:01:00.0: reg 0x14: [mem 0xffffffe000000000-0xffffffffffffffff 64bit pref]
[ 0.525270] pci 0000:01:00.0: reg 0x1c: [mem 0x6000000000-0x6001ffffff 64bit pref]
[ 0.525287] pci 0000:01:00.0: Enabling HDA controller
[ 0.525321] pci 0000:01:00.0: PME# supported from D0 D3hot
[ 0.525334] pci 0000:01:00.0: reg 0xbf0: [mem 0x00000000-0x0003ffff]
[ 0.525335] pci 0000:01:00.0: VF(n) BAR0 space: [mem 0x00000000-0x004fffff] (contains BAR0 for 20 VFs)
[ 0.525341] pci 0000:01:00.0: reg 0xbf4: [mem 0x00000000-0xffffffff 64bit pref]
[ 0.525342] pci 0000:01:00.0: VF(n) BAR1 space: [mem 0x00000000-0x13ffffffff 64bit pref] (contains BAR1 for 20 VFs)
[ 0.525348] pci 0000:01:00.0: reg 0xbfc: [mem 0x00000000-0x01ffffff 64bit pref]
[ 0.525349] pci 0000:01:00.0: VF(n) BAR3 space: [mem 0x00000000-0x27ffffff 64bit pref] (contains BAR3 for 20 VFs)
[ 0.525387] pci 0000:01:00.0: 126.016 Gb/s available PCIe bandwidth, limited by 8 GT/s x16 link at 0000:00:01.0 (capable of 252.048 Gb/s with 16 GT/s x16 link)
[ 0.525420] pci 0000:00:01.0: PCI bridge to [bus 01]
[ 0.525424] pci 0000:00:01.0: bridge window [mem 0x80000000-0x80ffffff]
[ 0.525426] pci 0000:00:01.0: bridge window [mem 0x6000000000-0x6001ffffff 64bit pref]
[ 0.525528] acpiphp: Slot [1] registered
[ 0.525540] pci 0000:00:1c.0: PCI bridge to [bus 02]
[ 0.525639] pci 0000:03:00.0: [10ec:8125] type 00 class 0x020000
[ 0.525669] pci 0000:03:00.0: reg 0x10: [io 0x3000-0x30ff]
[ 0.525688] pci 0000:03:00.0: reg 0x18: [mem 0x81100000-0x8110ffff 64bit]
[ 0.525701] pci 0000:03:00.0: reg 0x20: [mem 0x81110000-0x81113fff 64bit]
[ 0.525795] pci 0000:03:00.0: supports D1 D2
[ 0.525795] pci 0000:03:00.0: PME# supported from D0 D1 D2 D3hot D3cold
[ 0.525905] pci 0000:00:1c.4: PCI bridge to [bus 03]
[ 0.525908] pci 0000:00:1c.4: bridge window [io 0x3000-0x3fff]
[ 0.525910] pci 0000:00:1c.4: bridge window [mem 0x81100000-0x811fffff]
[ 0.526003] pci 0000:04:00.0: [144d:a808] type 00 class 0x010802
[ 0.526031] pci 0000:04:00.0: reg 0x10: [mem 0x81000000-0x81003fff 64bit]
[ 0.526212] pci 0000:00:1d.0: PCI bridge to [bus 04]
[ 0.526217] pci 0000:00:1d.0: bridge window [mem 0x81000000-0x810fffff]
[ 0.527953] ACPI: PCI Interrupt Link [LNKA] (IRQs 3 4 5 6 10 11 12 14 15) *0
[ 0.528040] ACPI: PCI Interrupt Link [LNKB] (IRQs 3 4 5 6 10 11 12 14 15) *1
[ 0.528123] ACPI: PCI Interrupt Link [LNKC] (IRQs 3 4 5 6 10 11 12 14 15) *0
[ 0.528206] ACPI: PCI Interrupt Link [LNKD] (IRQs 3 4 5 6 10 11 12 14 15) *0
[ 0.528289] ACPI: PCI Interrupt Link [LNKE] (IRQs 3 4 5 6 10 11 12 14 15) *0
[ 0.528371] ACPI: PCI Interrupt Link [LNKF] (IRQs 3 4 5 6 10 11 12 14 15) *0
[ 0.528454] ACPI: PCI Interrupt Link [LNKG] (IRQs 3 4 5 6 10 11 12 14 15) *0
[ 0.528536] ACPI: PCI Interrupt Link [LNKH] (IRQs 3 4 5 6 10 11 12 14 15) *0
[ 0.529053] pci 0000:00:02.0: vgaarb: setting as boot VGA device
[ 0.529053] pci 0000:00:02.0: vgaarb: VGA device added: decodes=io+mem,owns=io+mem,locks=none
[ 0.529053] pci 0000:00:02.0: vgaarb: bridge control possible
[ 0.529053] vgaarb: loaded
[ 0.529053] pps_core: LinuxPPS API ver. 1 registered
[ 0.529053] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[ 0.529053] PTP clock support registered
[ 0.529053] EDAC MC: Ver: 3.0.0
[ 0.529053] Registered efivars operations
[ 0.529053] PCI: Using ACPI for IRQ routing
[ 0.572298] PCI: pci_cache_line_size set to 64 bytes
[ 0.572351] pci 0000:01:00.0: can't claim BAR 1 [mem 0xffffffe000000000-0xffffffffffffffff 64bit pref]: no compatible bridge window
[ 0.572395] e820: reserve RAM buffer [mem 0x0009e000-0x0009ffff]
[ 0.572396] e820: reserve RAM buffer [mem 0x722ae000-0x73ffffff]
[ 0.572397] e820: reserve RAM buffer [mem 0x73c75000-0x73ffffff]
[ 0.572397] e820: reserve RAM buffer [mem 0x74b8a000-0x77ffffff]
[ 0.572398] e820: reserve RAM buffer [mem 0x74bac000-0x77ffffff]
[ 0.572399] e820: reserve RAM buffer [mem 0x78614000-0x7bffffff]
[ 0.572399] e820: reserve RAM buffer [mem 0x79fff000-0x7bffffff]
[ 0.572400] e820: reserve RAM buffer [mem 0x87e800000-0x87fffffff]
[ 0.573740] hpet0: at MMIO 0xfed00000, IRQs 2, 8, 0, 0, 0, 0, 0, 0
[ 0.573744] hpet0: 8 comparators, 64-bit 24.000000 MHz counter
[ 0.575799] clocksource: Switched to clocksource tsc-early
[ 0.577453] VFS: Disk quotas dquot_6.6.0
[ 0.577453] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[ 0.577453] AppArmor: AppArmor Filesystem Enabled
[ 0.577453] pnp: PnP ACPI init
[ 0.577453] pnp 00:00: disabling [mem 0x40000000-0x403fffff] because it overlaps 0000:01:00.0 BAR 8 [mem 0x00000000-0x13ffffffff 64bit pref]
[ 0.577453] system 00:00: Plug and Play ACPI device, IDs PNP0c02 (active)
[ 0.577453] system 00:01: [io 0x0a00-0x0a0f] has been reserved
[ 0.577453] system 00:01: [io 0x0a10-0x0a1f] has been reserved
[ 0.577453] system 00:01: [io 0x0a20-0x0a2f] has been reserved
[ 0.577453] system 00:01: Plug and Play ACPI device, IDs PNP0c02 (active)
[ 0.577453] pnp 00:02: [dma 0 disabled]
[ 0.577453] pnp 00:02: Plug and Play ACPI device, IDs PNP0501 (active)
[ 0.577453] system 00:03: [io 0x0680-0x069f] has been reserved
[ 0.577453] system 00:03: [io 0x164e-0x164f] has been reserved
[ 0.577453] system 00:03: Plug and Play ACPI device, IDs PNP0c02 (active)
[ 0.577453] system 00:04: [io 0x1854-0x1857] has been reserved
[ 0.577453] system 00:04: Plug and Play ACPI device, IDs INT3f0d PNP0c02 (active)
[ 0.577453] pnp 00:05: disabling [mem 0xfd000000-0xfd69ffff] because it overlaps 0000:01:00.0 BAR 8 [mem 0x00000000-0x13ffffffff 64bit pref]
[ 0.580630] pnp 00:05: disabling [mem 0xfd6c0000-0xfd6cffff] because it overlaps 0000:01:00.0 BAR 8 [mem 0x00000000-0x13ffffffff 64bit pref]
[ 0.580632] pnp 00:05: disabling [mem 0xfd6f0000-0xfdffffff] because it overlaps 0000:01:00.0 BAR 8 [mem 0x00000000-0x13ffffffff 64bit pref]
[ 0.580635] pnp 00:05: disabling [mem 0xfe000000-0xfe01ffff] because it overlaps 0000:01:00.0 BAR 8 [mem 0x00000000-0x13ffffffff 64bit pref]
[ 0.580637] pnp 00:05: disabling [mem 0xfe200000-0xfe7fffff] because it overlaps 0000:01:00.0 BAR 8 [mem 0x00000000-0x13ffffffff 64bit pref]
[ 0.580640] pnp 00:05: disabling [mem 0xff000000-0xffffffff] because it overlaps 0000:01:00.0 BAR 8 [mem 0x00000000-0x13ffffffff 64bit pref]
[ 0.580659] system 00:05: [io 0x1800-0x18fe] could not be reserved
[ 0.580663] system 00:05: Plug and Play ACPI device, IDs PNP0c02 (active)
[ 0.580933] system 00:06: [io 0x2000-0x20fe] has been reserved
[ 0.580937] system 00:06: Plug and Play ACPI device, IDs PNP0c02 (active)
[ 0.581153] pnp 00:07: disabling [mem 0xfd6e0000-0xfd6effff] because it overlaps 0000:01:00.0 BAR 8 [mem 0x00000000-0x13ffffffff 64bit pref]
[ 0.581156] pnp 00:07: disabling [mem 0xfd6d0000-0xfd6dffff] because it overlaps 0000:01:00.0 BAR 8 [mem 0x00000000-0x13ffffffff 64bit pref]
[ 0.581158] pnp 00:07: disabling [mem 0xfd6b0000-0xfd6bffff] because it overlaps 0000:01:00.0 BAR 8 [mem 0x00000000-0x13ffffffff 64bit pref]
[ 0.581161] pnp 00:07: disabling [mem 0xfd6a0000-0xfd6affff] because it overlaps 0000:01:00.0 BAR 8 [mem 0x00000000-0x13ffffffff 64bit pref]
[ 0.581181] system 00:07: Plug and Play ACPI device, IDs PNP0c02 (active)
[ 0.581710] pnp 00:08: disabling [mem 0xfed10000-0xfed17fff] because it overlaps 0000:01:00.0 BAR 8 [mem 0x00000000-0x13ffffffff 64bit pref]
[ 0.581713] pnp 00:08: disabling [mem 0xfed18000-0xfed18fff] because it overlaps 0000:01:00.0 BAR 8 [mem 0x00000000-0x13ffffffff 64bit pref]
[ 0.581715] pnp 00:08: disabling [mem 0xfed19000-0xfed19fff] because it overlaps 0000:01:00.0 BAR 8 [mem 0x00000000-0x13ffffffff 64bit pref]
[ 0.581718] pnp 00:08: disabling [mem 0xe0000000-0xefffffff] because it overlaps 0000:01:00.0 BAR 8 [mem 0x00000000-0x13ffffffff 64bit pref]
[ 0.581720] pnp 00:08: disabling [mem 0xfed20000-0xfed7ffff] because it overlaps 0000:01:00.0 BAR 8 [mem 0x00000000-0x13ffffffff 64bit pref]
[ 0.581723] pnp 00:08: disabling [mem 0xfed90000-0xfed93fff] because it overlaps 0000:01:00.0 BAR 8 [mem 0x00000000-0x13ffffffff 64bit pref]
[ 0.581725] pnp 00:08: disabling [mem 0xfee00000-0xfeefffff] because it overlaps 0000:01:00.0 BAR 8 [mem 0x00000000-0x13ffffffff 64bit pref]
[ 0.581745] system 00:08: Plug and Play ACPI device, IDs PNP0c02 (active)
[ 0.582038] pnp 00:09: disabling [mem 0xfe038000-0xfe038fff] because it overlaps 0000:01:00.0 BAR 8 [mem 0x00000000-0x13ffffffff 64bit pref]
[ 0.582058] system 00:09: Plug and Play ACPI device, IDs PNP0c02 (active)
[ 0.582437] pnp: PnP ACPI: found 10 devices
[ 0.587778] clocksource: acpi_pm: mask: 0xffffff max_cycles: 0xffffff, max_idle_ns: 2085701024 ns
[ 0.587783] pci_bus 0000:00: max bus depth: 1 pci_try_num: 2
[ 0.587792] pci 0000:00:15.0: BAR 0: assigned [mem 0x4010000000-0x4010000fff 64bit]
[ 0.587805] pci 0000:00:1e.0: BAR 0: assigned [mem 0x4010001000-0x4010001fff 64bit]
[ 0.587816] pci 0000:01:00.0: BAR 1: no space for [mem size 0x2000000000 64bit pref]
[ 0.587818] pci 0000:01:00.0: BAR 1: failed to assign [mem 0xffffffe000000000-0xffffffffffffffff 64bit pref]
[ 0.587821] pci 0000:01:00.0: BAR 8: no space for [mem size 0x1400000000 64bit pref]
[ 0.587823] pci 0000:01:00.0: BAR 8: failed to assign [mem size 0x1400000000 64bit pref]
[ 0.587826] pci 0000:01:00.0: BAR 10: no space for [mem size 0x28000000 64bit pref]
[ 0.587827] pci 0000:01:00.0: BAR 10: failed to assign [mem size 0x28000000 64bit pref]
[ 0.587830] pci 0000:01:00.0: BAR 7: no space for [mem size 0x00500000]
[ 0.587831] pci 0000:01:00.0: BAR 7: failed to assign [mem size 0x00500000]
[ 0.587833] pci 0000:00:01.0: PCI bridge to [bus 01]
[ 0.587836] pci 0000:00:01.0: bridge window [mem 0x80000000-0x80ffffff]
[ 0.587839] pci 0000:00:01.0: bridge window [mem 0x6000000000-0x6001ffffff 64bit pref]
[ 0.587843] pci 0000:00:1c.0: PCI bridge to [bus 02]
[ 0.587859] pci 0000:00:1c.4: PCI bridge to [bus 03]
[ 0.587861] pci 0000:00:1c.4: bridge window [io 0x3000-0x3fff]
[ 0.587865] pci 0000:00:1c.4: bridge window [mem 0x81100000-0x811fffff]
[ 0.587871] pci 0000:00:1d.0: PCI bridge to [bus 04]
[ 0.587874] pci 0000:00:1d.0: bridge window [mem 0x81000000-0x810fffff]
[ 0.587881] pci_bus 0000:00: No. 2 try to assign unassigned res
[ 0.587881] release child resource [mem 0x80000000-0x80ffffff]
[ 0.587882] pci 0000:00:01.0: resource 14 [mem 0x80000000-0x80ffffff] released
[ 0.587883] pci 0000:00:01.0: PCI bridge to [bus 01]
[ 0.587885] release child resource [mem 0x6000000000-0x6001ffffff 64bit pref]
[ 0.587886] pci 0000:00:01.0: resource 15 [mem 0x6000000000-0x6001ffffff 64bit pref] released
[ 0.587887] pci 0000:00:01.0: PCI bridge to [bus 01]
[ 0.587892] pci 0000:00:01.0: bridge window [mem 0x1000000000-0x3fffffffff 64bit pref] to [bus 01] add_size 1000000000 add_align 1000000000
[ 0.587893] pci 0000:00:01.0: bridge window [mem 0x01000000-0x01ffffff] to [bus 01] add_size 1000000 add_align 1000000
[ 0.587901] pci 0000:00:01.0: BAR 15: no space for [mem size 0x4000000000 64bit pref]
[ 0.587903] pci 0000:00:01.0: BAR 15: failed to assign [mem size 0x4000000000 64bit pref]
[ 0.587906] pci 0000:00:01.0: BAR 14: assigned [mem 0x82000000-0x83ffffff]
[ 0.587912] pci 0000:00:01.0: BAR 15: no space for [mem size 0x3000000000 64bit pref]
[ 0.587914] pci 0000:00:01.0: BAR 15: failed to assign [mem size 0x3000000000 64bit pref]
[ 0.587916] pci 0000:00:01.0: BAR 14: assigned [mem 0x80000000-0x80ffffff]
[ 0.587920] pci 0000:00:01.0: BAR 14: reassigned [mem 0x82000000-0x83ffffff] (expanded by 0x1000000)
[ 0.587924] pci 0000:01:00.0: BAR 1: no space for [mem size 0x2000000000 64bit pref]
[ 0.587926] pci 0000:01:00.0: BAR 1: failed to assign [mem 0xffffffe000000000-0xffffffffffffffff 64bit pref]
[ 0.587928] pci 0000:01:00.0: BAR 8: no space for [mem size 0x1400000000 64bit pref]
[ 0.587930] pci 0000:01:00.0: BAR 8: failed to assign [mem size 0x1400000000 64bit pref]
[ 0.587933] pci 0000:01:00.0: BAR 3: assigned [mem 0x82000000-0x83ffffff 64bit pref]
[ 0.587939] pci 0000:01:00.0: BAR 10: no space for [mem size 0x28000000 64bit pref]
[ 0.587941] pci 0000:01:00.0: BAR 10: failed to assign [mem size 0x28000000 64bit pref]
[ 0.587943] pci 0000:01:00.0: BAR 0: no space for [mem size 0x01000000]
[ 0.587945] pci 0000:01:00.0: BAR 0: failed to assign [mem size 0x01000000]
[ 0.587946] pci 0000:01:00.0: BAR 7: no space for [mem size 0x00500000]
[ 0.587948] pci 0000:01:00.0: BAR 7: failed to assign [mem size 0x00500000]
[ 0.587951] pci 0000:01:00.0: BAR 1: no space for [mem size 0x2000000000 64bit pref]
[ 0.587953] pci 0000:01:00.0: BAR 1: failed to assign [mem 0xffffffe000000000-0xffffffffffffffff 64bit pref]
[ 0.587955] pci 0000:01:00.0: BAR 3: assigned [mem 0x82000000-0x83ffffff 64bit pref]
[ 0.587961] pci 0000:01:00.0: BAR 0: no space for [mem size 0x01000000]
[ 0.587963] pci 0000:01:00.0: BAR 0: failed to assign [mem size 0x01000000]
[ 0.587965] pci 0000:01:00.0: BAR 7: no space for [mem size 0x00500000]
[ 0.587966] pci 0000:01:00.0: BAR 7: failed to assign [mem size 0x00500000]
[ 0.587968] pci 0000:01:00.0: BAR 10: no space for [mem size 0x28000000 64bit pref]
[ 0.587970] pci 0000:01:00.0: BAR 10: failed to assign [mem size 0x28000000 64bit pref]
[ 0.587972] pci 0000:01:00.0: BAR 8: no space for [mem size 0x1400000000 64bit pref]
[ 0.587974] pci 0000:01:00.0: BAR 8: failed to assign [mem size 0x1400000000 64bit pref]
[ 0.587976] pci 0000:00:01.0: PCI bridge to [bus 01]
[ 0.587979] pci 0000:00:01.0: bridge window [mem 0x82000000-0x83ffffff]
[ 0.587983] pci 0000:00:1c.0: PCI bridge to [bus 02]
[ 0.587999] pci 0000:00:1c.4: PCI bridge to [bus 03]
[ 0.588001] pci 0000:00:1c.4: bridge window [io 0x3000-0x3fff]
[ 0.588005] pci 0000:00:1c.4: bridge window [mem 0x81100000-0x811fffff]
[ 0.588011] pci 0000:00:1d.0: PCI bridge to [bus 04]
[ 0.588014] pci 0000:00:1d.0: bridge window [mem 0x81000000-0x810fffff]
[ 0.588020] pci_bus 0000:00: resource 4 [io 0x0000-0x0cf7 window]
[ 0.588021] pci_bus 0000:00: resource 5 [io 0x0d00-0xffff window]
[ 0.588022] pci_bus 0000:00: resource 6 [mem 0x000a0000-0x000bffff window]
[ 0.588023] pci_bus 0000:00: resource 7 [mem 0x000e0000-0x000e3fff window]
[ 0.588024] pci_bus 0000:00: resource 8 [mem 0x000e4000-0x000e7fff window]
[ 0.588024] pci_bus 0000:00: resource 9 [mem 0x000e8000-0x000ebfff window]
[ 0.588025] pci_bus 0000:00: resource 10 [mem 0x000ec000-0x000effff window]
[ 0.588026] pci_bus 0000:00: resource 11 [mem 0x000f0000-0x000fffff window]
[ 0.588027] pci_bus 0000:00: resource 12 [mem 0x7f800000-0xdfffffff window]
[ 0.588028] pci_bus 0000:00: resource 13 [mem 0x4000000000-0x7fffffffff window]
[ 0.588028] pci_bus 0000:00: resource 14 [mem 0xfc800000-0xfe7fffff window]
[ 0.588029] pci_bus 0000:01: resource 1 [mem 0x82000000-0x83ffffff]
[ 0.588030] pci_bus 0000:03: resource 0 [io 0x3000-0x3fff]
[ 0.588031] pci_bus 0000:03: resource 1 [mem 0x81100000-0x811fffff]
[ 0.588032] pci_bus 0000:04: resource 1 [mem 0x81000000-0x810fffff]
[ 0.588160] NET: Registered protocol family 2
[ 0.588343] IP idents hash table entries: 262144 (order: 9, 2097152 bytes)
[ 0.589896] tcp_listen_portaddr_hash hash table entries: 16384 (order: 6, 262144 bytes)
[ 0.589967] TCP established hash table entries: 262144 (order: 9, 2097152 bytes)
[ 0.590184] TCP bind hash table entries: 65536 (order: 8, 1048576 bytes)
[ 0.590262] TCP: Hash tables configured (established 262144 bind 65536)
[ 0.590298] UDP hash table entries: 16384 (order: 7, 524288 bytes)
[ 0.590357] UDP-Lite hash table entries: 16384 (order: 7, 524288 bytes)
[ 0.590434] NET: Registered protocol family 1
[ 0.590439] NET: Registered protocol family 44
[ 0.590447] pci 0000:00:02.0: Video device with shadowed ROM at [mem 0x000c0000-0x000dffff]
[ 0.590721] PCI: CLS 64 bytes, default 64
[ 0.590744] Unpacking initramfs...
[ 1.333028] Freeing initrd memory: 66272K
[ 1.333046] PCI-DMA: Using software bounce buffering for IO (SWIOTLB)
[ 1.333049] software IO TLB: mapped [mem 0x6e1f4000-0x721f4000] (64MB)
[ 1.333114] platform rtc_cmos: registered platform RTC device (no PNP device found)
[ 1.333807] Initialise system trusted keyrings
[ 1.333814] Key type blacklist registered
[ 1.333858] workingset: timestamp_bits=40 max_order=23 bucket_order=0
[ 1.334708] zbud: loaded
[ 1.448185] Key type asymmetric registered
[ 1.448188] Asymmetric key parser 'x509' registered
[ 1.448195] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 247)
[ 1.448215] io scheduler noop registered
[ 1.448217] io scheduler deadline registered
[ 1.448239] io scheduler cfq registered (default)
[ 1.448241] io scheduler mq-deadline registered
[ 1.449180] shpchp: Standard Hot Plug PCI Controller Driver version: 0.4
[ 1.449193] efifb: probing for efifb
[ 1.449203] efifb: framebuffer at 0x4000000000, using 3072k, total 3072k
[ 1.449205] efifb: mode is 1024x768x32, linelength=4096, pages=1
[ 1.449206] efifb: scrolling: redraw
[ 1.449208] efifb: Truecolor: size=8:8:8:8, shift=24:16:8:0
[ 1.450432] Console: switching to colour frame buffer device 128x48
[ 1.451609] fb0: EFI VGA frame buffer device
[ 1.451627] intel_idle: does not run on family 6 model 165
[ 1.451860] Monitor-Mwait will be used to enter C-1 state
[ 1.451862] Monitor-Mwait will be used to enter C-2 state
[ 1.454021] Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled
[ 1.474971] 00:02: ttyS0 at I/O 0x3f8 (irq = 4, base_baud = 115200) is a 16550A
[ 1.475489] Linux agpgart interface v0.103
[ 1.475548] AMD IOMMUv2 driver by Joerg Roedel <jroedel@suse.de>
[ 1.475564] AMD IOMMUv2 functionality not available on this system
[ 1.476711] i8042: PNP: No PS/2 controller found.
[ 1.476823] mousedev: PS/2 mouse device common for all mice
[ 1.476868] rtc_cmos rtc_cmos: RTC can wake from S4
[ 1.477431] rtc_cmos rtc_cmos: registered as rtc0
[ 1.477453] rtc_cmos rtc_cmos: alarms up to one month, y3k, 114 bytes nvram, hpet irqs
[ 1.477479] intel_pstate: Intel P-state driver initializing
[ 1.478252] intel_pstate: HWP enabled
[ 1.478560] ledtrig-cpu: registered to indicate activity on CPUs
[ 1.478824] NET: Registered protocol family 10
[ 1.482153] Segment Routing with IPv6
[ 1.482168] mip6: Mobile IPv6
[ 1.482175] NET: Registered protocol family 17
[ 1.482224] mpls_gso: MPLS GSO support
[ 1.482897] mce: Using 14 MCE banks
[ 1.482917] microcode: sig=0xa0655, pf=0x2, revision=0xf8
[ 1.483340] microcode: Microcode Update Driver: v2.2.
[ 1.483348] sched_clock: Marking stable (1482550316, 787874)->(1502960326, -19622136)
[ 1.484129] registered taskstats version 1
[ 1.484439] Loading compiled-in X.509 certificates
[ 1.501281] Loaded X.509 cert 'Debian Secure Boot CA: 6ccece7e4c6c0d1f6149f3dd27dfcc5cbb419ea1'
[ 1.501601] Loaded X.509 cert 'Debian Secure Boot Signer 2022 - linux: 14011249c2675ea8e5148542202005810584b25f'
[ 1.502267] Loaded UEFI:db cert 'Microsoft Corporation UEFI CA 2011: 13adbf4309bd82709c8cd54f316ed522988a1bd4' linked to secondary sys keyring
[ 1.502906] Loaded UEFI:db cert 'Microsoft Windows Production PCA 2011: a92902398e16c49778cd90f99e4f9ae17c55af53' linked to secondary sys keyring
[ 1.503914] zswap: loaded using pool lzo/zbud
[ 1.504344] AppArmor: AppArmor sha1 policy hashing enabled
[ 1.505397] rtc_cmos rtc_cmos: setting system clock to 2023-08-24 16:34:54 UTC (1692894894)
[ 1.620750] Freeing unused kernel image memory: 1620K
[ 1.664739] Write protecting the kernel read-only data: 16384k
[ 1.665959] Freeing unused kernel image memory: 2028K
[ 1.666482] Freeing unused kernel image memory: 908K
[ 1.671278] x86/mm: Checked W+X mappings: passed, no W+X pages found.
[ 1.671703] Run /init as init process
[ 1.707963] input: Sleep Button as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0E:00/input/input0
[ 1.708506] ACPI: Sleep Button [SLPB]
[ 1.709088] input: Power Button as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0C:00/input/input1
[ 1.709675] ACPI: Power Button [PWRB]
[ 1.710311] input: Power Button as /devices/LNXSYSTM:00/LNXPWRBN:00/input/input2
[ 1.710917] ACPI: Power Button [PWRF]
[ 1.711697] acpi PNP0C14:03: duplicate WMI GUID 05901221-D566-11D1-B2F0-00A0C9062910 (first instance was on PNP0C14:02)
[ 1.712103] acpi PNP0C14:04: duplicate WMI GUID 05901221-D566-11D1-B2F0-00A0C9062910 (first instance was on PNP0C14:02)
[ 1.715162] thermal LNXTHERM:00: registered as thermal_zone0
[ 1.715394] r8125: loading out-of-tree module taints kernel.
[ 1.715841] ACPI: Thermal Zone [TZ00] (28 C)
[ 1.717100] r8125: module verification failed: signature and/or required key missing - tainting kernel
[ 1.718207] cryptd: max_cpu_qlen set to 1000
[ 1.718266] r8125 2.5Gigabit Ethernet driver 9.011.01-NAPI loaded
[ 1.719580] r8125 0000:03:00.0: enabling device (0000 -> 0003)
[ 1.722231] SCSI subsystem initialized
[ 1.723550] ACPI: bus type USB registered
[ 1.724375] usbcore: registered new interface driver usbfs
[ 1.725157] usbcore: registered new interface driver hub
[ 1.725964] usbcore: registered new device driver usb
[ 1.726730] AVX2 version of gcm_enc/dec engaged.
[ 1.727318] AES CTR mode by8 optimization enabled
[ 1.729822] nvme nvme0: pci function 0000:04:00.0
[ 1.730770] libata version 3.00 loaded.
[ 1.736180] r8125: This product is covered by one or more of the following patents: US6,570,884, US6,115,776, and US6,327,625.
[ 1.738979] r8125 Copyright (C) 2022 Realtek NIC software team <nicfae@realtek.com>
This program comes with ABSOLUTELY NO WARRANTY; for details, please see <http://www.gnu.org/licenses/>.
This is free software, and you are welcome to redistribute it under certain conditions; see <http://www.gnu.org/licenses/>.
[ 1.945413] nvme nvme0: missing or invalid SUBNQN field.
[ 1.947869] nvme nvme0: Shutdown timeout set to 8 seconds
[ 1.985968] nvme0n1: p1 p2 p3
[ 1.992900] r8125 0000:03:00.0 enp3s0: renamed from eth0
[ 1.995849] xhci_hcd 0000:00:14.0: xHCI Host Controller
[ 1.996281] xhci_hcd 0000:00:14.0: new USB bus registered, assigned bus number 1
[ 1.997779] xhci_hcd 0000:00:14.0: hcc params 0x200077c1 hci version 0x110 quirks 0x0000000000009810
[ 1.998235] xhci_hcd 0000:00:14.0: cache line size of 64 is not supported
[ 1.998287] ahci 0000:00:17.0: version 3.0
[ 1.998364] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 4.19
[ 1.998752] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.999137] usb usb1: Product: xHCI Host Controller
[ 1.999516] usb usb1: Manufacturer: Linux 4.19.0-25-amd64 xhci-hcd
[ 1.999893] usb usb1: SerialNumber: 0000:00:14.0
[ 2.000319] hub 1-0:1.0: USB hub found
[ 2.000728] hub 1-0:1.0: 16 ports detected
[ 2.001899] xhci_hcd 0000:00:14.0: xHCI Host Controller
[ 2.002315] xhci_hcd 0000:00:14.0: new USB bus registered, assigned bus number 2
[ 2.002685] xhci_hcd 0000:00:14.0: Host supports USB 3.1 Enhanced SuperSpeed
[ 2.003069] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 4.19
[ 2.003443] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 2.003814] usb usb2: Product: xHCI Host Controller
[ 2.004176] usb usb2: Manufacturer: Linux 4.19.0-25-amd64 xhci-hcd
[ 2.004536] usb usb2: SerialNumber: 0000:00:14.0
[ 2.005010] hub 2-0:1.0: USB hub found
[ 2.005393] hub 2-0:1.0: 10 ports detected
[ 2.005946] usb: port power management may be unreliable
[ 2.008532] ahci 0000:00:17.0: AHCI 0001.0301 32 slots 6 ports 6 Gbps 0x3f impl SATA mode
[ 2.008908] ahci 0000:00:17.0: flags: 64bit ncq sntf clo only pio slum part ems deso sadm sds apst
[ 2.073794] scsi host0: ahci
[ 2.075611] scsi host1: ahci
[ 2.077350] scsi host2: ahci
[ 2.079162] scsi host3: ahci
[ 2.081295] scsi host4: ahci
[ 2.083313] scsi host5: ahci
[ 2.085248] ata1: SATA max UDMA/133 abar m2048@0x81202000 port 0x81202100 irq 170
[ 2.087101] ata2: SATA max UDMA/133 abar m2048@0x81202000 port 0x81202180 irq 170
[ 2.088928] ata3: SATA max UDMA/133 abar m2048@0x81202000 port 0x81202200 irq 170
[ 2.090719] ata4: SATA max UDMA/133 abar m2048@0x81202000 port 0x81202280 irq 170
[ 2.092512] ata5: SATA max UDMA/133 abar m2048@0x81202000 port 0x81202300 irq 170
[ 2.094301] ata6: SATA max UDMA/133 abar m2048@0x81202000 port 0x81202380 irq 170
[ 2.256797] usb 1-7: new high-speed USB device number 2 using xhci_hcd
[ 2.336709] tsc: Refined TSC clocksource calibration: 2904.000 MHz
[ 2.338538] clocksource: tsc: mask: 0xffffffffffffffff max_cycles: 0x29dc05e54fc, max_idle_ns: 440795291716 ns
[ 2.340462] clocksource: Switched to clocksource tsc
[ 2.411888] ata4: SATA link down (SStatus 4 SControl 300)
[ 2.413726] ata1: SATA link up 6.0 Gbps (SStatus 133 SControl 300)
[ 2.415466] ata3: SATA link down (SStatus 4 SControl 300)
[ 2.417035] ata2: SATA link up 6.0 Gbps (SStatus 133 SControl 300)
[ 2.417324] ata6: SATA link down (SStatus 4 SControl 300)
[ 2.417674] ata5: SATA link down (SStatus 4 SControl 300)
[ 2.418245] ata1.00: ATA-9: WDC WD60EZRZ-22GZ5B1, 80.00A80, max UDMA/133
[ 2.418524] ata1.00: 11721045168 sectors, multi 16: LBA48 NCQ (depth 32), AA
[ 2.418800] ata2.00: ATA-10: WDC WD60EFAX-68SHWN0, 82.00A82, max UDMA/133
[ 2.419132] ata2.00: 11721045168 sectors, multi 16: LBA48 NCQ (depth 32), AA
[ 2.420265] ata1.00: configured for UDMA/133
[ 2.420561] ata2.00: configured for UDMA/133
[ 2.420651] scsi 0:0:0:0: Direct-Access ATA WDC WD60EZRZ-22G 0A80 PQ: 0 ANSI: 5
[ 2.421329] scsi 1:0:0:0: Direct-Access ATA WDC WD60EFAX-68S 0A82 PQ: 0 ANSI: 5
[ 2.423972] sd 0:0:0:0: [sda] 11721045168 512-byte logical blocks: (6.00 TB/5.46 TiB)
[ 2.424001] sd 1:0:0:0: [sdb] 11721045168 512-byte logical blocks: (6.00 TB/5.46 TiB)
[ 2.424294] sd 0:0:0:0: [sda] 4096-byte physical blocks
[ 2.424598] sd 1:0:0:0: [sdb] 4096-byte physical blocks
[ 2.424903] sd 0:0:0:0: [sda] Write Protect is off
[ 2.425202] sd 1:0:0:0: [sdb] Write Protect is off
[ 2.425489] sd 0:0:0:0: [sda] Mode Sense: 00 3a 00 00
[ 2.425779] sd 1:0:0:0: [sdb] Mode Sense: 00 3a 00 00
[ 2.425782] sd 0:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[ 2.425783] sd 1:0:0:0: [sdb] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[ 2.442783] usb 1-7: New USB device found, idVendor=058f, idProduct=6387, bcdDevice= 1.04
[ 2.443156] usb 1-7: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 2.443522] usb 1-7: Product: Mass Storage
[ 2.443884] usb 1-7: SerialNumber: 43452089
[ 2.448012] usb-storage 1-7:1.0: USB Mass Storage device detected
[ 2.448503] scsi host6: usb-storage 1-7:1.0
[ 2.448997] usbcore: registered new interface driver usb-storage
[ 2.454818] sd 0:0:0:0: [sda] Attached SCSI disk
[ 2.486466] sd 1:0:0:0: [sdb] Attached SCSI disk
[ 2.491966] usbcore: registered new interface driver uas
[ 2.554967] md/raid1:md0: active with 2 out of 2 mirrors
[ 2.572680] usb 1-9: new low-speed USB device number 3 using xhci_hcd
[ 2.642866] md0: detected capacity change from 0 to 6001039835136
[ 2.726240] usb 1-9: New USB device found, idVendor=413c, idProduct=3016, bcdDevice=29.00
[ 2.727836] usb 1-9: New USB device strings: Mfr=0, Product=2, SerialNumber=0
[ 2.729482] usb 1-9: Product: Dell Premium USB Optical Mouse
[ 2.745337] hidraw: raw HID events driver (C) Jiri Kosina
[ 2.757871] usbcore: registered new interface driver usbhid
[ 2.759574] usbhid: USB HID core driver
[ 2.764744] input: Dell Premium USB Optical Mouse as /devices/pci0000:00/0000:00:14.0/usb1/1-9/1-9:1.0/0003:413C:3016.0001/input/input3
[ 2.768529] hid-generic 0003:413C:3016.0001: input,hidraw0: USB HID v1.11 Mouse [Dell Premium USB Optical Mouse] on usb-0000:00:14.0-9/input0
[ 2.856658] usb 1-10: new low-speed USB device number 4 using xhci_hcd
[ 2.896625] raid6: sse2x1 gen() 17011 MB/s
[ 2.964620] raid6: sse2x1 xor() 12420 MB/s
[ 3.010508] usb 1-10: New USB device found, idVendor=413c, idProduct=2003, bcdDevice= 3.01
[ 3.010842] usb 1-10: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 3.011177] usb 1-10: Product: Dell USB Keyboard
[ 3.011505] usb 1-10: Manufacturer: Dell
[ 3.015807] input: Dell Dell USB Keyboard as /devices/pci0000:00/0000:00:14.0/usb1/1-10/1-10:1.0/0003:413C:2003.0002/input/input4
[ 3.032623] raid6: sse2x2 gen() 20868 MB/s
[ 3.072748] hid-generic 0003:413C:2003.0002: input,hidraw1: USB HID v1.10 Keyboard [Dell Dell USB Keyboard] on usb-0000:00:14.0-10/input0
[ 3.100620] raid6: sse2x2 xor() 14338 MB/s
[ 3.168620] raid6: sse2x4 gen() 24039 MB/s
[ 3.200693] usb 1-11: new high-speed USB device number 5 using xhci_hcd
[ 3.236631] raid6: sse2x4 xor() 15528 MB/s
[ 3.304621] raid6: avx2x1 gen() 34124 MB/s
[ 3.350255] usb 1-11: New USB device found, idVendor=05e3, idProduct=0608, bcdDevice=60.70
[ 3.350629] usb 1-11: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[ 3.350997] usb 1-11: Product: USB2.0 Hub
[ 3.352184] hub 1-11:1.0: USB hub found
[ 3.352886] hub 1-11:1.0: 4 ports detected
[ 3.372621] raid6: avx2x1 xor() 23980 MB/s
[ 3.440621] raid6: avx2x2 gen() 40990 MB/s
[ 3.457447] scsi 6:0:0:0: Direct-Access Flash Disk 8.07 PQ: 0 ANSI: 2
[ 3.458749] sd 6:0:0:0: [sdc] 3901440 512-byte logical blocks: (2.00 GB/1.86 GiB)
[ 3.459289] sd 6:0:0:0: [sdc] Write Protect is off
[ 3.459730] sd 6:0:0:0: [sdc] Mode Sense: 03 00 00 00
[ 3.459977] sd 6:0:0:0: [sdc] No Caching mode page found
[ 3.460350] sd 6:0:0:0: [sdc] Assuming drive cache: write through
[ 3.480683] usb 1-12: new full-speed USB device number 6 using xhci_hcd
[ 3.508620] raid6: avx2x2 xor() 26102 MB/s
[ 3.576621] raid6: avx2x4 gen() 45946 MB/s
[ 3.622689] sdc: sdc1
[ 3.624140] sd 6:0:0:0: [sdc] Attached SCSI removable disk
[ 3.629408] usb 1-12: New USB device found, idVendor=1462, idProduct=7c75, bcdDevice= 0.01
[ 3.629787] usb 1-12: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 3.630167] usb 1-12: Product: MYSTIC LIGHT
[ 3.630537] usb 1-12: Manufacturer: MSI
[ 3.630900] usb 1-12: SerialNumber: A02020021806
[ 3.632765] input: MSI MYSTIC LIGHT as /devices/pci0000:00/0000:00:14.0/usb1/1-12/1-12:1.0/0003:1462:7C75.0003/input/input5
[ 3.633327] hid-generic 0003:1462:7C75.0003: input,hiddev0,hidraw2: USB HID v1.10 Device [MSI MYSTIC LIGHT ] on usb-0000:00:14.0-12/input0
[ 3.644620] raid6: avx2x4 xor() 28286 MB/s
[ 3.645045] raid6: using algorithm avx2x4 gen() 45946 MB/s
[ 3.645419] raid6: .... xor() 28286 MB/s, rmw enabled
[ 3.645782] raid6: using avx2x2 recovery algorithm
[ 3.646833] xor: measuring software checksum speed
[ 3.684620] prefetch64-sse: 25681.000 MB/sec
[ 3.724620] generic_sse: 24337.000 MB/sec
[ 3.724957] xor: using function: prefetch64-sse (25681.000 MB/sec)
[ 3.725911] async_tx: api initialized (async)
[ 3.765680] Btrfs loaded, crc32c=crc32c-intel
[ 3.815719] PM: Image not found (code -22)
[ 3.900795] EXT4-fs (nvme0n1p3): mounted filesystem with ordered data mode. Opts: (null)
[ 3.974453] systemd[1]: Inserted module 'autofs4'
[ 3.998856] systemd[1]: systemd 241 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD -IDN2 +IDN -PCRE2 default-hierarchy=hybrid)
[ 4.016726] systemd[1]: Detected architecture x86-64.
[ 4.019641] systemd[1]: Set hostname to <robbie>.
[ 4.063428] systemd[1]: Listening on initctl Compatibility Named Pipe.
[ 4.063868] systemd[1]: Listening on Syslog Socket.
[ 4.064287] systemd[1]: Listening on Journal Socket.
[ 4.065809] systemd[1]: Starting Set the console keyboard layout...
[ 4.066332] systemd[1]: Created slice system-systemd\x2dfsck.slice.
[ 4.066750] systemd[1]: Listening on udev Control Socket.
[ 4.067112] systemd[1]: Reached target Remote File Systems.
[ 4.076704] EXT4-fs (nvme0n1p3): re-mounted. Opts: errors=remount-ro
[ 4.106099] nvidia: module license 'NVIDIA' taints kernel.
[ 4.106444] Disabling lock debugging due to kernel taint
[ 4.122093] systemd-journald[414]: Received request to flush runtime journal from PID 1
[ 4.124106] nvidia-nvlink: Nvlink Core is being initialized, major device number 243
[ 4.125299] nvidia 0000:01:00.0: enabling device (0000 -> 0002)
[ 4.125764] NVRM: This PCI I/O region assigned to your NVIDIA device is invalid:
NVRM: BAR0 is 0M @ 0x0 (PCI:0000:01:00.0)
[ 4.126569] nvidia: probe of 0000:01:00.0 failed with error -1
[ 4.126980] NVRM: The NVIDIA probe routine failed for 1 device(s).
[ 4.127386] NVRM: None of the NVIDIA devices were initialized.
[ 4.127892] nvidia-nvlink: Unregistered Nvlink Core, major device number 243
[ 4.152164] sd 0:0:0:0: Attached scsi generic sg0 type 0
[ 4.152851] sd 1:0:0:0: Attached scsi generic sg1 type 0
[ 4.153553] sd 6:0:0:0: Attached scsi generic sg2 type 0
[ 4.154244] mei_me 0000:00:16.0: enabling device (0000 -> 0002)
[ 4.155075] input: PC Speaker as /devices/platform/pcspkr/input/input6
[ 4.156177] EFI Variables Facility v0.08 2004-May-17
[ 4.198437] pstore: Using compression: deflate
[ 4.198878] pstore: Registered efi as persistent store backend
[ 4.208900] snd_hda_intel 0000:00:1f.3: enabling device (0000 -> 0002)
[ 4.209780] snd_hda_intel 0000:00:1f.3: number of I/O streams is 16, forcing separate stream tags
[ 4.219819] Adding 31249404k swap on /dev/nvme0n1p2. Priority:-2 extents:1 across:31249404k SSFS
[ 4.232160] snd_hda_codec_realtek hdaudioC0D0: autoconfig for ALC892: line_outs=4 (0x14/0x15/0x16/0x17/0x0) type:line
[ 4.232524] snd_hda_codec_realtek hdaudioC0D0: speaker_outs=0 (0x0/0x0/0x0/0x0/0x0)
[ 4.232907] snd_hda_codec_realtek hdaudioC0D0: hp_outs=1 (0x1b/0x0/0x0/0x0/0x0)
[ 4.233268] snd_hda_codec_realtek hdaudioC0D0: mono: mono_out=0x0
[ 4.233622] snd_hda_codec_realtek hdaudioC0D0: inputs:
[ 4.234046] snd_hda_codec_realtek hdaudioC0D0: Front Mic=0x19
[ 4.234395] snd_hda_codec_realtek hdaudioC0D0: Rear Mic=0x18
[ 4.234742] snd_hda_codec_realtek hdaudioC0D0: Line=0x1a
[ 4.251954] snd_hda_codec_hdmi hdaudioC0D2: No i915 binding for Intel HDMI/DP codec
[ 4.252432] hdaudio hdaudioC0D2: Unable to bind the codec
[ 4.253046] input: HDA Intel Front Mic as /devices/pci0000:00/0000:00:1f.3/sound/card0/input7
[ 4.253633] input: HDA Intel Rear Mic as /devices/pci0000:00/0000:00:1f.3/sound/card0/input8
[ 4.254116] input: HDA Intel Line as /devices/pci0000:00/0000:00:1f.3/sound/card0/input9
[ 4.254505] input: HDA Intel Line Out Front as /devices/pci0000:00/0000:00:1f.3/sound/card0/input10
[ 4.254895] input: HDA Intel Line Out Surround as /devices/pci0000:00/0000:00:1f.3/sound/card0/input11
[ 4.255281] input: HDA Intel Line Out CLFE as /devices/pci0000:00/0000:00:1f.3/sound/card0/input12
[ 4.255883] input: HDA Intel Line Out Side as /devices/pci0000:00/0000:00:1f.3/sound/card0/input13
[ 4.256476] input: HDA Intel Front Headphone as /devices/pci0000:00/0000:00:1f.3/sound/card0/input14
[ 4.413023] nvidia-nvlink: Nvlink Core is being initialized, major device number 241
[ 4.414129] NVRM: This PCI I/O region assigned to your NVIDIA device is invalid:
[ 4.414808] nvidia: probe of 0000:01:00.0 failed with error -1
[ 4.415152] NVRM: The NVIDIA probe routine failed for 1 device(s).
[ 4.415493] NVRM: None of the NVIDIA devices were initialized.
[ 4.415924] nvidia-nvlink: Unregistered Nvlink Core, major device number 241
[ 4.643883] EXT4-fs (md0): mounted filesystem with ordered data mode. Opts: (null)
[ 4.666132] audit: type=1400 audit(1692894897.659:2): apparmor="STATUS" operation="profile_load" profile="unconfined" name="/usr/sbin/haveged" pid=619 comm="apparmor_parser"
[ 4.666881] audit: type=1400 audit(1692894897.659:3): apparmor="STATUS" operation="profile_load" profile="unconfined" name="libreoffice-senddoc" pid=620 comm="apparmor_parser"
[ 4.667637] audit: type=1400 audit(1692894897.659:4): apparmor="STATUS" operation="profile_load" profile="unconfined" name="libreoffice-xpdfimport" pid=626 comm="apparmor_parser"
[ 4.668409] audit: type=1400 audit(1692894897.659:5): apparmor="STATUS" operation="profile_load" profile="unconfined" name="nvidia_modprobe" pid=623 comm="apparmor_parser"
[ 4.669214] audit: type=1400 audit(1692894897.659:6): apparmor="STATUS" operation="profile_load" profile="unconfined" name="nvidia_modprobe//kmod" pid=623 comm="apparmor_parser"
[ 4.670049] audit: type=1400 audit(1692894897.659:7): apparmor="STATUS" operation="profile_load" profile="unconfined" name="libreoffice-oopslash" pid=625 comm="apparmor_parser"
[ 4.670051] audit: type=1400 audit(1692894897.659:8): apparmor="STATUS" operation="profile_load" profile="unconfined" name="/usr/bin/man" pid=624 comm="apparmor_parser"
[ 4.672024] audit: type=1400 audit(1692894897.659:9): apparmor="STATUS" operation="profile_load" profile="unconfined" name="man_filter" pid=624 comm="apparmor_parser"
[ 4.672976] audit: type=1400 audit(1692894897.659:10): apparmor="STATUS" operation="profile_load" profile="unconfined" name="man_groff" pid=624 comm="apparmor_parser"
[ 4.674056] nvidia-nvlink: Nvlink Core is being initialized, major device number 240
[ 4.675258] NVRM: This PCI I/O region assigned to your NVIDIA device is invalid:
[ 4.676249] nvidia: probe of 0000:01:00.0 failed with error -1
[ 4.676753] NVRM: The NVIDIA probe routine failed for 1 device(s).
[ 4.677240] NVRM: None of the NVIDIA devices were initialized.
[ 4.677338] nvidia-nvlink: Unregistered Nvlink Core, major device number 240
[ 4.947273] nvidia-nvlink: Nvlink Core is being initialized, major device number 240
[ 4.948680] NVRM: This PCI I/O region assigned to your NVIDIA device is invalid:
[ 4.949798] nvidia: probe of 0000:01:00.0 failed with error -1
[ 4.950474] NVRM: The NVIDIA probe routine failed for 1 device(s).
[ 4.950997] NVRM: None of the NVIDIA devices were initialized.
[ 4.951112] nvidia-nvlink: Unregistered Nvlink Core, major device number 240
