So far, so good, but we have to wait. I can’t say for sure.
No, it didn’t
nomodeset
Xorg logs at the moment of crash:
[ 8.792] (--) Log file renamed from "/home/showex/.local/share/xorg/Xorg.pid-782.log" to "/home/showex/.local/share/xorg/Xorg.0.log"
[ 8.793]
X.Org X Server 1.21.1.11
X Protocol Version 11, Revision 0
[ 8.793] Current Operating System: Linux showex-zzz 6.8.1-zen1-1-zen #1 ZEN SMP PREEMPT_DYNAMIC Sat, 16 Mar 2024 17:15:23 +0000 x86_64
[ 8.793] Kernel command line: BOOT_IMAGE=/@/boot/vmlinuz-linux-zen root=UUID=63f0d3ca-84ab-482c-8b6a-e5009cdeb426 rw rootflags=subvol=@ nowatchdog nvme_load=YES resume=UUID=4d813d8e-ca07-4ab7-a959-6aed44d44e4e nvidia-drm.modeset=1 loglevel=3
[ 8.793]
[ 8.793] Current version of pixman: 0.43.4
[ 8.793] Before reporting problems, check http://wiki.x.org
to make sure that you have the latest version.
[ 8.793] Markers: (--) probed, (**) from config file, (==) default setting,
(++) from command line, (!!) notice, (II) informational,
(WW) warning, (EE) error, (NI) not implemented, (??) unknown.
[ 8.793] (==) Log file: "/home/showex/.local/share/xorg/Xorg.0.log", Time: Fri Mar 29 23:51:41 2024
[ 8.795] (==) Using config directory: "/etc/X11/xorg.conf.d"
[ 8.795] (==) Using system config directory "/usr/share/X11/xorg.conf.d"
[ 8.795] (==) No Layout section. Using the first Screen section.
[ 8.795] (==) No screen section available. Using defaults.
[ 8.795] (**) |-->Screen "Default Screen Section" (0)
[ 8.795] (**) | |-->Monitor "<default monitor>"
[ 8.795] (==) No monitor specified for screen "Default Screen Section".
Using a default monitor configuration.
[ 8.795] (==) Automatically adding devices
[ 8.795] (==) Automatically enabling devices
[ 8.795] (==) Automatically adding GPU devices
[ 8.795] (==) Automatically binding GPU devices
[ 8.795] (==) Max clients allowed: 256, resource mask: 0x1fffff
[ 8.795] (WW) The directory "/usr/share/fonts/misc" does not exist.
[ 8.795] Entry deleted from font path.
[ 8.795] (WW) `fonts.dir' not found (or not valid) in "/usr/share/fonts/TTF".
[ 8.795] (Run 'mkfontdir' on "/usr/share/fonts/TTF").
[ 8.795] (WW) The directory "/usr/share/fonts/OTF" does not exist.
[ 8.795] (WW) The directory "/usr/share/fonts/Type1" does not exist.
[ 8.795] (WW) The directory "/usr/share/fonts/100dpi" does not exist.
[ 8.796] Entry deleted from font path.
[ 8.796] (WW) The directory "/usr/share/fonts/75dpi" does not exist.
[ 8.796] (==) FontPath set to:
[ 8.796] (==) ModulePath set to "/usr/lib/xorg/modules"
[ 8.796] (II) The server relies on udev to provide the list of input devices.
If no devices become available, reconfigure udev or disable AutoAddDevices.
[ 8.796] (II) Module ABI versions:
[ 8.796] X.Org ANSI C Emulation: 0.4
[ 8.796] X.Org Video Driver: 25.2
[ 8.796] X.Org XInput driver : 24.4
[ 8.796] X.Org Server Extension : 10.0
[ 8.796] (++) using VT number 2
[ 8.796] (II) systemd-logind: took control of session /org/freedesktop/login1/session/_31
[ 8.797] (II) xfree86: Adding drm device (/dev/dri/card0)
[ 8.797] (II) Platform probe for /sys/devices/pci0000:00/0000:00:01.0/0000:01:00.0/drm/card0
[ 8.797] (II) systemd-logind: got fd for /dev/dri/card0 226:0 fd 14 paused 0
[ 8.798] (**) OutputClass "nvidia" ModulePath extended to "/usr/lib/nvidia/xorg,/usr/lib/xorg/modules,/usr/lib/xorg/modules"
[ 8.799] (--) PCI:*(1@0:0:0) 10de:1f06:1462:c757 rev 161, Mem @ 0x39000000/16777216, 0x40000000/268435456, 0x50000000/33554432, I/O @ 0x00004000/128, BIOS @ 0x????????/131072
[ 8.799] (WW) Open ACPI failed (/var/run/acpid.socket) (No such file or directory)
[ 8.799] (II) LoadModule: "glx"
[ 8.799] (II) Loading /usr/lib/xorg/modules/extensions/libglx.so
[ 8.804] (II) Module glx: vendor="X.Org Foundation"
[ 8.804] compiled for 1.21.1.11, module version = 1.0.0
[ 8.804] ABI class: X.Org Server Extension, version 10.0
[ 8.804] (II) Applying OutputClass "nvidia" to /dev/dri/card0
[ 8.804] loading driver: nvidia
[ 8.804] (==) Matched nvidia as autoconfigured driver 0
[ 8.804] (==) Matched nouveau as autoconfigured driver 1
[ 8.804] (==) Matched nv as autoconfigured driver 2
[ 8.804] (==) Matched modesetting as autoconfigured driver 3
[ 8.804] (==) Matched fbdev as autoconfigured driver 4
[ 8.804] (==) Matched vesa as autoconfigured driver 5
[ 8.804] (==) Assigned the driver to the xf86ConfigLayout
[ 8.804] (II) LoadModule: "nvidia"
[ 8.804] (II) Loading /usr/lib/xorg/modules/drivers/nvidia_drv.so
[ 8.813] (II) Module nvidia: vendor="NVIDIA Corporation"
[ 8.813] compiled for 1.6.99.901, module version = 1.0.0
[ 8.813] Module class: X.Org Video Driver
[ 8.813] (II) LoadModule: "nouveau"
[ 8.813] (WW) Warning, couldn't open module nouveau
[ 8.813] (EE) Failed to load module "nouveau" (module does not exist, 0)
[ 8.813] (II) LoadModule: "nv"
[ 8.813] (WW) Warning, couldn't open module nv
[ 8.813] (EE) Failed to load module "nv" (module does not exist, 0)
[ 8.813] (II) LoadModule: "modesetting"
[ 8.813] (II) Loading /usr/lib/xorg/modules/drivers/modesetting_drv.so
[ 8.819] (II) Module modesetting: vendor="X.Org Foundation"
[ 8.819] compiled for 1.21.1.11, module version = 1.21.1
[ 8.819] Module class: X.Org Video Driver
[ 8.819] ABI class: X.Org Video Driver, version 25.2
[ 8.819] (II) LoadModule: "fbdev"
[ 8.819] (WW) Warning, couldn't open module fbdev
[ 8.819] (EE) Failed to load module "fbdev" (module does not exist, 0)
[ 8.819] (II) LoadModule: "vesa"
[ 8.819] (WW) Warning, couldn't open module vesa
[ 8.819] (EE) Failed to load module "vesa" (module does not exist, 0)
[ 8.819] (II) NVIDIA dlloader X Driver 550.67 Tue Mar 12 23:32:46 UTC 2024
[ 8.819] (II) NVIDIA Unified Driver for all Supported NVIDIA GPUs
[ 8.819] (II) modesetting: Driver for Modesetting Kernel Drivers: kms
[ 8.819] (II) systemd-logind: releasing fd for 226:0
[ 8.820] (II) Loading sub module "fb"
[ 8.820] (II) LoadModule: "fb"
[ 8.820] (II) Module "fb" already built-in
[ 8.820] (II) Loading sub module "wfb"
[ 8.820] (II) LoadModule: "wfb"
[ 8.820] (II) Loading /usr/lib/xorg/modules/libwfb.so
[ 8.821] (II) Module wfb: vendor="X.Org Foundation"
[ 8.821] compiled for 1.21.1.11, module version = 1.0.0
[ 8.821] ABI class: X.Org ANSI C Emulation, version 0.4
[ 8.822] (WW) Falling back to old probe method for modesetting
[ 8.822] (WW) VGA arbiter: cannot open kernel arbiter, no multi-card support
[ 8.822] (II) NVIDIA(0): Creating default Display subsection in Screen section
"Default Screen Section" for depth/fbbpp 24/32
[ 8.822] (==) NVIDIA(0): Depth 24, (==) framebuffer bpp 32
[ 8.822] (==) NVIDIA(0): RGB weight 888
[ 8.822] (==) NVIDIA(0): Default visual is TrueColor
[ 8.822] (==) NVIDIA(0): Using gamma correction (1.0, 1.0, 1.0)
[ 8.822] (II) Applying OutputClass "nvidia" options to /dev/dri/card0
[ 8.822] (**) NVIDIA(0): Option "AllowEmptyInitialConfiguration"
[ 8.822] (**) NVIDIA(0): Enabling 2D acceleration
[ 8.822] (II) Loading sub module "glxserver_nvidia"
[ 8.822] (II) LoadModule: "glxserver_nvidia"
[ 8.822] (II) Loading /usr/lib/nvidia/xorg/libglxserver_nvidia.so
[ 9.321] (II) Module glxserver_nvidia: vendor="NVIDIA Corporation"
[ 9.321] compiled for 1.6.99.901, module version = 1.0.0
[ 9.321] Module class: X.Org Server Extension
[ 9.321] (II) NVIDIA GLX Module 550.67 Tue Mar 12 23:40:29 UTC 2024
[ 9.321] (II) NVIDIA: The X server supports PRIME Render Offload.
[ 9.324] (--) NVIDIA(0): Valid display device(s) on GPU-0 at PCI:1:0:0
[ 9.324] (--) NVIDIA(0): DFP-0 (boot)
[ 9.324] (--) NVIDIA(0): DFP-1
[ 9.324] (--) NVIDIA(0): DFP-2
[ 9.324] (--) NVIDIA(0): DFP-3
[ 9.324] (--) NVIDIA(0): DFP-4
[ 9.324] (--) NVIDIA(0): DFP-5
[ 9.324] (--) NVIDIA(0): DFP-6
[ 9.324] (II) NVIDIA(0): NVIDIA GPU NVIDIA GeForce RTX 2060 SUPER (TU106-A) at
[ 9.324] (II) NVIDIA(0): PCI:1:0:0 (GPU-0)
[ 9.324] (--) NVIDIA(0): Memory: 8388608 kBytes
[ 9.324] (--) NVIDIA(0): VideoBIOS: 90.06.4c.00.1d
[ 9.324] (II) NVIDIA(0): Detected PCI Express Link width: 16X
[ 9.325] (--) NVIDIA(GPU-0): BenQ ZOWIE XL LCD (DFP-0): connected
[ 9.325] (--) NVIDIA(GPU-0): BenQ ZOWIE XL LCD (DFP-0): Internal DisplayPort
[ 9.325] (--) NVIDIA(GPU-0): BenQ ZOWIE XL LCD (DFP-0): 2660.0 MHz maximum pixel clock
[ 9.327] (--) NVIDIA(GPU-0): DFP-1: disconnected
[ 9.327] (--) NVIDIA(GPU-0): DFP-1: Internal TMDS
[ 9.327] (--) NVIDIA(GPU-0): DFP-1: 165.0 MHz maximum pixel clock
[ 9.327] (--) NVIDIA(GPU-0): DFP-2: disconnected
[ 9.327] (--) NVIDIA(GPU-0): DFP-2: Internal DisplayPort
[ 9.327] (--) NVIDIA(GPU-0): DFP-2: 2660.0 MHz maximum pixel clock
[ 9.327] (--) NVIDIA(GPU-0): DFP-3: disconnected
[ 9.327] (--) NVIDIA(GPU-0): DFP-3: Internal TMDS
[ 9.327] (--) NVIDIA(GPU-0): DFP-3: 165.0 MHz maximum pixel clock
[ 9.327] (--) NVIDIA(GPU-0): DFP-4: disconnected
[ 9.327] (--) NVIDIA(GPU-0): DFP-4: Internal TMDS
[ 9.327] (--) NVIDIA(GPU-0): DFP-4: 165.0 MHz maximum pixel clock
[ 9.327] (--) NVIDIA(GPU-0): DFP-5: disconnected
[ 9.327] (--) NVIDIA(GPU-0): DFP-5: Internal DisplayPort
[ 9.327] (--) NVIDIA(GPU-0): DFP-5: 2660.0 MHz maximum pixel clock
[ 9.327] (--) NVIDIA(GPU-0): DFP-6: disconnected
[ 9.327] (--) NVIDIA(GPU-0): DFP-6: Internal TMDS
[ 9.327] (--) NVIDIA(GPU-0): DFP-6: 165.0 MHz maximum pixel clock
[ 9.395] (==) NVIDIA(0):
[ 9.395] (==) NVIDIA(0): No modes were requested; the default mode "nvidia-auto-select"
[ 9.395] (==) NVIDIA(0): will be used as the requested mode.
[ 9.396] (II) NVIDIA(0): Validated MetaModes:
[ 9.396] (II) NVIDIA(0): "DFP-0:nvidia-auto-select"
[ 9.396] (II) NVIDIA(0): Virtual screen size determined to be 1920 x 1080
[ 9.462] (--) NVIDIA(0): DPI set to (92, 91); computed from "UseEdidDpi" X config
[ 9.462] (--) NVIDIA(0): option
[ 9.462] (II) UnloadModule: "modesetting"
[ 9.462] (II) Unloading modesetting
[ 9.462] (WW) NVIDIA: Failed to bind sideband socket to
[ 9.462] (WW) NVIDIA: '/var/run/nvidia-xdriver-88ecd5f2' Permission denied
[ 9.462] (II) NVIDIA: Reserving 24576.00 MB of virtual memory for indirect memory
[ 9.462] (II) NVIDIA: access.
[ 9.464] (II) NVIDIA(0): ACPI: failed to connect to the ACPI event daemon; the daemon
[ 9.464] (II) NVIDIA(0): may not be running or the "AcpidSocketPath" X
[ 9.464] (II) NVIDIA(0): configuration option may not be set correctly. When the
[ 9.464] (II) NVIDIA(0): ACPI event daemon is available, the NVIDIA X driver will
[ 9.464] (II) NVIDIA(0): try to use it to receive ACPI event notifications. For
[ 9.464] (II) NVIDIA(0): details, please see the "ConnectToAcpid" and
[ 9.464] (II) NVIDIA(0): "AcpidSocketPath" X configuration options in Appendix B: X
[ 9.464] (II) NVIDIA(0): Config Options in the README.
[ 9.482] (II) NVIDIA(0): Setting mode "DFP-0:nvidia-auto-select"
[ 9.553] (==) NVIDIA(0): Disabling shared memory pixmaps
[ 9.553] (==) NVIDIA(0): Backing store enabled
[ 9.553] (==) NVIDIA(0): Silken mouse enabled
[ 9.553] (==) NVIDIA(0): DPMS enabled
[ 9.553] (II) Loading sub module "dri2"
[ 9.553] (II) LoadModule: "dri2"
[ 9.553] (II) Module "dri2" already built-in
[ 9.553] (II) NVIDIA(0): [DRI2] Setup complete
[ 9.553] (II) NVIDIA(0): [DRI2] VDPAU driver: nvidia
[ 9.554] (II) Initializing extension Generic Event Extension
[ 9.554] (II) Initializing extension SHAPE
[ 9.554] (II) Initializing extension MIT-SHM
[ 9.554] (II) Initializing extension XInputExtension
[ 9.554] (II) Initializing extension XTEST
[ 9.554] (II) Initializing extension BIG-REQUESTS
[ 9.554] (II) Initializing extension SYNC
[ 9.554] (II) Initializing extension XKEYBOARD
[ 9.554] (II) Initializing extension XC-MISC
[ 9.554] (II) Initializing extension SECURITY
[ 9.554] (II) Initializing extension XFIXES
[ 9.554] (II) Initializing extension RENDER
[ 9.554] (II) Initializing extension RANDR
[ 9.555] (II) Initializing extension COMPOSITE
[ 9.555] (II) Initializing extension DAMAGE
[ 9.555] (II) Initializing extension MIT-SCREEN-SAVER
[ 9.555] (II) Initializing extension DOUBLE-BUFFER
[ 9.555] (II) Initializing extension RECORD
[ 9.555] (II) Initializing extension DPMS
[ 9.555] (II) Initializing extension Present
[ 9.555] (II) Initializing extension DRI3
[ 9.555] (II) Initializing extension X-Resource
[ 9.555] (II) Initializing extension XVideo
[ 9.555] (II) Initializing extension XVideo-MotionCompensation
[ 9.555] (II) Initializing extension GLX
[ 9.555] (II) Indirect GLX disabled.
[ 9.555] (II) GLX: Another vendor is already registered for screen 0
[ 9.555] (II) Initializing extension XFree86-VidModeExtension
[ 9.556] (II) Initializing extension XFree86-DGA
[ 9.556] (II) Initializing extension XFree86-DRI
[ 9.556] (II) Initializing extension DRI2
[ 9.556] (II) Initializing extension NV-GLX
[ 9.556] (II) Initializing extension NV-CONTROL
[ 9.556] (II) Initializing extension XINERAMA
[ 9.602] (II) config/udev: Adding input device Power Button (/dev/input/event2)
[ 9.602] (**) Power Button: Applying InputClass "devname"
[ 9.602] (**) Power Button: Applying InputClass "libinput keyboard catchall"
[ 9.602] (**) Power Button: Applying InputClass "system-keyboard"
[ 9.602] (II) LoadModule: "libinput"
[ 9.602] (II) Loading /usr/lib/xorg/modules/input/libinput_drv.so
[ 9.605] (II) Module libinput: vendor="X.Org Foundation"
[ 9.605] compiled for 1.21.1.8, module version = 1.4.0
[ 9.605] Module class: X.Org XInput Driver
[ 9.605] ABI class: X.Org XInput driver, version 24.4
[ 9.605] (II) Using input driver 'libinput' for 'Power Button'
[ 9.605] (II) systemd-logind: got fd for /dev/input/event2 13:66 fd 38 paused 0
[ 9.605] (**) Power Button: always reports core events
[ 9.605] (**) Option "Device" "/dev/input/event2"
[ 9.608] (II) event2 - Power Button: is tagged by udev as: Keyboard
[ 9.608] (II) event2 - Power Button: device is a keyboard
[ 9.608] (II) event2 - Power Button: device removed
[ 9.608] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXPWRBN:00/input/input2/event2"
[ 9.608] (II) XINPUT: Adding extended input device "Power Button" (type: KEYBOARD, id 6)
[ 9.608] (**) Option "xkb_layout" "us"
[ 9.609] (II) event2 - Power Button: is tagged by udev as: Keyboard
[ 9.609] (II) event2 - Power Button: device is a keyboard
[ 9.609] (II) config/udev: Adding input device Power Button (/dev/input/event1)
[ 9.609] (**) Power Button: Applying InputClass "devname"
[ 9.609] (**) Power Button: Applying InputClass "libinput keyboard catchall"
[ 9.609] (**) Power Button: Applying InputClass "system-keyboard"
[ 9.609] (II) Using input driver 'libinput' for 'Power Button'
[ 9.610] (II) systemd-logind: got fd for /dev/input/event1 13:65 fd 41 paused 0
[ 9.610] (**) Power Button: always reports core events
[ 9.610] (**) Option "Device" "/dev/input/event1"
[ 9.610] (II) event1 - Power Button: is tagged by udev as: Keyboard
[ 9.610] (II) event1 - Power Button: device is a keyboard
[ 9.611] (II) event1 - Power Button: device removed
[ 9.611] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0C:00/input/input1/event1"
[ 9.611] (II) XINPUT: Adding extended input device "Power Button" (type: KEYBOARD, id 7)
[ 9.611] (**) Option "xkb_layout" "us"
[ 9.611] (II) event1 - Power Button: is tagged by udev as: Keyboard
[ 9.611] (II) event1 - Power Button: device is a keyboard
[ 9.612] (II) config/udev: Adding input device Sleep Button (/dev/input/event0)
[ 9.612] (**) Sleep Button: Applying InputClass "devname"
[ 9.612] (**) Sleep Button: Applying InputClass "libinput keyboard catchall"
[ 9.612] (**) Sleep Button: Applying InputClass "system-keyboard"
[ 9.612] (II) Using input driver 'libinput' for 'Sleep Button'
[ 9.612] (II) systemd-logind: got fd for /dev/input/event0 13:64 fd 42 paused 0
[ 9.612] (**) Sleep Button: always reports core events
[ 9.612] (**) Option "Device" "/dev/input/event0"
[ 9.613] (II) event0 - Sleep Button: is tagged by udev as: Keyboard
[ 9.613] (II) event0 - Sleep Button: device is a keyboard
[ 9.613] (II) event0 - Sleep Button: device removed
[ 9.613] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0E:00/input/input0/event0"
[ 9.613] (II) XINPUT: Adding extended input device "Sleep Button" (type: KEYBOARD, id 8)
[ 9.613] (**) Option "xkb_layout" "us"
[ 9.614] (II) event0 - Sleep Button: device is a keyboard
[ 9.614] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=3 (/dev/input/event12)
[ 9.614] (**) HDA NVidia HDMI/DP,pcm=3: Applying InputClass "devname"
[ 9.614] (II) Using input driver 'libinput' for 'HDA NVidia HDMI/DP,pcm=3'
[ 9.614] (II) systemd-logind: got fd for /dev/input/event12 13:76 fd 43 paused 0
[ 9.614] (**) HDA NVidia HDMI/DP,pcm=3: always reports core events
[ 9.614] (**) Option "Device" "/dev/input/event12"
[ 9.615] (II) event12 - HDA NVidia HDMI/DP,pcm=3: is tagged by udev as: Switch
[ 9.615] (II) event12 - not using input device '/dev/input/event12'.
[ 9.615] (EE) libinput: HDA NVidia HDMI/DP,pcm=3: Failed to create a device for /dev/input/event12
[ 9.615] (EE) PreInit returned 2 for "HDA NVidia HDMI/DP,pcm=3"
[ 9.615] (II) UnloadModule: "libinput"
[ 9.615] (II) systemd-logind: releasing fd for 13:76
[ 9.616] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=7 (/dev/input/event13)
[ 9.616] (**) HDA NVidia HDMI/DP,pcm=7: Applying InputClass "devname"
[ 9.616] (II) Using input driver 'libinput' for 'HDA NVidia HDMI/DP,pcm=7'
[ 9.616] (II) systemd-logind: got fd for /dev/input/event13 13:77 fd 43 paused 0
[ 9.616] (**) HDA NVidia HDMI/DP,pcm=7: always reports core events
[ 9.616] (**) Option "Device" "/dev/input/event13"
[ 9.617] (II) event13 - HDA NVidia HDMI/DP,pcm=7: is tagged by udev as: Switch
[ 9.617] (II) event13 - not using input device '/dev/input/event13'.
[ 9.617] (EE) libinput: HDA NVidia HDMI/DP,pcm=7: Failed to create a device for /dev/input/event13
[ 9.617] (EE) PreInit returned 2 for "HDA NVidia HDMI/DP,pcm=7"
[ 9.617] (II) UnloadModule: "libinput"
[ 9.617] (II) systemd-logind: releasing fd for 13:77
[ 9.617] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=8 (/dev/input/event14)
[ 9.617] (**) HDA NVidia HDMI/DP,pcm=8: Applying InputClass "devname"
[ 9.617] (II) Using input driver 'libinput' for 'HDA NVidia HDMI/DP,pcm=8'
[ 9.618] (II) systemd-logind: got fd for /dev/input/event14 13:78 fd 43 paused 0
[ 9.618] (**) HDA NVidia HDMI/DP,pcm=8: always reports core events
[ 9.618] (**) Option "Device" "/dev/input/event14"
[ 9.618] (II) event14 - HDA NVidia HDMI/DP,pcm=8: is tagged by udev as: Switch
[ 9.619] (II) event14 - not using input device '/dev/input/event14'.
[ 9.619] (EE) libinput: HDA NVidia HDMI/DP,pcm=8: Failed to create a device for /dev/input/event14
[ 9.619] (EE) PreInit returned 2 for "HDA NVidia HDMI/DP,pcm=8"
[ 9.619] (II) UnloadModule: "libinput"
[ 9.619] (II) systemd-logind: releasing fd for 13:78
[ 9.619] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=9 (/dev/input/event15)
[ 9.619] (**) HDA NVidia HDMI/DP,pcm=9: Applying InputClass "devname"
[ 9.619] (II) Using input driver 'libinput' for 'HDA NVidia HDMI/DP,pcm=9'
[ 9.619] (II) systemd-logind: got fd for /dev/input/event15 13:79 fd 43 paused 0
[ 9.619] (**) HDA NVidia HDMI/DP,pcm=9: always reports core events
[ 9.619] (**) Option "Device" "/dev/input/event15"
[ 9.620] (II) event15 - HDA NVidia HDMI/DP,pcm=9: is tagged by udev as: Switch
[ 9.620] (II) event15 - not using input device '/dev/input/event15'.
[ 9.620] (EE) libinput: HDA NVidia HDMI/DP,pcm=9: Failed to create a device for /dev/input/event15
[ 9.620] (EE) PreInit returned 2 for "HDA NVidia HDMI/DP,pcm=9"
[ 9.620] (II) UnloadModule: "libinput"
[ 9.620] (II) systemd-logind: releasing fd for 13:79
[ 9.621] (II) config/udev: Adding input device Razer Razer Ornata Chroma (/dev/input/event3)
[ 9.621] (**) Razer Razer Ornata Chroma: Applying InputClass "devname"
[ 9.621] (**) Razer Razer Ornata Chroma: Applying InputClass "libinput keyboard catchall"
[ 9.621] (**) Razer Razer Ornata Chroma: Applying InputClass "system-keyboard"
[ 9.621] (II) Using input driver 'libinput' for 'Razer Razer Ornata Chroma'
[ 9.621] (II) systemd-logind: got fd for /dev/input/event3 13:67 fd 43 paused 0
[ 9.621] (**) Razer Razer Ornata Chroma: always reports core events
[ 9.621] (**) Option "Device" "/dev/input/event3"
[ 9.622] (II) event3 - Razer Razer Ornata Chroma: is tagged by udev as: Keyboard
[ 9.622] (II) event3 - Razer Razer Ornata Chroma: device is a keyboard
[ 9.622] (II) event3 - Razer Razer Ornata Chroma: device removed
[ 9.622] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:14.0/usb1/1-1/1-1:1.0/0003:1532:021E.0001/input/input3/event3"
[ 9.622] (II) XINPUT: Adding extended input device "Razer Razer Ornata Chroma" (type: KEYBOARD, id 9)
[ 9.622] (**) Option "xkb_layout" "us"
[ 9.623] (II) event3 - Razer Razer Ornata Chroma: is tagged by udev as: Keyboard
[ 9.623] (II) event3 - Razer Razer Ornata Chroma: device is a keyboard
[ 9.624] (II) config/udev: Adding input device Razer Razer Ornata Chroma Keyboard (/dev/input/event4)
[ 9.624] (**) Razer Razer Ornata Chroma Keyboard: Applying InputClass "devname"
[ 9.624] (**) Razer Razer Ornata Chroma Keyboard: Applying InputClass "libinput keyboard catchall"
[ 9.624] (**) Razer Razer Ornata Chroma Keyboard: Applying InputClass "system-keyboard"
[ 9.624] (II) Using input driver 'libinput' for 'Razer Razer Ornata Chroma Keyboard'
[ 9.625] (II) systemd-logind: got fd for /dev/input/event4 13:68 fd 44 paused 0
[ 9.625] (**) Razer Razer Ornata Chroma Keyboard: always reports core events
[ 9.625] (**) Option "Device" "/dev/input/event4"
[ 9.626] (II) event4 - Razer Razer Ornata Chroma Keyboard: is tagged by udev as: Keyboard
[ 9.626] (II) event4 - Razer Razer Ornata Chroma Keyboard: device is a keyboard
[ 9.626] (II) event4 - Razer Razer Ornata Chroma Keyboard: device removed
[ 9.626] (II) libinput: Razer Razer Ornata Chroma Keyboard: needs a virtual subdevice
[ 9.626] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:14.0/usb1/1-1/1-1:1.1/0003:1532:021E.0002/input/input4/event4"
[ 9.626] (II) XINPUT: Adding extended input device "Razer Razer Ornata Chroma Keyboard" (type: MOUSE, id 10)
[ 9.626] (**) Option "AccelerationScheme" "none"
[ 9.626] (**) Razer Razer Ornata Chroma Keyboard: (accel) selected scheme none/0
[ 9.626] (**) Razer Razer Ornata Chroma Keyboard: (accel) acceleration factor: 2.000
[ 9.626] (**) Razer Razer Ornata Chroma Keyboard: (accel) acceleration threshold: 4
[ 9.627] (II) event4 - Razer Razer Ornata Chroma Keyboard: is tagged by udev as: Keyboard
[ 9.627] (II) event4 - Razer Razer Ornata Chroma Keyboard: device is a keyboard
[ 9.628] (II) config/udev: Adding input device Razer Razer Ornata Chroma (/dev/input/event5)
[ 9.628] (**) Razer Razer Ornata Chroma: Applying InputClass "devname"
[ 9.628] (II) Using input driver 'libinput' for 'Razer Razer Ornata Chroma'
[ 9.628] (II) systemd-logind: got fd for /dev/input/event5 13:69 fd 45 paused 0
[ 9.628] (**) Razer Razer Ornata Chroma: always reports core events
[ 9.628] (**) Option "Device" "/dev/input/event5"
[ 9.629] (II) event5 - Razer Razer Ornata Chroma: not tagged as supported input device
[ 9.629] (II) event5 - not using input device '/dev/input/event5'.
[ 9.629] (EE) libinput: Razer Razer Ornata Chroma: Failed to create a device for /dev/input/event5
[ 9.629] (EE) PreInit returned 2 for "Razer Razer Ornata Chroma"
[ 9.629] (II) UnloadModule: "libinput"
[ 9.629] (II) systemd-logind: releasing fd for 13:69
[ 9.630] (II) config/udev: Adding input device Razer Razer Ornata Chroma (/dev/input/event6)
[ 9.630] (**) Razer Razer Ornata Chroma: Applying InputClass "devname"
[ 9.630] (**) Razer Razer Ornata Chroma: Applying InputClass "libinput pointer catchall"
[ 9.630] (II) Using input driver 'libinput' for 'Razer Razer Ornata Chroma'
[ 9.682] (II) systemd-logind: got fd for /dev/input/event6 13:70 fd 45 paused 0
[ 9.682] (**) Razer Razer Ornata Chroma: always reports core events
[ 9.682] (**) Option "Device" "/dev/input/event6"
[ 9.682] (II) event6 - Razer Razer Ornata Chroma: is tagged by udev as: Mouse
[ 9.683] (II) event6 - Razer Razer Ornata Chroma: device is a pointer
[ 9.683] (II) event6 - Razer Razer Ornata Chroma: device removed
[ 9.683] (II) libinput: Razer Razer Ornata Chroma: Step value 0 was provided, libinput Fallback acceleration function is used.
[ 9.683] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:14.0/usb1/1-1/1-1:1.2/0003:1532:021E.0003/input/input6/event6"
[ 9.683] (II) XINPUT: Adding extended input device "Razer Razer Ornata Chroma" (type: MOUSE, id 11)
[ 9.683] (**) Option "AccelerationScheme" "none"
[ 9.683] (**) Razer Razer Ornata Chroma: (accel) selected scheme none/0
[ 9.683] (**) Razer Razer Ornata Chroma: (accel) acceleration factor: 2.000
[ 9.683] (**) Razer Razer Ornata Chroma: (accel) acceleration threshold: 4
[ 9.683] (II) event6 - Razer Razer Ornata Chroma: is tagged by udev as: Mouse
[ 9.684] (II) config/udev: Adding input device Razer Razer Ornata Chroma (/dev/input/mouse0)
[ 9.684] (**) Razer Razer Ornata Chroma: Applying InputClass "devname"
[ 9.684] (II) Using input driver 'libinput' for 'Razer Razer Ornata Chroma'
[ 9.684] (**) Razer Razer Ornata Chroma: always reports core events
[ 9.684] (**) Option "Device" "/dev/input/mouse0"
[ 9.684] (EE) xf86OpenSerial: Cannot open device /dev/input/mouse0
Permission denied.
[ 9.684] (II) mouse0: opening input device '/dev/input/mouse0' failed (Permission denied).
[ 9.684] (II) mouse0 - failed to create input device '/dev/input/mouse0'.
[ 9.684] (EE) libinput: Razer Razer Ornata Chroma: Failed to create a device for /dev/input/mouse0
[ 9.684] (EE) PreInit returned 2 for "Razer Razer Ornata Chroma"
[ 9.684] (II) UnloadModule: "libinput"
[ 9.684] (II) config/udev: Adding input device Logitech G102 LIGHTSYNC Gaming Mouse (/dev/input/event7)
[ 9.684] (**) Logitech G102 LIGHTSYNC Gaming Mouse: Applying InputClass "devname"
[ 9.684] (**) Logitech G102 LIGHTSYNC Gaming Mouse: Applying InputClass "libinput pointer catchall"
[ 9.684] (II) Using input driver 'libinput' for 'Logitech G102 LIGHTSYNC Gaming Mouse'
[ 9.737] (II) systemd-logind: got fd for /dev/input/event7 13:71 fd 46 paused 0
[ 9.737] (**) Logitech G102 LIGHTSYNC Gaming Mouse: always reports core events
[ 9.737] (**) Option "Device" "/dev/input/event7"
[ 9.737] (II) event7 - Logitech G102 LIGHTSYNC Gaming Mouse: is tagged by udev as: Mouse
[ 9.738] (II) event7 - Logitech G102 LIGHTSYNC Gaming Mouse: device is a pointer
[ 9.738] (II) event7 - Logitech G102 LIGHTSYNC Gaming Mouse: device removed
[ 9.738] (II) libinput: Logitech G102 LIGHTSYNC Gaming Mouse: Step value 0 was provided, libinput Fallback acceleration function is used.
[ 9.738] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:14.0/usb1/1-2/1-2:1.0/0003:046D:C092.0004/input/input7/event7"
[ 9.738] (II) XINPUT: Adding extended input device "Logitech G102 LIGHTSYNC Gaming Mouse" (type: MOUSE, id 12)
[ 9.738] (**) Option "AccelerationScheme" "none"
[ 9.738] (**) Logitech G102 LIGHTSYNC Gaming Mouse: (accel) selected scheme none/0
[ 9.738] (**) Logitech G102 LIGHTSYNC Gaming Mouse: (accel) acceleration factor: 2.000
[ 9.738] (**) Logitech G102 LIGHTSYNC Gaming Mouse: (accel) acceleration threshold: 4
[ 9.738] (II) event7 - Logitech G102 LIGHTSYNC Gaming Mouse: is tagged by udev as: Mouse
[ 9.739] (II) event7 - Logitech G102 LIGHTSYNC Gaming Mouse: device is a pointer
[ 9.739] (II) config/udev: Adding input device Logitech G102 LIGHTSYNC Gaming Mouse (/dev/input/mouse1)
[ 9.739] (**) Logitech G102 LIGHTSYNC Gaming Mouse: Applying InputClass "devname"
[ 9.739] (II) Using input driver 'libinput' for 'Logitech G102 LIGHTSYNC Gaming Mouse'
[ 9.739] (**) Logitech G102 LIGHTSYNC Gaming Mouse: always reports core events
[ 9.739] (**) Option "Device" "/dev/input/mouse1"
[ 9.739] (EE) xf86OpenSerial: Cannot open device /dev/input/mouse1
Permission denied.
[ 9.739] (II) mouse1: opening input device '/dev/input/mouse1' failed (Permission denied).
[ 9.739] (II) mouse1 - failed to create input device '/dev/input/mouse1'.
[ 9.739] (EE) libinput: Logitech G102 LIGHTSYNC Gaming Mouse: Failed to create a device for /dev/input/mouse1
[ 9.739] (EE) PreInit returned 2 for "Logitech G102 LIGHTSYNC Gaming Mouse"
[ 9.739] (II) UnloadModule: "libinput"
[ 9.739] (II) config/udev: Adding input device Logitech G102 LIGHTSYNC Gaming Mouse Keyboard (/dev/input/event8)
[ 9.739] (**) Logitech G102 LIGHTSYNC Gaming Mouse Keyboard: Applying InputClass "devname"
[ 9.739] (**) Logitech G102 LIGHTSYNC Gaming Mouse Keyboard: Applying InputClass "libinput keyboard catchall"
[ 9.740] (**) Logitech G102 LIGHTSYNC Gaming Mouse Keyboard: Applying InputClass "system-keyboard"
[ 9.740] (II) Using input driver 'libinput' for 'Logitech G102 LIGHTSYNC Gaming Mouse Keyboard'
[ 9.740] (II) systemd-logind: got fd for /dev/input/event8 13:72 fd 47 paused 0
[ 9.740] (**) Logitech G102 LIGHTSYNC Gaming Mouse Keyboard: always reports core events
[ 9.740] (**) Option "Device" "/dev/input/event8"
[ 9.741] (II) event8 - Logitech G102 LIGHTSYNC Gaming Mouse Keyboard: is tagged by udev as: Keyboard
[ 9.741] (II) event8 - Logitech G102 LIGHTSYNC Gaming Mouse Keyboard: device is a keyboard
[ 9.741] (II) event8 - Logitech G102 LIGHTSYNC Gaming Mouse Keyboard: device removed
[ 9.741] (II) libinput: Logitech G102 LIGHTSYNC Gaming Mouse Keyboard: needs a virtual subdevice
[ 9.741] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:14.0/usb1/1-2/1-2:1.1/0003:046D:C092.0005/input/input8/event8"
[ 9.741] (II) XINPUT: Adding extended input device "Logitech G102 LIGHTSYNC Gaming Mouse Keyboard" (type: MOUSE, id 13)
[ 9.741] (**) Option "AccelerationScheme" "none"
[ 9.741] (**) Logitech G102 LIGHTSYNC Gaming Mouse Keyboard: (accel) selected scheme none/0
[ 9.741] (**) Logitech G102 LIGHTSYNC Gaming Mouse Keyboard: (accel) acceleration factor: 2.000
[ 9.741] (**) Logitech G102 LIGHTSYNC Gaming Mouse Keyboard: (accel) acceleration threshold: 4
[ 9.742] (II) event8 - Logitech G102 LIGHTSYNC Gaming Mouse Keyboard: is tagged by udev as: Keyboard
[ 9.742] (II) event8 - Logitech G102 LIGHTSYNC Gaming Mouse Keyboard: device is a keyboard
[ 9.742] (II) config/udev: Adding input device Logitech PRO X Consumer Control (/dev/input/event9)
[ 9.742] (**) Logitech PRO X Consumer Control: Applying InputClass "devname"
[ 9.742] (**) Logitech PRO X Consumer Control: Applying InputClass "libinput keyboard catchall"
[ 9.742] (**) Logitech PRO X Consumer Control: Applying InputClass "system-keyboard"
[ 9.742] (II) Using input driver 'libinput' for 'Logitech PRO X Consumer Control'
[ 9.743] (II) systemd-logind: got fd for /dev/input/event9 13:73 fd 48 paused 0
[ 9.743] (**) Logitech PRO X Consumer Control: always reports core events
[ 9.743] (**) Option "Device" "/dev/input/event9"
[ 9.743] (II) event9 - Logitech PRO X Consumer Control: is tagged by udev as: Keyboard
[ 9.743] (II) event9 - Logitech PRO X Consumer Control: device is a keyboard
[ 9.744] (II) event9 - Logitech PRO X Consumer Control: device removed
[ 9.744] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:14.0/usb1/1-4/1-4:1.3/0003:046D:0AAA.0006/input/input11/event9"
[ 9.744] (II) XINPUT: Adding extended input device "Logitech PRO X Consumer Control" (type: KEYBOARD, id 14)
[ 9.744] (**) Option "xkb_layout" "us"
[ 9.744] (II) event9 - Logitech PRO X Consumer Control: is tagged by udev as: Keyboard
[ 9.744] (II) event9 - Logitech PRO X Consumer Control: device is a keyboard
[ 9.745] (II) config/udev: Adding input device Logitech PRO X (/dev/input/event10)
[ 9.745] (**) Logitech PRO X: Applying InputClass "devname"
[ 9.745] (**) Logitech PRO X: Applying InputClass "libinput keyboard catchall"
[ 9.745] (**) Logitech PRO X: Applying InputClass "system-keyboard"
[ 9.745] (II) Using input driver 'libinput' for 'Logitech PRO X'
[ 9.745] (II) systemd-logind: got fd for /dev/input/event10 13:74 fd 49 paused 0
[ 9.746] (**) Logitech PRO X: always reports core events
[ 9.746] (**) Option "Device" "/dev/input/event10"
[ 9.746] (II) event10 - Logitech PRO X: is tagged by udev as: Keyboard
[ 9.746] (II) event10 - Logitech PRO X: device is a keyboard
[ 9.746] (II) event10 - Logitech PRO X: device removed
[ 9.746] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:14.0/usb1/1-4/1-4:1.3/0003:046D:0AAA.0006/input/input12/event10"
[ 9.746] (II) XINPUT: Adding extended input device "Logitech PRO X" (type: KEYBOARD, id 15)
[ 9.746] (**) Option "xkb_layout" "us"
[ 9.747] (II) event10 - Logitech PRO X: is tagged by udev as: Keyboard
[ 9.747] (II) event10 - Logitech PRO X: device is a keyboard
[ 9.748] (II) config/udev: Adding input device HDA Intel PCH Front Mic (/dev/input/event16)
[ 9.748] (**) HDA Intel PCH Front Mic: Applying InputClass "devname"
[ 9.748] (II) Using input driver 'libinput' for 'HDA Intel PCH Front Mic'
[ 9.748] (II) systemd-logind: got fd for /dev/input/event16 13:80 fd 50 paused 0
[ 9.748] (**) HDA Intel PCH Front Mic: always reports core events
[ 9.748] (**) Option "Device" "/dev/input/event16"
[ 9.749] (II) event16 - HDA Intel PCH Front Mic: is tagged by udev as: Switch
[ 9.749] (II) event16 - not using input device '/dev/input/event16'.
[ 9.749] (EE) libinput: HDA Intel PCH Front Mic: Failed to create a device for /dev/input/event16
[ 9.749] (EE) PreInit returned 2 for "HDA Intel PCH Front Mic"
[ 9.749] (II) UnloadModule: "libinput"
[ 9.749] (II) systemd-logind: releasing fd for 13:80
[ 9.749] (II) config/udev: Adding input device HDA Intel PCH Rear Mic (/dev/input/event17)
[ 9.749] (**) HDA Intel PCH Rear Mic: Applying InputClass "devname"
[ 9.749] (II) Using input driver 'libinput' for 'HDA Intel PCH Rear Mic'
[ 9.750] (II) systemd-logind: got fd for /dev/input/event17 13:81 fd 50 paused 0
[ 9.750] (**) HDA Intel PCH Rear Mic: always reports core events
[ 9.750] (**) Option "Device" "/dev/input/event17"
[ 9.750] (II) event17 - HDA Intel PCH Rear Mic: is tagged by udev as: Switch
[ 9.750] (II) event17 - not using input device '/dev/input/event17'.
[ 9.750] (EE) libinput: HDA Intel PCH Rear Mic: Failed to create a device for /dev/input/event17
[ 9.750] (EE) PreInit returned 2 for "HDA Intel PCH Rear Mic"
[ 9.750] (II) UnloadModule: "libinput"
[ 9.750] (II) systemd-logind: releasing fd for 13:81
[ 9.751] (II) config/udev: Adding input device HDA Intel PCH Line (/dev/input/event18)
[ 9.751] (**) HDA Intel PCH Line: Applying InputClass "devname"
[ 9.751] (II) Using input driver 'libinput' for 'HDA Intel PCH Line'
[ 9.751] (II) systemd-logind: got fd for /dev/input/event18 13:82 fd 50 paused 0
[ 9.751] (**) HDA Intel PCH Line: always reports core events
[ 9.751] (**) Option "Device" "/dev/input/event18"
[ 9.752] (II) event18 - HDA Intel PCH Line: is tagged by udev as: Switch
[ 9.752] (II) event18 - not using input device '/dev/input/event18'.
[ 9.752] (EE) libinput: HDA Intel PCH Line: Failed to create a device for /dev/input/event18
[ 9.752] (EE) PreInit returned 2 for "HDA Intel PCH Line"
[ 9.752] (II) UnloadModule: "libinput"
[ 9.752] (II) systemd-logind: releasing fd for 13:82
[ 9.752] (II) config/udev: Adding input device HDA Intel PCH Line Out (/dev/input/event19)
[ 9.752] (**) HDA Intel PCH Line Out: Applying InputClass "devname"
[ 9.752] (II) Using input driver 'libinput' for 'HDA Intel PCH Line Out'
[ 9.753] (II) systemd-logind: got fd for /dev/input/event19 13:83 fd 50 paused 0
[ 9.753] (**) HDA Intel PCH Line Out: always reports core events
[ 9.753] (**) Option "Device" "/dev/input/event19"
[ 9.753] (II) event19 - HDA Intel PCH Line Out: is tagged by udev as: Switch
[ 9.753] (II) event19 - not using input device '/dev/input/event19'.
[ 9.753] (EE) libinput: HDA Intel PCH Line Out: Failed to create a device for /dev/input/event19
[ 9.753] (EE) PreInit returned 2 for "HDA Intel PCH Line Out"
[ 9.753] (II) UnloadModule: "libinput"
[ 9.753] (II) systemd-logind: releasing fd for 13:83
[ 9.754] (II) config/udev: Adding input device HDA Intel PCH Front Headphone (/dev/input/event20)
[ 9.754] (**) HDA Intel PCH Front Headphone: Applying InputClass "devname"
[ 9.754] (II) Using input driver 'libinput' for 'HDA Intel PCH Front Headphone'
[ 9.754] (II) systemd-logind: got fd for /dev/input/event20 13:84 fd 50 paused 0
[ 9.754] (**) HDA Intel PCH Front Headphone: always reports core events
[ 9.754] (**) Option "Device" "/dev/input/event20"
[ 9.754] (II) event20 - HDA Intel PCH Front Headphone: is tagged by udev as: Switch
[ 9.755] (II) event20 - not using input device '/dev/input/event20'.
[ 9.755] (EE) libinput: HDA Intel PCH Front Headphone: Failed to create a device for /dev/input/event20
[ 9.755] (EE) PreInit returned 2 for "HDA Intel PCH Front Headphone"
[ 9.755] (II) UnloadModule: "libinput"
[ 9.755] (II) systemd-logind: releasing fd for 13:84
[ 9.755] (II) config/udev: Adding input device PC Speaker (/dev/input/event11)
[ 9.755] (**) PC Speaker: Applying InputClass "devname"
[ 9.755] (II) Using input driver 'libinput' for 'PC Speaker'
[ 9.755] (II) systemd-logind: got fd for /dev/input/event11 13:75 fd 50 paused 0
[ 9.755] (**) PC Speaker: always reports core events
[ 9.755] (**) Option "Device" "/dev/input/event11"
[ 9.756] (II) event11 - PC Speaker: not tagged as supported input device
[ 9.756] (II) event11 - not using input device '/dev/input/event11'.
[ 9.756] (EE) libinput: PC Speaker: Failed to create a device for /dev/input/event11
[ 9.756] (EE) PreInit returned 2 for "PC Speaker"
[ 9.756] (II) UnloadModule: "libinput"
[ 9.756] (II) systemd-logind: releasing fd for 13:75
[ 9.760] (**) Razer Razer Ornata Chroma Keyboard: Applying InputClass "devname"
[ 9.760] (**) Razer Razer Ornata Chroma Keyboard: Applying InputClass "libinput keyboard catchall"
[ 9.760] (**) Razer Razer Ornata Chroma Keyboard: Applying InputClass "system-keyboard"
[ 9.760] (II) Using input driver 'libinput' for 'Razer Razer Ornata Chroma Keyboard'
[ 9.760] (II) systemd-logind: returning pre-existing fd for /dev/input/event4 13:68
[ 9.760] (**) Razer Razer Ornata Chroma Keyboard: always reports core events
[ 9.760] (**) Option "Device" "/dev/input/event4"
[ 9.760] (II) libinput: Razer Razer Ornata Chroma Keyboard: is a virtual subdevice
[ 9.760] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:14.0/usb1/1-1/1-1:1.1/0003:1532:021E.0002/input/input4/event4"
[ 9.760] (II) XINPUT: Adding extended input device "Razer Razer Ornata Chroma Keyboard" (type: KEYBOARD, id 16)
[ 9.760] (**) Option "xkb_layout" "us"
[ 9.760] (**) Logitech G102 LIGHTSYNC Gaming Mouse Keyboard: Applying InputClass "devname"
[ 9.760] (**) Logitech G102 LIGHTSYNC Gaming Mouse Keyboard: Applying InputClass "libinput keyboard catchall"
[ 9.760] (**) Logitech G102 LIGHTSYNC Gaming Mouse Keyboard: Applying InputClass "system-keyboard"
[ 9.760] (II) Using input driver 'libinput' for 'Logitech G102 LIGHTSYNC Gaming Mouse Keyboard'
[ 9.760] (II) systemd-logind: returning pre-existing fd for /dev/input/event8 13:72
[ 9.760] (**) Logitech G102 LIGHTSYNC Gaming Mouse Keyboard: always reports core events
[ 9.760] (**) Option "Device" "/dev/input/event8"
[ 9.760] (II) libinput: Logitech G102 LIGHTSYNC Gaming Mouse Keyboard: is a virtual subdevice
[ 9.760] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:14.0/usb1/1-2/1-2:1.1/0003:046D:C092.0005/input/input8/event8"
[ 9.760] (II) XINPUT: Adding extended input device "Logitech G102 LIGHTSYNC Gaming Mouse Keyboard" (type: KEYBOARD, id 17)
[ 10.538] (--) NVIDIA(GPU-0): BenQ ZOWIE XL LCD (DFP-0): connected
[ 10.538] (--) NVIDIA(GPU-0): BenQ ZOWIE XL LCD (DFP-0): Internal DisplayPort
[ 10.538] (--) NVIDIA(GPU-0): BenQ ZOWIE XL LCD (DFP-0): 2660.0 MHz maximum pixel clock
[ 10.540] (--) NVIDIA(GPU-0): DFP-1: disconnected
[ 10.540] (--) NVIDIA(GPU-0): DFP-1: Internal TMDS
[ 10.540] (--) NVIDIA(GPU-0): DFP-1: 165.0 MHz maximum pixel clock
[ 10.540] (--) NVIDIA(GPU-0): DFP-2: disconnected
[ 10.540] (--) NVIDIA(GPU-0): DFP-2: Internal DisplayPort
[ 10.540] (--) NVIDIA(GPU-0): DFP-2: 2660.0 MHz maximum pixel clock
[ 10.540] (--) NVIDIA(GPU-0): DFP-3: disconnected
[ 10.540] (--) NVIDIA(GPU-0): DFP-3: Internal TMDS
[ 10.540] (--) NVIDIA(GPU-0): DFP-3: 165.0 MHz maximum pixel clock
[ 10.540] (--) NVIDIA(GPU-0): DFP-4: disconnected
[ 10.540] (--) NVIDIA(GPU-0): DFP-4: Internal TMDS
[ 10.540] (--) NVIDIA(GPU-0): DFP-4: 165.0 MHz maximum pixel clock
[ 10.540] (--) NVIDIA(GPU-0): DFP-5: disconnected
[ 10.540] (--) NVIDIA(GPU-0): DFP-5: Internal DisplayPort
[ 10.540] (--) NVIDIA(GPU-0): DFP-5: 2660.0 MHz maximum pixel clock
[ 10.540] (--) NVIDIA(GPU-0): DFP-6: disconnected
[ 10.540] (--) NVIDIA(GPU-0): DFP-6: Internal TMDS
[ 10.540] (--) NVIDIA(GPU-0): DFP-6: 165.0 MHz maximum pixel clock
[ 10.693] (II) NVIDIA(0): Setting mode "DP-0: 1920x1080_144 @1920x1080 +0+0 {ViewPortIn=1920x1080, ViewPortOut=1920x1080+0+0}"
[ 10.936] (--) NVIDIA(GPU-0): BenQ ZOWIE XL LCD (DFP-0): connected
[ 10.936] (--) NVIDIA(GPU-0): BenQ ZOWIE XL LCD (DFP-0): Internal DisplayPort
[ 10.936] (--) NVIDIA(GPU-0): BenQ ZOWIE XL LCD (DFP-0): 2660.0 MHz maximum pixel clock
[ 10.938] (--) NVIDIA(GPU-0): DFP-1: disconnected
[ 10.938] (--) NVIDIA(GPU-0): DFP-1: Internal TMDS
[ 10.938] (--) NVIDIA(GPU-0): DFP-1: 165.0 MHz maximum pixel clock
[ 10.938] (--) NVIDIA(GPU-0): DFP-2: disconnected
[ 10.938] (--) NVIDIA(GPU-0): DFP-2: Internal DisplayPort
[ 10.938] (--) NVIDIA(GPU-0): DFP-2: 2660.0 MHz maximum pixel clock
[ 10.938] (--) NVIDIA(GPU-0): DFP-3: disconnected
[ 10.938] (--) NVIDIA(GPU-0): DFP-3: Internal TMDS
[ 10.938] (--) NVIDIA(GPU-0): DFP-3: 165.0 MHz maximum pixel clock
[ 10.938] (--) NVIDIA(GPU-0): DFP-4: disconnected
[ 10.938] (--) NVIDIA(GPU-0): DFP-4: Internal TMDS
[ 10.938] (--) NVIDIA(GPU-0): DFP-4: 165.0 MHz maximum pixel clock
[ 10.938] (--) NVIDIA(GPU-0): DFP-5: disconnected
[ 10.938] (--) NVIDIA(GPU-0): DFP-5: Internal DisplayPort
[ 10.938] (--) NVIDIA(GPU-0): DFP-5: 2660.0 MHz maximum pixel clock
[ 10.938] (--) NVIDIA(GPU-0): DFP-6: disconnected
[ 10.938] (--) NVIDIA(GPU-0): DFP-6: Internal TMDS
[ 10.938] (--) NVIDIA(GPU-0): DFP-6: 165.0 MHz maximum pixel clock
I solved the problem after completely cleaning the computer, changing the thermal paste, and updating the bios to the latest version
