We have 40 servers with 4 GPUs (4x Tesla P100 NVLink PCIe). The last GPU keeps disappearing. We have reseated the GPUs and verified cooling is functioning, server is located mid-rack (other servers are racked higher with no issues). After a reboot, the GPU will function for a short time and then disappear again. I reviewed this forum and ran “nvidia-bug-report.sh”. I have attached the log below, hopefully, someone could help diagnose this problem.
nvidia-bug-report.sh log:
Start of NVIDIA bug report log file. Please include this file, along
with a detailed description of your problem, when reporting a graphics
driver bug via the NVIDIA Linux forum (see devtalk.nvidia.com)
or by sending email to ‘linux-bugs@nvidia.com’.
nvidia-bug-report.sh Version: 22518575
Date: Fri Oct 12 23:52:14 UTC 2018
uname: Linux enrichmentgpu-prd105.tripod.gq1.yahoo.com 3.10.0-514.26.2.el7.YAHOO.20170707.8.x86_64 #1 SMP Fri Jul 7 21:48:18 UTC 2017 x86_64 x86_64 x86_64 GNU/Linux
command line flags:
*** /etc/issue
*** ls: -rw-r–r-- 1 root root 23 2015-02-02 11:46:09.000000000 +0000 /etc/issue
\S
Kernel \r on an \m
*** /etc/redhat-release
*** ls: -rw-r–r-- 1 root root 52 2015-02-02 11:46:09.000000000 +0000 /etc/redhat-release
Red Hat Enterprise Linux Server release 7.1 (Maipo)
*** /var/log/nvidia-installer.log
*** ls: -rw-r–r-- 1 root root 29341 2017-08-24 14:18:54.574436144 +0000 /var/log/nvidia-installer.log
nvidia-installer log file ‘/var/log/nvidia-installer.log’
creation time: Thu Aug 24 14:18:37 2017
installer version: 384.66
PATH: /sbin:/usr/sbin:/bin:/usr/bin:/home/y/bin:/usr/local/bin:/usr/X11R6/bin:/home/y/bin64
nvidia-installer command line:
./nvidia-installer
-a
-s
Using built-in stream user interface
→ Detected 64 CPUs online; setting concurrency level to 32.
→ License accepted by command line option.
→ Installing NVIDIA driver version 384.66.
→ There appears to already be a driver installed on your system (version: 375.39). As part of installing this driver (version: 384.66), the existing driver will be uninstalled. Are you sure you want to continue? (Answer: Continue installation)
→ Performing CC sanity check with CC=“/bin/cc”.
→ Kernel source path: ‘/lib/modules/3.10.0-514.26.2.el7.YAHOO.20170707.8.x86_64/source’
→ Kernel output path: ‘/lib/modules/3.10.0-514.26.2.el7.YAHOO.20170707.8.x86_64/build’
→ Performing Compiler check.
→ Performing Dom0 check.
→ Performing Xen check.
→ Performing PREEMPT_RT check.
→ Cleaning kernel module build directory.
executing: ‘cd ./kernel; /bin/make -k -j32 clean NV_EXCLUDE_KERNEL_MODULES=“” SYSSRC=“/lib/modules/3.10.0-514.26.2.el7.YAHOO.20170707.8.x86_64/source” SYSOUT=“/lib/modules/3.10.0-514.26.2.el7.YAHOO.20170707.8.x86_64/build”’…
rm -f -r conftest
/bin/make “CC=cc” KBUILD_OUTPUT=/lib/modules/3.10.0-514.26.2.el7.YAHOO.20170707.8.x86_64/build KBUILD_VERBOSE= -C /lib/modules/3.10.0-514.26.2.el7.YAHOO.20170707.8.x86_64/source M=/tmp/selfgz29482/NVIDIA-Linux-x86_64-384.66-diagnostic/kernel ARCH=x86_64 NV_KERNEL_SOURCES=/lib/modules/3.10.0-514.26.2.el7.YAHOO.20170707.8.x86_64/source NV_KERNEL_OUTPUT=/lib/modules/3.10.0-514.26.2.el7.YAHOO.20170707.8.x86_64/build NV_KERNEL_MODULES=“nvidia nvidia-uvm nvidia-modeset nvidia-drm” INSTALL_MOD_DIR=kernel/drivers/video clean
make[1]: Entering directory /usr/src/kernels/3.10.0-514.26.2.el7.YAHOO.20170707.8.x86_64' /bin/make -C /lib/modules/3.10.0-514.26.2.el7.YAHOO.20170707.8.x86_64/build \ KBUILD_SRC=/usr/src/kernels/3.10.0-514.26.2.el7.YAHOO.20170707.8.x86_64 \ KBUILD_EXTMOD="/tmp/selfgz29482/NVIDIA-Linux-x86_64-384.66-diagnostic/kernel" -f /usr/src/kernels/3.10.0-514.26.2.el7.YAHOO.20170707.8.x86_64/Makefile \ clean make[1]: Leaving directory /usr/src/kernels/3.10.0-514.26.2.el7.YAHOO.20170707.8.x86_64’
→ Building kernel modules
executing: ‘cd ./kernel; /bin/make -k -j32 NV_EXCLUDE_KERNEL_MODULES=“” SYSSRC=“/lib/modules/3.10.0-514.26.2.el7.YAHOO.20170707.8.x86_64/source” SYSOUT=“/lib/modules/3.10.0-514.26.2.el7.YAHOO.20170707.8.x86_64/build”’…
/bin/make “CC=cc” KBUILD_OUTPUT=/lib/modules/3.10.0-514.26.2.el7.YAHOO.20170707.8.x86_64/build KBUILD_VERBOSE= -C /lib/modules/3.10.0-514.26.2.el7.YAHOO.20170707.8.x86_64/source M=/tmp/selfgz29482/NVIDIA-Linux-x86_64-384.66-diagnostic/kernel ARCH=x86_64 NV_KERNEL_SOURCES=/lib/modules/3.10.0-514.26.2.el7.YAHOO.20170707.8.x86_64/source NV_KERNEL_OUTPUT=/lib/modules/3.10.0-514.26.2.el7.YAHOO.20170707.8.x86_64/build NV_KERNEL_MODULES=“nvidia nvidia-uvm nvidia-modeset nvidia-drm” INSTALL_MOD_DIR=kernel/drivers/video modules
make[1]: Entering directory /usr/src/kernels/3.10.0-514.26.2.el7.YAHOO.20170707.8.x86_64' /bin/make -C /lib/modules/3.10.0-514.26.2.el7.YAHOO.20170707.8.x86_64/build \ KBUILD_SRC=/usr/src/kernels/3.10.0-514.26.2.el7.YAHOO.20170707.8.x86_64 \ KBUILD_EXTMOD="/tmp/selfgz29482/NVIDIA-Linux-x86_64-384.66-diagnostic/kernel" -f /usr/src/kernels/3.10.0-514.26.2.el7.YAHOO.20170707.8.x86_64/Makefile \ modules SYMLINK /tmp/selfgz29482/NVIDIA-Linux-x86_64-384.66-diagnostic/kernel/nvidia-modeset/nv-modeset-kernel.o SYMLINK /tmp/selfgz29482/NVIDIA-Linux-x86_64-384.66-diagnostic/kernel/nvidia/nv-kernel.o CONFTEST: INIT_WORK CONFTEST: hash__remap_4k_pfn CONFTEST: remap_pfn_range CONFTEST: follow_pfn CONFTEST: vmap CONFTEST: set_pages_uc CONFTEST: set_memory_uc CONFTEST: set_memory_array_uc CONFTEST: change_page_attr CONFTEST: pci_get_class CONFTEST: pci_choose_state CONFTEST: acpi_device_id CONFTEST: vm_insert_page CONFTEST: acquire_console_sem CONFTEST: kmem_cache_create CONFTEST: console_lock CONFTEST: on_each_cpu CONFTEST: smp_call_function CONFTEST: acpi_evaluate_integer CONFTEST: ioremap_cache CONFTEST: ioremap_wc CONFTEST: acpi_walk_namespace CONFTEST: pci_domain_nr CONFTEST: pci_dma_mapping_error CONFTEST: sg_alloc_table CONFTEST: sg_init_table CONFTEST: pci_get_domain_bus_and_slot CONFTEST: get_num_physpages CONFTEST: proc_create_data CONFTEST: efi_enabled CONFTEST: pde_data CONFTEST: proc_remove CONFTEST: pm_vt_switch_required CONFTEST: xen_ioemu_inject_msi CONFTEST: phys_to_dma CONFTEST: get_dma_ops CONFTEST: write_cr4 CONFTEST: of_get_property CONFTEST: of_find_node_by_phandle CONFTEST: of_node_to_nid CONFTEST: pnv_pci_get_npu_dev CONFTEST: for_each_online_node CONFTEST: node_end_pfn CONFTEST: pci_bus_address CONFTEST: pci_stop_and_remove_bus_device CONFTEST: pci_remove_bus_device CONFTEST: request_threaded_irq CONFTEST: register_cpu_notifier CONFTEST: cpuhp_setup_state CONFTEST: remap_page_range CONFTEST: address_space_init_once CONFTEST: kbasename CONFTEST: fatal_signal_pending CONFTEST: list_cut_position CONFTEST: wait_on_bit_lock_argument_count CONFTEST: vzalloc CONFTEST: bitmap_clear CONFTEST: usleep_range CONFTEST: radix_tree_empty CONFTEST: drm_dev_unref CONFTEST: drm_reinit_primary_mode_group CONFTEST: drm_atomic_set_mode_for_crtc CONFTEST: drm_atomic_clean_old_fb CONFTEST: get_user_pages_remote CONFTEST: drm_gem_object_lookup CONFTEST: drm_atomic_state_free CONFTEST: drm_driver_has_gem_prime_res_obj CONFTEST: is_export_symbol_gpl_of_node_to_nid CONFTEST: i2c_adapter CONFTEST: pm_message_t CONFTEST: irq_handler_t CONFTEST: acpi_device_ops CONFTEST: acpi_op_remove CONFTEST: outer_flush_all CONFTEST: proc_dir_entry CONFTEST: scatterlist CONFTEST: sg_table CONFTEST: file_operations CONFTEST: vm_operations_struct CONFTEST: atomic_long_type CONFTEST: file_inode CONFTEST: pci_save_state CONFTEST: task_struct CONFTEST: kuid_t CONFTEST: dma_ops CONFTEST: dma_map_ops CONFTEST: noncoherent_swiotlb_dma_ops CONFTEST: vm_fault_present CONFTEST: vm_fault_has_address CONFTEST: fault_flags CONFTEST: atomic64_type CONFTEST: address_space CONFTEST: backing_dev_info CONFTEST: kernel_write CONFTEST: strnstr CONFTEST: iterate_dir CONFTEST: kstrtoull CONFTEST: mm_context_t CONFTEST: vm_ops_fault_removed_vma_arg CONFTEST: pnv_npu2_init_context CONFTEST: drm_bus_present CONFTEST: drm_bus_has_bus_type CONFTEST: drm_bus_has_get_irq CONFTEST: drm_bus_has_get_name CONFTEST: drm_driver_has_legacy_dev_list CONFTEST: drm_driver_has_set_busid CONFTEST: drm_crtc_state_has_connectors_changed CONFTEST: drm_init_functions_have_name_arg CONFTEST: drm_mode_connector_list_update_has_merge_type_bits_arg CONFTEST: drm_helper_mode_fill_fb_struct CONFTEST: drm_master_drop_has_from_release_arg CONFTEST: drm_mode_config_funcs_has_atomic_state_alloc CONFTEST: drm_driver_unload_has_int_return_type CONFTEST: dom0_kernel_present CONFTEST: nvidia_vgpu_kvm_build CONFTEST: nvidia_grid_build CONFTEST: drm_available CONFTEST: drm_atomic_available CONFTEST: drm_atomic_modeset_nonblocking_commit_available CONFTEST: is_export_symbol_gpl_refcount_inc CONFTEST: is_export_symbol_gpl_refcount_dec_and_test CC [M] /tmp/selfgz29482/NVIDIA-Linux-x86_64-384.66-diagnostic/kernel/nvidia-drm/nvidia-drm.o CC [M] /tmp/selfgz29482/NVIDIA-Linux-x86_64-384.66-diagnostic/kernel/nvidia-drm/nvidia-drm-drv.o CC [M] /tmp/selfgz29482/NVIDIA-Linux-x86_64-384.66-diagnostic/kernel/nvidia-drm/nvidia-drm-utils.o CC [M] /tmp/selfgz29482/NVIDIA-Linux-x86_64-384.66-diagnostic/kernel/nvidia-drm/nvidia-drm-crtc.o CC [M] /tmp/selfgz29482/NVIDIA-Linux-x86_64-384.66-diagnostic/kernel/nvidia-drm/nvidia-drm-encoder.o CC [M] /tmp/selfgz29482/NVIDIA-Linux-x86_64-384.66-diagnostic/kernel/nvidia-drm/nvidia-drm-connector.o CC [M] /tmp/selfgz29482/NVIDIA-Linux-x86_64-384.66-diagnostic/kernel/nvidia-drm/nvidia-drm-gem.o CC [M] /tmp/selfgz29482/NVIDIA-Linux-x86_64-384.66-diagnostic/kernel/nvidia-drm/nvidia-drm-fb.o CC [M] /tmp/selfgz29482/NVIDIA-Linux-x86_64-384.66-diagnostic/kernel/nvidia-drm/nvidia-drm-modeset.o CC [M] /tmp/selfgz29482/NVIDIA-Linux-x86_64-384.66-diagnostic/kernel/nvidia-drm/nvidia-drm-prime-fence.o CC [M] /tmp/selfgz29482/NVIDIA-Linux-x86_64-384.66-diagnostic/kernel/nvidia-drm/nvidia-drm-linux.o CC [M] /tmp/selfgz29482/NVIDIA-Linux-x86_64-384.66-diagnostic/kernel/nvidia-drm/nvidia-drm-helper.o CC [M] /tmp/selfgz29482/NVIDIA-Linux-x86_64-384.66-diagnostic/kernel/nvidia-drm/nv-pci-table.o CC [M] /tmp/selfgz29482/NVIDIA-Linux-x86_64-384.66-diagnostic/kernel/nvidia-modeset/nvidia-modeset-linux.o CC [M] /tmp/selfgz29482/NVIDIA-Linux-x86_64-384.66-diagnostic/kernel/nvidia-uvm/uvm8_volta_host.o CC [M] /tmp/selfgz29482/NVIDIA-Linux-x86_64-384.66-diagnostic/kernel/nvidia-uvm/uvm8_volta.o CC [M] /tmp/selfgz29482/NVIDIA-Linux-x86_64-384.66-diagnostic/kernel/nvidia-uvm/uvm8_volta_fault_buffer.o CC [M] /tmp/selfgz29482/NVIDIA-Linux-x86_64-384.66-diagnostic/kernel/nvidia-uvm/uvm8_volta_access_counter_buffer.o CC [M] /tmp/selfgz29482/NVIDIA-Linux-x86_64-384.66-diagnostic/kernel/nvidia-uvm/uvm8_ats_numa.o CC [M] /tmp/selfgz29482/NVIDIA-Linux-x86_64-384.66-diagnostic/kernel/nvidia-uvm/uvm8_gpu_non_replayable_faults.o CC [M] /tmp/selfgz29482/NVIDIA-Linux-x86_64-384.66-diagnostic/kernel/nvidia-uvm/uvm8_gpu_access_counters.o CC [M] /tmp/selfgz29482/NVIDIA-Linux-x86_64-384.66-diagnostic/kernel/nvidia-uvm/uvm_utils.o CC [M] /tmp/selfgz29482/NVIDIA-Linux-x86_64-384.66-diagnostic/kernel/nvidia-uvm/uvm_common.o CC [M] /tmp/selfgz29482/NVIDIA-Linux-x86_64-384.66-diagnostic/kernel/nvidia-uvm/uvm_linux.o CC [M] /tmp/selfgz29482/NVIDIA-Linux-x86_64-384.66-diagnostic/kernel/nvidia-uvm/nvstatus.o CC [M] /tmp/selfgz29482/NVIDIA-Linux-x86_64-384.66-diagnostic/kernel/nvidia-uvm/nv-kthread-q.o CC [M] /tmp/selfgz29482/NVIDIA-Linux-x86_64-384.66-diagnostic/kernel/nvidia-uvm/nv-kthread-q-selftest.o CC [M] /tmp/selfgz29482/NVIDIA-Linux-x86_64-384.66-diagnostic/kernel/nvidia-uvm/uvm8.o CC [M] /tmp/selfgz29482/NVIDIA-Linux-x86_64-384.66-diagnostic/kernel/nvidia-uvm/uvm8_tools.o CC [M] /tmp/selfgz29482/NVIDIA-Linux-x86_64-384.66-diagnostic/kernel/nvidia-uvm/uvm8_global.o CC [M] /tmp/selfgz29482/NVIDIA-Linux-x86_64-384.66-diagnostic/kernel/nvidia-uvm/uvm8_gpu.o CC [M] /tmp/selfgz29482/NVIDIA-Linux-x86_64-384.66-diagnostic/kernel/nvidia-uvm/uvm8_gpu_isr.o CC [M] /tmp/selfgz29482/NVIDIA-Linux-x86_64-384.66-diagnostic/kernel/nvidia-uvm/uvm8_procfs.o CC [M] /tmp/selfgz29482/NVIDIA-Linux-x86_64-384.66-diagnostic/kernel/nvidia-uvm/uvm8_va_space.o CC [M] /tmp/selfgz29482/NVIDIA-Linux-x86_64-384.66-diagnostic/kernel/nvidia-uvm/uvm8_gpu_semaphore.o CC [M] /tmp/selfgz29482/NVIDIA-Linux-x86_64-384.66-diagnostic/kernel/nvidia-uvm/uvm8_mem.o CC [M] /tmp/selfgz29482/NVIDIA-Linux-x86_64-384.66-diagnostic/kernel/nvidia-uvm/uvm8_rm_mem.o CC [M] /tmp/selfgz29482/NVIDIA-Linux-x86_64-384.66-diagnostic/kernel/nvidia-uvm/uvm8_channel.o CC [M] /tmp/selfgz29482/NVIDIA-Linux-x86_64-384.66-diagnostic/kernel/nvidia-uvm/uvm8_lock.o CC [M] /tmp/selfgz29482/NVIDIA-Linux-x86_64-384.66-diagnostic/kernel/nvidia-uvm/uvm8_hal.o CC [M] /tmp/selfgz29482/NVIDIA-Linux-x86_64-384.66-diagnostic/kernel/nvidia-uvm/uvm8_range_tree.o CC [M] /tmp/selfgz29482/NVIDIA-Linux-x86_64-384.66-diagnostic/kernel/nvidia-uvm/uvm8_range_allocator.o CC [M] /tmp/selfgz29482/NVIDIA-Linux-x86_64-384.66-diagnostic/kernel/nvidia-uvm/uvm8_va_range.o CC [M] /tmp/selfgz29482/NVIDIA-Linux-x86_64-384.66-diagnostic/kernel/nvidia-uvm/uvm8_va_block.o CC [M] /tmp/selfgz29482/NVIDIA-Linux-x86_64-384.66-diagnostic/kernel/nvidia-uvm/uvm8_range_group.o CC [M] /tmp/selfgz29482/NVIDIA-Linux-x86_64-384.66-diagnostic/kernel/nvidia-uvm/uvm8_gpu_replayable_faults.o CC [M] /tmp/selfgz29482/NVIDIA-Linux-x86_64-384.66-diagnostic/kernel/nvidia-uvm/uvm8_perf_events.o CC [M] /tmp/selfgz29482/NVIDIA-Linux-x86_64-384.66-diagnostic/kernel/nvidia-uvm/uvm8_perf_module.o CC [M] /tmp/selfgz29482/NVIDIA-Linux-x86_64-384.66-diagnostic/kernel/nvidia-uvm/uvm8_mmu.o CC [M] /tmp/selfgz29482/NVIDIA-Linux-x86_64-384.66-diagnostic/kernel/nvidia-uvm/uvm8_pte_batch.o CC [M] /tmp/selfgz29482/NVIDIA-Linux-x86_64-384.66-diagnostic/kernel/nvidia-uvm/uvm8_tlb_batch.o CC [M] /tmp/selfgz29482/NVIDIA-Linux-x86_64-384.66-diagnostic/kernel/nvidia-uvm/uvm8_push.o CC [M] /tmp/selfgz29482/NVIDIA-Linux-x86_64-384.66-diagnostic/kernel/nvidia-uvm/uvm8_pushbuffer.o CC [M] /tmp/selfgz29482/NVIDIA-Linux-x86_64-384.66-diagnostic/kernel/nvidia-uvm/uvm8_thread_context.o CC [M] /tmp/selfgz29482/NVIDIA-Linux-x86_64-384.66-diagnostic/kernel/nvidia-uvm/uvm8_tracker.o CC [M] /tmp/selfgz29482/NVIDIA-Linux-x86_64-384.66-diagnostic/kernel/nvidia-uvm/uvm8_kepler.o CC [M] /tmp/selfgz29482/NVIDIA-Linux-x86_64-384.66-diagnostic/kernel/nvidia-uvm/uvm8_kepler_ce.o CC [M] /tmp/selfgz29482/NVIDIA-Linux-x86_64-384.66-diagnostic/kernel/nvidia-uvm/uvm8_kepler_host.o CC [M] /tmp/selfgz29482/NVIDIA-Linux-x86_64-384.66-diagnostic/kernel/nvidia-uvm/uvm8_kepler_mmu.o CC [M] /tmp/selfgz29482/NVIDIA-Linux-x86_64-384.66-diagnostic/kernel/nvidia-uvm/uvm8_maxwell.o CC [M] /tmp/selfgz29482/NVIDIA-Linux-x86_64-384.66-diagnostic/kernel/nvidia-uvm/uvm8_maxwell_host.o CC [M] /tmp/selfgz29482/NVIDIA-Linux-x86_64-384.66-diagnostic/kernel/nvidia-uvm/uvm8_pascal.o CC [M] /tmp/selfgz29482/NVIDIA-Linux-x86_64-384.66-diagnostic/kernel/nvidia-uvm/uvm8_pascal_ce.o CC [M] /tmp/selfgz29482/NVIDIA-Linux-x86_64-384.66-diagnostic/kernel/nvidia-uvm/uvm8_pascal_host.o CC [M] /tmp/selfgz29482/NVIDIA-Linux-x86_64-384.66-diagnostic/kernel/nvidia-uvm/uvm8_pascal_mmu.o CC [M] /tmp/selfgz29482/NVIDIA-Linux-x86_64-384.66-diagnostic/kernel/nvidia-uvm/uvm8_pascal_fault_buffer.o CC [M] /tmp/selfgz29482/NVIDIA-Linux-x86_64-384.66-diagnostic/kernel/nvidia-uvm/uvm8_policy.o CC [M] /tmp/selfgz29482/NVIDIA-Linux-x86_64-384.66-diagnostic/kernel/nvidia-uvm/uvm8_perf_utils.o CC [M] /tmp/selfgz29482/NVIDIA-Linux-x86_64-384.66-diagnostic/kernel/nvidia-uvm/uvm8_kvmalloc.o CC [M] /tmp/selfgz29482/NVIDIA-Linux-x86_64-384.66-diagnostic/kernel/nvidia-uvm/uvm8_pmm_gpu.o CC [M] /tmp/selfgz29482/NVIDIA-Linux-x86_64-384.66-diagnostic/kernel/nvidia-uvm/uvm8_migrate.o CC [M] /tmp/selfgz29482/NVIDIA-Linux-x86_64-384.66-diagnostic/kernel/nvidia-uvm/uvm8_map_external.o CC [M] /tmp/selfgz29482/NVIDIA-Linux-x86_64-384.66-diagnostic/kernel/nvidia-uvm/uvm8_user_channel.o CC [M] /tmp/selfgz29482/NVIDIA-Linux-x86_64-384.66-diagnostic/kernel/nvidia-uvm/uvm8_hmm.o CC [M] /tmp/selfgz29482/NVIDIA-Linux-x86_64-384.66-diagnostic/kernel/nvidia-uvm/uvm8_perf_heuristics.o CC [M] /tmp/selfgz29482/NVIDIA-Linux-x86_64-384.66-diagnostic/kernel/nvidia-uvm/uvm8_perf_thrashing.o CC [M] /tmp/selfgz29482/NVIDIA-Linux-x86_64-384.66-diagnostic/kernel/nvidia-uvm/uvm8_perf_prefetch.o CC [M] /tmp/selfgz29482/NVIDIA-Linux-x86_64-384.66-diagnostic/kernel/nvidia-uvm/uvm8_test.o CC [M] /tmp/selfgz29482/NVIDIA-Linux-x86_64-384.66-diagnostic/kernel/nvidia-uvm/uvm8_test_rng.o CC [M] /tmp/selfgz29482/NVIDIA-Linux-x86_64-384.66-diagnostic/kernel/nvidia-uvm/uvm8_range_tree_test.o CC [M] /tmp/selfgz29482/NVIDIA-Linux-x86_64-384.66-diagnostic/kernel/nvidia-uvm/uvm8_range_allocator_test.o CC [M] /tmp/selfgz29482/NVIDIA-Linux-x86_64-384.66-diagnostic/kernel/nvidia-uvm/uvm8_gpu_semaphore_test.o CC [M] /tmp/selfgz29482/NVIDIA-Linux-x86_64-384.66-diagnostic/kernel/nvidia-uvm/uvm8_mem_test.o CC [M] /tmp/selfgz29482/NVIDIA-Linux-x86_64-384.66-diagnostic/kernel/nvidia-uvm/uvm8_rm_mem_test.o CC [M] /tmp/selfgz29482/NVIDIA-Linux-x86_64-384.66-diagnostic/kernel/nvidia-uvm/uvm8_page_tree_test.o CC [M] /tmp/selfgz29482/NVIDIA-Linux-x86_64-384.66-diagnostic/kernel/nvidia-uvm/uvm8_tracker_test.o CC [M] /tmp/selfgz29482/NVIDIA-Linux-x86_64-384.66-diagnostic/kernel/nvidia-uvm/uvm8_push_test.o CC [M] /tmp/selfgz29482/NVIDIA-Linux-x86_64-384.66-diagnostic/kernel/nvidia-uvm/uvm8_channel_test.o CC [M] /tmp/selfgz29482/NVIDIA-Linux-x86_64-384.66-diagnostic/kernel/nvidia-uvm/uvm8_ce_test.o CC [M] /tmp/selfgz29482/NVIDIA-Linux-x86_64-384.66-diagnostic/kernel/nvidia-uvm/uvm8_lock_test.o CC [M] /tmp/selfgz29482/NVIDIA-Linux-x86_64-384.66-diagnostic/kernel/nvidia-uvm/uvm8_perf_utils_test.o CC [M] /tmp/selfgz29482/NVIDIA-Linux-x86_64-384.66-diagnostic/kernel/nvidia-uvm/uvm8_kvmalloc_test.o CC [M] /tmp/selfgz29482/NVIDIA-Linux-x86_64-384.66-diagnostic/kernel/nvidia-uvm/uvm8_pmm_test.o CC [M] /tmp/selfgz29482/NVIDIA-Linux-x86_64-384.66-diagnostic/kernel/nvidia-uvm/uvm8_perf_events_test.o CC [M] /tmp/selfgz29482/NVIDIA-Linux-x86_64-384.66-diagnostic/kernel/nvidia-uvm/uvm8_perf_module_test.o CC [M] /tmp/selfgz29482/NVIDIA-Linux-x86_64-384.66-diagnostic/kernel/nvidia-uvm/uvm8_get_rm_ptes_test.o CC [M] /tmp/selfgz29482/NVIDIA-Linux-x86_64-384.66-diagnostic/kernel/nvidia-uvm/uvm8_fault_buffer_flush_test.o CC [M] /tmp/selfgz29482/NVIDIA-Linux-x86_64-384.66-diagnostic/kernel/nvidia-uvm/uvm8_mmu_test.o CC [M] /tmp/selfgz29482/NVIDIA-Linux-x86_64-384.66-diagnostic/kernel/nvidia-uvm/uvm8_peer_identity_mappings_test.o CC [M] /tmp/selfgz29482/NVIDIA-Linux-x86_64-384.66-diagnostic/kernel/nvidia-uvm/uvm8_va_block_test.o CC [M] /tmp/selfgz29482/NVIDIA-Linux-x86_64-384.66-diagnostic/kernel/nvidia-uvm/uvm8_range_group_tree_test.o CC [M] /tmp/selfgz29482/NVIDIA-Linux-x86_64-384.66-diagnostic/kernel/nvidia/nv-frontend.o CC [M] /tmp/selfgz29482/NVIDIA-Linux-x86_64-384.66-diagnostic/kernel/nvidia/nv-instance.o CC [M] /tmp/selfgz29482/NVIDIA-Linux-x86_64-384.66-diagnostic/kernel/nvidia/nv.o CC [M] /tmp/selfgz29482/NVIDIA-Linux-x86_64-384.66-diagnostic/kernel/nvidia/nv-acpi.o CC [M] /tmp/selfgz29482/NVIDIA-Linux-x86_64-384.66-diagnostic/kernel/nvidia/nv-chrdev.o CC [M] /tmp/selfgz29482/NVIDIA-Linux-x86_64-384.66-diagnostic/kernel/nvidia/nv-cray.o CC [M] /tmp/selfgz29482/NVIDIA-Linux-x86_64-384.66-diagnostic/kernel/nvidia/nv-dma.o CC [M] /tmp/selfgz29482/NVIDIA-Linux-x86_64-384.66-diagnostic/kernel/nvidia/nv-gvi.o CC [M] /tmp/selfgz29482/NVIDIA-Linux-x86_64-384.66-diagnostic/kernel/nvidia/nv-i2c.o CC [M] /tmp/selfgz29482/NVIDIA-Linux-x86_64-384.66-diagnostic/kernel/nvidia/nv-mempool.o CC [M] /tmp/selfgz29482/NVIDIA-Linux-x86_64-384.66-diagnostic/kernel/nvidia/nv-mmap.o CC [M] /tmp/selfgz29482/NVIDIA-Linux-x86_64-384.66-diagnostic/kernel/nvidia/nv-p2p.o CC [M] /tmp/selfgz29482/NVIDIA-Linux-x86_64-384.66-diagnostic/kernel/nvidia/nv-pat.o CC [M] /tmp/selfgz29482/NVIDIA-Linux-x86_64-384.66-diagnostic/kernel/nvidia/nv-procfs.o CC [M] /tmp/selfgz29482/NVIDIA-Linux-x86_64-384.66-diagnostic/kernel/nvidia/nv-usermap.o CC [M] /tmp/selfgz29482/NVIDIA-Linux-x86_64-384.66-diagnostic/kernel/nvidia/nv-vm.o CC [M] /tmp/selfgz29482/NVIDIA-Linux-x86_64-384.66-diagnostic/kernel/nvidia/nv-vtophys.o CC [M] /tmp/selfgz29482/NVIDIA-Linux-x86_64-384.66-diagnostic/kernel/nvidia/os-interface.o CC [M] /tmp/selfgz29482/NVIDIA-Linux-x86_64-384.66-diagnostic/kernel/nvidia/os-mlock.o CC [M] /tmp/selfgz29482/NVIDIA-Linux-x86_64-384.66-diagnostic/kernel/nvidia/os-pci.o CC [M] /tmp/selfgz29482/NVIDIA-Linux-x86_64-384.66-diagnostic/kernel/nvidia/os-registry.o CC [M] /tmp/selfgz29482/NVIDIA-Linux-x86_64-384.66-diagnostic/kernel/nvidia/os-usermap.o CC [M] /tmp/selfgz29482/NVIDIA-Linux-x86_64-384.66-diagnostic/kernel/nvidia/nv-modeset-interface.o CC [M] /tmp/selfgz29482/NVIDIA-Linux-x86_64-384.66-diagnostic/kernel/nvidia/nv-pci-table.o CC [M] /tmp/selfgz29482/NVIDIA-Linux-x86_64-384.66-diagnostic/kernel/nvidia/nv-kthread-q.o CC [M] /tmp/selfgz29482/NVIDIA-Linux-x86_64-384.66-diagnostic/kernel/nvidia/nv-kthread-q-selftest.o CC [M] /tmp/selfgz29482/NVIDIA-Linux-x86_64-384.66-diagnostic/kernel/nvidia/nv-memdbg.o CC [M] /tmp/selfgz29482/NVIDIA-Linux-x86_64-384.66-diagnostic/kernel/nvidia/nv_uvm_interface.o ld -r -o /tmp/selfgz29482/NVIDIA-Linux-x86_64-384.66-diagnostic/kernel/nvidia-modeset/nv-modeset-interface.o /tmp/selfgz29482/NVIDIA-Linux-x86_64-384.66-diagnostic/kernel/nvidia-modeset/nvidia-modeset-linux.o CC [M] /tmp/selfgz29482/NVIDIA-Linux-x86_64-384.66-diagnostic/kernel/nvidia/nvlink_linux.o ld -r -o /tmp/selfgz29482/NVIDIA-Linux-x86_64-384.66-diagnostic/kernel/nvidia/nv-interface.o /tmp/selfgz29482/NVIDIA-Linux-x86_64-384.66-diagnostic/kernel/nvidia/nv-frontend.o /tmp/selfgz29482/NVIDIA-Linux-x86_64-384.66-diagnostic/kernel/nvidia/nv-instance.o /tmp/selfgz29482/NVIDIA-Linux-x86_64-384.66-diagnostic/kernel/nvidia/nv.o /tmp/selfgz29482/NVIDIA-Linux-x86_64-384.66-diagnostic/kernel/nvidia/nv-acpi.o /tmp/selfgz29482/NVIDIA-Linux-x86_64-384.66-diagnostic/kernel/nvidia/nv-chrdev.o /tmp/selfgz29482/NVIDIA-Linux-x86_64 -384.66-diagnostic/kernel/nvidia/nv-cray.o /tmp/selfgz29482/NVIDIA-Linux-x86_64-384.66-diagnostic/kernel/nvidia/nv-dma.o /tmp/selfgz29482/NVIDIA-Linux-x86_64-384.66-diagnostic/kernel/nvidia/nv-gvi.o /tmp/selfgz29482/NVIDIA-Linux-x86_64-384.66-diagnostic/kernel/nvidia/nv-i2c.o /tmp/selfgz29482/NVIDIA-Linux-x86_64-384.66-diagnostic/kernel/nvidia/nv-mempool.o /tmp/selfgz29482/NVIDIA-Linux-x86_64-384.66-diagnostic/kernel/nvidia/nv-mmap.o /tmp/selfgz29482/NVIDIA-Linux-x86_64-384.66-diagnostic/kernel/nvidia/nv-p2p.o /tmp/selfgz29482/NVIDIA-Linux-x86_64-384.66-diagnostic/kernel/nvidia/nv-pat.o /tmp/selfgz29482/NVIDIA-Linux-x86_64-384.66-diagnostic/kernel/nvidia/nv-procfs.o /tmp/selfgz29482/NVIDIA-Linux-x86_64-384.66-diagnostic/kernel/nvidia/nv-usermap.o /tmp/selfgz29482/NVIDIA-Linux-x86_64-384.66-diagnostic/kernel/nvidia/nv-vm.o /tmp/selfgz29482/NVIDIA-Linux-x86_64-384.66-diagnostic/kernel/nvidia/nv-vtophys.o /tmp/selfgz29482/NVIDIA-Linux-x86_64-384.66-diagnostic/kernel/nvidia/os-interface.o /tmp/selfgz29482/NVIDIA- Linux-x86_64-384.66-diagnostic/kernel/nvidia/os-mlock.o /tmp/selfgz29482/NVIDIA-Linux-x86_64-384.66-diagnostic/kernel/nvidia/os-pci.o /tmp/selfgz29482/NVIDIA-Linux-x86_64-384.66-diagnostic/kernel/nvidia/os-registry.o /tmp/selfgz29482/NVIDIA-Linux-x86_64-384.66-diagnostic/kernel/nvidia/os-usermap.o /tmp/selfgz29482/NVIDIA-Linux-x86_64-384.66-diagnostic/kernel/nvidia/nv-modeset-interface.o /tmp/selfgz29482/NVIDIA-Linux-x86_64-384.66-diagnostic/kernel/nvidia/nv-pci-table.o /tmp/selfgz29482/NVIDIA-Linux-x86_64-384.66-diagnostic/kernel/nvidia/nv-kthread-q.o /tmp/selfgz29482/NVIDIA-Linux-x86_64-384.66-diagnostic/kernel/nvidia/nv-kthread-q-selftest.o /tmp/selfgz29482/NVIDIA-Linux-x86_64-384.66-diagnostic/kernel/nvidia/nv-memdbg.o /tmp/selfgz29482/NVIDIA-Linux-x86_64-384.66-diagnostic/kernel/nvidia/nv_uvm_interface.o /tmp/selfgz29482/NVIDIA-Linux-x86_64-384.66-diagnostic/kernel/nvidia/nvlink_linux.o LD [M] /tmp/selfgz29482/NVIDIA-Linux-x86_64-384.66-diagnostic/kernel/nvidia.o LD [M] /tmp/selfgz29482/NVIDIA-Linux-x86_64-384.66-diagnostic/kernel/nvidia-uvm.o LD [M] /tmp/selfgz29482/NVIDIA-Linux-x86_64-384.66-diagnostic/kernel/nvidia-modeset.o LD [M] /tmp/selfgz29482/NVIDIA-Linux-x86_64-384.66-diagnostic/kernel/nvidia-drm.o Building modules, stage 2. MODPOST 4 modules CC /tmp/selfgz29482/NVIDIA-Linux-x86_64-384.66-diagnostic/kernel/nvidia-drm.mod.o CC /tmp/selfgz29482/NVIDIA-Linux-x86_64-384.66-diagnostic/kernel/nvidia-modeset.mod.o CC /tmp/selfgz29482/NVIDIA-Linux-x86_64-384.66-diagnostic/kernel/nvidia-uvm.mod.o CC /tmp/selfgz29482/NVIDIA-Linux-x86_64-384.66-diagnostic/kernel/nvidia.mod.o LD [M] /tmp/selfgz29482/NVIDIA-Linux-x86_64-384.66-diagnostic/kernel/nvidia-drm.ko LD [M] /tmp/selfgz29482/NVIDIA-Linux-x86_64-384.66-diagnostic/kernel/nvidia-modeset.ko LD [M] /tmp/selfgz29482/NVIDIA-Linux-x86_64-384.66-diagnostic/kernel/nvidia-uvm.ko LD [M] /tmp/selfgz29482/NVIDIA-Linux-x86_64-384.66-diagnostic/kernel/nvidia.ko make[1]: Leaving directory /usr/src/kernels/3.10.0-514.26.2.el7.YAHOO.20170707.8.x86_64’
→ done.
→ Kernel module compilation complete.
→ Unable to determine if Secure Boot is enabled: No such file or directory
→ Kernel messages:
[1737015.540208] systemd-journald[1048]: Failed to set file attributes: Operation not supported
[1737015.646030] systemd-journald[1048]: Failed to set file attributes: Operation not supported
[1860454.329625] XFS (dm-3): Unmounting Filesystem
[1860469.374647] nvidia-uvm: Unloaded the UVM driver in 8 mode
[1860469.383087] [drm] [nvidia-drm] [GPU ID 0x00008500] Unloading driver
[1860469.383346] [drm] [nvidia-drm] [GPU ID 0x00008400] Unloading driver
[1860469.383576] [drm] [nvidia-drm] [GPU ID 0x00000600] Unloading driver
[1860469.383859] [drm] [nvidia-drm] [GPU ID 0x00000500] Unloading driver
[1860469.397170] nvidia-modeset: Unloading
[1860469.409998] nvidia-nvlink: Unregistered the Nvlink Core, major device number 244
[1860480.708127] nvidia-nvlink: Nvlink Core is being initialized, major device number 244
[1860480.709173] NVRM: loading NVIDIA UNIX x86_64 Kernel Module 384.66 Tue Aug 1 16:02:12 PDT 2017 (using threaded interrupts)
[1860480.725583] nvidia-uvm: Loaded the UVM driver in 8 mode, major device number 243
[1860480.728610] nvidia-modeset: Loading NVIDIA Kernel Mode Setting Driver for UNIX platforms 384.66 Tue Aug 1 16:15:09 PDT 2017
[1860480.731763] [drm] [nvidia-drm] [GPU ID 0x00000500] Loading driver
[1860480.731892] [drm] [nvidia-drm] [GPU ID 0x00000600] Loading driver
[1860480.732040] [drm] [nvidia-drm] [GPU ID 0x00008400] Loading driver
[1860480.732192] [drm] [nvidia-drm] [GPU ID 0x00008500] Loading driver
[1860480.736223] [drm] [nvidia-drm] [GPU ID 0x00008500] Unloading driver
[1860480.736394] [drm] [nvidia-drm] [GPU ID 0x00008400] Unloading driver
[1860480.736536] [drm] [nvidia-drm] [GPU ID 0x00000600] Unloading driver
[1860480.736747] [drm] [nvidia-drm] [GPU ID 0x00000500] Unloading driver
[1860480.740699] nvidia-modeset: Unloading
[1860480.746194] nvidia-uvm: Unloaded the UVM driver in 8 mode
[1860480.751139] nvidia-nvlink: Unregistered the Nvlink Core, major device number 244
WARNING: nvidia-installer was forced to guess the X library path ‘/usr/lib64’ and X module path ‘/usr/lib64/xorg/modules’; these paths were not queryable from the system. If X fails to find the NVIDIA X driver module, please install the pkg-config utility and the X.Org SDK/development package for your distribution and reinstall the driver.
→ Installing both new and classic TLS OpenGL libraries.
→ Installing classic TLS 32bit OpenGL libraries.
→ Install NVIDIA’s 32-bit compatibility libraries? (Answer: Yes)
→ Will install GLVND GLX client libraries.
→ Will install GLVND EGL client libraries.
→ Skipping GLX non-GLVND file: “libGL.so.384.66”
→ Skipping GLX non-GLVND file: “libGL.so.1”
→ Skipping GLX non-GLVND file: “libGL.so”
→ Skipping EGL non-GLVND file: “libEGL.so.384.66”
→ Skipping EGL non-GLVND file: “libEGL.so”
→ Skipping EGL non-GLVND file: “libEGL.so.1”
→ Skipping GLX non-GLVND file: “./32/libGL.so.384.66”
→ Skipping EGL non-GLVND file: “./32/libEGL.so.384.66”
→ Uninstalling the previous installation with /bin/nvidia-uninstall.
Looking for install checker script at ./libglvnd_install_checker/check-libglvnd-install.sh
executing: ‘/bin/sh ./libglvnd_install_checker/check-libglvnd-install.sh’…
Checking for libglvnd installation.
Checking libGLdispatch…
Can’t load library libGLdispatch.so.0: libGLdispatch.so.0: cannot open shared object file: No such file or directory
Will install libglvnd libraries.
Will install libEGL vendor library config file to /usr/share/glvnd/egl_vendor.d
→ Searching for conflicting files:
→ done.
→ Installing ‘NVIDIA Accelerated Graphics Driver for Linux-x86_64’ (384.66):
executing: ‘/sbin/ldconfig’…
executing: '/sbin/depmod -a '…
→ done.
→ Driver file installation is complete.
→ Running post-install sanity check:
→ done.
→ Post-install sanity check passed.
→ Running runtime sanity check:
→ done.
→ Runtime sanity check passed.
→ Installation of the kernel module for the NVIDIA Accelerated Graphics Driver for Linux-x86_64 (version 384.66) is now complete.
*** /var/log/nvidia-uninstall.log
*** ls: -rw-r–r-- 1 root root 1164 2017-08-24 14:18:51.302429519 +0000 /var/log/nvidia-uninstall.log
nvidia-installer log file ‘/var/log/nvidia-uninstall.log’
creation time: Thu Aug 24 14:18:49 2017
installer version: 375.39
-s
–log-file-name=/var/log/nvidia-uninstall.log
→ If you plan to no longer use the NVIDIA driver, you should make sure that no X screens are configured to use the NVIDIA X driver in your X configuration file. If you used nvidia-xconfig to configure X, it may have created a backup of your original configuration. Would you like to run nvidia-xconfig --restore-original-backup to attempt restoration of the original X configuration file? (Answer: No)
→ Parsing log file:
→ done.
→ Validating previous installation:
→ done.
→ Uninstalling NVIDIA Accelerated Graphics Driver for Linux-x86_64 (1.0-37539 (375.39)):
→ done.
→ Running depmod and ldconfig:
→ done.
→ Uninstallation of existing driver: NVIDIA Accelerated Graphics Driver for Linux-x86_64 (375.39) is complete.
journalctl -b -0 _COMM=Xorg
– No entries –
journalctl -b -1 _COMM=Xorg
– No entries –
journalctl -b -2 _COMM=Xorg
– No entries –
journalctl -b -0 _COMM=Xorg.bin
– No entries –
journalctl -b -1 _COMM=Xorg.bin
– No entries –
journalctl -b -2 _COMM=Xorg.bin
– No entries –
– No entries –
– No entries –
– No entries –
*** /usr/share/nvidia/nvidia-application-profiles-384.66-rc
*** ls: -r–r–r-- 1 root root 5949 2017-08-24 14:18:51.846430621 +0000 /usr/share/nvidia/nvidia-application-profiles-384.66-rc
Application profiles for the NVIDIA Linux graphics driver, version 384.66
Last modified: Tue Aug 1 16:14:33 PDT 2017
These profiles were provided by NVIDIA and should not be modified. If you
wish to change the defaults provided here, you can override them by creating
custom rules in /etc/nvidia/nvidia-application-profiles-rc (which will apply
system-wide) or, for a given user, $HOME/.nv/nvidia-application-profiles-rc
(which will apply to that particular user). See the "APPLICATION PROFILE
SEARCH PATH" section of the NVIDIA Linux Graphics Driver README for more
information.
“profiles” : [
“name” : “NonConformantBlitFramebufferScissor”,
“settings” : [ “GLConformantBlitFramebufferScissor”, false ]
“name” : “CL1C”,
“settings” : [ “0x528ab3”, 1 ]
“name” : “FA0”,
“settings” : [ “10572898”, 0 ]
“name” : “ExactGLESVersion”,
“settings” : [ “ForceRequestedESVersion”, 1 ]
“name” : “IgnoreGLSLExtensionRequirements”,
“settings” : [ “GLIgnoreGLSLExtReqs”, true ]
“name” : “No GSYNC”,
“settings” : [ “GLGSYNCAllowed”, false ]
“name” : “UseThreadedOptimizations”,
“settings” : [ “GLThreadedOptimizations”, true ]
“name” : “NoThreadedOptimizations”,
“settings” : [ “GLThreadedOptimizations”, false ]
“name” : “NoAniso”,
“settings” : [ “GLLogMaxAniso”, 0 ]
“name” : “NamedVertexAttributesApplyDivisor”,
“settings” : [ “GL23cd0e”, 1 ]
“name” : “NonStrictDrawRangeElements”,
“settings” : [ “GLStrictDrawRangeElements”, false ]
“name” : “NoEnforceShaderInputOutputMatching”,
“settings” : [ “GLShaderPortabilityWarnings”, false ]
“rules” : [
“pattern” : {
“feature” : “dso”,
“matches” : “libcogl.so”
“profile” : “NonConformantBlitFramebufferScissor”
“pattern” : {
“feature” : “dso”,
“matches” : “libMaya.so”
“profile” : “CL1C”
“pattern” : {
“feature” : “dso”,
“profile” : “NamedVertexAttributesApplyDivisor”
{ “pattern” : “SkullGirls.x86_64-pc-linux-gnu”, “profile” : “NoAniso” },
{ “pattern” : “SkullGirls.i686-pc-linux-gnu”, “profile” : “NoAniso” },
{ “pattern” : “Indivisible_Linux.i686-pc-linux-gnu”, “profile” : “NoAniso” },
{ “pattern” : “xsi”, “profile” : “CL1C” },
{ “pattern” : “HoudiniFX”, “profile” : “CL1C” },
{ “pattern” : “katana”, “profile” : “CL1C” },
{ “pattern” : “Autodesk Mudbox 2014 64-bit”, “profile” : “CL1C” },
{ “pattern” : “octane”, “profile” : “CL1C” },
{ “pattern” : “Fusion64_6.4”, “profile” : “CL1C” },
{ “pattern” : “Nuke7.0”, “profile” : “CL1C” },
{ “pattern” : “vray.exe”, “profile” : “CL1C” },
{ “pattern” : “vray.bin”, “profile” : “CL1C” },
{ “pattern” : “kwin_gles”, “profile” : “FA0” },
{ “pattern” : “kwin_gles”, “profile” : “ExactGLESVersion” },
“pattern” : [
{ “feature” : “procname”, “matches” : “heaven_x86”},
{ “op” : “not”, “sub” : { “feature” : “findfile”, “matches” : “browser_x86” } }
“profile” : “IgnoreGLSLExtensionRequirements”
“pattern” : [
{ “feature” : “procname”, “matches” : “heaven_x64”},
{ “op” : “not”, “sub” : { “feature” : “findfile”, “matches” : “browser_x64” } }
{ “pattern” : { “feature” : “procname”, “matches” : “cinnamon” }, “profile” : “No GSYNC” },
{ “pattern” : { “feature” : “procname”, “matches” : “compiz” }, “profile” : “No GSYNC” },
{ “pattern” : { “feature” : “procname”, “matches” : “compton” }, “profile” : “No GSYNC” },
{ “pattern” : { “feature” : “procname”, “matches” : “enlightenment” }, “profile” : “No GSYNC” },
{ “pattern” : { “feature” : “procname”, “matches” : “gnome-shell” }, “profile” : “No GSYNC” },
{ “pattern” : { “feature” : “procname”, “matches” : “kscreenlocker_greet” }, “profile” : “No GSYNC” },
{ “pattern” : { “feature” : “procname”, “matches” : “kwin” }, “profile” : “No GSYNC” },
{ “pattern” : { “feature” : “procname”, “matches” : “kwin_x11” }, “profile” : “No GSYNC” },
{ “pattern” : { “feature” : “procname”, “matches” : “muffin” }, “profile” : “No GSYNC” },
{ “pattern” : { “feature” : “dso”, “matches” : “libmutter” }, “profile” : “No GSYNC” },
{ “pattern” : { “feature” : “procname”, “matches” : “steam” }, “profile” : “No GSYNC” },
{ “pattern” : { “feature” : “procname”, “matches” : “steamcompmgr” }, “profile” : “No GSYNC” },
“pattern” : “Borderlands2”,
“profile” : “UseThreadedOptimizations”
“pattern” : “BorderlandsPreSequel”,
“pattern” : “GoatGame”,
“profile” : “NonStrictDrawRangeElements”
“pattern” : “ShadowOfMordor”,
“profile” : “NoEnforceShaderInputOutputMatching”
“pattern” : “shotcut”,
“profile” : “NoThreadedOptimizations”
Skipping ldd output (glxinfo not found)
Vulkan loader not found
/sbin/lspci -d “10de:*” -v -xxx
05:00.0 3D controller: NVIDIA Corporation Device 15f9 (rev a1)
Subsystem: NVIDIA Corporation Device 116b
Flags: bus master, fast devsel, latency 0, IRQ 127
Memory at c4000000 (32-bit, non-prefetchable)
Memory at 383800000000 (64-bit, prefetchable)
Memory at 383c00000000 (64-bit, prefetchable)
Capabilities: [60] Power Management version 3
Capabilities: [68] MSI: Enable+ Count=1/1 Maskable- 64bit+
Capabilities: [78] Express Endpoint, MSI 00
Capabilities: [100] Virtual Channel
Capabilities: [250] Latency Tolerance Reporting
Capabilities: [258] L1 PM Substates
Capabilities: [128] Power Budgeting <?>
Capabilities: [420] Advanced Error Reporting
Capabilities: [600] Vendor Specific Information: ID=0001 Rev=1 Len=024 <?>
Capabilities: [900] #19
Kernel driver in use: nvidia
00: de 10 f9 15 07 00 10 00 a1 00 02 03 00 00 00 00
10: 00 00 00 c4 0c 00 00 00 38 38 00 00 0c 00 00 00
20: 3c 38 00 00 00 00 00 00 00 00 00 00 de 10 6b 11
30: 00 00 00 00 60 00 00 00 00 00 00 00 0b 01 00 00
40: de 10 6b 11 00 00 00 00 00 00 00 00 00 00 00 00
50: 03 00 00 00 01 00 00 00 ce d6 23 00 00 00 00 00
60: 01 68 03 00 08 00 00 00 05 78 81 00 d8 04 e0 fe
70: 00 00 00 00 00 00 00 00 10 00 02 00 e1 8d 64 00
80: 30 21 00 00 03 4d 45 08 02 01 03 11 00 00 00 00
90: 00 00 00 00 00 00 00 00 00 00 00 00 13 08 04 00
a0: 00 00 00 00 0e 00 00 00 03 00 1e 00 00 00 00 00
b0: 00 00 00 00 09 00 14 01 00 00 00 00 00 00 00 00
c0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
d0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
e0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
f0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
06:00.0 3D controller: NVIDIA Corporation Device 15f9 (rev a1)
Flags: bus master, fast devsel, latency 0, IRQ 128
Memory at c3000000 (32-bit, non-prefetchable)
Memory at 383000000000 (64-bit, prefetchable)
Memory at 383400000000 (64-bit, prefetchable)
10: 00 00 00 c3 0c 00 00 00 30 38 00 00 0c 00 00 00
20: 34 38 00 00 00 00 00 00 00 00 00 00 de 10 6b 11
60: 01 68 03 00 08 00 00 00 05 78 81 00 f8 04 e0 fe
80: 30 21 00 00 03 4d 45 0c 02 01 03 11 00 00 00 00
84:00.0 3D controller: NVIDIA Corporation Device 15f9 (rev a1)
Flags: bus master, fast devsel, latency 0, IRQ 129
Memory at fa000000 (32-bit, non-prefetchable)
Memory at 387800000000 (64-bit, prefetchable)
Memory at 387c00000000 (64-bit, prefetchable)
10: 00 00 00 fa 0c 00 00 00 78 38 00 00 0c 00 00 00
20: 7c 38 00 00 00 00 00 00 00 00 00 00 de 10 6b 11
60: 01 68 03 00 08 00 00 00 05 78 81 00 d8 00 e0 fe
/sbin/lspci -d “10b5:*” -v -xxx
02:00.0 PCI bridge: PLX Technology, Inc. Device 8764 (rev ab) (prog-if 00 [Normal decode])
Physical Slot: 3
Memory at c5000000 (32-bit, non-prefetchable)
Bus: primary=02, secondary=03, subordinate=06, sec-latency=0
Memory behind bridge: c3000000-c4ffffff
Prefetchable memory behind bridge: 0000383000000000-0000383c01ffffff
Capabilities: [40] Power Management version 3
Capabilities: [48] MSI: Enable+ Count=1/8 Maskable+ 64bit+
Capabilities: [68] Express Upstream Port, MSI 00
Capabilities: [a4] Subsystem: PLX Technology, Inc. Device 8764
Capabilities: [100] Device Serial Number ab-87-00-10-b5-df-0e-00
Capabilities: [fb4] Advanced Error Reporting
Capabilities: [138] Power Budgeting <?>
Capabilities: [10c] #19
Capabilities: [148] Virtual Channel
Capabilities: [e00] #12
Capabilities: [b00] Latency Tolerance Reporting
Capabilities: [b70] Vendor Specific Information: ID=0001 Rev=0 Len=010 <?>
Kernel driver in use: pcieport
00: b5 10 64 87 07 05 10 00 ab 00 04 06 08 00 01 00
10: 00 00 00 c5 00 00 00 00 02 03 06 00 f1 01 00 00
20: 00 c3 f0 c4 01 00 f1 01 30 38 00 00 3c 38 00 00
30: 00 00 00 00 40 00 00 00 00 00 00 00 0b 01 12 00
40: 01 48 03 c8 08 00 00 00 05 68 87 01 98 03 e0 fe
50: 00 00 00 00 00 00 00 00 ff 00 00 00 00 00 00 00
60: 00 00 00 00 00 00 00 00 10 a4 52 00 04 80 00 00
70: 20 08 09 00 03 69 41 00 02 00 03 01 00 00 00 00
80: 00 00 00 00 00 00 00 00 00 00 00 00 40 08 04 00
90: 00 00 00 00 0e 01 00 00 03 00 1e 00 00 00 00 00
a0: 00 00 00 00 0d 00 00 00 b5 10 64 87 00 00 00 00
b0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
03:04.0 PCI bridge: PLX Technology, Inc. Device 8764 (rev ab) (prog-if 00 [Normal decode])
Bus: primary=03, secondary=04, subordinate=04, sec-latency=0
Capabilities: [68] Express Downstream Port (Slot+), MSI 00
Capabilities: [f24] Access Control Services
10: 00 00 00 00 00 00 00 00 03 04 04 00 f1 01 00 00
20: f0 ff 00 00 f1 ff 01 00 00 00 00 00 00 00 00 00
40: 01 48 03 c8 08 00 00 00 05 68 87 01 b8 03 e0 fe
60: 00 00 00 00 00 00 00 00 10 a4 62 01 04 80 00 00
70: 30 08 09 00 03 69 79 04 00 00 01 00 80 0c 20 00
80: 00 00 00 00 00 00 00 00 00 00 00 00 60 08 04 00
90: 00 00 00 00 0e 01 00 00 03 00 01 00 00 00 00 00
03:08.0 PCI bridge: PLX Technology, Inc. Device 8764 (rev ab) (prog-if 00 [Normal decode])
Bus: primary=03, secondary=05, subordinate=05, sec-latency=0
Memory behind bridge: c4000000-c4ffffff
Prefetchable memory behind bridge: 0000383800000000-0000383c01ffffff
10: 00 00 00 00 00 00 00 00 03 05 05 00 f1 01 00 00
20: 00 c4 f0 c4 01 00 f1 01 38 38 00 00 3c 38 00 00
40: 01 48 03 c8 08 00 00 00 05 68 87 01 d8 03 e0 fe
70: 20 08 09 00 03 69 79 08 02 00 03 61 80 0c 40 00
80: 00 00 40 00 00 00 00 00 00 00 00 00 60 08 04 00
03:0c.0 PCI bridge: PLX Technology, Inc. Device 8764 (rev ab) (prog-if 00 [Normal decode])
Bus: primary=03, secondary=06, subordinate=06, sec-latency=0
Memory behind bridge: c3000000-c3ffffff
Prefetchable memory behind bridge: 0000383000000000-0000383401ffffff
10: 00 00 00 00 00 00 00 00 03 06 06 00 f1 01 00 00
20: 00 c3 f0 c3 01 00 f1 01 30 38 00 00 34 38 00 00
40: 01 48 03 c8 08 00 00 00 05 68 87 01 f8 03 e0 fe
70: 20 08 09 00 03 69 79 0c 02 00 03 61 80 0c 60 00
81:00.0 PCI bridge: PLX Technology, Inc. Device 8764 (rev ab) (prog-if 00 [Normal decode])
Physical Slot: 2
Memory at fb000000 (32-bit, non-prefetchable)
Bus: primary=81, secondary=82, subordinate=85, sec-latency=0
Memory behind bridge: fa000000-faffffff
Prefetchable memory behind bridge: 0000387800000000-0000387c01ffffff
10: 00 00 00 fb 00 00 00 00 81 82 85 00 f1 01 00 00
20: 00 fa f0 fa 01 00 f1 01 78 38 00 00 7c 38 00 00
40: 01 48 03 c8 08 00 00 00 05 68 87 01 58 00 e0 fe
82:04.0 PCI bridge: PLX Technology, Inc. Device 8764 (rev ab) (prog-if 00 [Normal decode])
Bus: primary=82, secondary=83, subordinate=83, sec-latency=0
10: 00 00 00 00 00 00 00 00 82 83 83 00 f1 01 00 00
40: 01 48 03 c8 08 00 00 00 05 68 87 01 78 00 e0 fe
80: 00 00 48 00 00 00 00 00 00 00 00 00 60 08 04 00
82:08.0 PCI bridge: PLX Technology, Inc. Device 8764 (rev ab) (prog-if 00 [Normal decode])
Bus: primary=82, secondary=84, subordinate=84, sec-latency=0
10: 00 00 00 00 00 00 00 00 82 84 84 00 f1 01 00 00
40: 01 48 03 c8 08 00 00 00 05 68 87 01 98 00 e0 fe
82:0c.0 PCI bridge: PLX Technology, Inc. Device 8764 (rev ab) (prog-if 00 [Normal decode])
Bus: primary=82, secondary=85, subordinate=85, sec-latency=0
10: 00 00 00 00 00 00 00 00 82 85 85 00 f1 01 00 00
40: 01 48 03 c8 08 00 00 00 05 68 87 01 b8 00 e0 fe
70: 30 08 09 00 03 69 79 0c 00 00 01 00 80 0c 60 00
/sbin/lspci -t
-±[0000:ff]-±08.0
| ±08.2
| ±08.3
| ±09.0
| ±09.2
| ±09.3
| ±0b.0
| ±0b.1
| ±0b.2
| ±0b.3
| ±0c.0
| ±0c.1
| ±0c.2
| ±0c.3
| ±0c.4
| ±0c.5
| ±0c.6
| ±0c.7
| ±0d.0
| ±0d.1
| ±0d.2
| ±0d.3
| ±0d.4
| ±0d.5
| ±0d.6
| ±0d.7
| ±0f.0
| ±0f.1
| ±0f.2
| ±0f.3
| ±0f.4
| ±0f.5
| ±0f.6
| ±10.0
| ±10.1
| ±10.5
| ±10.6
| ±10.7
| ±12.0
| ±12.1
| ±12.4
| ±12.5
| ±13.0
| ±13.1
| ±13.2
| ±13.3
| ±13.6
| ±13.7
| ±14.0
| ±14.1
| ±14.2
| ±14.3
| ±14.4
| ±14.5
| ±14.6
| ±14.7
| ±16.0
| ±16.1
| ±16.2
| ±16.3
| ±16.6
| ±16.7
| ±17.0
| ±17.1
| ±17.2
| ±17.3
| ±17.4
| ±17.5
| ±17.6
| ±17.7
| ±1e.0
| ±1e.1
| ±1e.2
| ±1e.3
| ±1e.4
| ±1f.0
| -1f.2
±[0000:80]-±02.0-[81-85]----00.0-[82-85]–±04.0-[83]–
| | ±08.0-[84]----00.0
| | -0c.0-[85]–
| ±04.0
| ±04.1
| ±04.2
| ±04.3
| ±04.4
| ±04.5
| ±04.6
| ±04.7
| ±05.0
| ±05.1
| ±05.2
| -05.4
±[0000:7f]-±08.0
| ±08.2
| ±08.3
| ±09.0
| ±09.2
| ±09.3
| ±0b.0
| ±0b.1
| ±0b.2
| ±0b.3
| ±0c.0
| ±0c.1
| ±0c.2
| ±0c.3
| ±0c.4
| ±0c.5
| ±0c.6
| ±0c.7
| ±0d.0
| ±0d.1
| ±0d.2
| ±0d.3
| ±0d.4
| ±0d.5
| ±0d.6
| ±0d.7
| ±0f.0
| ±0f.1
| ±0f.2
| ±0f.3
