Nvidia-smi reads only 3 GPUs from 4
I got 4 Dedicated Servers each one with 4 GPUs Nvidia GTX 1080.
I installed the Drivers and CUDA and everything is fine with 3 Servers except the last one when I do the nvidia-smi command I see only 3 GPUs readable but when I do the lspci | grep VGA I see the 4 GPUs.
I don’t know where the problem is coming from. I’m using Xubuntu Desktop 14.04 "Trusty Tahr.
Run nvidia-bug-report.sh on the specific machine and attach output file to your post.
Start of NVIDIA bug report log file. Please include this file, along
with a detailed description of your problem, when reporting a graphics
driver bug via the NVIDIA Linux forum (see devtalk.nvidia.com)
or by sending email to ‘linux-bugs@nvidia.com’.
nvidia-bug-report.sh Version: 21434654
Date: Fri Jun 2 08:43:16 EDT 2017
uname: Linux ns541816.ip-144-217-73.net 3.13.0-119-generic #166-Ubuntu SMP Wed May 3 12:18:55 UTC 2017 x86_64 x86_64 x86_64 GNU/Linux
command line flags:
*** /etc/issue
*** ls: -rw-r–r-- 1 root root 0 2017-06-01 11:39:46.963759476 -0400 /etc/issue
*** /etc/debian_version
*** ls: -rw-r–r-- 1 root root 11 2014-02-19 21:43:56.000000000 -0500 /etc/debian_version
jessie/sid
*** /var/log/nvidia-installer.log
*** ls: -rw-r–r-- 1 root root 28897 2017-06-01 11:57:38.995056197 -0400 /var/log/nvidia-installer.log
nvidia-installer log file ‘/var/log/nvidia-installer.log’
creation time: Thu Jun 1 11:57:26 2017
installer version: 375.26
PATH: /usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/snap/bin
nvidia-installer command line:
./nvidia-installer
–ui=none
–no-questions
–accept-license
–disable-nouveau
Using built-in stream user interface
→ Detected 32 CPUs online; setting concurrency level to 32.
→ License accepted by command line option.
→ Installing NVIDIA driver version 375.26.
→ There appears to already be a driver installed on your system (version: 367.35). As part of installing this driver (version: 375.26), the existing driver will be uninstalled. Are you sure you want to continue? (Answer: Continue installation)
→ Running distribution scripts
executing: ‘/usr/lib/nvidia/pre-install’…
→ done.
→ The distribution-provided pre-install script failed! Are you sure you want to continue? (Answer: Continue installation)
→ For some distributions, Nouveau can be disabled by adding a file in the modprobe configuration directory. Would you like nvidia-installer to attempt to create this modprobe file for you? (Answer: Yes)
→ One or more modprobe configuration files to disable Nouveau have been written. For some distributions, this may be sufficient to disable Nouveau; other distributions may require modification of the initial ramdisk. Please reboot your system and attempt NVIDIA driver installation again. Note if you later wish to reenable Nouveau, you will need to delete these files: /etc/modprobe.d/nvidia-installer-disable-nouveau.conf
→ Performing CC sanity check with CC=“/usr/bin/cc”.
→ Kernel source path: ‘/lib/modules/3.13.0-119-generic/build’
→ Kernel output path: ‘/lib/modules/3.13.0-119-generic/build’
→ Performing rivafb check.
→ Performing nvidiafb check.
→ Performing Xen check.
→ Performing PREEMPT_RT check.
→ Cleaning kernel module build directory.
executing: ‘cd ./kernel; /usr/bin/make -k -j32 clean NV_EXCLUDE_KERNEL_MODULES=“” SYSSRC=“/lib/modules/3.13.0-119-generic/build” SYSOUT=“/lib/modules/3.13.0-119-generic/build”’…
rm -f -r conftest
/usr/bin/make “CC=cc” KBUILD_VERBOSE= -C /lib/modules/3.13.0-119-generic/build M=/tmp/selfgz11795/NVIDIA-Linux-x86_64-375.26/kernel ARCH=x86_64 NV_KERNEL_SOURCES=/lib/modules/3.13.0-119-generic/build NV_KERNEL_OUTPUT=/lib/modules/3.13.0-119-generic/build NV_KERNEL_MODULES=“nvidia nvidia-uvm nvidia-modeset nvidia-drm” INSTALL_MOD_DIR=kernel/drivers/video clean
make[1]: Entering directory /usr/src/linux-headers-3.13.0-119-generic' make[1]: Leaving directory /usr/src/linux-headers-3.13.0-119-generic’
→ Building kernel modules
executing: ‘cd ./kernel; /usr/bin/make -k -j32 NV_EXCLUDE_KERNEL_MODULES=“” SYSSRC=“/lib/modules/3.13.0-119-generic/build” SYSOUT=“/lib/modules/3.13.0-119-generic/build”’…
/usr/bin/make “CC=cc” KBUILD_VERBOSE= -C /lib/modules/3.13.0-119-generic/build M=/tmp/selfgz11795/NVIDIA-Linux-x86_64-375.26/kernel ARCH=x86_64 NV_KERNEL_SOURCES=/lib/modules/3.13.0-119-generic/build NV_KERNEL_OUTPUT=/lib/modules/3.13.0-119-generic/build NV_KERNEL_MODULES=“nvidia nvidia-uvm nvidia-modeset nvidia-drm” INSTALL_MOD_DIR=kernel/drivers/video modules
make[1]: Entering directory /usr/src/linux-headers-3.13.0-119-generic' SYMLINK /tmp/selfgz11795/NVIDIA-Linux-x86_64-375.26/kernel/nvidia-modeset/nv-modeset-kernel.o SYMLINK /tmp/selfgz11795/NVIDIA-Linux-x86_64-375.26/kernel/nvidia/nv-kernel.o CONFTEST: INIT_WORK CONFTEST: follow_pfn CONFTEST: remap_pfn_range CONFTEST: vmap CONFTEST: set_pages_uc CONFTEST: set_memory_uc CONFTEST: set_memory_array_uc CONFTEST: change_page_attr CONFTEST: pci_get_class CONFTEST: pci_choose_state CONFTEST: vm_insert_page CONFTEST: acpi_device_id CONFTEST: acquire_console_sem CONFTEST: console_lock CONFTEST: on_each_cpu CONFTEST: kmem_cache_create CONFTEST: smp_call_function CONFTEST: acpi_evaluate_integer CONFTEST: ioremap_cache CONFTEST: ioremap_wc CONFTEST: acpi_walk_namespace CONFTEST: pci_dma_mapping_error CONFTEST: sg_alloc_table CONFTEST: sg_init_table CONFTEST: pci_domain_nr CONFTEST: pci_get_domain_bus_and_slot CONFTEST: get_num_physpages CONFTEST: efi_enabled CONFTEST: proc_create_data CONFTEST: pde_data CONFTEST: drm_driver_has_set_busid CONFTEST: proc_remove CONFTEST: pm_vt_switch_required CONFTEST: drm_driver_has_gem_prime_res_obj CONFTEST: xen_ioemu_inject_msi CONFTEST: phys_to_dma CONFTEST: get_dma_ops CONFTEST: write_cr4 CONFTEST: of_parse_phandle CONFTEST: for_each_online_node CONFTEST: node_end_pfn CONFTEST: pci_bus_address CONFTEST: pci_stop_and_remove_bus_device CONFTEST: pci_remove_bus_device CONFTEST: request_threaded_irq CONFTEST: remap_page_range CONFTEST: address_space_init_once CONFTEST: kbasename CONFTEST: fatal_signal_pending CONFTEST: list_cut_position CONFTEST: vzalloc CONFTEST: wait_on_bit_lock_argument_count CONFTEST: bitmap_clear CONFTEST: usleep_range CONFTEST: drm_dev_unref CONFTEST: radix_tree_empty CONFTEST: drm_reinit_primary_mode_group CONFTEST: drm_atomic_set_mode_for_crtc CONFTEST: drm_atomic_clean_old_fb CONFTEST: get_user_pages_remote CONFTEST: drm_gem_object_lookup CONFTEST: i2c_adapter CONFTEST: pm_message_t CONFTEST: irq_handler_t CONFTEST: acpi_device_ops CONFTEST: acpi_op_remove CONFTEST: outer_flush_all CONFTEST: proc_dir_entry CONFTEST: scatterlist CONFTEST: sg_table CONFTEST: file_operations CONFTEST: vm_operations_struct CONFTEST: atomic_long_type CONFTEST: pci_save_state CONFTEST: file_inode CONFTEST: task_struct CONFTEST: kuid_t CONFTEST: dma_ops CONFTEST: dma_map_ops CONFTEST: noncoherent_swiotlb_dma_ops CONFTEST: fault_flags CONFTEST: atomic64_type CONFTEST: address_space CONFTEST: backing_dev_info CONFTEST: kernel_write CONFTEST: iterate_dir CONFTEST: strnstr CONFTEST: kstrtoull CONFTEST: mm_context_t CONFTEST: drm_bus_present CONFTEST: drm_bus_has_bus_type CONFTEST: drm_bus_has_get_irq CONFTEST: drm_bus_has_get_name CONFTEST: drm_driver_has_legacy_dev_list CONFTEST: drm_crtc_state_has_connectors_changed CONFTEST: drm_init_functions_have_name_arg CONFTEST: drm_mode_connector_list_update_has_merge_type_bits_arg CONFTEST: drm_helper_mode_fill_fb_struct_has_const_mode_cmd_arg CONFTEST: drm_mode_config_funcs_has_atomic_state_alloc CONFTEST: drm_master_drop_has_from_release_arg CONFTEST: nvidia_vgpu_kvm_build CONFTEST: drm_available CONFTEST: nvidia_grid_build CONFTEST: drm_atomic_available CONFTEST: dom0_kernel_present CONFTEST: drm_atomic_modeset_nonblocking_commit_available CC [M] /tmp/selfgz11795/NVIDIA-Linux-x86_64-375.26/kernel/nvidia-drm/nvidia-drm.o CC [M] /tmp/selfgz11795/NVIDIA-Linux-x86_64-375.26/kernel/nvidia-drm/nvidia-drm-drv.o CC [M] /tmp/selfgz11795/NVIDIA-Linux-x86_64-375.26/kernel/nvidia-drm/nvidia-drm-utils.o CC [M] /tmp/selfgz11795/NVIDIA-Linux-x86_64-375.26/kernel/nvidia-drm/nvidia-drm-crtc.o CC [M] /tmp/selfgz11795/NVIDIA-Linux-x86_64-375.26/kernel/nvidia-drm/nvidia-drm-connector.o CC [M] /tmp/selfgz11795/NVIDIA-Linux-x86_64-375.26/kernel/nvidia-drm/nvidia-drm-encoder.o CC [M] /tmp/selfgz11795/NVIDIA-Linux-x86_64-375.26/kernel/nvidia-drm/nvidia-drm-gem.o CC [M] /tmp/selfgz11795/NVIDIA-Linux-x86_64-375.26/kernel/nvidia-drm/nvidia-drm-fb.o CC [M] /tmp/selfgz11795/NVIDIA-Linux-x86_64-375.26/kernel/nvidia-drm/nvidia-drm-modeset.o CC [M] /tmp/selfgz11795/NVIDIA-Linux-x86_64-375.26/kernel/nvidia-drm/nvidia-drm-mmap.o CC [M] /tmp/selfgz11795/NVIDIA-Linux-x86_64-375.26/kernel/nvidia-drm/nvidia-drm-fence.o CC [M] /tmp/selfgz11795/NVIDIA-Linux-x86_64-375.26/kernel/nvidia-drm/nvidia-drm-linux.o CC [M] /tmp/selfgz11795/NVIDIA-Linux-x86_64-375.26/kernel/nvidia-drm/nv-pci-table.o CC [M] /tmp/selfgz11795/NVIDIA-Linux-x86_64-375.26/kernel/nvidia-modeset/nvidia-modeset-linux.o CC [M] /tmp/selfgz11795/NVIDIA-Linux-x86_64-375.26/kernel/nvidia-uvm/uvm_utils.o CC [M] /tmp/selfgz11795/NVIDIA-Linux-x86_64-375.26/kernel/nvidia-uvm/uvm_common.o CC [M] /tmp/selfgz11795/NVIDIA-Linux-x86_64-375.26/kernel/nvidia-uvm/uvm_linux.o CC [M] /tmp/selfgz11795/NVIDIA-Linux-x86_64-375.26/kernel/nvidia-uvm/uvm_page_migration.o CC [M] /tmp/selfgz11795/NVIDIA-Linux-x86_64-375.26/kernel/nvidia-uvm/uvm_page_migration_stubs.o CC [M] /tmp/selfgz11795/NVIDIA-Linux-x86_64-375.26/kernel/nvidia-uvm/uvm_page_migration_kepler.o CC [M] /tmp/selfgz11795/NVIDIA-Linux-x86_64-375.26/kernel/nvidia-uvm/uvm_page_migration_maxwell.o CC [M] /tmp/selfgz11795/NVIDIA-Linux-x86_64-375.26/kernel/nvidia-uvm/uvm_page_migration_pascal.o CC [M] /tmp/selfgz11795/NVIDIA-Linux-x86_64-375.26/kernel/nvidia-uvm/uvm_channel_mgmt.o CC [M] /tmp/selfgz11795/NVIDIA-Linux-x86_64-375.26/kernel/nvidia-uvm/nvstatus.o CC [M] /tmp/selfgz11795/NVIDIA-Linux-x86_64-375.26/kernel/nvidia-uvm/nv-kthread-q.o CC [M] /tmp/selfgz11795/NVIDIA-Linux-x86_64-375.26/kernel/nvidia-uvm/nv-kthread-q-selftest.o CC [M] /tmp/selfgz11795/NVIDIA-Linux-x86_64-375.26/kernel/nvidia-uvm/uvm_common_test.o CC [M] /tmp/selfgz11795/NVIDIA-Linux-x86_64-375.26/kernel/nvidia-uvm/uvm_channel_directed_tests.o CC [M] /tmp/selfgz11795/NVIDIA-Linux-x86_64-375.26/kernel/nvidia-uvm/uvm_channel_basic_sanity_tests.o CC [M] /tmp/selfgz11795/NVIDIA-Linux-x86_64-375.26/kernel/nvidia-uvm/uvm_kernel_events.o CC [M] /tmp/selfgz11795/NVIDIA-Linux-x86_64-375.26/kernel/nvidia-uvm/uvm_kernel_counters.o CC [M] /tmp/selfgz11795/NVIDIA-Linux-x86_64-375.26/kernel/nvidia-uvm/uvm_debug_session.o CC [M] /tmp/selfgz11795/NVIDIA-Linux-x86_64-375.26/kernel/nvidia-uvm/uvm_gpu_ops_tests.o CC [M] /tmp/selfgz11795/NVIDIA-Linux-x86_64-375.26/kernel/nvidia-uvm/uvm_lite.o CC [M] /tmp/selfgz11795/NVIDIA-Linux-x86_64-375.26/kernel/nvidia-uvm/uvm_page_cache.o CC [M] /tmp/selfgz11795/NVIDIA-Linux-x86_64-375.26/kernel/nvidia-uvm/uvm_lite_api.o CC [M] /tmp/selfgz11795/NVIDIA-Linux-x86_64-375.26/kernel/nvidia-uvm/uvm_lite_prefetch.o CC [M] /tmp/selfgz11795/NVIDIA-Linux-x86_64-375.26/kernel/nvidia-uvm/uvm_lite_region_tracking.o CC [M] /tmp/selfgz11795/NVIDIA-Linux-x86_64-375.26/kernel/nvidia-uvm/uvm_mmu_mgmt_pascal.o CC [M] /tmp/selfgz11795/NVIDIA-Linux-x86_64-375.26/kernel/nvidia-uvm/uvm_mmu_mgmt.o CC [M] /tmp/selfgz11795/NVIDIA-Linux-x86_64-375.26/kernel/nvidia-uvm/uvm_mmu_mgmt_stubs.o CC [M] /tmp/selfgz11795/NVIDIA-Linux-x86_64-375.26/kernel/nvidia-uvm/uvm_full_fault_buffer.o CC [M] /tmp/selfgz11795/NVIDIA-Linux-x86_64-375.26/kernel/nvidia-uvm/uvm_full_fault_buffer_pascal.o CC [M] /tmp/selfgz11795/NVIDIA-Linux-x86_64-375.26/kernel/nvidia-uvm/mmu_fmt.o CC [M] /tmp/selfgz11795/NVIDIA-Linux-x86_64-375.26/kernel/nvidia-uvm/gmmu_fmt.o CC [M] /tmp/selfgz11795/NVIDIA-Linux-x86_64-375.26/kernel/nvidia-uvm/uvm8.o CC [M] /tmp/selfgz11795/NVIDIA-Linux-x86_64-375.26/kernel/nvidia-uvm/uvm8_tools.o CC [M] /tmp/selfgz11795/NVIDIA-Linux-x86_64-375.26/kernel/nvidia-uvm/uvm8_global.o CC [M] /tmp/selfgz11795/NVIDIA-Linux-x86_64-375.26/kernel/nvidia-uvm/uvm8_gpu.o CC [M] /tmp/selfgz11795/NVIDIA-Linux-x86_64-375.26/kernel/nvidia-uvm/uvm8_procfs.o CC [M] /tmp/selfgz11795/NVIDIA-Linux-x86_64-375.26/kernel/nvidia-uvm/uvm8_gpu_semaphore.o CC [M] /tmp/selfgz11795/NVIDIA-Linux-x86_64-375.26/kernel/nvidia-uvm/uvm8_va_space.o CC [M] /tmp/selfgz11795/NVIDIA-Linux-x86_64-375.26/kernel/nvidia-uvm/uvm8_mem.o CC [M] /tmp/selfgz11795/NVIDIA-Linux-x86_64-375.26/kernel/nvidia-uvm/uvm8_channel.o CC [M] /tmp/selfgz11795/NVIDIA-Linux-x86_64-375.26/kernel/nvidia-uvm/uvm8_rm_mem.o CC [M] /tmp/selfgz11795/NVIDIA-Linux-x86_64-375.26/kernel/nvidia-uvm/uvm8_lock.o CC [M] /tmp/selfgz11795/NVIDIA-Linux-x86_64-375.26/kernel/nvidia-uvm/uvm8_hal.o CC [M] /tmp/selfgz11795/NVIDIA-Linux-x86_64-375.26/kernel/nvidia-uvm/uvm8_range_tree.o CC [M] /tmp/selfgz11795/NVIDIA-Linux-x86_64-375.26/kernel/nvidia-uvm/uvm8_range_allocator.o CC [M] /tmp/selfgz11795/NVIDIA-Linux-x86_64-375.26/kernel/nvidia-uvm/uvm8_va_range.o CC [M] /tmp/selfgz11795/NVIDIA-Linux-x86_64-375.26/kernel/nvidia-uvm/uvm8_va_block.o CC [M] /tmp/selfgz11795/NVIDIA-Linux-x86_64-375.26/kernel/nvidia-uvm/uvm8_range_group.o CC [M] /tmp/selfgz11795/NVIDIA-Linux-x86_64-375.26/kernel/nvidia-uvm/uvm8_gpu_page_fault.o CC [M] /tmp/selfgz11795/NVIDIA-Linux-x86_64-375.26/kernel/nvidia-uvm/uvm8_perf_events.o CC [M] /tmp/selfgz11795/NVIDIA-Linux-x86_64-375.26/kernel/nvidia-uvm/uvm8_perf_module.o CC [M] /tmp/selfgz11795/NVIDIA-Linux-x86_64-375.26/kernel/nvidia-uvm/uvm8_mmu.o CC [M] /tmp/selfgz11795/NVIDIA-Linux-x86_64-375.26/kernel/nvidia-uvm/uvm8_pte_batch.o CC [M] /tmp/selfgz11795/NVIDIA-Linux-x86_64-375.26/kernel/nvidia-uvm/uvm8_tlb_batch.o CC [M] /tmp/selfgz11795/NVIDIA-Linux-x86_64-375.26/kernel/nvidia-uvm/uvm8_push.o CC [M] /tmp/selfgz11795/NVIDIA-Linux-x86_64-375.26/kernel/nvidia-uvm/uvm8_pushbuffer.o CC [M] /tmp/selfgz11795/NVIDIA-Linux-x86_64-375.26/kernel/nvidia-uvm/uvm8_thread_context.o CC [M] /tmp/selfgz11795/NVIDIA-Linux-x86_64-375.26/kernel/nvidia-uvm/uvm8_tracker.o CC [M] /tmp/selfgz11795/NVIDIA-Linux-x86_64-375.26/kernel/nvidia-uvm/uvm8_kepler.o CC [M] /tmp/selfgz11795/NVIDIA-Linux-x86_64-375.26/kernel/nvidia-uvm/uvm8_kepler_ce.o CC [M] /tmp/selfgz11795/NVIDIA-Linux-x86_64-375.26/kernel/nvidia-uvm/uvm8_kepler_host.o CC [M] /tmp/selfgz11795/NVIDIA-Linux-x86_64-375.26/kernel/nvidia-uvm/uvm8_kepler_mmu.o CC [M] /tmp/selfgz11795/NVIDIA-Linux-x86_64-375.26/kernel/nvidia-uvm/uvm8_maxwell.o CC [M] /tmp/selfgz11795/NVIDIA-Linux-x86_64-375.26/kernel/nvidia-uvm/uvm8_maxwell_host.o CC [M] /tmp/selfgz11795/NVIDIA-Linux-x86_64-375.26/kernel/nvidia-uvm/uvm8_pascal.o CC [M] /tmp/selfgz11795/NVIDIA-Linux-x86_64-375.26/kernel/nvidia-uvm/uvm8_pascal_ce.o CC [M] /tmp/selfgz11795/NVIDIA-Linux-x86_64-375.26/kernel/nvidia-uvm/uvm8_pascal_host.o CC [M] /tmp/selfgz11795/NVIDIA-Linux-x86_64-375.26/kernel/nvidia-uvm/uvm8_pascal_mmu.o CC [M] /tmp/selfgz11795/NVIDIA-Linux-x86_64-375.26/kernel/nvidia-uvm/uvm8_pascal_fault_buffer.o CC [M] /tmp/selfgz11795/NVIDIA-Linux-x86_64-375.26/kernel/nvidia-uvm/uvm8_policy.o CC [M] /tmp/selfgz11795/NVIDIA-Linux-x86_64-375.26/kernel/nvidia-uvm/uvm8_perf_utils.o CC [M] /tmp/selfgz11795/NVIDIA-Linux-x86_64-375.26/kernel/nvidia-uvm/uvm8_kvmalloc.o CC [M] /tmp/selfgz11795/NVIDIA-Linux-x86_64-375.26/kernel/nvidia-uvm/uvm8_pmm_gpu.o CC [M] /tmp/selfgz11795/NVIDIA-Linux-x86_64-375.26/kernel/nvidia-uvm/uvm8_migrate.o CC [M] /tmp/selfgz11795/NVIDIA-Linux-x86_64-375.26/kernel/nvidia-uvm/uvm8_map_external.o CC [M] /tmp/selfgz11795/NVIDIA-Linux-x86_64-375.26/kernel/nvidia-uvm/uvm8_user_channel.o CC [M] /tmp/selfgz11795/NVIDIA-Linux-x86_64-375.26/kernel/nvidia-uvm/uvm8_hmm.o CC [M] /tmp/selfgz11795/NVIDIA-Linux-x86_64-375.26/kernel/nvidia-uvm/uvm8_perf_heuristics.o CC [M] /tmp/selfgz11795/NVIDIA-Linux-x86_64-375.26/kernel/nvidia-uvm/uvm8_perf_thrashing.o CC [M] /tmp/selfgz11795/NVIDIA-Linux-x86_64-375.26/kernel/nvidia-uvm/uvm8_perf_prefetch.o CC [M] /tmp/selfgz11795/NVIDIA-Linux-x86_64-375.26/kernel/nvidia-uvm/uvm8_test.o CC [M] /tmp/selfgz11795/NVIDIA-Linux-x86_64-375.26/kernel/nvidia-uvm/uvm8_test_rng.o CC [M] /tmp/selfgz11795/NVIDIA-Linux-x86_64-375.26/kernel/nvidia-uvm/uvm8_range_tree_test.o CC [M] /tmp/selfgz11795/NVIDIA-Linux-x86_64-375.26/kernel/nvidia-uvm/uvm8_range_allocator_test.o CC [M] /tmp/selfgz11795/NVIDIA-Linux-x86_64-375.26/kernel/nvidia-uvm/uvm8_gpu_semaphore_test.o CC [M] /tmp/selfgz11795/NVIDIA-Linux-x86_64-375.26/kernel/nvidia-uvm/uvm8_mem_test.o CC [M] /tmp/selfgz11795/NVIDIA-Linux-x86_64-375.26/kernel/nvidia-uvm/uvm8_rm_mem_test.o CC [M] /tmp/selfgz11795/NVIDIA-Linux-x86_64-375.26/kernel/nvidia-uvm/uvm8_page_tree_test.o CC [M] /tmp/selfgz11795/NVIDIA-Linux-x86_64-375.26/kernel/nvidia-uvm/uvm8_tracker_test.o CC [M] /tmp/selfgz11795/NVIDIA-Linux-x86_64-375.26/kernel/nvidia-uvm/uvm8_push_test.o CC [M] /tmp/selfgz11795/NVIDIA-Linux-x86_64-375.26/kernel/nvidia-uvm/uvm8_channel_test.o CC [M] /tmp/selfgz11795/NVIDIA-Linux-x86_64-375.26/kernel/nvidia-uvm/uvm8_ce_test.o CC [M] /tmp/selfgz11795/NVIDIA-Linux-x86_64-375.26/kernel/nvidia-uvm/uvm8_lock_test.o CC [M] /tmp/selfgz11795/NVIDIA-Linux-x86_64-375.26/kernel/nvidia-uvm/uvm8_perf_utils_test.o CC [M] /tmp/selfgz11795/NVIDIA-Linux-x86_64-375.26/kernel/nvidia-uvm/uvm8_kvmalloc_test.o CC [M] /tmp/selfgz11795/NVIDIA-Linux-x86_64-375.26/kernel/nvidia-uvm/uvm8_pmm_test.o CC [M] /tmp/selfgz11795/NVIDIA-Linux-x86_64-375.26/kernel/nvidia-uvm/uvm8_perf_events_test.o CC [M] /tmp/selfgz11795/NVIDIA-Linux-x86_64-375.26/kernel/nvidia-uvm/uvm8_perf_module_test.o CC [M] /tmp/selfgz11795/NVIDIA-Linux-x86_64-375.26/kernel/nvidia-uvm/uvm8_get_rm_ptes_test.o CC [M] /tmp/selfgz11795/NVIDIA-Linux-x86_64-375.26/kernel/nvidia-uvm/uvm8_fault_buffer_flush_test.o CC [M] /tmp/selfgz11795/NVIDIA-Linux-x86_64-375.26/kernel/nvidia-uvm/uvm8_mmu_test.o CC [M] /tmp/selfgz11795/NVIDIA-Linux-x86_64-375.26/kernel/nvidia-uvm/uvm8_peer_identity_mappings_test.o CC [M] /tmp/selfgz11795/NVIDIA-Linux-x86_64-375.26/kernel/nvidia-uvm/uvm8_va_block_test.o CC [M] /tmp/selfgz11795/NVIDIA-Linux-x86_64-375.26/kernel/nvidia-uvm/uvm8_range_group_tree_test.o CC [M] /tmp/selfgz11795/NVIDIA-Linux-x86_64-375.26/kernel/nvidia/nv-frontend.o CC [M] /tmp/selfgz11795/NVIDIA-Linux-x86_64-375.26/kernel/nvidia/nv-instance.o CC [M] /tmp/selfgz11795/NVIDIA-Linux-x86_64-375.26/kernel/nvidia/nv.o CC [M] /tmp/selfgz11795/NVIDIA-Linux-x86_64-375.26/kernel/nvidia/nv-acpi.o CC [M] /tmp/selfgz11795/NVIDIA-Linux-x86_64-375.26/kernel/nvidia/nv-chrdev.o CC [M] /tmp/selfgz11795/NVIDIA-Linux-x86_64-375.26/kernel/nvidia/nv-cray.o CC [M] /tmp/selfgz11795/NVIDIA-Linux-x86_64-375.26/kernel/nvidia/nv-dma.o CC [M] /tmp/selfgz11795/NVIDIA-Linux-x86_64-375.26/kernel/nvidia/nv-gvi.o CC [M] /tmp/selfgz11795/NVIDIA-Linux-x86_64-375.26/kernel/nvidia/nv-i2c.o CC [M] /tmp/selfgz11795/NVIDIA-Linux-x86_64-375.26/kernel/nvidia/nv-mempool.o CC [M] /tmp/selfgz11795/NVIDIA-Linux-x86_64-375.26/kernel/nvidia/nv-mmap.o CC [M] /tmp/selfgz11795/NVIDIA-Linux-x86_64-375.26/kernel/nvidia/nv-p2p.o CC [M] /tmp/selfgz11795/NVIDIA-Linux-x86_64-375.26/kernel/nvidia/nv-pat.o CC [M] /tmp/selfgz11795/NVIDIA-Linux-x86_64-375.26/kernel/nvidia/nv-procfs.o CC [M] /tmp/selfgz11795/NVIDIA-Linux-x86_64-375.26/kernel/nvidia/nv-usermap.o CC [M] /tmp/selfgz11795/NVIDIA-Linux-x86_64-375.26/kernel/nvidia/nv-vm.o CC [M] /tmp/selfgz11795/NVIDIA-Linux-x86_64-375.26/kernel/nvidia/nv-vtophys.o CC [M] /tmp/selfgz11795/NVIDIA-Linux-x86_64-375.26/kernel/nvidia/os-interface.o CC [M] /tmp/selfgz11795/NVIDIA-Linux-x86_64-375.26/kernel/nvidia/os-mlock.o CC [M] /tmp/selfgz11795/NVIDIA-Linux-x86_64-375.26/kernel/nvidia/os-pci.o CC [M] /tmp/selfgz11795/NVIDIA-Linux-x86_64-375.26/kernel/nvidia/os-registry.o CC [M] /tmp/selfgz11795/NVIDIA-Linux-x86_64-375.26/kernel/nvidia/os-usermap.o CC [M] /tmp/selfgz11795/NVIDIA-Linux-x86_64-375.26/kernel/nvidia/nv-modeset-interface.o CC [M] /tmp/selfgz11795/NVIDIA-Linux-x86_64-375.26/kernel/nvidia/nv-pci-table.o CC [M] /tmp/selfgz11795/NVIDIA-Linux-x86_64-375.26/kernel/nvidia/nv-kthread-q.o CC [M] /tmp/selfgz11795/NVIDIA-Linux-x86_64-375.26/kernel/nvidia/nv-kthread-q-selftest.o CC [M] /tmp/selfgz11795/NVIDIA-Linux-x86_64-375.26/kernel/nvidia/nv_uvm_interface.o CC [M] /tmp/selfgz11795/NVIDIA-Linux-x86_64-375.26/kernel/nvidia/ebridge_linux.o CC [M] /tmp/selfgz11795/NVIDIA-Linux-x86_64-375.26/kernel/nvidia/ibmnpu_linux.o CC [M] /tmp/selfgz11795/NVIDIA-Linux-x86_64-375.26/kernel/nvidia/nvlink_linux.o CC [M] /tmp/selfgz11795/NVIDIA-Linux-x86_64-375.26/kernel/nvidia/nvlink_pci.o ld -r -o /tmp/selfgz11795/NVIDIA-Linux-x86_64-375.26/kernel/nvidia-modeset/nv-modeset-interface.o /tmp/selfgz11795/NVIDIA-Linux-x86_64-375.26/kernel/nvidia-modeset/nvidia-modeset-linux.o LD [M] /tmp/selfgz11795/NVIDIA-Linux-x86_64-375.26/kernel/nvidia.o LD [M] /tmp/selfgz11795/NVIDIA-Linux-x86_64-375.26/kernel/nvidia-uvm.o ld -r -o /tmp/selfgz11795/NVIDIA-Linux-x86_64-375.26/kernel/nvidia/nv-interface.o /tmp/selfgz11795/NVIDIA-Linux-x86_64-375.26/kernel/nvidia/nv-frontend.o /tmp/selfgz11795/NVIDIA-Linux-x86_64-375.26/kernel/nvidia/nv-instance.o /tmp/selfgz11795/NVIDIA-Linux-x86_64-375.26/kernel/nvidia/nv.o /tmp/selfgz11795/NVIDIA-Linux-x86_64-375.26/kernel/nvidia/nv-acpi.o /tmp/selfgz11795/NVIDIA-Linux-x86_64-375.26/kernel/nvidia/nv-chrdev.o /tmp/selfgz11795/NVIDIA-Linux-x86_64-375.26/kernel/nvidia/nv-cray.o /tmp/selfgz11795/NVIDIA-Linux-x86_64-375.26/kernel/nvidia/nv-dma.o /tmp/selfgz11795/NVIDIA-Linux-x86_64-375.26/kernel/nvidia/nv-gvi.o /tmp/selfgz11795/NVIDIA-Linux-x86_64-375.26/kernel/nvidia/nv-i2c.o /tmp/selfgz11795/NVIDIA-Linux-x86_64-375.26/kernel/nvidia/nv-mempool.o /tmp/selfgz11795/NVIDIA-Linux-x86_64-375.26/kernel/nvidia/nv-mmap.o /tmp/selfgz11795/NVIDIA-Linux-x86_64-375.26/kernel/nvidia/nv-p2p.o /tmp/selfgz11795/NVIDIA-Linux-x86_64-375.26/kernel/nvidia/nv-pat.o /tmp/selfgz11795/NVIDIA-Linux-x86_64-375.26/kernel/nvidia/nv-procfs.o /tmp/selfgz11795/NVIDIA-Linux-x86_64-375.26/kernel/nvidia/nv-usermap.o /tmp/selfgz11795/NVIDIA-Linux- x86_64-375.26/kernel/nvidia/nv-vm.o /tmp/selfgz11795/NVIDIA-Linux-x86_64-375.26/kernel/nvidia/nv-vtophys.o /tmp/selfgz11795/NVIDIA-Linux-x86_64-375.26/kernel/nvidia/os-interface.o /tmp/selfgz11795/NVIDIA-Linux-x86_64-375.26/kernel/nvidia/os-mlock.o /tmp/selfgz11795/NVIDIA-Linux-x86_64-375.26/kernel/nvidia/os-pci.o /tmp/selfgz11795/NVIDIA-Linux-x86_64-375.26/kernel/nvidia/os-registry.o /tmp/selfgz11795/NVIDIA-Linux-x86_64-375.26/kernel/nvidia/os-usermap.o /tmp/selfgz11795/NVIDIA-Linux-x86_64-375.26/kernel/nvidia/nv-modeset-interface.o /tmp/selfgz11795/NVIDIA-Linux-x86_64-375.26/kernel/nvidia/nv-pci-table.o /tmp/selfgz11795/NVIDIA-Linux-x86_64-375.26/kernel/nvidia/nv-kthread-q.o /tmp/selfgz11795/NVIDIA-Linux-x86_64-375.26/kernel/nvidia/nv-kthread-q-selftest.o /tmp/selfgz11795/NVIDIA-Linux-x86_64-375.26/kernel/nvidia/nv_uvm_interface.o /tmp/selfgz11795/NVIDIA-Linux-x86_64-375.26/kernel/nvidia/ebridge_linux.o /tmp/selfgz11795/NVIDIA-Linux-x86_64-375.26/kernel/nvidia/ibmnpu_linux.o /tmp/selfgz11795/NVIDIA-Linux-x8 6_64-375.26/kernel/nvidia/nvlink_linux.o /tmp/selfgz11795/NVIDIA-Linux-x86_64-375.26/kernel/nvidia/nvlink_pci.o LD [M] /tmp/selfgz11795/NVIDIA-Linux-x86_64-375.26/kernel/nvidia-modeset.o LD [M] /tmp/selfgz11795/NVIDIA-Linux-x86_64-375.26/kernel/nvidia-drm.o Building modules, stage 2. MODPOST 4 modules CC /tmp/selfgz11795/NVIDIA-Linux-x86_64-375.26/kernel/nvidia-drm.mod.o CC /tmp/selfgz11795/NVIDIA-Linux-x86_64-375.26/kernel/nvidia-modeset.mod.o CC /tmp/selfgz11795/NVIDIA-Linux-x86_64-375.26/kernel/nvidia-uvm.mod.o CC /tmp/selfgz11795/NVIDIA-Linux-x86_64-375.26/kernel/nvidia.mod.o LD [M] /tmp/selfgz11795/NVIDIA-Linux-x86_64-375.26/kernel/nvidia-modeset.ko LD [M] /tmp/selfgz11795/NVIDIA-Linux-x86_64-375.26/kernel/nvidia-drm.ko LD [M] /tmp/selfgz11795/NVIDIA-Linux-x86_64-375.26/kernel/nvidia-uvm.ko LD [M] /tmp/selfgz11795/NVIDIA-Linux-x86_64-375.26/kernel/nvidia.ko make[1]: Leaving directory /usr/src/linux-headers-3.13.0-119-generic’
→ done.
→ Kernel module compilation complete.
→ Kernel messages:
[ 198.473227] nvidia-modeset: Unloading
[ 198.480855] nvidia-nvlink: Unregistered the Nvlink Core, major device number 249
[ 208.543701] vgaarb: device changed decodes: PCI:0000:02:00.0,olddecodes=none,decodes=none:owns=none
[ 208.543777] vgaarb: device changed decodes: PCI:0000:03:00.0,olddecodes=none,decodes=none:owns=none
[ 208.543958] vgaarb: device changed decodes: PCI:0000:81:00.0,olddecodes=none,decodes=none:owns=none
[ 208.544098] vgaarb: device changed decodes: PCI:0000:82:00.0,olddecodes=none,decodes=none:owns=none
[ 208.544172] nvidia-nvlink: Nvlink Core is being initialized, major device number 249
[ 208.544187] NVRM: loading NVIDIA UNIX x86_64 Kernel Module 375.26 Thu Dec 8 18:36:43 PST 2016 (using threaded interrupts)
[ 208.546240] nvidia-uvm: Loaded the UVM driver in 8 mode, major device number 248
[ 208.547273] nvidia-modeset: Loading NVIDIA Kernel Mode Setting Driver for UNIX platforms 375.26 Thu Dec 8 18:04:14 PST 2016
[ 208.547707] [drm] [nvidia-drm] [GPU ID 0x00000200] Loading driver
[ 208.547743] [drm] [nvidia-drm] [GPU ID 0x00000300] Loading driver
[ 208.547777] [drm] [nvidia-drm] [GPU ID 0x00008100] Loading driver
[ 208.547805] [drm] [nvidia-drm] [GPU ID 0x00008200] Loading driver
[ 208.549591] [drm] [nvidia-drm] [GPU ID 0x00008200] Unloading driver
[ 208.549715] [drm] [nvidia-drm] [GPU ID 0x00008100] Unloading driver
[ 208.549784] [drm] [nvidia-drm] [GPU ID 0x00000300] Unloading driver
[ 208.549887] [drm] [nvidia-drm] [GPU ID 0x00000200] Unloading driver
[ 208.552836] nvidia-modeset: Unloading
[ 208.555688] nvidia-uvm: Unloaded the UVM driver in 8 mode
[ 208.556747] systemd-udevd[15761]: Failed to apply ACL on /dev/dri/card2: No such file or directory
[ 208.558023] systemd-udevd[15764]: Failed to apply ACL on /dev/dri/card4: No such file or directory
[ 208.558674] systemd-udevd[15762]: Failed to apply ACL on /dev/dri/card1: No such file or directory
[ 208.559248] nvidia-nvlink: Unregistered the Nvlink Core, major device number 249
[ 208.559273] systemd-udevd[15763]: Failed to apply ACL on /dev/dri/card3: No such file or directory
WARNING: nvidia-installer was forced to guess the X library path ‘/usr/lib’ and X module path ‘/usr/lib/xorg/modules’; these paths were not queryable from the system. If X fails to find the NVIDIA X driver module, please install the pkg-config utility and the X.Org SDK/development package for your distribution and reinstall the driver.
→ Installing both new and classic TLS OpenGL libraries.
→ Installing classic TLS 32bit OpenGL libraries.
WARNING: Unable to find a suitable destination to install 32-bit compatibility libraries. Your system may not be set up for 32-bit compatibility. 32-bit compatibility files will not be installed; if you wish to install them, re-run the installation and set a valid directory with the --compat32-libdir option.
→ Will install GLVND GLX client libraries.
→ Will install GLVND EGL client libraries.
→ Skipping GLX non-GLVND file: “libGL.so.375.26”
→ Skipping GLX non-GLVND file: “libGL.so.1”
→ Skipping GLX non-GLVND file: “libGL.so”
→ Skipping EGL non-GLVND file: “libEGL.so.375.26”
→ Skipping EGL non-GLVND file: “libEGL.so”
→ Skipping EGL non-GLVND file: “libEGL.so.1”
→ Uninstalling the previous installation with /usr/bin/nvidia-uninstall.
Looking for install checker script at ./libglvnd_install_checker/check-libglvnd-install.sh
executing: ‘/bin/sh ./libglvnd_install_checker/check-libglvnd-install.sh’…
Checking for libglvnd installation.
Checking libGLdispatch…
Can’t load library libGLdispatch.so.0: libGLdispatch.so.0: cannot open shared object file: No such file or directory
Will install libglvnd libraries.
Will install libEGL vendor library config file to /usr/share/glvnd/egl_vendor.d
→ Searching for conflicting files:
→ done.
→ Installing ‘NVIDIA Accelerated Graphics Driver for Linux-x86_64’ (375.26):
executing: ‘/sbin/ldconfig’…
executing: '/sbin/depmod -a '…
→ done.
→ Driver file installation is complete.
→ Running post-install sanity check:
→ done.
→ Post-install sanity check passed.
→ Running runtime sanity check:
→ done.
→ Runtime sanity check passed.
→ Would you like to run the nvidia-xconfig utility to automatically update your X configuration file so that the NVIDIA X driver will be used when you restart X? Any pre-existing X configuration file will be backed up. (Answer: No)
→ Installation of the NVIDIA Accelerated Graphics Driver for Linux-x86_64 (version: 375.26) is now complete. Please update your XF86Config or xorg.conf file as appropriate; see the file /usr/share/doc/NVIDIA_GLX-1.0/README.txt for details.
*** /var/log/nvidia-uninstall.log
*** ls: -rw-r–r-- 1 root root 1153 2017-06-01 11:57:37.851056178 -0400 /var/log/nvidia-uninstall.log
nvidia-installer log file ‘/var/log/nvidia-uninstall.log’
creation time: Thu Jun 1 11:57:36 2017
installer version: 367.35
-s
–log-file-name=/var/log/nvidia-uninstall.log
→ If you plan to no longer use the NVIDIA driver, you should make sure that no X screens are configured to use the NVIDIA X driver in your X configuration file. If you used nvidia-xconfig to configure X, it may have created a backup of your original configuration. Would you like to run nvidia-xconfig --restore-original-backup to attempt restoration of the original X configuration file? (Answer: No)
→ Parsing log file:
→ done.
→ Validating previous installation:
→ done.
→ Uninstalling NVIDIA Accelerated Graphics Driver for Linux-x86_64 (1.0-36735 (367.35)):
→ done.
→ Running depmod and ldconfig:
→ done.
→ Uninstallation of existing driver: NVIDIA Accelerated Graphics Driver for Linux-x86_64 (367.35) is complete.
*** /usr/share/nvidia/nvidia-application-profiles-375.26-rc
*** ls: -r–r–r-- 1 root root 5487 2017-06-01 11:57:38.127056183 -0400 /usr/share/nvidia/nvidia-application-profiles-375.26-rc
Application profiles for the NVIDIA Linux graphics driver, version 375.26
Last modified: Thu Dec 8 18:03:44 PST 2016
These profiles were provided by NVIDIA and should not be modified. If you
wish to change the defaults provided here, you can override them by creating
custom rules in /etc/nvidia/nvidia-application-profiles-rc (which will apply
system-wide) or, for a given user, $HOME/.nv/nvidia-application-profiles-rc
(which will apply to that particular user). See the "APPLICATION PROFILE
SEARCH PATH" section of the NVIDIA Linux Graphics Driver README for more
information.
“profiles” : [
“name” : “NonConformantBlitFramebufferScissor”,
“settings” : [ “GLConformantBlitFramebufferScissor”, false ]
“name” : “CL1C”,
“settings” : [ “0x528ab3”, 1 ]
“name” : “FA0”,
“settings” : [ “10572898”, 0 ]
“name” : “ExactGLESVersion”,
“settings” : [ “ForceRequestedESVersion”, 1 ]
“name” : “IgnoreGLSLExtensionRequirements”,
“settings” : [ “GLIgnoreGLSLExtReqs”, true ]
“name” : “No GSYNC”,
“settings” : [ “GLGSYNCAllowed”, false ]
“name” : “UseThreadedOptimizations”,
“settings” : [ “GLThreadedOptimizations”, true ]
“name” : “NoAniso”,
“settings” : [ “GLLogMaxAniso”, 0 ]
“name” : “NamedVertexAttributesApplyDivisor”,
“settings” : [ “GL23cd0e”, 1 ]
“name” : “NoEnforceShaderInputOutputMatching”,
“settings” : [ “GLShaderPortabilityWarnings”, false ]
“rules” : [
“pattern” : {
“feature” : “dso”,
“matches” : “libcogl.so”
“profile” : “NonConformantBlitFramebufferScissor”
“pattern” : {
“feature” : “dso”,
“matches” : “libMaya.so”
“profile” : “CL1C”
“pattern” : {
“feature” : “dso”,
“profile” : “NamedVertexAttributesApplyDivisor”
{ “pattern” : “SkullGirls.x86_64-pc-linux-gnu”, “profile” : “NoAniso” },
{ “pattern” : “SkullGirls.i686-pc-linux-gnu”, “profile” : “NoAniso” },
{ “pattern” : “Indivisible_Linux.i686-pc-linux-gnu”, “profile” : “NoAniso” },
{ “pattern” : “xsi”, “profile” : “CL1C” },
{ “pattern” : “HoudiniFX”, “profile” : “CL1C” },
{ “pattern” : “katana”, “profile” : “CL1C” },
{ “pattern” : “Autodesk Mudbox 2014 64-bit”, “profile” : “CL1C” },
{ “pattern” : “octane”, “profile” : “CL1C” },
{ “pattern” : “Fusion64_6.4”, “profile” : “CL1C” },
{ “pattern” : “Nuke7.0”, “profile” : “CL1C” },
{ “pattern” : “vray.exe”, “profile” : “CL1C” },
{ “pattern” : “vray.bin”, “profile” : “CL1C” },
{ “pattern” : “kwin_gles”, “profile” : “FA0” },
{ “pattern” : “kwin_gles”, “profile” : “ExactGLESVersion” },
“pattern” : [
{ “feature” : “procname”, “matches” : “heaven_x86”},
{ “op” : “not”, “sub” : { “feature” : “findfile”, “matches” : “browser_x86” } }
“profile” : “IgnoreGLSLExtensionRequirements”
“pattern” : [
{ “feature” : “procname”, “matches” : “heaven_x64”},
{ “op” : “not”, “sub” : { “feature” : “findfile”, “matches” : “browser_x64” } }
{ “pattern” : { “feature” : “procname”, “matches” : “cinnamon” }, “profile” : “No GSYNC” },
{ “pattern” : { “feature” : “procname”, “matches” : “compiz” }, “profile” : “No GSYNC” },
{ “pattern” : { “feature” : “procname”, “matches” : “compton” }, “profile” : “No GSYNC” },
{ “pattern” : { “feature” : “procname”, “matches” : “enlightenment” }, “profile” : “No GSYNC” },
{ “pattern” : { “feature” : “procname”, “matches” : “gnome-shell” }, “profile” : “No GSYNC” },
{ “pattern” : { “feature” : “procname”, “matches” : “kscreenlocker_greet” }, “profile” : “No GSYNC” },
{ “pattern” : { “feature” : “procname”, “matches” : “kwin” }, “profile” : “No GSYNC” },
{ “pattern” : { “feature” : “procname”, “matches” : “kwin_x11” }, “profile” : “No GSYNC” },
{ “pattern” : { “feature” : “procname”, “matches” : “muffin” }, “profile” : “No GSYNC” },
{ “pattern” : { “feature” : “dso”, “matches” : “libmutter.so” }, “profile” : “No GSYNC” },
{ “pattern” : { “feature” : “procname”, “matches” : “steam” }, “profile” : “No GSYNC” },
{ “pattern” : { “feature” : “procname”, “matches” : “steamcompmgr” }, “profile” : “No GSYNC” },
“pattern” : “Borderlands2”,
“profile” : “UseThreadedOptimizations”
“pattern” : “BorderlandsPreSequel”,
“pattern” : “ShadowOfMordor”,
“profile” : “NoEnforceShaderInputOutputMatching”
Skipping ldd output (glxinfo not found)
/usr/bin/lspci -d “10de:*” -v -xxx
02:00.0 VGA compatible controller: NVIDIA Corporation GP104 [GeForce GTX 1080] (rev a1) (prog-if 00 [VGA controller])
Subsystem: NVIDIA Corporation Device 119e
Physical Slot: 0
Flags: bus master, fast devsel, latency 0, IRQ 113
Memory at b6000000 (32-bit, non-prefetchable)
Memory at 13fe0000000 (64-bit, prefetchable)
Memory at 13ff0000000 (64-bit, prefetchable)
I/O ports at 6000
[virtual] Expansion ROM at b7000000 [disabled]
Capabilities: [60] Power Management version 3
Capabilities: [68] MSI: Enable+ Count=1/1 Maskable- 64bit+
Capabilities: [78] Express Legacy Endpoint, MSI 00
Capabilities: [100] Virtual Channel
Capabilities: [250] Latency Tolerance Reporting
Capabilities: [128] Power Budgeting <?> Capabilities: [420] Advanced Error Reporting Capabilities: [600] Vendor Specific Information: ID=0001 Rev=1 Len=024 <?>
Capabilities: [900] #19
Kernel driver in use: nvidia
00: de 10 80 1b 07 00 10 00 a1 00 00 03 00 00 80 00
10: 00 00 00 b6 0c 00 00 e0 3f 01 00 00 0c 00 00 f0
20: 3f 01 00 00 01 60 00 00 00 00 00 00 de 10 9e 11
30: 00 00 00 00 60 00 00 00 00 00 00 00 0b 01 00 00
40: de 10 9e 11 00 00 00 00 00 00 00 00 00 00 00 00
50: 01 00 00 00 01 00 00 00 ce d6 23 00 00 00 00 00
60: 01 68 03 00 08 00 00 00 05 78 81 00 38 07 e0 fe
70: 00 00 00 00 00 00 00 00 10 00 12 00 e1 8d 00 00
80: 30 29 00 00 03 4d 45 00 42 01 03 11 00 00 00 00
90: 00 00 00 00 00 00 00 00 00 00 00 00 13 08 04 00
a0: 00 00 00 00 0e 00 00 00 03 00 1e 00 00 00 00 00
b0: 00 00 00 00 09 00 14 01 00 00 00 00 00 00 00 00
c0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
d0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
e0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
f0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
02:00.1 Audio device: NVIDIA Corporation GP104 High Definition Audio Controller (rev a1)
Physical Slot: 0
Flags: bus master, fast devsel, latency 0, IRQ 36
Memory at b7080000 (32-bit, non-prefetchable)
Capabilities: [68] MSI: Enable- Count=1/1 Maskable- 64bit+
Capabilities: [78] Express Endpoint, MSI 00
Capabilities: [100] Advanced Error Reporting
Kernel driver in use: snd_hda_intel
00: de 10 f0 10 06 00 10 00 a1 00 03 04 10 00 80 00
10: 00 00 08 b7 00 00 00 00 00 00 00 00 00 00 00 00
20: 00 00 00 00 00 00 00 00 00 00 00 00 de 10 9e 11
30: 00 00 00 00 60 00 00 00 00 00 00 00 0a 02 00 00
50: 00 00 00 00 00 00 00 00 ce d6 23 00 00 00 00 00
60: 01 68 03 00 08 00 00 00 05 78 80 00 00 00 00 00
70: 00 00 00 00 00 00 00 00 10 00 02 00 e1 8d 00 00
80: 20 28 09 00 03 4d 45 00 03 01 03 11 00 00 00 00
a0: 00 00 00 00 0e 00 00 00 00 00 00 00 00 00 00 00
b0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
03:00.0 VGA compatible controller: NVIDIA Corporation GP104 [GeForce GTX 1080] (rev a1) (prog-if 00 [VGA controller])
Physical Slot: 1
Flags: bus master, fast devsel, latency 0, IRQ 114
Memory at b4000000 (32-bit, non-prefetchable)
Memory at 13fc0000000 (64-bit, prefetchable)
Memory at 13fd0000000 (64-bit, prefetchable)
I/O ports at 5000
[virtual] Expansion ROM at b5000000 [disabled]
10: 00 00 00 b4 0c 00 00 c0 3f 01 00 00 0c 00 00 d0
20: 3f 01 00 00 01 50 00 00 00 00 00 00 de 10 9e 11
60: 01 68 03 00 08 00 00 00 05 78 81 00 58 07 e0 fe
03:00.1 Audio device: NVIDIA Corporation GP104 High Definition Audio Controller (rev a1)
Physical Slot: 1
Flags: bus master, fast devsel, latency 0, IRQ 44
Memory at b5080000 (32-bit, non-prefetchable)
10: 00 00 08 b5 00 00 00 00 00 00 00 00 00 00 00 00
81:00.0 VGA compatible controller: NVIDIA Corporation GP104 [GeForce GTX 1080] (rev a1) (prog-if 00 [VGA controller])
Physical Slot: 4
Flags: bus master, fast devsel, latency 0, IRQ 56
Memory at fa000000 (32-bit, non-prefetchable)
Memory at 17fe0000000 (64-bit, prefetchable)
Memory at 17ff0000000 (64-bit, prefetchable)
I/O ports at f000
[virtual] Expansion ROM at fb000000 [disabled]
10: 00 00 00 fa 0c 00 00 e0 7f 01 00 00 0c 00 00 f0
20: 7f 01 00 00 01 f0 00 00 00 00 00 00 de 10 9e 11
60: 01 68 03 00 08 00 00 00 05 78 80 00 f8 00 e0 fe
80: 20 28 09 00 03 3d 45 00 42 00 01 11 00 00 00 00
81:00.1 Audio device: NVIDIA Corporation GP104 High Definition Audio Controller (rev a1)
Physical Slot: 4
Flags: bus master, fast devsel, latency 0, IRQ 60
Memory at fb080000 (32-bit, non-prefetchable)
10: 00 00 08 fb 00 00 00 00 00 00 00 00 00 00 00 00
80: 20 28 09 00 03 3d 45 00 03 00 01 11 00 00 00 00
82:00.0 VGA compatible controller: NVIDIA Corporation GP104 [GeForce GTX 1080] (rev a1) (prog-if 00 [VGA controller])
Physical Slot: 14
Flags: bus master, fast devsel, latency 0, IRQ 115
Memory at f8000000 (32-bit, non-prefetchable)
Memory at 17fc0000000 (64-bit, prefetchable)
Memory at 17fd0000000 (64-bit, prefetchable)
I/O ports at e000
[virtual] Expansion ROM at f9000000 [disabled]
10: 00 00 00 f8 0c 00 00 c0 7f 01 00 00 0c 00 00 d0
20: 7f 01 00 00 01 e0 00 00 00 00 00 00 de 10 9e 11
60: 01 68 03 00 08 00 00 00 05 78 81 00 d8 00 e0 fe
82:00.1 Audio device: NVIDIA Corporation GP104 High Definition Audio Controller (rev a1)
Physical Slot: 14
Flags: bus master, fast devsel, latency 0, IRQ 68
Memory at f9080000 (32-bit, non-prefetchable)
10: 00 00 08 f9 00 00 00 00 00 00 00 00 00 00 00 00
/usr/bin/lspci -d “10b5:*” -v -xxx
/usr/bin/lspci -t
-±[0000:ff]-±08.0
| ±08.2
| ±08.3
| ±09.0
| ±09.2
| ±09.3
| ±0b.0
| ±0b.1
| ±0b.2
| ±0b.3
| ±0c.0
| ±0c.1
| ±0c.2
| ±0c.3
| ±0c.4
| ±0c.5
| ±0c.6
| ±0c.7
| ±0d.0
| ±0d.1
| ±0f.0
| ±0f.1
| ±0f.4
| ±0f.5
| ±0f.6
| ±10.0
| ±10.1
| ±10.5
| ±10.6
| ±10.7
| ±12.0
| ±12.1
| ±13.0
| ±13.1
| ±13.2
| ±13.3
| ±13.4
| ±13.5
| ±13.6
| ±13.7
| ±14.0
| ±14.1
| ±14.2
| ±14.3
| ±14.4
| ±14.5
| ±14.6
| ±14.7
| ±15.0
| ±15.1
| ±15.2
| ±15.3
| ±16.0
| ±16.6
| ±16.7
| ±17.0
| ±17.4
| ±17.5
| ±17.6
| ±17.7
| ±1e.0
| ±1e.1
| ±1e.2
| ±1e.3
| ±1e.4
| ±1f.0
| -1f.2
±[0000:80]-±02.0-[81]–±00.0
| | -00.1
| ±03.0-[82]–±00.0
| | -00.1
| ±05.0
| ±05.1
| ±05.2
| -05.4
±[0000:7f]-±08.0
| ±08.2
| ±08.3
| ±09.0
| ±09.2
| ±09.3
| ±0b.0
| ±0b.1
| ±0b.2
| ±0b.3
| ±0c.0
| ±0c.1
| ±0c.2
| ±0c.3
| ±0c.4
| ±0c.5
| ±0c.6
| ±0c.7
| ±0d.0
| ±0d.1
| ±0f.0
| ±0f.1
| ±0f.4
| ±0f.5
| ±0f.6
| ±10.0
| ±10.1
| ±10.5
| ±10.6
| ±10.7
| ±12.0
| ±12.1
| ±13.0
| ±13.1
| ±13.2
| ±13.3
| ±13.4
| ±13.5
| ±13.6
| ±13.7
| ±14.0
| ±14.1
| ±14.2
| ±14.3
| ±14.4
| ±14.5
| ±14.6
| ±14.7
| ±15.0
| ±15.1
| ±15.2
| ±15.3
| ±16.0
| ±16.6
| ±16.7
| ±17.0
| ±17.4
| ±17.5
| ±17.6
| ±17.7
| ±1e.0
| ±1e.1
| ±1e.2
| ±1e.3
| ±1e.4
| ±1f.0
| -1f.2
-[0000:00]-±00.0
±01.0-[01]–
±02.0-[02]–±00.0
| -00.1
±03.0-[03]–±00.0
| -00.1
±05.0
±05.1
±05.2
±05.4
±11.0
±11.4
±14.0
±1a.0
±1b.0
±1c.0-[04]–
±1c.4-[05-06]----00.0-[06]----00.0
±1c.6-[07]----00.0
±1c.7-[08]----00.0
±1d.0
±1f.0
±1f.2
-1f.3
/usr/bin/lspci -nn
00:00.0 Host bridge [0600]: Intel Corporation Xeon E7 v4/Xeon E5 v4/Xeon E3 v4/Xeon D DMI2 [8086:6f00] (rev 01)
00:01.0 PCI bridge [0604]: Intel Corporation Xeon E7 v4/Xeon E5 v4/Xeon E3 v4/Xeon D PCI Express Root Port 1 [8086:6f02] (rev 01)
00:02.0 PCI bridge [0604]: Intel Corporation Xeon E7 v4/Xeon E5 v4/Xeon E3 v4/Xeon D PCI Express Root Port 2 [8086:6f04] (rev 01)
00:03.0 PCI bridge [0604]: Intel Corporation Xeon E7 v4/Xeon E5 v4/Xeon E3 v4/Xeon D PCI Express Root Port 3 [8086:6f08] (rev 01)
00:05.0 System peripheral [0880]: Intel Corporation Xeon E7 v4/Xeon E5 v4/Xeon E3 v4/Xeon D Map/VTd_Misc/System Management [8086:6f28] (rev 01)
00:05.1 System peripheral [0880]: Intel Corporation Xeon E7 v4/Xeon E5 v4/Xeon E3 v4/Xeon D IIO Hot Plug [8086:6f29] (rev 01)
00:05.2 System peripheral [0880]: Intel Corporation Xeon E7 v4/Xeon E5 v4/Xeon E3 v4/Xeon D IIO RAS/Control Status/Global Errors [8086:6f2a] (rev 01)
00:05.4 PIC [0800]: Intel Corporation Xeon E7 v4/Xeon E5 v4/Xeon E3 v4/Xeon D I/O APIC [8086:6f2c] (rev 01)
00:11.0 Unassigned class [ff00]: Intel Corporation C610/X99 series chipset SPSR [8086:8d7c] (rev 05)
00:11.4 SATA controller [0106]: Intel Corporation C610/X99 series chipset sSATA Controller [AHCI mode] [8086:8d62] (rev 05)
00:14.0 USB controller [0c03]: Intel Corporation C610/X99 series chipset USB xHCI Host Controller [8086:8d31] (rev 05)
00:1a.0 USB controller [0c03]: Intel Corporation C610/X99 series chipset USB Enhanced Host Controller #2 [8086:8d2d] (rev 05)
00:1b.0 Audio device [0403]: Intel Corporation C610/X99 series chipset HD Audio Controller [8086:8d20] (rev 05)
00:1c.0 PCI bridge [0604]: Intel Corporation C610/X99 series chipset PCI Express Root Port #1 [8086:8d10] (rev d5)
00:1c.4 PCI bridge [0604]: Intel Corporation C610/X99 series chipset PCI Express Root Port #5 [8086:8d18] (rev d5)
00:1c.6 PCI bridge [0604]: Intel Corporation C610/X99 series chipset PCI Express Root Port #7 [8086:8d1c] (rev d5)
00:1c.7 PCI bridge [0604]: Intel Corporation C610/X99 series chipset PCI Express Root Port #8 [8086:8d1e] (rev d5)
00:1d.0 USB controller [0c03]: Intel Corporation C610/X99 series chipset USB Enhanced Host Controller #1 [8086:8d26] (rev 05)
00:1f.0 ISA bridge [0601]: Intel Corporation C610/X99 series chipset LPC Controller [8086:8d44] (rev 05)
00:1f.2 SATA controller [0106]: Intel Corporation C610/X99 series chipset 6-Port SATA Controller [AHCI mode] [8086:8d02] (rev 05)
00:1f.3 SMBus [0c05]: Intel Corporation C610/X99 series chipset SMBus Controller [8086:8d22] (rev 05)
02:00.0 VGA compatible controller [0300]: NVIDIA Corporation GP104 [GeForce GTX 1080] [10de:1b80] (rev a1)
02:00.1 Audio device [0403]: NVIDIA Corporation GP104 High Definition Audio Controller [10de:10f0] (rev a1)
03:00.0 VGA compatible controller [0300]: NVIDIA Corporation GP104 [GeForce GTX 1080] [10de:1b80] (rev a1)
03:00.1 Audio device [0403]: NVIDIA Corporation GP104 High Definition Audio Controller [10de:10f0] (rev a1)
05:00.0 PCI bridge [0604]: ASPEED Technology, Inc. AST1150 PCI-to-PCI Bridge [1a03:1150] (rev 03)
06:00.0 VGA compatible controller [0300]: ASPEED Technology, Inc. ASPEED Graphics Family [1a03:2000] (rev 30)
07:00.0 Ethernet controller [0200]: Intel Corporation I210 Gigabit Network Connection [8086:1533] (rev 03)
08:00.0 Ethernet controller [0200]: Intel Corporation I210 Gigabit Network Connection [8086:1533] (rev 03)
7f:08.0 System peripheral [0880]: Intel Corporation Xeon E7 v4/Xeon E5 v4/Xeon E3 v4/Xeon D QPI Link 0 [8086:6f80] (rev 01)
7f:08.2 Performance counters [1101]: Intel Corporation Xeon E7 v4/Xeon E5 v4/Xeon E3 v4/Xeon D QPI Link 0 [8086:6f32] (rev 01)
7f:08.3 System peripheral [0880]: Intel Corporation Xeon E7 v4/Xeon E5 v4/Xeon E3 v4/Xeon D QPI Link 0 [8086:6f83] (rev 01)
7f:09.0 System peripheral [0880]: Intel Corporation Xeon E7 v4/Xeon E5 v4/Xeon E3 v4/Xeon D QPI Link 1 [8086:6f90] (rev 01)
7f:09.2 Performance counters [1101]: Intel Corporation Xeon E7 v4/Xeon E5 v4/Xeon E3 v4/Xeon D QPI Link 1 [8086:6f33] (rev 01)
7f:09.3 System peripheral [0880]: Intel Corporation Xeon E7 v4/Xeon E5 v4/Xeon E3 v4/Xeon D QPI Link 1 [8086:6f93] (rev 01)
7f:0b.0 System peripheral [0880]: Intel Corporation Xeon E7 v4/Xeon E5 v4/Xeon E3 v4/Xeon D R3 QPI Link 0/1 [8086:6f81] (rev 01)
7f:0b.1 Performance counters [1101]: Intel Corporation Xeon E7 v4/Xeon E5 v4/Xeon E3 v4/Xeon D R3 QPI Link 0/1 [8086:6f36] (rev 01)
7f:0b.2 Performance counters [1101]: Intel Corporation Xeon E7 v4/Xeon E5 v4/Xeon E3 v4/Xeon D R3 QPI Link 0/1 [8086:6f37] (rev 01)
7f:0b.3 System peripheral [0880]: Intel Corporation Xeon E7 v4/Xeon E5 v4/Xeon E3 v4/Xeon D R3 QPI Link Debug [8086:6f76] (rev 01)
7f:0c.0 System peripheral [0880]: Intel Corporation Xeon E7 v4/Xeon E5 v4/Xeon E3 v4/Xeon D Caching Agent [8086:6fe0] (rev 01)
7f:0c.1 System peripheral [0880]: Intel Corporation Xeon E7 v4/Xeon E5 v4/Xeon E3 v4/Xeon D Caching Agent [8086:6fe1] (rev 01)
7f:0c.2 System peripheral [0880]: Intel Corporation Xeon E7 v4/Xeon E5 v4/Xeon E3 v4/Xeon D Caching Agent [8086:6fe2] (rev 01)
7f:0c.3 System peripheral [0880]: Intel Corporation Xeon E7 v4/Xeon E5 v4/Xeon E3 v4/Xeon D Caching Agent [8086:6fe3] (rev 01)
7f:0c.4 System peripheral [0880]: Intel Corporation Xeon E7 v4/Xeon E5 v4/Xeon E3 v4/Xeon D Caching Agent [8086:6fe4] (rev 01)
7f:0c.5 System peripheral [0880]: Intel Corporation Xeon E7 v4/Xeon E5 v4/Xeon E3 v4/Xeon D Caching Agent [8086:6fe5] (rev 01)
7f:0c.6 System peripheral [0880]: Intel Corporation Xeon E7 v4/Xeon E5 v4/Xeon E3 v4/Xeon D Caching Agent [8086:6fe6] (rev 01)
7f:0c.7 System peripheral [0880]: Intel Corporation Xeon E7 v4/Xeon E5 v4/Xeon E3 v4/Xeon D Caching Agent [8086:6fe7] (rev 01)
7f:0d.0 System peripheral [0880]: Intel Corporation Xeon E7 v4/Xeon E5 v4/Xeon E3 v4/Xeon D Caching Agent [8086:6fe8] (rev 01)
7f:0d.1 System peripheral [0880]: Intel Corporation Xeon E7 v4/Xeon E5 v4/Xeon E3 v4/Xeon D Caching Agent [8086:6fe9] (rev 01)
7f:0f.0 System peripheral [0880]: Intel Corporation Xeon E7 v4/Xeon E5 v4/Xeon E3 v4/Xeon D Caching Agent [8086:6ff8] (rev 01)
7f:0f.1 System peripheral [0880]: Intel Corporation Xeon E7 v4/Xeon E5 v4/Xeon E3 v4/Xeon D Caching Agent [8086:6ff9] (rev 01)
7f:0f.4 System peripheral [0880]: Intel Corporation Xeon E7 v4/Xeon E5 v4/Xeon E3 v4/Xeon D Caching Agent [8086:6ffc] (rev 01)
7f:0f.5 System peripheral [0880]: Intel Corporation Xeon E7 v4/Xeon E5 v4/Xeon E3 v4/Xeon D Caching Agent [8086:6ffd] (rev 01)
7f:0f.6 System peripheral [0880]: Intel Corporation Xeon E7 v4/Xeon E5 v4/Xeon E3 v4/Xeon D Caching Agent [8086:6ffe] (rev 01)
7f:10.0 System peripheral [0880]: Intel Corporation Xeon E7 v4/Xeon E5 v4/Xeon E3 v4/Xeon D R2PCIe Agent [8086:6f1d] (rev 01)
7f:10.1 Performance counters [1101]: Intel Corporation Xeon E7 v4/Xeon E5 v4/Xeon E3 v4/Xeon D R2PCIe Agent [8086:6f34] (rev 01)
7f:10.5 System peripheral [0880]: Intel Corporation Xeon E7 v4/Xeon E5 v4/Xeon E3 v4/Xeon D Ubox [8086:6f1e] (rev 01)
7f:10.6 Performance counters [1101]: Intel Corporation Xeon E7 v4/Xeon E5 v4/Xeon E3 v4/Xeon D Ubox [8086:6f7d] (rev 01)
7f:10.7 System peripheral [0880]: Intel Corporation Xeon E7 v4/Xeon E5 v4/Xeon E3 v4/Xeon D Ubox [8086:6f1f] (rev 01)
7f:12.0 System peripheral [0880]: Intel Corporation Xeon E7 v4/Xeon E5 v4/Xeon E3 v4/Xeon D Home Agent 0 [8086:6fa0] (rev 01)
7f:12.1 Performance counters [1101]: Intel Corporation Xeon E7 v4/Xeon E5 v4/Xeon E3 v4/Xeon D Home Agent 0 [8086:6f30] (rev 01)
7f:13.0 System peripheral [0880]: Intel Corporation Xeon E7 v4/Xeon E5 v4/Xeon E3 v4/Xeon D Memory Controller 0 - Target Address/Thermal/RAS [8086:6fa8] (rev 01)
7f:13.1 System peripheral [0880]: Intel Corporation Xeon E7 v4/Xeon E5 v4/Xeon E3 v4/Xeon D Memory Controller 0 - Target Address/Thermal/RAS [8086:6f71] (rev 01)
7f:13.2 System peripheral [0880]: Intel Corporation Xeon E7 v4/Xeon E5 v4/Xeon E3 v4/Xeon D Memory Controller 0 - Channel Target Address Decoder [8086:6faa] (rev 01)
7f:13.3 System peripheral [0880]: Intel Corporation Xeon E7 v4/Xeon E5 v4/Xeon E3 v4/Xeon D Memory Controller 0 - Channel Target Address Decoder [8086:6fab] (rev 01)
7f:13.4 System peripheral [0880]: Intel Corporation Xeon E7 v4/Xeon E5 v4/Xeon E3 v4/Xeon D Memory Controller 0 - Channel Target Address Decoder [8086:6fac] (rev 01)
7f:13.5 System peripheral [0880]: Intel Corporatio
This was cut due to max post length. Please attach as file or upload to gist.github.com
Ouch, I’m sorry for that.
Here it’s gist:e049d3832bd2e65d172b6b546e07e996 · GitHub
Dmesg says 3 gpus working, one is broken. Might be the slot or a misplaced power connector, of course. I’d just replace.
The technical replied to me " All the GPUs are correctly powered. " but the problem still exists.
So? I said broken. Swap it with a working card to see if it’s the board or the graphics card, then RMA it.
