Max resolution has changed after installing nVidia driver 340.102 for 9500 GT in Linux Mint 18 MATE
I’ve been using Mint since September with this hardware and it was displaying fine until a couple of weeks when the resolution suddenly changed from 1600x1200 to 1024x768. First I tried to select nvidia-340 driver directly from the settings, but nothing happened. So, I downloaded the original driver (http://www.nvidia.com/Download/driverResults.aspx/114719/en-us), went to terminal (Ctrl-Alt-F1) and wrote:
sudo service mdm stop
sudo ./NVIDIA-Linux-x86_64-340.102.run
It filed to disable nouveau driver, so I searched on forums and found one that said to do:
sudo update-initramfs -u
After that, I repeated the process and seemed to install fine, but when loaded, the resolution had changed to 640x480 and not even centered.
Here is the log:
nvidia-installer log file '/var/log/nvidia-installer.log'
creation time: Tue May 16 09:13:40 2017
installer version: 340.102
PATH: /usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/snap/bin
nvidia-installer command line:
    ./nvidia-installer
Unable to load: nvidia-installer ncurses v6 user interface
Using: nvidia-installer ncurses user interface
-> License accepted.
-> Installing NVIDIA driver version 340.102.
-> Running distribution scripts
   executing: '/usr/lib/nvidia/pre-install'...
-> done.
-> The distribution-provided pre-install script failed!  Are you sure you want to continue? (Answer: Continue installation)
-> Would you like to register the kernel module sources with DKMS? This will allow DKMS to automatically build a new module, if you install a different kernel later. (Answer: Yes)
-> Installing both new and classic TLS OpenGL libraries.
-> Installing both new and classic TLS 32bit OpenGL libraries.
-> Install NVIDIA's 32-bit compatibility libraries? (Answer: No)
-> Skipping installation of the libvdpau wrapper library.
-> Searching for conflicting X files:
-> done.
-> Searching for conflicting OpenGL files:
-> done.
-> Installing 'NVIDIA Accelerated Graphics Driver for Linux-x86_64' (340.102):
   executing: '/sbin/ldconfig'...
-> done.
-> Driver file installation is complete.
-> Installing DKMS kernel module:
-> done.
-> Running post-install sanity check:
-> done.
-> Post-install sanity check passed.
-> Shared memory test passed.
-> Running runtime sanity check:
-> done.
-> Runtime sanity check passed.
-> Would you like to run the nvidia-xconfig utility to automatically update your X configuration file so that the NVIDIA X driver will be used when you restart X?  Any pre-existing X configuration file will be backed up. (Answer: Yes)
-> Your X configuration file has been successfully updated.  Installation of the NVIDIA Accelerated Graphics Driver for Linux-x86_64 (version: 340.102) is now complete.
It says that “Any pre-existing X configuration file will be backed up”, but it doesn’t say where it is.
Any help?
Please run nvidia-bug-report.sh and attach the resulting .gz file to your post.
I tried, but first it said
$ nvidia-bug-report.sh
Killed
and the second time it’s taking too long, I am not sure if it has hanged or it’s normal.
then there seems to be something very wrong. The interesting outputs would be
cat /var/log/Xorg.0.log
lspci -v (as root)
dmesg
$ cat /var/log/Xorg.0.log
[    38.828]
X.Org X Server 1.18.4
Release Date: 2016-07-19
[    38.828] X Protocol Version 11, Revision 0
[    38.828] Build Operating System: Linux 4.4.0-45-generic x86_64 Ubuntu
[    38.828] Current Operating System: Linux labgeo1-desktop 4.4.0-77-generic #98-Ubuntu SMP Wed Apr 26 08:34:02 UTC 2017 x86_64
[    38.828] Kernel command line: BOOT_IMAGE=/boot/vmlinuz-4.4.0-77-generic root=UUID=6907f491-8aa4-4f40-8209-104f92206e25 ro quiet splash vt.handoff=7
[    38.828] Build Date: 02 November 2016  10:06:10PM
[    38.828] xorg-server 2:1.18.4-0ubuntu0.2 (For technical support please see http://www.ubuntu.com/support)
[    38.828] Current version of pixman: 0.33.6
[    38.828] 	Before reporting problems, check http://wiki.x.org
	to make sure that you have the latest version.
[    38.828] Markers: (--) probed, (**) from config file, (==) default setting,
	(++) from command line, (!!) notice, (II) informational,
	(WW) warning, (EE) error, (NI) not implemented, (??) unknown.
[    38.828] (==) Log file: "/var/log/Xorg.0.log", Time: Tue May 16 13:16:30 2017
[    38.828] (==) Using config file: "/etc/X11/xorg.conf"
[    38.828] (==) Using system config directory "/usr/share/X11/xorg.conf.d"
[    38.850] (==) ServerLayout "Layout0"
[    38.850] (**) |-->Screen "Screen0" (0)
[    38.850] (**) |   |-->Monitor "Monitor0"
[    38.871] (**) |   |-->Device "Device0"
[    38.871] (**) |-->Input Device "Keyboard0"
[    38.871] (**) |-->Input Device "Mouse0"
[    38.871] (==) Automatically adding devices
[    38.871] (==) Automatically enabling devices
[    38.871] (==) Automatically adding GPU devices
[    38.871] (==) Max clients allowed: 256, resource mask: 0x1fffff
[    38.871] (WW) The directory "/usr/share/fonts/X11/cyrillic" does not exist.
[    38.871] 	Entry deleted from font path.
[    38.871] (WW) The directory "/usr/share/fonts/X11/100dpi/" does not exist.
[    38.871] (WW) The directory "/usr/share/fonts/X11/75dpi/" does not exist.
[    38.871] (WW) The directory "/usr/share/fonts/X11/100dpi" does not exist.
[    38.871] (WW) The directory "/usr/share/fonts/X11/75dpi" does not exist.
[    38.871] (==) FontPath set to:
	/usr/share/fonts/X11/misc,
	/usr/share/fonts/X11/Type1,
	built-ins
[    38.871] (==) ModulePath set to "/usr/lib/x86_64-linux-gnu/xorg/extra-modules,/usr/lib/xorg/extra-modules,/usr/lib/xorg/modules"
[    38.871] (WW) Hotplugging is on, devices using drivers 'kbd', 'mouse' or 'vmmouse' will be disabled.
[    38.871] (WW) Disabling Keyboard0
[    38.871] (WW) Disabling Mouse0
[    38.882] (II) Loader magic: 0x55a015898dc0
[    38.882] (II) Module ABI versions:
[    38.882] 	X.Org ANSI C Emulation: 0.4
[    38.882] 	X.Org Video Driver: 20.0
[    38.882] 	X.Org XInput driver : 22.1
[    38.882] 	X.Org Server Extension : 9.0
[    38.883] (++) using VT number 8
[    38.883] (II) systemd-logind: logind integration requires -keeptty and -keeptty was not provided, disabling logind integration
[    38.883] (II) xfree86: Adding drm device (/dev/dri/card0)
[    38.885] (--) PCI:*(0:1:0:0) 10de:0640:3842:c954 rev 161, Mem @ 0xf2000000/16777216, 0xe0000000/268435456, 0xf0000000/33554432, I/O @ 0x00001000/128
[    38.885] (II) LoadModule: "glx"
[    38.943] (II) Loading /usr/lib/xorg/modules/extensions/libglx.so
[    41.217] (II) Module glx: vendor="NVIDIA Corporation"
[    41.217] 	compiled for 4.0.2, module version = 1.0.0
[    41.217] 	Module class: X.Org Server Extension
[    41.232] (II) NVIDIA GLX Module  340.102  Mon Jan 16 12:37:38 PST 2017
[    41.262] (II) LoadModule: "nvidia"
[    41.262] (II) Loading /usr/lib/xorg/modules/drivers/nvidia_drv.so
[    41.439] (II) Module nvidia: vendor="NVIDIA Corporation"
[    41.439] 	compiled for 4.0.2, module version = 1.0.0
[    41.439] 	Module class: X.Org Video Driver
[    41.446] (II) NVIDIA dlloader X Driver  340.102  Mon Jan 16 12:17:09 PST 2017
[    41.446] (II) NVIDIA Unified Driver for all Supported NVIDIA GPUs
[    41.469] (II) Loading sub module "fb"
[    41.469] (II) LoadModule: "fb"
[    41.469] (II) Loading /usr/lib/xorg/modules/libfb.so
[    41.494] (II) Module fb: vendor="X.Org Foundation"
[    41.494] 	compiled for 1.18.4, module version = 1.0.0
[    41.494] 	ABI class: X.Org ANSI C Emulation, version 0.4
[    41.494] (WW) Unresolved symbol: fbGetGCPrivateKey
[    41.494] (II) Loading sub module "wfb"
[    41.494] (II) LoadModule: "wfb"
[    41.494] (II) Loading /usr/lib/xorg/modules/libwfb.so
[    41.507] (II) Module wfb: vendor="X.Org Foundation"
[    41.507] 	compiled for 1.18.4, module version = 1.0.0
[    41.507] 	ABI class: X.Org ANSI C Emulation, version 0.4
[    41.507] (II) Loading sub module "ramdac"
[    41.507] (II) LoadModule: "ramdac"
[    41.507] (II) Module "ramdac" already built-in
[    41.570] (EE) NVIDIA: Failed to initialize the NVIDIA kernel module. Please see the
[    41.570] (EE) NVIDIA:     system's kernel log for additional error messages and
[    41.570] (EE) NVIDIA:     consult the NVIDIA README for details.
[    41.570] (EE) No devices detected.
[    41.570] (==) Matched nvidia as autoconfigured driver 0
[    41.570] (==) Matched nouveau as autoconfigured driver 1
[    41.570] (==) Matched nvidia as autoconfigured driver 2
[    41.570] (==) Matched nouveau as autoconfigured driver 3
[    41.570] (==) Matched modesetting as autoconfigured driver 4
[    41.571] (==) Matched fbdev as autoconfigured driver 5
[    41.571] (==) Matched vesa as autoconfigured driver 6
[    41.571] (==) Assigned the driver to the xf86ConfigLayout
[    41.571] (II) LoadModule: "nvidia"
[    41.571] (II) Loading /usr/lib/xorg/modules/drivers/nvidia_drv.so
[    41.571] (II) Module nvidia: vendor="NVIDIA Corporation"
[    41.571] 	compiled for 4.0.2, module version = 1.0.0
[    41.571] 	Module class: X.Org Video Driver
[    41.571] (II) UnloadModule: "nvidia"
[    41.571] (II) Unloading nvidia
[    41.571] (II) Failed to load module "nvidia" (already loaded, 21920)
[    41.571] (II) LoadModule: "nouveau"
[    41.571] (II) Loading /usr/lib/xorg/modules/drivers/nouveau_drv.so
[    41.592] (II) Module nouveau: vendor="X.Org Foundation"
[    41.592] 	compiled for 1.18.1, module version = 1.0.12
[    41.592] 	Module class: X.Org Video Driver
[    41.592] 	ABI class: X.Org Video Driver, version 20.0
[    41.592] (II) LoadModule: "modesetting"
[    41.592] (II) Loading /usr/lib/xorg/modules/drivers/modesetting_drv.so
[    41.592] (II) Module modesetting: vendor="X.Org Foundation"
[    41.592] 	compiled for 1.18.4, module version = 1.18.4
[    41.592] (II) LoadModule: "fbdev"
[    41.592] (II) Loading /usr/lib/xorg/modules/drivers/fbdev_drv.so
[    41.592] (II) Module fbdev: vendor="X.Org Foundation"
[    41.592] 	compiled for 1.18.1, module version = 0.4.4
[    41.592] (II) LoadModule: "vesa"
[    41.592] (II) Loading /usr/lib/xorg/modules/drivers/vesa_drv.so
[    41.592] (II) Module vesa: vendor="X.Org Foundation"
[    41.592] 	compiled for 1.18.1, module version = 2.3.4
[    41.592] (II) NVIDIA dlloader X Driver  340.102  Mon Jan 16 12:17:09 PST 2017
[    41.592] (II) NVIDIA Unified Driver for all Supported NVIDIA GPUs
[    41.592] (II) NOUVEAU driver Date:   Tue Dec 8 15:52:25 2015 +1000
[    41.592] (II) NOUVEAU driver for NVIDIA chipset families :
[    41.592] 	RIVA TNT        (NV04)
[    41.592] 	RIVA TNT2       (NV05)
[    41.592] 	GeForce 256     (NV10)
[    41.592] 	GeForce 2       (NV11, NV15)
[    41.592] 	GeForce 4MX     (NV17, NV18)
[    41.592] 	GeForce 3       (NV20)
[    41.592] 	GeForce 4Ti     (NV25, NV28)
[    41.592] 	GeForce FX      (NV3x)
[    41.592] 	GeForce 6       (NV4x)
[    41.592] 	GeForce 7       (G7x)
[    41.592] 	GeForce 8       (G8x)
[    41.592] 	GeForce GTX 200 (NVA0)
[    41.592] 	GeForce GTX 400 (NVC0)
[    41.593] (II) modesetting: Driver for Modesetting Kernel Drivers: kms
[    41.593] (II) FBDEV: driver for framebuffer: fbdev
[    41.593] (II) VESA: driver for VESA chipsets: vesa
[    41.593] (WW) xf86OpenConsole: setpgid failed: Operation not permitted
[    41.593] (WW) xf86OpenConsole: setsid failed: Operation not permitted
[    41.654] (EE) NVIDIA: Failed to initialize the NVIDIA kernel module. Please see the
[    41.654] (EE) NVIDIA:     system's kernel log for additional error messages and
[    41.654] (EE) NVIDIA:     consult the NVIDIA README for details.
[    41.714] (EE) NVIDIA: Failed to initialize the NVIDIA kernel module. Please see the
[    41.714] (EE) NVIDIA:     system's kernel log for additional error messages and
[    41.714] (EE) NVIDIA:     consult the NVIDIA README for details.
[    41.714] (II) [drm] nouveau interface version: 1.3.1
[    41.714] (WW) Falling back to old probe method for modesetting
[    41.714] (WW) Falling back to old probe method for fbdev
[    41.714] (II) Loading sub module "fbdevhw"
[    41.714] (II) LoadModule: "fbdevhw"
[    41.714] (II) Loading /usr/lib/xorg/modules/libfbdevhw.so
[    41.714] (II) Module fbdevhw: vendor="X.Org Foundation"
[    41.714] 	compiled for 1.18.4, module version = 0.0.2
[    41.714] 	ABI class: X.Org Video Driver, version 20.0
[    41.715] (WW) Falling back to old probe method for vesa
[    41.715] (II) Loading sub module "dri2"
[    41.715] (II) LoadModule: "dri2"
[    41.715] (II) Module "dri2" already built-in
[    41.715] (--) NOUVEAU(0): Chipset: "NVIDIA NV96"
[    41.715] (**) NOUVEAU(0): Depth 24, (--) framebuffer bpp 32
[    41.715] (==) NOUVEAU(0): RGB weight 888
[    41.715] (==) NOUVEAU(0): Default visual is TrueColor
[    41.715] (==) NOUVEAU(0): Using HW cursor
[    41.715] (==) NOUVEAU(0): Allowed maximum DRI level 2.
[    41.715] (==) NOUVEAU(0): GLX sync to VBlank enabled.
[    41.715] (==) NOUVEAU(0): Page flipping enabled
[    41.715] (==) NOUVEAU(0): Swap limit set to 1 [Max allowed 2]
[    41.715] (==) NOUVEAU(0): Page flipping synced to vblank by kernel.
[    41.715] (II) NOUVEAU(0): Initializing outputs ...
[    41.859] (II) NOUVEAU(0): Output DVI-I-1 using monitor section Monitor0
[    41.870] (II) NOUVEAU(0): Output DVI-I-2 has no monitor section
[    41.870] (II) NOUVEAU(0): 2 crtcs needed for screen.
[    41.890] (II) NOUVEAU(0): Allocated crtc nr. 0 to this screen.
[    41.890] (II) NOUVEAU(0): Allocated crtc nr. 1 to this screen.
[    42.025] (II) NOUVEAU(0): EDID for output DVI-I-1
[    42.025] (II) NOUVEAU(0): Not using mode "1024x768" (hsync out of range)
[    42.025] (II) NOUVEAU(0): Not using mode "800x600" (hsync out of range)
[    42.026] (II) NOUVEAU(0): Printing probed modes for output DVI-I-1
[    42.026] (II) NOUVEAU(0): Modeline "848x480"x60.0   33.75  848 864 976 1088  480 486 494 517 +hsync +vsync (31.0 kHz e)
[    42.026] (II) NOUVEAU(0): Modeline "640x480"x59.9   25.18  640 656 752 800  480 490 492 525 -hsync -vsync (31.5 kHz e)
[    42.037] (II) NOUVEAU(0): EDID for output DVI-I-2
[    42.037] (II) NOUVEAU(0): Output DVI-I-1 connected
[    42.037] (II) NOUVEAU(0): Output DVI-I-2 disconnected
[    42.037] (II) NOUVEAU(0): Using exact sizes for initial modes
[    42.037] (II) NOUVEAU(0): Output DVI-I-1 using initial mode 640x480 +0+0
[    42.037] (II) NOUVEAU(0): Using default gamma of (1.0, 1.0, 1.0) unless otherwise stated.
[    42.037] (--) NOUVEAU(0): Virtual size is 640x480 (pitch 0)
[    42.037] (**) NOUVEAU(0):  Driver mode "640x480": 25.2 MHz (scaled from 0.0 MHz), 31.5 kHz, 59.9 Hz
[    42.037] (II) NOUVEAU(0): Modeline "640x480"x59.9   25.18  640 656 752 800  480 490 492 525 -hsync -vsync (31.5 kHz e)
[    42.037] (**) NOUVEAU(0):  Driver mode "848x480": 33.8 MHz (scaled from 0.0 MHz), 31.0 kHz, 60.0 Hz
[    42.037] (II) NOUVEAU(0): Modeline "848x480"x60.0   33.75  848 864 976 1088  480 486 494 517 +hsync +vsync (31.0 kHz e)
[    42.037] (==) NOUVEAU(0): DPI set to (96, 96)
[    42.037] (II) Loading sub module "fb"
[    42.037] (II) LoadModule: "fb"
[    42.037] (II) Loading /usr/lib/xorg/modules/libfb.so
[    42.037] (II) Module fb: vendor="X.Org Foundation"
[    42.037] 	compiled for 1.18.4, module version = 1.0.0
[    42.037] 	ABI class: X.Org ANSI C Emulation, version 0.4
[    42.038] (II) Loading sub module "shadowfb"
[    42.038] (II) LoadModule: "shadowfb"
[    42.038] (II) Loading /usr/lib/xorg/modules/libshadowfb.so
[    42.038] (II) Module shadowfb: vendor="X.Org Foundation"
[    42.038] 	compiled for 1.18.4, module version = 1.0.0
[    42.038] 	ABI class: X.Org ANSI C Emulation, version 0.4
[    42.038] (II) UnloadModule: "modesetting"
[    42.038] (II) Unloading modesetting
[    42.038] (II) UnloadModule: "fbdev"
[    42.038] (II) Unloading fbdev
[    42.038] (II) UnloadSubModule: "fbdevhw"
[    42.038] (II) Unloading fbdevhw
[    42.038] (II) UnloadModule: "vesa"
[    42.038] (II) Unloading vesa
[    42.038] (--) Depth 24 pixmap format is 32 bpp
[    42.056] (II) NOUVEAU(0): Channel setup complete.
[    42.075] (II) NOUVEAU(0): Hardware support for Present enabled
[    42.075] (II) NOUVEAU(0): [DRI2] Setup complete
[    42.075] (II) NOUVEAU(0): [DRI2]   DRI driver: nouveau
[    42.075] (II) NOUVEAU(0): [DRI2]   VDPAU driver: nouveau
[    42.075] (II) Loading sub module "exa"
[    42.075] (II) LoadModule: "exa"
[    42.075] (II) Loading /usr/lib/xorg/modules/libexa.so
[    42.076] (II) Module exa: vendor="X.Org Foundation"
[    42.076] 	compiled for 1.18.4, module version = 2.6.0
[    42.076] 	ABI class: X.Org Video Driver, version 20.0
[    42.076] (II) EXA(0): Driver allocated offscreen pixmaps
[    42.076] (II) EXA(0): Driver registered support for the following operations:
[    42.076] (II)         Solid
[    42.076] (II)         Copy
[    42.076] (II)         Composite (RENDER acceleration)
[    42.076] (II)         UploadToScreen
[    42.076] (II)         DownloadFromScreen
[    42.076] (==) NOUVEAU(0): Backing store enabled
[    42.076] (==) NOUVEAU(0): Silken mouse enabled
[    42.099] (II) NOUVEAU(0): [XvMC] Associated with Nouveau GeForce 8/9 Textured Video.
[    42.099] (II) NOUVEAU(0): [XvMC] Extension initialized.
[    42.099] (**) NOUVEAU(0): DPMS enabled
[    42.099] (II) NOUVEAU(0): RandR 1.2 enabled, ignore the following RandR disabled message.
[    42.109] (--) RandR disabled
[    42.117] (II) SELinux: Disabled on system
[    42.134] (EE) Failed to initialize GLX extension (Compatible NVIDIA X driver not found)
[    42.135] (II) NOUVEAU(0): NVEnterVT is called.
[    42.225] (II) NOUVEAU(0): Setting screen physical size to 169 x 127
[    42.225] resize called 640 480
[    42.434] (II) config/udev: Adding input device Power Button (/dev/input/event1)
[    42.435] (**) Power Button: Applying InputClass "evdev keyboard catchall"
[    42.435] (II) LoadModule: "evdev"
[    42.435] (II) Loading /usr/lib/xorg/modules/input/evdev_drv.so
[    42.450] (II) Module evdev: vendor="X.Org Foundation"
[    42.450] 	compiled for 1.18.1, module version = 2.10.1
[    42.450] 	Module class: X.Org XInput Driver
[    42.450] 	ABI class: X.Org XInput driver, version 22.1
[    42.450] (II) Using input driver 'evdev' for 'Power Button'
[    42.450] (**) Power Button: always reports core events
[    42.450] (**) evdev: Power Button: Device: "/dev/input/event1"
[    42.450] (--) evdev: Power Button: Vendor 0 Product 0x1
[    42.450] (--) evdev: Power Button: Found keys
[    42.450] (II) evdev: Power Button: Configuring as keyboard
[    42.450] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXPWRBN:00/input/input1/event1"
[    42.450] (II) XINPUT: Adding extended input device "Power Button" (type: KEYBOARD, id 6)
[    42.450] (**) Option "xkb_rules" "evdev"
[    42.450] (**) Option "xkb_model" "pc105"
[    42.450] (**) Option "xkb_layout" "latam"
[    42.471] (II) config/udev: Adding input device Sleep Button (/dev/input/event0)
[    42.471] (**) Sleep Button: Applying InputClass "evdev keyboard catchall"
[    42.471] (II) Using input driver 'evdev' for 'Sleep Button'
[    42.471] (**) Sleep Button: always reports core events
[    42.471] (**) evdev: Sleep Button: Device: "/dev/input/event0"
[    42.471] (--) evdev: Sleep Button: Vendor 0 Product 0x3
[    42.471] (--) evdev: Sleep Button: Found keys
[    42.471] (II) evdev: Sleep Button: Configuring as keyboard
[    42.471] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0E:00/input/input0/event0"
[    42.471] (II) XINPUT: Adding extended input device "Sleep Button" (type: KEYBOARD, id 7)
[    42.471] (**) Option "xkb_rules" "evdev"
[    42.471] (**) Option "xkb_model" "pc105"
[    42.471] (**) Option "xkb_layout" "latam"
[    42.473] (II) config/udev: Adding input device   USB Keyboard (/dev/input/event2)
[    42.473] (**)   USB Keyboard: Applying InputClass "evdev keyboard catchall"
[    42.473] (II) Using input driver 'evdev' for '  USB Keyboard'
[    42.473] (**)   USB Keyboard: always reports core events
[    42.473] (**) evdev:   USB Keyboard: Device: "/dev/input/event2"
[    42.473] (--) evdev:   USB Keyboard: Vendor 0x4d9 Product 0x1603
[    42.473] (--) evdev:   USB Keyboard: Found keys
[    42.473] (II) evdev:   USB Keyboard: Configuring as keyboard
[    42.473] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:1a.0/usb3/3-2/3-2:1.0/0003:04D9:1603.0002/input/input2/event2"
[    42.473] (II) XINPUT: Adding extended input device "  USB Keyboard" (type: KEYBOARD, id 8)
[    42.473] (**) Option "xkb_rules" "evdev"
[    42.473] (**) Option "xkb_model" "pc105"
[    42.473] (**) Option "xkb_layout" "latam"
[    42.474] (II) config/udev: Adding input device   USB Keyboard (/dev/input/event3)
[    42.474] (**)   USB Keyboard: Applying InputClass "evdev keyboard catchall"
[    42.474] (II) Using input driver 'evdev' for '  USB Keyboard'
[    42.474] (**)   USB Keyboard: always reports core events
[    42.474] (**) evdev:   USB Keyboard: Device: "/dev/input/event3"
[    42.474] (--) evdev:   USB Keyboard: Vendor 0x4d9 Product 0x1603
[    42.474] (--) evdev:   USB Keyboard: Found keys
[    42.474] (II) evdev:   USB Keyboard: Configuring as keyboard
[    42.474] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:1a.0/usb3/3-2/3-2:1.1/0003:04D9:1603.0003/input/input3/event3"
[    42.474] (II) XINPUT: Adding extended input device "  USB Keyboard" (type: KEYBOARD, id 9)
[    42.474] (**) Option "xkb_rules" "evdev"
[    42.474] (**) Option "xkb_model" "pc105"
[    42.474] (**) Option "xkb_layout" "latam"
[    42.475] (II) config/udev: Adding input device PixArt USB Optical Mouse (/dev/input/event4)
[    42.475] (**) PixArt USB Optical Mouse: Applying InputClass "evdev pointer catchall"
[    42.475] (II) Using input driver 'evdev' for 'PixArt USB Optical Mouse'
[    42.475] (**) PixArt USB Optical Mouse: always reports core events
[    42.475] (**) evdev: PixArt USB Optical Mouse: Device: "/dev/input/event4"
[    42.475] (--) evdev: PixArt USB Optical Mouse: Vendor 0x93a Product 0x2510
[    42.475] (--) evdev: PixArt USB Optical Mouse: Found 3 mouse buttons
[    42.475] (--) evdev: PixArt USB Optical Mouse: Found scroll wheel(s)
[    42.475] (--) evdev: PixArt USB Optical Mouse: Found relative axes
[    42.475] (--) evdev: PixArt USB Optical Mouse: Found x and y relative axes
[    42.475] (II) evdev: PixArt USB Optical Mouse: Configuring as mouse
[    42.475] (II) evdev: PixArt USB Optical Mouse: Adding scrollwheel support
[    42.475] (**) evdev: PixArt USB Optical Mouse: YAxisMapping: buttons 4 and 5
[    42.475] (**) evdev: PixArt USB Optical Mouse: EmulateWheelButton: 4, EmulateWheelInertia: 10, EmulateWheelTimeout: 200
[    42.475] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:1a.1/usb4/4-2/4-2:1.0/0003:093A:2510.0004/input/input4/event4"
[    42.475] (II) XINPUT: Adding extended input device "PixArt USB Optical Mouse" (type: MOUSE, id 10)
[    42.475] (II) evdev: PixArt USB Optical Mouse: initialized for relative axes.
[    42.475] (**) PixArt USB Optical Mouse: (accel) keeping acceleration scheme 1
[    42.475] (**) PixArt USB Optical Mouse: (accel) acceleration profile 0
[    42.475] (**) PixArt USB Optical Mouse: (accel) acceleration factor: 2.000
[    42.475] (**) PixArt USB Optical Mouse: (accel) acceleration threshold: 4
[    42.475] (II) config/udev: Adding input device PixArt USB Optical Mouse (/dev/input/mouse0)
[    42.476] (II) No input driver specified, ignoring this device.
[    42.476] (II) This device may have been added with another device file.
[    42.476] (II) config/udev: Adding input device HDA Intel MID Rear Mic (/dev/input/event5)
[    42.476] (II) config/udev: Adding input device HDA Intel MID Line (/dev/input/event6)
[    42.477] (II) config/udev: Adding input device HDA Intel MID Line Out (/dev/input/event7)
[    42.477] (II) No input driver specified, ignoring this device.
[    42.477] (II) This device may have been added with another device file.
[    42.482] (II) config/udev: Adding drm device (/dev/dri/card1)
[    42.482] (II) xfree86: Adding drm device (/dev/dri/card1)
[    42.482] (II) config/udev: Ignoring already known drm device (/dev/dri/card1)
[    42.482] (II) config/udev: removing GPU device /sys/devices/pci0000:00/0000:00:03.0/0000:01:00.0/drm/card1 /dev/dri/card1
[    42.483] (II) config/udev: Adding drm device (/dev/dri/card1)
[    42.483] (II) xfree86: Adding drm device (/dev/dri/card1)
[    42.483] (II) config/udev: Ignoring already known drm device (/dev/dri/card1)
[    42.483] (II) config/udev: removing GPU device /sys/devices/pci0000:00/0000:00:03.0/0000:01:00.0/drm/card1 /dev/dri/card1
$ sudo lspci -v
00:00.0 Host bridge: Intel Corporation Core Processor DMI (rev 11)
	Subsystem: Intel Corporation Core Processor DMI
	Flags: fast devsel
	Capabilities: [40] #00 [0000]
00:03.0 PCI bridge: Intel Corporation Core Processor PCI Express Root Port 1 (rev 11) (prog-if 00 [Normal decode])
	Flags: bus master, fast devsel, latency 0, IRQ 29
	Bus: primary=00, secondary=01, subordinate=01, sec-latency=0
	I/O behind bridge: 00001000-00001fff
	Memory behind bridge: f0000000-f2ffffff
	Prefetchable memory behind bridge: 00000000e0000000-00000000efffffff
	Capabilities: [40] Subsystem: Intel Corporation Core Processor PCI Express Root Port 1
	Capabilities: [60] MSI: Enable+ Count=1/2 Maskable+ 64bit-
	Capabilities: [90] Express Root Port (Slot+), MSI 00
	Capabilities: [e0] Power Management version 3
	Capabilities: [100] Advanced Error Reporting
	Capabilities: [150] Access Control Services
	Capabilities: [160] Vendor Specific Information: ID=0002 Rev=0 Len=00c <?>
	Kernel driver in use: pcieport
	Kernel modules: shpchp
00:08.0 System peripheral: Intel Corporation Core Processor System Management Registers (rev 11)
	Flags: fast devsel
	Capabilities: [40] Express Root Complex Integrated Endpoint, MSI 00
	Capabilities: [100] Vendor Specific Information: ID=0000 Rev=0 Len=000 <?>
00:08.1 System peripheral: Intel Corporation Core Processor Semaphore and Scratchpad Registers (rev 11)
	Flags: fast devsel
00:08.2 System peripheral: Intel Corporation Core Processor System Control and Status Registers (rev 11)
	Flags: fast devsel
00:08.3 System peripheral: Intel Corporation Core Processor Miscellaneous Registers (rev 11)
	Flags: fast devsel
00:10.0 System peripheral: Intel Corporation Core Processor QPI Link (rev 11)
	Flags: fast devsel
00:10.1 System peripheral: Intel Corporation Core Processor QPI Routing and Protocol Registers (rev 11)
	Flags: fast devsel
00:19.0 Ethernet controller: Intel Corporation 82578DC Gigabit Network Connection (rev 05)
	DeviceName: Intel(R) 82578DC Gigabit Network Connection
	Subsystem: Intel Corporation 82578DC Gigabit Network Connection
	Flags: bus master, fast devsel, latency 0, IRQ 31
	Memory at f3100000 (32-bit, non-prefetchable)
	Memory at f3124000 (32-bit, non-prefetchable)
	I/O ports at 2100
	Capabilities: [c8] Power Management version 2
	Capabilities: [d0] MSI: Enable+ Count=1/1 Maskable- 64bit+
	Capabilities: [e0] PCI Advanced Features
	Kernel driver in use: e1000e
	Kernel modules: e1000e
00:1a.0 USB controller: Intel Corporation 5 Series/3400 Series Chipset USB Universal Host Controller (rev 05) (prog-if 00 [UHCI])
	Subsystem: Intel Corporation 5 Series/3400 Series Chipset USB Universal Host Controller
	Flags: bus master, medium devsel, latency 0, IRQ 21
	I/O ports at 20e0
	Capabilities: [50] PCI Advanced Features
	Kernel driver in use: uhci_hcd
00:1a.1 USB controller: Intel Corporation 5 Series/3400 Series Chipset USB Universal Host Controller (rev 05) (prog-if 00 [UHCI])
	Flags: bus master, medium devsel, latency 0, IRQ 18
	I/O ports at 20c0
00:1a.2 USB controller: Intel Corporation 5 Series/3400 Series Chipset USB Universal Host Controller (rev 05) (prog-if 00 [UHCI])
	Flags: bus master, medium devsel, latency 0, IRQ 19
	I/O ports at 20a0
00:1a.7 USB controller: Intel Corporation 5 Series/3400 Series Chipset USB2 Enhanced Host Controller (rev 05) (prog-if 20 [EHCI])
	Subsystem: Intel Corporation 5 Series/3400 Series Chipset USB2 Enhanced Host Controller
	Flags: bus master, medium devsel, latency 0, IRQ 16
	Memory at f3125400 (32-bit, non-prefetchable)
	Capabilities: [50] Power Management version 2
	Capabilities: [58] Debug port: BAR=1 offset=00a0
	Capabilities: [98] PCI Advanced Features
	Kernel driver in use: ehci-pci
00:1b.0 Audio device: Intel Corporation 5 Series/3400 Series Chipset High Definition Audio (rev 05)
	DeviceName: Intel(R) High Definition Audio Device
	Subsystem: Intel Corporation 5 Series/3400 Series Chipset High Definition Audio
	Flags: bus master, fast devsel, latency 0, IRQ 32
	Memory at f3120000 (64-bit, non-prefetchable)
	Capabilities: [60] MSI: Enable+ Count=1/1 Maskable- 64bit+
	Capabilities: [70] Express Root Complex Integrated Endpoint, MSI 00
	Capabilities: [100] Virtual Channel
	Capabilities: [130] Root Complex Link
	Kernel driver in use: snd_hda_intel
	Kernel modules: snd_hda_intel
00:1c.0 PCI bridge: Intel Corporation 5 Series/3400 Series Chipset PCI Express Root Port 1 (rev 05) (prog-if 00 [Normal decode])
	Flags: bus master, fast devsel, latency 0, IRQ 30
	Bus: primary=00, secondary=02, subordinate=02, sec-latency=0
	I/O behind bridge: 00003000-00003fff
	Memory behind bridge: f3200000-f33fffff
	Prefetchable memory behind bridge: 00000000f3400000-00000000f35fffff
	Capabilities: [40] Express Root Port (Slot+), MSI 00
	Capabilities: [80] MSI: Enable+ Count=1/1 Maskable- 64bit-
	Capabilities: [90] Subsystem: Intel Corporation 5 Series/3400 Series Chipset PCI Express Root Port 1
	Capabilities: [a0] Power Management version 2
00:1d.0 USB controller: Intel Corporation 5 Series/3400 Series Chipset USB Universal Host Controller (rev 05) (prog-if 00 [UHCI])
	I/O ports at 2080
00:1d.1 USB controller: Intel Corporation 5 Series/3400 Series Chipset USB Universal Host Controller (rev 05) (prog-if 00 [UHCI])
	I/O ports at 2060
00:1d.2 USB controller: Intel Corporation 5 Series/3400 Series Chipset USB Universal Host Controller (rev 05) (prog-if 00 [UHCI])
	I/O ports at 2040
00:1d.3 USB controller: Intel Corporation 5 Series/3400 Series Chipset USB Universal Host Controller (rev 05) (prog-if 00 [UHCI])
	Flags: bus master, medium devsel, latency 0, IRQ 23
	I/O ports at 2020
00:1d.7 USB controller: Intel Corporation 5 Series/3400 Series Chipset USB2 Enhanced Host Controller (rev 05) (prog-if 20 [EHCI])
	Memory at f3125000 (32-bit, non-prefetchable)
00:1e.0 PCI bridge: Intel Corporation 82801 PCI Bridge (rev a5) (prog-if 01 [Subtractive decode])
	Bus: primary=00, secondary=03, subordinate=03, sec-latency=32
	Memory behind bridge: f3000000-f30fffff
	Capabilities: [50] Subsystem: Intel Corporation 82801 PCI Bridge
00:1f.0 ISA bridge: Intel Corporation P55 Chipset LPC Interface Controller (rev 05)
	Subsystem: Intel Corporation P55 Chipset LPC Interface Controller
	Capabilities: [e0] Vendor Specific Information: Len=10 <?>
	Kernel driver in use: lpc_ich
	Kernel modules: lpc_ich
00:1f.2 IDE interface: Intel Corporation 5 Series/3400 Series Chipset 4 port SATA IDE Controller (rev 05) (prog-if 8f [Master SecP SecO PriP PriO])
	DeviceName: Intel(R) SATA Controller 0
	Subsystem: Intel Corporation 5 Series/3400 Series Chipset 4 port SATA IDE Controller
	Flags: bus master, 66MHz, medium devsel, latency 0, IRQ 19
	I/O ports at 2178
	I/O ports at 218c
	I/O ports at 2170
	I/O ports at 2188
	I/O ports at 2150
	I/O ports at 2140
	Capabilities: [70] Power Management version 3
	Capabilities: [b0] PCI Advanced Features
	Kernel driver in use: ata_piix
	Kernel modules: pata_acpi
00:1f.3 SMBus: Intel Corporation 5 Series/3400 Series Chipset SMBus Controller (rev 05)
	Subsystem: Intel Corporation 5 Series/3400 Series Chipset SMBus Controller
	Flags: medium devsel, IRQ 9
	Memory at f3125800 (64-bit, non-prefetchable)
	I/O ports at 2000
	Kernel modules: i2c_i801
00:1f.5 IDE interface: Intel Corporation 5 Series/3400 Series Chipset 2 port SATA IDE Controller (rev 05) (prog-if 85 [Master SecO PriO])
	DeviceName: Intel(R) SATA Controller 1
	Subsystem: Intel Corporation 5 Series/3400 Series Chipset 2 port SATA IDE Controller
	I/O ports at 2168
	I/O ports at 2184
	I/O ports at 2160
	I/O ports at 2180
	I/O ports at 2130
	I/O ports at 2120
01:00.0 VGA compatible controller: NVIDIA Corporation G96 [GeForce 9500 GT] (rev a1) (prog-if 00 [VGA controller])
	Subsystem: eVga.com. Corp. G96 [GeForce 9500 GT]
	Flags: bus master, fast devsel, latency 0, IRQ 33
	Memory at f2000000 (32-bit, non-prefetchable)
	Memory at e0000000 (64-bit, prefetchable)
	Memory at f0000000 (64-bit, non-prefetchable)
	I/O ports at 1000
	Expansion ROM at <ignored> [disabled]
	Capabilities: [60] Power Management version 3
	Capabilities: [68] MSI: Enable+ Count=1/1 Maskable- 64bit+
	Capabilities: [78] Express Endpoint, MSI 00
	Capabilities: [b4] Vendor Specific Information: Len=14 <?>
	Capabilities: [128] Power Budgeting <?>
	Capabilities: [600] Vendor Specific Information: ID=0001 Rev=1 Len=024 <?>
	Kernel driver in use: nouveau
	Kernel modules: nvidiafb, nouveau, nvidia
03:03.0 FireWire (IEEE 1394): Texas Instruments TSB43AB22A IEEE-1394a-2000 Controller (PHY/Link) [iOHCI-Lynx] (prog-if 10 [OHCI])
	Subsystem: Intel Corporation TSB43AB22A IEEE-1394a-2000 Controller (PHY/Link) [iOHCI-Lynx]
	Flags: bus master, medium devsel, latency 32, IRQ 19
	Memory at f3004000 (32-bit, non-prefetchable)
	Memory at f3000000 (32-bit, non-prefetchable)
	Capabilities: [44] Power Management version 2
	Kernel driver in use: firewire_ohci
	Kernel modules: firewire_ohci
3f:00.0 Host bridge: Intel Corporation Core Processor QuickPath Architecture Generic Non-Core Registers (rev 04)
	Subsystem: Intel Corporation Core Processor QuickPath Architecture Generic Non-Core Registers
3f:00.1 Host bridge: Intel Corporation Core Processor QuickPath Architecture System Address Decoder (rev 04)
	Subsystem: Intel Corporation Core Processor QuickPath Architecture System Address Decoder
3f:02.0 Host bridge: Intel Corporation Core Processor QPI Link 0 (rev 04)
	Subsystem: Intel Corporation Core Processor QPI Link 0
	Kernel driver in use: i7core_edac
	Kernel modules: i7core_edac
3f:02.1 Host bridge: Intel Corporation Core Processor QPI Physical 0 (rev 04)
	Subsystem: Intel Corporation Core Processor QPI Physical 0
3f:03.0 Host bridge: Intel Corporation Core Processor Integrated Memory Controller (rev 04)
	Subsystem: Intel Corporation Core Processor Integrated Memory Controller
3f:03.1 Host bridge: Intel Corporation Core Processor Integrated Memory Controller Target Address Decoder (rev 04)
	Subsystem: Intel Corporation Core Processor Integrated Memory Controller Target Address Decoder
3f:03.4 Host bridge: Intel Corporation Core Processor Integrated Memory Controller Test Registers (rev 04)
	Subsystem: Intel Corporation Core Processor Integrated Memory Controller Test Registers
3f:04.0 Host bridge: Intel Corporation Core Processor Integrated Memory Controller Channel 0 Control Registers (rev 04)
	Subsystem: Intel Corporation Core Processor Integrated Memory Controller Channel 0 Control Registers
3f:04.1 Host bridge: Intel Corporation Core Processor Integrated Memory Controller Channel 0 Address Registers (rev 04)
	Subsystem: Intel Corporation Core Processor Integrated Memory Controller Channel 0 Address Registers
3f:04.2 Host bridge: Intel Corporation Core Processor Integrated Memory Controller Channel 0 Rank Registers (rev 04)
	Subsystem: Intel Corporation Core Processor Integrated Memory Controller Channel 0 Rank Registers
3f:04.3 Host bridge: Intel Corporation Core Processor Integrated Memory Controller Channel 0 Thermal Control Registers (rev 04)
	Subsystem: Intel Corporation Core Processor Integrated Memory Controller Channel 0 Thermal Control Registers
3f:05.0 Host bridge: Intel Corporation Core Processor Integrated Memory Controller Channel 1 Control Registers (rev 04)
	Subsystem: Intel Corporation Core Processor Integrated Memory Controller Channel 1 Control Registers
3f:05.1 Host bridge: Intel Corporation Core Processor Integrated Memory Controller Channel 1 Address Registers (rev 04)
	Subsystem: Intel Corporation Core Processor Integrated Memory Controller Channel 1 Address Registers
3f:05.2 Host bridge: Intel Corporation Core Processor Integrated Memory Controller Channel 1 Rank Registers (rev 04)
	Subsystem: Intel Corporation Core Processor Integrated Memory Controller Channel 1 Rank Registers
3f:05.3 Host bridge: Intel Corporation Core Processor Integrated Memory Controller Channel 1 Thermal Control Registers (rev 04)
	Subsystem: Intel Corporation Core Processor Integrated Memory Controller Channel 1 Thermal Control Registers
$ dmesg
[    0.000000] microcode: CPU0 microcode updated early to revision 0x7, date = 2013-08-20
[    0.000000] Initializing cgroup subsys cpuset
[    0.000000] Initializing cgroup subsys cpuacct
[    0.000000] Linux version 4.4.0-77-generic (buildd@lgw01-59) (gcc version 5.4.0 20160609 (Ubuntu 5.4.0-6ubuntu1~16.04.4) ) #98-Ubuntu SMP Wed Apr 26 08:34:02 UTC 2017 (Ubuntu 4.4.0-77.98-generic 4.4.59)
[    0.000000] Command line: BOOT_IMAGE=/boot/vmlinuz-4.4.0-77-generic root=UUID=6907f491-8aa4-4f40-8209-104f92206e25 ro quiet splash vt.handoff=7
[    0.000000] KERNEL supported cpus:
[    0.000000]   Intel GenuineIntel
[    0.000000]   AMD AuthenticAMD
[    0.000000]   Centaur CentaurHauls
[    0.000000] x86/fpu: Legacy x87 FPU detected.
[    0.000000] x86/fpu: Using 'lazy' FPU context switches.
[    0.000000] e820: BIOS-provided physical RAM map:
[    0.000000] BIOS-e820: [mem 0x0000000000000000-0x000000000008efff] usable
[    0.000000] BIOS-e820: [mem 0x000000000008f000-0x000000000009ffff] reserved
[    0.000000] BIOS-e820: [mem 0x00000000000e0000-0x00000000000fffff] reserved
[    0.000000] BIOS-e820: [mem 0x0000000000100000-0x00000000df62cfff] usable
[    0.000000] BIOS-e820: [mem 0x00000000df62d000-0x00000000df634fff] reserved
[    0.000000] BIOS-e820: [mem 0x00000000df635000-0x00000000df66efff] usable
[    0.000000] BIOS-e820: [mem 0x00000000df66f000-0x00000000df6befff] reserved
[    0.000000] BIOS-e820: [mem 0x00000000df6bf000-0x00000000df6e5fff] usable
[    0.000000] BIOS-e820: [mem 0x00000000df6e6000-0x00000000df7befff] ACPI NVS
[    0.000000] BIOS-e820: [mem 0x00000000df7bf000-0x00000000df7e6fff] usable
[    0.000000] BIOS-e820: [mem 0x00000000df7e7000-0x00000000df7f1fff] ACPI data
[    0.000000] BIOS-e820: [mem 0x00000000df7f2000-0x00000000df7f2fff] usable
[    0.000000] BIOS-e820: [mem 0x00000000df7f3000-0x00000000df7fefff] ACPI data
[    0.000000] BIOS-e820: [mem 0x00000000df7ff000-0x00000000df7fffff] usable
[    0.000000] BIOS-e820: [mem 0x00000000df800000-0x00000000dfffffff] reserved
[    0.000000] BIOS-e820: [mem 0x00000000f8000000-0x00000000ffffffff] reserved
[    0.000000] BIOS-e820: [mem 0x0000000100000000-0x000000021fffffff] usable
[    0.000000] NX (Execute Disable) protection: active
[    0.000000] SMBIOS 2.6 present.
[    0.000000] DMI:                  /DP55WB, BIOS WBIBX10J.86A.0312.2010.1123.2356 11/23/2010
[    0.000000] e820: update [mem 0x00000000-0x00000fff] usable ==> reserved
[    0.000000] e820: remove [mem 0x000a0000-0x000fffff] usable
[    0.000000] e820: last_pfn = 0x220000 max_arch_pfn = 0x400000000
[    0.000000] MTRR default type: uncachable
[    0.000000] MTRR fixed ranges enabled:
[    0.000000]   00000-9FFFF write-back
[    0.000000]   A0000-BFFFF uncachable
[    0.000000]   C0000-DFFFF write-protect
[    0.000000]   E0000-FFFFF uncachable
[    0.000000] MTRR variable ranges enabled:
[    0.000000]   0 base 000000000 mask F80000000 write-back
[    0.000000]   1 base 080000000 mask FC0000000 write-back
[    0.000000]   2 base 0C0000000 mask FE0000000 write-back
[    0.000000]   3 base 0FFE00000 mask FFFE00000 write-protect
[    0.000000]   4 base 100000000 mask F00000000 write-back
[    0.000000]   5 base 200000000 mask E00000000 write-back
[    0.000000]   6 disabled
[    0.000000]   7 disabled
[    0.000000] x86/PAT: Configuration [0-7]: WB  WC  UC- UC  WB  WC  UC- WT
[    0.000000] e820: last_pfn = 0xdf800 max_arch_pfn = 0x400000000
[    0.000000] Scanning 1 areas for low memory corruption
[    0.000000] Base memory trampoline at [ffff880000089000] 89000 size 24576
[    0.000000] BRK [0x0220b000, 0x0220bfff] PGTABLE
[    0.000000] BRK [0x0220c000, 0x0220cfff] PGTABLE
[    0.000000] BRK [0x0220d000, 0x0220dfff] PGTABLE
[    0.000000] BRK [0x0220e000, 0x0220efff] PGTABLE
[    0.000000] BRK [0x0220f000, 0x0220ffff] PGTABLE
[    0.000000] BRK [0x02210000, 0x02210fff] PGTABLE
[    0.000000] RAMDISK: [mem 0x33300000-0x35977fff]
[    0.000000] ACPI: Early table checksum verification disabled
[    0.000000] ACPI: RSDP 0x00000000000FE020 000024 (v02 INTEL )
[    0.000000] ACPI: XSDT 0x00000000DF7FD120 00006C (v01 INTEL  WBIBX10J 00000138      01000013)
[    0.000000] ACPI: FACP 0x00000000DF7FC000 0000F4 (v03 INTEL  WBIBX10J 00000138 MSFT 0100000D)
[    0.000000] ACPI BIOS Warning (bug): 32/64X length mismatch in FADT/Pm1aEventBlock: 32/16 (20150930/tbfadt-623)
[    0.000000] ACPI BIOS Warning (bug): 32/64X length mismatch in FADT/PmTimerBlock: 32/24 (20150930/tbfadt-623)
[    0.000000] ACPI BIOS Warning (bug): Invalid length for FADT/Pm1aEventBlock: 16, using default 32 (20150930/tbfadt-704)
[    0.000000] ACPI BIOS Warning (bug): Invalid length for FADT/PmTimerBlock: 24, using default 32 (20150930/tbfadt-704)
[    0.000000] ACPI: DSDT 0x00000000DF7F8000 003843 (v02 INTEL  WBIBX10J 00000138 MSFT 0100000D)
[    0.000000] ACPI: FACS 0x00000000DF76E000 000040
[    0.000000] ACPI: APIC 0x00000000DF7F7000 0000BC (v02 INTEL  WBIBX10J 00000138 MSFT 0100000D)
[    0.000000] ACPI: WDDT 0x00000000DF7F6000 000040 (v01 INTEL  WBIBX10J 00000138 MSFT 0100000D)
[    0.000000] ACPI: MCFG 0x00000000DF7F5000 00003C (v01 INTEL  WBIBX10J 00000138 MSFT 0100000D)
[    0.000000] ACPI: ASF! 0x00000000DF7F4000 0000A5 (v32 INTEL  WBIBX10J 00000138 MSFT 0100000D)
[    0.000000] ACPI: HPET 0x00000000DF7F3000 000038 (v01 INTEL  WBIBX10J 00000138 MSFT 0100000D)
[    0.000000] ACPI: ASPT 0x00000000DF7F1000 000034 (v05 INTEL  WBIBX10J 00000138 MSFT 0100000D)
[    0.000000] ACPI: WDTT 0x00000000DF7F0000 000224 (v02 INTEL  WBIBX10J 00000138 MSFT 0100000D)
[    0.000000] ACPI: SSDT 0x00000000DF7E8000 00759C (v01 INTEL  SSDT  PM 00000138 MSFT 0100000D)
[    0.000000] ACPI: Local APIC address 0xfee00000
[    0.000000] No NUMA configuration found
[    0.000000] Faking a node at [mem 0x0000000000000000-0x000000021fffffff]
[    0.000000] NODE_DATA(0) allocated [mem 0x21fff5000-0x21fff9fff]
[    0.000000] Zone ranges:
[    0.000000]   DMA      [mem 0x0000000000001000-0x0000000000ffffff]
[    0.000000]   DMA32    [mem 0x0000000001000000-0x00000000ffffffff]
[    0.000000]   Normal   [mem 0x0000000100000000-0x000000021fffffff]
[    0.000000]   Device   empty
[    0.000000] Movable zone start for each node
[    0.000000] Early memory node ranges
[    0.000000]   node   0: [mem 0x0000000000001000-0x000000000008efff]
[    0.000000]   node   0: [mem 0x0000000000100000-0x00000000df62cfff]
[    0.000000]   node   0: [mem 0x00000000df635000-0x00000000df66efff]
[    0.000000]   node   0: [mem 0x00000000df6bf000-0x00000000df6e5fff]
[    0.000000]   node   0: [mem 0x00000000df7bf000-0x00000000df7e6fff]
[    0.000000]   node   0: [mem 0x00000000df7f2000-0x00000000df7f2fff]
[    0.000000]   node   0: [mem 0x00000000df7ff000-0x00000000df7fffff]
[    0.000000]   node   0: [mem 0x0000000100000000-0x000000021fffffff]
[    0.000000] Initmem setup node 0 [mem 0x0000000000001000-0x000000021fffffff]
[    0.000000] On node 0 totalpages: 2094662
[    0.000000]   DMA zone: 64 pages used for memmap
[    0.000000]   DMA zone: 21 pages reserved
[    0.000000]   DMA zone: 3982 pages, LIFO batch:0
[    0.000000]   DMA32 zone: 14235 pages used for memmap
[    0.000000]   DMA32 zone: 911032 pages, LIFO batch:31
[    0.000000]   Normal zone: 18432 pages used for memmap
[    0.000000]   Normal zone: 1179648 pages, LIFO batch:31
[    0.000000] ACPI: PM-Timer IO Port: 0x408
[    0.000000] ACPI: LAPIC_NMI (acpi_id[0x00] high level lint[0x1])
[    0.000000] ACPI: LAPIC_NMI (acpi_id[0x01] high level lint[0x1])
[    0.000000] ACPI: LAPIC_NMI (acpi_id[0x02] high level lint[0x1])
[    0.000000] ACPI: LAPIC_NMI (acpi_id[0x03] high level lint[0x1])
[    0.000000] ACPI: LAPIC_NMI (acpi_id[0x04] high level lint[0x1])
[    0.000000] ACPI: LAPIC_NMI (acpi_id[0x05] high level lint[0x1])
[    0.000000] ACPI: LAPIC_NMI (acpi_id[0x06] high level lint[0x1])
[    0.000000] ACPI: LAPIC_NMI (acpi_id[0x07] high level lint[0x1])
[    0.000000] IOAPIC[0]: apic_id 8, version 32, address 0xfec00000, GSI 0-23
[    0.000000] ACPI: INT_SRC_OVR (bus 0 bus_irq 0 global_irq 2 dfl dfl)
[    0.000000] ACPI: INT_SRC_OVR (bus 0 bus_irq 9 global_irq 9 high level)
[    0.000000] ACPI: IRQ0 used by override.
[    0.000000] ACPI: IRQ9 used by override.
[    0.000000] Using ACPI (MADT) for SMP configuration information
[    0.000000] ACPI: HPET id: 0x8086a701 base: 0xfed00000
[    0.000000] smpboot: Allowing 8 CPUs, 0 hotplug CPUs
[    0.000000] PM: Registered nosave memory: [mem 0x00000000-0x00000fff]
[    0.000000] PM: Registered nosave memory: [mem 0x0008f000-0x0009ffff]
[    0.000000] PM: Registered nosave memory: [mem 0x000a0000-0x000dffff]
[    0.000000] PM: Registered nosave memory: [mem 0x000e0000-0x000fffff]
[    0.000000] PM: Registered nosave memory: [mem 0xdf62d000-0xdf634fff]
[    0.000000] PM: Registered nosave memory: [mem 0xdf66f000-0xdf6befff]
[    0.000000] PM: Registered nosave memory: [mem 0xdf6e6000-0xdf7befff]
[    0.000000] PM: Registered nosave memory: [mem 0xdf7e7000-0xdf7f1fff]
[    0.000000] PM: Registered nosave memory: [mem 0xdf7f3000-0xdf7fefff]
[    0.000000] PM: Registered nosave memory: [mem 0xdf800000-0xdfffffff]
[    0.000000] PM: Registered nosave memory: [mem 0xe0000000-0xf7ffffff]
[    0.000000] PM: Registered nosave memory: [mem 0xf8000000-0xffffffff]
[    0.000000] e820: [mem 0xe0000000-0xf7ffffff] available for PCI devices
[    0.000000] Booting paravirtualized kernel on bare hardware
[    0.000000] clocksource: refined-jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645519600211568 ns
[    0.000000] setup_percpu: NR_CPUS:512 nr_cpumask_bits:512 nr_cpu_ids:8 nr_node_ids:1
[    0.000000] PERCPU: Embedded 33 pages/cpu @ffff88021fc00000 s98264 r8192 d28712 u262144
[    0.000000] pcpu-alloc: s98264 r8192 d28712 u262144 alloc=1*2097152
[    0.000000] pcpu-alloc: [0] 0 1 2 3 4 5 6 7
[    0.000000] Built 1 zonelists in Node order, mobility grouping on.  Total pages: 2061910
[    0.000000] Policy zone: Normal
[    0.000000] Kernel command line: BOOT_IMAGE=/boot/vmlinuz-4.4.0-77-generic root=UUID=6907f491-8aa4-4f40-8209-104f92206e25 ro quiet splash vt.handoff=7
[    0.000000] PID hash table entries: 4096 (order: 3, 32768 bytes)
[    0.000000] Calgary: detecting Calgary via BIOS EBDA area
[    0.000000] Calgary: Unable to locate Rio Grande table in EBDA - bailing!
[    0.000000] Memory: 8122196K/8378648K available (8449K kernel code, 1294K rwdata, 3980K rodata, 1484K init, 1316K bss, 256452K reserved, 0K cma-reserved)
[    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=8, Nodes=1
[    0.000000] Hierarchical RCU implementation.
[    0.000000] 	Build-time adjustment of leaf fanout to 64.
[    0.000000] 	RCU restricting CPUs from NR_CPUS=512 to nr_cpu_ids=8.
[    0.000000] RCU: Adjusting geometry for rcu_fanout_leaf=64, nr_cpu_ids=8
[    0.000000] NR_IRQS:33024 nr_irqs:488 16
[    0.000000] vt handoff: transparent VT on vt#7
[    0.000000] Console: colour dummy device 80x25
[    0.000000] console [tty0] enabled
[    0.000000] clocksource: hpet: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 133484882848 ns
[    0.000000] hpet clockevent registered
[    0.000000] tsc: Fast TSC calibration using PIT
[    0.000000] tsc: Detected 2933.420 MHz processor
[    0.000027] Calibrating delay loop (skipped), value calculated using timer frequency.. 5866.84 BogoMIPS (lpj=11733680)
[    0.000030] pid_max: default: 32768 minimum: 301
[    0.000035] ACPI: Core revision 20150930
[    0.007537] ACPI: 2 ACPI AML tables successfully acquired and loaded
[    0.007555] Security Framework initialized
[    0.007557] Yama: becoming mindful.
[    0.007572] AppArmor: AppArmor initialized
[    0.008017] Dentry cache hash table entries: 1048576 (order: 11, 8388608 bytes)
[    0.009422] Inode-cache hash table entries: 524288 (order: 10, 4194304 bytes)
[    0.010056] Mount-cache hash table entries: 16384 (order: 5, 131072 bytes)
[    0.010064] Mountpoint-cache hash table entries: 16384 (order: 5, 131072 bytes)
[    0.010273] Initializing cgroup subsys io
[    0.010277] Initializing cgroup subsys memory
[    0.010283] Initializing cgroup subsys devices
[    0.010285] Initializing cgroup subsys freezer
[    0.010287] Initializing cgroup subsys net_cls
[    0.010289] Initializing cgroup subsys perf_event
[    0.010291] Initializing cgroup subsys net_prio
[    0.010294] Initializing cgroup subsys hugetlb
[    0.010296] Initializing cgroup subsys pids
[    0.010311] CPU: Physical Processor ID: 0
[    0.010312] CPU: Processor Core ID: 0
[    0.010316] mce: CPU supports 9 MCE banks
[    0.010324] CPU0: Thermal monitoring enabled (TM1)
[    0.010330] process: using mwait in idle threads
[    0.010333] Last level iTLB entries: 4KB 512, 2MB 7, 4MB 7
[    0.010334] Last level dTLB entries: 4KB 512, 2MB 32, 4MB 32, 1GB 0
[    0.010591] Freeing SMP alternatives memory: 32K (ffffffff820b8000 - ffffffff820c0000)
[    0.012330] ftrace: allocating 32117 entries in 126 pages
[    0.024735] smpboot: APIC(0) Converting physical 0 to logical package 0
[    0.024737] smpboot: Max logical packages: 2
[    0.025127] ..TIMER: vector=0x30 apic1=0 pin1=2 apic2=-1 pin2=-1
[    0.169443] smpboot: CPU0: Intel(R) Core(TM) i7 CPU         870  @ 2.93GHz (family: 0x6, model: 0x1e, stepping: 0x5)
[    0.169457] Performance Events: PEBS fmt1+, 16-deep LBR, Nehalem events, Intel PMU driver.
[    0.169471] core: CPU erratum AAJ80 worked around
[    0.169472] core: CPUID marked event: 'bus cycles' unavailable
[    0.169474] ... version:                3
[    0.169474] ... bit width:              48
[    0.169475] ... generic registers:      4
[    0.169476] ... value mask:             0000ffffffffffff
[    0.169477] ... max period:             000000007fffffff
[    0.169478] ... fixed-purpose events:   3
[    0.169478] ... event mask:             000000070000000f
[    0.170167] x86: Booting SMP configuration:
[    0.170168] .... node  #0, CPUs:      #1
[    0.172764] NMI watchdog: enabled on all CPUs, permanently consumes one hw-PMU counter.
[    0.172840]  #2
[    0.173334] microcode: CPU2 microcode updated early to revision 0x7, date = 2013-08-20
[    0.175471]  #3
[    0.177843]  #4
[    0.178307] microcode: CPU4 microcode updated early to revision 0x7, date = 2013-08-20
[    0.180439]  #5
[    0.182810]  #6
[    0.183272] microcode: CPU6 microcode updated early to revision 0x7, date = 2013-08-20
[    0.185407]  #7
[    0.187716] x86: Booted up 1 node, 8 CPUs
[    0.187719] smpboot: Total of 8 processors activated (46934.72 BogoMIPS)
[    0.193091] devtmpfs: initialized
[    0.196066] evm: security.selinux
[    0.196067] evm: security.SMACK64
[    0.196068] evm: security.SMACK64EXEC
[    0.196069] evm: security.SMACK64TRANSMUTE
[    0.196069] evm: security.SMACK64MMAP
[    0.196070] evm: security.ima
[    0.196071] evm: security.capability
[    0.196132] PM: Registering ACPI NVS region [mem 0xdf6e6000-0xdf7befff] (888832 bytes)
[    0.196216] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[    0.196230] futex hash table entries: 2048 (order: 5, 131072 bytes)
[    0.196315] pinctrl core: initialized pinctrl subsystem
[    0.196413] RTC time: 16:15:51, date: 05/16/17
[    0.196508] NET: Registered protocol family 16
[    0.205453] cpuidle: using governor ladder
[    0.217450] cpuidle: using governor menu
[    0.217455] PCCT header not found.
[    0.217560] ACPI FADT declares the system doesn't support PCIe ASPM, so disable it
[    0.217562] ACPI: bus type PCI registered
[    0.217563] acpiphp: ACPI Hot Plug PCI Controller Driver version: 0.5
[    0.217627] PCI: MMCONFIG for domain 0000 [bus 00-3f] at [mem 0xf8000000-0xfbffffff] (base 0xf8000000)
[    0.217629] PCI: MMCONFIG at [mem 0xf8000000-0xfbffffff] reserved in E820
[    0.217634] PCI: Using configuration type 1 for base access
[    0.217918] mtrr: your CPUs had inconsistent variable MTRR settings
[    0.217919] mtrr: probably your BIOS does not setup all CPUs.
[    0.217920] mtrr: corrected configuration.
[    0.229801] ACPI: Added _OSI(Module Device)
[    0.229802] ACPI: Added _OSI(Processor Device)
[    0.229804] ACPI: Added _OSI(3.0 _SCP Extensions)
[    0.229805] ACPI: Added _OSI(Processor Aggregator Device)
[    0.234898] ACPI: Interpreter enabled
[    0.234910] ACPI: (supports S0 S3 S4 S5)
[    0.234912] ACPI: Using IOAPIC for interrupt routing
[    0.234928] PCI: Using host bridge windows from ACPI; if necessary, use "pci=nocrs" and report a bug
[    0.238574] ACPI: PCI Root Bridge [PCI0] (domain 0000 [bus 00-3e])
[    0.238578] acpi PNP0A08:00: _OSC: OS supports [ExtendedConfig ASPM ClockPM Segments MSI]
[    0.238687] acpi PNP0A08:00: _OSC: platform does not support [PME]
[    0.238789] acpi PNP0A08:00: _OSC: OS now controls [PCIeHotplug AER PCIeCapability]
[    0.238791] acpi PNP0A08:00: FADT indicates ASPM is unsupported, using BIOS configuration
[    0.239019] PCI host bridge to bus 0000:00
[    0.239022] pci_bus 0000:00: root bus resource [io  0x0000-0x0cf7 window]
[    0.239023] pci_bus 0000:00: root bus resource [io  0x0d00-0xffff window]
[    0.239025] pci_bus 0000:00: root bus resource [mem 0x000a0000-0x000bffff window]
[    0.239026] pci_bus 0000:00: root bus resource [mem 0xe0000000-0xf7ffffff window]
[    0.239028] pci_bus 0000:00: root bus resource [bus 00-3e]
[    0.239036] pci 0000:00:00.0: [8086:d131] type 00 class 0x060000
[    0.239135] pci 0000:00:03.0: [8086:d138] type 01 class 0x060400
[    0.239180] pci 0000:00:03.0: PME# supported from D0 D3hot D3cold
[    0.239223] pci 0000:00:03.0: System wakeup disabled by ACPI
[    0.239257] pci 0000:00:08.0: [8086:d155] type 00 class 0x088000
[    0.239352] pci 0000:00:08.1: [8086:d156] type 00 class 0x088000
[    0.239443] pci 0000:00:08.2: [8086:d157] type 00 class 0x088000
[    0.239532] pci 0000:00:08.3: [8086:d158] type 00 class 0x088000
[    0.239617] pci 0000:00:10.0: [8086:d150] type 00 class 0x088000
[    0.239695] pci 0000:00:10.1: [8086:d151] type 00 class 0x088000
[    0.239788] pci 0000:00:19.0: [8086:10f0] type 00 class 0x020000
[    0.239811] pci 0000:00:19.0: reg 0x10: [mem 0xf3100000-0xf311ffff]
[    0.239819] pci 0000:00:19.0: reg 0x14: [mem 0xf3124000-0xf3124fff]
[    0.239826] pci 0000:00:19.0: reg 0x18: [io  0x2100-0x211f]
[    0.239870] pci 0000:00:19.0: PME# supported from D0 D3hot D3cold
[    0.239909] pci 0000:00:19.0: System wakeup disabled by ACPI
[    0.239945] pci 0000:00:1a.0: [8086:3b3b] type 00 class 0x0c0300
[    0.240015] pci 0000:00:1a.0: reg 0x20: [io  0x20e0-0x20ff]
[    0.240120] pci 0000:00:1a.0: System wakeup disabled by ACPI
[    0.240159] pci 0000:00:1a.1: [8086:3b3e] type 00 class 0x0c0300
[    0.240227] pci 0000:00:1a.1: reg 0x20: [io  0x20c0-0x20df]
[    0.240324] pci 0000:00:1a.1: System wakeup disabled by ACPI
[    0.240362] pci 0000:00:1a.2: [8086:3b3f] type 00 class 0x0c0300
[    0.240433] pci 0000:00:1a.2: reg 0x20: [io  0x20a0-0x20bf]
[    0.240526] pci 0000:00:1a.2: System wakeup disabled by ACPI
[    0.240566] pci 0000:00:1a.7: [8086:3b3c] type 00 class 0x0c0320
[    0.241396] pci 0000:00:1a.7: reg 0x10: [mem 0xf3125400-0xf31257ff]
[    0.245978] pci 0000:00:1a.7: PME# supported from D0 D3hot D3cold
[    0.246036] pci 0000:00:1a.7: System wakeup disabled by ACPI
[    0.246076] pci 0000:00:1b.0: [8086:3b56] type 00 class 0x040300
[    0.246100] pci 0000:00:1b.0: reg 0x10: [mem 0xf3120000-0xf3123fff 64bit]
[    0.246157] pci 0000:00:1b.0: PME# supported from D0 D3hot D3cold
[    0.246213] pci 0000:00:1b.0: System wakeup disabled by ACPI
[    0.246249] pci 0000:00:1c.0: [8086:3b42] type 01 class 0x060400
[    0.246305] pci 0000:00:1c.0: PME# supported from D0 D3hot D3cold
[    0.246347] pci 0000:00:1c.0: System wakeup disabled by ACPI
[    0.246391] pci 0000:00:1d.0: [8086:3b36] type 00 class 0x0c0300
[    0.246460] pci 0000:00:1d.0: reg 0x20: [io  0x2080-0x209f]
[    0.246561] pci 0000:00:1d.0: System wakeup disabled by ACPI
[    0.246599] pci 0000:00:1d.1: [8086:3b37] type 00 class 0x0c0300
[    0.246656] pci 0000:00:1d.1: reg 0x20: [io  0x2060-0x207f]
[    0.246742] pci 0000:00:1d.1: System wakeup disabled by ACPI
[    0.246779] pci 0000:00:1d.2: [8086:3b38] type 00 class 0x0c0300
[    0.246850] pci 0000:00:1d.2: reg 0x20: [io  0x2040-0x205f]
[    0.246946] pci 0000:00:1d.2: System wakeup disabled by ACPI
[    0.246983] pci 0000:00:1d.3: [8086:3b39] type 00 class 0x0c0300
[    0.247052] pci 0000:00:1d.3: reg 0x20: [io  0x2020-0x203f]
[    0.247146] pci 0000:00:1d.3: System wakeup disabled by ACPI
[    0.247185] pci 0000:00:1d.7: [8086:3b34] type 00 class 0x0c0320
[    0.248000] pci 0000:00:1d.7: reg 0x10: [mem 0xf3125000-0xf31253ff]
[    0.252723] pci 0000:00:1d.7: PME# supported from D0 D3hot D3cold
[    0.252783] pci 0000:00:1d.7: System wakeup disabled by ACPI
[    0.252817] pci 0000:00:1e.0: [8086:244e] type 01 class 0x060401
[    0.252894] pci 0000:00:1e.0: System wakeup disabled by ACPI
[    0.252929] pci 0000:00:1f.0: [8086:3b02] type 00 class 0x060100
[    0.253085] pci 0000:00:1f.2: [8086:3b20] type 00 class 0x01018f
[    0.253103] pci 0000:00:1f.2: reg 0x10: [io  0x2178-0x217f]
[    0.253110] pci 0000:00:1f.2: reg 0x14: [io  0x218c-0x218f]
[    0.253116] pci 0000:00:1f.2: reg 0x18: [io  0x2170-0x2177]
[    0.253123] pci 0000:00:1f.2: reg 0x1c: [io  0x2188-0x218b]
[    0.253130] pci 0000:00:1f.2: reg 0x20: [io  0x2150-0x215f]
[    0.253136] pci 0000:00:1f.2: reg 0x24: [io  0x2140-0x214f]
[    0.253218] pci 0000:00:1f.3: [8086:3b30] type 00 class 0x0c0500
[    0.253233] pci 0000:00:1f.3: reg 0x10: [mem 0xf3125800-0xf31258ff 64bit]
[    0.253251] pci 0000:00:1f.3: reg 0x20: [io  0x2000-0x201f]
[    0.253326] pci 0000:00:1f.5: [8086:3b26] type 00 class 0x010185
[    0.253344] pci 0000:00:1f.5: reg 0x10: [io  0x2168-0x216f]
[    0.253351] pci 0000:00:1f.5: reg 0x14: [io  0x2184-0x2187]
[    0.253357] pci 0000:00:1f.5: reg 0x18: [io  0x2160-0x2167]
[    0.253364] pci 0000:00:1f.5: reg 0x1c: [io  0x2180-0x2183]
[    0.253370] pci 0000:00:1f.5: reg 0x20: [io  0x2130-0x213f]
[    0.253377] pci 0000:00:1f.5: reg 0x24: [io  0x2120-0x212f]
[    0.253497] pci 0000:01:00.0: [10de:0640] type 00 class 0x030000
[    0.253516] pci 0000:01:00.0: reg 0x10: [mem 0xf2000000-0xf2ffffff]
[    0.253525] pci 0000:01:00.0: reg 0x14: [mem 0xe0000000-0xefffffff 64bit pref]
[    0.253534] pci 0000:01:00.0: reg 0x1c: [mem 0xf0000000-0xf1ffffff 64bit]
[    0.253540] pci 0000:01:00.0: reg 0x24: [io  0x1000-0x107f]
[    0.253547] pci 0000:01:00.0: reg 0x30: [mem 0xfff80000-0xffffffff pref]
[    0.261470] pci 0000:00:03.0: PCI bridge to [bus 01]
[    0.261476] pci 0000:00:03.0:   bridge window [io  0x1000-0x1fff]
[    0.261481] pci 0000:00:03.0:   bridge window [mem 0xf0000000-0xf2ffffff]
[    0.261488] pci 0000:00:03.0:   bridge window [mem 0xe0000000-0xefffffff 64bit pref]
[    0.261555] pci 0000:00:1c.0: PCI bridge to [bus 02]
[    0.261597] pci 0000:03:03.0: [104c:8023] type 00 class 0x0c0010
[    0.261618] pci 0000:03:03.0: reg 0x10: [mem 0xf3004000-0xf30047ff]
[    0.261627] pci 0000:03:03.0: reg 0x14: [mem 0xf3000000-0xf3003fff]
[    0.261690] pci 0000:03:03.0: supports D1 D2
[    0.261691] pci 0000:03:03.0: PME# supported from D0 D1 D2 D3hot
[    0.261759] pci 0000:00:1e.0: PCI bridge to [bus 03] (subtractive decode)
[    0.261763] pci 0000:00:1e.0:   bridge window [mem 0xf3000000-0xf30fffff]
[    0.261768] pci 0000:00:1e.0:   bridge window [io  0x0000-0x0cf7 window] (subtractive decode)
[    0.261770] pci 0000:00:1e.0:   bridge window [io  0x0d00-0xffff window] (subtractive decode)
[    0.261771] pci 0000:00:1e.0:   bridge window [mem 0x000a0000-0x000bffff window] (subtractive decode)
[    0.261773] pci 0000:00:1e.0:   bridge window [mem 0xe0000000-0xf7ffffff window] (subtractive decode)
[    0.261841] ACPI: PCI Interrupt Link [LNKA] (IRQs 3 4 5 7 9 10 *11 12)
[    0.261890] ACPI: PCI Interrupt Link [LNKB] (IRQs 3 4 5 7 9 10 11 12) *0, disabled.
[    0.261939] ACPI: PCI Interrupt Link [LNKC] (IRQs 3 4 5 7 *9 10 11 12)
[    0.261986] ACPI: PCI Interrupt Link [LNKD] (IRQs 3 4 5 7 *9 10 11 12)
[    0.262033] ACPI: PCI Interrupt Link [LNKE] (IRQs 3 4 5 7 9 *10 11 12)
[    0.262081] ACPI: PCI Interrupt Link [LNKF] (IRQs 3 4 5 7 9 10 *11 12)
[    0.262128] ACPI: PCI Interrupt Link [LNKG] (IRQs 3 4 5 7 9 *10 11 12)
[    0.262175] ACPI: PCI Interrupt Link [LNKH] (IRQs 3 4 5 7 9 10 *11 12)
[    0.262411] ACPI: Enabled 2 GPEs in block 00 to 3F
[    0.262510] vgaarb: setting as boot device: PCI:0000:01:00.0
[    0.262512] vgaarb: device added: PCI:0000:01:00.0,decodes=io+mem,owns=io+mem,locks=none
[    0.262513] vgaarb: loaded
[    0.262514] vgaarb: bridge control possible 0000:01:00.0
[    0.262697] SCSI subsystem initialized
[    0.262727] libata version 3.00 loaded.
[    0.262747] ACPI: bus type USB registered
[    0.262761] usbcore: registered new interface driver usbfs
[    0.262768] usbcore: registered new interface driver hub
[    0.262787] usbcore: registered new device driver usb
[    0.262900] PCI: Using ACPI for IRQ routing
[    0.264253] PCI: Discovered peer bus 3f
[    0.264254] PCI: root bus 3f: using default resources
[    0.264255] PCI: Probing PCI hardware (bus 3f)
[    0.264280] ACPI: \: failed to evaluate _DSM (0x1001)
[    0.264281] PCI host bridge to bus 0000:3f
[    0.264283] pci_bus 0000:3f: root bus resource [io  0x0000-0xffff]
[    0.264285] pci_bus 0000:3f: root bus resource [mem 0x00000000-0xfffffffff]
[    0.264286] pci_bus 0000:3f: No busn resource found for root bus, will use [bus 3f-ff]
[    0.264291] pci 0000:3f:00.0: [8086:2c51] type 00 class 0x060000
[    0.264329] pci 0000:3f:00.1: [8086:2c81] type 00 class 0x060000
[    0.264366] pci 0000:3f:02.0: [8086:2c90] type 00 class 0x060000
[    0.264401] pci 0000:3f:02.1: [8086:2c91] type 00 class 0x060000
[    0.264437] pci 0000:3f:03.0: [8086:2c98] type 00 class 0x060000
[    0.264471] pci 0000:3f:03.1: [8086:2c99] type 00 class 0x060000
[    0.264506] pci 0000:3f:03.4: [8086:2c9c] type 00 class 0x060000
[    0.264542] pci 0000:3f:04.0: [8086:2ca0] type 00 class 0x060000
[    0.264577] pci 0000:3f:04.1: [8086:2ca1] type 00 class 0x060000
[    0.264612] pci 0000:3f:04.2: [8086:2ca2] type 00 class 0x060000
[    0.264649] pci 0000:3f:04.3: [8086:2ca3] type 00 class 0x060000
[    0.264686] pci 0000:3f:05.0: [8086:2ca8] type 00 class 0x060000
[    0.264721] pci 0000:3f:05.1: [8086:2ca9] type 00 class 0x060000
[    0.264755] pci 0000:3f:05.2: [8086:2caa] type 00 class 0x060000
[    0.264790] pci 0000:3f:05.3: [8086:2cab] type 00 class 0x060000
[    0.264834] pci_bus 0000:3f: busn_res: [bus 3f-ff] end is updated to 3f
[    0.264838] PCI: pci_cache_line_size set to 64 bytes
[    0.264904] e820: reserve RAM buffer [mem 0x0008f000-0x0008ffff]
[    0.264906] e820: reserve RAM buffer [mem 0xdf62d000-0xdfffffff]
[    0.264907] e820: reserve RAM buffer [mem 0xdf66f000-0xdfffffff]
[    0.264909] e820: reserve RAM buffer [mem 0xdf6e6000-0xdfffffff]
[    0.264910] e820: reserve RAM buffer [mem 0xdf7e7000-0xdfffffff]
[    0.264911] e820: reserve RAM buffer [mem 0xdf7f3000-0xdfffffff]
[    0.264912] e820: reserve RAM buffer [mem 0xdf800000-0xdfffffff]
[    0.265008] NetLabel: Initializing
[    0.265009] NetLabel:  domain hash size = 128
[    0.265010] NetLabel:  protocols = UNLABELED CIPSOv4
[    0.265023] NetLabel:  unlabeled traffic allowed by default
[    0.265101] HPET: 8 timers in total, 5 timers will be used for per-cpu timer
[    0.265107] hpet0: at MMIO 0xfed00000, IRQs 2, 8, 24, 25, 26, 27, 28, 0
[    0.265112] hpet0: 8 comparators, 64-bit 14.318180 MHz counter
[    0.267145] hpet: hpet2 irq 24 for MSI
[    0.267177] hpet: hpet3 irq 25 for MSI
[    0.267205] hpet: hpet4 irq 26 for MSI
[    0.267237] hpet: hpet5 irq 27 for MSI
[    0.267274] hpet: hpet6 irq 28 for MSI
[    0.267359] amd_nb: Cannot enumerate AMD northbridges
[    0.267378] clocksource: Switched to clocksource hpet
[    0.272548] AppArmor: AppArmor Filesystem Enabled
[    0.272606] pnp: PnP ACPI init
[    0.272693] system 00:00: [mem 0xf8000000-0xffffffff] could not be reserved
[    0.272697] system 00:00: Plug and Play ACPI device, IDs PNP0c02 (active)
[    0.272808] pnp 00:01: Plug and Play ACPI device, IDs PNP0b00 (active)
[    0.272856] system 00:02: [io  0x0500-0x057f] has been reserved
[    0.272858] system 00:02: [io  0x0400-0x047f] could not be reserved
[    0.272860] system 00:02: [io  0x0680-0x06ff] has been reserved
[    0.272863] system 00:02: Plug and Play ACPI device, IDs PNP0c02 (active)
[    0.272924] system 00:03: Plug and Play ACPI device, IDs PNP0c02 (active)
[    0.272989] pnp: PnP ACPI: found 4 devices
[    0.279169] clocksource: acpi_pm: mask: 0xffffff max_cycles: 0xffffff, max_idle_ns: 2085701024 ns
[    0.279176] pci 0000:01:00.0: can't claim BAR 6 [mem 0xfff80000-0xffffffff pref]: no compatible bridge window
[    0.279190] pci 0000:00:1c.0: bridge window [io  0x1000-0x0fff] to [bus 02] add_size 1000
[    0.279193] pci 0000:00:1c.0: bridge window [mem 0x00100000-0x000fffff 64bit pref] to [bus 02] add_size 200000 add_align 100000
[    0.279196] pci 0000:00:1c.0: bridge window [mem 0x00100000-0x000fffff] to [bus 02] add_size 200000 add_align 100000
[    0.279206] pci 0000:00:1c.0: res[14]=[mem 0x00100000-0x000fffff] res_to_dev_res add_size 200000 min_align 100000
[    0.279208] pci 0000:00:1c.0: res[14]=[mem 0x00100000-0x002fffff] res_to_dev_res add_size 200000 min_align 100000
[    0.279209] pci 0000:00:1c.0: res[15]=[mem 0x00100000-0x000fffff 64bit pref] res_to_dev_res add_size 200000 min_align 100000
[    0.279211] pci 0000:00:1c.0: res[15]=[mem 0x00100000-0x002fffff 64bit pref] res_to_dev_res add_size 200000 min_align 100000
[    0.279213] pci 0000:00:1c.0: res[13]=[io  0x1000-0x0fff] res_to_dev_res add_size 1000 min_align 1000
[    0.279215] pci 0000:00:1c.0: res[13]=[io  0x1000-0x1fff] res_to_dev_res add_size 1000 min_align 1000
[    0.279218] pci 0000:00:1c.0: BAR 14: assigned [mem 0xf3200000-0xf33fffff]
[    0.279221] pci 0000:00:1c.0: BAR 15: assigned [mem 0xf3400000-0xf35fffff 64bit pref]
[    0.279224] pci 0000:00:1c.0: BAR 13: assigned [io  0x3000-0x3fff]
[    0.279227] pci 0000:01:00.0: BAR 6: no space for [mem size 0x00080000 pref]
[    0.279229] pci 0000:01:00.0: BAR 6: failed to assign [mem size 0x00080000 pref]
[    0.279231] pci 0000:00:03.0: PCI bridge to [bus 01]
[    0.279233] pci 0000:00:03.0:   bridge window [io  0x1000-0x1fff]
[    0.279236] pci 0000:00:03.0:   bridge window [mem 0xf0000000-0xf2ffffff]
[    0.279238] pci 0000:00:03.0:   bridge window [mem 0xe0000000-0xefffffff 64bit pref]
[    0.279242] pci 0000:00:1c.0: PCI bridge to [bus 02]
[    0.279244] pci 0000:00:1c.0:   bridge window [io  0x3000-0x3fff]
[    0.279248] pci 0000:00:1c.0:   bridge window [mem 0xf3200000-0xf33fffff]
[    0.279251] pci 0000:00:1c.0:   bridge window [mem 0xf3400000-0xf35fffff 64bit pref]
[    0.279256] pci 0000:00:1e.0: PCI bridge to [bus 03]
[    0.279260] pci 0000:00:1e.0:   bridge window [mem 0xf3000000-0xf30fffff]
[    0.279267] pci_bus 0000:00: resource 4 [io  0x0000-0x0cf7 window]
[    0.279268] pci_bus 0000:00: resource 5 [io  0x0d00-0xffff window]
[    0.279270] pci_bus 0000:00: resource 6 [mem 0x000a0000-0x000bffff window]
[    0.279271] pci_bus 0000:00: resource 7 [mem 0xe0000000-0xf7ffffff window]
[    0.279273] pci_bus 0000:01: resource 0 [io  0x1000-0x1fff]
[    0.279274] pci_bus 0000:01: resource 1 [mem 0xf0000000-0xf2ffffff]
[    0.279275] pci_bus 0000:01: resource 2 [mem 0xe0000000-0xefffffff 64bit pref]
[    0.279277] pci_bus 0000:02: resource 0 [io  0x3000-0x3fff]
[    0.279278] pci_bus 0000:02: resource 1 [mem 0xf3200000-0xf33fffff]
[    0.279280] pci_bus 0000:02: resource 2 [mem 0xf3400000-0xf35fffff 64bit pref]
[    0.279281] pci_bus 0000:03: resource 1 [mem 0xf3000000-0xf30fffff]
[    0.279283] pci_bus 0000:03: resource 4 [io  0x0000-0x0cf7 window]
[    0.279284] pci_bus 0000:03: resource 5 [io  0x0d00-0xffff window]
[    0.279286] pci_bus 0000:03: resource 6 [mem 0x000a0000-0x000bffff window]
[    0.279287] pci_bus 0000:03: resource 7 [mem 0xe0000000-0xf7ffffff window]
[    0.279290] pci_bus 0000:3f: resource 4 [io  0x0000-0xffff]
[    0.279291] pci_bus 0000:3f: resource 5 [mem 0x00000000-0xfffffffff]
[    0.279321] NET: Registered protocol family 2
[    0.279480] TCP established hash table entries: 65536 (order: 7, 524288 bytes)
[    0.279656] TCP bind hash table entries: 65536 (order: 8, 1048576 bytes)
[    0.279911] TCP: Hash tables configured (established 65536 bind 65536)
[    0.279937] UDP hash table entries: 4096 (order: 5, 131072 bytes)
[    0.279988] UDP-Lite hash table entries: 4096 (order: 5, 131072 bytes)
[    0.280069] NET: Registered protocol family 1
[    0.311643] pci 0000:01:00.0: Video device with shadowed ROM
[    0.311665] PCI: CLS 64 bytes, default 64
[    0.311705] Unpacking initramfs...
[    0.874385] Freeing initrd memory: 39392K (ffff880033300000 - ffff880035978000)
[    0.874406] PCI-DMA: Using software bounce buffering for IO (SWIOTLB)
[    0.874408] software IO TLB [mem 0xdb62d000-0xdf62d000] (64MB) mapped at [ffff8800db62d000-ffff8800df62cfff]
[    0.874590] Scanning for low memory corruption every 60 seconds
[    0.874991] audit: initializing netlink subsys (disabled)
[    0.875004] audit: type=2000 audit(1494951351.768:1): initialized
[    0.875320] Initialise system trusted keyring
[    0.875496] HugeTLB registered 2 MB page size, pre-allocated 0 pages
[    0.876797] zbud: loaded
[    0.876980] VFS: Disk quotas dquot_6.6.0
[    0.877011] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[    0.877245] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[    0.877485] fuse init (API version 7.23)
[    0.877610] Key type big_key registered
[    0.877625] Allocating IMA MOK and blacklist keyrings.
[    0.878276] Key type asymmetric registered
[    0.878279] Asymmetric key parser 'x509' registered
[    0.878312] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 249)
[    0.878354] io scheduler noop registered
[    0.878356] io scheduler deadline registered (default)
[    0.878383] io scheduler cfq registered
[    0.878725] pcieport 0000:00:1c.0: enabling device (0000 -> 0003)
[    0.878998] aer 0000:00:03.0:pcie02: service driver aer loaded
[    0.879010] pci_hotplug: PCI Hot Plug PCI Core version: 0.5
[    0.879023] pciehp 0000:00:1c.0:pcie04: Slot #0 AttnBtn- PwrCtrl- MRL- AttnInd- PwrInd- HotPlug+ Surprise+ Interlock- NoCompl+ LLActRep+
[    0.879077] pciehp 0000:00:1c.0:pcie04: service driver pciehp loaded
[    0.879081] pciehp: PCI Express Hot Plug Controller Driver version: 0.4
[    0.879109] vesafb: mode is 640x480x32, linelength=2560, pages=0
[    0.879110] vesafb: scrolling: redraw
[    0.879111] vesafb: Truecolor: size=8:8:8:8, shift=24:16:8:0
[    0.879121] vesafb: framebuffer at 0xf1000000, mapped to 0xffffc90001000000, using 1216k, total 1216k
[    0.879196] Console: switching to colour frame buffer device 80x30
[    0.879207] fb0: VESA VGA frame buffer device
[    0.879220] intel_idle: MWAIT substates: 0x1120
[    0.879232] intel_idle: v0.4.1 model 0x1E
[    0.879233] intel_idle: lapic_timer_reliable_states 0x2
[    0.879603] input: Sleep Button as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0E:00/input/input0
[    0.879606] ACPI: Sleep Button [SLPB]
[    0.879643] input: Power Button as /devices/LNXSYSTM:00/LNXPWRBN:00/input/input1
[    0.879644] ACPI: Power Button [PWRF]
[    0.880514] GHES: HEST is not enabled!
[    0.880600] Serial: 8250/16550 driver, 32 ports, IRQ sharing enabled
[    0.882191] Linux agpgart interface v0.103
[    0.885651] loop: module loaded
[    0.885777] ata_piix 0000:00:1f.2: version 2.13
[    0.885954] ata_piix 0000:00:1f.2: MAP [ P0 P2 P1 P3 ]
[    0.886505] scsi host0: ata_piix
[    0.886911] scsi host1: ata_piix
[    0.887013] ata1: SATA max UDMA/133 cmd 0x2178 ctl 0x218c bmdma 0x2150 irq 19
[    0.887024] ata2: SATA max UDMA/133 cmd 0x2170 ctl 0x2188 bmdma 0x2158 irq 19
[    0.887214] ata_piix 0000:00:1f.5: MAP [ P0 -- P1 -- ]
[    0.887596] scsi host2: ata_piix
[    0.888051] scsi host3: ata_piix
[    0.888140] ata3: SATA max UDMA/133 cmd 0x2168 ctl 0x2184 bmdma 0x2130 irq 19
[    0.888149] ata4: SATA max UDMA/133 cmd 0x2160 ctl 0x2180 bmdma 0x2138 irq 19
[    0.888245] libphy: Fixed MDIO Bus: probed
[    0.888247] tun: Universal TUN/TAP device driver, 1.6
[    0.888248] tun: (C) 1999-2004 Max Krasnyansky <maxk@qualcomm.com>
[    0.888294] PPP generic driver version 2.4.2
[    0.888430] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[    0.888439] ehci-pci: EHCI PCI platform driver
[    0.888633] ehci-pci 0000:00:1a.7: EHCI Host Controller
[    0.888639] ehci-pci 0000:00:1a.7: new USB bus registered, assigned bus number 1
[    0.888653] ehci-pci 0000:00:1a.7: debug port 2
[    0.892572] ehci-pci 0000:00:1a.7: cache line size of 64 is not supported
[    0.892586] ehci-pci 0000:00:1a.7: irq 16, io mem 0xf3125400
[    0.903636] ehci-pci 0000:00:1a.7: USB 2.0 started, EHCI 1.00
[    0.903737] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[    0.903739] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    0.903741] usb usb1: Product: EHCI Host Controller
[    0.903742] usb usb1: Manufacturer: Linux 4.4.0-77-generic ehci_hcd
[    0.903744] usb usb1: SerialNumber: 0000:00:1a.7
[    0.903915] hub 1-0:1.0: USB hub found
[    0.903932] hub 1-0:1.0: 6 ports detected
[    0.904279] ehci-pci 0000:00:1d.7: EHCI Host Controller
[    0.904284] ehci-pci 0000:00:1d.7: new USB bus registered, assigned bus number 2
[    0.904298] ehci-pci 0000:00:1d.7: debug port 2
[    0.908228] ehci-pci 0000:00:1d.7: cache line size of 64 is not supported
[    0.908239] ehci-pci 0000:00:1d.7: irq 23, io mem 0xf3125000
[    0.919655] ehci-pci 0000:00:1d.7: USB 2.0 started, EHCI 1.00
[    0.919713] usb usb2: New USB device found, idVendor=1d6b, idProduct=0002
[    0.919715] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    0.919716] usb usb2: Product: EHCI Host Controller
[    0.919718] usb usb2: Manufacturer: Linux 4.4.0-77-generic ehci_hcd
[    0.919719] usb usb2: SerialNumber: 0000:00:1d.7
[    0.919894] hub 2-0:1.0: USB hub found
[    0.919906] hub 2-0:1.0: 8 ports detected
[    0.920103] ehci-platform: EHCI generic platform driver
[    0.920112] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[    0.920116] ohci-pci: OHCI PCI platform driver
[    0.920126] ohci-platform: OHCI generic platform driver
[    0.920132] uhci_hcd: USB Universal Host Controller Interface driver
[    0.920321] uhci_hcd 0000:00:1a.0: UHCI Host Controller
[    0.920326] uhci_hcd 0000:00:1a.0: new USB bus registered, assigned bus number 3
[    0.920335] uhci_hcd 0000:00:1a.0: detected 2 ports
[    0.920366] uhci_hcd 0000:00:1a.0: irq 21, io base 0x000020e0
[    0.920404] usb usb3: New USB device found, idVendor=1d6b, idProduct=0001
[    0.920406] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    0.920407] usb usb3: Product: UHCI Host Controller
[    0.920409] usb usb3: Manufacturer: Linux 4.4.0-77-generic uhci_hcd
[    0.920410] usb usb3: SerialNumber: 0000:00:1a.0
[    0.920581] hub 3-0:1.0: USB hub found
[    0.920593] hub 3-0:1.0: 2 ports detected
[    0.920868] uhci_hcd 0000:00:1a.1: UHCI Host Controller
[    0.920873] uhci_hcd 0000:00:1a.1: new USB bus registered, assigned bus number 4
[    0.920882] uhci_hcd 0000:00:1a.1: detected 2 ports
[    0.920911] uhci_hcd 0000:00:1a.1: irq 18, io base 0x000020c0
[    0.920948] usb usb4: New USB device found, idVendor=1d6b, idProduct=0001
[    0.920950] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    0.920951] usb usb4: Product: UHCI Host Controller
[    0.920953] usb usb4: Manufacturer: Linux 4.4.0-77-generic uhci_hcd
[    0.920954] usb usb4: SerialNumber: 0000:00:1a.1
[    0.921130] hub 4-0:1.0: USB hub found
[    0.921141] hub 4-0:1.0: 2 ports detected
[    0.921397] uhci_hcd 0000:00:1a.2: UHCI Host Controller
[    0.921402] uhci_hcd 0000:00:1a.2: new USB bus registered, assigned bus number 5
[    0.921411] uhci_hcd 0000:00:1a.2: detected 2 ports
[    0.921436] uhci_hcd 0000:00:1a.2: irq 19, io base 0x000020a0
[    0.921474] usb usb5: New USB device found, idVendor=1d6b, idProduct=0001
[    0.921476] usb usb5: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    0.921477] usb usb5: Product: UHCI Host Controller
[    0.921478] usb usb5: Manufacturer: Linux 4.4.0-77-generic uhci_hcd
[    0.921480] usb usb5: SerialNumber: 0000:00:1a.2
[    0.921644] hub 5-0:1.0: USB hub found
[    0.921655] hub 5-0:1.0: 2 ports detected
[    0.921921] uhci_hcd 0000:00:1d.0: UHCI Host Controller
[    0.921926] uhci_hcd 0000:00:1d.0: new USB bus registered, assigned bus number 6
[    0.921936] uhci_hcd 0000:00:1d.0: detected 2 ports
[    0.921961] uhci_hcd 0000:00:1d.0: irq 19, io base 0x00002080
[    0.921997] usb usb6: New USB device found, idVendor=1d6b, idProduct=0001
[    0.921998] usb usb6: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    0.922000] usb usb6: Product: UHCI Host Controller
[    0.922001] usb usb6: Manufacturer: Linux 4.4.0-77-generic uhci_hcd
[    0.922002] usb usb6: SerialNumber: 0000:00:1d.0
[    0.922174] hub 6-0:1.0: USB hub found
[    0.922186] hub 6-0:1.0: 2 ports detected
[    0.922458] uhci_hcd 0000:00:1d.1: UHCI Host Controller
[    0.922463] uhci_hcd 0000:00:1d.1: new USB bus registered, assigned bus number 7
[    0.922472] uhci_hcd 0000:00:1d.1: detected 2 ports
[    0.922497] uhci_hcd 0000:00:1d.1: irq 16, io base 0x00002060
[    0.922534] usb usb7: New USB device found, idVendor=1d6b, idProduct=0001
[    0.922535] usb usb7: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    0.922537] usb usb7: Product: UHCI Host Controller
[    0.922538] usb usb7: Manufacturer: Linux 4.4.0-77-generic uhci_hcd
[    0.922539] usb usb7: SerialNumber: 0000:00:1d.1
[    0.922704] hub 7-0:1.0: USB hub found
[    0.922719] hub 7-0:1.0: 2 ports detected
[    0.922981] uhci_hcd 0000:00:1d.2: UHCI Host Controller
[    0.922985] uhci_hcd 0000:00:1d.2: new USB bus registered, assigned bus number 8
[    0.922995] uhci_hcd 0000:00:1d.2: detected 2 ports
[    0.923020] uhci_hcd 0000:00:1d.2: irq 18, io base 0x00002040
[    0.923056] usb usb8: New USB device found, idVendor=1d6b, idProduct=0001
[    0.923058] usb usb8: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    0.923059] usb usb8: Product: UHCI Host Controller
[    0.923061] usb usb8: Manufacturer: Linux 4.4.0-77-generic uhci_hcd
[    0.923062] usb usb8: SerialNumber: 0000:00:1d.2
[    0.923167] hub 8-0:1.0: USB hub found
[    0.923172] hub 8-0:1.0: 2 ports detected
[    0.923550] uhci_hcd 0000:00:1d.3: UHCI Host Controller
[    0.923555] uhci_hcd 0000:00:1d.3: new USB bus registered, assigned bus number 9
[    0.923564] uhci_hcd 0000:00:1d.3: detected 2 ports
[    0.923589] uhci_hcd 0000:00:1d.3: irq 23, io base 0x00002020
[    0.923626] usb usb9: New USB device found, idVendor=1d6b, idProduct=0001
[    0.923628] usb usb9: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    0.923629] usb usb9: Product: UHCI Host Controller
[    0.923630] usb usb9: Manufacturer: Linux 4.4.0-77-generic uhci_hcd
[    0.923632] usb usb9: SerialNumber: 0000:00:1d.3
[    0.923738] hub 9-0:1.0: USB hub found
[    0.923743] hub 9-0:1.0: 2 ports detected
[    0.923856] i8042: PNP: No PS/2 controller found. Probing ports directly.
[    1.222593] ata3: SATA link down (SStatus 0 SControl 300)
[    1.363549] ata4: SATA link up 3.0 Gbps (SStatus 123 SControl 300)
[    1.371974] ata4.00: ATA-8: ST2000DM001-9YN164, CC4C, max UDMA/133
[    1.371976] ata4.00: 3907029168 sectors, multi 16: LBA48 NCQ (depth 0/32)
[    1.387977] ata4.00: configured for UDMA/133
[    1.679653] ata2.00: SATA link up 1.5 Gbps (SStatus 113 SControl 300)
[    1.679670] ata2.01: SATA link down (SStatus 0 SControl 300)
[    1.679684] ata2.01: link offline, clearing class 3 to NONE
[    1.683535] usb 2-3: new high-speed USB device number 2 using ehci-pci
[    1.687724] ata2.00: ATAPI: ATAPI   iHAS124   B, AL08, max UDMA/100
[    1.703726] ata2.00: configured for UDMA/100
[    1.811510] usb 3-2: new low-speed USB device number 2 using uhci_hcd
[    1.818333] usb 2-3: New USB device found, idVendor=058f, idProduct=6364
[    1.818335] usb 2-3: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[    1.818337] usb 2-3: Product: Mass Storage Device
[    1.818338] usb 2-3: Manufacturer: Generic
[    1.818340] usb 2-3: SerialNumber: 058F63646476
[    1.871472] tsc: Refined TSC clocksource calibration: 2933.437 MHz
[    1.871475] clocksource: tsc: mask: 0xffffffffffffffff max_cycles: 0x2a48a5e2a02, max_idle_ns: 440795253616 ns
[    2.014930] i8042: No controller found
[    2.015118] mousedev: PS/2 mouse device common for all mice
[    2.015304] rtc_cmos 00:01: RTC can wake from S4
[    2.015446] rtc_cmos 00:01: rtc core: registered rtc_cmos as rtc0
[    2.015476] rtc_cmos 00:01: alarms up to one month, y3k, 114 bytes nvram, hpet irqs
[    2.015483] i2c /dev entries driver
[    2.015525] device-mapper: uevent: version 1.0.3
[    2.015599] device-mapper: ioctl: 4.34.0-ioctl (2015-10-28) initialised: dm-devel@redhat.com
[    2.015617] ledtrig-cpu: registered to indicate activity on CPUs
[    2.016373] NET: Registered protocol family 10
[    2.016685] NET: Registered protocol family 17
[    2.016696] Key type dns_resolver registered
[    2.017107] microcode: CPU0 sig=0x106e5, pf=0x2, revision=0x7
[    2.017123] microcode: CPU1 sig=0x106e5, pf=0x2, revision=0x7
[    2.017183] microcode: CPU2 sig=0x106e5, pf=0x2, revision=0x7
[    2.017199] microcode: CPU3 sig=0x106e5, pf=0x2, revision=0x7
[    2.017209] microcode: CPU4 sig=0x106e5, pf=0x2, revision=0x7
[    2.017220] microcode: CPU5 sig=0x106e5, pf=0x2, revision=0x7
[    2.017223] microcode: CPU6 sig=0x106e5, pf=0x2, revision=0x7
[    2.017232] microcode: CPU7 sig=0x106e5, pf=0x2, revision=0x7
[    2.017367] microcode: Microcode Update Driver: v2.01 <tigran@aivazian.fsnet.co.uk>, Peter Oruba
[    2.017917] registered taskstats version 1
[    2.017944] Loading compiled-in X.509 certificates
[    2.018811] Loaded X.509 cert 'Build time autogenerated kernel key: 60562572960efd370424d983abb028749c4780ed'
[    2.018831] zswap: loaded using pool lzo/zbud
[    2.021531] Key type trusted registered
[    2.025253] Key type encrypted registered
[    2.025259] AppArmor: AppArmor sha1 policy hashing enabled
[    2.025261] ima: No TPM chip found, activating TPM-bypass!
[    2.025281] evm: HMAC attrs: 0x1
[    2.025794]   Magic number: 1:612:287
[    2.025831] tty tty20: hash matches
[    2.025982] rtc_cmos 00:01: setting system clock to 2017-05-16 16:15:53 UTC (1494951353)
[    2.027205] BIOS EDD facility v0.16 2004-Jun-25, 0 devices found
[    2.027206] EDD information not available.
[    2.027249] PM: Hibernation image not present or could not be loaded.
[    2.059776] ata1.00: SATA link up 3.0 Gbps (SStatus 123 SControl 300)
[    2.059791] ata1.01: SATA link down (SStatus 0 SControl 300)
[    2.068261] ata1.00: ATA-8: WDC WD6400AAKS-00E4A0, 05.01D05, max UDMA/133
[    2.068267] ata1.00: 1250263728 sectors, multi 16: LBA48 NCQ (depth 0/32)
[    2.076128] ata1.00: configured for UDMA/133
[    2.076770] scsi 0:0:0:0: Direct-Access     ATA      WDC WD6400AAKS-0 1D05 PQ: 0 ANSI: 5
[    2.077642] sd 0:0:0:0: Attached scsi generic sg0 type 0
[    2.077704] sd 0:0:0:0: [sda] 1250263728 512-byte logical blocks: (640 GB/596 GiB)
[    2.078045] sd 0:0:0:0: [sda] Write Protect is off
[    2.078048] sd 0:0:0:0: [sda] Mode Sense: 00 3a 00 00
[    2.078295] sd 0:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[    2.081434] scsi 1:0:0:0: CD-ROM            ATAPI    iHAS124   B      AL08 PQ: 0 ANSI: 5
[    2.100904] sr 1:0:0:0: [sr0] scsi3-mmc drive: 48x/48x writer dvd-ram cd/rw xa/form2 cdda tray
[    2.100909] cdrom: Uniform CD-ROM driver Revision: 3.20
[    2.101287] sr 1:0:0:0: Attached scsi CD-ROM sr0
[    2.101533] sr 1:0:0:0: Attached scsi generic sg1 type 5
[    2.102251] scsi 3:0:0:0: Direct-Access     ATA      ST2000DM001-9YN1 CC4C PQ: 0 ANSI: 5
[    2.102982] sd 3:0:0:0: Attached scsi generic sg2 type 0
[    2.103064] sd 3:0:0:0: [sdb] 3907029168 512-byte logical blocks: (2.00 TB/1.82 TiB)
[    2.103068] sd 3:0:0:0: [sdb] 4096-byte physical blocks
[    2.103691] sd 3:0:0:0: [sdb] Write Protect is off
[    2.103699] sd 3:0:0:0: [sdb] Mode Sense: 00 3a 00 00
[    2.103899] sd 3:0:0:0: [sdb] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[    2.108224]  sda: sda1 sda2 sda3 sda4 < sda5 sda6 >
[    2.110422] sd 0:0:0:0: [sda] Attached SCSI disk
[    2.125791]  sdb: sdb1
[    2.126167] sd 3:0:0:0: [sdb] Attached SCSI disk
[    2.127540] Freeing unused kernel memory: 1484K (ffffffff81f45000 - ffffffff820b8000)
[    2.127542] Write protecting the kernel read-only data: 14336k
[    2.128282] Freeing unused kernel memory: 1780K (ffff880001843000 - ffff880001a00000)
[    2.128719] Freeing unused kernel memory: 116K (ffff880001de3000 - ffff880001e00000)
[    2.142953] random: systemd-udevd: uninitialized urandom read (16 bytes read, 39 bits of entropy available)
[    2.143008] random: systemd-udevd: uninitialized urandom read (16 bytes read, 39 bits of entropy available)
[    2.143019] random: systemd-udevd: uninitialized urandom read (16 bytes read, 39 bits of entropy available)
[    2.143030] random: systemd-udevd: uninitialized urandom read (16 bytes read, 39 bits of entropy available)
[    2.143568] random: udevadm: uninitialized urandom read (16 bytes read, 39 bits of entropy available)
[    2.143607] random: udevadm: uninitialized urandom read (16 bytes read, 39 bits of entropy available)
[    2.143953] random: udevadm: uninitialized urandom read (16 bytes read, 39 bits of entropy available)
[    2.143998] random: udevadm: uninitialized urandom read (16 bytes read, 39 bits of entropy available)
[    2.144041] random: udevadm: uninitialized urandom read (16 bytes read, 39 bits of entropy available)
[    2.144081] random: udevadm: uninitialized urandom read (16 bytes read, 39 bits of entropy available)
[    2.166637] FUJITSU Extended Socket Network Device Driver - version 1.0 - Copyright (c) 2015 FUJITSU LIMITED
[    2.173235] pps_core: LinuxPPS API ver. 1 registered
[    2.173237] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[    2.174713] PTP clock support registered
[    2.177576] hidraw: raw HID events driver (C) Jiri Kosina
[    2.178627] usb-storage 2-3:1.0: USB Mass Storage device detected
[    2.179112] scsi host4: usb-storage 2-3:1.0
[    2.179193] usbcore: registered new interface driver usb-storage
[    2.180737] usbcore: registered new interface driver usbhid
[    2.180739] usbhid: USB HID core driver
[    2.180754] e1000e: Intel(R) PRO/1000 Network Driver - 3.2.6-k
[    2.180756] e1000e: Copyright(c) 1999 - 2015 Intel Corporation.
[    2.180976] usbcore: registered new interface driver uas
[    2.181041] e1000e 0000:00:19.0: Interrupt Throttling Rate (ints/sec) set to dynamic conservative mode
[    2.207146] hid-generic 0003:058F:6364.0001: hiddev0,hidraw0: USB HID v1.10 Device [Generic Mass Storage Device] on usb-0000:00:1d.7-3/input1
[    2.235526] firewire_ohci 0000:03:03.0: added OHCI v1.10 device as card 0, 4 IR + 8 IT contexts, quirks 0x2
[    2.260627] usb 3-2: New USB device found, idVendor=04d9, idProduct=1603
[    2.260633] usb 3-2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[    2.260637] usb 3-2: Product: USB Keyboard
[    2.260641] usb 3-2: Manufacturer:
[    2.311795] input:   USB Keyboard as /devices/pci0000:00/0000:00:1a.0/usb3/3-2/3-2:1.0/0003:04D9:1603.0002/input/input2
[    2.367890] hid-generic 0003:04D9:1603.0002: input,hidraw1: USB HID v1.10 Keyboard [  USB Keyboard] on usb-0000:00:1a.0-2/input0
[    2.440187] e1000e 0000:00:19.0 eth0: (PCI Express:2.5GT/s:Width x1) 00:27:0e:26:50:b0
[    2.440190] e1000e 0000:00:19.0 eth0: Intel(R) PRO/1000 Network Connection
[    2.440302] e1000e 0000:00:19.0 eth0: MAC: 9, PHY: 9, PBA No: FFFFFF-0FF
[    2.440979] e1000e 0000:00:19.0 enp0s25: renamed from eth0
[    2.453721] input:   USB Keyboard as /devices/pci0000:00/0000:00:1a.0/usb3/3-2/3-2:1.1/0003:04D9:1603.0003/input/input3
[    2.508070] hid-generic 0003:04D9:1603.0003: input,hidraw2: USB HID v1.10 Device [  USB Keyboard] on usb-0000:00:1a.0-2/input1
[    2.535613] usb 4-2: new low-speed USB device number 2 using uhci_hcd
[    2.710668] usb 4-2: New USB device found, idVendor=093a, idProduct=2510
[    2.710674] usb 4-2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[    2.710678] usb 4-2: Product: USB Optical Mouse
[    2.710681] usb 4-2: Manufacturer: PixArt
[    2.724865] input: PixArt USB Optical Mouse as /devices/pci0000:00/0000:00:1a.1/usb4/4-2/4-2:1.0/0003:093A:2510.0004/input/input4
[    2.725658] hid-generic 0003:093A:2510.0004: input,hidraw3: USB HID v1.11 Mouse [PixArt USB Optical Mouse] on usb-0000:00:1a.1-2/input0
[    2.735799] firewire_core 0000:03:03.0: created device fw0: GUID 009027000269b083, S400
[    2.872014] clocksource: Switched to clocksource tsc
[    3.177287] scsi 4:0:0:0: Direct-Access     Generic- SD/MMC           1.00 PQ: 0 ANSI: 0
[    3.178355] scsi 4:0:0:1: Direct-Access     Generic- Compact Flash    1.01 PQ: 0 ANSI: 0
[    3.179433] scsi 4:0:0:2: Direct-Access     Generic- SM/xD-Picture    1.02 PQ: 0 ANSI: 0
[    3.180202] scsi 4:0:0:3: Direct-Access     Generic- MS/MS-Pro        1.03 PQ: 0 ANSI: 0 CCS
[    3.180716] sd 4:0:0:0: Attached scsi generic sg3 type 0
[    3.180840] sd 4:0:0:1: Attached scsi generic sg4 type 0
[    3.180952] sd 4:0:0:2: Attached scsi generic sg5 type 0
[    3.181580] sd 4:0:0:3: Attached scsi generic sg6 type 0
[    3.464736] sd 4:0:0:1: [sdd] Attached SCSI removable disk
[    3.466426] sd 4:0:0:2: [sde] Attached SCSI removable disk
[    3.466980] sd 4:0:0:3: [sdf] Attached SCSI removable disk
[    3.467971] sd 4:0:0:0: [sdc] Attached SCSI removable disk
[    4.366782] random: nonblocking pool is initialized
[    4.515474] raid6: sse2x1   gen()  7899 MB/s
[    4.583468] raid6: sse2x1   xor()  6166 MB/s
[    4.651468] raid6: sse2x2   gen()  9346 MB/s
[    4.719471] raid6: sse2x2   xor()  7186 MB/s
[    4.787472] raid6: sse2x4   gen() 10616 MB/s
[    4.855411] raid6: sse2x4   xor()  7910 MB/s
[    4.855412] raid6: using algorithm sse2x4 gen() 10616 MB/s
[    4.855413] raid6: .... xor() 7910 MB/s, rmw enabled
[    4.855414] raid6: using ssse3x2 recovery algorithm
[    4.856649] xor: measuring software checksum speed
[    4.895565]    prefetch64-sse: 14882.000 MB/sec
[    4.935564]    generic_sse: 13045.000 MB/sec
[    4.935566] xor: using function: prefetch64-sse (14882.000 MB/sec)
[    4.947232] Btrfs loaded
[    5.156906] EXT4-fs (sda3): mounted filesystem with ordered data mode. Opts: (null)
[    5.953495] systemd[1]: systemd 229 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ -LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD -IDN)
[    5.953637] systemd[1]: Detected architecture x86-64.
[    5.961281] systemd[1]: Set hostname to <labgeo1-desktop>.
[    7.439192] systemd[1]: Reached target Encrypted Volumes.
[    7.439261] systemd[1]: Listening on Journal Socket (/dev/log).
[    7.439269] systemd[1]: Reached target User and Group Name Lookups.
[    7.439613] systemd[1]: Created slice User and Session Slice.
[    7.439645] systemd[1]: Listening on Journal Socket.
[    7.439735] systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point.
[    7.439761] systemd[1]: Listening on LVM2 poll daemon socket.
[    7.439777] systemd[1]: Listening on udev Kernel Socket.
[    7.439824] systemd[1]: Listening on Journal Audit Socket.
[    7.439854] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[    7.439875] systemd[1]: Listening on fsck to fsckd communication Socket.
[    7.439896] systemd[1]: Listening on /dev/initctl Compatibility Named Pipe.
[    7.439914] systemd[1]: Listening on Syslog Socket.
[    7.439937] systemd[1]: Listening on udev Control Socket.
[    7.440113] systemd[1]: Created slice System Slice.
[    7.451676] systemd[1]: Mounting Debug File System...
[    7.452147] systemd[1]: Starting Set console keymap...
[    7.452623] systemd[1]: Starting Uncomplicated firewall...
[    7.453112] systemd[1]: Started Read required files in advance.
[    7.453884] systemd[1]: Starting Create list of required static device nodes for the current kernel...
[    7.454308] systemd[1]: Mounting Huge Pages File System...
[    7.454514] systemd[1]: Created slice system-systemd\x2dfsck.slice.
[    7.575665] systemd[1]: Starting Load Kernel Modules...
[    7.576153] systemd[1]: Starting Journal Service...
[    7.576630] systemd[1]: Started Braille Device Support.
[    7.576752] systemd[1]: Listening on Device-mapper event daemon FIFOs.
[    7.752750] systemd[1]: Listening on LVM2 metadata daemon socket.
[    7.767708] systemd[1]: Starting Monitoring of LVM2 mirrors, snapshots etc. using dmeventd or progress polling...
[    7.768222] systemd[1]: Mounting POSIX Message Queue File System...
[    7.768238] systemd[1]: Reached target Slices.
[    7.768272] systemd[1]: Reached target Remote File Systems (Pre).
[    7.768283] systemd[1]: Reached target Remote File Systems.
[    7.769698] systemd[1]: Started Uncomplicated firewall.
[    7.770069] systemd[1]: Started Create list of required static device nodes for the current kernel.
[    7.785561] systemd[1]: Starting Create Static Device Nodes in /dev...
[    8.036505] systemd[1]: Mounted POSIX Message Queue File System.
[    8.036595] systemd[1]: Mounted Debug File System.
[    8.036654] systemd[1]: Mounted Huge Pages File System.
[    8.234894] systemd[1]: Started Journal Service.
[    8.276597] lp: driver loaded but no devices found
[    8.308531] ppdev: user-space parallel port driver
[   10.346818] EXT4-fs (sda3): re-mounted. Opts: errors=remount-ro
[   10.538757] systemd-journald[373]: Received request to flush runtime journal from PID 1
[   10.867726] ACPI Warning: SystemIO range 0x0000000000000500-0x000000000000052F conflicts with OpRegion 0x0000000000000518-0x000000000000051B (\GPBL) (20150930/utaddress-254)
[   10.867731] ACPI Warning: SystemIO range 0x0000000000000500-0x000000000000052F conflicts with OpRegion 0x000000000000050C-0x000000000000050F (\GPLV) (20150930/utaddress-254)
[   10.867733] ACPI Warning: SystemIO range 0x0000000000000500-0x000000000000052F conflicts with OpRegion 0x0000000000000504-0x0000000000000507 (\GPIS) (20150930/utaddress-254)
[   10.867736] ACPI Warning: SystemIO range 0x0000000000000500-0x000000000000052F conflicts with OpRegion 0x0000000000000500-0x0000000000000503 (\GPUS) (20150930/utaddress-254)
[   10.867738] ACPI: If an ACPI driver is available for this device, you should use it instead of the native driver
[   10.906088] EDAC MC: Ver: 3.0.0
[   10.931329] EDAC MC0: Giving out device to module i7core_edac.c controller i7 core #0: DEV 0000:3f:03.0 (POLLED)
[   10.931363] EDAC PCI0: Giving out device to module i7core_edac controller EDAC PCI controller: DEV 0000:3f:03.0 (POLLED)
[   10.931442] EDAC i7core: Driver loaded, 1 memory controller(s) found.
[   10.988974] shpchp: Standard Hot Plug PCI Controller Driver version: 0.4
[   11.455163] kvm: disabled by bios
[   11.492341] kvm: disabled by bios
[   11.554019] gpio_ich: GPIO from 436 to 511 on gpio_ich
[   12.121781] snd_hda_codec_realtek hdaudioC0D2: ALC888: SKU not ready 0x411111f0
[   12.122236] snd_hda_codec_realtek hdaudioC0D2: autoconfig for ALC888: line_outs=1 (0x14/0x0/0x0/0x0/0x0) type:line
[   12.122238] snd_hda_codec_realtek hdaudioC0D2:    speaker_outs=0 (0x0/0x0/0x0/0x0/0x0)
[   12.122239] snd_hda_codec_realtek hdaudioC0D2:    hp_outs=1 (0x15/0x0/0x0/0x0/0x0)
[   12.122240] snd_hda_codec_realtek hdaudioC0D2:    mono: mono_out=0x0
[   12.122242] snd_hda_codec_realtek hdaudioC0D2:    dig-out=0x1e/0x0
[   12.122243] snd_hda_codec_realtek hdaudioC0D2:    inputs:
[   12.122245] snd_hda_codec_realtek hdaudioC0D2:      Front Mic=0x18
[   12.122246] snd_hda_codec_realtek hdaudioC0D2:      Rear Mic=0x1b
[   12.122247] snd_hda_codec_realtek hdaudioC0D2:      Line=0x1a
[   12.136368] input: HDA Intel MID Rear Mic as /devices/pci0000:00/0000:00:1b.0/sound/card0/input5
[   12.136414] input: HDA Intel MID Line as /devices/pci0000:00/0000:00:1b.0/sound/card0/input6
[   12.136463] input: HDA Intel MID Line Out as /devices/pci0000:00/0000:00:1b.0/sound/card0/input7
[   12.184180] [drm] Initialized drm 1.1.0 20060810
[   12.399406] wmi: Mapper loaded
[   13.234562] checking generic (f1000000 130000) vs hw (e0000000 10000000)
[   13.234565] checking generic (f1000000 130000) vs hw (f0000000 2000000)
[   13.234567] fb: switching to nouveaufb from VESA VGA
[   13.234653] Console: switching to colour dummy device 80x25
[   13.234826] nouveau 0000:01:00.0: NVIDIA G96 (096000c1)
[   13.266242] Adding 3905532k swap on /dev/sda5.  Priority:-1 extents:1 across:3905532k FS
[   13.354841] nouveau 0000:01:00.0: bios: version 62.94.29.00.00
[   13.375618] nouveau 0000:01:00.0: bios: M0203T not found
[   13.375620] nouveau 0000:01:00.0: bios: M0203E not matched!
[   13.375622] nouveau 0000:01:00.0: fb: 512 MiB DDR2
[   13.427264] [TTM] Zone  kernel: Available graphics memory: 4082500 kiB
[   13.427266] [TTM] Zone   dma32: Available graphics memory: 2097152 kiB
[   13.427267] [TTM] Initializing pool allocator
[   13.427271] [TTM] Initializing DMA pool allocator
[   13.427278] nouveau 0000:01:00.0: DRM: VRAM: 512 MiB
[   13.427280] nouveau 0000:01:00.0: DRM: GART: 1048576 MiB
[   13.427282] nouveau 0000:01:00.0: DRM: TMDS table version 2.0
[   13.427284] nouveau 0000:01:00.0: DRM: DCB version 4.0
[   13.427285] nouveau 0000:01:00.0: DRM: DCB outp 00: 02000300 00000028
[   13.427287] nouveau 0000:01:00.0: DRM: DCB outp 01: 01000302 00020030
[   13.427288] nouveau 0000:01:00.0: DRM: DCB outp 02: 04011310 00000028
[   13.427290] nouveau 0000:01:00.0: DRM: DCB outp 03: 02011312 00020030
[   13.427291] nouveau 0000:01:00.0: DRM: DCB outp 04: 010223f1 00c0c080
[   13.427293] nouveau 0000:01:00.0: DRM: DCB conn 00: 00001030
[   13.427294] nouveau 0000:01:00.0: DRM: DCB conn 01: 00002130
[   13.427295] nouveau 0000:01:00.0: DRM: DCB conn 02: 00000210
[   13.427296] nouveau 0000:01:00.0: DRM: DCB conn 03: 00000211
[   13.427297] nouveau 0000:01:00.0: DRM: DCB conn 04: 00000213
[   13.444932] nouveau 0000:01:00.0: DRM: failed to create encoder 0/1/0: -19
[   13.444934] nouveau 0000:01:00.0: DRM: TV-1 has no encoders, removing
[   13.444955] [drm] Supports vblank timestamp caching Rev 2 (21.10.2013).
[   13.444956] [drm] Driver supports precise vblank timestamp query.
[   13.722799] nouveau 0000:01:00.0: DRM: MM: using CRYPT for buffer copies
[   13.782996] [drm:drm_edid_block_valid [drm]] *ERROR* EDID checksum is invalid, remainder is 117
[   13.782998] Raw EDID:
[   13.782999]  	00 ff ff ff ff ff ff 00 5a 63 1c 13 01 01 01 01
[   13.783000]  	05 10 01 03 0e 29 1f 78 2e 30 85 a6 56 4a 99 24
[   13.783001]  	14 50 54 bf ef 80 a9 40 90 4f 90 40 81 80 81 40
[   13.783002]  	71 4f 01 01 01 01 48 3f 40 30 62 b0 32 40 40 c0
[   13.783002]  	13 00 98 32 11 00 00 1e 00 00 00 ff 00 50 53 42
[   13.783003]  	30 36 30 35 30 30 30 39 30 0a 00 00 00 fd 00 32
[   13.783004]  	4b 1e 5c 11 00 0a 20 20 20 20 20 20 00 00 00 fc
[   13.783005]  	00 00 00 00 00 00 00 00 53 45 52 49 45 53 00 eb
[   13.810072] [drm:drm_edid_block_valid [drm]] *ERROR* EDID checksum is invalid, remainder is 117
[   13.810074] Raw EDID:
[   13.810075]  	00 ff ff ff ff ff ff 00 5a 63 1c 13 01 01 01 01
[   13.810076]  	05 10 01 03 0e 29 1f 78 2e 30 85 a6 56 4a 99 24
[   13.810076]  	14 50 54 bf ef 80 a9 40 90 4f 90 40 81 80 81 40
[   13.810077]  	71 4f 01 01 01 01 48 3f 40 30 62 b0 32 40 40 c0
[   13.810078]  	13 00 98 32 11 00 00 1e 00 00 00 ff 00 50 53 42
[   13.810078]  	30 36 30 35 30 30 30 39 30 0a 00 00 00 fd 00 32
[   13.810079]  	4b 1e 5c 11 00 0a 20 20 20 20 20 20 00 00 00 fc
[   13.810080]  	00 00 00 00 00 00 00 00 53 45 52 49 45 53 00 eb
[   13.837345] [drm:drm_edid_block_valid [drm]] *ERROR* EDID checksum is invalid, remainder is 117
[   13.837346] Raw EDID:
continue…
[   13.837347]  	00 ff ff ff ff ff ff 00 5a 63 1c 13 01 01 01 01
[   13.837348]  	05 10 01 03 0e 29 1f 78 2e 30 85 a6 56 4a 99 24
[   13.837348]  	14 50 54 bf ef 80 a9 40 90 4f 90 40 81 80 81 40
[   13.837349]  	71 4f 01 01 01 01 48 3f 40 30 62 b0 32 40 40 c0
[   13.837350]  	13 00 98 32 11 00 00 1e 00 00 00 ff 00 50 53 42
[   13.837351]  	30 36 30 35 30 30 30 39 30 0a 00 00 00 fd 00 32
[   13.837351]  	4b 1e 5c 11 00 0a 20 20 20 20 20 20 00 00 00 fc
[   13.837352]  	00 00 00 00 00 00 00 00 53 45 52 49 45 53 00 eb
[   13.864497] [drm:drm_edid_block_valid [drm]] *ERROR* EDID checksum is invalid, remainder is 117
[   13.864498] Raw EDID:
[   13.864499]  	00 ff ff ff ff ff ff 00 5a 63 1c 13 01 01 01 01
[   13.864500]  	05 10 01 03 0e 29 1f 78 2e 30 85 a6 56 4a 99 24
[   13.864501]  	14 50 54 bf ef 80 a9 40 90 4f 90 40 81 80 81 40
[   13.864502]  	71 4f 01 01 01 01 48 3f 40 30 62 b0 32 40 40 c0
[   13.864502]  	13 00 98 32 11 00 00 1e 00 00 00 ff 00 50 53 42
[   13.864503]  	30 36 30 35 30 30 30 39 30 0a 00 00 00 fd 00 32
[   13.864504]  	4b 1e 5c 11 00 0a 20 20 20 20 20 20 00 00 00 fc
[   13.864505]  	00 00 00 00 00 00 00 00 53 45 52 49 45 53 00 eb
[   13.864506] nouveau 0000:01:00.0: DVI-I-1: EDID block 0 invalid.
[   13.864508] nouveau 0000:01:00.0: DRM: DDC responded, but no EDID for DVI-I-1
[   13.893904] nouveau 0000:01:00.0: DRM: allocated 1024x768 fb: 0x70000, bo ffff880213eb0400
[   13.894016] fbcon: nouveaufb (fb0) is primary device
[   13.894099] Console: switching to colour frame buffer device 128x48
[   13.894119] nouveau 0000:01:00.0: fb0: nouveaufb frame buffer device
[   13.903627] [drm] Initialized nouveau 1.3.1 20120801 for 0000:01:00.0 on minor 0
[   15.244167] EXT4-fs (sda6): mounted filesystem with ordered data mode. Opts: (null)
[   16.109378] nvidia: module license 'NVIDIA' taints kernel.
[   16.109381] Disabling lock debugging due to kernel taint
[   16.113425] nvidia: module verification failed: signature and/or required key missing - tainting kernel
[   16.117780] NVRM: The NVIDIA probe routine was not called for 1 device(s).
[   16.117783] NVRM: This can occur when a driver such as:
               NVRM: nouveau, rivafb, nvidiafb or rivatv
               NVRM: was loaded and obtained ownership of the NVIDIA device(s).
[   16.117784] NVRM: Try unloading the conflicting kernel module (and/or
               NVRM: reconfigure your kernel without the conflicting
               NVRM: driver(s)), then try loading the NVIDIA kernel module
               NVRM: again.
[   16.117786] NVRM: No NVIDIA graphics adapter probed!
[   16.117787] [drm] Module unloaded
[   17.913351] audit: type=1400 audit(1494951369.382:2): apparmor="STATUS" operation="profile_load" profile="unconfined" name="docker-default" pid=823 comm="apparmor_parser"
[   17.922625] audit: type=1400 audit(1494951369.390:3): apparmor="STATUS" operation="profile_load" profile="unconfined" name="/usr/sbin/ippusbxd" pid=828 comm="apparmor_parser"
[   18.032455] audit: type=1400 audit(1494951369.502:4): apparmor="STATUS" operation="profile_load" profile="unconfined" name="/usr/sbin/tcpdump" pid=831 comm="apparmor_parser"
[   18.037560] audit: type=1400 audit(1494951369.506:5): apparmor="STATUS" operation="profile_load" profile="unconfined" name="/usr/sbin/ntpd" pid=829 comm="apparmor_parser"
[   18.037791] audit: type=1400 audit(1494951369.506:6): apparmor="STATUS" operation="profile_load" profile="unconfined" name="/usr/sbin/cups-browsed" pid=826 comm="apparmor_parser"
[   18.044956] audit: type=1400 audit(1494951369.514:7): apparmor="STATUS" operation="profile_load" profile="unconfined" name="/sbin/dhclient" pid=824 comm="apparmor_parser"
[   18.044961] audit: type=1400 audit(1494951369.514:8): apparmor="STATUS" operation="profile_load" profile="unconfined" name="/usr/lib/NetworkManager/nm-dhcp-client.action" pid=824 comm="apparmor_parser"
[   18.044965] audit: type=1400 audit(1494951369.514:9): apparmor="STATUS" operation="profile_load" profile="unconfined" name="/usr/lib/NetworkManager/nm-dhcp-helper" pid=824 comm="apparmor_parser"
[   18.044971] audit: type=1400 audit(1494951369.514:10): apparmor="STATUS" operation="profile_load" profile="unconfined" name="/usr/lib/connman/scripts/dhclient-script" pid=824 comm="apparmor_parser"
[   18.080046] audit: type=1400 audit(1494951369.550:11): apparmor="STATUS" operation="profile_load" profile="unconfined" name="/usr/lib/cups/backend/cups-pdf" pid=827 comm="apparmor_parser"
[   21.595028] cgroup: new mount options do not match the existing superblock, will be ignored
[   24.886777] IPv6: ADDRCONF(NETDEV_UP): enp0s25: link is not ready
[   25.119906] IPv6: ADDRCONF(NETDEV_UP): enp0s25: link is not ready
[   27.933422] e1000e: enp0s25 NIC Link is Up 100 Mbps Full Duplex, Flow Control: Rx
[   27.933545] e1000e 0000:00:19.0 enp0s25: 10/100 speed: disabling TSO
[   27.933592] IPv6: ADDRCONF(NETDEV_CHANGE): enp0s25: link becomes ready
[   33.294149] nouveau 0000:01:00.0: DRM: DDC responded, but no EDID for DVI-I-1
[   41.640726] ------------[ cut here ]------------
[   41.640733] WARNING: CPU: 0 PID: 1580 at /build/linux-FyIZxz/linux-4.4.0/fs/proc/generic.c:352 proc_register+0xe8/0x110()
[   41.640734] proc_dir_entry 'driver/nvidia' already registered
[   41.640735] Modules linked in: nvidia(POE+) binfmt_misc nouveau mxm_wmi wmi video ttm drm_kms_helper drm input_leds snd_hda_codec_realtek snd_hda_codec_generic i2c_algo_bit snd_hda_intel fb_sys_fops snd_hda_codec syscopyarea snd_hda_core sysfillrect snd_hwdep sysimgblt snd_pcm snd_seq_midi snd_seq_midi_event gpio_ich coretemp snd_rawmidi snd_seq snd_seq_device kvm snd_timer snd soundcore irqbypass shpchp i7core_edac edac_core lpc_ich mac_hid parport_pc ppdev lp parport autofs4 btrfs xor raid6_pq dm_mirror dm_region_hash dm_log hid_generic uas e1000e usbhid firewire_ohci usb_storage firewire_core hid pata_acpi crc_itu_t ptp pps_core fjes
[   41.640760] CPU: 0 PID: 1580 Comm: modprobe Tainted: P           OE   4.4.0-77-generic #98-Ubuntu
[   41.640761] Hardware name:                  /DP55WB, BIOS WBIBX10J.86A.0312.2010.1123.2356 11/23/2010
[   41.640762]  0000000000000286 000000007ef7654a ffff8800d753bae8 ffffffff813f8493
[   41.640764]  ffff8800d753bb30 ffffffff81ce20c0 ffff8800d753bb20 ffffffff81081302
[   41.640765]  ffff8802120a3d00 ffff880217089c00 ffff8800d897c745 ffff880217089c38
[   41.640767] Call Trace:
[   41.640770]  [<ffffffff813f8493>] dump_stack+0x63/0x90
[   41.640774]  [<ffffffff81081302>] warn_slowpath_common+0x82/0xc0
[   41.640775]  [<ffffffff8108139c>] warn_slowpath_fmt+0x5c/0x80
[   41.640777]  [<ffffffff81282129>] ? proc_alloc_inum+0x49/0xe0
[   41.640779]  [<ffffffff812822f8>] proc_register+0xe8/0x110
[   41.640780]  [<ffffffff81282436>] proc_mkdir_data+0x66/0x90
[   41.640782]  [<ffffffff81282473>] proc_mkdir_mode+0x13/0x20
[   41.640847]  [<ffffffffc0bca0dc>] nv_register_procfs+0x4c/0x1d0 [nvidia]
[   41.640904]  [<ffffffffc106a2a3>] nvidia_init_module+0x2a3/0x7a0 [nvidia]
[   41.640961]  [<ffffffffc106a7b5>] ? nv_drm_init+0x15/0x15 [nvidia]
[   41.641018]  [<ffffffffc106a806>] nvidia_frontend_init_module+0x51/0x84b [nvidia]
[   41.641020]  [<ffffffff81002123>] do_one_initcall+0xb3/0x200
[   41.641023]  [<ffffffff811d0f71>] ? __vunmap+0x91/0xe0
[   41.641026]  [<ffffffff811ed1a3>] ? kmem_cache_alloc_trace+0x183/0x1f0
[   41.641029]  [<ffffffff8118da83>] do_init_module+0x5f/0x1cf
[   41.641032]  [<ffffffff8110a9af>] load_module+0x166f/0x1c10
[   41.641034]  [<ffffffff81106f50>] ? __symbol_put+0x60/0x60
[   41.641036]  [<ffffffff81214e20>] ? kernel_read+0x50/0x80
[   41.641038]  [<ffffffff8110b194>] SYSC_finit_module+0xb4/0xe0
[   41.641040]  [<ffffffff8110b1de>] SyS_finit_module+0xe/0x10
[   41.641043]  [<ffffffff8183b972>] entry_SYSCALL_64_fastpath+0x16/0x71
[   41.641044] ---[ end trace 89a2402581d53455 ]---
[   41.641045] NVRM: failed to register procfs!
[   41.641231] NVRM: The NVIDIA probe routine was not called for 1 device(s).
[   41.641234] NVRM: This can occur when a driver such as:
[   41.641236] NVRM: Try unloading the conflicting kernel module (and/or
               NVRM: again.
[   41.641238] NVRM: No NVIDIA graphics adapter probed!
[   41.641239] [drm] Module unloaded
[   41.718297] ------------[ cut here ]------------
[   41.718303] WARNING: CPU: 3 PID: 1588 at /build/linux-FyIZxz/linux-4.4.0/fs/proc/generic.c:352 proc_register+0xe8/0x110()
[   41.718304] proc_dir_entry 'driver/nvidia' already registered
[   41.718305] Modules linked in: nvidia(POE+) binfmt_misc nouveau mxm_wmi wmi video ttm drm_kms_helper drm input_leds snd_hda_codec_realtek snd_hda_codec_generic i2c_algo_bit snd_hda_intel fb_sys_fops snd_hda_codec syscopyarea snd_hda_core sysfillrect snd_hwdep sysimgblt snd_pcm snd_seq_midi snd_seq_midi_event gpio_ich coretemp snd_rawmidi snd_seq snd_seq_device kvm snd_timer snd soundcore irqbypass shpchp i7core_edac edac_core lpc_ich mac_hid parport_pc ppdev lp parport autofs4 btrfs xor raid6_pq dm_mirror dm_region_hash dm_log hid_generic uas e1000e usbhid firewire_ohci usb_storage firewire_core hid pata_acpi crc_itu_t ptp pps_core fjes
[   41.718330] CPU: 3 PID: 1588 Comm: modprobe Tainted: P        W  OE   4.4.0-77-generic #98-Ubuntu
[   41.718331] Hardware name:                  /DP55WB, BIOS WBIBX10J.86A.0312.2010.1123.2356 11/23/2010
[   41.718332]  0000000000000286 00000000c37717c9 ffff8800d753bae8 ffffffff813f8493
[   41.718334]  ffff8800d753bb30 ffffffff81ce20c0 ffff8800d753bb20 ffffffff81081302
[   41.718336]  ffff8802120a3d00 ffff880217089c00 ffff8800daa42d45 ffff880217089c38
[   41.718337] Call Trace:
[   41.718341]  [<ffffffff813f8493>] dump_stack+0x63/0x90
[   41.718344]  [<ffffffff81081302>] warn_slowpath_common+0x82/0xc0
[   41.718345]  [<ffffffff8108139c>] warn_slowpath_fmt+0x5c/0x80
[   41.718347]  [<ffffffff81282129>] ? proc_alloc_inum+0x49/0xe0
[   41.718349]  [<ffffffff812822f8>] proc_register+0xe8/0x110
[   41.718351]  [<ffffffff81282436>] proc_mkdir_data+0x66/0x90
[   41.718352]  [<ffffffff81282473>] proc_mkdir_mode+0x13/0x20
[   41.718417]  [<ffffffffc15e00dc>] nv_register_procfs+0x4c/0x1d0 [nvidia]
[   41.718485]  [<ffffffffc1a802a3>] nvidia_init_module+0x2a3/0x7a0 [nvidia]
[   41.718548]  [<ffffffffc1a807b5>] ? nv_drm_init+0x15/0x15 [nvidia]
[   41.718605]  [<ffffffffc1a80806>] nvidia_frontend_init_module+0x51/0x84b [nvidia]
[   41.718608]  [<ffffffff81002123>] do_one_initcall+0xb3/0x200
[   41.718611]  [<ffffffff811d0f71>] ? __vunmap+0x91/0xe0
[   41.718614]  [<ffffffff811ed1a3>] ? kmem_cache_alloc_trace+0x183/0x1f0
[   41.718617]  [<ffffffff8118da83>] do_init_module+0x5f/0x1cf
[   41.718619]  [<ffffffff8110a9af>] load_module+0x166f/0x1c10
[   41.718621]  [<ffffffff81106f50>] ? __symbol_put+0x60/0x60
[   41.718623]  [<ffffffff81214e20>] ? kernel_read+0x50/0x80
[   41.718625]  [<ffffffff8110b194>] SYSC_finit_module+0xb4/0xe0
[   41.718627]  [<ffffffff8110b1de>] SyS_finit_module+0xe/0x10
[   41.718630]  [<ffffffff8183b972>] entry_SYSCALL_64_fastpath+0x16/0x71
[   41.718631] ---[ end trace 89a2402581d53456 ]---
[   41.718633] NVRM: failed to register procfs!
[   41.718921] NVRM: The NVIDIA probe routine was not called for 1 device(s).
[   41.718928] NVRM: This can occur when a driver such as:
[   41.718936] NVRM: Try unloading the conflicting kernel module (and/or
               NVRM: again.
[   41.718942] NVRM: No NVIDIA graphics adapter probed!
[   41.718946] [drm] Module unloaded
[   41.776925] ------------[ cut here ]------------
[   41.776931] WARNING: CPU: 7 PID: 1596 at /build/linux-FyIZxz/linux-4.4.0/fs/proc/generic.c:352 proc_register+0xe8/0x110()
[   41.776933] proc_dir_entry 'driver/nvidia' already registered
[   41.776933] Modules linked in: nvidia(POE+) binfmt_misc nouveau mxm_wmi wmi video ttm drm_kms_helper drm input_leds snd_hda_codec_realtek snd_hda_codec_generic i2c_algo_bit snd_hda_intel fb_sys_fops snd_hda_codec syscopyarea snd_hda_core sysfillrect snd_hwdep sysimgblt snd_pcm snd_seq_midi snd_seq_midi_event gpio_ich coretemp snd_rawmidi snd_seq snd_seq_device kvm snd_timer snd soundcore irqbypass shpchp i7core_edac edac_core lpc_ich mac_hid parport_pc ppdev lp parport autofs4 btrfs xor raid6_pq dm_mirror dm_region_hash dm_log hid_generic uas e1000e usbhid firewire_ohci usb_storage firewire_core hid pata_acpi crc_itu_t ptp pps_core fjes
[   41.776959] CPU: 7 PID: 1596 Comm: modprobe Tainted: P        W  OE   4.4.0-77-generic #98-Ubuntu
[   41.776960] Hardware name:                  /DP55WB, BIOS WBIBX10J.86A.0312.2010.1123.2356 11/23/2010
[   41.776961]  0000000000000286 000000000960e094 ffff880214fb7ae8 ffffffff813f8493
[   41.776963]  ffff880214fb7b30 ffffffff81ce20c0 ffff880214fb7b20 ffffffff81081302
[   41.776964]  ffff8802120a3d00 ffff880217089c00 ffff880211434385 ffff880217089c38
[   41.776966] Call Trace:
[   41.776970]  [<ffffffff813f8493>] dump_stack+0x63/0x90
[   41.776973]  [<ffffffff81081302>] warn_slowpath_common+0x82/0xc0
[   41.776975]  [<ffffffff8108139c>] warn_slowpath_fmt+0x5c/0x80
[   41.776976]  [<ffffffff81282129>] ? proc_alloc_inum+0x49/0xe0
[   41.776978]  [<ffffffff812822f8>] proc_register+0xe8/0x110
[   41.776980]  [<ffffffff81282436>] proc_mkdir_data+0x66/0x90
[   41.776981]  [<ffffffff81282473>] proc_mkdir_mode+0x13/0x20
[   41.777046]  [<ffffffffc0bca0dc>] nv_register_procfs+0x4c/0x1d0 [nvidia]
[   41.777105]  [<ffffffffc1a802a3>] nvidia_init_module+0x2a3/0x7a0 [nvidia]
[   41.777180]  [<ffffffffc1a807b5>] ? nv_drm_init+0x15/0x15 [nvidia]
[   41.777234]  [<ffffffffc1a80806>] nvidia_frontend_init_module+0x51/0x84b [nvidia]
[   41.777236]  [<ffffffff81002123>] do_one_initcall+0xb3/0x200
[   41.777239]  [<ffffffff81837a48>] ? preempt_schedule_common+0x18/0x30
[   41.777240]  [<ffffffff81837a7c>] ? _cond_resched+0x1c/0x30
[   41.777243]  [<ffffffff811ed1a3>] ? kmem_cache_alloc_trace+0x183/0x1f0
[   41.777246]  [<ffffffff8118da83>] do_init_module+0x5f/0x1cf
[   41.777248]  [<ffffffff8110a9af>] load_module+0x166f/0x1c10
[   41.777250]  [<ffffffff81106f50>] ? __symbol_put+0x60/0x60
[   41.777252]  [<ffffffff81214e20>] ? kernel_read+0x50/0x80
[   41.777254]  [<ffffffff8110b194>] SYSC_finit_module+0xb4/0xe0
[   41.777255]  [<ffffffff8110b1de>] SyS_finit_module+0xe/0x10
[   41.777258]  [<ffffffff8183b972>] entry_SYSCALL_64_fastpath+0x16/0x71
[   41.777259] ---[ end trace 89a2402581d53457 ]---
[   41.777260] NVRM: failed to register procfs!
[   41.777574] NVRM: The NVIDIA probe routine was not called for 1 device(s).
[   41.777581] NVRM: This can occur when a driver such as:
[   41.777588] NVRM: Try unloading the conflicting kernel module (and/or
               NVRM: again.
[   41.777595] NVRM: No NVIDIA graphics adapter probed!
[   41.777598] [drm] Module unloaded
[   41.930310] nouveau 0000:01:00.0: DRM: DDC responded, but no EDID for DVI-I-1
[   42.047782] CE: hpet increased min_delta_ns to 20115 nsec
[   42.078227] aufs 4.x-rcN-20160111
[   42.105170] nouveau 0000:01:00.0: DRM: DDC responded, but no EDID for DVI-I-1
[   42.413289] bridge: automatic filtering via arp/ip/ip6tables has been deprecated. Update your scripts to load br_netfilter if you need this.
[   42.414557] Bridge firewalling registered
[   42.435058] nf_conntrack version 0.5.0 (65536 buckets, 262144 max)
[   42.539871] ip_tables: (C) 2000-2006 Netfilter Core Team
[   42.591693] Initializing XFRM netlink socket
[   42.597055] Netfilter messages via NETLINK v0.30.
[   42.598517] ctnetlink v0.93: registering with nfnetlink.
[   42.641788] IPv6: ADDRCONF(NETDEV_UP): docker0: link is not ready
[   43.443177] aufs au_opts_verify:1597:dockerd[1433]: dirperm1 breaks the protection by the permission bits on the lower branch
[  572.788399] nouveau 0000:01:00.0: DRM: DDC responded, but no EDID for DVI-I-1
[  572.934360] nouveau 0000:01:00.0: DRM: DDC responded, but no EDID for DVI-I-1
[  573.086229] nouveau 0000:01:00.0: DRM: DDC responded, but no EDID for DVI-I-1
[  573.877062] nouveau 0000:01:00.0: DRM: DDC responded, but no EDID for DVI-I-1
[  574.184470] nouveau 0000:01:00.0: DRM: DDC responded, but no EDID for DVI-I-1
[  574.399857] nouveau 0000:01:00.0: DRM: DDC responded, but no EDID for DVI-I-1
[  732.253478] nouveau 0000:01:00.0: DRM: DDC responded, but no EDID for DVI-I-1
[ 1134.136432] CE: hpet2 increased min_delta_ns to 20115 nsec
Obviously, nouveau gets loaded as driver, you’ll have to blacklist it so the binary nvidia driver gets used.
Oh, and there’s something wrong with your monitor’s EDID so it’s using low-res as a fall-back.
OK, I have blacklisted nouveau. Here are the results…
$ cat /var/log/Xorg.0.log
[    38.395]
X.Org X Server 1.18.4
Release Date: 2016-07-19
[    38.395] X Protocol Version 11, Revision 0
[    38.395] Build Operating System: Linux 4.4.0-45-generic x86_64 Ubuntu
[    38.395] Current Operating System: Linux labgeo1-desktop 4.4.0-77-generic #98-Ubuntu SMP Wed Apr 26 08:34:02 UTC 2017 x86_64
[    38.395] Kernel command line: BOOT_IMAGE=/boot/vmlinuz-4.4.0-77-generic root=UUID=6907f491-8aa4-4f40-8209-104f92206e25 ro quiet splash vt.handoff=7
[    38.395] Build Date: 02 November 2016  10:06:10PM
[    38.395] xorg-server 2:1.18.4-0ubuntu0.2 (For technical support please see http://www.ubuntu.com/support)
[    38.395] Current version of pixman: 0.33.6
[    38.395] 	Before reporting problems, check http://wiki.x.org
	to make sure that you have the latest version.
[    38.395] Markers: (--) probed, (**) from config file, (==) default setting,
	(++) from command line, (!!) notice, (II) informational,
	(WW) warning, (EE) error, (NI) not implemented, (??) unknown.
[    38.395] (==) Log file: "/var/log/Xorg.0.log", Time: Wed May 17 07:55:04 2017
[    38.395] (==) Using config file: "/etc/X11/xorg.conf"
[    38.395] (==) Using system config directory "/usr/share/X11/xorg.conf.d"
[    38.417] (==) ServerLayout "Layout0"
[    38.417] (**) |-->Screen "Screen0" (0)
[    38.417] (**) |   |-->Monitor "Monitor0"
[    38.450] (**) |   |-->Device "Device0"
[    38.450] (**) |-->Input Device "Keyboard0"
[    38.450] (**) |-->Input Device "Mouse0"
[    38.450] (==) Automatically adding devices
[    38.450] (==) Automatically enabling devices
[    38.450] (==) Automatically adding GPU devices
[    38.450] (==) Max clients allowed: 256, resource mask: 0x1fffff
[    38.450] (WW) The directory "/usr/share/fonts/X11/cyrillic" does not exist.
[    38.450] 	Entry deleted from font path.
[    38.450] (WW) The directory "/usr/share/fonts/X11/100dpi/" does not exist.
[    38.450] (WW) The directory "/usr/share/fonts/X11/75dpi/" does not exist.
[    38.450] (WW) The directory "/usr/share/fonts/X11/100dpi" does not exist.
[    38.450] (WW) The directory "/usr/share/fonts/X11/75dpi" does not exist.
[    38.450] (==) FontPath set to:
	/usr/share/fonts/X11/misc,
	/usr/share/fonts/X11/Type1,
	built-ins
[    38.450] (==) ModulePath set to "/usr/lib/x86_64-linux-gnu/xorg/extra-modules,/usr/lib/xorg/extra-modules,/usr/lib/xorg/modules"
[    38.450] (WW) Hotplugging is on, devices using drivers 'kbd', 'mouse' or 'vmmouse' will be disabled.
[    38.450] (WW) Disabling Keyboard0
[    38.450] (WW) Disabling Mouse0
[    38.473] (II) Loader magic: 0x56310c449dc0
[    38.473] (II) Module ABI versions:
[    38.473] 	X.Org ANSI C Emulation: 0.4
[    38.473] 	X.Org Video Driver: 20.0
[    38.473] 	X.Org XInput driver : 22.1
[    38.473] 	X.Org Server Extension : 9.0
[    38.474] (++) using VT number 8
[    38.474] (II) systemd-logind: logind integration requires -keeptty and -keeptty was not provided, disabling logind integration
[    38.474] (II) xfree86: Adding drm device (/dev/dri/card0)
[    38.476] (--) PCI:*(0:1:0:0) 10de:0640:3842:c954 rev 161, Mem @ 0xf2000000/16777216, 0xe0000000/268435456, 0xf0000000/33554432, I/O @ 0x00001000/128
[    38.476] (II) LoadModule: "glx"
[    38.527] (II) Loading /usr/lib/xorg/modules/extensions/libglx.so
[    41.592] (II) Module glx: vendor="NVIDIA Corporation"
[    41.592] 	compiled for 4.0.2, module version = 1.0.0
[    41.592] 	Module class: X.Org Server Extension
[    41.632] (II) NVIDIA GLX Module  340.102  Mon Jan 16 12:37:38 PST 2017
[    41.662] (II) LoadModule: "nvidia"
[    41.662] (II) Loading /usr/lib/xorg/modules/drivers/nvidia_drv.so
[    41.929] (II) Module nvidia: vendor="NVIDIA Corporation"
[    41.929] 	compiled for 4.0.2, module version = 1.0.0
[    41.929] 	Module class: X.Org Video Driver
[    41.954] (II) NVIDIA dlloader X Driver  340.102  Mon Jan 16 12:17:09 PST 2017
[    41.954] (II) NVIDIA Unified Driver for all Supported NVIDIA GPUs
[    41.985] (II) Loading sub module "fb"
[    41.985] (II) LoadModule: "fb"
[    41.985] (II) Loading /usr/lib/xorg/modules/libfb.so
[    42.002] (II) Module fb: vendor="X.Org Foundation"
[    42.002] 	compiled for 1.18.4, module version = 1.0.0
[    42.002] 	ABI class: X.Org ANSI C Emulation, version 0.4
[    42.002] (WW) Unresolved symbol: fbGetGCPrivateKey
[    42.002] (II) Loading sub module "wfb"
[    42.002] (II) LoadModule: "wfb"
[    42.002] (II) Loading /usr/lib/xorg/modules/libwfb.so
[    42.027] (II) Module wfb: vendor="X.Org Foundation"
[    42.027] 	compiled for 1.18.4, module version = 1.0.0
[    42.027] 	ABI class: X.Org ANSI C Emulation, version 0.4
[    42.027] (II) Loading sub module "ramdac"
[    42.027] (II) LoadModule: "ramdac"
[    42.027] (II) Module "ramdac" already built-in
[    42.075] (**) NVIDIA(0): Depth 24, (--) framebuffer bpp 32
[    42.075] (==) NVIDIA(0): RGB weight 888
[    42.075] (==) NVIDIA(0): Default visual is TrueColor
[    42.075] (==) NVIDIA(0): Using gamma correction (1.0, 1.0, 1.0)
[    42.097] (**) NVIDIA(0): Enabling 2D acceleration
[    43.362] (WW) NVIDIA(0): The EDID read for display device CRT-0 is invalid: the
[    43.362] (WW) NVIDIA(0):     checksum for EDID version 1 is invalid.
[    43.362] (--) NVIDIA(0):
[    43.362] (--) NVIDIA(0): Raw EDID bytes:
[    43.362] (--) NVIDIA(0):   00 ff ff ff ff ff ff 00  5a 63 1c 13 01 01 01 01
[    43.362] (--) NVIDIA(0):   05 10 01 03 0e 29 1f 78  2e 30 85 a6 56 4a 99 24
[    43.362] (--) NVIDIA(0):   14 50 54 bf ef 80 a9 40  90 4f 90 40 81 80 81 40
[    43.362] (--) NVIDIA(0):   71 4f 01 01 01 01 48 3f  40 30 62 b0 32 40 40 c0
[    43.362] (--) NVIDIA(0):   13 00 98 32 11 00 00 1e  00 00 00 ff 00 50 53 42
[    43.362] (--) NVIDIA(0):   30 36 30 35 30 30 30 39  30 0a 00 00 00 fd 00 32
[    43.362] (--) NVIDIA(0):   4b 1e 5c 11 00 0a 20 20  20 20 20 20 00 00 00 fc
[    43.362] (--) NVIDIA(0):   00 00 00 00 00 00 00 00  53 45 52 49 45 53 00 eb
[    43.362] (--) NVIDIA(0):   00 00 00 00 00 00 00 00  00 00 00 00 00 00 00 00
[    43.363] (II) NVIDIA(GPU-0): Found DRM driver nvidia-drm (20150116)
[    43.364] (II) NVIDIA(0): NVIDIA GPU GeForce 9500 GT (G96) at PCI:1:0:0 (GPU-0)
[    43.364] (--) NVIDIA(0): Memory: 524288 kBytes
[    43.364] (--) NVIDIA(0): VideoBIOS: 62.94.29.00.50
[    43.364] (II) NVIDIA(0): Detected PCI Express Link width: 16X
[    43.368] (--) NVIDIA(0): Valid display device(s) on GeForce 9500 GT at PCI:1:0:0
[    43.368] (--) NVIDIA(0):     CRT-0 (boot, connected)
[    43.368] (--) NVIDIA(0):     CRT-1
[    43.368] (--) NVIDIA(0):     TV-0
[    43.368] (--) NVIDIA(0):     DFP-0
[    43.368] (--) NVIDIA(0):     DFP-1
[    43.368] (--) NVIDIA(GPU-0): CRT-0: 400.0 MHz maximum pixel clock
[    43.368] (--) NVIDIA(GPU-0): CRT-1: 400.0 MHz maximum pixel clock
[    43.368] (--) NVIDIA(GPU-0): TV-0: 400.0 MHz maximum pixel clock
[    43.368] (--) NVIDIA(0): DFP-0: Internal TMDS
[    43.368] (--) NVIDIA(GPU-0): DFP-0: 330.0 MHz maximum pixel clock
[    43.368] (--) NVIDIA(0): DFP-1: Internal TMDS
[    43.368] (--) NVIDIA(GPU-0): DFP-1: 330.0 MHz maximum pixel clock
[    43.368] (**) NVIDIA(0): Using HorizSync/VertRefresh ranges from the EDID for display
[    43.369] (**) NVIDIA(0):     device CRT-0 (Using EDID frequencies has been enabled on
[    43.369] (**) NVIDIA(0):     all display devices.)
[    43.370] (==) NVIDIA(0):
[    43.370] (==) NVIDIA(0): No modes were requested; the default mode "nvidia-auto-select"
[    43.370] (==) NVIDIA(0):     will be used as the requested mode.
[    43.370] (II) NVIDIA(0): Validated MetaModes:
[    43.370] (II) NVIDIA(0):     "CRT-0:nvidia-auto-select"
[    43.370] (II) NVIDIA(0): Virtual screen size determined to be 640 x 480
[    43.402] (WW) NVIDIA(0): Unable to get display device CRT-0's EDID; cannot compute DPI
[    43.402] (WW) NVIDIA(0):     from CRT-0's EDID.
[    43.402] (==) NVIDIA(0): DPI set to (75, 75); computed from built-in default
[    43.402] (--) Depth 24 pixmap format is 32 bpp
[    43.402] (II) NVIDIA: Using 768.00 MB of virtual memory for indirect memory access.
[    43.411] (II) NVIDIA(0): Setting mode "CRT-0:nvidia-auto-select"
[    43.456] (II) NVIDIA(0): Built-in logo is bigger than the screen.
[    43.486] (==) NVIDIA(0): Disabling shared memory pixmaps
[    43.486] (==) NVIDIA(0): Backing store enabled
[    43.487] (==) NVIDIA(0): Silken mouse enabled
[    43.506] (**) NVIDIA(0): DPMS enabled
[    43.506] (II) Loading sub module "dri2"
[    43.506] (II) LoadModule: "dri2"
[    43.506] (II) Module "dri2" already built-in
[    43.506] (II) NVIDIA(0): [DRI2] Setup complete
[    43.506] (II) NVIDIA(0): [DRI2]   VDPAU driver: nvidia
[    43.507] (--) RandR disabled
[    43.524] (II) SELinux: Disabled on system
[    43.525] (II) Initializing extension GLX
[    43.525] (II) Indirect GLX disabled.(II) config/udev: Adding input device Power Button (/dev/input/event1)
[    43.697] (**) Power Button: Applying InputClass "evdev keyboard catchall"
[    43.697] (II) LoadModule: "evdev"
[    43.697] (II) Loading /usr/lib/xorg/modules/input/evdev_drv.so
[    43.716] (II) Module evdev: vendor="X.Org Foundation"
[    43.716] 	compiled for 1.18.1, module version = 2.10.1
[    43.716] 	Module class: X.Org XInput Driver
[    43.716] 	ABI class: X.Org XInput driver, version 22.1
[    43.716] (II) Using input driver 'evdev' for 'Power Button'
[    43.716] (**) Power Button: always reports core events
[    43.716] (**) evdev: Power Button: Device: "/dev/input/event1"
[    43.716] (--) evdev: Power Button: Vendor 0 Product 0x1
[    43.716] (--) evdev: Power Button: Found keys
[    43.716] (II) evdev: Power Button: Configuring as keyboard
[    43.716] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXPWRBN:00/input/input1/event1"
[    43.717] (II) XINPUT: Adding extended input device "Power Button" (type: KEYBOARD, id 6)
[    43.717] (**) Option "xkb_rules" "evdev"
[    43.717] (**) Option "xkb_model" "pc105"
[    43.717] (**) Option "xkb_layout" "latam"
[    43.734] (II) config/udev: Adding input device Sleep Button (/dev/input/event0)
[    43.734] (**) Sleep Button: Applying InputClass "evdev keyboard catchall"
[    43.734] (II) Using input driver 'evdev' for 'Sleep Button'
[    43.734] (**) Sleep Button: always reports core events
[    43.734] (**) evdev: Sleep Button: Device: "/dev/input/event0"
[    43.734] (--) evdev: Sleep Button: Vendor 0 Product 0x3
[    43.734] (--) evdev: Sleep Button: Found keys
[    43.734] (II) evdev: Sleep Button: Configuring as keyboard
[    43.734] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0E:00/input/input0/event0"
[    43.734] (II) XINPUT: Adding extended input device "Sleep Button" (type: KEYBOARD, id 7)
[    43.734] (**) Option "xkb_rules" "evdev"
[    43.734] (**) Option "xkb_model" "pc105"
[    43.734] (**) Option "xkb_layout" "latam"
[    43.735] (II) config/udev: Adding input device   USB Keyboard (/dev/input/event2)
[    43.735] (**)   USB Keyboard: Applying InputClass "evdev keyboard catchall"
[    43.735] (II) Using input driver 'evdev' for '  USB Keyboard'
[    43.735] (**)   USB Keyboard: always reports core events
[    43.735] (**) evdev:   USB Keyboard: Device: "/dev/input/event2"
[    43.735] (--) evdev:   USB Keyboard: Vendor 0x4d9 Product 0x1603
[    43.735] (--) evdev:   USB Keyboard: Found keys
[    43.735] (II) evdev:   USB Keyboard: Configuring as keyboard
[    43.735] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:1a.0/usb3/3-2/3-2:1.0/0003:04D9:1603.0002/input/input2/event2"
[    43.735] (II) XINPUT: Adding extended input device "  USB Keyboard" (type: KEYBOARD, id 8)
[    43.735] (**) Option "xkb_rules" "evdev"
[    43.735] (**) Option "xkb_model" "pc105"
[    43.735] (**) Option "xkb_layout" "latam"
[    43.736] (II) config/udev: Adding input device   USB Keyboard (/dev/input/event3)
[    43.736] (**)   USB Keyboard: Applying InputClass "evdev keyboard catchall"
[    43.736] (II) Using input driver 'evdev' for '  USB Keyboard'
[    43.736] (**)   USB Keyboard: always reports core events
[    43.736] (**) evdev:   USB Keyboard: Device: "/dev/input/event3"
[    43.736] (--) evdev:   USB Keyboard: Vendor 0x4d9 Product 0x1603
[    43.736] (--) evdev:   USB Keyboard: Found keys
[    43.736] (II) evdev:   USB Keyboard: Configuring as keyboard
[    43.736] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:1a.0/usb3/3-2/3-2:1.1/0003:04D9:1603.0003/input/input3/event3"
[    43.736] (II) XINPUT: Adding extended input device "  USB Keyboard" (type: KEYBOARD, id 9)
[    43.736] (**) Option "xkb_rules" "evdev"
[    43.736] (**) Option "xkb_model" "pc105"
[    43.736] (**) Option "xkb_layout" "latam"
[    43.736] (II) config/udev: Adding input device PixArt USB Optical Mouse (/dev/input/event4)
[    43.736] (**) PixArt USB Optical Mouse: Applying InputClass "evdev pointer catchall"
[    43.736] (II) Using input driver 'evdev' for 'PixArt USB Optical Mouse'
[    43.736] (**) PixArt USB Optical Mouse: always reports core events
[    43.736] (**) evdev: PixArt USB Optical Mouse: Device: "/dev/input/event4"
[    43.736] (--) evdev: PixArt USB Optical Mouse: Vendor 0x93a Product 0x2510
[    43.736] (--) evdev: PixArt USB Optical Mouse: Found 3 mouse buttons
[    43.736] (--) evdev: PixArt USB Optical Mouse: Found scroll wheel(s)
[    43.736] (--) evdev: PixArt USB Optical Mouse: Found relative axes
[    43.736] (--) evdev: PixArt USB Optical Mouse: Found x and y relative axes
[    43.736] (II) evdev: PixArt USB Optical Mouse: Configuring as mouse
[    43.736] (II) evdev: PixArt USB Optical Mouse: Adding scrollwheel support
[    43.736] (**) evdev: PixArt USB Optical Mouse: YAxisMapping: buttons 4 and 5
[    43.736] (**) evdev: PixArt USB Optical Mouse: EmulateWheelButton: 4, EmulateWheelInertia: 10, EmulateWheelTimeout: 200
[    43.736] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:1a.1/usb4/4-2/4-2:1.0/0003:093A:2510.0004/input/input4/event4"
[    43.736] (II) XINPUT: Adding extended input device "PixArt USB Optical Mouse" (type: MOUSE, id 10)
[    43.736] (II) evdev: PixArt USB Optical Mouse: initialized for relative axes.
[    43.736] (**) PixArt USB Optical Mouse: (accel) keeping acceleration scheme 1
[    43.736] (**) PixArt USB Optical Mouse: (accel) acceleration profile 0
[    43.736] (**) PixArt USB Optical Mouse: (accel) acceleration factor: 2.000
[    43.736] (**) PixArt USB Optical Mouse: (accel) acceleration threshold: 4
[    43.737] (II) config/udev: Adding input device PixArt USB Optical Mouse (/dev/input/mouse0)
[    43.737] (II) No input driver specified, ignoring this device.
[    43.737] (II) This device may have been added with another device file.
[    43.737] (II) config/udev: Adding input device HDA Intel MID Rear Mic (/dev/input/event5)
[    43.737] (II) config/udev: Adding input device HDA Intel MID Line (/dev/input/event6)
[    43.737] (II) config/udev: Adding input device HDA Intel MID Line Out (/dev/input/event7)
[    54.931] (WW) NVIDIA(GPU-0): The EDID read for display device CRT-0 is invalid: the
[    54.931] (WW) NVIDIA(GPU-0):     checksum for EDID version 1 is invalid.
[    54.931] (--) NVIDIA(GPU-0):
[    54.931] (--) NVIDIA(GPU-0): Raw EDID bytes:
[    54.931] (--) NVIDIA(GPU-0):   00 ff ff ff ff ff ff 00  5a 63 1c 13 01 01 01 01
[    54.931] (--) NVIDIA(GPU-0):   05 10 01 03 0e 29 1f 78  2e 30 85 a6 56 4a 99 24
[    54.931] (--) NVIDIA(GPU-0):   14 50 54 bf ef 80 a9 40  90 4f 90 40 81 80 81 40
[    54.931] (--) NVIDIA(GPU-0):   71 4f 01 01 01 01 48 3f  40 30 62 b0 32 40 40 c0
[    54.931] (--) NVIDIA(GPU-0):   13 00 98 32 11 00 00 1e  00 00 00 ff 00 50 53 42
[    54.931] (--) NVIDIA(GPU-0):   30 36 30 35 30 30 30 39  30 0a 00 00 00 fd 00 32
[    54.931] (--) NVIDIA(GPU-0):   4b 1e 5c 11 00 0a 20 20  20 20 20 20 00 00 00 fc
[    54.931] (--) NVIDIA(GPU-0):   00 00 00 00 00 00 00 00  53 45 52 49 45 53 00 eb
[    54.931] (--) NVIDIA(GPU-0):   00 00 00 00 00 00 00 00  00 00 00 00 00 00 00 00
[    55.050] (WW) NVIDIA(GPU-0): The EDID read for display device CRT-0 is invalid: the
[    55.050] (WW) NVIDIA(GPU-0):     checksum for EDID version 1 is invalid.
[    55.050] (--) NVIDIA(GPU-0):
[    55.050] (--) NVIDIA(GPU-0): Raw EDID bytes:
[    55.050] (--) NVIDIA(GPU-0):   00 ff ff ff ff ff ff 00  5a 63 1c 13 01 01 01 01
[    55.050] (--) NVIDIA(GPU-0):   05 10 01 03 0e 29 1f 78  2e 30 85 a6 56 4a 99 24
[    55.050] (--) NVIDIA(GPU-0):   14 50 54 bf ef 80 a9 40  90 4f 90 40 81 80 81 40
[    55.050] (--) NVIDIA(GPU-0):   71 4f 01 01 01 01 48 3f  40 30 62 b0 32 40 40 c0
[    55.050] (--) NVIDIA(GPU-0):   13 00 98 32 11 00 00 1e  00 00 00 ff 00 50 53 42
[    55.050] (--) NVIDIA(GPU-0):   30 36 30 35 30 30 30 39  30 0a 00 00 00 fd 00 32
[    55.050] (--) NVIDIA(GPU-0):   4b 1e 5c 11 00 0a 20 20  20 20 20 20 00 00 00 fc
[    55.050] (--) NVIDIA(GPU-0):   00 00 00 00 00 00 00 00  53 45 52 49 45 53 00 eb
[    55.050] (--) NVIDIA(GPU-0):   00 00 00 00 00 00 00 00  00 00 00 00 00 00 00 00
[    55.051] (--) NVIDIA(GPU-0):   00 00 00 00 00 00 00 00  00 00 00 00 00 00 00 00
[    55.179] (WW) NVIDIA(GPU-0): The EDID read for display device CRT-0 is invalid: the
[    55.179] (WW) NVIDIA(GPU-0):     checksum for EDID version 1 is invalid.
[    55.179] (--) NVIDIA(GPU-0):
[    55.179] (--) NVIDIA(GPU-0): Raw EDID bytes:
[    55.179] (--) NVIDIA(GPU-0):   00 ff ff ff ff ff ff 00  5a 63 1c 13 01 01 01 01
[    55.179] (--) NVIDIA(GPU-0):   05 10 01 03 0e 29 1f 78  2e 30 85 a6 56 4a 99 24
[    55.179] (--) NVIDIA(GPU-0):   14 50 54 bf ef 80 a9 40  90 4f 90 40 81 80 81 40
[    55.179] (--) NVIDIA(GPU-0):   71 4f 01 01 01 01 48 3f  40 30 62 b0 32 40 40 c0
[    55.179] (--) NVIDIA(GPU-0):   13 00 98 32 11 00 00 1e  00 00 00 ff 00 50 53 42
[    55.179] (--) NVIDIA(GPU-0):   30 36 30 35 30 30 30 39  30 0a 00 00 00 fd 00 32
[    55.179] (--) NVIDIA(GPU-0):   4b 1e 5c 11 00 0a 20 20  20 20 20 20 00 00 00 fc
[    55.179] (--) NVIDIA(GPU-0):   00 00 00 00 00 00 00 00  53 45 52 49 45 53 00 eb
[    55.179] (--) NVIDIA(GPU-0):   00 00 00 00 00 00 00 00  00 00 00 00 00 00 00 00
[    55.380] (WW) NVIDIA(GPU-0): The EDID read for display device CRT-0 is invalid: the
[    55.380] (WW) NVIDIA(GPU-0):     checksum for EDID version 1 is invalid.
[    55.380] (--) NVIDIA(GPU-0):
[    55.380] (--) NVIDIA(GPU-0): Raw EDID bytes:
[    55.380] (--) NVIDIA(GPU-0):   00 ff ff ff ff ff ff 00  5a 63 1c 13 01 01 01 01
[    55.380] (--) NVIDIA(GPU-0):   05 10 01 03 0e 29 1f 78  2e 30 85 a6 56 4a 99 24
[    55.380] (--) NVIDIA(GPU-0):   14 50 54 bf ef 80 a9 40  90 4f 90 40 81 80 81 40
[    55.380] (--) NVIDIA(GPU-0):   71 4f 01 01 01 01 48 3f  40 30 62 b0 32 40 40 c0
[    55.380] (--) NVIDIA(GPU-0):   13 00 98 32 11 00 00 1e  00 00 00 ff 00 50 53 42
[    55.380] (--) NVIDIA(GPU-0):   30 36 30 35 30 30 30 39  30 0a 00 00 00 fd 00 32
[    55.380] (--) NVIDIA(GPU-0):   4b 1e 5c 11 00 0a 20 20  20 20 20 20 00 00 00 fc
[    55.380] (--) NVIDIA(GPU-0):   00 00 00 00 00 00 00 00  53 45 52 49 45 53 00 eb
[    55.380] (--) NVIDIA(GPU-0):   00 00 00 00 00 00 00 00  00 00 00 00 00 00 00 00
[    57.413] (WW) NVIDIA(GPU-0): The EDID read for display device CRT-0 is invalid: the
[    57.413] (WW) NVIDIA(GPU-0):     checksum for EDID version 1 is invalid.
[    57.413] (--) NVIDIA(GPU-0):
[    57.413] (--) NVIDIA(GPU-0): Raw EDID bytes:
[    57.413] (--) NVIDIA(GPU-0):   00 ff ff ff ff ff ff 00  5a 63 1c 13 01 01 01 01
[    57.413] (--) NVIDIA(GPU-0):   05 10 01 03 0e 29 1f 78  2e 30 85 a6 56 4a 99 24
[    57.413] (--) NVIDIA(GPU-0):   14 50 54 bf ef 80 a9 40  90 4f 90 40 81 80 81 40
[    57.413] (--) NVIDIA(GPU-0):   71 4f 01 01 01 01 48 3f  40 30 62 b0 32 40 40 c0
[    57.413] (--) NVIDIA(GPU-0):   13 00 98 32 11 00 00 1e  00 00 00 ff 00 50 53 42
[    57.413] (--) NVIDIA(GPU-0):   30 36 30 35 30 30 30 39  30 0a 00 00 00 fd 00 32
[    57.413] (--) NVIDIA(GPU-0):   4b 1e 5c 11 00 0a 20 20  20 20 20 20 00 00 00 fc
[    57.413] (--) NVIDIA(GPU-0):   00 00 00 00 00 00 00 00  53 45 52 49 45 53 00 eb
[    57.413] (--) NVIDIA(GPU-0):   00 00 00 00 00 00 00 00  00 00 00 00 00 00 00 00
$ sudo lspci -v
00:00.0 Host bridge: Intel Corporation Core Processor DMI (rev 11)
	Subsystem: Intel Corporation Core Processor DMI
	Flags: fast devsel
	Capabilities: [40] #00 [0000]
00:03.0 PCI bridge: Intel Corporation Core Processor PCI Express Root Port 1 (rev 11) (prog-if 00 [Normal decode])
	Flags: bus master, fast devsel, latency 0, IRQ 29
	Bus: primary=00, secondary=01, subordinate=01, sec-latency=0
	I/O behind bridge: 00001000-00001fff
	Memory behind bridge: f0000000-f2ffffff
	Prefetchable memory behind bridge: 00000000e0000000-00000000efffffff
	Capabilities: [40] Subsystem: Intel Corporation Core Processor PCI Express Root Port 1
	Capabilities: [60] MSI: Enable+ Count=1/2 Maskable+ 64bit-
	Capabilities: [90] Express Root Port (Slot+), MSI 00
	Capabilities: [e0] Power Management version 3
	Capabilities: [100] Advanced Error Reporting
	Capabilities: [150] Access Control Services
	Capabilities: [160] Vendor Specific Information: ID=0002 Rev=0 Len=00c <?>
	Kernel driver in use: pcieport
	Kernel modules: shpchp
00:08.0 System peripheral: Intel Corporation Core Processor System Management Registers (rev 11)
	Flags: fast devsel
	Capabilities: [40] Express Root Complex Integrated Endpoint, MSI 00
	Capabilities: [100] Vendor Specific Information: ID=0000 Rev=0 Len=000 <?>
00:08.1 System peripheral: Intel Corporation Core Processor Semaphore and Scratchpad Registers (rev 11)
	Flags: fast devsel
00:08.2 System peripheral: Intel Corporation Core Processor System Control and Status Registers (rev 11)
	Flags: fast devsel
00:08.3 System peripheral: Intel Corporation Core Processor Miscellaneous Registers (rev 11)
	Flags: fast devsel
00:10.0 System peripheral: Intel Corporation Core Processor QPI Link (rev 11)
	Flags: fast devsel
00:10.1 System peripheral: Intel Corporation Core Processor QPI Routing and Protocol Registers (rev 11)
	Flags: fast devsel
00:19.0 Ethernet controller: Intel Corporation 82578DC Gigabit Network Connection (rev 05)
	DeviceName: Intel(R) 82578DC Gigabit Network Connection
	Subsystem: Intel Corporation 82578DC Gigabit Network Connection
	Flags: bus master, fast devsel, latency 0, IRQ 31
	Memory at f3100000 (32-bit, non-prefetchable)
	Memory at f3124000 (32-bit, non-prefetchable)
	I/O ports at 2100
	Capabilities: [c8] Power Management version 2
	Capabilities: [d0] MSI: Enable+ Count=1/1 Maskable- 64bit+
	Capabilities: [e0] PCI Advanced Features
	Kernel driver in use: e1000e
	Kernel modules: e1000e
00:1a.0 USB controller: Intel Corporation 5 Series/3400 Series Chipset USB Universal Host Controller (rev 05) (prog-if 00 [UHCI])
	Subsystem: Intel Corporation 5 Series/3400 Series Chipset USB Universal Host Controller
	Flags: bus master, medium devsel, latency 0, IRQ 21
	I/O ports at 20e0
	Capabilities: [50] PCI Advanced Features
	Kernel driver in use: uhci_hcd
00:1a.1 USB controller: Intel Corporation 5 Series/3400 Series Chipset USB Universal Host Controller (rev 05) (prog-if 00 [UHCI])
	Flags: bus master, medium devsel, latency 0, IRQ 18
	I/O ports at 20c0
00:1a.2 USB controller: Intel Corporation 5 Series/3400 Series Chipset USB Universal Host Controller (rev 05) (prog-if 00 [UHCI])
	Flags: bus master, medium devsel, latency 0, IRQ 19
	I/O ports at 20a0
00:1a.7 USB controller: Intel Corporation 5 Series/3400 Series Chipset USB2 Enhanced Host Controller (rev 05) (prog-if 20 [EHCI])
	Subsystem: Intel Corporation 5 Series/3400 Series Chipset USB2 Enhanced Host Controller
	Flags: bus master, medium devsel, latency 0, IRQ 16
	Memory at f3125400 (32-bit, non-prefetchable)
	Capabilities: [50] Power Management version 2
	Capabilities: [58] Debug port: BAR=1 offset=00a0
	Capabilities: [98] PCI Advanced Features
	Kernel driver in use: ehci-pci
00:1b.0 Audio device: Intel Corporation 5 Series/3400 Series Chipset High Definition Audio (rev 05)
	DeviceName: Intel(R) High Definition Audio Device
	Subsystem: Intel Corporation 5 Series/3400 Series Chipset High Definition Audio
	Flags: bus master, fast devsel, latency 0, IRQ 32
	Memory at f3120000 (64-bit, non-prefetchable)
	Capabilities: [60] MSI: Enable+ Count=1/1 Maskable- 64bit+
	Capabilities: [70] Express Root Complex Integrated Endpoint, MSI 00
	Capabilities: [100] Virtual Channel
	Capabilities: [130] Root Complex Link
	Kernel driver in use: snd_hda_intel
	Kernel modules: snd_hda_intel
00:1c.0 PCI bridge: Intel Corporation 5 Series/3400 Series Chipset PCI Express Root Port 1 (rev 05) (prog-if 00 [Normal decode])
	Flags: bus master, fast devsel, latency 0, IRQ 30
	Bus: primary=00, secondary=02, subordinate=02, sec-latency=0
	I/O behind bridge: 00003000-00003fff
	Memory behind bridge: f3200000-f33fffff
	Prefetchable memory behind bridge: 00000000f3400000-00000000f35fffff
	Capabilities: [40] Express Root Port (Slot+), MSI 00
	Capabilities: [80] MSI: Enable+ Count=1/1 Maskable- 64bit-
	Capabilities: [90] Subsystem: Intel Corporation 5 Series/3400 Series Chipset PCI Express Root Port 1
	Capabilities: [a0] Power Management version 2
00:1d.0 USB controller: Intel Corporation 5 Series/3400 Series Chipset USB Universal Host Controller (rev 05) (prog-if 00 [UHCI])
	I/O ports at 2080
00:1d.1 USB controller: Intel Corporation 5 Series/3400 Series Chipset USB Universal Host Controller (rev 05) (prog-if 00 [UHCI])
	I/O ports at 2060
00:1d.2 USB controller: Intel Corporation 5 Series/3400 Series Chipset USB Universal Host Controller (rev 05) (prog-if 00 [UHCI])
	I/O ports at 2040
00:1d.3 USB controller: Intel Corporation 5 Series/3400 Series Chipset USB Universal Host Controller (rev 05) (prog-if 00 [UHCI])
	Flags: bus master, medium devsel, latency 0, IRQ 23
	I/O ports at 2020
00:1d.7 USB controller: Intel Corporation 5 Series/3400 Series Chipset USB2 Enhanced Host Controller (rev 05) (prog-if 20 [EHCI])
	Memory at f3125000 (32-bit, non-prefetchable)
00:1e.0 PCI bridge: Intel Corporation 82801 PCI Bridge (rev a5) (prog-if 01 [Subtractive decode])
	Bus: primary=00, secondary=03, subordinate=03, sec-latency=32
	Memory behind bridge: f3000000-f30fffff
	Capabilities: [50] Subsystem: Intel Corporation 82801 PCI Bridge
00:1f.0 ISA bridge: Intel Corporation P55 Chipset LPC Interface Controller (rev 05)
	Subsystem: Intel Corporation P55 Chipset LPC Interface Controller
	Capabilities: [e0] Vendor Specific Information: Len=10 <?>
	Kernel driver in use: lpc_ich
	Kernel modules: lpc_ich
00:1f.2 IDE interface: Intel Corporation 5 Series/3400 Series Chipset 4 port SATA IDE Controller (rev 05) (prog-if 8f [Master SecP SecO PriP PriO])
	DeviceName: Intel(R) SATA Controller 0
	Subsystem: Intel Corporation 5 Series/3400 Series Chipset 4 port SATA IDE Controller
	Flags: bus master, 66MHz, medium devsel, latency 0, IRQ 19
	I/O ports at 2178
	I/O ports at 218c
	I/O ports at 2170
	I/O ports at 2188
	I/O ports at 2150
	I/O ports at 2140
	Capabilities: [70] Power Management version 3
	Capabilities: [b0] PCI Advanced Features
	Kernel driver in use: ata_piix
	Kernel modules: pata_acpi
00:1f.3 SMBus: Intel Corporation 5 Series/3400 Series Chipset SMBus Controller (rev 05)
	Subsystem: Intel Corporation 5 Series/3400 Series Chipset SMBus Controller
	Flags: medium devsel, IRQ 9
	Memory at f3125800 (64-bit, non-prefetchable)
	I/O ports at 2000
	Kernel modules: i2c_i801
00:1f.5 IDE interface: Intel Corporation 5 Series/3400 Series Chipset 2 port SATA IDE Controller (rev 05) (prog-if 85 [Master SecO PriO])
	DeviceName: Intel(R) SATA Controller 1
	Subsystem: Intel Corporation 5 Series/3400 Series Chipset 2 port SATA IDE Controller
	I/O ports at 2168
	I/O ports at 2184
	I/O ports at 2160
	I/O ports at 2180
	I/O ports at 2130
	I/O ports at 2120
01:00.0 VGA compatible controller: NVIDIA Corporation G96 [GeForce 9500 GT] (rev a1) (prog-if 00 [VGA controller])
	Subsystem: eVga.com. Corp. G96 [GeForce 9500 GT]
	Flags: bus master, fast devsel, latency 0, IRQ 33
	Memory at f2000000 (32-bit, non-prefetchable)
	Memory at e0000000 (64-bit, prefetchable)
	Memory at f0000000 (64-bit, non-prefetchable)
	I/O ports at 1000
	Expansion ROM at <unassigned> [disabled]
	Capabilities: [60] Power Management version 3
	Capabilities: [68] MSI: Enable+ Count=1/1 Maskable- 64bit+
	Capabilities: [78] Express Endpoint, MSI 00
	Capabilities: [b4] Vendor Specific Information: Len=14 <?>
	Capabilities: [128] Power Budgeting <?>
	Capabilities: [600] Vendor Specific Information: ID=0001 Rev=1 Len=024 <?>
	Kernel driver in use: nvidia
	Kernel modules: nvidiafb, nouveau, nvidia
03:03.0 FireWire (IEEE 1394): Texas Instruments TSB43AB22A IEEE-1394a-2000 Controller (PHY/Link) [iOHCI-Lynx] (prog-if 10 [OHCI])
	Subsystem: Intel Corporation TSB43AB22A IEEE-1394a-2000 Controller (PHY/Link) [iOHCI-Lynx]
	Flags: bus master, medium devsel, latency 32, IRQ 19
	Memory at f3004000 (32-bit, non-prefetchable)
	Memory at f3000000 (32-bit, non-prefetchable)
	Capabilities: [44] Power Management version 2
	Kernel driver in use: firewire_ohci
	Kernel modules: firewire_ohci
3f:00.0 Host bridge: Intel Corporation Core Processor QuickPath Architecture Generic Non-Core Registers (rev 04)
	Subsystem: Intel Corporation Core Processor QuickPath Architecture Generic Non-Core Registers
3f:00.1 Host bridge: Intel Corporation Core Processor QuickPath Architecture System Address Decoder (rev 04)
	Subsystem: Intel Corporation Core Processor QuickPath Architecture System Address Decoder
3f:02.0 Host bridge: Intel Corporation Core Processor QPI Link 0 (rev 04)
	Subsystem: Intel Corporation Core Processor QPI Link 0
	Kernel driver in use: i7core_edac
	Kernel modules: i7core_edac
3f:02.1 Host bridge: Intel Corporation Core Processor QPI Physical 0 (rev 04)
	Subsystem: Intel Corporation Core Processor QPI Physical 0
3f:03.0 Host bridge: Intel Corporation Core Processor Integrated Memory Controller (rev 04)
	Subsystem: Intel Corporation Core Processor Integrated Memory Controller
3f:03.1 Host bridge: Intel Corporation Core Processor Integrated Memory Controller Target Address Decoder (rev 04)
	Subsystem: Intel Corporation Core Processor Integrated Memory Controller Target Address Decoder
3f:03.4 Host bridge: Intel Corporation Core Processor Integrated Memory Controller Test Registers (rev 04)
	Subsystem: Intel Corporation Core Processor Integrated Memory Controller Test Registers
3f:04.0 Host bridge: Intel Corporation Core Processor Integrated Memory Controller Channel 0 Control Registers (rev 04)
	Subsystem: Intel Corporation Core Processor Integrated Memory Controller Channel 0 Control Registers
3f:04.1 Host bridge: Intel Corporation Core Processor Integrated Memory Controller Channel 0 Address Registers (rev 04)
	Subsystem: Intel Corporation Core Processor Integrated Memory Controller Channel 0 Address Registers
3f:04.2 Host bridge: Intel Corporation Core Processor Integrated Memory Controller Channel 0 Rank Registers (rev 04)
	Subsystem: Intel Corporation Core Processor Integrated Memory Controller Channel 0 Rank Registers
3f:04.3 Host bridge: Intel Corporation Core Processor Integrated Memory Controller Channel 0 Thermal Control Registers (rev 04)
	Subsystem: Intel Corporation Core Processor Integrated Memory Controller Channel 0 Thermal Control Registers
3f:05.0 Host bridge: Intel Corporation Core Processor Integrated Memory Controller Channel 1 Control Registers (rev 04)
	Subsystem: Intel Corporation Core Processor Integrated Memory Controller Channel 1 Control Registers
3f:05.1 Host bridge: Intel Corporation Core Processor Integrated Memory Controller Channel 1 Address Registers (rev 04)
	Subsystem: Intel Corporation Core Processor Integrated Memory Controller Channel 1 Address Registers
3f:05.2 Host bridge: Intel Corporation Core Processor Integrated Memory Controller Channel 1 Rank Registers (rev 04)
	Subsystem: Intel Corporation Core Processor Integrated Memory Controller Channel 1 Rank Registers
3f:05.3 Host bridge: Intel Corporation Core Processor Integrated Memory Controller Channel 1 Thermal Control Registers (rev 04)
	Subsystem: Intel Corporation Core Processor Integrated Memory Controller Channel 1 Thermal Control Registers
$ dmesg
[    0.000000] microcode: CPU0 microcode updated early to revision 0x7, date = 2013-08-20
[    0.000000] Initializing cgroup subsys cpuset
[    0.000000] Initializing cgroup subsys cpuacct
[    0.000000] Linux version 4.4.0-77-generic (buildd@lgw01-59) (gcc version 5.4.0 20160609 (Ubuntu 5.4.0-6ubuntu1~16.04.4) ) #98-Ubuntu SMP Wed Apr 26 08:34:02 UTC 2017 (Ubuntu 4.4.0-77.98-generic 4.4.59)
[    0.000000] Command line: BOOT_IMAGE=/boot/vmlinuz-4.4.0-77-generic root=UUID=6907f491-8aa4-4f40-8209-104f92206e25 ro quiet splash vt.handoff=7
[    0.000000] KERNEL supported cpus:
[    0.000000]   Intel GenuineIntel
[    0.000000]   AMD AuthenticAMD
[    0.000000]   Centaur CentaurHauls
[    0.000000] x86/fpu: Legacy x87 FPU detected.
[    0.000000] x86/fpu: Using 'lazy' FPU context switches.
[    0.000000] e820: BIOS-provided physical RAM map:
[    0.000000] BIOS-e820: [mem 0x0000000000000000-0x000000000008efff] usable
[    0.000000] BIOS-e820: [mem 0x000000000008f000-0x000000000009ffff] reserved
[    0.000000] BIOS-e820: [mem 0x00000000000e0000-0x00000000000fffff] reserved
[    0.000000] BIOS-e820: [mem 0x0000000000100000-0x00000000df62cfff] usable
[    0.000000] BIOS-e820: [mem 0x00000000df62d000-0x00000000df634fff] reserved
[    0.000000] BIOS-e820: [mem 0x00000000df635000-0x00000000df66efff] usable
[    0.000000] BIOS-e820: [mem 0x00000000df66f000-0x00000000df6befff] reserved
[    0.000000] BIOS-e820: [mem 0x00000000df6bf000-0x00000000df6e5fff] usable
[    0.000000] BIOS-e820: [mem 0x00000000df6e6000-0x00000000df7befff] ACPI NVS
[    0.000000] BIOS-e820: [mem 0x00000000df7bf000-0x00000000df7e6fff] usable
[    0.000000] BIOS-e820: [mem 0x00000000df7e7000-0x00000000df7f1fff] ACPI data
[    0.000000] BIOS-e820: [mem 0x00000000df7f2000-0x00000000df7f2fff] usable
[    0.000000] BIOS-e820: [mem 0x00000000df7f3000-0x00000000df7fefff] ACPI data
[    0.000000] BIOS-e820: [mem 0x00000000df7ff000-0x00000000df7fffff] usable
[    0.000000] BIOS-e820: [mem 0x00000000df800000-0x00000000dfffffff] reserved
[    0.000000] BIOS-e820: [mem 0x00000000f8000000-0x00000000ffffffff] reserved
[    0.000000] BIOS-e820: [mem 0x0000000100000000-0x000000021fffffff] usable
[    0.000000] NX (Execute Disable) protection: active
[    0.000000] SMBIOS 2.6 present.
[    0.000000] DMI:                  /DP55WB, BIOS WBIBX10J.86A.0312.2010.1123.2356 11/23/2010
[    0.000000] e820: update [mem 0x00000000-0x00000fff] usable ==> reserved
[    0.000000] e820: remove [mem 0x000a0000-0x000fffff] usable
[    0.000000] e820: last_pfn = 0x220000 max_arch_pfn = 0x400000000
[    0.000000] MTRR default type: uncachable
[    0.000000] MTRR fixed ranges enabled:
[    0.000000]   00000-9FFFF write-back
[    0.000000]   A0000-BFFFF uncachable
[    0.000000]   C0000-DFFFF write-protect
[    0.000000]   E0000-FFFFF uncachable
[    0.000000] MTRR variable ranges enabled:
[    0.000000]   0 base 000000000 mask F80000000 write-back
[    0.000000]   1 base 080000000 mask FC0000000 write-back
[    0.000000]   2 base 0C0000000 mask FE0000000 write-back
[    0.000000]   3 base 0FFE00000 mask FFFE00000 write-protect
[    0.000000]   4 base 100000000 mask F00000000 write-back
[    0.000000]   5 base 200000000 mask E00000000 write-back
[    0.000000]   6 disabled
[    0.000000]   7 disabled
[    0.000000] x86/PAT: Configuration [0-7]: WB  WC  UC- UC  WB  WC  UC- WT
[    0.000000] e820: last_pfn = 0xdf800 max_arch_pfn = 0x400000000
[    0.000000] Scanning 1 areas for low memory corruption
[    0.000000] Base memory trampoline at [ffff880000089000] 89000 size 24576
[    0.000000] BRK [0x0220b000, 0x0220bfff] PGTABLE
[    0.000000] BRK [0x0220c000, 0x0220cfff] PGTABLE
[    0.000000] BRK [0x0220d000, 0x0220dfff] PGTABLE
[    0.000000] BRK [0x0220e000, 0x0220efff] PGTABLE
[    0.000000] BRK [0x0220f000, 0x0220ffff] PGTABLE
[    0.000000] BRK [0x02210000, 0x02210fff] PGTABLE
[    0.000000] RAMDISK: [mem 0x33300000-0x35977fff]
[    0.000000] ACPI: Early table checksum verification disabled
[    0.000000] ACPI: RSDP 0x00000000000FE020 000024 (v02 INTEL )
[    0.000000] ACPI: XSDT 0x00000000DF7FD120 00006C (v01 INTEL  WBIBX10J 00000138      01000013)
[    0.000000] ACPI: FACP 0x00000000DF7FC000 0000F4 (v03 INTEL  WBIBX10J 00000138 MSFT 0100000D)
[    0.000000] ACPI BIOS Warning (bug): 32/64X length mismatch in FADT/Pm1aEventBlock: 32/16 (20150930/tbfadt-623)
[    0.000000] ACPI BIOS Warning (bug): 32/64X length mismatch in FADT/PmTimerBlock: 32/24 (20150930/tbfadt-623)
[    0.000000] ACPI BIOS Warning (bug): Invalid length for FADT/Pm1aEventBlock: 16, using default 32 (20150930/tbfadt-704)
[    0.000000] ACPI BIOS Warning (bug): Invalid length for FADT/PmTimerBlock: 24, using default 32 (20150930/tbfadt-704)
[    0.000000] ACPI: DSDT 0x00000000DF7F8000 003843 (v02 INTEL  WBIBX10J 00000138 MSFT 0100000D)
[    0.000000] ACPI: FACS 0x00000000DF76E000 000040
[    0.000000] ACPI: APIC 0x00000000DF7F7000 0000BC (v02 INTEL  WBIBX10J 00000138 MSFT 0100000D)
[    0.000000] ACPI: WDDT 0x00000000DF7F6000 000040 (v01 INTEL  WBIBX10J 00000138 MSFT 0100000D)
[    0.000000] ACPI: MCFG 0x00000000DF7F5000 00003C (v01 INTEL  WBIBX10J 00000138 MSFT 0100000D)
[    0.000000] ACPI: ASF! 0x00000000DF7F4000 0000A5 (v32 INTEL  WBIBX10J 00000138 MSFT 0100000D)
[    0.000000] ACPI: HPET 0x00000000DF7F3000 000038 (v01 INTEL  WBIBX10J 00000138 MSFT 0100000D)
[    0.000000] ACPI: ASPT 0x00000000DF7F1000 000034 (v05 INTEL  WBIBX10J 00000138 MSFT 0100000D)
[    0.000000] ACPI: WDTT 0x00000000DF7F0000 000224 (v02 INTEL  WBIBX10J 00000138 MSFT 0100000D)
[    0.000000] ACPI: SSDT 0x00000000DF7E8000 00759C (v01 INTEL  SSDT  PM 00000138 MSFT 0100000D)
[    0.000000] ACPI: Local APIC address 0xfee00000
[    0.000000] No NUMA configuration found
[    0.000000] Faking a node at [mem 0x0000000000000000-0x000000021fffffff]
[    0.000000] NODE_DATA(0) allocated [mem 0x21fff5000-0x21fff9fff]
[    0.000000] Zone ranges:
[    0.000000]   DMA      [mem 0x0000000000001000-0x0000000000ffffff]
[    0.000000]   DMA32    [mem 0x0000000001000000-0x00000000ffffffff]
[    0.000000]   Normal   [mem 0x0000000100000000-0x000000021fffffff]
[    0.000000]   Device   empty
[    0.000000] Movable zone start for each node
[    0.000000] Early memory node ranges
[    0.000000]   node   0: [mem 0x0000000000001000-0x000000000008efff]
[    0.000000]   node   0: [mem 0x0000000000100000-0x00000000df62cfff]
[    0.000000]   node   0: [mem 0x00000000df635000-0x00000000df66efff]
[    0.000000]   node   0: [mem 0x00000000df6bf000-0x00000000df6e5fff]
[    0.000000]   node   0: [mem 0x00000000df7bf000-0x00000000df7e6fff]
[    0.000000]   node   0: [mem 0x00000000df7f2000-0x00000000df7f2fff]
[    0.000000]   node   0: [mem 0x00000000df7ff000-0x00000000df7fffff]
[    0.000000]   node   0: [mem 0x0000000100000000-0x000000021fffffff]
[    0.000000] Initmem setup node 0 [mem 0x0000000000001000-0x000000021fffffff]
[    0.000000] On node 0 totalpages: 2094662
[    0.000000]   DMA zone: 64 pages used for memmap
[    0.000000]   DMA zone: 21 pages reserved
[    0.000000]   DMA zone: 3982 pages, LIFO batch:0
[    0.000000]   DMA32 zone: 14235 pages used for memmap
[    0.000000]   DMA32 zone: 911032 pages, LIFO batch:31
[    0.000000]   Normal zone: 18432 pages used for memmap
[    0.000000]   Normal zone: 1179648 pages, LIFO batch:31
[    0.000000] ACPI: PM-Timer IO Port: 0x408
[    0.000000] ACPI: LAPIC_NMI (acpi_id[0x00] high level lint[0x1])
[    0.000000] ACPI: LAPIC_NMI (acpi_id[0x01] high level lint[0x1])
[    0.000000] ACPI: LAPIC_NMI (acpi_id[0x02] high level lint[0x1])
[    0.000000] ACPI: LAPIC_NMI (acpi_id[0x03] high level lint[0x1])
[    0.000000] ACPI: LAPIC_NMI (acpi_id[0x04] high level lint[0x1])
[    0.000000] ACPI: LAPIC_NMI (acpi_id[0x05] high level lint[0x1])
[    0.000000] ACPI: LAPIC_NMI (acpi_id[0x06] high level lint[0x1])
[    0.000000] ACPI: LAPIC_NMI (acpi_id[0x07] high level lint[0x1])
[    0.000000] IOAPIC[0]: apic_id 8, version 32, address 0xfec00000, GSI 0-23
[    0.000000] ACPI: INT_SRC_OVR (bus 0 bus_irq 0 global_irq 2 dfl dfl)
[    0.000000] ACPI: INT_SRC_OVR (bus 0 bus_irq 9 global_irq 9 high level)
[    0.000000] ACPI: IRQ0 used by override.
[    0.000000] ACPI: IRQ9 used by override.
[    0.000000] Using ACPI (MADT) for SMP configuration information
[    0.000000] ACPI: HPET id: 0x8086a701 base: 0xfed00000
[    0.000000] smpboot: Allowing 8 CPUs, 0 hotplug CPUs
[    0.000000] PM: Registered nosave memory: [mem 0x00000000-0x00000fff]
[    0.000000] PM: Registered nosave memory: [mem 0x0008f000-0x0009ffff]
[    0.000000] PM: Registered nosave memory: [mem 0x000a0000-0x000dffff]
[    0.000000] PM: Registered nosave memory: [mem 0x000e0000-0x000fffff]
[    0.000000] PM: Registered nosave memory: [mem 0xdf62d000-0xdf634fff]
[    0.000000] PM: Registered nosave memory: [mem 0xdf66f000-0xdf6befff]
[    0.000000] PM: Registered nosave memory: [mem 0xdf6e6000-0xdf7befff]
[    0.000000] PM: Registered nosave memory: [mem 0xdf7e7000-0xdf7f1fff]
[    0.000000] PM: Registered nosave memory: [mem 0xdf7f3000-0xdf7fefff]
[    0.000000] PM: Registered nosave memory: [mem 0xdf800000-0xdfffffff]
[    0.000000] PM: Registered nosave memory: [mem 0xe0000000-0xf7ffffff]
[    0.000000] PM: Registered nosave memory: [mem 0xf8000000-0xffffffff]
[    0.000000] e820: [mem 0xe0000000-0xf7ffffff] available for PCI devices
[    0.000000] Booting paravirtualized kernel on bare hardware
[    0.000000] clocksource: refined-jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645519600211568 ns
[    0.000000] setup_percpu: NR_CPUS:512 nr_cpumask_bits:512 nr_cpu_ids:8 nr_node_ids:1
[    0.000000] PERCPU: Embedded 33 pages/cpu @ffff88021fc00000 s98264 r8192 d28712 u262144
[    0.000000] pcpu-alloc: s98264 r8192 d28712 u262144 alloc=1*2097152
[    0.000000] pcpu-alloc: [0] 0 1 2 3 4 5 6 7
[    0.000000] Built 1 zonelists in Node order, mobility grouping on.  Total pages: 2061910
[    0.000000] Policy zone: Normal
[    0.000000] Kernel command line: BOOT_IMAGE=/boot/vmlinuz-4.4.0-77-generic root=UUID=6907f491-8aa4-4f40-8209-104f92206e25 ro quiet splash vt.handoff=7
[    0.000000] PID hash table entries: 4096 (order: 3, 32768 bytes)
[    0.000000] Calgary: detecting Calgary via BIOS EBDA area
[    0.000000] Calgary: Unable to locate Rio Grande table in EBDA - bailing!
[    0.000000] Memory: 8122196K/8378648K available (8449K kernel code, 1294K rwdata, 3980K rodata, 1484K init, 1316K bss, 256452K reserved, 0K cma-reserved)
[    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=8, Nodes=1
[    0.000000] Hierarchical RCU implementation.
[    0.000000] 	Build-time adjustment of leaf fanout to 64.
[    0.000000] 	RCU restricting CPUs from NR_CPUS=512 to nr_cpu_ids=8.
[    0.000000] RCU: Adjusting geometry for rcu_fanout_leaf=64, nr_cpu_ids=8
[    0.000000] NR_IRQS:33024 nr_irqs:488 16
[    0.000000] vt handoff: transparent VT on vt#7
[    0.000000] Console: colour dummy device 80x25
[    0.000000] console [tty0] enabled
[    0.000000] clocksource: hpet: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 133484882848 ns
[    0.000000] hpet clockevent registered
[    0.000000] tsc: Fast TSC calibration using PIT
[    0.000000] tsc: Detected 2933.480 MHz processor
[    0.000027] Calibrating delay loop (skipped), value calculated using timer frequency.. 5866.96 BogoMIPS (lpj=11733920)
[    0.000030] pid_max: default: 32768 minimum: 301
[    0.000035] ACPI: Core revision 20150930
[    0.007532] ACPI: 2 ACPI AML tables successfully acquired and loaded
[    0.007550] Security Framework initialized
[    0.007552] Yama: becoming mindful.
[    0.007566] AppArmor: AppArmor initialized
[    0.008012] Dentry cache hash table entries: 1048576 (order: 11, 8388608 bytes)
[    0.009419] Inode-cache hash table entries: 524288 (order: 10, 4194304 bytes)
[    0.010055] Mount-cache hash table entries: 16384 (order: 5, 131072 bytes)
[    0.010063] Mountpoint-cache hash table entries: 16384 (order: 5, 131072 bytes)
[    0.010272] Initializing cgroup subsys io
[    0.010275] Initializing cgroup subsys memory
[    0.010281] Initializing cgroup subsys devices
[    0.010284] Initializing cgroup subsys freezer
[    0.010286] Initializing cgroup subsys net_cls
[    0.010287] Initializing cgroup subsys perf_event
[    0.010289] Initializing cgroup subsys net_prio
[    0.010292] Initializing cgroup subsys hugetlb
[    0.010294] Initializing cgroup subsys pids
[    0.010309] CPU: Physical Processor ID: 0
[    0.010310] CPU: Processor Core ID: 0
[    0.010314] mce: CPU supports 9 MCE banks
[    0.010323] CPU0: Thermal monitoring enabled (TM1)
[    0.010328] process: using mwait in idle threads
[    0.010331] Last level iTLB entries: 4KB 512, 2MB 7, 4MB 7
[    0.010332] Last level dTLB entries: 4KB 512, 2MB 32, 4MB 32, 1GB 0
[    0.010589] Freeing SMP alternatives memory: 32K (ffffffff820b8000 - ffffffff820c0000)
[    0.012345] ftrace: allocating 32117 entries in 126 pages
[    0.024724] smpboot: APIC(0) Converting physical 0 to logical package 0
[    0.024725] smpboot: Max logical packages: 2
[    0.025116] ..TIMER: vector=0x30 apic1=0 pin1=2 apic2=-1 pin2=-1
[    0.169439] smpboot: CPU0: Intel(R) Core(TM) i7 CPU         870  @ 2.93GHz (family: 0x6, model: 0x1e, stepping: 0x5)
[    0.169453] Performance Events: PEBS fmt1+, 16-deep LBR, Nehalem events, Intel PMU driver.
[    0.169467] core: CPU erratum AAJ80 worked around
[    0.169468] core: CPUID marked event: 'bus cycles' unavailable
[    0.169470] ... version:                3
[    0.169470] ... bit width:              48
[    0.169471] ... generic registers:      4
[    0.169472] ... value mask:             0000ffffffffffff
[    0.169473] ... max period:             000000007fffffff
[    0.169474] ... fixed-purpose events:   3
[    0.169474] ... event mask:             000000070000000f
[    0.170159] x86: Booting SMP configuration:
[    0.170160] .... node  #0, CPUs:      #1
[    0.172757] NMI watchdog: enabled on all CPUs, permanently consumes one hw-PMU counter.
[    0.172833]  #2
[    0.173330] microcode: CPU2 microcode updated early to revision 0x7, date = 2013-08-20
[    0.175468]  #3
[    0.177841]  #4
[    0.178303] microcode: CPU4 microcode updated early to revision 0x7, date = 2013-08-20
[    0.180438]  #5
[    0.182811]  #6
[    0.183274] microcode: CPU6 microcode updated early to revision 0x7, date = 2013-08-20
[    0.185409]  #7
[    0.187714] x86: Booted up 1 node, 8 CPUs
[    0.187717] smpboot: Total of 8 processors activated (46935.68 BogoMIPS)
[    0.193088] devtmpfs: initialized
[    0.196064] evm: security.selinux
[    0.196066] evm: security.SMACK64
[    0.196066] evm: security.SMACK64EXEC
[    0.196067] evm: security.SMACK64TRANSMUTE
[    0.196068] evm: security.SMACK64MMAP
[    0.196069] evm: security.ima
[    0.196069] evm: security.capability
[    0.196130] PM: Registering ACPI NVS region [mem 0xdf6e6000-0xdf7befff] (888832 bytes)
[    0.196214] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[    0.196227] futex hash table entries: 2048 (order: 5, 131072 bytes)
[    0.196313] pinctrl core: initialized pinctrl subsystem
[    0.196411] RTC time: 10:54:26, date: 05/17/17
[    0.196506] NET: Registered protocol family 16
[    0.205449] cpuidle: using governor ladder
[    0.217445] cpuidle: using governor menu
[    0.217450] PCCT header not found.
[    0.217555] ACPI FADT declares the system doesn't support PCIe ASPM, so disable it
[    0.217557] ACPI: bus type PCI registered
[    0.217558] acpiphp: ACPI Hot Plug PCI Controller Driver version: 0.5
[    0.217622] PCI: MMCONFIG for domain 0000 [bus 00-3f] at [mem 0xf8000000-0xfbffffff] (base 0xf8000000)
[    0.217624] PCI: MMCONFIG at [mem 0xf8000000-0xfbffffff] reserved in E820
[    0.217628] PCI: Using configuration type 1 for base access
[    0.217913] mtrr: your CPUs had inconsistent variable MTRR settings
[    0.217914] mtrr: probably your BIOS does not setup all CPUs.
[    0.217915] mtrr: corrected configuration.
[    0.229794] ACPI: Added _OSI(Module Device)
[    0.229796] ACPI: Added _OSI(Processor Device)
[    0.229797] ACPI: Added _OSI(3.0 _SCP Extensions)
[    0.229798] ACPI: Added _OSI(Processor Aggregator Device)
[    0.234890] ACPI: Interpreter enabled
[    0.234903] ACPI: (supports S0 S3 S4 S5)
[    0.234905] ACPI: Using IOAPIC for interrupt routing
[    0.234921] PCI: Using host bridge windows from ACPI; if necessary, use "pci=nocrs" and report a bug
[    0.238549] ACPI: PCI Root Bridge [PCI0] (domain 0000 [bus 00-3e])
[    0.238554] acpi PNP0A08:00: _OSC: OS supports [ExtendedConfig ASPM ClockPM Segments MSI]
[    0.238662] acpi PNP0A08:00: _OSC: platform does not support [PME]
[    0.238764] acpi PNP0A08:00: _OSC: OS now controls [PCIeHotplug AER PCIeCapability]
[    0.238766] acpi PNP0A08:00: FADT indicates ASPM is unsupported, using BIOS configuration
[    0.238994] PCI host bridge to bus 0000:00
[    0.238996] pci_bus 0000:00: root bus resource [io  0x0000-0x0cf7 window]
[    0.238998] pci_bus 0000:00: root bus resource [io  0x0d00-0xffff window]
[    0.238999] pci_bus 0000:00: root bus resource [mem 0x000a0000-0x000bffff window]
[    0.239001] pci_bus 0000:00: root bus resource [mem 0xe0000000-0xf7ffffff window]
[    0.239003] pci_bus 0000:00: root bus resource [bus 00-3e]
[    0.239010] pci 0000:00:00.0: [8086:d131] type 00 class 0x060000
[    0.239110] pci 0000:00:03.0: [8086:d138] type 01 class 0x060400
[    0.239155] pci 0000:00:03.0: PME# supported from D0 D3hot D3cold
[    0.239198] pci 0000:00:03.0: System wakeup disabled by ACPI
[    0.239232] pci 0000:00:08.0: [8086:d155] type 00 class 0x088000
[    0.239326] pci 0000:00:08.1: [8086:d156] type 00 class 0x088000
[    0.239418] pci 0000:00:08.2: [8086:d157] type 00 class 0x088000
[    0.239506] pci 0000:00:08.3: [8086:d158] type 00 class 0x088000
[    0.239591] pci 0000:00:10.0: [8086:d150] type 00 class 0x088000
[    0.239669] pci 0000:00:10.1: [8086:d151] type 00 class 0x088000
[    0.239767] pci 0000:00:19.0: [8086:10f0] type 00 class 0x020000
[    0.239790] pci 0000:00:19.0: reg 0x10: [mem 0xf3100000-0xf311ffff]
[    0.239797] pci 0000:00:19.0: reg 0x14: [mem 0xf3124000-0xf3124fff]
[    0.239805] pci 0000:00:19.0: reg 0x18: [io  0x2100-0x211f]
[    0.239849] pci 0000:00:19.0: PME# supported from D0 D3hot D3cold
[    0.239887] pci 0000:00:19.0: System wakeup disabled by ACPI
[    0.239924] pci 0000:00:1a.0: [8086:3b3b] type 00 class 0x0c0300
[    0.239998] pci 0000:00:1a.0: reg 0x20: [io  0x20e0-0x20ff]
[    0.240102] pci 0000:00:1a.0: System wakeup disabled by ACPI
[    0.240141] pci 0000:00:1a.1: [8086:3b3e] type 00 class 0x0c0300
[    0.240207] pci 0000:00:1a.1: reg 0x20: [io  0x20c0-0x20df]
[    0.240303] pci 0000:00:1a.1: System wakeup disabled by ACPI
[    0.240340] pci 0000:00:1a.2: [8086:3b3f] type 00 class 0x0c0300
[    0.240410] pci 0000:00:1a.2: reg 0x20: [io  0x20a0-0x20bf]
[    0.240505] pci 0000:00:1a.2: System wakeup disabled by ACPI
[    0.240545] pci 0000:00:1a.7: [8086:3b3c] type 00 class 0x0c0320
[    0.241401] pci 0000:00:1a.7: reg 0x10: [mem 0xf3125400-0xf31257ff]
[    0.245918] pci 0000:00:1a.7: PME# supported from D0 D3hot D3cold
[    0.245976] pci 0000:00:1a.7: System wakeup disabled by ACPI
[    0.246017] pci 0000:00:1b.0: [8086:3b56] type 00 class 0x040300
[    0.246041] pci 0000:00:1b.0: reg 0x10: [mem 0xf3120000-0xf3123fff 64bit]
[    0.246097] pci 0000:00:1b.0: PME# supported from D0 D3hot D3cold
[    0.246152] pci 0000:00:1b.0: System wakeup disabled by ACPI
[    0.246188] pci 0000:00:1c.0: [8086:3b42] type 01 class 0x060400
[    0.246244] pci 0000:00:1c.0: PME# supported from D0 D3hot D3cold
[    0.246286] pci 0000:00:1c.0: System wakeup disabled by ACPI
[    0.246327] pci 0000:00:1d.0: [8086:3b36] type 00 class 0x0c0300
[    0.246390] pci 0000:00:1d.0: reg 0x20: [io  0x2080-0x209f]
[    0.246490] pci 0000:00:1d.0: System wakeup disabled by ACPI
[    0.246528] pci 0000:00:1d.1: [8086:3b37] type 00 class 0x0c0300
[    0.246597] pci 0000:00:1d.1: reg 0x20: [io  0x2060-0x207f]
[    0.246692] pci 0000:00:1d.1: System wakeup disabled by ACPI
[    0.246726] pci 0000:00:1d.2: [8086:3b38] type 00 class 0x0c0300
[    0.246781] pci 0000:00:1d.2: reg 0x20: [io  0x2040-0x205f]
[    0.246878] pci 0000:00:1d.2: System wakeup disabled by ACPI
[    0.246915] pci 0000:00:1d.3: [8086:3b39] type 00 class 0x0c0300
[    0.246984] pci 0000:00:1d.3: reg 0x20: [io  0x2020-0x203f]
[    0.247081] pci 0000:00:1d.3: System wakeup disabled by ACPI
[    0.247120] pci 0000:00:1d.7: [8086:3b34] type 00 class 0x0c0320
[    0.247915] pci 0000:00:1d.7: reg 0x10: [mem 0xf3125000-0xf31253ff]
[    0.252285] pci 0000:00:1d.7: PME# supported from D0 D3hot D3cold
[    0.252345] pci 0000:00:1d.7: System wakeup disabled by ACPI
[    0.252379] pci 0000:00:1e.0: [8086:244e] type 01 class 0x060401
[    0.252456] pci 0000:00:1e.0: System wakeup disabled by ACPI
[    0.252491] pci 0000:00:1f.0: [8086:3b02] type 00 class 0x060100
[    0.252649] pci 0000:00:1f.2: [8086:3b20] type 00 class 0x01018f
[    0.252667] pci 0000:00:1f.2: reg 0x10: [io  0x2178-0x217f]
[    0.252674] pci 0000:00:1f.2: reg 0x14: [io  0x218c-0x218f]
[    0.252680] pci 0000:00:1f.2: reg 0x18: [io  0x2170-0x2177]
[    0.252687] pci 0000:00:1f.2: reg 0x1c: [io  0x2188-0x218b]
[    0.252694] pci 0000:00:1f.2: reg 0x20: [io  0x2150-0x215f]
[    0.252700] pci 0000:00:1f.2: reg 0x24: [io  0x2140-0x214f]
[    0.252787] pci 0000:00:1f.3: [8086:3b30] type 00 class 0x0c0500
[    0.252802] pci 0000:00:1f.3: reg 0x10: [mem 0xf3125800-0xf31258ff 64bit]
[    0.252820] pci 0000:00:1f.3: reg 0x20: [io  0x2000-0x201f]
[    0.252895] pci 0000:00:1f.5: [8086:3b26] type 00 class 0x010185
[    0.252913] pci 0000:00:1f.5: reg 0x10: [io  0x2168-0x216f]
[    0.252919] pci 0000:00:1f.5: reg 0x14: [io  0x2184-0x2187]
[    0.252926] pci 0000:00:1f.5: reg 0x18: [io  0x2160-0x2167]
[    0.252933] pci 0000:00:1f.5: reg 0x1c: [io  0x2180-0x2183]
[    0.252939] pci 0000:00:1f.5: reg 0x20: [io  0x2130-0x213f]
[    0.252946] pci 0000:00:1f.5: reg 0x24: [io  0x2120-0x212f]
[    0.253062] pci 0000:01:00.0: [10de:0640] type 00 class 0x030000
[    0.253080] pci 0000:01:00.0: reg 0x10: [mem 0xf2000000-0xf2ffffff]
[    0.253090] pci 0000:01:00.0: reg 0x14: [mem 0xe0000000-0xefffffff 64bit pref]
[    0.253099] pci 0000:01:00.0: reg 0x1c: [mem 0xf0000000-0xf1ffffff 64bit]
[    0.253105] pci 0000:01:00.0: reg 0x24: [io  0x1000-0x107f]
[    0.253112] pci 0000:01:00.0: reg 0x30: [mem 0xfff80000-0xffffffff pref]
[    0.257465] pci 0000:00:03.0: PCI bridge to [bus 01]
[    0.257471] pci 0000:00:03.0:   bridge window [io  0x1000-0x1fff]
[    0.257476] pci 0000:00:03.0:   bridge window [mem 0xf0000000-0xf2ffffff]
[    0.257483] pci 0000:00:03.0:   bridge window [mem 0xe0000000-0xefffffff 64bit pref]
[    0.257553] pci 0000:00:1c.0: PCI bridge to [bus 02]
[    0.257595] pci 0000:03:03.0: [104c:8023] type 00 class 0x0c0010
[    0.257616] pci 0000:03:03.0: reg 0x10: [mem 0xf3004000-0xf30047ff]
[    0.257625] pci 0000:03:03.0: reg 0x14: [mem 0xf3000000-0xf3003fff]
[    0.257684] pci 0000:03:03.0: supports D1 D2
[    0.257685] pci 0000:03:03.0: PME# supported from D0 D1 D2 D3hot
[    0.257752] pci 0000:00:1e.0: PCI bridge to [bus 03] (subtractive decode)
[    0.257761] pci 0000:00:1e.0:   bridge window [mem 0xf3000000-0xf30fffff]
[    0.257766] pci 0000:00:1e.0:   bridge window [io  0x0000-0x0cf7 window] (subtractive decode)
[    0.257768] pci 0000:00:1e.0:   bridge window [io  0x0d00-0xffff window] (subtractive decode)
[    0.257769] pci 0000:00:1e.0:   bridge window [mem 0x000a0000-0x000bffff window] (subtractive decode)
[    0.257771] pci 0000:00:1e.0:   bridge window [mem 0xe0000000-0xf7ffffff window] (subtractive decode)
[    0.257839] ACPI: PCI Interrupt Link [LNKA] (IRQs 3 4 5 7 9 10 *11 12)
[    0.257888] ACPI: PCI Interrupt Link [LNKB] (IRQs 3 4 5 7 9 10 11 12) *0, disabled.
[    0.257936] ACPI: PCI Interrupt Link [LNKC] (IRQs 3 4 5 7 *9 10 11 12)
[    0.257984] ACPI: PCI Interrupt Link [LNKD] (IRQs 3 4 5 7 *9 10 11 12)
[    0.258031] ACPI: PCI Interrupt Link [LNKE] (IRQs 3 4 5 7 9 *10 11 12)
[    0.258079] ACPI: PCI Interrupt Link [LNKF] (IRQs 3 4 5 7 9 10 *11 12)
[    0.258126] ACPI: PCI Interrupt Link [LNKG] (IRQs 3 4 5 7 9 *10 11 12)
[    0.258174] ACPI: PCI Interrupt Link [LNKH] (IRQs 3 4 5 7 9 10 *11 12)
[    0.258408] ACPI: Enabled 2 GPEs in block 00 to 3F
[    0.258508] vgaarb: setting as boot device: PCI:0000:01:00.0
[    0.258510] vgaarb: device added: PCI:0000:01:00.0,decodes=io+mem,owns=io+mem,locks=none
[    0.258511] vgaarb: loaded
[    0.258512] vgaarb: bridge control possible 0000:01:00.0
[    0.258695] SCSI subsystem initialized
[    0.258726] libata version 3.00 loaded.
[    0.258745] ACPI: bus type USB registered
[    0.258759] usbcore: registered new interface driver usbfs
[    0.258767] usbcore: registered new interface driver hub
[    0.258786] usbcore: registered new device driver usb
[    0.258899] PCI: Using ACPI for IRQ routing
[    0.260249] PCI: Discovered peer bus 3f
[    0.260250] PCI: root bus 3f: using default resources
[    0.260251] PCI: Probing PCI hardware (bus 3f)
[    0.260276] ACPI: \: failed to evaluate _DSM (0x1001)
[    0.260277] PCI host bridge to bus 0000:3f
[    0.260279] pci_bus 0000:3f: root bus resource [io  0x0000-0xffff]
[    0.260281] pci_bus 0000:3f: root bus resource [mem 0x00000000-0xfffffffff]
[    0.260282] pci_bus 0000:3f: No busn resource found for root bus, will use [bus 3f-ff]
[    0.260287] pci 0000:3f:00.0: [8086:2c51] type 00 class 0x060000
[    0.260324] pci 0000:3f:00.1: [8086:2c81] type 00 class 0x060000
[    0.260361] pci 0000:3f:02.0: [8086:2c90] type 00 class 0x060000
[    0.260396] pci 0000:3f:02.1: [8086:2c91] type 00 class 0x060000
[    0.260432] pci 0000:3f:03.0: [8086:2c98] type 00 class 0x060000
[    0.260467] pci 0000:3f:03.1: [8086:2c99] type 00 class 0x060000
[    0.260502] pci 0000:3f:03.4: [8086:2c9c] type 00 class 0x060000
[    0.260537] pci 0000:3f:04.0: [8086:2ca0] type 00 class 0x060000
[    0.260572] pci 0000:3f:04.1: [8086:2ca1] type 00 class 0x060000
[    0.260607] pci 0000:3f:04.2: [8086:2ca2] type 00 class 0x060000
[    0.260645] pci 0000:3f:04.3: [8086:2ca3] type 00 class 0x060000
[    0.260681] pci 0000:3f:05.0: [8086:2ca8] type 00 class 0x060000
[    0.260716] pci 0000:3f:05.1: [8086:2ca9] type 00 class 0x060000
[    0.260751] pci 0000:3f:05.2: [8086:2caa] type 00 class 0x060000
[    0.260785] pci 0000:3f:05.3: [8086:2cab] type 00 class 0x060000
[    0.260829] pci_bus 0000:3f: busn_res: [bus 3f-ff] end is updated to 3f
[    0.260833] PCI: pci_cache_line_size set to 64 bytes
[    0.260899] e820: reserve RAM buffer [mem 0x0008f000-0x0008ffff]
[    0.260900] e820: reserve RAM buffer [mem 0xdf62d000-0xdfffffff]
[    0.260901] e820: reserve RAM buffer [mem 0xdf66f000-0xdfffffff]
[    0.260903] e820: reserve RAM buffer [mem 0xdf6e6000-0xdfffffff]
[    0.260904] e820: reserve RAM buffer [mem 0xdf7e7000-0xdfffffff]
[    0.260905] e820: reserve RAM buffer [mem 0xdf7f3000-0xdfffffff]
[    0.260906] e820: reserve RAM buffer [mem 0xdf800000-0xdfffffff]
[    0.261002] NetLabel: Initializing
[    0.261003] NetLabel:  domain hash size = 128
[    0.261004] NetLabel:  protocols = UNLABELED CIPSOv4
[    0.261017] NetLabel:  unlabeled traffic allowed by default
[    0.261095] HPET: 8 timers in total, 5 timers will be used for per-cpu timer
[    0.261102] hpet0: at MMIO 0xfed00000, IRQs 2, 8, 24, 25, 26, 27, 28, 0
[    0.261106] hpet0: 8 comparators, 64-bit 14.318180 MHz counter
[    0.263140] hpet: hpet2 irq 24 for MSI
[    0.263171] hpet: hpet3 irq 25 for MSI
[    0.263200] hpet: hpet4 irq 26 for MSI
[    0.263232] hpet: hpet5 irq 27 for MSI
[    0.263268] hpet: hpet6 irq 28 for MSI
[    0.263337] amd_nb: Cannot enumerate AMD northbridges
[    0.263350] clocksource: Switched to clocksource hpet
[    0.268517] AppArmor: AppArmor Filesystem Enabled
[    0.268573] pnp: PnP ACPI init
[    0.268661] system 00:00: [mem 0xf8000000-0xffffffff] could not be reserved
[    0.268665] system 00:00: Plug and Play ACPI device, IDs PNP0c02 (active)
[    0.268795] pnp 00:01: Plug and Play ACPI device, IDs PNP0b00 (active)
[    0.268844] system 00:02: [io  0x0500-0x057f] has been reserved
[    0.268846] system 00:02: [io  0x0400-0x047f] could not be reserved
[    0.268848] system 00:02: [io  0x0680-0x06ff] has been reserved
[    0.268851] system 00:02: Plug and Play ACPI device, IDs PNP0c02 (active)
[    0.268912] system 00:03: Plug and Play ACPI device, IDs PNP0c02 (active)
[    0.268977] pnp: PnP ACPI: found 4 devices
[    0.275146] clocksource: acpi_pm: mask: 0xffffff max_cycles: 0xffffff, max_idle_ns: 2085701024 ns
[    0.275152] pci 0000:01:00.0: can't claim BAR 6 [mem 0xfff80000-0xffffffff pref]: no compatible bridge window
[    0.275167] pci 0000:00:1c.0: bridge window [io  0x1000-0x0fff] to [bus 02] add_size 1000
[    0.275169] pci 0000:00:1c.0: bridge window [mem 0x00100000-0x000fffff 64bit pref] to [bus 02] add_size 200000 add_align 100000
[    0.275172] pci 0000:00:1c.0: bridge window [mem 0x00100000-0x000fffff] to [bus 02] add_size 200000 add_align 100000
[    0.275182] pci 0000:00:1c.0: res[14]=[mem 0x00100000-0x000fffff] res_to_dev_res add_size 200000 min_align 100000
[    0.275184] pci 0000:00:1c.0: res[14]=[mem 0x00100000-0x002fffff] res_to_dev_res add_size 200000 min_align 100000
[    0.275186] pci 0000:00:1c.0: res[15]=[mem 0x00100000-0x000fffff 64bit pref] res_to_dev_res add_size 200000 min_align 100000
[    0.275187] pci 0000:00:1c.0: res[15]=[mem 0x00100000-0x002fffff 64bit pref] res_to_dev_res add_size 200000 min_align 100000
[    0.275189] pci 0000:00:1c.0: res[13]=[io  0x1000-0x0fff] res_to_dev_res add_size 1000 min_align 1000
[    0.275191] pci 0000:00:1c.0: res[13]=[io  0x1000-0x1fff] res_to_dev_res add_size 1000 min_align 1000
[    0.275195] pci 0000:00:1c.0: BAR 14: assigned [mem 0xf3200000-0xf33fffff]
[    0.275198] pci 0000:00:1c.0: BAR 15: assigned [mem 0xf3400000-0xf35fffff 64bit pref]
[    0.275200] pci 0000:00:1c.0: BAR 13: assigned [io  0x3000-0x3fff]
[    0.275203] pci 0000:01:00.0: BAR 6: no space for [mem size 0x00080000 pref]
[    0.275205] pci 0000:01:00.0: BAR 6: failed to assign [mem size 0x00080000 pref]
[    0.275207] pci 0000:00:03.0: PCI bridge to [bus 01]
[    0.275209] pci 0000:00:03.0:   bridge window [io  0x1000-0x1fff]
[    0.275212] pci 0000:00:03.0:   bridge window [mem 0xf0000000-0xf2ffffff]
[    0.275214] pci 0000:00:03.0:   bridge window [mem 0xe0000000-0xefffffff 64bit pref]
[    0.275218] pci 0000:00:1c.0: PCI bridge to [bus 02]
[    0.275221] pci 0000:00:1c.0:   bridge window [io  0x3000-0x3fff]
[    0.275224] pci 0000:00:1c.0:   bridge window [mem 0xf3200000-0xf33fffff]
[    0.275227] pci 0000:00:1c.0:   bridge window [mem 0xf3400000-0xf35fffff 64bit pref]
[    0.275232] pci 0000:00:1e.0: PCI bridge to [bus 03]
[    0.275236] pci 0000:00:1e.0:   bridge window [mem 0xf3000000-0xf30fffff]
[    0.275243] pci_bus 0000:00: resource 4 [io  0x0000-0x0cf7 window]
[    0.275244] pci_bus 0000:00: resource 5 [io  0x0d00-0xffff window]
[    0.275246] pci_bus 0000:00: resource 6 [mem 0x000a0000-0x000bffff window]
[    0.275247] pci_bus 0000:00: resource 7 [mem 0xe0000000-0xf7ffffff window]
[    0.275249] pci_bus 0000:01: resource 0 [io  0x1000-0x1fff]
[    0.275250] pci_bus 0000:01: resource 1 [mem 0xf0000000-0xf2ffffff]
[    0.275251] pci_bus 0000:01: resource 2 [mem 0xe0000000-0xefffffff 64bit pref]
[    0.275253] pci_bus 0000:02: resource 0 [io  0x3000-0x3fff]
[    0.275254] pci_bus 0000:02: resource 1 [mem 0xf3200000-0xf33fffff]
[    0.275256] pci_bus 0000:02: resource 2 [mem 0xf3400000-0xf35fffff 64bit pref]
[    0.275257] pci_bus 0000:03: resource 1 [mem 0xf3000000-0xf30fffff]
[    0.275259] pci_bus 0000:03: resource 4 [io  0x0000-0x0cf7 window]
[    0.275260] pci_bus 0000:03: resource 5 [io  0x0d00-0xffff window]
[    0.275262] pci_bus 0000:03: resource 6 [mem 0x000a0000-0x000bffff window]
[    0.275263] pci_bus 0000:03: resource 7 [mem 0xe0000000-0xf7ffffff window]
[    0.275266] pci_bus 0000:3f: resource 4 [io  0x0000-0xffff]
[    0.275267] pci_bus 0000:3f: resource 5 [mem 0x00000000-0xfffffffff]
[    0.275297] NET: Registered protocol family 2
[    0.275456] TCP established hash table entries: 65536 (order: 7, 524288 bytes)
[    0.275632] TCP bind hash table entries: 65536 (order: 8, 1048576 bytes)
[    0.275886] TCP: Hash tables configured (established 65536 bind 65536)
[    0.275912] UDP hash table entries: 4096 (order: 5, 131072 bytes)
[    0.275964] UDP-Lite hash table entries: 4096 (order: 5, 131072 bytes)
[    0.276045] NET: Registered protocol family 1
[    0.307618] pci 0000:01:00.0: Video device with shadowed ROM
[    0.307640] PCI: CLS 64 bytes, default 64
[    0.307680] Unpacking initramfs...
[    0.870303] Freeing initrd memory: 39392K (ffff880033300000 - ffff880035978000)
[    0.870324] PCI-DMA: Using software bounce buffering for IO (SWIOTLB)
[    0.870326] software IO TLB [mem 0xdb62d000-0xdf62d000] (64MB) mapped at [ffff8800db62d000-ffff8800df62cfff]
[    0.870509] Scanning for low memory corruption every 60 seconds
[    0.870910] audit: initializing netlink subsys (disabled)
[    0.870923] audit: type=2000 audit(1495018466.764:1): initialized
[    0.871238] Initialise system trusted keyring
[    0.871399] HugeTLB registered 2 MB page size, pre-allocated 0 pages
[    0.872698] zbud: loaded
[    0.872886] VFS: Disk quotas dquot_6.6.0
[    0.872917] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[    0.873151] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[    0.873390] fuse init (API version 7.23)
[    0.873514] Key type big_key registered
[    0.873529] Allocating IMA MOK and blacklist keyrings.
[    0.874194] Key type asymmetric registered
[    0.874197] Asymmetric key parser 'x509' registered
[    0.874230] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 249)
[    0.874273] io scheduler noop registered
[    0.874275] io scheduler deadline registered (default)
[    0.874302] io scheduler cfq registered
[    0.874642] pcieport 0000:00:1c.0: enabling device (0000 -> 0003)
[    0.874917] aer 0000:00:03.0:pcie02: service driver aer loaded
[    0.874929] pci_hotplug: PCI Hot Plug PCI Core version: 0.5
[    0.874943] pciehp 0000:00:1c.0:pcie04: Slot #0 AttnBtn- PwrCtrl- MRL- AttnInd- PwrInd- HotPlug+ Surprise+ Interlock- NoCompl+ LLActRep+
[    0.874996] pciehp 0000:00:1c.0:pcie04: service driver pciehp loaded
[    0.875000] pciehp: PCI Express Hot Plug Controller Driver version: 0.4
[    0.875028] vesafb: mode is 640x480x32, linelength=2560, pages=0
[    0.875029] vesafb: scrolling: redraw
[    0.875030] vesafb: Truecolor: size=8:8:8:8, shift=24:16:8:0
[    0.875040] vesafb: framebuffer at 0xf1000000, mapped to 0xffffc90001000000, using 1216k, total 1216k
[    0.875115] Console: switching to colour frame buffer device 80x30
[    0.875125] fb0: VESA VGA frame buffer device
[    0.875138] intel_idle: MWAIT substates: 0x1120
[    0.875152] intel_idle: v0.4.1 model 0x1E
[    0.875152] intel_idle: lapic_timer_reliable_states 0x2
[    0.875521] input: Sleep Button as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0E:00/input/input0
[    0.875524] ACPI: Sleep Button [SLPB]
[    0.875560] input: Power Button as /devices/LNXSYSTM:00/LNXPWRBN:00/input/input1
[    0.875562] ACPI: Power Button [PWRF]
[    0.876415] GHES: HEST is not enabled!
[    0.876501] Serial: 8250/16550 driver, 32 ports, IRQ sharing enabled
[    0.878086] Linux agpgart interface v0.103
[    0.881961] loop: module loaded
[    0.882085] ata_piix 0000:00:1f.2: version 2.13
[    0.882264] ata_piix 0000:00:1f.2: MAP [ P0 P2 P1 P3 ]
[    0.882787] scsi host0: ata_piix
[    0.883154] scsi host1: ata_piix
[    0.883257] ata1: SATA max UDMA/133 cmd 0x2178 ctl 0x218c bmdma 0x2150 irq 19
[    0.883266] ata2: SATA max UDMA/133 cmd 0x2170 ctl 0x2188 bmdma 0x2158 irq 19
[    0.883514] ata_piix 0000:00:1f.5: MAP [ P0 -- P1 -- ]
[    0.884026] scsi host2: ata_piix
[    0.884405] scsi host3: ata_piix
[    0.884500] ata3: SATA max UDMA/133 cmd 0x2168 ctl 0x2184 bmdma 0x2130 irq 19
[    0.884509] ata4: SATA max UDMA/133 cmd 0x2160 ctl 0x2180 bmdma 0x2138 irq 19
[    0.884586] libphy: Fixed MDIO Bus: probed
[    0.884589] tun: Universal TUN/TAP device driver, 1.6
[    0.884590] tun: (C) 1999-2004 Max Krasnyansky <maxk@qualcomm.com>
[    0.884750] PPP generic driver version 2.4.2
[    0.884893] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[    0.884903] ehci-pci: EHCI PCI platform driver
[    0.885136] ehci-pci 0000:00:1a.7: EHCI Host Controller
[    0.885141] ehci-pci 0000:00:1a.7: new USB bus registered, assigned bus number 1
[    0.885153] ehci-pci 0000:00:1a.7: debug port 2
[    0.889081] ehci-pci 0000:00:1a.7: cache line size of 64 is not supported
[    0.889090] ehci-pci 0000:00:1a.7: irq 16, io mem 0xf3125400
[    0.899599] ehci-pci 0000:00:1a.7: USB 2.0 started, EHCI 1.00
[    0.899668] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[    0.899672] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    0.899676] usb usb1: Product: EHCI Host Controller
[    0.899679] usb usb1: Manufacturer: Linux 4.4.0-77-generic ehci_hcd
[    0.899682] usb usb1: SerialNumber: 0000:00:1a.7
[    0.899974] hub 1-0:1.0: USB hub found
[    0.899981] hub 1-0:1.0: 6 ports detected
[    0.900325] ehci-pci 0000:00:1d.7: EHCI Host Controller
[    0.900330] ehci-pci 0000:00:1d.7: new USB bus registered, assigned bus number 2
[    0.900341] ehci-pci 0000:00:1d.7: debug port 2
[    0.904273] ehci-pci 0000:00:1d.7: cache line size of 64 is not supported
[    0.904284] ehci-pci 0000:00:1d.7: irq 23, io mem 0xf3125000
[    0.915545] ehci-pci 0000:00:1d.7: USB 2.0 started, EHCI 1.00
[    0.915608] usb usb2: New USB device found, idVendor=1d6b, idProduct=0002
[    0.915612] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    0.915616] usb usb2: Product: EHCI Host Controller
[    0.915619] usb usb2: Manufacturer: Linux 4.4.0-77-generic ehci_hcd
[    0.915622] usb usb2: SerialNumber: 0000:00:1d.7
[    0.915960] hub 2-0:1.0: USB hub found
[    0.915972] hub 2-0:1.0: 8 ports detected
[    0.916164] ehci-platform: EHCI generic platform driver
[    0.916172] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[    0.916176] ohci-pci: OHCI PCI platform driver
[    0.916186] ohci-platform: OHCI generic platform driver
[    0.916192] uhci_hcd: USB Universal Host Controller Interface driver
[    0.916382] uhci_hcd 0000:00:1a.0: UHCI Host Controller
[    0.916387] uhci_hcd 0000:00:1a.0: new USB bus registered, assigned bus number 3
[    0.916396] uhci_hcd 0000:00:1a.0: detected 2 ports
[    0.916428] uhci_hcd 0000:00:1a.0: irq 21, io base 0x000020e0
[    0.916466] usb usb3: New USB device found, idVendor=1d6b, idProduct=0001
[    0.916467] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    0.916469] usb usb3: Product: UHCI Host Controller
[    0.916470] usb usb3: Manufacturer: Linux 4.4.0-77-generic uhci_hcd
[    0.916471] usb usb3: SerialNumber: 0000:00:1a.0
[    0.916803] hub 3-0:1.0: USB hub found
[    0.916815] hub 3-0:1.0: 2 ports detected
[    0.917082] uhci_hcd 0000:00:1a.1: UHCI Host Controller
[    0.917087] uhci_hcd 0000:00:1a.1: new USB bus registered, assigned bus number 4
[    0.917096] uhci_hcd 0000:00:1a.1: detected 2 ports
[    0.917125] uhci_hcd 0000:00:1a.1: irq 18, io base 0x000020c0
[    0.917164] usb usb4: New USB device found, idVendor=1d6b, idProduct=0001
[    0.917165] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    0.917167] usb usb4: Product: UHCI Host Controller
[    0.917168] usb usb4: Manufacturer: Linux 4.4.0-77-generic uhci_hcd
[    0.917169] usb usb4: SerialNumber: 0000:00:1a.1
[    0.917489] hub 4-0:1.0: USB hub found
[    0.917502] hub 4-0:1.0: 2 ports detected
[    0.917765] uhci_hcd 0000:00:1a.2: UHCI Host Controller
[    0.917769] uhci_hcd 0000:00:1a.2: new USB bus registered, assigned bus number 5
[    0.917780] uhci_hcd 0000:00:1a.2: detected 2 ports
[    0.917805] uhci_hcd 0000:00:1a.2: irq 19, io base 0x000020a0
[    0.917842] usb usb5: New USB device found, idVendor=1d6b, idProduct=0001
[    0.917844] usb usb5: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    0.917845] usb usb5: Product: UHCI Host Controller
[    0.917846] usb usb5: Manufacturer: Linux 4.4.0-77-generic uhci_hcd
[    0.917848] usb usb5: SerialNumber: 0000:00:1a.2
[    0.918065] hub 5-0:1.0: USB hub found
[    0.918079] hub 5-0:1.0: 2 ports detected
[    0.918348] uhci_hcd 0000:00:1d.0: UHCI Host Controller
[    0.918354] uhci_hcd 0000:00:1d.0: new USB bus registered, assigned bus number 6
[    0.918363] uhci_hcd 0000:00:1d.0: detected 2 ports
[    0.918388] uhci_hcd 0000:00:1d.0: irq 19, io base 0x00002080
[    0.918425] usb usb6: New USB device found, idVendor=1d6b, idProduct=0001
[    0.918426] usb usb6: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    0.918428] usb usb6: Product: UHCI Host Controller
[    0.918429] usb usb6: Manufacturer: Linux 4.4.0-77-generic uhci_hcd
[    0.918430] usb usb6: SerialNumber: 0000:00:1d.0
[    0.918657] hub 6-0:1.0: USB hub found
[    0.918671] hub 6-0:1.0: 2 ports detected
[    0.918946] uhci_hcd 0000:00:1d.1: UHCI Host Controller
[    0.918950] uhci_hcd 0000:00:1d.1: new USB bus registered, assigned bus number 7
[    0.918960] uhci_hcd 0000:00:1d.1: detected 2 ports
[    0.918984] uhci_hcd 0000:00:1d.1: irq 16, io base 0x00002060
[    0.919020] usb usb7: New USB device found, idVendor=1d6b, idProduct=0001
[    0.919022] usb usb7: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    0.919023] usb usb7: Product: UHCI Host Controller
[    0.919025] usb usb7: Manufacturer: Linux 4.4.0-77-generic uhci_hcd
[    0.919026] usb usb7: SerialNumber: 0000:00:1d.1
[    0.919245] hub 7-0:1.0: USB hub found
[    0.919260] hub 7-0:1.0: 2 ports detected
[    0.919610] uhci_hcd 0000:00:1d.2: UHCI Host Controller
[    0.919615] uhci_hcd 0000:00:1d.2: new USB bus registered, assigned bus number 8
[    0.919625] uhci_hcd 0000:00:1d.2: detected 2 ports
[    0.919649] uhci_hcd 0000:00:1d.2: irq 18, io base 0x00002040
[    0.919690] usb usb8: New USB device found, idVendor=1d6b, idProduct=0001
[    0.919692] usb usb8: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    0.919693] usb usb8: Product: UHCI Host Controller
[    0.919694] usb usb8: Manufacturer: Linux 4.4.0-77-generic uhci_hcd
[    0.919696] usb usb8: SerialNumber: 0000:00:1d.2
[    0.920011] hub 8-0:1.0: USB hub found
[    0.920022] hub 8-0:1.0: 2 ports detected
[    0.920279] uhci_hcd 0000:00:1d.3: UHCI Host Controller
[    0.920283] uhci_hcd 0000:00:1d.3: new USB bus registered, assigned bus number 9
[    0.920293] uhci_hcd 0000:00:1d.3: detected 2 ports
[    0.920318] uhci_hcd 0000:00:1d.3: irq 23, io base 0x00002020
[    0.920356] usb usb9: New USB device found, idVendor=1d6b, idProduct=0001
[    0.920357] usb usb9: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    0.920359] usb usb9: Product: UHCI Host Controller
[    0.920360] usb usb9: Manufacturer: Linux 4.4.0-77-generic uhci_hcd
[    0.920361] usb usb9: SerialNumber: 0000:00:1d.3
[    0.920664] hub 9-0:1.0: USB hub found
[    0.920679] hub 9-0:1.0: 2 ports detected
[    0.920796] i8042: PNP: No PS/2 controller found. Probing ports directly.
[    1.218370] ata3: SATA link down (SStatus 0 SControl 300)
[    1.371516] ata4: SATA link up 3.0 Gbps (SStatus 123 SControl 300)
[    1.379934] ata4.00: ATA-8: ST2000DM001-9YN164, CC4C, max UDMA/133
[    1.379937] ata4.00: 3907029168 sectors, multi 16: LBA48 NCQ (depth 0/32)
[    1.395940] ata4.00: configured for UDMA/133
[    1.679501] usb 2-3: new high-speed USB device number 2 using ehci-pci
[    1.683555] ata1.00: SATA link up 3.0 Gbps (SStatus 123 SControl 300)
[    1.683570] ata1.01: SATA link down (SStatus 0 SControl 300)
[    1.692545] ata1.00: ATA-8: WDC WD6400AAKS-00E4A0, 05.01D05, max UDMA/133
[    1.692548] ata1.00: 1250263728 sectors, multi 16: LBA48 NCQ (depth 0/32)
[    1.700563] ata1.00: configured for UDMA/133
[    1.701035] scsi 0:0:0:0: Direct-Access     ATA      WDC WD6400AAKS-0 1D05 PQ: 0 ANSI: 5
[    1.701499] sd 0:0:0:0: Attached scsi generic sg0 type 0
[    1.701543] sd 0:0:0:0: [sda] 1250263728 512-byte logical blocks: (640 GB/596 GiB)
[    1.701810] sd 0:0:0:0: [sda] Write Protect is off
[    1.701813] sd 0:0:0:0: [sda] Mode Sense: 00 3a 00 00
[    1.701954] sd 0:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[    1.741125]  sda: sda1 sda2 sda3 sda4 < sda5 sda6 >
[    1.742271] sd 0:0:0:0: [sda] Attached SCSI disk
[    1.807475] usb 3-2: new low-speed USB device number 2 using uhci_hcd
[    1.814612] usb 2-3: New USB device found, idVendor=058f, idProduct=6364
[    1.814614] usb 2-3: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[    1.814616] usb 2-3: Product: Mass Storage Device
[    1.814617] usb 2-3: Manufacturer: Generic
[    1.814619] usb 2-3: SerialNumber: 058F63646476
[    2.015033] i8042: No controller found
[    2.015045] tsc: Refined TSC clocksource calibration: 2933.435 MHz
[    2.015047] clocksource: tsc: mask: 0xffffffffffffffff max_cycles: 0x2a48a423a57, max_idle_ns: 440795322270 ns
[    2.015520] mousedev: PS/2 mouse device common for all mice
[    2.016328] rtc_cmos 00:01: RTC can wake from S4
[    2.016642] rtc_cmos 00:01: rtc core: registered rtc_cmos as rtc0
[    2.016685] rtc_cmos 00:01: alarms up to one month, y3k, 114 bytes nvram, hpet irqs
[    2.016704] i2c /dev entries driver
[    2.016769] device-mapper: uevent: version 1.0.3
[    2.016984] device-mapper: ioctl: 4.34.0-ioctl (2015-10-28) initialised: dm-devel@redhat.com
[    2.017026] ledtrig-cpu: registered to indicate activity on CPUs
[    2.018131] NET: Registered protocol family 10
[    2.018486] NET: Registered protocol family 17
[    2.018495] Key type dns_resolver registered
[    2.018869] microcode: CPU0 sig=0x106e5, pf=0x2, revision=0x7
[    2.018890] microcode: CPU1 sig=0x106e5, pf=0x2, revision=0x7
[    2.018927] microcode: CPU2 sig=0x106e5, pf=0x2, revision=0x7
[    2.018938] microcode: CPU3 sig=0x106e5, pf=0x2, revision=0x7
[    2.018984] microcode: CPU4 sig=0x106e5, pf=0x2, revision=0x7
[    2.019002] microcode: CPU5 sig=0x106e5, pf=0x2, revision=0x7
[    2.019038] microcode: CPU6 sig=0x106e5, pf=0x2, revision=0x7
[    2.019051] microcode: CPU7 sig=0x106e5, pf=0x2, revision=0x7
[    2.019118] microcode: Microcode Update Driver: v2.01 <tigran@aivazian.fsnet.co.uk>, Peter Oruba
[    2.019491] registered taskstats version 1
[    2.019504] Loading compiled-in X.509 certificates
[    2.020344] Loaded X.509 cert 'Build time autogenerated kernel key: 60562572960efd370424d983abb028749c4780ed'
[    2.020362] zswap: loaded using pool lzo/zbud
[    2.022982] Key type trusted registered
[    2.027690] Key type encrypted registered
[    2.027702] AppArmor: AppArmor sha1 policy hashing enabled
[    2.027708] ima: No TPM chip found, activating TPM-bypass!
[    2.027748] evm: HMAC attrs: 0x1
[    2.028492]   Magic number: 1:222:932
[    2.028688] rtc_cmos 00:01: setting system clock to 2017-05-17 10:54:28 UTC (1495018468)
[    2.029994] BIOS EDD facility v0.16 2004-Jun-25, 0 devices found
[    2.029995] EDD information not available.
[    2.030042] PM: Hibernation image not present or could not be loaded.
[    2.051700] ata2.00: SATA link up 1.5 Gbps (SStatus 113 SControl 300)
[    2.051716] ata2.01: SATA link down (SStatus 0 SControl 300)
[    2.051729] ata2.01: link offline, clearing class 3 to NONE
[    2.059808] ata2.00: ATAPI: ATAPI   iHAS124   B, AL08, max UDMA/100
[    2.075678] ata2.00: configured for UDMA/100
[    2.078402] scsi 1:0:0:0: CD-ROM            ATAPI    iHAS124   B      AL08 PQ: 0 ANSI: 5
[    2.094789] sr 1:0:0:0: [sr0] scsi3-mmc drive: 48x/48x writer dvd-ram cd/rw xa/form2 cdda tray
[    2.094794] cdrom: Uniform CD-ROM driver Revision: 3.20
[    2.095025] sr 1:0:0:0: Attached scsi CD-ROM sr0
[    2.095182] sr 1:0:0:0: Attached scsi generic sg1 type 5
[    2.095881] scsi 3:0:0:0: Direct-Access     ATA      ST2000DM001-9YN1 CC4C PQ: 0 ANSI: 5
[    2.096684] sd 3:0:0:0: Attached scsi generic sg2 type 0
[    2.096849] sd 3:0:0:0: [sdb] 3907029168 512-byte logical blocks: (2.00 TB/1.82 TiB)
[    2.096855] sd 3:0:0:0: [sdb] 4096-byte physical blocks
[    2.097500] sd 3:0:0:0: [sdb] Write Protect is off
[    2.097507] sd 3:0:0:0: [sdb] Mode Sense: 00 3a 00 00
[    2.097825] sd 3:0:0:0: [sdb] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[    2.109658]  sdb: sdb1
[    2.110213] sd 3:0:0:0: [sdb] Attached SCSI disk
[    2.111502] Freeing unused kernel memory: 1484K (ffffffff81f45000 - ffffffff820b8000)
[    2.111504] Write protecting the kernel read-only data: 14336k
[    2.112318] Freeing unused kernel memory: 1780K (ffff880001843000 - ffff880001a00000)
[    2.112764] Freeing unused kernel memory: 116K (ffff880001de3000 - ffff880001e00000)
[    2.126881] random: systemd-udevd: uninitialized urandom read (16 bytes read, 42 bits of entropy available)
[    2.126934] random: systemd-udevd: uninitialized urandom read (16 bytes read, 42 bits of entropy available)
[    2.126944] random: systemd-udevd: uninitialized urandom read (16 bytes read, 42 bits of entropy available)
[    2.126955] random: systemd-udevd: uninitialized urandom read (16 bytes read, 42 bits of entropy available)
[    2.127563] random: udevadm: uninitialized urandom read (16 bytes read, 42 bits of entropy available)
[    2.127597] random: udevadm: uninitialized urandom read (16 bytes read, 42 bits of entropy available)
[    2.127935] random: udevadm: uninitialized urandom read (16 bytes read, 42 bits of entropy available)
[    2.127978] random: udevadm: uninitialized urandom read (16 bytes read, 42 bits of entropy available)
[    2.128023] random: udevadm: uninitialized urandom read (16 bytes read, 42 bits of entropy available)
[    2.128063] random: udevadm: uninitialized urandom read (16 bytes read, 42 bits of entropy available)
[    2.149948] FUJITSU Extended Socket Network Device Driver - version 1.0 - Copyright (c) 2015 FUJITSU LIMITED
[    2.156826] pps_core: LinuxPPS API ver. 1 registered
[    2.156828] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[    2.157965] PTP clock support registered
[    2.161907] e1000e: Intel(R) PRO/1000 Network Driver - 3.2.6-k
[    2.161909] e1000e: Copyright(c) 1999 - 2015 Intel Corporation.
[    2.162083] usb-storage 2-3:1.0: USB Mass Storage device detected
[    2.162222] e1000e 0000:00:19.0: Interrupt Throttling Rate (ints/sec) set to dynamic conservative mode
[    2.162377] scsi host4: usb-storage 2-3:1.0
[    2.162460] usbcore: registered new interface driver usb-storage
[    2.163235] hidraw: raw HID events driver (C) Jiri Kosina
[    2.163874] usbcore: registered new interface driver uas
[    2.166878] usbcore: registered new interface driver usbhid
[    2.166880] usbhid: USB HID core driver
[    2.188464] hid-generic 0003:058F:6364.0001: hiddev0,hidraw0: USB HID v1.10 Device [Generic Mass Storage Device] on usb-0000:00:1d.7-3/input1
[    2.219551] firewire_ohci 0000:03:03.0: added OHCI v1.10 device as card 0, 4 IR + 8 IT contexts, quirks 0x2
[    2.272552] usb 3-2: New USB device found, idVendor=04d9, idProduct=1603
[    2.272555] usb 3-2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[    2.272556] usb 3-2: Product: USB Keyboard
[    2.272558] usb 3-2: Manufacturer:
[    2.323819] input:   USB Keyboard as /devices/pci0000:00/0000:00:1a.0/usb3/3-2/3-2:1.0/0003:04D9:1603.0002/input/input2
[    2.379595] hid-generic 0003:04D9:1603.0002: input,hidraw1: USB HID v1.10 Keyboard [  USB Keyboard] on usb-0000:00:1a.0-2/input0
[    2.415773] e1000e 0000:00:19.0 eth0: (PCI Express:2.5GT/s:Width x1) 00:27:0e:26:50:b0
[    2.415775] e1000e 0000:00:19.0 eth0: Intel(R) PRO/1000 Network Connection
[    2.415883] e1000e 0000:00:19.0 eth0: MAC: 9, PHY: 9, PBA No: FFFFFF-0FF
[    2.416514] e1000e 0000:00:19.0 enp0s25: renamed from eth0
[    2.465680] input:   USB Keyboard as /devices/pci0000:00/0000:00:1a.0/usb3/3-2/3-2:1.1/0003:04D9:1603.0003/input/input3
[    2.519539] hid-generic 0003:04D9:1603.0003: input,hidraw2: USB HID v1.10 Device [  USB Keyboard] on usb-0000:00:1a.0-2/input1
[    2.531581] usb 4-2: new low-speed USB device number 2 using uhci_hcd
[    2.706587] usb 4-2: New USB device found, idVendor=093a, idProduct=2510
[    2.706593] usb 4-2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[    2.706597] usb 4-2: Product: USB Optical Mouse
[    2.706600] usb 4-2: Manufacturer: PixArt
[    2.719702] firewire_core 0000:03:03.0: created device fw0: GUID 009027000269b083, S400
[    2.720757] input: PixArt USB Optical Mouse as /devices/pci0000:00/0000:00:1a.1/usb4/4-2/4-2:1.0/0003:093A:2510.0004/input/input4
[    2.721236] hid-generic 0003:093A:2510.0004: input,hidraw3: USB HID v1.11 Mouse [PixArt USB Optical Mouse] on usb-0000:00:1a.1-2/input0
[    3.011917] clocksource: Switched to clocksource tsc
[    3.131507] usb 1-6: new high-speed USB device number 4 using ehci-pci
[    3.161134] scsi 4:0:0:0: Direct-Access     Generic- SD/MMC           1.00 PQ: 0 ANSI: 0
[    3.161758] scsi 4:0:0:1: Direct-Access     Generic- Compact Flash    1.01 PQ: 0 ANSI: 0
[    3.162430] scsi 4:0:0:2: Direct-Access     Generic- SM/xD-Picture    1.02 PQ: 0 ANSI: 0
[    3.163298] scsi 4:0:0:3: Direct-Access     Generic- MS/MS-Pro        1.03 PQ: 0 ANSI: 0 CCS
[    3.163842] sd 4:0:0:0: Attached scsi generic sg3 type 0
[    3.163967] sd 4:0:0:1: Attached scsi generic sg4 type 0
[    3.164095] sd 4:0:0:2: Attached scsi generic sg5 type 0
[    3.164266] sd 4:0:0:3: Attached scsi generic sg6 type 0
[    3.264894] usb 1-6: New USB device found, idVendor=22b8, idProduct=2e82
[    3.264900] usb 1-6: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[    3.264903] usb 1-6: Product: XT1068
[    3.264906] usb 1-6: Manufacturer: motorola
[    3.264910] usb 1-6: SerialNumber: ZX1D23DDH4
[    3.447998] sd 4:0:0:1: [sdd] Attached SCSI removable disk
[    3.448971] sd 4:0:0:2: [sde] Attached SCSI removable disk
[    3.450139] sd 4:0:0:3: [sdf] Attached SCSI removable disk
[    3.451095] sd 4:0:0:0: [sdc] Attached SCSI removable disk
[    4.615915] random: nonblocking pool is initialized
[    4.759343] raid6: sse2x1   gen()  7796 MB/s
[    4.827347] raid6: sse2x1   xor()  6076 MB/s
[    4.895341] raid6: sse2x2   gen()  9214 MB/s
[    4.963339] raid6: sse2x2   xor()  7091 MB/s
[    5.031347] raid6: sse2x4   gen() 10546 MB/s
[    5.099343] raid6: sse2x4   xor()  7804 MB/s
[    5.099344] raid6: using algorithm sse2x4 gen() 10546 MB/s
[    5.099345] raid6: .... xor() 7804 MB/s, rmw enabled
[    5.099346] raid6: using ssse3x2 recovery algorithm
[    5.100477] xor: measuring software checksum speed
[    5.139379]    prefetch64-sse: 14228.000 MB/sec
[    5.179331]    generic_sse: 12397.000 MB/sec
[    5.179332] xor: using function: prefetch64-sse (14228.000 MB/sec)
[    5.191095] Btrfs loaded
[    5.389724] EXT4-fs (sda3): mounted filesystem with ordered data mode. Opts: (null)
[    5.647428] CE: hpet increased min_delta_ns to 20115 nsec
[    6.236553] systemd[1]: systemd 229 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ -LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD -IDN)
[    6.236694] systemd[1]: Detected architecture x86-64.
[    6.244210] systemd[1]: Set hostname to <labgeo1-desktop>.
[    7.731531] systemd[1]: Reached target Remote File Systems (Pre).
[    7.731607] systemd[1]: Listening on Journal Socket.
[    7.731638] systemd[1]: Listening on udev Control Socket.
[    7.731658] systemd[1]: Listening on LVM2 metadata daemon socket.
[    7.731866] systemd[1]: Created slice User and Session Slice.
[    7.731891] systemd[1]: Listening on /dev/initctl Compatibility Named Pipe.
[    7.732061] systemd[1]: Created slice System Slice.
[    7.732078] systemd[1]: Reached target Slices.
[    7.747416] systemd[1]: Mounting Debug File System...
[    7.747891] systemd[1]: Started Braille Device Support.
[    7.748746] systemd[1]: Mounting POSIX Message Queue File System...
[    7.843562] systemd[1]: Starting Load Kernel Modules...
[    7.844072] systemd[1]: Starting Uncomplicated firewall...
[    7.844670] systemd[1]: Starting Create list of required static device nodes for the current kernel...
[    7.844691] systemd[1]: Reached target Remote File Systems.
[    7.844745] systemd[1]: Listening on Device-mapper event daemon FIFOs.
[    7.845179] systemd[1]: Starting Monitoring of LVM2 mirrors, snapshots etc. using dmeventd or progress polling...
[    7.845211] systemd[1]: Listening on LVM2 poll daemon socket.
[    7.845249] systemd[1]: Listening on udev Kernel Socket.
[    7.845659] systemd[1]: Starting Set console keymap...
[    7.845713] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[    7.846306] systemd[1]: Mounting Huge Pages File System...
[    7.846332] systemd[1]: Reached target User and Group Name Lookups.
[    7.846404] systemd[1]: Listening on Journal Socket (/dev/log).
[    7.846560] systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point.
[    7.977460] systemd[1]: Listening on Syslog Socket.
[    7.977488] systemd[1]: Listening on fsck to fsckd communication Socket.
[    7.977501] systemd[1]: Reached target Encrypted Volumes.
[    7.987406] systemd[1]: Started Read required files in advance.
[    7.987596] systemd[1]: Listening on Journal Audit Socket.
[    7.988063] systemd[1]: Starting Journal Service...
[    7.988297] systemd[1]: Created slice system-systemd\x2dfsck.slice.
[    7.989661] systemd[1]: Started Uncomplicated firewall.
[    8.013142] systemd[1]: Started Create list of required static device nodes for the current kernel.
[    8.013705] systemd[1]: Starting Create Static Device Nodes in /dev...
[    8.260971] systemd[1]: Mounted POSIX Message Queue File System.
[    8.261096] systemd[1]: Mounted Debug File System.
[    8.261152] systemd[1]: Mounted Huge Pages File System.
[    8.442615] lp: driver loaded but no devices found
[    8.488862] ppdev: user-space parallel port driver
[    8.553543] systemd[1]: Started Journal Service.
[   10.553925] EXT4-fs (sda3): re-mounted. Opts: errors=remount-ro
[   10.716975] systemd-journald[374]: Received request to flush runtime journal from PID 1
[   11.122287] EDAC MC: Ver: 3.0.0
[   11.155827] EDAC MC0: Giving out device to module i7core_edac.c controller i7 core #0: DEV 0000:3f:03.0 (POLLED)
[   11.155858] EDAC PCI0: Giving out device to module i7core_edac controller EDAC PCI controller: DEV 0000:3f:03.0 (POLLED)
[   11.155935] EDAC i7core: Driver loaded, 1 memory controller(s) found.
[   11.158582] ACPI Warning: SystemIO range 0x0000000000000500-0x000000000000052F conflicts with OpRegion 0x0000000000000518-0x000000000000051B (\GPBL) (20150930/utaddress-254)
[   11.158586] ACPI Warning: SystemIO range 0x0000000000000500-0x000000000000052F conflicts with OpRegion 0x000000000000050C-0x000000000000050F (\GPLV) (20150930/utaddress-254)
[   11.158588] ACPI Warning: SystemIO range 0x0000000000000500-0x000000000000052F conflicts with OpRegion 0x0000000000000504-0x0000000000000507 (\GPIS) (20150930/utaddress-254)
[   11.158591] ACPI Warning: SystemIO range 0x0000000000000500-0x000000000000052F conflicts with OpRegion 0x0000000000000500-0x0000000000000503 (\GPUS) (20150930/utaddress-254)
[   11.158593] ACPI: If an ACPI driver is available for this device, you should use it instead of the native driver
[   11.246727] shpchp: Standard Hot Plug PCI Controller Driver version: 0.4
[   11.724533] kvm: disabled by bios
[   11.729705] [drm] Initialized drm 1.1.0 20060810
[   11.803518] gpio_ich: GPIO from 436 to 511 on gpio_ich
[   12.604622] snd_hda_codec_realtek hdaudioC0D2: ALC888: SKU not ready 0x411111f0
[   12.605076] snd_hda_codec_realtek hdaudioC0D2: autoconfig for ALC888: line_outs=1 (0x14/0x0/0x0/0x0/0x0) type:line
[   12.605078] snd_hda_codec_realtek hdaudioC0D2:    speaker_outs=0 (0x0/0x0/0x0/0x0/0x0)
[   12.605080] snd_hda_codec_realtek hdaudioC0D2:    hp_outs=1 (0x15/0x0/0x0/0x0/0x0)
[   12.605081] snd_hda_codec_realtek hdaudioC0D2:    mono: mono_out=0x0
[   12.605082] snd_hda_codec_realtek hdaudioC0D2:    dig-out=0x1e/0x0
[   12.605083] snd_hda_codec_realtek hdaudioC0D2:    inputs:
[   12.605085] snd_hda_codec_realtek hdaudioC0D2:      Front Mic=0x18
[   12.605087] snd_hda_codec_realtek hdaudioC0D2:      Rear Mic=0x1b
[   12.605088] snd_hda_codec_realtek hdaudioC0D2:      Line=0x1a
[   12.618606] input: HDA Intel MID Rear Mic as /devices/pci0000:00/0000:00:1b.0/sound/card0/input5
[   12.618658] input: HDA Intel MID Line as /devices/pci0000:00/0000:00:1b.0/sound/card0/input6
[   12.618703] input: HDA Intel MID Line Out as /devices/pci0000:00/0000:00:1b.0/sound/card0/input7
[   13.566679] Adding 3905532k swap on /dev/sda5.  Priority:-1 extents:1 across:3905532k FS
[   14.358959] nvidia: module license 'NVIDIA' taints kernel.
[   14.358962] Disabling lock debugging due to kernel taint
[   14.362515] nvidia: module verification failed: signature and/or required key missing - tainting kernel
[   14.366866] vgaarb: device changed decodes: PCI:0000:01:00.0,olddecodes=io+mem,decodes=none:owns=io+mem
[   14.367170] [drm] Initialized nvidia-drm 0.0.0 20150116 for 0000:01:00.0 on minor 0
[   14.367176] NVRM: loading NVIDIA UNIX x86_64 Kernel Module  340.102  Mon Jan 16 13:06:29 PST 2017
[   14.918621] EXT4-fs (sda6): mounted filesystem with ordered data mode. Opts: (null)
[   17.420123] audit: type=1400 audit(1495018483.887:2): apparmor="STATUS" operation="profile_load" profile="unconfined" name="docker-default" pid=825 comm="apparmor_parser"
[   17.439057] audit: type=1400 audit(1495018483.903:3): apparmor="STATUS" operation="profile_load" profile="unconfined" name="/usr/sbin/ippusbxd" pid=830 comm="apparmor_parser"
[   17.601131] audit: type=1400 audit(1495018484.067:4): apparmor="STATUS" operation="profile_load" profile="unconfined" name="/usr/sbin/ntpd" pid=831 comm="apparmor_parser"
[   17.601385] audit: type=1400 audit(1495018484.067:5): apparmor="STATUS" operation="profile_load" profile="unconfined" name="/usr/sbin/tcpdump" pid=833 comm="apparmor_parser"
[   17.602117] audit: type=1400 audit(1495018484.067:6): apparmor="STATUS" operation="profile_load" profile="unconfined" name="/sbin/dhclient" pid=826 comm="apparmor_parser"
[   17.602121] audit: type=1400 audit(1495018484.067:7): apparmor="STATUS" operation="profile_load" profile="unconfined" name="/usr/lib/NetworkManager/nm-dhcp-client.action" pid=826 comm="apparmor_parser"
[   17.602125] audit: type=1400 audit(1495018484.067:8): apparmor="STATUS" operation="profile_load" profile="unconfined" name="/usr/lib/NetworkManager/nm-dhcp-helper" pid=826 comm="apparmor_parser"
[   17.602131] audit: type=1400 audit(1495018484.067:9): apparmor="STATUS" operation="profile_load" profile="unconfined" name="/usr/lib/connman/scripts/dhclient-script" pid=826 comm="apparmor_parser"
[   17.605068] audit: type=1400 audit(1495018484.071:10): apparmor="STATUS" operation="profile_load" profile="unconfined" name="/usr/sbin/cups-browsed" pid=828 comm="apparmor_parser"
[   17.635778] audit: type=1400 audit(1495018484.103:11): apparmor="STATUS" operation="profile_load" profile="unconfined" name="/usr/lib/cups/backend/cups-pdf" pid=829 comm="apparmor_parser"
[   20.644339] cgroup: new mount options do not match the existing superblock, will be ignored
[   24.477643] IPv6: ADDRCONF(NETDEV_UP): enp0s25: link is not ready
[   24.715442] IPv6: ADDRCONF(NETDEV_UP): enp0s25: link is not ready
continue
[   27.468809] e1000e: enp0s25 NIC Link is Up 100 Mbps Full Duplex, Flow Control: Rx
[   27.468943] e1000e 0000:00:19.0 enp0s25: 10/100 speed: disabling TSO
[   27.468983] IPv6: ADDRCONF(NETDEV_CHANGE): enp0s25: link becomes ready
[   43.269274] NVRM: Your system is not currently configured to drive a VGA console
[   43.269283] NVRM: on the primary VGA device. The NVIDIA Linux graphics driver
[   43.269285] NVRM: requires the use of a text-mode VGA console. Use of other console
[   43.269287] NVRM: drivers including, but not limited to, vesafb, may result in
[   43.269289] NVRM: corruption and stability problems, and is not supported.
[   44.160766] aufs 4.x-rcN-20160111
[   44.594977] bridge: automatic filtering via arp/ip/ip6tables has been deprecated. Update your scripts to load br_netfilter if you need this.
[   44.596353] Bridge firewalling registered
[   44.625816] nf_conntrack version 0.5.0 (65536 buckets, 262144 max)
[   44.686482] ip_tables: (C) 2000-2006 Netfilter Core Team
[   44.743262] Initializing XFRM netlink socket
[   44.749168] Netfilter messages via NETLINK v0.30.
[   44.750886] ctnetlink v0.93: registering with nfnetlink.
[   44.796287] IPv6: ADDRCONF(NETDEV_UP): docker0: link is not ready
[   45.533781] aufs au_opts_verify:1597:dockerd[1527]: dirperm1 breaks the protection by the permission bits on the lower branch
What about the monitor’s EDID problem? Could it be due to hardware? or configuration?
Ok, looks good now.
Your system, graphics card and driver have always been fine. Just your monitor failed i.e. its edid. That’s why you suddenly had only 1024x768 resolution. That’s a hardware failure. You might try another cable or connector (if you don’t already have) but i doubt that will help.
To keep your monitor you will have to set up the monitor section in xorg.conf by hand with values from the datasheet of your monitor manually.
If you don’t have a xorg.conf generate one using nvidia-xconfig --no-use-edid --no-use-edid-freqs
In the montor section, you’ll have to set
HorizSync
VertRefresh
Modeline (for each resolution you want to use)
Modeline calculator:
https://arachnoid.com/modelines/
I’ve done something towards that:
cvt 1600 1200
sudo xrandr --newmode "1600x1200_60.00"  161.00  1600 1712 1880 2160  1200 1203 1207 1245 -hsync +vsync
sudo xrandr --addmode DVI-I-1 1600x1200_60.00
sudo xrandr --output DVI-I-1 --mode 1600x1200_60.00
which works only if I don’t blacklist nouveau, but if I do, it just doesn’t work. Do you know why? Anyhow it’s good to know it’s hardware failure. Thank you.
The output names differ between drivers and you have to tell the nvidia driver to ignore edid and edid freqs and set horizsync and vertrefresh in monitor section right.
What does the Displays / Monitor Preferences indicate?
