I have an Optimus nvidia gpu GeForce 940M on an intel graphic board on a fedora 24 64bit machine.
The graphic hardware is :
lspci |grep VGA|3D
00:02.0 VGA compatible controller: Intel Corporation HD Graphics 520 (rev 07)
01:00.0 3D controller: NVIDIA Corporation GM108M [GeForce 940M] (rev ff)
I have tried to install the nvidia driver 367.44 (but also previous versions) and apparently the installation went fine. When restarted I could not get the desktop either with gdm or kdm. The Xorg.0.log file of the failed graphical boot is the following:
[ 230.077]
X.Org X Server 1.18.4
Release Date: 2016-07-19
[ 230.079] X Protocol Version 11, Revision 0
[ 230.079] Build Operating System: 4.6.3-300.fc24.x86_64
[ 230.080] Current Operating System: Linux new-host.station 4.6.6-300.fc24.x86_64 #1 SMP Wed Aug 10 21:07:35 UTC 2016 x86_64
[ 230.081] Kernel command line: BOOT_IMAGE=/vmlinuz-4.6.6-300.fc24.x86_64 root=UUID=163e4621-7dc7-4f14-b20e-b6dd7763fe59 ro net.ifnames=0 biosdevname=0 norhgb quiet rd.driver.blacklist=nouveau
[ 230.083] Build Date: 19 July 2016 06:08:11PM
[ 230.084] Build ID: xorg-x11-server 1.18.4-1.fc24
[ 230.085] Current version of pixman: 0.34.0
[ 230.087] Before reporting problems, check http://wiki.x.org
to make sure that you have the latest version.
[ 230.087] Markers: (–) probed, () from config file, (==) default setting,
(++) from command line, (!!) notice, (II) informational,
(WW) warning, (EE) error, (NI) not implemented, (??) unknown.
[ 230.092] (==) Log file: “/var/log/Xorg.0.log”, Time: Wed Aug 24 08:50:43 2016
[ 230.110] (==) Using config directory: “/etc/X11/xorg.conf.d”
[ 230.112] (==) Using system config directory “/usr/share/X11/xorg.conf.d”
[ 230.164] (==) No Layout section. Using the first Screen section.
[ 230.164] (==) No screen section available. Using defaults.
[ 230.164] () |–>Screen “Default Screen Section” (0)
[ 230.164] () | |–>Monitor “”
[ 230.173] (==) No monitor specified for screen “Default Screen Section”.
Using a default monitor configuration.
[ 230.173] (==) Automatically adding devices
[ 230.173] (==) Automatically enabling devices
[ 230.173] (==) Automatically adding GPU devices
[ 230.174] (==) Max clients allowed: 256, resource mask: 0x1fffff
[ 230.192] () FontPath set to:
/usr/share/fonts/msttcore,
catalogue:/etc/X11/fontpath.d,
built-ins
[ 230.192] (==) ModulePath set to “/usr/lib64/xorg/modules”
[ 230.192] (II) The server relies on udev to provide the list of input devices.
If no devices become available, reconfigure udev or disable AutoAddDevices.
[ 230.192] (II) Loader magic: 0x824dc0
[ 230.192] (II) Module ABI versions:
[ 230.192] X.Org ANSI C Emulation: 0.4
[ 230.192] X.Org Video Driver: 20.0
[ 230.192] X.Org XInput driver : 22.1
[ 230.192] X.Org Server Extension : 9.0
[ 230.199] (++) using VT number 1
[ 230.210] (II) systemd-logind: took control of session /org/freedesktop/login1/session/_31
[ 230.212] (II) xfree86: Adding drm device (/dev/dri/card0)
[ 230.215] (II) systemd-logind: got fd for /dev/dri/card0 226:0 fd 8 paused 0
[ 230.216] (II) xfree86: Adding drm device (/dev/dri/card1)
[ 230.218] (II) systemd-logind: got fd for /dev/dri/card1 226:1 fd 9 paused 0
[ 230.223] (–) PCI:*(0:0:2:0) 8086:1916:103c:80a4 rev 7, Mem @ 0x92000000/16777216, 0xa0000000/268435456, I/O @ 0x00005000/64, BIOS @ 0x???/131072
[ 230.223] (–) PCI: (0:1:0:0) 10de:1347:103c:80a4 rev 162, Mem @ 0x93000000/16777216, 0x80000000/268435456, 0x90000000/33554432, I/O @ 0x00004000/128, BIOS @ 0x???/65536
[ 230.223] (II) LoadModule: “glx”
[ 230.224] (II) Loading /usr/lib64/xorg/modules/extensions/libglx.so
[ 230.233] (II) Module glx: vendor=“NVIDIA Corporation”
[ 230.233] compiled for 4.0.2, module version = 1.0.0
[ 230.233] Module class: X.Org Server Extension
[ 230.233] (II) NVIDIA GLX Module 367.44 Wed Aug 17 21:50:26 PDT 2016
[ 230.233] (II) Applying OutputClass “nvidia” to /dev/dri/card1
[ 230.233] loading driver: nvidia
[ 230.233] (==) Matched intel as autoconfigured driver 0
[ 230.233] (==) Matched nvidia as autoconfigured driver 1
[ 230.233] (==) Matched nouveau as autoconfigured driver 2
[ 230.233] (==) Matched nv as autoconfigured driver 3
[ 230.233] (==) Matched intel as autoconfigured driver 4
[ 230.233] (==) Matched modesetting as autoconfigured driver 5
[ 230.233] (==) Matched fbdev as autoconfigured driver 6
[ 230.233] (==) Matched vesa as autoconfigured driver 7
[ 230.233] (==) Assigned the driver to the xf86ConfigLayout
[ 230.233] (II) LoadModule: “intel”
[ 230.233] (II) Loading /usr/lib64/xorg/modules/drivers/intel_drv.so
[ 230.276] (II) Module intel: vendor=“X.Org Foundation”
[ 230.276] compiled for 1.18.3, module version = 2.99.917
[ 230.276] Module class: X.Org Video Driver
[ 230.276] ABI class: X.Org Video Driver, version 20.0
[ 230.276] (II) LoadModule: “nvidia”
[ 230.276] (II) Loading /usr/lib64/xorg/modules/drivers/nvidia_drv.so
[ 230.276] (II) Module nvidia: vendor=“NVIDIA Corporation”
[ 230.276] compiled for 4.0.2, module version = 1.0.0
[ 230.276] (II) LoadModule: “nouveau”
[ 230.277] (WW) Warning, couldn’t open module nouveau
[ 230.277] (II) UnloadModule: “nouveau”
[ 230.277] (II) Unloading nouveau
[ 230.277] (EE) Failed to load module “nouveau” (module does not exist, 0)
[ 230.277] (II) LoadModule: “nv”
[ 230.277] (WW) Warning, couldn’t open module nv
[ 230.278] (II) UnloadModule: “nv”
[ 230.278] (II) Unloading nv
[ 230.278] (EE) Failed to load module “nv” (module does not exist, 0)
[ 230.278] (II) LoadModule: “modesetting”
[ 230.278] (II) Loading /usr/lib64/xorg/modules/drivers/modesetting_drv.so
[ 230.288] (II) Module modesetting: vendor=“X.Org Foundation”
[ 230.288] compiled for 1.18.4, module version = 1.18.4
[ 230.288] Module class: X.Org Video Driver
[ 230.288] ABI class: X.Org Video Driver, version 20.0
[ 230.288] (II) LoadModule: “fbdev”
[ 230.288] (II) Loading /usr/lib64/xorg/modules/drivers/fbdev_drv.so
[ 230.295] (II) Module fbdev: vendor=“X.Org Foundation”
[ 230.295] compiled for 1.18.0, module version = 0.4.3
[ 230.295] Module class: X.Org Video Driver
[ 230.295] ABI class: X.Org Video Driver, version 20.0
[ 230.295] (II) LoadModule: “vesa”
[ 230.295] (II) Loading /usr/lib64/xorg/modules/drivers/vesa_drv.so
[ 230.304] (II) Module vesa: vendor=“X.Org Foundation”
[ 230.304] compiled for 1.18.0, module version = 2.3.2
[ 230.304] Module class: X.Org Video Driver
[ 230.304] ABI class: X.Org Video Driver, version 20.0
[ 230.304] (II) intel: Driver for Intel® Integrated Graphics Chipsets:
i810, i810-dc100, i810e, i815, i830M, 845G, 854, 852GM/855GM, 865G,
915G, E7221 (i915), 915GM, 945G, 945GM, 945GME, Pineview GM,
Pineview G, 965G, G35, 965Q, 946GZ, 965GM, 965GME/GLE, G33, Q35, Q33,
GM45, 4 Series, G45/G43, Q45/Q43, G41, B43
[ 230.305] (II) intel: Driver for Intel® HD Graphics: 2000-6000
[ 230.305] (II) intel: Driver for Intel® Iris™ Graphics: 5100, 6100
[ 230.305] (II) intel: Driver for Intel® Iris™ Pro Graphics: 5200, 6200, P6300
[ 230.305] (II) NVIDIA dlloader X Driver 367.44 Wed Aug 17 21:28:13 PDT 2016
[ 230.305] (II) NVIDIA Unified Driver for all Supported NVIDIA GPUs
[ 230.305] (II) modesetting: Driver for Modesetting Kernel Drivers: kms
[ 230.305] (II) FBDEV: driver for framebuffer: fbdev
[ 230.305] (II) VESA: driver for VESA chipsets: vesa
[ 230.306] (II) systemd-logind: releasing fd for 226:1
[ 230.307] (II) modeset(0): using drv /dev/dri/card0
[ 230.307] (WW) Falling back to old probe method for fbdev
[ 230.307] (II) Loading sub module “fbdevhw”
[ 230.307] (II) LoadModule: “fbdevhw”
[ 230.307] (II) Loading /usr/lib64/xorg/modules/libfbdevhw.so
[ 230.315] (II) Module fbdevhw: vendor=“X.Org Foundation”
[ 230.315] compiled for 1.18.4, module version = 0.0.2
[ 230.315] ABI class: X.Org Video Driver, version 20.0
[ 230.315] (WW) Falling back to old probe method for vesa
[ 230.316] (II) modeset(0): Creating default Display subsection in Screen section
“Default Screen Section” for depth/fbbpp 24/32
[ 230.316] (==) modeset(0): Depth 24, (==) framebuffer bpp 32
[ 230.316] (==) modeset(0): RGB weight 888
[ 230.316] (==) modeset(0): Default visual is TrueColor
[ 230.316] (II) Loading sub module “glamoregl”
[ 230.316] (II) LoadModule: “glamoregl”
[ 230.316] (WW) Warning, couldn’t open module glamoregl
[ 230.316] (II) UnloadModule: “glamoregl”
[ 230.316] (II) Unloading glamoregl
[ 230.316] (EE) modeset: Failed to load module “glamoregl” (module does not exist, 0)
[ 230.316] (EE) modeset(0): Failed to load glamor module.
[ 230.316] (II) modeset(0): ShadowFB: preferred YES, enabled YES
[ 230.317] (II) modeset(0): Output eDP-1 has no monitor section
[ 230.405] (II) modeset(0): Output HDMI-1 has no monitor section
[ 230.406] (II) modeset(0): EDID for output eDP-1
[ 230.406] (II) modeset(0): Manufacturer: CMN Model: 15c4 Serial#: 0
[ 230.406] (II) modeset(0): Year: 2014 Week: 38
[ 230.406] (II) modeset(0): EDID Version: 1.4
[ 230.406] (II) modeset(0): Digital Display Input
[ 230.406] (II) modeset(0): 6 bits per channel
[ 230.406] (II) modeset(0): Digital interface is DisplayPort
[ 230.406] (II) modeset(0): Max Image Size [cm]: horiz.: 34 vert.: 19
[ 230.406] (II) modeset(0): Gamma: 2.20
[ 230.406] (II) modeset(0): No DPMS capabilities specified
[ 230.406] (II) modeset(0): Supported color encodings: RGB 4:4:4
[ 230.406] (II) modeset(0): First detailed timing is preferred mode
[ 230.406] (II) modeset(0): Preferred mode is native pixel format and refresh rate
[ 230.406] (II) modeset(0): redX: 0.565 redY: 0.330 greenX: 0.323 greenY: 0.577
[ 230.406] (II) modeset(0): blueX: 0.160 blueY: 0.145 whiteX: 0.313 whiteY: 0.329
[ 230.406] (II) modeset(0): Manufacturer’s mask: 0
[ 230.406] (II) modeset(0): Supported detailed timing:
[ 230.406] (II) modeset(0): clock: 152.8 MHz Image Size: 344 x 193 mm
[ 230.406] (II) modeset(0): h_active: 1920 h_sync: 2020 h_sync_end 2086 h_blank_end 2250 h_border: 0
[ 230.406] (II) modeset(0): v_active: 1080 v_sync: 1086 v_sync_end 1096 v_blanking: 1132 v_border: 0
[ 230.406] (II) modeset(0): clock: 101.9 MHz Image Size: 344 x 193 mm
[ 230.406] (II) modeset(0): Unknown vendor-specific block 2
[ 230.406] (II) modeset(0): EDID (in hex):
[ 230.406] (II) modeset(0): 00ffffffffffff000daec41500000000
[ 230.406] (II) modeset(0): 261801049522137802ef059054529329
[ 230.407] (II) modeset(0): 25505400000001010101010101010101
[ 230.407] (II) modeset(0): 010101010101b43b804a713834406442
[ 230.407] (II) modeset(0): 6a0058c11000001acd27804a71383440
[ 230.407] (II) modeset(0): 64426a0058c11000001a000000000000
[ 230.407] (II) modeset(0): 00000000000000000000000000000002
[ 230.407] (II) modeset(0): 000c44ff0b3c6e13101f6e000000001f
[ 230.407] (II) modeset(0): Printing probed modes for output eDP-1
[ 230.407] (II) modeset(0): Modeline "1920x1080"x60.0 152.84 1920 2020 2086 2250 1080 1086 1096 1132 +hsync -vsync (67.9 kHz eP)
[ 230.407] (II) modeset(0): Modeline "1920x1080"x40.0 101.89 1920 2020 2086 2250 1080 1086 1096 1132 +hsync -vsync (45.3 kHz e)
[ 230.407] (II) modeset(0): Modeline "1400x1050"x60.0 122.00 1400 1488 1640 1880 1050 1052 1064 1082 +hsync +vsync (64.9 kHz d)
[ 230.407] (II) modeset(0): Modeline "1280x1024"x60.0 108.00 1280 1328 1440 1688 1024 1025 1028 1066 +hsync +vsync (64.0 kHz d)
[ 230.407] (II) modeset(0): Modeline "1280x960"x60.0 108.00 1280 1376 1488 1800 960 961 964 1000 +hsync +vsync (60.0 kHz d)
[ 230.407] (II) modeset(0): Modeline "1024x768"x120.1 133.47 1024 1100 1212 1400 768 768 770 794 doublescan -hsync +vsync (95.3 kHz d)
[ 230.407] (II) modeset(0): Modeline "1024x768"x60.0 65.00 1024 1048 1184 1344 768 771 777 806 -hsync -vsync (48.4 kHz d)
[ 230.407] (II) modeset(0): Modeline "960x720"x120.0 117.00 960 1024 1128 1300 720 720 722 750 doublescan -hsync +vsync (90.0 kHz d)
[ 230.407] (II) modeset(0): Modeline "928x696"x120.1 109.15 928 976 1088 1264 696 696 698 719 doublescan -hsync +vsync (86.4 kHz d)
[ 230.407] (II) modeset(0): Modeline "896x672"x120.0 102.40 896 960 1060 1224 672 672 674 697 doublescan -hsync +vsync (83.7 kHz d)
[ 230.407] (II) modeset(0): Modeline "800x600"x120.0 81.00 800 832 928 1080 600 600 602 625 doublescan +hsync +vsync (75.0 kHz d)
[ 230.407] (II) modeset(0): Modeline "800x600"x60.3 40.00 800 840 968 1056 600 601 605 628 +hsync +vsync (37.9 kHz d)
[ 230.407] (II) modeset(0): Modeline "800x600"x56.2 36.00 800 824 896 1024 600 601 603 625 +hsync +vsync (35.2 kHz d)
[ 230.407] (II) modeset(0): Modeline "700x525"x120.0 61.00 700 744 820 940 525 526 532 541 doublescan +hsync +vsync (64.9 kHz d)
[ 230.407] (II) modeset(0): Modeline "640x512"x120.0 54.00 640 664 720 844 512 512 514 533 doublescan +hsync +vsync (64.0 kHz d)
[ 230.408] (II) modeset(0): Modeline "640x480"x120.0 54.00 640 688 744 900 480 480 482 500 doublescan +hsync +vsync (60.0 kHz d)
[ 230.408] (II) modeset(0): Modeline "640x480"x59.9 25.18 640 656 752 800 480 490 492 525 -hsync -vsync (31.5 kHz d)
[ 230.408] (II) modeset(0): Modeline "512x384"x120.0 32.50 512 524 592 672 384 385 388 403 doublescan -hsync -vsync (48.4 kHz d)
[ 230.408] (II) modeset(0): Modeline "400x300"x120.6 20.00 400 420 484 528 300 300 302 314 doublescan +hsync +vsync (37.9 kHz d)
[ 230.408] (II) modeset(0): Modeline "400x300"x112.7 18.00 400 412 448 512 300 300 301 312 doublescan +hsync +vsync (35.2 kHz d)
[ 230.408] (II) modeset(0): Modeline "320x240"x120.1 12.59 320 328 376 400 240 245 246 262 doublescan -hsync -vsync (31.5 kHz d)
[ 230.496] (II) modeset(0): EDID for output HDMI-1
[ 230.496] (II) modeset(0): Output eDP-1 connected
[ 230.496] (II) modeset(0): Output HDMI-1 disconnected
[ 230.496] (II) modeset(0): Using exact sizes for initial modes
[ 230.496] (II) modeset(0): Output eDP-1 using initial mode 1920x1080 +0+0
[ 230.496] (II) modeset(0): Using default gamma of (1.0, 1.0, 1.0) unless otherwise stated.
[ 230.496] (==) modeset(0): DPI set to (96, 96)
[ 230.496] (II) Loading sub module “fb”
[ 230.496] (II) LoadModule: “fb”
[ 230.497] (II) Loading /usr/lib64/xorg/modules/libfb.so
[ 230.506] (II) Module fb: vendor=“X.Org Foundation”
[ 230.507] compiled for 1.18.4, module version = 1.0.0
[ 230.507] ABI class: X.Org ANSI C Emulation, version 0.4
[ 230.507] (II) Loading sub module “shadow”
[ 230.507] (II) LoadModule: “shadow”
[ 230.507] (II) Loading /usr/lib64/xorg/modules/libshadow.so
[ 230.514] (II) Module shadow: vendor=“X.Org Foundation”
[ 230.514] compiled for 1.18.4, module version = 1.1.0
[ 230.514] ABI class: X.Org ANSI C Emulation, version 0.4
[ 230.514] (II) UnloadModule: “fbdev”
[ 230.514] (II) Unloading fbdev
[ 230.514] (II) UnloadSubModule: “fbdevhw”
[ 230.514] (II) Unloading fbdevhw
[ 230.514] (II) UnloadModule: “vesa”
[ 230.514] (II) Unloading vesa
[ 230.514] (==) Depth 24 pixmap format is 32 bpp
[ 230.516] (==) modeset(0): Backing store enabled
[ 230.516] (==) modeset(0): Silken mouse enabled
[ 230.516] (II) modeset(0): RandR 1.2 enabled, ignore the following RandR disabled message.
[ 230.517] (==) modeset(0): DPMS enabled
[ 230.528] (–) RandR disabled
[ 230.537] (II) SELinux: Disabled by boolean
[ 230.539] (EE) Failed to initialize GLX extension (Compatible NVIDIA X driver not found)
[ 230.539] (II) modeset(0): Damage tracking initialized
[ 230.539] (II) modeset(0): Setting screen physical size to 508 x 285
[ 231.032] (II) config/udev: Adding input device Power Button (/dev/input/event2)
[ 231.032] () Power Button: Applying InputClass “evdev keyboard catchall”
[ 231.032] () Power Button: Applying InputClass “libinput keyboard catchall”
[ 231.032] () Power Button: Applying InputClass “system-keyboard”
[ 231.032] (II) LoadModule: “libinput”
[ 231.032] (II) Loading /usr/lib64/xorg/modules/input/libinput_drv.so
[ 231.095] (II) Module libinput: vendor=“X.Org Foundation”
[ 231.095] compiled for 1.18.3, module version = 0.19.0
[ 231.095] Module class: X.Org XInput Driver
[ 231.095] ABI class: X.Org XInput driver, version 22.1
[ 231.097] (II) systemd-logind: got fd for /dev/input/event2 13:66 fd 14 paused 0
[ 231.097] (II) Using input driver ‘libinput’ for ‘Power Button’
[ 231.097] () Power Button: always reports core events
[ 231.097] () Option “Device” “/dev/input/event2”
[ 231.097] () Option “_source” “server/udev”
[ 231.098] (II) input device ‘Power Button’, /dev/input/event2 is tagged by udev as: Keyboard
[ 231.098] (II) input device ‘Power Button’, /dev/input/event2 is a keyboard
[ 231.098] () Option “config_info” “udev:/sys/devices/LNXSYSTM:00/LNXPWRBN:00/input/input2/event2”
[ 231.098] (II) XINPUT: Adding extended input device “Power Button” (type: KEYBOARD, id 6)
[ 231.098] () Option “xkb_layout” “it”
[ 231.146] (II) input device ‘Power Button’, /dev/input/event2 is tagged by udev as: Keyboard
[ 231.146] (II) input device ‘Power Button’, /dev/input/event2 is a keyboard
[ 231.147] (II) config/udev: Adding input device Video Bus (/dev/input/event4)
[ 231.147] () Video Bus: Applying InputClass “evdev keyboard catchall”
[ 231.147] () Video Bus: Applying InputClass “libinput keyboard catchall”
[ 231.147] () Video Bus: Applying InputClass “system-keyboard”
[ 231.149] (II) systemd-logind: got fd for /dev/input/event4 13:68 fd 17 paused 0
[ 231.149] (II) Using input driver ‘libinput’ for ‘Video Bus’
[ 231.149] () Video Bus: always reports core events
[ 231.149] () Option “Device” “/dev/input/event4”
[ 231.149] () Option “_source” “server/udev”
[ 231.150] (II) input device ‘Video Bus’, /dev/input/event4 is tagged by udev as: Keyboard
[ 231.150] (II) input device ‘Video Bus’, /dev/input/event4 is a keyboard
[ 231.150] () Option “config_info” “udev:/sys/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/LNXVIDEO:00/input/input6/event4”
[ 231.150] (II) XINPUT: Adding extended input device “Video Bus” (type: KEYBOARD, id 7)
[ 231.150] () Option “xkb_layout” “it”
[ 231.151] (II) input device ‘Video Bus’, /dev/input/event4 is tagged by udev as: Keyboard
[ 231.151] (II) input device ‘Video Bus’, /dev/input/event4 is a keyboard
[ 231.152] (II) config/udev: Adding input device Video Bus (/dev/input/event5)
[ 231.152] () Video Bus: Applying InputClass “evdev keyboard catchall”
[ 231.152] () Video Bus: Applying InputClass “libinput keyboard catchall”
[ 231.152] () Video Bus: Applying InputClass “system-keyboard”
[ 231.153] (II) systemd-logind: got fd for /dev/input/event5 13:69 fd 18 paused 0
[ 231.153] (II) Using input driver ‘libinput’ for ‘Video Bus’
[ 231.153] () Video Bus: always reports core events
[ 231.153] () Option “Device” “/dev/input/event5”
[ 231.153] () Option “_source” “server/udev”
[ 231.153] (II) input device ‘Video Bus’, /dev/input/event5 is tagged by udev as: Keyboard
[ 231.153] (II) input device ‘Video Bus’, /dev/input/event5 is a keyboard
[ 231.153] () Option “config_info” “udev:/sys/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/device:37/LNXVIDEO:01/input/input7/event5”
[ 231.153] (II) XINPUT: Adding extended input device “Video Bus” (type: KEYBOARD, id 8)
[ 231.153] () Option “xkb_layout” “it”
[ 231.154] (II) input device ‘Video Bus’, /dev/input/event5 is tagged by udev as: Keyboard
[ 231.154] (II) input device ‘Video Bus’, /dev/input/event5 is a keyboard
[ 231.155] (II) config/udev: Adding input device Power Button (/dev/input/event1)
[ 231.155] () Power Button: Applying InputClass “evdev keyboard catchall”
[ 231.155] () Power Button: Applying InputClass “libinput keyboard catchall”
[ 231.155] () Power Button: Applying InputClass “system-keyboard”
[ 231.155] (II) systemd-logind: got fd for /dev/input/event1 13:65 fd 19 paused 0
[ 231.155] (II) Using input driver ‘libinput’ for ‘Power Button’
[ 231.155] () Power Button: always reports core events
[ 231.155] () Option “Device” “/dev/input/event1”
[ 231.156] () Option “_source” “server/udev”
[ 231.156] (II) input device ‘Power Button’, /dev/input/event1 is tagged by udev as: Keyboard
[ 231.156] (II) input device ‘Power Button’, /dev/input/event1 is a keyboard
[ 231.156] () Option “config_info” “udev:/sys/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0C:00/input/input1/event1”
[ 231.156] (II) XINPUT: Adding extended input device “Power Button” (type: KEYBOARD, id 9)
[ 231.156] () Option “xkb_layout” “it”
[ 231.157] (II) input device ‘Power Button’, /dev/input/event1 is tagged by udev as: Keyboard
[ 231.157] (II) input device ‘Power Button’, /dev/input/event1 is a keyboard
[ 231.157] (II) config/udev: Adding input device Lid Switch (/dev/input/event0)
[ 231.157] (II) No input driver specified, ignoring this device.
[ 231.157] (II) This device may have been added with another device file.
[ 231.158] (II) config/udev: Adding input device HP Truevision HD (/dev/input/event10)
[ 231.158] () HP Truevision HD: Applying InputClass “evdev keyboard catchall”
[ 231.158] () HP Truevision HD: Applying InputClass “libinput keyboard catchall”
[ 231.158] () HP Truevision HD: Applying InputClass “system-keyboard”
[ 231.159] (II) systemd-logind: got fd for /dev/input/event10 13:74 fd 20 paused 0
[ 231.159] (II) Using input driver ‘libinput’ for ‘HP Truevision HD’
[ 231.159] () HP Truevision HD: always reports core events
[ 231.159] () Option “Device” “/dev/input/event10”
[ 231.159] () Option “_source” “server/udev”
[ 231.159] (II) input device ‘HP Truevision HD’, /dev/input/event10 is tagged by udev as: Keyboard
[ 231.159] (II) input device ‘HP Truevision HD’, /dev/input/event10 is a keyboard
[ 231.159] () Option “config_info” “udev:/sys/devices/pci0000:00/0000:00:14.0/usb1/1-3/1-3:1.0/input/input11/event10”
[ 231.159] (II) XINPUT: Adding extended input device “HP Truevision HD” (type: KEYBOARD, id 10)
[ 231.159] () Option “xkb_layout” “it”
[ 231.160] (II) input device ‘HP Truevision HD’, /dev/input/event10 is tagged by udev as: Keyboard
[ 231.160] (II) input device ‘HP Truevision HD’, /dev/input/event10 is a keyboard
[ 231.161] (II) config/udev: Adding input device Dell Dell USB Optical Mouse (/dev/input/event6)
[ 231.161] () Dell Dell USB Optical Mouse: Applying InputClass “evdev pointer catchall”
[ 231.161] () Dell Dell USB Optical Mouse: Applying InputClass “libinput pointer catchall”
[ 231.212] (II) systemd-logind: got fd for /dev/input/event6 13:70 fd 21 paused 0
[ 231.212] (II) Using input driver ‘libinput’ for ‘Dell Dell USB Optical Mouse’
[ 231.212] () Dell Dell USB Optical Mouse: always reports core events
[ 231.212] () Option “Device” “/dev/input/event6”
[ 231.212] () Option “_source” “server/udev”
[ 231.213] (II) input device ‘Dell Dell USB Optical Mouse’, /dev/input/event6 is tagged by udev as: Mouse
[ 231.213] (II) Device ‘Dell Dell USB Optical Mouse’ set to 400 DPI
[ 231.213] (II) input device ‘Dell Dell USB Optical Mouse’, /dev/input/event6 is a pointer caps
[ 231.213] () Option “config_info” “udev:/sys/devices/pci0000:00/0000:00:14.0/usb1/1-6/1-6:1.0/0003:413C:3012.0001/input/input8/event6”
[ 231.213] (II) XINPUT: Adding extended input device “Dell Dell USB Optical Mouse” (type: MOUSE, id 11)
[ 231.213] () Option “AccelerationScheme” “none”
[ 231.213] () Dell Dell USB Optical Mouse: (accel) selected scheme none/0
[ 231.213] () Dell Dell USB Optical Mouse: (accel) acceleration factor: 2.000
[ 231.213] () Dell Dell USB Optical Mouse: (accel) acceleration threshold: 4
[ 231.214] (II) input device ‘Dell Dell USB Optical Mouse’, /dev/input/event6 is tagged by udev as: Mouse
[ 231.214] (II) Device ‘Dell Dell USB Optical Mouse’ set to 400 DPI
[ 231.214] (II) input device ‘Dell Dell USB Optical Mouse’, /dev/input/event6 is a pointer caps
[ 231.215] (II) config/udev: Adding input device Dell Dell USB Optical Mouse (/dev/input/mouse0)
[ 231.215] (II) No input driver specified, ignoring this device.
[ 231.215] (II) This device may have been added with another device file.
[ 231.216] (II) config/udev: Adding input device HDA Intel PCH Mic (/dev/input/event12)
[ 231.216] (II) No input driver specified, ignoring this device.
[ 231.216] (II) This device may have been added with another device file.
[ 231.216] (II) config/udev: Adding input device HDA Intel PCH Headphone (/dev/input/event13)
[ 231.217] (II) No input driver specified, ignoring this device.
[ 231.217] (II) This device may have been added with another device file.
[ 231.217] (II) config/udev: Adding input device HDA Intel PCH HDMI/DP,pcm=3 (/dev/input/event14)
[ 231.218] (II) config/udev: Adding input device HDA Intel PCH HDMI/DP,pcm=7 (/dev/input/event15)
[ 231.218] (II) No input driver specified, ignoring this device.
[ 231.218] (II) This device may have been added with another device file.
[ 231.218] (II) config/udev: Adding input device HDA Intel PCH HDMI/DP,pcm=8 (/dev/input/event16)
[ 231.219] (II) config/udev: Adding input device AT Translated Set 2 keyboard (/dev/input/event3)
[ 231.219] () AT Translated Set 2 keyboard: Applying InputClass “evdev keyboard catchall”
[ 231.219] () AT Translated Set 2 keyboard: Applying InputClass “libinput keyboard catchall”
[ 231.219] () AT Translated Set 2 keyboard: Applying InputClass “system-keyboard”
[ 231.220] (II) systemd-logind: got fd for /dev/input/event3 13:67 fd 22 paused 0
[ 231.220] (II) Using input driver ‘libinput’ for ‘AT Translated Set 2 keyboard’
[ 231.220] () AT Translated Set 2 keyboard: always reports core events
[ 231.220] () Option “Device” “/dev/input/event3”
[ 231.220] () Option “_source” “server/udev”
[ 231.221] (II) input device ‘AT Translated Set 2 keyboard’, /dev/input/event3 is tagged by udev as: Keyboard
[ 231.221] (II) input device ‘AT Translated Set 2 keyboard’, /dev/input/event3 is a keyboard
[ 231.221] () Option “config_info” “udev:/sys/devices/platform/i8042/serio0/input/input3/event3”
[ 231.221] (II) XINPUT: Adding extended input device “AT Translated Set 2 keyboard” (type: KEYBOARD, id 12)
[ 231.221] () Option “xkb_layout” “it”
[ 231.222] (II) input device ‘AT Translated Set 2 keyboard’, /dev/input/event3 is tagged by udev as: Keyboard
[ 231.222] (II) input device ‘AT Translated Set 2 keyboard’, /dev/input/event3 is a keyboard
[ 231.223] (II) config/udev: Adding input device SynPS/2 Synaptics TouchPad (/dev/input/event7)
[ 231.223] () SynPS/2 Synaptics TouchPad: Applying InputClass “evdev touchpad catchall”
[ 231.223] () SynPS/2 Synaptics TouchPad: Applying InputClass “evdev touchscreen catchall”
[ 231.223] () SynPS/2 Synaptics TouchPad: Applying InputClass “touchpad catchall”
[ 231.223] () SynPS/2 Synaptics TouchPad: Applying InputClass “Default clickpad buttons”
[ 231.223] () SynPS/2 Synaptics TouchPad: Applying InputClass “libinput touchpad catchall”
[ 231.223] () SynPS/2 Synaptics TouchPad: Applying InputClass “libinput touchscreen catchall”
[ 231.223] (II) LoadModule: “synaptics”
[ 231.223] (II) Loading /usr/lib64/xorg/modules/input/synaptics_drv.so
[ 231.235] (II) Module synaptics: vendor=“X.Org Foundation”
[ 231.235] compiled for 1.18.0, module version = 1.8.3
[ 231.235] Module class: X.Org XInput Driver
[ 231.235] ABI class: X.Org XInput driver, version 22.1
[ 231.235] (II) systemd-logind: got fd for /dev/input/event7 13:71 fd 23 paused 0
[ 231.235] (II) Using input driver ‘synaptics’ for ‘SynPS/2 Synaptics TouchPad’
[ 231.235] () SynPS/2 Synaptics TouchPad: always reports core events
[ 231.235] () Option “Device” “/dev/input/event7”
[ 231.244] (II) synaptics: SynPS/2 Synaptics TouchPad: found clickpad property
[ 231.244] (–) synaptics: SynPS/2 Synaptics TouchPad: x-axis range 1326 - 5656 (res 41)
[ 231.244] (–) synaptics: SynPS/2 Synaptics TouchPad: y-axis range 1200 - 4712 (res 58)
[ 231.244] (–) synaptics: SynPS/2 Synaptics TouchPad: pressure range 0 - 255
[ 231.244] (–) synaptics: SynPS/2 Synaptics TouchPad: finger width range 0 - 15
[ 231.244] (–) synaptics: SynPS/2 Synaptics TouchPad: buttons: left double triple
[ 231.244] (–) synaptics: SynPS/2 Synaptics TouchPad: Vendor 0x2 Product 0x7
[ 231.244] () Option “SoftButtonAreas” “50% 0 82% 0 0 0 0 0”
[ 231.244] (–) synaptics: SynPS/2 Synaptics TouchPad: touchpad found
[ 231.244] () SynPS/2 Synaptics TouchPad: always reports core events
[ 231.244] () Option “config_info” “udev:/sys/devices/platform/i8042/serio1/input/input5/event7”
[ 231.244] (II) XINPUT: Adding extended input device “SynPS/2 Synaptics TouchPad” (type: TOUCHPAD, id 13)
[ 231.244] () synaptics: SynPS/2 Synaptics TouchPad: (accel) MinSpeed is now constant deceleration 2.5
[ 231.244] () synaptics: SynPS/2 Synaptics TouchPad: (accel) MaxSpeed is now 1.75
[ 231.244] () synaptics: SynPS/2 Synaptics TouchPad: (accel) AccelFactor is now 0.036
[ 231.245] () SynPS/2 Synaptics TouchPad: (accel) keeping acceleration scheme 1
[ 231.245] () SynPS/2 Synaptics TouchPad: (accel) acceleration profile 1
[ 231.245] () SynPS/2 Synaptics TouchPad: (accel) acceleration factor: 2.000
[ 231.245] () SynPS/2 Synaptics TouchPad: (accel) acceleration threshold: 4
[ 231.245] (–) synaptics: SynPS/2 Synaptics TouchPad: touchpad found
[ 231.246] (II) config/udev: Adding input device SynPS/2 Synaptics TouchPad (/dev/input/mouse1)
[ 231.246] (II) No input driver specified, ignoring this device.
[ 231.246] (II) This device may have been added with another device file.
[ 231.246] (II) config/udev: Adding input device ST LIS3LV02DL Accelerometer (/dev/input/event8)
[ 231.247] (II) config/udev: Adding input device ST LIS3LV02DL Accelerometer (/dev/input/js0)
[ 231.247] (II) No input driver specified, ignoring this device.
[ 231.247] (II) This device may have been added with another device file.
[ 231.251] (II) config/udev: Adding input device HP Wireless hotkeys (/dev/input/event9)
[ 231.251] () HP Wireless hotkeys: Applying InputClass “evdev keyboard catchall”
[ 231.251] () HP Wireless hotkeys: Applying InputClass “libinput keyboard catchall”
[ 231.251] () HP Wireless hotkeys: Applying InputClass “system-keyboard”
[ 231.253] (II) systemd-logind: got fd for /dev/input/event9 13:73 fd 24 paused 0
[ 231.253] (II) Using input driver ‘libinput’ for ‘HP Wireless hotkeys’
[ 231.253] () HP Wireless hotkeys: always reports core events
[ 231.253] () Option “Device” “/dev/input/event9”
[ 231.253] () Option “_source” “server/udev”
[ 231.253] (II) input device ‘HP Wireless hotkeys’, /dev/input/event9 is tagged by udev as: Keyboard
[ 231.253] (II) input device ‘HP Wireless hotkeys’, /dev/input/event9 is a keyboard
[ 231.254] () Option “config_info” “udev:/sys/devices/virtual/input/input10/event9”
[ 231.254] (II) XINPUT: Adding extended input device “HP Wireless hotkeys” (type: KEYBOARD, id 14)
[ 231.254] () Option “xkb_layout” “it”
[ 231.254] (II) input device ‘HP Wireless hotkeys’, /dev/input/event9 is tagged by udev as: Keyboard
[ 231.254] (II) input device ‘HP Wireless hotkeys’, /dev/input/event9 is a keyboard
[ 231.255] (II) config/udev: Adding input device HP WMI hotkeys (/dev/input/event11)
[ 231.255] () HP WMI hotkeys: Applying InputClass “evdev keyboard catchall”
[ 231.255] () HP WMI hotkeys: Applying InputClass “libinput keyboard catchall”
[ 231.255] () HP WMI hotkeys: Applying InputClass “system-keyboard”
[ 231.256] (II) systemd-logind: got fd for /dev/input/event11 13:75 fd 25 paused 0
[ 231.256] (II) Using input driver ‘libinput’ for ‘HP WMI hotkeys’
[ 231.256] () HP WMI hotkeys: always reports core events
[ 231.256] () Option “Device” “/dev/input/event11”
[ 231.256] () Option “_source” “server/udev”
[ 231.257] (II) input device ‘HP WMI hotkeys’, /dev/input/event11 is tagged by udev as: Keyboard
[ 231.257] (II) input device ‘HP WMI hotkeys’, /dev/input/event11 is a keyboard
[ 231.257] () Option “config_info” “udev:/sys/devices/virtual/input/input12/event11”
[ 231.257] (II) XINPUT: Adding extended input device “HP WMI hotkeys” (type: KEYBOARD, id 15)
[ 231.257] () Option “xkb_layout” “it”
[ 231.258] (II) input device ‘HP WMI hotkeys’, /dev/input/event11 is tagged by udev as: Keyboard
[ 231.258] (II) input device ‘HP WMI hotkeys’, /dev/input/event11 is a keyboard
[ 239.421] () Option “fd” “14”
[ 239.421] () Option “fd” “17”
[ 239.421] () Option “fd” “18”
[ 239.421] () Option “fd” “19”
[ 239.421] () Option “fd” “20”
[ 239.421] () Option “fd” “21”
[ 239.421] () Option “fd” “22”
[ 239.421] () Option “fd” “24”
[ 239.421] (**) Option “fd” “25”
[ 239.422] (II) UnloadModule: “libinput”
[ 239.422] (II) systemd-logind: releasing fd for 13:75
[ 239.429] (II) UnloadModule: “libinput”
[ 239.429] (II) systemd-logind: releasing fd for 13:73
[ 239.450] (II) UnloadModule: “synaptics”
[ 239.450] (II) systemd-logind: releasing fd for 13:71
[ 239.459] (II) UnloadModule: “libinput”
[ 239.459] (II) systemd-logind: releasing fd for 13:67
[ 239.468] (II) UnloadModule: “libinput”
[ 239.468] (II) systemd-logind: releasing fd for 13:70
[ 239.477] (II) UnloadModule: “libinput”
[ 239.477] (II) systemd-logind: releasing fd for 13:74
[ 239.486] (II) UnloadModule: “libinput”
[ 239.486] (II) systemd-logind: releasing fd for 13:65
[ 239.492] (II) UnloadModule: “libinput”
[ 239.492] (II) systemd-logind: releasing fd for 13:69
[ 239.498] (II) UnloadModule: “libinput”
[ 239.498] (II) systemd-logind: releasing fd for 13:68
[ 239.507] (II) UnloadModule: “libinput”
[ 239.507] (II) systemd-logind: releasing fd for 13:66
[ 240.577] (II) Server terminated successfully (0). Closing log file.
The only way to somehow exploit the nvidia gpu is to install bumblebee for closed source using kdm. That succedes no problem.
Any chance to have an nvidia driver to avoid the bumblebee workaround?
