I’m having a similar problem:
- running Fedora 24, 64 bit
uname -a
Linux beast 4.6.4-301.fc24.x86_64 #1 SMP Tue Jul 12 11:50:00 UTC 2016 x86_64 x86_64 x86_64 GNU/Linux
glxinfo | grep -i vend
server glx vendor string: SGI
client glx vendor string: Mesa Project and SGI
Vendor: VMware, Inc. (0xffffffff)
OpenGL vendor string: VMware, Inc.
lspci | grep NVI
01:00.0 VGA compatible controller: NVIDIA Corporation GM200 [GeForce GTX 980 Ti] (rev a1)
This is a high end workstation with plenty of RAM, NVMe disks, 32 CPUs… but the UI of Gnome3 is being extremely slow and even typing this message the letters appear with delay on the screen.
I never installed any product from VMware.
nouevau is blacklisted:
lsmod | grep nvidia
nvidia_drm 45056 2
nvidia_modeset 765952 3 nvidia_drm
nvidia 11067392 53 nvidia_modeset
drm_kms_helper 143360 1 nvidia_drm
drm 339968 5 drm_kms_helper,nvidia_drm
Running nVidia Driver Version: 367.27
Follows the Xorx.0.log:
[ 9.106] (--) Log file renamed from "/var/log/Xorg.pid-1883.log" to "/var/log/Xorg.0.log"
[ 9.107]
X.Org X Server 1.18.4
Release Date: 2016-07-19
[ 9.107] X Protocol Version 11, Revision 0
[ 9.107] Build Operating System: 4.6.3-300.fc24.x86_64
[ 9.107] Current Operating System: Linux beast 4.6.4-301.fc24.x86_64 #1 SMP Tue Jul 12 11:50:00 UTC 2016 x86_64
[ 9.107] Kernel command line: BOOT_IMAGE=/vmlinuz-4.6.4-301.fc24.x86_64 root=UUID=118f0acd-ce66-4f4a-b393-2051021b4d74 ro rd.driver.blacklist=nouveau LANG=en_GB.UTF-8
[ 9.107] Build Date: 19 July 2016 06:08:11PM
[ 9.107] Build ID: xorg-x11-server 1.18.4-1.fc24
[ 9.107] Current version of pixman: 0.34.0
[ 9.107] Before reporting problems, check http://wiki.x.org
to make sure that you have the latest version.
[ 9.107] Markers: (--) probed, (**) from config file, (==) default setting,
(++) from command line, (!!) notice, (II) informational,
(WW) warning, (EE) error, (NI) not implemented, (??) unknown.
[ 9.107] (==) Log file: "/var/log/Xorg.0.log", Time: Tue Aug 2 13:48:26 2016
[ 9.108] (==) Using config file: "/etc/X11/xorg.conf"
[ 9.108] (==) Using config directory: "/etc/X11/xorg.conf.d"
[ 9.108] (==) Using system config directory "/usr/share/X11/xorg.conf.d"
[ 9.110] (==) ServerLayout "Layout0"
[ 9.110] (**) |-->Screen "Screen0" (0)
[ 9.110] (**) | |-->Monitor "Monitor0"
[ 9.111] (**) | |-->Device "Device0"
[ 9.111] (**) |-->Input Device "Keyboard0"
[ 9.111] (**) |-->Input Device "Mouse0"
[ 9.111] (==) Automatically adding devices
[ 9.111] (==) Automatically enabling devices
[ 9.111] (==) Automatically adding GPU devices
[ 9.111] (==) Max clients allowed: 256, resource mask: 0x1fffff
[ 9.112] (**) FontPath set to:
/usr/share/fonts/default/Type1,
catalogue:/etc/X11/fontpath.d,
built-ins
[ 9.112] (==) ModulePath set to "/usr/lib64/xorg/modules"
[ 9.112] (WW) Hotplugging is on, devices using drivers 'kbd', 'mouse' or 'vmmouse' will be disabled.
[ 9.112] (WW) Disabling Keyboard0
[ 9.113] (WW) Disabling Mouse0
[ 9.113] (II) Loader magic: 0x824dc0
[ 9.113] (II) Module ABI versions:
[ 9.113] X.Org ANSI C Emulation: 0.4
[ 9.113] X.Org Video Driver: 20.0
[ 9.113] X.Org XInput driver : 22.1
[ 9.113] X.Org Server Extension : 9.0
[ 9.114] (++) using VT number 1
[ 9.116] (II) systemd-logind: took control of session /org/freedesktop/login1/session/c2
[ 9.116] (II) xfree86: Adding drm device (/dev/dri/card0)
[ 9.117] (II) systemd-logind: got fd for /dev/dri/card0 226:0 fd 9 paused 0
[ 9.120] (--) PCI:*(0:1:0:0) 10de:17c8:1043:855c rev 161, Mem @ 0xfa000000/16777216, 0xc0000000/268435456, 0xd0000000/33554432, I/O @ 0x0000e000/128, BIOS @ 0x????????/131072
[ 9.120] (II) LoadModule: "glx"
[ 9.120] (II) Loading /usr/lib64/xorg/modules/extensions/libglx.so
[ 9.123] (II) Module glx: vendor="X.Org Foundation"
[ 9.123] compiled for 1.18.4, module version = 1.0.0
[ 9.123] ABI class: X.Org Server Extension, version 9.0
[ 9.123] (==) AIGLX enabled
[ 9.123] (II) LoadModule: "nvidia"
[ 9.125] (II) Loading /usr/lib64/xorg/modules/drivers/nvidia_drv.so
[ 9.142] (II) Module nvidia: vendor="NVIDIA Corporation"
[ 9.142] compiled for 4.0.2, module version = 1.0.0
[ 9.142] Module class: X.Org Video Driver
[ 9.147] (II) NVIDIA dlloader X Driver 367.27 Thu Jun 9 17:57:30 PDT 2016
[ 9.147] (II) NVIDIA Unified Driver for all Supported NVIDIA GPUs
[ 9.147] (II) systemd-logind: releasing fd for 226:0
[ 9.147] (II) Loading sub module "fb"
[ 9.147] (II) LoadModule: "fb"
[ 9.147] (II) Loading /usr/lib64/xorg/modules/libfb.so
[ 9.148] (II) Module fb: vendor="X.Org Foundation"
[ 9.148] compiled for 1.18.4, module version = 1.0.0
[ 9.148] ABI class: X.Org ANSI C Emulation, version 0.4
[ 9.148] (II) Loading sub module "wfb"
[ 9.148] (II) LoadModule: "wfb"
[ 9.148] (II) Loading /usr/lib64/xorg/modules/libwfb.so
[ 9.149] (II) Module wfb: vendor="X.Org Foundation"
[ 9.149] compiled for 1.18.4, module version = 1.0.0
[ 9.149] ABI class: X.Org ANSI C Emulation, version 0.4
[ 9.149] (II) Loading sub module "ramdac"
[ 9.149] (II) LoadModule: "ramdac"
[ 9.149] (II) Module "ramdac" already built-in
[ 9.149] (**) NVIDIA(0): Depth 24, (--) framebuffer bpp 32
[ 9.149] (==) NVIDIA(0): RGB weight 888
[ 9.149] (==) NVIDIA(0): Default visual is TrueColor
[ 9.149] (==) NVIDIA(0): Using gamma correction (1.0, 1.0, 1.0)
[ 9.149] (**) NVIDIA(0): Enabling 2D acceleration
[ 9.149] (EE) NVIDIA(0): Failed to initialize the GLX module; please check in your X
[ 9.149] (EE) NVIDIA(0): log file that the GLX module has been loaded in your X
[ 9.149] (EE) NVIDIA(0): server, and that the module is the NVIDIA GLX module. If
[ 9.149] (EE) NVIDIA(0): you continue to encounter problems, Please try
[ 9.149] (EE) NVIDIA(0): reinstalling the NVIDIA driver.
[ 9.840] (--) NVIDIA(0): Valid display device(s) on GPU-0 at PCI:1:0:0
[ 9.840] (--) NVIDIA(0): CRT-0
[ 9.840] (--) NVIDIA(0): DFP-0 (boot)
[ 9.840] (--) NVIDIA(0): DFP-1
[ 9.840] (--) NVIDIA(0): DFP-2
[ 9.840] (--) NVIDIA(0): DFP-3
[ 9.840] (--) NVIDIA(0): DFP-4
[ 9.840] (--) NVIDIA(0): DFP-5
[ 9.840] (--) NVIDIA(0): DFP-6
[ 9.840] (--) NVIDIA(0): DFP-7
[ 9.855] (--) NVIDIA(0): CRT-0: disconnected
[ 9.855] (--) NVIDIA(0): CRT-0: 400.0 MHz maximum pixel clock
[ 9.885] (--) NVIDIA(0): DELL U3011 (DFP-0): connected
[ 9.885] (--) NVIDIA(0): DELL U3011 (DFP-0): Internal TMDS
[ 9.885] (--) NVIDIA(0): DELL U3011 (DFP-0): 330.0 MHz maximum pixel clock
[ 9.886] (--) NVIDIA(0): DFP-1: disconnected
[ 9.886] (--) NVIDIA(0): DFP-1: Internal TMDS
[ 9.886] (--) NVIDIA(0): DFP-1: 330.0 MHz maximum pixel clock
[ 9.886] (--) NVIDIA(0): DFP-2: disconnected
[ 9.886] (--) NVIDIA(0): DFP-2: Internal DisplayPort
[ 9.886] (--) NVIDIA(0): DFP-2: 960.0 MHz maximum pixel clock
[ 9.886] (--) NVIDIA(0): DFP-3: disconnected
[ 9.886] (--) NVIDIA(0): DFP-3: Internal TMDS
[ 9.886] (--) NVIDIA(0): DFP-3: 330.0 MHz maximum pixel clock
[ 9.886] (--) NVIDIA(0): DFP-4: disconnected
[ 9.886] (--) NVIDIA(0): DFP-4: Internal DisplayPort
[ 9.886] (--) NVIDIA(0): DFP-4: 960.0 MHz maximum pixel clock
[ 9.886] (--) NVIDIA(0): DFP-5: disconnected
[ 9.886] (--) NVIDIA(0): DFP-5: Internal TMDS
[ 9.886] (--) NVIDIA(0): DFP-5: 330.0 MHz maximum pixel clock
[ 9.886] (--) NVIDIA(0): DFP-6: disconnected
[ 9.886] (--) NVIDIA(0): DFP-6: Internal DisplayPort
[ 9.886] (--) NVIDIA(0): DFP-6: 960.0 MHz maximum pixel clock
[ 9.886] (--) NVIDIA(0): DFP-7: disconnected
[ 9.886] (--) NVIDIA(0): DFP-7: Internal TMDS
[ 9.886] (--) NVIDIA(0): DFP-7: 330.0 MHz maximum pixel clock
[ 9.887] (II) NVIDIA(0): NVIDIA GPU GeForce GTX 980 Ti (GM200-A) at PCI:1:0:0 (GPU-0)
[ 9.887] (--) NVIDIA(0): Memory: 6291456 kBytes
[ 9.887] (--) NVIDIA(0): VideoBIOS: 84.00.36.00.83
[ 9.887] (II) NVIDIA(0): Detected PCI Express Link width: 16X
[ 9.887] (**) NVIDIA(0): Using HorizSync/VertRefresh ranges from the EDID for display
[ 9.887] (**) NVIDIA(0): device DELL U3011 (DFP-0) (Using EDID frequencies has been
[ 9.887] (**) NVIDIA(0): enabled on all display devices.)
[ 9.888] (==) NVIDIA(0):
[ 9.888] (==) NVIDIA(0): No modes were requested; the default mode "nvidia-auto-select"
[ 9.888] (==) NVIDIA(0): will be used as the requested mode.
[ 9.889] (II) NVIDIA(0): Validated MetaModes:
[ 9.889] (II) NVIDIA(0): "DFP-0:nvidia-auto-select"
[ 9.889] (II) NVIDIA(0): Virtual screen size determined to be 2560 x 1600
[ 9.896] (--) NVIDIA(0): DPI set to (101, 101); computed from "UseEdidDpi" X config
[ 9.896] (--) NVIDIA(0): option
[ 9.896] (--) Depth 24 pixmap format is 32 bpp
[ 9.897] (II) NVIDIA: Using 12288.00 MB of virtual memory for indirect memory
[ 9.897] (II) NVIDIA: access.
[ 9.900] (II) NVIDIA(0): ACPI: failed to connect to the ACPI event daemon; the daemon
[ 9.900] (II) NVIDIA(0): may not be running or the "AcpidSocketPath" X
[ 9.900] (II) NVIDIA(0): configuration option may not be set correctly. When the
[ 9.900] (II) NVIDIA(0): ACPI event daemon is available, the NVIDIA X driver will
[ 9.900] (II) NVIDIA(0): try to use it to receive ACPI event notifications. For
[ 9.900] (II) NVIDIA(0): details, please see the "ConnectToAcpid" and
[ 9.900] (II) NVIDIA(0): "AcpidSocketPath" X configuration options in Appendix B: X
[ 9.900] (II) NVIDIA(0): Config Options in the README.
[ 9.913] (II) NVIDIA(0): Setting mode "DFP-0:nvidia-auto-select"
[ 9.965] (==) NVIDIA(0): Disabling shared memory pixmaps
[ 9.965] (==) NVIDIA(0): Backing store enabled
[ 9.965] (==) NVIDIA(0): Silken mouse enabled
[ 9.966] (**) NVIDIA(0): DPMS enabled
[ 9.966] (II) Loading sub module "dri2"
[ 9.966] (II) LoadModule: "dri2"
[ 9.966] (II) Module "dri2" already built-in
[ 9.966] (II) NVIDIA(0): [DRI2] Setup complete
[ 9.966] (II) NVIDIA(0): [DRI2] VDPAU driver: nvidia
[ 9.966] (--) RandR disabled
[ 9.968] (II) SELinux: Disabled by boolean
[ 9.969] (II) AIGLX: Screen 0 is not DRI2 capable
[ 9.969] (EE) AIGLX: reverting to software rendering
[ 9.972] (II) AIGLX: enabled GLX_MESA_copy_sub_buffer
[ 9.973] (II) AIGLX: Loaded and initialized swrast
[ 9.973] (II) GLX: Initialized DRISWRAST GL provider for screen 0
[ 10.012] (II) config/udev: Adding input device Power Button (/dev/input/event1)
[ 10.012] (**) Power Button: Applying InputClass "evdev keyboard catchall"
[ 10.012] (**) Power Button: Applying InputClass "libinput keyboard catchall"
[ 10.012] (**) Power Button: Applying InputClass "system-keyboard"
[ 10.012] (II) LoadModule: "libinput"
[ 10.012] (II) Loading /usr/lib64/xorg/modules/input/libinput_drv.so
[ 10.015] (II) Module libinput: vendor="X.Org Foundation"
[ 10.015] compiled for 1.18.3, module version = 0.19.0
[ 10.015] Module class: X.Org XInput Driver
[ 10.015] ABI class: X.Org XInput driver, version 22.1
[ 10.015] (II) systemd-logind: got fd for /dev/input/event1 13:65 fd 25 paused 0
[ 10.015] (II) Using input driver 'libinput' for 'Power Button'
[ 10.015] (**) Power Button: always reports core events
[ 10.015] (**) Option "Device" "/dev/input/event1"
[ 10.015] (**) Option "_source" "server/udev"
[ 10.016] (II) input device 'Power Button', /dev/input/event1 is tagged by udev as: Keyboard
[ 10.016] (II) input device 'Power Button', /dev/input/event1 is a keyboard
[ 10.016] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXPWRBN:00/input/input1/event1"
[ 10.016] (II) XINPUT: Adding extended input device "Power Button" (type: KEYBOARD, id 6)
[ 10.016] (**) Option "xkb_layout" "gb"
[ 10.028] (II) input device 'Power Button', /dev/input/event1 is tagged by udev as: Keyboard
[ 10.028] (II) input device 'Power Button', /dev/input/event1 is a keyboard
[ 10.028] (II) config/udev: Adding input device Power Button (/dev/input/event0)
[ 10.028] (**) Power Button: Applying InputClass "evdev keyboard catchall"
[ 10.028] (**) Power Button: Applying InputClass "libinput keyboard catchall"
[ 10.028] (**) Power Button: Applying InputClass "system-keyboard"
[ 10.029] (II) systemd-logind: got fd for /dev/input/event0 13:64 fd 28 paused 0
[ 10.029] (II) Using input driver 'libinput' for 'Power Button'
[ 10.029] (**) Power Button: always reports core events
[ 10.029] (**) Option "Device" "/dev/input/event0"
[ 10.029] (**) Option "_source" "server/udev"
[ 10.029] (II) input device 'Power Button', /dev/input/event0 is tagged by udev as: Keyboard
[ 10.029] (II) input device 'Power Button', /dev/input/event0 is a keyboard
[ 10.029] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0C:00/input/input0/event0"
[ 10.029] (II) XINPUT: Adding extended input device "Power Button" (type: KEYBOARD, id 7)
[ 10.029] (**) Option "xkb_layout" "gb"
[ 10.030] (II) input device 'Power Button', /dev/input/event0 is tagged by udev as: Keyboard
[ 10.030] (II) input device 'Power Button', /dev/input/event0 is a keyboard
[ 10.030] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=3 (/dev/input/event18)
[ 10.030] (II) No input driver specified, ignoring this device.
[ 10.030] (II) This device may have been added with another device file.
[ 10.030] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=7 (/dev/input/event19)
[ 10.030] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=8 (/dev/input/event20)
[ 10.031] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=9 (/dev/input/event21)
[ 10.031] (II) No input driver specified, ignoring this device.
[ 10.031] (II) This device may have been added with another device file.
[ 10.031] (II) config/udev: Adding input device HDA Intel PCH Front Mic (/dev/input/event10)
[ 10.031] (II) config/udev: Adding input device HDA Intel PCH Rear Mic (/dev/input/event11)
[ 10.031] (II) config/udev: Adding input device HDA Intel PCH Line (/dev/input/event12)
[ 10.031] (II) config/udev: Adding input device HDA Intel PCH Line Out Front (/dev/input/event13)
[ 10.032] (II) config/udev: Adding input device HDA Intel PCH Line Out Surround (/dev/input/event14)
[ 10.032] (II) No input driver specified, ignoring this device.
[ 10.032] (II) This device may have been added with another device file.
[ 10.032] (II) config/udev: Adding input device HDA Intel PCH Line Out CLFE (/dev/input/event15)
[ 10.032] (II) config/udev: Adding input device HDA Intel PCH Line Out Side (/dev/input/event16)
[ 10.032] (II) config/udev: Adding input device HDA Intel PCH Front Headphone (/dev/input/event17)
[ 10.033] (II) config/udev: Adding input device Logitech G700s Rechargeable Gaming Mouse (/dev/input/event4)
[ 10.033] (**) Logitech G700s Rechargeable Gaming Mouse: Applying InputClass "evdev pointer catchall"
[ 10.033] (**) Logitech G700s Rechargeable Gaming Mouse: Applying InputClass "libinput pointer catchall"
[ 10.084] (II) systemd-logind: got fd for /dev/input/event4 13:68 fd 29 paused 0
[ 10.084] (II) Using input driver 'libinput' for 'Logitech G700s Rechargeable Gaming Mouse'
[ 10.084] (**) Logitech G700s Rechargeable Gaming Mouse: always reports core events
[ 10.084] (**) Option "Device" "/dev/input/event4"
[ 10.084] (**) Option "_source" "server/udev"
[ 10.084] (II) input device 'Logitech G700s Rechargeable Gaming Mouse', /dev/input/event4 is tagged by udev as: Mouse
[ 10.084] (II) input device 'Logitech G700s Rechargeable Gaming Mouse', /dev/input/event4 is a pointer caps
[ 10.084] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:1d.0/usb2/2-1/2-1.1/2-1.1.1/2-1.1.1:1.0/0003:046D:C07C.0003/input/input7/event4"
[ 10.084] (II) XINPUT: Adding extended input device "Logitech G700s Rechargeable Gaming Mouse" (type: MOUSE, id 8)
[ 10.084] (**) Option "AccelerationScheme" "none"
[ 10.084] (**) Logitech G700s Rechargeable Gaming Mouse: (accel) selected scheme none/0
[ 10.084] (**) Logitech G700s Rechargeable Gaming Mouse: (accel) acceleration factor: 2.000
[ 10.084] (**) Logitech G700s Rechargeable Gaming Mouse: (accel) acceleration threshold: 4
[ 10.085] (II) input device 'Logitech G700s Rechargeable Gaming Mouse', /dev/input/event4 is tagged by udev as: Mouse
[ 10.085] (II) input device 'Logitech G700s Rechargeable Gaming Mouse', /dev/input/event4 is a pointer caps
[ 10.085] (II) config/udev: Adding input device Logitech G700s Rechargeable Gaming Mouse (/dev/input/mouse0)
[ 10.085] (II) No input driver specified, ignoring this device.
[ 10.085] (II) This device may have been added with another device file.
[ 10.086] (II) config/udev: Adding input device Logitech G700s Rechargeable Gaming Mouse (/dev/input/event5)
[ 10.086] (**) Logitech G700s Rechargeable Gaming Mouse: Applying InputClass "evdev keyboard catchall"
[ 10.086] (**) Logitech G700s Rechargeable Gaming Mouse: Applying InputClass "libinput keyboard catchall"
[ 10.086] (**) Logitech G700s Rechargeable Gaming Mouse: Applying InputClass "system-keyboard"
[ 10.086] (II) systemd-logind: got fd for /dev/input/event5 13:69 fd 30 paused 0
[ 10.086] (II) Using input driver 'libinput' for 'Logitech G700s Rechargeable Gaming Mouse'
[ 10.086] (**) Logitech G700s Rechargeable Gaming Mouse: always reports core events
[ 10.086] (**) Option "Device" "/dev/input/event5"
[ 10.086] (**) Option "_source" "server/udev"
[ 10.086] (II) input device 'Logitech G700s Rechargeable Gaming Mouse', /dev/input/event5 is tagged by udev as: Keyboard
[ 10.086] (II) input device 'Logitech G700s Rechargeable Gaming Mouse', /dev/input/event5 is a keyboard
[ 10.086] (II) libinput: Logitech G700s Rechargeable Gaming Mouse: needs a virtual subdevice
[ 10.086] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:1d.0/usb2/2-1/2-1.1/2-1.1.1/2-1.1.1:1.1/0003:046D:C07C.0004/input/input8/event5"
[ 10.086] (II) XINPUT: Adding extended input device "Logitech G700s Rechargeable Gaming Mouse" (type: MOUSE, id 9)
[ 10.086] (**) Option "AccelerationScheme" "none"
[ 10.087] (**) Logitech G700s Rechargeable Gaming Mouse: (accel) selected scheme none/0
[ 10.087] (**) Logitech G700s Rechargeable Gaming Mouse: (accel) acceleration factor: 2.000
[ 10.087] (**) Logitech G700s Rechargeable Gaming Mouse: (accel) acceleration threshold: 4
[ 10.087] (II) input device 'Logitech G700s Rechargeable Gaming Mouse', /dev/input/event5 is tagged by udev as: Keyboard
[ 10.087] (II) input device 'Logitech G700s Rechargeable Gaming Mouse', /dev/input/event5 is a keyboard
[ 10.087] (II) config/udev: Adding input device Yubico Yubico Yubikey II (/dev/input/event8)
[ 10.087] (**) Yubico Yubico Yubikey II: Applying InputClass "evdev keyboard catchall"
[ 10.087] (**) Yubico Yubico Yubikey II: Applying InputClass "libinput keyboard catchall"
[ 10.087] (**) Yubico Yubico Yubikey II: Applying InputClass "system-keyboard"
[ 10.088] (II) systemd-logind: got fd for /dev/input/event8 13:72 fd 31 paused 0
[ 10.088] (II) Using input driver 'libinput' for 'Yubico Yubico Yubikey II'
[ 10.088] (**) Yubico Yubico Yubikey II: always reports core events
[ 10.088] (**) Option "Device" "/dev/input/event8"
[ 10.088] (**) Option "_source" "server/udev"
[ 10.088] (II) input device 'Yubico Yubico Yubikey II', /dev/input/event8 is tagged by udev as: Keyboard
[ 10.088] (II) input device 'Yubico Yubico Yubikey II', /dev/input/event8 is a keyboard
[ 10.088] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:1d.0/usb2/2-1/2-1.1/2-1.1.2/2-1.1.2.1/2-1.1.2.1.2/2-1.1.2.1.2:1.0/0003:1050:0010.0007/input/input11/event8"
[ 10.088] (II) XINPUT: Adding extended input device "Yubico Yubico Yubikey II" (type: KEYBOARD, id 10)
[ 10.088] (**) Option "xkb_layout" "gb"
[ 10.089] (II) input device 'Yubico Yubico Yubikey II', /dev/input/event8 is tagged by udev as: Keyboard
[ 10.089] (II) input device 'Yubico Yubico Yubikey II', /dev/input/event8 is a keyboard
[ 10.089] (II) config/udev: Adding input device Logitech USB Receiver (/dev/input/event6)
[ 10.089] (**) Logitech USB Receiver: Applying InputClass "evdev pointer catchall"
[ 10.089] (**) Logitech USB Receiver: Applying InputClass "libinput pointer catchall"
[ 10.141] (II) systemd-logind: got fd for /dev/input/event6 13:70 fd 32 paused 0
[ 10.141] (II) Using input driver 'libinput' for 'Logitech USB Receiver'
[ 10.141] (**) Logitech USB Receiver: always reports core events
[ 10.141] (**) Option "Device" "/dev/input/event6"
[ 10.141] (**) Option "_source" "server/udev"
[ 10.141] (II) input device 'Logitech USB Receiver', /dev/input/event6 is tagged by udev as: Mouse
[ 10.141] (II) Device 'Logitech USB Receiver' set to 1000 DPI
[ 10.141] (II) input device 'Logitech USB Receiver', /dev/input/event6 is a pointer caps
[ 10.141] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:1d.0/usb2/2-1/2-1.1/2-1.1.4/2-1.1.4:1.0/0003:046D:C531.0005/input/input9/event6"
[ 10.141] (II) XINPUT: Adding extended input device "Logitech USB Receiver" (type: MOUSE, id 11)
[ 10.141] (**) Option "AccelerationScheme" "none"
[ 10.141] (**) Logitech USB Receiver: (accel) selected scheme none/0
[ 10.141] (**) Logitech USB Receiver: (accel) acceleration factor: 2.000
[ 10.141] (**) Logitech USB Receiver: (accel) acceleration threshold: 4
[ 10.142] (II) input device 'Logitech USB Receiver', /dev/input/event6 is tagged by udev as: Mouse
[ 10.142] (II) Device 'Logitech USB Receiver' set to 1000 DPI
[ 10.142] (II) input device 'Logitech USB Receiver', /dev/input/event6 is a pointer caps
[ 10.142] (II) config/udev: Adding input device Logitech USB Receiver (/dev/input/mouse1)
[ 10.142] (II) No input driver specified, ignoring this device.
[ 10.142] (II) This device may have been added with another device file.
[ 10.142] (II) config/udev: Adding input device Logitech USB Receiver (/dev/input/event7)
[ 10.142] (**) Logitech USB Receiver: Applying InputClass "evdev keyboard catchall"
[ 10.142] (**) Logitech USB Receiver: Applying InputClass "libinput keyboard catchall"
[ 10.142] (**) Logitech USB Receiver: Applying InputClass "system-keyboard"
[ 10.143] (II) systemd-logind: got fd for /dev/input/event7 13:71 fd 33 paused 0
[ 10.143] (II) Using input driver 'libinput' for 'Logitech USB Receiver'
[ 10.143] (**) Logitech USB Receiver: always reports core events
[ 10.143] (**) Option "Device" "/dev/input/event7"
[ 10.143] (**) Option "_source" "server/udev"
[ 10.143] (II) input device 'Logitech USB Receiver', /dev/input/event7 is tagged by udev as: Keyboard
[ 10.143] (II) input device 'Logitech USB Receiver', /dev/input/event7 is a keyboard
[ 10.143] (II) libinput: Logitech USB Receiver: needs a virtual subdevice
[ 10.143] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:1d.0/usb2/2-1/2-1.1/2-1.1.4/2-1.1.4:1.1/0003:046D:C531.0006/input/input10/event7"
[ 10.143] (II) XINPUT: Adding extended input device "Logitech USB Receiver" (type: MOUSE, id 12)
[ 10.143] (**) Option "AccelerationScheme" "none"
[ 10.143] (**) Logitech USB Receiver: (accel) selected scheme none/0
[ 10.143] (**) Logitech USB Receiver: (accel) acceleration factor: 2.000
[ 10.143] (**) Logitech USB Receiver: (accel) acceleration threshold: 4
[ 10.144] (II) input device 'Logitech USB Receiver', /dev/input/event7 is tagged by udev as: Keyboard
[ 10.144] (II) input device 'Logitech USB Receiver', /dev/input/event7 is a keyboard
[ 10.144] (II) config/udev: Adding input device CM Storm Quickfire TKL 6keys (/dev/input/event2)
[ 10.144] (**) CM Storm Quickfire TKL 6keys: Applying InputClass "evdev keyboard catchall"
[ 10.144] (**) CM Storm Quickfire TKL 6keys: Applying InputClass "libinput keyboard catchall"
[ 10.144] (**) CM Storm Quickfire TKL 6keys: Applying InputClass "system-keyboard"
[ 10.145] (II) systemd-logind: got fd for /dev/input/event2 13:66 fd 34 paused 0
[ 10.145] (II) Using input driver 'libinput' for 'CM Storm Quickfire TKL 6keys'
[ 10.145] (**) CM Storm Quickfire TKL 6keys: always reports core events
[ 10.145] (**) Option "Device" "/dev/input/event2"
[ 10.145] (**) Option "_source" "server/udev"
[ 10.145] (II) input device 'CM Storm Quickfire TKL 6keys', /dev/input/event2 is tagged by udev as: Keyboard
[ 10.145] (II) input device 'CM Storm Quickfire TKL 6keys', /dev/input/event2 is a keyboard
[ 10.145] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:1d.0/usb2/2-1/2-1.2/2-1.2:1.0/0003:2516:0011.0001/input/input5/event2"
[ 10.145] (II) XINPUT: Adding extended input device "CM Storm Quickfire TKL 6keys" (type: KEYBOARD, id 13)
[ 10.145] (**) Option "xkb_layout" "gb"
[ 10.146] (II) input device 'CM Storm Quickfire TKL 6keys', /dev/input/event2 is tagged by udev as: Keyboard
[ 10.146] (II) input device 'CM Storm Quickfire TKL 6keys', /dev/input/event2 is a keyboard
[ 10.146] (II) config/udev: Adding input device CM Storm Quickfire TKL 6keys (/dev/input/event3)
[ 10.146] (**) CM Storm Quickfire TKL 6keys: Applying InputClass "evdev keyboard catchall"
[ 10.146] (**) CM Storm Quickfire TKL 6keys: Applying InputClass "libinput keyboard catchall"
[ 10.146] (**) CM Storm Quickfire TKL 6keys: Applying InputClass "system-keyboard"
[ 10.146] (II) systemd-logind: got fd for /dev/input/event3 13:67 fd 35 paused 0
[ 10.147] (II) Using input driver 'libinput' for 'CM Storm Quickfire TKL 6keys'
[ 10.147] (**) CM Storm Quickfire TKL 6keys: always reports core events
[ 10.147] (**) Option "Device" "/dev/input/event3"
[ 10.147] (**) Option "_source" "server/udev"
[ 10.147] (II) input device 'CM Storm Quickfire TKL 6keys', /dev/input/event3 is tagged by udev as: Keyboard
[ 10.147] (II) input device 'CM Storm Quickfire TKL 6keys', /dev/input/event3 is a keyboard
[ 10.147] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:1d.0/usb2/2-1/2-1.2/2-1.2:1.1/0003:2516:0011.0002/input/input6/event3"
[ 10.147] (II) XINPUT: Adding extended input device "CM Storm Quickfire TKL 6keys" (type: KEYBOARD, id 14)
[ 10.147] (**) Option "xkb_layout" "gb"
[ 10.148] (II) config/udev: Adding input device Eee PC WMI hotkeys (/dev/input/event9)
[ 10.148] (**) Eee PC WMI hotkeys: Applying InputClass "evdev keyboard catchall"
[ 10.148] (**) Eee PC WMI hotkeys: Applying InputClass "libinput keyboard catchall"
[ 10.148] (**) Eee PC WMI hotkeys: Applying InputClass "system-keyboard"
[ 10.148] (II) systemd-logind: got fd for /dev/input/event9 13:73 fd 36 paused 0
[ 10.148] (II) Using input driver 'libinput' for 'Eee PC WMI hotkeys'
[ 10.148] (**) Eee PC WMI hotkeys: always reports core events
[ 10.148] (**) Option "Device" "/dev/input/event9"
[ 10.148] (**) Option "_source" "server/udev"
[ 10.148] (II) input device 'Eee PC WMI hotkeys', /dev/input/event9 is tagged by udev as: Keyboard
[ 10.148] (II) input device 'Eee PC WMI hotkeys', /dev/input/event9 is a keyboard
[ 10.148] (**) Option "config_info" "udev:/sys/devices/platform/eeepc-wmi/input/input12/event9"
[ 10.148] (II) XINPUT: Adding extended input device "Eee PC WMI hotkeys" (type: KEYBOARD, id 15)
[ 10.148] (**) Option "xkb_layout" "gb"
[ 10.149] (II) input device 'Eee PC WMI hotkeys', /dev/input/event9 is tagged by udev as: Keyboard
[ 10.149] (II) input device 'Eee PC WMI hotkeys', /dev/input/event9 is a keyboard
[ 10.152] (**) Logitech G700s Rechargeable Gaming Mouse: Applying InputClass "evdev keyboard catchall"
[ 10.152] (**) Logitech G700s Rechargeable Gaming Mouse: Applying InputClass "libinput keyboard catchall"
[ 10.152] (**) Logitech G700s Rechargeable Gaming Mouse: Applying InputClass "system-keyboard"
[ 10.152] (II) systemd-logind: returning pre-existing fd for /dev/input/event5 13:69
[ 10.152] (II) Using input driver 'libinput' for 'Logitech G700s Rechargeable Gaming Mouse'
[ 10.152] (**) Logitech G700s Rechargeable Gaming Mouse: always reports core events
[ 10.152] (**) Option "Device" "/dev/input/event5"
[ 10.152] (**) Option "_source" "_driver/libinput"
[ 10.152] (II) libinput: Logitech G700s Rechargeable Gaming Mouse: is a virtual subdevice
[ 10.152] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:1d.0/usb2/2-1/2-1.1/2-1.1.1/2-1.1.1:1.1/0003:046D:C07C.0004/input/input8/event5"
[ 10.152] (II) XINPUT: Adding extended input device "Logitech G700s Rechargeable Gaming Mouse" (type: KEYBOARD, id 16)
[ 10.152] (**) Option "xkb_layout" "gb"
[ 10.152] (**) Logitech USB Receiver: Applying InputClass "evdev keyboard catchall"
[ 10.152] (**) Logitech USB Receiver: Applying InputClass "libinput keyboard catchall"
[ 10.152] (**) Logitech USB Receiver: Applying InputClass "system-keyboard"
[ 10.152] (II) systemd-logind: returning pre-existing fd for /dev/input/event7 13:71
[ 10.152] (II) Using input driver 'libinput' for 'Logitech USB Receiver'
[ 10.152] (**) Logitech USB Receiver: always reports core events
[ 10.153] (**) Option "Device" "/dev/input/event7"
[ 10.153] (**) Option "_source" "_driver/libinput"
[ 10.153] (II) libinput: Logitech USB Receiver: is a virtual subdevice
[ 10.153] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:1d.0/usb2/2-1/2-1.1/2-1.1.4/2-1.1.4:1.1/0003:046D:C531.0006/input/input10/event7"
[ 10.153] (II) XINPUT: Adding extended input device "Logitech USB Receiver" (type: KEYBOARD, id 17)
[ 10.153] (**) Option "xkb_layout" "gb"
[ 10.334] (--) NVIDIA(GPU-0): CRT-0: disconnected
[ 10.334] (--) NVIDIA(GPU-0): CRT-0: 400.0 MHz maximum pixel clock
[ 10.365] (--) NVIDIA(GPU-0): DELL U3011 (DFP-0): connected
[ 10.365] (--) NVIDIA(GPU-0): DELL U3011 (DFP-0): Internal TMDS
[ 10.365] (--) NVIDIA(GPU-0): DELL U3011 (DFP-0): 330.0 MHz maximum pixel clock
[ 10.365] (--) NVIDIA(GPU-0): DFP-1: disconnected
[ 10.365] (--) NVIDIA(GPU-0): DFP-1: Internal TMDS
[ 10.365] (--) NVIDIA(GPU-0): DFP-1: 330.0 MHz maximum pixel clock
[ 10.365] (--) NVIDIA(GPU-0): DFP-2: disconnected
[ 10.365] (--) NVIDIA(GPU-0): DFP-2: Internal DisplayPort
[ 10.365] (--) NVIDIA(GPU-0): DFP-2: 960.0 MHz maximum pixel clock
[ 10.365] (--) NVIDIA(GPU-0): DFP-3: disconnected
[ 10.365] (--) NVIDIA(GPU-0): DFP-3: Internal TMDS
[ 10.365] (--) NVIDIA(GPU-0): DFP-3: 330.0 MHz maximum pixel clock
[ 10.365] (--) NVIDIA(GPU-0): DFP-4: disconnected
[ 10.365] (--) NVIDIA(GPU-0): DFP-4: Internal DisplayPort
[ 10.365] (--) NVIDIA(GPU-0): DFP-4: 960.0 MHz maximum pixel clock
[ 10.365] (--) NVIDIA(GPU-0): DFP-5: disconnected
[ 10.365] (--) NVIDIA(GPU-0): DFP-5: Internal TMDS
[ 10.365] (--) NVIDIA(GPU-0): DFP-5: 330.0 MHz maximum pixel clock
[ 10.365] (--) NVIDIA(GPU-0): DFP-6: disconnected
[ 10.365] (--) NVIDIA(GPU-0): DFP-6: Internal DisplayPort
[ 10.365] (--) NVIDIA(GPU-0): DFP-6: 960.0 MHz maximum pixel clock
[ 10.365] (--) NVIDIA(GPU-0): DFP-7: disconnected
[ 10.365] (--) NVIDIA(GPU-0): DFP-7: Internal TMDS
[ 10.365] (--) NVIDIA(GPU-0): DFP-7: 330.0 MHz maximum pixel clock
[ 10.389] (--) NVIDIA(GPU-0): CRT-0: disconnected
[ 10.389] (--) NVIDIA(GPU-0): CRT-0: 400.0 MHz maximum pixel clock
[ 10.420] (--) NVIDIA(GPU-0): DELL U3011 (DFP-0): connected
[ 10.420] (--) NVIDIA(GPU-0): DELL U3011 (DFP-0): Internal TMDS
[ 10.420] (--) NVIDIA(GPU-0): DELL U3011 (DFP-0): 330.0 MHz maximum pixel clock
[ 10.420] (--) NVIDIA(GPU-0): DFP-1: disconnected
[ 10.420] (--) NVIDIA(GPU-0): DFP-1: Internal TMDS
[ 10.420] (--) NVIDIA(GPU-0): DFP-1: 330.0 MHz maximum pixel clock
[ 10.420] (--) NVIDIA(GPU-0): DFP-2: disconnected
[ 10.420] (--) NVIDIA(GPU-0): DFP-2: Internal DisplayPort
[ 10.420] (--) NVIDIA(GPU-0): DFP-2: 960.0 MHz maximum pixel clock
[ 10.420] (--) NVIDIA(GPU-0): DFP-3: disconnected
[ 10.420] (--) NVIDIA(GPU-0): DFP-3: Internal TMDS
[ 10.420] (--) NVIDIA(GPU-0): DFP-3: 330.0 MHz maximum pixel clock
[ 10.420] (--) NVIDIA(GPU-0): DFP-4: disconnected
[ 10.420] (--) NVIDIA(GPU-0): DFP-4: Internal DisplayPort
[ 10.420] (--) NVIDIA(GPU-0): DFP-4: 960.0 MHz maximum pixel clock
[ 10.420] (--) NVIDIA(GPU-0): DFP-5: disconnected
[ 10.420] (--) NVIDIA(GPU-0): DFP-5: Internal TMDS
[ 10.420] (--) NVIDIA(GPU-0): DFP-5: 330.0 MHz maximum pixel clock
[ 10.420] (--) NVIDIA(GPU-0): DFP-6: disconnected
[ 10.420] (--) NVIDIA(GPU-0): DFP-6: Internal DisplayPort
[ 10.420] (--) NVIDIA(GPU-0): DFP-6: 960.0 MHz maximum pixel clock
[ 10.420] (--) NVIDIA(GPU-0): DFP-7: disconnected
[ 10.420] (--) NVIDIA(GPU-0): DFP-7: Internal TMDS
[ 10.420] (--) NVIDIA(GPU-0): DFP-7: 330.0 MHz maximum pixel clock
[ 12.561] (--) NVIDIA(GPU-0): CRT-0: disconnected
[ 12.561] (--) NVIDIA(GPU-0): CRT-0: 400.0 MHz maximum pixel clock
[ 12.592] (--) NVIDIA(GPU-0): DELL U3011 (DFP-0): connected
[ 12.592] (--) NVIDIA(GPU-0): DELL U3011 (DFP-0): Internal TMDS
[ 12.592] (--) NVIDIA(GPU-0): DELL U3011 (DFP-0): 330.0 MHz maximum pixel clock
[ 12.592] (--) NVIDIA(GPU-0): DFP-1: disconnected
[ 12.592] (--) NVIDIA(GPU-0): DFP-1: Internal TMDS
[ 12.592] (--) NVIDIA(GPU-0): DFP-1: 330.0 MHz maximum pixel clock
[ 12.592] (--) NVIDIA(GPU-0): DFP-2: disconnected
[ 12.592] (--) NVIDIA(GPU-0): DFP-2: Internal DisplayPort
[ 12.592] (--) NVIDIA(GPU-0): DFP-2: 960.0 MHz maximum pixel clock
[ 12.592] (--) NVIDIA(GPU-0): DFP-3: disconnected
[ 12.592] (--) NVIDIA(GPU-0): DFP-3: Internal TMDS
[ 12.592] (--) NVIDIA(GPU-0): DFP-3: 330.0 MHz maximum pixel clock
[ 12.592] (--) NVIDIA(GPU-0): DFP-4: disconnected
[ 12.592] (--) NVIDIA(GPU-0): DFP-4: Internal DisplayPort
[ 12.592] (--) NVIDIA(GPU-0): DFP-4: 960.0 MHz maximum pixel clock
[ 12.592] (--) NVIDIA(GPU-0): DFP-5: disconnected
[ 12.592] (--) NVIDIA(GPU-0): DFP-5: Internal TMDS
[ 12.592] (--) NVIDIA(GPU-0): DFP-5: 330.0 MHz maximum pixel clock
[ 12.592] (--) NVIDIA(GPU-0): DFP-6: disconnected
[ 12.593] (--) NVIDIA(GPU-0): DFP-6: Internal DisplayPort
[ 12.593] (--) NVIDIA(GPU-0): DFP-6: 960.0 MHz maximum pixel clock
[ 12.593] (--) NVIDIA(GPU-0): DFP-7: disconnected
[ 12.593] (--) NVIDIA(GPU-0): DFP-7: Internal TMDS
[ 12.593] (--) NVIDIA(GPU-0): DFP-7: 330.0 MHz maximum pixel clock
[ 32.388] (**) Option "fd" "25"
[ 32.388] (**) Option "fd" "28"
[ 32.388] (**) Option "fd" "29"
[ 32.388] (**) Option "fd" "30"
[ 32.388] (**) Option "fd" "31"
[ 32.389] (**) Option "fd" "32"
[ 32.389] (**) Option "fd" "33"
[ 32.389] (**) Option "fd" "34"
[ 32.389] (**) Option "fd" "35"
[ 32.389] (**) Option "fd" "36"
[ 32.389] (**) Option "fd" "30"
[ 32.730] (II) systemd-logind: got pause for 13:67
[ 32.730] (II) systemd-logind: got pause for 13:71
[ 32.730] (II) systemd-logind: got pause for 13:64
[ 32.730] (II) systemd-logind: got pause for 13:66
[ 32.730] (II) systemd-logind: got pause for 13:72
[ 32.730] (II) systemd-logind: got pause for 13:68
[ 32.730] (II) systemd-logind: got pause for 13:73
[ 32.730] (II) systemd-logind: got pause for 13:69
[ 32.730] (II) systemd-logind: got pause for 13:65
[ 32.730] (II) systemd-logind: got pause for 13:70
[ 89180.668] (II) config/udev: removing device Yubico Yubico Yubikey II
[ 89180.668] (II) UnloadModule: "libinput"
[ 89180.668] (II) systemd-logind: releasing fd for 13:72
[118887.954] (II) config/udev: Adding input device Yubico Yubico Yubikey II (/dev/input/event8)
[118887.954] (**) Yubico Yubico Yubikey II: Applying InputClass "evdev keyboard catchall"
[118887.954] (**) Yubico Yubico Yubikey II: Applying InputClass "libinput keyboard catchall"
[118887.954] (**) Yubico Yubico Yubikey II: Applying InputClass "system-keyboard"
[118887.955] (II) systemd-logind: got fd for /dev/input/event8 13:72 fd 21 paused 1
[118887.955] (II) systemd-logind: releasing fd for 13:72
[137141.197] (II) config/udev: removing device Logitech G700s Rechargeable Gaming Mouse
[137141.197] (II) UnloadModule: "libinput"
[137141.197] (II) systemd-logind: releasing fd for 13:68
[137141.236] (II) config/udev: removing device Logitech G700s Rechargeable Gaming Mouse
[137141.236] (II) UnloadModule: "libinput"
[137141.236] (II) systemd-logind: not releasing fd for 13:69, still in use
[137141.236] (II) systemd-logind: releasing fd for 13:69
Please let me know if there’s anything else which I could add?
Looking forward for some suggestions, as the system is pretty much unusuable.
