Ubuntu 22.04 in the middle of updating drivers from 530.41.03 to 535.54.03 video input cuts out
timeline 10:36 - 10:39
switch to TTY not helped, SSH not tested
syslog
Jul  3 10:37:14 Panter nvidia-persistenced: Received signal 15
Jul  3 10:37:14 Panter systemd[1]: Stopping NVIDIA Persistence Daemon...
Jul  3 10:37:14 Panter nvidia-persistenced: Socket closed.
Jul  3 10:37:14 Panter nvidia-persistenced: PID file unlocked.
Jul  3 10:37:14 Panter nvidia-persistenced: PID file closed.
Jul  3 10:37:14 Panter nvidia-persistenced: The daemon no longer has permission to remove its runtime data directory /var/run/nvidia-persistenced
Jul  3 10:37:14 Panter nvidia-persistenced: Shutdown (1085)
Jul  3 10:37:14 Panter systemd[1]: nvidia-persistenced.service: Deactivated successfully.
Jul  3 10:37:14 Panter systemd[1]: Stopped NVIDIA Persistence Daemon.
Jul  3 10:37:19 Panter systemd[1]: Reloading.
Jul  3 10:37:19 Panter systemd[1]: Starting Discard unused blocks on filesystems from /etc/fstab...
Jul  3 10:37:19 Panter systemd[1]: Starting NVIDIA system hibernate actions...
Jul  3 10:37:19 Panter hibernate: nvidia-hibernate.service
Jul  3 10:37:19 Panter logger[9260]: <13>Jul  3 10:37:19 hibernate: nvidia-hibernate.service
Jul  3 10:37:19 Panter kernel: [  424.892353] snd_hda_codec_hdmi hdaudioC0D0: HDMI: invalid ELD data byte 16
Jul  3 10:37:19 Panter systemd[1]: nvidia-hibernate.service: Deactivated successfully.
Jul  3 10:37:19 Panter systemd[1]: Finished NVIDIA system hibernate actions.
Jul  3 10:37:20 Panter systemd[1]: Reloading.
Jul  3 10:37:20 Panter systemd[1]: Starting NVIDIA system resume actions...
Jul  3 10:37:20 Panter suspend: nvidia-resume.service
Jul  3 10:37:20 Panter logger[9305]: <13>Jul  3 10:37:20 suspend: nvidia-resume.service
Jul  3 10:37:20 Panter systemd[1]: nvidia-resume.service: Deactivated successfully.
Jul  3 10:37:20 Panter systemd[1]: Finished NVIDIA system resume actions.
Jul  3 10:37:20 Panter acpid: client 1346[0:0] has disconnected
Jul  3 10:37:20 Panter rtkit-daemon[1537]: Supervising 7 threads of 3 processes of 1 users.
Jul  3 10:37:20 Panter rtkit-daemon[1537]: Successfully made thread 9312 of process 1530 owned by '1000' RT at priority 5.
Jul  3 10:37:20 Panter rtkit-daemon[1537]: Supervising 8 threads of 3 processes of 1 users.
Jul  3 10:37:20 Panter acpid: client connected from 1346[0:0]
Jul  3 10:37:20 Panter acpid: 1 client rule loaded
Jul  3 10:37:20 Panter rtkit-daemon[1537]: Successfully made thread 9315 of process 1530 owned by '1000' RT at priority 5.
Jul  3 10:37:21 Panter systemd[1]: Starting NVIDIA system suspend actions...
Jul  3 10:37:21 Panter suspend: nvidia-suspend.service
Jul  3 10:37:21 Panter logger[9348]: <13>Jul  3 10:37:21 suspend: nvidia-suspend.service
Jul  3 10:37:21 Panter kernel: [  426.645430] snd_hda_codec_hdmi hdaudioC0D0: HDMI: invalid ELD data byte 12
Jul  3 10:37:21 Panter systemd[1]: nvidia-suspend.service: Deactivated successfully.
Jul  3 10:37:21 Panter systemd[1]: Finished NVIDIA system suspend actions.
Jul  3 10:37:21 Panter systemd[1]: Reloading.
Jul  3 10:37:22 Panter systemd[1]: Starting NVIDIA system hibernate actions...
Jul  3 10:37:22 Panter hibernate: nvidia-hibernate.service
Jul  3 10:37:22 Panter logger[9399]: <13>Jul  3 10:37:22 hibernate: nvidia-hibernate.service
Jul  3 10:37:22 Panter systemd[1]: Starting NVIDIA system resume actions...
Jul  3 10:37:22 Panter suspend: nvidia-resume.service
Jul  3 10:37:22 Panter logger[9403]: <13>Jul  3 10:37:22 suspend: nvidia-resume.service
Jul  3 10:37:22 Panter nvidia-sleep.sh[9400]: /usr/bin/nvidia-sleep.sh: řádek 20: echo: chyba zápisu: Chyba vstupu/výstupu
Jul  3 10:37:22 Panter systemd[1]: Starting NVIDIA system suspend actions...
Jul  3 10:37:22 Panter systemd[1]: nvidia-hibernate.service: Main process exited, code=exited, status=1/FAILURE
Jul  3 10:37:22 Panter suspend: nvidia-suspend.service
Jul  3 10:37:22 Panter systemd[1]: nvidia-hibernate.service: Failed with result 'exit-code'.
Jul  3 10:37:22 Panter logger[9407]: <13>Jul  3 10:37:22 suspend: nvidia-suspend.service
Jul  3 10:37:22 Panter systemd[1]: Failed to start NVIDIA system hibernate actions.
Jul  3 10:37:22 Panter kernel: [  427.641772] snd_hda_codec_hdmi hdaudioC0D0: HDMI: invalid ELD data byte 0
dmesg
Xorg.0.log - but from last boot only
[     8.508]
X.Org X Server 1.21.1.4
X Protocol Version 11, Revision 0
[     8.508] Current Operating System: Linux Panter 5.19.0-46-generic #47~22.04.1-Ubuntu SMP PREEMPT_DYNAMIC Wed Jun 21 15:35:31 UTC 2 x86_64
[     8.508] Kernel command line: BOOT_IMAGE=/boot/vmlinuz-5.19.0-46-generic root=UUID=eeac54ab-ce8e-49fa-90f2-a63c06bb4f22 ro crashkernel=384M-:512M
[     8.508] xorg-server 2:21.1.4-2ubuntu1.7~22.04.1 (For technical support please see http://www.ubuntu.com/support)
[     8.508] Current version of pixman: 0.40.0
[     8.508] 	Before reporting problems, check http://wiki.x.org
	to make sure that you have the latest version.
[     8.508] Markers: (--) probed, (**) from config file, (==) default setting,
	(++) from command line, (!!) notice, (II) informational,
	(WW) warning, (EE) error, (NI) not implemented, (??) unknown.
[     8.508] (==) Log file: "/var/log/Xorg.0.log", Time: Mon Jul  3 10:47:12 2023
[     8.509] (==) Using system config directory "/usr/share/X11/xorg.conf.d"
[     8.510] (==) No Layout section.  Using the first Screen section.
[     8.510] (==) No screen section available. Using defaults.
[     8.510] (**) |-->Screen "Default Screen Section" (0)
[     8.510] (**) |   |-->Monitor "<default monitor>"
[     8.511] (==) No monitor specified for screen "Default Screen Section".
	Using a default monitor configuration.
[     8.511] (==) Automatically adding devices
[     8.511] (==) Automatically enabling devices
[     8.511] (==) Automatically adding GPU devices
[     8.511] (==) Automatically binding GPU devices
[     8.511] (==) Max clients allowed: 256, resource mask: 0x1fffff
[     8.512] (WW) The directory "/usr/share/fonts/X11/cyrillic" does not exist.
[     8.512] 	Entry deleted from font path.
[     8.512] (WW) The directory "/usr/share/fonts/X11/100dpi/" does not exist.
[     8.512] (WW) The directory "/usr/share/fonts/X11/75dpi/" does not exist.
[     8.513] (WW) The directory "/usr/share/fonts/X11/100dpi" does not exist.
[     8.513] 	Entry deleted from font path.
[     8.513] (WW) The directory "/usr/share/fonts/X11/75dpi" does not exist.
[     8.513] (==) FontPath set to:
	/usr/share/fonts/X11/misc,
	/usr/share/fonts/X11/Type1,
	built-ins
[     8.513] (==) ModulePath set to "/usr/lib/xorg/modules"
[     8.513] (II) The server relies on udev to provide the list of input devices.
	If no devices become available, reconfigure udev or disable AutoAddDevices.
[     8.513] (II) Loader magic: 0x5586d0e14020
[     8.513] (II) Module ABI versions:
[     8.513] 	X.Org ANSI C Emulation: 0.4
[     8.513] 	X.Org Video Driver: 25.2
[     8.513] 	X.Org XInput driver : 24.4
[     8.513] 	X.Org Server Extension : 10.0
[     8.513] (++) using VT number 7
[     8.513] (II) systemd-logind: logind integration requires -keeptty and -keeptty was not provided, disabling logind integration
[     8.514] (II) xfree86: Adding drm device (/dev/dri/card0)
[     8.514] (II) Platform probe for /sys/devices/pci0000:00/0000:00:01.0/0000:01:00.0/drm/card0
[     8.515] (**) OutputClass "nvidia" ModulePath extended to "/usr/lib/x86_64-linux-gnu/nvidia/xorg,/usr/lib/xorg/modules"
[     8.516] (--) PCI:*(1@0:0:0) 10de:1c03:1458:3771 rev 161, Mem @ 0xf6000000/16777216, 0xe0000000/268435456, 0xf0000000/33554432, I/O @ 0x0000e000/128, BIOS @ 0x????????/131072
[     8.516] (II) LoadModule: "glx"
[     8.518] (II) Loading /usr/lib/xorg/modules/extensions/libglx.so
[     8.528] (II) Module glx: vendor="X.Org Foundation"
[     8.528] 	compiled for 1.21.1.4, module version = 1.0.0
[     8.528] 	ABI class: X.Org Server Extension, version 10.0
[     8.528] (II) Applying OutputClass "nvidia" to /dev/dri/card0
[     8.528] 	loading driver: nvidia
[     8.772] (==) Matched nvidia as autoconfigured driver 0
[     8.772] (==) Matched nouveau as autoconfigured driver 1
[     8.772] (==) Matched modesetting as autoconfigured driver 2
[     8.772] (==) Matched fbdev as autoconfigured driver 3
[     8.772] (==) Matched vesa as autoconfigured driver 4
[     8.772] (==) Assigned the driver to the xf86ConfigLayout
[     8.772] (II) LoadModule: "nvidia"
[     8.772] (II) Loading /usr/lib/x86_64-linux-gnu/nvidia/xorg/nvidia_drv.so
[     8.780] (II) Module nvidia: vendor="NVIDIA Corporation"
[     8.780] 	compiled for 1.6.99.901, module version = 1.0.0
[     8.780] 	Module class: X.Org Video Driver
[     8.780] (II) LoadModule: "nouveau"
[     8.780] (II) Loading /usr/lib/xorg/modules/drivers/nouveau_drv.so
[     8.783] (II) Module nouveau: vendor="X.Org Foundation"
[     8.783] 	compiled for 1.21.1.3, module version = 1.0.17
[     8.783] 	Module class: X.Org Video Driver
[     8.783] 	ABI class: X.Org Video Driver, version 25.2
[     8.783] (II) LoadModule: "modesetting"
[     8.783] (II) Loading /usr/lib/xorg/modules/drivers/modesetting_drv.so
[     8.784] (II) Module modesetting: vendor="X.Org Foundation"
[     8.784] 	compiled for 1.21.1.4, module version = 1.21.1
[     8.784] 	Module class: X.Org Video Driver
[     8.784] 	ABI class: X.Org Video Driver, version 25.2
[     8.784] (II) LoadModule: "fbdev"
[     8.784] (II) Loading /usr/lib/xorg/modules/drivers/fbdev_drv.so
[     8.784] (II) Module fbdev: vendor="X.Org Foundation"
[     8.784] 	compiled for 1.21.1.3, module version = 0.5.0
[     8.784] (II) LoadModule: "vesa"
[     8.784] (II) Loading /usr/lib/xorg/modules/drivers/vesa_drv.so
[     8.785] (II) Module vesa: vendor="X.Org Foundation"
[     8.785] 	compiled for 1.21.1.3, module version = 2.5.0
[     8.785] 	Module class: X.Org Video Driver
[     8.785] 	ABI class: X.Org Video Driver, version 25.2
[     8.785] (II) NVIDIA dlloader X Driver  535.54.03  Tue Jun  6 22:23:02 UTC 2023
[     8.785] (II) NVIDIA Unified Driver for all Supported NVIDIA GPUs
[     8.785] (II) NOUVEAU driver Date:   Sat Jan 23 12:24:42 2021 -0500
[     8.785] (II) NOUVEAU driver for NVIDIA chipset families :
[     8.785] 	RIVA TNT            (NV04)
[     8.785] 	RIVA TNT2           (NV05)
[     8.785] 	GeForce 256         (NV10)
[     8.785] 	GeForce 2           (NV11, NV15)
[     8.785] 	GeForce 4MX         (NV17, NV18)
[     8.785] 	GeForce 3           (NV20)
[     8.785] 	GeForce 4Ti         (NV25, NV28)
[     8.786] 	GeForce FX          (NV3x)
[     8.786] 	GeForce 6           (NV4x)
[     8.786] 	GeForce 7           (G7x)
[     8.786] 	GeForce 8           (G8x)
[     8.786] 	GeForce 9           (G9x)
[     8.786] 	GeForce GTX 2xx/3xx (GT2xx)
[     8.786] 	GeForce GTX 4xx/5xx (GFxxx)
[     8.786] 	GeForce GTX 6xx/7xx (GKxxx)
[     8.786] 	GeForce GTX 9xx     (GMxxx)
[     8.786] 	GeForce GTX 10xx    (GPxxx)
[     8.786] (II) modesetting: Driver for Modesetting Kernel Drivers: kms
[     8.786] (II) FBDEV: driver for framebuffer: fbdev
[     8.786] (II) VESA: driver for VESA chipsets: vesa
[     8.789] (II) Loading sub module "fb"
[     8.789] (II) LoadModule: "fb"
[     8.789] (II) Module "fb" already built-in
[     8.789] (II) Loading sub module "wfb"
[     8.789] (II) LoadModule: "wfb"
[     8.789] (II) Loading /usr/lib/xorg/modules/libwfb.so
[     8.790] (II) Module wfb: vendor="X.Org Foundation"
[     8.790] 	compiled for 1.21.1.4, module version = 1.0.0
[     8.790] 	ABI class: X.Org ANSI C Emulation, version 0.4
[     8.791] (WW) Falling back to old probe method for modesetting
[     8.792] (WW) Falling back to old probe method for fbdev
[     8.792] (II) Loading sub module "fbdevhw"
[     8.792] (II) LoadModule: "fbdevhw"
[     8.792] (II) Loading /usr/lib/xorg/modules/libfbdevhw.so
[     8.792] (II) Module fbdevhw: vendor="X.Org Foundation"
[     8.792] 	compiled for 1.21.1.4, module version = 0.0.2
[     8.792] 	ABI class: X.Org Video Driver, version 25.2
[     8.792] (II) NVIDIA(0): Creating default Display subsection in Screen section
	"Default Screen Section" for depth/fbbpp 24/32
[     8.792] (==) NVIDIA(0): Depth 24, (==) framebuffer bpp 32
[     8.792] (==) NVIDIA(0): RGB weight 888
[     8.792] (==) NVIDIA(0): Default visual is TrueColor
[     8.792] (==) NVIDIA(0): Using gamma correction (1.0, 1.0, 1.0)
[     8.792] (II) Applying OutputClass "nvidia" options to /dev/dri/card0
[     8.792] (**) NVIDIA(0): Option "AllowEmptyInitialConfiguration"
[     8.792] (**) NVIDIA(0): Enabling 2D acceleration
[     8.792] (II) Loading sub module "glxserver_nvidia"
[     8.792] (II) LoadModule: "glxserver_nvidia"
[     8.792] (II) Loading /usr/lib/x86_64-linux-gnu/nvidia/xorg/libglxserver_nvidia.so
[     8.891] (II) Module glxserver_nvidia: vendor="NVIDIA Corporation"
[     8.891] 	compiled for 1.6.99.901, module version = 1.0.0
[     8.891] 	Module class: X.Org Server Extension
[     8.891] (II) NVIDIA GLX Module  535.54.03  Tue Jun  6 22:23:41 UTC 2023
[     8.893] (II) NVIDIA: The X server supports PRIME Render Offload.
[     8.894] (--) NVIDIA(0): Valid display device(s) on GPU-0 at PCI:1:0:0
[     8.894] (--) NVIDIA(0):     DFP-0
[     8.894] (--) NVIDIA(0):     DFP-1
[     8.894] (--) NVIDIA(0):     DFP-2 (boot)
[     8.894] (--) NVIDIA(0):     DFP-3
[     8.894] (--) NVIDIA(0):     DFP-4
[     8.895] (II) NVIDIA(0): NVIDIA GPU NVIDIA GeForce GTX 1060 6GB (GP106-A) at PCI:1:0:0
[     8.895] (II) NVIDIA(0):     (GPU-0)
[     8.895] (--) NVIDIA(0): Memory: 6291456 kBytes
[     8.895] (--) NVIDIA(0): VideoBIOS: 86.06.45.40.00
[     8.895] (II) NVIDIA(0): Detected PCI Express Link width: 16X
[     8.895] (--) NVIDIA(GPU-0): DFP-0: disconnected
[     8.895] (--) NVIDIA(GPU-0): DFP-0: Internal TMDS
[     8.895] (--) NVIDIA(GPU-0): DFP-0: 330.0 MHz maximum pixel clock
[     8.895] (--) NVIDIA(GPU-0): DFP-1: disconnected
[     8.895] (--) NVIDIA(GPU-0): DFP-1: Internal TMDS
[     8.895] (--) NVIDIA(GPU-0): DFP-1: 165.0 MHz maximum pixel clock
[     8.895] (--) NVIDIA(GPU-0): BenQ BL2411 (DFP-2): connected
[     8.895] (--) NVIDIA(GPU-0): BenQ BL2411 (DFP-2): Internal DisplayPort
[     8.895] (--) NVIDIA(GPU-0): BenQ BL2411 (DFP-2): 1440.0 MHz maximum pixel clock
[     8.900] (--) NVIDIA(GPU-0): DFP-3: disconnected
[     8.900] (--) NVIDIA(GPU-0): DFP-3: Internal TMDS
[     8.900] (--) NVIDIA(GPU-0): DFP-3: 165.0 MHz maximum pixel clock
[     8.900] (--) NVIDIA(GPU-0): DFP-4: disconnected
[     8.900] (--) NVIDIA(GPU-0): DFP-4: Internal TMDS
[     8.900] (--) NVIDIA(GPU-0): DFP-4: 330.0 MHz maximum pixel clock
[     8.906] (==) NVIDIA(0):
[     8.906] (==) NVIDIA(0): No modes were requested; the default mode "nvidia-auto-select"
[     8.906] (==) NVIDIA(0):     will be used as the requested mode.
[     8.906] (II) NVIDIA(0): Validated MetaModes:
[     8.906] (II) NVIDIA(0):     "DFP-2:nvidia-auto-select"
[     8.906] (II) NVIDIA(0): Virtual screen size determined to be 1920 x 1200
[     8.914] (--) NVIDIA(0): DPI set to (93, 95); computed from "UseEdidDpi" X config
[     8.914] (--) NVIDIA(0):     option
[     8.914] (II) UnloadModule: "nouveau"
[     8.914] (II) Unloading nouveau
[     8.914] (II) UnloadModule: "modesetting"
[     8.914] (II) Unloading modesetting
[     8.914] (II) UnloadModule: "fbdev"
[     8.914] (II) Unloading fbdev
[     8.914] (II) UnloadSubModule: "fbdevhw"
[     8.914] (II) Unloading fbdevhw
[     8.914] (II) UnloadModule: "vesa"
[     8.914] (II) Unloading vesa
[     8.915] (II) NVIDIA: Reserving 24576.00 MB of virtual memory for indirect memory
[     8.915] (II) NVIDIA:     access.
[     8.936] (II) NVIDIA(0): Setting mode "DFP-2:nvidia-auto-select"
[     9.009] (==) NVIDIA(0): Disabling shared memory pixmaps
[     9.009] (==) NVIDIA(0): Backing store enabled
[     9.009] (==) NVIDIA(0): Silken mouse enabled
[     9.011] (==) NVIDIA(0): DPMS enabled
[     9.011] (II) Loading sub module "dri2"
[     9.011] (II) LoadModule: "dri2"
[     9.011] (II) Module "dri2" already built-in
[     9.012] (II) NVIDIA(0): [DRI2] Setup complete
[     9.012] (II) NVIDIA(0): [DRI2]   VDPAU driver: nvidia
[     9.012] (II) Initializing extension Generic Event Extension
[     9.012] (II) Initializing extension SHAPE
[     9.013] (II) Initializing extension MIT-SHM
[     9.013] (II) Initializing extension XInputExtension
[     9.013] (II) Initializing extension XTEST
[     9.013] (II) Initializing extension BIG-REQUESTS
[     9.014] (II) Initializing extension SYNC
[     9.014] (II) Initializing extension XKEYBOARD
[     9.014] (II) Initializing extension XC-MISC
[     9.014] (II) Initializing extension SECURITY
[     9.014] (II) Initializing extension XFIXES
[     9.014] (II) Initializing extension RENDER
[     9.014] (II) Initializing extension RANDR
[     9.014] (II) Initializing extension COMPOSITE
[     9.014] (II) Initializing extension DAMAGE
[     9.014] (II) Initializing extension MIT-SCREEN-SAVER
[     9.014] (II) Initializing extension DOUBLE-BUFFER
[     9.014] (II) Initializing extension RECORD
[     9.015] (II) Initializing extension DPMS
[     9.015] (II) Initializing extension Present
[     9.015] (II) Initializing extension DRI3
[     9.015] (II) Initializing extension X-Resource
[     9.015] (II) Initializing extension XVideo
[     9.015] (II) Initializing extension XVideo-MotionCompensation
[     9.015] (II) Initializing extension SELinux
[     9.015] (II) SELinux: Disabled on system
[     9.015] (II) Initializing extension GLX
[     9.015] (II) Indirect GLX disabled.
[     9.016] (II) GLX: Another vendor is already registered for screen 0
[     9.016] (II) Initializing extension XFree86-VidModeExtension
[     9.016] (II) Initializing extension XFree86-DGA
[     9.016] (II) Initializing extension XFree86-DRI
[     9.016] (II) Initializing extension DRI2
[     9.016] (II) Initializing extension NV-GLX
[     9.016] (II) Initializing extension NV-CONTROL
[     9.016] (II) Initializing extension XINERAMA
[     9.202] (II) config/udev: Adding input device Power Button (/dev/input/event1)
[     9.202] (**) Power Button: Applying InputClass "libinput keyboard catchall"
[     9.202] (II) LoadModule: "libinput"
[     9.202] (II) Loading /usr/lib/xorg/modules/input/libinput_drv.so
[     9.208] (II) Module libinput: vendor="X.Org Foundation"
[     9.208] 	compiled for 1.20.14, module version = 1.2.1
[     9.208] 	Module class: X.Org XInput Driver
[     9.208] 	ABI class: X.Org XInput driver, version 24.1
[     9.208] (II) Using input driver 'libinput' for 'Power Button'
[     9.208] (**) Power Button: always reports core events
[     9.208] (**) Option "Device" "/dev/input/event1"
[     9.224] (II) event1  - Power Button: is tagged by udev as: Keyboard
[     9.224] (II) event1  - Power Button: device is a keyboard
[     9.224] (II) event1  - Power Button: device removed
[     9.241] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXPWRBN:00/input/input1/event1"
[     9.241] (II) XINPUT: Adding extended input device "Power Button" (type: KEYBOARD, id 6)
[     9.241] (**) Option "xkb_model" "pc105"
[     9.241] (**) Option "xkb_layout" "cz"
[     9.256] (II) event1  - Power Button: is tagged by udev as: Keyboard
[     9.256] (II) event1  - Power Button: device is a keyboard
[     9.256] (II) config/udev: Adding input device Power Button (/dev/input/event0)
[     9.256] (**) Power Button: Applying InputClass "libinput keyboard catchall"
[     9.256] (II) Using input driver 'libinput' for 'Power Button'
[     9.256] (**) Power Button: always reports core events
[     9.256] (**) Option "Device" "/dev/input/event0"
[     9.257] (II) event0  - Power Button: is tagged by udev as: Keyboard
[     9.257] (II) event0  - Power Button: device is a keyboard
[     9.257] (II) event0  - Power Button: device removed
[     9.289] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0C:00/input/input0/event0"
[     9.289] (II) XINPUT: Adding extended input device "Power Button" (type: KEYBOARD, id 7)
[     9.289] (**) Option "xkb_model" "pc105"
[     9.289] (**) Option "xkb_layout" "cz"
[     9.290] (II) event0  - Power Button: is tagged by udev as: Keyboard
[     9.290] (II) event0  - Power Button: device is a keyboard
[     9.291] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=3 (/dev/input/event8)
[     9.291] (II) No input driver specified, ignoring this device.
[     9.291] (II) This device may have been added with another device file.
[     9.291] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=7 (/dev/input/event9)
[     9.292] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=8 (/dev/input/event10)
[     9.292] (II) No input driver specified, ignoring this device.
[     9.292] (II) This device may have been added with another device file.
[     9.292] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=9 (/dev/input/event11)
[     9.292] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=10 (/dev/input/event12)
[     9.293] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=11 (/dev/input/event13)
[     9.293] (II) No input driver specified, ignoring this device.
[     9.293] (II) This device may have been added with another device file.
[     9.293] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=12 (/dev/input/event14)
[     9.293] (II) config/udev: Adding input device Clip-on USB microphone ATR4650-USB (/dev/input/event5)
[     9.293] (**) Clip-on USB microphone ATR4650-USB: Applying InputClass "libinput keyboard catchall"
[     9.293] (II) Using input driver 'libinput' for 'Clip-on USB microphone ATR4650-USB'
[     9.293] (**) Clip-on USB microphone ATR4650-USB: always reports core events
[     9.293] (**) Option "Device" "/dev/input/event5"
[     9.294] (II) event5  - Clip-on USB microphone ATR4650-USB: is tagged by udev as: Keyboard
[     9.295] (II) event5  - Clip-on USB microphone ATR4650-USB: device is a keyboard
[     9.295] (II) event5  - Clip-on USB microphone ATR4650-USB: device removed
[     9.313] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:14.0/usb3/3-3/3-3:1.3/0003:0909:004F.0004/input/input10/event5"
[     9.313] (II) XINPUT: Adding extended input device "Clip-on USB microphone ATR4650-USB" (type: KEYBOARD, id 8)
[     9.313] (**) Option "xkb_model" "pc105"
[     9.313] (**) Option "xkb_layout" "cz"
[     9.314] (II) event5  - Clip-on USB microphone ATR4650-USB: is tagged by udev as: Keyboard
[     9.315] (II) event5  - Clip-on USB microphone ATR4650-USB: device is a keyboard
[     9.315] (II) config/udev: Adding input device Logitech USB-PS/2 Optical Mouse (/dev/input/event2)
[     9.315] (**) Logitech USB-PS/2 Optical Mouse: Applying InputClass "libinput pointer catchall"
[     9.315] (II) Using input driver 'libinput' for 'Logitech USB-PS/2 Optical Mouse'
[     9.315] (**) Logitech USB-PS/2 Optical Mouse: always reports core events
[     9.315] (**) Option "Device" "/dev/input/event2"
[     9.374] (II) event2  - Logitech USB-PS/2 Optical Mouse: is tagged by udev as: Mouse
[     9.374] (II) event2  - Logitech USB-PS/2 Optical Mouse: device is a pointer
[     9.374] (II) event2  - Logitech USB-PS/2 Optical Mouse: device removed
[     9.425] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:1a.0/usb1/1-1/1-1.5/1-1.5:1.0/0003:046D:C051.0001/input/input5/event2"
[     9.425] (II) XINPUT: Adding extended input device "Logitech USB-PS/2 Optical Mouse" (type: MOUSE, id 9)
[     9.425] (**) Option "AccelerationScheme" "none"
[     9.425] (**) Logitech USB-PS/2 Optical Mouse: (accel) selected scheme none/0
[     9.425] (**) Logitech USB-PS/2 Optical Mouse: (accel) acceleration factor: 2.000
[     9.425] (**) Logitech USB-PS/2 Optical Mouse: (accel) acceleration threshold: 4
[     9.487] (II) event2  - Logitech USB-PS/2 Optical Mouse: is tagged by udev as: Mouse
[     9.488] (II) event2  - Logitech USB-PS/2 Optical Mouse: device is a pointer
[     9.489] (II) config/udev: Adding input device Logitech USB-PS/2 Optical Mouse (/dev/input/mouse0)
[     9.489] (II) No input driver specified, ignoring this device.
[     9.489] (II) This device may have been added with another device file.
[     9.491] (II) config/udev: Adding input device ASUSTeK TUF GAMING K5 (/dev/input/event3)
[     9.491] (**) ASUSTeK TUF GAMING K5: Applying InputClass "libinput keyboard catchall"
[     9.491] (II) Using input driver 'libinput' for 'ASUSTeK TUF GAMING K5'
[     9.491] (**) ASUSTeK TUF GAMING K5: always reports core events
[     9.491] (**) Option "Device" "/dev/input/event3"
[     9.493] (II) event3  - ASUSTeK TUF GAMING K5: is tagged by udev as: Keyboard
[     9.493] (II) event3  - ASUSTeK TUF GAMING K5: device is a keyboard
[     9.494] (II) event3  - ASUSTeK TUF GAMING K5: device removed
[     9.509] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:1a.0/usb1/1-1/1-1.6/1-1.6:1.0/0003:0B05:1899.0002/input/input6/event3"
[     9.509] (II) XINPUT: Adding extended input device "ASUSTeK TUF GAMING K5" (type: KEYBOARD, id 10)
[     9.509] (**) Option "xkb_model" "pc105"
[     9.509] (**) Option "xkb_layout" "cz"
[     9.512] (II) event3  - ASUSTeK TUF GAMING K5: is tagged by udev as: Keyboard
[     9.512] (II) event3  - ASUSTeK TUF GAMING K5: device is a keyboard
[     9.514] (II) config/udev: Adding input device ASUSTeK TUF GAMING K5 Keyboard (/dev/input/event4)
[     9.514] (**) ASUSTeK TUF GAMING K5 Keyboard: Applying InputClass "libinput keyboard catchall"
[     9.514] (II) Using input driver 'libinput' for 'ASUSTeK TUF GAMING K5 Keyboard'
[     9.514] (**) ASUSTeK TUF GAMING K5 Keyboard: always reports core events
[     9.514] (**) Option "Device" "/dev/input/event4"
[     9.517] (II) event4  - ASUSTeK TUF GAMING K5 Keyboard: is tagged by udev as: Keyboard
[     9.517] (II) event4  - ASUSTeK TUF GAMING K5 Keyboard: device is a keyboard
[     9.517] (II) event4  - ASUSTeK TUF GAMING K5 Keyboard: device removed
[     9.553] (II) libinput: ASUSTeK TUF GAMING K5 Keyboard: needs a virtual subdevice
[     9.553] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:1a.0/usb1/1-1/1-1.6/1-1.6:1.1/0003:0B05:1899.0003/input/input7/event4"
[     9.553] (II) XINPUT: Adding extended input device "ASUSTeK TUF GAMING K5 Keyboard" (type: MOUSE, id 11)
[     9.553] (**) Option "AccelerationScheme" "none"
[     9.553] (**) ASUSTeK TUF GAMING K5 Keyboard: (accel) selected scheme none/0
[     9.553] (**) ASUSTeK TUF GAMING K5 Keyboard: (accel) acceleration factor: 2.000
[     9.553] (**) ASUSTeK TUF GAMING K5 Keyboard: (accel) acceleration threshold: 4
[     9.556] (II) event4  - ASUSTeK TUF GAMING K5 Keyboard: is tagged by udev as: Keyboard
[     9.556] (II) event4  - ASUSTeK TUF GAMING K5 Keyboard: device is a keyboard
[     9.558] (II) config/udev: Adding input device ASUSTeK TUF GAMING K5 Mouse (/dev/input/event6)
[     9.558] (**) ASUSTeK TUF GAMING K5 Mouse: Applying InputClass "libinput pointer catchall"
[     9.558] (II) Using input driver 'libinput' for 'ASUSTeK TUF GAMING K5 Mouse'
[     9.558] (**) ASUSTeK TUF GAMING K5 Mouse: always reports core events
[     9.558] (**) Option "Device" "/dev/input/event6"
[     9.560] (II) event6  - ASUSTeK TUF GAMING K5 Mouse: is tagged by udev as: Mouse
[     9.561] (II) event6  - ASUSTeK TUF GAMING K5 Mouse: device is a pointer
[     9.561] (II) event6  - ASUSTeK TUF GAMING K5 Mouse: device removed
[     9.593] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:1a.0/usb1/1-1/1-1.6/1-1.6:1.1/0003:0B05:1899.0003/input/input8/event6"
[     9.593] (II) XINPUT: Adding extended input device "ASUSTeK TUF GAMING K5 Mouse" (type: MOUSE, id 12)
[     9.593] (**) Option "AccelerationScheme" "none"
[     9.593] (**) ASUSTeK TUF GAMING K5 Mouse: (accel) selected scheme none/0
[     9.593] (**) ASUSTeK TUF GAMING K5 Mouse: (accel) acceleration factor: 2.000
[     9.593] (**) ASUSTeK TUF GAMING K5 Mouse: (accel) acceleration threshold: 4
[     9.596] (II) event6  - ASUSTeK TUF GAMING K5 Mouse: is tagged by udev as: Mouse
[     9.596] (II) event6  - ASUSTeK TUF GAMING K5 Mouse: device is a pointer
[     9.598] (II) config/udev: Adding input device ASUSTeK TUF GAMING K5 Mouse (/dev/input/mouse1)
[     9.598] (II) No input driver specified, ignoring this device.
[     9.598] (II) This device may have been added with another device file.
[     9.599] (II) config/udev: Adding input device ASUSTeK TUF GAMING K5 (/dev/input/event7)
[     9.599] (II) No input driver specified, ignoring this device.
[     9.599] (II) This device may have been added with another device file.
[     9.600] (II) config/udev: Adding input device HDA Creative Mic (/dev/input/event15)
[     9.600] (II) No input driver specified, ignoring this device.
[     9.600] (II) This device may have been added with another device file.
[     9.601] (II) config/udev: Adding input device HDA Creative Line Out Surround (/dev/input/event16)
[     9.601] (II) No input driver specified, ignoring this device.
[     9.601] (II) This device may have been added with another device file.
[     9.601] (II) config/udev: Adding input device HDA Creative Line Out CLFE (/dev/input/event17)
[     9.602] (II) config/udev: Adding input device HDA Creative Front Headphone (/dev/input/event18)
[     9.602] (II) No input driver specified, ignoring this device.
[     9.602] (II) This device may have been added with another device file.
[     9.615] (**) ASUSTeK TUF GAMING K5 Keyboard: Applying InputClass "libinput keyboard catchall"
[     9.615] (II) Using input driver 'libinput' for 'ASUSTeK TUF GAMING K5 Keyboard'
[     9.615] (**) ASUSTeK TUF GAMING K5 Keyboard: always reports core events
[     9.615] (**) Option "Device" "/dev/input/event4"
[     9.615] (II) libinput: ASUSTeK TUF GAMING K5 Keyboard: is a virtual subdevice
[     9.615] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:1a.0/usb1/1-1/1-1.6/1-1.6:1.1/0003:0B05:1899.0003/input/input7/event4"
[     9.615] (II) XINPUT: Adding extended input device "ASUSTeK TUF GAMING K5 Keyboard" (type: KEYBOARD, id 13)
[     9.615] (**) Option "xkb_model" "pc105"
[     9.615] (**) Option "xkb_layout" "cz"
[    11.182] (--) NVIDIA(GPU-0): DFP-0: disconnected
[    11.182] (--) NVIDIA(GPU-0): DFP-0: Internal TMDS
[    11.182] (--) NVIDIA(GPU-0): DFP-0: 330.0 MHz maximum pixel clock
[    11.182] (--) NVIDIA(GPU-0): DFP-1: disconnected
[    11.182] (--) NVIDIA(GPU-0): DFP-1: Internal TMDS
[    11.182] (--) NVIDIA(GPU-0): DFP-1: 165.0 MHz maximum pixel clock
[    11.183] (--) NVIDIA(GPU-0): BenQ BL2411 (DFP-2): connected
[    11.183] (--) NVIDIA(GPU-0): BenQ BL2411 (DFP-2): Internal DisplayPort
[    11.183] (--) NVIDIA(GPU-0): BenQ BL2411 (DFP-2): 1440.0 MHz maximum pixel clock
[    11.187] (--) NVIDIA(GPU-0): DFP-3: disconnected
[    11.187] (--) NVIDIA(GPU-0): DFP-3: Internal TMDS
[    11.187] (--) NVIDIA(GPU-0): DFP-3: 165.0 MHz maximum pixel clock
[    11.187] (--) NVIDIA(GPU-0): DFP-4: disconnected
[    11.187] (--) NVIDIA(GPU-0): DFP-4: Internal TMDS
[    11.187] (--) NVIDIA(GPU-0): DFP-4: 330.0 MHz maximum pixel clock
[    12.348] (--) NVIDIA(GPU-0): DFP-0: disconnected
[    12.348] (--) NVIDIA(GPU-0): DFP-0: Internal TMDS
[    12.348] (--) NVIDIA(GPU-0): DFP-0: 330.0 MHz maximum pixel clock
[    12.348] (--) NVIDIA(GPU-0): DFP-1: disconnected
[    12.348] (--) NVIDIA(GPU-0): DFP-1: Internal TMDS
[    12.348] (--) NVIDIA(GPU-0): DFP-1: 165.0 MHz maximum pixel clock
[    12.348] (--) NVIDIA(GPU-0): BenQ BL2411 (DFP-2): connected
[    12.348] (--) NVIDIA(GPU-0): BenQ BL2411 (DFP-2): Internal DisplayPort
[    12.348] (--) NVIDIA(GPU-0): BenQ BL2411 (DFP-2): 1440.0 MHz maximum pixel clock
[    12.353] (--) NVIDIA(GPU-0): DFP-3: disconnected
[    12.353] (--) NVIDIA(GPU-0): DFP-3: Internal TMDS
[    12.353] (--) NVIDIA(GPU-0): DFP-3: 165.0 MHz maximum pixel clock
[    12.353] (--) NVIDIA(GPU-0): DFP-4: disconnected
[    12.353] (--) NVIDIA(GPU-0): DFP-4: Internal TMDS
[    12.353] (--) NVIDIA(GPU-0): DFP-4: 330.0 MHz maximum pixel clock
[  1575.012] (EE) event3  - ASUSTeK TUF GAMING K5: client bug: event processing lagging behind by 34ms, your system is too slow
[  1654.759] (EE) event3  - ASUSTeK TUF GAMING K5: client bug: event processing lagging behind by 21ms, your system is too slow
[  2818.356] (EE) event3  - ASUSTeK TUF GAMING K5: client bug: event processing lagging behind by 35ms, your system is too slow
dpkg.log
[code]2023-07-03 10:36:21 startup archives unpack
2023-07-03 10:36:21 install libelf1:i386 <none> 0.186-1build1
2023-07-03 10:36:21 status triggers-pending libc-bin:amd64 2.35-0ubuntu3.1
2023-07-03 10:36:21 status half-installed libelf1:i386 0.186-1build1
2023-07-03 10:36:21 status unpacked libelf1:i386 0.186-1build1
2023-07-03 10:36:21 install libexpat1:i386 <none> 2.4.7-1ubuntu0.2
2023-07-03 10:36:21 status half-installed libexpat1:i386 2.4.7-1ubuntu0.2
2023-07-03 10:36:21 status unpacked libexpat1:i386 2.4.7-1ubuntu0.2
2023-07-03 10:36:22 install libffi8:i386 <none> 3.4.2-4
2023-07-03 10:36:22 status half-installed libffi8:i386 3.4.2-4
2023-07-03 10:36:22 status unpacked libffi8:i386 3.4.2-4
2023-07-03 10:36:22 install libstdc++6:i386 <none> 12.1.0-2ubuntu1~22.04
2023-07-03 10:36:22 status half-installed libstdc++6:i386 12.1.0-2ubuntu1~22.04
2023-07-03 10:36:22 status unpacked libstdc++6:i386 12.1.0-2ubuntu1~22.04
2023-07-03 10:36:22 install libicu70:i386 <none> 70.1-2
2023-07-03 10:36:22 status half-installed libicu70:i386 70.1-2
2023-07-03 10:36:22 status unpacked libicu70:i386 70.1-2
2023-07-03 10:36:23 install libxml2:i386 <none> 2.9.13+dfsg-1ubuntu0.3
2023-07-03 10:36:23 status half-installed libxml2:i386 2.9.13+dfsg-1ubuntu0.3
2023-07-03 10:36:23 status unpacked libxml2:i386 2.9.13+dfsg-1ubuntu0.3
2023-07-03 10:36:23 install libdrm2:i386 <none> 2.4.113-2~ubuntu0.22.04.1
2023-07-03 10:36:23 status half-installed libdrm2:i386 2.4.113-2~ubuntu0.22.04.1
2023-07-03 10:36:23 status unpacked libdrm2:i386 2.4.113-2~ubuntu0.22.04.1
2023-07-03 10:36:23 install libedit2:i386 <none> 3.1-20210910-1build1
2023-07-03 10:36:23 status half-installed libedit2:i386 3.1-20210910-1build1
2023-07-03 10:36:23 status triggers-pending man-db:amd64 2.10.2-1
2023-07-03 10:36:23 status unpacked libedit2:i386 3.1-20210910-1build1
2023-07-03 10:36:23 install libatomic1:i386 <none> 12.1.0-2ubuntu1~22.04
2023-07-03 10:36:23 status half-installed libatomic1:i386 12.1.0-2ubuntu1~22.04
2023-07-03 10:36:23 status unpacked libatomic1:i386 12.1.0-2ubuntu1~22.04
2023-07-03 10:36:23 install libdrm-amdgpu1:i386 <none> 2.4.113-2~ubuntu0.22.04.1
2023-07-03 10:36:23 status half-installed libdrm-amdgpu1:i386 2.4.113-2~ubuntu0.22.04.1
2023-07-03 10:36:23 status unpacked libdrm-amdgpu1:i386 2.4.113-2~ubuntu0.22.04.1
2023-07-03 10:36:23 install libdrm-nouveau2:i386 <none> 2.4.113-2~ubuntu0.22.04.1
2023-07-03 10:36:23 status half-installed libdrm-nouveau2:i386 2.4.113-2~ubuntu0.22.04.1
2023-07-03 10:36:24 status unpacked libdrm-nouveau2:i386 2.4.113-2~ubuntu0.22.04.1
2023-07-03 10:36:24 install libdrm-radeon1:i386 <none> 2.4.113-2~ubuntu0.22.04.1
2023-07-03 10:36:24 status half-installed libdrm-radeon1:i386 2.4.113-2~ubuntu0.22.04.1
2023-07-03 10:36:24 status unpacked libdrm-radeon1:i386 2.4.113-2~ubuntu0.22.04.1
2023-07-03 10:36:24 install libglapi-mesa:i386 <none> 22.2.5-0ubuntu0.1~22.04.3
2023-07-03 10:36:24 status half-installed libglapi-mesa:i386 22.2.5-0ubuntu0.1~22.04.3
2023-07-03 10:36:24 status unpacked libglapi-mesa:i386 22.2.5-0ubuntu0.1~22.04.3
2023-07-03 10:36:24 install libllvm15:i386 <none> 1:15.0.7-0ubuntu0.22.04.1
2023-07-03 10:36:24 status half-installed libllvm15:i386 1:15.0.7-0ubuntu0.22.04.1
2023-07-03 10:36:26 status unpacked libllvm15:i386 1:15.0.7-0ubuntu0.22.04.1
2023-07-03 10:36:26 install libsensors5:i386 <none> 1:3.6.0-7ubuntu1
2023-07-03 10:36:26 status half-installed libsensors5:i386 1:3.6.0-7ubuntu1
2023-07-03 10:36:26 status unpacked libsensors5:i386 1:3.6.0-7ubuntu1
2023-07-03 10:36:26 install libxcb-dri3-0:i386 <none> 1.14-3ubuntu3
2023-07-03 10:36:26 status half-installed libxcb-dri3-0:i386 1.14-3ubuntu3
2023-07-03 10:36:26 status unpacked libxcb-dri3-0:i386 1.14-3ubuntu3
2023-07-03 10:36:26 install libgl1-mesa-dri:i386 <none> 22.2.5-0ubuntu0.1~22.04.3
2023-07-03 10:36:26 status half-installed libgl1-mesa-dri:i386 22.2.5-0ubuntu0.1~22.04.3
2023-07-03 10:36:27 status unpacked libgl1-mesa-dri:i386 22.2.5-0ubuntu0.1~22.04.3
2023-07-03 10:36:27 install libx11-xcb1:i386 <none> 2:1.7.5-1ubuntu0.2
2023-07-03 10:36:27 status half-installed libx11-xcb1:i386 2:1.7.5-1ubuntu0.2
2023-07-03 10:36:27 status unpacked libx11-xcb1:i386 2:1.7.5-1ubuntu0.2
2023-07-03 10:36:27 install libxcb-dri2-0:i386 <none> 1.14-3ubuntu3
2023-07-03 10:36:27 status half-installed libxcb-dri2-0:i386 1.14-3ubuntu3
2023-07-03 10:36:27 status unpacked libxcb-dri2-0:i386 1.14-3ubuntu3
2023-07-03 10:36:27 install libxcb-glx0:i386 <none> 1.14-3ubuntu3
2023-07-03 10:36:27 status half-installed libxcb-glx0:i386 1.14-3ubuntu3
2023-07-03 10:36:27 status unpacked libxcb-glx0:i386 1.14-3ubuntu3
2023-07-03 10:36:27 install libxcb-present0:i386 <none> 1.14-3ubuntu3
2023-07-03 10:36:27 status half-installed libxcb-present0:i386 1.14-3ubuntu3
2023-07-03 10:36:27 status unpacked libxcb-present0:i386 1.14-3ubuntu3
2023-07-03 10:36:27 install libxcb-shm0:i386 <none> 1.14-3ubuntu3
2023-07-03 10:36:27 status half-installed libxcb-shm0:i386 1.14-3ubuntu3
2023-07-03 10:36:28 status unpacked libxcb-shm0:i386 1.14-3ubuntu3
2023-07-03 10:36:28 install libxcb-sync1:i386 <none> 1.14-3ubuntu3
2023-07-03 10:36:28 status half-installed libxcb-sync1:i386 1.14-3ubuntu3
2023-07-03 10:36:28 status unpacked libxcb-sync1:i386 1.14-3ubuntu3
2023-07-03 10:36:28 install libxcb-xfixes0:i386 <none> 1.14-3ubuntu3
2023-07-03 10:36:28 status half-installed libxcb-xfixes0:i386 1.14-3ubuntu3
2023-07-03 10:36:28 status unpacked libxcb-xfixes0:i386 1.14-3ubuntu3
2023-07-03 10:36:28 install libxfixes3:i386 <none> 1:6.0.0-1
2023-07-03 10:36:28 status half-installed libxfixes3:i386 1:6.0.0-1
2023-07-03 10:36:28 status unpacked libxfixes3:i386 1:6.0.0-1
2023-07-03 10:36:28 install libxshmfence1:i386 <none> 1.3-1build4
2023-07-03 10:36:28 status half-installed libxshmfence1:i386 1.3-1build4
2023-07-03 10:36:28 status unpacked libxshmfence1:i386 1.3-1build4
2023-07-03 10:36:28 install libxxf86vm1:i386 <none> 1:1.1.4-1build3
2023-07-03 10:36:28 status half-installed libxxf86vm1:i386 1:1.1.4-1build3
2023-07-03 10:36:28 status unpacked libxxf86vm1:i386 1:1.1.4-1build3
2023-07-03 10:36:29 install libglx-mesa0:i386 <none> 22.2.5-0ubuntu0.1~22.04.3
2023-07-03 10:36:29 status half-installed libglx-mesa0:i386 22.2.5-0ubuntu0.1~22.04.3
2023-07-03 10:36:29 status unpacked libglx-mesa0:i386 22.2.5-0ubuntu0.1~22.04.3
2023-07-03 10:36:29 upgrade nvidia-driver-530:amd64 530.41.03-0ubuntu0.22.04.2 535.54.03-0ubuntu0.22.04.1
2023-07-03 10:36:29 status half-configured nvidia-driver-530:amd64 530.41.03-0ubuntu0.22.04.2
2023-07-03 10:36:29 status unpacked nvidia-driver-530:amd64 530.41.03-0ubuntu0.22.04.2
2023-07-03 10:36:29 status half-installed nvidia-driver-530:amd64 530.41.03-0ubuntu0.22.04.2
2023-07-03 10:36:29 status unpacked nvidia-driver-530:amd64 535.54.03-0ubuntu0.22.04.1
2023-07-03 10:36:29 upgrade libnvidia-extra-530:amd64 530.41.03-0ubuntu0.22.04.2 535.54.03-0ubuntu0.22.04.1
2023-07-03 10:36:29 status half-configured libnvidia-extra-530:amd64 530.41.03-0ubuntu0.22.04.2
2023-07-03 10:36:29 status unpacked libnvidia-extra-530:amd64 530.41.03-0ubuntu0.22.04.2
2023-07-03 10:36:29 status half-installed libnvidia-extra-530:amd64 530.41.03-0ubuntu0.22.04.2
2023-07-03 10:36:29 status unpacked libnvidia-extra-530:amd64 535.54.03-0ubuntu0.22.04.1
2023-07-03 10:36:29 install libnvidia-extra-535:amd64 <none> 535.54.03-0ubuntu0.22.04.1
2023-07-03 10:36:29 status half-installed libnvidia-extra-535:amd64 535.54.03-0ubuntu0.22.04.1
2023-07-03 10:36:29 status unpacked libnvidia-extra-535:amd64 535.54.03-0ubuntu0.22.04.1
2023-07-03 10:36:29 upgrade libnvidia-common-530:all 530.41.03-0ubuntu0.22.04.2 535.54.03-0ubuntu0.22.04.1
2023-07-03 10:36:29 status half-configured libnvidia-common-530:all 530.41.03-0ubuntu0.22.04.2
2023-07-03 10:36:29 status unpacked libnvidia-common-530:all 530.41.03-0ubuntu0.22.04.2
2023-07-03 10:36:29 status half-installed libnvidia-common-530:all 530.41.03-0ubuntu0.22.04.2
2023-07-03 10:36:29 status unpacked libnvidia-common-530:all 535.54.03-0ubuntu0.22.04.1
2023-07-03 10:36:30 install libnvidia-common-535:all <none> 535.54.03-0ubuntu0.22.04.1
2023-07-03 10:36:30 status half-installed libnvidia-common-535:all 535.54.03-0ubuntu0.22.04.1
2023-07-03 10:36:30 status unpacked libnvidia-common-535:all 535.54.03-0ubuntu0.22.04.1
2023-07-03 10:36:30 upgrade libnvidia-gl-530:i386 530.41.03-0ubuntu0.22.04.2 535.54.03-0ubuntu0.22.04.1
2023-07-03 10:36:30 status half-configured libnvidia-gl-530:i386 530.41.03-0ubuntu0.22.04.2
2023-07-03 10:36:30 status unpacked libnvidia-gl-530:i386 530.41.03-0ubuntu0.22.04.2
2023-07-03 10:36:30 status half-configured libnvidia-gl-530:amd64 530.41.03-0ubuntu0.22.04.2
2023-07-03 10:36:30 status half-installed libnvidia-gl-530:i386 530.41.03-0ubuntu0.22.04.2
2023-07-03 10:36:30 status unpacked libnvidia-gl-530:i386 535.54.03-0ubuntu0.22.04.1
2023-07-03 10:36:30 upgrade libnvidia-gl-530:amd64 530.41.03-0ubuntu0.22.04.2 535.54.03-0ubuntu0.22.04.1
2023-07-03 10:36:30 status unpacked libnvidia-gl-530:amd64 530.41.03-0ubuntu0.22.04.2
2023-07-03 10:36:30 status half-installed libnvidia-gl-530:amd64 530.41.03-0ubuntu0.22.04.2
2023-07-03 10:36:30 status unpacked libnvidia-gl-530:amd64 535.54.03-0ubuntu0.22.04.1
2023-07-03 10:36:30 install libnvidia-gl-535:i386 <none> 535.54.03-0ubuntu0.22.04.1
2023-07-03 10:36:30 status half-installed libnvidia-gl-535:i386 535.54.03-0ubuntu0.22.04.1
2023-07-03 10:36:32 status unpacked libnvidia-gl-535:i386 535.54.03-0ubuntu0.22.04.1
2023-07-03 10:36:32 install libnvidia-gl-535:amd64 <none> 535.54.03-0ubuntu0.22.04.1
2023-07-03 10:36:32 status half-installed libnvidia-gl-535:amd64 535.54.03-0ubuntu0.22.04.1
2023-07-03 10:36:38 status unpacked libnvidia-gl-535:amd64 535.54.03-0ubuntu0.22.04.1
2023-07-03 10:36:38 upgrade nvidia-dkms-530:amd64 530.41.03-0ubuntu0.22.04.2 535.54.03-0ubuntu0.22.04.1
2023-07-03 10:36:38 status half-configured nvidia-dkms-530:amd64 530.41.03-0ubuntu0.22.04.2
2023-07-03 10:37:05 status unpacked nvidia-dkms-530:amd64 530.41.03-0ubuntu0.22.04.2
2023-07-03 10:37:05 status half-installed nvidia-dkms-530:amd64 530.41.03-0ubuntu0.22.04.2
2023-07-03 10:37:05 status unpacked nvidia-dkms-530:amd64 535.54.03-0ubuntu0.22.04.1
2023-07-03 10:37:05 upgrade nvidia-kernel-source-530:amd64 530.41.03-0ubuntu0.22.04.2 535.54.03-0ubuntu0.22.04.1
2023-07-03 10:37:05 status half-configured nvidia-kernel-source-530:amd64 530.41.03-0ubuntu0.22.04.2
2023-07-03 10:37:05 status unpacked nvidia-kernel-source-530:amd64 530.41.03-0ubuntu0.22.04.2
2023-07-03 10:37:05 status half-installed nvidia-kernel-source-530:amd64 530.41.03-0ubuntu0.22.04.2
2023-07-03 10:37:06 status unpacked nvidia-kernel-source-530:amd64 535.54.03-0ubuntu0.22.04.1
2023-07-03 10:37:06 install nvidia-kernel-source-535:amd64 <none> 535.54.03-0ubuntu0.22.04.1
2023-07-03 10:37:06 status half-installed nvidia-kernel-source-535:amd64 535.54.03-0ubuntu0.22.04.1
2023-07-03 10:37:07 status unpacked nvidia-kernel-source-535:amd64 535.54.03-0ubuntu0.22.04.1
2023-07-03 10:37:07 upgrade nvidia-kernel-common-530:amd64 530.41.03-0ubuntu0.22.04.2 535.54.03-0ubuntu0.22.04.1
2023-07-03 10:37:07 status half-configured nvidia-kernel-common-530:amd64 530.41.03-0ubuntu0.22.04.2
2023-07-03 10:37:07 status unpacked nvidia-kernel-common-530:amd64 530.41.03-0ubuntu0.22.04.2
2023-07-03 10:37:07 status half-installed nvidia-kernel-common-530:amd64 530.41.03-0ubuntu0.22.04.2
2023-07-03 10:37:07 status unpacked nvidia-kernel-common-530:amd64 535.54.03-0ubuntu0.22.04.1
2023-07-03 10:37:07 install nvidia-firmware-535-535.54.03:amd64 <none> 535.54.03-0ubuntu0.22.04.1
2023-07-03 10:37:07 status half-installed nvidia-firmware-535-535.54.03:amd64 535.54.03-0ubuntu0.22.04.1
2023-07-03 10:37:08 status unpacked nvidia-firmware-535-535.54.03:amd64 535.54.03-0ubuntu0.22.04.1
2023-07-03 10:37:08 install nvidia-kernel-common-535:amd64 <none> 535.54.03-0ubuntu0.22.04.1
2023-07-03 10:37:08 status triggers-pending initramfs-tools:all 0.140ubuntu13.1
2023-07-03 10:37:08 status half-installed nvidia-kernel-common-535:amd64 535.54.03-0ubuntu0.22.04.1
2023-07-03 10:37:08 status unpacked nvidia-kernel-common-535:amd64 535.54.03-0ubuntu0.22.04.1
2023-07-03 10:37:08 install nvidia-dkms-535:amd64 <none> 535.54.03-0ubuntu0.22.04.1
2023-07-03 10:37:08 status half-installed nvidia-dkms-535:amd64 535.54.03-0ubuntu0.22.04.1
2023-07-03 10:37:08 status unpacked nvidia-dkms-535:amd64 535.54.03-0ubuntu0.22.04.1
2023-07-03 10:37:08 upgrade libnvidia-decode-530:i386 530.41.03-0ubuntu0.22.04.2 535.54.03-0ubuntu0.22.04.1
2023-07-03 10:37:08 status half-configured libnvidia-decode-530:i386 530.41.03-0ubuntu0.22.04.2
2023-07-03 10:37:08 status unpacked libnvidia-decode-530:i386 530.41.03-0ubuntu0.22.04.2
2023-07-03 10:37:08 status half-configured libnvidia-decode-530:amd64 530.41.03-0ubuntu0.22.04.2
2023-07-03 10:37:08 status half-installed libnvidia-decode-530:i386 530.41.03-0ubuntu0.22.04.2
2023-07-03 10:37:08 status unpacked libnvidia-decode-530:i386 535.54.03-0ubuntu0.22.04.1
2023-07-03 10:37:08 upgrade libnvidia-decode-530:amd64 530.41.03-0ubuntu0.22.04.2 535.54.03-0ubuntu0.22.04.1
2023-07-03 10:37:08 status unpacked libnvidia-decode-530:amd64 530.41.03-0ubuntu0.22.04.2
2023-07-03 10:37:08 status half-installed libnvidia-decode-530:amd64 530.41.03-0ubuntu0.22.04.2
2023-07-03 10:37:08 status unpacked libnvidia-decode-530:amd64 535.54.03-0ubuntu0.22.04.1
2023-07-03 10:37:09 install libnvidia-decode-535:amd64 <none> 535.54.03-0ubuntu0.22.04.1
2023-07-03 10:37:09 status half-installed libnvidia-decode-535:amd64 535.54.03-0ubuntu0.22.04.1
2023-07-03 10:37:09 status unpacked libnvidia-decode-535:amd64 535.54.03-0ubuntu0.22.04.1
2023-07-03 10:37:09 upgrade libnvidia-compute-530:i386 530.41.03-0ubuntu0.22.04.2 535.54.03-0ubuntu0.22.04.1
2023-07-03 10:37:09 status half-configured libnvidia-compute-530:i386 530.41.03-0ubuntu0.22.04.2
2023-07-03 10:37:09 status unpacked libnvidia-compute-530:i386 530.41.03-0ubuntu0.22.04.2
2023-07-03 10:37:09 status half-configured libnvidia-compute-530:amd64 530.41.03-0ubuntu0.22.04.2
2023-07-03 10:37:09 status half-installed libnvidia-compute-530:i386 530.41.03-0ubuntu0.22.04.2
2023-07-03 10:37:09 status unpacked libnvidia-compute-530:i386 535.54.03-0ubuntu0.22.04.1
2023-07-03 10:37:09 upgrade libnvidia-compute-530:amd64 530.41.03-0ubuntu0.22.04.2 535.54.03-0ubuntu0.22.04.1
2023-07-03 10:37:09 status unpacked libnvidia-compute-530:amd64 530.41.03-0ubuntu0.22.04.2
2023-07-03 10:37:09 status half-installed libnvidia-compute-530:amd64 530.41.03-0ubuntu0.22.04.2
2023-07-03 10:37:09 status unpacked libnvidia-compute-530:amd64 535.54.03-0ubuntu0.22.04.1
2023-07-03 10:37:09 install libnvidia-compute-535:i386 <none> 535.54.03-0ubuntu0.22.04.1
2023-07-03 10:37:09 status half-installed libnvidia-compute-535:i386 535.54.03-0ubuntu0.22.04.1
2023-07-03 10:37:11 status unpacked libnvidia-compute-535:i386 535.54.03-0ubuntu0.22.04.1
2023-07-03 10:37:12 install libnvidia-decode-535:i386 <none> 535.54.03-0ubuntu0.22.04.1
2023-07-03 10:37:12 status half-installed libnvidia-decode-535:i386 535.54.03-0ubuntu0.22.04.1
2023-07-03 10:37:12 status unpacked libnvidia-decode-535:i386 535.54.03-0ubuntu0.22.04.1
2023-07-03 10:37:12 install libnvidia-compute-535:amd64 <none> 535.54.03-0ubuntu0.22.04.1
2023-07-03 10:37:12 status half-installed libnvidia-compute-535:amd64 535.54.03-0ubuntu0.22.04.1
2023-07-03 10:37:14 status unpacked libnvidia-compute-535:amd64 535.54.03-0ubuntu0.22.04.1
2023-07-03 10:37:14 upgrade nvidia-compute-utils-530:amd64 530.41.03-0ubuntu0.22.04.2 535.54.03-0ubuntu0.22.04.1
2023-07-03 10:37:14 status half-configured nvidia-compute-utils-530:amd64 530.41.03-0ubuntu0.22.04.2
2023-07-03 10:37:14 status unpacked nvidia-compute-utils-530:amd64 530.41.03-0ubuntu0.22.04.2
2023-07-03 10:37:14 status half-installed nvidia-compute-utils-530:amd64 530.41.03-0ubuntu0.22.04.2
2023-07-03 10:37:14 status unpacked nvidia-compute-utils-530:amd64 535.54.03-0ubuntu0.22.04.1
2023-07-03 10:37:14 install nvidia-compute-utils-535:amd64 <none> 535.54.03-0ubuntu0.22.04.1
2023-07-03 10:37:14 status half-installed nvidia-compute-utils-535:amd64 535.54.03-0ubuntu0.22.04.1
2023-07-03 10:37:15 status unpacked nvidia-compute-utils-535:amd64 535.54.03-0ubuntu0.22.04.1
2023-07-03 10:37:15 upgrade libnvidia-encode-530:i386 530.41.03-0ubuntu0.22.04.2 535.54.03-0ubuntu0.22.04.1
2023-07-03 10:37:15 status half-configured libnvidia-encode-530:i386 530.41.03-0ubuntu0.22.04.2
2023-07-03 10:37:15 status unpacked libnvidia-encode-530:i386 530.41.03-0ubuntu0.22.04.2
2023-07-03 10:37:15 status half-configured libnvidia-encode-530:amd64 530.41.03-0ubuntu0.22.04.2
2023-07-03 10:37:15 status half-installed libnvidia-encode-530:i386 530.41.03-0ubuntu0.22.04.2
2023-07-03 10:37:15 status unpacked libnvidia-encode-530:i386 535.54.03-0ubuntu0.22.04.1
2023-07-03 10:37:15 upgrade libnvidia-encode-530:amd64 530.41.03-0ubuntu0.22.04.2 535.54.03-0ubuntu0.22.04.1
2023-07-03 10:37:15 status unpacked libnvidia-encode-530:amd64 530.41.03-0ubuntu0.22.04.2
2023-07-03 10:37:15 status half-installed libnvidia-encode-530:amd64 530.41.03-0ubuntu0.22.04.2
2023-07-03 10:37:15 status unpacked libnvidia-encode-530:amd64 535.54.03-0ubuntu0.22.04.1
2023-07-03 10:37:15 install libnvidia-encode-535:i386 <none> 535.54.03-0ubuntu0.22.04.1
2023-07-03 10:37:15 status half-installed libnvidia-encode-535:i386 535.54.03-0ubuntu0.22.04.1
2023-07-03 10:37:15 status unpacked libnvidia-encode-535:i386 535.54.03-0ubuntu0.22.04.1
2023-07-03 10:37:15 install libnvidia-encode-535:amd64 <none> 535.54.03-0ubuntu0.22.04.1
2023-07-03 10:37:15 status half-installed libnvidia-encode-535:amd64 535.54.03-0ubuntu0.22.04.1
2023-07-03 10:37:15 status unpacked libnvidia-encode-535:amd64 535.54.03-0ubuntu0.22.04.1
2023-07-03 10:37:15 upgrade nvidia-utils-530:amd64 530.41.03-0ubuntu0.22.04.2 535.54.03-0ubuntu0.22.04.1
2023-07-03 10:37:15 status half-configured nvidia-utils-530:amd64 530.41.03-0ubuntu0.22.04.2
2023-07-03 10:37:15 status unpacked nvidia-utils-530:amd64 530.41.03-0ubuntu0.22.04.2
2023-07-03 10:37:15 status half-installed nvidia-utils-530:amd64 530.41.03-0ubuntu0.22.04.2
2023-07-03 10:37:15 status unpacked nvidia-utils-530:amd64 535.54.03-0ubuntu0.22.04.1
2023-07-03 10:37:16 install nvidia-utils-535:amd64 <none> 535.54.03-0ubuntu0.22.04.1
2023-07-03 10:37:16 status half-installed nvidia-utils-535:amd64 535.54.03-0ubuntu0.22.04.1
2023-07-03 10:37:16 status unpacked nvidia-utils-535:amd64 535.54.03-0ubuntu0.22.04.1
2023-07-03 10:37:16 upgrade xserver-xorg-video-nvidia-530:amd64 530.41.03-0ubuntu0.22.04.2 535.54.03-0ubuntu0.22.04.1
2023-07-03 10:37:16 status half-configured xserver-xorg-video-nvidia-530:amd64 530.41.03-0ubuntu0.22.04.2
2023-07-03 10:37:16 status unpacked xserver-xorg-video-nvidia-530:amd64 530.41.03-0ubuntu0.22.04.2
2023-07-03 10:37:16 status half-installed xserver-xorg-video-nvidia-530:amd64 530.41.03-0ubuntu0.22.04.2
2023-07-03 10:37:16 status unpacked xserver-xorg-video-nvidia-530:amd64 535.54.03-0ubuntu0.22.04.1
2023-07-03 10:37:16 upgrade libnvidia-cfg1-530:amd64 530.41.03-0ubuntu0.22.04.2 535.54.03-0ubuntu0.22.04.1
2023-07-03 10:37:16 status half-configured libnvidia-cfg1-530:amd64 530.41.03-0ubuntu0.22.04.2
2023-07-03 10:37:16 status unpacked libnvidia-cfg1-530:amd64 530.41.03-0ubuntu0.22.04.2
2023-07-03 10:37:16 status half-installed libnvidia-cfg1-530:amd64 530.41.03-0ubuntu0.22.04.2
2023-07-03 10:37:16 status unpacked libnvidia-cfg1-530:amd64 535.54.03-0ubuntu0.22.04.1
2023-07-03 10:37:16 install libnvidia-cfg1-535:amd64 <none> 535.54.03-0ubuntu0.22.04.1
2023-07-03 10:37:16 status half-installed libnvidia-cfg1-535:amd64 535.54.03-0ubuntu0.22.04.1
2023-07-03 10:37:16 status unpacked libnvidia-cfg1-535:amd64 535.54.03-0ubuntu0.22.04.1
2023-07-03 10:37:16 install xserver-xorg-video-nvidia-535:amd64 <none> 535.54.03-0ubuntu0.22.04.1
2023-07-03 10:37:16 status half-installed xserver-xorg-video-nvidia-535:amd64 535.54.03-0ubuntu0.22.04.1
2023-07-03 10:37:17 status unpacked xserver-xorg-video-nvidia-535:amd64 535.54.03-0ubuntu0.22.04.1
2023-07-03 10:37:17 upgrade libnvidia-fbc1-530:amd64 530.41.03-0ubuntu0.22.04.2 535.54.03-0ubuntu0.22.04.1
2023-07-03 10:37:17 status half-configured libnvidia-fbc1-530:amd64 530.41.03-0ubuntu0.22.04.2
2023-07-03 10:37:17 status unpacked libnvidia-fbc1-530:amd64 530.41.03-0ubuntu0.22.04.2
2023-07-03 10:37:17 status half-installed libnvidia-fbc1-530:amd64 530.41.03-0ubuntu0.22.04.2
2023-07-03 10:37:17 status unpacked libnvidia-fbc1-530:amd64 535.54.03-0ubuntu0.22.04.1
2023-07-03 10:37:17 install libnvidia-fbc1-535:amd64 <none> 535.54.03-0ubuntu0.22.04.1
2023-07-03 10:37:17 status half-installed libnvidia-fbc1-535:amd64 535.54.03-0ubuntu0.22.04.1
2023-07-03 10:37:17 status unpacked libnvidia-fbc1-535:amd64 535.54.03-0ubuntu0.22.04.1
2023-07-03 10:37:17 install nvidia-driver-535:amd64 <none> 535.54.03-0ubuntu0.22.04.1
2023-07-03 10:37:17 status half-installed nvidia-driver-535:amd64 535.54.03-0ubuntu0.22.04.1
2023-07-03 10:37:17 status unpacked nvidia-driver-535:amd64 535.54.03-0ubuntu0.22.04.1
2023-07-03 10:37:17 install libglvnd0:i386 <none> 1.4.0-1
2023-07-03 10:37:17 status half-installed libglvnd0:i386 1.4.0-1
2023-07-03 10:37:17 status unpacked libglvnd0:i386 1.4.0-1
2023-07-03 10:37:17 install libglx0:i386 <none> 1.4.0-1
2023-07-03 10:37:17 status half-installed libglx0:i386 1.4.0-1
2023-07-03 10:37:17 status unpacked libglx0:i386 1.4.0-1
2023-07-03 10:37:18 install libgl1:i386 <none> 1.4.0-1
2023-07-03 10:37:18 status half-installed libgl1:i386 1.4.0-1
2023-07-03 10:37:18 status unpacked libgl1:i386 1.4.0-1
2023-07-03 10:37:18 install libnvidia-fbc1-535:i386 <none> 535.54.03-0ubuntu0.22.04.1
2023-07-03 10:37:18 status half-installed libnvidia-fbc1-535:i386 535.54.03-0ubuntu0.22.04.1
2023-07-03 10:37:18 status unpacked libnvidia-fbc1-535:i386 535.54.03-0ubuntu0.22.04.1
2023-07-03 10:37:18 startup packages configure
2023-07-03 10:37:18 configure libexpat1:i386 2.4.7-1ubuntu0.2 <none>
2023-07-03 10:37:18 status unpacked libexpat1:i386 2.4.7-1ubuntu0.2
2023-07-03 10:37:18 status half-configured libexpat1:i386 2.4.7-1ubuntu0.2
2023-07-03 10:37:18 status installed libexpat1:i386 2.4.7-1ubuntu0.2
2023-07-03 10:37:18 configure libxcb-dri3-0:i386 1.14-3ubuntu3 <none>
2023-07-03 10:37:18 status unpacked libxcb-dri3-0:i386 1.14-3ubuntu3
2023-07-03 10:37:18 status half-configured libxcb-dri3-0:i386 1.14-3ubuntu3
2023-07-03 10:37:18 status installed libxcb-dri3-0:i386 1.14-3ubuntu3
2023-07-03 10:37:18 configure libx11-xcb1:i386 2:1.7.5-1ubuntu0.2 <none>
2023-07-03 10:37:18 status unpacked libx11-xcb1:i386 2:1.7.5-1ubuntu0.2
2023-07-03 10:37:18 status half-configured libx11-xcb1:i386 2:1.7.5-1ubuntu0.2
2023-07-03 10:37:18 status installed libx11-xcb1:i386 2:1.7.5-1ubuntu0.2
2023-07-03 10:37:18 configure libxcb-xfixes0:i386 1.14-3ubuntu3 <none>
2023-07-03 10:37:18 status unpacked libxcb-xfixes0:i386 1.14-3ubuntu3
2023-07-03 10:37:18 status half-configured libxcb-xfixes0:i386 1.14-3ubuntu3
2023-07-03 10:37:18 status installed libxcb-xfixes0:i386 1.14-3ubuntu3
2023-07-03 10:37:18 configure nvidia-firmware-535-535.54.03:amd64 535.54.03-0ubuntu0.22.04.1 <none>
2023-07-03 10:37:18 status unpacked nvidia-firmware-535-535.54.03:amd64 535.54.03-0ubuntu0.22.04.1
2023-07-03 10:37:18 status half-configured nvidia-firmware-535-535.54.03:amd64 535.54.03-0ubuntu0.22.04.1
2023-07-03 10:37:18 status installed nvidia-firmware-535-535.54.03:amd64 535.54.03-0ubuntu0.22.04.1
2023-07-03 10:37:18 configure libglvnd0:i386 1.4.0-1 <none>
2023-07-03 10:37:18 status unpacked libglvnd0:i386 1.4.0-1
2023-07-03 10:37:18 status half-configured libglvnd0:i386 1.4.0-1
2023-07-03 10:37:18 status installed libglvnd0:i386 1.4.0-1
2023-07-03 10:37:18 configure libxcb-glx0:i386 1.14-3ubuntu3 <none>
2023-07-03 10:37:18 status unpacked libxcb-glx0:i386 1.14-3ubuntu3
2023-07-03 10:37:18 status half-configured libxcb-glx0:i386 1.14-3ubuntu3
2023-07-03 10:37:18 status installed libxcb-glx0:i386 1.14-3ubuntu3
2023-07-03 10:37:18 configure libedit2:i386 3.1-20210910-1build1 <none>
2023-07-03 10:37:18 status unpacked libedit2:i386 3.1-20210910-1build1
2023-07-03 10:37:18 status half-configured libedit2:i386 3.1-20210910-1build1
2023-07-03 10:37:18 status installed libedit2:i386 3.1-20210910-1build1
2023-07-03 10:37:18 configure libnvidia-fbc1-535:amd64 535.54.03-0ubuntu0.22.04.1 <none>
2023-07-03 10:37:18 status unpacked libnvidia-fbc1-535:amd64 535.54.03-0ubuntu0.22.04.1
2023-07-03 10:37:18 status half-configured libnvidia-fbc1-535:amd64 535.54.03-0ubuntu0.22.04.1
2023-07-03 10:37:18 status installed libnvidia-fbc1-535:amd64 535.54.03-0ubuntu0.22.04.1
2023-07-03 10:37:18 configure libxcb-shm0:i386 1.14-3ubuntu3 <none>
2023-07-03 10:37:18 status unpacked libxcb-shm0:i386 1.14-3ubuntu3
2023-07-03 10:37:18 status half-configured libxcb-shm0:i386 1.14-3ubuntu3
2023-07-03 10:37:18 status installed libxcb-shm0:i386 1.14-3ubuntu3
2023-07-03 10:37:18 configure nvidia-kernel-common-535:amd64 535.54.03-0ubuntu0.22.04.1 <none>
2023-07-03 10:37:18 status unpacked nvidia-kernel-common-535:amd64 535.54.03-0ubuntu0.22.04.1
2023-07-03 10:37:18 status half-configured nvidia-kernel-common-535:amd64 535.54.03-0ubuntu0.22.04.1
2023-07-03 10:37:22 status installed nvidia-kernel-common-535:amd64 535.54.03-0ubuntu0.22.04.1
2023-07-03 10:37:23 configure libxxf86vm1:i386 1:1.1.4-1build3 <none>
2023-07-03 10:37:23 status unpacked libxxf86vm1:i386 1:1.1.4-1build3
2023-07-03 10:37:23 status half-configured libxxf86vm1:i386 1:1.1.4-1build3
2023-07-03 10:37:23 status installed libxxf86vm1:i386 1:1.1.4-1build3
2023-07-03 10:37:23 configure libxcb-present0:i386 1.14-3ubuntu3 <none>
2023-07-03 10:37:23 status unpacked libxcb-present0:i386 1.14-3ubuntu3
2023-07-03 10:37:23 status half-configured libxcb-present0:i386 1.14-3ubuntu3
2023-07-03 10:37:23 status installed libxcb-present0:i386 1.14-3ubuntu3
2023-07-03 10:37:23 configure libxfixes3:i386 1:6.0.0-1 <none>
2023-07-03 10:37:23 status unpacked libxfixes3:i386 1:6.0.0-1
2023-07-03 10:37:23 status half-configured libxfixes3:i386 1:6.0.0-1
2023-07-03 10:37:23 status installed libxfixes3:i386 1:6.0.0-1
2023-07-03 10:37:23 configure libnvidia-common-535:all 535.54.03-0ubuntu0.22.04.1 <none>
2023-07-03 10:37:23 status unpacked libnvidia-common-535:all 535.54.03-0ubuntu0.22.04.1
2023-07-03 10:37:23 status half-configured libnvidia-common-535:all 535.54.03-0ubuntu0.22.04.1
2023-07-03 10:37:23 status installed libnvidia-common-535:all 535.54.03-0ubuntu0.22.04.1
2023-07-03 10:37:23 configure libxcb-sync1:i386 1.14-3ubuntu3 <none>
2023-07-03 10:37:23 status unpacked libxcb-sync1:i386 1.14-3ubuntu3
2023-07-03 10:37:23 status half-configured libxcb-sync1:i386 1.14-3ubuntu3
2023-07-03 10:37:23 status installed libxcb-sync1:i386 1.14-3ubuntu3
2023-07-03 10:37:23 configure libatomic1:i386 12.1.0-2ubuntu1~22.04 <none>
2023-07-03 10:37:23 status unpacked libatomic1:i386 12.1.0-2ubuntu1~22.04
2023-07-03 10:37:23 status half-configured libatomic1:i386 12.1.0-2ubuntu1~22.04
2023-07-03 10:37:23 status installed libatomic1:i386 12.1.0-2ubuntu1~22.04
2023-07-03 10:37:23 configure libnvidia-extra-535:amd64 535.54.03-0ubuntu0.22.04.1 <none>
2023-07-03 10:37:23 status unpacked libnvidia-extra-535:amd64 535.54.03-0ubuntu0.22.04.1
2023-07-03 10:37:23 status half-configured libnvidia-extra-535:amd64 535.54.03-0ubuntu0.22.04.1
2023-07-03 10:37:23 status installed libnvidia-extra-535:amd64 535.54.03-0ubuntu0.22.04.1
2023-07-03 10:37:23 configure libnvidia-cfg1-535:amd64 535.54.03-0ubuntu0.22.04.1 <none>
2023-07-03 10:37:23 status unpacked libnvidia-cfg1-535:amd64 535.54.03-0ubuntu0.22.04.1
2023-07-03 10:37:23 status half-configured libnvidia-cfg1-535:amd64 535.54.03-0ubuntu0.22.04.1
2023-07-03 10:37:23 status installed libnvidia-cfg1-535:amd64 535.54.03-0ubuntu0.22.04.1
2023-07-03 10:37:23 configure libsensors5:i386 1:3.6.0-7ubuntu1 <none>
2023-07-03 10:37:23 status unpacked libsensors5:i386 1:3.6.0-7ubuntu1
2023-07-03 10:37:23 status half-configured libsensors5:i386 1:3.6.0-7ubuntu1
2023-07-03 10:37:23 status installed libsensors5:i386 1:3.6.0-7ubuntu1
2023-07-03 10:37:23 configure libglapi-mesa:i386 22.2.5-0ubuntu0.1~22.04.3 <none>
2023-07-03 10:37:23 status unpacked libglapi-mesa:i386 22.2.5-0ubuntu0.1~22.04.3
2023-07-03 10:37:23 status half-configured libglapi-mesa:i386 22.2.5-0ubuntu0.1~22.04.3
2023-07-03 10:37:23 status installed libglapi-mesa:i386 22.2.5-0ubuntu0.1~22.04.3
2023-07-03 10:37:23 configure libxcb-dri2-0:i386 1.14-3ubuntu3 <none>
2023-07-03 10:37:23 status unpacked libxcb-dri2-0:i386 1.14-3ubuntu3
2023-07-03 10:37:23 status half-configured libxcb-dri2-0:i386 1.14-3ubuntu3
2023-07-03 10:37:23 status installed libxcb-dri2-0:i386 1.14-3ubuntu3
2023-07-03 10:37:23 configure libffi8:i386 3.4.2-4 <none>
2023-07-03 10:37:23 status unpacked libffi8:i386 3.4.2-4
2023-07-03 10:37:23 status half-configured libffi8:i386 3.4.2-4
2023-07-03 10:37:23 status installed libffi8:i386 3.4.2-4
2023-07-03 10:37:23 configure libdrm2:i386 2.4.113-2~ubuntu0.22.04.1 <none>
2023-07-03 10:37:23 status unpacked libdrm2:i386 2.4.113-2~ubuntu0.22.04.1
2023-07-03 10:37:23 status half-configured libdrm2:i386 2.4.113-2~ubuntu0.22.04.1
2023-07-03 10:37:23 status installed libdrm2:i386 2.4.113-2~ubuntu0.22.04.1
2023-07-03 10:37:23 configure libnvidia-common-530:all 535.54.03-0ubuntu0.22.04.1 <none>
2023-07-03 10:37:23 status unpacked libnvidia-common-530:all 535.54.03-0ubuntu0.22.04.1
2023-07-03 10:37:23 status half-configured libnvidia-common-530:all 535.54.03-0ubuntu0.22.04.1
2023-07-03 10:37:23 status installed libnvidia-common-530:all 535.54.03-0ubuntu0.22.04.1
2023-07-03 10:37:23 configure libxshmfence1:i386 1.3-1build4 <none>
2023-07-03 10:37:23 status unpacked libxshmfence1:i386 1.3-1build4
2023-07-03 10:37:23 status half-configured libxshmfence1:i386 1.3-1build4
2023-07-03 10:37:23 status installed libxshmfence1:i386 1.3-1build4
2023-07-03 10:37:23 configure nvidia-kernel-source-535:amd64 535.54.03-0ubuntu0.22.04.1 <none>
2023-07-03 10:37:23 status unpacked nvidia-kernel-source-535:amd64 535.54.03-0ubuntu0.22.04.1
2023-07-03 10:37:23 status half-configured nvidia-kernel-source-535:amd64 535.54.03-0ubuntu0.22.04.1
2023-07-03 10:37:23 status installed nvidia-kernel-source-535:amd64 535.54.03-0ubuntu0.22.04.1
2023-07-03 10:37:23 configure libnvidia-gl-535:amd64 535.54.03-0ubuntu0.22.04.1 <none>
2023-07-03 10:37:23 status unpacked libnvidia-gl-535:amd64 535.54.03-0ubuntu0.22.04.1
2023-07-03 10:37:23 status half-configured libnvidia-gl-535:amd64 535.54.03-0ubuntu0.22.04.1
2023-07-03 10:37:23 status installed libnvidia-gl-535:amd64 535.54.03-0ubuntu0.22.04.1
2023-07-03 10:37:23 configure libnvidia-gl-535:i386 535.54.03-0ubuntu0.22.04.1 <none>
2023-07-03 10:37:23 status unpacked libnvidia-gl-535:i386 535.54.03-0ubuntu0.22.04.1
2023-07-03 10:37:23 status half-configured libnvidia-gl-535:i386 535.54.03-0ubuntu0.22.04.1
2023-07-03 10:37:23 status installed libnvidia-gl-535:i386 535.54.03-0ubuntu0.22.04.1
2023-07-03 10:37:23 configure libnvidia-compute-535:amd64 535.54.03-0ubuntu0.22.04.1 <none>
2023-07-03 10:37:23 status unpacked libnvidia-compute-535:amd64 535.54.03-0ubuntu0.22.04.1
2023-07-03 10:37:24 status half-configured libnvidia-compute-535:amd64 535.54.03-0ubuntu0.22.04.1
2023-07-03 10:37:24 status installed libnvidia-compute-535:amd64 535.54.03-0ubuntu0.22.04.1
2023-07-03 10:37:24 configure libnvidia-compute-535:i386 535.54.03-0ubuntu0.22.04.1 <none>
2023-07-03 10:37:24 status unpacked libnvidia-compute-535:i386 535.54.03-0ubuntu0.22.04.1
2023-07-03 10:37:24 status half-configured libnvidia-compute-535:i386 535.54.03-0ubuntu0.22.04.1
2023-07-03 10:37:24 status installed libnvidia-compute-535:i386 535.54.03-0ubuntu0.22.04.1
2023-07-03 10:37:24 configure libnvidia-cfg1-530:amd64 535.54.03-0ubuntu0.22.04.1 <none>
2023-07-03 10:37:24 status unpacked libnvidia-cfg1-530:amd64 535.54.03-0ubuntu0.22.04.1
2023-07-03 10:37:24 status half-configured libnvidia-cfg1-530:amd64 535.54.03-0ubuntu0.22.04.1
2023-07-03 10:37:24 status installed libnvidia-cfg1-530:amd64 535.54.03-0ubuntu0.22.04.1
2023-07-03 10:37:24 configure libelf1:i386 0.186-1build1 <none>
2023-07-03 10:37:24 status unpacked libelf1:i386 0.186-1build1
2023-07-03 10:37:24 status half-configured libelf1:i386 0.186-1build1
2023-07-03 10:37:24 status installed libelf1:i386 0.186-1build1
2023-07-03 10:37:24 configure libstdc++6:i386 12.1.0-2ubuntu1~22.04 <none>
2023-07-03 10:37:24 status unpacked libstdc++6:i386 12.1.0-2ubuntu1~22.04
2023-07-03 10:37:24 status half-configured libstdc++6:i386 12.1.0-2ubuntu1~22.04
2023-07-03 10:37:24 status installed libstdc++6:i386 12.1.0-2ubuntu1~22.04
2023-07-03 10:37:24 configure nvidia-utils-535:amd64 535.54.03-0ubuntu0.22.04.1 <none>
2023-07-03 10:37:24 status unpacked nvidia-utils-535:amd64 535.54.03-0ubuntu0.22.04.1
2023-07-03 10:37:24 status half-configured nvidia-utils-535:amd64 535.54.03-0ubuntu0.22.04.1
2023-07-03 10:37:24 status installed nvidia-utils-535:amd64 535.54.03-0ubuntu0.22.04.1
2023-07-03 10:37:24 configure libicu70:i386 70.1-2 <none>
2023-07-03 10:37:24 status unpacked libicu70:i386 70.1-2
2023-07-03 10:37:24 status half-configured libicu70:i386 70.1-2
2023-07-03 10:37:24 status installed libicu70:i386 70.1-2
2023-07-03 10:37:24 configure libdrm-amdgpu1:i386 2.4.113-2~ubuntu0.22.04.1 <none>
2023-07-03 10:37:24 status unpacked libdrm-amdgpu1:i386 2.4.113-2~ubuntu0.22.04.1
2023-07-03 10:37:24 status half-configured libdrm-amdgpu1:i386 2.4.113-2~ubuntu0.22.04.1
2023-07-03 10:37:24 status installed libdrm-amdgpu1:i386 2.4.113-2~ubuntu0.22.04.1
2023-07-03 10:37:24 configure libnvidia-gl-530:amd64 535.54.03-0ubuntu0.22.04.1 <none>
2023-07-03 10:37:24 status unpacked libnvidia-gl-530:amd64 535.54.03-0ubuntu0.22.04.1
2023-07-03 10:37:24 status half-configured libnvidia-gl-530:amd64 535.54.03-0ubuntu0.22.04.1
2023-07-03 10:37:24 status installed libnvidia-gl-530:amd64 535.54.03-0ubuntu0.22.04.1
2023-07-03 10:37:24 configure libnvidia-gl-530:i386 535.54.03-0ubuntu0.22.04.1 <none>
2023-07-03 10:37:24 status unpacked libnvidia-gl-530:i386 535.54.03-0ubuntu0.22.04.1
2023-07-03 10:37:24 status half-configured libnvidia-gl-530:i386 535.54.03-0ubuntu0.22.04.1
2023-07-03 10:37:24 status installed libnvidia-gl-530:i386 535.54.03-0ubuntu0.22.04.1
2023-07-03 10:37:24 configure nvidia-compute-utils-535:amd64 535.54.03-0ubuntu0.22.04.1 <none>
2023-07-03 10:37:24 status unpacked nvidia-compute-utils-535:amd64 535.54.03-0ubuntu0.22.04.1
2023-07-03 10:37:24 status half-configured nvidia-compute-utils-535:amd64 535.54.03-0ubuntu0.22.04.1
2023-07-03 10:37:25 status installed nvidia-compute-utils-535:amd64 535.54.03-0ubuntu0.22.04.1
2023-07-03 10:37:25 configure libdrm-nouveau2:i386 2.4.113-2~ubuntu0.22.04.1 <none>
2023-07-03 10:37:25 status unpacked libdrm-nouveau2:i386 2.4.113-2~ubuntu0.22.04.1
2023-07-03 10:37:25 status half-configured libdrm-nouveau2:i386 2.4.113-2~ubuntu0.22.04.1
2023-07-03 10:37:25 status installed libdrm-nouveau2:i386 2.4.113-2~ubuntu0.22.04.1
2023-07-03 10:37:25 configure nvidia-kernel-source-530:amd64 535.54.03-0ubuntu0.22.04.1 <none>
2023-07-03 10:37:25 status unpacked nvidia-kernel-source-530:amd64 535.54.03-0ubuntu0.22.04.1
2023-07-03 10:37:25 status half-configured nvidia-kernel-source-530:amd64 535.54.03-0ubuntu0.22.04.1
2023-07-03 10:37:25 status installed nvidia-kernel-source-530:amd64 535.54.03-0ubuntu0.22.04.1
2023-07-03 10:37:25 configure libnvidia-fbc1-530:amd64 535.54.03-0ubuntu0.22.04.1 <none>
2023-07-03 10:37:25 status unpacked libnvidia-fbc1-530:amd64 535.54.03-0ubuntu0.22.04.1
2023-07-03 10:37:25 status half-configured libnvidia-fbc1-530:amd64 535.54.03-0ubuntu0.22.04.1
2023-07-03 10:37:25 status installed libnvidia-fbc1-530:amd64 535.54.03-0ubuntu0.22.04.1
2023-07-03 10:37:25 configure nvidia-kernel-common-530:amd64 535.54.03-0ubuntu0.22.04.1 <none>
2023-07-03 10:37:25 status unpacked nvidia-kernel-common-530:amd64 535.54.03-0ubuntu0.22.04.1
2023-07-03 10:37:25 status half-configured nvidia-kernel-common-530:amd64 535.54.03-0ubuntu0.22.04.1
2023-07-03 10:37:25 status installed nvidia-kernel-common-530:amd64 535.54.03-0ubuntu0.22.04.1
2023-07-03 10:37:25 configure libdrm-radeon1:i386 2.4.113-2~ubuntu0.22.04.1 <none>
2023-07-03 10:37:25 status unpacked libdrm-radeon1:i386 2.4.113-2~ubuntu0.22.04.1
2023-07-03 10:37:25 status half-configured libdrm-radeon1:i386 2.4.113-2~ubuntu0.22.04.1
2023-07-03 10:37:25 status installed libdrm-radeon1:i386 2.4.113-2~ubuntu0.22.04.1
2023-07-03 10:37:25 configure nvidia-dkms-535:amd64 535.54.03-0ubuntu0.22.04.1 <none>
2023-07-03 10:37:25 status unpacked nvidia-dkms-535:amd64 535.54.03-0ubuntu0.22.04.1
2023-07-03 10:37:25 status half-configured nvidia-dkms-535:amd64 535.54.03-0ubuntu0.22.04.1
2023-07-03 10:39:19 status installed nvidia-dkms-535:amd64 535.54.03-0ubuntu0.22.04.1
2023-07-03 10:39:19 configure libnvidia-decode-535:amd64 535.54.03-0ubuntu0.22.04.1 <none>
2023-07-03 10:39:19 status unpacked libnvidia-decode-535:amd64 535.54.03-0ubuntu0.22.04.1
2023-07-03 10:39:19 status half-configured libnvidia-decode-535:amd64 535.54.03-0ubuntu0.22.04.1
2023-07-03 10:39:19 status installed libnvidia-decode-535:amd64 535.54.03-0ubuntu0.22.04.1
2023-07-03 10:39:19 configure libnvidia-decode-535:i386 535.54.03-0ubuntu0.22.04.1 <none>
2023-07-03 10:39:19 status unpacked libnvidia-decode-535:i386 535.54.03-0ubuntu0.22.04.1
2023-07-03 10:39:19 status half-configured libnvidia-decode-535:i386 535.54.03-0ubuntu0.22.04.1
2023-07-03 10:39:19 status installed libnvidia-decode-535:i386 535.54.03-0ubuntu0.22.04.1
2023-07-03 10:39:19 configure libnvidia-extra-530:amd64 535.54.03-0ubuntu0.22.04.1 <none>
2023-07-03 10:39:19 status unpacked libnvidia-extra-530:amd64 535.54.03-0ubuntu0.22.04.1
2023-07-03 10:39:19 status half-configured libnvidia-extra-530:amd64 535.54.03-0ubuntu0.22.04.1
2023-07-03 10:39:19 status installed libnvidia-extra-530:amd64 535.54.03-0ubuntu0.22.04.1
2023-07-03 10:39:19 configure libnvidia-compute-530:amd64 535.54.03-0ubuntu0.22.04.1 <none>
2023-07-03 10:39:19 status unpacked libnvidia-compute-530:amd64 535.54.03-0ubuntu0.22.04.1
2023-07-03 10:39:19 status half-configured libnvidia-compute-530:amd64 535.54.03-0ubuntu0.22.04.1
2023-07-03 10:39:19 status installed libnvidia-compute-530:amd64 535.54.03-0ubuntu0.22.04.1
2023-07-03 10:39:19 configure libnvidia-compute-530:i386 535.54.03-0ubuntu0.22.04.1 <none>
2023-07-03 10:39:19 status unpacked libnvidia-compute-530:i386 535.54.03-0ubuntu0.22.04.1
2023-07-03 10:39:19 status half-configured libnvidia-compute-530:i386 535.54.03-0ubuntu0.22.04.1
2023-07-03 10:39:19 status installed libnvidia-compute-530:i386 535.54.03-0ubuntu0.22.04.1
2023-07-03 10:39:19 configure xserver-xorg-video-nvidia-535:amd64 535.54.03-0ubuntu0.22.04.1 <none>
2023-07-03 10:39:19 status unpacked xserver-xorg-video-nvidia-535:amd64 535.54.03-0ubuntu0.22.04.1
2023-07-03 10:39:19 status half-configured xserver-xorg-video-nvidia-535:amd64 535.54.03-0ubuntu0.22.04.1
2023-07-03 10:39:19 status installed xserver-xorg-video-nvidia-535:amd64 535.54.03-0ubuntu0.22.04.1
2023-07-03 10:39:19 configure nvidia-dkms-530:amd64 535.54.03-0ubuntu0.22.04.1 <none>
2023-07-03 10:39:19 status unpacked nvidia-dkms-530:amd64 535.54.03-0ubuntu0.22.04.1
2023-07-03 10:39:19 status half-configured nvidia-dkms-530:amd64 535.54.03-0ubuntu0.22.04.1
2023-07-03 10:39:19 status installed nvidia-dkms-530:amd64 535.54.03-0ubuntu0.22.04.1
2023-07-03 10:39:19 configure libnvidia-decode-530:amd64 535.54.03-0ubuntu0.22.04.1 <none>
2023-07-03 10:39:19 status unpacked libnvidia-decode-530:amd64 535.54.03-0ubuntu0.22.04.1
2023-07-03 10:39:19 status half-configured libnvidia-decode-530:amd64 535.54.03-0ubuntu0.22.04.1
2023-07-03 10:39:19 status installed libnvidia-decode-530:amd64 535.54.03-0ubuntu0.22.04.1
2023-07-03 10:39:19 configure libnvidia-decode-530:i386 535.54.03-0ubuntu0.22.04.1 <none>
2023-07-03 10:39:19 status unpacked libnvidia-decode-530:i386 535.54.03-0ubuntu0.22.04.1
2023-07-03 10:39:19 status half-configured libnvidia-decode-530:i386 535.54.03-0ubuntu0.22.04.1
2023-07-03 10:39:19 status installed libnvidia-decode-530:i386 535.54.03-0ubuntu0.22.04.1
2023-07-03 10:39:19 configure xserver-xorg-video-nvidia-530:amd64 535.54.03-0ubuntu0.22.04.1 <none>
2023-07-03 10:39:19 status unpacked xserver-xorg-video-nvidia-530:amd64 535.54.03-0ubuntu0.22.04.1
2023-07-03 10:39:19 status half-configured xserver-xorg-video-nvidia-530:amd64 535.54.03-0ubuntu0.22.04.1
2023-07-03 10:39:19 status installed xserver-xorg-video-nvidia-530:amd64 535.54.03-0ubuntu0.22.04.1
2023-07-03 10:39:19 configure nvidia-utils-530:amd64 535.54.03-0ubuntu0.22.04.1 <none>
2023-07-03 10:39:19 status unpacked nvidia-utils-530:amd64 535.54.03-0ubuntu0.22.04.1
2023-07-03 10:39:19 status half-configured nvidia-utils-530:amd64 535.54.03-0ubuntu0.22.04.1
2023-07-03 10:39:19 status installed nvidia-utils-530:amd64 535.54.03-0ubuntu0.22.04.1
2023-07-03 10:39:19 configure nvidia-compute-utils-530:amd64 535.54.03-0ubuntu0.22.04.1 <none>
2023-07-03 10:39:19 status unpacked nvidia-compute-utils-530:amd64 535.54.03-0ubuntu0.22.04.1
2023-07-03 10:39:19 status half-configured nvidia-compute-utils-530:amd64 535.54.03-0ubuntu0.22.04.1
2023-07-03 10:39:19 status installed nvidia-compute-utils-530:amd64 535.54.03-0ubuntu0.22.04.1
2023-07-03 10:39:19 configure libxml2:i386 2.9.13+dfsg-1ubuntu0.3 <none>
2023-07-03 10:39:19 status unpacked libxml2:i386 2.9.13+dfsg-1ubuntu0.3
2023-07-03 10:39:19 status half-configured libxml2:i386 2.9.13+dfsg-1ubuntu0.3
2023-07-03 10:39:19 status installed libxml2:i386 2.9.13+dfsg-1ubuntu0.3
2023-07-03 10:39:19 configure libnvidia-encode-535:amd64 535.54.03-0ubuntu0.22.04.1 <none>
2023-07-03 10:39:19 status unpacked libnvidia-encode-535:amd64 535.54.03-0ubuntu0.22.04.1
2023-07-03 10:39:19 status half-configured libnvidia-encode-535:amd64 535.54.03-0ubuntu0.22.04.1
2023-07-03 10:39:19 status installed libnvidia-encode-535:amd64 535.54.03-0ubuntu0.22.04.1
2023-07-03 10:39:19 configure libnvidia-encode-535:i386 535.54.03-0ubuntu0.22.04.1 <none>
2023-07-03 10:39:19 status unpacked libnvidia-encode-535:i386 535.54.03-0ubuntu0.22.04.1
2023-07-03 10:39:19 status half-configured libnvidia-encode-535:i386 535.54.03-0ubuntu0.22.04.1
2023-07-03 10:39:19 status installed libnvidia-encode-535:i386 535.54.03-0ubuntu0.22.04.1
2023-07-03 10:39:19 configure nvidia-driver-535:amd64 535.54.03-0ubuntu0.22.04.1 <none>
2023-07-03 10:39:19 status unpacked nvidia-driver-535:amd64 535.54.03-0ubuntu0.22.04.1
2023-07-03 10:39:19 status half-configured nvidia-driver-535:amd64 535.54.03-0ubuntu0.22.04.1
2023-07-03 10:39:19 status installed nvidia-driver-535:amd64 535.54.03-0ubuntu0.22.04.1
2023-07-03 10:39:19 configure libllvm15:i386 1:15.0.7-0ubuntu0.22.04.1 <none>
2023-07-03 10:39:19 status unpacked libllvm15:i386 1:15.0.7-0ubuntu0.22.04.1
2023-07-03 10:39:19 status half-configured libllvm15:i386 1:15.0.7-0ubuntu0.22.04.1
2023-07-03 10:39:19 status installed libllvm15:i386 1:15.0.7-0ubuntu0.22.04.1
2023-07-03 10:39:19 configure libnvidia-encode-530:amd64 535.54.03-0ubuntu0.22.04.1 <none>
2023-07-03 10:39:19 status unpacked libnvidia-encode-530:amd64 535.54.03-0ubuntu0.22.04.1
2023-07-03 10:39:20 status half-configured libnvidia-encode-530:amd64 535.54.03-0ubuntu0.22.04.1
2023-07-03 10:39:20 status installed libnvidia-encode-530:amd64 535.54.03-0ubuntu0.22.04.1
2023-07-03 10:39:20 configure libnvidia-encode-530:i386 535.54.03-0ubuntu0.22.04.1 <none>
2023-07-03 10:39:20 status unpacked libnvidia-encode-530:i386 535.54.03-0ubuntu0.22.04.1
2023-07-03 10:39:20 status half-configured libnvidia-encode-530:i386 535.54.03-0ubuntu0.22.04.1
2023-07-03 10:39:20 status installed libnvidia-encode-530:i386 535.54.03-0ubuntu0.22.04.1
2023-07-03 10:39:20 configure libgl1-mesa-dri:i386 22.2.5-0ubuntu0.1~22.04.3 <none>
2023-07-03 10:39:20 status unpacked libgl1-mesa-dri:i386 22.2.5-0ubuntu0.1~22.04.3
2023-07-03 10:39:20 status half-configured libgl1-mesa-dri:i386 22.2.5-0ubuntu0.1~22.04.3
2023-07-03 10:39:20 status installed libgl1-mesa-dri:i386 22.2.5-0ubuntu0.1~22.04.3
2023-07-03 10:39:20 configure nvidia-driver-530:amd64 535.54.03-0ubuntu0.22.04.1 <none>
2023-07-03 10:39:20 status unpacked nvidia-driver-530:amd64 535.54.03-0ubuntu0.22.04.1
2023-07-03 10:39:20 status half-configured nvidia-driver-530:amd64 535.54.03-0ubuntu0.22.04.1
2023-07-03 10:39:20 status installed nvidia-driver-530:amd64 535.54.03-0ubuntu0.22.04.1
2023-07-03 10:39:20 configure libglx-mesa0:i386 22.2.5-0ubuntu0.1~22.04.3 <none>
2023-07-03 10:39:20 status unpacked libglx-mesa0:i386 22.2.5-0ubuntu0.1~22.04.3
2023-07-03 10:39:20 status half-configured libglx-mesa0:i386 22.2.5-0ubuntu0.1~22.04.3
2023-07-03 10:39:20 status installed libglx-mesa0:i386 22.2.5-0ubuntu0.1~22.04.3
2023-07-03 10:39:20 configure libglx0:i386 1.4.0-1 <none>
2023-07-03 10:39:20 status unpacked libglx0:i386 1.4.0-1
2023-07-03 10:39:20 status half-configured libglx0:i386 1.4.0-1
2023-07-03 10:39:20 status installed libglx0:i386 1.4.0-1
2023-07-03 10:39:20 configure libgl1:i386 1.4.0-1 <none>
2023-07-03 10:39:20 status unpacked libgl1:i386 1.4.0-1
2023-07-03 10:39:20 status half-configured libgl1:i386 1.4.0-1
2023-07-03 10:39:20 status installed libgl1:i386 1.4.0-1
2023-07-03 10:39:20 configure libnvidia-fbc1-535:i386 535.54.03-0ubuntu0.22.04.1 <none>
2023-07-03 10:39:20 status unpacked libnvidia-fbc1-535:i386 535.54.03-0ubuntu0.22.04.1
2023-07-03 10:39:20 status half-configured libnvidia-fbc1-535:i386 535.54.03-0ubuntu0.22.04.1
2023-07-03 10:39:20 status installed libnvidia-fbc1-535:i386 535.54.03-0ubuntu0.22.04.1
2023-07-03 10:39:20 trigproc initramfs-tools:all 0.140ubuntu13.1 <none>
2023-07-03 10:39:20 status half-configured initramfs-tools:all 0.140ubuntu13.1
2023-07-03 10:39:43 status installed initramfs-tools:all 0.140ubuntu13.1
2023-07-03 10:39:43 trigproc libc-bin:amd64 2.35-0ubuntu3.1 <none>
2023-07-03 10:39:43 status half-configured libc-bin:amd64 2.35-0ubuntu3.1
2023-07-03 10:39:43 status installed libc-bin:amd64 2.35-0ubuntu3.1
2023-07-03 10:39:43 trigproc man-db:amd64 2.10.2-1 <none>
2023-07-03 10:39:43 status half-configured man-db:amd64 2.10.2-1
2023-07-03 10:39:44 status installed man-db:amd64 2.10.2-1[/code]
After emergency sync, reboot (sysrq) is all fine.
I was created same report here.
I have received unconfirmed information that something may have changed at Ubuntu in the package packaging.
