Hi everyone. I have lenovo z570 laptop with intel hd 3000 and nvidia gt630m cards. I have installed kali linux 2017.1 and nvidia driver with this tutorial. At first I skip fixing screen tearing part of this tutorial, everything was ok (except tearing). Few days ago I decided to fix tearing (by adding “nvidia-drm.modeset=1” in GRUB_CMDLINE_LINUX_DEFAULT) and it was fixed. But there was another problem: after reboot I can’t see anything except background image on login screen. But if I type login and password I enter the system. In the output of “xrandr --verbose” I see VGA-0 display which I didn’t see before I fixed tearing with adding “nvidia-drm.modeset=1”. What to do with this VGA-0? Give me some advices please.
xrandr --listproviders
Providers: number : 2
Provider 0: id: 0x2bb cap: 0x1, Source Output crtcs: 2 outputs: 1 associated providers: 1 name:NVIDIA-0
Provider 1: id: 0x45 cap: 0x2, Sink Output crtcs: 2 outputs: 4 associated providers: 1 name:modesetting
xrandr --verbose
Screen 0: minimum 8 x 8, current 1366 x 768, maximum 16384 x 16384
VGA-0 connected (normal left inverted right x axis y axis)
Identifier: 0x2be
Timestamp: 62859
Subpixel: unknown
Clones:
CRTCs: 1 2
Transform: 1.000000 0.000000 0.000000
0.000000 1.000000 0.000000
0.000000 0.000000 1.000000
filter:
_MUTTER_PRESENTATION_OUTPUT: 0
BorderDimensions: 4
supported: 4
Border: 0 0 0 0
range: (0, 65535)
SignalFormat: VGA
supported: VGA
ConnectorType: VGA
ConnectorNumber: 1
_ConnectorLocation: 1
1024x768 (0x4a) 65.000MHz -HSync -VSync +preferred
h: width 1024 start 1048 end 1184 total 1344 skew 0 clock 48.36KHz
v: height 768 start 771 end 777 total 806 clock 60.00Hz
1360x768 (0x48) 72.000MHz +HSync -VSync
h: width 1360 start 1408 end 1440 total 1520 skew 0 clock 47.37KHz
v: height 768 start 771 end 781 total 790 clock 59.96Hz
1360x768 (0x47) 84.750MHz -HSync +VSync
h: width 1360 start 1432 end 1568 total 1776 skew 0 clock 47.72KHz
v: height 768 start 771 end 781 total 798 clock 59.80Hz
1152x864 (0x2bf) 81.620MHz -HSync +VSync
h: width 1152 start 1216 end 1336 total 1520 skew 0 clock 53.70KHz
v: height 864 start 865 end 868 total 895 clock 60.00Hz
800x600 (0x2c0) 50.000MHz +HSync +VSync
h: width 800 start 856 end 976 total 1040 skew 0 clock 48.08KHz
v: height 600 start 637 end 643 total 666 clock 72.19Hz
800x600 (0x51) 40.000MHz +HSync +VSync
h: width 800 start 840 end 968 total 1056 skew 0 clock 37.88KHz
v: height 600 start 601 end 605 total 628 clock 60.32Hz
800x600 (0x52) 36.000MHz +HSync +VSync
h: width 800 start 824 end 896 total 1024 skew 0 clock 35.16KHz
v: height 600 start 601 end 603 total 625 clock 56.25Hz
680x384 (0x5c) 36.000MHz +HSync -VSync DoubleScan
h: width 680 start 704 end 720 total 760 skew 0 clock 47.37KHz
v: height 384 start 385 end 390 total 395 clock 59.96Hz
680x384 (0x5b) 42.375MHz -HSync +VSync DoubleScan
h: width 680 start 716 end 784 total 888 skew 0 clock 47.72KHz
v: height 384 start 385 end 390 total 399 clock 59.80Hz
640x480 (0x5a) 25.175MHz -HSync -VSync
h: width 640 start 656 end 752 total 800 skew 0 clock 31.47KHz
v: height 480 start 490 end 492 total 525 clock 59.94Hz
512x384 (0x5e) 32.500MHz -HSync -VSync DoubleScan
h: width 512 start 524 end 592 total 672 skew 0 clock 48.36KHz
v: height 384 start 385 end 388 total 403 clock 60.00Hz
400x300 (0x2c1) 25.000MHz +HSync +VSync DoubleScan
h: width 400 start 428 end 488 total 520 skew 0 clock 48.08KHz
v: height 300 start 318 end 321 total 333 clock 72.19Hz
320x240 (0x61) 12.587MHz -HSync -VSync DoubleScan
h: width 320 start 328 end 376 total 400 skew 0 clock 31.47KHz
v: height 240 start 245 end 246 total 262 clock 60.05Hz
LVDS-1-1 connected primary 1366x768+0+0 (0x46) normal (normal left inverted right x axis y axis) 344mm x 194mm
Identifier: 0x41
Timestamp: 62859
Subpixel: horizontal rgb
Gamma: 1.0:1.0:1.0
Brightness: 1.0
Clones:
CRTC: 0
CRTCs: 0 3
filter:
EDID:
00ffffffffffff0030aeb04000000000
0014010380221378eac8959e57549226
0f505400000001010101010101010101
0101010101017a1e5618510016303020
250058c2100000190000000f00000000
000000000025d9066a00000000fe0053
414d53554e470a2020202020000000fe
004c544e313536415431364c3031001f
PRIME Synchronization: 1
supported: 0, 1
scaling mode: Full aspect
supported: None, Full, Center, Full aspect
1366x768 (0x46) 78.020MHz -HSync -VSync *current +preferred
h: width 1366 start 1414 end 1446 total 1646 skew 0 clock 47.40KHz
v: height 768 start 770 end 775 total 790 clock 60.00Hz
1024x768 (0x49) 133.475MHz -HSync +VSync DoubleScan
h: width 1024 start 1100 end 1212 total 1400 skew 0 clock 95.34KHz
v: height 768 start 768 end 770 total 794 clock 60.04Hz
960x720 (0x4b) 117.000MHz -HSync +VSync DoubleScan
h: width 960 start 1024 end 1128 total 1300 skew 0 clock 90.00KHz
v: height 720 start 720 end 722 total 750 clock 60.00Hz
928x696 (0x4c) 109.150MHz -HSync +VSync DoubleScan
h: width 928 start 976 end 1088 total 1264 skew 0 clock 86.35KHz
v: height 696 start 696 end 698 total 719 clock 60.05Hz
896x672 (0x4d) 102.400MHz -HSync +VSync DoubleScan
h: width 896 start 960 end 1060 total 1224 skew 0 clock 83.66KHz
v: height 672 start 672 end 674 total 697 clock 60.01Hz
960x600 (0x4e) 77.000MHz +HSync -VSync DoubleScan
h: width 960 start 984 end 1000 total 1040 skew 0 clock 74.04KHz
v: height 600 start 601 end 604 total 617 clock 60.00Hz
960x540 (0x4f) 69.250MHz +HSync -VSync DoubleScan
h: width 960 start 984 end 1000 total 1040 skew 0 clock 66.59KHz
v: height 540 start 541 end 544 total 555 clock 59.99Hz
800x600 (0x50) 81.000MHz +HSync +VSync DoubleScan
h: width 800 start 832 end 928 total 1080 skew 0 clock 75.00KHz
v: height 600 start 600 end 602 total 625 clock 60.00Hz
840x525 (0x53) 73.125MHz -HSync +VSync DoubleScan
h: width 840 start 892 end 980 total 1120 skew 0 clock 65.29KHz
v: height 525 start 526 end 529 total 544 clock 60.01Hz
840x525 (0x54) 59.500MHz +HSync -VSync DoubleScan
h: width 840 start 864 end 880 total 920 skew 0 clock 64.67KHz
v: height 525 start 526 end 529 total 540 clock 59.88Hz
800x512 (0x55) 51.562MHz +HSync +VSync DoubleScan
h: width 800 start 800 end 828 total 832 skew 0 clock 61.97KHz
v: height 512 start 512 end 514 total 515 clock 60.17Hz
700x525 (0x56) 61.000MHz +HSync +VSync DoubleScan
h: width 700 start 744 end 820 total 940 skew 0 clock 64.89KHz
v: height 525 start 526 end 532 total 541 clock 59.98Hz
640x512 (0x57) 54.000MHz +HSync +VSync DoubleScan
h: width 640 start 664 end 720 total 844 skew 0 clock 63.98KHz
v: height 512 start 512 end 514 total 533 clock 60.02Hz
720x450 (0x58) 53.250MHz -HSync +VSync DoubleScan
h: width 720 start 760 end 836 total 952 skew 0 clock 55.93KHz
v: height 450 start 451 end 454 total 467 clock 59.89Hz
640x480 (0x59) 54.000MHz +HSync +VSync DoubleScan
h: width 640 start 688 end 744 total 900 skew 0 clock 60.00KHz
v: height 480 start 480 end 482 total 500 clock 60.00Hz
576x432 (0x5d) 40.810MHz -HSync +VSync DoubleScan
h: width 576 start 608 end 668 total 760 skew 0 clock 53.70KHz
v: height 432 start 432 end 434 total 447 clock 60.06Hz
400x300 (0x5f) 20.000MHz +HSync +VSync DoubleScan
h: width 400 start 420 end 484 total 528 skew 0 clock 37.88KHz
v: height 300 start 300 end 302 total 314 clock 60.32Hz
400x300 (0x60) 18.000MHz +HSync +VSync DoubleScan
h: width 400 start 412 end 448 total 512 skew 0 clock 35.16KHz
v: height 300 start 300 end 301 total 312 clock 56.34Hz
VGA-1-2 disconnected (normal left inverted right x axis y axis)
Identifier: 0x42
Timestamp: 62859
Subpixel: unknown
Clones:
CRTCs: 0 3
filter:
supported: 0, 1
HDMI-1-1 disconnected (normal left inverted right x axis y axis)
Identifier: 0x43
Timestamp: 62859
Subpixel: unknown
Clones:
CRTCs: 0 3
filter:
supported: 0, 1
aspect ratio: Automatic
supported: Automatic, 4:3, 16:9
Broadcast RGB: Automatic
supported: Automatic, Full, Limited 16:235
audio: auto
supported: force-dvi, off, auto, on
DP-1-1 disconnected (normal left inverted right x axis y axis)
Identifier: 0x44
Timestamp: 62859
Subpixel: unknown
Clones:
CRTCs: 0 3
filter:
supported: 0, 1
audio: auto
xorg.conf
Section "ServerLayout"
Identifier "layout"
Screen 0 "nvidia"
Inactive "intel"
EndSection
Section "Device"
Identifier "intel"
Driver "modesetting"
BusID "PCI:0@0:2:0"
Option "AccelMethod" "None"
EndSection
Section "Screen"
Identifier "intel"
Device "intel"
EndSection
Section "Device"
Identifier "nvidia"
Driver "nvidia"
BusID "PCI:1@0:0:0"
Option "ConstrainCursor" "off"
EndSection
Section "Screen"
Identifier "nvidia"
Device "nvidia"
Option "AllowEmptyInitialConfiguration" "on"
Option "IgnoreDisplayDevices" "CRT"
EndSection
xorg.log
[ 117.838] _XSERVTransSocketUNIXCreateListener: ...SocketCreateListener() failed
[ 117.838] _XSERVTransMakeAllCOTSServerListeners: server already running
[ 117.838] (--) Log file renamed from "/var/log/Xorg.pid-986.log" to "/var/log/Xorg.1.log"
[ 117.838]
X.Org X Server 1.19.2
Release Date: 2017-03-02
[ 117.838] X Protocol Version 11, Revision 0
[ 117.838] Build Operating System: Linux 3.16.0-4-amd64 x86_64 Debian
[ 117.838] Current Operating System: Linux kali 4.9.0-kali4-amd64 #1 SMP Debian 4.9.25-1kali1 (2017-05-04) x86_64
[ 117.838] Kernel command line: BOOT_IMAGE=/boot/vmlinuz-4.9.0-kali4-amd64 root=UUID=85dd9b70-4688-4797-801f-f8d2f7f0ce47 ro initrd=/install/gtk/initrd.gz quiet acpi_backlight=none nvidia-drm.modeset=1
[ 117.838] Build Date: 03 March 2017 03:14:41PM
[ 117.838] xorg-server 2:1.19.2-1 (https://www.debian.org/support)
[ 117.838] Current version of pixman: 0.34.0
[ 117.838] Before reporting problems, check http://wiki.x.org
to make sure that you have the latest version.
[ 117.838] Markers: (--) probed, (**) from config file, (==) default setting,
(++) from command line, (!!) notice, (II) informational,
(WW) warning, (EE) error, (NI) not implemented, (??) unknown.
[ 117.838] (==) Log file: "/var/log/Xorg.1.log", Time: Sat Jun 3 10:39:41 2017
[ 117.839] (==) Using config file: "/etc/X11/xorg.conf"
[ 117.839] (==) Using system config directory "/usr/share/X11/xorg.conf.d"
[ 117.839] (==) ServerLayout "layout"
[ 117.839] (**) |-->Screen "nvidia" (0)
[ 117.839] (**) | |-->Monitor "<default monitor>"
[ 117.839] (**) | |-->Device "nvidia"
[ 117.839] (**) | |-->GPUDevice "nvidia"
[ 117.839] (==) No monitor specified for screen "nvidia".
Using a default monitor configuration.
[ 117.839] (**) |-->Inactive Device "intel"
[ 117.839] (==) Automatically adding devices
[ 117.839] (==) Automatically enabling devices
[ 117.839] (==) Automatically adding GPU devices
[ 117.839] (==) Max clients allowed: 256, resource mask: 0x1fffff
[ 117.839] (WW) The directory "/usr/share/fonts/X11/cyrillic" does not exist.
[ 117.839] Entry deleted from font path.
[ 117.839] (WW) The directory "/usr/share/fonts/X11/100dpi/" does not exist.
[ 117.839] (WW) The directory "/usr/share/fonts/X11/75dpi/" does not exist.
[ 117.839] (WW) The directory "/usr/share/fonts/X11/100dpi" does not exist.
[ 117.839] (WW) The directory "/usr/share/fonts/X11/75dpi" does not exist.
[ 117.839] (==) FontPath set to:
/usr/share/fonts/X11/misc,
/usr/share/fonts/X11/Type1,
built-ins
[ 117.839] (==) ModulePath set to "/usr/lib/xorg/modules"
[ 117.839] (II) The server relies on udev to provide the list of input devices.
If no devices become available, reconfigure udev or disable AutoAddDevices.
[ 117.839] (II) Loader magic: 0x563f16742e00
[ 117.839] (II) Module ABI versions:
[ 117.839] X.Org ANSI C Emulation: 0.4
[ 117.839] X.Org Video Driver: 23.0
[ 117.839] X.Org XInput driver : 24.1
[ 117.839] X.Org Server Extension : 10.0
[ 117.840] (++) using VT number 2
[ 117.844] (II) systemd-logind: took control of session /org/freedesktop/login1/session/_35
[ 117.845] (II) xfree86: Adding drm device (/dev/dri/card0)
[ 117.849] (II) systemd-logind: got fd for /dev/dri/card0 226:0 fd 13 paused 0
[ 117.849] (II) xfree86: Adding drm device (/dev/dri/card1)
[ 117.849] (II) systemd-logind: got fd for /dev/dri/card1 226:1 fd 14 paused 0
[ 117.851] (--) PCI:*(0:0:2:0) 8086:0116:17aa:397d rev 9, Mem @ 0xf1000000/4194304, 0xe0000000/268435456, I/O @ 0x00004000/64, BIOS @ 0x????????/131072
[ 117.851] (--) PCI: (0:1:0:0) 10de:0de9:17aa:397d rev 161, Mem @ 0xf0000000/16777216, 0xc0000000/268435456, 0xd0000000/33554432, I/O @ 0x00003000/128
[ 117.851] (II) LoadModule: "glx"
[ 117.851] (II) Loading /usr/lib/xorg/modules/linux/libglx.so
[ 117.856] (II) Module glx: vendor="NVIDIA Corporation"
[ 117.856] compiled for 4.0.2, module version = 1.0.0
[ 117.856] Module class: X.Org Server Extension
[ 117.856] (II) NVIDIA GLX Module 375.66 Mon May 1 14:28:39 PDT 2017
[ 117.856] (II) LoadModule: "nvidia"
[ 117.856] (II) Loading /usr/lib/xorg/modules/drivers/nvidia_drv.so
[ 117.856] (II) Module nvidia: vendor="NVIDIA Corporation"
[ 117.856] Module class: X.Org Video Driver
[ 117.857] (II) LoadModule: "modesetting"
[ 117.857] (II) Loading /usr/lib/xorg/modules/drivers/modesetting_drv.so
[ 117.857] (II) Module modesetting: vendor="X.Org Foundation"
[ 117.857] compiled for 1.19.2, module version = 1.19.2
[ 117.857] Module class: X.Org Video Driver
[ 117.857] ABI class: X.Org Video Driver, version 23.0
[ 117.857] (II) NVIDIA dlloader X Driver 375.66 Mon May 1 14:03:26 PDT 2017
[ 117.857] (II) NVIDIA Unified Driver for all Supported NVIDIA GPUs
[ 117.857] (II) modesetting: Driver for Modesetting Kernel Drivers: kms
[ 117.857] (II) systemd-logind: releasing fd for 226:0
[ 117.883] (II) Loading sub module "fb"
[ 117.883] (II) LoadModule: "fb"
[ 117.883] (II) Loading /usr/lib/xorg/modules/libfb.so
[ 117.883] (II) Module fb: vendor="X.Org Foundation"
[ 117.883] compiled for 1.19.2, module version = 1.0.0
[ 117.883] ABI class: X.Org ANSI C Emulation, version 0.4
[ 117.883] (II) Loading sub module "wfb"
[ 117.883] (II) LoadModule: "wfb"
[ 117.883] (II) Loading /usr/lib/xorg/modules/libwfb.so
[ 117.883] (II) Module wfb: vendor="X.Org Foundation"
[ 117.884] (II) Loading sub module "ramdac"
[ 117.884] (II) LoadModule: "ramdac"
[ 117.884] (II) Module "ramdac" already built-in
[ 117.884] (II) modeset(G0): using drv /dev/dri/card1
[ 117.884] (II) NVIDIA(0): Creating default Display subsection in Screen section
"nvidia" for depth/fbbpp 24/32
[ 117.884] (==) NVIDIA(0): Depth 24, (==) framebuffer bpp 32
[ 117.884] (==) NVIDIA(0): RGB weight 888
[ 117.884] (==) NVIDIA(0): Default visual is TrueColor
[ 117.884] (==) NVIDIA(0): Using gamma correction (1.0, 1.0, 1.0)
[ 117.884] (**) NVIDIA(0): Option "ConstrainCursor" "off"
[ 117.884] (**) NVIDIA(0): Option "AllowEmptyInitialConfiguration" "on"
[ 117.884] (**) NVIDIA(0): Option "IgnoreDisplayDevices" "CRT"
[ 117.884] (**) NVIDIA(0): Enabling 2D acceleration
[ 117.886] (--) NVIDIA(0): Valid display device(s) on GPU-0 at PCI:1:0:0
[ 117.886] (--) NVIDIA(0): CRT-0 (boot)
[ 117.887] (II) NVIDIA(0): NVIDIA GPU GeForce GT 630M (GF108) at PCI:1:0:0 (GPU-0)
[ 117.887] (--) NVIDIA(0): Memory: 1048576 kBytes
[ 117.887] (--) NVIDIA(0): VideoBIOS: 70.08.92.00.19
[ 117.887] (II) NVIDIA(0): Detected PCI Express Link width: 16X
[ 117.889] (--) NVIDIA(GPU-0): CRT-0: connected
[ 117.889] (--) NVIDIA(GPU-0): CRT-0: 400.0 MHz maximum pixel clock
[ 117.891] (==) NVIDIA(0):
[ 117.892] (==) NVIDIA(0): No modes were requested; the default mode "nvidia-auto-select"
[ 117.892] (==) NVIDIA(0): will be used as the requested mode.
[ 117.892] (II) NVIDIA(0): Validated MetaModes:
[ 117.892] (II) NVIDIA(0): "CRT-0:nvidia-auto-select"
[ 117.892] (II) NVIDIA(0): Virtual screen size determined to be 1024 x 768
[ 117.899] (WW) NVIDIA(0): CRT-0 does not have an EDID, or its EDID does not contain a
[ 117.899] (WW) NVIDIA(0): maximum image size; cannot compute DPI from CRT-0's EDID.
[ 117.899] (==) NVIDIA(0): DPI set to (75, 75); computed from built-in default
[ 117.899] (==) modeset(G0): Depth 24, (==) framebuffer bpp 32
[ 117.899] (**) modeset(G0): Option "AccelMethod" "None"
[ 117.899] (==) modeset(G0): RGB weight 888
[ 117.899] (==) modeset(G0): Default visual is TrueColor
[ 117.899] (**) modeset(G0): glamor disabled
[ 117.899] (II) modeset(G0): ShadowFB: preferred YES, enabled YES
[ 117.899] (II) modeset(G0): Double-buffered shadow updates: off
[ 117.899] (II) modeset(G0): Output LVDS-1-1 has no monitor section
[ 117.900] (II) modeset(G0): Output VGA-1-2 has no monitor section
[ 117.901] (II) modeset(G0): Output HDMI-1-1 has no monitor section
[ 117.901] (II) modeset(G0): Output DP-1-1 has no monitor section
[ 117.901] (II) modeset(G0): EDID for output LVDS-1-1
[ 117.901] (II) modeset(G0): Manufacturer: LEN Model: 40b0 Serial#: 0
[ 117.901] (II) modeset(G0): Year: 2010 Week: 0
[ 117.901] (II) modeset(G0): EDID Version: 1.3
[ 117.901] (II) modeset(G0): Digital Display Input
[ 117.901] (II) modeset(G0): Max Image Size [cm]: horiz.: 34 vert.: 19
[ 117.901] (II) modeset(G0): Gamma: 2.20
[ 117.901] (II) modeset(G0): DPMS capabilities: StandBy Suspend Off
[ 117.901] (II) modeset(G0): Supported color encodings: RGB 4:4:4 YCrCb 4:4:4
[ 117.901] (II) modeset(G0): First detailed timing is preferred mode
[ 117.901] (II) modeset(G0): redX: 0.620 redY: 0.340 greenX: 0.330 greenY: 0.570
[ 117.901] (II) modeset(G0): blueX: 0.150 blueY: 0.060 whiteX: 0.313 whiteY: 0.329
[ 117.901] (II) modeset(G0): Manufacturer's mask: 0
[ 117.901] (II) modeset(G0): Supported detailed timing:
[ 117.901] (II) modeset(G0): clock: 78.0 MHz Image Size: 344 x 194 mm
[ 117.901] (II) modeset(G0): h_active: 1366 h_sync: 1414 h_sync_end 1446 h_blank_end 1646 h_border: 0
[ 117.901] (II) modeset(G0): v_active: 768 v_sync: 770 v_sync_end 775 v_blanking: 790 v_border: 0
[ 117.901] (II) modeset(G0): Unknown vendor-specific block f
[ 117.901] (II) modeset(G0): SAMSUNG
[ 117.901] (II) modeset(G0): LTN156AT16L01
[ 117.901] (II) modeset(G0): EDID (in hex):
[ 117.901] (II) modeset(G0): 00ffffffffffff0030aeb04000000000
[ 117.901] (II) modeset(G0): 0014010380221378eac8959e57549226
[ 117.901] (II) modeset(G0): 0f505400000001010101010101010101
[ 117.901] (II) modeset(G0): 0101010101017a1e5618510016303020
[ 117.901] (II) modeset(G0): 250058c2100000190000000f00000000
[ 117.901] (II) modeset(G0): 000000000025d9066a00000000fe0053
[ 117.901] (II) modeset(G0): 414d53554e470a2020202020000000fe
[ 117.901] (II) modeset(G0): 004c544e313536415431364c3031001f
[ 117.902] (II) modeset(G0): Printing probed modes for output LVDS-1-1
[ 117.902] (II) modeset(G0): Modeline "1366x768"x60.0 78.02 1366 1414 1446 1646 768 770 775 790 -hsync -vsync (47.4 kHz eP)
[ 117.902] (II) modeset(G0): Modeline "1360x768"x59.8 84.75 1360 1432 1568 1776 768 771 781 798 -hsync +vsync (47.7 kHz d)
[ 117.902] (II) modeset(G0): Modeline "1360x768"x60.0 72.00 1360 1408 1440 1520 768 771 781 790 +hsync -vsync (47.4 kHz d)
[ 117.902] (II) modeset(G0): Modeline "1024x768"x120.1 133.47 1024 1100 1212 1400 768 768 770 794 doublescan -hsync +vsync (95.3 kHz d)
[ 117.902] (II) modeset(G0): Modeline "1024x768"x60.0 65.00 1024 1048 1184 1344 768 771 777 806 -hsync -vsync (48.4 kHz d)
[ 117.902] (II) modeset(G0): Modeline "960x720"x120.0 117.00 960 1024 1128 1300 720 720 722 750 doublescan -hsync +vsync (90.0 kHz d)
[ 117.902] (II) modeset(G0): Modeline "928x696"x120.1 109.15 928 976 1088 1264 696 696 698 719 doublescan -hsync +vsync (86.4 kHz d)
[ 117.902] (II) modeset(G0): Modeline "896x672"x120.0 102.40 896 960 1060 1224 672 672 674 697 doublescan -hsync +vsync (83.7 kHz d)
[ 117.902] (II) modeset(G0): Modeline "960x600"x120.0 77.00 960 984 1000 1040 600 601 604 617 doublescan +hsync -vsync (74.0 kHz d)
[ 117.902] (II) modeset(G0): Modeline "960x540"x120.0 69.25 960 984 1000 1040 540 541 544 555 doublescan +hsync -vsync (66.6 kHz d)
[ 117.902] (II) modeset(G0): Modeline "800x600"x120.0 81.00 800 832 928 1080 600 600 602 625 doublescan +hsync +vsync (75.0 kHz d)
[ 117.902] (II) modeset(G0): Modeline "800x600"x60.3 40.00 800 840 968 1056 600 601 605 628 +hsync +vsync (37.9 kHz d)
[ 117.902] (II) modeset(G0): Modeline "800x600"x56.2 36.00 800 824 896 1024 600 601 603 625 +hsync +vsync (35.2 kHz d)
[ 117.902] (II) modeset(G0): Modeline "840x525"x120.0 73.12 840 892 980 1120 525 526 529 544 doublescan -hsync +vsync (65.3 kHz d)
[ 117.902] (II) modeset(G0): Modeline "840x525"x119.8 59.50 840 864 880 920 525 526 529 540 doublescan +hsync -vsync (64.7 kHz d)
[ 117.902] (II) modeset(G0): Modeline "800x512"x120.3 51.56 800 800 828 832 512 512 514 515 doublescan +hsync +vsync (62.0 kHz d)
[ 117.902] (II) modeset(G0): Modeline "700x525"x120.0 61.00 700 744 820 940 525 526 532 541 doublescan +hsync +vsync (64.9 kHz d)
[ 117.902] (II) modeset(G0): Modeline "640x512"x120.0 54.00 640 664 720 844 512 512 514 533 doublescan +hsync +vsync (64.0 kHz d)
[ 117.902] (II) modeset(G0): Modeline "720x450"x119.8 53.25 720 760 836 952 450 451 454 467 doublescan -hsync +vsync (55.9 kHz d)
[ 117.902] (II) modeset(G0): Modeline "640x480"x120.0 54.00 640 688 744 900 480 480 482 500 doublescan +hsync +vsync (60.0 kHz d)
[ 117.902] (II) modeset(G0): Modeline "640x480"x59.9 25.18 640 656 752 800 480 490 492 525 -hsync -vsync (31.5 kHz d)
[ 117.902] (II) modeset(G0): Modeline "680x384"x119.6 42.38 680 716 784 888 384 385 390 399 doublescan -hsync +vsync (47.7 kHz d)
[ 117.902] (II) modeset(G0): Modeline "680x384"x119.9 36.00 680 704 720 760 384 385 390 395 doublescan +hsync -vsync (47.4 kHz d)
[ 117.902] (II) modeset(G0): Modeline "576x432"x120.1 40.81 576 608 668 760 432 432 434 447 doublescan -hsync +vsync (53.7 kHz d)
[ 117.902] (II) modeset(G0): Modeline "512x384"x120.0 32.50 512 524 592 672 384 385 388 403 doublescan -hsync -vsync (48.4 kHz d)
[ 117.902] (II) modeset(G0): Modeline "400x300"x120.6 20.00 400 420 484 528 300 300 302 314 doublescan +hsync +vsync (37.9 kHz d)
[ 117.902] (II) modeset(G0): Modeline "400x300"x112.7 18.00 400 412 448 512 300 300 301 312 doublescan +hsync +vsync (35.2 kHz d)
[ 117.902] (II) modeset(G0): Modeline "320x240"x120.1 12.59 320 328 376 400 240 245 246 262 doublescan -hsync -vsync (31.5 kHz d)
[ 117.903] (II) modeset(G0): EDID for output VGA-1-2
[ 117.904] (II) modeset(G0): EDID for output HDMI-1-1
[ 117.904] (II) modeset(G0): EDID for output DP-1-1
[ 117.904] (==) modeset(G0): Using gamma correction (1.0, 1.0, 1.0)
[ 117.904] (==) modeset(G0): DPI set to (96, 96)
[ 117.904] (II) Loading sub module "fb"
[ 117.904] (II) LoadModule: "fb"
[ 117.904] (II) Loading /usr/lib/xorg/modules/libfb.so
[ 117.904] (II) Module fb: vendor="X.Org Foundation"
[ 117.904] compiled for 1.19.2, module version = 1.0.0
[ 117.904] ABI class: X.Org ANSI C Emulation, version 0.4
[ 117.904] (II) Loading sub module "shadow"
[ 117.904] (II) LoadModule: "shadow"
[ 117.904] (II) Loading /usr/lib/xorg/modules/libshadow.so
[ 117.904] (II) Module shadow: vendor="X.Org Foundation"
[ 117.904] compiled for 1.19.2, module version = 1.1.0
[ 117.904] (--) Depth 24 pixmap format is 32 bpp
[ 117.905] (==) modeset(G0): Backing store enabled
[ 117.905] (==) modeset(G0): Silken mouse enabled
[ 117.905] (II) modeset(G0): RandR 1.2 enabled, ignore the following RandR disabled message.
[ 117.905] (==) modeset(G0): DPMS enabled
[ 117.905] (WW) modeset(G0): Option "AllowEmptyInitialConfiguration" is not used
[ 117.905] (WW) modeset(G0): Option "IgnoreDisplayDevices" is not used
[ 117.905] (II) NVIDIA: Using 12288.00 MB of virtual memory for indirect memory
[ 117.905] (II) NVIDIA: access.
[ 117.908] (II) NVIDIA(0): ACPI: failed to connect to the ACPI event daemon; the daemon
[ 117.908] (II) NVIDIA(0): may not be running or the "AcpidSocketPath" X
[ 117.908] (II) NVIDIA(0): configuration option may not be set correctly. When the
[ 117.908] (II) NVIDIA(0): ACPI event daemon is available, the NVIDIA X driver will
[ 117.908] (II) NVIDIA(0): try to use it to receive ACPI event notifications. For
[ 117.908] (II) NVIDIA(0): details, please see the "ConnectToAcpid" and
[ 117.909] (II) NVIDIA(0): "AcpidSocketPath" X configuration options in Appendix B: X
[ 117.909] (II) NVIDIA(0): Config Options in the README.
[ 117.932] (II) NVIDIA(0): Setting mode "CRT-0:nvidia-auto-select"
[ 117.956] (==) NVIDIA(0): Disabling shared memory pixmaps
[ 117.956] (==) NVIDIA(0): Backing store enabled
[ 117.956] (==) NVIDIA(0): Silken mouse enabled
[ 117.956] (==) NVIDIA(0): DPMS enabled
[ 117.956] (II) Loading sub module "dri2"
[ 117.956] (II) LoadModule: "dri2"
[ 117.956] (II) Module "dri2" already built-in
[ 117.956] (II) NVIDIA(0): [DRI2] Setup complete
[ 117.956] (II) NVIDIA(0): [DRI2] VDPAU driver: nvidia
[ 117.956] (--) RandR disabled
[ 117.961] (II) SELinux: Disabled on system
[ 117.961] (II) Initializing extension GLX
[ 117.961] (II) Indirect GLX disabled.
[ 118.310] (II) modeset(G0): Damage tracking initialized
[ 118.402] (II) config/udev: Adding input device Power Button (/dev/input/event5)
[ 118.402] (**) Power Button: Applying InputClass "libinput keyboard catchall"
[ 118.402] (II) LoadModule: "libinput"
[ 118.402] (II) Loading /usr/lib/xorg/modules/input/libinput_drv.so
[ 118.405] (II) Module libinput: vendor="X.Org Foundation"
[ 118.405] compiled for 1.19.0, module version = 0.23.0
[ 118.405] Module class: X.Org XInput Driver
[ 118.405] ABI class: X.Org XInput driver, version 24.1
[ 118.405] (II) Using input driver 'libinput' for 'Power Button'
[ 118.405] (II) systemd-logind: got fd for /dev/input/event5 13:69 fd 40 paused 0
[ 118.405] (**) Power Button: always reports core events
[ 118.405] (**) Option "Device" "/dev/input/event5"
[ 118.405] (**) Option "_source" "server/udev"
[ 118.406] (II) input device 'Power Button', /dev/input/event5 is tagged by udev as: Keyboard
[ 118.406] (II) input device 'Power Button', /dev/input/event5 is a keyboard
[ 118.406] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXPWRBN:00/input/input6/event5"
[ 118.406] (II) XINPUT: Adding extended input device "Power Button" (type: KEYBOARD, id 6)
[ 118.406] (**) Option "xkb_model" "pc105"
[ 118.406] (**) Option "xkb_layout" "us,ru"
[ 118.406] (**) Option "xkb_variant" ","
[ 118.406] (**) Option "xkb_options" "grp:alt_shift_toggle,grp_led:scroll"
[ 118.434] (II) input device 'Power Button', /dev/input/event5 is tagged by udev as: Keyboard
[ 118.434] (II) input device 'Power Button', /dev/input/event5 is a keyboard
[ 118.434] (II) config/udev: Adding input device Video Bus (/dev/input/event8)
[ 118.434] (**) Video Bus: Applying InputClass "libinput keyboard catchall"
[ 118.434] (II) Using input driver 'libinput' for 'Video Bus'
[ 118.435] (II) systemd-logind: got fd for /dev/input/event8 13:72 fd 43 paused 0
[ 118.435] (**) Video Bus: always reports core events
[ 118.435] (**) Option "Device" "/dev/input/event8"
[ 118.435] (**) Option "_source" "server/udev"
[ 118.435] (II) input device 'Video Bus', /dev/input/event8 is tagged by udev as: Keyboard
[ 118.435] (II) input device 'Video Bus', /dev/input/event8 is a keyboard
[ 118.435] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/LNXVIDEO:01/input/input12/event8"
[ 118.436] (II) XINPUT: Adding extended input device "Video Bus" (type: KEYBOARD, id 7)
[ 118.436] (**) Option "xkb_model" "pc105"
[ 118.436] (**) Option "xkb_layout" "us,ru"
[ 118.436] (**) Option "xkb_variant" ","
[ 118.436] (**) Option "xkb_options" "grp:alt_shift_toggle,grp_led:scroll"
[ 118.436] (II) input device 'Video Bus', /dev/input/event8 is tagged by udev as: Keyboard
[ 118.436] (II) input device 'Video Bus', /dev/input/event8 is a keyboard
[ 118.437] (II) config/udev: Adding input device Video Bus (/dev/input/event7)
[ 118.437] (**) Video Bus: Applying InputClass "libinput keyboard catchall"
[ 118.437] (II) Using input driver 'libinput' for 'Video Bus'
[ 118.437] (II) systemd-logind: got fd for /dev/input/event7 13:71 fd 44 paused 0
[ 118.437] (**) Video Bus: always reports core events
[ 118.437] (**) Option "Device" "/dev/input/event7"
[ 118.437] (**) Option "_source" "server/udev"
[ 118.438] (II) input device 'Video Bus', /dev/input/event7 is tagged by udev as: Keyboard
[ 118.438] (II) input device 'Video Bus', /dev/input/event7 is a keyboard
[ 118.438] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/device:35/LNXVIDEO:00/input/input11/event7"
[ 118.438] (II) XINPUT: Adding extended input device "Video Bus" (type: KEYBOARD, id 8)
[ 118.438] (**) Option "xkb_model" "pc105"
[ 118.438] (**) Option "xkb_layout" "us,ru"
[ 118.438] (**) Option "xkb_variant" ","
[ 118.438] (**) Option "xkb_options" "grp:alt_shift_toggle,grp_led:scroll"
[ 118.439] (II) input device 'Video Bus', /dev/input/event7 is tagged by udev as: Keyboard
[ 118.439] (II) input device 'Video Bus', /dev/input/event7 is a keyboard
[ 118.439] (II) config/udev: Adding input device Lid Switch (/dev/input/event3)
[ 118.439] (II) No input driver specified, ignoring this device.
[ 118.439] (II) This device may have been added with another device file.
[ 118.439] (II) config/udev: Adding input device Sleep Button (/dev/input/event4)
[ 118.439] (**) Sleep Button: Applying InputClass "libinput keyboard catchall"
[ 118.439] (II) Using input driver 'libinput' for 'Sleep Button'
[ 118.440] (II) systemd-logind: got fd for /dev/input/event4 13:68 fd 45 paused 0
[ 118.440] (**) Sleep Button: always reports core events
[ 118.440] (**) Option "Device" "/dev/input/event4"
[ 118.440] (**) Option "_source" "server/udev"
[ 118.440] (II) input device 'Sleep Button', /dev/input/event4 is tagged by udev as: Keyboard
[ 118.440] (II) input device 'Sleep Button', /dev/input/event4 is a keyboard
[ 118.440] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0E:00/input/input5/event4"
[ 118.440] (II) XINPUT: Adding extended input device "Sleep Button" (type: KEYBOARD, id 9)
[ 118.440] (**) Option "xkb_model" "pc105"
[ 118.440] (**) Option "xkb_layout" "us,ru"
[ 118.440] (**) Option "xkb_variant" ","
[ 118.440] (**) Option "xkb_options" "grp:alt_shift_toggle,grp_led:scroll"
[ 118.441] (II) input device 'Sleep Button', /dev/input/event4 is tagged by udev as: Keyboard
[ 118.441] (II) input device 'Sleep Button', /dev/input/event4 is a keyboard
[ 118.442] (II) config/udev: Adding input device A4Tech PS/2+USB Mouse (/dev/input/event2)
[ 118.442] (**) A4Tech PS/2+USB Mouse: Applying InputClass "libinput pointer catchall"
[ 118.442] (II) Using input driver 'libinput' for 'A4Tech PS/2+USB Mouse'
[ 118.442] (II) systemd-logind: got fd for /dev/input/event2 13:66 fd 46 paused 0
[ 118.442] (**) A4Tech PS/2+USB Mouse: always reports core events
[ 118.443] (**) Option "Device" "/dev/input/event2"
[ 118.443] (**) Option "_source" "server/udev"
[ 118.443] (II) input device 'A4Tech PS/2+USB Mouse', /dev/input/event2 is tagged by udev as: Mouse
[ 118.443] (II) input device 'A4Tech PS/2+USB Mouse', /dev/input/event2 is a pointer caps
[ 118.443] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:1a.0/usb1/1-1/1-1.3/1-1.3:1.0/0003:09DA:000E.0001/input/input3/event2"
[ 118.443] (II) XINPUT: Adding extended input device "A4Tech PS/2+USB Mouse" (type: MOUSE, id 10)
[ 118.443] (**) Option "AccelerationScheme" "none"
[ 118.443] (**) A4Tech PS/2+USB Mouse: (accel) selected scheme none/0
[ 118.443] (**) A4Tech PS/2+USB Mouse: (accel) acceleration factor: 2.000
[ 118.443] (**) A4Tech PS/2+USB Mouse: (accel) acceleration threshold: 4
[ 118.444] (II) input device 'A4Tech PS/2+USB Mouse', /dev/input/event2 is tagged by udev as: Mouse
[ 118.444] (II) input device 'A4Tech PS/2+USB Mouse', /dev/input/event2 is a pointer caps
[ 118.444] (II) config/udev: Adding input device A4Tech PS/2+USB Mouse (/dev/input/mouse1)
[ 118.444] (II) No input driver specified, ignoring this device.
[ 118.444] (II) This device may have been added with another device file.
[ 118.445] (II) config/udev: Adding input device Lenovo EasyCamera (/dev/input/event14)
[ 118.445] (**) Lenovo EasyCamera: Applying InputClass "libinput keyboard catchall"
[ 118.445] (II) Using input driver 'libinput' for 'Lenovo EasyCamera'
[ 118.445] (II) systemd-logind: got fd for /dev/input/event14 13:78 fd 47 paused 0
[ 118.445] (**) Lenovo EasyCamera: always reports core events
[ 118.445] (**) Option "Device" "/dev/input/event14"
[ 118.445] (**) Option "_source" "server/udev"
[ 118.446] (II) input device 'Lenovo EasyCamera', /dev/input/event14 is tagged by udev as: Keyboard
[ 118.446] (II) input device 'Lenovo EasyCamera', /dev/input/event14 is a keyboard
[ 118.446] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:1a.0/usb1/1-1/1-1.5/1-1.5:1.0/input/input15/event14"
[ 118.446] (II) XINPUT: Adding extended input device "Lenovo EasyCamera" (type: KEYBOARD, id 11)
[ 118.446] (**) Option "xkb_model" "pc105"
[ 118.446] (**) Option "xkb_layout" "us,ru"
[ 118.446] (**) Option "xkb_variant" ","
[ 118.446] (**) Option "xkb_options" "grp:alt_shift_toggle,grp_led:scroll"
[ 118.447] (II) config/udev: Adding input device HDA Intel PCH Headphone (/dev/input/event12)
[ 118.447] (II) No input driver specified, ignoring this device.
[ 118.447] (II) This device may have been added with another device file.
[ 118.447] (II) config/udev: Adding input device HDA Intel PCH HDMI/DP,pcm=3 (/dev/input/event13)
[ 118.447] (II) config/udev: Adding input device HDA Digital PCBeep (/dev/input/event10)
[ 118.447] (II) config/udev: Adding input device HDA Intel PCH Mic (/dev/input/event11)
[ 118.448] (II) config/udev: Adding input device Ideapad extra buttons (/dev/input/event9)
[ 118.448] (**) Ideapad extra buttons: Applying InputClass "libinput keyboard catchall"
[ 118.448] (II) Using input driver 'libinput' for 'Ideapad extra buttons'
[ 118.448] (II) systemd-logind: got fd for /dev/input/event9 13:73 fd 48 paused 0
[ 118.448] (**) Ideapad extra buttons: always reports core events
[ 118.448] (**) Option "Device" "/dev/input/event9"
[ 118.448] (**) Option "_source" "server/udev"
[ 118.449] (II) input device 'Ideapad extra buttons', /dev/input/event9 is tagged by udev as: Keyboard
[ 118.449] (II) input device 'Ideapad extra buttons', /dev/input/event9 is a keyboard
[ 118.449] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:1f.0/PNP0C09:00/VPC2004:00/input/input13/event9"
[ 118.449] (II) XINPUT: Adding extended input device "Ideapad extra buttons" (type: KEYBOARD, id 12)
[ 118.449] (**) Option "xkb_model" "pc105"
[ 118.449] (**) Option "xkb_layout" "us,ru"
[ 118.449] (**) Option "xkb_variant" ","
[ 118.449] (**) Option "xkb_options" "grp:alt_shift_toggle,grp_led:scroll"
[ 118.450] (II) config/udev: Adding input device AT Translated Set 2 keyboard (/dev/input/event0)
[ 118.450] (**) AT Translated Set 2 keyboard: Applying InputClass "libinput keyboard catchall"
[ 118.450] (II) Using input driver 'libinput' for 'AT Translated Set 2 keyboard'
[ 118.450] (II) systemd-logind: got fd for /dev/input/event0 13:64 fd 49 paused 0
[ 118.450] (**) AT Translated Set 2 keyboard: always reports core events
[ 118.450] (**) Option "Device" "/dev/input/event0"
[ 118.450] (**) Option "_source" "server/udev"
[ 118.451] (II) input device 'AT Translated Set 2 keyboard', /dev/input/event0 is tagged by udev as: Keyboard
[ 118.451] (II) input device 'AT Translated Set 2 keyboard', /dev/input/event0 is a keyboard
[ 118.451] (**) Option "config_info" "udev:/sys/devices/platform/i8042/serio0/input/input0/event0"
[ 118.451] (II) XINPUT: Adding extended input device "AT Translated Set 2 keyboard" (type: KEYBOARD, id 13)
[ 118.451] (**) Option "xkb_model" "pc105"
[ 118.451] (**) Option "xkb_layout" "us,ru"
[ 118.451] (**) Option "xkb_variant" ","
[ 118.451] (**) Option "xkb_options" "grp:alt_shift_toggle,grp_led:scroll"
[ 118.452] (II) config/udev: Adding input device SynPS/2 Synaptics TouchPad (/dev/input/event1)
[ 118.452] (**) SynPS/2 Synaptics TouchPad: Applying InputClass "libinput touchpad catchall"
[ 118.452] (II) Using input driver 'libinput' for 'SynPS/2 Synaptics TouchPad'
[ 118.452] (II) systemd-logind: got fd for /dev/input/event1 13:65 fd 50 paused 0
[ 118.452] (**) SynPS/2 Synaptics TouchPad: always reports core events
[ 118.452] (**) Option "Device" "/dev/input/event1"
[ 118.452] (**) Option "_source" "server/udev"
[ 118.452] (II) input device 'SynPS/2 Synaptics TouchPad', /dev/input/event1 is tagged by udev as: Touchpad
[ 118.452] (II) input device 'SynPS/2 Synaptics TouchPad', /dev/input/event1 is a touchpad
[ 118.453] (**) Option "config_info" "udev:/sys/devices/platform/i8042/serio1/input/input2/event1"
[ 118.453] (II) XINPUT: Adding extended input device "SynPS/2 Synaptics TouchPad" (type: TOUCHPAD, id 14)
[ 118.453] (**) Option "AccelerationScheme" "none"
[ 118.453] (**) SynPS/2 Synaptics TouchPad: (accel) selected scheme none/0
[ 118.453] (**) SynPS/2 Synaptics TouchPad: (accel) acceleration factor: 2.000
[ 118.453] (**) SynPS/2 Synaptics TouchPad: (accel) acceleration threshold: 4
[ 118.453] (II) input device 'SynPS/2 Synaptics TouchPad', /dev/input/event1 is tagged by udev as: Touchpad
[ 118.453] (II) input device 'SynPS/2 Synaptics TouchPad', /dev/input/event1 is a touchpad
[ 118.453] (II) config/udev: Adding input device SynPS/2 Synaptics TouchPad (/dev/input/mouse0)
[ 118.453] (II) No input driver specified, ignoring this device.
[ 118.453] (II) This device may have been added with another device file.
[ 118.454] (II) config/udev: Adding input device PC Speaker (/dev/input/event6)
[ 118.454] (II) No input driver specified, ignoring this device.
[ 118.454] (II) This device may have been added with another device file.
[ 120.943] (--) NVIDIA(GPU-0): CRT-0: connected
[ 120.943] (--) NVIDIA(GPU-0): CRT-0: 400.0 MHz maximum pixel clock
[ 120.948] (II) NVIDIA(0): Setting mode "NULL"
[ 121.049] (--) NVIDIA(GPU-0): CRT-0: connected
[ 121.050] (--) NVIDIA(GPU-0): CRT-0: 400.0 MHz maximum pixel clock
[ 121.052] (--) NVIDIA(GPU-0): CRT-0: connected
[ 121.052] (--) NVIDIA(GPU-0): CRT-0: 400.0 MHz maximum pixel clock
[ 128.495] (--) NVIDIA(GPU-0): CRT-0: connected
[ 128.495] (--) NVIDIA(GPU-0): CRT-0: 400.0 MHz maximum pixel clock
[ 128.497] (--) NVIDIA(GPU-0): CRT-0: connected
[ 128.497] (--) NVIDIA(GPU-0): CRT-0: 400.0 MHz maximum pixel clock
dmesg | grep nvidia
[ 0.000000] Command line: BOOT_IMAGE=/boot/vmlinuz-4.9.0-kali4-amd64 root=UUID=85dd9b70-4688-4797-801f-f8d2f7f0ce47 ro initrd=/install/gtk/initrd.gz quiet acpi_backlight=none nvidia-drm.modeset=1
[ 0.000000] Kernel command line: BOOT_IMAGE=/boot/vmlinuz-4.9.0-kali4-amd64 root=UUID=85dd9b70-4688-4797-801f-f8d2f7f0ce47 ro initrd=/install/gtk/initrd.gz quiet acpi_backlight=none nvidia-drm.modeset=1
[ 8.637495] nvidia: loading out-of-tree module taints kernel.
[ 8.637507] nvidia: module license 'NVIDIA' taints kernel.
[ 8.654195] nvidia 0000:01:00.0: enabling device (0000 -> 0003)
[ 8.654472] nvidia-nvlink: Nvlink Core is being initialized, major device number 248
[ 8.899839] nvidia-modeset: Loading NVIDIA Kernel Mode Setting Driver for UNIX platforms 375.66 Mon May 1 14:33:30 PDT 2017
[ 9.075486] [drm] [nvidia-drm] [GPU ID 0x00000100] Loading driver
[ 9.519461] nvidia-modeset: Allocated GPU:0 (GPU-f0aed6ff-9414-86e1-41a1-c0790de4fb21) @ PCI:0000:01:00.0
[ 9.545001] nvidia-modeset: WARNING: GPU:0: Unable to read EDID for display device VGA-0
[ 32.744484] nvidia-modeset: WARNING: GPU:0: Unable to read EDID for display device VGA-0
[ 35.225983] nvidia-modeset: WARNING: GPU:0: Unable to read EDID for display device VGA-0
[ 35.332001] nvidia-modeset: WARNING: GPU:0: Unable to read EDID for display device VGA-0
[ 35.334290] nvidia-modeset: WARNING: GPU:0: Unable to read EDID for display device VGA-0
[ 42.420677] nvidia-modeset: WARNING: GPU:0: Unable to read EDID for display device VGA-0
[ 42.437071] nvidia-modeset: WARNING: GPU:0: Unable to read EDID for display device VGA-0
[ 117.894185] nvidia-modeset: WARNING: GPU:0: Unable to read EDID for display device VGA-0
[ 120.948048] nvidia-modeset: WARNING: GPU:0: Unable to read EDID for display device VGA-0
[ 121.054775] nvidia-modeset: WARNING: GPU:0: Unable to read EDID for display device VGA-0
[ 121.056981] nvidia-modeset: WARNING: GPU:0: Unable to read EDID for display device VGA-0
[ 128.500194] nvidia-modeset: WARNING: GPU:0: Unable to read EDID for display device VGA-0
[ 128.502175] nvidia-modeset: WARNING: GPU:0: Unable to read EDID for display device VGA-0
