So I still want to get the NVIDIA GPU running, that’s why I have this notebook :)
Seems OpenGL renderer is set to intel, although I want Nvidia.
[ 687.609] (–) Log file renamed from “/var/log/Xorg.pid-6185.log” to “/var/log/Xorg.0.log”
[ 687.609]
X.Org X Server 1.20.8
X Protocol Version 11, Revision 0
[ 687.609] Build Operating System: Linux 4.15.0-115-generic x86_64 Ubuntu
[ 687.609] Current Operating System: Linux starseed 5.6.0-1034-oem #36-Ubuntu SMP Fri Nov 6 18:22:26 UTC 2020 x86_64
[ 687.609] Kernel command line: BOOT_IMAGE=/vmlinuz-5.6.0-1034-oem root=/dev/mapper/vgubuntu-root ro text kopt=root=/dev/mapper/vgubuntu-root acpi_osi=Linux acpi_backlight=vendor acpi=force acpi_enforce_resources=lax acpi_os_name=Linux
[ 687.609] Build Date: 04 September 2020 01:34:27PM
[ 687.609] xorg-server 2:1.20.8-2ubuntu2.4 (For technical support please see http://www.ubuntu.com/support)
[ 687.609] Current version of pixman: 0.38.4
[ 687.609] Before reporting problems, check http://wiki.x.org
to make sure that you have the latest version.
[ 687.609] Markers: (–) probed, () from config file, (==) default setting,
(++) from command line, (!!) notice, (II) informational,
(WW) warning, (EE) error, (NI) not implemented, (??) unknown.
[ 687.609] (==) Log file: “/var/log/Xorg.0.log”, Time: Sun Nov 29 17:44:07 2020
[ 687.609] (==) Using config file: “/etc/X11/xorg.conf”
[ 687.609] (==) Using system config directory “/usr/share/X11/xorg.conf.d”
[ 687.610] (==) ServerLayout “layout”
[ 687.610] () |–>Screen “nvidia” (0)
[ 687.610] () | |–>Monitor “”
[ 687.610] (==) No device specified for screen “nvidia”.
Using the first device section listed.
[ 687.610] () | |–>Device “intel”
[ 687.610] (==) No monitor specified for screen “nvidia”.
Using a default monitor configuration.
[ 687.610] (**) |–>Inactive Device “intel”
[ 687.610] (==) Automatically adding devices
[ 687.610] (==) Automatically enabling devices
[ 687.610] (==) Automatically adding GPU devices
[ 687.610] (==) Automatically binding GPU devices
[ 687.610] (==) Max clients allowed: 256, resource mask: 0x1fffff
[ 687.610] (WW) The directory “/usr/share/fonts/X11/cyrillic” does not exist.
[ 687.610] Entry deleted from font path.
[ 687.610] (WW) The directory “/usr/share/fonts/X11/75dpi/” does not exist.
[ 687.610] (WW) The directory “/usr/share/fonts/X11/75dpi” does not exist.
[ 687.610] (==) FontPath set to:
/usr/share/fonts/X11/misc,
/usr/share/fonts/X11/100dpi/:unscaled,
/usr/share/fonts/X11/Type1,
/usr/share/fonts/X11/100dpi,
built-ins
[ 687.610] (==) ModulePath set to “/usr/lib/xorg/modules”
[ 687.610] (II) The server relies on udev to provide the list of input devices.
If no devices become available, reconfigure udev or disable AutoAddDevices.
[ 687.610] (II) Loader magic: 0x55e7670e5020
[ 687.610] (II) Module ABI versions:
[ 687.610] X.Org ANSI C Emulation: 0.4
[ 687.610] X.Org Video Driver: 24.1
[ 687.610] X.Org XInput driver : 24.1
[ 687.610] X.Org Server Extension : 10.0
[ 687.611] (++) using VT number 1
[ 687.613] (II) systemd-logind: took control of session /org/freedesktop/login1/session/c2
[ 687.614] (II) xfree86: Adding drm device (/dev/dri/card1)
[ 687.614] (II) systemd-logind: got fd for /dev/dri/card1 226:1 fd 12 paused 0
[ 687.614] (II) xfree86: Adding drm device (/dev/dri/card0)
[ 687.615] (II) systemd-logind: got fd for /dev/dri/card0 226:0 fd 13 paused 0
[ 687.617] () OutputClass “nvidia” ModulePath extended to “/usr/lib/x86_64-linux-gnu/nvidia/xorg,/usr/lib/xorg/modules”
[ 687.617] () OutputClass “Nvidia Prime” ModulePath extended to “/lib/x86_64-linux-gnu/nvidia/xorg,/usr/lib/x86_64-linux-gnu/nvidia/xorg,/usr/lib/xorg/modules”
[ 687.617] () OutputClass “Nvidia Prime” setting /dev/dri/card1 as PrimaryGPU
[ 687.622] (–) PCI: (0@0:2:0) 8086:0416:1558:6505 rev 6, Mem @ 0xf7400000/4194304, 0xd0000000/268435456, I/O @ 0x0000f000/64, BIOS @ 0x???/131072
[ 687.622] (–) PCI:*(1@0:0:0) 10de:139a:1558:6505 rev 162, Mem @ 0xf6000000/16777216, 0xe0000000/268435456, 0xf0000000/33554432, I/O @ 0x0000e000/128, BIOS @ 0x???/524288
[ 687.623] (II) “glx” will be loaded. This was enabled by default and also specified in the config file.
[ 687.623] (II) LoadModule: “modesetting”
[ 687.623] (II) Loading /usr/lib/xorg/modules/drivers/modesetting_drv.so
[ 687.623] (II) Module modesetting: vendor=“X.Org Foundation”
[ 687.623] compiled for 1.20.8, module version = 1.20.8
[ 687.623] Module class: X.Org Video Driver
[ 687.623] ABI class: X.Org Video Driver, version 24.1
[ 687.623] (II) LoadModule: “glxservernvidia”
[ 687.623] (WW) Warning, couldn’t open module glxservernvidia
[ 687.623] (EE) Failed to load module “glxservernvidia” (module does not exist, 0)
[ 687.623] (II) LoadModule: “glx”
[ 687.623] (II) Loading /usr/lib/xorg/modules/extensions/libglx.so
[ 687.624] (II) Module glx: vendor=“X.Org Foundation”
[ 687.624] compiled for 1.20.8, module version = 1.0.0
[ 687.624] ABI class: X.Org Server Extension, version 10.0
[ 687.624] (II) LoadModule: “modesetting”
[ 687.624] (II) Loading /usr/lib/xorg/modules/drivers/modesetting_drv.so
[ 687.624] (II) Module modesetting: vendor=“X.Org Foundation”
[ 687.624] compiled for 1.20.8, module version = 1.20.8
[ 687.624] Module class: X.Org Video Driver
[ 687.624] ABI class: X.Org Video Driver, version 24.1
[ 687.624] (II) UnloadModule: “modesetting”
[ 687.624] (II) Unloading modesetting
[ 687.624] (II) Failed to load module “modesetting” (already loaded, 0)
[ 687.624] (II) Applying OutputClass “nvidia” to /dev/dri/card1
[ 687.624] loading driver: nvidia
[ 687.624] (II) Applying OutputClass “Nvidia Prime” to /dev/dri/card1
[ 687.625] loading driver: nvidia
[ 687.735] (II) Applying OutputClass “intel” to /dev/dri/card0
[ 687.735] loading driver: modesetting
[ 687.843] (==) Matched nvidia as autoconfigured driver 0
[ 687.843] (==) Matched nouveau as autoconfigured driver 1
[ 687.843] (==) Matched modesetting as autoconfigured driver 2
[ 687.843] (==) Matched fbdev as autoconfigured driver 3
[ 687.843] (==) Matched vesa as autoconfigured driver 4
[ 687.843] (==) Assigned the driver to the xf86ConfigLayout
[ 687.843] (II) LoadModule: “nvidia”
[ 687.844] (II) Loading /usr/lib/x86_64-linux-gnu/nvidia/xorg/nvidia_drv.so
[ 687.844] (II) Module nvidia: vendor=“NVIDIA Corporation”
[ 687.844] compiled for 1.6.99.901, module version = 1.0.0
[ 687.844] Module class: X.Org Video Driver
[ 687.844] (II) LoadModule: “nouveau”
[ 687.844] (II) Loading /usr/lib/xorg/modules/drivers/nouveau_drv.so
[ 687.844] (II) Module nouveau: vendor=“X.Org Foundation”
[ 687.844] compiled for 1.20.3, module version = 1.0.16
[ 687.844] ABI class: X.Org Video Driver, version 24.0
[ 687.844] (II) LoadModule: “modesetting”
[ 687.845] (II) Loading /usr/lib/xorg/modules/drivers/modesetting_drv.so
[ 687.845] (II) Module modesetting: vendor=“X.Org Foundation”
[ 687.845] compiled for 1.20.8, module version = 1.20.8
[ 687.845] Module class: X.Org Video Driver
[ 687.845] ABI class: X.Org Video Driver, version 24.1
[ 687.845] (II) UnloadModule: “modesetting”
[ 687.845] (II) Unloading modesetting
[ 687.845] (II) Failed to load module “modesetting” (already loaded, 0)
[ 687.845] (II) LoadModule: “fbdev”
[ 687.845] (II) Loading /usr/lib/xorg/modules/drivers/fbdev_drv.so
[ 687.845] (II) Module fbdev: vendor=“X.Org Foundation”
[ 687.845] compiled for 1.20.1, module version = 0.5.0
[ 687.845] ABI class: X.Org Video Driver, version 24.0
[ 687.845] (II) LoadModule: “vesa”
[ 687.845] (II) Loading /usr/lib/xorg/modules/drivers/vesa_drv.so
[ 687.845] (II) Module vesa: vendor=“X.Org Foundation”
[ 687.845] compiled for 1.20.4, module version = 2.4.0
[ 687.845] (II) modesetting: Driver for Modesetting Kernel Drivers: kms
[ 687.845] (II) NVIDIA dlloader X Driver 455.38 Thu Oct 22 06:02:31 UTC 2020
[ 687.845] (II) NVIDIA Unified Driver for all Supported NVIDIA GPUs
[ 687.845] (II) NOUVEAU driver Date: Mon Jan 28 23:25:58 2019 -0500
[ 687.845] (II) NOUVEAU driver for NVIDIA chipset families :
[ 687.845] RIVA TNT (NV04)
[ 687.845] RIVA TNT2 (NV05)
[ 687.845] GeForce 256 (NV10)
[ 687.845] GeForce 2 (NV11, NV15)
[ 687.846] GeForce 4MX (NV17, NV18)
[ 687.846] GeForce 3 (NV20)
[ 687.846] GeForce 4Ti (NV25, NV28)
[ 687.846] GeForce FX (NV3x)
[ 687.846] GeForce 6 (NV4x)
[ 687.846] GeForce 7 (G7x)
[ 687.846] GeForce 8 (G8x)
[ 687.846] GeForce 9 (G9x)
[ 687.846] GeForce GTX 2xx/3xx (GT2xx)
[ 687.846] GeForce GTX 4xx/5xx (GFxxx)
[ 687.846] GeForce GTX 6xx/7xx (GKxxx)
[ 687.846] GeForce GTX 9xx (GMxxx)
[ 687.846] GeForce GTX 10xx (GPxxx)
[ 687.846] (II) FBDEV: driver for framebuffer: fbdev
[ 687.846] (II) VESA: driver for VESA chipsets: vesa
[ 687.846] (II) modeset(0): using drv /dev/dri/card0
[ 687.846] (WW) Falling back to old probe method for fbdev
[ 687.846] (II) Loading sub module “fbdevhw”
[ 687.846] (II) LoadModule: “fbdevhw”
[ 687.847] (II) Loading /usr/lib/xorg/modules/libfbdevhw.so
[ 687.847] (II) Module fbdevhw: vendor=“X.Org Foundation”
[ 687.847] compiled for 1.20.8, module version = 0.0.2
[ 687.847] ABI class: X.Org Video Driver, version 24.1
[ 687.847] (II) systemd-logind: releasing fd for 226:1
[ 687.848] (II) Loading sub module “fb”
[ 687.848] (II) LoadModule: “fb”
[ 687.848] (II) Loading /usr/lib/xorg/modules/libfb.so
[ 687.848] (II) Module fb: vendor=“X.Org Foundation”
[ 687.848] compiled for 1.20.8, module version = 1.0.0
[ 687.848] ABI class: X.Org ANSI C Emulation, version 0.4
[ 687.848] (II) Loading sub module “wfb”
[ 687.848] (II) LoadModule: “wfb”
[ 687.848] (II) Loading /usr/lib/xorg/modules/libwfb.so
[ 687.848] (II) Module wfb: vendor=“X.Org Foundation”
[ 687.848] (II) Loading sub module “ramdac”
[ 687.848] (II) LoadModule: “ramdac”
[ 687.848] (II) Module “ramdac” already built-in
[ 687.849] (II) modeset(0): Creating default Display subsection in Screen section
“nvidia” for depth/fbbpp 24/32
[ 687.849] (==) modeset(0): Depth 24, (==) framebuffer bpp 32
[ 687.849] (==) modeset(0): RGB weight 888
[ 687.849] (==) modeset(0): Default visual is TrueColor
[ 687.849] (II) Loading sub module “glamoregl”
[ 687.849] (II) LoadModule: “glamoregl”
[ 687.849] (II) Loading /usr/lib/xorg/modules/libglamoregl.so
[ 687.853] (II) Module glamoregl: vendor=“X.Org Foundation”
[ 687.853] compiled for 1.20.8, module version = 1.0.1
[ 687.853] ABI class: X.Org ANSI C Emulation, version 0.4
[ 687.879] (II) modeset(0): glamor X acceleration enabled on Mesa DRI Intel® HD Graphics 4600 (HSW GT2)
[ 687.879] (II) modeset(0): glamor initialized
[ 687.879] (II) modeset(0): Output eDP-1 has no monitor section
[ 687.881] (II) modeset(0): Output VGA-1 has no monitor section
[ 687.908] (II) modeset(0): Output HDMI-1 has no monitor section
[ 687.908] (II) modeset(0): EDID for output eDP-1
[ 687.908] (II) modeset(0): Manufacturer: AUO Model: 12ed Serial#: 0
[ 687.908] (II) modeset(0): Year: 2012 Week: 0
[ 687.908] (II) modeset(0): EDID Version: 1.4
[ 687.908] (II) modeset(0): Digital Display Input
[ 687.908] (II) modeset(0): 6 bits per channel
[ 687.908] (II) modeset(0): Digital interface is DisplayPort
[ 687.908] (II) modeset(0): Max Image Size [cm]: horiz.: 34 vert.: 19
[ 687.908] (II) modeset(0): Gamma: 2.20
[ 687.908] (II) modeset(0): No DPMS capabilities specified
[ 687.908] (II) modeset(0): Supported color encodings: RGB 4:4:4
[ 687.908] (II) modeset(0): First detailed timing is preferred mode
[ 687.908] (II) modeset(0): Preferred mode is native pixel format and refresh rate
[ 687.908] (II) modeset(0): redX: 0.590 redY: 0.340 greenX: 0.325 greenY: 0.580
[ 687.908] (II) modeset(0): blueX: 0.150 blueY: 0.110 whiteX: 0.313 whiteY: 0.329
[ 687.908] (II) modeset(0): Manufacturer’s mask: 0
[ 687.908] (II) modeset(0): Supported detailed timing:
[ 687.908] (II) modeset(0): clock: 141.4 MHz Image Size: 344 x 193 mm
[ 687.908] (II) modeset(0): h_active: 1920 h_sync: 1968 h_sync_end 2068 h_blank_end 2112 h_border: 0
[ 687.908] (II) modeset(0): v_active: 1080 v_sync: 1088 v_sync_end 1102 v_blanking: 1112 v_border: 0
[ 687.908] (II) modeset(0): clock: 94.3 MHz Image Size: 344 x 193 mm
[ 687.908] (II) modeset(0): AUO
[ 687.908] (II) modeset(0): B156HAN01.2
[ 687.908] (II) modeset(0): EDID (in hex):
[ 687.909] (II) modeset(0): 00ffffffffffff0006afed1200000000
[ 687.909] (II) modeset(0): 00160104952213780206959757539426
[ 687.909] (II) modeset(0): 1c505400000001010101010101010101
[ 687.909] (II) modeset(0): 0101010101013c3780c0703820403064
[ 687.909] (II) modeset(0): 8e0058c110000018d32480c070382040
[ 687.909] (II) modeset(0): 30648e0058c110000018000000fe0041
[ 687.909] (II) modeset(0): 554f0a202020202020202020000000fe
[ 687.909] (II) modeset(0): 004231353648414e30312e32200a0022
[ 687.909] (II) modeset(0): Printing probed modes for output eDP-1
[ 687.909] (II) modeset(0): Modeline "1920x1080"x60.2 141.40 1920 1968 2068 2112 1080 1088 1102 1112 -hsync -vsync (67.0 kHz eP)
[ 687.909] (II) modeset(0): Modeline "1920x1080"x120.0 356.38 1920 2080 2288 2656 1080 1081 1084 1118 doublescan -hsync +vsync (134.2 kHz d)
[ 687.909] (II) modeset(0): Modeline "1920x1080"x119.9 266.50 1920 1944 1960 2000 1080 1081 1084 1111 doublescan +hsync -vsync (133.2 kHz d)
[ 687.909] (II) modeset(0): Modeline "1920x1080"x60.0 173.00 1920 2048 2248 2576 1080 1083 1088 1120 -hsync +vsync (67.2 kHz d)
[ 687.909] (II) modeset(0): Modeline "1920x1080"x59.9 138.50 1920 1968 2000 2080 1080 1083 1088 1111 +hsync -vsync (66.6 kHz d)
[ 687.909] (II) modeset(0): Modeline "1920x1080"x40.1 94.27 1920 1968 2068 2112 1080 1088 1102 1112 -hsync -vsync (44.6 kHz e)
[ 687.909] (II) modeset(0): Modeline "1680x1050"x60.0 146.25 1680 1784 1960 2240 1050 1053 1059 1089 -hsync +vsync (65.3 kHz d)
[ 687.909] (II) modeset(0): Modeline "1680x1050"x59.9 119.00 1680 1728 1760 1840 1050 1053 1059 1080 +hsync -vsync (64.7 kHz d)
[ 687.909] (II) modeset(0): Modeline "1600x1024"x60.2 103.12 1600 1600 1656 1664 1024 1024 1029 1030 +hsync +vsync (62.0 kHz d)
[ 687.909] (II) modeset(0): Modeline "1400x1050"x60.0 122.00 1400 1488 1640 1880 1050 1052 1064 1082 +hsync +vsync (64.9 kHz d)
[ 687.909] (II) modeset(0): Modeline "1600x900"x120.0 246.00 1600 1728 1900 2200 900 901 904 932 doublescan -hsync +vsync (111.8 kHz d)
[ 687.909] (II) modeset(0): Modeline "1600x900"x119.9 186.50 1600 1624 1640 1680 900 901 904 926 doublescan +hsync -vsync (111.0 kHz d)
[ 687.909] (II) modeset(0): Modeline "1600x900"x59.9 118.25 1600 1696 1856 2112 900 903 908 934 -hsync +vsync (56.0 kHz d)
[ 687.909] (II) modeset(0): Modeline "1600x900"x59.8 97.50 1600 1648 1680 1760 900 903 908 926 +hsync -vsync (55.4 kHz d)
[ 687.909] (II) modeset(0): Modeline "1280x1024"x60.0 108.00 1280 1328 1440 1688 1024 1025 1028 1066 +hsync +vsync (64.0 kHz d)
[ 687.909] (II) modeset(0): Modeline "1440x900"x59.9 106.50 1440 1520 1672 1904 900 903 909 934 -hsync +vsync (55.9 kHz d)
[ 687.909] (II) modeset(0): Modeline "1400x900"x60.0 103.50 1400 1480 1624 1848 900 903 913 934 -hsync +vsync (56.0 kHz d)
[ 687.909] (II) modeset(0): Modeline "1400x900"x59.9 86.50 1400 1448 1480 1560 900 903 913 926 +hsync -vsync (55.4 kHz d)
[ 687.909] (II) modeset(0): Modeline "1280x960"x60.0 108.00 1280 1376 1488 1800 960 961 964 1000 +hsync +vsync (60.0 kHz d)
[ 687.909] (II) modeset(0): Modeline "1440x810"x120.0 198.12 1440 1548 1704 1968 810 811 814 839 doublescan -hsync +vsync (100.7 kHz d)
[ 687.909] (II) modeset(0): Modeline "1440x810"x119.9 151.88 1440 1464 1480 1520 810 811 814 833 doublescan +hsync -vsync (99.9 kHz d)
[ 687.909] (II) modeset(0): Modeline "1368x768"x59.9 85.25 1368 1440 1576 1784 768 771 781 798 -hsync +vsync (47.8 kHz d)
[ 687.909] (II) modeset(0): Modeline "1368x768"x59.9 72.25 1368 1416 1448 1528 768 771 781 790 +hsync -vsync (47.3 kHz d)
[ 687.909] (II) modeset(0): Modeline "1360x768"x59.8 84.75 1360 1432 1568 1776 768 771 781 798 -hsync +vsync (47.7 kHz d)
[ 687.909] (II) modeset(0): Modeline "1360x768"x60.0 72.00 1360 1408 1440 1520 768 771 781 790 +hsync -vsync (47.4 kHz d)
[ 687.909] (II) modeset(0): Modeline "1280x800"x120.0 174.25 1280 1380 1516 1752 800 801 804 829 doublescan -hsync +vsync (99.5 kHz d)
[ 687.909] (II) modeset(0): Modeline "1280x800"x119.9 134.25 1280 1304 1320 1360 800 801 804 823 doublescan +hsync -vsync (98.7 kHz d)
[ 687.909] (II) modeset(0): Modeline "1280x800"x59.8 83.50 1280 1352 1480 1680 800 803 809 831 -hsync +vsync (49.7 kHz d)
[ 687.909] (II) modeset(0): Modeline "1280x800"x59.9 71.00 1280 1328 1360 1440 800 803 809 823 +hsync -vsync (49.3 kHz d)
[ 687.909] (II) modeset(0): Modeline "1152x864"x60.0 81.62 1152 1216 1336 1520 864 865 868 895 -hsync +vsync (53.7 kHz d)
[ 687.909] (II) modeset(0): Modeline "1280x720"x120.0 156.12 1280 1376 1512 1744 720 721 724 746 doublescan -hsync +vsync (89.5 kHz d)
[ 687.909] (II) modeset(0): Modeline "1280x720"x120.0 120.75 1280 1304 1320 1360 720 721 724 740 doublescan +hsync -vsync (88.8 kHz d)
[ 687.909] (II) modeset(0): Modeline "1280x720"x59.9 74.50 1280 1344 1472 1664 720 723 728 748 -hsync +vsync (44.8 kHz d)
[ 687.909] (II) modeset(0): Modeline "1280x720"x59.7 63.75 1280 1328 1360 1440 720 723 728 741 +hsync -vsync (44.3 kHz d)
[ 687.909] (II) modeset(0): Modeline "1024x768"x120.1 133.47 1024 1100 1212 1400 768 768 770 794 doublescan -hsync +vsync (95.3 kHz d)
[ 687.909] (II) modeset(0): Modeline "1024x768"x60.0 65.00 1024 1048 1184 1344 768 771 777 806 -hsync -vsync (48.4 kHz d)
[ 687.909] (II) modeset(0): Modeline "960x720"x120.0 117.00 960 1024 1128 1300 720 720 722 750 doublescan -hsync +vsync (90.0 kHz d)
[ 687.909] (II) modeset(0): Modeline "928x696"x120.1 109.15 928 976 1088 1264 696 696 698 719 doublescan -hsync +vsync (86.4 kHz d)
[ 687.909] (II) modeset(0): Modeline "896x672"x120.0 102.40 896 960 1060 1224 672 672 674 697 doublescan -hsync +vsync (83.7 kHz d)
[ 687.909] (II) modeset(0): Modeline "1024x576"x119.9 98.50 1024 1092 1200 1376 576 577 580 597 doublescan -hsync +vsync (71.6 kHz d)
[ 687.909] (II) modeset(0): Modeline "1024x576"x119.9 78.38 1024 1048 1064 1104 576 577 580 592 doublescan +hsync -vsync (71.0 kHz d)
[ 687.909] (II) modeset(0): Modeline "1024x576"x59.9 46.50 1024 1064 1160 1296 576 579 584 599 -hsync +vsync (35.9 kHz d)
[ 687.909] (II) modeset(0): Modeline "1024x576"x59.8 42.00 1024 1072 1104 1184 576 579 584 593 +hsync -vsync (35.5 kHz d)
[ 687.909] (II) modeset(0): Modeline "960x600"x119.9 96.62 960 1028 1128 1296 600 601 604 622 doublescan -hsync +vsync (74.6 kHz d)
[ 687.909] (II) modeset(0): Modeline "960x600"x120.0 77.00 960 984 1000 1040 600 601 604 617 doublescan +hsync -vsync (74.0 kHz d)
[ 687.909] (II) modeset(0): Modeline "960x540"x119.9 86.50 960 1024 1124 1288 540 541 544 560 doublescan -hsync +vsync (67.2 kHz d)
[ 687.909] (II) modeset(0): Modeline "960x540"x120.0 69.25 960 984 1000 1040 540 541 544 555 doublescan +hsync -vsync (66.6 kHz d)
[ 687.909] (II) modeset(0): Modeline "960x540"x59.6 40.75 960 992 1088 1216 540 543 548 562 -hsync +vsync (33.5 kHz d)
[ 687.909] (II) modeset(0): Modeline "960x540"x59.8 37.25 960 1008 1040 1120 540 543 548 556 +hsync -vsync (33.3 kHz d)
[ 687.909] (II) modeset(0): Modeline "800x600"x120.0 81.00 800 832 928 1080 600 600 602 625 doublescan +hsync +vsync (75.0 kHz d)
[ 687.909] (II) modeset(0): Modeline "800x600"x60.3 40.00 800 840 968 1056 600 601 605 628 +hsync +vsync (37.9 kHz d)
[ 687.909] (II) modeset(0): Modeline "800x600"x56.2 36.00 800 824 896 1024 600 601 603 625 +hsync +vsync (35.2 kHz d)
[ 687.909] (II) modeset(0): Modeline "840x525"x120.0 73.12 840 892 980 1120 525 526 529 544 doublescan -hsync +vsync (65.3 kHz d)
[ 687.909] (II) modeset(0): Modeline "840x525"x119.8 59.50 840 864 880 920 525 526 529 540 doublescan +hsync -vsync (64.7 kHz d)
[ 687.909] (II) modeset(0): Modeline "864x486"x59.9 32.50 864 888 968 1072 486 489 494 506 -hsync +vsync (30.3 kHz d)
[ 687.909] (II) modeset(0): Modeline "864x486"x59.6 30.50 864 912 944 1024 486 489 494 500 +hsync -vsync (29.8 kHz d)
[ 687.909] (II) modeset(0): Modeline "800x512"x120.3 51.56 800 800 828 832 512 512 514 515 doublescan +hsync +vsync (62.0 kHz d)
[ 687.909] (II) modeset(0): Modeline "700x525"x120.0 61.00 700 744 820 940 525 526 532 541 doublescan +hsync +vsync (64.9 kHz d)
[ 687.909] (II) modeset(0): Modeline "800x450"x119.9 59.12 800 848 928 1056 450 451 454 467 doublescan -hsync +vsync (56.0 kHz d)
[ 687.909] (II) modeset(0): Modeline "800x450"x119.6 48.75 800 824 840 880 450 451 454 463 doublescan +hsync -vsync (55.4 kHz d)
[ 687.909] (II) modeset(0): Modeline "640x512"x120.0 54.00 640 664 720 844 512 512 514 533 doublescan +hsync +vsync (64.0 kHz d)
[ 687.909] (II) modeset(0): Modeline "720x450"x119.8 53.25 720 760 836 952 450 451 454 467 doublescan -hsync +vsync (55.9 kHz d)
[ 687.909] (II) modeset(0): Modeline "700x450"x119.9 51.75 700 740 812 924 450 451 456 467 doublescan -hsync +vsync (56.0 kHz d)
[ 687.909] (II) modeset(0): Modeline "700x450"x119.8 43.25 700 724 740 780 450 451 456 463 doublescan +hsync -vsync (55.4 kHz d)
[ 687.909] (II) modeset(0): Modeline "640x480"x120.0 54.00 640 688 744 900 480 480 482 500 doublescan +hsync +vsync (60.0 kHz d)
[ 687.909] (II) modeset(0): Modeline "640x480"x59.9 25.18 640 656 752 800 480 490 492 525 -hsync -vsync (31.5 kHz d)
[ 687.909] (II) modeset(0): Modeline "720x405"x59.5 22.50 720 744 808 896 405 408 413 422 -hsync +vsync (25.1 kHz d)
[ 687.909] (II) modeset(0): Modeline "720x405"x59.0 21.75 720 768 800 880 405 408 413 419 +hsync -vsync (24.7 kHz d)
[ 687.909] (II) modeset(0): Modeline "684x384"x119.8 42.62 684 720 788 892 384 385 390 399 doublescan -hsync +vsync (47.8 kHz d)
[ 687.909] (II) modeset(0): Modeline "684x384"x119.7 36.12 684 708 724 764 384 385 390 395 doublescan +hsync -vsync (47.3 kHz d)
[ 687.909] (II) modeset(0): Modeline "680x384"x119.6 42.38 680 716 784 888 384 385 390 399 doublescan -hsync +vsync (47.7 kHz d)
[ 687.909] (II) modeset(0): Modeline "680x384"x119.9 36.00 680 704 720 760 384 385 390 395 doublescan +hsync -vsync (47.4 kHz d)
[ 687.909] (II) modeset(0): Modeline "640x400"x119.8 41.75 640 676 740 840 400 401 404 415 doublescan -hsync +vsync (49.7 kHz d)
[ 687.909] (II) modeset(0): Modeline "640x400"x120.0 35.50 640 664 680 720 400 401 404 411 doublescan +hsync -vsync (49.3 kHz d)
[ 687.909] (II) modeset(0): Modeline "576x432"x120.1 40.81 576 608 668 760 432 432 434 447 doublescan -hsync +vsync (53.7 kHz d)
[ 687.909] (II) modeset(0): Modeline "640x360"x119.7 37.25 640 672 736 832 360 361 364 374 doublescan -hsync +vsync (44.8 kHz d)
[ 687.909] (II) modeset(0): Modeline "640x360"x119.7 31.88 640 664 680 720 360 361 364 370 doublescan +hsync -vsync (44.3 kHz d)
[ 687.909] (II) modeset(0): Modeline "640x360"x59.8 18.00 640 664 720 800 360 363 368 376 -hsync +vsync (22.5 kHz d)
[ 687.909] (II) modeset(0): Modeline "640x360"x59.3 17.75 640 688 720 800 360 363 368 374 +hsync -vsync (22.2 kHz d)
[ 687.909] (II) modeset(0): Modeline "512x384"x120.0 32.50 512 524 592 672 384 385 388 403 doublescan -hsync -vsync (48.4 kHz d)
[ 687.909] (II) modeset(0): Modeline "512x288"x120.0 23.25 512 532 580 648 288 289 292 299 doublescan -hsync +vsync (35.9 kHz d)
[ 687.909] (II) modeset(0): Modeline "512x288"x119.8 21.00 512 536 552 592 288 289 292 296 doublescan +hsync -vsync (35.5 kHz d)
[ 687.909] (II) modeset(0): Modeline "480x270"x119.3 20.38 480 496 544 608 270 271 274 281 doublescan -hsync +vsync (33.5 kHz d)
[ 687.909] (II) modeset(0): Modeline "480x270"x119.6 18.62 480 504 520 560 270 271 274 278 doublescan +hsync -vsync (33.3 kHz d)
[ 687.909] (II) modeset(0): Modeline "400x300"x120.6 20.00 400 420 484 528 300 300 302 314 doublescan +hsync +vsync (37.9 kHz d)
[ 687.909] (II) modeset(0): Modeline "400x300"x112.7 18.00 400 412 448 512 300 300 301 312 doublescan +hsync +vsync (35.2 kHz d)
[ 687.909] (II) modeset(0): Modeline "432x243"x119.8 16.25 432 444 484 536 243 244 247 253 doublescan -hsync +vsync (30.3 kHz d)
[ 687.909] (II) modeset(0): Modeline "432x243"x119.1 15.25 432 456 472 512 243 244 247 250 doublescan +hsync -vsync (29.8 kHz d)
[ 687.909] (II) modeset(0): Modeline "320x240"x120.1 12.59 320 328 376 400 240 245 246 262 doublescan -hsync -vsync (31.5 kHz d)
[ 687.909] (II) modeset(0): Modeline "360x202"x119.0 11.25 360 372 404 448 202 204 206 211 doublescan -hsync +vsync (25.1 kHz d)
[ 687.909] (II) modeset(0): Modeline "360x202"x118.3 10.88 360 384 400 440 202 204 206 209 doublescan +hsync -vsync (24.7 kHz d)
[ 687.909] (II) modeset(0): Modeline "320x180"x119.7 9.00 320 332 360 400 180 181 184 188 doublescan -hsync +vsync (22.5 kHz d)
[ 687.909] (II) modeset(0): Modeline "320x180"x118.6 8.88 320 344 360 400 180 181 184 187 doublescan +hsync -vsync (22.2 kHz d)
[ 687.911] (II) modeset(0): EDID for output VGA-1
[ 687.939] (II) modeset(0): EDID for output HDMI-1
[ 687.939] (II) modeset(0): Manufacturer: FUS Model: 73e Serial#: 10
[ 687.939] (II) modeset(0): Year: 2007 Week: 37
[ 687.939] (II) modeset(0): EDID Version: 1.3
[ 687.939] (II) modeset(0): Digital Display Input
[ 687.939] (II) modeset(0): Max Image Size [cm]: horiz.: 52 vert.: 32
[ 687.939] (II) modeset(0): Gamma: 2.20
[ 687.939] (II) modeset(0): DPMS capabilities: Off
[ 687.940] (II) modeset(0): Supported color encodings: RGB 4:4:4 YCrCb 4:4:4
[ 687.940] (II) modeset(0): First detailed timing is preferred mode
[ 687.940] (II) modeset(0): redX: 0.640 redY: 0.330 greenX: 0.300 greenY: 0.600
[ 687.940] (II) modeset(0): blueX: 0.150 blueY: 0.060 whiteX: 0.313 whiteY: 0.329
[ 687.940] (II) modeset(0): Supported established timings:
[ 687.940] (II) modeset(0): 720x400@70Hz
[ 687.940] (II) modeset(0): 640x480@60Hz
[ 687.940] (II) modeset(0): 640x480@75Hz
[ 687.940] (II) modeset(0): 800x600@60Hz
[ 687.940] (II) modeset(0): 800x600@75Hz
[ 687.940] (II) modeset(0): 1024x768@60Hz
[ 687.940] (II) modeset(0): 1024x768@75Hz
[ 687.940] (II) modeset(0): 1280x1024@75Hz
[ 687.940] (II) modeset(0): Manufacturer’s mask: 0
[ 687.940] (II) modeset(0): Supported standard timings:
[ 687.940] (II) modeset(0): #0: hsize: 1680 vsize 1050 refresh: 60 vid: 179
[ 687.940] (II) modeset(0): #1: hsize: 1440 vsize 900 refresh: 60 vid: 149
[ 687.940] (II) modeset(0): #2: hsize: 1440 vsize 900 refresh: 75 vid: 3989
[ 687.940] (II) modeset(0): #3: hsize: 1280 vsize 800 refresh: 60 vid: 129
[ 687.940] (II) modeset(0): #4: hsize: 1280 vsize 800 refresh: 75 vid: 3969
[ 687.940] (II) modeset(0): #5: hsize: 1280 vsize 720 refresh: 60 vid: 49281
[ 687.940] (II) modeset(0): #6: hsize: 1280 vsize 1024 refresh: 60 vid: 32897
[ 687.940] (II) modeset(0): #7: hsize: 1600 vsize 1200 refresh: 60 vid: 16553
[ 687.940] (II) modeset(0): Supported detailed timing:
[ 687.940] (II) modeset(0): clock: 154.0 MHz Image Size: 518 x 324 mm
[ 687.940] (II) modeset(0): h_active: 1920 h_sync: 1968 h_sync_end 2000 h_blank_end 2080 h_border: 0
[ 687.940] (II) modeset(0): v_active: 1200 v_sync: 1203 v_sync_end 1209 v_blanking: 1235 v_border: 0
[ 687.940] (II) modeset(0): clock: 148.5 MHz Image Size: 518 x 324 mm
[ 687.940] (II) modeset(0): h_active: 1920 h_sync: 2448 h_sync_end 2492 h_blank_end 2640 h_border: 0
[ 687.940] (II) modeset(0): v_active: 1080 v_sync: 1089 v_sync_end 1095 v_blanking: 1125 v_border: 0
[ 687.940] (II) modeset(0): Monitor name: P24W-3
[ 687.940] (II) modeset(0): Serial No: YE2L000221
[ 687.940] (II) modeset(0): clock: 74.2 MHz Image Size: 518 x 324 mm
[ 687.940] (II) modeset(0): h_active: 1920 h_sync: 2008 h_sync_end 2052 h_blank_end 2200 h_border: 0
[ 687.940] (II) modeset(0): v_active: 540 v_sync: 542 v_sync_end 547 v_blanking: 562 v_border: 0
[ 687.940] (II) modeset(0): h_active: 1280 h_sync: 1720 h_sync_end 1760 h_blank_end 1980 h_border: 0
[ 687.940] (II) modeset(0): v_active: 720 v_sync: 725 v_sync_end 730 v_blanking: 750 v_border: 0
[ 687.940] (II) modeset(0): clock: 27.0 MHz Image Size: 518 x 324 mm
[ 687.940] (II) modeset(0): h_active: 720 h_sync: 732 h_sync_end 796 h_blank_end 864 h_border: 0
[ 687.940] (II) modeset(0): v_active: 576 v_sync: 581 v_sync_end 586 v_blanking: 625 v_border: 0
[ 687.940] (II) modeset(0): h_active: 720 h_sync: 736 h_sync_end 798 h_blank_end 858 h_border: 0
[ 687.940] (II) modeset(0): v_active: 480 v_sync: 489 v_sync_end 495 v_blanking: 525 v_border: 0
[ 687.940] (II) modeset(0): Number of EDID sections to follow: 1
[ 687.940] (II) modeset(0): EDID (in hex):
[ 687.940] (II) modeset(0): 00ffffffffffff001ab33e070a000000
[ 687.940] (II) modeset(0): 25110103803420782aee95a3544c9926
[ 687.940] (II) modeset(0): 0f5054a54b00b3009500950f8100810f
[ 687.940] (II) modeset(0): 81c08180a940283c80a070b023403020
[ 687.940] (II) modeset(0): 360006442100001a023a80d072382d40
[ 687.940] (II) modeset(0): 102c9680064421000018000000fc0050
[ 687.940] (II) modeset(0): 3234572d330a202020202020000000ff
[ 687.940] (II) modeset(0): 005945324c3030303232310a202001a2
[ 687.940] (II) modeset(0): 02030e0449909f85940413031201023a
[ 687.940] (II) modeset(0): 80d072382d40102c9680064421000018
[ 687.940] (II) modeset(0): 011d8018711c1620582c250006442100
[ 687.940] (II) modeset(0): 009e011d80d0721c1620102c25800644
[ 687.940] (II) modeset(0): 2100009e011d00bc52d01e20b8285540
[ 687.940] (II) modeset(0): 06442100001e8c0ad090204031200c40
[ 687.940] (II) modeset(0): 55000644210000188c0ad08a20e02d10
[ 687.940] (II) modeset(0): 103e96000644210000180000000000d5
[ 687.940] (II) modeset(0): Printing probed modes for output HDMI-1
[ 687.940] (II) modeset(0): Modeline "1920x1200"x60.0 154.00 1920 1968 2000 2080 1200 1203 1209 1235 +hsync -vsync (74.0 kHz eP)
[ 687.940] (II) modeset(0): Modeline "1920x1080"x60.0 148.50 1920 2008 2052 2200 1080 1084 1089 1125 +hsync +vsync (67.5 kHz e)
[ 687.941] (II) modeset(0): Modeline "1920x1080"x50.0 148.50 1920 2448 2492 2640 1080 1089 1095 1125 -hsync -vsync (56.2 kHz e)
[ 687.941] (II) modeset(0): Modeline "1920x1080"x50.0 148.50 1920 2448 2492 2640 1080 1084 1089 1125 +hsync +vsync (56.2 kHz e)
[ 687.941] (II) modeset(0): Modeline "1920x1080"x59.9 148.35 1920 2008 2052 2200 1080 1084 1089 1125 +hsync +vsync (67.4 kHz e)
[ 687.941] (II) modeset(0): Modeline "1920x1080i"x30.0 74.25 1920 2008 2052 2200 1080 1084 1094 1125 interlace +hsync +vsync (33.8 kHz e)
[ 687.941] (II) modeset(0): Modeline "1920x1080i"x25.0 74.25 1920 2448 2492 2640 1080 1084 1094 1125 interlace +hsync +vsync (28.1 kHz e)
[ 687.941] (II) modeset(0): Modeline "1920x1080i"x30.0 74.18 1920 2008 2052 2200 1080 1084 1094 1125 interlace +hsync +vsync (33.7 kHz e)
[ 687.941] (II) modeset(0): Modeline "1600x1200"x60.0 162.00 1600 1664 1856 2160 1200 1201 1204 1250 +hsync +vsync (75.0 kHz e)
[ 687.941] (II) modeset(0): Modeline "1680x1050"x59.9 119.00 1680 1728 1760 1840 1050 1053 1059 1080 +hsync -vsync (64.7 kHz e)
[ 687.941] (II) modeset(0): Modeline "1280x1024"x75.0 135.00 1280 1296 1440 1688 1024 1025 1028 1066 +hsync +vsync (80.0 kHz e)
[ 687.941] (II) modeset(0): Modeline "1280x1024"x60.0 108.00 1280 1328 1440 1688 1024 1025 1028 1066 +hsync +vsync (64.0 kHz e)
[ 687.941] (II) modeset(0): Modeline "1440x900"x75.0 136.75 1440 1536 1688 1936 900 903 909 942 -hsync +vsync (70.6 kHz e)
[ 687.941] (II) modeset(0): Modeline "1440x900"x59.9 88.75 1440 1488 1520 1600 900 903 909 926 +hsync -vsync (55.5 kHz e)
[ 687.941] (II) modeset(0): Modeline "1280x800"x74.9 106.50 1280 1360 1488 1696 800 803 809 838 -hsync +vsync (62.8 kHz e)
[ 687.941] (II) modeset(0): Modeline "1280x800"x59.9 71.00 1280 1328 1360 1440 800 803 809 823 +hsync -vsync (49.3 kHz e)
[ 687.941] (II) modeset(0): Modeline "1280x720"x60.0 74.25 1280 1390 1430 1650 720 725 730 750 +hsync +vsync (45.0 kHz e)
[ 687.941] (II) modeset(0): Modeline "1280x720"x50.0 74.25 1280 1720 1760 1980 720 725 730 750 +hsync +vsync (37.5 kHz e)
[ 687.941] (II) modeset(0): Modeline "1280x720"x59.9 74.18 1280 1390 1430 1650 720 725 730 750 +hsync +vsync (45.0 kHz e)
[ 687.941] (II) modeset(0): Modeline "1024x768"x75.0 78.75 1024 1040 1136 1312 768 769 772 800 +hsync +vsync (60.0 kHz e)
[ 687.941] (II) modeset(0): Modeline "1024x768"x60.0 65.00 1024 1048 1184 1344 768 771 777 806 -hsync -vsync (48.4 kHz e)
[ 687.941] (II) modeset(0): Modeline "800x600"x75.0 49.50 800 816 896 1056 600 601 604 625 +hsync +vsync (46.9 kHz e)
[ 687.941] (II) modeset(0): Modeline "800x600"x60.3 40.00 800 840 968 1056 600 601 605 628 +hsync +vsync (37.9 kHz e)
[ 687.941] (II) modeset(0): Modeline "720x576"x50.0 27.00 720 732 796 864 576 581 586 625 -hsync -vsync (31.2 kHz e)
[ 687.941] (II) modeset(0): Modeline "720x480"x60.0 27.03 720 736 798 858 480 489 495 525 -hsync -vsync (31.5 kHz e)
[ 687.941] (II) modeset(0): Modeline "720x480"x59.9 27.00 720 736 798 858 480 489 495 525 -hsync -vsync (31.5 kHz e)
[ 687.941] (II) modeset(0): Modeline "640x480"x75.0 31.50 640 656 720 840 480 481 484 500 -hsync -vsync (37.5 kHz e)
[ 687.941] (II) modeset(0): Modeline "640x480"x60.0 25.20 640 656 752 800 480 490 492 525 -hsync -vsync (31.5 kHz e)
[ 687.941] (II) modeset(0): Modeline "640x480"x59.9 25.18 640 656 752 800 480 490 492 525 -hsync -vsync (31.5 kHz e)
[ 687.941] (II) modeset(0): Modeline "720x400"x70.1 28.32 720 738 846 900 400 412 414 449 -hsync +vsync (31.5 kHz e)
[ 687.941] (II) modeset(0): Output eDP-1 connected
[ 687.941] (II) modeset(0): Output VGA-1 disconnected
[ 687.941] (II) modeset(0): Output HDMI-1 connected
[ 687.941] (II) modeset(0): Using spanning desktop for initial modes
[ 687.941] (II) modeset(0): Output eDP-1 using initial mode 1920x1080 +0+0
[ 687.941] (II) modeset(0): Output HDMI-1 using initial mode 1920x1200 +1920+0
[ 687.941] (==) modeset(0): Using gamma correction (1.0, 1.0, 1.0)
[ 687.941] (==) modeset(0): DPI set to (96, 96)
[ 687.941] (II) Loading sub module “fb”
[ 687.941] (II) LoadModule: “fb”
[ 687.941] (II) Loading /usr/lib/xorg/modules/libfb.so
[ 687.941] (II) Module fb: vendor=“X.Org Foundation”
[ 687.941] compiled for 1.20.8, module version = 1.0.0
[ 687.941] ABI class: X.Org ANSI C Emulation, version 0.4
[ 687.941] (==) NVIDIA(G0): Depth 24, (==) framebuffer bpp 32
[ 687.941] (==) NVIDIA(G0): RGB weight 888
[ 687.941] (==) NVIDIA(G0): Default visual is TrueColor
[ 687.941] (==) NVIDIA(G0): Using gamma correction (1.0, 1.0, 1.0)
[ 687.941] (II) Applying OutputClass “nvidia” options to /dev/dri/card1
[ 687.941] (II) Applying OutputClass “Nvidia Prime” options to /dev/dri/card1
[ 687.941] () NVIDIA(G0): Option “AllowEmptyInitialConfiguration”
[ 687.941] () NVIDIA(G0): Enabling 2D acceleration
[ 687.942] (II) Loading sub module “glxserver_nvidia”
[ 687.942] (II) LoadModule: “glxserver_nvidia”
[ 687.942] (II) Loading /usr/lib/x86_64-linux-gnu/nvidia/xorg/libglxserver_nvidia.so
[ 687.951] (II) Module glxserver_nvidia: vendor=“NVIDIA Corporation”
[ 687.951] compiled for 1.6.99.901, module version = 1.0.0
[ 687.951] Module class: X.Org Server Extension
[ 687.951] (II) NVIDIA GLX Module 455.38 Thu Oct 22 06:01:10 UTC 2020
[ 687.951] (II) NVIDIA: The X server supports PRIME Render Offload.
[ 688.184] (II) NVIDIA(G0): NVIDIA GPU GeForce GTX 950M (GM107-A) at PCI:1:0:0 (GPU-0)
[ 688.184] (–) NVIDIA(G0): Memory: 2097152 kBytes
[ 688.185] (–) NVIDIA(G0): VideoBIOS: 82.07.7d.00.01
[ 688.185] (II) NVIDIA(G0): Detected PCI Express Link width: 16X
[ 688.185] (II) NVIDIA(G0): Validated MetaModes:
[ 688.185] (II) NVIDIA(G0): “NULL”
[ 688.185] (II) NVIDIA(G0): Virtual screen size determined to be 640 x 480
[ 688.185] (WW) NVIDIA(G0): Unable to get display device for DPI computation.
[ 688.185] (==) NVIDIA(G0): DPI set to (75, 75); computed from built-in default
[ 688.185] (II) UnloadModule: “nouveau”
[ 688.185] (II) Unloading nouveau
[ 688.185] (II) UnloadModule: “fbdev”
[ 688.185] (II) Unloading fbdev
[ 688.185] (II) UnloadSubModule: “fbdevhw”
[ 688.185] (II) Unloading fbdevhw
[ 688.185] (II) UnloadModule: “vesa”
[ 688.185] (II) Unloading vesa
[ 688.229] (==) modeset(0): Backing store enabled
[ 688.229] (==) modeset(0): Silken mouse enabled
[ 688.406] (II) modeset(0): Initializing kms color map for depth 24, 8 bpc.
[ 688.407] (==) modeset(0): DPMS enabled
[ 688.407] (II) modeset(0): [DRI2] Setup complete
[ 688.407] (II) modeset(0): [DRI2] DRI driver: i965
[ 688.407] (II) modeset(0): [DRI2] VDPAU driver: va_gl
[ 688.407] (II) NVIDIA: Using 6144.00 MB of virtual memory for indirect memory
[ 688.407] (II) NVIDIA: access.
[ 688.435] (II) NVIDIA(G0): Setting mode “NULL”
[ 688.437] (==) NVIDIA(G0): Disabling shared memory pixmaps
[ 688.437] (==) NVIDIA(G0): Backing store enabled
[ 688.437] (==) NVIDIA(G0): Silken mouse enabled
[ 688.437] (==) NVIDIA(G0): DPMS enabled
[ 688.438] (WW) NVIDIA(G0): Option “IgnoreDisplayDevices” is not used
[ 688.438] (WW) NVIDIA(G0): Option “PrimaryGPU” is not used
[ 688.438] (II) Loading sub module “dri2”
[ 688.438] (II) LoadModule: “dri2”
[ 688.438] (II) Module “dri2” already built-in
[ 688.438] (II) NVIDIA(G0): [DRI2] Setup complete
[ 688.438] (II) NVIDIA(G0): [DRI2] VDPAU driver: nvidia
[ 688.438] (II) Initializing extension Generic Event Extension
[ 688.438] (II) Initializing extension SHAPE
[ 688.438] (II) Initializing extension MIT-SHM
[ 688.438] (II) Initializing extension XInputExtension
[ 688.438] (II) Initializing extension XTEST
[ 688.438] (II) Initializing extension BIG-REQUESTS
[ 688.438] (II) Initializing extension SYNC
[ 688.438] (II) Initializing extension XKEYBOARD
[ 688.439] (II) Initializing extension XC-MISC
[ 688.439] (II) Initializing extension SECURITY
[ 688.439] (II) Initializing extension XFIXES
[ 688.439] (II) Initializing extension RENDER
[ 688.439] (II) Initializing extension RANDR
[ 688.439] (II) Initializing extension COMPOSITE
[ 688.439] (II) Initializing extension DAMAGE
[ 688.439] (II) Initializing extension MIT-SCREEN-SAVER
[ 688.439] (II) Initializing extension DOUBLE-BUFFER
[ 688.440] (II) Initializing extension RECORD
[ 688.440] (II) Initializing extension DPMS
[ 688.440] (II) Initializing extension Present
[ 688.440] (II) Initializing extension DRI3
[ 688.440] (II) Initializing extension X-Resource
[ 688.440] (II) Initializing extension XVideo
[ 688.440] (II) Initializing extension XVideo-MotionCompensation
[ 688.440] (II) Initializing extension SELinux
[ 688.440] (II) SELinux: Disabled on system
[ 688.440] (II) Initializing extension GLX
[ 688.440] (II) Indirect GLX disabled.
[ 688.445] (II) AIGLX: Loaded and initialized i965
[ 688.445] (II) GLX: Initialized DRI2 GL provider for screen 0
[ 688.445] (II) Initializing extension XFree86-VidModeExtension
[ 688.445] (II) Initializing extension XFree86-DGA
[ 688.445] (II) Initializing extension XFree86-DRI
[ 688.445] (II) Initializing extension DRI2
[ 688.445] (II) Initializing extension NV-GLX
[ 688.445] (II) Initializing extension NV-CONTROL
[ 688.447] (II) modeset(0): Damage tracking initialized
[ 688.447] (II) modeset(0): Setting screen physical size to 1016 x 317
[ 688.478] (II) config/udev: Adding input device Power Button (/dev/input/event3)
[ 688.478] () Power Button: Applying InputClass “libinput keyboard catchall”
[ 688.478] (II) LoadModule: “libinput”
[ 688.478] (II) Loading /usr/lib/xorg/modules/input/libinput_drv.so
[ 688.480] (II) Module libinput: vendor=“X.Org Foundation”
[ 688.480] compiled for 1.20.4, module version = 0.29.0
[ 688.480] Module class: X.Org XInput Driver
[ 688.480] ABI class: X.Org XInput driver, version 24.1
[ 688.480] (II) Using input driver ‘libinput’ for ‘Power Button’
[ 688.480] (II) systemd-logind: got fd for /dev/input/event3 13:67 fd 39 paused 0
[ 688.480] () Power Button: always reports core events
[ 688.480] () Option “Device” “/dev/input/event3”
[ 688.480] () Option “_source” “server/udev”
[ 688.482] (II) event3 - Power Button: is tagged by udev as: Keyboard
[ 688.482] (II) event3 - Power Button: device is a keyboard
[ 688.482] (II) event3 - Power Button: device removed
[ 688.482] () Option “config_info” “udev:/sys/devices/LNXSYSTM:00/LNXPWRBN:00/input/input3/event3”
[ 688.482] (II) XINPUT: Adding extended input device “Power Button” (type: KEYBOARD, id 6)
[ 688.482] () Option “xkb_model” “pc105”
[ 688.482] () Option “xkb_layout” “us”
[ 688.483] (II) event3 - Power Button: is tagged by udev as: Keyboard
[ 688.483] (II) event3 - Power Button: device is a keyboard
[ 688.483] (II) config/udev: Adding input device Video Bus (/dev/input/event11)
[ 688.483] () Video Bus: Applying InputClass “libinput keyboard catchall”
[ 688.483] (II) Using input driver ‘libinput’ for ‘Video Bus’
[ 688.484] (II) systemd-logind: got fd for /dev/input/event11 13:75 fd 42 paused 0
[ 688.484] () Video Bus: always reports core events
[ 688.484] () Option “Device” “/dev/input/event11”
[ 688.484] () Option “_source” “server/udev”
[ 688.485] (II) event11 - Video Bus: is tagged by udev as: Keyboard
[ 688.485] (II) event11 - Video Bus: device is a keyboard
[ 688.485] (II) event11 - Video Bus: device removed
[ 688.485] () Option “config_info” “udev:/sys/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/LNXVIDEO:01/input/input18/event11”
[ 688.485] (II) XINPUT: Adding extended input device “Video Bus” (type: KEYBOARD, id 7)
[ 688.485] () Option “xkb_model” “pc105”
[ 688.485] () Option “xkb_layout” “us”
[ 688.486] (II) event11 - Video Bus: is tagged by udev as: Keyboard
[ 688.486] (II) event11 - Video Bus: device is a keyboard
[ 688.486] (II) config/udev: Adding input device Video Bus (/dev/input/event10)
[ 688.486] () Video Bus: Applying InputClass “libinput keyboard catchall”
[ 688.486] (II) Using input driver ‘libinput’ for ‘Video Bus’
[ 688.487] (II) systemd-logind: got fd for /dev/input/event10 13:74 fd 43 paused 0
[ 688.487] () Video Bus: always reports core events
[ 688.487] () Option “Device” “/dev/input/event10”
[ 688.487] () Option “_source” “server/udev”
[ 688.488] (II) event10 - Video Bus: is tagged by udev as: Keyboard
[ 688.488] (II) event10 - Video Bus: device is a keyboard
[ 688.488] (II) event10 - Video Bus: device removed
[ 688.488] () Option “config_info” “udev:/sys/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/device:50/LNXVIDEO:00/input/input17/event10”
[ 688.488] (II) XINPUT: Adding extended input device “Video Bus” (type: KEYBOARD, id 8)
[ 688.488] () Option “xkb_model” “pc105”
[ 688.488] () Option “xkb_layout” “us”
[ 688.489] (II) event10 - Video Bus: is tagged by udev as: Keyboard
[ 688.489] (II) event10 - Video Bus: device is a keyboard
[ 688.490] (II) config/udev: Adding input device Power Button (/dev/input/event0)
[ 688.490] () Power Button: Applying InputClass “libinput keyboard catchall”
[ 688.490] (II) Using input driver ‘libinput’ for ‘Power Button’
[ 688.490] (II) systemd-logind: got fd for /dev/input/event0 13:64 fd 44 paused 0
[ 688.490] () Power Button: always reports core events
[ 688.490] () Option “Device” “/dev/input/event0”
[ 688.490] () Option “_source” “server/udev”
[ 688.492] (II) event0 - Power Button: is tagged by udev as: Keyboard
[ 688.492] (II) event0 - Power Button: device is a keyboard
[ 688.492] (II) event0 - Power Button: device removed
[ 688.492] () Option “config_info” “udev:/sys/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0C:00/input/input0/event0”
[ 688.492] (II) XINPUT: Adding extended input device “Power Button” (type: KEYBOARD, id 9)
[ 688.492] () Option “xkb_model” “pc105”
[ 688.492] () Option “xkb_layout” “us”
[ 688.493] (II) event0 - Power Button: is tagged by udev as: Keyboard
[ 688.493] (II) event0 - Power Button: device is a keyboard
[ 688.493] (II) config/udev: Adding input device Lid Switch (/dev/input/event2)
[ 688.493] (II) No input driver specified, ignoring this device.
[ 688.493] (II) This device may have been added with another device file.
[ 688.494] (II) config/udev: Adding input device Sleep Button (/dev/input/event1)
[ 688.494] () Sleep Button: Applying InputClass “libinput keyboard catchall”
[ 688.494] (II) Using input driver ‘libinput’ for ‘Sleep Button’
[ 688.494] (II) systemd-logind: got fd for /dev/input/event1 13:65 fd 45 paused 0
[ 688.494] () Sleep Button: always reports core events
[ 688.494] () Option “Device” “/dev/input/event1”
[ 688.494] () Option “_source” “server/udev”
[ 688.495] (II) event1 - Sleep Button: is tagged by udev as: Keyboard
[ 688.495] (II) event1 - Sleep Button: device is a keyboard
[ 688.495] (II) event1 - Sleep Button: device removed
[ 688.495] () Option “config_info” “udev:/sys/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0E:00/input/input1/event1”
[ 688.495] (II) XINPUT: Adding extended input device “Sleep Button” (type: KEYBOARD, id 10)
[ 688.495] () Option “xkb_model” “pc105”
[ 688.495] () Option “xkb_layout” “us”
[ 688.496] (II) event1 - Sleep Button: is tagged by udev as: Keyboard
[ 688.496] (II) event1 - Sleep Button: device is a keyboard
[ 688.497] (II) config/udev: Adding input device HDA Intel HDMI HDMI/DP,pcm=3 (/dev/input/event13)
[ 688.497] (II) No input driver specified, ignoring this device.
[ 688.497] (II) This device may have been added with another device file.
[ 688.497] (II) config/udev: Adding input device HDA Intel HDMI HDMI/DP,pcm=7 (/dev/input/event14)
[ 688.497] (II) config/udev: Adding input device HDA Intel HDMI HDMI/DP,pcm=8 (/dev/input/event15)
[ 688.498] (II) config/udev: Adding input device HDA Intel HDMI HDMI/DP,pcm=9 (/dev/input/event16)
[ 688.498] (II) No input driver specified, ignoring this device.
[ 688.498] (II) This device may have been added with another device file.
[ 688.498] (II) config/udev: Adding input device HDA Intel HDMI HDMI/DP,pcm=10 (/dev/input/event17)
[ 688.499] (II) config/udev: Adding input device HID 05f3:0007 (/dev/input/event7)
[ 688.499] () HID 05f3:0007: Applying InputClass “libinput keyboard catchall”
[ 688.499] (II) Using input driver ‘libinput’ for ‘HID 05f3:0007’
[ 688.499] (II) systemd-logind: got fd for /dev/input/event7 13:71 fd 46 paused 0
[ 688.499] () HID 05f3:0007: always reports core events
[ 688.499] () Option “Device” “/dev/input/event7”
[ 688.499] () Option “_source” “server/udev”
[ 688.501] (II) event7 - HID 05f3:0007: is tagged by udev as: Keyboard
[ 688.501] (II) event7 - HID 05f3:0007: device is a keyboard
[ 688.501] (II) event7 - HID 05f3:0007: device removed
[ 688.501] () Option “config_info” “udev:/sys/devices/pci0000:00/0000:00:14.0/usb3/3-2/3-2.3/3-2.3.2/3-2.3.2:1.0/0003:05F3:0007.0002/input/input14/event7”
[ 688.501] (II) XINPUT: Adding extended input device “HID 05f3:0007” (type: KEYBOARD, id 11)
[ 688.501] () Option “xkb_model” “pc105”
[ 688.501] () Option “xkb_layout” “us”
[ 688.502] (II) event7 - HID 05f3:0007: is tagged by udev as: Keyboard
[ 688.502] (II) event7 - HID 05f3:0007: device is a keyboard
[ 688.503] (II) config/udev: Adding input device HID 05f3:0007 System Control (/dev/input/event8)
[ 688.503] () HID 05f3:0007 System Control: Applying InputClass “libinput keyboard catchall”
[ 688.503] (II) Using input driver ‘libinput’ for ‘HID 05f3:0007 System Control’
[ 688.504] (II) systemd-logind: got fd for /dev/input/event8 13:72 fd 47 paused 0
[ 688.504] () HID 05f3:0007 System Control: always reports core events
[ 688.504] () Option “Device” “/dev/input/event8”
[ 688.504] () Option “_source” “server/udev”
[ 688.505] (II) event8 - HID 05f3:0007 System Control: is tagged by udev as: Keyboard
[ 688.505] (II) event8 - HID 05f3:0007 System Control: device is a keyboard
[ 688.506] (II) event8 - HID 05f3:0007 System Control: device removed
[ 688.506] () Option “config_info” “udev:/sys/devices/pci0000:00/0000:00:14.0/usb3/3-2/3-2.3/3-2.3.2/3-2.3.2:1.1/0003:05F3:0007.0003/input/input15/event8”
[ 688.506] (II) XINPUT: Adding extended input device “HID 05f3:0007 System Control” (type: KEYBOARD, id 12)
[ 688.506] () Option “xkb_model” “pc105”
[ 688.506] () Option “xkb_layout” “us”
[ 688.507] (II) event8 - HID 05f3:0007 System Control: is tagged by udev as: Keyboard
[ 688.507] (II) event8 - HID 05f3:0007 System Control: device is a keyboard
[ 688.508] (II) config/udev: Adding input device HID 05f3:0007 Consumer Control (/dev/input/event9)
[ 688.508] () HID 05f3:0007 Consumer Control: Applying InputClass “libinput keyboard catchall”
[ 688.508] (II) Using input driver ‘libinput’ for ‘HID 05f3:0007 Consumer Control’
[ 688.508] (II) systemd-logind: got fd for /dev/input/event9 13:73 fd 48 paused 0
[ 688.508] () HID 05f3:0007 Consumer Control: always reports core events
[ 688.508] () Option “Device” “/dev/input/event9”
[ 688.508] () Option “_source” “server/udev”
[ 688.510] (II) event9 - HID 05f3:0007 Consumer Control: is tagged by udev as: Keyboard
[ 688.510] (II) event9 - HID 05f3:0007 Consumer Control: device is a keyboard
[ 688.510] (II) event9 - HID 05f3:0007 Consumer Control: device removed
[ 688.510] () Option “config_info” “udev:/sys/devices/pci0000:00/0000:00:14.0/usb3/3-2/3-2.3/3-2.3.2/3-2.3.2:1.1/0003:05F3:0007.0003/input/input16/event9”
[ 688.510] (II) XINPUT: Adding extended input device “HID 05f3:0007 Consumer Control” (type: KEYBOARD, id 13)
[ 688.510] () Option “xkb_model” “pc105”
[ 688.510] () Option “xkb_layout” “us”
[ 688.511] (II) event9 - HID 05f3:0007 Consumer Control: is tagged by udev as: Keyboard
[ 688.511] (II) event9 - HID 05f3:0007 Consumer Control: device is a keyboard
[ 688.512] (II) config/udev: Adding input device HOLTEK Evoluent VerticalMouse 4 (/dev/input/event6)
[ 688.512] () HOLTEK Evoluent VerticalMouse 4: Applying InputClass “libinput pointer catchall”
[ 688.512] (II) Using input driver ‘libinput’ for ‘HOLTEK Evoluent VerticalMouse 4’
[ 688.570] (II) systemd-logind: got fd for /dev/input/event6 13:70 fd 49 paused 0
[ 688.570] () HOLTEK Evoluent VerticalMouse 4: always reports core events
[ 688.570] () Option “Device” “/dev/input/event6”
[ 688.570] () Option “_source” “server/udev”
[ 688.573] (II) event6 - HOLTEK Evoluent VerticalMouse 4: is tagged by udev as: Mouse
[ 688.573] (II) event6 - HOLTEK Evoluent VerticalMouse 4: device is a pointer
[ 688.573] (II) event6 - HOLTEK Evoluent VerticalMouse 4: device removed
[ 688.574] () Option “config_info” “udev:/sys/devices/pci0000:00/0000:00:14.0/usb3/3-3/3-3:1.0/0003:1A7C:0191.0001/input/input13/event6”
[ 688.574] (II) XINPUT: Adding extended input device “HOLTEK Evoluent VerticalMouse 4” (type: MOUSE, id 14)
[ 688.574] () Option “AccelerationScheme” “none”
[ 688.574] () HOLTEK Evoluent VerticalMouse 4: (accel) selected scheme none/0
[ 688.574] () HOLTEK Evoluent VerticalMouse 4: (accel) acceleration factor: 2.000
[ 688.574] () HOLTEK Evoluent VerticalMouse 4: (accel) acceleration threshold: 4
[ 688.577] (II) event6 - HOLTEK Evoluent VerticalMouse 4: is tagged by udev as: Mouse
[ 688.577] (II) event6 - HOLTEK Evoluent VerticalMouse 4: device is a pointer
[ 688.578] (II) config/udev: Adding input device HOLTEK Evoluent VerticalMouse 4 (/dev/input/mouse1)
[ 688.578] (II) No input driver specified, ignoring this device.
[ 688.578] (II) This device may have been added with another device file.
[ 688.580] (II) config/udev: Adding input device BisonCam, NB Pro: BisonCam, NB (/dev/input/event20)
[ 688.580] () BisonCam, NB Pro: BisonCam, NB : Applying InputClass “libinput keyboard catchall”
[ 688.580] (II) Using input driver ‘libinput’ for 'BisonCam, NB Pro: BisonCam, NB ’
[ 688.581] (II) systemd-logind: got fd for /dev/input/event20 13:84 fd 50 paused 0
[ 688.582] () BisonCam, NB Pro: BisonCam, NB : always reports core events
[ 688.582] () Option “Device” “/dev/input/event20”
[ 688.582] () Option “_source” “server/udev”
[ 688.584] (II) event20 - BisonCam, NB Pro: BisonCam, NB : is tagged by udev as: Keyboard
[ 688.585] (II) event20 - BisonCam, NB Pro: BisonCam, NB : device is a keyboard
[ 688.585] (II) event20 - BisonCam, NB Pro: BisonCam, NB : device removed
[ 688.585] () Option “config_info” “udev:/sys/devices/pci0000:00/0000:00:14.0/usb3/3-8/3-8:1.0/input/input27/event20”
[ 688.585] (II) XINPUT: Adding extended input device "BisonCam, NB Pro: BisonCam, NB " (type: KEYBOARD, id 15)
[ 688.585] () Option “xkb_model” “pc105”
[ 688.585] () Option “xkb_layout” “us”
[ 688.586] (II) event20 - BisonCam, NB Pro: BisonCam, NB : is tagged by udev as: Keyboard
[ 688.587] (II) event20 - BisonCam, NB Pro: BisonCam, NB : device is a keyboard
[ 688.587] (II) config/udev: Adding input device HDA Intel PCH Mic (/dev/input/event18)
[ 688.587] (II) No input driver specified, ignoring this device.
[ 688.587] (II) This device may have been added with another device file.
[ 688.587] (II) config/udev: Adding input device HDA Intel PCH Front Headphone (/dev/input/event19)
[ 688.588] (II) config/udev: Adding input device AT Translated Set 2 keyboard (/dev/input/event4)
[ 688.588] () AT Translated Set 2 keyboard: Applying InputClass “libinput keyboard catchall”
[ 688.588] (II) Using input driver ‘libinput’ for ‘AT Translated Set 2 keyboard’
[ 688.588] (II) systemd-logind: got fd for /dev/input/event4 13:68 fd 51 paused 0
[ 688.588] () AT Translated Set 2 keyboard: always reports core events
[ 688.588] () Option “Device” “/dev/input/event4”
[ 688.588] () Option “_source” “server/udev”
[ 688.589] (II) event4 - AT Translated Set 2 keyboard: is tagged by udev as: Keyboard
[ 688.589] (II) event4 - AT Translated Set 2 keyboard: device is a keyboard
[ 688.590] (II) event4 - AT Translated Set 2 keyboard: device removed
[ 688.590] () Option “config_info” “udev:/sys/devices/platform/i8042/serio0/input/input4/event4”
[ 688.590] (II) XINPUT: Adding extended input device “AT Translated Set 2 keyboard” (type: KEYBOARD, id 16)
[ 688.590] () Option “xkb_model” “pc105”
[ 688.590] () Option “xkb_layout” “us”
[ 688.591] (II) event4 - AT Translated Set 2 keyboard: is tagged by udev as: Keyboard
[ 688.591] (II) event4 - AT Translated Set 2 keyboard: device is a keyboard
[ 688.592] (II) config/udev: Adding input device ETPS/2 Elantech Touchpad (/dev/input/event5)
[ 688.592] () ETPS/2 Elantech Touchpad: Applying InputClass “libinput touchpad catchall”
[ 688.592] (II) Using input driver ‘libinput’ for ‘ETPS/2 Elantech Touchpad’
[ 688.592] (II) systemd-logind: got fd for /dev/input/event5 13:69 fd 52 paused 0
[ 688.592] () ETPS/2 Elantech Touchpad: always reports core events
[ 688.592] () Option “Device” “/dev/input/event5”
[ 688.592] () Option “_source” “server/udev”
[ 688.593] (II) event5 - ETPS/2 Elantech Touchpad: is tagged by udev as: Touchpad
[ 688.594] (II) event5 - ETPS/2 Elantech Touchpad: device is a touchpad
[ 688.594] (II) event5 - ETPS/2 Elantech Touchpad: device removed
[ 688.594] () Option “config_info” “udev:/sys/devices/platform/i8042/serio2/input/input10/event5”
[ 688.594] (II) XINPUT: Adding extended input device “ETPS/2 Elantech Touchpad” (type: TOUCHPAD, id 17)
[ 688.594] () Option “AccelerationScheme” “none”
[ 688.594] () ETPS/2 Elantech Touchpad: (accel) selected scheme none/0
[ 688.594] () ETPS/2 Elantech Touchpad: (accel) acceleration factor: 2.000
[ 688.594] () ETPS/2 Elantech Touchpad: (accel) acceleration threshold: 4
[ 688.595] (II) event5 - ETPS/2 Elantech Touchpad: is tagged by udev as: Touchpad
[ 688.596] (II) event5 - ETPS/2 Elantech Touchpad: device is a touchpad
[ 688.596] (II) config/udev: Adding input device ETPS/2 Elantech Touchpad (/dev/input/mouse0)
[ 688.596] (II) No input driver specified, ignoring this device.
[ 688.596] (II) This device may have been added with another device file.
[ 688.598] (II) config/udev: Adding input device TUXEDO Keyboard (/dev/input/event12)
[ 688.598] () TUXEDO Keyboard: Applying InputClass “libinput keyboard catchall”
[ 688.598] (II) Using input driver ‘libinput’ for ‘TUXEDO Keyboard’
[ 688.598] (II) systemd-logind: got fd for /dev/input/event12 13:76 fd 53 paused 0
[ 688.599] () TUXEDO Keyboard: always reports core events
[ 688.599] () Option “Device” “/dev/input/event12”
[ 688.599] () Option “_source” “server/udev”
[ 688.599] (II) event12 - TUXEDO Keyboard: is tagged by udev as: Keyboard
[ 688.599] (II) event12 - TUXEDO Keyboard: device is a keyboard
[ 688.599] (II) event12 - TUXEDO Keyboard: device removed
[ 688.600] () Option “config_info” “udev:/sys/devices/platform/tuxedo_keyboard/input/input19/event12”
[ 688.600] (II) XINPUT: Adding extended input device “TUXEDO Keyboard” (type: KEYBOARD, id 18)
[ 688.600] () Option “xkb_model” “pc105”
[ 688.600] () Option “xkb_layout” “us”
[ 688.600] (II) event12 - TUXEDO Keyboard: is tagged by udev as: Keyboard
[ 688.600] (II) event12 - TUXEDO Keyboard: device is a keyboard
[ 688.726] (II) modeset(0): EDID vendor “AUO”, prod id 4845
[ 688.726] (II) modeset(0): Printing DDC gathered Modelines:
[ 688.726] (II) modeset(0): Modeline "1920x1080"x0.0 141.40 1920 1968 2068 2112 1080 1088 1102 1112 -hsync -vsync (67.0 kHz eP)
[ 688.726] (II) modeset(0): Modeline "1920x1080"x0.0 94.27 1920 1968 2068 2112 1080 1088 1102 1112 -hsync -vsync (44.6 kHz e)
[ 688.769] (II) modeset(0): EDID vendor “AUO”, prod id 4845
[ 688.769] (II) modeset(0): Printing DDC gathered Modelines:
[ 688.769] (II) modeset(0): Modeline "1920x1080"x0.0 141.40 1920 1968 2068 2112 1080 1088 1102 1112 -hsync -vsync (67.0 kHz eP)
[ 688.769] (II) modeset(0): Modeline "1920x1080"x0.0 94.27 1920 1968 2068 2112 1080 1088 1102 1112 -hsync -vsync (44.6 kHz e)
[ 688.799] (II) modeset(0): EDID vendor “AUO”, prod id 4845
[ 688.799] (II) modeset(0): Printing DDC gathered Modelines:
[ 688.799] (II) modeset(0): Modeline "1920x1080"x0.0 141.40 1920 1968 2068 2112 1080 1088 1102 1112 -hsync -vsync (67.0 kHz eP)
[ 688.799] (II) modeset(0): Modeline "1920x1080"x0.0 94.27 1920 1968 2068 2112 1080 1088 1102 1112 -hsync -vsync (44.6 kHz e)
[ 688.838] (II) modeset(0): EDID vendor “AUO”, prod id 4845
[ 688.838] (II) modeset(0): Printing DDC gathered Modelines:
[ 688.838] (II) modeset(0): Modeline "1920x1080"x0.0 141.40 1920 1968 2068 2112 1080 1088 1102 1112 -hsync -vsync (67.0 kHz eP)
[ 688.838] (II) modeset(0): Modeline "1920x1080"x0.0 94.27 1920 1968 2068 2112 1080 1088 1102 1112 -hsync -vsync (44.6 kHz e)
[ 688.877] (II) modeset(0): EDID vendor “AUO”, prod id 4845
[ 688.877] (II) modeset(0): Printing DDC gathered Modelines:
[ 688.877] (II) modeset(0): Modeline "1920x1080"x0.0 141.40 1920 1968 2068 2112 1080 1088 1102 1112 -hsync -vsync (67.0 kHz eP)
[ 688.877] (II) modeset(0): Modeline "1920x1080"x0.0 94.27 1920 1968 2068 2112 1080 1088 1102 1112 -hsync -vsync (44.6 kHz e)
[ 689.193] (II) modeset(0): Allocate new frame buffer 1920x1200 stride
[ 690.367] (II) modeset(0): EDID vendor “AUO”, prod id 4845
[ 690.367] (II) modeset(0): Printing DDC gathered Modelines:
[ 690.367] (II) modeset(0): Modeline "1920x1080"x0.0 141.40 1920 1968 2068 2112 1080 1088 1102 1112 -hsync -vsync (67.0 kHz eP)
[ 690.367] (II) modeset(0): Modeline "1920x1080"x0.0 94.27 1920 1968 2068 2112 1080 1088 1102 1112 -hsync -vsync (44.6 kHz e)
[ 690.430] (II) modeset(0): Allocate new frame buffer 3840x1200 stride
[ 691.547] (II) modeset(0): EDID vendor “AUO”, prod id 4845
[ 691.547] (II) modeset(0): Printing DDC gathered Modelines:
[ 691.547] (II) modeset(0): Modeline "1920x1080"x0.0 141.40 1920 1968 2068 2112 1080 1088 1102 1112 -hsync -vsync (67.0 kHz eP)
[ 691.547] (II) modeset(0): Modeline "1920x1080"x0.0 94.27 1920 1968 2068 2112 1080 1088 1102 1112 -hsync -vsync (44.6 kHz e)
[ 696.292] () Option “fd” “39”
[ 696.292] (II) event3 - Power Button: device removed
[ 696.293] () Option “fd” “42”
[ 696.293] (II) event11 - Video Bus: device removed
[ 696.293] () Option “fd” “43”
[ 696.293] (II) event10 - Video Bus: device removed
[ 696.294] () Option “fd” “44”
[ 696.294] (II) event0 - Power Button: device removed
[ 696.294] () Option “fd” “45”
[ 696.294] (II) event1 - Sleep Button: device removed
[ 696.294] () Option “fd” “46”
[ 696.294] (II) event7 - HID 05f3:0007: device removed
[ 696.295] () Option “fd” “47”
[ 696.295] (II) event8 - HID 05f3:0007 System Control: device removed
[ 696.295] () Option “fd” “48”
[ 696.295] (II) event9 - HID 05f3:0007 Consumer Control: device removed
[ 696.295] () Option “fd” “49”
[ 696.296] (II) event6 - HOLTEK Evoluent VerticalMouse 4: device removed
[ 696.296] () Option “fd” “50”
[ 696.296] (II) event20 - BisonCam, NB Pro: BisonCam, NB : device removed
[ 696.296] () Option “fd” “51”
[ 696.296] (II) event4 - AT Translated Set 2 keyboard: device removed
[ 696.297] () Option “fd” “52”
[ 696.297] (II) event5 - ETPS/2 Elantech Touchpad: device removed
[ 696.297] (**) Option “fd” “53”
[ 696.297] (II) event12 - TUXEDO Keyboard: device removed
[ 696.297] (II) AIGLX: Suspending AIGLX clients for VT switch
[ 696.309] (EE) modeset(0): failed to set mode: Permission denied
[ 696.310] (II) systemd-logind: got pause for 13:76
[ 696.310] (II) systemd-logind: got pause for 13:75
[ 696.310] (II) systemd-logind: got pause for 13:74
[ 696.310] (II) systemd-logind: got pause for 13:70
[ 696.310] (II) systemd-logind: got pause for 13:84
[ 696.310] (II) systemd-logind: got pause for 13:68
[ 696.310] (II) systemd-logind: got pause for 13:72
[ 696.310] (II) systemd-logind: got pause for 13:65
[ 696.310] (II) systemd-logind: got pause for 13:73
[ 696.310] (II) systemd-logind: got pause for 13:64
[ 696.310] (II) systemd-logind: got pause for 13:67
[ 696.310] (II) systemd-logind: got pause for 226:0
[ 696.310] (II) systemd-logind: got pause for 13:71
[ 696.310] (II) systemd-logind: got pause for 13:69
[ 806.239] (II) UnloadModule: “libinput”
[ 806.239] (II) systemd-logind: releasing fd for 13:76
[ 806.430] (II) UnloadModule: “libinput”
[ 806.430] (II) systemd-logind: releasing fd for 13:69
[ 806.550] (II) UnloadModule: “libinput”
[ 806.550] (II) systemd-logind: releasing fd for 13:68
[ 806.582] (II) UnloadModule: “libinput”
[ 806.582] (II) systemd-logind: releasing fd for 13:84
[ 806.626] (II) UnloadModule: “libinput”
[ 806.626] (II) systemd-logind: releasing fd for 13:70
[ 806.654] (II) UnloadModule: “libinput”
[ 806.654] (II) systemd-logind: releasing fd for 13:73
[ 806.694] (II) UnloadModule: “libinput”
[ 806.694] (II) systemd-logind: releasing fd for 13:72
[ 806.714] (II) UnloadModule: “libinput”
[ 806.714] (II) systemd-logind: releasing fd for 13:71
[ 806.738] (II) UnloadModule: “libinput”
[ 806.738] (II) systemd-logind: releasing fd for 13:65
[ 806.766] (II) UnloadModule: “libinput”
[ 806.766] (II) systemd-logind: releasing fd for 13:64
[ 806.790] (II) UnloadModule: “libinput”
[ 806.790] (II) systemd-logind: releasing fd for 13:74
[ 806.810] (II) UnloadModule: “libinput”
[ 806.810] (II) systemd-logind: releasing fd for 13:75
[ 806.835] (II) UnloadModule: “libinput”
[ 806.835] (II) systemd-logind: releasing fd for 13:67
[ 806.868] (II) NVIDIA(GPU-0): Deleting GPU-0
[ 806.869] (WW) xf86CloseConsole: KDSETMODE failed: Input/output error
[ 806.869] (WW) xf86CloseConsole: VT_GETMODE failed: Input/output error
[ 806.869] (WW) xf86CloseConsole: VT_ACTIVATE failed: Input/output error
[ 806.870] (II) Server terminated successfully (0). Closing log file.
Peculiar here is that the module is named glxserver_nvidia and not glxservernvidia.
In fact searching for glxservernvidia does almost not yield any results on Google, and leads to Google suggesting “did you mean glxserver_nvidia ?”.
