Random black screen
I still can SSH, but locally any sound stops 15 seconds after the black screen and any keystroke doesn’t seem to have any impact of the computer, so I gathered those informations through SSH
NVRM: GPU at PCI:0000:01:00: GPU-25ebd6e0-8288-92bb-63be-726a324d49a7
NVRM: Xid (PCI:0000:01:00): 79, pid=4497, GPU has fallen off the bus.
NVRM: GPU 0000:01:00.0: GPU has fallen off the bus.
NVRM: A GPU crash dump has been created. If possible, please run
NVRM: nvidia-bug-report.sh as root to collect this data before
NVRM: the NVIDIA kernel module is unloaded.
____________________________________________
Start of NVIDIA bug report log file.  Please include this file, along
with a detailed description of your problem, when reporting a graphics
driver bug via the NVIDIA Linux forum (see devtalk.nvidia.com)
or by sending email to 'linux-bugs@nvidia.com'.
nvidia-bug-report.sh Version: 28008694
Date: Thu 20 Aug 2020 02:29:14 PM CEST
uname: Linux localhost 5.8.1-arch1-1 #1 SMP PREEMPT Wed, 12 Aug 2020 18:50:43 +0000 x86_64 GNU/Linux
command line flags:
*** /sys/bus/pci/devices/0000:01:00.0/power/control
*** ls: -rw-r--r-- 1 root root 4096 2020-08-20 14:29:14.280959180 +0200 /sys/bus/pci/devices/0000:01:00.0/power/control
on
*** /sys/bus/pci/devices/0000:01:00.0/power/runtime_status
*** ls: -r--r--r-- 1 root root 4096 2020-08-20 14:29:14.280959180 +0200 /sys/bus/pci/devices/0000:01:00.0/power/runtime_status
active
*** /sys/bus/pci/devices/0000:01:00.0/power/runtime_usage
*** ls: -r--r--r-- 1 root root 4096 2020-08-20 14:29:14.284292345 +0200 /sys/bus/pci/devices/0000:01:00.0/power/runtime_usage
2
*** /sys/bus/pci/devices/0000:01:00.1/power/control
*** ls: -rw-r--r-- 1 root root 4096 2020-08-20 14:29:14.287625508 +0200 /sys/bus/pci/devices/0000:01:00.1/power/control
auto
*** /sys/bus/pci/devices/0000:01:00.1/power/runtime_status
*** ls: -r--r--r-- 1 root root 4096 2020-08-20 14:29:14.290958673 +0200 /sys/bus/pci/devices/0000:01:00.1/power/runtime_status
suspended
*** /sys/bus/pci/devices/0000:01:00.1/power/runtime_usage
*** ls: -r--r--r-- 1 root root 4096 2020-08-20 14:29:14.290958673 +0200 /sys/bus/pci/devices/0000:01:00.1/power/runtime_usage
0
*** /proc/driver/nvidia/./gpus/0000:01:00.0/power
*** ls: -r--r--r-- 1 root root 0 2020-08-20 14:29:14.297625001 +0200 /proc/driver/nvidia/./gpus/0000:01:00.0/power
Runtime D3 status:          Disabled
Video Memory:               Active
GPU Hardware Support:
 Video Memory Self Refresh: Not Supported
 Video Memory Off:          Not Supported
*** /etc/issue
*** ls: -rw-r--r-- 1 root root 20 2020-05-20 00:42:31.000000000 +0200 /etc/issue
Arch Linux \r (\l)
*** /var/log/nvidia-installer.log does not exist
journalctl -b -0 _COMM=Xorg
-- Logs begin at Sun 2020-01-12 19:06:24 CET, end at Thu 2020-08-20 14:29:14 CEST. --
-- No entries --
journalctl -b -1 _COMM=Xorg
-- No entries --
journalctl -b -2 _COMM=Xorg
-- No entries --
journalctl -b -0 _COMM=Xorg.bin
-- No entries --
journalctl -b -1 _COMM=Xorg.bin
-- No entries --
journalctl -b -2 _COMM=Xorg.bin
-- No entries --
-- No entries --
-- No entries --
-- No entries --
journalctl -b -0 _COMM=gdm-x-session
-- No entries --
journalctl -b -1 _COMM=gdm-x-session
-- No entries --
journalctl -b -2 _COMM=gdm-x-session
-- No entries --
/sbin/coredumpctl info COREDUMP_COMM=Xorg COREDUMP_COMM=Xorg.bin COREDUMP_COMM=X
*** /var/log/Xorg.0.log
*** ls: -rw-r--r-- 1 root user 45701 2020-08-20 13:50:47.363102857 +0200 /var/log/Xorg.0.log
[   429.279] (WW) Failed to open protocol names file lib/xorg/protocol.txt
[   429.280]
X.Org X Server 1.20.8
X Protocol Version 11, Revision 0
[   429.281] Build Operating System: Linux Arch Linux
[   429.282] Current Operating System: Linux localhost 5.8.1-arch1-1 #1 SMP PREEMPT Wed, 12 Aug 2020 18:50:43 +0000 x86_64
[   429.282] Kernel command line: root=UUID=6c37d730-4b14-4479-8554-92d2e75478d5 rw initrd=\initramfs-linux.img
[   429.282] Build Date: 31 July 2020  04:00:57PM
[   429.283]
[   429.283] Current version of pixman: 0.40.0
[   429.284] 	Before reporting problems, check http://wiki.x.org
	to make sure that you have the latest version.
[   429.284] Markers: (--) probed, (**) from config file, (==) default setting,
	(++) from command line, (!!) notice, (II) informational,
	(WW) warning, (EE) error, (NI) not implemented, (??) unknown.
[   429.286] (==) Log file: "/var/log/Xorg.0.log", Time: Thu Aug 20 13:27:57 2020
[   429.288] (==) Using config file: "/etc/X11/xorg.conf"
[   429.289] (==) Using config directory: "/etc/X11/xorg.conf.d"
[   429.289] (==) Using system config directory "/usr/share/X11/xorg.conf.d"
[   429.290] (==) ServerLayout "Layout0"
[   429.290] (**) |-->Screen "Screen0" (0)
[   429.290] (**) |   |-->Monitor "Monitor0"
[   429.290] (**) |   |-->Device "Device0"
[   429.290] (**) |   |-->GPUDevice "Device0"
[   429.290] (**) |-->Input Device "Keyboard0"
[   429.290] (**) |-->Input Device "Mouse0"
[   429.290] (**) Option "Xinerama" "0"
[   429.290] (==) Automatically adding devices
[   429.290] (==) Automatically enabling devices
[   429.290] (==) Automatically adding GPU devices
[   429.290] (==) Automatically binding GPU devices
[   429.290] (==) Max clients allowed: 256, resource mask: 0x1fffff
[   429.292] (WW) `fonts.dir' not found (or not valid) in "/usr/share/fonts/OTF".
[   429.292] 	Entry deleted from font path.
[   429.292] 	(Run 'mkfontdir' on "/usr/share/fonts/OTF").
[   429.292] (WW) The directory "/usr/share/fonts/Type1" does not exist.
[   429.292] (WW) The directory "/usr/share/fonts/100dpi" does not exist.
[   429.292] (WW) The directory "/usr/share/fonts/75dpi" does not exist.
[   429.292] (==) FontPath set to:
	/usr/share/fonts/misc,
	/usr/share/fonts/TTF
[   429.292] (==) ModulePath set to "/usr/lib/xorg/modules"
[   429.292] (WW) Hotplugging is on, devices using drivers 'kbd', 'mouse' or 'vmmouse' will be disabled.
[   429.292] (WW) Disabling Keyboard0
[   429.292] (WW) Disabling Mouse0
[   429.292] (II) Module ABI versions:
[   429.292] 	X.Org ANSI C Emulation: 0.4
[   429.293] 	X.Org Video Driver: 24.1
[   429.293] 	X.Org XInput driver : 24.1
[   429.293] 	X.Org Server Extension : 10.0
[   429.293] (++) using VT number 1
[   429.294] (II) systemd-logind: took control of session /org/freedesktop/login1/session/_31
[   429.295] (II) xfree86: Adding drm device (/dev/dri/card0)
[   429.295] (II) systemd-logind: got fd for /dev/dri/card0 226:0 fd 10 paused 0
[   429.296] (**) OutputClass "nvidia" ModulePath extended to "/usr/lib/nvidia/xorg,/usr/lib/xorg/modules,/usr/lib/xorg/modules"
[   429.297] (--) PCI:*(1@0:0:0) 10de:13c2:1462:3160 rev 161, Mem @ 0xde000000/16777216, 0xc0000000/268435456, 0xd0000000/33554432, I/O @ 0x0000e000/128, BIOS @ 0x????????/131072
[   429.297] (WW) Open ACPI failed (/var/run/acpid.socket) (No such file or directory)
[   429.297] (II) LoadModule: "glx"
[   429.299] (II) Loading /usr/lib/xorg/modules/extensions/libglx.so
[   429.301] (II) Module glx: vendor="X.Org Foundation"
[   429.301] 	compiled for 1.20.8, module version = 1.0.0
[   429.301] 	ABI class: X.Org Server Extension, version 10.0
[   429.301] (II) LoadModule: "nvidia"
[   429.301] (II) Loading /usr/lib/xorg/modules/drivers/nvidia_drv.so
[   429.308] (II) Module nvidia: vendor="NVIDIA Corporation"
[   429.308] 	compiled for 1.6.99.901, module version = 1.0.0
[   429.308] 	Module class: X.Org Video Driver
[   429.309] (II) NVIDIA dlloader X Driver  450.57  Sun Jul  5 14:40:23 UTC 2020
[   429.309] (II) NVIDIA Unified Driver for all Supported NVIDIA GPUs
[   429.310] (II) systemd-logind: releasing fd for 226:0
[   429.311] (II) Loading sub module "fb"
[   429.311] (II) LoadModule: "fb"
[   429.311] (II) Loading /usr/lib/xorg/modules/libfb.so
[   429.312] (II) Module fb: vendor="X.Org Foundation"
[   429.312] 	compiled for 1.20.8, module version = 1.0.0
[   429.312] 	ABI class: X.Org ANSI C Emulation, version 0.4
[   429.312] (II) Loading sub module "wfb"
[   429.312] (II) LoadModule: "wfb"
[   429.312] (II) Loading /usr/lib/xorg/modules/libwfb.so
[   429.313] (II) Module wfb: vendor="X.Org Foundation"
[   429.313] 	compiled for 1.20.8, module version = 1.0.0
[   429.313] 	ABI class: X.Org ANSI C Emulation, version 0.4
[   429.313] (II) Loading sub module "ramdac"
[   429.313] (II) LoadModule: "ramdac"
[   429.313] (II) Module "ramdac" already built-in
[   429.315] (**) NVIDIA(0): Depth 24, (--) framebuffer bpp 32
[   429.315] (==) NVIDIA(0): RGB weight 888
[   429.315] (==) NVIDIA(0): Default visual is TrueColor
[   429.315] (==) NVIDIA(0): Using gamma correction (1.0, 1.0, 1.0)
[   429.315] (II) Applying OutputClass "nvidia" options to /dev/dri/card0
[   429.315] (**) NVIDIA(0): Option "Stereo" "0"
[   429.315] (**) NVIDIA(0): Option "nvidiaXineramaInfoOrder" "DFP-1"
[   429.315] (**) NVIDIA(0): Option "SLI" "Off"
[   429.315] (**) NVIDIA(0): Option "MultiGPU" "Off"
[   429.315] (**) NVIDIA(0): Option "BaseMosaic" "off"
[   429.315] (**) NVIDIA(0): Option "AllowEmptyInitialConfiguration"
[   429.315] (**) NVIDIA(0): Stereo disabled by request
[   429.315] (**) NVIDIA(0): NVIDIA SLI disabled.
[   429.315] (**) NVIDIA(0): NVIDIA Multi-GPU disabled.
[   429.315] (**) NVIDIA(0): Option "MetaModes" "HDMI-0: 3840x2160_60 +0+0, DP-0: 1920x1080_144 +3840+0"
[   429.315] (**) NVIDIA(0): Enabling 2D acceleration
[   429.315] (II) Loading sub module "glxserver_nvidia"
[   429.315] (II) LoadModule: "glxserver_nvidia"
[   429.315] (II) Loading /usr/lib/nvidia/xorg/libglxserver_nvidia.so
[   429.378] (II) Module glxserver_nvidia: vendor="NVIDIA Corporation"
[   429.378] 	compiled for 1.6.99.901, module version = 1.0.0
[   429.378] 	Module class: X.Org Server Extension
[   429.378] (II) NVIDIA GLX Module  450.57  Sun Jul  5 14:43:44 UTC 2020
[   429.381] (II) NVIDIA: The X server supports PRIME Render Offload.
[   430.025] (--) NVIDIA(0): Valid display device(s) on GPU-0 at PCI:1:0:0
[   430.025] (--) NVIDIA(0):     CRT-0
[   430.025] (--) NVIDIA(0):     DFP-0
[   430.025] (--) NVIDIA(0):     DFP-1 (boot)
[   430.025] (--) NVIDIA(0):     DFP-2
[   430.025] (--) NVIDIA(0):     DFP-3
[   430.025] (--) NVIDIA(0):     DFP-4
[   430.025] (II) NVIDIA(0): NVIDIA GPU GeForce GTX 970 (GM204-A) at PCI:1:0:0 (GPU-0)
[   430.025] (--) NVIDIA(0): Memory: 4194304 kBytes
[   430.025] (--) NVIDIA(0): VideoBIOS: 84.04.2f.00.f1
[   430.025] (II) NVIDIA(0): Detected PCI Express Link width: 16X
[   430.029] (--) NVIDIA(GPU-0): CRT-0: disconnected
[   430.029] (--) NVIDIA(GPU-0): CRT-0: 400.0 MHz maximum pixel clock
[   430.033] (--) NVIDIA(GPU-0): DFP-0: disconnected
[   430.033] (--) NVIDIA(GPU-0): DFP-0: Internal TMDS
[   430.033] (--) NVIDIA(GPU-0): DFP-0: 330.0 MHz maximum pixel clock
[   430.064] (--) NVIDIA(GPU-0): HPN HP ENVY 27s (DFP-1): connected
[   430.064] (--) NVIDIA(GPU-0): HPN HP ENVY 27s (DFP-1): Internal TMDS
[   430.064] (--) NVIDIA(GPU-0): HPN HP ENVY 27s (DFP-1): 600.0 MHz maximum pixel clock
[   430.064] (--) NVIDIA(GPU-0): Idek Iiyama PLG2773H (DFP-2): connected
[   430.064] (--) NVIDIA(GPU-0): Idek Iiyama PLG2773H (DFP-2): Internal DisplayPort
[   430.064] (--) NVIDIA(GPU-0): Idek Iiyama PLG2773H (DFP-2): 960.0 MHz maximum pixel clock
[   430.065] (--) NVIDIA(GPU-0): DFP-3: disconnected
[   430.065] (--) NVIDIA(GPU-0): DFP-3: Internal TMDS
[   430.065] (--) NVIDIA(GPU-0): DFP-3: 165.0 MHz maximum pixel clock
[   430.065] (--) NVIDIA(GPU-0): DFP-4: disconnected
[   430.065] (--) NVIDIA(GPU-0): DFP-4: Internal TMDS
[   430.065] (--) NVIDIA(GPU-0): DFP-4: 330.0 MHz maximum pixel clock
[   430.070] (II) NVIDIA(0): Validated MetaModes:
[   430.070] (II) NVIDIA(0):     "HDMI-0:3840x2160_60+0+0,DP-0:1920x1080_144+3840+0"
[   430.070] (II) NVIDIA(0): Virtual screen size determined to be 5760 x 2160
[   430.074] (--) NVIDIA(0): DPI set to (162, 161); computed from "UseEdidDpi" X config
[   430.074] (--) NVIDIA(0):     option
[   430.074] (II) NVIDIA: Using 6144.00 MB of virtual memory for indirect memory
[   430.074] (II) NVIDIA:     access.
[   430.076] (II) NVIDIA(0): ACPI: failed to connect to the ACPI event daemon; the daemon
[   430.076] (II) NVIDIA(0):     may not be running or the "AcpidSocketPath" X
[   430.076] (II) NVIDIA(0):     configuration option may not be set correctly.  When the
[   430.076] (II) NVIDIA(0):     ACPI event daemon is available, the NVIDIA X driver will
[   430.076] (II) NVIDIA(0):     try to use it to receive ACPI event notifications.  For
[   430.076] (II) NVIDIA(0):     details, please see the "ConnectToAcpid" and
[   430.076] (II) NVIDIA(0):     "AcpidSocketPath" X configuration options in Appendix B: X
[   430.076] (II) NVIDIA(0):     Config Options in the README.
[   430.092] (II) NVIDIA(0): Setting mode "HDMI-0:3840x2160_60+0+0,DP-0:1920x1080_144+3840+0"
[   430.186] (==) NVIDIA(0): Disabling shared memory pixmaps
[   430.186] (==) NVIDIA(0): Backing store enabled
[   430.186] (==) NVIDIA(0): Silken mouse disabled
[   430.186] (**) NVIDIA(0): DPMS enabled
[   430.189] (II) Loading sub module "dri2"
[   430.189] (II) LoadModule: "dri2"
[   430.189] (II) Module "dri2" already built-in
[   430.189] (II) NVIDIA(0): [DRI2] Setup complete
[   430.189] (II) NVIDIA(0): [DRI2]   VDPAU driver: nvidia
[   430.190] (II) Initializing extension Generic Event Extension
[   430.190] (II) Initializing extension SHAPE
[   430.190] (II) Initializing extension MIT-SHM
[   430.190] (II) Initializing extension XInputExtension
[   430.190] (II) Initializing extension XTEST
[   430.190] (II) Initializing extension BIG-REQUESTS
[   430.190] (II) Initializing extension SYNC
[   430.190] (II) Initializing extension XKEYBOARD
[   430.190] (II) Initializing extension XC-MISC
[   430.190] (II) Initializing extension SECURITY
[   430.190] (II) Initializing extension XFIXES
[   430.190] (II) Initializing extension RENDER
[   430.190] (II) Initializing extension RANDR
[   430.190] (II) Initializing extension COMPOSITE
[   430.190] (II) Initializing extension DAMAGE
[   430.190] (II) Initializing extension MIT-SCREEN-SAVER
[   430.190] (II) Initializing extension DOUBLE-BUFFER
[   430.190] (II) Initializing extension RECORD
[   430.190] (II) Initializing extension DPMS
[   430.190] (II) Initializing extension Present
[   430.190] (II) Initializing extension DRI3
[   430.190] (II) Initializing extension X-Resource
[   430.190] (II) Initializing extension XVideo
[   430.190] (II) Initializing extension XVideo-MotionCompensation
[   430.190] (II) Initializing extension GLX
[   430.191] (II) Initializing extension GLX
[   430.191] (II) Indirect GLX disabled.
[   430.191] (II) GLX: Another vendor is already registered for screen 0
[   430.191] (II) Initializing extension XFree86-VidModeExtension
[   430.191] (II) Initializing extension XFree86-DGA
[   430.191] (II) Initializing extension XFree86-DRI
[   430.191] (II) Initializing extension DRI2
[   430.191] (II) Initializing extension NV-GLX
[   430.191] (II) Initializing extension NV-CONTROL
[   430.191] (II) Initializing extension XINERAMA
[   430.239] (II) config/udev: Adding input device Power Button (/dev/input/event1)
[   430.239] (**) Power Button: Applying InputClass "libinput keyboard catchall"
[   430.239] (**) Power Button: Applying InputClass "system-keyboard"
[   430.239] (II) LoadModule: "libinput"
[   430.239] (II) Loading /usr/lib/xorg/modules/input/libinput_drv.so
[   430.244] (II) Module libinput: vendor="X.Org Foundation"
[   430.244] 	compiled for 1.20.8, module version = 0.30.0
[   430.244] 	Module class: X.Org XInput Driver
[   430.244] 	ABI class: X.Org XInput driver, version 24.1
[   430.244] (II) Using input driver 'libinput' for 'Power Button'
[   430.244] (II) systemd-logind: got fd for /dev/input/event1 13:65 fd 33 paused 0
[   430.244] (**) Power Button: always reports core events
[   430.244] (**) Option "Device" "/dev/input/event1"
[   430.244] (**) Option "_source" "server/udev"
[   430.251] (II) event1  - Power Button: is tagged by udev as: Keyboard
[   430.251] (II) event1  - Power Button: device is a keyboard
[   430.251] (II) event1  - Power Button: device removed
[   430.251] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXPWRBN:00/input/input1/event1"
[   430.251] (II) XINPUT: Adding extended input device "Power Button" (type: KEYBOARD, id 6)
[   430.251] (**) Option "xkb_model" "fr-latin1"
[   430.251] (**) Option "xkb_layout" "fr"
[   430.263] (II) event1  - Power Button: is tagged by udev as: Keyboard
[   430.263] (II) event1  - Power Button: device is a keyboard
[   430.264] (II) config/udev: Adding input device Power Button (/dev/input/event0)
[   430.264] (**) Power Button: Applying InputClass "libinput keyboard catchall"
[   430.264] (**) Power Button: Applying InputClass "system-keyboard"
[   430.264] (II) Using input driver 'libinput' for 'Power Button'
[   430.264] (II) systemd-logind: got fd for /dev/input/event0 13:64 fd 36 paused 0
[   430.264] (**) Power Button: always reports core events
[   430.264] (**) Option "Device" "/dev/input/event0"
[   430.264] (**) Option "_source" "server/udev"
[   430.265] (II) event0  - Power Button: is tagged by udev as: Keyboard
[   430.265] (II) event0  - Power Button: device is a keyboard
[   430.265] (II) event0  - Power Button: device removed
[   430.265] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0C:00/input/input0/event0"
[   430.265] (II) XINPUT: Adding extended input device "Power Button" (type: KEYBOARD, id 7)
[   430.265] (**) Option "xkb_model" "fr-latin1"
[   430.265] (**) Option "xkb_layout" "fr"
[   430.266] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=12 (/dev/input/event10)
[   430.266] (II) No input driver specified, ignoring this device.
[   430.266] (II) This device may have been added with another device file.
[   430.266] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=3 (/dev/input/event4)
[   430.266] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=7 (/dev/input/event5)
[   430.266] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=8 (/dev/input/event6)
[   430.267] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=9 (/dev/input/event7)
[   430.267] (II) No input driver specified, ignoring this device.
[   430.267] (II) This device may have been added with another device file.
[   430.267] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=10 (/dev/input/event8)
[   430.267] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=11 (/dev/input/event9)
[   430.267] (II) config/udev: Adding input device Valve Software Steam Controller (/dev/input/event19)
[   430.267] (**) Valve Software Steam Controller: Applying InputClass "libinput pointer catchall"
[   430.267] (**) Valve Software Steam Controller: Applying InputClass "libinput keyboard catchall"
[   430.267] (**) Valve Software Steam Controller: Applying InputClass "system-keyboard"
[   430.267] (II) Using input driver 'libinput' for 'Valve Software Steam Controller'
[   430.268] (II) systemd-logind: got fd for /dev/input/event19 13:83 fd 37 paused 0
[   430.268] (**) Valve Software Steam Controller: always reports core events
[   430.268] (**) Option "Device" "/dev/input/event19"
[   430.268] (**) Option "_source" "server/udev"
[   430.269] (II) event19 - Valve Software Steam Controller: is tagged by udev as: Keyboard Mouse
[   430.269] (II) event19 - Valve Software Steam Controller: device is a pointer
[   430.269] (II) event19 - Valve Software Steam Controller: device is a keyboard
[   430.269] (II) event19 - Valve Software Steam Controller: device removed
[   430.269] (II) libinput: Valve Software Steam Controller: needs a virtual subdevice
[   430.269] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:14.0/usb2/2-10/2-10:1.0/0003:28DE:1142.0001/input/input29/event19"
[   430.269] (II) XINPUT: Adding extended input device "Valve Software Steam Controller" (type: MOUSE, id 8)
[   430.269] (**) Option "AccelerationScheme" "none"
[   430.269] (**) Valve Software Steam Controller: (accel) selected scheme none/0
[   430.269] (**) Valve Software Steam Controller: (accel) acceleration factor: 2.000
[   430.269] (**) Valve Software Steam Controller: (accel) acceleration threshold: 4
[   430.270] (II) event19 - Valve Software Steam Controller: is tagged by udev as: Keyboard Mouse
[   430.270] (II) event19 - Valve Software Steam Controller: device is a pointer
[   430.270] (II) event19 - Valve Software Steam Controller: device is a keyboard
[   430.270] (II) config/udev: Adding input device Valve Software Steam Controller (/dev/input/mouse0)
[   430.270] (**) Valve Software Steam Controller: Applying InputClass "system-keyboard"
[   430.270] (II) No input driver specified, ignoring this device.
[   430.270] (II) This device may have been added with another device file.
[   430.271] (II) config/udev: Adding input device Logitech Logitech Gaming Keyboard (/dev/input/event22)
[   430.271] (**) Logitech Logitech Gaming Keyboard: Applying InputClass "libinput keyboard catchall"
[   430.271] (**) Logitech Logitech Gaming Keyboard: Applying InputClass "system-keyboard"
[   430.271] (II) Using input driver 'libinput' for 'Logitech Logitech Gaming Keyboard'
[   430.271] (II) systemd-logind: got fd for /dev/input/event22 13:86 fd 38 paused 0
[   430.271] (**) Logitech Logitech Gaming Keyboard: always reports core events
[   430.271] (**) Option "Device" "/dev/input/event22"
[   430.271] (**) Option "_source" "server/udev"
[   430.272] (II) event22 - Logitech Logitech Gaming Keyboard: is tagged by udev as: Keyboard
[   430.272] (II) event22 - Logitech Logitech Gaming Keyboard: device is a keyboard
[   430.272] (II) event22 - Logitech Logitech Gaming Keyboard: device removed
[   430.272] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:14.0/usb2/2-13/2-13.1/2-13.1:1.0/0003:046D:C221.0008/input/input26/event22"
[   430.272] (II) XINPUT: Adding extended input device "Logitech Logitech Gaming Keyboard" (type: KEYBOARD, id 9)
[   430.272] (**) Option "xkb_model" "fr-latin1"
[   430.272] (**) Option "xkb_layout" "fr"
[   430.273] (II) event22 - Logitech Logitech Gaming Keyboard: is tagged by udev as: Keyboard
[   430.273] (II) event22 - Logitech Logitech Gaming Keyboard: device is a keyboard
[   430.274] (II) config/udev: Adding input device Logitech Logitech Gaming Keyboard Consumer Control (/dev/input/event18)
[   430.274] (**) Logitech Logitech Gaming Keyboard Consumer Control: Applying InputClass "libinput keyboard catchall"
[   430.274] (**) Logitech Logitech Gaming Keyboard Consumer Control: Applying InputClass "system-keyboard"
[   430.274] (II) Using input driver 'libinput' for 'Logitech Logitech Gaming Keyboard Consumer Control'
[   430.275] (II) systemd-logind: got fd for /dev/input/event18 13:82 fd 39 paused 0
[   430.275] (**) Logitech Logitech Gaming Keyboard Consumer Control: always reports core events
[   430.275] (**) Option "Device" "/dev/input/event18"
[   430.275] (**) Option "_source" "server/udev"
[   430.276] (II) event18 - Logitech Logitech Gaming Keyboard Consumer Control: is tagged by udev as: Keyboard
[   430.276] (II) event18 - Logitech Logitech Gaming Keyboard Consumer Control: device is a keyboard
[   430.276] (II) event18 - Logitech Logitech Gaming Keyboard Consumer Control: device removed
[   430.276] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:14.0/usb2/2-13/2-13.1/2-13.1:1.1/0003:046D:C221.0009/input/input27/event18"
[   430.276] (II) XINPUT: Adding extended input device "Logitech Logitech Gaming Keyboard Consumer Control" (type: KEYBOARD, id 10)
[   430.276] (**) Option "xkb_model" "fr-latin1"
[   430.276] (**) Option "xkb_layout" "fr"
[   430.277] (II) event18 - Logitech Logitech Gaming Keyboard Consumer Control: is tagged by udev as: Keyboard
[   430.277] (II) event18 - Logitech Logitech Gaming Keyboard Consumer Control: device is a keyboard
[   430.277] (II) config/udev: Adding input device Logitech Gaming Keyboard Gaming Keys (/dev/input/event25)
[   430.277] (**) Logitech Gaming Keyboard Gaming Keys: Applying InputClass "libinput keyboard catchall"
[   430.277] (**) Logitech Gaming Keyboard Gaming Keys: Applying InputClass "system-keyboard"
[   430.277] (II) Using input driver 'libinput' for 'Logitech Gaming Keyboard Gaming Keys'
[   430.331] (II) systemd-logind: got fd for /dev/input/event25 13:89 fd 40 paused 0
[   430.331] (**) Logitech Gaming Keyboard Gaming Keys: always reports core events
[   430.331] (**) Option "Device" "/dev/input/event25"
[   430.331] (**) Option "_source" "server/udev"
[   430.332] (II) event25 - Logitech Gaming Keyboard Gaming Keys: is tagged by udev as: Keyboard
[   430.332] (II) event25 - Logitech Gaming Keyboard Gaming Keys: device is a keyboard
[   430.332] (II) event25 - Logitech Gaming Keyboard Gaming Keys: device removed
[   430.332] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:14.0/usb2/2-13/2-13.4/2-13.4:1.0/0003:046D:C222.000C/input/input32/event25"
[   430.332] (II) XINPUT: Adding extended input device "Logitech Gaming Keyboard Gaming Keys" (type: KEYBOARD, id 11)
[   430.332] (**) Option "xkb_model" "fr-latin1"
[   430.332] (**) Option "xkb_layout" "fr"
[   430.333] (II) event25 - Logitech Gaming Keyboard Gaming Keys: is tagged by udev as: Keyboard
[   430.333] (II) event25 - Logitech Gaming Keyboard Gaming Keys: device is a keyboard
[   430.334] (II) config/udev: Adding input device Logitech Gaming Mouse G502 (/dev/input/event20)
[   430.334] (**) Logitech Gaming Mouse G502: Applying InputClass "libinput pointer catchall"
[   430.334] (II) Using input driver 'libinput' for 'Logitech Gaming Mouse G502'
[   430.388] (II) systemd-logind: got fd for /dev/input/event20 13:84 fd 41 paused 0
[   430.388] (**) Logitech Gaming Mouse G502: always reports core events
[   430.388] (**) Option "Device" "/dev/input/event20"
[   430.388] (**) Option "_source" "server/udev"
[   430.389] (II) event20 - Logitech Gaming Mouse G502: is tagged by udev as: Mouse
[   430.389] (II) event20 - Logitech Gaming Mouse G502: device set to 2400 DPI
[   430.389] (II) event20 - Logitech Gaming Mouse G502: device is a pointer
[   430.389] (II) event20 - Logitech Gaming Mouse G502: device removed
[   430.389] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:14.0/usb2/2-14/2-14:1.0/0003:046D:C332.0006/input/input20/event20"
[   430.389] (II) XINPUT: Adding extended input device "Logitech Gaming Mouse G502" (type: MOUSE, id 12)
[   430.389] (**) Option "AccelerationScheme" "none"
[   430.389] (**) Logitech Gaming Mouse G502: (accel) selected scheme none/0
[   430.389] (**) Logitech Gaming Mouse G502: (accel) acceleration factor: 2.000
[   430.389] (**) Logitech Gaming Mouse G502: (accel) acceleration threshold: 4
[   430.390] (II) event20 - Logitech Gaming Mouse G502: is tagged by udev as: Mouse
[   430.390] (II) event20 - Logitech Gaming Mouse G502: device set to 2400 DPI
[   430.390] (II) event20 - Logitech Gaming Mouse G502: device is a pointer
[   430.390] (II) config/udev: Adding input device Logitech Gaming Mouse G502 (/dev/input/mouse1)
[   430.390] (II) No input driver specified, ignoring this device.
[   430.390] (II) This device may have been added with another device file.
[   430.391] (II) config/udev: Adding input device Logitech Gaming Mouse G502 Keyboard (/dev/input/event21)
[   430.391] (**) Logitech Gaming Mouse G502 Keyboard: Applying InputClass "libinput keyboard catchall"
[   430.391] (**) Logitech Gaming Mouse G502 Keyboard: Applying InputClass "system-keyboard"
[   430.391] (II) Using input driver 'libinput' for 'Logitech Gaming Mouse G502 Keyboard'
[   430.391] (II) systemd-logind: got fd for /dev/input/event21 13:85 fd 42 paused 0
[   430.391] (**) Logitech Gaming Mouse G502 Keyboard: always reports core events
[   430.391] (**) Option "Device" "/dev/input/event21"
[   430.391] (**) Option "_source" "server/udev"
[   430.392] (II) event21 - Logitech Gaming Mouse G502 Keyboard: is tagged by udev as: Keyboard
[   430.392] (II) event21 - Logitech Gaming Mouse G502 Keyboard: device is a keyboard
[   430.392] (II) event21 - Logitech Gaming Mouse G502 Keyboard: device removed
[   430.392] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:14.0/usb2/2-14/2-14:1.1/0003:046D:C332.0007/input/input21/event21"
[   430.392] (II) XINPUT: Adding extended input device "Logitech Gaming Mouse G502 Keyboard" (type: KEYBOARD, id 13)
[   430.392] (**) Option "xkb_model" "fr-latin1"
[   430.392] (**) Option "xkb_layout" "fr"
[   430.393] (II) event21 - Logitech Gaming Mouse G502 Keyboard: is tagged by udev as: Keyboard
[   430.393] (II) event21 - Logitech Gaming Mouse G502 Keyboard: device is a keyboard
[   430.394] (II) config/udev: Adding input device Logitech Gaming Mouse G502 Consumer Control (/dev/input/event23)
[   430.394] (**) Logitech Gaming Mouse G502 Consumer Control: Applying InputClass "libinput keyboard catchall"
[   430.394] (**) Logitech Gaming Mouse G502 Consumer Control: Applying InputClass "system-keyboard"
[   430.394] (II) Using input driver 'libinput' for 'Logitech Gaming Mouse G502 Consumer Control'
[   430.394] (II) systemd-logind: got fd for /dev/input/event23 13:87 fd 43 paused 0
[   430.394] (**) Logitech Gaming Mouse G502 Consumer Control: always reports core events
[   430.394] (**) Option "Device" "/dev/input/event23"
[   430.394] (**) Option "_source" "server/udev"
[   430.395] (II) event23 - Logitech Gaming Mouse G502 Consumer Control: is tagged by udev as: Keyboard
[   430.395] (II) event23 - Logitech Gaming Mouse G502 Consumer Control: device is a keyboard
[   430.395] (II) event23 - Logitech Gaming Mouse G502 Consumer Control: device removed
[   430.395] (II) libinput: Logitech Gaming Mouse G502 Consumer Control: needs a virtual subdevice
[   430.395] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:14.0/usb2/2-14/2-14:1.1/0003:046D:C332.0007/input/input22/event23"
[   430.395] (II) XINPUT: Adding extended input device "Logitech Gaming Mouse G502 Consumer Control" (type: MOUSE, id 14)
[   430.395] (**) Option "AccelerationScheme" "none"
[   430.395] (**) Logitech Gaming Mouse G502 Consumer Control: (accel) selected scheme none/0
[   430.395] (**) Logitech Gaming Mouse G502 Consumer Control: (accel) acceleration factor: 2.000
[   430.395] (**) Logitech Gaming Mouse G502 Consumer Control: (accel) acceleration threshold: 4
[   430.396] (II) event23 - Logitech Gaming Mouse G502 Consumer Control: is tagged by udev as: Keyboard
[   430.396] (II) event23 - Logitech Gaming Mouse G502 Consumer Control: device is a keyboard
[   430.396] (II) config/udev: Adding input device Logitech Gaming Mouse G502 System Control (/dev/input/event24)
[   430.396] (**) Logitech Gaming Mouse G502 System Control: Applying InputClass "libinput keyboard catchall"
[   430.396] (**) Logitech Gaming Mouse G502 System Control: Applying InputClass "system-keyboard"
[   430.396] (II) Using input driver 'libinput' for 'Logitech Gaming Mouse G502 System Control'
[   430.397] (II) systemd-logind: got fd for /dev/input/event24 13:88 fd 44 paused 0
[   430.397] (**) Logitech Gaming Mouse G502 System Control: always reports core events
[   430.397] (**) Option "Device" "/dev/input/event24"
[   430.397] (**) Option "_source" "server/udev"
[   430.398] (II) event24 - Logitech Gaming Mouse G502 System Control: is tagged by udev as: Keyboard
[   430.398] (II) event24 - Logitech Gaming Mouse G502 System Control: device is a keyboard
[   430.398] (II) event24 - Logitech Gaming Mouse G502 System Control: device removed
[   430.398] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:14.0/usb2/2-14/2-14:1.1/0003:046D:C332.0007/input/input23/event24"
[   430.398] (II) XINPUT: Adding extended input device "Logitech Gaming Mouse G502 System Control" (type: KEYBOARD, id 15)
[   430.398] (**) Option "xkb_model" "fr-latin1"
[   430.398] (**) Option "xkb_layout" "fr"
[   430.399] (II) event24 - Logitech Gaming Mouse G502 System Control: is tagged by udev as: Keyboard
[   430.399] (II) event24 - Logitech Gaming Mouse G502 System Control: device is a keyboard
[   430.399] (II) config/udev: Adding input device HDA Intel PCH Front Mic (/dev/input/event11)
[   430.399] (II) No input driver specified, ignoring this device.
[   430.399] (II) This device may have been added with another device file.
[   430.399] (II) config/udev: Adding input device HDA Intel PCH Rear Mic (/dev/input/event12)
[   430.399] (II) config/udev: Adding input device HDA Intel PCH Line (/dev/input/event13)
[   430.400] (II) config/udev: Adding input device HDA Intel PCH Line Out Front (/dev/input/event14)
[   430.400] (II) No input driver specified, ignoring this device.
[   430.400] (II) This device may have been added with another device file.
[   430.400] (II) config/udev: Adding input device HDA Intel PCH Line Out Surround (/dev/input/event15)
[   430.400] (II) config/udev: Adding input device HDA Intel PCH Line Out CLFE (/dev/input/event16)
[   430.400] (II) config/udev: Adding input device HDA Intel PCH Front Headphone (/dev/input/event17)
[   430.400] (II) config/udev: Adding input device Eee PC WMI hotkeys (/dev/input/event3)
[   430.400] (**) Eee PC WMI hotkeys: Applying InputClass "libinput keyboard catchall"
[   430.400] (**) Eee PC WMI hotkeys: Applying InputClass "system-keyboard"
[   430.400] (II) Using input driver 'libinput' for 'Eee PC WMI hotkeys'
[   430.401] (II) systemd-logind: got fd for /dev/input/event3 13:67 fd 45 paused 0
[   430.401] (**) Eee PC WMI hotkeys: always reports core events
[   430.401] (**) Option "Device" "/dev/input/event3"
[   430.401] (**) Option "_source" "server/udev"
[   430.401] (II) event3  - Eee PC WMI hotkeys: is tagged by udev as: Keyboard
[   430.401] (II) event3  - Eee PC WMI hotkeys: device is a keyboard
[   430.402] (II) event3  - Eee PC WMI hotkeys: device removed
[   430.402] (**) Option "config_info" "udev:/sys/devices/platform/eeepc-wmi/input/input3/event3"
[   430.402] (II) XINPUT: Adding extended input device "Eee PC WMI hotkeys" (type: KEYBOARD, id 16)
[   430.402] (**) Option "xkb_model" "fr-latin1"
[   430.402] (**) Option "xkb_layout" "fr"
[   430.402] (II) event3  - Eee PC WMI hotkeys: is tagged by udev as: Keyboard
[   430.402] (II) event3  - Eee PC WMI hotkeys: device is a keyboard
[   430.402] (II) config/udev: Adding input device PC Speaker (/dev/input/event2)
[   430.402] (II) No input driver specified, ignoring this device.
[   430.402] (II) This device may have been added with another device file.
[   430.405] (**) Valve Software Steam Controller: Applying InputClass "libinput pointer catchall"
[   430.405] (**) Valve Software Steam Controller: Applying InputClass "libinput keyboard catchall"
[   430.405] (**) Valve Software Steam Controller: Applying InputClass "system-keyboard"
[   430.405] (II) Using input driver 'libinput' for 'Valve Software Steam Controller'
[   430.405] (II) systemd-logind: returning pre-existing fd for /dev/input/event19 13:83
[   430.405] (**) Valve Software Steam Controller: always reports core events
[   430.405] (**) Option "Device" "/dev/input/event19"
[   430.405] (**) Option "_source" "_driver/libinput"
[   430.405] (II) libinput: Valve Software Steam Controller: is a virtual subdevice
[   430.405] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:14.0/usb2/2-10/2-10:1.0/0003:28DE:1142.0001/input/input29/event19"
[   430.405] (II) XINPUT: Adding extended input device "Valve Software Steam Controller" (type: KEYBOARD, id 17)
[   430.405] (**) Option "xkb_model" "fr-latin1"
[   430.405] (**) Option "xkb_layout" "fr"
[   430.405] (**) Logitech Gaming Mouse G502 Consumer Control: Applying InputClass "libinput keyboard catchall"
[   430.405] (**) Logitech Gaming Mouse G502 Consumer Control: Applying InputClass "system-keyboard"
[   430.405] (II) Using input driver 'libinput' for 'Logitech Gaming Mouse G502 Consumer Control'
[   430.405] (II) systemd-logind: returning pre-existing fd for /dev/input/event23 13:87
[   430.405] (**) Logitech Gaming Mouse G502 Consumer Control: always reports core events
[   430.405] (**) Option "Device" "/dev/input/event23"
[   430.405] (II) libinput: Logitech Gaming Mouse G502 Consumer Control: is a virtual subdevice
[   430.405] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:14.0/usb2/2-14/2-14:1.1/0003:046D:C332.0007/input/input22/event23"
[   430.405] (II) XINPUT: Adding extended input device "Logitech Gaming Mouse G502 Consumer Control" (type: KEYBOARD, id 18)
[   430.405] (--) NVIDIA(GPU-0): Idek Iiyama PLG2773H (DFP-2): connected
[   430.405] (--) NVIDIA(GPU-0): Idek Iiyama PLG2773H (DFP-2): Internal DisplayPort
[   430.405] (--) NVIDIA(GPU-0): Idek Iiyama PLG2773H (DFP-2): 960.0 MHz maximum pixel clock
[   431.475] (--) NVIDIA(GPU-0): Idek Iiyama PLG2773H (DFP-2): connected
[   431.475] (--) NVIDIA(GPU-0): Idek Iiyama PLG2773H (DFP-2): Internal DisplayPort
[   431.475] (--) NVIDIA(GPU-0): Idek Iiyama PLG2773H (DFP-2): 960.0 MHz maximum pixel clock
[   446.019] (--) NVIDIA(GPU-0): CRT-0: disconnected
[   446.019] (--) NVIDIA(GPU-0): CRT-0: 400.0 MHz maximum pixel clock
[   446.023] (--) NVIDIA(GPU-0): DFP-0: disconnected
[   446.023] (--) NVIDIA(GPU-0): DFP-0: Internal TMDS
[   446.023] (--) NVIDIA(GPU-0): DFP-0: 330.0 MHz maximum pixel clock
[   446.057] (--) NVIDIA(GPU-0): HPN HP ENVY 27s (DFP-1): connected
[   446.057] (--) NVIDIA(GPU-0): HPN HP ENVY 27s (DFP-1): Internal TMDS
[   446.057] (--) NVIDIA(GPU-0): HPN HP ENVY 27s (DFP-1): 600.0 MHz maximum pixel clock
[   446.057] (--) NVIDIA(GPU-0): Idek Iiyama PLG2773H (DFP-2): connected
[   446.057] (--) NVIDIA(GPU-0): Idek Iiyama PLG2773H (DFP-2): Internal DisplayPort
[   446.057] (--) NVIDIA(GPU-0): Idek Iiyama PLG2773H (DFP-2): 960.0 MHz maximum pixel clock
[   446.058] (--) NVIDIA(GPU-0): DFP-3: disconnected
[   446.058] (--) NVIDIA(GPU-0): DFP-3: Internal TMDS
[   446.058] (--) NVIDIA(GPU-0): DFP-3: 165.0 MHz maximum pixel clock
[   446.058] (--) NVIDIA(GPU-0): DFP-4: disconnected
[   446.058] (--) NVIDIA(GPU-0): DFP-4: Internal TMDS
[   446.058] (--) NVIDIA(GPU-0): DFP-4: 330.0 MHz maximum pixel clock
[   446.157] (II) NVIDIA(0): Setting mode "HDMI-0: 3840x2160_60 @3840x2160 +0+0 {ViewPortIn=3840x2160, ViewPortOut=3840x2160+0+0}, DP-0: nvidia-auto-select @1920x1080 +3840+0 {ViewPortIn=1920x1080, ViewPortOut=1920x1080+0+0}"
[   448.560] (--) NVIDIA(GPU-0): CRT-0: disconnected
[   448.560] (--) NVIDIA(GPU-0): CRT-0: 400.0 MHz maximum pixel clock
[   448.564] (--) NVIDIA(GPU-0): DFP-0: disconnected
[   448.564] (--) NVIDIA(GPU-0): DFP-0: Internal TMDS
[   448.564] (--) NVIDIA(GPU-0): DFP-0: 330.0 MHz maximum pixel clock
[   448.599] (--) NVIDIA(GPU-0): HPN HP ENVY 27s (DFP-1): connected
[   448.599] (--) NVIDIA(GPU-0): HPN HP ENVY 27s (DFP-1): Internal TMDS
[   448.599] (--) NVIDIA(GPU-0): HPN HP ENVY 27s (DFP-1): 600.0 MHz maximum pixel clock
[   448.599] (--) NVIDIA(GPU-0): Idek Iiyama PLG2773H (DFP-2): connected
[   448.599] (--) NVIDIA(GPU-0): Idek Iiyama PLG2773H (DFP-2): Internal DisplayPort
[   448.599] (--) NVIDIA(GPU-0): Idek Iiyama PLG2773H (DFP-2): 960.0 MHz maximum pixel clock
[   448.600] (--) NVIDIA(GPU-0): DFP-3: disconnected
[   448.600] (--) NVIDIA(GPU-0): DFP-3: Internal TMDS
[   448.600] (--) NVIDIA(GPU-0): DFP-3: 165.0 MHz maximum pixel clock
[   448.600] (--) NVIDIA(GPU-0): DFP-4: disconnected
[   448.600] (--) NVIDIA(GPU-0): DFP-4: Internal TMDS
[   448.600] (--) NVIDIA(GPU-0): DFP-4: 330.0 MHz maximum pixel clock
[   725.919] (EE) client bug: timer event20 debounce short: scheduled expiry is in the past (-2ms), your system is too slow
[  1795.062] (--) NVIDIA(GPU-0): CRT-0: disconnected
[  1795.062] (--) NVIDIA(GPU-0): CRT-0: 400.0 MHz maximum pixel clock
[  1795.066] (--) NVIDIA(GPU-0): DFP-0: disconnected
[  1795.066] (--) NVIDIA(GPU-0): DFP-0: Internal TMDS
[  1795.066] (--) NVIDIA(GPU-0): DFP-0: 330.0 MHz maximum pixel clock
[  1795.101] (--) NVIDIA(GPU-0): HPN HP ENVY 27s (DFP-1): connected
[  1795.101] (--) NVIDIA(GPU-0): HPN HP ENVY 27s (DFP-1): Internal TMDS
[  1795.101] (--) NVIDIA(GPU-0): HPN HP ENVY 27s (DFP-1): 600.0 MHz maximum pixel clock
[  1795.101] (--) NVIDIA(GPU-0): Idek Iiyama PLG2773H (DFP-2): connected
[  1795.101] (--) NVIDIA(GPU-0): Idek Iiyama PLG2773H (DFP-2): Internal DisplayPort
[  1795.101] (--) NVIDIA(GPU-0): Idek Iiyama PLG2773H (DFP-2): 960.0 MHz maximum pixel clock
[  1795.102] (--) NVIDIA(GPU-0): DFP-3: disconnected
[  1795.102] (--) NVIDIA(GPU-0): DFP-3: Internal TMDS
[  1795.102] (--) NVIDIA(GPU-0): DFP-3: 165.0 MHz maximum pixel clock
[  1795.102] (--) NVIDIA(GPU-0): DFP-4: disconnected
[  1795.102] (--) NVIDIA(GPU-0): DFP-4: Internal TMDS
[  1795.102] (--) NVIDIA(GPU-0): DFP-4: 330.0 MHz maximum pixel clock
[  1795.107] (--) NVIDIA(GPU-0): CRT-0: disconnected
[  1795.107] (--) NVIDIA(GPU-0): CRT-0: 400.0 MHz maximum pixel clock
[  1795.111] (--) NVIDIA(GPU-0): DFP-0: disconnected
[  1795.111] (--) NVIDIA(GPU-0): DFP-0: Internal TMDS
[  1795.111] (--) NVIDIA(GPU-0): DFP-0: 330.0 MHz maximum pixel clock
[  1795.145] (--) NVIDIA(GPU-0): HPN HP ENVY 27s (DFP-1): connected
[  1795.145] (--) NVIDIA(GPU-0): HPN HP ENVY 27s (DFP-1): Internal TMDS
[  1795.145] (--) NVIDIA(GPU-0): HPN HP ENVY 27s (DFP-1): 600.0 MHz maximum pixel clock
[  1795.146] (--) NVIDIA(GPU-0): Idek Iiyama PLG2773H (DFP-2): connected
[  1795.146] (--) NVIDIA(GPU-0): Idek Iiyama PLG2773H (DFP-2): Internal DisplayPort
[  1795.146] (--) NVIDIA(GPU-0): Idek Iiyama PLG2773H (DFP-2): 960.0 MHz maximum pixel clock
[  1795.147] (--) NVIDIA(GPU-0): DFP-3: disconnected
[  1795.147] (--) NVIDIA(GPU-0): DFP-3: Internal TMDS
[  1795.147] (--) NVIDIA(GPU-0): DFP-3: 165.0 MHz maximum pixel clock
[  1795.147] (--) NVIDIA(GPU-0): DFP-4: disconnected
[  1795.147] (--) NVIDIA(GPU-0): DFP-4: Internal TMDS
[  1795.147] (--) NVIDIA(GPU-0): DFP-4: 330.0 MHz maximum pixel clock
[  1799.188] (--) NVIDIA(GPU-0): CRT-0: disconnected
[  1799.188] (--) NVIDIA(GPU-0): CRT-0: 400.0 MHz maximum pixel clock
[  1799.194] (--) NVIDIA(GPU-0): DFP-0: disconnected
[  1799.194] (--) NVIDIA(GPU-0): DFP-0: Internal TMDS
[  1799.194] (--) NVIDIA(GPU-0): DFP-0: 330.0 MHz maximum pixel clock
[  1799.228] (--) NVIDIA(GPU-0): HPN HP ENVY 27s (DFP-1): connected
[  1799.228] (--) NVIDIA(GPU-0): HPN HP ENVY 27s (DFP-1): Internal TMDS
[  1799.228] (--) NVIDIA(GPU-0): HPN HP ENVY 27s (DFP-1): 600.0 MHz maximum pixel clock
[  1799.228] (--) NVIDIA(GPU-0): Idek Iiyama PLG2773H (DFP-2): connected
[  1799.228] (--) NVIDIA(GPU-0): Idek Iiyama PLG2773H (DFP-2): Internal DisplayPort
[  1799.228] (--) NVIDIA(GPU-0): Idek Iiyama PLG2773H (DFP-2): 960.0 MHz maximum pixel clock
[  1799.229] (--) NVIDIA(GPU-0): DFP-3: disconnected
[  1799.229] (--) NVIDIA(GPU-0): DFP-3: Internal TMDS
[  1799.229] (--) NVIDIA(GPU-0): DFP-3: 165.0 MHz maximum pixel clock
[  1799.229] (--) NVIDIA(GPU-0): DFP-4: disconnected
[  1799.229] (--) NVIDIA(GPU-0): DFP-4: Internal TMDS
[  1799.229] (--) NVIDIA(GPU-0): DFP-4: 330.0 MHz maximum pixel clock
[  1799.247] (--) NVIDIA(GPU-0): CRT-0: disconnected
[  1799.247] (--) NVIDIA(GPU-0): CRT-0: 400.0 MHz maximum pixel clock
[  1799.252] (--) NVIDIA(GPU-0): DFP-0: disconnected
[  1799.252] (--) NVIDIA(GPU-0): DFP-0: Internal TMDS
[  1799.252] (--) NVIDIA(GPU-0): DFP-0: 330.0 MHz maximum pixel clock
[  1799.286] (--) NVIDIA(GPU-0): HPN HP ENVY 27s (DFP-1): connected
[  1799.286] (--) NVIDIA(GPU-0): HPN HP ENVY 27s (DFP-1): Internal TMDS
[  1799.286] (--) NVIDIA(GPU-0): HPN HP ENVY 27s (DFP-1): 600.0 MHz maximum pixel clock
[  1799.286] (--) NVIDIA(GPU-0): Idek Iiyama PLG2773H (DFP-2): connected
[  1799.286] (--) NVIDIA(GPU-0): Idek Iiyama PLG2773H (DFP-2): Internal DisplayPort
[  1799.286] (--) NVIDIA(GPU-0): Idek Iiyama PLG2773H (DFP-2): 960.0 MHz maximum pixel clock
[  1799.287] (--) NVIDIA(GPU-0): DFP-3: disconnected
[  1799.287] (--) NVIDIA(GPU-0): DFP-3: Internal TMDS
[  1799.287] (--) NVIDIA(GPU-0): DFP-3: 165.0 MHz maximum pixel clock
[  1799.287] (--) NVIDIA(GPU-0): DFP-4: disconnected
[  1799.287] (--) NVIDIA(GPU-0): DFP-4: Internal TMDS
[  1799.287] (--) NVIDIA(GPU-0): DFP-4: 330.0 MHz maximum pixel clock
[  1799.293] (--) NVIDIA(GPU-0): CRT-0: disconnected
[  1799.293] (--) NVIDIA(GPU-0): CRT-0: 400.0 MHz maximum pixel clock
[  1799.297] (--) NVIDIA(GPU-0): DFP-0: disconnected
[  1799.297] (--) NVIDIA(GPU-0): DFP-0: Internal TMDS
[  1799.297] (--) NVIDIA(GPU-0): DFP-0: 330.0 MHz maximum pixel clock
[  1799.331] (--) NVIDIA(GPU-0): HPN HP ENVY 27s (DFP-1): connected
[  1799.331] (--) NVIDIA(GPU-0): HPN HP ENVY 27s (DFP-1): Internal TMDS
[  1799.331] (--) NVIDIA(GPU-0): HPN HP ENVY 27s (DFP-1): 600.0 MHz maximum pixel clock
[  1799.332] (--) NVIDIA(GPU-0): Idek Iiyama PLG2773H (DFP-2): connected
[  1799.332] (--) NVIDIA(GPU-0): Idek Iiyama PLG2773H (DFP-2): Internal DisplayPort
[  1799.332] (--) NVIDIA(GPU-0): Idek Iiyama PLG2773H (DFP-2): 960.0 MHz maximum pixel clock
[  1799.333] (--) NVIDIA(GPU-0): DFP-3: disconnected
[  1799.333] (--) NVIDIA(GPU-0): DFP-3: Internal TMDS
[  1799.333] (--) NVIDIA(GPU-0): DFP-3: 165.0 MHz maximum pixel clock
[  1799.333] (--) NVIDIA(GPU-0): DFP-4: disconnected
[  1799.333] (--) NVIDIA(GPU-0): DFP-4: Internal TMDS
[  1799.333] (--) NVIDIA(GPU-0): DFP-4: 330.0 MHz maximum pixel clock
*** /etc/X11/xorg.conf
*** ls: -rw-r--r-- 1 root root 1619 2020-07-01 22:33:05.360666582 +0200 /etc/X11/xorg.conf
# nvidia-settings: X configuration file generated by nvidia-settings
# nvidia-settings:  version 440.82
Section "ServerLayout"
    Identifier     "Layout0"
    Screen      0  "Screen0" 0 0
    InputDevice    "Keyboard0" "CoreKeyboard"
    InputDevice    "Mouse0" "CorePointer"
EndSection
Section "Files"
EndSection
Section "InputDevice"
    # generated from default
    Identifier     "Mouse0"
    Driver         "mouse"
    Option         "Protocol" "auto"
    Option         "Device" "/dev/psaux"
    Option         "Emulate3Buttons" "no"
    Option         "ZAxisMapping" "4 5"
EndSection
    Identifier     "Keyboard0"
    Driver         "kbd"
EndSection
Section "Monitor"
    # HorizSync source: edid, VertRefresh source: edid
    Identifier     "Monitor0"
    VendorName     "Unknown"
    ModelName      "HPN HP ENVY 27s"
    HorizSync       135.0 - 135.0
    VertRefresh     40.0 - 60.0
    Option         "DPMS"
EndSection
Section "Device"
    Identifier     "Device0"
    Driver         "nvidia"
    VendorName     "NVIDIA Corporation"
    BoardName      "GeForce GTX 970"
EndSection
Section "Screen"
    Identifier     "Screen0"
    Device         "Device0"
    Monitor        "Monitor0"
    DefaultDepth    24
    Option         "Stereo" "0"
    Option         "nvidiaXineramaInfoOrder" "DFP-2"
    Option         "metamodes" ""
    Option         "SLI" "Off"
    SubSection     "Display"
        Depth       24
    EndSubSection
EndSection
*** /etc/X11/xorg.conf.d/00-keyboard.conf
*** ls: -rw-r--r-- 1 root root 349 2020-02-15 10:41:49.739203959 +0100 /etc/X11/xorg.conf.d/00-keyboard.conf
# Written by systemd-localed(8), read by systemd-localed and Xorg. It's
# probably wise not to edit this file manually. Use localectl(1) to
# instruct systemd-localed to update it.
Section "InputClass"
        Identifier "system-keyboard"
        MatchIsKeyboard "on"
        Option "XkbLayout" "fr"
        Option "XkbModel" "fr-latin1"
EndSection
*** /etc/X11/xorg.conf.d/01-nvidia.conf
*** ls: -rw-r--r-- 1 root root 1673 2020-02-28 19:45:29.708346342 +0100 /etc/X11/xorg.conf.d/01-nvidia.conf
# nvidia-settings:  version 440.59
EndSection
Section "Files"
EndSection
    Identifier     "Mouse0"
    Driver         "mouse"
EndSection
    Driver         "kbd"
EndSection
Section "Monitor"
    Option         "DPMS"
EndSection
Section "Device"
    Driver         "nvidia"
EndSection
Section "Screen"
    Device         "Device0"
    Monitor        "Monitor0"
    DefaultDepth    24
    Option         "Stereo" "0"
    Option         "metamodes" "HDMI-0: 3840x2160_60 +0+0, DP-0: 1920x1080_144 +3840+0"
    Option         "SLI" "Off"
        Depth       24
    EndSubSection
EndSection
*** /usr/share/X11/xorg.conf.d/10-nvidia-drm-outputclass.conf
*** ls: -rw-r--r-- 1 root root 227 2020-07-09 18:06:25.000000000 +0200 /usr/share/X11/xorg.conf.d/10-nvidia-drm-outputclass.conf
Section "OutputClass"
    Identifier "nvidia"
    MatchDriver "nvidia-drm"
    Driver "nvidia"
    ModulePath "/usr/lib/nvidia/xorg"
    ModulePath "/usr/lib/xorg/modules"
EndSection
*** /usr/share/X11/xorg.conf.d/10-quirks.conf
*** ls: -rw-r--r-- 1 root root 1350 2020-07-31 18:00:57.000000000 +0200 /usr/share/X11/xorg.conf.d/10-quirks.conf
# Collection of quirks and blacklist/whitelists for specific devices.
# Accelerometer device, posts data through ABS_X/ABS_Y, making X unusable
# http://bugs.freedesktop.org/show_bug.cgi?id=22442
        Identifier "ThinkPad HDAPS accelerometer blacklist"
        MatchProduct "ThinkPad HDAPS accelerometer data"
        Option "Ignore" "on"
EndSection
# https://bugzilla.redhat.com/show_bug.cgi?id=523914
# Mouse does not move in PV Xen guest
# Explicitly tell evdev to not ignore the absolute axes.
        Identifier "Xen Virtual Pointer axis blacklist"
        MatchProduct "Xen Virtual Pointer"
        Option "IgnoreAbsoluteAxes" "off"
        Option "IgnoreRelativeAxes" "off"
EndSection
# https://bugs.freedesktop.org/show_bug.cgi?id=55867
# Bug 55867 - Doesn't know how to tag XI_TRACKBALL
        Identifier "Tag trackballs as XI_TRACKBALL"
        MatchProduct "trackball"
        MatchDriver "evdev"
        Option "TypeName" "TRACKBALL"
EndSection
# https://bugs.freedesktop.org/show_bug.cgi?id=62831
# Bug 62831 - Mionix Naos 5000 mouse detected incorrectly
        Identifier "Tag Mionix Naos 5000 mouse XI_MOUSE"
        MatchProduct "La-VIEW Technology Naos 5000 Mouse"
        MatchDriver "evdev"
        Option "TypeName" "MOUSE"
EndSection
*** /usr/share/X11/xorg.conf.d/40-libinput.conf
*** ls: -rw-r--r-- 1 root root 1429 2020-05-19 11:45:08.000000000 +0200 /usr/share/X11/xorg.conf.d/40-libinput.conf
# Match on all types of devices but joysticks
# If you want to configure your devices, do not copy this file.
# Instead, use a config snippet that contains something like this:
# Section "InputClass"
#   Identifier "something or other"
#   MatchDriver "libinput"
#   MatchIsTouchpad "on"
#   ... other Match directives ...
#   Option "someoption" "value"
# EndSection
# This applies the option any libinput device also matched by the other
# directives. See the xorg.conf(5) man page for more info on
# matching devices.
        Identifier "libinput pointer catchall"
        MatchIsPointer "on"
        MatchDevicePath "/dev/input/event*"
        Driver "libinput"
EndSection
        Identifier "libinput keyboard catchall"
        Driver "libinput"
EndSection
        Identifier "libinput touchpad catchall"
        Driver "libinput"
EndSection
        Identifier "libinput touchscreen catchall"
        MatchIsTouchscreen "on"
        Driver "libinput"
EndSection
        Identifier "libinput tablet catchall"
        MatchIsTablet "on"
        Driver "libinput"
EndSection
*** /var/log/Xorg.0.log.old
*** ls: -rw-r--r-- 1 root user 65996 2020-08-20 10:06:38.847926063 +0200 /var/log/Xorg.0.log.old
[    25.469] (WW) Failed to open protocol names file lib/xorg/protocol.txt
[    25.470]
[    25.472] Build Operating System: Linux Arch Linux
[    25.472] Current Operating System: Linux localhost 5.7.10-arch1-1 #1 SMP PREEMPT Wed, 22 Jul 2020 19:57:42 +0000 x86_64
[    25.473] Kernel command line: root=UUID=6c37d730-4b14-4479-8554-92d2e75478d5 rw initrd=\initramfs-linux.img
[    25.474] Build Date: 05 May 2020  05:08:17AM
[    25.475]
[    25.476] Current version of pixman: 0.40.0
[    25.477] 	Before reporting problems, check http://wiki.x.org
[    25.477] Markers: (--) probed, (**) from config file, (==) default setting,
[    25.480] (==) Log file: "/var/log/Xorg.0.log", Time: Fri Jul 24 19:38:27 2020
[    25.483] (==) Using config file: "/etc/X11/xorg.conf"
[    25.484] (==) Using config directory: "/etc/X11/xorg.conf.d"
[    25.484] (==) Using system config directory "/usr/share/X11/xorg.conf.d"
[    25.486] (==) ServerLayout "Layout0"
[    25.486] (**) |-->Screen "Screen0" (0)
[    25.486] (**) |   |-->Monitor "Monitor0"
[    25.486] (**) |   |-->Device "Device0"
[    25.486] (**) |   |-->GPUDevice "Device0"
[    25.487] (**) |-->Input Device "Keyboard0"
[    25.487] (**) |-->Input Device "Mouse0"
[    25.487] (**) Option "Xinerama" "0"
[    25.487] (==) Automatically adding devices
[    25.487] (==) Automatically enabling devices
[    25.487] (==) Automatically adding GPU devices
[    25.487] (==) Automatically binding GPU devices
[    25.487] (==) Max clients allowed: 256, resource mask: 0x1fffff
[    25.488] (WW) `fonts.dir' not found (or not valid) in "/usr/share/fonts/OTF".
[    25.488] 	Entry deleted from font path.
[    25.488] 	(Run 'mkfontdir' on "/usr/share/fonts/OTF").
[    25.488] (WW) The directory "/usr/share/fonts/Type1" does not exist.
[    25.488] (WW) The directory "/usr/share/fonts/100dpi" does not exist.
[    25.488] (WW) The directory "/usr/share/fonts/75dpi" does not exist.
[    25.488] (==) FontPath set to:
[    25.488] (==) ModulePath set to "/usr/lib/xorg/modules"
[    25.488] (WW) Hotplugging is on, devices using drivers 'kbd', 'mouse' or 'vmmouse' will be disabled.
[    25.488] (WW) Disabling Keyboard0
[    25.488] (WW) Disabling Mouse0
[    25.488] (II) Module ABI versions:
[    25.488] 	X.Org ANSI C Emulation: 0.4
[    25.488] 	X.Org Video Driver: 24.1
[    25.488] 	X.Org XInput driver : 24.1
[    25.488] 	X.Org Server Extension : 10.0
[    25.488] (++) using VT number 1
[    25.489] (II) systemd-logind: took control of session /org/freedesktop/login1/session/_31
[    25.489] (II) xfree86: Adding drm device (/dev/dri/card0)
[    25.490] (II) systemd-logind: got fd for /dev/dri/card0 226:0 fd 10 paused 0
[    25.490] (**) OutputClass "nvidia" ModulePath extended to "/usr/lib/nvidia/xorg,/usr/lib/xorg/modules,/usr/lib/xorg/modules"
[    25.491] (--) PCI:*(1@0:0:0) 10de:13c2:1462:3160 rev 161, Mem @ 0xde000000/16777216, 0xc0000000/268435456, 0xd0000000/33554432, I/O @ 0x0000e000/128, BIOS @ 0x????????/131072
[    25.491] (WW) Open ACPI failed (/var/run/acpid.socket) (No such file or directory)
[    25.491] (II) LoadModule: "glx"
[    25.492] (II) Loading /usr/lib/xorg/modules/extensions/libglx.so
[    25.501] (II) Module glx: vendor="X.Org Foundation"
[    25.501] 	compiled for 1.20.8, module version = 1.0.0
[    25.501] 	ABI class: X.Org Server Extension, version 10.0
[    25.501] (II) LoadModule: "nvidia"
[    25.501] (II) Loading /usr/lib/xorg/modules/drivers/nvidia_drv.so
[    25.508] (II) Module nvidia: vendor="NVIDIA Corporation"
[    25.508] 	compiled for 1.6.99.901, module version = 1.0.0
[    25.508] 	Module class: X.Org Video Driver
[    25.509] (II) NVIDIA dlloader X Driver  450.57  Sun Jul  5 14:40:23 UTC 2020
[    25.509] (II) NVIDIA Unified Driver for all Supported NVIDIA GPUs
[    25.510] (II) systemd-logind: releasing fd for 226:0
[    25.511] (II) Loading sub module "fb"
[    25.511] (II) LoadModule: "fb"
[    25.511] (II) Loading /usr/lib/xorg/modules/libfb.so
[    25.512] (II) Module fb: vendor="X.Org Foundation"
[    25.512] 	compiled for 1.20.8, module version = 1.0.0
[    25.512] 	ABI class: X.Org ANSI C Emulation, version 0.4
[    25.512] (II) Loading sub module "wfb"
[    25.512] (II) LoadModule: "wfb"
[    25.512] (II) Loading /usr/lib/xorg/modules/libwfb.so
[    25.513] (II) Module wfb: vendor="X.Org Foundation"
[    25.513] 	compiled for 1.20.8, module version = 1.0.0
[    25.513] 	ABI class: X.Org ANSI C Emulation, version 0.4
[    25.513] (II) Loading sub module "ramdac"
[    25.513] (II) LoadModule: "ramdac"
[    25.513] (II) Module "ramdac" already built-in
[    25.515] (**) NVIDIA(0): Depth 24, (--) framebuffer bpp 32
[    25.515] (==) NVIDIA(0): RGB weight 888
[    25.515] (==) NVIDIA(0): Default visual is TrueColor
[    25.515] (==) NVIDIA(0): Using gamma correction (1.0, 1.0, 1.0)
[    25.516] (II) Applying OutputClass "nvidia" options to /dev/dri/card0
[    25.516] (**) NVIDIA(0): Option "Stereo" "0"
[    25.516] (**) NVIDIA(0): Option "nvidiaXineramaInfoOrder" "DFP-1"
[    25.516] (**) NVIDIA(0): Option "SLI" "Off"
[    25.516] (**) NVIDIA(0): Option "MultiGPU" "Off"
[    25.516] (**) NVIDIA(0): Option "BaseMosaic" "off"
[    25.516] (**) NVIDIA(0): Option "AllowEmptyInitialConfiguration"
[    25.516] (**) NVIDIA(0): Stereo disabled by request
[    25.516] (**) NVIDIA(0): NVIDIA SLI disabled.
[    25.516] (**) NVIDIA(0): NVIDIA Multi-GPU disabled.
[    25.516] (**) NVIDIA(0): Option "MetaModes" "HDMI-0: 3840x2160_60 +0+0, DP-0: 1920x1080_144 +3840+0"
[    25.516] (**) NVIDIA(0): Enabling 2D acceleration
[    25.516] (II) Loading sub module "glxserver_nvidia"
[    25.516] (II) LoadModule: "glxserver_nvidia"
[    25.516] (II) Loading /usr/lib/nvidia/xorg/libglxserver_nvidia.so
[    25.581] (II) Module glxserver_nvidia: vendor="NVIDIA Corporation"
[    25.581] 	compiled for 1.6.99.901, module version = 1.0.0
[    25.581] 	Module class: X.Org Server Extension
[    25.581] (II) NVIDIA GLX Module  450.57  Sun Jul  5 14:43:44 UTC 2020
[    25.583] (II) NVIDIA: The X server supports PRIME Render Offload.
[    26.318] (--) NVIDIA(0): Valid display device(s) on GPU-0 at PCI:1:0:0
[    26.318] (--) NVIDIA(0):     CRT-0
[    26.318] (--) NVIDIA(0):     DFP-0
[    26.318] (--) NVIDIA(0):     DFP-1 (boot)
[    26.318] (--) NVIDIA(0):     DFP-2
[    26.318] (--) NVIDIA(0):     DFP-3
[    26.318] (--) NVIDIA(0):     DFP-4
[    26.319] (II) NVIDIA(0): NVIDIA GPU GeForce GTX 970 (GM204-A) at PCI:1:0:0 (GPU-0)
[    26.319] (--) NVIDIA(0): Memory: 4194304 kBytes
[    26.319] (--) NVIDIA(0): VideoBIOS: 84.04.2f.00.f1
[    26.319] (II) NVIDIA(0): Detected PCI Express Link width: 16X
[    26.323] (--) NVIDIA(GPU-0): CRT-0: disconnected
[    26.323] (--) NVIDIA(GPU-0): CRT-0: 400.0 MHz maximum pixel clock
[    26.327] (--) NVIDIA(GPU-0): DFP-0: disconnected
[    26.327] (--) NVIDIA(GPU-0): DFP-0: Internal TMDS
[    26.327] (--) NVIDIA(GPU-0): DFP-0: 330.0 MHz maximum pixel clock
[    26.358] (--) NVIDIA(GPU-0): HPN HP ENVY 27s (DFP-1): connected
[    26.358] (--) NVIDIA(GPU-0): HPN HP ENVY 27s (DFP-1): Internal TMDS
[    26.358] (--) NVIDIA(GPU-0): HPN HP ENVY 27s (DFP-1): 600.0 MHz maximum pixel clock
[    26.358] (--) NVIDIA(GPU-0): Idek Iiyama PLG2773H (DFP-2): connected
[    26.358] (--) NVIDIA(GPU-0): Idek Iiyama PLG2773H (DFP-2): Internal DisplayPort
[    26.358] (--) NVIDIA(GPU-0): Idek Iiyama PLG2773H (DFP-2): 960.0 MHz maximum pixel clock
[    26.359] (--) NVIDIA(GPU-0): DFP-3: disconnected
[    26.359] (--) NVIDIA(GPU-0): DFP-3: Internal TMDS
[    26.359] (--) NVIDIA(GPU-0): DFP-3: 165.0 MHz maximum pixel clock
[    26.359] (--) NVIDIA(GPU-0): DFP-4: disconnected
[    26.359] (--) NVIDIA(GPU-0): DFP-4: Internal TMDS
[    26.359] (--) NVIDIA(GPU-0): DFP-4: 330.0 MHz maximum pixel clock
[    26.362] (EE) NVIDIA(GPU-0): Unable to add conservative default mode "nvidia-auto-select".
[    26.362] (EE) NVIDIA(GPU-0): Unable to add "nvidia-auto-select" mode to ModePool.
[    26.362] (II) NVIDIA(0): Validated MetaModes:
[    26.362] (II) NVIDIA(0):     "HDMI-0:3840x2160_60+0+0,DP-0:1920x1080_144+3840+0"
[    26.362] (II) NVIDIA(0): Virtual screen size determined to be 3840 x 2160
[    26.365] (--) NVIDIA(0): DPI set to (162, 161); computed from "UseEdidDpi" X config
[    26.365] (--) NVIDIA(0):     option
[    26.366] (II) NVIDIA: Using 6144.00 MB of virtual memory for indirect memory
[    26.366] (II) NVIDIA:     access.
[    26.367] (II) NVIDIA(0): ACPI: failed to connect to the ACPI event daemon; the daemon
[    26.367] (II) NVIDIA(0):     may not be running or the "AcpidSocketPath" X
[    26.367] (II) NVIDIA(0):     configuration option may not be set correctly.  When the
[    26.367] (II) NVIDIA(0):     ACPI event daemon is available, the NVIDIA X driver will
[    26.367] (II) NVIDIA(0):     try to use it to receive ACPI event notifications.  For
[    26.367] (II) NVIDIA(0):     details, please see the "ConnectToAcpid" and
[    26.367] (II) NVIDIA(0):     "AcpidSocketPath" X configuration options in Appendix B: X
[    26.367] (II) NVIDIA(0):     Config Options in the README.
[    26.384] (II) NVIDIA(0): Setting mode "HDMI-0:3840x2160_60+0+0,DP-0:1920x1080_144+3840+0"
[    26.475] (==) NVIDIA(0): Disabling shared memory pixmaps
[    26.475] (==) NVIDIA(0): Backing store enabled
[    26.475] (==) NVIDIA(0): Silken mouse disabled
[    26.475] (**) NVIDIA(0): DPMS enabled
[    26.475] (II) Loading sub module "dri2"
[    26.475] (II) LoadModule: "dri2"
[    26.475] (II) Module "dri2" already built-in
[    26.475] (II) NVIDIA(0): [DRI2] Setup complete
[    26.475] (II) NVIDIA(0): [DRI2]   VDPAU driver: nvidia
[    26.476] (II) Initializing extension Generic Event Extension
[    26.476] (II) Initializing extension SHAPE
[    26.476] (II) Initializing extension MIT-SHM
[    26.476] (II) Initializing extension XInputExtension
[    26.476] (II) Initializing extension XTEST
[    26.476] (II) Initializing extension BIG-REQUESTS
[    26.476] (II) Initializing extension SYNC
[    26.476] (II) Initializing extension XKEYBOARD
[    26.476] (II) Initializing extension XC-MISC
[    26.476] (II) Initializing extension SECURITY
[    26.476] (II) Initializing extension XFIXES
[    26.476] (II) Initializing extension RENDER
[    26.476] (II) Initializing extension RANDR
[    26.476] (II) Initializing extension COMPOSITE
[    26.476] (II) Initializing extension DAMAGE
[    26.476] (II) Initializing extension MIT-SCREEN-SAVER
[    26.476] (II) Initializing extension DOUBLE-BUFFER
[    26.476] (II) Initializing extension RECORD
[    26.476] (II) Initializing extension DPMS
[    26.476] (II) Initializing extension Present
[    26.476] (II) Initializing extension DRI3
[    26.476] (II) Initializing extension X-Resource
[    26.476] (II) Initializing extension XVideo
[    26.476] (II) Initializing extension XVideo-MotionCompensation
[    26.476] (II) Initializing extension GLX
[    26.476] (II) Indirect GLX disabled.
[    26.476] (II) GLX: Another vendor is already registered for screen 0
[    26.476] (II) Initializing extension XFree86-VidModeExtension
[    26.476] (II) Initializing extension XFree86-DGA
[    26.476] (II) Initializing extension XFree86-DRI
[    26.476] (II) Initializing extension DRI2
[    26.476] (II) Initializing extension NV-GLX
[    26.476] (II) Initializing extension NV-CONTROL
[    26.476] (II) Initializing extension XINERAMA
[    26.527] (II) config/udev: Adding input device Power Button (/dev/input/event1)
[    26.527] (**) Power Button: Applying InputClass "libinput keyboard catchall"
[    26.527] (**) Power Button: Applying InputClass "system-keyboard"
[    26.527] (II) LoadModule: "libinput"
[    26.527] (II) Loading /usr/lib/xorg/modules/input/libinput_drv.so
[    26.532] (II) Module libinput: vendor="X.Org Foundation"
[    26.532] 	compiled for 1.20.8, module version = 0.30.0
[    26.532] 	Module class: X.Org XInput Driver
[    26.532] 	ABI class: X.Org XInput driver, version 24.1
[    26.532] (II) Using input driver 'libinput' for 'Power Button'
[    26.532] (II) systemd-logind: got fd for /dev/input/event1 13:65 fd 33 paused 0
[    26.532] (**) Power Button: always reports core events
[    26.532] (**) Option "Device" "/dev/input/event1"
[    26.532] (**) Option "_source" "server/udev"
[    26.539] (II) event1  - Power Button: is tagged by udev as: Keyboard
[    26.539] (II) event1  - Power Button: device is a keyboard
[    26.539] (II) event1  - Power Button: device removed
[    26.539] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXPWRBN:00/input/input1/event1"
[    26.539] (II) XINPUT: Adding extended input device "Power Button" (type: KEYBOARD, id 6)
[    26.539] (**) Option "xkb_model" "fr-latin1"
[    26.539] (**) Option "xkb_layout" "fr"
[    26.555] (II) event1  - Power Button: is tagged by udev as: Keyboard
[    26.555] (II) event1  - Power Button: device is a keyboard
[    26.555] (II) config/udev: Adding input device Power Button (/dev/input/event0)
[    26.555] (**) Power Button: Applying InputClass "libinput keyboard catchall"
[    26.555] (**) Power Button: Applying InputClass "system-keyboard"
[    26.555] (II) Using input driver 'libinput' for 'Power Button'
[    26.556] (II) systemd-logind: got fd for /dev/input/event0 13:64 fd 36 paused 0
[    26.556] (**) Power Button: always reports core events
[    26.556] (**) Option "Device" "/dev/input/event0"
[    26.556] (**) Option "_source" "server/udev"
[    26.556] (II) event0  - Power Button: is tagged by udev as: Keyboard
[    26.556] (II) event0  - Power Button: device is a keyboard
[    26.556] (II) event0  - Power Button: device removed
[    26.556] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0C:00/input/input0/event0"
[    26.556] (II) XINPUT: Adding extended input device "Power Button" (type: KEYBOARD, id 7)
[    26.556] (**) Option "xkb_model" "fr-latin1"
[    26.556] (**) Option "xkb_layout" "fr"
[    26.557] (II) event0  - Power Button: is tagged by udev as: Keyboard
[    26.557] (II) event0  - Power Button: device is a keyboard
[    26.557] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=3 (/dev/input/event15)
[    26.557] (II) No input driver specified, ignoring this device.
[    26.557] (II) This device may have been added with another device file.
[    26.558] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=7 (/dev/input/event16)
[    26.558] (II) No input driver specified, ignoring this device.
[    26.558] (II) This device may have been added with another device file.
[    26.558] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=8 (/dev/input/event17)
[    26.558] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=9 (/dev/input/event18)
[    26.558] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=10 (/dev/input/event19)
[    26.558] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=11 (/dev/input/event20)
[    26.559] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=12 (/dev/input/event21)
[    26.559] (II) No input driver specified, ignoring this device.
[    26.559] (II) This device may have been added with another device file.
[    26.559] (II) config/udev: Adding input device Valve Software Steam Controller (/dev/input/event4)
[    26.559] (**) Valve Software Steam Controller: Applying InputClass "libinput pointer catchall"
[    26.559] (**) Valve Software Steam Controller: Applying InputClass "libinput keyboard catchall"
[    26.559] (**) Valve Software Steam Controller: Applying InputClass "system-keyboard"
[    26.559] (II) Using input driver 'libinput' for 'Valve Software Steam Controller'
[    26.560] (II) systemd-logind: got fd for /dev/input/event4 13:68 fd 37 paused 0
[    26.560] (**) Valve Software Steam Controller: always reports core events
[    26.560] (**) Option "Device" "/dev/input/event4"
[    26.560] (**) Option "_source" "server/udev"
[    26.561] (II) event4  - Valve Software Steam Controller: is tagged by udev as: Keyboard Mouse
[    26.561] (II) event4  - Valve Software Steam Controller: device is a pointer
[    26.561] (II) event4  - Valve Software Steam Controller: device is a keyboard
[    26.561] (II) event4  - Valve Software Steam Controller: device removed
[    26.561] (II) libinput: Valve Software Steam Controller: needs a virtual subdevice
[    26.561] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:14.0/usb2/2-10/2-10:1.0/0003:28DE:1142.0001/input/input29/event4"
[    26.561] (II) XINPUT: Adding extended input device "Valve Software Steam Controller" (type: MOUSE, id 8)
[    26.561] (**) Option "AccelerationScheme" "none"
[    26.561] (**) Valve Software Steam Controller: (accel) selected scheme none/0
[    26.561] (**) Valve Software Steam Controller: (accel) acceleration factor: 2.000
[    26.561] (**) Valve Software Steam Controller: (accel) acceleration threshold: 4
[    26.562] (II) event4  - Valve Software Steam Controller: is tagged by udev as: Keyboard Mouse
[    26.562] (II) event4  - Valve Software Steam Controller: device is a pointer
[    26.562] (II) event4  - Valve Software Steam Controller: device is a keyboard
[    26.563] (II) config/udev: Adding input device Valve Software Steam Controller (/dev/input/mouse1)
[    26.563] (**) Valve Software Steam Controller: Applying InputClass "system-keyboard"
[    26.563] (II) No input driver specified, ignoring this device.
[    26.563] (II) This device may have been added with another device file.
[    26.564] (II) config/udev: Adding input device Logitech Logitech Gaming Keyboard (/dev/input/event5)
[    26.564] (**) Logitech Logitech Gaming Keyboard: Applying InputClass "libinput keyboard catchall"
[    26.564] (**) Logitech Logitech Gaming Keyboard: Applying InputClass "system-keyboard"
[    26.564] (II) Using input driver 'libinput' for 'Logitech Logitech Gaming Keyboard'
[    26.564] (II) systemd-logind: got fd for /dev/input/event5 13:69 fd 38 paused 0
[    26.564] (**) Logitech Logitech Gaming Keyboard: always reports core events
[    26.564] (**) Option "Device" "/dev/input/event5"
[    26.564] (**) Option "_source" "server/udev"
[    26.565] (II) event5  - Logitech Logitech Gaming Keyboard: is tagged by udev as: Keyboard
[    26.565] (II) event5  - Logitech Logitech Gaming Keyboard: device is a keyboard
[    26.565] (II) event5  - Logitech Logitech Gaming Keyboard: device removed
[    26.565] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:14.0/usb2/2-13/2-13.1/2-13.1:1.0/0003:046D:C221.0008/input/input6/event5"
[    26.565] (II) XINPUT: Adding extended input device "Logitech Logitech Gaming Keyboard" (type: KEYBOARD, id 9)
[    26.565] (**) Option "xkb_model" "fr-latin1"
[    26.566] (**) Option "xkb_layout" "fr"
[    26.567] (II) event5  - Logitech Logitech Gaming Keyboard: is tagged by udev as: Keyboard
[    26.567] (II) event5  - Logitech Logitech Gaming Keyboard: device is a keyboard
[    26.567] (II) config/udev: Adding input device Logitech Logitech Gaming Keyboard Consumer Control (/dev/input/event13)
[    26.567] (**) Logitech Logitech Gaming Keyboard Consumer Control: Applying InputClass "libinput keyboard catchall"
[    26.567] (**) Logitech Logitech Gaming Keyboard Consumer Control: Applying InputClass "system-keyboard"
[    26.567] (II) Using input driver 'libinput' for 'Logitech Logitech Gaming Keyboard Consumer Control'
[    26.568] (II) systemd-logind: got fd for /dev/input/event13 13:77 fd 39 paused 0
[    26.568] (**) Logitech Logitech Gaming Keyboard Consumer Control: always reports core events
[    26.568] (**) Option "Device" "/dev/input/event13"
[    26.568] (**) Option "_source" "server/udev"
[    26.569] (II) event13 - Logitech Logitech Gaming Keyboard Consumer Control: is tagged by udev as: Keyboard
[    26.569] (II) event13 - Logitech Logitech Gaming Keyboard Consumer Control: device is a keyboard
[    26.569] (II) event13 - Logitech Logitech Gaming Keyboard Consumer Control: device removed
[    26.569] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:14.0/usb2/2-13/2-13.1/2-13.1:1.1/0003:046D:C221.0009/input/input21/event13"
[    26.569] (II) XINPUT: Adding extended input device "Logitech Logitech Gaming Keyboard Consumer Control" (type: KEYBOARD, id 10)
[    26.569] (**) Option "xkb_model" "fr-latin1"
[    26.569] (**) Option "xkb_layout" "fr"
[    26.570] (II) event13 - Logitech Logitech Gaming Keyboard Consumer Control: is tagged by udev as: Keyboard
[    26.570] (II) event13 - Logitech Logitech Gaming Keyboard Consumer Control: device is a keyboard
[    26.571] (II) config/udev: Adding input device Logitech Gaming Keyboard Gaming Keys (/dev/input/event14)
[    26.571] (**) Logitech Gaming Keyboard Gaming Keys: Applying InputClass "libinput keyboard catchall"
[    26.571] (**) Logitech Gaming Keyboard Gaming Keys: Applying InputClass "system-keyboard"
[    26.571] (II) Using input driver 'libinput' for 'Logitech Gaming Keyboard Gaming Keys'
[    26.628] (II) systemd-logind: got fd for /dev/input/event14 13:78 fd 40 paused 0
[    26.628] (**) Logitech Gaming Keyboard Gaming Keys: always reports core events
[    26.628] (**) Option "Device" "/dev/input/event14"
[    26.628] (**) Option "_source" "server/udev"
[    26.630] (II) event14 - Logitech Gaming Keyboard Gaming Keys: is tagged by udev as: Keyboard
[    26.630] (II) event14 - Logitech Gaming Keyboard Gaming Keys: device is a keyboard
[    26.630] (II) event14 - Logitech Gaming Keyboard Gaming Keys: device removed
[    26.630] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:14.0/usb2/2-13/2-13.4/2-13.4:1.0/0003:046D:C222.000A/input/input32/event14"
[    26.630] (II) XINPUT: Adding extended input device "Logitech Gaming Keyboard Gaming Keys" (type: KEYBOARD, id 11)
[    26.630] (**) Option "xkb_model" "fr-latin1"
[    26.630] (**) Option "xkb_layout" "fr"
[    26.632] (II) event14 - Logitech Gaming Keyboard Gaming Keys: is tagged by udev as: Keyboard
[    26.632] (II) event14 - Logitech Gaming Keyboard Gaming Keys: device is a keyboard
[    26.633] (II) config/udev: Adding input device Logitech Gaming Mouse G502 (/dev/input/event22)
[    26.633] (**) Logitech Gaming Mouse G502: Applying InputClass "libinput pointer catchall"
[    26.633] (II) Using input driver 'libinput' for 'Logitech Gaming Mouse G502'
[    26.688] (II) systemd-logind: got fd for /dev/input/event22 13:86 fd 41 paused 0
[    26.688] (**) Logitech Gaming Mouse G502: always reports core events
[    26.688] (**) Option "Device" "/dev/input/event22"
[    26.688] (**) Option "_source" "server/udev"
[    26.690] (II) event22 - Logitech Gaming Mouse G502: is tagged by udev as: Mouse
[    26.690] (II) event22 - Logitech Gaming Mouse G502: device set to 2400 DPI
[    26.690] (II) event22 - Logitech Gaming Mouse G502: device is a pointer
[    26.690] (II) event22 - Logitech Gaming Mouse G502: device removed
[    26.690] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:14.0/usb2/2-14/2-14:1.0/0003:046D:C332.0006/input/input23/event22"
[    26.690] (II) XINPUT: Adding extended input device "Logitech Gaming Mouse G502" (type: MOUSE, id 12)
[    26.691] (**) Option "AccelerationScheme" "none"
[    26.691] (**) Logitech Gaming Mouse G502: (accel) selected scheme none/0
[    26.691] (**) Logitech Gaming Mouse G502: (accel) acceleration factor: 2.000
[    26.691] (**) Logitech Gaming Mouse G502: (accel) acceleration threshold: 4
[    26.692] (II) event22 - Logitech Gaming Mouse G502: is tagged by udev as: Mouse
[    26.692] (II) event22 - Logitech Gaming Mouse G502: device set to 2400 DPI
[    26.693] (II) event22 - Logitech Gaming Mouse G502: device is a pointer
[    26.693] (II) config/udev: Adding input device Logitech Gaming Mouse G502 (/dev/input/mouse0)
[    26.693] (II) No input driver specified, ignoring this device.
[    26.693] (II) This device may have been added with another device file.
[    26.694] (II) config/udev: Adding input device Logitech Gaming Mouse G502 Keyboard (/dev/input/event23)
[    26.694] (**) Logitech Gaming Mouse G502 Keyboard: Applying InputClass "libinput keyboard catchall"
[    26.694] (**) Logitech Gaming Mouse G502 Keyboard: Applying InputClass "system-keyboard"
[    26.694] (II) Using input driver 'libinput' for 'Logitech Gaming Mouse G502 Keyboard'
[    26.695] (II) systemd-logind: got fd for /dev/input/event23 13:87 fd 42 paused 0
[    26.695] (**) Logitech Gaming Mouse G502 Keyboard: always reports core events
[    26.695] (**) Option "Device" "/dev/input/event23"
[    26.695] (**) Option "_source" "server/udev"
[    26.697] (II) event23 - Logitech Gaming Mouse G502 Keyboard: is tagged by udev as: Keyboard
[    26.697] (II) event23 - Logitech Gaming Mouse G502 Keyboard: device is a keyboard
[    26.697] (II) event23 - Logitech Gaming Mouse G502 Keyboard: device removed
[    26.697] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:14.0/usb2/2-14/2-14:1.1/0003:046D:C332.0007/input/input24/event23"
[    26.697] (II) XINPUT: Adding extended input device "Logitech Gaming Mouse G502 Keyboard" (type: KEYBOARD, id 13)
[    26.697] (**) Option "xkb_model" "fr-latin1"
[    26.697] (**) Option "xkb_layout" "fr"
[    26.698] (II) event23 - Logitech Gaming Mouse G502 Keyboard: is tagged by udev as: Keyboard
[    26.698] (II) event23 - Logitech Gaming Mouse G502 Keyboard: device is a keyboard
[    26.699] (II) config/udev: Adding input device Logitech Gaming Mouse G502 Consumer Control (/dev/input/event24)
[    26.699] (**) Logitech Gaming Mouse G502 Consumer Control: Applying InputClass "libinput keyboard catchall"
[    26.699] (**) Logitech Gaming Mouse G502 Consumer Control: Applying InputClass "system-keyboard"
[    26.699] (II) Using input driver 'libinput' for 'Logitech Gaming Mouse G502 Consumer Control'
[    26.700] (II) systemd-logind: got fd for /dev/input/event24 13:88 fd 43 paused 0
[    26.700] (**) Logitech Gaming Mouse G502 Consumer Control: always reports core events
[    26.700] (**) Option "Device" "/dev/input/event24"
[    26.700] (**) Option "_source" "server/udev"
[    26.701] (II) event24 - Logitech Gaming Mouse G502 Consumer Control: is tagged by udev as: Keyboard
[    26.701] (II) event24 - Logitech Gaming Mouse G502 Consumer Control: device is a keyboard
[    26.701] (II) event24 - Logitech Gaming Mouse G502 Consumer Control: device removed
[    26.701] (II) libinput: Logitech Gaming Mouse G502 Consumer Control: needs a virtual subdevice
[    26.702] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:14.0/usb2/2-14/2-14:1.1/0003:046D:C332.0007/input/input25/event24"
[    26.702] (II) XINPUT: Adding extended input device "Logitech Gaming Mouse G502 Consumer Control" (type: MOUSE, id 14)
[    26.702] (**) Option "AccelerationScheme" "none"
[    26.702] (**) Logitech Gaming Mouse G502 Consumer Control: (accel) selected scheme none/0
[    26.702] (**) Logitech Gaming Mouse G502 Consumer Control: (accel) acceleration factor: 2.000
[    26.702] (**) Logitech Gaming Mouse G502 Consumer Control: (accel) acceleration threshold: 4
[    26.703] (II) event24 - Logitech Gaming Mouse G502 Consumer Control: is tagged by udev as: Keyboard
[    26.703] (II) event24 - Logitech Gaming Mouse G502 Consumer Control: device is a keyboard
[    26.704] (II) config/udev: Adding input device Logitech Gaming Mouse G502 System Control (/dev/input/event25)
[    26.704] (**) Logitech Gaming Mouse G502 System Control: Applying InputClass "libinput keyboard catchall"
[    26.704] (**) Logitech Gaming Mouse G502 System Control: Applying InputClass "system-keyboard"
[    26.704] (II) Using input driver 'libinput' for 'Logitech Gaming Mouse G502 System Control'
[    26.705] (II) systemd-logind: got fd for /dev/input/event25 13:89 fd 44 paused 0
[    26.705] (**) Logitech Gaming Mouse G502 System Control: always reports core events
[    26.705] (**) Option "Device" "/dev/input/event25"
[    26.705] (**) Option "_source" "server/udev"
[    26.705] (II) event25 - Logitech Gaming Mouse G502 System Control: is tagged by udev as: Keyboard
[    26.705] (II) event25 - Logitech Gaming Mouse G502 System Control: device is a keyboard
[    26.706] (II) event25 - Logitech Gaming Mouse G502 System Control: device removed
[    26.706] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:14.0/usb2/2-14/2-14:1.1/0003:046D:C332.0007/input/input26/event25"
[    26.706] (II) XINPUT: Adding extended input device "Logitech Gaming Mouse G502 System Control" (type: KEYBOARD, id 15)
[    26.706] (**) Option "xkb_model" "fr-latin1"
[    26.706] (**) Option "xkb_layout" "fr"
[    26.706] (II) event25 - Logitech Gaming Mouse G502 System Control: is tagged by udev as: Keyboard
[    26.706] (II) event25 - Logitech Gaming Mouse G502 System Control: device is a keyboard
[    26.707] (II) config/udev: Adding input device HDA Intel PCH Line Out Front (/dev/input/event9)
[    26.707] (II) No input driver specified, ignoring this device.
[    26.707] (II) This device may have been added with another device file.
[    26.707] (II) config/udev: Adding input device HDA Intel PCH Line Out Surround (/dev/input/event10)
[    26.707] (II) config/udev: Adding input device HDA Intel PCH Line Out CLFE (/dev/input/event11)
[    26.707] (II) config/udev: Adding input device HDA Intel PCH Front Headphone (/dev/input/event12)
[    26.707] (II) config/udev: Adding input device HDA Intel PCH Front Mic (/dev/input/event6)
[    26.708] (II) config/udev: Adding input device HDA Intel PCH Rear Mic (/dev/input/event7)
[    26.708] (II) No input driver specified, ignoring this device.
[    26.708] (II) This device may have been added with another device file.
[    26.708] (II) config/udev: Adding input device HDA Intel PCH Line (/dev/input/event8)
[    26.708] (II) config/udev: Adding input device Eee PC WMI hotkeys (/dev/input/event3)
[    26.708] (**) Eee PC WMI hotkeys: Applying InputClass "libinput keyboard catchall"
[    26.708] (**) Eee PC WMI hotkeys: Applying InputClass "system-keyboard"
[    26.708] (II) Using input driver 'libinput' for 'Eee PC WMI hotkeys'
[    26.709] (II) systemd-logind: got fd for /dev/input/event3 13:67 fd 45 paused 0
[    26.709] (**) Eee PC WMI hotkeys: always reports core events
[    26.709] (**) Option "Device" "/dev/input/event3"
[    26.709] (**) Option "_source" "server/udev"
[    26.709] (II) event3  - Eee PC WMI hotkeys: is tagged by udev as: Keyboard
[    26.709] (II) event3  - Eee PC WMI hotkeys: device is a keyboard
[    26.709] (II) event3  - Eee PC WMI hotkeys: device removed
[    26.709] (**) Option "config_info" "udev:/sys/devices/platform/eeepc-wmi/input/input3/event3"
[    26.709] (II) XINPUT: Adding extended input device "Eee PC WMI hotkeys" (type: KEYBOARD, id 16)
[    26.709] (**) Option "xkb_model" "fr-latin1"
[    26.709] (**) Option "xkb_layout" "fr"
[    26.710] (II) event3  - Eee PC WMI hotkeys: is tagged by udev as: Keyboard
[    26.710] (II) event3  - Eee PC WMI hotkeys: device is a keyboard
[    26.710] (II) config/udev: Adding input device PC Speaker (/dev/input/event2)
[    26.710] (II) No input driver specified, ignoring this device.
[    26.710] (II) This device may have been added with another device file.
[    26.712] (**) Valve Software Steam Controller: Applying InputClass "libinput pointer catchall"
[    26.712] (**) Valve Software Steam Controller: Applying InputClass "libinput keyboard catchall"
[    26.712] (**) Valve Software Steam Controller: Applying InputClass "system-keyboard"
[    26.712] (II) Using input driver 'libinput' for 'Valve Software Steam Controller'
[    26.712] (II) systemd-logind: returning pre-existing fd for /dev/input/event4 13:68
[    26.712] (**) Valve Software Steam Controller: always reports core events
[    26.712] (**) Option "Device" "/dev/input/event4"
[    26.712] (**) Option "_source" "_driver/libinput"
[    26.712] (II) libinput: Valve Software Steam Controller: is a virtual subdevice
[    26.712] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:14.0/usb2/2-10/2-10:1.0/0003:28DE:1142.0001/input/input29/event4"
[    26.712] (II) XINPUT: Adding extended input device "Valve Software Steam Controller" (type: KEYBOARD, id 17)
[    26.712] (**) Option "xkb_model" "fr-latin1"
[    26.712] (**) Option "xkb_layout" "fr"
[    26.713] (**) Logitech Gaming Mouse G502 Consumer Control: Applying InputClass "libinput keyboard catchall"
[    26.713] (**) Logitech Gaming Mouse G502 Consumer Control: Applying InputClass "system-keyboard"
[    26.713] (II) Using input driver 'libinput' for 'Logitech Gaming Mouse G502 Consumer Control'
[    26.713] (II) systemd-logind: returning pre-existing fd for /dev/input/event24 13:88
[    26.713] (**) Logitech Gaming Mouse G502 Consumer Control: always reports core events
[    26.713] (**) Option "Device" "/dev/input/event24"
[    26.713] (**) Option "_source" "_driver/libinput"
[    26.713] (II) libinput: Logitech Gaming Mouse G502 Consumer Control: is a virtual subdevice
[    26.713] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:14.0/usb2/2-14/2-14:1.1/0003:046D:C332.0007/input/input25/event24"
[    26.713] (II) XINPUT: Adding extended input device "Logitech Gaming Mouse G502 Consumer Control" (type: KEYBOARD, id 18)
[    26.713] (**) Option "xkb_model" "fr-latin1"
[    26.713] (**) Option "xkb_layout" "fr"
[    26.713] (--) NVIDIA(GPU-0): Idek Iiyama PLG2773H (DFP-2): connected
[    26.713] (--) NVIDIA(GPU-0): Idek Iiyama PLG2773H (DFP-2): Internal DisplayPort
[    26.713] (--) NVIDIA(GPU-0): Idek Iiyama PLG2773H (DFP-2): 960.0 MHz maximum pixel clock
[    26.747] (--) NVIDIA(GPU-0): HPN HP ENVY 27s (DFP-1): connected
[    26.747] (--) NVIDIA(GPU-0): HPN HP ENVY 27s (DFP-1): Internal TMDS
[    26.747] (--) NVIDIA(GPU-0): HPN HP ENVY 27s (DFP-1): 600.0 MHz maximum pixel clock
[    26.782] (--) NVIDIA(GPU-0): HPN HP ENVY 27s (DFP-1): connected
[    26.782] (--) NVIDIA(GPU-0): HPN HP ENVY 27s (DFP-1): Internal TMDS
[    26.782] (--) NVIDIA(GPU-0): HPN HP ENVY 27s (DFP-1): 600.0 MHz maximum pixel clock
[    31.709] (--) NVIDIA(GPU-0): CRT-0: disconnected
[    31.709] (--) NVIDIA(GPU-0): CRT-0: 400.0 MHz maximum pixel clock
[    31.713] (--) NVIDIA(GPU-0): DFP-0: disconnected
[    31.714] (--) NVIDIA(GPU-0): DFP-0: Internal TMDS
[    31.714] (--) NVIDIA(GPU-0): DFP-0: 330.0 MHz maximum pixel clock
[    31.748] (--) NVIDIA(GPU-0): HPN HP ENVY 27s (DFP-1): connected
[    31.748] (--) NVIDIA(GPU-0): HPN HP ENVY 27s (DFP-1): Internal TMDS
[    31.748] (--) NVIDIA(GPU-0): HPN HP ENVY 27s (DFP-1): 600.0 MHz maximum pixel clock
[    31.748] (--) NVIDIA(GPU-0): Idek Iiyama PLG2773H (DFP-2): connected
[    31.748] (--) NVIDIA(GPU-0): Idek Iiyama PLG2773H (DFP-2): Internal DisplayPort
[    31.748] (--) NVIDIA(GPU-0): Idek Iiyama PLG2773H (DFP-2): 960.0 MHz maximum pixel clock
[    31.749] (--) NVIDIA(GPU-0): DFP-3: disconnected
[    31.749] (--) NVIDIA(GPU-0): DFP-3: Internal TMDS
[    31.749] (--) NVIDIA(GPU-0): DFP-3: 165.0 MHz maximum pixel clock
[    31.749] (--) NVIDIA(GPU-0): DFP-4: disconnected
[    31.749] (--) NVIDIA(GPU-0): DFP-4: Internal TMDS
[    31.749] (--) NVIDIA(GPU-0): DFP-4: 330.0 MHz maximum pixel clock
[  2155.513] (**) Option "fd" "33"
[  2155.513] (II) event1  - Power Button: device removed
[  2155.513] (**) Option "fd" "36"
[  2155.513] (II) event0  - Power Button: device removed
[  2155.513] (**) Option "fd" "37"
[  2155.513] (**) Option "fd" "38"
[  2155.513] (II) event5  - Logitech Logitech Gaming Keyboard: device removed
[  2155.514] (**) Option "fd" "39"
[  2155.514] (II) event13 - Logitech Logitech Gaming Keyboard Consumer Control: device removed
[  2155.514] (**) Option "fd" "40"
[  2155.514] (II) event14 - Logitech Gaming Keyboard Gaming Keys: device removed
[  2155.514] (**) Option "fd" "41"
[  2155.514] (II) event22 - Logitech Gaming Mouse G502: device removed
[  2155.514] (**) Option "fd" "42"
[  2155.514] (II) event23 - Logitech Gaming Mouse G502 Keyboard: device removed
[  2155.514] (**) Option "fd" "43"
[  2155.514] (**) Option "fd" "44"
[  2155.514] (II) event25 - Logitech Gaming Mouse G502 System Control: device removed
[  2155.514] (**) Option "fd" "45"
[  2155.514] (II) event3  - Eee PC WMI hotkeys: device removed
[  2155.514] (**) Option "fd" "37"
[  2155.514] (II) event4  - Valve Software Steam Controller: device removed
[  2155.514] (II) event24 - Logitech Gaming Mouse G502 Consumer Control: device removed
[  2155.636] (II) systemd-logind: got pause for 13:64
[  2155.636] (II) systemd-logind: got pause for 13:88
[  2155.636] (II) systemd-logind: got pause for 13:67
[  2155.636] (II) systemd-logind: got pause for 13:77
[  2155.636] (II) systemd-logind: got pause for 13:65
[  2155.636] (II) systemd-logind: got pause for 13:69
[  2155.636] (II) systemd-logind: got pause for 13:68
[  2155.636] (II) systemd-logind: got pause for 13:87
[  2155.636] (II) systemd-logind: got pause for 13:78
[  2155.636] (II) systemd-logind: got pause for 13:89
[  2155.636] (II) systemd-logind: got pause for 13:86
[  2159.252] (II) systemd-logind: got resume for 13:64
[  2159.322] (--) NVIDIA(GPU-0): CRT-0: disconnected
[  2159.322] (--) NVIDIA(GPU-0): CRT-0: 400.0 MHz maximum pixel clock
[  2159.326] (--) NVIDIA(GPU-0): DFP-0: disconnected
@pingo-power
[  2159.326] (--) NVIDIA(GPU-0): DFP-0: Internal TMDS
[  2159.326] (--) NVIDIA(GPU-0): DFP-0: 330.0 MHz maximum pixel clock
[  2159.361] (--) NVIDIA(GPU-0): HPN HP ENVY 27s (DFP-1): connected
[  2159.361] (--) NVIDIA(GPU-0): HPN HP ENVY 27s (DFP-1): Internal TMDS
[  2159.361] (--) NVIDIA(GPU-0): HPN HP ENVY 27s (DFP-1): 600.0 MHz maximum pixel clock
[  2159.361] (--) NVIDIA(GPU-0): Idek Iiyama PLG2773H (DFP-2): connected
[  2159.361] (--) NVIDIA(GPU-0): Idek Iiyama PLG2773H (DFP-2): Internal DisplayPort
[  2159.361] (--) NVIDIA(GPU-0): Idek Iiyama PLG2773H (DFP-2): 960.0 MHz maximum pixel clock
[  2159.362] (--) NVIDIA(GPU-0): DFP-3: disconnected
[  2159.362] (--) NVIDIA(GPU-0): DFP-3: Internal TMDS
[  2159.362] (--) NVIDIA(GPU-0): DFP-3: 165.0 MHz maximum pixel clock
[  2159.362] (--) NVIDIA(GPU-0): DFP-4: disconnected
[  2159.362] (--) NVIDIA(GPU-0): DFP-4: Internal TMDS
[  2159.362] (--) NVIDIA(GPU-0): DFP-4: 330.0 MHz maximum pixel clock
[  2159.373] (II) NVIDIA(0): Setting mode "HDMI-0:3840x2160_60+0+0,DP-0:1920x1080_144+3840+0"
[  2159.402] (II) NVIDIA(0): ACPI: failed to connect to the ACPI event daemon; the daemon
[  2159.402] (II) NVIDIA(0):     may not be running or the "AcpidSocketPath" X
[  2159.402] (II) NVIDIA(0):     configuration option may not be set correctly.  When the
[  2159.404] (II) NVIDIA(0):     ACPI event daemon is available, the NVIDIA X driver will
[  2159.404] (II) NVIDIA(0):     try to use it to receive ACPI event notifications.  For
[  2159.404] (II) NVIDIA(0):     details, please see the "ConnectToAcpid" and
[  2159.404] (II) NVIDIA(0):     "AcpidSocketPath" X configuration options in Appendix B: X
[  2159.404] (II) NVIDIA(0):     Config Options in the README.
[  2159.441] (II) event0  - Power Button: is tagged by udev as: Keyboard
[  2159.441] (II) event0  - Power Button: device is a keyboard
[  2159.442] (II) systemd-logind: got resume for 13:88
[  2159.443] (II) event24 - Logitech Gaming Mouse G502 Consumer Control: is tagged by udev as: Keyboard
[  2159.443] (II) event24 - Logitech Gaming Mouse G502 Consumer Control: device is a keyboard
[  2159.444] (II) systemd-logind: got resume for 13:67
[  2159.444] (II) event3  - Eee PC WMI hotkeys: is tagged by udev as: Keyboard
[  2159.445] (II) event3  - Eee PC WMI hotkeys: device is a keyboard
[  2159.445] (II) systemd-logind: got resume for 13:77
[  2159.446] (II) event13 - Logitech Logitech Gaming Keyboard Consumer Control: is tagged by udev as: Keyboard
[  2159.446] (II) event13 - Logitech Logitech Gaming Keyboard Consumer Control: device is a keyboard
[  2159.446] (II) systemd-logind: got resume for 13:65
[  2159.447] (II) event1  - Power Button: is tagged by udev as: Keyboard
[  2159.447] (II) event1  - Power Button: device is a keyboard
[  2159.447] (II) systemd-logind: got resume for 13:69
[  2159.448] (II) event5  - Logitech Logitech Gaming Keyboard: is tagged by udev as: Keyboard
[  2159.448] (II) event5  - Logitech Logitech Gaming Keyboard: device is a keyboard
[  2159.449] (II) systemd-logind: got resume for 13:68
[  2159.450] (II) event4  - Valve Software Steam Controller: is tagged by udev as: Keyboard Mouse
[  2159.450] (II) event4  - Valve Software Steam Controller: device is a pointer
[  2159.450] (II) event4  - Valve Software Steam Controller: device is a keyboard
[  2159.451] (II) systemd-logind: got resume for 13:87
[  2159.452] (II) event23 - Logitech Gaming Mouse G502 Keyboard: is tagged by udev as: Keyboard
[  2159.452] (II) event23 - Logitech Gaming Mouse G502 Keyboard: device is a keyboard
[  2159.452] (II) systemd-logind: got resume for 13:78
[  2159.453] (II) event14 - Logitech Gaming Keyboard Gaming Keys: is tagged by udev as: Keyboard
[  2159.453] (II) event14 - Logitech Gaming Keyboard Gaming Keys: device is a keyboard
[  2159.454] (II) systemd-logind: got resume for 13:89
[  2159.455] (II) event25 - Logitech Gaming Mouse G502 System Control: is tagged by udev as: Keyboard
[  2159.455] (II) event25 - Logitech Gaming Mouse G502 System Control: device is a keyboard
[  2159.455] (II) systemd-logind: got resume for 13:86
[  2159.456] (II) event22 - Logitech Gaming Mouse G502: is tagged by udev as: Mouse
[  2159.456] (II) event22 - Logitech Gaming Mouse G502: device set to 2400 DPI
[  2159.456] (II) event22 - Logitech Gaming Mouse G502: device is a pointer
[  2159.457] (--) NVIDIA(GPU-0): Idek Iiyama PLG2773H (DFP-2): connected
[  2159.457] (--) NVIDIA(GPU-0): Idek Iiyama PLG2773H (DFP-2): Internal DisplayPort
[  2159.457] (--) NVIDIA(GPU-0): Idek Iiyama PLG2773H (DFP-2): 960.0 MHz maximum pixel clock
[  2159.491] (--) NVIDIA(GPU-0): HPN HP ENVY 27s (DFP-1): connected
[  2159.491] (--) NVIDIA(GPU-0): HPN HP ENVY 27s (DFP-1): Internal TMDS
[  2159.491] (--) NVIDIA(GPU-0): HPN HP ENVY 27s (DFP-1): 600.0 MHz maximum pixel clock
[  2159.529] (--) NVIDIA(GPU-0): HPN HP ENVY 27s (DFP-1): connected
[  2159.529] (--) NVIDIA(GPU-0): HPN HP ENVY 27s (DFP-1): Internal TMDS
[  2159.529] (--) NVIDIA(GPU-0): HPN HP ENVY 27s (DFP-1): 600.0 MHz maximum pixel clock
[  8119.266] (**) Option "fd" "38"
[  8119.266] (II) event1  - Power Button: device removed
[  8119.266] (**) Option "fd" "25"
[  8119.266] (II) event0  - Power Button: device removed
[  8119.267] (**) Option "fd" "40"
[  8119.267] (**) Option "fd" "39"
[  8119.267] (II) event5  - Logitech Logitech Gaming Keyboard: device removed
[  8119.267] (**) Option "fd" "37"
[  8119.267] (II) event13 - Logitech Logitech Gaming Keyboard Consumer Control: device removed
[  8119.267] (**) Option "fd" "42"
[  8119.267] (II) event14 - Logitech Gaming Keyboard Gaming Keys: device removed
[  8119.267] (**) Option "fd" "44"
[  8119.267] (II) event22 - Logitech Gaming Mouse G502: device removed
[  8119.267] (**) Option "fd" "41"
[  8119.267] (II) event23 - Logitech Gaming Mouse G502 Keyboard: device removed
[  8119.268] (**) Option "fd" "61"
[  8119.268] (**) Option "fd" "43"
[  8119.268] (II) event25 - Logitech Gaming Mouse G502 System Control: device removed
[  8119.268] (**) Option "fd" "24"
[  8119.268] (II) event3  - Eee PC WMI hotkeys: device removed
[  8119.268] (**) Option "fd" "40"
[  8119.268] (II) event4  - Valve Software Steam Controller: device removed
[  8119.269] (**) Option "fd" "61"
[  8119.269] (II) event24 - Logitech Gaming Mouse G502 Consumer Control: device removed
[  8119.397] (II) systemd-logind: got pause for 13:64
[  8119.397] (II) systemd-logind: got pause for 13:88
[  8119.397] (II) systemd-logind: got pause for 13:67
[  8119.397] (II) systemd-logind: got pause for 13:77
[  8119.397] (II) systemd-logind: got pause for 13:65
[  8119.397] (II) systemd-logind: got pause for 13:69
[  8119.397] (II) systemd-logind: got pause for 13:68
[  8119.397] (II) systemd-logind: got pause for 13:87
[  8119.397] (II) systemd-logind: got pause for 13:78
[  8119.397] (II) systemd-logind: got pause for 13:89
[  8119.397] (II) systemd-logind: got pause for 13:86
[  8121.545] (II) systemd-logind: got resume for 13:64
[  8121.549] (--) NVIDIA(GPU-0): CRT-0: disconnected
[  8121.549] (--) NVIDIA(GPU-0): CRT-0: 400.0 MHz maximum pixel clock
[  8121.553] (--) NVIDIA(GPU-0): DFP-0: disconnected
[  8121.553] (--) NVIDIA(GPU-0): DFP-0: Internal TMDS
[  8121.553] (--) NVIDIA(GPU-0): DFP-0: 330.0 MHz maximum pixel clock
[  8121.589] (--) NVIDIA(GPU-0): HPN HP ENVY 27s (DFP-1): connected
[  8121.589] (--) NVIDIA(GPU-0): HPN HP ENVY 27s (DFP-1): Internal TMDS
[  8121.589] (--) NVIDIA(GPU-0): HPN HP ENVY 27s (DFP-1): 600.0 MHz maximum pixel clock
[  8121.589] (--) NVIDIA(GPU-0): Idek Iiyama PLG2773H (DFP-2): connected
[  8121.589] (--) NVIDIA(GPU-0): Idek Iiyama PLG2773H (DFP-2): Internal DisplayPort
[  8121.589] (--) NVIDIA(GPU-0): Idek Iiyama PLG2773H (DFP-2): 960.0 MHz maximum pixel clock
[  8121.590] (--) NVIDIA(GPU-0): DFP-3: disconnected
[  8121.590] (--) NVIDIA(GPU-0): DFP-3: Internal TMDS
[  8121.590] (--) NVIDIA(GPU-0): DFP-3: 165.0 MHz maximum pixel clock
[  8121.590] (--) NVIDIA(GPU-0): DFP-4: disconnected
[  8121.590] (--) NVIDIA(GPU-0): DFP-4: Internal TMDS
[  8121.590] (--) NVIDIA(GPU-0): DFP-4: 330.0 MHz maximum pixel clock
[  8121.601] (II) NVIDIA(0): Setting mode "HDMI-0:3840x2160_60+0+0,DP-0:1920x1080_144+3840+0"
[  8121.632] (II) NVIDIA(0): ACPI: failed to connect to the ACPI event daemon; the daemon
[  8121.632] (II) NVIDIA(0):     may not be running or the "AcpidSocketPath" X
[  8121.632] (II) NVIDIA(0):     configuration option may not be set correctly.  When the
[  8121.632] (II) NVIDIA(0):     ACPI event daemon is available, the NVIDIA X driver will
[  8121.632] (II) NVIDIA(0):     try to use it to receive ACPI event notifications.  For
[  8121.632] (II) NVIDIA(0):     details, please see the "ConnectToAcpid" and
[  8121.632] (II) NVIDIA(0):     "AcpidSocketPath" X configuration options in Appendix B: X
[  8121.632] (II) NVIDIA(0):     Config Options in the README.
[  8121.670] (II) event0  - Power Button: is tagged by udev as: Keyboard
[  8121.670] (II) event0  - Power Button: device is a keyboard
[  8121.673] (II) systemd-logind: got resume for 13:88
[  8121.673] (II) event24 - Logitech Gaming Mouse G502 Consumer Control: is tagged by udev as: Keyboard
[  8121.673] (II) event24 - Logitech Gaming Mouse G502 Consumer Control: device is a keyboard
[  8121.678] (II) systemd-logind: got resume for 13:67
[  8121.679] (II) event3  - Eee PC WMI hotkeys: is tagged by udev as: Keyboard
[  8121.679] (II) event3  - Eee PC WMI hotkeys: device is a keyboard
[  8121.679] (II) systemd-logind: got resume for 13:77
[  8121.680] (II) event13 - Logitech Logitech Gaming Keyboard Consumer Control: is tagged by udev as: Keyboard
[  8121.680] (II) event13 - Logitech Logitech Gaming Keyboard Consumer Control: device is a keyboard
[  8121.681] (II) systemd-logind: got resume for 13:65
[  8121.681] (II) event1  - Power Button: is tagged by udev as: Keyboard
[  8121.681] (II) event1  - Power Button: device is a keyboard
[  8121.687] (II) systemd-logind: got resume for 13:69
[  8121.688] (II) event5  - Logitech Logitech Gaming Keyboard: is tagged by udev as: Keyboard
[  8121.688] (II) event5  - Logitech Logitech Gaming Keyboard: device is a keyboard
[  8121.691] (II) systemd-logind: got resume for 13:68
[  8121.692] (II) event4  - Valve Software Steam Controller: is tagged by udev as: Keyboard Mouse
[  8121.692] (II) event4  - Valve Software Steam Controller: device is a pointer
[  8121.692] (II) event4  - Valve Software Steam Controller: device is a keyboard
[  8121.694] (II) systemd-logind: got resume for 13:87
[  8121.695] (II) event23 - Logitech Gaming Mouse G502 Keyboard: is tagged by udev as: Keyboard
[  8121.695] (II) event23 - Logitech Gaming Mouse G502 Keyboard: device is a keyboard
[  8121.696] (II) systemd-logind: got resume for 13:78
[  8121.707] (II) event14 - Logitech Gaming Keyboard Gaming Keys: is tagged by udev as: Keyboard
[  8121.707] (II) event14 - Logitech Gaming Keyboard Gaming Keys: device is a keyboard
[  8121.711] (II) systemd-logind: got resume for 13:89
[  8121.712] (II) event25 - Logitech Gaming Mouse G502 System Control: is tagged by udev as: Keyboard
[  8121.712] (II) event25 - Logitech Gaming Mouse G502 System Control: device is a keyboard
[  8121.712] (II) systemd-logind: got resume for 13:86
[  8121.713] (II) event22 - Logitech Gaming Mouse G502: is tagged by udev as: Mouse
[  8121.713] (II) event22 - Logitech Gaming Mouse G502: device set to 2400 DPI
[  8121.713] (II) event22 - Logitech Gaming Mouse G502: device is a pointer
[  8121.714] (--) NVIDIA(GPU-0): Idek Iiyama PLG2773H (DFP-2): connected
[  8121.714] (--) NVIDIA(GPU-0): Idek Iiyama PLG2773H (DFP-2): Internal DisplayPort
[  8121.714] (--) NVIDIA(GPU-0): Idek Iiyama PLG2773H (DFP-2): 960.0 MHz maximum pixel clock
[  8126.250] (--) NVIDIA(GPU-0): HPN HP ENVY 27s (DFP-1): connected
[  8126.250] (--) NVIDIA(GPU-0): HPN HP ENVY 27s (DFP-1): Internal TMDS
[  8126.250] (--) NVIDIA(GPU-0): HPN HP ENVY 27s (DFP-1): 600.0 MHz maximum pixel clock
[  8126.286] (--) NVIDIA(GPU-0): HPN HP ENVY 27s (DFP-1): connected
[  8126.286] (--) NVIDIA(GPU-0): HPN HP ENVY 27s (DFP-1): Internal TMDS
[  8126.286] (--) NVIDIA(GPU-0): HPN HP ENVY 27s (DFP-1): 600.0 MHz maximum pixel clock
[  8126.376] (--) NVIDIA(GPU-0): Idek Iiyama PLG2773H (DFP-2): connected
[  8126.376] (--) NVIDIA(GPU-0): Idek Iiyama PLG2773H (DFP-2): Internal DisplayPort
[  8126.376] (--) NVIDIA(GPU-0): Idek Iiyama PLG2773H (DFP-2): 960.0 MHz maximum pixel clock
[  8847.828] (--) NVIDIA(GPU-0): CRT-0: disconnected
[  8847.828] (--) NVIDIA(GPU-0): CRT-0: 400.0 MHz maximum pixel clock
[  8847.832] (--) NVIDIA(GPU-0): DFP-0: disconnected
[  8847.832] (--) NVIDIA(GPU-0): DFP-0: Internal TMDS
[  8847.832] (--) NVIDIA(GPU-0): DFP-0: 330.0 MHz maximum pixel clock
[  8847.866] (--) NVIDIA(GPU-0): HPN HP ENVY 27s (DFP-1): connected
[  8847.866] (--) NVIDIA(GPU-0): HPN HP ENVY 27s (DFP-1): Internal TMDS
[  8847.866] (--) NVIDIA(GPU-0): HPN HP ENVY 27s (DFP-1): 600.0 MHz maximum pixel clock
[  8847.866] (--) NVIDIA(GPU-0): Idek Iiyama PLG2773H (DFP-2): connected
[  8847.866] (--) NVIDIA(GPU-0): Idek Iiyama PLG2773H (DFP-2): Internal DisplayPort
[  8847.866] (--) NVIDIA(GPU-0): Idek Iiyama PLG2773H (DFP-2): 960.0 MHz maximum pixel clock
[  8847.867] (--) NVIDIA(GPU-0): DFP-3: disconnected
[  8847.867] (--) NVIDIA(GPU-0): DFP-3: Internal TMDS
[  8847.867] (--) NVIDIA(GPU-0): DFP-3: 165.0 MHz maximum pixel clock
[  8847.867] (--) NVIDIA(GPU-0): DFP-4: disconnected
[  8847.867] (--) NVIDIA(GPU-0): DFP-4: Internal TMDS
[  8847.867] (--) NVIDIA(GPU-0): DFP-4: 330.0 MHz maximum pixel clock
[  8847.872] (--) NVIDIA(GPU-0): CRT-0: disconnected
[  8847.872] (--) NVIDIA(GPU-0): CRT-0: 400.0 MHz maximum pixel clock
[  8847.876] (--) NVIDIA(GPU-0): DFP-0: disconnected
[  8847.876] (--) NVIDIA(GPU-0): DFP-0: Internal TMDS
[  8847.876] (--) NVIDIA(GPU-0): DFP-0: 330.0 MHz maximum pixel clock
[  8847.911] (--) NVIDIA(GPU-0): HPN HP ENVY 27s (DFP-1): connected
[  8847.911] (--) NVIDIA(GPU-0): HPN HP ENVY 27s (DFP-1): Internal TMDS
[  8847.911] (--) NVIDIA(GPU-0): HPN HP ENVY 27s (DFP-1): 600.0 MHz maximum pixel clock
[  8847.911] (--) NVIDIA(GPU-0): Idek Iiyama PLG2773H (DFP-2): connected
[  8847.911] (--) NVIDIA(GPU-0): Idek Iiyama PLG2773H (DFP-2): Internal DisplayPort
[  8847.911] (--) NVIDIA(GPU-0): Idek Iiyama PLG2773H (DFP-2): 960.0 MHz maximum pixel clock
[  8847.912] (--) NVIDIA(GPU-0): DFP-3: disconnected
[  8847.912] (--) NVIDIA(GPU-0): DFP-3: Internal TMDS
[  8847.912] (--) NVIDIA(GPU-0): DFP-3: 165.0 MHz maximum pixel clock
[  8847.912] (--) NVIDIA(GPU-0): DFP-4: disconnected
[  8847.912] (--) NVIDIA(GPU-0): DFP-4: Internal TMDS
[  8847.912] (--) NVIDIA(GPU-0): DFP-4: 330.0 MHz maximum pixel clock
[  8855.316] (--) NVIDIA(GPU-0): CRT-0: disconnected
[  8855.316] (--) NVIDIA(GPU-0): CRT-0: 400.0 MHz maximum pixel clock
[  8855.320] (--) NVIDIA(GPU-0): DFP-0: disconnected
[  8855.320] (--) NVIDIA(GPU-0): DFP-0: Internal TMDS
[  8855.320] (--) NVIDIA(GPU-0): DFP-0: 330.0 MHz maximum pixel clock
[  8855.355] (--) NVIDIA(GPU-0): HPN HP ENVY 27s (DFP-1): connected
[  8855.355] (--) NVIDIA(GPU-0): HPN HP ENVY 27s (DFP-1): Internal TMDS
[  8855.355] (--) NVIDIA(GPU-0): HPN HP ENVY 27s (DFP-1): 600.0 MHz maximum pixel clock
[  8855.355] (--) NVIDIA(GPU-0): Idek Iiyama PLG2773H (DFP-2): connected
[  8855.355] (--) NVIDIA(GPU-0): Idek Iiyama PLG2773H (DFP-2): Internal DisplayPort
[  8855.355] (--) NVIDIA(GPU-0): Idek Iiyama PLG2773H (DFP-2): 960.0 MHz maximum pixel clock
[  8855.356] (--) NVIDIA(GPU-0): DFP-3: disconnected
[  8855.356] (--) NVIDIA(GPU-0): DFP-3: Internal TMDS
[  8855.356] (--) NVIDIA(GPU-0): DFP-3: 165.0 MHz maximum pixel clock
[  8855.356] (--) NVIDIA(GPU-0): DFP-4: disconnected
[  8855.356] (--) NVIDIA(GPU-0): DFP-4: Internal TMDS
[  8855.356] (--) NVIDIA(GPU-0): DFP-4: 330.0 MHz maximum pixel clock
[  8855.362] (--) NVIDIA(GPU-0): CRT-0: disconnected
[  8855.362] (--) NVIDIA(GPU-0): CRT-0: 400.0 MHz maximum pixel clock
[  8855.366] (--) NVIDIA(GPU-0): DFP-0: disconnected
[  8855.366] (--) NVIDIA(GPU-0): DFP-0: Internal TMDS
[  8855.366] (--) NVIDIA(GPU-0): DFP-0: 330.0 MHz maximum pixel clock
[  8855.401] (--) NVIDIA(GPU-0): HPN HP ENVY 27s (DFP-1): connected
[  8855.401] (--) NVIDIA(GPU-0): HPN HP ENVY 27s (DFP-1): Internal TMDS
[  8855.401] (--) NVIDIA(GPU-0): HPN HP ENVY 27s (DFP-1): 600.0 MHz maximum pixel clock
[  8855.401] (--) NVIDIA(GPU-0): Idek Iiyama PLG2773H (DFP-2): connected
[  8855.401] (--) NVIDIA(GPU-0): Idek Iiyama PLG2773H (DFP-2): Internal DisplayPort
[  8855.401] (--) NVIDIA(GPU-0): Idek Iiyama PLG2773H (DFP-2): 960.0 MHz maximum pixel clock
[  8855.402] (--) NVIDIA(GPU-0): DFP-3: disconnected
[  8855.402] (--) NVIDIA(GPU-0): DFP-3: Internal TMDS
[  8855.402] (--) NVIDIA(GPU-0): DFP-3: 165.0 MHz maximum pixel clock
[  8855.402] (--) NVIDIA(GPU-0): DFP-4: disconnected
[  8855.402] (--) NVIDIA(GPU-0): DFP-4: Internal TMDS
[  8855.402] (--) NVIDIA(GPU-0): DFP-4: 330.0 MHz maximum pixel clock
[  8855.412] (--) NVIDIA(GPU-0): CRT-0: disconnected
[  8855.412] (--) NVIDIA(GPU-0): CRT-0: 400.0 MHz maximum pixel clock
[  8855.416] (--) NVIDIA(GPU-0): DFP-0: disconnected
[  8855.416] (--) NVIDIA(GPU-0): DFP-0: Internal TMDS
[  8855.417] (--) NVIDIA(GPU-0): DFP-0: 330.0 MHz maximum pixel clock
[  8855.451] (--) NVIDIA(GPU-0): HPN HP ENVY 27s (DFP-1): connected
[  8855.451] (--) NVIDIA(GPU-0): HPN HP ENVY 27s (DFP-1): Internal TMDS
[  8855.451] (--) NVIDIA(GPU-0): HPN HP ENVY 27s (DFP-1): 600.0 MHz maximum pixel clock
[  8855.451] (--) NVIDIA(GPU-0): Idek Iiyama PLG2773H (DFP-2): connected
[  8855.451] (--) NVIDIA(GPU-0): Idek Iiyama PLG2773H (DFP-2): Internal DisplayPort
[  8855.451] (--) NVIDIA(GPU-0): Idek Iiyama PLG2773H (DFP-2): 960.0 MHz maximum pixel clock
[  8855.452] (--) NVIDIA(GPU-0): DFP-3: disconnected
[  8855.452] (--) NVIDIA(GPU-0): DFP-3: Internal TMDS
[  8855.452] (--) NVIDIA(GPU-0): DFP-3: 165.0 MHz maximum pixel clock
[  8855.452] (--) NVIDIA(GPU-0): DFP-4: disconnected
[  8855.452] (--) NVIDIA(GPU-0): DFP-4: Internal TMDS
[  8855.452] (--) NVIDIA(GPU-0): DFP-4: 330.0 MHz maximum pixel clock
[  9125.151] (EE) client bug: timer event22 debounce short: scheduled expiry is in the past (-3ms), your system is too slow
[  9372.345] (EE) client bug: timer event22 debounce short: scheduled expiry is in the past (-8ms), your system is too slow
[  9815.085] (II) NVIDIA(0): Setting mode "DPY-2:3840x2160_60+0+0,DPY-3:1920x1080_144+3840+0"
[  9815.318] (II) NVIDIA(0): Setting mode "HDMI-0: 3840x2160_60 @3840x2160 +0+0 {ViewPortIn=3840x2160, ViewPortOut=3840x2160+0+0}, DP-0: nvidia-auto-select @1920x1080 +3840+0 {ViewPortIn=1920x1080, ViewPortOut=1920x1080+0+0}"
[  9815.427] (II) NVIDIA(0): Setting mode "HDMI-0: nvidia-auto-select @3840x2160 +0+0 {ViewPortIn=3840x2160, ViewPortOut=3840x2160+0+0}, DP-0: nvidia-auto-select @1920x1080 +3840+0 {ViewPortIn=1920x1080, ViewPortOut=1920x1080+0+0}"
[  9815.563] (--) NVIDIA(GPU-0): CRT-0: disconnected
[  9815.563] (--) NVIDIA(GPU-0): CRT-0: 400.0 MHz maximum pixel clock
[  9815.567] (--) NVIDIA(GPU-0): DFP-0: disconnected
[  9815.567] (--) NVIDIA(GPU-0): DFP-0: Internal TMDS
[  9815.567] (--) NVIDIA(GPU-0): DFP-0: 330.0 MHz maximum pixel clock
[  9815.602] (--) NVIDIA(GPU-0): HPN HP ENVY 27s (DFP-1): connected
[  9815.602] (--) NVIDIA(GPU-0): HPN HP ENVY 27s (DFP-1): Internal TMDS
[  9815.602] (--) NVIDIA(GPU-0): HPN HP ENVY 27s (DFP-1): 600.0 MHz maximum pixel clock
[  9815.602] (--) NVIDIA(GPU-0): Idek Iiyama PLG2773H (DFP-2): connected
[  9815.602] (--) NVIDIA(GPU-0): Idek Iiyama PLG2773H (DFP-2): Internal DisplayPort
[  9815.602] (--) NVIDIA(GPU-0): Idek Iiyama PLG2773H (DFP-2): 960.0 MHz maximum pixel clock
[  9815.603] (--) NVIDIA(GPU-0): DFP-3: disconnected
[  9815.603] (--) NVIDIA(GPU-0): DFP-3: Internal TMDS
[  9815.603] (--) NVIDIA(GPU-0): DFP-3: 165.0 MHz maximum pixel clock
[  9815.603] (--) NVIDIA(GPU-0): DFP-4: disconnected
[  9815.603] (--) NVIDIA(GPU-0): DFP-4: Internal TMDS
[  9815.603] (--) NVIDIA(GPU-0): DFP-4: 330.0 MHz maximum pixel clock
[ 11440.378] (EE) client bug: timer event22 debounce short: scheduled expiry is in the past (-3ms), your system is too slow
[ 12315.044] (EE) client bug: timer event22 debounce: scheduled expiry is in the past (-22ms), your system is too slow
[ 12315.044] (EE) client bug: timer event22 debounce short: scheduled expiry is in the past (-35ms), your system is too slow
[ 12681.859] (--) NVIDIA(GPU-0): CRT-0: disconnected
[ 12681.859] (--) NVIDIA(GPU-0): CRT-0: 400.0 MHz maximum pixel clock
[ 12681.864] (--) NVIDIA(GPU-0): DFP-0: disconnected
[ 12681.864] (--) NVIDIA(GPU-0): DFP-0: Internal TMDS
[ 12681.864] (--) NVIDIA(GPU-0): DFP-0: 330.0 MHz maximum pixel clock
[ 12681.900] (--) NVIDIA(GPU-0): HPN HP ENVY 27s (DFP-1): connected
[ 12681.900] (--) NVIDIA(GPU-0): HPN HP ENVY 27s (DFP-1): Internal TMDS
[ 12681.900] (--) NVIDIA(GPU-0): HPN HP ENVY 27s (DFP-1): 600.0 MHz maximum pixel clock
[ 12681.900] (--) NVIDIA(GPU-0): Idek Iiyama PLG2773H (DFP-2): connected
[ 12681.900] (--) NVIDIA(GPU-0): Idek Iiyama PLG2773H (DFP-2): Internal DisplayPort
[ 12681.900] (--) NVIDIA(GPU-0): Idek Iiyama PLG2773H (DFP-2): 960.0 MHz maximum pixel clock
[ 12681.901] (--) NVIDIA(GPU-0): DFP-3: disconnected
[ 12681.901] (--) NVIDIA(GPU-0): DFP-3: Internal TMDS
[ 12681.901] (--) NVIDIA(GPU-0): DFP-3: 165.0 MHz maximum pixel clock
[ 12681.901] (--) NVIDIA(GPU-0): DFP-4: disconnected
[ 12681.901] (--) NVIDIA(GPU-0): DFP-4: Internal TMDS
[ 12681.901] (--) NVIDIA(GPU-0): DFP-4: 330.0 MHz maximum pixel clock
[ 13143.870] (EE) client bug: timer event22 debounce short: scheduled expiry is in the past (-8ms), your system is too slow
[ 13160.460] (EE) client bug: timer event22 debounce: scheduled expiry is in the past (-51ms), your system is too slow
[ 13160.460] (EE) client bug: timer event22 debounce short: scheduled expiry is in the past (-64ms), your system is too slow
[ 13241.719] (EE) client bug: timer event22 debounce short: scheduled expiry is in the past (-0ms), your system is too slow
[ 13362.991] (EE) client bug: timer event22 debounce short: scheduled expiry is in the past (-3ms), your system is too slow
[ 13414.855] (--) NVIDIA(GPU-0): CRT-0: disconnected
[ 13414.855] (--) NVIDIA(GPU-0): CRT-0: 400.0 MHz maximum pixel clock
[ 13414.859] (--) NVIDIA(GPU-0): DFP-0: disconnected
[ 13414.859] (--) NVIDIA(GPU-0): DFP-0: Internal TMDS
[ 13414.859] (--) NVIDIA(GPU-0): DFP-0: 330.0 MHz maximum pixel clock
[ 13414.894] (--) NVIDIA(GPU-0): HPN HP ENVY 27s (DFP-1): connected
[ 13414.894] (--) NVIDIA(GPU-0): HPN HP ENVY 27s (DFP-1): Internal TMDS
[ 13414.894] (--) NVIDIA(GPU-0): HPN HP ENVY 27s (DFP-1): 600.0 MHz maximum pixel clock
[ 13414.894] (--) NVIDIA(GPU-0): Idek Iiyama PLG2773H (DFP-2): connected
[ 13414.894] (--) NVIDIA(GPU-0): Idek Iiyama PLG2773H (DFP-2): Internal DisplayPort
[ 13414.894] (--) NVIDIA(GPU-0): Idek Iiyama PLG2773H (DFP-2): 960.0 MHz maximum pixel clock
[ 13414.895] (--) NVIDIA(GPU-0): DFP-3: disconnected
[ 13414.895] (--) NVIDIA(GPU-0): DFP-3: Internal TMDS
[ 13414.895] (--) NVIDIA(GPU-0): DFP-3: 165.0 MHz maximum pixel clock
[ 13414.895] (--) NVIDIA(GPU-0): DFP-4: disconnected
[ 13414.895] (--) NVIDIA(GPU-0): DFP-4: Internal TMDS
[ 13414.895] (--) NVIDIA(GPU-0): DFP-4: 330.0 MHz maximum pixel clock
____________________________________________
*** /var/log/Xorg.1.log
*** ls: -rw-r--r-- 1 root user 60202 2020-06-25 19:57:38.533205216 +0200 /var/log/Xorg.1.log
[  9213.251] (WW) Failed to open protocol names file lib/xorg/protocol.txt
[  9213.252]
X.Org X Server 1.20.8
X Protocol Version 11, Revision 0
[  9213.253] Build Operating System: Linux Arch Linux
[  9213.254] Current Operating System: Linux localhost 5.7.4-arch1-1 #1 SMP PREEMPT Thu, 18 Jun 2020 16:01:07 +0000 x86_64
[  9213.254] Kernel command line: root=UUID=6c37d730-4b14-4479-8554-92d2e75478d5 rw initrd=\initramfs-linux.img
[  9213.254] Build Date: 05 May 2020  05:08:17AM
[  9213.255]
[  9213.255] Current version of pixman: 0.40.0
[  9213.256] 	Before reporting problems, check http://wiki.x.org
	to make sure that you have the latest version.
[  9213.256] Markers: (--) probed, (**) from config file, (==) default setting,
	(++) from command line, (!!) notice, (II) informational,
	(WW) warning, (EE) error, (NI) not implemented, (??) unknown.
[  9213.258] (==) Log file: "/var/log/Xorg.1.log", Time: Thu Jun 25 19:14:27 2020
[  9213.259] (==) Using config file: "/etc/X11/xorg.conf"
[  9213.259] (==) Using config directory: "/etc/X11/xorg.conf.d"
[  9213.259] (==) Using system config directory "/usr/share/X11/xorg.conf.d"
[  9213.260] (==) ServerLayout "Layout0"
[  9213.260] (**) |-->Screen "Screen0" (0)
[  9213.260] (**) |   |-->Monitor "Monitor0"
[  9213.260] (**) |   |-->Device "Device0"
[  9213.260] (**) |   |-->GPUDevice "Device0"
[  9213.260] (**) |-->Input Device "Keyboard0"
[  9213.260] (**) |-->Input Device "Mouse0"
[  9213.260] (**) Option "Xinerama" "0"
[  9213.260] (==) Automatically adding devices
[  9213.260] (==) Automatically enabling devices
[  9213.260] (==) Automatically adding GPU devices
[  9213.260] (==) Automatically binding GPU devices
[  9213.260] (==) Max clients allowed: 256, resource mask: 0x1fffff
[  9213.260] (WW) `fonts.dir' not found (or not valid) in "/usr/share/fonts/OTF".
[  9213.260] 	Entry deleted from font path.
[  9213.260] 	(Run 'mkfontdir' on "/usr/share/fonts/OTF").
[  9213.260] (WW) The directory "/usr/share/fonts/Type1" does not exist.
[  9213.260] (WW) The directory "/usr/share/fonts/100dpi" does not exist.
[  9213.260] (WW) The directory "/usr/share/fonts/75dpi" does not exist.
[  9213.260] (==) FontPath set to:
	/usr/share/fonts/misc,
	/usr/share/fonts/TTF
[  9213.260] (==) ModulePath set to "/usr/lib/xorg/modules"
[  9213.260] (WW) Hotplugging is on, devices using drivers 'kbd', 'mouse' or 'vmmouse' will be disabled.
[  9213.260] (WW) Disabling Keyboard0
[  9213.260] (WW) Disabling Mouse0
[  9213.260] (II) Module ABI versions:
[  9213.260] 	X.Org ANSI C Emulation: 0.4
[  9213.260] 	X.Org Video Driver: 24.1
[  9213.260] 	X.Org XInput driver : 24.1
[  9213.260] 	X.Org Server Extension : 10.0
[  9213.261] (++) using VT number 1
[  9213.262] (II) systemd-logind: took control of session /org/freedesktop/login1/session/_33
[  9213.262] (II) xfree86: Adding drm device (/dev/dri/card0)
[  9213.262] (II) systemd-logind: got fd for /dev/dri/card0 226:0 fd 10 paused 0
[  9213.263] (**) OutputClass "nvidia" ModulePath extended to "/usr/lib/nvidia/xorg,/usr/lib/xorg/modules,/usr/lib/xorg/modules"
[  9213.264] (--) PCI:*(1@0:0:0) 10de:13c2:1462:3160 rev 161, Mem @ 0xde000000/16777216, 0xc0000000/268435456, 0xd0000000/33554432, I/O @ 0x0000e000/128, BIOS @ 0x????????/131072
[  9213.264] (WW) Open ACPI failed (/var/run/acpid.socket) (No such file or directory)
[  9213.264] (II) LoadModule: "glx"
[  9213.264] (II) Loading /usr/lib/xorg/modules/extensions/libglx.so
[  9213.265] (II) Module glx: vendor="X.Org Foundation"
[  9213.265] 	compiled for 1.20.8, module version = 1.0.0
[  9213.265] 	ABI class: X.Org Server Extension, version 10.0
[  9213.265] (II) LoadModule: "nvidia"
[  9213.265] (II) Loading /usr/lib/xorg/modules/drivers/nvidia_drv.so
[  9213.265] (II) Module nvidia: vendor="NVIDIA Corporation"
[  9213.265] 	compiled for 1.6.99.901, module version = 1.0.0
[  9213.265] 	Module class: X.Org Video Driver
[  9213.265] (II) NVIDIA dlloader X Driver  440.82  Wed Apr  1 19:50:17 UTC 2020
[  9213.265] (II) NVIDIA Unified Driver for all Supported NVIDIA GPUs
[  9213.265] (II) systemd-logind: releasing fd for 226:0
[  9213.265] (II) Loading sub module "fb"
[  9213.265] (II) LoadModule: "fb"
[  9213.265] (II) Loading /usr/lib/xorg/modules/libfb.so
[  9213.266] (II) Module fb: vendor="X.Org Foundation"
[  9213.266] 	compiled for 1.20.8, module version = 1.0.0
[  9213.266] 	ABI class: X.Org ANSI C Emulation, version 0.4
[  9213.266] (II) Loading sub module "wfb"
[  9213.266] (II) LoadModule: "wfb"
[  9213.266] (II) Loading /usr/lib/xorg/modules/libwfb.so
[  9213.266] (II) Module wfb: vendor="X.Org Foundation"
[  9213.266] (II) Loading sub module "ramdac"
[  9213.266] (II) LoadModule: "ramdac"
[  9213.266] (II) Module "ramdac" already built-in
[  9213.266] (**) NVIDIA(0): Depth 24, (--) framebuffer bpp 32
[  9213.266] (==) NVIDIA(0): RGB weight 888
[  9213.266] (==) NVIDIA(0): Default visual is TrueColor
[  9213.266] (==) NVIDIA(0): Using gamma correction (1.0, 1.0, 1.0)
[  9213.266] (II) Applying OutputClass "nvidia" options to /dev/dri/card0
[  9213.266] (**) NVIDIA(0): Option "Stereo" "0"
[  9213.266] (**) NVIDIA(0): Option "nvidiaXineramaInfoOrder" "DFP-1"
[  9213.266] (**) NVIDIA(0): Option "SLI" "Off"
[  9213.266] (**) NVIDIA(0): Option "MultiGPU" "Off"
[  9213.266] (**) NVIDIA(0): Option "BaseMosaic" "off"
[  9213.266] (**) NVIDIA(0): Option "AllowEmptyInitialConfiguration"
[  9213.266] (**) NVIDIA(0): Stereo disabled by request
[  9213.266] (**) NVIDIA(0): NVIDIA SLI disabled.
[  9213.266] (**) NVIDIA(0): NVIDIA Multi-GPU disabled.
[  9213.266] (**) NVIDIA(0): Option "MetaModes" "HDMI-0: 3840x2160_60 +0+0, DP-0: 1920x1080_144 +3840+0"
[  9213.266] (**) NVIDIA(0): Enabling 2D acceleration
[  9213.266] (II) Loading sub module "glxserver_nvidia"
[  9213.266] (II) LoadModule: "glxserver_nvidia"
[  9213.266] (II) Loading /usr/lib/nvidia/xorg/libglxserver_nvidia.so
[  9213.270] (II) Module glxserver_nvidia: vendor="NVIDIA Corporation"
[  9213.270] 	compiled for 1.6.99.901, module version = 1.0.0
[  9213.270] 	Module class: X.Org Server Extension
[  9213.270] (II) NVIDIA GLX Module  440.82  Wed Apr  1 19:47:36 UTC 2020
[  9213.270] (II) NVIDIA: The X server supports PRIME Render Offload.
[  9213.271] (--) NVIDIA(0): Valid display device(s) on GPU-0 at PCI:1:0:0
[  9213.271] (--) NVIDIA(0):     CRT-0
[  9213.271] (--) NVIDIA(0):     DFP-0
[  9213.271] (--) NVIDIA(0):     DFP-1
[  9213.271] (--) NVIDIA(0):     DFP-2 (boot)
[  9213.271] (--) NVIDIA(0):     DFP-3
[  9213.271] (--) NVIDIA(0):     DFP-4
[  9213.272] (II) NVIDIA(0): NVIDIA GPU GeForce GTX 970 (GM204-A) at PCI:1:0:0 (GPU-0)
[  9213.272] (--) NVIDIA(0): Memory: 4194304 kBytes
[  9213.272] (--) NVIDIA(0): VideoBIOS: 84.04.2f.00.f1
[  9213.272] (II) NVIDIA(0): Detected PCI Express Link width: 16X
[  9213.277] (--) NVIDIA(GPU-0): CRT-0: disconnected
[  9213.277] (--) NVIDIA(GPU-0): CRT-0: 400.0 MHz maximum pixel clock
[  9213.281] (--) NVIDIA(GPU-0): DFP-0: disconnected
[  9213.281] (--) NVIDIA(GPU-0): DFP-0: Internal TMDS
[  9213.281] (--) NVIDIA(GPU-0): DFP-0: 330.0 MHz maximum pixel clock
[  9213.281] (--) NVIDIA(GPU-0): DFP-1: disconnected
[  9213.281] (--) NVIDIA(GPU-0): DFP-1: Internal TMDS
[  9213.281] (--) NVIDIA(GPU-0): DFP-1: 165.0 MHz maximum pixel clock
[  9213.281] (--) NVIDIA(GPU-0): HPN HP ENVY 27s (DFP-2): connected
[  9213.281] (--) NVIDIA(GPU-0): HPN HP ENVY 27s (DFP-2): Internal DisplayPort
[  9213.281] (--) NVIDIA(GPU-0): HPN HP ENVY 27s (DFP-2): 960.0 MHz maximum pixel clock
[  9213.283] (--) NVIDIA(GPU-0): DFP-3: disconnected
[  9213.283] (--) NVIDIA(GPU-0): DFP-3: Internal TMDS
[  9213.283] (--) NVIDIA(GPU-0): DFP-3: 165.0 MHz maximum pixel clock
[  9213.283] (--) NVIDIA(GPU-0): DFP-4: disconnected
[  9213.283] (--) NVIDIA(GPU-0): DFP-4: Internal TMDS
[  9213.283] (--) NVIDIA(GPU-0): DFP-4: 330.0 MHz maximum pixel clock
[  9213.286] (WW) NVIDIA(0): No valid modes for
[  9213.286] (WW) NVIDIA(0):     "HDMI-0:3840x2160_60+0+0,DP-0:1920x1080_144+3840+0";
[  9213.286] (WW) NVIDIA(0):     removing.
[  9213.286] (WW) NVIDIA(0): Unable to validate any modes; falling back to the default mode
[  9213.286] (WW) NVIDIA(0):     "nvidia-auto-select".
[  9213.286] (II) NVIDIA(0): Validated MetaModes:
[  9213.286] (II) NVIDIA(0):     "DFP-2:nvidia-auto-select"
[  9213.286] (II) NVIDIA(0): Virtual screen size determined to be 3840 x 2160
[  9213.293] (--) NVIDIA(0): DPI set to (162, 161); computed from "UseEdidDpi" X config
[  9213.293] (--) NVIDIA(0):     option
[  9213.294] (II) NVIDIA: Using 6144.00 MB of virtual memory for indirect memory
[  9213.294] (II) NVIDIA:     access.
[  9213.296] (II) NVIDIA(0): ACPI: failed to connect to the ACPI event daemon; the daemon
[  9213.296] (II) NVIDIA(0):     may not be running or the "AcpidSocketPath" X
[  9213.296] (II) NVIDIA(0):     configuration option may not be set correctly.  When the
[  9213.296] (II) NVIDIA(0):     ACPI event daemon is available, the NVIDIA X driver will
[  9213.296] (II) NVIDIA(0):     try to use it to receive ACPI event notifications.  For
[  9213.296] (II) NVIDIA(0):     details, please see the "ConnectToAcpid" and
[  9213.296] (II) NVIDIA(0):     "AcpidSocketPath" X configuration options in Appendix B: X
[  9213.296] (II) NVIDIA(0):     Config Options in the README.
[  9213.323] (II) NVIDIA(0): Setting mode "DFP-2:nvidia-auto-select"
[  9213.410] (==) NVIDIA(0): Disabling shared memory pixmaps
[  9213.411] (==) NVIDIA(0): Backing store enabled
[  9213.411] (==) NVIDIA(0): Silken mouse disabled
[  9213.411] (**) NVIDIA(0): DPMS enabled
[  9213.411] (II) Loading sub module "dri2"
[  9213.411] (II) LoadModule: "dri2"
[  9213.411] (II) Module "dri2" already built-in
[  9213.411] (II) NVIDIA(0): [DRI2] Setup complete
[  9213.411] (II) NVIDIA(0): [DRI2]   VDPAU driver: nvidia
[  9213.411] (II) Initializing extension Generic Event Extension
[  9213.411] (II) Initializing extension SHAPE
[  9213.411] (II) Initializing extension MIT-SHM
[  9213.411] (II) Initializing extension XInputExtension
[  9213.411] (II) Initializing extension XTEST
[  9213.411] (II) Initializing extension BIG-REQUESTS
[  9213.411] (II) Initializing extension SYNC
[  9213.411] (II) Initializing extension XKEYBOARD
[  9213.411] (II) Initializing extension XC-MISC
[  9213.411] (II) Initializing extension SECURITY
[  9213.411] (II) Initializing extension XFIXES
[  9213.411] (II) Initializing extension RENDER
[  9213.411] (II) Initializing extension RANDR
[  9213.411] (II) Initializing extension COMPOSITE
[  9213.411] (II) Initializing extension DAMAGE
[  9213.411] (II) Initializing extension MIT-SCREEN-SAVER
[  9213.411] (II) Initializing extension DOUBLE-BUFFER
[  9213.411] (II) Initializing extension RECORD
[  9213.411] (II) Initializing extension DPMS
[  9213.411] (II) Initializing extension Present
[  9213.411] (II) Initializing extension DRI3
[  9213.411] (II) Initializing extension X-Resource
[  9213.411] (II) Initializing extension XVideo
[  9213.411] (II) Initializing extension XVideo-MotionCompensation
[  9213.411] (II) Initializing extension GLX
[  9213.411] (II) Indirect GLX disabled.
[  9213.411] (II) GLX: Another vendor is already registered for screen 0
[  9213.411] (II) Initializing extension XFree86-VidModeExtension
[  9213.411] (II) Initializing extension XFree86-DGA
[  9213.411] (II) Initializing extension XFree86-DRI
[  9213.411] (II) Initializing extension DRI2
[  9213.411] (II) Initializing extension NV-GLX
[  9213.411] (II) Initializing extension NV-CONTROL
[  9213.411] (II) Initializing extension XINERAMA
[  9213.435] (II) config/udev: Adding input device Power Button (/dev/input/event1)
[  9213.435] (**) Power Button: Applying InputClass "libinput keyboard catchall"
[  9213.435] (**) Power Button: Applying InputClass "system-keyboard"
[  9213.435] (II) LoadModule: "libinput"
[  9213.435] (II) Loading /usr/lib/xorg/modules/input/libinput_drv.so
[  9213.437] (II) Module libinput: vendor="X.Org Foundation"
[  9213.437] 	compiled for 1.20.8, module version = 0.30.0
[  9213.437] 	Module class: X.Org XInput Driver
[  9213.437] 	ABI class: X.Org XInput driver, version 24.1
[  9213.437] (II) Using input driver 'libinput' for 'Power Button'
[  9213.437] (II) systemd-logind: got fd for /dev/input/event1 13:65 fd 32 paused 0
[  9213.437] (**) Power Button: always reports core events
[  9213.437] (**) Option "Device" "/dev/input/event1"
[  9213.437] (**) Option "_source" "server/udev"
[  9213.438] (II) event1  - Power Button: is tagged by udev as: Keyboard
[  9213.439] (II) event1  - Power Button: device is a keyboard
[  9213.439] (II) event1  - Power Button: device removed
[  9213.439] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXPWRBN:00/input/input1/event1"
[  9213.439] (II) XINPUT: Adding extended input device "Power Button" (type: KEYBOARD, id 6)
[  9213.439] (**) Option "xkb_model" "fr-latin1"
[  9213.439] (**) Option "xkb_layout" "fr"
[  9213.452] (II) event1  - Power Button: is tagged by udev as: Keyboard
[  9213.452] (II) event1  - Power Button: device is a keyboard
[  9213.452] (II) config/udev: Adding input device Power Button (/dev/input/event0)
[  9213.452] (**) Power Button: Applying InputClass "libinput keyboard catchall"
[  9213.452] (**) Power Button: Applying InputClass "system-keyboard"
[  9213.452] (II) Using input driver 'libinput' for 'Power Button'
[  9213.453] (II) systemd-logind: got fd for /dev/input/event0 13:64 fd 35 paused 0
[  9213.453] (**) Power Button: always reports core events
[  9213.453] (**) Option "Device" "/dev/input/event0"
[  9213.453] (**) Option "_source" "server/udev"
[  9213.454] (II) event0  - Power Button: is tagged by udev as: Keyboard
[  9213.454] (II) event0  - Power Button: device is a keyboard
[  9213.454] (II) event0  - Power Button: device removed
[  9213.454] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0C:00/input/input0/event0"
[  9213.454] (II) XINPUT: Adding extended input device "Power Button" (type: KEYBOARD, id 7)
[  9213.454] (**) Option "xkb_model" "fr-latin1"
[  9213.454] (**) Option "xkb_layout" "fr"
[  9213.455] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=12 (/dev/input/event10)
[  9213.455] (II) No input driver specified, ignoring this device.
[  9213.455] (II) This device may have been added with another device file.
[  9213.455] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=3 (/dev/input/event4)
[  9213.455] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=7 (/dev/input/event5)
[  9213.455] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=8 (/dev/input/event6)
[  9213.456] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=9 (/dev/input/event7)
[  9213.456] (II) No input driver specified, ignoring this device.
[  9213.456] (II) This device may have been added with another device file.
[  9213.456] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=10 (/dev/input/event8)
[  9213.456] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=11 (/dev/input/event9)
[  9213.456] (II) config/udev: Adding input device Valve Software Steam Controller (/dev/input/event18)
[  9213.456] (**) Valve Software Steam Controller: Applying InputClass "libinput pointer catchall"
[  9213.456] (**) Valve Software Steam Controller: Applying InputClass "libinput keyboard catchall"
[  9213.456] (**) Valve Software Steam Controller: Applying InputClass "system-keyboard"
[  9213.456] (II) Using input driver 'libinput' for 'Valve Software Steam Controller'
[  9213.457] (II) systemd-logind: got fd for /dev/input/event18 13:82 fd 36 paused 0
[  9213.457] (**) Valve Software Steam Controller: always reports core events
[  9213.457] (**) Option "Device" "/dev/input/event18"
[  9213.457] (**) Option "_source" "server/udev"
[  9213.458] (II) event18 - Valve Software Steam Controller: is tagged by udev as: Keyboard Mouse
[  9213.458] (II) event18 - Valve Software Steam Controller: device is a pointer
[  9213.458] (II) event18 - Valve Software Steam Controller: device is a keyboard
[  9213.458] (II) event18 - Valve Software Steam Controller: device removed
[  9213.458] (II) libinput: Valve Software Steam Controller: needs a virtual subdevice
[  9213.458] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:14.0/usb2/2-10/2-10:1.0/0003:28DE:1142.0001/input/input26/event18"
[  9213.458] (II) XINPUT: Adding extended input device "Valve Software Steam Controller" (type: MOUSE, id 8)
[  9213.458] (**) Option "AccelerationScheme" "none"
[  9213.458] (**) Valve Software Steam Controller: (accel) selected scheme none/0
[  9213.458] (**) Valve Software Steam Controller: (accel) acceleration factor: 2.000
[  9213.458] (**) Valve Software Steam Controller: (accel) acceleration threshold: 4
[  9213.459] (II) event18 - Valve Software Steam Controller: is tagged by udev as: Keyboard Mouse
[  9213.459] (II) event18 - Valve Software Steam Controller: device is a pointer
[  9213.459] (II) event18 - Valve Software Steam Controller: device is a keyboard
[  9213.459] (II) config/udev: Adding input device Valve Software Steam Controller (/dev/input/mouse1)
[  9213.459] (**) Valve Software Steam Controller: Applying InputClass "system-keyboard"
[  9213.459] (II) No input driver specified, ignoring this device.
[  9213.459] (II) This device may have been added with another device file.
[  9213.460] (II) config/udev: Adding input device Logitech Logitech Gaming Keyboard (/dev/input/event19)
[  9213.460] (**) Logitech Logitech Gaming Keyboard: Applying InputClass "libinput keyboard catchall"
[  9213.460] (**) Logitech Logitech Gaming Keyboard: Applying InputClass "system-keyboard"
[  9213.460] (II) Using input driver 'libinput' for 'Logitech Logitech Gaming Keyboard'
[  9213.460] (II) systemd-logind: got fd for /dev/input/event19 13:83 fd 37 paused 0
[  9213.460] (**) Logitech Logitech Gaming Keyboard: always reports core events
[  9213.460] (**) Option "Device" "/dev/input/event19"
[  9213.460] (**) Option "_source" "server/udev"
[  9213.461] (II) event19 - Logitech Logitech Gaming Keyboard: is tagged by udev as: Keyboard
[  9213.462] (II) event19 - Logitech Logitech Gaming Keyboard: device is a keyboard
[  9213.462] (II) event19 - Logitech Logitech Gaming Keyboard: device removed
[  9213.462] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:14.0/usb2/2-13/2-13.1/2-13.1:1.0/0003:046D:C221.000C/input/input27/event19"
[  9213.462] (II) XINPUT: Adding extended input device "Logitech Logitech Gaming Keyboard" (type: KEYBOARD, id 9)
[  9213.462] (**) Option "xkb_model" "fr-latin1"
[  9213.462] (**) Option "xkb_layout" "fr"
[  9213.463] (II) event19 - Logitech Logitech Gaming Keyboard: is tagged by udev as: Keyboard
[  9213.463] (II) event19 - Logitech Logitech Gaming Keyboard: device is a keyboard
[  9213.464] (II) config/udev: Adding input device Logitech Logitech Gaming Keyboard Consumer Control (/dev/input/event24)
[  9213.464] (**) Logitech Logitech Gaming Keyboard Consumer Control: Applying InputClass "libinput keyboard catchall"
[  9213.464] (**) Logitech Logitech Gaming Keyboard Consumer Control: Applying InputClass "system-keyboard"
[  9213.464] (II) Using input driver 'libinput' for 'Logitech Logitech Gaming Keyboard Consumer Control'
[  9213.464] (II) systemd-logind: got fd for /dev/input/event24 13:88 fd 38 paused 0
[  9213.464] (**) Logitech Logitech Gaming Keyboard Consumer Control: always reports core events
[  9213.464] (**) Option "Device" "/dev/input/event24"
[  9213.464] (**) Option "_source" "server/udev"
[  9213.466] (II) event24 - Logitech Logitech Gaming Keyboard Consumer Control: is tagged by udev as: Keyboard
[  9213.466] (II) event24 - Logitech Logitech Gaming Keyboard Consumer Control: device is a keyboard
[  9213.466] (II) event24 - Logitech Logitech Gaming Keyboard Consumer Control: device removed
[  9213.466] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:14.0/usb2/2-13/2-13.1/2-13.1:1.1/0003:046D:C221.000D/input/input28/event24"
[  9213.466] (II) XINPUT: Adding extended input device "Logitech Logitech Gaming Keyboard Consumer Control" (type: KEYBOARD, id 10)
[  9213.466] (**) Option "xkb_model" "fr-latin1"
[  9213.466] (**) Option "xkb_layout" "fr"
[  9213.467] (II) event24 - Logitech Logitech Gaming Keyboard Consumer Control: is tagged by udev as: Keyboard
[  9213.467] (II) event24 - Logitech Logitech Gaming Keyboard Consumer Control: device is a keyboard
[  9213.468] (II) config/udev: Adding input device Logitech Gaming Keyboard Gaming Keys (/dev/input/event25)
[  9213.468] (**) Logitech Gaming Keyboard Gaming Keys: Applying InputClass "libinput keyboard catchall"
[  9213.468] (**) Logitech Gaming Keyboard Gaming Keys: Applying InputClass "system-keyboard"
[  9213.468] (II) Using input driver 'libinput' for 'Logitech Gaming Keyboard Gaming Keys'
[  9213.468] (II) systemd-logind: got fd for /dev/input/event25 13:89 fd 39 paused 0
[  9213.468] (**) Logitech Gaming Keyboard Gaming Keys: always reports core events
[  9213.468] (**) Option "Device" "/dev/input/event25"
[  9213.468] (**) Option "_source" "server/udev"
[  9213.469] (II) event25 - Logitech Gaming Keyboard Gaming Keys: is tagged by udev as: Keyboard
[  9213.470] (II) event25 - Logitech Gaming Keyboard Gaming Keys: device is a keyboard
[  9213.470] (II) event25 - Logitech Gaming Keyboard Gaming Keys: device removed
[  9213.470] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:14.0/usb2/2-13/2-13.4/2-13.4:1.0/0003:046D:C222.000E/input/input32/event25"
[  9213.470] (II) XINPUT: Adding extended input device "Logitech Gaming Keyboard Gaming Keys" (type: KEYBOARD, id 11)
[  9213.470] (**) Option "xkb_model" "fr-latin1"
[  9213.470] (**) Option "xkb_layout" "fr"
[  9213.471] (II) event25 - Logitech Gaming Keyboard Gaming Keys: is tagged by udev as: Keyboard
[  9213.471] (II) event25 - Logitech Gaming Keyboard Gaming Keys: device is a keyboard
[  9213.471] (II) config/udev: Adding input device Logitech Gaming Mouse G502 (/dev/input/event20)
[  9213.471] (**) Logitech Gaming Mouse G502: Applying InputClass "libinput pointer catchall"
[  9213.471] (II) Using input driver 'libinput' for 'Logitech Gaming Mouse G502'
[  9213.472] (II) systemd-logind: got fd for /dev/input/event20 13:84 fd 40 paused 0
[  9213.472] (**) Logitech Gaming Mouse G502: always reports core events
[  9213.472] (**) Option "Device" "/dev/input/event20"
[  9213.472] (**) Option "_source" "server/udev"
[  9213.473] (II) event20 - Logitech Gaming Mouse G502: is tagged by udev as: Mouse
[  9213.473] (II) event20 - Logitech Gaming Mouse G502: device set to 2400 DPI
[  9213.473] (II) event20 - Logitech Gaming Mouse G502: device is a pointer
[  9213.473] (II) event20 - Logitech Gaming Mouse G502: device removed
[  9213.473] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:14.0/usb2/2-14/2-14:1.0/0003:046D:C332.0006/input/input20/event20"
[  9213.473] (II) XINPUT: Adding extended input device "Logitech Gaming Mouse G502" (type: MOUSE, id 12)
[  9213.473] (**) Option "AccelerationScheme" "none"
[  9213.473] (**) Logitech Gaming Mouse G502: (accel) selected scheme none/0
[  9213.473] (**) Logitech Gaming Mouse G502: (accel) acceleration factor: 2.000
[  9213.473] (**) Logitech Gaming Mouse G502: (accel) acceleration threshold: 4
[  9213.474] (II) event20 - Logitech Gaming Mouse G502: is tagged by udev as: Mouse
[  9213.474] (II) event20 - Logitech Gaming Mouse G502: device set to 2400 DPI
[  9213.474] (II) event20 - Logitech Gaming Mouse G502: device is a pointer
[  9213.474] (II) config/udev: Adding input device Logitech Gaming Mouse G502 (/dev/input/mouse0)
[  9213.474] (II) No input driver specified, ignoring this device.
[  9213.474] (II) This device may have been added with another device file.
[  9213.475] (II) config/udev: Adding input device Logitech Gaming Mouse G502 Keyboard (/dev/input/event21)
[  9213.475] (**) Logitech Gaming Mouse G502 Keyboard: Applying InputClass "libinput keyboard catchall"
[  9213.475] (**) Logitech Gaming Mouse G502 Keyboard: Applying InputClass "system-keyboard"
[  9213.475] (II) Using input driver 'libinput' for 'Logitech Gaming Mouse G502 Keyboard'
[  9213.475] (II) systemd-logind: got fd for /dev/input/event21 13:85 fd 41 paused 0
[  9213.475] (**) Logitech Gaming Mouse G502 Keyboard: always reports core events
[  9213.475] (**) Option "Device" "/dev/input/event21"
[  9213.475] (**) Option "_source" "server/udev"
[  9213.476] (II) event21 - Logitech Gaming Mouse G502 Keyboard: is tagged by udev as: Keyboard
[  9213.476] (II) event21 - Logitech Gaming Mouse G502 Keyboard: device is a keyboard
[  9213.476] (II) event21 - Logitech Gaming Mouse G502 Keyboard: device removed
[  9213.476] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:14.0/usb2/2-14/2-14:1.1/0003:046D:C332.0007/input/input21/event21"
[  9213.476] (II) XINPUT: Adding extended input device "Logitech Gaming Mouse G502 Keyboard" (type: KEYBOARD, id 13)
[  9213.476] (**) Option "xkb_model" "fr-latin1"
[  9213.476] (**) Option "xkb_layout" "fr"
[  9213.477] (II) event21 - Logitech Gaming Mouse G502 Keyboard: is tagged by udev as: Keyboard
[  9213.477] (II) event21 - Logitech Gaming Mouse G502 Keyboard: device is a keyboard
[  9213.478] (II) config/udev: Adding input device Logitech Gaming Mouse G502 Consumer Control (/dev/input/event22)
[  9213.478] (**) Logitech Gaming Mouse G502 Consumer Control: Applying InputClass "libinput keyboard catchall"
[  9213.478] (**) Logitech Gaming Mouse G502 Consumer Control: Applying InputClass "system-keyboard"
[  9213.478] (II) Using input driver 'libinput' for 'Logitech Gaming Mouse G502 Consumer Control'
[  9213.479] (II) systemd-logind: got fd for /dev/input/event22 13:86 fd 42 paused 0
[  9213.479] (**) Logitech Gaming Mouse G502 Consumer Control: always reports core events
[  9213.479] (**) Option "Device" "/dev/input/event22"
[  9213.479] (**) Option "_source" "server/udev"
[  9213.480] (II) event22 - Logitech Gaming Mouse G502 Consumer Control: is tagged by udev as: Keyboard
[  9213.480] (II) event22 - Logitech Gaming Mouse G502 Consumer Control: device is a keyboard
[  9213.480] (II) event22 - Logitech Gaming Mouse G502 Consumer Control: device removed
[  9213.480] (II) libinput: Logitech Gaming Mouse G502 Consumer Control: needs a virtual subdevice
[  9213.480] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:14.0/usb2/2-14/2-14:1.1/0003:046D:C332.0007/input/input22/event22"
[  9213.480] (II) XINPUT: Adding extended input device "Logitech Gaming Mouse G502 Consumer Control" (type: MOUSE, id 14)
[  9213.480] (**) Option "AccelerationScheme" "none"
[  9213.480] (**) Logitech Gaming Mouse G502 Consumer Control: (accel) selected scheme none/0
[  9213.480] (**) Logitech Gaming Mouse G502 Consumer Control: (accel) acceleration factor: 2.000
[  9213.480] (**) Logitech Gaming Mouse G502 Consumer Control: (accel) acceleration threshold: 4
[  9213.481] (II) event22 - Logitech Gaming Mouse G502 Consumer Control: is tagged by udev as: Keyboard
[  9213.481] (II) event22 - Logitech Gaming Mouse G502 Consumer Control: device is a keyboard
[  9213.481] (II) config/udev: Adding input device Logitech Gaming Mouse G502 System Control (/dev/input/event23)
[  9213.481] (**) Logitech Gaming Mouse G502 System Control: Applying InputClass "libinput keyboard catchall"
[  9213.481] (**) Logitech Gaming Mouse G502 System Control: Applying InputClass "system-keyboard"
[  9213.481] (II) Using input driver 'libinput' for 'Logitech Gaming Mouse G502 System Control'
[  9213.482] (II) systemd-logind: got fd for /dev/input/event23 13:87 fd 43 paused 0
[  9213.482] (**) Logitech Gaming Mouse G502 System Control: always reports core events
[  9213.482] (**) Option "Device" "/dev/input/event23"
[  9213.482] (**) Option "_source" "server/udev"
[  9213.482] (II) event23 - Logitech Gaming Mouse G502 System Control: is tagged by udev as: Keyboard
[  9213.483] (II) event23 - Logitech Gaming Mouse G502 System Control: device is a keyboard
[  9213.483] (II) event23 - Logitech Gaming Mouse G502 System Control: device removed
[  9213.483] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:14.0/usb2/2-14/2-14:1.1/0003:046D:C332.0007/input/input23/event23"
[  9213.483] (II) XINPUT: Adding extended input device "Logitech Gaming Mouse G502 System Control" (type: KEYBOARD, id 15)
[  9213.483] (**) Option "xkb_model" "fr-latin1"
[  9213.483] (**) Option "xkb_layout" "fr"
[  9213.483] (II) event23 - Logitech Gaming Mouse G502 System Control: is tagged by udev as: Keyboard
[  9213.484] (II) event23 - Logitech Gaming Mouse G502 System Control: device is a keyboard
[  9213.484] (II) config/udev: Adding input device HDA Intel PCH Front Mic (/dev/input/event11)
[  9213.484] (II) No input driver specified, ignoring this device.
[  9213.484] (II) This device may have been added with another device file.
[  9213.484] (II) config/udev: Adding input device HDA Intel PCH Rear Mic (/dev/input/event12)
[  9213.484] (II) config/udev: Adding input device HDA Intel PCH Line (/dev/input/event13)
[  9213.484] (II) config/udev: Adding input device HDA Intel PCH Line Out Front (/dev/input/event14)
[  9213.485] (II) config/udev: Adding input device HDA Intel PCH Line Out Surround (/dev/input/event15)
[  9213.485] (II) No input driver specified, ignoring this device.
[  9213.485] (II) This device may have been added with another device file.
[  9213.485] (II) config/udev: Adding input device HDA Intel PCH Line Out CLFE (/dev/input/event16)
[  9213.485] (II) config/udev: Adding input device HDA Intel PCH Front Headphone (/dev/input/event17)
[  9213.485] (II) config/udev: Adding input device Eee PC WMI hotkeys (/dev/input/event3)
[  9213.485] (**) Eee PC WMI hotkeys: Applying InputClass "libinput keyboard catchall"
[  9213.485] (**) Eee PC WMI hotkeys: Applying InputClass "system-keyboard"
[  9213.485] (II) Using input driver 'libinput' for 'Eee PC WMI hotkeys'
[  9213.486] (II) systemd-logind: got fd for /dev/input/event3 13:67 fd 44 paused 0
[  9213.486] (**) Eee PC WMI hotkeys: always reports core events
[  9213.486] (**) Option "Device" "/dev/input/event3"
[  9213.486] (**) Option "_source" "server/udev"
[  9213.486] (II) event3  - Eee PC WMI hotkeys: is tagged by udev as: Keyboard
[  9213.486] (II) event3  - Eee PC WMI hotkeys: device is a keyboard
[  9213.486] (II) event3  - Eee PC WMI hotkeys: device removed
[  9213.486] (**) Option "config_info" "udev:/sys/devices/platform/eeepc-wmi/input/input3/event3"
[  9213.486] (II) XINPUT: Adding extended input device "Eee PC WMI hotkeys" (type: KEYBOARD, id 16)
[  9213.486] (**) Option "xkb_model" "fr-latin1"
[  9213.486] (**) Option "xkb_layout" "fr"
[  9213.487] (II) event3  - Eee PC WMI hotkeys: is tagged by udev as: Keyboard
[  9213.487] (II) event3  - Eee PC WMI hotkeys: device is a keyboard
[  9213.487] (II) config/udev: Adding input device PC Speaker (/dev/input/event2)
[  9213.487] (II) No input driver specified, ignoring this device.
[  9213.487] (II) This device may have been added with another device file.
[  9213.489] (**) Valve Software Steam Controller: Applying InputClass "libinput pointer catchall"
[  9213.489] (**) Valve Software Steam Controller: Applying InputClass "libinput keyboard catchall"
[  9213.489] (**) Valve Software Steam Controller: Applying InputClass "system-keyboard"
[  9213.489] (II) Using input driver 'libinput' for 'Valve Software Steam Controller'
[  9213.489] (II) systemd-logind: returning pre-existing fd for /dev/input/event18 13:82
[  9213.489] (**) Valve Software Steam Controller: always reports core events
[  9213.489] (**) Option "Device" "/dev/input/event18"
[  9213.489] (**) Option "_source" "_driver/libinput"
[  9213.489] (II) libinput: Valve Software Steam Controller: is a virtual subdevice
[  9213.490] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:14.0/usb2/2-10/2-10:1.0/0003:28DE:1142.0001/input/input26/event18"
[  9213.490] (II) XINPUT: Adding extended input device "Valve Software Steam Controller" (type: KEYBOARD, id 17)
[  9213.490] (**) Option "xkb_model" "fr-latin1"
[  9213.490] (**) Option "xkb_layout" "fr"
[  9213.490] (**) Logitech Gaming Mouse G502 Consumer Control: Applying InputClass "libinput keyboard catchall"
[  9213.490] (**) Logitech Gaming Mouse G502 Consumer Control: Applying InputClass "system-keyboard"
[  9213.490] (II) Using input driver 'libinput' for 'Logitech Gaming Mouse G502 Consumer Control'
[  9213.490] (II) systemd-logind: returning pre-existing fd for /dev/input/event22 13:86
[  9213.490] (**) Logitech Gaming Mouse G502 Consumer Control: always reports core events
[  9213.490] (**) Option "Device" "/dev/input/event22"
[  9213.490] (**) Option "_source" "_driver/libinput"
[  9213.490] (II) libinput: Logitech Gaming Mouse G502 Consumer Control: is a virtual subdevice
[  9213.490] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:14.0/usb2/2-14/2-14:1.1/0003:046D:C332.0007/input/input22/event22"
[  9213.490] (II) XINPUT: Adding extended input device "Logitech Gaming Mouse G502 Consumer Control" (type: KEYBOARD, id 18)
[  9215.408] (**) Option "fd" "32"
[  9215.408] (II) event1  - Power Button: device removed
[  9215.409] (**) Option "fd" "35"
[  9215.409] (II) event0  - Power Button: device removed
[  9215.409] (**) Option "fd" "36"
[  9215.409] (**) Option "fd" "37"
[  9215.409] (II) event19 - Logitech Logitech Gaming Keyboard: device removed
[  9215.409] (**) Option "fd" "38"
[  9215.409] (II) event24 - Logitech Logitech Gaming Keyboard Consumer Control: device removed
[  9215.409] (**) Option "fd" "39"
[  9215.409] (II) event25 - Logitech Gaming Keyboard Gaming Keys: device removed
[  9215.409] (**) Option "fd" "40"
[  9215.409] (II) event20 - Logitech Gaming Mouse G502: device removed
[  9215.410] (**) Option "fd" "41"
[  9215.410] (II) event21 - Logitech Gaming Mouse G502 Keyboard: device removed
[  9215.410] (**) Option "fd" "42"
[  9215.410] (**) Option "fd" "43"
[  9215.410] (II) event23 - Logitech Gaming Mouse G502 System Control: device removed
[  9215.410] (**) Option "fd" "44"
[  9215.410] (II) event3  - Eee PC WMI hotkeys: device removed
[  9215.410] (**) Option "fd" "36"
[  9215.410] (II) event18 - Valve Software Steam Controller: device removed
[  9215.410] (II) event22 - Logitech Gaming Mouse G502 Consumer Control: device removed
[  9215.493] (II) systemd-logind: got pause for 13:84
[  9215.493] (II) systemd-logind: got pause for 13:87
[  9215.493] (II) systemd-logind: got pause for 13:83
[  9215.493] (II) systemd-logind: got pause for 13:86
[  9215.493] (II) systemd-logind: got pause for 13:64
[  9215.493] (II) systemd-logind: got pause for 13:65
[  9215.493] (II) systemd-logind: got pause for 13:88
[  9215.493] (II) systemd-logind: got pause for 13:82
[  9215.493] (II) systemd-logind: got pause for 13:67
[  9215.493] (II) systemd-logind: got pause for 13:89
[  9215.493] (II) systemd-logind: got pause for 13:85
[  9222.755] (II) systemd-logind: got resume for 13:84
[  9222.759] (--) NVIDIA(GPU-0): CRT-0: disconnected
[  9222.759] (--) NVIDIA(GPU-0): CRT-0: 400.0 MHz maximum pixel clock
[  9222.764] (--) NVIDIA(GPU-0): DFP-0: disconnected
[  9222.764] (--) NVIDIA(GPU-0): DFP-0: Internal TMDS
[  9222.764] (--) NVIDIA(GPU-0): DFP-0: 330.0 MHz maximum pixel clock
[  9222.764] (--) NVIDIA(GPU-0): DFP-1: disconnected
[  9222.764] (--) NVIDIA(GPU-0): DFP-1: Internal TMDS
[  9222.764] (--) NVIDIA(GPU-0): DFP-1: 165.0 MHz maximum pixel clock
[  9222.764] (--) NVIDIA(GPU-0): HPN HP ENVY 27s (DFP-2): connected
[  9222.764] (--) NVIDIA(GPU-0): HPN HP ENVY 27s (DFP-2): Internal DisplayPort
[  9222.764] (--) NVIDIA(GPU-0): HPN HP ENVY 27s (DFP-2): 960.0 MHz maximum pixel clock
[  9222.765] (--) NVIDIA(GPU-0): DFP-3: disconnected
[  9222.765] (--) NVIDIA(GPU-0): DFP-3: Internal TMDS
[  9222.765] (--) NVIDIA(GPU-0): DFP-3: 165.0 MHz maximum pixel clock
[  9222.766] (--) NVIDIA(GPU-0):
[  9222.766] (--) NVIDIA(GPU-0): DFP-4: disconnected
[  9222.766] (--) NVIDIA(GPU-0): DFP-4: Internal TMDS
[  9222.766] (--) NVIDIA(GPU-0): DFP-4: 330.0 MHz maximum pixel clock
[  9222.780] (II) NVIDIA(0): Setting mode "DFP-2:nvidia-auto-select"
[  9222.849] (II) NVIDIA(0): ACPI: failed to connect to the ACPI event daemon; the daemon
[  9222.849] (II) NVIDIA(0):     may not be running or the "AcpidSocketPath" X
[  9222.849] (II) NVIDIA(0):     configuration option may not be set correctly.  When the
[  9222.849] (II) NVIDIA(0):     ACPI event daemon is available, the NVIDIA X driver will
[  9222.849] (II) NVIDIA(0):     try to use it to receive ACPI event notifications.  For
[  9222.849] (II) NVIDIA(0):     details, please see the "ConnectToAcpid" and
[  9222.849] (II) NVIDIA(0):     "AcpidSocketPath" X configuration options in Appendix B: X
[  9222.849] (II) NVIDIA(0):     Config Options in the README.
[  9222.883] (II) event20 - Logitech Gaming Mouse G502: is tagged by udev as: Mouse
[  9222.883] (II) event20 - Logitech Gaming Mouse G502: device set to 2400 DPI
[  9222.883] (II) event20 - Logitech Gaming Mouse G502: device is a pointer
[  9222.884] (II) systemd-logind: got resume for 13:87
[  9222.884] (II) event23 - Logitech Gaming Mouse G502 System Control: is tagged by udev as: Keyboard
[  9222.884] (II) event23 - Logitech Gaming Mouse G502 System Control: device is a keyboard
[  9222.884] (II) systemd-logind: got resume for 13:83
[  9222.885] (II) event19 - Logitech Logitech Gaming Keyboard: is tagged by udev as: Keyboard
[  9222.885] (II) event19 - Logitech Logitech Gaming Keyboard: device is a keyboard
[  9222.885] (II) systemd-logind: got resume for 13:86
[  9222.886] (II) event22 - Logitech Gaming Mouse G502 Consumer Control: is tagged by udev as: Keyboard
[  9222.886] (II) event22 - Logitech Gaming Mouse G502 Consumer Control: device is a keyboard
[  9222.886] (II) systemd-logind: got resume for 13:64
[  9222.887] (II) event0  - Power Button: is tagged by udev as: Keyboard
[  9222.887] (II) event0  - Power Button: device is a keyboard
[  9222.887] (II) systemd-logind: got resume for 13:65
[  9222.887] (II) event1  - Power Button: is tagged by udev as: Keyboard
[  9222.887] (II) event1  - Power Button: device is a keyboard
[  9222.887] (II) systemd-logind: got resume for 13:88
[  9222.888] (II) event24 - Logitech Logitech Gaming Keyboard Consumer Control: is tagged by udev as: Keyboard
[  9222.888] (II) event24 - Logitech Logitech Gaming Keyboard Consumer Control: device is a keyboard
[  9222.891] (II) systemd-logind: got resume for 13:82
[  9222.892] (II) event18 - Valve Software Steam Controller: is tagged by udev as: Keyboard Mouse
[  9222.892] (II) event18 - Valve Software Steam Controller: device is a pointer
[  9222.892] (II) event18 - Valve Software Steam Controller: device is a keyboard
[  9222.916] (II) systemd-logind: got resume for 13:67
[  9222.917] (II) event3  - Eee PC WMI hotkeys: is tagged by udev as: Keyboard
[  9222.917] (II) event3  - Eee PC WMI hotkeys: device is a keyboard
[  9222.948] (II) systemd-logind: got resume for 13:89
[  9222.950] (II) event25 - Logitech Gaming Keyboard Gaming Keys: is tagged by udev as: Keyboard
[  9222.950] (II) event25 - Logitech Gaming Keyboard Gaming Keys: device is a keyboard
[  9222.975] (II) systemd-logind: got resume for 13:85
[  9222.977] (II) event21 - Logitech Gaming Mouse G502 Keyboard: is tagged by udev as: Keyboard
[  9222.977] (II) event21 - Logitech Gaming Mouse G502 Keyboard: device is a keyboard
[  9233.255] (--) NVIDIA(GPU-0): CRT-0: disconnected
[  9233.256] (--) NVIDIA(GPU-0): CRT-0: 400.0 MHz maximum pixel clock
[  9233.260] (--) NVIDIA(GPU-0): DFP-0: disconnected
[  9233.260] (--) NVIDIA(GPU-0): DFP-0: Internal TMDS
[  9233.260] (--) NVIDIA(GPU-0): DFP-0: 330.0 MHz maximum pixel clock
[  9233.260] (--) NVIDIA(GPU-0): DFP-1: disconnected
[  9233.260] (--) NVIDIA(GPU-0): DFP-1: Internal TMDS
[  9233.260] (--) NVIDIA(GPU-0): DFP-1: 165.0 MHz maximum pixel clock
[  9233.260] (--) NVIDIA(GPU-0): HPN HP ENVY 27s (DFP-2): connected
[  9233.260] (--) NVIDIA(GPU-0): HPN HP ENVY 27s (DFP-2): Internal DisplayPort
[  9233.260] (--) NVIDIA(GPU-0): HPN HP ENVY 27s (DFP-2): 960.0 MHz maximum pixel clock
[  9233.261] (--) NVIDIA(GPU-0): DFP-3: disconnected
[  9233.261] (--) NVIDIA(GPU-0): DFP-3: Internal TMDS
[  9233.261] (--) NVIDIA(GPU-0): DFP-3: 165.0 MHz maximum pixel clock
[  9233.261] (--) NVIDIA(GPU-0): DFP-4: disconnected
[  9233.261] (--) NVIDIA(GPU-0): DFP-4: Internal TMDS
[  9233.261] (--) NVIDIA(GPU-0): DFP-4: 330.0 MHz maximum pixel clock
[  9233.350] (II) NVIDIA(0): Setting mode "DP-0: nvidia-auto-select @3840x2160 +0+0 {ViewPortIn=3840x2160, ViewPortOut=3840x2160+0+0}"
[  9234.088] (**) Option "fd" "38"
[  9234.088] (II) event1  - Power Button: device removed
[  9234.088] (**) Option "fd" "37"
[  9234.088] (II) event0  - Power Button: device removed
[  9234.088] (**) Option "fd" "42"
[  9234.088] (**) Option "fd" "23"
[  9234.088] (II) event19 - Logitech Logitech Gaming Keyboard: device removed
[  9234.088] (**) Option "fd" "39"
[  9234.088] (II) event24 - Logitech Logitech Gaming Keyboard Consumer Control: device removed
[  9234.088] (**) Option "fd" "44"
[  9234.088] (II) event25 - Logitech Gaming Keyboard Gaming Keys: device removed
[  9234.088] (**) Option "fd" "24"
[  9234.088] (II) event20 - Logitech Gaming Mouse G502: device removed
[  9234.088] (**) Option "fd" "48"
[  9234.088] (II) event21 - Logitech Gaming Mouse G502 Keyboard: device removed
[  9234.088] (**) Option "fd" "36"
[  9234.088] (**) Option "fd" "41"
[  9234.088] (II) event23 - Logitech Gaming Mouse G502 System Control: device removed
[  9234.088] (**) Option "fd" "43"
[  9234.088] (II) event3  - Eee PC WMI hotkeys: device removed
[  9234.088] (II) event18 - Valve Software Steam Controller: device removed
[  9234.088] (II) event22 - Logitech Gaming Mouse G502 Consumer Control: device removed
[  9234.171] (II) systemd-logind: got pause for 13:84
[  9234.171] (II) systemd-logind: got pause for 13:87
[  9234.171] (II) systemd-logind: got pause for 13:83
[  9234.171] (II) systemd-logind: got pause for 13:86
[  9234.171] (II) systemd-logind: got pause for 13:64
[  9234.171] (II) systemd-logind: got pause for 13:65
[  9234.171] (II) systemd-logind: got pause for 13:88
[  9234.171] (II) systemd-logind: got pause for 13:82
[  9234.171] (II) systemd-logind: got pause for 13:67
[  9234.171] (II) systemd-logind: got pause for 13:89
[  9234.171] (II) systemd-logind: got pause for 13:85
[  9236.721] (II) systemd-logind: got resume for 13:84
[  9236.726] (--) NVIDIA(GPU-0): CRT-0: disconnected
[  9236.726] (--) NVIDIA(GPU-0): CRT-0: 400.0 MHz maximum pixel clock
[  9236.730] (--) NVIDIA(GPU-0): DFP-0: disconnected
[  9236.730] (--) NVIDIA(GPU-0): DFP-0: Internal TMDS
[  9236.730] (--) NVIDIA(GPU-0): DFP-0: 330.0 MHz maximum pixel clock
[  9236.730] (--) NVIDIA(GPU-0): DFP-1: disconnected
[  9236.730] (--) NVIDIA(GPU-0): DFP-1: Internal TMDS
[  9236.730] (--) NVIDIA(GPU-0): DFP-1: 165.0 MHz maximum pixel clock
[  9236.730] (--) NVIDIA(GPU-0): HPN HP ENVY 27s (DFP-2): connected
[  9236.730] (--) NVIDIA(GPU-0): HPN HP ENVY 27s (DFP-2): Internal DisplayPort
[  9236.730] (--) NVIDIA(GPU-0): HPN HP ENVY 27s (DFP-2): 960.0 MHz maximum pixel clock
[  9236.731] (--) NVIDIA(GPU-0): DFP-3: disconnected
[  9236.731] (--) NVIDIA(GPU-0): DFP-3: Internal TMDS
[  9236.731] (--) NVIDIA(GPU-0): DFP-3: 165.0 MHz maximum pixel clock
[  9236.731] (--) NVIDIA(GPU-0): DFP-4: disconnected
[  9236.731] (--) NVIDIA(GPU-0): DFP-4: Internal TMDS
[  9236.731] (--) NVIDIA(GPU-0): DFP-4: 330.0 MHz maximum pixel clock
[  9236.742] (II) NVIDIA(0): Setting mode "DP-0: nvidia-auto-select @3840x2160 +0+0 {ViewPortIn=3840x2160, ViewPortOut=3840x2160+0+0}"
[  9236.804] (II) NVIDIA(0): ACPI: failed to connect to the ACPI event daemon; the daemon
[  9236.804] (II) NVIDIA(0):     may not be running or the "AcpidSocketPath" X
[  9236.804] (II) NVIDIA(0):     configuration option may not be set correctly.  When the
[  9236.804] (II) NVIDIA(0):     ACPI event daemon is available, the NVIDIA X driver will
[  9236.804] (II) NVIDIA(0):     try to use it to receive ACPI event notifications.  For
[  9236.804] (II) NVIDIA(0):     details, please see the "ConnectToAcpid" and
[  9236.804] (II) NVIDIA(0):     "AcpidSocketPath" X configuration options in Appendix B: X
[  9236.804] (II) NVIDIA(0):     Config Options in the README.
[  9236.841] (II) event20 - Logitech Gaming Mouse G502: is tagged by udev as: Mouse
[  9236.841] (II) event20 - Logitech Gaming Mouse G502: device set to 2400 DPI
[  9236.841] (II) event20 - Logitech Gaming Mouse G502: device is a pointer
[  9236.841] (II) systemd-logind: got resume for 13:87
[  9236.842] (II) event23 - Logitech Gaming Mouse G502 System Control: is tagged by udev as: Keyboard
[  9236.842] (II) event23 - Logitech Gaming Mouse G502 System Control: device is a keyboard
[  9236.842] (II) systemd-logind: got resume for 13:83
[  9236.843] (II) event19 - Logitech Logitech Gaming Keyboard: is tagged by udev as: Keyboard
[  9236.843] (II) event19 - Logitech Logitech Gaming Keyboard: device is a keyboard
[  9236.844] (II) systemd-logind: got resume for 13:86
[  9236.844] (II) event22 - Logitech Gaming Mouse G502 Consumer Control: is tagged by udev as: Keyboard
[  9236.844] (II) event22 - Logitech Gaming Mouse G502 Consumer Control: device is a keyboard
[  9236.845] (II) systemd-logind: got resume for 13:64
[  9236.845] (II) event0  - Power Button: is tagged by udev as: Keyboard
[  9236.845] (II) event0  - Power Button: device is a keyboard
[  9236.845] (II) systemd-logind: got resume for 13:65
[  9236.846] (II) event1  - Power Button: is tagged by udev as: Keyboard
[  9236.846] (II) event1  - Power Button: device is a keyboard
[  9236.846] (II) systemd-logind: got resume for 13:88
[  9236.847] (II) event24 - Logitech Logitech Gaming Keyboard Consumer Control: is tagged by udev as: Keyboard
[  9236.847] (II) event24 - Logitech Logitech Gaming Keyboard Consumer Control: device is a keyboard
[  9236.858] (II) systemd-logind: got resume for 13:82
[  9236.859] (II) event18 - Valve Software Steam Controller: is tagged by udev as: Keyboard Mouse
[  9236.859] (II) event18 - Valve Software Steam Controller: device is a pointer
[  9236.859] (II) event18 - Valve Software Steam Controller: device is a keyboard
[  9236.878] (II) systemd-logind: got resume for 13:67
[  9236.879] (II) event3  - Eee PC WMI hotkeys: is tagged by udev as: Keyboard
[  9236.879] (II) event3  - Eee PC WMI hotkeys: device is a keyboard
[  9236.970] (II) systemd-logind: got resume for 13:89
[  9236.971] (II) event25 - Logitech Gaming Keyboard Gaming Keys: is tagged by udev as: Keyboard
[  9236.971] (II) event25 - Logitech Gaming Keyboard Gaming Keys: device is a keyboard
[  9236.971] (II) systemd-logind: got resume for 13:85
[  9236.972] (II) event21 - Logitech Gaming Mouse G502 Keyboard: is tagged by udev as: Keyboard
[  9236.972] (II) event21 - Logitech Gaming Mouse G502 Keyboard: device is a keyboard
[  9240.173] (**) Option "fd" "52"
[  9240.173] (II) event1  - Power Button: device removed
[  9240.173] (**) Option "fd" "51"
[  9240.174] (II) event0  - Power Button: device removed
[  9240.174] (**) Option "fd" "56"
[  9240.174] (**) Option "fd" "42"
[  9240.174] (II) event19 - Logitech Logitech Gaming Keyboard: device removed
[  9240.175] (**) Option "fd" "53"
[  9240.175] (II) event24 - Logitech Logitech Gaming Keyboard Consumer Control: device removed
[  9240.175] (**) Option "fd" "59"
[  9240.175] (II) event25 - Logitech Gaming Keyboard Gaming Keys: device removed
[  9240.175] (**) Option "fd" "43"
[  9240.175] (II) event20 - Logitech Gaming Mouse G502: device removed
[  9240.175] (**) Option "fd" "54"
[  9240.175] (II) event21 - Logitech Gaming Mouse G502 Keyboard: device removed
[  9240.176] (**) Option "fd" "50"
[  9240.176] (**) Option "fd" "55"
[  9240.176] (II) event23 - Logitech Gaming Mouse G502 System Control: device removed
[  9240.176] (**) Option "fd" "57"
[  9240.176] (II) event3  - Eee PC WMI hotkeys: device removed
[  9240.176] (**) Option "fd" "56"
[  9240.176] (II) event18 - Valve Software Steam Controller: device removed
[  9240.177] (**) Option "fd" "50"
[  9240.177] (II) event22 - Logitech Gaming Mouse G502 Consumer Control: device removed
[  9240.291] (II) systemd-logind: got pause for 13:84
[  9240.291] (II) systemd-logind: got pause for 13:87
[  9240.291] (II) systemd-logind: got pause for 13:83
[  9240.291] (II) systemd-logind: got pause for 13:86
[  9240.291] (II) systemd-logind: got pause for 13:64
[  9240.291] (II) systemd-logind: got pause for 13:65
[  9240.291] (II) systemd-logind: got pause for 13:88
[  9240.291] (II) systemd-logind: got pause for 13:82
[  9240.291] (II) systemd-logind: got pause for 13:67
[  9240.291] (II) systemd-logind: got pause for 13:89
[  9240.291] (II) systemd-logind: got pause for 13:85
[  9242.998] (II) systemd-logind: got resume for 13:84
[  9243.002] (--) NVIDIA(GPU-0): CRT-0: disconnected
[  9243.002] (--) NVIDIA(GPU-0): CRT-0: 400.0 MHz maximum pixel clock
[  9243.006] (--) NVIDIA(GPU-0): DFP-0: disconnected
[  9243.006] (--) NVIDIA(GPU-0): DFP-0: Internal TMDS
[  9243.006] (--) NVIDIA(GPU-0): DFP-0: 330.0 MHz maximum pixel clock
[  9243.006] (--) NVIDIA(GPU-0): DFP-1: disconnected
[  9243.006] (--) NVIDIA(GPU-0): DFP-1: Internal TMDS
[  9243.006] (--) NVIDIA(GPU-0): DFP-1: 165.0 MHz maximum pixel clock
[  9243.006] (--) NVIDIA(GPU-0): HPN HP ENVY 27s (DFP-2): connected
[  9243.007] (--) NVIDIA(GPU-0): HPN HP ENVY 27s (DFP-2): Internal DisplayPort
[  9243.007] (--) NVIDIA(GPU-0): HPN HP ENVY 27s (DFP-2): 960.0 MHz maximum pixel clock
[  9243.007] (--) NVIDIA(GPU-0): DFP-3: disconnected
[  9243.007] (--) NVIDIA(GPU-0): DFP-3: Internal TMDS
[  9243.007] (--) NVIDIA(GPU-0): DFP-3: 165.0 MHz maximum pixel clock
[  9243.008] (--) NVIDIA(GPU-0): DFP-4: disconnected
[  9243.008] (--) NVIDIA(GPU-0): DFP-4: Internal TMDS
[  9243.008] (--) NVIDIA(GPU-0): DFP-4: 330.0 MHz maximum pixel clock
[  9243.018] (II) NVIDIA(0): Setting mode "DP-0: nvidia-auto-select @3840x2160 +0+0 {ViewPortIn=3840x2160, ViewPortOut=3840x2160+0+0}"
[  9243.074] (II) NVIDIA(0): ACPI: failed to connect to the ACPI event daemon; the daemon
[  9243.074] (II) NVIDIA(0):     may not be running or the "AcpidSocketPath" X
[  9243.074] (II) NVIDIA(0):     configuration option may not be set correctly.  When the
[  9243.074] (II) NVIDIA(0):     ACPI event daemon is available, the NVIDIA X driver will
[  9243.074] (II) NVIDIA(0):     try to use it to receive ACPI event notifications.  For
[  9243.074] (II) NVIDIA(0):     details, please see the "ConnectToAcpid" and
[  9243.074] (II) NVIDIA(0):     "AcpidSocketPath" X configuration options in Appendix B: X
[  9243.074] (II) NVIDIA(0):     Config Options in the README.
[  9243.111] (II) event20 - Logitech Gaming Mouse G502: is tagged by udev as: Mouse
[  9243.111] (II) event20 - Logitech Gaming Mouse G502: device set to 2400 DPI
[  9243.111] (II) event20 - Logitech Gaming Mouse G502: device is a pointer
[  9243.111] (II) systemd-logind: got resume for 13:87
[  9243.112] (II) event23 - Logitech Gaming Mouse G502 System Control: is tagged by udev as: Keyboard
[  9243.112] (II) event23 - Logitech Gaming Mouse G502 System Control: device is a keyboard
[  9243.112] (II) systemd-logind: got resume for 13:83
[  9243.113] (II) event19 - Logitech Logitech Gaming Keyboard: is tagged by udev as: Keyboard
[  9243.113] (II) event19 - Logitech Logitech Gaming Keyboard: device is a keyboard
[  9243.114] (II) systemd-logind: got resume for 13:86
[  9243.114] (II) event22 - Logitech Gaming Mouse G502 Consumer Control: is tagged by udev as: Keyboard
[  9243.114] (II) event22 - Logitech Gaming Mouse G502 Consumer Control: device is a keyboard
[  9243.115] (II) systemd-logind: got resume for 13:64
[  9243.115] (II) event0  - Power Button: is tagged by udev as: Keyboard
[  9243.115] (II) event0  - Power Button: device is a keyboard
[  9243.115] (II) systemd-logind: got resume for 13:65
[  9243.116] (II) event1  - Power Button: is tagged by udev as: Keyboard
[  9243.116] (II) event1  - Power Button: device is a keyboard
[  9243.120] (II) systemd-logind: got resume for 13:88
[  9243.120] (II) event24 - Logitech Logitech Gaming Keyboard Consumer Control: is tagged by udev as: Keyboard
[  9243.120] (II) event24 - Logitech Logitech Gaming Keyboard Consumer Control: device is a keyboard
[  9243.157] (II) systemd-logind: got resume for 13:82
[  9243.158] (II) event18 - Valve Software Steam Controller: is tagged by udev as: Keyboard Mouse
[  9243.158] (II) event18 - Valve Software Steam Controller: device is a pointer
[  9243.158] (II) event18 - Valve Software Steam Controller: device is a keyboard
[  9243.174] (II) systemd-logind: got resume for 13:67
[  9243.174] (II) event3  - Eee PC WMI hotkeys: is tagged by udev as: Keyboard
[  9243.174] (II) event3  - Eee PC WMI hotkeys: device is a keyboard
[  9243.207] (II) systemd-logind: got resume for 13:89
[  9243.208] (II) event25 - Logitech Gaming Keyboard Gaming Keys: is tagged by udev as: Keyboard
[  9243.208] (II) event25 - Logitech Gaming Keyboard Gaming Keys: device is a keyboard
[  9243.218] (II) systemd-logind: got resume for 13:85
[  9243.220] (II) event21 - Logitech Gaming Mouse G502 Keyboard: is tagged by udev as: Keyboard
[  9243.220] (II) event21 - Logitech Gaming Mouse G502 Keyboard: device is a keyboard
[  9245.575] (**) Option "fd" "53"
[  9245.575] (II) event1  - Power Button: device removed
[  9245.575] (**) Option "fd" "52"
[  9245.575] (II) event0  - Power Button: device removed
[  9245.575] (**) Option "fd" "57"
[  9245.575] (**) Option "fd" "43"
[  9245.575] (II) event19 - Logitech Logitech Gaming Keyboard: device removed
[  9245.575] (**) Option "fd" "56"
[  9245.575] (II) event24 - Logitech Logitech Gaming Keyboard Consumer Control: device removed
[  9245.575] (**) Option "fd" "59"
[  9245.575] (II) event25 - Logitech Gaming Keyboard Gaming Keys: device removed
[  9245.575] (**) Option "fd" "44"
[  9245.575] (II) event20 - Logitech Gaming Mouse G502: device removed
[  9245.576] (**) Option "fd" "60"
[  9245.576] (II) event21 - Logitech Gaming Mouse G502 Keyboard: device removed
[  9245.576] (**) Option "fd" "51"
[  9245.576] (**) Option "fd" "55"
[  9245.576] (II) event23 - Logitech Gaming Mouse G502 System Control: device removed
[  9245.576] (**) Option "fd" "58"
[  9245.576] (II) event3  - Eee PC WMI hotkeys: device removed
[  9245.576] (**) Option "fd" "57"
[  9245.576] (II) event18 - Valve Software Steam Controller: device removed
[  9245.576] (II) event22 - Logitech Gaming Mouse G502 Consumer Control: device removed
[  9245.661] (II) systemd-logind: got pause for 13:84
[  9245.661] (II) systemd-logind: got pause for 13:87
[  9245.661] (II) systemd-logind: got pause for 13:83
[  9245.661] (II) systemd-logind: got pause for 13:86
[  9245.661] (II) systemd-logind: got pause for 13:64
[  9245.661] (II) systemd-logind: got pause for 13:65
[  9245.661] (II) systemd-logind: got pause for 13:88
[  9245.661] (II) systemd-logind: got pause for 13:82
[  9245.661] (II) systemd-logind: got pause for 13:67
[  9245.661] (II) systemd-logind: got pause for 13:89
[  9245.661] (II) systemd-logind: got pause for 13:85
[ 11804.330] (II) UnloadModule: "libinput"
[ 11804.330] (II) systemd-logind: not releasing fd for 13:86, still in use
[ 11804.331] (II) UnloadModule: "libinput"
[ 11804.331] (II) systemd-logind: not releasing fd for 13:82, still in use
[ 11804.331] (II) systemd-logind: releasing fd for 13:67
[ 11804.416] (II) UnloadModule: "libinput"
[ 11804.416] (II) systemd-logind: releasing fd for 13:87
[ 11804.448] (II) UnloadModule: "libinput"
[ 11804.448] (II) systemd-logind: releasing fd for 13:86
[ 11804.485] (II) UnloadModule: "libinput"
[ 11804.485] (II) systemd-logind: releasing fd for 13:85
[ 11804.509] (II) UnloadModule: "libinput"
[ 11804.509] (II) systemd-logind: releasing fd for 13:84
[ 11804.518] (II) UnloadModule: "libinput"
[ 11804.518] (II) systemd-logind: releasing fd for 13:89
[ 11804.542] (II) UnloadModule: "libinput"
[ 11804.542] (II) systemd-logind: releasing fd for 13:88
[ 11804.571] (II) UnloadModule: "libinput"
[ 11804.571] (II) systemd-logind: releasing fd for 13:83
[ 11804.595] (II) UnloadModule: "libinput"
[ 11804.595] (II) systemd-logind: releasing fd for 13:82
[ 11804.632] (II) UnloadModule: "libinput"
[ 11804.632] (II) systemd-logind: releasing fd for 13:64
[ 11804.669] (II) UnloadModule: "libinput"
[ 11804.669] (II) systemd-logind: releasing fd for 13:65
[ 11804.722] (II) NVIDIA(GPU-0): Deleting GPU-0
[ 11804.722] (WW) xf86CloseConsole: KDSETMODE failed: Input/output error
[ 11804.722] (WW) xf86CloseConsole: VT_GETMODE failed: Input/output error
[ 11804.722] (WW) xf86CloseConsole: VT_ACTIVATE failed: Input/output error
[ 11804.723] (II) Server terminated successfully (0). Closing log file.
*** /var/log/Xorg.1.log.old
*** ls: -rw-r--r-- 1 root user 45012 2020-06-23 14:54:55.322843382 +0200 /var/log/Xorg.1.log.old
[  3434.269] (WW) Failed to open protocol names file lib/xorg/protocol.txt
[  3434.270]
[  3434.274] Build Operating System: Linux Arch Linux
[  3434.275] Current Operating System: Linux localhost 5.7.4-arch1-1 #1 SMP PREEMPT Thu, 18 Jun 2020 16:01:07 +0000 x86_64
[  3434.276] Kernel command line: root=UUID=6c37d730-4b14-4479-8554-92d2e75478d5 rw initrd=\initramfs-linux.img
[  3434.278] Build Date: 05 May 2020  05:08:17AM
[  3434.279]
[  3434.279] Current version of pixman: 0.40.0
[  3434.281] 	Before reporting problems, check http://wiki.x.org
[  3434.281] Markers: (--) probed, (**) from config file, (==) default setting,
[  3434.284] (==) Log file: "/var/log/Xorg.1.log", Time: Tue Jun 23 13:46:10 2020
[  3434.288] (==) Using config file: "/etc/X11/xorg.conf"
[  3434.288] (==) Using config directory: "/etc/X11/xorg.conf.d"
[  3434.289] (==) Using system config directory "/usr/share/X11/xorg.conf.d"
[  3434.291] (==) ServerLayout "Layout0"
[  3434.291] (**) |-->Screen "Screen0" (0)
[  3434.291] (**) |   |-->Monitor "Monitor0"
[  3434.291] (**) |   |-->Device "Device0"
[  3434.291] (**) |   |-->GPUDevice "Device0"
[  3434.292] (**) |-->Input Device "Keyboard0"
[  3434.292] (**) |-->Input Device "Mouse0"
[  3434.292] (**) Option "Xinerama" "0"
[  3434.292] (==) Automatically adding devices
[  3434.292] (==) Automatically enabling devices
[  3434.292] (==) Automatically adding GPU devices
[  3434.292] (==) Automatically binding GPU devices
[  3434.292] (==) Max clients allowed: 256, resource mask: 0x1fffff
[  3434.294] (WW) `fonts.dir' not found (or not valid) in "/usr/share/fonts/OTF".
[  3434.294] 	Entry deleted from font path.
[  3434.294] 	(Run 'mkfontdir' on "/usr/share/fonts/OTF").
[  3434.294] (WW) The directory "/usr/share/fonts/Type1" does not exist.
[  3434.294] (WW) The directory "/usr/share/fonts/100dpi" does not exist.
[  3434.294] (WW) The directory "/usr/share/fonts/75dpi" does not exist.
[  3434.294] (==) FontPath set to:
[  3434.294] (==) ModulePath set to "/usr/lib/xorg/modules"
[  3434.294] (WW) Hotplugging is on, devices using drivers 'kbd', 'mouse' or 'vmmouse' will be disabled.
[  3434.294] (WW) Disabling Keyboard0
[  3434.294] (WW) Disabling Mouse0
[  3434.294] (II) Module ABI versions:
[  3434.294] 	X.Org ANSI C Emulation: 0.4
[  3434.294] 	X.Org Video Driver: 24.1
[  3434.294] 	X.Org XInput driver : 24.1
[  3434.294] 	X.Org Server Extension : 10.0
[  3434.295] (++) using VT number 1
[  3434.296] (II) systemd-logind: took control of session /org/freedesktop/login1/session/_31
[  3434.296] (II) xfree86: Adding drm device (/dev/dri/card0)
[  3434.296] (II) systemd-logind: got fd for /dev/dri/card0 226:0 fd 10 paused 0
[  3434.297] (**) OutputClass "nvidia" ModulePath extended to "/usr/lib/nvidia/xorg,/usr/lib/xorg/modules,/usr/lib/xorg/modules"
[  3434.298] (--) PCI:*(1@0:0:0) 10de:13c2:1462:3160 rev 161, Mem @ 0xde000000/16777216, 0xc0000000/268435456, 0xd0000000/33554432, I/O @ 0x0000e000/128, BIOS @ 0x????????/131072
[  3434.298] (WW) Open ACPI failed (/var/run/acpid.socket) (No such file or directory)
[  3434.298] (II) LoadModule: "glx"
[  3434.299] (II) Loading /usr/lib/xorg/modules/extensions/libglx.so
[  3434.302] (II) Module glx: vendor="X.Org Foundation"
[  3434.302] 	compiled for 1.20.8, module version = 1.0.0
[  3434.302] 	ABI class: X.Org Server Extension, version 10.0
[  3434.302] (II) LoadModule: "nvidia"
[  3434.302] (II) Loading /usr/lib/xorg/modules/drivers/nvidia_drv.so
[  3434.309] (II) Module nvidia: vendor="NVIDIA Corporation"
[  3434.309] 	compiled for 1.6.99.901, module version = 1.0.0
[  3434.309] 	Module class: X.Org Video Driver
[  3434.310] (II) NVIDIA dlloader X Driver  440.82  Wed Apr  1 19:50:17 UTC 2020
[  3434.310] (II) NVIDIA Unified Driver for all Supported NVIDIA GPUs
[  3434.310] (II) systemd-logind: releasing fd for 226:0
[  3434.312] (II) Loading sub module "fb"
[  3434.312] (II) LoadModule: "fb"
[  3434.312] (II) Loading /usr/lib/xorg/modules/libfb.so
[  3434.313] (II) Module fb: vendor="X.Org Foundation"
[  3434.313] 	compiled for 1.20.8, module version = 1.0.0
[  3434.313] 	ABI class: X.Org ANSI C Emulation, version 0.4
[  3434.313] (II) Loading sub module "wfb"
[  3434.313] (II) LoadModule: "wfb"
[  3434.313] (II) Loading /usr/lib/xorg/modules/libwfb.so
[  3434.314] (II) Module wfb: vendor="X.Org Foundation"
[  3434.314] 	compiled for 1.20.8, module version = 1.0.0
[  3434.314] 	ABI class: X.Org ANSI C Emulation, version 0.4
[  3434.314] (II) Loading sub module "ramdac"
[  3434.314] (II) LoadModule: "ramdac"
[  3434.314] (II) Module "ramdac" already built-in
[  3434.316] (**) NVIDIA(0): Depth 24, (--) framebuffer bpp 32
[  3434.316] (==) NVIDIA(0): RGB weight 888
[  3434.316] (==) NVIDIA(0): Default visual is TrueColor
[  3434.317] (==) NVIDIA(0): Using gamma correction (1.0, 1.0, 1.0)
[  3434.317] (II) Applying OutputClass "nvidia" options to /dev/dri/card0
[  3434.317] (**) NVIDIA(0): Option "Stereo" "0"
[  3434.317] (**) NVIDIA(0): Option "nvidiaXineramaInfoOrder" "DFP-1"
[  3434.317] (**) NVIDIA(0): Option "SLI" "Off"
[  3434.317] (**) NVIDIA(0): Option "MultiGPU" "Off"
[  3434.317] (**) NVIDIA(0): Option "BaseMosaic" "off"
[  3434.317] (**) NVIDIA(0): Option "AllowEmptyInitialConfiguration"
[  3434.317] (**) NVIDIA(0): Stereo disabled by request
[  3434.317] (**) NVIDIA(0): NVIDIA SLI disabled.
[  3434.317] (**) NVIDIA(0): NVIDIA Multi-GPU disabled.
[  3434.317] (**) NVIDIA(0): Option "MetaModes" "HDMI-0: 3840x2160_60 +0+0, DP-0: 1920x1080_144 +3840+0"
[  3434.317] (**) NVIDIA(0): Enabling 2D acceleration
[  3434.317] (II) Loading sub module "glxserver_nvidia"
[  3434.317] (II) LoadModule: "glxserver_nvidia"
[  3434.317] (II) Loading /usr/lib/nvidia/xorg/libglxserver_nvidia.so
[  3434.385] (II) Module glxserver_nvidia: vendor="NVIDIA Corporation"
[  3434.385] 	compiled for 1.6.99.901, module version = 1.0.0
[  3434.385] 	Module class: X.Org Server Extension
[  3434.386] (II) NVIDIA GLX Module  440.82  Wed Apr  1 19:47:36 UTC 2020
[  3434.388] (II) NVIDIA: The X server supports PRIME Render Offload.
[  3434.647] (--) NVIDIA(0): Valid display device(s) on GPU-0 at PCI:1:0:0
[  3434.647] (--) NVIDIA(0):     CRT-0
[  3434.647] (--) NVIDIA(0):     DFP-0
[  3434.647] (--) NVIDIA(0):     DFP-1
[  3434.647] (--) NVIDIA(0):     DFP-2 (boot)
[  3434.647] (--) NVIDIA(0):     DFP-3
[  3434.647] (--) NVIDIA(0):     DFP-4
[  3434.647] (II) NVIDIA(0): NVIDIA GPU GeForce GTX 970 (GM204-A) at PCI:1:0:0 (GPU-0)
[  3434.647] (--) NVIDIA(0): Memory: 4194304 kBytes
[  3434.647] (--) NVIDIA(0): VideoBIOS: 84.04.2f.00.f1
[  3434.647] (II) NVIDIA(0): Detected PCI Express Link width: 16X
[  3434.651] (--) NVIDIA(GPU-0): CRT-0: disconnected
[  3434.651] (--) NVIDIA(GPU-0): CRT-0: 400.0 MHz maximum pixel clock
[  3434.655] (--) NVIDIA(GPU-0): DFP-0: disconnected
[  3434.655] (--) NVIDIA(GPU-0): DFP-0: Internal TMDS
[  3434.655] (--) NVIDIA(GPU-0): DFP-0: 330.0 MHz maximum pixel clock
[  3434.655] (--) NVIDIA(GPU-0): DFP-1: disconnected
[  3434.655] (--) NVIDIA(GPU-0): DFP-1: Internal TMDS
[  3434.655] (--) NVIDIA(GPU-0): DFP-1: 165.0 MHz maximum pixel clock
[  3434.655] (--) NVIDIA(GPU-0): HPN HP ENVY 27s (DFP-2): connected
[  3434.655] (--) NVIDIA(GPU-0): HPN HP ENVY 27s (DFP-2): Internal DisplayPort
[  3434.656] (--) NVIDIA(GPU-0): HPN HP ENVY 27s (DFP-2): 960.0 MHz maximum pixel clock
[  3434.656] (--) NVIDIA(GPU-0): DFP-3: disconnected
[  3434.656] (--) NVIDIA(GPU-0): DFP-3: Internal TMDS
[  3434.656] (--) NVIDIA(GPU-0): DFP-3: 165.0 MHz maximum pixel clock
[  3434.657] (--) NVIDIA(GPU-0): DFP-4: disconnected
[  3434.657] (--) NVIDIA(GPU-0): DFP-4: Internal TMDS
[  3434.657] (--) NVIDIA(GPU-0): DFP-4: 330.0 MHz maximum pixel clock
[  3434.659] (WW) NVIDIA(0): No valid modes for
[  3434.659] (WW) NVIDIA(0):     "HDMI-0:3840x2160_60+0+0,DP-0:1920x1080_144+3840+0";
[  3434.659] (WW) NVIDIA(0):     removing.
[  3434.659] (WW) NVIDIA(0): Unable to validate any modes; falling back to the default mode
[  3434.659] (WW) NVIDIA(0):     "nvidia-auto-select".
[  3434.659] (II) NVIDIA(0): Validated MetaModes:
[  3434.659] (II) NVIDIA(0):     "DFP-2:nvidia-auto-select"
[  3434.659] (II) NVIDIA(0): Virtual screen size determined to be 3840 x 2160
[  3434.662] (--) NVIDIA(0): DPI set to (162, 161); computed from "UseEdidDpi" X config
[  3434.662] (--) NVIDIA(0):     option
[  3434.662] (II) NVIDIA: Using 6144.00 MB of virtual memory for indirect memory
[  3434.662] (II) NVIDIA:     access.
[  3434.664] (II) NVIDIA(0): ACPI: failed to connect to the ACPI event daemon; the daemon
[  3434.664] (II) NVIDIA(0):     may not be running or the "AcpidSocketPath" X
[  3434.664] (II) NVIDIA(0):     configuration option may not be set correctly.  When the
[  3434.664] (II) NVIDIA(0):     ACPI event daemon is available, the NVIDIA X driver will
[  3434.664] (II) NVIDIA(0):     try to use it to receive ACPI event notifications.  For
[  3434.664] (II) NVIDIA(0):     details, please see the "ConnectToAcpid" and
[  3434.664] (II) NVIDIA(0):     "AcpidSocketPath" X configuration options in Appendix B: X
[  3434.664] (II) NVIDIA(0):     Config Options in the README.
[  3434.696] (II) NVIDIA(0): Setting mode "DFP-2:nvidia-auto-select"
[  3434.802] (==) NVIDIA(0): Disabling shared memory pixmaps
[  3434.802] (==) NVIDIA(0): Backing store enabled
[  3434.802] (==) NVIDIA(0): Silken mouse disabled
[  3434.802] (**) NVIDIA(0): DPMS enabled
[  3434.802] (II) Loading sub module "dri2"
[  3434.802] (II) LoadModule: "dri2"
[  3434.802] (II) Module "dri2" already built-in
[  3434.802] (II) NVIDIA(0): [DRI2] Setup complete
[  3434.802] (II) NVIDIA(0): [DRI2]   VDPAU driver: nvidia
[  3434.802] (II) Initializing extension Generic Event Extension
[  3434.802] (II) Initializing extension SHAPE
[  3434.802] (II) Initializing extension MIT-SHM
[  3434.802] (II) Initializing extension XInputExtension
[  3434.802] (II) Initializing extension XTEST
[  3434.802] (II) Initializing extension BIG-REQUESTS
[  3434.802] (II) Initializing extension SYNC
[  3434.802] (II) Initializing extension XKEYBOARD
[  3434.802] (II) Initializing extension XC-MISC
[  3434.802] (II) Initializing extension SECURITY
[  3434.802] (II) Initializing extension XFIXES
[  3434.802] (II) Initializing extension RENDER
[  3434.802] (II) Initializing extension RANDR
[  3434.802] (II) Initializing extension COMPOSITE
[  3434.802] (II) Initializing extension DAMAGE
[  3434.802] (II) Initializing extension MIT-SCREEN-SAVER
[  3434.802] (II) Initializing extension DOUBLE-BUFFER
[  3434.802] (II) Initializing extension RECORD
[  3434.802] (II) Initializing extension DPMS
[  3434.802] (II) Initializing extension Present
[  3434.802] (II) Initializing extension DRI3
[  3434.802] (II) Initializing extension X-Resource
[  3434.802] (II) Initializing extension XVideo
[  3434.802] (II) Initializing extension XVideo-MotionCompensation
[  3434.802] (II) Initializing extension GLX
[  3434.802] (II) Indirect GLX disabled.
[  3434.802] (II) GLX: Another vendor is already registered for screen 0
[  3434.802] (II) Initializing extension XFree86-VidModeExtension
[  3434.802] (II) Initializing extension XFree86-DGA
[  3434.802] (II) Initializing extension XFree86-DRI
[  3434.802] (II) Initializing extension DRI2
[  3434.802] (II) Initializing extension NV-GLX
@pingo-power
[  3434.802] (II) Initializing extension NV-CONTROL
[  3434.802] (II) Initializing extension XINERAMA
[  3434.857] (II) config/udev: Adding input device Power Button (/dev/input/event1)
[  3434.857] (**) Power Button: Applying InputClass "libinput keyboard catchall"
[  3434.857] (**) Power Button: Applying InputClass "system-keyboard"
[  3434.857] (II) LoadModule: "libinput"
[  3434.857] (II) Loading /usr/lib/xorg/modules/input/libinput_drv.so
[  3434.862] (II) Module libinput: vendor="X.Org Foundation"
[  3434.862] 	compiled for 1.20.8, module version = 0.30.0
[  3434.862] 	Module class: X.Org XInput Driver
[  3434.862] 	ABI class: X.Org XInput driver, version 24.1
[  3434.862] (II) Using input driver 'libinput' for 'Power Button'
[  3434.863] (II) systemd-logind: got fd for /dev/input/event1 13:65 fd 32 paused 0
[  3434.863] (**) Power Button: always reports core events
[  3434.863] (**) Option "Device" "/dev/input/event1"
[  3434.863] (**) Option "_source" "server/udev"
[  3434.870] (II) event1  - Power Button: is tagged by udev as: Keyboard
[  3434.870] (II) event1  - Power Button: device is a keyboard
[  3434.870] (II) event1  - Power Button: device removed
[  3434.870] (**) Option "config_info" "udev : /sys/devices/LNXSYSTM:00/LNXPWRBN:00/input/input1/event1"
[  3434.870] (II) XINPUT: Adding extended input device "Power Button" (type: KEYBOARD, id 6)
[  3434.870] (**) Option "xkb_model" "fr-latin1"
[  3434.870] (**) Option "xkb_layout" "fr"
[  3434.885] (II) event1  - Power Button: is tagged by udev as: Keyboard
[  3434.886] (II) event1  - Power Button: device is a keyboard
[  3434.886] (II) config/udev: Adding input device Power Button (/dev/input/event0)
[  3434.886] (**) Power Button: Applying InputClass "libinput keyboard catchall"
[  3434.886] (**) Power Button: Applying InputClass "system-keyboard"
[  3434.886] (II) Using input driver 'libinput' for 'Power Button'
[  3434.886] (II) systemd-logind: got fd for /dev/input/event0 13:64 fd 35 paused 0
[  3434.886] (**) Power Button: always reports core events
[  3434.886] (**) Option "Device" "/dev/input/event0"
[  3434.886] (**) Option "_source" "server/udev"
[  3434.887] (II) event0  - Power Button: is tagged by udev as: Keyboard
[  3434.887] (II) event0  - Power Button: device is a keyboard
[  3434.887] (II) event0  - Power Button: device removed
[  3434.887] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0C:00/input/input0/event0"
[  3434.887] (II) XINPUT: Adding extended input device "Power Button" (type: KEYBOARD, id 7)
[  3434.887] (**) Option "xkb_model" "fr-latin1"
[  3434.887] (**) Option "xkb_layout" "fr"
[  3434.888] (II) event0  - Power Button: is tagged by udev as: Keyboard
[  3434.888] (II) event0  - Power Button: device is a keyboard
[  3434.888] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=12 (/dev/input/event10)
[  3434.888] (II) No input driver specified, ignoring this device.
[  3434.888] (II) This device may have been added with another device file.
[  3434.888] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=3 (/dev/input/event4)
[  3434.888] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=7 (/dev/input/event5)
[  3434.889] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=8 (/dev/input/event6)
[  3434.889] (II) No input driver specified, ignoring this device.
[  3434.889] (II) This device may have been added with another device file.
[  3434.889] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=9 (/dev/input/event7)
[  3434.889] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=10 (/dev/input/event8)
[  3434.889] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=11 (/dev/input/event9)
[  3434.890] (II) config/udev: Adding input device Valve Software Steam Controller (/dev/input/event19)
[  3434.890] (**) Valve Software Steam Controller: Applying InputClass "libinput pointer catchall"
[  3434.890] (**) Valve Software Steam Controller: Applying InputClass "libinput keyboard catchall"
[  3434.890] (**) Valve Software Steam Controller: Applying InputClass "system-keyboard"
[  3434.890] (II) Using input driver 'libinput' for 'Valve Software Steam Controller'
[  3434.890] (II) systemd-logind: got fd for /dev/input/event19 13:83 fd 36 paused 0
[  3434.890] (**) Valve Software Steam Controller: always reports core events
[  3434.890] (**) Option "Device" "/dev/input/event19"
[  3434.890] (**) Option "_source" "server/udev"
[  3434.891] (II) event19 - Valve Software Steam Controller: is tagged by udev as: Keyboard Mouse
[  3434.891] (II) event19 - Valve Software Steam Controller: device is a pointer
[  3434.891] (II) event19 - Valve Software Steam Controller: device is a keyboard
[  3434.891] (II) event19 - Valve Software Steam Controller: device removed
[  3434.891] (II) libinput: Valve Software Steam Controller: needs a virtual subdevice
[  3434.891] (**) Option "config_info" "udev: / sys/devices/pci0000:00/0000:00:14.0/usb2/2-10/2-10:1.0/0003:28DE:1142.0001/input/input29/event19"
[  3434.891] (II) XINPUT: Adding extended input device "Valve Software Steam Controller" (type: MOUSE, id 8)
[  3434.891] (**) Option "AccelerationScheme" "none"
[  3434.891] (**) Valve Software Steam Controller: (accel) selected scheme none/0
[  3434.891] (**) Valve Software Steam Controller: (accel) acceleration factor: 2.000
[  3434.891] (**) Valve Software Steam Controller: (accel) acceleration threshold: 4
[  3434.892] (II) event19 - Valve Software Steam Controller: is tagged by udev as: Keyboard Mouse
[  3434.893] (II) event19 - Valve Software Steam Controller: device is a pointer
[  3434.893] (II) event19 - Valve Software Steam Controller: device is a keyboard
[  3434.893] (II) config/udev: Adding input device Valve Software Steam Controller (/dev/input/mouse0)
[  3434.893] (**) Valve Software Steam Controller: Applying InputClass "system-keyboard"
[  3434.893] (II) No input driver specified, ignoring this device.
[  3434.893] (II) This device may have been added with another device file.
[  3434.894] (II) config/udev: Adding input device Logitech Logitech Gaming Keyboard (/dev/input/event22)
[  3434.894] (**) Logitech Logitech Gaming Keyboard: Applying InputClass "libinput keyboard catchall"
[  3434.894] (**) Logitech Logitech Gaming Keyboard: Applying InputClass "system-keyboard"
[  3434.894] (II) Using input driver 'libinput' for 'Logitech Logitech Gaming Keyboard'
[  3434.895] (II) systemd-logind: got fd for /dev/input/event22 13:86 fd 37 paused 0
[  3434.895] (**) Logitech Logitech Gaming Keyboard: always reports core events
[  3434.895] (**) Option "Device" "/dev/input/event22"
[  3434.895] (**) Option "_source" "server/udev"
[  3434.896] (II) event22 - Logitech Logitech Gaming Keyboard: is tagged by udev as: Keyboard
[  3434.896] (II) event22 - Logitech Logitech Gaming Keyboard: device is a keyboard
[  3434.896] (II) event22 - Logitech Logitech Gaming Keyboard: device removed
[  3434.896] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:14.0/usb2/2-13/2-13.1/2-13.1:1.0/0003:046D:C221.0008/input/input26/event22"
[  3434.896] (II) XINPUT: Adding extended input device "Logitech Logitech Gaming Keyboard" (type: KEYBOARD, id 9)
[  3434.896] (**) Option "xkb_model" "fr-latin1"
[  3434.896] (**) Option "xkb_layout" "fr"
[  3434.898] (II) event22 - Logitech Logitech Gaming Keyboard: is tagged by udev as: Keyboard
[  3434.898] (II) event22 - Logitech Logitech Gaming Keyboard: device is a keyboard
[  3434.899] (II) config/udev: Adding input device Logitech Logitech Gaming Keyboard Consumer Control (/dev/input/event18)
[  3434.899] (**) Logitech Logitech Gaming Keyboard Consumer Control: Applying InputClass "libinput keyboard catchall"
[  3434.899] (**) Logitech Logitech Gaming Keyboard Consumer Control: Applying InputClass "system-keyboard"
[  3434.899] (II) Using input driver 'libinput' for 'Logitech Logitech Gaming Keyboard Consumer Control'
[  3434.899] (II) systemd-logind: got fd for /dev/input/event18 13:82 fd 38 paused 0
[  3434.899] (**) Logitech Logitech Gaming Keyboard Consumer Control: always reports core events
[  3434.899] (**) Option "Device" "/dev/input/event18"
[  3434.899] (**) Option "_source" "server/udev"
[  3434.900] (II) event18 - Logitech Logitech Gaming Keyboard Consumer Control: is tagged by udev as: Keyboard
[  3434.900] (II) event18 - Logitech Logitech Gaming Keyboard Consumer Control: device is a keyboard
[  3434.900] (II) event18 - Logitech Logitech Gaming Keyboard Consumer Control: device removed
[  3434.900] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:14.0/usb2/2-13/2-13.1/2-13.1:1.1/0003:046D:C221.0009/input/input27/event18"
[  3434.900] (II) XINPUT: Adding extended input device "Logitech Logitech Gaming Keyboard Consumer Control" (type: KEYBOARD, id 10)
[  3434.900] (**) Option "xkb_model" "fr-latin1"
[  3434.900] (**) Option "xkb_layout" "fr"
[  3434.901] (II) event18 - Logitech Logitech Gaming Keyboard Consumer Control: is tagged by udev as: Keyboard
[  3434.901] (II) event18 - Logitech Logitech Gaming Keyboard Consumer Control: device is a keyboard
[  3434.901] (II) config/udev: Adding input device Logitech Gaming Keyboard Gaming Keys (/dev/input/event25)
[  3434.902] (**) Logitech Gaming Keyboard Gaming Keys: Applying InputClass "libinput keyboard catchall"
[  3434.902] (**) Logitech Gaming Keyboard Gaming Keys: Applying InputClass "system-keyboard"
[  3434.902] (II) Using input driver 'libinput' for 'Logitech Gaming Keyboard Gaming Keys'
[  3434.959] (II) systemd-logind: got fd for /dev/input/event25 13:89 fd 39 paused 0
[  3434.959] (**) Logitech Gaming Keyboard Gaming Keys: always reports core events
[  3434.959] (**) Option "Device" "/dev/input/event25"
[  3434.959] (**) Option "_source" "server/udev"
[  3434.961] (II) event25 - Logitech Gaming Keyboard Gaming Keys: is tagged by udev as: Keyboard
[  3434.961] (II) event25 - Logitech Gaming Keyboard Gaming Keys: device is a keyboard
[  3434.961] (II) event25 - Logitech Gaming Keyboard Gaming Keys: device removed
[  3434.961] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:14.0/usb2/2-13/2-13.4/2-13.4:1.0/0003:046D:C222.000E/input/input32/event25"
[  3434.961] (II) XINPUT: Adding extended input device "Logitech Gaming Keyboard Gaming Keys" (type: KEYBOARD, id 11)
[  3434.961] (**) Option "xkb_model" "fr-latin1"
[  3434.961] (**) Option "xkb_layout" "fr"
[  3434.964] (II) event25 - Logitech Gaming Keyboard Gaming Keys: is tagged by udev as: Keyboard
[  3434.964] (II) event25 - Logitech Gaming Keyboard Gaming Keys: device is a keyboard
[  3434.965] (II) config/udev: Adding input device Logitech Gaming Mouse G502 (/dev/input/event20)
[  3434.965] (**) Logitech Gaming Mouse G502: Applying InputClass "libinput pointer catchall"
[  3434.965] (II) Using input driver 'libinput' for 'Logitech Gaming Mouse G502'
[  3435.022] (II) systemd-logind: got fd for /dev/input/event20 13:84 fd 40 paused 0
[  3435.022] (**) Logitech Gaming Mouse G502: always reports core events
[  3435.022] (**) Option "Device" "/dev/input/event20"
[  3435.022] (**) Option "_source" "server/udev"
[  3435.025] (II) event20 - Logitech Gaming Mouse G502: is tagged by udev as: Mouse
[  3435.025] (II) event20 - Logitech Gaming Mouse G502: device set to 2400 DPI
[  3435.025] (II) event20 - Logitech Gaming Mouse G502: device is a pointer
[  3435.025] (II) event20 - Logitech Gaming Mouse G502: device removed
[  3435.025] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:14.0/usb2/2-14/2-14:1.0/0003:046D:C332.0006/input/input20/event20"
[  3435.025] (II) XINPUT: Adding extended input device "Logitech Gaming Mouse G502" (type: MOUSE, id 12)
[  3435.025] (**) Option "AccelerationScheme" "none"
[  3435.025] (**) Logitech Gaming Mouse G502: (accel) selected scheme none/0
[  3435.025] (**) Logitech Gaming Mouse G502: (accel) acceleration factor: 2.000
[  3435.026] (**) Logitech Gaming Mouse G502: (accel) acceleration threshold: 4
[  3435.028] (II) event20 - Logitech Gaming Mouse G502: is tagged by udev as: Mouse
[  3435.028] (II) event20 - Logitech Gaming Mouse G502: device set to 2400 DPI
[  3435.028] (II) event20 - Logitech Gaming Mouse G502: device is a pointer
[  3435.029] (II) config/udev: Adding input device Logitech Gaming Mouse G502 (/dev/input/mouse1)
[  3435.029] (II) No input driver specified, ignoring this device.
[  3435.029] (II) This device may have been added with another device file.
[  3435.030] (II) config/udev: Adding input device Logitech Gaming Mouse G502 Keyboard (/dev/input/event21)
[  3435.030] (**) Logitech Gaming Mouse G502 Keyboard: Applying InputClass "libinput keyboard catchall"
[  3435.030] (**) Logitech Gaming Mouse G502 Keyboard: Applying InputClass "system-keyboard"
[  3435.030] (II) Using input driver 'libinput' for 'Logitech Gaming Mouse G502 Keyboard'
[  3435.030] (II) systemd-logind: got fd for /dev/input/event21 13:85 fd 41 paused 0
[  3435.030] (**) Logitech Gaming Mouse G502 Keyboard: always reports core events
[  3435.030] (**) Option "Device" "/dev/input/event21"
[  3435.030] (**) Option "_source" "server/udev"
[  3435.032] (II) event21 - Logitech Gaming Mouse G502 Keyboard: is tagged by udev as: Keyboard
[  3435.032] (II) event21 - Logitech Gaming Mouse G502 Keyboard: device is a keyboard
[  3435.032] (II) event21 - Logitech Gaming Mouse G502 Keyboard: device removed
[  3435.032] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:14.0/usb2/2-14/2-14:1.1/0003:046D:C332.0007/input/input21/event21"
[  3435.032] (II) XINPUT: Adding extended input device "Logitech Gaming Mouse G502 Keyboard" (type: KEYBOARD, id 13)
[  3435.032] (**) Option "xkb_model" "fr-latin1"
[  3435.032] (**) Option "xkb_layout" "fr"
[  3435.033] (II) event21 - Logitech Gaming Mouse G502 Keyboard: is tagged by udev as: Keyboard
[  3435.033] (II) event21 - Logitech Gaming Mouse G502 Keyboard: device is a keyboard
[  3435.034] (II) config/udev: Adding input device Logitech Gaming Mouse G502 Consumer Control (/dev/input/event23)
[  3435.034] (**) Logitech Gaming Mouse G502 Consumer Control: Applying InputClass "libinput keyboard catchall"
[  3435.034] (**) Logitech Gaming Mouse G502 Consumer Control: Applying InputClass "system-keyboard"
[  3435.034] (II) Using input driver 'libinput' for 'Logitech Gaming Mouse G502 Consumer Control'
[  3435.035] (II) systemd-logind: got fd for /dev/input/event23 13:87 fd 42 paused 0
[  3435.035] (**) Logitech Gaming Mouse G502 Consumer Control: always reports core events
[  3435.035] (**) Option "Device" "/dev/input/event23"
[  3435.035] (**) Option "_source" "server/udev"
[  3435.036] (II) event23 - Logitech Gaming Mouse G502 Consumer Control: is tagged by udev as: Keyboard
[  3435.036] (II) event23 - Logitech Gaming Mouse G502 Consumer Control: device is a keyboard
[  3435.036] (II) event23 - Logitech Gaming Mouse G502 Consumer Control: device removed
[  3435.036] (II) libinput: Logitech Gaming Mouse G502 Consumer Control: needs a virtual subdevice
[  3435.036] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:14.0/usb2/2-14/2-14:1.1/0003:046D:C332.0007/input/input22/event23"
[  3435.036] (II) XINPUT: Adding extended input device "Logitech Gaming Mouse G502 Consumer Control" (type: MOUSE, id 14)
[  3435.037] (**) Option "AccelerationScheme" "none"
[  3435.037] (**) Logitech Gaming Mouse G502 Consumer Control: (accel) selected scheme none/0
[  3435.037] (**) Logitech Gaming Mouse G502 Consumer Control: (accel) acceleration factor: 2.000
[  3435.037] (**) Logitech Gaming Mouse G502 Consumer Control: (accel) acceleration threshold: 4
[  3435.038] (II) event23 - Logitech Gaming Mouse G502 Consumer Control: is tagged by udev as: Keyboard
[  3435.038] (II) event23 - Logitech Gaming Mouse G502 Consumer Control: device is a keyboard
[  3435.039] (II) config/udev: Adding input device Logitech Gaming Mouse G502 System Control (/dev/input/event24)
[  3435.039] (**) Logitech Gaming Mouse G502 System Control: Applying InputClass "libinput keyboard catchall"
[  3435.039] (**) Logitech Gaming Mouse G502 System Control: Applying InputClass "system-keyboard"
[  3435.039] (II) Using input driver 'libinput' for 'Logitech Gaming Mouse G502 System Control'
[  3435.039] (II) systemd-logind: got fd for /dev/input/event24 13:88 fd 43 paused 0
[  3435.039] (**) Logitech Gaming Mouse G502 System Control: always reports core events
[  3435.040] (**) Option "Device" "/dev/input/event24"
[  3435.040] (**) Option "_source" "server/udev"
[  3435.041] (II) event24 - Logitech Gaming Mouse G502 System Control: is tagged by udev as: Keyboard
[  3435.041] (II) event24 - Logitech Gaming Mouse G502 System Control: device is a keyboard
[  3435.041] (II) event24 - Logitech Gaming Mouse G502 System Control: device removed
[  3435.041] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:14.0/usb2/2-14/2-14:1.1/0003:046D:C332.0007/input/input23/event24"
[  3435.041] (II) XINPUT: Adding extended input device "Logitech Gaming Mouse G502 System Control" (type: KEYBOARD, id 15)
[  3435.041] (**) Option "xkb_model" "fr-latin1"
[  3435.041] (**) Option "xkb_layout" "fr"
[  3435.043] (II) event24 - Logitech Gaming Mouse G502 System Control: is tagged by udev as: Keyboard
[  3435.043] (II) event24 - Logitech Gaming Mouse G502 System Control: device is a keyboard
[  3435.043] (II) config/udev: Adding input device HDA Intel PCH Front Mic (/dev/input/event11)
[  3435.043] (II) No input driver specified, ignoring this device.
[  3435.043] (II) This device may have been added with another device file.
[  3435.044] (II) config/udev: Adding input device HDA Intel PCH Rear Mic (/dev/input/event12)
[  3435.044] (II) No input driver specified, ignoring this device.
[  3435.044] (II) This device may have been added with another device file.
[  3435.044] (II) config/udev: Adding input device HDA Intel PCH Line (/dev/input/event13)
[  3435.045] (II) config/udev: Adding input device HDA Intel PCH Line Out Front (/dev/input/event14)
[  3435.045] (II) No input driver specified, ignoring this device.
[  3435.045] (II) This device may have been added with another device file.
[  3435.045] (II) config/udev: Adding input device HDA Intel PCH Line Out Surround (/dev/input/event15)
[  3435.045] (II) config/udev: Adding input device HDA Intel PCH Line Out CLFE (/dev/input/event16)
[  3435.046] (II) config/udev: Adding input device HDA Intel PCH Front Headphone (/dev/input/event17)
[  3435.046] (II) No input driver specified, ignoring this device.
[  3435.046] (II) This device may have been added with another device file.
[  3435.046] (II) config/udev: Adding input device Eee PC WMI hotkeys (/dev/input/event3)
[  3435.046] (**) Eee PC WMI hotkeys: Applying InputClass "libinput keyboard catchall"
[  3435.046] (**) Eee PC WMI hotkeys: Applying InputClass "system-keyboard"
[  3435.046] (II) Using input driver 'libinput' for 'Eee PC WMI hotkeys'
[  3435.047] (II) systemd-logind: got fd for /dev/input/event3 13:67 fd 44 paused 0
[  3435.047] (**) Eee PC WMI hotkeys: always reports core events
[  3435.047] (**) Option "Device" "/dev/input/event3"
[  3435.047] (**) Option "_source" "server/udev"
[  3435.048] (II) event3  - Eee PC WMI hotkeys: is tagged by udev as: Keyboard
[  3435.048] (II) event3  - Eee PC WMI hotkeys: device is a keyboard
[  3435.048] (II) event3  - Eee PC WMI hotkeys: device removed
[  3435.048] (**) Option "config_info" "udev:/sys/devices/platform/eeepc-wmi/input/input3/event3"
[  3435.048] (II) XINPUT: Adding extended input device "Eee PC WMI hotkeys" (type: KEYBOARD, id 16)
[  3435.048] (**) Option "xkb_model" "fr-latin1"
[  3435.048] (**) Option "xkb_layout" "fr"
[  3435.049] (II) event3  - Eee PC WMI hotkeys: is tagged by udev as: Keyboard
[  3435.049] (II) event3  - Eee PC WMI hotkeys: device is a keyboard
[  3435.050] (II) config/udev: Adding input device PC Speaker (/dev/input/event2)
[  3435.050] (II) No input driver specified, ignoring this device.
[  3435.050] (II) This device may have been added with another device file.
[  3435.054] (**) Valve Software Steam Controller: Applying InputClass "libinput pointer catchall"
[  3435.054] (**) Valve Software Steam Controller: Applying InputClass "libinput keyboard catchall"
[  3435.054] (**) Valve Software Steam Controller: Applying InputClass "system-keyboard"
[  3435.054] (II) Using input driver 'libinput' for 'Valve Software Steam Controller'
[  3435.054] (II) systemd-logind: returning pre-existing fd for /dev/input/event19 13:83
[  3435.054] (**) Valve Software Steam Controller: always reports core events
[  3435.054] (**) Option "Device" "/dev/input/event19"
[  3435.054] (**) Option "_source" "_driver/libinput"
[  3435.054] (II) libinput: Valve Software Steam Controller: is a virtual subdevice
[  3435.054] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:14.0/usb2/2-10/2-10:1.0/0003:28DE:1142.0001/input/input29/event19"
[  3435.054] (II) XINPUT: Adding extended input device "Valve Software Steam Controller" (type: KEYBOARD, id 17)
[  3435.054] (**) Option "xkb_model" "fr-latin1"
[  3435.055] (**) Option "xkb_layout" "fr"
[  3435.055] (**) Logitech Gaming Mouse G502 Consumer Control: Applying InputClass "libinput keyboard catchall"
[  3435.055] (**) Logitech Gaming Mouse G502 Consumer Control: Applying InputClass "system-keyboard"
[  3435.055] (II) Using input driver 'libinput' for 'Logitech Gaming Mouse G502 Consumer Control'
[  3435.055] (II) systemd-logind: returning pre-existing fd for /dev/input/event23 13:87
[  3435.055] (**) Logitech Gaming Mouse G502 Consumer Control: always reports core events
[  3435.055] (**) Option "Device" "/dev/input/event23"
[  3435.055] (**) Option "_source" "_driver/libinput"
[  3435.055] (II) libinput: Logitech Gaming Mouse G502 Consumer Control: is a virtual subdevice
[  3435.055] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:14.0/usb2/2-14/2-14:1.1/0003:046D:C332.0007/input/input22/event23"
[  3435.055] (II) XINPUT: Adding extended input device "Logitech Gaming Mouse G502 Consumer Control" (type: KEYBOARD, id 18)
[  3435.055] (**) Option "xkb_model" "fr-latin1"
[  3435.055] (--) NVIDIA(GPU-0): HPN HP ENVY 27s (DFP-2): connected
[  3435.055] (--) NVIDIA(GPU-0): HPN HP ENVY 27s (DFP-2): Internal DisplayPort
[  3435.055] (--) NVIDIA(GPU-0): HPN HP ENVY 27s (DFP-2): 960.0 MHz maximum pixel clock
[  3902.074] (EE) client bug: timer event20 debounce: scheduled expiry is in the past (-20ms), your system is too slow
[  3902.074] (EE) client bug: timer event20 debounce short: scheduled expiry is in the past (-33ms), your system is too slow
[  4330.457] (EE) client bug: timer event20 debounce: scheduled expiry is in the past (-4ms), your system is too slow
[  4330.457] (EE) client bug: timer event20 debounce short: scheduled expiry is in the past (-17ms), your system is too slow
[  4860.872] (--) NVIDIA(GPU-0): CRT-0: disconnected
[  4860.872] (--) NVIDIA(GPU-0): CRT-0: 400.0 MHz maximum pixel clock
[  4860.876] (--) NVIDIA(GPU-0): DFP-0: disconnected
[  4860.876] (--) NVIDIA(GPU-0): DFP-0: Internal TMDS
[  4860.876] (--) NVIDIA(GPU-0): DFP-0: 330.0 MHz maximum pixel clock
[  4860.876] (--) NVIDIA(GPU-0): DFP-1: disconnected
[  4860.876] (--) NVIDIA(GPU-0): DFP-1: Internal TMDS
[  4860.876] (--) NVIDIA(GPU-0): DFP-1: 165.0 MHz maximum pixel clock
[  4860.876] (--) NVIDIA(GPU-0): HPN HP ENVY 27s (DFP-2): connected
[  4860.876] (--) NVIDIA(GPU-0): HPN HP ENVY 27s (DFP-2): Internal DisplayPort
[  4860.876] (--) NVIDIA(GPU-0): HPN HP ENVY 27s (DFP-2): 960.0 MHz maximum pixel clock
[  4860.877] (--) NVIDIA(GPU-0): DFP-3: disconnected
[  4860.877] (--) NVIDIA(GPU-0): DFP-3: Internal TMDS
[  4860.877] (--) NVIDIA(GPU-0): DFP-3: 165.0 MHz maximum pixel clock
[  4860.877] (--) NVIDIA(GPU-0): DFP-4: disconnected
[  4860.877] (--) NVIDIA(GPU-0): DFP-4: Internal TMDS
[  4860.877] (--) NVIDIA(GPU-0): DFP-4: 330.0 MHz maximum pixel clock
[  4861.864] (--) NVIDIA(GPU-0): CRT-0: disconnected
[  4861.865] (--) NVIDIA(GPU-0): CRT-0: 400.0 MHz maximum pixel clock
[  4861.869] (--) NVIDIA(GPU-0): DFP-0: disconnected
[  4861.869] (--) NVIDIA(GPU-0): DFP-0: Internal TMDS
[  4861.869] (--) NVIDIA(GPU-0): DFP-0: 330.0 MHz maximum pixel clock
[  4861.869] (--) NVIDIA(GPU-0): DFP-1: disconnected
[  4861.869] (--) NVIDIA(GPU-0): DFP-1: Internal TMDS
[  4861.869] (--) NVIDIA(GPU-0): DFP-1: 165.0 MHz maximum pixel clock
[  4861.869] (--) NVIDIA(GPU-0): HPN HP ENVY 27s (DFP-2): connected
[  4861.869] (--) NVIDIA(GPU-0): HPN HP ENVY 27s (DFP-2): Internal DisplayPort
[  4861.869] (--) NVIDIA(GPU-0): HPN HP ENVY 27s (DFP-2): 960.0 MHz maximum pixel clock
[  4861.870] (--) NVIDIA(GPU-0): DFP-3: disconnected
[  4861.870] (--) NVIDIA(GPU-0): DFP-3: Internal TMDS
[  4861.870] (--) NVIDIA(GPU-0): DFP-3: 165.0 MHz maximum pixel clock
[  4861.870] (--) NVIDIA(GPU-0): DFP-4: disconnected
[  4861.870] (--) NVIDIA(GPU-0): DFP-4: Internal TMDS
[  4861.870] (--) NVIDIA(GPU-0): DFP-4: 330.0 MHz maximum pixel clock
[  4868.141] (--) NVIDIA(GPU-0): CRT-0: disconnected
[  4868.141] (--) NVIDIA(GPU-0): CRT-0: 400.0 MHz maximum pixel clock
[  4868.145] (--) NVIDIA(GPU-0): DFP-0: disconnected
[  4868.145] (--) NVIDIA(GPU-0): DFP-0: Internal TMDS
[  4868.145] (--) NVIDIA(GPU-0): DFP-0: 330.0 MHz maximum pixel clock
[  4868.146] (--) NVIDIA(GPU-0): DFP-1: disconnected
[  4868.146] (--) NVIDIA(GPU-0): DFP-1: Internal TMDS
[  4868.146] (--) NVIDIA(GPU-0): DFP-1: 165.0 MHz maximum pixel clock
[  4868.146] (--) NVIDIA(GPU-0): HPN HP ENVY 27s (DFP-2): connected
[  4868.146] (--) NVIDIA(GPU-0): HPN HP ENVY 27s (DFP-2): Internal DisplayPort
[  4868.146] (--) NVIDIA(GPU-0): HPN HP ENVY 27s (DFP-2): 960.0 MHz maximum pixel clock
[  4868.147] (--) NVIDIA(GPU-0): DFP-3: disconnected
[  4868.147] (--) NVIDIA(GPU-0): DFP-3: Internal TMDS
[  4868.147] (--) NVIDIA(GPU-0): DFP-3: 165.0 MHz maximum pixel clock
[  4868.147] (--) NVIDIA(GPU-0): DFP-4: disconnected
[  4868.147] (--) NVIDIA(GPU-0): DFP-4: Internal TMDS
[  4868.147] (--) NVIDIA(GPU-0): DFP-4: 330.0 MHz maximum pixel clock
[  5456.604] (EE) client bug: timer event20 debounce: scheduled expiry is in the past (-2ms), your system is too slow
[  5456.604] (EE) client bug: timer event20 debounce short: scheduled expiry is in the past (-15ms), your system is too slow
[  5659.828] (EE) client bug: timer event20 debounce short: scheduled expiry is in the past (-5ms), your system is too slow
[  7477.133] (II) event20 - Logitech Gaming Mouse G502: SYN_DROPPED event - some input events have been lost.
[  7478.362] (II) event20 - Logitech Gaming Mouse G502: SYN_DROPPED event - some input events have been lost.
[  7478.362] (EE) client bug: timer event20 debounce: scheduled expiry is in the past (-97ms), your system is too slow
[  7478.362] (EE) client bug: timer event20 debounce short: scheduled expiry is in the past (-110ms), your system is too slow
[  7483.943] (EE) client bug: timer event20 debounce: scheduled expiry is in the past (-20ms), your system is too slow
[  7483.943] (EE) client bug: timer event20 debounce short: scheduled expiry is in the past (-34ms), your system is too slow
[  7485.367] (EE) client bug: timer event20 debounce: scheduled expiry is in the past (-25ms), your system is too slow
[  7485.367] (EE) client bug: timer event20 debounce short: scheduled expiry is in the past (-38ms), your system is too slow
[  7488.979] (II) event20 - Logitech Gaming Mouse G502: SYN_DROPPED event - some input events have been lost.
[  7493.157] (II) event20 - Logitech Gaming Mouse G502: SYN_DROPPED event - some input events have been lost.
[  7493.304] (II) event20 - Logitech Gaming Mouse G502: SYN_DROPPED event - some input events have been lost.
[  7493.304] (II) event20 - Logitech Gaming Mouse G502: WARNING: log rate limit exceeded (5 msgs per 30000ms). Discarding future messages.
[  7528.054] (EE) client bug: timer event20 debounce short: scheduled expiry is in the past (-4ms), your system is too slow
[  7529.829] (EE) client bug: timer event20 debounce: scheduled expiry is in the past (-54ms), your system is too slow
[  7530.758] (EE) client bug: timer event20 debounce short: scheduled expiry is in the past (-996ms), your system is too slow
[  7530.758] (II) event20 - Logitech Gaming Mouse G502: SYN_DROPPED event - some input events have been lost.
[  7532.788] (EE) client bug: timer event20 debounce short: scheduled expiry is in the past (-4ms), your system is too slow
[  7533.459] (EE) client bug: timer event20 debounce: scheduled expiry is in the past (-18ms), your system is too slow
[  7533.505] (EE) client bug: timer event20 debounce: scheduled expiry is in the past (-0ms), your system is too slow
[  7533.505] (EE) client bug: timer event20 debounce short: scheduled expiry is in the past (-14ms), your system is too slow
[  7534.205] (EE) client bug: timer event20 debounce: scheduled expiry is in the past (-3ms), your system is too slow
[  7534.266] (EE) client bug: timer event20 debounce: scheduled expiry is in the past (-0ms), your system is too slow
[  7534.266] (EE) client bug: timer event20 debounce short: scheduled expiry is in the past (-13ms), your system is too slow
[  7535.841] (EE) client bug: timer event20 debounce short: scheduled expiry is in the past (-9ms), your system is too slow
[  7536.532] (EE) client bug: timer event20 debounce: scheduled expiry is in the past (-49ms), your system is too slow
[  7538.207] (II) event20 - Logitech Gaming Mouse G502: SYN_DROPPED event - some input events have been lost.
[  7538.638] (II) event20 - Logitech Gaming Mouse G502: SYN_DROPPED event - some input events have been lost.
[  7538.844] (II) event20 - Logitech Gaming Mouse G502: SYN_DROPPED event - some input events have been lost.
[  7539.247] (II) event20 - Logitech Gaming Mouse G502: SYN_DROPPED event - some input events have been lost.
[  7539.247] (II) event20 - Logitech Gaming Mouse G502: WARNING: log rate limit exceeded (5 msgs per 30000ms). Discarding future messages.
[  7552.858] (EE) client bug: timer event20 debounce short: scheduled expiry is in the past (-3ms), your system is too slow
[  7553.629] (EE) client bug: timer event20 debounce: scheduled expiry is in the past (-5ms), your system is too slow
[  7554.896] (EE) client bug: timer event20 debounce: scheduled expiry is in the past (-11ms), your system is too slow
[  7554.950] (EE) client bug: timer event20 debounce short: scheduled expiry is in the past (-0ms), your system is too slow
[  7555.920] (EE) client bug: timer event20 debounce: scheduled expiry is in the past (-14ms), your system is too slow
[  7555.920] (EE) client bug: timer event20 debounce short: scheduled expiry is in the past (-27ms), your system is too slow
[  7559.294] (EE) client bug: timer event20 debounce: scheduled expiry is in the past (-311ms), your system is too slow
[  7559.294] (EE) client bug: timer event20 debounce: scheduled expiry is in the past (-211ms), your system is too slow
[  7559.294] (EE) client bug: timer event20 debounce short: scheduled expiry is in the past (-224ms), your system is too slow
____________________________________________
*** /var/log/Xorg.2.log
*** ls: -rw-r--r-- 1 root user 38223 2020-06-23 14:55:28.726177785 +0200 /var/log/Xorg.2.log
[  7583.866] (WW) Failed to open protocol names file lib/xorg/protocol.txt
[  7583.867]
X.Org X Server 1.20.8
X Protocol Version 11, Revision 0
[  7583.871] Build Operating System: Linux Arch Linux
[  7583.872] Current Operating System: Linux localhost 5.7.4-arch1-1 #1 SMP PREEMPT Thu, 18 Jun 2020 16:01:07 +0000 x86_64
[  7583.873] Kernel command line: root=UUID=6c37d730-4b14-4479-8554-92d2e75478d5 rw initrd=\initramfs-linux.img
[  7583.875] Build Date: 05 May 2020  05:08:17AM
[  7583.876]
[  7583.878] Current version of pixman: 0.40.0
[  7583.881] 	Before reporting problems, check
	to make sure that you have the latest version.
[  7583.881] Markers: (--) probed, (**) from config file, (==) default setting,
	(++) from command line, (!!) notice, (II) informational,
	(WW) warning, (EE) error, (NI) not implemented, (??) unknown.
[  7583.887] (==) Log file: "/var/log/Xorg.2.log", Time: Tue Jun 23 14:55:19 2020
[  7583.890] (==) Using config file: "/etc/X11/xorg.conf"
[  7583.891] (==) Using config directory: "/etc/X11/xorg.conf.d"
[  7583.892] (==) Using system config directory "/usr/share/X11/xorg.conf.d"
[  7583.893] (==) ServerLayout "Layout0"
[  7583.893] (**) |-->Screen "Screen0" (0)
[  7583.893] (**) |   |-->Monitor "Monitor0"
[  7583.894] (**) |   |-->Device "Device0"
[  7583.894] (**) |   |-->GPUDevice "Device0"
[  7583.894] (**) |-->Input Device "Keyboard0"
[  7583.894] (**) |-->Input Device "Mouse0"
[  7583.894] (**) Option "Xinerama" "0"
[  7583.894] (==) Automatically adding devices
[  7583.894] (==) Automatically enabling devices
[  7583.894] (==) Automatically adding GPU devices
[  7583.894] (==) Automatically binding GPU devices
[  7583.894] (==) Max clients allowed: 256, resource mask: 0x1fffff
[  7583.897] (WW) `fonts.dir' not found (or not valid) in "/usr/share/fonts/OTF".
[  7583.897] 	Entry deleted from font path.
[  7583.897] 	(Run 'mkfontdir' on "/usr/share/fonts/OTF").
[  7583.897] (WW) The directory "/usr/share/fonts/Type1" does not exist.
[  7583.897] (WW) The directory "/usr/share/fonts/100dpi" does not exist.
[  7583.897] (WW) The directory "/usr/share/fonts/75dpi" does not exist.
[  7583.897] (==) FontPath set to:
	/usr/share/fonts/misc,
	/usr/share/fonts/TTF
[  7583.897] (==) ModulePath set to "/usr/lib/xorg/modules"
[  7583.897] (WW) Hotplugging is on, devices using drivers 'kbd', 'mouse' or 'vmmouse' will be disabled.
[  7583.897] (WW) Disabling Keyboard0
[  7583.897] (WW) Disabling Mouse0
[  7583.897] (II) Module ABI versions:
[  7583.897] 	X.Org ANSI C Emulation: 0.4
[  7583.897] 	X.Org Video Driver: 24.1
[  7583.897] 	X.Org XInput driver : 24.1
[  7583.897] 	X.Org Server Extension : 10.0
[  7583.897] (++) using VT number 1
[  7583.899] (II) systemd-logind: took control of session /org/freedesktop/login1/session/_31
[  7583.899] (II) xfree86: Adding drm device (/dev/dri/card0)
[  7583.899] (II) systemd-logind: got fd for /dev/dri/card0 226:0 fd 10 paused 0
[  7583.900] (**) OutputClass "nvidia" ModulePath extended to "/usr/lib/nvidia/xorg,/usr/lib/xorg/modules,/usr/lib/xorg/modules"
[  7583.900] (--) PCI:*(1@0:0:0) 10de:13c2:1462:3160 rev 161, Mem @ 0xde000000/16777216, 0xc0000000/268435456, 0xd0000000/33554432, I/O @ 0x0000e000/128, BIOS @ 0x????????/131072
[  7583.900] (WW) Open ACPI failed (/var/run/acpid.socket) (No such file or directory)
[  7583.900] (II) LoadModule: "glx"
[  7583.902] (II) Loading /usr/lib/xorg/modules/extensions/libglx.so
[  7583.906] (II) Module glx: vendor="X.Org Foundation"
[  7583.906] 	compiled for 1.20.8, module version = 1.0.0
[  7583.906] 	ABI class: X.Org Server Extension, version 10.0
[  7583.906] (II) LoadModule: "nvidia"
[  7583.907] (II) Loading /usr/lib/xorg/modules/drivers/nvidia_drv.so
[  7583.913] (II) Module nvidia: vendor="NVIDIA Corporation"
[  7583.913] 	compiled for 1.6.99.901, module version = 1.0.0
[  7583.913] 	Module class: X.Org Video Driver
[  7583.914] (II) NVIDIA dlloader X Driver  440.82  Wed Apr  1 19:50:17 UTC 2020
[  7583.914] (II) NVIDIA Unified Driver for all Supported NVIDIA GPUs
[  7583.914] (II) systemd-logind: releasing fd for 226:0
[  7583.915] (II) Loading sub module "fb"
[  7583.916] (II) LoadModule: "fb"
[  7583.916] (II) Loading /usr/lib/xorg/modules/libfb.so
[  7583.917] (II) Module fb: vendor="X.Org Foundation"
[  7583.917] 	compiled for 1.20.8, module version = 1.0.0
[  7583.917] 	ABI class: X.Org ANSI C Emulation, version 0.4
[  7583.917] (II) Loading sub module "wfb"
[  7583.917] (II) LoadModule: "wfb"
[  7583.917] (II) Loading /usr/lib/xorg/modules/libwfb.so
[  7583.918] (II) Module wfb: vendor="X.Org Foundation"
[  7583.918] 	compiled for 1.20.8, module version = 1.0.0
[  7583.918] 	ABI class: X.Org ANSI C Emulation, version 0.4
[  7583.918] (II) Loading sub module "ramdac"
[  7583.918] (II) LoadModule: "ramdac"
[  7583.918] (II) Module "ramdac" already built-in
[  7583.920] (**) NVIDIA(0): Depth 24, (--) framebuffer bpp 32
[  7583.920] (==) NVIDIA(0): RGB weight 888
[  7583.920] (==) NVIDIA(0): Default visual is TrueColor
[  7583.920] (==) NVIDIA(0): Using gamma correction (1.0, 1.0, 1.0)
[  7583.921] (II) Applying OutputClass "nvidia" options to /dev/dri/card0
[  7583.921] (**) NVIDIA(0): Option "Stereo" "0"
[  7583.921] (**) NVIDIA(0): Option "nvidiaXineramaInfoOrder" "DFP-1"
[  7583.921] (**) NVIDIA(0): Option "SLI" "Off"
[  7583.921] (**) NVIDIA(0): Option "MultiGPU" "Off"
[  7583.921] (**) NVIDIA(0): Option "BaseMosaic" "off"
[  7583.921] (**) NVIDIA(0): Option "AllowEmptyInitialConfiguration"
[  7583.921] (**) NVIDIA(0): Stereo disabled by request
[  7583.921] (**) NVIDIA(0): NVIDIA SLI disabled.
[  7583.921] (**) NVIDIA(0): NVIDIA Multi-GPU disabled.
[  7583.921] (**) NVIDIA(0): Option "MetaModes" "HDMI-0: 3840x2160_60 +0+0, DP-0: 1920x1080_144 +3840+0"
[  7583.921] (**) NVIDIA(0): Enabling 2D acceleration
[  7583.921] (II) Loading sub module "glxserver_nvidia"
[  7583.921] (II) LoadModule: "glxserver_nvidia"
[  7583.921] (II) Loading /usr/lib/nvidia/xorg/libglxserver_nvidia.so
[  7583.970] (II) Module glxserver_nvidia: vendor="NVIDIA Corporation"
[  7583.970] 	compiled for 1.6.99.901, module version = 1.0.0
[  7583.970] 	Module class: X.Org Server Extension
[  7583.971] (II) NVIDIA GLX Module  440.82  Wed Apr  1 19:47:36 UTC 2020
[  7583.972] (II) NVIDIA: The X server supports PRIME Render Offload.
[  7584.239] (--) NVIDIA(0): Valid display device(s) on GPU-0 at PCI:1:0:0
[  7584.239] (--) NVIDIA(0):     CRT-0
[  7584.239] (--) NVIDIA(0):     DFP-0
[  7584.239] (--) NVIDIA(0):     DFP-1
[  7584.239] (--) NVIDIA(0):     DFP-2 (boot)
[  7584.239] (--) NVIDIA(0):     DFP-3
[  7584.239] (--) NVIDIA(0):     DFP-4
[  7584.239] (II) NVIDIA(0): NVIDIA GPU GeForce GTX 970 (GM204-A) at PCI:1:0:0 (GPU-0)
[  7584.239] (--) NVIDIA(0): Memory: 4194304 kBytes
[  7584.239] (--) NVIDIA(0): VideoBIOS: 84.04.2f.00.f1
[  7584.239] (II) NVIDIA(0): Detected PCI Express Link width: 16X
[  7584.243] (--) NVIDIA(GPU-0): CRT-0: disconnected
[  7584.243] (--) NVIDIA(GPU-0): CRT-0: 400.0 MHz maximum pixel clock
[  7584.247] (--) NVIDIA(GPU-0): DFP-0: disconnected
[  7584.247] (--) NVIDIA(GPU-0): DFP-0: Internal TMDS
[  7584.247] (--) NVIDIA(GPU-0): DFP-0: 330.0 MHz maximum pixel clock
[  7584.247] (--) NVIDIA(GPU-0): DFP-1: disconnected
[  7584.247] (--) NVIDIA(GPU-0): DFP-1: Internal TMDS
[  7584.247] (--) NVIDIA(GPU-0): DFP-1: 165.0 MHz maximum pixel clock
[  7584.247] (--) NVIDIA(GPU-0): HPN HP ENVY 27s (DFP-2): connected
[  7584.247] (--) NVIDIA(GPU-0): HPN HP ENVY 27s (DFP-2): Internal DisplayPort
[  7584.247] (--) NVIDIA(GPU-0): HPN HP ENVY 27s (DFP-2): 960.0 MHz maximum pixel clock
[  7584.248] (--) NVIDIA(GPU-0): DFP-3: disconnected
[  7584.248] (--) NVIDIA(GPU-0): DFP-3: Internal TMDS
[  7584.248] (--) NVIDIA(GPU-0): DFP-3: 165.0 MHz maximum pixel clock
[  7584.248] (--) NVIDIA(GPU-0): DFP-4: disconnected
[  7584.248] (--) NVIDIA(GPU-0): DFP-4: Internal TMDS
[  7584.248] (--) NVIDIA(GPU-0): DFP-4: 330.0 MHz maximum pixel clock
[  7584.251] (WW) NVIDIA(0): No valid modes for
[  7584.251] (WW) NVIDIA(0):     "HDMI-0:3840x2160_60+0+0,DP-0:1920x1080_144+3840+0";
[  7584.251] (WW) NVIDIA(0):     removing.
[  7584.251] (WW) NVIDIA(0): Unable to validate any modes; falling back to the default mode
[  7584.251] (WW) NVIDIA(0):     "nvidia-auto-select".
[  7584.251] (II) NVIDIA(0): Validated MetaModes:
[  7584.251] (II) NVIDIA(0):     "DFP-2:nvidia-auto-select"
[  7584.251] (II) NVIDIA(0): Virtual screen size determined to be 3840 x 2160
[  7584.254] (--) NVIDIA(0): DPI set to (162, 161); computed from "UseEdidDpi" X config
[  7584.254] (--) NVIDIA(0):     option
[  7584.254] (II) NVIDIA: Using 6144.00 MB of virtual memory for indirect memory
[  7584.254] (II) NVIDIA:     access.
[  7584.256] (II) NVIDIA(0): ACPI: failed to connect to the ACPI event daemon; the daemon
[  7584.256] (II) NVIDIA(0):     may not be running or the "AcpidSocketPath" X
[  7584.256] (II) NVIDIA(0):     configuration option may not be set correctly.  When the
[  7584.256] (II) NVIDIA(0):     ACPI event daemon is available, the NVIDIA X driver will
[  7584.256] (II) NVIDIA(0):     try to use it to receive ACPI event notifications.  For
[  7584.256] (II) NVIDIA(0):     details, please see the "ConnectToAcpid" and
[  7584.256] (II) NVIDIA(0):     "AcpidSocketPath" X configuration options in Appendix B: X
[  7584.256] (II) NVIDIA(0):     Config Options in the README.
[  7584.278] (II) NVIDIA(0): Setting mode "DFP-2:nvidia-auto-select"
[  7584.375] (==) NVIDIA(0): Disabling shared memory pixmaps
[  7584.375] (==) NVIDIA(0): Backing store enabled
[  7584.375] (==) NVIDIA(0): Silken mouse disabled
[  7584.376] (**) NVIDIA(0): DPMS enabled
[  7584.376] (II) Loading sub module "dri2"
[  7584.376] (II) LoadModule: "dri2"
[  7584.376] (II) Module "dri2" already built-in
[  7584.376] (II) NVIDIA(0): [DRI2] Setup complete
[  7584.376] (II) NVIDIA(0): [DRI2]   VDPAU driver: nvidia
[  7584.376] (II) Initializing extension Generic Event Extension
[  7584.376] (II) Initializing extension SHAPE
[  7584.376] (II) Initializing extension MIT-SHM
[  7584.376] (II) Initializing extension XInputExtension
[  7584.376] (II) Initializing extension XTEST
[  7584.376] (II) Initializing extension BIG-REQUESTS
[  7584.376] (II) Initializing extension SYNC
[  7584.376] (II) Initializing extension XKEYBOARD
[  7584.376] (II) Initializing extension XC-MISC
[  7584.376] (II) Initializing extension SECURITY
[  7584.376] (II) Initializing extension XFIXES
[  7584.376] (II) Initializing extension RENDER
[  7584.376] (II) Initializing extension RANDR
[  7584.376] (II) Initializing extension COMPOSITE
[  7584.376] (II) Initializing extension DAMAGE
[  7584.376] (II) Initializing extension MIT-SCREEN-SAVER
[  7584.376] (II) Initializing extension DOUBLE-BUFFER
[  7584.376] (II) Initializing extension RECORD
[  7584.376] (II) Initializing extension DPMS
[  7584.376] (II) Initializing extension Present
[  7584.376] (II) Initializing extension DRI3
[  7584.376] (II) Initializing extension X-Resource
[  7584.376] (II) Initializing extension XVideo
[  7584.376] (II) Initializing extension XVideo-MotionCompensation
[  7584.376] (II) Initializing extension GLX
[  7584.376] (II) Indirect GLX disabled.
[  7584.376] (II) GLX: Another vendor is already registered for screen 0
[  7584.376] (II) Initializing extension XFree86-VidModeExtension
[  7584.376] (II) Initializing extension XFree86-DGA
[  7584.376] (II) Initializing extension XFree86-DRI
[  7584.376] (II) Initializing extension DRI2
[  7584.376] (II) Initializing extension NV-GLX
[  7584.376] (II) Initializing extension NV-CONTROL
[  7584.376] (II) Initializing extension XINERAMA
[  7584.424] (II) config/udev: Adding input device Power Button (/dev/input/event1)
[  7584.424] (**) Power Button: Applying InputClass "libinput keyboard catchall"
[  7584.424] (**) Power Button: Applying InputClass "system-keyboard"
[  7584.424] (II) LoadModule: "libinput"
[  7584.424] (II) Loading /usr/lib/xorg/modules/input/libinput_drv.so
[  7584.430] (II) Module libinput: vendor="X.Org Foundation"
[  7584.430] 	compiled for 1.20.8, module version = 0.30.0
[  7584.430] 	Module class: X.Org XInput Driver
[  7584.430] 	ABI class: X.Org XInput driver, version 24.1
[  7584.430] (II) Using input driver 'libinput' for 'Power Button'
[  7584.430] (II) systemd-logind: got fd for /dev/input/event1 13:65 fd 32 paused 0
[  7584.430] (**) Power Button: always reports core events
[  7584.430] (**) Option "Device" "/dev/input/event1"
[  7584.430] (**) Option "_source" "server/udev"
[  7584.437] (II) event1  - Power Button: is tagged by udev as: Keyboard
[  7584.437] (II) event1  - Power Button: device is a keyboard
[  7584.437] (II) event1  - Power Button: device removed
[  7584.437] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXPWRBN:00/input/input1/event1"
[  7584.437] (II) XINPUT: Adding extended input device "Power Button" (type: KEYBOARD, id 6)
[  7584.437] (**) Option "xkb_model" "fr-latin1"
[  7584.437] (**) Option "xkb_layout" "fr"
[  7584.452] (II) event1  - Power Button: is tagged by udev as: Keyboard
[  7584.452] (II) event1  - Power Button: device is a keyboard
[  7584.452] (II) config/udev: Adding input device Power Button (/dev/input/event0)
[  7584.452] (**) Power Button: Applying InputClass "libinput keyboard catchall"
[  7584.452] (**) Power Button: Applying InputClass "system-keyboard"
[  7584.452] (II) Using input driver 'libinput' for 'Power Button'
[  7584.453] (II) systemd-logind: got fd for /dev/input/event0 13:64 fd 35 paused 0
[  7584.453] (**) Power Button: always reports core events
[  7584.453] (**) Option "Device" "/dev/input/event0"
[  7584.453] (**) Option "_source" "server/udev"
[  7584.453] (II) event0  - Power Button: is tagged by udev as: Keyboard
[  7584.453] (II) event0  - Power Button: device is a keyboard
[  7584.454] (II) event0  - Power Button: device removed
[  7584.454] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0C:00/input/input0/event0"
[  7584.454] (II) XINPUT: Adding extended input device "Power Button" (type: KEYBOARD, id 7)
[  7584.454] (**) Option "xkb_model" "fr-latin1"
[  7584.454] (**) Option "xkb_layout" "fr"
[  7584.454] (II) event0  - Power Button: is tagged by udev as: Keyboard
[  7584.454] (II) event0  - Power Button: device is a keyboard
[  7584.455] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=12 (/dev/input/event10)
[  7584.455] (II) No input driver specified, ignoring this device.
[  7584.455] (II) This device may have been added with another device file.
[  7584.455] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=3 (/dev/input/event4)
[  7584.455] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=7 (/dev/input/event5)
[  7584.455] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=8 (/dev/input/event6)
[  7584.455] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=9 (/dev/input/event7)
[  7584.456] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=10 (/dev/input/event8)
[  7584.456] (II) No input driver specified, ignoring this device.
[  7584.456] (II) This device may have been added with another device file.
[  7584.456] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=11 (/dev/input/event9)
[  7584.456] (II) config/udev: Adding input device Valve Software Steam Controller (/dev/input/event19)
[  7584.456] (**) Valve Software Steam Controller: Applying InputClass "libinput pointer catchall"
[  7584.456] (**) Valve Software Steam Controller: Applying InputClass "libinput keyboard catchall"
[  7584.456] (**) Valve Software Steam Controller: Applying InputClass "system-keyboard"
[  7584.456] (II) Using input driver 'libinput' for 'Valve Software Steam Controller'
[  7584.457] (II) systemd-logind: got fd for /dev/input/event19 13:83 fd 36 paused 0
[  7584.457] (**) Valve Software Steam Controller: always reports core events
[  7584.457] (**) Option "Device" "/dev/input/event19"
[  7584.457] (**) Option "_source" "server/udev"
[  7584.458] (II) event19 - Valve Software Steam Controller: is tagged by udev as: Keyboard Mouse
[  7584.458] (II) event19 - Valve Software Steam Controller: device is a pointer
[  7584.458] (II) event19 - Valve Software Steam Controller: device is a keyboard
[  7584.458] (II) event19 - Valve Software Steam Controller: device removed
[  7584.458] (II) libinput: Valve Software Steam Controller: needs a virtual subdevice
[  7584.458] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:14.0/usb2/2-10/2-10:1.0/0003:28DE:1142.0001/input/input29/event19"
[  7584.458] (II) XINPUT: Adding extended input device "Valve Software Steam Controller" (type: MOUSE, id 8)
[  7584.458] (**) Option "AccelerationScheme" "none"
[  7584.458] (**) Valve Software Steam Controller: (accel) selected scheme none/0
[  7584.458] (**) Valve Software Steam Controller: (accel) acceleration factor: 2.000
[  7584.458] (**) Valve Software Steam Controller: (accel) acceleration threshold: 4
[  7584.459] (II) event19 - Valve Software Steam Controller: is tagged by udev as: Keyboard Mouse
[  7584.459] (II) event19 - Valve Software Steam Controller: device is a pointer
[  7584.459] (II) event19 - Valve Software Steam Controller: device is a keyboard
[  7584.459] (II) config/udev: Adding input device Valve Software Steam Controller (/dev/input/mouse0)
[  7584.459] (**) Valve Software Steam Controller: Applying InputClass "system-keyboard"
[  7584.459] (II) No input driver specified, ignoring this device.
[  7584.459] (II) This device may have been added with another device file.
[  7584.460] (II) config/udev: Adding input device Logitech Logitech Gaming Keyboard (/dev/input/event22)
[  7584.460] (**) Logitech Logitech Gaming Keyboard: Applying InputClass "libinput keyboard catchall"
[  7584.460] (**) Logitech Logitech Gaming Keyboard: Applying InputClass "system-keyboard"
[  7584.460] (II) Using input driver 'libinput' for 'Logitech Logitech Gaming Keyboard'
[  7584.460] (II) systemd-logind: got fd for /dev/input/event22 13:86 fd 37 paused 0
[  7584.460] (**) Logitech Logitech Gaming Keyboard: always reports core events
[  7584.460] (**) Option "Device" "/dev/input/event22"
[  7584.460] (**) Option "_source" "server/udev"
[  7584.461] (II) event22 - Logitech Logitech Gaming Keyboard: is tagged by udev as: Keyboard
[  7584.461] (II) event22 - Logitech Logitech Gaming Keyboard: device is a keyboard
[  7584.461] (II) event22 - Logitech Logitech Gaming Keyboard: device removed
[  7584.461] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:14.0/usb2/2-13/2-13.1/2-13.1:1.0/0003:046D:C221.0008/input/input26/event22"
[  7584.461] (II) XINPUT: Adding extended input device "Logitech Logitech Gaming Keyboard" (type: KEYBOARD, id 9)
[  7584.461] (**) Option "xkb_model" "fr-latin1"
[  7584.461] (**) Option "xkb_layout" "fr"
[  7584.462] (II) event22 - Logitech Logitech Gaming Keyboard: is tagged by udev as: Keyboard
[  7584.462] (II) event22 - Logitech Logitech Gaming Keyboard: device is a keyboard
[  7584.463] (II) config/udev: Adding input device Logitech Logitech Gaming Keyboard Consumer Control (/dev/input/event18)
[  7584.463] (**) Logitech Logitech Gaming Keyboard Consumer Control: Applying InputClass "libinput keyboard catchall"
[  7584.463] (**) Logitech Logitech Gaming Keyboard Consumer Control: Applying InputClass "system-keyboard"
[  7584.463] (II) Using input driver 'libinput' for 'Logitech Logitech Gaming Keyboard Consumer Control'
[  7584.463] (II) systemd-logind: got fd for /dev/input/event18 13:82 fd 38 paused 0
[  7584.463] (**) Logitech Logitech Gaming Keyboard Consumer Control: always reports core events
[  7584.463] (**) Option "Device" "/dev/input/event18"
[  7584.463] (**) Option "_source" "server/udev"
[  7584.464] (II) event18 - Logitech Logitech Gaming Keyboard Consumer Control: is tagged by udev as: Keyboard
[  7584.464] (II) event18 - Logitech Logitech Gaming Keyboard Consumer Control: device is a keyboard
[  7584.464] (II) event18 - Logitech Logitech Gaming Keyboard Consumer Control: device removed
[  7584.464] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:14.0/usb2/2-13/2-13.1/2-13.1:1.1/0003:046D:C221.0009/input/input27/event18"
[  7584.464] (II) XINPUT: Adding extended input device "Logitech Logitech Gaming Keyboard Consumer Control" (type: KEYBOARD, id 10)
[  7584.464] (**) Option "xkb_model" "fr-latin1"
[  7584.464] (**) Option "xkb_layout" "fr"
[  7584.465] (II) event18 - Logitech Logitech Gaming Keyboard Consumer Control: is tagged by udev as: Keyboard
[  7584.465] (II) event18 - Logitech Logitech Gaming Keyboard Consumer Control: device is a keyboard
[  7584.466] (II) config/udev: Adding input device Logitech Gaming Keyboard Gaming Keys (/dev/input/event25)
[  7584.466] (**) Logitech Gaming Keyboard Gaming Keys: Applying InputClass "libinput keyboard catchall"
[  7584.466] (**) Logitech Gaming Keyboard Gaming Keys: Applying InputClass "system-keyboard"
[  7584.466] (II) Using input driver 'libinput' for 'Logitech Gaming Keyboard Gaming Keys'
[  7584.521] (II) systemd-logind: got fd for /dev/input/event25 13:89 fd 39 paused 0
[  7584.522] (**) Logitech Gaming Keyboard Gaming Keys: always reports core events
[  7584.522] (**) Option "Device" "/dev/input/event25"
[  7584.522] (**) Option "_source" "server/udev"
[  7584.523] (II) event25 - Logitech Gaming Keyboard Gaming Keys: is tagged by udev as: Keyboard
[  7584.523] (II) event25 - Logitech Gaming Keyboard Gaming Keys: device is a keyboard
[  7584.523] (II) event25 - Logitech Gaming Keyboard Gaming Keys: device removed
[  7584.523] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:14.0/usb2/2-13/2-13.4/2-13.4:1.0/0003:046D:C222.000E/input/input32/event25"
[  7584.523] (II) XINPUT: Adding extended input device "Logitech Gaming Keyboard Gaming Keys" (type: KEYBOARD, id 11)
[  7584.523] (**) Option "xkb_model" "fr-latin1"
[  7584.523] (**) Option "xkb_layout" "fr"
[  7584.525] (II) event25 - Logitech Gaming Keyboard Gaming Keys: is tagged by udev as: Keyboard
[  7584.525] (II) event25 - Logitech Gaming Keyboard Gaming Keys: device is a keyboard
[  7584.526] (II) config/udev: Adding input device Logitech Gaming Mouse G502 (/dev/input/event20)
[  7584.526] (**) Logitech Gaming Mouse G502: Applying InputClass "libinput pointer catchall"
[  7584.526] (II) Using input driver 'libinput' for 'Logitech Gaming Mouse G502'
[  7584.582] (II) systemd-logind: got fd for /dev/input/event20 13:84 fd 40 paused 0
[  7584.582] (**) Logitech Gaming Mouse G502: always reports core events
[  7584.582] (**) Option "Device" "/dev/input/event20"
[  7584.582] (**) Option "_source" "server/udev"
[  7584.584] (II) event20 - Logitech Gaming Mouse G502: is tagged by udev as: Mouse
[  7584.584] (II) event20 - Logitech Gaming Mouse G502: device set to 2400 DPI
[  7584.584] (II) event20 - Logitech Gaming Mouse G502: device is a pointer
[  7584.584] (II) event20 - Logitech Gaming Mouse G502: device removed
[  7584.584] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:14.0/usb2/2-14/2-14:1.0/0003:046D:C332.0006/input/input20/event20"
[  7584.584] (II) XINPUT: Adding extended input device "Logitech Gaming Mouse G502" (type: MOUSE, id 12)
[  7584.584] (**) Option "AccelerationScheme" "none"
[  7584.584] (**) Logitech Gaming Mouse G502: (accel) selected scheme none/0
[  7584.584] (**) Logitech Gaming Mouse G502: (accel) acceleration factor: 2.000
[  7584.584] (**) Logitech Gaming Mouse G502: (accel) acceleration threshold: 4
[  7584.587] (II) event20 - Logitech Gaming Mouse G502: is tagged by udev as: Mouse
[  7584.587] (II) event20 - Logitech Gaming Mouse G502: device set to 2400 DPI
[  7584.587] (II) event20 - Logitech Gaming Mouse G502: device is a pointer
[  7584.588] (II) config/udev: Adding input device Logitech Gaming Mouse G502 (/dev/input/mouse1)
[  7584.588] (II) No input driver specified, ignoring this device.
[  7584.588] (II) This device may have been added with another device file.
[  7584.589] (II) config/udev: Adding input device Logitech Gaming Mouse G502 Keyboard (/dev/input/event21)
[  7584.589] (**) Logitech Gaming Mouse G502 Keyboard: Applying InputClass "libinput keyboard catchall"
[  7584.589] (**) Logitech Gaming Mouse G502 Keyboard: Applying InputClass "system-keyboard"
[  7584.589] (II) Using input driver 'libinput' for 'Logitech Gaming Mouse G502 Keyboard'
[  7584.589] (II) systemd-logind: got fd for /dev/input/event21 13:85 fd 41 paused 0
[  7584.589] (**) Logitech Gaming Mouse G502 Keyboard: always reports core events
[  7584.589] (**) Option "Device" "/dev/input/event21"
[  7584.589] (**) Option "_source" "server/udev"
[  7584.590] (II) event21 - Logitech Gaming Mouse G502 Keyboard: is tagged by udev as: Keyboard
[  7584.591] (II) event21 - Logitech Gaming Mouse G502 Keyboard: device is a keyboard
[  7584.591] (II) event21 - Logitech Gaming Mouse G502 Keyboard: device removed
[  7584.591] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:14.0/usb2/2-14/2-14:1.1/0003:046D:C332.0007/input/input21/event21"
[  7584.591] (II) XINPUT: Adding extended input device "Logitech Gaming Mouse G502 Keyboard" (type: KEYBOARD, id 13)
[  7584.591] (**) Option "xkb_model" "fr-latin1"
[  7584.591] (**) Option "xkb_layout" "fr"
[  7584.592] (II) event21 - Logitech Gaming Mouse G502 Keyboard: is tagged by udev as: Keyboard
[  7584.592] (II) event21 - Logitech Gaming Mouse G502 Keyboard: device is a keyboard
[  7584.593] (II) config/udev: Adding input device Logitech Gaming Mouse G502 Consumer Control (/dev/input/event23)
[  7584.593] (**) Logitech Gaming Mouse G502 Consumer Control: Applying InputClass "libinput keyboard catchall"
[  7584.593] (**) Logitech Gaming Mouse G502 Consumer Control: Applying InputClass "system-keyboard"
[  7584.593] (II) Using input driver 'libinput' for 'Logitech Gaming Mouse G502 Consumer Control'
[  7584.594] (II) systemd-logind: got fd for /dev/input/event23 13:87 fd 42 paused 0
[  7584.594] (**) Logitech Gaming Mouse G502 Consumer Control: always reports core events
[  7584.594] (**) Option "Device" "/dev/input/event23"
[  7584.594] (**) Option "_source" "server/udev"
[  7584.595] (II) event23 - Logitech Gaming Mouse G502 Consumer Control: is tagged by udev as: Keyboard
[  7584.595] (II) event23 - Logitech Gaming Mouse G502 Consumer Control: device is a keyboard
[  7584.595] (II) event23 - Logitech Gaming Mouse G502 Consumer Control: device removed
[  7584.595] (II) libinput: Logitech Gaming Mouse G502 Consumer Control: needs a virtual subdevice
[  7584.595] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:14.0/usb2/2-14/2-14:1.1/0003:046D:C332.0007/input/input22/event23"
[  7584.595] (II) XINPUT: Adding extended input device "Logitech Gaming Mouse G502 Consumer Control" (type: MOUSE, id 14)
[  7584.595] (**) Option "AccelerationScheme" "none"
[  7584.595] (**) Logitech Gaming Mouse G502 Consumer Control: (accel) selected scheme none/0
[  7584.595] (**) Logitech Gaming Mouse G502 Consumer Control: (accel) acceleration factor: 2.000
[  7584.595] (**) Logitech Gaming Mouse G502 Consumer Control: (accel) acceleration threshold: 4
[  7584.596] (II) event23 - Logitech Gaming Mouse G502 Consumer Control: is tagged by udev as: Keyboard
[  7584.596] (II) event23 - Logitech Gaming Mouse G502 Consumer Control: device is a keyboard
[  7584.597] (II) config/udev: Adding input device Logitech Gaming Mouse G502 System Control (/dev/input/event24)
[  7584.597] (**) Logitech Gaming Mouse G502 System Control: Applying InputClass "libinput keyboard catchall"
[  7584.597] (**) Logitech Gaming Mouse G502 System Control: Applying InputClass "system-keyboard"
[  7584.597] (II) Using input driver 'libinput' for 'Logitech Gaming Mouse G502 System Control'
[  7584.598] (II) systemd-logind: got fd for /dev/input/event24 13:88 fd 43 paused 0
[  7584.598] (**) Logitech Gaming Mouse G502 System Control: always reports core events
[  7584.598] (**) Option "Device" "/dev/input/event24"
[  7584.598] (**) Option "_source" "server/udev"
[  7584.599] (II) event24 - Logitech Gaming Mouse G502 System Control: is tagged by udev as: Keyboard
[  7584.599] (II) event24 - Logitech Gaming Mouse G502 System Control: device is a keyboard
[  7584.599] (II) event24 - Logitech Gaming Mouse G502 System Control: device removed
[  7584.599] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:14.0/usb2/2-14/2-14:1.1/0003:046D:C332.0007/input/input23/event24"
[  7584.599] (II) XINPUT: Adding extended input device "Logitech Gaming Mouse G502 System Control" (type: KEYBOARD, id 15)
[  7584.599] (**) Option "xkb_model" "fr-latin1"
[  7584.599] (**) Option "xkb_layout" "fr"
[  7584.601] (II) event24 - Logitech Gaming Mouse G502 System Control: is tagged by udev as: Keyboard
[  7584.601] (II) event24 - Logitech Gaming Mouse G502 System Control: device is a keyboard
[  7584.601] (II) config/udev: Adding input device HDA Intel PCH Front Mic (/dev/input/event11)
[  7584.601] (II) No input driver specified, ignoring this device.
[  7584.601] (II) This device may have been added with another device file.
[  7584.602] (II) config/udev: Adding input device HDA Intel PCH Rear Mic (/dev/input/event12)
[  7584.602] (II) No input driver specified, ignoring this device.
[  7584.602] (II) This device may have been added with another device file.
[  7584.602] (II) config/udev: Adding input device HDA Intel PCH Line (/dev/input/event13)
[  7584.602] (II) config/udev: Adding input device HDA Intel PCH Line Out Front (/dev/input/event14)
[  7584.602] (II) config/udev: Adding input device HDA Intel PCH Line Out Surround (/dev/input/event15)
[  7584.602] (II) config/udev: Adding input device HDA Intel PCH Line Out CLFE (/dev/input/event16)
[  7584.603] (II) config/udev: Adding input device HDA Intel PCH Front Headphone (/dev/input/event17)
[  7584.603] (II) No input driver specified, ignoring this device.
[  7584.603] (II) This device may have been added with another device file.
[  7584.603] (II) config/udev: Adding input device Eee PC WMI hotkeys (/dev/input/event3)
[  7584.603] (**) Eee PC WMI hotkeys: Applying InputClass "libinput keyboard catchall"
[  7584.603] (**) Eee PC WMI hotkeys: Applying InputClass "system-keyboard"
[  7584.603] (II) Using input driver 'libinput' for 'Eee PC WMI hotkeys'
[  7584.603] (II) systemd-logind: got fd for /dev/input/event3 13:67 fd 44 paused 0
[  7584.603] (**) Eee PC WMI hotkeys: always reports core events
[  7584.603] (**) Option "Device" "/dev/input/event3"
[  7584.603] (**) Option "_source" "server/udev"
[  7584.604] (II) event3  - Eee PC WMI hotkeys: is tagged by udev as: Keyboard
[  7584.604] (II) event3  - Eee PC WMI hotkeys: device is a keyboard
[  7584.604] (II) event3  - Eee PC WMI hotkeys: device removed
[  7584.604] (**) Option "config_info" "udev:/sys/devices/platform/eeepc-wmi/input/input3/event3"
[  7584.604] (II) XINPUT: Adding extended input device "Eee PC WMI hotkeys" (type: KEYBOARD, id 16)
[  7584.604] (**) Option "xkb_model" "fr-latin1"
[  7584.604] (**) Option "xkb_layout" "fr"
[  7584.605] (II) event3  - Eee PC WMI hotkeys: is tagged by udev as: Keyboard
[  7584.605] (II) event3  - Eee PC WMI hotkeys: device is a keyboard
[  7584.605] (II) config/udev: Adding input device PC Speaker (/dev/input/event2)
[  7584.605] (II) No input driver specified, ignoring this device.
[  7584.605] (II) This device may have been added with another device file.
[  7584.607] (**) Valve Software Steam Controller: Applying InputClass "libinput pointer catchall"
[  7584.607] (**) Valve Software Steam Controller: Applying InputClass "libinput keyboard catchall"
[  7584.607] (**) Valve Software Steam Controller: Applying InputClass "system-keyboard"
[  7584.607] (II) Using input driver 'libinput' for 'Valve Software Steam Controller'
[  7584.607] (II) systemd-logind: returning pre-existing fd for /dev/input/event19 13:83
[  7584.607] (**) Valve Software Steam Controller: always reports core events
[  7584.607] (**) Option "Device" "/dev/input/event19"
[  7584.607] (**) Option "_source" "_driver/libinput"
[  7584.607] (II) libinput: Valve Software Steam Controller: is a virtual subdevice
[  7584.607] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:14.0/usb2/2-10/2-10:1.0/0003:28DE:1142.0001/input/input29/event19"
[  7584.607] (II) XINPUT: Adding extended input device "Valve Software Steam Controller" (type: KEYBOARD, id 17)
[  7584.607] (**) Option "xkb_model" "fr-latin1"
[  7584.607] (**) Option "xkb_layout" "fr"
[  7584.607] (**) Logitech Gaming Mouse G502 Consumer Control: Applying InputClass "libinput keyboard catchall"
[  7584.607] (**) Logitech Gaming Mouse G502 Consumer Control: Applying InputClass "system-keyboard"
[  7584.607] (II) Using input driver 'libinput' for 'Logitech Gaming Mouse G502 Consumer Control'
[  7584.607] (II) systemd-logind: returning pre-existing fd for /dev/input/event23 13:87
[  7584.607] (**) Logitech Gaming Mouse G502 Consumer Control: always reports core events
[  7584.607] (**) Option "Device" "/dev/input/event23"
[  7584.607] (II) libinput: Logitech Gaming Mouse G502 Consumer Control: is a virtual subdevice
[  7584.607] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:14.0/usb2/2-14/2-14:1.1/0003:046D:C332.0007/input/input22/event23"
[  7584.607] (II) XINPUT: Adding extended input device "Logitech Gaming Mouse G502 Consumer Control" (type: KEYBOARD, id 18)
[  7584.608] (--) NVIDIA(GPU-0): HPN HP ENVY 27s (DFP-2): connected
[  7584.608] (--) NVIDIA(GPU-0): HPN HP ENVY 27s (DFP-2): Internal DisplayPort
[  7584.608] (--) NVIDIA(GPU-0): HPN HP ENVY 27s (DFP-2): 960.0 MHz maximum pixel clock
[  7591.499] (--) NVIDIA(GPU-0): CRT-0: disconnected
[  7591.499] (--) NVIDIA(GPU-0): CRT-0: 400.0 MHz maximum pixel clock
[  7591.503] (--) NVIDIA(GPU-0): DFP-0: disconnected
[  7591.503] (--) NVIDIA(GPU-0): DFP-0: Internal TMDS
[  7591.503] (--) NVIDIA(GPU-0): DFP-0: 330.0 MHz maximum pixel clock
[  7591.503] (--) NVIDIA(GPU-0): DFP-1: disconnected
[  7591.503] (--) NVIDIA(GPU-0): DFP-1: Internal TMDS
[  7591.503] (--) NVIDIA(GPU-0): DFP-1: 165.0 MHz maximum pixel clock
[  7591.503] (--) NVIDIA(GPU-0): HPN HP ENVY 27s (DFP-2): connected
[  7591.504] (--) NVIDIA(GPU-0): HPN HP ENVY 27s (DFP-2): Internal DisplayPort
[  7591.504] (--) NVIDIA(GPU-0): HPN HP ENVY 27s (DFP-2): 960.0 MHz maximum pixel clock
[  7591.505] (--) NVIDIA(GPU-0): DFP-3: disconnected
[  7591.505] (--) NVIDIA(GPU-0): DFP-3: Internal TMDS
[  7591.505] (--) NVIDIA(GPU-0): DFP-3: 165.0 MHz maximum pixel clock
[  7591.505] (--) NVIDIA(GPU-0): DFP-4: disconnected
[  7591.505] (--) NVIDIA(GPU-0): DFP-4: Internal TMDS
[  7591.505] (--) NVIDIA(GPU-0): DFP-4: 330.0 MHz maximum pixel clock
[  7592.690] (--) NVIDIA(GPU-0): CRT-0: disconnected
[  7592.690] (--) NVIDIA(GPU-0): CRT-0: 400.0 MHz maximum pixel clock
[  7592.694] (--) NVIDIA(GPU-0): DFP-0: disconnected
[  7592.694] (--) NVIDIA(GPU-0): DFP-0: Internal TMDS
[  7592.694] (--) NVIDIA(GPU-0): DFP-0: 330.0 MHz maximum pixel clock
[  7592.694] (--) NVIDIA(GPU-0): DFP-1: disconnected
[  7592.694] (--) NVIDIA(GPU-0): DFP-1: Internal TMDS
[  7592.694] (--) NVIDIA(GPU-0): DFP-1: 165.0 MHz maximum pixel clock
[  7592.695] (--) NVIDIA(GPU-0): HPN HP ENVY 27s (DFP-2): connected
[  7592.695] (--) NVIDIA(GPU-0): HPN HP ENVY 27s (DFP-2): Internal DisplayPort
[  7592.695] (--) NVIDIA(GPU-0): HPN HP ENVY 27s (DFP-2): 960.0 MHz maximum pixel clock
[  7592.696] (--) NVIDIA(GPU-0): DFP-3: disconnected
[  7592.696] (--) NVIDIA(GPU-0): DFP-3: Internal TMDS
[  7592.696] (--) NVIDIA(GPU-0): DFP-3: 165.0 MHz maximum pixel clock
[  7592.696] (--) NVIDIA(GPU-0): DFP-4: disconnected
[  7592.696] (--) NVIDIA(GPU-0): DFP-4: Internal TMDS
[  7592.696] (--) NVIDIA(GPU-0): DFP-4: 330.0 MHz maximum pixel clock
*** /var/log/Xorg.3.log
*** ls: -rw-r--r-- 1 root user 53078 2020-06-23 21:14:02.983794206 +0200 /var/log/Xorg.3.log
[  8471.839] (WW) Failed to open protocol names file lib/xorg/protocol.txt
[  8471.840]
[  8471.842] Build Operating System: Linux Arch Linux
[  8471.844] Current Operating System: Linux localhost 5.7.4-arch1-1 #1 SMP PREEMPT Thu, 18 Jun 2020 16:01:07 +0000 x86_64
[  8471.844] Kernel command line: root=UUID=6c37d730-4b14-4479-8554-92d2e75478d5 rw initrd=\initramfs-linux.img
[  8471.846] Build Date: 05 May 2020  05:08:17AM
[  8471.846]
[  8471.847] Current version of pixman: 0.40.0
[  8471.849] 	Before reporting problems, check
[  8471.849] Markers: (--) probed, (**) from config file, (==) default setting,
[  8471.853] (==) Log file: "/var/log/Xorg.3.log", Time: Tue Jun 23 15:10:07 2020
[  8471.854] (==) Using config file: "/etc/X11/xorg.conf"
[  8471.855] (==) Using config directory: "/etc/X11/xorg.conf.d"
[  8471.856] (==) Using system config directory "/usr/share/X11/xorg.conf.d"
[  8471.856] (==) ServerLayout "Layout0"
[  8471.856] (**) |-->Screen "Screen0" (0)
[  8471.856] (**) |   |-->Monitor "Monitor0"
[  8471.856] (**) |   |-->Device "Device0"
[  8471.856] (**) |   |-->GPUDevice "Device0"
[  8471.856] (**) |-->Input Device "Keyboard0"
[  8471.856] (**) |-->Input Device "Mouse0"
[  8471.856] (**) Option "Xinerama" "0"
[  8471.856] (==) Automatically adding devices
[  8471.856] (==) Automatically enabling devices
[  8471.856] (==) Automatically adding GPU devices
[  8471.856] (==) Automatically binding GPU devices
[  8471.856] (==) Max clients allowed: 256, resource mask: 0x1fffff
[  8471.856] (WW) `fonts.dir' not found (or not valid) in "/usr/share/fonts/OTF".
[  8471.856] 	Entry deleted from font path.
[  8471.856] 	(Run 'mkfontdir' on "/usr/share/fonts/OTF").
[  8471.856] (WW) The directory "/usr/share/fonts/Type1" does not exist.
[  8471.856] (WW) The directory "/usr/share/fonts/100dpi" does not exist.
[  8471.856] (WW) The directory "/usr/share/fonts/75dpi" does not exist.
[  8471.856] (==) FontPath set to:
[  8471.856] (==) ModulePath set to "/usr/lib/xorg/modules"
[  8471.856] (WW) Hotplugging is on, devices using drivers 'kbd', 'mouse' or 'vmmouse' will be disabled.
[  8471.856] (WW) Disabling Keyboard0
[  8471.856] (WW) Disabling Mouse0
[  8471.856] (II) Module ABI versions:
[  8471.856] 	X.Org ANSI C Emulation: 0.4
[  8471.856] 	X.Org Video Driver: 24.1
[  8471.856] 	X.Org XInput driver : 24.1
[  8471.856] 	X.Org Server Extension : 10.0
[  8471.856] (++) using VT number 1
[  8471.858] (II) systemd-logind: took control of session /org/freedesktop/login1/session/_31
[  8471.858] (II) xfree86: Adding drm device (/dev/dri/card0)
[  8471.858] (II) systemd-logind: got fd for /dev/dri/card0 226:0 fd 10 paused 0
[  8471.859] (**) OutputClass "nvidia" ModulePath extended to "/usr/lib/nvidia/xorg,/usr/lib/xorg/modules,/usr/lib/xorg/modules"
[  8471.859] (--) PCI:*(1@0:0:0) 10de:13c2:1462:3160 rev 161, Mem @ 0xde000000/16777216, 0xc0000000/268435456, 0xd0000000/33554432, I/O @ 0x0000e000/128, BIOS @ 0x????????/131072
[  8471.859] (WW) Open ACPI failed (/var/run/acpid.socket) (No such file or directory)
[  8471.860] (II) LoadModule: "glx"
[  8471.860] (II) Loading /usr/lib/xorg/modules/extensions/libglx.so
[  8471.860] (II) Module glx: vendor="X.Org Foundation"
[  8471.860] 	compiled for 1.20.8, module version = 1.0.0
[  8471.860] 	ABI class: X.Org Server Extension, version 10.0
[  8471.860] (II) LoadModule: "nvidia"
[  8471.860] (II) Loading /usr/lib/xorg/modules/drivers/nvidia_drv.so
[  8471.861] (II) Module nvidia: vendor="NVIDIA Corporation"
[  8471.861] 	compiled for 1.6.99.901, module version = 1.0.0
[  8471.861] 	Module class: X.Org Video Driver
[  8471.861] (II) NVIDIA dlloader X Driver  440.82  Wed Apr  1 19:50:17 UTC 2020
[  8471.861] (II) NVIDIA Unified Driver for all Supported NVIDIA GPUs
[  8471.861] (II) systemd-logind: releasing fd for 226:0
[  8471.861] (II) Loading sub module "fb"
[  8471.861] (II) LoadModule: "fb"
[  8471.861] (II) Loading /usr/lib/xorg/modules/libfb.so
[  8471.861] (II) Module fb: vendor="X.Org Foundation"
[  8471.861] 	compiled for 1.20.8, module version = 1.0.0
[  8471.861] 	ABI class: X.Org ANSI C Emulation, version 0.4
[  8471.861] (II) Loading sub module "wfb"
[  8471.861] (II) LoadModule: "wfb"
[  8471.861] (II) Loading /usr/lib/xorg/modules/libwfb.so
[  8471.861] (II) Module wfb: vendor="X.Org Foundation"
[  8471.861] (II) Loading sub module "ramdac"
[  8471.861] (II) LoadModule: "ramdac"
[  8471.861] (II) Module "ramdac" already built-in
[  8471.862] (**) NVIDIA(0): Depth 24, (--) framebuffer bpp 32
[  8471.862] (==) NVIDIA(0): RGB weight 888
[  8471.862] (==) NVIDIA(0): Default visual is TrueColor
[  8471.862] (==) NVIDIA(0): Using gamma correction (1.0, 1.0, 1.0)
[  8471.862] (II) Applying OutputClass "nvidia" options to /dev/dri/card0
[  8471.862] (**) NVIDIA(0): Option "Stereo" "0"
[  8471.862] (**) NVIDIA(0): Option "nvidiaXineramaInfoOrder" "DFP-1"
[  8471.862] (**) NVIDIA(0): Option "SLI" "Off"
[  8471.862] (**) NVIDIA(0): Option "MultiGPU" "Off"
[  8471.862] (**) NVIDIA(0): Option "BaseMosaic" "off"
[  8471.862] (**) NVIDIA(0): Option "AllowEmptyInitialConfiguration"
[  8471.862] (**) NVIDIA(0): Stereo disabled by request
[  8471.862] (**) NVIDIA(0): NVIDIA SLI disabled.
[  8471.862] (**) NVIDIA(0): NVIDIA Multi-GPU disabled.
[  8471.862] (**) NVIDIA(0): Option "MetaModes" "HDMI-0: 3840x2160_60 +0+0, DP-0: 1920x1080_144 +3840+0"
[  8471.862] (**) NVIDIA(0): Enabling 2D acceleration
[  8471.862] (II) Loading sub module "glxserver_nvidia"
[  8471.862] (II) LoadModule: "glxserver_nvidia"
[  8471.862] (II) Loading /usr/lib/nvidia/xorg/libglxserver_nvidia.so
[  8471.867] (II) Module glxserver_nvidia: vendor="NVIDIA Corporation"
[  8471.867] 	compiled for 1.6.99.901, module version = 1.0.0
[  8471.867] 	Module class: X.Org Server Extension
[  8471.867] (II) NVIDIA GLX Module  440.82  Wed Apr  1 19:47:36 UTC 2020
[  8471.867] (II) NVIDIA: The X server supports PRIME Render Offload.
[  8472.138] (--) NVIDIA(0): Valid display device(s) on GPU-0 at PCI:1:0:0
[  8472.138] (--) NVIDIA(0):     CRT-0
[  8472.138] (--) NVIDIA(0):     DFP-0
[  8472.138] (--) NVIDIA(0):     DFP-1
[  8472.138] (--) NVIDIA(0):     DFP-2 (boot)
[  8472.138] (--) NVIDIA(0):     DFP-3
[  8472.138] (--) NVIDIA(0):     DFP-4
[  8472.139] (II) NVIDIA(0): NVIDIA GPU GeForce GTX 970 (GM204-A) at PCI:1:0:0 (GPU-0)
[  8472.139] (--) NVIDIA(0): Memory: 4194304 kBytes
[  8472.139] (--) NVIDIA(0): VideoBIOS: 84.04.2f.00.f1
[  8472.139] (II) NVIDIA(0): Detected PCI Express Link width: 16X
[  8472.143] (--) NVIDIA(GPU-0): CRT-0: disconnected
[  8472.143] (--) NVIDIA(GPU-0): CRT-0: 400.0 MHz maximum pixel clock
[  8472.147] (--) NVIDIA(GPU-0): DFP-0: disconnected
[  8472.147] (--) NVIDIA(GPU-0): DFP-0: Internal TMDS
[  8472.147] (--) NVIDIA(GPU-0): DFP-0: 330.0 MHz maximum pixel clock
[  8472.147] (--) NVIDIA(GPU-0): DFP-1: disconnected
[  8472.147] (--) NVIDIA(GPU-0): DFP-1: Internal TMDS
[  8472.147] (--) NVIDIA(GPU-0): DFP-1: 165.0 MHz maximum pixel clock
[  8472.147] (--) NVIDIA(GPU-0): HPN HP ENVY 27s (DFP-2): connected
[  8472.147] (--) NVIDIA(GPU-0): HPN HP ENVY 27s (DFP-2): Internal DisplayPort
[  8472.147] (--) NVIDIA(GPU-0): HPN HP ENVY 27s (DFP-2): 960.0 MHz maximum pixel clock
[  8472.148] (--) NVIDIA(GPU-0): DFP-3: disconnected
[  8472.148] (--) NVIDIA(GPU-0): DFP-3: Internal TMDS
[  8472.148] (--) NVIDIA(GPU-0): DFP-3: 165.0 MHz maximum pixel clock
[  8472.148] (--) NVIDIA(GPU-0): DFP-4: disconnected
[  8472.148] (--) NVIDIA(GPU-0): DFP-4: Internal TMDS
[  8472.148] (--) NVIDIA(GPU-0): DFP-4: 330.0 MHz maximum pixel clock
[  8472.150] (WW) NVIDIA(0): No valid modes for
[  8472.150] (WW) NVIDIA(0):     "HDMI-0:3840x2160_60+0+0,DP-0:1920x1080_144+3840+0";
[  8472.150] (WW) NVIDIA(0):     removing.
[  8472.150] (WW) NVIDIA(0): Unable to validate any modes; falling back to the default mode
[  8472.150] (WW) NVIDIA(0):     "nvidia-auto-select".
[  8472.151] (II) NVIDIA(0): Validated MetaModes:
[  8472.151] (II) NVIDIA(0):     "DFP-2:nvidia-auto-select"
[  8472.151] (II) NVIDIA(0): Virtual screen size determined to be 3840 x 2160
[  8472.154] (--) NVIDIA(0): DPI set to (162, 161); computed from "UseEdidDpi" X config
[  8472.154] (--) NVIDIA(0):     option
[  8472.154] (II) NVIDIA: Using 6144.00 MB of virtual memory for indirect memory
[  8472.154] (II) NVIDIA:     access.
[  8472.156] (II) NVIDIA(0): ACPI: failed to connect to the ACPI event daemon; the daemon
[  8472.156] (II) NVIDIA(0):     may not be running or the "AcpidSocketPath" X
[  8472.156] (II) NVIDIA(0):     configuration option may not be set correctly.  When the
[  8472.156] (II) NVIDIA(0):     ACPI event daemon is available, the NVIDIA X driver will
[  8472.156] (II) NVIDIA(0):     try to use it to receive ACPI event notifications.  For
[  8472.156] (II) NVIDIA(0):     details, please see the "ConnectToAcpid" and
[  8472.156] (II) NVIDIA(0):     "AcpidSocketPath" X configuration options in Appendix B: X
[  8472.156] (II) NVIDIA(0):     Config Options in the README.
[  8472.187] (II) NVIDIA(0): Setting mode "DFP-2:nvidia-auto-select"
[  8472.290] (==) NVIDIA(0): Disabling shared memory pixmaps
[  8472.290] (==) NVIDIA(0): Backing store enabled
[  8472.290] (==) NVIDIA(0): Silken mouse disabled
[  8472.290] (**) NVIDIA(0): DPMS enabled
[  8472.290] (II) Loading sub module "dri2"
[  8472.290] (II) LoadModule: "dri2"
[  8472.290] (II) Module "dri2" already built-in
[  8472.290] (II) NVIDIA(0): [DRI2] Setup complete
[  8472.290] (II) NVIDIA(0): [DRI2]   VDPAU driver: nvidia
[  8472.290] (II) Initializing extension Generic Event Extension
[  8472.290] (II) Initializing extension SHAPE
[  8472.290] (II) Initializing extension MIT-SHM
[  8472.290] (II) Initializing extension XInputExtension
[  8472.290] (II) Initializing extension XTEST
[  8472.290] (II) Initializing extension BIG-REQUESTS
[  8472.290] (II) Initializing extension SYNC
[  8472.290] (II) Initializing extension XKEYBOARD
[  8472.290] (II) Initializing extension XC-MISC
[  8472.290] (II) Initializing extension SECURITY
[  8472.290] (II) Initializing extension XFIXES
[  8472.290] (II) Initializing extension RENDER
[  8472.290] (II) Initializing extension RANDR
[  8472.290] (II) Initializing extension COMPOSITE
[  8472.290] (II) Initializing extension DAMAGE
[  8472.290] (II) Initializing extension MIT-SCREEN-SAVER
[  8472.290] (II) Initializing extension DOUBLE-BUFFER
[  8472.290] (II) Initializing extension RECORD
[  8472.290] (II) Initializing extension DPMS
[  8472.290] (II) Initializing extension Present
[  8472.290] (II) Initializing extension DRI3
[  8472.290] (II) Initializing extension X-Resource
[  8472.290] (II) Initializing extension XVideo
[  8472.290] (II) Initializing extension XVideo-MotionCompensation
[  8472.290] (II) Initializing extension GLX
[  8472.290] (II) Indirect GLX disabled.
[  8472.290] (II) GLX: Another vendor is already registered for screen 0
[  8472.290] (II) Initializing extension XFree86-VidModeExtension
[  8472.290] (II) Initializing extension XFree86-DGA
[  8472.290] (II) Initializing extension XFree86-DRI
[  8472.290] (II) Initializing extension DRI2
[  8472.290] (II) Initializing extension NV-GLX
[  8472.290] (II) Initializing extension NV-CONTROL
[  8472.290] (II) Initializing extension XINERAMA
[  8472.313] (II) config/udev: Adding input device Power Button (/dev/input/event1)
[  8472.313] (**) Power Button: Applying InputClass "libinput keyboard catchall"
[  8472.313] (**) Power Button: Applying InputClass "system-keyboard"
[  8472.313] (II) LoadModule: "libinput"
[  8472.313] (II) Loading /usr/lib/xorg/modules/input/libinput_drv.so
[  8472.314] (II) Module libinput: vendor="X.Org Foundation"
[  8472.314] 	compiled for 1.20.8, module version = 0.30.0
[  8472.314] 	Module class: X.Org XInput Driver
[  8472.314] 	ABI class: X.Org XInput driver, version 24.1
[  8472.314] (II) Using input driver 'libinput' for 'Power Button'
[  8472.315] (II) systemd-logind: got fd for /dev/input/event1 13:65 fd 32 paused 0
[  8472.315] (**) Power Button: always reports core events
[  8472.315] (**) Option "Device" "/dev/input/event1"
[  8472.315] (**) Option "_source" "server/udev"
[  8472.316] (II) event1  - Power Button: is tagged by udev as: Keyboard
[  8472.316] (II) event1  - Power Button: device is a keyboard
[  8472.316] (II) event1  - Power Button: device removed
[  8472.316] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXPWRBN:00/input/input1/event1"
[  8472.316] (II) XINPUT: Adding extended input device "Power Button" (type: KEYBOARD, id 6)
[  8472.316] (**) Option "xkb_model" "fr-latin1"
[  8472.316] (**) Option "xkb_layout" "fr"
[  8472.327] (II) event1  - Power Button: is tagged by udev as: Keyboard
[  8472.327] (II) event1  - Power Button: device is a keyboard
[  8472.328] (II) config/udev: Adding input device Power Button (/dev/input/event0)
[  8472.328] (**) Power Button: Applying InputClass "libinput keyboard catchall"
[  8472.328] (**) Power Button: Applying InputClass "system-keyboard"
[  8472.328] (II) Using input driver 'libinput' for 'Power Button'
[  8472.328] (II) systemd-logind: got fd for /dev/input/event0 13:64 fd 35 paused 0
[  8472.328] (**) Power Button: always reports core events
[  8472.328] (**) Option "Device" "/dev/input/event0"
[  8472.328] (**) Option "_source" "server/udev"
[  8472.329] (II) event0  - Power Button: is tagged by udev as: Keyboard
[  8472.329] (II) event0  - Power Button: device is a keyboard
[  8472.329] (II) event0  - Power Button: device removed
[  8472.329] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0C:00/input/input0/event0"
[  8472.329] (II) XINPUT: Adding extended input device "Power Button" (type: KEYBOARD, id 7)
[  8472.329] (**) Option "xkb_model" "fr-latin1"
[  8472.329] (**) Option "xkb_layout" "fr"
[  8472.330] (II) event0  - Power Button: is tagged by udev as: Keyboard
[  8472.330] (II) event0  - Power Button: device is a keyboard
[  8472.330] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=12 (/dev/input/event10)
[  8472.330] (II) No input driver specified, ignoring this device.
[  8472.330] (II) This device may have been added with another device file.
[  8472.330] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=3 (/dev/input/event4)
[  8472.330] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=7 (/dev/input/event5)
[  8472.331] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=8 (/dev/input/event6)
[  8472.331] (II) No input driver specified, ignoring this device.
[  8472.331] (II) This device may have been added with another device file.
[  8472.331] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=9 (/dev/input/event7)
[  8472.331] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=10 (/dev/input/event8)
[  8472.331] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=11 (/dev/input/event9)
[  8472.332] (II) config/udev: Adding input device Valve Software Steam Controller (/dev/input/event19)
[  8472.332] (**) Valve Software Steam Controller: Applying InputClass "libinput pointer catchall"
[  8472.332] (**) Valve Software Steam Controller: Applying InputClass "libinput keyboard catchall"
[  8472.332] (**) Valve Software Steam Controller: Applying InputClass "system-keyboard"
[  8472.332] (II) Using input driver 'libinput' for 'Valve Software Steam Controller'
[  8472.332] (II) systemd-logind: got fd for /dev/input/event19 13:83 fd 36 paused 0
[  8472.332] (**) Valve Software Steam Controller: always reports core events
[  8472.332] (**) Option "Device" "/dev/input/event19"
[  8472.332] (**) Option "_source" "server/udev"
[  8472.333] (II) event19 - Valve Software Steam Controller: is tagged by udev as: Keyboard Mouse
[  8472.333] (II) event19 - Valve Software Steam Controller: device is a pointer
[  8472.333] (II) event19 - Valve Software Steam Controller: device is a keyboard
[  8472.333] (II) event19 - Valve Software Steam Controller: device removed
[  8472.333] (II) libinput: Valve Software Steam Controller: needs a virtual subdevice
[  8472.333] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:14.0/usb2/2-10/2-10:1.0/0003:28DE:1142.0001/input/input29/event19"
[  8472.333] (II) XINPUT: Adding extended input device "Valve Software Steam Controller" (type: MOUSE, id 8)
[  8472.333] (**) Option "AccelerationScheme" "none"
[  8472.333] (**) Valve Software Steam Controller: (accel) selected scheme none/0
[  8472.333] (**) Valve Software Steam Controller: (accel) acceleration factor: 2.000
[  8472.333] (**) Valve Software Steam Controller: (accel) acceleration threshold: 4
[  8472.334] (II) event19 - Valve Software Steam Controller: is tagged by udev as: Keyboard Mouse
[  8472.334] (II) event19 - Valve Software Steam Controller: device is a pointer
[  8472.334] (II) event19 - Valve Software Steam Controller: device is a keyboard
[  8472.335] (II) config/udev: Adding input device Valve Software Steam Controller (/dev/input/mouse0)
[  8472.335] (**) Valve Software Steam Controller: Applying InputClass "system-keyboard"
[  8472.335] (II) No input driver specified, ignoring this device.
[  8472.335] (II) This device may have been added with another device file.
[  8472.335] (II) config/udev: Adding input device Logitech Logitech Gaming Keyboard (/dev/input/event22)
[  8472.335] (**) Logitech Logitech Gaming Keyboard: Applying InputClass "libinput keyboard catchall"
[  8472.335] (**) Logitech Logitech Gaming Keyboard: Applying InputClass "system-keyboard"
[  8472.335] (II) Using input driver 'libinput' for 'Logitech Logitech Gaming Keyboard'
[  8472.336] (II) systemd-logind: got fd for /dev/input/event22 13:86 fd 37 paused 0
[  8472.336] (**) Logitech Logitech Gaming Keyboard: always reports core events
[  8472.336] (**) Option "Device" "/dev/input/event22"
[  8472.336] (**) Option "_source" "server/udev"
[  8472.337] (II) event22 - Logitech Logitech Gaming Keyboard: is tagged by udev as: Keyboard
[  8472.337] (II) event22 - Logitech Logitech Gaming Keyboard: device is a keyboard
[  8472.337] (II) event22 - Logitech Logitech Gaming Keyboard: device removed
[  8472.337] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:14.0/usb2/2-13/2-13.1/2-13.1:1.0/0003:046D:C221.0008/input/input26/event22"
[  8472.337] (II) XINPUT: Adding extended input device "Logitech Logitech Gaming Keyboard" (type: KEYBOARD, id 9)
[  8472.337] (**) Option "xkb_model" "fr-latin1"
[  8472.337] (**) Option "xkb_layout" "fr"
[  8472.338] (II) event22 - Logitech Logitech Gaming Keyboard: is tagged by udev as: Keyboard
[  8472.338] (II) event22 - Logitech Logitech Gaming Keyboard: device is a keyboard
[  8472.338] (II) config/udev: Adding input device Logitech Logitech Gaming Keyboard Consumer Control (/dev/input/event18)
[  8472.338] (**) Logitech Logitech Gaming Keyboard Consumer Control: Applying InputClass "libinput keyboard catchall"
[  8472.338] (**) Logitech Logitech Gaming Keyboard Consumer Control: Applying InputClass "system-keyboard"
[  8472.338] (II) Using input driver 'libinput' for 'Logitech Logitech Gaming Keyboard Consumer Control'
[  8472.339] (II) systemd-logind: got fd for /dev/input/event18 13:82 fd 38 paused 0
[  8472.339] (**) Logitech Logitech Gaming Keyboard Consumer Control: always reports core events
[  8472.339] (**) Option "Device" "/dev/input/event18"
[  8472.339] (**) Option "_source" "server/udev"
[  8472.340] (II) event18 - Logitech Logitech Gaming Keyboard Consumer Control: is tagged by udev as: Keyboard
[  8472.340] (II) event18 - Logitech Logitech Gaming Keyboard Consumer Control: device is a keyboard
[  8472.340] (II) event18 - Logitech Logitech Gaming Keyboard Consumer Control: device removed
[  8472.340] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:14.0/usb2/2-13/2-13.1/2-13.1:1.1/0003:046D:C221.0009/input/input27/event18"
[  8472.340] (II) XINPUT: Adding extended input device "Logitech Logitech Gaming Keyboard Consumer Control" (type: KEYBOARD, id 10)
[  8472.340] (**) Option "xkb_model" "fr-latin1"
[  8472.340] (**) Option "xkb_layout" "fr"
[  8472.341] (II) event18 - Logitech Logitech Gaming Keyboard Consumer Control: is tagged by udev as: Keyboard
[  8472.341] (II) event18 - Logitech Logitech Gaming Keyboard Consumer Control: device is a keyboard
[  8472.341] (II) config/udev: Adding input device Logitech Gaming Keyboard Gaming Keys (/dev/input/event25)
[  8472.341] (**) Logitech Gaming Keyboard Gaming Keys: Applying InputClass "libinput keyboard catchall"
[  8472.341] (**) Logitech Gaming Keyboard Gaming Keys: Applying InputClass "system-keyboard"
[  8472.341] (II) Using input driver 'libinput' for 'Logitech Gaming Keyboard Gaming Keys'
[  8472.398] (II) systemd-logind: got fd for /dev/input/event25 13:89 fd 39 paused 0
[  8472.398] (**) Logitech Gaming Keyboard Gaming Keys: always reports core events
[  8472.398] (**) Option "Device" "/dev/input/event25"
[  8472.398] (**) Option "_source" "server/udev"
[  8472.400] (II) event25 - Logitech Gaming Keyboard Gaming Keys: is tagged by udev as: Keyboard
[  8472.400] (II) event25 - Logitech Gaming Keyboard Gaming Keys: device is a keyboard
[  8472.401] (II) event25 - Logitech Gaming Keyboard Gaming Keys: device removed
[  8472.401] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:14.0/usb2/2-13/2-13.4/2-13.4:1.0/0003:046D:C222.000E/input/input32/event25"
[  8472.401] (II) XINPUT: Adding extended input device "Logitech Gaming Keyboard Gaming Keys" (type: KEYBOARD, id 11)
[  8472.401] (**) Option "xkb_model" "fr-latin1"
[  8472.401] (**) Option "xkb_layout" "fr"
[  8472.403] (II) event25 - Logitech Gaming Keyboard Gaming Keys: is tagged by udev as: Keyboard
[  8472.403] (II) event25 - Logitech Gaming Keyboard Gaming Keys: device is a keyboard
[  8472.404] (II) config/udev: Adding input device Logitech Gaming Mouse G502 (/dev/input/event20)
[  8472.404] (**) Logitech Gaming Mouse G502: Applying InputClass "libinput pointer catchall"
[  8472.404] (II) Using input driver 'libinput' for 'Logitech Gaming Mouse G502'
[  8472.462] (II) systemd-logind: got fd for /dev/input/event20 13:84 fd 40 paused 0
[  8472.462] (**) Logitech Gaming Mouse G502: always reports core events
[  8472.462] (**) Option "Device" "/dev/input/event20"
[  8472.462] (**) Option "_source" "server/udev"
[  8472.464] (II) event20 - Logitech Gaming Mouse G502: is tagged by udev as: Mouse
[  8472.465] (II) event20 - Logitech Gaming Mouse G502: device set to 2400 DPI
[  8472.465] (II) event20 - Logitech Gaming Mouse G502: device is a pointer
[  8472.465] (II) event20 - Logitech Gaming Mouse G502: device removed
[  8472.465] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:14.0/usb2/2-14/2-14:1.0/0003:046D:C332.0006/input/input20/event20"
[  8472.465] (II) XINPUT: Adding extended input device "Logitech Gaming Mouse G502" (type: MOUSE, id 12)
[  8472.465] (**) Option "AccelerationScheme" "none"
[  8472.465] (**) Logitech Gaming Mouse G502: (accel) selected scheme none/0
[  8472.465] (**) Logitech Gaming Mouse G502: (accel) acceleration factor: 2.000
[  8472.465] (**) Logitech Gaming Mouse G502: (accel) acceleration threshold: 4
[  8472.468] (II) event20 - Logitech Gaming Mouse G502: is tagged by udev as: Mouse
[  8472.468] (II) event20 - Logitech Gaming Mouse G502: device set to 2400 DPI
[  8472.468] (II) event20 - Logitech Gaming Mouse G502: device is a pointer
[  8472.470] (II) config/udev: Adding input device Logitech Gaming Mouse G502 (/dev/input/mouse1)
[  8472.470] (II) No input driver specified, ignoring this device.
[  8472.470] (II) This device may have been added with another device file.
[  8472.471] (II) config/udev: Adding input device Logitech Gaming Mouse G502 Keyboard (/dev/input/event21)
[  8472.472] (**) Logitech Gaming Mouse G502 Keyboard: Applying InputClass "libinput keyboard catchall"
[  8472.472] (**) Logitech Gaming Mouse G502 Keyboard: Applying InputClass "system-keyboard"
[  8472.472] (II) Using input driver 'libinput' for 'Logitech Gaming Mouse G502 Keyboard'
[  8472.473] (II) systemd-logind: got fd for /dev/input/event21 13:85 fd 41 paused 0
[  8472.473] (**) Logitech Gaming Mouse G502 Keyboard: always reports core events
[  8472.473] (**) Option "Device" "/dev/input/event21"
[  8472.473] (**) Option "_source" "server/udev"
[  8472.474] (II) event21 - Logitech Gaming Mouse G502 Keyboard: is tagged by udev as: Keyboard
[  8472.474] (II) event21 - Logitech Gaming Mouse G502 Keyboard: device is a keyboard
[  8472.474] (II) event21 - Logitech Gaming Mouse G502 Keyboard: device removed
[  8472.474] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:14.0/usb2/2-14/2-14:1.1/0003:046D:C332.0007/input/input21/event21"
[  8472.474] (II) XINPUT: Adding extended input device "Logitech Gaming Mouse G502 Keyboard" (type: KEYBOARD, id 13)
[  8472.474] (**) Option "xkb_model" "fr-latin1"
[  8472.474] (**) Option "xkb_layout" "fr"
[  8472.475] (II) event21 - Logitech Gaming Mouse G502 Keyboard: is tagged by udev as: Keyboard
[  8472.475] (II) event21 - Logitech Gaming Mouse G502 Keyboard: device is a keyboard
[  8472.475] (II) config/udev: Adding input device Logitech Gaming Mouse G502 Consumer Control (/dev/input/event23)
[  8472.475] (**) Logitech Gaming Mouse G502 Consumer Control: Applying InputClass "libinput keyboard catchall"
[  8472.475] (**) Logitech Gaming Mouse G502 Consumer Control: Applying InputClass "system-keyboard"
[  8472.475] (II) Using input driver 'libinput' for 'Logitech Gaming Mouse G502 Consumer Control'
[  8472.476] (II) systemd-logind: got fd for /dev/input/event23 13:87 fd 42 paused 0
[  8472.476] (**) Logitech Gaming Mouse G502 Consumer Control: always reports core events
[  8472.476] (**) Option "Device" "/dev/input/event23"
[  8472.476] (**) Option "_source" "server/udev"
@pingo-power
[  8472.477] (II) event23 - Logitech Gaming Mouse G502 Consumer Control: is tagged by udev as: Keyboard
[  8472.477] (II) event23 - Logitech Gaming Mouse G502 Consumer Control: device is a keyboard
[  8472.477] (II) event23 - Logitech Gaming Mouse G502 Consumer Control: device removed
[  8472.477] (II) libinput: Logitech Gaming Mouse G502 Consumer Control: needs a virtual subdevice
[  8472.477] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:14.0/usb2/2-14/2-14:1.1/0003:046D:C332.0007/input/input22/event23"
[  8472.477] (II) XINPUT: Adding extended input device "Logitech Gaming Mouse G502 Consumer Control" (type: MOUSE, id 14)
[  8472.477] (**) Option "AccelerationScheme" "none"
[  8472.477] (**) Logitech Gaming Mouse G502 Consumer Control: (accel) selected scheme none/0
[  8472.477] (**) Logitech Gaming Mouse G502 Consumer Control: (accel) acceleration factor: 2.000
[  8472.477] (**) Logitech Gaming Mouse G502 Consumer Control: (accel) acceleration threshold: 4
[  8472.478] (II) event23 - Logitech Gaming Mouse G502 Consumer Control: is tagged by udev as: Keyboard
[  8472.478] (II) event23 - Logitech Gaming Mouse G502 Consumer Control: device is a keyboard
[  8472.478] (II) config/udev: Adding input device Logitech Gaming Mouse G502 System Control (/dev/input/event24)
[  8472.478] (**) Logitech Gaming Mouse G502 System Control: Applying InputClass "libinput keyboard catchall"
[  8472.478] (**) Logitech Gaming Mouse G502 System Control: Applying InputClass "system-keyboard"
[  8472.478] (II) Using input driver 'libinput' for 'Logitech Gaming Mouse G502 System Control'
[  8472.479] (II) systemd-logind: got fd for /dev/input/event24 13:88 fd 43 paused 0
[  8472.479] (**) Logitech Gaming Mouse G502 System Control: always reports core events
[  8472.479] (**) Option "Device" "/dev/input/event24"
[  8472.479] (**) Option "_source" "server/udev"
[  8472.479] (II) event24 - Logitech Gaming Mouse G502 System Control: is tagged by udev as: Keyboard
[  8472.480] (II) event24 - Logitech Gaming Mouse G502 System Control: device is a keyboard
[  8472.480] (II) event24 - Logitech Gaming Mouse G502 System Control: device removed
[  8472.480] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:14.0/usb2/2-14/2-14:1.1/0003:046D:C332.0007/input/input23/event24"
[  8472.480] (II) XINPUT: Adding extended input device "Logitech Gaming Mouse G502 System Control" (type: KEYBOARD, id 15)
[  8472.480] (**) Option "xkb_model" "fr-latin1"
[  8472.480] (**) Option "xkb_layout" "fr"
[  8472.481] (II) event24 - Logitech Gaming Mouse G502 System Control: is tagged by udev as: Keyboard
[  8472.481] (II) event24 - Logitech Gaming Mouse G502 System Control: device is a keyboard
[  8472.481] (II) config/udev: Adding input device HDA Intel PCH Front Mic (/dev/input/event11)
[  8472.481] (II) No input driver specified, ignoring this device.
[  8472.481] (II) This device may have been added with another device file.
[  8472.481] (II) config/udev: Adding input device HDA Intel PCH Rear Mic (/dev/input/event12)
[  8472.481] (II) config/udev: Adding input device HDA Intel PCH Line (/dev/input/event13)
[  8472.481] (II) config/udev: Adding input device HDA Intel PCH Line Out Front (/dev/input/event14)
[  8472.482] (II) config/udev: Adding input device HDA Intel PCH Line Out Surround (/dev/input/event15)
[  8472.482] (II) No input driver specified, ignoring this device.
[  8472.482] (II) This device may have been added with another device file.
[  8472.482] (II) config/udev: Adding input device HDA Intel PCH Line Out CLFE (/dev/input/event16)
[  8472.482] (II) config/udev: Adding input device HDA Intel PCH Front Headphone (/dev/input/event17)
[  8472.482] (II) config/udev: Adding input device Eee PC WMI hotkeys (/dev/input/event3)
[  8472.482] (**) Eee PC WMI hotkeys: Applying InputClass "libinput keyboard catchall"
[  8472.482] (**) Eee PC WMI hotkeys: Applying InputClass "system-keyboard"
[  8472.482] (II) Using input driver 'libinput' for 'Eee PC WMI hotkeys'
[  8472.483] (II) systemd-logind: got fd for /dev/input/event3 13:67 fd 44 paused 0
[  8472.483] (**) Eee PC WMI hotkeys: always reports core events
[  8472.483] (**) Option "Device" "/dev/input/event3"
[  8472.483] (**) Option "_source" "server/udev"
[  8472.483] (II) event3  - Eee PC WMI hotkeys: is tagged by udev as: Keyboard
[  8472.483] (II) event3  - Eee PC WMI hotkeys: device is a keyboard
[  8472.483] (II) event3  - Eee PC WMI hotkeys: device removed
[  8472.483] (**) Option "config_info" "udev:/sys/devices/platform/eeepc-wmi/input/input3/event3"
[  8472.483] (II) XINPUT: Adding extended input device "Eee PC WMI hotkeys" (type: KEYBOARD, id 16)
[  8472.483] (**) Option "xkb_model" "fr-latin1"
[  8472.483] (**) Option "xkb_layout" "fr"
[  8472.484] (II) event3  - Eee PC WMI hotkeys: is tagged by udev as: Keyboard
[  8472.484] (II) event3  - Eee PC WMI hotkeys: device is a keyboard
[  8472.484] (II) config/udev: Adding input device PC Speaker (/dev/input/event2)
[  8472.484] (II) No input driver specified, ignoring this device.
[  8472.484] (II) This device may have been added with another device file.
[  8472.487] (**) Valve Software Steam Controller: Applying InputClass "libinput pointer catchall"
[  8472.487] (**) Valve Software Steam Controller: Applying InputClass "libinput keyboard catchall"
[  8472.487] (**) Valve Software Steam Controller: Applying InputClass "system-keyboard"
[  8472.487] (II) Using input driver 'libinput' for 'Valve Software Steam Controller'
[  8472.487] (II) systemd-logind: returning pre-existing fd for /dev/input/event19 13:83
[  8472.487] (**) Valve Software Steam Controller: always reports core events
[  8472.487] (**) Option "Device" "/dev/input/event19"
[  8472.487] (**) Option "_source" "_driver/libinput"
[  8472.487] (II) libinput: Valve Software Steam Controller: is a virtual subdevice
[  8472.487] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:14.0/usb2/2-10/2-10:1.0/0003:28DE:1142.0001/input/input29/event19"
[  8472.487] (II) XINPUT: Adding extended input device "Valve Software Steam Controller" (type: KEYBOARD, id 17)
[  8472.487] (**) Option "xkb_model" "fr-latin1"
[  8472.487] (**) Option "xkb_layout" "fr"
[  8472.488] (**) Logitech Gaming Mouse G502 Consumer Control: Applying InputClass "libinput keyboard catchall"
[  8472.488] (**) Logitech Gaming Mouse G502 Consumer Control: Applying InputClass "system-keyboard"
[  8472.488] (II) Using input driver 'libinput' for 'Logitech Gaming Mouse G502 Consumer Control'
[  8472.488] (II) systemd-logind: returning pre-existing fd for /dev/input/event23 13:87
[  8472.488] (**) Logitech Gaming Mouse G502 Consumer Control: always reports core events
[  8472.488] (**) Option "Device" "/dev/input/event23"
[  8472.488] (**) Option "_source" "_driver/libinput"
[  8472.488] (II) libinput: Logitech Gaming Mouse G502 Consumer Control: is a virtual subdevice
[  8472.488] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:14.0/usb2/2-14/2-14:1.1/0003:046D:C332.0007/input/input22/event23"
[  8472.488] (II) XINPUT: Adding extended input device "Logitech Gaming Mouse G502 Consumer Control" (type: KEYBOARD, id 18)
[  8472.488] (**) Option "xkb_model" "fr-latin1"
[  8472.488] (**) Option "xkb_layout" "fr"
[  8472.488] (--) NVIDIA(GPU-0): HPN HP ENVY 27s (DFP-2): connected
[  8472.488] (--) NVIDIA(GPU-0): HPN HP ENVY 27s (DFP-2): Internal DisplayPort
[  8472.488] (--) NVIDIA(GPU-0): HPN HP ENVY 27s (DFP-2): 960.0 MHz maximum pixel clock
[  8480.715] (--) NVIDIA(GPU-0): CRT-0: disconnected
[  8480.715] (--) NVIDIA(GPU-0): CRT-0: 400.0 MHz maximum pixel clock
[  8480.719] (--) NVIDIA(GPU-0): DFP-0: disconnected
[  8480.719] (--) NVIDIA(GPU-0): DFP-0: Internal TMDS
[  8480.719] (--) NVIDIA(GPU-0): DFP-0: 330.0 MHz maximum pixel clock
[  8480.719] (--) NVIDIA(GPU-0): DFP-1: disconnected
[  8480.719] (--) NVIDIA(GPU-0): DFP-1: Internal TMDS
[  8480.719] (--) NVIDIA(GPU-0): DFP-1: 165.0 MHz maximum pixel clock
[  8480.719] (--) NVIDIA(GPU-0): HPN HP ENVY 27s (DFP-2): connected
[  8480.719] (--) NVIDIA(GPU-0): HPN HP ENVY 27s (DFP-2): Internal DisplayPort
[  8480.719] (--) NVIDIA(GPU-0): HPN HP ENVY 27s (DFP-2): 960.0 MHz maximum pixel clock
[  8480.720] (--) NVIDIA(GPU-0): DFP-3: disconnected
[  8480.720] (--) NVIDIA(GPU-0): DFP-3: Internal TMDS
[  8480.720] (--) NVIDIA(GPU-0): DFP-3: 165.0 MHz maximum pixel clock
[  8480.721] (--) NVIDIA(GPU-0): DFP-4: disconnected
[  8480.721] (--) NVIDIA(GPU-0): DFP-4: Internal TMDS
[  8480.721] (--) NVIDIA(GPU-0): DFP-4: 330.0 MHz maximum pixel clock
[  8481.480] (--) NVIDIA(GPU-0): CRT-0: disconnected
[  8481.480] (--) NVIDIA(GPU-0): CRT-0: 400.0 MHz maximum pixel clock
[  8481.484] (--) NVIDIA(GPU-0): DFP-0: disconnected
[  8481.484] (--) NVIDIA(GPU-0): DFP-0: Internal TMDS
[  8481.484] (--) NVIDIA(GPU-0): DFP-0: 330.0 MHz maximum pixel clock
[  8481.484] (--) NVIDIA(GPU-0): DFP-1: disconnected
[  8481.484] (--) NVIDIA(GPU-0): DFP-1: Internal TMDS
[  8481.484] (--) NVIDIA(GPU-0): DFP-1: 165.0 MHz maximum pixel clock
[  8481.485] (--) NVIDIA(GPU-0): HPN HP ENVY 27s (DFP-2): connected
[  8481.485] (--) NVIDIA(GPU-0): HPN HP ENVY 27s (DFP-2): Internal DisplayPort
[  8481.485] (--) NVIDIA(GPU-0): HPN HP ENVY 27s (DFP-2): 960.0 MHz maximum pixel clock
[  8481.486] (--) NVIDIA(GPU-0): DFP-3: disconnected
[  8481.486] (--) NVIDIA(GPU-0): DFP-3: Internal TMDS
[  8481.486] (--) NVIDIA(GPU-0): DFP-3: 165.0 MHz maximum pixel clock
[  8481.486] (--) NVIDIA(GPU-0): DFP-4: disconnected
[  8481.486] (--) NVIDIA(GPU-0): DFP-4: Internal TMDS
[  8481.486] (--) NVIDIA(GPU-0): DFP-4: 330.0 MHz maximum pixel clock
[  8780.836] (EE) client bug: timer event20 debounce short: scheduled expiry is in the past (-5ms), your system is too slow
[  9788.117] (EE) client bug: timer event20 debounce short: scheduled expiry is in the past (-5ms), your system is too slow
[  9836.904] (EE) client bug: timer event20 debounce: scheduled expiry is in the past (-19ms), your system is too slow
[  9836.904] (EE) client bug: timer event20 debounce short: scheduled expiry is in the past (-32ms), your system is too slow
[ 10645.587] (--) NVIDIA(GPU-0): CRT-0: disconnected
[ 10645.587] (--) NVIDIA(GPU-0): CRT-0: 400.0 MHz maximum pixel clock
[ 10645.591] (--) NVIDIA(GPU-0): DFP-0: disconnected
[ 10645.591] (--) NVIDIA(GPU-0): DFP-0: Internal TMDS
[ 10645.591] (--) NVIDIA(GPU-0): DFP-0: 330.0 MHz maximum pixel clock
[ 10645.591] (--) NVIDIA(GPU-0): DFP-1: disconnected
[ 10645.591] (--) NVIDIA(GPU-0): DFP-1: Internal TMDS
[ 10645.591] (--) NVIDIA(GPU-0): DFP-1: 165.0 MHz maximum pixel clock
[ 10645.591] (--) NVIDIA(GPU-0): HPN HP ENVY 27s (DFP-2): connected
[ 10645.591] (--) NVIDIA(GPU-0): HPN HP ENVY 27s (DFP-2): Internal DisplayPort
[ 10645.591] (--) NVIDIA(GPU-0): HPN HP ENVY 27s (DFP-2): 960.0 MHz maximum pixel clock
[ 10645.592] (--) NVIDIA(GPU-0): DFP-3: disconnected
[ 10645.592] (--) NVIDIA(GPU-0): DFP-3: Internal TMDS
[ 10645.592] (--) NVIDIA(GPU-0): DFP-3: 165.0 MHz maximum pixel clock
[ 10645.592] (--) NVIDIA(GPU-0): DFP-4: disconnected
[ 10645.592] (--) NVIDIA(GPU-0): DFP-4: Internal TMDS
[ 10645.592] (--) NVIDIA(GPU-0): DFP-4: 330.0 MHz maximum pixel clock
[ 10930.647] (EE) client bug: timer event20 debounce: scheduled expiry is in the past (-0ms), your system is too slow
[ 10930.647] (EE) client bug: timer event20 debounce short: scheduled expiry is in the past (-13ms), your system is too slow
[ 11382.453] (EE) client bug: timer event20 debounce short: scheduled expiry is in the past (-4ms), your system is too slow
[ 12686.377] (EE) client bug: timer event20 debounce: scheduled expiry is in the past (-22ms), your system is too slow
[ 12686.377] (EE) client bug: timer event20 debounce short: scheduled expiry is in the past (-35ms), your system is too slow
[ 13000.260] (EE) client bug: timer event20 debounce short: scheduled expiry is in the past (-10ms), your system is too slow
[ 13050.202] (EE) client bug: timer event20 debounce: scheduled expiry is in the past (-10ms), your system is too slow
[ 13050.202] (EE) client bug: timer event20 debounce short: scheduled expiry is in the past (-23ms), your system is too slow
[ 14735.205] (--) NVIDIA(GPU-0): CRT-0: disconnected
[ 14735.208] (--) NVIDIA(GPU-0): CRT-0: 400.0 MHz maximum pixel clock
[ 14735.212] (--) NVIDIA(GPU-0): DFP-0: disconnected
[ 14735.212] (--) NVIDIA(GPU-0): DFP-0: Internal TMDS
[ 14735.212] (--) NVIDIA(GPU-0): DFP-0: 330.0 MHz maximum pixel clock
[ 14735.212] (--) NVIDIA(GPU-0): DFP-1: disconnected
[ 14735.212] (--) NVIDIA(GPU-0): DFP-1: Internal TMDS
[ 14735.212] (--) NVIDIA(GPU-0): DFP-1: 165.0 MHz maximum pixel clock
[ 14735.212] (--) NVIDIA(GPU-0): HPN HP ENVY 27s (DFP-2): connected
[ 14735.212] (--) NVIDIA(GPU-0): HPN HP ENVY 27s (DFP-2): Internal DisplayPort
[ 14735.212] (--) NVIDIA(GPU-0): HPN HP ENVY 27s (DFP-2): 960.0 MHz maximum pixel clock
[ 14735.213] (--) NVIDIA(GPU-0): DFP-3: disconnected
[ 14735.213] (--) NVIDIA(GPU-0): DFP-3: Internal TMDS
[ 14735.213] (--) NVIDIA(GPU-0): DFP-3: 165.0 MHz maximum pixel clock
[ 14735.213] (--) NVIDIA(GPU-0): DFP-4: disconnected
[ 14735.213] (--) NVIDIA(GPU-0): DFP-4: Internal TMDS
[ 14735.213] (--) NVIDIA(GPU-0): DFP-4: 330.0 MHz maximum pixel clock
[ 15936.852] (**) Option "fd" "32"
[ 15936.852] (II) event1  - Power Button: device removed
[ 15936.853] (**) Option "fd" "35"
[ 15936.853] (II) event0  - Power Button: device removed
[ 15936.853] (**) Option "fd" "36"
[ 15936.854] (**) Option "fd" "37"
[ 15936.854] (II) event22 - Logitech Logitech Gaming Keyboard: device removed
[ 15936.854] (**) Option "fd" "38"
[ 15936.854] (II) event18 - Logitech Logitech Gaming Keyboard Consumer Control: device removed
[ 15936.855] (**) Option "fd" "39"
[ 15936.855] (II) event25 - Logitech Gaming Keyboard Gaming Keys: device removed
[ 15936.855] (**) Option "fd" "40"
[ 15936.855] (II) event20 - Logitech Gaming Mouse G502: device removed
[ 15936.856] (**) Option "fd" "41"
[ 15936.856] (II) event21 - Logitech Gaming Mouse G502 Keyboard: device removed
[ 15936.856] (**) Option "fd" "42"
[ 15936.856] (**) Option "fd" "43"
[ 15936.856] (II) event24 - Logitech Gaming Mouse G502 System Control: device removed
[ 15936.857] (**) Option "fd" "44"
[ 15936.857] (II) event3  - Eee PC WMI hotkeys: device removed
[ 15936.857] (**) Option "fd" "36"
[ 15936.857] (II) event19 - Valve Software Steam Controller: device removed
[ 15936.858] (**) Option "fd" "42"
[ 15936.858] (II) event23 - Logitech Gaming Mouse G502 Consumer Control: device removed
[ 15936.965] (II) systemd-logind: got pause for 13:65
[ 15936.965] (II) systemd-logind: got pause for 13:83
[ 15936.965] (II) systemd-logind: got pause for 13:87
[ 15936.965] (II) systemd-logind: got pause for 13:86
[ 15936.965] (II) systemd-logind: got pause for 13:67
[ 15936.965] (II) systemd-logind: got pause for 13:64
[ 15936.965] (II) systemd-logind: got pause for 13:89
[ 15936.965] (II) systemd-logind: got pause for 13:88
[ 15936.965] (II) systemd-logind: got pause for 13:85
[ 15936.965] (II) systemd-logind: got pause for 13:82
[ 15936.965] (II) systemd-logind: got pause for 13:84
[ 15940.781] (II) systemd-logind: got resume for 13:65
[ 15940.786] (--) NVIDIA(GPU-0): CRT-0: disconnected
[ 15940.786] (--) NVIDIA(GPU-0): CRT-0: 400.0 MHz maximum pixel clock
[ 15940.790] (--) NVIDIA(GPU-0): DFP-0: disconnected
[ 15940.790] (--) NVIDIA(GPU-0): DFP-0: Internal TMDS
[ 15940.790] (--) NVIDIA(GPU-0): DFP-0: 330.0 MHz maximum pixel clock
[ 15940.790] (--) NVIDIA(GPU-0): DFP-1: disconnected
[ 15940.790] (--) NVIDIA(GPU-0): DFP-1: Internal TMDS
[ 15940.790] (--) NVIDIA(GPU-0): DFP-1: 165.0 MHz maximum pixel clock
[ 15940.790] (--) NVIDIA(GPU-0): HPN HP ENVY 27s (DFP-2): connected
[ 15940.790] (--) NVIDIA(GPU-0): HPN HP ENVY 27s (DFP-2): Internal DisplayPort
[ 15940.790] (--) NVIDIA(GPU-0): HPN HP ENVY 27s (DFP-2): 960.0 MHz maximum pixel clock
[ 15940.791] (--) NVIDIA(GPU-0): DFP-3: disconnected
[ 15940.791] (--) NVIDIA(GPU-0): DFP-3: Internal TMDS
[ 15940.791] (--) NVIDIA(GPU-0): DFP-3: 165.0 MHz maximum pixel clock
[ 15940.791] (--) NVIDIA(GPU-0): DFP-4: disconnected
[ 15940.791] (--) NVIDIA(GPU-0): DFP-4: Internal TMDS
[ 15940.791] (--) NVIDIA(GPU-0): DFP-4: 330.0 MHz maximum pixel clock
[ 15940.806] (II) NVIDIA(0): Setting mode "DFP-2:nvidia-auto-select"
[ 15940.860] (II) NVIDIA(0): ACPI: failed to connect to the ACPI event daemon; the daemon
[ 15940.860] (II) NVIDIA(0):     may not be running or the "AcpidSocketPath" X
[ 15940.860] (II) NVIDIA(0):     configuration option may not be set correctly.  When the
[ 15940.860] (II) NVIDIA(0):     ACPI event daemon is available, the NVIDIA X driver will
[ 15940.860] (II) NVIDIA(0):     try to use it to receive ACPI event notifications.  For
[ 15940.860] (II) NVIDIA(0):     details, please see the "ConnectToAcpid" and
[ 15940.860] (II) NVIDIA(0):     "AcpidSocketPath" X configuration options in Appendix B: X
[ 15940.860] (II) NVIDIA(0):     Config Options in the README.
[ 15940.898] (II) event1  - Power Button: is tagged by udev as: Keyboard
[ 15940.898] (II) event1  - Power Button: device is a keyboard
[ 15940.898] (II) systemd-logind: got resume for 13:83
[ 15940.899] (II) event19 - Valve Software Steam Controller: is tagged by udev as: Keyboard Mouse
[ 15940.899] (II) event19 - Valve Software Steam Controller: device is a pointer
[ 15940.899] (II) event19 - Valve Software Steam Controller: device is a keyboard
[ 15940.900] (II) systemd-logind: got resume for 13:87
[ 15940.901] (II) event23 - Logitech Gaming Mouse G502 Consumer Control: is tagged by udev as: Keyboard
[ 15940.901] (II) event23 - Logitech Gaming Mouse G502 Consumer Control: device is a keyboard
[ 15940.901] (II) systemd-logind: got resume for 13:86
[ 15940.902] (II) event22 - Logitech Logitech Gaming Keyboard: is tagged by udev as: Keyboard
[ 15940.902] (II) event22 - Logitech Logitech Gaming Keyboard: device is a keyboard
[ 15940.903] (II) systemd-logind: got resume for 13:67
[ 15940.903] (II) event3  - Eee PC WMI hotkeys: is tagged by udev as: Keyboard
[ 15940.903] (II) event3  - Eee PC WMI hotkeys: device is a keyboard
[ 15940.903] (II) systemd-logind: got resume for 13:64
[ 15940.904] (II) event0  - Power Button: is tagged by udev as: Keyboard
[ 15940.904] (II) event0  - Power Button: device is a keyboard
[ 15940.904] (II) systemd-logind: got resume for 13:89
[ 15940.905] (II) event25 - Logitech Gaming Keyboard Gaming Keys: is tagged by udev as: Keyboard
[ 15940.905] (II) event25 - Logitech Gaming Keyboard Gaming Keys: device is a keyboard
[ 15940.911] (II) systemd-logind: got resume for 13:88
[ 15940.912] (II) event24 - Logitech Gaming Mouse G502 System Control: is tagged by udev as: Keyboard
[ 15940.912] (II) event24 - Logitech Gaming Mouse G502 System Control: device is a keyboard
[ 15940.913] (II) systemd-logind: got resume for 13:85
[ 15940.913] (II) event21 - Logitech Gaming Mouse G502 Keyboard: is tagged by udev as: Keyboard
[ 15940.913] (II) event21 - Logitech Gaming Mouse G502 Keyboard: device is a keyboard
[ 15940.914] (II) systemd-logind: got resume for 13:82
[ 15940.915] (II) event18 - Logitech Logitech Gaming Keyboard Consumer Control: is tagged by udev as: Keyboard
[ 15940.915] (II) event18 - Logitech Logitech Gaming Keyboard Consumer Control: device is a keyboard
[ 15940.915] (II) systemd-logind: got resume for 13:84
[ 15940.916] (II) event20 - Logitech Gaming Mouse G502: is tagged by udev as: Mouse
[ 15940.916] (II) event20 - Logitech Gaming Mouse G502: device set to 2400 DPI
[ 15940.916] (II) event20 - Logitech Gaming Mouse G502: device is a pointer
[ 17542.146] (EE) client bug: timer event20 debounce short: scheduled expiry is in the past (-0ms), your system is too slow
[ 18418.594] (EE) client bug: timer event20 debounce: scheduled expiry is in the past (-34ms), your system is too slow
[ 18418.594] (EE) client bug: timer event20 debounce short: scheduled expiry is in the past (-48ms), your system is too slow
[ 21839.152] (EE) client bug: timer event20 debounce short: scheduled expiry is in the past (-2ms), your system is too slow
[ 21957.811] (EE) client bug: timer event20 debounce short: scheduled expiry is in the past (-1ms), your system is too slow
[ 23116.171] (EE) client bug: timer event20 debounce: scheduled expiry is in the past (-14ms), your system is too slow
[ 23116.171] (EE) client bug: timer event20 debounce short: scheduled expiry is in the past (-27ms), your system is too slow
[ 24274.410] (EE) client bug: timer event20 debounce short: scheduled expiry is in the past (-0ms), your system is too slow
[ 25769.202] (EE) client bug: timer event20 debounce: scheduled expiry is in the past (-0ms), your system is too slow
[ 25769.204] (EE) client bug: timer event20 debounce short: scheduled expiry is in the past (-15ms), your system is too slow
[ 25772.821] (EE) client bug: timer event20 debounce: scheduled expiry is in the past (-3ms), your system is too slow
[ 25772.821] (EE) client bug: timer event20 debounce short: scheduled expiry is in the past (-16ms), your system is too slow
[ 26611.553] (EE) client bug: timer event20 debounce: scheduled expiry is in the past (-14ms), your system is too slow
[ 26611.554] (EE) client bug: timer event20 debounce short: scheduled expiry is in the past (-28ms), your system is too slow
[ 28890.904] (EE) client bug: timer event20 debounce short: scheduled expiry is in the past (-2ms), your system is too slow
[ 28900.933] (EE) client bug: timer event20 debounce short: scheduled expiry is in the past (-3ms), your system is too slow
[ 28945.438] (EE) client bug: timer event20 debounce short: scheduled expiry is in the past (-0ms), your system is too slow
[ 29133.832] (II) event20 - Logitech Gaming Mouse G502: SYN_DROPPED event - some input events have been lost.
[ 29982.612] (EE) client bug: timer event20 debounce: scheduled expiry is in the past (-473ms), your system is too slow
[ 29982.624] (II) event20 - Logitech Gaming Mouse G502: SYN_DROPPED event - some input events have been lost.
[ 30025.274] (II) event20 - Logitech Gaming Mouse G502: SYN_DROPPED event - some input events have been lost.
[ 30025.620] (II) event20 - Logitech Gaming Mouse G502: SYN_DROPPED event - some input events have been lost.
[ 30025.951] (II) event20 - Logitech Gaming Mouse G502: SYN_DROPPED event - some input events have been lost.
[ 30026.506] (II) event20 - Logitech Gaming Mouse G502: SYN_DROPPED event - some input events have been lost.
[ 30026.625] (II) event20 - Logitech Gaming Mouse G502: SYN_DROPPED event - some input events have been lost.
[ 30026.632] (II) event20 - Logitech Gaming Mouse G502: WARNING: log rate limit exceeded (5 msgs per 30000ms). Discarding future messages.
[ 30039.900] (**) Option "fd" "39"
[ 30040.060] (II) event1  - Power Button: device removed
[ 30040.648] (**) Option "fd" "36"
[ 30040.723] (II) event0  - Power Button: device removed
[ 30041.009] (**) Option "fd" "23"
[ 30043.734] (**) Option "fd" "32"
[ 30043.820] (II) event22 - Logitech Logitech Gaming Keyboard: device removed
[ 30047.161] (**) Option "fd" "42"
[ 30047.320] (II) event18 - Logitech Logitech Gaming Keyboard Consumer Control: device removed
[ 30059.326] (**) Option "fd" "37"
[ 30059.543] (II) event25 - Logitech Gaming Keyboard Gaming Keys: device removed
[ 30068.002] (**) Option "fd" "43"
[ 30068.409] (II) event20 - Logitech Gaming Mouse G502: device removed
[ 30084.709] (**) Option "fd" "38"
[ 30084.946] (II) event21 - Logitech Gaming Mouse G502 Keyboard: device removed
[ 30187.393] (**) Option "fd" "24"
[ 30251.661] (**) Option "fd" "87"
[ 30252.726] (II) event24 - Logitech Gaming Mouse G502 System Control: device removed
[ 30282.549] (**) Option "fd" "35"
[ 30283.462] (II) event3  - Eee PC WMI hotkeys: device removed
[ 30302.574] (**) Option "fd" "23"
[ 30303.271] (II) event19 - Valve Software Steam Controller: device removed
____________________________________________
*** /var/log/Xorg.3.log.old
*** ls: -rw-r--r-- 1 root user 42236 2020-06-23 15:10:02.849539192 +0200 /var/log/Xorg.3.log.old
[  7842.374] (WW) Failed to open protocol names file lib/xorg/protocol.txt
[  7842.376]
X.Org X Server 1.20.8
X Protocol Version 11, Revision 0
[  7842.381] Build Operating System: Linux Arch Linux
[  7842.383] Current Operating System: Linux localhost 5.7.4-arch1-1 #1 SMP PREEMPT Thu, 18 Jun 2020 16:01:07 +0000 x86_64
[  7842.384] Kernel command line: root=UUID=6c37d730-4b14-4479-8554-92d2e75478d5 rw initrd=\initramfs-linux.img
[  7842.387] Build Date: 05 May 2020  05:08:17AM
[  7842.388]
[  7842.390] Current version of pixman: 0.40.0
[  7842.392] 	Before reporting problems, check http://wiki.x.org
   to make sure that you have the latest version.
[  7842.392] Markers: (--) probed, (**) from config file, (==) default setting,
   (++) from command line, (!!) notice, (II) informational,
   (WW) warning, (EE) error, (NI) not implemented, (??) unknown.
[  7842.396] (==) Log file: "/var/log/Xorg.3.log", Time: Tue Jun 23 14:59:38 2020
[  7842.399] (==) Using config file: "/etc/X11/xorg.conf"
[  7842.400] (==) Using config directory: "/etc/X11/xorg.conf.d"
[  7842.401] (==) Using system config directory "/usr/share/X11/xorg.conf.d"
[  7842.403] (==) ServerLayout "Layout0"
[  7842.403] (**) |-->Screen "Screen0" (0)
[  7842.403] (**) |   |-->Monitor "Monitor0"
[  7842.403] (**) |   |-->Device "Device0"
[  7842.403] (**) |   |-->GPUDevice "Device0"
[  7842.404] (**) |-->Input Device "Keyboard0"
[  7842.404] (**) |-->Input Device "Mouse0"
[  7842.404] (**) Option "Xinerama" "0"
[  7842.404] (==) Automatically adding devices
[  7842.404] (==) Automatically enabling devices
[  7842.404] (==) Automatically adding GPU devices
[  7842.404] (==) Automatically binding GPU devices
[  7842.404] (==) Max clients allowed: 256, resource mask: 0x1fffff
[  7842.406] (WW) `fonts.dir' not found (or not valid) in "/usr/share/fonts/OTF".
[  7842.406] 	Entry deleted from font path.
[  7842.406] 	(Run 'mkfontdir' on "/usr/share/fonts/OTF").
[  7842.406] (WW) The directory "/usr/share/fonts/Type1" does not exist.
[  7842.406] (WW) The directory "/usr/share/fonts/100dpi" does not exist.
[  7842.406] (WW) The directory "/usr/share/fonts/75dpi" does not exist.
[  7842.406] (==) FontPath set to:
   /usr/share/fonts/misc,
   /usr/share/fonts/TTF
[  7842.406] (==) ModulePath set to "/usr/lib/xorg/modules"
[  7842.406] (WW) Hotplugging is on, devices using drivers 'kbd', 'mouse' or 'vmmouse' will be disabled.
[  7842.406] (WW) Disabling Keyboard0
[  7842.406] (WW) Disabling Mouse0
[  7842.406] (II) Module ABI versions:
[  7842.406] 	X.Org ANSI C Emulation: 0.4
[  7842.406] 	X.Org Video Driver: 24.1
[  7842.406] 	X.Org XInput driver : 24.1
[  7842.406] 	X.Org Server Extension : 10.0
[  7842.407] (++) using VT number 1
[  7842.408] (II) systemd-logind: took control of session /org/freedesktop/login1/session/_31
[  7842.408] (II) xfree86: Adding drm device (/dev/dri/card0)
[  7842.408] (II) systemd-logind: got fd for /dev/dri/card0 226:0 fd 10 paused 0
[  7842.409] (**) OutputClass "nvidia" ModulePath extended to "/usr/lib/nvidia/xorg,/usr/lib/xorg/modules,/usr/lib/xorg/modules"
[  7842.410] (--) PCI:*(1@0:0:0) 10de:13c2:1462:3160 rev 161, Mem @ 0xde000000/16777216, 0xc0000000/268435456, 0xd0000000/33554432, I/O @ 0x0000e000/128, BIOS @ 0x????????/131072
[  7842.410] (WW) Open ACPI failed (/var/run/acpid.socket) (No such file or directory)
[  7842.410] (II) LoadModule: "glx"
[  7842.411] (II) Loading /usr/lib/xorg/modules/extensions/libglx.so
[  7842.421] (II) Module glx: vendor="X.Org Foundation"
[  7842.421] 	compiled for 1.20.8, module version = 1.0.0
[  7842.421] 	ABI class: X.Org Server Extension, version 10.0
[  7842.421] (II) LoadModule: "nvidia"
[  7842.421] (II) Loading /usr/lib/xorg/modules/drivers/nvidia_drv.so
[  7842.428] (II) Module nvidia: vendor="NVIDIA Corporation"
[  7842.428] 	compiled for 1.6.99.901, module version = 1.0.0
[  7842.428] 	Module class: X.Org Video Driver
[  7842.429] (II) NVIDIA dlloader X Driver  440.82  Wed Apr  1 19:50:17 UTC 2020
[  7842.429] (II) NVIDIA Unified Driver for all Supported NVIDIA GPUs
[  7842.430] (II) systemd-logind: releasing fd for 226:0
[  7842.431] (II) Loading sub module "fb"
[  7842.431] (II) LoadModule: "fb"
[  7842.431] (II) Loading /usr/lib/xorg/modules/libfb.so
[  7842.432] (II) Module fb: vendor="X.Org Foundation"
[  7842.432] 	compiled for 1.20.8, module version = 1.0.0
[  7842.432] 	ABI class: X.Org ANSI C Emulation, version 0.4
[  7842.432] (II) Loading sub module "wfb"
[  7842.432] (II) LoadModule: "wfb"
[  7842.432] (II) Loading /usr/lib/xorg/modules/libwfb.so
[  7842.434] (II) Module wfb: vendor="X.Org Foundation"
[  7842.434] 	compiled for 1.20.8, module version = 1.0.0
[  7842.434] 	ABI class: X.Org ANSI C Emulation, version 0.4
[  7842.434] (II) Loading sub module "ramdac"
[  7842.434] (II) LoadModule: "ramdac"
[  7842.434] (II) Module "ramdac" already built-in
[  7842.436] (**) NVIDIA(0): Depth 24, (--) framebuffer bpp 32
[  7842.436] (==) NVIDIA(0): RGB weight 888
[  7842.436] (==) NVIDIA(0): Default visual is TrueColor
[  7842.436] (==) NVIDIA(0): Using gamma correction (1.0, 1.0, 1.0)
[  7842.436] (II) Applying OutputClass "nvidia" options to /dev/dri/card0
[  7842.436] (**) NVIDIA(0): Option "Stereo" "0"
[  7842.436] (**) NVIDIA(0): Option "nvidiaXineramaInfoOrder" "DFP-1"
[  7842.436] (**) NVIDIA(0): Option "SLI" "Off"
[  7842.436] (**) NVIDIA(0): Option "MultiGPU" "Off"
[  7842.436] (**) NVIDIA(0): Option "BaseMosaic" "off"
[  7842.437] (**) NVIDIA(0): Option "AllowEmptyInitialConfiguration"
[  7842.437] (**) NVIDIA(0): Stereo disabled by request
[  7842.437] (**) NVIDIA(0): NVIDIA SLI disabled.
[  7842.437] (**) NVIDIA(0): NVIDIA Multi-GPU disabled.
[  7842.437] (**) NVIDIA(0): Option "MetaModes" "HDMI-0: 3840x2160_60 +0+0, DP-0: 1920x1080_144 +3840+0"
[  7842.437] (**) NVIDIA(0): Enabling 2D acceleration
[  7842.437] (II) Loading sub module "glxserver_nvidia"
[  7842.437] (II) LoadModule: "glxserver_nvidia"
[  7842.437] (II) Loading /usr/lib/nvidia/xorg/libglxserver_nvidia.so
[  7842.506] (II) Module glxserver_nvidia: vendor="NVIDIA Corporation"
[  7842.506] 	compiled for 1.6.99.901, module version = 1.0.0
[  7842.507] 	Module class: X.Org Server Extension
[  7842.507] (II) NVIDIA GLX Module  440.82  Wed Apr  1 19:47:36 UTC 2020
[  7842.510] (II) NVIDIA: The X server supports PRIME Render Offload.
[  7842.775] (--) NVIDIA(0): Valid display device(s) on GPU-0 at PCI:1:0:0
[  7842.775] (--) NVIDIA(0):     CRT-0
[  7842.775] (--) NVIDIA(0):     DFP-0
[  7842.775] (--) NVIDIA(0):     DFP-1
[  7842.775] (--) NVIDIA(0):     DFP-2 (boot)
[  7842.775] (--) NVIDIA(0):     DFP-3
[  7842.775] (--) NVIDIA(0):     DFP-4
[  7842.776] (II) NVIDIA(0): NVIDIA GPU GeForce GTX 970 (GM204-A) at PCI:1:0:0 (GPU-0)
[  7842.776] (--) NVIDIA(0): Memory: 4194304 kBytes
[  7842.776] (--) NVIDIA(0): VideoBIOS: 84.04.2f.00.f1
[  7842.776] (II) NVIDIA(0): Detected PCI Express Link width: 16X
[  7842.780] (--) NVIDIA(GPU-0): CRT-0: disconnected
[  7842.780] (--) NVIDIA(GPU-0): CRT-0: 400.0 MHz maximum pixel clock
[  7842.784] (--) NVIDIA(GPU-0): DFP-0: disconnected
[  7842.784] (--) NVIDIA(GPU-0): DFP-0: Internal TMDS
[  7842.784] (--) NVIDIA(GPU-0): DFP-0: 330.0 MHz maximum pixel clock
[  7842.784] (--) NVIDIA(GPU-0): DFP-1: disconnected
[  7842.784] (--) NVIDIA(GPU-0): DFP-1: Internal TMDS
[  7842.784] (--) NVIDIA(GPU-0): DFP-1: 165.0 MHz maximum pixel clock
[  7842.784] (--) NVIDIA(GPU-0): HPN HP ENVY 27s (DFP-2): connected
[  7842.784] (--) NVIDIA(GPU-0): HPN HP ENVY 27s (DFP-2): Internal DisplayPort
[  7842.784] (--) NVIDIA(GPU-0): HPN HP ENVY 27s (DFP-2): 960.0 MHz maximum pixel clock
[  7842.785] (--) NVIDIA(GPU-0): DFP-3: disconnected
[  7842.785] (--) NVIDIA(GPU-0): DFP-3: Internal TMDS
[  7842.785] (--) NVIDIA(GPU-0): DFP-3: 165.0 MHz maximum pixel clock
[  7842.785] (--) NVIDIA(GPU-0): DFP-4: disconnected
[  7842.785] (--) NVIDIA(GPU-0): DFP-4: Internal TMDS
[  7842.785] (--) NVIDIA(GPU-0): DFP-4: 330.0 MHz maximum pixel clock
[  7842.787] (WW) NVIDIA(0): No valid modes for
[  7842.787] (WW) NVIDIA(0):     "HDMI-0:3840x2160_60+0+0,DP-0:1920x1080_144+3840+0";
[  7842.787] (WW) NVIDIA(0):     removing.
[  7842.787] (WW) NVIDIA(0): Unable to validate any modes; falling back to the default mode
[  7842.787] (WW) NVIDIA(0):     "nvidia-auto-select".
[  7842.787] (II) NVIDIA(0): Validated MetaModes:
[  7842.787] (II) NVIDIA(0):     "DFP-2:nvidia-auto-select"
[  7842.787] (II) NVIDIA(0): Virtual screen size determined to be 3840 x 2160
[  7842.791] (--) NVIDIA(0): DPI set to (162, 161); computed from "UseEdidDpi" X config
[  7842.791] (--) NVIDIA(0):     option
[  7842.791] (II) NVIDIA: Using 6144.00 MB of virtual memory for indirect memory
[  7842.791] (II) NVIDIA:     access.
[  7842.793] (II) NVIDIA(0): ACPI: failed to connect to the ACPI event daemon; the daemon
[  7842.793] (II) NVIDIA(0):     may not be running or the "AcpidSocketPath" X
[  7842.793] (II) NVIDIA(0):     configuration option may not be set correctly.  When the
[  7842.793] (II) NVIDIA(0):     ACPI event daemon is available, the NVIDIA X driver will
[  7842.793] (II) NVIDIA(0):     try to use it to receive ACPI event notifications.  For
[  7842.793] (II) NVIDIA(0):     details, please see the "ConnectToAcpid" and
[  7842.793] (II) NVIDIA(0):     "AcpidSocketPath" X configuration options in Appendix B: X
[  7842.793] (II) NVIDIA(0):     Config Options in the README.
[  7842.825] (II) NVIDIA(0): Setting mode "DFP-2:nvidia-auto-select"
[  7842.930] (==) NVIDIA(0): Disabling shared memory pixmaps
[  7842.930] (==) NVIDIA(0): Backing store enabled
[  7842.930] (==) NVIDIA(0): Silken mouse disabled
[  7842.930] (**) NVIDIA(0): DPMS enabled
[  7842.930] (II) Loading sub module "dri2"
[  7842.930] (II) LoadModule: "dri2"
[  7842.930] (II) Module "dri2" already built-in
[  7842.930] (II) NVIDIA(0): [DRI2] Setup complete
[  7842.930] (II) NVIDIA(0): [DRI2]   VDPAU driver: nvidia
[  7842.931] (II) Initializing extension Generic Event Extension
[  7842.931] (II) Initializing extension SHAPE
[  7842.931] (II) Initializing extension MIT-SHM
[  7842.931] (II) Initializing extension XInputExtension
[  7842.931] (II) Initializing extension XTEST
[  7842.931] (II) Initializing extension BIG-REQUESTS
[  7842.931] (II) Initializing extension SYNC
[  7842.931] (II) Initializing extension XKEYBOARD
[  7842.931] (II) Initializing extension XC-MISC
[  7842.931] (II) Initializing extension SECURITY
[  7842.931] (II) Initializing extension XFIXES
[  7842.931] (II) Initializing extension RENDER
[  7842.931] (II) Initializing extension RANDR
[  7842.931] (II) Initializing extension COMPOSITE
[  7842.931] (II) Initializing extension DAMAGE
[  7842.931] (II) Initializing extension MIT-SCREEN-SAVER
[  7842.931] (II) Initializing extension DOUBLE-BUFFER
[  7842.931] (II) Initializing extension RECORD
[  7842.931] (II) Initializing extension DPMS
[  7842.931] (II) Initializing extension Present
[  7842.931] (II) Initializing extension DRI3
[  7842.931] (II) Initializing extension X-Resource
[  7842.931] (II) Initializing extension XVideo
[  7842.931] (II) Initializing extension XVideo-MotionCompensation
[  7842.931] (II) Initializing extension GLX
[  7842.931] (II) Indirect GLX disabled.
[  7842.931] (II) GLX: Another vendor is already registered for screen 0
[  7842.931] (II) Initializing extension XFree86-VidModeExtension
[  7842.931] (II) Initializing extension XFree86-DGA
[  7842.931] (II) Initializing extension XFree86-DRI
[  7842.931] (II) Initializing extension DRI2
[  7842.931] (II) Initializing extension NV-GLX
[  7842.931] (II) Initializing extension NV-CONTROL
[  7842.931] (II) Initializing extension XINERAMA
[  7842.988] (II) config/udev: Adding input device Power Button (/dev/input/event1)
[  7842.988] (**) Power Button: Applying InputClass "libinput keyboard catchall"
[  7842.988] (**) Power Button: Applying InputClass "system-keyboard"
[  7842.988] (II) LoadModule: "libinput"
[  7842.989] (II) Loading /usr/lib/xorg/modules/input/libinput_drv.so
[  7842.994] (II) Module libinput: vendor="X.Org Foundation"
[  7842.994] 	compiled for 1.20.8, module version = 0.30.0
[  7842.994] 	Module class: X.Org XInput Driver
[  7842.994] 	ABI class: X.Org XInput driver, version 24.1
[  7842.994] (II) Using input driver 'libinput' for 'Power Button'
[  7842.995] (II) systemd-logind: got fd for /dev/input/event1 13:65 fd 32 paused 0
[  7842.995] (**) Power Button: always reports core events
[  7842.995] (**) Option "Device" "/dev/input/event1"
[  7842.995] (**) Option "_source" "server/udev"
[  7843.001] (II) event1  - Power Button: is tagged by udev as: Keyboard
[  7843.001] (II) event1  - Power Button: device is a keyboard
[  7843.001] (II) event1  - Power Button: device removed
[  7843.001] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXPWRBN:00/input/input1/event1"
[  7843.001] (II) XINPUT: Adding extended input device "Power Button" (type: KEYBOARD, id 6)
[  7843.001] (**) Option "xkb_model" "fr-latin1"
[  7843.001] (**) Option "xkb_layout" "fr"
[  7843.017] (II) event1  - Power Button: is tagged by udev as: Keyboard
[  7843.017] (II) event1  - Power Button: device is a keyboard
[  7843.018] (II) config/udev: Adding input device Power Button (/dev/input/event0)
[  7843.018] (**) Power Button: Applying InputClass "libinput keyboard catchall"
[  7843.018] (**) Power Button: Applying InputClass "system-keyboard"
[  7843.018] (II) Using input driver 'libinput' for 'Power Button'
[  7843.019] (II) systemd-logind: got fd for /dev/input/event0 13:64 fd 35 paused 0
[  7843.019] (**) Power Button: always reports core events
[  7843.019] (**) Option "Device" "/dev/input/event0"
[  7843.019] (**) Option "_source" "server/udev"
[  7843.019] (II) event0  - Power Button: is tagged by udev as: Keyboard
[  7843.019] (II) event0  - Power Button: device is a keyboard
[  7843.019] (II) event0  - Power Button: device removed
[  7843.019] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0C:00/input/input0/event0"
[  7843.019] (II) XINPUT: Adding extended input device "Power Button" (type: KEYBOARD, id 7)
[  7843.019] (**) Option "xkb_model" "fr-latin1"
[  7843.019] (**) Option "xkb_layout" "fr"
[  7843.020] (II) event0  - Power Button: is tagged by udev as: Keyboard
[  7843.020] (II) event0  - Power Button: device is a keyboard
[  7843.021] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=12 (/dev/input/event10)
[  7843.021] (II) No input driver specified, ignoring this device.
[  7843.021] (II) This device may have been added with another device file.
[  7843.021] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=3 (/dev/input/event4)
[  7843.021] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=7 (/dev/input/event5)
[  7843.022] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=8 (/dev/input/event6)
[  7843.022] (II) No input driver specified, ignoring this device.
[  7843.022] (II) This device may have been added with another device file.
[  7843.022] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=9 (/dev/input/event7)
[  7843.022] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=10 (/dev/input/event8)
[  7843.023] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=11 (/dev/input/event9)
[  7843.023] (II) No input driver specified, ignoring this device.
[  7843.023] (II) This device may have been added with another device file.
[  7843.023] (II) config/udev: Adding input device Valve Software Steam Controller (/dev/input/event19)
[  7843.023] (**) Valve Software Steam Controller: Applying InputClass "libinput pointer catchall"
[  7843.023] (**) Valve Software Steam Controller: Applying InputClass "libinput keyboard catchall"
[  7843.023] (**) Valve Software Steam Controller: Applying InputClass "system-keyboard"
[  7843.023] (II) Using input driver 'libinput' for 'Valve Software Steam Controller'
[  7843.024] (II) systemd-logind: got fd for /dev/input/event19 13:83 fd 36 paused 0
[  7843.024] (**) Valve Software Steam Controller: always reports core events
[  7843.024] (**) Option "Device" "/dev/input/event19"
[  7843.024] (**) Option "_source" "server/udev"
[  7843.025] (II) event19 - Valve Software Steam Controller: is tagged by udev as: Keyboard Mouse
[  7843.025] (II) event19 - Valve Software Steam Controller: device is a pointer
[  7843.025] (II) event19 - Valve Software Steam Controller: device is a keyboard
[  7843.025] (II) event19 - Valve Software Steam Controller: device removed
[  7843.025] (II) libinput: Valve Software Steam Controller: needs a virtual subdevice
[  7843.025] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:14.0/usb2/2-10/2-10:1.0/0003:28DE:1142.0001/input/input29/event19"
[  7843.025] (II) XINPUT: Adding extended input device "Valve Software Steam Controller" (type: MOUSE, id 8)
[  7843.025] (**) Option "AccelerationScheme" "none"
[  7843.025] (**) Valve Software Steam Controller: (accel) selected scheme none/0
[  7843.025] (**) Valve Software Steam Controller: (accel) acceleration factor: 2.000
[  7843.025] (**) Valve Software Steam Controller: (accel) acceleration threshold: 4
[  7843.027] (II) event19 - Valve Software Steam Controller: is tagged by udev as: Keyboard Mouse
[  7843.027] (II) event19 - Valve Software Steam Controller: device is a pointer
[  7843.027] (II) event19 - Valve Software Steam Controller: device is a keyboard
[  7843.027] (II) config/udev: Adding input device Valve Software Steam Controller (/dev/input/mouse0)
[  7843.027] (**) Valve Software Steam Controller: Applying InputClass "system-keyboard"
[  7843.027] (II) No input driver specified, ignoring this device.
[  7843.027] (II) This device may have been added with another device file.
[  7843.028] (II) config/udev: Adding input device Logitech Logitech Gaming Keyboard (/dev/input/event22)
[  7843.028] (**) Logitech Logitech Gaming Keyboard: Applying InputClass "libinput keyboard catchall"
[  7843.028] (**) Logitech Logitech Gaming Keyboard: Applying InputClass "system-keyboard"
[  7843.028] (II) Using input driver 'libinput' for 'Logitech Logitech Gaming Keyboard'
[  7843.028] (II) systemd-logind: got fd for /dev/input/event22 13:86 fd 37 paused 0
[  7843.028] (**) Logitech Logitech Gaming Keyboard: always reports core events
[  7843.028] (**) Option "Device" "/dev/input/event22"
[  7843.028] (**) Option "_source" "server/udev"
[  7843.029] (II) event22 - Logitech Logitech Gaming Keyboard: is tagged by udev as: Keyboard
[  7843.029] (II) event22 - Logitech Logitech Gaming Keyboard: device is a keyboard
[  7843.029] (II) event22 - Logitech Logitech Gaming Keyboard: device removed
[  7843.029] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:14.0/usb2/2-13/2-13.1/2-13.1:1.0/0003:046D:C221.0008/input/input26/event22"
[  7843.029] (II) XINPUT: Adding extended input device "Logitech Logitech Gaming Keyboard" (type: KEYBOARD, id 9)
[  7843.030] (**) Option "xkb_model" "fr-latin1"
[  7843.030] (**) Option "xkb_layout" "fr"
[  7843.030] (II) event22 - Logitech Logitech Gaming Keyboard: is tagged by udev as: Keyboard
[  7843.030] (II) event22 - Logitech Logitech Gaming Keyboard: device is a keyboard
[  7843.031] (II) config/udev: Adding input device Logitech Logitech Gaming Keyboard Consumer Control (/dev/input/event18)
[  7843.031] (**) Logitech Logitech Gaming Keyboard Consumer Control: Applying InputClass "libinput keyboard catchall"
[  7843.031] (**) Logitech Logitech Gaming Keyboard Consumer Control: Applying InputClass "system-keyboard"
[  7843.031] (II) Using input driver 'libinput' for 'Logitech Logitech Gaming Keyboard Consumer Control'
[  7843.032] (II) systemd-logind: got fd for /dev/input/event18 13:82 fd 38 paused 0
[  7843.032] (**) Logitech Logitech Gaming Keyboard Consumer Control: always reports core events
[  7843.032] (**) Option "Device" "/dev/input/event18"
[  7843.032] (**) Option "_source" "server/udev"
[  7843.032] (II) event18 - Logitech Logitech Gaming Keyboard Consumer Control: is tagged by udev as: Keyboard
[  7843.032] (II) event18 - Logitech Logitech Gaming Keyboard Consumer Control: device is a keyboard
[  7843.033] (II) event18 - Logitech Logitech Gaming Keyboard Consumer Control: device removed
[  7843.033] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:14.0/usb2/2-13/2-13.1/2-13.1:1.1/0003:046D:C221.0009/input/input27/event18"
[  7843.033] (II) XINPUT: Adding extended input device "Logitech Logitech Gaming Keyboard Consumer Control" (type: KEYBOARD, id 10)
[  7843.033] (**) Option "xkb_model" "fr-latin1"
[  7843.033] (**) Option "xkb_layout" "fr"
[  7843.034] (II) event18 - Logitech Logitech Gaming Keyboard Consumer Control: is tagged by udev as: Keyboard
[  7843.034] (II) event18 - Logitech Logitech Gaming Keyboard Consumer Control: device is a keyboard
[  7843.034] (II) config/udev: Adding input device Logitech Gaming Keyboard Gaming Keys (/dev/input/event25)
[  7843.034] (**) Logitech Gaming Keyboard Gaming Keys: Applying InputClass "libinput keyboard catchall"
[  7843.034] (**) Logitech Gaming Keyboard Gaming Keys: Applying InputClass "system-keyboard"
[  7843.034] (II) Using input driver 'libinput' for 'Logitech Gaming Keyboard Gaming Keys'
[  7843.088] (II) systemd-logind: got fd for /dev/input/event25 13:89 fd 39 paused 0
[  7843.088] (**) Logitech Gaming Keyboard Gaming Keys: always reports core events
[  7843.088] (**) Option "Device" "/dev/input/event25"
[  7843.088] (**) Option "_source" "server/udev"
[  7843.091] (II) event25 - Logitech Gaming Keyboard Gaming Keys: is tagged by udev as: Keyboard
[  7843.091] (II) event25 - Logitech Gaming Keyboard Gaming Keys: device is a keyboard
[  7843.091] (II) event25 - Logitech Gaming Keyboard Gaming Keys: device removed
[  7843.091] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:14.0/usb2/2-13/2-13.4/2-13.4:1.0/0003:046D:C222.000E/input/input32/event25"
[  7843.091] (II) XINPUT: Adding extended input device "Logitech Gaming Keyboard Gaming Keys" (type: KEYBOARD, id 11)
[  7843.091] (**) Option "xkb_model" "fr-latin1"
[  7843.091] (**) Option "xkb_layout" "fr"
[  7843.094] (II) event25 - Logitech Gaming Keyboard Gaming Keys: is tagged by udev as: Keyboard
[  7843.094] (II) event25 - Logitech Gaming Keyboard Gaming Keys: device is a keyboard
[  7843.095] (II) config/udev: Adding input device Logitech Gaming Mouse G502 (/dev/input/event20)
[  7843.095] (**) Logitech Gaming Mouse G502: Applying InputClass "libinput pointer catchall"
[  7843.095] (II) Using input driver 'libinput' for 'Logitech Gaming Mouse G502'
[  7843.152] (II) systemd-logind: got fd for /dev/input/event20 13:84 fd 40 paused 0
[  7843.152] (**) Logitech Gaming Mouse G502: always reports core events
[  7843.152] (**) Option "Device" "/dev/input/event20"
[  7843.152] (**) Option "_source" "server/udev"
[  7843.154] (II) event20 - Logitech Gaming Mouse G502: is tagged by udev as: Mouse
[  7843.155] (II) event20 - Logitech Gaming Mouse G502: device set to 2400 DPI
[  7843.155] (II) event20 - Logitech Gaming Mouse G502: device is a pointer
[  7843.155] (II) event20 - Logitech Gaming Mouse G502: device removed
[  7843.155] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:14.0/usb2/2-14/2-14:1.0/0003:046D:C332.0006/input/input20/event20"
[  7843.155] (II) XINPUT: Adding extended input device "Logitech Gaming Mouse G502" (type: MOUSE, id 12)
[  7843.155] (**) Option "AccelerationScheme" "none"
[  7843.155] (**) Logitech Gaming Mouse G502: (accel) selected scheme none/0
[  7843.155] (**) Logitech Gaming Mouse G502: (accel) acceleration factor: 2.000
[  7843.155] (**) Logitech Gaming Mouse G502: (accel) acceleration threshold: 4
[  7843.158] (II) event20 - Logitech Gaming Mouse G502: is tagged by udev as: Mouse
[  7843.158] (II) event20 - Logitech Gaming Mouse G502: device set to 2400 DPI
[  7843.158] (II) event20 - Logitech Gaming Mouse G502: device is a pointer
[  7843.160] (II) config/udev: Adding input device Logitech Gaming Mouse G502 (/dev/input/mouse1)
[  7843.160] (II) No input driver specified, ignoring this device.
[  7843.160] (II) This device may have been added with another device file.
[  7843.161] (II) config/udev: Adding input device Logitech Gaming Mouse G502 Keyboard (/dev/input/event21)
[  7843.161] (**) Logitech Gaming Mouse G502 Keyboard: Applying InputClass "libinput keyboard catchall"
[  7843.161] (**) Logitech Gaming Mouse G502 Keyboard: Applying InputClass "system-keyboard"
[  7843.161] (II) Using input driver 'libinput' for 'Logitech Gaming Mouse G502 Keyboard'
[  7843.163] (II) systemd-logind: got fd for /dev/input/event21 13:85 fd 41 paused 0
[  7843.163] (**) Logitech Gaming Mouse G502 Keyboard: always reports core events
[  7843.163] (**) Option "Device" "/dev/input/event21"
[  7843.163] (**) Option "_source" "server/udev"
[  7843.164] (II) event21 - Logitech Gaming Mouse G502 Keyboard: is tagged by udev as: Keyboard
[  7843.164] (II) event21 - Logitech Gaming Mouse G502 Keyboard: device is a keyboard
[  7843.164] (II) event21 - Logitech Gaming Mouse G502 Keyboard: device removed
[  7843.164] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:14.0/usb2/2-14/2-14:1.1/0003:046D:C332.0007/input/input21/event21"
[  7843.164] (II) XINPUT: Adding extended input device "Logitech Gaming Mouse G502 Keyboard" (type: KEYBOARD, id 13)
[  7843.164] (**) Option "xkb_model" "fr-latin1"
[  7843.164] (**) Option "xkb_layout" "fr"
[  7843.165] (II) event21 - Logitech Gaming Mouse G502 Keyboard: is tagged by udev as: Keyboard
[  7843.165] (II) event21 - Logitech Gaming Mouse G502 Keyboard: device is a keyboard
[  7843.165] (II) config/udev: Adding input device Logitech Gaming Mouse G502 Consumer Control (/dev/input/event23)
[  7843.165] (**) Logitech Gaming Mouse G502 Consumer Control: Applying InputClass "libinput keyboard catchall"
[  7843.165] (**) Logitech Gaming Mouse G502 Consumer Control: Applying InputClass "system-keyboard"
[  7843.165] (II) Using input driver 'libinput' for 'Logitech Gaming Mouse G502 Consumer Control'
[  7843.166] (II) systemd-logind: got fd for /dev/input/event23 13:87 fd 42 paused 0
[  7843.166] (**) Logitech Gaming Mouse G502 Consumer Control: always reports core events
[  7843.166] (**) Option "Device" "/dev/input/event23"
[  7843.166] (**) Option "_source" "server/udev"
[  7843.167] (II) event23 - Logitech Gaming Mouse G502 Consumer Control: is tagged by udev as: Keyboard
[  7843.167] (II) event23 - Logitech Gaming Mouse G502 Consumer Control: device is a keyboard
[  7843.167] (II) event23 - Logitech Gaming Mouse G502 Consumer Control: device removed
[  7843.167] (II) libinput: Logitech Gaming Mouse G502 Consumer Control: needs a virtual subdevice
[  7843.167] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:14.0/usb2/2-14/2-14:1.1/0003:046D:C332.0007/input/input22/event23"
[  7843.167] (II) XINPUT: Adding extended input device "Logitech Gaming Mouse G502 Consumer Control" (type: MOUSE, id 14)
[  7843.167] (**) Option "AccelerationScheme" "none"
[  7843.167] (**) Logitech Gaming Mouse G502 Consumer Control: (accel) selected scheme none/0
[  7843.167] (**) Logitech Gaming Mouse G502 Consumer Control: (accel) acceleration factor: 2.000
[  7843.167] (**) Logitech Gaming Mouse G502 Consumer Control: (accel) acceleration threshold: 4
[  7843.168] (II) event23 - Logitech Gaming Mouse G502 Consumer Control: is tagged by udev as: Keyboard
[  7843.168] (II) event23 - Logitech Gaming Mouse G502 Consumer Control: device is a keyboard
[  7843.168] (II) config/udev: Adding input device Logitech Gaming Mouse G502 System Control (/dev/input/event24)
[  7843.168] (**) Logitech Gaming Mouse G502 System Control: Applying InputClass "libinput keyboard catchall"
[  7843.168] (**) Logitech Gaming Mouse G502 System Control: Applying InputClass "system-keyboard"
[  7843.168] (II) Using input driver 'libinput' for 'Logitech Gaming Mouse G502 System Control'
[  7843.169] (II) systemd-logind: got fd for /dev/input/event24 13:88 fd 43 paused 0
[  7843.169] (**) Logitech Gaming Mouse G502 System Control: always reports core events
[  7843.169] (**) Option "Device" "/dev/input/event24"
[  7843.169] (**) Option "_source" "server/udev"
[  7843.170] (II) event24 - Logitech Gaming Mouse G502 System Control: is tagged by udev as: Keyboard
[  7843.170] (II) event24 - Logitech Gaming Mouse G502 System Control: device is a keyboard
[  7843.170] (II) event24 - Logitech Gaming Mouse G502 System Control: device removed
[  7843.170] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:14.0/usb2/2-14/2-14:1.1/0003:046D:C332.0007/input/input23/event24"
[  7843.170] (II) XINPUT: Adding extended input device "Logitech Gaming Mouse G502 System Control" (type: KEYBOARD, id 15)
[  7843.170] (**) Option "xkb_model" "fr-latin1"
[  7843.170] (**) Option "xkb_layout" "fr"
[  7843.171] (II) event24 - Logitech Gaming Mouse G502 System Control: is tagged by udev as: Keyboard
[  7843.171] (II) event24 - Logitech Gaming Mouse G502 System Control: device is a keyboard
[  7843.171] (II) config/udev: Adding input device HDA Intel PCH Front Mic (/dev/input/event11)
[  7843.171] (II) No input driver specified, ignoring this device.
[  7843.171] (II) This device may have been added with another device file.
[  7843.171] (II) config/udev: Adding input device HDA Intel PCH Rear Mic (/dev/input/event12)
[  7843.171] (II) config/udev: Adding input device HDA Intel PCH Line (/dev/input/event13)
[  7843.171] (II) config/udev: Adding input device HDA Intel PCH Line Out Front (/dev/input/event14)
[  7843.172] (II) config/udev: Adding input device HDA Intel PCH Line Out Surround (/dev/input/event15)
[  7843.172] (II) No input driver specified, ignoring this device.
[  7843.172] (II) This device may have been added with another device file.
[  7843.172] (II) config/udev: Adding input device HDA Intel PCH Line Out CLFE (/dev/input/event16)
[  7843.172] (II) config/udev: Adding input device HDA Intel PCH Front Headphone (/dev/input/event17)
[  7843.172] (II) config/udev: Adding input device Eee PC WMI hotkeys (/dev/input/event3)
[  7843.172] (**) Eee PC WMI hotkeys: Applying InputClass "libinput keyboard catchall"
[  7843.172] (**) Eee PC WMI hotkeys: Applying InputClass "system-keyboard"
[  7843.172] (II) Using input driver 'libinput' for 'Eee PC WMI hotkeys'
[  7843.173] (II) systemd-logind: got fd for /dev/input/event3 13:67 fd 44 paused 0
[  7843.173] (**) Eee PC WMI hotkeys: always reports core events
[  7843.173] (**) Option "Device" "/dev/input/event3"
[  7843.173] (**) Option "_source" "server/udev"
[  7843.173] (II) event3  - Eee PC WMI hotkeys: is tagged by udev as: Keyboard
[  7843.173] (II) event3  - Eee PC WMI hotkeys: device is a keyboard
[  7843.173] (II) event3  - Eee PC WMI hotkeys: device removed
[  7843.173] (**) Option "config_info" "udev:/sys/devices/platform/eeepc-wmi/input/input3/event3"
[  7843.173] (II) XINPUT: Adding extended input device "Eee PC WMI hotkeys" (type: KEYBOARD, id 16)
[  7843.173] (**) Option "xkb_model" "fr-latin1"
[  7843.173] (**) Option "xkb_layout" "fr"
[  7843.174] (II) event3  - Eee PC WMI hotkeys: is tagged by udev as: Keyboard
[  7843.174] (II) event3  - Eee PC WMI hotkeys: device is a keyboard
[  7843.174] (II) config/udev: Adding input device PC Speaker (/dev/input/event2)
[  7843.174] (II) No input driver specified, ignoring this device.
[  7843.174] (II) This device may have been added with another device file.
[  7843.177] (**) Valve Software Steam Controller: Applying InputClass "libinput pointer catchall"
[  7843.177] (**) Valve Software Steam Controller: Applying InputClass "libinput keyboard catchall"
[  7843.177] (**) Valve Software Steam Controller: Applying InputClass "system-keyboard"
[  7843.177] (II) Using input driver 'libinput' for 'Valve Software Steam Controller'
[  7843.177] (II) systemd-logind: returning pre-existing fd for /dev/input/event19 13:83
[  7843.177] (**) Valve Software Steam Controller: always reports core events
[  7843.177] (**) Option "Device" "/dev/input/event19"
[  7843.177] (**) Option "_source" "_driver/libinput"
[  7843.177] (II) libinput: Valve Software Steam Controller: is a virtual subdevice
[  7843.177] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:14.0/usb2/2-10/2-10:1.0/0003:28DE:1142.0001/input/input29/event19"
[  7843.177] (II) XINPUT: Adding extended input device "Valve Software Steam Controller" (type: KEYBOARD, id 17)
[  7843.177] (**) Option "xkb_model" "fr-latin1"
[  7843.177] (**) Option "xkb_layout" "fr"
[  7843.177] (**) Logitech Gaming Mouse G502 Consumer Control: Applying InputClass "libinput keyboard catchall"
[  7843.177] (**) Logitech Gaming Mouse G502 Consumer Control: Applying InputClass "system-keyboard"
[  7843.177] (II) Using input driver 'libinput' for 'Logitech Gaming Mouse G502 Consumer Control'
[  7843.177] (II) systemd-logind: returning pre-existing fd for /dev/input/event23 13:87
[  7843.177] (**) Logitech Gaming Mouse G502 Consumer Control: always reports core events
[  7843.177] (**) Option "Device" "/dev/input/event23"
[  7843.177] (II) libinput: Logitech Gaming Mouse G502 Consumer Control: is a virtual subdevice
[  7843.177] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:14.0/usb2/2-14/2-14:1.1/0003:046D:C332.0007/input/input22/event23"
[  7843.177] (II) XINPUT: Adding extended input device "Logitech Gaming Mouse G502 Consumer Control" (type: KEYBOARD, id 18)
[  7843.178] (--) NVIDIA(GPU-0): HPN HP ENVY 27s (DFP-2): connected
[  7843.178] (--) NVIDIA(GPU-0): HPN HP ENVY 27s (DFP-2): Internal DisplayPort
[  7843.178] (--) NVIDIA(GPU-0): HPN HP ENVY 27s (DFP-2): 960.0 MHz maximum pixel clock
[  7853.089] (--) NVIDIA(GPU-0): CRT-0: disconnected
[  7853.089] (--) NVIDIA(GPU-0): CRT-0: 400.0 MHz maximum pixel clock
[  7853.093] (--) NVIDIA(GPU-0): DFP-0: disconnected
[  7853.093] (--) NVIDIA(GPU-0): DFP-0: Internal TMDS
[  7853.093] (--) NVIDIA(GPU-0): DFP-0: 330.0 MHz maximum pixel clock
[  7853.093] (--) NVIDIA(GPU-0): DFP-1: disconnected
[  7853.093] (--) NVIDIA(GPU-0): DFP-1: Internal TMDS
[  7853.093] (--) NVIDIA(GPU-0): DFP-1: 165.0 MHz maximum pixel clock
[  7853.093] (--) NVIDIA(GPU-0): HPN HP ENVY 27s (DFP-2): connected
[  7853.093] (--) NVIDIA(GPU-0): HPN HP ENVY 27s (DFP-2): Internal DisplayPort
[  7853.093] (--) NVIDIA(GPU-0): HPN HP ENVY 27s (DFP-2): 960.0 MHz maximum pixel clock
[  7853.094] (--) NVIDIA(GPU-0): DFP-3: disconnected
[  7853.094] (--) NVIDIA(GPU-0): DFP-3: Internal TMDS
[  7853.094] (--) NVIDIA(GPU-0): DFP-3: 165.0 MHz maximum pixel clock
[  7853.094] (--) NVIDIA(GPU-0): DFP-4: disconnected
[  7853.094] (--) NVIDIA(GPU-0): DFP-4: Internal TMDS
[  7853.094] (--) NVIDIA(GPU-0): DFP-4: 330.0 MHz maximum pixel clock
[  7854.239] (--) NVIDIA(GPU-0): CRT-0: disconnected
[  7854.239] (--) NVIDIA(GPU-0): CRT-0: 400.0 MHz maximum pixel clock
[  7854.243] (--) NVIDIA(GPU-0): DFP-0: disconnected
[  7854.243] (--) NVIDIA(GPU-0): DFP-0: Internal TMDS
[  7854.243] (--) NVIDIA(GPU-0): DFP-0: 330.0 MHz maximum pixel clock
[  7854.243] (--) NVIDIA(GPU-0): DFP-1: disconnected
[  7854.243] (--) NVIDIA(GPU-0): DFP-1: Internal TMDS
[  7854.243] (--) NVIDIA(GPU-0): DFP-1: 165.0 MHz maximum pixel clock
[  7854.244] (--) NVIDIA(GPU-0): HPN HP ENVY 27s (DFP-2): connected
[  7854.244] (--) NVIDIA(GPU-0): HPN HP ENVY 27s (DFP-2): Internal DisplayPort
[  7854.244] (--) NVIDIA(GPU-0): HPN HP ENVY 27s (DFP-2): 960.0 MHz maximum pixel clock
[  7854.245] (--) NVIDIA(GPU-0): DFP-3: disconnected
[  7854.245] (--) NVIDIA(GPU-0): DFP-3: Internal TMDS
[  7854.245] (--) NVIDIA(GPU-0): DFP-3: 165.0 MHz maximum pixel clock
[  7854.245] (--) NVIDIA(GPU-0): DFP-4: disconnected
[  7854.245] (--) NVIDIA(GPU-0): DFP-4: Internal TMDS
[  7854.245] (--) NVIDIA(GPU-0): DFP-4: 330.0 MHz maximum pixel clock
[  8023.677] (--) NVIDIA(GPU-0): CRT-0: disconnected
[  8023.677] (--) NVIDIA(GPU-0): CRT-0: 400.0 MHz maximum pixel clock
[  8023.681] (--) NVIDIA(GPU-0): DFP-0: disconnected
[  8023.681] (--) NVIDIA(GPU-0): DFP-0: Internal TMDS
[  8023.682] (--) NVIDIA(GPU-0): DFP-0: 330.0 MHz maximum pixel clock
[  8023.682] (--) NVIDIA(GPU-0): DFP-1: disconnected
[  8023.682] (--) NVIDIA(GPU-0): DFP-1: Internal TMDS
[  8023.682] (--) NVIDIA(GPU-0): DFP-1: 165.0 MHz maximum pixel clock
[  8023.682] (--) NVIDIA(GPU-0): HPN HP ENVY 27s (DFP-2): connected
[  8023.682] (--) NVIDIA(GPU-0): HPN HP ENVY 27s (DFP-2): Internal DisplayPort
[  8023.682] (--) NVIDIA(GPU-0): HPN HP ENVY 27s (DFP-2): 960.0 MHz maximum pixel clock
[  8023.683] (--) NVIDIA(GPU-0): DFP-3: disconnected
[  8023.683] (--) NVIDIA(GPU-0): DFP-3: Internal TMDS
[  8023.683] (--) NVIDIA(GPU-0): DFP-3: 165.0 MHz maximum pixel clock
[  8023.683] (--) NVIDIA(GPU-0): DFP-4: disconnected
[  8023.683] (--) NVIDIA(GPU-0): DFP-4: Internal TMDS
[  8023.683] (--) NVIDIA(GPU-0): DFP-4: 330.0 MHz maximum pixel clock
[  8466.341] (**) Option "fd" "32"
[  8466.341] (II) event1  - Power Button: device removed
[  8466.341] (**) Option "fd" "35"
[  8466.341] (II) event0  - Power Button: device removed
[  8466.341] (**) Option "fd" "36"
[  8466.341] (**) Option "fd" "37"
[  8466.341] (II) event22 - Logitech Logitech Gaming Keyboard: device removed
[  8466.341] (**) Option "fd" "38"
[  8466.341] (II) event18 - Logitech Logitech Gaming Keyboard Consumer Control: device removed
[  8466.341] (**) Option "fd" "39"
[  8466.341] (II) event25 - Logitech Gaming Keyboard Gaming Keys: device removed
[  8466.341] (**) Option "fd" "40"
[  8466.341] (II) event20 - Logitech Gaming Mouse G502: device removed
[  8466.341] (**) Option "fd" "41"
[  8466.341] (II) event21 - Logitech Gaming Mouse G502 Keyboard: device removed
[  8466.341] (**) Option "fd" "42"
[  8466.342] (**) Option "fd" "43"
[  8466.342] (II) event24 - Logitech Gaming Mouse G502 System Control: device removed
[  8466.342] (**) Option "fd" "44"
[  8466.342] (II) event3  - Eee PC WMI hotkeys: device removed
[  8466.342] (**) Option "fd" "36"
[  8466.342] (II) event19 - Valve Software Steam Controller: device removed
[  8466.343] (**) Option "fd" "42"
[  8466.343] (II) event23 - Logitech Gaming Mouse G502 Consumer Control: device removed
[  8466.343] (II) UnloadModule: "libinput"
[  8466.343] (II) systemd-logind: not releasing fd for 13:87, still in use
[  8466.343] (II) systemd-logind: not releasing fd for 13:83, still in use
[  8466.344] (II) UnloadModule: "libinput"
[  8466.344] (II) systemd-logind: releasing fd for 13:67
[  8466.367] (II) UnloadModule: "libinput"
[  8466.367] (II) systemd-logind: releasing fd for 13:88
[  8466.391] (II) UnloadModule: "libinput"
[  8466.391] (II) systemd-logind: releasing fd for 13:87
[  8466.421] (II) UnloadModule: "libinput"
[  8466.421] (II) systemd-logind: releasing fd for 13:85
[  8466.455] (II) UnloadModule: "libinput"
[  8466.455] (II) systemd-logind: releasing fd for 13:84
[  8466.505] (II) UnloadModule: "libinput"
[  8466.505] (II) systemd-logind: releasing fd for 13:89
[  8466.541] (II) UnloadModule: "libinput"
[  8466.541] (II) systemd-logind: releasing fd for 13:82
[  8466.571] (II) UnloadModule: "libinput"
[  8466.571] (II) systemd-logind: releasing fd for 13:86
[  8466.584] (II) UnloadModule: "libinput"
[  8466.585] (II) systemd-logind: releasing fd for 13:83
[  8466.626] (II) UnloadModule: "libinput"
[  8466.626] (II) systemd-logind: releasing fd for 13:64
[  8466.648] (II) UnloadModule: "libinput"
[  8466.648] (II) systemd-logind: releasing fd for 13:65
[  8466.817] (II) NVIDIA(GPU-0): Deleting GPU-0
[  8466.819] (II) Server terminated successfully (0). Closing log file.
*** /home/user/.nvidia-settings-rc
*** ls: -rw-r--r-- 1 user user 2385 2020-07-02 11:08:52.783752535 +0200 /home/user/.nvidia-settings-rc
# /home/user/.nvidia-settings-rc
# Configuration file for nvidia-settings - the NVIDIA X Server Settings utility
# Generated on Thu Jul  2 11:08:52 2020
# ConfigProperties:
RcFileLocale = C
DisplayStatusBar = Yes
SliderTextEntries = Yes
IncludeDisplayNameInConfigFile = No
ShowQuitDialog = Yes
UpdateRulesOnProfileNameChange = Yes
Timer = Memory_Used_(GPU_0),Yes,3000
Timer = Thermal_Monitor_(GPU_0),Yes,1000
Timer = PowerMizer_Monitor_(GPU_0),Yes,1000
# Attributes:
0/SyncToVBlank=1
0/LogAniso=0
0/FSAA=0
0/TextureClamping=1
0/FXAA=0
0/AllowFlipping=1
0/FSAAAppControlled=1
0/LogAnisoAppControlled=1
0/OpenGLImageSettings=0
0/FSAAAppEnhanced=0
0/ShowGraphicsVisualIndicator=0
0/XVideoSyncToDisplayID=HDMI-0
[DPY:DVI-I-0]/Dithering=0
[DPY:DVI-I-0]/DitheringMode=0
[DPY:DVI-I-0]/DitheringDepth=0
[DPY:DVI-I-0]/SynchronousPaletteUpdates=0
[DPY:DVI-I-1]/Dithering=0
[DPY:DVI-I-1]/DitheringMode=0
[DPY:DVI-I-1]/DitheringDepth=0
[DPY:DVI-I-1]/ColorSpace=0
[DPY:DVI-I-1]/ColorRange=0
[DPY:DVI-I-1]/SynchronousPaletteUpdates=0
[DPY:HDMI-0]/RedBrightness=0.000000
[DPY:HDMI-0]/GreenBrightness=0.000000
[DPY:HDMI-0]/BlueBrightness=0.000000
[DPY:HDMI-0]/RedContrast=0.000000
[DPY:HDMI-0]/GreenContrast=0.000000
[DPY:HDMI-0]/BlueContrast=0.000000
[DPY:HDMI-0]/RedGamma=1.000000
[DPY:HDMI-0]/GreenGamma=1.000000
[DPY:HDMI-0]/BlueGamma=1.000000
[DPY:HDMI-0]/Dithering=0
[DPY:HDMI-0]/DitheringMode=0
[DPY:HDMI-0]/DitheringDepth=0
[DPY:HDMI-0]/DigitalVibrance=0
[DPY:HDMI-0]/ColorSpace=0
[DPY:HDMI-0]/ColorRange=0
[DPY:HDMI-0]/SynchronousPaletteUpdates=0
[DPY:DP-0]/RedBrightness=0.000000
[DPY:DP-0]/GreenBrightness=0.000000
[DPY:DP-0]/BlueBrightness=0.000000
[DPY:DP-0]/RedContrast=0.000000
[DPY:DP-0]/GreenContrast=0.000000
[DPY:DP-0]/BlueContrast=0.000000
[DPY:DP-0]/RedGamma=1.000000
[DPY:DP-0]/GreenGamma=1.000000
[DPY:DP-0]/BlueGamma=1.000000
[DPY:DP-0]/Dithering=0
[DPY:DP-0]/DitheringMode=0
[DPY:DP-0]/DitheringDepth=0
[DPY:DP-0]/DigitalVibrance=0
[DPY:DP-0]/ColorSpace=0
[DPY:DP-0]/ColorRange=0
[DPY:DP-0]/SynchronousPaletteUpdates=0
[DPY:DP-1]/Dithering=0
[DPY:DP-1]/DitheringMode=0
[DPY:DP-1]/DitheringDepth=0
[DPY:DP-1]/ColorSpace=0
[DPY:DP-1]/ColorRange=0
[DPY:DP-1]/SynchronousPaletteUpdates=0
[DPY:DVI-D-0]/Dithering=0
[DPY:DVI-D-0]/DitheringMode=0
[DPY:DVI-D-0]/DitheringDepth=0
[DPY:DVI-D-0]/ColorSpace=0
[DPY:DVI-D-0]/ColorRange=0
[DPY:DVI-D-0]/SynchronousPaletteUpdates=0
*** /root/.nvidia-settings-rc
*** ls: -rw-r--r-- 1 root root 2056 2020-04-29 17:18:58.755752730 +0200 /root/.nvidia-settings-rc
# /root/.nvidia-settings-rc
# Generated on Wed Apr 29 17:18:58 2020
# ConfigProperties:
RcFileLocale = C
# Attributes:
0/SyncToVBlank=0
0/LogAniso=0
0/FSAA=0
0/TextureClamping=1
0/FXAA=0
0/AllowFlipping=1
0/FSAAAppEnhanced=0
0/ShowGraphicsVisualIndicator=1
0/XVideoSyncToDisplayID=DP-0
*** /usr/share/nvidia/nvidia-application-profiles-450.57-rc
*** ls: -rw-r--r-- 1 root root 7737 2020-07-09 18:06:25.000000000 +0200 /usr/share/nvidia/nvidia-application-profiles-450.57-rc
# Application profiles for the NVIDIA Linux graphics driver, version 450.57
# Last modified: Sun Jul  5 14:51:40 UTC 2020
# These profiles were provided by NVIDIA and should not be modified.  If you
# wish to change the defaults provided here, you can override them by creating
# custom rules in /etc/nvidia/nvidia-application-profiles-rc (which will apply
# system-wide) or, for a given user, $HOME/.nv/nvidia-application-profiles-rc
# (which will apply to that particular user). See the "APPLICATION PROFILE
# SEARCH PATH" section of the NVIDIA Linux Graphics Driver README for more
# information.
   "profiles" : [
         "name" : "NonConformantBlitFramebufferScissor",
         "settings" : [ "GLConformantBlitFramebufferScissor", false ]
         "name" : "CL1C",
         "settings" : [ "0x528ab3", 1 ]
         "name" : "FA0",
         "settings" : [ "10572898", 0 ]
         "name" : "ExactGLESVersion",
         "settings" : [ "ForceRequestedESVersion", 1 ]
         "name" : "IgnoreGLSLExtensionRequirements",
         "settings" : [ "GLIgnoreGLSLExtReqs", true ]
         "name" : "No VRR/OSD",
         "settings" : [
             "key" : "GLVRRAllowed",
             "value" : false
             "key" : "VKDirectGSYNCAllowed",
             "value" : false
             "key" : "VKDirectGSYNCCompatibleAllowed",
             "value" : 0
             "key" : "GLShowGraphicsOSD",
             "value" : false
         "name" : "UseThreadedOptimizations",
         "settings" : [ "GLThreadedOptimizations", true ]
         "name" : "NoThreadedOptimizations",
         "settings" : [ "GLThreadedOptimizations", false ]
         "name" : "NoAniso",
         "settings" : [ "GLLogMaxAniso", 0 ]
         "name" : "NamedVertexAttributesApplyDivisor",
         "settings" : [ "GL23cd0e", 1 ]
       "name" : "NonStrictDrawRangeElements",
       "settings" : [ "GLStrictDrawRangeElements", false ]
         "name" : "usernforceShaderInputOutputMatching",
         "settings" : [ "GLShaderPortabilityWarnings", false ]
         "name" : "HideVendorID",
         "settings" : [ "OVERRIDE_VENDORID", 4098 ]
         "name" : "DisablePersampleFragcoord",
         "settings" : [ "DisablePersampleFragcoord", true ]
           "name" : "IdleQueueOnSwapchainOOD",
           "settings" : [ "IdleQueueOnSwapchainOOD", true ]
   "rules" : [
         "pattern" : {
            "feature" : "dso",
            "matches" : "libcogl.so"
         "profile" : "NonConformantBlitFramebufferScissor"
         "pattern" : {
           "feature" : "dso",
           "matches" : "libMaya.so"
         "profile" : "CL1C"
         "pattern" : {
           "feature" : "dso",
         "profile" : "NamedVertexAttributesApplyDivisor"
       { "pattern" : "SkullGirls.x86_64-pc-linux-gnu", "profile" : "NoAniso" },
       { "pattern" : "SkullGirls.i686-pc-linux-gnu", "profile" : "NoAniso" },
       { "pattern" : "Indivisible_Linux.i686-pc-linux-gnu", "profile" : "NoAniso" },
       { "pattern" : "xsi", "profile" : "CL1C" },
       { "pattern" : "HoudiniFX", "profile" : "CL1C" },
       { "pattern" : "katana", "profile" : "CL1C" },
       { "pattern" : "Autodesk Mudbox 2014 64-bit", "profile" : "CL1C" },
       { "pattern" : "octane", "profile" : "CL1C" },
       { "pattern" : "Fusion64_6.4", "profile" : "CL1C" },
       { "pattern" : "Nuke7.0", "profile" : "CL1C" },
       { "pattern" : "vray.exe", "profile" : "CL1C" },
       { "pattern" : "vray.bin", "profile" : "CL1C" },
       { "pattern" : "kwin_gles", "profile" : "FA0" },
       { "pattern" : "kwin_gles", "profile" : "ExactGLESVersion" },
          "pattern" : [
           { "feature" : "procname", "matches" : "heaven_x86"},
           { "op" : "not", "sub" : { "feature" : "findfile", "matches" : "browser_x86" } }
          "profile" : "IgnoreGLSLExtensionRequirements"
          "pattern" : [
           { "feature" : "procname", "matches" : "heaven_x64"},
           { "op" : "not", "sub" : { "feature" : "findfile", "matches" : "browser_x64" } }
       { "pattern" : { "feature" : "procname", "matches" : "cinnamon" }, "profile" : "No VRR/OSD" },
       { "pattern" : { "feature" : "procname", "matches" : "compiz" }, "profile" : "No VRR/OSD" },
       { "pattern" : { "feature" : "procname", "matches" : "compton" }, "profile" : "No VRR/OSD" },
       { "pattern" : { "feature" : "procname", "matches" : "enlightenment" }, "profile" : "No VRR/OSD" },
       { "pattern" : { "feature" : "procname", "matches" : "gnome-shell" }, "profile" : "No VRR/OSD" },
       { "pattern" : { "feature" : "procname", "matches" : "kscreenlocker_greet" }, "profile" : "No VRR/OSD" },
       { "pattern" : { "feature" : "procname", "matches" : "kwin" }, "profile" : "No VRR/OSD" },
       { "pattern" : { "feature" : "procname", "matches" : "kwin_x11" }, "profile" : "No VRR/OSD" },
       { "pattern" : { "feature" : "procname", "matches" : "plasmashell" }, "profile" : "No VRR/OSD" },
       { "pattern" : { "feature" : "procname", "matches" : "ksplashqml" }, "profile" : "No VRR/OSD" },
       { "pattern" : { "feature" : "procname", "matches" : "systemsettings5" }, "profile" : "No VRR/OSD" },
       { "pattern" : { "feature" : "procname", "matches" : "muffin" }, "profile" : "No VRR/OSD" },
       { "pattern" : { "feature" : "dso", "matches" : "libmutter" }, "profile" : "No VRR/OSD" },
       { "pattern" : { "feature" : "procname", "matches" : "steam" }, "profile" : "No VRR/OSD" },
       { "pattern" : { "feature" : "procname", "matches" : "steamcompmgr" }, "profile" : "No VRR/OSD" },
       { "pattern" : { "feature" : "procname", "matches" : "vrmonitor" }, "profile" : "No VRR/OSD" },
       { "pattern" : "GoatGame", "profile" : "NonStrictDrawRangeElements" },
       { "pattern" : "ShadowOfMordor", "profile" : "usernforceShaderInputOutputMatching" },
       { "pattern" : { "feature" : "commname", "matches" : "NMS.exe"} , "profile" : "HideVendorID" },
       { "pattern" : "shotcut", "profile" : "NoThreadedOptimizations" },
       { "pattern" : "MetroLL", "profile" : "NoThreadedOptimizations" },
       { "pattern" : "Borderlands2", "profile" : "UseThreadedOptimizations" },
       { "pattern" : "BorderlandsPreSequel", "profile" : "UseThreadedOptimizations" },
       { "pattern": "AlienIsolation", "profile" : "UseThreadedOptimizations" },
       { "pattern": "Civ6", "profile" : "UseThreadedOptimizations" },
       { "pattern": "CivBE", "profile" : "UseThreadedOptimizations" },
       { "pattern": "overlord.i386", "profile" : "UseThreadedOptimizations" },
       { "pattern": "X-Plane-x86_64", "profile" : "UseThreadedOptimizations" },
       { "pattern": "RocketLeague", "profile" : "UseThreadedOptimizations" },
       { "pattern": "DeusExMD", "profile" : "DisablePersampleFragcoord" },
       { "pattern": "Dirt4", "profile" : "IdleQueueOnSwapchainOOD" },
       { "pattern": "RiseOfTheTombRaider", "profile" : "IdleQueueOnSwapchainOOD" }
ldd /sbin/glxinfo
   linux-vdso.so.1 (0x00007ffc1f356000)
   libGL.so.1 => /usr/lib/libGL.so.1 (0x00007fca5fc61000)
   libX11.so.6 => /usr/lib/libX11.so.6 (0x00007fca5fb20000)
   libc.so.6 => /usr/lib/libc.so.6 (0x00007fca5f959000)
   libGLdispatch.so.0 => /usr/lib/libGLdispatch.so.0 (0x00007fca5f8a2000)
   libGLX.so.0 => /usr/lib/libGLX.so.0 (0x00007fca5f86f000)
   libxcb.so.1 => /usr/lib/libxcb.so.1 (0x00007fca5f845000)
   libdl.so.2 => /usr/lib/libdl.so.2 (0x00007fca5f83d000)
   /lib64/ld-linux-x86-64.so.2 => /usr/lib64/ld-linux-x86-64.so.2 (0x00007fca5fd46000)
   libXau.so.6 => /usr/lib/libXau.so.6 (0x00007fca5f838000)
   libXdmcp.so.6 => /usr/lib/libXdmcp.so.6 (0x00007fca5f830000)
Found Vulkan loader(s):
/usr/lib/libvulkan.so.1.2.149
/usr/lib32/libvulkan.so.1.2.149
Listing common ICD paths:
/usr/share/vulkan/icd.d/nvidia_icd.json
/sbin/lspci -d "10de:*" -v -xxx
01:00.0 VGA compatible controller: NVIDIA Corporation GM204 [GeForce GTX 970] (rev ff) (prog-if ff)
   !!! Unknown header type 7f
   Kernel driver in use: nvidia
   Kernel modules: nouveau, nvidia_drm, nvidia
00: ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff
10: ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff
20: ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff
30: ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff
40: ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff
50: ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff
60: ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff
70: ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff
80: ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff
90: ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff
a0: ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff
b0: ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff
c0: ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff
d0: ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff
e0: ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff
f0: ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff
01:00.1 Audio device: NVIDIA Corporation GM204 High Definition Audio Controller (rev ff) (prog-if ff)
   Kernel driver in use: snd_hda_intel
   Kernel modules: snd_hda_intel
/sbin/lspci -d "10b5:*" -v -xxx
/sbin/lspci -t
-[0000:00]-+-00.0
          +-01.0-[01]--+-00.0
          |            \-00.1
          +-14.0
          +-16.0
          +-19.0
          +-1a.0
          +-1b.0
          +-1c.0-[02]--
          +-1c.3-[03-04]----00.0-[04]--
          +-1c.6-[05]----00.0
          +-1d.0
          +-1f.0
          +-1f.2
          \-1f.3
/sbin/lspci -nn
00:00.0 Host bridge [0600]: Intel Corporation 4th Gen Core Processor DRAM Controller [8086:0c00] (rev 06)
00:01.0 PCI bridge [0604]: Intel Corporation Xeon E3-1200 v3/4th Gen Core Processor PCI Express x16 Controller [8086:0c01] (rev 06)
00:14.0 USB controller [0c03]: Intel Corporation 9 Series Chipset Family USB xHCI Controller [8086:8cb1]
00:16.0 Communication controller [0780]: Intel Corporation 9 Series Chipset Family ME Interface #1 [8086:8cba]
00:19.0 Ethernet controller [0200]: Intel Corporation Ethernet Connection (2) I218-V [8086:15a1]
00:1a.0 USB controller [0c03]: Intel Corporation 9 Series Chipset Family USB EHCI Controller #2 [8086:8cad]
00:1b.0 Audio device [0403]: Intel Corporation 9 Series Chipset Family HD Audio Controller [8086:8ca0]
00:1c.0 PCI bridge [0604]: Intel Corporation 9 Series Chipset Family PCI Express Root Port 1 [8086:8c90] (rev d0)
00:1c.3 PCI bridge [0604]: Intel Corporation 82801 PCI Bridge [8086:244e] (rev d0)
00:1c.6 PCI bridge [0604]: Intel Corporation 9 Series Chipset Family PCI Express Root Port 7 [8086:8c9c] (rev d0)
00:1d.0 USB controller [0c03]: Intel Corporation 9 Series Chipset Family USB EHCI Controller #1 [8086:8ca6]
00:1f.0 ISA bridge [0601]: Intel Corporation Z97 Chipset LPC Controller [8086:8cc4]
00:1f.2 SATA controller [0106]: Intel Corporation 9 Series Chipset Family SATA Controller [AHCI Mode] [8086:8c82]
00:1f.3 SMBus [0c05]: Intel Corporation 9 Series Chipset Family SMBus Controller [8086:8ca2]
01:00.0 VGA compatible controller [0300]: NVIDIA Corporation GM204 [GeForce GTX 970] [10de:13c2] (rev ff)
01:00.1 Audio device [0403]: NVIDIA Corporation GM204 High Definition Audio Controller [10de:0fbb] (rev ff)
03:00.0 PCI bridge [0604]: ASMedia Technology Inc. ASM1083/1085 PCIe to PCI Bridge [1b21:1080] (rev 04)
05:00.0 Non-Volatile memory controller [0108]: Samsung Electronics Co Ltd NVMe SSD Controller SM981/PM981/PM983 [144d:a808]
/sbin/numactl -H
available: 1 nodes (0)
node 0 cpus: 0 1 2 3
node 0 size: 15949 MB
node 0 free: 1298 MB
node distances:
node   0
 0:  10
*** /sys/devices/system/node/has_cpu
*** ls: -r--r--r-- 1 root root 4096 2020-08-20 14:29:16.057535715 +0200 /sys/devices/system/node/has_cpu
0
*** /sys/devices/system/node/has_memory
*** ls: -r--r--r-- 1 root root 4096 2020-08-20 14:29:16.057535715 +0200 /sys/devices/system/node/has_memory
0
*** /sys/devices/system/node/has_normal_memory
*** ls: -r--r--r-- 1 root root 4096 2020-08-20 14:29:16.057535715 +0200 /sys/devices/system/node/has_normal_memory
0
*** /sys/devices/system/node/online
*** ls: -r--r--r-- 1 root root 4096 2020-08-20 14:29:16.060868880 +0200 /sys/devices/system/node/online
0
*** /sys/devices/system/node/possible
*** ls: -r--r--r-- 1 root root 4096 2020-08-20 14:29:16.067535210 +0200 /sys/devices/system/node/possible
0
*** /sys/bus/pci/devices/0000:01:00.0/local_cpulist
*** ls: -r--r--r-- 1 root root 4096 2020-08-20 14:29:16.057535715 +0200 /sys/bus/pci/devices/0000:01:00.0/local_cpulist
0-3
*** /sys/bus/pci/devices/0000:01:00.0/numa_node
*** ls: -rw-r--r-- 1 root root 4096 2020-08-20 14:29:16.027537232 +0200 /sys/bus/pci/devices/0000:01:00.0/numa_node
-1
/sbin/lsusb
Bus 003 Device 002: ID 8087:8001 Intel Corp. Integrated Hub
Bus 003 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 001 Device 002: ID 8087:8009 Intel Corp.
Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 004 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 002 Device 003: ID 13d3:3393 IMC Networks
Bus 002 Device 002: ID 1a40:0101 Terminus Technology Inc. Hub
Bus 002 Device 006: ID 046d:c332 Logitech, Inc. G502 Proteus Spectrum Optical Mouse
Bus 002 Device 008: ID 046d:c222 Logitech, Inc. G15 Keyboard / LCD
Bus 002 Device 007: ID 046d:c221 Logitech, Inc. G11/G15 Keyboard / Keyboard
Bus 002 Device 005: ID 046d:c223 Logitech, Inc. G11/G15 Keyboard / USB Hub
Bus 002 Device 004: ID 28de:1142 Valve Software Wireless Steam Controller
Bus 002 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Skipping dmidecode output (dmidecode not found)
/sbin/modinfo nvidia | grep vermagic
vermagic:       5.8.1-arch1-1 SMP preempt mod_unload
Scanning kernel log files for NVIDIA kernel messages:
 journalctl -b -0:
Aug 20 13:20:51 localhost kernel: nvidia-nvlink: Nvlink Core is being initialized, major device number 238
Aug 20 13:20:51 localhost kernel: NVRM: loading NVIDIA UNIX x86_64 Kernel Module  450.57  Sun Jul  5 14:42:25 UTC 2020
Aug 20 13:20:51 localhost kernel: nvidia-modeset: Loading NVIDIA Kernel Mode Setting Driver for UNIX platforms  450.57  Sun Jul  5 14:52:29 UTC 2020
Aug 20 13:20:51 localhost kernel: [drm] [nvidia-drm] [GPU ID 0x00000100] Loading driver
Aug 20 13:20:51 localhost kernel: [drm] Initialized nvidia-drm 0.0.0 20160202 for 0000:01:00.0 on minor 0
                                             #6  0x00007efdf30effcb n/a (libnvidia-glcore.so.450.57 + 0xeb5fcb)
                                             #7  0x00007efdf3132500 n/a (libnvidia-glcore.so.450.57 + 0xef8500)
                                             #8  0x00007efdf3132cf6 n/a (libnvidia-glcore.so.450.57 + 0xef8cf6)
Aug 20 14:26:17 localhost kernel: NVRM: GPU at PCI:0000:01:00: GPU-25ebd6e0-8288-92bb-63be-726a324d49a7
Aug 20 14:26:17 localhost kernel: NVRM: Xid (PCI:0000:01:00): 79, pid=4497, GPU has fallen off the bus.
Aug 20 14:26:17 localhost kernel: NVRM: GPU 0000:01:00.0: GPU has fallen off the bus.
Aug 20 14:26:17 localhost kernel: NVRM: A GPU crash dump has been created. If possible, please run
                             NVRM: nvidia-bug-report.sh as root to collect this data before
                             NVRM: the NVIDIA kernel module is unloaded.
Aug 20 14:29:14 localhost dbus-daemon[364]: [system] Activating via systemd: service name='org.freedesktop.home1' unit='dbus-org.freedesktop.home1.service' requested by ':1.500' (uid=0 pid=5104 comm="sudo nvidia-bug-report.sh ")
Aug 20 14:29:14 localhost sudo[5104]:      user : TTY=pts/3 ; PWD=/home/user ; USER=root ; COMMAND=/usr/bin/nvidia-bug-report.sh
 journalctl -b -1:
Aug 20 12:14:42 localhost kernel: nvidia-nvlink: Nvlink Core is being initialized, major device number 238
Aug 20 12:14:42 localhost kernel: NVRM: loading NVIDIA UNIX x86_64 Kernel Module  450.57  Sun Jul  5 14:42:25 UTC 2020
Aug 20 12:14:42 localhost kernel: nvidia-modeset: Loading NVIDIA Kernel Mode Setting Driver for UNIX platforms  450.57  Sun Jul  5 14:52:29 UTC 2020
Aug 20 12:14:42 localhost kernel: [drm] [nvidia-drm] [GPU ID 0x00000100] Loading driver
Aug 20 12:14:42 localhost kernel: [drm] Initialized nvidia-drm 0.0.0 20160202 for 0000:01:00.0 on minor 0
 journalctl -b -2:
Aug 20 12:12:12 localhost kernel: nvidia-nvlink: Nvlink Core is being initialized, major device number 238
Aug 20 12:12:12 localhost kernel: NVRM: loading NVIDIA UNIX x86_64 Kernel Module  450.57  Sun Jul  5 14:42:25 UTC 2020
Aug 20 12:12:12 localhost kernel: nvidia-modeset: Loading NVIDIA Kernel Mode Setting Driver for UNIX platforms  450.57  Sun Jul  5 14:52:29 UTC 2020
Aug 20 12:12:12 localhost kernel: [drm] [nvidia-drm] [GPU ID 0x00000100] Loading driver
Aug 20 12:12:12 localhost kernel: [drm] Initialized nvidia-drm 0.0.0 20160202 for 0000:01:00.0 on minor 0
dmesg:
[    0.000000] BIOS-e820: [mem 0x00000000bdd76000-0x00000000bdd93fff] ACPI data
[    0.000000] BIOS-e820: [mem 0x00000000bdd94000-0x00000000be2b7fff] ACPI NVS
[    0.000000] BIOS-e820: [mem 0x00000000be2b8000-0x00000000beffefff] reserved
[    0.000000] BIOS-e820: [mem 0x00000000befff000-0x00000000beffffff] usable
[    0.000000] BIOS-e820: [mem 0x00000000e0000000-0x00000000efffffff] reserved
[    0.000000] BIOS-e820: [mem 0x00000000fec00000-0x00000000fec00fff] reserved
[    0.000000] BIOS-e820: [mem 0x00000000fed00000-0x00000000fed03fff] reserved
[    0.000000] BIOS-e820: [mem 0x00000000fed1c000-0x00000000fed1ffff] reserved
[    0.000000] BIOS-e820: [mem 0x00000000fee00000-0x00000000fee00fff] reserved
[    0.000000] BIOS-e820: [mem 0x00000000ff000000-0x00000000ffffffff] reserved
[    0.000000] BIOS-e820: [mem 0x0000000100000000-0x000000043effffff] usable
[    0.000000] NX (Execute Disable) protection: active
[    0.000000] e820: update [mem 0x99ef2018-0x99f13e57] usable ==> usable
[    0.000000] e820: update [mem 0x99ee0018-0x99ef1057] usable ==> usable
[    0.000000] extended physical RAM map:
[    0.000000] reserve setup_data: [mem 0x0000000000000000-0x0000000000057fff] usable
[    0.000000] reserve setup_data: [mem 0x0000000000058000-0x0000000000058fff] reserved
[    0.000000] reserve setup_data: [mem 0x0000000000059000-0x000000000009efff] usable
[    0.000000] reserve setup_data: [mem 0x000000000009f000-0x000000000009ffff] reserved
[    0.000000] reserve setup_data: [mem 0x0000000000100000-0x0000000099ee0017] usable
[    0.000000] reserve setup_data: [mem 0x0000000099ee0018-0x0000000099ef1057] usable
[    0.000000] reserve setup_data: [mem 0x0000000099ef1058-0x0000000099ef2017] usable
[    0.000000] reserve setup_data: [mem 0x0000000099ef2018-0x0000000099f13e57] usable
[    0.000000] reserve setup_data: [mem 0x0000000099f13e58-0x000000009ce5dfff] usable
[    0.000000] reserve setup_data: [mem 0x000000009ce5e000-0x000000009ce64fff] ACPI NVS
[    0.000000] reserve setup_data: [mem 0x000000009ce65000-0x000000009d2c4fff] usable
[    0.000000] reserve setup_data: [mem 0x000000009d2c5000-0x000000009d735fff] reserved
[    0.000000] reserve setup_data: [mem 0x000000009d736000-0x00000000bd861fff] usable
[    0.000000] reserve setup_data: [mem 0x00000000bd862000-0x00000000bdd75fff] reserved
[    0.000000] reserve setup_data: [mem 0x00000000bdd76000-0x00000000bdd93fff] ACPI data
[    0.000000] reserve setup_data: [mem 0x00000000bdd94000-0x00000000be2b7fff] ACPI NVS
[    0.000000] reserve setup_data: [mem 0x00000000be2b8000-0x00000000beffefff] reserved
[    0.000000] reserve setup_data: [mem 0x00000000befff000-0x00000000beffffff] usable
[    0.000000] reserve setup_data: [mem 0x00000000e0000000-0x00000000efffffff] reserved
[    0.000000] reserve setup_data: [mem 0x00000000fec00000-0x00000000fec00fff] reserved
[    0.000000] reserve setup_data: [mem 0x00000000fed00000-0x00000000fed03fff] reserved
[    0.000000] reserve setup_data: [mem 0x00000000fed1c000-0x00000000fed1ffff] reserved
[    0.000000] reserve setup_data: [mem 0x00000000fee00000-0x00000000fee00fff] reserved
[    0.000000] reserve setup_data: [mem 0x00000000ff000000-0x00000000ffffffff] reserved
[    0.000000] reserve setup_data: [mem 0x0000000100000000-0x000000043effffff] usable
[    0.000000] efi: EFI v2.31 by American Megatrends
[    0.000000] efi: ESRT=0xbef50818 ACPI 2.0=0xbdd7c000 ACPI=0xbdd7c000 SMBIOS=0xf04d0
[    0.000000] SMBIOS 2.8 present.
[    0.000000] DMI: ASUS All Series/Z97-A, BIOS 2012 09/30/2014
[    0.000000] tsc: Fast TSC calibration using PIT
[    0.000000] tsc: Detected 3397.844 MHz processor
[    0.000595] e820: update [mem 0x00000000-0x00000fff] usable ==> reserved
[    0.000596] e820: remove [mem 0x000a0000-0x000fffff] usable
[    0.000601] last_pfn = 0x43f000 max_arch_pfn = 0x400000000
[    0.000604] MTRR default type: uncachable
[    0.000605] MTRR fixed ranges enabled:
[    0.000606]   00000-9FFFF write-back
[    0.000606]   A0000-BFFFF uncachable
[    0.000607]   C0000-CFFFF write-protect
[    0.000607]   D0000-DFFFF uncachable
[    0.000608]   E0000-FFFFF write-protect
[    0.000608] MTRR variable ranges enabled:
[    0.000609]   0 base 0000000000 mask 7C00000000 write-back
[    0.000610]   1 base 0400000000 mask 7FE0000000 write-back
[    0.000610]   2 base 0420000000 mask 7FF0000000 write-back
[    0.000611]   3 base 0430000000 mask 7FF8000000 write-back
[    0.000612]   4 base 0438000000 mask 7FFC000000 write-back
[    0.000612]   5 base 043C000000 mask 7FFE000000 write-back
[    0.000613]   6 base 043E000000 mask 7FFF000000 write-back
[    0.000613]   7 base 00C0000000 mask 7FC0000000 uncachable
[    0.000614]   8 disabled
[    0.000614]   9 disabled
[    0.000834] x86/PAT: Configuration [0-7]: WB  WC  UC- UC  WB  WP  UC- WT
[    0.000956] total RAM covered: 16368M
[    0.001240] Found optimal setting for mtrr clean up
[    0.001240]  gran_size: 64K 	chunk_size: 32M 	num_reg: 6  	lose cover RAM: 0G
[    0.001443] e820: update [mem 0xc0000000-0xffffffff] usable ==> reserved
[    0.001445] last_pfn = 0xbf000 max_arch_pfn = 0x400000000
[    0.007148] found SMP MP-table at [mem 0x000fd900-0x000fd90f]
[    0.007159] esrt: Reserving ESRT space from 0x00000000bef50818 to 0x00000000bef50850.
[    0.007178] check: Scanning 1 areas for low memory corruption
[    0.007182] Using GB pages for direct mapping
[    0.007540] Secure boot disabled
[    0.007541] RAMDISK: [mem 0x7f67f000-0x7fffffff]
[    0.007545] ACPI: Early table checksum verification disabled
[    0.007547] ACPI: RSDP 0x00000000BDD7C000 000024 (v02 ALASKA)
[    0.007549] ACPI: XSDT 0x00000000BDD7C088 000084 (v01 ALASKA A M I    01072009 AMI  00010013)
[    0.007553] ACPI: FACP 0x00000000BDD8B748 00010C (v05 ALASKA A M I    01072009 AMI  00010013)
[    0.007556] ACPI: DSDT 0x00000000BDD7C1A0 00F5A6 (v02 ALASKA A M I    00000011 INTL 20120711)
[    0.007558] ACPI: FACS 0x00000000BE2B7F80 000040
[    0.007560] ACPI: APIC 0x00000000BDD8B858 000072 (v03 ALASKA A M I    01072009 AMI  00010013)
[    0.007562] ACPI: FPDT 0x00000000BDD8B8D0 000044 (v01 ALASKA A M I    01072009 AMI  00010013)
[    0.007564] ACPI: SSDT 0x00000000BDD8B918 000C7D (v01 Ther_R Ther_Rvp 00001000 INTL 20120711)
[    0.007566] ACPI: SSDT 0x00000000BDD8C598 000539 (v01 PmRef  Cpu0Ist  00003000 INTL 20051117)
[    0.007568] ACPI: SSDT 0x00000000BDD8CAD8 000B74 (v01 CpuRef CpuSsdt  00003000 INTL 20051117)
[    0.007570] ACPI: SSDT 0x00000000BDD8D650 0001C7 (v01 PmRef  LakeTiny 00003000 INTL 20051117)
@pingo-power
[    0.007571] ACPI: MCFG 0x00000000BDD8D818 00003C (v01 ALASKA A M I    01072009 MSFT 00000097)
[    0.007573] ACPI: HPET 0x00000000BDD8D858 000038 (v01 ALASKA A M I    01072009 AMI. 00000005)
[    0.007575] ACPI: SSDT 0x00000000BDD8D890 00036D (v01 SataRe SataTabl 00001000 INTL 20120711)
[    0.007577] ACPI: SSDT 0x00000000BDD8DC00 005977 (v01 SaSsdt SaSsdt   00003000 INTL 20120711)
[    0.007579] ACPI: BGRT 0x00000000BDD935D0 000038 (v01 ALASKA A M I    01072009 AMI  00010013)
[    0.007584] ACPI: Local APIC address 0xfee00000
[    0.007616] No NUMA configuration found
[    0.007616] Faking a node at [mem 0x0000000000000000-0x000000043effffff]
[    0.007620] NODE_DATA(0) allocated [mem 0x43effa000-0x43effdfff]
[    0.007645] Zone ranges:
[    0.007645]   DMA      [mem 0x0000000000001000-0x0000000000ffffff]
[    0.007646]   DMA32    [mem 0x0000000001000000-0x00000000ffffffff]
[    0.007647]   Normal   [mem 0x0000000100000000-0x000000043effffff]
[    0.007647]   Device   empty
[    0.007648] Movable zone start for each node
[    0.007648] Early memory node ranges
[    0.007649]   node   0: [mem 0x0000000000001000-0x0000000000057fff]
[    0.007650]   node   0: [mem 0x0000000000059000-0x000000000009efff]
[    0.007650]   node   0: [mem 0x0000000000100000-0x000000009ce5dfff]
[    0.007651]   node   0: [mem 0x000000009ce65000-0x000000009d2c4fff]
[    0.007651]   node   0: [mem 0x000000009d736000-0x00000000bd861fff]
[    0.007652]   node   0: [mem 0x00000000befff000-0x00000000beffffff]
[    0.007652]   node   0: [mem 0x0000000100000000-0x000000043effffff]
[    0.007754] Zeroed struct page in unavailable ranges: 15480 pages
[    0.007755] Initmem setup node 0 [mem 0x0000000000001000-0x000000043effffff]
[    0.007756] On node 0 totalpages: 4178824
[    0.007757]   DMA zone: 64 pages used for memmap
[    0.007758]   DMA zone: 24 pages reserved
[    0.007758]   DMA zone: 3997 pages, LIFO batch:0
[    0.007781]   DMA32 zone: 12048 pages used for memmap
[    0.007781]   DMA32 zone: 771051 pages, LIFO batch:63
[    0.012125]   Normal zone: 53184 pages used for memmap
[    0.012126]   Normal zone: 3403776 pages, LIFO batch:63
[    0.031360] ACPI: PM-Timer IO Port: 0x1808
[    0.031362] ACPI: Local APIC address 0xfee00000
[    0.031367] ACPI: LAPIC_NMI (acpi_id[0xff] high edge lint[0x1])
[    0.031376] IOAPIC[0]: apic_id 8, version 32, address 0xfec00000, GSI 0-23
[    0.031378] ACPI: INT_SRC_OVR (bus 0 bus_irq 0 global_irq 2 dfl dfl)
[    0.031379] ACPI: INT_SRC_OVR (bus 0 bus_irq 9 global_irq 9 high level)
[    0.031380] ACPI: IRQ0 used by override.
[    0.031380] ACPI: IRQ9 used by override.
[    0.031381] Using ACPI (MADT) for SMP configuration information
[    0.031383] ACPI: HPET id: 0x8086a701 base: 0xfed00000
[    0.031386] efi_bgrt: Ignoring BGRT: invalid image address
[    0.031388] [Firmware Bug]: TSC_DEADLINE disabled due to Errata; please update microcode to version: 0x22 (or later)
[    0.031390] smpboot: Allowing 4 CPUs, 0 hotplug CPUs
[    0.031409] PM: hibernation: Registered nosave memory: [mem 0x00000000-0x00000fff]
[    0.031410] PM: hibernation: Registered nosave memory: [mem 0x00058000-0x00058fff]
[    0.031412] PM: hibernation: Registered nosave memory: [mem 0x0009f000-0x0009ffff]
[    0.031412] PM: hibernation: Registered nosave memory: [mem 0x000a0000-0x000fffff]
[    0.031413] PM: hibernation: Registered nosave memory: [mem 0x99ee0000-0x99ee0fff]
[    0.031415] PM: hibernation: Registered nosave memory: [mem 0x99ef1000-0x99ef1fff]
[    0.031415] PM: hibernation: Registered nosave memory: [mem 0x99ef2000-0x99ef2fff]
[    0.031416] PM: hibernation: Registered nosave memory: [mem 0x99f13000-0x99f13fff]
[    0.031418] PM: hibernation: Registered nosave memory: [mem 0x9ce5e000-0x9ce64fff]
[    0.031419] PM: hibernation: Registered nosave memory: [mem 0x9d2c5000-0x9d735fff]
[    0.031420] PM: hibernation: Registered nosave memory: [mem 0xbd862000-0xbdd75fff]
[    0.031421] PM: hibernation: Registered nosave memory: [mem 0xbdd76000-0xbdd93fff]
[    0.031421] PM: hibernation: Registered nosave memory: [mem 0xbdd94000-0xbe2b7fff]
[    0.031421] PM: hibernation: Registered nosave memory: [mem 0xbe2b8000-0xbeffefff]
[    0.031423] PM: hibernation: Registered nosave memory: [mem 0xbf000000-0xdfffffff]
[    0.031423] PM: hibernation: Registered nosave memory: [mem 0xe0000000-0xefffffff]
[    0.031424] PM: hibernation: Registered nosave memory: [mem 0xf0000000-0xfebfffff]
[    0.031424] PM: hibernation: Registered nosave memory: [mem 0xfec00000-0xfec00fff]
[    0.031424] PM: hibernation: Registered nosave memory: [mem 0xfec01000-0xfecfffff]
[    0.031425] PM: hibernation: Registered nosave memory: [mem 0xfed00000-0xfed03fff]
[    0.031425] PM: hibernation: Registered nosave memory: [mem 0xfed04000-0xfed1bfff]
[    0.031426] PM: hibernation: Registered nosave memory: [mem 0xfed1c000-0xfed1ffff]
[    0.031426] PM: hibernation: Registered nosave memory: [mem 0xfed20000-0xfedfffff]
[    0.031426] PM: hibernation: Registered nosave memory: [mem 0xfee00000-0xfee00fff]
[    0.031427] PM: hibernation: Registered nosave memory: [mem 0xfee01000-0xfeffffff]
[    0.031427] PM: hibernation: Registered nosave memory: [mem 0xff000000-0xffffffff]
[    0.031429] [mem 0xbf000000-0xdfffffff] available for PCI devices
[    0.031429] Booting paravirtualized kernel on bare hardware
[    0.031432] clocksource: refined-jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 6370452778343963 ns
[    0.035091] setup_percpu: NR_CPUS:320 nr_cpumask_bits:320 nr_cpu_ids:4 nr_node_ids:1
[    0.035214] percpu: Embedded 56 pages/cpu s192512 r8192 d28672 u524288
[    0.035220] pcpu-alloc: s192512 r8192 d28672 u524288 alloc=1*2097152
[    0.035220] pcpu-alloc: [0] 0 1 2 3
[    0.035237] Built 1 zonelists, mobility grouping on.  Total pages: 4113504
[    0.035237] Policy zone: Normal
[    0.035238] Kernel command line: root=UUID=6c37d730-4b14-4479-8554-92d2e75478d5 rw initrd=\initramfs-linux.img
[    0.035900] Dentry cache hash table entries: 2097152 (order: 12, 16777216 bytes, linear)
[    0.036215] Inode-cache hash table entries: 1048576 (order: 11, 8388608 bytes, linear)
[    0.036250] mem auto-init: stack:byref_all, heap alloc:on, heap free:off
[    0.071778] Memory: 16090020K/16715296K available (14339K kernel code, 1479K rwdata, 7912K rodata, 1648K init, 3024K bss, 625276K reserved, 0K cma-reserved)
[    0.071784] random: get_random_u64 called from __kmem_cache_create+0x3e/0x600 with crng_init=0
[    0.071868] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
[    0.071878] Kernel/User page tables isolation: enabled
[    0.071893] ftrace: allocating 40096 entries in 157 pages
[    0.082418] ftrace: allocated 157 pages with 5 groups
[    0.082489] rcu: Preemptible hierarchical RCU implementation.
[    0.082490] rcu: 	RCU dyntick-idle grace-period acceleration is enabled.
[    0.082490] rcu: 	RCU restricting CPUs from NR_CPUS=320 to nr_cpu_ids=4.
[    0.082491] rcu: 	RCU priority boosting: priority 1 delay 500 ms.
[    0.082492] 	Trampoline variant of Tasks RCU enabled.
[    0.082492] 	Rude variant of Tasks RCU enabled.
[    0.082492] rcu: RCU calculated value of scheduler-enlistment delay is 30 jiffies.
[    0.082493] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=4
[    0.084707] NR_IRQS: 20736, nr_irqs: 456, preallocated irqs: 16
[    0.084923] Console: colour dummy device 80x25
[    0.084929] printk: console [tty0] enabled
[    0.084939] ACPI: Core revision 20200528
[    0.085031] clocksource: hpet: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 133484882848 ns
[    0.085039] APIC: Switch to symmetric I/O mode setup
[    0.085343] ..TIMER: vector=0x30 apic1=0 pin1=2 apic2=0 pin2=0
[    0.101709] clocksource: tsc-early: mask: 0xffffffffffffffff max_cycles: 0x30fa5a50507, max_idle_ns: 440795321410 ns
[    0.101711] Calibrating delay loop (skipped), value calculated using timer frequency.. 6798.84 BogoMIPS (lpj=11326146)
[    0.101713] pid_max: default: 32768 minimum: 301
[    0.107551] LSM: Security Framework initializing
[    0.107554] Yama: becoming mindful.
[    0.107587] Mount-cache hash table entries: 32768 (order: 6, 262144 bytes, linear)
[    0.107611] Mountpoint-cache hash table entries: 32768 (order: 6, 262144 bytes, linear)
[    0.107789] mce: CPU0: Thermal monitoring enabled (TM1)
[    0.107801] process: using mwait in idle threads
[    0.107802] Last level iTLB entries: 4KB 1024, 2MB 1024, 4MB 1024
[    0.107803] Last level dTLB entries: 4KB 1024, 2MB 1024, 4MB 1024, 1GB 4
[    0.107805] Spectre V1 : Mitigation: usercopy/swapgs barriers and __user pointer sanitization
[    0.107806] Spectre V2 : Mitigation: Full generic retpoline
[    0.107806] Spectre V2 : Spectre v2 / SpectreRSB mitigation: Filling RSB on context switch
[    0.107807] Speculative Store Bypass: Vulnerable
[    0.107809] SRBDS: Vulnerable: No microcode
[    0.107810] MDS: Vulnerable: Clear CPU buffers attempted, no microcode
[    0.107962] Freeing SMP alternatives memory: 32K
[    0.218741] smpboot: CPU0: Intel(R) Core(TM) i5-4670K CPU @ 3.40GHz (family: 0x6, model: 0x3c, stepping: 0x3)
[    0.218812] Performance Events: PEBS fmt2+, Haswell events, 16-deep LBR, full-width counters, Intel PMU driver.
[    0.218825] ... version:                3
[    0.218826] ... bit width:              48
[    0.218826] ... generic registers:      8
[    0.218827] ... value mask:             0000ffffffffffff
[    0.218827] ... max period:             00007fffffffffff
[    0.218828] ... fixed-purpose events:   3
[    0.218828] ... event mask:             00000007000000ff
[    0.218855] rcu: Hierarchical SRCU implementation.
[    0.219342] NMI watchdog: Enabled. Permanently consumes one hw-PMU counter.
[    0.219378] smp: Bringing up secondary CPUs ...
[    0.219461] x86: Booting SMP configuration:
[    0.219461] .... node  #0, CPUs:      #1 #2 #3
[    0.219729] smp: Brought up 1 node, 4 CPUs
[    0.219729] smpboot: Max logical packages: 1
[    0.219729] smpboot: Total of 4 processors activated (27193.36 BogoMIPS)
[    0.219729] devtmpfs: initialized
[    0.219729] x86/mm: Memory block size: 128MB
[    0.222294] PM: Registering ACPI NVS region [mem 0x9ce5e000-0x9ce64fff] (28672 bytes)
[    0.222294] PM: Registering ACPI NVS region [mem 0xbdd94000-0xbe2b7fff] (5390336 bytes)
[    0.222294] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 6370867519511994 ns
[    0.222294] futex hash table entries: 1024 (order: 4, 65536 bytes, linear)
[    0.222294] pinctrl core: initialized pinctrl subsystem
[    0.222294] PM: RTC time: 11:20:48, date: 2020-08-20
[    0.222294] thermal_sys: Registered thermal governor 'fair_share'
[    0.222294] thermal_sys: Registered thermal governor 'bang_bang'
[    0.222294] thermal_sys: Registered thermal governor 'step_wise'
[    0.222294] thermal_sys: Registered thermal governor 'user_space'
[    0.222294] thermal_sys: Registered thermal governor 'power_allocator'
[    0.222294] NET: Registered protocol family 16
[    0.222294] DMA: preallocated 2048 KiB GFP_KERNEL pool for atomic allocations
[    0.222294] DMA: preallocated 2048 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
[    0.222294] DMA: preallocated 2048 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
[    0.222294] audit: initializing netlink subsys (disabled)
[    0.222294] audit: type=2000 audit(1597922448.136:1): state=initialized audit_enabled=0 res=1
[    0.222294] cpuidle: using governor ladder
[    0.222294] cpuidle: using governor menu
[    0.222294] ACPI FADT declares the system doesn't support PCIe ASPM, so disable it
[    0.222294] ACPI: bus type PCI registered
[    0.222294] acpiphp: ACPI Hot Plug PCI Controller Driver version: 0.5
[    0.222294] PCI: MMCONFIG for domain 0000 [bus 00-ff] at [mem 0xe0000000-0xefffffff] (base 0xe0000000)
[    0.222294] PCI: MMCONFIG at [mem 0xe0000000-0xefffffff] reserved in E820
[    0.222294] PCI: Using configuration type 1 for base access
[    0.222294] core: PMU erratum BJ122, BV98, HSD29 workaround disabled, HT off
[    0.222294] ENERGY_PERF_BIAS: Set to 'normal', was 'performance'
[    0.222600] HugeTLB registered 1.00 GiB page size, pre-allocated 0 pages
[    0.222600] HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages
[    0.225110] fbcon: Taking over console
[    0.225122] ACPI: Added _OSI(Module Device)
[    0.225123] ACPI: Added _OSI(Processor Device)
[    0.225124] ACPI: Added _OSI(3.0 _SCP Extensions)
[    0.225124] ACPI: Added _OSI(Processor Aggregator Device)
[    0.225125] ACPI: Added _OSI(Linux-Dell-Video)
[    0.225125] ACPI: Added _OSI(Linux-Lenovo-NV-HDMI-Audio)
[    0.225126] ACPI: Added _OSI(Linux-HPI-Hybrid-Graphics)
[    0.236859] ACPI: 7 ACPI AML tables successfully acquired and loaded
[    0.239248] ACPI: Dynamic OEM Table Load:
[    0.239252] ACPI: SSDT 0xFFFF9B562C939C00 0003D3 (v01 PmRef  Cpu0Cst  00003001 INTL 20051117)
[    0.240240] ACPI: Dynamic OEM Table Load:
[    0.240243] ACPI: SSDT 0xFFFF9B562C8E2000 0005AA (v01 PmRef  ApIst    00003000 INTL 20051117)
[    0.241271] ACPI: Dynamic OEM Table Load:
[    0.241273] ACPI: SSDT 0xFFFF9B562C64F600 000119 (v01 PmRef  ApCst    00003000 INTL 20051117)
[    0.242744] ACPI: EC: EC started
[    0.242745] ACPI: EC: interrupt blocked
[    0.242759] ACPI: EC: EC_CMD/EC_SC=0x66, EC_DATA=0x62
[    0.242760] ACPI: \_SB_.PCI0.LPCB.EC0_: Boot DSDT EC used to handle transactions
[    0.242761] ACPI: Interpreter enabled
[    0.242788] ACPI: (supports S0 S3 S4 S5)
[    0.242789] ACPI: Using IOAPIC for interrupt routing
[    0.242815] PCI: Using host bridge windows from ACPI; if necessary, use "pci=nocrs" and report a bug
[    0.243117] ACPI: Enabled 12 GPEs in block 00 to 3F
[    0.243854] ACPI: Power Resource [PG00] (on)
[    0.244139] ACPI: Power Resource [PG01] (on)
[    0.244411] ACPI: Power Resource [PG02] (on)
[    0.252023] ACPI: Power Resource [FN00] (off)
[    0.252096] ACPI: Power Resource [FN01] (off)
[    0.252165] ACPI: Power Resource [FN02] (off)
[    0.252232] ACPI: Power Resource [FN03] (off)
[    0.252299] ACPI: Power Resource [FN04] (off)
[    0.253217] ACPI: PCI Root Bridge [PCI0] (domain 0000 [bus 00-fe])
[    0.253222] acpi PNP0A08:00: _OSC: OS supports [ExtendedConfig ASPM ClockPM Segments MSI EDR HPX-Type3]
[    0.253945] acpi PNP0A08:00: _OSC: OS now controls [PCIeHotplug SHPCHotplug PME AER PCIeCapability LTR DPC]
[    0.253946] acpi PNP0A08:00: FADT indicates ASPM is unsupported, using BIOS configuration
[    0.254436] PCI host bridge to bus 0000:00
[    0.254438] pci_bus 0000:00: root bus resource [io  0x0000-0x0cf7 window]
[    0.254439] pci_bus 0000:00: root bus resource [io  0x0d00-0xffff window]
[    0.254440] pci_bus 0000:00: root bus resource [mem 0x000a0000-0x000bffff window]
[    0.254441] pci_bus 0000:00: root bus resource [mem 0x000d0000-0x000d3fff window]
[    0.254441] pci_bus 0000:00: root bus resource [mem 0x000d4000-0x000d7fff window]
[    0.254442] pci_bus 0000:00: root bus resource [mem 0x000d8000-0x000dbfff window]
[    0.254443] pci_bus 0000:00: root bus resource [mem 0x000dc000-0x000dffff window]
[    0.254444] pci_bus 0000:00: root bus resource [mem 0xc0000000-0xfeafffff window]
[    0.254445] pci_bus 0000:00: root bus resource [bus 00-fe]
[    0.254452] pci 0000:00:00.0: [8086:0c00] type 00 class 0x060000
[    0.254534] pci 0000:00:01.0: [8086:0c01] type 01 class 0x060400
[    0.254568] pci 0000:00:01.0: PME# supported from D0 D3hot D3cold
[    0.254742] pci 0000:00:14.0: [8086:8cb1] type 00 class 0x0c0330
[    0.254760] pci 0000:00:14.0: reg 0x10: [mem 0xdf220000-0xdf22ffff 64bit]
[    0.254813] pci 0000:00:14.0: PME# supported from D3hot D3cold
[    0.254891] pci 0000:00:16.0: [8086:8cba] type 00 class 0x078000
[    0.254909] pci 0000:00:16.0: reg 0x10: [mem 0xdf23a000-0xdf23a00f 64bit]
[    0.254964] pci 0000:00:16.0: PME# supported from D0 D3hot D3cold
[    0.255082] pci 0000:00:19.0: [8086:15a1] type 00 class 0x020000
[    0.255098] pci 0000:00:19.0: reg 0x10: [mem 0xdf200000-0xdf21ffff]
[    0.255104] pci 0000:00:19.0: reg 0x14: [mem 0xdf238000-0xdf238fff]
[    0.255111] pci 0000:00:19.0: reg 0x18: [io  0xf040-0xf05f]
[    0.255162] pci 0000:00:19.0: PME# supported from D0 D3hot D3cold
[    0.255242] pci 0000:00:1a.0: [8086:8cad] type 00 class 0x0c0320
[    0.255261] pci 0000:00:1a.0: reg 0x10: [mem 0xdf237000-0xdf2373ff]
[    0.255334] pci 0000:00:1a.0: PME# supported from D0 D3hot D3cold
[    0.255414] pci 0000:00:1b.0: [8086:8ca0] type 00 class 0x040300
[    0.255430] pci 0000:00:1b.0: reg 0x10: [mem 0xdf230000-0xdf233fff 64bit]
[    0.255484] pci 0000:00:1b.0: PME# supported from D0 D3hot D3cold
[    0.255592] pci 0000:00:1c.0: [8086:8c90] type 01 class 0x060400
[    0.255661] pci 0000:00:1c.0: PME# supported from D0 D3hot D3cold
[    0.255819] pci 0000:00:1c.3: [8086:244e] type 01 class 0x060401
[    0.255890] pci 0000:00:1c.3: PME# supported from D0 D3hot D3cold
[    0.256047] pci 0000:00:1c.6: [8086:8c9c] type 01 class 0x060400
[    0.256117] pci 0000:00:1c.6: PME# supported from D0 D3hot D3cold
[    0.256274] pci 0000:00:1d.0: [8086:8ca6] type 00 class 0x0c0320
[    0.256293] pci 0000:00:1d.0: reg 0x10: [mem 0xdf236000-0xdf2363ff]
[    0.256367] pci 0000:00:1d.0: PME# supported from D0 D3hot D3cold
[    0.256449] pci 0000:00:1f.0: [8086:8cc4] type 00 class 0x060100
[    0.256615] pci 0000:00:1f.2: [8086:8c82] type 00 class 0x010601
[    0.256629] pci 0000:00:1f.2: reg 0x10: [io  0xf090-0xf097]
[    0.256635] pci 0000:00:1f.2: reg 0x14: [io  0xf080-0xf083]
[    0.256640] pci 0000:00:1f.2: reg 0x18: [io  0xf070-0xf077]
[    0.256646] pci 0000:00:1f.2: reg 0x1c: [io  0xf060-0xf063]
[    0.256652] pci 0000:00:1f.2: reg 0x20: [io  0xf020-0xf03f]
[    0.256657] pci 0000:00:1f.2: reg 0x24: [mem 0xdf235000-0xdf2357ff]
[    0.256688] pci 0000:00:1f.2: PME# supported from D3hot
[    0.256763] pci 0000:00:1f.3: [8086:8ca2] type 00 class 0x0c0500
[    0.256778] pci 0000:00:1f.3: reg 0x10: [mem 0xdf234000-0xdf2340ff 64bit]
[    0.256794] pci 0000:00:1f.3: reg 0x20: [io  0xf000-0xf01f]
[    0.256906] pci 0000:01:00.0: [10de:13c2] type 00 class 0x030000
[    0.256923] pci 0000:01:00.0: reg 0x10: [mem 0xde000000-0xdeffffff]
[    0.256932] pci 0000:01:00.0: reg 0x14: [mem 0xc0000000-0xcfffffff 64bit pref]
[    0.256941] pci 0000:01:00.0: reg 0x1c: [mem 0xd0000000-0xd1ffffff 64bit pref]
[    0.256947] pci 0000:01:00.0: reg 0x24: [io  0xe000-0xe07f]
[    0.256953] pci 0000:01:00.0: reg 0x30: [mem 0xdf000000-0xdf07ffff pref]
[    0.256966] pci 0000:01:00.0: BAR 3: assigned to efifb
[    0.257028] pci 0000:01:00.0: 32.000 Gb/s available PCIe bandwidth, limited by 2.5 GT/s PCIe x16 link at 0000:00:01.0 (capable of 126.016 Gb/s with 8.0 GT/s PCIe x16 link)
[    0.257074] pci 0000:01:00.1: [10de:0fbb] type 00 class 0x040300
[    0.257087] pci 0000:01:00.1: reg 0x10: [mem 0xdf080000-0xdf083fff]
[    0.257196] pci 0000:00:01.0: ASPM: current common clock configuration is inconsistent, reconfiguring
[    0.268405] pci 0000:00:01.0: PCI bridge to [bus 01]
[    0.268406] pci 0000:00:01.0:   bridge window [io  0xe000-0xefff]
[    0.268408] pci 0000:00:01.0:   bridge window [mem 0xde000000-0xdf0fffff]
[    0.268410] pci 0000:00:01.0:   bridge window [mem 0xc0000000-0xd1ffffff 64bit pref]
[    0.268479] acpiphp: Slot [1] registered
[    0.268482] pci 0000:00:1c.0: PCI bridge to [bus 02]
[    0.268534] pci 0000:03:00.0: [1b21:1080] type 01 class 0x060401
[    0.268719] pci 0000:00:1c.3: PCI bridge to [bus 03-04] (subtractive decode)
[    0.268725] pci 0000:00:1c.3:   bridge window [io  0x0000-0x0cf7 window] (subtractive decode)
[    0.268726] pci 0000:00:1c.3:   bridge window [io  0x0d00-0xffff window] (subtractive decode)
[    0.268727] pci 0000:00:1c.3:   bridge window [mem 0x000a0000-0x000bffff window] (subtractive decode)
[    0.268728] pci 0000:00:1c.3:   bridge window [mem 0x000d0000-0x000d3fff window] (subtractive decode)
[    0.268728] pci 0000:00:1c.3:   bridge window [mem 0x000d4000-0x000d7fff window] (subtractive decode)
[    0.268729] pci 0000:00:1c.3:   bridge window [mem 0x000d8000-0x000dbfff window] (subtractive decode)
[    0.268730] pci 0000:00:1c.3:   bridge window [mem 0x000dc000-0x000dffff window] (subtractive decode)
[    0.268731] pci 0000:00:1c.3:   bridge window [mem 0xc0000000-0xfeafffff window] (subtractive decode)
[    0.268756] pci_bus 0000:04: extended config space not accessible
[    0.268823] pci 0000:03:00.0: PCI bridge to [bus 04] (subtractive decode)
[    0.268839] pci 0000:03:00.0:   bridge window [io  0x0000-0x0cf7 window] (subtractive decode)
[    0.268840] pci 0000:03:00.0:   bridge window [io  0x0d00-0xffff window] (subtractive decode)
[    0.268841] pci 0000:03:00.0:   bridge window [mem 0x000a0000-0x000bffff window] (subtractive decode)
[    0.268842] pci 0000:03:00.0:   bridge window [mem 0x000d0000-0x000d3fff window] (subtractive decode)
[    0.268842] pci 0000:03:00.0:   bridge window [mem 0x000d4000-0x000d7fff window] (subtractive decode)
[    0.268843] pci 0000:03:00.0:   bridge window [mem 0x000d8000-0x000dbfff window] (subtractive decode)
[    0.268844] pci 0000:03:00.0:   bridge window [mem 0x000dc000-0x000dffff window] (subtractive decode)
[    0.268844] pci 0000:03:00.0:   bridge window [mem 0xc0000000-0xfeafffff window] (subtractive decode)
[    0.268925] pci 0000:05:00.0: [144d:a808] type 00 class 0x010802
[    0.268954] pci 0000:05:00.0: reg 0x10: [mem 0xdf100000-0xdf103fff 64bit]
[    0.269115] pci 0000:05:00.0: 8.000 Gb/s available PCIe bandwidth, limited by 5.0 GT/s PCIe x2 link at 0000:00:1c.6 (capable of 31.504 Gb/s with 8.0 GT/s PCIe x4 link)
[    0.269220] pci 0000:00:1c.6: PCI bridge to [bus 05]
[    0.269224] pci 0000:00:1c.6:   bridge window [mem 0xdf100000-0xdf1fffff]
[    0.269941] ACPI: PCI Interrupt Link [LNKA] (IRQs 3 4 5 6 7 10 *11 12 14 15)
[    0.269992] ACPI: PCI Interrupt Link [LNKB] (IRQs 3 4 5 6 7 *10 11 12 14 15)
[    0.270042] ACPI: PCI Interrupt Link [LNKC] (IRQs 3 4 5 *6 7 10 11 12 14 15)
[    0.270091] ACPI: PCI Interrupt Link [LNKD] (IRQs 3 4 *5 6 7 10 11 12 14 15)
[    0.270140] ACPI: PCI Interrupt Link [LNKE] (IRQs *3 4 5 6 7 10 11 12 14 15)
[    0.270189] ACPI: PCI Interrupt Link [LNKF] (IRQs 3 4 5 6 7 10 11 12 14 *15)
[    0.270238] ACPI: PCI Interrupt Link [LNKG] (IRQs 3 4 5 6 7 10 11 12 *14 15)
[    0.270287] ACPI: PCI Interrupt Link [LNKH] (IRQs 3 4 5 6 *7 10 11 12 14 15)
[    0.271711] ACPI: EC: interrupt unblocked
[    0.271711] ACPI: EC: event unblocked
[    0.271711] ACPI: EC: EC_CMD/EC_SC=0x66, EC_DATA=0x62
[    0.271711] ACPI: EC: GPE=0x1e
[    0.271711] ACPI: \_SB_.PCI0.LPCB.EC0_: Boot DSDT EC initialization complete
[    0.271711] ACPI: \_SB_.PCI0.LPCB.EC0_: EC: Used to handle transactions and events
[    0.271711] iommu: Default domain type: Translated
[    0.271721] pci 0000:01:00.0: vgaarb: setting as boot VGA device
[    0.271721] pci 0000:01:00.0: vgaarb: VGA device added: decodes=io+mem,owns=io+mem,locks=none
[    0.271721] pci 0000:01:00.0: vgaarb: bridge control possible
[    0.271721] vgaarb: loaded
[    0.271842] SCSI subsystem initialized
[    0.271850] libata version 3.00 loaded.
[    0.271850] ACPI: bus type USB registered
[    0.271850] usbcore: registered new interface driver usbfs
[    0.271850] usbcore: registered new interface driver hub
[    0.271850] usbcore: registered new device driver usb
[    0.271850] pps_core: LinuxPPS API ver. 1 registered
[    0.271850] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[    0.271850] PTP clock support registered
[    0.271850] EDAC MC: Ver: 3.0.0
[    0.271850] Registered efivars operations
[    0.271850] NetLabel: Initializing
[    0.271850] NetLabel:  domain hash size = 128
[    0.271850] NetLabel:  protocols = UNLABELED CIPSOv4 CALIPSO
[    0.271850] NetLabel:  unlabeled traffic allowed by default
[    0.271850] PCI: Using ACPI for IRQ routing
[    0.276198] PCI: pci_cache_line_size set to 64 bytes
[    0.276240] e820: reserve RAM buffer [mem 0x00058000-0x0005ffff]
[    0.276241] e820: reserve RAM buffer [mem 0x0009f000-0x0009ffff]
[    0.276242] e820: reserve RAM buffer [mem 0x99ee0018-0x9bffffff]
[    0.276243] e820: reserve RAM buffer [mem 0x99ef2018-0x9bffffff]
[    0.276243] e820: reserve RAM buffer [mem 0x9ce5e000-0x9fffffff]
[    0.276244] e820: reserve RAM buffer [mem 0x9d2c5000-0x9fffffff]
[    0.276244] e820: reserve RAM buffer [mem 0xbd862000-0xbfffffff]
[    0.276245] e820: reserve RAM buffer [mem 0xbf000000-0xbfffffff]
[    0.276246] e820: reserve RAM buffer [mem 0x43f000000-0x43fffffff]
[    0.276249] hpet0: at MMIO 0xfed00000, IRQs 2, 8, 0, 0, 0, 0, 0, 0
[    0.276249] hpet0: 8 comparators, 64-bit 14.318180 MHz counter
[    0.278377] clocksource: Switched to clocksource tsc-early
[    0.287090] VFS: Disk quotas dquot_6.6.0
[    0.287100] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[    0.287148] pnp: PnP ACPI init
[    0.287262] system 00:00: [mem 0xfed40000-0xfed44fff] has been reserved
[    0.287265] system 00:00: Plug and Play ACPI device, IDs PNP0c01 (active)
[    0.287351] system 00:01: [io  0x0800-0x087f] has been reserved
[    0.287354] system 00:01: Plug and Play ACPI device, IDs PNP0c02 (active)
[    0.287368] pnp 00:02: Plug and Play ACPI device, IDs PNP0b00 (active)
[    0.287399] system 00:03: [io  0x1854-0x1857] has been reserved
[    0.287401] system 00:03: Plug and Play ACPI device, IDs INT3f0d PNP0c02 (active)
[    0.287494] system 00:04: [io  0x0290-0x029f] has been reserved
[    0.287495] system 00:04: [io  0x02a0-0x02af] has been reserved
[    0.287496] system 00:04: [io  0x0a00-0x0aff] has been reserved
[    0.287498] system 00:04: Plug and Play ACPI device, IDs PNP0c02 (active)
[    0.287539] system 00:05: [io  0x04d0-0x04d1] has been reserved
[    0.287541] system 00:05: Plug and Play ACPI device, IDs PNP0c02 (active)
[    0.287761] pnp 00:06: [dma 0 disabled]
[    0.287795] pnp 00:06: Plug and Play ACPI device, IDs PNP0501 (active)
[    0.288087] system 00:07: [mem 0xfed1c000-0xfed1ffff] has been reserved
[    0.288088] system 00:07: [mem 0xfed10000-0xfed17fff] has been reserved
[    0.288089] system 00:07: [mem 0xfed18000-0xfed18fff] has been reserved
[    0.288090] system 00:07: [mem 0xfed19000-0xfed19fff] has been reserved
[    0.288091] system 00:07: [mem 0xe0000000-0xefffffff] has been reserved
[    0.288092] system 00:07: [mem 0xfed20000-0xfed3ffff] has been reserved
[    0.288093] system 00:07: [mem 0xfed90000-0xfed93fff] has been reserved
[    0.288093] system 00:07: [mem 0xfed45000-0xfed8ffff] has been reserved
[    0.288094] system 00:07: [mem 0xff000000-0xffffffff] has been reserved
[    0.288095] system 00:07: [mem 0xfee00000-0xfeefffff] could not be reserved
[    0.288096] system 00:07: [mem 0xdffe0000-0xdffeffff] has been reserved
[    0.288097] system 00:07: [mem 0xdfff0000-0xdfffffff] has been reserved
[    0.288100] system 00:07: Plug and Play ACPI device, IDs PNP0c02 (active)
[    0.288277] pnp: PnP ACPI: found 8 devices
[    0.293626] clocksource: acpi_pm: mask: 0xffffff max_cycles: 0xffffff, max_idle_ns: 2085701024 ns
[    0.293667] NET: Registered protocol family 2
[    0.293764] tcp_listen_portaddr_hash hash table entries: 8192 (order: 5, 131072 bytes, linear)
[    0.293828] TCP established hash table entries: 131072 (order: 8, 1048576 bytes, linear)
[    0.293966] TCP bind hash table entries: 65536 (order: 8, 1048576 bytes, linear)
[    0.294048] TCP: Hash tables configured (established 131072 bind 65536)
[    0.294118] UDP hash table entries: 8192 (order: 6, 262144 bytes, linear)
[    0.294151] UDP-Lite hash table entries: 8192 (order: 6, 262144 bytes, linear)
[    0.294217] NET: Registered protocol family 1
[    0.294220] NET: Registered protocol family 44
[    0.294229] pci 0000:00:01.0: PCI bridge to [bus 01]
[    0.294230] pci 0000:00:01.0:   bridge window [io  0xe000-0xefff]
[    0.294233] pci 0000:00:01.0:   bridge window [mem 0xde000000-0xdf0fffff]
[    0.294234] pci 0000:00:01.0:   bridge window [mem 0xc0000000-0xd1ffffff 64bit pref]
[    0.294237] pci 0000:00:1c.0: PCI bridge to [bus 02]
[    0.294244] pci 0000:03:00.0: PCI bridge to [bus 04]
[    0.294259] pci 0000:00:1c.3: PCI bridge to [bus 03-04]
[    0.294267] pci 0000:00:1c.6: PCI bridge to [bus 05]
[    0.294270] pci 0000:00:1c.6:   bridge window [mem 0xdf100000-0xdf1fffff]
[    0.294276] pci_bus 0000:00: resource 4 [io  0x0000-0x0cf7 window]
[    0.294277] pci_bus 0000:00: resource 5 [io  0x0d00-0xffff window]
[    0.294278] pci_bus 0000:00: resource 6 [mem 0x000a0000-0x000bffff window]
[    0.294279] pci_bus 0000:00: resource 7 [mem 0x000d0000-0x000d3fff window]
[    0.294279] pci_bus 0000:00: resource 8 [mem 0x000d4000-0x000d7fff window]
[    0.294280] pci_bus 0000:00: resource 9 [mem 0x000d8000-0x000dbfff window]
[    0.294281] pci_bus 0000:00: resource 10 [mem 0x000dc000-0x000dffff window]
[    0.294282] pci_bus 0000:00: resource 11 [mem 0xc0000000-0xfeafffff window]
[    0.294283] pci_bus 0000:01: resource 0 [io  0xe000-0xefff]
[    0.294283] pci_bus 0000:01: resource 1 [mem 0xde000000-0xdf0fffff]
[    0.294284] pci_bus 0000:01: resource 2 [mem 0xc0000000-0xd1ffffff 64bit pref]
[    0.294285] pci_bus 0000:03: resource 4 [io  0x0000-0x0cf7 window]
[    0.294286] pci_bus 0000:03: resource 5 [io  0x0d00-0xffff window]
[    0.294287] pci_bus 0000:03: resource 6 [mem 0x000a0000-0x000bffff window]
[    0.294287] pci_bus 0000:03: resource 7 [mem 0x000d0000-0x000d3fff window]
[    0.294288] pci_bus 0000:03: resource 8 [mem 0x000d4000-0x000d7fff window]
[    0.294289] pci_bus 0000:03: resource 9 [mem 0x000d8000-0x000dbfff window]
[    0.294290] pci_bus 0000:03: resource 10 [mem 0x000dc000-0x000dffff window]
[    0.294291] pci_bus 0000:03: resource 11 [mem 0xc0000000-0xfeafffff window]
[    0.294291] pci_bus 0000:04: resource 4 [io  0x0000-0x0cf7 window]
[    0.294292] pci_bus 0000:04: resource 5 [io  0x0d00-0xffff window]
[    0.294293] pci_bus 0000:04: resource 6 [mem 0x000a0000-0x000bffff window]
[    0.294294] pci_bus 0000:04: resource 7 [mem 0x000d0000-0x000d3fff window]
[    0.294294] pci_bus 0000:04: resource 8 [mem 0x000d4000-0x000d7fff window]
[    0.294295] pci_bus 0000:04: resource 9 [mem 0x000d8000-0x000dbfff window]
[    0.294296] pci_bus 0000:04: resource 10 [mem 0x000dc000-0x000dffff window]
[    0.294297] pci_bus 0000:04: resource 11 [mem 0xc0000000-0xfeafffff window]
[    0.294297] pci_bus 0000:05: resource 1 [mem 0xdf100000-0xdf1fffff]
[    0.313410] pci 0000:00:1a.0: quirk_usb_early_handoff+0x0/0x6d5 took 18405 usecs
[    0.333407] pci 0000:00:1d.0: quirk_usb_early_handoff+0x0/0x6d5 took 19517 usecs
[    0.333422] pci 0000:01:00.0: Video device with shadowed ROM at [mem 0x000c0000-0x000dffff]
[    0.333431] pci 0000:01:00.1: D0 power state depends on 0000:01:00.0
[    0.333458] pci 0000:03:00.0: Disabling ASPM L0s/L1
[    0.333463] PCI: CLS 64 bytes, default 64
[    0.333491] Trying to unpack rootfs image as initramfs...
[    0.434638] Freeing initrd memory: 9732K
[    0.434643] PCI-DMA: Using software bounce buffering for IO (SWIOTLB)
[    0.434645] software IO TLB: mapped [mem 0xab8cf000-0xaf8cf000] (64MB)
[    0.434741] check: Scanning for low memory corruption every 60 seconds
[    0.434958] Initialise system trusted keyrings
[    0.434964] Key type blacklist registered
[    0.434994] workingset: timestamp_bits=41 max_order=22 bucket_order=0
[    0.435800] zbud: loaded
[    0.444456] Key type asymmetric registered
[    0.444457] Asymmetric key parser 'x509' registered
[    0.444463] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 245)
[    0.444492] io scheduler mq-deadline registered
[    0.444493] io scheduler kyber registered
[    0.444507] io scheduler bfq registered
[    0.444747] pcieport 0000:00:01.0: PME: Signaling with IRQ 24
[    0.444876] pcieport 0000:00:1c.0: PME: Signaling with IRQ 25
[    0.445009] pcieport 0000:00:1c.3: PME: Signaling with IRQ 26
[    0.445138] pcieport 0000:00:1c.6: PME: Signaling with IRQ 27
[    0.445197] shpchp: Standard Hot Plug PCI Controller Driver version: 0.4
[    0.445248] efifb: probing for efifb
[    0.445257] efifb: No BGRT, not showing boot graphics
[    0.445258] efifb: framebuffer at 0xd1000000, using 3072k, total 3072k
[    0.445259] efifb: mode is 1024x768x32, linelength=4096, pages=1
[    0.445259] efifb: scrolling: redraw
[    0.445260] efifb: Truecolor: size=8:8:8:8, shift=24:16:8:0
[    0.445317] Console: switching to colour frame buffer device 128x48
[    0.446361] fb0: EFI VGA frame buffer device
[    0.446366] intel_idle: MWAIT substates: 0x42120
[    0.446367] intel_idle: v0.5.1 model 0x3C
[    0.446493] intel_idle: Local APIC timer is reliable in all C-states
[    0.446546] input: Power Button as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0C:00/input/input0
[    0.446560] ACPI: Power Button [PWRB]
[    0.446587] input: Power Button as /devices/LNXSYSTM:00/LNXPWRBN:00/input/input1
[    0.451016] ACPI: Power Button [PWRF]
[    0.451790] thermal LNXTHERM:00: registered as thermal_zone0
[    0.451791] ACPI: Thermal Zone [TZ00] (28 C)
[    0.451997] thermal LNXTHERM:01: registered as thermal_zone1
[    0.451998] ACPI: Thermal Zone [TZ01] (30 C)
[    0.452201] Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled
[    0.452342] 00:06: ttyS0 at I/O 0x3f8 (irq = 4, base_baud = 115200) is a 16550A
[    0.453264] AMD-Vi: AMD IOMMUv2 driver by Joerg Roedel <jroedel@suse.de>
[    0.453265] AMD-Vi: AMD IOMMUv2 functionality not available on this system
[    0.453722] nvme nvme0: pci function 0000:05:00.0
[    0.453731] nvme 0000:05:00.0: enabling device (0000 -> 0002)
[    0.453741] ahci 0000:00:1f.2: version 3.0
[    0.453932] ahci 0000:00:1f.2: AHCI 0001.0300 32 slots 6 ports 6 Gbps 0x3 impl SATA mode
[    0.453933] ahci 0000:00:1f.2: flags: 64bit ncq led clo pio slum part ems apst
[    0.458477] nvme nvme0: missing or invalid SUBNQN field.
[    0.458491] nvme nvme0: Shutdown timeout set to 8 seconds
[    0.465354] scsi host0: ahci
[    0.465563] scsi host1: ahci
[    0.465698] scsi host2: ahci
[    0.465779] scsi host3: ahci
[    0.465832] scsi host4: ahci
[    0.465879] scsi host5: ahci
[    0.465904] ata1: SATA max UDMA/133 abar m2048@0xdf235000 port 0xdf235100 irq 29
[    0.465905] ata2: SATA max UDMA/133 abar m2048@0xdf235000 port 0xdf235180 irq 29
[    0.465906] ata3: DUMMY
[    0.465906] ata4: DUMMY
[    0.465906] ata5: DUMMY
[    0.465907] ata6: DUMMY
[    0.465936] usbcore: registered new interface driver usbserial_generic
[    0.465939] usbserial: USB Serial support registered for generic
[    0.465951] rtc_cmos 00:02: RTC can wake from S4
[    0.466095] rtc_cmos 00:02: registered as rtc0
[    0.466130] rtc_cmos 00:02: setting system clock to 2020-08-20T11:20:48 UTC (1597922448)
[    0.466140] rtc_cmos 00:02: alarms up to one month, y3k, 242 bytes nvram, hpet irqs
[    0.466180] intel_pstate: Intel P-state driver initializing
[    0.466342] ledtrig-cpu: registered to indicate activity on CPUs
[    0.466390] drop_monitor: Initializing network drop monitor service
[    0.466492] NET: Registered protocol family 10
[    0.467223] nvme nvme0: 4/0/0 default/read/poll queues
[    0.470274] Segment Routing with IPv6
[    0.470275] RPL Segment Routing with IPv6
[    0.470289] NET: Registered protocol family 17
[    0.470532] microcode: sig=0x306c3, pf=0x2, revision=0x19
[    0.470591] microcode: Microcode Update Driver: v2.2.
[    0.470594] IPI shorthand broadcast: enabled
[    0.470599] sched_clock: Marking stable (470429791, 158492)->(489338834, -18750551)
[    0.470660] registered taskstats version 1
[    0.470667] Loading compiled-in X.509 certificates
[    0.471930]  nvme0n1: p1
[    0.472752] Loaded X.509 cert 'Build time autogenerated kernel key: 0493c22ef2ae5686379af54b7613a8d04c5296fb'
[    0.472855] zswap: loaded using pool lz4/z3fold
[    0.472947] Key type ._fscrypt registered
[    0.472948] Key type .fscrypt registered
[    0.472948] Key type fscrypt-provisioning registered
[    0.473449] PM:   Magic number: 0:951:327
[    0.473592] RAS: Correctable Errors collector initialized.
[    0.781416] ata2: SATA link up 6.0 Gbps (SStatus 133 SControl 300)
[    0.781429] ata1: SATA link up 6.0 Gbps (SStatus 133 SControl 300)
[    0.782377] ata2.00: ATA-9: ST1000DM003-1CH162, HP34, max UDMA/100
[    0.782378] ata2.00: 1953525168 sectors, multi 16: LBA48 NCQ (depth 32), AA
[    0.782386] ata1.00: ATA-9: KINGSTON SHSS37A480G, SAFM001B, max UDMA/133
[    0.782387] ata1.00: 937703088 sectors, multi 0: LBA48 NCQ (depth 32), AA
[    0.782665] ata1.00: configured for UDMA/133
[    0.782733] scsi 0:0:0:0: Direct-Access     ATA      KINGSTON SHSS37A 001B PQ: 0 ANSI: 5
[    0.782851] sd 0:0:0:0: [sda] 937703088 512-byte logical blocks: (480 GB/447 GiB)
[    0.782861] sd 0:0:0:0: [sda] Write Protect is off
[    0.782862] sd 0:0:0:0: [sda] Mode Sense: 00 3a 00 00
[    0.782870] sd 0:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[    0.783129] ata2.00: configured for UDMA/100
[    0.783252] scsi 1:0:0:0: Direct-Access     ATA      ST1000DM003-1CH1 HP34 PQ: 0 ANSI: 5
[    0.783357] sd 1:0:0:0: [sdb] 1953525168 512-byte logical blocks: (1.00 TB/932 GiB)
[    0.783359] sd 1:0:0:0: [sdb] 4096-byte physical blocks
[    0.783364] sd 1:0:0:0: [sdb] Write Protect is off
[    0.783365] sd 1:0:0:0: [sdb] Mode Sense: 00 3a 00 00
[    0.783373] sd 1:0:0:0: [sdb] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[    0.784453]  sda: sda2 sda4 sda7 sda8
[    0.784827] sd 0:0:0:0: [sda] Attached SCSI disk
[    0.804572]  sdb: sdb1 sdb2
[    0.804917] sd 1:0:0:0: [sdb] Attached SCSI disk
[    0.805622] Freeing unused decrypted memory: 2040K
[    0.805834] Freeing unused kernel image (initmem) memory: 1648K
[    0.817682] Write protecting the kernel read-only data: 24576k
[    0.818083] Freeing unused kernel image (text/rodata gap) memory: 2044K
[    0.818164] Freeing unused kernel image (rodata/data gap) memory: 280K
[    0.855090] x86/mm: Checked W+X mappings: passed, no W+X pages found.
[    0.855091] x86/mm: Checking user space page tables
[    0.891061] x86/mm: Checked W+X mappings: passed, no W+X pages found.
[    0.891063] Run /init as init process
[    0.891063]   with arguments:
[    0.891064]     /init
[    0.891064]   with environment:
[    0.891064]     HOME=/
[    0.891065]     TERM=linux
[    0.954801] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[    0.955448] ehci-pci: EHCI PCI platform driver
[    0.955577] ehci-pci 0000:00:1a.0: EHCI Host Controller
[    0.955581] ehci-pci 0000:00:1a.0: new USB bus registered, assigned bus number 1
[    0.955590] ehci-pci 0000:00:1a.0: debug port 2
[    0.959777] ehci-pci 0000:00:1a.0: cache line size of 64 is not supported
[    0.959788] ehci-pci 0000:00:1a.0: irq 16, io mem 0xdf237000
[    0.970015] ehci-pci 0000:00:1a.0: USB 2.0 started, EHCI 1.00
[    0.970049] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.08
[    0.970050] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    0.970051] usb usb1: Product: EHCI Host Controller
[    0.970052] usb usb1: Manufacturer: Linux 5.8.1-arch1-1 ehci_hcd
[    0.970053] usb usb1: SerialNumber: 0000:00:1a.0
[    0.970159] hub 1-0:1.0: USB hub found
[    0.970163] hub 1-0:1.0: 2 ports detected
[    0.970288] xhci_hcd 0000:00:14.0: xHCI Host Controller
[    0.970293] xhci_hcd 0000:00:14.0: new USB bus registered, assigned bus number 2
[    0.971366] xhci_hcd 0000:00:14.0: hcc params 0x200077c1 hci version 0x100 quirks 0x0000000000009810
[    0.971369] xhci_hcd 0000:00:14.0: cache line size of 64 is not supported
[    0.971496] usb usb2: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.08
[    0.971497] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    0.971498] usb usb2: Product: xHCI Host Controller
[    0.971498] usb usb2: Manufacturer: Linux 5.8.1-arch1-1 xhci-hcd
[    0.971499] usb usb2: SerialNumber: 0000:00:14.0
[    0.971626] hub 2-0:1.0: USB hub found
[    0.971668] hub 2-0:1.0: 14 ports detected
[    0.972276] ehci-pci 0000:00:1d.0: EHCI Host Controller
[    0.972280] ehci-pci 0000:00:1d.0: new USB bus registered, assigned bus number 3
[    0.972302] ehci-pci 0000:00:1d.0: debug port 2
[    0.972316] xhci_hcd 0000:00:14.0: xHCI Host Controller
[    0.972318] xhci_hcd 0000:00:14.0: new USB bus registered, assigned bus number 4
[    0.972320] xhci_hcd 0000:00:14.0: Host supports USB 3.0 SuperSpeed
[    0.972348] usb usb4: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.08
[    0.972349] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    0.972350] usb usb4: Product: xHCI Host Controller
[    0.972350] usb usb4: Manufacturer: Linux 5.8.1-arch1-1 xhci-hcd
[    0.972351] usb usb4: SerialNumber: 0000:00:14.0
[    0.972457] hub 4-0:1.0: USB hub found
[    0.972469] hub 4-0:1.0: 6 ports detected
[    0.976207] ehci-pci 0000:00:1d.0: cache line size of 64 is not supported
[    0.976226] ehci-pci 0000:00:1d.0: irq 23, io mem 0xdf236000
[    0.986691] ehci-pci 0000:00:1d.0: USB 2.0 started, EHCI 1.00
[    0.986722] usb usb3: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.08
[    0.986723] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    0.986724] usb usb3: Product: EHCI Host Controller
[    0.986725] usb usb3: Manufacturer: Linux 5.8.1-arch1-1 ehci_hcd
[    0.986726] usb usb3: SerialNumber: 0000:00:1d.0
[    0.986876] hub 3-0:1.0: USB hub found
[    0.986880] hub 3-0:1.0: 2 ports detected
[    1.000708] random: fast init done
[    1.298420] usb 1-1: new high-speed USB device number 2 using ehci-pci
[    1.301747] usb 2-5: new high-speed USB device number 2 using xhci_hcd
[    1.315082] usb 3-1: new high-speed USB device number 2 using ehci-pci
[    1.408525] EXT4-fs (sda7): mounted filesystem with ordered data mode. Opts: (null)
[    1.441718] tsc: Refined TSC clocksource calibration: 3398.030 MHz
[    1.441721] clocksource: tsc: mask: 0xffffffffffffffff max_cycles: 0x30fb0a05005, max_idle_ns: 440795375639 ns
[    1.441739] clocksource: Switched to clocksource tsc
[    1.442052] usb 2-5: New USB device found, idVendor=1a40, idProduct=0101, bcdDevice= 1.11
[    1.442053] usb 2-5: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[    1.442054] usb 2-5: Product: USB 2.0 Hub
[    1.442512] hub 2-5:1.0: USB hub found
[    1.442533] hub 2-5:1.0: 4 ports detected
[    1.445363] usb 1-1: New USB device found, idVendor=8087, idProduct=8009, bcdDevice= 0.00
[    1.445374] usb 1-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[    1.445555] hub 1-1:1.0: USB hub found
[    1.445670] hub 1-1:1.0: 6 ports detected
[    1.462147] usb 3-1: New USB device found, idVendor=8087, idProduct=8001, bcdDevice= 0.00
[    1.462148] usb 3-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[    1.462381] hub 3-1:1.0: USB hub found
[    1.462488] hub 3-1:1.0: 8 ports detected
[    1.538947] systemd[1]: systemd 246.2-1-arch running in system mode. (+PAM +AUDIT -SELINUX -IMA -APPARMOR +SMACK -SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +ZSTD +SECCOMP +BLKID +ELFUTILS +KMOD +IDN2 -IDN +PCRE2 default-hierarchy=hybrid)
[    1.555116] systemd[1]: Detected architecture x86-64.
[    1.565106] usb 2-8: new full-speed USB device number 3 using xhci_hcd
[    1.601098] systemd[1]: Set hostname to <localhost>.
[    1.665137] random: systemd-crontab: uninitialized urandom read (24 bytes read)
[    1.706619] usb 2-8: string descriptor 0 read error: -22
[    1.706622] usb 2-8: New USB device found, idVendor=13d3, idProduct=3393, bcdDevice= 0.02
[    1.706623] usb 2-8: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[    1.828386] usb 2-10: new full-speed USB device number 4 using xhci_hcd
[    1.833177] systemd[1]: /usr/lib/systemd/system/cron-failure@.service:11: Special user nobody configured, this is not safe!
[    1.834337] systemd[1]: /usr/lib/systemd/system/cron-failure@.service:11: Special user nobody configured, this is not safe!
[    1.835307] systemd[1]: /usr/lib/systemd/system/cron-failure@.service:11: Special user nobody configured, this is not safe!
[    1.836221] systemd[1]: /usr/lib/systemd/system/cron-failure@.service:11: Special user nobody configured, this is not safe!
[    1.837171] systemd[1]: /usr/lib/systemd/system/cron-failure@.service:11: Special user nobody configured, this is not safe!
[    1.838060] systemd[1]: /usr/lib/systemd/system/cron-failure@.service:11: Special user nobody configured, this is not safe!
[    1.838981] systemd[1]: /usr/lib/systemd/system/cron-failure@.service:11: Special user nobody configured, this is not safe!
[    1.839888] systemd[1]: /usr/lib/systemd/system/cron-failure@.service:11: Special user nobody configured, this is not safe!
[    1.840796] systemd[1]: /usr/lib/systemd/system/cron-failure@.service:11: Special user nobody configured, this is not safe!
[    1.841371] systemd[1]: /usr/lib/systemd/system/atopacct.service:10: PIDFile= references a path below legacy directory /var/run/, updating /var/run/atopacctd.pid → /run/atopacctd.pid; please update the unit file accordingly.
[    1.842118] systemd[1]: Queued start job for default target Graphical Interface.
[    1.842782] systemd[1]: Created slice system-getty.slice.
[    1.843010] systemd[1]: Created slice system-modprobe.slice.
[    1.843171] systemd[1]: Created slice system-systemd\x2dfsck.slice.
[    1.843370] systemd[1]: Created slice User and Session Slice.
[    1.843445] systemd[1]: Started Dispatch Password Requests to Console Directory Watch.
[    1.843514] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[    1.843659] systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point.
[    1.843725] systemd[1]: Reached target Local Encrypted Volumes.
[    1.843781] systemd[1]: Reached target Remote File Systems.
[    1.843820] systemd[1]: Reached target Slices.
[    1.843859] systemd[1]: Reached target Swap.
[    1.843929] systemd[1]: Listening on Device-mapper event daemon FIFOs.
[    1.844150] systemd[1]: Listening on LVM2 metadata daemon socket.
[    1.844359] systemd[1]: Listening on LVM2 poll daemon socket.
[    1.845497] systemd[1]: Listening on Process Core Dump Socket.
[    1.845634] systemd[1]: Listening on Journal Audit Socket.
[    1.845736] systemd[1]: Listening on Journal Socket (/dev/log).
[    1.845840] systemd[1]: Listening on Journal Socket.
[    1.845949] systemd[1]: Listening on udev Control Socket.
[    1.846040] systemd[1]: Listening on udev Kernel Socket.
[    1.846578] systemd[1]: Mounting Huge Pages File System...
[    1.847172] systemd[1]: Mounting POSIX Message Queue File System...
[    1.847822] systemd[1]: Mounting Kernel Debug File System...
[    1.848431] systemd[1]: Mounting Kernel Trace File System...
[    1.849157] systemd[1]: Mounting Temporary Directory (/tmp)...
[    1.849848] systemd[1]: Starting Create list of static device nodes for the current kernel...
[    1.850410] systemd[1]: Starting Monitoring of LVM2 mirrors, snapshots etc. using dmeventd or progress polling...
[    1.850985] systemd[1]: Starting Load Kernel Module drm...
[    1.852273] systemd[1]: Starting Set Up Additional Binary Formats...
[    1.852358] systemd[1]: Condition check resulted in File System Check on Root Device being skipped.
[    1.853461] systemd[1]: Starting Journal Service...
[    1.855777] systemd[1]: Starting Load Kernel Modules...
[    1.856637] systemd[1]: Starting Remount Root and Kernel File Systems...
[    1.856732] systemd[1]: Condition check resulted in Repartition Root Disk being skipped.
[    1.857326] systemd[1]: Starting Coldplug All udev Devices...
[    1.858454] systemd[1]: Mounted Huge Pages File System.
[    1.858583] systemd[1]: Mounted POSIX Message Queue File System.
[    1.858995] Linux agpgart interface v0.103
[    1.859047] systemd[1]: Mounted Kernel Debug File System.
[    1.859497] systemd[1]: Mounted Kernel Trace File System.
[    1.859917] systemd[1]: Mounted Temporary Directory (/tmp).
[    1.860568] systemd[1]: Finished Create list of static device nodes for the current kernel.
[    1.861046] systemd[1]: proc-sys-fs-binfmt_misc.automount: Got automount request for /proc/sys/fs/binfmt_misc, triggered by 224 (systemd-binfmt)
[    1.861676] systemd[1]: Mounting Arbitrary Executable File Formats File System...
[    1.861896] EXT4-fs (sda7): re-mounted. Opts: (null)
[    1.863108] systemd[1]: Finished Remount Root and Kernel File Systems.
[    1.864024] systemd[1]: Mounted Arbitrary Executable File Formats File System.
[    1.864533] systemd[1]: Condition check resulted in First Boot Wizard being skipped.
[    1.865476] vfs_monitor: loading out-of-tree module taints kernel.
[    1.865491] vfs_monitor: module verification failed: signature and/or required key missing - tainting kernel
[    1.865774] mp: /, major: 8, minor: 7
[    1.865775] mp: /tmp, major: 0, minor: 46
[    1.865775] partition count: 2, comm[226]: systemd-modules, path: /usr/lib/systemd/systemd-modules-load, cmdline: /usr/lib/systemd/systemd-modules-load
[    1.868491] systemd[1]: Condition check resulted in Rebuild Hardware Database being skipped.
[    1.868821] random: lvm: uninitialized urandom read (4 bytes read)
[    1.870635] systemd[1]: Starting Load/Save Random Seed...
[    1.871065] systemd[1]: Condition check resulted in Create System Users being skipped.
[    1.871572] systemd[1]: Starting Create Static Device Nodes in /dev...
[    1.882094] systemd[1]: Finished Set Up Additional Binary Formats.
[    1.888636] systemd[1]: Finished Create Static Device Nodes in /dev.
[    1.889939] systemd[1]: Starting Rule-based Manager for Device Events and Files...
[    1.905562] register_kretprobes 10 ok
[    1.905782] systemd[1]: modprobe@drm.service: Succeeded.
[    1.906014] systemd[1]: Finished Load Kernel Module drm.
[    1.909888] i2c /dev entries driver
[    1.910560] systemd[1]: Finished Load Kernel Modules.
[    1.911092] systemd[1]: Condition check resulted in FUSE Control File System being skipped.
[    1.911658] systemd[1]: Mounting Kernel Configuration File System...
[    1.912560] systemd[1]: Starting Apply Kernel Variables...
[    1.913472] systemd[1]: Mounted Kernel Configuration File System.
[    1.919717] systemd[1]: Finished Apply Kernel Variables.
[    1.928221] systemd[1]: Finished Coldplug All udev Devices.
[    1.971443] usb 2-10: New USB device found, idVendor=28de, idProduct=1142, bcdDevice= 0.01
[    1.971445] usb 2-10: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[    1.971445] usb 2-10: Product: Steam Controller
[    1.971446] usb 2-10: Manufacturer: Valve Software
[    2.082697] systemd[1]: Started Journal Service.
[    2.083144] audit: type=1130 audit(1597922450.112:2): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-journald comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[    2.095082] usb 2-13: new full-speed USB device number 5 using xhci_hcd
[    2.181097] audit: type=1130 audit(1597922450.208:3): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-udevd comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[    2.182253] audit: type=1130 audit(1597922450.212:4): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=lvm2-lvmetad comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[    2.237159] usb 2-13: New USB device found, idVendor=046d, idProduct=c223, bcdDevice= 1.03
[    2.237161] usb 2-13: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[    2.237162] usb 2-13: Product: Logitech G15 Keyboard
[    2.237163] usb 2-13: Manufacturer: Logitech
[    2.237785] hub 2-13:1.0: USB hub found
[    2.238053] hub 2-13:1.0: 4 ports detected
[    2.294689] e1000e: Intel(R) PRO/1000 Network Driver - 3.2.6-k
[    2.294690] e1000e: Copyright(c) 1999 - 2015 Intel Corporation.
[    2.294839] e1000e 0000:00:19.0: Interrupt Throttling Rate (ints/sec) set to dynamic conservative mode
[    2.295343] audit: type=1130 audit(1597922450.322:5): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-journal-flush comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[    2.328180] ACPI Warning: SystemIO range 0x0000000000001828-0x000000000000182F conflicts with OpRegion 0x0000000000001800-0x000000000000187F (\PMIO) (20200528/utaddress-204)
[    2.328184] ACPI: If an ACPI driver is available for this device, you should use it instead of the native driver
[    2.328186] ACPI Warning: SystemIO range 0x0000000000001C40-0x0000000000001C4F conflicts with OpRegion 0x0000000000001C00-0x0000000000001C7F (\_GPE.GPBX) (20200528/utaddress-204)
[    2.328188] ACPI Warning: SystemIO range 0x0000000000001C40-0x0000000000001C4F conflicts with OpRegion 0x0000000000001C00-0x0000000000001FFF (\GPR) (20200528/utaddress-204)
[    2.328189] ACPI: If an ACPI driver is available for this device, you should use it instead of the native driver
[    2.328190] ACPI Warning: SystemIO range 0x0000000000001C30-0x0000000000001C3F conflicts with OpRegion 0x0000000000001C00-0x0000000000001C7F (\_GPE.GPBX) (20200528/utaddress-204)
[    2.328191] ACPI Warning: SystemIO range 0x0000000000001C30-0x0000000000001C3F conflicts with OpRegion 0x0000000000001C00-0x0000000000001C3F (\GPRL) (20200528/utaddress-204)
[    2.328193] ACPI Warning: SystemIO range 0x0000000000001C30-0x0000000000001C3F conflicts with OpRegion 0x0000000000001C00-0x0000000000001FFF (\GPR) (20200528/utaddress-204)
[    2.328194] ACPI: If an ACPI driver is available for this device, you should use it instead of the native driver
[    2.328195] ACPI Warning: SystemIO range 0x0000000000001C00-0x0000000000001C2F conflicts with OpRegion 0x0000000000001C00-0x0000000000001C7F (\_GPE.GPBX) (20200528/utaddress-204)
[    2.328196] ACPI Warning: SystemIO range 0x0000000000001C00-0x0000000000001C2F conflicts with OpRegion 0x0000000000001C00-0x0000000000001C3F (\GPRL) (20200528/utaddress-204)
[    2.328197] ACPI Warning: SystemIO range 0x0000000000001C00-0x0000000000001C2F conflicts with OpRegion 0x0000000000001C00-0x0000000000001FFF (\GPR) (20200528/utaddress-204)
[    2.328199] ACPI: If an ACPI driver is available for this device, you should use it instead of the native driver
[    2.328199] lpc_ich: Resource conflict(s) found affecting gpio_ich
[    2.338705] input: PC Speaker as /devices/platform/pcspkr/input/input2
[    2.361751] usb 2-14: new full-speed USB device number 6 using xhci_hcd
[    2.368847] RAPL PMU: API unit is 2^-32 Joules, 3 fixed counters, 655360 ms ovfl timer
[    2.368848] RAPL PMU: hw unit of domain pp0-core 2^-14 Joules
[    2.368849] RAPL PMU: hw unit of domain package 2^-14 Joules
[    2.368849] RAPL PMU: hw unit of domain dram 2^-14 Joules
[    2.374582] e1000e 0000:00:19.0 0000:00:19.0 (uninitialized): registered PHC clock
[    2.386115] i801_smbus 0000:00:1f.3: SPD Write Disable is set
[    2.386137] i801_smbus 0000:00:1f.3: SMBus using PCI interrupt
[    2.386863] cryptd: max_cpu_qlen set to 1000
[    2.387178] i2c i2c-0: 2/4 memory slots populated (from DMI)
[    2.387993] i2c i2c-0: Successfully instantiated SPD at 0x50
[    2.389517] i2c i2c-0: Successfully instantiated SPD at 0x52
[    2.397241] AVX2 version of gcm_enc/dec engaged.
[    2.397242] AES CTR mode by8 optimization enabled
[    2.429529] asus_wmi: ASUS WMI generic driver loaded
[    2.434423] asus_wmi: Initialization: 0x0
[    2.434459] asus_wmi: BIOS WMI version: 0.9
[    2.434501] asus_wmi: SFUN value: 0x0
[    2.434503] eeepc-wmi eeepc-wmi: Detected ASUSWMI, use DCTS
[    2.435022] input: Eee PC WMI hotkeys as /devices/platform/eeepc-wmi/input/input3
[    2.445292] e1000e 0000:00:19.0 eth0: (PCI Express:2.5GT/s:Width x1) 10:c3:7b:6d:d1:82
[    2.445305] e1000e 0000:00:19.0 eth0: Intel(R) PRO/1000 Network Connection
[    2.445328] e1000e 0000:00:19.0 eth0: MAC: 11, PHY: 12, PBA No: FFFFFF-0FF
[    2.472313] e1000e 0000:00:19.0 eno1: renamed from eth0
[    2.483820] iTCO_vendor_support: vendor-support=0
[    2.484014] at24 0-0050: supply vcc not found, using dummy regulator
[    2.495218] at24 0-0050: 256 byte spd EEPROM, read-only
[    2.495242] at24 0-0052: supply vcc not found, using dummy regulator
[    2.495748] at24 0-0052: 256 byte spd EEPROM, read-only
[    2.502775] usb 2-14: New USB device found, idVendor=046d, idProduct=c332, bcdDevice= 3.01
[    2.502776] usb 2-14: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[    2.502777] usb 2-14: Product: Gaming Mouse G502
[    2.502778] usb 2-14: Manufacturer: Logitech
[    2.502779] usb 2-14: SerialNumber: 0668354E3630
[    2.517256] snd_hda_intel 0000:00:1b.0: enabling device (0000 -> 0002)
[    2.517754] snd_hda_intel 0000:01:00.1: Disabling MSI
[    2.517758] snd_hda_intel 0000:01:00.1: Handle vga_switcheroo audio client
[    2.528527] iTCO_wdt: Intel TCO WatchDog Timer Driver v1.11
[    2.528563] iTCO_wdt: Found a 9 Series TCO device (Version=2, TCOBASE=0x1860)
[    2.529092] iTCO_wdt: initialized. heartbeat=30 sec (nowayout=0)
[    2.543173] audit: type=1130 audit(1597922450.572:6): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=lvm2-monitor comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[    2.575054] usb 2-13.1: new low-speed USB device number 7 using xhci_hcd
[    2.578006] hid: raw HID events driver (C) Jiri Kosina
[    2.583143] input: HDA NVidia HDMI/DP,pcm=3 as /devices/pci0000:00/0000:00:01.0/0000:01:00.1/sound/card1/input4
[    2.583174] input: HDA NVidia HDMI/DP,pcm=7 as /devices/pci0000:00/0000:00:01.0/0000:01:00.1/sound/card1/input5
[    2.583198] input: HDA NVidia HDMI/DP,pcm=8 as /devices/pci0000:00/0000:00:01.0/0000:01:00.1/sound/card1/input6
[    2.583223] input: HDA NVidia HDMI/DP,pcm=9 as /devices/pci0000:00/0000:00:01.0/0000:01:00.1/sound/card1/input7
[    2.583248] input: HDA NVidia HDMI/DP,pcm=10 as /devices/pci0000:00/0000:00:01.0/0000:01:00.1/sound/card1/input8
[    2.583274] input: HDA NVidia HDMI/DP,pcm=11 as /devices/pci0000:00/0000:00:01.0/0000:01:00.1/sound/card1/input9
[    2.583340] input: HDA NVidia HDMI/DP,pcm=12 as /devices/pci0000:00/0000:00:01.0/0000:01:00.1/sound/card1/input10
[    2.585058] snd_hda_codec_realtek hdaudioC0D0: autoconfig for ALC892: line_outs=3 (0x14/0x15/0x16/0x0/0x0) type:line
[    2.585060] snd_hda_codec_realtek hdaudioC0D0:    speaker_outs=0 (0x0/0x0/0x0/0x0/0x0)
[    2.585061] snd_hda_codec_realtek hdaudioC0D0:    hp_outs=1 (0x1b/0x0/0x0/0x0/0x0)
[    2.585061] snd_hda_codec_realtek hdaudioC0D0:    mono: mono_out=0x0
[    2.585063] snd_hda_codec_realtek hdaudioC0D0:    dig-out=0x11/0x1e
[    2.585064] snd_hda_codec_realtek hdaudioC0D0:    inputs:
[    2.585065] snd_hda_codec_realtek hdaudioC0D0:      Front Mic=0x19
[    2.585065] snd_hda_codec_realtek hdaudioC0D0:      Rear Mic=0x18
[    2.585066] snd_hda_codec_realtek hdaudioC0D0:      Line=0x1a
[    2.589910] audit: type=1130 audit(1597922450.618:7): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-fsck@dev-disk-by\x2duuid-d29ae3ee\x2d7452\x2d45a3\x2d899a\x2d86cc6964b0db comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[    2.597209] usbcore: registered new interface driver usbhid
[    2.597210] usbhid: USB HID core driver
[    2.600061] EXT4-fs (sda8): mounted filesystem with ordered data mode. Opts: (null)
[    2.600075] partition /home [8, 8] added, comm[316]: mount
[    2.603315] input: HDA Intel PCH Front Mic as /devices/pci0000:00/0000:00:1b.0/sound/card0/input11
[    2.603344] input: HDA Intel PCH Rear Mic as /devices/pci0000:00/0000:00:1b.0/sound/card0/input12
[    2.603370] input: HDA Intel PCH Line as /devices/pci0000:00/0000:00:1b.0/sound/card0/input13
[    2.603395] input: HDA Intel PCH Line Out Front as /devices/pci0000:00/0000:00:1b.0/sound/card0/input14
[    2.603418] input: HDA Intel PCH Line Out Surround as /devices/pci0000:00/0000:00:1b.0/sound/card0/input15
[    2.603444] input: HDA Intel PCH Line Out CLFE as /devices/pci0000:00/0000:00:1b.0/sound/card0/input16
[    2.603469] input: HDA Intel PCH Front Headphone as /devices/pci0000:00/0000:00:1b.0/sound/card0/input17
[    2.612243] input: Valve Software Steam Controller Keyboard as /devices/pci0000:00/0000:00:14.0/usb2/2-10/2-10:1.0/0003:28DE:1142.0001/input/input18
[    2.615177] audit: type=1130 audit(1597922450.645:8): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-fsck@dev-disk-by\x2duuid-40AF\x2dD3B9 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[    2.668446] input: Valve Software Steam Controller Mouse as /devices/pci0000:00/0000:00:14.0/usb2/2-10/2-10:1.0/0003:28DE:1142.0001/input/input19
[    2.668483] hid-generic 0003:28DE:1142.0001: input,hidraw0: USB HID v1.11 Keyboard [Valve Software Steam Controller] on usb-0000:00:14.0-10/input0
[    2.668570] hid-generic 0003:28DE:1142.0002: hiddev0,hidraw1: USB HID v1.11 Device [Valve Software Steam Controller] on usb-0000:00:14.0-10/input1
[    2.668637] hid-generic 0003:28DE:1142.0003: hiddev1,hidraw2: USB HID v1.11 Device [Valve Software Steam Controller] on usb-0000:00:14.0-10/input2
[    2.668699] hid-generic 0003:28DE:1142.0004: hiddev2,hidraw3: USB HID v1.11 Device [Valve Software Steam Controller] on usb-0000:00:14.0-10/input3
[    2.668760] hid-generic 0003:28DE:1142.0005: hiddev3,hidraw4: USB HID v1.11 Device [Valve Software Steam Controller] on usb-0000:00:14.0-10/input4
[    2.668825] input: Logitech Gaming Mouse G502 as /devices/pci0000:00/0000:00:14.0/usb2/2-14/2-14:1.0/0003:046D:C332.0006/input/input20
[    2.668853] hid-generic 0003:046D:C332.0006: input,hidraw5: USB HID v1.11 Mouse [Logitech Gaming Mouse G502] on usb-0000:00:14.0-14/input0
[    2.668999] input: Logitech Gaming Mouse G502 Keyboard as /devices/pci0000:00/0000:00:14.0/usb2/2-14/2-14:1.1/0003:046D:C332.0007/input/input21
[    2.669641] Bluetooth: Core ver 2.22
[    2.669650] NET: Registered protocol family 31
[    2.669650] Bluetooth: HCI device and connection manager initialized
[    2.669652] Bluetooth: HCI socket layer initialized
[    2.669653] Bluetooth: L2CAP socket layer initialized
[    2.669655] Bluetooth: SCO socket layer initialized
[    2.670850] usb 2-13.1: New USB device found, idVendor=046d, idProduct=c221, bcdDevice= 1.70
[    2.670851] usb 2-13.1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[    2.670852] usb 2-13.1: Product: Logitech Gaming Keyboard
[    2.670853] usb 2-13.1: Manufacturer: Logitech
[    2.673995] partition /boot [8, 2] added, comm[322]: mount
[    2.674015] input: Logitech Logitech Gaming Keyboard as /devices/pci0000:00/0000:00:14.0/usb2/2-13/2-13.1/2-13.1:1.0/0003:046D:C221.0008/input/input26
[    2.689552] usbcore: registered new interface driver btusb
[    2.692812] usbcore: registered new interface driver ath3k
[    2.701060] audit: type=1130 audit(1597922450.728:9): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-rfkill comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[    2.711126] audit: type=1130 audit(1597922450.738:10): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-tmpfiles-setup comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[    2.725192] input: Logitech Gaming Mouse G502 Consumer Control as /devices/pci0000:00/0000:00:14.0/usb2/2-14/2-14:1.1/0003:046D:C332.0007/input/input22
[    2.735620] intel_rapl_common: Found RAPL domain package
[    2.735621] intel_rapl_common: Found RAPL domain core
[    2.735622] intel_rapl_common: Found RAPL domain dram
[    2.785157] hid-generic 0003:046D:C221.0008: input,hidraw6: USB HID v1.10 Keyboard [Logitech Logitech Gaming Keyboard] on usb-0000:00:14.0-13.1/input0
[    2.785267] input: Logitech Gaming Mouse G502 System Control as /devices/pci0000:00/0000:00:14.0/usb2/2-14/2-14:1.1/0003:046D:C332.0007/input/input23
[    2.785328] hid-generic 0003:046D:C332.0007: input,hiddev4,hidraw7: USB HID v1.11 Keyboard [Logitech Gaming Mouse G502] on usb-0000:00:14.0-14/input1
[    2.787978] input: Logitech Logitech Gaming Keyboard Consumer Control as /devices/pci0000:00/0000:00:14.0/usb2/2-13/2-13.1/2-13.1:1.1/0003:046D:C221.0009/input/input27
[    2.901841] hid-generic 0003:046D:C221.0009: input,hiddev5,hidraw8: USB HID v1.10 Device [Logitech Logitech Gaming Keyboard] on usb-0000:00:14.0-13.1/input1
[    2.903569] mousedev: PS/2 mouse device common for all mice
[    2.949892] input: Valve Software Steam Controller as /devices/pci0000:00/0000:00:14.0/usb2/2-10/2-10:1.0/0003:28DE:1142.0001/input/input29
[    2.965121] Process accounting resumed
[    2.968754] random: atopgpud: uninitialized urandom read (24 bytes read)
[    2.974074] random: dbus-daemon: uninitialized urandom read (12 bytes read)
[    2.978392] usb 2-13.4: new full-speed USB device number 8 using xhci_hcd
[    2.982252] nct6775: Enabling hardware monitor logical device mappings.
[    2.982261] nct6775: Found NCT6791D or compatible chip at 0x2e:0x290
[    2.982265] ACPI Warning: SystemIO range 0x0000000000000295-0x0000000000000296 conflicts with OpRegion 0x0000000000000290-0x0000000000000299 (\_GPE.HWM) (20200528/utaddress-204)
[    2.982272] ACPI: If an ACPI driver is available for this device, you should use it instead of the native driver
[    3.005152] hid-steam 0003:28DE:1142.0001: input,hidraw0: USB HID v1.11 Keyboard [Valve Software Steam Controller] on usb-0000:00:14.0-10/input0
[    3.005279] hid-steam 0003:28DE:1142.0002: hiddev0: USB HID v1.11 Device [Valve Software Steam Controller] on usb-0000:00:14.0-10/input1
[    3.005347] hid-steam 0003:28DE:1142.000A: hidraw1: USB HID v1.11 Device [Valve Software Steam Controller] on usb-0000:00:14.0-10/input1
[    3.033115] random: dbus-daemon: uninitialized urandom read (12 bytes read)
[    3.061722] hid-steam 0003:28DE:1142.0002: Steam wireless receiver connected
[    3.062152] hid-steam 0003:28DE:1142.0003: hiddev1: USB HID v1.11 Device [Valve Software Steam Controller] on usb-0000:00:14.0-10/input2
[    3.062255] hid-steam 0003:28DE:1142.000B: hidraw2: USB HID v1.11 Device [Valve Software Steam Controller] on usb-0000:00:14.0-10/input2
[    3.064569] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[    3.064570] Bluetooth: BNEP filters: protocol multicast
[    3.064572] Bluetooth: BNEP socket layer initialized
[    3.071114] usb 2-13.4: New USB device found, idVendor=046d, idProduct=c222, bcdDevice= 1.03
[    3.071115] usb 2-13.4: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[    3.071116] usb 2-13.4: Product: G15 Keyboard
[    3.071117] usb 2-13.4: Manufacturer: G15 Keyboard
[    3.073303] input: G15 Keyboard G15 Keyboard Keypad as /devices/pci0000:00/0000:00:14.0/usb2/2-13/2-13.4/2-13.4:1.0/0003:046D:C222.000C/input/input30
[    3.081726] NET: Registered protocol family 38
[    3.121725] hid-steam 0003:28DE:1142.0003: Steam wireless receiver connected
[    3.122224] hid-steam 0003:28DE:1142.0004: hiddev2: USB HID v1.11 Device [Valve Software Steam Controller] on usb-0000:00:14.0-10/input3
[    3.122324] hid-steam 0003:28DE:1142.000D: hidraw3: USB HID v1.11 Device [Valve Software Steam Controller] on usb-0000:00:14.0-10/input3
[    3.124955] nvidia: module license 'NVIDIA' taints kernel.
[    3.124956] Disabling lock debugging due to kernel taint
[    3.128535] hid-generic 0003:046D:C222.000C: input,hiddev6,hidraw9: USB HID v1.11 Keypad [G15 Keyboard G15 Keyboard] on usb-0000:00:14.0-13.4/input0
[    3.145057] random: crng init done
[    3.145059] random: 3 urandom warning(s) missed due to ratelimiting
[    3.151463] nvidia-nvlink: Nvlink Core is being initialized, major device number 238
[    3.152394] nvidia 0000:01:00.0: vgaarb: changed VGA decodes: olddecodes=io+mem,decodes=none:owns=io+mem
[    3.155191] hid-steam 0003:28DE:1142.0005: hiddev3: USB HID v1.11 Device [Valve Software Steam Controller] on usb-0000:00:14.0-10/input4
[    3.155258] hid-steam 0003:28DE:1142.000E: hidraw4: USB HID v1.11 Device [Valve Software Steam Controller] on usb-0000:00:14.0-10/input4
[    3.178407] hid-steam 0003:28DE:1142.0004: Steam wireless receiver connected
[    3.211739] hid-steam 0003:28DE:1142.0005: Steam wireless receiver connected
[    3.245285] lg-g15 0003:046D:C222.000C: hidraw9: USB HID v1.11 Keypad [G15 Keyboard G15 Keyboard] on usb-0000:00:14.0-13.4/input0
[    3.254397] NVRM: loading NVIDIA UNIX x86_64 Kernel Module  450.57  Sun Jul  5 14:42:25 UTC 2020
[    3.284666] nvidia-modeset: Loading NVIDIA Kernel Mode Setting Driver for UNIX platforms  450.57  Sun Jul  5 14:52:29 UTC 2020
[    3.289174] [drm] [nvidia-drm] [GPU ID 0x00000100] Loading driver
[    3.289176] [drm] Initialized nvidia-drm 0.0.0 20160202 for 0000:01:00.0 on minor 0
[    3.302675] input: Logitech Gaming Keyboard Gaming Keys as /devices/pci0000:00/0000:00:14.0/usb2/2-13/2-13.4/2-13.4:1.0/0003:046D:C222.000C/input/input32
[    6.737328] e1000e 0000:00:19.0 eno1: NIC Link is Up 1000 Mbps Full Duplex, Flow Control: Rx/Tx
[    6.737380] IPv6: ADDRCONF(NETDEV_CHANGE): eno1: link becomes ready
[    6.794755] kauditd_printk_skb: 22 callbacks suppressed
[    6.794756] audit: type=1130 audit(1597922454.822:33): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-wait-online comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[    7.706583] audit: type=1131 audit(1597922455.738:34): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-rfkill comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[   14.008053] audit: type=1131 audit(1597922462.038:35): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[   17.049901] audit: type=1130 audit(1597922465.078:36): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=cron-user-user-0 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[   17.049903] audit: type=1131 audit(1597922465.078:37): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=cron-user-user-0 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[   18.193091] audit: type=1100 audit(1597922466.222:38): pid=380 uid=0 auid=4294967295 ses=4294967295 msg='op=PAM:authentication grantors=pam_securetty,pam_shells,pam_faillock,pam_permit,pam_faillock acct="user" exe="/usr/bin/login" hostname=localhost addr=? terminal=tty1 res=success'
[   18.195409] audit: type=1101 audit(1597922466.225:39): pid=380 uid=0 auid=4294967295 ses=4294967295 msg='op=PAM:accounting grantors=pam_access,pam_unix,pam_permit,pam_time acct="user" exe="/usr/bin/login" hostname=localhost addr=? terminal=tty1 res=success'
[   18.196333] audit: type=1103 audit(1597922466.225:40): pid=380 uid=0 auid=4294967295 ses=4294967295 msg='op=PAM:setcred grantors=pam_securetty,pam_shells,pam_faillock,pam_permit,pam_faillock acct="user" exe="/usr/bin/login" hostname=localhost addr=? terminal=tty1 res=success'
[   18.196383] audit: type=1006 audit(1597922466.225:41): pid=380 uid=0 old-auid=4294967295 auid=1000 tty=tty1 old-ses=4294967295 ses=1 res=1
[   18.209503] audit: type=1130 audit(1597922466.238:42): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=user-runtime-dir@1000 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[   18.214162] audit: type=1101 audit(1597922466.242:43): pid=449 uid=0 auid=4294967295 ses=4294967295 msg='op=PAM:accounting grantors=pam_access,pam_unix,pam_permit,pam_time acct="user" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[   18.214177] audit: type=1103 audit(1597922466.242:44): pid=449 uid=0 auid=4294967295 ses=4294967295 msg='op=PAM:setcred grantors=? acct="user" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=failed'
[   33.322957] kauditd_printk_skb: 7 callbacks suppressed
[   33.322958] audit: type=1131 audit(1597922481.355:52): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-hostnamed comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[   33.411843] audit: type=1334 audit(1597922481.442:53): prog-id=10 op=UNLOAD
[   33.411850] audit: type=1334 audit(1597922481.442:54): prog-id=9 op=UNLOAD
[  101.631162] audit: type=1130 audit(1597922549.956:55): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=cron-user-user-0 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[  101.631165] audit: type=1131 audit(1597922549.956:56): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=cron-user-user-0 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[  161.636176] audit: type=1130 audit(1597922609.965:57): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=cron-user-user-0 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[  161.636179] audit: type=1131 audit(1597922609.965:58): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=cron-user-user-0 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[  221.647382] audit: type=1130 audit(1597922669.977:59): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=cron-user-user-0 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[  221.647395] audit: type=1131 audit(1597922669.977:60): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=cron-user-user-0 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[  260.349791] audit: type=1130 audit(1597922708.679:61): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=cron-user-user-0 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[  260.349794] audit: type=1131 audit(1597922708.679:62): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=cron-user-user-0 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[  341.698222] audit: type=1130 audit(1597922790.028:63): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=cron-user-user-0 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[  341.698225] audit: type=1131 audit(1597922790.028:64): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=cron-user-user-0 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[  391.633322] audit: type=1130 audit(1597922839.963:65): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=cron-user-user-0 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[  391.633325] audit: type=1131 audit(1597922839.963:66): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=cron-user-user-0 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[  429.229756] resource sanity check: requesting [mem 0x000c0000-0x000fffff], which spans more than PCI Bus 0000:00 [mem 0x000d0000-0x000d3fff window]
[  429.229873] caller _nv000743rm+0x1af/0x200 [nvidia] mapping multiple BARs
[  445.365874] fuse: init (API version 7.31)
[  446.888099] audit: type=1334 audit(1597922895.221:67): prog-id=12 op=LOAD
[  446.888102] audit: type=1334 audit(1597922895.221:68): prog-id=13 op=LOAD
[  447.066361] audit: type=1130 audit(1597922895.401:69): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=polkit comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[  447.068575] audit: type=1130 audit(1597922895.401:70): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=accounts-daemon comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[  447.142910] audit: type=1130 audit(1597922895.478:71): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=rtkit-daemon comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[  447.168293] audit: type=1130 audit(1597922895.501:72): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=wpa_supplicant comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[  447.170823] audit: type=1130 audit(1597922895.505:73): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=geoclue comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[  447.390393] audit: type=1130 audit(1597922895.725:74): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=upower comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[  447.693788] Bluetooth: RFCOMM TTY layer initialized
[  447.693792] Bluetooth: RFCOMM socket layer initialized
[  447.693795] Bluetooth: RFCOMM ver 1.11
[  448.015128] audit: type=1130 audit(1597922896.348:75): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=cron-user-user-0 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[  448.015130] audit: type=1131 audit(1597922896.348:76): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=cron-user-user-0 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[  448.762181] rfkill: input handler disabled
[  478.769047] kauditd_printk_skb: 9 callbacks suppressed
[  478.769048] audit: type=1131 audit(1597922927.103:86): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-hostnamed comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[  478.853986] audit: type=1334 audit(1597922927.190:87): prog-id=15 op=UNLOAD
[  478.853988] audit: type=1334 audit(1597922927.190:88): prog-id=14 op=UNLOAD
[  478.970327] audit: type=1131 audit(1597922927.303:89): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-localed comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[  479.070660] audit: type=1334 audit(1597922927.406:90): prog-id=17 op=UNLOAD
[  479.070673] audit: type=1334 audit(1597922927.406:91): prog-id=16 op=UNLOAD
[  480.244250] audit: type=1131 audit(1597922928.580:92): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=blueman-mechanism comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[  499.571583] audit: type=1130 audit(1597922947.907:93): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=cron-user-user-0 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[  499.571586] audit: type=1131 audit(1597922947.907:94): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=cron-user-user-0 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[  507.699073] audit: type=1131 audit(1597922956.034:95): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=geoclue comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[  582.302286] audit: type=1130 audit(1597923030.636:96): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=cron-user-user-0 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[  582.302298] audit: type=1131 audit(1597923030.636:97): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=cron-user-user-0 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[  621.825315] audit: type=1130 audit(1597923070.159:98): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=cron-user-user-0 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[  621.825317] audit: type=1131 audit(1597923070.159:99): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=cron-user-user-0 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[  702.264718] audit: type=1130 audit(1597923150.600:100): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=cron-user-user-0 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[  702.264722] audit: type=1131 audit(1597923150.600:101): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=cron-user-user-0 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[  752.556338] audit: type=1130 audit(1597923200.895:102): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=cron-user-user-0 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[  752.556341] audit: type=1131 audit(1597923200.895:103): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=cron-user-user-0 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[  822.244665] audit: type=1130 audit(1597923270.583:104): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=cron-user-user-0 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[  822.244668] audit: type=1131 audit(1597923270.583:105): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=cron-user-user-0 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[  882.190705] audit: type=1130 audit(1597923330.529:106): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=cron-user-user-0 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[  882.190707] audit: type=1131 audit(1597923330.529:107): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=cron-user-user-0 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[  922.229550] audit: type=1130 audit(1597923370.570:108): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-tmpfiles-clean comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[  922.229553] audit: type=1131 audit(1597923370.570:109): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-tmpfiles-clean comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[  925.412223] audit: type=1130 audit(1597923373.754:110): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=cron-user-user-0 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[  925.412225] audit: type=1131 audit(1597923373.754:111): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=cron-user-user-0 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 1002.240157] audit: type=1130 audit(1597923450.583:112): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=cron-user-user-0 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 1002.240168] audit: type=1131 audit(1597923450.583:113): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=cron-user-user-0 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 1012.637644] audit: type=1334 audit(1597923460.980:114): prog-id=18 op=LOAD
[ 1012.637646] audit: type=1334 audit(1597923460.980:115): prog-id=19 op=LOAD
[ 1012.878210] audit: type=1130 audit(1597923461.223:116): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-hostnamed comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 1042.925914] audit: type=1131 audit(1597923491.270:117): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-hostnamed comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 1042.966748] audit: type=1334 audit(1597923491.313:118): prog-id=19 op=UNLOAD
[ 1042.966750] audit: type=1334 audit(1597923491.313:119): prog-id=18 op=UNLOAD
[ 1046.409049] audit: type=1130 audit(1597923494.753:120): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=cron-user-user-0 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 1046.409051] audit: type=1131 audit(1597923494.753:121): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=cron-user-user-0 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 1122.409004] audit: type=1130 audit(1597923570.752:122): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=cron-user-user-0 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 1122.409007] audit: type=1131 audit(1597923570.752:123): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=cron-user-user-0 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 1182.451235] audit: type=1130 audit(1597923630.795:124): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=cron-user-user-0 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 1182.451238] audit: type=1131 audit(1597923630.795:125): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=cron-user-user-0 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 1242.350581] audit: type=1130 audit(1597923690.695:126): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=cron-user-user-0 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 1242.350584] audit: type=1131 audit(1597923690.695:127): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=cron-user-user-0 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 1302.126513] audit: type=1130 audit(1597923750.469:128): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=cron-user-user-0 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 1302.126516] audit: type=1131 audit(1597923750.469:129): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=cron-user-user-0 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 1362.509505] audit: type=1130 audit(1597923810.853:130): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=cron-user-user-0 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 1362.509508] audit: type=1131 audit(1597923810.853:131): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=cron-user-user-0 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 1434.336776] audit: type=1130 audit(1597923882.684:132): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=cron-user-user-0 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 1434.336778] audit: type=1131 audit(1597923882.684:133): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=cron-user-user-0 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 1482.456351] audit: type=1130 audit(1597923930.805:134): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=cron-user-user-0 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 1482.456354] audit: type=1131 audit(1597923930.805:135): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=cron-user-user-0 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 1542.281484] audit: type=1130 audit(1597923990.629:136): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=cron-user-user-0 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 1542.281487] audit: type=1131 audit(1597923990.629:137): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=cron-user-user-0 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 1589.772482] audit: type=1130 audit(1597924038.121:138): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=cron-user-user-0 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 1589.772485] audit: type=1131 audit(1597924038.121:139): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=cron-user-user-0 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 1653.967073] audit: type=1130 audit(1597924102.315:140): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=cron-user-user-0 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 1653.967075] audit: type=1131 audit(1597924102.315:141): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=cron-user-user-0 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 1722.395733] audit: type=1130 audit(1597924170.747:142): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=cron-user-user-0 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 1722.395736] audit: type=1131 audit(1597924170.747:143): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=cron-user-user-0 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 1794.404087] audit: type=1130 audit(1597924242.756:144): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=cron-user-user-0 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 1794.404090] audit: type=1131 audit(1597924242.759:145): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=cron-user-user-0 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 1794.972795] SGI_video_sync[2638]: segfault at e6 ip 00005650edf5b4f2 sp 00007efdef4d18c0 error 6 in teams[5650eb476000+4bf7000]
[ 1794.972800] Code: e8 43 00 00 00 4c 89 f7 e8 db 01 00 00 41 8b 46 10 41 8b 4e 18 c1 e0 0c 25 00 f0 0f 00 c1 e1 14 81 e1 00 00 f0 0f 09 c1 09 d9 <c6> 01 00 81 e3 ff 0f 00 00 c6 03 00 bf 01 00 00 00 e8 e8 d4 10 02
[ 1794.972824] audit: type=1701 audit(1597924243.326:146): auid=1000 uid=1000 gid=1000 ses=1 pid=2600 comm="SGI_video_sync" exe="/usr/share/teams/teams" sig=11 res=1
[ 1794.982531] audit: type=1334 audit(1597924243.336:147): prog-id=20 op=LOAD
[ 1794.982548] audit: type=1334 audit(1597924243.336:148): prog-id=21 op=LOAD
[ 1794.983600] audit: type=1130 audit(1597924243.336:149): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-coredump@0-2641-0 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 1795.453726] audit: type=1131 audit(1597924243.806:150): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-coredump@0-2641-0 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 1795.524257] audit: type=1334 audit(1597924243.879:151): prog-id=21 op=UNLOAD
[ 1795.524262] audit: type=1334 audit(1597924243.879:152): prog-id=20 op=UNLOAD
[ 1842.450199] audit: type=1130 audit(1597924290.807:153): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=cron-user-user-0 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 1842.450202] audit: type=1131 audit(1597924290.807:154): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=cron-user-user-0 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 1902.331327] audit: type=1130 audit(1597924350.689:155): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=cron-user-user-0 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 1902.331329] audit: type=1131 audit(1597924350.689:156): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=cron-user-user-0 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 1962.387763] audit: type=1130 audit(1597924410.747:157): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=cron-user-user-0 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 1962.387766] audit: type=1131 audit(1597924410.747:158): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=cron-user-user-0 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 2022.362951] audit: type=1130 audit(1597924470.722:159): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=cron-user-user-0 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 2022.362954] audit: type=1131 audit(1597924470.722:160): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=cron-user-user-0 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 2082.409456] audit: type=1130 audit(1597924530.769:161): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=cron-user-user-0 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 2082.409459] audit: type=1131 audit(1597924530.769:162): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=cron-user-user-0 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 2154.611824] audit: type=1130 audit(1597924602.975:163): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=cron-user-user-0 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 2154.611826] audit: type=1131 audit(1597924602.975:164): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=cron-user-user-0 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 2182.501679] audit: type=1130 audit(1597924630.861:165): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=cron-user-user-0 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 2182.501681] audit: type=1131 audit(1597924630.861:166): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=cron-user-user-0 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 2262.503016] audit: type=1130 audit(1597924710.864:167): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=cron-user-user-0 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 2262.503018] audit: type=1131 audit(1597924710.864:168): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=cron-user-user-0 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 2312.381535] audit: type=1130 audit(1597924760.740:169): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=cron-user-user-0 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 2312.381538] audit: type=1131 audit(1597924760.740:170): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=cron-user-user-0 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 2382.402933] audit: type=1130 audit(1597924830.764:171): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=cron-user-user-0 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 2382.402936] audit: type=1131 audit(1597924830.764:172): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=cron-user-user-0 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 2435.228675] audit: type=1130 audit(1597924883.587:173): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=cron-user-user-0 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 2435.228677] audit: type=1131 audit(1597924883.587:174): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=cron-user-user-0 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 2514.424026] audit: type=1130 audit(1597924962.784:175): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=cron-user-user-0 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 2514.424028] audit: type=1131 audit(1597924962.784:176): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=cron-user-user-0 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 2562.438743] audit: type=1130 audit(1597925010.801:177): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=cron-user-user-0 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 2562.438746] audit: type=1131 audit(1597925010.801:178): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=cron-user-user-0 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 2622.563917] audit: type=1130 audit(1597925070.922:179): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=cron-user-user-0 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 2622.563920] audit: type=1131 audit(1597925070.922:180): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=cron-user-user-0 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 2656.158072] audit: type=1130 audit(1597925104.519:181): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=cron-user-user-0 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 2656.158074] audit: type=1131 audit(1597925104.519:182): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=cron-user-user-0 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 2732.316104] audit: type=1130 audit(1597925180.676:183): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=cron-user-user-0 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 2732.316107] audit: type=1131 audit(1597925180.676:184): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=cron-user-user-0 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 2802.989759] audit: type=1130 audit(1597925251.354:185): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=cron-user-user-0 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 2802.989761] audit: type=1131 audit(1597925251.354:186): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=cron-user-user-0 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 2874.558262] audit: type=1130 audit(1597925322.922:187): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=cron-user-user-0 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 2874.558264] audit: type=1131 audit(1597925322.922:188): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=cron-user-user-0 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 2922.349884] audit: type=1130 audit(1597925370.712:189): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=cron-user-user-0 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 2922.349887] audit: type=1131 audit(1597925370.712:190): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=cron-user-user-0 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
@pingo-power
[ 2982.440471] audit: type=1130 audit(1597925430.807:191): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=cron-user-user-0 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 2982.440474] audit: type=1131 audit(1597925430.807:192): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=cron-user-user-0 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 3042.650999] audit: type=1130 audit(1597925491.018:193): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=cron-user-user-0 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 3042.651001] audit: type=1131 audit(1597925491.018:194): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=cron-user-user-0 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 3102.931112] audit: type=1130 audit(1597925551.299:195): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=cron-user-user-0 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 3102.931114] audit: type=1131 audit(1597925551.299:196): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=cron-user-user-0 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 3162.827647] audit: type=1130 audit(1597925611.197:197): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=cron-user-user-0 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 3162.827650] audit: type=1131 audit(1597925611.197:198): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=cron-user-user-0 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 3234.986405] audit: type=1130 audit(1597925683.355:199): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=cron-user-user-0 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 3234.986407] audit: type=1131 audit(1597925683.355:200): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=cron-user-user-0 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 3282.630481] audit: type=1130 audit(1597925730.999:201): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=cron-user-user-0 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 3282.630484] audit: type=1131 audit(1597925730.999:202): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=cron-user-user-0 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 3317.369630] audit: type=1130 audit(1597925765.740:203): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=cron-user-user-0 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 3317.369632] audit: type=1131 audit(1597925765.740:204): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=cron-user-user-0 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 3402.679106] audit: type=1130 audit(1597925851.052:205): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=cron-user-user-0 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 3402.679108] audit: type=1131 audit(1597925851.052:206): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=cron-user-user-0 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 3462.493730] audit: type=1130 audit(1597925910.870:207): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=cron-user-user-0 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 3462.493732] audit: type=1131 audit(1597925910.870:208): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=cron-user-user-0 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 3522.565422] audit: type=1130 audit(1597925970.941:209): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=cron-user-user-0 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 3522.565424] audit: type=1131 audit(1597925970.941:210): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=cron-user-user-0 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 3594.688489] audit: type=1130 audit(1597926043.066:211): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=cron-user-user-0 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 3594.688491] audit: type=1131 audit(1597926043.066:212): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=cron-user-user-0 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 3633.616625] audit: type=1130 audit(1597926081.997:213): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=cron-user-user-0 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 3633.616628] audit: type=1131 audit(1597926081.997:214): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=cron-user-user-0 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 3702.945271] audit: type=1130 audit(1597926151.325:215): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=cron-user-user-0 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 3702.945274] audit: type=1131 audit(1597926151.325:216): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=cron-user-user-0 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 3762.652537] audit: type=1130 audit(1597926211.033:217): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=cron-user-user-0 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 3762.652539] audit: type=1131 audit(1597926211.033:218): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=cron-user-user-0 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 3822.662316] audit: type=1130 audit(1597926271.048:219): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=cron-user-user-0 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 3822.662319] audit: type=1131 audit(1597926271.048:220): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=cron-user-user-0 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 3882.691932] audit: type=1130 audit(1597926331.076:221): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=cron-user-user-0 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 3882.691934] audit: type=1131 audit(1597926331.076:222): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=cron-user-user-0 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 3924.326074] audit: type=1130 audit(1597926372.710:223): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=cron-user-user-0 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 3924.326076] audit: type=1131 audit(1597926372.710:224): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=cron-user-user-0 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 3928.633376] NVRM: GPU at PCI:0000:01:00: GPU-25ebd6e0-8288-92bb-63be-726a324d49a7
[ 3928.633379] NVRM: Xid (PCI:0000:01:00): 79, pid=4497, GPU has fallen off the bus.
[ 3928.633380] NVRM: GPU 0000:01:00.0: GPU has fallen off the bus.
[ 3928.633390] NVRM: A GPU crash dump has been created. If possible, please run
               NVRM: nvidia-bug-report.sh as root to collect this data before
               NVRM: the NVIDIA kernel module is unloaded.
[ 4002.346800] audit: type=1701 audit(1597926450.732:225): auid=1000 uid=1000 gid=1000 ses=1 pid=1545 comm=4D6564696150447E6F646572202332 exe="/usr/lib/firefox/firefox" sig=7 res=1
[ 4002.393676] audit: type=1334 audit(1597926450.778:226): prog-id=22 op=LOAD
[ 4002.393773] audit: type=1334 audit(1597926450.778:227): prog-id=23 op=LOAD
[ 4002.404863] audit: type=1130 audit(1597926450.788:228): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-coredump@1-5041-0 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 4003.454767] audit: type=1130 audit(1597926451.839:229): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=cron-user-user-0 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 4003.454769] audit: type=1131 audit(1597926451.839:230): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=cron-user-user-0 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 4027.546141] audit: type=1131 audit(1597926475.932:231): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-coredump@1-5041-0 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 4027.690512] audit: type=1334 audit(1597926476.079:232): prog-id=23 op=UNLOAD
[ 4027.690524] audit: type=1334 audit(1597926476.079:233): prog-id=22 op=UNLOAD
[ 4062.778961] audit: type=1130 audit(1597926511.167:234): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=cron-user-user-0 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 4062.778964] audit: type=1131 audit(1597926511.167:235): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=cron-user-user-0 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 4102.216300] audit: type=1130 audit(1597926550.607:236): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=cron-user-user-0 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 4102.216303] audit: type=1131 audit(1597926550.607:237): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=cron-user-user-0 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 4105.850469] audit: type=1100 audit(1597926554.240:238): pid=5104 uid=1000 auid=4294967295 ses=4294967295 msg='op=PAM:authentication grantors=pam_faillock,pam_permit,pam_faillock acct="user" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/3 res=success'
[ 4105.852177] audit: type=1101 audit(1597926554.240:239): pid=5104 uid=1000 auid=4294967295 ses=4294967295 msg='op=PAM:accounting grantors=pam_unix,pam_permit,pam_time acct="user" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/3 res=success'
[ 4105.854180] audit: type=1110 audit(1597926554.244:240): pid=5104 uid=0 auid=4294967295 ses=4294967295 msg='op=PAM:setcred grantors=pam_faillock,pam_permit,pam_faillock acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/3 res=success'
[ 4105.857061] audit: type=1105 audit(1597926554.247:241): pid=5104 uid=0 auid=4294967295 ses=4294967295 msg='op=PAM:session_open grantors=pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/3 res=success'
____________________________________________
Using built-in specs.
COLLECT_GCC=gcc
COLLECT_LTO_WRAPPER=/usr/lib/gcc/x86_64-pc-linux-gnu/10.1.0/lto-wrapper
Target: x86_64-pc-linux-gnu
Configured with: /build/gcc/src/gcc/configure --prefix=/usr --libdir=/usr/lib --libexecdir=/usr/lib --mandir=/usr/share/man --infodir=/usr/share/info --with-bugurl=https://bugs.archlinux.org/ --enable-languages=c,c++,ada,fortran,go,lto,objc,obj-c++,d --with-isl --with-linker-hash-style=gnu --with-system-zlib --enable-__cxa_atexit --enable-cet=auto --enable-checking=release --enable-clocale=gnu --enable-default-pie --enable-default-ssp --enable-gnu-indirect-function --enable-gnu-unique-object --enable-install-libiberty --enable-linker-build-id --enable-lto --enable-multilib --enable-plugin --enable-shared --enable-threads=posix --disable-libssp --disable-libstdcxx-pch --disable-libunwind-exceptions --disable-werror gdc_include_dir=/usr/include/dlang/gdc
Thread model: posix
Supported LTO compression algorithms: zlib zstd
gcc version 10.1.0 (GCC)
COLLECT_GCC=g++
Thread model: posix
xset -q:
xset:  unable to open display ""
nvidia-settings -q all:
Unable to init server: Could not connect: Connection refused
nvidia-settings could not connect to an X server
xrandr --verbose:
xrandr could not connect to an X server
Running window manager properties:
Unable to detect window manager properties
*** /proc/cmdline
*** ls: -r--r--r-- 1 root root 0 2020-08-20 14:29:16.027537232 +0200 /proc/cmdline
root=UUID=6c37d730-4b14-4479-8554-92d2e75478d5 rw initrd=\initramfs-linux.img
*** /proc/cpuinfo
*** ls: -r--r--r-- 1 root root 0 2020-08-20 14:29:20.897292177 +0200 /proc/cpuinfo
processor	: 0
vendor_id	: GenuineIntel
cpu family	: 6
model		: 60
model name	: Intel(R) Core(TM) i5-4670K CPU @ 3.40GHz
stepping	: 3
microcode	: 0x19
cpu MHz		: 3756.765
cache size	: 6144 KB
physical id	: 0
siblings	: 4
core id		: 0
cpu cores	: 4
apicid		: 0
initial apicid	: 0
fpu		: yes
fpu_exception	: yes
cpuid level	: 13
wp		: yes
flags		: fpu vme de pse tsc msr pae mce cx8 apic sep mtrr pge mca cmov pat pse36 clflush dts acpi mmx fxsr sse sse2 ss ht tm pbe syscall nx pdpe1gb rdtscp lm constant_tsc arch_perfmon pebs bts rep_good nopl xtopology nonstop_tsc cpuid aperfmperf pni pclmulqdq dtes64 monitor ds_cpl vmx est tm2 ssse3 sdbg fma cx16 xtpr pdcm pcid sse4_1 sse4_2 movbe popcnt aes xsave avx f16c rdrand lahf_lm abm cpuid_fault epb invpcid_single pti tpr_shadow vnmi flexpriority ept vpid ept_ad fsgsbase tsc_adjust bmi1 avx2 smep bmi2 erms invpcid xsaveopt dtherm ida arat pln pts
vmx flags	: vnmi preemption_timer invvpid ept_x_only ept_ad ept_1gb flexpriority tsc_offset vtpr mtf vapic ept vpid unrestricted_guest ple
bugs		: cpu_meltdown spectre_v1 spectre_v2 spec_store_bypass l1tf mds swapgs itlb_multihit srbds
bogomips	: 6798.84
clflush size	: 64
cache_alignment	: 64
address sizes	: 39 bits physical, 48 bits virtual
power management:
processor	: 1
cpu family	: 6
model		: 60
stepping	: 3
microcode	: 0x19
cpu MHz		: 3650.872
physical id	: 0
siblings	: 4
core id		: 1
cpu cores	: 4
apicid		: 2
initial apicid	: 2
fpu		: yes
fpu_exception	: yes
cpuid level	: 13
wp		: yes
bogomips	: 6798.84
clflush size	: 64
power management:
processor	: 2
cpu family	: 6
model		: 60
stepping	: 3
microcode	: 0x19
cpu MHz		: 3647.422
physical id	: 0
siblings	: 4
core id		: 2
cpu cores	: 4
apicid		: 4
initial apicid	: 4
fpu		: yes
fpu_exception	: yes
cpuid level	: 13
wp		: yes
bogomips	: 6798.84
clflush size	: 64
power management:
processor	: 3
cpu family	: 6
model		: 60
stepping	: 3
microcode	: 0x19
cpu MHz		: 3756.965
physical id	: 0
siblings	: 4
core id		: 3
cpu cores	: 4
apicid		: 6
initial apicid	: 6
fpu		: yes
fpu_exception	: yes
cpuid level	: 13
wp		: yes
bogomips	: 6798.84
clflush size	: 64
power management:
*** /proc/interrupts
*** ls: -r--r--r-- 1 root root 0 2020-08-20 14:29:20.913958008 +0200 /proc/interrupts
           CPU0       CPU1       CPU2       CPU3
  0:         40          0          0          0   IO-APIC   2-edge      timer
  8:          1          0          0          0   IO-APIC   8-edge      rtc0
  9:          0          0          0          0   IO-APIC   9-fasteoi   acpi
 16:          0         31          0          0   IO-APIC  16-fasteoi   ehci_hcd:usb1
 17:        839          0          0          0   IO-APIC  17-fasteoi   snd_hda_intel:card1
 18:          0          0          5          0   IO-APIC  18-fasteoi   i801_smbus
 23:          0          0          0         35   IO-APIC  23-fasteoi   ehci_hcd:usb3
 24:          0          0          0          0   PCI-MSI 16384-edge      PCIe PME
 25:          0          0          0          0   PCI-MSI 458752-edge      PCIe PME
 26:          0          0          0          0   PCI-MSI 464896-edge      PCIe PME
 27:          0          0          0          0   PCI-MSI 471040-edge      PCIe PME
 28:          0          0          0         13   PCI-MSI 2621440-edge      nvme0q0
 29:          0          0     389898          0   PCI-MSI 512000-edge      ahci[0000:00:1f.2]
 30:         57          0          0          0   PCI-MSI 2621441-edge      nvme0q1
 31:          0         66          0          0   PCI-MSI 2621442-edge      nvme0q2
 32:          0          0         18          0   PCI-MSI 2621443-edge      nvme0q3
 33:          0          0          0         28   PCI-MSI 2621444-edge      nvme0q4
 34:          0          0     149797          0   PCI-MSI 327680-edge      xhci_hcd
 35:     129293          0          0          0   PCI-MSI 409600-edge      eno1
 36:          0         19          0          0   PCI-MSI 360448-edge      mei_me
 37:          0          0          0       2000   PCI-MSI 442368-edge      snd_hda_intel:card0
 38:          0     281800          0          0   PCI-MSI 524288-edge      nvidia
NMI:         86         73         73         73   Non-maskable interrupts
LOC:     997849    1022633     958673     989123   Local timer interrupts
SPU:          0          0          0          0   Spurious interrupts
PMI:         86         73         73         73   Performance monitoring interrupts
IWI:          4          3          0          0   IRQ work interrupts
RTR:          0          0          0          0   APIC ICR read retries
RES:     214839     217671     259845     209531   Rescheduling interrupts
CAL:     412502     416516     404950     430022   Function call interrupts
TLB:     604512     638134     645107     634822   TLB shootdowns
TRM:          0          0          0          0   Thermal event interrupts
THR:          0          0          0          0   Threshold APIC interrupts
DFR:          0          0          0          0   Deferred Error APIC interrupts
MCE:          0          0          0          0   Machine check exceptions
MCP:         14         15         15         15   Machine check polls
ERR:          0
MIS:          0
PIN:          0          0          0          0   Posted-interrupt notification event
NPI:          0          0          0          0   Nested posted-interrupt event
PIW:          0          0          0          0   Posted-interrupt wakeup event
*** /proc/meminfo
*** ls: -r--r--r-- 1 root root 0 2020-08-20 14:28:27.537001392 +0200 /proc/meminfo
MemTotal:       16332548 kB
MemFree:         1314836 kB
MemAvailable:    2410740 kB
Buffers:           23316 kB
Cached:          9629052 kB
SwapCached:            0 kB
Active:          5813576 kB
Inactive:        8711272 kB
Active(anon):    4896280 kB
Inactive(anon):  8335184 kB
Active(file):     917296 kB
Inactive(file):   376088 kB
Unevictable:       12708 kB
Mlocked:           12708 kB
SwapTotal:             0 kB
SwapFree:              0 kB
Dirty:                84 kB
Writeback:             0 kB
AnonPages:       4885212 kB
Mapped:          2278756 kB
Shmem:           8354892 kB
KReclaimable:     112420 kB
Slab:             226076 kB
SReclaimable:     112420 kB
SUnreclaim:       113656 kB
KernelStack:       17156 kB
PageTables:        55084 kB
NFS_Unstable:          0 kB
Bounce:                0 kB
WritebackTmp:          0 kB
CommitLimit:     8166272 kB
Committed_AS:   20574596 kB
VmallocTotal:   34359738367 kB
VmallocUsed:       52380 kB
VmallocChunk:          0 kB
Percpu:             2304 kB
HardwareCorrupted:     0 kB
AnonHugePages:         0 kB
ShmemHugePages:        0 kB
ShmemPmdMapped:        0 kB
FileHugePages:         0 kB
FilePmdMapped:         0 kB
HugePages_Total:       0
HugePages_Free:        0
HugePages_Rsvd:        0
HugePages_Surp:        0
Hugepagesize:       2048 kB
Hugetlb:               0 kB
DirectMap4k:      477100 kB
DirectMap2M:    15190016 kB
DirectMap1G:     1048576 kB
*** /proc/modules
*** ls: -r--r--r-- 1 root root 0 2020-08-20 14:29:20.917291175 +0200 /proc/modules
rfcomm 90112 16 - Live 0xffffffffc0a5f000
fuse 139264 3 - Live 0xffffffffc0968000
nvidia_drm 57344 6 - Live 0xffffffffc0a44000 (POE)
nvidia_modeset 1187840 13 nvidia_drm, Live 0xffffffffc1eea000 (POE)
input_leds 16384 0 - Live 0xffffffffc09bf000
cmac 16384 7 - Live 0xffffffffc09b7000
hid_lg_g15 20480 0 - Live 0xffffffffc09ae000
algif_hash 16384 3 - Live 0xffffffffc09a6000
nvidia 19726336 641 nvidia_modeset, Live 0xffffffffc0c19000 (POE)
algif_skcipher 16384 3 - Live 0xffffffffc09a1000
af_alg 32768 14 algif_hash,algif_skcipher, Live 0xffffffffc095c000
bnep 28672 2 - Live 0xffffffffc0952000
nct6775 73728 0 - Live 0xffffffffc0931000
hwmon_vid 16384 1 nct6775, Live 0xffffffffc04cb000
mousedev 24576 0 - Live 0xffffffffc092a000
joydev 28672 0 - Live 0xffffffffc0922000
hid_steam 20480 0 - Live 0xffffffffc07cb000
intel_rapl_msr 20480 0 - Live 0xffffffffc075e000
intel_rapl_common 32768 1 intel_rapl_msr, Live 0xffffffffc03f5000
x86_pkg_temp_thermal 20480 0 - Live 0xffffffffc0789000
ath3k 24576 0 - Live 0xffffffffc0778000
intel_powerclamp 20480 0 - Live 0xffffffffc0409000
btusb 65536 0 - Live 0xffffffffc0794000
btrtl 24576 1 btusb, Live 0xffffffffc0771000
coretemp 20480 0 - Live 0xffffffffc050c000
btbcm 20480 1 btusb, Live 0xffffffffc0506000
nls_iso8859_1 16384 1 - Live 0xffffffffc0685000
btintel 32768 1 btusb, Live 0xffffffffc0780000
nls_cp437 20480 1 - Live 0xffffffffc0400000
kvm_intel 323584 0 - Live 0xffffffffc09d3000
bluetooth 720896 38 rfcomm,bnep,ath3k,btusb,btrtl,btbcm,btintel, Live 0xffffffffc0ae6000
vfat 24576 1 - Live 0xffffffffc0608000
fat 86016 1 vfat, Live 0xffffffffc0691000
hid_generic 16384 0 - Live 0xffffffffc03f0000
snd_hda_codec_realtek 139264 1 - Live 0xffffffffc0bf6000
usbhid 65536 0 - Live 0xffffffffc07fa000
ecdh_generic 16384 2 bluetooth, Live 0xffffffffc03a9000
snd_hda_codec_generic 98304 1 snd_hda_codec_realtek, Live 0xffffffffc04ed000
hid 143360 4 hid_lg_g15,hid_steam,hid_generic,usbhid, Live 0xffffffffc0ac2000
ledtrig_audio 16384 2 snd_hda_codec_realtek,snd_hda_codec_generic, Live 0xffffffffc0420000
snd_hda_codec_hdmi 73728 1 - Live 0xffffffffc04b8000
kvm 847872 1 kvm_intel, Live 0xffffffffc0852000
ecc 36864 1 ecdh_generic, Live 0xffffffffc0446000
iTCO_wdt 16384 0 - Live 0xffffffffc042d000
intel_pmc_bxt 16384 1 iTCO_wdt, Live 0xffffffffc0428000
at24 24576 0 - Live 0xffffffffc054d000
irqbypass 16384 1 kvm, Live 0xffffffffc0417000
mei_hdcp 24576 0 - Live 0xffffffffc0496000
iTCO_vendor_support 16384 1 iTCO_wdt, Live 0xffffffffc06a8000
eeepc_wmi 16384 0 - Live 0xffffffffc05cc000
crct10dif_pclmul 16384 1 - Live 0xffffffffc068c000
crc32_pclmul 16384 0 - Live 0xffffffffc0610000
asus_wmi 45056 1 eeepc_wmi, Live 0xffffffffc064e000
snd_hda_intel 57344 5 - Live 0xffffffffc05f9000
battery 20480 1 asus_wmi, Live 0xffffffffc0547000
sparse_keymap 16384 1 asus_wmi, Live 0xffffffffc05c7000
rfkill 28672 7 bluetooth,asus_wmi, Live 0xffffffffc039e000
wmi_bmof 16384 0 - Live 0xffffffffc04a4000
ghash_clmulni_intel 16384 0 - Live 0xffffffffc04a9000
snd_intel_dspcfg 24576 1 snd_hda_intel, Live 0xffffffffc0410000
drm_kms_helper 262144 1 nvidia_drm, Live 0xffffffffc0811000
mxm_wmi 16384 0 - Live 0xffffffffc0485000
snd_hda_codec 167936 4 snd_hda_codec_realtek,snd_hda_codec_generic,snd_hda_codec_hdmi,snd_hda_intel, Live 0xffffffffc072f000
aesni_intel 372736 10 - Live 0xffffffffc06d3000
crypto_simd 16384 1 aesni_intel, Live 0xffffffffc0480000
snd_hda_core 106496 5 snd_hda_codec_realtek,snd_hda_codec_generic,snd_hda_codec_hdmi,snd_hda_intel,snd_hda_codec, Live 0xffffffffc0633000
cryptd 24576 5 ghash_clmulni_intel,crypto_simd, Live 0xffffffffc0474000
snd_hwdep 16384 1 snd_hda_codec, Live 0xffffffffc046b000
glue_helper 16384 1 aesni_intel, Live 0xffffffffc0466000
i2c_i801 36864 0 - Live 0xffffffffc05ef000
cec 73728 1 drm_kms_helper, Live 0xffffffffc04da000
rapl 16384 0 - Live 0xffffffffc04d0000
snd_pcm 147456 5 snd_hda_codec_hdmi,snd_hda_intel,snd_hda_codec,snd_hda_core, Live 0xffffffffc06ae000
intel_cstate 16384 0 - Live 0xffffffffc0491000
pcspkr 16384 0 - Live 0xffffffffc048c000
i2c_smbus 20480 1 i2c_i801, Live 0xffffffffc062d000
rc_core 61440 1 cec, Live 0xffffffffc0616000
intel_uncore 163840 0 - Live 0xffffffffc065c000
snd_timer 45056 1 snd_pcm, Live 0xffffffffc05de000
mei_me 49152 1 - Live 0xffffffffc05d1000
syscopyarea 16384 1 drm_kms_helper, Live 0xffffffffc0461000
snd 114688 17 snd_hda_codec_realtek,snd_hda_codec_generic,snd_hda_codec_hdmi,snd_hda_intel,snd_hda_codec,snd_hwdep,snd_pcm,snd_timer, Live 0xffffffffc05aa000
sysfillrect 16384 1 drm_kms_helper, Live 0xffffffffc045c000
sysimgblt 16384 1 drm_kms_helper, Live 0xffffffffc0457000
e1000e 303104 0 - Live 0xffffffffc055f000
fb_sys_fops 16384 1 drm_kms_helper, Live 0xffffffffc055a000
mei 126976 3 mei_hdcp,mei_me, Live 0xffffffffc0527000
lpc_ich 28672 0 - Live 0xffffffffc0519000
soundcore 16384 1 snd, Live 0xffffffffc0514000
evdev 28672 17 - Live 0xffffffffc0393000
wmi 36864 3 asus_wmi,wmi_bmof,mxm_wmi, Live 0xffffffffc0439000
mac_hid 16384 0 - Live 0xffffffffc0434000
i2c_dev 24576 0 - Live 0xffffffffc03e5000
crypto_user 16384 0 - Live 0xffffffffc03dd000
drm 585728 9 nvidia_drm,drm_kms_helper, Live 0xffffffffc02f8000
vfs_monitor 24576 0 - Live 0xffffffffc02eb000 (OE)
agpgart 53248 1 drm, Live 0xffffffffc02dd000
ip_tables 36864 0 - Live 0xffffffffc02b9000
x_tables 53248 1 ip_tables, Live 0xffffffffc02ab000
ext4 802816 2 - Live 0xffffffffc01e6000
crc32c_generic 16384 0 - Live 0xffffffffc01e1000
crc16 16384 2 bluetooth,ext4, Live 0xffffffffc01b2000
mbcache 16384 1 ext4, Live 0xffffffffc0175000
jbd2 139264 1 ext4, Live 0xffffffffc01be000
xhci_pci 20480 0 - Live 0xffffffffc01ac000
crc32c_intel 24576 4 - Live 0xffffffffc01a1000
xhci_pci_renesas 20480 1 xhci_pci, Live 0xffffffffc0199000
ehci_pci 20480 0 - Live 0xffffffffc01b8000
ehci_hcd 98304 1 ehci_pci, Live 0xffffffffc017a000
xhci_hcd 286720 1 xhci_pci, Live 0xffffffffc0123000
*** /proc/version
*** ls: -r--r--r-- 1 root root 0 2020-08-20 14:29:20.917291175 +0200 /proc/version
Linux version 5.8.1-arch1-1 (linux@archlinux) (gcc (GCC) 10.1.0, GNU ld (GNU Binutils) 2.34.0) #1 SMP PREEMPT Wed, 12 Aug 2020 18:50:43 +0000
*** /proc/pci does not exist
*** /proc/iomem
*** ls: -r--r--r-- 1 root root 0 2020-08-20 14:29:20.920624341 +0200 /proc/iomem
00000000-00000fff : Reserved
00001000-00057fff : System RAM
00058000-00058fff : Reserved
00059000-0009efff : System RAM
0009f000-0009ffff : Reserved
000a0000-000bffff : PCI Bus 0000:00
000c0000-000cebff : Video ROM
000d0000-000d3fff : PCI Bus 0000:00
000d4000-000d7fff : PCI Bus 0000:00
000d8000-000dbfff : PCI Bus 0000:00
000dc000-000dffff : PCI Bus 0000:00
000f0000-000fffff : System ROM
00100000-99ee0017 : System RAM
  7b000000-7be00d96 : Kernel code
  7c000000-7c7b9fff : Kernel rodata
  7c800000-7c971cbf : Kernel data
  7cf0c000-7d1fffff : Kernel bss
99ee0018-99ef1057 : System RAM
99ef1058-99ef2017 : System RAM
99ef2018-99f13e57 : System RAM
99f13e58-9ce5dfff : System RAM
9ce5e000-9ce64fff : ACPI Non-volatile Storage
9ce65000-9d2c4fff : System RAM
9d2c5000-9d735fff : Reserved
9d736000-bd861fff : System RAM
bd862000-bdd75fff : Reserved
bdd76000-bdd93fff : ACPI Tables
bdd94000-be2b7fff : ACPI Non-volatile Storage
be2b8000-beffefff : Reserved
befff000-beffffff : System RAM
bf000000-bfffffff : RAM buffer
c0000000-feafffff : PCI Bus 0000:00
  c0000000-d1ffffff : PCI Bus 0000:01
    c0000000-cfffffff : 0000:01:00.0
    d0000000-d1ffffff : 0000:01:00.0
      d1000000-d12fffff : efifb
  de000000-df0fffff : PCI Bus 0000:01
    de000000-deffffff : 0000:01:00.0
      de000000-deffffff : nvidia
    df080000-df083fff : 0000:01:00.1
      df080000-df083fff : ICH HD audio
  df100000-df1fffff : PCI Bus 0000:05
    df100000-df103fff : 0000:05:00.0
      df100000-df103fff : nvme
  df200000-df21ffff : 0000:00:19.0
    df200000-df21ffff : e1000e
  df220000-df22ffff : 0000:00:14.0
    df220000-df22ffff : xhci-hcd
  df230000-df233fff : 0000:00:1b.0
    df230000-df233fff : ICH HD audio
  df234000-df2340ff : 0000:00:1f.3
  df235000-df2357ff : 0000:00:1f.2
    df235000-df2357ff : ahci
  df236000-df2363ff : 0000:00:1d.0
    df236000-df2363ff : ehci_hcd
  df237000-df2373ff : 0000:00:1a.0
    df237000-df2373ff : ehci_hcd
  df238000-df238fff : 0000:00:19.0
    df238000-df238fff : e1000e
  df23a000-df23a00f : 0000:00:16.0
    df23a000-df23a00f : mei_me
  dffe0000-dffeffff : pnp 00:07
  dfff0000-dfffffff : pnp 00:07
  e0000000-efffffff : PCI MMCONFIG 0000 [bus 00-ff]
    e0000000-efffffff : Reserved
      e0000000-efffffff : pnp 00:07
fec00000-fec00fff : Reserved
  fec00000-fec003ff : IOAPIC 0
fed00000-fed03fff : Reserved
  fed00000-fed003ff : HPET 0
    fed00000-fed003ff : PNP0103:00
fed10000-fed17fff : pnp 00:07
fed18000-fed18fff : pnp 00:07
fed19000-fed19fff : pnp 00:07
fed1c000-fed1ffff : Reserved
  fed1c000-fed1ffff : pnp 00:07
    fed1f410-fed1f414 : iTCO_wdt.1.auto
fed20000-fed3ffff : pnp 00:07
fed40000-fed44fff : pnp 00:00
fed45000-fed8ffff : pnp 00:07
fed90000-fed93fff : pnp 00:07
fee00000-fee00fff : Local APIC
  fee00000-fee00fff : Reserved
ff000000-ffffffff : Reserved
  ff000000-ffffffff : INT0800:00
    ff000000-ffffffff : pnp 00:07
100000000-43effffff : System RAM
43f000000-43fffffff : RAM buffer
*** /proc/mtrr
*** ls: -rw-r--r-- 1 root root 0 2020-08-20 13:20:50.748955156 +0200 /proc/mtrr
reg00: base=0x000000000 (    0MB), size= 2048MB, count=1: write-back
reg01: base=0x080000000 ( 2048MB), size= 1024MB, count=1: write-back
reg02: base=0x100000000 ( 4096MB), size= 4096MB, count=1: write-back
reg03: base=0x200000000 ( 8192MB), size= 8192MB, count=1: write-back
reg04: base=0x400000000 (16384MB), size= 1024MB, count=1: write-back
reg05: base=0x43f000000 (17392MB), size=   16MB, count=1: uncachable
*** /proc/driver/nvidia/./version
*** ls: -r--r--r-- 1 root root 0 2020-08-20 14:29:14.250960705 +0200 /proc/driver/nvidia/./version
NVRM version: NVIDIA UNIX x86_64 Kernel Module  450.57  Sun Jul  5 14:42:25 UTC 2020
GCC version:  gcc version 10.1.0 (GCC)
*** /proc/driver/nvidia/./gpus/0000:01:00.0/information
*** ls: -r--r--r-- 1 root root 0 2020-08-20 14:29:20.927290675 +0200 /proc/driver/nvidia/./gpus/0000:01:00.0/information
Model: 		 GeForce GTX 970
IRQ:   		 38
GPU UUID: 	 GPU-25ebd6e0-8288-92bb-63be-726a324d49a7
Video BIOS: 	 84.04.2f.00.f1
Bus Type: 	 PCI
DMA Size: 	 40 bits
DMA Mask: 	 0xffffffffff
Bus Location: 	 0000:01:00.0
Device Minor: 	 0
Blacklisted:	 No
*** /proc/driver/nvidia/./gpus/0000:01:00.0/registry
*** ls: -rw-r--r-- 1 root root 0 2020-08-20 14:29:20.930623841 +0200 /proc/driver/nvidia/./gpus/0000:01:00.0/registry
Binary: ""
*** /proc/driver/nvidia/./warnings/README
*** ls: -r--r--r-- 1 root root 0 2020-08-20 14:29:20.930623841 +0200 /proc/driver/nvidia/./warnings/README
The NVIDIA graphics driver tries to detect potential problems
with the host system and warns about them using the system's
logging mechanisms. Important warning message are also logged
to dedicated text files in this directory.
*** /proc/driver/nvidia/./params
*** ls: -r--r--r-- 1 root root 0 2020-08-20 14:29:20.933957007 +0200 /proc/driver/nvidia/./params
ResmanDebugLevel: 4294967295
RmLogonRC: 1
ModifyDeviceFiles: 1
DeviceFileUID: 0
DeviceFileGID: 0
DeviceFileMode: 438
InitializeSystemMemoryAllocations: 1
UsePageAttributeTable: 4294967295
EnableMSI: 1
MapRegistersEarly: 0
RegisterForACPIEvents: 1
EnablePCIeGen3: 0
MemoryPoolSize: 0
KMallocHeapMaxSize: 0
VMallocHeapMaxSize: 0
IgnoreMMIOCheck: 0
TCEBypassMode: 0
EnableStreamMemOPs: 0
EnableBacklightHandler: 1
EnableUserNUMAManagement: 1
NvLinkDisable: 0
RmProfilingAdminOnly: 1
PreserveVideoMemoryAllocations: 0
DynamicPowerManagement: 0
DynamicPowerManagementVideoMemoryThreshold: 200
RegisterPCIDriver: 1
EnablePCIERelaxedOrderingMode: 0
RegistryDwords: ""
RegistryDwordsPerDevice: ""
RmMsg: ""
AssignGpus: ""
GpuBlacklist: ""
TemporaryFilePath: ""
*** /proc/driver/nvidia/./registry
*** ls: -rw-r--r-- 1 root root 0 2020-08-20 14:29:20.937290174 +0200 /proc/driver/nvidia/./registry
Binary: ""
*** /proc/asound/cards
*** ls: -r--r--r-- 1 root root 0 2020-08-20 14:29:20.937290174 +0200 /proc/asound/cards
 0 [PCH            ]: HDA-Intel - HDA Intel PCH
                      HDA Intel PCH at 0xdf230000 irq 37
 1 [NVidia         ]: HDA-Intel - HDA NVidia
                      HDA NVidia at 0xdf080000 irq 17
*** /proc/asound/pcm
*** ls: -r--r--r-- 1 root root 0 2020-08-20 14:29:20.940623340 +0200 /proc/asound/pcm
00-00: ALC892 Analog : ALC892 Analog : playback 1 : capture 1
00-01: ALC892 Digital : ALC892 Digital : playback 1
00-02: ALC892 Alt Analog : ALC892 Alt Analog : capture 1
01-03: HDMI 0 : HDMI 0 : playback 1
01-07: HDMI 1 : HDMI 1 : playback 1
01-08: HDMI 2 : HDMI 2 : playback 1
01-09: HDMI 3 : HDMI 3 : playback 1
01-10: HDMI 4 : HDMI 4 : playback 1
01-11: HDMI 5 : HDMI 5 : playback 1
01-12: HDMI 6 : HDMI 6 : playback 1
*** /proc/asound/modules
*** ls: -r--r--r-- 1 root root 0 2020-08-20 14:29:20.940623340 +0200 /proc/asound/modules
 0 snd_hda_intel
 1 snd_hda_intel
*** /proc/asound/devices
*** ls: -r--r--r-- 1 root root 0 2020-08-20 14:29:20.943956506 +0200 /proc/asound/devices
  2: [ 1- 3]: digital audio playback
  3: [ 1- 7]: digital audio playback
  4: [ 1- 8]: digital audio playback
  5: [ 1- 9]: digital audio playback
  6: [ 1-10]: digital audio playback
  7: [ 1-11]: digital audio playback
  8: [ 1-12]: digital audio playback
  9: [ 1- 0]: hardware dependent
 10: [ 1]   : control
 11: [ 0- 0]: digital audio playback
 12: [ 0- 0]: digital audio capture
 13: [ 0- 1]: digital audio playback
 14: [ 0- 2]: digital audio capture
 15: [ 0- 0]: hardware dependent
 16: [ 0]   : control
 33:        : timer
*** /proc/asound/version
*** ls: -r--r--r-- 1 root root 0 2020-08-20 14:29:20.947289673 +0200 /proc/asound/version
Advanced Linux Sound Architecture Driver Version k5.8.1-arch1-1.
*** /proc/asound/timers
*** ls: -r--r--r-- 1 root root 0 2020-08-20 14:29:20.947289673 +0200 /proc/asound/timers
G0: system timer : 3333.333us (10000000 ticks)
P0-0-0: PCM playback 0-0-0 : SLAVE
P0-0-1: PCM capture 0-0-1 : SLAVE
P0-1-0: PCM playback 0-1-0 : SLAVE
P0-2-1: PCM capture 0-2-1 : SLAVE
P1-3-0: PCM playback 1-3-0 : SLAVE
P1-7-0: PCM playback 1-7-0 : SLAVE
P1-8-0: PCM playback 1-8-0 : SLAVE
P1-9-0: PCM playback 1-9-0 : SLAVE
P1-10-0: PCM playback 1-10-0 : SLAVE
P1-11-0: PCM playback 1-11-0 : SLAVE
P1-12-0: PCM playback 1-12-0 : SLAVE
*** /proc/asound/hwdep
*** ls: -r--r--r-- 1 root root 0 2020-08-20 14:29:20.950622839 +0200 /proc/asound/hwdep
01-00: HDA Codec 0
00-00: HDA Codec 0
*** /proc/asound/card0/codec#0
*** ls: -r--r--r-- 1 root root 0 2020-08-20 14:29:20.950622839 +0200 /proc/asound/card0/codec#0
Codec: Realtek ALC892
Address: 0
AFG Function Id: 0x1 (unsol 1)
Vendor Id: 0x10ec0892
Subsystem Id: 0x1043860b
Revision Id: 0x100302
No Modem Function Group found
Default PCM:
    rates [0x5f0]: 32000 44100 48000 88200 96000 192000
    bits [0xe]: 16 20 24
    formats [0x1]: PCM
Default Amp-In caps: N/A
Default Amp-Out caps: N/A
State of AFG node 0x01:
  Power states:  D0 D1 D2 D3 CLKSTOP EPSS
  Power: setting=D0, actual=D0
GPIO: io=2, o=0, i=0, unsolicited=1, wake=0
  IO[0]: enable=0, dir=0, wake=0, sticky=0, data=0, unsol=0
  IO[1]: enable=0, dir=0, wake=0, sticky=0, data=0, unsol=0
Node 0x02 [Audio Output] wcaps 0x41d: Stereo Amp-Out
  Control: name="Front Playback Volume", index=0, device=0
    ControlAmp: chs=3, dir=Out, idx=0, ofs=0
  Device: name="ALC892 Analog", type="Audio", device=0
  Amp-Out caps: ofs=0x40, nsteps=0x40, stepsize=0x03, mute=0
  Amp-Out vals:  [0x2f 0x2f]
  Converter: stream=5, channel=0
  PCM:
    rates [0x560]: 44100 48000 96000 192000
    formats [0x1]: PCM
  Power states:  D0 D1 D2 D3 EPSS
Node 0x03 [Audio Output] wcaps 0x41d: Stereo Amp-Out
  Control: name="Surround Playback Volume", index=0, device=0
  Amp-Out vals:  [0x00 0x00]
  PCM:
    formats [0x1]: PCM
Node 0x04 [Audio Output] wcaps 0x41d: Stereo Amp-Out
  Control: name="Center Playback Volume", index=0, device=0
    ControlAmp: chs=1, dir=Out, idx=0, ofs=0
  Control: name="LFE Playback Volume", index=0, device=0
    ControlAmp: chs=2, dir=Out, idx=0, ofs=0
  PCM:
    formats [0x1]: PCM
Node 0x05 [Audio Output] wcaps 0x41d: Stereo Amp-Out
  Control: name="Headphone Playback Volume", index=0, device=0
  PCM:
    formats [0x1]: PCM
Node 0x06 [Audio Output] wcaps 0x611: Stereo Digital
  Digital:
  Digital category: 0x0
  IEC Coding Type: 0x0
  PCM:
    formats [0x1]: PCM
Node 0x07 [Vendor Defined Widget] wcaps 0xf00000: Mono
Node 0x08 [Audio Input] wcaps 0x10051b: Stereo Amp-In
  Control: name="Capture Volume", index=0, device=0
    ControlAmp: chs=3, dir=In, idx=0, ofs=0
  Control: name="Capture Switch", index=0, device=0
  Amp-In caps: ofs=0x10, nsteps=0x2e, stepsize=0x03, mute=1
  Amp-In vals:  [0x1c 0x1c]
  Converter: stream=1, channel=0
  SDI-Select: 0
  PCM:
    formats [0x1]: PCM
  Connection: 1
     0x23
Node 0x09 [Audio Input] wcaps 0x10051b: Stereo Amp-In
  Control: name="Capture Volume", index=1, device=0
  Control: name="Capture Switch", index=1, device=0
  Device: name="ALC892 Alt Analog", type="Audio", device=2
  Amp-In vals:  [0x80 0x80]
  Converter: stream=0, channel=0
  SDI-Select: 0
  PCM:
    formats [0x1]: PCM
  Connection: 1
     0x22
Node 0x0a [Audio Input] wcaps 0x100711: Stereo Digital
  SDI-Select: 0
  Digital:
  PCM:
    formats [0x1]: PCM
  Connection: 1
     0x1f
Node 0x0b [Audio Mixer] wcaps 0x20010b: Stereo Amp-In
  Control: name="Front Mic Playback Volume", index=0, device=0
    ControlAmp: chs=3, dir=In, idx=1, ofs=0
  Control: name="Front Mic Playback Switch", index=0, device=0
  Control: name="Rear Mic Playback Volume", index=0, device=0
  Control: name="Rear Mic Playback Switch", index=0, device=0
  Control: name="Line Playback Volume", index=0, device=0
    ControlAmp: chs=3, dir=In, idx=2, ofs=0
  Control: name="Line Playback Switch", index=0, device=0
  Amp-In caps: ofs=0x17, nsteps=0x1f, stepsize=0x05, mute=1
  Amp-In vals:  [0x80 0x80] [0x80 0x80] [0x80 0x80] [0x80 0x80] [0x80 0x80] [0x80 0x80] [0x80 0x80] [0x80 0x80] [0x80 0x80] [0x80 0x80]
  Connection: 10
     0x18 0x19 0x1a 0x1b 0x1c 0x1d 0x14 0x15 0x16 0x17
Node 0x0c [Audio Mixer] wcaps 0x20010b: Stereo Amp-In
  Amp-In caps: ofs=0x00, nsteps=0x00, stepsize=0x00, mute=1
  Amp-In vals:  [0x00 0x00] [0x80 0x80]
  Connection: 2
     0x02 0x0b
Node 0x0d [Audio Mixer] wcaps 0x20010b: Stereo Amp-In
  Connection: 2
     0x03 0x0b
Node 0x0e [Audio Mixer] wcaps 0x20010b: Stereo Amp-In
  Connection: 2
     0x04 0x0b
Node 0x0f [Audio Mixer] wcaps 0x20010b: Stereo Amp-In
  Connection: 2
     0x05 0x0b
Node 0x10 [Audio Output] wcaps 0x611: Stereo Digital
  Control: name="IEC958 Playback Con Mask", index=0, device=0
  Control: name="IEC958 Playback Pro Mask", index=0, device=0
  Control: name="IEC958 Playback Default", index=0, device=0
  Control: name="IEC958 Playback Switch", index=0, device=0
  Control: name="IEC958 Default PCM Playback Switch", index=0, device=0
  Device: name="ALC892 Digital", type="SPDIF", device=1
  Digital:
  PCM:
    formats [0x1]: PCM
Node 0x11 [Pin Complex] wcaps 0x400781: Stereo Digital
  Pincap 0x00000010: OUT
  Pin Default 0x90460130: [Fixed] SPDIF Out at Int N/A
    Conn = Digital, Color = Unknown
    DefAssociation = 0x3, Sequence = 0x0
    Misc = NO_PRESENCE
  Pin-ctls: 0x40: OUT
  Unsolicited: tag=00, enabled=0
  Connection: 1
     0x10
Node 0x12 [Pin Complex] wcaps 0x400401: Stereo
  Pincap 0x00000020: IN
  Pin Default 0x40170000: [N/A] Speaker at Ext N/A
    Conn = Analog, Color = Unknown
    DefAssociation = 0x0, Sequence = 0x0
  Pin-ctls: 0x00:
Node 0x13 [Vendor Defined Widget] wcaps 0xf00000: Mono
Node 0x14 [Pin Complex] wcaps 0x40058d: Stereo Amp-Out
  Control: name="Front Playback Switch", index=0, device=0
  Amp-Out caps: ofs=0x00, nsteps=0x00, stepsize=0x00, mute=1
  Pincap 0x0001003e: IN OUT HP EAPD Detect Trigger
  EAPD 0x2: EAPD
  Pin Default 0x01014010: [Jack] Line Out at Ext Rear
    Conn = 1/8, Color = Green
    DefAssociation = 0x1, Sequence = 0x0
  Pin-ctls: 0x00:
  Unsolicited: tag=05, enabled=1
  Connection: 1
     0x0c
Node 0x15 [Pin Complex] wcaps 0x40058d: Stereo Amp-Out
  Control: name="Surround Playback Switch", index=0, device=0
  Amp-Out vals:  [0x80 0x80]
  Pincap 0x00000036: IN OUT Detect Trigger
  Pin Default 0x01011012: [Jack] Line Out at Ext Rear
    Conn = 1/8, Color = Black
    DefAssociation = 0x1, Sequence = 0x2
  Pin-ctls: 0x00:
  Unsolicited: tag=06, enabled=1
  Connection: 1
     0x0d
Node 0x16 [Pin Complex] wcaps 0x40058d: Stereo Amp-Out
  Control: name="Center Playback Switch", index=0, device=0
  Control: name="LFE Playback Switch", index=0, device=0
  Pin Default 0x01016011: [Jack] Line Out at Ext Rear
    Conn = 1/8, Color = Orange
    DefAssociation = 0x1, Sequence = 0x1
  Pin-ctls: 0x00:
  Unsolicited: tag=07, enabled=1
  Connection: 1
     0x0e
Node 0x17 [Pin Complex] wcaps 0x40058d: Stereo Amp-Out
  Pin Default 0x411111f0: [N/A] Speaker at Ext Rear
    DefAssociation = 0xf, Sequence = 0x0
    Misc = NO_PRESENCE
  Pin-ctls: 0x20: IN
  Connection: 1
     0x0f
Node 0x18 [Pin Complex] wcaps 0x40058f: Stereo Amp-In Amp-Out
  Control: name="Rear Mic Boost Volume", index=0, device=0
  Amp-In caps: ofs=0x00, nsteps=0x03, stepsize=0x27, mute=0
  Pincap 0x00003736: IN OUT Detect Trigger
    Vref caps: HIZ 50 GRD 80 100
  Pin Default 0x01a19050: [Jack] Mic at Ext Rear
    Conn = 1/8, Color = Pink
    DefAssociation = 0x5, Sequence = 0x0
  Pin-ctls: 0x21: IN VREF_50
  Unsolicited: tag=03, enabled=1
  Connection: 5
     0x0c* 0x0d 0x0e 0x0f 0x26
Node 0x19 [Pin Complex] wcaps 0x40058f: Stereo Amp-In Amp-Out
  Control: name="Front Mic Boost Volume", index=0, device=0
  Pincap 0x0000373e: IN OUT HP Detect Trigger
  Pin Default 0x02a19060: [Jack] Mic at Ext Front
    DefAssociation = 0x6, Sequence = 0x0
  Pin-ctls: 0x24: IN VREF_80
  Unsolicited: tag=02, enabled=1
  Connection: 5
Node 0x1a [Pin Complex] wcaps 0x40058f: Stereo Amp-In Amp-Out
  Control: name="Line Boost Volume", index=0, device=0
  Pin Default 0x0181305f: [Jack] Line In at Ext Rear
    Conn = 1/8, Color = Blue
    DefAssociation = 0x5, Sequence = 0xf
  Pin-ctls: 0x20: IN VREF_HIZ
  Unsolicited: tag=04, enabled=1
  Connection: 5
Node 0x1b [Pin Complex] wcaps 0x40058f: Stereo Amp-In Amp-Out
  Control: name="Headphone Playback Switch", index=0, device=0
  Pincap 0x0001373e: IN OUT HP EAPD Detect Trigger
  EAPD 0x2: EAPD
  Pin Default 0x02214020: [Jack] HP Out at Ext Front
    DefAssociation = 0x2, Sequence = 0x0
  Pin-ctls: 0xc0: OUT HP VREF_HIZ
  Unsolicited: tag=01, enabled=1
  Connection: 5
     0x0c 0x0d 0x0e 0x0f* 0x26
Node 0x1c [Pin Complex] wcaps 0x400481: Stereo
  Pincap 0x00000024: IN Detect
    Misc = NO_PRESENCE
  Pin-ctls: 0x20: IN
Node 0x1d [Pin Complex] wcaps 0x400400: Mono
  Pin Default 0x4047e629: [N/A] SPDIF Out at Ext N/A
    Conn = Analog, Color = White
    DefAssociation = 0x2, Sequence = 0x9
  Pin-ctls: 0x20: IN
Node 0x1e [Pin Complex] wcaps 0x400781: Stereo Digital
  Pin Default 0x01456140: [Jack] SPDIF Out at Ext Rear
    Conn = Optical, Color = Orange
    DefAssociation = 0x4, Sequence = 0x0
    Misc = NO_PRESENCE
  Pin-ctls: 0x40: OUT
  Connection: 1
     0x06
Node 0x1f [Pin Complex] wcaps 0x400681: Stereo Digital
    Misc = NO_PRESENCE
  Pin-ctls: 0x20: IN
Node 0x20 [Vendor Defined Widget] wcaps 0xf00040: Mono
  Processing caps: benign=0, ncoeff=24
Node 0x21 [Vendor Defined Widget] wcaps 0xf00000: Mono
Node 0x22 [Audio Mixer] wcaps 0x20010b: Stereo Amp-In
  Amp-In vals:  [0x80 0x80] [0x00 0x00] [0x80 0x80] [0x80 0x80] [0x80 0x80] [0x80 0x80] [0x80 0x80] [0x80 0x80] [0x80 0x80] [0x80 0x80] [0x80 0x80] [0x80 0x80]
  Connection: 12
     0x18 0x19 0x1a 0x1b 0x1c 0x1d 0x14 0x15 0x16 0x17 0x0b 0x12
Node 0x23 [Audio Mixer] wcaps 0x20010b: Stereo Amp-In
  Connection: 11
Node 0x24 [Vendor Defined Widget] wcaps 0xf00000: Mono
Node 0x25 [Audio Output] wcaps 0x41d: Stereo Amp-Out
  Amp-Out vals:  [0x40 0x40]
  PCM:
    formats [0x1]: PCM
Node 0x26 [Audio Mixer] wcaps 0x20010b: Stereo Amp-In
  Connection: 2
     0x25 0x0b
*** /proc/asound/card1/codec#0
*** ls: -r--r--r-- 1 root root 0 2020-08-20 14:29:21.003953502 +0200 /proc/asound/card1/codec#0
Codec: Nvidia GPU 71 HDMI/DP
Address: 0
AFG Function Id: 0x1 (unsol 0)
Vendor Id: 0x10de0071
Subsystem Id: 0x14623160
Revision Id: 0x100100
Default PCM:
N/A
  Power: setting=UNKNOWN, actual=UNKNOWN, Error, Clock-stop-OK, Setting-reset
Invalid AFG subtree
*** /proc/asound/card1/eld#0.0
*** ls: -rw-r--r-- 1 root root 0 2020-08-20 14:29:21.373935021 +0200 /proc/asound/card1/eld#0.0
monitor_present		1
eld_valid		0
*** /proc/asound/card1/eld#0.1
*** ls: -rw-r--r-- 1 root root 0 2020-08-20 14:29:21.373935021 +0200 /proc/asound/card1/eld#0.1
monitor_present		1
eld_valid		0
*** /proc/asound/card1/eld#0.10
*** ls: -rw-r--r-- 1 root root 0 2020-08-20 14:29:21.387267689 +0200 /proc/asound/card1/eld#0.10
monitor_present		1
eld_valid		0
*** /proc/asound/card1/eld#0.11
*** ls: -rw-r--r-- 1 root root 0 2020-08-20 14:29:21.387267689 +0200 /proc/asound/card1/eld#0.11
monitor_present		1
eld_valid		0
*** /proc/asound/card1/eld#0.12
*** ls: -rw-r--r-- 1 root root 0 2020-08-20 14:29:21.390600855 +0200 /proc/asound/card1/eld#0.12
monitor_present		1
eld_valid		0
*** /proc/asound/card1/eld#0.13
*** ls: -rw-r--r-- 1 root root 0 2020-08-20 14:29:21.393934022 +0200 /proc/asound/card1/eld#0.13
monitor_present		1
eld_valid		0
*** /proc/asound/card1/eld#0.14
*** ls: -rw-r--r-- 1 root root 0 2020-08-20 14:29:21.393934022 +0200 /proc/asound/card1/eld#0.14
monitor_present		1
eld_valid		0
*** /proc/asound/card1/eld#0.15
*** ls: -rw-r--r-- 1 root root 0 2020-08-20 14:29:21.397267189 +0200 /proc/asound/card1/eld#0.15
monitor_present		1
eld_valid		0
*** /proc/asound/card1/eld#0.2
*** ls: -rw-r--r-- 1 root root 0 2020-08-20 14:29:21.397267189 +0200 /proc/asound/card1/eld#0.2
monitor_present		1
eld_valid		0
*** /proc/asound/card1/eld#0.3
*** ls: -rw-r--r-- 1 root root 0 2020-08-20 14:29:21.400600356 +0200 /proc/asound/card1/eld#0.3
monitor_present		1
eld_valid		0
*** /proc/asound/card1/eld#0.4
*** ls: -rw-r--r-- 1 root root 0 2020-08-20 14:29:21.400600356 +0200 /proc/asound/card1/eld#0.4
monitor_present		1
eld_valid		0
*** /proc/asound/card1/eld#0.5
*** ls: -rw-r--r-- 1 root root 0 2020-08-20 14:29:21.403933522 +0200 /proc/asound/card1/eld#0.5
monitor_present		1
eld_valid		0
*** /proc/asound/card1/eld#0.6
*** ls: -rw-r--r-- 1 root root 0 2020-08-20 14:29:21.403933522 +0200 /proc/asound/card1/eld#0.6
monitor_present		1
eld_valid		0
*** /proc/asound/card1/eld#0.7
*** ls: -rw-r--r-- 1 root root 0 2020-08-20 14:29:21.407266690 +0200 /proc/asound/card1/eld#0.7
monitor_present		1
eld_valid		0
*** /proc/asound/card1/eld#0.8
*** ls: -rw-r--r-- 1 root root 0 2020-08-20 14:29:21.407266690 +0200 /proc/asound/card1/eld#0.8
monitor_present		1
eld_valid		0
*** /proc/asound/card1/eld#0.9
*** ls: -rw-r--r-- 1 root root 0 2020-08-20 14:29:21.410599857 +0200 /proc/asound/card1/eld#0.9
monitor_present		1
eld_valid		0
*** ls: lrwxrwxrwx 1 root root 0 2020-08-20 14:29:16.027537232 +0200 /sys/class/drm/card0/device/driver -> ../../../../bus/pci/drivers/nvidia
*** ls: lrwxrwxrwx 1 root root 0 2020-08-20 14:29:16.027537232 +0200 /sys/class/drm/renderD128/device/driver -> ../../../../bus/pci/drivers/nvidia
Skipping vulkaninfo output (vulkaninfo not found)
/sbin/nvidia-smi --query
Unable to determine the device handle for GPU 0000:01:00.0: GPU is lost.  Reboot the system to recover this GPU
/sbin/nvidia-smi --query --unit
==============NVSMI LOG==============
Timestamp                                 : Thu Aug 20 14:29:21 2020
Driver Version                            : 450.57
CUDA Version                              : 11.0
HIC Info                                  : N/A
Attached Units                            : 0
base64 "nvidia-nvml-temp5105.log"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/sbin/nvidia-debugdump -D
ERROR: internal_dumpGpuComponent() failed, return code: 0xf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@pingo-power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@pingo-power
 8hA3ppgFhQeuqEf4ztl5ee5btPq/QMXcFvE5HzyU0PogOoLRjxBVK6Qlai96Bw+bO27InFKewMQ8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@pingo-power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@pingo-power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@pingo-power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____________________________________________
Skipping acpidump output (acpidump not found)
End of NVIDIA bug report log file.
have you fixed it already?i have met the same question the same as you,and i have test my gpu with gpu_burn,it returns OK, what’s more, it is strange for me,when i train small neural networks,like Minist,it works normally,without any problem,however when i tend to use large NNs,like deepgcn,it will shutdown imediatelly,however i can use SSH to connect , i have tried to reinstall my Ubuntu system,but it seems useless. i have no idea about it
GPU version:Geforce RTX 2080TI
Nope, nothing more today @zsq1162263228, it seems to be a recurrent problem happening in a buch of computer of mine running on different nVidia GPU platforms, it’s maybe hardware related and we have to live with it
