Hello!
I have been suffering from this problem for about six months:
every day at the end of the day I put the computer to sleep mode. The next day (although this is reproduced in 100% of cases immediately) I turn on the computer and I have two black screens with a cursor (I have two monitors). Sometimes after a couple of minutes, sometimes even ten minutes pass when, finally, I see the interface. Moreover, it does not work completely right away, that is, open programs work, but there is no response to the win key, the time on the clock has frozen, the plasma(KDE Plasma) elements do not respond, etc. The only thing that helps is to launch the terminal via hotkeys, launch htop and kill the plasmashell process, which loads the cpu to 100% of one of the cores. After automatic restart of plasmashell, everything becomes normal.
I have an nvidia graphics card. I tried different kernels, such as zen, lts and just linux - the effect is the same.
I tried to install a different desktop manager - all the same, after exiting sleep, there are also black screens and only a “live” cursor. I think it’s related to nvidia drivers.
It started about half a year ago, it didn’t happen before. I haven’t updated the system for 2 months before this, and after the update this appeared.
The crash can be reproduced every time.
System info
OS: Arch Linux x86_64
Host: MS-7D17 1.0
Kernel: 6.12.8-zen1-1-zen
Uptime: 2 hours, 48 mins
Packages: 1138 (pacman)
Shell: bash 5.2.37
Resolution: 1920x1080, 1920x1080
DE: Plasma 6.2.5
WM: KWin
Theme: Cutefish-dark [GTK2/3]
Icons: breeze-dark [GTK2/3]
Terminal: terminator
CPU: 11th Gen Intel i5-11400F (12) @ 4.400GHz
GPU: NVIDIA Geforce RTX 3050
Memory: 4977MiB / 15884MiB
NVSMI LOG
==============NVSMI LOG==============
Timestamp : Fri Jan 10 00:33:05 2025
Driver Version : 565.77
CUDA Version : 12.7
Attached GPUs : 1
GPU 00000000:01:00.0
Product Name : NVIDIA GeForce RTX 3050
Product Brand : GeForce
Product Architecture : Ampere
Display Mode : Enabled
Display Active : Enabled
Persistence Mode : Disabled
Addressing Mode : None
MIG Mode
Current : N/A
Pending : N/A
Accounting Mode : Disabled
Accounting Mode Buffer Size : 4000
Driver Model
Current : N/A
Pending : N/A
Serial Number : N/A
GPU UUID : GPU-ee987550-889f-c9ae-0761-cdc1c742e25f
Minor Number : 0
VBIOS Version : 94.06.37.00.86
MultiGPU Board : No
Board ID : 0x100
Board Part Number : N/A
GPU Part Number : 2507-150-A1
FRU Part Number : N/A
Platform Info
RACK Serial Number : N/A
Chassis Physical Slot Number : N/A
Compute Slot Index : N/A
Node Index : N/A
Peer Type : N/A
Module Id : 1
Inforom Version
Image Version : G001.0000.03.03
OEM Object : 2.0
ECC Object : N/A
Power Management Object : N/A
Inforom BBX Object Flush
Latest Timestamp : N/A
Latest Duration : N/A
GPU Operation Mode
Current : N/A
Pending : N/A
GPU C2C Mode : N/A
GPU Virtualization Mode
Virtualization Mode : None
Host VGPU Mode : N/A
vGPU Heterogeneous Mode : N/A
GPU Reset Status
Reset Required : No
Drain and Reset Recommended : No
GPU Recovery Action : None
GSP Firmware Version : 565.77
IBMNPU
Relaxed Ordering Mode : N/A
PCI
Bus : 0x01
Device : 0x00
Domain : 0x0000
Base Classcode : 0x3
Sub Classcode : 0x0
Device Id : 0x250710DE
Bus Id : 00000000:01:00.0
Sub System Id : 0xC9781462
GPU Link Info
PCIe Generation
Max : 4
Current : 2
Device Current : 2
Device Max : 4
Host Max : 4
Link Width
Max : 16x
Current : 8x
Bridge Chip
Type : N/A
Firmware : N/A
Replays Since Reset : 0
Replay Number Rollovers : 0
Tx Throughput : 2550 KB/s
Rx Throughput : 7300 KB/s
Atomic Caps Outbound : N/A
Atomic Caps Inbound : N/A
Fan Speed : 0 %
Performance State : P5
Clocks Event Reasons
Idle : Active
Applications Clocks Setting : Not Active
SW Power Cap : Not Active
HW Slowdown : Not Active
HW Thermal Slowdown : Not Active
HW Power Brake Slowdown : Not Active
Sync Boost : Not Active
SW Thermal Slowdown : Not Active
Display Clock Setting : Not Active
Sparse Operation Mode : N/A
FB Memory Usage
Total : 8192 MiB
Reserved : 333 MiB
Used : 716 MiB
Free : 7145 MiB
BAR1 Memory Usage
Total : 256 MiB
Used : 24 MiB
Free : 232 MiB
Conf Compute Protected Memory Usage
Total : 0 MiB
Used : 0 MiB
Free : 0 MiB
Compute Mode : Default
Utilization
Gpu : 22 %
Memory : 17 %
Encoder : 0 %
Decoder : 0 %
JPEG : 0 %
OFA : 0 %
Encoder Stats
Active Sessions : 0
Average FPS : 0
Average Latency : 0
FBC Stats
Active Sessions : 0
Average FPS : 0
Average Latency : 0
ECC Mode
Current : N/A
Pending : N/A
ECC Errors
Volatile
SRAM Correctable : N/A
SRAM Uncorrectable Parity : N/A
SRAM Uncorrectable SEC-DED : N/A
DRAM Correctable : N/A
DRAM Uncorrectable : N/A
Aggregate
SRAM Threshold Exceeded : N/A
Aggregate Uncorrectable SRAM Sources
SRAM L2 : N/A
SRAM SM : N/A
SRAM Microcontroller : N/A
SRAM PCIE : N/A
SRAM Other : N/A
Retired Pages
Single Bit ECC : N/A
Double Bit ECC : N/A
Pending Page Blacklist : N/A
Remapped Rows : N/A
Temperature
GPU Current Temp : 60 C
GPU T.Limit Temp : N/A
GPU Shutdown Temp : 97 C
GPU Slowdown Temp : 94 C
GPU Max Operating Temp : 92 C
GPU Target Temperature : 83 C
Memory Current Temp : N/A
Memory Max Operating Temp : N/A
GPU Power Readings
Power Draw : 18.54 W
Current Power Limit : 130.00 W
Requested Power Limit : 130.00 W
Default Power Limit : 130.00 W
Min Power Limit : 100.00 W
Max Power Limit : 130.00 W
GPU Memory Power Readings
Power Draw : N/A
Module Power Readings
Power Draw : N/A
Current Power Limit : N/A
Requested Power Limit : N/A
Default Power Limit : N/A
Min Power Limit : N/A
Max Power Limit : N/A
Clocks
Graphics : 577 MHz
SM : 577 MHz
Memory : 810 MHz
Video : 555 MHz
Applications Clocks
Graphics : N/A
Memory : N/A
Default Applications Clocks
Graphics : N/A
Memory : N/A
Deferred Clocks
Memory : N/A
Max Clocks
Graphics : 2190 MHz
SM : 2190 MHz
Memory : 7001 MHz
Video : 1950 MHz
Max Customer Boost Clocks
Graphics : N/A
Clock Policy
Auto Boost : N/A
Auto Boost Default : N/A
Voltage
Graphics : 650.000 mV
Fabric
State : N/A
Status : N/A
CliqueId : N/A
ClusterUUID : N/A
Health
Bandwidth : N/A
Processes
GPU instance ID : N/A
Compute instance ID : N/A
Process ID : 621
Type : G
Used GPU Memory : 176 MiB
Process ID : 809
Type : G
Used GPU Memory : 1 MiB
Process ID : 850
Type : G
Process ID : 909
Type : G
Process ID : 911
Type : G
Process ID : 912
Type : G
Used GPU Memory : 13 MiB
Process ID : 942
Type : G
Process ID : 959
Type : G
Process ID : 960
Type : G
Process ID : 961
Type : G
Used GPU Memory : 2 MiB
Process ID : 962
Type : G
Process ID : 963
Type : G
Process ID : 964
Type : G
Process ID : 1138
Type : G
Process ID : 1147
Type : G
Process ID : 3305
Type : G
Used GPU Memory : 66 MiB
Process ID : 3367
Type : G
Process ID : 3412
Type : G
Name : /opt/google/chrome/chrome --type=gpu-process --string-annotations --crashpad-handler-pid=3374 --enable-crash-reporter=, --change-stack-guard-on-fork=enable --gpu-preferences=UAAAAAAAAAAgAAAEAAAAAAAAAAAAAAAAAABgAAEAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAQAAABAAAAAAAAAAEAAAAAAAAAAIAAAAAAAAAAgAAAAAAAAA --shared-files --field-trial-handle=3,i,7744591575658997661,9097098883869163878,262144 --variations-seed-version=20250109-050117.839000
Used GPU Memory : 109 MiB
Process ID : 6427
Type : G
Capabilities
EGM : disabled
Some logs from KDE report(on KDE bugs they noticed line “QSGRenderLoop::handleContextCreationFailure” and said that this was an NVIDIA bug):
Report KDE
– Backtrace:
Application: plasmashell (plasmashell), signal: Aborted
Content of s_kcrashErrorMessage: std::unique_ptr<char > = {get() = }
warning: Can’t open file /home/elvis/.cache/plasmashell/qmlcache/33c917e773abe4bc3a0103a6068c9216dcb36d95.qmlc (deleted) during file-backed mapping note processing
warning: Can’t open file /home/elvis/.cache/plasmashell/qmlcache/269d180e0b992c7912c25ac7872ddf08d257f916.qmlc (deleted) during file-backed mapping note processing
warning: Can’t open file /home/elvis/.cache/plasmashell/qmlcache/b81c1a728a79168f7736cf864b2eec291fc77054.qmlc (deleted) during file-backed mapping note processing
warning: Can’t open file /memfd:JSGCHeap:QtQml (deleted) during file-backed mapping note processing
warning: Can’t open file /home/elvis/.cache/plasmashell/qmlcache/c1600cc797c41f278479c5812c87627ad5efdfe4.qmlc (deleted) during file-backed mapping note processing
warning: Can’t open file /home/elvis/.cache/plasmashell/qmlcache/be9726676cc7ae806f4abaacf19ff20f610baab0.qmlc (deleted) during file-backed mapping note processing
warning: Can’t open file /home/elvis/.cache/plasmashell/qmlcache/4adbf3794249d8212164b9fb1861df23f4d88430.qmlc (deleted) during file-backed mapping note processing
warning: Can’t open file /home/elvis/.cache/plasmashell/qmlcache/3c7046493df8930311902504c264ae3fec7dd001.qmlc (deleted) during file-backed mapping note processing
warning: Can’t open file /home/elvis/.cache/plasmashell/qmlcache/0509fd8636623126e9a310036326c94e2cbc70a5.qmlc (deleted) during file-backed mapping note processing
warning: Can’t open file /home/elvis/.cache/plasmashell/qmlcache/a27e1c2a0b6cdc12787ab03090c60229f6903ec7.qmlc (deleted) during file-backed mapping note processing
warning: Can’t open file /home/elvis/.cache/plasmashell/qmlcache/5f612594f2dbf235ceb0690f5ba4a2d73e811317.qmlc (deleted) during file-backed mapping note processing
warning: Can’t open file /home/elvis/.cache/plasmashell/qmlcache/49ada484fc7975261e7c1a6eed7db137394fa294.qmlc (deleted) during file-backed mapping note processing
warning: Can’t open file /home/elvis/.cache/plasmashell/qmlcache/0dc2aa4ab8fb8857abf07d7ce561b170fbd242bf.qmlc (deleted) during file-backed mapping note processing
warning: Can’t open file /home/elvis/.cache/plasmashell/qmlcache/3bf33d0e44130692145828ba698629488b20f3c8.qmlc (deleted) during file-backed mapping note processing
warning: Can’t open file /home/elvis/.cache/plasmashell/qmlcache/2cd889abf8ca50857f22dbd4a1ffed6202baa09c.qmlc (deleted) during file-backed mapping note processing
warning: Can’t open file /home/elvis/.cache/plasmashell/qmlcache/6619bfb40bfbb70d412708498b0fe9d7545c6c4c.qmlc (deleted) during file-backed mapping note processing
warning: Can’t open file /home/elvis/.cache/plasmashell/qmlcache/c3d54385f9a1f0f0928171a48019d6859557c4ac.qmlc (deleted) during file-backed mapping note processing
warning: Can’t open file /home/elvis/.cache/plasmashell/qmlcache/ac1b683dc69269d381a3af9e40c34e0570751211.qmlc (deleted) during file-backed mapping note processing
warning: Can’t open file /home/elvis/.cache/plasmashell/qmlcache/6358abf35463f13e2274beed39bc4fd1200d4410.qmlc (deleted) during file-backed mapping note processing
warning: Can’t open file /home/elvis/.cache/plasmashell/qmlcache/27ccb62863115205a0af1c213216db42ae58ba6c.qmlc (deleted) during file-backed mapping note processing
warning: Can’t open file /home/elvis/.cache/plasmashell/qmlcache/33e546ee74ab2a9bf470424f8a50bcbb4430d92d.qmlc (deleted) during file-backed mapping note processing
warning: Can’t open file /memfd:JITCode:QtQml (deleted) during file-backed mapping note processing
warning: Can’t open file /memfd:unknown-usage:QtQml (deleted) during file-backed mapping note processing
warning: Can’t open file /memfd:/.nvidia_drv.XXXXXX (deleted) during file-backed mapping note processing
warning: Can’t open file /memfd:/.glXXXXXX (deleted) during file-backed mapping note processing
warning: Can’t open file /memfd:xorg (deleted) during file-backed mapping note processing
warning: Can’t open file /memfd:JSVMStack:QtQml (deleted) during file-backed mapping note processing
warning: Can’t open file /home/elvis/.cache/plasma_theme_default.kcache (deleted) during file-backed mapping note processing
warning: Can’t open file /memfd:pulseaudio (deleted) during file-backed mapping note processing
[New LWP 912]
[New LWP 917]
[New LWP 1060]
[New LWP 1050]
[New LWP 1049]
[New LWP 1052]
[New LWP 1072]
[New LWP 2356]
[New LWP 2358]
[New LWP 2040]
[New LWP 2348]
[New LWP 1930]
[New LWP 2360]
[New LWP 1058]
[New LWP 916]
[New LWP 1063]
[New LWP 1037]
[New LWP 2359]
[New LWP 2357]
[New LWP 1878]
Downloading 736.73 K separate debug info for /usr/lib/qt6/qml/QtQuick/Shapes/libqmlshapesplugin.so…
Downloading 2.17 M separate debug info for /usr/lib/qt6/qml/org/kde/private/kquickcontrols/libkquickcontrolsprivateplugin.so…
Downloading 19.12 M separate debug info for /usr/lib/libKF6NewStuffCore.so.6…
Downloading 22.10 M separate debug info for /usr/lib/libKF6Attica.so.6…
Downloading 18.78 M separate debug info for /usr/lib/libKF6Syndication.so.6…
[Thread debugging using libthread_db enabled]
Using host libthread_db library “/usr/lib/libthread_db.so.1”.
Core was generated by `/usr/bin/plasmashell --no-respawn’.
Program terminated with signal SIGABRT, Aborted.
#0 __pthread_kill_implementation (threadid=, signo=signo@entry=6, no_tid=no_tid@entry=0) at pthread_kill.c:44
44 return INTERNAL_SYSCALL_ERROR_P (ret) ? INTERNAL_SYSCALL_ERRNO (ret) : 0;
[Current thread is 1 (Thread 0x7c3bad13da00 (LWP 912))]
Cannot QML trace cores :(
/usr/share/drkonqi/gdb/python/gdb_preamble/preamble.py:516: DeprecationWarning: datetime.datetime.utcfromtimestamp() is deprecated and scheduled for removal in a future version. Use timezone-aware objects to represent datetimes in UTC: datetime.datetime.fromtimestamp(timestamp, datetime.UTC).
boot_time = datetime.utcfromtimestamp(psutil.boot_time()).strftime(‘%Y-%m-%dT%H:%M:%S’)
/usr/share/drkonqi/gdb/python/gdb_preamble/preamble.py:533: DeprecationWarning: datetime.datetime.utcnow() is deprecated and scheduled for removal in a future version. Use timezone-aware objects to represent datetimes in UTC: datetime.datetime.now(datetime.UTC).
‘timestamp’: datetime.utcnow().isoformat(),
Thread 20 (Thread 0x7c3b35fff6c0 (LWP 1878)):
#0 0x00007c3bb2e9fa19 in __futex_abstimed_wait_common64 (private=0, futex_word=0x60dbf2dc7b34, expected=0, op=393, abstime=0x0, cancel=true) at futex-internal.c:57
#1 __futex_abstimed_wait_common (futex_word=futex_word@entry=0x60dbf2dc7b34, expected=expected@entry=0, clockid=clockid@entry=0, abstime=abstime@entry=0x0, private=private@entry=0, cancel=cancel@entry=true) at futex-internal.c:87
#2 0x00007c3bb2e9fa9f in __GI___futex_abstimed_wait_cancelable64 (futex_word=futex_word@entry=0x60dbf2dc7b34, expected=expected@entry=0, clockid=clockid@entry=0, abstime=abstime@entry=0x0, private=private@entry=0) at futex-internal.c:139
#3 0x00007c3bb2ea2479 in __pthread_cond_wait_common (cond=0x60dbf2dc7b08, mutex=, clockid=0, abstime=0x0) at pthread_cond_wait.c:503
#4 ___pthread_cond_wait (cond=0x60dbf2dc7b08, mutex=) at pthread_cond_wait.c:618
#5 0x00007c3bb36de440 in QWaitConditionPrivate::wait (this=0x60dbf2dc7ae0, deadline=…) at /usr/src/debug/qt6-base/qtbase/src/corelib/thread/qwaitcondition_unix.cpp:105
#6 QWaitCondition::wait (this=this@entry=0x60dbf26beec0, mutex=mutex@entry=0x60dbf26beeb8, deadline=…) at /usr/src/debug/qt6-base/qtbase/src/corelib/thread/qwaitcondition_unix.cpp:183
#7 0x00007c3bb504452a in QSGRenderThreadEventQueue::takeEvent (this=, wait=true) at /usr/src/debug/qt6-declarative/qtdeclarative/src/quick/scenegraph/qsgthreadedrenderloop.cpp:198
#8 QSGRenderThread::processEventsAndWaitForMore (this=0x60dbf26bee00) at /usr/src/debug/qt6-declarative/qtdeclarative/src/quick/scenegraph/qsgthreadedrenderloop.cpp:869
#9 QSGRenderThread::run (this=0x60dbf26bee00) at /usr/src/debug/qt6-declarative/qtdeclarative/src/quick/scenegraph/qsgthreadedrenderloop.cpp:992
#10 0x00007c3bb36d90cd in operator() (__closure=) at /usr/src/debug/qt6-base/qtbase/src/corelib/thread/qthread_unix.cpp:354
#11 (anonymous namespace)::terminate_on_exception<QThreadPrivate::start(void*)::<lambda()> > (t=) at /usr/src/debug/qt6-base/qtbase/src/corelib/thread/qthread_unix.cpp:290
#12 QThreadPrivate::start (arg=0x60dbf26bee00) at /usr/src/debug/qt6-base/qtbase/src/corelib/thread/qthread_unix.cpp:318
#13 0x00007c3bb2ea339d in start_thread (arg=) at pthread_create.c:447
#14 0x00007c3bb2f2849c in __GI___clone3 () at …/sysdeps/unix/sysv/linux/x86_64/clone3.S:78
Thread 19 (Thread 0x7c3b78afb6c0 (LWP 2357)):
#0 0x00007c3bb2e9fa19 in __futex_abstimed_wait_common64 (private=0, futex_word=0x60dbf1002a40, expected=0, op=137, abstime=0x7c3b78afaa80, cancel=true) at futex-internal.c:57
#1 __futex_abstimed_wait_common (futex_word=futex_word@entry=0x60dbf1002a40, expected=expected@entry=0, clockid=clockid@entry=1, abstime=abstime@entry=0x7c3b78afaa80, private=private@entry=0, cancel=cancel@entry=true) at futex-internal.c:87
#2 0x00007c3bb2e9fa9f in __GI___futex_abstimed_wait_cancelable64 (futex_word=futex_word@entry=0x60dbf1002a40, expected=expected@entry=0, clockid=clockid@entry=1, abstime=abstime@entry=0x7c3b78afaa80, private=private@entry=0) at futex-internal.c:139
#3 0x00007c3bb2ea27e2 in __pthread_cond_wait_common (cond=0x60dbf1002a18, mutex=, clockid=1, abstime=0x7c3b78afaa80) at pthread_cond_wait.c:503
#4 ___pthread_cond_timedwait64 (cond=0x60dbf1002a18, mutex=, abstime=0x7c3b78afaa80) at pthread_cond_wait.c:643
#5 0x00007c3bb36de3c8 in QWaitConditionPrivate::wait_relative (this=0x60dbf10029f0, deadline=…) at /usr/src/debug/qt6-base/qtbase/src/corelib/thread/qwaitcondition_unix.cpp:95
#6 QWaitConditionPrivate::wait (this=0x60dbf10029f0, deadline=…) at /usr/src/debug/qt6-base/qtbase/src/corelib/thread/qwaitcondition_unix.cpp:103
#7 QWaitCondition::wait (this=this@entry=0x60dbf1010350, mutex=mutex@entry=0x60dbef6d1c48, deadline=…) at /usr/src/debug/qt6-base/qtbase/src/corelib/thread/qwaitcondition_unix.cpp:183
#8 0x00007c3bb36dfad5 in QThreadPoolThread::run (this=0x60dbf1010340) at /usr/src/debug/qt6-base/qtbase/src/corelib/thread/qthreadpool.cpp:118
#9 0x00007c3bb36d90cd in operator() (__closure=) at /usr/src/debug/qt6-base/qtbase/src/corelib/thread/qthread_unix.cpp:354
#10 (anonymous namespace)::terminate_on_exception<QThreadPrivate::start(void*)::<lambda()> > (t=) at /usr/src/debug/qt6-base/qtbase/src/corelib/thread/qthread_unix.cpp:290
#11 QThreadPrivate::start (arg=0x60dbf1010340) at /usr/src/debug/qt6-base/qtbase/src/corelib/thread/qthread_unix.cpp:318
#12 0x00007c3bb2ea339d in start_thread (arg=) at pthread_create.c:447
#13 0x00007c3bb2f2849c in __GI___clone3 () at …/sysdeps/unix/sysv/linux/x86_64/clone3.S:78
Thread 18 (Thread 0x7c3b5a4836c0 (LWP 2359)):
#0 0x00007c3bb2e9fa19 in __futex_abstimed_wait_common64 (private=0, futex_word=0x60dbf1206f14, expected=0, op=137, abstime=0x7c3b5a482a80, cancel=true) at futex-internal.c:57
#1 __futex_abstimed_wait_common (futex_word=futex_word@entry=0x60dbf1206f14, expected=expected@entry=0, clockid=clockid@entry=1, abstime=abstime@entry=0x7c3b5a482a80, private=private@entry=0, cancel=cancel@entry=true) at futex-internal.c:87
#2 0x00007c3bb2e9fa9f in __GI___futex_abstimed_wait_cancelable64 (futex_word=futex_word@entry=0x60dbf1206f14, expected=expected@entry=0, clockid=clockid@entry=1, abstime=abstime@entry=0x7c3b5a482a80, private=private@entry=0) at futex-internal.c:139
#3 0x00007c3bb2ea27e2 in __pthread_cond_wait_common (cond=0x60dbf1206ee8, mutex=, clockid=1, abstime=0x7c3b5a482a80) at pthread_cond_wait.c:503
#4 ___pthread_cond_timedwait64 (cond=0x60dbf1206ee8, mutex=, abstime=0x7c3b5a482a80) at pthread_cond_wait.c:643
#5 0x00007c3bb36de3c8 in QWaitConditionPrivate::wait_relative (this=0x60dbf1206ec0, deadline=…) at /usr/src/debug/qt6-base/qtbase/src/corelib/thread/qwaitcondition_unix.cpp:95
#6 QWaitConditionPrivate::wait (this=0x60dbf1206ec0, deadline=…) at /usr/src/debug/qt6-base/qtbase/src/corelib/thread/qwaitcondition_unix.cpp:103
#7 QWaitCondition::wait (this=this@entry=0x60dbf1206e30, mutex=mutex@entry=0x60dbef6d1c48, deadline=…) at /usr/src/debug/qt6-base/qtbase/src/corelib/thread/qwaitcondition_unix.cpp:183
#8 0x00007c3bb36dfad5 in QThreadPoolThread::run (this=0x60dbf1206e20) at /usr/src/debug/qt6-base/qtbase/src/corelib/thread/qthreadpool.cpp:118
#11 QThreadPrivate::start (arg=0x60dbf1206e20) at /usr/src/debug/qt6-base/qtbase/src/corelib/thread/qthread_unix.cpp:318
Thread 17 (Thread 0x7c3ba4bba6c0 (LWP 1037)):
#0 0x00007c3bb2f1abb0 in __GI_ppoll (fds=fds@entry=0x7c3ba0004fc0, nfds=nfds@entry=1, timeout=, timeout@entry=0x0, sigmask=sigmask@entry=0x0) at …/sysdeps/unix/sysv/linux/ppoll.c:42
#1 0x00007c3bb21d3327 in ppoll (__fds=0x7c3ba0004fc0, __nfds=1, __timeout=0x0, __ss=0x0) at /usr/include/bits/poll2.h:101
#2 g_main_context_poll_unlocked (priority=, context=0x7c3b98000c90, timeout_usec=, fds=0x7c3ba0004fc0, n_fds=1) at …/glib/glib/gmain.c:4591
#3 g_main_context_iterate_unlocked.isra.0 (context=context@entry=0x7c3b98000c90, block=block@entry=1, dispatch=dispatch@entry=1, self=) at …/glib/glib/gmain.c:4268
#4 0x00007c3bb216fa55 in g_main_context_iteration (context=0x7c3b98000c90, may_block=1) at …/glib/glib/gmain.c:4338
#5 0x00007c3bb37c22fd in QEventDispatcherGlib::processEvents (this=0x7c3b98000ba0, flags=…) at /usr/src/debug/qt6-base/qtbase/src/corelib/kernel/qeventdispatcher_glib.cpp:399
#6 0x00007c3bb3561ee6 in QEventLoop::processEvents (this=0x7c3ba4bb9b30, flags=…) at /usr/src/debug/qt6-base/qtbase/src/corelib/kernel/qeventloop.cpp:103
#7 QEventLoop::exec (this=0x7c3ba4bb9b30, flags=…) at /usr/src/debug/qt6-base/qtbase/src/corelib/kernel/qeventloop.cpp:194
#8 0x00007c3bb3658082 in QThread::exec (this=) at /usr/src/debug/qt6-base/qtbase/src/corelib/thread/qthread.cpp:621
#9 QThread::run (this=) at /usr/src/debug/qt6-base/qtbase/src/corelib/thread/qthread.cpp:742
#12 QThreadPrivate::start (arg=0x60dbef5b65f0) at /usr/src/debug/qt6-base/qtbase/src/corelib/thread/qthread_unix.cpp:318
Thread 16 (Thread 0x7c3b7a3fe6c0 (LWP 1063)):
#0 0x00007c3bb2e9fa19 in __futex_abstimed_wait_common64 (private=0, futex_word=0x60dbf05d9ca4, expected=0, op=393, abstime=0x0, cancel=true) at futex-internal.c:57
#1 __futex_abstimed_wait_common (futex_word=futex_word@entry=0x60dbf05d9ca4, expected=expected@entry=0, clockid=clockid@entry=0, abstime=abstime@entry=0x0, private=private@entry=0, cancel=cancel@entry=true) at futex-internal.c:87
#2 0x00007c3bb2e9fa9f in __GI___futex_abstimed_wait_cancelable64 (futex_word=futex_word@entry=0x60dbf05d9ca4, expected=expected@entry=0, clockid=clockid@entry=0, abstime=abstime@entry=0x0, private=private@entry=0) at futex-internal.c:139
#3 0x00007c3bb2ea2479 in __pthread_cond_wait_common (cond=0x60dbf05d9c78, mutex=, clockid=0, abstime=0x0) at pthread_cond_wait.c:503
#4 ___pthread_cond_wait (cond=0x60dbf05d9c78, mutex=) at pthread_cond_wait.c:618
#5 0x00007c3bb36de440 in QWaitConditionPrivate::wait (this=0x60dbf05d9c50, deadline=…) at /usr/src/debug/qt6-base/qtbase/src/corelib/thread/qwaitcondition_unix.cpp:105
#6 QWaitCondition::wait (this=this@entry=0x60dbefe1a280, mutex=mutex@entry=0x60dbefe1a278, deadline=…) at /usr/src/debug/qt6-base/qtbase/src/corelib/thread/qwaitcondition_unix.cpp:183
#8 QSGRenderThread::processEventsAndWaitForMore (this=0x60dbefe1a1c0) at /usr/src/debug/qt6-declarative/qtdeclarative/src/quick/scenegraph/qsgthreadedrenderloop.cpp:869
#9 QSGRenderThread::run (this=0x60dbefe1a1c0) at /usr/src/debug/qt6-declarative/qtdeclarative/src/quick/scenegraph/qsgthreadedrenderloop.cpp:992
#12 QThreadPrivate::start (arg=0x60dbefe1a1c0) at /usr/src/debug/qt6-base/qtbase/src/corelib/thread/qthread_unix.cpp:318
Thread 15 (Thread 0x7c3baccd06c0 (LWP 916)):
#0 0x00007c3bb2f1abb0 in __GI_ppoll (fds=fds@entry=0x60dbeed4a200, nfds=nfds@entry=3, timeout=, timeout@entry=0x7c3bacccf900, sigmask=sigmask@entry=0x0) at …/sysdeps/unix/sysv/linux/ppoll.c:42
#1 0x00007c3bb21d3327 in ppoll (__fds=0x60dbeed4a200, __nfds=3, __timeout=0x7c3bacccf900, __ss=0x0) at /usr/include/bits/poll2.h:101
#2 g_main_context_poll_unlocked (priority=, context=0x7c3ba8000cb0, timeout_usec=, fds=0x60dbeed4a200, n_fds=3) at …/glib/glib/gmain.c:4591
#3 g_main_context_iterate_unlocked.isra.0 (context=context@entry=0x7c3ba8000cb0, block=block@entry=1, dispatch=dispatch@entry=1, self=) at …/glib/glib/gmain.c:4268
#4 0x00007c3bb216fa55 in g_main_context_iteration (context=0x7c3ba8000cb0, may_block=1) at …/glib/glib/gmain.c:4338
#5 0x00007c3bb37c22fd in QEventDispatcherGlib::processEvents (this=0x7c3ba8000ba0, flags=…) at /usr/src/debug/qt6-base/qtbase/src/corelib/kernel/qeventdispatcher_glib.cpp:399
#6 0x00007c3bb3561ee6 in QEventLoop::processEvents (this=0x7c3bacccfae0, flags=…) at /usr/src/debug/qt6-base/qtbase/src/corelib/kernel/qeventloop.cpp:103
#7 QEventLoop::exec (this=0x7c3bacccfae0, flags=…) at /usr/src/debug/qt6-base/qtbase/src/corelib/kernel/qeventloop.cpp:194
#8 0x00007c3bb3657f22 in QThread::exec (this=this@entry=0x7c3bb3bfeb20 <QGlobalStatic<QtGlobalStatic::Holder<(anonymous namespace)::Q_QGS__q_manager> >::instance()::holder>) at /usr/src/debug/qt6-base/qtbase/src/corelib/global/qflags.h:74
#9 0x00007c3bb3b735ae in QDBusConnectionManager::run (this=0x7c3bb3bfeb20 <QGlobalStatic<QtGlobalStatic::Holder<(anonymous namespace)::Q_QGS__q_manager> >::instance()::holder>) at /usr/src/debug/qt6-base/qtbase/src/dbus/qdbusconnectionmanager.cpp:144
#12 QThreadPrivate::start (arg=0x7c3bb3bfeb20 <QGlobalStatic<QtGlobalStatic::Holder<(anonymous namespace)::Q_QGS__q_manager> >::instance()::holder>) at /usr/src/debug/qt6-base/qtbase/src/corelib/thread/qthread_unix.cpp:318
Thread 14 (Thread 0x7c3b7b7fe6c0 (LWP 1058)):
#0 0x00007c3bb2f1a63d in __GI___poll (fds=0x7c3b7b7fdba8, nfds=1, timeout=300000) at …/sysdeps/unix/sysv/linux/poll.c:29
#1 0x00007c3ba5c23987 in ??? () at /usr/lib/libnvidia-glcore.so.565.77
#2 0x00007c3ba5c12864 in ??? () at /usr/lib/libnvidia-glcore.so.565.77
#3 0x00007c3bb2ea339d in start_thread (arg=) at pthread_create.c:447
#4 0x00007c3bb2f2849c in __GI___clone3 () at …/sysdeps/unix/sysv/linux/x86_64/clone3.S:78
Thread 13 (Thread 0x7c3b591af6c0 (LWP 2360)):
#0 0x00007c3bb2e9fa19 in __futex_abstimed_wait_common64 (private=0, futex_word=0x60dbf1206b44, expected=0, op=137, abstime=0x7c3b591aea80, cancel=true) at futex-internal.c:57
#1 __futex_abstimed_wait_common (futex_word=futex_word@entry=0x60dbf1206b44, expected=expected@entry=0, clockid=clockid@entry=1, abstime=abstime@entry=0x7c3b591aea80, private=private@entry=0, cancel=cancel@entry=true) at futex-internal.c:87
#2 0x00007c3bb2e9fa9f in __GI___futex_abstimed_wait_cancelable64 (futex_word=futex_word@entry=0x60dbf1206b44, expected=expected@entry=0, clockid=clockid@entry=1, abstime=abstime@entry=0x7c3b591aea80, private=private@entry=0) at futex-internal.c:139
#3 0x00007c3bb2ea27e2 in __pthread_cond_wait_common (cond=0x60dbf1206b18, mutex=, clockid=1, abstime=0x7c3b591aea80) at pthread_cond_wait.c:503
#4 ___pthread_cond_timedwait64 (cond=0x60dbf1206b18, mutex=, abstime=0x7c3b591aea80) at pthread_cond_wait.c:643
#5 0x00007c3bb36de3c8 in QWaitConditionPrivate::wait_relative (this=0x60dbf1206af0, deadline=…) at /usr/src/debug/qt6-base/qtbase/src/corelib/thread/qwaitcondition_unix.cpp:95
#6 QWaitConditionPrivate::wait (this=0x60dbf1206af0, deadline=…) at /usr/src/debug/qt6-base/qtbase/src/corelib/thread/qwaitcondition_unix.cpp:103
#7 QWaitCondition::wait (this=this@entry=0x60dbf1206ad0, mutex=mutex@entry=0x60dbef6d1c48, deadline=…) at /usr/src/debug/qt6-base/qtbase/src/corelib/thread/qwaitcondition_unix.cpp:183
#8 0x00007c3bb36dfad5 in QThreadPoolThread::run (this=0x60dbf1206ac0) at /usr/src/debug/qt6-base/qtbase/src/corelib/thread/qthreadpool.cpp:118
#11 QThreadPrivate::start (arg=0x60dbf1206ac0) at /usr/src/debug/qt6-base/qtbase/src/corelib/thread/qthread_unix.cpp:318
Thread 12 (Thread 0x7c3b375ff6c0 (LWP 1930)):
#0 0x00007c3bb2e9fa19 in __futex_abstimed_wait_common64 (private=0, futex_word=0x60dbf1bde840, expected=0, op=393, abstime=0x0, cancel=true) at futex-internal.c:57
#1 __futex_abstimed_wait_common (futex_word=futex_word@entry=0x60dbf1bde840, expected=expected@entry=0, clockid=clockid@entry=0, abstime=abstime@entry=0x0, private=private@entry=0, cancel=cancel@entry=true) at futex-internal.c:87
#2 0x00007c3bb2e9fa9f in __GI___futex_abstimed_wait_cancelable64 (futex_word=futex_word@entry=0x60dbf1bde840, expected=expected@entry=0, clockid=clockid@entry=0, abstime=abstime@entry=0x0, private=private@entry=0) at futex-internal.c:139
#3 0x00007c3bb2ea2479 in __pthread_cond_wait_common (cond=0x60dbf1bde818, mutex=, clockid=0, abstime=0x0) at pthread_cond_wait.c:503
#4 ___pthread_cond_wait (cond=0x60dbf1bde818, mutex=) at pthread_cond_wait.c:618
#5 0x00007c3bb36de440 in QWaitConditionPrivate::wait (this=0x60dbf1bde7f0, deadline=…) at /usr/src/debug/qt6-base/qtbase/src/corelib/thread/qwaitcondition_unix.cpp:105
#6 QWaitCondition::wait (this=this@entry=0x60dbf19b4910, mutex=mutex@entry=0x60dbf19b4908, deadline=…) at /usr/src/debug/qt6-base/qtbase/src/corelib/thread/qwaitcondition_unix.cpp:183
#8 QSGRenderThread::processEventsAndWaitForMore (this=0x60dbf19b4850) at /usr/src/debug/qt6-declarative/qtdeclarative/src/quick/scenegraph/qsgthreadedrenderloop.cpp:869
#9 QSGRenderThread::run (this=0x60dbf19b4850) at /usr/src/debug/qt6-declarative/qtdeclarative/src/quick/scenegraph/qsgthreadedrenderloop.cpp:992
#12 QThreadPrivate::start (arg=0x60dbf19b4850) at /usr/src/debug/qt6-base/qtbase/src/corelib/thread/qthread_unix.cpp:318
Thread 11 (Thread 0x7c3b792fc6c0 (LWP 2348)):
#0 0x00007c3bb2e9fa19 in __futex_abstimed_wait_common64 (private=0, futex_word=0x60dbf0c50864, expected=0, op=393, abstime=0x0, cancel=true) at futex-internal.c:57
#1 __futex_abstimed_wait_common (futex_word=futex_word@entry=0x60dbf0c50864, expected=expected@entry=0, clockid=clockid@entry=0, abstime=abstime@entry=0x0, private=private@entry=0, cancel=cancel@entry=true) at futex-internal.c:87
#2 0x00007c3bb2e9fa9f in __GI___futex_abstimed_wait_cancelable64 (futex_word=futex_word@entry=0x60dbf0c50864, expected=expected@entry=0, clockid=clockid@entry=0, abstime=abstime@entry=0x0, private=private@entry=0) at futex-internal.c:139
#3 0x00007c3bb2ea2479 in __pthread_cond_wait_common (cond=0x60dbf0c50838, mutex=, clockid=0, abstime=0x0) at pthread_cond_wait.c:503
#4 ___pthread_cond_wait (cond=0x60dbf0c50838, mutex=) at pthread_cond_wait.c:618
#5 0x00007c3bb36de440 in QWaitConditionPrivate::wait (this=0x60dbf0c50810, deadline=…) at /usr/src/debug/qt6-base/qtbase/src/corelib/thread/qwaitcondition_unix.cpp:105
#6 QWaitCondition::wait (this=this@entry=0x7c3ba0011950, mutex=mutex@entry=0x7c3ba0011948, deadline=…) at /usr/src/debug/qt6-base/qtbase/src/corelib/thread/qwaitcondition_unix.cpp:183
#8 QSGRenderThread::processEventsAndWaitForMore (this=0x7c3ba0011890) at /usr/src/debug/qt6-declarative/qtdeclarative/src/quick/scenegraph/qsgthreadedrenderloop.cpp:869
#9 QSGRenderThread::run (this=0x7c3ba0011890) at /usr/src/debug/qt6-declarative/qtdeclarative/src/quick/scenegraph/qsgthreadedrenderloop.cpp:992
#12 QThreadPrivate::start (arg=0x7c3ba0011890) at /usr/src/debug/qt6-base/qtbase/src/corelib/thread/qthread_unix.cpp:318
Thread 10 (Thread 0x7c3b29fff6c0 (LWP 2040)):
#0 0x00007c3bb2e9fa19 in __futex_abstimed_wait_common64 (private=0, futex_word=0x60dbf19fb730, expected=0, op=393, abstime=0x0, cancel=true) at futex-internal.c:57
#1 __futex_abstimed_wait_common (futex_word=futex_word@entry=0x60dbf19fb730, expected=expected@entry=0, clockid=clockid@entry=0, abstime=abstime@entry=0x0, private=private@entry=0, cancel=cancel@entry=true) at futex-internal.c:87
#2 0x00007c3bb2e9fa9f in __GI___futex_abstimed_wait_cancelable64 (futex_word=futex_word@entry=0x60dbf19fb730, expected=expected@entry=0, clockid=clockid@entry=0, abstime=abstime@entry=0x0, private=private@entry=0) at futex-internal.c:139
#3 0x00007c3bb2ea2479 in __pthread_cond_wait_common (cond=0x60dbf19fb708, mutex=, clockid=0, abstime=0x0) at pthread_cond_wait.c:503
#4 ___pthread_cond_wait (cond=0x60dbf19fb708, mutex=) at pthread_cond_wait.c:618
#5 0x00007c3bb36de440 in QWaitConditionPrivate::wait (this=0x60dbf19fb6e0, deadline=…) at /usr/src/debug/qt6-base/qtbase/src/corelib/thread/qwaitcondition_unix.cpp:105
#6 QWaitCondition::wait (this=this@entry=0x60dbf24eb0e0, mutex=mutex@entry=0x60dbf24eb0d8, deadline=…) at /usr/src/debug/qt6-base/qtbase/src/corelib/thread/qwaitcondition_unix.cpp:183
#8 QSGRenderThread::processEventsAndWaitForMore (this=0x60dbf24eb020) at /usr/src/debug/qt6-declarative/qtdeclarative/src/quick/scenegraph/qsgthreadedrenderloop.cpp:869
#9 QSGRenderThread::run (this=0x60dbf24eb020) at /usr/src/debug/qt6-declarative/qtdeclarative/src/quick/scenegraph/qsgthreadedrenderloop.cpp:992
#12 QThreadPrivate::start (arg=0x60dbf24eb020) at /usr/src/debug/qt6-base/qtbase/src/corelib/thread/qthread_unix.cpp:318
Thread 9 (Thread 0x7c3b79afd6c0 (LWP 2358)):
#0 0x00007c3bb2e9fa19 in __futex_abstimed_wait_common64 (private=0, futex_word=0x60dbf1023c74, expected=0, op=137, abstime=0x7c3b79afca80, cancel=true) at futex-internal.c:57
#1 __futex_abstimed_wait_common (futex_word=futex_word@entry=0x60dbf1023c74, expected=expected@entry=0, clockid=clockid@entry=1, abstime=abstime@entry=0x7c3b79afca80, private=private@entry=0, cancel=cancel@entry=true) at futex-internal.c:87
#2 0x00007c3bb2e9fa9f in __GI___futex_abstimed_wait_cancelable64 (futex_word=futex_word@entry=0x60dbf1023c74, expected=expected@entry=0, clockid=clockid@entry=1, abstime=abstime@entry=0x7c3b79afca80, private=private@entry=0) at futex-internal.c:139
#3 0x00007c3bb2ea27e2 in __pthread_cond_wait_common (cond=0x60dbf1023c48, mutex=, clockid=1, abstime=0x7c3b79afca80) at pthread_cond_wait.c:503
#4 ___pthread_cond_timedwait64 (cond=0x60dbf1023c48, mutex=, abstime=0x7c3b79afca80) at pthread_cond_wait.c:643
#5 0x00007c3bb36de3c8 in QWaitConditionPrivate::wait_relative (this=0x60dbf1023c20, deadline=…) at /usr/src/debug/qt6-base/qtbase/src/corelib/thread/qwaitcondition_unix.cpp:95
#6 QWaitConditionPrivate::wait (this=0x60dbf1023c20, deadline=…) at /usr/src/debug/qt6-base/qtbase/src/corelib/thread/qwaitcondition_unix.cpp:103
#7 QWaitCondition::wait (this=this@entry=0x60dbf1020690, mutex=mutex@entry=0x60dbef6d1c48, deadline=…) at /usr/src/debug/qt6-base/qtbase/src/corelib/thread/qwaitcondition_unix.cpp:183
#8 0x00007c3bb36dfad5 in QThreadPoolThread::run (this=0x60dbf1020680) at /usr/src/debug/qt6-base/qtbase/src/corelib/thread/qthreadpool.cpp:118
#11 QThreadPrivate::start (arg=0x60dbf1020680) at /usr/src/debug/qt6-base/qtbase/src/corelib/thread/qthread_unix.cpp:318
Thread 8 (Thread 0x7c3b5b9ff6c0 (LWP 2356)):
#0 0x00007c3bb2e9fa19 in __futex_abstimed_wait_common64 (private=0, futex_word=0x60dbf0869f74, expected=0, op=137, abstime=0x7c3b5b9fea80, cancel=true) at futex-internal.c:57
#1 __futex_abstimed_wait_common (futex_word=futex_word@entry=0x60dbf0869f74, expected=expected@entry=0, clockid=clockid@entry=1, abstime=abstime@entry=0x7c3b5b9fea80, private=private@entry=0, cancel=cancel@entry=true) at futex-internal.c:87
#2 0x00007c3bb2e9fa9f in __GI___futex_abstimed_wait_cancelable64 (futex_word=futex_word@entry=0x60dbf0869f74, expected=expected@entry=0, clockid=clockid@entry=1, abstime=abstime@entry=0x7c3b5b9fea80, private=private@entry=0) at futex-internal.c:139
#3 0x00007c3bb2ea27e2 in __pthread_cond_wait_common (cond=0x60dbf0869f48, mutex=, clockid=1, abstime=0x7c3b5b9fea80) at pthread_cond_wait.c:503
#4 ___pthread_cond_timedwait64 (cond=0x60dbf0869f48, mutex=, abstime=0x7c3b5b9fea80) at pthread_cond_wait.c:643
#5 0x00007c3bb36de3c8 in QWaitConditionPrivate::wait_relative (this=0x60dbf0869f20, deadline=…) at /usr/src/debug/qt6-base/qtbase/src/corelib/thread/qwaitcondition_unix.cpp:95
#6 QWaitConditionPrivate::wait (this=0x60dbf0869f20, deadline=…) at /usr/src/debug/qt6-base/qtbase/src/corelib/thread/qwaitcondition_unix.cpp:103
#7 QWaitCondition::wait (this=this@entry=0x60dbf0bbfe10, mutex=mutex@entry=0x60dbef6d1c48, deadline=…) at /usr/src/debug/qt6-base/qtbase/src/corelib/thread/qwaitcondition_unix.cpp:183
#8 0x00007c3bb36dfad5 in QThreadPoolThread::run (this=0x60dbf0bbfe00) at /usr/src/debug/qt6-base/qtbase/src/corelib/thread/qthreadpool.cpp:118
#11 QThreadPrivate::start (arg=0x60dbf0bbfe00) at /usr/src/debug/qt6-base/qtbase/src/corelib/thread/qthread_unix.cpp:318
Thread 7 (Thread 0x7c3b5b1fe6c0 (LWP 1072)):
#0 0x00007c3bb2f1abb0 in __GI_ppoll (fds=fds@entry=0x7c3b48002a70, nfds=nfds@entry=1, timeout=, timeout@entry=0x0, sigmask=sigmask@entry=0x0) at …/sysdeps/unix/sysv/linux/ppoll.c:42
#1 0x00007c3bb21d3327 in ppoll (__fds=0x7c3b48002a70, __nfds=1, __timeout=0x0, __ss=0x0) at /usr/include/bits/poll2.h:101
#2 g_main_context_poll_unlocked (priority=, context=0x7c3b48000c90, timeout_usec=, fds=0x7c3b48002a70, n_fds=1) at …/glib/glib/gmain.c:4591
#3 g_main_context_iterate_unlocked.isra.0 (context=context@entry=0x7c3b48000c90, block=block@entry=1, dispatch=dispatch@entry=1, self=) at …/glib/glib/gmain.c:4268
#4 0x00007c3bb216fa55 in g_main_context_iteration (context=0x7c3b48000c90, may_block=1) at …/glib/glib/gmain.c:4338
#5 0x00007c3bb37c22fd in QEventDispatcherGlib::processEvents (this=0x7c3b48000ba0, flags=…) at /usr/src/debug/qt6-base/qtbase/src/corelib/kernel/qeventdispatcher_glib.cpp:399
#6 0x00007c3bb3561ee6 in QEventLoop::processEvents (this=0x7c3b5b1fdae0, flags=…) at /usr/src/debug/qt6-base/qtbase/src/corelib/kernel/qeventloop.cpp:103
#7 QEventLoop::exec (this=0x7c3b5b1fdae0, flags=…) at /usr/src/debug/qt6-base/qtbase/src/corelib/kernel/qeventloop.cpp:194
#8 0x00007c3bb3657f22 in QThread::exec (this=this@entry=0x60dbef8b0520) at /usr/src/debug/qt6-base/qtbase/src/corelib/global/qflags.h:74
#9 0x00007c3bb4f7e538 in QQuickPixmapReader::run (this=0x60dbef8b0520) at /usr/src/debug/qt6-declarative/qtdeclarative/src/quick/util/qquickpixmapcache.cpp:1177
#12 QThreadPrivate::start (arg=0x60dbef8b0520) at /usr/src/debug/qt6-base/qtbase/src/corelib/thread/qthread_unix.cpp:318
Thread 6 (Thread 0x7c3b950cf6c0 (LWP 1052)):
#0 0x00007c3bb2e9fa19 in __futex_abstimed_wait_common64 (private=0, futex_word=0x60dbeffbb360, expected=0, op=393, abstime=0x0, cancel=true) at futex-internal.c:57
#1 __futex_abstimed_wait_common (futex_word=futex_word@entry=0x60dbeffbb360, expected=expected@entry=0, clockid=clockid@entry=0, abstime=abstime@entry=0x0, private=private@entry=0, cancel=cancel@entry=true) at futex-internal.c:87
#2 0x00007c3bb2e9fa9f in __GI___futex_abstimed_wait_cancelable64 (futex_word=futex_word@entry=0x60dbeffbb360, expected=expected@entry=0, clockid=clockid@entry=0, abstime=abstime@entry=0x0, private=private@entry=0) at futex-internal.c:139
#3 0x00007c3bb2ea2479 in __pthread_cond_wait_common (cond=0x60dbeffbb338, mutex=, clockid=0, abstime=0x0) at pthread_cond_wait.c:503
#4 ___pthread_cond_wait (cond=0x60dbeffbb338, mutex=) at pthread_cond_wait.c:618
#5 0x00007c3bb36de440 in QWaitConditionPrivate::wait (this=0x60dbeffbb310, deadline=…) at /usr/src/debug/qt6-base/qtbase/src/corelib/thread/qwaitcondition_unix.cpp:105
#6 QWaitCondition::wait (this=this@entry=0x60dbefe41e40, mutex=mutex@entry=0x60dbefe41e38, deadline=…) at /usr/src/debug/qt6-base/qtbase/src/corelib/thread/qwaitcondition_unix.cpp:183
#8 QSGRenderThread::processEventsAndWaitForMore (this=0x60dbefe41d80) at /usr/src/debug/qt6-declarative/qtdeclarative/src/quick/scenegraph/qsgthreadedrenderloop.cpp:869
#9 QSGRenderThread::run (this=0x60dbefe41d80) at /usr/src/debug/qt6-declarative/qtdeclarative/src/quick/scenegraph/qsgthreadedrenderloop.cpp:992
#12 QThreadPrivate::start (arg=0x60dbefe41d80) at /usr/src/debug/qt6-base/qtbase/src/corelib/thread/qthread_unix.cpp:318
Thread 5 (Thread 0x7c3b933fb6c0 (LWP 1049)):
#0 0x00007c3bb2f1abb0 in __GI_ppoll (fds=fds@entry=0x7c3b989182d0, nfds=nfds@entry=1, timeout=, timeout@entry=0x7c3b933fa8e0, sigmask=sigmask@entry=0x0) at …/sysdeps/unix/sysv/linux/ppoll.c:42
#1 0x00007c3bb21d3327 in ppoll (__fds=0x7c3b989182d0, __nfds=1, __timeout=0x7c3b933fa8e0, __ss=0x0) at /usr/include/bits/poll2.h:101
#2 g_main_context_poll_unlocked (priority=, context=0x7c3b8c000c90, timeout_usec=, fds=0x7c3b989182d0, n_fds=1) at …/glib/glib/gmain.c:4591
#3 g_main_context_iterate_unlocked.isra.0 (context=context@entry=0x7c3b8c000c90, block=block@entry=1, dispatch=dispatch@entry=1, self=) at …/glib/glib/gmain.c:4268
#4 0x00007c3bb216fa55 in g_main_context_iteration (context=0x7c3b8c000c90, may_block=1) at …/glib/glib/gmain.c:4338
#5 0x00007c3bb37c22fd in QEventDispatcherGlib::processEvents (this=0x7c3b8c000ba0, flags=…) at /usr/src/debug/qt6-base/qtbase/src/corelib/kernel/qeventdispatcher_glib.cpp:399
#6 0x00007c3bb3561ee6 in QEventLoop::processEvents (this=0x7c3b933faac0, flags=…) at /usr/src/debug/qt6-base/qtbase/src/corelib/kernel/qeventloop.cpp:103
#7 QEventLoop::exec (this=0x7c3b933faac0, flags=…) at /usr/src/debug/qt6-base/qtbase/src/corelib/kernel/qeventloop.cpp:194
#8 0x00007c3bb3657f22 in QThread::exec (this=this@entry=0x60dbf0b629a0) at /usr/src/debug/qt6-base/qtbase/src/corelib/global/qflags.h:74
#9 0x00007c3b917b78b0 in KCupsConnection::run (this=0x60dbf0b629a0) at /usr/src/debug/print-manager/print-manager-6.2.4/src/libkcups/KCupsConnection.cpp:253
#12 QThreadPrivate::start (arg=0x60dbf0b629a0) at /usr/src/debug/qt6-base/qtbase/src/corelib/thread/qthread_unix.cpp:318
Thread 4 (Thread 0x7c3b911c96c0 (LWP 1050)):
#0 0x00007c3bb2f1a63d in __GI___poll (fds=fds@entry=0x7c3b7c0073e0, nfds=nfds@entry=2, timeout=timeout@entry=-1) at …/sysdeps/unix/sysv/linux/poll.c:29
#1 0x00007c3b927b7a78 in poll (__fds=0x7c3b7c0073e0, __nfds=2, __timeout=-1) at /usr/include/bits/poll2.h:44
#2 poll_func (ufds=0x7c3b7c0073e0, nfds=2, timeout=-1, userdata=0x60dbf0bcb010) at …/pulseaudio/src/pulse/thread-mainloop.c:70
#3 0x00007c3b927a1654 in pa_mainloop_poll (m=m@entry=0x60dbf0bd1c90) at …/pulseaudio/src/pulse/mainloop.c:863
#4 0x00007c3b927ab7c5 in pa_mainloop_iterate (m=m@entry=0x60dbf0bd1c90, block=block@entry=1, retval=retval@entry=0x0) at …/pulseaudio/src/pulse/mainloop.c:945
#5 0x00007c3b927ab891 in pa_mainloop_run (m=0x60dbf0bd1c90, retval=0x0) at …/pulseaudio/src/pulse/mainloop.c:963
#6 0x00007c3b927bcbd4 in thread (userdata=0x60dbf0bd1c40) at …/pulseaudio/src/pulse/thread-mainloop.c:101
#7 0x00007c3b9275c34f in internal_thread_func (userdata=0x60dbf0bd17d0) at …/pulseaudio/src/pulsecore/thread-posix.c:81
#8 0x00007c3bb2ea339d in start_thread (arg=) at pthread_create.c:447
#9 0x00007c3bb2f2849c in __GI___clone3 () at …/sysdeps/unix/sysv/linux/x86_64/clone3.S:78
Thread 3 (Thread 0x7c3b7abff6c0 (LWP 1060)):
#0 0x00007c3bb2e9fa19 in __futex_abstimed_wait_common64 (private=0, futex_word=0x60dbf0f50014, expected=0, op=393, abstime=0x0, cancel=true) at futex-internal.c:57
#1 __futex_abstimed_wait_common (futex_word=futex_word@entry=0x60dbf0f50014, expected=expected@entry=0, clockid=clockid@entry=0, abstime=abstime@entry=0x0, private=private@entry=0, cancel=cancel@entry=true) at futex-internal.c:87
#2 0x00007c3bb2e9fa9f in __GI___futex_abstimed_wait_cancelable64 (futex_word=futex_word@entry=0x60dbf0f50014, expected=expected@entry=0, clockid=clockid@entry=0, abstime=abstime@entry=0x0, private=private@entry=0) at futex-internal.c:139
#3 0x00007c3bb2ea2479 in __pthread_cond_wait_common (cond=0x60dbf0f4ffe8, mutex=, clockid=0, abstime=0x0) at pthread_cond_wait.c:503
#4 ___pthread_cond_wait (cond=0x60dbf0f4ffe8, mutex=) at pthread_cond_wait.c:618
#5 0x00007c3bb36de440 in QWaitConditionPrivate::wait (this=0x60dbf0f4ffc0, deadline=…) at /usr/src/debug/qt6-base/qtbase/src/corelib/thread/qwaitcondition_unix.cpp:105
#6 QWaitCondition::wait (this=this@entry=0x60dbf02950c0, mutex=mutex@entry=0x60dbf02950b8, deadline=…) at /usr/src/debug/qt6-base/qtbase/src/corelib/thread/qwaitcondition_unix.cpp:183
#8 QSGRenderThread::processEventsAndWaitForMore (this=0x60dbf0295000) at /usr/src/debug/qt6-declarative/qtdeclarative/src/quick/scenegraph/qsgthreadedrenderloop.cpp:869
#9 QSGRenderThread::run (this=0x60dbf0295000) at /usr/src/debug/qt6-declarative/qtdeclarative/src/quick/scenegraph/qsgthreadedrenderloop.cpp:992
#12 QThreadPrivate::start (arg=0x60dbf0295000) at /usr/src/debug/qt6-base/qtbase/src/corelib/thread/qthread_unix.cpp:318
Thread 2 (Thread 0x7c3ba7fff6c0 (LWP 917)):
#0 0x00007c3bb2f1a63d in __GI___poll (fds=fds@entry=0x7c3ba7ffea28, nfds=nfds@entry=1, timeout=timeout@entry=-1) at …/sysdeps/unix/sysv/linux/poll.c:29
#1 0x00007c3bb601020b in poll (__timeout=-1, __nfds=1, __fds=0x7c3ba7ffea28) at /usr/include/bits/poll2.h:39
#2 _xcb_conn_wait (c=c@entry=0x60dbeed4d880, vector=vector@entry=0x0, count=count@entry=0x0, cond=) at /usr/src/debug/libxcb/libxcb-1.17.0/src/xcb_conn.c:510
#3 0x00007c3bb6011f3d in _xcb_conn_wait (count=0x0, vector=0x0, cond=0x60dbeed4d8c0, c=0x60dbeed4d880) at /usr/src/debug/libxcb/libxcb-1.17.0/src/xcb_conn.c:476
#4 xcb_wait_for_event (c=0x60dbeed4d880) at /usr/src/debug/libxcb/libxcb-1.17.0/src/xcb_in.c:703
#5 0x00007c3bacdacd19 in QXcbEventQueue::run (this=0x60dbeed4a840) at /usr/src/debug/qt6-base/qtbase/src/plugins/platforms/xcb/qxcbeventqueue.cpp:192
#6 0x00007c3bb36d90cd in operator() (__closure=) at /usr/src/debug/qt6-base/qtbase/src/corelib/thread/qthread_unix.cpp:354
#7 (anonymous namespace)::terminate_on_exception<QThreadPrivate::start(void*)::<lambda()> > (t=) at /usr/src/debug/qt6-base/qtbase/src/corelib/thread/qthread_unix.cpp:290
#8 QThreadPrivate::start (arg=0x60dbeed4a840) at /usr/src/debug/qt6-base/qtbase/src/corelib/thread/qthread_unix.cpp:318
#9 0x00007c3bb2ea339d in start_thread (arg=) at pthread_create.c:447
#10 0x00007c3bb2f2849c in __GI___clone3 () at …/sysdeps/unix/sysv/linux/x86_64/clone3.S:78
Thread 1 (Thread 0x7c3bad13da00 (LWP 912)):
[KCrash Handler]
#5 __pthread_kill_implementation (threadid=, signo=signo@entry=6, no_tid=no_tid@entry=0) at pthread_kill.c:44
#6 0x00007c3bb2ea5463 in __pthread_kill_internal (threadid=, signo=6) at pthread_kill.c:78
#7 0x00007c3bb2e4c120 in __GI_raise (sig=sig@entry=6) at …/sysdeps/posix/raise.c:26
#8 0x00007c3bb2e334c3 in __GI_abort () at abort.c:79
#9 0x00007c3bb34905e8 in qAbort () at /usr/src/debug/qt6-base/qtbase/src/corelib/global/qassert.cpp:49
#10 qt_message_fatal<QString&> (context=, message=…) at /usr/src/debug/qt6-base/qtbase/src/corelib/global/qlogging.cpp:2116
#11 qt_message(QtMsgType, const QMessageLogContext &, const char *, typedef __va_list_tag __va_list_tag *) (msgType=msgType@entry=QtFatalMsg, context=…, msg=msg@entry=0x7c3bb51889c5 “%s”, ap=ap@entry=0x7ffced78aae8) at /usr/src/debug/qt6-base/qtbase/src/corelib/global/qlogging.cpp:382
#12 0x00007c3bb3491571 in QMessageLogger::fatal (this=this@entry=0x7ffced78adb0, msg=msg@entry=0x7c3bb51889c5 “%s”) at /usr/src/debug/qt6-base/qtbase/src/corelib/global/qlogging.cpp:884
#13 0x00007c3bb4d3c0ad in QSGRenderLoop::handleContextCreationFailure (this=, window=0x60dbef56a180) at /usr/src/debug/qt6-declarative/qtdeclarative/src/quick/scenegraph/qsgrenderloop.cpp:292
#14 0x00007c3bb4e5edbe in QQuickWindow::event (this=, event=) at /usr/src/debug/qt6-declarative/qtdeclarative/src/quick/items/qquickwindow.cpp:1636
#15 0x00007c3bb56fe78a in QApplicationPrivate::notify_helper (this=, receiver=0x60dbef56a180, e=0x7c3ba002a600) at /usr/src/debug/qt6-base/qtbase/src/widgets/kernel/qapplication.cpp:3296
#16 0x00007c3bb3557ac8 in QCoreApplication::notifyInternal2 (receiver=0x60dbef56a180, event=event@entry=0x7c3ba002a600) at /usr/src/debug/qt6-base/qtbase/src/corelib/kernel/qcoreapplication.cpp:1168
#17 0x00007c3bb3558555 in QCoreApplication::sendEvent (receiver=, event=) at /usr/src/debug/qt6-base/qtbase/src/corelib/kernel/qcoreapplication.cpp:1612
#18 QCoreApplicationPrivate::sendPostedEvents (receiver=0x0, event_type=0, data=0x60dbeed338b0) at /usr/src/debug/qt6-base/qtbase/src/corelib/kernel/qcoreapplication.cpp:1968
#19 0x00007c3bb37c4f7c in QCoreApplication::sendPostedEvents (receiver=0x0, event_type=0) at /usr/src/debug/qt6-base/qtbase/src/corelib/kernel/qcoreapplication.cpp:1800
#20 postEventSourceDispatch (s=0x60dbeed8b2a0) at /usr/src/debug/qt6-base/qtbase/src/corelib/kernel/qeventdispatcher_glib.cpp:246
#21 0x00007c3bb2170559 in g_main_dispatch (context=0x7c3ba8000f30) at …/glib/glib/gmain.c:3357
#22 0x00007c3bb21d3257 in g_main_context_dispatch_unlocked (context=0x7c3ba8000f30) at …/glib/glib/gmain.c:4208
#23 g_main_context_iterate_unlocked.isra.0 (context=context@entry=0x7c3ba8000f30, block=block@entry=1, dispatch=dispatch@entry=1, self=) at …/glib/glib/gmain.c:4273
#24 0x00007c3bb216fa55 in g_main_context_iteration (context=0x7c3ba8000f30, may_block=1) at …/glib/glib/gmain.c:4338
#25 0x00007c3bb37c22fd in QEventDispatcherGlib::processEvents (this=0x60dbeedb6540, flags=…) at /usr/src/debug/qt6-base/qtbase/src/corelib/kernel/qeventdispatcher_glib.cpp:399
#26 0x00007c3bb3561ee6 in QEventLoop::processEvents (this=0x7ffced78b480, flags=…) at /usr/src/debug/qt6-base/qtbase/src/corelib/kernel/qeventloop.cpp:103
#27 QEventLoop::exec (this=0x7ffced78b480, flags=…) at /usr/src/debug/qt6-base/qtbase/src/corelib/kernel/qeventloop.cpp:194
#28 0x00007c3bb3558f4f in QCoreApplication::exec () at /usr/src/debug/qt6-base/qtbase/src/corelib/global/qflags.h:74
#29 0x00007c3bb56fa6ba in QApplication::exec () at /usr/src/debug/qt6-base/qtbase/src/widgets/kernel/qapplication.cpp:2564
#30 0x000060dbba74917f in main (argc=, argv=) at /usr/src/debug/plasma-workspace/plasma-workspace-6.2.4/shell/main.cpp:192
nvidia-bug-report.log.gz (784.1 KB)
