on Debian Bookworm/xfce + nvidia closed source drivers, my desktop remains black after sleep or switching terminals. The xserver is running and there’s a mouse pointer but no window manager/desktop.
I honestly don’t know if it’s an issue with the driver, but there seem to be similiar looking problems on the forum. It seems like it should be something simple, as everything works perfectly until the screen is put to sleep.
Also, I’m using a Display Port via an HDMI adapter. And I’m only using one screen at the moment, but I’d typically want two working.
The card has worked for years on the same box running Ubuntu without issues. When I installed Debian/xfce I was getting intermittent GPU crashes with the nouveau driver so, after unsuccessfully trying the open source nvidia driver, I switched to the proprietary one.
I wonder if the following lines in /var/log/Xorg.0.log could be a clue:
[ 102.447] (II) NVIDIA(0): Setting mode ""DFP-1:nvidia-auto-select""
[ 102.491] (II) NVIDIA(0): ACPI: failed to connect to the ACPI event daemon; the daemon
[ 102.491] (II) NVIDIA(0): may not be running or the ""AcpidSocketPath"" X
[ 102.491] (II) NVIDIA(0): configuration option may not be set correctly. When the
[ 102.491] (II) NVIDIA(0): ACPI event daemon is available, the NVIDIA X driver will
[ 102.491] (II) NVIDIA(0): try to use it to receive ACPI event notifications. For
[ 102.491] (II) NVIDIA(0): details, please see the ""ConnectToAcpid"" and
[ 102.491] (II) NVIDIA(0): ""AcpidSocketPath"" X configuration options in Appendix B: X
[ 102.491] (II) NVIDIA(0): Config Options in the README.
I’ve searched the 3000 or so files called README on my system, but none have the string ““AcpidSocketPath”” or ““ConnectToAcpid””. Also, the ACPI event daemon is not installed on my system.
I can install it, but I’m not in a hurry to reinstall the nvidia drivers, as it has been a journey. Therefore, I’m guessing I’ll have to manually configure whatever links acpid to nvidia.
Any pointer to doing this configuration, or any other clues or pointers, would be greatly appreciated!
Cheers,
bitrat
PS: I see the following in /usr/share/X11/xorg.conf.d/nvidia-drm-outputclass.conf
# This xorg.conf.d configuration snippet configures the X server to
# automatically load the nvidia X driver when it detects a device driven by the
# nvidia-drm.ko kernel module. Please note that this only works on Linux kernels
# version 3.9 or higher with CONFIG_DRM enabled, and only if the nvidia-drm.ko
# kernel module is loaded before the X server is started.
Section ""OutputClass""
Identifier ""nvidia""
MatchDriver ""nvidia-drm""
Driver ""nvidia""
EndSection
According to the Xorg log (see below) the nouveau driver is loaded, then unloaded, then nvidia. Can I improve this?
FYI:
$ lsmod | grep nvidia
nvidia_uvm 4661248 0
nvidia_drm 102400 5
drm_kms_helper 208896 1 nvidia_drm
nvidia_modeset 1347584 8 nvidia_drm
nvidia 54059008 101 nvidia_uvm,nvidia_modeset
drm 614400 9 drm_kms_helper,nvidia,nvidia_drm
video 65536 1 nvidia_modeset
Xorg log follows:
I couldn’t see where to attach an nvidia-bug-report. I can get one from another machine when the screen is blank as well.
$ sudo cat /var/log/Xorg.0.log
[ 2624.382]
X.Org X Server 1.21.1.7
X Protocol Version 11, Revision 0
[ 2624.382] Current Operating System: Linux host 6.1.0-20-amd64 #1 SMP PREEMPT_DYNAMIC Debian 6.1.85-1 (2024-04-11) x86_64
[ 2624.382] Kernel command line: BOOT_IMAGE=/boot/vmlinuz-6.1.0-20-amd64 root=UUID=xxxxxxxx-xxxx-xxxx-xxxx-xxxxxxxxxxxx ro quiet
[ 2624.382] xorg-server 2:21.1.7-3+deb12u7 (https://www.debian.org/support)
[ 2624.382] Current version of pixman: 0.42.2
[ 2624.382] Before reporting problems, check http://wiki.x.org
to make sure that you have the latest version.
[ 2624.382] Markers: (--) probed, (**) from config file, (==) default setting,
(++) from command line, (!!) notice, (II) informational,
(WW) warning, (EE) error, (NI) not implemented, (??) unknown.
[ 2624.382] (==) Log file: ""/var/log/Xorg.0.log"", Time: Fri Apr 19 18:41:07 2024
[ 2624.382] (==) Using system config directory ""/usr/share/X11/xorg.conf.d""
[ 2624.382] (==) No Layout section. Using the first Screen section.
[ 2624.382] (==) No screen section available. Using defaults.
[ 2624.382] (**) |-->Screen ""Default Screen Section"" (0)
[ 2624.382] (**) | |-->Monitor ""<default monitor>""
[ 2624.383] (==) No monitor specified for screen ""Default Screen Section"".
Using a default monitor configuration.
[ 2624.383] (==) Automatically adding devices
[ 2624.383] (==) Automatically enabling devices
[ 2624.383] (==) Automatically adding GPU devices
[ 2624.383] (==) Automatically binding GPU devices
[ 2624.383] (==) Max clients allowed: 256, resource mask: 0x1fffff
[ 2624.383] (WW) The directory ""/usr/share/fonts/X11/cyrillic"" does not exist.
[ 2624.383] Entry deleted from font path.
[ 2624.383] (WW) The directory ""/usr/share/fonts/X11/100dpi/"" does not exist.
[ 2624.383] (WW) The directory ""/usr/share/fonts/X11/75dpi/"" does not exist.
[ 2624.383] (WW) The directory ""/usr/share/fonts/X11/100dpi"" does not exist.
[ 2624.383] (WW) The directory ""/usr/share/fonts/X11/75dpi"" does not exist.
[ 2624.383] (==) FontPath set to:
/usr/share/fonts/X11/misc,
/usr/share/fonts/X11/Type1,
built-ins
[ 2624.383] (==) ModulePath set to ""/usr/lib/xorg/modules""
[ 2624.383] (II) The server relies on udev to provide the list of input devices.
If no devices become available, reconfigure udev or disable AutoAddDevices.
[ 2624.383] (II) Loader magic: 0x55f41798ef00
[ 2624.383] (II) Module ABI versions:
[ 2624.383] X.Org ANSI C Emulation: 0.4
[ 2624.383] X.Org Video Driver: 25.2
[ 2624.383] X.Org XInput driver : 24.4
[ 2624.383] X.Org Server Extension : 10.0
[ 2624.383] (++) using VT number 7
[ 2624.383] (II) systemd-logind: logind integration requires -keeptty and -keeptty was not provided, disabling logind integration
[ 2624.383] (II) xfree86: Adding drm device (/dev/dri/card0)
[ 2624.383] (II) Platform probe for /sys/devices/pci0000:00/0000:00:01.0/0000:01:00.0/drm/card0
[ 2624.385] (--) PCI:*(1@0:0:0) 10de:13ba:10de:1097 rev 162, Mem @ 0xf6000000/16777216, 0xe0000000/268435456, 0xf0000000/33554432, I/O @ 0x0000e000/128, BIOS @ 0x????????/131072
[ 2624.385] (II) LoadModule: ""glx""
[ 2624.385] (II) Loading /usr/lib/xorg/modules/extensions/libglx.so
[ 2624.385] (II) Module glx: vendor=""X.Org Foundation""
[ 2624.385] compiled for 1.21.1.7, module version = 1.0.0
[ 2624.385] ABI class: X.Org Server Extension, version 10.0
[ 2624.385] (II) Applying OutputClass ""nvidia"" to /dev/dri/card0
[ 2624.385] loading driver: nvidia
[ 2624.608] (==) Matched nvidia as autoconfigured driver 0
[ 2624.608] (==) Matched nouveau as autoconfigured driver 1
[ 2624.608] (==) Matched nv as autoconfigured driver 2
[ 2624.608] (==) Matched modesetting as autoconfigured driver 3
[ 2624.608] (==) Matched fbdev as autoconfigured driver 4
[ 2624.608] (==) Matched vesa as autoconfigured driver 5
[ 2624.608] (==) Assigned the driver to the xf86ConfigLayout
[ 2624.608] (II) LoadModule: ""nvidia""
[ 2624.608] (II) Loading /usr/lib/xorg/modules/drivers/nvidia_drv.so
[ 2624.608] (II) Module nvidia: vendor=""NVIDIA Corporation""
[ 2624.608] compiled for 1.6.99.901, module version = 1.0.0
[ 2624.608] Module class: X.Org Video Driver
[ 2624.608] (II) LoadModule: ""nouveau""
[ 2624.608] (II) Loading /usr/lib/xorg/modules/drivers/nouveau_drv.so
[ 2624.608] (II) Module nouveau: vendor=""X.Org Foundation""
[ 2624.608] compiled for 1.21.1.3, module version = 1.0.17
[ 2624.608] ABI class: X.Org Video Driver, version 25.2
[ 2624.608] (II) LoadModule: ""nv""
[ 2624.608] (WW) Warning, couldn't open module nv
[ 2624.608] (EE) Failed to load module ""nv"" (module does not exist, 0)
[ 2624.608] (II) LoadModule: ""modesetting""
[ 2624.608] (II) Loading /usr/lib/xorg/modules/drivers/modesetting_drv.so
[ 2624.608] (II) Module modesetting: vendor=""X.Org Foundation""
[ 2624.608] compiled for 1.21.1.7, module version = 1.21.1
[ 2624.608] (II) LoadModule: ""fbdev""
[ 2624.609] (II) Loading /usr/lib/xorg/modules/drivers/fbdev_drv.so
[ 2624.609] (II) Module fbdev: vendor=""X.Org Foundation""
[ 2624.609] compiled for 1.21.1.3, module version = 0.5.0
[ 2624.609] Module class: X.Org Video Driver
[ 2624.609] ABI class: X.Org Video Driver, version 25.2
[ 2624.609] (II) LoadModule: ""vesa""
[ 2624.609] (II) Loading /usr/lib/xorg/modules/drivers/vesa_drv.so
[ 2624.609] (II) Module vesa: vendor=""X.Org Foundation""
[ 2624.609] compiled for 1.21.1.3, module version = 2.5.0
[ 2624.609] (II) NVIDIA dlloader X Driver 550.54.15 Tue Mar 5 22:03:48 UTC 2024
[ 2624.609] (II) NVIDIA Unified Driver for all Supported NVIDIA GPUs
[ 2624.609] (II) NOUVEAU driver Date: Sat Jan 23 12:24:42 2021 -0500
[ 2624.609] (II) NOUVEAU driver for NVIDIA chipset families :
[ 2624.609] RIVA TNT (NV04)
[ 2624.609] RIVA TNT2 (NV05)
[ 2624.609] GeForce 256 (NV10)
[ 2624.609] GeForce 2 (NV11, NV15)
[ 2624.609] GeForce 4MX (NV17, NV18)
[ 2624.609] GeForce 3 (NV20)
[ 2624.609] GeForce 4Ti (NV25, NV28)
[ 2624.609] GeForce FX (NV3x)
[ 2624.609] GeForce 6 (NV4x)
[ 2624.609] GeForce 7 (G7x)
[ 2624.609] GeForce 8 (G8x)
[ 2624.609] GeForce 9 (G9x)
[ 2624.609] GeForce GTX 2xx/3xx (GT2xx)
[ 2624.609] GeForce GTX 4xx/5xx (GFxxx)
[ 2624.609] GeForce GTX 6xx/7xx (GKxxx)
[ 2624.609] GeForce GTX 9xx (GMxxx)
[ 2624.609] GeForce GTX 10xx (GPxxx)
[ 2624.609] (II) modesetting: Driver for Modesetting Kernel Drivers: kms
[ 2624.609] (II) FBDEV: driver for framebuffer: fbdev
[ 2624.609] (II) VESA: driver for VESA chipsets: vesa
[ 2624.615] (II) Loading sub module ""fb""
[ 2624.615] (II) LoadModule: ""fb""
[ 2624.615] (II) Module ""fb"" already built-in
[ 2624.615] (II) Loading sub module ""wfb""
[ 2624.615] (II) LoadModule: ""wfb""
[ 2624.615] (II) Loading /usr/lib/xorg/modules/libwfb.so
[ 2624.615] (II) Module wfb: vendor=""X.Org Foundation""
[ 2624.615] compiled for 1.21.1.7, module version = 1.0.0
[ 2624.615] ABI class: X.Org ANSI C Emulation, version 0.4
[ 2624.616] (WW) Falling back to old probe method for modesetting
[ 2624.616] (WW) Falling back to old probe method for fbdev
[ 2624.616] (II) Loading sub module ""fbdevhw""
[ 2624.616] (II) LoadModule: ""fbdevhw""
[ 2624.616] (II) Loading /usr/lib/xorg/modules/libfbdevhw.so
[ 2624.616] (II) Module fbdevhw: vendor=""X.Org Foundation""
[ 2624.616] compiled for 1.21.1.7, module version = 0.0.2
[ 2624.616] ABI class: X.Org Video Driver, version 25.2
[ 2624.616] (EE) open /dev/fb0: No such file or directory
[ 2624.616] (II) NVIDIA(0): Creating default Display subsection in Screen section
""Default Screen Section"" for depth/fbbpp 24/32
[ 2624.616] (==) NVIDIA(0): Depth 24, (==) framebuffer bpp 32
[ 2624.616] (==) NVIDIA(0): RGB weight 888
[ 2624.616] (==) NVIDIA(0): Default visual is TrueColor
[ 2624.616] (==) NVIDIA(0): Using gamma correction (1.0, 1.0, 1.0)
[ 2624.616] (**) NVIDIA(0): Enabling 2D acceleration
[ 2624.616] (II) Loading sub module ""glxserver_nvidia""
[ 2624.616] (II) LoadModule: ""glxserver_nvidia""
[ 2624.616] (II) Loading /usr/lib/xorg/modules/extensions/libglxserver_nvidia.so
[ 2624.624] (II) Module glxserver_nvidia: vendor=""NVIDIA Corporation""
[ 2624.624] compiled for 1.6.99.901, module version = 1.0.0
[ 2624.624] Module class: X.Org Server Extension
[ 2624.624] (II) NVIDIA GLX Module 550.54.15 Tue Mar 5 22:04:43 UTC 2024
[ 2624.624] (II) NVIDIA: The X server supports PRIME Render Offload.
[ 2624.624] (--) NVIDIA(0): Valid display device(s) on GPU-0 at PCI:1:0:0
[ 2624.624] (--) NVIDIA(0): CRT-0
[ 2624.624] (--) NVIDIA(0): DFP-0
[ 2624.624] (--) NVIDIA(0): DFP-1 (boot)
[ 2624.624] (--) NVIDIA(0): DFP-2
[ 2624.624] (--) NVIDIA(0): DFP-3
[ 2624.624] (--) NVIDIA(0): DFP-4
[ 2624.625] (II) NVIDIA(0): NVIDIA GPU Quadro K2200 (GM107GL-A) at PCI:1:0:0 (GPU-0)
[ 2624.625] (--) NVIDIA(0): Memory: 4194304 kBytes
[ 2624.625] (--) NVIDIA(0): VideoBIOS: 82.07.5a.00.0a
[ 2624.625] (II) NVIDIA(0): Detected PCI Express Link width: 16X
[ 2624.629] (--) NVIDIA(GPU-0): CRT-0: disconnected
[ 2624.629] (--) NVIDIA(GPU-0): CRT-0: 400.0 MHz maximum pixel clock
[ 2624.633] (--) NVIDIA(GPU-0): DFP-0: disconnected
[ 2624.633] (--) NVIDIA(GPU-0): DFP-0: Internal TMDS
[ 2624.633] (--) NVIDIA(GPU-0): DFP-0: 330.0 MHz maximum pixel clock
[ 2624.678] (--) NVIDIA(GPU-0): AOC 2450W (DFP-1): connected
[ 2624.678] (--) NVIDIA(GPU-0): AOC 2450W (DFP-1): Internal TMDS
[ 2624.678] (--) NVIDIA(GPU-0): AOC 2450W (DFP-1): 165.0 MHz maximum pixel clock
[ 2624.678] (--) NVIDIA(GPU-0): DFP-2: disconnected
[ 2624.678] (--) NVIDIA(GPU-0): DFP-2: Internal TMDS
[ 2624.678] (--) NVIDIA(GPU-0): DFP-2: 165.0 MHz maximum pixel clock
[ 2624.678] (--) NVIDIA(GPU-0): DFP-3: disconnected
[ 2624.678] (--) NVIDIA(GPU-0): DFP-3: Internal DisplayPort
[ 2624.678] (--) NVIDIA(GPU-0): DFP-3: 960.0 MHz maximum pixel clock
[ 2624.678] (--) NVIDIA(GPU-0): DFP-4: disconnected
[ 2624.678] (--) NVIDIA(GPU-0): DFP-4: Internal DisplayPort
[ 2624.678] (--) NVIDIA(GPU-0): DFP-4: 960.0 MHz maximum pixel clock
[ 2624.681] (==) NVIDIA(0):
[ 2624.681] (==) NVIDIA(0): No modes were requested; the default mode ""nvidia-auto-select""
[ 2624.681] (==) NVIDIA(0): will be used as the requested mode.
[ 2624.681] (II) NVIDIA(0): Validated MetaModes:
[ 2624.681] (II) NVIDIA(0): ""DFP-1:nvidia-auto-select""
[ 2624.681] (II) NVIDIA(0): Virtual screen size determined to be 1920 x 1080
[ 2624.686] (--) NVIDIA(0): DPI set to (93, 94); computed from ""UseEdidDpi"" X config
[ 2624.686] (--) NVIDIA(0): option
[ 2624.686] (II) UnloadModule: ""nouveau""
[ 2624.686] (II) Unloading nouveau
[ 2624.686] (II) UnloadModule: ""modesetting""
[ 2624.686] (II) Unloading modesetting
[ 2624.686] (II) UnloadModule: ""fbdev""
[ 2624.686] (II) Unloading fbdev
[ 2624.686] (II) UnloadSubModule: ""fbdevhw""
[ 2624.686] (II) Unloading fbdevhw
[ 2624.686] (II) UnloadModule: ""vesa""
[ 2624.686] (II) Unloading vesa
[ 2624.686] (II) NVIDIA: Reserving 6144.00 MB of virtual memory for indirect memory
[ 2624.686] (II) NVIDIA: access.
[ 2624.689] (II) NVIDIA(0): ACPI: failed to connect to the ACPI event daemon; the daemon
[ 2624.689] (II) NVIDIA(0): may not be running or the ""AcpidSocketPath"" X
[ 2624.689] (II) NVIDIA(0): configuration option may not be set correctly. When the
[ 2624.689] (II) NVIDIA(0): ACPI event daemon is available, the NVIDIA X driver will
[ 2624.689] (II) NVIDIA(0): try to use it to receive ACPI event notifications. For
[ 2624.689] (II) NVIDIA(0): details, please see the ""ConnectToAcpid"" and
[ 2624.689] (II) NVIDIA(0): ""AcpidSocketPath"" X configuration options in Appendix B: X
[ 2624.689] (II) NVIDIA(0): Config Options in the README.
[ 2624.708] (II) NVIDIA(0): Setting mode ""DFP-1:nvidia-auto-select""
[ 2624.754] (==) NVIDIA(0): Disabling shared memory pixmaps
[ 2624.754] (==) NVIDIA(0): Backing store enabled
[ 2624.754] (==) NVIDIA(0): Silken mouse enabled
[ 2624.754] (==) NVIDIA(0): DPMS enabled
[ 2624.754] (II) Loading sub module ""dri2""
[ 2624.754] (II) LoadModule: ""dri2""
[ 2624.754] (II) Module ""dri2"" already built-in
[ 2624.754] (II) NVIDIA(0): [DRI2] Setup complete
[ 2624.754] (II) NVIDIA(0): [DRI2] VDPAU driver: nvidia
[ 2624.754] (II) Initializing extension Generic Event Extension
[ 2624.754] (II) Initializing extension SHAPE
[ 2624.754] (II) Initializing extension MIT-SHM
[ 2624.754] (II) Initializing extension XInputExtension
[ 2624.754] (II) Initializing extension XTEST
[ 2624.755] (II) Initializing extension BIG-REQUESTS
[ 2624.755] (II) Initializing extension SYNC
[ 2624.755] (II) Initializing extension XKEYBOARD
[ 2624.755] (II) Initializing extension XC-MISC
[ 2624.755] (II) Initializing extension SECURITY
[ 2624.755] (II) Initializing extension XFIXES
[ 2624.755] (II) Initializing extension RENDER
[ 2624.755] (II) Initializing extension RANDR
[ 2624.755] (II) Initializing extension COMPOSITE
[ 2624.755] (II) Initializing extension DAMAGE
[ 2624.755] (II) Initializing extension MIT-SCREEN-SAVER
[ 2624.756] (II) Initializing extension DOUBLE-BUFFER
[ 2624.756] (II) Initializing extension RECORD
[ 2624.756] (II) Initializing extension DPMS
[ 2624.756] (II) Initializing extension Present
[ 2624.756] (II) Initializing extension DRI3
[ 2624.756] (II) Initializing extension X-Resource
[ 2624.756] (II) Initializing extension XVideo
[ 2624.756] (II) Initializing extension XVideo-MotionCompensation
[ 2624.756] (II) Initializing extension SELinux
[ 2624.756] (II) SELinux: Disabled on system
[ 2624.756] (II) Initializing extension GLX
[ 2624.756] (II) Indirect GLX disabled.
[ 2624.756] (II) GLX: Another vendor is already registered for screen 0
[ 2624.756] (II) Initializing extension XFree86-VidModeExtension
[ 2624.756] (II) Initializing extension XFree86-DGA
[ 2624.756] (II) Initializing extension XFree86-DRI
[ 2624.756] (II) Initializing extension DRI2
[ 2624.756] (II) Initializing extension NV-GLX
[ 2624.756] (II) Initializing extension NV-CONTROL
[ 2624.756] (II) Initializing extension XINERAMA
[ 2624.791] (II) config/udev: Adding input device Power Button (/dev/input/event2)
[ 2624.791] (**) Power Button: Applying InputClass ""libinput keyboard catchall""
[ 2624.791] (II) LoadModule: ""libinput""
[ 2624.791] (II) Loading /usr/lib/xorg/modules/input/libinput_drv.so
[ 2624.792] (II) Module libinput: vendor=""X.Org Foundation""
[ 2624.792] compiled for 1.21.1.3, module version = 1.2.1
[ 2624.792] Module class: X.Org XInput Driver
[ 2624.792] ABI class: X.Org XInput driver, version 24.4
[ 2624.792] (II) Using input driver 'libinput' for 'Power Button'
[ 2624.792] (**) Power Button: always reports core events
[ 2624.792] (**) Option ""Device"" ""/dev/input/event2""
[ 2624.794] (II) event2 - Power Button: is tagged by udev as: Keyboard
[ 2624.794] (II) event2 - Power Button: device is a keyboard
[ 2624.794] (II) event2 - Power Button: device removed
[ 2624.828] (**) Option ""config_info"" ""udev:/sys/devices/LNXSYSTM:00/LNXPWRBN:00/input/input2/event2""
[ 2624.828] (II) XINPUT: Adding extended input device ""Power Button"" (type: KEYBOARD, id 6)
[ 2624.828] (**) Option ""xkb_model"" ""pc105""
[ 2624.828] (**) Option ""xkb_layout"" ""us""
[ 2624.829] (II) event2 - Power Button: is tagged by udev as: Keyboard
[ 2624.829] (II) event2 - Power Button: device is a keyboard
[ 2624.830] (II) config/udev: Adding input device Power Button (/dev/input/event0)
[ 2624.830] (**) Power Button: Applying InputClass ""libinput keyboard catchall""
[ 2624.830] (II) Using input driver 'libinput' for 'Power Button'
[ 2624.830] (**) Power Button: always reports core events
[ 2624.830] (**) Option ""Device"" ""/dev/input/event0""
[ 2624.830] (II) event0 - Power Button: is tagged by udev as: Keyboard
[ 2624.830] (II) event0 - Power Button: device is a keyboard
[ 2624.830] (II) event0 - Power Button: device removed
[ 2624.856] (**) Option ""config_info"" ""udev:/sys/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0C:00/input/input0/event0""
[ 2624.856] (II) XINPUT: Adding extended input device ""Power Button"" (type: KEYBOARD, id 7)
[ 2624.856] (**) Option ""xkb_model"" ""pc105""
[ 2624.856] (**) Option ""xkb_layout"" ""us""
[ 2624.856] (II) event0 - Power Button: is tagged by udev as: Keyboard
[ 2624.856] (II) event0 - Power Button: device is a keyboard
[ 2624.857] (II) config/udev: Adding input device Sleep Button (/dev/input/event1)
[ 2624.857] (**) Sleep Button: Applying InputClass ""libinput keyboard catchall""
[ 2624.857] (II) Using input driver 'libinput' for 'Sleep Button'
[ 2624.857] (**) Sleep Button: always reports core events
[ 2624.857] (**) Option ""Device"" ""/dev/input/event1""
[ 2624.857] (II) event1 - Sleep Button: is tagged by udev as: Keyboard
[ 2624.857] (II) event1 - Sleep Button: device is a keyboard
[ 2624.857] (II) event1 - Sleep Button: device removed
[ 2624.880] (**) Option ""config_info"" ""udev:/sys/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0E:00/input/input1/event1""
[ 2624.880] (II) XINPUT: Adding extended input device ""Sleep Button"" (type: KEYBOARD, id 8)
[ 2624.880] (**) Option ""xkb_model"" ""pc105""
[ 2624.880] (**) Option ""xkb_layout"" ""us""
[ 2624.880] (II) event1 - Sleep Button: is tagged by udev as: Keyboard
[ 2624.880] (II) event1 - Sleep Button: device is a keyboard
[ 2624.881] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=3 (/dev/input/event6)
[ 2624.881] (II) No input driver specified, ignoring this device.
[ 2624.881] (II) This device may have been added with another device file.
[ 2624.881] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=7 (/dev/input/event7)
[ 2624.881] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=8 (/dev/input/event8)
[ 2624.882] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=9 (/dev/input/event9)
[ 2624.882] (II) No input driver specified, ignoring this device.
[ 2624.882] (II) This device may have been added with another device file.
[ 2624.882] (II) config/udev: Adding input device PS/2+USB Mouse (/dev/input/event4)
[ 2624.882] (**) PS/2+USB Mouse: Applying InputClass ""libinput pointer catchall""
[ 2624.882] (II) Using input driver 'libinput' for 'PS/2+USB Mouse'
[ 2624.882] (**) PS/2+USB Mouse: always reports core events
[ 2624.882] (**) Option ""Device"" ""/dev/input/event4""
[ 2624.941] (II) event4 - PS/2+USB Mouse: is tagged by udev as: Mouse
[ 2624.941] (II) event4 - PS/2+USB Mouse: device is a pointer
[ 2624.941] (II) event4 - PS/2+USB Mouse: device removed
[ 2624.972] (**) Option ""config_info"" ""udev:/sys/devices/pci0000:00/0000:00:14.0/usb2/2-3/2-3.1/2-3.1.3/2-3.1.3:1.0/0003:1267:0210.0002/input/input4/event4""
[ 2624.972] (II) XINPUT: Adding extended input device ""PS/2+USB Mouse"" (type: MOUSE, id 9)
[ 2624.972] (**) Option ""AccelerationScheme"" ""none""
[ 2624.972] (**) PS/2+USB Mouse: (accel) selected scheme none/0
[ 2624.972] (**) PS/2+USB Mouse: (accel) acceleration factor: 2.000
[ 2624.972] (**) PS/2+USB Mouse: (accel) acceleration threshold: 4
[ 2625.033] (II) event4 - PS/2+USB Mouse: is tagged by udev as: Mouse
[ 2625.033] (II) event4 - PS/2+USB Mouse: device is a pointer
[ 2625.033] (II) config/udev: Adding input device PS/2+USB Mouse (/dev/input/mouse0)
[ 2625.033] (II) No input driver specified, ignoring this device.
[ 2625.033] (II) This device may have been added with another device file.
[ 2625.034] (II) config/udev: Adding input device Silitek USB Keyboard (/dev/input/event3)
[ 2625.034] (**) Silitek USB Keyboard: Applying InputClass ""libinput keyboard catchall""
[ 2625.034] (II) Using input driver 'libinput' for 'Silitek USB Keyboard'
[ 2625.034] (**) Silitek USB Keyboard: always reports core events
[ 2625.034] (**) Option ""Device"" ""/dev/input/event3""
[ 2625.035] (II) event3 - Silitek USB Keyboard: is tagged by udev as: Keyboard
[ 2625.035] (II) event3 - Silitek USB Keyboard: device is a keyboard
[ 2625.035] (II) event3 - Silitek USB Keyboard: device removed
[ 2625.048] (**) Option ""config_info"" ""udev:/sys/devices/pci0000:00/0000:00:14.0/usb2/2-3/2-3.1/2-3.1.4/2-3.1.4:1.0/0003:049F:0083.0001/input/input3/event3""
[ 2625.048] (II) XINPUT: Adding extended input device ""Silitek USB Keyboard"" (type: KEYBOARD, id 10)
[ 2625.048] (**) Option ""xkb_model"" ""pc105""
[ 2625.048] (**) Option ""xkb_layout"" ""us""
[ 2625.049] (II) event3 - Silitek USB Keyboard: is tagged by udev as: Keyboard
[ 2625.049] (II) event3 - Silitek USB Keyboard: device is a keyboard
[ 2625.050] (II) config/udev: Adding input device HDA Intel PCH Front Mic (/dev/input/event10)
[ 2625.050] (II) No input driver specified, ignoring this device.
[ 2625.050] (II) This device may have been added with another device file.
[ 2625.050] (II) config/udev: Adding input device HDA Intel PCH Rear Mic (/dev/input/event11)
[ 2625.051] (II) config/udev: Adding input device HDA Intel PCH Line (/dev/input/event12)
[ 2625.051] (II) No input driver specified, ignoring this device.
[ 2625.051] (II) This device may have been added with another device file.
[ 2625.051] (II) config/udev: Adding input device HDA Intel PCH Line Out Front (/dev/input/event13)
[ 2625.051] (II) config/udev: Adding input device HDA Intel PCH Line Out Surround (/dev/input/event14)
[ 2625.051] (II) config/udev: Adding input device HDA Intel PCH Line Out CLFE (/dev/input/event15)
[ 2625.052] (II) config/udev: Adding input device HDA Intel PCH Line Out Side (/dev/input/event16)
[ 2625.052] (II) No input driver specified, ignoring this device.
[ 2625.052] (II) This device may have been added with another device file.
[ 2625.052] (II) config/udev: Adding input device HDA Intel PCH Front Headphone (/dev/input/event17)
[ 2625.052] (II) config/udev: Adding input device PC Speaker (/dev/input/event5)
[ 2917.767] (--) NVIDIA(GPU-0): CRT-0: disconnected
[ 2917.767] (--) NVIDIA(GPU-0): CRT-0: 400.0 MHz maximum pixel clock
[ 2917.770] (--) NVIDIA(GPU-0): DFP-0: disconnected
[ 2917.770] (--) NVIDIA(GPU-0): DFP-0: Internal TMDS
[ 2917.770] (--) NVIDIA(GPU-0): DFP-0: 330.0 MHz maximum pixel clock
[ 2917.816] (--) NVIDIA(GPU-0): AOC 2450W (DFP-1): connected
[ 2917.816] (--) NVIDIA(GPU-0): AOC 2450W (DFP-1): Internal TMDS
[ 2917.816] (--) NVIDIA(GPU-0): AOC 2450W (DFP-1): 165.0 MHz maximum pixel clock
[ 2917.816] (--) NVIDIA(GPU-0): DFP-2: disconnected
[ 2917.816] (--) NVIDIA(GPU-0): DFP-2: Internal TMDS
[ 2917.816] (--) NVIDIA(GPU-0): DFP-2: 165.0 MHz maximum pixel clock
[ 2917.816] (--) NVIDIA(GPU-0): DFP-3: disconnected
[ 2917.816] (--) NVIDIA(GPU-0): DFP-3: Internal DisplayPort
[ 2917.816] (--) NVIDIA(GPU-0): DFP-3: 960.0 MHz maximum pixel clock
[ 2917.816] (--) NVIDIA(GPU-0): DFP-4: disconnected
[ 2917.816] (--) NVIDIA(GPU-0): DFP-4: Internal DisplayPort
[ 2917.816] (--) NVIDIA(GPU-0): DFP-4: 960.0 MHz maximum pixel clock
[ 2918.076] (--) NVIDIA(GPU-0): CRT-0: disconnected
[ 2918.076] (--) NVIDIA(GPU-0): CRT-0: 400.0 MHz maximum pixel clock
[ 2918.080] (--) NVIDIA(GPU-0): DFP-0: disconnected
[ 2918.080] (--) NVIDIA(GPU-0): DFP-0: Internal TMDS
[ 2918.080] (--) NVIDIA(GPU-0): DFP-0: 330.0 MHz maximum pixel clock
[ 2918.126] (--) NVIDIA(GPU-0): AOC 2450W (DFP-1): connected
[ 2918.126] (--) NVIDIA(GPU-0): AOC 2450W (DFP-1): Internal TMDS
[ 2918.126] (--) NVIDIA(GPU-0): AOC 2450W (DFP-1): 165.0 MHz maximum pixel clock
[ 2918.126] (--) NVIDIA(GPU-0): DFP-2: disconnected
[ 2918.126] (--) NVIDIA(GPU-0): DFP-2: Internal TMDS
[ 2918.126] (--) NVIDIA(GPU-0): DFP-2: 165.0 MHz maximum pixel clock
[ 2918.126] (--) NVIDIA(GPU-0): DFP-3: disconnected
[ 2918.126] (--) NVIDIA(GPU-0): DFP-3: Internal DisplayPort
[ 2918.126] (--) NVIDIA(GPU-0): DFP-3: 960.0 MHz maximum pixel clock
[ 2918.126] (--) NVIDIA(GPU-0): DFP-4: disconnected
[ 2918.126] (--) NVIDIA(GPU-0): DFP-4: Internal DisplayPort
[ 2918.126] (--) NVIDIA(GPU-0): DFP-4: 960.0 MHz maximum pixel clock
[ 11776.672] (II) event4 - PS/2+USB Mouse: Enabling spurious button debouncing, see https://wayland.freedesktop.org/libinput/doc/1.22.1/button-debouncing.html for details
[ 13621.664] (--) NVIDIA(GPU-0): AOC 2450W (DFP-1): connected
[ 13621.664] (--) NVIDIA(GPU-0): AOC 2450W (DFP-1): Internal TMDS
[ 13621.664] (--) NVIDIA(GPU-0): AOC 2450W (DFP-1): 165.0 MHz maximum pixel clock
[ 13621.712] (--) NVIDIA(GPU-0): AOC 2450W (DFP-1): connected
[ 13621.712] (--) NVIDIA(GPU-0): AOC 2450W (DFP-1): Internal TMDS
[ 13621.712] (--) NVIDIA(GPU-0): AOC 2450W (DFP-1): 165.0 MHz maximum pixel clock
[ 14435.098] (--) NVIDIA(GPU-0): AOC 2450W (DFP-1): connected
[ 14435.099] (--) NVIDIA(GPU-0): AOC 2450W (DFP-1): Internal TMDS
[ 14435.099] (--) NVIDIA(GPU-0): AOC 2450W (DFP-1): 165.0 MHz maximum pixel clock
[ 14435.147] (--) NVIDIA(GPU-0): AOC 2450W (DFP-1): connected
[ 14435.147] (--) NVIDIA(GPU-0): AOC 2450W (DFP-1): Internal TMDS
[ 14435.147] (--) NVIDIA(GPU-0): AOC 2450W (DFP-1): 165.0 MHz maximum pixel clock
[ 15717.202] (--) NVIDIA(GPU-0): AOC 2450W (DFP-1): connected
[ 15717.202] (--) NVIDIA(GPU-0): AOC 2450W (DFP-1): Internal TMDS
[ 15717.202] (--) NVIDIA(GPU-0): AOC 2450W (DFP-1): 165.0 MHz maximum pixel clock
[ 15717.251] (--) NVIDIA(GPU-0): AOC 2450W (DFP-1): connected
[ 15717.251] (--) NVIDIA(GPU-0): AOC 2450W (DFP-1): Internal TMDS
[ 15717.251] (--) NVIDIA(GPU-0): AOC 2450W (DFP-1): 165.0 MHz maximum pixel clock
[ 41851.933] (--) NVIDIA(GPU-0): AOC 2450W (DFP-1): connected
[ 41851.933] (--) NVIDIA(GPU-0): AOC 2450W (DFP-1): Internal TMDS
[ 41851.933] (--) NVIDIA(GPU-0): AOC 2450W (DFP-1): 165.0 MHz maximum pixel clock
[ 41851.983] (--) NVIDIA(GPU-0): AOC 2450W (DFP-1): connected
[ 41851.983] (--) NVIDIA(GPU-0): AOC 2450W (DFP-1): Internal TMDS
[ 41851.983] (--) NVIDIA(GPU-0): AOC 2450W (DFP-1): 165.0 MHz maximum pixel clock
[ 79036.865] (--) NVIDIA(GPU-0): AOC 2450W (DFP-1): connected
[ 79036.878] (--) NVIDIA(GPU-0): AOC 2450W (DFP-1): Internal TMDS
[ 79036.878] (--) NVIDIA(GPU-0): AOC 2450W (DFP-1): 165.0 MHz maximum pixel clock
[ 79036.927] (--) NVIDIA(GPU-0): AOC 2450W (DFP-1): connected
[ 79036.927] (--) NVIDIA(GPU-0): AOC 2450W (DFP-1): Internal TMDS
[ 79036.927] (--) NVIDIA(GPU-0): AOC 2450W (DFP-1): 165.0 MHz maximum pixel clock
[ 82637.140] (--) NVIDIA(GPU-0): AOC 2450W (DFP-1): connected
[ 82637.140] (--) NVIDIA(GPU-0): AOC 2450W (DFP-1): Internal TMDS
[ 82637.140] (--) NVIDIA(GPU-0): AOC 2450W (DFP-1): 165.0 MHz maximum pixel clock
[ 82637.189] (--) NVIDIA(GPU-0): AOC 2450W (DFP-1): connected
[ 82637.189] (--) NVIDIA(GPU-0): AOC 2450W (DFP-1): Internal TMDS
[ 82637.189] (--) NVIDIA(GPU-0): AOC 2450W (DFP-1): 165.0 MHz maximum pixel clock
[ 91000.690] (--) NVIDIA(GPU-0): CRT-0: disconnected
[ 91000.690] (--) NVIDIA(GPU-0): CRT-0: 400.0 MHz maximum pixel clock
[ 91000.694] (--) NVIDIA(GPU-0): DFP-0: disconnected
[ 91000.694] (--) NVIDIA(GPU-0): DFP-0: Internal TMDS
[ 91000.694] (--) NVIDIA(GPU-0): DFP-0: 330.0 MHz maximum pixel clock
[ 91000.739] (--) NVIDIA(GPU-0): AOC 2450W (DFP-1): connected
[ 91000.739] (--) NVIDIA(GPU-0): AOC 2450W (DFP-1): Internal TMDS
[ 91000.739] (--) NVIDIA(GPU-0): AOC 2450W (DFP-1): 165.0 MHz maximum pixel clock
[ 91000.739] (--) NVIDIA(GPU-0): DFP-2: disconnected
[ 91000.739] (--) NVIDIA(GPU-0): DFP-2: Internal TMDS
[ 91000.739] (--) NVIDIA(GPU-0): DFP-2: 165.0 MHz maximum pixel clock
[ 91000.739] (--) NVIDIA(GPU-0): DFP-3: disconnected
[ 91000.739] (--) NVIDIA(GPU-0): DFP-3: Internal DisplayPort
[ 91000.739] (--) NVIDIA(GPU-0): DFP-3: 960.0 MHz maximum pixel clock
[ 91000.739] (--) NVIDIA(GPU-0): DFP-4: disconnected
[ 91000.739] (--) NVIDIA(GPU-0): DFP-4: Internal DisplayPort
[ 91000.739] (--) NVIDIA(GPU-0): DFP-4: 960.0 MHz maximum pixel clock
[ 91001.676] (--) NVIDIA(GPU-0): CRT-0: disconnected
[ 91001.676] (--) NVIDIA(GPU-0): CRT-0: 400.0 MHz maximum pixel clock
[ 91001.680] (--) NVIDIA(GPU-0): DFP-0: disconnected
[ 91001.680] (--) NVIDIA(GPU-0): DFP-0: Internal TMDS
[ 91001.680] (--) NVIDIA(GPU-0): DFP-0: 330.0 MHz maximum pixel clock
[ 91001.725] (--) NVIDIA(GPU-0): AOC 2450W (DFP-1): connected
[ 91001.725] (--) NVIDIA(GPU-0): AOC 2450W (DFP-1): Internal TMDS
[ 91001.725] (--) NVIDIA(GPU-0): AOC 2450W (DFP-1): 165.0 MHz maximum pixel clock
[ 91001.725] (--) NVIDIA(GPU-0): DFP-2: disconnected
[ 91001.725] (--) NVIDIA(GPU-0): DFP-2: Internal TMDS
[ 91001.725] (--) NVIDIA(GPU-0): DFP-2: 165.0 MHz maximum pixel clock
[ 91001.725] (--) NVIDIA(GPU-0): DFP-3: disconnected
[ 91001.725] (--) NVIDIA(GPU-0): DFP-3: Internal DisplayPort
[ 91001.725] (--) NVIDIA(GPU-0): DFP-3: 960.0 MHz maximum pixel clock
[ 91001.725] (--) NVIDIA(GPU-0): DFP-4: disconnected
[ 91001.725] (--) NVIDIA(GPU-0): DFP-4: Internal DisplayPort
[ 91001.725] (--) NVIDIA(GPU-0): DFP-4: 960.0 MHz maximum pixel clock
[ 91001.743] (--) NVIDIA(GPU-0): CRT-0: disconnected
[ 91001.743] (--) NVIDIA(GPU-0): CRT-0: 400.0 MHz maximum pixel clock
[ 91001.746] (--) NVIDIA(GPU-0): DFP-0: disconnected
[ 91001.746] (--) NVIDIA(GPU-0): DFP-0: Internal TMDS
[ 91001.746] (--) NVIDIA(GPU-0): DFP-0: 330.0 MHz maximum pixel clock
[ 91001.792] (--) NVIDIA(GPU-0): AOC 2450W (DFP-1): connected
[ 91001.792] (--) NVIDIA(GPU-0): AOC 2450W (DFP-1): Internal TMDS
[ 91001.792] (--) NVIDIA(GPU-0): AOC 2450W (DFP-1): 165.0 MHz maximum pixel clock
[ 91001.792] (--) NVIDIA(GPU-0): DFP-2: disconnected
[ 91001.792] (--) NVIDIA(GPU-0): DFP-2: Internal TMDS
[ 91001.792] (--) NVIDIA(GPU-0): DFP-2: 165.0 MHz maximum pixel clock
[ 91001.792] (--) NVIDIA(GPU-0): DFP-3: disconnected
[ 91001.792] (--) NVIDIA(GPU-0): DFP-3: Internal DisplayPort
[ 91001.792] (--) NVIDIA(GPU-0): DFP-3: 960.0 MHz maximum pixel clock
[ 91001.792] (--) NVIDIA(GPU-0): DFP-4: disconnected
[ 91001.792] (--) NVIDIA(GPU-0): DFP-4: Internal DisplayPort
[ 91001.792] (--) NVIDIA(GPU-0): DFP-4: 960.0 MHz maximum pixel clock
```","<p>Hi,</p>
<p>on Debian Bookworm/xfce + nvidia closed source drivers, my desktop remains black after sleep or switching terminals. The xserver is running and thereâs a mouse pointer but no window manager/desktop.</p>
<p>I honestly donât know if itâs an issue with the driver, but there seem to be similiar looking problems on the forum. It seems like it should be something simple, as everything works perfectly until the screen is put to sleep.</p>
<p>Also, Iâm using a Display Port via an HDMI adapter. And Iâm only using one screen at the moment, but Iâd typically want two working.</p>
<p>The card has worked for years on the same box running Ubuntu without issues. When I installed Debian/xfce I was getting intermittent GPU crashes with the nouveau driver so, after unsuccessfully trying the open source nvidia driver, I switched to the proprietary one.</p>
<p>I wonder if the following lines in <em>/var/log/Xorg.0.log</em> could be a clue:</p>
<pre><code class=""lang-auto"">[ 102.447] (II) NVIDIA(0): Setting mode ""DFP-1:nvidia-auto-select""
</code></pre>
<p>Iâve searched the 3000 or so files called README on my system, but none have the string âAcpidSocketPathâ or âConnectToAcpidâ. Also, the ACPI event daemon is not installed on my system.</p>
<p>I can install it, but Iâm not in a hurry to reinstall the nvidia drivers, as it has been a journey. Therefore, Iâm guessing Iâll have to manually configure whatever links acpid to nvidia.</p>
<p>Any pointer to doing this configuration, or any other clues or pointers, would be greatly appreciated!</p>
<p>:-)</p>
<p>Cheers,<br>
bitrat</p>
<hr>
<p>PS: I see the following in <em>/usr/share/X11/xorg.conf.d/nvidia-drm-outputclass.conf</em></p>
<pre><code class=""lang-auto""># This xorg.conf.d configuration snippet configures the X server to
Driver ""nvidia""
EndSection
</code></pre>
<p>According to the Xorg log (see below) the nouveau driver is loaded, then unloaded, then nvidia. Can I improve this?</p>
<p>FYI:</p>
<pre><code class=""lang-auto"">$ lsmod | grep nvidia
nvidia_drm 102400 5
</code></pre>
<p>Xorg log follows:</p>
<p>I couldnât see where to attach an nvidia-bug-report. I can get one from another machine when the screen is blank as well.</p>
<pre><code class=""lang-auto"">$ sudo cat /var/log/Xorg.0.log
[ 2624.382]
built-ins
