I am using IBM’s AC922 (POWER9 chips) with V100 Tesla GPUs. This server has an integrated VGA port, which I use as the console port. It works fine with Redhat 7.4, probably with nouveau driver.
But as soon as I install CUDA on this server and reboot, the console screen shows big sad face with “Oh no something has gone wrong” message. I believe this is because NVIDIA driver automatically puts nouveau into the blacklist, and the AOC VGA port doesn’t work with NVIDIA driver. Now I can use only text screen with this VGA port.
How can I fix this problem ? I’d really like to have my GUI screen back.
The following is the content of /var/log/Xorg.0.log. I notice there are several (EE) errors as below.
[ 63.180] (EE) modeset(0): eglGetDisplay() failed
[ 63.180] (EE) modeset(0): glamor initialization failed
[ 62.647]
X.Org X Server 1.19.3
Release Date: 2017-03-15
[ 62.647] X Protocol Version 11, Revision 0
[ 62.647] Build Operating System: 3.10.0-514.el7.ppc64le
[ 62.647] Current Operating System: Linux localhost.localdomain 4.11.0-44.el7a.ppc64le #1 SMP Mon Oct 16 17:13:52 EDT 2017 ppc64le
[ 62.647] Kernel command line: root=UUID=6679f5fb-4539-4614-932d-8320a19e68db ro crashkernel=auto rd.md.uuid=37b3c850:5a511f5a:312d95ee:730a3d2a rd.md.uuid=f5b23807:933062c5:eb1791e2:060b6fc4 rhgb quiet LANG=en_US.UTF-8
[ 62.647] Build Date: 26 June 2017 06:31:24PM
[ 62.647] Build ID: xorg-x11-server 1.19.3-11.el7
[ 62.647] Current version of pixman: 0.34.0
[ 62.647] Before reporting problems, check http://wiki.x.org
to make sure that you have the latest version.
[ 62.647] Markers: (–) probed, () from config file, (==) default setting,
(++) from command line, (!!) notice, (II) informational,
(WW) warning, (EE) error, (NI) not implemented, (??) unknown.
[ 62.647] (==) Log file: “/var/log/Xorg.0.log”, Time: Sat Feb 10 23:15:19 2018
[ 62.647] (==) Using config directory: “/etc/X11/xorg.conf.d”
[ 62.647] (==) Using system config directory “/usr/share/X11/xorg.conf.d”
[ 62.648] (==) No Layout section. Using the first Screen section.
[ 62.648] (==) No screen section available. Using defaults.
[ 62.648] () |–>Screen “Default Screen Section” (0)
[ 62.648] () | |–>Monitor “”
[ 62.648] (==) No monitor specified for screen “Default Screen Section”.
Using a default monitor configuration.
[ 62.648] (==) Automatically adding devices
[ 62.648] (==) Automatically enabling devices
[ 62.648] (==) Automatically adding GPU devices
[ 62.648] (==) Automatically binding GPU devices
[ 62.648] (==) Max clients allowed: 256, resource mask: 0x1fffff
[ 62.648] (==) FontPath set to:
catalogue:/etc/X11/fontpath.d,
built-ins
[ 62.648] () ModulePath set to “/usr/lib64/nvidia/xorg,/usr/lib64/xorg/modules”
[ 62.648] (II) The server relies on udev to provide the list of input devices.
If no devices become available, reconfigure udev or disable AutoAddDevices.
[ 62.648] (II) Loader magic: 0x27170008
[ 62.648] (II) Module ABI versions:
[ 62.648] X.Org ANSI C Emulation: 0.4
[ 62.648] X.Org Video Driver: 23.0
[ 62.648] X.Org XInput driver : 24.1
[ 62.648] X.Org Server Extension : 10.0
[ 62.648] (II) xfree86: Adding drm device (/dev/dri/card0)
[ 62.648] (II) xfree86: Adding drm device (/dev/dri/card1)
[ 62.648] (II) xfree86: Adding drm device (/dev/dri/card2)
[ 62.648] (II) xfree86: Adding drm device (/dev/dri/card3)
[ 62.649] (II) xfree86: Adding drm device (/dev/dri/card4)
[ 62.653] (–) PCI:*(2:2:0:0) 1a03:2000:1a03:2000 rev 65, Mem @ 0x600c100000000/16777216, 0x600c101000000/131072, BIOS @ 0x???/65536
[ 62.653] (–) PCI: (4:4:0:0) 10de:1db1:10de:1212 rev 161, Mem @ 0x600c200000000/16777216, 0x6024000000000/17179869184, 0x6024400000000/33554432, BIOS @ 0x???/65536
[ 62.653] (–) PCI: (4:5:0:0) 10de:1db1:10de:1212 rev 161, Mem @ 0x600c201000000/16777216, 0x6024800000000/17179869184, 0x6024600000000/33554432, BIOS @ 0x???/65536
[ 62.653] (–) PCI: (53:3:0:0) 10de:1db1:10de:1212 rev 161, Mem @ 0x620c280000000/16777216, 0x6228000000000/17179869184, 0x6228400000000/33554432, BIOS @ 0x???/65536
[ 62.653] (–) PCI: (53:4:0:0) 10de:1db1:10de:1212 rev 161, Mem @ 0x620c281000000/16777216, 0x6228800000000/17179869184, 0x6228600000000/33554432, BIOS @ 0x???/65536
[ 62.653] (WW) “glamoregl” will not be loaded unless you’ve specified it to be loaded elsewhere.
[ 62.653] (II) “glx” will be loaded by default.
[ 62.653] (II) LoadModule: “glx”
[ 62.653] (II) Loading /usr/lib64/nvidia/xorg/libglx.so
[ 62.721] (II) Module glx: vendor=“NVIDIA Corporation”
[ 62.721] compiled for 4.0.2, module version = 1.0.0
[ 62.721] Module class: X.Org Server Extension
[ 62.721] (II) NVIDIA GLX Module 390.46 Fri Mar 16 21:36:43 PDT 2018
[ 63.087] (==) Matched nouveau as autoconfigured driver 0
[ 63.087] (==) Matched nouveau as autoconfigured driver 1
[ 63.087] (==) Matched nouveau as autoconfigured driver 2
[ 63.087] (==) Matched nouveau as autoconfigured driver 3
[ 63.087] (==) Matched modesetting as autoconfigured driver 4
[ 63.087] (==) Matched fbdev as autoconfigured driver 5
[ 63.087] (==) Assigned the driver to the xf86ConfigLayout
[ 63.087] (II) LoadModule: “nouveau”
[ 63.087] (II) Loading /usr/lib64/xorg/modules/drivers/nouveau_drv.so
[ 63.088] (II) Module nouveau: vendor=“X.Org Foundation”
[ 63.088] compiled for 1.19.3, module version = 1.0.13
[ 63.088] Module class: X.Org Video Driver
[ 63.088] ABI class: X.Org Video Driver, version 23.0
[ 63.088] (II) LoadModule: “modesetting”
[ 63.088] (II) Loading /usr/lib64/xorg/modules/drivers/modesetting_drv.so
[ 63.088] (II) Module modesetting: vendor=“X.Org Foundation”
[ 63.088] compiled for 1.19.3, module version = 1.19.3
[ 63.088] (II) LoadModule: “fbdev”
[ 63.088] (II) Loading /usr/lib64/xorg/modules/drivers/fbdev_drv.so
[ 63.088] (II) Module fbdev: vendor=“X.Org Foundation”
[ 63.088] compiled for 1.19.1, module version = 0.4.3
[ 63.088] (II) NOUVEAU driver
[ 63.088] (II) NOUVEAU driver for NVIDIA chipset families :
[ 63.088] RIVA TNT (NV04)
[ 63.089] RIVA TNT2 (NV05)
[ 63.089] GeForce 256 (NV10)
[ 63.089] GeForce 2 (NV11, NV15)
[ 63.089] GeForce 4MX (NV17, NV18)
[ 63.089] GeForce 3 (NV20)
[ 63.089] GeForce 4Ti (NV25, NV28)
[ 63.089] GeForce FX (NV3x)
[ 63.089] GeForce 6 (NV4x)
[ 63.089] GeForce 7 (G7x)
[ 63.089] GeForce 8 (G8x)
[ 63.089] GeForce GTX 200 (NVA0)
[ 63.089] GeForce GTX 400 (NVC0)
[ 63.089] (II) modesetting: Driver for Modesetting Kernel Drivers: kms
[ 63.089] (II) FBDEV: driver for framebuffer: fbdev
[ 63.089] (++) using VT number 1
[ 63.089] (EE) [drm] Failed to open DRM device for (null): -2
[ 63.089] (II) modeset(0): using drv /dev/dri/card0
[ 63.089] (WW) Falling back to old probe method for fbdev
[ 63.090] (II) Loading sub module “fbdevhw”
[ 63.090] (II) LoadModule: “fbdevhw”
[ 63.090] (II) Loading /usr/lib64/xorg/modules/libfbdevhw.so
[ 63.090] (II) Module fbdevhw: vendor=“X.Org Foundation”
[ 63.090] compiled for 1.19.3, module version = 0.0.2
[ 63.090] ABI class: X.Org Video Driver, version 23.0
[ 63.090] (II) modeset(0): Creating default Display subsection in Screen section
“Default Screen Section” for depth/fbbpp 24/32
[ 63.090] (==) modeset(0): Depth 24, (==) framebuffer bpp 32
[ 63.090] (==) modeset(0): RGB weight 888
[ 63.090] (==) modeset(0): Default visual is TrueColor
[ 63.090] (II) Loading sub module “glamoregl”
[ 63.090] (II) LoadModule: “glamoregl”
[ 63.090] (II) Loading /usr/lib64/xorg/modules/libglamoregl.so
[ 63.098] (II) Module glamoregl: vendor=“X.Org Foundation”
[ 63.098] compiled for 1.19.3, module version = 1.0.0
[ 63.098] ABI class: X.Org ANSI C Emulation, version 0.4
[ 63.098] (II) glamor: OpenGL accelerated X.org driver based.
[ 63.180] (II) modeset(0): ShadowFB: preferred YES, enabled YES
[ 63.180] (II) modeset(0): Double-buffered shadow updates: on
[ 63.243] (II) modeset(0): Output VGA-1 has no monitor section
[ 63.304] (II) modeset(0): EDID for output VGA-1
[ 63.304] (II) modeset(0): Manufacturer: AOC Model: 2351 Serial#: 347
[ 63.305] (II) modeset(0): Year: 2012 Week: 11
[ 63.305] (II) modeset(0): EDID Version: 1.3
[ 63.305] (II) modeset(0): Analog Display Input, Input Voltage Level: 0.700/0.700 V
[ 63.305] (II) modeset(0): Sync: Separate
[ 63.305] (II) modeset(0): Max Image Size [cm]: horiz.: 51 vert.: 29
[ 63.305] (II) modeset(0): Gamma: 2.20
[ 63.305] (II) modeset(0): DPMS capabilities: Off; RGB/Color Display
[ 63.305] (II) modeset(0): First detailed timing is preferred mode
[ 63.305] (II) modeset(0): redX: 0.642 redY: 0.331 greenX: 0.306 greenY: 0.625
[ 63.305] (II) modeset(0): blueX: 0.151 blueY: 0.073 whiteX: 0.313 whiteY: 0.329
[ 63.305] (II) modeset(0): Supported established timings:
[ 63.305] (II) modeset(0): 720x400@70Hz
[ 63.305] (II) modeset(0): 640x480@60Hz
[ 63.305] (II) modeset(0): 640x480@67Hz
[ 63.305] (II) modeset(0): 640x480@72Hz
[ 63.305] (II) modeset(0): 640x480@75Hz
[ 63.305] (II) modeset(0): 800x600@56Hz
[ 63.305] (II) modeset(0): 800x600@60Hz
[ 63.305] (II) modeset(0): 800x600@72Hz
[ 63.305] (II) modeset(0): 800x600@75Hz
[ 63.305] (II) modeset(0): 832x624@75Hz
[ 63.305] (II) modeset(0): 1024x768@60Hz
[ 63.305] (II) modeset(0): 1024x768@70Hz
[ 63.305] (II) modeset(0): 1024x768@75Hz
[ 63.305] (II) modeset(0): 1280x1024@75Hz
[ 63.305] (II) modeset(0): Manufacturer’s mask: 0
[ 63.305] (II) modeset(0): Supported standard timings:
[ 63.305] (II) modeset(0): #0: hsize: 1920 vsize 1080 refresh: 60 vid: 49361
[ 63.305] (II) modeset(0): #1: hsize: 1680 vsize 1050 refresh: 60 vid: 179
[ 63.305] (II) modeset(0): #2: hsize: 1440 vsize 900 refresh: 60 vid: 149
[ 63.305] (II) modeset(0): #3: hsize: 1280 vsize 1024 refresh: 60 vid: 32897
[ 63.305] (II) modeset(0): #4: hsize: 1280 vsize 960 refresh: 60 vid: 16513
[ 63.305] (II) modeset(0): #5: hsize: 1280 vsize 720 refresh: 60 vid: 49281
[ 63.305] (II) modeset(0): Supported detailed timing:
[ 63.305] (II) modeset(0): clock: 148.5 MHz Image Size: 509 x 286 mm
[ 63.305] (II) modeset(0): h_active: 1920 h_sync: 2008 h_sync_end 2052 h_blank_end 2200 h_border: 0
[ 63.305] (II) modeset(0): v_active: 1080 v_sync: 1084 v_sync_end 1089 v_blanking: 1125 v_border: 0
[ 63.305] (II) modeset(0): Ranges: V min: 50 V max: 76 Hz, H min: 30 H max: 83 kHz, PixClock max 175 MHz
[ 63.305] (II) modeset(0): Monitor name: 2351
[ 63.305] (II) modeset(0): Serial No: AHZC3OA000347
[ 63.305] (II) modeset(0): EDID (in hex):
[ 63.305] (II) modeset(0): 00ffffffffffff0005e351235b010000
[ 63.305] (II) modeset(0): 0b16010368331d782a74f5a4544ea026
[ 63.305] (II) modeset(0): 125054bfef00d1c0b300950081808140
[ 63.305] (II) modeset(0): 81c001010101023a801871382d40582c
[ 63.305] (II) modeset(0): 4500fd1e1100001e000000fd00324c1e
[ 63.305] (II) modeset(0): 5311000a202020202020000000fc0032
[ 63.305] (II) modeset(0): 3335310a2020202020202020000000ff
[ 63.305] (II) modeset(0): 0041485a43334f41303030333437006b
[ 63.305] (II) modeset(0): Printing probed modes for output VGA-1
[ 63.305] (II) modeset(0): Modeline "1920x1080"x60.0 148.50 1920 2008 2052 2200 1080 1084 1089 1125 +hsync +vsync (67.5 kHz eP)
[ 63.305] (II) modeset(0): Modeline "1680x1050"x60.0 146.25 1680 1784 1960 2240 1050 1053 1059 1089 -hsync +vsync (65.3 kHz e)
[ 63.305] (II) modeset(0): Modeline "1280x1024"x75.0 135.00 1280 1296 1440 1688 1024 1025 1028 1066 +hsync +vsync (80.0 kHz e)
[ 63.305] (II) modeset(0): Modeline "1280x1024"x60.0 108.00 1280 1328 1440 1688 1024 1025 1028 1066 +hsync +vsync (64.0 kHz e)
[ 63.305] (II) modeset(0): Modeline "1440x900"x59.9 106.50 1440 1520 1672 1904 900 903 909 934 -hsync +vsync (55.9 kHz e)
[ 63.305] (II) modeset(0): Modeline "1024x768"x75.0 78.75 1024 1040 1136 1312 768 769 772 800 +hsync +vsync (60.0 kHz e)
[ 63.305] (II) modeset(0): Modeline "1024x768"x70.1 75.00 1024 1048 1184 1328 768 771 777 806 -hsync -vsync (56.5 kHz e)
[ 63.305] (II) modeset(0): Modeline "1024x768"x60.0 65.00 1024 1048 1184 1344 768 771 777 806 -hsync -vsync (48.4 kHz e)
[ 63.305] (II) modeset(0): Modeline "800x600"x72.2 50.00 800 856 976 1040 600 637 643 666 +hsync +vsync (48.1 kHz e)
[ 63.305] (II) modeset(0): Modeline "800x600"x75.0 49.50 800 816 896 1056 600 601 604 625 +hsync +vsync (46.9 kHz e)
[ 63.305] (II) modeset(0): Modeline "800x600"x60.3 40.00 800 840 968 1056 600 601 605 628 +hsync +vsync (37.9 kHz e)
[ 63.305] (II) modeset(0): Modeline "800x600"x56.2 36.00 800 824 896 1024 600 601 603 625 +hsync +vsync (35.2 kHz e)
[ 63.305] (II) modeset(0): Modeline "640x480"x75.0 31.50 640 656 720 840 480 481 484 500 -hsync -vsync (37.5 kHz e)
[ 63.305] (II) modeset(0): Modeline "640x480"x72.8 31.50 640 664 704 832 480 489 492 520 -hsync -vsync (37.9 kHz e)
[ 63.305] (II) modeset(0): Modeline "640x480"x66.7 30.24 640 704 768 864 480 483 486 525 -hsync -vsync (35.0 kHz e)
[ 63.305] (II) modeset(0): Modeline "640x480"x59.9 25.18 640 656 752 800 480 490 492 525 -hsync -vsync (31.5 kHz e)
[ 63.305] (II) modeset(0): Output VGA-1 connected
[ 63.305] (II) modeset(0): Using exact sizes for initial modes
[ 63.305] (II) modeset(0): Output VGA-1 using initial mode 1920x1080 +0+0
[ 63.305] (==) modeset(0): Using gamma correction (1.0, 1.0, 1.0)
[ 63.305] (==) modeset(0): DPI set to (96, 96)
[ 63.305] (II) Loading sub module “fb”
[ 63.305] (II) LoadModule: “fb”
[ 63.305] (II) Loading /usr/lib64/xorg/modules/libfb.so
[ 63.306] (II) Module fb: vendor=“X.Org Foundation”
[ 63.306] compiled for 1.19.3, module version = 1.0.0
[ 63.306] ABI class: X.Org ANSI C Emulation, version 0.4
[ 63.306] (II) Loading sub module “shadow”
[ 63.306] (II) LoadModule: “shadow”
[ 63.306] (II) Loading /usr/lib64/xorg/modules/libshadow.so
[ 63.306] (II) Module shadow: vendor=“X.Org Foundation”
[ 63.306] compiled for 1.19.3, module version = 1.1.0
[ 63.306] (II) UnloadModule: “fbdev”
[ 63.306] (II) Unloading fbdev
[ 63.306] (II) UnloadSubModule: “fbdevhw”
[ 63.306] (II) Unloading fbdevhw
[ 63.306] (==) Depth 24 pixmap format is 32 bpp
[ 63.307] (==) modeset(0): Backing store enabled
[ 63.307] (==) modeset(0): Silken mouse enabled
[ 63.307] (II) modeset(0): RandR 1.2 enabled, ignore the following RandR disabled message.
[ 63.307] (==) modeset(0): DPMS enabled
[ 63.307] (–) RandR disabled
[ 63.312] (II) SELinux: Disabled on system
[ 63.312] (EE) Failed to initialize GLX extension (Compatible NVIDIA X driver not found)
[ 63.312] (II) modeset(0): Damage tracking initialized
[ 63.312] (II) modeset(0): Setting screen physical size to 508 x 285
[ 63.342] (II) config/udev: Adding input device Sun USB Keyboard (/dev/input/event1)
[ 63.342] () Sun USB Keyboard: Applying InputClass “evdev keyboard catchall”
[ 63.342] () Sun USB Keyboard: Applying InputClass “system-keyboard”
[ 63.342] (II) LoadModule: “evdev”
[ 63.343] (II) Loading /usr/lib64/xorg/modules/input/evdev_drv.so
[ 63.343] (II) Module evdev: vendor=“X.Org Foundation”
[ 63.343] compiled for 1.19.1, module version = 2.10.5
[ 63.343] Module class: X.Org XInput Driver
[ 63.343] ABI class: X.Org XInput driver, version 24.1
[ 63.343] (II) Using input driver ‘evdev’ for ‘Sun USB Keyboard’
[ 63.343] () Sun USB Keyboard: always reports core events
[ 63.343] () evdev: Sun USB Keyboard: Device: “/dev/input/event1”
[ 63.343] (–) evdev: Sun USB Keyboard: Vendor 0x430 Product 0xa2
[ 63.343] (–) evdev: Sun USB Keyboard: Found keys
[ 63.343] (II) evdev: Sun USB Keyboard: Configuring as keyboard
[ 63.343] () Option “config_info” “udev:/sys/devices/pci0001:00/0001:00:00.0/0001:01:00.0/usb1/1-1/1-1.4/1-1.4:1.0/0003:0430:00A2.0002/input/input1/event1”
[ 63.343] (II) XINPUT: Adding extended input device “Sun USB Keyboard” (type: KEYBOARD, id 6)
[ 63.343] () Option “xkb_rules” “evdev”
[ 63.343] () Option “xkb_layout” “us,kr”
[ 63.343] () Option “xkb_variant” “,”
[ 63.364] (II) config/udev: Adding input device PixArt USB Optical Mouse (/dev/input/event0)
[ 63.364] () PixArt USB Optical Mouse: Applying InputClass “evdev pointer catchall”
[ 63.364] (II) Using input driver ‘evdev’ for ‘PixArt USB Optical Mouse’
[ 63.364] () PixArt USB Optical Mouse: always reports core events
[ 63.364] () evdev: PixArt USB Optical Mouse: Device: “/dev/input/event0”
[ 63.364] (–) evdev: PixArt USB Optical Mouse: Vendor 0x93a Product 0x2510
[ 63.364] (–) evdev: PixArt USB Optical Mouse: Found 3 mouse buttons
[ 63.364] (–) evdev: PixArt USB Optical Mouse: Found scroll wheel(s)
[ 63.364] (–) evdev: PixArt USB Optical Mouse: Found relative axes
[ 63.364] (–) evdev: PixArt USB Optical Mouse: Found x and y relative axes
[ 63.364] (II) evdev: PixArt USB Optical Mouse: Configuring as mouse
[ 63.364] (II) evdev: PixArt USB Optical Mouse: Adding scrollwheel support
[ 63.364] () evdev: PixArt USB Optical Mouse: YAxisMapping: buttons 4 and 5
[ 63.364] () evdev: PixArt USB Optical Mouse: EmulateWheelButton: 4, EmulateWheelInertia: 10, EmulateWheelTimeout: 200
[ 63.364] () Option “config_info” “udev:/sys/devices/pci0001:00/0001:00:00.0/0001:01:00.0/usb1/1-2/1-2:1.0/0003:093A:2510.0001/input/input0/event0”
[ 63.364] (II) XINPUT: Adding extended input device “PixArt USB Optical Mouse” (type: MOUSE, id 7)
[ 63.364] (II) evdev: PixArt USB Optical Mouse: initialized for relative axes.
[ 63.364] () PixArt USB Optical Mouse: (accel) keeping acceleration scheme 1
[ 63.364] () PixArt USB Optical Mouse: (accel) acceleration profile 0
[ 63.364] () PixArt USB Optical Mouse: (accel) acceleration factor: 2.000
[ 63.364] () PixArt USB Optical Mouse: (accel) acceleration threshold: 4
[ 63.365] (II) config/udev: Adding input device PixArt USB Optical Mouse (/dev/input/mouse0)
[ 63.365] (II) No input driver specified, ignoring this device.
[ 63.365] (II) This device may have been added with another device file.
[ 65.078] AUDIT: Sat Feb 10 23:15:22 2018: 7681: client 1 connected from local host ( uid=0 gid=0 pid=7706 )
Auth name: MIT-MAGIC-COOKIE-1 ID: 98
[ 65.078] AUDIT: Sat Feb 10 23:15:22 2018: 7681: client 1 disconnected
[ 65.080] AUDIT: Sat Feb 10 23:15:22 2018: 7681: client 1 connected from local host ( uid=0 gid=0 pid=7718 )
[ 65.080] AUDIT: Sat Feb 10 23:15:22 2018: 7681: client 1 disconnected
[ 65.082] AUDIT: Sat Feb 10 23:15:22 2018: 7681: client 1 connected from local host ( uid=0 gid=0 pid=7673 )
[ 65.181] AUDIT: Sat Feb 10 23:15:22 2018: 7681: client 2 connected from local host ( uid=42 gid=42 pid=7732 )
[ 65.204] AUDIT: Sat Feb 10 23:15:22 2018: 7681: client 3 connected from local host ( uid=42 gid=42 pid=7734 )
[ 65.209] AUDIT: Sat Feb 10 23:15:22 2018: 7681: client 4 connected from local host ( uid=42 gid=42 pid=7734 )
[ 65.210] AUDIT: Sat Feb 10 23:15:22 2018: 7681: client 4 disconnected
[ 65.212] AUDIT: Sat Feb 10 23:15:22 2018: 7681: client 4 connected from local host ( uid=42 gid=42 pid=7736 )
[ 65.212] AUDIT: Sat Feb 10 23:15:22 2018: 7681: client 4 disconnected
[ 65.218] AUDIT: Sat Feb 10 23:15:22 2018: 7681: client 4 connected from local host ( uid=42 gid=42 pid=7736 )
[ 65.218] AUDIT: Sat Feb 10 23:15:22 2018: 7681: client 4 disconnected
[ 65.221] AUDIT: Sat Feb 10 23:15:22 2018: 7681: client 4 connected from local host ( uid=42 gid=42 pid=7743 )
[ 65.221] AUDIT: Sat Feb 10 23:15:22 2018: 7681: client 4 disconnected
[ 65.222] AUDIT: Sat Feb 10 23:15:22 2018: 7681: client 4 connected from local host ( uid=42 gid=42 pid=7743 )
[ 65.222] AUDIT: Sat Feb 10 23:15:22 2018: 7681: client 5 connected from local host ( uid=42 gid=42 pid=7744 )
[ 65.235] AUDIT: Sat Feb 10 23:15:22 2018: 7681: client 5 disconnected
[ 65.245] AUDIT: Sat Feb 10 23:15:22 2018: 7681: client 5 connected from local host ( uid=42 gid=42 pid=7747 )
[ 65.251] AUDIT: Sat Feb 10 23:15:22 2018: 7681: client 6 connected from local host ( uid=42 gid=42 pid=7747 )
[ 65.251] AUDIT: Sat Feb 10 23:15:22 2018: 7681: client 6 disconnected
[ 65.254] AUDIT: Sat Feb 10 23:15:22 2018: 7681: client 5 disconnected
[ 65.255] AUDIT: Sat Feb 10 23:15:22 2018: 7681: client 3 disconnected
[ 65.262] AUDIT: Sat Feb 10 23:15:22 2018: 7681: client 3 connected from local host ( uid=42 gid=42 pid=7748 )
[ 65.267] AUDIT: Sat Feb 10 23:15:22 2018: 7681: client 5 connected from local host ( uid=42 gid=42 pid=7748 )
[ 65.267] AUDIT: Sat Feb 10 23:15:22 2018: 7681: client 5 disconnected
[ 70.273] AUDIT: Sat Feb 10 23:15:27 2018: 7681: client 5 connected from local host ( uid=42 gid=42 pid=7750 )
[ 70.275] AUDIT: Sat Feb 10 23:15:27 2018: 7681: client 5 disconnected
[ 70.283] AUDIT: Sat Feb 10 23:15:27 2018: 7681: client 5 connected from local host ( uid=42 gid=42 pid=7751 )
[ 70.288] AUDIT: Sat Feb 10 23:15:27 2018: 7681: client 6 connected from local host ( uid=42 gid=42 pid=7751 )
[ 70.289] AUDIT: Sat Feb 10 23:15:27 2018: 7681: client 6 disconnected
[ 70.292] AUDIT: Sat Feb 10 23:15:27 2018: 7681: client 5 disconnected
[ 70.292] AUDIT: Sat Feb 10 23:15:27 2018: 7681: client 3 disconnected
[ 70.299] AUDIT: Sat Feb 10 23:15:27 2018: 7681: client 3 connected from local host ( uid=42 gid=42 pid=7752 )
[ 70.304] AUDIT: Sat Feb 10 23:15:27 2018: 7681: client 5 connected from local host ( uid=42 gid=42 pid=7752 )
[ 70.304] AUDIT: Sat Feb 10 23:15:27 2018: 7681: client 5 disconnected
[ 70.424] (II) modeset(0): Disabling kernel dirty updates, not required.
