Hi, I’m using current nvidia drivers (nvidia-346.59) on Kubuntu 15.04, with Cuda 7.0 also installed (yet from Nvidia dev repository).
The system works fine if I use the intel card, but when I use prime-select to switch from intel to nvidia, then after logoff I get a black screen and the system hangs.
I’m thus forced to switch to a virtual console by pressing [Ctrl+Alt+Fn] and then revert to the intel card and restart the sddm service.
Even reboot doesn’t help, as I get yet another black screen.
$ apt-cache policy nvidia-346 nvidia-prime
nvidia-346:
Installed: 346.59-0ubuntu1
Candidate: 346.59-0ubuntu1
Version table:
*** 346.59-0ubuntu1 0
500 http://it.archive.ubuntu.com/ubuntu/ vivid/restricted amd64 Packages
100 /var/lib/dpkg/status
346.46-0ubuntu1 0
500 http://developer.download.nvidia.com/compute/cuda/repos/ubuntu1410/x86_64/ Packages
nvidia-prime:
Installed: 0.8.1
Candidate: 0.8.1
Version table:
*** 0.8.1 0
500 http://it.archive.ubuntu.com/ubuntu/ vivid/main amd64 Packages
$ lspci -v
01:00.0 VGA compatible controller: NVIDIA Corporation GK107GLM [Quadro K1100M] (rev a1) (prog-if 00 [VGA controller])
Subsystem: Dell Device 15cc
Flags: bus master, fast devsel, latency 0, IRQ 16
Memory at f3000000 (32-bit, non-prefetchable)
Memory at d0000000 (64-bit, prefetchable)
Memory at e0000000 (64-bit, prefetchable)
I/O ports at e000
Expansion ROM at f4000000 [disabled]
Capabilities: <access denied>
Kernel driver in use: nvidia
*** /etc/X11/xorg.conf
*** ls: -rw-r--r-- 1 root root 593 2015-07-26 18:17:26.987864801 +0200 /etc/X11/xorg.conf
Section "ServerLayout"
Identifier "layout"
Screen 0 "nvidia"
Inactive "intel"
EndSection
Section "Device"
Identifier "intel"
Driver "intel"
BusID "PCI:0@0:2:0"
Option "AccelMethod" "SNA"
EndSection
Section "Screen"
Identifier "intel"
Device "intel"
EndSection
Section "Device"
Identifier "nvidia"
Driver "nvidia"
BusID "PCI:1@0:0:0"
Option "ConstrainCursor" "off"
EndSection
Section "Screen"
Identifier "nvidia"
Device "nvidia"
Option "AllowEmptyInitialConfiguration" "on"
Option "IgnoreDisplayDevices" "CRT"
EndSection
dmesg extract:
[ 28.210156] nvidia: module license 'NVIDIA' taints kernel.
[ 28.210159] Disabling lock debugging due to kernel taint
[ 28.212155] nvidia: module verification failed: signature and/or required key missing - tainting kernel
[ 28.215216] nvidia 0000:01:00.0: enabling device (0004 -> 0007)
[ 28.215283] vgaarb: device changed decodes: PCI:0000:01:00.0,olddecodes=io+mem,decodes=none:owns=none
[ 28.215597] [drm] Initialized nvidia-drm 0.0.0 20150116 for 0000:01:00.0 on minor 1
[ 28.215602] NVRM: loading NVIDIA UNIX x86_64 Kernel Module 346.59 Tue Mar 31 14:10:31 PDT 2015
*** /var/log/Xorg.0.log
*** ls: -rw-r--r-- 1 root root 31416 2015-07-26 22:55:47.010829709 +0200 /var/log/Xorg.0.log
[ 46.601]
X.Org X Server 1.17.1
Release Date: 2015-02-10
[ 46.601] X Protocol Version 11, Revision 0
[ 46.601] Build Operating System: Linux 3.2.0-61-generic x86_64 Ubuntu
[ 46.601] Current Operating System: Linux Home1 3.19.0-24-generic #25-Ubuntu SMP Wed Jul 22 18:24:45 UTC 2015 x86_64
[ 46.601] Kernel command line: BOOT_IMAGE=/vmlinuz-3.19.0-24-generic.efi.signed root=/dev/mapper/vg-test--root ro acpi_backlight=vendor dell_laptop.backlight=0 pci=nocrs pci=realloc quiet splash vt.
handoff=7
[ 46.601] Build Date: 19 March 2015 09:26:59AM
[ 46.601] xorg-server 2:1.17.1-0ubuntu3 (For technical support please see http://www.ubuntu.com/support)
[ 46.601] Current version of pixman: 0.32.6
[ 46.601] Before reporting problems, check http://wiki.x.org
to make sure that you have the latest version.
[ 46.601] Markers: (--) probed, (**) from config file, (==) default setting,
(++) from command line, (!!) notice, (II) informational,
(WW) warning, (EE) error, (NI) not implemented, (??) unknown.
[ 46.601] (==) Log file: "/var/log/Xorg.0.log", Time: Sun Jul 26 22:52:21 2015
[ 46.628] (==) Using config file: "/etc/X11/xorg.conf"
[ 46.628] (==) Using system config directory "/usr/share/X11/xorg.conf.d"
[ 46.634] (==) ServerLayout "layout"
[ 46.634] (**) |-->Screen "nvidia" (0)
[ 46.634] (**) | |-->Monitor "<default monitor>"
[ 46.634] (**) | |-->Device "nvidia"
[ 46.634] (==) No monitor specified for screen "nvidia".
Using a default monitor configuration.
[ 46.634] (**) |-->Inactive Device "intel"
[ 46.634] (==) Automatically adding devices
[ 46.634] (==) Automatically enabling devices
[ 46.634] (==) Automatically adding GPU devices
[ 46.634] (WW) The directory "/usr/share/fonts/X11/cyrillic" does not exist.
[ 46.634] Entry deleted from font path.
[ 46.634] (WW) The directory "/usr/share/fonts/X11/100dpi/" does not exist.
[ 46.634] (WW) The directory "/usr/share/fonts/X11/75dpi/" does not exist.
[ 46.634] (WW) The directory "/usr/share/fonts/X11/100dpi" does not exist.
[ 46.634] (WW) The directory "/usr/share/fonts/X11/75dpi" does not exist.
[ 46.634] (==) FontPath set to:
/usr/share/fonts/X11/misc,
/usr/share/fonts/X11/Type1,
built-ins
[ 46.634] (==) ModulePath set to "/usr/lib/x86_64-linux-gnu/xorg/extra-modules,/usr/lib/xorg/extra-modules,/usr/lib/xorg/modules"
[ 46.634] (II) The server relies on udev to provide the list of input devices.
If no devices become available, reconfigure udev or disable AutoAddDevices.
[ 46.634] (II) Loader magic: 0x7f1d60b4bd80
[ 46.634] (II) Module ABI versions:
[ 46.634] X.Org ANSI C Emulation: 0.4
[ 46.634] X.Org Video Driver: 19.0
[ 46.634] X.Org XInput driver : 21.0
[ 46.634] X.Org Server Extension : 9.0
[ 46.634] (II) xfree86: Adding drm device (/dev/dri/card1)
[ 46.634] (II) xfree86: Adding drm device (/dev/dri/card0)
[ 46.635] (--) PCI:*(0:0:2:0) 8086:0416:1028:05cc rev 6, Mem @ 0xf5400000/4194304, 0xc0000000/268435456, I/O @ 0x0000f000/64
[ 46.635] (--) PCI: (0:1:0:0) 10de:0ff6:1028:15cc rev 161, Mem @ 0xf3000000/16777216, 0xd0000000/268435456, 0xe0000000/33554432, I/O @ 0x0000e000/128, BIOS @ 0x????????/524288
[ 46.635] (WW) "glamoregl" will not be loaded unless you've specified it to be loaded elsewhere.
[ 46.635] (II) "glx" will be loaded by default.
[ 46.635] (WW) "xmir" is not to be loaded by default. Skipping.
[ 46.635] (II) LoadModule: "glx"
[ 46.650] (II) Loading /usr/lib/x86_64-linux-gnu/xorg/extra-modules/libglx.so
[ 47.368] (II) Module glx: vendor="NVIDIA Corporation"
[ 47.368] compiled for 4.0.2, module version = 1.0.0
[ 47.368] Module class: X.Org Server Extension
[ 47.374] (II) NVIDIA GLX Module 346.59 Tue Mar 31 13:38:58 PDT 2015
[ 47.386] (II) LoadModule: "nvidia"
[ 47.386] (II) Loading /usr/lib/x86_64-linux-gnu/xorg/extra-modules/nvidia_drv.so
[ 47.450] (II) Module nvidia: vendor="NVIDIA Corporation"
[ 47.450] compiled for 4.0.2, module version = 1.0.0
[ 47.450] Module class: X.Org Video Driver
[ 47.460] (II) LoadModule: "intel"
[ 47.460] (II) Loading /usr/lib/xorg/modules/drivers/intel_drv.so
[ 47.469] (II) Module intel: vendor="X.Org Foundation"
[ 47.469] compiled for 1.17.1, module version = 2.99.917
[ 47.469] Module class: X.Org Video Driver
[ 47.469] ABI class: X.Org Video Driver, version 19.0
[ 47.469] (II) NVIDIA dlloader X Driver 346.59 Tue Mar 31 13:17:41 PDT 2015
[ 47.469] (II) NVIDIA Unified Driver for all Supported NVIDIA GPUs
[ 47.470] (II) intel: Driver for Intel(R) Integrated Graphics Chipsets:
i810, i810-dc100, i810e, i815, i830M, 845G, 854, 852GM/855GM, 865G,
915G, E7221 (i915), 915GM, 945G, 945GM, 945GME, Pineview GM,
Pineview G, 965G, G35, 965Q, 946GZ, 965GM, 965GME/GLE, G33, Q35, Q33,
GM45, 4 Series, G45/G43, Q45/Q43, G41, B43
[ 47.471] (II) intel: Driver for Intel(R) HD Graphics: 2000-6000
[ 47.471] (II) intel: Driver for Intel(R) Iris(TM) Graphics: 5100, 6100
[ 47.471] (II) intel: Driver for Intel(R) Iris(TM) Pro Graphics: 5200, 6200, P6300
[ 47.471] (++) using VT number 7
[ 47.479] (II) Loading sub module "fb"
[ 47.479] (II) LoadModule: "fb"
[ 47.479] (II) Loading /usr/lib/xorg/modules/libfb.so
[ 47.489] (II) Module fb: vendor="X.Org Foundation"
[ 47.489] compiled for 1.17.1, module version = 1.0.0
[ 47.489] ABI class: X.Org ANSI C Emulation, version 0.4
[ 47.489] (II) Loading sub module "wfb"
[ 47.489] (II) LoadModule: "wfb"
[ 47.489] (II) Loading /usr/lib/xorg/modules/libwfb.so
[ 47.495] (II) Module wfb: vendor="X.Org Foundation"
[ 47.496] compiled for 1.17.1, module version = 1.0.0
[ 47.496] ABI class: X.Org ANSI C Emulation, version 0.4
[ 47.496] (II) Loading sub module "ramdac"
[ 47.496] (II) LoadModule: "ramdac"
[ 47.496] (II) Module "ramdac" already built-in
[ 47.497] (II) intel(G0): Using Kernel Mode Setting driver: i915, version 1.6.0 20141121
[ 47.497] (II) intel(G0): SNA compiled: xserver-xorg-video-intel 2:2.99.917-1~exp1ubuntu2.2 (Alessio Treglia <quadrispro@ubuntu.com>)
[ 47.497] (II) intel(G0): SNA compiled for use with valgrind
[ 47.497] (II) intel(G1): Using Kernel Mode Setting driver: i915, version 1.6.0 20141121
[ 47.497] (II) intel(G1): SNA compiled: xserver-xorg-video-intel 2:2.99.917-1~exp1ubuntu2.2 (Alessio Treglia <quadrispro@ubuntu.com>)
[ 47.497] (II) intel(G1): SNA compiled for use with valgrind
[ 47.497] (II) NVIDIA(0): Creating default Display subsection in Screen section
"nvidia" for depth/fbbpp 24/32
[ 47.497] (==) NVIDIA(0): Depth 24, (==) framebuffer bpp 32
[ 47.497] (==) NVIDIA(0): RGB weight 888
[ 47.497] (==) NVIDIA(0): Default visual is TrueColor
[ 47.497] (==) NVIDIA(0): Using gamma correction (1.0, 1.0, 1.0)
[ 47.498] (**) NVIDIA(0): Option "ConstrainCursor" "off"
[ 47.498] (**) NVIDIA(0): Option "AllowEmptyInitialConfiguration" "on"
[ 47.498] (**) NVIDIA(0): Option "IgnoreDisplayDevices" "CRT"
[ 47.498] (**) NVIDIA(0): Enabling 2D acceleration
[ 48.232] (II) NVIDIA(GPU-0): Found DRM driver nvidia-drm (20150116)
[ 48.233] (II) NVIDIA(0): NVIDIA GPU Quadro K1100M (GK107GL) at PCI:1:0:0 (GPU-0)
[ 48.233] (--) NVIDIA(0): Memory: 2097152 kBytes
[ 48.233] (--) NVIDIA(0): VideoBIOS: 80.07.ab.00.07
[ 48.233] (II) NVIDIA(0): Detected PCI Express Link width: 16X
[ 48.241] (--) NVIDIA(0): Valid display device(s) on Quadro K1100M at PCI:1:0:0
[ 48.241] (--) NVIDIA(0): DFP-0
[ 48.241] (--) NVIDIA(0): DFP-1
[ 48.241] (--) NVIDIA(0): DFP-2
[ 48.241] (--) NVIDIA(0): DFP-3
[ 48.241] (--) NVIDIA(0): DFP-4
[ 48.241] (--) NVIDIA(0): DFP-5
[ 48.241] (--) NVIDIA(0): DFP-0: Internal TMDS
[ 48.241] (--) NVIDIA(GPU-0): DFP-0: 165.0 MHz maximum pixel clock
[ 48.241] (--) NVIDIA(0): DFP-1: Internal TMDS
[ 48.241] (--) NVIDIA(GPU-0): DFP-1: 165.0 MHz maximum pixel clock
[ 48.241] (--) NVIDIA(0): DFP-2: Internal TMDS
[ 48.241] (--) NVIDIA(GPU-0): DFP-2: 165.0 MHz maximum pixel clock
[ 48.241] (--) NVIDIA(0): DFP-3: Internal DisplayPort
[ 48.241] (--) NVIDIA(GPU-0): DFP-3: 960.0 MHz maximum pixel clock
[ 48.241] (--) NVIDIA(0): DFP-4: Internal DisplayPort
[ 48.241] (--) NVIDIA(GPU-0): DFP-4: 960.0 MHz maximum pixel clock
[ 48.241] (--) NVIDIA(0): DFP-5: Internal DisplayPort
[ 48.241] (--) NVIDIA(GPU-0): DFP-5: 960.0 MHz maximum pixel clock
[ 48.241] (==) NVIDIA(0):
[ 48.241] (==) NVIDIA(0): No modes were requested; the default mode "nvidia-auto-select"
[ 48.241] (==) NVIDIA(0): will be used as the requested mode.
[ 48.241] (--) NVIDIA(0): No enabled display devices found; starting anyway because
[ 48.241] (--) NVIDIA(0): AllowEmptyInitialConfiguration is enabled
[ 48.241] (II) NVIDIA(0): Validated MetaModes:
[ 48.241] (II) NVIDIA(0): "NULL"
[ 48.241] (II) NVIDIA(0): Virtual screen size determined to be 640 x 480
[ 48.244] (WW) NVIDIA(0): Unable to get display device for DPI computation.
[ 48.244] (==) NVIDIA(0): DPI set to (75, 75); computed from built-in default
[ 48.244] (--) intel(G0): Integrated Graphics Chipset: Intel(R) HD Graphics 4600
[ 48.244] (--) intel(G0): CPU: x86-64, sse2, sse3, ssse3, sse4.1, sse4.2, avx, avx2
[ 48.244] (==) intel(G0): Depth 24, (--) framebuffer bpp 32
[ 48.244] (==) intel(G0): RGB weight 888
[ 48.244] (==) intel(G0): Default visual is TrueColor
[ 48.244] (**) intel(G0): Option "AccelMethod" "SNA"
[ 48.244] (II) intel(G0): Output eDP1 has no monitor section
[ 48.245] (--) intel(G0): Found backlight control interface dell_backlight (type 'platform') for output eDP1
[ 48.245] (II) intel(G0): Enabled output eDP1
[ 48.245] (II) intel(G0): Output VGA1 has no monitor section
[ 48.245] (II) intel(G0): Enabled output VGA1
[ 48.245] (II) intel(G0): Output DP1 has no monitor section
[ 48.245] (II) intel(G0): Enabled output DP1
[ 48.245] (II) intel(G0): Output HDMI1 has no monitor section
[ 48.245] (II) intel(G0): Enabled output HDMI1
[ 48.245] (--) intel(G0): Using a maximum size of 256x256 for hardware cursors
[ 48.245] (II) intel(G0): Output VIRTUAL1 has no monitor section
[ 48.245] (II) intel(G0): Enabled output VIRTUAL1
[ 48.247] (==) intel(G0): TearFree disabled
[ 48.247] (==) intel(G0): DPI set to (96, 96)
[ 48.247] (II) Loading sub module "dri2"
[ 48.247] (II) LoadModule: "dri2"
[ 48.247] (II) Module "dri2" already built-in
[ 48.247] (II) Loading sub module "present"
[ 48.247] (II) LoadModule: "present"
[ 48.247] (II) Module "present" already built-in
[ 50.490] (EE) intel(G1): [drm] failed to set drm interface version: Permission denied [13].
[ 50.490] (II) intel(G1): [drm] Contents of '/sys/kernel/debug/dri/0/clients':
[ 50.490] (II) intel(G1): [drm] command pid dev master a uid magic
[ 50.490] (II) intel(G1): [drm] Xorg 1119 0 y y 0 0
[ 50.490] (II) intel(G1): [drm] Xorg 1119 0 n y 0 0
[ 50.490] (EE) intel(G1): Failed to claim DRM device.
[ 50.490] (II) UnloadModule: "intel"
[ 50.490] (--) Depth 24 pixmap format is 32 bpp
[ 50.490] (II) intel(G0): SNA initialized with Haswell (gen7.5, gt2) backend
[ 50.490] (==) intel(G0): Backing store enabled
[ 50.490] (==) intel(G0): Silken mouse enabled
[ 50.490] (II) intel(G0): HW Cursor enabled
[ 50.490] (II) intel(G0): RandR 1.2 enabled, ignore the following RandR disabled message.
[ 50.490] (==) intel(G0): DPMS enabled
[ 50.490] (==) intel(G0): display hotplug detection enabled
[ 50.490] (II) intel(G0): [DRI2] Setup complete
[ 50.490] (II) intel(G0): [DRI2] DRI driver: i965
[ 50.490] (II) intel(G0): [DRI2] VDPAU driver: i965
[ 50.490] (II) intel(G0): direct rendering: DRI2 enabled
[ 50.490] (II) intel(G0): hardware support for Present enabled
[ 50.490] (WW) intel(G0): Option "AllowEmptyInitialConfiguration" is not used
[ 50.490] (WW) intel(G0): Option "IgnoreDisplayDevices" is not used
[ 50.490] (II) NVIDIA: Using 3072.00 MB of virtual memory for indirect memory
[ 50.490] (II) NVIDIA: access.
[ 50.501] (II) NVIDIA(0): Setting mode "NULL"
[ 50.548] (II) NVIDIA(0): Built-in logo is bigger than the screen.
[ 50.556] (==) NVIDIA(0): Disabling shared memory pixmaps
[ 50.556] (==) NVIDIA(0): Backing store enabled
[ 50.556] (==) NVIDIA(0): Silken mouse enabled
[ 50.557] (==) NVIDIA(0): DPMS enabled
[ 50.563] (II) Loading sub module "dri2"
[ 50.563] (II) LoadModule: "dri2"
[ 50.563] (II) Module "dri2" already built-in
[ 50.563] (II) NVIDIA(0): [DRI2] Setup complete
[ 50.563] (II) NVIDIA(0): [DRI2] VDPAU driver: nvidia
[ 50.563] (--) RandR disabled
[ 50.567] (II) SELinux: Disabled on system
[ 50.567] (II) Initializing extension GLX
[ 50.567] (II) Indirect GLX disabled.(II) XKB: reuse xkmfile /var/lib/xkb/server-B20D7FC79C7F597315E3E501AEF10E0D866E8E92.xkm
[ 52.755] (II) config/udev: Adding input device Power Button (/dev/input/event3)
[ 52.755] (**) Power Button: Applying InputClass "evdev keyboard catchall"
[ 52.755] (II) LoadModule: "evdev"
[ 52.755] (II) Loading /usr/lib/xorg/modules/input/evdev_drv.so
[ 52.779] (II) Module evdev: vendor="X.Org Foundation"
[ 52.779] compiled for 1.16.0, module version = 2.9.0
[ 52.779] Module class: X.Org XInput Driver
[ 52.779] ABI class: X.Org XInput driver, version 21.0
[ 52.779] (II) Using input driver 'evdev' for 'Power Button'
[ 52.779] (**) Power Button: always reports core events
[ 52.779] (**) evdev: Power Button: Device: "/dev/input/event3"
[ 52.779] (--) evdev: Power Button: Vendor 0 Product 0x1
[ 52.779] (--) evdev: Power Button: Found keys
[ 52.779] (II) evdev: Power Button: Configuring as keyboard
[ 52.779] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXPWRBN:00/input/input3/event3"
[ 52.779] (II) XINPUT: Adding extended input device "Power Button" (type: KEYBOARD, id 6)
[ 52.779] (**) Option "xkb_rules" "evdev"
[ 52.779] (**) Option "xkb_model" "pc105"
[ 52.779] (**) Option "xkb_layout" "it"
[ 52.781] (II) XKB: reuse xkmfile /var/lib/xkb/server-3781FECB9CB8D26EE03343DB2C93394EA704B98F.xkm
[ 52.781] (II) config/udev: Adding input device Video Bus (/dev/input/event6)
[ 52.781] (**) Video Bus: Applying InputClass "evdev keyboard catchall"
[ 52.781] (II) Using input driver 'evdev' for 'Video Bus'
[ 52.781] (**) Video Bus: always reports core events
[ 52.781] (**) evdev: Video Bus: Device: "/dev/input/event6"
[ 52.781] (--) evdev: Video Bus: Vendor 0 Product 0x6
[ 52.781] (--) evdev: Video Bus: Found keys
[ 52.781] (II) evdev: Video Bus: Configuring as keyboard
[ 52.781] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/LNXVIDEO:01/input/input8/event6"
[ 52.781] (II) XINPUT: Adding extended input device "Video Bus" (type: KEYBOARD, id 7)
[ 52.781] (**) Option "xkb_rules" "evdev"
[ 52.781] (**) Option "xkb_model" "pc105"
[ 52.781] (**) Option "xkb_layout" "it"
[ 52.781] (II) config/udev: Adding input device Video Bus (/dev/input/event5)
[ 52.781] (**) evdev: Video Bus: Device: "/dev/input/event5"
[ 52.781] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/device:50/LNXVIDEO:00/input/input7/event5"
[ 52.781] (II) XINPUT: Adding extended input device "Video Bus" (type: KEYBOARD, id 8)
[ 52.782] (II) config/udev: Adding input device Power Button (/dev/input/event1)
[ 52.782] (**) Power Button: Applying InputClass "evdev keyboard catchall"
[ 52.782] (II) Using input driver 'evdev' for 'Power Button'
[ 52.782] (**) Power Button: always reports core events
[ 52.782] (**) evdev: Power Button: Device: "/dev/input/event1"
[ 52.782] (--) evdev: Power Button: Vendor 0 Product 0x1
[ 52.782] (--) evdev: Power Button: Found keys
[ 52.782] (II) evdev: Power Button: Configuring as keyboard
[ 52.782] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0C:00/input/input1/event1"
[ 52.782] (II) XINPUT: Adding extended input device "Power Button" (type: KEYBOARD, id 9)
[ 52.782] (**) Option "xkb_rules" "evdev"
[ 52.782] (**) Option "xkb_model" "pc105"
[ 52.782] (**) Option "xkb_layout" "it"
[ 52.782] (II) config/udev: Adding input device Lid Switch (/dev/input/event0)
[ 52.782] (II) No input driver specified, ignoring this device.
[ 52.782] (II) This device may have been added with another device file.
[ 52.782] (II) config/udev: Adding input device Sleep Button (/dev/input/event2)
[ 52.782] (**) Sleep Button: Applying InputClass "evdev keyboard catchall"
[ 52.782] (II) Using input driver 'evdev' for 'Sleep Button'
[ 52.782] (**) Sleep Button: always reports core events
[ 52.782] (**) evdev: Sleep Button: Device: "/dev/input/event2"
[ 52.782] (--) evdev: Sleep Button: Vendor 0 Product 0x3
[ 52.782] (--) evdev: Sleep Button: Found keys
[ 52.782] (II) evdev: Sleep Button: Configuring as keyboard
[ 52.782] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0E:00/input/input2/event2"
[ 52.782] (II) XINPUT: Adding extended input device "Sleep Button" (type: KEYBOARD, id 10)
[ 52.782] (II) config/udev: Adding input device HDA Intel HDMI HDMI/DP,pcm=3 (/dev/input/event16)
[ 52.783] (II) config/udev: Adding input device HDA Intel HDMI HDMI/DP,pcm=7 (/dev/input/event17)
[ 52.783] (II) No input driver specified, ignoring this device.
[ 52.783] (II) This device may have been added with another device file.
[ 52.783] (II) config/udev: Adding input device HDA Intel HDMI HDMI/DP,pcm=8 (/dev/input/event18)
[ 52.783] (II) config/udev: Adding input device Logitech M325 (/dev/input/event9)
[ 52.783] (**) Logitech M325: Applying InputClass "evdev pointer catchall"
[ 52.783] (II) Using input driver 'evdev' for 'Logitech M325'
[ 52.783] (**) Logitech M325: always reports core events
[ 52.783] (**) evdev: Logitech M325: Device: "/dev/input/event9"
[ 52.783] (--) evdev: Logitech M325: Vendor 0x46d Product 0x400a
[ 52.783] (--) evdev: Logitech M325: Found 20 mouse buttons
[ 52.783] (--) evdev: Logitech M325: Found scroll wheel(s)
[ 52.783] (--) evdev: Logitech M325: Found relative axes
[ 52.783] (--) evdev: Logitech M325: Found x and y relative axes
[ 52.783] (II) evdev: Logitech M325: Configuring as mouse
[ 52.783] (II) evdev: Logitech M325: Adding scrollwheel support
[ 52.783] (**) evdev: Logitech M325: YAxisMapping: buttons 4 and 5
[ 52.783] (**) evdev: Logitech M325: EmulateWheelButton: 4, EmulateWheelInertia: 10, EmulateWheelTimeout: 200
[ 52.783] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:14.0/usb1/1-2/1-2:1.2/0003:046D:C52B.0003/0003:046D:400A.0004/input/input10/event9"
[ 52.783] (II) XINPUT: Adding extended input device "Logitech M325" (type: MOUSE, id 11)
[ 52.783] (II) evdev: Logitech M325: initialized for relative axes.
[ 52.783] (**) Logitech M325: (accel) keeping acceleration scheme 1
[ 52.783] (**) Logitech M325: (accel) acceleration profile 0
[ 52.783] (**) Logitech M325: (accel) acceleration factor: 2.000
[ 52.783] (**) Logitech M325: (accel) acceleration threshold: 4
[ 52.783] (II) config/udev: Adding input device Logitech M325 (/dev/input/mouse2)
[ 52.783] (II) config/udev: Adding input device Laptop_Integrated_Webcam_HD (/dev/input/event10)
[ 52.783] (**) Laptop_Integrated_Webcam_HD: Applying InputClass "evdev keyboard catchall"
[ 52.783] (II) Using input driver 'evdev' for 'Laptop_Integrated_Webcam_HD'
[ 52.783] (**) Laptop_Integrated_Webcam_HD: always reports core events
[ 52.783] (**) evdev: Laptop_Integrated_Webcam_HD: Device: "/dev/input/event10"
[ 52.783] (--) evdev: Laptop_Integrated_Webcam_HD: Vendor 0xc45 Product 0x649d
[ 52.783] (--) evdev: Laptop_Integrated_Webcam_HD: Found keys
[ 52.783] (II) evdev: Laptop_Integrated_Webcam_HD: Configuring as keyboard
[ 52.783] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:1a.0/usb3/3-1/3-1.5/3-1.5:1.0/input/input11/event10"
[ 52.783] (II) XINPUT: Adding extended input device "Laptop_Integrated_Webcam_HD" (type: KEYBOARD, id 12)
[ 52.783] (**) Option "xkb_rules" "evdev"
[ 52.783] (**) Option "xkb_model" "pc105"
[ 52.783] (**) Option "xkb_layout" "it"
[ 52.783] (II) config/udev: Adding input device HDA Intel PCH Front Mic (/dev/input/event12)
[ 52.784] (II) config/udev: Adding input device HDA Intel PCH Dock Mic (/dev/input/event13)
[ 52.784] (II) No input driver specified, ignoring this device.
[ 52.784] (II) This device may have been added with another device file.
[ 52.784] (II) config/udev: Adding input device HDA Intel PCH Dock Line Out (/dev/input/event14)
[ 52.784] (II) config/udev: Adding input device HDA Intel PCH Front Headphone (/dev/input/event15)
[ 52.784] (II) config/udev: Adding input device AT Translated Set 2 keyboard (/dev/input/event4)
[ 52.784] (**) AT Translated Set 2 keyboard: Applying InputClass "evdev keyboard catchall"
[ 52.784] (II) Using input driver 'evdev' for 'AT Translated Set 2 keyboard'
[ 52.784] (**) AT Translated Set 2 keyboard: always reports core events
[ 52.784] (**) evdev: AT Translated Set 2 keyboard: Device: "/dev/input/event4"
[ 52.784] (--) evdev: AT Translated Set 2 keyboard: Vendor 0x1 Product 0x1
[ 52.784] (--) evdev: AT Translated Set 2 keyboard: Found keys
[ 52.784] (II) evdev: AT Translated Set 2 keyboard: Configuring as keyboard
[ 52.784] (**) Option "config_info" "udev:/sys/devices/platform/i8042/serio0/input/input4/event4"
[ 52.784] (II) XINPUT: Adding extended input device "AT Translated Set 2 keyboard" (type: KEYBOARD, id 13)
[ 52.784] (**) Option "xkb_rules" "evdev"
[ 52.784] (**) Option "xkb_model" "pc105"
[ 52.784] (**) Option "xkb_layout" "it"
[ 52.784] (II) config/udev: Adding input device AlpsPS/2 ALPS GlidePoint (/dev/input/event8)
[ 52.784] (**) AlpsPS/2 ALPS GlidePoint: Applying InputClass "evdev touchpad catchall"
[ 52.784] (**) AlpsPS/2 ALPS GlidePoint: Applying InputClass "touchpad catchall"
[ 52.784] (**) AlpsPS/2 ALPS GlidePoint: Applying InputClass "Default clickpad buttons"
[ 52.784] (II) LoadModule: "synaptics"
[ 52.784] (II) Loading /usr/lib/xorg/modules/input/synaptics_drv.so
[ 52.784] (II) Module synaptics: vendor="X.Org Foundation"
[ 52.784] compiled for 1.16.0, module version = 1.8.99
[ 52.784] Module class: X.Org XInput Driver
[ 52.784] ABI class: X.Org XInput driver, version 21.0
[ 52.784] (II) Using input driver 'synaptics' for 'AlpsPS/2 ALPS GlidePoint'
[ 52.784] (**) AlpsPS/2 ALPS GlidePoint: always reports core events
[ 52.784] (**) Option "Device" "/dev/input/event8"
[ 52.804] (II) synaptics: AlpsPS/2 ALPS GlidePoint: ignoring touch events for semi-multitouch device
[ 52.804] (--) synaptics: AlpsPS/2 ALPS GlidePoint: x-axis range 0 - 2000 (res 25)
[ 52.804] (--) synaptics: AlpsPS/2 ALPS GlidePoint: y-axis range 0 - 1400 (res 32)
[ 52.804] (--) synaptics: AlpsPS/2 ALPS GlidePoint: pressure range 0 - 127
[ 52.804] (II) synaptics: AlpsPS/2 ALPS GlidePoint: device does not report finger width.
[ 52.804] (--) synaptics: AlpsPS/2 ALPS GlidePoint: buttons: left right middle double triple
[ 52.804] (--) synaptics: AlpsPS/2 ALPS GlidePoint: Vendor 0x2 Product 0x8
[ 52.804] (--) synaptics: AlpsPS/2 ALPS GlidePoint: invalid finger width range. defaulting to 0 - 15
[ 52.804] (--) synaptics: AlpsPS/2 ALPS GlidePoint: touchpad found
[ 52.804] (**) AlpsPS/2 ALPS GlidePoint: always reports core events
[ 52.820] (**) Option "config_info" "udev:/sys/devices/platform/i8042/serio1/input/input6/event8"
[ 52.820] (II) XINPUT: Adding extended input device "AlpsPS/2 ALPS GlidePoint" (type: TOUCHPAD, id 14)
[ 52.820] (**) synaptics: AlpsPS/2 ALPS GlidePoint: (accel) MinSpeed is now constant deceleration 2.5
[ 52.820] (**) synaptics: AlpsPS/2 ALPS GlidePoint: (accel) MaxSpeed is now 1.75
[ 52.820] (**) synaptics: AlpsPS/2 ALPS GlidePoint: (accel) AccelFactor is now 0.082
[ 52.820] (**) AlpsPS/2 ALPS GlidePoint: (accel) keeping acceleration scheme 1
[ 52.820] (**) AlpsPS/2 ALPS GlidePoint: (accel) acceleration profile 1
[ 52.820] (**) AlpsPS/2 ALPS GlidePoint: (accel) acceleration factor: 2.000
[ 52.820] (**) AlpsPS/2 ALPS GlidePoint: (accel) acceleration threshold: 4
[ 52.820] (--) synaptics: AlpsPS/2 ALPS GlidePoint: touchpad found
[ 52.820] (II) config/udev: Adding input device AlpsPS/2 ALPS GlidePoint (/dev/input/mouse1)
[ 52.820] (**) AlpsPS/2 ALPS GlidePoint: Ignoring device from InputClass "touchpad ignore duplicates"
[ 52.820] (II) config/udev: Adding input device DualPoint Stick (/dev/input/event7)
[ 52.820] (**) DualPoint Stick: Applying InputClass "evdev pointer catchall"
[ 52.820] (**) DualPoint Stick: Applying InputClass "trackpoint catchall"
[ 52.820] (II) Using input driver 'evdev' for 'DualPoint Stick'
[ 52.820] (**) DualPoint Stick: always reports core events
[ 52.820] (**) evdev: DualPoint Stick: Device: "/dev/input/event7"
[ 52.820] (--) evdev: DualPoint Stick: Vendor 0x2 Product 0x8
[ 52.820] (--) evdev: DualPoint Stick: Found 3 mouse buttons
[ 52.820] (--) evdev: DualPoint Stick: Found relative axes
[ 52.820] (--) evdev: DualPoint Stick: Found x and y relative axes
[ 52.820] (II) evdev: DualPoint Stick: Configuring as mouse
[ 52.820] (**) Option "Emulate3Buttons" "true"
[ 52.820] (**) Option "EmulateWheel" "true"
[ 52.820] (**) Option "EmulateWheelButton" "2"
[ 52.820] (**) Option "YAxisMapping" "4 5"
[ 52.820] (**) evdev: DualPoint Stick: YAxisMapping: buttons 4 and 5
[ 52.820] (**) Option "XAxisMapping" "6 7"
[ 52.820] (**) evdev: DualPoint Stick: XAxisMapping: buttons 6 and 7
[ 52.820] (**) evdev: DualPoint Stick: EmulateWheelButton: 2, EmulateWheelInertia: 10, EmulateWheelTimeout: 200
[ 52.820] (**) Option "config_info" "udev:/sys/devices/platform/i8042/serio1/input/input9/event7"
[ 52.820] (II) XINPUT: Adding extended input device "DualPoint Stick" (type: MOUSE, id 15)
[ 52.821] (II) evdev: DualPoint Stick: initialized for relative axes.
[ 52.821] (**) DualPoint Stick: (accel) keeping acceleration scheme 1
[ 52.821] (**) DualPoint Stick: (accel) acceleration profile 0
[ 52.821] (**) DualPoint Stick: (accel) acceleration factor: 2.000
[ 52.821] (**) DualPoint Stick: (accel) acceleration threshold: 4
[ 52.821] (II) config/udev: Adding input device DualPoint Stick (/dev/input/mouse0)
[ 52.821] (II) No input driver specified, ignoring this device.
[ 52.821] (II) This device may have been added with another device file.
[ 52.821] (II) config/udev: Adding input device Dell WMI hotkeys (/dev/input/event11)
[ 52.821] (**) Dell WMI hotkeys: Applying InputClass "evdev keyboard catchall"
[ 52.821] (II) Using input driver 'evdev' for 'Dell WMI hotkeys'
[ 52.821] (**) Dell WMI hotkeys: always reports core events
[ 52.821] (**) evdev: Dell WMI hotkeys: Device: "/dev/input/event11"
[ 52.821] (--) evdev: Dell WMI hotkeys: Vendor 0 Product 0
[ 52.822] (--) evdev: Dell WMI hotkeys: Found keys
[ 52.822] (II) evdev: Dell WMI hotkeys: Configuring as keyboard
[ 52.822] (**) Option "config_info" "udev:/sys/devices/virtual/input/input12/event11"
[ 52.822] (II) XINPUT: Adding extended input device "Dell WMI hotkeys" (type: KEYBOARD, id 16)
[ 52.822] (**) Option "xkb_rules" "evdev"
[ 52.822] (**) Option "xkb_model" "pc105"
[ 52.822] (**) Option "xkb_layout" "it"
[ 53.293] (II) intel(G0): EDID vendor "AUO", prod id 8685
[ 53.293] (II) intel(G0): Printing DDC gathered Modelines:
[ 53.293] (II) intel(G0): Modeline "1920x1080"x0.0 140.00 1920 1968 2068 2082 1080 1090 1100 1120 +hsync -vsync (67.2 kHz eP)
[ 53.293] (II) intel(G0): Modeline "1920x1080"x0.0 140.00 1920 1968 2068 2520 1080 1090 1100 1388 +hsync -vsync (55.6 kHz e)
[ 53.294] reporting 8 11 17 141
[ 53.344] have a master to look out for
[ 53.344] adjust shatters 0 1920
[ 53.347] need to create shared pixmap 1(II) intel(G0): switch to mode 1920x1080@60.0 on eDP1 using pipe 0, position (0, 0), rotation normal, reflection none
[ 53.602] reporting 8 11 17 141
[ 53.607] reporting 8 11 17 141
[ 53.608] have a master to look out for
[ 53.610] need to create shared pixmap 1reporting 8 11 17 141
[ 54.706] reporting 8 11 17 141
[ 54.753] have a master to look out for
[ 54.753] adjust shatters 0 1920
[ 54.755] need to create shared pixmap 1(II) intel(G0): switch to mode 1920x1080@60.0 on eDP1 using pipe 0, position (0, 0), rotation normal, reflection none
[ 80.353] (II) NVIDIA(0): Setting mode "NULL"
[ 80.382] (II) intel(G0): switch to mode 1920x1080@60.0 on eDP1 using pipe 0, position (0, 0), rotation normal, reflection none
[ 80.412] (--) synaptics: AlpsPS/2 ALPS GlidePoint: touchpad found
[ 90.944] (II) NVIDIA(0): Setting mode "NULL"
[ 90.969] (II) intel(G0): switch to mode 1920x1080@60.0 on eDP1 using pipe 0, position (0, 0), rotation normal, reflection none
[ 90.989] (--) synaptics: AlpsPS/2 ALPS GlidePoint: touchpad found
[ 252.354] (II) NVIDIA(0): Setting mode "NULL"
[ 252.411] (II) intel(G0): switch to mode 1920x1080@60.0 on eDP1 using pipe 0, position (0, 0), rotation normal, reflection none
[ 252.439] (--) synaptics: AlpsPS/2 ALPS GlidePoint: touchpad found
