"On no! Something went wrong" error with 367.27 driver on Quadro K620 running SLES 12
I have installed the above drivers (adding the SLES repo ftp://download.nvidia.com/novell/sle12/) on my SLES 12 box.
I have attached the output of nvidia-debug.
I am using nxserver to login remotely but get the below error message when I try connect with a virtual desktop (I can connect to a phyical desktop no problem).
“Oh no! Something has gone wrong.” and “A problem has occurred and the system can’t recover. Please log out and try again.”
I generated the xorg.conf using nvidia-xconfig and this seems to work fine for physical.
I see a XEVIE issue in /var/log/messages. See below. Other than this I can see no issue.
Excerpt from /var/log/messages
2016-07-14T10:00:06.374754-07:00 linux-sr8i systemd[1]: Starting Session c4 of user jmcglone.
2016-07-14T10:00:06.375187-07:00 linux-sr8i systemd-logind[4546]: New session c4 of user jmcglone.
2016-07-14T10:00:06.375498-07:00 linux-sr8i systemd[1]: Started Session c4 of user jmcglone.
2016-07-14T10:00:06.382888-07:00 linux-sr8i nxexec: pam_unix(nx:session): session closed for user jmcglone
2016-07-14T10:00:07.209141-07:00 linux-sr8i rtkit-daemon[5363]: Supervising 0 threads of 0 processes of 0 users.
2016-07-14T10:00:07.211849-07:00 linux-sr8i rtkit-daemon[5363]: Supervising 0 threads of 0 processes of 1 users.
2016-07-14T10:00:07.224503-07:00 linux-sr8i rtkit-daemon[5363]: message repeated 4 times: [ Supervising 0 threads of 0 processes of 1 users.]
2016-07-14T10:00:07.306037-07:00 linux-sr8i org.a11y.Bus[13700]: Activating service name=‘org.a11y.atspi.Registry’
2016-07-14T10:00:07.308838-07:00 linux-sr8i org.a11y.Bus[13700]: Successfully activated service ‘org.a11y.atspi.Registry’
2016-07-14T10:00:07.309017-07:00 linux-sr8i org.a11y.atspi.Registry[13825]: SpiRegistry daemon is running with well-known name - org.a11y.atspi.Registry
2016-07-14T10:00:07.309324-07:00 linux-sr8i org.a11y.atspi.Registry[13825]: Xlib: extension “XEVIE” missing on display “:1002”.
2016-07-14T10:00:12.438985-07:00 linux-sr8i systemd[1]: Mounting FUSE Control File System…
2016-07-14T10:00:12.440029-07:00 linux-sr8i kernel: [ 571.927557] fuse init (API version 7.22)
2016-07-14T10:00:12.443481-07:00 linux-sr8i systemd[1]: Mounted FUSE Control File System.
2016-07-14T10:00:12.851401-07:00 linux-sr8i sshd[16333]: Accepted publickey for nx from 127.0.0.1 port 60477 ssh2: RSA 39:42:a2:98:7b:7c:1d:49:91:cb:2e:79:29:94:2a:eb [MD5]
2016-07-14T10:00:12.852358-07:00 linux-sr8i sshd[16333]: pam_unix(sshd:session): session opened for user nx by (uid=0)
2016-07-14T10:00:12.853895-07:00 linux-sr8i systemd[1]: Starting user-486.slice.
2016-07-14T10:00:12.854170-07:00 linux-sr8i systemd[1]: Created slice user-486.slice.
2016-07-14T10:00:12.855583-07:00 linux-sr8i systemd[1]: Starting User Manager for UID 486…
2016-07-14T10:00:12.857768-07:00 linux-sr8i systemd[1]: Starting Session 4 of user nx.
2016-07-14T10:00:12.858058-07:00 linux-sr8i systemd-logind[4546]: New session 4 of user nx.
2016-07-14T10:00:12.858271-07:00 linux-sr8i systemd[1]: Started Session 4 of user nx.
2016-07-14T10:00:12.858486-07:00 linux-sr8i systemd: pam_unix(systemd-user:session): session opened for user nx by (uid=0)
nvidia-bug-report.log (906 KB)
Start of NVIDIA bug report log file. Please include this file, along
with a detailed description of your problem, when reporting a graphics
driver bug via the NVIDIA Linux forum (see devtalk.nvidia.com)
or by sending email to ‘linux-bugs@nvidia.com’.
nvidia-bug-report.sh Version: 20301301
Date: Mon Jul 18 02:07:29 PDT 2016
uname: Linux linux-sr8i 3.12.60-52.54-default #1 SMP Sat Jun 25 06:22:00 UTC 2016 (e55cce6) x86_64 x86_64 x86_64 GNU/Linux
command line flags:
*** /etc/issue
*** ls: -rw-r–r-- 1 root root 74 2014-10-14 01:52:43.000000000 -0700 /etc/issue
Welcome to SUSE Linux Enterprise Server 12 (x86_64) - Kernel \r (\l).
*** /var/log/nvidia-installer.log does not exist
*** /var/log/Xorg.0.log
*** ls: -rw-r–r-- 1 root root 22035 2016-07-14 09:59:39.776129294 -0700 /var/log/Xorg.0.log
[ 37.326]
X.Org X Server 1.15.2
Release Date: 2014-06-27
[ 37.326] X Protocol Version 11, Revision 0
[ 37.326] Build Operating System: openSUSE SUSE LINUX
[ 37.326] Current Operating System: Linux linux-sr8i 3.12.60-52.54-default #1 SMP Sat Jun 25 06:22:00 UTC 2016 (e55cce6) x86_64
[ 37.326] Kernel command line: BOOT_IMAGE=/boot/vmlinuz-3.12.60-52.54-default root=UUID=8ee93df3-1313-4fee-8989-4164da0ebf15 resume=/dev/disk/by-uuid/f45d8404-92ab-4a80-8878-7d8230dc196a splash=silent quiet crashkernel=232M-:116M showopts
[ 37.326] Build Date: 19 February 2016 02:44:39PM
[ 37.326]
[ 37.326] Current version of pixman: 0.32.6
[ 37.327] Before reporting problems, check http://wiki.x.org
to make sure that you have the latest version.
[ 37.327] Markers: (–) probed, () from config file, (==) default setting,
(++) from command line, (!!) notice, (II) informational,
(WW) warning, (EE) error, (NI) not implemented, (??) unknown.
[ 37.327] (==) Log file: “/var/log/Xorg.0.log”, Time: Thu Jul 14 09:51:18 2016
[ 37.327] (==) Using config file: “/etc/X11/xorg.conf”
[ 37.327] (==) Using config directory: “/etc/X11/xorg.conf.d”
[ 37.327] (==) Using system config directory “/usr/share/X11/xorg.conf.d”
[ 37.327] (==) ServerLayout “Layout0”
[ 37.327] (
) |–>Screen “Screen0” (0)
[ 37.327] () | |–>Monitor “Monitor0”
[ 37.328] (
) | |–>Device “Device0”
[ 37.328] () |–>Input Device “Keyboard0”
[ 37.328] (
) |–>Input Device “Mouse0”
[ 37.328] (==) Automatically adding devices
[ 37.328] (==) Automatically enabling devices
[ 37.328] (==) Automatically adding GPU devices
[ 37.328] (WW) The directory “/usr/share/fonts/misc/sgi” does not exist.
[ 37.328] Entry deleted from font path.
[ 37.328] (==) FontPath set to:
/usr/share/fonts/misc:unscaled,
/usr/share/fonts/Type1/,
/usr/share/fonts/100dpi:unscaled,
/usr/share/fonts/75dpi:unscaled,
/usr/share/fonts/ghostscript/,
/usr/share/fonts/cyrillic:unscaled,
/usr/share/fonts/truetype/,
built-ins
[ 37.328] (==) ModulePath set to “/usr/lib64/xorg/modules”
[ 37.328] (WW) Hotplugging is on, devices using drivers ‘kbd’, ‘mouse’ or ‘vmmouse’ will be disabled.
[ 37.328] (WW) Disabling Keyboard0
[ 37.328] (WW) Disabling Mouse0
[ 37.328] (II) Loader magic: 0x602b60
[ 37.328] (II) Module ABI versions:
[ 37.328] X.Org ANSI C Emulation: 0.4
[ 37.328] X.Org Video Driver: 15.0
[ 37.328] X.Org XInput driver : 20.0
[ 37.328] X.Org Server Extension : 8.0
[ 37.334] (–) PCI:*(0:3:0:0) 10de:13bb:10de:1098 rev 162, Mem @ 0xd2000000/16777216, 0xc0000000/268435456, 0xd0000000/33554432, I/O @ 0x00006000/128, BIOS @ 0x???/524288
[ 37.334] Initializing built-in extension Generic Event Extension
[ 37.334] Initializing built-in extension SHAPE
[ 37.334] Initializing built-in extension MIT-SHM
[ 37.334] Initializing built-in extension XInputExtension
[ 37.334] Initializing built-in extension XTEST
[ 37.334] Initializing built-in extension BIG-REQUESTS
[ 37.334] Initializing built-in extension SYNC
[ 37.334] Initializing built-in extension XKEYBOARD
[ 37.334] Initializing built-in extension XC-MISC
[ 37.334] Initializing built-in extension SECURITY
[ 37.334] Initializing built-in extension XINERAMA
[ 37.334] Initializing built-in extension XFIXES
[ 37.334] Initializing built-in extension RENDER
[ 37.334] Initializing built-in extension RANDR
[ 37.334] Initializing built-in extension COMPOSITE
[ 37.334] Initializing built-in extension DAMAGE
[ 37.334] Initializing built-in extension MIT-SCREEN-SAVER
[ 37.334] Initializing built-in extension DOUBLE-BUFFER
[ 37.334] Initializing built-in extension RECORD
[ 37.334] Initializing built-in extension DPMS
[ 37.334] Initializing built-in extension Present
[ 37.334] Initializing built-in extension DRI3
[ 37.334] Initializing built-in extension X-Resource
[ 37.334] Initializing built-in extension XVideo
[ 37.334] Initializing built-in extension XVideo-MotionCompensation
[ 37.334] Initializing built-in extension XFree86-VidModeExtension
[ 37.334] Initializing built-in extension XFree86-DGA
[ 37.334] Initializing built-in extension DRI2
[ 37.334] (II) LoadModule: “glx”
[ 37.335] (II) Loading /usr/lib64/xorg/modules/extensions/libglx.so
[ 37.407] (II) Module glx: vendor=“NVIDIA Corporation”
[ 37.407] compiled for 4.0.2, module version = 1.0.0
[ 37.407] Module class: X.Org Server Extension
[ 37.407] (II) NVIDIA GLX Module 367.27 Thu Jun 9 18:19:55 PDT 2016
[ 37.407] Loading extension GLX
[ 37.407] (II) LoadModule: “nvidia”
[ 37.407] (II) Loading /usr/lib64/xorg/modules/drivers/nvidia_drv.so
[ 37.413] (II) Module nvidia: vendor=“NVIDIA Corporation”
[ 37.413] compiled for 4.0.2, module version = 1.0.0
[ 37.413] Module class: X.Org Video Driver
[ 37.413] (II) NVIDIA dlloader X Driver 367.27 Thu Jun 9 17:57:30 PDT 2016
[ 37.413] (II) NVIDIA Unified Driver for all Supported NVIDIA GPUs
[ 37.413] (++) using VT number 7
[ 37.413] (II) Loading sub module “fb”
[ 37.413] (II) LoadModule: “fb”
[ 37.413] (II) Loading /usr/lib64/xorg/modules/libfb.so
[ 37.414] (II) Module fb: vendor=“X.Org Foundation”
[ 37.414] compiled for 1.15.2, module version = 1.0.0
[ 37.414] ABI class: X.Org ANSI C Emulation, version 0.4
[ 37.414] (II) Loading sub module “wfb”
[ 37.414] (II) LoadModule: “wfb”
[ 37.414] (II) Loading /usr/lib64/xorg/modules/libwfb.so
[ 37.414] (II) Module wfb: vendor=“X.Org Foundation”
[ 37.414] (II) Loading sub module “ramdac”
[ 37.414] (II) LoadModule: “ramdac”
[ 37.414] (II) Module “ramdac” already built-in
[ 37.415] () NVIDIA(0): Depth 24, (–) framebuffer bpp 32
[ 37.415] (==) NVIDIA(0): RGB weight 888
[ 37.415] (==) NVIDIA(0): Default visual is TrueColor
[ 37.415] (==) NVIDIA(0): Using gamma correction (1.0, 1.0, 1.0)
[ 37.415] (
) NVIDIA(0): Option “AllowEmptyInitialConfiguration” “True”
[ 37.415] () NVIDIA(0): Enabling 2D acceleration
[ 38.308] (–) NVIDIA(0): Valid display device(s) on GPU-0 at PCI:3:0:0
[ 38.308] (–) NVIDIA(0): CRT-0
[ 38.308] (–) NVIDIA(0): DFP-0 (boot)
[ 38.308] (–) NVIDIA(0): DFP-1
[ 38.308] (–) NVIDIA(0): DFP-2
[ 38.311] (–) NVIDIA(0): CRT-0: disconnected
[ 38.311] (–) NVIDIA(0): CRT-0: 400.0 MHz maximum pixel clock
[ 38.313] (–) NVIDIA(0): DFP-0: disconnected
[ 38.313] (–) NVIDIA(0): DFP-0: Internal TMDS
[ 38.313] (–) NVIDIA(0): DFP-0: 330.0 MHz maximum pixel clock
[ 38.313] (–) NVIDIA(0): DFP-1: disconnected
[ 38.313] (–) NVIDIA(0): DFP-1: Internal TMDS
[ 38.313] (–) NVIDIA(0): DFP-1: 165.0 MHz maximum pixel clock
[ 38.313] (–) NVIDIA(0): DFP-2: disconnected
[ 38.313] (–) NVIDIA(0): DFP-2: Internal DisplayPort
[ 38.313] (–) NVIDIA(0): DFP-2: 960.0 MHz maximum pixel clock
[ 38.314] (II) NVIDIA(0): NVIDIA GPU Quadro K620 (GM107GL-A) at PCI:3:0:0 (GPU-0)
[ 38.314] (–) NVIDIA(0): Memory: 2097152 kBytes
[ 38.314] (–) NVIDIA(0): VideoBIOS: 82.07.7a.00.03
[ 38.314] (II) NVIDIA(0): Detected PCI Express Link width: 16X
[ 38.314] (==) NVIDIA(0):
[ 38.314] (==) NVIDIA(0): No modes were requested; the default mode “nvidia-auto-select”
[ 38.314] (==) NVIDIA(0): will be used as the requested mode.
[ 38.314] (–) NVIDIA(0): No enabled display devices found; starting anyway because
[ 38.314] (–) NVIDIA(0): AllowEmptyInitialConfiguration is enabled
[ 38.314] (II) NVIDIA(0): Validated MetaModes:
[ 38.314] (II) NVIDIA(0): “NULL”
[ 38.314] (
) NVIDIA(0): Virtual screen size configured to be 2560 x 1440
[ 38.314] (WW) NVIDIA(0): Unable to get display device for DPI computation.
[ 38.314] (==) NVIDIA(0): DPI set to (75, 75); computed from built-in default
[ 38.314] (–) Depth 24 pixmap format is 32 bpp
[ 38.315] (II) NVIDIA: Using 12288.00 MB of virtual memory for indirect memory
[ 38.316] (II) NVIDIA: access.
[ 38.323] (II) NVIDIA(0): ACPI: failed to connect to the ACPI event daemon; the daemon
[ 38.323] (II) NVIDIA(0): may not be running or the “AcpidSocketPath” X
[ 38.323] (II) NVIDIA(0): configuration option may not be set correctly. When the
[ 38.323] (II) NVIDIA(0): ACPI event daemon is available, the NVIDIA X driver will
[ 38.323] (II) NVIDIA(0): try to use it to receive ACPI event notifications. For
[ 38.323] (II) NVIDIA(0): details, please see the “ConnectToAcpid” and
[ 38.323] (II) NVIDIA(0): “AcpidSocketPath” X configuration options in Appendix B: X
[ 38.323] (II) NVIDIA(0): Config Options in the README.
[ 38.360] (II) NVIDIA(0): Setting mode “NULL”
[ 38.380] Loading extension NV-GLX
[ 38.386] (==) NVIDIA(0): Disabling shared memory pixmaps
[ 38.386] (==) NVIDIA(0): Backing store enabled
[ 38.386] (==) NVIDIA(0): Silken mouse enabled
[ 38.386] () NVIDIA(0): DPMS enabled
[ 38.386] Loading extension NV-CONTROL
[ 38.386] (II) Loading sub module “dri2”
[ 38.386] (II) LoadModule: “dri2”
[ 38.386] (II) Module “dri2” already built-in
[ 38.386] (II) NVIDIA(0): [DRI2] Setup complete
[ 38.386] (II) NVIDIA(0): [DRI2] VDPAU driver: nvidia
[ 38.386] (–) RandR disabled
[ 38.390] (II) Initializing extension GLX
[ 38.432] (II) config/udev: Adding input device Power Button (/dev/input/event1)
[ 38.432] (
) Power Button: Applying InputClass “evdev keyboard catchall”
[ 38.432] () Power Button: Applying InputClass “system-keyboard”
[ 38.432] (
[ 38.432] (II) LoadModule: “evdev”
[ 38.432] (II) Loading /usr/lib64/xorg/modules/input/evdev_drv.so
[ 38.433] (II) Module evdev: vendor=“X.Org Foundation”
[ 38.433] compiled for 1.15.2, module version = 2.8.2
[ 38.433] Module class: X.Org XInput Driver
[ 38.433] ABI class: X.Org XInput driver, version 20.0
[ 38.433] (II) Using input driver ‘evdev’ for ‘Power Button’
[ 38.433] () Power Button: always reports core events
[ 38.433] (
) evdev: Power Button: Device: “/dev/input/event1”
[ 38.433] (–) evdev: Power Button: Vendor 0 Product 0x1
[ 38.433] (–) evdev: Power Button: Found keys
[ 38.433] (II) evdev: Power Button: Configuring as keyboard
[ 38.433] () Option “config_info” “udev:/sys/devices/LNXSYSTM:00/LNXPWRBN:00/input/input4/event1”
[ 38.433] (II) XINPUT: Adding extended input device “Power Button” (type: KEYBOARD, id 6)
[ 38.433] (
) Option “xkb_rules” “evdev”
[ 38.433] () Option “xkb_model” “pc104”
[ 38.433] (
) Option “xkb_layout” “us”
[ 38.446] (II) config/udev: Adding input device Power Button (/dev/input/event0)
[ 38.446] () Power Button: Applying InputClass “evdev keyboard catchall”
[ 38.446] (
[ 38.446] (II) Using input driver ‘evdev’ for ‘Power Button’
[ 38.446] (
[ 38.446] () evdev: Power Button: Device: “/dev/input/event0”
[ 38.446] (–) evdev: Power Button: Vendor 0 Product 0x1
[ 38.446] (–) evdev: Power Button: Found keys
[ 38.446] (II) evdev: Power Button: Configuring as keyboard
[ 38.446] (
) Option “config_info” “udev:/sys/devices/LNXSYSTM:00/device:00/PNP0C0C:00/input/input3/event0”
[ 38.446] (II) XINPUT: Adding extended input device “Power Button” (type: KEYBOARD, id 7)
[ 38.446] () Option “xkb_rules” “evdev”
[ 38.446] (
[ 38.446] () Option “xkb_layout” “us”
[ 38.447] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=3 (/dev/input/event12)
[ 38.447] (II) No input driver specified, ignoring this device.
[ 38.447] (II) This device may have been added with another device file.
[ 38.447] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=7 (/dev/input/event11)
[ 38.447] (II) config/udev: Adding input device NOVATEK USB NETVISTA FULL WIDTH KEYBOARD (/dev/input/event3)
[ 38.447] (
) NOVATEK USB NETVISTA FULL WIDTH KEYBOARD: Applying InputClass “evdev keyboard catchall”
[ 38.447] () NOVATEK USB NETVISTA FULL WIDTH KEYBOARD: Applying InputClass “system-keyboard”
[ 38.447] (
[ 38.447] (II) Using input driver ‘evdev’ for ‘NOVATEK USB NETVISTA FULL WIDTH KEYBOARD’
[ 38.447] () NOVATEK USB NETVISTA FULL WIDTH KEYBOARD: always reports core events
[ 38.447] (
) evdev: NOVATEK USB NETVISTA FULL WIDTH KEYBOARD: Device: “/dev/input/event3”
[ 38.447] (–) evdev: NOVATEK USB NETVISTA FULL WIDTH KEYBOARD: Vendor 0x461 Product 0x4e04
[ 38.447] (–) evdev: NOVATEK USB NETVISTA FULL WIDTH KEYBOARD: Found keys
[ 38.447] (II) evdev: NOVATEK USB NETVISTA FULL WIDTH KEYBOARD: Configuring as keyboard
[ 38.447] () Option “config_info” “udev:/sys/devices/pci0000:00/0000:00:14.0/usb3/3-5/3-5.1/3-5.1:1.0/input/input6/event3”
[ 38.447] (II) XINPUT: Adding extended input device “NOVATEK USB NETVISTA FULL WIDTH KEYBOARD” (type: KEYBOARD, id 8)
[ 38.447] (
[ 38.447] () Option “xkb_model” “pc104”
[ 38.447] (
[ 38.447] (II) config/udev: Adding input device NOVATEK USB NETVISTA FULL WIDTH KEYBOARD (/dev/input/event4)
[ 38.447] () NOVATEK USB NETVISTA FULL WIDTH KEYBOARD: Applying InputClass “evdev keyboard catchall”
[ 38.447] (
[ 38.447] (
[ 38.447] () evdev: NOVATEK USB NETVISTA FULL WIDTH KEYBOARD: Device: “/dev/input/event4”
[ 38.447] (
) Option “config_info” “udev:/sys/devices/pci0000:00/0000:00:14.0/usb3/3-5/3-5.1/3-5.1:1.1/input/input7/event4”
[ 38.448] (II) XINPUT: Adding extended input device “NOVATEK USB NETVISTA FULL WIDTH KEYBOARD” (type: KEYBOARD, id 9)
[ 38.448] () Option “xkb_rules” “evdev”
[ 38.448] (
[ 38.448] () Option “xkb_layout” “us”
[ 38.448] (II) config/udev: Adding input device PixArt Lenovo USB Optical Mouse (/dev/input/event5)
[ 38.448] (
) PixArt Lenovo USB Optical Mouse: Applying InputClass “evdev pointer catchall”
[ 38.448] () PixArt Lenovo USB Optical Mouse: Applying InputClass “evdev pointer catchall”
[ 38.448] (II) Using input driver ‘evdev’ for ‘PixArt Lenovo USB Optical Mouse’
[ 38.448] (
) PixArt Lenovo USB Optical Mouse: always reports core events
[ 38.448] () evdev: PixArt Lenovo USB Optical Mouse: Device: “/dev/input/event5”
[ 38.448] (–) evdev: PixArt Lenovo USB Optical Mouse: Vendor 0x17ef Product 0x6019
[ 38.448] (–) evdev: PixArt Lenovo USB Optical Mouse: Found 3 mouse buttons
[ 38.448] (–) evdev: PixArt Lenovo USB Optical Mouse: Found scroll wheel(s)
[ 38.448] (–) evdev: PixArt Lenovo USB Optical Mouse: Found relative axes
[ 38.448] (–) evdev: PixArt Lenovo USB Optical Mouse: Found x and y relative axes
[ 38.448] (II) evdev: PixArt Lenovo USB Optical Mouse: Configuring as mouse
[ 38.448] (II) evdev: PixArt Lenovo USB Optical Mouse: Adding scrollwheel support
[ 38.448] (
) evdev: PixArt Lenovo USB Optical Mouse: YAxisMapping: buttons 4 and 5
[ 38.448] () evdev: PixArt Lenovo USB Optical Mouse: EmulateWheelButton: 4, EmulateWheelInertia: 10, EmulateWheelTimeout: 200
[ 38.448] (
) Option “config_info” “udev:/sys/devices/pci0000:00/0000:00:14.0/usb3/3-5/3-5.2/3-5.2:1.0/input/input8/event5”
[ 38.448] (II) XINPUT: Adding extended input device “PixArt Lenovo USB Optical Mouse” (type: MOUSE, id 10)
[ 38.448] (II) evdev: PixArt Lenovo USB Optical Mouse: initialized for relative axes.
[ 38.448] () PixArt Lenovo USB Optical Mouse: (accel) keeping acceleration scheme 1
[ 38.448] (
) PixArt Lenovo USB Optical Mouse: (accel) acceleration profile 0
[ 38.448] () PixArt Lenovo USB Optical Mouse: (accel) acceleration factor: 2.000
[ 38.448] (
) PixArt Lenovo USB Optical Mouse: (accel) acceleration threshold: 4
[ 38.448] (II) config/udev: Adding input device PixArt Lenovo USB Optical Mouse (/dev/input/mouse0)
[ 38.448] (II) No input driver specified, ignoring this device.
[ 38.448] (II) This device may have been added with another device file.
[ 38.449] (II) config/udev: Adding input device HDA Intel PCH Rear Mic (/dev/input/event9)
[ 38.449] (II) No input driver specified, ignoring this device.
[ 38.449] (II) This device may have been added with another device file.
[ 38.449] (II) config/udev: Adding input device HDA Intel PCH Line (/dev/input/event8)
[ 38.449] (II) config/udev: Adding input device HDA Intel PCH Line Out (/dev/input/event7)
[ 38.449] (II) config/udev: Adding input device HDA Intel PCH Front Headphone (/dev/input/event6)
[ 38.449] (II) config/udev: Adding input device HDA Intel PCH Front Mic (/dev/input/event10)
[ 38.449] (II) config/udev: Adding input device PC Speaker (/dev/input/event2)
[ 39.037] (–) NVIDIA(GPU-0): CRT-0: disconnected
[ 39.037] (–) NVIDIA(GPU-0): CRT-0: 400.0 MHz maximum pixel clock
[ 39.039] (–) NVIDIA(GPU-0): DFP-0: disconnected
[ 39.039] (–) NVIDIA(GPU-0): DFP-0: Internal TMDS
[ 39.039] (–) NVIDIA(GPU-0): DFP-0: 330.0 MHz maximum pixel clock
[ 39.040] (–) NVIDIA(GPU-0): DFP-1: disconnected
[ 39.040] (–) NVIDIA(GPU-0): DFP-1: Internal TMDS
[ 39.040] (–) NVIDIA(GPU-0): DFP-1: 165.0 MHz maximum pixel clock
[ 39.040] (–) NVIDIA(GPU-0): DFP-2: disconnected
[ 39.040] (–) NVIDIA(GPU-0): DFP-2: Internal DisplayPort
[ 39.040] (–) NVIDIA(GPU-0): DFP-2: 960.0 MHz maximum pixel clock
[ 538.696] (–) NVIDIA(GPU-0): CRT-0: disconnected
[ 538.696] (–) NVIDIA(GPU-0): CRT-0: 400.0 MHz maximum pixel clock
[ 538.699] (–) NVIDIA(GPU-0): DFP-0: disconnected
[ 538.699] (–) NVIDIA(GPU-0): DFP-0: Internal TMDS
[ 538.699] (–) NVIDIA(GPU-0): DFP-0: 330.0 MHz maximum pixel clock
[ 538.699] (–) NVIDIA(GPU-0): DFP-1: disconnected
[ 538.699] (–) NVIDIA(GPU-0): DFP-1: Internal TMDS
[ 538.699] (–) NVIDIA(GPU-0): DFP-1: 165.0 MHz maximum pixel clock
[ 538.699] (–) NVIDIA(GPU-0): DFP-2: disconnected
[ 538.699] (–) NVIDIA(GPU-0): DFP-2: Internal DisplayPort
[ 538.699] (–) NVIDIA(GPU-0): DFP-2: 960.0 MHz maximum pixel clock
[ 538.703] (–) NVIDIA(GPU-0): CRT-0: disconnected
[ 538.703] (–) NVIDIA(GPU-0): CRT-0: 400.0 MHz maximum pixel clock
[ 538.705] (–) NVIDIA(GPU-0): DFP-0: disconnected
[ 538.705] (–) NVIDIA(GPU-0): DFP-0: Internal TMDS
[ 538.705] (–) NVIDIA(GPU-0): DFP-0: 330.0 MHz maximum pixel clock
[ 538.706] (–) NVIDIA(GPU-0): DFP-1: disconnected
[ 538.706] (–) NVIDIA(GPU-0): DFP-1: Internal TMDS
[ 538.706] (–) NVIDIA(GPU-0): DFP-1: 165.0 MHz maximum pixel clock
[ 538.706] (–) NVIDIA(GPU-0): DFP-2: disconnected
[ 538.706] (–) NVIDIA(GPU-0): DFP-2: Internal DisplayPort
[ 538.706] (–) NVIDIA(GPU-0): DFP-2: 960.0 MHz maximum pixel clock
[ 538.777] (–) NVIDIA(GPU-0): CRT-0: disconnected
[ 538.777] (–) NVIDIA(GPU-0): CRT-0: 400.0 MHz maximum pixel clock
[ 538.779] (–) NVIDIA(GPU-0): DFP-0: disconnected
[ 538.779] (–) NVIDIA(GPU-0): DFP-0: Internal TMDS
[ 538.779] (–) NVIDIA(GPU-0): DFP-0: 330.0 MHz maximum pixel clock
[ 538.780] (–) NVIDIA(GPU-0): DFP-1: disconnected
[ 538.780] (–) NVIDIA(GPU-0): DFP-1: Internal TMDS
[ 538.780] (–) NVIDIA(GPU-0): DFP-1: 165.0 MHz maximum pixel clock
[ 538.780] (–) NVIDIA(GPU-0): DFP-2: disconnected
[ 538.780] (–) NVIDIA(GPU-0): DFP-2: Internal DisplayPort
[ 538.780] (–) NVIDIA(GPU-0): DFP-2: 960.0 MHz maximum pixel clock
*** /etc/X11/xorg.conf
*** ls: -rw-r–r-- 1 root root 1452 2016-07-14 09:49:17.520236748 -0700 /etc/X11/xorg.conf
nvidia-xconfig: X configuration file generated by nvidia-xconfig
nvidia-xconfig: version 367.27 (buildmeister@swio-display-x64-rhel04-12) Thu Jun 9 19:24:36 PDT 2016
Section “ServerLayout”
Identifier “Layout0”
Screen 0 “Screen0” 0 0
InputDevice “Keyboard0” “CoreKeyboard”
InputDevice “Mouse0” “CorePointer”
EndSection
Section “Files”
EndSection
Section “InputDevice”
# generated from data in "/etc/sysconfig/mouse"
Identifier     "Mouse0"
Driver         "mouse"
Option         "Protocol" "IMPS/2"
Option         "Device" "/dev/input/mice"
Option         "Emulate3Buttons" "yes"
Option         "ZAxisMapping" "4 5"
EndSection
# generated from default
Identifier     "Keyboard0"
Driver         "kbd"
EndSection
Section “Monitor”
Identifier “Monitor0”
VendorName “Unknown”
ModelName “Unknown”
HorizSync 28.0 - 33.0
VertRefresh 43.0 - 72.0
Option “DPMS”
EndSection
Section “Device”
Identifier “Device0”
Driver “nvidia”
VendorName “NVIDIA Corporation”
EndSection
Section “Screen”
Identifier “Screen0”
Device “Device0”
Monitor “Monitor0”
DefaultDepth 24
SubSection “Display”
Virtual 2560 1440
Depth 24
EndSubSection
EndSection
*** /etc/X11/xorg.conf.d/00-keyboard.conf
*** ls: -rw-r–r-- 1 root root 232 2016-07-13 09:52:24.260302833 -0700 /etc/X11/xorg.conf.d/00-keyboard.conf
Read and parsed by systemd-localed. It’s probably wise not to edit this file
manually too freely.
Section “InputClass”
Identifier “system-keyboard”
MatchIsKeyboard “on”
Option “XkbLayout” “us”
EndSection
*** /etc/X11/xorg.conf.d/10-evdev.conf
*** ls: -rw-r–r-- 1 root root 1099 2016-02-19 06:46:15.000000000 -0800 /etc/X11/xorg.conf.d/10-evdev.conf
Catch-all evdev loader for udev-based systems
We don’t simply match on any device since that also adds accelerometers
and other devices that we don’t really want to use. The list below
matches everything but joysticks.
Identifier “evdev pointer catchall”
MatchIsPointer “on”
MatchDevicePath “/dev/input/event*”
Driver “evdev”
EndSection
Identifier “evdev keyboard catchall”
Driver “evdev”
EndSection
Identifier “evdev touchpad catchall”
MatchIsTouchpad “on”
Driver “evdev”
EndSection
Identifier “evdev tablet catchall”
MatchIsTablet “on”
Driver “evdev”
EndSection
Identifier “evdev touchscreen catchall”
MatchIsTouchscreen “on”
Driver “evdev”
EndSection
*** /etc/X11/xorg.conf.d/10-libvnc.conf
*** ls: -rw-r–r-- 1 root root 488 2016-04-28 00:13:47.000000000 -0700 /etc/X11/xorg.conf.d/10-libvnc.conf
This file contains configuration of libvnc.so module
To get libvnc.so module working, do this:
1. run “vncpasswd” as root user
2. uncomment configuration lines below
Please note you can specify any option which Xvnc accepts.
Refer to Xvnc -help output for detailed list of options.
#Section “Module”
Load “vnc”
#EndSection
#Section “Screen”
Identifier "Screen0
Option “SecurityTypes” “VncAuth”
Option “PasswordFile” “/root/.vnc/passwd”
#EndSection
*** /etc/X11/xorg.conf.d/11-evdev.conf
*** ls: -rw-r–r-- 1 root root 484 2015-09-09 19:41:15.000000000 -0700 /etc/X11/xorg.conf.d/11-evdev.conf
# Novell Bugs #597214, #780626, #843333, #861813
Identifier “Trackpoint Wheel Emulation”
MatchProduct “TPPS/2 IBM TrackPoint|ThinkPad USB Keyboard with TrackPoint”
MatchIsPointer “on”
Driver “evdev”
Option “EmulateWheel” “on”
Option “EmulateWheelButton” “2”
# Since middle button is in use now these button events need to be emulated (bnc#869097)
Option “Emulate3Buttons” “on”
EndSection
*** /etc/X11/xorg.conf.d/50-device.conf
*** ls: -rw-r–r-- 1 root root 529 2011-07-01 03:49:43.000000000 -0700 /etc/X11/xorg.conf.d/50-device.conf
Having multiple “Device” sections is known to be problematic. Make
sure you don’t have in use another one laying around e.g. in another
xorg.conf.d file or even a generic xorg.conf file. More details can
be found in https://bugs.freedesktop.org/show_bug.cgi?id=32430.
#Section “Device”
Identifier “Default Device”
driver “radeon”
## Required magic for radeon/radeonhd drivers; output name
## (here: “DVI-0”) can be figured out via ‘xrandr -q’
#Option “monitor-DVI-0” “Default Monitor”
#EndSection
*** /etc/X11/xorg.conf.d/50-elotouch.conf
*** ls: -rw-r–r-- 1 root root 199 2015-09-09 19:41:15.000000000 -0700 /etc/X11/xorg.conf.d/50-elotouch.conf
MatchProduct “Elo TouchSystems CarrollTouch 4500U|Elo TouchSystems CarrollTouch 4000U”
Identifier “Elotouch”
Driver “evdev”
Option “Mode” “Absolute”
EndSection
*** /etc/X11/xorg.conf.d/50-monitor.conf
*** ls: -rw-r–r-- 1 root root 527 2011-07-01 03:49:53.000000000 -0700 /etc/X11/xorg.conf.d/50-monitor.conf
Having multiple “Monitor” sections is known to be problematic. Make
#Section “Monitor”
Identifier “Default Monitor”
## If your monitor doesn’t support DDC you may override the
## defaults here
#HorizSync 28-85
#VertRefresh 50-100
## Add your mode lines here, use e.g the cvt tool
#EndSection
*** /etc/X11/xorg.conf.d/50-screen.conf
*** ls: -rw-r–r-- 1 root root 491 2011-07-01 03:50:05.000000000 -0700 /etc/X11/xorg.conf.d/50-screen.conf
Having multiple “Screen” sections is known to be problematic. Make
#Section “Screen”
Identifier “Default Screen”
Device “Default Device”
## Doesn’t help for radeon/radeonhd drivers; use magic in
## 50-device.conf instead
Monitor “Default Monitor”
#EndSection
*** /etc/X11/xorg.conf.d/50-synaptics.conf
*** ls: -rw-r–r-- 1 root root 1911 2014-09-26 14:58:43.000000000 -0700 /etc/X11/xorg.conf.d/50-synaptics.conf
Example xorg.conf.d snippet that assigns the touchpad driver
to all touchpads. See xorg.conf.d(5) for more information on
InputClass.
DO NOT EDIT THIS FILE, your distribution will likely overwrite
it when updating. Copy (and rename) this file into
/etc/X11/xorg.conf.d first.
Additional options may be added in the form of
Option “OptionName” “value”
Identifier “touchpad catchall”
Driver “synaptics”
This option is recommend on all Linux systems using evdev, but cannot be
enabled by default. See the following link for details:
Who-T: How to ignore configuration errors
    MatchDevicePath "/dev/input/event*"
    Option	"HorizEdgeScroll" "off"
enable tap-to-click as default (bnc#722457)
Option "TapButton1" "1"
Option "TapButton3" "2"
Option "TapButton2" "3"
EndSection
Identifier “touchpad ignore duplicates”
MatchOS “Linux”
MatchDevicePath “/dev/input/mouse*”
Option “Ignore” “on”
EndSection
This option enables the bottom right corner to be a right button on clickpads
and the right and middle top areas to be right / middle buttons on clickpads
with a top button area.
This option is only interpreted by clickpads.
Identifier “Default clickpad buttons”
MatchDriver “synaptics”
Option “SoftButtonAreas” “50% 0 82% 0 0 0 0 0”
Option “SecondarySoftButtonAreas” “58% 0 0 8% 42% 58% 0 8%”
EndSection
This option disables software buttons on Apple touchpads.
Identifier “Disable clickpad buttons on Apple touchpads”
MatchProduct “Apple|bcm5974”
Option “SoftButtonAreas” “0 0 0 0 0 0 0 0”
EndSection
*** /etc/X11/xorg.conf.d/50-vmmouse.conf
*** ls: -rw-r–r-- 1 root root 115 2015-08-21 04:01:34.000000000 -0700 /etc/X11/xorg.conf.d/50-vmmouse.conf
Identifier “vmmouse”
MatchIsPointer “on”
MatchTag “vmmouse”
Driver “vmmouse”
EndSection
*** /etc/X11/xorg.conf.d/50-wacom.conf
*** ls: -rw-r–r-- 1 root root 858 2014-09-23 06:34:20.000000000 -0700 /etc/X11/xorg.conf.d/50-wacom.conf
Identifier “Wacom class”
MatchProduct “Wacom|WACOM|Hanwang|PTK-540WL|ISD-V4”
Driver “wacom”
EndSection
Identifier “Wacom serial class”
MatchProduct “Serial Wacom Tablet”
Driver “wacom”
EndSection
Identifier “Wacom serial class identifiers”
MatchProduct “WACf|FUJ02e5|FUJ02e7|FUJ02e9”
Driver “wacom”
EndSection
Waltop tablets
Identifier “Waltop class”
MatchProduct “WALTOP”
MatchIsTablet “on”
Driver “wacom”
EndSection
N-Trig Duosense Electromagnetic Digitizer
Identifier “Wacom N-Trig class”
MatchProduct “HID 1b96:0001|N-Trig Pen|N-Trig DuoSense”
Driver “wacom”
Option “Button2” “3”
EndSection
*** /usr/share/X11/xorg.conf.d/10-evdev.conf
*** ls: -rw-r–r-- 1 root root 1099 2016-02-19 06:46:12.000000000 -0800 /usr/share/X11/xorg.conf.d/10-evdev.conf
MatchIsPointer “on”
Driver “evdev”
EndSection
Driver “evdev”
EndSection
Driver “evdev”
EndSection
MatchIsTablet “on”
Driver “evdev”
EndSection
Driver “evdev”
EndSection
*** /usr/share/X11/xorg.conf.d/10-quirks.conf
*** ls: -rw-r–r-- 1 root root 1867 2016-02-19 06:46:12.000000000 -0800 /usr/share/X11/xorg.conf.d/10-quirks.conf
Collection of quirks and blacklist/whitelists for specific devices.
Accelerometer device, posts data through ABS_X/ABS_Y, making X unusable
22442 – ThinkPad HDAPS accelerometer gets recognized as MOUSE and makes Xorg unusable
Identifier “ThinkPad HDAPS accelerometer blacklist”
MatchProduct “ThinkPad HDAPS accelerometer data”
EndSection
523914 – Mouse does not move in PV Xen guest under RHEL-5.4
Explicitly tell evdev to not ignore the absolute axes.
Identifier “Xen Virtual Pointer axis blacklist”
MatchProduct “Xen Virtual Pointer”
Option “IgnoreAbsoluteAxes” “off”
Option “IgnoreRelativeAxes” “off”
EndSection
612140 – please make Evoluent VerticalMouse 3 work out of the box
Button mapping on this mouse is quirky
Identifier “Evoluent VerticalMouse 3”
MatchProduct “Evoluent VerticalMouse 3”
# Sets following configuration:
# top button: left
# middle button: middle
# bottom button: right
# wheel click: middle
# thumb button: 8 (back)
Option “ButtonMapping” “1 2 2 4 5 6 7 3 8”
EndSection
55867 – Doesn't know how to tag XI_TRACKBALL
Bug 55867 - Doesn’t know how to tag XI_TRACKBALL
Identifier “Tag trackballs as XI_TRACKBALL”
MatchProduct “trackball”
MatchDriver “evdev”
Option “TypeName” “TRACKBALL”
EndSection
62831 – Mionix Naos 5000 mouse detected incorrectly
Bug 62831 - Mionix Naos 5000 mouse detected incorrectly
Identifier “Tag Mionix Naos 5000 mouse XI_MOUSE”
MatchProduct “La-VIEW Technology Naos 5000 Mouse”
MatchDriver “evdev”
Option “TypeName” “MOUSE”
EndSection
*** /var/log/Xorg.1.log
*** ls: -rw-r–r-- 1 root root 11079 2016-07-14 08:33:22.704133633 -0700 /var/log/Xorg.1.log
[ 39.206]
[ 39.206] X Protocol Version 11, Revision 0
[ 39.206] Build Operating System: openSUSE SUSE LINUX
[ 39.206] Current Operating System: Linux linux-sr8i 3.12.60-52.54-default #1 SMP Sat Jun 25 06:22:00 UTC 2016 (e55cce6) x86_64
[ 39.206] Kernel command line: BOOT_IMAGE=/boot/vmlinuz-3.12.60-52.54-default root=UUID=8ee93df3-1313-4fee-8989-4164da0ebf15 resume=/dev/disk/by-uuid/f45d8404-92ab-4a80-8878-7d8230dc196a splash=silent quiet crashkernel=232M-:116M showopts
[ 39.206] Build Date: 19 February 2016 02:44:39PM
[ 39.206]
[ 39.206] Current version of pixman: 0.32.6
[ 39.206] Before reporting problems, check http://wiki.x.org
[ 39.206] Markers: (–) probed, () from config file, (==) default setting,
[ 39.206] (==) Log file: “/var/log/Xorg.1.log”, Time: Thu Jul 14 08:33:21 2016
[ 39.206] (==) Using config directory: “/etc/X11/xorg.conf.d”
[ 39.206] (==) Using system config directory “/usr/share/X11/xorg.conf.d”
[ 39.207] (==) No Layout section. Using the first Screen section.
[ 39.207] (==) No screen section available. Using defaults.
[ 39.207] (
) |–>Screen “Default Screen Section” (0)
[ 39.207] (**) | |–>Monitor “”
[ 39.207] (==) No monitor specified for screen “Default Screen Section”.
Using a default monitor configuration.
[ 39.207] (==) Automatically adding devices
[ 39.207] (==) Automatically enabling devices
[ 39.207] (==) Automatically adding GPU devices
[ 39.207] (WW) The directory “/usr/share/fonts/misc/sgi” does not exist.
[ 39.207] Entry deleted from font path.
[ 39.207] (==) FontPath set to:
built-ins
[ 39.207] (==) ModulePath set to “/usr/lib64/xorg/modules”
[ 39.207] (II) The server relies on udev to provide the list of input devices.
If no devices become available, reconfigure udev or disable AutoAddDevices.
[ 39.207] (II) Loader magic: 0x602b60
[ 39.207] (II) Module ABI versions:
[ 39.207] X.Org ANSI C Emulation: 0.4
[ 39.207] X.Org Video Driver: 15.0
[ 39.207] X.Org XInput driver : 20.0
[ 39.207] X.Org Server Extension : 8.0
[ 39.212] (–) PCI:*(0:3:0:0) 10de:13bb:10de:1098 rev 162, Mem @ 0xd2000000/16777216, 0xc0000000/268435456, 0xd0000000/33554432, I/O @ 0x00006000/128, BIOS @ 0x???/524288
[ 39.213] Initializing built-in extension Generic Event Extension
[ 39.213] Initializing built-in extension SHAPE
[ 39.213] Initializing built-in extension MIT-SHM
[ 39.213] Initializing built-in extension XInputExtension
[ 39.213] Initializing built-in extension XTEST
[ 39.213] Initializing built-in extension BIG-REQUESTS
[ 39.213] Initializing built-in extension SYNC
[ 39.213] Initializing built-in extension XKEYBOARD
[ 39.213] Initializing built-in extension XC-MISC
[ 39.213] Initializing built-in extension SECURITY
[ 39.213] Initializing built-in extension XINERAMA
[ 39.213] Initializing built-in extension XFIXES
[ 39.213] Initializing built-in extension RENDER
[ 39.213] Initializing built-in extension RANDR
[ 39.213] Initializing built-in extension COMPOSITE
[ 39.213] Initializing built-in extension DAMAGE
[ 39.213] Initializing built-in extension MIT-SCREEN-SAVER
[ 39.213] Initializing built-in extension DOUBLE-BUFFER
[ 39.213] Initializing built-in extension RECORD
[ 39.213] Initializing built-in extension DPMS
[ 39.213] Initializing built-in extension Present
[ 39.213] Initializing built-in extension DRI3
[ 39.213] Initializing built-in extension X-Resource
[ 39.213] Initializing built-in extension XVideo
[ 39.213] Initializing built-in extension XVideo-MotionCompensation
[ 39.213] Initializing built-in extension XFree86-VidModeExtension
[ 39.213] Initializing built-in extension XFree86-DGA
[ 39.213] Initializing built-in extension DRI2
[ 39.213] (II) LoadModule: “glx”
[ 39.213] (II) Loading /usr/lib64/xorg/modules/extensions/libglx.so
[ 39.219] (II) Module glx: vendor=“NVIDIA Corporation”
[ 39.219] compiled for 4.0.2, module version = 1.0.0
[ 39.219] Module class: X.Org Server Extension
[ 39.219] (II) NVIDIA GLX Module 367.27 Thu Jun 9 18:19:55 PDT 2016
[ 39.219] Loading extension GLX
[ 39.219] (==) Matched nvidia as autoconfigured driver 0
[ 39.219] (==) Matched nouveau as autoconfigured driver 1
[ 39.219] (==) Matched nv as autoconfigured driver 2
[ 39.219] (==) Matched modesetting as autoconfigured driver 3
[ 39.219] (==) Matched fbdev as autoconfigured driver 4
[ 39.219] (==) Matched vesa as autoconfigured driver 5
[ 39.219] (==) Assigned the driver to the xf86ConfigLayout
[ 39.219] (II) LoadModule: “nvidia”
[ 39.219] (II) Loading /usr/lib64/xorg/modules/drivers/nvidia_drv.so
[ 39.220] (II) Module nvidia: vendor=“NVIDIA Corporation”
[ 39.220] compiled for 4.0.2, module version = 1.0.0
[ 39.220] Module class: X.Org Video Driver
[ 39.220] (II) LoadModule: “nouveau”
[ 39.220] (WW) Warning, couldn’t open module nouveau
[ 39.220] (II) UnloadModule: “nouveau”
[ 39.220] (II) Unloading nouveau
[ 39.220] (EE) Failed to load module “nouveau” (module does not exist, 0)
[ 39.220] (II) LoadModule: “nv”
[ 39.220] (WW) Warning, couldn’t open module nv
[ 39.220] (II) UnloadModule: “nv”
[ 39.220] (II) Unloading nv
[ 39.220] (EE) Failed to load module “nv” (module does not exist, 0)
[ 39.220] (II) LoadModule: “modesetting”
[ 39.221] (II) Loading /usr/lib64/xorg/modules/drivers/modesetting_drv.so
[ 39.221] (II) Module modesetting: vendor=“X.Org Foundation”
[ 39.221] compiled for 1.15.2, module version = 0.9.0
[ 39.221] Module class: X.Org Video Driver
[ 39.221] ABI class: X.Org Video Driver, version 15.0
[ 39.221] (II) LoadModule: “fbdev”
[ 39.221] (II) Loading /usr/lib64/xorg/modules/drivers/fbdev_drv.so
[ 39.221] (II) Module fbdev: vendor=“X.Org Foundation”
[ 39.221] compiled for 1.15.2, module version = 0.4.4
[ 39.221] (II) LoadModule: “vesa”
[ 39.221] (II) Loading /usr/lib64/xorg/modules/drivers/vesa_drv.so
[ 39.221] (II) Module vesa: vendor=“X.Org Foundation”
[ 39.221] compiled for 1.15.2, module version = 2.3.3
[ 39.221] (II) NVIDIA dlloader X Driver 367.27 Thu Jun 9 17:57:30 PDT 2016
[ 39.221] (II) NVIDIA Unified Driver for all Supported NVIDIA GPUs
[ 39.221] (II) modesetting: Driver for Modesetting Kernel Drivers: kms
[ 39.221] (II) FBDEV: driver for framebuffer: fbdev
[ 39.221] (II) VESA: driver for VESA chipsets: vesa
[ 39.221] (++) using VT number 7
[ 39.272] (II) Loading sub module “fb”
[ 39.272] (II) LoadModule: “fb”
[ 39.272] (II) Loading /usr/lib64/xorg/modules/libfb.so
[ 39.272] (II) Module fb: vendor=“X.Org Foundation”
[ 39.272] compiled for 1.15.2, module version = 1.0.0
[ 39.272] ABI class: X.Org ANSI C Emulation, version 0.4
[ 39.272] (II) Loading sub module “wfb”
[ 39.272] (II) LoadModule: “wfb”
[ 39.272] (II) Loading /usr/lib64/xorg/modules/libwfb.so
[ 39.273] (II) Module wfb: vendor=“X.Org Foundation”
[ 39.273] compiled for 1.15.2, module version = 1.0.0
[ 39.273] ABI class: X.Org ANSI C Emulation, version 0.4
[ 39.273] (II) Loading sub module “ramdac”
[ 39.273] (II) LoadModule: “ramdac”
[ 39.273] (II) Module “ramdac” already built-in
[ 39.273] (WW) Falling back to old probe method for modesetting
[ 39.273] (EE) open /dev/dri/card0: No such file or directory
[ 39.273] (WW) Falling back to old probe method for fbdev
[ 39.273] (II) Loading sub module “fbdevhw”
[ 39.273] (II) LoadModule: “fbdevhw”
[ 39.274] (II) Loading /usr/lib64/xorg/modules/libfbdevhw.so
[ 39.274] (II) Module fbdevhw: vendor=“X.Org Foundation”
[ 39.274] compiled for 1.15.2, module version = 0.0.2
[ 39.274] ABI class: X.Org Video Driver, version 15.0
[ 39.274] (WW) Falling back to old probe method for vesa
[ 39.274] (II) NVIDIA(0): Creating default Display subsection in Screen section
“Default Screen Section” for depth/fbbpp 24/32
[ 39.274] (==) NVIDIA(0): Depth 24, (==) framebuffer bpp 32
[ 39.274] (==) NVIDIA(0): RGB weight 888
[ 39.274] (==) NVIDIA(0): Default visual is TrueColor
[ 39.274] (==) NVIDIA(0): Using gamma correction (1.0, 1.0, 1.0)
[ 39.274] (**) NVIDIA(0): Enabling 2D acceleration
[ 39.973] (–) NVIDIA(0): Valid display device(s) on GPU-0 at PCI:3:0:0
[ 39.973] (–) NVIDIA(0): CRT-0
[ 39.973] (–) NVIDIA(0): DFP-0 (boot)
[ 39.973] (–) NVIDIA(0): DFP-1
[ 39.973] (–) NVIDIA(0): DFP-2
[ 39.975] (–) NVIDIA(0): CRT-0: disconnected
[ 39.975] (–) NVIDIA(0): CRT-0: 400.0 MHz maximum pixel clock
[ 39.978] (–) NVIDIA(0): DFP-0: disconnected
[ 39.978] (–) NVIDIA(0): DFP-0: Internal TMDS
[ 39.978] (–) NVIDIA(0): DFP-0: 330.0 MHz maximum pixel clock
[ 39.978] (–) NVIDIA(0): DFP-1: disconnected
[ 39.978] (–) NVIDIA(0): DFP-1: Internal TMDS
[ 39.978] (–) NVIDIA(0): DFP-1: 165.0 MHz maximum pixel clock
[ 39.978] (–) NVIDIA(0): DFP-2: disconnected
[ 39.978] (–) NVIDIA(0): DFP-2: Internal DisplayPort
[ 39.978] (–) NVIDIA(0): DFP-2: 960.0 MHz maximum pixel clock
[ 39.979] (II) NVIDIA(0): NVIDIA GPU Quadro K620 (GM107GL-A) at PCI:3:0:0 (GPU-0)
[ 39.979] (–) NVIDIA(0): Memory: 2097152 kBytes
[ 39.979] (–) NVIDIA(0): VideoBIOS: 82.07.7a.00.03
[ 39.979] (II) NVIDIA(0): Detected PCI Express Link width: 16X
[ 39.979] (EE) NVIDIA(0): Failed to assign any connected display devices to X screen 0.
[ 39.979] (EE) NVIDIA(0): Set AllowEmptyInitialConfiguration if you want the server
[ 39.979] (EE) NVIDIA(0): to start anyway
[ 39.979] (EE) NVIDIA(0): Failing initialization of X screen 0
[ 40.653] (II) UnloadModule: “nvidia”
[ 40.653] (II) UnloadSubModule: “wfb”
[ 40.653] (II) UnloadSubModule: “fb”
[ 40.653] (EE) Screen(s) found, but none have a usable configuration.
[ 40.653] (EE)
Fatal server error:
[ 40.653] (EE) no screens found(EE)
[ 40.653] (EE)
Please consult the The X.Org Foundation support
at http://wiki.x.org
for help.
[ 40.653] (EE) Please also check the log file at “/var/log/Xorg.1.log” for additional information.
[ 40.653] (EE)
[ 40.710] (EE) Server terminated with error (1). Closing log file.
*** /var/log/Xorg.2.log
*** ls: -rw-r–r-- 1 root root 11079 2016-07-14 08:33:24.168133565 -0700 /var/log/Xorg.2.log
[ 40.737]
[ 40.737] X Protocol Version 11, Revision 0
[ 40.737] Build Operating System: openSUSE SUSE LINUX
[ 40.737] Current Operating System: Linux linux-sr8i 3.12.60-52.54-default #1 SMP Sat Jun 25 06:22:00 UTC 2016 (e55cce6) x86_64
[ 40.737] Kernel command line: BOOT_IMAGE=/boot/vmlinuz-3.12.60-52.54-default root=UUID=8ee93df3-1313-4fee-8989-4164da0ebf15 resume=/dev/disk/by-uuid/f45d8404-92ab-4a80-8878-7d8230dc196a splash=silent quiet crashkernel=232M-:116M showopts
[ 40.737] Build Date: 19 February 2016 02:44:39PM
[ 40.737]
[ 40.737] Current version of pixman: 0.32.6
[ 40.737] Before reporting problems, check http://wiki.x.org
[ 40.737] Markers: (–) probed, () from config file, (==) default setting,
[ 40.737] (==) Log file: “/var/log/Xorg.2.log”, Time: Thu Jul 14 08:33:22 2016
[ 40.738] (==) Using config directory: “/etc/X11/xorg.conf.d”
[ 40.738] (==) Using system config directory “/usr/share/X11/xorg.conf.d”
[ 40.738] (==) No Layout section. Using the first Screen section.
[ 40.738] (==) No screen section available. Using defaults.
[ 40.738] (
[ 40.738] (**) | |–>Monitor “”
[ 40.738] (==) No monitor specified for screen “Default Screen Section”.
[ 40.738] (==) Automatically adding devices
[ 40.738] (==) Automatically enabling devices
[ 40.738] (==) Automatically adding GPU devices
[ 40.738] (WW) The directory “/usr/share/fonts/misc/sgi” does not exist.
[ 40.738] Entry deleted from font path.
[ 40.738] (==) FontPath set to:
built-ins
[ 40.738] (==) ModulePath set to “/usr/lib64/xorg/modules”
[ 40.738] (II) The server relies on udev to provide the list of input devices.
[ 40.738] (II) Loader magic: 0x602b60
[ 40.738] (II) Module ABI versions:
[ 40.738] X.Org ANSI C Emulation: 0.4
[ 40.738] X.Org Video Driver: 15.0
[ 40.738] X.Org XInput driver : 20.0
[ 40.738] X.Org Server Extension : 8.0
[ 40.744] (–) PCI:*(0:3:0:0) 10de:13bb:10de:1098 rev 162, Mem @ 0xd2000000/16777216, 0xc0000000/268435456, 0xd0000000/33554432, I/O @ 0x00006000/128, BIOS @ 0x???/524288
[ 40.744] Initializing built-in extension Generic Event Extension
[ 40.744] Initializing built-in extension SHAPE
[ 40.744] Initializing built-in extension MIT-SHM
[ 40.744] Initializing built-in extension XInputExtension
[ 40.744] Initializing built-in extension XTEST
[ 40.744] Initializing built-in extension BIG-REQUESTS
[ 40.744] Initializing built-in extension SYNC
[ 40.744] Initializing built-in extension XKEYBOARD
[ 40.744] Initializing built-in extension XC-MISC
[ 40.744] Initializing built-in extension SECURITY
[ 40.744] Initializing built-in extension XINERAMA
[ 40.744] Initializing built-in extension XFIXES
[ 40.744] Initializing built-in extension RENDER
[ 40.744] Initializing built-in extension RANDR
[ 40.744] Initializing built-in extension COMPOSITE
[ 40.744] Initializing built-in extension DAMAGE
[ 40.744] Initializing built-in extension MIT-SCREEN-SAVER
[ 40.744] Initializing built-in extension DOUBLE-BUFFER
[ 40.744] Initializing built-in extension RECORD
[ 40.744] Initializing built-in extension DPMS
[ 40.744] Initializing built-in extension Present
[ 40.744] Initializing built-in extension DRI3
[ 40.744] Initializing built-in extension X-Resource
[ 40.744] Initializing built-in extension XVideo
[ 40.744] Initializing built-in extension XVideo-MotionCompensation
[ 40.744] Initializing built-in extension XFree86-VidModeExtension
[ 40.744] Initializing built-in extension XFree86-DGA
[ 40.744] Initializing built-in extension DRI2
[ 40.744] (II) LoadModule: “glx”
[ 40.744] (II) Loading /usr/lib64/xorg/modules/extensions/libglx.so
[ 40.750] (II) Module glx: vendor=“NVIDIA Corporation”
[ 40.750] compiled for 4.0.2, module version = 1.0.0
[ 40.750] Module class: X.Org Server Extension
[ 40.750] (II) NVIDIA GLX Module 367.27 Thu Jun 9 18:19:55 PDT 2016
[ 40.750] Loading extension GLX
[ 40.750] (==) Matched nvidia as autoconfigured driver 0
[ 40.750] (==) Matched nouveau as autoconfigured driver 1
[ 40.750] (==) Matched nv as autoconfigured driver 2
[ 40.750] (==) Matched modesetting as autoconfigured driver 3
[ 40.750] (==) Matched fbdev as autoconfigured driver 4
[ 40.750] (==) Matched vesa as autoconfigured driver 5
[ 40.750] (==) Assigned the driver to the xf86ConfigLayout
[ 40.750] (II) LoadModule: “nvidia”
[ 40.750] (II) Loading /usr/lib64/xorg/modules/drivers/nvidia_drv.so
[ 40.751] (II) Module nvidia: vendor=“NVIDIA Corporation”
[ 40.751] compiled for 4.0.2, module version = 1.0.0
[ 40.751] Module class: X.Org Video Driver
[ 40.751] (II) LoadModule: “nouveau”
[ 40.751] (WW) Warning, couldn’t open module nouveau
[ 40.751] (II) UnloadModule: “nouveau”
[ 40.751] (II) Unloading nouveau
[ 40.751] (EE) Failed to load module “nouveau” (module does not exist, 0)
[ 40.751] (II) LoadModule: “nv”
[ 40.751] (WW) Warning, couldn’t open module nv
[ 40.751] (II) UnloadModule: “nv”
[ 40.751] (II) Unloading nv
[ 40.751] (EE) Failed to load module “nv” (module does not exist, 0)
[ 40.751] (II) LoadModule: “modesetting”
[ 40.751] (II) Loading /usr/lib64/xorg/modules/drivers/modesetting_drv.so
[ 40.751] (II) Module modesetting: vendor=“X.Org Foundation”
[ 40.751] compiled for 1.15.2, module version = 0.9.0
[ 40.751] ABI class: X.Org Video Driver, version 15.0
[ 40.751] (II) LoadModule: “fbdev”
[ 40.752] (II) Loading /usr/lib64/xorg/modules/drivers/fbdev_drv.so
[ 40.752] (II) Module fbdev: vendor=“X.Org Foundation”
[ 40.752] compiled for 1.15.2, module version = 0.4.4
[ 40.752] Module class: X.Org Video Driver
[ 40.752] ABI class: X.Org Video Driver, version 15.0
[ 40.752] (II) LoadModule: “vesa”
[ 40.752] (II) Loading /usr/lib64/xorg/modules/drivers/vesa_drv.so
[ 40.752] (II) Module vesa: vendor=“X.Org Foundation”
[ 40.752] compiled for 1.15.2, module version = 2.3.3
[ 40.752] (II) NVIDIA dlloader X Driver 367.27 Thu Jun 9 17:57:30 PDT 2016
[ 40.752] (II) NVIDIA Unified Driver for all Supported NVIDIA GPUs
[ 40.752] (II) modesetting: Driver for Modesetting Kernel Drivers: kms
[ 40.752] (II) FBDEV: driver for framebuffer: fbdev
[ 40.752] (II) VESA: driver for VESA chipsets: vesa
[ 40.752] (++) using VT number 7
[ 40.796] (II) Loading sub module “fb”
[ 40.796] (II) LoadModule: “fb”
[ 40.797] (II) Loading /usr/lib64/xorg/modules/libfb.so
[ 40.797] (II) Module fb: vendor=“X.Org Foundation”
[ 40.797] compiled for 1.15.2, module version = 1.0.0
[ 40.797] ABI class: X.Org ANSI C Emulation, version 0.4
[ 40.797] (II) Loading sub module “wfb”
[ 40.797] (II) LoadModule: “wfb”
[ 40.797] (II) Loading /usr/lib64/xorg/modules/libwfb.so
[ 40.797] (II) Module wfb: vendor=“X.Org Foundation”
[ 40.797] (II) Loading sub module “ramdac”
[ 40.797] (II) LoadModule: “ramdac”
[ 40.797] (II) Module “ramdac” already built-in
[ 40.798] (WW) Falling back to old probe method for modesetting
[ 40.798] (EE) open /dev/dri/card0: No such file or directory
[ 40.798] (WW) Falling back to old probe method for fbdev
[ 40.798] (II) Loading sub module “fbdevhw”
[ 40.798] (II) LoadModule: “fbdevhw”
[ 40.798] (II) Loading /usr/lib64/xorg/modules/libfbdevhw.so
[ 40.798] (II) Module fbdevhw: vendor=“X.Org Foundation”
[ 40.798] compiled for 1.15.2, module version = 0.0.2
[ 40.798] ABI class: X.Org Video Driver, version 15.0
[ 40.798] (WW) Falling back to old probe method for vesa
[ 40.798] (II) NVIDIA(0): Creating default Display subsection in Screen section
[ 40.798] (==) NVIDIA(0): Depth 24, (==) framebuffer bpp 32
[ 40.798] (==) NVIDIA(0): RGB weight 888
[ 40.798] (==) NVIDIA(0): Default visual is TrueColor
[ 40.798] (==) NVIDIA(0): Using gamma correction (1.0, 1.0, 1.0)
[ 40.798] (**) NVIDIA(0): Enabling 2D acceleration
[ 41.467] (–) NVIDIA(0): Valid display device(s) on GPU-0 at PCI:3:0:0
[ 41.467] (–) NVIDIA(0): CRT-0
[ 41.467] (–) NVIDIA(0): DFP-0 (boot)
[ 41.467] (–) NVIDIA(0): DFP-1
[ 41.467] (–) NVIDIA(0): DFP-2
[ 41.470] (–) NVIDIA(0): CRT-0: disconnected
[ 41.470] (–) NVIDIA(0): CRT-0: 400.0 MHz maximum pixel clock
[ 41.472] (–) NVIDIA(0): DFP-0: disconnected
[ 41.472] (–) NVIDIA(0): DFP-0: Internal TMDS
[ 41.472] (–) NVIDIA(0): DFP-0: 330.0 MHz maximum pixel clock
[ 41.472] (–) NVIDIA(0): DFP-1: disconnected
[ 41.472] (–) NVIDIA(0): DFP-1: Internal TMDS
[ 41.472] (–) NVIDIA(0): DFP-1: 165.0 MHz maximum pixel clock
[ 41.472] (–) NVIDIA(0): DFP-2: disconnected
[ 41.472] (–) NVIDIA(0): DFP-2: Internal DisplayPort
[ 41.472] (–) NVIDIA(0): DFP-2: 960.0 MHz maximum pixel clock
[ 41.473] (II) NVIDIA(0): NVIDIA GPU Quadro K620 (GM107GL-A) at PCI:3:0:0 (GPU-0)
[ 41.473] (–) NVIDIA(0): Memory: 2097152 kBytes
[ 41.473] (–) NVIDIA(0): VideoBIOS: 82.07.7a.00.03
[ 41.473] (II) NVIDIA(0): Detected PCI Express Link width: 16X
[ 41.473] (EE) NVIDIA(0): Failed to assign any connected display devices to X screen 0.
[ 41.473] (EE) NVIDIA(0): Set AllowEmptyInitialConfiguration if you want the server
[ 41.473] (EE) NVIDIA(0): to start anyway
[ 41.473] (EE) NVIDIA(0): Failing initialization of X screen 0
[ 42.118] (II) UnloadModule: “nvidia”
[ 42.118] (II) UnloadSubModule: “wfb”
[ 42.118] (II) UnloadSubModule: “fb”
[ 42.118] (EE) Screen(s) found, but none have a usable configuration.
[ 42.118] (EE)
Fatal server error:
[ 42.118] (EE) no screens found(EE)
[ 42.118] (EE)
for help.
[ 42.118] (EE) Please also check the log file at “/var/log/Xorg.2.log” for additional information.
[ 42.118] (EE)
[ 42.172] (EE) Server terminated with error (1). Closing log file.
*** /var/log/Xorg.2.log.old
*** ls: -rw-r–r-- 1 root users 24347 2016-07-14 08:29:49.676192144 -0700 /var/log/Xorg.2.log.old
[ 397.354]
[ 397.354] X Protocol Version 11, Revision 0
[ 397.354] Build Operating System: openSUSE SUSE LINUX
[ 397.354] Current Operating System: Linux linux-sr8i 3.12.60-52.54-default #1 SMP Sat Jun 25 06:22:00 UTC 2016 (e55cce6) x86_64
[ 397.354] Kernel command line: BOOT_IMAGE=/boot/vmlinuz-3.12.60-52.54-default root=UUID=8ee93df3-1313-4fee
