Nvidia driver 367.57 ubuntu 16.10 No external display
Dear nvidia,
I have install nvidia driver 367.57 with the ppa from ubuntu but external display doesnt work.
When i open the nvidia software an go to “X server display Configuration” i see X Screen 0 (no Scanout)
Option “X server Xvideo Settings” Currently synced to display: unknown.
When i look at the log of xorg i see the following log:
[   135.144] _XSERVTransSocketUNIXCreateListener: ...SocketCreateListener() failed
[   135.145] _XSERVTransMakeAllCOTSServerListeners: server already running
[   135.145] (--) Log file renamed from "/home/bram/.local/share/xorg/Xorg.pid-2244.log" to "/home/bram/.local/share/xorg/Xorg.1.log"
[   135.145]
X.Org X Server 1.18.4
Release Date: 2016-07-19
[   135.145] X Protocol Version 11, Revision 0
[   135.145] Build Operating System: Linux 3.13.0-95-generic x86_64 Ubuntu
[   135.145] Current Operating System: Linux bizarro 4.8.0-27-generic #29-Ubuntu SMP Thu Oct 20 21:03:13 UTC 2016 x86_64
[   135.145] Kernel command line: BOOT_IMAGE=/boot/vmlinuz-4.8.0-27-generic root=UUID=ffdc838b-d311-42c5-91c0-8361a84e71ee ro quiet splash maxcpus=4 vt.handoff=7
[   135.145] Build Date: 07 September 2016  05:11:52AM
[   135.145] xorg-server 2:1.18.4-1ubuntu6 (For technical support please see http://www.ubuntu.com/support)
[   135.145] Current version of pixman: 0.33.6
[   135.145] 	Before reporting problems, check http://wiki.x.org
	to make sure that you have the latest version.
[   135.145] Markers: (--) probed, (**) from config file, (==) default setting,
	(++) from command line, (!!) notice, (II) informational,
	(WW) warning, (EE) error, (NI) not implemented, (??) unknown.
[   135.145] (==) Log file: "/home/bram/.local/share/xorg/Xorg.1.log", Time: Fri Oct 28 06:29:46 2016
[   135.145] (==) Using config file: "/etc/X11/xorg.conf"
[   135.145] (==) Using system config directory "/usr/share/X11/xorg.conf.d"
[   135.146] (==) ServerLayout "layout"
[   135.146] (**) |-->Screen "nvidia" (0)
[   135.146] (**) |   |-->Monitor "<default monitor>"
[   135.146] (**) |   |-->Device "nvidia"
[   135.146] (**) |   |-->GPUDevice "nvidia"
[   135.146] (==) No monitor specified for screen "nvidia".
	Using a default monitor configuration.
[   135.146] (**) |-->Inactive Device "intel"
[   135.146] (==) Automatically adding devices
[   135.146] (==) Automatically enabling devices
[   135.146] (==) Automatically adding GPU devices
[   135.146] (==) Max clients allowed: 256, resource mask: 0x1fffff
[   135.146] (WW) The directory "/usr/share/fonts/X11/cyrillic" does not exist.
[   135.146] 	Entry deleted from font path.
[   135.146] (WW) The directory "/usr/share/fonts/X11/100dpi/" does not exist.
[   135.146] (WW) The directory "/usr/share/fonts/X11/75dpi/" does not exist.
[   135.146] (WW) The directory "/usr/share/fonts/X11/100dpi" does not exist.
[   135.146] (WW) The directory "/usr/share/fonts/X11/75dpi" does not exist.
[   135.146] (==) FontPath set to:
	/usr/share/fonts/X11/misc,
	/usr/share/fonts/X11/Type1,
	built-ins
[   135.146] (==) ModulePath set to "/usr/lib/x86_64-linux-gnu/xorg/extra-modules,/usr/lib/xorg/extra-modules,/usr/lib/xorg/modules"
[   135.146] (II) The server relies on udev to provide the list of input devices.
	If no devices become available, reconfigure udev or disable AutoAddDevices.
[   135.146] (II) Loader magic: 0x564d7ff2d020
[   135.146] (II) Module ABI versions:
[   135.146] 	X.Org ANSI C Emulation: 0.4
[   135.146] 	X.Org Video Driver: 20.0
[   135.146] 	X.Org XInput driver : 22.1
[   135.146] 	X.Org Server Extension : 9.0
[   135.147] (++) using VT number 2
[   135.148] (II) systemd-logind: took control of session /org/freedesktop/login1/session/_33
[   135.148] (II) xfree86: Adding drm device (/dev/dri/card0)
[   135.148] (II) systemd-logind: got fd for /dev/dri/card0 226:0 fd 10 paused 0
[   135.148] (II) xfree86: Adding drm device (/dev/dri/card1)
[   135.148] (II) systemd-logind: got fd for /dev/dri/card1 226:1 fd 11 paused 0
[   135.149] (--) PCI:*(0:0:2:0) 8086:191b:1558:6a01 rev 6, Mem @ 0x2ffe000000/16777216, 0x60000000/268435456, I/O @ 0x0000f000/64, BIOS @ 0x????????/131072
[   135.149] (--) PCI: (0:1:0:0) 10de:1be1:1558:6a03 rev 161, Mem @ 0xde000000/16777216, 0xc0000000/268435456, 0xd0000000/33554432, I/O @ 0x0000e000/128, BIOS @ 0x????????/524288
[   135.149] (WW) "glamoregl" will not be loaded unless you've specified it to be loaded elsewhere.
[   135.150] (II) "glx" will be loaded by default.
[   135.150] (II) LoadModule: "glx"
[   135.150] (II) Loading /usr/lib/x86_64-linux-gnu/xorg/extra-modules/libglx.so
[   135.152] (II) Module glx: vendor="NVIDIA Corporation"
[   135.152] 	compiled for 4.0.2, module version = 1.0.0
[   135.152] 	Module class: X.Org Server Extension
[   135.152] (II) NVIDIA GLX Module  367.57  Mon Oct  3 20:28:17 PDT 2016
[   135.152] (II) LoadModule: "nvidia"
[   135.152] (II) Loading /usr/lib/x86_64-linux-gnu/xorg/extra-modules/nvidia_drv.so
[   135.152] (II) Module nvidia: vendor="NVIDIA Corporation"
[   135.152] 	Module class: X.Org Video Driver
[   135.152] (II) LoadModule: "modesetting"
[   135.153] (II) Loading /usr/lib/xorg/modules/drivers/modesetting_drv.so
[   135.153] (II) Module modesetting: vendor="X.Org Foundation"
[   135.153] 	compiled for 1.18.4, module version = 1.18.4
[   135.153] 	Module class: X.Org Video Driver
[   135.153] 	ABI class: X.Org Video Driver, version 20.0
[   135.153] (II) NVIDIA dlloader X Driver  367.57  Mon Oct  3 20:03:48 PDT 2016
[   135.153] (II) NVIDIA Unified Driver for all Supported NVIDIA GPUs
[   135.153] (II) modesetting: Driver for Modesetting Kernel Drivers: kms
[   135.153] xf86EnableIOPorts: failed to set IOPL for I/O (Operation not permitted)
[   135.153] (II) systemd-logind: releasing fd for 226:0
[   135.153] (II) Loading sub module "fb"
[   135.153] (II) LoadModule: "fb"
[   135.153] (II) Loading /usr/lib/xorg/modules/libfb.so
[   135.153] (II) Module fb: vendor="X.Org Foundation"
[   135.153] 	compiled for 1.18.4, module version = 1.0.0
[   135.153] 	ABI class: X.Org ANSI C Emulation, version 0.4
[   135.153] (II) Loading sub module "wfb"
[   135.153] (II) LoadModule: "wfb"
[   135.153] (II) Loading /usr/lib/xorg/modules/libwfb.so
[   135.153] (II) Module wfb: vendor="X.Org Foundation"
[   135.153] (II) Loading sub module "ramdac"
[   135.153] (II) LoadModule: "ramdac"
[   135.154] (II) Module "ramdac" already built-in
[   135.154] (II) modeset(G0): using drv /dev/dri/card1
[   135.154] (WW) VGA arbiter: cannot open kernel arbiter, no multi-card support
[   135.154] (II) NVIDIA(0): Creating default Display subsection in Screen section
	"nvidia" for depth/fbbpp 24/32
[   135.154] (==) NVIDIA(0): Depth 24, (==) framebuffer bpp 32
[   135.154] (==) NVIDIA(0): RGB weight 888
[   135.154] (==) NVIDIA(0): Default visual is TrueColor
[   135.154] (==) NVIDIA(0): Using gamma correction (1.0, 1.0, 1.0)
[   135.154] (**) NVIDIA(0): Option "ConstrainCursor" "off"
[   135.154] (**) NVIDIA(0): Option "AllowEmptyInitialConfiguration" "Yes"
[   135.154] (**) NVIDIA(0): Option "RegistryDwords" "PowerMizerEnable=0x1; PerfLevelSrc=0x2222; PowerMizerLevel=0x3; PowerMizerDefault=0x3; PowerMizerDefaultAC=0x2"
[   135.154] (**) NVIDIA(0): Enabling 2D acceleration
[   135.156] (II) NVIDIA(0): NVIDIA GPU GeForce GTX 1070 (GP104-B) at PCI:1:0:0 (GPU-0)
[   135.156] (--) NVIDIA(0): Memory: 8388608 kBytes
[   135.156] (--) NVIDIA(0): VideoBIOS: 86.04.2a.00.11
[   135.156] (II) NVIDIA(0): Detected PCI Express Link width: 16X
[   135.156] (II) NVIDIA(0): Validated MetaModes:
[   135.156] (II) NVIDIA(0):     "NULL"
[   135.156] (II) NVIDIA(0): Virtual screen size determined to be 640 x 480
[   135.156] (WW) NVIDIA(0): Unable to get display device for DPI computation.
[   135.157] (==) NVIDIA(0): DPI set to (75, 75); computed from built-in default
[   135.157] (==) modeset(G0): Depth 24, (==) framebuffer bpp 32
[   135.157] (**) modeset(G0): Option "AccelMethod" "None"
[   135.157] (==) modeset(G0): RGB weight 888
[   135.157] (==) modeset(G0): Default visual is TrueColor
[   135.157] (**) modeset(G0): glamor disabled
[   135.157] (II) modeset(G0): ShadowFB: preferred YES, enabled YES
[   135.158] (II) modeset(G0): Output eDP-1 has no monitor section
[   135.160] (II) modeset(G0): Output DP-1 has no monitor section
[   135.161] (II) modeset(G0): EDID for output eDP-1
[   135.161] (II) modeset(G0): Manufacturer: LGD  Model: 46f  Serial#: 0
[   135.161] (II) modeset(G0): Year: 2014  Week: 0
[   135.161] (II) modeset(G0): EDID Version: 1.4
[   135.161] (II) modeset(G0): Digital Display Input
[   135.161] (II) modeset(G0): 6 bits per channel
[   135.161] (II) modeset(G0): Digital interface is DisplayPort
[   135.161] (II) modeset(G0): Max Image Size [cm]: horiz.: 34  vert.: 19
[   135.161] (II) modeset(G0): Gamma: 2.20
[   135.161] (II) modeset(G0): DPMS capabilities: StandBy Suspend Off
[   135.161] (II) modeset(G0): Supported color encodings: RGB 4:4:4 YCrCb 4:4:4
[   135.161] (II) modeset(G0): First detailed timing is preferred mode
[   135.161] (II) modeset(G0): Preferred mode is native pixel format and refresh rate
[   135.161] (II) modeset(G0): redX: 0.640 redY: 0.345   greenX: 0.335 greenY: 0.625
[   135.161] (II) modeset(G0): blueX: 0.150 blueY: 0.052   whiteX: 0.313 whiteY: 0.329
[   135.161] (II) modeset(G0): Manufacturer's mask: 0
[   135.161] (II) modeset(G0): Supported detailed timing:
[   135.161] (II) modeset(G0): clock: 138.7 MHz   Image Size:  344 x 194 mm
[   135.161] (II) modeset(G0): h_active: 1920  h_sync: 1968  h_sync_end 2000 h_blank_end 2080 h_border: 0
[   135.161] (II) modeset(G0): v_active: 1080  v_sync: 1083  v_sync_end 1088 v_blanking: 1111 v_border: 0
[   135.161] (II) modeset(G0): clock: 110.9 MHz   Image Size:  344 x 194 mm
[   135.161] (II) modeset(G0):  3874Y�156WF6
[   135.161] (II) modeset(G0): Unknown vendor-specific block 0
[   135.161] (II) modeset(G0): EDID (in hex):
[   135.161] (II) modeset(G0): 	00ffffffffffff0030e46f0400000000
[   135.161] (II) modeset(G0): 	0018010495221378eadc95a35855a026
[   135.161] (II) modeset(G0): 	0d505400000001010101010101010101
[   135.161] (II) modeset(G0): 	0101010101012e3680a070381f403020
[   135.161] (II) modeset(G0): 	350058c21000001a522b80a070381f40
[   135.161] (II) modeset(G0): 	3020350058c21000001a000000fe0033
[   135.161] (II) modeset(G0): 	38373459803135365746360a00000000
[   135.161] (II) modeset(G0): 	000041319e001000000a010a20200092
[   135.161] (II) modeset(G0): Printing probed modes for output eDP-1
[   135.161] (II) modeset(G0): Modeline "1920x1080"x60.0  138.70  1920 1968 2000 2080  1080 1083 1088 1111 +hsync -vsync (66.7 kHz eP)
[   135.161] (II) modeset(G0): Modeline "1920x1080"x59.9  138.50  1920 1968 2000 2080  1080 1083 1088 1111 +hsync -vsync (66.6 kHz d)
[   135.161] (II) modeset(G0): Modeline "1920x1080"x48.0  110.90  1920 1968 2000 2080  1080 1083 1088 1111 +hsync -vsync (53.3 kHz e)
[   135.161] (II) modeset(G0): Modeline "1680x1050"x60.0  146.25  1680 1784 1960 2240  1050 1053 1059 1089 -hsync +vsync (65.3 kHz d)
[   135.161] (II) modeset(G0): Modeline "1680x1050"x59.9  119.00  1680 1728 1760 1840  1050 1053 1059 1080 +hsync -vsync (64.7 kHz d)
[   135.161] (II) modeset(G0): Modeline "1600x1024"x60.2  103.12  1600 1600 1656 1664  1024 1024 1029 1030 +hsync +vsync (62.0 kHz d)
[   135.161] (II) modeset(G0): Modeline "1400x1050"x60.0  122.00  1400 1488 1640 1880  1050 1052 1064 1082 +hsync +vsync (64.9 kHz d)
[   135.161] (II) modeset(G0): Modeline "1280x1024"x60.0  108.00  1280 1328 1440 1688  1024 1025 1028 1066 +hsync +vsync (64.0 kHz d)
[   135.161] (II) modeset(G0): Modeline "1440x900"x59.9  106.50  1440 1520 1672 1904  900 903 909 934 -hsync +vsync (55.9 kHz d)
[   135.161] (II) modeset(G0): Modeline "1280x960"x60.0  108.00  1280 1376 1488 1800  960 961 964 1000 +hsync +vsync (60.0 kHz d)
[   135.161] (II) modeset(G0): Modeline "1360x768"x59.8   84.75  1360 1432 1568 1776  768 771 781 798 -hsync +vsync (47.7 kHz d)
[   135.161] (II) modeset(G0): Modeline "1360x768"x60.0   72.00  1360 1408 1440 1520  768 771 781 790 +hsync -vsync (47.4 kHz d)
[   135.162] (II) modeset(G0): Modeline "1152x864"x60.0   81.62  1152 1216 1336 1520  864 865 868 895 -hsync +vsync (53.7 kHz d)
[   135.162] (II) modeset(G0): Modeline "1024x768"x120.1  133.47  1024 1100 1212 1400  768 768 770 794 doublescan -hsync +vsync (95.3 kHz d)
[   135.162] (II) modeset(G0): Modeline "1024x768"x60.0   65.00  1024 1048 1184 1344  768 771 777 806 -hsync -vsync (48.4 kHz d)
[   135.162] (II) modeset(G0): Modeline "960x720"x120.0  117.00  960 1024 1128 1300  720 720 722 750 doublescan -hsync +vsync (90.0 kHz d)
[   135.162] (II) modeset(G0): Modeline "928x696"x120.1  109.15  928 976 1088 1264  696 696 698 719 doublescan -hsync +vsync (86.4 kHz d)
[   135.162] (II) modeset(G0): Modeline "896x672"x120.0  102.40  896 960 1060 1224  672 672 674 697 doublescan -hsync +vsync (83.7 kHz d)
[   135.162] (II) modeset(G0): Modeline "960x600"x120.0   77.00  960 984 1000 1040  600 601 604 617 doublescan +hsync -vsync (74.0 kHz d)
[   135.162] (II) modeset(G0): Modeline "960x540"x120.0   69.25  960 984 1000 1040  540 541 544 555 doublescan +hsync -vsync (66.6 kHz d)
[   135.162] (II) modeset(G0): Modeline "800x600"x120.0   81.00  800 832 928 1080  600 600 602 625 doublescan +hsync +vsync (75.0 kHz d)
[   135.162] (II) modeset(G0): Modeline "800x600"x60.3   40.00  800 840 968 1056  600 601 605 628 +hsync +vsync (37.9 kHz d)
[   135.162] (II) modeset(G0): Modeline "800x600"x56.2   36.00  800 824 896 1024  600 601 603 625 +hsync +vsync (35.2 kHz d)
[   135.162] (II) modeset(G0): Modeline "840x525"x120.0   73.12  840 892 980 1120  525 526 529 544 doublescan -hsync +vsync (65.3 kHz d)
[   135.162] (II) modeset(G0): Modeline "840x525"x119.8   59.50  840 864 880 920  525 526 529 540 doublescan +hsync -vsync (64.7 kHz d)
[   135.162] (II) modeset(G0): Modeline "800x512"x120.3   51.56  800 800 828 832  512 512 514 515 doublescan +hsync +vsync (62.0 kHz d)
[   135.162] (II) modeset(G0): Modeline "700x525"x120.0   61.00  700 744 820 940  525 526 532 541 doublescan +hsync +vsync (64.9 kHz d)
[   135.162] (II) modeset(G0): Modeline "640x512"x120.0   54.00  640 664 720 844  512 512 514 533 doublescan +hsync +vsync (64.0 kHz d)
[   135.162] (II) modeset(G0): Modeline "720x450"x119.8   53.25  720 760 836 952  450 451 454 467 doublescan -hsync +vsync (55.9 kHz d)
[   135.162] (II) modeset(G0): Modeline "640x480"x120.0   54.00  640 688 744 900  480 480 482 500 doublescan +hsync +vsync (60.0 kHz d)
[   135.162] (II) modeset(G0): Modeline "640x480"x59.9   25.18  640 656 752 800  480 490 492 525 -hsync -vsync (31.5 kHz d)
[   135.162] (II) modeset(G0): Modeline "680x384"x119.6   42.38  680 716 784 888  384 385 390 399 doublescan -hsync +vsync (47.7 kHz d)
[   135.162] (II) modeset(G0): Modeline "680x384"x119.9   36.00  680 704 720 760  384 385 390 395 doublescan +hsync -vsync (47.4 kHz d)
[   135.162] (II) modeset(G0): Modeline "576x432"x120.1   40.81  576 608 668 760  432 432 434 447 doublescan -hsync +vsync (53.7 kHz d)
[   135.162] (II) modeset(G0): Modeline "512x384"x120.0   32.50  512 524 592 672  384 385 388 403 doublescan -hsync -vsync (48.4 kHz d)
[   135.162] (II) modeset(G0): Modeline "400x300"x120.6   20.00  400 420 484 528  300 300 302 314 doublescan +hsync +vsync (37.9 kHz d)
[   135.162] (II) modeset(G0): Modeline "400x300"x112.7   18.00  400 412 448 512  300 300 301 312 doublescan +hsync +vsync (35.2 kHz d)
[   135.162] (II) modeset(G0): Modeline "320x240"x120.1   12.59  320 328 376 400  240 245 246 262 doublescan -hsync -vsync (31.5 kHz d)
[   135.164] (II) modeset(G0): EDID for output DP-1
[   135.164] (II) modeset(G0): Using default gamma of (1.0, 1.0, 1.0) unless otherwise stated.
[   135.164] (==) modeset(G0): DPI set to (96, 96)
[   135.164] (II) Loading sub module "fb"
[   135.164] (II) LoadModule: "fb"
[   135.164] (II) Loading /usr/lib/xorg/modules/libfb.so
[   135.164] (II) Module fb: vendor="X.Org Foundation"
[   135.164] 	compiled for 1.18.4, module version = 1.0.0
[   135.164] 	ABI class: X.Org ANSI C Emulation, version 0.4
[   135.164] (II) Loading sub module "shadow"
[   135.164] (II) LoadModule: "shadow"
[   135.164] (II) Loading /usr/lib/xorg/modules/libshadow.so
[   135.164] (II) Module shadow: vendor="X.Org Foundation"
[   135.164] 	compiled for 1.18.4, module version = 1.1.0
[   135.164] (--) Depth 24 pixmap format is 32 bpp
[   135.164] (==) modeset(G0): Backing store enabled
[   135.164] (==) modeset(G0): Silken mouse enabled
[   135.164] (II) modeset(G0): RandR 1.2 enabled, ignore the following RandR disabled message.
[   135.164] (==) modeset(G0): DPMS enabled
[   135.164] (WW) modeset(G0): Option "AllowEmptyInitialConfiguration" is not used
[   135.427] (II) NVIDIA: Using 49152.00 MB of virtual memory for indirect memory
[   135.427] (II) NVIDIA:     access.
[   135.480] (II) NVIDIA(0): Setting mode "NULL"
[   135.485] (==) NVIDIA(0): Disabling shared memory pixmaps
[   135.485] (==) NVIDIA(0): Backing store enabled
[   135.485] (==) NVIDIA(0): Silken mouse enabled
[   135.485] (==) NVIDIA(0): DPMS enabled
[   135.485] (II) Loading sub module "dri2"
[   135.485] (II) LoadModule: "dri2"
[   135.485] (II) Module "dri2" already built-in
[   135.485] (II) NVIDIA(0): [DRI2] Setup complete
[   135.485] (II) NVIDIA(0): [DRI2]   VDPAU driver: nvidia
[   135.485] (--) RandR disabled
[   135.488] (II) SELinux: Disabled on system
[   135.488] (II) Initializing extension GLX
[   135.488] (II) Indirect GLX disabled.
[   135.489] (II) modeset(G0): Damage tracking initialized
[   135.511] (II) config/udev: Adding input device Power Button (/dev/input/event3)
[   135.511] (**) Power Button: Applying InputClass "evdev keyboard catchall"
[   135.511] (**) Power Button: Applying InputClass "libinput keyboard catchall"
[   135.511] (II) LoadModule: "libinput"
[   135.511] (II) Loading /usr/lib/xorg/modules/input/libinput_drv.so
[   135.512] (II) Module libinput: vendor="X.Org Foundation"
[   135.512] 	compiled for 1.18.3, module version = 0.19.0
[   135.512] 	Module class: X.Org XInput Driver
[   135.512] 	ABI class: X.Org XInput driver, version 22.1
[   135.512] (II) systemd-logind: got fd for /dev/input/event3 13:67 fd 28 paused 0
[   135.512] (II) Using input driver 'libinput' for 'Power Button'
[   135.512] (**) Power Button: always reports core events
[   135.512] (**) Option "Device" "/dev/input/event3"
[   135.512] (**) Option "_source" "server/udev"
[   135.512] (II) input device 'Power Button', /dev/input/event3 is tagged by udev as: Keyboard
[   135.512] (II) input device 'Power Button', /dev/input/event3 is a keyboard
[   135.512] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXPWRBN:00/input/input3/event3"
[   135.512] (II) XINPUT: Adding extended input device "Power Button" (type: KEYBOARD, id 6)
[   135.512] (**) Option "xkb_model" "pc105"
[   135.512] (**) Option "xkb_layout" "us"
[   135.512] (**) Option "xkb_variant" "intl"
[   135.523] (II) input device 'Power Button', /dev/input/event3 is tagged by udev as: Keyboard
[   135.523] (II) input device 'Power Button', /dev/input/event3 is a keyboard
[   135.523] (II) config/udev: Adding input device Video Bus (/dev/input/event5)
[   135.524] (**) Video Bus: Applying InputClass "evdev keyboard catchall"
[   135.524] (**) Video Bus: Applying InputClass "libinput keyboard catchall"
[   135.524] (II) systemd-logind: got fd for /dev/input/event5 13:69 fd 31 paused 0
[   135.524] (II) Using input driver 'libinput' for 'Video Bus'
[   135.524] (**) Video Bus: always reports core events
[   135.524] (**) Option "Device" "/dev/input/event5"
[   135.524] (**) Option "_source" "server/udev"
[   135.524] (II) input device 'Video Bus', /dev/input/event5 is tagged by udev as: Keyboard
[   135.524] (II) input device 'Video Bus', /dev/input/event5 is a keyboard
[   135.524] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/LNXVIDEO:00/input/input10/event5"
[   135.524] (II) XINPUT: Adding extended input device "Video Bus" (type: KEYBOARD, id 7)
[   135.524] (**) Option "xkb_model" "pc105"
[   135.524] (**) Option "xkb_layout" "us"
[   135.524] (**) Option "xkb_variant" "intl"
[   135.525] (II) input device 'Video Bus', /dev/input/event5 is tagged by udev as: Keyboard
[   135.525] (II) input device 'Video Bus', /dev/input/event5 is a keyboard
[   135.525] (II) config/udev: Adding input device Video Bus (/dev/input/event6)
[   135.525] (**) Video Bus: Applying InputClass "evdev keyboard catchall"
[   135.525] (**) Video Bus: Applying InputClass "libinput keyboard catchall"
[   135.525] (II) systemd-logind: got fd for /dev/input/event6 13:70 fd 32 paused 0
[   135.525] (II) Using input driver 'libinput' for 'Video Bus'
[   135.525] (**) Video Bus: always reports core events
[   135.525] (**) Option "Device" "/dev/input/event6"
[   135.525] (**) Option "_source" "server/udev"
[   135.525] (II) input device 'Video Bus', /dev/input/event6 is tagged by udev as: Keyboard
[   135.525] (II) input device 'Video Bus', /dev/input/event6 is a keyboard
[   135.525] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/device:11/LNXVIDEO:01/input/input11/event6"
[   135.525] (II) XINPUT: Adding extended input device "Video Bus" (type: KEYBOARD, id 8)
[   135.525] (**) Option "xkb_model" "pc105"
[   135.525] (**) Option "xkb_layout" "us"
[   135.525] (**) Option "xkb_variant" "intl"
[   135.526] (II) input device 'Video Bus', /dev/input/event6 is tagged by udev as: Keyboard
[   135.526] (II) input device 'Video Bus', /dev/input/event6 is a keyboard
[   135.526] (II) config/udev: Adding input device Power Button (/dev/input/event0)
[   135.526] (**) Power Button: Applying InputClass "evdev keyboard catchall"
[   135.526] (**) Power Button: Applying InputClass "libinput keyboard catchall"
[   135.526] (II) systemd-logind: got fd for /dev/input/event0 13:64 fd 33 paused 0
[   135.526] (II) Using input driver 'libinput' for 'Power Button'
[   135.526] (**) Power Button: always reports core events
[   135.526] (**) Option "Device" "/dev/input/event0"
[   135.526] (**) Option "_source" "server/udev"
[   135.526] (II) input device 'Power Button', /dev/input/event0 is tagged by udev as: Keyboard
[   135.526] (II) input device 'Power Button', /dev/input/event0 is a keyboard
[   135.526] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0C:00/input/input0/event0"
[   135.526] (II) XINPUT: Adding extended input device "Power Button" (type: KEYBOARD, id 9)
[   135.526] (**) Option "xkb_model" "pc105"
[   135.526] (**) Option "xkb_layout" "us"
[   135.527] (**) Option "xkb_variant" "intl"
[   135.527] (II) input device 'Power Button', /dev/input/event0 is tagged by udev as: Keyboard
[   135.527] (II) input device 'Power Button', /dev/input/event0 is a keyboard
[   135.527] (II) config/udev: Adding input device Lid Switch (/dev/input/event2)
[   135.527] (II) No input driver specified, ignoring this device.
[   135.527] (II) This device may have been added with another device file.
[   135.527] (II) config/udev: Adding input device Sleep Button (/dev/input/event1)
[   135.527] (**) Sleep Button: Applying InputClass "evdev keyboard catchall"
[   135.527] (**) Sleep Button: Applying InputClass "libinput keyboard catchall"
[   135.527] (II) systemd-logind: got fd for /dev/input/event1 13:65 fd 34 paused 0
[   135.527] (II) Using input driver 'libinput' for 'Sleep Button'
[   135.527] (**) Sleep Button: always reports core events
[   135.527] (**) Option "Device" "/dev/input/event1"
[   135.527] (**) Option "_source" "server/udev"
[   135.528] (II) input device 'Sleep Button', /dev/input/event1 is tagged by udev as: Keyboard
[   135.528] (II) input device 'Sleep Button', /dev/input/event1 is a keyboard
[   135.528] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0E:00/input/input1/event1"
[   135.528] (II) XINPUT: Adding extended input device "Sleep Button" (type: KEYBOARD, id 10)
[   135.528] (**) Option "xkb_model" "pc105"
[   135.528] (**) Option "xkb_layout" "us"
[   135.528] (**) Option "xkb_variant" "intl"
[   135.529] (II) config/udev: Adding input device Logitech USB Keyboard (/dev/input/event7)
[   135.529] (**) Logitech USB Keyboard: Applying InputClass "evdev keyboard catchall"
[   135.529] (**) Logitech USB Keyboard: Applying InputClass "libinput keyboard catchall"
[   135.529] (II) systemd-logind: got fd for /dev/input/event7 13:71 fd 35 paused 0
[   135.529] (II) Using input driver 'libinput' for 'Logitech USB Keyboard'
[   135.529] (**) Logitech USB Keyboard: always reports core events
[   135.529] (**) Option "Device" "/dev/input/event7"
[   135.529] (**) Option "_source" "server/udev"
[   135.529] (II) input device 'Logitech USB Keyboard', /dev/input/event7 is tagged by udev as: Keyboard
[   135.529] (II) input device 'Logitech USB Keyboard', /dev/input/event7 is a keyboard
[   135.529] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:14.0/usb1/1-5/1-5.5/1-5.5:1.0/0003:046D:C31C.0001/input/input13/event7"
[   135.529] (II) XINPUT: Adding extended input device "Logitech USB Keyboard" (type: KEYBOARD, id 11)
[   135.529] (**) Option "xkb_model" "pc105"
[   135.529] (**) Option "xkb_layout" "us"
[   135.529] (**) Option "xkb_variant" "intl"
[   135.530] (II) input device 'Logitech USB Keyboard', /dev/input/event7 is tagged by udev as: Keyboard
[   135.530] (II) input device 'Logitech USB Keyboard', /dev/input/event7 is a keyboard
[   135.530] (II) config/udev: Adding input device Logitech USB Keyboard (/dev/input/event8)
[   135.530] (**) Logitech USB Keyboard: Applying InputClass "evdev keyboard catchall"
[   135.530] (**) Logitech USB Keyboard: Applying InputClass "libinput keyboard catchall"
[   135.530] (II) systemd-logind: got fd for /dev/input/event8 13:72 fd 36 paused 0
[   135.530] (II) Using input driver 'libinput' for 'Logitech USB Keyboard'
[   135.530] (**) Logitech USB Keyboard: always reports core events
[   135.530] (**) Option "Device" "/dev/input/event8"
[   135.530] (**) Option "_source" "server/udev"
[   135.531] (II) input device 'Logitech USB Keyboard', /dev/input/event8 is tagged by udev as: Keyboard
[   135.531] (II) input device 'Logitech USB Keyboard', /dev/input/event8 is a keyboard
[   135.531] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:14.0/usb1/1-5/1-5.5/1-5.5:1.1/0003:046D:C31C.0002/input/input14/event8"
[   135.531] (II) XINPUT: Adding extended input device "Logitech USB Keyboard" (type: KEYBOARD, id 12)
[   135.531] (**) Option "xkb_model" "pc105"
[   135.531] (**) Option "xkb_layout" "us"
[   135.531] (**) Option "xkb_variant" "intl"
[   135.531] (II) config/udev: Adding input device Logitech M705 (/dev/input/event10)
[   135.531] (**) Logitech M705: Applying InputClass "evdev pointer catchall"
[   135.531] (**) Logitech M705: Applying InputClass "libinput pointer catchall"
[   135.532] (II) systemd-logind: got fd for /dev/input/event10 13:74 fd 37 paused 0
[   135.532] (II) Using input driver 'libinput' for 'Logitech M705'
[   135.532] (**) Logitech M705: always reports core events
[   135.532] (**) Option "Device" "/dev/input/event10"
[   135.532] (**) Option "_source" "server/udev"
[   135.532] (II) input device 'Logitech M705', /dev/input/event10 is tagged by udev as: Mouse
[   135.532] (II) Device 'Logitech M705' set to 800 DPI
[   135.532] (II) input device 'Logitech M705', /dev/input/event10 is a pointer caps
[   135.532] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:14.0/usb1/1-5/1-5.6/1-5.6:1.2/0003:046D:C52B.0005/0003:046D:101B.0006/input/input17/event10"
[   135.532] (II) XINPUT: Adding extended input device "Logitech M705" (type: MOUSE, id 13)
[   135.532] (**) Option "AccelerationScheme" "none"
[   135.532] (**) Logitech M705: (accel) selected scheme none/0
[   135.532] (**) Logitech M705: (accel) acceleration factor: 2.000
[   135.532] (**) Logitech M705: (accel) acceleration threshold: 4
[   135.533] (II) config/udev: Adding input device Logitech M705 (/dev/input/mouse1)
[   135.533] (II) No input driver specified, ignoring this device.
[   135.533] (II) This device may have been added with another device file.
[   135.533] (II) config/udev: Adding input device Logitech M705 (/dev/input/event11)
[   135.533] (**) Logitech M705: Applying InputClass "evdev pointer catchall"
[   135.533] (**) Logitech M705: Applying InputClass "libinput pointer catchall"
[   135.533] (II) systemd-logind: got fd for /dev/input/event11 13:75 fd 38 paused 0
[   135.533] (II) Using input driver 'libinput' for 'Logitech M705'
[   135.533] (**) Logitech M705: always reports core events
[   135.533] (**) Option "Device" "/dev/input/event11"
[   135.533] (**) Option "_source" "server/udev"
[   135.534] (II) input device 'Logitech M705', /dev/input/event11 is tagged by udev as: Mouse
[   135.534] (II) Device 'Logitech M705' set to 800 DPI
[   135.534] (II) input device 'Logitech M705', /dev/input/event11 is a pointer caps
[   135.534] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:14.0/usb1/1-5/1-5.6/1-5.6:1.2/0003:046D:C52B.0005/0003:046D:101B.0008/input/input18/event11"
[   135.534] (II) XINPUT: Adding extended input device "Logitech M705" (type: MOUSE, id 14)
[   135.534] (**) Option "AccelerationScheme" "none"
[   135.534] (**) Logitech M705: (accel) selected scheme none/0
[   135.534] (**) Logitech M705: (accel) acceleration factor: 2.000
[   135.534] (**) Logitech M705: (accel) acceleration threshold: 4
[   135.534] (II) config/udev: Adding input device Logitech M705 (/dev/input/mouse2)
[   135.534] (II) No input driver specified, ignoring this device.
[   135.534] (II) This device may have been added with another device file.
[   135.535] (II) config/udev: Adding input device Chicony USB 2.0 Camera (/dev/input/event12)
[   135.535] (**) Chicony USB 2.0 Camera: Applying InputClass "evdev keyboard catchall"
[   135.535] (**) Chicony USB 2.0 Camera: Applying InputClass "libinput keyboard catchall"
[   135.535] (II) systemd-logind: got fd for /dev/input/event12 13:76 fd 39 paused 0
[   135.535] (II) Using input driver 'libinput' for 'Chicony USB 2.0 Camera'
[   135.535] (**) Chicony USB 2.0 Camera: always reports core events
[   135.535] (**) Option "Device" "/dev/input/event12"
[   135.535] (**) Option "_source" "server/udev"
[   135.535] (II) input device 'Chicony USB 2.0 Camera', /dev/input/event12 is tagged by udev as: Keyboard
[   135.535] (II) input device 'Chicony USB 2.0 Camera', /dev/input/event12 is a keyboard
[   135.535] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:14.0/usb1/1-9/1-9:1.0/input/input19/event12"
[   135.535] (II) XINPUT: Adding extended input device "Chicony USB 2.0 Camera" (type: KEYBOARD, id 15)
[   135.535] (**) Option "xkb_model" "pc105"
[   135.535] (**) Option "xkb_layout" "us"
[   135.535] (**) Option "xkb_variant" "intl"
[   135.536] (II) input device 'Chicony USB 2.0 Camera', /dev/input/event12 is tagged by udev as: Keyboard
[   135.536] (II) input device 'Chicony USB 2.0 Camera', /dev/input/event12 is a keyboard
[   135.536] (II) config/udev: Adding input device HDA Intel PCH Mic (/dev/input/event13)
[   135.536] (II) No input driver specified, ignoring this device.
[   135.536] (II) This device may have been added with another device file.
[   135.536] (II) config/udev: Adding input device HDA Intel PCH Line Out (/dev/input/event14)
[   135.536] (II) config/udev: Adding input device HDA Intel PCH HDMI/DP,pcm=3 (/dev/input/event15)
[   135.536] (II) config/udev: Adding input device HDA Intel PCH HDMI/DP,pcm=7 (/dev/input/event16)
[   135.537] (II) config/udev: Adding input device HDA Intel PCH HDMI/DP,pcm=8 (/dev/input/event17)
[   135.537] (II) No input driver specified, ignoring this device.
[   135.537] (II) This device may have been added with another device file.
[   135.537] (II) config/udev: Adding input device AT Translated Set 2 keyboard (/dev/input/event4)
[   135.537] (**) AT Translated Set 2 keyboard: Applying InputClass "evdev keyboard catchall"
[   135.537] (**) AT Translated Set 2 keyboard: Applying InputClass "libinput keyboard catchall"
[   135.537] (II) systemd-logind: got fd for /dev/input/event4 13:68 fd 40 paused 0
[   135.537] (II) Using input driver 'libinput' for 'AT Translated Set 2 keyboard'
[   135.537] (**) AT Translated Set 2 keyboard: always reports core events
[   135.537] (**) Option "Device" "/dev/input/event4"
[   135.537] (**) Option "_source" "server/udev"
[   135.537] (II) input device 'AT Translated Set 2 keyboard', /dev/input/event4 is tagged by udev as: Keyboard
[   135.537] (II) input device 'AT Translated Set 2 keyboard', /dev/input/event4 is a keyboard
[   135.537] (**) Option "config_info" "udev:/sys/devices/platform/i8042/serio0/input/input4/event4"
[   135.537] (II) XINPUT: Adding extended input device "AT Translated Set 2 keyboard" (type: KEYBOARD, id 16)
[   135.537] (**) Option "xkb_model" "pc105"
[   135.537] (**) Option "xkb_layout" "us"
[   135.537] (**) Option "xkb_variant" "intl"
[   135.538] (II) input device 'AT Translated Set 2 keyboard', /dev/input/event4 is tagged by udev as: Keyboard
[   135.538] (II) input device 'AT Translated Set 2 keyboard', /dev/input/event4 is a keyboard
[   135.538] (II) config/udev: Adding input device SynPS/2 Synaptics TouchPad (/dev/input/event9)
[   135.538] (**) SynPS/2 Synaptics TouchPad: Applying InputClass "evdev touchpad catchall"
[   135.538] (**) SynPS/2 Synaptics TouchPad: Applying InputClass "touchpad catchall"
[   135.538] (**) SynPS/2 Synaptics TouchPad: Applying InputClass "Default clickpad buttons"
[   135.538] (**) SynPS/2 Synaptics TouchPad: Applying InputClass "libinput touchpad catchall"
[   135.538] (II) systemd-logind: got fd for /dev/input/event9 13:73 fd 41 paused 0
[   135.538] (II) Using input driver 'libinput' for 'SynPS/2 Synaptics TouchPad'
[   135.538] (**) SynPS/2 Synaptics TouchPad: always reports core events
[   135.538] (**) Option "Device" "/dev/input/event9"
[   135.538] (**) Option "_source" "server/udev"
[   135.538] (II) input device 'SynPS/2 Synaptics TouchPad', /dev/input/event9 is tagged by udev as: Touchpad
[   135.538] (II) input device 'SynPS/2 Synaptics TouchPad', /dev/input/event9 is a touchpad
[   135.538] (**) Option "config_info" "udev:/sys/devices/platform/i8042/serio2/input/input12/event9"
[   135.538] (II) XINPUT: Adding extended input device "SynPS/2 Synaptics TouchPad" (type: TOUCHPAD, id 17)
[   135.539] (**) Option "AccelerationScheme" "none"
[   135.539] (**) SynPS/2 Synaptics TouchPad: (accel) selected scheme none/0
[   135.539] (**) SynPS/2 Synaptics TouchPad: (accel) acceleration factor: 2.000
[   135.539] (**) SynPS/2 Synaptics TouchPad: (accel) acceleration threshold: 4
[   135.539] (II) input device 'SynPS/2 Synaptics TouchPad', /dev/input/event9 is tagged by udev as: Touchpad
[   135.539] (II) input device 'SynPS/2 Synaptics TouchPad', /dev/input/event9 is a touchpad
[   135.539] (II) config/udev: Adding input device SynPS/2 Synaptics TouchPad (/dev/input/mouse0)
[   135.539] (**) SynPS/2 Synaptics TouchPad: Ignoring device from InputClass "touchpad ignore duplicates"
When i query for external connectors i dont find anything.
xrandr -q
Screen 0: minimum 8 x 8, current 1920 x 1080, maximum 32767 x 32767
eDP-1 connected primary 1920x1080+0+0 344mm x 194mm
   1920x1080     60.02*+  59.93    47.99
   1680x1050     59.95    59.88
   1600x1024     60.17
   1400x1050     59.98
   1280x1024     60.02
   1440x900      59.89
   1280x960      60.00
   1360x768      59.80    59.96
   1152x864      60.00
   1024x768      60.04    60.00
   960x720       60.00
   928x696       60.05
   896x672       60.01
   960x600       60.00
   960x540       59.99
   800x600       60.00    60.32    56.25
   840x525       60.01    59.88
   800x512       60.17
   700x525       59.98
   640x512       60.02
   720x450       59.89
   640x480       60.00    59.94
   680x384       59.80    59.96
   576x432       60.06
   512x384       60.00
   400x300       60.32    56.34
   320x240       60.05
DP-1 disconnected
Judging by your description and the log, it sounds like this is a laptop.
Could you please post the nvidia-bug-report.log.gz, generated as described here: If you have a problem, PLEASE read this first - Linux - NVIDIA Developer Forums ? It could help with some of the guesswork.
It’s possible that your laptop is one of the few where the external display is hooked up to the dGPU (like a desktop), and the internal display is hooked up to the iGPU (typical Optimus configuration). If that’s the case, you should upgrade to the 375.10 beta (https://devtalk.nvidia.com/default/topic/972585), because it fixes some major issues with those configurations.
Moreover, nvidia-settings currently has known issues with configuring displays on PRIME setups, such as with Optimus laptops. Try using an RandR-based tool, such as xrandr.
A quick test could be to simply run ‘xrandr --auto’ with everything connected. If it’s working, the external display should turn on, but should overlap the same region as the internal display. You can then try more complicated setups with xrandr, or with a graphical tool such as the Display tool included with your DE, or a generic graphical tool like ARandR.
Thanks,
Thanks for your post. I have create a nvidia debug log. You can find it here: https://ufile.io/44318
i have changed the username and laptop name
I have udpated to 375 trough ubuntu PPA but i still have the same problem. Trough xrander i cannot enable the second screen.
xrandr --listproviders
Providers: number : 3
Provider 0: id: 0x204 cap: 0x1, Source Output crtcs: 0 outputs: 0 associated providers: 1 name:NVIDIA-0
Provider 1: id: 0x44 cap: 0x2, Sink Output crtcs: 3 outputs: 2 associated providers: 1 name:modesetting
Provider 2: id: 0x44 cap: 0x2, Sink Output crtcs: 3 outputs: 2 associated providers: 1 name:modesetting
xrandr -q
eDP-1-1 connected primary 1920x1080+0+0 344mm x 194mm
1600x1024 60.17
1400x1050 59.98
1280x1024 60.02
1440x900 59.89
1280x960 60.00
1152x864 60.00
960x720 60.00
928x696 60.05
896x672 60.01
960x600 60.00
960x540 59.99
840x525 60.01 59.88
800x512 60.17
700x525 59.98
640x512 60.02
720x450 59.89
640x480 60.00 59.94
680x384 59.80 59.96
576x432 60.06
512x384 60.00
400x300 60.32 56.34
320x240 60.05
DP-1-1 disconnected
[/[    37.837] _XSERVTransSocketUNIXCreateListener: ...SocketCreateListener() failed
[    37.837] _XSERVTransMakeAllCOTSServerListeners: server already running
[    37.838] (--) Log file renamed from "/home/bram/.local/share/xorg/Xorg.pid-2309.log" to "/home/bram/.local/share/xorg/Xorg.1.log"
[    37.838]
[    37.838] X Protocol Version 11, Revision 0
[    37.838] Build Operating System: Linux 4.4.0-45-generic x86_64 Ubuntu
[    37.839] Current Operating System: Linux bizarro 4.8.0-28-generic #30-Ubuntu SMP Fri Nov 11 14:03:52 UTC 2016 x86_64
[    37.839] Kernel command line: BOOT_IMAGE=/boot/vmlinuz-4.8.0-28-generic root=UUID=ffdc838b-d311-42c5-91c0-8361a84e71ee ro quiet splash maxcpus=4 vt.handoff=7
[    37.839] Build Date: 02 November 2016  10:06:55PM
[    37.839] xorg-server 2:1.18.4-1ubuntu6.1 (For technical support please see http://www.ubuntu.com/support)
[    37.839] Current version of pixman: 0.33.6
[    37.839] 	Before reporting problems, check http://wiki.x.org
[    37.839] Markers: (--) probed, (**) from config file, (==) default setting,
[    37.839] (==) Log file: "/home/bram/.local/share/xorg/Xorg.1.log", Time: Mon Nov 21 09:19:18 2016
[    37.839] (==) Using config file: "/etc/X11/xorg.conf"
[    37.839] (==) Using system config directory "/usr/share/X11/xorg.conf.d"
[    37.839] (==) ServerLayout "layout"
[    37.839] (**) |-->Screen "nvidia" (0)
[    37.839] (**) |   |-->Monitor "<default monitor>"
[    37.839] (**) |   |-->Device "nvidia"
[    37.839] (**) |   |-->GPUDevice "nvidia"
[    37.839] (==) No monitor specified for screen "nvidia".
[    37.839] (**) |-->Inactive Device "intel"
[    37.839] (==) Automatically adding devices
[    37.839] (==) Automatically enabling devices
[    37.839] (==) Automatically adding GPU devices
[    37.839] (==) Max clients allowed: 256, resource mask: 0x1fffff
[    37.839] (WW) The directory "/usr/share/fonts/X11/cyrillic" does not exist.
[    37.839] 	Entry deleted from font path.
[    37.839] (WW) The directory "/usr/share/fonts/X11/100dpi/" does not exist.
[    37.839] (WW) The directory "/usr/share/fonts/X11/75dpi/" does not exist.
[    37.839] (WW) The directory "/usr/share/fonts/X11/100dpi" does not exist.
[    37.839] (WW) The directory "/usr/share/fonts/X11/75dpi" does not exist.
[    37.839] (==) FontPath set to:
	built-ins
[    37.839] (==) ModulePath set to "/usr/lib/x86_64-linux-gnu/xorg/extra-modules,/usr/lib/xorg/extra-modules,/usr/lib/xorg/modules"
[    37.839] (II) The server relies on udev to provide the list of input devices.
[    37.839] (II) Loader magic: 0x564b88993020
[    37.839] (II) Module ABI versions:
[    37.839] 	X.Org ANSI C Emulation: 0.4
[    37.839] 	X.Org Video Driver: 20.0
[    37.839] 	X.Org XInput driver : 22.1
[    37.839] 	X.Org Server Extension : 9.0
[    37.842] (++) using VT number 2
[    37.843] (II) systemd-logind: took control of session /org/freedesktop/login1/session/_33
[    37.844] (II) xfree86: Adding drm device (/dev/dri/card0)
[    37.845] (II) systemd-logind: got fd for /dev/dri/card0 226:0 fd 10 paused 0
[    37.845] (II) xfree86: Adding drm device (/dev/dri/card1)
[    37.845] (II) systemd-logind: got fd for /dev/dri/card1 226:1 fd 11 paused 0
[    37.846] (--) PCI:*(0:0:2:0) 8086:191b:1558:6a01 rev 6, Mem @ 0x2ffe000000/16777216, 0x60000000/268435456, I/O @ 0x0000f000/64, BIOS @ 0x????????/131072
[    37.846] (--) PCI: (0:1:0:0) 10de:1be1:1558:6a03 rev 161, Mem @ 0xde000000/16777216, 0xc0000000/268435456, 0xd0000000/33554432, I/O @ 0x0000e000/128, BIOS @ 0x????????/524288
[    37.846] (WW) "glamoregl" will not be loaded unless you've specified it to be loaded elsewhere.
[    37.846] (II) "glx" will be loaded by default.
[    37.846] (II) LoadModule: "glx"
[    37.847] (II) Loading /usr/lib/x86_64-linux-gnu/xorg/extra-modules/libglx.so
[    37.849] (II) Module glx: vendor="NVIDIA Corporation"
[    37.849] 	compiled for 4.0.2, module version = 1.0.0
[    37.849] 	Module class: X.Org Server Extension
[    37.849] (II) NVIDIA GLX Module  375.20  Tue Nov 15 16:38:52 PST 2016
[    37.849] (II) LoadModule: "nvidia"
[    37.849] (II) Loading /usr/lib/x86_64-linux-gnu/xorg/extra-modules/nvidia_drv.so
[    37.849] (II) Module nvidia: vendor="NVIDIA Corporation"
[    37.849] 	Module class: X.Org Video Driver
[    37.849] (II) LoadModule: "modesetting"
[    37.849] (II) Loading /usr/lib/xorg/modules/drivers/modesetting_drv.so
[    37.849] (II) Module modesetting: vendor="X.Org Foundation"
[    37.849] 	compiled for 1.18.4, module version = 1.18.4
[    37.849] 	ABI class: X.Org Video Driver, version 20.0
[    37.849] (II) NVIDIA dlloader X Driver  375.20  Tue Nov 15 16:15:23 PST 2016
[    37.849] (II) NVIDIA Unified Driver for all Supported NVIDIA GPUs
[    37.849] (II) modesetting: Driver for Modesetting Kernel Drivers: kms
[    37.850] xf86EnableIOPorts: failed to set IOPL for I/O (Operation not permitted)
[    37.850] (II) systemd-logind: releasing fd for 226:0
[    37.850] (II) Loading sub module "fb"
[    37.850] (II) LoadModule: "fb"
[    37.850] (II) Loading /usr/lib/xorg/modules/libfb.so
[    37.850] (II) Module fb: vendor="X.Org Foundation"
[    37.850] 	compiled for 1.18.4, module version = 1.0.0
[    37.850] 	ABI class: X.Org ANSI C Emulation, version 0.4
[    37.850] (II) Loading sub module "wfb"
[    37.850] (II) LoadModule: "wfb"
[    37.850] (II) Loading /usr/lib/xorg/modules/libwfb.so
[    37.850] (II) Module wfb: vendor="X.Org Foundation"
[    37.850] (II) Loading sub module "ramdac"
[    37.850] (II) LoadModule: "ramdac"
[    37.850] (II) Module "ramdac" already built-in
[    37.851] (II) modeset(G0): using drv /dev/dri/card1
[    37.851] (WW) VGA arbiter: cannot open kernel arbiter, no multi-card support
[    37.851] (II) NVIDIA(0): Creating default Display subsection in Screen section
[    37.851] (==) NVIDIA(0): Depth 24, (==) framebuffer bpp 32
[    37.851] (==) NVIDIA(0): RGB weight 888
[    37.851] (==) NVIDIA(0): Default visual is TrueColor
[    37.851] (==) NVIDIA(0): Using gamma correction (1.0, 1.0, 1.0)
[    37.851] (**) NVIDIA(0): Option "ConstrainCursor" "off"
[    37.851] (**) NVIDIA(0): Option "AllowEmptyInitialConfiguration" "Yes"
[    37.851] (**) NVIDIA(0): Option "RegistryDwords" "PowerMizerEnable=0x1; PerfLevelSrc=0x2222; PowerMizerLevel=0x3; PowerMizerDefault=0x3; PowerMizerDefaultAC=0x2"
[    37.851] (**) NVIDIA(0): Enabling 2D acceleration
[    37.853] (II) NVIDIA(0): NVIDIA GPU GeForce GTX 1070 (GP104-B) at PCI:1:0:0 (GPU-0)
[    37.853] (--) NVIDIA(0): Memory: 8388608 kBytes
[    37.853] (--) NVIDIA(0): VideoBIOS: 86.04.2a.00.11
[    37.853] (II) NVIDIA(0): Detected PCI Express Link width: 16X
[    37.853] (II) NVIDIA(0): Validated MetaModes:
[    37.853] (II) NVIDIA(0):     "NULL"
[    37.853] (II) NVIDIA(0): Virtual screen size determined to be 640 x 480
[    37.853] (WW) NVIDIA(0): Unable to get display device for DPI computation.
[    37.853] (==) NVIDIA(0): DPI set to (75, 75); computed from built-in default
[    37.853] (==) modeset(G0): Depth 24, (==) framebuffer bpp 32
[    37.853] (**) modeset(G0): Option "AccelMethod" "None"
[    37.853] (==) modeset(G0): RGB weight 888
[    37.853] (==) modeset(G0): Default visual is TrueColor
[    37.853] (**) modeset(G0): glamor disabled
[    37.853] (II) modeset(G0): ShadowFB: preferred YES, enabled YES
[    37.855] (II) modeset(G0): Output eDP-1-1 has no monitor section
[    37.857] (II) modeset(G0): Output DP-1-1 has no monitor section
[    37.858] (II) modeset(G0): EDID for output eDP-1-1
[    37.858] (II) modeset(G0): Manufacturer: LGD  Model: 46f  Serial#: 0
[    37.858] (II) modeset(G0): Year: 2014  Week: 0
[    37.858] (II) modeset(G0): EDID Version: 1.4
[    37.858] (II) modeset(G0): Digital Display Input
[    37.858] (II) modeset(G0): 6 bits per channel
[    37.858] (II) modeset(G0): Digital interface is DisplayPort
[    37.858] (II) modeset(G0): Max Image Size [cm]: horiz.: 34  vert.: 19
[    37.858] (II) modeset(G0): Gamma: 2.20
[    37.858] (II) modeset(G0): DPMS capabilities: StandBy Suspend Off
[    37.858] (II) modeset(G0): Supported color encodings: RGB 4:4:4 YCrCb 4:4:4
[    37.858] (II) modeset(G0): First detailed timing is preferred mode
[    37.858] (II) modeset(G0): Preferred mode is native pixel format and refresh rate
[    37.858] (II) modeset(G0): redX: 0.640 redY: 0.345   greenX: 0.335 greenY: 0.625
[    37.858] (II) modeset(G0): blueX: 0.150 blueY: 0.052   whiteX: 0.313 whiteY: 0.329
[    37.858] (II) modeset(G0): Manufacturer's mask: 0
[    37.858] (II) modeset(G0): Supported detailed timing:
[    37.858] (II) modeset(G0): clock: 138.7 MHz   Image Size:  344 x 194 mm
[    37.858] (II) modeset(G0): h_active: 1920  h_sync: 1968  h_sync_end 2000 h_blank_end 2080 h_border: 0
[    37.858] (II) modeset(G0): v_active: 1080  v_sync: 1083  v_sync_end 1088 v_blanking: 1111 v_border: 0
[    37.858] (II) modeset(G0): clock: 110.9 MHz   Image Size:  344 x 194 mm
[    37.858] (II) modeset(G0):  3874Y�156WF6
[    37.858] (II) modeset(G0): Unknown vendor-specific block 0
[    37.858] (II) modeset(G0): EDID (in hex):
[    37.858] (II) modeset(G0): 	00ffffffffffff0030e46f0400000000
[    37.858] (II) modeset(G0): 	0018010495221378eadc95a35855a026
[    37.858] (II) modeset(G0): 	0d505400000001010101010101010101
[    37.858] (II) modeset(G0): 	0101010101012e3680a070381f403020
[    37.858] (II) modeset(G0): 	350058c21000001a522b80a070381f40
[    37.858] (II) modeset(G0): 	3020350058c21000001a000000fe0033
[    37.858] (II) modeset(G0): 	38373459803135365746360a00000000
[    37.858] (II) modeset(G0): 	000041319e001000000a010a20200092
[    37.858] (II) modeset(G0): Printing probed modes for output eDP-1-1
[    37.858] (II) modeset(G0): Modeline "1920x1080"x60.0  138.70  1920 1968 2000 2080  1080 1083 1088 1111 +hsync -vsync (66.7 kHz eP)
[    37.858] (II) modeset(G0): Modeline "1920x1080"x59.9  138.50  1920 1968 2000 2080  1080 1083 1088 1111 +hsync -vsync (66.6 kHz d)
[    37.858] (II) modeset(G0): Modeline "1920x1080"x48.0  110.90  1920 1968 2000 2080  1080 1083 1088 1111 +hsync -vsync (53.3 kHz e)
[    37.858] (II) modeset(G0): Modeline "1680x1050"x60.0  146.25  1680 1784 1960 2240  1050 1053 1059 1089 -hsync +vsync (65.3 kHz d)
[    37.858] (II) modeset(G0): Modeline "1680x1050"x59.9  119.00  1680 1728 1760 1840  1050 1053 1059 1080 +hsync -vsync (64.7 kHz d)
[    37.858] (II) modeset(G0): Modeline "1600x1024"x60.2  103.12  1600 1600 1656 1664  1024 1024 1029 1030 +hsync +vsync (62.0 kHz d)
[    37.858] (II) modeset(G0): Modeline "1400x1050"x60.0  122.00  1400 1488 1640 1880  1050 1052 1064 1082 +hsync +vsync (64.9 kHz d)
[    37.859] (II) modeset(G0): Modeline "1280x1024"x60.0  108.00  1280 1328 1440 1688  1024 1025 1028 1066 +hsync +vsync (64.0 kHz d)
[    37.859] (II) modeset(G0): Modeline "1440x900"x59.9  106.50  1440 1520 1672 1904  900 903 909 934 -hsync +vsync (55.9 kHz d)
[    37.859] (II) modeset(G0): Modeline "1280x960"x60.0  108.00  1280 1376 1488 1800  960 961 964 1000 +hsync +vsync (60.0 kHz d)
[    37.859] (II) modeset(G0): Modeline "1360x768"x59.8   84.75  1360 1432 1568 1776  768 771 781 798 -hsync +vsync (47.7 kHz d)
[    37.859] (II) modeset(G0): Modeline "1360x768"x60.0   72.00  1360 1408 1440 1520  768 771 781 790 +hsync -vsync (47.4 kHz d)
[    37.859] (II) modeset(G0): Modeline "1152x864"x60.0   81.62  1152 1216 1336 1520  864 865 868 895 -hsync +vsync (53.7 kHz d)
[    37.859] (II) modeset(G0): Modeline "1024x768"x120.1  133.47  1024 1100 1212 1400  768 768 770 794 doublescan -hsync +vsync (95.3 kHz d)
[    37.859] (II) modeset(G0): Modeline "1024x768"x60.0   65.00  1024 1048 1184 1344  768 771 777 806 -hsync -vsync (48.4 kHz d)
[    37.859] (II) modeset(G0): Modeline "960x720"x120.0  117.00  960 1024 1128 1300  720 720 722 750 doublescan -hsync +vsync (90.0 kHz d)
[    37.859] (II) modeset(G0): Modeline "928x696"x120.1  109.15  928 976 1088 1264  696 696 698 719 doublescan -hsync +vsync (86.4 kHz d)
[    37.859] (II) modeset(G0): Modeline "896x672"x120.0  102.40  896 960 1060 1224  672 672 674 697 doublescan -hsync +vsync (83.7 kHz d)
[    37.859] (II) modeset(G0): Modeline "960x600"x120.0   77.00  960 984 1000 1040  600 601 604 617 doublescan +hsync -vsync (74.0 kHz d)
[    37.859] (II) modeset(G0): Modeline "960x540"x120.0   69.25  960 984 1000 1040  540 541 544 555 doublescan +hsync -vsync (66.6 kHz d)
[    37.859] (II) modeset(G0): Modeline "800x600"x120.0   81.00  800 832 928 1080  600 600 602 625 doublescan +hsync +vsync (75.0 kHz d)
[    37.859] (II) modeset(G0): Modeline "800x600"x60.3   40.00  800 840 968 1056  600 601 605 628 +hsync +vsync (37.9 kHz d)
[    37.859] (II) modeset(G0): Modeline "800x600"x56.2   36.00  800 824 896 1024  600 601 603 625 +hsync +vsync (35.2 kHz d)
[    37.859] (II) modeset(G0): Modeline "840x525"x120.0   73.12  840 892 980 1120  525 526 529 544 doublescan -hsync +vsync (65.3 kHz d)
[    37.859] (II) modeset(G0): Modeline "840x525"x119.8   59.50  840 864 880 920  525 526 529 540 doublescan +hsync -vsync (64.7 kHz d)
[    37.859] (II) modeset(G0): Modeline "800x512"x120.3   51.56  800 800 828 832  512 512 514 515 doublescan +hsync +vsync (62.0 kHz d)
[    37.859] (II) modeset(G0): Modeline "700x525"x120.0   61.00  700 744 820 940  525 526 532 541 doublescan +hsync +vsync (64.9 kHz d)
[    37.859] (II) modeset(G0): Modeline "640x512"x120.0   54.00  640 664 720 844  512 512 514 533 doublescan +hsync +vsync (64.0 kHz d)
[    37.859] (II) modeset(G0): Modeline "720x450"x119.8   53.25  720 760 836 952  450 451 454 467 doublescan -hsync +vsync (55.9 kHz d)
[    37.859] (II) modeset(G0): Modeline "640x480"x120.0   54.00  640 688 744 900  480 480 482 500 doublescan +hsync +vsync (60.0 kHz d)
[    37.859] (II) modeset(G0): Modeline "640x480"x59.9   25.18  640 656 752 800  480 490 492 525 -hsync -vsync (31.5 kHz d)
[    37.859] (II) modeset(G0): Modeline "680x384"x119.6   42.38  680 716 784 888  384 385 390 399 doublescan -hsync +vsync (47.7 kHz d)
[    37.859] (II) modeset(G0): Modeline "680x384"x119.9   36.00  680 704 720 760  384 385 390 395 doublescan +hsync -vsync (47.4 kHz d)
[    37.859] (II) modeset(G0): Modeline "576x432"x120.1   40.81  576 608 668 760  432 432 434 447 doublescan -hsync +vsync (53.7 kHz d)
[    37.859] (II) modeset(G0): Modeline "512x384"x120.0   32.50  512 524 592 672  384 385 388 403 doublescan -hsync -vsync (48.4 kHz d)
[    37.859] (II) modeset(G0): Modeline "400x300"x120.6   20.00  400 420 484 528  300 300 302 314 doublescan +hsync +vsync (37.9 kHz d)
[    37.859] (II) modeset(G0): Modeline "400x300"x112.7   18.00  400 412 448 512  300 300 301 312 doublescan +hsync +vsync (35.2 kHz d)
[    37.859] (II) modeset(G0): Modeline "320x240"x120.1   12.59  320 328 376 400  240 245 246 262 doublescan -hsync -vsync (31.5 kHz d)
[    37.861] (II) modeset(G0): EDID for output DP-1-1
[    37.861] (II) modeset(G0): Using default gamma of (1.0, 1.0, 1.0) unless otherwise stated.
[    37.861] (==) modeset(G0): DPI set to (96, 96)
[    37.861] (II) Loading sub module "fb"
[    37.861] (II) LoadModule: "fb"
[    37.861] (II) Loading /usr/lib/xorg/modules/libfb.so
[    37.861] (II) Module fb: vendor="X.Org Foundation"
[    37.861] 	compiled for 1.18.4, module version = 1.0.0
[    37.861] 	ABI class: X.Org ANSI C Emulation, version 0.4
[    37.861] (II) Loading sub module "shadow"
[    37.861] (II) LoadModule: "shadow"
[    37.861] (II) Loading /usr/lib/xorg/modules/libshadow.so
[    37.861] (II) Module shadow: vendor="X.Org Foundation"
[    37.861] 	compiled for 1.18.4, module version = 1.1.0
[    37.861] (--) Depth 24 pixmap format is 32 bpp
[    37.862] (==) modeset(G0): Backing store enabled
[    37.862] (==) modeset(G0): Silken mouse enabled
[    37.862] (II) modeset(G0): RandR 1.2 enabled, ignore the following RandR disabled message.
[    37.862] (==) modeset(G0): DPMS enabled
[    37.862] (WW) modeset(G0): Option "AllowEmptyInitialConfiguration" is not used
[    38.139] (II) NVIDIA: Using 49152.00 MB of virtual memory for indirect memory
[    38.139] (II) NVIDIA:     access.
[    38.186] (II) NVIDIA(0): Setting mode "NULL"
[    38.192] (==) NVIDIA(0): Disabling shared memory pixmaps
[    38.192] (==) NVIDIA(0): Backing store enabled
[    38.192] (==) NVIDIA(0): Silken mouse enabled
[    38.192] (==) NVIDIA(0): DPMS enabled
[    38.192] (II) Loading sub module "dri2"
[    38.192] (II) LoadModule: "dri2"
[    38.192] (II) Module "dri2" already built-in
[    38.192] (II) NVIDIA(0): [DRI2] Setup complete
[    38.192] (II) NVIDIA(0): [DRI2]   VDPAU driver: nvidia
[    38.192] (--) RandR disabled
[    38.194] (II) SELinux: Disabled on system
[    38.194] (II) Initializing extension GLX
[    38.194] (II) Indirect GLX disabled.
[    38.195] (II) modeset(G0): Damage tracking initialized
[    38.216] (II) config/udev: Adding input device Power Button (/dev/input/event3)
[    38.216] (**) Power Button: Applying InputClass "evdev keyboard catchall"
[    38.216] (**) Power Button: Applying InputClass "libinput keyboard catchall"
[    38.216] (II) LoadModule: "libinput"
[    38.216] (II) Loading /usr/lib/xorg/modules/input/libinput_drv.so
[    38.217] (II) Module libinput: vendor="X.Org Foundation"
[    38.217] 	compiled for 1.18.3, module version = 0.19.0
[    38.217] 	Module class: X.Org XInput Driver
[    38.217] 	ABI class: X.Org XInput driver, version 22.1
[    38.218] (II) systemd-logind: got fd for /dev/input/event3 13:67 fd 28 paused 0
[    38.218] (II) Using input driver 'libinput' for 'Power Button'
[    38.218] (**) Power Button: always reports core events
[    38.218] (**) Option "Device" "/dev/input/event3"
[    38.218] (**) Option "_source" "server/udev"
[    38.218] (II) input device 'Power Button', /dev/input/event3 is tagged by udev as: Keyboard
[    38.218] (II) input device 'Power Button', /dev/input/event3 is a keyboard
[    38.218] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXPWRBN:00/input/input3/event3"
[    38.218] (II) XINPUT: Adding extended input device "Power Button" (type: KEYBOARD, id 6)
[    38.218] (**) Option "xkb_model" "pc105"
[    38.218] (**) Option "xkb_layout" "us"
[    38.218] (**) Option "xkb_variant" "intl"
[    38.229] (II) input device 'Power Button', /dev/input/event3 is tagged by udev as: Keyboard
[    38.229] (II) input device 'Power Button', /dev/input/event3 is a keyboard
[    38.229] (II) config/udev: Adding input device Video Bus (/dev/input/event5)
[    38.229] (**) Video Bus: Applying InputClass "evdev keyboard catchall"
[    38.229] (**) Video Bus: Applying InputClass "libinput keyboard catchall"
[    38.229] (II) systemd-logind: got fd for /dev/input/event5 13:69 fd 31 paused 0
[    38.229] (II) Using input driver 'libinput' for 'Video Bus'
[    38.229] (**) Video Bus: always reports core events
[    38.229] (**) Option "Device" "/dev/input/event5"
[    38.229] (**) Option "_source" "server/udev"
[    38.229] (II) input device 'Video Bus', /dev/input/event5 is tagged by udev as: Keyboard
[    38.229] (II) input device 'Video Bus', /dev/input/event5 is a keyboard
[    38.230] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/LNXVIDEO:00/input/input13/event5"
[    38.230] (II) XINPUT: Adding extended input device "Video Bus" (type: KEYBOARD, id 7)
[    38.230] (**) Option "xkb_model" "pc105"
[    38.230] (**) Option "xkb_layout" "us"
[    38.230] (**) Option "xkb_variant" "intl"
[    38.230] (II) input device 'Video Bus', /dev/input/event5 is tagged by udev as: Keyboard
[    38.230] (II) input device 'Video Bus', /dev/input/event5 is a keyboard
[    38.230] (II) config/udev: Adding input device Video Bus (/dev/input/event6)
[    38.230] (**) Video Bus: Applying InputClass "evdev keyboard catchall"
[    38.230] (**) Video Bus: Applying InputClass "libinput keyboard catchall"
[    38.230] (II) systemd-logind: got fd for /dev/input/event6 13:70 fd 32 paused 0
[    38.230] (II) Using input driver 'libinput' for 'Video Bus'
[    38.230] (**) Video Bus: always reports core events
[    38.230] (**) Option "Device" "/dev/input/event6"
[    38.230] (**) Option "_source" "server/udev"
[    38.231] (II) input device 'Video Bus', /dev/input/event6 is tagged by udev as: Keyboard
[    38.231] (II) input device 'Video Bus', /dev/input/event6 is a keyboard
[    38.231] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/device:11/LNXVIDEO:01/input/input14/event6"
[    38.231] (II) XINPUT: Adding extended input device "Video Bus" (type: KEYBOARD, id 8)
[    38.231] (**) Option "xkb_model" "pc105"
[    38.231] (**) Option "xkb_layout" "us"
[    38.231] (**) Option "xkb_variant" "intl"
[    38.231] (II) config/udev: Adding input device Power Button (/dev/input/event0)
[    38.231] (**) Power Button: Applying InputClass "evdev keyboard catchall"
[    38.231] (**) Power Button: Applying InputClass "libinput keyboard catchall"
[    38.231] (II) systemd-logind: got fd for /dev/input/event0 13:64 fd 33 paused 0
[    38.232] (II) Using input driver 'libinput' for 'Power Button'
[    38.232] (**) Power Button: always reports core events
[    38.232] (**) Option "Device" "/dev/input/event0"
[    38.232] (**) Option "_source" "server/udev"
[    38.232] (II) input device 'Power Button', /dev/input/event0 is tagged by udev as: Keyboard
[    38.232] (II) input device 'Power Button', /dev/input/event0 is a keyboard
[    38.232] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0C:00/input/input0/event0"
[    38.232] (II) XINPUT: Adding extended input device "Power Button" (type: KEYBOARD, id 9)
[    38.232] (**) Option "xkb_model" "pc105"
[    38.232] (**) Option "xkb_layout" "us"
[    38.232] (**) Option "xkb_variant" "intl"
[    38.232] (II) config/udev: Adding input device Lid Switch (/dev/input/event2)
[    38.232] (II) No input driver specified, ignoring this device.
[    38.232] (II) This device may have been added with another device file.
[    38.233] (II) config/udev: Adding input device Sleep Button (/dev/input/event1)
[    38.233] (**) Sleep Button: Applying InputClass "evdev keyboard catchall"
[    38.233] (**) Sleep Button: Applying InputClass "libinput keyboard catchall"
[    38.233] (II) systemd-logind: got fd for /dev/input/event1 13:65 fd 34 paused 0
[    38.233] (II) Using input driver 'libinput' for 'Sleep Button'
[    38.233] (**) Sleep Button: always reports core events
[    38.233] (**) Option "Device" "/dev/input/event1"
[    38.233] (**) Option "_source" "server/udev"
[    38.233] (II) input device 'Sleep Button', /dev/input/event1 is tagged by udev as: Keyboard
[    38.233] (II) input device 'Sleep Button', /dev/input/event1 is a keyboard
[    38.233] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0E:00/input/input1/event1"
[    38.233] (II) XINPUT: Adding extended input device "Sleep Button" (type: KEYBOARD, id 10)
[    38.233] (**) Option "xkb_model" "pc105"
[    38.233] (**) Option "xkb_layout" "us"
[    38.233] (**) Option "xkb_variant" "intl"
[    38.234] (II) config/udev: Adding input device Chicony USB 2.0 Camera (/dev/input/event8)
[    38.234] (**) Chicony USB 2.0 Camera: Applying InputClass "evdev keyboard catchall"
[    38.234] (**) Chicony USB 2.0 Camera: Applying InputClass "libinput keyboard catchall"
[    38.234] (II) systemd-logind: got fd for /dev/input/event8 13:72 fd 35 paused 0
[    38.234] (II) Using input driver 'libinput' for 'Chicony USB 2.0 Camera'
[    38.234] (**) Chicony USB 2.0 Camera: always reports core events
[    38.234] (**) Option "Device" "/dev/input/event8"
[    38.234] (**) Option "_source" "server/udev"
[    38.234] (II) input device 'Chicony USB 2.0 Camera', /dev/input/event8 is tagged by udev as: Keyboard
[    38.234] (II) input device 'Chicony USB 2.0 Camera', /dev/input/event8 is a keyboard
[    38.234] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:14.0/usb1/1-9/1-9:1.0/input/input17/event8"
[    38.234] (II) XINPUT: Adding extended input device "Chicony USB 2.0 Camera" (type: KEYBOARD, id 11)
[    38.234] (**) Option "xkb_model" "pc105"
[    38.234] (**) Option "xkb_layout" "us"
[    38.235] (**) Option "xkb_variant" "intl"
[    38.235] (II) input device 'Chicony USB 2.0 Camera', /dev/input/event8 is tagged by udev as: Keyboard
[    38.235] (II) input device 'Chicony USB 2.0 Camera', /dev/input/event8 is a keyboard
[    38.235] (II) config/udev: Adding input device HDA Intel PCH Mic (/dev/input/event9)
[    38.235] (II) No input driver specified, ignoring this device.
[    38.235] (II) This device may have been added with another device file.
[    38.235] (II) config/udev: Adding input device HDA Intel PCH Line Out (/dev/input/event10)
[    38.235] (II) config/udev: Adding input device HDA Intel PCH HDMI/DP,pcm=3 (/dev/input/event11)
[    38.236] (II) config/udev: Adding input device HDA Intel PCH HDMI/DP,pcm=7 (/dev/input/event12)
[    38.236] (II) No input driver specified, ignoring this device.
[    38.236] (II) This device may have been added with another device file.
[    38.236] (II) config/udev: Adding input device HDA Intel PCH HDMI/DP,pcm=8 (/dev/input/event13)
[    38.236] (II) config/udev: Adding input device AT Translated Set 2 keyboard (/dev/input/event4)
[    38.236] (**) AT Translated Set 2 keyboard: Applying InputClass "evdev keyboard catchall"
[    38.236] (**) AT Translated Set 2 keyboard: Applying InputClass "libinput keyboard catchall"
[    38.236] (II) systemd-logind: got fd for /dev/input/event4 13:68 fd 36 paused 0
[    38.236] (II) Using input driver 'libinput' for 'AT Translated Set 2 keyboard'
[    38.236] (**) AT Translated Set 2 keyboard: always reports core events
[    38.236] (**) Option "Device" "/dev/input/event4"
[    38.236] (**) Option "_source" "server/udev"
[    38.236] (II) input device 'AT Translated Set 2 keyboard', /dev/input/event4 is tagged by udev as: Keyboard
[    38.236] (II) input device 'AT Translated Set 2 keyboard', /dev/input/event4 is a keyboard
[    38.236] (**) Option "config_info" "udev:/sys/devices/platform/i8042/serio0/input/input4/event4"
[    38.236] (II) XINPUT: Adding extended input device "AT Translated Set 2 keyboard" (type: KEYBOARD, id 12)
[    38.237] (**) Option "xkb_model" "pc105"
[    38.237] (**) Option "xkb_layout" "us"
[    38.237] (**) Option "xkb_variant" "intl"
[    38.237] (II) input device 'AT Translated Set 2 keyboard', /dev/input/event4 is tagged by udev as: Keyboard
[    38.237] (II) input device 'AT Translated Set 2 keyboard', /dev/input/event4 is a keyboard
[    38.237] (II) config/udev: Adding input device SynPS/2 Synaptics TouchPad (/dev/input/event7)
[    38.237] (**) SynPS/2 Synaptics TouchPad: Applying InputClass "evdev touchpad catchall"
[    38.237] (**) SynPS/2 Synaptics TouchPad: Applying InputClass "touchpad catchall"
[    38.237] (**) SynPS/2 Synaptics TouchPad: Applying InputClass "Default clickpad buttons"
[    38.237] (**) SynPS/2 Synaptics TouchPad: Applying InputClass "libinput touchpad catchall"
[    38.237] (II) systemd-logind: got fd for /dev/input/event7 13:71 fd 37 paused 0
[    38.237] (II) Using input driver 'libinput' for 'SynPS/2 Synaptics TouchPad'
[    38.237] (**) SynPS/2 Synaptics TouchPad: always reports core events
[    38.237] (**) Option "Device" "/dev/input/event7"
[    38.237] (**) Option "_source" "server/udev"
[    38.238] (II) input device 'SynPS/2 Synaptics TouchPad', /dev/input/event7 is tagged by udev as: Touchpad
[    38.238] (II) input device 'SynPS/2 Synaptics TouchPad', /dev/input/event7 is a touchpad
[    38.238] (**) Option "config_info" "udev:/sys/devices/platform/i8042/serio2/input/input12/event7"
[    38.238] (II) XINPUT: Adding extended input device "SynPS/2 Synaptics TouchPad" (type: TOUCHPAD, id 13)
[    38.238] (**) Option "AccelerationScheme" "none"
[    38.238] (**) SynPS/2 Synaptics TouchPad: (accel) selected scheme none/0
[    38.238] (**) SynPS/2 Synaptics TouchPad: (accel) acceleration factor: 2.000
[    38.238] (**) SynPS/2 Synaptics TouchPad: (accel) acceleration threshold: 4
[    38.238] (II) config/udev: Adding input device SynPS/2 Synaptics TouchPad (/dev/input/mouse0)
[    38.238] (**) SynPS/2 Synaptics TouchPad: Ignoring device from InputClass "touchpad ignore duplicates"
[    79.182] (II) config/udev: Adding input device Logitech USB Keyboard (/dev/input/event15)
[    79.182] (**) Logitech USB Keyboard: Applying InputClass "evdev keyboard catchall"
[    79.182] (**) Logitech USB Keyboard: Applying InputClass "libinput keyboard catchall"
[    79.182] (II) systemd-logind: got fd for /dev/input/event15 13:79 fd 54 paused 0
[    79.182] (II) Using input driver 'libinput' for 'Logitech USB Keyboard'
[    79.182] (**) Logitech USB Keyboard: always reports core events
[    79.182] (**) Option "Device" "/dev/input/event15"
[    79.182] (**) Option "_source" "server/udev"
[    79.183] (II) input device 'Logitech USB Keyboard', /dev/input/event15 is tagged by udev as: Keyboard
[    79.183] (II) input device 'Logitech USB Keyboard', /dev/input/event15 is a keyboard
[    79.183] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:14.0/usb1/1-5/1-5.5/1-5.5:1.1/0003:046D:C31C.0002/input/input24/event15"
[    79.183] (II) XINPUT: Adding extended input device "Logitech USB Keyboard" (type: KEYBOARD, id 14)
[    79.183] (**) Option "xkb_model" "pc105"
[    79.183] (**) Option "xkb_layout" "us"
[    79.183] (**) Option "xkb_variant" "intl"
[    79.183] (WW) Option "xkb_options" requires a string value
[    79.184] (II) config/udev: Adding input device Logitech USB Keyboard (/dev/input/event14)
[    79.184] (**) Logitech USB Keyboard: Applying InputClass "evdev keyboard catchall"
[    79.184] (**) Logitech USB Keyboard: Applying InputClass "libinput keyboard catchall"
[    79.184] (II) systemd-logind: got fd for /dev/input/event14 13:78 fd 55 paused 0
[    79.184] (II) Using input driver 'libinput' for 'Logitech USB Keyboard'
[    79.184] (**) Logitech USB Keyboard: always reports core events
[    79.184] (**) Option "Device" "/dev/input/event14"
[    79.184] (**) Option "_source" "server/udev"
[    79.184] (II) input device 'Logitech USB Keyboard', /dev/input/event14 is tagged by udev as: Keyboard
[    79.185] (II) input device 'Logitech USB Keyboard', /dev/input/event14 is a keyboard
[    79.185] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:14.0/usb1/1-5/1-5.5/1-5.5:1.0/0003:046D:C31C.0001/input/input23/event14"
[    79.185] (II) XINPUT: Adding extended input device "Logitech USB Keyboard" (type: KEYBOARD, id 15)
[    79.185] (**) Option "xkb_model" "pc105"
[    79.185] (**) Option "xkb_layout" "us"
[    79.185] (**) Option "xkb_variant" "intl"
[    79.185] (WW) Option "xkb_options" requires a string value
[    79.185] (II) input device 'Logitech USB Keyboard', /dev/input/event14 is tagged by udev as: Keyboard
[    79.359] (II) config/udev: Adding input device Logitech M705 (/dev/input/mouse2)
[    79.359] (II) No input driver specified, ignoring this device.
[    79.359] (II) This device may have been added with another device file.
[    79.362] (II) config/udev: Adding input device Logitech M705 (/dev/input/mouse1)
[    79.362] (II) No input driver specified, ignoring this device.
[    79.362] (II) This device may have been added with another device file.
[    79.399] (II) config/udev: Adding input device Logitech M705 (/dev/input/event17)
[    79.399] (**) Logitech M705: Applying InputClass "evdev pointer catchall"
[    79.399] (**) Logitech M705: Applying InputClass "libinput pointer catchall"
[    79.402] (II) systemd-logind: got fd for /dev/input/event17 13:81 fd 56 paused 0
[    79.402] (II) Using input driver 'libinput' for 'Logitech M705'
[    79.402] (**) Logitech M705: always reports core events
[    79.402] (**) Option "Device" "/dev/input/event17"
[    79.402] (**) Option "_source" "server/udev"
[    79.403] (II) input device 'Logitech M705', /dev/input/event17 is tagged by udev as: Mouse
[    79.403] (II) Device 'Logitech M705' set to 800 DPI
[    79.403] (II) input device 'Logitech M705', /dev/input/event17 is a pointer caps
[    79.403] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:14.0/usb1/1-5/1-5.6/1-5.6:1.2/0003:046D:C52B.0005/0003:046D:101B.0008/input/input26/event17"
[    79.403] (II) XINPUT: Adding extended input device "Logitech M705" (type: MOUSE, id 16)
[    79.404] (**) Option "AccelerationScheme" "none"
[    79.404] (**) Logitech M705: (accel) selected scheme none/0
[    79.405] (**) Logitech M705: (accel) acceleration factor: 2.000
[    79.405] (**) Logitech M705: (accel) acceleration threshold: 4
[    79.405] (II) input device 'Logitech M705', /dev/input/event17 is tagged by udev as: Mouse
[    79.406] (II) Device 'Logitech M705' set to 800 DPI
[    79.406] (II) input device 'Logitech M705', /dev/input/event17 is a pointer caps
[    79.421] (II) config/udev: Adding input device Logitech M705 (/dev/input/event16)
[    79.421] (**) Logitech M705: Applying InputClass "evdev pointer catchall"
[    79.421] (**) Logitech M705: Applying InputClass "libinput pointer catchall"
[    79.422] (II) systemd-logind: got fd for /dev/input/event16 13:80 fd 57 paused 0
[    79.422] (II) Using input driver 'libinput' for 'Logitech M705'
[    79.422] (**) Logitech M705: always reports core events
[    79.422] (**) Option "Device" "/dev/input/event16"
[    79.422] (**) Option "_source" "server/udev"
[    79.424] (II) input device 'Logitech M705', /dev/input/event16 is tagged by udev as: Mouse
[    79.424] (II) Device 'Logitech M705' set to 800 DPI
[    79.424] (II) input device 'Logitech M705', /dev/input/event16 is a pointer caps
[    79.424] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:14.0/usb1/1-5/1-5.6/1-5.6:1.2/0003:046D:C52B.0005/0003:046D:101B.0006/input/input25/event16"
[    79.424] (II) XINPUT: Adding extended input device "Logitech M705" (type: MOUSE, id 17)
[    79.425] (**) Option "AccelerationScheme" "none"
[    79.425] (**) Logitech M705: (accel) selected scheme none/0
[    79.425] (**) Logitech M705: (accel) acceleration factor: 2.000
[    79.425] (**) Logitech M705: (accel) acceleration threshold: 4
[    79.426] (II) input device 'Logitech M705', /dev/input/event16 is tagged by udev as: Mouse
[    79.426] (II) Device 'Logitech M705' set to 800 DPI
[    79.426] (II) input device 'Logitech M705', /dev/input/event16 is a pointer caps
Same problem here, did you solve? Also 375.26 is not working
