I have 2 graphic cards on my laptop: integrated one + Quadro 1000. Running Optimus.
Nvidia driver is 390.154.
VGA output is not detecting my external monitor.
- Here is my /var/log/Xorg.0.log file:
[ 9.434]
X.Org X Server 1.20.11
X Protocol Version 11, Revision 0
[ 9.434] Build Operating System: linux Debian
[ 9.434] Current Operating System: Linux bob 5.10.0-12-amd64 #1 SMP Debian 5.10.103-1 (2022-03-07) x86_64
[ 9.434] Kernel command line: BOOT_IMAGE=/boot/vmlinuz-5.10.0-12-amd64 root=UUID=aaddf4e1-1640-4a05-a10c-246b6ba5b460 ro quiet splash
[ 9.434] Build Date: 05 August 2022 08:00:36AM
[ 9.434] xorg-server 2:1.20.11-1+deb11u2 (https://www.debian.org/support)
[ 9.434] Current version of pixman: 0.40.0
[ 9.434] Before reporting problems, check http://wiki.x.org
to make sure that you have the latest version.
[ 9.434] Markers: (--) probed, (**) from config file, (==) default setting,
(++) from command line, (!!) notice, (II) informational,
(WW) warning, (EE) error, (NI) not implemented, (??) unknown.
[ 9.434] (==) Log file: "/var/log/Xorg.0.log", Time: Tue Nov 8 12:33:14 2022
[ 9.435] (==) Using config directory: "/etc/X11/xorg.conf.d"
[ 9.435] (==) Using system config directory "/usr/share/X11/xorg.conf.d"
[ 9.437] (==) No Layout section. Using the first Screen section.
[ 9.437] (==) No screen section available. Using defaults.
[ 9.437] (**) |-->Screen "Default Screen Section" (0)
[ 9.437] (**) | |-->Monitor "<default monitor>"
[ 9.437] (==) No monitor specified for screen "Default Screen Section".
Using a default monitor configuration.
[ 9.437] (==) Automatically adding devices
[ 9.437] (==) Automatically enabling devices
[ 9.437] (==) Automatically adding GPU devices
[ 9.437] (==) Max clients allowed: 256, resource mask: 0x1fffff
[ 9.442] (==) FontPath set to:
/usr/share/fonts/X11/misc,
/usr/share/fonts/X11/cyrillic,
/usr/share/fonts/X11/100dpi/:unscaled,
/usr/share/fonts/X11/75dpi/:unscaled,
/usr/share/fonts/X11/Type1,
/usr/share/fonts/X11/100dpi,
/usr/share/fonts/X11/75dpi,
built-ins
[ 9.442] (==) ModulePath set to "/usr/lib/xorg/modules"
[ 9.442] (II) The server relies on udev to provide the list of input devices.
If no devices become available, reconfigure udev or disable AutoAddDevices.
[ 9.442] (II) Loader magic: 0x556d817b5e40
[ 9.442] (II) Module ABI versions:
[ 9.442] X.Org ANSI C Emulation: 0.4
[ 9.442] X.Org Video Driver: 24.1
[ 9.442] X.Org XInput driver : 24.1
[ 9.442] X.Org Server Extension : 10.0
[ 9.442] (++) using VT number 7
[ 9.442] (II) systemd-logind: logind integration requires -keeptty and -keeptty was not provided, disabling logind integration
[ 9.443] (II) xfree86: Adding drm device (/dev/dri/card0)
[ 9.454] (--) PCI:*(0@0:2:0) 8086:0126:17aa:21d1 rev 9, Mem @ 0xf1400000/4194304, 0xe0000000/268435456, I/O @ 0x00006000/64, BIOS @ 0x????????/131072
[ 9.454] (--) PCI: (1@0:0:0) 10de:0dfa:17aa:21d1 rev 161, Mem @ 0xf0000000/16777216, 0xc0000000/268435456, 0xd0000000/33554432, I/O @ 0x00005000/128, BIOS @ 0x????????/524288
[ 9.454] (II) LoadModule: "glx"
[ 9.455] (II) Loading /usr/lib/xorg/modules/extensions/libglx.so
[ 9.461] (II) Module glx: vendor="X.Org Foundation"
[ 9.461] compiled for 1.20.11, module version = 1.0.0
[ 9.461] ABI class: X.Org Server Extension, version 10.0
[ 9.461] (==) Matched modesetting as autoconfigured driver 0
[ 9.461] (==) Matched fbdev as autoconfigured driver 1
[ 9.461] (==) Matched vesa as autoconfigured driver 2
[ 9.461] (==) Assigned the driver to the xf86ConfigLayout
[ 9.461] (II) LoadModule: "modesetting"
[ 9.462] (II) Loading /usr/lib/xorg/modules/drivers/modesetting_drv.so
[ 9.463] (II) Module modesetting: vendor="X.Org Foundation"
[ 9.463] compiled for 1.20.11, module version = 1.20.11
[ 9.463] Module class: X.Org Video Driver
[ 9.463] ABI class: X.Org Video Driver, version 24.1
[ 9.463] (II) LoadModule: "fbdev"
[ 9.463] (II) Loading /usr/lib/xorg/modules/drivers/fbdev_drv.so
[ 9.463] (II) Module fbdev: vendor="X.Org Foundation"
[ 9.463] compiled for 1.20.0, module version = 0.5.0
[ 9.463] ABI class: X.Org Video Driver, version 24.0
[ 9.463] (II) LoadModule: "vesa"
[ 9.464] (II) Loading /usr/lib/xorg/modules/drivers/vesa_drv.so
[ 9.464] (II) Module vesa: vendor="X.Org Foundation"
[ 9.464] compiled for 1.20.9, module version = 2.5.0
[ 9.464] Module class: X.Org Video Driver
[ 9.464] ABI class: X.Org Video Driver, version 24.1
[ 9.464] (II) modesetting: Driver for Modesetting Kernel Drivers: kms
[ 9.464] (II) FBDEV: driver for framebuffer: fbdev
[ 9.464] (II) VESA: driver for VESA chipsets: vesa
[ 9.485] (II) modeset(0): using drv /dev/dri/card0
[ 9.485] (WW) Falling back to old probe method for fbdev
[ 9.485] (II) Loading sub module "fbdevhw"
[ 9.485] (II) LoadModule: "fbdevhw"
[ 9.485] (II) Loading /usr/lib/xorg/modules/libfbdevhw.so
[ 9.486] (II) Module fbdevhw: vendor="X.Org Foundation"
[ 9.486] compiled for 1.20.11, module version = 0.0.2
[ 9.486] ABI class: X.Org Video Driver, version 24.1
[ 9.486] (II) modeset(0): Creating default Display subsection in Screen section
"Default Screen Section" for depth/fbbpp 24/32
[ 9.486] (==) modeset(0): Depth 24, (==) framebuffer bpp 32
[ 9.486] (==) modeset(0): RGB weight 888
[ 9.486] (==) modeset(0): Default visual is TrueColor
[ 9.486] (II) Loading sub module "glamoregl"
[ 9.486] (II) LoadModule: "glamoregl"
[ 9.487] (II) Loading /usr/lib/xorg/modules/libglamoregl.so
[ 9.495] (II) Module glamoregl: vendor="X.Org Foundation"
[ 9.495] compiled for 1.20.11, module version = 1.0.1
[ 9.495] ABI class: X.Org ANSI C Emulation, version 0.4
[ 9.660] (II) modeset(0): glamor X acceleration enabled on Mesa DRI Intel(R) HD Graphics 3000 (SNB GT2)
[ 9.660] (II) modeset(0): glamor initialized
[ 9.661] (II) modeset(0): Output LVDS-1 has no monitor section
[ 9.774] (II) modeset(0): Output VGA-1 has no monitor section
[ 9.774] (II) modeset(0): EDID for output LVDS-1
[ 9.774] (II) modeset(0): Manufacturer: LEN Model: 40b2 Serial#: 0
[ 9.774] (II) modeset(0): Year: 2009 Week: 1
[ 9.774] (II) modeset(0): EDID Version: 1.3
[ 9.774] (II) modeset(0): Digital Display Input
[ 9.774] (II) modeset(0): Max Image Size [cm]: horiz.: 34 vert.: 19
[ 9.774] (II) modeset(0): Gamma: 2.20
[ 9.774] (II) modeset(0): DPMS capabilities: StandBy Suspend Off
[ 9.774] (II) modeset(0): Supported color encodings: RGB 4:4:4 YCrCb 4:4:4
[ 9.774] (II) modeset(0): First detailed timing is preferred mode
[ 9.774] (II) modeset(0): redX: 0.676 redY: 0.314 greenX: 0.215 greenY: 0.665
[ 9.774] (II) modeset(0): blueX: 0.141 blueY: 0.069 whiteX: 0.313 whiteY: 0.329
[ 9.774] (II) modeset(0): Manufacturer's mask: 0
[ 9.774] (II) modeset(0): Supported detailed timing:
[ 9.774] (II) modeset(0): clock: 139.0 MHz Image Size: 344 x 193 mm
[ 9.774] (II) modeset(0): h_active: 1920 h_sync: 1980 h_sync_end 2028 h_blank_end 2050 h_border: 0
[ 9.774] (II) modeset(0): v_active: 1080 v_sync: 1090 v_sync_end 1100 v_blanking: 1130 v_border: 0
[ 9.774] (II) modeset(0): clock: 115.8 MHz Image Size: 344 x 193 mm
[ 9.774] (II) modeset(0): Unknown vendor-specific block f
[ 9.774] (II) modeset(0): B156HW01 V4
[ 9.774] (II) modeset(0): EDID (in hex):
[ 9.774] (II) modeset(0): 00ffffffffffff0030aeb24000000000
[ 9.774] (II) modeset(0): 0113010380221378ea2135ad5037aa24
[ 9.774] (II) modeset(0): 11505400000001010101010101010101
[ 9.774] (II) modeset(0): 0101010101014c368082703832403c30
[ 9.774] (II) modeset(0): aa0058c1100000183f2d808270383240
[ 9.775] (II) modeset(0): 3c30aa0058c1100000180000000f00d1
[ 9.775] (II) modeset(0): 0932d109281b190006af5634000000fe
[ 9.775] (II) modeset(0): 004231353648573031205634200a00d6
[ 9.775] (II) modeset(0): Printing probed modes for output LVDS-1
[ 9.775] (II) modeset(0): Modeline "1920x1080"x60.0 139.00 1920 1980 2028 2050 1080 1090 1100 1130 -hsync -vsync (67.8 kHz eP)
[ 9.775] (II) modeset(0): Modeline "1920x1080"x119.9 266.50 1920 1944 1960 2000 1080 1081 1084 1111 doublescan +hsync -vsync (133.2 kHz d)
[ 9.775] (II) modeset(0): Modeline "1920x1080"x60.0 173.00 1920 2048 2248 2576 1080 1083 1088 1120 -hsync +vsync (67.2 kHz d)
[ 9.775] (II) modeset(0): Modeline "1920x1080"x59.9 138.50 1920 1968 2000 2080 1080 1083 1088 1111 +hsync -vsync (66.6 kHz d)
[ 9.775] (II) modeset(0): Modeline "1920x1080"x50.0 115.83 1920 1980 2028 2050 1080 1090 1100 1130 -hsync -vsync (56.5 kHz e)
[ 9.775] (II) modeset(0): Modeline "1680x1050"x60.0 146.25 1680 1784 1960 2240 1050 1053 1059 1089 -hsync +vsync (65.3 kHz d)
[ 9.775] (II) modeset(0): Modeline "1680x1050"x59.9 119.00 1680 1728 1760 1840 1050 1053 1059 1080 +hsync -vsync (64.7 kHz d)
[ 9.775] (II) modeset(0): Modeline "1600x1024"x60.2 103.12 1600 1600 1656 1664 1024 1024 1029 1030 +hsync +vsync (62.0 kHz d)
[ 9.775] (II) modeset(0): Modeline "1400x1050"x60.0 122.00 1400 1488 1640 1880 1050 1052 1064 1082 +hsync +vsync (64.9 kHz d)
[ 9.775] (II) modeset(0): Modeline "1600x900"x120.0 246.00 1600 1728 1900 2200 900 901 904 932 doublescan -hsync +vsync (111.8 kHz d)
[ 9.775] (II) modeset(0): Modeline "1600x900"x119.9 186.50 1600 1624 1640 1680 900 901 904 926 doublescan +hsync -vsync (111.0 kHz d)
[ 9.775] (II) modeset(0): Modeline "1600x900"x59.9 118.25 1600 1696 1856 2112 900 903 908 934 -hsync +vsync (56.0 kHz d)
[ 9.775] (II) modeset(0): Modeline "1600x900"x59.8 97.50 1600 1648 1680 1760 900 903 908 926 +hsync -vsync (55.4 kHz d)
[ 9.775] (II) modeset(0): Modeline "1280x1024"x60.0 108.00 1280 1328 1440 1688 1024 1025 1028 1066 +hsync +vsync (64.0 kHz d)
[ 9.775] (II) modeset(0): Modeline "1440x900"x59.9 106.50 1440 1520 1672 1904 900 903 909 934 -hsync +vsync (55.9 kHz d)
[ 9.775] (II) modeset(0): Modeline "1400x900"x60.0 103.50 1400 1480 1624 1848 900 903 913 934 -hsync +vsync (56.0 kHz d)
[ 9.775] (II) modeset(0): Modeline "1400x900"x59.9 86.50 1400 1448 1480 1560 900 903 913 926 +hsync -vsync (55.4 kHz d)
[ 9.775] (II) modeset(0): Modeline "1280x960"x60.0 108.00 1280 1376 1488 1800 960 961 964 1000 +hsync +vsync (60.0 kHz d)
[ 9.775] (II) modeset(0): Modeline "1440x810"x120.0 198.12 1440 1548 1704 1968 810 811 814 839 doublescan -hsync +vsync (100.7 kHz d)
[ 9.775] (II) modeset(0): Modeline "1440x810"x119.9 151.88 1440 1464 1480 1520 810 811 814 833 doublescan +hsync -vsync (99.9 kHz d)
[ 9.775] (II) modeset(0): Modeline "1368x768"x59.9 85.25 1368 1440 1576 1784 768 771 781 798 -hsync +vsync (47.8 kHz d)
[ 9.775] (II) modeset(0): Modeline "1368x768"x59.9 72.25 1368 1416 1448 1528 768 771 781 790 +hsync -vsync (47.3 kHz d)
[ 9.775] (II) modeset(0): Modeline "1360x768"x59.8 84.75 1360 1432 1568 1776 768 771 781 798 -hsync +vsync (47.7 kHz d)
[ 9.775] (II) modeset(0): Modeline "1360x768"x60.0 72.00 1360 1408 1440 1520 768 771 781 790 +hsync -vsync (47.4 kHz d)
[ 9.775] (II) modeset(0): Modeline "1280x800"x120.0 174.25 1280 1380 1516 1752 800 801 804 829 doublescan -hsync +vsync (99.5 kHz d)
[ 9.775] (II) modeset(0): Modeline "1280x800"x119.9 134.25 1280 1304 1320 1360 800 801 804 823 doublescan +hsync -vsync (98.7 kHz d)
[ 9.775] (II) modeset(0): Modeline "1280x800"x59.8 83.50 1280 1352 1480 1680 800 803 809 831 -hsync +vsync (49.7 kHz d)
[ 9.775] (II) modeset(0): Modeline "1280x800"x59.9 71.00 1280 1328 1360 1440 800 803 809 823 +hsync -vsync (49.3 kHz d)
[ 9.775] (II) modeset(0): Modeline "1152x864"x60.0 81.62 1152 1216 1336 1520 864 865 868 895 -hsync +vsync (53.7 kHz d)
[ 9.775] (II) modeset(0): Modeline "1280x720"x120.0 156.12 1280 1376 1512 1744 720 721 724 746 doublescan -hsync +vsync (89.5 kHz d)
[ 9.775] (II) modeset(0): Modeline "1280x720"x120.0 120.75 1280 1304 1320 1360 720 721 724 740 doublescan +hsync -vsync (88.8 kHz d)
[ 9.775] (II) modeset(0): Modeline "1280x720"x59.9 74.50 1280 1344 1472 1664 720 723 728 748 -hsync +vsync (44.8 kHz d)
[ 9.775] (II) modeset(0): Modeline "1280x720"x59.7 63.75 1280 1328 1360 1440 720 723 728 741 +hsync -vsync (44.3 kHz d)
[ 9.775] (II) modeset(0): Modeline "1024x768"x120.1 133.47 1024 1100 1212 1400 768 768 770 794 doublescan -hsync +vsync (95.3 kHz d)
[ 9.775] (II) modeset(0): Modeline "1024x768"x60.0 65.00 1024 1048 1184 1344 768 771 777 806 -hsync -vsync (48.4 kHz d)
[ 9.775] (II) modeset(0): Modeline "960x720"x120.0 117.00 960 1024 1128 1300 720 720 722 750 doublescan -hsync +vsync (90.0 kHz d)
[ 9.775] (II) modeset(0): Modeline "928x696"x120.1 109.15 928 976 1088 1264 696 696 698 719 doublescan -hsync +vsync (86.4 kHz d)
[ 9.775] (II) modeset(0): Modeline "896x672"x120.0 102.40 896 960 1060 1224 672 672 674 697 doublescan -hsync +vsync (83.7 kHz d)
[ 9.775] (II) modeset(0): Modeline "1024x576"x119.9 98.50 1024 1092 1200 1376 576 577 580 597 doublescan -hsync +vsync (71.6 kHz d)
[ 9.775] (II) modeset(0): Modeline "1024x576"x119.9 78.38 1024 1048 1064 1104 576 577 580 592 doublescan +hsync -vsync (71.0 kHz d)
[ 9.775] (II) modeset(0): Modeline "1024x576"x59.9 46.50 1024 1064 1160 1296 576 579 584 599 -hsync +vsync (35.9 kHz d)
[ 9.775] (II) modeset(0): Modeline "1024x576"x59.8 42.00 1024 1072 1104 1184 576 579 584 593 +hsync -vsync (35.5 kHz d)
[ 9.775] (II) modeset(0): Modeline "960x600"x119.9 96.62 960 1028 1128 1296 600 601 604 622 doublescan -hsync +vsync (74.6 kHz d)
[ 9.775] (II) modeset(0): Modeline "960x600"x120.0 77.00 960 984 1000 1040 600 601 604 617 doublescan +hsync -vsync (74.0 kHz d)
[ 9.775] (II) modeset(0): Modeline "960x540"x119.9 86.50 960 1024 1124 1288 540 541 544 560 doublescan -hsync +vsync (67.2 kHz d)
[ 9.775] (II) modeset(0): Modeline "960x540"x120.0 69.25 960 984 1000 1040 540 541 544 555 doublescan +hsync -vsync (66.6 kHz d)
[ 9.775] (II) modeset(0): Modeline "960x540"x59.6 40.75 960 992 1088 1216 540 543 548 562 -hsync +vsync (33.5 kHz d)
[ 9.775] (II) modeset(0): Modeline "960x540"x59.8 37.25 960 1008 1040 1120 540 543 548 556 +hsync -vsync (33.3 kHz d)
[ 9.775] (II) modeset(0): Modeline "800x600"x120.0 81.00 800 832 928 1080 600 600 602 625 doublescan +hsync +vsync (75.0 kHz d)
[ 9.775] (II) modeset(0): Modeline "800x600"x60.3 40.00 800 840 968 1056 600 601 605 628 +hsync +vsync (37.9 kHz d)
[ 9.775] (II) modeset(0): Modeline "800x600"x56.2 36.00 800 824 896 1024 600 601 603 625 +hsync +vsync (35.2 kHz d)
[ 9.775] (II) modeset(0): Modeline "840x525"x120.0 73.12 840 892 980 1120 525 526 529 544 doublescan -hsync +vsync (65.3 kHz d)
[ 9.775] (II) modeset(0): Modeline "840x525"x119.8 59.50 840 864 880 920 525 526 529 540 doublescan +hsync -vsync (64.7 kHz d)
[ 9.775] (II) modeset(0): Modeline "864x486"x59.9 32.50 864 888 968 1072 486 489 494 506 -hsync +vsync (30.3 kHz d)
[ 9.775] (II) modeset(0): Modeline "864x486"x59.6 30.50 864 912 944 1024 486 489 494 500 +hsync -vsync (29.8 kHz d)
[ 9.775] (II) modeset(0): Modeline "800x512"x120.3 51.56 800 800 828 832 512 512 514 515 doublescan +hsync +vsync (62.0 kHz d)
[ 9.775] (II) modeset(0): Modeline "700x525"x120.0 61.00 700 744 820 940 525 526 532 541 doublescan +hsync +vsync (64.9 kHz d)
[ 9.775] (II) modeset(0): Modeline "800x450"x119.9 59.12 800 848 928 1056 450 451 454 467 doublescan -hsync +vsync (56.0 kHz d)
[ 9.775] (II) modeset(0): Modeline "800x450"x119.6 48.75 800 824 840 880 450 451 454 463 doublescan +hsync -vsync (55.4 kHz d)
[ 9.775] (II) modeset(0): Modeline "640x512"x120.0 54.00 640 664 720 844 512 512 514 533 doublescan +hsync +vsync (64.0 kHz d)
[ 9.775] (II) modeset(0): Modeline "720x450"x119.8 53.25 720 760 836 952 450 451 454 467 doublescan -hsync +vsync (55.9 kHz d)
[ 9.775] (II) modeset(0): Modeline "700x450"x119.9 51.75 700 740 812 924 450 451 456 467 doublescan -hsync +vsync (56.0 kHz d)
[ 9.775] (II) modeset(0): Modeline "700x450"x119.8 43.25 700 724 740 780 450 451 456 463 doublescan +hsync -vsync (55.4 kHz d)
[ 9.775] (II) modeset(0): Modeline "640x480"x120.0 54.00 640 688 744 900 480 480 482 500 doublescan +hsync +vsync (60.0 kHz d)
[ 9.775] (II) modeset(0): Modeline "640x480"x59.9 25.18 640 656 752 800 480 490 492 525 -hsync -vsync (31.5 kHz d)
[ 9.775] (II) modeset(0): Modeline "720x405"x59.5 22.50 720 744 808 896 405 408 413 422 -hsync +vsync (25.1 kHz d)
[ 9.775] (II) modeset(0): Modeline "720x405"x59.0 21.75 720 768 800 880 405 408 413 419 +hsync -vsync (24.7 kHz d)
[ 9.775] (II) modeset(0): Modeline "684x384"x119.8 42.62 684 720 788 892 384 385 390 399 doublescan -hsync +vsync (47.8 kHz d)
[ 9.775] (II) modeset(0): Modeline "684x384"x119.7 36.12 684 708 724 764 384 385 390 395 doublescan +hsync -vsync (47.3 kHz d)
[ 9.775] (II) modeset(0): Modeline "680x384"x119.6 42.38 680 716 784 888 384 385 390 399 doublescan -hsync +vsync (47.7 kHz d)
[ 9.775] (II) modeset(0): Modeline "680x384"x119.9 36.00 680 704 720 760 384 385 390 395 doublescan +hsync -vsync (47.4 kHz d)
[ 9.775] (II) modeset(0): Modeline "640x400"x119.8 41.75 640 676 740 840 400 401 404 415 doublescan -hsync +vsync (49.7 kHz d)
[ 9.775] (II) modeset(0): Modeline "640x400"x120.0 35.50 640 664 680 720 400 401 404 411 doublescan +hsync -vsync (49.3 kHz d)
[ 9.775] (II) modeset(0): Modeline "576x432"x120.1 40.81 576 608 668 760 432 432 434 447 doublescan -hsync +vsync (53.7 kHz d)
[ 9.775] (II) modeset(0): Modeline "640x360"x119.7 37.25 640 672 736 832 360 361 364 374 doublescan -hsync +vsync (44.8 kHz d)
[ 9.775] (II) modeset(0): Modeline "640x360"x119.7 31.88 640 664 680 720 360 361 364 370 doublescan +hsync -vsync (44.3 kHz d)
[ 9.775] (II) modeset(0): Modeline "640x360"x59.8 18.00 640 664 720 800 360 363 368 376 -hsync +vsync (22.5 kHz d)
[ 9.775] (II) modeset(0): Modeline "640x360"x59.3 17.75 640 688 720 800 360 363 368 374 +hsync -vsync (22.2 kHz d)
[ 9.775] (II) modeset(0): Modeline "512x384"x120.0 32.50 512 524 592 672 384 385 388 403 doublescan -hsync -vsync (48.4 kHz d)
[ 9.775] (II) modeset(0): Modeline "512x288"x120.0 23.25 512 532 580 648 288 289 292 299 doublescan -hsync +vsync (35.9 kHz d)
[ 9.775] (II) modeset(0): Modeline "512x288"x119.8 21.00 512 536 552 592 288 289 292 296 doublescan +hsync -vsync (35.5 kHz d)
[ 9.775] (II) modeset(0): Modeline "480x270"x119.3 20.38 480 496 544 608 270 271 274 281 doublescan -hsync +vsync (33.5 kHz d)
[ 9.775] (II) modeset(0): Modeline "480x270"x119.6 18.62 480 504 520 560 270 271 274 278 doublescan +hsync -vsync (33.3 kHz d)
[ 9.775] (II) modeset(0): Modeline "400x300"x120.6 20.00 400 420 484 528 300 300 302 314 doublescan +hsync +vsync (37.9 kHz d)
[ 9.775] (II) modeset(0): Modeline "400x300"x112.7 18.00 400 412 448 512 300 300 301 312 doublescan +hsync +vsync (35.2 kHz d)
[ 9.775] (II) modeset(0): Modeline "432x243"x119.8 16.25 432 444 484 536 243 244 247 253 doublescan -hsync +vsync (30.3 kHz d)
[ 9.775] (II) modeset(0): Modeline "432x243"x119.1 15.25 432 456 472 512 243 244 247 250 doublescan +hsync -vsync (29.8 kHz d)
[ 9.775] (II) modeset(0): Modeline "320x240"x120.1 12.59 320 328 376 400 240 245 246 262 doublescan -hsync -vsync (31.5 kHz d)
[ 9.775] (II) modeset(0): Modeline "360x202"x119.0 11.25 360 372 404 448 202 204 206 211 doublescan -hsync +vsync (25.1 kHz d)
[ 9.775] (II) modeset(0): Modeline "360x202"x118.3 10.88 360 384 400 440 202 204 206 209 doublescan +hsync -vsync (24.7 kHz d)
[ 9.775] (II) modeset(0): Modeline "320x180"x119.7 9.00 320 332 360 400 180 181 184 188 doublescan -hsync +vsync (22.5 kHz d)
[ 9.775] (II) modeset(0): Modeline "320x180"x118.6 8.88 320 344 360 400 180 181 184 187 doublescan +hsync -vsync (22.2 kHz d)
[ 9.890] (II) modeset(0): EDID for output VGA-1
[ 9.890] (II) modeset(0): Output LVDS-1 connected
[ 9.890] (II) modeset(0): Output VGA-1 disconnected
[ 9.890] (II) modeset(0): Using exact sizes for initial modes
[ 9.890] (II) modeset(0): Output LVDS-1 using initial mode 1920x1080 +0+0
[ 9.890] (==) modeset(0): Using gamma correction (1.0, 1.0, 1.0)
[ 9.890] (==) modeset(0): DPI set to (96, 96)
[ 9.890] (II) Loading sub module "fb"
[ 9.890] (II) LoadModule: "fb"
[ 9.891] (II) Loading /usr/lib/xorg/modules/libfb.so
[ 9.893] (II) Module fb: vendor="X.Org Foundation"
[ 9.893] compiled for 1.20.11, module version = 1.0.0
[ 9.893] ABI class: X.Org ANSI C Emulation, version 0.4
[ 9.893] (II) UnloadModule: "fbdev"
[ 9.893] (II) Unloading fbdev
[ 9.893] (II) UnloadSubModule: "fbdevhw"
[ 9.893] (II) Unloading fbdevhw
[ 9.894] (II) UnloadModule: "vesa"
[ 9.894] (II) Unloading vesa
[ 9.916] (==) modeset(0): Backing store enabled
[ 9.916] (==) modeset(0): Silken mouse enabled
[ 9.938] (II) modeset(0): Initializing kms color map for depth 24, 8 bpc.
[ 9.938] (==) modeset(0): DPMS enabled
[ 9.939] (II) modeset(0): [DRI2] Setup complete
[ 9.939] (II) modeset(0): [DRI2] DRI driver: i965
[ 9.939] (II) modeset(0): [DRI2] VDPAU driver: va_gl
[ 9.939] (II) Initializing extension Generic Event Extension
[ 9.939] (II) Initializing extension SHAPE
[ 9.940] (II) Initializing extension MIT-SHM
[ 9.940] (II) Initializing extension XInputExtension
[ 9.941] (II) Initializing extension XTEST
[ 9.941] (II) Initializing extension BIG-REQUESTS
[ 9.942] (II) Initializing extension SYNC
[ 9.942] (II) Initializing extension XKEYBOARD
[ 9.942] (II) Initializing extension XC-MISC
[ 9.943] (II) Initializing extension SECURITY
[ 9.943] (II) Initializing extension XFIXES
[ 9.943] (II) Initializing extension RENDER
[ 9.943] (II) Initializing extension RANDR
[ 9.944] (II) Initializing extension COMPOSITE
[ 9.944] (II) Initializing extension DAMAGE
[ 9.945] (II) Initializing extension MIT-SCREEN-SAVER
[ 9.945] (II) Initializing extension DOUBLE-BUFFER
[ 9.945] (II) Initializing extension RECORD
[ 9.945] (II) Initializing extension DPMS
[ 9.946] (II) Initializing extension Present
[ 9.946] (II) Initializing extension DRI3
[ 9.946] (II) Initializing extension X-Resource
[ 9.947] (II) Initializing extension XVideo
[ 9.947] (II) Initializing extension XVideo-MotionCompensation
[ 9.947] (II) Initializing extension SELinux
[ 9.947] (II) SELinux: Disabled on system
[ 9.947] (II) Initializing extension GLX
[ 9.959] (II) AIGLX: Loaded and initialized i965
[ 9.959] (II) GLX: Initialized DRI2 GL provider for screen 0
[ 9.959] (II) Initializing extension XFree86-VidModeExtension
[ 9.959] (II) Initializing extension XFree86-DGA
[ 9.959] (II) Initializing extension XFree86-DRI
[ 9.959] (II) Initializing extension DRI2
[ 9.970] (II) modeset(0): Damage tracking initialized
[ 9.970] (II) modeset(0): Setting screen physical size to 508 x 285
[ 10.055] (II) config/udev: Adding input device Power Button (/dev/input/event3)
[ 10.056] (**) Power Button: Applying InputClass "evdev keyboard catchall"
[ 10.056] (**) Power Button: Applying InputClass "libinput keyboard catchall"
[ 10.056] (II) LoadModule: "evdev"
[ 10.056] (II) Loading /usr/lib/xorg/modules/input/evdev_drv.so
[ 10.058] (II) Module evdev: vendor="X.Org Foundation"
[ 10.058] compiled for 1.20.8, module version = 2.10.6
[ 10.058] Module class: X.Org XInput Driver
[ 10.058] ABI class: X.Org XInput driver, version 24.1
[ 10.058] (II) Using input driver 'evdev' for 'Power Button'
[ 10.058] (**) Power Button: always reports core events
[ 10.058] (**) evdev: Power Button: Device: "/dev/input/event3"
[ 10.058] (--) evdev: Power Button: Vendor 0 Product 0x1
[ 10.058] (--) evdev: Power Button: Found keys
[ 10.058] (II) evdev: Power Button: Configuring as keyboard
[ 10.058] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXPWRBN:00/input/input4/event3"
[ 10.058] (II) XINPUT: Adding extended input device "Power Button" (type: KEYBOARD, id 6)
[ 10.058] (**) Option "xkb_rules" "evdev"
[ 10.058] (**) Option "xkb_model" "pc105"
[ 10.058] (**) Option "xkb_layout" "us"
[ 10.058] (**) Option "xkb_options" "grp:rctrl_rshift_toggle,terminate:ctrl_alt_bksp,grp_led:scroll"
[ 10.088] (II) config/udev: Adding input device Video Bus (/dev/input/event4)
[ 10.089] (**) Video Bus: Applying InputClass "evdev keyboard catchall"
[ 10.089] (**) Video Bus: Applying InputClass "libinput keyboard catchall"
[ 10.089] (II) Using input driver 'evdev' for 'Video Bus'
[ 10.089] (**) Video Bus: always reports core events
[ 10.089] (**) evdev: Video Bus: Device: "/dev/input/event4"
[ 10.089] (--) evdev: Video Bus: Vendor 0 Product 0x6
[ 10.089] (--) evdev: Video Bus: Found keys
[ 10.089] (II) evdev: Video Bus: Configuring as keyboard
[ 10.089] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/LNXVIDEO:00/input/input6/event4"
[ 10.089] (II) XINPUT: Adding extended input device "Video Bus" (type: KEYBOARD, id 7)
[ 10.089] (**) Option "xkb_rules" "evdev"
[ 10.089] (**) Option "xkb_model" "pc105"
[ 10.089] (**) Option "xkb_layout" "us"
[ 10.089] (**) Option "xkb_options" "grp:rctrl_rshift_toggle,terminate:ctrl_alt_bksp,grp_led:scroll"
[ 10.092] (II) config/udev: Adding input device Video Bus (/dev/input/event5)
[ 10.092] (**) Video Bus: Applying InputClass "evdev keyboard catchall"
[ 10.092] (**) Video Bus: Applying InputClass "libinput keyboard catchall"
[ 10.092] (II) Using input driver 'evdev' for 'Video Bus'
[ 10.092] (**) Video Bus: always reports core events
[ 10.092] (**) evdev: Video Bus: Device: "/dev/input/event5"
[ 10.092] (--) evdev: Video Bus: Vendor 0 Product 0x6
[ 10.092] (--) evdev: Video Bus: Found keys
[ 10.092] (II) evdev: Video Bus: Configuring as keyboard
[ 10.092] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/device:09/LNXVIDEO:01/input/input7/event5"
[ 10.092] (II) XINPUT: Adding extended input device "Video Bus" (type: KEYBOARD, id 8)
[ 10.093] (**) Option "xkb_rules" "evdev"
[ 10.093] (**) Option "xkb_model" "pc105"
[ 10.093] (**) Option "xkb_layout" "us"
[ 10.093] (**) Option "xkb_options" "grp:rctrl_rshift_toggle,terminate:ctrl_alt_bksp,grp_led:scroll"
[ 10.094] (II) config/udev: Adding input device Lid Switch (/dev/input/event1)
[ 10.094] (II) No input driver specified, ignoring this device.
[ 10.094] (II) This device may have been added with another device file.
[ 10.095] (II) config/udev: Adding input device Sleep Button (/dev/input/event2)
[ 10.095] (**) Sleep Button: Applying InputClass "evdev keyboard catchall"
[ 10.095] (**) Sleep Button: Applying InputClass "libinput keyboard catchall"
[ 10.095] (II) Using input driver 'evdev' for 'Sleep Button'
[ 10.095] (**) Sleep Button: always reports core events
[ 10.095] (**) evdev: Sleep Button: Device: "/dev/input/event2"
[ 10.095] (--) evdev: Sleep Button: Vendor 0 Product 0x3
[ 10.095] (--) evdev: Sleep Button: Found keys
[ 10.095] (II) evdev: Sleep Button: Configuring as keyboard
[ 10.095] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0E:00/input/input3/event2"
[ 10.095] (II) XINPUT: Adding extended input device "Sleep Button" (type: KEYBOARD, id 9)
[ 10.095] (**) Option "xkb_rules" "evdev"
[ 10.095] (**) Option "xkb_model" "pc105"
[ 10.095] (**) Option "xkb_layout" "us"
[ 10.095] (**) Option "xkb_options" "grp:rctrl_rshift_toggle,terminate:ctrl_alt_bksp,grp_led:scroll"
[ 10.096] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=3 (/dev/input/event15)
[ 10.096] (II) No input driver specified, ignoring this device.
[ 10.096] (II) This device may have been added with another device file.
[ 10.096] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=7 (/dev/input/event16)
[ 10.097] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=8 (/dev/input/event17)
[ 10.097] (II) No input driver specified, ignoring this device.
[ 10.097] (II) This device may have been added with another device file.
[ 10.097] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=9 (/dev/input/event18)
[ 10.098] (II) config/udev: Adding input device Integrated Camera: Integrated C (/dev/input/event10)
[ 10.098] (**) Integrated Camera: Integrated C: Applying InputClass "evdev keyboard catchall"
[ 10.098] (**) Integrated Camera: Integrated C: Applying InputClass "libinput keyboard catchall"
[ 10.098] (II) Using input driver 'evdev' for 'Integrated Camera: Integrated C'
[ 10.098] (**) Integrated Camera: Integrated C: always reports core events
[ 10.098] (**) evdev: Integrated Camera: Integrated C: Device: "/dev/input/event10"
[ 10.098] (--) evdev: Integrated Camera: Integrated C: Vendor 0x4f2 Product 0xb217
[ 10.098] (--) evdev: Integrated Camera: Integrated C: Found keys
[ 10.098] (II) evdev: Integrated Camera: Integrated C: Configuring as keyboard
[ 10.098] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:1a.0/usb1/1-1/1-1.6/1-1.6:1.0/input/input21/event10"
[ 10.098] (II) XINPUT: Adding extended input device "Integrated Camera: Integrated C" (type: KEYBOARD, id 10)
[ 10.098] (**) Option "xkb_rules" "evdev"
[ 10.098] (**) Option "xkb_model" "pc105"
[ 10.098] (**) Option "xkb_layout" "us"
[ 10.098] (**) Option "xkb_options" "grp:rctrl_rshift_toggle,terminate:ctrl_alt_bksp,grp_led:scroll"
[ 10.099] (II) config/udev: Adding input device HDA Intel PCH Mic (/dev/input/event11)
[ 10.099] (II) No input driver specified, ignoring this device.
[ 10.099] (II) This device may have been added with another device file.
[ 10.099] (II) config/udev: Adding input device HDA Intel PCH Dock Mic (/dev/input/event12)
[ 10.100] (II) config/udev: Adding input device HDA Intel PCH Dock Headphone (/dev/input/event13)
[ 10.100] (II) No input driver specified, ignoring this device.
[ 10.100] (II) This device may have been added with another device file.
[ 10.100] (II) config/udev: Adding input device HDA Intel PCH Headphone (/dev/input/event14)
[ 10.101] (II) config/udev: Adding input device Logitech Wireless Mouse (/dev/input/event7)
[ 10.101] (**) Logitech Wireless Mouse: Applying InputClass "evdev pointer catchall"
[ 10.101] (**) Logitech Wireless Mouse: Applying InputClass "libinput pointer catchall"
[ 10.101] (II) Using input driver 'evdev' for 'Logitech Wireless Mouse'
[ 10.101] (**) Logitech Wireless Mouse: always reports core events
[ 10.101] (**) evdev: Logitech Wireless Mouse: Device: "/dev/input/event7"
[ 10.101] (--) evdev: Logitech Wireless Mouse: Vendor 0x46d Product 0x4054
[ 10.101] (--) evdev: Logitech Wireless Mouse: Found 20 mouse buttons
[ 10.101] (--) evdev: Logitech Wireless Mouse: Found scroll wheel(s)
[ 10.101] (--) evdev: Logitech Wireless Mouse: Found relative axes
[ 10.101] (--) evdev: Logitech Wireless Mouse: Found x and y relative axes
[ 10.101] (II) evdev: Logitech Wireless Mouse: Configuring as mouse
[ 10.101] (II) evdev: Logitech Wireless Mouse: Adding scrollwheel support
[ 10.101] (**) evdev: Logitech Wireless Mouse: YAxisMapping: buttons 4 and 5
[ 10.101] (**) evdev: Logitech Wireless Mouse: EmulateWheelButton: 4, EmulateWheelInertia: 10, EmulateWheelTimeout: 200
[ 10.101] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:1c.6/0000:0e:00.0/usb2/2-2/2-2:1.1/0003:046D:C534.0002/0003:046D:4054.0003/input/input19/event7"
[ 10.101] (II) XINPUT: Adding extended input device "Logitech Wireless Mouse" (type: MOUSE, id 11)
[ 10.101] (II) evdev: Logitech Wireless Mouse: initialized for relative axes.
[ 10.101] (**) Logitech Wireless Mouse: (accel) keeping acceleration scheme 1
[ 10.101] (**) Logitech Wireless Mouse: (accel) acceleration profile 0
[ 10.101] (**) Logitech Wireless Mouse: (accel) acceleration factor: 2.000
[ 10.101] (**) Logitech Wireless Mouse: (accel) acceleration threshold: 4
[ 10.102] (II) config/udev: Adding input device Logitech Wireless Mouse (/dev/input/mouse1)
[ 10.102] (II) No input driver specified, ignoring this device.
[ 10.102] (II) This device may have been added with another device file.
[ 10.103] (II) config/udev: Adding input device AT Translated Set 2 keyboard (/dev/input/event0)
[ 10.103] (**) AT Translated Set 2 keyboard: Applying InputClass "evdev keyboard catchall"
[ 10.103] (**) AT Translated Set 2 keyboard: Applying InputClass "libinput keyboard catchall"
[ 10.103] (II) Using input driver 'evdev' for 'AT Translated Set 2 keyboard'
[ 10.103] (**) AT Translated Set 2 keyboard: always reports core events
[ 10.103] (**) evdev: AT Translated Set 2 keyboard: Device: "/dev/input/event0"
[ 10.103] (--) evdev: AT Translated Set 2 keyboard: Vendor 0x1 Product 0x1
[ 10.103] (--) evdev: AT Translated Set 2 keyboard: Found keys
[ 10.103] (II) evdev: AT Translated Set 2 keyboard: Configuring as keyboard
[ 10.103] (**) Option "config_info" "udev:/sys/devices/platform/i8042/serio0/input/input0/event0"
[ 10.103] (II) XINPUT: Adding extended input device "AT Translated Set 2 keyboard" (type: KEYBOARD, id 12)
[ 10.103] (**) Option "xkb_rules" "evdev"
[ 10.103] (**) Option "xkb_model" "pc105"
[ 10.103] (**) Option "xkb_layout" "us"
[ 10.103] (**) Option "xkb_options" "grp:rctrl_rshift_toggle,terminate:ctrl_alt_bksp,grp_led:scroll"
[ 10.104] (II) config/udev: Adding input device SynPS/2 Synaptics TouchPad (/dev/input/event6)
[ 10.104] (**) SynPS/2 Synaptics TouchPad: Applying InputClass "evdev touchpad catchall"
[ 10.104] (**) SynPS/2 Synaptics TouchPad: Applying InputClass "libinput touchpad catchall"
[ 10.104] (**) SynPS/2 Synaptics TouchPad: Applying InputClass "touchpad catchall"
[ 10.104] (**) SynPS/2 Synaptics TouchPad: Applying InputClass "Default clickpad buttons"
[ 10.104] (II) LoadModule: "synaptics"
[ 10.104] (II) Loading /usr/lib/xorg/modules/input/synaptics_drv.so
[ 10.105] (II) Module synaptics: vendor="X.Org Foundation"
[ 10.105] compiled for 1.20.8, module version = 1.9.1
[ 10.105] Module class: X.Org XInput Driver
[ 10.105] ABI class: X.Org XInput driver, version 24.1
[ 10.105] (II) Using input driver 'synaptics' for 'SynPS/2 Synaptics TouchPad'
[ 10.105] (**) SynPS/2 Synaptics TouchPad: always reports core events
[ 10.105] (**) Option "Device" "/dev/input/event6"
[ 10.150] (II) synaptics: SynPS/2 Synaptics TouchPad: ignoring touch events for semi-multitouch device
[ 10.151] (--) synaptics: SynPS/2 Synaptics TouchPad: x-axis range 1472 - 5888 (res 75)
[ 10.151] (--) synaptics: SynPS/2 Synaptics TouchPad: y-axis range 1408 - 4820 (res 105)
[ 10.151] (--) synaptics: SynPS/2 Synaptics TouchPad: pressure range 0 - 255
[ 10.151] (--) synaptics: SynPS/2 Synaptics TouchPad: finger width range 0 - 15
[ 10.151] (--) synaptics: SynPS/2 Synaptics TouchPad: buttons: left right double triple
[ 10.151] (--) synaptics: SynPS/2 Synaptics TouchPad: Vendor 0x2 Product 0x7
[ 10.151] (**) Option "VertEdgeScroll" "1"
[ 10.151] (**) Option "HorizEdgeScroll" "1"
[ 10.151] (**) Option "CornerCoasting" "1"
[ 10.151] (**) Option "VertTwoFingerScroll" "1"
[ 10.151] (**) Option "HorizTwoFingerScroll" "1"
[ 10.151] (**) Option "RBCornerButton" "9"
[ 10.151] (**) Option "LBCornerButton" "8"
[ 10.151] (**) Option "TapButton1" "1"
[ 10.151] (**) Option "TapButton2" "2"
[ 10.151] (**) Option "TapButton3" "3"
[ 10.151] (**) Option "CircularScrolling" "1"
[ 10.151] (**) Option "CircScrollTrigger" "7"
[ 10.152] (**) Option "MinSpeed" "0.5"
[ 10.152] (**) Option "MaxSpeed" "1.0"
[ 10.152] (**) Option "AccelFactor" "0.075"
[ 10.152] (**) Option "CoastingSpeed" "8"
[ 10.152] (--) synaptics: SynPS/2 Synaptics TouchPad: touchpad found
[ 10.152] (**) SynPS/2 Synaptics TouchPad: always reports core events
[ 10.202] (**) Option "config_info" "udev:/sys/devices/platform/i8042/serio1/input/input5/event6"
[ 10.202] (II) XINPUT: Adding extended input device "SynPS/2 Synaptics TouchPad" (type: TOUCHPAD, id 13)
[ 10.202] (**) synaptics: SynPS/2 Synaptics TouchPad: (accel) MinSpeed is now constant deceleration 2.0
[ 10.203] (**) synaptics: SynPS/2 Synaptics TouchPad: (accel) MaxSpeed is now 2.00
[ 10.203] (**) synaptics: SynPS/2 Synaptics TouchPad: (accel) AccelFactor is now 0.075
[ 10.203] (**) SynPS/2 Synaptics TouchPad: (accel) keeping acceleration scheme 1
[ 10.203] (**) SynPS/2 Synaptics TouchPad: (accel) acceleration profile 1
[ 10.203] (**) SynPS/2 Synaptics TouchPad: (accel) acceleration factor: 2.000
[ 10.203] (**) SynPS/2 Synaptics TouchPad: (accel) acceleration threshold: 4
[ 10.203] (--) synaptics: SynPS/2 Synaptics TouchPad: touchpad found
[ 10.205] (II) config/udev: Adding input device SynPS/2 Synaptics TouchPad (/dev/input/mouse0)
[ 10.205] (**) SynPS/2 Synaptics TouchPad: Ignoring device from InputClass "touchpad ignore duplicates"
[ 10.206] (II) config/udev: Adding input device TPPS/2 IBM TrackPoint (/dev/input/event8)
[ 10.206] (**) TPPS/2 IBM TrackPoint: Applying InputClass "evdev pointer catchall"
[ 10.206] (**) TPPS/2 IBM TrackPoint: Applying InputClass "Trackpoint Wheel Emulation"
[ 10.206] (**) TPPS/2 IBM TrackPoint: Applying InputClass "libinput pointer catchall"
[ 10.207] (**) TPPS/2 IBM TrackPoint: Applying InputClass "evdev pointer catchall"
[ 10.207] (II) Using input driver 'evdev' for 'TPPS/2 IBM TrackPoint'
[ 10.207] (**) TPPS/2 IBM TrackPoint: always reports core events
[ 10.207] (**) evdev: TPPS/2 IBM TrackPoint: Device: "/dev/input/event8"
[ 10.207] (--) evdev: TPPS/2 IBM TrackPoint: Vendor 0x2 Product 0xa
[ 10.207] (--) evdev: TPPS/2 IBM TrackPoint: Found 3 mouse buttons
[ 10.207] (--) evdev: TPPS/2 IBM TrackPoint: Found relative axes
[ 10.207] (--) evdev: TPPS/2 IBM TrackPoint: Found x and y relative axes
[ 10.207] (II) evdev: TPPS/2 IBM TrackPoint: Configuring as mouse
[ 10.207] (**) Option "Emulate3Buttons" "false"
[ 10.207] (**) Option "EmulateWheel" "true"
[ 10.207] (**) Option "EmulateWheelButton" "2"
[ 10.207] (**) Option "YAxisMapping" "4 5"
[ 10.207] (**) evdev: TPPS/2 IBM TrackPoint: YAxisMapping: buttons 4 and 5
[ 10.207] (**) Option "XAxisMapping" "6 7"
[ 10.207] (**) evdev: TPPS/2 IBM TrackPoint: XAxisMapping: buttons 6 and 7
[ 10.207] (**) evdev: TPPS/2 IBM TrackPoint: EmulateWheelButton: 2, EmulateWheelInertia: 10, EmulateWheelTimeout: 200
[ 10.207] (**) Option "config_info" "udev:/sys/devices/platform/i8042/serio1/serio2/input/input8/event8"
[ 10.207] (II) XINPUT: Adding extended input device "TPPS/2 IBM TrackPoint" (type: MOUSE, id 14)
[ 10.207] (II) evdev: TPPS/2 IBM TrackPoint: initialized for relative axes.
[ 10.207] (**) TPPS/2 IBM TrackPoint: (accel) keeping acceleration scheme 1
[ 10.207] (**) TPPS/2 IBM TrackPoint: (accel) acceleration profile 0
[ 10.207] (**) TPPS/2 IBM TrackPoint: (accel) acceleration factor: 2.000
[ 10.207] (**) TPPS/2 IBM TrackPoint: (accel) acceleration threshold: 4
[ 10.208] (II) config/udev: Adding input device TPPS/2 IBM TrackPoint (/dev/input/mouse2)
[ 10.208] (II) No input driver specified, ignoring this device.
[ 10.208] (II) This device may have been added with another device file.
[ 10.209] (II) config/udev: Adding input device ThinkPad Extra Buttons (/dev/input/event9)
[ 10.209] (**) ThinkPad Extra Buttons: Applying InputClass "evdev keyboard catchall"
[ 10.209] (**) ThinkPad Extra Buttons: Applying InputClass "libinput keyboard catchall"
[ 10.209] (II) Using input driver 'evdev' for 'ThinkPad Extra Buttons'
[ 10.209] (**) ThinkPad Extra Buttons: always reports core events
[ 10.209] (**) evdev: ThinkPad Extra Buttons: Device: "/dev/input/event9"
[ 10.209] (--) evdev: ThinkPad Extra Buttons: Vendor 0x17aa Product 0x5054
[ 10.209] (--) evdev: ThinkPad Extra Buttons: Found keys
[ 10.209] (II) evdev: ThinkPad Extra Buttons: Configuring as keyboard
[ 10.209] (**) Option "config_info" "udev:/sys/devices/platform/thinkpad_acpi/input/input20/event9"
[ 10.209] (II) XINPUT: Adding extended input device "ThinkPad Extra Buttons" (type: KEYBOARD, id 15)
[ 10.209] (**) Option "xkb_rules" "evdev"
[ 10.210] (**) Option "xkb_model" "pc105"
[ 10.210] (**) Option "xkb_layout" "us"
[ 10.210] (**) Option "xkb_options" "grp:rctrl_rshift_toggle,terminate:ctrl_alt_bksp,grp_led:scroll"
[ 10.211] (II) config/udev: Adding input device ACPI Virtual Keyboard Device (/dev/input/event19)
[ 10.211] (**) ACPI Virtual Keyboard Device: Applying InputClass "evdev keyboard catchall"
[ 10.211] (**) ACPI Virtual Keyboard Device: Applying InputClass "libinput keyboard catchall"
[ 10.211] (II) Using input driver 'evdev' for 'ACPI Virtual Keyboard Device'
[ 10.211] (**) ACPI Virtual Keyboard Device: always reports core events
[ 10.211] (**) evdev: ACPI Virtual Keyboard Device: Device: "/dev/input/event19"
[ 10.211] (--) evdev: ACPI Virtual Keyboard Device: Vendor 0 Product 0
[ 10.211] (--) evdev: ACPI Virtual Keyboard Device: Found keys
[ 10.211] (II) evdev: ACPI Virtual Keyboard Device: Configuring as keyboard
[ 10.211] (**) Option "config_info" "udev:/sys/devices/virtual/input/input30/event19"
[ 10.211] (II) XINPUT: Adding extended input device "ACPI Virtual Keyboard Device" (type: KEYBOARD, id 16)
[ 10.211] (**) Option "xkb_rules" "evdev"
[ 10.211] (**) Option "xkb_model" "pc105"
[ 10.211] (**) Option "xkb_layout" "us"
[ 10.211] (**) Option "xkb_options" "grp:rctrl_rshift_toggle,terminate:ctrl_alt_bksp,grp_led:scroll"
[ 14.810] (II) modeset(0): EDID vendor "LEN", prod id 16562
[ 14.810] (II) modeset(0): Printing DDC gathered Modelines:
[ 14.810] (II) modeset(0): Modeline "1920x1080"x0.0 139.00 1920 1980 2028 2050 1080 1090 1100 1130 -hsync -vsync (67.8 kHz eP)
[ 14.810] (II) modeset(0): Modeline "1920x1080"x0.0 115.83 1920 1980 2028 2050 1080 1090 1100 1130 -hsync -vsync (56.5 kHz e)
- Here is nvidia-smi result:
| NVIDIA-SMI 390.154 Driver Version: 390.154 |
| 0 Quadro 1000M Off | 00000000:01:00.0 N/A | N/A |
| N/A 49C P0 N/A / N/A | 0MiB / 1985MiB | N/A Default |
| Processes: GPU Memory |
| GPU PID Type Process name Usage |
| 0 Not Supported |
