Nvidia GTX1050Ti - Not Recognizing Second Monitor (HDMI)
Dell Inspirion 15 7000 w/ Nvidia GTX1050Ti Mobile
Linux Mint 19.1 w/ nvidia driver version 390-116
X11 running under lightdm
Primary display to laptop monitor works correctly
Not recognizing second monitor (HDMI port)
lspci -nnk | egrep -A3 -i “3D|VGA”
00:02.0 VGA compatible controller [0300]: Intel Corporation Device [8086:591b] (rev 04)
Subsystem: Dell Device [1028:0798]
Kernel driver in use: i915
Kernel modules: i915
01:00.0 VGA compatible controller [0300]: NVIDIA Corporation GP107M [GeForce GTX 1050 Ti Mobile] [10de:1c8c] (rev a1)
Subsystem: Dell GP107M [GeForce GTX 1050 Ti Mobile] [1028:0798]
Kernel driver in use: nvidia
Kernel modules: nvidiafb, nouveau, nvidia_drm, nvidia
Any suggestions or guidance?
[ 6.861]
X.Org X Server 1.19.6
Release Date: 2017-12-20
[ 6.861] X Protocol Version 11, Revision 0
[ 6.861] Build Operating System: Linux 4.4.0-138-generic x86_64 Ubuntu
[ 6.861] Current Operating System: Linux MB-000-071 4.15.0-48-generic #51-Ubuntu SMP Wed Apr 3 08:28:49 UTC 2019 x86_64
[ 6.861] Kernel command line: BOOT_IMAGE=/boot/vmlinuz-4.15.0-48-generic root=UUID=d26f052e-ad38-4e9d-a40d-55c6644b3fb2 ro quiet splash vt.handoff=1
[ 6.861] Build Date: 25 October 2018 04:11:27PM
[ 6.861] xorg-server 2:1.19.6-1ubuntu4.2 (For technical support please see http://www.ubuntu.com/support)
[ 6.861] Current version of pixman: 0.34.0
[ 6.861] Before reporting problems, check http://wiki.x.org
to make sure that you have the latest version.
[ 6.861] Markers: (–) probed, () from config file, (==) default setting,
(++) from command line, (!!) notice, (II) informational,
(WW) warning, (EE) error, (NI) not implemented, (??) unknown.
[ 6.861] (==) Log file: “/var/log/Xorg.0.log”, Time: Sun Apr 28 16:14:00 2019
[ 6.862] (==) Using system config directory “/usr/share/X11/xorg.conf.d”
[ 6.863] (==) No Layout section. Using the first Screen section.
[ 6.863] (==) No screen section available. Using defaults.
[ 6.863] (
) |–>Screen “Default Screen Section” (0)
[ 6.863] (**) | |–>Monitor “”
[ 6.863] (==) No monitor specified for screen “Default Screen Section”.
Using a default monitor configuration.
[ 6.863] (==) Automatically adding devices
[ 6.863] (==) Automatically enabling devices
[ 6.863] (==) Automatically adding GPU devices
[ 6.863] (==) Automatically binding GPU devices
[ 6.863] (==) Max clients allowed: 256, resource mask: 0x1fffff
[ 6.864] (WW) The directory “/usr/share/fonts/X11/cyrillic” does not exist.
[ 6.864] Entry deleted from font path.
[ 6.864] (WW) The directory “/usr/share/fonts/X11/100dpi/” does not exist.
[ 6.864] (WW) The directory “/usr/share/fonts/X11/75dpi/” does not exist.
[ 6.864] (WW) The directory “/usr/share/fonts/X11/100dpi” does not exist.
[ 6.864] (WW) The directory “/usr/share/fonts/X11/75dpi” does not exist.
[ 6.864] (==) FontPath set to:
/usr/share/fonts/X11/misc,
/usr/share/fonts/X11/Type1,
built-ins
[ 6.864] (==) ModulePath set to “/usr/lib/xorg/modules”
[ 6.864] (II) The server relies on udev to provide the list of input devices.
If no devices become available, reconfigure udev or disable AutoAddDevices.
[ 6.864] (II) Loader magic: 0x55d5f2e6f020
[ 6.864] (II) Module ABI versions:
[ 6.864] X.Org ANSI C Emulation: 0.4
[ 6.864] X.Org Video Driver: 23.0
[ 6.864] X.Org XInput driver : 24.1
[ 6.864] X.Org Server Extension : 10.0
[ 6.865] (++) using VT number 7
[ 6.865] (II) systemd-logind: logind integration requires -keeptty and -keeptty was not provided, disabling logind integration
[ 6.865] (II) xfree86: Adding drm device (/dev/dri/card0)
[ 6.883] (–) PCI:*(0:0:2:0) 8086:591b:1028:0798 rev 4, Mem @ 0xdd000000/16777216, 0xb0000000/268435456, I/O @ 0x0000f000/64, BIOS @ 0x???/131072
[ 6.884] (–) PCI: (0:1:0:0) 10de:1c8c:1028:0798 rev 161, Mem @ 0xde000000/16777216, 0xc0000000/268435456, 0xd0000000/33554432, I/O @ 0x0000e000/128, BIOS @ 0x???/524288
[ 6.884] (II) LoadModule: “glx”
[ 6.884] (II) Loading /usr/lib/xorg/modules/extensions/libglx.so
[ 6.891] (II) Module glx: vendor=“X.Org Foundation”
[ 6.891] compiled for 1.19.6, module version = 1.0.0
[ 6.891] ABI class: X.Org Server Extension, version 10.0
[ 6.891] (==) Matched modesetting as autoconfigured driver 0
[ 6.891] (==) Matched fbdev as autoconfigured driver 1
[ 6.891] (==) Matched vesa as autoconfigured driver 2
[ 6.891] (==) Assigned the driver to the xf86ConfigLayout
[ 6.891] (II) LoadModule: “modesetting”
[ 6.891] (II) Loading /usr/lib/xorg/modules/drivers/modesetting_drv.so
[ 6.892] (II) Module modesetting: vendor=“X.Org Foundation”
[ 6.892] compiled for 1.19.6, module version = 1.19.6
[ 6.892] Module class: X.Org Video Driver
[ 6.892] ABI class: X.Org Video Driver, version 23.0
[ 6.892] (II) LoadModule: “fbdev”
[ 6.892] (II) Loading /usr/lib/xorg/modules/drivers/fbdev_drv.so
[ 6.892] (II) Module fbdev: vendor=“X.Org Foundation”
[ 6.892] compiled for 1.19.3, module version = 0.4.4
[ 6.892] (II) LoadModule: “vesa”
[ 6.892] (II) Loading /usr/lib/xorg/modules/drivers/vesa_drv.so
[ 6.893] (II) Module vesa: vendor=“X.Org Foundation”
[ 6.893] compiled for 1.19.3, module version = 2.3.4
[ 6.893] Module class: X.Org Video Driver
[ 6.893] ABI class: X.Org Video Driver, version 23.0
[ 6.893] (II) modesetting: Driver for Modesetting Kernel Drivers: kms
[ 6.893] (II) FBDEV: driver for framebuffer: fbdev
[ 6.893] (II) VESA: driver for VESA chipsets: vesa
[ 6.915] (II) modeset(0): using drv /dev/dri/card0
[ 6.915] (WW) Falling back to old probe method for fbdev
[ 6.915] (II) Loading sub module “fbdevhw”
[ 6.915] (II) LoadModule: “fbdevhw”
[ 6.916] (II) Loading /usr/lib/xorg/modules/libfbdevhw.so
[ 6.916] (II) Module fbdevhw: vendor=“X.Org Foundation”
[ 6.916] compiled for 1.19.6, module version = 0.0.2
[ 6.916] ABI class: X.Org Video Driver, version 23.0
[ 6.916] (WW) Falling back to old probe method for vesa
[ 6.917] (II) modeset(0): Creating default Display subsection in Screen section
“Default Screen Section” for depth/fbbpp 24/32
[ 6.917] (==) modeset(0): Depth 24, (==) framebuffer bpp 32
[ 6.917] (==) modeset(0): RGB weight 888
[ 6.917] (==) modeset(0): Default visual is TrueColor
[ 6.917] (II) Loading sub module “glamoregl”
[ 6.917] (II) LoadModule: “glamoregl”
[ 6.917] (II) Loading /usr/lib/xorg/modules/libglamoregl.so
[ 6.926] (II) Module glamoregl: vendor=“X.Org Foundation”
[ 6.926] compiled for 1.19.6, module version = 1.0.0
[ 6.926] ABI class: X.Org ANSI C Emulation, version 0.4
[ 6.926] (II) glamor: OpenGL accelerated X.org driver based.
[ 6.976] (II) glamor: EGL version 1.4 (DRI2):
[ 6.988] (II) modeset(0): glamor initialized
[ 6.989] (II) modeset(0): Output eDP-1 has no monitor section
[ 6.990] (II) modeset(0): Output DP-1 has no monitor section
[ 6.991] (II) modeset(0): EDID for output eDP-1
[ 6.991] (II) modeset(0): Manufacturer: AUO Model: 63ed Serial#: 0
[ 6.991] (II) modeset(0): Year: 2017 Week: 0
[ 6.991] (II) modeset(0): EDID Version: 1.4
[ 6.991] (II) modeset(0): Digital Display Input
[ 6.991] (II) modeset(0): 6 bits per channel
[ 6.991] (II) modeset(0): Digital interface is DisplayPort
[ 6.991] (II) modeset(0): Max Image Size [cm]: horiz.: 34 vert.: 19
[ 6.991] (II) modeset(0): Gamma: 2.20
[ 6.991] (II) modeset(0): No DPMS capabilities specified
[ 6.991] (II) modeset(0): Supported color encodings: RGB 4:4:4
[ 6.991] (II) modeset(0): First detailed timing is preferred mode
[ 6.991] (II) modeset(0): Preferred mode is native pixel format and refresh rate
[ 6.991] (II) modeset(0): redX: 0.575 redY: 0.345 greenX: 0.350 greenY: 0.575
[ 6.991] (II) modeset(0): blueX: 0.160 blueY: 0.150 whiteX: 0.313 whiteY: 0.329
[ 6.991] (II) modeset(0): Manufacturer’s mask: 0
[ 6.991] (II) modeset(0): Supported detailed timing:
[ 6.991] (II) modeset(0): clock: 142.0 MHz Image Size: 344 x 193 mm
[ 6.991] (II) modeset(0): h_active: 1920 h_sync: 2028 h_sync_end 2076 h_blank_end 2100 h_border: 0
[ 6.991] (II) modeset(0): v_active: 1080 v_sync: 1090 v_sync_end 1100 v_blanking: 1126 v_border: 0
[ 6.991] (II) modeset(0): clock: 113.6 MHz Image Size: 344 x 193 mm
[ 6.991] (II) modeset(0): CV56F\80B156HAN
[ 6.991] (II) modeset(0): Unknown vendor-specific block 0
[ 6.991] (II) modeset(0): EDID (in hex):
[ 6.991] (II) modeset(0): 00ffffffffffff0006afed6300000000
[ 6.991] (II) modeset(0): 001b0104952213780259259358599329
[ 6.991] (II) modeset(0): 26505400000001010101010101010101
[ 6.991] (II) modeset(0): 010101010101783780b470382e406c30
[ 6.991] (II) modeset(0): aa0058c11000001a602c80b470382e40
[ 6.991] (II) modeset(0): 6c30aa0058c11000001a000000fe0043
[ 6.991] (II) modeset(0): 56353646804231353648414e00000000
[ 6.991] (II) modeset(0): 0000410296001000000a010a202000a9
[ 6.992] (II) modeset(0): Printing probed modes for output eDP-1
[ 6.992] (II) modeset(0): Modeline "1920x1080"x60.1 142.00 1920 2028 2076 2100 1080 1090 1100 1126 +hsync -vsync (67.6 kHz eP)
[ 6.992] (II) modeset(0): Modeline "1920x1080"x120.0 356.38 1920 2080 2288 2656 1080 1081 1084 1118 doublescan -hsync +vsync (134.2 kHz d)
[ 6.992] (II) modeset(0): Modeline "1920x1080"x119.9 266.50 1920 1944 1960 2000 1080 1081 1084 1111 doublescan +hsync -vsync (133.2 kHz d)
[ 6.992] (II) modeset(0): Modeline "1920x1080"x60.0 173.00 1920 2048 2248 2576 1080 1083 1088 1120 -hsync +vsync (67.2 kHz d)
[ 6.992] (II) modeset(0): Modeline "1920x1080"x59.9 138.50 1920 1968 2000 2080 1080 1083 1088 1111 +hsync -vsync (66.6 kHz d)
[ 6.992] (II) modeset(0): Modeline "1920x1080"x48.0 113.60 1920 2028 2076 2100 1080 1090 1100 1126 +hsync -vsync (54.1 kHz e)
[ 6.992] (II) modeset(0): Modeline "1680x1050"x60.0 146.25 1680 1784 1960 2240 1050 1053 1059 1089 -hsync +vsync (65.3 kHz d)
[ 6.992] (II) modeset(0): Modeline "1680x1050"x59.9 119.00 1680 1728 1760 1840 1050 1053 1059 1080 +hsync -vsync (64.7 kHz d)
[ 6.992] (II) modeset(0): Modeline "1600x1024"x60.2 103.12 1600 1600 1656 1664 1024 1024 1029 1030 +hsync +vsync (62.0 kHz d)
[ 6.992] (II) modeset(0): Modeline "1400x1050"x60.0 122.00 1400 1488 1640 1880 1050 1052 1064 1082 +hsync +vsync (64.9 kHz d)
[ 6.992] (II) modeset(0): Modeline "1600x900"x120.0 246.00 1600 1728 1900 2200 900 901 904 932 doublescan -hsync +vsync (111.8 kHz d)
[ 6.992] (II) modeset(0): Modeline "1600x900"x119.9 186.50 1600 1624 1640 1680 900 901 904 926 doublescan +hsync -vsync (111.0 kHz d)
[ 6.992] (II) modeset(0): Modeline "1600x900"x59.9 118.25 1600 1696 1856 2112 900 903 908 934 -hsync +vsync (56.0 kHz d)
[ 6.992] (II) modeset(0): Modeline "1600x900"x59.8 97.50 1600 1648 1680 1760 900 903 908 926 +hsync -vsync (55.4 kHz d)
[ 6.992] (II) modeset(0): Modeline "1280x1024"x60.0 108.00 1280 1328 1440 1688 1024 1025 1028 1066 +hsync +vsync (64.0 kHz d)
[ 6.992] (II) modeset(0): Modeline "1440x900"x59.9 106.50 1440 1520 1672 1904 900 903 909 934 -hsync +vsync (55.9 kHz d)
[ 6.992] (II) modeset(0): Modeline "1400x900"x60.0 103.50 1400 1480 1624 1848 900 903 913 934 -hsync +vsync (56.0 kHz d)
[ 6.992] (II) modeset(0): Modeline "1400x900"x59.9 86.50 1400 1448 1480 1560 900 903 913 926 +hsync -vsync (55.4 kHz d)
[ 6.992] (II) modeset(0): Modeline "1280x960"x60.0 108.00 1280 1376 1488 1800 960 961 964 1000 +hsync +vsync (60.0 kHz d)
[ 6.992] (II) modeset(0): Modeline "1440x810"x120.0 198.12 1440 1548 1704 1968 810 811 814 839 doublescan -hsync +vsync (100.7 kHz d)
[ 6.992] (II) modeset(0): Modeline "1440x810"x119.9 151.88 1440 1464 1480 1520 810 811 814 833 doublescan +hsync -vsync (99.9 kHz d)
[ 6.992] (II) modeset(0): Modeline "1368x768"x59.9 85.25 1368 1440 1576 1784 768 771 781 798 -hsync +vsync (47.8 kHz d)
[ 6.992] (II) modeset(0): Modeline "1368x768"x59.9 72.25 1368 1416 1448 1528 768 771 781 790 +hsync -vsync (47.3 kHz d)
[ 6.992] (II) modeset(0): Modeline "1360x768"x59.8 84.75 1360 1432 1568 1776 768 771 781 798 -hsync +vsync (47.7 kHz d)
[ 6.992] (II) modeset(0): Modeline "1360x768"x60.0 72.00 1360 1408 1440 1520 768 771 781 790 +hsync -vsync (47.4 kHz d)
[ 6.992] (II) modeset(0): Modeline "1280x800"x120.0 174.25 1280 1380 1516 1752 800 801 804 829 doublescan -hsync +vsync (99.5 kHz d)
[ 6.992] (II) modeset(0): Modeline "1280x800"x119.9 134.25 1280 1304 1320 1360 800 801 804 823 doublescan +hsync -vsync (98.7 kHz d)
[ 6.992] (II) modeset(0): Modeline "1280x800"x59.8 83.50 1280 1352 1480 1680 800 803 809 831 -hsync +vsync (49.7 kHz d)
[ 6.992] (II) modeset(0): Modeline "1280x800"x59.9 71.00 1280 1328 1360 1440 800 803 809 823 +hsync -vsync (49.3 kHz d)
[ 6.992] (II) modeset(0): Modeline "1152x864"x60.0 81.62 1152 1216 1336 1520 864 865 868 895 -hsync +vsync (53.7 kHz d)
[ 6.992] (II) modeset(0): Modeline "1280x720"x120.0 156.12 1280 1376 1512 1744 720 721 724 746 doublescan -hsync +vsync (89.5 kHz d)
[ 6.992] (II) modeset(0): Modeline "1280x720"x120.0 120.75 1280 1304 1320 1360 720 721 724 740 doublescan +hsync -vsync (88.8 kHz d)
[ 6.992] (II) modeset(0): Modeline "1280x720"x59.9 74.50 1280 1344 1472 1664 720 723 728 748 -hsync +vsync (44.8 kHz d)
[ 6.992] (II) modeset(0): Modeline "1280x720"x59.7 63.75 1280 1328 1360 1440 720 723 728 741 +hsync -vsync (44.3 kHz d)
[ 6.992] (II) modeset(0): Modeline "1024x768"x120.1 133.47 1024 1100 1212 1400 768 768 770 794 doublescan -hsync +vsync (95.3 kHz d)
[ 6.992] (II) modeset(0): Modeline "1024x768"x60.0 65.00 1024 1048 1184 1344 768 771 777 806 -hsync -vsync (48.4 kHz d)
[ 6.992] (II) modeset(0): Modeline "960x720"x120.0 117.00 960 1024 1128 1300 720 720 722 750 doublescan -hsync +vsync (90.0 kHz d)
[ 6.992] (II) modeset(0): Modeline "928x696"x120.1 109.15 928 976 1088 1264 696 696 698 719 doublescan -hsync +vsync (86.4 kHz d)
[ 6.992] (II) modeset(0): Modeline "896x672"x120.0 102.40 896 960 1060 1224 672 672 674 697 doublescan -hsync +vsync (83.7 kHz d)
[ 6.992] (II) modeset(0): Modeline "1024x576"x119.9 98.50 1024 1092 1200 1376 576 577 580 597 doublescan -hsync +vsync (71.6 kHz d)
[ 6.992] (II) modeset(0): Modeline "1024x576"x119.9 78.38 1024 1048 1064 1104 576 577 580 592 doublescan +hsync -vsync (71.0 kHz d)
[ 6.992] (II) modeset(0): Modeline "1024x576"x59.9 46.50 1024 1064 1160 1296 576 579 584 599 -hsync +vsync (35.9 kHz d)
[ 6.992] (II) modeset(0): Modeline "1024x576"x59.8 42.00 1024 1072 1104 1184 576 579 584 593 +hsync -vsync (35.5 kHz d)
[ 6.992] (II) modeset(0): Modeline "960x600"x119.9 96.62 960 1028 1128 1296 600 601 604 622 doublescan -hsync +vsync (74.6 kHz d)
[ 6.992] (II) modeset(0): Modeline "960x600"x120.0 77.00 960 984 1000 1040 600 601 604 617 doublescan +hsync -vsync (74.0 kHz d)
[ 6.992] (II) modeset(0): Modeline "960x540"x119.9 86.50 960 1024 1124 1288 540 541 544 560 doublescan -hsync +vsync (67.2 kHz d)
[ 6.992] (II) modeset(0): Modeline "960x540"x120.0 69.25 960 984 1000 1040 540 541 544 555 doublescan +hsync -vsync (66.6 kHz d)
[ 6.992] (II) modeset(0): Modeline "960x540"x59.6 40.75 960 992 1088 1216 540 543 548 562 -hsync +vsync (33.5 kHz d)
[ 6.992] (II) modeset(0): Modeline "960x540"x59.8 37.25 960 1008 1040 1120 540 543 548 556 +hsync -vsync (33.3 kHz d)
[ 6.992] (II) modeset(0): Modeline "800x600"x120.0 81.00 800 832 928 1080 600 600 602 625 doublescan +hsync +vsync (75.0 kHz d)
[ 6.992] (II) modeset(0): Modeline "800x600"x60.3 40.00 800 840 968 1056 600 601 605 628 +hsync +vsync (37.9 kHz d)
[ 6.992] (II) modeset(0): Modeline "800x600"x56.2 36.00 800 824 896 1024 600 601 603 625 +hsync +vsync (35.2 kHz d)
[ 6.992] (II) modeset(0): Modeline "840x525"x120.0 73.12 840 892 980 1120 525 526 529 544 doublescan -hsync +vsync (65.3 kHz d)
[ 6.992] (II) modeset(0): Modeline "840x525"x119.8 59.50 840 864 880 920 525 526 529 540 doublescan +hsync -vsync (64.7 kHz d)
[ 6.992] (II) modeset(0): Modeline "864x486"x59.9 32.50 864 888 968 1072 486 489 494 506 -hsync +vsync (30.3 kHz d)
[ 6.992] (II) modeset(0): Modeline "864x486"x59.6 30.50 864 912 944 1024 486 489 494 500 +hsync -vsync (29.8 kHz d)
[ 6.992] (II) modeset(0): Modeline "800x512"x120.3 51.56 800 800 828 832 512 512 514 515 doublescan +hsync +vsync (62.0 kHz d)
[ 6.992] (II) modeset(0): Modeline "700x525"x120.0 61.00 700 744 820 940 525 526 532 541 doublescan +hsync +vsync (64.9 kHz d)
[ 6.992] (II) modeset(0): Modeline "800x450"x119.9 59.12 800 848 928 1056 450 451 454 467 doublescan -hsync +vsync (56.0 kHz d)
[ 6.992] (II) modeset(0): Modeline "800x450"x119.6 48.75 800 824 840 880 450 451 454 463 doublescan +hsync -vsync (55.4 kHz d)
[ 6.992] (II) modeset(0): Modeline "640x512"x120.0 54.00 640 664 720 844 512 512 514 533 doublescan +hsync +vsync (64.0 kHz d)
[ 6.992] (II) modeset(0): Modeline "720x450"x119.8 53.25 720 760 836 952 450 451 454 467 doublescan -hsync +vsync (55.9 kHz d)
[ 6.992] (II) modeset(0): Modeline "700x450"x119.9 51.75 700 740 812 924 450 451 456 467 doublescan -hsync +vsync (56.0 kHz d)
[ 6.992] (II) modeset(0): Modeline "700x450"x119.8 43.25 700 724 740 780 450 451 456 463 doublescan +hsync -vsync (55.4 kHz d)
[ 6.992] (II) modeset(0): Modeline "640x480"x120.0 54.00 640 688 744 900 480 480 482 500 doublescan +hsync +vsync (60.0 kHz d)
[ 6.992] (II) modeset(0): Modeline "640x480"x59.9 25.18 640 656 752 800 480 490 492 525 -hsync -vsync (31.5 kHz d)
[ 6.992] (II) modeset(0): Modeline "720x405"x59.5 22.50 720 744 808 896 405 408 413 422 -hsync +vsync (25.1 kHz d)
[ 6.992] (II) modeset(0): Modeline "720x405"x59.0 21.75 720 768 800 880 405 408 413 419 +hsync -vsync (24.7 kHz d)
[ 6.992] (II) modeset(0): Modeline "684x384"x119.8 42.62 684 720 788 892 384 385 390 399 doublescan -hsync +vsync (47.8 kHz d)
[ 6.992] (II) modeset(0): Modeline "684x384"x119.7 36.12 684 708 724 764 384 385 390 395 doublescan +hsync -vsync (47.3 kHz d)
[ 6.993] (II) modeset(0): Modeline "680x384"x119.6 42.38 680 716 784 888 384 385 390 399 doublescan -hsync +vsync (47.7 kHz d)
[ 6.993] (II) modeset(0): Modeline "680x384"x119.9 36.00 680 704 720 760 384 385 390 395 doublescan +hsync -vsync (47.4 kHz d)
[ 6.993] (II) modeset(0): Modeline "640x400"x119.8 41.75 640 676 740 840 400 401 404 415 doublescan -hsync +vsync (49.7 kHz d)
[ 6.993] (II) modeset(0): Modeline "640x400"x120.0 35.50 640 664 680 720 400 401 404 411 doublescan +hsync -vsync (49.3 kHz d)
[ 6.993] (II) modeset(0): Modeline "576x432"x120.1 40.81 576 608 668 760 432 432 434 447 doublescan -hsync +vsync (53.7 kHz d)
[ 6.993] (II) modeset(0): Modeline "640x360"x119.7 37.25 640 672 736 832 360 361 364 374 doublescan -hsync +vsync (44.8 kHz d)
[ 6.993] (II) modeset(0): Modeline "640x360"x119.7 31.88 640 664 680 720 360 361 364 370 doublescan +hsync -vsync (44.3 kHz d)
[ 6.993] (II) modeset(0): Modeline "640x360"x59.8 18.00 640 664 720 800 360 363 368 376 -hsync +vsync (22.5 kHz d)
[ 6.993] (II) modeset(0): Modeline "640x360"x59.3 17.75 640 688 720 800 360 363 368 374 +hsync -vsync (22.2 kHz d)
[ 6.993] (II) modeset(0): Modeline "512x384"x120.0 32.50 512 524 592 672 384 385 388 403 doublescan -hsync -vsync (48.4 kHz d)
[ 6.993] (II) modeset(0): Modeline "512x288"x120.0 23.25 512 532 580 648 288 289 292 299 doublescan -hsync +vsync (35.9 kHz d)
[ 6.993] (II) modeset(0): Modeline "512x288"x119.8 21.00 512 536 552 592 288 289 292 296 doublescan +hsync -vsync (35.5 kHz d)
[ 6.993] (II) modeset(0): Modeline "480x270"x119.3 20.38 480 496 544 608 270 271 274 281 doublescan -hsync +vsync (33.5 kHz d)
[ 6.993] (II) modeset(0): Modeline "480x270"x119.6 18.62 480 504 520 560 270 271 274 278 doublescan +hsync -vsync (33.3 kHz d)
[ 6.993] (II) modeset(0): Modeline "400x300"x120.6 20.00 400 420 484 528 300 300 302 314 doublescan +hsync +vsync (37.9 kHz d)
[ 6.993] (II) modeset(0): Modeline "400x300"x112.7 18.00 400 412 448 512 300 300 301 312 doublescan +hsync +vsync (35.2 kHz d)
[ 6.993] (II) modeset(0): Modeline "432x243"x119.8 16.25 432 444 484 536 243 244 247 253 doublescan -hsync +vsync (30.3 kHz d)
[ 6.993] (II) modeset(0): Modeline "432x243"x119.1 15.25 432 456 472 512 243 244 247 250 doublescan +hsync -vsync (29.8 kHz d)
[ 6.993] (II) modeset(0): Modeline "320x240"x120.1 12.59 320 328 376 400 240 245 246 262 doublescan -hsync -vsync (31.5 kHz d)
[ 6.993] (II) modeset(0): Modeline "360x202"x119.0 11.25 360 372 404 448 202 204 206 211 doublescan -hsync +vsync (25.1 kHz d)
[ 6.993] (II) modeset(0): Modeline "360x202"x118.3 10.88 360 384 400 440 202 204 206 209 doublescan +hsync -vsync (24.7 kHz d)
[ 6.993] (II) modeset(0): Modeline "320x180"x119.7 9.00 320 332 360 400 180 181 184 188 doublescan -hsync +vsync (22.5 kHz d)
[ 6.993] (II) modeset(0): Modeline "320x180"x118.6 8.88 320 344 360 400 180 181 184 187 doublescan +hsync -vsync (22.2 kHz d)
[ 6.993] (II) modeset(0): EDID for output DP-1
[ 6.993] (II) modeset(0): Output eDP-1 connected
[ 6.993] (II) modeset(0): Output DP-1 disconnected
[ 6.993] (II) modeset(0): Using exact sizes for initial modes
[ 6.993] (II) modeset(0): Output eDP-1 using initial mode 1920x1080 +0+0
[ 6.993] (==) modeset(0): Using gamma correction (1.0, 1.0, 1.0)
[ 6.993] (==) modeset(0): DPI set to (96, 96)
[ 6.993] (II) Loading sub module “fb”
[ 6.993] (II) LoadModule: “fb”
[ 6.993] (II) Loading /usr/lib/xorg/modules/libfb.so
[ 6.994] (II) Module fb: vendor=“X.Org Foundation”
[ 6.994] compiled for 1.19.6, module version = 1.0.0
[ 6.994] ABI class: X.Org ANSI C Emulation, version 0.4
[ 6.994] (II) UnloadModule: “fbdev”
[ 6.994] (II) Unloading fbdev
[ 6.994] (II) UnloadSubModule: “fbdevhw”
[ 6.994] (II) Unloading fbdevhw
[ 6.994] (II) UnloadModule: “vesa”
[ 6.994] (II) Unloading vesa
[ 6.994] (==) Depth 24 pixmap format is 32 bpp
[ 7.004] (==) modeset(0): Backing store enabled
[ 7.004] (==) modeset(0): Silken mouse enabled
[ 7.004] (II) modeset(0): RandR 1.2 enabled, ignore the following RandR disabled message.
[ 7.066] (==) modeset(0): DPMS enabled
[ 7.066] (II) modeset(0): [DRI2] Setup complete
[ 7.066] (II) modeset(0): [DRI2] DRI driver: i965
[ 7.066] (II) modeset(0): [DRI2] VDPAU driver: i965
[ 7.066] (–) RandR disabled
[ 7.071] (II) SELinux: Disabled on system
[ 7.081] (II) AIGLX: enabled GLX_MESA_copy_sub_buffer
[ 7.081] (II) AIGLX: enabled GLX_ARB_create_context
[ 7.081] (II) AIGLX: enabled GLX_ARB_create_context_profile
[ 7.081] (II) AIGLX: enabled GLX_EXT_create_context_es{,2}_profile
[ 7.081] (II) AIGLX: enabled GLX_INTEL_swap_event
[ 7.081] (II) AIGLX: enabled GLX_SGI_swap_control
[ 7.081] (II) AIGLX: enabled GLX_EXT_framebuffer_sRGB
[ 7.081] (II) AIGLX: enabled GLX_ARB_fbconfig_float
[ 7.081] (II) AIGLX: enabled GLX_EXT_fbconfig_packed_float
[ 7.081] (II) AIGLX: GLX_EXT_texture_from_pixmap backed by buffer objects
[ 7.081] (II) AIGLX: enabled GLX_ARB_create_context_robustness
[ 7.082] (II) AIGLX: Loaded and initialized i965
[ 7.082] (II) GLX: Initialized DRI2 GL provider for screen 0
[ 7.094] (II) modeset(0): Damage tracking initialized
[ 7.094] (II) modeset(0): Setting screen physical size to 508 x 285
[ 7.140] (II) config/udev: Adding input device Power Button (/dev/input/event3)
[ 7.141] () Power Button: Applying InputClass “libinput keyboard catchall”
[ 7.141] (II) LoadModule: “libinput”
[ 7.141] (II) Loading /usr/lib/xorg/modules/input/libinput_drv.so
[ 7.144] (II) Module libinput: vendor=“X.Org Foundation”
[ 7.144] compiled for 1.19.6, module version = 0.27.1
[ 7.144] Module class: X.Org XInput Driver
[ 7.144] ABI class: X.Org XInput driver, version 24.1
[ 7.144] (II) Using input driver ‘libinput’ for ‘Power Button’
[ 7.144] (
) Power Button: always reports core events
[ 7.144] () Option “Device” “/dev/input/event3”
[ 7.144] (
) Option “_source” “server/udev”
[ 7.145] (II) event3 - Power Button: is tagged by udev as: Keyboard
[ 7.145] (II) event3 - Power Button: device is a keyboard
[ 7.145] (II) event3 - Power Button: device removed
[ 7.176] () Option “config_info” “udev:/sys/devices/LNXSYSTM:00/LNXPWRBN:00/input/input3/event3”
[ 7.176] (II) XINPUT: Adding extended input device “Power Button” (type: KEYBOARD, id 6)
[ 7.176] (
) Option “xkb_model” “pc105”
[ 7.176] () Option “xkb_layout” “us”
[ 7.176] (II) event3 - Power Button: is tagged by udev as: Keyboard
[ 7.176] (II) event3 - Power Button: device is a keyboard
[ 7.176] (II) config/udev: Adding input device Video Bus (/dev/input/event5)
[ 7.177] (
) Video Bus: Applying InputClass “libinput keyboard catchall”
[ 7.177] (II) Using input driver ‘libinput’ for ‘Video Bus’
[ 7.177] () Video Bus: always reports core events
[ 7.177] (
) Option “Device” “/dev/input/event5”
[ 7.177] () Option “_source” “server/udev”
[ 7.177] (II) event5 - Video Bus: is tagged by udev as: Keyboard
[ 7.177] (II) event5 - Video Bus: device is a keyboard
[ 7.177] (II) event5 - Video Bus: device removed
[ 7.204] (
) Option “config_info” “udev:/sys/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/LNXVIDEO:00/input/input7/event5”
[ 7.204] (II) XINPUT: Adding extended input device “Video Bus” (type: KEYBOARD, id 7)
[ 7.204] () Option “xkb_model” “pc105”
[ 7.204] (
[ 7.204] (II) event5 - Video Bus: is tagged by udev as: Keyboard
[ 7.204] (II) event5 - Video Bus: device is a keyboard
[ 7.205] (II) config/udev: Adding input device Video Bus (/dev/input/event6)
[ 7.205] () Video Bus: Applying InputClass “libinput keyboard catchall”
[ 7.205] (II) Using input driver ‘libinput’ for ‘Video Bus’
[ 7.205] (
[ 7.205] () Option “Device” “/dev/input/event6”
[ 7.205] (
[ 7.205] (II) event6 - Video Bus: is tagged by udev as: Keyboard
[ 7.205] (II) event6 - Video Bus: device is a keyboard
[ 7.205] (II) event6 - Video Bus: device removed
[ 7.220] () Option “config_info” “udev:/sys/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/device:0a/LNXVIDEO:01/input/input8/event6”
[ 7.220] (II) XINPUT: Adding extended input device “Video Bus” (type: KEYBOARD, id 8)
[ 7.220] (
[ 7.220] () Option “xkb_layout” “us”
[ 7.220] (II) event6 - Video Bus: is tagged by udev as: Keyboard
[ 7.220] (II) event6 - Video Bus: device is a keyboard
[ 7.221] (II) config/udev: Adding input device Power Button (/dev/input/event1)
[ 7.221] (
[ 7.221] (II) Using input driver ‘libinput’ for ‘Power Button’
[ 7.221] () Power Button: always reports core events
[ 7.221] (
) Option “Device” “/dev/input/event1”
[ 7.221] () Option “_source” “server/udev”
[ 7.221] (II) event1 - Power Button: is tagged by udev as: Keyboard
[ 7.221] (II) event1 - Power Button: device is a keyboard
[ 7.221] (II) event1 - Power Button: device removed
[ 7.240] (
) Option “config_info” “udev:/sys/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0C:00/input/input1/event1”
[ 7.240] (II) XINPUT: Adding extended input device “Power Button” (type: KEYBOARD, id 9)
[ 7.240] () Option “xkb_model” “pc105”
[ 7.240] (
[ 7.240] (II) event1 - Power Button: is tagged by udev as: Keyboard
[ 7.240] (II) event1 - Power Button: device is a keyboard
[ 7.241] (II) config/udev: Adding input device Lid Switch (/dev/input/event0)
[ 7.241] (II) No input driver specified, ignoring this device.
[ 7.241] (II) This device may have been added with another device file.
[ 7.241] (II) config/udev: Adding input device Sleep Button (/dev/input/event2)
[ 7.241] () Sleep Button: Applying InputClass “libinput keyboard catchall”
[ 7.241] (II) Using input driver ‘libinput’ for ‘Sleep Button’
[ 7.241] (
) Sleep Button: always reports core events
[ 7.241] () Option “Device” “/dev/input/event2”
[ 7.241] (
[ 7.242] (II) event2 - Sleep Button: is tagged by udev as: Keyboard
[ 7.242] (II) event2 - Sleep Button: device is a keyboard
[ 7.242] (II) event2 - Sleep Button: device removed
[ 7.256] () Option “config_info” “udev:/sys/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0E:00/input/input2/event2”
[ 7.256] (II) XINPUT: Adding extended input device “Sleep Button” (type: KEYBOARD, id 10)
[ 7.256] (
[ 7.256] () Option “xkb_layout” “us”
[ 7.257] (II) event2 - Sleep Button: is tagged by udev as: Keyboard
[ 7.257] (II) event2 - Sleep Button: device is a keyboard
[ 7.257] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=3 (/dev/input/event16)
[ 7.257] (II) No input driver specified, ignoring this device.
[ 7.257] (II) This device may have been added with another device file.
[ 7.258] (II) config/udev: Adding input device Logitech USB Laser Mouse (/dev/input/event7)
[ 7.258] (
) Logitech USB Laser Mouse: Applying InputClass “libinput pointer catchall”
[ 7.258] (II) Using input driver ‘libinput’ for ‘Logitech USB Laser Mouse’
[ 7.258] () Logitech USB Laser Mouse: always reports core events
[ 7.258] (
) Option “Device” “/dev/input/event7”
[ 7.258] () Option “_source” “server/udev”
[ 7.316] (II) event7 - Logitech USB Laser Mouse: is tagged by udev as: Mouse
[ 7.317] (II) event7 - Logitech USB Laser Mouse: device set to 1000 DPI
[ 7.317] (II) event7 - Logitech USB Laser Mouse: device is a pointer
[ 7.317] (II) event7 - Logitech USB Laser Mouse: device removed
[ 7.360] (
) Option “config_info” “udev:/sys/devices/pci0000:00/0000:00:14.0/usb1/1-1/1-1:1.0/0003:046D:C069.0001/input/input9/event7”
[ 7.360] (II) XINPUT: Adding extended input device “Logitech USB Laser Mouse” (type: MOUSE, id 11)
[ 7.360] () Option “AccelerationScheme” “none”
[ 7.360] (
) Logitech USB Laser Mouse: (accel) selected scheme none/0
[ 7.360] () Logitech USB Laser Mouse: (accel) acceleration factor: 2.000
[ 7.360] (
) Logitech USB Laser Mouse: (accel) acceleration threshold: 4
[ 7.420] (II) event7 - Logitech USB Laser Mouse: is tagged by udev as: Mouse
[ 7.420] (II) event7 - Logitech USB Laser Mouse: device set to 1000 DPI
[ 7.420] (II) event7 - Logitech USB Laser Mouse: device is a pointer
[ 7.422] (II) config/udev: Adding input device Logitech USB Laser Mouse (/dev/input/mouse0)
[ 7.422] (II) No input driver specified, ignoring this device.
[ 7.422] (II) This device may have been added with another device file.
[ 7.423] (II) config/udev: Adding input device Integrated Webcam: Integrated W (/dev/input/event13)
[ 7.423] () Integrated Webcam: Integrated W: Applying InputClass “libinput keyboard catchall”
[ 7.423] (II) Using input driver ‘libinput’ for ‘Integrated Webcam: Integrated W’
[ 7.423] (
) Integrated Webcam: Integrated W: always reports core events
[ 7.423] () Option “Device” “/dev/input/event13”
[ 7.423] (
[ 7.424] (II) event13 - Integrated Webcam: Integrated W: is tagged by udev as: Keyboard
[ 7.424] (II) event13 - Integrated Webcam: Integrated W: device is a keyboard
[ 7.424] (II) event13 - Integrated Webcam: Integrated W: device removed
[ 7.464] () Option “config_info” “udev:/sys/devices/pci0000:00/0000:00:14.0/usb1/1-12/1-12:1.0/input/input14/event13”
[ 7.464] (II) XINPUT: Adding extended input device “Integrated Webcam: Integrated W” (type: KEYBOARD, id 12)
[ 7.464] (
[ 7.464] () Option “xkb_layout” “us”
[ 7.465] (II) event13 - Integrated Webcam: Integrated W: is tagged by udev as: Keyboard
[ 7.465] (II) event13 - Integrated Webcam: Integrated W: device is a keyboard
[ 7.466] (II) config/udev: Adding input device Logitech Logitech Illuminated Keyboard (/dev/input/event8)
[ 7.466] (
) Logitech Logitech Illuminated Keyboard: Applying InputClass “libinput keyboard catchall”
[ 7.466] (II) Using input driver ‘libinput’ for ‘Logitech Logitech Illuminated Keyboard’
[ 7.466] () Logitech Logitech Illuminated Keyboard: always reports core events
[ 7.466] (
) Option “Device” “/dev/input/event8”
[ 7.466] () Option “_source” “server/udev”
[ 7.467] (II) event8 - Logitech Logitech Illuminated Keyboard: is tagged by udev as: Keyboard
[ 7.467] (II) event8 - Logitech Logitech Illuminated Keyboard: device is a keyboard
[ 7.467] (II) event8 - Logitech Logitech Illuminated Keyboard: device removed
[ 7.480] (
) Option “config_info” “udev:/sys/devices/pci0000:00/0000:00:14.0/usb1/1-2/1-2:1.0/0003:046D:C318.0002/input/input10/event8”
[ 7.480] (II) XINPUT: Adding extended input device “Logitech Logitech Illuminated Keyboard” (type: KEYBOARD, id 13)
[ 7.480] () Option “xkb_model” “pc105”
[ 7.480] (
[ 7.481] (II) event8 - Logitech Logitech Illuminated Keyboard: is tagged by udev as: Keyboard
[ 7.481] (II) event8 - Logitech Logitech Illuminated Keyboard: device is a keyboard
[ 7.482] (II) config/udev: Adding input device Logitech Logitech Illuminated Keyboard (/dev/input/event9)
[ 7.482] () Logitech Logitech Illuminated Keyboard: Applying InputClass “libinput keyboard catchall”
[ 7.482] (II) Using input driver ‘libinput’ for ‘Logitech Logitech Illuminated Keyboard’
[ 7.482] (
[ 7.482] () Option “Device” “/dev/input/event9”
[ 7.482] (
[ 7.483] (II) event9 - Logitech Logitech Illuminated Keyboard: is tagged by udev as: Keyboard
[ 7.483] (II) event9 - Logitech Logitech Illuminated Keyboard: device is a keyboard
[ 7.483] (II) event9 - Logitech Logitech Illuminated Keyboard: device removed
[ 7.496] (II) libinput: Logitech Logitech Illuminated Keyboard: needs a virtual subdevice
[ 7.496] () Option “config_info” “udev:/sys/devices/pci0000:00/0000:00:14.0/usb1/1-2/1-2:1.1/0003:046D:C318.0003/input/input11/event9”
[ 7.496] (II) XINPUT: Adding extended input device “Logitech Logitech Illuminated Keyboard” (type: MOUSE, id 14)
[ 7.496] (
[ 7.496] () Logitech Logitech Illuminated Keyboard: (accel) selected scheme none/0
[ 7.496] (
) Logitech Logitech Illuminated Keyboard: (accel) acceleration factor: 2.000
[ 7.496] () Logitech Logitech Illuminated Keyboard: (accel) acceleration threshold: 4
[ 7.497] (II) event9 - Logitech Logitech Illuminated Keyboard: is tagged by udev as: Keyboard
[ 7.497] (II) event9 - Logitech Logitech Illuminated Keyboard: device is a keyboard
[ 7.498] (II) config/udev: Adding input device DLL0798:00 06CB:7E92 Touchpad (/dev/input/event15)
[ 7.498] (
) DLL0798:00 06CB:7E92 Touchpad: Applying InputClass “libinput touchpad catchall”
[ 7.498] (II) Using input driver ‘libinput’ for ‘DLL0798:00 06CB:7E92 Touchpad’
[ 7.498] () DLL0798:00 06CB:7E92 Touchpad: always reports core events
[ 7.498] (
) Option “Device” “/dev/input/event15”
[ 7.498] () Option “_source” “server/udev”
[ 7.499] (II) event15 - DLL0798:00 06CB:7E92 Touchpad: is tagged by udev as: Touchpad
[ 7.499] (II) event15 - DLL0798:00 06CB:7E92 Touchpad: device is a touchpad
[ 7.499] (II) event15 - DLL0798:00 06CB:7E92 Touchpad: device removed
[ 7.536] (
) Option “config_info” “udev:/sys/devices/pci0000:00/0000:00:15.1/i2c_designware.1/i2c-6/i2c-DLL0798:00/0018:06CB:7E92.0004/input/input17/event15”
[ 7.536] (II) XINPUT: Adding extended input device “DLL0798:00 06CB:7E92 Touchpad” (type: TOUCHPAD, id 15)
[ 7.536] () Option “AccelerationScheme” “none”
[ 7.536] (
) DLL0798:00 06CB:7E92 Touchpad: (accel) selected scheme none/0
[ 7.536] () DLL0798:00 06CB:7E92 Touchpad: (accel) acceleration factor: 2.000
[ 7.536] (
) DLL0798:00 06CB:7E92 Touchpad: (accel) acceleration threshold: 4
[ 7.537] (II) event15 - DLL0798:00 06CB:7E92 Touchpad: is tagged by udev as: Touchpad
[ 7.537] (II) event15 - DLL0798:00 06CB:7E92 Touchpad: device is a touchpad
[ 7.538] (II) config/udev: Adding input device DLL0798:00 06CB:7E92 Touchpad (/dev/input/mouse2)
[ 7.538] (II) No input driver specified, ignoring this device.
[ 7.538] (II) This device may have been added with another device file.
[ 7.538] (II) config/udev: Adding input device HDA Intel PCH Headphone Mic (/dev/input/event17)
[ 7.539] (II) config/udev: Adding input device Intel HID events (/dev/input/event11)
[ 7.539] () Intel HID events: Applying InputClass “libinput keyboard catchall”
[ 7.539] (II) Using input driver ‘libinput’ for ‘Intel HID events’
[ 7.539] (
) Intel HID events: always reports core events
[ 7.539] () Option “Device” “/dev/input/event11”
[ 7.539] (
[ 7.539] (II) event11 - Intel HID events: is tagged by udev as: Keyboard
[ 7.539] (II) event11 - Intel HID events: device is a keyboard
[ 7.539] (II) event11 - Intel HID events: device removed
[ 7.568] () Option “config_info” “udev:/sys/devices/platform/INT33D5:00/input/input12/event11”
[ 7.568] (II) XINPUT: Adding extended input device “Intel HID events” (type: KEYBOARD, id 16)
[ 7.568] (
[ 7.568] () Option “xkb_layout” “us”
[ 7.568] (II) event11 - Intel HID events: is tagged by udev as: Keyboard
[ 7.568] (II) event11 - Intel HID events: device is a keyboard
[ 7.569] (II) config/udev: Adding input device Intel HID 5 button array (/dev/input/event12)
[ 7.569] (
) Intel HID 5 button array: Applying InputClass “libinput keyboard catchall”
[ 7.569] (II) Using input driver ‘libinput’ for ‘Intel HID 5 button array’
[ 7.569] () Intel HID 5 button array: always reports core events
[ 7.569] (
) Option “Device” “/dev/input/event12”
[ 7.569] () Option “_source” “server/udev”
[ 7.570] (II) event12 - Intel HID 5 button array: is tagged by udev as: Keyboard Switch
[ 7.570] (II) event12 - Intel HID 5 button array: device is a keyboard
[ 7.570] (II) event12 - Intel HID 5 button array: device removed
[ 7.584] (
) Option “config_info” “udev:/sys/devices/platform/INT33D5:00/input/input13/event12”
[ 7.584] (II) XINPUT: Adding extended input device “Intel HID 5 button array” (type: KEYBOARD, id 17)
[ 7.584] () Option “xkb_model” “pc105”
[ 7.584] (
[ 7.584] (II) event12 - Intel HID 5 button array: is tagged by udev as: Keyboard Switch
[ 7.585] (II) event12 - Intel HID 5 button array: device is a keyboard
[ 7.585] (II) config/udev: Adding input device Dell WMI hotkeys (/dev/input/event14)
[ 7.585] () Dell WMI hotkeys: Applying InputClass “libinput keyboard catchall”
[ 7.585] (II) Using input driver ‘libinput’ for ‘Dell WMI hotkeys’
[ 7.585] (
) Dell WMI hotkeys: always reports core events
[ 7.585] () Option “Device” “/dev/input/event14”
[ 7.585] (
[ 7.586] (II) event14 - Dell WMI hotkeys: is tagged by udev as: Keyboard
[ 7.586] (II) event14 - Dell WMI hotkeys: device is a keyboard
[ 7.586] (II) event14 - Dell WMI hotkeys: device removed
[ 7.600] () Option “config_info” “udev:/sys/devices/platform/PNP0C14:02/wmi_bus/wmi_bus-PNP0C14:02/9DBB5994-A997-11DA-B012-B622A1EF5492/input/input15/event14”
[ 7.600] (II) XINPUT: Adding extended input device “Dell WMI hotkeys” (type: KEYBOARD, id 18)
[ 7.600] (
[ 7.600] () Option “xkb_layout” “us”
[ 7.601] (II) event14 - Dell WMI hotkeys: is tagged by udev as: Keyboard
[ 7.601] (II) event14 - Dell WMI hotkeys: device is a keyboard
[ 7.601] (II) config/udev: Adding input device AT Translated Set 2 keyboard (/dev/input/event4)
[ 7.601] (
) AT Translated Set 2 keyboard: Applying InputClass “libinput keyboard catchall”
[ 7.601] (II) Using input driver ‘libinput’ for ‘AT Translated Set 2 keyboard’
[ 7.601] () AT Translated Set 2 keyboard: always reports core events
[ 7.601] (
) Option “Device” “/dev/input/event4”
[ 7.601] () Option “_source” “server/udev”
[ 7.602] (II) event4 - AT Translated Set 2 keyboard: is tagged by udev as: Keyboard
[ 7.602] (II) event4 - AT Translated Set 2 keyboard: device is a keyboard
[ 7.602] (II) event4 - AT Translated Set 2 keyboard: device removed
[ 7.616] (
) Option “config_info” “udev:/sys/devices/platform/i8042/serio0/input/input4/event4”
[ 7.616] (II) XINPUT: Adding extended input device “AT Translated Set 2 keyboard” (type: KEYBOARD, id 19)
[ 7.616] () Option “xkb_model” “pc105”
[ 7.616] (
[ 7.617] (II) event4 - AT Translated Set 2 keyboard: is tagged by udev as: Keyboard
[ 7.617] (II) event4 - AT Translated Set 2 keyboard: device is a keyboard
[ 7.617] (II) config/udev: Adding input device SynPS/2 Synaptics TouchPad (/dev/input/event10)
[ 7.617] () SynPS/2 Synaptics TouchPad: Applying InputClass “libinput touchpad catchall”
[ 7.617] (II) Using input driver ‘libinput’ for ‘SynPS/2 Synaptics TouchPad’
[ 7.617] (
) SynPS/2 Synaptics TouchPad: always reports core events
[ 7.617] () Option “Device” “/dev/input/event10”
[ 7.617] (
[ 7.618] (II) event10 - SynPS/2 Synaptics TouchPad: is tagged by udev as: Touchpad
[ 7.618] (II) event10 - SynPS/2 Synaptics TouchPad: no resolution or size hints, assuming a size of 69x50mm
[ 7.618] (II) event10 - SynPS/2 Synaptics TouchPad: device is a touchpad
[ 7.618] (II) event10 - SynPS/2 Synaptics TouchPad: device removed
[ 7.656] () Option “config_info” “udev:/sys/devices/platform/i8042/serio1/input/input6/event10”
[ 7.656] (II) XINPUT: Adding extended input device “SynPS/2 Synaptics TouchPad” (type: TOUCHPAD, id 20)
[ 7.656] (
[ 7.656] () SynPS/2 Synaptics TouchPad: (accel) selected scheme none/0
[ 7.656] (
) SynPS/2 Synaptics TouchPad: (accel) acceleration factor: 2.000
[ 7.656] () SynPS/2 Synaptics TouchPad: (accel) acceleration threshold: 4
[ 7.657] (II) event10 - SynPS/2 Synaptics TouchPad: is tagged by udev as: Touchpad
[ 7.657] (II) event10 - SynPS/2 Synaptics TouchPad: no resolution or size hints, assuming a size of 69x50mm
[ 7.657] (II) event10 - SynPS/2 Synaptics TouchPad: device is a touchpad
[ 7.658] (II) config/udev: Adding input device SynPS/2 Synaptics TouchPad (/dev/input/mouse1)
[ 7.658] (II) No input driver specified, ignoring this device.
[ 7.658] (II) This device may have been added with another device file.
[ 7.682] (
[ 7.682] (II) Using input driver ‘libinput’ for ‘Logitech Logitech Illuminated Keyboard’
[ 7.682] () Logitech Logitech Illuminated Keyboard: always reports core events
[ 7.682] (
[ 7.682] () Option “_source” “_driver/libinput”
[ 7.682] (II) libinput: Logitech Logitech Illuminated Keyboard: is a virtual subdevice
[ 7.682] (
[ 7.682] (II) XINPUT: Adding extended input device “Logitech Logitech Illuminated Keyboard” (type: KEYBOARD, id 21)
[ 7.682] () Option “xkb_model” “pc105”
[ 7.682] (
[ 7.756] (II) modeset(0): EDID vendor “AUO”, prod id 25581
[ 7.756] (II) modeset(0): Printing DDC gathered Modelines:
[ 7.756] (II) modeset(0): Modeline "1920x1080"x0.0 142.00 1920 2028 2076 2100 1080 1090 1100 1126 +hsync -vsync (67.6 kHz eP)
[ 7.756] (II) modeset(0): Modeline "1920x1080"x0.0 113.60 1920 2028 2076 2100 1080 1090 1100 1126 +hsync -vsync (54.1 kHz e)
[ 7.763] (II) modeset(0): EDID vendor “AUO”, prod id 25581
[ 7.763] (II) modeset(0): Printing DDC gathered Modelines:
[ 7.763] (II) modeset(0): Modeline "1920x1080"x0.0 142.00 1920 2028 2076 2100 1080 1090 1100 1126 +hsync -vsync (67.6 kHz eP)
[ 7.763] (II) modeset(0): Modeline "1920x1080"x0.0 113.60 1920 2028 2076 2100 1080 1090 1100 1126 +hsync -vsync (54.1 kHz e)
[ 7.765] (II) modeset(0): EDID vendor “AUO”, prod id 25581
[ 7.765] (II) modeset(0): Printing DDC gathered Modelines:
[ 7.765] (II) modeset(0): Modeline "1920x1080"x0.0 142.00 1920 2028 2076 2100 1080 1090 1100 1126 +hsync -vsync (67.6 kHz eP)
[ 7.765] (II) modeset(0): Modeline "1920x1080"x0.0 113.60 1920 2028 2076 2100 1080 1090 1100 1126 +hsync -vsync (54.1 kHz e)
[ 7.771] (II) modeset(0): EDID vendor “AUO”, prod id 25581
[ 7.771] (II) modeset(0): Printing DDC gathered Modelines:
[ 7.771] (II) modeset(0): Modeline "1920x1080"x0.0 142.00 1920 2028 2076 2100 1080 1090 1100 1126 +hsync -vsync (67.6 kHz eP)
[ 7.771] (II) modeset(0): Modeline "1920x1080"x0.0 113.60 1920 2028 2076 2100 1080 1090 1100 1126 +hsync -vsync (54.1 kHz e)
[ 7.777] (II) modeset(0): EDID vendor “AUO”, prod id 25581
[ 7.777] (II) modeset(0): Printing DDC gathered Modelines:
[ 7.777] (II) modeset(0): Modeline "1920x1080"x0.0 142.00 1920 2028 2076 2100 1080 1090 1100 1126 +hsync -vsync (67.6 kHz eP)
[ 7.777] (II) modeset(0): Modeline "1920x1080"x0.0 113.60 1920 2028 2076 2100 1080 1090 1100 1126 +hsync -vsync (54.1 kHz e)
[ 8.051] (II) modeset(0): Allocate new frame buffer 320x200 stride
[ 8.057] (II) modeset(0): Allocate new frame buffer 1920x1080 stride
[ 9.595] (II) modeset(0): EDID vendor “AUO”, prod id 25581
[ 9.595] (II) modeset(0): Printing DDC gathered Modelines:
[ 9.595] (II) modeset(0): Modeline "1920x1080"x0.0 142.00 1920 2028 2076 2100 1080 1090 1100 1126 +hsync -vsync (67.6 kHz eP)
[ 9.595] (II) modeset(0): Modeline "1920x1080"x0.0 113.60 1920 2028 2076 2100 1080 1090 1100 1126 +hsync -vsync (54.1 kHz e)
[ 9.644] (II) modeset(0): EDID vendor “AUO”, prod id 25581
[ 9.644] (II) modeset(0): Printing DDC gathered Modelines:
[ 9.644] (II) modeset(0): Modeline "1920x1080"x0.0 142.00 1920 2028 2076 2100 1080 1090 1100 1126 +hsync -vsync (67.6 kHz eP)
[ 9.644] (II) modeset(0): Modeline "1920x1080"x0.0 113.60 1920 2028 2076 2100 1080 1090 1100 1126 +hsync -vsync (54.1 kHz e)
[ 9.659] (II) modeset(0): EDID vendor “AUO”, prod id 25581
[ 9.659] (II) modeset(0): Printing DDC gathered Modelines:
[ 9.659] (II) modeset(0): Modeline "1920x1080"x0.0 142.00 1920 2028 2076 2100 1080 1090 1100 1126 +hsync -vsync (67.6 kHz eP)
[ 9.659] (II) modeset(0): Modeline "1920x1080"x0.0 113.60 1920 2028 2076 2100 1080 1090 1100 1126 +hsync -vsync (54.1 kHz e)
[ 9.673] (II) modeset(0): EDID vendor “AUO”, prod id 25581
[ 9.673] (II) modeset(0): Printing DDC gathered Modelines:
[ 9.673] (II) modeset(0): Modeline "1920x1080"x0.0 142.00 1920 2028 2076 2100 1080 1090 1100 1126 +hsync -vsync (67.6 kHz eP)
[ 9.673] (II) modeset(0): Modeline "1920x1080"x0.0 113.60 1920 2028 2076 2100 1080 1090 1100 1126 +hsync -vsync (54.1 kHz e)
[ 9.681] (II) modeset(0): EDID vendor “AUO”, prod id 25581
[ 9.681] (II) modeset(0): Printing DDC gathered Modelines:
[ 9.681] (II) modeset(0): Modeline "1920x1080"x0.0 142.00 1920 2028 2076 2100 1080 1090 1100 1126 +hsync -vsync (67.6 kHz eP)
[ 9.681] (II) modeset(0): Modeline "1920x1080"x0.0 113.60 1920 2028 2076 2100 1080 1090 1100 1126 +hsync -vsync (54.1 kHz e)
[ 11.178] (II) modeset(0): EDID vendor “AUO”, prod id 25581
[ 11.178] (II) modeset(0): Printing DDC gathered Modelines:
[ 11.178] (II) modeset(0): Modeline "1920x1080"x0.0 142.00 1920 2028 2076 2100 1080 1090 1100 1126 +hsync -vsync (67.6 kHz eP)
[ 11.178] (II) modeset(0): Modeline "1920x1080"x0.0 113.60 1920 2028 2076 2100 1080 1090 1100 1126 +hsync -vsync (54.1 kHz e)
  • make sure that secure boot is disabled.
  • run
sudo prime-select nvidia
  • run
grep nvidia /etc/modprobe.d/* /lib/modprobe.d/*
to find a file containing
blacklist nvidia
and remove it,
then run
sudo update-initramfs -u
and reboot. If the problem persists, please run nvidia-bug-report.sh as root and attach the resulting .gz file to your post. Hovering the mouse over an existing post of yours will reveal a paperclip icon.
https://devtalk.nvidia.com/default/topic/1043347/announcements/attaching-files-to-forum-topics-posts/
@generix
Just to let you know that you made my day.
THANKS
