- The card doesn’t detect the monitor when
startx
is invoked. - The console is displayed, but only at 640x480 mode.
- nvidia-smi says that no monitor is connected.
- more recent monitors are detected on the same connector.
- nvidia quadro fx 1700 detects the t221 monitor, and startx runs fine.
Please help if there is anyone aware of this issue!
Is this a driver problem or a hardware problem?
Has anyone used this monitor with reasonably recent cards (with driver version >= 390)?
OS: Ubuntu 18.04.2 LTS, nvidia driver 390.116-0ubuntu0.18.04.1 amd64
Card: [MSI Computer Video Card (GTX 1050 TI 4G OC)] https://www.msi.com/Graphics-card/GeForce-GTX-1050-Ti-4G-OC.html
Monitor: [IBM T221] http://www.ibmfiles.com/ibmfiles/monitors/T221_usersguide.pdf
Here the /var/log/Xorg.0.log
It says no monitor is connected, even though the monitor is showing console outputs
[ 3133.304]
X.Org X Server 1.19.6
Release Date: 2017-12-20
[ 3133.304] X Protocol Version 11, Revision 0
[ 3133.304] Build Operating System: Linux 4.4.0-138-generic x86_64 Ubuntu
[ 3133.304] Current Operating System: Linux T3400 4.15.0-47-generic #50-Ubuntu SMP Wed Mar 13 10:44:52 UTC 2019 x86_64
[ 3133.304] Kernel command line: BOOT_IMAGE=/boot/vmlinuz-4.15.0-47-generic root=/dev/mapper/linux_systems-ubuntu64 ro recovery nomodeset rd.retry=300 rd.timeout=360
[ 3133.305] Build Date: 25 October 2018 04:11:27PM
[ 3133.305] xorg-server 2:1.19.6-1ubuntu4.2 (For technical support please see http://www.ubuntu.com/support)
[ 3133.305] Current version of pixman: 0.34.0
[ 3133.305] Before reporting problems, check http://wiki.x.org
to make sure that you have the latest version.
[ 3133.305] Markers: (--) probed, (**) from config file, (==) default setting,
(++) from command line, (!!) notice, (II) informational,
(WW) warning, (EE) error, (NI) not implemented, (??) unknown.
[ 3133.306] (==) Log file: "/var/log/Xorg.0.log", Time: Wed Apr 10 06:18:46 2019
[ 3133.306] (==) Using config file: "/etc/X11/xorg.conf"
[ 3133.306] (==) Using config directory: "/etc/X11/xorg.conf.d"
[ 3133.306] (==) Using system config directory "/usr/share/X11/xorg.conf.d"
[ 3133.307] (==) ServerLayout "Layout0"
[ 3133.307] (**) |-->Screen "Screen0" (0)
[ 3133.307] (**) | |-->Monitor "IBM T221 HLF"
[ 3133.307] (**) | |-->Device "Device0"
[ 3133.307] (**) |-->Input Device "Keyboard0"
[ 3133.307] (**) |-->Input Device "Mouse0"
[ 3133.307] (==) Automatically adding devices
[ 3133.307] (==) Automatically enabling devices
[ 3133.307] (==) Automatically adding GPU devices
[ 3133.308] (==) Automatically binding GPU devices
[ 3133.308] (==) Max clients allowed: 256, resource mask: 0x1fffff
[ 3133.308] (WW) The directory "/usr/share/fonts/X11/cyrillic" does not exist.
[ 3133.308] Entry deleted from font path.
[ 3133.308] (WW) The directory "/usr/share/fonts/X11/100dpi/" does not exist.
[ 3133.308] (WW) The directory "/usr/share/fonts/X11/75dpi/" does not exist.
[ 3133.309] (WW) The directory "/usr/share/fonts/X11/100dpi" does not exist.
[ 3133.309] Entry deleted from font path.
[ 3133.309] (WW) The directory "/usr/share/fonts/X11/75dpi" does not exist.
[ 3133.309] (==) FontPath set to:
/usr/share/fonts/X11/misc,
/usr/share/fonts/X11/Type1,
built-ins
[ 3133.309] (==) ModulePath set to "/usr/lib/xorg/modules"
[ 3133.309] (WW) Hotplugging is on, devices using drivers 'kbd', 'mouse' or 'vmmouse' will be disabled.
[ 3133.309] (WW) Disabling Keyboard0
[ 3133.310] (WW) Disabling Mouse0
[ 3133.310] (II) Loader magic: 0x560373e06020
[ 3133.310] (II) Module ABI versions:
[ 3133.310] X.Org ANSI C Emulation: 0.4
[ 3133.310] X.Org Video Driver: 23.0
[ 3133.310] X.Org XInput driver : 24.1
[ 3133.310] X.Org Server Extension : 10.0
[ 3133.311] (++) using VT number 1
[ 3133.314] (II) systemd-logind: took control of session /org/freedesktop/login1/session/_31
[ 3133.314] (II) xfree86: Adding drm device (/dev/dri/card0)
[ 3133.315] (II) systemd-logind: got fd for /dev/dri/card0 226:0 fd 11 paused 0
[ 3133.317] (**) OutputClass "nvidia" ModulePath extended to "/usr/lib/x86_64-linux-gnu/nvidia/xorg,/usr/lib/xorg/modules"
[ 3133.318] (--) PCI:*(0:2:0:0) 10de:1c82:1462:8c96 rev 161, Mem @ 0xfc000000/16777216, 0xc0000000/268435456, 0xd0000000/33554432, I/O @ 0x0000dc80/128, BIOS @ 0x????????/131072
[ 3133.318] (II) LoadModule: "glx"
[ 3133.318] (II) Loading /usr/lib/x86_64-linux-gnu/nvidia/xorg/libglx.so
[ 3133.324] (II) Module glx: vendor="NVIDIA Corporation"
[ 3133.324] compiled for 4.0.2, module version = 1.0.0
[ 3133.324] Module class: X.Org Server Extension
[ 3133.324] (II) NVIDIA GLX Module 390.116 Sun Jan 27 06:24:32 PST 2019
[ 3133.324] (II) LoadModule: "nouveau"
[ 3133.324] (WW) Warning, couldn't open module nouveau
[ 3133.325] (II) UnloadModule: "nouveau"
[ 3133.325] (II) Unloading nouveau
[ 3133.325] (EE) Failed to load module "nouveau" (module does not exist, 0)
[ 3133.325] (II) Applying OutputClass "nvidia" to /dev/dri/card0
[ 3133.325] loading driver: nvidia
[ 3133.325] (==) Matched nvidia as autoconfigured driver 0
[ 3133.325] (==) Matched nouveau as autoconfigured driver 1
[ 3133.325] (==) Matched nouveau as autoconfigured driver 2
[ 3133.325] (==) Matched modesetting as autoconfigured driver 3
[ 3133.325] (==) Matched fbdev as autoconfigured driver 4
[ 3133.325] (==) Matched vesa as autoconfigured driver 5
[ 3133.325] (==) Assigned the driver to the xf86ConfigLayout
[ 3133.325] (II) LoadModule: "nvidia"
[ 3133.325] (II) Loading /usr/lib/x86_64-linux-gnu/nvidia/xorg/nvidia_drv.so
[ 3133.325] (II) Module nvidia: vendor="NVIDIA Corporation"
[ 3133.325] compiled for 4.0.2, module version = 1.0.0
[ 3133.325] Module class: X.Org Video Driver
[ 3133.325] (II) LoadModule: "nouveau"
[ 3133.325] (WW) Warning, couldn't open module nouveau
[ 3133.325] (II) LoadModule: "modesetting"
[ 3133.326] (II) Loading /usr/lib/xorg/modules/drivers/modesetting_drv.so
[ 3133.326] (II) Module modesetting: vendor="X.Org Foundation"
[ 3133.326] compiled for 1.19.6, module version = 1.19.6
[ 3133.326] Module class: X.Org Video Driver
[ 3133.326] ABI class: X.Org Video Driver, version 23.0
[ 3133.326] (II) LoadModule: "fbdev"
[ 3133.326] (WW) Warning, couldn't open module fbdev
[ 3133.326] (II) UnloadModule: "fbdev"
[ 3133.326] (II) Unloading fbdev
[ 3133.326] (EE) Failed to load module "fbdev" (module does not exist, 0)
[ 3133.326] (II) LoadModule: "vesa"
[ 3133.326] (WW) Warning, couldn't open module vesa
[ 3133.326] (II) UnloadModule: "vesa"
[ 3133.326] (II) Unloading vesa
[ 3133.326] (EE) Failed to load module "vesa" (module does not exist, 0)
[ 3133.326] (II) NVIDIA dlloader X Driver 390.116 Sun Jan 27 05:57:42 PST 2019
[ 3133.326] (II) NVIDIA Unified Driver for all Supported NVIDIA GPUs
[ 3133.326] (II) modesetting: Driver for Modesetting Kernel Drivers: kms
[ 3133.326] (II) systemd-logind: releasing fd for 226:0
[ 3133.328] (II) Loading sub module "fb"
[ 3133.328] (II) LoadModule: "fb"
[ 3133.328] (II) Loading /usr/lib/xorg/modules/libfb.so
[ 3133.328] (II) Module fb: vendor="X.Org Foundation"
[ 3133.328] compiled for 1.19.6, module version = 1.0.0
[ 3133.328] ABI class: X.Org ANSI C Emulation, version 0.4
[ 3133.328] (II) Loading sub module "wfb"
[ 3133.328] (II) LoadModule: "wfb"
[ 3133.328] (II) Loading /usr/lib/xorg/modules/libwfb.so
[ 3133.328] (II) Module wfb: vendor="X.Org Foundation"
[ 3133.328] (II) Loading sub module "ramdac"
[ 3133.328] (II) LoadModule: "ramdac"
[ 3133.328] (II) Module "ramdac" already built-in
[ 3133.329] (WW) Falling back to old probe method for modesetting
[ 3133.329] (**) NVIDIA(0): Depth 24, (--) framebuffer bpp 32
[ 3133.329] (==) NVIDIA(0): RGB weight 888
[ 3133.329] (==) NVIDIA(0): Default visual is TrueColor
[ 3133.329] (**) NVIDIA(0): Using gamma correction (2.2, 2.2, 2.2)
[ 3133.329] (II) Applying OutputClass "nvidia" options to /dev/dri/card0
[ 3133.329] (**) NVIDIA(0): Option "Stereo" "0"
[ 3133.329] (**) NVIDIA(0): Option "SLI" "Off"
[ 3133.329] (**) NVIDIA(0): Option "MultiGPU" "Off"
[ 3133.329] (**) NVIDIA(0): Option "BaseMosaic" "Off"
[ 3133.329] (**) NVIDIA(0): Option "AllowEmptyInitialConfiguration"
[ 3133.329] (**) NVIDIA(0): Stereo disabled by request
[ 3133.329] (**) NVIDIA(0): NVIDIA SLI disabled.
[ 3133.329] (**) NVIDIA(0): NVIDIA Multi-GPU disabled.
[ 3133.329] (**) NVIDIA(0): Enabling 2D acceleration
[ 3133.900] (--) NVIDIA(0): Valid display device(s) on GPU-0 at PCI:2:0:0
[ 3133.900] (--) NVIDIA(0): DFP-0 (boot)
[ 3133.900] (--) NVIDIA(0): DFP-1
[ 3133.900] (--) NVIDIA(0): DFP-2
[ 3133.900] (--) NVIDIA(0): DFP-3
[ 3133.901] (II) NVIDIA(0): NVIDIA GPU GeForce GTX 1050 Ti (GP107-A) at PCI:2:0:0 (GPU-0)
[ 3133.901] (--) NVIDIA(0): Memory: 4194304 kBytes
[ 3133.901] (--) NVIDIA(0): VideoBIOS: 86.07.42.00.83
[ 3133.902] (II) NVIDIA(0): Detected PCI Express Link width: 16X
[ 3133.902] (--) NVIDIA(GPU-0): DFP-0: disconnected
[ 3133.902] (--) NVIDIA(GPU-0): DFP-0: Internal TMDS
[ 3133.902] (--) NVIDIA(GPU-0): DFP-0 Name Aliases:
[ 3133.902] (--) NVIDIA(GPU-0): DPY-0
[ 3133.902] (--) NVIDIA(GPU-0): DVI-D-0
[ 3133.902] (--) NVIDIA(GPU-0): DFP-0: 330.0 MHz maximum pixel clock
[ 3133.902] (--) NVIDIA(GPU-0): DFP-1: disconnected
[ 3133.902] (--) NVIDIA(GPU-0): DFP-1: Internal TMDS
[ 3133.902] (--) NVIDIA(GPU-0): DFP-1 Name Aliases:
[ 3133.902] (--) NVIDIA(GPU-0): DPY-1
[ 3133.902] (--) NVIDIA(GPU-0): HDMI-0
[ 3133.902] (--) NVIDIA(GPU-0): DFP-1: 165.0 MHz maximum pixel clock
[ 3133.902] (--) NVIDIA(GPU-0): DFP-2: disconnected
[ 3133.902] (--) NVIDIA(GPU-0): DFP-2: Internal DisplayPort
[ 3133.902] (--) NVIDIA(GPU-0): DFP-2 Name Aliases:
[ 3133.902] (--) NVIDIA(GPU-0): DPY-2
[ 3133.902] (--) NVIDIA(GPU-0): DP-0
[ 3133.902] (--) NVIDIA(GPU-0): DFP-2: 1440.0 MHz maximum pixel clock
[ 3133.902] (--) NVIDIA(GPU-0): DFP-3: disconnected
[ 3133.902] (--) NVIDIA(GPU-0): DFP-3: Internal TMDS
[ 3133.902] (--) NVIDIA(GPU-0): DFP-3 Name Aliases:
[ 3133.902] (--) NVIDIA(GPU-0): DPY-3
[ 3133.902] (--) NVIDIA(GPU-0): DP-1
[ 3133.902] (--) NVIDIA(GPU-0): DFP-3: 165.0 MHz maximum pixel clock
[ 3133.902] (==) NVIDIA(0):
[ 3133.902] (==) NVIDIA(0): No modes were requested; the default mode "nvidia-auto-select"
[ 3133.902] (==) NVIDIA(0): will be used as the requested mode.
[ 3133.902] (--) NVIDIA(0): No enabled display devices found; starting anyway because
[ 3133.903] (--) NVIDIA(0): AllowEmptyInitialConfiguration is enabled
[ 3133.903] (II) NVIDIA(0): Validated MetaModes:
[ 3133.903] (II) NVIDIA(0): Virtual screen size determined to be 640 x 480
[ 3133.903] (WW) NVIDIA(0): Unable to get display device for DPI computation.
[ 3133.903] (**) NVIDIA(0): DPI set to (67, 40); computed from "DisplaySize" Monitor
[ 3133.903] (**) NVIDIA(0): section option
[ 3133.903] (II) UnloadModule: "modesetting"
[ 3133.903] (II) Unloading modesetting
[ 3133.903] (--) Depth 24 pixmap format is 32 bpp
[ 3133.904] (II) NVIDIA: Using 24576.00 MB of virtual memory for indirect memory
[ 3133.904] (II) NVIDIA: access.
[ 3133.927] (II) NVIDIA(0): Setting mode "NULL"
[ 3133.961] (==) NVIDIA(0): Disabling shared memory pixmaps
[ 3133.961] (==) NVIDIA(0): Backing store enabled
[ 3133.961] (==) NVIDIA(0): Silken mouse enabled
[ 3133.962] (**) NVIDIA(0): DPMS enabled
[ 3133.962] (II) Loading sub module "dri2"
[ 3133.962] (II) LoadModule: "dri2"
[ 3133.962] (II) Module "dri2" already built-in
[ 3133.962] (II) NVIDIA(0): [DRI2] Setup complete
[ 3133.962] (II) NVIDIA(0): [DRI2] VDPAU driver: nvidia
[ 3133.962] (--) RandR disabled
[ 3133.965] (II) SELinux: Disabled on system
[ 3133.965] (II) Initializing extension GLX
[ 3133.965] (II) Indirect GLX disabled.
[ 3134.013] (II) config/udev: Adding input device Power Button (/dev/input/event1)
[ 3134.013] (**) Power Button: Applying InputClass "evdev keyboard catchall"
[ 3134.013] (**) Power Button: Applying InputClass "libinput keyboard catchall"
[ 3134.013] (II) LoadModule: "libinput"
[ 3134.013] (II) Loading /usr/lib/xorg/modules/input/libinput_drv.so
[ 3134.015] (II) Module libinput: vendor="X.Org Foundation"
[ 3134.015] compiled for 1.19.6, module version = 0.27.1
[ 3134.015] Module class: X.Org XInput Driver
[ 3134.015] ABI class: X.Org XInput driver, version 24.1
[ 3134.015] (II) Using input driver 'libinput' for 'Power Button'
[ 3134.015] (II) systemd-logind: got fd for /dev/input/event1 13:65 fd 37 paused 0
[ 3134.015] (**) Power Button: always reports core events
[ 3134.015] (**) Option "Device" "/dev/input/event1"
[ 3134.015] (**) Option "_source" "server/udev"
[ 3134.016] (II) event1 - Power Button: is tagged by udev as: Keyboard
[ 3134.016] (II) event1 - Power Button: device is a keyboard
[ 3134.016] (II) event1 - Power Button: device removed
[ 3134.016] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXPWRBN:00/input/input1/event1"
[ 3134.016] (II) XINPUT: Adding extended input device "Power Button" (type: KEYBOARD, id 6)
[ 3134.016] (**) Option "xkb_model" "microsoft4000"
[ 3134.016] (**) Option "xkb_layout" "us"
[ 3134.016] (**) Option "xkb_options" "ctrl:swapcaps,terminate:ctrl_alt_bksp"
[ 3134.035] (II) event1 - Power Button: is tagged by udev as: Keyboard
[ 3134.035] (II) event1 - Power Button: device is a keyboard
[ 3134.036] (II) config/udev: Adding input device Power Button (/dev/input/event0)
[ 3134.036] (**) Power Button: Applying InputClass "evdev keyboard catchall"
[ 3134.036] (**) Power Button: Applying InputClass "libinput keyboard catchall"
[ 3134.036] (II) Using input driver 'libinput' for 'Power Button'
[ 3134.036] (II) systemd-logind: got fd for /dev/input/event0 13:64 fd 40 paused 0
[ 3134.036] (**) Power Button: always reports core events
[ 3134.036] (**) Option "Device" "/dev/input/event0"
[ 3134.037] (**) Option "_source" "server/udev"
[ 3134.037] (II) event0 - Power Button: is tagged by udev as: Keyboard
[ 3134.037] (II) event0 - Power Button: device is a keyboard
[ 3134.037] (II) event0 - Power Button: device removed
[ 3134.037] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0C:00/input/input0/event0"
[ 3134.037] (II) XINPUT: Adding extended input device "Power Button" (type: KEYBOARD, id 7)
[ 3134.037] (**) Option "xkb_model" "microsoft4000"
[ 3134.037] (**) Option "xkb_layout" "us"
[ 3134.037] (**) Option "xkb_options" "ctrl:swapcaps,terminate:ctrl_alt_bksp"
[ 3134.038] (II) event0 - Power Button: is tagged by udev as: Keyboard
[ 3134.038] (II) event0 - Power Button: device is a keyboard
[ 3134.039] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=3 (/dev/input/event8)
[ 3134.039] (II) No input driver specified, ignoring this device.
[ 3134.039] (II) This device may have been added with another device file.
[ 3134.039] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=7 (/dev/input/event9)
[ 3134.040] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=8 (/dev/input/event10)
[ 3134.040] (II) No input driver specified, ignoring this device.
[ 3134.040] (II) This device may have been added with another device file.
[ 3134.040] (II) config/udev: Adding input device Microsoft Natural® Ergonomic Keyboard 4000 (/dev/input/event2)
[ 3134.040] (**) Microsoft Natural® Ergonomic Keyboard 4000: Applying InputClass "evdev keyboard catchall"
[ 3134.040] (**) Microsoft Natural® Ergonomic Keyboard 4000: Applying InputClass "libinput keyboard catchall"
[ 3134.040] (II) Using input driver 'libinput' for 'Microsoft Natural® Ergonomic Keyboard 4000'
[ 3134.041] (II) systemd-logind: got fd for /dev/input/event2 13:66 fd 41 paused 0
[ 3134.041] (**) Microsoft Natural® Ergonomic Keyboard 4000: always reports core events
[ 3134.041] (**) Option "Device" "/dev/input/event2"
[ 3134.041] (**) Option "_source" "server/udev"
[ 3134.042] (II) event2 - Microsoft Natural® Ergonomic Keyboard 4000: is tagged by udev as: Keyboard
[ 3134.042] (II) event2 - Microsoft Natural® Ergonomic Keyboard 4000: device is a keyboard
[ 3134.042] (II) event2 - Microsoft Natural® Ergonomic Keyboard 4000: device removed
[ 3134.042] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:1a.1/usb4/4-2/4-2:1.0/0003:045E:00DC.0001/input/input5/event2"
[ 3134.042] (II) XINPUT: Adding extended input device "Microsoft Natural® Ergonomic Keyboard 4000" (type: KEYBOARD, id 8)
[ 3134.042] (**) Option "xkb_model" "microsoft4000"
[ 3134.042] (**) Option "xkb_layout" "us"
[ 3134.042] (**) Option "xkb_options" "ctrl:swapcaps,terminate:ctrl_alt_bksp"
[ 3134.043] (II) event2 - Microsoft Natural® Ergonomic Keyboard 4000: is tagged by udev as: Keyboard
[ 3134.043] (II) event2 - Microsoft Natural® Ergonomic Keyboard 4000: device is a keyboard
[ 3134.044] (II) config/udev: Adding input device Microsoft Natural® Ergonomic Keyboard 4000 (/dev/input/event3)
[ 3134.044] (**) Microsoft Natural® Ergonomic Keyboard 4000: Applying InputClass "evdev keyboard catchall"
[ 3134.044] (**) Microsoft Natural® Ergonomic Keyboard 4000: Applying InputClass "libinput keyboard catchall"
[ 3134.044] (II) Using input driver 'libinput' for 'Microsoft Natural® Ergonomic Keyboard 4000'
[ 3134.045] (II) systemd-logind: got fd for /dev/input/event3 13:67 fd 42 paused 0
[ 3134.045] (**) Microsoft Natural® Ergonomic Keyboard 4000: always reports core events
[ 3134.045] (**) Option "Device" "/dev/input/event3"
[ 3134.045] (**) Option "_source" "server/udev"
[ 3134.046] (II) event3 - Microsoft Natural® Ergonomic Keyboard 4000: is tagged by udev as: Keyboard
[ 3134.046] (II) event3 - Microsoft Natural® Ergonomic Keyboard 4000: device is a keyboard
[ 3134.046] (II) event3 - Microsoft Natural® Ergonomic Keyboard 4000: device removed
[ 3134.046] (II) libinput: Microsoft Natural® Ergonomic Keyboard 4000: needs a virtual subdevice
[ 3134.046] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:1a.1/usb4/4-2/4-2:1.1/0003:045E:00DC.0002/input/input6/event3"
[ 3134.046] (II) XINPUT: Adding extended input device "Microsoft Natural® Ergonomic Keyboard 4000" (type: MOUSE, id 9)
[ 3134.046] (**) Option "AccelerationScheme" "none"
[ 3134.046] (**) Microsoft Natural® Ergonomic Keyboard 4000: (accel) selected scheme none/0
[ 3134.046] (**) Microsoft Natural® Ergonomic Keyboard 4000: (accel) acceleration factor: 2.000
[ 3134.046] (**) Microsoft Natural® Ergonomic Keyboard 4000: (accel) acceleration threshold: 4
[ 3134.047] (II) event3 - Microsoft Natural® Ergonomic Keyboard 4000: is tagged by udev as: Keyboard
[ 3134.047] (II) event3 - Microsoft Natural® Ergonomic Keyboard 4000: device is a keyboard
[ 3134.048] (II) config/udev: Adding input device HDA Intel Front Headphone (/dev/input/event7)
[ 3134.048] (II) No input driver specified, ignoring this device.
[ 3134.048] (II) This device may have been added with another device file.
[ 3134.048] (II) config/udev: Adding input device HDA Intel Mic (/dev/input/event4)
[ 3134.049] (II) config/udev: Adding input device HDA Intel Line (/dev/input/event5)
[ 3134.049] (II) No input driver specified, ignoring this device.
[ 3134.049] (II) This device may have been added with another device file.
[ 3134.049] (II) config/udev: Adding input device HDA Intel Line Out (/dev/input/event6)
[ 3134.058] (**) Microsoft Natural® Ergonomic Keyboard 4000: Applying InputClass "evdev keyboard catchall"
[ 3134.058] (**) Microsoft Natural® Ergonomic Keyboard 4000: Applying InputClass "libinput keyboard catchall"
[ 3134.058] (II) Using input driver 'libinput' for 'Microsoft Natural® Ergonomic Keyboard 4000'
[ 3134.058] (II) systemd-logind: returning pre-existing fd for /dev/input/event3 13:67
[ 3134.058] (**) Microsoft Natural® Ergonomic Keyboard 4000: always reports core events
[ 3134.058] (**) Option "Device" "/dev/input/event3"
[ 3134.058] (**) Option "_source" "_driver/libinput"
[ 3134.058] (II) libinput: Microsoft Natural® Ergonomic Keyboard 4000: is a virtual subdevice
[ 3134.058] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:1a.1/usb4/4-2/4-2:1.1/0003:045E:00DC.0002/input/input6/event3"
[ 3134.058] (II) XINPUT: Adding extended input device "Microsoft Natural® Ergonomic Keyboard 4000" (type: KEYBOARD, id 10)
[ 3134.058] (**) Option "xkb_model" "microsoft4000"
[ 3134.058] (**) Option "xkb_layout" "us"
[ 3134.058] (**) Option "xkb_options" "ctrl:swapcaps,terminate:ctrl_alt_bksp"
[ 3144.046] (II) Server zapped. Shutting down.
[ 3144.065] (**) Option "fd" "37"
[ 3144.065] (II) event1 - Power Button: device removed
[ 3144.065] (**) Option "fd" "40"
[ 3144.065] (II) event0 - Power Button: device removed
[ 3144.065] (**) Option "fd" "41"
[ 3144.065] (II) event2 - Microsoft Natural® Ergonomic Keyboard 4000: device removed
[ 3144.065] (**) Option "fd" "42"
[ 3144.065] (II) event3 - Microsoft Natural® Ergonomic Keyboard 4000: device removed
[ 3144.067] (II) UnloadModule: "libinput"
[ 3144.067] (II) systemd-logind: not releasing fd for 13:67, still in use
[ 3144.067] (II) systemd-logind: releasing fd for 13:67
[ 3144.076] (II) UnloadModule: "libinput"
[ 3144.076] (II) systemd-logind: releasing fd for 13:66
[ 3144.092] (II) UnloadModule: "libinput"
[ 3144.092] (II) systemd-logind: releasing fd for 13:64
[ 3144.108] (II) UnloadModule: "libinput"
[ 3144.108] (II) systemd-logind: releasing fd for 13:65
[ 3148.635] (II) NVIDIA(GPU-0): Deleting GPU-0
[ 3148.638] (II) Server terminated successfully (0). Closing log file.
Here’s output from nvidia-smi -q
$ nvidia-smi -q
==============NVSMI LOG==============
Timestamp : Wed Apr 10 07:16:14 2019
Driver Version : 390.116
Attached GPUs : 1
GPU 00000000:02:00.0
Product Name : GeForce GTX 1050 Ti
Product Brand : GeForce
Display Mode : Disabled
Display Active : Disabled
Persistence Mode : Disabled
Accounting Mode : Disabled
Accounting Mode Buffer Size : 4000
Driver Model
Current : N/A
Pending : N/A
Serial Number : N/A
GPU UUID : GPU-71e38920-0438-d355-92d7-dc39f14d8a78
Minor Number : 0
VBIOS Version : 86.07.42.00.83
MultiGPU Board : No
Board ID : 0x200
GPU Part Number : N/A
Inforom Version
Image Version : G001.0000.01.04
OEM Object : 1.1
ECC Object : N/A
Power Management Object : N/A
GPU Operation Mode
Current : N/A
Pending : N/A
GPU Virtualization Mode
Virtualization mode : None
PCI
Bus : 0x02
Device : 0x00
Domain : 0x0000
Device Id : 0x1C8210DE
Bus Id : 00000000:02:00.0
Sub System Id : 0x8C961462
GPU Link Info
PCIe Generation
Max : 2
Current : 2
Link Width
Max : 16x
Current : 16x
Bridge Chip
Type : N/A
Firmware : N/A
Replays since reset : 0
Tx Throughput : 0 KB/s
Rx Throughput : 0 KB/s
Fan Speed : 35 %
Performance State : P0
Clocks Throttle Reasons
Idle : Not Active
Applications Clocks Setting : Not Active
SW Power Cap : Not Active
HW Slowdown : Not Active
HW Thermal Slowdown : Not Active
HW Power Brake Slowdown : Not Active
Sync Boost : Not Active
SW Thermal Slowdown : Not Active
Display Clock Setting : Not Active
FB Memory Usage
Total : 4039 MiB
Used : 0 MiB
Free : 4039 MiB
BAR1 Memory Usage
Total : 256 MiB
Used : 2 MiB
Free : 254 MiB
Compute Mode : Default
Utilization
Gpu : 1 %
Memory : 0 %
Encoder : 0 %
Decoder : 0 %
Encoder Stats
Active Sessions : 0
Average FPS : 0
Average Latency : 0
Ecc Mode
Current : N/A
Pending : N/A
ECC Errors
Volatile
Single Bit
Device Memory : N/A
Register File : N/A
L1 Cache : N/A
L2 Cache : N/A
Texture Memory : N/A
Texture Shared : N/A
CBU : N/A
Total : N/A
Double Bit
Device Memory : N/A
Register File : N/A
L1 Cache : N/A
L2 Cache : N/A
CBU : N/A
Total : N/A
Aggregate
Single Bit
Device Memory : N/A
Register File : N/A
L1 Cache : N/A
L2 Cache : N/A
CBU : N/A
Total : N/A
Double Bit
Device Memory : N/A
Register File : N/A
L1 Cache : N/A
L2 Cache : N/A
CBU : N/A
Total : N/A
Retired Pages
Single Bit ECC : N/A
Double Bit ECC : N/A
Pending : N/A
Temperature
GPU Current Temp : 22 C
GPU Shutdown Temp : 102 C
GPU Slowdown Temp : 99 C
GPU Max Operating Temp : N/A
Memory Current Temp : N/A
Memory Max Operating Temp : N/A
Power Readings
Power Management : Supported
Power Draw : N/A
Power Limit : 75.00 W
Default Power Limit : 75.00 W
Enforced Power Limit : 75.00 W
Min Power Limit : 52.50 W
Max Power Limit : 75.00 W
Clocks
Graphics : 1341 MHz
SM : 1341 MHz
Memory : 3504 MHz
Video : 1215 MHz
Applications Clocks
Graphics : N/A
Memory : N/A
Default Applications Clocks
Graphics : N/A
Memory : N/A
Max Clocks
Graphics : 1961 MHz
SM : 1961 MHz
Memory : 3504 MHz
Video : 1708 MHz
Max Customer Boost Clocks
Graphics : N/A
Clock Policy
Auto Boost : N/A
Auto Boost Default : N/A
Processes : None
makoto@T3400:~ 9.6G [505] 07:16 2s :)
