Hello Wayne,
I tried with just the DP monitor plugged in on boot and I still get the wrong resolution (not the fallback):
casey@casey-desktop:~$ dmesg
[ 0.000000] Booting Linux on physical CPU 0x0
[ 0.000000] Linux version 4.9.140-tegra (root@casey-desktop) (gcc version 7.4.0 (Ubuntu/Linaro 7.4.0-1ubuntu1~18.04.1) ) #1 SMP PREEMPT Wed Aug 14 20:44:54 PDT 2019
[ 0.000000] Boot CPU: AArch64 Processor [411fd071]
[ 0.000000] OF: fdt:memory scan node memory@80000000, reg size 48,
[ 0.000000] OF: fdt: - 80000000 , 7ee00000
[ 0.000000] OF: fdt: - 100000000 , 7f200000
[ 0.000000] OF: fdt:Reserved memory: failed to reserve memory for node ‘fb0_carveout’: base 0x0000000000000000, size 0 MiB
[ 0.000000] OF: fdt:Reserved memory: failed to reserve memory for node ‘fb1_carveout’: base 0x0000000000000000, size 0 MiB
[ 0.000000] OF: reserved mem: initialized node vpr-carveout, compatible id nvidia,vpr-carveout
[ 0.000000] OF: reserved mem: initialized node iram-carveout, compatible id nvidia,iram-carveout
[ 0.000000] OF: reserved mem: initialized node ramoops_carveout, compatible id nvidia,ramoops
[ 0.000000] cma: Reserved 64 MiB at 0x00000000fac00000
[ 0.000000] On node 0 totalpages: 1039872
[ 0.000000] DMA zone: 8192 pages used for memmap
[ 0.000000] DMA zone: 0 pages reserved
[ 0.000000] DMA zone: 519168 pages, LIFO batch:31
[ 0.000000] Normal zone: 8136 pages used for memmap
[ 0.000000] Normal zone: 520704 pages, LIFO batch:31
[ 0.000000] psci: probing for conduit method from DT.
[ 0.000000] psci: PSCIv1.0 detected in firmware.
[ 0.000000] psci: Using standard PSCI v0.2 function IDs
[ 0.000000] psci: MIGRATE_INFO_TYPE not supported.
[ 0.000000] psci: SMC Calling Convention v1.1
[ 0.000000] percpu: Embedded 25 pages/cpu @ffffffc0fefb3000 s61592 r8192 d32616 u102400
[ 0.000000] pcpu-alloc: s61592 r8192 d32616 u102400 alloc=25*4096
[ 0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
[ 0.000000] CPU features: enabling workaround for ARM erratum 832075
[ 0.000000] Speculative Store Bypass Disable mitigation not required
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 1023544
[ 0.000000] Kernel command line: tegraid=21.1.2.0.0 ddr_die=4096M@2048M section=512M memtype=0 vpr_resize usb_port_owner_info=0 lane_owner_info=0 emc_max_dvfs=0 touch_id=0@63 video=tegrafb no_console_suspend=1 console=ttyS0,115200n8 debug_uartport=lsport,2 earlyprintk=uart8250-32bit,0x70006000 maxcpus=4 usbcore.old_scheme_first=1 lp0_vec=0x1000@0xff780000 core_edp_mv=1075 core_edp_ma=4000 root=/dev/mmcblk0p1 rw rootwait rootfstype=ext4 console=ttyS0,115200n8 console=tty0 fbcon=map:0 net.ifnames=0 root=/dev/mmcblk0p1 rw rootwait rootfstype=ext4 console=ttyS0,115200n8 console=tty0 fbcon=map:0 net.ifnames=0 quiet
[ 0.000000] log_buf_len individual max cpu contribution: 32768 bytes
[ 0.000000] log_buf_len total cpu_extra contributions: 98304 bytes
[ 0.000000] log_buf_len min size: 32768 bytes
[ 0.000000] log_buf_len: 131072 bytes
[ 0.000000] early log buf free: 29572(90%)
[ 0.000000] PID hash table entries: 4096 (order: 3, 32768 bytes)
[ 0.000000] Dentry cache hash table entries: 524288 (order: 10, 4194304 bytes)
[ 0.000000] Inode-cache hash table entries: 262144 (order: 9, 2097152 bytes)
[ 0.000000] Memory: 3570104K/4159488K available (15230K kernel code, 2914K rwdata, 6848K rodata, 8576K init, 609K bss, 114248K reserved, 475136K cma-reserved)
[ 0.000000] Virtual kernel memory layout:
[ 0.000000] modules : 0xffffff8000000000 - 0xffffff8008000000 ( 128 MB)
[ 0.000000] vmalloc : 0xffffff8008000000 - 0xffffffbebfff0000 ( 250 GB)
[ 0.000000] .text : 0xffffff8008080000 - 0xffffff8008f60000 ( 15232 KB)
[ 0.000000] .rodata : 0xffffff8008f60000 - 0xffffff8009620000 ( 6912 KB)
[ 0.000000] .init : 0xffffff8009620000 - 0xffffff8009e80000 ( 8576 KB)
[ 0.000000] .data : 0xffffff8009e80000 - 0xffffff800a158808 ( 2915 KB)
[ 0.000000] .bss : 0xffffff800a158808 - 0xffffff800a1f0dbc ( 610 KB)
[ 0.000000] fixed : 0xffffffbefe7fd000 - 0xffffffbefec00000 ( 4108 KB)
[ 0.000000] PCI I/O : 0xffffffbefee00000 - 0xffffffbeffe00000 ( 16 MB)
[ 0.000000] vmemmap : 0xffffffbf00000000 - 0xffffffc000000000 ( 4 GB maximum)
[ 0.000000] 0xffffffbf00000000 - 0xffffffbf03fc8000 ( 63 MB actual)
[ 0.000000] memory : 0xffffffc000000000 - 0xffffffc0ff200000 ( 4082 MB)
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
[ 0.000000] Preemptible hierarchical RCU implementation.
[ 0.000000] Build-time adjustment of leaf fanout to 64.
[ 0.000000] RCU restricting CPUs from NR_CPUS=64 to nr_cpu_ids=4.
[ 0.000000] RCU: Adjusting geometry for rcu_fanout_leaf=64, nr_cpu_ids=4
[ 0.000000] NR_IRQS:64 nr_irqs:64 0
[ 0.000000] /interrupt-controller@60004000: 192 interrupts forwarded to /interrupt-controller
[ 0.000000] t210 clock and reset probe
[ 0.000000] tegra-pmc: get_secure_pmc_setting: done secure_pmc=1
[ 0.000000] clk_cbus_recalc_rate: no gbus parent
[ 0.000000] arm_arch_timer: Architected cp15 timer(s) running at 19.20MHz (phys).
[ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x46d987e47, max_idle_ns: 440795202767 ns
[ 0.000006] sched_clock: 56 bits at 19MHz, resolution 52ns, wraps every 4398046511078ns
[ 0.001704] Console: colour dummy device 80x25
[ 0.001723] console [tty0] enabled
[ 0.001739] kmemleak: Kernel memory leak detector disabled
[ 0.001757] Calibrating delay loop (skipped), value calculated using timer frequency… 38.40 BogoMIPS (lpj=76800)
[ 0.001769] pid_max: default: 32768 minimum: 301
[ 0.002208] Security Framework initialized
[ 0.002430] Mount-cache hash table entries: 8192 (order: 4, 65536 bytes)
[ 0.002438] Mountpoint-cache hash table entries: 8192 (order: 4, 65536 bytes)
[ 0.003543] ftrace: allocating 46935 entries in 184 pages
[ 0.174540] sched-energy: CPU device node has no sched-energy-costs
[ 0.174575] ASID allocator initialised with 65536 entries
[ 0.211639] tegra-id: chipid=22117.
[ 0.211653] tegra-id: opt_subrevision=0.
[ 0.211672] Tegra Speedo/IDDQ fuse revision 4
[ 0.211677] Tegra: CPU Speedo ID 9, SoC Speedo ID 0, GPU Speedo ID 2
[ 0.211681] Tegra: CPU Process ID 0, SoC Process ID 1, GPU Process ID 0
[ 0.211687] Tegra: CPU Speedo Value 2089, SoC Speedo Value 1976, GPU Speedo Value 2097
[ 0.211690] Tegra: CPU IDDQ Value 2068, SoC IDDQ Value 2400, GPU IDDQ Value 2930
[ 0.211708] Tegra Revision: A02 SKU: 0x8f CPU Process: 0 SoC Process: 1
[ 0.211725] DTS File Name: /dvs/git/dirty/git-master_linux/kernel/kernel-4.9/arch/arm64/boot/dts/…/…/…/…/…/…/hardware/nvidia/platform/t210/porg/kernel-dts/tegra210-p3448-0000-p3449-0000-b00.dts
[ 0.211734] DTB Build time: Jul 16 2019 17:09:35
[ 0.261042] CPU1: Booted secondary processor [411fd071]
[ 0.292963] CPU2: Booted secondary processor [411fd071]
[ 0.324931] CPU3: Booted secondary processor [411fd071]
[ 0.325021] Brought up 4 CPUs
[ 0.325028] SMP: Total of 4 processors activated.
[ 0.325037] CPU features: detected feature: 32-bit EL0 Support
[ 0.325300] CPU: All CPU(s) started at EL2
[ 0.325318] alternatives: patching kernel code
[ 0.333371] devtmpfs: initialized
[ 0.369546] Initilizing CustomIPI irq domain
[ 0.369920] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[ 0.369940] futex hash table entries: 1024 (order: 4, 65536 bytes)
[ 0.380408] pinctrl core: initialized pinctrl subsystem
[ 0.381078] OS set in device tree is not L4T.
[ 0.381483] regulator-dummy: no parameters
[ 0.381748] Initializing plugin-manager
[ 0.381861] Plugin module not found
[ 0.382088] node /plugin-manager/fragement@0 match with board >=3448-0000-100
[ 0.382626] node /plugin-manager/fragment@1 match with board >=3448-0000-101
[ 0.383465] node /plugin-manager/fragment@5 match with board 3449-0000-200
[ 0.383865] node /plugin-manager/fragement@6 match with odm-data enable-tegra-wdt
[ 0.384267] node /plugin-manager/fragement@8 match with odm-data enable-tegra-wdt
[ 0.384656] node /plugin-manager/fragement@9 match with board <3448-0000-300
[ 0.389267] NET: Registered protocol family 16
[ 0.390587] pstore: using zlib compression
[ 0.390626] console [pstore-1] enabled
[ 0.390632] pstore: Registered ramoops as persistent store backend
[ 0.390637] ramoops: attached 0x200000@0xb0000000, ecc: 0/0
[ 0.405060] cpuidle: using governor menu
[ 0.409248] tegra_smmu 70019000.iommu: Loaded Tegra IOMMU driver
[ 0.410829] vdso: 2 pages (1 code @ ffffff8008f67000, 1 data @ ffffff8009e84000)
[ 0.410853] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[ 0.413493] atomic_pool_init():622: DMA: preallocated 1024 KiB pool for atomic allocations
[ 0.416015] tegra_powergate_init: DONE
[ 0.416031] DTS File Name: /dvs/git/dirty/git-master_linux/kernel/kernel-4.9/arch/arm64/boot/dts/…/…/…/…/…/…/hardware/nvidia/platform/t210/porg/kernel-dts/tegra210-p3448-0000-p3449-0000-b00.dts
[ 0.416037] DTB Build time: Jul 16 2019 17:09:35
[ 0.417732] Tegra reboot handler registered.
[ 0.422137] iommu: Adding device tegra-carveouts to group 0
[ 0.422279] platform tegra-carveouts: domain=ffffffc0f9ba23d8 allocates as[0]=ffffffc0f9bd40a8
[ 0.422620] iommu: Adding device smmu_test to group 1
[ 0.422668] platform smmu_test: domain=ffffffc0f9ba2618 allocates as[0]=ffffffc0f9bd4110
[ 0.423495] mc: mapped MMIO address: 0xffffff800802e000 -> 0x70019000
[ 0.423552] mc: mapped MMIO address: 0xffffff8008065000 -> 0x7001c000
[ 0.423604] mc: mapped MMIO address: 0xffffff8008079000 -> 0x7001d000
[ 0.423614] nv-tegra-mc 70019000.mc: No mssnvlink node
[ 0.423633] mc-err: mcerr ops are set to t21x
[ 0.432703] iommu: Adding device 70090000.xusb to group 2
[ 0.433002] iommu: Adding device 70006000.serial to group 3
[ 0.433085] platform 70006000.serial: domain=ffffffc0f9422cd8 allocates as[0]=ffffffc0f9bd4178
[ 0.433514] iommu: Adding device 70006040.serial to group 4
[ 0.433766] iommu: Adding device 70006200.serial to group 5
[ 0.433943] iommu: Adding device sound to group 6
[ 0.433994] platform sound: domain=ffffffc0f94ac258 allocates as[0]=ffffffc0f9bd41e0
[ 0.434539] iommu: Adding device 7000d400.spi to group 7
[ 0.434790] iommu: Adding device 7000d600.spi to group 8
[ 0.435076] iommu: Adding device 70410000.spi to group 9
[ 0.435374] iommu: Adding device 50000000.host1x to group 10
[ 0.435639] iommu: Adding device 54080000.vi to group 11
[ 0.436023] iommu: Adding device 54600000.isp to group 12
[ 0.436274] iommu: Adding device 54680000.isp to group 13
[ 0.436542] iommu: Adding device tegradc.0 to group 14
[ 0.436593] platform tegradc.0: domain=ffffffc0f94b8198 allocates as[0]=ffffffc0f9bd4248
[ 0.437144] platform tegradc.0: IOVA linear map 0x00000000d7000000(19000000)
[ 0.437479] iommu: Adding device tegradc.1 to group 15
[ 0.437526] platform tegradc.1: domain=ffffffc0f94b83d8 allocates as[0]=ffffffc0f9bd42b0
[ 0.438029] platform tegradc.1: IOVA linear map 0x00000000d7000000(19000000)
[ 0.438302] iommu: Adding device 54340000.vic to group 16
[ 0.438502] iommu: Adding device 544c0000.nvenc to group 17
[ 0.438689] iommu: Adding device 54500000.tsec to group 18
[ 0.438874] iommu: Adding device 54100000.tsecb to group 19
[ 0.439071] iommu: Adding device 54480000.nvdec to group 20
[ 0.439256] iommu: Adding device 54380000.nvjpg to group 21
[ 0.440283] iommu: Adding device 546c0000.i2c to group 22
[ 0.440617] iommu: Adding device 57000000.gpu to group 23
[ 0.440670] platform 57000000.gpu: domain=ffffffc0f94c33d8 allocates as[0]=ffffffc0f9bd4318
[ 0.440726] platform 57000000.gpu: domain=ffffffc0f94c33d8 allocates as[1]=ffffffc0f9bd4380
[ 0.440765] platform 57000000.gpu: domain=ffffffc0f94c33d8 allocates as[2]=ffffffc0f9bd43e8
[ 0.440797] platform 57000000.gpu: domain=ffffffc0f94c33d8 allocates as[3]=ffffffc0f9bd4450
[ 0.441698] tegra-pmc 7000e400.pmc: i2c-thermtrip node not found, emergency thermal reset disabled.
[ 0.441711] tegra-pmc 7000e400.pmc: scratch reg offset dts data not present
[ 0.441723] tegra-pmc: ### PMC reset source: TEGRA_SOFTWARE_RESET
[ 0.441728] tegra-pmc: ### PMC reset level: TEGRA_RESET_LEVEL_WARM
[ 0.441732] tegra-pmc: ### PMC reset status reg: 0x3
[ 0.493228] padctrl padctrl.0: Pad control driver tegra-pmc-padctrl registered
[ 0.493237] tegra-pmc: Clear bootloader IO dpd settings
[ 0.493257] tegra-pmc 7000e400.pmc: IO padctrl driver initialized
[ 0.493320] tegra-pmc 7000e400.pmc: PMC: Successfully configure bootrom reset commands
[ 0.493611] iommu: Adding device 70012000.se to group 24
[ 0.494361] iommu: Adding device 7000c000.i2c to group 25
[ 0.494607] iommu: Adding device 7000c400.i2c to group 26
[ 0.494842] iommu: Adding device 7000c500.i2c to group 27
[ 0.495087] iommu: Adding device 7000c700.i2c to group 28
[ 0.495350] iommu: Adding device 7000d000.i2c to group 29
[ 0.495597] iommu: Adding device 7000d100.i2c to group 30
[ 0.495896] iommu: Adding device sdhci-tegra.0 to group 31
[ 0.495952] platform sdhci-tegra.0: domain=ffffffc0f958b558 allocates as[0]=ffffffc0f9bd44b8
[ 0.496770] iommu: Adding device 700d0000.xudc to group 32
[ 0.500091] vdd-ac-bat: 5000 mV
[ 0.500425] vdd-5v0-sys: 5000 mV
[ 0.501374] vdd-5v0-hdmi: supplied by vdd-5v0-sys
[ 0.501415] vdd-5v0-hdmi: 5000 mV
[ 0.501815] vdd-1v8-sys: 1800 mV
[ 0.502245] vdd-fan: supplied by vdd-5v0-sys
[ 0.502279] vdd-fan: 5000 mV
[ 0.502647] vdd-usb-vbus: supplied by vdd-5v0-sys
[ 0.502681] vdd-usb-vbus: 5000 mV
[ 0.503190] vdd-usb-vbus2: 5000 mV
[ 0.534150] HugeTLB registered 2 MB page size, pre-allocated 0 pages
[ 0.536900] gpio gpiochip0: gpio-line-names specifies 240 line names but there are 256 lines on the chip
[ 0.538010] GPIO line 151 (camera-control-output-low) hogged as output/low
[ 0.538028] GPIO line 152 (camera-control-output-low) hogged as output/low
[ 0.538429] gpiochip_setup_dev: registered GPIOs 0 to 255 on device: gpiochip0 (tegra-gpio)
[ 0.546121] eventlib_kernel: keventlib is initialized, test id: 0
[ 0.546462] SCSI subsystem initialized
[ 0.546686] libata version 3.00 loaded.
[ 0.546957] usbcore: registered new interface driver usbfs
[ 0.547005] usbcore: registered new interface driver hub
[ 0.547083] usbcore: registered new device driver usb
[ 0.550774] max77620 4-003c: PMIC Version OTP:0x35 and ES:0x8
[ 0.556353] vdd-core: 600 <–> 1162 mV at 1075 mV
[ 0.557226] vdd-ddr-1v1: Bringing 1125000uV into 1150000-1150000uV
[ 0.557297] random: fast init done
[ 0.560362] vdd-ddr-1v1: 1150 mV
[ 0.564230] vdd-pre-reg-1v35: 1350 mV
[ 0.568228] vdd-1v8: 1800 mV
[ 0.572227] avdd-sys-1v2: 1200 mV
[ 0.576227] vdd-pex-1v0: 1050 mV
[ 0.576805] vddio-sdmmc-ap: 1800 <–> 3300 mV at 3300 mV
[ 0.577290] max77620-ldo3: at 3100 mV
[ 0.580233] vdd-rtc: 850 <–> 1100 mV at 1000 mV
[ 0.580723] max77620-ldo5: at 3100 mV
[ 0.581205] max77620-ldo6: at 2800 mV
[ 0.584237] avdd-1v05-pll: 1050 mV
[ 0.588226] avdd-io-hdmi-dp: 1050 mV
[ 0.589282] GPIO line 505 (spmic-default-output-high) hogged as output/high
[ 0.589549] gpiochip_setup_dev: registered GPIOs 504 to 511 on device: gpiochip1 (max77620-gpio)
[ 0.590890] max77620 4-003c: max77620 probe successful
[ 0.593548] media: Linux media interface: v0.10
[ 0.593602] Linux video capture interface: v2.00
[ 0.594473] pps_core: LinuxPPS API ver. 1 registered
[ 0.594480] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti giometti@linux.it
[ 0.594507] PTP clock support registered
[ 0.598217] tegra_fiq_debugger_init: found FIQ source (IRQ 98)
[ 0.604463] tegra210-emc 7001b000.external-memory-controller: validated EMC DFS table
[ 0.605225] Advanced Linux Sound Architecture Driver Initialized.
[ 0.605856] Bluetooth: Core ver 2.22
[ 0.605907] NET: Registered protocol family 31
[ 0.605911] Bluetooth: HCI device and connection manager initialized
[ 0.605923] Bluetooth: HCI socket layer initialized
[ 0.605932] Bluetooth: L2CAP socket layer initialized
[ 0.605958] Bluetooth: SCO socket layer initialized
[ 0.607618] tegra210_dvfs: no clock found for sdmmc2_ddr
[ 0.607633] tegra210_dvfs: no clock found for sdmmc4_ddr
[ 0.607677] tegra210_dvfs: no clock found for sdmmc1_ddr
[ 0.607690] tegra210_dvfs: no clock found for sdmmc3_ddr
[ 0.610829] tegra_dvfs: Unable to get vdd-cpu rail for step info, defering probe
[ 0.611912] vdd-3v3-sys: supplied by vdd-5v0-sys
[ 0.611989] vdd-3v3-sys: 3300 mV
[ 0.612283] vdd-1v8-sys: supplied by vdd-3v3-sys
[ 0.616289] vdd-usb-vbus2: supplied by vdd-3v3-sys
[ 0.616735] vdd-3v3-sd: supplied by vdd-3v3-sys
[ 0.616772] vdd-3v3-sd: 3300 mV
[ 0.617567] avdd-io-edp-1v05: supplied by avdd-1v05-pll
[ 0.617614] avdd-io-edp-1v05: 1050 mV
[ 0.618059] vdd-usb-hub-en: supplied by vdd-1v8-sys
[ 0.618093] vdd-usb-hub-en: 5000 mV
[ 0.619440] camchar: rtcpu character device driver loaded
[ 0.620134] extcon-gpio-states extcon:extcon@1: Cable state:1, cable id:1
[ 0.621505] clocksource: Switched to clocksource arch_sys_counter
[ 0.661256] VFS: Disk quotas dquot_6.6.0
[ 0.661381] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[ 0.661974] nvmap_heap_init: nvmap_heap_init: created heap block cache
[ 0.662384] dma_declare_coherent_resizable_cma_memory:324: resizable heap=vpr, base=0x00000000d7000000, size=0x19000000
[ 0.662401] dma-vpr: heap size is not multiple of cma_chunk_size heap_info->num_chunks (13) rem_chunk_size(0x1000000)
[ 0.662613] cma: enabled page replacement for spfn=d7000, epfn=f0000
[ 0.662618] dma_declare_coherent_resizable_cma_memory:373: resizable cma heap=vpr create successful
[ 0.662630] tegra-carveouts tegra-carveouts: assigned reserved memory node vpr-carveout
[ 0.662664] tegra-carveouts tegra-carveouts: iram :dma coherent mem declare 0x0000000040001000,258048
[ 0.662670] tegra-carveouts tegra-carveouts: assigned reserved memory node iram-carveout
[ 0.662683] nvmap: nvmap_select_cache_ops() nvmap cache ops set to set/ways
[ 0.662691] nvmap_page_pool_init: Total RAM pages: 1011310
[ 0.662696] nvmap_page_pool_init: nvmap page pool size: 126413 pages (493 MB)
[ 0.662791] nvmap_background_zero_thread: PP zeroing thread starting.
[ 0.663302] misc nvmap: created heap iram base 0x0000000040001000 size (252KiB)
[ 0.664177] misc nvmap: created heap vpr base 0x00000000d7000000 size (409600KiB)
[ 0.672385] thermal thermal_zone0: Registering thermal zone thermal_zone0 for type AO-therm
[ 0.672790] thermal thermal_zone1: Registering thermal zone thermal_zone1 for type CPU-therm
[ 0.673025] thermal thermal_zone2: Registering thermal zone thermal_zone2 for type GPU-therm
[ 0.673245] thermal thermal_zone3: Registering thermal zone thermal_zone3 for type PLL-therm
[ 0.673419] thermal thermal_zone4: Registering thermal zone thermal_zone4 for type PMIC-Die
[ 0.673715] pre_t19x_iso_plat_init(): iso emc max clk=1600000KHz
[ 0.673719] pre_t19x_iso_plat_init(): max_iso_bw=33280000KB
[ 0.674152] NET: Registered protocol family 2
[ 0.675167] TCP established hash table entries: 32768 (order: 6, 262144 bytes)
[ 0.675376] TCP bind hash table entries: 32768 (order: 7, 524288 bytes)
[ 0.675871] TCP: Hash tables configured (established 32768 bind 32768)
[ 0.676010] UDP hash table entries: 2048 (order: 4, 65536 bytes)
[ 0.676090] UDP-Lite hash table entries: 2048 (order: 4, 65536 bytes)
[ 0.676500] NET: Registered protocol family 1
[ 0.677190] RPC: Registered named UNIX socket transport module.
[ 0.677197] RPC: Registered udp transport module.
[ 0.677201] RPC: Registered tcp transport module.
[ 0.677204] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.677217] PCI: CLS 0 bytes, default 64
[ 0.677442] Trying to unpack rootfs image as initramfs…
[ 0.922087] Freeing initrd memory: 5432K
[ 0.931720] host1x 50000000.host1x: initialized
[ 0.933479] hw perfevents: enabled with armv8_pmuv3 PMU driver, 7 counters available
[ 0.936775] audit: initializing netlink subsys (disabled)
[ 0.936842] audit: type=2000 audit(0.787:1): initialized
[ 0.937630] workingset: timestamp_bits=46 max_order=20 bucket_order=0
[ 0.947555] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 0.949012] ntfs: driver 2.1.32 [Flags: R/W].
[ 0.949969] 9p: Installing v9fs 9p2000 file system support
[ 0.953167] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 240)
[ 0.953302] io scheduler noop registered
[ 0.953632] io scheduler cfq registered (default)
[ 0.956261] gic 702f9000.agic: GIC IRQ controller registered
[ 0.959225] iommu: Adding device 702ef000.adsp to group 33
[ 0.966229] iommu: Adding device aconnect@702c0000:adsp_audio to group 34
[ 0.966398] tegra-aconnect aconnect@702c0000: Tegra ACONNECT bus registered
[ 0.966965] tegra-xusb-padctl 7009f000.xusb_padctl: TEGRA_FUSE_SKU_CALIB_0 = 0xbacb418
[ 0.966972] tegra-xusb-padctl 7009f000.xusb_padctl: TEGRA_FUSE_USB_CALIB_EXT_0 = 0x4
[ 0.968584] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-usb2.0, lane = usb2-0, function = xusb
[ 0.968685] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-usb2.1, lane = usb2-1, function = xusb
[ 0.968780] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-usb2.2, lane = usb2-2, function = xusb
[ 0.968971] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-pcie.3, lane = pcie-0, function = pcie-x1
[ 0.969058] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-pcie.4, lane = pcie-1, function = pcie-x4
[ 0.969149] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-pcie.5, lane = pcie-2, function = pcie-x4
[ 0.969232] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-pcie.6, lane = pcie-3, function = pcie-x4
[ 0.969330] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-pcie.7, lane = pcie-4, function = pcie-x4
[ 0.969411] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-pcie.8, lane = pcie-5, function = xusb
[ 0.969533] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-pcie.9, lane = pcie-6, function = xusb
[ 0.974786] tegra-pwm 7000a000.pwm: PWM clk cannot sleep in ops
[ 0.976450] tegra-dfll-pwm 70110000.pwm: DFLL pwm-rate: 12800000
[ 0.978331] tegra-pcie 1003000.pcie: 4x1, 1x1 configuration
[ 0.979603] tegra-pcie 1003000.pcie: PCIE: Enable power rails
[ 0.979954] tegra-pcie 1003000.pcie: probing port 0, using 4 lanes
[ 0.981121] tegra_camera_platform tegra-camera-platform: tegra_camera_probe:camera_platform_driver probe
[ 0.981354] misc tegra_camera_ctrl: tegra_camera_isomgr_register isp_iso_bw=1500000, vi_iso_bw=750000, max_bw=1500000
[ 0.981731] tegra-pcie 1003000.pcie: probing port 1, using 1 lanes
[ 0.981876] Adding domain tsec-pd to PM domain host1x-pd
[ 0.985011] tsec 54500000.tsec: initialized
[ 0.986397] tsec 54100000.tsecb: initialized
[ 0.987105] Adding domain nvdec-pd to PM domain host1x-pd
[ 0.990412] nvdec 54480000.nvdec: initialized
[ 0.991427] Adding domain vic03-pd to PM domain host1x-pd
[ 0.991605] Adding domain msenc-pd to PM domain host1x-pd
[ 0.991762] Adding domain nvjpg-pd to PM domain host1x-pd
[ 0.995816] falcon 54340000.vic: initialized
[ 0.996999] falcon 544c0000.nvenc: initialized
[ 0.998324] falcon 54380000.nvjpg: initialized
[ 1.002658] tegradc tegradc.0: disp0 connected to head0->/host1x/sor1
[ 1.002778] display board info: id 0x0, fab 0x0
[ 1.002844] generic_infoframe_type: 0x87
[ 1.002984] tegradc tegradc.0: DT parsed successfully
[ 1.003030] tegradc tegradc.0: Display dc.ffffff800ab80000 registered with id=0
[ 1.006270] tegradc tegradc.0: probed
[ 1.010597] tegra-apbdma 60020000.dma: Tegra20 APB DMA driver register 32 channels
[ 1.014682] tegra-adma 702e2000.adma: Tegra210 ADMA driver registered 10 channels
[ 1.015372] tegra-fuse-burn 7000f800.efuse:efuse-burn: Fuse burn driver initialized
[ 1.015719] kfuse 7000fc00.kfuse: initialized
[ 1.017090] tegra-pmc-iopower pmc-iopower: Regulator supply iopower-dbg-supply not available
[ 1.018155] tegra-pmc-iopower pmc-iopower: NO_IOPOWER setting 0x0
[ 1.019604] tegra-dfll-pwm 70110000.pwm: DFLL_PWM regulator is available now
[ 1.019625] vdd-cpu: 708 <–> 1322 mV at 708 mV
[ 1.020079] pwm-regulator pwm_regulators:pwm-regulator@0: PWM regulator registration passed
[ 1.021261] vdd-gpu: applied init 1000000uV constraint
[ 1.021269] vdd-gpu: 708 <–> 1323 mV at 997 mV
[ 1.021703] pwm-regulator pwm_regulators:pwm-regulator@1: PWM regulator registration passed
[ 1.026045] Serial: 8250/16550 driver, 4 ports, IRQ sharing disabled
[ 1.026192] No Device Node present for smmu client: serial8250 !!
[ 1.026208] platform serial8250: No iommus property found in DT node, got swgids from fixup(101004000)
[ 1.026279] iommu: Adding device serial8250 to group 35
[ 1.028880] console [ttyS0] disabled
[ 1.028955] 70006000.serial: ttyS0 at MMIO 0x70006000 (irq = 63, base_baud = 25500000) is a Tegra
[ 1.029047] console [ttyS0] enabled
[ 1.029923] 70006040.serial: ttyTHS1 at MMIO 0x70006040 (irq = 64, base_baud = 0) is a TEGRA_UART
[ 1.030199] serial-tegra 70006200.serial: RX in PIO mode
[ 1.030286] 70006200.serial: ttyTHS2 at MMIO 0x70006200 (irq = 65, base_baud = 0) is a TEGRA_UART
[ 1.031197] [drm] Initialized
[ 1.033044] Console: switching to colour frame buffer device 80x30
[ 1.033083] tegradc tegradc.0: fb registered
[ 1.035010] tegradc tegradc.1: disp1 connected to head1->/host1x/sor
[ 1.035108] tegradc tegradc.1: No lt-data, using default setting
[ 1.035141] tegradc tegradc.1: No hpd-gpio in DT
[ 1.035177] tegradc tegradc.1: DT parsed successfully
[ 1.035228] tegradc tegradc.1: Display dc.ffffff800d500000 registered with id=1
[ 1.036847] tegradc tegradc.1: dpd enable lookup fail:-19
[ 1.042201] brd: module loaded
[ 1.548164] Host read timeout at address 545c00c4
[ 1.549100] loop: module loaded
[ 1.549208] tegra_profiler: version: 1.134, samples/io: 47/26
[ 1.549324] tegra_profiler: auth: init
[ 1.549779] tegradc tegradc.1: probed
[ 1.550931] THERMAL EST: found 2 subdevs
[ 1.550948] THERMAL EST num_resources: 0
[ 1.550958] [THERMAL EST subdev 0]
[ 1.550967] [THERMAL EST subdev 1]
[ 1.551632] thermal thermal_zone5: Registering thermal zone thermal_zone5 for type thermal-fan-est
[ 1.551636] THERMAL EST: thz register success.
[ 1.552056] THERMAL EST: end of probe, return err: 0
[ 1.554293] hisi_sas: driver version v1.6
[ 1.564994] tegra-qspi 70410000.spi: Prod settings list not found
[ 1.566730] qspi_mtd spi32766.0: MX25U3235F (4096 Kbytes)
[ 1.566743] qspi_mtd spi32766.0: mtd .name = spi32766.0, .size = 0x400000 (4MiB) .erasesize = 0x00001000 (4KiB) .numeraseregions = 0
[ 1.570442] libphy: Fixed MDIO Bus: probed
[ 1.571032] tun: Universal TUN/TAP device driver, 1.6
[ 1.571038] tun: © 1999-2004 Max Krasnyansky maxk@qualcomm.com
[ 1.572337] e1000e: Intel® PRO/1000 Network Driver - 3.2.6-k
[ 1.572343] e1000e: Copyright© 1999 - 2015 Intel Corporation.
[ 1.572404] igb: Intel® Gigabit Ethernet Network Driver - version 5.4.0-k
[ 1.572408] igb: Copyright © 2007-2014 Intel Corporation.
[ 1.572457] igbvf: Intel® Gigabit Virtual Function Network Driver - version 2.4.0-k
[ 1.572461] igbvf: Copyright © 2009 - 2012 Intel Corporation.
[ 1.572509] Intel® 10GbE PCI Express Linux Network Driver - version 4.6.4
[ 1.572514] Copyright© 1999 - 2017 Intel Corporation.
[ 1.573532] PPP generic driver version 2.4.2
[ 1.573755] PPP BSD Compression module registered
[ 1.573761] PPP Deflate Compression module registered
[ 1.573813] PPP MPPE Compression module registered
[ 1.573820] NET: Registered protocol family 24
[ 1.573900] usbcore: registered new interface driver r8152
[ 1.573951] usbcore: registered new interface driver asix
[ 1.574002] usbcore: registered new interface driver ax88179_178a
[ 1.574041] usbcore: registered new interface driver cdc_ether
[ 1.574075] usbcore: registered new interface driver net1080
[ 1.574112] usbcore: registered new interface driver cdc_subset
[ 1.574144] usbcore: registered new interface driver zaurus
[ 1.574202] usbcore: registered new interface driver cdc_ncm
[ 1.574390] VFIO - User Level meta-driver version: 0.3
[ 1.575097] tegradc tegradc.1: fb registered
[ 1.575942] ehci_hcd: USB 2.0 ‘Enhanced’ Host Controller (EHCI) Driver
[ 1.575968] ehci-pci: EHCI PCI platform driver
[ 1.576017] ohci_hcd: USB 1.1 ‘Open’ Host Controller (OHCI) Driver
[ 1.576030] ohci-pci: OHCI PCI platform driver
[ 1.576078] ohci-platform: OHCI generic platform driver
[ 1.578994] tegra-xusb 70090000.xusb: USB2 port 0 has OTG_CAP
[ 1.579738] tegra-xusb-padctl 7009f000.xusb_padctl: enabled OTG on UTMI pad 0
[ 1.580918] tegra-xusb 70090000.xusb: extcon 0: ffffffc0f9692000 id
[ 1.583079] usbcore: registered new interface driver uas
[ 1.583157] usbcore: registered new interface driver usb-storage
[ 1.583312] usbcore: registered new interface driver usbserial
[ 1.583907] tegra-xusb 70090000.xusb: Firmware timestamp: 2019-05-08 09:42:10 UTC, Version: 50.22 release
[ 1.583975] tegra-xusb 70090000.xusb: xHCI Host Controller
[ 1.584006] tegra-xusb 70090000.xusb: new USB bus registered, assigned bus number 1
[ 1.584926] tegra-xusb 70090000.xusb: hcc params 0x0184f525 hci version 0x100 quirks 0x00050010
[ 1.584987] tegra-xusb 70090000.xusb: irq 61, io mem 0x70090000
[ 1.585198] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ 1.585205] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.585210] usb usb1: Product: xHCI Host Controller
[ 1.585214] usb usb1: Manufacturer: Linux 4.9.140-tegra xhci-hcd
[ 1.585219] usb usb1: SerialNumber: 70090000.xusb
[ 1.585975] hub 1-0:1.0: USB hub found
[ 1.586032] hub 1-0:1.0: 5 ports detected
[ 1.586667] tegra-xusb 70090000.xusb: xHCI Host Controller
[ 1.586680] tegra-xusb 70090000.xusb: new USB bus registered, assigned bus number 2
[ 1.586777] usb usb2: We don’t know the algorithms for LPM for this host, disabling LPM.
[ 1.586880] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003
[ 1.586886] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.586892] usb usb2: Product: xHCI Host Controller
[ 1.586896] usb usb2: Manufacturer: Linux 4.9.140-tegra xhci-hcd
[ 1.586901] usb usb2: SerialNumber: 70090000.xusb
[ 1.587020] tegra-xudc-new 700d0000.xudc: device count: 1
[ 1.587459] hub 2-0:1.0: USB hub found
[ 1.587502] hub 2-0:1.0: 4 ports detected
[ 1.588346] tegradc tegradc.1: nominal-pclk:74250000 parent:74250000 div:1.0 pclk:74250000 73507500~80932500
[ 1.588370] tegra-xudc-new 700d0000.xudc: USB charger detection disabled
[ 1.588382] tegra-xudc-new 700d0000.xudc: vbus state: 1
[ 1.588397] tegra-xudc-new 700d0000.xudc: device mode on: 0
[ 1.588413] tegra-xusb-padctl 7009f000.xusb_padctl: power on UTMI pads 0
[ 1.588436] tegra-xudc-new 700d0000.xudc: active: 0 => 1
[ 1.589186] mousedev: PS/2 mouse device common for all mice
[ 1.589300] usbcore: registered new interface driver xpad
[ 1.590478] tegradc tegradc.1: tegra_dp_get_bpp: vmode=0x10600000 did not specify bpp
[ 1.594120] tegradc tegradc.1: DP: no prod_c_hbr prod settings node in device tree
[ 1.598743] dp lt: state 0 (Reset), pending_lt_evt 1
[ 1.598749] dp lt: switching from state 0 (Reset) to state 0 (Reset)
[ 1.598755] dp lt: state 0 (Reset), pending_lt_evt 0
[ 1.599972] tegradc tegradc.1: DP: no prod_c_hbr prod settings node in device tree
[ 1.600122] dp lt: switching from state 0 (Reset) to state 2 (clock recovery)
[ 1.600128] dp lt: state 2 (clock recovery), pending_lt_evt 0
[ 1.600370] dp lt: config: lane 0: vs level: 0, pe level: 0, pc2 level: 0
[ 1.600381] dp lt: config: lane 1: vs level: 0, pe level: 0, pc2 level: 0
[ 1.600391] dp lt: config: lane 2: vs level: 0, pe level: 0, pc2 level: 0
[ 1.600402] dp lt: config: lane 3: vs level: 0, pe level: 0, pc2 level: 0
[ 1.600412] dp lt: tx_pu: 0x20
[ 1.601323] dp lt: CR not done
[ 1.601737] dp lt: new config: lane 0: vs level: 1, pe level: 0, pc2 level: 0
[ 1.601742] dp lt: new config: lane 1: vs level: 1, pe level: 0, pc2 level: 0
[ 1.601745] dp lt: new config: lane 2: vs level: 1, pe level: 0, pc2 level: 0
[ 1.601748] dp lt: new config: lane 3: vs level: 1, pe level: 0, pc2 level: 0
[ 1.601752] dp lt: CR retry
[ 1.601756] dp lt: switching from state 2 (clock recovery) to state 2 (clock recovery)
[ 1.601761] dp lt: state 2 (clock recovery), pending_lt_evt 0
[ 1.601774] dp lt: config: lane 0: vs level: 1, pe level: 0, pc2 level: 0
[ 1.601785] dp lt: config: lane 1: vs level: 1, pe level: 0, pc2 level: 0
[ 1.601795] dp lt: config: lane 2: vs level: 1, pe level: 0, pc2 level: 0
[ 1.601806] dp lt: config: lane 3: vs level: 1, pe level: 0, pc2 level: 0
[ 1.601813] dp lt: tx_pu: 0x30
[ 1.602723] dp lt: CR done
[ 1.602727] dp lt: switching from state 2 (clock recovery) to state 3 (channel equalization)
[ 1.602740] dp lt: state 3 (channel equalization), pending_lt_evt 0
[ 1.605162] dp lt: CE done
[ 1.605168] dp lt: switching from state 3 (channel equalization) to state 5 (link training pass)
[ 1.605248] extcon-disp-state extcon:disp-state: cable 46 state 1
[ 1.605253] Extcon AUX0(DP): enable
[ 1.605257] dp_audio switch 1
[ 1.605781] hpd: state 7 (Takeover from bootloader), hpd 1, pending_hpd_evt 1
[ 1.605790] hpd: switching from state 7 (Takeover from bootloader) to state 1 (Check Plug)
[ 1.689604] tegra-xusb-padctl 7009f000.xusb_padctl: power on UTMI pads 1
[ 1.708542] max77686-rtc max77620-rtc: rtc core: registered max77620-rtc as rtc0
[ 1.709552] hpd: state 1 (Check Plug), hpd 1, pending_hpd_evt 0
[ 1.709560] hpd: switching from state 1 (Check Plug) to state 2 (Check EDID)
[ 1.711018] rtc rtc1: alarm rtc device
[ 1.711038] tegra_rtc 7000e000.rtc: rtc core: registered 7000e000.rtc as rtc1
[ 1.711069] tegra_rtc 7000e000.rtc: Tegra internal Real Time Clock
[ 1.711647] i2c /dev entries driver
[ 1.713856] imx219 6-0010: tegracam sensor driver:imx219_v2.0.6
[ 1.717526] hpd: state 2 (Check EDID), hpd 1, pending_hpd_evt 0
[ 1.718963] tegradc tegradc.1: blank - powerdown
[ 1.737201] tegra-vii2c 546c0000.i2c: no acknowledge from address 0x10
[ 1.737276] imx219 6-0010: imx219_board_setup: error during i2c read probe (-121)
[ 1.737308] imx219 6-0010: board setup failed
[ 1.737405] imx219: probe of 6-0010 failed with error -121
[ 1.739216] max77620-power max77620-power: Event recorder REG_NVERC : 0x0
[ 1.742174] tegra_soctherm 700e2000.soctherm: pllx_offset tz:0 max:14, min:2
[ 1.742179] tegra_soctherm 700e2000.soctherm: pllx_offset tz:2 max:8, min:4
[ 1.742627] tegra_soctherm 700e2000.soctherm: soctherm: trip temperature -2147483647 forced to -127000
[ 1.742644] tegra_soctherm 700e2000.soctherm: thermtrip: will shut down when cpu reaches 102500 mC
[ 1.742652] tegra_soctherm 700e2000.soctherm: throttrip: will throttle when cpu reaches 100500 mC
[ 1.742782] tegra_soctherm 700e2000.soctherm: soctherm: trip temperature -2147483647 forced to -127000
[ 1.742792] tegra_soctherm 700e2000.soctherm: thermtrip: will shut down when gpu reaches 103000 mC
[ 1.742798] tegra_soctherm 700e2000.soctherm: throttrip: will throttle when gpu reaches 101000 mC
[ 1.742970] tegra_soctherm 700e2000.soctherm: soctherm: trip temperature -2147483647 forced to -127000
[ 1.742980] tegra_soctherm 700e2000.soctherm: thermtrip: will shut down when pll reaches 127000 mC
[ 1.742984] tegra_soctherm 700e2000.soctherm: throttrip: pll: missing hot temperature
[ 1.743151] tegra_soctherm 700e2000.soctherm: failed to register sensor: -19
[ 1.743940] tegra_aotag tegra-aotag: Registering sensor 0
[ 1.743992] tegra_aotag tegra-aotag: Invalid temp readout
[ 1.744019] tegra_aotag tegra-aotag: Invalid temp readout
[ 1.744036] tegra_aotag tegra-aotag: Bound to TZ : ID 0
[ 1.744044] tegra_aotag tegra-aotag: Probe done [SUCCESS]:0
[ 1.744950] tegra_soctherm 700e2000.soctherm: soctherm: trip temperature -2147483647 forced to -127000
[ 1.744970] tegra_dfll_action dfll-cdev-cap: Tegra DFLL ‘cap cooling device’ registered
[ 1.745160] tegra_aotag tegra-aotag: Invalid temp readout
[ 1.745189] tegra_dfll_action dfll-cdev-floor: Tegra DFLL ‘floor cooling device’ registered
[ 1.745621] parse_throttle_dt_data: Num cap clks = 6
[ 1.745626] parse_throttle_dt_data: clk=cclk_g type=2
[ 1.745639] parse_throttle_dt_data: clk=gpu type=4
[ 1.745666] parse_throttle_dt_data: clk=cap.throttle.c2bus type=0
[ 1.745684] parse_throttle_dt_data: clk=cap.throttle.c3bus type=0
[ 1.745704] parse_throttle_dt_data: clk=cap.throttle.sclk type=0
[ 1.745707] parse_throttle_dt_data: clk=emc type=3
[ 1.746101] tegra_soctherm 700e2000.soctherm: soctherm: trip temperature -2147483647 forced to -127000
[ 1.746208] tegra_soctherm 700e2000.soctherm: soctherm: trip temperature -2147483647 forced to -127000
[ 1.746333] tegra_throttle_probe: probe successful. #cdevs=4
[ 1.747072] FAN dev name: pwm-fan
[ 1.747132] FAN:gpio request success.
[ 1.747212] pwm_fan_driver pwm-fan: cap state:7, cap pwm:255
[ 1.747515] pwm_fan_driver pwm-fan: got pwm for fan. polarity is normal
[ 1.747727] pwm_fan_driver pwm-fan: fan tach request irq success
[ 1.747737] pwm_fan_driver pwm-fan: tach period: 1000
[ 1.747836] pwm_fan_driver pwm-fan: index 0: pwm=0, rpm=0, rru=40, rrd=40, state:2
[ 1.747841] pwm_fan_driver pwm-fan: index 1: pwm=80, rpm=1000, rru=2, rrd=2, state:2
[ 1.747845] pwm_fan_driver pwm-fan: index 2: pwm=120, rpm=2000, rru=1, rrd=1, state:2
[ 1.747849] pwm_fan_driver pwm-fan: index 3: pwm=160, rpm=3000, rru=1, rrd=1, state:2
[ 1.747852] pwm_fan_driver pwm-fan: index 4: pwm=255, rpm=4000, rru=1, rrd=1, state:3
[ 1.747856] pwm_fan_driver pwm-fan: index 5: pwm=255, rpm=5000, rru=1, rrd=1, state:3
[ 1.747860] pwm_fan_driver pwm-fan: index 6: pwm=255, rpm=6000, rru=1, rrd=1, state:3
[ 1.747863] pwm_fan_driver pwm-fan: index 7: pwm=255, rpm=7000, rru=1, rrd=1, state:4
[ 1.747867] pwm_fan_driver pwm-fan: index 8: pwm=255, rpm=10000, rru=1, rrd=1, state:4
[ 1.747871] pwm_fan_driver pwm-fan: index 9: pwm=255, rpm=11000, rru=1, rrd=1, state:4
[ 1.748512] tegra-wdt 60005100.watchdog: Tegra WDT enabled on probe. Timeout = 120 seconds.
[ 1.748850] tegra-wdt 60005100.watchdog: initialized (timeout = 120 sec, nowayout = 1)
[ 1.749762] device-mapper: uevent: version 1.0.3
[ 1.750243] device-mapper: ioctl: 4.35.0-ioctl (2016-06-23) initialised: dm-devel@redhat.com
[ 1.755941] tegra210-cpufreq cpufreq: probe()…completed
[ 1.756030] dp lt: state 5 (link training pass), pending_lt_evt 1
[ 1.756032] dp lt: switching from state 5 (link training pass) to state 0 (Reset)
[ 1.756035] dp lt: state 0 (Reset), pending_lt_evt 0
[ 1.756040] dp lt: link training force disable
[ 1.756042] dp lt: switching from state 0 (Reset) to state 4 (link training fail/disable)
[ 1.756665] sdhci: Secure Digital Host Controller Interface driver
[ 1.756667] sdhci: Copyright© Pierre Ossman
[ 1.756668] sdhci-pltfm: SDHCI platform and OF driver helper
[ 1.757157] sdhci-tegra sdhci-tegra.0: Got CD GPIO
[ 1.757563] sdhci-tegra sdhci-tegra.0: Client registration for eMC Successful
[ 1.757689] sdhci-tegra sdhci-tegra.0: wakeup init done, cdirq 300
[ 1.772979] tegra-se 70012000.se: tegra_se_probe: complete
[ 1.773482] hidraw: raw HID events driver © Jiri Kosina
[ 1.774589] usbcore: registered new interface driver usbhid
[ 1.774590] usbhid: USB HID core driver
[ 1.775591] extcon-disp-state extcon:disp-state: cable 46 state 0
[ 1.775594] Extcon AUX0(DP) disable
[ 1.775595] dp_audio switch 0
[ 1.775940] tegradc tegradc.1: unblank
[ 1.777435] tegra21x_actmon 6000c800.actmon: in actmon_register()…
[ 1.777661] tegra21x_actmon 6000c800.actmon: initialization Completed for the device mc_all
[ 1.779304] nvpmodel: initialized successfully
[ 1.780378] usbcore: registered new interface driver snd-usb-audio
[ 1.780435] No Device Node present for smmu client: snd-soc-dummy !!
[ 1.780439] platform snd-soc-dummy: No iommus property found in DT node, got swgids from fixup(101004000)
[ 1.780457] iommu: Adding device snd-soc-dummy to group 36
[ 1.801784] mmc0: SDHCI controller on sdhci-tegra.0 [sdhci-tegra.0] using ADMA 64-bit with 64 bit addr
[ 1.805723] OPE platform probe
[ 1.805816] OPE platform probe successful
[ 1.806261] OPE platform probe
[ 1.806344] OPE platform probe successful
[ 1.811586] tegradc tegradc.1: nominal-pclk:25180000 parent:25179638 div:1.0 pclk:25179638 24928200~27446200
[ 1.812400] input: tegra-hda HDMI/DP,pcm=3 as /devices/70030000.hda/sound/card0/input0
[ 1.812985] tegradc tegradc.1: tegra_dp_get_bpp: vmode=0x10000000 did not specify bpp
[ 1.816598] tegradc tegradc.1: DP: no prod_c_hbr prod settings node in device tree
[ 1.820996] dp lt: state 4 (link training fail/disable), pending_lt_evt 1
[ 1.820998] dp lt: switching from state 4 (link training fail/disable) to state 0 (Reset)
[ 1.821001] dp lt: state 0 (Reset), pending_lt_evt 0
[ 1.822181] tegradc tegradc.1: DP: no prod_c_hbr prod settings node in device tree
[ 1.822340] dp lt: switching from state 0 (Reset) to state 2 (clock recovery)
[ 1.822344] dp lt: state 2 (clock recovery), pending_lt_evt 0
[ 1.822581] dp lt: config: lane 0: vs level: 0, pe level: 0, pc2 level: 0
[ 1.822590] dp lt: config: lane 1: vs level: 0, pe level: 0, pc2 level: 0
[ 1.822600] dp lt: config: lane 2: vs level: 0, pe level: 0, pc2 level: 0
[ 1.822609] dp lt: config: lane 3: vs level: 0, pe level: 0, pc2 level: 0
[ 1.822616] dp lt: tx_pu: 0x20
[ 1.823532] dp lt: CR done
[ 1.823534] dp lt: switching from state 2 (clock recovery) to state 3 (channel equalization)
[ 1.823537] dp lt: state 3 (channel equalization), pending_lt_evt 0
[ 1.825967] dp lt: CE done
[ 1.825970] dp lt: switching from state 3 (channel equalization) to state 5 (link training pass)
[ 1.826008] extcon-disp-state extcon:disp-state: cable 46 state 1
[ 1.826010] Extcon AUX0(DP): enable
[ 1.826011] dp_audio switch 1
[ 1.826320] tegradc tegradc.1: sync windows ret = 250
[ 1.831507] tegra-asoc: sound: ADMAIF1 <-> ADMAIF1 mapping ok
[ 1.831644] tegra-asoc: sound: ADMAIF2 <-> ADMAIF2 mapping ok
[ 1.831781] tegra-asoc: sound: ADMAIF3 <-> ADMAIF3 mapping ok
[ 1.831910] tegra-asoc: sound: ADMAIF4 <-> ADMAIF4 mapping ok
[ 1.832039] tegra-asoc: sound: ADMAIF5 <-> ADMAIF5 mapping ok
[ 1.832170] tegra-asoc: sound: ADMAIF6 <-> ADMAIF6 mapping ok
[ 1.832299] tegra-asoc: sound: ADMAIF7 <-> ADMAIF7 mapping ok
[ 1.832426] tegra-asoc: sound: ADMAIF8 <-> ADMAIF8 mapping ok
[ 1.832554] tegra-asoc: sound: ADMAIF9 <-> ADMAIF9 mapping ok
[ 1.832683] tegra-asoc: sound: ADMAIF10 <-> ADMAIF10 mapping ok
[ 1.838327] tegradc tegradc.1: blank - powerdown
[ 1.842764] dp lt: state 5 (link training pass), pending_lt_evt 1
[ 1.842767] dp lt: switching from state 5 (link training pass) to state 0 (Reset)
[ 1.842770] dp lt: state 0 (Reset), pending_lt_evt 0
[ 1.842775] dp lt: link training force disable
[ 1.842777] dp lt: switching from state 0 (Reset) to state 4 (link training fail/disable)
[ 1.844528] u32 classifier
[ 1.844530] Actions configured
[ 1.844601] Initializing XFRM netlink socket
[ 1.845333] NET: Registered protocol family 10
[ 1.846076] NET: Registered protocol family 17
[ 1.846086] NET: Registered protocol family 15
[ 1.846162] bridge: filtering via arp/ip/ip6tables is no longer available by default. Update your scripts to load br_netfilter if you need this.
[ 1.846210] Bluetooth: RFCOMM socket layer initialized
[ 1.846218] Bluetooth: RFCOMM ver 1.11
[ 1.846222] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
[ 1.846227] Bluetooth: HIDP socket layer initialized
[ 1.846245] 9pnet: Installing 9P2000 support
[ 1.846282] Key type dns_resolver registered
[ 1.846658] Registered cp15_barrier emulation handler
[ 1.846666] Registered setend emulation handler
[ 1.847762] registered taskstats version 1
[ 1.848282] Adding domain ve2-pd to PM domain host1x-pd
[ 1.848535] Adding domain ve-pd to PM domain host1x-pd
[ 1.850605] isp 54600000.isp: initialized
[ 1.851592] isp 54680000.isp: initialized
[ 1.862965] last reset is due to software reset
[ 1.862968] KERNEL: PMC reset status reg: 0x3
[ 1.863045] BL: PMC reset status reg: 0x3
[ 1.863047] BL: PMIC poweroff Event Recorder: 0x0
[ 1.863148] extcon-disp-state extcon:disp-state: cable 46 state 0
[ 1.863150] Extcon AUX0(DP) disable
[ 1.863152] dp_audio switch 0
[ 1.863528] tegradc tegradc.1: unblank
[ 1.864543] clk_cbus_recalc_rate: no gbus parent
[ 1.864547] clk_cbus_round_rate: no gbus parent
[ 1.864549] clk_cbus_round_rate: no gbus parent
[ 1.864553] clk_cbus_recalc_rate: no gbus parent
[ 1.864656] clk_cbus_recalc_rate: no gbus parent
[ 1.864659] clk_cbus_round_rate: no gbus parent
[ 1.864660] clk_cbus_round_rate: no gbus parent
[ 1.864664] clk_cbus_recalc_rate: no gbus parent
[ 1.865345] tegra_dvfs: GPU-cap: registered
[ 1.865398] tegra dvfs: vdd-cpu: nominal 1168mV, offset 708000uV, step 19200uV, scaling enabled
[ 1.865400] tegra dvfs: vdd-core: nominal 1075mV, offset 600000uV, step 12500uV, scaling enabled
[ 1.865402] tegra dvfs: vdd-gpu: nominal 1048mV, offset 708000uV, step 10000uV, scaling enabled
[ 1.866858] tegra_dvfs: vdd-gpu-vts: registered
[ 1.867609] tegra_core_action core_dvfs_cdev_floor: Tegra CORE DVFS ‘floor cooling device’ registered
[ 1.868260] tegra_core_action core_dvfs_cdev_cap: Tegra CORE DVFS ‘cap cooling device’ registered
[ 1.868731] input: gpio-keys as /devices/gpio-keys/input/input1
[ 1.895608] tegradc tegradc.1: nominal-pclk:25180000 parent:25179638 div:1.0 pclk:25179638 24928200~27446200
[ 1.896991] tegradc tegradc.1: tegra_dp_get_bpp: vmode=0x10000000 did not specify bpp
[ 1.898637] tegra_rtc 7000e000.rtc: setting system clock to 2019-08-20 15:03:30 UTC (1566313410)
[ 1.899635] vi 54080000.vi: vi_probe: ++
[ 1.901394] tegradc tegradc.1: DP: no prod_c_hbr prod settings node in device tree
[ 1.902512] vi 54080000.vi: initialized
[ 1.904500] vi 54080000.vi: subdev nvcsi–1 bound
[ 1.905943] Disable partitions left on by BL
[ 1.905945] disb
[ 1.905988] bwmgr: missing cdev-type property
[ 1.906080] tegra_soctherm 700e2000.soctherm: soctherm: trip temperature -2147483647 forced to -127000
[ 1.906086] DRAM derating cdev registered.
[ 1.907003] dp lt: state 4 (link training fail/disable), pending_lt_evt 1
[ 1.907005] dp lt: switching from state 4 (link training fail/disable) to state 0 (Reset)
[ 1.907008] dp lt: state 0 (Reset), pending_lt_evt 0
[ 1.907099] vdd-fan: disabling
[ 1.907102] vdd-usb-vbus: disabling
[ 1.907104] vdd-usb-vbus2: disabling
[ 1.907212] ALSA device list:
[ 1.907214] #0: tegra-hda at 0x70038000 irq 83
[ 1.907216] #1: tegra-snd-t210ref-mobile-rt565x
[ 1.908212] tegradc tegradc.1: DP: no prod_c_hbr prod settings node in device tree
[ 1.908352] dp lt: switching from state 0 (Reset) to state 2 (clock recovery)
[ 1.908355] dp lt: state 2 (clock recovery), pending_lt_evt 0
[ 1.908588] dp lt: config: lane 0: vs level: 0, pe level: 0, pc2 level: 0
[ 1.908596] dp lt: config: lane 1: vs level: 0, pe level: 0, pc2 level: 0
[ 1.908603] dp lt: config: lane 2: vs level: 0, pe level: 0, pc2 level: 0
[ 1.908611] dp lt: config: lane 3: vs level: 0, pe level: 0, pc2 level: 0
[ 1.908616] dp lt: tx_pu: 0x20
[ 1.909516] dp lt: CR done
[ 1.909518] dp lt: switching from state 2 (clock recovery) to state 3 (channel equalization)
[ 1.909521] dp lt: state 3 (channel equalization), pending_lt_evt 0
[ 1.911888] dp lt: CE done
[ 1.911890] dp lt: switching from state 3 (channel equalization) to state 5 (link training pass)
[ 1.911922] extcon-disp-state extcon:disp-state: cable 46 state 1
[ 1.911923] Extcon AUX0(DP): enable
[ 1.911924] dp_audio switch 1
[ 1.912188] tegradc tegradc.1: sync windows ret = 250
[ 1.912279] extcon-disp-state extcon:disp-state: cable 44 state 1
[ 1.912281] Extcon DP: HPD enabled
[ 1.912294] hpd: Display connected, hpd_switch 1
[ 1.912297] hpd: switching from state 2 (Check EDID) to state 4 (Enabled)
[ 1.913520] tegra-pcie 1003000.pcie: link 0 down, retrying
[ 1.913531] usb 1-2: new high-speed USB device number 2 using tegra-xusb
[ 1.915531] Freeing unused kernel memory: 8576K
[ 1.934152] L4T-INITRD Build DATE: Tue Aug 20 15:03:30 UTC 2019
[ 1.938746] Root device found: mmcblk0p1
[ 1.949113] usb 1-2: New USB device found, idVendor=0bda, idProduct=5411
[ 1.949118] usb 1-2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 1.949121] usb 1-2: Product: 4-Port USB 2.1 Hub
[ 1.949124] usb 1-2: Manufacturer: Generic
[ 1.950566] hub 1-2:1.0: USB hub found
[ 1.952519] hub 1-2:1.0: 4 ports detected
[ 2.038137] mmc0: hw tuning done …
[ 2.038182] mmc0: new ultra high speed SDR104 SDXC card at address 0001
[ 2.038491] mmcblk0: mmc0:0001 SD16G 58.3 GiB
[ 2.048783] mmcblk0: p1 p2 p3 p4 p5 p6 p7 p8 p9 p10 p11 p12
[ 2.143502] Found dev node: /dev/mmcblk0p1
[ 2.185836] EXT4-fs (mmcblk0p1): mounted filesystem with ordered data mode. Opts: (null)
[ 2.186639] Rootfs mounted over mmcblk0p1
[ 2.212705] Switching from initrd to actual rootfs
[ 2.241572] usb 1-2.1: new high-speed USB device number 3 using tegra-xusb
[ 2.280329] usb 1-2.1: New USB device found, idVendor=148f, idProduct=5370
[ 2.280333] usb 1-2.1: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 2.280337] usb 1-2.1: Product: 802.11 n WLAN
[ 2.280339] usb 1-2.1: Manufacturer: Ralink
[ 2.280342] usb 1-2.1: SerialNumber: 1.0
[ 2.324096] tegra-pcie 1003000.pcie: link 0 down, retrying
[ 2.361557] usb 1-2.3: new low-speed USB device number 4 using tegra-xusb
[ 2.388488] usb 1-2.3: New USB device found, idVendor=413c, idProduct=2003
[ 2.388492] usb 1-2.3: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 2.388495] usb 1-2.3: Product: Dell USB Keyboard
[ 2.388498] usb 1-2.3: Manufacturer: Dell
[ 2.393482] input: Dell Dell USB Keyboard as /devices/70090000.xusb/usb1/1-2/1-2.3/1-2.3:1.0/0003:413C:2003.0001/input/input2
[ 2.453998] hid-generic 0003:413C:2003.0001: input,hidraw0: USB HID v1.10 Keyboard [Dell Dell USB Keyboard] on usb-70090000.xusb-2.3/input0
[ 2.496167] ip_tables: © 2000-2006 Netfilter Core Team
[ 2.508563] cgroup: cgroup2: unknown option “nsdelegate”
[ 2.533559] usb 1-2.4: new low-speed USB device number 5 using tegra-xusb
[ 2.535589] systemd[1]: systemd 237 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD -IDN2 +IDN -PCRE2 default-hierarchy=hybrid)
[ 2.536328] systemd[1]: Detected architecture arm64.
[ 2.558527] usb 1-2.4: New USB device found, idVendor=046d, idProduct=c05a
[ 2.558532] usb 1-2.4: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 2.558536] usb 1-2.4: Product: USB Optical Mouse
[ 2.558539] usb 1-2.4: Manufacturer: Logitech
[ 2.562068] input: Logitech USB Optical Mouse as /devices/70090000.xusb/usb1/1-2/1-2.4/1-2.4:1.0/0003:046D:C05A.0002/input/input3
[ 2.562487] hid-generic 0003:046D:C05A.0002: input,hidraw1: USB HID v1.11 Mouse [Logitech USB Optical Mouse] on usb-70090000.xusb-2.4/input0
[ 2.562865] systemd[1]: Set hostname to .
[ 2.669103] systemd[1]: File /lib/systemd/system/systemd-journald.service:36 configures an IP firewall (IPAddressDeny=any), but the local system does not support BPF/cgroup based firewalling.
[ 2.669113] systemd[1]: Proceeding WITHOUT firewalling in effect! (This warning is only shown for the first loaded unit using IP firewalling.)
[ 2.735916] tegra-pcie 1003000.pcie: link 0 down, retrying
[ 2.737979] tegra-pcie 1003000.pcie: link 0 down, ignoring
[ 2.842434] tegra-pcie 1003000.pcie: PCI host bridge to bus 0000:00
[ 2.842439] pci_bus 0000:00: root bus resource [io 0x0000-0xffff]
[ 2.842442] pci_bus 0000:00: root bus resource [mem 0x13000000-0x1fffffff]
[ 2.842445] pci_bus 0000:00: root bus resource [mem 0x20000000-0x3fffffff pref]
[ 2.842448] pci_bus 0000:00: root bus resource [bus 00-ff]
[ 2.842468] pci 0000:00:02.0: [10de:0faf] type 01 class 0x060400
[ 2.842524] pci 0000:00:02.0: PME# supported from D0 D1 D2 D3hot D3cold
[ 2.842659] pci 0000:00:02.0: bridge configuration invalid ([bus 00-00]), reconfiguring
[ 2.842762] pci 0000:01:00.0: [10ec:8168] type 00 class 0x020000
[ 2.842786] pci 0000:01:00.0: reg 0x10: [io 0x0000-0x00ff]
[ 2.842815] pci 0000:01:00.0: reg 0x18: [mem 0x00000000-0x00000fff 64bit]
[ 2.842835] pci 0000:01:00.0: reg 0x20: [mem 0x00000000-0x00003fff 64bit]
[ 2.842965] pci 0000:01:00.0: supports D1 D2
[ 2.842968] pci 0000:01:00.0: PME# supported from D0 D1 D2 D3hot D3cold
[ 2.853647] pci_bus 0000:01: busn_res: [bus 01-ff] end is updated to 01
[ 2.853672] pci 0000:00:02.0: BAR 14: assigned [mem 0x13000000-0x130fffff]
[ 2.853676] pci 0000:00:02.0: BAR 13: assigned [io 0x1000-0x1fff]
[ 2.853681] pci 0000:01:00.0: BAR 4: assigned [mem 0x13000000-0x13003fff 64bit]
[ 2.853698] pci 0000:01:00.0: BAR 2: assigned [mem 0x13004000-0x13004fff 64bit]
[ 2.853713] pci 0000:01:00.0: BAR 0: assigned [io 0x1000-0x10ff]
[ 2.853720] pci 0000:00:02.0: PCI bridge to [bus 01]
[ 2.853723] pci 0000:00:02.0: bridge window [io 0x1000-0x1fff]
[ 2.853727] pci 0000:00:02.0: bridge window [mem 0x13000000-0x130fffff]
[ 2.853963] pcieport 0000:00:02.0: Signaling PME through PCIe PME interrupt
[ 2.853966] pci 0000:01:00.0: Signaling PME through PCIe PME interrupt
[ 2.853971] pcie_pme 0000:00:02.0:pcie001: service driver pcie_pme loaded
[ 2.854054] aer 0000:00:02.0:pcie002: service driver aer loaded
[ 2.854214] r8168 0000:01:00.0: enabling device (0000 -> 0003)
[ 2.854230] r8168 Gigabit Ethernet driver 8.045.08-NAPI loaded
[ 2.856973] random: systemd: uninitialized urandom read (16 bytes read)
[ 2.857005] systemd[1]: Reached target User and Group Name Lookups.
[ 2.857371] random: systemd: uninitialized urandom read (16 bytes read)
[ 2.859275] systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point.
[ 2.859311] random: systemd: uninitialized urandom read (16 bytes read)
[ 2.859333] systemd[1]: Reached target Swap.
[ 2.859479] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[ 2.860797] systemd[1]: Created slice User and Session Slice.
[ 2.868812] r8168: This product is covered by one or more of the following patents: US6,570,884, US6,115,776, and US6,327,625.
[ 2.868832] r8168 Copyright © 2017 Realtek NIC software team nicfae@realtek.com
This program comes with ABSOLUTELY NO WARRANTY; for details, please see http://www.gnu.org/licenses/.
This is free software, and you are welcome to redistribute it under certain conditions; see http://www.gnu.org/licenses/.
[ 2.975743] EXT4-fs (mmcblk0p1): re-mounted. Opts: (null)
[ 3.251075] systemd-journald[2001]: Received request to flush runtime journal from PID 1
[ 4.547189] random: crng init done
[ 4.547196] random: 7 urandom warning(s) missed due to ratelimiting
[ 4.814287] nvgpu: 57000000.gpu gm20b_init_clk_setup_sw:1268 [INFO] GPCPLL initial settings: NA mode, M=1, N=34, P=3 (id = 1)
[ 5.500681] using random self ethernet address
[ 5.505181] using random host ethernet address
[ 5.521146] Mass Storage Function, version: 2009/09/11
[ 5.521152] LUN: removable file: (no medium)
[ 5.526061] using random self ethernet address
[ 5.530583] using random host ethernet address
[ 5.599350] rndis0: HOST MAC 2a:5c:9a:d0:90:18
[ 5.599519] rndis0: MAC 2a:5c:9a:d0:90:19
[ 5.600441] usb0: HOST MAC 2a:5c:9a:d0:90:1a
[ 5.600469] usb0: MAC 2a:5c:9a:d0:90:1b
[ 5.600498] tegra-xudc-new 700d0000.xudc: ep 0 (type: 0, dir: out) enabled
[ 5.605171] l4tbr0: port 1(rndis0) entered blocking state
[ 5.605177] l4tbr0: port 1(rndis0) entered disabled state
[ 5.606192] device rndis0 entered promiscuous mode
[ 5.613994] IPv6: ADDRCONF(NETDEV_UP): rndis0: link is not ready
[ 5.618889] l4tbr0: port 2(usb0) entered blocking state
[ 5.618894] l4tbr0: port 2(usb0) entered disabled state
[ 5.619294] device usb0 entered promiscuous mode
[ 5.625908] IPv6: ADDRCONF(NETDEV_UP): usb0: link is not ready
[ 5.750835] tegra-xusb 70090000.xusb: Upgrade port 0 to USB3.0
[ 5.750841] tegra-xusb 70090000.xusb: Upgrade port 1 to USB3.0
[ 6.078635] usb 2-1: new SuperSpeed USB device number 2 using tegra-xusb
[ 6.117025] usb 2-1: New USB device found, idVendor=0bda, idProduct=0411
[ 6.117031] usb 2-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 6.117035] usb 2-1: Product: 4-Port USB 3.1 Hub
[ 6.117038] usb 2-1: Manufacturer: Generic
[ 6.122882] hub 2-1:1.0: USB hub found
[ 6.124458] hub 2-1:1.0: 4 ports detected
[ 6.281547] usb 2-1: usb_suspend_both: status 0
[ 6.281723] usb usb2: usb_suspend_both: status 0
[ 6.896899] usb 1-2.1: reset high-speed USB device number 3 using tegra-xusb
[ 6.998759] ieee80211 phy0: rt2x00_set_rt: Info - RT chipset 5390, rev 0502 detected
[ 7.048450] ieee80211 phy0: rt2x00_set_rf: Info - RF chipset 5370 detected
[ 7.064697] ieee80211 phy0: Selected rate control algorithm ‘minstrel_ht’
[ 7.067632] usbcore: registered new interface driver rt2800usb
[ 7.135483] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 7.136586] eth0: 0xffffff800d4c6000, 00:e0:4c:68:02:c4, IRQ 405
[ 7.186907] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 7.302272] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
[ 7.302424] ieee80211 phy0: rt2x00lib_request_firmware: Info - Loading firmware file ‘rt2870.bin’
[ 7.366317] ieee80211 phy0: rt2x00lib_request_firmware: Info - Firmware detected - version: 0.36
[ 7.413914] zram: Added device: zram0
[ 7.414503] zram: Added device: zram1
[ 7.415308] zram: Added device: zram2
[ 7.416141] zram: Added device: zram3
[ 7.446197] zram0: detected capacity change from 0 to 519585792
[ 7.588309] Adding 507404k swap on /dev/zram0. Priority:5 extents:1 across:507404k SS
[ 7.593851] zram1: detected capacity change from 0 to 519585792
[ 7.606790] Adding 507404k swap on /dev/zram1. Priority:5 extents:1 across:507404k SS
[ 7.611944] zram2: detected capacity change from 0 to 519585792
[ 7.627498] Adding 507404k swap on /dev/zram2. Priority:5 extents:1 across:507404k SS
[ 7.632553] zram3: detected capacity change from 0 to 519585792
[ 7.642935] Adding 507404k swap on /dev/zram3. Priority:5 extents:1 across:507404k SS
[ 7.651390] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
[ 7.719982] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
[ 9.398538] tegradc tegradc.1: unblank
[ 9.398547] tegradc tegradc.0: blank - powerdown
[ 12.541531] wlan0: authenticate with fa:38:80:63:55:69
[ 12.566399] wlan0: send auth to fa:38:80:63:55:69 (try 1/3)
[ 12.568356] wlan0: authenticated
[ 12.569549] wlan0: associate with fa:38:80:63:55:69 (try 1/3)
[ 12.575947] wlan0: RX AssocResp from fa:38:80:63:55:69 (capab=0x431 status=0 aid=2)
[ 12.581050] wlan0: associated
[ 12.601660] IPv6: ADDRCONF(NETDEV_CHANGE): wlan0: link becomes ready
[ 12.760147] wlan0: Limiting TX power to 30 (30 - 0) dBm as advertised by fa:38:80:63:55:69
[ 13.057841] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[ 13.057853] Bluetooth: BNEP socket layer initialized
[ 13.296791] fuse init (API version 7.26)
[ 14.748744] tegradc tegradc.1: unblank
[ 14.748754] tegradc tegradc.0: blank - powerdown
- I’m not sure how to get a non-truncated version of this log - can you point me in the right direction?
