Hi, Linuxdev, it is a DVI monitor, an HDMI to DVI cable is used to connect the DX1 HDMI output to the monitor. 100% repeatable, I tried two different sets of minotor+cable, they both work perfectly for TK1 board, but TX1 doesn’t work (most likely the OS doesn’t boot because no IP address has been allocated ever, so no SSH operation possible).
If I plug the HDMI cable after the system is boot, or say after I see the TX1 IP address become available, I see the monitor blinking between a blue background, with the correct date and time info shown in the upper right corner.
root@tegra-ubuntu:~# cat find /sys -name edid
00 ff ff ff ff ff ff 00 10 ac 15 40 34 43 43 41
10 10 01 03 80 26 1e 78 ee de 95 a3 54 4c 99 26
0f 50 54 a5 4b 00 71 4f 81 80 01 01 01 01 01 01
01 01 01 01 01 01 30 2a 00 98 51 00 2a 40 30 70
13 00 78 2d 11 00 00 1e 00 00 00 ff 00 44 43 33
32 33 36 34 49 41 43 43 34 0a 00 00 00 fc 00 44
45 4c 4c 20 31 39 30 37 46 50 0a 20 00 00 00 fd
00 38 4c 1e 51 0e 00 0a 20 20 20 20 20 20 00 27
root@tegra-ubuntu:~# ls /sys/kernel/debug/tegradc.0/edid -l
-r–r--r-- 1 root root 0 Jan 1 1970 /sys/kernel/debug/tegradc.0/edid
Hi, WayneWWW, the dmesg output is attached here, sorry for the lengthy content, I didn’t know what to grep :-)
ubuntu@tegra-ubuntu:~$ dmesg
[ 82.202474] CPU: 0 PID: 2432 Comm: compiz Not tainted 4.4.38-tegra #1
[ 82.209015] Hardware name: jetson_tx1 (DT)
[ 82.213150] task: ffffffc0f4a3e400 ti: ffffffc0e5bd8000 task.ti: ffffffc0e5bd8000
[ 82.220665] PC is at 0x7f820cc6e4
[ 82.224025] LR is at 0x7f820cc678
[ 82.227339] pc : [<0000007f820cc6e4>] lr : [<0000007f820cc678>] pstate: 00000000
[ 82.234825] sp : 0000007fcfc47f60
[ 82.238174] x29: 0000007fcfc47f60 x28: 0000000000000000
[ 82.243514] x27: 0000007f81b6f6c0 x26: 0000007f81b65000
[ 82.248883] x25: 0000007f819bcb28 x24: 0000000000000000
[ 82.254248] x23: 0000007fcfc47fa0 x22: 0000000000000000
[ 82.259613] x21: 0000007fcfc48060 x20: 0000007f8215d000
[ 82.265003] x19: 0000000000000000 x18: 0000000000000014
[ 82.270362] x17: 0000007f820cc630 x16: 0000007f81b68778
[ 82.275731] x15: 00000000000001db x14: 5f6c656e61705f74
[ 82.281099] x13: 6e6569646172675f x12: 656e696665722f73
[ 82.286467] x11: 6e6f63692f797469 x10: 6e752f6572616873
[ 82.291866] x9 : 0000000000f9ff90 x8 : 0000007fcfc47fa0
[ 82.297231] x7 : 0000000000000000 x6 : 0000000000000000
[ 82.302588] x5 : 0000007f94a1b9b0 x4 : 00000000ffffffff
[ 82.307955] x3 : 0000000000000001 x2 : 267cc88e2a57da00
[ 82.313316] x1 : 0000000000000000 x0 : 0000000000000000
[ 82.320230] Library at 0x7f820cc6e4: 0x7f82080000 /usr/lib/aarch64-linux-gnu/libnux-graphics-4.0.so.0.8.0
[ 82.329857] Library at 0x7f820cc678: 0x7f82080000 /usr/lib/aarch64-linux-gnu/libnux-graphics-4.0.so.0.8.0
[ 82.339458] vdso base = 0x7f94cf0000
[ 83.431554] compiz[2446]: unhandled level 2 translation fault (11) at 0x000000e0, esr 0x92000006
[ 83.440343] pgd = ffffffc0e81b3000
[ 83.443802] [000000e0] *pgd=0000000171d64003, *pud=0000000171d64003, *pmd=0000000000000000
[ 83.453604] CPU: 0 PID: 2446 Comm: compiz Not tainted 4.4.38-tegra #1
[ 83.460043] Hardware name: jetson_tx1 (DT)
[ 83.464141] task: ffffffc0f4a3e400 ti: ffffffc04361c000 task.ti: ffffffc04361c000
[ 83.471616] PC is at 0x7f8b9ec6e4
[ 83.474921] LR is at 0x7f8b9ec678
[ 83.478276] pc : [<0000007f8b9ec6e4>] lr : [<0000007f8b9ec678>] pstate: 00000000
[ 83.485673] sp : 0000007fe91234f0
[ 83.488986] x29: 0000007fe91234f0 x28: 0000000000000000
[ 83.494310] x27: 0000007f8b48f6c0 x26: 0000007f8b485000
[ 83.499639] x25: 0000007f8b2dcb28 x24: 0000000000000000
[ 83.504962] x23: 0000007fe9123530 x22: 0000000000000000
[ 83.510314] x21: 0000007fe91235f0 x20: 0000007f8ba7d000
[ 83.515641] x19: 0000000000000000 x18: 0000000000000014
[ 83.520961] x17: 0000007f8b9ec630 x16: 0000007f8b488778
[ 83.526285] x15: 00000000000001db x14: 5f6c656e61705f74
[ 83.531612] x13: 6e6569646172675f x12: 656e696665722f73
[ 83.536931] x11: 6e6f63692f797469 x10: 6e752f6572616873
[ 83.542281] x9 : 0000000000fc5ed0 x8 : 0000007fe9123530
[ 83.547617] x7 : 0000000000000000 x6 : 0000000000000000
[ 83.552937] x5 : 0000007f9a33a9b0 x4 : 00000000ffffffff
[ 83.558258] x3 : 0000000000000001 x2 : 52618a2229456a00
[ 83.563587] x1 : 0000000000000000 x0 : 0000000000000000
[ 83.570398] Library at 0x7f8b9ec6e4: 0x7f8b9a0000 /usr/lib/aarch64-linux-gnu/libnux-graphics-4.0.so.0.8.0
[ 83.579980] Library at 0x7f8b9ec678: 0x7f8b9a0000 /usr/lib/aarch64-linux-gnu/libnux-graphics-4.0.so.0.8.0
[ 83.589535] vdso base = 0x7f9a60f000
[ 84.687138] compiz[2460]: unhandled level 2 translation fault (11) at 0x000000e0, esr 0x92000006
[ 84.695928] pgd = ffffffc03ab92000
[ 84.699319] [000000e0] *pgd=00000000c0c42003, *pud=00000000c0c42003, *pmd=0000000000000000
[ 84.709112] CPU: 1 PID: 2460 Comm: compiz Not tainted 4.4.38-tegra #1
[ 84.715549] Hardware name: jetson_tx1 (DT)
[ 84.719670] task: ffffffc0f4a3e400 ti: ffffffc0e8318000 task.ti: ffffffc0e8318000
[ 84.727151] PC is at 0x7f958a86e4
[ 84.730465] LR is at 0x7f958a8678
[ 84.733778] pc : [<0000007f958a86e4>] lr : [<0000007f958a8678>] pstate: 00000000
[ 84.741162] sp : 0000007feb528a60
[ 84.744478] x29: 0000007feb528a60 x28: 0000000000000000
[ 84.749819] x27: 0000007f9534b6c0 x26: 0000007f95341000
[ 84.755142] x25: 0000007f95198b28 x24: 0000000000000000
[ 84.760468] x23: 0000007feb528aa0 x22: 0000000000000000
[ 84.765791] x21: 0000007feb528b60 x20: 0000007f95939000
[ 84.771113] x19: 0000000000000000 x18: 0000000000000014
[ 84.776439] x17: 0000007f958a8630 x16: 0000007f95344778
[ 84.781760] x15: 00000000000001db x14: 5f6c656e61705f74
[ 84.787085] x13: 6e6569646172675f x12: 656e696665722f73
[ 84.792413] x11: 6e6f63692f797469 x10: 6e752f6572616873
[ 84.797734] x9 : 0000000000fc5880 x8 : 0000007feb528aa0
[ 84.803055] x7 : 0000000000000000 x6 : 0000000000000000
[ 84.808439] x5 : 0000007fa81e59b0 x4 : 00000000ffffffff
[ 84.813777] x3 : 0000000000000001 x2 : 490fd40fcec15500
[ 84.819100] x1 : 0000000000000000 x0 : 0000000000000000
[ 84.825916] Library at 0x7f958a86e4: 0x7f9585c000 /usr/lib/aarch64-linux-gnu/libnux-graphics-4.0.so.0.8.0
[ 84.835471] Library at 0x7f958a8678: 0x7f9585c000 /usr/lib/aarch64-linux-gnu/libnux-graphics-4.0.so.0.8.0
[ 84.845027] vdso base = 0x7fa84ba000
[ 85.935959] compiz[2473]: unhandled level 2 translation fault (11) at 0x000000e0, esr 0x92000006
[ 85.944800] pgd = ffffffc0de006000
[ 85.948336] [000000e0] *pgd=00000001639be003, *pud=00000001639be003, *pmd=0000000000000000
[ 85.958147] CPU: 0 PID: 2473 Comm: compiz Not tainted 4.4.38-tegra #1
[ 85.964682] Hardware name: jetson_tx1 (DT)
[ 85.968820] task: ffffffc0f4a3e400 ti: ffffffc043730000 task.ti: ffffffc043730000
[ 85.976374] PC is at 0x7f9cbf66e4
[ 85.979724] LR is at 0x7f9cbf6678
[ 85.983031] pc : [<0000007f9cbf66e4>] lr : [<0000007f9cbf6678>] pstate: 00000000
[ 85.990486] sp : 0000007fd5e6a530
[ 85.993838] x29: 0000007fd5e6a530 x28: 0000000000000000
[ 85.999174] x27: 0000007f9c6996c0 x26: 0000007f9c68f000
[ 86.004574] x25: 0000007f9c4e6b28 x24: 0000000000000000
[ 86.009937] x23: 0000007fd5e6a570 x22: 0000000000000000
[ 86.015298] x21: 0000007fd5e6a630 x20: 0000007f9cc87000
[ 86.020667] x19: 0000000000000000 x18: 0000000000000014
[ 86.026023] x17: 0000007f9cbf6630 x16: 0000007f9c692778
[ 86.031383] x15: 00000000000001db x14: 5f6c656e61705f74
[ 86.036784] x13: 6e6569646172675f x12: 656e696665722f73
[ 86.042141] x11: 6e6f63692f797469 x10: 6e752f6572616873
[ 86.047513] x9 : 0000000000fc1fd0 x8 : 0000007fd5e6a570
[ 86.052872] x7 : 0000000000000000 x6 : 0000000000000000
[ 86.058233] x5 : 0000007fa5b939b0 x4 : 00000000ffffffff
[ 86.063600] x3 : 0000000000000001 x2 : 48a3132f9d98aa00
[ 86.068994] x1 : 0000000000000000 x0 : 0000000000000000
[ 86.075907] Library at 0x7f9cbf66e4: 0x7f9cbaa000 /usr/lib/aarch64-linux-gnu/libnux-graphics-4.0.so.0.8.0
[ 86.085502] Library at 0x7f9cbf6678: 0x7f9cbaa000 /usr/lib/aarch64-linux-gnu/libnux-graphics-4.0.so.0.8.0
[ 86.095092] vdso base = 0x7fa5e68000
[ 87.222628] compiz[2487]: unhandled level 2 translation fault (11) at 0x000000e0, esr 0x92000006
[ 87.231431] pgd = ffffffc07ac8e000
[ 87.234823] [000000e0] *pgd=00000000fac8f003, *pud=00000000fac8f003, *pmd=0000000000000000
[ 87.244737] CPU: 1 PID: 2487 Comm: compiz Not tainted 4.4.38-tegra #1
[ 87.251194] Hardware name: jetson_tx1 (DT)
[ 87.255315] task: ffffffc0de2ed780 ti: ffffffc0de2b0000 task.ti: ffffffc0de2b0000
[ 87.262810] PC is at 0x7f88b1f6e4
[ 87.266159] LR is at 0x7f88b1f678
[ 87.269493] pc : [<0000007f88b1f6e4>] lr : [<0000007f88b1f678>] pstate: 00000000
[ 87.276903] sp : 0000007ffdc6fc20
[ 87.280235] x29: 0000007ffdc6fc20 x28: 0000000000000000
[ 87.285564] x27: 0000007f83ffe6c0 x26: 0000007f83ff4000
[ 87.290904] x25: 0000007f83e4bb28 x24: 0000000000000000
[ 87.296257] x23: 0000007ffdc6fc60 x22: 0000000000000000
[ 87.301599] x21: 0000007ffdc6fd20 x20: 0000007f88bb0000
[ 87.306939] x19: 0000000000000000 x18: 0000000000000014
[ 87.312289] x17: 0000007f88b1f630 x16: 0000007f83ff7778
[ 87.317633] x15: 00000000000001db x14: 5f6c656e61705f74
[ 87.322976] x13: 6e6569646172675f x12: 656e696665722f73
[ 87.328334] x11: 6e6f63692f797469 x10: 6e752f6572616873
[ 87.333674] x9 : 0000000000fbcaf0 x8 : 0000007ffdc6fc60
[ 87.339018] x7 : 0000000000000000 x6 : 0000000000000000
[ 87.344371] x5 : 0000007f934619b0 x4 : 00000000ffffffff
[ 87.349710] x3 : 0000000000000001 x2 : 69ad6bdffd991500
[ 87.355050] x1 : 0000000000000000 x0 : 0000000000000000
[ 87.361888] Library at 0x7f88b1f6e4: 0x7f88ad3000 /usr/lib/aarch64-linux-gnu/libnux-graphics-4.0.so.0.8.0
[ 87.371473] Library at 0x7f88b1f678: 0x7f88ad3000 /usr/lib/aarch64-linux-gnu/libnux-graphics-4.0.so.0.8.0
[ 87.381051] vdso base = 0x7f93736000
[ 88.512185] compiz[2500]: unhandled level 2 translation fault (11) at 0x000000e0, esr 0x92000006
[ 88.520974] pgd = ffffffc04357d000
[ 88.524384] [000000e0] *pgd=00000000ba173003, *pud=00000000ba173003, *pmd=0000000000000000
[ 88.534203] CPU: 1 PID: 2500 Comm: compiz Not tainted 4.4.38-tegra #1
[ 88.540638] Hardware name: jetson_tx1 (DT)
[ 88.544734] task: ffffffc0de2ed780 ti: ffffffc043748000 task.ti: ffffffc043748000
[ 88.552214] PC is at 0x7fa94c66e4
[ 88.555529] LR is at 0x7fa94c6678
[ 88.558834] pc : [<0000007fa94c66e4>] lr : [<0000007fa94c6678>] pstate: 00000000
[ 88.566219] sp : 0000007fe7dfa300
[ 88.569531] x29: 0000007fe7dfa300 x28: 0000000000000000
[ 88.574856] x27: 0000007fa8f696c0 x26: 0000007fa8f5f000
[ 88.580182] x25: 0000007fa8db6b28 x24: 0000000000000000
[ 88.585514] x23: 0000007fe7dfa340 x22: 0000000000000000
[ 88.590833] x21: 0000007fe7dfa400 x20: 0000007fa9557000
[ 88.596163] x19: 0000000000000000 x18: 0000000000000014
[ 88.601483] x17: 0000007fa94c6630 x16: 0000007fa8f62778
[ 88.606802] x15: 00000000000001db x14: 5f6c656e61705f74
[ 88.612131] x13: 6e6569646172675f x12: 656e696665722f73
[ 88.617452] x11: 6e6f63692f797469 x10: 6e752f6572616873
[ 88.622771] x9 : 0000000000fab980 x8 : 0000007fe7dfa340
[ 88.628098] x7 : 0000000000000000 x6 : 0000000000000000
[ 88.633420] x5 : 0000007fb3e049b0 x4 : 00000000ffffffff
[ 88.638741] x3 : 0000000000000001 x2 : 0755f0e04828cc00
[ 88.644066] x1 : 0000000000000000 x0 : 0000000000000000
[ 88.650889] Library at 0x7fa94c66e4: 0x7fa947a000 /usr/lib/aarch64-linux-gnu/libnux-graphics-4.0.so.0.8.0
[ 88.660445] Library at 0x7fa94c6678: 0x7fa947a000 /usr/lib/aarch64-linux-gnu/libnux-graphics-4.0.so.0.8.0
[ 88.670002] vdso base = 0x7fb40d9000
[ 89.816242] compiz[2513]: unhandled level 2 translation fault (11) at 0x000000e0, esr 0x92000006
[ 89.825055] pgd = ffffffc0e38a4000
[ 89.828516] [000000e0] *pgd=000000015cc07003, *pud=000000015cc07003, *pmd=0000000000000000
[ 89.838336] CPU: 0 PID: 2513 Comm: compiz Not tainted 4.4.38-tegra #1
[ 89.844869] Hardware name: jetson_tx1 (DT)
[ 89.848989] task: ffffffc0de2ebe80 ti: ffffffc043728000 task.ti: ffffffc043728000
[ 89.856487] PC is at 0x7f705a06e4
[ 89.859822] LR is at 0x7f705a0678
[ 89.863127] pc : [<0000007f705a06e4>] lr : [<0000007f705a0678>] pstate: 00000000
[ 89.870543] sp : 0000007fc27c1f80
[ 89.873876] x29: 0000007fc27c1f80 x28: 0000000000000000
[ 89.879238] x27: 0000007f6bffe6c0 x26: 0000007f6bff4000
[ 89.884589] x25: 0000007f6be4bb28 x24: 0000000000000000
[ 89.889936] x23: 0000007fc27c1fc0 x22: 0000000000000000
[ 89.895279] x21: 0000007fc27c2080 x20: 0000007f70631000
[ 89.900629] x19: 0000000000000000 x18: 0000000000000014
[ 89.905979] x17: 0000007f705a0630 x16: 0000007f6bff7778
[ 89.911358] x15: 00000000000001db x14: 5f6c656e61705f74
[ 89.916706] x13: 6e6569646172675f x12: 656e696665722f73
[ 89.922047] x11: 6e6f63692f797469 x10: 6e752f6572616873
[ 89.927390] x9 : 0000000000fa9260 x8 : 0000007fc27c1fc0
[ 89.932743] x7 : 0000000000000000 x6 : 0000000000000000
[ 89.938086] x5 : 0000007f7aee79b0 x4 : 00000000ffffffff
[ 89.943466] x3 : 0000000000000001 x2 : 6ff5f198b5dcc300
[ 89.948814] x1 : 0000000000000000 x0 : 0000000000000000
[ 89.955678] Library at 0x7f705a06e4: 0x7f70554000 /usr/lib/aarch64-linux-gnu/libnux-graphics-4.0.so.0.8.0
[ 89.965261] Library at 0x7f705a0678: 0x7f70554000 /usr/lib/aarch64-linux-gnu/libnux-graphics-4.0.so.0.8.0
[ 89.974870] vdso base = 0x7f7b1bc000
[ 91.095295] compiz[2526]: unhandled level 2 translation fault (11) at 0x000000e0, esr 0x92000006
[ 91.104091] pgd = ffffffc0dc40b000
[ 91.107624] [000000e0] *pgd=000000015c409003, *pud=000000015c409003, *pmd=0000000000000000
[ 91.117412] CPU: 3 PID: 2526 Comm: compiz Not tainted 4.4.38-tegra #1
[ 91.123982] Hardware name: jetson_tx1 (DT)
[ 91.128118] task: ffffffc0de2ebe80 ti: ffffffc043750000 task.ti: ffffffc043750000
[ 91.135633] PC is at 0x7f7837a6e4
[ 91.138938] LR is at 0x7f7837a678
[ 91.142320] pc : [<0000007f7837a6e4>] lr : [<0000007f7837a678>] pstate: 00000000
[ 91.149747] sp : 0000007fde8e1550
[ 91.153096] x29: 0000007fde8e1550 x28: 0000000000000000
[ 91.158425] x27: 0000007f7245d6c0 x26: 0000007f72453000
[ 91.163791] x25: 0000007f722aab28 x24: 0000000000000000
[ 91.169154] x23: 0000007fde8e1590 x22: 0000000000000000
[ 91.174510] x21: 0000007fde8e1650 x20: 0000007f7840b000
[ 91.179877] x19: 0000000000000000 x18: 0000000000000014
[ 91.185234] x17: 0000007f7837a630 x16: 0000007f72456778
[ 91.190600] x15: 00000000000001db x14: 5f6c656e61705f74
[ 91.195966] x13: 6e6569646172675f x12: 656e696665722f73
[ 91.201330] x11: 6e6f63692f797469 x10: 6e752f6572616873
[ 91.206691] x9 : 0000000000fbefb0 x8 : 0000007fde8e1590
[ 91.212060] x7 : 0000000000000000 x6 : 0000000000000000
[ 91.217418] x5 : 0000007f8130a9b0 x4 : 00000000ffffffff
[ 91.222773] x3 : 0000000000000001 x2 : c527951f8de4bb00
[ 91.228142] x1 : 0000000000000000 x0 : 0000000000000000
[ 91.234986] Library at 0x7f7837a6e4: 0x7f7832e000 /usr/lib/aarch64-linux-gnu/libnux-graphics-4.0.so.0.8.0
[ 91.244628] Library at 0x7f7837a678: 0x7f7832e000 /usr/lib/aarch64-linux-gnu/libnux-graphics-4.0.so.0.8.0
[ 91.254226] vdso base = 0x7f815df000
[ 92.376501] compiz[2540]: unhandled level 2 translation fault (11) at 0x000000e0, esr 0x92000006
[ 92.385299] pgd = ffffffc0e826e000
[ 92.388704] [000000e0] *pgd=0000000168036003, *pud=0000000168036003, *pmd=0000000000000000
[ 92.398482] CPU: 1 PID: 2540 Comm: compiz Not tainted 4.4.38-tegra #1
[ 92.404942] Hardware name: jetson_tx1 (DT)
[ 92.409039] task: ffffffc0de2ebe80 ti: ffffffc0e5a7c000 task.ti: ffffffc0e5a7c000
[ 92.416513] PC is at 0x7f8e15c6e4
[ 92.419826] LR is at 0x7f8e15c678
[ 92.423131] pc : [<0000007f8e15c6e4>] lr : [<0000007f8e15c678>] pstate: 00000000
[ 92.430519] sp : 0000007fecea41c0
[ 92.433832] x29: 0000007fecea41c0 x28: 0000000000000000
[ 92.439154] x27: 0000007f8dbff6c0 x26: 0000007f8dbf5000
[ 92.444482] x25: 0000007f8da4cb28 x24: 0000000000000000
[ 92.449806] x23: 0000007fecea4200 x22: 0000000000000000
[ 92.455126] x21: 0000007fecea42c0 x20: 0000007f8e1ed000
[ 92.460453] x19: 0000000000000000 x18: 0000000000000014
[ 92.465774] x17: 0000007f8e15c630 x16: 0000007f8dbf8778
[ 92.471169] x15: 00000000000001db x14: 5f6c656e61705f74
[ 92.476501] x13: 6e6569646172675f x12: 656e696665722f73
[ 92.481825] x11: 6e6f63692f797469 x10: 6e752f6572616873
[ 92.487147] x9 : 0000000000fdc770 x8 : 0000007fecea4200
[ 92.492478] x7 : 0000000000000000 x6 : 0000000000000000
[ 92.497798] x5 : 0000007fa0a9b9b0 x4 : 00000000ffffffff
[ 92.503119] x3 : 0000000000000001 x2 : a4ecad5fb37f0000
[ 92.508446] x1 : 0000000000000000 x0 : 0000000000000000
[ 92.515255] Library at 0x7f8e15c6e4: 0x7f8e110000 /usr/lib/aarch64-linux-gnu/libnux-graphics-4.0.so.0.8.0
[ 92.524809] Library at 0x7f8e15c678: 0x7f8e110000 /usr/lib/aarch64-linux-gnu/libnux-graphics-4.0.so.0.8.0
[ 92.534364] vdso base = 0x7fa0d70000
[ 93.730605] compiz[2554]: unhandled level 2 translation fault (11) at 0x000000e0, esr 0x92000006
[ 93.739402] pgd = ffffffc0de2a0000
[ 93.742807] [000000e0] *pgd=000000016597d003, *pud=000000016597d003, *pmd=0000000000000000
[ 93.752693] CPU: 0 PID: 2554 Comm: compiz Not tainted 4.4.38-tegra #1
[ 93.759133] Hardware name: jetson_tx1 (DT)
[ 93.763228] task: ffffffc0de2ebe80 ti: ffffffc040fd4000 task.ti: ffffffc040fd4000
[ 93.770703] PC is at 0x7f7c5786e4
[ 93.774015] LR is at 0x7f7c578678
[ 93.777331] pc : [<0000007f7c5786e4>] lr : [<0000007f7c578678>] pstate: 00000000
[ 93.784747] sp : 0000007fc4265b90
[ 93.788059] x29: 0000007fc4265b90 x28: 0000000000000000
[ 93.793379] x27: 0000007f77ffe6c0 x26: 0000007f77ff4000
[ 93.798703] x25: 0000007f77e4bb28 x24: 0000000000000000
[ 93.804030] x23: 0000007fc4265bd0 x22: 0000000000000000
[ 93.809369] x21: 0000007fc4265c90 x20: 0000007f7c609000
[ 93.814721] x19: 0000000000000000 x18: 0000000000000014
[ 93.820052] x17: 0000007f7c578630 x16: 0000007f77ff7778
[ 93.825389] x15: 00000000000001db x14: 5f6c656e61705f74
[ 93.830712] x13: 6e6569646172675f x12: 656e696665722f73
[ 93.836041] x11: 6e6f63692f797469 x10: 6e752f6572616873
[ 93.841362] x9 : 0000000000fb4660 x8 : 0000007fc4265bd0
[ 93.846711] x7 : 0000000000000000 x6 : 0000000000000000
[ 93.852039] x5 : 0000007f86ec49b0 x4 : 00000000ffffffff
[ 93.857364] x3 : 0000000000000001 x2 : 4b3a1b3fb2c81300
[ 93.862686] x1 : 0000000000000000 x0 : 0000000000000000
[ 93.869517] Library at 0x7f7c5786e4: 0x7f7c52c000 /usr/lib/aarch64-linux-gnu/libnux-graphics-4.0.so.0.8.0
[ 93.879102] Library at 0x7f7c578678: 0x7f7c52c000 /usr/lib/aarch64-linux-gnu/libnux-graphics-4.0.so.0.8.0
[ 93.888656] vdso base = 0x7f87199000
[ 95.019234] compiz[2568]: unhandled level 2 translation fault (11) at 0x000000e0, esr 0x92000006
[ 95.028097] pgd = ffffffc0ebad6000
[ 95.031566] [000000e0] *pgd=000000016bb6b003, *pud=000000016bb6b003, *pmd=0000000000000000
[ 95.041380] CPU: 0 PID: 2568 Comm: compiz Not tainted 4.4.38-tegra #1
[ 95.047856] Hardware name: jetson_tx1 (DT)
[ 95.051974] task: ffffffc0de253e80 ti: ffffffc03a24c000 task.ti: ffffffc03a24c000
[ 95.059475] PC is at 0x7f94d6f6e4
[ 95.062815] LR is at 0x7f94d6f678
[ 95.066177] pc : [<0000007f94d6f6e4>] lr : [<0000007f94d6f678>] pstate: 00000000
[ 95.073588] sp : 0000007ff0c5fa70
[ 95.076921] x29: 0000007ff0c5fa70 x28: 0000000000000000
[ 95.082249] x27: 0000007f948126c0 x26: 0000007f94808000
[ 95.087598] x25: 0000007f9465fb28 x24: 0000000000000000
[ 95.092974] x23: 0000007ff0c5fab0 x22: 0000000000000000
[ 95.098316] x21: 0000007ff0c5fb70 x20: 0000007f94e00000
[ 95.103665] x19: 0000000000000000 x18: 0000000000000014
[ 95.109006] x17: 0000007f94d6f630 x16: 0000007f9480b778
[ 95.114349] x15: 00000000000001db x14: 5f6c656e61705f74
[ 95.119698] x13: 6e6569646172675f x12: 656e696665722f73
[ 95.125083] x11: 6e6f63692f797469 x10: 6e752f6572616873
[ 95.130426] x9 : 0000000000fa8030 x8 : 0000007ff0c5fab0
[ 95.135778] x7 : 0000000000000000 x6 : 0000000000000000
[ 95.141119] x5 : 0000007f9dd009b0 x4 : 00000000ffffffff
[ 95.146458] x3 : 0000000000000001 x2 : d006d76527a5fd00
[ 95.151809] x1 : 0000000000000000 x0 : 0000000000000000
[ 95.158666] Library at 0x7f94d6f6e4: 0x7f94d23000 /usr/lib/aarch64-linux-gnu/libnux-graphics-4.0.so.0.8.0
[ 95.168252] Library at 0x7f94d6f678: 0x7f94d23000 /usr/lib/aarch64-linux-gnu/libnux-graphics-4.0.so.0.8.0
[ 95.177830] vdso base = 0x7f9dfd5000
[ 96.326643] compiz[2582]: unhandled level 2 translation fault (11) at 0x000000e0, esr 0x92000006
[ 96.335722] pgd = ffffffc0435ac000
[ 96.339118] [000000e0] *pgd=00000000ba172003, *pud=00000000ba172003, *pmd=0000000000000000
[ 96.349025] CPU: 3 PID: 2582 Comm: compiz Not tainted 4.4.38-tegra #1
[ 96.355563] Hardware name: jetson_tx1 (DT)
[ 96.359698] task: ffffffc0de253e80 ti: ffffffc0ebba0000 task.ti: ffffffc0ebba0000
[ 96.367216] PC is at 0x7facdea6e4
[ 96.370569] LR is at 0x7facdea678
[ 96.373922] pc : [<0000007facdea6e4>] lr : [<0000007facdea678>] pstate: 00000000
[ 96.381352] sp : 0000007fc60ddcd0
[ 96.384710] x29: 0000007fc60ddcd0 x28: 0000000000000000
[ 96.390042] x27: 0000007fac88d6c0 x26: 0000007fac883000
[ 96.395401] x25: 0000007fac6dab28 x24: 0000000000000000
[ 96.400774] x23: 0000007fc60ddd10 x22: 0000000000000000
[ 96.406132] x21: 0000007fc60dddd0 x20: 0000007face7b000
[ 96.411502] x19: 0000000000000000 x18: 0000000000000014
[ 96.416862] x17: 0000007facdea630 x16: 0000007fac886778
[ 96.422225] x15: 00000000000001db x14: 5f6c656e61705f74
[ 96.427591] x13: 6e6569646172675f x12: 656e696665722f73
[ 96.432948] x11: 6e6f63692f797469 x10: 6e752f6572616873
[ 96.438308] x9 : 0000000000fb0cb0 x8 : 0000007fc60ddd10
[ 96.443682] x7 : 0000000000000000 x6 : 0000000000000000
[ 96.449045] x5 : 0000007fb772c9b0 x4 : 00000000ffffffff
[ 96.454408] x3 : 0000000000000001 x2 : 32c2969432d9ea00
[ 96.459782] x1 : 0000000000000000 x0 : 0000000000000000
[ 96.466625] Library at 0x7facdea6e4: 0x7facd9e000 /usr/lib/aarch64-linux-gnu/libnux-graphics-4.0.so.0.8.0
[ 96.476268] Library at 0x7facdea678: 0x7facd9e000 /usr/lib/aarch64-linux-gnu/libnux-graphics-4.0.so.0.8.0
[ 96.485864] vdso base = 0x7fb7a01000
[ 97.623135] compiz[2596]: unhandled level 2 translation fault (11) at 0x000000e0, esr 0x92000006
[ 97.631958] pgd = ffffffc0e5832000
[ 97.635349] [000000e0] *pgd=0000000165835003, *pud=0000000165835003, *pmd=0000000000000000
[ 97.645179] CPU: 1 PID: 2596 Comm: compiz Not tainted 4.4.38-tegra #1
[ 97.651616] Hardware name: jetson_tx1 (DT)
[ 97.655713] task: ffffffc0de2eb200 ti: ffffffc0dc5b8000 task.ti: ffffffc0dc5b8000
[ 97.663187] PC is at 0x7f9bb1d6e4
[ 97.666501] LR is at 0x7f9bb1d678
[ 97.669815] pc : [<0000007f9bb1d6e4>] lr : [<0000007f9bb1d678>] pstate: 00000000
[ 97.677203] sp : 0000007fef1b5c00
[ 97.680515] x29: 0000007fef1b5c00 x28: 0000000000000000
[ 97.685836] x27: 0000007f9b5c06c0 x26: 0000007f9b5b6000
[ 97.691158] x25: 0000007f9b40db28 x24: 0000000000000000
[ 97.696488] x23: 0000007fef1b5c40 x22: 0000000000000000
[ 97.701810] x21: 0000007fef1b5d00 x20: 0000007f9bbae000
[ 97.707130] x19: 0000000000000000 x18: 0000000000000014
[ 97.712525] x17: 0000007f9bb1d630 x16: 0000007f9b5b9778
[ 97.717853] x15: 00000000000001db x14: 5f6c656e61705f74
[ 97.723174] x13: 6e6569646172675f x12: 656e696665722f73
[ 97.728502] x11: 6e6f63692f797469 x10: 6e752f6572616873
[ 97.733823] x9 : 0000000000faa840 x8 : 0000007fef1b5c40
[ 97.739146] x7 : 0000000000000000 x6 : 0000000000000000
[ 97.744473] x5 : 0000007faa4689b0 x4 : 00000000ffffffff
[ 97.749794] x3 : 0000000000000001 x2 : aacf24d65e972c00
[ 97.755115] x1 : 0000000000000000 x0 : 0000000000000000
[ 97.761938] Library at 0x7f9bb1d6e4: 0x7f9bad1000 /usr/lib/aarch64-linux-gnu/libnux-graphics-4.0.so.0.8.0
[ 97.771552] Library at 0x7f9bb1d678: 0x7f9bad1000 /usr/lib/aarch64-linux-gnu/libnux-graphics-4.0.so.0.8.0
[ 97.781113] vdso base = 0x7faa73d000
[ 98.924229] compiz[2609]: unhandled level 2 translation fault (11) at 0x000000e0, esr 0x92000006
[ 98.933021] pgd = ffffffc072496000
[ 98.936433] [000000e0] *pgd=00000000f3993003, *pud=00000000f3993003, *pmd=0000000000000000
[ 98.946233] CPU: 1 PID: 2609 Comm: compiz Not tainted 4.4.38-tegra #1
[ 98.952668] Hardware name: jetson_tx1 (DT)
[ 98.956766] task: ffffffc0de2ea580 ti: ffffffc0f4ae4000 task.ti: ffffffc0f4ae4000
[ 98.964240] PC is at 0x7f9c6fb6e4
[ 98.967552] LR is at 0x7f9c6fb678
[ 98.970857] pc : [<0000007f9c6fb6e4>] lr : [<0000007f9c6fb678>] pstate: 00000000
[ 98.978246] sp : 0000007fd2c7e200
[ 98.981559] x29: 0000007fd2c7e200 x28: 0000000000000000
[ 98.986883] x27: 0000007f966506c0 x26: 0000007f96646000
[ 98.992211] x25: 0000007f9649db28 x24: 0000000000000000
[ 98.997535] x23: 0000007fd2c7e240 x22: 0000000000000000
[ 99.002858] x21: 0000007fd2c7e300 x20: 0000007f9c78c000
[ 99.008183] x19: 0000000000000000 x18: 0000000000000014
[ 99.013504] x17: 0000007f9c6fb630 x16: 0000007f96649778
[ 99.018827] x15: 00000000000001db x14: 5f6c656e61705f74
[ 99.024154] x13: 6e6569646172675f x12: 656e696665722f73
[ 99.029475] x11: 6e6f63692f797469 x10: 6e752f6572616873
[ 99.034796] x9 : 0000000000fbba30 x8 : 0000007fd2c7e240
[ 99.040128] x7 : 0000000000000000 x6 : 0000000000000000
[ 99.045449] x5 : 0000007fa568e9b0 x4 : 00000000ffffffff
[ 99.050770] x3 : 0000000000000001 x2 : 87f688678700d000
[ 99.056098] x1 : 0000000000000000 x0 : 0000000000000000
[ 99.062905] Library at 0x7f9c6fb6e4: 0x7f9c6af000 /usr/lib/aarch64-linux-gnu/libnux-graphics-4.0.so.0.8.0
[ 99.072458] Library at 0x7f9c6fb678: 0x7f9c6af000 /usr/lib/aarch64-linux-gnu/libnux-graphics-4.0.so.0.8.0
[ 99.082014] vdso base = 0x7fa5963000
[ 100.202774] compiz[2623]: unhandled level 2 translation fault (11) at 0x000000e0, esr 0x92000006
[ 100.211594] pgd = ffffffc0de025000
[ 100.214986] [000000e0] *pgd=000000015e026003, *pud=000000015e026003, *pmd=0000000000000000
[ 100.224837] CPU: 2 PID: 2623 Comm: compiz Not tainted 4.4.38-tegra #1
[ 100.231272] Hardware name: jetson_tx1 (DT)
[ 100.235369] task: ffffffc0de07f080 ti: ffffffc07255c000 task.ti: ffffffc07255c000
[ 100.242854] PC is at 0x7f853966e4
[ 100.246167] LR is at 0x7f85396678
[ 100.249481] pc : [<0000007f853966e4>] lr : [<0000007f85396678>] pstate: 00000000
[ 100.256868] sp : 0000007fe7940100
[ 100.260188] x29: 0000007fe7940100 x28: 0000000000000000
[ 100.265512] x27: 0000007f84e396c0 x26: 0000007f84e2f000
[ 100.270835] x25: 0000007f84c86b28 x24: 0000000000000000
[ 100.276165] x23: 0000007fe7940140 x22: 0000000000000000
[ 100.281488] x21: 0000007fe7940200 x20: 0000007f85427000
[ 100.286810] x19: 0000000000000000 x18: 0000000000000014
[ 100.296057] x17: 0000007f85396630 x16: 0000007f84e32778
[ 100.301377] x15: 00000000000001db x14: 5f6c656e61705f74
[ 100.306700] x13: 6e6569646172675f x12: 656e696665722f73
[ 100.312027] x11: 6e6f63692f797469 x10: 6e752f6572616873
[ 100.317349] x9 : 0000000000f976b0 x8 : 0000007fe7940140
[ 100.322671] x7 : 0000000000000000 x6 : 0000000000000000
[ 100.327998] x5 : 0000007f8fcd89b0 x4 : 00000000ffffffff
[ 100.333319] x3 : 0000000000000001 x2 : 7733ab00a6562200
[ 100.338642] x1 : 0000000000000000 x0 : 0000000000000000
[ 100.345456] Library at 0x7f853966e4: 0x7f8534a000 /usr/lib/aarch64-linux-gnu/libnux-graphics-4.0.so.0.8.0
[ 100.355011] Library at 0x7f85396678: 0x7f8534a000 /usr/lib/aarch64-linux-gnu/libnux-graphics-4.0.so.0.8.0
[ 100.364567] vdso base = 0x7f8ffad000
[ 101.491914] compiz[2639]: unhandled level 2 translation fault (11) at 0x000000e0, esr 0x92000006
[ 101.500698] pgd = ffffffc03bec0000
[ 101.504102] [000000e0] *pgd=00000000bab3d003, *pud=00000000bab3d003, *pmd=0000000000000000
[ 101.513891] CPU: 1 PID: 2639 Comm: compiz Not tainted 4.4.38-tegra #1
[ 101.520337] Hardware name: jetson_tx1 (DT)
[ 101.524432] task: ffffffc0de2e8c80 ti: ffffffc0f4ae4000 task.ti: ffffffc0f4ae4000
[ 101.531912] PC is at 0x7f90d6a6e4
[ 101.535215] LR is at 0x7f90d6a678
[ 101.538530] pc : [<0000007f90d6a6e4>] lr : [<0000007f90d6a678>] pstate: 00000000
[ 101.545915] sp : 0000007fe1d737c0
[ 101.549226] x29: 0000007fe1d737c0 x28: 0000000000000000
[ 101.554553] x27: 0000007f9080d6c0 x26: 0000007f90803000
[ 101.559880] x25: 0000007f9065ab28 x24: 0000000000000000
[ 101.565202] x23: 0000007fe1d73800 x22: 0000000000000000
[ 101.570523] x21: 0000007fe1d738c0 x20: 0000007f90dfb000
[ 101.575853] x19: 0000000000000000 x18: 0000000000000014
[ 101.581174] x17: 0000007f90d6a630 x16: 0000007f90806778
[ 101.586494] x15: 00000000000001db x14: 5f6c656e61705f74
[ 101.591823] x13: 6e6569646172675f x12: 656e696665722f73
[ 101.597143] x11: 6e6f63692f797469 x10: 6e752f6572616873
[ 101.602464] x9 : 0000000000fa8180 x8 : 0000007fe1d73800
[ 101.607790] x7 : 0000000000000000 x6 : 0000000000000000
[ 101.613112] x5 : 0000007f9b6ae9b0 x4 : 00000000ffffffff
[ 101.618432] x3 : 0000000000000001 x2 : 976895c3a218f500
[ 101.623758] x1 : 0000000000000000 x0 : 0000000000000000
[ 101.630567] Library at 0x7f90d6a6e4: 0x7f90d1e000 /usr/lib/aarch64-linux-gnu/libnux-graphics-4.0.so.0.8.0
[ 101.640122] Library at 0x7f90d6a678: 0x7f90d1e000 /usr/lib/aarch64-linux-gnu/libnux-graphics-4.0.so.0.8.0
[ 101.649677] vdso base = 0x7f9b983000
[ 102.754405] compiz[2653]: unhandled level 2 translation fault (11) at 0x000000e0, esr 0x92000006
[ 102.763205] pgd = ffffffc0dc47f000
[ 102.766611] [000000e0] *pgd=0000000165ac5003, *pud=0000000165ac5003, *pmd=0000000000000000
[ 102.776422] CPU: 1 PID: 2653 Comm: compiz Not tainted 4.4.38-tegra #1
[ 102.782860] Hardware name: jetson_tx1 (DT)
[ 102.786953] task: ffffffc0de2e8c80 ti: ffffffc0e5a7c000 task.ti: ffffffc0e5a7c000
[ 102.794429] PC is at 0x7f706096e4
[ 102.797741] LR is at 0x7f70609678
[ 102.801055] pc : [<0000007f706096e4>] lr : [<0000007f70609678>] pstate: 00000000
[ 102.808441] sp : 0000007fec711950
[ 102.811768] x29: 0000007fec711950 x28: 0000000000000000
[ 102.817094] x27: 0000007f6a6506c0 x26: 0000007f6a646000
[ 102.822419] x25: 0000007f6a49db28 x24: 0000000000000000
[ 102.827748] x23: 0000007fec711990 x22: 0000000000000000
[ 102.833067] x21: 0000007fec711a50 x20: 0000007f7069a000
[ 102.838387] x19: 0000000000000000 x18: 0000000000000014
[ 102.843718] x17: 0000007f70609630 x16: 0000007f6a649778
[ 102.849038] x15: 00000000000001db x14: 5f6c656e61705f74
[ 102.854358] x13: 6e6569646172675f x12: 656e696665722f73
[ 102.859687] x11: 6e6f63692f797469 x10: 6e752f6572616873
[ 102.865006] x9 : 0000000000fa7c90 x8 : 0000007fec711990
[ 102.870327] x7 : 0000000000000000 x6 : 0000000000000000
[ 102.875656] x5 : 0000007f795a39b0 x4 : 00000000ffffffff
[ 102.880978] x3 : 0000000000000001 x2 : 87fbdfc19c125600
[ 102.886297] x1 : 0000000000000000 x0 : 0000000000000000
[ 102.893110] Library at 0x7f706096e4: 0x7f705bd000 /usr/lib/aarch64-linux-gnu/libnux-graphics-4.0.so.0.8.0
[ 102.902666] Library at 0x7f70609678: 0x7f705bd000 /usr/lib/aarch64-linux-gnu/libnux-graphics-4.0.so.0.8.0
[ 102.912218] vdso base = 0x7f79878000
[ 104.123420] compiz[2667]: unhandled level 2 translation fault (11) at 0x000000e0, esr 0x92000006
[ 104.132208] pgd = ffffffc0726b5000
[ 104.135612] [000000e0] *pgd=00000000fccc0003, *pud=00000000fccc0003, *pmd=0000000000000000
[ 104.145394] CPU: 2 PID: 2667 Comm: compiz Not tainted 4.4.38-tegra #1
[ 104.151850] Hardware name: jetson_tx1 (DT)
[ 104.155945] task: ffffffc0de07f080 ti: ffffffc0f4a6c000 task.ti: ffffffc0f4a6c000
[ 104.163424] PC is at 0x7f699f96e4
[ 104.166736] LR is at 0x7f699f9678
[ 104.170050] pc : [<0000007f699f96e4>] lr : [<0000007f699f9678>] pstate: 00000000
[ 104.177435] sp : 0000007fd1f48990
[ 104.180749] x29: 0000007fd1f48990 x28: 0000000000000000
[ 104.189996] x27: 0000007f6949c6c0 x26: 0000007f69492000
[ 104.195319] x25: 0000007f692e9b28 x24: 0000000000000000
[ 104.200650] x23: 0000007fd1f489d0 x22: 0000000000000000
[ 104.205972] x21: 0000007fd1f48a90 x20: 0000007f69a8a000
[ 104.211297] x19: 0000000000000000 x18: 0000000000000014
[ 104.216624] x17: 0000007f699f9630 x16: 0000007f69495778
[ 104.221947] x15: 00000000000001db x14: 5f6c656e61705f74
[ 104.227268] x13: 6e6569646172675f x12: 656e696665722f73
[ 104.232596] x11: 6e6f63692f797469 x10: 6e752f6572616873
[ 104.237917] x9 : 0000000000fe3850 x8 : 0000007fd1f489d0
[ 104.243242] x7 : 0000000000000000 x6 : 0000000000000000
[ 104.248566] x5 : 0000007f7c3459b0 x4 : 00000000ffffffff
[ 104.253887] x3 : 0000000000000001 x2 : 7446d64940686f00
[ 104.259206] x1 : 0000000000000000 x0 : 0000000000000000
[ 104.266023] Library at 0x7f699f96e4: 0x7f699ad000 /usr/lib/aarch64-linux-gnu/libnux-graphics-4.0.so.0.8.0
[ 104.275576] Library at 0x7f699f9678: 0x7f699ad000 /usr/lib/aarch64-linux-gnu/libnux-graphics-4.0.so.0.8.0
[ 104.285132] vdso base = 0x7f7c61a000
[ 105.423026] compiz[2680]: unhandled level 2 translation fault (11) at 0x000000e0, esr 0x92000006
[ 105.431819] pgd = ffffffc0725b4000
[ 105.435210] [000000e0] *pgd=00000000f25b5003, *pud=00000000f25b5003, *pmd=0000000000000000
[ 105.445030] CPU: 2 PID: 2680 Comm: compiz Not tainted 4.4.38-tegra #1
[ 105.451466] Hardware name: jetson_tx1 (DT)
[ 105.455561] task: ffffffc0de250c80 ti: ffffffc0de1a8000 task.ti: ffffffc0de1a8000
[ 105.463037] PC is at 0x7f7244b6e4
[ 105.466351] LR is at 0x7f7244b678
[ 105.469664] pc : [<0000007f7244b6e4>] lr : [<0000007f7244b678>] pstate: 00000000
[ 105.477049] sp : 0000007fe4f2a340
[ 105.480383] x29: 0000007fe4f2a340 x28: 0000000000000000
[ 105.485708] x27: 0000007f71eee6c0 x26: 0000007f71ee4000
[ 105.491030] x25: 0000007f71d3bb28 x24: 0000000000000000
[ 105.500281] x23: 0000007fe4f2a380 x22: 0000000000000000
[ 105.505604] x21: 0000007fe4f2a440 x20: 0000007f724dc000
[ 105.510924] x19: 0000000000000000 x18: 0000000000000014
[ 105.516248] x17: 0000007f7244b630 x16: 0000007f71ee7778
[ 105.521572] x15: 00000000000001db x14: 5f6c656e61705f74
[ 105.526891] x13: 6e6569646172675f x12: 656e696665722f73
[ 105.532218] x11: 6e6f63692f797469 x10: 6e752f6572616873
[ 105.537538] x9 : 0000000000facc50 x8 : 0000007fe4f2a380
[ 105.542860] x7 : 0000000000000000 x6 : 0000000000000000
[ 105.548190] x5 : 0000007f84d959b0 x4 : 00000000ffffffff
[ 105.553512] x3 : 0000000000000001 x2 : dc87061dcf9d3100
[ 105.558835] x1 : 0000000000000000 x0 : 0000000000000000
[ 105.565658] Library at 0x7f7244b6e4: 0x7f723ff000 /usr/lib/aarch64-linux-gnu/libnux-graphics-4.0.so.0.8.0
[ 105.575211] Library at 0x7f7244b678: 0x7f723ff000 /usr/lib/aarch64-linux-gnu/libnux-graphics-4.0.so.0.8.0
[ 105.584767] vdso base = 0x7f8506a000
[ 106.797641] compiz[2694]: unhandled level 2 translation fault (11) at 0x000000e0, esr 0x92000006
[ 106.806451] pgd = ffffffc0de0e3000
[ 106.809872] [000000e0] *pgd=0000000165a3e003, *pud=0000000165a3e003, *pmd=0000000000000000
[ 106.819713] CPU: 1 PID: 2694 Comm: compiz Not tainted 4.4.38-tegra #1
[ 106.826148] Hardware name: jetson_tx1 (DT)
[ 106.830243] task: ffffffc0de250c80 ti: ffffffc03bd54000 task.ti: ffffffc03bd54000
[ 106.837716] PC is at 0x7f890e86e4
[ 106.841028] LR is at 0x7f890e8678
[ 106.844343] pc : [<0000007f890e86e4>] lr : [<0000007f890e8678>] pstate: 00000000
[ 106.851731] sp : 0000007fc7d6e830
[ 106.855035] x29: 0000007fc7d6e830 x28: 0000000000000000
[ 106.860367] x27: 0000007f88b8b6c0 x26: 0000007f88b81000
[ 106.865690] x25: 0000007f889d8b28 x24: 0000000000000000
[ 106.871013] x23: 0000007fc7d6e870 x22: 0000000000000000
[ 106.876339] x21: 0000007fc7d6e930 x20: 0000007f89179000
[ 106.881660] x19: 0000000000000000 x18: 0000000000000014
[ 106.886995] x17: 0000007f890e8630 x16: 0000007f88b84778
[ 106.892324] x15: 00000000000001db x14: 5f6c656e61705f74
[ 106.897644] x13: 6e6569646172675f x12: 656e696665722f73
[ 106.902965] x11: 6e6f63692f797469 x10: 6e752f6572616873
[ 106.908296] x9 : 0000000000fcd660 x8 : 0000007fc7d6e870
[ 106.913619] x7 : 0000000000000000 x6 : 0000000000000000
[ 106.918939] x5 : 0000007f93a2d9b0 x4 : 00000000ffffffff
[ 106.924269] x3 : 0000000000000001 x2 : 534d3c42d8281a00
[ 106.929593] x1 : 0000000000000000 x0 : 0000000000000000
[ 106.936408] Library at 0x7f890e86e4: 0x7f8909c000 /usr/lib/aarch64-linux-gnu/libnux-graphics-4.0.so.0.8.0
[ 106.945976] Library at 0x7f890e8678: 0x7f8909c000 /usr/lib/aarch64-linux-gnu/libnux-graphics-4.0.so.0.8.0
[ 106.955532] vdso base = 0x7f93d02000
[ 108.067610] compiz[2708]: unhandled level 2 translation fault (11) at 0x000000e0, esr 0x92000006
[ 108.076411] pgd = ffffffc03bf1b000
[ 108.079822] [000000e0] *pgd=00000000f268f003, *pud=00000000f268f003, *pmd=0000000000000000
[ 108.089623] CPU: 3 PID: 2708 Comm: compiz Not tainted 4.4.38-tegra #1
[ 108.096061] Hardware name: jetson_tx1 (DT)
[ 108.100159] task: ffffffc0de07b200 ti: ffffffc043784000 task.ti: ffffffc043784000
[ 108.107633] PC is at 0x7f8b8476e4
[ 108.110938] LR is at 0x7f8b847678
[ 108.114251] pc : [<0000007f8b8476e4>] lr : [<0000007f8b847678>] pstate: 00000000
[ 108.121641] sp : 0000007fe97bd0d0
[ 108.124953] x29: 0000007fe97bd0d0 x28: 0000000000000000
[ 108.130275] x27: 0000007f8b2ea6c0 x26: 0000007f8b2e0000
[ 108.135604] x25: 0000007f8b137b28 x24: 0000000000000000
[ 108.140929] x23: 0000007fe97bd110 x22: 0000000000000000
[ 108.146251] x21: 0000007fe97bd1d0 x20: 0000007f8b8d8000
[ 108.151579] x19: 0000000000000000 x18: 0000000000000014
[ 108.156899] x17: 0000007f8b847630 x16: 0000007f8b2e3778
[ 108.162223] x15: 00000000000001db x14: 5f6c656e61705f74
[ 108.167549] x13: 6e6569646172675f x12: 656e696665722f73
[ 108.172872] x11: 6e6f63692f797469 x10: 6e752f6572616873
[ 108.178192] x9 : 0000000000f96d00 x8 : 0000007fe97bd110
[ 108.183523] x7 : 0000000000000000 x6 : 0000000000000000
[ 108.188844] x5 : 0000007f9a1929b0 x4 : 00000000ffffffff
[ 108.194164] x3 : 0000000000000001 x2 : 21d6b622260ea900
[ 108.199493] x1 : 0000000000000000 x0 : 0000000000000000
[ 108.206302] Library at 0x7f8b8476e4: 0x7f8b7fb000 /usr/lib/aarch64-linux-gnu/libnux-graphics-4.0.so.0.8.0
[ 108.215855] Library at 0x7f8b847678: 0x7f8b7fb000 /usr/lib/aarch64-linux-gnu/libnux-graphics-4.0.so.0.8.0
[ 108.225411] vdso base = 0x7f9a467000
[ 109.349034] compiz[2722]: unhandled level 2 translation fault (11) at 0x000000e0, esr 0x92000006
[ 109.357821] pgd = ffffffc0dc4fc000
[ 109.361285] [000000e0] *pgd=000000016bac1003, *pud=000000016bac1003, *pmd=0000000000000000
[ 109.371077] CPU: 1 PID: 2722 Comm: compiz Not tainted 4.4.38-tegra #1
[ 109.377532] Hardware name: jetson_tx1 (DT)
[ 109.381628] task: ffffffc0de07b200 ti: ffffffc0de2d4000 task.ti: ffffffc0de2d4000
[ 109.389107] PC is at 0x7f808d46e4
[ 109.392420] LR is at 0x7f808d4678
[ 109.395733] pc : [<0000007f808d46e4>] lr : [<0000007f808d4678>] pstate: 00000000
[ 109.403118] sp : 0000007ff5003520
[ 109.406431] x29: 0000007ff5003520 x28: 0000000000000000
[ 109.411761] x27: 0000007f7bffe6c0 x26: 0000007f7bff4000
[ 109.417083] x25: 0000007f7be4bb28 x24: 0000000000000000
[ 109.422405] x23: 0000007ff5003560 x22: 0000000000000000
[ 109.427734] x21: 0000007ff5003620 x20: 0000007f80965000
[ 109.433058] x19: 0000000000000000 x18: 0000000000000014
[ 109.438381] x17: 0000007f808d4630 x16: 0000007f7bff7778
[ 109.443774] x15: 00000000000001db x14: 5f6c656e61705f74
[ 109.449100] x13: 6e6569646172675f x12: 656e696665722f73
[ 109.454423] x11: 6e6f63692f797469 x10: 6e752f6572616873
[ 109.459750] x9 : 0000000000fdccf0 x8 : 0000007ff5003560
[ 109.465071] x7 : 0000000000000000 x6 : 0000000000000000
[ 109.470395] x5 : 0000007f8b2149b0 x4 : 00000000ffffffff
[ 109.475721] x3 : 0000000000000001 x2 : a77a94301e709a00
[ 109.481042] x1 : 0000000000000000 x0 : 0000000000000000
[ 109.487862] Library at 0x7f808d46e4: 0x7f80888000 /usr/lib/aarch64-linux-gnu/libnux-graphics-4.0.so.0.8.0
[ 109.497416] Library at 0x7f808d4678: 0x7f80888000 /usr/lib/aarch64-linux-gnu/libnux-graphics-4.0.so.0.8.0
[ 109.506968] vdso base = 0x7f8b4e9000
[ 110.649418] compiz[2735]: unhandled level 2 translation fault (11) at 0x000000e0, esr 0x92000006
[ 110.658206] pgd = ffffffc040f0a000
[ 110.661612] [000000e0] *pgd=0000000165a3c003, *pud=0000000165a3c003, *pmd=0000000000000000
[ 110.671392] CPU: 2 PID: 2735 Comm: compiz Not tainted 4.4.38-tegra #1
[ 110.677846] Hardware name: jetson_tx1 (DT)
[ 110.681943] task: ffffffc0de07b200 ti: ffffffc040e28000 task.ti: ffffffc040e28000
[ 110.689422] PC is at 0x7f657b76e4
[ 110.692741] LR is at 0x7f657b7678
[ 110.696055] pc : [<0000007f657b76e4>] lr : [<0000007f657b7678>] pstate: 00000000
[ 110.703439] sp : 0000007fc4f1aaa0
[ 110.706749] x29: 0000007fc4f1aaa0 x28: 0000000000000000
[ 110.712079] x27: 0000007f6525a6c0 x26: 0000007f65250000
[ 110.717402] x25: 0000007f650a7b28 x24: 0000000000000000
[ 110.722722] x23: 0000007fc4f1aae0 x22: 0000000000000000
[ 110.728051] x21: 0000007fc4f1aba0 x20: 0000007f65848000
[ 110.733371] x19: 0000000000000000 x18: 0000000000000014
[ 110.738690] x17: 0000007f657b7630 x16: 0000007f65253778
[ 110.744015] x15: 00000000000001db x14: 5f6c656e61705f74
[ 110.749338] x13: 6e6569646172675f x12: 656e696665722f73
[ 110.754660] x11: 6e6f63692f797469 x10: 6e752f6572616873
[ 110.759985] x9 : 0000000000fade50 x8 : 0000007fc4f1aae0
[ 110.765305] x7 : 0000000000000000 x6 : 0000000000000000
[ 110.770628] x5 : 0000007f780f79b0 x4 : 00000000ffffffff
[ 110.775955] x3 : 0000000000000001 x2 : d4bfef4540765500
[ 110.781516] x1 : 0000000000000000 x0 : 0000000000000000
[ 110.788413] Library at 0x7f657b76e4: 0x7f6576b000 /usr/lib/aarch64-linux-gnu/libnux-graphics-4.0.so.0.8.0
[ 110.797969] Library at 0x7f657b7678: 0x7f6576b000 /usr/lib/aarch64-linux-gnu/libnux-graphics-4.0.so.0.8.0
[ 110.807539] vdso base = 0x7f783cc000
[ 111.937241] compiz[2748]: unhandled level 2 translation fault (11) at 0x000000e0, esr 0x92000006
[ 111.946050] pgd = ffffffc043596000
[ 111.949520] [000000e0] *pgd=00000000c3595003, *pud=00000000c3595003, *pmd=0000000000000000
[ 111.959355] CPU: 2 PID: 2748 Comm: compiz Not tainted 4.4.38-tegra #1
[ 111.965826] Hardware name: jetson_tx1 (DT)
[ 111.969945] task: ffffffc0de253200 ti: ffffffc0e5a60000 task.ti: ffffffc0e5a60000
[ 111.977445] PC is at 0x7f9ff356e4
[ 111.980778] LR is at 0x7f9ff35678
[ 111.984112] pc : [<0000007f9ff356e4>] lr : [<0000007f9ff35678>] pstate: 00000000
[ 111.991518] sp : 0000007fe304a990
[ 111.994824] x29: 0000007fe304a990 x28: 0000000000000000
[ 112.000180] x27: 0000007f9f9ed6c0 x26: 0000007f9f9e3000
[ 112.005521] x25: 0000007f9f83ab28 x24: 0000000000000000
[ 112.010864] x23: 0000007fe304a9d0 x22: 0000000000000000
[ 112.016218] x21: 0000007fe304aa90 x20: 0000007f9ffc6000
[ 112.021560] x19: 0000000000000000 x18: 0000000000000014
[ 112.026903] x17: 0000007f9ff35630 x16: 0000007f9f9e6778
[ 112.032253] x15: 00000000000001db x14: 5f6c656e61705f74
[ 112.037594] x13: 6e6569646172675f x12: 656e696665722f73
[ 112.042937] x11: 6e6f63692f797469 x10: 6e752f6572616873
[ 112.048285] x9 : 0000000000fcb510 x8 : 0000007fe304a9d0
[ 112.053626] x7 : 0000000000000000 x6 : 0000000000000000
[ 112.058973] x5 : 0000007fae89c9b0 x4 : 00000000ffffffff
[ 112.064333] x3 : 0000000000000001 x2 : 1a11f435cd716500
[ 112.069676] x1 : 0000000000000000 x0 : 0000000000000000
[ 112.076546] Library at 0x7f9ff356e4: 0x7f9fee9000 /usr/lib/aarch64-linux-gnu/libnux-graphics-4.0.so.0.8.0
[ 112.086122] Library at 0x7f9ff35678: 0x7f9fee9000 /usr/lib/aarch64-linux-gnu/libnux-graphics-4.0.so.0.8.0
[ 112.095699] vdso base = 0x7faeb71000
[ 113.210268] compiz[2762]: unhandled level 2 translation fault (11) at 0x000000e0, esr 0x92000006
[ 113.219065] pgd = ffffffc0e397a000
[ 113.222471] [000000e0] *pgd=0000000163975003, *pud=0000000163975003, *pmd=0000000000000000
[ 113.232287] CPU: 3 PID: 2762 Comm: compiz Not tainted 4.4.38-tegra #1
[ 113.238729] Hardware name: jetson_tx1 (DT)
[ 113.242825] task: ffffffc0de253200 ti: ffffffc040ef8000 task.ti: ffffffc040ef8000
[ 113.250301] PC is at 0x7f888d16e4
[ 113.253614] LR is at 0x7f888d1678
[ 113.256930] pc : [<0000007f888d16e4>] lr : [<0000007f888d1678>] pstate: 00000000
[ 113.264316] sp : 0000007ff751d650
[ 113.267629] x29: 0000007ff751d650 x28: 0000000000000000
[ 113.272952] x27: 0000007f826506c0 x26: 0000007f82646000
[ 113.278276] x25: 0000007f8249db28 x24: 0000000000000000
[ 113.283603] x23: 0000007ff751d690 x22: 0000000000000000
[ 113.288923] x21: 0000007ff751d750 x20: 0000007f88962000
[ 113.294244] x19: 0000000000000000 x18: 0000000000000014
[ 113.299572] x17: 0000007f888d1630 x16: 0000007f82649778
[ 113.304894] x15: 00000000000001db x14: 5f6c656e61705f74
[ 113.310216] x13: 6e6569646172675f x12: 656e696665722f73
[ 113.315544] x11: 6e6f63692f797469 x10: 6e752f6572616873
[ 113.320868] x9 : 0000000000fada10 x8 : 0000007ff751d690
[ 113.326188] x7 : 0000000000000000 x6 : 0000000000000000
[ 113.331516] x5 : 0000007f918689b0 x4 : 00000000ffffffff
[ 113.336839] x3 : 0000000000000001 x2 : de50125252e6ab00
[ 113.342160] x1 : 0000000000000000 x0 : 0000000000000000
[ 113.348975] Library at 0x7f888d16e4: 0x7f88885000 /usr/lib/aarch64-linux-gnu/libnux-graphics-4.0.so.0.8.0
[ 113.358532] Library at 0x7f888d1678: 0x7f88885000 /usr/lib/aarch64-linux-gnu/libnux-graphics-4.0.so.0.8.0
[ 113.368086] vdso base = 0x7f91b3d000
[ 114.495874] compiz[2775]: unhandled level 2 translation fault (11) at 0x000000e0, esr 0x92000006
[ 114.504659] pgd = ffffffc0de3f3000
[ 114.508071] [000000e0] *pgd=000000016b8b8003, *pud=000000016b8b8003, *pmd=0000000000000000
[ 114.517870] CPU: 3 PID: 2775 Comm: compiz Not tainted 4.4.38-tegra #1
[ 114.524305] Hardware name: jetson_tx1 (DT)
[ 114.528404] task: ffffffc0726ea580 ti: ffffffc0434b0000 task.ti: ffffffc0434b0000
[ 114.535879] PC is at 0x7fa0a946e4
[ 114.539184] LR is at 0x7fa0a94678
[ 114.542496] pc : [<0000007fa0a946e4>] lr : [<0000007fa0a94678>] pstate: 00000000
[ 114.549884] sp : 0000007fccd60d10
[ 114.553197] x29: 0000007fccd60d10 x28: 0000000000000000
[ 114.558519] x27: 0000007f9a6506c0 x26: 0000007f9a646000
[ 114.563846] x25: 0000007f9a49db28 x24: 0000000000000000
[ 114.569170] x23: 0000007fccd60d50 x22: 0000000000000000
[ 114.574491] x21: 0000007fccd60e10 x20: 0000007fa0b25000
[ 114.579817] x19: 0000000000000000 x18: 0000000000000014
[ 114.585138] x17: 0000007fa0a94630 x16: 0000007f9a649778
[ 114.590463] x15: 00000000000001db x14: 5f6c656e61705f74
[ 114.595789] x13: 6e6569646172675f x12: 656e696665722f73
[ 114.601110] x11: 6e6f63692f797469 x10: 6e752f6572616873
[ 114.606429] x9 : 0000000000f95940 x8 : 0000007fccd60d50
[ 114.611761] x7 : 0000000000000000 x6 : 0000000000000000
[ 114.617081] x5 : 0000007fa9a309b0 x4 : 00000000ffffffff
[ 114.622403] x3 : 0000000000000001 x2 : cc377bed85c0d000
[ 114.627730] x1 : 0000000000000000 x0 : 0000000000000000
[ 114.634539] Library at 0x7fa0a946e4: 0x7fa0a48000 /usr/lib/aarch64-linux-gnu/libnux-graphics-4.0.so.0.8.0
[ 114.644093] Library at 0x7fa0a94678: 0x7fa0a48000 /usr/lib/aarch64-linux-gnu/libnux-graphics-4.0.so.0.8.0
[ 114.653650] vdso base = 0x7fa9d05000
[ 115.875174] compiz[2789]: unhandled level 2 translation fault (11) at 0x000000e0, esr 0x92000006
[ 115.883993] pgd = ffffffc043576000
[ 115.887385] [000000e0] *pgd=00000000c0d0e003, *pud=00000000c0d0e003, *pmd=0000000000000000
[ 115.897199] CPU: 3 PID: 2789 Comm: compiz Not tainted 4.4.38-tegra #1
[ 115.903680] Hardware name: jetson_tx1 (DT)
[ 115.907788] task: ffffffc0de2e8c80 ti: ffffffc0e596c000 task.ti: ffffffc0e596c000
[ 115.915266] PC is at 0x7f85b266e4
[ 115.918578] LR is at 0x7f85b26678
[ 115.921892] pc : [<0000007f85b266e4>] lr : [<0000007f85b26678>] pstate: 00000000
[ 115.929281] sp : 0000007fd3a566c0
[ 115.932594] x29: 0000007fd3a566c0 x28: 0000000000000000
[ 115.937915] x27: 0000007f855c96c0 x26: 0000007f855bf000
[ 115.943237] x25: 0000007f85416b28 x24: 0000000000000000
[ 115.948566] x23: 0000007fd3a56700 x22: 0000000000000000
[ 115.953887] x21: 0000007fd3a567c0 x20: 0000007f85bb7000
[ 115.959206] x19: 0000000000000000 x18: 0000000000000014
[ 115.964533] x17: 0000007f85b26630 x16: 0000007f855c2778
[ 115.969857] x15: 00000000000001db x14: 5f6c656e61705f74
[ 115.975178] x13: 6e6569646172675f x12: 656e696665722f73
[ 115.980505] x11: 6e6f63692f797469 x10: 6e752f6572616873
[ 115.985826] x9 : 0000000000fc3570 x8 : 0000007fd3a56700
[ 115.991147] x7 : 0000000000000000 x6 : 0000000000000000
[ 115.996473] x5 : 0000007f9846c9b0 x4 : 00000000ffffffff
[ 116.001792] x3 : 0000000000000001 x2 : ae8460a42324e900
[ 116.007111] x1 : 0000000000000000 x0 : 0000000000000000
[ 116.013931] Library at 0x7f85b266e4: 0x7f85ada000 /usr/lib/aarch64-linux-gnu/libnux-graphics-4.0.so.0.8.0
[ 116.023485] Library at 0x7f85b26678: 0x7f85ada000 /usr/lib/aarch64-linux-gnu/libnux-graphics-4.0.so.0.8.0
[ 116.033041] vdso base = 0x7f98741000
[ 117.112756] compiz[2802]: unhandled level 2 translation fault (11) at 0x000000e0, esr 0x92000006
[ 117.121543] pgd = ffffffc0de025000
[ 117.125109] [000000e0] *pgd=00000001681fe003, *pud=00000001681fe003, *pmd=0000000000000000
[ 117.134897] CPU: 2 PID: 2802 Comm: compiz Not tainted 4.4.38-tegra #1
[ 117.141419] Hardware name: jetson_tx1 (DT)
[ 117.145556] task: ffffffc0de250000 ti: ffffffc0de24c000 task.ti: ffffffc0de24c000
[ 117.153036] PC is at 0x7f65fbe6e4
[ 117.156349] LR is at 0x7f65fbe678
[ 117.159663] pc : [<0000007f65fbe6e4>] lr : [<0000007f65fbe678>] pstate: 00000000
[ 117.167051] sp : 0000007fdf8052b0
[ 117.170362] x29: 0000007fdf8052b0 x28: 0000000000000000
[ 117.175691] x27: 0000007f65a616c0 x26: 0000007f65a57000
[ 117.181012] x25: 0000007f658aeb28 x24: 0000000000000000
[ 117.186334] x23: 0000007fdf8052f0 x22: 0000000000000000
[ 117.191661] x21: 0000007fdf8053b0 x20: 0000007f6604f000
[ 117.196982] x19: 0000000000000000 x18: 0000000000000014
[ 117.202302] x17: 0000007f65fbe630 x16: 0000007f65a5a778
[ 117.207632] x15: 00000000000001db x14: 5f6c656e61705f74
[ 117.212953] x13: 6e6569646172675f x12: 656e696665722f73
[ 117.218273] x11: 6e6f63692f797469 x10: 6e752f6572616873
[ 117.223601] x9 : 0000000000fd0e30 x8 : 0000007fdf8052f0
[ 117.228924] x7 : 0000000000000000 x6 : 0000000000000000
[ 117.234245] x5 : 0000007f789059b0 x4 : 00000000ffffffff
[ 117.239571] x3 : 0000000000000001 x2 : 423afafeef02ff00
[ 117.244894] x1 : 0000000000000000 x0 : 0000000000000000
[ 117.251711] Library at 0x7f65fbe6e4: 0x7f65f72000 /usr/lib/aarch64-linux-gnu/libnux-graphics-4.0.so.0.8.0
[ 117.261265] Library at 0x7f65fbe678: 0x7f65f72000 /usr/lib/aarch64-linux-gnu/libnux-graphics-4.0.so.0.8.0
[ 117.270818] vdso base = 0x7f78bda000
[ 118.376518] compiz[2816]: unhandled level 2 translation fault (11) at 0x000000e0, esr 0x92000006
[ 118.385329] pgd = ffffffc0ebae9000
[ 118.388746] [000000e0] *pgd=00000001659d3003, *pud=00000001659d3003, *pmd=0000000000000000
[ 118.398575] CPU: 2 PID: 2816 Comm: compiz Not tainted 4.4.38-tegra #1
[ 118.405013] Hardware name: jetson_tx1 (DT)
[ 118.409112] task: ffffffc0de250000 ti: ffffffc040fc8000 task.ti: ffffffc040fc8000
[ 118.416587] PC is at 0x7fa464c6e4
[ 118.419900] LR is at 0x7fa464c678
[ 118.423205] pc : [<0000007fa464c6e4>] lr : [<0000007fa464c678>] pstate: 00000000
[ 118.430594] sp : 0000007fcec09400
[ 118.433907] x29: 0000007fcec09400 x28: 0000000000000000
[ 118.439229] x27: 0000007f9e6506c0 x26: 0000007f9e646000
[ 118.444557] x25: 0000007f9e49db28 x24: 0000000000000000
[ 118.449880] x23: 0000007fcec09440 x22: 0000000000000000
[ 118.455199] x21: 0000007fcec09500 x20: 0000007fa46dd000
[ 118.460525] x19: 0000000000000000 x18: 0000000000000014
[ 118.465844] x17: 0000007fa464c630 x16: 0000007f9e649778
[ 118.471166] x15: 00000000000001db x14: 5f6c656e61705f74
[ 118.476493] x13: 6e6569646172675f x12: 656e696665722f73
[ 118.481815] x11: 6e6f63692f797469 x10: 6e752f6572616873
[ 118.487134] x9 : 0000000000fae450 x8 : 0000007fcec09440
[ 118.492463] x7 : 0000000000000000 x6 : 0000000000000000
[ 118.497783] x5 : 0000007fad5e49b0 x4 : 00000000ffffffff
[ 118.503102] x3 : 0000000000000001 x2 : 7dde936b1b05aa00
[ 118.508432] x1 : 0000000000000000 x0 : 0000000000000000
[ 118.515242] Library at 0x7fa464c6e4: 0x7fa4600000 /usr/lib/aarch64-linux-gnu/libnux-graphics-4.0.so.0.8.0
[ 118.524795] Library at 0x7fa464c678: 0x7fa4600000 /usr/lib/aarch64-linux-gnu/libnux-graphics-4.0.so.0.8.0
[ 118.534350] vdso base = 0x7fad8b9000
[ 119.638559] compiz[2830]: unhandled level 2 translation fault (11) at 0x000000e0, esr 0x92000006
[ 119.647351] pgd = ffffffc03a20d000
[ 119.650762] [000000e0] *pgd=00000000ba210003, *pud=00000000ba210003, *pmd=0000000000000000
[ 119.660576] CPU: 1 PID: 2830 Comm: compiz Not tainted 4.4.38-tegra #1
[ 119.667029] Hardware name: jetson_tx1 (DT)
[ 119.671129] task: ffffffc0726e8c80 ti: ffffffc0de1b4000 task.ti: ffffffc0de1b4000
[ 119.678606] PC is at 0x7f98e216e4
[ 119.681921] LR is at 0x7f98e21678
[ 119.685234] pc : [<0000007f98e216e4>] lr : [<0000007f98e21678>] pstate: 00000000
[ 119.692624] sp : 0000007fdf817290
[ 119.695936] x29: 0000007fdf817290 x28: 0000000000000000
[ 119.701257] x27: 0000007f988c46c0 x26: 0000007f988ba000
[ 119.706578] x25: 0000007f98711b28 x24: 0000000000000000
[ 119.711907] x23: 0000007fdf8172d0 x22: 0000000000000000
[ 119.717227] x21: 0000007fdf817390 x20: 0000007f98eb2000
[ 119.722547] x19: 0000000000000000 x18: 0000000000000014
[ 119.727888] x17: 0000007f98e21630 x16: 0000007f988bd778
[ 119.733212] x15: 00000000000001db x14: 5f6c656e61705f74
[ 119.738600] x13: 6e6569646172675f x12: 656e696665722f73
[ 119.743931] x11: 6e6f63692f797469 x10: 6e752f6572616873
[ 119.749252] x9 : 0000000000fbded0 x8 : 0000007fdf8172d0
[ 119.754576] x7 : 0000000000000000 x6 : 0000000000000000
[ 119.759902] x5 : 0000007fa1dba9b0 x4 : 00000000ffffffff
[ 119.765222] x3 : 0000000000000001 x2 : b35fe3eab26fda00
[ 119.770543] x1 : 0000000000000000 x0 : 0000000000000000
[ 119.777361] Library at 0x7f98e216e4: 0x7f98dd5000 /usr/lib/aarch64-linux-gnu/libnux-graphics-4.0.so.0.8.0
[ 119.786927] Library at 0x7f98e21678: 0x7f98dd5000 /usr/lib/aarch64-linux-gnu/libnux-graphics-4.0.so.0.8.0
[ 119.796486] vdso base = 0x7fa208f000
[ 120.902610] compiz[2843]: unhandled level 2 translation fault (11) at 0x000000e0, esr 0x92000006
[ 120.911401] pgd = ffffffc0f2ffe000
[ 120.914804] [000000e0] *pgd=000000016bba8003, *pud=000000016bba8003, *pmd=0000000000000000
[ 120.924616] CPU: 2 PID: 2843 Comm: compiz Not tainted 4.4.38-tegra #1
[ 120.931054] Hardware name: jetson_tx1 (DT)
[ 120.935151] task: ffffffc0726e8c80 ti: ffffffc040f6c000 task.ti: ffffffc040f6c000
[ 120.942647] PC is at 0x7f80c4d6e4
[ 120.945962] LR is at 0x7f80c4d678
[ 120.949278] pc : [<0000007f80c4d6e4>] lr : [<0000007f80c4d678>] pstate: 00000000
[ 120.956664] sp : 0000007ffa3b9640
[ 120.959976] x29: 0000007ffa3b9640 x28: 0000000000000000
[ 120.965300] x27: 0000007f806f06c0 x26: 0000007f806e6000
[ 120.970625] x25: 0000007f8053db28 x24: 0000000000000000
[ 120.975953] x23: 0000007ffa3b9680 x22: 0000000000000000
[ 120.981274] x21: 0000007ffa3b9740 x20: 0000007f80cde000
[ 120.986595] x19: 0000000000000000 x18: 0000000000000014
[ 120.991923] x17: 0000007f80c4d630 x16: 0000007f806e9778
[ 120.997245] x15: 00000000000001db x14: 5f6c656e61705f74
[ 121.002566] x13: 6e6569646172675f x12: 656e696665722f73
[ 121.007894] x11: 6e6f63692f797469 x10: 6e752f6572616873
[ 121.013215] x9 : 0000000000fae870 x8 : 0000007ffa3b9680
[ 121.018536] x7 : 0000000000000000 x6 : 0000000000000000
[ 121.023863] x5 : 0000007f89bde9b0 x4 : 00000000ffffffff
[ 121.029188] x3 : 0000000000000001 x2 : 1db5a27bab083900
[ 121.034510] x1 : 0000000000000000 x0 : 0000000000000000
[ 121.041326] Library at 0x7f80c4d6e4: 0x7f80c01000 /usr/lib/aarch64-linux-gnu/libnux-graphics-4.0.so.0.8.0
[ 121.050881] Library at 0x7f80c4d678: 0x7f80c01000 /usr/lib/aarch64-linux-gnu/libnux-graphics-4.0.so.0.8.0
[ 121.060435] vdso base = 0x7f89eb3000
[ 122.156650] compiz[2857]: unhandled level 2 translation fault (11) at 0x000000e0, esr 0x92000006
[ 122.165436] pgd = ffffffc03bd59000
[ 122.168847] [000000e0] *pgd=00000000f24b1003, *pud=00000000f24b1003, *pmd=0000000000000000
[ 122.178632] CPU: 2 PID: 2857 Comm: compiz Not tainted 4.4.38-tegra #1
[ 122.185087] Hardware name: jetson_tx1 (DT)
[ 122.189181] task: ffffffc0726e8c80 ti: ffffffc04367c000 task.ti: ffffffc04367c000
[ 122.196658] PC is at 0x7f7c41b6e4
[ 122.199974] LR is at 0x7f7c41b678
[ 122.203279] pc : [<0000007f7c41b6e4>] lr : [<0000007f7c41b678>] pstate: 00000000
[ 122.210667] sp : 0000007fdc1ce980
[ 122.213979] x29: 0000007fdc1ce980 x28: 0000000000000000
[ 122.219304] x27: 0000007f765006c0 x26: 0000007f764f6000
[ 122.224630] x25: 0000007f7634db28 x24: 0000000000000000
[ 122.229951] x23: 0000007fdc1ce9c0 x22: 0000000000000000
[ 122.235271] x21: 0000007fdc1cea80 x20: 0000007f7c4ac000
[ 122.240602] x19: 0000000000000000 x18: 0000000000000014
[ 122.245922] x17: 0000007f7c41b630 x16: 0000007f764f9778
[ 122.251243] x15: 00000000000001db x14: 5f6c656e61705f74
[ 122.256572] x13: 6e6569646172675f x12: 656e696665722f73
[ 122.261894] x11: 6e6f63692f797469 x10: 6e752f6572616873
[ 122.267214] x9 : 0000000000f8f940 x8 : 0000007fdc1ce9c0
[ 122.272540] x7 : 0000000000000000 x6 : 0000000000000000
[ 122.277862] x5 : 0000007f853ae9b0 x4 : 00000000ffffffff
[ 122.283183] x3 : 0000000000000001 x2 : d97386226a260600
[ 122.288510] x1 : 0000000000000000 x0 : 0000000000000000
[ 122.295315] Library at 0x7f7c41b6e4: 0x7f7c3cf000 /usr/lib/aarch64-linux-gnu/libnux-graphics-4.0.so.0.8.0
[ 122.304871] Library at 0x7f7c41b678: 0x7f7c3cf000 /usr/lib/aarch64-linux-gnu/libnux-graphics-4.0.so.0.8.0
[ 122.314424] vdso base = 0x7f85683000
[ 123.450732] compiz[2871]: unhandled level 2 translation fault (11) at 0x000000e0, esr 0x92000006
[ 123.459548] pgd = ffffffc072417000
[ 123.462941] [000000e0] *pgd=00000000c3466003, *pud=00000000c3466003, *pmd=0000000000000000
[ 123.472792] CPU: 3 PID: 2871 Comm: compiz Not tainted 4.4.38-tegra #1
[ 123.479238] Hardware name: jetson_tx1 (DT)
[ 123.483338] task: ffffffc0726e8c80 ti: ffffffc0de3b0000 task.ti: ffffffc0de3b0000
[ 123.490812] PC is at 0x7f849476e4
[ 123.494125] LR is at 0x7f84947678
[ 123.497438] pc : [<0000007f849476e4>] lr : [<0000007f84947678>] pstate: 00000000
[ 123.504826] sp : 0000007fc17c3b60
[ 123.508138] x29: 0000007fc17c3b60 x28: 0000000000000000
[ 123.513462] x27: 0000007f7e6506c0 x26: 0000007f7e646000
[ 123.518783] x25: 0000007f7e49db28 x24: 0000000000000000
[ 123.524114] x23: 0000007fc17c3ba0 x22: 0000000000000000
[ 123.529434] x21: 0000007fc17c3c60 x20: 0000007f849d8000
[ 123.534754] x19: 0000000000000000 x18: 0000000000000014
[ 123.540081] x17: 0000007f84947630 x16: 0000007f7e649778
[ 123.545405] x15: 00000000000001db x14: 5f6c656e61705f74
[ 123.550726] x13: 6e6569646172675f x12: 656e696665722f73
[ 123.556054] x11: 6e6f63692f797469 x10: 6e752f6572616873
[ 123.561375] x9 : 0000000000fb1430 x8 : 0000007fc17c3ba0
[ 123.566701] x7 : 0000000000000000 x6 : 0000000000000000
[ 123.572028] x5 : 0000007f8d8e29b0 x4 : 00000000ffffffff
[ 123.577348] x3 : 0000000000000001 x2 : fee862413ef6d100
[ 123.582669] x1 : 0000000000000000 x0 : 0000000000000000
[ 123.589487] Library at 0x7f849476e4: 0x7f848fb000 /usr/lib/aarch64-linux-gnu/libnux-graphics-4.0.so.0.8.0
[ 123.599042] Library at 0x7f84947678: 0x7f848fb000 /usr/lib/aarch64-linux-gnu/libnux-graphics-4.0.so.0.8.0
[ 123.608598] vdso base = 0x7f8dbb7000
[ 124.735554] compiz[2884]: unhandled level 2 translation fault (11) at 0x000000e0, esr 0x92000006
[ 124.744338] pgd = ffffffc0de03e000
[ 124.747745] [000000e0] *pgd=000000015e0dd003, *pud=000000015e0dd003, *pmd=0000000000000000
[ 124.757550] CPU: 1 PID: 2884 Comm: compiz Not tainted 4.4.38-tegra #1
[ 124.763986] Hardware name: jetson_tx1 (DT)
[ 124.768082] task: ffffffc0de07be80 ti: ffffffc0436cc000 task.ti: ffffffc0436cc000
[ 124.775560] PC is at 0x7fa84686e4
[ 124.778864] LR is at 0x7fa8468678
[ 124.782178] pc : [<0000007fa84686e4>] lr : [<0000007fa8468678>] pstate: 00000000
[ 124.789563] sp : 0000007feb523110
[ 124.792875] x29: 0000007feb523110 x28: 0000000000000000
[ 124.798200] x27: 0000007fa25526c0 x26: 0000007fa2548000
[ 124.803527] x25: 0000007fa239fb28 x24: 0000000000000000
[ 124.808888] x23: 0000007feb523150 x22: 0000000000000000
[ 124.814225] x21: 0000007feb523210 x20: 0000007fa84f9000
[ 124.819558] x19: 0000000000000000 x18: 0000000000000014
[ 124.824880] x17: 0000007fa8468630 x16: 0000007fa254b778
[ 124.830201] x15: 00000000000001db x14: 5f6c656e61705f74
[ 124.835532] x13: 6e6569646172675f x12: 656e696665722f73
[ 124.840854] x11: 6e6f63692f797469 x10: 6e752f6572616873
[ 124.846175] x9 : 0000000000fb0f70 x8 : 0000007feb523150
[ 124.851502] x7 : 0000000000000000 x6 : 0000000000000000
[ 124.856825] x5 : 0000007fb13f89b0 x4 : 00000000ffffffff
[ 124.862145] x3 : 0000000000000001 x2 : 4d27577b9f839200
[ 124.867464] x1 : 0000000000000000 x0 : 0000000000000000
[ 124.874277] Library at 0x7fa84686e4: 0x7fa841c000 /usr/lib/aarch64-linux-gnu/libnux-graphics-4.0.so.0.8.0
[ 124.883833] Library at 0x7fa8468678: 0x7fa841c000 /usr/lib/aarch64-linux-gnu/libnux-graphics-4.0.so.0.8.0
[ 124.893386] vdso base = 0x7fb16cd000
[ 125.994571] compiz[2897]: unhandled level 2 translation fault (11) at 0x000000e0, esr 0x92000006
[ 126.003381] pgd = ffffffc03a1af000
[ 126.006804] [000000e0] *pgd=00000000fa229003, *pud=00000000fa229003, *pmd=0000000000000000
[ 126.016639] CPU: 2 PID: 2897 Comm: compiz Not tainted 4.4.38-tegra #1
[ 126.023075] Hardware name: jetson_tx1 (DT)
[ 126.027172] task: ffffffc0de07be80 ti: ffffffc0e5a2c000 task.ti: ffffffc0e5a2c000
[ 126.034646] PC is at 0x7f986f66e4
[ 126.037960] LR is at 0x7f986f6678
[ 126.041272] pc : [<0000007f986f66e4>] lr : [<0000007f986f6678>] pstate: 00000000
[ 126.048662] sp : 0000007fe5b1c450
[ 126.051974] x29: 0000007fe5b1c450 x28: 0000000000000000
[ 126.057299] x27: 0000007f93ffe6c0 x26: 0000007f93ff4000
[ 126.062621] x25: 0000007f93e4bb28 x24: 0000000000000000
[ 126.067951] x23: 0000007fe5b1c490 x22: 0000000000000000
[ 126.073273] x21: 0000007fe5b1c550 x20: 0000007f98787000
[ 126.078594] x19: 0000000000000000 x18: 0000000000000014
[ 126.083921] x17: 0000007f986f6630 x16: 0000007f93ff7778
[ 126.089244] x15: 00000000000001db x14: 5f6c656e61705f74
[ 126.094567] x13: 6e6569646172675f x12: 656e696665722f73
[ 126.099893] x11: 6e6f63692f797469 x10: 6e752f6572616873
[ 126.105213] x9 : 0000000000fbe1a0 x8 : 0000007fe5b1c490
[ 126.110538] x7 : 0000000000000000 x6 : 0000000000000000
[ 126.115864] x5 : 0000007fa30389b0 x4 : 00000000ffffffff
[ 126.121183] x3 : 0000000000000001 x2 : 65829b54271cc500
[ 126.126503] x1 : 0000000000000000 x0 : 0000000000000000
[ 126.133321] Library at 0x7f986f66e4: 0x7f986aa000 /usr/lib/aarch64-linux-gnu/libnux-graphics-4.0.so.0.8.0
[ 126.142876] Library at 0x7f986f6678: 0x7f986aa000 /usr/lib/aarch64-linux-gnu/libnux-graphics-4.0.so.0.8.0
[ 126.152432] vdso base = 0x7fa330d000
[ 127.334786] compiz[2910]: unhandled level 2 translation fault (11) at 0x000000e0, esr 0x92000006
[ 127.343576] pgd = ffffffc0f4a19000
[ 127.346967] [000000e0] *pgd=00000001683fe003, *pud=00000001683fe003, *pmd=0000000000000000
[ 127.356763] CPU: 2 PID: 2910 Comm: compiz Not tainted 4.4.38-tegra #1
[ 127.363219] Hardware name: jetson_tx1 (DT)
[ 127.367318] task: ffffffc0de2e8000 ti: ffffffc03beb0000 task.ti: ffffffc03beb0000
[ 127.374798] PC is at 0x7f7bea56e4
[ 127.378112] LR is at 0x7f7bea5678
[ 127.381426] pc : [<0000007f7bea56e4>] lr : [<0000007f7bea5678>] pstate: 00000000
[ 127.388813] sp : 0000007fdb4e81c0
[ 127.392129] x29: 0000007fdb4e81c0 x28: 0000000000000000
[ 127.397452] x27: 0000007f7b9486c0 x26: 0000007f7b93e000
[ 127.402773] x25: 0000007f7b795b28 x24: 0000000000000000
