Hello! I’m trying to connect Oculus Rift DK2 to Jetson TX2 through HDMI-0, but unfortunately it appears in two strange modes:
- 1080x1920 mode with incorrect colors and down-shifted screen https://ibb.co/mwKJ6G, and
- 1080x948 mode, where screen splits on two and duplicate on each "eye" https://ibb.co/gA3NYw
I have played with xrandr, tried to add new mode, but it have excepted with an error:
X Error of failed request: BadMatch (invalid parameter attributes)
Major opcode of failed request: 140 (RANDR)
Minor opcode of failed request: 18 (RRAddOutputMode)
Serial number of failed request: 20
Current serial number in output stream: 21
I’ve tried to change xgamma, there weren’t any results. I tried to edit EDID, and disable extensions flag (http://analogbit.com/2008/07/02/fixing-dvi-hdmi-displays-due-to-edid-bugs-on-nvidia/)
I’ve tried to use another nvidia driver (downgrade to 27.1.0 from last 28.1.0)
My system: I use last JetPack 3.1 (OS ver. 28.0.1), Ubuntu 16.04
My xorg.conf:
Section "Module"
Disable "dri"
SubSection "extmod"
Option "omit xfree86-dga"
EndSubSection
EndSection
Section "ServerLayout"
# could be RightOf, LeftOf, etc
Identifier "default"
Screen 0 "Screen0" 1920 0
# Screen 1 "Screen1" 1920 0
InputDevice "Keyboard0" "CoreKeyboard"
InputDevice "Mouse0" "CorePointer"
Option "Xinerama" "0"
EndSection
Section "InputDevice"
# generated from default
Identifier "Keyboard0"
Driver "kbd"
EndSection
Identifier "Mouse0"
Driver "mouse"
Option "Protocol" "auto"
Option "Device" "/dev/psaux"
Option "Emulate3Buttons" "no"
Option "ZAxisMapping" "4 5"
EndSection
Section "Monitor"
Identifier "Monitor0"
VendorName "OVR"
ModelName "Oculus VR Inc. Rift DK2"
HorizSync 30.0 - 150.0
VertRefresh 56.0 - 77.0
Option "UseEDID" "false"
Option "AllowEmptyInitialConfiguration"
Option "IgnoreEDID" "true"
DisplaySize 1080 1920
Gamma 2.20
Option "DPMS" "true"
# Modeline "Mode1920" 225.00 1080 1176 1288 1496 1920 1923 1933 2006 -hsync +vsync
Modeline "Mode1080" 220.75 1920 2064 2264 2608 1080 1083 1088 1130 -hsync +vsync
Option "PreferredMode" "Mode1080"
EndSection
Section "Device"
Identifier "Device0"
Driver "nvidia"
VendorName "NVIDIA Corporation"
# BoardName "GeForce GTX 780 Ti"
# BusID "PCI:1:0:0"
# Option "CustomEDID" "/etc/X11/edid_custom.bin"
Screen 0
EndSection
Section "Screen"
Identifier "Screen0"
Device "Device0"
Monitor "Monitor0"
DefaultDepth 24
Option "Stereo" "0"
Option "nvidiaXineramaInfoOrder" "DFP-0"
Option "metamodes" "HDMI-0: nvidia-auto-select +0+0 {rotation=left}; HDMI-0: 1080x1920_72 +0+0 {rotation=left}; HDMI-0: 1080x1920_60 +0+0 {rotation=left}; HDMI-0: 1080x948 +0+0 {rotation=left}; HDMI-0: nvidia-auto-select +0+0 {rotation=left, viewportin=768x1024, viewportout=1080x810+0+555}; HDMI-0: nvidia-auto-select +0+0 {rotation=left, viewportin=600x800, viewportout=1080x810+0+555}"
Option "SLI" "Off"
Option "MultiGPU" "Off"
Option "BaseMosaic" "off"
Option "ModeValidation" "AllowNonEdidModes, NoMaxPClkCheck, NoEdidMaxPClkCheck, NoMaxSizeCheck, NoHorizSyncCheck, NoVertRefreshCheck, NoVirtualSizeCheck, NoTotalSizeCheck, NoExtendedGpuCapabilitiesCheck"
SubSection "Display"
Depth 24
Virtual 1080 1920
EndSubSection
EndSection
My Xorg.0.log:
[ 8.446]
X.Org X Server 1.18.4
Release Date: 2016-07-19
[ 8.446] X Protocol Version 11, Revision 0
[ 8.446] Build Operating System: Linux 4.4.0-89-generic aarch64 Ubuntu
[ 8.446] Current Operating System: Linux tegra-ubuntu 4.4.38-tegra #1 SMP PREEMPT Thu Jul 20 00:49:07 PDT 2017 aarch64
[ 8.446] Kernel command line: root=/dev/mmcblk0p1 rw rootwait console=ttyS0,115200n8 console=tty0 OS=l4t fbcon=map:0 net.ifnames=0 memtype=0 video=tegrafb no_console_suspend=1 earlycon=uart8250,mmio32,0x03100000 nvdumper_reserved=0x2772e0000 gpt tegraid=18.1.2.0.0 tegra_keep_boot_clocks maxcpus=6 androidboot.serialno=0322717087289 bl_prof_dataptr=0x10000@0x277240000 sdhci_tegra.en_boot_part_access=1 root=/dev/mmcblk0p1 rw rootwait rootfstype=ext4
[ 8.446] Build Date: 09 August 2017 09:40:20PM
[ 8.446] xorg-server 2:1.18.4-0ubuntu0.4 (For technical support please see http://www.ubuntu.com/support)
[ 8.446] Current version of pixman: 0.33.6
[ 8.446] Before reporting problems, check http://wiki.x.org
to make sure that you have the latest version.
[ 8.446] Markers: (--) probed, (**) from config file, (==) default setting,
(++) from command line, (!!) notice, (II) informational,
(WW) warning, (EE) error, (NI) not implemented, (??) unknown.
[ 8.446] (==) Log file: "/var/log/Xorg.0.log", Time: Fri Oct 6 17:47:05 2017
[ 8.450] (==) Using config file: "/etc/X11/xorg.conf"
[ 8.450] (==) Using system config directory "/usr/share/X11/xorg.conf.d"
[ 8.452] (==) ServerLayout "default"
[ 8.452] (**) |-->Screen "Screen0" (0)
[ 8.452] (**) | |-->Monitor "Monitor0"
[ 8.452] (**) | |-->Device "Device0"
[ 8.453] (**) |-->Input Device "Keyboard0"
[ 8.453] (**) |-->Input Device "Mouse0"
[ 8.453] (**) Option "Xinerama" "0"
[ 8.453] (==) Automatically adding devices
[ 8.453] (==) Automatically enabling devices
[ 8.453] (==) Automatically adding GPU devices
[ 8.453] (==) Max clients allowed: 256, resource mask: 0x1fffff
[ 8.456] (WW) The directory "/usr/share/fonts/X11/cyrillic" does not exist.
[ 8.456] Entry deleted from font path.
[ 8.456] (WW) The directory "/usr/share/fonts/X11/100dpi/" does not exist.
[ 8.456] (WW) The directory "/usr/share/fonts/X11/75dpi/" does not exist.
[ 8.456] (WW) The directory "/usr/share/fonts/X11/100dpi" does not exist.
[ 8.456] (WW) The directory "/usr/share/fonts/X11/75dpi" does not exist.
[ 8.456] (==) FontPath set to:
/usr/share/fonts/X11/misc,
/usr/share/fonts/X11/Type1,
built-ins
[ 8.456] (==) ModulePath set to "/usr/lib/aarch64-linux-gnu/xorg/extra-modules,/usr/lib/xorg/extra-modules,/usr/lib/xorg/modules"
[ 8.456] (WW) Hotplugging is on, devices using drivers 'kbd', 'mouse' or 'vmmouse' will be disabled.
[ 8.456] (WW) Disabling Keyboard0
[ 8.456] (WW) Disabling Mouse0
[ 8.457] (II) Loader magic: 0x558de09d80
[ 8.457] (II) Module ABI versions:
[ 8.457] X.Org ANSI C Emulation: 0.4
[ 8.457] X.Org Video Driver: 20.0
[ 8.457] X.Org XInput driver : 22.1
[ 8.457] X.Org Server Extension : 9.0
[ 8.458] (++) using VT number 7
[ 8.458] (II) systemd-logind: logind integration requires -keeptty and -keeptty was not provided, disabling logind integration
[ 8.458] (II) no primary bus or device found
[ 8.458] (WW) "dri" will not be loaded unless you've specified it to be loaded elsewhere.
[ 8.458] (II) "glx" will be loaded by default.
[ 8.458] (II) LoadModule: "extmod"
[ 8.458] (II) Module "extmod" already built-in
[ 8.458] (II) LoadModule: "glx"
[ 8.461] (II) Loading /usr/lib/xorg/modules/extensions/libglx.so
[ 8.594] (II) Module glx: vendor="NVIDIA Corporation"
[ 8.594] compiled for 4.0.2, module version = 1.0.0
[ 8.594] Module class: X.Org Server Extension
[ 8.594] (II) NVIDIA GLX Module 28.1.0 Release Build (integ_stage_rel) (buildbrain@mobile-u64-553) Thu Jul 20 00:50:32 PDT 2017
[ 8.594] (II) LoadModule: "nvidia"
[ 8.595] (II) Loading /usr/lib/xorg/modules/drivers/nvidia_drv.so
[ 8.613] (II) Module nvidia: vendor="NVIDIA Corporation"
[ 8.613] compiled for 4.0.2, module version = 1.0.0
[ 8.613] Module class: X.Org Video Driver
[ 8.613] (II) NVIDIA dlloader X Driver 28.1.0 Release Build (integ_stage_rel) (buildbrain@mobile-u64-553) Thu Jul 20 00:51:56 PDT 2017
[ 8.613] (II) NVIDIA Unified Driver for all Supported NVIDIA GPUs
[ 8.616] (WW) Falling back to old probe method for NVIDIA
[ 8.616] (II) Loading sub module "fb"
[ 8.616] (II) LoadModule: "fb"
[ 8.616] (II) Loading /usr/lib/xorg/modules/libfb.so
[ 8.618] (II) Module fb: vendor="X.Org Foundation"
[ 8.618] compiled for 1.18.4, module version = 1.0.0
[ 8.618] ABI class: X.Org ANSI C Emulation, version 0.4
[ 8.618] (II) Loading sub module "wfb"
[ 8.618] (II) LoadModule: "wfb"
[ 8.620] (II) Loading /usr/lib/xorg/modules/libwfb.so
[ 8.622] (II) Module wfb: vendor="X.Org Foundation"
[ 8.622] compiled for 1.18.4, module version = 1.0.0
[ 8.622] ABI class: X.Org ANSI C Emulation, version 0.4
[ 8.622] (II) Loading sub module "ramdac"
[ 8.622] (II) LoadModule: "ramdac"
[ 8.623] (II) Module "ramdac" already built-in
[ 8.623] (WW) VGA arbiter: cannot open kernel arbiter, no multi-card support
[ 8.623] (**) NVIDIA(0): Depth 24, (--) framebuffer bpp 32
[ 8.623] (==) NVIDIA(0): RGB weight 888
[ 8.623] (==) NVIDIA(0): Default visual is TrueColor
[ 8.623] (**) NVIDIA(0): Using gamma correction (2.2, 2.2, 2.2)
[ 8.624] (**) NVIDIA(0): Option "Stereo" "0"
[ 8.624] (**) NVIDIA(0): Option "nvidiaXineramaInfoOrder" "DFP-0"
[ 8.624] (**) NVIDIA(0): Option "SLI" "Off"
[ 8.624] (**) NVIDIA(0): Option "MultiGPU" "Off"
[ 8.624] (**) NVIDIA(0): Option "ModeValidation" "AllowNonEdidModes, NoMaxPClkCheck, NoEdidMaxPClkCheck, NoMaxSizeCheck, NoHorizSyncCheck, NoVertRefreshCheck, NoVirtualSizeCheck, NoTotalSizeCheck, NoExtendedGpuCapabilitiesCheck"
[ 8.624] (**) NVIDIA(0): Option "BaseMosaic" "off"
[ 8.624] (**) NVIDIA(0): Option "AllowEmptyInitialConfiguration"
[ 8.624] (**) NVIDIA(0): Stereo disabled by request
[ 8.624] (**) NVIDIA(0): NVIDIA SLI disabled.
[ 8.624] (**) NVIDIA(0): NVIDIA Multi-GPU disabled.
[ 8.624] (**) NVIDIA(0): Option "UseEDID" "false"
[ 8.624] (**) NVIDIA(0): Option "MetaModes" "HDMI-0: nvidia-auto-select +0+0 {rotation=left}; HDMI-0: 1080x1920_72 +0+0 {rotation=left}; HDMI-0: 1080x1920_60 +0+0 {rotation=left}; HDMI-0: 1080x948 +0+0 {rotation=left}; HDMI-0: nvidia-auto-select +0+0 {rotation=left, viewportin=768x1024, viewportout=1080x810+0+555}; HDMI-0: nvidia-auto-select +0+0 {rotation=left, viewportin=600x800, viewportout=1080x810+0+555}"
[ 8.624] (**) NVIDIA(0): Enabling 2D acceleration
[ 8.624] (**) NVIDIA(0): Ignoring EDIDs
[ 8.625] (--) NVIDIA(0): Valid display device(s) on GPU-0 at SoC
[ 8.625] (--) NVIDIA(0): DFP-0
[ 8.625] (II) NVIDIA(0): NVIDIA GPU NVIDIA Tegra X2 (nvgpu) (GP10B) at SoC (GPU-0)
[ 8.625] (--) NVIDIA(0): Memory: 8039124 kBytes
[ 8.625] (--) NVIDIA(0): VideoBIOS:
[ 8.625] (WW) NVIDIA(0): No valid modes for
[ 8.625] (WW) NVIDIA(0): "HDMI-0:nvidia-auto-select+0+0{rotation=left}"; removing.
[ 8.625] (WW) NVIDIA(0): No valid modes for "HDMI-0:1080x1920_72+0+0{rotation=left}";
[ 8.625] (WW) NVIDIA(0): removing.
[ 8.625] (WW) NVIDIA(0): No valid modes for "HDMI-0:1080x1920_60+0+0{rotation=left}";
[ 8.625] (WW) NVIDIA(0): No valid modes for "HDMI-0:1080x948+0+0{rotation=left}";
[ 8.625] (WW) NVIDIA(0): "HDMI-0:nvidia-auto-select+0+0{rotation=left,viewportin=768x1024,viewportout=1080x810+0+555}";
[ 8.625] (WW) NVIDIA(0): "HDMI-0:nvidia-auto-select+0+0{rotation=left,viewportin=600x800,viewportout=1080x810+0+555}";
[ 8.625] (WW) NVIDIA(0): Unable to validate any modes; falling back to the default mode
[ 8.625] (WW) NVIDIA(0): "nvidia-auto-select".
[ 8.626] (--) NVIDIA(0): No enabled display devices found; starting anyway because
[ 8.626] (--) NVIDIA(0): AllowEmptyInitialConfiguration is enabled
[ 8.626] (II) NVIDIA(0): Validated MetaModes:
[ 8.626] (II) NVIDIA(0): "NULL"
[ 8.626] (**) NVIDIA(0): Virtual screen size configured to be 1080 x 1920
[ 8.626] (WW) NVIDIA(0): Unable to get display device for DPI computation.
[ 8.626] (**) NVIDIA(0): DPI set to (25, 25); computed from "DisplaySize" Monitor
[ 8.626] (**) NVIDIA(0): section option
[ 8.626] (--) Depth 24 pixmap format is 32 bpp
[ 8.626] (II) NVIDIA: Reserving 49152.00 MB of virtual memory for indirect memory
[ 8.626] (II) NVIDIA: access.
[ 8.630] (EE) NVIDIA(0): Failed to allocate NVIDIA Error Handler
[ 8.630] (II) NVIDIA(0): ACPI: failed to connect to the ACPI event daemon; the daemon
[ 8.630] (II) NVIDIA(0): may not be running or the "AcpidSocketPath" X
[ 8.630] (II) NVIDIA(0): configuration option may not be set correctly. When the
[ 8.630] (II) NVIDIA(0): ACPI event daemon is available, the NVIDIA X driver will
[ 8.630] (II) NVIDIA(0): try to use it to receive ACPI event notifications. For
[ 8.630] (II) NVIDIA(0): details, please see the "ConnectToAcpid" and
[ 8.630] (II) NVIDIA(0): "AcpidSocketPath" X configuration options in Appendix B: X
[ 8.630] (II) NVIDIA(0): Config Options in the README.
[ 8.667] (II) NVIDIA(0): Setting mode "NULL"
[ 8.671] (==) NVIDIA(0): Disabling shared memory pixmaps
[ 8.671] (==) NVIDIA(0): Backing store enabled
[ 8.671] (==) NVIDIA(0): Silken mouse enabled
[ 8.676] (**) NVIDIA(0): DPMS enabled
[ 8.676] (WW) NVIDIA(0): Option "IgnoreEDID" is not used
[ 8.676] (WW) NVIDIA(0): Option "PreferredMode" is not used
[ 8.676] (II) Loading sub module "dri2"
[ 8.676] (II) LoadModule: "dri2"
[ 8.676] (II) Module "dri2" already built-in
[ 8.676] (II) NVIDIA(0): [DRI2] Setup complete
[ 8.676] (II) NVIDIA(0): [DRI2] VDPAU driver: nvidia
[ 8.676] (--) RandR disabled
[ 8.684] (II) SELinux: Disabled on system
[ 8.685] (II) Initializing extension GLX
[ 8.685] (II) Indirect GLX disabled.
[ 8.796] (II) config/udev: Adding input device tegra-hda HDMI/DP,pcm=3 (/dev/input/event0)
[ 8.797] (II) No input driver specified, ignoring this device.
[ 8.797] (II) This device may have been added with another device file.
[ 8.797] (II) config/udev: Adding input device tegra-hda HDMI/DP,pcm=7 (/dev/input/event1)
[ 8.798] (II) config/udev: Adding input device gpio-keys (/dev/input/event3)
[ 8.798] (**) gpio-keys: Applying InputClass "evdev keyboard catchall"
[ 8.798] (II) LoadModule: "evdev"
[ 8.798] (II) Loading /usr/lib/xorg/modules/input/evdev_drv.so
[ 8.802] (II) Module evdev: vendor="X.Org Foundation"
[ 8.802] compiled for 1.18.1, module version = 2.10.1
[ 8.802] Module class: X.Org XInput Driver
[ 8.802] ABI class: X.Org XInput driver, version 22.1
[ 8.802] (II) Using input driver 'evdev' for 'gpio-keys'
[ 8.802] (**) gpio-keys: always reports core events
[ 8.802] (**) evdev: gpio-keys: Device: "/dev/input/event3"
[ 8.802] (--) evdev: gpio-keys: Vendor 0x1 Product 0x1
[ 8.802] (--) evdev: gpio-keys: Found keys
[ 8.802] (II) evdev: gpio-keys: Configuring as keyboard
[ 8.802] (**) Option "config_info" "udev:/sys/devices/gpio-keys/input/input3/event3"
[ 8.802] (II) XINPUT: Adding extended input device "gpio-keys" (type: KEYBOARD, id 6)
[ 8.802] (**) Option "xkb_rules" "evdev"
[ 8.802] (**) Option "xkb_model" "pc105"
[ 8.802] (**) Option "xkb_layout" "us"
[ 8.804] (II) config/udev: Adding input device tegra-snd-t186ref-mobile-rt565x Headphone Jack (/dev/input/event2)
[ 8.804] (**) tegra-snd-t186ref-mobile-rt565x Headphone Jack: Applying InputClass "evdev keyboard catchall"
[ 8.804] (II) Using input driver 'evdev' for 'tegra-snd-t186ref-mobile-rt565x Headphone Jack'
[ 8.804] (**) tegra-snd-t186ref-mobile-rt565x Headphone Jack: always reports core events
[ 8.804] (**) evdev: tegra-snd-t186ref-mobile-rt565x Headphone Jack: Device: "/dev/input/event2"
[ 8.804] (--) evdev: tegra-snd-t186ref-mobile-rt565x Headphone Jack: Vendor 0 Product 0
[ 8.804] (--) evdev: tegra-snd-t186ref-mobile-rt565x Headphone Jack: Found keys
[ 8.804] (II) evdev: tegra-snd-t186ref-mobile-rt565x Headphone Jack: Configuring as keyboard
[ 8.804] (**) Option "config_info" "udev:/sys/devices/sound/sound/card1/input2/event2"
[ 8.804] (II) XINPUT: Adding extended input device "tegra-snd-t186ref-mobile-rt565x Headphone Jack" (type: KEYBOARD, id 7)
[ 8.805] (**) Option "xkb_rules" "evdev"
[ 8.805] (**) Option "xkb_model" "pc105"
[ 8.805] (**) Option "xkb_layout" "us"
[ 11.732] (II) config/udev: Adding input device SIGMACHIP USB Keyboard (/dev/input/event5)
[ 11.732] (**) SIGMACHIP USB Keyboard: Applying InputClass "evdev keyboard catchall"
[ 11.732] (II) Using input driver 'evdev' for 'SIGMACHIP USB Keyboard'
[ 11.732] (**) SIGMACHIP USB Keyboard: always reports core events
[ 11.732] (**) evdev: SIGMACHIP USB Keyboard: Device: "/dev/input/event5"
[ 11.732] (--) evdev: SIGMACHIP USB Keyboard: Vendor 0x1c4f Product 0x2
[ 11.732] (--) evdev: SIGMACHIP USB Keyboard: Found 1 mouse buttons
[ 11.732] (--) evdev: SIGMACHIP USB Keyboard: Found scroll wheel(s)
[ 11.732] (--) evdev: SIGMACHIP USB Keyboard: Found relative axes
[ 11.732] (II) evdev: SIGMACHIP USB Keyboard: Forcing relative x/y axes to exist.
[ 11.733] (--) evdev: SIGMACHIP USB Keyboard: Found absolute axes
[ 11.733] (II) evdev: SIGMACHIP USB Keyboard: Forcing absolute x/y axes to exist.
[ 11.733] (--) evdev: SIGMACHIP USB Keyboard: Found keys
[ 11.733] (II) evdev: SIGMACHIP USB Keyboard: Configuring as mouse
[ 11.733] (II) evdev: SIGMACHIP USB Keyboard: Configuring as keyboard
[ 11.733] (II) evdev: SIGMACHIP USB Keyboard: Adding scrollwheel support
[ 11.733] (**) evdev: SIGMACHIP USB Keyboard: YAxisMapping: buttons 4 and 5
[ 11.733] (**) evdev: SIGMACHIP USB Keyboard: EmulateWheelButton: 4, EmulateWheelInertia: 10, EmulateWheelTimeout: 200
[ 11.733] (**) Option "config_info" "udev:/sys/devices/3530000.xhci/usb1/1-1/1-1:1.1/0003:1C4F:0002.0002/input/input5/event5"
[ 11.733] (II) XINPUT: Adding extended input device "SIGMACHIP USB Keyboard" (type: KEYBOARD, id 8)
[ 11.733] (**) Option "xkb_rules" "evdev"
[ 11.733] (**) Option "xkb_model" "pc105"
[ 11.733] (**) Option "xkb_layout" "us"
[ 11.733] (WW) Option "xkb_variant" requires a string value
[ 11.733] (WW) Option "xkb_options" requires a string value
[ 11.733] (II) evdev: SIGMACHIP USB Keyboard: initialized for relative axes.
[ 11.733] (WW) evdev: SIGMACHIP USB Keyboard: ignoring absolute axes.
[ 11.734] (**) SIGMACHIP USB Keyboard: (accel) keeping acceleration scheme 1
[ 11.734] (**) SIGMACHIP USB Keyboard: (accel) acceleration profile 0
[ 11.734] (**) SIGMACHIP USB Keyboard: (accel) acceleration factor: 2.000
[ 11.734] (**) SIGMACHIP USB Keyboard: (accel) acceleration threshold: 4
[ 11.752] (II) config/udev: Adding input device SIGMACHIP USB Keyboard (/dev/input/event4)
[ 11.753] (**) SIGMACHIP USB Keyboard: Applying InputClass "evdev keyboard catchall"
[ 11.753] (II) Using input driver 'evdev' for 'SIGMACHIP USB Keyboard'
[ 11.753] (**) SIGMACHIP USB Keyboard: always reports core events
[ 11.753] (**) evdev: SIGMACHIP USB Keyboard: Device: "/dev/input/event4"
[ 11.753] (--) evdev: SIGMACHIP USB Keyboard: Vendor 0x1c4f Product 0x2
[ 11.753] (--) evdev: SIGMACHIP USB Keyboard: Found keys
[ 11.753] (II) evdev: SIGMACHIP USB Keyboard: Configuring as keyboard
[ 11.753] (**) Option "config_info" "udev:/sys/devices/3530000.xhci/usb1/1-1/1-1:1.0/0003:1C4F:0002.0001/input/input4/event4"
[ 11.753] (II) XINPUT: Adding extended input device "SIGMACHIP USB Keyboard" (type: KEYBOARD, id 9)
[ 11.753] (**) Option "xkb_rules" "evdev"
[ 11.753] (**) Option "xkb_model" "pc105"
[ 11.753] (**) Option "xkb_layout" "us"
[ 11.753] (WW) Option "xkb_variant" requires a string value
[ 11.753] (WW) Option "xkb_options" requires a string value
[ 11.804] (II) config/udev: Adding input device HD Pro Webcam C920 (/dev/input/event7)
[ 11.805] (**) HD Pro Webcam C920: Applying InputClass "evdev keyboard catchall"
[ 11.805] (II) Using input driver 'evdev' for 'HD Pro Webcam C920'
[ 11.805] (**) HD Pro Webcam C920: always reports core events
[ 11.805] (**) evdev: HD Pro Webcam C920: Device: "/dev/input/event7"
[ 11.805] (--) evdev: HD Pro Webcam C920: Vendor 0x46d Product 0x82d
[ 11.805] (--) evdev: HD Pro Webcam C920: Found keys
[ 11.805] (II) evdev: HD Pro Webcam C920: Configuring as keyboard
[ 11.805] (**) Option "config_info" "udev:/sys/devices/3530000.xhci/usb1/1-2/1-2.3/1-2.3:1.0/input/input7/event7"
[ 11.805] (II) XINPUT: Adding extended input device "HD Pro Webcam C920" (type: KEYBOARD, id 10)
[ 11.805] (**) Option "xkb_rules" "evdev"
[ 11.805] (**) Option "xkb_model" "pc105"
[ 11.805] (**) Option "xkb_layout" "us"
[ 11.805] (WW) Option "xkb_variant" requires a string value
[ 11.805] (WW) Option "xkb_options" requires a string value
[ 11.966] (II) config/udev: Adding input device HD Pro Webcam C920 (/dev/input/event6)
[ 11.967] (**) HD Pro Webcam C920: Applying InputClass "evdev keyboard catchall"
[ 11.967] (II) Using input driver 'evdev' for 'HD Pro Webcam C920'
[ 11.967] (**) HD Pro Webcam C920: always reports core events
[ 11.967] (**) evdev: HD Pro Webcam C920: Device: "/dev/input/event6"
[ 11.967] (--) evdev: HD Pro Webcam C920: Vendor 0x46d Product 0x82d
[ 11.967] (--) evdev: HD Pro Webcam C920: Found keys
[ 11.967] (II) evdev: HD Pro Webcam C920: Configuring as keyboard
[ 11.967] (**) Option "config_info" "udev:/sys/devices/3530000.xhci/usb1/1-2/1-2.1/1-2.1:1.0/input/input6/event6"
[ 11.967] (II) XINPUT: Adding extended input device "HD Pro Webcam C920" (type: KEYBOARD, id 11)
[ 11.968] (**) Option "xkb_rules" "evdev"
[ 11.968] (**) Option "xkb_model" "pc105"
[ 11.968] (**) Option "xkb_layout" "us"
[ 11.968] (WW) Option "xkb_variant" requires a string value
[ 11.968] (WW) Option "xkb_options" requires a string value
[ 12.548] (WW) NVIDIA(GPU-0): Unrecognized ModeValidation token "AllowNonEdidModes";
[ 12.548] (WW) NVIDIA(GPU-0): ignoring.
[ 12.548] (WW) NVIDIA(GPU-0): Unrecognized ModeValidation token "NoMaxPClkCheck"; ignoring.
[ 12.548] (WW) NVIDIA(GPU-0): Unrecognized ModeValidation token "NoEdidMaxPClkCheck";
[ 12.548] (WW) NVIDIA(GPU-0): Unrecognized ModeValidation token "NoHorizSyncCheck";
[ 12.548] (WW) NVIDIA(GPU-0): Unrecognized ModeValidation token "NoVertRefreshCheck";
[ 12.548] (WW) NVIDIA(GPU-0): Unrecognized ModeValidation token "NoTotalSizeCheck";
[ 12.548] (WW) NVIDIA(GPU-0): "NoExtendedGpuCapabilitiesCheck"; ignoring.
[ 12.548] (**) NVIDIA(GPU-0): Mode Validation Overrides for Oculus VR Inc. Rift DK2
[ 12.548] (**) NVIDIA(GPU-0): (DFP-0):
[ 12.548] (**) NVIDIA(GPU-0): NoMaxSizeCheck
[ 12.548] (**) NVIDIA(GPU-0): NoVirtualSizeCheck
[ 12.553] (--) NVIDIA(GPU-0): Oculus VR Inc. Rift DK2 (DFP-0): connected
[ 12.553] (--) NVIDIA(GPU-0): Oculus VR Inc. Rift DK2 (DFP-0): External TMDS
[ 12.553] (II) NVIDIA(0): Setting mode "NULL"
[ 12.581] (II) NVIDIA(0): Setting mode "HDMI-0: nvidia-auto-select @1080x1920 +0+0 {ViewPortIn=1080x1920, ViewPortOut=1080x1920+0+0}"
[ 13.705] (--) NVIDIA(GPU-0): Oculus VR Inc. Rift DK2 (DFP-0): connected
[ 13.705] (--) NVIDIA(GPU-0): Oculus VR Inc. Rift DK2 (DFP-0): External TMDS
[ 129.387] (--) NVIDIA(GPU-0): Oculus VR Inc. Rift DK2 (DFP-0): connected
[ 129.387] (--) NVIDIA(GPU-0): Oculus VR Inc. Rift DK2 (DFP-0): External TMDS
[ 129.667] (II) NVIDIA(0): Setting mode "NULL"
[ 129.776] (II) NVIDIA(0): Setting mode "HDMI-0: 1080x948 @948x1080 +0+0 {ViewPortIn=948x1080, ViewPortOut=1080x948+0+0, Rotation=90}"
[ 131.213] (--) NVIDIA(GPU-0): Oculus VR Inc. Rift DK2 (DFP-0): connected
[ 131.213] (--) NVIDIA(GPU-0): Oculus VR Inc. Rift DK2 (DFP-0): External TMDS
[ 133.012] (--) NVIDIA(GPU-0): Oculus VR Inc. Rift DK2 (DFP-0): connected
[ 133.013] (--) NVIDIA(GPU-0): Oculus VR Inc. Rift DK2 (DFP-0): External TMDS
