Using Ubuntu 14.04 with updated packages
-Browsing with Firefox
-Keyboard: Logitech K260
Suddenly Keyboard input is no more working, mouse pointer continues to move,
but mouse clicks gives no response
[ 16.218]
X.Org X Server 1.15.1
Release Date: 2014-04-13
[ 16.219] X Protocol Version 11, Revision 0
[ 16.219] Build Operating System: Linux 3.2.0-58-highbank armv7l Ubuntu
[ 16.220] Current Operating System: Linux tegra-ubuntu 3.10.24-g6a2d13a #1 SMP PREEMPT Fri Apr 18 15:56:45 PDT 2014 armv7l
[ 16.220] Kernel command line: fbcon=map:1 tegraid=40.1.1.0.0 mem=1862M@2048M memtype=255 vpr=151M@3945M tsec=32M@3913M otf_key=7fc9294863965fd002be52107486ce25 ddr_die=2048M@2048M section=256M commchip_id=0 usb_port_owner_info=0 lane_owner_info=6 emc_max_dvfs=0 touch_id=0@0 video=tegrafb no_console_suspend=1 console=ttyS0,115200n8 debug_uartport=lsport,3 console=tty1 usbcore.old_scheme_first=1 lp0_vec=2064@0xf46ff000 tegra_fbmem=32899072@0xad012000 core_edp_mv=1150 core_edp_ma=4000 pmuboard=0x0177:0x0000:0x03:0x45:0x00 power_supply=Adapter audio_codec=rt5640 board_info=0x0177:0x0000:0x03:0x45:0x00 root=/dev/mmcblk0p1 rw rootwait tegraboot=sdmmc gpt gpt_sector=49151 modem_id=0 android.kerneltype=normal
[ 16.221] Build Date: 16 April 2014 01:41:53PM
[ 16.221] xorg-server 2:1.15.1-0ubuntu2 (For technical support please see http://www.ubuntu.com/support)
[ 16.221] Current version of pixman: 0.30.2
[ 16.222] Before reporting problems, check http://wiki.x.org
to make sure that you have the latest version.
[ 16.222] Markers: (–) probed, () from config file, (==) default setting,
(++) from command line, (!!) notice, (II) informational,
(WW) warning, (EE) error, (NI) not implemented, (??) unknown.
[ 16.224] (==) Log file: “/var/log/Xorg.0.log”, Time: Tue Feb 1 01:02:23 2000
[ 16.232] (==) Using config file: “/etc/X11/xorg.conf”
[ 16.232] (==) Using system config directory “/usr/share/X11/xorg.conf.d”
[ 16.241] (==) No Layout section. Using the first Screen section.
[ 16.241] (==) No screen section available. Using defaults.
[ 16.241] () |–>Screen “Default Screen Section” (0)
[ 16.242] () | |–>Monitor “”
[ 16.244] (==) No device specified for screen “Default Screen Section”.
Using the first device section listed.
[ 16.244] () | |–>Device “Tegra0”
[ 16.244] (==) No monitor specified for screen “Default Screen Section”.
Using a default monitor configuration.
[ 16.245] (==) Automatically adding devices
[ 16.245] (==) Automatically enabling devices
[ 16.245] (==) Automatically adding GPU devices
[ 16.254] (WW) The directory “/usr/share/fonts/X11/cyrillic” does not exist.
[ 16.254] Entry deleted from font path.
[ 16.255] (WW) The directory “/usr/share/fonts/X11/100dpi/” does not exist.
[ 16.255] Entry deleted from font path.
[ 16.255] (WW) The directory “/usr/share/fonts/X11/75dpi/” does not exist.
[ 16.256] (WW) The directory “/usr/share/fonts/X11/100dpi” does not exist.
[ 16.257] Entry deleted from font path.
[ 16.257] (WW) The directory “/usr/share/fonts/X11/75dpi” does not exist.
[ 16.257] (==) FontPath set to:
/usr/share/fonts/X11/misc,
/usr/share/fonts/X11/Type1,
built-ins
[ 16.257] (==) ModulePath set to “/usr/lib/arm-linux-gnueabihf/xorg/extra-modules,/usr/lib/xorg/extra-modules,/usr/lib/xorg/modules”
[ 16.257] (II) The server relies on udev to provide the list of input devices.
If no devices become available, reconfigure udev or disable AutoAddDevices.
[ 16.258] (II) Loader magic: 0xb67f5f18
[ 16.258] (II) Module ABI versions:
[ 16.258] X.Org ANSI C Emulation: 0.4
[ 16.258] X.Org Video Driver: 15.0
[ 16.258] X.Org XInput driver : 20.0
[ 16.258] X.Org Server Extension : 8.0
[ 16.261] Initializing built-in extension Generic Event Extension
[ 16.261] Initializing built-in extension SHAPE
[ 16.261] Initializing built-in extension MIT-SHM
[ 16.262] Initializing built-in extension XInputExtension
[ 16.262] Initializing built-in extension XTEST
[ 16.262] Initializing built-in extension BIG-REQUESTS
[ 16.262] Initializing built-in extension SYNC
[ 16.262] Initializing built-in extension XKEYBOARD
[ 16.263] Initializing built-in extension XC-MISC
[ 16.263] Initializing built-in extension SECURITY
[ 16.263] Initializing built-in extension XINERAMA
[ 16.263] Initializing built-in extension XFIXES
[ 16.263] Initializing built-in extension RENDER
[ 16.264] Initializing built-in extension RANDR
[ 16.264] Initializing built-in extension COMPOSITE
[ 16.265] Initializing built-in extension DAMAGE
[ 16.265] Initializing built-in extension MIT-SCREEN-SAVER
[ 16.265] Initializing built-in extension DOUBLE-BUFFER
[ 16.265] Initializing built-in extension RECORD
[ 16.265] Initializing built-in extension DPMS
[ 16.265] Initializing built-in extension Present
[ 16.266] Initializing built-in extension DRI3
[ 16.266] Initializing built-in extension X-Resource
[ 16.266] Initializing built-in extension XVideo
[ 16.266] Initializing built-in extension XVideo-MotionCompensation
[ 16.266] Initializing built-in extension SELinux
[ 16.267] Initializing built-in extension XFree86-VidModeExtension
[ 16.267] Initializing built-in extension XFree86-DGA
[ 16.267] Initializing built-in extension XFree86-DRI
[ 16.267] Initializing built-in extension DRI2
[ 16.267] (WW) “dri” will not be loaded unless you’ve specified it to be loaded elsewhere.
[ 16.267] (II) “glx” will be loaded by default.
[ 16.267] (WW) “xmir” is not to be loaded by default. Skipping.
[ 16.267] (II) LoadModule: “extmod”
[ 16.269] (II) Module “extmod” already built-in
[ 16.269] (II) LoadModule: “glx”
[ 16.282] (II) Loading /usr/lib/xorg/modules/extensions/libglx.so
[ 16.658] (II) Module glx: vendor=“NVIDIA Corporation”
[ 16.659] compiled for 4.0.2, module version = 1.0.0
[ 16.659] Module class: X.Org Server Extension
[ 16.659] (II) NVIDIA GLX Module 19.2 Release Build (integ_stage_rel) (buildbrain@mobile-u64-389) Fri Apr 18 15:58:11 PDT 2014
[ 16.659] Loading extension GLX
[ 16.659] (II) LoadModule: “nvidia”
[ 16.661] (II) Loading /usr/lib/xorg/modules/drivers/nvidia_drv.so
[ 16.705] (II) Module nvidia: vendor=“NVIDIA Corporation”
[ 16.705] compiled for 4.0.2, module version = 1.0.0
[ 16.706] Module class: X.Org Video Driver
[ 16.727] (II) NVIDIA dlloader X Driver 19.2 Release Build (integ_stage_rel) (buildbrain@mobile-u64-389) Fri Apr 18 15:58:47 PDT 2014
[ 16.727] (II) NVIDIA Unified Driver for all Supported NVIDIA GPUs
[ 16.727] (++) using VT number 7
[ 16.833] (WW) Falling back to old probe method for NVIDIA
[ 16.834] (II) Loading sub module “fb”
[ 16.834] (II) LoadModule: “fb”
[ 16.835] (II) Loading /usr/lib/xorg/modules/libfb.so
[ 16.840] (II) Module fb: vendor=“X.Org Foundation”
[ 16.840] compiled for 1.15.1, module version = 1.0.0
[ 16.840] ABI class: X.Org ANSI C Emulation, version 0.4
[ 16.841] (WW) Unresolved symbol: fbGetGCPrivateKey
[ 16.841] (II) Loading sub module “wfb”
[ 16.841] (II) LoadModule: “wfb”
[ 16.842] (II) Loading /usr/lib/xorg/modules/libwfb.so
[ 16.846] (II) Module wfb: vendor=“X.Org Foundation”
[ 16.846] compiled for 1.15.1, module version = 1.0.0
[ 16.846] ABI class: X.Org ANSI C Emulation, version 0.4
[ 16.847] (II) Loading sub module “ramdac”
[ 16.847] (II) LoadModule: “ramdac”
[ 16.847] (II) Module “ramdac” already built-in
[ 16.854] (II) NVIDIA(0): Creating default Display subsection in Screen section
“Default Screen Section” for depth/fbbpp 24/32
[ 16.854] (==) NVIDIA(0): Depth 24, (==) framebuffer bpp 32
[ 16.854] (==) NVIDIA(0): RGB weight 888
[ 16.854] (==) NVIDIA(0): Default visual is TrueColor
[ 16.854] (==) NVIDIA(0): Using gamma correction (1.0, 1.0, 1.0)
[ 16.855] () NVIDIA(0): Enabling 2D acceleration
[ 17.030] (II) NVIDIA(0): NVIDIA GPU GK20A (GK20A) at SoC (GPU-0)
[ 17.030] (–) NVIDIA(0): Memory: 1048576 kBytes
[ 17.030] (–) NVIDIA(0): VideoBIOS:
[ 17.030] (–) NVIDIA(0): Valid display device(s) on GK20A at SoC
[ 17.030] (–) NVIDIA(0): DFP-0 (connected)
[ 17.030] (–) NVIDIA(0): DFP-1 (connected)
[ 17.031] (–) NVIDIA(0): DFP-0: Internal Single Link TMDS
[ 17.031] (–) NVIDIA(0): DFP-1: Internal Single Link TMDS
[ 17.031] () NVIDIA(0): Option “Ignore”
[ 17.031] () NVIDIA(0): Ignoring display device DFP-0
[ 17.032] () NVIDIA(0): Using HorizSync/VertRefresh ranges from the EDID for display
[ 17.032] () NVIDIA(0): device DFP-1 (Using EDID frequencies has been enabled on
[ 17.032] () NVIDIA(0): all display devices.)
[ 17.034] (==) NVIDIA(0):
[ 17.034] (==) NVIDIA(0): No modes were requested; the default mode “nvidia-auto-select”
[ 17.034] (==) NVIDIA(0): will be used as the requested mode.
[ 17.035] (==) NVIDIA(0):
[ 17.035] (II) NVIDIA(0): Validated MetaModes:
[ 17.035] (II) NVIDIA(0): “DFP-1:nvidia-auto-select”
[ 17.035] (II) NVIDIA(0): Virtual screen size determined to be 1920 x 1080
[ 17.042] (WW) NVIDIA(0): Unable to support custom viewPortOut 1920 x 1079 +0 +0
[ 17.044] (WW) NVIDIA(0): Unable to support custom viewPortOut 1728 x 1080 +96 +0
[ 17.045] (WW) NVIDIA(0): Unable to support custom viewPortOut 1920 x 1080 +0 +0
[ 17.047] (WW) NVIDIA(0): Unable to get display device DFP-1’s EDID; cannot compute DPI
[ 17.047] (WW) NVIDIA(0): from DFP-1’s EDID.
[ 17.047] (==) NVIDIA(0): DPI set to (75, 75); computed from built-in default
[ 17.047] (–) Depth 24 pixmap format is 32 bpp
[ 17.057] (WW) NVIDIA(GPU-0): Failed to enter interactive mode.
[ 17.120] (EE) NVIDIA(0): Failed to allocate NVIDIA Error Handler
[ 17.121] (II) NVIDIA(0): ACPI: failed to connect to the ACPI event daemon; the daemon
[ 17.121] (II) NVIDIA(0): may not be running or the “AcpidSocketPath” X
[ 17.121] (II) NVIDIA(0): configuration option may not be set correctly. When the
[ 17.121] (II) NVIDIA(0): ACPI event daemon is available, the NVIDIA X driver will
[ 17.121] (II) NVIDIA(0): try to use it to receive ACPI event notifications. For
[ 17.121] (II) NVIDIA(0): details, please see the “ConnectToAcpid” and
[ 17.121] (II) NVIDIA(0): “AcpidSocketPath” X configuration options in Appendix B: X
[ 17.121] (II) NVIDIA(0): Config Options in the README.
[ 17.122] (II) NVIDIA(0): Setting mode “DFP-1:nvidia-auto-select”
[ 17.317] Loading extension NV-GLX
[ 17.342] (==) NVIDIA(0): Disabling shared memory pixmaps
[ 17.342] (==) NVIDIA(0): Backing store enabled
[ 17.343] (==) NVIDIA(0): Silken mouse enabled
[ 17.361] (==) NVIDIA(0): DPMS enabled
[ 17.362] Loading extension NV-CONTROL
[ 17.386] (EE) NVIDIA(0): Failed to allocate NVIDIA Damage Manager
[ 17.386] Loading extension XINERAMA
[ 17.386] (II) Loading sub module “dri2”
[ 17.387] (II) LoadModule: “dri2”
[ 17.387] (II) Module “dri2” already built-in
[ 17.387] (II) NVIDIA(0): [DRI2] Setup complete
[ 17.387] (II) NVIDIA(0): [DRI2] VDPAU driver: nvidia
[ 17.388] (–) RandR disabled
[ 17.493] (II) SELinux: Disabled on system
[ 17.506] (II) Initializing extension GLX
[ 17.644] (II) XKB: reuse xkmfile /var/lib/xkb/server-B20D7FC79C7F597315E3E501AEF10E0D866E8E92.xkm
[ 17.683] (II) config/udev: Adding input device gpio-keys.2 (/dev/input/event3)
[ 17.684] () gpio-keys.2: Applying InputClass “evdev keyboard catchall”
[ 17.684] (II) LoadModule: “evdev”
[ 17.685] (II) Loading /usr/lib/xorg/modules/input/evdev_drv.so
[ 17.691] (II) Module evdev: vendor=“X.Org Foundation”
[ 17.691] compiled for 1.15.0, module version = 2.8.2
[ 17.691] Module class: X.Org XInput Driver
[ 17.691] ABI class: X.Org XInput driver, version 20.0
[ 17.692] (II) Using input driver ‘evdev’ for ‘gpio-keys.2’
[ 17.692] () gpio-keys.2: always reports core events
[ 17.692] () evdev: gpio-keys.2: Device: “/dev/input/event3”
[ 17.692] (–) evdev: gpio-keys.2: Vendor 0x1 Product 0x1
[ 17.692] (–) evdev: gpio-keys.2: Found keys
[ 17.692] (II) evdev: gpio-keys.2: Configuring as keyboard
[ 17.693] () Option “config_info” “udev:/sys/devices/platform/gpio-keys.2/input/input3/event3”
[ 17.693] (II) XINPUT: Adding extended input device “gpio-keys.2” (type: KEYBOARD, id 6)
[ 17.693] () Option “xkb_rules” “evdev”
[ 17.693] () Option “xkb_model” “pc105”
[ 17.694] () Option “xkb_layout” “us”
[ 17.702] (II) config/udev: Adding input device Logitech USB Receiver (/dev/input/event0)
[ 17.703] () Logitech USB Receiver: Applying InputClass “evdev keyboard catchall”
[ 17.703] (II) Using input driver ‘evdev’ for ‘Logitech USB Receiver’
[ 17.703] () Logitech USB Receiver: always reports core events
[ 17.703] () evdev: Logitech USB Receiver: Device: “/dev/input/event0”
[ 17.703] (–) evdev: Logitech USB Receiver: Vendor 0x46d Product 0xc52e
[ 17.704] (–) evdev: Logitech USB Receiver: Found keys
[ 17.704] (II) evdev: Logitech USB Receiver: Configuring as keyboard
[ 17.704] () Option “config_info” “udev:/sys/devices/platform/tegra-ehci.2/usb2/2-1/2-1:1.0/input/input0/event0”
[ 17.704] (II) XINPUT: Adding extended input device “Logitech USB Receiver” (type: KEYBOARD, id 7)
[ 17.704] () Option “xkb_rules” “evdev”
[ 17.705] () Option “xkb_model” “pc105”
[ 17.705] () Option “xkb_layout” “us”
[ 17.712] (II) config/udev: Adding input device Logitech USB Receiver (/dev/input/event1)
[ 17.712] () Logitech USB Receiver: Applying InputClass “evdev pointer catchall”
[ 17.712] () Logitech USB Receiver: Applying InputClass “evdev keyboard catchall”
[ 17.712] (II) Using input driver ‘evdev’ for ‘Logitech USB Receiver’
[ 17.713] () Logitech USB Receiver: always reports core events
[ 17.713] () evdev: Logitech USB Receiver: Device: “/dev/input/event1”
[ 17.713] (–) evdev: Logitech USB Receiver: Vendor 0x46d Product 0xc52e
[ 17.713] (–) evdev: Logitech USB Receiver: Found 20 mouse buttons
[ 17.714] (–) evdev: Logitech USB Receiver: Found scroll wheel(s)
[ 17.714] (–) evdev: Logitech USB Receiver: Found relative axes
[ 17.714] (–) evdev: Logitech USB Receiver: Found x and y relative axes
[ 17.714] (–) evdev: Logitech USB Receiver: Found absolute axes
[ 17.714] (II) evdev: Logitech USB Receiver: Forcing absolute x/y axes to exist.
[ 17.714] (–) evdev: Logitech USB Receiver: Found keys
[ 17.714] (II) evdev: Logitech USB Receiver: Configuring as mouse
[ 17.714] (II) evdev: Logitech USB Receiver: Configuring as keyboard
[ 17.715] (II) evdev: Logitech USB Receiver: Adding scrollwheel support
[ 17.715] () evdev: Logitech USB Receiver: YAxisMapping: buttons 4 and 5
[ 17.715] () evdev: Logitech USB Receiver: EmulateWheelButton: 4, EmulateWheelInertia: 10, EmulateWheelTimeout: 200
[ 17.715] () Option “config_info” “udev:/sys/devices/platform/tegra-ehci.2/usb2/2-1/2-1:1.1/input/input1/event1”
[ 17.716] (II) XINPUT: Adding extended input device “Logitech USB Receiver” (type: KEYBOARD, id 8)
[ 17.716] () Option “xkb_rules” “evdev”
[ 17.716] () Option “xkb_model” “pc105”
[ 17.716] () Option “xkb_layout” “us”
[ 17.718] (II) evdev: Logitech USB Receiver: initialized for relative axes.
[ 17.718] (WW) evdev: Logitech USB Receiver: ignoring absolute axes.
[ 17.719] () Logitech USB Receiver: (accel) keeping acceleration scheme 1
[ 17.720] () Logitech USB Receiver: (accel) acceleration profile 0
[ 17.720] () Logitech USB Receiver: (accel) acceleration factor: 2.000
[ 17.720] () Logitech USB Receiver: (accel) acceleration threshold: 4
[ 17.724] (II) config/udev: Adding input device tegra-rt5639 Headphone Jack (/dev/input/event2)
[ 17.724] (II) No input driver specified, ignoring this device.
[ 17.724] (II) This device may have been added with another device file.
[ 23.553] (II) XKB: reuse xkmfile /var/lib/xkb/server-B20D7FC79C7F597315E3E501AEF10E0D866E8E92.xkm
[ 25.065] (II) XKB: reuse xkmfile /var/lib/xkb/server-34CEB476A3CB596DA76FD7010A029F76732EF824.xkm
[ 25.236] (II) XKB: reuse xkmfile /var/lib/xkb/server-A5F4841E1B0A84EC47251C21EC8527F0F6620E99.xkm
[ 25.270] (II) XKB: reuse xkmfile /var/lib/xkb/server-586940767B762A206CA77B9BD9BFDF9DE00F6E5D.xkm
[ 25.345] (II) XKB: reuse xkmfile /var/lib/xkb/server-586940767B762A206CA77B9BD9BFDF9DE00F6E5D.xkm
[ 25.407] (II) XKB: reuse xkmfile /var/lib/xkb/server-586940767B762A206CA77B9BD9BFDF9DE00F6E5D.xkm
[ 25.445] (II) XKB: reuse xkmfile /var/lib/xkb/server-586940767B762A206CA77B9BD9BFDF9DE00F6E5D.xkm
[ 25.512] (II) XKB: reuse xkmfile /var/lib/xkb/server-586940767B762A206CA77B9BD9BFDF9DE00F6E5D.xkm
[ 25.532] (II) XKB: reuse xkmfile /var/lib/xkb/server-A5F4841E1B0A84EC47251C21EC8527F0F6620E99.xkm
[ 25.617] (II) XKB: reuse xkmfile /var/lib/xkb/server-586940767B762A206CA77B9BD9BFDF9DE00F6E5D.xkm
[ 25.666] (II) XKB: reuse xkmfile /var/lib/xkb/server-586940767B762A206CA77B9BD9BFDF9DE00F6E5D.xkm
[ 25.722] (II) XKB: reuse xkmfile /var/lib/xkb/server-586940767B762A206CA77B9BD9BFDF9DE00F6E5D.xkm
[ 25.767] (II) XKB: reuse xkmfile /var/lib/xkb/server-586940767B762A206CA77B9BD9BFDF9DE00F6E5D.xkm
[ 25.808] (II) XKB: reuse xkmfile /var/lib/xkb/server-586940767B762A206CA77B9BD9BFDF9DE00F6E5D.xkm
[ 63.864] (II) XKB: reuse xkmfile /var/lib/xkb/server-586940767B762A206CA77B9BD9BFDF9DE00F6E5D.xkm
(EE) [mi] EQ overflowing. Additional events will be discarded until existing events are processed.
(EE)
(EE) Backtrace:
(EE)
(EE) [mi] These backtraces from mieqEnqueue may point to a culprit higher up the stack.
(EE) [mi] mieq is NOT the cause. It is a victim.
(EE) [mi] EQ overflow continuing. 100 events have been dropped.
(EE)
(EE) Backtrace:
(EE)
(EE) [mi] EQ overflow continuing. 200 events have been dropped.
(EE)
(EE) Backtrace:
(EE)
(EE) [mi] EQ overflow continuing. 300 events have been dropped.
(EE)
(EE) Backtrace:
(EE)
(EE) [mi] EQ overflow continuing. 400 events have been dropped.
(EE)
(EE) Backtrace:
(EE)
(EE) [mi] EQ overflow continuing. 500 events have been dropped.
(EE)
(EE) Backtrace:
(EE)
(EE) [mi] EQ overflow continuing. 600 events have been dropped.
(EE)
(EE) Backtrace:
(EE)
(EE) [mi] EQ overflow continuing. 700 events have been dropped.
(EE)
(EE) Backtrace:
(EE)
(EE) [mi] EQ overflow continuing. 800 events have been dropped.
(EE)
(EE) Backtrace:
(EE)
(EE) [mi] EQ overflow continuing. 900 events have been dropped.
(EE)
(EE) Backtrace:
(EE)
(EE) [mi] EQ overflow continuing. 1000 events have been dropped.
(EE) [mi] No further overflow reports will be reported until the clog is cleared.
(EE)
(EE) Backtrace:
(EE)
