sorry. i’m not sure you want to see that file like this.
and i ran ‘df -H’ with . but it said there are no such command.
Specifically, i install h5py in my jetson tx2 board. but because its downloading time was so long, i thought this stopped on a dime. so i restarted ubuntu.
and as you know, when it restated, the screen went changed.
[ 22.619]
X.Org X Server 1.18.4
Release Date: 2016-07-19
[ 22.619] X Protocol Version 11, Revision 0
[ 22.619] Build Operating System: Linux 4.4.0-97-generic aarch64 Ubuntu
[ 22.619] Current Operating System: Linux tegra-ubuntu 4.4.38-tegra #1 SMP PREEMPT Thu Jul 20 00:49:07 PDT 2017 aarch64
[ 22.619] Kernel command line: root=/dev/mmcblk0p1 rw rootwait console=ttyS0,115200n8 console=tty0 OS=l4t fbcon=map:0 net.ifnames=0 memtype=0 video=tegrafb no_console_suspend=1 earlycon=uart8250,mmio32,0x03100000 nvdumper_reserved=0x2772e0000 gpt tegraid=18.1.2.0.0 tegra_keep_boot_clocks maxcpus=6 androidboot.serialno=0321017053511 bl_prof_dataptr=0x10000@0x277240000 sdhci_tegra.en_boot_part_access=1 root=/dev/mmcblk0p1 rw rootwait rootfstype=ext4
[ 22.619] Build Date: 13 October 2017 01:58:44PM
[ 22.619] xorg-server 2:1.18.4-0ubuntu0.7 (For technical support please see http://www.ubuntu.com/support)
[ 22.619] Current version of pixman: 0.33.6
[ 22.619] Before reporting problems, check http://wiki.x.org
to make sure that you have the latest version.
[ 22.619] Markers: (--) probed, (**) from config file, (==) default setting,
(++) from command line, (!!) notice, (II) informational,
(WW) warning, (EE) error, (NI) not implemented, (??) unknown.
[ 22.619] (==) Log file: "/var/log/Xorg.0.log", Time: Sat Jun 16 14:52:00 2018
[ 22.620] (==) Using config file: "/etc/X11/xorg.conf"
[ 22.620] (==) Using system config directory "/usr/share/X11/xorg.conf.d"
[ 22.620] (==) No Layout section. Using the first Screen section.
[ 22.620] (==) No screen section available. Using defaults.
[ 22.620] (**) |-->Screen "Default Screen Section" (0)
[ 22.620] (**) | |-->Monitor "<default monitor>"
[ 22.620] (==) No device specified for screen "Default Screen Section".
Using the first device section listed.
[ 22.620] (**) | |-->Device "Tegra0"
[ 22.620] (==) No monitor specified for screen "Default Screen Section".
Using a default monitor configuration.
[ 22.620] (==) Automatically adding devices
[ 22.620] (==) Automatically enabling devices
[ 22.620] (==) Automatically adding GPU devices
[ 22.620] (==) Max clients allowed: 256, resource mask: 0x1fffff
[ 22.620] (WW) The directory "/usr/share/fonts/X11/cyrillic" does not exist.
[ 22.621] Entry deleted from font path.
[ 22.621] (WW) The directory "/usr/share/fonts/X11/100dpi/" does not exist.
[ 22.621] (WW) The directory "/usr/share/fonts/X11/75dpi/" does not exist.
[ 22.621] (WW) The directory "/usr/share/fonts/X11/100dpi" does not exist.
[ 22.621] (WW) The directory "/usr/share/fonts/X11/75dpi" does not exist.
[ 22.621] (==) FontPath set to:
/usr/share/fonts/X11/misc,
/usr/share/fonts/X11/Type1,
built-ins
[ 22.621] (==) ModulePath set to "/usr/lib/aarch64-linux-gnu/xorg/extra-modules,/usr/lib/xorg/extra-modules,/usr/lib/xorg/modules"
[ 22.621] (II) The server relies on udev to provide the list of input devices.
If no devices become available, reconfigure udev or disable AutoAddDevices.
[ 22.621] (II) Loader magic: 0x5569cd2d80
[ 22.621] (II) Module ABI versions:
[ 22.621] X.Org ANSI C Emulation: 0.4
[ 22.621] X.Org Video Driver: 20.0
[ 22.621] X.Org XInput driver : 22.1
[ 22.621] X.Org Server Extension : 9.0
[ 22.622] (++) using VT number 7
[ 22.622] (II) systemd-logind: logind integration requires -keeptty and -keeptty was not provided, disabling logind integration
[ 22.622] (II) no primary bus or device found
[ 22.622] (WW) "dri" will not be loaded unless you've specified it to be loaded elsewhere.
[ 22.622] (II) "glx" will be loaded by default.
[ 22.622] (II) LoadModule: "extmod"
[ 22.622] (II) Module "extmod" already built-in
[ 22.622] (II) LoadModule: "glx"
[ 22.622] (II) Loading /usr/lib/xorg/modules/extensions/libglx.so
[ 22.633] (II) Module glx: vendor="NVIDIA Corporation"
[ 22.633] compiled for 4.0.2, module version = 1.0.0
[ 22.633] Module class: X.Org Server Extension
[ 22.633] (II) NVIDIA GLX Module 28.1.0 Release Build (integ_stage_rel) (buildbrain@mobile-u64-553) Thu Jul 20 00:50:32 PDT 2017
[ 22.633] (II) LoadModule: "nvidia"
[ 22.633] (II) Loading /usr/lib/xorg/modules/drivers/nvidia_drv.so
[ 22.634] (II) Module nvidia: vendor="NVIDIA Corporation"
[ 22.634] compiled for 4.0.2, module version = 1.0.0
[ 22.634] Module class: X.Org Video Driver
[ 22.634] (II) NVIDIA dlloader X Driver 28.1.0 Release Build (integ_stage_rel) (buildbrain@mobile-u64-553) Thu Jul 20 00:51:56 PDT 2017
[ 22.634] (II) NVIDIA Unified Driver for all Supported NVIDIA GPUs
[ 22.634] (WW) Falling back to old probe method for NVIDIA
[ 22.634] (II) Loading sub module "fb"
[ 22.634] (II) LoadModule: "fb"
[ 22.634] (II) Loading /usr/lib/xorg/modules/libfb.so
[ 22.634] (II) Module fb: vendor="X.Org Foundation"
[ 22.634] compiled for 1.18.4, module version = 1.0.0
[ 22.634] ABI class: X.Org ANSI C Emulation, version 0.4
[ 22.634] (II) Loading sub module "wfb"
[ 22.634] (II) LoadModule: "wfb"
[ 22.635] (II) Loading /usr/lib/xorg/modules/libwfb.so
[ 22.635] (II) Module wfb: vendor="X.Org Foundation"
[ 22.635] compiled for 1.18.4, module version = 1.0.0
[ 22.635] ABI class: X.Org ANSI C Emulation, version 0.4
[ 22.635] (II) Loading sub module "ramdac"
[ 22.635] (II) LoadModule: "ramdac"
[ 22.635] (II) Module "ramdac" already built-in
[ 22.635] (WW) VGA arbiter: cannot open kernel arbiter, no multi-card support
[ 22.636] (II) NVIDIA(0): Creating default Display subsection in Screen section
"Default Screen Section" for depth/fbbpp 24/32
[ 22.636] (==) NVIDIA(0): Depth 24, (==) framebuffer bpp 32
[ 22.636] (==) NVIDIA(0): RGB weight 888
[ 22.636] (==) NVIDIA(0): Default visual is TrueColor
[ 22.636] (==) NVIDIA(0): Using gamma correction (1.0, 1.0, 1.0)
[ 22.636] (**) NVIDIA(0): Option "AllowEmptyInitialConfiguration" "true"
[ 22.636] (**) NVIDIA(0): Enabling 2D acceleration
[ 22.657] (--) NVIDIA(0): Valid display device(s) on GPU-0 at SoC
[ 22.657] (--) NVIDIA(0): DFP-0
[ 22.657] (II) NVIDIA(0): NVIDIA GPU NVIDIA Tegra X2 (nvgpu) (GP10B) at SoC (GPU-0)
[ 22.657] (--) NVIDIA(0): Memory: 8039124 kBytes
[ 22.657] (--) NVIDIA(0): VideoBIOS:
[ 22.657] (--) NVIDIA(GPU-0): LG Electronics LG IPS FULLHD (DFP-0): connected
[ 22.657] (--) NVIDIA(GPU-0): LG Electronics LG IPS FULLHD (DFP-0): External TMDS
[ 22.662] (==) NVIDIA(0):
[ 22.662] (==) NVIDIA(0): No modes were requested; the default mode "nvidia-auto-select"
[ 22.662] (==) NVIDIA(0): will be used as the requested mode.
[ 22.662] (II) NVIDIA(0): Validated MetaModes:
[ 22.662] (II) NVIDIA(0): "DFP-0:nvidia-auto-select"
[ 22.662] (II) NVIDIA(0): Virtual screen size determined to be 1920 x 1080
[ 22.664] (--) NVIDIA(0): DPI set to (101, 101); computed from "UseEdidDpi" X config
[ 22.664] (--) NVIDIA(0): option
[ 22.664] (--) Depth 24 pixmap format is 32 bpp
[ 22.664] (II) NVIDIA: Reserving 49152.00 MB of virtual memory for indirect memory
[ 22.664] (II) NVIDIA: access.
[ 22.666] (EE) NVIDIA(0): Failed to allocate NVIDIA Error Handler
[ 22.667] (II) NVIDIA(0): ACPI: failed to connect to the ACPI event daemon; the daemon
[ 22.667] (II) NVIDIA(0): may not be running or the "AcpidSocketPath" X
[ 22.667] (II) NVIDIA(0): configuration option may not be set correctly. When the
[ 22.667] (II) NVIDIA(0): ACPI event daemon is available, the NVIDIA X driver will
[ 22.667] (II) NVIDIA(0): try to use it to receive ACPI event notifications. For
[ 22.667] (II) NVIDIA(0): details, please see the "ConnectToAcpid" and
[ 22.667] (II) NVIDIA(0): "AcpidSocketPath" X configuration options in Appendix B: X
[ 22.667] (II) NVIDIA(0): Config Options in the README.
[ 22.700] (II) NVIDIA(0): Setting mode "DFP-0:nvidia-auto-select"
[ 23.869] (==) NVIDIA(0): Disabling shared memory pixmaps
[ 23.869] (==) NVIDIA(0): Backing store enabled
[ 23.869] (==) NVIDIA(0): Silken mouse enabled
[ 23.893] (==) NVIDIA(0): DPMS enabled
[ 23.893] (II) Loading sub module "dri2"
[ 23.893] (II) LoadModule: "dri2"
[ 23.893] (II) Module "dri2" already built-in
[ 23.893] (II) NVIDIA(0): [DRI2] Setup complete
[ 23.894] (II) NVIDIA(0): [DRI2] VDPAU driver: nvidia
[ 23.930] (--) RandR disabled
[ 23.953] (II) SELinux: Disabled on system
[ 23.956] (II) Initializing extension GLX
[ 23.956] (II) Indirect GLX disabled.
[ 24.052] (II) config/udev: Adding input device tegra-hda HDMI/DP,pcm=3 (/dev/input/event0)
[ 24.052] (II) No input driver specified, ignoring this device.
[ 24.052] (II) This device may have been added with another device file.
[ 24.053] (II) config/udev: Adding input device tegra-hda HDMI/DP,pcm=7 (/dev/input/event1)
[ 24.053] (II) No input driver specified, ignoring this device.
[ 24.053] (II) This device may have been added with another device file.
[ 24.054] (II) config/udev: Adding input device HOLDCHIP USB Keyboard (/dev/input/event4)
[ 24.054] (**) HOLDCHIP USB Keyboard: Applying InputClass "evdev keyboard catchall"
[ 24.054] (II) LoadModule: "evdev"
[ 24.054] (II) Loading /usr/lib/xorg/modules/input/evdev_drv.so
[ 24.055] (II) Module evdev: vendor="X.Org Foundation"
[ 24.055] compiled for 1.18.1, module version = 2.10.1
[ 24.055] Module class: X.Org XInput Driver
[ 24.055] ABI class: X.Org XInput driver, version 22.1
[ 24.055] (II) Using input driver 'evdev' for 'HOLDCHIP USB Keyboard'
[ 24.055] (**) HOLDCHIP USB Keyboard: always reports core events
[ 24.055] (**) evdev: HOLDCHIP USB Keyboard: Device: "/dev/input/event4"
[ 24.055] (--) evdev: HOLDCHIP USB Keyboard: Vendor 0x4d9 Product 0x24
[ 24.055] (--) evdev: HOLDCHIP USB Keyboard: Found keys
[ 24.055] (II) evdev: HOLDCHIP USB Keyboard: Configuring as keyboard
[ 24.055] (**) Option "config_info" "udev:/sys/devices/3530000.xhci/usb1/1-2/1-2.3/1-2.3:1.0/0003:04D9:0024.0001/input/input4/event4"
[ 24.055] (II) XINPUT: Adding extended input device "HOLDCHIP USB Keyboard" (type: KEYBOARD, id 6)
[ 24.055] (**) Option "xkb_rules" "evdev"
[ 24.055] (**) Option "xkb_model" "pc105"
[ 24.055] (**) Option "xkb_layout" "us"
[ 24.057] (II) config/udev: Adding input device HOLDCHIP USB Keyboard (/dev/input/event5)
[ 24.057] (**) HOLDCHIP USB Keyboard: Applying InputClass "evdev keyboard catchall"
[ 24.057] (II) Using input driver 'evdev' for 'HOLDCHIP USB Keyboard'
[ 24.057] (**) HOLDCHIP USB Keyboard: always reports core events
[ 24.057] (**) evdev: HOLDCHIP USB Keyboard: Device: "/dev/input/event5"
[ 24.057] (--) evdev: HOLDCHIP USB Keyboard: Vendor 0x4d9 Product 0x24
[ 24.057] (--) evdev: HOLDCHIP USB Keyboard: Found 3 mouse buttons
[ 24.057] (--) evdev: HOLDCHIP USB Keyboard: Found keys
[ 24.057] (II) evdev: HOLDCHIP USB Keyboard: Forcing relative x/y axes to exist.
[ 24.057] (II) evdev: HOLDCHIP USB Keyboard: Configuring as mouse
[ 24.057] (II) evdev: HOLDCHIP USB Keyboard: Configuring as keyboard
[ 24.057] (**) evdev: HOLDCHIP USB Keyboard: YAxisMapping: buttons 4 and 5
[ 24.057] (**) evdev: HOLDCHIP USB Keyboard: EmulateWheelButton: 4, EmulateWheelInertia: 10, EmulateWheelTimeout: 200
[ 24.057] (**) Option "config_info" "udev:/sys/devices/3530000.xhci/usb1/1-2/1-2.3/1-2.3:1.1/0003:04D9:0024.0002/input/input5/event5"
[ 24.057] (II) XINPUT: Adding extended input device "HOLDCHIP USB Keyboard" (type: KEYBOARD, id 7)
[ 24.057] (**) Option "xkb_rules" "evdev"
[ 24.057] (**) Option "xkb_model" "pc105"
[ 24.057] (**) Option "xkb_layout" "us"
[ 24.059] (II) config/udev: Adding input device HID 12c9:1002 (/dev/input/event6)
[ 24.059] (**) HID 12c9:1002: Applying InputClass "evdev pointer catchall"
[ 24.059] (**) HID 12c9:1002: Applying InputClass "evdev keyboard catchall"
[ 24.059] (II) Using input driver 'evdev' for 'HID 12c9:1002'
[ 24.059] (**) HID 12c9:1002: always reports core events
[ 24.059] (**) evdev: HID 12c9:1002: Device: "/dev/input/event6"
[ 24.059] (--) evdev: HID 12c9:1002: Vendor 0x12c9 Product 0x1002
[ 24.059] (--) evdev: HID 12c9:1002: Found 9 mouse buttons
[ 24.059] (--) evdev: HID 12c9:1002: Found scroll wheel(s)
[ 24.059] (--) evdev: HID 12c9:1002: Found relative axes
[ 24.059] (--) evdev: HID 12c9:1002: Found x and y relative axes
[ 24.059] (--) evdev: HID 12c9:1002: Found absolute axes
[ 24.059] (II) evdev: HID 12c9:1002: Forcing absolute x/y axes to exist.
[ 24.059] (--) evdev: HID 12c9:1002: Found keys
[ 24.059] (II) evdev: HID 12c9:1002: Configuring as mouse
[ 24.059] (II) evdev: HID 12c9:1002: Configuring as keyboard
[ 24.059] (II) evdev: HID 12c9:1002: Adding scrollwheel support
[ 24.059] (**) evdev: HID 12c9:1002: YAxisMapping: buttons 4 and 5
[ 24.059] (**) evdev: HID 12c9:1002: EmulateWheelButton: 4, EmulateWheelInertia: 10, EmulateWheelTimeout: 200
[ 24.059] (**) Option "config_info" "udev:/sys/devices/3530000.xhci/usb1/1-2/1-2.4/1-2.4:1.0/0003:12C9:1002.0003/input/input6/event6"
[ 24.059] (II) XINPUT: Adding extended input device "HID 12c9:1002" (type: KEYBOARD, id 8)
[ 24.059] (**) Option "xkb_rules" "evdev"
[ 24.059] (**) Option "xkb_model" "pc105"
[ 24.059] (**) Option "xkb_layout" "us"
[ 24.060] (II) evdev: HID 12c9:1002: initialized for relative axes.
[ 24.060] (WW) evdev: HID 12c9:1002: ignoring absolute axes.
[ 24.060] (**) HID 12c9:1002: (accel) keeping acceleration scheme 1
[ 24.060] (**) HID 12c9:1002: (accel) acceleration profile 0
[ 24.060] (**) HID 12c9:1002: (accel) acceleration factor: 2.000
[ 24.060] (**) HID 12c9:1002: (accel) acceleration threshold: 4
[ 24.061] (II) config/udev: Adding input device HID 12c9:1002 (/dev/input/event7)
[ 24.061] (**) HID 12c9:1002: Applying InputClass "evdev keyboard catchall"
[ 24.061] (II) Using input driver 'evdev' for 'HID 12c9:1002'
[ 24.061] (**) HID 12c9:1002: always reports core events
[ 24.061] (**) evdev: HID 12c9:1002: Device: "/dev/input/event7"
[ 24.061] (--) evdev: HID 12c9:1002: Vendor 0x12c9 Product 0x1002
[ 24.061] (--) evdev: HID 12c9:1002: Found keys
[ 24.061] (II) evdev: HID 12c9:1002: Configuring as keyboard
[ 24.061] (**) Option "config_info" "udev:/sys/devices/3530000.xhci/usb1/1-2/1-2.4/1-2.4:1.1/0003:12C9:1002.0004/input/input7/event7"
[ 24.061] (II) XINPUT: Adding extended input device "HID 12c9:1002" (type: KEYBOARD, id 9)
[ 24.061] (**) Option "xkb_rules" "evdev"
[ 24.061] (**) Option "xkb_model" "pc105"
[ 24.061] (**) Option "xkb_layout" "us"
[ 24.062] (II) config/udev: Adding input device gpio-keys (/dev/input/event3)
[ 24.062] (**) gpio-keys: Applying InputClass "evdev keyboard catchall"
[ 24.062] (II) Using input driver 'evdev' for 'gpio-keys'
[ 24.062] (**) gpio-keys: always reports core events
[ 24.062] (**) evdev: gpio-keys: Device: "/dev/input/event3"
[ 24.062] (--) evdev: gpio-keys: Vendor 0x1 Product 0x1
[ 24.062] (--) evdev: gpio-keys: Found keys
[ 24.062] (II) evdev: gpio-keys: Configuring as keyboard
[ 24.062] (**) Option "config_info" "udev:/sys/devices/gpio-keys/input/input3/event3"
[ 24.062] (II) XINPUT: Adding extended input device "gpio-keys" (type: KEYBOARD, id 10)
[ 24.062] (**) Option "xkb_rules" "evdev"
[ 24.062] (**) Option "xkb_model" "pc105"
[ 24.062] (**) Option "xkb_layout" "us"
[ 24.063] (II) config/udev: Adding input device tegra-snd-t186ref-mobile-rt565x Headphone Jack (/dev/input/event2)
[ 24.063] (**) tegra-snd-t186ref-mobile-rt565x Headphone Jack: Applying InputClass "evdev keyboard catchall"
[ 24.063] (II) Using input driver 'evdev' for 'tegra-snd-t186ref-mobile-rt565x Headphone Jack'
[ 24.063] (**) tegra-snd-t186ref-mobile-rt565x Headphone Jack: always reports core events
[ 24.063] (**) evdev: tegra-snd-t186ref-mobile-rt565x Headphone Jack: Device: "/dev/input/event2"
[ 24.064] (--) evdev: tegra-snd-t186ref-mobile-rt565x Headphone Jack: Vendor 0 Product 0
[ 24.064] (--) evdev: tegra-snd-t186ref-mobile-rt565x Headphone Jack: Found keys
[ 24.064] (II) evdev: tegra-snd-t186ref-mobile-rt565x Headphone Jack: Configuring as keyboard
[ 24.064] (**) Option "config_info" "udev:/sys/devices/sound/sound/card1/input2/event2"
[ 24.064] (II) XINPUT: Adding extended input device "tegra-snd-t186ref-mobile-rt565x Headphone Jack" (type: KEYBOARD, id 11)
[ 24.064] (**) Option "xkb_rules" "evdev"
[ 24.064] (**) Option "xkb_model" "pc105"
[ 24.064] (**) Option "xkb_layout" "us"
[ 25.262] (--) NVIDIA(GPU-0): LG Electronics LG IPS FULLHD (DFP-0): connected
[ 25.262] (--) NVIDIA(GPU-0): LG Electronics LG IPS FULLHD (DFP-0): External TMDS
[ 25.496] (II) NVIDIA(0): Setting mode "HDMI-0: nvidia-auto-select @1920x1080 +0+0 {ViewPortIn=1920x1080, ViewPortOut=1920x1080+0+0}"
[ 26.027] (--) NVIDIA(GPU-0): LG Electronics LG IPS FULLHD (DFP-0): connected
[ 26.027] (--) NVIDIA(GPU-0): LG Electronics LG IPS FULLHD (DFP-0): External TMDS
[ 52.908] (--) NVIDIA(GPU-0): LG Electronics LG IPS FULLHD (DFP-0): connected
[ 52.908] (--) NVIDIA(GPU-0): LG Electronics LG IPS FULLHD (DFP-0): External TMDS
[ 54.574] (--) NVIDIA(GPU-0): LG Electronics LG IPS FULLHD (DFP-0): connected
[ 54.574] (--) NVIDIA(GPU-0): LG Electronics LG IPS FULLHD (DFP-0): External TMDS
[ 55.042] (II) NVIDIA(0): Setting mode "HDMI-0: nvidia-auto-select @1920x1080 +0+0 {ViewPortIn=1920x1080, ViewPortOut=1920x1080+0+0}"
[ 55.279] (--) NVIDIA(GPU-0): LG Electronics LG IPS FULLHD (DFP-0): connected
[ 55.279] (--) NVIDIA(GPU-0): LG Electronics LG IPS FULLHD (DFP-0): External TMDS
[ 913.626] (II) NVIDIA(0): Setting mode "HDMI-0: nvidia-auto-select @1920x1080 +0+0 {ViewPortIn=1920x1080, ViewPortOut=1920x1080+0+0}"
[ 913.888] (--) NVIDIA(GPU-0): LG Electronics LG IPS FULLHD (DFP-0): connected
[ 913.888] (--) NVIDIA(GPU-0): LG Electronics LG IPS FULLHD (DFP-0): External TMDS
[ 946.161] (--) NVIDIA(GPU-0): LG Electronics LG IPS FULLHD (DFP-0): connected
[ 946.162] (--) NVIDIA(GPU-0): LG Electronics LG IPS FULLHD (DFP-0): External TMDS
[ 4649.533] (II) config/udev: removing device HOLDCHIP USB Keyboard
[ 4649.556] (II) evdev: HOLDCHIP USB Keyboard: Close
[ 4649.556] (II) UnloadModule: "evdev"
[ 4649.556] (II) config/udev: removing device HOLDCHIP USB Keyboard
[ 4649.572] (II) evdev: HOLDCHIP USB Keyboard: Close
[ 4649.572] (II) UnloadModule: "evdev"
[ 4651.253] (II) config/udev: removing device HID 12c9:1002
[ 4651.275] (II) evdev: HID 12c9:1002: Close
[ 4651.277] (II) UnloadModule: "evdev"
[ 4651.336] (II) config/udev: removing device HID 12c9:1002
[ 4651.353] (II) evdev: HID 12c9:1002: Close
[ 4651.353] (II) UnloadModule: "evdev"
[ 4662.149] (II) NVIDIA(0): Setting mode "HDMI-0: nvidia-auto-select @1920x1080 +0+0 {ViewPortIn=1920x1080, ViewPortOut=1920x1080+0+0}"
[ 4662.182] (EE) NVIDIA(0): Failed to set the display configuration.
[ 5334.860] (--) NVIDIA(GPU-0): LG Electronics LG IPS FULLHD (DFP-0): connected
[ 5334.861] (--) NVIDIA(GPU-0): LG Electronics LG IPS FULLHD (DFP-0): External TMDS
[ 5334.878] (II) NVIDIA(0): Setting mode "HDMI-0: nvidia-auto-select @1920x1080 +0+0 {ViewPortIn=1920x1080, ViewPortOut=1920x1080+0+0}"
[ 5334.911] (EE) NVIDIA(0): Failed to set the display configuration.
[ 5334.926] (II) NVIDIA(0): Setting mode "HDMI-0: nvidia-auto-select @1920x1080 +0+0 {ViewPortIn=1920x1080, ViewPortOut=1920x1080+0+0}"
[ 5334.959] (EE) NVIDIA(0): Failed to set the display configuration.
[ 5335.419] (--) NVIDIA(GPU-0): LG Electronics LG IPS FULLHD (DFP-0): connected
[ 5335.420] (--) NVIDIA(GPU-0): LG Electronics LG IPS FULLHD (DFP-0): External TMDS
[ 5335.432] (II) NVIDIA(0): Setting mode "HDMI-0: nvidia-auto-select @1920x1080 +0+0 {ViewPortIn=1920x1080, ViewPortOut=1920x1080+0+0}"
[ 5336.568] (--) NVIDIA(GPU-0): LG Electronics LG IPS FULLHD (DFP-0): connected
[ 5336.569] (--) NVIDIA(GPU-0): LG Electronics LG IPS FULLHD (DFP-0): External TMDS
[ 5336.570] (--) NVIDIA(GPU-0): LG Electronics LG IPS FULLHD (DFP-0): connected
[ 5336.570] (--) NVIDIA(GPU-0): LG Electronics LG IPS FULLHD (DFP-0): External TMDS
[ 5336.587] (II) NVIDIA(0): Setting mode "HDMI-0: nvidia-auto-select @1920x1080 +0+0 {ViewPortIn=1920x1080, ViewPortOut=1920x1080+0+0}"
[ 5336.867] (--) NVIDIA(GPU-0): LG Electronics LG IPS FULLHD (DFP-0): connected
[ 5336.867] (--) NVIDIA(GPU-0): LG Electronics LG IPS FULLHD (DFP-0): External TMDS
[ 5336.878] (--) NVIDIA(GPU-0): LG Electronics LG IPS FULLHD (DFP-0): connected
[ 5336.878] (--) NVIDIA(GPU-0): LG Electronics LG IPS FULLHD (DFP-0): External TMDS
[ 5354.799] (II) config/udev: Adding input device HOLDCHIP USB Keyboard (/dev/input/event6)
[ 5354.799] (**) HOLDCHIP USB Keyboard: Applying InputClass "evdev keyboard catchall"
[ 5354.799] (II) Using input driver 'evdev' for 'HOLDCHIP USB Keyboard'
[ 5354.799] (**) HOLDCHIP USB Keyboard: always reports core events
[ 5354.799] (**) evdev: HOLDCHIP USB Keyboard: Device: "/dev/input/event6"
[ 5354.799] (--) evdev: HOLDCHIP USB Keyboard: Vendor 0x4d9 Product 0x24
[ 5354.799] (--) evdev: HOLDCHIP USB Keyboard: Found keys
[ 5354.799] (II) evdev: HOLDCHIP USB Keyboard: Configuring as keyboard
[ 5354.799] (**) Option "config_info" "udev:/sys/devices/3530000.xhci/usb1/1-2/1-2.3/1-2.3:1.0/0003:04D9:0024.0007/input/input10/event6"
[ 5354.799] (II) XINPUT: Adding extended input device "HOLDCHIP USB Keyboard" (type: KEYBOARD, id 6)
[ 5354.799] (**) Option "xkb_rules" "evdev"
[ 5354.799] (**) Option "xkb_model" "pc105"
[ 5354.799] (**) Option "xkb_layout" "us"
[ 5354.799] (WW) Option "xkb_variant" requires a string value
[ 5354.799] (WW) Option "xkb_options" requires a string value
[ 5354.801] (II) config/udev: Adding input device HID 12c9:1002 (/dev/input/event5)
[ 5354.801] (**) HID 12c9:1002: Applying InputClass "evdev keyboard catchall"
[ 5354.801] (II) Using input driver 'evdev' for 'HID 12c9:1002'
[ 5354.801] (**) HID 12c9:1002: always reports core events
[ 5354.801] (**) evdev: HID 12c9:1002: Device: "/dev/input/event5"
[ 5354.801] (--) evdev: HID 12c9:1002: Vendor 0x12c9 Product 0x1002
[ 5354.801] (--) evdev: HID 12c9:1002: Found keys
[ 5354.801] (II) evdev: HID 12c9:1002: Configuring as keyboard
[ 5354.801] (**) Option "config_info" "udev:/sys/devices/3530000.xhci/usb1/1-2/1-2.4/1-2.4:1.1/0003:12C9:1002.0006/input/input9/event5"
[ 5354.801] (II) XINPUT: Adding extended input device "HID 12c9:1002" (type: KEYBOARD, id 7)
[ 5354.801] (**) Option "xkb_rules" "evdev"
[ 5354.801] (**) Option "xkb_model" "pc105"
[ 5354.801] (**) Option "xkb_layout" "us"
[ 5354.801] (WW) Option "xkb_variant" requires a string value
[ 5354.801] (WW) Option "xkb_options" requires a string value
[ 5354.803] (II) config/udev: Adding input device HID 12c9:1002 (/dev/input/event4)
[ 5354.803] (**) HID 12c9:1002: Applying InputClass "evdev pointer catchall"
[ 5354.803] (**) HID 12c9:1002: Applying InputClass "evdev keyboard catchall"
[ 5354.803] (II) Using input driver 'evdev' for 'HID 12c9:1002'
[ 5354.803] (**) HID 12c9:1002: always reports core events
[ 5354.803] (**) evdev: HID 12c9:1002: Device: "/dev/input/event4"
[ 5354.803] (--) evdev: HID 12c9:1002: Vendor 0x12c9 Product 0x1002
[ 5354.803] (--) evdev: HID 12c9:1002: Found 9 mouse buttons
[ 5354.803] (--) evdev: HID 12c9:1002: Found scroll wheel(s)
[ 5354.803] (--) evdev: HID 12c9:1002: Found relative axes
[ 5354.803] (--) evdev: HID 12c9:1002: Found x and y relative axes
[ 5354.803] (--) evdev: HID 12c9:1002: Found absolute axes
[ 5354.804] (II) evdev: HID 12c9:1002: Forcing absolute x/y axes to exist.
[ 5354.804] (--) evdev: HID 12c9:1002: Found keys
[ 5354.804] (II) evdev: HID 12c9:1002: Configuring as mouse
[ 5354.804] (II) evdev: HID 12c9:1002: Configuring as keyboard
[ 5354.804] (II) evdev: HID 12c9:1002: Adding scrollwheel support
[ 5354.804] (**) evdev: HID 12c9:1002: YAxisMapping: buttons 4 and 5
[ 5354.804] (**) evdev: HID 12c9:1002: EmulateWheelButton: 4, EmulateWheelInertia: 10, EmulateWheelTimeout: 200
[ 5354.804] (**) Option "config_info" "udev:/sys/devices/3530000.xhci/usb1/1-2/1-2.4/1-2.4:1.0/0003:12C9:1002.0005/input/input8/event4"
[ 5354.804] (II) XINPUT: Adding extended input device "HID 12c9:1002" (type: KEYBOARD, id 8)
[ 5354.804] (**) Option "xkb_rules" "evdev"
[ 5354.804] (**) Option "xkb_model" "pc105"
[ 5354.804] (**) Option "xkb_layout" "us"
[ 5354.804] (WW) Option "xkb_variant" requires a string value
[ 5354.804] (WW) Option "xkb_options" requires a string value
[ 5354.805] (II) evdev: HID 12c9:1002: initialized for relative axes.
[ 5354.805] (WW) evdev: HID 12c9:1002: ignoring absolute axes.
[ 5354.805] (**) HID 12c9:1002: (accel) keeping acceleration scheme 1
[ 5354.805] (**) HID 12c9:1002: (accel) acceleration profile 0
[ 5354.805] (**) HID 12c9:1002: (accel) acceleration factor: 2.000
[ 5354.805] (**) HID 12c9:1002: (accel) acceleration threshold: 4
[ 5354.841] (II) config/udev: Adding input device HOLDCHIP USB Keyboard (/dev/input/event7)
[ 5354.841] (**) HOLDCHIP USB Keyboard: Applying InputClass "evdev keyboard catchall"
[ 5354.841] (II) Using input driver 'evdev' for 'HOLDCHIP USB Keyboard'
[ 5354.841] (**) HOLDCHIP USB Keyboard: always reports core events
[ 5354.841] (**) evdev: HOLDCHIP USB Keyboard: Device: "/dev/input/event7"
[ 5354.841] (--) evdev: HOLDCHIP USB Keyboard: Vendor 0x4d9 Product 0x24
[ 5354.841] (--) evdev: HOLDCHIP USB Keyboard: Found 3 mouse buttons
[ 5354.841] (--) evdev: HOLDCHIP USB Keyboard: Found keys
[ 5354.841] (II) evdev: HOLDCHIP USB Keyboard: Forcing relative x/y axes to exist.
[ 5354.841] (II) evdev: HOLDCHIP USB Keyboard: Configuring as mouse
[ 5354.841] (II) evdev: HOLDCHIP USB Keyboard: Configuring as keyboard
[ 5354.841] (**) evdev: HOLDCHIP USB Keyboard: YAxisMapping: buttons 4 and 5
[ 5354.841] (**) evdev: HOLDCHIP USB Keyboard: EmulateWheelButton: 4, EmulateWheelInertia: 10, EmulateWheelTimeout: 200
[ 5354.841] (**) Option "config_info" "udev:/sys/devices/3530000.xhci/usb1/1-2/1-2.3/1-2.3:1.1/0003:04D9:0024.0008/input/input11/event7"
[ 5354.841] (II) XINPUT: Adding extended input device "HOLDCHIP USB Keyboard" (type: KEYBOARD, id 9)
[ 5354.841] (**) Option "xkb_rules" "evdev"
[ 5354.841] (**) Option "xkb_model" "pc105"
[ 5354.841] (**) Option "xkb_layout" "us"
[ 5354.841] (WW) Option "xkb_variant" requires a string value
[ 5354.841] (WW) Option "xkb_options" requires a string value
