Totally not shown… here it is the output of dmesg:
[ 0.000000] Booting Linux on physical CPU 0x0
[ 0.000000] Initializing cgroup subsys cpu
[ 0.000000] Initializing cgroup subsys cpuacct
[ 0.000000] Linux version 3.10.40-ga7da876 (buildbrain@mobile-u64-234) (gcc version 4.5.3 (crosstool-NG hg_unknown@20110628.165246) ) #1 SMP PREEMPT Tue Jun 7 21:05:06 PDT 2016
[ 0.000000] CPU: ARMv7 Processor [413fc0f3] revision 3 (ARMv7), cr=10c5387d
[ 0.000000] CPU: PIPT / VIPT nonaliasing data cache, PIPT instruction cache
[ 0.000000] Machine: jetson-tk1, model: NVIDIA Tegra124 PM375, serial: 0
[ 0.000000] Truncating memory at 0x80000000 to fit in 32-bit physical address space
[ 0.000000] Found tsec, start=0xf4900000 size=2000000
[ 0.000000] Tegra reserved memory:
[ 0.000000] LP0: f46ff000 - f46ff80f
[ 0.000000] Bootloader framebuffer: 00000000 - 00000000
[ 0.000000] Bootloader framebuffer2: 00000000 - 00000000
[ 0.000000] Framebuffer: f8500000 - f96fffff
[ 0.000000] 2nd Framebuffer: f9700000 - fdefffff
[ 0.000000] Carveout: 00000000 - 00000000
[ 0.000000] Vpr: 00000000 - 00000000
[ 0.000000] Tsec: f4900000 - f68fffff
[ 0.000000] cma: CMA: reserved 16 MiB at ae800000
[ 0.000000] Memory policy: ECC disabled, Data cache writealloc
[ 0.000000] On node 0 totalpages: 492288
[ 0.000000] free_area_init_node: node 0, pgdat c0d21d00, node_mem_map c0e09000
[ 0.000000] Normal zone: 1520 pages used for memmap
[ 0.000000] Normal zone: 0 pages reserved
[ 0.000000] Normal zone: 194560 pages, LIFO batch:31
[ 0.000000] HighMem zone: 2510 pages used for memmap
[ 0.000000] HighMem zone: 297728 pages, LIFO batch:31
[ 0.000000] DTS File Name: /dvs/git/dirty/git-master_linux/kernel/arch/arm/boot/dts/tegra124-jetson_tk1-pm375-000-c00-00.dts
[ 0.000000] Tegra12: CPU Speedo value 2321, Soc Speedo value 2313, Gpu Speedo value 2160
[ 0.000000] Tegra12: CPU Speedo ID 1, Soc Speedo ID 1, Gpu Speedo ID 1
[ 0.000000] Tegra12: CPU Process ID 1,Soc Process ID 1,Gpu Process ID 1
[ 0.000000] Tegra Revision: A01 SKU: 0x81 CPU Process: 1 Core Process: 1
[ 0.000000] tegra: PLLP fixed rate: 408000000
[ 0.000000] tegra_clk_shared_bus_user_init: c2bus client se left ON
[ 0.000000] tegra_clk_shared_bus_user_init: c4bus client vi left ON
[ 0.000000] Lowering cpu_lp maximum rate from 1350000000 to 1092000000
[ 0.000000] Lowering sbus maximum rate from 420000000 to 384000000
[ 0.000000] Lowering vic03 maximum rate from 900000000 to 828000000
[ 0.000000] Lowering tsec maximum rate from 900000000 to 828000000
[ 0.000000] Lowering msenc maximum rate from 600000000 to 528000000
[ 0.000000] Lowering se maximum rate from 600000000 to 528000000
[ 0.000000] Lowering vde maximum rate from 600000000 to 528000000
[ 0.000000] Lowering host1x maximum rate from 500000000 to 444000000
[ 0.000000] Lowering vi maximum rate from 700000000 to 600000000
[ 0.000000] Lowering isp maximum rate from 700000000 to 600000000
[ 0.000000] Lowering c4bus maximum rate from 700000000 to 600000000
[ 0.000000] Lowering pll_c maximum rate from 1400000000 to 1066000000
[ 0.000000] Lowering pll_c2 maximum rate from 1200000000 to 1066000000
[ 0.000000] Lowering pll_c3 maximum rate from 1200000000 to 1066000000
[ 0.000000] Lowering hdmi maximum rate from 594000000 to 297000000
[ 0.000000] Lowering sdmmc1 maximum rate from 208000000 to 204000000
[ 0.000000] Lowering sdmmc3 maximum rate from 208000000 to 204000000
[ 0.000000] Lowering gbus maximum rate from 1032000000 to 852000000
[ 0.000000] Lowering cpu_g maximum rate from 3000000000 to 2065500000
[ 0.000000] tegra dvfs: VDD_CPU nominal 1260mV, scaling enabled
[ 0.000000] tegra dvfs: VDD_CORE nominal 1150mV, scaling enabled
[ 0.000000] tegra dvfs: VDD_GPU nominal 1200mV, scaling enabled
[ 0.000000] Switching to timer-based delay loop
[ 0.000000] tegra_powergate_init: DONE
[ 0.000000] tegra12_plle_clk_enable: pll_e is already enabled
[ 0.000000] PERCPU: Embedded 9 pages/cpu @c1df3000 s15168 r8192 d13504 u36864
[ 0.000000] pcpu-alloc: s15168 r8192 d13504 u36864 alloc=9*4096
[ 0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 490768
[ 0.000000] Kernel command line: console=ttyS0,115200n8 console=tty1 no_console_suspend=1 lp0_vec=2064@0xf46ff000 mem=2015M@2048M memtype=255 ddr_die=2048M@2048M section=256M pmuboard=0x0177:0x0000:0x02:0x43:0x00 tsec=32M@3913M otf_key=c75e5bb91eb3bd947560357b64422f85 usbcore.old_scheme_first=1 core_edp_mv=1150 core_edp_ma=4000 tegraid=40.1.1.0.0 debug_uartport=lsport,3 power_supply=Adapter audio_codec=rt5640 modem_id=0 android.kerneltype=normal fbcon=map:1 commchip_id=0 usb_port_owner_info=2 lane_owner_info=6 emc_max_dvfs=0 touch_id=0@0 board_info=0x0177:0x0000:0x02:0x43:0x00 net.ifnames=0 root=/dev/mmcblk0p1 rw rootwait tegraboot=sdmmc gpt
[ 0.000000] PID hash table entries: 4096 (order: 2, 16384 bytes)
[ 0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes)
[ 0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes)
[ 0.000000] Memory: 1923MB = 1923MB total
[ 0.000000] Memory: 1920996k/1920996k available, 142364k reserved, 1190908K highmem
[ 0.000000] Virtual kernel memory layout:
[ 0.000000] vector : 0xffff0000 - 0xffff1000 ( 4 kB)
[ 0.000000] fixmap : 0xfff00000 - 0xfffe0000 ( 896 kB)
[ 0.000000] vmalloc : 0xf0000000 - 0xff000000 ( 240 MB)
[ 0.000000] lowmem : 0xc0000000 - 0xef800000 ( 760 MB)
[ 0.000000] pkmap : 0xbfe00000 - 0xc0000000 ( 2 MB)
[ 0.000000] modules : 0xbf000000 - 0xbfe00000 ( 14 MB)
[ 0.000000] .text : 0xc0008000 - 0xc0b5b6cc (11598 kB)
[ 0.000000] .init : 0xc0b5c000 - 0xc0bd8b40 ( 499 kB)
[ 0.000000] .data : 0xc0bda000 - 0xc0d3b058 (1413 kB)
[ 0.000000] .bss : 0xc0d3b058 - 0xc0dd5f8c ( 620 kB)
[ 0.000000] Preemptible hierarchical RCU implementation.
[ 0.000000] NR_IRQS:960
[ 0.000000] the number of interrupt controllers found is 5
[ 0.000000] Architected local timer running at 12.00MHz (phys).
[ 0.000000] sched_clock: 56 bits at 12MHz, resolution 83ns, wraps every 2863311536128ns
[ 0.000000] Ignoring duplicate/late registration of read_current_timer delay
[ 0.000000] Console: colour dummy device 80x30
[ 0.000000] console [tty1] enabled
[ 0.003831] Calibrating delay loop (skipped), value calculated using timer frequency.. lpj=12000
[ 0.003904] pid_max: default: 32768 minimum: 301
[ 0.004202] Mount-cache hash table entries: 512
[ 0.027196] Initializing cgroup subsys debug
[ 0.027242] Initializing cgroup subsys freezer
[ 0.027329] CPU: Testing write buffer coherency: ok
[ 0.027400] ftrace: allocating 33483 entries in 66 pages
[ 0.069605] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
[ 0.069650] Setting up static identity map for 0xc08242b8 - 0xc0824354
[ 0.073642] ftrace: Allocated trace_printk buffers
[ 0.081344] CPU1: thread -1, cpu 1, socket 0, mpidr 80000001
[ 0.084349] CPU2: thread -1, cpu 2, socket 0, mpidr 80000002
[ 0.087393] CPU3: thread -1, cpu 3, socket 0, mpidr 80000003
[ 0.087589] Brought up 4 CPUs
[ 0.087655] SMP: Total of 4 processors activated.
[ 0.087672] CPU: All CPU(s) started in SVC mode.
[ 0.088543] devtmpfs: initialized
[ 0.097470] pinctrl core: initialized pinctrl subsystem
[ 0.097800] regulator-dummy: no parameters
[ 0.098505] NET: Registered protocol family 16
[ 0.100850] DMA: preallocated 256 KiB pool for atomic coherent allocations
[ 0.102112] tegra_smmu tegra_smmu: Loaded Tegra IOMMU driver
[ 0.103511] console [pstore-1] enabled
[ 0.103549] ramoops: attached 0x200000@0xf8300000, ecc: 0/0
[ 0.103943] cpuidle: using governor ladder
[ 0.103967] cpuidle: using governor menu
[ 0.107803] ardbeg_camera_auxdata: update camera lookup table.
[ 0.116842] tegra-gpio 6000d000.gpio: Initialising GPIO state 0: name default
[ 0.117258] gpiochip_add: registered GPIOs 0 to 255 on device: tegra-gpio
[ 0.124227] Wake16 for irq=34
[ 0.126729] Wake58 for irq=81
[ 0.126780] Wake41 for irq=129
[ 0.126800] Wake43 for irq=129
[ 0.126847] Wake40 for irq=53
[ 0.126866] Wake42 for irq=53
[ 0.131165] board_info: id:sku:fab:major:minor = 0x0177:0x0000:0x42:0x44:0x00
[ 0.131251] board_info: id:sku:fab:major:minor = 0x0177:0x0000:0x42:0x44:0x00
[ 0.131317] disp1 pclk=154700000
[ 0.131327] disp2 pclk=297000000
[ 0.131336] Selecting UARTD as the debug console
[ 0.131384] The debug console clock name is uartd
[ 0.131666] ardbeg_modem_init: modem_id = 0
[ 0.134394] Clear bootloader IO dpd settings
[ 0.134632] Loading jetson TK1 EMC tables.
[ 0.134890] tegra: pll_m is selected as scalable EMC clock source
[ 0.134935] Lowering emc maximum rate from 1200000000 to 924000000
[ 0.134965] tegra: validated EMC DFS table
[ 0.135097] ardbeg_edp_init: CPU regulator 12500 mA
[ 0.401090] ardbeg_edp_init: GPU regulator 11400 mA
[ 0.402088] swapper/0 isomgr_init(): iso emc max clk=924000KHz
[ 0.402111] swapper/0 isomgr_init(): max_iso_bw=7392000KB<6>[ 0.402504] ardbeg_touch_init init raydium touch
[ 0.402655] Raydium - touch platform_id : 8
[ 0.485492] platform tegradc.0: IOVA linear map 0xf8500000(1200000)
[ 0.488808] platform tegradc.0: IOVA linear map 0xf9700000(4800000)
[ 0.493837] platform tegradc.1: IOVA linear map 0xf8500000(1200000)
[ 0.497159] platform tegradc.1: IOVA linear map 0xf9700000(4800000)
[ 0.497599] FUSE: cp_rev 0 ft_rev 0
[ 0.497775] tegra11_soctherem_oc_int_init(): OC interrupts are not enabled
[ 0.498204] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
[ 0.498236] hw-breakpoint: maximum watchpoint size is 8 bytes.
[ 0.498475] mc-err: Started MC error interface!
[ 0.509277] bio: create slab <bio-0> at 0
[ 0.511190] reg-fixed-voltage 0.regulator: Consumer c1 does not have device name
[ 0.511227] reg-fixed-voltage 0.regulator: Consumer c2 does not have device name
[ 0.511260] of_get_named_gpio_flags: can't parse gpios property
[ 0.511356] vdd-ac-bat: 8400 mV
[ 0.511493] reg-fixed-voltage 1.regulator: Consumer c1 does not have device name
[ 0.511528] reg-fixed-voltage 1.regulator: Consumer c2 does not have device name
[ 0.511557] of_get_named_gpio_flags: can't parse gpios property
[ 0.511660] vdd-3v3-aon: 3300 mV
[ 0.511819] reg-fixed-voltage 8.regulator: Consumer c1 does not have device name
[ 0.511853] reg-fixed-voltage 8.regulator: Consumer c2 does not have device name
[ 0.511885] reg-fixed-voltage 8.regulator: Consumer c3 does not have device name
[ 0.511922] reg-fixed-voltage 8.regulator: Consumer c6 does not have device name
[ 0.511953] reg-fixed-voltage 8.regulator: Consumer c7 does not have device name
[ 0.511984] reg-fixed-voltage 8.regulator: Consumer c8 does not have device name
[ 0.512015] reg-fixed-voltage 8.regulator: Consumer c9 does not have device name
[ 0.512046] reg-fixed-voltage 8.regulator: Consumer c10 does not have device name
[ 0.512077] reg-fixed-voltage 8.regulator: Consumer c11 does not have device name
[ 0.512127] reg-fixed-voltage 8.regulator: Consumer c12 does not have device name
[ 0.512173] of_get_named_gpio_flags: can't parse gpios property
[ 0.512262] reg-3v3-supply: 3300 mV
[ 0.513896] vgaarb: loaded
[ 0.514549] SCSI subsystem initialized
[ 0.514761] libata version 3.00 loaded.
[ 0.514945] usbcore: registered new interface driver usbfs
[ 0.515022] usbcore: registered new interface driver hub
[ 0.515142] usbcore: registered new device driver usb
[ 0.515395] of_get_named_gpio_flags exited with status 20
[ 0.515414] of_get_named_gpio_flags exited with status 21
[ 0.515826] of_get_named_gpio_flags exited with status 157
[ 0.515843] of_get_named_gpio_flags exited with status 158
[ 0.516084] of_get_named_gpio_flags exited with status 217
[ 0.516101] of_get_named_gpio_flags exited with status 218
[ 0.516348] of_get_named_gpio_flags exited with status 172
[ 0.516365] of_get_named_gpio_flags exited with status 173
[ 0.516598] of_get_named_gpio_flags exited with status 206
[ 0.516615] of_get_named_gpio_flags exited with status 207
[ 0.518023] as3722 4-0040: AS3722 ID: ID1:ID2:ID3 = 0x0c:0x01:0x15
[ 0.518054] as3722 4-0040: Final OTP version 1V21
[ 0.522773] gpiochip_find_base: found new base at 1016
[ 0.522868] gpiochip_add: registered GPIOs 1016 to 1023 on device: as3722-gpio
[ 0.522903] GPIO chip as3722-gpio: created GPIO range 0->7 ==> as3722-pinctrl PIN 0->7
[ 0.523078] as3722-regulator as3722-regulator.0: Consumer c1 does not have device name
[ 0.523139] as3722-regulator as3722-regulator.0: Consumer c1 does not have device name
[ 0.523193] as3722-regulator as3722-regulator.0: Consumer c1 does not have device name
[ 0.523225] as3722-regulator as3722-regulator.0: Consumer c2 does not have device name
[ 0.523257] as3722-regulator as3722-regulator.0: Consumer c3 does not have device name
[ 0.523308] as3722-regulator as3722-regulator.0: Consumer c4 does not have device name
[ 0.523370] as3722-regulator as3722-regulator.0: Consumer c1 does not have device name
[ 0.523402] as3722-regulator as3722-regulator.0: Consumer c2 does not have device name
[ 0.523435] as3722-regulator as3722-regulator.0: Consumer c3 does not have device name
[ 0.523467] as3722-regulator as3722-regulator.0: Consumer c4 does not have device name
[ 0.523499] as3722-regulator as3722-regulator.0: Consumer c5 does not have device name
[ 0.523530] as3722-regulator as3722-regulator.0: Consumer c6 does not have device name
[ 0.523562] as3722-regulator as3722-regulator.0: Consumer c7 does not have device name
[ 0.523628] as3722-regulator as3722-regulator.0: Consumer c1 does not have device name
[ 0.523660] as3722-regulator as3722-regulator.0: Consumer c2 does not have device name
[ 0.523691] as3722-regulator as3722-regulator.0: Consumer c3 does not have device name
[ 0.523723] as3722-regulator as3722-regulator.0: Consumer c4 does not have device name
[ 0.523758] as3722-regulator as3722-regulator.0: Consumer c6 does not have device name
[ 0.523792] as3722-regulator as3722-regulator.0: Consumer c8 does not have device name
[ 0.523823] as3722-regulator as3722-regulator.0: Consumer c9 does not have device name
[ 0.523855] as3722-regulator as3722-regulator.0: Consumer c10 does not have device name
[ 0.523888] as3722-regulator as3722-regulator.0: Consumer c11 does not have device name
[ 0.523920] as3722-regulator as3722-regulator.0: Consumer c12 does not have device name
[ 0.523952] as3722-regulator as3722-regulator.0: Consumer c13 does not have device name
[ 0.523984] as3722-regulator as3722-regulator.0: Consumer c14 does not have device name
[ 0.524016] as3722-regulator as3722-regulator.0: Consumer c15 does not have device name
[ 0.524072] as3722-regulator as3722-regulator.0: Consumer c1 does not have device name
[ 0.524104] as3722-regulator as3722-regulator.0: Consumer c2 does not have device name
[ 0.524159] as3722-regulator as3722-regulator.0: Consumer c1 does not have device name
[ 0.524191] as3722-regulator as3722-regulator.0: Consumer c2 does not have device name
[ 0.524223] as3722-regulator as3722-regulator.0: Consumer c3 does not have device name
[ 0.524255] as3722-regulator as3722-regulator.0: Consumer c4 does not have device name
[ 0.524286] as3722-regulator as3722-regulator.0: Consumer c5 does not have device name
[ 0.524336] as3722-regulator as3722-regulator.0: Consumer c6 does not have device name
[ 0.524369] as3722-regulator as3722-regulator.0: Consumer c7 does not have device name
[ 0.524401] as3722-regulator as3722-regulator.0: Consumer c8 does not have device name
[ 0.524432] as3722-regulator as3722-regulator.0: Consumer c9 does not have device name
[ 0.524492] as3722-regulator as3722-regulator.0: Consumer c2 does not have device name
[ 0.524524] as3722-regulator as3722-regulator.0: Consumer c3 does not have device name
[ 0.524615] as3722-regulator as3722-regulator.0: Consumer c8 does not have device name
[ 0.524647] as3722-regulator as3722-regulator.0: Consumer c9 does not have device name
[ 0.524679] as3722-regulator as3722-regulator.0: Consumer c10 does not have device name
[ 0.524735] as3722-regulator as3722-regulator.0: Consumer c1 does not have device name
[ 0.524787] as3722-regulator as3722-regulator.0: Consumer c1 does not have device name
[ 0.524819] as3722-regulator as3722-regulator.0: Consumer c2 does not have device name
[ 0.524851] as3722-regulator as3722-regulator.0: Consumer c3 does not have device name
[ 0.524907] as3722-regulator as3722-regulator.0: Consumer c1 does not have device name
[ 0.524939] as3722-regulator as3722-regulator.0: Consumer c2 does not have device name
[ 0.524996] as3722-regulator as3722-regulator.0: Consumer c2 does not have device name
[ 0.525052] as3722-regulator as3722-regulator.0: Consumer c1 does not have device name
[ 0.525084] as3722-regulator as3722-regulator.0: Consumer c2 does not have device name
[ 0.525159] as3722-regulator as3722-regulator.0: Consumer c1 does not have device name
[ 0.525191] as3722-regulator as3722-regulator.0: Consumer c2 does not have device name
[ 0.525223] as3722-regulator as3722-regulator.0: Consumer c3 does not have device name
[ 0.526175] vdd-cpu: 650 <--> 1300 mV at 1000 mV 3500 mA
[ 0.526948] vdd-core: applied init 1150000uV constraint
[ 0.527554] vdd-core: 700 <--> 1350 mV at 1150 mV 3500 mA
[ 0.528756] vddio-ddr: at 1350 mV
[ 0.529088] as3722-sd3: no parameters
[ 0.529677] avdd-pll-pex: 1050 mV
[ 0.530888] vdd-1v8: at 1800 mV
[ 0.531227] vdd-gpu: applied init 1000000uV constraint
[ 0.532124] vdd-gpu: 650 <--> 1200 mV at 1000 mV 3500 mA
[ 0.532641] avdd-pll: at 1050 mV at 300 mA
[ 0.533931] vdd-cam: 1800 mV at 150 mA
[ 0.534616] avdd-dsi-csi: at 1200 mV at 150 mA
[ 0.535853] vdd-rtc: 800 mV at 150 mA
[ 0.536333] avdd-cam: 2800 mV at 150 mA
[ 0.536844] vdd-1v2-cam: 1175 mV at 150 mA
[ 0.537222] vddio-sdmmc-2: 1800 <--> 3300 mV at 150 mA
[ 0.537729] vdd-1v1-cam: 1275 mV at 150 mA
[ 0.538700] avdd-spi: 3300 mV at 150 mA
[ 0.539207] vdd-2v7-cam: 2800 mV at 150 mA
[ 0.539714] vpp-fuse: 1800 mV at 150 mA
[ 0.540336] of_get_named_gpio_flags: can't parse gpios property
[ 0.540346] of_get_named_gpio_flags: can't parse gpios property
[ 0.540836] Linux video capture interface: v2.00
[ 0.541960] Advanced Linux Sound Architecture Driver Initialized.
[ 0.542404] ardbeg_wifi_power: 1
[ 0.642623] of_get_named_gpio_flags exited with status 108
[ 0.642745] usb0-vbus: 5000 mV
[ 0.642935] of_get_named_gpio_flags exited with status 109
[ 0.643056] usb1-usb2-vbus: 5000 mV
[ 0.643230] of_get_named_gpio_flags exited with status 86
[ 0.643367] vdd-hdmi: 5000 mV
[ 0.643541] of_get_named_gpio_flags exited with status 63
[ 0.643650] avdd-hdmi-pll: 3300 mV
[ 0.643700] avdd-hdmi-pll: supplied by avdd-pll-pex
[ 0.643870] reg-fixed-sync-voltage 6.regulator: Consumer c1 does not have device name
[ 0.643914] of_get_named_gpio_flags exited with status 122
[ 0.644022] vdd-lcd-bl: 3300 mV
[ 0.644177] reg-fixed-sync-voltage 7.regulator: Consumer c1 does not have device name
[ 0.644222] of_get_named_gpio_flags exited with status 58
[ 0.644357] vdd-lcd-bl-en: 5000 mV
[ 0.644510] reg-fixed-sync-voltage 9.regulator: Consumer c3 does not have device name
[ 0.644542] of_get_named_gpio_flags: can't parse gpios property
[ 0.644631] reg-5v0-supply: 5000 mV
[ 0.644797] reg-fixed-sync-voltage a.regulator: Consumer c1 does not have device name
[ 0.644831] reg-fixed-sync-voltage a.regulator: Consumer c2 does not have device name
[ 0.644863] reg-fixed-sync-voltage a.regulator: Consumer c3 does not have device name
[ 0.644912] reg-fixed-sync-voltage a.regulator: Consumer c10 does not have device name
[ 0.644944] reg-fixed-sync-voltage a.regulator: Consumer c11 does not have device name
[ 0.644976] reg-fixed-sync-voltage a.regulator: Consumer c12 does not have device name
[ 0.645008] reg-fixed-sync-voltage a.regulator: Consumer c13 does not have device name
[ 0.645040] reg-fixed-sync-voltage a.regulator: Consumer c14 does not have device name
[ 0.645071] reg-fixed-sync-voltage a.regulator: Consumer c15 does not have device name
[ 0.645126] of_get_named_gpio_flags: can't parse gpios property
[ 0.645222] reg-1v8-supply: 1800 mV
[ 0.645568] reg-fixed-sync-voltage b.regulator: Consumer c1 does not have device name
[ 0.645614] of_get_named_gpio_flags exited with status 138
[ 0.645724] reg-dcdc-1v2: 1200 mV
[ 0.645898] reg-fixed-sync-voltage c.regulator: Consumer c7 does not have device name
[ 0.645932] reg-fixed-sync-voltage c.regulator: Consumer c8 does not have device name
[ 0.645975] of_get_named_gpio_flags exited with status 1018
[ 0.646520] as3722-gpio2-supply: 3300 mV
[ 0.646744] reg-fixed-sync-voltage d.regulator: Consumer c1 does not have device name
[ 0.646790] of_get_named_gpio_flags exited with status 1020
[ 0.647268] as3722-gpio4-supply: 3300 mV
[ 0.647460] of_get_named_gpio_flags exited with status 136
[ 0.647571] sdmmc-en-supply: 3300 mV
[ 0.647736] of_get_named_gpio_flags exited with status 138
[ 0.647838] vdd-cdc-1v2-aud: 1200 mV
[ 0.647994] reg-fixed-sync-voltage 10.regulator: Consumer c1 does not have device name
[ 0.648029] reg-fixed-sync-voltage 10.regulator: Consumer c2 does not have device name
[ 0.648061] reg-fixed-sync-voltage 10.regulator: Consumer c3 does not have device name
[ 0.648091] of_get_named_gpio_flags: can't parse gpios property
[ 0.648186] reg-aon-1v8: 1800 mV
[ 0.648366] reg-fixed-sync-voltage 11.regulator: Consumer c1 does not have device name
[ 0.648398] of_get_named_gpio_flags: can't parse gpios property
[ 0.648488] reg-aon-1v2: 1200 mV
[ 0.651518] as3722-adc-extcon as3722-adc-extcon.2: USB-Host is disconnected
[ 0.654940] tegra: started io power detection dynamic control
[ 0.654968] tegra: NO_IO_POWER setting 0x0
[ 0.654994] Switching to clocksource arch_sys_counter
[ 0.676552] nvmap_heap_init: nvmap_heap_init: created heap block cache
[ 0.676742] nvmap_page_pool_init: Total MB RAM: 1891
[ 0.676766] nvmap_page_pool_init: nvmap page pool size: 60543 pages (236 MB)
[ 0.676926] nvmap_background_zero_thread: PP zeroing thread starting.
[ 0.677124] iram: dma coherent mem declare 0x40001000,258048
[ 0.677936] misc nvmap: created heap iram base 0x40001000 size (252KiB)
[ 0.678140] nvmap:inner cache maint threshold=2097152
[ 0.688017] Wake39 for irq=52
[ 0.688138] tegra-otg tegra-otg: otg transceiver registered
[ 0.688495] NET: Registered protocol family 2
[ 0.689179] TCP established hash table entries: 8192 (order: 4, 65536 bytes)
[ 0.689386] TCP bind hash table entries: 8192 (order: 4, 65536 bytes)
[ 0.689588] TCP: Hash tables configured (established 8192 bind 8192)
[ 0.689650] TCP: reno registered
[ 0.689675] UDP hash table entries: 512 (order: 2, 16384 bytes)
[ 0.689733] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes)
[ 0.690023] NET: Registered protocol family 1
[ 0.690443] RPC: Registered named UNIX socket transport module.
[ 0.690469] RPC: Registered udp transport module.
[ 0.690490] RPC: Registered tcp transport module.
[ 0.690511] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.690538] PCI: CLS 0 bytes, default 64
[ 0.690787] tegra-fuse tegra-fuse: Fuse driver initialized succesfully
[ 0.696511] host1x host1x: initialized
[ 0.697756] CPU PMU: probing PMU on CPU 0
[ 0.697792] hw perfevents: enabled with ARMv7 Cortex-A15 PMU driver, 7 counters available
[ 0.698430] tegra_throttle : init passed
[ 0.698557] Tegra cpuquiet initialized: disabled
[ 0.698711] cpu-tegra: init EDP limit: 2065 MHz
[ 0.699708] thermal thermal_zone0: Registering thermal zone thermal_zone0 for type CPU-therm
[ 0.700112] thermal thermal_zone1: Registering thermal zone thermal_zone1 for type GPU-therm
[ 0.700350] thermal thermal_zone2: Registering thermal zone thermal_zone2 for type MEM-therm
[ 0.700595] thermal thermal_zone3: Registering thermal zone thermal_zone3 for type PLL-therm
[ 0.702151] bounce pool size: 64 pages
[ 0.703649] Installing knfsd (copyright (C) 1996 okir@monad.swb.de).
[ 0.703946] NTFS driver 2.1.30 [Flags: R/O].
[ 0.704250] fuse init (API version 7.22)
[ 0.704494] msgmni has been set to 1457
[ 0.705927] io scheduler noop registered (default)
[ 0.706261] of_get_named_gpio_flags: can't parse gpios property
[ 0.706272] of_get_named_gpio_flags: can't parse gpios property
[ 0.706281] of_get_named_gpio_flags: can't parse gpios property
[ 0.745339] PCI host bridge to bus 0000:00
[ 0.745369] pci_bus 0000:00: root bus resource [mem 0x32100000-0x3fffffff]
[ 0.745400] pci_bus 0000:00: root bus resource [mem 0x12100000-0x320fffff pref]
[ 0.745432] pci_bus 0000:00: root bus resource [io 0x1000-0xffff]
[ 0.745459] pci_bus 0000:00: No busn resource found for root bus, will use [bus 00-ff]
[ 0.745517] pci 0000:00:00.0: [10de:0e12] type 01 class 0x060400
[ 0.745611] pci 0000:00:00.0: PME# supported from D0 D1 D2 D3hot D3cold
[ 0.745841] PCI: bus0: Fast back to back transfers disabled
[ 0.745870] pci 0000:00:00.0: bridge configuration invalid ([bus 00-00]), reconfiguring
[ 0.746253] pci 0000:01:00.0: [10ec:8168] type 00 class 0x020000
[ 0.746289] pci 0000:01:00.0: reg 10: [io 0x0000-0x00ff]
[ 0.746336] pci 0000:01:00.0: reg 18: [mem 0x00000000-0x00000fff 64bit pref]
[ 0.746369] pci 0000:01:00.0: reg 20: [mem 0x00000000-0x00003fff 64bit pref]
[ 0.746473] pci 0000:01:00.0: supports D1 D2
[ 0.746483] pci 0000:01:00.0: PME# supported from D0 D1 D2 D3hot D3cold
[ 0.748114] PCI: bus1: Fast back to back transfers disabled
[ 0.748146] pci_bus 0000:01: busn_res: [bus 01-ff] end is updated to 01
[ 0.748163] pci_bus 0000:00: busn_res: [bus 00-ff] end is updated to 01
[ 0.748455] pcieport 0000:00:00.0: Signaling PME through PCIe PME interrupt
[ 0.748485] pci 0000:01:00.0: Signaling PME through PCIe PME interrupt
[ 0.748514] pcie_pme 0000:00:00.0:pcie01: service driver pcie_pme loaded
[ 0.748631] aer 0000:00:00.0:pcie02: service driver aer loaded
[ 0.748803] PCI host bridge to bus 0000:02
[ 0.748829] pci_bus 0000:02: root bus resource [mem 0x32100000-0x3fffffff]
[ 0.748858] pci_bus 0000:02: root bus resource [mem 0x12100000-0x320fffff pref]
[ 0.748888] pci_bus 0000:02: root bus resource [io 0x10000-0x1ffff]
[ 0.748915] pci_bus 0000:02: No busn resource found for root bus, will use [bus 02-ff]
[ 0.748969] pci 0000:02:00.0: [10de:0e13] type 01 class 0x060400
[ 0.749083] pci 0000:02:00.0: PME# supported from D0 D1 D2 D3hot D3cold
[ 0.749312] PCI: bus2: Fast back to back transfers disabled
[ 0.749341] pci 0000:02:00.0: bridge configuration invalid ([bus 00-00]), reconfiguring
[ 0.749549] pci 0000:03:00.0: [10ec:8168] type 00 class 0x020000
[ 0.749583] pci 0000:03:00.0: reg 10: [io 0x0000-0x00ff]
[ 0.749630] pci 0000:03:00.0: reg 18: [mem 0x00000000-0x00000fff 64bit]
[ 0.749663] pci 0000:03:00.0: reg 20: [mem 0x00000000-0x00003fff 64bit pref]
[ 0.749765] pci 0000:03:00.0: supports D1 D2
[ 0.749776] pci 0000:03:00.0: PME# supported from D0 D1 D2 D3hot D3cold
[ 0.751114] PCI: bus3: Fast back to back transfers disabled
[ 0.751144] pci_bus 0000:03: busn_res: [bus 03-ff] end is updated to 03
[ 0.751159] pci_bus 0000:02: busn_res: [bus 02-ff] end is updated to 03
[ 0.751408] pcieport 0000:02:00.0: Signaling PME through PCIe PME interrupt
[ 0.751437] pci 0000:03:00.0: Signaling PME through PCIe PME interrupt
[ 0.751466] pcie_pme 0000:02:00.0:pcie01: service driver pcie_pme loaded
[ 0.751582] aer 0000:02:00.0:pcie02: service driver aer loaded
[ 0.751691] pcieport 0000:02:00.0: BAR 8: assigned [mem 0x32100000-0x321fffff]
[ 0.751726] pcieport 0000:02:00.0: BAR 9: assigned [mem 0x12100000-0x121fffff 64bit pref]
[ 0.751760] pcieport 0000:02:00.0: BAR 7: assigned [io 0x10000-0x10fff]
[ 0.751792] pci 0000:03:00.0: BAR 4: assigned [mem 0x12100000-0x12103fff 64bit pref]
[ 0.751841] pci 0000:03:00.0: BAR 2: assigned [mem 0x32100000-0x32100fff 64bit]
[ 0.751887] pci 0000:03:00.0: BAR 0: assigned [io 0x10000-0x100ff]
[ 0.751919] pcieport 0000:02:00.0: PCI bridge to [bus 03]
[ 0.751946] pcieport 0000:02:00.0: bridge window [io 0x10000-0x10fff]
[ 0.751975] pcieport 0000:02:00.0: bridge window [mem 0x32100000-0x321fffff]
[ 0.752007] pcieport 0000:02:00.0: bridge window [mem 0x12100000-0x121fffff 64bit pref]
[ 0.752078] pcieport 0000:00:00.0: BAR 9: assigned [mem 0x12200000-0x122fffff 64bit pref]
[ 0.752113] pcieport 0000:00:00.0: BAR 7: assigned [io 0x1000-0x1fff]
[ 0.752144] pci 0000:01:00.0: BAR 4: assigned [mem 0x12200000-0x12203fff 64bit pref]
[ 0.752193] pci 0000:01:00.0: BAR 2: assigned [mem 0x12204000-0x12204fff 64bit pref]
[ 0.752240] pci 0000:01:00.0: BAR 0: assigned [io 0x1000-0x10ff]
[ 0.752270] pcieport 0000:00:00.0: PCI bridge to [bus 01]
[ 0.752296] pcieport 0000:00:00.0: bridge window [io 0x1000-0x1fff]
[ 0.752328] pcieport 0000:00:00.0: bridge window [mem 0x12200000-0x122fffff 64bit pref]
[ 0.752379] PCIE: No Link speed change happened
[ 0.752966] pwm-backlight pwm-backlight: unable to request PWM, trying legacy API
[ 0.753103] sysedp_create_consumer: unable to create pwm-backlight, no consumer_data for pwm-backlight found
[ 0.753988] tsec tsec: initialized
[ 0.755501] isp isp.0: initialized
[ 0.756495] isp isp.1: initialized
[ 0.758102] falcon vic03.0: initialized
[ 0.759340] falcon msenc: initialized
[ 0.760171] tegradc tegradc.0: DSI: HS clock rate is 464500
[ 0.761593] p,wuxga-10-1 panel dt support not available
[ 1.040968] tegradc tegradc.0: nominal-pclk:154700000 parent:154500000 div:1.0 pclk:154500000 153153000~168623000
[ 1.130236] tegradc tegradc.0: DSI pad calibration done
[ 1.137384] tegradc tegradc.0: probed
[ 1.137855] tegradc tegradc.0: fb registered
[ 1.137878] tegradc tegradc.0: nominal-pclk:154679000 parent:463500000 div:3.0 pclk:154500000 153132210~168600110
[ 1.143770] gpio wake4 for gpio=111
[ 1.144075] tegra-i2c tegra12-i2c.3: no acknowledge from address 0x50
[ 1.145105] tegradc tegradc.1: probed
[ 1.149466] Console: switching to colour frame buffer device 80x30
[ 1.154076] tegradc tegradc.1: fb registered
[ 1.155780] hdmi_state_machine_worker (tid edb0c080): state 7 (Takeover from bootloader), hpd 0, pending_hpd_evt 1
[ 1.159181] hdmi_state_machine_set_state_l: switching from state 7 (Takeover from bootloader) to state 0 (Reset)
[ 1.162565] tegra-apbdma tegra-apbdma: Tegra20 APB DMA driver register 32 channels
[ 1.166645] Serial: 8250/16550 driver, 4 ports, IRQ sharing disabled
[ 1.169693] serial8250.0: ttyS0 at MMIO 0x70006300 (irq = 122) is a Tegra
[ 1.171650] tegra_dc_hdmi_irq: start
[ 1.173591] tegra_dc_hdmi_irq: end
[ 1.175508] hdmi_state_machine_worker (tid edb29ac0): state 0 (Reset), hpd 1, pending_hpd_evt 1
[ 1.175514] hdmi_state_machine_set_state_l: switching from state 0 (Reset) to state 0 (Reset)
[ 1.215095] hdmi_state_machine_worker (tid edb29ac0): state 0 (Reset), hpd 1, pending_hpd_evt 0
[ 1.215100] hdmi_disable_l: audio_switch 0
[ 1.215103] hdmi_disable_l: hpd_switch 0
[ 1.215108] hdmi_state_machine_set_state_l: switching from state 0 (Reset) to state 1 (Check Plug)
[ 1.225100] hdmi_state_machine_worker (tid edb29ac0): state 1 (Check Plug), hpd 1, pending_hpd_evt 0
[ 1.225107] hdmi_state_machine_set_state_l: switching from state 1 (Check Plug) to state 2 (Check EDID)
[ 1.285101] hdmi_state_machine_worker (tid edb29ac0): state 2 (Check EDID), hpd 1, pending_hpd_evt 0
[ 1.287741] tegra-i2c tegra12-i2c.3: no acknowledge from address 0x50
[ 1.287825] hdmi_state_machine_set_state_l: switching from state 2 (Check EDID) to state 2 (Check EDID)
[ 1.347101] hdmi_state_machine_worker (tid edb29ac0): state 2 (Check EDID), hpd 1, pending_hpd_evt 0
[ 1.349893] tegra-i2c tegra12-i2c.3: no acknowledge from address 0x50
[ 1.349971] hdmi_state_machine_set_state_l: switching from state 2 (Check EDID) to state 2 (Check EDID)
[ 1.409104] hdmi_state_machine_worker (tid edb29ac0): state 2 (Check EDID), hpd 1, pending_hpd_evt 0
[ 1.409309] tegra-i2c tegra12-i2c.3: no acknowledge from address 0x50
[ 1.409386] hdmi_state_machine_set_state_l: switching from state 2 (Check EDID) to state 2 (Check EDID)
[ 1.469102] hdmi_state_machine_worker (tid edb29ac0): state 2 (Check EDID), hpd 1, pending_hpd_evt 0
[ 1.469306] tegra-i2c tegra12-i2c.3: no acknowledge from address 0x50
[ 1.469383] hdmi_state_machine_set_state_l: switching from state 2 (Check EDID) to state 2 (Check EDID)
[ 1.529100] hdmi_state_machine_worker (tid edb29ac0): state 2 (Check EDID), hpd 1, pending_hpd_evt 0
[ 1.529305] tegra-i2c tegra12-i2c.3: no acknowledge from address 0x50
[ 1.529381] Failed to read EDID after 5 times. Giving up.
[ 1.529385] hdmi_disable_l: audio_switch 0
[ 1.529388] hdmi_disable_l: hpd_switch 0
[ 1.529393] hdmi_state_machine_set_state_l: switching from state 2 (Check EDID) to state 3 (Disabled)
[ 3.760433] console [ttyS0] enabled
[ 3.766313] serial-tegra.0: ttyTHS0 at MMIO 0x70006000 (irq = 68) is a SERIAL_TEGRA
[ 3.777977] serial-tegra.1: ttyTHS1 at MMIO 0x70006040 (irq = 69) is a SERIAL_TEGRA
[ 3.789668] serial-tegra.2: ttyTHS2 at MMIO 0x70006200 (irq = 78) is a SERIAL_TEGRA
[ 3.806586] loop: module loaded
[ 3.811996] nct1008_nct72 0-004c: success in enabling rail vdd_nct72
[ 3.823521] gpio wake35 for gpio=70
[ 3.829208] nct1008_nct72 0-004c: nct1008_probe: initialized
[ 3.837530] thermal thermal_zone4: Registering thermal zone thermal_zone4 for type Tboard_tegra
[ 3.851398] thermal thermal_zone5: Registering thermal zone thermal_zone5 for type Tdiode_tegra
[ 3.866185] tegra_profiler: Branch: Dev
[ 3.872079] tegra_profiler: Version: 1.103
[ 3.878238] tegra_profiler: Samples version: 34
[ 3.884733] tegra_profiler: IO version: 18
[ 3.890696] armv7_pmu: arch: Cortex A15, type: 4, ver: 0
[ 3.898098] tegra_profiler: auth: init
[ 3.903968] GPS: mt3332_gps_mod_init: platform_driver_register ret = 0
[ 3.913082] tegra-sata tegra-sata.0: version 1.0
[ 3.913098] of_get_named_gpio_flags: can't parse gpios property
[ 3.913726] tegra-sata tegra-sata.0: AHCI 0001.0301 32 slots 2 ports 3 Gbps 0x1 impl TEGRA-SATA mode
[ 3.926627] tegra-sata tegra-sata.0: flags: 64bit ncq sntf pm led pmp pio slum part sadm apst
[ 3.940207] scsi0 : tegra-sata
[ 3.945625] scsi1 : tegra-sata
[ 3.950700] ata1: SATA max UDMA/133 irq 55
[ 3.956564] ata2: DUMMY
[ 3.962583] tun: Universal TUN/TAP device driver, 1.6
[ 3.969331] tun: (C) 1999-2004 Max Krasnyansky <maxk@qualcomm.com>
[ 3.977529] r8169 Gigabit Ethernet driver 2.3LK-NAPI loaded
[ 3.985531] r8169 0000:01:00.0 eth0: RTL8168evl/8111evl at 0xf0000000, 00:13:3b:0f:93:5c, XID 0c900800 IRQ 642
[ 3.999039] r8169 0000:01:00.0 eth0: jumbo features [frames: 9200 bytes, tx checksumming: ko]
[ 4.011188] r8169 Gigabit Ethernet driver 2.3LK-NAPI loaded
[ 4.020857] r8169 0000:03:00.0 eth1: RTL8168g/8111g at 0xf0002000, 00:04:4b:5a:f0:d0, XID 0c000800 IRQ 643
[ 4.033944] r8169 0000:03:00.0 eth1: jumbo features [frames: 9200 bytes, tx checksumming: ko]
[ 4.046228] usbcore: registered new interface driver asix
[ 4.053601] usbcore: registered new interface driver ax88179_178a
[ 4.061637] usbcore: registered new interface driver cdc_ether
[ 4.069390] usbcore: registered new interface driver smsc95xx
[ 4.076987] usbcore: registered new interface driver cdc_subset
[ 4.084715] usbcore: registered new interface driver cdc_ncm
[ 4.092092] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[ 4.100466] ehci-pci: EHCI PCI platform driver
[ 4.106748] tegra_xusb_read_usb_calib: usb_calib0 = 0x02c4838a
[ 4.114618] usbcore: registered new interface driver usb-storage
[ 4.122445] usbcore: registered new interface driver usbserial
[ 4.130010] usbcore: registered new interface driver option
[ 4.137285] usbserial: USB Serial support registered for GSM modem (1-port)
[ 4.145998] usbcore: registered new interface driver pl2303
[ 4.153303] usbserial: USB Serial support registered for pl2303
[ 4.160917] Nvidia Tegra High-Speed USB Device Controller driver (Apr 30, 2012)
[ 4.171667] tegra USB phy - inst[0] platform info:
[ 4.178112] port_otg: yes
[ 4.182308] has_hostpc: yes
[ 4.186631] phy_interface: USB_PHY_INTF_UTMI
[ 4.192417] op_mode: TEGRA_USB_OPMODE_DEVICE
[ 4.198149] qc2_voltage: 0
[ 4.202247] vbus_pmu_irq: 0
[ 4.206365] vbus_gpio: -1
[ 4.210250] charging: enabled
[ 4.214497] remote_wakeup: disabled
[ 4.224574] tegra-udc tegra-udc.0: usb_bat_chg regulator not registered: USB charging will not be enabled
[ 4.239984] as3722-rtc as3722-rtc.1: rtc core: registered as3722 as rtc0
[ 4.248344] as3722-rtc as3722-rtc.1: RTC interrupt 449
[ 4.257804] i2c /dev entries driver
[ 4.263933] virtual_init
[ 4.265115] ata1: SATA link down (SStatus 0 SControl 300)
[ 4.276614] nvavp nvavp: allocated IOVA at 8ff00000 for AVP os
[ 4.284703] tegra_dtv_probe: probing dtv.
[ 4.290329] setup_stream: bufsize = 4096, bufnum = 4
[ 4.295565] ar0832_init: ++
[ 4.301763] i2c-core: driver [max77387] using legacy suspend method
[ 4.309636] i2c-core: driver [max77387] using legacy resume method
[ 4.317366] i2c-core: driver [as364x] using legacy suspend method
[ 4.324882] i2c-core: driver [as364x] using legacy resume method
[ 4.332469] [IMX135] sensor driver loading
[ 4.338037] [IMX179] sensor driver loading
[ 4.343617] [IMX185] sensor driver loading
[ 4.349102] [imx132] sensor driver loading
[ 4.354574] [AR0330] sensor driver loading
[ 4.360084] [ar0261] sensor driver loading
[ 4.365479] [AR1335] sensor driver loading
[ 4.370869] [ov4689] sensor driver loading
[ 4.377043] usbcore: registered new interface driver uvcvideo
[ 4.384112] USB Video Class driver (1.1.1)
[ 4.388101] otg state changed: SUSPEND --> PERIPHERAL
[ 4.396615] zram: Created 1 device(s) ...
[ 4.402826] tegra_wdt tegra_wdt.0: last reset is due to power on reset
[ 4.410836] WDT heartbeat enabled on probe
[ 4.416160] tegra_wdt_probe done
[ 4.420903] sdhci: Secure Digital Host Controller Interface driver
[ 4.428433] sdhci: Copyright(c) Pierre Ossman
[ 4.434076] sdhci-pltfm: SDHCI platform and OF driver helper
[ 4.441341] sdhci-tegra sdhci-tegra.3: vddio_sd_slot regulator not found: -517. Assuming vddio_sd_slot is not required.
[ 4.454911] sdhci-tegra sdhci-tegra.3: Speedo value 2313
[ 4.461617] sdhci-tegra sdhci-tegra.3: Tuning constraints: nom_mv 1150, boot_mv 1150, min_or_mv 1100
[ 4.473884] mmc0: no vqmmc regulator found
[ 4.479485] mmc0: no vmmc regulator found
[ 4.484853] mmc0: Invalid maximum block size, assuming 512 bytes
[ 4.492391] sysedp_create_consumer: unable to create sdhci-tegra.3, no consumer_data for sdhci-tegra.3 found
[ 4.527096] mmc0: SDHCI controller on sdhci-tegra.3 [sdhci-tegra.3] using ADMA
[ 4.540145] sdhci-tegra sdhci-tegra.2: Speedo value 2313
[ 4.547389] sdhci-tegra sdhci-tegra.2: Tuning constraints: nom_mv 1150, boot_mv 1150, min_or_mv 1100
[ 4.560674] mmc1: no vqmmc regulator found
[ 4.566700] mmc1: no vmmc regulator found
[ 4.572631] mmc1: Invalid maximum block size, assuming 512 bytes
[ 4.580655] sysedp_create_consumer: unable to create sdhci-tegra.2, no consumer_data for sdhci-tegra.2 found
[ 4.616094] mmc1: SDHCI controller on sdhci-tegra.2 [sdhci-tegra.2] using ADMA
[ 4.629363] gpio wake56 for gpio=170
[ 4.638760] tegra-se tegra12-se: tegra_se_probe: complete
[ 4.648794] usbcore: registered new interface driver usbhid
[ 4.656317] usbhid: USB HID core driver
[ 4.662572] tegra-hier-ictlr tegra-hier-ictlr: probed
[ 4.681824] mmc0: BKOPS_EN bit is not set
[ 4.692957] sdhci-tegra sdhci-tegra.3: Found T2T coeffs data
[ 4.700507] sdhci-tegra sdhci-tegra.3: 200MHz tap hole coeffs found
[ 4.768689] usbcore: registered new interface driver snd-usb-audio
[ 4.777322] MAX98090 driver built on Jun 7 2016 at 21:02:54
[ 4.785567] tegra_offload_platform probe successfull.
[ 4.793491] succefully registered offload opstegra30_avp_audio_platform_probe successful.
[ 5.067723] rt5639 0-001c: read 0xfd=0x6
[ 5.089218] rt5639 0-001c: ASoC: mux INR Mux has no paths
[ 5.096413] rt5639 0-001c: ASoC: mux INL Mux has no paths
[ 5.104502] gpio wake49 for gpio=143
[ 5.109897] rt5639 0-001c: rt5639_headset_detect jack_type = 1
[ 5.117781] tegra-snd-rt5639 tegra-snd-rt5639.0: rt5639-aif1 <-> tegra30-i2s.1 mapping ok
[ 5.130242] tegra-snd-rt5639 tegra-snd-rt5639.0: dit-hifi <-> tegra30-spdif mapping ok
[ 5.142575] tegra-snd-rt5639 tegra-snd-rt5639.0: dit-hifi <-> tegra30-i2s.3 mapping ok
[ 5.154902] tegra-snd-rt5639 tegra-snd-rt5639.0: rt5639-aif1 <-> dit-hifi mapping ok
[ 5.167194] tegra-snd-rt5639 tegra-snd-rt5639.0: dit-hifi <-> dit-hifi mapping ok
[ 5.179253] tegra-snd-rt5639 tegra-snd-rt5639.0: Allocating for stream playback
[ 5.190605] tegra-snd-rt5639 tegra-snd-rt5639.0: Allocating for stream capture
[ 5.202014] tegra-snd-rt5639 tegra-snd-rt5639.0: snd-soc-dummy-dai <-> tegra-offload-pcm mapping ok
[ 5.215969] compress asoc: snd-soc-dummy-dai <-> tegra-offload-compr mapping ok
[ 5.228256] tegra-snd-rt5639 tegra-snd-rt5639.0: Allocating for stream playback
[ 5.239989] tegra-snd-rt5639 tegra-snd-rt5639.0: Allocating for stream capture
[ 5.250093] **********Auto tuning windows*************
[ 5.250096] WIN_ATTR legend: 0-BOUN_ST, 1-BOUN_END, 2-HOLE
[ 5.250104] win[0]: 0(0) - 81(1)
[ 5.250108] win[1]: 88(0) - 167(1)
[ 5.250112] win[2]: 175(0) - 255(1)
[ 5.250116] ***************************************
[ 5.250126] ********tuning windows after inserting holes*****
[ 5.250129] WIN_ATTR legend: 0-BOUN_ST, 1-BOUN_END, 2-HOLE
[ 5.250133] win[0]:-84(0) - 1(1)
[ 5.250138] win[1]:2(0) - 2(1)
[ 5.250142] win[2]:3(0) - 45(2)
[ 5.250146] win[3]:47(2) - 81(1)
[ 5.250151] win[4]:88(0) - 131(2)
[ 5.250155] win[5]:133(2) - 167(1)
[ 5.250158] win[6]:175(0) - 217(2)
[ 5.250162] win[7]:219(2) - 255(1)
[ 5.250165] ***********************************************
[ 5.250169] **********Tuning values*********
[ 5.250171] **estimated values**
[ 5.250176] T2T_Vmax 55, T2T_Vmin 77, 1'st_hole_Vmax 49, UI_Vmax 90
[ 5.250179] **Calculated values**
[ 5.250183] T2T_Vmax 58, 1'st_hole_Vmax 46, UI_Vmax 86
[ 5.250186] T2T_Vmin 58, 1'st_hole_Vmin 46, UI_Vmin 86
[ 5.250189] ***********************************
[ 5.250196] ***********final tuning windows**********
[ 5.250199] win[0]: -67 - -16
[ 5.250203] win[1]: 19 - -15
[ 5.250206] win[2]: 20 - 36
[ 5.250209] win[3]: 57 - 64
[ 5.250212] win[4]: 105 - 116
[ 5.250215] win[5]: 149 - 150
[ 5.250218] win[6]: 192 - 196
[ 5.250221] win[7]: 241 - 238
[ 5.250223] ********************************
[ 5.250228] best tap win - (20-36), best tap value 28 prev_best_tap 0
[ 5.443433] tegra-snd-rt5639 tegra-snd-rt5639.0: snd-soc-dummy-dai <-> tegra-offload-pcm mapping ok
[ 5.455220] tegra-snd-rt5639 tegra-snd-rt5639.0: rt5639-aif1 <-> tegra30-i2s.1 mapping ok
[ 5.469665] input: tegra-rt5639 Headphone Jack as /devices/platform/tegra-snd-rt5639.0/sound/card1/input0
[ 5.483045] sysedp_create_consumer: unable to create speaker, no consumer_data for speaker found
[ 5.493929] oprofile: using timer interrupt.
[ 5.501339] GACT probability NOT on
[ 5.506262] Mirror/redirect action on
[ 5.511412] u32 classifier
[ 5.515545] Actions configured
[ 5.520354] Netfilter messages via NETLINK v0.30.
[ 5.526555] nf_conntrack version 0.5.0 (16384 buckets, 65536 max)
[ 5.534606] NF_TPROXY: Transparent proxy support initialized, version 4.1.0
[ 5.543131] NF_TPROXY: Copyright (c) 2006-2007 BalaBit IT Ltd.
[ 5.550916] xt_time: kernel timezone is -0000
[ 5.557208] ip_tables: (C) 2000-2006 Netfilter Core Team
[ 5.564454] arp_tables: (C) 2002 David S. Miller
[ 5.570836] TCP: cubic registered
[ 5.576094] NET: Registered protocol family 10
[ 5.583355] mip6: Mobile IPv6
[ 5.588174] ip6_tables: (C) 2000-2006 Netfilter Core Team
[ 5.595602] sit: IPv6 over IPv4 tunneling driver
[ 5.602918] NET: Registered protocol family 17
[ 5.609153] NET: Registered protocol family 15
[ 5.615401] NET: Registered protocol family 35
[ 5.621492] NET: Registered protocol family 37
[ 5.627475] NET: Registered protocol family 41
[ 5.634672] VFP support v0.3: implementor 41 architecture 4 part 30 variant f rev 0
[ 5.668523] Registering SWP/SWPB emulation handler
[ 5.674706] last reset is due to power on reset
[ 5.674706]
[ 5.683416] Disabling clocks left on by bootloader:
[ 5.689680] audio_2x
[ 5.693519] audio
[ 5.697067] audio4
[ 5.700624] audio3
[ 5.704104] audio2
[ 5.707521] audio1
[ 5.710880] audio0
[ 5.714265] hdmi_audio
[ 5.717889] entropy
[ 5.721222] dsi2-fixed
[ 5.724785] dsi1-fixed
[ 5.728322] nor
[ 5.731300] trace
[ 5.734307] sdmmc4_ddr
[ 5.737709] sdmmc3_ddr
[ 5.741143] cclk_lp
[ 5.744295] pll_x_out0
[ 5.747726] pll_m_out1
[ 5.751260] tegra_dvfs: vdd_cpu connected to regulator
[ 5.757271] tegra_dvfs: vdd_core connected to regulator
[ 5.763304] tegra_dvfs: vdd_gpu connected to regulator
[ 5.770141] cpu_cold cooling device is registered
[ 5.771337] Tegra CPU DFLL is initialized with use_dfll = 1
[ 5.771398] CPU rate: 696 MHz
[ 5.785387] cpu_hot cooling device is registered
[ 5.785829] **********Auto tuning windows*************
[ 5.785831] WIN_ATTR legend: 0-BOUN_ST, 1-BOUN_END, 2-HOLE
[ 5.785836] win[0]: 0(0) - 81(1)
[ 5.785840] win[1]: 87(0) - 169(1)
[ 5.785843] win[2]: 175(0) - 255(1)
[ 5.785845] ***************************************
[ 5.785852] ********tuning windows after inserting holes*****
[ 5.785854] WIN_ATTR legend: 0-BOUN_ST, 1-BOUN_END, 2-HOLE
[ 5.785857] win[0]:-1(0) - 47(2)
[ 5.785860] win[1]:49(2) - 81(1)
[ 5.785863] win[2]:87(0) - 135(2)
[ 5.785866] win[3]:137(2) - 169(1)
[ 5.785869] win[4]:175(0) - 223(2)
[ 5.785872] win[5]:225(2) - 255(1)
[ 5.785874] ***********************************************
[ 5.785878] **********Tuning values*********
[ 5.785879] **estimated values**
[ 5.785883] T2T_Vmax 55, T2T_Vmin 77, 1'st_hole_Vmax 49, UI_Vmax 90
[ 5.785885] **Calculated values**
[ 5.785888] T2T_Vmax 56, 1'st_hole_Vmax 48, UI_Vmax 88
[ 5.785890] T2T_Vmin 56, 1'st_hole_Vmin 48, UI_Vmin 89
[ 5.785892] ***********************************
[ 5.785897] ***********final tuning windows**********
[ 5.785900] win[0]: 16 - 37
[ 5.785902] win[1]: 60 - 64
[ 5.785905] win[2]: 104 - 120
[ 5.785907] win[3]: 154 - 152
[ 5.785910] win[4]: 192 - 203
[ 5.785912] win[5]: 248 - 238
[ 5.785914] ********************************
[ 5.785918] best tap win - (16-37), best tap value 27 prev_best_tap 28
[ 5.785928] sdhci-tegra sdhci-tegra.3: sdhci_tegra_verify_best_tap: tuning freq 200000000hz, best tap 27
[ 5.942595] tegra dvfs: tegra sysfs cap interface is initialized
[ 5.942688] tegra dvfs: tegra sysfs gpu & emc interface is initialized
[ 5.969937] tegra_actmon.emc: Completed initialization (0)
[ 5.970308] mmc0: new HS200 MMC card at address 0001
[ 5.970498] mmcblk mmc0:0001: Card claimed for testing.
[ 5.988975] mmcblk0: mmc0:0001 SEM16G 14.6 GiB
[ 5.989069] tegra_actmon.avp: Completed initialization (0)
[ 6.001611] tegra_mon.cpu_emc: Completed initialization (0)
[ 6.001623] mmcblk0rpmb: mmc0:0001 SEM16G partition 3 4.00 MiB
[ 6.004607] mmcblk0: p1 p2 p3 p4 p5 p6 p7 p8 p9
[ 6.023939] reg-aon-1v2: incomplete constraints, leaving on
[ 6.030742] reg-aon-1v8: incomplete constraints, leaving on
[ 6.037506] sdmmc-en-supply: incomplete constraints, leaving on
[ 6.044587] reg-dcdc-1v2: incomplete constraints, leaving on
[ 6.051467] reg-5v0-supply: incomplete constraints, leaving on
[ 6.058521] avdd-hdmi-pll: incomplete constraints, leaving on
[ 6.065560] usb1-usb2-vbus: incomplete constraints, leaving on
[ 6.072730] usb0-vbus: incomplete constraints, leaving on
[ 6.079470] vpp-fuse: incomplete constraints, leaving on
[ 6.086184] vdd-2v7-cam: incomplete constraints, leaving on
[ 6.093236] avdd-spi: incomplete constraints, leaving on
[ 6.100064] vdd-1v1-cam: incomplete constraints, leaving on
[ 6.107113] vddio-sdmmc-2: incomplete constraints, leaving on
[ 6.114285] vdd-1v2-cam: incomplete constraints, leaving on
[ 6.121275] avdd-cam: incomplete constraints, leaving on
[ 6.127948] vdd-cam: incomplete constraints, leaving on
[ 6.134582] as3722-sd3: incomplete constraints, leaving on
[ 6.141431] vdd-3v3-aon: incomplete constraints, leaving on
[ 6.148421] vdd-ac-bat: incomplete constraints, leaving on
[ 6.155331] regulator-dummy: incomplete constraints, leaving on
[ 6.163304] of_get_named_gpio_flags exited with status 128
[ 6.163351] gpio wake51 for gpio=128
[ 6.168556] input: gpio-keys.3 as /devices/platform/gpio-keys.3/input/input1
[ 6.178304] as3722-rtc as3722-rtc.1: setting system clock to 2017-03-13 12:47:28 UTC (1489409248)
[ 6.191109] ALSA device list:
[ 6.195266] #0: HDA NVIDIA Tegra at 0x70038000 irq 113
[ 6.201817] #1: tegra-rt5639
[ 6.206959] EXT4-fs (mmcblk0p1): couldn't mount as ext3 due to feature incompatibilities
[ 6.217988] EXT4-fs (mmcblk0p1): couldn't mount as ext2 due to feature incompatibilities
[ 6.499831] EXT4-fs (mmcblk0p1): ext4_orphan_cleanup: deleting unreferenced inode 133617
[ 6.499924] EXT4-fs (mmcblk0p1): ext4_orphan_cleanup: deleting unreferenced inode 815061
[ 6.500148] EXT4-fs (mmcblk0p1): ext4_orphan_cleanup: deleting unreferenced inode 814953
[ 6.500226] EXT4-fs (mmcblk0p1): ext4_orphan_cleanup: deleting unreferenced inode 815533
[ 6.500402] EXT4-fs (mmcblk0p1): ext4_orphan_cleanup: deleting unreferenced inode 815810
[ 6.500479] EXT4-fs (mmcblk0p1): ext4_orphan_cleanup: deleting unreferenced inode 809832
[ 6.500556] EXT4-fs (mmcblk0p1): ext4_orphan_cleanup: deleting unreferenced inode 815439
[ 6.500799] EXT4-fs (mmcblk0p1): ext4_orphan_cleanup: deleting unreferenced inode 815571
[ 6.500877] EXT4-fs (mmcblk0p1): ext4_orphan_cleanup: deleting unreferenced inode 131939
[ 6.500948] EXT4-fs (mmcblk0p1): ext4_orphan_cleanup: deleting unreferenced inode 131937
[ 6.501025] EXT4-fs (mmcblk0p1): ext4_orphan_cleanup: deleting unreferenced inode 805942
[ 6.501132] EXT4-fs (mmcblk0p1): ext4_orphan_cleanup: deleting unreferenced inode 131928
[ 6.501206] EXT4-fs (mmcblk0p1): ext4_orphan_cleanup: deleting unreferenced inode 131915
[ 6.501279] EXT4-fs (mmcblk0p1): ext4_orphan_cleanup: deleting unreferenced inode 814900
[ 6.501353] EXT4-fs (mmcblk0p1): ext4_orphan_cleanup: deleting unreferenced inode 807538
[ 6.501475] EXT4-fs (mmcblk0p1): ext4_orphan_cleanup: deleting unreferenced inode 815930
[ 6.501542] EXT4-fs (mmcblk0p1): 16 orphan inodes deleted
[ 6.508397] EXT4-fs (mmcblk0p1): recovery complete
[ 6.539356] EXT4-fs (mmcblk0p1): mounted filesystem with ordered data mode. Opts: (null)
[ 6.550317] VFS: Mounted root (ext4 filesystem) on device 179:1.
[ 6.560884] devtmpfs: mounted
[ 6.565601] Freeing unused kernel memory: 496K (c0b5c000 - c0bd8000)
[ 6.827635] init: plymouth-upstart-bridge main process (120) terminated with status 1
[ 6.839279] init: plymouth-upstart-bridge main process ended, respawning
[ 6.891502] init: plymouth-upstart-bridge main process (130) terminated with status 1
[ 6.903217] init: plymouth-upstart-bridge main process ended, respawning
[ 6.916238] init: ureadahead main process (123) terminated with status 5
[ 6.953617] init: plymouth-upstart-bridge main process (134) terminated with status 1
[ 6.965386] init: plymouth-upstart-bridge main process ended, respawning
[ 8.451360] systemd-udevd[309]: starting version 204
[ 8.794452] Tegra cpuquiet clusterswitch enabled
[ 8.846025] otg state changed: PERIPHERAL --> SUSPEND
[ 8.846250] tegra-udc tegra-udc.0: USB cable/charger disconnected
[ 8.846577] otg state changed: SUSPEND --> HOST
[ 8.847985] tegra USB phy - inst[0] platform info:
[ 8.848010] port_otg: yes
[ 8.848028] has_hostpc: yes
[ 8.848048] phy_interface: USB_PHY_INTF_UTMI
[ 8.848092] op_mode: TEGRA_USB_OPMODE_HOST
[ 8.848110] qc2_voltage: 0
[ 8.848131] vbus_gpio: -1
[ 8.848147] hot_plug: disabled
[ 8.848162] remote_wakeup: enabled
[ 8.885892] vi vi.0: vi_probe: ++
[ 8.894269] vi vi.0: initialized
[ 8.894919] vi vi.1: vi_probe: ++
[ 8.903655] vi vi.1: initialized
[ 8.965672] systemd-udevd[375]: renamed network interface eth0 to rename3
[ 8.973510] systemd-udevd[379]: renamed network interface eth1 to eth0
[ 9.025558] systemd-udevd[375]: renamed network interface rename3 to eth1
[ 9.150306] Bluetooth: Core ver 2.16
[ 9.150606] NET: Registered protocol family 31
[ 9.150622] Bluetooth: HCI device and connection manager initialized
[ 9.150690] Bluetooth: HCI socket layer initialized
[ 9.150720] Bluetooth: L2CAP socket layer initialized
[ 9.150786] Bluetooth: SCO socket layer initialized
[ 9.182772] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[ 9.182837] Bluetooth: BNEP socket layer initialized
[ 9.257931] Bluetooth: RFCOMM socket layer initialized
[ 9.257940] Bluetooth: RFCOMM ver 1.11
[ 9.303569] tegra-xhci tegra-xhci: Firmware File: tegra_xusb_firmware (134656 Bytes)
[ 9.304635] tegra-xhci tegra-xhci: Firmware DMA Memory: dma 0x800c0000 mapped 0xf05a9000 (134656 Bytes)
[ 9.307497] tegra-xhci tegra-xhci: XUSB device id = 0xfa3 (T124+)
[ 9.361590] tegra-xhci tegra-xhci: Firmware timestamp: 2014-09-16 02:10:07 UTC, Falcon state 0x0
[ 9.361693] tegra-xhci tegra-xhci: Nvidia xHCI Host Controller
[ 9.361724] tegra-xhci tegra-xhci: new USB bus registered, assigned bus number 1
[ 9.362555] tegra-xhci tegra-xhci: irq 71, io mem 0x70090000
[ 9.362668] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ 9.362681] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 9.362693] usb usb1: Product: Nvidia xHCI Host Controller
[ 9.362705] usb usb1: Manufacturer: Linux 3.10.40-ga7da876 tegra-xhci
[ 9.362715] usb usb1: SerialNumber: tegra-xhci
[ 9.363287] xHCI xhci_add_endpoint called for root hub
[ 9.363299] xHCI xhci_check_bandwidth called for root hub
[ 9.363482] hub 1-0:1.0: USB hub found
[ 9.363513] hub 1-0:1.0: 6 ports detected
[ 9.373731] tegra-xhci tegra-xhci: Nvidia xHCI Host Controller
[ 9.373765] tegra-xhci tegra-xhci: new USB bus registered, assigned bus number 2
[ 9.373970] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003
[ 9.373989] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 9.374003] usb usb2: Product: Nvidia xHCI Host Controller
[ 9.374018] usb usb2: Manufacturer: Linux 3.10.40-ga7da876 tegra-xhci
[ 9.374030] usb usb2: SerialNumber: tegra-xhci
[ 9.374573] xHCI xhci_add_endpoint called for root hub
[ 9.374587] xHCI xhci_check_bandwidth called for root hub
[ 9.374808] hub 2-0:1.0: USB hub found
[ 9.374840] hub 2-0:1.0: 2 ports detected
[ 9.382364] Wake58 for irq=81
[ 9.382398] Wake40 for irq=53
[ 9.382407] Wake42 for irq=53
[ 9.382430] Wake41 for irq=129
[ 9.382439] Wake43 for irq=129
[ 9.852811] tegra-ehci tegra-ehci.0: Tegra EHCI Host Controller
[ 9.852852] tegra-ehci tegra-ehci.0: new USB bus registered, assigned bus number 3
[ 9.852976] tegra-ehci tegra-ehci.0: irq 52, io mem 0x7d000000
[ 9.858099] tegra-ehci tegra-ehci.0: USB 2.0 started, EHCI 1.10
[ 9.858187] usb usb3: New USB device found, idVendor=1d6b, idProduct=0002
[ 9.858200] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 9.858212] usb usb3: Product: Tegra EHCI Host Controller
[ 9.858223] usb usb3: Manufacturer: Linux 3.10.40-ga7da876 ehci_hcd
[ 9.858233] usb usb3: SerialNumber: tegra-ehci.0
[ 9.858927] hub 3-0:1.0: USB hub found
[ 9.858954] hub 3-0:1.0: 1 port detected
[ 10.794745] init: failsafe main process (585) killed by TERM signal
[ 10.895195] init: Failed to obtain startpar-bridge instance: Unknown parameter: INSTANCE
[ 11.015804] device-mapper: uevent: version 1.0.3
[ 11.016085] device-mapper: ioctl: 4.24.0-ioctl (2013-01-15) initialised: dm-devel@redhat.com
[ 11.247167] r8169 0000:01:00.0 eth1: link down
[ 11.247222] r8169 0000:01:00.0 eth1: link down
[ 11.247319] IPv6: ADDRCONF(NETDEV_UP): eth1: link is not ready
[ 11.259168] r8169 0000:03:00.0 eth0: link down
[ 11.259211] r8169 0000:03:00.0 eth0: link down
[ 11.259303] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 11.585440] init: plymouth-upstart-bridge main process ended, respawning
[ 12.217463] Tegra cpuquiet clusterswitch disabled
[ 12.379227] init: plymouth-stop pre-start process (1087) terminated with status 1
[ 13.437077] r8169 0000:01:00.0 eth1: link up
[ 13.437093] IPv6: ADDRCONF(NETDEV_CHANGE): eth1: link becomes ready
[ 14.071693] r8169 0000:03:00.0 eth0: link up
[ 14.071712] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
[ 15.377089] HDMI: No HDMI device connected
