Jetson Nano 4Gb no HDMI output
Hello guys,
I have been using my jetson nano for some time now and while trying to install vpi2 in order to use jetson inference. I hooked it up to an external display just to find there is no output. When I first plug it in, the nvidia logo shows up and some other lines while it boots up, but then the screen goes black and keeps flickering grey after !
I looked for similar topics but they weren’t quiet close (like this one here : Jetson nano - no display from HDMI ). I can remotely access the card via ssh.
Any suggestions to what would be the problem ?
I have already started a topic (Jetson Nano no HDMI output) but did not have the time to continue troubleshooting.
@WayneWWW @linuxdev
Here is the output of the Xorg.0.log file as requested in the previous topic (This is it already plugged into an external monitor):
[ 5260.984] (–) Log file renamed from “/var/log/Xorg.pid-312.log” to “/var/log/Xorg.0.log”
[ 5260.985]
X.Org X Server 1.19.6
Release Date: 2017-12-20
[ 5260.985] X Protocol Version 11, Revision 0
[ 5260.985] Build Operating System: Linux 5.4.0-139-generic aarch64 Ubuntu
[ 5260.985] Current Operating System: Linux anas-desktop 4.9.253-tegra #1 SMP PREEMPT Mon Jul 26 12:13:06 PDT 2021 aarch64
[ 5260.985] Kernel command line: tegraid=21.1.2.0.0 ddr_die=4096M@2048M section=512M memtype=0 vpr_resize usb_port_owner_info=0 lane_owner_info=0 emc_max_dvfs=0 touch_id=0@63 video=tegrafb no_console_suspend=1 console=ttyS0,115200n8 debug_uartport=lsport,4 earlyprintk=uart8250-32bit,0x70006000 maxcpus=4 usbcore.old_scheme_first=1 lp0_vec=0x1000@0xff780000 core_edp_mv=1125 core_edp_ma=4000 gpt tegra_fbmem=0x800000@0x92cb4000 is_hdmi_initialised=1 earlycon=uart8250,mmio32,0x70006000 root=/dev/mmcblk0p1 rw rootwait rootfstype=ext4 console=ttyS0,115200n8 console=tty0 fbcon=map:0 net.ifnames=0 sdhci_tegra.en_boot_part_access=1 quiet root=/dev/nvme0n1 rw rootwait rootfstype=ext4 console=ttyS0,115200n8 console=tty0 fbcon=map:0 net.ifnames=0 sdhci_tegra.en_boot_part_access=1
[ 5260.985] Build Date: 29 March 2023 03:17:58PM
[ 5260.985] xorg-server 2:1.19.6-1ubuntu4.15 (For technical support please see Enterprise open source support | Ubuntu)
[ 5260.985] Current version of pixman: 0.34.0
[ 5260.985] Before reporting problems, check http://wiki.x.org
to make sure that you have the latest version.
[ 5260.985] Markers: (–) probed, () from config file, (==) default setting,
(++) from command line, (!!) notice, (II) informational,
(WW) warning, (EE) error, (NI) not implemented, (??) unknown.
[ 5260.986] (==) Log file: “/var/log/Xorg.0.log”, Time: Wed Nov 1 08:12:33 2023
[ 5260.986] (==) Using config file: “/etc/X11/xorg.conf”
[ 5260.986] (==) Using system config directory “/usr/share/X11/xorg.conf.d”
[ 5260.986] (==) No Layout section. Using the first Screen section.
[ 5260.986] (==) No screen section available. Using defaults.
[ 5260.986] (
) |–>Screen “Default Screen Section” (0)
[ 5260.986] () | |–>Monitor “”
[ 5260.987] (==) No device specified for screen “Default Screen Section”.
Using the first device section listed.
[ 5260.987] (
) | |–>Device “Tegra0”
[ 5260.987] (==) No monitor specified for screen “Default Screen Section”.
Using a default monitor configuration.
[ 5260.987] (==) Automatically adding devices
[ 5260.987] (==) Automatically enabling devices
[ 5260.987] (==) Automatically adding GPU devices
[ 5260.987] (==) Automatically binding GPU devices
[ 5260.987] (==) Max clients allowed: 256, resource mask: 0x1fffff
[ 5260.987] (WW) The directory “/usr/share/fonts/X11/cyrillic” does not exist.
[ 5260.987] Entry deleted from font path.
[ 5260.987] (WW) The directory “/usr/share/fonts/X11/100dpi/” does not exist.
[ 5260.988] (WW) The directory “/usr/share/fonts/X11/75dpi/” does not exist.
[ 5260.988] Entry deleted from font path.
[ 5260.988] (WW) The directory “/usr/share/fonts/X11/100dpi” does not exist.
[ 5260.988] (WW) The directory “/usr/share/fonts/X11/75dpi” does not exist.
[ 5260.988] (==) FontPath set to:
/usr/share/fonts/X11/misc,
/usr/share/fonts/X11/Type1,
built-ins
[ 5260.988] (==) ModulePath set to “/usr/lib/xorg/modules”
[ 5260.988] (II) The server relies on udev to provide the list of input devices.
If no devices become available, reconfigure udev or disable AutoAddDevices.
[ 5260.988] (II) Loader magic: 0x556773d010
[ 5260.988] (II) Module ABI versions:
[ 5260.988] X.Org ANSI C Emulation: 0.4
[ 5260.988] X.Org Video Driver: 23.0
[ 5260.988] X.Org XInput driver : 24.1
[ 5260.988] X.Org Server Extension : 10.0
[ 5260.994] (++) using VT number 1
[ 5260.999] (II) systemd-logind: took control of session /org/freedesktop/login1/session/c815
[ 5261.001] (II) no primary bus or device found
[ 5261.001] (WW) “dri” will not be loaded unless you’ve specified it to be loaded elsewhere.
[ 5261.001] (II) “glx” will be loaded by default.
[ 5261.001] (II) LoadModule: “extmod”
[ 5261.001] (II) Module “extmod” already built-in
[ 5261.001] (II) LoadModule: “glx”
[ 5261.001] (II) Loading /usr/lib/xorg/modules/extensions/libglx.so
[ 5261.004] (II) Module glx: vendor=“X.Org Foundation”
[ 5261.004] compiled for 1.19.6, module version = 1.0.0
[ 5261.004] ABI class: X.Org Server Extension, version 10.0
[ 5261.004] (II) LoadModule: “nvidia”
[ 5261.004] (II) Loading /usr/lib/xorg/modules/drivers/nvidia_drv.so
[ 5261.005] (II) Module nvidia: vendor=“NVIDIA Corporation”
[ 5261.005] compiled for 4.0.2, module version = 1.0.0
[ 5261.005] Module class: X.Org Video Driver
[ 5261.006] (II) NVIDIA dlloader X Driver 32.6.1 Release Build (integ_stage_rel) (buildbrain@mobile-u64-5755-d7000) Thu Sep 16 21:03:52 PDT 2021
[ 5261.006] (II) NVIDIA Unified Driver for all Supported NVIDIA GPUs
[ 5261.006] (WW) Falling back to old probe method for NVIDIA
[ 5261.006] (II) Loading sub module “fb”
[ 5261.006] (II) LoadModule: “fb”
[ 5261.006] (II) Loading /usr/lib/xorg/modules/libfb.so
[ 5261.006] (II) Module fb: vendor=“X.Org Foundation”
[ 5261.006] compiled for 1.19.6, module version = 1.0.0
[ 5261.007] ABI class: X.Org ANSI C Emulation, version 0.4
[ 5261.007] (II) Loading sub module “wfb”
[ 5261.007] (II) LoadModule: “wfb”
[ 5261.007] (II) Loading /usr/lib/xorg/modules/libwfb.so
[ 5261.007] (II) Module wfb: vendor=“X.Org Foundation”
[ 5261.007] compiled for 1.19.6, module version = 1.0.0
[ 5261.007] (II) Loading sub module “ramdac”
[ 5261.007] (II) LoadModule: “ramdac”
[ 5261.007] (II) Module “ramdac” already built-in
[ 5261.009] (WW) VGA arbiter: cannot open kernel arbiter, no multi-card support
[ 5261.009] (II) NVIDIA(0): Creating default Display subsection in Screen section
“Default Screen Section” for depth/fbbpp 24/32
[ 5261.009] (==) NVIDIA(0): Depth 24, (==) framebuffer bpp 32
[ 5261.009] (==) NVIDIA(0): RGB weight 888
[ 5261.009] (==) NVIDIA(0): Default visual is TrueColor
[ 5261.009] (==) NVIDIA(0): Using gamma correction (1.0, 1.0, 1.0)
[ 5261.009] (DB) xf86MergeOutputClassOptions unsupported bus type 0
[ 5261.009] () NVIDIA(0): Option “AllowEmptyInitialConfiguration” “true”
[ 5261.009] (
) NVIDIA(0): Enabling 2D acceleration
[ 5261.009] (II) Loading sub module “glxserver_nvidia”
[ 5261.009] (II) LoadModule: “glxserver_nvidia”
[ 5261.010] (II) Loading /usr/lib/xorg/modules/extensions/libglxserver_nvidia.so
[ 5261.017] (II) Module glxserver_nvidia: vendor=“NVIDIA Corporation”
[ 5261.017] compiled for 4.0.2, module version = 1.0.0
[ 5261.017] Module class: X.Org Server Extension
[ 5261.017] (II) NVIDIA GLX Module 32.6.1 Release Build (integ_stage_rel) (buildbrain@mobile-u64-5755-d7000) Thu Sep 16 21:02:40 PDT 2021
[ 5261.029] (–) NVIDIA(0): Valid display device(s) on GPU-0 at SoC
[ 5261.029] (–) NVIDIA(0): DFP-0
[ 5261.029] (–) NVIDIA(0): DFP-1
[ 5261.029] (II) NVIDIA(0): NVIDIA GPU NVIDIA Tegra X1 (nvgpu) (GM20B) at SoC (GPU-0)
[ 5261.029] (–) NVIDIA(0): Memory: 4051008 kBytes
[ 5261.030] (–) NVIDIA(0): VideoBIOS:
[ 5261.030] (–) NVIDIA(GPU-0): Tech Concepts MT5531 (DFP-0): connected
[ 5261.030] (–) NVIDIA(GPU-0): Tech Concepts MT5531 (DFP-0): External TMDS
[ 5261.030] (==) NVIDIA(0):
[ 5261.030] (==) NVIDIA(0): No modes were requested; the default mode “nvidia-auto-select”
[ 5261.030] (==) NVIDIA(0): will be used as the requested mode.
[ 5261.030] (II) NVIDIA(0): Validated MetaModes:
[ 5261.031] (II) NVIDIA(0): “DFP-0:nvidia-auto-select”
[ 5261.031] (II) NVIDIA(0): Virtual screen size determined to be 1360 x 768
[ 5261.032] (–) NVIDIA(0): DPI set to (59, 60); computed from “UseEdidDpi” X config
[ 5261.032] (–) NVIDIA(0): option
[ 5261.032] (–) Depth 24 pixmap format is 32 bpp
[ 5261.032] (II) NVIDIA: Reserving 6144.00 MB of virtual memory for indirect memory
[ 5261.032] (II) NVIDIA: access.
[ 5261.035] (EE) NVIDIA(0): Failed to allocate NVIDIA Error Handler
[ 5261.035] (II) NVIDIA(0): ACPI: failed to connect to the ACPI event daemon; the daemon
[ 5261.035] (II) NVIDIA(0): may not be running or the “AcpidSocketPath” X
[ 5261.035] (II) NVIDIA(0): configuration option may not be set correctly. When the
[ 5261.035] (II) NVIDIA(0): ACPI event daemon is available, the NVIDIA X driver will
[ 5261.035] (II) NVIDIA(0): try to use it to receive ACPI event notifications. For
[ 5261.035] (II) NVIDIA(0): details, please see the “ConnectToAcpid” and
[ 5261.035] (II) NVIDIA(0): “AcpidSocketPath” X configuration options in Appendix B: X
[ 5261.035] (II) NVIDIA(0): Config Options in the README.
[ 5261.086] (II) NVIDIA(0): Setting mode “DFP-0:nvidia-auto-select”
[ 5261.092] (==) NVIDIA(0): Disabling shared memory pixmaps
[ 5261.092] (==) NVIDIA(0): Backing store enabled
[ 5261.092] (==) NVIDIA(0): Silken mouse enabled
[ 5261.107] (==) NVIDIA(0): DPMS enabled
[ 5261.107] (II) Loading sub module “dri2”
[ 5261.107] (II) LoadModule: “dri2”
[ 5261.107] (II) Module “dri2” already built-in
[ 5261.107] (II) NVIDIA(0): [DRI2] Setup complete
[ 5261.107] (II) NVIDIA(0): [DRI2] VDPAU driver: nvidia
[ 5261.126] (–) RandR disabled
[ 5261.134] (II) SELinux: Disabled on system
[ 5261.135] (II) Initializing extension GLX
[ 5261.135] (II) Indirect GLX disabled.
[ 5261.222] (II) config/udev: Adding input device tegra-hda HDMI/DP,pcm=3 (/dev/input/event0)
[ 5261.222] (II) No input driver specified, ignoring this device.
[ 5261.222] (II) This device may have been added with another device file.
[ 5261.223] (II) config/udev: Adding input device gpio-keys (/dev/input/event2)
[ 5261.223] () gpio-keys: Applying InputClass “libinput keyboard catchall”
[ 5261.223] (II) LoadModule: “libinput”
[ 5261.224] (II) Loading /usr/lib/xorg/modules/input/libinput_drv.so
[ 5261.228] (II) Module libinput: vendor=“X.Org Foundation”
[ 5261.228] compiled for 1.19.6, module version = 0.27.1
[ 5261.228] Module class: X.Org XInput Driver
[ 5261.228] ABI class: X.Org XInput driver, version 24.1
[ 5261.228] (II) Using input driver ‘libinput’ for ‘gpio-keys’
[ 5261.231] (II) systemd-logind: got fd for /dev/input/event2 13:66 fd 34 paused 0
[ 5261.231] (
) gpio-keys: always reports core events
[ 5261.231] () Option “Device” “/dev/input/event2”
[ 5261.231] (
) Option “_source” “server/udev”
[ 5261.232] (II) event2 - gpio-keys: is tagged by udev as: Keyboard
[ 5261.232] (II) event2 - gpio-keys: device is a keyboard
[ 5261.232] (II) event2 - gpio-keys: device removed
[ 5261.233] () Option “config_info” “udev:/sys/devices/gpio-keys/input/input2/event2”
[ 5261.233] (II) XINPUT: Adding extended input device “gpio-keys” (type: KEYBOARD, id 6)
[ 5261.233] (
) Option “xkb_model” “pc105”
[ 5261.233] () Option “xkb_layout” “fr”
[ 5261.233] (
) Option “xkb_variant” “azerty”
[ 5261.275] (II) event2 - gpio-keys: is tagged by udev as: Keyboard
[ 5261.276] (II) event2 - gpio-keys: device is a keyboard
[ 5266.683] (**) Option “fd” “34”
[ 5266.685] (II) event2 - gpio-keys: device removed
[ 5266.694] (II) UnloadModule: “libinput”
[ 5266.694] (II) systemd-logind: releasing fd for 13:66
[ 5266.817] (II) NVIDIA(GPU-0): Deleting GPU-0
[ 5266.914] (II) Server terminated successfully (0). Closing log file.
The xorg log looks like just a termination log. For example, this log is from your previous system shutdown.
Looks like xorg didn’t launch in your next boot.
Please try to run something like xinit and see if xorg log got updated.
When I execute xinit I get this:
_XSERVTransSocketUNIXCreateListener: …SocketCreateListener() failed
_XSERVTransMakeAllCOTSServerListeners: server already running
(EE)
Fatal server error:
(EE) Cannot establish any listening sockets - Make sure an X server isn’t already running(EE)
(EE)
Please consult the The X.Org Foundation support
at http://wiki.x.org
for help.
(EE) Please also check the log file at “/var/log/Xorg.0.log” for additional information.
(EE)
(EE) Server terminated with error (1). Closing log file.
No protocol specified
xinit: giving up
xinit: unable to connect to X server: Resource temporarily unavailable
xinit: server error
I believe the .log file that I had shared previously was up to date because each time I want to copy it “gedit” informs me that it has been modified and to update it to the last version. Anyway, here is the last version as of now :
[ 313.361] (–) Log file renamed from “/var/log/Xorg.pid-12205.log” to “/var/log/Xorg.0.log”
[ 313.362]
[ 313.362] X Protocol Version 11, Revision 0
[ 313.362] Build Operating System: Linux 5.4.0-139-generic aarch64 Ubuntu
[ 313.362] Current Operating System: Linux anas-desktop 4.9.253-tegra #1 SMP PREEMPT Mon Jul 26 12:13:06 PDT 2021 aarch64
[ 313.362] Kernel command line: tegraid=21.1.2.0.0 ddr_die=4096M@2048M section=512M memtype=0 vpr_resize usb_port_owner_info=0 lane_owner_info=0 emc_max_dvfs=0 touch_id=0@63 video=tegrafb no_console_suspend=1 console=ttyS0,115200n8 debug_uartport=lsport,4 earlyprintk=uart8250-32bit,0x70006000 maxcpus=4 usbcore.old_scheme_first=1 lp0_vec=0x1000@0xff780000 core_edp_mv=1125 core_edp_ma=4000 gpt earlycon=uart8250,mmio32,0x70006000 root=/dev/mmcblk0p1 rw rootwait rootfstype=ext4 console=ttyS0,115200n8 console=tty0 fbcon=map:0 net.ifnames=0 sdhci_tegra.en_boot_part_access=1 quiet root=/dev/nvme0n1 rw rootwait rootfstype=ext4 console=ttyS0,115200n8 console=tty0 fbcon=map:0 net.ifnames=0 sdhci_tegra.en_boot_part_access=1
[ 313.362] Build Date: 29 March 2023 03:17:58PM
[ 313.362] xorg-server 2:1.19.6-1ubuntu4.15 (For technical support please see Enterprise open source support | Ubuntu)
[ 313.362] Current version of pixman: 0.34.0
[ 313.362] Before reporting problems, check http://wiki.x.org
[ 313.362] Markers: (–) probed, () from config file, (==) default setting,
[ 313.362] (==) Log file: “/var/log/Xorg.0.log”, Time: Wed Nov 1 11:52:54 2023
[ 313.363] (==) Using config file: “/etc/X11/xorg.conf”
[ 313.363] (==) Using system config directory “/usr/share/X11/xorg.conf.d”
[ 313.363] (==) No Layout section. Using the first Screen section.
[ 313.363] (==) No screen section available. Using defaults.
[ 313.363] (
[ 313.363] () | |–>Monitor “”
[ 313.364] (==) No device specified for screen “Default Screen Section”.
[ 313.364] (
[ 313.364] (==) No monitor specified for screen “Default Screen Section”.
[ 313.364] (==) Automatically adding devices
[ 313.364] (==) Automatically enabling devices
[ 313.364] (==) Automatically adding GPU devices
[ 313.364] (==) Automatically binding GPU devices
[ 313.364] (==) Max clients allowed: 256, resource mask: 0x1fffff
[ 313.364] (WW) The directory “/usr/share/fonts/X11/cyrillic” does not exist.
[ 313.364] Entry deleted from font path.
[ 313.364] (WW) The directory “/usr/share/fonts/X11/100dpi/” does not exist.
[ 313.364] (WW) The directory “/usr/share/fonts/X11/75dpi/” does not exist.
[ 313.364] (WW) The directory “/usr/share/fonts/X11/100dpi” does not exist.
[ 313.364] (WW) The directory “/usr/share/fonts/X11/75dpi” does not exist.
[ 313.364] (==) FontPath set to:
built-ins
[ 313.364] (==) ModulePath set to “/usr/lib/xorg/modules”
[ 313.365] (II) The server relies on udev to provide the list of input devices.
[ 313.365] (II) Loader magic: 0x558ab0c010
[ 313.365] (II) Module ABI versions:
[ 313.365] X.Org ANSI C Emulation: 0.4
[ 313.365] X.Org Video Driver: 23.0
[ 313.365] X.Org XInput driver : 24.1
[ 313.365] X.Org Server Extension : 10.0
[ 313.367] (++) using VT number 1
[ 313.371] (II) systemd-logind: took control of session /org/freedesktop/login1/session/c49
[ 313.373] (II) no primary bus or device found
[ 313.373] (WW) “dri” will not be loaded unless you’ve specified it to be loaded elsewhere.
[ 313.373] (II) “glx” will be loaded by default.
[ 313.373] (II) LoadModule: “extmod”
[ 313.374] (II) Module “extmod” already built-in
[ 313.374] (II) LoadModule: “glx”
[ 313.374] (II) Loading /usr/lib/xorg/modules/extensions/libglx.so
[ 313.376] (II) Module glx: vendor=“X.Org Foundation”
[ 313.376] compiled for 1.19.6, module version = 1.0.0
[ 313.376] ABI class: X.Org Server Extension, version 10.0
[ 313.376] (II) LoadModule: “nvidia”
[ 313.377] (II) Loading /usr/lib/xorg/modules/drivers/nvidia_drv.so
[ 313.378] (II) Module nvidia: vendor=“NVIDIA Corporation”
[ 313.378] compiled for 4.0.2, module version = 1.0.0
[ 313.378] Module class: X.Org Video Driver
[ 313.378] (II) NVIDIA dlloader X Driver 32.6.1 Release Build (integ_stage_rel) (buildbrain@mobile-u64-5755-d7000) Thu Sep 16 21:03:52 PDT 2021
[ 313.378] (II) NVIDIA Unified Driver for all Supported NVIDIA GPUs
[ 313.378] (WW) Falling back to old probe method for NVIDIA
[ 313.378] (II) Loading sub module “fb”
[ 313.378] (II) LoadModule: “fb”
[ 313.378] (II) Loading /usr/lib/xorg/modules/libfb.so
[ 313.379] (II) Module fb: vendor=“X.Org Foundation”
[ 313.379] compiled for 1.19.6, module version = 1.0.0
[ 313.379] ABI class: X.Org ANSI C Emulation, version 0.4
[ 313.379] (II) Loading sub module “wfb”
[ 313.379] (II) LoadModule: “wfb”
[ 313.379] (II) Loading /usr/lib/xorg/modules/libwfb.so
[ 313.379] (II) Module wfb: vendor=“X.Org Foundation”
[ 313.379] (II) Loading sub module “ramdac”
[ 313.379] (II) LoadModule: “ramdac”
[ 313.380] (II) Module “ramdac” already built-in
[ 313.381] (WW) VGA arbiter: cannot open kernel arbiter, no multi-card support
[ 313.381] (II) NVIDIA(0): Creating default Display subsection in Screen section
[ 313.381] (==) NVIDIA(0): Depth 24, (==) framebuffer bpp 32
[ 313.381] (==) NVIDIA(0): RGB weight 888
[ 313.381] (==) NVIDIA(0): Default visual is TrueColor
[ 313.381] (==) NVIDIA(0): Using gamma correction (1.0, 1.0, 1.0)
[ 313.381] (DB) xf86MergeOutputClassOptions unsupported bus type 0
[ 313.381] () NVIDIA(0): Option “AllowEmptyInitialConfiguration” “true”
[ 313.381] (
[ 313.381] (II) Loading sub module “glxserver_nvidia”
[ 313.381] (II) LoadModule: “glxserver_nvidia”
[ 313.382] (II) Loading /usr/lib/xorg/modules/extensions/libglxserver_nvidia.so
[ 313.389] (II) Module glxserver_nvidia: vendor=“NVIDIA Corporation”
[ 313.389] compiled for 4.0.2, module version = 1.0.0
[ 313.389] Module class: X.Org Server Extension
[ 313.389] (II) NVIDIA GLX Module 32.6.1 Release Build (integ_stage_rel) (buildbrain@mobile-u64-5755-d7000) Thu Sep 16 21:02:40 PDT 2021
[ 313.400] (–) NVIDIA(0): Valid display device(s) on GPU-0 at SoC
[ 313.400] (–) NVIDIA(0): DFP-0
[ 313.400] (–) NVIDIA(0): DFP-1
[ 313.400] (II) NVIDIA(0): NVIDIA GPU NVIDIA Tegra X1 (nvgpu) (GM20B) at SoC (GPU-0)
[ 313.400] (–) NVIDIA(0): Memory: 4059200 kBytes
[ 313.400] (–) NVIDIA(0): VideoBIOS:
[ 313.401] (–) NVIDIA(GPU-0): Tech Concepts MT5531 (DFP-0): connected
[ 313.401] (–) NVIDIA(GPU-0): Tech Concepts MT5531 (DFP-0): External TMDS
[ 313.401] (==) NVIDIA(0):
[ 313.401] (==) NVIDIA(0): No modes were requested; the default mode “nvidia-auto-select”
[ 313.401] (==) NVIDIA(0): will be used as the requested mode.
[ 313.401] (II) NVIDIA(0): Validated MetaModes:
[ 313.401] (II) NVIDIA(0): “DFP-0:nvidia-auto-select”
[ 313.401] (II) NVIDIA(0): Virtual screen size determined to be 1360 x 768
[ 313.403] (–) NVIDIA(0): DPI set to (59, 60); computed from “UseEdidDpi” X config
[ 313.403] (–) NVIDIA(0): option
[ 313.403] (–) Depth 24 pixmap format is 32 bpp
[ 313.403] (II) NVIDIA: Reserving 6144.00 MB of virtual memory for indirect memory
[ 313.403] (II) NVIDIA: access.
[ 313.406] (EE) NVIDIA(0): Failed to allocate NVIDIA Error Handler
[ 313.406] (II) NVIDIA(0): ACPI: failed to connect to the ACPI event daemon; the daemon
[ 313.406] (II) NVIDIA(0): may not be running or the “AcpidSocketPath” X
[ 313.406] (II) NVIDIA(0): configuration option may not be set correctly. When the
[ 313.406] (II) NVIDIA(0): ACPI event daemon is available, the NVIDIA X driver will
[ 313.406] (II) NVIDIA(0): try to use it to receive ACPI event notifications. For
[ 313.406] (II) NVIDIA(0): details, please see the “ConnectToAcpid” and
[ 313.406] (II) NVIDIA(0): “AcpidSocketPath” X configuration options in Appendix B: X
[ 313.406] (II) NVIDIA(0): Config Options in the README.
[ 313.460] (II) NVIDIA(0): Setting mode “DFP-0:nvidia-auto-select”
[ 313.466] (==) NVIDIA(0): Disabling shared memory pixmaps
[ 313.467] (==) NVIDIA(0): Backing store enabled
[ 313.467] (==) NVIDIA(0): Silken mouse enabled
[ 313.476] (==) NVIDIA(0): DPMS enabled
[ 313.476] (II) Loading sub module “dri2”
[ 313.477] (II) LoadModule: “dri2”
[ 313.477] (II) Module “dri2” already built-in
[ 313.477] (II) NVIDIA(0): [DRI2] Setup complete
[ 313.477] (II) NVIDIA(0): [DRI2] VDPAU driver: nvidia
[ 313.498] (–) RandR disabled
[ 313.506] (II) SELinux: Disabled on system
[ 313.507] (II) Initializing extension GLX
[ 313.507] (II) Indirect GLX disabled.
[ 313.598] (II) config/udev: Adding input device tegra-hda HDMI/DP,pcm=3 (/dev/input/event0)
[ 313.598] (II) No input driver specified, ignoring this device.
[ 313.598] (II) This device may have been added with another device file.
[ 313.599] (II) config/udev: Adding input device gpio-keys (/dev/input/event1)
[ 313.599] () gpio-keys: Applying InputClass “libinput keyboard catchall”
[ 313.599] (II) LoadModule: “libinput”
[ 313.599] (II) Loading /usr/lib/xorg/modules/input/libinput_drv.so
[ 313.603] (II) Module libinput: vendor=“X.Org Foundation”
[ 313.603] compiled for 1.19.6, module version = 0.27.1
[ 313.603] Module class: X.Org XInput Driver
[ 313.603] ABI class: X.Org XInput driver, version 24.1
[ 313.603] (II) Using input driver ‘libinput’ for ‘gpio-keys’
[ 313.605] (II) systemd-logind: got fd for /dev/input/event1 13:65 fd 34 paused 0
[ 313.605] (
[ 313.605] () Option “Device” “/dev/input/event1”
[ 313.605] (
[ 313.606] (II) event1 - gpio-keys: is tagged by udev as: Keyboard
[ 313.607] (II) event1 - gpio-keys: device is a keyboard
[ 313.607] (II) event1 - gpio-keys: device removed
[ 313.607] () Option “config_info” “udev:/sys/devices/gpio-keys/input/input1/event1”
[ 313.607] (II) XINPUT: Adding extended input device “gpio-keys” (type: KEYBOARD, id 6)
[ 313.607] (
[ 313.607] () Option “xkb_layout” “fr”
[ 313.607] (
[ 313.646] (II) event1 - gpio-keys: is tagged by udev as: Keyboard
[ 313.646] (II) event1 - gpio-keys: device is a keyboard
[ 319.131] (**) Option “fd” “34”
[ 319.135] (II) event1 - gpio-keys: device removed
[ 319.146] (II) UnloadModule: “libinput”
[ 319.147] (II) systemd-logind: releasing fd for 13:65
[ 319.264] (II) NVIDIA(GPU-0): Deleting GPU-0
[ 319.403] (II) Server terminated successfully (0). Closing log file.
Looks like previous log said xinit is already running in background.
Please check with ps aux and see if that is true.
Also, please share me the result of “df -h” command.
df -h gives this :
Filesystem Size Used Avail Use% Mounted on
/dev/nvme0n1 458G 16G 419G 4% /
none 1,8G 0 1,8G 0% /dev
tmpfs 2,0G 40K 2,0G 1% /dev/shm
tmpfs 2,0G 29M 2,0G 2% /run
tmpfs 5,0M 4,0K 5,0M 1% /run/lock
tmpfs 2,0G 0 2,0G 0% /sys/fs/cgroup
tmpfs 397M 16K 397M 1% /run/user/1000
tmpfs 397M 8,0K 397M 1% /run/user/120
ps aux gives this :
USER PID %CPU %MEM VSZ RSS TTY STAT START TIME COMMAND
root 1 5.6 0.2 161324 8404 ? Ss 14:21 0:09 /sbin/init 2
root 2 0.0 0.0 0 0 ? S 14:21 0:00 [kthreadd]
root 3 0.0 0.0 0 0 ? S 14:21 0:00 [ksoftirqd/0]
root 4 0.0 0.0 0 0 ? S 14:21 0:00 [kworker/0:0]
root 5 0.0 0.0 0 0 ? S< 14:21 0:00 [kworker/0:0H]
root 6 0.3 0.0 0 0 ? S 14:21 0:00 [kworker/u8:0]
root 7 0.0 0.0 0 0 ? S 14:21 0:00 [rcu_preempt]
root 8 0.0 0.0 0 0 ? S 14:21 0:00 [rcu_sched]
root 9 0.0 0.0 0 0 ? S 14:21 0:00 [rcu_bh]
root 10 0.0 0.0 0 0 ? S 14:21 0:00 [migration/0]
root 11 0.0 0.0 0 0 ? S< 14:21 0:00 [lru-add-drain]
root 12 0.0 0.0 0 0 ? S 14:21 0:00 [watchdog/0]
root 13 0.0 0.0 0 0 ? S 14:21 0:00 [cpuhp/0]
root 14 0.0 0.0 0 0 ? S 14:21 0:00 [cpuhp/1]
root 15 0.0 0.0 0 0 ? S 14:21 0:00 [watchdog/1]
root 16 0.0 0.0 0 0 ? S 14:21 0:00 [migration/1]
root 17 0.0 0.0 0 0 ? S 14:21 0:00 [ksoftirqd/1]
root 18 0.0 0.0 0 0 ? S 14:21 0:00 [kworker/1:0]
root 19 0.0 0.0 0 0 ? S< 14:21 0:00 [kworker/1:0H]
root 20 0.0 0.0 0 0 ? S 14:21 0:00 [cpuhp/2]
root 21 0.0 0.0 0 0 ? S 14:21 0:00 [watchdog/2]
root 22 0.0 0.0 0 0 ? S 14:21 0:00 [migration/2]
root 23 0.0 0.0 0 0 ? S 14:21 0:00 [ksoftirqd/2]
root 24 0.0 0.0 0 0 ? S 14:21 0:00 [kworker/2:0]
root 25 0.0 0.0 0 0 ? S< 14:21 0:00 [kworker/2:0H]
root 26 0.0 0.0 0 0 ? S 14:21 0:00 [cpuhp/3]
root 27 0.0 0.0 0 0 ? S 14:21 0:00 [watchdog/3]
root 28 0.0 0.0 0 0 ? S 14:21 0:00 [migration/3]
root 29 0.0 0.0 0 0 ? S 14:21 0:00 [ksoftirqd/3]
root 30 0.0 0.0 0 0 ? S 14:21 0:00 [kworker/3:0]
root 31 0.0 0.0 0 0 ? S< 14:21 0:00 [kworker/3:0H]
root 32 0.0 0.0 0 0 ? S 14:21 0:00 [kdevtmpfs]
root 33 0.0 0.0 0 0 ? S< 14:21 0:00 [netns]
root 34 0.0 0.0 0 0 ? S 14:21 0:00 [kworker/u8:1]
root 40 0.0 0.0 0 0 ? S 14:21 0:00 [kworker/u8:2]
root 65 0.1 0.0 0 0 ? S 14:21 0:00 [kworker/u8:3]
root 97 0.0 0.0 0 0 ? S 14:21 0:00 [irq/18-mc_stat
root 483 0.0 0.0 0 0 ? S 14:21 0:00 [kworker/u8:4]
root 590 0.0 0.0 0 0 ? S 14:21 0:00 [khungtaskd]
root 591 0.0 0.0 0 0 ? S 14:21 0:00 [oom_reaper]
root 592 0.0 0.0 0 0 ? S< 14:21 0:00 [writeback]
root 593 0.0 0.0 0 0 ? S 14:21 0:00 [kcompactd0]
root 595 0.0 0.0 0 0 ? SN 14:21 0:00 [ksmd]
root 596 0.0 0.0 0 0 ? SN 14:21 0:00 [khugepaged]
root 597 0.0 0.0 0 0 ? S< 14:21 0:00 [crypto]
root 598 0.0 0.0 0 0 ? S< 14:21 0:00 [kintegrityd]
root 599 0.0 0.0 0 0 ? S< 14:21 0:00 [bioset]
root 601 0.0 0.0 0 0 ? S< 14:21 0:00 [kblockd]
root 621 0.0 0.0 0 0 ? S< 14:21 0:00 [ata_sff]
root 638 0.0 0.0 0 0 ? S 14:21 0:00 [kworker/3:1]
root 648 0.0 0.0 0 0 ? S 14:21 0:00 [irq/355-max776
root 672 0.0 0.0 0 0 ? S 14:21 0:00 [kworker/0:1]
root 699 0.0 0.0 0 0 ? S< 14:21 0:00 [devfreq_wq]
root 725 0.0 0.0 0 0 ? S< 14:21 0:00 [watchdogd]
root 743 0.0 0.0 0 0 ? S 14:21 0:00 [vpr-shrink_thr
root 744 0.0 0.0 0 0 ? S 14:21 0:00 [nvmap-bz]
root 835 0.0 0.0 0 0 ? S 14:21 0:00 [kworker/2:1]
root 836 0.0 0.0 0 0 ? S< 14:21 0:00 [rpciod]
root 837 0.0 0.0 0 0 ? S< 14:21 0:00 [xprtiod]
root 840 0.0 0.0 0 0 ? S< 14:21 0:00 [host_low_prio_
root 841 0.0 0.0 0 0 ? S 14:21 0:00 [irq/68-host_sy
root 842 0.0 0.0 0 0 ? S 14:21 0:00 [irq/69-host_st
root 882 0.0 0.0 0 0 ? S 14:21 0:00 [kswapd0]
root 883 0.0 0.0 0 0 ? S< 14:21 0:00 [vmstat]
root 965 0.0 0.0 0 0 ? S< 14:21 0:00 [SquashFS read
root 968 0.0 0.0 0 0 ? S< 14:21 0:00 [nfsiod]
root 1008 0.0 0.0 0 0 ? S< 14:21 0:00 [kthrotld]
root 1047 0.0 0.0 0 0 ? S 14:21 0:00 [kworker/0:2]
root 1080 0.0 0.0 0 0 ? S< 14:21 0:00 [nvhdcp0]
root 1092 0.0 0.0 0 0 ? S 14:21 0:00 [kworker/3:2]
root 1104 0.0 0.0 0 0 ? S< 14:21 0:00 [nvhdcp0]
root 1126 0.0 0.0 0 0 ? S 14:21 0:00 [tegradc.0/a]
root 1129 0.0 0.0 0 0 ? S 14:21 0:00 [tegradc.0/b]
root 1139 0.0 0.0 0 0 ? S 14:21 0:00 [tegradc.0/c]
root 1142 0.0 0.0 0 0 ? S 14:21 0:00 [tegradc.0/d]
root 1143 0.0 0.0 0 0 ? S 14:21 0:00 [tegradc.0/e]
root 1144 0.0 0.0 0 0 ? S 14:21 0:00 [tegradc.0/sl]
root 1145 0.2 0.0 0 0 ? S 14:21 0:00 [irq/73-tegradc
root 1149 0.0 0.0 0 0 ? S 14:21 0:00 [irq/324-tegrad
root 1164 0.0 0.0 0 0 ? S 14:21 0:00 [irq/76-tegra_d
root 1186 0.0 0.0 0 0 ? S 14:21 0:00 [tegradc.1/a]
root 1187 0.0 0.0 0 0 ? S 14:21 0:00 [tegradc.1/b]
root 1188 0.0 0.0 0 0 ? S 14:21 0:00 [tegradc.1/c]
root 1189 0.0 0.0 0 0 ? S 14:21 0:00 [tegradc.1/d]
root 1190 0.0 0.0 0 0 ? S 14:21 0:00 [tegradc.1/e]
root 1191 0.0 0.0 0 0 ? S 14:21 0:00 [tegradc.1/sl]
root 1192 0.0 0.0 0 0 ? S 14:21 0:00 [irq/74-tegradc
root 1239 0.0 0.0 0 0 ? S 14:21 0:00 [kworker/1:1]
root 1256 0.0 0.0 0 0 ? S< 14:21 0:00 [bioset]
root 1257 0.0 0.0 0 0 ? S< 14:21 0:00 [bioset]
root 1258 0.0 0.0 0 0 ? S< 14:21 0:00 [bioset]
root 1259 0.0 0.0 0 0 ? S< 14:21 0:00 [bioset]
root 1260 0.0 0.0 0 0 ? S< 14:21 0:00 [bioset]
root 1261 0.0 0.0 0 0 ? S< 14:21 0:00 [bioset]
root 1262 0.0 0.0 0 0 ? S< 14:21 0:00 [bioset]
root 1263 0.0 0.0 0 0 ? S< 14:21 0:00 [bioset]
root 1264 0.0 0.0 0 0 ? S< 14:21 0:00 [bioset]
root 1265 0.0 0.0 0 0 ? S< 14:21 0:00 [bioset]
root 1266 0.0 0.0 0 0 ? S< 14:21 0:00 [bioset]
root 1267 0.0 0.0 0 0 ? S< 14:21 0:00 [bioset]
root 1268 0.0 0.0 0 0 ? S< 14:21 0:00 [bioset]
root 1269 0.0 0.0 0 0 ? S< 14:21 0:00 [bioset]
root 1270 0.0 0.0 0 0 ? S< 14:21 0:00 [bioset]
root 1271 0.0 0.0 0 0 ? S< 14:21 0:00 [bioset]
root 1305 0.0 0.0 0 0 ? S< 14:21 0:00 [bioset]
root 1308 0.0 0.0 0 0 ? S< 14:21 0:00 [bioset]
root 1311 0.0 0.0 0 0 ? S< 14:21 0:00 [bioset]
root 1314 0.0 0.0 0 0 ? S< 14:21 0:00 [bioset]
root 1317 0.0 0.0 0 0 ? S< 14:21 0:00 [bioset]
root 1320 0.0 0.0 0 0 ? S< 14:21 0:00 [bioset]
root 1323 0.0 0.0 0 0 ? S< 14:21 0:00 [bioset]
root 1326 0.0 0.0 0 0 ? S< 14:21 0:00 [bioset]
root 1336 0.0 0.0 0 0 ? S< 14:21 0:00 [kworker/u9:0]
root 1352 0.0 0.0 0 0 ? S< 14:21 0:00 [nvme]
root 1362 0.0 0.0 0 0 ? S 14:21 0:00 [irq/66-7000d40
root 1364 0.0 0.0 0 0 ? S 14:21 0:00 [spi0]
root 1367 0.0 0.0 0 0 ? S 14:21 0:00 [irq/67-7000d60
root 1369 0.0 0.0 0 0 ? S 14:21 0:00 [spi1]
root 1434 0.0 0.0 0 0 ? S< 14:21 0:00 [ixgbe]
root 1436 0.0 0.0 0 0 ? S< 14:21 0:00 [mlxsw_core]
root 1461 0.0 0.0 0 0 ? S< 14:21 0:00 [vfio-irqfd-cle
root 1473 0.0 0.0 0 0 ? S< 14:21 0:00 [uas]
root 1485 0.0 0.0 0 0 ? S 14:21 0:00 [kworker/3:3]
root 1488 0.0 0.0 0 0 ? S 14:21 0:00 [irq/60-7009000
root 1489 0.0 0.0 0 0 ? S 14:21 0:00 [irq/62-7009000
root 1511 0.0 0.0 0 0 ? S< 14:21 0:00 [bioset]
root 1512 0.0 0.0 0 0 ? S< 14:21 0:00 [bioset]
root 1516 0.0 0.0 0 0 ? S 14:21 0:00 [irq/19-tegra_r
root 1553 0.0 0.0 0 0 ? S 14:21 0:00 [irq/95-700e200
root 1554 0.0 0.0 0 0 ? S 14:21 0:00 [irq/96-socther
root 1575 0.0 0.0 0 0 ? S< 14:21 0:00 [kworker/3:1H]
root 1582 0.0 0.0 0 0 ? S 14:21 0:00 [cfinteractive]
root 1591 0.0 0.0 0 0 ? S 14:21 0:00 [kworker/3:4]
root 1592 0.0 0.0 0 0 ? S 14:21 0:00 [irq/91-mmc0]
root 1613 0.0 0.0 0 0 ? S 14:21 0:00 [irq/92-mmc1]
root 1615 0.0 0.0 0 0 ? S 14:21 0:00 [kworker/3:5]
root 1707 0.0 0.0 0 0 ? S 14:21 0:00 [irq/13-6000c80
root 1729 0.0 0.0 0 0 ? S 14:21 0:00 [kworker/1:2]
root 1789 0.0 0.0 0 0 ? S 14:21 0:00 [irq/301-sdhci-
root 1818 0.0 0.0 0 0 ? S< 14:21 0:00 [ipv6_addrconf]
root 1820 0.0 0.0 0 0 ? S< 14:21 0:00 [krfcommd]
root 1852 0.0 0.0 0 0 ? S< 14:21 0:00 [bioset]
root 1853 0.0 0.0 0 0 ? S 14:21 0:00 [mmcqd/0]
root 1854 0.0 0.0 0 0 ? S< 14:21 0:00 [bioset]
root 1858 0.0 0.0 0 0 ? S 14:21 0:00 [mmcqd/0boot0]
root 1859 0.0 0.0 0 0 ? S< 14:21 0:00 [bioset]
root 1860 0.0 0.0 0 0 ? S 14:21 0:00 [mmcqd/0boot1]
root 1861 0.0 0.0 0 0 ? S< 14:21 0:00 [bioset]
root 1862 0.0 0.0 0 0 ? S 14:21 0:00 [mmcqd/0rpmb]
root 1907 0.0 0.0 0 0 ? S< 14:21 0:00 [kworker/0:1H]
root 1908 0.0 0.0 0 0 ? S< 14:21 0:00 [kworker/1:1H]
root 1909 0.0 0.0 0 0 ? S< 14:21 0:00 [kworker/2:1H]
root 1910 0.0 0.0 0 0 ? S 14:21 0:00 [jbd2/nvme0n1-8
root 1911 0.0 0.0 0 0 ? S< 14:21 0:00 [ext4-rsv-conve
root 1919 0.0 0.0 0 0 ? S< 14:21 0:00 [kworker/u9:1]
root 1989 1.6 0.3 42964 14144 ? S<s 14:21 0:02 /lib/systemd/sy
root 2063 0.0 0.0 0 0 ? S 14:21 0:00 [kauditd]
root 2497 1.2 0.1 15824 4468 ? Ss 14:21 0:01 /lib/systemd/sy
root 2716 0.0 0.0 0 0 ? S 14:21 0:00 [irq/80-gk20a_s
root 2719 0.0 0.0 0 0 ? S 14:21 0:00 [kworker/2:2]
root 2720 0.0 0.0 0 0 ? S 14:21 0:00 [kworker/1:3]
root 2957 0.3 0.1 7680 5028 ? Ss 14:21 0:00 /usr/sbin/haveg
systemd+ 2959 0.0 0.1 10404 5248 ? Ss 14:21 0:00 /lib/systemd/sy
systemd+ 2975 0.0 0.0 83792 2476 ? Ssl 14:21 0:00 /lib/systemd/sy
root 2976 0.0 0.0 6408 3032 ? Ss 14:21 0:00 /sbin/rpcbind -
root 3844 0.2 0.4 100792 16824 ? Ssl 14:21 0:00 /usr/bin/python
syslog 3859 0.5 0.0 219968 3728 ? Ssl 14:21 0:00 /usr/sbin/rsysl
avahi 3898 0.1 0.0 6156 2716 ? Rs 14:21 0:00 avahi-daemon: r
root 3904 0.0 0.0 0 0 ? S 14:21 0:00 [kworker/u8:5]
root 3944 0.2 0.2 387852 11196 ? Ssl 14:21 0:00 /usr/lib/udisks
root 3965 0.6 0.1 10368 5244 ? Ss 14:21 0:01 /lib/systemd/sy
message+ 3983 3.5 0.1 8340 5088 ? Ss 14:21 0:05 /usr/bin/dbus-d
avahi 4055 0.0 0.0 5968 340 ? S 14:21 0:00 avahi-daemon: c
root 4113 0.2 0.1 9548 6424 ? Ss 14:21 0:00 /sbin/wpa_suppl
root 4120 2.0 0.4 402000 16464 ? Ssl 14:21 0:03 /usr/sbin/Netwo
root 4125 0.0 0.0 6636 2644 ? Ss 14:21 0:00 /usr/sbin/cron
root 4126 0.3 0.1 234212 6624 ? Ssl 14:21 0:00 /usr/lib/accoun
root 4152 0.1 0.2 312876 9028 ? Ssl 14:21 0:00 /usr/sbin/Modem
root 4158 0.0 0.0 0 0 ? S 14:21 0:00 [kworker/u8:6]
root 4343 0.0 0.0 0 0 ? S 14:21 0:00 [kworker/0:3]
root 4344 10.3 0.2 236448 8772 ? Ssl 14:21 0:16 /usr/lib/policy
root 4440 0.1 0.0 0 0 ? S 14:21 0:00 [sugov:0]
whoopsie 4535 0.1 0.2 321516 11676 ? Ssl 14:21 0:00 /usr/bin/whoops
kernoops 4633 0.0 0.0 9476 1696 ? Ss 14:21 0:00 /usr/sbin/kerne
root 4669 0.2 1.0 1557148 43728 ? Ssl 14:21 0:00 /usr/bin/contai
kernoops 4701 0.0 0.0 9476 1700 ? Ss 14:21 0:00 /usr/sbin/kerne
root 4721 0.0 0.0 0 0 ? S 14:21 0:00 [file-storage]
root 4729 0.0 0.0 0 0 ? S 14:21 0:00 [kworker/2:3]
root 4737 0.0 0.1 10412 5064 ? Ss 14:21 0:00 /usr/sbin/sshd
root 4805 0.0 0.0 0 0 ? S< 14:21 0:00 [loop0]
root 4822 0.0 0.0 11564 3340 ? S 14:21 0:00 /usr/sbin/xrdp-
xrdp 4940 0.0 0.0 9024 1680 ? S 14:21 0:00 /usr/sbin/xrdp
root 5016 0.0 0.0 6628 3156 ? Ss 14:21 0:00 /bin/bash /etc/
root 5024 0.0 0.0 21500 1412 ? Ssl 14:21 0:00 /usr/sbin/nvs-s
root 5073 0.2 0.0 0 0 ? S 14:21 0:00 [nvgpu_channel_
root 5076 0.0 0.0 4764 428 ? S 14:21 0:00 sleep 300
root 5092 0.0 0.4 72520 17692 ? Ss 14:21 0:00 /usr/sbin/nvarg
root 5195 0.0 0.0 0 0 ? S< 14:21 0:00 [bioset]
root 5200 0.0 0.0 0 0 ? S< 14:21 0:00 [bioset]
root 5204 0.0 0.0 0 0 ? S< 14:21 0:00 [bioset]
root 5207 0.0 0.0 0 0 ? S< 14:21 0:00 [bioset]
root 5231 0.3 0.1 235992 8104 ? Ssl 14:21 0:00 /usr/sbin/gdm3
root 5232 0.0 0.0 5276 2004 ttyS0 Ss+ 14:21 0:00 /sbin/agetty -o
root 5254 0.2 1.4 1353212 57964 ? Ssl 14:21 0:00 /usr/bin/docker
root 5378 0.0 0.0 3144 660 ? Ss 14:21 0:00 /usr/sbin/nvphs
root 5382 0.0 0.0 12260 1976 ? Sl 14:21 0:00 /usr/sbin/nvphs
root 5394 0.0 0.0 0 0 ? S< 14:21 0:00 [cfg80211]
root 5843 0.0 0.0 5276 2000 ttyGS0 Ss+ 14:21 0:00 /sbin/agetty -o
root 5844 0.0 0.0 6628 2932 ? Ss 14:21 0:00 /bin/bash /etc/
root 5885 0.0 0.0 5276 1928 ttyTHS1 Ss+ 14:21 0:00 /sbin/getty -L
root 6336 0.0 0.0 0 0 ? S 14:21 0:00 [RTW_CMD_THREAD
root 6627 0.0 0.1 247320 7832 ? Ssl 14:21 0:00 /usr/lib/upower
rtkit 6630 0.0 0.0 152372 2436 ? SNsl 14:21 0:00 /usr/lib/rtkit/
root 6638 0.0 0.0 7112 3992 ? Ss 14:21 0:00 /usr/lib/blueto
colord 6863 0.2 0.3 241456 12788 ? Ssl 14:21 0:00 /usr/lib/colord
root 6908 0.0 0.2 17516 11476 ? Ss 14:21 0:00 /usr/sbin/dhcpd
xrdp 7547 9.4 0.7 44588 30060 ? S 14:22 0:11 /usr/sbin/xrdp
root 7647 0.0 0.0 11564 2724 ? S 14:22 0:00 /usr/sbin/xrdp-
anas 7652 0.1 0.1 12712 7244 ? Ss 14:22 0:00 /lib/systemd/sy
anas 7653 0.0 0.0 163568 2892 ? S 14:22 0:00 (sd-pam)
anas 7665 0.3 0.3 549852 13152 ? Sl 14:22 0:00 /usr/lib/gnome-
anas 7666 1.2 1.9 818984 81144 ? Rl 14:22 0:01 /usr/lib/xorg/X
anas 7690 0.0 0.0 85984 2628 ? Sl 14:22 0:00 /usr/sbin/xrdp-
anas 7716 0.5 0.1 7628 4596 ? Ss 14:22 0:00 /usr/bin/dbus-d
anas 7744 0.0 0.1 235144 6564 ? Ssl 14:22 0:00 /usr/lib/gvfs/g
anas 7749 0.0 0.1 377016 4684 ? Sl 14:22 0:00 /usr/lib/gvfs/g
anas 7750 0.0 0.1 158176 4172 ? Ssl 14:22 0:00 /usr/lib/gvfs/g
anas 7783 0.0 0.0 4184 332 ? Ss 14:22 0:00 /usr/bin/ssh-ag
anas 7803 0.0 0.1 304384 5684 ? Ssl 14:22 0:00 /usr/lib/at-spi
anas 7808 0.0 0.0 6824 3620 ? S 14:22 0:00 /usr/bin/dbus-d
anas 7810 0.0 0.1 159320 5744 ? Sl 14:22 0:00 /usr/lib/at-spi
anas 7827 0.0 0.1 235568 7004 ? SLl 14:22 0:00 /usr/bin/gnome-
anas 7835 26.4 8.5 3811456 346984 ? Sl 14:22 0:31 /usr/bin/gnome-
anas 7852 0.0 0.1 942248 6660 ? Sl 14:22 0:00 /usr/bin/pulsea
anas 7864 0.0 0.1 381052 7304 ? Sl 14:22 0:00 ibus-daemon --x
anas 7868 0.0 0.1 232656 6148 ? Sl 14:22 0:00 /usr/lib/ibus/i
anas 7870 0.1 0.4 183216 19732 ? Sl 14:22 0:00 /usr/lib/ibus/i
anas 7872 0.0 0.1 232424 5512 ? Sl 14:22 0:00 /usr/lib/ibus/i
anas 7884 0.0 0.5 510812 22428 ? Sl 14:22 0:00 /usr/lib/gnome-
anas 7888 0.1 0.5 388068 24304 ? Ssl 14:22 0:00 /usr/lib/evolut
anas 7896 0.1 0.8 519280 35636 ? Sl 14:22 0:00 /usr/lib/gnome-
anas 7907 0.0 0.2 236556 9136 ? Sl 14:22 0:00 /usr/lib/gnome-
root 7942 0.1 0.1 234340 6372 ? Ssl 14:22 0:00 /usr/lib/aarch6
anas 7951 0.2 0.2 309792 10884 ? Ssl 14:22 0:00 /usr/lib/gvfs/g
anas 7980 0.0 0.1 233668 5536 ? Ssl 14:22 0:00 /usr/lib/gvfs/g
anas 7984 0.0 0.1 231924 5540 ? Ssl 14:22 0:00 /usr/lib/gvfs/g
anas 7988 0.0 0.1 231804 5340 ? Ssl 14:22 0:00 /usr/lib/gvfs/g
anas 7992 0.0 0.1 312028 7000 ? Ssl 14:22 0:00 /usr/lib/gvfs/g
root 7997 19.6 0.7 348452 29788 ? Ssl 14:22 0:22 /usr/lib/packag
anas 8020 0.2 0.5 406260 21284 ? Sl 14:22 0:00 /usr/lib/gnome-
anas 8025 0.0 0.2 243436 9028 ? Sl 14:22 0:00 /usr/lib/gnome-
anas 8030 0.0 0.1 379276 5496 ? Sl 14:22 0:00 /usr/lib/gnome-
anas 8032 0.0 0.1 231668 4576 ? Sl 14:22 0:00 /usr/lib/gnome-
anas 8036 0.2 0.2 386680 9208 ? Sl 14:22 0:00 /usr/lib/gnome-
anas 8038 0.0 0.1 310696 7240 ? Sl 14:22 0:00 /usr/lib/gnome-
anas 8045 0.2 0.5 332020 21524 ? Sl 14:22 0:00 /usr/lib/gnome-
anas 8050 0.0 0.1 239432 7432 ? Sl 14:22 0:00 /usr/lib/gnome-
anas 8062 0.2 0.4 257572 20072 ? Sl 14:22 0:00 /usr/lib/gnome-
anas 8075 0.2 0.4 182840 19232 ? Sl 14:22 0:00 /usr/lib/gnome-
anas 8076 0.0 0.1 232260 5472 ? Sl 14:22 0:00 /usr/lib/gnome-
anas 8079 0.0 0.3 288756 13476 ? Sl 14:22 0:00 /usr/lib/gnome-
anas 8083 0.2 0.5 480212 21244 ? Sl 14:22 0:00 /usr/lib/gnome-
anas 8084 0.2 0.5 331956 20628 ? Sl 14:22 0:00 /usr/lib/gnome-
anas 8087 0.0 0.1 307560 6012 ? Sl 14:22 0:00 /usr/lib/gnome-
anas 8089 0.0 0.1 232264 5500 ? Sl 14:22 0:00 /usr/lib/gnome-
anas 8096 0.2 0.5 884860 22692 ? Sl 14:22 0:00 /usr/lib/gnome-
anas 8104 0.0 0.2 333500 11472 ? Sl 14:22 0:00 /usr/lib/gnome-
anas 8157 0.7 1.0 497748 40668 ? Sl 14:22 0:00 python3 /usr/sh
anas 8161 0.0 0.1 309292 7360 ? Sl 14:22 0:00 /usr/lib/aarch6
anas 8190 0.5 0.6 371848 28200 ? Sl 14:22 0:00 /usr/lib/vino/v
anas 8209 0.0 0.1 229948 5824 ? Sl 14:22 0:00 /usr/lib/gnome-
anas 8214 0.0 0.2 249496 9756 ? Sl 14:22 0:00 /usr/lib/aarch6
anas 8250 0.7 1.6 576212 66224 ? Ssl 14:22 0:00 /usr/lib/evolut
anas 8272 0.0 0.5 496424 20708 ? S 14:22 0:00 python3 /usr/sh
anas 8273 0.0 0.5 496424 20712 ? S 14:22 0:00 python3 /usr/sh
anas 8275 0.0 0.5 496436 20732 ? S 14:22 0:00 python3 /usr/sh
anas 8276 0.0 0.5 496436 20732 ? S 14:22 0:00 python3 /usr/sh
anas 8277 0.1 0.5 496436 20748 ? S 14:22 0:00 python3 /usr/sh
anas 8278 0.0 0.5 496436 20716 ? S 14:22 0:00 python3 /usr/sh
anas 8279 0.0 0.5 496436 20716 ? S 14:22 0:00 python3 /usr/sh
anas 8300 0.7 1.5 925308 61700 ? Sl 14:22 0:00 /usr/lib/evolut
anas 8315 0.0 0.1 158768 6064 ? Sl 14:22 0:00 /usr/lib/ibus/i
anas 8327 0.0 0.1 155152 4936 ? Sl 14:22 0:00 /usr/lib/dconf/
anas 8329 0.0 0.6 519972 25748 ? Ssl 14:22 0:00 /usr/lib/evolut
anas 8345 0.1 0.6 814468 26600 ? Sl 14:22 0:00 /usr/lib/evolut
anas 8901 0.0 0.4 548960 16344 ? Sl 14:22 0:00 zeitgeist-datah
anas 8910 0.1 0.1 308452 7900 ? Ssl 14:22 0:00 /usr/bin/zeitge
anas 8982 0.5 1.3 902864 53876 ? Sl 14:22 0:00 /usr/bin/gnome-
anas 8985 0.5 0.8 452780 36196 ? SLl 14:22 0:00 /usr/bin/seahor
anas 8988 0.8 0.8 454064 35044 ? Rsl 14:22 0:00 /usr/lib/gnome-
anas 8990 10.0 3.8 921016 155292 ? SLl 14:22 0:09 /usr/bin/gnome-
anas 9008 0.0 0.1 309264 6804 ? Sl 14:22 0:00 /usr/lib/gvfs/g
anas 9129 0.1 0.1 8792 5476 pts/0 Ss 14:22 0:00 bash
root 9317 0.3 0.5 373328 22756 ? Ssl 14:22 0:00 /usr/lib/fwupd/
anas 9784 0.6 0.7 442424 29648 ? Sl 14:23 0:00 update-notifier
root 10344 1.3 0.1 163196 7404 ? Sl 14:24 0:00 gdm-session-wor
gdm 10356 3.0 0.1 12644 7008 ? Ss 14:24 0:00 /lib/systemd/sy
gdm 10357 0.0 0.0 163568 2892 ? S 14:24 0:00 (sd-pam)
gdm 10368 0.3 0.1 159596 5600 tty1 Ssl+ 14:24 0:00 /usr/lib/gdm3/g
root 10370 7.3 0.7 6434868 30508 tty1 Sl+ 14:24 0:00 /usr/lib/xorg/X
gdm 10377 0.3 0.0 6704 3492 ? Ss 14:24 0:00 /usr/bin/dbus-d
gdm 10383 0.6 0.2 32092 9316 tty1 S+ 14:24 0:00 /usr/lib/gnome-
gdm 10385 0.0 0.1 304268 5296 ? Ssl 14:24 0:00 /usr/lib/at-spi
gdm 10390 0.3 0.0 6596 3232 ? S 14:24 0:00 /usr/bin/dbus-d
gdm 10392 0.3 0.1 159104 6276 ? Sl 14:24 0:00 /usr/lib/at-spi
gdm 10398 1.0 0.2 30624 11132 tty1 S+ 14:24 0:00 /usr/lib/gnome-
anas 10399 0.0 0.0 8644 3184 pts/0 R+ 14:24 0:00 ps aux
please also share dmesg.
Also, please attach it as a file. It is really not a good idea to copy & paste…
Also, just a basic check.
Could you directly check the timestamp of your /var/log/Xorg.0.log right after you boot up the jetson? And make sure it is really updated after your boot up?
For example, if you boot up at13:33 11/1 2023, I expect the timestamp should be just around 13:33 but will not be much earlier than it.
Yes there you go, the xorg file is up to date
dmesg.txt (74.5 KB)
xorg_log.txt (11.2 KB)
The dmesg is full of display driver spew.
Thus, actually this log does not provide much help. It only tells there are indeed some problems.
Please also attach the kernel log from /var/log.
there are two kernel log files: kern.log and kern.log.1 which one ? kern.log doesn’t seem to work well, there is a problem with it (invalid characters)
Actually you can just reboot your device again and see which one got updated. Upload that one.
Okay here it is, it is a little more chunky
kern_log.txt (4.5 MB)
Also, I have seen in the dmsg file that the output is of 1360x768 which is the same that appears on the monitor. It comes for a few seconds and goes away same amount of time. Like the card is trying to output something of that size but keeps trying and trying infinitely.
There was in my last topic about the same subject something to do with the “edid” I don’t know if this is causing the problem ?
I just notice you are using a custom board and try to boot from nvme.
Is it possible to dump the log from serial console port? In case you don’t know the purpose here. This serial console log will print bootloader log but what you’ve dumped so far is only kernel log.
Also, just another point here. If you think dumping these logs took too much time, the quick way here is you could remove the nvme and flash the board again (it will flash to emmc).
Also, edid does not cause the problem
EDID is a memory in your monitor which jetson or any other HDMI source will read it to know what is the recommended resolution for this monitor.
How do I dump the log from serial console port ?
And if I won’t loose any data removing the ssd and flashing the emmc, that for me is the best way to go.
I already posted the method to dump serial console log in previous comment.
But that is only for devkit. I don’t know whether your custom board can do that or not.
My custom board doesn’t have the same layout and pins so I don’t wanna tamper with it.
Is there any solution without needing bootloader log ?
As I already said, just reflash the board.
Basically all the request items here are all just for debug. The root cause is not yet identified.
I guess something goes wrong in userspace so that kernel keeps doing repeating behavior.
For that case, reflash might be the fastest solution.
Yeah because also I was not able to download and start jetson inference, so I thought maybe reset it to default settings.
In an earlier log I did see this, which says that to some extent, it is working:
I am wondering, if you are on command line (perhaps via ssh or serial console, and not specifying a DISPLAY environment variable, which would interfere with this), does anything change if you stop and then start the GUI via:
# Making sure it attempts console only:
sudo systemctl isolate multi-user.target
# Now attempt GUI:
sudo systemctl isolate graphical.target
