Display not responding
My jetpack 4.6 jetson nano
i installed cuda10.2 components using dpkg command
This is my jtop image
after this , after powercycling the device , there is issue occuring in monitor
monitor is stuck or tries to get into ui , im able to access ssh and enter into board
debuflog_after_cuda_installation.txt (20.3 KB)
dmesg log after cuda installation
after_cuda.txt (100.7 KB)
device flash log before cuda installation
flash_device.txt (28.9 KB)
flashing log from host
flashing_host.txt (19.2 KB)
what is /var/log/Xorg.0.log result?
[ 366.835] (–) Log file renamed from “/var/log/Xorg.pid-26414.log” to “/var/log/Xorg.0.log”
[ 366.836]
X.Org X Server 1.19.6
Release Date: 2017-12-20
[ 366.836] X Protocol Version 11, Revision 0
[ 366.836] Build Operating System: Linux 4.15.0-140-generic aarch64 Ubuntu
[ 366.836] Current Operating System: Linux localhost.localdomain 4.9.253-tegra #1 SMP PREEMPT Mon Jul 11 18:23:13 IST 2022 aarch64
[ 366.836] Kernel command line: tegraid=21.1.2.0.0 ddr_die=4096M@2048M section=512M memtype=0 vpr_resize usb_port_owner_info=0 lane_owner_info=0 emc_max_dvfs=0 touch_id=0@63 video=tegrafb no_console_suspend=1 console=ttyS0,115200n8 debug_uartport=lsport,4 earlyprintk=uart8250-32bit,0x70006000 maxcpus=4 usbcore.old_scheme_first=1 lp0_vec=0x1000@0xff780000 core_edp_mv=1125 core_edp_ma=4000 gpt tegra_fbmem=0x800000@0x92cb4000 is_hdmi_initialised=1 earlycon=uart8250,mmio32,0x70006000 root=/dev/mmcblk0p1 rw rootwait rootfstype=ext4 console=ttyS0,115200n8 console=tty0 fbcon=map:0 net.ifnames=0 sdhci_tegra.en_boot_part_access=1 quiet root=/dev/mmcblk0p1 rw rootwait rootfstype=ext4 console=ttyS0,115200n8 console=tty0 fbcon=map:0 net.ifnames=0 sdhci_tegra.en_boot_part_access=1
[ 366.837] Build Date: 08 April 2021 01:53:49PM
[ 366.837] xorg-server 2:1.19.6-1ubuntu4.9 (For technical support please see http://www.ubuntu.com/support)
[ 366.837] Current version of pixman: 0.34.0
[ 366.837] Before reporting problems, check http://wiki.x.org
to make sure that you have the latest version.
[ 366.837] Markers: (–) probed, () from config file, (==) default setting,
(++) from command line, (!!) notice, (II) informational,
(WW) warning, (EE) error, (NI) not implemented, (??) unknown.
[ 366.837] (==) Log file: “/var/log/Xorg.0.log”, Time: Fri May 31 06:43:59 2024
[ 366.837] (==) Using config file: “/etc/X11/xorg.conf”
[ 366.837] (==) Using system config directory “/usr/share/X11/xorg.conf.d”
[ 366.838] (==) No Layout section. Using the first Screen section.
[ 366.838] (==) No screen section available. Using defaults.
[ 366.838] (
) |–>Screen “Default Screen Section” (0)
[ 366.838] () | |–>Monitor “”
[ 366.838] (==) No device specified for screen “Default Screen Section”.
Using the first device section listed.
[ 366.838] (
) | |–>Device “Tegra0”
[ 366.838] (==) No monitor specified for screen “Default Screen Section”.
Using a default monitor configuration.
[ 366.839] (==) Automatically adding devices
[ 366.839] (==) Automatically enabling devices
[ 366.839] (==) Automatically adding GPU devices
[ 366.839] (==) Automatically binding GPU devices
[ 366.839] (==) Max clients allowed: 256, resource mask: 0x1fffff
[ 366.839] (WW) The directory “/usr/share/fonts/X11/cyrillic” does not exist.
[ 366.839] Entry deleted from font path.
[ 366.839] (WW) The directory “/usr/share/fonts/X11/100dpi/” does not exist.
[ 366.839] (WW) The directory “/usr/share/fonts/X11/75dpi/” does not exist.
[ 366.839] (WW) The directory “/usr/share/fonts/X11/100dpi” does not exist.
[ 366.839] (WW) The directory “/usr/share/fonts/X11/75dpi” does not exist.
[ 366.839] (==) FontPath set to:
/usr/share/fonts/X11/misc,
/usr/share/fonts/X11/Type1,
built-ins
[ 366.839] (==) ModulePath set to “/usr/lib/xorg/modules”
[ 366.839] (II) The server relies on udev to provide the list of input devices.
If no devices become available, reconfigure udev or disable AutoAddDevices.
[ 366.839] (II) Loader magic: 0x556dd34010
[ 366.839] (II) Module ABI versions:
[ 366.839] X.Org ANSI C Emulation: 0.4
[ 366.839] X.Org Video Driver: 23.0
[ 366.839] X.Org XInput driver : 24.1
[ 366.839] X.Org Server Extension : 10.0
[ 366.844] (++) using VT number 1
[ 366.848] (II) systemd-logind: took control of session /org/freedesktop/login1/session/c505
[ 366.850] (II) no primary bus or device found
[ 366.850] (WW) “dri” will not be loaded unless you’ve specified it to be loaded elsewhere.
[ 366.850] (II) “glx” will be loaded by default.
[ 366.850] (II) LoadModule: “extmod”
[ 366.850] (II) Module “extmod” already built-in
[ 366.850] (II) LoadModule: “glx”
[ 366.851] (II) Loading /usr/lib/xorg/modules/extensions/libglx.so
[ 366.853] (II) Module glx: vendor=“X.Org Foundation”
[ 366.853] compiled for 1.19.6, module version = 1.0.0
[ 366.853] ABI class: X.Org Server Extension, version 10.0
[ 366.853] (II) LoadModule: “nvidia”
[ 366.853] (II) Loading /usr/lib/xorg/modules/drivers/nvidia_drv.so
[ 366.854] (II) Module nvidia: vendor=“NVIDIA Corporation”
[ 366.854] compiled for 4.0.2, module version = 1.0.0
[ 366.854] Module class: X.Org Video Driver
[ 366.854] (II) NVIDIA dlloader X Driver 32.6.1 Release Build (integ_stage_rel) (buildbrain@mobile-u64-5496-d5000) Mon Jul 26 12:12:35 PDT 2021
[ 366.854] (II) NVIDIA Unified Driver for all Supported NVIDIA GPUs
[ 366.854] (WW) Falling back to old probe method for NVIDIA
[ 366.854] (II) Loading sub module “fb”
[ 366.854] (II) LoadModule: “fb”
[ 366.855] (II) Loading /usr/lib/xorg/modules/libfb.so
[ 366.855] (II) Module fb: vendor=“X.Org Foundation”
[ 366.855] compiled for 1.19.6, module version = 1.0.0
[ 366.855] ABI class: X.Org ANSI C Emulation, version 0.4
[ 366.855] (II) Loading sub module “wfb”
[ 366.855] (II) LoadModule: “wfb”
[ 366.855] (II) Loading /usr/lib/xorg/modules/libwfb.so
[ 366.855] (II) Module wfb: vendor=“X.Org Foundation”
[ 366.856] (II) Loading sub module “ramdac”
[ 366.856] (II) LoadModule: “ramdac”
[ 366.856] (II) Module “ramdac” already built-in
[ 366.857] (WW) VGA arbiter: cannot open kernel arbiter, no multi-card support
[ 366.857] (II) NVIDIA(0): Creating default Display subsection in Screen section
“Default Screen Section” for depth/fbbpp 24/32
[ 366.857] (==) NVIDIA(0): Depth 24, (==) framebuffer bpp 32
[ 366.857] (==) NVIDIA(0): RGB weight 888
[ 366.857] (==) NVIDIA(0): Default visual is TrueColor
[ 366.857] (==) NVIDIA(0): Using gamma correction (1.0, 1.0, 1.0)
[ 366.857] (DB) xf86MergeOutputClassOptions unsupported bus type 0
[ 366.857] () NVIDIA(0): Option “AllowEmptyInitialConfiguration” “true”
[ 366.857] (
) NVIDIA(0): Enabling 2D acceleration
[ 366.857] (II) Loading sub module “glxserver_nvidia”
[ 366.857] (II) LoadModule: “glxserver_nvidia”
[ 366.858] (II) Loading /usr/lib/xorg/modules/extensions/libglxserver_nvidia.so
[ 366.864] (II) Module glxserver_nvidia: vendor=“NVIDIA Corporation”
[ 366.864] compiled for 4.0.2, module version = 1.0.0
[ 366.864] Module class: X.Org Server Extension
[ 366.864] (II) NVIDIA GLX Module 32.6.1 Release Build (integ_stage_rel) (buildbrain@mobile-u64-5496-d5000) Mon Jul 26 12:11:24 PDT 2021
[ 366.868] (–) NVIDIA(0): Valid display device(s) on GPU-0 at SoC
[ 366.868] (–) NVIDIA(0): DFP-0
[ 366.868] (–) NVIDIA(0): DFP-1
[ 366.869] (II) NVIDIA(0): NVIDIA GPU NVIDIA Tegra X1 (nvgpu) (GM20B) at SoC (GPU-0)
[ 366.869] (–) NVIDIA(0): Memory: 4050980 kBytes
[ 366.869] (–) NVIDIA(0): VideoBIOS:
[ 366.869] (–) NVIDIA(GPU-0): Dell D1918H (DFP-0): connected
[ 366.869] (–) NVIDIA(GPU-0): Dell D1918H (DFP-0): External TMDS
[ 366.869] (==) NVIDIA(0):
[ 366.869] (==) NVIDIA(0): No modes were requested; the default mode “nvidia-auto-select”
[ 366.869] (==) NVIDIA(0): will be used as the requested mode.
[ 366.870] (==) NVIDIA(0):
[ 366.870] (II) NVIDIA(0): Validated MetaModes:
[ 366.870] (II) NVIDIA(0): “DFP-0:nvidia-auto-select”
[ 366.870] (II) NVIDIA(0): Virtual screen size determined to be 1366 x 768
[ 366.871] (–) NVIDIA(0): DPI set to (84, 84); computed from “UseEdidDpi” X config
[ 366.871] (–) NVIDIA(0): option
[ 366.871] (–) Depth 24 pixmap format is 32 bpp
[ 366.871] (II) NVIDIA: Reserving 6144.00 MB of virtual memory for indirect memory
[ 366.871] (II) NVIDIA: access.
[ 366.874] (EE) NVIDIA(0): Failed to allocate NVIDIA Error Handler
[ 366.874] (II) NVIDIA(0): ACPI: failed to connect to the ACPI event daemon; the daemon
[ 366.874] (II) NVIDIA(0): may not be running or the “AcpidSocketPath” X
[ 366.874] (II) NVIDIA(0): configuration option may not be set correctly. When the
[ 366.874] (II) NVIDIA(0): ACPI event daemon is available, the NVIDIA X driver will
[ 366.874] (II) NVIDIA(0): try to use it to receive ACPI event notifications. For
[ 366.874] (II) NVIDIA(0): details, please see the “ConnectToAcpid” and
[ 366.874] (II) NVIDIA(0): “AcpidSocketPath” X configuration options in Appendix B: X
[ 366.874] (II) NVIDIA(0): Config Options in the README.
[ 366.928] (II) NVIDIA(0): Setting mode “DFP-0:nvidia-auto-select”
[ 366.936] (==) NVIDIA(0): Disabling shared memory pixmaps
[ 366.936] (==) NVIDIA(0): Backing store enabled
[ 366.936] (==) NVIDIA(0): Silken mouse enabled
[ 366.941] (==) NVIDIA(0): DPMS enabled
[ 366.941] (II) Loading sub module “dri2”
[ 366.941] (II) LoadModule: “dri2”
[ 366.941] (II) Module “dri2” already built-in
[ 366.942] (II) NVIDIA(0): [DRI2] Setup complete
[ 366.942] (II) NVIDIA(0): [DRI2] VDPAU driver: nvidia
[ 366.961] (–) RandR disabled
[ 366.969] (II) SELinux: Disabled on system
[ 366.970] (II) Initializing extension GLX
[ 366.970] (II) Indirect GLX disabled.
[ 367.032] (EE) Error compiling keymap (server-0) executing ‘“/usr/bin/xkbcomp” -w 1 “-R/usr/share/X11/xkb” -xkm “-” -em1 “The XKEYBOARD keymap compiler (xkbcomp) reports:” -emp "> " -eml “Errors from xkbcomp are not fatal to the X server” “/tmp/server-0.xkm”’
[ 367.033] (EE) XKB: Couldn’t compile keymap
[ 367.033] (EE) XKB: Failed to load keymap. Loading default keymap instead.
[ 367.069] (EE) Error compiling keymap (server-0) executing ‘“/usr/bin/xkbcomp” -w 1 “-R/usr/share/X11/xkb” -xkm “-” -em1 “The XKEYBOARD keymap compiler (xkbcomp) reports:” -emp "> " -eml “Errors from xkbcomp are not fatal to the X server” “/tmp/server-0.xkm”’
[ 367.069] (EE) XKB: Couldn’t compile keymap
[ 367.069] XKB: Failed to compile keymap
[ 367.069] Keyboard initialization failed. This could be a missing or incorrect setup of xkeyboard-config.
[ 367.069] (EE)
Fatal server error:
[ 367.069] (EE) Failed to activate virtual core keyboard: 2(EE)
[ 367.069] (EE)
Please consult the The X.Org Foundation support
at http://wiki.x.org
for help.
[ 367.069] (EE) Please also check the log file at “/var/log/Xorg.0.log” for additional information.
[ 367.069] (EE)
[ 367.246] (EE) Server terminated with error (1). Closing log file.
var_log_Xorg.0.log (10.7 KB)
please refer to
