my jetpack is 4.6
After i rebooted the board the monitor was stuck at a log and no further response from monitor
debuflog_after_cuda_installation.txt (20.3 KB)
I can access ssh
Monitor is not interacting as it is stuck at a log
Please dump the dmesg and /var/log/Xorg.0.log here.
hereby sharing the log for both cases when ethernet is connected and not connected
When ethernet is connected to the device , im getting the issue
dmesg_eth_connected.txt (61.2 KB)
var_log_issue_Xorg.0.log (15.2 KB)
Issue is like, im able to log in to device and after 2…3 minutes the issue occur which im adding to this querry
but im able to get ssh
When ethernet is not connected
dmesg_eth_not_connected.txt (120.8 KB)
var_log_Xorg.0.log (14.8 KB)
monitor is stuck at this stage
What are you trying to say here? So the issue won’t happen when you do not connect the ethernet?
So the GUI was there in the beginning?
yes
It was present after flashing
after that i connected ethernet and installed cuda packages
at that time also there was no issues
after installing cuda packages
while ethernet is connected issue is there
OK. I guess it is just simple case.
What is the result of “df -h” when this issue happened?
700 mb was remaining i guess
ethernet is connected to internet
and when ethernet is not present the device wont automatically show the hdmi issue
when ethernet is connected we are able to login and after 2 minutes it showss this issue
still ssh is available
waiting for response
The issue here is simple. Your xorg is disabled by some reason.
What is the result of running sudo service restart gdm3 ?
Please also check your xorg.log got refreshed by this command after restart?
Also, how about you boot up first without ethernet check the /var/log/syslog first. Remember the timestamp of the last line
Then, plug the ethernet cable there. If what you told is true, after a while your GUI will disappear.
After GUI disappear, go back to your /var/loog/syslog and see what got recorded after you connect the ethernet.
cat /var/log/syslog | tail
Jun 3 12:16:31 localhost systemd[1]: Started Snap Daemon.
Jun 3 12:16:31 localhost gnome-software[7981]: enabled plugins: packagekit-refine-repos, packagekit, packagekit-proxy, packagekit-local, packagekit-url-to-app, fwupd, systemd-updates, os-release, packagekit-upgrade, desktop-categories, shell-extensions, packagekit-refresh, ubuntuone, packagekit-offline, appstream, hardcoded-popular, modalias, rewrite-resource, packagekit-refine, hardcoded-featured, steam, hardcoded-blacklist, generic-updates, desktop-menu-path, odrs, provenance, packagekit-history, snap, provenance-license, icons, key-colors, key-colors-metadata
Jun 3 12:16:31 localhost gnome-software[7981]: disabled plugins: dummy, dpkg, repos, epiphany
Jun 3 12:16:32 localhost dbus-daemon[3908]: [system] Activating via systemd: service name='org.freedesktop.fwupd' unit='fwupd.service' requested by ':1.116' (uid=1000 pid=7981 comm="/usr/bin/gnome-software --gapplication-service ")
Jun 3 12:16:32 localhost systemd[1]: Starting Firmware update daemon...
Jun 3 12:16:32 localhost fwupd[8076]: 12:16:32:0465 FuEngine Failed to load SMBIOS: Failed to open file “/sys/firmware/dmi/tables/smbios_entry_point”: No such file or directory
Jun 3 12:16:32 localhost dbus-daemon[3908]: [system] Successfully activated service 'org.freedesktop.fwupd'
Jun 3 12:16:32 localhost systemd[1]: Started Firmware update daemon.
Jun 3 12:16:33 localhost dhcpd[6523]: DHCPREQUEST for 192.168.55.100 from f6:62:10:24:f3:f6 (vvsa-Vostro-3400) via l4tbr0
Jun 3 12:16:33 localhost dhcpd[6523]: DHCPACK on 192.168.55.100 to f6:62:10:24:f3:f6 (vvsa-Vostro-3400) via l4tbr0
Now i connected Ethernet
waited for 10 mins
uptime
09:03:09 up 10 min, 2 users, load average: 0.08, 0.50, 0.38
df -h
Filesystem Size Used Avail Use% Mounted on
/dev/mmcblk0p1 14G 13G 711M 95% /
none 1.7G 0 1.7G 0% /dev
tmpfs 2.0G 88K 2.0G 1% /dev/shm
tmpfs 2.0G 37M 1.9G 2% /run
tmpfs 5.0M 4.0K 5.0M 1% /run/lock
tmpfs 2.0G 0 2.0G 0% /sys/fs/cgroup
tmpfs 396M 12K 396M 1% /run/user/120
tmpfs 396M 108K 396M 1% /run/user/1000
Board didn’t turn off
I connected ethernet and turned on board
Jun 4 09:07:07 localhost dhcpd[6589]: DHCPREQUEST for 192.168.55.100 from f6:62:10:24:f3:f6 (vvsa-Vostro-3400) via l4tbr0
Jun 4 09:07:07 localhost dhcpd[6589]: DHCPACK on 192.168.55.100 to f6:62:10:24:f3:f6 (vvsa-Vostro-3400) via l4tbr0
Jun 4 09:07:15 localhost dhcpd[6589]: DHCPREQUEST for 192.168.55.100 from f6:62:10:24:f3:f6 (vvsa-Vostro-3400) via l4tbr0
Jun 4 09:07:15 localhost dhcpd[6589]: DHCPACK on 192.168.55.100 to f6:62:10:24:f3:f6 (vvsa-Vostro-3400) via l4tbr0
Jun 4 09:07:22 localhost dhcpd[6589]: DHCPREQUEST for 192.168.55.100 from f6:62:10:24:f3:f6 (vvsa-Vostro-3400) via l4tbr0
Jun 4 09:07:22 localhost dhcpd[6589]: DHCPACK on 192.168.55.100 to f6:62:10:24:f3:f6 (vvsa-Vostro-3400) via l4tbr0
Jun 4 09:07:30 localhost dhcpd[6589]: DHCPREQUEST for 192.168.55.100 from f6:62:10:24:f3:f6 (vvsa-Vostro-3400) via l4tbr0
Jun 4 09:07:30 localhost dhcpd[6589]: DHCPACK on 192.168.55.100 to f6:62:10:24:f3:f6 (vvsa-Vostro-3400) via l4tbr0
Jun 4 09:07:37 localhost dhcpd[6589]: DHCPREQUEST for 192.168.55.100 from f6:62:10:24:f3:f6 (vvsa-Vostro-3400) via l4tbr0
Jun 4 09:07:37 localhost dhcpd[6589]: DHCPACK on 192.168.55.100 to f6:62:10:24:f3:f6 (vvsa-Vostro-3400) via l4tbr0
But showing error in monitor
dmesg_issue.log (23.2 KB)
df -h
/dev/mmcblk0p1 14G 13G 710M 95% /
none 1.8G 0 1.8G 0% /dev
tmpfs 2.0G 29M 2.0G 2% /run
tmpfs 397M 120K 397M 1% /run/user/1000
I think you could try more tests on your side first to summarize how to trigger this issue first.
When error happened, check the service status of gdm3 and see why it not able to get up.
Your new error is something new. Never reported in any of your previous log before. I don’t consider them to be as issue actually.
scenario 1:
board gets booted
i enterned user name and password
This is the Xorg log
scenario1.txt (12.7 KB)
I run the command
sudo systemctl restart gdm3
The monitor showed a blackscreen and restarted to he login page
I gave the username and password
I went to blackscreen
After 3…4 minutes
It came ON to login page again
After login in , device is running now
Jun 4 09:24:13 localhost compiz[9820]: /usr/bin/compiz (core) - Warn: Attempted to restack relative to 0x1a00036 which is not a child of the root window or a window compiz owns
Jun 4 09:24:13 localhost unity-panel-ser[9834]: menus_destroyed: assertion 'IS_WINDOW_MENU(wm)' failed
Jun 4 09:24:13 localhost compiz[9820]: WARN 2024-06-04 09:24:13 unity.dash.gsettingsscopereader GSettingsScopes.cpp:108 Error fetching protocol metadata for scope: social.scope : Valid key file could not be found in search dirs
Jun 4 09:24:13 localhost compiz[9820]: WARN 2024-06-04 09:24:13 unity <unknown>:0 g_settings_set_value: value for key 'visual-bell-type' in schema 'org.gnome.desktop.wm.preferences' is outside of valid range
Jun 4 09:24:13 localhost unity-panel-ser[9834]: window_menu_model_new: assertion 'BAMF_IS_APPLICATION(app)' failed
Jun 4 09:24:13 localhost unity-panel-ser[9834]: track_menus: assertion 'IS_WINDOW_MENU(menus)' failed
Jun 4 09:24:13 localhost gnome-screensav[9692]: Lost the name, shutting down.
Jun 4 09:24:13 localhost compiz[9820]: WARN 2024-06-04 09:24:13 unity <unknown>:0 Failed to fetch xid: GDBus.Error:org.freedesktop.DBus.Error.UnknownMethod: No such interface 'org.ayatana.bamf.window' on object at path /org/ayatana/bamf/window/16777221
Jun 4 09:24:13 localhost compiz[9820]: WARN 2024-06-04 09:24:13 unity <unknown>:0 Failed to fetch type: GDBus.Error:org.freedesktop.DBus.Error.UnknownMethod: No such interface 'org.ayatana.bamf.window' on object at path /org/ayatana/bamf/window/16777221
Jun 4 09:24:13 localhost compiz[9820]: WARN 2024-06-04 09:24:13 unity <unknown>:0 Failed to fetch monitor: GDBus.Error:org.freedesktop.DBus.Error.UnknownMethod: No such interface 'org.ayatana.bamf.window' on object at path /org/ayatana/bamf/window/16777221
Jun 4 09:24:13 localhost compiz[9820]: WARN 2024-06-04 09:24:13 unity <unknown>:0 Failed to fetch maximized state: GDBus.Error:org.freedesktop.DBus.Error.UnknownMethod: No such interface 'org.ayatana.bamf.window' on object at path /org/ayatana/bamf/window/16777221
Jun 4 09:24:13 localhost compiz[9820]: WARN 2024-06-04 09:24:13 unity <unknown>:0 Unable to fetch children: GDBus.Error:org.freedesktop.DBus.Error.UnknownMethod: No such interface 'org.ayatana.bamf.view' on object at path /org/ayatana/bamf/application/0x559f40a1c0
Jun 4 09:24:13 localhost compiz[9820]: WARN 2024-06-04 09:24:13 unity <unknown>:0 Failed to fetch path: GDBus.Error:org.freedesktop.DBus.Error.UnknownMethod: No such interface 'org.ayatana.bamf.application' on object at path /org/ayatana/bamf/application/0x559f40a1c0
Jun 4 09:24:13 localhost compiz[9820]: message repeated 7 times: [ WARN 2024-06-04 09:24:13 unity <unknown>:0 Failed to fetch path: GDBus.Error:org.freedesktop.DBus.Error.UnknownMethod: No such interface 'org.ayatana.bamf.application' on object at path /org/ayatana/bamf/application/0x559f40a1c0]
Jun 4 09:24:13 localhost unity-settings-[9637]: Grab failed for some keys, another application may already have access the them.
Jun 4 09:24:13 localhost compiz[9820]: ERROR 2024-06-04 09:24:13 unity.glib.dbus.server GLibDBusServer.cpp:538 DBus name lost 'org.gnome.Shell'
Jun 4 09:24:13 localhost compiz[9820]: ERROR 2024-06-04 09:24:13 unity.glib.dbus.server GLibDBusServer.cpp:538 DBus name lost 'com.canonical.Unity'
Jun 4 09:24:13 localhost compiz[9820]: ERROR 2024-06-04 09:24:13 unity.glib.dbus.proxy GLibDBusProxy.cpp:632 Impossible to get property: Operation was cancelled
Jun 4 09:24:16 localhost dhcpd[6721]: DHCPREQUEST for 192.168.55.100 from f6:62:10:24:f3:f6 (vvsa-Vostro-3400) via l4tbr0
Jun 4 09:24:16 localhost dhcpd[6721]: DHCPACK on 192.168.55.100 to f6:62:10:24:f3:f6 (vvsa-Vostro-3400) via l4tbr0
Jun 4 09:24:20 localhost compiz[9820]: WARN 2024-06-04 09:24:20 unity.filemanager.gnome GnomeFileManager.cpp:69 Locations have been invalidated, maybe there's no filemanager around...
Jun 4 09:24:24 localhost dhcpd[6721]: DHCPREQUEST for 192.168.55.100 from f6:62:10:24:f3:f6 (vvsa-Vostro-3400) via l4tbr0
Jun 4 09:24:24 localhost dhcpd[6721]: DHCPACK on 192.168.55.100 to f6:62:10:24:f3:f6 (vvsa-Vostro-3400) via l4tbr0
Jun 4 09:24:28 localhost zeitgeist-daemon[7959]: #033[31m[09:24:28.985356 WARNING]#033[0m zeitgeist-daemon.vala:127: Unable to parse version info!
Jun 4 09:24:31 localhost dhcpd[6721]: DHCPREQUEST for 192.168.55.100 from f6:62:10:24:f3:f6 (vvsa-Vostro-3400) via l4tbr0
Jun 4 09:24:31 localhost dhcpd[6721]: DHCPACK on 192.168.55.100 to f6:62:10:24:f3:f6 (vvsa-Vostro-3400) via l4tbr0
Jun 4 09:24:39 localhost dhcpd[6721]: DHCPREQUEST for 192.168.55.100 from f6:62:10:24:f3:f6 (vvsa-Vostro-3400) via l4tbr0
Jun 4 09:24:39 localhost dhcpd[6721]: DHCPACK on 192.168.55.100 to f6:62:10:24:f3:f6 (vvsa-Vostro-3400) via l4tbr0
Jun 4 09:24:46 localhost dhcpd[6721]: DHCPREQUEST for 192.168.55.100 from f6:62:10:24:f3:f6 (vvsa-Vostro-3400) via l4tbr0
Jun 4 09:24:46 localhost dhcpd[6721]: DHCPACK on 192.168.55.100 to f6:62:10:24:f3:f6 (vvsa-Vostro-3400) via l4tbr0
Jun 4 09:24:54 localhost dhcpd[6721]: DHCPREQUEST for 192.168.55.100 from f6:62:10:24:f3:f6 (vvsa-Vostro-3400) via l4tbr0
Jun 4 09:24:54 localhost dhcpd[6721]: DHCPACK on 192.168.55.100 to f6:62:10:24:f3:f6 (vvsa-Vostro-3400) via l4tbr0
Jun 4 09:25:01 localhost dhcpd[6721]: DHCPREQUEST for 192.168.55.100 from f6:62:10:24:f3:f6 (vvsa-Vostro-3400) via l4tbr0
Jun 4 09:25:01 localhost dhcpd[6721]: DHCPACK on 192.168.55.100 to f6:62:10:24:f3:f6 (vvsa-Vostro-3400) via l4tbr0
Jun 4 09:25:07 localhost dbus-daemon[7278]: [session uid=1000 pid=7278] Activating service name='org.freedesktop.Notifications' requested by ':1.185' (uid=1000 pid=9637 comm="/usr/lib/unity-settings-daemon/unity-settings-daem")
Jun 4 09:25:08 localhost dbus-daemon[7278]: [session uid=1000 pid=7278] Successfully activated service 'org.freedesktop.Notifications'
Jun 4 09:25:08 localhost unity-settings-[9637]: GtkDialog mapped without a transient parent. This is discouraged.
Jun 4 09:25:09 localhost dhcpd[6721]: DHCPREQUEST for 192.168.55.100 from f6:62:10:24:f3:f6 (vvsa-Vostro-3400) via l4tbr0
Jun 4 09:25:09 localhost dhcpd[6721]: DHCPACK on 192.168.55.100 to f6:62:10:24:f3:f6 (vvsa-Vostro-3400) via l4tbr0
Jun 4 09:25:12 localhost gnome-software[10124]: plugin appstream took 3.3 seconds to do setup
Jun 4 09:25:12 localhost systemd[1]: Starting Snap Daemon...
Jun 4 09:25:12 localhost snapd[10147]: AppArmor status: apparmor not enabled
Jun 4 09:25:12 localhost snapd[10147]: daemon.go:347: started snapd/2.49.2+18.04 (series 16; classic; devmode) ubuntu/18.04 (arm64) linux/4.9.253-tegra.
Jun 4 09:25:12 localhost snapd[10147]: daemon.go:440: adjusting startup timeout by 30s (pessimistic estimate of 30s plus 5s per snap)
Jun 4 09:25:12 localhost systemd[1]: Started Snap Daemon.
Jun 4 09:25:12 localhost gnome-software[10124]: enabled plugins: packagekit-refine-repos, packagekit, packagekit-proxy, packagekit-local, packagekit-url-to-app, fwupd, systemd-updates, os-release, packagekit-upgrade, desktop-categories, shell-extensions, packagekit-refresh, ubuntuone, packagekit-offline, appstream, hardcoded-popular, modalias, rewrite-resource, packagekit-refine, hardcoded-featured, steam, hardcoded-blacklist, generic-updates, desktop-menu-path, odrs, provenance, packagekit-history, snap, provenance-license, icons, key-colors, key-colors-metadata
Jun 4 09:25:12 localhost gnome-software[10124]: disabled plugins: dummy, dpkg, repos, epiphany
Jun 4 09:25:13 localhost gnome-software[10124]: failed to call gs_plugin_refresh on shell-extensions: [*/*/*/source/shell-extensions/*] failed to download https://extensions.gnome.org//static/extensions.json: SSL handshake failed
Jun 4 09:25:15 localhost PackageKit: get-updates transaction /316_dcacdccd from uid 1000 finished with success after 1603ms
Jun 4 09:25:15 localhost gnome-software[10124]: failed to call gs_plugin_add_installed on shell-extensions: GDBus.Error:org.freedesktop.DBus.Error.UnknownMethod: No such interface 'org.gnome.Shell.Extensions' on object at path /org/gnome/Shell
Jun 4 09:25:15 localhost gnome-software[10124]: Only 0 apps for recent list, hiding
Jun 4 09:25:16 localhost PackageKit: resolve transaction /317_ebebcbcb from uid 1000 finished with success after 950ms
Jun 4 09:25:16 localhost dhcpd[6721]: DHCPREQUEST for 192.168.55.100 from f6:62:10:24:f3:f6 (vvsa-Vostro-3400) via l4tbr0
Jun 4 09:25:16 localhost dhcpd[6721]: DHCPACK on 192.168.55.100 to f6:62:10:24:f3:f6 (vvsa-Vostro-3400) via l4tbr0
Jun 4 09:25:16 localhost gnome-software[10124]: Only 8 apps for popular list, hiding
Jun 4 09:25:18 localhost PackageKit: search-file transaction /318_dbccccde from uid 1000 finished with success after 1203ms
Jun 4 09:25:19 localhost systemd[7240]: Starting Notification regarding a crash report...
Jun 4 09:25:19 localhost PackageKit: search-file transaction /319_dededaaa from uid 1000 finished with success after 1172ms
Jun 4 09:25:19 localhost update-notifier-crash[10285]: gnome-session-check-accelerated-gl-helper
Jun 4 09:25:20 localhost PackageKit: search-file transaction /320_edecdcae from uid 1000 finished with success after 1208ms
Jun 4 09:25:21 localhost PackageKit: search-file transaction /321_ecbaaaac from uid 1000 finished with success after 1150ms
Jun 4 09:25:22 localhost PackageKit: search-file transaction /322_deceecbc from uid 1000 finished with success after 1136ms
Jun 4 09:25:24 localhost PackageKit: search-file transaction /323_acdbaeca from uid 1000 finished with success after 1115ms
Jun 4 09:25:24 localhost dhcpd[6721]: DHCPREQUEST for 192.168.55.100 from f6:62:10:24:f3:f6 (vvsa-Vostro-3400) via l4tbr0
In GUI now it shows 700mb only left
scenario2 : after systemctl restart Xorg log
scenario2.txt (14.4 KB)
Jun 4 09:25:24 localhost dhcpd[6721]: DHCPACK on 192.168.55.100 to f6:62:10:24:f3:f6 (vvsa-Vostro-3400) via l4tbr0
Jun 4 09:25:25 localhost PackageKit: search-file transaction /324_bedbacce from uid 1000 finished with success after 1106ms
Jun 4 09:25:25 localhost gnome-software[10124]: Failed to find one package for nvvp.desktop, /usr/share/applications/nvvp.desktop, [0]
Jun 4 09:25:26 localhost PackageKit: search-file transaction /325_bdbcdeab from uid 1000 finished with success after 1096ms
Jun 4 09:25:26 localhost gnome-software[10124]: Failed to find one package for nsight.desktop, /usr/share/applications/nsight.desktop, [0]
Jun 4 09:25:27 localhost PackageKit: search-file transaction /326_bbedcdca from uid 1000 finished with success after 1112ms
Jun 4 09:25:27 localhost snapd[10147]: daemon.go:589: gracefully waiting for running hooks
Jun 4 09:25:27 localhost snapd[10147]: daemon.go:591: done waiting for running hooks
Jun 4 09:25:27 localhost snapd[10147]: daemon stop requested to wait for socket activation
Jun 4 09:25:28 localhost PackageKit: get-details transaction /327_badcddbb from uid 1000 finished with success after 897ms
Jun 4 09:25:31 localhost dhcpd[6721]: DHCPREQUEST for 192.168.55.100 from f6:62:10:24:f3:f6 (vvsa-Vostro-3400) via l4tbr0
Jun 4 09:25:31 localhost dhcpd[6721]: DHCPACK on 192.168.55.100 to f6:62:10:24:f3:f6 (vvsa-Vostro-3400) via l4tbr0
Jun 4 09:25:39 localhost dhcpd[6721]: DHCPREQUEST for 192.168.55.100 from f6:62:10:24:f3:f6 (vvsa-Vostro-3400) via l4tbr0
Jun 4 09:25:39 localhost dhcpd[6721]: DHCPACK on 192.168.55.100 to f6:62:10:24:f3:f6 (vvsa-Vostro-3400) via l4tbr0
Jun 4 09:25:46 localhost dhcpd[6721]: DHCPREQUEST for 192.168.55.100 from f6:62:10:24:f3:f6 (vvsa-Vostro-3400) via l4tbr0
Jun 4 09:25:46 localhost dhcpd[6721]: DHCPACK on 192.168.55.100 to f6:62:10:24:f3:f6 (vvsa-Vostro-3400) via l4tbr0
Jun 4 09:25:54 localhost dhcpd[6721]: DHCPREQUEST for 192.168.55.100 from f6:62:10:24:f3:f6 (vvsa-Vostro-3400) via l4tbr0
Jun 4 09:25:54 localhost dhcpd[6721]: DHCPACK on 192.168.55.100 to f6:62:10:24:f3:f6 (vvsa-Vostro-3400) via l4tbr0
Jun 4 09:26:01 localhost dhcpd[6721]: DHCPREQUEST for 192.168.55.100 from f6:62:10:24:f3:f6 (vvsa-Vostro-3400) via l4tbr0
Jun 4 09:26:01 localhost dhcpd[6721]: DHCPACK on 192.168.55.100 to f6:62:10:24:f3:f6 (vvsa-Vostro-3400) via l4tbr0
Jun 4 09:26:09 localhost dhcpd[6721]: DHCPREQUEST for 192.168.55.100 from f6:62:10:24:f3:f6 (vvsa-Vostro-3400) via l4tbr0
Jun 4 09:26:09 localhost dhcpd[6721]: DHCPACK on 192.168.55.100 to f6:62:10:24:f3:f6 (vvsa-Vostro-3400) via l4tbr0
Jun 4 09:26:16 localhost dhcpd[6721]: DHCPREQUEST for 192.168.55.100 from f6:62:10:24:f3:f6 (vvsa-Vostro-3400) via l4tbr0
Jun 4 09:26:16 localhost dhcpd[6721]: DHCPACK on 192.168.55.100 to f6:62:10:24:f3:f6 (vvsa-Vostro-3400) via l4tbr0
Jun 4 09:26:24 localhost dhcpd[6721]: DHCPREQUEST for 192.168.55.100 from f6:62:10:24:f3:f6 (vvsa-Vostro-3400) via l4tbr0
Jun 4 09:26:24 localhost dhcpd[6721]: DHCPACK on 192.168.55.100 to f6:62:10:24:f3:f6 (vvsa-Vostro-3400) via l4tbr0
Jun 4 09:26:31 localhost dhcpd[6721]: DHCPREQUEST for 192.168.55.100 from f6:62:10:24:f3:f6 (vvsa-Vostro-3400) via l4tbr0
Jun 4 09:26:31 localhost dhcpd[6721]: DHCPACK on 192.168.55.100 to f6:62:10:24:f3:f6 (vvsa-Vostro-3400) via l4tbr0
Jun 4 09:26:37 localhost NetworkManager[4143]: <info> [1717493197.9814] connectivity: (l4tbr0) timed out
Jun 4 09:26:39 localhost dhcpd[6721]: DHCPREQUEST for 192.168.55.100 from f6:62:10:24:f3:f6 (vvsa-Vostro-3400) via l4tbr0
Jun 4 09:26:39 localhost dhcpd[6721]: DHCPACK on 192.168.55.100 to f6:62:10:24:f3:f6 (vvsa-Vostro-3400) via l4tbr0
This is the syslog
As of now the board is running
can’t identify what is the root cause
Then please reflash the board. It could be a quick way.
Move to use rel-32.7.4 too.
ok
I will reflash
then we can install cuda packages 10.2 which is needed using commands right ?
The firmware or the image is custom
I flashed the device
There was no issue initially
I connected internet via ethernet
after 1 minute
to install cuda packages , I run the command sudo apt-get update
Within 10seconds the issue occured
Now i rebooted the device , then the issue occured
My observation is when the device is booting with ethernet connected , iam able to log in to device
But the issue is occuring after 3…4 minutes
I tried without connecting that ethernet 24minutes
no issue occured
Then i connected the ethernet cable till now device hasn’t shown any error
Which jetpack version is in use here?
How did you install cuda?
Jetpack 4.6
Now cuda is not installed
What is your exact point to keep using jp4.6? Is there any special requirement to test on this?
Even if there is a bug, it won’t get fixed. We don’t really debug issues on old release… better moving to latest rel-32.7.4…
