I am new to the nano, working with a dev kit. I am using Balena (www.balena.io) to build a scalable IIoT app and evaluating whether the nano will meet our needs. Balena uses docker containers on top of a Yocto core, and they support the nano. I built a basic Ubuntu container and installed the L4T package. When I run startx I am getting an error:
X.Org X Server 1.19.6
Release Date: 2017-12-20
X Protocol Version 11, Revision 0
Build Operating System: Linux 4.4.0-168-generic aarch64 Ubuntu
Current Operating System: Linux 95295ec09afd 4.9.140-l4t-r32.3.1 #1 SMP PREEMPT Thu Mar 5 14:37:57 UTC 2020 aarch64
Kernel command line: tegraid=21.1.2.0.0 ddr_die=4096M@2048M section=512M memtype=0 vpr_resize usb_port_owner_info=0 lane_owner_info=0 emc_max_dvfs=0 touch_id=0@63 video=tegrafb no_console_suspend=1 console=ttyS0,115200n8 debug_uartport=lsport,0 earlyprintk=uart8250-32bit,0x70006000 maxcpus=4 usbcore.old_scheme_first=1 lp0_vec=0x1000@0xff780000 core_edp_mv=1075 core_edp_ma=4000 tegra_fbmem=0x800000@0x92cb4000 is_hdmi_initialised=1 console=ttyS0,115200 console=tty0 fbcon=map:0 net.ifnames=0 root=PARTUUID=1fe4f4f7-ea07-4438-aaa3-23126c5c3897 ro rootwait sdhci_tegra.en_boot_part_access=1
Build Date: 14 November 2019 06:20:13PM
xorg-server 2:1.19.6-1ubuntu4.4 (For technical support please see http://www.ubuntu.com/support)
Current version of pixman: 0.34.0
Before reporting problems, check http://wiki.x.org
to make sure that you have the latest version.
Markers: (--) probed, (**) from config file, (==) default setting,
(++) from command line, (!!) notice, (II) informational,
(WW) warning, (EE) error, (NI) not implemented, (??) unknown.
(==) Log file: "/var/log/Xorg.0.log", Time: Thu Jun 25 03:00:36 2020
(==) Using config file: "/etc/X11/xorg.conf"
(==) Using system config directory "/usr/share/X11/xorg.conf.d"
(EE)
Fatal server error:
(EE) NVIDIA: A GPU exception occurred during X server initialization
(EE)
(EE)
Please consult the The X.Org Foundation support
at http://wiki.x.org
for help.
(EE) Please also check the log file at "/var/log/Xorg.0.log" for additional information.
(EE)
And the device reboots itself right after. When I check the dmesg logs on startup, I see some NVGPU errors (shown below). Oddly, it worked the first few times, but now I can’t get it back to a working state. Does anyone have ideas of what could be wrong based on the errors?
[ 15.873487] EXT4-fs (mmcblk0p13): couldn't mount as ext3 due to feature incompatibilities
[ 15.889358] EXT4-fs (mmcblk0p13): couldn't mount as ext2 due to feature incompatibilities
[ 15.914654] EXT4-fs (mmcblk0p13): mounted filesystem with ordered data mode. Opts: (null)
[ 15.989912] EXT4-fs (mmcblk0p15): mounted filesystem with ordered data mode. Opts: (null)
[ 17.300019] EXT4-fs (mmcblk0p13): re-mounted. Opts: (null)
[ 17.904449] cgroup: cgroup2: unknown option "nsdelegate"
[ 18.464936] systemd[1]: File /lib/systemd/system/systemd-journald.service:12 configures an IP firewall (IPAddressDeny=any), but the local system does not support BPF/cgroup based firewalling.
[ 18.495239] systemd[1]: Proceeding WITHOUT firewalling in effect! (This warning is only shown for the first loaded unit using IP firewalling.)
[ 18.828622] systemd[1]: /lib/systemd/system/chronyd.service:9: PIDFile= references path below legacy directory /var/run/, updating /var/run/chrony/chronyd.pid → /run/chrony/chronyd.pid; please update the unit file accordingly.
[ 19.817005] nvgpu: 57000000.gpu gm20b_init_clk_setup_sw:1268 [INFO] GPCPLL initial settings: NA mode, M=1, N=34, P=3 (id = 1)
[ 20.925707] EXT4-fs (mmcblk0p16): mounted filesystem with ordered data mode. Opts: (null)
[ 23.898590] usbcore: registered new interface driver btusb
[ 23.927303] usbcore: registered new interface driver usbserial
[ 23.947392] usbcore: registered new interface driver ch341
[ 23.956789] usbserial: USB Serial support registered for ch341-uart
[ 23.968582] ch341 1-2.2:1.0: ch341-uart converter detected
[ 23.984118] usb 1-2.2: ch341-uart converter now attached to ttyUSB0
[ 24.037538] input: HID 222a:0001 as /devices/70090000.xusb/usb1/1-2/1-2.1/1-2.1:1.0/0003:222A:0001.0001/input/input2
[ 24.061839] hid-multitouch 0003:222A:0001.0001: input,hidraw1: USB HID v1.10 Device [HID 222a:0001] on usb-70090000.xusb-2.1/input0
[ 30.827707] nvgpu: 57000000.gpu __nvgpu_timeout_expired_msg_cpu:94 [ERR] Timeout detected @ gr_gk20a_ctx_wait_ucode+0xb8/0x3b0 [nvgpu]
[ 30.847212] nvgpu: 57000000.gpu gr_gk20a_ctx_wait_ucode:528 [ERR] timeout waiting on mailbox=0 value=0x00000010
[ 30.863607] nvgpu: 57000000.gpu gk20a_fecs_dump_falcon_stats:129 [ERR] gr_fecs_os_r : 0
[ 30.877404] nvgpu: 57000000.gpu gk20a_fecs_dump_falcon_stats:131 [ERR] gr_fecs_cpuctl_r : 0x40
[ 30.891799] nvgpu: 57000000.gpu gk20a_fecs_dump_falcon_stats:133 [ERR] gr_fecs_idlestate_r : 0x1
[ 30.906448] nvgpu: 57000000.gpu gk20a_fecs_dump_falcon_stats:135 [ERR] gr_fecs_mailbox0_r : 0x0
[ 30.920999] nvgpu: 57000000.gpu gk20a_fecs_dump_falcon_stats:137 [ERR] gr_fecs_mailbox1_r : 0x0
[ 30.935673] nvgpu: 57000000.gpu gk20a_fecs_dump_falcon_stats:139 [ERR] gr_fecs_irqstat_r : 0x0
[ 30.949985] nvgpu: 57000000.gpu gk20a_fecs_dump_falcon_stats:141 [ERR] gr_fecs_irqmode_r : 0x4
[ 30.964328] nvgpu: 57000000.gpu gk20a_fecs_dump_falcon_stats:143 [ERR] gr_fecs_irqmask_r : 0x8704
[ 30.978887] nvgpu: 57000000.gpu gk20a_fecs_dump_falcon_stats:145 [ERR] gr_fecs_irqdest_r : 0x0
[ 30.993197] nvgpu: 57000000.gpu gk20a_fecs_dump_falcon_stats:147 [ERR] gr_fecs_debug1_r : 0x40
[ 31.007445] nvgpu: 57000000.gpu gk20a_fecs_dump_falcon_stats:149 [ERR] gr_fecs_debuginfo_r : 0x0
[ 31.021890] nvgpu: 57000000.gpu gk20a_fecs_dump_falcon_stats:151 [ERR] gr_fecs_ctxsw_status_1_r : 0x300
[ 31.037007] nvgpu: 57000000.gpu gk20a_fecs_dump_falcon_stats:155 [ERR] gr_fecs_ctxsw_mailbox_r(0) : 0x10
[ 31.052244] nvgpu: 57000000.gpu gk20a_fecs_dump_falcon_stats:155 [ERR] gr_fecs_ctxsw_mailbox_r(1) : 0x0
[ 31.067336] nvgpu: 57000000.gpu gk20a_fecs_dump_falcon_stats:155 [ERR] gr_fecs_ctxsw_mailbox_r(2) : 0x41009
[ 31.082696] nvgpu: 57000000.gpu gk20a_fecs_dump_falcon_stats:155 [ERR] gr_fecs_ctxsw_mailbox_r(3) : 0x20
[ 31.097752] nvgpu: 57000000.gpu gk20a_fecs_dump_falcon_stats:155 [ERR] gr_fecs_ctxsw_mailbox_r(4) : 0x1ffda0
[ 31.113075] nvgpu: 57000000.gpu gk20a_fecs_dump_falcon_stats:155 [ERR] gr_fecs_ctxsw_mailbox_r(5) : 0x0
[ 31.127894] nvgpu: 57000000.gpu gk20a_fecs_dump_falcon_stats:155 [ERR] gr_fecs_ctxsw_mailbox_r(6) : 0x0
[ 31.142693] nvgpu: 57000000.gpu gk20a_fecs_dump_falcon_stats:155 [ERR] gr_fecs_ctxsw_mailbox_r(7) : 0x0
[ 31.157433] nvgpu: 57000000.gpu gk20a_fecs_dump_falcon_stats:155 [ERR] gr_fecs_ctxsw_mailbox_r(8) : 0x0
[ 31.172126] nvgpu: 57000000.gpu gk20a_fecs_dump_falcon_stats:155 [ERR] gr_fecs_ctxsw_mailbox_r(9) : 0x0
[ 31.186720] nvgpu: 57000000.gpu gk20a_fecs_dump_falcon_stats:155 [ERR] gr_fecs_ctxsw_mailbox_r(10) : 0x0
[ 31.201402] nvgpu: 57000000.gpu gk20a_fecs_dump_falcon_stats:155 [ERR] gr_fecs_ctxsw_mailbox_r(11) : 0x0
[ 31.216056] nvgpu: 57000000.gpu gk20a_fecs_dump_falcon_stats:155 [ERR] gr_fecs_ctxsw_mailbox_r(12) : 0x0
[ 31.230615] nvgpu: 57000000.gpu gk20a_fecs_dump_falcon_stats:155 [ERR] gr_fecs_ctxsw_mailbox_r(13) : 0x0
[ 31.245059] nvgpu: 57000000.gpu gk20a_fecs_dump_falcon_stats:155 [ERR] gr_fecs_ctxsw_mailbox_r(14) : 0x0
[ 31.259421] nvgpu: 57000000.gpu gk20a_fecs_dump_falcon_stats:155 [ERR] gr_fecs_ctxsw_mailbox_r(15) : 0x0
[ 31.273564] nvgpu: 57000000.gpu gk20a_fecs_dump_falcon_stats:159 [ERR] gr_fecs_engctl_r : 0x0
[ 31.286617] nvgpu: 57000000.gpu gk20a_fecs_dump_falcon_stats:161 [ERR] gr_fecs_curctx_r : 0x0
[ 31.300150] nvgpu: 57000000.gpu gk20a_fecs_dump_falcon_stats:163 [ERR] gr_fecs_nxtctx_r : 0x0
[ 31.312884] nvgpu: 57000000.gpu gk20a_fecs_dump_falcon_stats:169 [ERR] FECS_FALCON_REG_IMB : 0xbadfbadf
[ 31.326628] nvgpu: 57000000.gpu gk20a_fecs_dump_falcon_stats:175 [ERR] FECS_FALCON_REG_DMB : 0xbadfbadf
[ 31.326654] nvgpu: 57000000.gpu gk20a_fecs_dump_falcon_stats:181 [ERR] FECS_FALCON_REG_CSW : 0xbadfbadf
[ 31.326665] nvgpu: 57000000.gpu gk20a_fecs_dump_falcon_stats:187 [ERR] FECS_FALCON_REG_CTX : 0xbadfbadf
[ 31.326675] nvgpu: 57000000.gpu gk20a_fecs_dump_falcon_stats:193 [ERR] FECS_FALCON_REG_EXCI : 0xbadfbadf
[ 31.326685] nvgpu: 57000000.gpu gk20a_fecs_dump_falcon_stats:200 [ERR] FECS_FALCON_REG_PC : 0xbadfbadf
[ 31.326694] nvgpu: 57000000.gpu gk20a_fecs_dump_falcon_stats:206 [ERR] FECS_FALCON_REG_SP : 0xbadfbadf
[ 31.326704] nvgpu: 57000000.gpu gk20a_fecs_dump_falcon_stats:200 [ERR] FECS_FALCON_REG_PC : 0xbadfbadf
[ 31.326713] nvgpu: 57000000.gpu gk20a_fecs_dump_falcon_stats:206 [ERR] FECS_FALCON_REG_SP : 0xbadfbadf
[ 31.326722] nvgpu: 57000000.gpu gk20a_fecs_dump_falcon_stats:200 [ERR] FECS_FALCON_REG_PC : 0xbadfbadf
[ 31.326732] nvgpu: 57000000.gpu gk20a_fecs_dump_falcon_stats:206 [ERR] FECS_FALCON_REG_SP : 0xbadfbadf
[ 31.326741] nvgpu: 57000000.gpu gk20a_fecs_dump_falcon_stats:200 [ERR] FECS_FALCON_REG_PC : 0xbadfbadf
[ 31.326750] nvgpu: 57000000.gpu gk20a_fecs_dump_falcon_stats:206 [ERR] FECS_FALCON_REG_SP : 0xbadfbadf
[ 31.326768] NV_PGRAPH_STATUS: 0xa1
[ 31.326775] NV_PGRAPH_STATUS1: 0x0
[ 31.326781] NV_PGRAPH_STATUS2: 0x0
[ 31.326788] NV_PGRAPH_ENGINE_STATUS: 0x1
[ 31.326794] NV_PGRAPH_GRFIFO_STATUS : 0x1
[ 31.326801] NV_PGRAPH_GRFIFO_CONTROL : 0x10001
[ 31.326808] NV_PGRAPH_PRI_FECS_HOST_INT_STATUS : 0x0
[ 31.326814] NV_PGRAPH_EXCEPTION : 0x0
[ 31.326820] NV_PGRAPH_FECS_INTR : 0x0
[ 31.326826] NV_PFIFO_ENGINE_STATUS(GR) : 0x90000000
[ 31.326832] NV_PGRAPH_ACTIVITY0: 0x0
[ 31.326839] NV_PGRAPH_ACTIVITY1: 0x600
[ 31.326844] NV_PGRAPH_ACTIVITY2: 0x0
[ 31.326850] NV_PGRAPH_ACTIVITY4: 0x0
[ 31.326856] NV_PGRAPH_PRI_SKED_ACTIVITY: 0x0
[ 31.326863] NV_PGRAPH_PRI_GPC0_GPCCS_GPC_ACTIVITY0: 0x0
[ 31.326870] NV_PGRAPH_PRI_GPC0_GPCCS_GPC_ACTIVITY1: 0x0
[ 31.326876] NV_PGRAPH_PRI_GPC0_GPCCS_GPC_ACTIVITY2: 0x0
[ 31.326883] NV_PGRAPH_PRI_GPC0_GPCCS_GPC_ACTIVITY3: 0x0
[ 31.326890] NV_PGRAPH_PRI_GPC0_TPC0_TPCCS_TPC_ACTIVITY0: 0x0
[ 31.326897] NV_PGRAPH_PRI_GPC0_TPCS_TPCCS_TPC_ACTIVITY0: 0x0
[ 31.326904] NV_PGRAPH_PRI_GPCS_GPCCS_GPC_ACTIVITY0: 0x0
[ 31.326911] NV_PGRAPH_PRI_GPCS_GPCCS_GPC_ACTIVITY1: 0x0
[ 31.326918] NV_PGRAPH_PRI_GPCS_GPCCS_GPC_ACTIVITY2: 0x0
[ 31.326924] NV_PGRAPH_PRI_GPCS_GPCCS_GPC_ACTIVITY3: 0x0
[ 31.326931] NV_PGRAPH_PRI_GPCS_TPC0_TPCCS_TPC_ACTIVITY0: 0x0
[ 31.326939] NV_PGRAPH_PRI_GPCS_TPCS_TPCCS_TPC_ACTIVITY0: 0x0
[ 31.326946] NV_PGRAPH_PRI_BE0_BECS_BE_ACTIVITY0: 0x0
[ 31.326952] NV_PGRAPH_PRI_BE1_BECS_BE_ACTIVITY0: 0x0
[ 31.326959] NV_PGRAPH_PRI_BES_BECS_BE_ACTIVITY0: 0x0
[ 31.326966] NV_PGRAPH_PRI_DS_MPIPE_STATUS: 0x0
[ 31.326973] NV_PGRAPH_PRI_FE_GO_IDLE_ON_STATUS: 0x2e
[ 31.326980] NV_PGRAPH_PRI_FE_GO_IDLE_TIMEOUT : 0x800
[ 31.326986] NV_PGRAPH_PRI_FE_GO_IDLE_CHECK : 0x800
[ 31.326993] NV_PGRAPH_PRI_FE_GO_IDLE_INFO : 0x23000700
[ 31.327001] NV_PGRAPH_PRI_GPC0_TPC0_TEX_M_TEX_SUBUNITS_STATUS: 0x0
[ 31.327008] NV_PGRAPH_PRI_CWD_FS: 0x101
[ 31.327014] NV_PGRAPH_PRI_FE_TPC_FS: 0x1
[ 31.327020] NV_PGRAPH_PRI_CWD_GPC_TPC_ID(0): 0x0
[ 31.327027] NV_PGRAPH_PRI_CWD_SM_ID(0): 0x0
[ 31.327033] NV_PGRAPH_PRI_FECS_CTXSW_STATUS_FE_0: 0x2000
[ 31.327039] NV_PGRAPH_PRI_FECS_CTXSW_STATUS_1: 0x300
[ 31.327046] NV_PGRAPH_PRI_GPC0_GPCCS_CTXSW_STATUS_GPC_0: 0x0
[ 31.327053] NV_PGRAPH_PRI_GPC0_GPCCS_CTXSW_STATUS_1: 0x300
[ 31.327060] NV_PGRAPH_PRI_FECS_CTXSW_IDLESTATE : 0xe
[ 31.327067] NV_PGRAPH_PRI_GPC0_GPCCS_CTXSW_IDLESTATE : 0xf
[ 31.327074] NV_PGRAPH_PRI_FECS_CURRENT_CTX : 0x807ff65e
[ 31.327080] NV_PGRAPH_PRI_FECS_NEW_CTX : 0x807ff65e
[ 31.327088] NV_PGRAPH_PRI_BE0_CROP_STATUS1 : 0x5800000
[ 31.327095] NV_PGRAPH_PRI_BES_CROP_STATUS1 : 0x5800000
[ 31.327102] NV_PGRAPH_PRI_BE0_ZROP_STATUS : 0x0
[ 31.327109] NV_PGRAPH_PRI_BE0_ZROP_STATUS2 : 0x0
[ 31.327116] NV_PGRAPH_PRI_BES_ZROP_STATUS : 0x0
[ 31.327123] NV_PGRAPH_PRI_BES_ZROP_STATUS2 : 0x0
[ 31.327129] NV_PGRAPH_PRI_BE0_BECS_BE_EXCEPTION: 0x0
[ 31.327136] NV_PGRAPH_PRI_BE0_BECS_BE_EXCEPTION_EN: 0x0
[ 31.327144] NV_PGRAPH_PRI_GPC0_GPCCS_GPC_EXCEPTION: 0x0
[ 31.327151] NV_PGRAPH_PRI_GPC0_GPCCS_GPC_EXCEPTION_EN: 0x30000
[ 31.327158] NV_PGRAPH_PRI_GPC0_TPC0_TPCCS_TPC_EXCEPTION: 0x0
[ 31.327165] NV_PGRAPH_PRI_GPC0_TPC0_TPCCS_TPC_EXCEPTION_EN: 0x3
[ 31.327179] nvgpu: 57000000.gpu gr_gk20a_submit_fecs_method_op:579 [ERR] fecs method: data=0x807ff65e push adr=0x00000009
[ 31.327189] nvgpu: 57000000.gpu gr_gk20a_fecs_ctx_image_save:1367 [ERR] save context image failed
