What following says?
U-Boot 2016.07-ge6da093be3 (Jun 25 2020 - 21:18:08 -0700)
TEGRA210
Model: NVIDIA P3450-Porg
Board: NVIDIA P3450-PORG
DRAM: 4 GiB
MMC: Tegra SD/MMC: 0, Tegra SD/MMC: 1
SF: Failed to get idcodes
*** Warning - spi_flash_probe() failed, using default environment
In: serial
Out: serial
Err: serial
Net: No ethernet found.
Card did not respond to voltage select!
** Bad device mmc 1 **
Hit any key to stop autoboot: 0
switch to partitions #0, OK
mmc0(part 0) is current device
Scanning mmc 0:1…
Found /boot/extlinux/extlinux.conf
Retrieving file: /boot/extlinux/extlinux.conf
878 bytes read in 91 ms (8.8 KiB/s)
1: primary kernel
Retrieving file: /boot/initrd
5488163 bytes read in 191 ms (27.4 MiB/s)
Retrieving file: /boot/Image
34330632 bytes read in 810 ms (40.4 MiB/s)
append: tegraid=21.1.2.0.0 ddr_die=4096M@2048M section=512M memtype=0 vpr_resize usb_port_owner_info=0 lane_owner_info=0 emc_max_dvfs=0 touch_id=0@63 video=tegrafb no_console_suspend=1 console=ttyS0,115200n8 debug_uartport=lsport,2 earlyprintk=uart8250-32bit,0x70006000 maxcpus=4 usbcore.old_scheme_first=1 lp0_vec=0x1000@0xff780000 core_edp_mv=1075 core_edp_ma=4000 tegra_fbmem=0x800000@0x92cb0000 is_hdmi_initialised=1 earlycon=uart8250,mmio32,0x70006000 root=/dev/mmcblk0p1 rw rootwait rootfstype=ext4 console=ttyS0,115200n8 console=tty0 fbcon=map:0 net.ifnames=0 sdhci_tegra.en_boot_part_access=1 quiet root=/dev/mmcblk0p1 rw rootwait rootfstype=ext4 console=ttyS0,115200n8 console=tty0 fbcon=map:0 net.ifnames=0 sdhci_tegra.en_boot_part_access=1
Flattened Device Tree blob at 83100000
Booting using the fdt blob at 0x83100000
reserving fdt memory region: addr=80000000 size=20000
Using Device Tree in place at 0000000083100000, end 000000008317778b
Starting kernel …
[ 0.000000] Booting Linux on physical CPU 0x0
[ 0.000000] Linux version 4.9.140-tegra (buildbrain@mobile-u64-3456) (gcc version 7.3.1 20180425 [linaro-7.3-2018.05 revision d29120a424ecfbc167ef90065c0eeb7f91977701] (Linaro GCC 7.3-2018.05) ) #1 SMP PREEMPT Thu Jun 25 21:25:44 PDT 2020
[ 0.000000] Boot CPU: AArch64 Processor [411fd071]
[ 0.000000] OF: fdt:memory scan node memory@80000000, reg size 48,
[ 0.000000] OF: fdt: - 80000000 , 7ee00000
[ 0.000000] OF: fdt: - 100000000 , 7f200000
[ 0.000000] Found tegra_fbmem: 00800000@92cb0000
[ 0.000000] earlycon: uart8250 at MMIO32 0x0000000070006000 (options ‘’)
[ 0.000000] bootconsole [uart8250] enabled
[ 1.088132] tegradc tegradc.1: dpd enable lookup fail:-19
[ 1.119589] kobject_add_internal failed for rt8168_power with -EEXIST, don’t try to register things with the same name in the same directory.
[ 1.132539] unable to create rt8168_power_saver kernel object!
[ 1.308821] imx219 7-0010: imx219_board_setup: error during i2c read probe (-121)
[ 1.308855] imx219 7-0010: board setup failed
[ 1.332892] imx219 8-0010: imx219_board_setup: error during i2c read probe (-121)
[ 1.332925] imx219 8-0010: board setup failed
[ 1.683724] cgroup: cgroup2: unknown option “nsdelegate”
[ 2.102450] tegra_cec 70015000.tegra_cec: Sent res: 0.
[ 2.219765] tegra_cec 70015000.tegra_cec: Broadcast res: 0.
[ 2.227376] tegra_cec 70015000.tegra_cec: tegra_cec_init Done.
[ 2.686601] using random self ethernet address
[ 2.691368] using random host ethernet address
[ 3.216635] random: crng init done
[ 3.220072] random: 7 urandom warning(s) missed due to ratelimiting
[ 5.941335] nvgpu: 57000000.gpu gk20a_pmu_isr:724 [ERR] pmu exterr intr not implemented. Clearing interrupt.
[ 5.953172] nvgpu: 57000000.gpu gk20a_falcon_dump_stats:560 [ERR] <<< FALCON id-0 DEBUG INFORMATION - START >>>
[ 5.964406] nvgpu: 57000000.gpu gk20a_falcon_dump_imblk:504 [ERR] FALCON IMEM BLK MAPPING (PA->VA) (96 TOTAL):
[ 5.975639] nvgpu: 57000000.gpu gk20a_falcon_dump_imblk:518 [ERR] 0x00: 0x01000000 0x01000100 0x01000200 0x01000300
[ 5.987280] nvgpu: 57000000.gpu gk20a_falcon_dump_imblk:520 [ERR] 0x04: 0x01000400 0x01000500 0x01000600 0x01000700
[ 5.998943] nvgpu: 57000000.gpu gk20a_falcon_dump_imblk:518 [ERR] 0x08: 0x01000800 0x01000900 0x01000a00 0x01000b00
[ 6.010588] nvgpu: 57000000.gpu gk20a_falcon_dump_imblk:520 [ERR] 0x0c: 0x01000c00 0x01000d00 0x01000e00 0x01000f00
[ 6.022239] nvgpu: 57000000.gpu gk20a_falcon_dump_imblk:518 [ERR] 0x10: 0x01001000 0x01001100 0x01001200 0x01001300
[ 6.033875] nvgpu: 57000000.gpu gk20a_falcon_dump_imblk:520 [ERR] 0x14: 0x01001400 0x01001500 0x01001600 0x01002d00
[ 6.045521] nvgpu: 57000000.gpu gk20a_falcon_dump_imblk:518 [ERR] 0x18: 0x01002e00 0x01002f00 0x01003000 0x01003100
[ 6.057150] nvgpu: 57000000.gpu gk20a_falcon_dump_imblk:520 [ERR] 0x1c: 0x01001c00 0x01001d00 0x01001e00 0x01001f00
[ 6.068795] nvgpu: 57000000.gpu gk20a_falcon_dump_imblk:518 [ERR] 0x20: 0x01002000 0x01002100 0x01002200 0x01004b00
[ 6.080428] nvgpu: 57000000.gpu gk20a_falcon_dump_imblk:520 [ERR] 0x24: 0x01004c00 0x01004d00 0x01004e00 0x01004f00
[ 6.092069] nvgpu: 57000000.gpu gk20a_falcon_dump_imblk:518 [ERR] 0x28: 0x01005000 0x01005100 0x01002300 0x01002400
[ 6.103719] nvgpu: 57000000.gpu gk20a_falcon_dump_imblk:520 [ERR] 0x2c: 0x01002500 0x01003200 0x01003300 0x01003400
[ 6.115378] nvgpu: 57000000.gpu gk20a_falcon_dump_imblk:518 [ERR] 0x30: 0x01003500 0x01003600 0x01003700 0x01003800
[ 6.127021] nvgpu: 57000000.gpu gk20a_falcon_dump_imblk:520 [ERR] 0x34: 0x01003900 0x01003a00 0x01003b00 0x01003c00
[ 6.138676] nvgpu: 57000000.gpu gk20a_falcon_dump_imblk:518 [ERR] 0x38: 0x01003d00 0x01003e00 0x01003f00 0x01004000
[ 6.150311] nvgpu: 57000000.gpu gk20a_falcon_dump_imblk:520 [ERR] 0x3c: 0x01004100 0x01004200 0x01004300 0x01004400
[ 6.161956] nvgpu: 57000000.gpu gk20a_falcon_dump_imblk:518 [ERR] 0x40: 0x01004500 0x01004600 0x01004700 0x01004800
[ 6.173589] nvgpu: 57000000.gpu gk20a_falcon_dump_imblk:520 [ERR] 0x44: 0x01004900 0x01004a00 0x01005200 0x01005300
[ 6.185236] nvgpu: 57000000.gpu gk20a_falcon_dump_imblk:518 [ERR] 0x48: 0x01005400 0x01005500 0x01005600 0x01005700
[ 6.196880] nvgpu: 57000000.gpu gk20a_falcon_dump_imblk:520 [ERR] 0x4c: 0x01005800 0x01005900 0x01005a00 0x01005b00
[ 6.208541] nvgpu: 57000000.gpu gk20a_falcon_dump_imblk:518 [ERR] 0x50: 0x01005c00 0x01005d00 0x01005e00 0x01005f00
[ 6.220181] nvgpu: 57000000.gpu gk20a_falcon_dump_imblk:520 [ERR] 0x54: 0x01006000 0x01006100 0x01006200 0x01006300
[ 6.231840] nvgpu: 57000000.gpu gk20a_falcon_dump_imblk:518 [ERR] 0x58: 0x01006400 0x01006500 0x01006600 0x01002600
[ 6.243496] nvgpu: 57000000.gpu gk20a_falcon_dump_imblk:520 [ERR] 0x5c: 0x01002700 0x01002800 0x01002900 0x01002c00
[ 6.255135] nvgpu: 57000000.gpu gk20a_falcon_dump_pc_trace:541 [ERR] PC TRACE (TOTAL 7 ENTRIES. entry 0 is the most recent branch):
[ 6.267828] nvgpu: 57000000.gpu gk20a_falcon_dump_pc_trace:549 [ERR] FALCON_TRACEPC(0) : 0x0000054a
[ 6.277901] nvgpu: 57000000.gpu gk20a_falcon_dump_pc_trace:549 [ERR] FALCON_TRACEPC(1) : 0x00000545
[ 6.287972] nvgpu: 57000000.gpu gk20a_falcon_dump_pc_trace:549 [ERR] FALCON_TRACEPC(2) : 0x0000054e
[ 6.298034] nvgpu: 57000000.gpu gk20a_falcon_dump_pc_trace:549 [ERR] FALCON_TRACEPC(3) : 0x00000318
[ 6.308095] nvgpu: 57000000.gpu gk20a_falcon_dump_pc_trace:549 [ERR] FALCON_TRACEPC(4) : 0x000015e2
[ 6.318172] nvgpu: 57000000.gpu gk20a_falcon_dump_pc_trace:549 [ERR] FALCON_TRACEPC(5) : 0x0000160e
[ 6.328251] nvgpu: 57000000.gpu gk20a_falcon_dump_pc_trace:549 [ERR] FALCON_TRACEPC(6) : 0x00000a59
[ 6.338330] nvgpu: 57000000.gpu gk20a_falcon_dump_stats:567 [ERR] FALCON ICD REGISTERS DUMP
[ 6.338335] nvgpu: 57000000.gpu gk20a_falcon_dump_stats:575 [ERR] FALCON_REG_PC : 0x1041
[ 6.338339] nvgpu: 57000000.gpu gk20a_falcon_dump_stats:582 [ERR] FALCON_REG_SP : 0x43c4
[ 6.338345] nvgpu: 57000000.gpu gk20a_falcon_dump_stats:575 [ERR] FALCON_REG_PC : 0x1041
[ 6.338349] nvgpu: 57000000.gpu gk20a_falcon_dump_stats:582 [ERR] FALCON_REG_SP : 0x43c4
[ 6.338353] nvgpu: 57000000.gpu gk20a_falcon_dump_stats:575 [ERR] FALCON_REG_PC : 0x15c9
[ 6.338357] nvgpu: 57000000.gpu gk20a_falcon_dump_stats:582 [ERR] FALCON_REG_SP : 0x43c4
[ 6.338360] nvgpu: 57000000.gpu gk20a_falcon_dump_stats:575 [ERR] FALCON_REG_PC : 0x1041
[ 6.338364] nvgpu: 57000000.gpu gk20a_falcon_dump_stats:582 [ERR] FALCON_REG_SP : 0x43c4
[ 6.338368] nvgpu: 57000000.gpu gk20a_falcon_dump_stats:589 [ERR] FALCON_REG_IMB : 0xff5071
[ 6.338372] nvgpu: 57000000.gpu gk20a_falcon_dump_stats:595 [ERR] FALCON_REG_DMB : 0xff50d8
[ 6.338375] nvgpu: 57000000.gpu gk20a_falcon_dump_stats:601 [ERR] FALCON_REG_CSW : 0x330801
[ 6.338379] nvgpu: 57000000.gpu gk20a_falcon_dump_stats:607 [ERR] FALCON_REG_CTX : 0x0
[ 6.338383] nvgpu: 57000000.gpu gk20a_falcon_dump_stats:613 [ERR] FALCON_REG_EXCI : 0x693
[ 6.338387] nvgpu: 57000000.gpu gk20a_falcon_dump_stats:622 [ERR] FALCON_REG_RSTAT[0] : 0xa5a5a5a5
[ 6.338392] nvgpu: 57000000.gpu gk20a_falcon_dump_stats:622 [ERR] FALCON_REG_RSTAT[1] : 0xa5a5a5a5
[ 6.338395] nvgpu: 57000000.gpu gk20a_falcon_dump_stats:622 [ERR] FALCON_REG_RSTAT[2] : 0xa5a5a5a5
[ 6.338399] nvgpu: 57000000.gpu gk20a_falcon_dump_stats:622 [ERR] FALCON_REG_RSTAT[3] : 0xa5a5a5a5
[ 6.338403] nvgpu: 57000000.gpu gk20a_falcon_dump_stats:622 [ERR] FALCON_REG_RSTAT[4] : 0xa5a5a5a5
[ 6.338407] nvgpu: 57000000.gpu gk20a_falcon_dump_stats:622 [ERR] FALCON_REG_RSTAT[5] : 0xa5a5a5a5
[ 6.338409] nvgpu: 57000000.gpu gk20a_falcon_dump_stats:625 [ERR] FALCON REGISTERS DUMP
[ 6.338412] nvgpu: 57000000.gpu gk20a_falcon_dump_stats:627 [ERR] falcon_falcon_os_r : 0
[ 6.338415] nvgpu: 57000000.gpu gk20a_falcon_dump_stats:629 [ERR] falcon_falcon_cpuctl_r : 0x60
[ 6.338419] nvgpu: 57000000.gpu gk20a_falcon_dump_stats:631 [ERR] falcon_falcon_idlestate_r : 0x0
[ 6.338422] nvgpu: 57000000.gpu gk20a_falcon_dump_stats:633 [ERR] falcon_falcon_mailbox0_r : 0x0
[ 6.338425] nvgpu: 57000000.gpu gk20a_falcon_dump_stats:635 [ERR] falcon_falcon_mailbox1_r : 0x0
[ 6.338429] nvgpu: 57000000.gpu gk20a_falcon_dump_stats:637 [ERR] falcon_falcon_irqstat_r : 0x60
[ 6.338432] nvgpu: 57000000.gpu gk20a_falcon_dump_stats:639 [ERR] falcon_falcon_irqmode_r : 0xfc24
[ 6.338436] nvgpu: 57000000.gpu gk20a_falcon_dump_stats:641 [ERR] falcon_falcon_irqmask_r : 0x7879
[ 6.338439] nvgpu: 57000000.gpu gk20a_falcon_dump_stats:643 [ERR] falcon_falcon_irqdest_r : 0x90372
[ 6.338442] nvgpu: 57000000.gpu gk20a_falcon_dump_stats:645 [ERR] falcon_falcon_debug1_r : 0x10000
[ 6.338445] nvgpu: 57000000.gpu gk20a_falcon_dump_stats:647 [ERR] falcon_falcon_debuginfo_r : 0x0
[ 6.338449] nvgpu: 57000000.gpu gk20a_falcon_dump_stats:649 [ERR] falcon_falcon_bootvec_r : 0x3200
[ 6.338452] nvgpu: 57000000.gpu gk20a_falcon_dump_stats:651 [ERR] falcon_falcon_hwcfg_r : 0x400cc060
[ 6.338455] nvgpu: 57000000.gpu gk20a_falcon_dump_stats:653 [ERR] falcon_falcon_engctl_r : 0x0
[ 6.338459] nvgpu: 57000000.gpu gk20a_falcon_dump_stats:655 [ERR] falcon_falcon_curctx_r : 0x707fffe7
[ 6.338462] nvgpu: 57000000.gpu gk20a_falcon_dump_stats:657 [ERR] falcon_falcon_nxtctx_r : 0x707fffe7
[ 6.338465] nvgpu: 57000000.gpu gk20a_falcon_dump_stats:659 [ERR] falcon_falcon_exterrstat_r : 0x85002efb
[ 6.338469] nvgpu: 57000000.gpu gk20a_falcon_dump_stats:661 [ERR] falcon_falcon_exterraddr_r : 0x18405804
[ 6.338474] nvgpu: 57000000.gpu gk20a_pmu_dump_falcon_stats:630 [ERR] pwr_pmu_mailbox_r(0) : 0x0
[ 6.338478] nvgpu: 57000000.gpu gk20a_pmu_dump_falcon_stats:630 [ERR] pwr_pmu_mailbox_r(1) : 0x0
[ 6.338481] nvgpu: 57000000.gpu gk20a_pmu_dump_falcon_stats:630 [ERR] pwr_pmu_mailbox_r(2) : 0x0
[ 6.338485] nvgpu: 57000000.gpu gk20a_pmu_dump_falcon_stats:630 [ERR] pwr_pmu_mailbox_r(3) : 0x0
[ 6.338488] nvgpu: 57000000.gpu gk20a_pmu_dump_falcon_stats:630 [ERR] pwr_pmu_mailbox_r(4) : 0x0
[ 6.338492] nvgpu: 57000000.gpu gk20a_pmu_dump_falcon_stats:630 [ERR] pwr_pmu_mailbox_r(5) : 0x0
[ 6.338495] nvgpu: 57000000.gpu gk20a_pmu_dump_falcon_stats:630 [ERR] pwr_pmu_mailbox_r(6) : 0x0
[ 6.338498] nvgpu: 57000000.gpu gk20a_pmu_dump_falcon_stats:630 [ERR] pwr_pmu_mailbox_r(7) : 0x0
[ 6.338502] nvgpu: 57000000.gpu gk20a_pmu_dump_falcon_stats:630 [ERR] pwr_pmu_mailbox_r(8) : 0x0
[ 6.338505] nvgpu: 57000000.gpu gk20a_pmu_dump_falcon_stats:630 [ERR] pwr_pmu_mailbox_r(9) : 0x0
[ 6.338508] nvgpu: 57000000.gpu gk20a_pmu_dump_falcon_stats:630 [ERR] pwr_pmu_mailbox_r(10) : 0x0
[ 6.338512] nvgpu: 57000000.gpu gk20a_pmu_dump_falcon_stats:630 [ERR] pwr_pmu_mailbox_r(11) : 0x0
[ 6.338516] nvgpu: 57000000.gpu gk20a_pmu_dump_falcon_stats:635 [ERR] pwr_pmu_debug_r(0) : 0x0
[ 6.338519] nvgpu: 57000000.gpu gk20a_pmu_dump_falcon_stats:635 [ERR] pwr_pmu_debug_r(1) : 0x0
[ 6.338523] nvgpu: 57000000.gpu gk20a_pmu_dump_falcon_stats:635 [ERR] pwr_pmu_debug_r(2) : 0x2a
[ 6.338526] nvgpu: 57000000.gpu gk20a_pmu_dump_falcon_stats:635 [ERR] pwr_pmu_debug_r(3) : 0x0
[ 6.338530] nvgpu: 57000000.gpu gk20a_pmu_dump_falcon_stats:639 [ERR] pwr_pmu_bar0_error_status_r : 0x0
[ 6.338533] nvgpu: 57000000.gpu gk20a_pmu_dump_falcon_stats:652 [ERR] pwr_pmu_bar0_fecs_error_r : 0xbadf1201
[ 6.338537] nvgpu: 57000000.gpu gk20a_pmu_dump_falcon_stats:655 [ERR] pwr_falcon_exterrstat_r : 0x85002efb
[ 6.338541] nvgpu: 57000000.gpu gk20a_pmu_dump_falcon_stats:659 [ERR] pwr_falcon_exterraddr_r : 0x18405804
[ 6.338573] nvgpu: 57000000.gpu print_pmu_trace:88 [ERR] dump PMU trace buffer
[ 6.338578] nvgpu: 57000000.gpu nvgpu_pmu_dump_falcon_stats:51 [ERR] pmu state: 7
[ 6.338580] nvgpu: 57000000.gpu nvgpu_pmu_dump_falcon_stats:52 [ERR] elpg state: 0
[ 6.338584] nvgpu: 57000000.gpu gk20a_fecs_dump_falcon_stats:129 [ERR] gr_fecs_os_r : 0
[ 6.338588] nvgpu: 57000000.gpu gk20a_fecs_dump_falcon_stats:131 [ERR] gr_fecs_cpuctl_r : 0x60
[ 6.338591] nvgpu: 57000000.gpu gk20a_fecs_dump_falcon_stats:133 [ERR] gr_fecs_idlestate_r : 0x0
[ 6.338594] nvgpu: 57000000.gpu gk20a_fecs_dump_falcon_stats:135 [ERR] gr_fecs_mailbox0_r : 0x0
[ 6.338597] nvgpu: 57000000.gpu gk20a_fecs_dump_falcon_stats:137 [ERR] gr_fecs_mailbox1_r : 0x0
[ 6.338601] nvgpu: 57000000.gpu gk20a_fecs_dump_falcon_stats:139 [ERR] gr_fecs_irqstat_r : 0x0
[ 6.338604] nvgpu: 57000000.gpu gk20a_fecs_dump_falcon_stats:141 [ERR] gr_fecs_irqmode_r : 0x4
[ 6.338607] nvgpu: 57000000.gpu gk20a_fecs_dump_falcon_stats:143 [ERR] gr_fecs_irqmask_r : 0x8704
[ 6.338610] nvgpu: 57000000.gpu gk20a_fecs_dump_falcon_stats:145 [ERR] gr_fecs_irqdest_r : 0x0
[ 6.338614] nvgpu: 57000000.gpu gk20a_fecs_dump_falcon_stats:147 [ERR] gr_fecs_debug1_r : 0x40
[ 6.338617] nvgpu: 57000000.gpu gk20a_fecs_dump_falcon_stats:149 [ERR] gr_fecs_debuginfo_r : 0x0
[ 6.338620] nvgpu: 57000000.gpu gk20a_fecs_dump_falcon_stats:151 [ERR] gr_fecs_ctxsw_status_1_r : 0x382
[ 6.338623] nvgpu: 57000000.gpu gk20a_fecs_dump_falcon_stats:155 [ERR] gr_fecs_ctxsw_mailbox_r(0) : 0x1
[ 6.338627] nvgpu: 57000000.gpu gk20a_fecs_dump_falcon_stats:155 [ERR] gr_fecs_ctxsw_mailbox_r(1) : 0x0
[ 6.338630] nvgpu: 57000000.gpu gk20a_fecs_dump_falcon_stats:155 [ERR] gr_fecs_ctxsw_mailbox_r(2) : 0x1
[ 6.338633] nvgpu: 57000000.gpu gk20a_fecs_dump_falcon_stats:155 [ERR] gr_fecs_ctxsw_mailbox_r(3) : 0x0
[ 6.338636] nvgpu: 57000000.gpu gk20a_fecs_dump_falcon_stats:155 [ERR] gr_fecs_ctxsw_mailbox_r(4) : 0x1ffda0
[ 6.338639] nvgpu: 57000000.gpu gk20a_fecs_dump_falcon_stats:155 [ERR] gr_fecs_ctxsw_mailbox_r(5) : 0x0
[ 6.338642] nvgpu: 57000000.gpu gk20a_fecs_dump_falcon_stats:155 [ERR] gr_fecs_ctxsw_mailbox_r(6) : 0x0
[ 6.338646] nvgpu: 57000000.gpu gk20a_fecs_dump_falcon_stats:155 [ERR] gr_fecs_ctxsw_mailbox_r(7) : 0x0
[ 6.338649] nvgpu: 57000000.gpu gk20a_fecs_dump_falcon_stats:155 [ERR] gr_fecs_ctxsw_mailbox_r(8) : 0x0
[ 6.338652] nvgpu: 57000000.gpu gk20a_fecs_dump_falcon_stats:155 [ERR] gr_fecs_ctxsw_mailbox_r(9) : 0x0
[ 6.338655] nvgpu: 57000000.gpu gk20a_fecs_dump_falcon_stats:155 [ERR] gr_fecs_ctxsw_mailbox_r(10) : 0x0
[ 6.338658] nvgpu: 57000000.gpu gk20a_fecs_dump_falcon_stats:155 [ERR] gr_fecs_ctxsw_mailbox_r(11) : 0x0
[ 6.338661] nvgpu: 57000000.gpu gk20a_fecs_dump_falcon_stats:155 [ERR] gr_fecs_ctxsw_mailbox_r(12) : 0x0
[ 6.338664] nvgpu: 57000000.gpu gk20a_fecs_dump_falcon_stats:155 [ERR] gr_fecs_ctxsw_mailbox_r(13) : 0x0
[ 6.338668] nvgpu: 57000000.gpu gk20a_fecs_dump_falcon_stats:155 [ERR] gr_fecs_ctxsw_mailbox_r(14) : 0x0
[ 6.338671] nvgpu: 57000000.gpu gk20a_fecs_dump_falcon_stats:155 [ERR] gr_fecs_ctxsw_mailbox_r(15) : 0x0
[ 6.338674] nvgpu: 57000000.gpu gk20a_fecs_dump_falcon_stats:159 [ERR] gr_fecs_engctl_r : 0x0
[ 6.338677] nvgpu: 57000000.gpu gk20a_fecs_dump_falcon_stats:161 [ERR] gr_fecs_curctx_r : 0x0
[ 6.338681] nvgpu: 57000000.gpu gk20a_fecs_dump_falcon_stats:163 [ERR] gr_fecs_nxtctx_r : 0x0
[ 6.338684] nvgpu: 57000000.gpu gk20a_fecs_dump_falcon_stats:169 [ERR] FECS_FALCON_REG_IMB : 0xbadfbadf
[ 6.338688] nvgpu: 57000000.gpu gk20a_fecs_dump_falcon_stats:175 [ERR] FECS_FALCON_REG_DMB : 0xbadfbadf
[ 6.338692] nvgpu: 57000000.gpu gk20a_fecs_dump_falcon_stats:181 [ERR] FECS_FALCON_REG_CSW : 0xbadfbadf
[ 6.338695] nvgpu: 57000000.gpu gk20a_fecs_dump_falcon_stats:187 [ERR] FECS_FALCON_REG_CTX : 0xbadfbadf
[ 6.338699] nvgpu: 57000000.gpu gk20a_fecs_dump_falcon_stats:193 [ERR] FECS_FALCON_REG_EXCI : 0xbadfbadf
[ 6.338703] nvgpu: 57000000.gpu gk20a_fecs_dump_falcon_stats:200 [ERR] FECS_FALCON_REG_PC : 0xbadfbadf
[ 6.338706] nvgpu: 57000000.gpu gk20a_fecs_dump_falcon_stats:206 [ERR] FECS_FALCON_REG_SP : 0xbadfbadf
[ 6.338710] nvgpu: 57000000.gpu gk20a_fecs_dump_falcon_stats:200 [ERR] FECS_FALCON_REG_PC : 0xbadfbadf
[ 6.338714] nvgpu: 57000000.gpu gk20a_fecs_dump_falcon_stats:206 [ERR] FECS_FALCON_REG_SP : 0xbadfbadf
[ 6.338717] nvgpu: 57000000.gpu gk20a_fecs_dump_falcon_stats:200 [ERR] FECS_FALCON_REG_PC : 0xbadfbadf
[ 6.338721] nvgpu: 57000000.gpu gk20a_fecs_dump_falcon_stats:206 [ERR] FECS_FALCON_REG_SP : 0xbadfbadf
[ 6.338724] nvgpu: 57000000.gpu gk20a_fecs_dump_falcon_stats:200 [ERR] FECS_FALCON_REG_PC : 0xbadfbadf
[ 6.338728] nvgpu: 57000000.gpu gk20a_fecs_dump_falcon_stats:206 [ERR] FECS_FALCON_REG_SP : 0xbadfbadf
[ 6.338817] nvgpu: 57000000.gpu gk20a_ptimer_isr:50 [ERR] PRI timeout: ADR 0x00122124 READ DATA 0x00000000
[ 6.338820] nvgpu: 57000000.gpu gk20a_ptimer_isr:56 [ERR] FECS_ERRCODE 0xbadf5202
Ubuntu 18.04.4 LTS jetson9-desktop ttyS0
R32 (release), REVISION: 4.3, GCID: 21589087, BOARD: t210ref, EABI: aarch64, DATE: Fri Jun 26 04:38:25 UTC 2020
Thank you.
