I encountered a GUI loading issue after running.
sudo apt-get upgrade
sudo reboot
I went through most of the related posts but couldn’t solve the issue. I am able to ssh to the device.
The display shows the system hangs at “started Update UTMP about System Runlevel Changes”
I looked the Xorg.0.log and systemctl status gdm3.service. Here are the outputs:
Xorg.0.log:
[ 22.909] (--) Log file renamed from "/var/log/Xorg.pid-8510.log" to "/var/log/Xorg.0.log"
[ 22.911]
X.Org X Server 1.19.6
Release Date: 2017-12-20
[ 22.911] X Protocol Version 11, Revision 0
[ 22.911] Build Operating System: Linux 4.15.0-163-generic aarch64 Ubuntu
[ 22.911] Current Operating System: Linux 00-Raiser 4.9.140-tegra #1 SMP PREEMPT Wed Apr 8 18:15:20 PDT 2020 aarch64
[ 22.911] Kernel command line: root=/dev/mmcblk0p1 rw rootwait rootfstype=ext4 console=ttyTCU0,115200n8 console=tty0 fbcon=map:0 net.ifnames=0 rootfstype=ext4 video=tegrafb no_console_suspend=1 earlycon=tegra_comb_uart,mmio32,0x0c168000 gpt usbcore.old_scheme_first=1 tegraid=19.1.2.0.0 maxcpus=8 boot.slot_suffix= boot.ratchetvalues=0.4.2 vpr_resize sdhci_tegra.en_boot_part_access=1
[ 22.911] Build Date: 14 December 2021 04:14:51PM
[ 22.911] xorg-server 2:1.19.6-1ubuntu4.10 (For technical support please see http://www.ubuntu.com/support)
[ 22.911] Current version of pixman: 0.34.0
[ 22.911] Before reporting problems, check http://wiki.x.org
to make sure that you have the latest version.
[ 22.911] Markers: (--) probed, (**) from config file, (==) default setting,
(++) from command line, (!!) notice, (II) informational,
(WW) warning, (EE) error, (NI) not implemented, (??) unknown.
[ 22.912] (==) Log file: "/var/log/Xorg.0.log", Time: Tue Feb 8 14:43:48 2022
[ 22.912] (==) Using config file: "/etc/X11/xorg.conf"
[ 22.912] (==) Using system config directory "/usr/share/X11/xorg.conf.d"
[ 22.913] (==) No Layout section. Using the first Screen section.
[ 22.913] (**) |-->Screen "Default Screen" (0)
[ 22.913] (**) | |-->Monitor "<default monitor>"
[ 22.916] (**) | |-->Device "Tegra0"
[ 22.916] (==) No monitor specified for screen "Default Screen".
Using a default monitor configuration.
[ 22.916] (==) Automatically adding devices
[ 22.916] (==) Automatically enabling devices
[ 22.916] (==) Automatically adding GPU devices
[ 22.916] (==) Automatically binding GPU devices
[ 22.916] (==) Max clients allowed: 256, resource mask: 0x1fffff
[ 22.916] (WW) The directory "/usr/share/fonts/X11/100dpi/" does not exist.
[ 22.916] Entry deleted from font path.
[ 22.916] (WW) The directory "/usr/share/fonts/X11/75dpi/" does not exist.
[ 22.916] (WW) The directory "/usr/share/fonts/X11/100dpi" does not exist.
[ 22.916] (WW) The directory "/usr/share/fonts/X11/75dpi" does not exist.
[ 22.917] (==) FontPath set to:
/usr/share/fonts/X11/misc,
/usr/share/fonts/X11/cyrillic,
/usr/share/fonts/X11/Type1,
built-ins
[ 22.917] (==) ModulePath set to "/usr/lib/xorg/modules"
[ 22.917] (II) The server relies on udev to provide the list of input devices.
If no devices become available, reconfigure udev or disable AutoAddDevices.
[ 22.917] (II) Loader magic: 0x5558562010
[ 22.917] (II) Module ABI versions:
[ 22.917] X.Org ANSI C Emulation: 0.4
[ 22.917] X.Org Video Driver: 23.0
[ 22.917] X.Org XInput driver : 24.1
[ 22.917] X.Org Server Extension : 10.0
[ 22.919] (++) using VT number 1
[ 22.928] (II) systemd-logind: took control of session /org/freedesktop/login1/session/c2
[ 22.932] (II) no primary bus or device found
[ 22.932] (WW) "dri" will not be loaded unless you've specified it to be loaded elsewhere.
[ 22.932] (II) "glx" will be loaded by default.
[ 22.932] (II) LoadModule: "extmod"
[ 22.933] (II) Module "extmod" already built-in
[ 22.933] (II) LoadModule: "glx"
[ 22.933] (II) Loading /usr/lib/xorg/modules/extensions/libglx.so
[ 22.936] (II) Module glx: vendor="X.Org Foundation"
[ 22.936] compiled for 1.19.6, module version = 1.0.0
[ 22.936] ABI class: X.Org Server Extension, version 10.0
[ 22.936] (II) LoadModule: "nvidia"
[ 22.937] (II) Loading /usr/lib/xorg/modules/drivers/nvidia_drv.so
[ 22.938] (II) Module nvidia: vendor="NVIDIA Corporation"
[ 22.938] compiled for 4.0.2, module version = 1.0.0
[ 22.938] Module class: X.Org Video Driver
[ 22.938] (II) NVIDIA dlloader X Driver 32.4.4 Release Build (integ_stage_rel) (buildbrain@mobile-u64-4294) Tue Oct 27 21:02:20 PDT 2020
[ 22.938] (II) NVIDIA Unified Driver for all Supported NVIDIA GPUs
[ 22.939] (WW) Falling back to old probe method for NVIDIA
[ 22.939] (II) Loading sub module "fb"
[ 22.939] (II) LoadModule: "fb"
[ 22.939] (II) Loading /usr/lib/xorg/modules/libfb.so
[ 22.940] (II) Module fb: vendor="X.Org Foundation"
[ 22.940] compiled for 1.19.6, module version = 1.0.0
[ 22.940] ABI class: X.Org ANSI C Emulation, version 0.4
[ 22.940] (II) Loading sub module "wfb"
[ 22.940] (II) LoadModule: "wfb"
[ 22.940] (II) Loading /usr/lib/xorg/modules/libwfb.so
[ 22.941] (II) Module wfb: vendor="X.Org Foundation"
[ 22.941] compiled for 1.19.6, module version = 1.0.0
[ 22.941] ABI class: X.Org ANSI C Emulation, version 0.4
[ 22.941] (II) Loading sub module "ramdac"
[ 22.941] (II) LoadModule: "ramdac"
[ 22.941] (II) Module "ramdac" already built-in
[ 22.943] (WW) VGA arbiter: cannot open kernel arbiter, no multi-card support
[ 22.943] (==) NVIDIA(0): Depth 24, (==) framebuffer bpp 32
[ 22.943] (==) NVIDIA(0): RGB weight 888
[ 22.943] (==) NVIDIA(0): Default visual is TrueColor
[ 22.943] (==) NVIDIA(0): Using gamma correction (1.0, 1.0, 1.0)
[ 22.943] (DB) xf86MergeOutputClassOptions unsupported bus type 0
[ 22.943] (**) NVIDIA(0): Option "AllowEmptyInitialConfiguration" "true"
[ 22.944] (**) NVIDIA(0): Enabling 2D acceleration
[ 22.944] (II) Loading sub module "glxserver_nvidia"
[ 22.944] (II) LoadModule: "glxserver_nvidia"
[ 22.944] (II) Loading /usr/lib/xorg/modules/extensions/libglxserver_nvidia.so
[ 22.953] (II) Module glxserver_nvidia: vendor="NVIDIA Corporation"
[ 22.953] compiled for 4.0.2, module version = 1.0.0
[ 22.954] Module class: X.Org Server Extension
[ 22.954] (II) NVIDIA GLX Module 32.4.4 Release Build (integ_stage_rel) (buildbrain@mobile-u64-4294) Tue Oct 27 21:00:13 PDT 2020
[ 22.958] (--) NVIDIA(0): Valid display device(s) on GPU-0 at SoC
[ 22.958] (--) NVIDIA(0): DFP-0
[ 22.958] (--) NVIDIA(0): DFP-1
[ 22.958] (--) NVIDIA(0): DFP-2
[ 22.958] (II) NVIDIA(0): NVIDIA GPU Xavier (nvgpu) (GV11B) at SoC (GPU-0)
[ 22.958] (--) NVIDIA(0): Memory: 32692996 kBytes
[ 22.958] (--) NVIDIA(0): VideoBIOS:
[ 22.959] (==) NVIDIA(0):
[ 22.959] (==) NVIDIA(0): No modes were requested; the default mode "nvidia-auto-select"
[ 22.959] (==) NVIDIA(0): will be used as the requested mode.
[ 22.959] (--) NVIDIA(0): No enabled display devices found; starting anyway because
[ 22.959] (--) NVIDIA(0): AllowEmptyInitialConfiguration is enabled
[ 22.959] (II) NVIDIA(0): Validated MetaModes:
[ 22.959] (II) NVIDIA(0): "NULL"
[ 22.959] (**) NVIDIA(0): Virtual screen size configured to be 1280 x 720
[ 22.959] (WW) NVIDIA(0): Unable to get display device for DPI computation.
[ 22.959] (==) NVIDIA(0): DPI set to (75, 75); computed from built-in default
[ 22.959] (--) Depth 24 pixmap format is 32 bpp
[ 22.960] (II) NVIDIA: Reserving 24576.00 MB of virtual memory for indirect memory
[ 22.960] (II) NVIDIA: access.
[ 22.966] (EE) NVIDIA(0): Failed to allocate NVIDIA Error Handler
[ 22.967] (II) NVIDIA(0): ACPI: failed to connect to the ACPI event daemon; the daemon
[ 22.967] (II) NVIDIA(0): may not be running or the "AcpidSocketPath" X
[ 22.967] (II) NVIDIA(0): configuration option may not be set correctly. When the
[ 22.967] (II) NVIDIA(0): ACPI event daemon is available, the NVIDIA X driver will
[ 22.967] (II) NVIDIA(0): try to use it to receive ACPI event notifications. For
[ 22.967] (II) NVIDIA(0): details, please see the "ConnectToAcpid" and
[ 22.967] (II) NVIDIA(0): "AcpidSocketPath" X configuration options in Appendix B: X
[ 22.967] (II) NVIDIA(0): Config Options in the README.
systemctl status gdm3.service:
Feb 08 14:43:38 00-Raiser systemd[1]: Starting GNOME Display Manager...
Feb 08 14:43:38 00-Raiser systemd[1]: Started GNOME Display Manager.
Feb 08 14:43:39 00-Raiser gdm-autologin][7401]: AccountsService: ActUserManager: user (null) has no username (object path: /org/freedesktop/Accounts/User1000, uid:
Feb 08 14:43:39 00-Raiser gdm-autologin][7401]: gkr-pam: no password is available for user
Feb 08 14:43:39 00-Raiser gdm-autologin][7401]: pam_unix(gdm-autologin:session): session opened for user archer by (uid=0)
Feb 08 14:43:44 00-Raiser gdm-launch-environment][8154]: pam_unix(gdm-launch-environment:session): session opened for user gdm by (uid=0)
Feb 08 14:43:48 00-Raiser gdm3[7184]: Child process -8430 was already dead.
Feb 08 14:43:48 00-Raiser gdm3[7184]: Child process 8154 was already dead.
Feb 08 14:43:48 00-Raiser gdm3[7184]: Unable to kill session worker process
Feb 08 14:43:48 00-Raiser gdm-launch-environment][8489]: pam_unix(gdm-launch-environment:session): session opened for user gdm by (uid=0)
The log file seems unfinished as it ends at “[ 22.967] (II) NVIDIA(0): Config Options in the README.”.
I am a little lost from here.
Any help and comments would be appreciated!
Archer
