Sadness, please help…
I dropped suse tumbleweed 32bit for leap 42.3 64bit.
The auto detection of my monitors seems not to work. The driver detects 2 monitors on card2 and 1 monitor on card 1.
Startup time of X seems buggy too. Shutdown of X definitely breaks. I can’t restart X. Have to bounce the rig. I tried various drivers from 390 up to 396.18 beta.
I tried switching off Xinerama but i did not get any difference in the behaviour.
lspci | grep "VGA"
01:00.0 VGA compatible controller: NVIDIA Corporation Device 1c82 (rev a1)
02:00.0 VGA compatible controller: NVIDIA Corporation Device 1c82 (rev a1)
uname -a
Linux 4.4.76-1-default #1 SMP Fri Jul 14 08:48:13 UTC 2017 (9a2885c) x86_64 x86_64 x86_64 GNU/Linux
/var/log/Xorg.0.log
[ 65.611]
X.Org X Server 1.18.3
Release Date: 2016-04-04
[ 65.611] X Protocol Version 11, Revision 0
[ 65.611] Build Operating System: openSUSE SUSE LINUX
[ 65.612] Current Operating System: Linux boeretroos 4.4.76-1-default #1 SMP Fri Jul 14 08:48:13 UTC 2017 (9a2885c) x86_64
[ 65.612] Kernel command line: BOOT_IMAGE=/vmlinuz-4.4.76-1-default root=UUID=79205948-fab1-47c0-8033-e93318887ed7 resume=/dev/sdb2 quiet showopts resume=/dev/sdb2 quiet showopts resume=/dev/sdb2 quiet showopts resume=/dev/sdb2 quiet showopts
[ 65.612] Build Date: 11 July 2017 02:20:05PM
[ 65.612]
[ 65.612] Current version of pixman: 0.34.0
[ 65.612] Before reporting problems, check http://wiki.x.org
to make sure that you have the latest version.
[ 65.612] Markers: (--) probed, (**) from config file, (==) default setting,
(++) from command line, (!!) notice, (II) informational,
(WW) warning, (EE) error, (NI) not implemented, (??) unknown.
[ 65.612] (==) Log file: "/var/log/Xorg.0.log", Time: Thu May 10 14:20:58 2018
[ 65.693] (==) Using config directory: "/etc/X11/xorg.conf.d"
[ 65.693] (==) Using system config directory "/usr/share/X11/xorg.conf.d"
[ 65.827] (==) ServerLayout "quad"
[ 65.827] (**) |-->Screen "screen0" (0)
[ 65.827] (**) | |-->Monitor "monitor0"
[ 65.827] (**) | |-->Device "nvcard1"
[ 65.827] (**) |-->Screen "screen1" (1)
[ 65.827] (**) | |-->Monitor "monitor1"
[ 65.827] (**) | |-->Device "nvcard2"
[ 65.827] (**) Option "Xinerama" "0"
[ 65.827] (==) Automatically adding devices
[ 65.827] (==) Automatically enabling devices
[ 65.827] (==) Automatically adding GPU devices
[ 65.827] (==) Max clients allowed: 256, resource mask: 0x1fffff
[ 65.922] (WW) The directory "/usr/share/fonts/misc/sgi" does not exist.
[ 65.923] Entry deleted from font path.
[ 65.932] (==) FontPath set to:
/usr/share/fonts/misc:unscaled,
/usr/share/fonts/Type1/,
/usr/share/fonts/100dpi:unscaled,
/usr/share/fonts/75dpi:unscaled,
/usr/share/fonts/ghostscript/,
/usr/share/fonts/cyrillic:unscaled,
/usr/share/fonts/truetype/,
built-ins
[ 65.932] (==) ModulePath set to "/usr/lib64/xorg/modules"
[ 65.932] (**) Extension "XFree86-DGA" is disabled
[ 65.932] (II) The server relies on udev to provide the list of input devices.
If no devices become available, reconfigure udev or disable AutoAddDevices.
[ 65.932] (II) Loader magic: 0x80fce0
[ 65.932] (II) Module ABI versions:
[ 65.932] X.Org ANSI C Emulation: 0.4
[ 65.932] X.Org Video Driver: 20.0
[ 65.932] X.Org XInput driver : 22.1
[ 65.932] X.Org Server Extension : 9.0
[ 65.932] (--) using VT number 2
[ 65.932] (II) systemd-logind: logind integration requires -keeptty and -keeptty was not provided, disabling logind integration
[ 65.933] (II) xfree86: Adding drm device (/dev/dri/card0)
[ 65.933] (II) xfree86: Adding drm device (/dev/dri/card1)
[ 65.934] (--) PCI:*(0:1:0:0) 10de:1c82:1458:372a rev 161, Mem @ 0xf6000000/16777216, 0xe0000000/268435456, 0xf0000000/33554432, I/O @ 0x0000e000/128, BIOS @ 0x????????/524288
[ 65.934] (--) PCI: (0:2:0:0) 10de:1c82:1458:372a rev 161, Mem @ 0xf4000000/16777216, 0xc0000000/268435456, 0xd0000000/33554432, I/O @ 0x0000d000/128, BIOS @ 0x????????/524288
[ 65.934] (II) "glx" will be loaded by default.
[ 65.934] (II) LoadModule: "dri2"
[ 65.934] (II) Module "dri2" already built-in
[ 65.934] (II) LoadModule: "glamoregl"
[ 65.935] (II) Loading /usr/lib64/xorg/modules/libglamoregl.so
[ 65.985] (II) Module glamoregl: vendor="X.Org Foundation"
[ 65.985] compiled for 1.18.3, module version = 1.0.0
[ 65.985] ABI class: X.Org ANSI C Emulation, version 0.4
[ 65.985] (II) LoadModule: "glx"
[ 66.006] (II) Loading /usr/lib64/xorg/modules/extensions/libglx.so
[ 66.353] (II) Module glx: vendor="NVIDIA Corporation"
[ 66.353] compiled for 4.0.2, module version = 1.0.0
[ 66.353] Module class: X.Org Server Extension
[ 66.357] (II) NVIDIA GLX Module 390.48 Wed Mar 21 23:42:56 PDT 2018
[ 66.367] (II) LoadModule: "nvidia"
[ 66.367] (II) Loading /usr/lib64/xorg/modules/drivers/nvidia_drv.so
[ 66.410] (II) Module nvidia: vendor="NVIDIA Corporation"
[ 66.410] compiled for 4.0.2, module version = 1.0.0
[ 66.410] Module class: X.Org Video Driver
[ 66.422] (II) NVIDIA dlloader X Driver 390.48 Wed Mar 21 23:18:15 PDT 2018
[ 66.422] (II) NVIDIA Unified Driver for all Supported NVIDIA GPUs
[ 66.435] (II) Loading sub module "fb"
[ 66.435] (II) LoadModule: "fb"
[ 66.435] (II) Loading /usr/lib64/xorg/modules/libfb.so
[ 66.445] (II) Module fb: vendor="X.Org Foundation"
[ 66.445] compiled for 1.18.3, module version = 1.0.0
[ 66.445] ABI class: X.Org ANSI C Emulation, version 0.4
[ 66.445] (II) Loading sub module "wfb"
[ 66.445] (II) LoadModule: "wfb"
[ 66.445] (II) Loading /usr/lib64/xorg/modules/libwfb.so
[ 66.458] (II) Module wfb: vendor="X.Org Foundation"
[ 66.458] compiled for 1.18.3, module version = 1.0.0
[ 66.458] ABI class: X.Org ANSI C Emulation, version 0.4
[ 66.458] (II) Loading sub module "ramdac"
[ 66.458] (II) LoadModule: "ramdac"
[ 66.458] (II) Module "ramdac" already built-in
[ 66.458] (II) NVIDIA(0): Creating default Display subsection in Screen section
"screen0" for depth/fbbpp 24/32
[ 66.458] (==) NVIDIA(0): Depth 24, (==) framebuffer bpp 32
[ 66.458] (==) NVIDIA(0): RGB weight 888
[ 66.458] (==) NVIDIA(0): Default visual is TrueColor
[ 66.458] (==) NVIDIA(0): Using gamma correction (1.0, 1.0, 1.0)
[ 66.459] (**) NVIDIA(0): Enabling 2D acceleration
[ 67.435] (--) NVIDIA(0): Valid display device(s) on GPU-0 at PCI:1:0:0
[ 67.435] (--) NVIDIA(0): DFP-0
[ 67.435] (--) NVIDIA(0): DFP-1 (boot)
[ 67.435] (--) NVIDIA(0): DFP-2
[ 67.435] (--) NVIDIA(0): DFP-3
[ 67.435] (--) NVIDIA(0): DFP-4
[ 67.435] (--) NVIDIA(0): DFP-5
[ 67.436] (II) NVIDIA(0): NVIDIA GPU GeForce GTX 1050 Ti (GP107-A) at PCI:1:0:0 (GPU-0)
[ 67.436] (--) NVIDIA(0): Memory: 4194304 kBytes
[ 67.436] (--) NVIDIA(0): VideoBIOS: 86.07.39.00.54
[ 67.436] (II) NVIDIA(0): Detected PCI Express Link width: 16X
[ 67.436] (--) NVIDIA(GPU-0): DFP-0: disconnected
[ 67.436] (--) NVIDIA(GPU-0): DFP-0: Internal TMDS
[ 67.436] (--) NVIDIA(GPU-0): DFP-0: 330.0 MHz maximum pixel clock
[ 67.466] (--) NVIDIA(GPU-0): Toshiba Matsushita Display Technology Co., Ltd LCD-MONITOR (DFP-1): connected
[ 67.466] (--) NVIDIA(GPU-0): Toshiba Matsushita Display Technology Co., Ltd LCD-MONITOR (DFP-1): Internal TMDS
[ 67.466] (--) NVIDIA(GPU-0): Toshiba Matsushita Display Technology Co., Ltd LCD-MONITOR (DFP-1): 600.0 MHz maximum pixel clock
[ 67.466] (--) NVIDIA(GPU-0): Toshiba Matsushita Display Technology Co., Ltd LCD-MONITOR (DFP-2): connected
[ 67.466] (--) NVIDIA(GPU-0): Toshiba Matsushita Display Technology Co., Ltd LCD-MONITOR (DFP-2): Internal DisplayPort
[ 67.466] (--) NVIDIA(GPU-0): Toshiba Matsushita Display Technology Co., Ltd LCD-MONITOR (DFP-2): 1440.0 MHz maximum pixel clock
[ 67.467] (--) NVIDIA(GPU-0): DFP-3: disconnected
[ 67.467] (--) NVIDIA(GPU-0): DFP-3: Internal TMDS
[ 67.467] (--) NVIDIA(GPU-0): DFP-3: 165.0 MHz maximum pixel clock
[ 67.497] (--) NVIDIA(GPU-0): Toshiba Matsushita Display Technology Co., Ltd LCD-MONITOR (DFP-4): connected
[ 67.497] (--) NVIDIA(GPU-0): Toshiba Matsushita Display Technology Co., Ltd LCD-MONITOR (DFP-4): Internal TMDS
[ 67.497] (--) NVIDIA(GPU-0): Toshiba Matsushita Display Technology Co., Ltd LCD-MONITOR (DFP-4): 600.0 MHz maximum pixel clock
[ 67.527] (--) NVIDIA(GPU-0): Toshiba Matsushita Display Technology Co., Ltd LCD-MONITOR (DFP-5): connected
[ 67.527] (--) NVIDIA(GPU-0): Toshiba Matsushita Display Technology Co., Ltd LCD-MONITOR (DFP-5): Internal TMDS
[ 67.527] (--) NVIDIA(GPU-0): Toshiba Matsushita Display Technology Co., Ltd LCD-MONITOR (DFP-5): 600.0 MHz maximum pixel clock
[ 67.538] (==) NVIDIA(0):
[ 67.538] (==) NVIDIA(0): No modes were requested; the default mode "nvidia-auto-select"
[ 67.538] (==) NVIDIA(0): will be used as the requested mode.
[ 67.538] (II) NVIDIA(0): Validated MetaModes:
[ 67.538] (II) NVIDIA(0): "DFP-1:nvidia-auto-select,DFP-2:nvidia-auto-select,DFP-4:nvidia-auto-select,DFP-5:nvidia-auto-select"
[ 67.538] (II) NVIDIA(0): Virtual screen size determined to be 5760 x 900
[ 67.541] (--) NVIDIA(0): DPI set to (91, 91); computed from "UseEdidDpi" X config
[ 67.541] (--) NVIDIA(0): option
[ 67.542] (II) NVIDIA(1): Creating default Display subsection in Screen section
"screen1" for depth/fbbpp 24/32
[ 67.542] (==) NVIDIA(1): Depth 24, (==) framebuffer bpp 32
[ 67.542] (==) NVIDIA(1): RGB weight 888
[ 67.542] (==) NVIDIA(1): Default visual is TrueColor
[ 67.542] (==) NVIDIA(1): Using gamma correction (1.0, 1.0, 1.0)
[ 67.542] (**) NVIDIA(1): Enabling 2D acceleration
[ 68.884] (--) NVIDIA(0): Valid display device(s) on GPU-1 at PCI:2:0:0
[ 68.884] (--) NVIDIA(0): DFP-0
[ 68.884] (--) NVIDIA(0): DFP-1 (boot)
[ 68.884] (--) NVIDIA(0): DFP-2
[ 68.884] (--) NVIDIA(0): DFP-3
[ 68.884] (--) NVIDIA(0): DFP-4
[ 68.884] (--) NVIDIA(0): DFP-5
[ 68.887] (II) NVIDIA(1): NVIDIA GPU GeForce GTX 1050 Ti (GP107-A) at PCI:2:0:0 (GPU-1)
[ 68.887] (--) NVIDIA(1): Memory: 4194304 kBytes
[ 68.887] (--) NVIDIA(1): VideoBIOS: 86.07.39.00.54
[ 68.887] (II) NVIDIA(1): Detected PCI Express Link width: 16X
[ 68.887] (--) NVIDIA(GPU-1): DFP-0: disconnected
[ 68.887] (--) NVIDIA(GPU-1): DFP-0: Internal TMDS
[ 68.887] (--) NVIDIA(GPU-1): DFP-0: 330.0 MHz maximum pixel clock
[ 68.917] (--) NVIDIA(GPU-1): Toshiba Matsushita Display Technology Co., Ltd LCD-MONITOR (DFP-1): connected
[ 68.917] (--) NVIDIA(GPU-1): Toshiba Matsushita Display Technology Co., Ltd LCD-MONITOR (DFP-1): Internal TMDS
[ 68.917] (--) NVIDIA(GPU-1): Toshiba Matsushita Display Technology Co., Ltd LCD-MONITOR (DFP-1): 600.0 MHz maximum pixel clock
[ 68.918] (--) NVIDIA(GPU-1): Toshiba Matsushita Display Technology Co., Ltd LCD-MONITOR (DFP-2): connected
[ 68.918] (--) NVIDIA(GPU-1): Toshiba Matsushita Display Technology Co., Ltd LCD-MONITOR (DFP-2): Internal DisplayPort
[ 68.918] (--) NVIDIA(GPU-1): Toshiba Matsushita Display Technology Co., Ltd LCD-MONITOR (DFP-2): 1440.0 MHz maximum pixel clock
[ 68.919] (--) NVIDIA(GPU-1): DFP-3: disconnected
[ 68.919] (--) NVIDIA(GPU-1): DFP-3: Internal TMDS
[ 68.919] (--) NVIDIA(GPU-1): DFP-3: 165.0 MHz maximum pixel clock
[ 68.949] (--) NVIDIA(GPU-1): Toshiba Matsushita Display Technology Co., Ltd LCD-MONITOR (DFP-4): connected
[ 68.949] (--) NVIDIA(GPU-1): Toshiba Matsushita Display Technology Co., Ltd LCD-MONITOR (DFP-4): Internal TMDS
[ 68.949] (--) NVIDIA(GPU-1): Toshiba Matsushita Display Technology Co., Ltd LCD-MONITOR (DFP-4): 600.0 MHz maximum pixel clock
[ 68.979] (--) NVIDIA(GPU-1): Toshiba Matsushita Display Technology Co., Ltd LCD-MONITOR (DFP-5): connected
[ 68.979] (--) NVIDIA(GPU-1): Toshiba Matsushita Display Technology Co., Ltd LCD-MONITOR (DFP-5): Internal TMDS
[ 68.979] (--) NVIDIA(GPU-1): Toshiba Matsushita Display Technology Co., Ltd LCD-MONITOR (DFP-5): 600.0 MHz maximum pixel clock
[ 69.001] (==) NVIDIA(1):
[ 69.001] (==) NVIDIA(1): No modes were requested; the default mode "nvidia-auto-select"
[ 69.001] (==) NVIDIA(1): will be used as the requested mode.
[ 69.001] (II) NVIDIA(1): Validated MetaModes:
[ 69.001] (II) NVIDIA(1): "DFP-1:nvidia-auto-select,DFP-2:nvidia-auto-select,DFP-4:nvidia-auto-select,DFP-5:nvidia-auto-select"
[ 69.001] (II) NVIDIA(1): Virtual screen size determined to be 5760 x 900
[ 69.006] (--) NVIDIA(1): DPI set to (91, 91); computed from "UseEdidDpi" X config
[ 69.006] (--) NVIDIA(1): option
[ 69.006] (--) Depth 24 pixmap format is 32 bpp
[ 69.009] (II) NVIDIA: Using 24576.00 MB of virtual memory for indirect memory
[ 69.009] (II) NVIDIA: access.
[ 69.012] (II) NVIDIA(0): ACPI: failed to connect to the ACPI event daemon; the daemon
[ 69.012] (II) NVIDIA(0): may not be running or the "AcpidSocketPath" X
[ 69.012] (II) NVIDIA(0): configuration option may not be set correctly. When the
[ 69.012] (II) NVIDIA(0): ACPI event daemon is available, the NVIDIA X driver will
[ 69.012] (II) NVIDIA(0): try to use it to receive ACPI event notifications. For
[ 69.012] (II) NVIDIA(0): details, please see the "ConnectToAcpid" and
[ 69.012] (II) NVIDIA(0): "AcpidSocketPath" X configuration options in Appendix B: X
[ 69.012] (II) NVIDIA(0): Config Options in the README.
[ 69.029] (II) NVIDIA(0): Setting mode "DFP-1:nvidia-auto-select,DFP-2:nvidia-auto-select,DFP-4:nvidia-auto-select,DFP-5:nvidia-auto-select"
[ 75.067] (==) NVIDIA(0): Disabling shared memory pixmaps
[ 75.067] (==) NVIDIA(0): Backing store enabled
[ 75.067] (==) NVIDIA(0): Silken mouse enabled
[ 75.068] (==) NVIDIA(0): DPMS enabled
[ 75.068] (II) Loading sub module "dri2"
[ 75.068] (II) LoadModule: "dri2"
[ 75.068] (II) Module "dri2" already built-in
[ 75.068] (II) NVIDIA(0): [DRI2] Setup complete
[ 75.068] (II) NVIDIA(0): [DRI2] VDPAU driver: nvidia
[ 75.068] (--) RandR disabled
[ 75.073] (II) NVIDIA(1): ACPI: failed to connect to the ACPI event daemon; the daemon
[ 75.073] (II) NVIDIA(1): may not be running or the "AcpidSocketPath" X
[ 75.073] (II) NVIDIA(1): configuration option may not be set correctly. When the
[ 75.073] (II) NVIDIA(1): ACPI event daemon is available, the NVIDIA X driver will
[ 75.073] (II) NVIDIA(1): try to use it to receive ACPI event notifications. For
[ 75.073] (II) NVIDIA(1): details, please see the "ConnectToAcpid" and
[ 75.073] (II) NVIDIA(1): "AcpidSocketPath" X configuration options in Appendix B: X
[ 75.073] (II) NVIDIA(1): Config Options in the README.
[ 75.098] (II) NVIDIA(1): Setting mode "DFP-1:nvidia-auto-select,DFP-2:nvidia-auto-select,DFP-4:nvidia-auto-select,DFP-5:nvidia-auto-select"
[ 81.123] (==) NVIDIA(1): Disabling shared memory pixmaps
[ 81.123] (==) NVIDIA(1): Backing store enabled
[ 81.123] (==) NVIDIA(1): Silken mouse enabled
[ 81.124] (==) NVIDIA(1): DPMS enabled
[ 81.124] (II) Loading sub module "dri2"
[ 81.124] (II) LoadModule: "dri2"
[ 81.124] (II) Module "dri2" already built-in
[ 81.124] (II) NVIDIA(1): [DRI2] Setup complete
[ 81.124] (II) NVIDIA(1): [DRI2] VDPAU driver: nvidia
[ 81.124] (--) RandR disabled
[ 81.127] (II) Initializing extension GLX
[ 81.127] (II) Indirect GLX disabled.
[ 81.692] (II) config/udev: Adding input device Power Button (/dev/input/event2)
[ 81.692] (**) Power Button: Applying InputClass "evdev keyboard catchall"
[ 81.692] (**) Power Button: Applying InputClass "system-keyboard"
[ 81.692] (**) Power Button: Applying InputClass "libinput keyboard catchall"
[ 81.692] (**) Power Button: Applying InputClass "LocalKeyboard"
[ 81.692] (II) LoadModule: "libinput"
[ 81.710] (II) Loading /usr/lib64/xorg/modules/input/libinput_drv.so
[ 81.741] (II) Module libinput: vendor="X.Org Foundation"
[ 81.741] compiled for 1.18.3, module version = 0.25.1
[ 81.741] Module class: X.Org XInput Driver
[ 81.741] ABI class: X.Org XInput driver, version 22.1
[ 81.741] (II) Using input driver 'libinput' for 'Power Button'
[ 81.741] (**) Power Button: always reports core events
[ 81.741] (**) Option "Device" "/dev/input/event2"
[ 81.741] (**) Option "_source" "server/udev"
[ 81.742] (II) input device 'Power Button', /dev/input/event2 is tagged by udev as: Keyboard
[ 81.742] (II) input device 'Power Button', /dev/input/event2 is a keyboard
[ 81.752] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXPWRBN:00/input/input2/event2"
[ 81.752] (II) XINPUT: Adding extended input device "Power Button" (type: KEYBOARD, id 6)
[ 81.752] (**) Option "xkb_layout" "us"
[ 81.752] (II) input device 'Power Button', /dev/input/event2 is tagged by udev as: Keyboard
[ 81.752] (II) input device 'Power Button', /dev/input/event2 is a keyboard
[ 81.752] (II) config/udev: Adding input device Power Button (/dev/input/event1)
[ 81.752] (**) Power Button: Applying InputClass "evdev keyboard catchall"
[ 81.752] (**) Power Button: Applying InputClass "system-keyboard"
[ 81.752] (**) Power Button: Applying InputClass "libinput keyboard catchall"
[ 81.752] (**) Power Button: Applying InputClass "LocalKeyboard"
[ 81.752] (II) Using input driver 'libinput' for 'Power Button'
[ 81.752] (**) Power Button: always reports core events
[ 81.752] (**) Option "Device" "/dev/input/event1"
[ 81.752] (**) Option "_source" "server/udev"
[ 81.753] (II) input device 'Power Button', /dev/input/event1 is tagged by udev as: Keyboard
[ 81.753] (II) input device 'Power Button', /dev/input/event1 is a keyboard
[ 81.800] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0C:00/input/input1/event1"
[ 81.800] (II) XINPUT: Adding extended input device "Power Button" (type: KEYBOARD, id 7)
[ 81.800] (**) Option "xkb_layout" "us"
[ 81.800] (II) input device 'Power Button', /dev/input/event1 is tagged by udev as: Keyboard
[ 81.800] (II) input device 'Power Button', /dev/input/event1 is a keyboard
[ 81.800] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=3 (/dev/input/event14)
[ 81.800] (II) No input driver specified, ignoring this device.
[ 81.800] (II) This device may have been added with another device file.
[ 81.801] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=7 (/dev/input/event15)
[ 81.801] (II) No input driver specified, ignoring this device.
[ 81.801] (II) This device may have been added with another device file.
[ 81.801] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=8 (/dev/input/event16)
[ 81.801] (II) config/udev: Adding input device HDA Intel PCH Line Out Surround (/dev/input/event10)
[ 81.801] (II) config/udev: Adding input device HDA Intel PCH Line Out CLFE (/dev/input/event11)
[ 81.802] (II) config/udev: Adding input device HDA Intel PCH Line Out Side (/dev/input/event12)
[ 81.802] (II) No input driver specified, ignoring this device.
[ 81.802] (II) This device may have been added with another device file.
[ 81.802] (II) config/udev: Adding input device HDA Intel PCH Front Headphone (/dev/input/event13)
[ 81.802] (II) config/udev: Adding input device HDA Intel PCH Front Mic (/dev/input/event6)
[ 81.802] (II) config/udev: Adding input device HDA Intel PCH Rear Mic (/dev/input/event7)
[ 81.803] (II) config/udev: Adding input device HDA Intel PCH Line (/dev/input/event8)
[ 81.803] (II) No input driver specified, ignoring this device.
[ 81.803] (II) This device may have been added with another device file.
[ 81.803] (II) config/udev: Adding input device HDA Intel PCH Line Out Front (/dev/input/event9)
[ 81.803] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=3 (/dev/input/event17)
[ 81.803] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=7 (/dev/input/event18)
[ 81.804] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=8 (/dev/input/event19)
[ 81.804] (II) No input driver specified, ignoring this device.
[ 81.804] (II) This device may have been added with another device file.
[ 81.804] (II) config/udev: Adding input device Logitech Optical USB Mouse (/dev/input/event3)
[ 81.804] (**) Logitech Optical USB Mouse: Applying InputClass "evdev pointer catchall"
[ 81.804] (**) Logitech Optical USB Mouse: Applying InputClass "libinput pointer catchall"
[ 81.804] (II) Using input driver 'libinput' for 'Logitech Optical USB Mouse'
[ 81.804] (**) Logitech Optical USB Mouse: always reports core events
[ 81.804] (**) Option "Device" "/dev/input/event3"
[ 81.804] (**) Option "_source" "server/udev"
[ 81.860] (II) input device 'Logitech Optical USB Mouse', /dev/input/event3 is tagged by udev as: Mouse
[ 81.860] (II) Device 'Logitech Optical USB Mouse' set to 400 DPI
[ 81.860] (II) input device 'Logitech Optical USB Mouse', /dev/input/event3 is a pointer caps
[ 81.904] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:1c.7/0000:09:00.0/usb2/2-1/2-1:1.0/0003:046D:C016.0001/input/input3/event3"
[ 81.904] (II) XINPUT: Adding extended input device "Logitech Optical USB Mouse" (type: MOUSE, id 8)
[ 81.904] (**) Option "AccelerationScheme" "none"
[ 81.904] (**) Logitech Optical USB Mouse: (accel) selected scheme none/0
[ 81.904] (**) Logitech Optical USB Mouse: (accel) acceleration factor: 2.000
[ 81.904] (**) Logitech Optical USB Mouse: (accel) acceleration threshold: 4
[ 81.960] (II) input device 'Logitech Optical USB Mouse', /dev/input/event3 is tagged by udev as: Mouse
[ 81.960] (II) Device 'Logitech Optical USB Mouse' set to 400 DPI
[ 81.960] (II) input device 'Logitech Optical USB Mouse', /dev/input/event3 is a pointer caps
[ 81.960] (II) config/udev: Adding input device Logitech Optical USB Mouse (/dev/input/mouse0)
[ 81.960] (II) No input driver specified, ignoring this device.
[ 81.960] (II) This device may have been added with another device file.
[ 81.960] (II) config/udev: Adding input device Eee PC WMI hotkeys (/dev/input/event5)
[ 81.960] (**) Eee PC WMI hotkeys: Applying InputClass "evdev keyboard catchall"
[ 81.960] (**) Eee PC WMI hotkeys: Applying InputClass "system-keyboard"
[ 81.960] (**) Eee PC WMI hotkeys: Applying InputClass "libinput keyboard catchall"
[ 81.960] (**) Eee PC WMI hotkeys: Applying InputClass "LocalKeyboard"
[ 81.960] (II) Using input driver 'libinput' for 'Eee PC WMI hotkeys'
[ 81.960] (**) Eee PC WMI hotkeys: always reports core events
[ 81.960] (**) Option "Device" "/dev/input/event5"
[ 81.960] (**) Option "_source" "server/udev"
[ 81.961] (II) input device 'Eee PC WMI hotkeys', /dev/input/event5 is tagged by udev as: Keyboard
[ 81.961] (II) input device 'Eee PC WMI hotkeys', /dev/input/event5 is a keyboard
[ 81.976] (**) Option "config_info" "udev:/sys/devices/platform/eeepc-wmi/input/input5/event5"
[ 81.976] (II) XINPUT: Adding extended input device "Eee PC WMI hotkeys" (type: KEYBOARD, id 9)
[ 81.976] (**) Option "xkb_layout" "us"
[ 81.976] (II) input device 'Eee PC WMI hotkeys', /dev/input/event5 is tagged by udev as: Keyboard
[ 81.976] (II) input device 'Eee PC WMI hotkeys', /dev/input/event5 is a keyboard
[ 81.976] (II) config/udev: Adding input device AT Translated Set 2 keyboard (/dev/input/event0)
[ 81.976] (**) AT Translated Set 2 keyboard: Applying InputClass "evdev keyboard catchall"
[ 81.976] (**) AT Translated Set 2 keyboard: Applying InputClass "system-keyboard"
[ 81.976] (**) AT Translated Set 2 keyboard: Applying InputClass "libinput keyboard catchall"
[ 81.976] (**) AT Translated Set 2 keyboard: Applying InputClass "LocalKeyboard"
[ 81.976] (II) Using input driver 'libinput' for 'AT Translated Set 2 keyboard'
[ 81.976] (**) AT Translated Set 2 keyboard: always reports core events
[ 81.976] (**) Option "Device" "/dev/input/event0"
[ 81.976] (**) Option "_source" "server/udev"
[ 81.977] (II) input device 'AT Translated Set 2 keyboard', /dev/input/event0 is tagged by udev as: Keyboard
[ 81.977] (II) input device 'AT Translated Set 2 keyboard', /dev/input/event0 is a keyboard
[ 82.000] (**) Option "config_info" "udev:/sys/devices/platform/i8042/serio0/input/input0/event0"
[ 82.000] (II) XINPUT: Adding extended input device "AT Translated Set 2 keyboard" (type: KEYBOARD, id 10)
[ 82.000] (**) Option "xkb_layout" "us"
[ 82.000] (II) input device 'AT Translated Set 2 keyboard', /dev/input/event0 is tagged by udev as: Keyboard
[ 82.000] (II) input device 'AT Translated Set 2 keyboard', /dev/input/event0 is a keyboard
[ 82.000] (II) config/udev: Adding input device PC Speaker (/dev/input/event4)
[ 82.000] (II) No input driver specified, ignoring this device.
[ 82.000] (II) This device may have been added with another device file.
[ 82.005] (--) NVIDIA(GPU-0): Toshiba Matsushita Display Technology Co., Ltd LCD-MONITOR (DFP-2): connected
[ 82.005] (--) NVIDIA(GPU-0): Toshiba Matsushita Display Technology Co., Ltd LCD-MONITOR (DFP-2): Internal DisplayPort
[ 82.005] (--) NVIDIA(GPU-0): Toshiba Matsushita Display Technology Co., Ltd LCD-MONITOR (DFP-2): 1440.0 MHz maximum pixel clock
[ 82.035] (--) NVIDIA(GPU-0): Toshiba Matsushita Display Technology Co., Ltd LCD-MONITOR (DFP-5): connected
[ 82.035] (--) NVIDIA(GPU-0): Toshiba Matsushita Display Technology Co., Ltd LCD-MONITOR (DFP-5): Internal TMDS
[ 82.035] (--) NVIDIA(GPU-0): Toshiba Matsushita Display Technology Co., Ltd LCD-MONITOR (DFP-5): 600.0 MHz maximum pixel clock
[ 82.064] (--) NVIDIA(GPU-0): Toshiba Matsushita Display Technology Co., Ltd LCD-MONITOR (DFP-4): connected
[ 82.064] (--) NVIDIA(GPU-0): Toshiba Matsushita Display Technology Co., Ltd LCD-MONITOR (DFP-4): Internal TMDS
[ 82.065] (--) NVIDIA(GPU-0): Toshiba Matsushita Display Technology Co., Ltd LCD-MONITOR (DFP-4): 600.0 MHz maximum pixel clock
[ 82.094] (--) NVIDIA(GPU-0): Toshiba Matsushita Display Technology Co., Ltd LCD-MONITOR (DFP-1): connected
[ 82.094] (--) NVIDIA(GPU-0): Toshiba Matsushita Display Technology Co., Ltd LCD-MONITOR (DFP-1): Internal TMDS
[ 82.095] (--) NVIDIA(GPU-0): Toshiba Matsushita Display Technology Co., Ltd LCD-MONITOR (DFP-1): 600.0 MHz maximum pixel clock
[ 82.124] (--) NVIDIA(GPU-0): Toshiba Matsushita Display Technology Co., Ltd LCD-MONITOR (DFP-5): connected
[ 82.124] (--) NVIDIA(GPU-0): Toshiba Matsushita Display Technology Co., Ltd LCD-MONITOR (DFP-5): Internal TMDS
[ 82.124] (--) NVIDIA(GPU-0): Toshiba Matsushita Display Technology Co., Ltd LCD-MONITOR (DFP-5): 600.0 MHz maximum pixel clock
[ 82.154] (--) NVIDIA(GPU-0): Toshiba Matsushita Display Technology Co., Ltd LCD-MONITOR (DFP-4): connected
[ 82.154] (--) NVIDIA(GPU-0): Toshiba Matsushita Display Technology Co., Ltd LCD-MONITOR (DFP-4): Internal TMDS
[ 82.154] (--) NVIDIA(GPU-0): Toshiba Matsushita Display Technology Co., Ltd LCD-MONITOR (DFP-4): 600.0 MHz maximum pixel clock
[ 82.184] (--) NVIDIA(GPU-0): Toshiba Matsushita Display Technology Co., Ltd LCD-MONITOR (DFP-1): connected
[ 82.184] (--) NVIDIA(GPU-0): Toshiba Matsushita Display Technology Co., Ltd LCD-MONITOR (DFP-1): Internal TMDS
[ 82.184] (--) NVIDIA(GPU-0): Toshiba Matsushita Display Technology Co., Ltd LCD-MONITOR (DFP-1): 600.0 MHz maximum pixel clock
[ 82.185] (--) NVIDIA(GPU-1): Toshiba Matsushita Display Technology Co., Ltd LCD-MONITOR (DFP-2): connected
[ 82.185] (--) NVIDIA(GPU-1): Toshiba Matsushita Display Technology Co., Ltd LCD-MONITOR (DFP-2): Internal DisplayPort
[ 82.185] (--) NVIDIA(GPU-1): Toshiba Matsushita Display Technology Co., Ltd LCD-MONITOR (DFP-2): 1440.0 MHz maximum pixel clock
[ 82.215] (--) NVIDIA(GPU-1): Toshiba Matsushita Display Technology Co., Ltd LCD-MONITOR (DFP-5): connected
[ 82.215] (--) NVIDIA(GPU-1): Toshiba Matsushita Display Technology Co., Ltd LCD-MONITOR (DFP-5): Internal TMDS
[ 82.215] (--) NVIDIA(GPU-1): Toshiba Matsushita Display Technology Co., Ltd LCD-MONITOR (DFP-5): 600.0 MHz maximum pixel clock
[ 82.245] (--) NVIDIA(GPU-1): Toshiba Matsushita Display Technology Co., Ltd LCD-MONITOR (DFP-4): connected
[ 82.245] (--) NVIDIA(GPU-1): Toshiba Matsushita Display Technology Co., Ltd LCD-MONITOR (DFP-4): Internal TMDS
[ 82.245] (--) NVIDIA(GPU-1): Toshiba Matsushita Display Technology Co., Ltd LCD-MONITOR (DFP-4): 600.0 MHz maximum pixel clock
[ 82.276] (--) NVIDIA(GPU-1): Toshiba Matsushita Display Technology Co., Ltd LCD-MONITOR (DFP-1): connected
[ 82.276] (--) NVIDIA(GPU-1): Toshiba Matsushita Display Technology Co., Ltd LCD-MONITOR (DFP-1): Internal TMDS
[ 82.276] (--) NVIDIA(GPU-1): Toshiba Matsushita Display Technology Co., Ltd LCD-MONITOR (DFP-1): 600.0 MHz maximum pixel clock
[ 82.307] (--) NVIDIA(GPU-1): Toshiba Matsushita Display Technology Co., Ltd LCD-MONITOR (DFP-5): connected
[ 82.307] (--) NVIDIA(GPU-1): Toshiba Matsushita Display Technology Co., Ltd LCD-MONITOR (DFP-5): Internal TMDS
[ 82.307] (--) NVIDIA(GPU-1): Toshiba Matsushita Display Technology Co., Ltd LCD-MONITOR (DFP-5): 600.0 MHz maximum pixel clock
[ 82.337] (--) NVIDIA(GPU-1): Toshiba Matsushita Display Technology Co., Ltd LCD-MONITOR (DFP-4): connected
[ 82.337] (--) NVIDIA(GPU-1): Toshiba Matsushita Display Technology Co., Ltd LCD-MONITOR (DFP-4): Internal TMDS
[ 82.337] (--) NVIDIA(GPU-1): Toshiba Matsushita Display Technology Co., Ltd LCD-MONITOR (DFP-4): 600.0 MHz maximum pixel clock
[ 82.367] (--) NVIDIA(GPU-1): Toshiba Matsushita Display Technology Co., Ltd LCD-MONITOR (DFP-1): connected
[ 82.367] (--) NVIDIA(GPU-1): Toshiba Matsushita Display Technology Co., Ltd LCD-MONITOR (DFP-1): Internal TMDS
[ 82.367] (--) NVIDIA(GPU-1): Toshiba Matsushita Display Technology Co., Ltd LCD-MONITOR (DFP-1): 600.0 MHz maximum pixel clock
[ 82.983] (--) NVIDIA(GPU-0): DFP-0: disconnected
[ 82.983] (--) NVIDIA(GPU-0): DFP-0: Internal TMDS
[ 82.983] (--) NVIDIA(GPU-0): DFP-0: 330.0 MHz maximum pixel clock
[ 83.013] (--) NVIDIA(GPU-0): Toshiba Matsushita Display Technology Co., Ltd LCD-MONITOR (DFP-1): connected
[ 83.013] (--) NVIDIA(GPU-0): Toshiba Matsushita Display Technology Co., Ltd LCD-MONITOR (DFP-1): Internal TMDS
[ 83.013] (--) NVIDIA(GPU-0): Toshiba Matsushita Display Technology Co., Ltd LCD-MONITOR (DFP-1): 600.0 MHz maximum pixel clock
[ 83.013] (--) NVIDIA(GPU-0): Toshiba Matsushita Display Technology Co., Ltd LCD-MONITOR (DFP-2): connected
[ 83.013] (--) NVIDIA(GPU-0): Toshiba Matsushita Display Technology Co., Ltd LCD-MONITOR (DFP-2): Internal DisplayPort
[ 83.013] (--) NVIDIA(GPU-0): Toshiba Matsushita Display Technology Co., Ltd LCD-MONITOR (DFP-2): 1440.0 MHz maximum pixel clock
[ 83.014] (--) NVIDIA(GPU-0): DFP-3: disconnected
[ 83.014] (--) NVIDIA(GPU-0): DFP-3: Internal TMDS
[ 83.014] (--) NVIDIA(GPU-0): DFP-3: 165.0 MHz maximum pixel clock
[ 83.044] (--) NVIDIA(GPU-0): Toshiba Matsushita Display Technology Co., Ltd LCD-MONITOR (DFP-4): connected
[ 83.044] (--) NVIDIA(GPU-0): Toshiba Matsushita Display Technology Co., Ltd LCD-MONITOR (DFP-4): Internal TMDS
[ 83.044] (--) NVIDIA(GPU-0): Toshiba Matsushita Display Technology Co., Ltd LCD-MONITOR (DFP-4): 600.0 MHz maximum pixel clock
[ 83.073] (--) NVIDIA(GPU-0): Toshiba Matsushita Display Technology Co., Ltd LCD-MONITOR (DFP-5): connected
[ 83.073] (--) NVIDIA(GPU-0): Toshiba Matsushita Display Technology Co., Ltd LCD-MONITOR (DFP-5): Internal TMDS
[ 83.073] (--) NVIDIA(GPU-0): Toshiba Matsushita Display Technology Co., Ltd LCD-MONITOR (DFP-5): 600.0 MHz maximum pixel clock
