Hi guys !
I am Having the exact same symptoms in the Black X Cursor pic… https://www.nvidia.com/en-us/geforce/forums/game-ready-drivers/13/284683/dual-monitor-setup-not-working-in-centos-7-running/
Except that I’m trying to run two separate Xservers under FedoraWS35 with a single GTX460 driver NVIDIA-Linux-x86_64-390.144
xrandr shows DVI-I-0 is connected but does not show DVI-I-1, instead it shows DVI-I-2 DVI-I-3 disconnected
This same X config with the same HW is working fine under an EOL/obsolete Debian.
I am running out of options please, help !
[ 21818.696] (--) Log file renamed from "/var/log/Xorg.pid-61587.log" to "/var/log/Xorg.0.log"
[ 21818.696]
X.Org X Server 1.20.11
X Protocol Version 11, Revision 0
[ 21818.696] Build Operating System: 5.12.13-300.fc34.x86_64
[ 21818.696] Current Operating System: Linux ws 5.14.17-301.fc35.x86_64 #1 SMP Mon Nov 8 13:57:43 UTC 2021 x86_64
[ 21818.696] Kernel command line: BOOT_IMAGE=(hd0,msdos1)/vmlinuz-5.14.17-301.fc35.x86_64 root=UUID=d7fd511e-236e-4777-a5bc-b33c72033ac1 ro rootflags=subvol=root nomodeset rhgb quiet
[ 21818.696] Build Date: 23 July 2021 12:00:00AM
[ 21818.696] Build ID: xorg-x11-server 1.20.11-2.fc35
[ 21818.696] Current version of pixman: 0.40.0
[ 21818.696] Before reporting problems, check http://wiki.x.org
to make sure that you have the latest version.
[ 21818.696] Markers: (--) probed, (**) from config file, (==) default setting,
(++) from command line, (!!) notice, (II) informational,
(WW) warning, (EE) error, (NI) not implemented, (??) unknown.
[ 21818.697] (==) Log file: "/var/log/Xorg.0.log", Time: Tue Nov 16 11:08:56 2021
[ 21818.697] (==) Using config file: "/etc/X11/xorg.conf"
[ 21818.697] (==) Using config directory: "/etc/X11/xorg.conf.d"
[ 21818.697] (==) Using system config directory "/usr/share/X11/xorg.conf.d"
[ 21818.697] (==) ServerLayout "X.org Configured"
[ 21818.697] (**) |-->Screen "Screen0" (0)
[ 21818.697] (**) | |-->Monitor "Monitor0"
[ 21818.698] (**) | |-->Device "nvidia0"
[ 21818.698] (**) |-->Screen "Screen1" (1)
[ 21818.698] (**) | |-->Monitor "Monitor1"
[ 21818.698] (**) | |-->Device "nvidia1"
[ 21818.698] (**) |-->Input Device "Mouse0"
[ 21818.698] (**) |-->Input Device "Keyboard0"
[ 21818.698] (**) Option "Xinerama" "0"
[ 21818.698] (==) Automatically adding devices
[ 21818.698] (==) Automatically enabling devices
[ 21818.698] (==) Automatically adding GPU devices
[ 21818.698] (==) Automatically binding GPU devices
[ 21818.698] (==) Max clients allowed: 256, resource mask: 0x1fffff
[ 21818.698] (==) FontPath set to:
catalogue:/etc/X11/fontpath.d,
built-ins
[ 21818.698] (==) ModulePath set to "/usr/lib64/xorg/modules"
[ 21818.698] (WW) Hotplugging is on, devices using drivers 'kbd', 'mouse' or 'vmmouse' will be disabled.
[ 21818.698] (WW) Disabling Mouse0
[ 21818.698] (WW) Disabling Keyboard0
[ 21818.698] (II) Loader magic: 0x563e8458ea40
[ 21818.698] (II) Module ABI versions:
[ 21818.698] X.Org ANSI C Emulation: 0.4
[ 21818.698] X.Org Video Driver: 24.1
[ 21818.698] X.Org XInput driver : 24.1
[ 21818.698] X.Org Server Extension : 10.0
[ 21818.698] (++) using VT number 1
[ 21818.700] (II) systemd-logind: took control of session /org/freedesktop/login1/session/c18
[ 21818.700] (II) xfree86: Adding drm device (/dev/dri/card0)
[ 21818.701] (II) systemd-logind: got fd for /dev/dri/card0 226:0 fd 14 paused 0
[ 21818.708] (--) PCI:*(3@0:0:0) 10de:0e22:196e:0804 rev 161, Mem @ 0xd0000000/33554432, 0xe8000000/134217728, 0xf0000000/67108864, I/O @ 0x00003000/128, BIOS @ 0x????????/524288
[ 21818.708] (II) LoadModule: "glx"
[ 21818.708] (II) Loading /usr/lib64/xorg/modules/extensions/libglx.so
[ 21818.713] (II) Module glx: vendor="NVIDIA Corporation"
[ 21818.713] compiled for 4.0.2, module version = 1.0.0
[ 21818.713] Module class: X.Org Server Extension
[ 21818.713] (II) NVIDIA GLX Module 390.144 Wed Jun 2 23:02:00 UTC 2021
[ 21818.713] (II) LoadModule: "nvidia"
[ 21818.713] (II) Loading /usr/lib64/xorg/modules/drivers/nvidia_drv.so
[ 21818.713] (II) Module nvidia: vendor="NVIDIA Corporation"
[ 21818.713] Module class: X.Org Video Driver
[ 21818.713] (II) NVIDIA dlloader X Driver 390.144 Wed Jun 2 23:05:01 UTC 2021
[ 21818.713] (II) NVIDIA Unified Driver for all Supported NVIDIA GPUs
[ 21818.714] (II) systemd-logind: releasing fd for 226:0
[ 21818.714] (II) Loading sub module "fb"
[ 21818.714] (II) LoadModule: "fb"
[ 21818.714] (II) Loading /usr/lib64/xorg/modules/libfb.so
[ 21818.715] (II) Module fb: vendor="X.Org Foundation"
[ 21818.715] compiled for 1.20.11, module version = 1.0.0
[ 21818.715] ABI class: X.Org ANSI C Emulation, version 0.4
[ 21818.715] (II) Loading sub module "wfb"
[ 21818.715] (II) LoadModule: "wfb"
[ 21818.715] (II) Loading /usr/lib64/xorg/modules/libwfb.so
[ 21818.715] (II) Module wfb: vendor="X.Org Foundation"
[ 21818.715] (II) Loading sub module "ramdac"
[ 21818.715] (II) LoadModule: "ramdac"
[ 21818.715] (II) Module "ramdac" already built-in
[ 21818.716] (**) NVIDIA(0): Depth 24, (--) framebuffer bpp 32
[ 21818.716] (==) NVIDIA(0): RGB weight 888
[ 21818.716] (==) NVIDIA(0): Default visual is TrueColor
[ 21818.716] (==) NVIDIA(0): Using gamma correction (1.0, 1.0, 1.0)
[ 21818.716] (**) NVIDIA(0): Option "Stereo" "0"
[ 21818.716] (**) NVIDIA(0): Option "nvidiaXineramaInfoOrder" "CRT-0"
[ 21818.716] (**) NVIDIA(0): Option "SLI" "Off"
[ 21818.716] (**) NVIDIA(0): Option "MultiGPU" "Off"
[ 21818.716] (**) NVIDIA(0): Option "BaseMosaic" "Off"
[ 21818.716] (**) NVIDIA(0): Stereo disabled by request
[ 21818.716] (**) NVIDIA(0): NVIDIA SLI disabled.
[ 21818.716] (**) NVIDIA(0): NVIDIA Multi-GPU disabled.
[ 21818.716] (**) NVIDIA(0): Option "ConnectedMonitor" "CRT-0, CRT-1"
[ 21818.716] (**) NVIDIA(0): Option "UseDisplayDevice" "DVI-I-0"
[ 21818.716] (**) NVIDIA(1): Option "UseDisplayDevice" "DVI-I-1"
[ 21818.716] (**) NVIDIA(0): Enabling 2D acceleration
[ 21818.716] (**) NVIDIA(0): ConnectedMonitor string: "CRT-0, CRT-1"
[ 21819.051] (--) NVIDIA(0): Valid display device(s) on GPU-0 at PCI:3:0:0
[ 21819.051] (--) NVIDIA(0): CRT-0 (boot)
[ 21819.051] (--) NVIDIA(0): CRT-1
[ 21819.051] (--) NVIDIA(0): DFP-0
[ 21819.051] (--) NVIDIA(0): DFP-1
[ 21819.051] (--) NVIDIA(0): DFP-2
[ 21819.051] (**) NVIDIA(0): Using ConnectedMonitor string "CRT-0, CRT-1".
[ 21819.053] (II) NVIDIA(0): NVIDIA GPU GeForce GTX 460 (GF104) at PCI:3:0:0 (GPU-0)
[ 21819.053] (--) NVIDIA(0): Memory: 1048576 kBytes
[ 21819.053] (--) NVIDIA(0): VideoBIOS: 70.04.13.00.52
[ 21819.053] (II) NVIDIA(0): Detected PCI Express Link width: 16X
[ 21819.056] (--) NVIDIA(GPU-0): CRT-0: connected
[ 21819.056] (--) NVIDIA(GPU-0): CRT-0: 400.0 MHz maximum pixel clock
[ 21819.073] (--) NVIDIA(GPU-0): LG Electronics 700E (CRT-1): connected
[ 21819.073] (--) NVIDIA(GPU-0): LG Electronics 700E (CRT-1): 400.0 MHz maximum pixel clock
[ 21819.073] (--) NVIDIA(GPU-0): DFP-0: disconnected
[ 21819.073] (--) NVIDIA(GPU-0): DFP-0: Internal TMDS
[ 21819.073] (--) NVIDIA(GPU-0): DFP-0: 330.0 MHz maximum pixel clock
[ 21819.073] (--) NVIDIA(GPU-0): DFP-1: disconnected
[ 21819.073] (--) NVIDIA(GPU-0): DFP-1: Internal TMDS
[ 21819.073] (--) NVIDIA(GPU-0): DFP-1: 165.0 MHz maximum pixel clock
[ 21819.073] (--) NVIDIA(GPU-0): DFP-2: disconnected
[ 21819.073] (--) NVIDIA(GPU-0): DFP-2: Internal TMDS
[ 21819.073] (--) NVIDIA(GPU-0): DFP-2: 330.0 MHz maximum pixel clock
[ 21819.091] (II) NVIDIA(0): Validated MetaModes:
[ 21819.091] (II) NVIDIA(0): "CRT-0:1280x1024"
[ 21819.091] (II) NVIDIA(0): Virtual screen size determined to be 1280 x 1024
[ 21819.113] (WW) NVIDIA(0): CRT-0 does not have an EDID, or its EDID does not contain a
[ 21819.113] (WW) NVIDIA(0): maximum image size; cannot compute DPI from CRT-0's EDID.
[ 21819.113] (==) NVIDIA(0): DPI set to (75, 75); computed from built-in default
[ 21819.113] (**) NVIDIA(1): Depth 24, (--) framebuffer bpp 32
[ 21819.113] (==) NVIDIA(1): RGB weight 888
[ 21819.113] (==) NVIDIA(1): Default visual is TrueColor
[ 21819.113] (==) NVIDIA(1): Using gamma correction (1.0, 1.0, 1.0)
[ 21819.113] (**) NVIDIA(1): Option "Stereo" "0"
[ 21819.113] (**) NVIDIA(1): Option "SLI" "Off"
[ 21819.113] (**) NVIDIA(1): Option "MultiGPU" "Off"
[ 21819.113] (**) NVIDIA(1): Option "BaseMosaic" "Off"
[ 21819.113] (**) NVIDIA(1): Stereo disabled by request
[ 21819.113] (**) NVIDIA(1): NVIDIA SLI disabled.
[ 21819.113] (**) NVIDIA(1): NVIDIA Multi-GPU disabled.
[ 21819.113] (II) NVIDIA(1): NVIDIA GPU GeForce GTX 460 (GF104) at PCI:3:0:0 (GPU-0)
[ 21819.113] (--) NVIDIA(1): Memory: 1048576 kBytes
[ 21819.113] (--) NVIDIA(1): VideoBIOS: 70.04.13.00.52
[ 21819.113] (II) NVIDIA(1): Detected PCI Express Link width: 16X
[ 21819.117] (II) NVIDIA(1): Validated MetaModes:
[ 21819.117] (II) NVIDIA(1): "CRT-1:1024x768"
[ 21819.117] (II) NVIDIA(1): Virtual screen size determined to be 1024 x 768
[ 21819.121] (--) NVIDIA(1): DPI set to (78, 78); computed from "UseEdidDpi" X config
[ 21819.121] (--) NVIDIA(1): option
[ 21819.122] (II) NVIDIA: Using 6144.00 MB of virtual memory for indirect memory
[ 21819.122] (II) NVIDIA: access.
[ 21819.124] (II) NVIDIA(0): ACPI: failed to connect to the ACPI event daemon; the daemon
[ 21819.124] (II) NVIDIA(0): may not be running or the "AcpidSocketPath" X
[ 21819.124] (II) NVIDIA(0): configuration option may not be set correctly. When the
[ 21819.124] (II) NVIDIA(0): ACPI event daemon is available, the NVIDIA X driver will
[ 21819.124] (II) NVIDIA(0): try to use it to receive ACPI event notifications. For
[ 21819.124] (II) NVIDIA(0): details, please see the "ConnectToAcpid" and
[ 21819.124] (II) NVIDIA(0): "AcpidSocketPath" X configuration options in Appendix B: X
[ 21819.124] (II) NVIDIA(0): Config Options in the README.
[ 21819.159] (II) NVIDIA(0): Setting mode "CRT-0:1280x1024"
[ 21819.193] (==) NVIDIA(0): Disabling shared memory pixmaps
[ 21819.193] (==) NVIDIA(0): Backing store enabled
[ 21819.193] (==) NVIDIA(0): Silken mouse enabled
[ 21819.193] (==) NVIDIA(0): DPMS enabled
[ 21819.193] (WW) NVIDIA(0): Option "Enable" is not used
[ 21819.193] (II) Loading sub module "dri2"
[ 21819.193] (II) LoadModule: "dri2"
[ 21819.193] (II) Module "dri2" already built-in
[ 21819.193] (II) NVIDIA(0): [DRI2] Setup complete
[ 21819.193] (II) NVIDIA(0): [DRI2] VDPAU driver: nvidia
[ 21819.196] (II) NVIDIA(1): ACPI: failed to connect to the ACPI event daemon; the daemon
[ 21819.196] (II) NVIDIA(1): may not be running or the "AcpidSocketPath" X
[ 21819.196] (II) NVIDIA(1): configuration option may not be set correctly. When the
[ 21819.196] (II) NVIDIA(1): ACPI event daemon is available, the NVIDIA X driver will
[ 21819.196] (II) NVIDIA(1): try to use it to receive ACPI event notifications. For
[ 21819.196] (II) NVIDIA(1): details, please see the "ConnectToAcpid" and
[ 21819.196] (II) NVIDIA(1): "AcpidSocketPath" X configuration options in Appendix B: X
[ 21819.196] (II) NVIDIA(1): Config Options in the README.
[ 21819.250] (II) NVIDIA(1): Setting mode "CRT-1:1024x768"
[ 21819.286] (==) NVIDIA(1): Disabling shared memory pixmaps
[ 21819.286] (==) NVIDIA(1): Backing store enabled
[ 21819.286] (==) NVIDIA(1): Silken mouse enabled
[ 21819.286] (==) NVIDIA(1): DPMS enabled
[ 21819.286] (WW) NVIDIA(1): Option "Enable" is not used
[ 21819.286] (II) Loading sub module "dri2"
[ 21819.286] (II) LoadModule: "dri2"
[ 21819.286] (II) Module "dri2" already built-in
[ 21819.286] (II) NVIDIA(1): [DRI2] Setup complete
[ 21819.286] (II) NVIDIA(1): [DRI2] VDPAU driver: nvidia
[ 21819.286] (II) Initializing extension Generic Event Extension
[ 21819.286] (II) Initializing extension SHAPE
[ 21819.287] (II) Initializing extension MIT-SHM
[ 21819.287] (II) Initializing extension XInputExtension
[ 21819.287] (II) Initializing extension XTEST
[ 21819.287] (II) Initializing extension BIG-REQUESTS
[ 21819.287] (II) Initializing extension SYNC
[ 21819.287] (II) Initializing extension XKEYBOARD
[ 21819.287] (II) Initializing extension XC-MISC
[ 21819.287] (II) Initializing extension SECURITY
[ 21819.288] (II) Initializing extension XFIXES
[ 21819.288] (II) Initializing extension RENDER
[ 21819.288] (II) Initializing extension RANDR
[ 21819.288] (II) Initializing extension COMPOSITE
[ 21819.288] (II) Initializing extension DAMAGE
[ 21819.288] (II) Initializing extension MIT-SCREEN-SAVER
[ 21819.288] (II) Initializing extension DOUBLE-BUFFER
[ 21819.288] (II) Initializing extension RECORD
[ 21819.288] (II) Initializing extension DPMS
[ 21819.288] (II) Initializing extension Present
[ 21819.289] (II) Initializing extension DRI3
[ 21819.289] (II) Initializing extension X-Resource
[ 21819.289] (II) Initializing extension XVideo
[ 21819.289] (II) Initializing extension XVideo-MotionCompensation
[ 21819.289] (II) Initializing extension SELinux
[ 21819.289] (II) SELinux: Disabled by boolean
[ 21819.289] (II) Initializing extension XFree86-VidModeExtension
[ 21819.289] (II) Initializing extension XFree86-DGA
[ 21819.289] (II) Initializing extension DRI2
[ 21819.289] (II) Initializing extension GLX
[ 21819.289] (II) Indirect GLX disabled.
[ 21819.290] (II) Initializing extension NV-GLX
[ 21819.290] (II) Initializing extension NV-CONTROL
[ 21819.332] (II) config/udev: Adding input device Power Button (/dev/input/event1)
[ 21819.332] (**) Power Button: Applying InputClass "evdev keyboard catchall"
[ 21819.332] (**) Power Button: Applying InputClass "libinput keyboard catchall"
[ 21819.332] (**) Power Button: Applying InputClass "system-keyboard"
[ 21819.332] (II) LoadModule: "evdev"
[ 21819.333] (II) Loading /usr/lib64/xorg/modules/input/evdev_drv.so
[ 21819.333] (II) Module evdev: vendor="X.Org Foundation"
[ 21819.333] compiled for 1.20.11, module version = 2.10.6
[ 21819.333] Module class: X.Org XInput Driver
[ 21819.333] ABI class: X.Org XInput driver, version 24.1
[ 21819.333] (II) Using input driver 'evdev' for 'Power Button'
[ 21819.334] (II) systemd-logind: got fd for /dev/input/event1 13:65 fd 42 paused 0
[ 21819.334] (**) Power Button: always reports core events
[ 21819.334] (**) evdev: Power Button: Device: "/dev/input/event1"
[ 21819.334] (--) evdev: Power Button: Vendor 0 Product 0x1
[ 21819.334] (--) evdev: Power Button: Found keys
[ 21819.334] (II) evdev: Power Button: Configuring as keyboard
[ 21819.334] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXPWRBN:00/input/input1/event1"
[ 21819.334] (II) XINPUT: Adding extended input device "Power Button" (type: KEYBOARD, id 6)
[ 21819.334] (**) Option "xkb_rules" "evdev"
[ 21819.334] (**) Option "xkb_layout" "fr,us"
[ 21819.334] (**) Option "xkb_variant" ","
[ 21819.365] (II) config/udev: Adding input device Sleep Button (/dev/input/event0)
[ 21819.365] (**) Sleep Button: Applying InputClass "evdev keyboard catchall"
[ 21819.365] (**) Sleep Button: Applying InputClass "libinput keyboard catchall"
[ 21819.365] (**) Sleep Button: Applying InputClass "system-keyboard"
[ 21819.365] (II) Using input driver 'evdev' for 'Sleep Button'
[ 21819.366] (II) systemd-logind: got fd for /dev/input/event0 13:64 fd 43 paused 0
[ 21819.366] (**) Sleep Button: always reports core events
[ 21819.366] (**) evdev: Sleep Button: Device: "/dev/input/event0"
[ 21819.366] (--) evdev: Sleep Button: Vendor 0 Product 0x3
[ 21819.366] (--) evdev: Sleep Button: Found keys
[ 21819.366] (II) evdev: Sleep Button: Configuring as keyboard
[ 21819.366] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0E:00/input/input0/event0"
[ 21819.366] (II) XINPUT: Adding extended input device "Sleep Button" (type: KEYBOARD, id 7)
[ 21819.366] (**) Option "xkb_rules" "evdev"
[ 21819.366] (**) Option "xkb_layout" "fr,us"
[ 21819.366] (**) Option "xkb_variant" ","
[ 21819.367] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=9 (/dev/input/event10)
[ 21819.367] (II) No input driver specified, ignoring this device.
[ 21819.367] (II) This device may have been added with another device file.
[ 21819.368] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=3 (/dev/input/event7)
[ 21819.368] (II) No input driver specified, ignoring this device.
[ 21819.368] (II) This device may have been added with another device file.
[ 21819.368] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=7 (/dev/input/event8)
[ 21819.369] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=8 (/dev/input/event9)
[ 21819.369] (II) No input driver specified, ignoring this device.
[ 21819.369] (II) This device may have been added with another device file.
[ 21819.369] (II) config/udev: Adding input device PIXART USB OPTICAL MOUSE (/dev/input/event2)
[ 21819.369] (**) PIXART USB OPTICAL MOUSE: Applying InputClass "evdev pointer catchall"
[ 21819.369] (**) PIXART USB OPTICAL MOUSE: Applying InputClass "libinput pointer catchall"
[ 21819.369] (II) Using input driver 'evdev' for 'PIXART USB OPTICAL MOUSE'
[ 21819.370] (II) systemd-logind: got fd for /dev/input/event2 13:66 fd 44 paused 0
[ 21819.370] (**) PIXART USB OPTICAL MOUSE: always reports core events
[ 21819.370] (**) evdev: PIXART USB OPTICAL MOUSE: Device: "/dev/input/event2"
[ 21819.370] (--) evdev: PIXART USB OPTICAL MOUSE: Vendor 0x93a Product 0x2510
[ 21819.370] (--) evdev: PIXART USB OPTICAL MOUSE: Found 3 mouse buttons
[ 21819.370] (--) evdev: PIXART USB OPTICAL MOUSE: Found scroll wheel(s)
[ 21819.370] (--) evdev: PIXART USB OPTICAL MOUSE: Found relative axes
[ 21819.370] (--) evdev: PIXART USB OPTICAL MOUSE: Found x and y relative axes
[ 21819.370] (II) evdev: PIXART USB OPTICAL MOUSE: Configuring as mouse
[ 21819.370] (II) evdev: PIXART USB OPTICAL MOUSE: Adding scrollwheel support
[ 21819.370] (**) evdev: PIXART USB OPTICAL MOUSE: YAxisMapping: buttons 4 and 5
[ 21819.370] (**) evdev: PIXART USB OPTICAL MOUSE: EmulateWheelButton: 4, EmulateWheelInertia: 10, EmulateWheelTimeout: 200
[ 21819.370] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:1a.1/usb4/4-1/4-1:1.0/0003:093A:2510.0001/input/input2/event2"
[ 21819.370] (II) XINPUT: Adding extended input device "PIXART USB OPTICAL MOUSE" (type: MOUSE, id 8)
[ 21819.370] (II) evdev: PIXART USB OPTICAL MOUSE: initialized for relative axes.
[ 21819.371] (**) PIXART USB OPTICAL MOUSE: (accel) keeping acceleration scheme 1
[ 21819.371] (**) PIXART USB OPTICAL MOUSE: (accel) acceleration profile 0
[ 21819.371] (**) PIXART USB OPTICAL MOUSE: (accel) acceleration factor: 2.000
[ 21819.371] (**) PIXART USB OPTICAL MOUSE: (accel) acceleration threshold: 4
[ 21819.371] (II) config/udev: Adding input device PIXART USB OPTICAL MOUSE (/dev/input/mouse0)
[ 21819.371] (II) No input driver specified, ignoring this device.
[ 21819.371] (II) This device may have been added with another device file.
[ 21819.372] (II) config/udev: Adding input device USB USB Keykoard (/dev/input/event3)
[ 21819.372] (**) USB USB Keykoard: Applying InputClass "evdev keyboard catchall"
[ 21819.372] (**) USB USB Keykoard: Applying InputClass "libinput keyboard catchall"
[ 21819.372] (**) USB USB Keykoard: Applying InputClass "system-keyboard"
[ 21819.372] (II) Using input driver 'evdev' for 'USB USB Keykoard'
[ 21819.373] (II) systemd-logind: got fd for /dev/input/event3 13:67 fd 45 paused 0
[ 21819.373] (**) USB USB Keykoard: always reports core events
[ 21819.373] (**) evdev: USB USB Keykoard: Device: "/dev/input/event3"
[ 21819.373] (--) evdev: USB USB Keykoard: Vendor 0x1c4f Product 0x2
[ 21819.373] (--) evdev: USB USB Keykoard: Found keys
[ 21819.373] (II) evdev: USB USB Keykoard: Configuring as keyboard
[ 21819.373] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:1a.2/usb5/5-1/5-1:1.0/0003:1C4F:0002.0002/input/input3/event3"
[ 21819.373] (II) XINPUT: Adding extended input device "USB USB Keykoard" (type: KEYBOARD, id 9)
[ 21819.373] (**) Option "xkb_rules" "evdev"
[ 21819.373] (**) Option "xkb_layout" "fr,us"
[ 21819.373] (**) Option "xkb_variant" ","
[ 21819.374] (II) config/udev: Adding input device USB USB Keykoard Consumer Control (/dev/input/event4)
[ 21819.374] (**) USB USB Keykoard Consumer Control: Applying InputClass "evdev keyboard catchall"
[ 21819.374] (**) USB USB Keykoard Consumer Control: Applying InputClass "libinput keyboard catchall"
[ 21819.374] (**) USB USB Keykoard Consumer Control: Applying InputClass "system-keyboard"
[ 21819.374] (II) Using input driver 'evdev' for 'USB USB Keykoard Consumer Control'
[ 21819.375] (II) systemd-logind: got fd for /dev/input/event4 13:68 fd 46 paused 0
[ 21819.375] (**) USB USB Keykoard Consumer Control: always reports core events
[ 21819.375] (**) evdev: USB USB Keykoard Consumer Control: Device: "/dev/input/event4"
[ 21819.375] (--) evdev: USB USB Keykoard Consumer Control: Vendor 0x1c4f Product 0x2
[ 21819.375] (--) evdev: USB USB Keykoard Consumer Control: Found 1 mouse buttons
[ 21819.375] (--) evdev: USB USB Keykoard Consumer Control: Found scroll wheel(s)
[ 21819.375] (--) evdev: USB USB Keykoard Consumer Control: Found relative axes
[ 21819.375] (II) evdev: USB USB Keykoard Consumer Control: Forcing relative x/y axes to exist.
[ 21819.375] (--) evdev: USB USB Keykoard Consumer Control: Found absolute axes
[ 21819.375] (II) evdev: USB USB Keykoard Consumer Control: Forcing absolute x/y axes to exist.
[ 21819.375] (--) evdev: USB USB Keykoard Consumer Control: Found keys
[ 21819.375] (II) evdev: USB USB Keykoard Consumer Control: Configuring as mouse
[ 21819.375] (II) evdev: USB USB Keykoard Consumer Control: Configuring as keyboard
[ 21819.375] (II) evdev: USB USB Keykoard Consumer Control: Adding scrollwheel support
[ 21819.375] (**) evdev: USB USB Keykoard Consumer Control: YAxisMapping: buttons 4 and 5
[ 21819.375] (**) evdev: USB USB Keykoard Consumer Control: EmulateWheelButton: 4, EmulateWheelInertia: 10, EmulateWheelTimeout: 200
[ 21819.375] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:1a.2/usb5/5-1/5-1:1.1/0003:1C4F:0002.0003/input/input4/event4"
[ 21819.375] (II) XINPUT: Adding extended input device "USB USB Keykoard Consumer Control" (type: KEYBOARD, id 10)
[ 21819.375] (**) Option "xkb_rules" "evdev"
[ 21819.375] (**) Option "xkb_layout" "fr,us"
[ 21819.375] (**) Option "xkb_variant" ","
[ 21819.375] (II) evdev: USB USB Keykoard Consumer Control: initialized for relative axes.
[ 21819.375] (WW) evdev: USB USB Keykoard Consumer Control: ignoring absolute axes.
[ 21819.375] (**) USB USB Keykoard Consumer Control: (accel) keeping acceleration scheme 1
[ 21819.376] (**) USB USB Keykoard Consumer Control: (accel) acceleration profile 0
[ 21819.376] (**) USB USB Keykoard Consumer Control: (accel) acceleration factor: 2.000
[ 21819.376] (**) USB USB Keykoard Consumer Control: (accel) acceleration threshold: 4
[ 21819.376] (II) config/udev: Adding input device USB USB Keykoard System Control (/dev/input/event5)
[ 21819.376] (**) USB USB Keykoard System Control: Applying InputClass "evdev keyboard catchall"
[ 21819.376] (**) USB USB Keykoard System Control: Applying InputClass "libinput keyboard catchall"
[ 21819.376] (**) USB USB Keykoard System Control: Applying InputClass "system-keyboard"
[ 21819.376] (II) Using input driver 'evdev' for 'USB USB Keykoard System Control'
[ 21819.377] (II) systemd-logind: got fd for /dev/input/event5 13:69 fd 47 paused 0
[ 21819.377] (**) USB USB Keykoard System Control: always reports core events
[ 21819.377] (**) evdev: USB USB Keykoard System Control: Device: "/dev/input/event5"
[ 21819.377] (--) evdev: USB USB Keykoard System Control: Vendor 0x1c4f Product 0x2
[ 21819.377] (--) evdev: USB USB Keykoard System Control: Found keys
[ 21819.377] (II) evdev: USB USB Keykoard System Control: Configuring as keyboard
[ 21819.377] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:1a.2/usb5/5-1/5-1:1.1/0003:1C4F:0002.0003/input/input5/event5"
[ 21819.377] (II) XINPUT: Adding extended input device "USB USB Keykoard System Control" (type: KEYBOARD, id 11)
[ 21819.377] (**) Option "xkb_rules" "evdev"
[ 21819.377] (**) Option "xkb_layout" "fr,us"
[ 21819.377] (**) Option "xkb_variant" ","
[ 21819.378] (II) config/udev: Adding input device HDA Intel Rear Mic (/dev/input/event11)
[ 21819.378] (II) No input driver specified, ignoring this device.
[ 21819.378] (II) This device may have been added with another device file.
[ 21819.378] (II) config/udev: Adding input device HDA Intel Line (/dev/input/event12)
[ 21819.379] (II) config/udev: Adding input device HDA Intel Line Out Front (/dev/input/event13)
[ 21819.379] (II) No input driver specified, ignoring this device.
[ 21819.379] (II) This device may have been added with another device file.
[ 21819.379] (II) config/udev: Adding input device HDA Intel Line Out Surround (/dev/input/event14)
[ 21819.380] (II) config/udev: Adding input device HDA Intel Line Out CLFE (/dev/input/event15)
[ 21819.380] (II) No input driver specified, ignoring this device.
[ 21819.380] (II) This device may have been added with another device file.
[ 21819.380] (II) config/udev: Adding input device PC Speaker (/dev/input/event6)
[ 21819.671] (--) NVIDIA(GPU-0): CRT-0: connected
[ 21819.671] (--) NVIDIA(GPU-0): CRT-0: 400.0 MHz maximum pixel clock
[ 21819.687] (--) NVIDIA(GPU-0): LG Electronics 700E (CRT-1): connected
[ 21819.687] (--) NVIDIA(GPU-0): LG Electronics 700E (CRT-1): 400.0 MHz maximum pixel clock
[ 21819.687] (--) NVIDIA(GPU-0): DFP-0: disconnected
[ 21819.687] (--) NVIDIA(GPU-0): DFP-0: Internal TMDS
[ 21819.687] (--) NVIDIA(GPU-0): DFP-0: 330.0 MHz maximum pixel clock
[ 21819.688] (--) NVIDIA(GPU-0): DFP-1: disconnected
[ 21819.688] (--) NVIDIA(GPU-0): DFP-1: Internal TMDS
[ 21819.688] (--) NVIDIA(GPU-0): DFP-1: 165.0 MHz maximum pixel clock
[ 21819.688] (--) NVIDIA(GPU-0): DFP-2: disconnected
[ 21819.688] (--) NVIDIA(GPU-0): DFP-2: Internal TMDS
[ 21819.688] (--) NVIDIA(GPU-0): DFP-2: 330.0 MHz maximum pixel clock
[ 21819.771] (II) NVIDIA(0): Setting mode "NULL"
[ 21819.819] (II) NVIDIA(0): Setting mode "DVI-I-0: nvidia-auto-select @1024x768 +0+0 {ViewPortIn=1024x768, ViewPortOut=1024x768+0+0}"
[ 21820.717] (--) NVIDIA(GPU-0): CRT-0: connected
[ 21820.717] (--) NVIDIA(GPU-0): CRT-0: 400.0 MHz maximum pixel clock
[ 21820.734] (--) NVIDIA(GPU-0): LG Electronics 700E (CRT-1): connected
[ 21820.734] (--) NVIDIA(GPU-0): LG Electronics 700E (CRT-1): 400.0 MHz maximum pixel clock
[ 21820.734] (--) NVIDIA(GPU-0): DFP-0: disconnected
[ 21820.734] (--) NVIDIA(GPU-0): DFP-0: Internal TMDS
[ 21820.734] (--) NVIDIA(GPU-0): DFP-0: 330.0 MHz maximum pixel clock
[ 21820.734] (--) NVIDIA(GPU-0): DFP-1: disconnected
[ 21820.734] (--) NVIDIA(GPU-0): DFP-1: Internal TMDS
[ 21820.734] (--) NVIDIA(GPU-0): DFP-1: 165.0 MHz maximum pixel clock
[ 21820.734] (--) NVIDIA(GPU-0): DFP-2: disconnected
[ 21820.734] (--) NVIDIA(GPU-0): DFP-2: Internal TMDS
[ 21820.734] (--) NVIDIA(GPU-0): DFP-2: 330.0 MHz maximum pixel clock
[ 21830.837] (II) systemd-logind: got pause for 13:65
[ 21830.837] (II) systemd-logind: got pause for 13:67
[ 21830.837] (II) systemd-logind: got pause for 13:66
[ 21830.837] (II) systemd-logind: got pause for 13:64
[ 21830.837] (II) systemd-logind: got pause for 13:68
[ 21830.837] (II) systemd-logind: got pause for 13:69
[ 21835.550] (II) evdev: USB USB Keykoard System Control: Close
[ 21835.550] (II) UnloadModule: "evdev"
[ 21835.550] (II) systemd-logind: releasing fd for 13:69
[ 21835.560] (II) evdev: USB USB Keykoard Consumer Control: Close
[ 21835.560] (II) UnloadModule: "evdev"
[ 21835.560] (II) systemd-logind: releasing fd for 13:68
[ 21835.577] (II) evdev: USB USB Keykoard: Close
[ 21835.577] (II) UnloadModule: "evdev"
[ 21835.577] (II) systemd-logind: releasing fd for 13:67
[ 21835.589] (II) evdev: PIXART USB OPTICAL MOUSE: Close
[ 21835.589] (II) UnloadModule: "evdev"
[ 21835.589] (II) systemd-logind: releasing fd for 13:66
[ 21835.597] (II) evdev: Sleep Button: Close
[ 21835.597] (II) UnloadModule: "evdev"
[ 21835.597] (II) systemd-logind: releasing fd for 13:64
[ 21835.606] (II) evdev: Power Button: Close
[ 21835.606] (II) UnloadModule: "evdev"
[ 21835.606] (II) systemd-logind: releasing fd for 13:65
[ 21835.640] (II) NVIDIA(GPU-0): Deleting GPU-0
[ 21835.642] (II) Server terminated successfully (0). Closing log file.
