No BaseMosaic or SLI on GTX650Ti cards
I’m attempting to setup two (eventually four) monitors across two GTX-650-Ti Boost cards.
My computer is currently running Archlinux, and it has been driving the two existing screens with one of the 650s for months, so I’m sure the displays and one of the cards works. The other cards will run the displays, but I haven’t used it as extensively.
As the topic mentions, I’ve tried getting both BaseMosaic and SLI to work, and am greeted with a blank screen and system freeze on X startup. I’m more concerned with Mosaic, as this is the feature which ostensibly will allow me to run four monitors in a desired configuration.
I’m going to walk back through the steps for BaseMosaic one more time and upload the .conf and .log as I go.
Archlinux:
$ alsi
                  ##                    OS: Arch Linux x86_64
                 ####                   Hostname: BNS-anarch
                ######                  Uptime: 17 min, 9 sec
               ########                 Kernel: 3.12.3-1-ARCH
              ##########                Shell: /bin/bash
             ############               Packages: 1410
            ##############              Desktop Environment: GNOME
           ################             RAM: 2397 MB / 16013 MB (14%)
          ##################            CPU: AMD FX(tm)-8350 Eight-Core Processor
         ####################           Boot: 23M / 1022M (3%) (vfat)
        ######################          Root: 71G / 109G (68%) (ext4)
I have tried this with 319.76 and 331.20, right now my system has 331.20 installed (I believe this time it is from the nvidia download site’s .run file, not from Arch’s packager)
$ sudo nvidia-settings -v
nvidia-settings:  version 331.20  (buildmeister@swio-display-x86-rhel47-05)  Wed Oct 30
18:20:32 PDT 2013
  The NVIDIA X Server Settings tool.
  This program is used to configure the NVIDIA Linux graphics driver.
  For more detail, please see the nvidia-settings(1) man page.
  Copyright (C) 2004 - 2010 NVIDIA Corporation.
Xorg.0.log.old with no xorg.conf, complete bootup and shutdown:
[    22.123]
X.Org X Server 1.14.4
Release Date: 2013-10-31
[    22.123] X Protocol Version 11, Revision 0
[    22.123] Build Operating System: Linux 3.11.6-1-ARCH x86_64
[    22.123] Current Operating System: Linux BNS-anarch 3.12.3-1-ARCH #1 SMP PREEMPT Wed Dec 4 21:45:42 CET 2013 x86_64
[    22.123] Kernel command line: initrd=\initramfs-linux.img root=/dev/sda2	rw
[    22.123] Build Date: 01 November 2013  05:10:48PM
[    22.123]
[    22.123] Current version of pixman: 0.32.4
[    22.123] 	Before reporting problems, check http://wiki.x.org
	to make sure that you have the latest version.
[    22.123] Markers: (--) probed, (**) from config file, (==) default setting,
	(++) from command line, (!!) notice, (II) informational,
	(WW) warning, (EE) error, (NI) not implemented, (??) unknown.
[    22.123] (==) Log file: "/var/log/Xorg.0.log", Time: Wed Dec 11 11:30:06 2013
[    22.124] (==) Using config directory: "/etc/X11/xorg.conf.d"
[    22.125] (==) No Layout section.  Using the first Screen section.
[    22.125] (==) No screen section available. Using defaults.
[    22.125] (**) |-->Screen "Default Screen Section" (0)
[    22.125] (**) |   |-->Monitor "<default monitor>"
[    22.125] (==) No monitor specified for screen "Default Screen Section".
	Using a default monitor configuration.
[    22.125] (==) Automatically adding devices
[    22.125] (==) Automatically enabling devices
[    22.125] (==) Automatically adding GPU devices
[    22.127] (WW) The directory "/usr/share/fonts/OTF/" does not exist.
[    22.127] 	Entry deleted from font path.
[    22.127] (WW) `fonts.dir' not found (or not valid) in "/usr/share/fonts/100dpi/".
[    22.127] 	(Run 'mkfontdir' on "/usr/share/fonts/100dpi/").
[    22.128] (WW) `fonts.dir' not found (or not valid) in "/usr/share/fonts/75dpi/".
[    22.128] 	Entry deleted from font path.
[    22.128] 	(Run 'mkfontdir' on "/usr/share/fonts/75dpi/").
[    22.128] (==) FontPath set to:
	/usr/share/fonts/misc/,
	/usr/share/fonts/TTF/,
	/usr/share/fonts/Type1/
[    22.128] (==) ModulePath set to "/usr/lib/xorg/modules"
[    22.128] (II) The server relies on udev to provide the list of input devices.
	If no devices become available, reconfigure udev or disable AutoAddDevices.
[    22.128] (II) Loader magic: 0x7fdc20
[    22.128] (II) Module ABI versions:
[    22.128] 	X.Org ANSI C Emulation: 0.4
[    22.128] 	X.Org Video Driver: 14.1
[    22.128] 	X.Org XInput driver : 19.1
[    22.128] 	X.Org Server Extension : 7.0
[    22.128] (II) xfree86: Adding drm device (/dev/dri/card0)
[    22.129] (II) xfree86: Adding drm device (/dev/dri/card1)
[    22.132] (--) PCI:*(0:1:0:0) 10de:11c2:3842:3657 rev 161, Mem @ 0xf6000000/16777216, 0xd0000000/134217728, 0xd8000000/33554432, I/O @ 0x0000e000/128, BIOS @ 0x????????/524288
[    22.132] (--) PCI: (0:4:0:0) 10de:11c2:3842:3657 rev 161, Mem @ 0xf4000000/16777216, 0xc0000000/134217728, 0xc8000000/33554432, I/O @ 0x0000c000/128, BIOS @ 0x????????/524288
[    22.133] Initializing built-in extension Generic Event Extension
[    22.133] Initializing built-in extension SHAPE
[    22.133] Initializing built-in extension MIT-SHM
[    22.133] Initializing built-in extension XInputExtension
[    22.133] Initializing built-in extension XTEST
[    22.133] Initializing built-in extension BIG-REQUESTS
[    22.133] Initializing built-in extension SYNC
[    22.133] Initializing built-in extension XKEYBOARD
[    22.133] Initializing built-in extension XC-MISC
[    22.133] Initializing built-in extension SECURITY
[    22.133] Initializing built-in extension XINERAMA
[    22.133] Initializing built-in extension XFIXES
[    22.133] Initializing built-in extension RENDER
[    22.133] Initializing built-in extension RANDR
[    22.133] Initializing built-in extension COMPOSITE
[    22.133] Initializing built-in extension DAMAGE
[    22.133] Initializing built-in extension MIT-SCREEN-SAVER
[    22.133] Initializing built-in extension DOUBLE-BUFFER
[    22.133] Initializing built-in extension RECORD
[    22.133] Initializing built-in extension DPMS
[    22.133] Initializing built-in extension X-Resource
[    22.133] Initializing built-in extension XVideo
[    22.133] Initializing built-in extension XVideo-MotionCompensation
[    22.133] Initializing built-in extension XFree86-VidModeExtension
[    22.133] Initializing built-in extension XFree86-DGA
[    22.133] Initializing built-in extension XFree86-DRI
[    22.133] Initializing built-in extension DRI2
[    22.133] (II) LoadModule: "glx"
[    22.135] (II) Loading /usr/lib/xorg/modules/extensions/libglx.so
[    22.201] (II) Module glx: vendor="NVIDIA Corporation"
[    22.201] 	compiled for 4.0.2, module version = 1.0.0
[    22.201] 	Module class: X.Org Server Extension
[    22.201] (II) NVIDIA GLX Module  331.20  Wed Oct 30 17:36:48 PDT 2013
[    22.202] Loading extension GLX
[    22.202] (==) Matched nouveau as autoconfigured driver 0
[    22.202] (==) Matched nvidia as autoconfigured driver 1
[    22.202] (==) Matched nv as autoconfigured driver 2
[    22.202] (==) Matched nouveau as autoconfigured driver 3
[    22.202] (==) Matched nvidia as autoconfigured driver 4
[    22.202] (==) Matched nv as autoconfigured driver 5
[    22.202] (==) Matched nouveau as autoconfigured driver 6
[    22.202] (==) Matched nvidia as autoconfigured driver 7
[    22.202] (==) Matched nv as autoconfigured driver 8
[    22.202] (==) Matched vesa as autoconfigured driver 9
[    22.202] (==) Matched modesetting as autoconfigured driver 10
[    22.202] (==) Matched fbdev as autoconfigured driver 11
[    22.202] (==) Assigned the driver to the xf86ConfigLayout
[    22.202] (II) LoadModule: "nouveau"
[    22.204] (WW) Warning, couldn't open module nouveau
[    22.204] (II) UnloadModule: "nouveau"
[    22.204] (II) Unloading nouveau
[    22.204] (EE) Failed to load module "nouveau" (module does not exist, 0)
[    22.204] (II) LoadModule: "nvidia"
[    22.205] (II) Loading /usr/lib/xorg/modules/drivers/nvidia_drv.so
[    22.215] (II) Module nvidia: vendor="NVIDIA Corporation"
[    22.215] 	compiled for 4.0.2, module version = 1.0.0
[    22.215] 	Module class: X.Org Video Driver
[    22.215] (II) LoadModule: "nv"
[    22.216] (WW) Warning, couldn't open module nv
[    22.216] (II) UnloadModule: "nv"
[    22.216] (II) Unloading nv
[    22.216] (EE) Failed to load module "nv" (module does not exist, 0)
[    22.216] (II) LoadModule: "vesa"
[    22.216] (WW) Warning, couldn't open module vesa
[    22.216] (II) UnloadModule: "vesa"
[    22.216] (II) Unloading vesa
[    22.216] (EE) Failed to load module "vesa" (module does not exist, 0)
[    22.216] (II) LoadModule: "modesetting"
[    22.217] (WW) Warning, couldn't open module modesetting
[    22.217] (II) UnloadModule: "modesetting"
[    22.217] (II) Unloading modesetting
[    22.217] (EE) Failed to load module "modesetting" (module does not exist, 0)
[    22.217] (II) LoadModule: "fbdev"
[    22.217] (WW) Warning, couldn't open module fbdev
[    22.217] (II) UnloadModule: "fbdev"
[    22.217] (II) Unloading fbdev
[    22.217] (EE) Failed to load module "fbdev" (module does not exist, 0)
[    22.217] (II) NVIDIA dlloader X Driver  331.20  Wed Oct 30 17:16:53 PDT 2013
[    22.217] (II) NVIDIA Unified Driver for all Supported NVIDIA GPUs
[    22.218] (++) using VT number 1
[    22.219] (II) Loading sub module "fb"
[    22.219] (II) LoadModule: "fb"
[    22.219] (II) Loading /usr/lib/xorg/modules/libfb.so
[    22.220] (II) Module fb: vendor="X.Org Foundation"
[    22.220] 	compiled for 1.14.4, module version = 1.0.0
[    22.220] 	ABI class: X.Org ANSI C Emulation, version 0.4
[    22.220] (WW) Unresolved symbol: fbGetGCPrivateKey
[    22.220] (II) Loading sub module "wfb"
[    22.220] (II) LoadModule: "wfb"
[    22.221] (II) Loading /usr/lib/xorg/modules/libwfb.so
[    22.222] (II) Module wfb: vendor="X.Org Foundation"
[    22.222] 	compiled for 1.14.4, module version = 1.0.0
[    22.222] 	ABI class: X.Org ANSI C Emulation, version 0.4
[    22.222] (II) Loading sub module "ramdac"
[    22.222] (II) LoadModule: "ramdac"
[    22.222] (II) Module "ramdac" already built-in
[    22.224] (II) NVIDIA(0): Creating default Display subsection in Screen section
	"Default Screen Section" for depth/fbbpp 24/32
[    22.224] (==) NVIDIA(0): Depth 24, (==) framebuffer bpp 32
[    22.224] (==) NVIDIA(0): RGB weight 888
[    22.224] (==) NVIDIA(0): Default visual is TrueColor
[    22.224] (==) NVIDIA(0): Using gamma correction (1.0, 1.0, 1.0)
[    22.224] (**) NVIDIA(0): Enabling 2D acceleration
[    22.859] (II) NVIDIA(0): Display (Ancor Communications Inc VS248 (DFP-0)) does not
[    22.859] (II) NVIDIA(0):     support NVIDIA 3D Vision stereo.
[    22.859] (II) NVIDIA(GPU-0): Found DRM driver nvidia-drm (20130102)
[    22.860] (II) NVIDIA(0): NVIDIA GPU GeForce GTX 650 Ti BOOST (GK106) at PCI:1:0:0
[    22.860] (II) NVIDIA(0):     (GPU-0)
[    22.860] (--) NVIDIA(0): Memory: 2097152 kBytes
[    22.860] (--) NVIDIA(0): VideoBIOS: 80.06.59.00.50
[    22.860] (II) NVIDIA(0): Detected PCI Express Link width: 16X
[    22.870] (--) NVIDIA(0): Valid display device(s) on GeForce GTX 650 Ti BOOST at PCI:1:0:0
[    22.870] (--) NVIDIA(0):     CRT-0
[    22.870] (--) NVIDIA(0):     Ancor Communications Inc VS248 (DFP-0) (boot, connected)
[    22.870] (--) NVIDIA(0):     DFP-1
[    22.870] (--) NVIDIA(0):     DFP-2
[    22.870] (--) NVIDIA(0):     DFP-3
[    22.870] (--) NVIDIA(0):     DFP-4
[    22.870] (--) NVIDIA(0): CRT-0: 400.0 MHz maximum pixel clock
[    22.870] (--) NVIDIA(0): Ancor Communications Inc VS248 (DFP-0): Internal Dual Link TMDS
[    22.870] (--) NVIDIA(0): Ancor Communications Inc VS248 (DFP-0): 330.0 MHz maximum pixel clock
[    22.870] (--) NVIDIA(0): DFP-1: Internal Single Link TMDS
[    22.870] (--) NVIDIA(0): DFP-1: 165.0 MHz maximum pixel clock
[    22.870] (--) NVIDIA(0): DFP-2: Internal Single Link TMDS
[    22.870] (--) NVIDIA(0): DFP-2: 165.0 MHz maximum pixel clock
[    22.870] (--) NVIDIA(0): DFP-3: Internal Single Link TMDS
[    22.870] (--) NVIDIA(0): DFP-3: 330.0 MHz maximum pixel clock
[    22.870] (--) NVIDIA(0): DFP-4: Internal DisplayPort
[    22.870] (--) NVIDIA(0): DFP-4: 960.0 MHz maximum pixel clock
[    22.870] (**) NVIDIA(0): Using HorizSync/VertRefresh ranges from the EDID for display
[    22.870] (**) NVIDIA(0):     device Ancor Communications Inc VS248 (DFP-0) (Using EDID
[    22.870] (**) NVIDIA(0):     frequencies has been enabled on all display devices.)
[    22.873] (==) NVIDIA(0):
[    22.873] (==) NVIDIA(0): No modes were requested; the default mode "nvidia-auto-select"
[    22.873] (==) NVIDIA(0):     will be used as the requested mode.
[    22.873] (II) NVIDIA(0): Validated MetaModes:
[    22.873] (II) NVIDIA(0):     "DFP-0:nvidia-auto-select"
[    22.873] (II) NVIDIA(0): Virtual screen size determined to be 1920 x 1080
[    22.913] (--) NVIDIA(0): DPI set to (92, 91); computed from "UseEdidDpi" X config
[    22.913] (--) NVIDIA(0):     option
[    22.913] (--) Depth 24 pixmap format is 32 bpp
[    23.533] (II) NVIDIA(0): Display (Ancor Communications Inc VS248 (DFP-0)) does not
[    23.533] (II) NVIDIA(0):     support NVIDIA 3D Vision stereo.
[    23.533] (II) NVIDIA(GPU-1): Found DRM driver nvidia-drm (20130102)
[    23.557] (II) NVIDIA(GPU-1): NVIDIA GPU GeForce GTX 650 Ti BOOST (GK106) at PCI:4:0:0
[    23.557] (II) NVIDIA(GPU-1):     (GPU-1)
[    23.557] (--) NVIDIA(GPU-1): Memory: 2097152 kBytes
[    23.557] (--) NVIDIA(GPU-1): VideoBIOS: 80.06.59.00.50
[    23.557] (II) NVIDIA(GPU-1): Detected PCI Express Link width: 16X
[    23.557] (--) NVIDIA(GPU-1): Valid display device(s) on GeForce GTX 650 Ti BOOST at PCI:4:0:0
[    23.557] (--) NVIDIA(GPU-1):     CRT-0
[    23.557] (--) NVIDIA(GPU-1):     Ancor Communications Inc VS248 (DFP-0) (boot, connected)
[    23.557] (--) NVIDIA(GPU-1):     DFP-1
[    23.557] (--) NVIDIA(GPU-1):     DFP-2
[    23.557] (--) NVIDIA(GPU-1):     DFP-3
[    23.557] (--) NVIDIA(GPU-1):     DFP-4
[    23.557] (--) NVIDIA(GPU-1): CRT-0: 400.0 MHz maximum pixel clock
[    23.557] (--) NVIDIA(GPU-1): Ancor Communications Inc VS248 (DFP-0): Internal Dual Link TMDS
[    23.557] (--) NVIDIA(GPU-1): Ancor Communications Inc VS248 (DFP-0): 330.0 MHz maximum pixel clock
[    23.557] (--) NVIDIA(GPU-1): DFP-1: Internal Single Link TMDS
[    23.557] (--) NVIDIA(GPU-1): DFP-1: 165.0 MHz maximum pixel clock
[    23.557] (--) NVIDIA(GPU-1): DFP-2: Internal Single Link TMDS
[    23.557] (--) NVIDIA(GPU-1): DFP-2: 165.0 MHz maximum pixel clock
[    23.557] (--) NVIDIA(GPU-1): DFP-3: Internal Single Link TMDS
[    23.557] (--) NVIDIA(GPU-1): DFP-3: 330.0 MHz maximum pixel clock
[    23.557] (--) NVIDIA(GPU-1): DFP-4: Internal DisplayPort
[    23.557] (--) NVIDIA(GPU-1): DFP-4: 960.0 MHz maximum pixel clock
[    23.557] (II) NVIDIA: Using 3072.00 MB of virtual memory for indirect memory
[    23.557] (II) NVIDIA:     access.
[    23.565] (II) NVIDIA(0): ACPI: failed to connect to the ACPI event daemon; the daemon
[    23.565] (II) NVIDIA(0):     may not be running or the "AcpidSocketPath" X
[    23.565] (II) NVIDIA(0):     configuration option may not be set correctly.  When the
[    23.565] (II) NVIDIA(0):     ACPI event daemon is available, the NVIDIA X driver will
[    23.565] (II) NVIDIA(0):     try to use it to receive ACPI event notifications.  For
[    23.565] (II) NVIDIA(0):     details, please see the "ConnectToAcpid" and
[    23.565] (II) NVIDIA(0):     "AcpidSocketPath" X configuration options in Appendix B: X
[    23.565] (II) NVIDIA(0):     Config Options in the README.
[    23.576] (II) NVIDIA(0): Setting mode "DFP-0:nvidia-auto-select"
[    23.633] Loading extension NV-GLX
[    23.653] (==) NVIDIA(0): Disabling shared memory pixmaps
[    23.653] (==) NVIDIA(0): Backing store disabled
[    23.653] (==) NVIDIA(0): Silken mouse enabled
[    23.654] (==) NVIDIA(0): DPMS enabled
[    23.654] Loading extension NV-CONTROL
[    23.654] Loading extension XINERAMA
[    23.654] (II) Loading sub module "dri2"
[    23.654] (II) LoadModule: "dri2"
[    23.654] (II) Module "dri2" already built-in
[    23.655] (II) NVIDIA(0): [DRI2] Setup complete
[    23.655] (II) NVIDIA(0): [DRI2]   VDPAU driver: nvidia
[    23.655] (--) RandR disabled
[    23.664] (II) Initializing extension GLX
[    23.766] (II) config/udev: Adding input device Power Button (/dev/input/event1)
[    23.766] (**) Power Button: Applying InputClass "evdev keyboard catchall"
[    23.766] (II) LoadModule: "evdev"
[    23.766] (II) Loading /usr/lib/xorg/modules/input/evdev_drv.so
[    23.768] (II) Module evdev: vendor="X.Org Foundation"
[    23.768] 	compiled for 1.14.3, module version = 2.8.2
[    23.768] 	Module class: X.Org XInput Driver
[    23.768] 	ABI class: X.Org XInput driver, version 19.1
[    23.768] (II) Using input driver 'evdev' for 'Power Button'
[    23.768] (**) Power Button: always reports core events
[    23.768] (**) evdev: Power Button: Device: "/dev/input/event1"
[    23.768] (--) evdev: Power Button: Vendor 0 Product 0x1
[    23.768] (--) evdev: Power Button: Found keys
[    23.768] (II) evdev: Power Button: Configuring as keyboard
[    23.768] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXPWRBN:00/input/input3/event1"
[    23.768] (II) XINPUT: Adding extended input device "Power Button" (type: KEYBOARD, id 6)
[    23.768] (**) Option "xkb_rules" "evdev"
[    23.768] (**) Option "xkb_model" "pc104"
[    23.768] (**) Option "xkb_layout" "us"
[    23.802] (II) config/udev: Adding input device Power Button (/dev/input/event0)
[    23.802] (**) Power Button: Applying InputClass "evdev keyboard catchall"
[    23.802] (II) Using input driver 'evdev' for 'Power Button'
[    23.802] (**) Power Button: always reports core events
[    23.802] (**) evdev: Power Button: Device: "/dev/input/event0"
[    23.802] (--) evdev: Power Button: Vendor 0 Product 0x1
[    23.802] (--) evdev: Power Button: Found keys
[    23.802] (II) evdev: Power Button: Configuring as keyboard
[    23.802] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/device:00/PNP0C0C:00/input/input2/event0"
[    23.802] (II) XINPUT: Adding extended input device "Power Button" (type: KEYBOARD, id 7)
[    23.802] (**) Option "xkb_rules" "evdev"
[    23.802] (**) Option "xkb_model" "pc104"
[    23.802] (**) Option "xkb_layout" "us"
[    23.803] (II) config/udev: Adding drm device (/dev/dri/card0)
[    23.803] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=3 (/dev/input/event16)
[    23.803] (II) No input driver specified, ignoring this device.
[    23.803] (II) This device may have been added with another device file.
[    23.803] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=7 (/dev/input/event15)
[    23.803] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=8 (/dev/input/event14)
[    23.804] (II) No input driver specified, ignoring this device.
[    23.804] (II) This device may have been added with another device file.
[    23.804] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=9 (/dev/input/event13)
[    23.804] (II) config/udev: Adding drm device (/dev/dri/card1)
[    23.804] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=3 (/dev/input/event21)
[    23.805] (II) No input driver specified, ignoring this device.
[    23.805] (II) This device may have been added with another device file.
[    23.805] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=7 (/dev/input/event20)
[    23.805] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=8 (/dev/input/event19)
[    23.806] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=9 (/dev/input/event18)
[    23.806] (II) No input driver specified, ignoring this device.
[    23.806] (II) This device may have been added with another device file.
[    23.806] (II) config/udev: Adding input device Mad Catz Mad Catz R.A.T.5 Mouse (/dev/input/event17)
[    23.806] (**) Mad Catz Mad Catz R.A.T.5 Mouse: Applying InputClass "evdev pointer catchall"
[    23.806] (**) Mad Catz Mad Catz R.A.T.5 Mouse: Applying InputClass "Mouse Remap"
[    23.806] (II) Using input driver 'evdev' for 'Mad Catz Mad Catz R.A.T.5 Mouse'
[    23.806] (**) Mad Catz Mad Catz R.A.T.5 Mouse: always reports core events
[    23.806] (**) evdev: Mad Catz Mad Catz R.A.T.5 Mouse: Device: "/dev/input/event17"
[    23.806] (**) evdev: Mad Catz Mad Catz R.A.T.5 Mouse: ButtonMapping '1 2 3 4 5 6 7 8 9 10 11 12 0 0 0 16 17 18 19 20 21'
[    23.806] (--) evdev: Mad Catz Mad Catz R.A.T.5 Mouse: Vendor 0x738 Product 0x1705
[    23.806] (--) evdev: Mad Catz Mad Catz R.A.T.5 Mouse: Found 17 mouse buttons
[    23.806] (--) evdev: Mad Catz Mad Catz R.A.T.5 Mouse: Found scroll wheel(s)
[    23.807] (--) evdev: Mad Catz Mad Catz R.A.T.5 Mouse: Found relative axes
[    23.807] (--) evdev: Mad Catz Mad Catz R.A.T.5 Mouse: Found x and y relative axes
[    23.807] (II) evdev: Mad Catz Mad Catz R.A.T.5 Mouse: Configuring as mouse
[    23.807] (II) evdev: Mad Catz Mad Catz R.A.T.5 Mouse: Adding scrollwheel support
[    23.807] (**) evdev: Mad Catz Mad Catz R.A.T.5 Mouse: YAxisMapping: buttons 4 and 5
[    23.807] (**) evdev: Mad Catz Mad Catz R.A.T.5 Mouse: EmulateWheelButton: 4, EmulateWheelInertia: 10, EmulateWheelTimeout: 200
[    23.807] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:12.0/usb6/6-3/6-3:1.0/input/input20/event17"
[    23.807] (II) XINPUT: Adding extended input device "Mad Catz Mad Catz R.A.T.5 Mouse" (type: MOUSE, id 8)
[    23.807] (II) evdev: Mad Catz Mad Catz R.A.T.5 Mouse: initialized for relative axes.
[    23.807] (**) Mad Catz Mad Catz R.A.T.5 Mouse: (accel) keeping acceleration scheme 1
[    23.807] (**) Mad Catz Mad Catz R.A.T.5 Mouse: (accel) acceleration profile 0
[    23.807] (**) Mad Catz Mad Catz R.A.T.5 Mouse: (accel) acceleration factor: 2.000
[    23.807] (**) Mad Catz Mad Catz R.A.T.5 Mouse: (accel) acceleration threshold: 4
[    23.808] (II) config/udev: Adding input device Mad Catz Mad Catz R.A.T.5 Mouse (/dev/input/mouse0)
[    23.808] (II) No input driver specified, ignoring this device.
[    23.808] (II) This device may have been added with another device file.
[    23.808] (II) config/udev: Adding input device Blue Microphones Yeti Stereo Microphone (/dev/input/event22)
[    23.808] (**) Blue Microphones Yeti Stereo Microphone: Applying InputClass "evdev keyboard catchall"
[    23.808] (II) Using input driver 'evdev' for 'Blue Microphones Yeti Stereo Microphone'
[    23.808] (**) Blue Microphones Yeti Stereo Microphone: always reports core events
[    23.808] (**) evdev: Blue Microphones Yeti Stereo Microphone: Device: "/dev/input/event22"
[    23.808] (--) evdev: Blue Microphones Yeti Stereo Microphone: Vendor 0xb58e Product 0x9e84
[    23.808] (--) evdev: Blue Microphones Yeti Stereo Microphone: Found 1 mouse buttons
[    23.808] (--) evdev: Blue Microphones Yeti Stereo Microphone: Found absolute axes
[    23.808] (--) evdev: Blue Microphones Yeti Stereo Microphone: Found absolute multitouch axes
[    23.808] (II) evdev: Blue Microphones Yeti Stereo Microphone: Forcing absolute x/y axes to exist.
[    23.808] (--) evdev: Blue Microphones Yeti Stereo Microphone: Found keys
[    23.808] (II) evdev: Blue Microphones Yeti Stereo Microphone: Forcing relative x/y axes to exist.
[    23.808] (II) evdev: Blue Microphones Yeti Stereo Microphone: Configuring as mouse
[    23.808] (II) evdev: Blue Microphones Yeti Stereo Microphone: Configuring as keyboard
[    23.808] (**) evdev: Blue Microphones Yeti Stereo Microphone: YAxisMapping: buttons 4 and 5
[    23.808] (**) evdev: Blue Microphones Yeti Stereo Microphone: EmulateWheelButton: 4, EmulateWheelInertia: 10, EmulateWheelTimeout: 200
[    23.809] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:12.0/usb6/6-4/6-4:1.3/input/input25/event22"
[    23.809] (II) XINPUT: Adding extended input device "Blue Microphones Yeti Stereo Microphone" (type: KEYBOARD, id 9)
[    23.809] (**) Option "xkb_rules" "evdev"
[    23.809] (**) Option "xkb_model" "pc104"
[    23.809] (**) Option "xkb_layout" "us"
[    23.809] (II) evdev: Blue Microphones Yeti Stereo Microphone: initialized for absolute axes.
[    23.809] (**) Blue Microphones Yeti Stereo Microphone: (accel) keeping acceleration scheme 1
[    23.809] (**) Blue Microphones Yeti Stereo Microphone: (accel) acceleration profile 0
[    23.809] (**) Blue Microphones Yeti Stereo Microphone: (accel) acceleration factor: 2.000
[    23.809] (**) Blue Microphones Yeti Stereo Microphone: (accel) acceleration threshold: 4
[    23.810] (II) config/udev: Adding input device USB Keyboard (/dev/input/event11)
[    23.810] (**) USB Keyboard: Applying InputClass "evdev keyboard catchall"
[    23.810] (II) Using input driver 'evdev' for 'USB Keyboard'
[    23.810] (**) USB Keyboard: always reports core events
[    23.810] (**) evdev: USB Keyboard: Device: "/dev/input/event11"
[    23.810] (--) evdev: USB Keyboard: Vendor 0x4d9 Product 0x169
[    23.810] (--) evdev: USB Keyboard: Found keys
[    23.810] (II) evdev: USB Keyboard: Configuring as keyboard
[    23.810] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:13.0/usb9/9-3/9-3:1.0/input/input14/event11"
[    23.810] (II) XINPUT: Adding extended input device "USB Keyboard" (type: KEYBOARD, id 10)
[    23.810] (**) Option "xkb_rules" "evdev"
[    23.810] (**) Option "xkb_model" "pc104"
[    23.810] (**) Option "xkb_layout" "us"
[    23.811] (II) config/udev: Adding input device USB Keyboard (/dev/input/event12)
[    23.811] (**) USB Keyboard: Applying InputClass "evdev keyboard catchall"
[    23.811] (II) Using input driver 'evdev' for 'USB Keyboard'
[    23.811] (**) USB Keyboard: always reports core events
[    23.811] (**) evdev: USB Keyboard: Device: "/dev/input/event12"
[    23.811] (--) evdev: USB Keyboard: Vendor 0x4d9 Product 0x169
[    23.811] (--) evdev: USB Keyboard: Found keys
[    23.811] (II) evdev: USB Keyboard: Configuring as keyboard
[    23.811] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:13.0/usb9/9-3/9-3:1.1/input/input15/event12"
[    23.811] (II) XINPUT: Adding extended input device "USB Keyboard" (type: KEYBOARD, id 11)
[    23.811] (**) Option "xkb_rules" "evdev"
[    23.811] (**) Option "xkb_model" "pc104"
[    23.811] (**) Option "xkb_layout" "us"
[    23.812] (II) config/udev: Adding input device HDA ATI SB Line Out Surround (/dev/input/event6)
[    23.812] (II) No input driver specified, ignoring this device.
[    23.812] (II) This device may have been added with another device file.
[    23.813] (II) config/udev: Adding input device HDA ATI SB Line Out CLFE (/dev/input/event5)
[    23.813] (II) No input driver specified, ignoring this device.
[    23.813] (II) This device may have been added with another device file.
[    23.813] (II) config/udev: Adding input device HDA ATI SB Line Out Side (/dev/input/event4)
[    23.813] (II) config/udev: Adding input device HDA ATI SB Front Headphone (/dev/input/event3)
[    23.813] (II) config/udev: Adding input device HDA ATI SB Front Mic (/dev/input/event10)
[    23.814] (II) config/udev: Adding input device HDA ATI SB Rear Mic (/dev/input/event9)
[    23.814] (II) No input driver specified, ignoring this device.
[    23.814] (II) This device may have been added with another device file.
[    23.814] (II) config/udev: Adding input device HDA ATI SB Line (/dev/input/event8)
[    23.814] (II) config/udev: Adding input device HDA ATI SB Line Out Front (/dev/input/event7)
[    23.814] (II) config/udev: Adding input device PC Speaker (/dev/input/event2)
[    30.937] (II) NVIDIA(GPU-0): Display (Ancor Communications Inc VS248 (DFP-0)) does not
[    30.937] (II) NVIDIA(GPU-0):     support NVIDIA 3D Vision stereo.
[    31.613] (II) NVIDIA(GPU-0): Display (Ancor Communications Inc VS248 (DFP-0)) does not
[    31.613] (II) NVIDIA(GPU-0):     support NVIDIA 3D Vision stereo.
[  2560.687] (II) evdev: USB Keyboard: Close
[  2560.687] (II) UnloadModule: "evdev"
[  2560.687] (II) evdev: Blue Microphones Yeti Stereo Microphone: Close
[  2560.687] (II) evdev: Mad Catz Mad Catz R.A.T.5 Mouse: Close
[  2560.687] (II) evdev: Power Button: Close
[  2561.110] (II) NVIDIA(GPU-1): Deleting GPU-1
[  2561.110] (II) NVIDIA(GPU-0): Deleting GPU-0
[  2561.111] (EE) Server terminated successfully (0). Closing log file.
Setting up xorg.conf:
Open nvidia-settings:
With no xorg.conf, one monitor is detected and attached to Screen0.
I select “X Server Disp Conf” which brings up a graphic of both monitors.
Select [Advanced…] button
Check [Enable BaseMosaic] box
Save to /etc/X11/xorg.conf
/etc/X11/xorg.conf:
# nvidia-settings: X configuration file generated by nvidia-settings
# nvidia-settings:  version 331.20  (buildmeister@swio-display-x86-rhel47-05)  Wed Oct 30 18:20:32 PDT 2013
Section "ServerLayout"
    Identifier     "Layout0"
    Screen      0  "Screen0" 0 0
    InputDevice    "Keyboard0" "CoreKeyboard"
    InputDevice    "Mouse0" "CorePointer"
    Option         "Xinerama" "0"
EndSection
Section "Files"
EndSection
Section "InputDevice"
    # generated from default
    Identifier     "Mouse0"
    Driver         "mouse"
    Option         "Protocol" "auto"
    Option         "Device" "/dev/psaux"
    Option         "Emulate3Buttons" "no"
    Option         "ZAxisMapping" "4 5"
EndSection
    Identifier     "Keyboard0"
    Driver         "kbd"
EndSection
Section "Monitor"
    # HorizSync source: edid, VertRefresh source: edid
    Identifier     "Monitor0"
    VendorName     "Unknown"
    ModelName      "Ancor Communications Inc VS248"
    HorizSync       30.0 - 83.0
    VertRefresh     50.0 - 76.0
    Option         "DPMS"
EndSection
Section "Device"
    Identifier     "Device0"
    Driver         "nvidia"
    VendorName     "NVIDIA Corporation"
    BoardName      "GeForce GTX 650 Ti BOOST"
    BusID          "PCI:1:0:0"
EndSection
Section "Screen"
    Identifier     "Screen0"
    Device         "Device0"
    Monitor        "Monitor0"
    DefaultDepth    24
    Option         "Stereo" "0"
    Option         "nvidiaXineramaInfoOrder" "DFP-0"
    Option         "metamodes" "GPU-65de2c48-af30-15a2-98a8-c717d88bec62.DVI-I-1: nvidia-auto-select +0+0, GPU-f645364c-b218-3bf2-93f7-9d9042a40b59.DVI-I-1: nvidia-auto-select +1920+0"
    Option         "MultiGPU" "Off"
    Option         "SLI" "off"
    Option         "BaseMosaic" "on"
    SubSection     "Display"
        Depth       24
    EndSubSection
EndSection
Reminder to me, files left to include:
Xorg.0.log
Xorg.0.log.old
nvidia-bug-report
I’m not sure I’ll be able to run the bug report with X server running, as I know it’ll crash the system, but I will attempt it and return shortly.
Edit 12-11-2013
Ok, after a reboot, I’m back :)
I have lxdm.service disabled, so the computer boots up to a console.
With the SLI cable not installed:
I start lxdm, the screen flickers, and my login prompt appears on the primary monitor. Second monitor is still in standby. Mouse cannot move off screen in any direction.
Xorg.0.log:
[   257.252]
[   257.252] X Protocol Version 11, Revision 0
[   257.252] Build Operating System: Linux 3.11.6-1-ARCH x86_64
[   257.252] Current Operating System: Linux BNS-anarch 3.12.3-1-ARCH #1 SMP PREEMPT Wed Dec 4 21:45:42 CET 2013 x86_64
[   257.252] Kernel command line: initrd=\initramfs-linux.img root=/dev/sda2	rw
[   257.252] Build Date: 01 November 2013  05:10:48PM
[   257.252]
[   257.252] Current version of pixman: 0.32.4
[   257.252] 	Before reporting problems, check http://wiki.x.org
[   257.252] Markers: (--) probed, (**) from config file, (==) default setting,
[   257.252] (==) Log file: "/var/log/Xorg.0.log", Time: Wed Dec 11 12:17:07 2013
[   257.253] (==) Using config file: "/etc/X11/xorg.conf"
[   257.253] (==) Using config directory: "/etc/X11/xorg.conf.d"
[   257.255] (==) ServerLayout "Layout0"
[   257.255] (**) |-->Screen "Screen0" (0)
[   257.255] (**) |   |-->Monitor "Monitor0"
[   257.255] (**) |   |-->Device "Device0"
[   257.255] (**) |-->Input Device "Keyboard0"
[   257.255] (**) |-->Input Device "Mouse0"
[   257.255] (**) Option "Xinerama" "0"
[   257.255] (==) Automatically adding devices
[   257.255] (==) Automatically enabling devices
[   257.255] (==) Automatically adding GPU devices
[   257.257] (WW) The directory "/usr/share/fonts/OTF/" does not exist.
[   257.257] 	Entry deleted from font path.
[   257.257] (WW) `fonts.dir' not found (or not valid) in "/usr/share/fonts/100dpi/".
[   257.257] 	(Run 'mkfontdir' on "/usr/share/fonts/100dpi/").
[   257.257] (WW) `fonts.dir' not found (or not valid) in "/usr/share/fonts/75dpi/".
[   257.257] 	(Run 'mkfontdir' on "/usr/share/fonts/75dpi/").
[   257.257] (==) FontPath set to:
[   257.257] (==) ModulePath set to "/usr/lib/xorg/modules"
[   257.258] (WW) Hotplugging is on, devices using drivers 'kbd', 'mouse' or 'vmmouse' will be disabled.
[   257.258] (WW) Disabling Keyboard0
[   257.258] (WW) Disabling Mouse0
[   257.258] (II) Loader magic: 0x7fdc20
[   257.258] (II) Module ABI versions:
[   257.258] 	X.Org ANSI C Emulation: 0.4
[   257.258] 	X.Org Video Driver: 14.1
[   257.258] 	X.Org XInput driver : 19.1
[   257.258] 	X.Org Server Extension : 7.0
[   257.258] (II) xfree86: Adding drm device (/dev/dri/card0)
[   257.258] (II) xfree86: Adding drm device (/dev/dri/card1)
[   257.262] (--) PCI:*(0:1:0:0) 10de:11c2:3842:3657 rev 161, Mem @ 0xf6000000/16777216, 0xd0000000/134217728, 0xd8000000/33554432, I/O @ 0x0000e000/128, BIOS @ 0x????????/524288
[   257.262] (--) PCI: (0:4:0:0) 10de:11c2:3842:3657 rev 161, Mem @ 0xf4000000/16777216, 0xc0000000/134217728, 0xc8000000/33554432, I/O @ 0x0000c000/128, BIOS @ 0x????????/524288
[   257.262] Initializing built-in extension Generic Event Extension
[   257.262] Initializing built-in extension SHAPE
[   257.262] Initializing built-in extension MIT-SHM
[   257.262] Initializing built-in extension XInputExtension
[   257.262] Initializing built-in extension XTEST
[   257.262] Initializing built-in extension BIG-REQUESTS
[   257.262] Initializing built-in extension SYNC
[   257.262] Initializing built-in extension XKEYBOARD
[   257.262] Initializing built-in extension XC-MISC
[   257.262] Initializing built-in extension SECURITY
[   257.262] Initializing built-in extension XINERAMA
[   257.262] Initializing built-in extension XFIXES
[   257.262] Initializing built-in extension RENDER
[   257.262] Initializing built-in extension RANDR
[   257.262] Initializing built-in extension COMPOSITE
[   257.262] Initializing built-in extension DAMAGE
[   257.262] Initializing built-in extension MIT-SCREEN-SAVER
[   257.262] Initializing built-in extension DOUBLE-BUFFER
[   257.262] Initializing built-in extension RECORD
[   257.262] Initializing built-in extension DPMS
[   257.262] Initializing built-in extension X-Resource
[   257.262] Initializing built-in extension XVideo
[   257.263] Initializing built-in extension XVideo-MotionCompensation
[   257.263] Initializing built-in extension XFree86-VidModeExtension
[   257.263] Initializing built-in extension XFree86-DGA
[   257.263] Initializing built-in extension XFree86-DRI
[   257.263] Initializing built-in extension DRI2
[   257.263] (II) LoadModule: "glx"
[   257.264] (II) Loading /usr/lib/xorg/modules/extensions/libglx.so
[   257.334] (II) Module glx: vendor="NVIDIA Corporation"
[   257.334] 	compiled for 4.0.2, module version = 1.0.0
[   257.334] 	Module class: X.Org Server Extension
[   257.334] (II) NVIDIA GLX Module  331.20  Wed Oct 30 17:36:48 PDT 2013
[   257.335] Loading extension GLX
[   257.335] (II) LoadModule: "nvidia"
[   257.337] (II) Loading /usr/lib/xorg/modules/drivers/nvidia_drv.so
[   257.344] (II) Module nvidia: vendor="NVIDIA Corporation"
[   257.344] 	compiled for 4.0.2, module version = 1.0.0
[   257.344] 	Module class: X.Org Video Driver
[   257.345] (II) NVIDIA dlloader X Driver  331.20  Wed Oct 30 17:16:53 PDT 2013
[   257.345] (II) NVIDIA Unified Driver for all Supported NVIDIA GPUs
[   257.345] (++) using VT number 1
[   257.347] (II) Loading sub module "fb"
[   257.347] (II) LoadModule: "fb"
[   257.347] (II) Loading /usr/lib/xorg/modules/libfb.so
[   257.348] (II) Module fb: vendor="X.Org Foundation"
[   257.348] 	compiled for 1.14.4, module version = 1.0.0
[   257.348] 	ABI class: X.Org ANSI C Emulation, version 0.4
[   257.348] (WW) Unresolved symbol: fbGetGCPrivateKey
[   257.348] (II) Loading sub module "wfb"
[   257.348] (II) LoadModule: "wfb"
[   257.348] (II) Loading /usr/lib/xorg/modules/libwfb.so
[   257.350] (II) Module wfb: vendor="X.Org Foundation"
[   257.350] 	compiled for 1.14.4, module version = 1.0.0
[   257.350] 	ABI class: X.Org ANSI C Emulation, version 0.4
[   257.350] (II) Loading sub module "ramdac"
[   257.350] (II) LoadModule: "ramdac"
[   257.350] (II) Module "ramdac" already built-in
[   257.352] (**) NVIDIA(0): Depth 24, (--) framebuffer bpp 32
[   257.352] (==) NVIDIA(0): RGB weight 888
[   257.352] (==) NVIDIA(0): Default visual is TrueColor
[   257.352] (==) NVIDIA(0): Using gamma correction (1.0, 1.0, 1.0)
[   257.352] (**) NVIDIA(0): Option "Stereo" "0"
[   257.352] (**) NVIDIA(0): Option "nvidiaXineramaInfoOrder" "DFP-0"
[   257.353] (**) NVIDIA(0): Option "SLI" "off"
[   257.353] (**) NVIDIA(0): Option "MultiGPU" "Off"
[   257.353] (**) NVIDIA(0): Option "BaseMosaic" "on"
[   257.353] (**) NVIDIA(0): Stereo disabled by request
[   257.353] (**) NVIDIA(0): NVIDIA SLI disabled.
[   257.353] (**) NVIDIA(0): NVIDIA Multi-GPU disabled.
[   257.353] (**) NVIDIA(0): Option "MetaModes" "GPU-65de2c48-af30-15a2-98a8-c717d88bec62.DVI-I-1: nvidia-auto-select +0+0, GPU-f645364c-b218-3bf2-93f7-9d9042a40b59.DVI-I-1: nvidia-auto-select +1920+0"
[   257.353] (**) NVIDIA(0): Enabling 2D acceleration
[   257.957] (EE) NVIDIA(GPU-0): Failed to find a valid Base Mosaic configuration.
[   257.957] (EE) NVIDIA(GPU-0): Invalid Base Mosaic configuration 1 of 1:
[   257.957] (EE) NVIDIA(GPU-0): GPUs:
[   257.957] (EE) NVIDIA(GPU-0):     1) NVIDIA GPU at PCI:1:0:0
[   257.957] (EE) NVIDIA(GPU-0):     2) NVIDIA GPU at PCI:4:0:0
[   257.957] (EE) NVIDIA(GPU-0): Errors:
[   257.957] (EE) NVIDIA(GPU-0):     - The video link was not detected
[   257.957] (WW) NVIDIA(GPU-0): Failed to find a valid Base Mosaic configuration for the
[   257.957] (WW) NVIDIA(GPU-0):     NVIDIA graphics device PCI:1:0:0. Please see Chapter 29:
[   257.957] (WW) NVIDIA(GPU-0):     Configuring SLI and Multi-GPU FrameRendering in the README
[   257.957] (WW) NVIDIA(GPU-0):     for troubleshooting suggestions.
nvidia-bug-report-nosli
Ok, to me it looks like BaseMosaic requires SLI, so I’m going to shutdown, install the SLI cable, and power back up.
Edit 12-11-2013
Ok, back up again.
With sli cable in place:
Computer boots up to terminal login.
I log in, and start lxdm.service.
Screen flicks to black and the entire system freezes. No keyboard or mouse, no SSH, nothing.
Primary monitor stays turned on, but blank. Secondary monitor remains in standby.
Partial Xorg.0.log from the failed bootup:
[    68.939]
[    68.939] X Protocol Version 11, Revision 0
[    68.939] Build Operating System: Linux 3.11.6-1-ARCH x86_64
[    68.939] Current Operating System: Linux BNS-anarch 3.12.3-1-ARCH #1 SMP PREEMPT Wed Dec 4 21:45:42 CET 2013 x86_64
[    68.939] Kernel command line: initrd=\initramfs-linux.img root=/dev/sda2	rw
[    68.939] Build Date: 01 November 2013  05:10:48PM
[    68.939]
[    68.939] Current version of pixman: 0.32.4
[    68.939] 	Before reporting problems, check http://wiki.x.org
[    68.939] Markers: (--) probed, (**) from config file, (==) default setting,
[    68.940] (==) Log file: "/var/log/Xorg.0.log", Time: Wed Dec 11 12:39:23 2013
[    68.941] (==) Using config file: "/etc/X11/xorg.conf"
[    68.941] (==) Using config directory: "/etc/X11/xorg.conf.d"
[    68.942] (==) ServerLayout "Layout0"
[    68.942] (**) |-->Screen "Screen0" (0)
[    68.942] (**) |   |-->Monitor "Monitor0"
[    68.942] (**) |   |-->Device "Device0"
[    68.943] (**) |-->Input Device "Keyboard0"
[    68.943] (**) |-->Input Device "Mouse0"
[    68.943] (**) Option "Xinerama" "0"
[    68.943] (==) Automatically adding devices
[    68.943] (==) Automatically enabling devices
[    68.943] (==) Automatically adding GPU devices
[    68.944] (WW) The directory "/usr/share/fonts/OTF/" does not exist.
[    68.944] 	Entry deleted from font path.
[    68.945] (WW) `fonts.dir' not found (or not valid) in "/usr/share/fonts/100dpi/".
[    68.945] 	Entry deleted from font path.
[    68.945] 	(Run 'mkfontdir' on "/usr/share/fonts/100dpi/").
[    68.945] (WW) `fonts.dir' not found (or not valid) in "/usr/share/fonts/75dpi/".
[    68.945] 	(Run 'mkfontdir' on "/usr/share/fonts/75dpi/").
[    68.945] (==) FontPath set to:
[    68.945] (==) ModulePath set to "/usr/lib/xorg/modules"
[    68.945] (WW) Hotplugging is on, devices using drivers 'kbd', 'mouse' or 'vmmouse' will be disabled.
[    68.945] (WW) Disabling Keyboard0
[    68.945] (WW) Disabling Mouse0
[    68.945] (II) Loader magic: 0x7fdc20
[    68.945] (II) Module ABI versions:
[    68.945] 	X.Org ANSI C Emulation: 0.4
[    68.945] 	X.Org Video Driver: 14.1
[    68.945] 	X.Org XInput driver : 19.1
[    68.945] 	X.Org Server Extension : 7.0
[    68.946] (II) xfree86: Adding drm device (/dev/dri/card0)
[    68.946] (II) xfree86: Adding drm device (/dev/dri/card1)
[    68.950] (--) PCI:*(0:1:0:0) 10de:11c2:3842:3657 rev 161, Mem @ 0xf6000000/16777216, 0xd0000000/134217728, 0xd8000000/33554432, I/O @ 0x0000e000/128, BIOS @ 0x????????/524288
[    68.950] (--) PCI: (0:4:0:0) 10de:11c2:3842:3657 rev 161, Mem @ 0xf4000000/16777216, 0xc0000000/134217728, 0xc8000000/33554432, I/O @ 0x0000c000/128, BIOS @ 0x????????/524288
[    68.950] Initializing built-in extension Generic Event Extension
[    68.950] Initializing built-in extension SHAPE
[    68.950] Initializing built-in extension MIT-SHM
[    68.950] Initializing built-in extension XInputExtension
[    68.950] Initializing built-in extension XTEST
[    68.950] Initializing built-in extension BIG-REQUESTS
[    68.950] Initializing built-in extension SYNC
[    68.950] Initializing built-in extension XKEYBOARD
[    68.950] Initializing built-in extension XC-MISC
[    68.950] Initializing built-in extension SECURITY
[    68.950] Initializing built-in extension XINERAMA
[    68.950] Initializing built-in extension XFIXES
[    68.950] Initializing built-in extension RENDER
[    68.950] Initializing built-in extension RANDR
[    68.950] Initializing built-in extension COMPOSITE
[    68.950] Initializing built-in extension DAMAGE
[    68.950] Initializing built-in extension MIT-SCREEN-SAVER
[    68.950] Initializing built-in extension DOUBLE-BUFFER
[    68.950] Initializing built-in extension RECORD
[    68.950] Initializing built-in extension DPMS
[    68.950] Initializing built-in extension X-Resource
[    68.950] Initializing built-in extension XVideo
[    68.950] Initializing built-in extension XVideo-MotionCompensation
[    68.950] Initializing built-in extension XFree86-VidModeExtension
[    68.950] Initializing built-in extension XFree86-DGA
[    68.950] Initializing built-in extension XFree86-DRI
[    68.950] Initializing built-in extension DRI2
[    68.950] (II) LoadModule: "glx"
[    68.952] (II) Loading /usr/lib/xorg/modules/extensions/libglx.so
[    69.018] (II) Module glx: vendor="NVIDIA Corporation"
[    69.018] 	compiled for 4.0.2, module version = 1.0.0
[    69.018] 	Module class: X.Org Server Extension
[    69.018] (II) NVIDIA GLX Module  331.20  Wed Oct 30 17:36:48 PDT 2013
[    69.019] Loading extension GLX
[    69.019] (II) LoadModule: "nvidia"
[    69.020] (II) Loading /usr/lib/xorg/modules/drivers/nvidia_drv.so
[    69.028] (II) Module nvidia: vendor="NVIDIA Corporation"
[    69.028] 	compiled for 4.0.2, module version = 1.0.0
[    69.028] 	Module class: X.Org Video Driver
[    69.029] (II) NVIDIA dlloader X Driver  331.20  Wed Oct 30 17:16:53 PDT 2013
[    69.029] (II) NVIDIA Unified Driver for all Supported NVIDIA GPUs
[    69.029] (++) using VT number 1
[    69.030] (II) Loading sub module "fb"
[    69.030] (II) LoadModule: "fb"
[    69.031] (II) Loading /usr/lib/xorg/modules/libfb.so
[    69.032] (II) Module fb: vendor="X.Org Foundation"
[    69.032] 	compiled for 1.14.4, module version = 1.0.0
[    69.032] 	ABI class: X.Org ANSI C Emulation, version 0.4
[    69.032] (WW) Unresolved symbol: fbGetGCPrivateKey
[    69.032] (II) Loading sub module "wfb"
[    69.032] (II) LoadModule: "wfb"
[    69.032] (II) Loading /usr/lib/xorg/modules/libwfb.so
[    69.034] (II) Module wfb: vendor="X.Org Foundation"
[    69.034] 	compiled for 1.14.4, module version = 1.0.0
[    69.034] 	ABI class: X.Org ANSI C Emulation, version 0.4
[    69.034] (II) Loading sub module "ramdac"
[    69.034] (II) LoadModule: "ramdac"
[    69.034] (II) Module "ramdac" already built-in
[    69.036] (**) NVIDIA(0): Depth 24, (--) framebuffer bpp 32
[    69.036] (==) NVIDIA(0): RGB weight 888
[    69.036] (==) NVIDIA(0): Default visual is TrueColor
[    69.036] (==) NVIDIA(0): Using gamma correction (1.0, 1.0, 1.0)
[    69.036] (**) NVIDIA(0): Option "Stereo" "0"
[    69.036] (**) NVIDIA(0): Option "nvidiaXineramaInfoOrder" "DFP-0"
[    69.036] (**) NVIDIA(0): Option "SLI" "off"
[    69.036] (**) NVIDIA(0): Option "MultiGPU" "Off"
[    69.036] (**) NVIDIA(0): Option "BaseMosaic" "on"
[    69.036] (**) NVIDIA(0): Stereo disabled by request
[    69.036] (**) NVIDIA(0): NVIDIA SLI disabled.
[    69.036] (**) NVIDIA(0): NVIDIA Multi-GPU disabled.
[    69.036] (**) NVIDIA(0): Option "MetaModes" "GPU-65de2c48-af30-15a2-98a8-c717d88bec62.DVI-I-1: nvidia-auto-select +0+0, GPU-f645364c-b218-3bf2-93f7-9d9042a40b59.DVI-I-1: nvidia-auto-select +1920+0"
[    69.036] (**) NVIDIA(0): Enabling 2D acceleration
[    70.496] (II) NVIDIA(GPU-0): NVIDIA Base Mosaic enabled.
[    70.534] (II) NVIDIA(0): Display (Ancor Communications Inc VS248 (DFP-0)) does not
[    70.534] (II) NVIDIA(0):     support NVIDIA 3D Vision stereo.
[    70.568] (II) NVIDIA(0): Display (Ancor Communications Inc VS248 (DFP-0)) does not
[    70.568] (II) NVIDIA(0):     support NVIDIA 3D Vision stereo.
[    70.569] (II) NVIDIA(GPU-0): Found DRM driver nvidia-drm (20130102)
[    70.569] (II) NVIDIA(GPU-1): Found DRM driver nvidia-drm (20130102)
[    70.571] (II) NVIDIA(0): NVIDIA GPU GeForce GTX 650 Ti BOOST (GK106) at PCI:1:0:0
[    70.571] (II) NVIDIA(0):     (GPU-0)
[    70.571] (--) NVIDIA(0): Memory: 2097152 kBytes
[    70.571] (--) NVIDIA(0): VideoBIOS: 80.06.59.00.50
[    70.571] (II) NVIDIA(0): Detected PCI Express Link width: 16X
[    70.571] (II) NVIDIA(0): NVIDIA GPU GeForce GTX 650 Ti BOOST (GK106) at PCI:4:0:0
[    70.571] (II) NVIDIA(0):     (GPU-1)
[    70.572] (II) NVIDIA(0): Detected PCI Express Link width: 16X
Another nvidia-bug-report file, generated with the sli cable in place, but without any xorg.conf file, so that the system would actually start the X session:
nvidia-bug-report-sli-no-xorg
I’ll hang on to this system for a while, if anyone has suggestions or needs me to gather more information, please let me know.
Thanks,
-CTAG
Please attach nvidia bug report .
sandipt,
I apologize my original post is such a mess. It linked to two nvidia-bug-report files, but I will re-upload them to a different host in case that was a problem.
Bug report taken with no SLI cable, and with settings in xorg.conf for Base Mosaic:
Bug report taken with SLI cable installed, but no basemosaic settings configured in Xorg.conf (or the system would crash with no option to get a bug report):
nvidia-bug-report-sliNoXorg
If these were not what you need, please let me know.
Thank you,
-CTAG
Ok,
A week later, now three or so weeks into not being able to use my desktop, and the only solution that allows me to run both monitors is to set each monitor as a separate X session, which is substantially less than useful, but it works.
I read that BaseMosaic on Linux has been crippled to support three monitors, which does make sense seeing that the BaseMosaic implementation appears little more then a hack anyway. However, the documentation shows four monitors in its example, which seems rather misleading even if it’s pertaining to a somehow more valid graphics card.
SLI and SLI-Mosaic still don’t work for me. If someone could point me in a new direction for troubleshooting, I’d appreciate it.
Thanks,
-CTAG
Is this issue still repro with latest driver version?
I believe it still is. CTAG and I have been having the same issue for some time. I am going to try the latest stable once again, and then I will try the beta and report back.
Nope, same problem still exists on 331 and 334 drivers.
Did you test with 334.21 driver? Is the it helped?
I can confirm that this exact issue still exists in 340.24 on Ubuntu 14.04.
I’ve spent the past 24 hours trying to resolve this with no success.
I have two Quadro K600 cards running basemosaic for four monitors. I was under the impression that basemosaic was only available on Quadro cards.
