I have a workstation with 2 Xeon CPUs with many cores, 1 NVIDIA GTX1050, 1 NVIDIA TESLA K40 (Computing only).
I have recently upgraded ubuntu from 14 to 16.04 LTS. It went into unsuccessfull login-loop. Reinstalled unity, compiz couple of times, uninstalled nvidia drivers and reinstall solved the login. Now I am having issues with wireless mouse and keyboard lag-freeze occasionally. Cable mouse works smoothly. I am suspecting that it can be still be an issue with the drivers or desktop integration with cards. Please let me know what I should post here to help resolving the problem.
Below are my queries and whatever they return.
Why does nvidia-bug-report contain entries about wireless mouse/keyboard.
Here is what I get:
1.
$nvidia-detector
none
$ubuntu-drivers devices
== cpu-microcode.py ==
driver : intel-microcode - distro free
== /sys/devices/pci0000:80/0000:80:01.0/0000:81:00.0 ==
model : GK110BGL [Tesla K40c]
vendor : NVIDIA Corporation
modalias : pci:v000010DEd00001024sv000010DEsd00000983bc03sc02i00
driver : xserver-xorg-video-nouveau - distro free builtin
driver : nvidia-340 - third-party free
== /sys/devices/pci0000:00/0000:00:02.0/0000:03:00.0 ==
modalias : pci:v000010DEd00001B81sv00001043sd000085A0bc03sc00i00
driver : nvidia-381 - third-party free
driver : nvidia-387 - third-party free recommended
driver : nvidia-384 - third-party free
$ lsdev
Device DMA IRQ I/O Ports
0000:00:11.4 46 0000-0000 0000-0000 0000-0000 0000-0000 0000-0000
0000:00:1f.2 52 0000-0000 0000-0000 0000-0000 0000-0000 0000-0000
0000:00:1f.3 0000-0000
0000:03:00.0 0000-0000
0000:06:00.0 0000-0000
0000:07:00.0 0000-0000
0000:08:00.0 58 0000-0000 0000-0000 0000-0000 0000-0000 0000-0000
acpi 9
ACPI 0000-0000 0000-0000 0000-0000 0000-0000 0000-0000 0000-0000
aerdrv, PCIe PME 25 26 28 30 36
ahci 0000-0000 0000-0000 0000-0000 0000-0000 0000-0000 0000-0000 0000-0000 0000-0000 0000-0000 0000-0000 0000-0000 0000-0000 0000-0000 0000-0000 0000-0000
APEI 0000-0000
cascade 4
dma 0000-0000
dma1 0000-0000
dma2 0000-0000
dmar0 72
dmar1 73
ehci_hcd:usb2 18
eth0 47
eth0-TxRx-0 48
eth0-TxRx-1 49
eth0-TxRx-2 50
eth0-TxRx-3 51
eth1 53
eth1-TxRx-0 54
eth1-TxRx-1 55
eth1-TxRx-2 56
eth1-TxRx-3 57
fpu 0000-0000
i8042 1 12
iTCO_wdt.0.auto 0000-0000 0000-0000
keyboard 0000-0000 0000-0000
nvidia 59 62
PCI 0000-0000 0000-0000 0000-0000 0000-0000 0000-0000 0000-0000 0000-0000 0000-0000
PCIe PME 31 32 33 34
pic1 0000-0000
pic2 0000-0000
pnp 0000-0000 0000-0000 0000-0000 0000-0000 0000-0000 0000-0000
PNP0800:00 0000-0000
PNP0C04:00 0000-0000
rtc0 8 0000-0000
serial 0000-0000 0000-0000
snd_hda_intel 60 61
timer 0
timer0 0000-0000
timer1 0000-0000
vesafb 0000-0000
xhci-hcd:usb3 19
xhci_hcd 38 39 40 41 42 43 44 45
$ sudo lsusb
Bus 002 Device 002: ID 8087:8002 Intel Corp.
Bus 002 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 001 Device 002: ID 8087:800a Intel Corp.
Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 004 Device 003: ID 174c:55aa ASMedia Technology Inc. ASM1051E SATA 6Gb/s bridge, ASM1053E SATA 6Gb/s bridge, ASM1153 SATA 3Gb/s bridge
Bus 004 Device 002: ID 174c:3074 ASMedia Technology Inc. ASM1074 SuperSpeed hub
Bus 004 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 003 Device 002: ID 174c:2074 ASMedia Technology Inc. ASM1074 High-Speed hub
Bus 003 Device 004: ID 045e:07b2 Microsoft Corp.
Bus 003 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 006 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 005 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
sudo lshw | grep USB
description: USB controller
product: ASM1042A USB 3.0 Host Controller
product: C610/X99 series chipset USB xHCI Host Controller
description: USB hub
product: C610/X99 series chipset USB Enhanced Host Controller #2
product: C610/X99 series chipset USB Enhanced Host Controller #1
$ sudo lshw | grep -i NVIDIA
product: NVIDIA Corporation
vendor: NVIDIA Corporation
configuration: driver=nvidia latency=0
$ compiz --version
Compiz 0.9.12.2
[CODE]
Start of NVIDIA bug report log file. Please include this file, along
with a detailed description of your problem, when reporting a graphics
driver bug via the NVIDIA Linux forum (see devtalk.nvidia.com)
or by sending email to ‘linux-bugs@nvidia.com’.
nvidia-bug-report.sh Version: 22640938
Date: Fri Jan 5 17:28:38 +03 2018
uname: Linux tesla 4.4.0-104-generic #127-Ubuntu SMP Mon Dec 11 12:16:42 UTC 2017 x86_64 x86_64 x86_64 GNU/Linux
command line flags:
*** /etc/issue
*** ls: -rw-r–r-- 1 root root 26 2017-07-31 16:36:56.000000000 +0300 /etc/issue
Ubuntu 16.04.3 LTS \n \l
*** /etc/debian_version
*** ls: -rw-r–r-- 1 root root 12 2015-04-30 13:00:00.000000000 +0300 /etc/debian_version
stretch/sid
*** /var/log/nvidia-installer.log
*** ls: -rw-r–r-- 1 root root 951 2018-01-03 15:51:21.801849500 +0300 /var/log/nvidia-installer.log
nvidia-installer log file ‘/var/log/nvidia-installer.log’
creation time: Wed Jan 3 15:51:04 2018
installer version: 367.27
PATH: /usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/games:/usr/local/games
nvidia-installer command line:
./nvidia-installer
Unable to load: nvidia-installer ncurses v6 user interface
Using: nvidia-installer ncurses user interface
→ Detected 56 CPUs online; setting concurrency level to 32.
→ License accepted.
→ Installing NVIDIA driver version 367.27.
→ Running distribution scripts
executing: ‘/usr/lib/nvidia/pre-install’…
→ done.
→ The distribution-provided pre-install script failed! Are you sure you want to continue? (Answer: Abort installation)
ERROR: Installation has failed. Please see the file ‘/var/log/nvidia-installer.log’ for details. You may find suggestions on fixing installation problems in the README available on the Linux driver download page at www.nvidia.com.
*** /var/log/nvidia-uninstall.log
*** ls: -rw-r–r-- 1 root root 2719 2017-12-27 10:46:08.183730802 +0300 /var/log/nvidia-uninstall.log
nvidia-installer log file ‘/var/log/nvidia-uninstall.log’
creation time: Wed Dec 27 10:46:05 2017
installer version: 375.51
PATH: /usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/snap/bin
/usr/bin/nvidia-uninstall
-s
Using built-in stream user interface
→ If you plan to no longer use the NVIDIA driver, you should make sure that no X screens are configured to use the NVIDIA X driver in your X configuration file. If you used nvidia-xconfig to configure X, it may have created a backup of your original configuration. Would you like to run nvidia-xconfig --restore-original-backup
to attempt restoration of the original X configuration file? (Answer: No)
→ Parsing log file:
→ done.
→ Validating previous installation:
→ The installed file ‘/usr/lib/x86_64-linux-gnu/libOpenCL.so.1.0.0’ seems to have changed, but prelink -u
failed; unable to restore ‘/usr/lib/x86_64-linux-gnu/libOpenCL.so.1.0.0’ to an un-prelinked state.
ERROR: File ‘/usr/lib/xorg/modules/extensions/libglx.so’ is not a symbolic link.
→ The previously installed symlink ‘/usr/lib/x86_64-linux-gnu/libcuda.so.1’ has target ‘libcuda.so.304.135’, but it was installed with target ‘libcuda.so.375.51’. /usr/lib/x86_64-linux-gnu/libcuda.so.1 will not be uninstalled.
→ The previously installed symlink ‘/usr/lib/x86_64-linux-gnu/libOpenCL.so.1’ has target ‘libOpenCL.so.1.0.0’, but it was installed with target ‘libOpenCL.so.1.0’. /usr/lib/x86_64-linux-gnu/libOpenCL.so.1 will not be uninstalled.
→ Unable to access previously installed symlink ‘/usr/lib/x86_64-linux-gnu/libOpenCL.so’ (No such file or directory).
→ done.
WARNING: Your driver installation has been altered since it was initially installed; this may happen, for example, if you have since installed the NVIDIA driver through a mechanism other than nvidia-installer (such as your distribution’s native package management system). nvidia-installer will attempt to uninstall as best it can. Please see the file ‘/var/log/nvidia-uninstall.log’ for details.
→ Uninstalling NVIDIA Accelerated Graphics Driver for Linux-x86_64 (1.0-37551 (375.51)):
→ Unable to restore symbolic link /usr/lib/x86_64-linux-gnu/mesa-egl/libEGL.so.1 → libEGL.so.1.0.0 (File exists).
→ Unable to restore symbolic link /usr/lib/x86_64-linux-gnu/mesa-egl/libGLESv2.so.2 → libGLESv2.so.2.0.0 (File exists).
→ Unable to restore symbolic link /usr/lib/x86_64-linux-gnu/mesa/libGL.so.1 → libGL.so.1.2.0 (File exists).
→ done.
→ Running depmod and ldconfig:
→ done.
→ Uninstallation of existing driver: NVIDIA Accelerated Graphics Driver for Linux-x86_64 (375.51) is complete.
journalctl -b -0 _COMM=Xorg
– No entries –
journalctl -b -1 _COMM=Xorg
journalctl -b -2 _COMM=Xorg
journalctl -b -0 _COMM=Xorg.bin
– No entries –
journalctl -b -1 _COMM=Xorg.bin
journalctl -b -2 _COMM=Xorg.bin
– No entries –
*** /var/log/Xorg.0.log
*** ls: -rw-r–r-- 1 root root 140027 2018-01-05 16:38:32.154795418 +0300 /var/log/Xorg.0.log
[ 9.900]
X.Org X Server 1.18.4
Release Date: 2016-07-19
[ 9.900] X Protocol Version 11, Revision 0
[ 9.900] Build Operating System: Linux 4.4.0-97-generic x86_64 Ubuntu
[ 9.900] Current Operating System: Linux tesla 4.4.0-104-generic #127-Ubuntu SMP Mon Dec 11 12:16:42 UTC 2017 x86_64
[ 9.900] Kernel command line: BOOT_IMAGE=/vmlinuz-4.4.0-104-generic root=/dev/mapper/ubuntu–vg-root ro
[ 9.900] Build Date: 13 October 2017 01:57:05PM
[ 9.900] xorg-server 2:1.18.4-0ubuntu0.7 (For technical support please see Enterprise open source support | Ubuntu)
[ 9.900] Current version of pixman: 0.33.6
[ 9.900] Before reporting problems, check http://wiki.x.org
to make sure that you have the latest version.
[ 9.900] Markers: (–) probed, () from config file, (==) default setting,
(++) from command line, (!!) notice, (II) informational,
(WW) warning, (EE) error, (NI) not implemented, (??) unknown.
[ 9.900] (==) Log file: “/var/log/Xorg.0.log”, Time: Thu Jan 4 15:13:16 2018
[ 9.902] (==) Using config file: “/etc/X11/xorg.conf”
[ 9.902] (==) Using system config directory “/usr/share/X11/xorg.conf.d”
[ 9.905] (==) ServerLayout “Layout0”
[ 9.905] () |–>Screen “Screen0” (0)
[ 9.905] () | |–>Monitor “Monitor0”
[ 9.905] () | |–>Device “Device0”
[ 9.905] () |–>Input Device “Keyboard0”
[ 9.905] () |–>Input Device “Mouse0”
[ 9.905] (==) Automatically adding devices
[ 9.905] (==) Automatically enabling devices
[ 9.905] (==) Automatically adding GPU devices
[ 9.905] (==) Max clients allowed: 256, resource mask: 0x1fffff
[ 9.914] (WW) The directory “/usr/share/fonts/X11/cyrillic” does not exist.
[ 9.914] Entry deleted from font path.
[ 9.914] (WW) The directory “/usr/share/fonts/X11/100dpi/” does not exist.
[ 9.914] (WW) The directory “/usr/share/fonts/X11/75dpi/” does not exist.
[ 9.916] (WW) The directory “/usr/share/fonts/X11/100dpi” does not exist.
[ 9.916] Entry deleted from font path.
[ 9.916] (WW) The directory “/usr/share/fonts/X11/75dpi” does not exist.
[ 9.916] (==) FontPath set to:
/usr/share/fonts/X11/misc,
/usr/share/fonts/X11/Type1,
built-ins
[ 9.916] (==) ModulePath set to “/usr/lib/x86_64-linux-gnu/xorg/extra-modules,/usr/lib/xorg/extra-modules,/usr/lib/xorg/modules”
[ 9.916] (WW) Hotplugging is on, devices using drivers ‘kbd’, ‘mouse’ or ‘vmmouse’ will be disabled.
[ 9.916] (WW) Disabling Keyboard0
[ 9.916] (WW) Disabling Mouse0
[ 9.916] (II) Loader magic: 0x5601a90a2dc0
[ 9.916] (II) Module ABI versions:
[ 9.916] X.Org ANSI C Emulation: 0.4
[ 9.916] X.Org Video Driver: 20.0
[ 9.916] X.Org XInput driver : 22.1
[ 9.916] X.Org Server Extension : 9.0
[ 9.916] (++) using VT number 7
[ 9.916] (II) systemd-logind: logind integration requires -keeptty and -keeptty was not provided, disabling logind integration
[ 9.916] (II) xfree86: Adding drm device (/dev/dri/card0)
[ 9.916] (II) xfree86: Adding drm device (/dev/dri/card1)
[ 9.921] (–) PCI:*(0:3:0:0) 10de:1b81:1043:85a0 rev 161, Mem @ 0xc6000000/16777216, 0xb0000000/268435456, 0xc0000000/33554432, I/O @ 0x00006000/128, BIOS @ 0x???/524288
[ 9.921] (–) PCI: (0:129:0:0) 10de:1024:10de:0983 rev 161, Mem @ 0xfa000000/16777216, 0xe0000000/268435456, 0xf0000000/33554432
[ 9.921] (WW) “glamoregl” will not be loaded unless you’ve specified it to be loaded elsewhere.
[ 9.921] (II) “glx” will be loaded by default.
[ 9.921] (II) LoadModule: “glx”
[ 9.922] (II) Loading /usr/lib/x86_64-linux-gnu/xorg/extra-modules/libglx.so
[ 9.972] (II) Module glx: vendor=“NVIDIA Corporation”
[ 9.972] compiled for 4.0.2, module version = 1.0.0
[ 9.972] Module class: X.Org Server Extension
[ 9.973] (II) NVIDIA GLX Module 387.34 Tue Nov 21 02:04:31 PST 2017
[ 9.973] (II) LoadModule: “nvidia”
[ 9.973] (II) Loading /usr/lib/x86_64-linux-gnu/xorg/extra-modules/nvidia_drv.so
[ 9.980] (II) Module nvidia: vendor=“NVIDIA Corporation”
[ 9.980] compiled for 4.0.2, module version = 1.0.0
[ 9.980] Module class: X.Org Video Driver
[ 9.981] (II) NVIDIA dlloader X Driver 387.34 Tue Nov 21 01:38:22 PST 2017
[ 9.981] (II) NVIDIA Unified Driver for all Supported NVIDIA GPUs
[ 9.983] (II) Loading sub module “fb”
[ 9.983] (II) LoadModule: “fb”
[ 9.983] (II) Loading /usr/lib/xorg/modules/libfb.so
[ 9.984] (II) Module fb: vendor=“X.Org Foundation”
[ 9.984] compiled for 1.18.4, module version = 1.0.0
[ 9.984] ABI class: X.Org ANSI C Emulation, version 0.4
[ 9.984] (II) Loading sub module “wfb”
[ 9.984] (II) LoadModule: “wfb”
[ 9.984] (II) Loading /usr/lib/xorg/modules/libwfb.so
[ 9.985] (II) Module wfb: vendor=“X.Org Foundation”
[ 9.985] compiled for 1.18.4, module version = 1.0.0
[ 9.985] ABI class: X.Org ANSI C Emulation, version 0.4
[ 9.985] (II) Loading sub module “ramdac”
[ 9.985] (II) LoadModule: “ramdac”
[ 9.985] (II) Module “ramdac” already built-in
[ 12.216] () NVIDIA(0): Depth 24, (–) framebuffer bpp 32
[ 12.216] (==) NVIDIA(0): RGB weight 888
[ 12.216] (==) NVIDIA(0): Default visual is TrueColor
[ 12.216] (==) NVIDIA(0): Using gamma correction (1.0, 1.0, 1.0)
[ 12.216] () NVIDIA(0): Enabling 2D acceleration
[ 12.432] (–) NVIDIA(0): Valid display device(s) on GPU-0 at PCI:3:0:0
[ 12.432] (–) NVIDIA(0): DFP-0
[ 12.432] (–) NVIDIA(0): DFP-1
[ 12.432] (–) NVIDIA(0): DFP-2
[ 12.432] (–) NVIDIA(0): DFP-3
[ 12.432] (–) NVIDIA(0): DFP-4
[ 12.432] (–) NVIDIA(0): DFP-5 (boot)
[ 12.432] (–) NVIDIA(0): DFP-6
[ 12.433] (II) NVIDIA(0): NVIDIA GPU GeForce GTX 1070 (GP104-A) at PCI:3:0:0 (GPU-0)
[ 12.433] (–) NVIDIA(0): Memory: 8388608 kBytes
[ 12.433] (–) NVIDIA(0): VideoBIOS: 86.04.26.00.80
[ 12.433] (II) NVIDIA(0): Detected PCI Express Link width: 16X
[ 12.433] (–) NVIDIA(GPU-0): DFP-0: disconnected
[ 12.433] (–) NVIDIA(GPU-0): DFP-0: Internal TMDS
[ 12.433] (–) NVIDIA(GPU-0): DFP-0: 330.0 MHz maximum pixel clock
[ 12.433] (–) NVIDIA(GPU-0): DFP-1: disconnected
[ 12.433] (–) NVIDIA(GPU-0): DFP-1: Internal TMDS
[ 12.433] (–) NVIDIA(GPU-0): DFP-1: 165.0 MHz maximum pixel clock
[ 12.433] (–) NVIDIA(GPU-0): DFP-2: disconnected
[ 12.433] (–) NVIDIA(GPU-0): DFP-2: Internal TMDS
[ 12.433] (–) NVIDIA(GPU-0): DFP-2: 165.0 MHz maximum pixel clock
[ 12.433] (–) NVIDIA(GPU-0): DFP-3: disconnected
[ 12.433] (–) NVIDIA(GPU-0): DFP-3: Internal DisplayPort
[ 12.433] (–) NVIDIA(GPU-0): DFP-3: 1440.0 MHz maximum pixel clock
[ 12.433] (–) NVIDIA(GPU-0): DFP-4: disconnected
[ 12.433] (–) NVIDIA(GPU-0): DFP-4: Internal TMDS
[ 12.433] (–) NVIDIA(GPU-0): DFP-4: 165.0 MHz maximum pixel clock
[ 12.434] (–) NVIDIA(GPU-0): DELL U2414H (DFP-5): connected
[ 12.434] (–) NVIDIA(GPU-0): DELL U2414H (DFP-5): Internal DisplayPort
[ 12.434] (–) NVIDIA(GPU-0): DELL U2414H (DFP-5): 1440.0 MHz maximum pixel clock
[ 12.434] (–) NVIDIA(GPU-0): DFP-6: disconnected
[ 12.434] (–) NVIDIA(GPU-0): DFP-6: Internal TMDS
[ 12.434] (–) NVIDIA(GPU-0): DFP-6: 165.0 MHz maximum pixel clock
[ 12.436] (==) NVIDIA(0):
[ 12.437] (==) NVIDIA(0): No modes were requested; the default mode “nvidia-auto-select”
[ 12.437] (==) NVIDIA(0): will be used as the requested mode.
[ 12.437] (II) NVIDIA(0): Validated MetaModes:
[ 12.437] (II) NVIDIA(0): “DFP-5:nvidia-auto-select”
[ 12.437] (II) NVIDIA(0): Virtual screen size determined to be 1920 x 1080
[ 12.447] (–) NVIDIA(0): DPI set to (92, 91); computed from “UseEdidDpi” X config
[ 12.447] (–) NVIDIA(0): option
[ 12.447] (–) Depth 24 pixmap format is 32 bpp
[ 14.656] (II) NVIDIA(GPU-1): NVIDIA GPU Tesla K40c (GK110B) at PCI:129:0:0 (GPU-1)
[ 14.656] (–) NVIDIA(GPU-1): Memory: 11796480 kBytes
[ 14.656] (–) NVIDIA(GPU-1): VideoBIOS: 80.80.3e.00.02
[ 14.656] (II) NVIDIA(GPU-1): Detected PCI Express Link width: 16X
[ 14.659] (II) NVIDIA: Using 24576.00 MB of virtual memory for indirect memory
[ 14.659] (II) NVIDIA: access.
[ 14.694] (II) NVIDIA(0): Setting mode “DFP-5:nvidia-auto-select”
[ 14.796] (==) NVIDIA(0): Disabling shared memory pixmaps
[ 14.796] (==) NVIDIA(0): Backing store enabled
[ 14.796] (==) NVIDIA(0): Silken mouse enabled
[ 14.797] () NVIDIA(0): DPMS enabled
[ 14.797] (II) Loading sub module “dri2”
[ 14.797] (II) LoadModule: “dri2”
[ 14.797] (II) Module “dri2” already built-in
[ 14.797] (II) NVIDIA(0): [DRI2] Setup complete
[ 14.797] (II) NVIDIA(0): [DRI2] VDPAU driver: nvidia
[ 14.797] (–) RandR disabled
[ 14.801] (II) SELinux: Disabled on system
[ 14.801] (II) Initializing extension GLX
[ 14.801] (II) Indirect GLX disabled.
[ 14.865] (II) config/udev: Adding input device Power Button (/dev/input/event1)
[ 14.865] () Power Button: Applying InputClass “evdev keyboard catchall”
[ 14.865] (II) LoadModule: “evdev”
[ 14.865] (II) Loading /usr/lib/xorg/modules/input/evdev_drv.so
[ 14.867] (II) Module evdev: vendor=“X.Org Foundation”
[ 14.867] compiled for 1.18.1, module version = 2.10.1
[ 14.867] Module class: X.Org XInput Driver
[ 14.867] ABI class: X.Org XInput driver, version 22.1
[ 14.867] (II) Using input driver ‘evdev’ for ‘Power Button’
[ 14.867] () Power Button: always reports core events
[ 14.867] () evdev: Power Button: Device: “/dev/input/event1”
[ 14.867] (–) evdev: Power Button: Vendor 0 Product 0x1
[ 14.867] (–) evdev: Power Button: Found keys
[ 14.867] (II) evdev: Power Button: Configuring as keyboard
[ 14.867] () Option “config_info” “udev:/sys/devices/LNXSYSTM:00/LNXPWRBN:00/input/input1/event1”
[ 14.867] (II) XINPUT: Adding extended input device “Power Button” (type: KEYBOARD, id 6)
[ 14.867] () Option “xkb_rules” “evdev”
[ 14.867] () Option “xkb_model” “pc105”
[ 14.867] () Option “xkb_layout” “tr”
[ 14.879] (II) config/udev: Adding input device Power Button (/dev/input/event0)
[ 14.879] () Power Button: Applying InputClass “evdev keyboard catchall”
[ 14.879] (II) Using input driver ‘evdev’ for ‘Power Button’
[ 14.879] () Power Button: always reports core events
[ 14.879] () evdev: Power Button: Device: “/dev/input/event0”
[ 14.879] (–) evdev: Power Button: Vendor 0 Product 0x1
[ 14.879] (–) evdev: Power Button: Found keys
[ 14.879] (II) evdev: Power Button: Configuring as keyboard
[ 14.879] () Option “config_info” “udev:/sys/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0C:00/input/input0/event0”
[ 14.879] (II) XINPUT: Adding extended input device “Power Button” (type: KEYBOARD, id 7)
[ 14.879] () Option “xkb_rules” “evdev”
[ 14.879] () Option “xkb_model” “pc105”
[ 14.879] () Option “xkb_layout” “tr”
[ 14.880] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=3 (/dev/input/event14)
[ 14.880] (II) No input driver specified, ignoring this device.
[ 14.880] (II) This device may have been added with another device file.
[ 14.880] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=7 (/dev/input/event15)
[ 14.880] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=8 (/dev/input/event16)
[ 14.880] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=9 (/dev/input/event17)
[ 14.881] (II) config/udev: Adding input device Microsoft Microsoft® 2.4GHz Transceiver v7.0 (/dev/input/event2)
[ 14.881] () Microsoft Microsoft® 2.4GHz Transceiver v7.0: Applying InputClass “evdev keyboard catchall”
[ 14.881] (II) Using input driver ‘evdev’ for ‘Microsoft Microsoft® 2.4GHz Transceiver v7.0’
[ 14.881] () Microsoft Microsoft® 2.4GHz Transceiver v7.0: always reports core events
[ 14.881] () evdev: Microsoft Microsoft® 2.4GHz Transceiver v7.0: Device: “/dev/input/event2”
[ 14.881] (–) evdev: Microsoft Microsoft® 2.4GHz Transceiver v7.0: Vendor 0x45e Product 0x7b2
[ 14.881] (–) evdev: Microsoft Microsoft® 2.4GHz Transceiver v7.0: Found keys
[ 14.881] (II) evdev: Microsoft Microsoft® 2.4GHz Transceiver v7.0: Configuring as keyboard
[ 14.881] () Option “config_info” “udev:/sys/devices/pci0000:00/0000:00:14.0/usb3/3-9/3-9.1/3-9.1:1.0/0003:045E:07B2.0001/input/input5/event2”
[ 14.881] (II) XINPUT: Adding extended input device “Microsoft Microsoft® 2.4GHz Transceiver v7.0” (type: KEYBOARD, id 8)
[ 14.881] () Option “xkb_rules” “evdev”
[ 14.881] () Option “xkb_model” “pc105”
[ 14.881] () Option “xkb_layout” “tr”
[ 14.881] (II) config/udev: Adding input device Microsoft Microsoft® 2.4GHz Transceiver v7.0 (/dev/input/event3)
[ 14.881] () Microsoft Microsoft® 2.4GHz Transceiver v7.0: Applying InputClass “evdev pointer catchall”
[ 14.881] () evdev: Microsoft Microsoft® 2.4GHz Transceiver v7.0: Device: “/dev/input/event3”
[ 14.936] (–) evdev: Microsoft Microsoft® 2.4GHz Transceiver v7.0: Vendor 0x45e Product 0x7b2
[ 14.936] (–) evdev: Microsoft Microsoft® 2.4GHz Transceiver v7.0: Found 9 mouse buttons
[ 14.936] (–) evdev: Microsoft Microsoft® 2.4GHz Transceiver v7.0: Found scroll wheel(s)
[ 14.936] (–) evdev: Microsoft Microsoft® 2.4GHz Transceiver v7.0: Found relative axes
[ 14.936] (–) evdev: Microsoft Microsoft® 2.4GHz Transceiver v7.0: Found x and y relative axes
[ 14.936] (II) evdev: Microsoft Microsoft® 2.4GHz Transceiver v7.0: Configuring as mouse
[ 14.936] (II) evdev: Microsoft Microsoft® 2.4GHz Transceiver v7.0: Adding scrollwheel support
[ 14.936] () evdev: Microsoft Microsoft® 2.4GHz Transceiver v7.0: YAxisMapping: buttons 4 and 5
[ 14.936] () evdev: Microsoft Microsoft® 2.4GHz Transceiver v7.0: EmulateWheelButton: 4, EmulateWheelInertia: 10, EmulateWheelTimeout: 200
[ 14.936] () Option “config_info” “udev:/sys/devices/pci0000:00/0000:00:14.0/usb3/3-9/3-9.1/3-9.1:1.1/0003:045E:07B2.0002/input/input6/event3”
[ 14.936] (II) XINPUT: Adding extended input device “Microsoft Microsoft® 2.4GHz Transceiver v7.0” (type: MOUSE, id 9)
[ 14.936] (II) evdev: Microsoft Microsoft® 2.4GHz Transceiver v7.0: initialized for relative axes.
[ 14.936] () Microsoft Microsoft® 2.4GHz Transceiver v7.0: (accel) keeping acceleration scheme 1
[ 14.936] () Microsoft Microsoft® 2.4GHz Transceiver v7.0: (accel) acceleration profile 0
[ 14.936] () Microsoft Microsoft® 2.4GHz Transceiver v7.0: (accel) acceleration factor: 2.000
[ 14.936] () Microsoft Microsoft® 2.4GHz Transceiver v7.0: (accel) acceleration threshold: 4
[ 14.936] (II) config/udev: Adding input device Microsoft Microsoft® 2.4GHz Transceiver v7.0 (/dev/input/mouse0)
[ 14.936] (II) No input driver specified, ignoring this device.
[ 14.936] (II) This device may have been added with another device file.
[ 14.937] (II) config/udev: Adding input device Microsoft Microsoft® 2.4GHz Transceiver v7.0 (/dev/input/event4)
[ 14.937] () Microsoft Microsoft® 2.4GHz Transceiver v7.0: Applying InputClass “evdev keyboard catchall”
[ 14.937] (II) Using input driver ‘evdev’ for ‘Microsoft Microsoft® 2.4GHz Transceiver v7.0’
[ 14.937] () Microsoft Microsoft® 2.4GHz Transceiver v7.0: always reports core events
[ 14.937] () evdev: Microsoft Microsoft® 2.4GHz Transceiver v7.0: Device: “/dev/input/event4”
[ 14.937] (–) evdev: Microsoft Microsoft® 2.4GHz Transceiver v7.0: Vendor 0x45e Product 0x7b2
[ 14.937] (–) evdev: Microsoft Microsoft® 2.4GHz Transceiver v7.0: Found 1 mouse buttons
[ 14.937] (–) evdev: Microsoft Microsoft® 2.4GHz Transceiver v7.0: Found scroll wheel(s)
[ 14.937] (–) evdev: Microsoft Microsoft® 2.4GHz Transceiver v7.0: Found relative axes
[ 14.937] (–) evdev: Microsoft Microsoft® 2.4GHz Transceiver v7.0: Found absolute axes
[ 14.937] (–) evdev: Microsoft Microsoft® 2.4GHz Transceiver v7.0: Found absolute multitouch axes
[ 14.937] (–) evdev: Microsoft Microsoft® 2.4GHz Transceiver v7.0: Fake MT device detected
[ 14.937] (–) evdev: Microsoft Microsoft® 2.4GHz Transceiver v7.0: Found x and y absolute axes
[ 14.937] (–) evdev: Microsoft Microsoft® 2.4GHz Transceiver v7.0: Found keys
[ 14.937] (II) evdev: Microsoft Microsoft® 2.4GHz Transceiver v7.0: Forcing relative x/y axes to exist.
[ 14.937] (II) evdev: Microsoft Microsoft® 2.4GHz Transceiver v7.0: Configuring as mouse
[ 14.937] (II) evdev: Microsoft Microsoft® 2.4GHz Transceiver v7.0: Configuring as keyboard
[ 14.937] (II) evdev: Microsoft Microsoft® 2.4GHz Transceiver v7.0: Adding scrollwheel support
[ 14.937] () evdev: Microsoft Microsoft® 2.4GHz Transceiver v7.0: YAxisMapping: buttons 4 and 5
[ 14.937] () evdev: Microsoft Microsoft® 2.4GHz Transceiver v7.0: EmulateWheelButton: 4, EmulateWheelInertia: 10, EmulateWheelTimeout: 200
[ 14.937] () Option “config_info” “udev:/sys/devices/pci0000:00/0000:00:14.0/usb3/3-9/3-9.1/3-9.1:1.2/0003:045E:07B2.0003/input/input7/event4”
[ 14.937] (II) XINPUT: Adding extended input device “Microsoft Microsoft® 2.4GHz Transceiver v7.0” (type: KEYBOARD, id 10)
[ 14.937] () Option “xkb_rules” “evdev”
[ 14.937] () Option “xkb_model” “pc105”
[ 14.937] () Option “xkb_layout” “tr”
[ 14.937] (II) evdev: Microsoft Microsoft® 2.4GHz Transceiver v7.0: initialized for relative axes.
[ 14.937] (WW) evdev: Microsoft Microsoft® 2.4GHz Transceiver v7.0: ignoring absolute axes.
[ 14.937] () Microsoft Microsoft® 2.4GHz Transceiver v7.0: (accel) keeping acceleration scheme 1
[ 14.937] () Microsoft Microsoft® 2.4GHz Transceiver v7.0: (accel) acceleration profile 0
[ 14.937] () Microsoft Microsoft® 2.4GHz Transceiver v7.0: (accel) acceleration factor: 2.000
[ 14.937] () Microsoft Microsoft® 2.4GHz Transceiver v7.0: (accel) acceleration threshold: 4
[ 14.937] (II) config/udev: Adding input device Microsoft Microsoft® 2.4GHz Transceiver v7.0 (/dev/input/js0)
[ 14.937] (II) No input driver specified, ignoring this device.
[ 14.937] (II) This device may have been added with another device file.
[ 14.938] (II) config/udev: Adding input device HDA Intel PCH Rear Mic (/dev/input/event7)
[ 14.938] (II) No input driver specified, ignoring this device.
[ 14.938] (II) This device may have been added with another device file.
[ 14.938] (II) config/udev: Adding input device HDA Intel PCH Line (/dev/input/event8)
[ 14.938] (II) config/udev: Adding input device HDA Intel PCH Line Out Front (/dev/input/event9)
[ 14.938] (II) config/udev: Adding input device HDA Intel PCH Line Out Surround (/dev/input/event10)
[ 14.938] (II) config/udev: Adding input device HDA Intel PCH Line Out CLFE (/dev/input/event11)
[ 14.939] (II) config/udev: Adding input device HDA Intel PCH Line Out Side (/dev/input/event12)
[ 14.939] (II) No input driver specified, ignoring this device.
[ 14.939] (II) This device may have been added with another device file.
[ 14.939] (II) config/udev: Adding input device HDA Intel PCH Front Headphone (/dev/input/event13)
[ 14.939] (II) config/udev: Adding input device HDA Intel PCH Front Mic (/dev/input/event6)
[ 14.939] (II) config/udev: Adding input device Eee PC WMI hotkeys (/dev/input/event5)
[ 14.939] () Eee PC WMI hotkeys: Applying InputClass “evdev keyboard catchall”
[ 14.939] (II) Using input driver ‘evdev’ for ‘Eee PC WMI hotkeys’
[ 14.939] () Eee PC WMI hotkeys: always reports core events
[ 14.939] () evdev: Eee PC WMI hotkeys: Device: “/dev/input/event5”
[ 14.939] (–) evdev: Eee PC WMI hotkeys: Vendor 0 Product 0
[ 14.939] (–) evdev: Eee PC WMI hotkeys: Found keys
[ 14.939] (II) evdev: Eee PC WMI hotkeys: Configuring as keyboard
[ 14.939] () Option “config_info” “udev:/sys/devices/platform/eeepc-wmi/input/input8/event5”
[ 14.939] (II) XINPUT: Adding extended input device “Eee PC WMI hotkeys” (type: KEYBOARD, id 11)
[ 14.939] () Option “xkb_rules” “evdev”
[ 14.939] () Option “xkb_model” “pc105”
[ 14.939] () Option “xkb_layout” “tr”
[ 14.942] (–) NVIDIA(GPU-0): DELL U2414H (DFP-5): connected
[ 14.942] (–) NVIDIA(GPU-0): DELL U2414H (DFP-5): Internal DisplayPort
[ 14.942] (–) NVIDIA(GPU-0): DELL U2414H (DFP-5): 1440.0 MHz maximum pixel clock
[ 14.944] (II) config/udev: Adding input device Microsoft Microsoft® 2.4GHz Transceiver v7.0 (/dev/input/mouse0)
[ 14.944] (II) No input driver specified, ignoring this device.
[ 14.944] (II) This device may have been added with another device file.
[ 14.944] (II) config/udev: Adding input device Microsoft Microsoft® 2.4GHz Transceiver v7.0 (/dev/input/js0)
[ 14.945] (II) config/udev: removing device Power Button
[ 14.960] (II) evdev: Power Button: Close
[ 14.960] (II) UnloadModule: “evdev”
[ 14.960] (II) config/udev: Adding input device Power Button (/dev/input/event1)
[ 14.960] () Power Button: Applying InputClass “evdev keyboard catchall”
[ 14.960] (II) Using input driver ‘evdev’ for ‘Power Button’
[ 14.960] () Power Button: always reports core events
[ 14.960] () evdev: Power Button: Device: “/dev/input/event1”
[ 14.960] (–) evdev: Power Button: Vendor 0 Product 0x1
[ 14.960] (–) evdev: Power Button: Found keys
[ 14.960] (II) evdev: Power Button: Configuring as keyboard
[ 14.960] () Option “config_info” “udev:/sys/devices/LNXSYSTM:00/LNXPWRBN:00/input/input1/event1”
[ 14.960] (II) XINPUT: Adding extended input device “Power Button” (type: KEYBOARD, id 6)
[ 14.960] () Option “xkb_rules” “evdev”
[ 14.960] () Option “xkb_model” “pc105”
[ 14.960] () Option “xkb_layout” “tr”
[ 14.960] (WW) Option “xkb_variant” requires a string value
[ 14.960] (WW) Option “xkb_options” requires a string value
[ 14.960] (II) config/udev: Adding input device HDA Intel PCH Line Out Surround (/dev/input/event10)
[ 14.960] (II) No input driver specified, ignoring this device.
[ 14.960] (II) This device may have been added with another device file.
[ 14.960] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=7 (/dev/input/event15)
[ 14.961] (II) config/udev: Adding input device HDA Intel PCH Rear Mic (/dev/input/event7)
[ 14.961] (II) No input driver specified, ignoring this device.
[ 14.961] (II) This device may have been added with another device file.
[ 14.961] (II) config/udev: Adding input device HDA Intel PCH Line Out CLFE (/dev/input/event11)
[ 14.961] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=3 (/dev/input/event14)
[ 14.961] (II) config/udev: removing device Power Button
[ 14.976] (II) evdev: Power Button: Close
[ 14.976] (II) UnloadModule: “evdev”
[ 14.976] (II) config/udev: Adding input device Power Button (/dev/input/event0)
[ 14.976] () Power Button: Applying InputClass “evdev keyboard catchall”
[ 14.976] (II) Using input driver ‘evdev’ for ‘Power Button’
[ 14.976] () Power Button: always reports core events
[ 14.976] () evdev: Power Button: Device: “/dev/input/event0”
[ 14.976] (–) evdev: Power Button: Vendor 0 Product 0x1
[ 14.976] (–) evdev: Power Button: Found keys
[ 14.976] (II) evdev: Power Button: Configuring as keyboard
[ 14.976] () Option “config_info” “udev:/sys/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0C:00/input/input0/event0”
[ 14.976] (II) XINPUT: Adding extended input device “Power Button” (type: KEYBOARD, id 7)
[ 14.976] () Option “xkb_rules” “evdev”
[ 14.976] () Option “xkb_model” “pc105”
[ 14.976] () Option “xkb_layout” “tr”
[ 14.976] (WW) Option “xkb_variant” requires a string value
[ 14.976] (WW) Option “xkb_options” requires a string value
[ 14.976] (II) config/udev: removing device Microsoft Microsoft® 2.4GHz Transceiver v7.0
[ 14.996] (II) evdev: Microsoft Microsoft® 2.4GHz Transceiver v7.0: Close
[ 14.996] (II) UnloadModule: “evdev”
[ 14.996] (II) config/udev: Adding input device Microsoft Microsoft® 2.4GHz Transceiver v7.0 (/dev/input/event4)
[ 14.996] () Microsoft Microsoft® 2.4GHz Transceiver v7.0: Applying InputClass “evdev keyboard catchall”
[ 14.996] (II) Using input driver ‘evdev’ for ‘Microsoft Microsoft® 2.4GHz Transceiver v7.0’
[ 14.996] () Microsoft Microsoft® 2.4GHz Transceiver v7.0: always reports core events
[ 14.996] () evdev: Microsoft Microsoft® 2.4GHz Transceiver v7.0: Device: “/dev/input/event4”
[ 14.996] (–) evdev: Microsoft Microsoft® 2.4GHz Transceiver v7.0: Vendor 0x45e Product 0x7b2
[ 14.996] (–) evdev: Microsoft Microsoft® 2.4GHz Transceiver v7.0: Found 1 mouse buttons
[ 14.996] (–) evdev: Microsoft Microsoft® 2.4GHz Transceiver v7.0: Found scroll wheel(s)
[ 14.996] (–) evdev: Microsoft Microsoft® 2.4GHz Transceiver v7.0: Found relative axes
[ 14.996] (–) evdev: Microsoft Microsoft® 2.4GHz Transceiver v7.0: Found absolute axes
[ 14.996] (–) evdev: Microsoft Microsoft® 2.4GHz Transceiver v7.0: Found absolute multitouch axes
[ 14.996] (–) evdev: Microsoft Microsoft® 2.4GHz Transceiver v7.0: Fake MT device detected
[ 14.996] (–) evdev: Microsoft Microsoft® 2.4GHz Transceiver v7.0: Found x and y absolute axes
[ 14.996] (–) evdev: Microsoft Microsoft® 2.4GHz Transceiver v7.0: Found keys
[ 14.996] (II) evdev: Microsoft Microsoft® 2.4GHz Transceiver v7.0: Forcing relative x/y axes to exist.
[ 14.996] (II) evdev: Microsoft Microsoft® 2.4GHz Transceiver v7.0: Configuring as mouse
[ 14.996] (II) evdev: Microsoft Microsoft® 2.4GHz Transceiver v7.0: Configuring as keyboard
[ 14.996] (II) evdev: Microsoft Microsoft® 2.4GHz Transceiver v7.0: Adding scrollwheel support
[ 14.996] () evdev: Microsoft Microsoft® 2.4GHz Transceiver v7.0: YAxisMapping: buttons 4 and 5
[ 14.996] () evdev: Microsoft Microsoft® 2.4GHz Transceiver v7.0: EmulateWheelButton: 4, EmulateWheelInertia: 10, EmulateWheelTimeout: 200
[ 14.996] () Option “config_info” “udev:/sys/devices/pci0000:00/0000:00:14.0/usb3/3-9/3-9.1/3-9.1:1.2/0003:045E:07B2.0003/input/input7/event4”
[ 14.996] (II) XINPUT: Adding extended input device “Microsoft Microsoft® 2.4GHz Transceiver v7.0” (type: KEYBOARD, id 10)
[ 14.996] () Option “xkb_rules” “evdev”
[ 14.996] () Option “xkb_model” “pc105”
[ 14.996] () Option “xkb_layout” “tr”
[ 14.996] (WW) Option “xkb_variant” requires a string value
[ 14.996] (WW) Option “xkb_options” requires a string value
[ 14.996] (II) evdev: Microsoft Microsoft® 2.4GHz Transceiver v7.0: initialized for relative axes.
[ 14.996] (WW) evdev: Microsoft Microsoft® 2.4GHz Transceiver v7.0: ignoring absolute axes.
[ 14.996] () Microsoft Microsoft® 2.4GHz Transceiver v7.0: (accel) keeping acceleration scheme 1
[ 14.996] () Microsoft Microsoft® 2.4GHz Transceiver v7.0: (accel) acceleration profile 0
[ 14.996] () Microsoft Microsoft® 2.4GHz Transceiver v7.0: (accel) acceleration factor: 2.000
[ 14.996] () Microsoft Microsoft® 2.4GHz Transceiver v7.0: (accel) acceleration threshold: 4
[ 14.996] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=8 (/dev/input/event16)
[ 14.997] (II) No input driver specified, ignoring this device.
[ 14.997] (II) This device may have been added with another device file.
[ 14.997] (II) config/udev: Adding input device HDA Intel PCH Line Out Front (/dev/input/event9)
[ 14.997] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=9 (/dev/input/event17)
[ 14.997] (II) config/udev: removing device Microsoft Microsoft® 2.4GHz Transceiver v7.0
[ 15.012] (II) evdev: Microsoft Microsoft® 2.4GHz Transceiver v7.0: Close
[ 15.012] (II) UnloadModule: “evdev”
[ 15.012] (II) config/udev: Adding input device Microsoft Microsoft® 2.4GHz Transceiver v7.0 (/dev/input/event2)
[ 15.012] () Microsoft Microsoft® 2.4GHz Transceiver v7.0: Applying InputClass “evdev keyboard catchall”
[ 15.012] (II) Using input driver ‘evdev’ for ‘Microsoft Microsoft® 2.4GHz Transceiver v7.0’
[ 15.012] () Microsoft Microsoft® 2.4GHz Transceiver v7.0: always reports core events
[ 15.012] () evdev: Microsoft Microsoft® 2.4GHz Transceiver v7.0: Device: “/dev/input/event2”
[ 15.012] (–) evdev: Microsoft Microsoft® 2.4GHz Transceiver v7.0: Vendor 0x45e Product 0x7b2
[ 15.012] (–) evdev: Microsoft Microsoft® 2.4GHz Transceiver v7.0: Found keys
[ 15.012] (II) evdev: Microsoft Microsoft® 2.4GHz Transceiver v7.0: Configuring as keyboard
[ 15.012] () Option “config_info” “udev:/sys/devices/pci0000:00/0000:00:14.0/usb3/3-9/3-9.1/3-9.1:1.0/0003:045E:07B2.0001/input/input5/event2”
[ 15.012] (II) XINPUT: Adding extended input device “Microsoft Microsoft® 2.4GHz Transceiver v7.0” (type: KEYBOARD, id 8)
[ 15.012] () Option “xkb_rules” “evdev”
[ 15.012] () Option “xkb_model” “pc105”
[ 15.012] () Option “xkb_layout” “tr”
[ 15.012] (WW) Option “xkb_variant” requires a string value
[ 15.012] (WW) Option “xkb_options” requires a string value
[ 15.013] (II) config/udev: Adding input device HDA Intel PCH Front Mic (/dev/input/event6)
[ 15.013] (II) No input driver specified, ignoring this device.
[ 15.013] (II) This device may have been added with another device file.
[ 15.013] (II) config/udev: Adding input device HDA Intel PCH Front Headphone (/dev/input/event13)
[ 15.013] (II) config/udev: Adding input device HDA Intel PCH Line (/dev/input/event8)
[ 15.013] (II) config/udev: Adding input device HDA Intel PCH Line Out Side (/dev/input/event12)
[ 15.013] (II) config/udev: removing device Eee PC WMI hotkeys
[ 15.052] (II) evdev: Eee PC WMI hotkeys: Close
[ 15.052] (II) UnloadModule: “evdev”
[ 15.052] (II) config/udev: Adding input device Eee PC WMI hotkeys (/dev/input/event5)
[ 15.052] () Eee PC WMI hotkeys: Applying InputClass “evdev keyboard catchall”
[ 15.052] (II) Using input driver ‘evdev’ for ‘Eee PC WMI hotkeys’
[ 15.052] () Eee PC WMI hotkeys: always reports core events
[ 15.052] () evdev: Eee PC WMI hotkeys: Device: “/dev/input/event5”
[ 15.052] (–) evdev: Eee PC WMI hotkeys: Vendor 0 Product 0
[ 15.052] (–) evdev: Eee PC WMI hotkeys: Found keys
[ 15.052] (II) evdev: Eee PC WMI hotkeys: Configuring as keyboard
[ 15.052] () Option “config_info” “udev:/sys/devices/platform/eeepc-wmi/input/input8/event5”
[ 15.052] (II) XINPUT: Adding extended input device “Eee PC WMI hotkeys” (type: KEYBOARD, id 11)
[ 15.052] () Option “xkb_rules” “evdev”
[ 15.052] () Option “xkb_model” “pc105”
[ 15.052] () Option “xkb_layout” “tr”
[ 15.052] (WW) Option “xkb_variant” requires a string value
[ 15.052] (WW) Option “xkb_options” requires a string value
[ 15.052] (II) config/udev: removing device Microsoft Microsoft® 2.4GHz Transceiver v7.0
[ 15.084] (II) evdev: Microsoft Microsoft® 2.4GHz Transceiver v7.0: Close
[ 15.084] (II) UnloadModule: “evdev”
[ 15.084] (II) config/udev: Adding input device Microsoft Microsoft® 2.4GHz Transceiver v7.0 (/dev/input/event3)
[ 15.084] () Microsoft Microsoft® 2.4GHz Transceiver v7.0: Applying InputClass “evdev pointer catchall”
[ 15.084] (II) Using input driver ‘evdev’ for ‘Microsoft Microsoft® 2.4GHz Transceiver v7.0’
[ 15.084] () Microsoft Microsoft® 2.4GHz Transceiver v7.0: always reports core events
[ 15.084] () evdev: Microsoft Microsoft® 2.4GHz Transceiver v7.0: Device: “/dev/input/event3”
[ 15.140] (–) evdev: Microsoft Microsoft® 2.4GHz Transceiver v7.0: Vendor 0x45e Product 0x7b2
[ 15.140] (–) evdev: Microsoft Microsoft® 2.4GHz Transceiver v7.0: Found 9 mouse buttons
[ 15.140] (–) evdev: Microsoft Microsoft® 2.4GHz Transceiver v7.0: Found scroll wheel(s)
[ 15.140] (–) evdev: Microsoft Microsoft® 2.4GHz Transceiver v7.0: Found relative axes
[ 15.140] (–) evdev: Microsoft Microsoft® 2.4GHz Transceiver v7.0: Found x and y relative axes
[ 15.140] (II) evdev: Microsoft Microsoft® 2.4GHz Transceiver v7.0: Configuring as mouse
[ 15.140] (II) evdev: Microsoft Microsoft® 2.4GHz Transceiver v7.0: Adding scrollwheel support
[ 15.140] () evdev: Microsoft Microsoft® 2.4GHz Transceiver v7.0: YAxisMapping: buttons 4 and 5
[ 15.140] () evdev: Microsoft Microsoft® 2.4GHz Transceiver v7.0: EmulateWheelButton: 4, EmulateWheelInertia: 10, EmulateWheelTimeout: 200
[ 15.140] () Option “config_info” “udev:/sys/devices/pci0000:00/0000:00:14.0/usb3/3-9/3-9.1/3-9.1:1.1/0003:045E:07B2.0002/input/input6/event3”
[ 15.140] (II) XINPUT: Adding extended input device “Microsoft Microsoft® 2.4GHz Transceiver v7.0” (type: MOUSE, id 9)
[ 15.140] (II) evdev: Microsoft Microsoft® 2.4GHz Transceiver v7.0: initialized for relative axes.
[ 15.140] () Microsoft Microsoft® 2.4GHz Transceiver v7.0: (accel) keeping acceleration scheme 1
[ 15.140] () Microsoft Microsoft® 2.4GHz Transceiver v7.0: (accel) acceleration profile 0
[ 15.140] () Microsoft Microsoft® 2.4GHz Transceiver v7.0: (accel) acceleration factor: 2.000
[ 15.140] () Microsoft Microsoft® 2.4GHz Transceiver v7.0: (accel) acceleration threshold: 4
[ 15.598] (–) NVIDIA(GPU-0): DFP-0: disconnected
[ 15.598] (–) NVIDIA(GPU-0): DFP-0: Internal TMDS
[ 15.598] (–) NVIDIA(GPU-0): DFP-0: 330.0 MHz maximum pixel clock
[ 15.598] (–) NVIDIA(GPU-0): DFP-1: disconnected
[ 15.598] (–) NVIDIA(GPU-0): DFP-1: Internal TMDS
[ 15.598] (–) NVIDIA(GPU-0): DFP-1: 165.0 MHz maximum pixel clock
[ 15.599] (–) NVIDIA(GPU-0): DFP-2: disconnected
[ 15.599] (–) NVIDIA(GPU-0): DFP-2: Internal TMDS
[ 15.599] (–) NVIDIA(GPU-0): DFP-2: 165.0 MHz maximum pixel clock
[ 15.599] (–) NVIDIA(GPU-0): DFP-3: disconnected
[ 15.599] (–) NVIDIA(GPU-0): DFP-3: Internal DisplayPort
[ 15.599] (–) NVIDIA(GPU-0): DFP-3: 1440.0 MHz maximum pixel clock
[ 15.599] (–) NVIDIA(GPU-0): DFP-4: disconnected
[ 15.599] (–) NVIDIA(GPU-0): DFP-4: Internal TMDS
[ 15.599] (–) NVIDIA(GPU-0): DFP-4: 165.0 MHz maximum pixel clock
[ 15.599] (–) NVIDIA(GPU-0): DELL U2414H (DFP-5): connected
[ 15.599] (–) NVIDIA(GPU-0): DELL U2414H (DFP-5): Internal DisplayPort
[ 15.599] (–) NVIDIA(GPU-0): DELL U2414H (DFP-5): 1440.0 MHz maximum pixel clock
[ 15.600] (–) NVIDIA(GPU-0): DFP-6: disconnected
[ 15.600] (–) NVIDIA(GPU-0): DFP-6: Internal TMDS
[ 15.600] (–) NVIDIA(GPU-0): DFP-6: 165.0 MHz maximum pixel clock
[ 15.775] (–) NVIDIA(GPU-0): DFP-0: disconnected
[ 15.775] (–) NVIDIA(GPU-0): DFP-0: Internal TMDS
[ 15.775] (–) NVIDIA(GPU-0): DFP-0: 330.0 MHz maximum pixel clock
[ 15.775] (–) NVIDIA(GPU-0): DFP-1: disconnected
[ 15.775] (–) NVIDIA(GPU-0): DFP-1: Internal TMDS
[ 15.775] (–) NVIDIA(GPU-0): DFP-1: 165.0 MHz maximum pixel clock
[ 15.775] (–) NVIDIA(GPU-0): DFP-2: disconnected
[ 15.775] (–) NVIDIA(GPU-0): DFP-2: Internal TMDS
[ 15.775] (–) NVIDIA(GPU-0): DFP-2: 165.0 MHz maximum pixel clock
[ 15.775] (–) NVIDIA(GPU-0): DFP-3: disconnected
[ 15.775] (–) NVIDIA(GPU-0): DFP-3: Internal DisplayPort
[ 15.775] (–) NVIDIA(GPU-0): DFP-3: 1440.0 MHz maximum pixel clock
[ 15.775] (–) NVIDIA(GPU-0): DFP-4: disconnected
[ 15.775] (–) NVIDIA(GPU-0): DFP-4: Internal TMDS
[ 15.775] (–) NVIDIA(GPU-0): DFP-4: 165.0 MHz maximum pixel clock
[ 15.775] (–) NVIDIA(GPU-0): DELL U2414H (DFP-5): connected
[ 15.775] (–) NVIDIA(GPU-0): DELL U2414H (DFP-5): Internal DisplayPort
[ 15.775] (–) NVIDIA(GPU-0): DELL U2414H (DFP-5): 1440.0 MHz maximum pixel clock
[ 15.776] (–) NVIDIA(GPU-0): DFP-6: disconnected
[ 15.776] (–) NVIDIA(GPU-0): DFP-6: Internal TMDS
[ 15.776] (–) NVIDIA(GPU-0): DFP-6: 165.0 MHz maximum pixel clock
[ 23.006] (–) NVIDIA(GPU-0): DFP-0: disconnected
[ 23.006] (–) NVIDIA(GPU-0): DFP-0: Internal TMDS
[ 23.006] (–) NVIDIA(GPU-0): DFP-0: 330.0 MHz maximum pixel clock
[ 23.006] (–) NVIDIA(GPU-0): DFP-1: disconnected
[ 23.006] (–) NVIDIA(GPU-0): DFP-1: Internal TMDS
[ 23.006] (–) NVIDIA(GPU-0): DFP-1: 165.0 MHz maximum pixel clock
[ 23.011] (–) NVIDIA(GPU-0): DFP-2: disconnected
[ 23.011] (–) NVIDIA(GPU-0): DFP-2: Internal TMDS
[ 23.011] (–) NVIDIA(GPU-0): DFP-2: 165.0 MHz maximum pixel clock
[ 23.011] (–) NVIDIA(GPU-0): DFP-3: disconnected
[ 23.011] (–) NVIDIA(GPU-0): DFP-3: Internal DisplayPort
[ 23.011] (–) NVIDIA(GPU-0): DFP-3: 1440.0 MHz maximum pixel clock
[ 23.011] (–) NVIDIA(GPU-0): DFP-4: disconnected
[ 23.011] (–) NVIDIA(GPU-0): DFP-4: Internal TMDS
[ 23.011] (–) NVIDIA(GPU-0): DFP-4: 165.0 MHz maximum pixel clock
[ 23.012] (–) NVIDIA(GPU-0): DELL U2414H (DFP-5): connected
[ 23.012] (–) NVIDIA(GPU-0): DELL U2414H (DFP-5): Internal DisplayPort
[ 23.012] (–) NVIDIA(GPU-0): DELL U2414H (DFP-5): 1440.0 MHz maximum pixel clock
[ 23.012] (–) NVIDIA(GPU-0): DFP-6: disconnected
[ 23.012] (–) NVIDIA(GPU-0): DFP-6: Internal TMDS
[ 23.012] (–) NVIDIA(GPU-0): DFP-6: 165.0 MHz maximum pixel clock
[ 23.390] (–) NVIDIA(GPU-0): DFP-0: disconnected
[ 23.390] (–) NVIDIA(GPU-0): DFP-0: Internal TMDS
[ 23.390] (–) NVIDIA(GPU-0): DFP-0: 330.0 MHz maximum pixel clock
[ 23.390] (–) NVIDIA(GPU-0): DFP-1: disconnected
[ 23.390] (–) NVIDIA(GPU-0): DFP-1: Internal TMDS
[ 23.390] (–) NVIDIA(GPU-0): DFP-1: 165.0 MHz maximum pixel clock
[ 23.390] (–) NVIDIA(GPU-0): DFP-2: disconnected
[ 23.390] (–) NVIDIA(GPU-0): DFP-2: Internal TMDS
[ 23.390] (–) NVIDIA(GPU-0): DFP-2: 165.0 MHz maximum pixel clock
[ 23.390] (–) NVIDIA(GPU-0): DFP-3: disconnected
[ 23.390] (–) NVIDIA(GPU-0): DFP-3: Internal DisplayPort
[ 23.390] (–) NVIDIA(GPU-0): DFP-3: 1440.0 MHz maximum pixel clock
[ 23.391] (–) NVIDIA(GPU-0): DFP-4: disconnected
[ 23.391] (–) NVIDIA(GPU-0): DFP-4: Internal TMDS
[ 23.391] (–) NVIDIA(GPU-0): DFP-4: 165.0 MHz maximum pixel clock
[ 23.391] (–) NVIDIA(GPU-0): DELL U2414H (DFP-5): connected
[ 23.391] (–) NVIDIA(GPU-0): DELL U2414H (DFP-5): Internal DisplayPort
[ 23.391] (–) NVIDIA(GPU-0): DELL U2414H (DFP-5): 1440.0 MHz maximum pixel clock
[ 23.391] (–) NVIDIA(GPU-0): DFP-6: disconnected
[ 23.391] (–) NVIDIA(GPU-0): DFP-6: Internal TMDS
[ 23.391] (–) NVIDIA(GPU-0): DFP-6: 165.0 MHz maximum pixel clock
[ 25.640] (–) NVIDIA(GPU-0): DFP-0: disconnected
[ 25.640] (–) NVIDIA(GPU-0): DFP-0: Internal TMDS
[ 25.640] (–) NVIDIA(GPU-0): DFP-0: 330.0 MHz maximum pixel clock
[ 25.640] (–) NVIDIA(GPU-0): DFP-1: disconnected
[ 25.640] (–) NVIDIA(GPU-0): DFP-1: Internal TMDS
[ 25.640] (–) NVIDIA(GPU-0): DFP-1: 165.0 MHz maximum pixel clock
[ 25.640] (–) NVIDIA(GPU-0): DFP-2: disconnected
[ 25.640] (–) NVIDIA(GPU-0): DFP-2: Internal TMDS
[ 25.640] (–) NVIDIA(GPU-0): DFP-2: 165.0 MHz maximum pixel clock
[ 25.640] (–) NVIDIA(GPU-0): DFP-3: disconnected
[ 25.640] (–) NVIDIA(GPU-0): DFP-3: Internal DisplayPort
[ 25.640] (–) NVIDIA(GPU-0): DFP-3: 1440.0 MHz maximum pixel clock
[ 25.640] (–) NVIDIA(GPU-0): DFP-4: disconnected
[ 25.640] (–) NVIDIA(GPU-0): DFP-4: Internal TMDS
[ 25.640] (–) NVIDIA(GPU-0): DFP-4: 165.0 MHz maximum pixel clock
[ 25.640] (–) NVIDIA(GPU-0): DELL U2414H (DFP-5): connected
[ 25.640] (–) NVIDIA(GPU-0): DELL U2414H (DFP-5): Internal DisplayPort
[ 25.640] (–) NVIDIA(GPU-0): DELL U2414H (DFP-5): 1440.0 MHz maximum pixel clock
[ 25.641] (–) NVIDIA(GPU-0): DFP-6: disconnected
[ 25.641] (–) NVIDIA(GPU-0): DFP-6: Internal TMDS
[ 25.641] (–) NVIDIA(GPU-0): DFP-6: 165.0 MHz maximum pixel clock
[ 754.854] (II) config/udev: removing device Microsoft Microsoft® 2.4GHz Transceiver v7.0
[ 754.876] (II) evdev: Microsoft Microsoft® 2.4GHz Transceiver v7.0: Close
[ 754.876] (II) UnloadModule: “evdev”
[ 754.898] (II) config/udev: removing device Microsoft Microsoft® 2.4GHz Transceiver v7.0
[ 754.908] (II) evdev: Microsoft Microsoft® 2.4GHz Transceiver v7.0: Close
[ 754.909] (II) UnloadModule: “evdev”
[ 754.942] (II) config/udev: removing device Microsoft Microsoft® 2.4GHz Transceiver v7.0
[ 754.968] (II) evdev: Microsoft Microsoft® 2.4GHz Transceiver v7.0: Close
[ 754.968] (II) UnloadModule: “evdev”
[ 761.263] (II) config/udev: Adding input device Microsoft Microsoft® 2.4GHz Transceiver v7.0 (/dev/input/mouse0)
[ 761.263] (II) No input driver specified, ignoring this device.
[ 761.263] (II) This device may have been added with another device file.
[ 761.265] (II) config/udev: Adding input device Microsoft Microsoft® 2.4GHz Transceiver v7.0 (/dev/input/js0)
[ 761.265] (II) No input driver specified, ignoring this device.
[ 761.265] (II) This device may have been added with another device file.
[ 761.297] (II) config/udev: Adding input device Microsoft Microsoft® 2.4GHz Transceiver v7.0 (/dev/input/event2)
[ 761.297] () Microsoft Microsoft® 2.4GHz Transceiver v7.0: Applying InputClass “evdev keyboard catchall”
[ 761.297] (II) Using input driver ‘evdev’ for ‘Microsoft Microsoft® 2.4GHz Transceiver v7.0’
[ 761.297] () Microsoft Microsoft® 2.4GHz Transceiver v7.0: always reports core events
[ 761.297] () evdev: Microsoft Microsoft® 2.4GHz Transceiver v7.0: Device: “/dev/input/event2”
[ 761.298] (–) evdev: Microsoft Microsoft® 2.4GHz Transceiver v7.0: Vendor 0x45e Product 0x7b2
[ 761.298] (–) evdev: Microsoft Microsoft® 2.4GHz Transceiver v7.0: Found keys
[ 761.298] (II) evdev: Microsoft Microsoft® 2.4GHz Transceiver v7.0: Configuring as keyboard
[ 761.298] () Option “config_info” “udev:/sys/devices/pci0000:00/0000:00:01.1/0000:02:00.0/usb5/5-2/5-2:1.0/0003:045E:07B2.0004/input/input21/event2”
[ 761.298] (II) XINPUT: Adding extended input device “Microsoft Microsoft® 2.4GHz Transceiver v7.0” (type: KEYBOARD, id 8)
[ 761.298] () Option “xkb_rules” “evdev”
[ 761.298] () Option “xkb_model” “pc105”
[ 761.298] () Option “xkb_layout” “tr”
[ 761.298] (WW) Option “xkb_variant” requires a string value
[ 761.298] (WW) Option “xkb_options” requires a string value
[ 761.342] (II) config/udev: Adding input device Microsoft Microsoft® 2.4GHz Transceiver v7.0 (/dev/input/event4)
[ 761.342] () Microsoft Microsoft® 2.4GHz Transceiver v7.0: Applying InputClass “evdev keyboard catchall”
[ 761.342] (II) Using input driver ‘evdev’ for ‘Microsoft Microsoft® 2.4GHz Transceiver v7.0’
[ 761.342] () Microsoft Microsoft® 2.4GHz Transceiver v7.0: always reports core events
[ 761.342] () evdev: Microsoft Microsoft® 2.4GHz Transceiver v7.0: Device: “/dev/input/event4”
[ 761.342] (–) evdev: Microsoft Microsoft® 2.4GHz Transceiver v7.0: Vendor 0x45e Product 0x7b2
[ 761.342] (–) evdev: Microsoft Microsoft® 2.4GHz Transceiver v7.0: Found 1 mouse buttons
[ 761.342] (–) evdev: Microsoft Microsoft® 2.4GHz Transceiver v7.0: Found scroll wheel(s)
[ 761.342] (–) evdev: Microsoft Microsoft® 2.4GHz Transceiver v7.0: Found relative axes
[ 761.342] (–) evdev: Microsoft Microsoft® 2.4GHz Transceiver v7.0: Found absolute axes
[ 761.342] (–) evdev: Microsoft Microsoft® 2.4GHz Transceiver v7.0: Found absolute multitouch axes
[ 761.342] (–) evdev: Microsoft Microsoft® 2.4GHz Transceiver v7.0: Fake MT device detected
[ 761.342] (–) evdev: Microsoft Microsoft® 2.4GHz Transceiver v7.0: Found x and y absolute axes
[ 761.342] (–) evdev: Microsoft Microsoft® 2.4GHz Transceiver v7.0: Found keys
[ 761.342] (II) evdev: Microsoft Microsoft® 2.4GHz Transceiver v7.0: Forcing relative x/y axes to exist.
[ 761.342] (II) evdev: Microsoft Microsoft® 2.4GHz Transceiver v7.0: Configuring as mouse
[ 761.342] (II) evdev: Microsoft Microsoft® 2.4GHz Transceiver v7.0: Configuring as keyboard
[ 761.342] (II) evdev: Microsoft Microsoft® 2.4GHz Transceiver v7.0: Adding scrollwheel support
[ 761.342] () evdev: Microsoft Microsoft® 2.4GHz Transceiver v7.0: YAxisMapping: buttons 4 and 5
[ 761.342] () evdev: Microsoft Microsoft® 2.4GHz Transceiver v7.0: EmulateWheelButton: 4, EmulateWheelInertia: 10, EmulateWheelTimeout: 200
[ 761.342] () Option “config_info” “udev:/sys/devices/pci0000:00/0000:00:01.1/0000:02:00.0/usb5/5-2/5-2:1.2/0003:045E:07B2.0006/input/input23/event4”
[ 761.342] (II) XINPUT: Adding extended input device “Microsoft Microsoft® 2.4GHz Transceiver v7.0” (type: KEYBOARD, id 9)
[ 761.342] () Option “xkb_rules” “evdev”
[ 761.342] () Option “xkb_model” “pc105”
[ 761.342] () Option “xkb_layout” “tr”
[ 761.342] (WW) Option “xkb_variant” requires a string value
[ 761.342] (WW) Option “xkb_options” requires a string value
[ 761.343] (II) evdev: Microsoft Microsoft® 2.4GHz Transceiver v7.0: initialized for relative axes.
[ 761.343] (WW) evdev: Microsoft Microsoft® 2.4GHz Transceiver v7.0: ignoring absolute axes.
[ 761.343] () Microsoft Microsoft® 2.4GHz Transceiver v7.0: (accel) keeping acceleration scheme 1
[ 761.343] () Microsoft Microsoft® 2.4GHz Transceiver v7.0: (accel) acceleration profile 0
[ 761.343] () Microsoft Microsoft® 2.4GHz Transceiver v7.0: (accel) acceleration factor: 2.000
[ 761.343] () Microsoft Microsoft® 2.4GHz Transceiver v7.0: (accel) acceleration threshold: 4
[ 761.353] (II) config/udev: Adding input device Microsoft Microsoft® 2.4GHz Transceiver v7.0 (/dev/input/event3)
[ 761.353] () Microsoft Microsoft® 2.4GHz Transceiver v7.0: Applying InputClass “evdev pointer catchall”
[ 761.353] (II) Using input driver ‘evdev’ for ‘Microsoft Microsoft® 2.4GHz Transceiver v7.0’
[ 761.353] () Microsoft Microsoft® 2.4GHz Transceiver v7.0: always reports core events
[ 761.353] () evdev: Microsoft Microsoft® 2.4GHz Transceiver v7.0: Device: “/dev/input/event3”
[ 761.424] (–) evdev: Microsoft Microsoft® 2.4GHz Transceiver v7.0: Vendor 0x45e Product 0x7b2
[ 761.424] (–) evdev: Microsoft Microsoft® 2.4GHz Transceiver v7.0: Found 9 mouse buttons
[ 761.424] (–) evdev: Microsoft Microsoft® 2.4GHz Transceiver v7.0: Found scroll wheel(s)
[ 761.424] (–) evdev: Microsoft Microsoft® 2.4GHz Transceiver v7.0: Found relative axes
[ 761.424] (–) evdev: Microsoft Microsoft® 2.4GHz Transceiver v7.0: Found x and y relative axes
[ 761.424] (II) evdev: Microsoft Microsoft® 2.4GHz Transceiver v7.0: Configuring as mouse
[ 761.424] (II) evdev: Microsoft Microsoft® 2.4GHz Transceiver v7.0: Adding scrollwheel support
[ 761.424] () evdev: Microsoft Microsoft® 2.4GHz Transceiver v7.0: YAxisMapping: buttons 4 and 5
[ 761.424] () evdev: Microsoft Microsoft® 2.4GHz Transceiver v7.0: EmulateWheelButton: 4, EmulateW
