Nvidia driver 418 or 430 installation issues on Ubuntu 190.4 disco
Start of NVIDIA bug report log file. Please include this file, along
with a detailed description of your problem, when reporting a graphics
driver bug via the NVIDIA Linux forum (see devtalk.nvidia.com)
or by sending email to ‘linux-bugs@nvidia.com’.
nvidia-bug-report.sh Version: 25648098
Date: 2019年 04月 30日 星期二 12:04:25 CST
uname: Linux y7k 5.0.0-050000-generic #201903032031 SMP Mon Mar 4 01:33:18 UTC 2019 x86_64 x86_64 x86_64 GNU/Linux
command line flags:
*** /etc/issue
*** ls: -rw-r–r-- 1 root root 20 2019-04-16 15:36:43.000000000 +0800 /etc/issue
Ubuntu 19.04 \n \l
*** /etc/debian_version
*** ls: -rw-r–r-- 1 root root 11 2017-06-26 06:18:00.000000000 +0800 /etc/debian_version
buster/sid
*** /var/log/nvidia-installer.log
*** ls: -rw-r–r-- 1 root root 29540 2019-04-29 14:25:40.154483242 +0800 /var/log/nvidia-installer.log
nvidia-installer log file ‘/var/log/nvidia-installer.log’
creation time: Mon Apr 29 14:25:19 2019
installer version: 418.39
PATH: /usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/snap/bin
nvidia-installer command line:
./nvidia-installer
–ui=none
–no-questions
–accept-license
–disable-nouveau
–no-cc-version-check
–install-libglvnd
Using built-in stream user interface
→ Detected 12 CPUs online; setting concurrency level to 12.
→ Installing NVIDIA driver version 418.39.
→ There appears to already be a driver installed on your system (version: 418.39). As part of installing this driver (version: 418.39), the existing driver will be uninstalled. Are you sure you want to continue? (Answer: Continue installation)
→ An alternate method of installing the NVIDIA driver was detected. (This is usually a package provided by your distributor.) A driver installed via that method may integrate better with your system than a driver installed by nvidia-installer.
Please review the message provided by the maintainer of this alternate installation method and decide how to proceed:
The NVIDIA driver provided by Ubuntu can be installed by launching the “Software & Updates” application, and by selecting the NVIDIA driver from the “Additional Drivers” tab.
WARNING: One or more modprobe configuration files to disable Nouveau are already present at: /etc/modprobe.d/nvidia-installer-disable-nouveau.conf. Please be sure you have rebooted your system since these files were written. If you have rebooted, then Nouveau may be enabled for other reasons, such as being included in the system initial ramdisk or in your X configuration file. Please consult the NVIDIA driver README and your Linux distribution’s documentation for details on how to correctly disable the Nouveau kernel driver.
→ For some distributions, Nouveau can be disabled by adding a file in the modprobe configuration directory. Would you like nvidia-installer to attempt to create this modprobe file for you? (Answer: Yes)
→ One or more modprobe configuration files to disable Nouveau have been written. For some distributions, this may be sufficient to disable Nouveau; other distributions may require modification of the initial ramdisk. Please reboot your system and attempt NVIDIA driver installation again. Note if you later wish to reenable Nouveau, you will need to delete these files: /etc/modprobe.d/nvidia-installer-disable-nouveau.conf
→ Would you like to register the kernel module sources with DKMS? This will allow DKMS to automatically build a new module, if you install a different kernel later. (Answer: No)
→ Performing CC sanity check with CC=“/usr/bin/cc”.
→ Kernel source path: ‘/lib/modules/5.0.0-050000-generic/build’
→ Kernel output path: ‘/lib/modules/5.0.0-050000-generic/build’
→ Performing Compiler check.
→ Performing Dom0 check.
→ Performing Xen check.
→ Performing PREEMPT_RT check.
→ Performing vgpu_kvm check.
→ Cleaning kernel module build directory.
executing: ‘cd ./kernel; /usr/bin/make -k -j12 clean NV_EXCLUDE_KERNEL_MODULES=“” SYSSRC=“/lib/modules/5.0.0-050000-generic/build” SYSOUT=“/lib/modules/5.0.0-050000-generic/build”’…
rm -f -r conftest
make[1]: Entering directory ‘/usr/src/linux-headers-5.0.0-050000-generic’
make[1]: Leaving directory ‘/usr/src/linux-headers-5.0.0-050000-generic’
→ Building kernel modules
executing: ‘cd ./kernel; /usr/bin/make -k -j12 NV_EXCLUDE_KERNEL_MODULES=“” SYSSRC=“/lib/modules/5.0.0-050000-generic/build” SYSOUT=“/lib/modules/5.0.0-050000-generic/build”’…
SYMLINK /tmp/selfgz2271/NVIDIA-Linux-x86_64-418.39/kernel/nvidia/nv-kernel.o
SYMLINK /tmp/selfgz2271/NVIDIA-Linux-x86_64-418.39/kernel/nvidia-modeset/nv-modeset-kernel.o
CONFTEST: INIT_WORK
CONFTEST: remap_pfn_range
CONFTEST: hash__remap_4k_pfn
CONFTEST: follow_pfn
CONFTEST: vmap
CONFTEST: set_pages_uc
CONFTEST: set_memory_uc
CONFTEST: set_memory_array_uc
CONFTEST: change_page_attr
CONFTEST: pci_get_class
CONFTEST: pci_choose_state
CONFTEST: vm_insert_page
CONFTEST: acpi_device_id
CONFTEST: acquire_console_sem
CONFTEST: console_lock
CONFTEST: kmem_cache_create
CONFTEST: on_each_cpu
CONFTEST: smp_call_function
CONFTEST: acpi_evaluate_integer
CONFTEST: ioremap_cache
CONFTEST: ioremap_wc
CONFTEST: acpi_walk_namespace
CONFTEST: pci_domain_nr
CONFTEST: pci_dma_mapping_error
CONFTEST: sg_alloc_table
CONFTEST: sg_init_table
CONFTEST: pci_get_domain_bus_and_slot
CONFTEST: get_num_physpages
CONFTEST: efi_enabled
CONFTEST: proc_create_data
CONFTEST: pde_data
CONFTEST: proc_remove
CONFTEST: pm_vt_switch_required
CONFTEST: xen_ioemu_inject_msi
CONFTEST: phys_to_dma
CONFTEST: get_dma_ops
CONFTEST: write_cr4
CONFTEST: of_get_property
CONFTEST: of_find_node_by_phandle
CONFTEST: of_node_to_nid
CONFTEST: pnv_pci_get_npu_dev
CONFTEST: of_get_ibm_chip_id
CONFTEST: for_each_online_node
CONFTEST: node_end_pfn
CONFTEST: pci_bus_address
CONFTEST: pci_stop_and_remove_bus_device
CONFTEST: pci_remove_bus_device
CONFTEST: request_threaded_irq
CONFTEST: register_cpu_notifier
CONFTEST: cpuhp_setup_state
CONFTEST: dma_map_resource
CONFTEST: backlight_device_register
CONFTEST: register_acpi_notifier
CONFTEST: timer_setup
CONFTEST: pci_enable_msix_range
CONFTEST: compound_order
CONFTEST: do_gettimeofday
CONFTEST: remap_page_range
CONFTEST: address_space_init_once
CONFTEST: kbasename
CONFTEST: fatal_signal_pending
CONFTEST: list_cut_position
CONFTEST: vzalloc
CONFTEST: wait_on_bit_lock_argument_count
CONFTEST: bitmap_clear
CONFTEST: usleep_range
CONFTEST: radix_tree_empty
CONFTEST: radix_tree_replace_slot
CONFTEST: pnv_npu2_init_context
CONFTEST: drm_dev_unref
CONFTEST: drm_reinit_primary_mode_group
CONFTEST: get_user_pages_remote
CONFTEST: drm_gem_object_lookup
CONFTEST: drm_atomic_state_ref_counting
CONFTEST: drm_driver_has_gem_prime_res_obj
CONFTEST: drm_atomic_helper_connector_dpms
CONFTEST: drm_connector_funcs_have_mode_in_name
CONFTEST: vmf_insert_pfn
CONFTEST: drm_framebuffer_get
CONFTEST: drm_gem_object_get
CONFTEST: drm_dev_put
CONFTEST: is_export_symbol_gpl_of_node_to_nid
CONFTEST: is_export_symbol_present_swiotlb_map_sg_attrs
CONFTEST: is_export_symbol_present_swiotlb_dma_ops
CONFTEST: i2c_adapter
CONFTEST: pm_message_t
CONFTEST: irq_handler_t
CONFTEST: acpi_device_ops
CONFTEST: acpi_op_remove
CONFTEST: outer_flush_all
CONFTEST: proc_dir_entry
CONFTEST: scatterlist
CONFTEST: sg_table
CONFTEST: file_operations
CONFTEST: vm_operations_struct
CONFTEST: atomic_long_type
CONFTEST: pci_save_state
CONFTEST: file_inode
CONFTEST: task_struct
CONFTEST: kuid_t
CONFTEST: dma_ops
CONFTEST: swiotlb_dma_ops
CONFTEST: dma_map_ops
CONFTEST: noncoherent_swiotlb_dma_ops
CONFTEST: vm_fault_present
CONFTEST: vm_fault_has_address
CONFTEST: backlight_properties_type
CONFTEST: fault_flags
CONFTEST: atomic64_type
CONFTEST: backing_dev_info
CONFTEST: mm_context_t
CONFTEST: vm_ops_fault_removed_vma_arg
CONFTEST: node_states_n_memory
CONFTEST: drm_bus_present
CONFTEST: drm_bus_has_bus_type
CONFTEST: drm_bus_has_get_irq
CONFTEST: drm_bus_has_get_name
CONFTEST: drm_driver_has_legacy_dev_list
CONFTEST: drm_driver_has_set_busid
CONFTEST: drm_crtc_state_has_connectors_changed
CONFTEST: drm_init_function_args
CONFTEST: drm_mode_connector_list_update_has_merge_type_bits_arg
CONFTEST: drm_helper_mode_fill_fb_struct
CONFTEST: drm_master_drop_has_from_release_arg
CONFTEST: drm_driver_unload_has_int_return_type
CONFTEST: kref_has_refcount_of_type_refcount_t
CONFTEST: drm_atomic_helper_crtc_destroy_state_has_crtc_arg
CONFTEST: drm_crtc_helper_funcs_has_atomic_enable
CONFTEST: drm_mode_object_find_has_file_priv_arg
CONFTEST: dma_buf_owner
CONFTEST: drm_connector_list_iter
CONFTEST: dom0_kernel_present
CONFTEST: nvidia_vgpu_hyperv_available
CONFTEST: nvidia_vgpu_kvm_build
CONFTEST: nvidia_grid_build
CONFTEST: drm_available
CONFTEST: drm_atomic_available
CONFTEST: drm_atomic_modeset_nonblocking_commit_available
CONFTEST: is_export_symbol_gpl_refcount_inc
CONFTEST: is_export_symbol_gpl_refcount_dec_and_test
CC [M] /tmp/selfgz2271/NVIDIA-Linux-x86_64-418.39/kernel/nvidia/nv-frontend.o
CC [M] /tmp/selfgz2271/NVIDIA-Linux-x86_64-418.39/kernel/nvidia/nv-instance.o
CC [M] /tmp/selfgz2271/NVIDIA-Linux-x86_64-418.39/kernel/nvidia/nv.o
CC [M] /tmp/selfgz2271/NVIDIA-Linux-x86_64-418.39/kernel/nvidia/nv-acpi.o
CC [M] /tmp/selfgz2271/NVIDIA-Linux-x86_64-418.39/kernel/nvidia/nv-chrdev.o
CC [M] /tmp/selfgz2271/NVIDIA-Linux-x86_64-418.39/kernel/nvidia/nv-cray.o
CC [M] /tmp/selfgz2271/NVIDIA-Linux-x86_64-418.39/kernel/nvidia/nv-dma.o
CC [M] /tmp/selfgz2271/NVIDIA-Linux-x86_64-418.39/kernel/nvidia/nv-gvi.o
CC [M] /tmp/selfgz2271/NVIDIA-Linux-x86_64-418.39/kernel/nvidia/nv-i2c.o
CC [M] /tmp/selfgz2271/NVIDIA-Linux-x86_64-418.39/kernel/nvidia/nv-mempool.o
CC [M] /tmp/selfgz2271/NVIDIA-Linux-x86_64-418.39/kernel/nvidia/nv-mmap.o
CC [M] /tmp/selfgz2271/NVIDIA-Linux-x86_64-418.39/kernel/nvidia/nv-p2p.o
CC [M] /tmp/selfgz2271/NVIDIA-Linux-x86_64-418.39/kernel/nvidia/nv-pat.o
CC [M] /tmp/selfgz2271/NVIDIA-Linux-x86_64-418.39/kernel/nvidia/nv-procfs.o
CC [M] /tmp/selfgz2271/NVIDIA-Linux-x86_64-418.39/kernel/nvidia/nv-usermap.o
CC [M] /tmp/selfgz2271/NVIDIA-Linux-x86_64-418.39/kernel/nvidia/nv-vm.o
CC [M] /tmp/selfgz2271/NVIDIA-Linux-x86_64-418.39/kernel/nvidia/nv-vtophys.o
CC [M] /tmp/selfgz2271/NVIDIA-Linux-x86_64-418.39/kernel/nvidia/os-interface.o
CC [M] /tmp/selfgz2271/NVIDIA-Linux-x86_64-418.39/kernel/nvidia/os-mlock.o
CC [M] /tmp/selfgz2271/NVIDIA-Linux-x86_64-418.39/kernel/nvidia/os-pci.o
CC [M] /tmp/selfgz2271/NVIDIA-Linux-x86_64-418.39/kernel/nvidia/os-registry.o
CC [M] /tmp/selfgz2271/NVIDIA-Linux-x86_64-418.39/kernel/nvidia/os-usermap.o
CC [M] /tmp/selfgz2271/NVIDIA-Linux-x86_64-418.39/kernel/nvidia/nv-modeset-interface.o
CC [M] /tmp/selfgz2271/NVIDIA-Linux-x86_64-418.39/kernel/nvidia/nv-pci-table.o
CC [M] /tmp/selfgz2271/NVIDIA-Linux-x86_64-418.39/kernel/nvidia/nv-kthread-q.o
CC [M] /tmp/selfgz2271/NVIDIA-Linux-x86_64-418.39/kernel/nvidia/nv-kthread-q-selftest.o
CC [M] /tmp/selfgz2271/NVIDIA-Linux-x86_64-418.39/kernel/nvidia/nv-memdbg.o
CC [M] /tmp/selfgz2271/NVIDIA-Linux-x86_64-418.39/kernel/nvidia/nv-ibmnpu.o
CC [M] /tmp/selfgz2271/NVIDIA-Linux-x86_64-418.39/kernel/nvidia/nv-report-err.o
CC [M] /tmp/selfgz2271/NVIDIA-Linux-x86_64-418.39/kernel/nvidia/nv-rsync.o
CC [M] /tmp/selfgz2271/NVIDIA-Linux-x86_64-418.39/kernel/nvidia/nv-msi.o
CC [M] /tmp/selfgz2271/NVIDIA-Linux-x86_64-418.39/kernel/nvidia/nv_uvm_interface.o
CC [M] /tmp/selfgz2271/NVIDIA-Linux-x86_64-418.39/kernel/nvidia/nvlink_linux.o
CC [M] /tmp/selfgz2271/NVIDIA-Linux-x86_64-418.39/kernel/nvidia/linux_nvswitch.o
CC [M] /tmp/selfgz2271/NVIDIA-Linux-x86_64-418.39/kernel/nvidia-uvm/uvm_utils.o
CC [M] /tmp/selfgz2271/NVIDIA-Linux-x86_64-418.39/kernel/nvidia-uvm/uvm_common.o
CC [M] /tmp/selfgz2271/NVIDIA-Linux-x86_64-418.39/kernel/nvidia-uvm/uvm_linux.o
CC [M] /tmp/selfgz2271/NVIDIA-Linux-x86_64-418.39/kernel/nvidia-uvm/nvstatus.o
CC [M] /tmp/selfgz2271/NVIDIA-Linux-x86_64-418.39/kernel/nvidia-uvm/nvCpuUuid.o
CC [M] /tmp/selfgz2271/NVIDIA-Linux-x86_64-418.39/kernel/nvidia-uvm/uvm8.o
CC [M] /tmp/selfgz2271/NVIDIA-Linux-x86_64-418.39/kernel/nvidia-uvm/uvm8_tools.o
CC [M] /tmp/selfgz2271/NVIDIA-Linux-x86_64-418.39/kernel/nvidia-uvm/uvm8_global.o
CC [M] /tmp/selfgz2271/NVIDIA-Linux-x86_64-418.39/kernel/nvidia-uvm/uvm8_gpu.o
CC [M] /tmp/selfgz2271/NVIDIA-Linux-x86_64-418.39/kernel/nvidia-uvm/uvm8_gpu_isr.o
CC [M] /tmp/selfgz2271/NVIDIA-Linux-x86_64-418.39/kernel/nvidia-uvm/uvm8_procfs.o
CC [M] /tmp/selfgz2271/NVIDIA-Linux-x86_64-418.39/kernel/nvidia-uvm/uvm8_va_space.o
CC [M] /tmp/selfgz2271/NVIDIA-Linux-x86_64-418.39/kernel/nvidia-uvm/uvm8_va_space_mm.o
CC [M] /tmp/selfgz2271/NVIDIA-Linux-x86_64-418.39/kernel/nvidia-uvm/uvm8_gpu_semaphore.o
CC [M] /tmp/selfgz2271/NVIDIA-Linux-x86_64-418.39/kernel/nvidia-uvm/uvm8_mem.o
CC [M] /tmp/selfgz2271/NVIDIA-Linux-x86_64-418.39/kernel/nvidia-uvm/uvm8_rm_mem.o
CC [M] /tmp/selfgz2271/NVIDIA-Linux-x86_64-418.39/kernel/nvidia-uvm/uvm8_channel.o
CC [M] /tmp/selfgz2271/NVIDIA-Linux-x86_64-418.39/kernel/nvidia-uvm/uvm8_lock.o
CC [M] /tmp/selfgz2271/NVIDIA-Linux-x86_64-418.39/kernel/nvidia-uvm/uvm8_hal.o
CC [M] /tmp/selfgz2271/NVIDIA-Linux-x86_64-418.39/kernel/nvidia-uvm/uvm8_range_tree.o
CC [M] /tmp/selfgz2271/NVIDIA-Linux-x86_64-418.39/kernel/nvidia-uvm/uvm8_range_allocator.o
CC [M] /tmp/selfgz2271/NVIDIA-Linux-x86_64-418.39/kernel/nvidia-uvm/uvm8_va_range.o
CC [M] /tmp/selfgz2271/NVIDIA-Linux-x86_64-418.39/kernel/nvidia-uvm/uvm8_va_block.o
CC [M] /tmp/selfgz2271/NVIDIA-Linux-x86_64-418.39/kernel/nvidia-uvm/uvm8_range_group.o
CC [M] /tmp/selfgz2271/NVIDIA-Linux-x86_64-418.39/kernel/nvidia-uvm/uvm8_gpu_replayable_faults.o
CC [M] /tmp/selfgz2271/NVIDIA-Linux-x86_64-418.39/kernel/nvidia-uvm/uvm8_gpu_non_replayable_faults.o
CC [M] /tmp/selfgz2271/NVIDIA-Linux-x86_64-418.39/kernel/nvidia-uvm/uvm8_gpu_access_counters.o
CC [M] /tmp/selfgz2271/NVIDIA-Linux-x86_64-418.39/kernel/nvidia-uvm/uvm8_perf_events.o
CC [M] /tmp/selfgz2271/NVIDIA-Linux-x86_64-418.39/kernel/nvidia-uvm/uvm8_perf_module.o
CC [M] /tmp/selfgz2271/NVIDIA-Linux-x86_64-418.39/kernel/nvidia-uvm/uvm8_mmu.o
CC [M] /tmp/selfgz2271/NVIDIA-Linux-x86_64-418.39/kernel/nvidia-uvm/uvm8_pte_batch.o
CC [M] /tmp/selfgz2271/NVIDIA-Linux-x86_64-418.39/kernel/nvidia-uvm/uvm8_tlb_batch.o
CC [M] /tmp/selfgz2271/NVIDIA-Linux-x86_64-418.39/kernel/nvidia-uvm/uvm8_push.o
CC [M] /tmp/selfgz2271/NVIDIA-Linux-x86_64-418.39/kernel/nvidia-uvm/uvm8_pushbuffer.o
CC [M] /tmp/selfgz2271/NVIDIA-Linux-x86_64-418.39/kernel/nvidia-uvm/uvm8_thread_context.o
CC [M] /tmp/selfgz2271/NVIDIA-Linux-x86_64-418.39/kernel/nvidia-uvm/uvm8_tracker.o
CC [M] /tmp/selfgz2271/NVIDIA-Linux-x86_64-418.39/kernel/nvidia-uvm/uvm8_kepler.o
CC [M] /tmp/selfgz2271/NVIDIA-Linux-x86_64-418.39/kernel/nvidia-uvm/uvm8_kepler_ce.o
CC [M] /tmp/selfgz2271/NVIDIA-Linux-x86_64-418.39/kernel/nvidia-uvm/uvm8_kepler_host.o
CC [M] /tmp/selfgz2271/NVIDIA-Linux-x86_64-418.39/kernel/nvidia-uvm/uvm8_kepler_mmu.o
CC [M] /tmp/selfgz2271/NVIDIA-Linux-x86_64-418.39/kernel/nvidia-uvm/uvm8_maxwell.o
CC [M] /tmp/selfgz2271/NVIDIA-Linux-x86_64-418.39/kernel/nvidia-uvm/uvm8_maxwell_host.o
CC [M] /tmp/selfgz2271/NVIDIA-Linux-x86_64-418.39/kernel/nvidia-uvm/uvm8_pascal.o
CC [M] /tmp/selfgz2271/NVIDIA-Linux-x86_64-418.39/kernel/nvidia-uvm/uvm8_pascal_ce.o
CC [M] /tmp/selfgz2271/NVIDIA-Linux-x86_64-418.39/kernel/nvidia-uvm/uvm8_pascal_host.o
CC [M] /tmp/selfgz2271/NVIDIA-Linux-x86_64-418.39/kernel/nvidia-uvm/uvm8_pascal_mmu.o
CC [M] /tmp/selfgz2271/NVIDIA-Linux-x86_64-418.39/kernel/nvidia-uvm/uvm8_pascal_fault_buffer.o
CC [M] /tmp/selfgz2271/NVIDIA-Linux-x86_64-418.39/kernel/nvidia-uvm/uvm8_volta_host.o
CC [M] /tmp/selfgz2271/NVIDIA-Linux-x86_64-418.39/kernel/nvidia-uvm/uvm8_volta_mmu.o
CC [M] /tmp/selfgz2271/NVIDIA-Linux-x86_64-418.39/kernel/nvidia-uvm/uvm8_volta.o
CC [M] /tmp/selfgz2271/NVIDIA-Linux-x86_64-418.39/kernel/nvidia-uvm/uvm8_volta_fault_buffer.o
CC [M] /tmp/selfgz2271/NVIDIA-Linux-x86_64-418.39/kernel/nvidia-uvm/uvm8_volta_access_counter_buffer.o
CC [M] /tmp/selfgz2271/NVIDIA-Linux-x86_64-418.39/kernel/nvidia-uvm/uvm8_turing.o
CC [M] /tmp/selfgz2271/NVIDIA-Linux-x86_64-418.39/kernel/nvidia-uvm/uvm8_turing_mmu.o
CC [M] /tmp/selfgz2271/NVIDIA-Linux-x86_64-418.39/kernel/nvidia-uvm/uvm8_turing_host.o
CC [M] /tmp/selfgz2271/NVIDIA-Linux-x86_64-418.39/kernel/nvidia-uvm/uvm8_policy.o
CC [M] /tmp/selfgz2271/NVIDIA-Linux-x86_64-418.39/kernel/nvidia-uvm/uvm8_perf_utils.o
CC [M] /tmp/selfgz2271/NVIDIA-Linux-x86_64-418.39/kernel/nvidia-uvm/uvm8_kvmalloc.o
CC [M] /tmp/selfgz2271/NVIDIA-Linux-x86_64-418.39/kernel/nvidia-uvm/uvm8_pmm_sysmem.o
CC [M] /tmp/selfgz2271/NVIDIA-Linux-x86_64-418.39/kernel/nvidia-uvm/uvm8_pmm_gpu.o
CC [M] /tmp/selfgz2271/NVIDIA-Linux-x86_64-418.39/kernel/nvidia-uvm/uvm8_migrate.o
CC [M] /tmp/selfgz2271/NVIDIA-Linux-x86_64-418.39/kernel/nvidia-uvm/uvm8_populate_pageable.o
CC [M] /tmp/selfgz2271/NVIDIA-Linux-x86_64-418.39/kernel/nvidia-uvm/uvm8_migrate_pageable.o
CC [M] /tmp/selfgz2271/NVIDIA-Linux-x86_64-418.39/kernel/nvidia-uvm/uvm8_map_external.o
CC [M] /tmp/selfgz2271/NVIDIA-Linux-x86_64-418.39/kernel/nvidia-uvm/uvm8_user_channel.o
CC [M] /tmp/selfgz2271/NVIDIA-Linux-x86_64-418.39/kernel/nvidia-uvm/uvm8_hmm.o
CC [M] /tmp/selfgz2271/NVIDIA-Linux-x86_64-418.39/kernel/nvidia-uvm/uvm8_perf_heuristics.o
CC [M] /tmp/selfgz2271/NVIDIA-Linux-x86_64-418.39/kernel/nvidia-uvm/uvm8_perf_thrashing.o
CC [M] /tmp/selfgz2271/NVIDIA-Linux-x86_64-418.39/kernel/nvidia-uvm/uvm8_perf_prefetch.o
CC [M] /tmp/selfgz2271/NVIDIA-Linux-x86_64-418.39/kernel/nvidia-uvm/uvm8_ats_ibm.o
CC [M] /tmp/selfgz2271/NVIDIA-Linux-x86_64-418.39/kernel/nvidia-uvm/uvm8_ats_faults.o
CC [M] /tmp/selfgz2271/NVIDIA-Linux-x86_64-418.39/kernel/nvidia-uvm/uvm8_test.o
CC [M] /tmp/selfgz2271/NVIDIA-Linux-x86_64-418.39/kernel/nvidia-uvm/uvm8_test_rng.o
CC [M] /tmp/selfgz2271/NVIDIA-Linux-x86_64-418.39/kernel/nvidia-uvm/uvm8_range_tree_test.o
CC [M] /tmp/selfgz2271/NVIDIA-Linux-x86_64-418.39/kernel/nvidia-uvm/uvm8_range_allocator_test.o
CC [M] /tmp/selfgz2271/NVIDIA-Linux-x86_64-418.39/kernel/nvidia-uvm/uvm8_gpu_semaphore_test.o
CC [M] /tmp/selfgz2271/NVIDIA-Linux-x86_64-418.39/kernel/nvidia-uvm/uvm8_mem_test.o
CC [M] /tmp/selfgz2271/NVIDIA-Linux-x86_64-418.39/kernel/nvidia-uvm/uvm8_rm_mem_test.o
CC [M] /tmp/selfgz2271/NVIDIA-Linux-x86_64-418.39/kernel/nvidia-uvm/uvm8_page_tree_test.o
CC [M] /tmp/selfgz2271/NVIDIA-Linux-x86_64-418.39/kernel/nvidia-uvm/uvm8_tracker_test.o
CC [M] /tmp/selfgz2271/NVIDIA-Linux-x86_64-418.39/kernel/nvidia-uvm/uvm8_push_test.o
CC [M] /tmp/selfgz2271/NVIDIA-Linux-x86_64-418.39/kernel/nvidia-uvm/uvm8_channel_test.o
CC [M] /tmp/selfgz2271/NVIDIA-Linux-x86_64-418.39/kernel/nvidia-uvm/uvm8_ce_test.o
CC [M] /tmp/selfgz2271/NVIDIA-Linux-x86_64-418.39/kernel/nvidia-uvm/uvm8_lock_test.o
CC [M] /tmp/selfgz2271/NVIDIA-Linux-x86_64-418.39/kernel/nvidia-uvm/uvm8_perf_utils_test.o
CC [M] /tmp/selfgz2271/NVIDIA-Linux-x86_64-418.39/kernel/nvidia-uvm/uvm8_kvmalloc_test.o
CC [M] /tmp/selfgz2271/NVIDIA-Linux-x86_64-418.39/kernel/nvidia-uvm/uvm8_pmm_test.o
CC [M] /tmp/selfgz2271/NVIDIA-Linux-x86_64-418.39/kernel/nvidia-uvm/uvm8_pmm_sysmem_test.o
CC [M] /tmp/selfgz2271/NVIDIA-Linux-x86_64-418.39/kernel/nvidia-uvm/uvm8_perf_events_test.o
CC [M] /tmp/selfgz2271/NVIDIA-Linux-x86_64-418.39/kernel/nvidia-uvm/uvm8_perf_module_test.o
CC [M] /tmp/selfgz2271/NVIDIA-Linux-x86_64-418.39/kernel/nvidia-uvm/uvm8_get_rm_ptes_test.o
CC [M] /tmp/selfgz2271/NVIDIA-Linux-x86_64-418.39/kernel/nvidia-uvm/uvm8_fault_buffer_flush_test.o
CC [M] /tmp/selfgz2271/NVIDIA-Linux-x86_64-418.39/kernel/nvidia-uvm/uvm8_mmu_test.o
CC [M] /tmp/selfgz2271/NVIDIA-Linux-x86_64-418.39/kernel/nvidia-uvm/uvm8_peer_identity_mappings_test.o
CC [M] /tmp/selfgz2271/NVIDIA-Linux-x86_64-418.39/kernel/nvidia-uvm/uvm8_va_block_test.o
CC [M] /tmp/selfgz2271/NVIDIA-Linux-x86_64-418.39/kernel/nvidia-uvm/uvm8_range_group_tree_test.o
CC [M] /tmp/selfgz2271/NVIDIA-Linux-x86_64-418.39/kernel/nvidia-modeset/nvidia-modeset-linux.o
CC [M] /tmp/selfgz2271/NVIDIA-Linux-x86_64-418.39/kernel/nvidia-drm/nvidia-drm.o
CC [M] /tmp/selfgz2271/NVIDIA-Linux-x86_64-418.39/kernel/nvidia-drm/nvidia-drm-drv.o
CC [M] /tmp/selfgz2271/NVIDIA-Linux-x86_64-418.39/kernel/nvidia-drm/nvidia-drm-utils.o
CC [M] /tmp/selfgz2271/NVIDIA-Linux-x86_64-418.39/kernel/nvidia-drm/nvidia-drm-crtc.o
CC [M] /tmp/selfgz2271/NVIDIA-Linux-x86_64-418.39/kernel/nvidia-drm/nvidia-drm-encoder.o
CC [M] /tmp/selfgz2271/NVIDIA-Linux-x86_64-418.39/kernel/nvidia-drm/nvidia-drm-connector.o
CC [M] /tmp/selfgz2271/NVIDIA-Linux-x86_64-418.39/kernel/nvidia-drm/nvidia-drm-gem.o
CC [M] /tmp/selfgz2271/NVIDIA-Linux-x86_64-418.39/kernel/nvidia-drm/nvidia-drm-fb.o
CC [M] /tmp/selfgz2271/NVIDIA-Linux-x86_64-418.39/kernel/nvidia-drm/nvidia-drm-modeset.o
CC [M] /tmp/selfgz2271/NVIDIA-Linux-x86_64-418.39/kernel/nvidia-drm/nvidia-drm-prime-fence.o
CC [M] /tmp/selfgz2271/NVIDIA-Linux-x86_64-418.39/kernel/nvidia-drm/nvidia-drm-linux.o
CC [M] /tmp/selfgz2271/NVIDIA-Linux-x86_64-418.39/kernel/nvidia-drm/nvidia-drm-helper.o
CC [M] /tmp/selfgz2271/NVIDIA-Linux-x86_64-418.39/kernel/nvidia-drm/nv-pci-table.o
CC [M] /tmp/selfgz2271/NVIDIA-Linux-x86_64-418.39/kernel/nvidia-drm/nvidia-drm-gem-nvkms-memory.o
CC [M] /tmp/selfgz2271/NVIDIA-Linux-x86_64-418.39/kernel/nvidia-drm/nvidia-drm-gem-user-memory.o
ld -r -o /tmp/selfgz2271/NVIDIA-Linux-x86_64-418.39/kernel/nvidia/nv-interface.o /tmp/selfgz2271/NVIDIA-Linux-x86_64-418.39/kernel/nvidia/nv-frontend.o /tmp/selfgz2271/NVIDIA-Linux-x86_64-418.39/kernel/nvidia/nv-instance.o /tmp/selfgz2271/NVIDIA-Linux-x86_64-418.39/kernel/nvidia/nv.o /tmp/selfgz2271/NVIDIA-Linux-x86_64-418.39/kernel/nvidia/nv-acpi.o /tmp/selfgz2271/NVIDIA-Linux-x86_64-418.39/kernel/nvidia/nv-chrdev.o /tmp/selfgz2271/NVIDIA-Linux-x86_64-418.39/kernel/nvidia/nv-cray.o /tmp/selfgz2271/NVIDIA-Linux-x86_64-418.39/kernel/nvidia/nv-dma.o /tmp/selfgz2271/NVIDIA-Linux-x86_64-418.39/kernel/nvidia/nv-gvi.o /tmp/selfgz2271/NVIDIA-Linux-x86_64-418.39/kernel/nvidia/nv-i2c.o /tmp/selfgz2271/NVIDIA-Linux-x86_64-418.39/kernel/nvidia/nv-mempool.o /tmp/selfgz2271/NVIDIA-Linux-x86_64-418.39/kernel/nvidia/nv-mmap.o /tmp/selfgz2271/NVIDIA-Linux-x86_64-418.39/kernel/nvidia/nv-p2p.o /tmp/selfgz2271/NVIDIA-Linux-x86_64-418.39/kernel/nvidia/nv-pat.o /tmp/selfgz2271/NV
IDIA-Linux-x86_64-418.39/kernel/nvidia/nv-procfs.o /tmp/selfgz2271/NVIDIA-Linux-x86_64-418.39/kernel/nvidia/nv-usermap.o /tmp/selfgz2271/NVIDIA-Linux-x86_64-418.39/kernel/nvidia/nv-vm.o /tmp/selfgz2271/NVIDIA-Linux-x86_64-418.39/kernel/nvidia/nv-vtophys.o /tmp/selfgz2271/NVIDIA-Linux-x86_64-418.39/kernel/nvidia/os-interface.o /tmp/selfgz2271/NVIDIA-Linux-x86_64-418.39/kernel/nvidia/os-mlock.o /tmp/selfgz2271/NVIDIA-Linux-x86_64-418.39/kernel/nvidia/os-pci.o /tmp/selfgz2271/NVIDIA-Linux-x86_64-418.39/kernel/nvidia/os-registry.o /tmp/selfgz2271/NVIDIA-Linux-x86_64-418.39/kernel/nvidia/os-usermap.o /tmp/selfgz2271/NVIDIA-Linux-x86_64-418.39/kernel/nvidia/nv-modeset-interface.o /tmp/selfgz2271/NVIDIA-Linux-x86_64-418.39/kernel/nvidia/nv-pci-table.o /tmp/selfgz2271/NVIDIA-Linux-x86_64-418.39/kernel/nvidia/nv-kthread-q.o /tmp/selfgz2271/NVIDIA-Linux-x86_64-418.39/kernel/nvidia/nv-kthread-q-selftest.o /tmp/selfgz2271/NVIDIA-Linux-x86_64-418.39/kernel/nvidia/nv-memdbg.o /tmp/selfgz2271/NVIDIA-Linux-x86_64-418.39/kern
el/nvidia/nv-ibmnpu.o /tmp/selfgz2271/NVIDIA-Linux-x86_64-418.39/kernel/nvidia/nv-report-err.o /tmp/selfgz2271/NVIDIA-Linux-x86_64-418.39/kernel/nvidia/nv-rsync.o /tmp/selfgz2271/NVIDIA-Linux-x86_64-418.39/kernel/nvidia/nv-msi.o /tmp/selfgz2271/NVIDIA-Linux-x86_64-418.39/kernel/nvidia/nv_uvm_interface.o /tmp/selfgz2271/NVIDIA-Linux-x86_64-418.39/kernel/nvidia/nvlink_linux.o /tmp/selfgz2271/NVIDIA-Linux-x86_64-418.39/kernel/nvidia/linux_nvswitch.o
ld -r -o /tmp/selfgz2271/NVIDIA-Linux-x86_64-418.39/kernel/nvidia-modeset/nv-modeset-interface.o /tmp/selfgz2271/NVIDIA-Linux-x86_64-418.39/kernel/nvidia-modeset/nvidia-modeset-linux.o
LD [M] /tmp/selfgz2271/NVIDIA-Linux-x86_64-418.39/kernel/nvidia.o
LD [M] /tmp/selfgz2271/NVIDIA-Linux-x86_64-418.39/kernel/nvidia-uvm.o
LD [M] /tmp/selfgz2271/NVIDIA-Linux-x86_64-418.39/kernel/nvidia-modeset.o
LD [M] /tmp/selfgz2271/NVIDIA-Linux-x86_64-418.39/kernel/nvidia-drm.o
Building modules, stage 2.
MODPOST 4 modules
CC /tmp/selfgz2271/NVIDIA-Linux-x86_64-418.39/kernel/nvidia-drm.mod.o
CC /tmp/selfgz2271/NVIDIA-Linux-x86_64-418.39/kernel/nvidia-modeset.mod.o
CC /tmp/selfgz2271/NVIDIA-Linux-x86_64-418.39/kernel/nvidia-uvm.mod.o
CC /tmp/selfgz2271/NVIDIA-Linux-x86_64-418.39/kernel/nvidia.mod.o
LD [M] /tmp/selfgz2271/NVIDIA-Linux-x86_64-418.39/kernel/nvidia-drm.ko
LD [M] /tmp/selfgz2271/NVIDIA-Linux-x86_64-418.39/kernel/nvidia-modeset.ko
LD [M] /tmp/selfgz2271/NVIDIA-Linux-x86_64-418.39/kernel/nvidia-uvm.ko
LD [M] /tmp/selfgz2271/NVIDIA-Linux-x86_64-418.39/kernel/nvidia.ko
→ done.
→ Kernel module compilation complete.
→ Kernel messages:
[ 13.748728] snd_hda_codec_realtek hdaudioC0D0: autoconfig for ALC236: line_outs=1 (0x14/0x0/0x0/0x0/0x0) type:speaker
[ 13.748730] snd_hda_codec_realtek hdaudioC0D0: speaker_outs=0 (0x0/0x0/0x0/0x0/0x0)
[ 13.748731] snd_hda_codec_realtek hdaudioC0D0: hp_outs=1 (0x21/0x0/0x0/0x0/0x0)
[ 13.748731] snd_hda_codec_realtek hdaudioC0D0: mono: mono_out=0x0
[ 13.748732] snd_hda_codec_realtek hdaudioC0D0: inputs:
[ 13.748733] snd_hda_codec_realtek hdaudioC0D0: Mic=0x19
[ 13.748734] snd_hda_codec_realtek hdaudioC0D0: Internal Mic=0x12
[ 14.028258] snd_hda_codec_hdmi hdaudioC0D2: No i915 binding for Intel HDMI/DP codec
[ 14.028587] hdaudio hdaudioC0D2: Unable to bind the codec
[ 14.028742] input: HDA Intel PCH Mic as /devices/pci0000:00/0000:00:1f.3/sound/card0/input17
[ 14.028787] input: HDA Intel PCH Headphone as /devices/pci0000:00/0000:00:1f.3/sound/card0/input18
[ 269.147762] [drm] [nvidia-drm] [GPU ID 0x00000100] Unloading driver
[ 269.255644] nvidia-modeset: Unloading
[ 269.329725] nvidia-nvlink: Unregistered the Nvlink Core, major device number 234
[ 283.127852] nvidia-nvlink: Nvlink Core is being initialized, major device number 234
[ 283.128120] nvidia 0000:01:00.0: vgaarb: changed VGA decodes: olddecodes=none,decodes=none:owns=none
[ 283.227519] NVRM: loading NVIDIA UNIX x86_64 Kernel Module 418.39 Sat Feb 9 19:19:37 CST 2019
[ 283.231214] nvidia-uvm: Loaded the UVM driver in 8 mode, major device number 510
[ 283.232244] nvidia-modeset: Loading NVIDIA Kernel Mode Setting Driver for UNIX platforms 418.39 Sat Feb 9 19:13:33 CST 2019
[ 283.234162] [drm] [nvidia-drm] [GPU ID 0x00000100] Loading driver
[ 283.234164] [drm] Initialized nvidia-drm 0.0.0 20160202 for 0000:01:00.0 on minor 0
[ 283.235296] [drm] [nvidia-drm] [GPU ID 0x00000100] Unloading driver
[ 283.296263] nvidia-modeset: Unloading
[ 283.486227] nvidia-uvm: Unloaded the UVM driver in 8 mode
[ 283.514227] nvidia-nvlink: Unregistered the Nvlink Core, major device number 234
→ Install NVIDIA’s 32-bit compatibility libraries? (Answer: Yes)
→ Will install GLVND GLX client libraries.
→ Will install GLVND EGL client libraries.
→ Skipping GLX non-GLVND file: “libGL.so.418.39”
→ Skipping GLX non-GLVND file: “libGL.so.1”
→ Skipping GLX non-GLVND file: “libGL.so”
→ Skipping EGL non-GLVND file: “libEGL.so.418.39”
→ Skipping EGL non-GLVND file: “libEGL.so”
→ Skipping EGL non-GLVND file: “libEGL.so.1”
→ Skipping GLX non-GLVND file: “./32/libGL.so.418.39”
→ Skipping EGL non-GLVND file: “./32/libEGL.so.418.39”
→ Uninstalling the previous installation with /usr/bin/nvidia-uninstall.
Will install libglvnd libraries.
Will install libEGL vendor library config file to /usr/share/glvnd/egl_vendor.d
→ Searching for conflicting files:
→ done.
→ Installing ‘NVIDIA Accelerated Graphics Driver for Linux-x86_64’ (418.39):
executing: ‘/sbin/ldconfig’…
executing: '/sbin/depmod -a '…
→ done.
→ Driver file installation is complete.
→ Running post-install sanity check:
→ done.
→ Post-install sanity check passed.
→ Running runtime sanity check:
→ done.
→ Runtime sanity check passed.
→ Would you like to run the nvidia-xconfig utility to automatically update your X configuration file so that the NVIDIA X driver will be used when you restart X? Any pre-existing X configuration file will be backed up. (Answer: No)
→ Installation of the NVIDIA Accelerated Graphics Driver for Linux-x86_64 (version: 418.39) is now complete. Please update your xorg.conf file as appropriate; see the file /usr/share/doc/NVIDIA_GLX-1.0/README.txt for details.
*** /var/log/nvidia-uninstall.log
*** ls: -rw-r–r-- 1 root root 1160 2019-04-29 14:25:35.666042780 +0800 /var/log/nvidia-uninstall.log
nvidia-installer log file ‘/var/log/nvidia-uninstall.log’
creation time: Mon Apr 29 14:25:33 2019
-s
–log-file-name=/var/log/nvidia-uninstall.log
–skip-depmod
→ If you plan to no longer use the NVIDIA driver, you should make sure that no X screens are configured to use the NVIDIA X driver in your X configuration file. If you used nvidia-xconfig to configure X, it may have created a backup of your original configuration. Would you like to run nvidia-xconfig --restore-original-backup to attempt restoration of the original X configuration file? (Answer: No)
→ Parsing log file:
→ done.
→ Validating previous installation:
→ done.
→ Uninstalling NVIDIA Accelerated Graphics Driver for Linux-x86_64 (1.0-41839 (418.39)):
→ done.
→ Running ldconfig:
→ done.
→ Uninstallation of existing driver: NVIDIA Accelerated Graphics Driver for Linux-x86_64 (418.39) is complete.
journalctl -b -0 _COMM=Xorg
– Logs begin at Fri 2019-01-04 12:50:41 CST, end at Tue 2019-04-30 12:04:25 CST. –
– No entries –
journalctl -b -1 _COMM=Xorg
– No entries –
journalctl -b -2 _COMM=Xorg
– No entries –
journalctl -b -0 _COMM=Xorg.bin
– No entries –
journalctl -b -1 _COMM=Xorg.bin
– No entries –
journalctl -b -2 _COMM=Xorg.bin
– No entries –
– No entries –
– No entries –
– No entries –
*** /var/log/Xorg.0.log
*** ls: -rw-r–r-- 1 root root 20168 2019-04-30 09:50:14.558911594 +0800 /var/log/Xorg.0.log
[ 4.299]
X.Org X Server 1.20.4
X Protocol Version 11, Revision 0
[ 4.299] Build Operating System: Linux 4.4.0-143-generic x86_64 Ubuntu
[ 4.300] Current Operating System: Linux y7k 5.0.0-050000-generic #201903032031 SMP Mon Mar 4 01:33:18 UTC 2019 x86_64
[ 4.300] Kernel command line: BOOT_IMAGE=/vmlinuz-5.0.0-050000-generic root=UUID=6add1581-e550-4c5c-b7af-4bd8a57d7f7d ro quiet splash nomodeset acpi_blacklight=vendor acpi_osi=inux vt.handoff=1
[ 4.300] Build Date: 03 April 2019 09:03:57AM
[ 4.300] xorg-server 2:1.20.4-1ubuntu3 (For technical support please see Enterprise open source support | Ubuntu)
[ 4.300] Current version of pixman: 0.36.0
[ 4.300] Before reporting problems, check http://wiki.x.org
to make sure that you have the latest version.
[ 4.300] Markers: (–) probed, () from config file, (==) default setting,
(++) from command line, (!!) notice, (II) informational,
(WW) warning, (EE) error, (NI) not implemented, (??) unknown.
[ 4.300] (==) Log file: “/var/log/Xorg.0.log”, Time: Tue Apr 30 09:49:07 2019
[ 4.300] (==) Using system config directory “/usr/share/X11/xorg.conf.d”
[ 4.302] (==) No Layout section. Using the first Screen section.
[ 4.302] (==) No screen section available. Using defaults.
[ 4.302] (
) |–>Screen “Default Screen Section” (0)
[ 4.302] (**) | |–>Monitor “”
[ 4.303] (==) No monitor specified for screen “Default Screen Section”.
Using a default monitor configuration.
[ 4.303] (==) Automatically adding devices
[ 4.303] (==) Automatically enabling devices
[ 4.303] (==) Automatically adding GPU devices
[ 4.303] (==) Automatically binding GPU devices
[ 4.303] (==) Max clients allowed: 256, resource mask: 0x1fffff
[ 4.304] (WW) The directory “/usr/share/fonts/X11/cyrillic” does not exist.
[ 4.304] Entry deleted from font path.
[ 4.304] (WW) The directory “/usr/share/fonts/X11/100dpi/” does not exist.
[ 4.304] (WW) The directory “/usr/share/fonts/X11/75dpi/” does not exist.
[ 4.304] (WW) The directory “/usr/share/fonts/X11/100dpi” does not exist.
[ 4.304] (WW) The directory “/usr/share/fonts/X11/75dpi” does not exist.
[ 4.304] (==) FontPath set to:
/usr/share/fonts/X11/misc,
/usr/share/fonts/X11/Type1,
built-ins
[ 4.304] (==) ModulePath set to “/usr/lib/xorg/modules”
[ 4.304] (II) The server relies on udev to provide the list of input devices.
If no devices become available, reconfigure udev or disable AutoAddDevices.
[ 4.304] (II) Loader magic: 0x55ae218c3020
[ 4.304] (II) Module ABI versions:
[ 4.304] X.Org ANSI C Emulation: 0.4
[ 4.304] X.Org Video Driver: 24.0
[ 4.304] X.Org XInput driver : 24.1
[ 4.304] X.Org Server Extension : 10.0
[ 4.305] (++) using VT number 7
[ 4.305] (II) systemd-logind: logind integration requires -keeptty and -keeptty was not provided, disabling logind integration
[ 4.307] (–) PCI:*(0@0:2:0) 8086:3e9b:17aa:39f5 rev 0, Mem @ 0xa2000000/16777216, 0xb0000000/268435456, I/O @ 0x00005000/64, BIOS @ 0x???/131072
[ 4.307] (–) PCI: (1@0:0:0) 10de:1c20:17aa:39f5 rev 161, Mem @ 0xa3000000/16777216, 0x90000000/268435456, 0xa0000000/33554432, I/O @ 0x00004000/128, BIOS @ 0x???/524288
[ 4.307] (II) LoadModule: “glx”
[ 4.308] (II) Loading /usr/lib/xorg/modules/extensions/libglx.so
[ 4.313] (II) Module glx: vendor=“X.Org Foundation”
[ 4.313] compiled for 1.20.4, module version = 1.0.0
[ 4.313] ABI class: X.Org Server Extension, version 10.0
[ 4.313] (==) Matched modesetting as autoconfigured driver 0
[ 4.314] (==) Matched fbdev as autoconfigured driver 1
[ 4.314] (==) Matched vesa as autoconfigured driver 2
[ 4.314] (==) Assigned the driver to the xf86ConfigLayout
[ 4.314] (II) LoadModule: “modesetting”
[ 4.314] (II) Loading /usr/lib/xorg/modules/drivers/modesetting_drv.so
[ 4.314] (II) Module modesetting: vendor=“X.Org Foundation”
[ 4.314] compiled for 1.20.4, module version = 1.20.4
[ 4.314] Module class: X.Org Video Driver
[ 4.314] ABI class: X.Org Video Driver, version 24.0
[ 4.314] (II) LoadModule: “fbdev”
[ 4.314] (II) Loading /usr/lib/xorg/modules/drivers/fbdev_drv.so
[ 4.315] (II) Module fbdev: vendor=“X.Org Foundation”
[ 4.315] compiled for 1.20.1, module version = 0.5.0
[ 4.315] Module class: X.Org Video Driver
[ 4.315] ABI class: X.Org Video Driver, version 24.0
[ 4.315] (II) LoadModule: “vesa”
[ 4.315] (II) Loading /usr/lib/xorg/modules/drivers/vesa_drv.so
[ 4.315] (II) Module vesa: vendor=“X.Org Foundation”
[ 4.315] compiled for 1.20.4, module version = 2.4.0
[ 4.315] (II) modesetting: Driver for Modesetting Kernel Drivers: kms
[ 4.315] (II) FBDEV: driver for framebuffer: fbdev
[ 4.315] (II) VESA: driver for VESA chipsets: vesa
[ 4.319] (EE) open /dev/dri/card0: No such file or directory
[ 4.319] (WW) Falling back to old probe method for modesetting
[ 4.319] (II) Loading sub module “fbdevhw”
[ 4.319] (II) LoadModule: “fbdevhw”
[ 4.319] (II) Loading /usr/lib/xorg/modules/libfbdevhw.so
[ 4.319] (II) Module fbdevhw: vendor=“X.Org Foundation”
[ 4.319] compiled for 1.20.4, module version = 0.0.2
[ 4.319] ABI class: X.Org Video Driver, version 24.0
[ 4.319] () FBDEV(1): claimed PCI slot 0@0:2:0
[ 4.319] (II) FBDEV(1): using default device
[ 4.319] (EE) Screen 0 deleted because of no matching config section.
[ 4.319] (II) UnloadModule: “modesetting”
[ 4.319] (II) FBDEV(0): Creating default Display subsection in Screen section
“Default Screen Section” for depth/fbbpp 24/32
[ 4.319] (==) FBDEV(0): Depth 24, (==) framebuffer bpp 32
[ 4.319] (==) FBDEV(0): RGB weight 888
[ 4.319] (==) FBDEV(0): Default visual is TrueColor
[ 4.319] (==) FBDEV(0): Using gamma correction (1.0, 1.0, 1.0)
[ 4.319] (II) FBDEV(0): hardware: EFI VGA (video memory: 8128kB)
[ 4.319] (II) FBDEV(0): checking modes against framebuffer device…
[ 4.319] (II) FBDEV(0): checking modes against monitor…
[ 4.319] (II) FBDEV(0): Virtual size is 1920x1080 (pitch 1920)
[ 4.319] (
) FBDEV(0): Built-in mode “current”: 207.4 MHz, 85.3 kHz, 77.2 Hz
[ 4.319] (II) FBDEV(0): Modeline "current"x0.0 207.38 1920 1952 2192 2432 1080 1084 1088 1104 -hsync -vsync -csync (85.3 kHz b)
[ 4.319] (==) FBDEV(0): DPI set to (96, 96)
[ 4.319] (II) Loading sub module “fb”
[ 4.319] (II) LoadModule: “fb”
[ 4.319] (II) Loading /usr/lib/xorg/modules/libfb.so
[ 4.319] (II) Module fb: vendor=“X.Org Foundation”
[ 4.319] compiled for 1.20.4, module version = 1.0.0
[ 4.319] ABI class: X.Org ANSI C Emulation, version 0.4
[ 4.319] () FBDEV(0): using shadow framebuffer
[ 4.319] (II) Loading sub module “shadow”
[ 4.319] (II) LoadModule: “shadow”
[ 4.320] (II) Loading /usr/lib/xorg/modules/libshadow.so
[ 4.320] (II) Module shadow: vendor=“X.Org Foundation”
[ 4.320] compiled for 1.20.4, module version = 1.1.0
[ 4.320] ABI class: X.Org ANSI C Emulation, version 0.4
[ 4.320] (II) UnloadModule: “vesa”
[ 4.320] (II) Unloading vesa
[ 4.320] (II) FBDEV(0): FBIOBLANK: Invalid argument (Screen blanking not supported by kernel - disabling)
[ 4.321] (==) FBDEV(0): Backing store enabled
[ 4.321] (==) FBDEV(0): DPMS enabled
[ 4.321] (II) Found 2 VGA devices: arbiter wrapping enabled
[ 4.321] (II) Initializing extension Generic Event Extension
[ 4.321] (II) Initializing extension SHAPE
[ 4.321] (II) Initializing extension MIT-SHM
[ 4.321] (II) Initializing extension XInputExtension
[ 4.322] (II) Initializing extension XTEST
[ 4.322] (II) Initializing extension BIG-REQUESTS
[ 4.322] (II) Initializing extension SYNC
[ 4.322] (II) Initializing extension XKEYBOARD
[ 4.322] (II) Initializing extension XC-MISC
[ 4.322] (II) Initializing extension SECURITY
[ 4.322] (II) Initializing extension XFIXES
[ 4.322] (II) Initializing extension RENDER
[ 4.323] (II) Initializing extension RANDR
[ 4.323] (II) Initializing extension COMPOSITE
[ 4.323] (II) Initializing extension DAMAGE
[ 4.323] (II) Initializing extension MIT-SCREEN-SAVER
[ 4.323] (II) Initializing extension DOUBLE-BUFFER
[ 4.323] (II) Initializing extension RECORD
[ 4.323] (II) Initializing extension DPMS
[ 4.323] (II) Initializing extension Present
[ 4.323] (II) Initializing extension DRI3
[ 4.323] (II) Initializing extension X-Resource
[ 4.323] (II) Initializing extension XVideo
[ 4.323] (II) Initializing extension XVideo-MotionCompensation
[ 4.323] (II) Initializing extension SELinux
[ 4.323] (II) SELinux: Disabled on system
[ 4.323] (II) Initializing extension GLX
[ 4.323] (II) AIGLX: Screen 0 is not DRI2 capable
[ 4.382] (II) IGLX: Loaded and initialized swrast
[ 4.382] (II) GLX: Initialized DRISWRAST GL provider for screen 0
[ 4.382] (II) Initializing extension XFree86-VidModeExtension
[ 4.382] (II) Initializing extension XFree86-DGA
[ 4.382] (II) Initializing extension XFree86-DRI
[ 4.382] (II) Initializing extension DRI2
[ 4.417] (II) config/udev: Adding input device Power Button (/dev/input/event1)
[ 4.417] (
) Power Button: Applying InputClass “libinput keyboard catchall”
[ 4.417] (II) LoadModule: “libinput”
[ 4.417] (II) Loading /usr/lib/xorg/modules/input/libinput_drv.so
[ 4.419] (II) Module libinput: vendor=“X.Org Foundation”
[ 4.419] compiled for 1.20.4, module version = 0.28.2
[ 4.419] Module class: X.Org XInput Driver
[ 4.419] ABI class: X.Org XInput driver, version 24.1
[ 4.419] (II) Using input driver ‘libinput’ for ‘Power Button’
[ 4.419] () Power Button: always reports core events
[ 4.419] (
) Option “Device” “/dev/input/event1”
[ 4.419] () Option “_source” “server/udev”
[ 4.422] (II) event1 - Power Button: is tagged by udev as: Keyboard
[ 4.422] (II) event1 - Power Button: device is a keyboard
[ 4.422] (II) event1 - Power Button: device removed
[ 4.445] (
) Option “config_info” “udev:/sys/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0C:00/input/input1/event1”
[ 4.445] (II) XINPUT: Adding extended input device “Power Button” (type: KEYBOARD, id 6)
[ 4.445] () Option “xkb_model” “pc105”
[ 4.445] (
) Option “xkb_layout” “us”
[ 4.446] (II) event1 - Power Button: is tagged by udev as: Keyboard
[ 4.446] (II) event1 - Power Button: device is a keyboard
[ 4.446] (II) config/udev: Adding input device Lid Switch (/dev/input/event0)
[ 4.446] (II) No input driver specified, ignoring this device.
[ 4.446] (II) This device may have been added with another device file.
[ 4.446] (II) config/udev: Adding input device Sleep Button (/dev/input/event2)
[ 4.446] () Sleep Button: Applying InputClass “libinput keyboard catchall”
[ 4.446] (II) Using input driver ‘libinput’ for ‘Sleep Button’
[ 4.446] (
) Sleep Button: always reports core events
[ 4.446] () Option “Device” “/dev/input/event2”
[ 4.446] (
[ 4.447] (II) event2 - Sleep Button: is tagged by udev as: Keyboard
[ 4.447] (II) event2 - Sleep Button: device is a keyboard
[ 4.447] (II) event2 - Sleep Button: device removed
[ 4.477] () Option “config_info” “udev:/sys/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0E:00/input/input2/event2”
[ 4.477] (II) XINPUT: Adding extended input device “Sleep Button” (type: KEYBOARD, id 7)
[ 4.477] (
[ 4.477] () Option “xkb_layout” “us”
[ 4.478] (II) event2 - Sleep Button: is tagged by udev as: Keyboard
[ 4.478] (II) event2 - Sleep Button: device is a keyboard
[ 4.478] (II) config/udev: Adding input device Logitech MX Anywhere 2S (/dev/input/event6)
[ 4.478] (
) Logitech MX Anywhere 2S: Applying InputClass “libinput pointer catchall”
[ 4.478] () Logitech MX Anywhere 2S: Applying InputClass “libinput keyboard catchall”
[ 4.478] (II) Using input driver ‘libinput’ for ‘Logitech MX Anywhere 2S’
[ 4.478] (
) Logitech MX Anywhere 2S: always reports core events
[ 4.478] () Option “Device” “/dev/input/event6”
[ 4.478] (
[ 4.479] (II) event6 - Logitech MX Anywhere 2S: is tagged by udev as: Keyboard Mouse
[ 4.479] (II) event6 - Logitech MX Anywhere 2S: device is a pointer
[ 4.479] (II) event6 - Logitech MX Anywhere 2S: device is a keyboard
[ 4.479] (II) event6 - Logitech MX Anywhere 2S: device removed
[ 4.493] (II) libinput: Logitech MX Anywhere 2S: needs a virtual subdevice
[ 4.493] () Option “config_info” “udev:/sys/devices/pci0000:00/0000:00:14.0/usb1/1-3/1-3:1.2/0003:046D:C52B.0004/0003:046D:406A.0005/input/input13/event6”
[ 4.493] (II) XINPUT: Adding extended input device “Logitech MX Anywhere 2S” (type: MOUSE, id 8)
[ 4.494] (
) Option “AccelerationScheme” “none”
[ 4.494] () Logitech MX Anywhere 2S: (accel) selected scheme none/0
[ 4.494] (
) Logitech MX Anywhere 2S: (accel) acceleration factor: 2.000
[ 4.494] () Logitech MX Anywhere 2S: (accel) acceleration threshold: 4
[ 4.494] (II) event6 - Logitech MX Anywhere 2S: is tagged by udev as: Keyboard Mouse
[ 4.494] (II) event6 - Logitech MX Anywhere 2S: device is a pointer
[ 4.495] (II) event6 - Logitech MX Anywhere 2S: device is a keyboard
[ 4.495] (II) config/udev: Adding input device Logitech MX Anywhere 2S (/dev/input/mouse2)
[ 4.495] (II) No input driver specified, ignoring this device.
[ 4.495] (II) This device may have been added with another device file.
[ 4.495] (II) config/udev: Adding input device Integrated Camera: Integrated C (/dev/input/event4)
[ 4.495] (
) Integrated Camera: Integrated C: Applying InputClass “libinput keyboard catchall”
[ 4.495] (II) Using input driver ‘libinput’ for ‘Integrated Camera: Integrated C’
[ 4.495] () Integrated Camera: Integrated C: always reports core events
[ 4.495] (
) Option “Device” “/dev/input/event4”
[ 4.495] () Option “_source” “server/udev”
[ 4.496] (II) event4 - Integrated Camera: Integrated C: is tagged by udev as: Keyboard
[ 4.496] (II) event4 - Integrated Camera: Integrated C: device is a keyboard
[ 4.496] (II) event4 - Integrated Camera: Integrated C: device removed
[ 4.525] (
) Option “config_info” “udev:/sys/devices/pci0000:00/0000:00:14.0/usb1/1-6/1-6:1.0/input/input14/event4”
[ 4.525] (II) XINPUT: Adding extended input device “Integrated Camera: Integrated C” (type: KEYBOARD, id 9)
[ 4.525] () Option “xkb_model” “pc105”
[ 4.525] (
[ 4.526] (II) event4 - Integrated Camera: Integrated C: is tagged by udev as: Keyboard
[ 4.526] (II) event4 - Integrated Camera: Integrated C: device is a keyboard
[ 4.527] (II) config/udev: Adding input device ELAN061B:00 04F3:304B Touchpad (/dev/input/event5)
[ 4.527] () ELAN061B:00 04F3:304B Touchpad: Applying InputClass “libinput touchpad catchall”
[ 4.527] (II) Using input driver ‘libinput’ for ‘ELAN061B:00 04F3:304B Touchpad’
[ 4.527] (
) ELAN061B:00 04F3:304B Touchpad: always reports core events
[ 4.527] () Option “Device” “/dev/input/event5”
[ 4.527] (
[ 4.528] (II) event5 - ELAN061B:00 04F3:304B Touchpad: is tagged by udev as: Touchpad
[ 4.529] (II) event5 - ELAN061B:00 04F3:304B Touchpad: device is a touchpad
[ 4.529] (II) event5 - ELAN061B:00 04F3:304B Touchpad: device removed
[ 4.561] () Option “config_info” “udev:/sys/devices/pci0000:00/0000:00:15.1/i2c_designware.1/i2c-2/i2c-ELAN061B:00/0018:04F3:304B.0001/input/input16/event5”
[ 4.561] (II) XINPUT: Adding extended input device “ELAN061B:00 04F3:304B Touchpad” (type: TOUCHPAD, id 10)
[ 4.562] (
[ 4.562] () ELAN061B:00 04F3:304B Touchpad: (accel) selected scheme none/0
[ 4.562] (
) ELAN061B:00 04F3:304B Touchpad: (accel) acceleration factor: 2.000
[ 4.562] () ELAN061B:00 04F3:304B Touchpad: (accel) acceleration threshold: 4
[ 4.563] (II) event5 - ELAN061B:00 04F3:304B Touchpad: is tagged by udev as: Touchpad
[ 4.563] (II) event5 - ELAN061B:00 04F3:304B Touchpad: device is a touchpad
[ 4.564] (II) config/udev: Adding input device ELAN061B:00 04F3:304B Touchpad (/dev/input/mouse0)
[ 4.564] (II) No input driver specified, ignoring this device.
[ 4.564] (II) This device may have been added with another device file.
[ 4.564] (II) config/udev: Adding input device AT Translated Set 2 keyboard (/dev/input/event3)
[ 4.564] (
) AT Translated Set 2 keyboard: Applying InputClass “libinput keyboard catchall”
[ 4.564] (II) Using input driver ‘libinput’ for ‘AT Translated Set 2 keyboard’
[ 4.564] () AT Translated Set 2 keyboard: always reports core events
[ 4.564] (
) Option “Device” “/dev/input/event3”
[ 4.564] () Option “_source” “server/udev”
[ 4.565] (II) event3 - AT Translated Set 2 keyboard: is tagged by udev as: Keyboard
[ 4.565] (II) event3 - AT Translated Set 2 keyboard: device is a keyboard
[ 4.565] (II) event3 - AT Translated Set 2 keyboard: device removed
[ 4.585] (
) Option “config_info” “udev:/sys/devices/platform/i8042/serio0/input/input3/event3”
[ 4.586] (II) XINPUT: Adding extended input device “AT Translated Set 2 keyboard” (type: KEYBOARD, id 11)
[ 4.586] () Option “xkb_model” “pc105”
[ 4.586] (
[ 4.586] (II) event3 - AT Translated Set 2 keyboard: is tagged by udev as: Keyboard
[ 4.586] (II) event3 - AT Translated Set 2 keyboard: device is a keyboard
[ 4.589] () Logitech MX Anywhere 2S: Applying InputClass “libinput pointer catchall”
[ 4.589] (
[ 4.589] (II) Using input driver ‘libinput’ for ‘Logitech MX Anywhere 2S’
[ 4.589] () Logitech MX Anywhere 2S: always reports core events
[ 4.589] (
[ 4.589] () Option “_source” “_driver/libinput”
[ 4.589] (II) libinput: Logitech MX Anywhere 2S: is a virtual subdevice
[ 4.589] (
[ 4.589] (II) XINPUT: Adding extended input device “Logitech MX Anywhere 2S” (type: KEYBOARD, id 12)
[ 4.589] () Option “xkb_model” “pc105”
[ 4.589] (
[ 14.064] (II) config/udev: Adding input device HDA Intel PCH Mic (/dev/input/event7)
[ 14.064] (II) No input driver specified, ignoring this device.
[ 14.064] (II) This device may have been added with another device file.
[ 14.072] (II) config/udev: Adding input device HDA Intel PCH Headphone (/dev/input/event8)
[ 14.072] (II) No input driver specified, ignoring this device.
[ 14.072] (II) This device may have been added with another device file.
[ 71.070] (EE) event5 - ELAN061B:00 04F3:304B Touchpad: kernel bug: Touch jump detected and discarded.
See Touchpad jumping cursor bugs — libinput 1.12.6 documentation for details
*** /usr/share/X11/xorg.conf.d/10-amdgpu.conf
*** ls: -rw-r–r-- 1 root root 92 2019-04-07 04:02:05.000000000 +0800 /usr/share/X11/xorg.conf.d/10-amdgpu.conf
Section “OutputClass”
Identifier “AMDgpu”
MatchDriver “amdgpu”
Driver “amdgpu”
EndSection
*** /usr/share/X11/xorg.conf.d/10-quirks.conf
*** ls: -rw-r–r-- 1 root root 1350 2019-04-03 17:03:57.000000000 +0800 /usr/share/X11/xorg.conf.d/10-quirks.conf
Collection of quirks and blacklist/whitelists for specific devices.
Accelerometer device, posts data through ABS_X/ABS_Y, making X unusable
22442 – ThinkPad HDAPS accelerometer gets recognized as MOUSE and makes Xorg unusable
Section “InputClass”
Identifier “ThinkPad HDAPS accelerometer blacklist”
MatchProduct “ThinkPad HDAPS accelerometer data”
Option “Ignore” “on”
EndSection
523914 – Mouse does not move in PV Xen guest under RHEL-5.4
Explicitly tell evdev to not ignore the absolute axes.
Identifier “Xen Virtual Pointer axis blacklist”
MatchProduct “Xen Virtual Pointer”
Option “IgnoreAbsoluteAxes” “off”
Option “IgnoreRelativeAxes” “off”
EndSection
55867 – Doesn't know how to tag XI_TRACKBALL
Bug 55867 - Doesn’t know how to tag XI_TRACKBALL
Identifier “Tag trackballs as XI_TRACKBALL”
MatchProduct “trackball”
MatchDriver “evdev”
Option “TypeName” “TRACKBALL”
EndSection
62831 – Mionix Naos 5000 mouse detected incorrectly
Bug 62831 - Mionix Naos 5000 mouse detected incorrectly
Identifier “Tag Mionix Naos 5000 mouse XI_MOUSE”
MatchProduct “La-VIEW Technology Naos 5000 Mouse”
MatchDriver “evdev”
Option “TypeName” “MOUSE”
EndSection
*** /usr/share/X11/xorg.conf.d/10-radeon.conf
*** ls: -rw-r–r-- 1 root root 92 2019-03-28 19:15:14.000000000 +0800 /usr/share/X11/xorg.conf.d/10-radeon.conf
Identifier “Radeon”
MatchDriver “radeon”
Driver “radeon”
EndSection
*** /usr/share/X11/xorg.conf.d/11-nvidia-prime.conf
*** ls: -rw-r–r-- 1 root root 329 2019-04-27 10:46:41.212001852 +0800 /usr/share/X11/xorg.conf.d/11-nvidia-prime.conf
DO NOT EDIT. AUTOMATICALLY GENERATED BY gpu-manager
Identifier “Nvidia Prime”
MatchDriver “nvidia-drm”
Driver “nvidia”
Option “AllowEmptyInitialConfiguration”
Option “IgnoreDisplayDevices” “CRT”
Option “PrimaryGPU” “Yes”
ModulePath “/x86_64-linux-gnu/nvidia/xorg”
EndSection
*** /usr/share/X11/xorg.conf.d/40-libinput.conf
*** ls: -rw-r–r-- 1 root root 1429 2019-03-31 09:56:52.000000000 +0800 /usr/share/X11/xorg.conf.d/40-libinput.conf
Match on all types of devices but joysticks
If you want to configure your devices, do not copy this file.
Instead, use a config snippet that contains something like this:
Identifier “something or other”
MatchDriver “libinput”
MatchIsTouchpad “on”
… other Match directives …
Option “someoption” “value”
EndSection
This applies the option any libinput device also matched by the other
directives. See the xorg.conf(5) man page for more info on
matching devices.
Identifier “libinput pointer catchall”
MatchIsPointer “on”
MatchDevicePath “/dev/input/event*”
Driver “libinput”
EndSection
Identifier “libinput keyboard catchall”
MatchIsKeyboard “on”
Driver “libinput”
EndSection
Identifier “libinput touchpad catchall”
Driver “libinput”
EndSection
Identifier “libinput touchscreen catchall”
MatchIsTouchscreen “on”
Driver “libinput”
EndSection
Identifier “libinput tablet catchall”
MatchIsTablet “on”
Driver “libinput”
EndSection
*** /usr/share/X11/xorg.conf.d/70-wacom.conf
*** ls: -rw-r–r-- 1 root root 3039 2019-04-12 15:26:53.000000000 +0800 /usr/share/X11/xorg.conf.d/70-wacom.conf
Some of the below input classes appear 3x times, once for each of
“tablet”, “touchscreen”, and “touchpad” to ensure that the Wacom
driver is not accidentally bound to other types of hardware that
Wacom has made which are not handled by the wacom driver (e.g the
Wacom Bluetooth Keyboard)
Linux Wacom Tablet Project / Bugs / #294 Wacom Bluetooth Keyboard mistakenly bound to xf86-input-wacom driver
Identifier “Wacom USB tablet class”
MatchUSBID “056a:"
MatchDevicePath "/dev/input/event
MatchIsTablet “true”
Driver “wacom”
EndSection
#Section “InputClass”
Identifier “Wacom USB touchscreen class”
MatchUSBID “056a:*”
MatchIsTouchscreen “true”
Driver “wacom”
#EndSection
Identifier “Wacom USB touchpad class”
MatchUSBID “056a:"
MatchIsTouchpad “true”
Driver “wacom”
EndSection
Identifier “Wacom tablet class”
MatchProduct “Wacom|WACOM|PTK-540WL|ISD-V4”
Driver “wacom”
EndSection
Identifier “Wacom touchscreen class”
Driver “wacom”
#EndSection
Identifier “Wacom touchpad class”
Driver “wacom”
EndSection
Serial Wacom devices should always be one of tablet, touchscreen, or
touchpad so we can safely get away with just one match section in
these cases
Identifier “Wacom PnP device class”
MatchPnPID “WACf*|WCOM*|WACM*|FUJ02e5|FUJ02e7|FUJ02e9”
Driver “wacom”
EndSection
Identifier “Wacom serial class”
MatchProduct “Serial Wacom Tablet”
Driver “wacom”
EndSection
Identifier “Wacom serial class identifiers”
MatchProduct “WACf|FUJ02e5|FUJ02e7|FUJ02e9”
Driver “wacom”
EndSection
Hanwang tablets
Identifier “Hanwang class”
MatchProduct “Hanwang”
Driver “wacom”
EndSection
Waltop tablets
Identifier “Waltop class”
MatchProduct “WALTOP”
MatchIsTablet “on”
Driver “wacom”
EndSection
N-Trig Duosense Electromagnetic Digitizer
Identifier “Wacom N-Trig class”
MatchProduct “HID 1b96:0001|N-Trig Pen|N-Trig DuoSense”
Driver “wacom”
Option “Button2” “3”
EndSection
Dell Canvas 27 (touch part is an Advanced Silicon, pen part a Wacom)
Identifier “Dell Canvas 27 Touch”
MatchUSBID “2575:0204”
MatchIsTouc
nvidia-bug-report.log.gz (78 KB)
It’s an Optimus notebook, so you can’t use the .run installer.
Please follow this:
  • remove the .run installer driver using the --uninstall option
  • remove the kernel parameter ‘nomodeset’
  • add the ubuntu graphics ppa [url]https://launchpad.net/~graphics-drivers/+archive/ubuntu/ppa[/url]
  • install the driver from there (sudo apt install nvidia-driver-430)
  • install nvidia-prime (sudo apt install nvidia-prime)
  • switch to nvidia (sudo prime-select nvidia)
  • remove stray blacklist files (sudo rm /lib/modprobe.d/blacklist-nvidia.conf /etc/modprobe.d/blacklist-nvidia.conf)
  • update the initrd (sudo update-initramfs -u)
  • reboot
    If this doesn’t resolve the issue, please create a new nvidia-bug-report.log.
