Video driver provided by CUDA toolkit fails to compile: Fedora 29, kernel 5.1.21
I have a Lenovo W530 with Quaddro K1000M gpu that has been happily running the Nvidia driver v. 418.88. But now I want to install the CUDA toolkit, and the one that downloads (10.1) includes the 418.67 driver. So I uninstalled 418.88, and following the instructions in the Linux install guide, installed cuda using the dnf package manager. However, this version of the driver module fails to compile. The log is attached as well as the output of nvidia-bug-report.sh.
Hope you can help,
Bob Shelby
IBM Almaden Research Ctr.
418.67-1-for-5.1.21-200.fc29.x86_64.failed.log …
2019/08/09 15:28:49 akmods: Building RPM using the command ‘/sbin/akmodsbuild --kernels 5.1.21-200.fc29.x86_64 /usr/src/akmods/nvidia-kmod.latest’
/tmp/akmodsbuild.K1VY6VgX/BUILD/nvidia-kmod-418.67-x86_64/_kmod_build_5.1.21-200.fc29.x86_64/nvidia-uvm/uvm8.c:187:14: error: initialization of ‘vm_fault_t (*)(struct vm_fault )’ {aka 'unsigned int ()(struct vm_fault )'} from incompatible pointer type 'int ()(struct vm_fault )’ [-Werror=incompatible-pointer-types]
.fault = uvm_vm_fault_sigbus_wrapper
/tmp/akmodsbuild.K1VY6VgX/BUILD/nvidia-kmod-418.67-x86_64/_kmod_build_5.1.21-200.fc29.x86_64/nvidia-uvm/uvm8.c:187:14: note: (near initialization for ‘uvm_vm_ops_disabled.fault’)
/tmp/akmodsbuild.K1VY6VgX/BUILD/nvidia-kmod-418.67-x86_64/_kmod_build_5.1.21-200.fc29.x86_64/nvidia-uvm/uvm8.c:525:21: error: initialization of 'vm_fault_t (
.fault = uvm_vm_fault_wrapper,
/tmp/akmodsbuild.K1VY6VgX/BUILD/nvidia-kmod-418.67-x86_64/_kmod_build_5.1.21-200.fc29.x86_64/nvidia-uvm/uvm8.c:525:21: note: (near initialization for ‘uvm_vm_ops_managed.fault’)
/tmp/akmodsbuild.K1VY6VgX/BUILD/nvidia-kmod-418.67-x86_64/_kmod_build_5.1.21-200.fc29.x86_64/nvidia-uvm/uvm8.c:526:21: error: initialization of 'vm_fault_t (
.page_mkwrite = uvm_vm_fault_wrapper,
/tmp/akmodsbuild.K1VY6VgX/BUILD/nvidia-kmod-418.67-x86_64/_kmod_build_5.1.21-200.fc29.x86_64/nvidia-uvm/uvm8.c:526:21: note: (near initialization for ‘uvm_vm_ops_managed.page_mkwrite’)
/tmp/akmodsbuild.K1VY6VgX/BUILD/nvidia-kmod-418.67-x86_64/_kmod_build_5.1.21-200.fc29.x86_64/nvidia-uvm/uvm8.c:609:21: error: initialization of 'vm_fault_t (
)(struct vm_fault )’ {aka 'unsigned int ()(struct vm_fault )'} from incompatible pointer type 'int ()(struct vm_fault *)’ [-Werror=incompatible-pointer-types]
.fault = uvm_vm_fault_sigbus_wrapper,
/tmp/akmodsbuild.K1VY6VgX/BUILD/nvidia-kmod-418.67-x86_64/_kmod_build_5.1.21-200.fc29.x86_64/nvidia-uvm/uvm8.c:609:21: note: (near initialization for ‘uvm_vm_ops_semaphore_pool.fault’)
CC [M] /tmp/akmodsbuild.K1VY6VgX/BUILD/nvidia-kmod-418.67-x86_64/_kmod_build_5.1.21-200.fc29.x86_64/nvidia-uvm/uvm8_gpu_semaphore.o
cc1: warning: unrecognized command line option ‘-Wno-address-of-packed-member’
cc1: some warnings being treated as errors
make[2]: *** [scripts/Makefile.build:276: /tmp/akmodsbuild.K1VY6VgX/BUILD/nvidia-kmod-418.67-x86_64/_kmod_build_5.1.21-200.fc29.x86_64/nvidia-uvm/uvm8.o] Error 1
make[2]: *** Waiting for unfinished jobs…
make[1]: *** [Makefile:1575: module/tmp/akmodsbuild.K1VY6VgX/BUILD/nvidia-kmod-418.67-x86_64/_kmod_build_5.1.21-200.fc29.x86_64] Error 2
make[1]: Leaving directory ‘/usr/src/kernels/5.1.21-200.fc29.x86_64’
make: *** [Makefile:81: modules] Error 2
error: Bad exit status from /var/tmp/rpm-tmp.qHVnG0 (%build)
RPM build errors:
user erisuser does not exist - using root
group erisuser does not exist - using root
2019/08/09 15:29:30 akmodsbuild: * Rebuilding /usr/src/akmods/nvidia-kmod.latest for kernel(s) 5.1.21-200.fc29.x86_64: warning: user erisuser does not exist - using root
2019/08/09 15:29:30 akmodsbuild: warning: group erisuser does not exist - using root
2019/08/09 15:29:30 akmodsbuild: warning: user erisuser does not exist - using root
2019/08/09 15:29:30 akmodsbuild: Installing /usr/src/akmods/nvidia-kmod.latest
2019/08/09 15:29:30 akmodsbuild: Building target platforms: x86_64
2019/08/09 15:29:30 akmodsbuild: Building for target x86_64
2019/08/09 15:29:30 akmodsbuild: Executing(%prep): /bin/sh -e /var/tmp/rpm-tmp.UsEojf
2019/08/09 15:29:30 akmodsbuild: + umask 022
2019/08/09 15:29:30 akmodsbuild: + cd /tmp/akmodsbuild.K1VY6VgX//BUILD
2019/08/09 15:29:30 akmodsbuild: + kmodtool --target x86_64 --repo rpmfusion --kmodname nvidia-kmod --filterfile /tmp/akmodsbuild.K1VY6VgX/SOURCES/nvidia-kmodtool-excludekernel-filterfile --obsolete-name nvidia-newest --obsolete-version 418.67 --akmod --for-kernels 5.1.21-200.fc29.x86_64
2019/08/09 15:29:30 akmodsbuild: %global _prefix_usr /usr
2019/08/09 15:29:30 akmodsbuild: %if 0%{?rhel}
2019/08/09 15:29:30 akmodsbuild: %package -n kmod-nvidia
2019/08/09 15:29:30 akmodsbuild: Summary: nvidia kernel module(s) for 5.1.21-200.fc29
2019/08/09 15:29:30 akmodsbuild: Provides: kernel-modules = 5.1.21-200.fc29.x86_64
2019/08/09 15:29:30 akmodsbuild: Provides: nvidia-kmod = %{?epoch:%{epoch}:}%{version}-%{release}
2019/08/09 15:29:30 akmodsbuild: Requires: nvidia-kmod-common >= %{?epoch:%{epoch}:}%{version}
2019/08/09 15:29:30 akmodsbuild: Requires(post): %{?_prefix_usr}/sbin/weak-modules
2019/08/09 15:29:30 akmodsbuild: Requires(post): %{?_prefix_usr}/sbin/depmod
2019/08/09 15:29:30 akmodsbuild: Requires(postun): %{?_prefix_usr}/sbin/weak-modules
2019/08/09 15:29:30 akmodsbuild: Requires(postun): %{?_prefix_usr}/sbin/depmod
2019/08/09 15:29:30 akmodsbuild: %else
2019/08/09 15:29:30 akmodsbuild: %package -n kmod-nvidia-5.1.21-200.fc29.x86_64
2019/08/09 15:29:30 akmodsbuild: Summary: nvidia kernel module(s) for 5.1.21-200.fc29.x86_64
2019/08/09 15:29:30 akmodsbuild: Provides: kernel-modules-for-kernel = 5.1.21-200.fc29.x86_64
2019/08/09 15:29:30 akmodsbuild: %endif
2019/08/09 15:29:30 akmodsbuild: Provides: kmod-nvidia-newest-5.1.21-200.fc29.x86_64 = 418.67
2019/08/09 15:29:30 akmodsbuild: Obsoletes: kmod-nvidia-newest-5.1.21-200.fc29.x86_64 < 418.67
2019/08/09 15:29:30 akmodsbuild: Requires: kernel >= 5.1.21-200.fc29
2019/08/09 15:29:30 akmodsbuild: Requires: kernel < 5.1.21-201.fc29
2019/08/09 15:29:30 akmodsbuild: BuildRequires: kernel-devel = 5.1.21-200.fc29 redhat-rpm-config kernel-abi-whitelists
2019/08/09 15:29:30 akmodsbuild: %post -n kmod-nvidia
2019/08/09 15:29:30 akmodsbuild: %{?_prefix_usr}/sbin/depmod -aeF /boot/System.map-5.1.21-200.fc29.x86_64 5.1.21-200.fc29.x86_64 > /dev/null || :
2019/08/09 15:29:30 akmodsbuild: modules=( $(find /usr/lib/modules/5.1.21-200.fc29.x86_64/extra/nvidia/ | grep -e ‘.ko$’) )
2019/08/09 15:29:30 akmodsbuild: printf ‘%sn’ “${modules[@]}” | %{?_prefix_usr}/sbin/weak-modules --add-modules
2019/08/09 15:29:30 akmodsbuild: %preun -n kmod-nvidia
2019/08/09 15:29:30 akmodsbuild: rpm -ql kmod-nvidia-%{version}-%{release}.x86_64 | grep -e ‘.ko$’ > /var/run/rpm-kmod-nvidia-modules
2019/08/09 15:29:30 akmodsbuild: %postun -n kmod-nvidia
2019/08/09 15:29:30 akmodsbuild: %{?prefix_usr}/sbin/depmod -aeF /boot/System.map-5.1.21-200.fc29.x86_64 5.1.21-200.fc29.x86_64 &> /dev/null || :
2019/08/09 15:29:30 akmodsbuild: modules=( $(cat /var/run/rpm-kmod-nvidia-modules) )
2019/08/09 15:29:30 akmodsbuild: rm /var/run/rpm-kmod-nvidia-modules
2019/08/09 15:29:30 akmodsbuild: printf ‘%sn’ “${modules[@]}” | %{?prefix_usr}/sbin/weak-modules --remove-modules
2019/08/09 15:29:30 akmodsbuild: Requires: kernel-uname-r = 5.1.21-200.fc29.x86_64
2019/08/09 15:29:30 akmodsbuild: BuildRequires: kernel-devel-uname-r = 5.1.21-200.fc29.x86_64
2019/08/09 15:29:30 akmodsbuild: BuildRequires: gcc
2019/08/09 15:29:30 akmodsbuild: %post -n kmod-nvidia-5.1.21-200.fc29.x86_64
2019/08/09 15:29:30 akmodsbuild: %{?prefix_usr}/sbin/depmod -aeF /boot/System.map-5.1.21-200.fc29.x86_64 5.1.21-200.fc29.x86_64 > /dev/null || :
2019/08/09 15:29:30 akmodsbuild: %postun -n kmod-nvidia-5.1.21-200.fc29.x86_64
2019/08/09 15:29:30 akmodsbuild: %description -n kmod-nvidia
2019/08/09 15:29:30 akmodsbuild: This package provides the nvidia kernel modules built for the Linux
2019/08/09 15:29:30 akmodsbuild: kernel 5.1.21-200.fc29 for the %{target_cpu} family of processors.
2019/08/09 15:29:30 akmodsbuild: %files -n kmod-nvidia
2019/08/09 15:29:30 akmodsbuild: %defattr(644,root,root,755)
2019/08/09 15:29:30 akmodsbuild: %dir /usr/lib/modules/5.1.21-200.fc29.x86_64/extra
2019/08/09 15:29:30 akmodsbuild: /usr/lib/modules/5.1.21-200.fc29.x86_64/extra/nvidia/
2019/08/09 15:29:30 akmodsbuild: %description -n kmod-nvidia-5.1.21-200.fc29.x86_64
2019/08/09 15:29:30 akmodsbuild: kernel 5.1.21-200.fc29.x86_64 for the %{target_cpu} family of processors.
2019/08/09 15:29:30 akmodsbuild: %files -n kmod-nvidia-5.1.21-200.fc29.x86_64
2019/08/09 15:29:30 akmodsbuild: %global kmodinstdir_prefix /usr/lib/modules/
2019/08/09 15:29:30 akmodsbuild: %global kmodinstdir_postfix /extra/nvidia/
2019/08/09 15:29:30 akmodsbuild: %global kernel_versions 5.1.21-200.fc29.x86_64
%{usrsrc}/kernels/5.1.21-200.fc29.x86_64
2019/08/09 15:29:30 akmodsbuild: %global debug_package %{nil}
2019/08/09 15:29:30 akmodsbuild: + cd /tmp/akmodsbuild.K1VY6VgX/BUILD
2019/08/09 15:29:30 akmodsbuild: + rm -rf nvidia-kmod-418.67-x86_64
2019/08/09 15:29:30 akmodsbuild: + /usr/bin/xz -dc /tmp/akmodsbuild.K1VY6VgX/SOURCES/nvidia-kmod-418.67-x86_64.tar.xz
2019/08/09 15:29:30 akmodsbuild: + /usr/bin/tar -xof -
2019/08/09 15:29:30 akmodsbuild: + STATUS=0
2019/08/09 15:29:30 akmodsbuild: + ‘[’ 0 -ne 0 ‘]’
2019/08/09 15:29:30 akmodsbuild: + cd nvidia-kmod-418.67-x86_64
2019/08/09 15:29:30 akmodsbuild: + /usr/bin/chmod -Rf a+rX,u+w,g-w,o-w .
2019/08/09 15:29:30 akmodsbuild: + for kernel_version in 5.1.21-200.fc29.x86_64
2019/08/09 15:29:30 akmodsbuild: + mkdir kmod_build_5.1.21-200.fc29.x86_64
2019/08/09 15:29:30 akmodsbuild: + cp -fr kernel/Kbuild kernel/Makefile kernel/common kernel/conftest.sh kernel/dkms.conf kernel/nvidia kernel/nvidia-drm kernel/nvidia-modeset kernel/nvidia-uvm kmod_build_5.1.21-200.fc29.x86_64
2019/08/09 15:29:30 akmodsbuild: + exit 0
2019/08/09 15:29:30 akmodsbuild: Executing(%build): /bin/sh -e /var/tmp/rpm-tmp.qHVnG0
2019/08/09 15:29:30 akmodsbuild: + pushd _kmod_build_5.1.21-200.fc29.x86_64/
2019/08/09 15:29:30 akmodsbuild: /tmp/akmodsbuild.K1VY6VgX/BUILD/nvidia-kmod-418.67-x86_64/_kmod_build_5.1.21-200.fc29.x86_64 /tmp/akmodsbuild.K1VY6VgX/BUILD/nvidia-kmod-418.67-x86_64
2019/08/09 15:29:30 akmodsbuild: + make -j8 IGNORE_XEN_PRESENCE=1 IGNORE_PREEMPT_RT_PRESENCE=1 IGNORE_CC_MISMATCH=1 SYSSRC=/usr/src/kernels/5.1.21-200.fc29.x86_64 module
2019/08/09 15:29:30 akmodsbuild: make[1]: Entering directory ‘/usr/src/kernels/5.1.21-200.fc29.x86_64’
2019/08/09 15:29:30 akmodsbuild: SYMLINK /tmp/akmodsbuild.K1VY6VgX/BUILD/nvidia-kmod-418.67-x86_64/_kmod_build_5.1.21-200.fc29.x86_64/nvidia/nv-kernel.o
2019/08/09 15:29:30 akmodsbuild: SYMLINK /tmp/akmodsbuild.K1VY6VgX/BUILD/nvidia-kmod-418.67-x86_64/_kmod_build_5.1.21-200.fc29.x86_64/nvidia-modeset/nv-modeset-kernel.o
2019/08/09 15:29:30 akmodsbuild: CONFTEST: INIT_WORK
2019/08/09 15:29:30 akmodsbuild: CONFTEST: remap_pfn_range
2019/08/09 15:29:30 akmodsbuild: CONFTEST: hash__remap_4k_pfn
2019/08/09 15:29:30 akmodsbuild: CONFTEST: follow_pfn
2019/08/09 15:29:30 akmodsbuild: CONFTEST: vmap
2019/08/09 15:29:30 akmodsbuild: CONFTEST: set_pages_uc
2019/08/09 15:29:30 akmodsbuild: CONFTEST: list_is_first
2019/08/09 15:29:30 akmodsbuild: CONFTEST: set_memory_uc
2019/08/09 15:29:30 akmodsbuild: CONFTEST: set_memory_array_uc
2019/08/09 15:29:30 akmodsbuild: CONFTEST: change_page_attr
2019/08/09 15:29:30 akmodsbuild: CONFTEST: pci_get_class
2019/08/09 15:29:30 akmodsbuild: CONFTEST: pci_choose_state
2019/08/09 15:29:30 akmodsbuild: CONFTEST: vm_insert_page
2019/08/09 15:29:30 akmodsbuild: CONFTEST: acpi_device_id
2019/08/09 15:29:30 akmodsbuild: CONFTEST: acquire_console_sem
2019/08/09 15:29:30 akmodsbuild: CONFTEST: console_lock
2019/08/09 15:29:30 akmodsbuild: CONFTEST: kmem_cache_create
2019/08/09 15:29:30 akmodsbuild: CONFTEST: on_each_cpu
2019/08/09 15:29:30 akmodsbuild: CONFTEST: smp_call_function
2019/08/09 15:29:30 akmodsbuild: CONFTEST: acpi_evaluate_integer
2019/08/09 15:29:30 akmodsbuild: CONFTEST: ioremap_cache
2019/08/09 15:29:30 akmodsbuild: CONFTEST: ioremap_wc
2019/08/09 15:29:30 akmodsbuild: CONFTEST: acpi_walk_namespace
2019/08/09 15:29:30 akmodsbuild: CONFTEST: pci_domain_nr
2019/08/09 15:29:30 akmodsbuild: CONFTEST: pci_dma_mapping_error
2019/08/09 15:29:30 akmodsbuild: CONFTEST: sg_alloc_table
2019/08/09 15:29:30 akmodsbuild: CONFTEST: get_num_physpages
2019/08/09 15:29:30 akmodsbuild: CONFTEST: sg_init_table
2019/08/09 15:29:30 akmodsbuild: CONFTEST: pci_get_domain_bus_and_slot
2019/08/09 15:29:30 akmodsbuild: CONFTEST: efi_enabled
2019/08/09 15:29:30 akmodsbuild: CONFTEST: proc_create_data
2019/08/09 15:29:30 akmodsbuild: CONFTEST: pde_data
2019/08/09 15:29:30 akmodsbuild: CONFTEST: pm_vt_switch_required
2019/08/09 15:29:30 akmodsbuild: CONFTEST: proc_remove
2019/08/09 15:29:30 akmodsbuild: CONFTEST: xen_ioemu_inject_msi
2019/08/09 15:29:30 akmodsbuild: CONFTEST: phys_to_dma
2019/08/09 15:29:30 akmodsbuild: CONFTEST: get_dma_ops
2019/08/09 15:29:30 akmodsbuild: CONFTEST: write_cr4
2019/08/09 15:29:30 akmodsbuild: CONFTEST: of_get_property
2019/08/09 15:29:30 akmodsbuild: CONFTEST: of_find_node_by_phandle
2019/08/09 15:29:30 akmodsbuild: CONFTEST: of_node_to_nid
2019/08/09 15:29:30 akmodsbuild: CONFTEST: pnv_pci_get_npu_dev
2019/08/09 15:29:30 akmodsbuild: CONFTEST: of_get_ibm_chip_id
2019/08/09 15:29:30 akmodsbuild: CONFTEST: for_each_online_node
2019/08/09 15:29:30 akmodsbuild: CONFTEST: node_end_pfn
2019/08/09 15:29:30 akmodsbuild: CONFTEST: pci_bus_address
2019/08/09 15:29:30 akmodsbuild: CONFTEST: pci_stop_and_remove_bus_device
2019/08/09 15:29:30 akmodsbuild: CONFTEST: pci_remove_bus_device
2019/08/09 15:29:30 akmodsbuild: CONFTEST: request_threaded_irq
2019/08/09 15:29:30 akmodsbuild: CONFTEST: register_cpu_notifier
2019/08/09 15:29:30 akmodsbuild: CONFTEST: cpuhp_setup_state
2019/08/09 15:29:30 akmodsbuild: CONFTEST: dma_map_resource
2019/08/09 15:29:30 akmodsbuild: CONFTEST: backlight_device_register
2019/08/09 15:29:30 akmodsbuild: CONFTEST: register_acpi_notifier
2019/08/09 15:29:30 akmodsbuild: CONFTEST: timer_setup
2019/08/09 15:29:30 akmodsbuild: CONFTEST: pci_enable_msix_range
2019/08/09 15:29:30 akmodsbuild: CONFTEST: compound_order
2019/08/09 15:29:30 akmodsbuild: CONFTEST: do_gettimeofday
2019/08/09 15:29:30 akmodsbuild: CONFTEST: remap_page_range
2019/08/09 15:29:30 akmodsbuild: CONFTEST: address_space_init_once
2019/08/09 15:29:30 akmodsbuild: CONFTEST: kbasename
2019/08/09 15:29:30 akmodsbuild: CONFTEST: fatal_signal_pending
2019/08/09 15:29:30 akmodsbuild: CONFTEST: list_cut_position
2019/08/09 15:29:30 akmodsbuild: CONFTEST: vzalloc
2019/08/09 15:29:30 akmodsbuild: CONFTEST: wait_on_bit_lock_argument_count
2019/08/09 15:29:30 akmodsbuild: CONFTEST: bitmap_clear
2019/08/09 15:29:30 akmodsbuild: CONFTEST: usleep_range
2019/08/09 15:29:30 akmodsbuild: CONFTEST: radix_tree_empty
2019/08/09 15:29:30 akmodsbuild: CONFTEST: radix_tree_replace_slot
2019/08/09 15:29:30 akmodsbuild: CONFTEST: pnv_npu2_init_context
2019/08/09 15:29:30 akmodsbuild: CONFTEST: drm_dev_unref
2019/08/09 15:29:30 akmodsbuild: CONFTEST: drm_reinit_primary_mode_group
2019/08/09 15:29:30 akmodsbuild: CONFTEST: get_user_pages_remote
2019/08/09 15:29:30 akmodsbuild: CONFTEST: drm_gem_object_lookup
2019/08/09 15:29:30 akmodsbuild: CONFTEST: drm_atomic_state_ref_counting
2019/08/09 15:29:30 akmodsbuild: CONFTEST: drm_driver_has_gem_prime_res_obj
2019/08/09 15:29:30 akmodsbuild: CONFTEST: drm_atomic_helper_connector_dpms
2019/08/09 15:29:30 akmodsbuild: CONFTEST: drm_connector_funcs_have_mode_in_name
2019/08/09 15:29:30 akmodsbuild: CONFTEST: vmf_insert_pfn
2019/08/09 15:29:30 akmodsbuild: CONFTEST: drm_framebuffer_get
2019/08/09 15:29:30 akmodsbuild: CONFTEST: drm_gem_object_get
2019/08/09 15:29:30 akmodsbuild: CONFTEST: drm_dev_put
2019/08/09 15:29:30 akmodsbuild: CONFTEST: is_export_symbol_gpl_of_node_to_nid
2019/08/09 15:29:30 akmodsbuild: CONFTEST: is_export_symbol_present_swiotlb_map_sg_attrs
2019/08/09 15:29:30 akmodsbuild: CONFTEST: is_export_symbol_present_swiotlb_dma_ops
2019/08/09 15:29:30 akmodsbuild: CONFTEST: i2c_adapter
2019/08/09 15:29:30 akmodsbuild: CONFTEST: pm_message_t
2019/08/09 15:29:30 akmodsbuild: CONFTEST: irq_handler_t
2019/08/09 15:29:30 akmodsbuild: CONFTEST: acpi_device_ops
2019/08/09 15:29:30 akmodsbuild: CONFTEST: acpi_op_remove
2019/08/09 15:29:30 akmodsbuild: CONFTEST: outer_flush_all
2019/08/09 15:29:30 akmodsbuild: CONFTEST: proc_dir_entry
2019/08/09 15:29:30 akmodsbuild: CONFTEST: scatterlist
2019/08/09 15:29:30 akmodsbuild: CONFTEST: sg_table
2019/08/09 15:29:30 akmodsbuild: CONFTEST: file_operations
2019/08/09 15:29:30 akmodsbuild: CONFTEST: vm_operations_struct
2019/08/09 15:29:30 akmodsbuild: CONFTEST: atomic_long_type
2019/08/09 15:29:30 akmodsbuild: CONFTEST: pci_save_state
2019/08/09 15:29:30 akmodsbuild: CONFTEST: file_inode
2019/08/09 15:29:30 akmodsbuild: CONFTEST: task_struct
2019/08/09 15:29:30 akmodsbuild: CONFTEST: kuid_t
2019/08/09 15:29:30 akmodsbuild: CONFTEST: dma_ops
2019/08/09 15:29:30 akmodsbuild: CONFTEST: swiotlb_dma_ops
2019/08/09 15:29:30 akmodsbuild: CONFTEST: dma_map_ops
2019/08/09 15:29:30 akmodsbuild: CONFTEST: noncoherent_swiotlb_dma_ops
2019/08/09 15:29:30 akmodsbuild: CONFTEST: vm_fault_present
2019/08/09 15:29:30 akmodsbuild: CONFTEST: vm_fault_has_address
2019/08/09 15:29:30 akmodsbuild: CONFTEST: backlight_properties_type
2019/08/09 15:29:30 akmodsbuild: CONFTEST: vmbus_channel_has_ringbuffer_page
2019/08/09 15:29:30 akmodsbuild: CONFTEST: fault_flags
2019/08/09 15:29:30 akmodsbuild: CONFTEST: atomic64_type
2019/08/09 15:29:30 akmodsbuild: CONFTEST: backing_dev_info
2019/08/09 15:29:30 akmodsbuild: CONFTEST: mm_context_t
2019/08/09 15:29:30 akmodsbuild: CONFTEST: vm_ops_fault_removed_vma_arg
2019/08/09 15:29:30 akmodsbuild: CONFTEST: node_states_n_memory
2019/08/09 15:29:30 akmodsbuild: CONFTEST: drm_bus_present
2019/08/09 15:29:30 akmodsbuild: CONFTEST: drm_bus_has_bus_type
2019/08/09 15:29:30 akmodsbuild: CONFTEST: drm_bus_has_get_irq
2019/08/09 15:29:30 akmodsbuild: CONFTEST: drm_bus_has_get_name
2019/08/09 15:29:30 akmodsbuild: CONFTEST: drm_driver_has_legacy_dev_list
2019/08/09 15:29:30 akmodsbuild: CONFTEST: drm_driver_has_set_busid
2019/08/09 15:29:30 akmodsbuild: CONFTEST: drm_crtc_state_has_connectors_changed
2019/08/09 15:29:30 akmodsbuild: CONFTEST: drm_init_function_args
2019/08/09 15:29:30 akmodsbuild: CONFTEST: drm_mode_connector_list_update_has_merge_type_bits_arg
2019/08/09 15:29:30 akmodsbuild: CONFTEST: drm_helper_mode_fill_fb_struct
2019/08/09 15:29:30 akmodsbuild: CONFTEST: drm_master_drop_has_from_release_arg
2019/08/09 15:29:30 akmodsbuild: CONFTEST: drm_driver_unload_has_int_return_type
2019/08/09 15:29:30 akmodsbuild: CONFTEST: kref_has_refcount_of_type_refcount_t
2019/08/09 15:29:30 akmodsbuild: CONFTEST: drm_atomic_helper_crtc_destroy_state_has_crtc_arg
2019/08/09 15:29:30 akmodsbuild: CONFTEST: drm_crtc_helper_funcs_has_atomic_enable
2019/08/09 15:29:30 akmodsbuild: CONFTEST: drm_mode_object_find_has_file_priv_arg
2019/08/09 15:29:30 akmodsbuild: CONFTEST: dma_buf_owner
2019/08/09 15:29:30 akmodsbuild: CONFTEST: drm_connector_list_iter
2019/08/09 15:29:30 akmodsbuild: CONFTEST: drm_atomic_helper_swap_state_has_stall_arg
2019/08/09 15:29:30 akmodsbuild: CONFTEST: dom0_kernel_present
2019/08/09 15:29:30 akmodsbuild: CONFTEST: nvidia_vgpu_hyperv_available
2019/08/09 15:29:30 akmodsbuild: CONFTEST: nvidia_vgpu_kvm_build
2019/08/09 15:29:30 akmodsbuild: CONFTEST: nvidia_grid_build
2019/08/09 15:29:30 akmodsbuild: CONFTEST: drm_available
2019/08/09 15:29:30 akmodsbuild: CONFTEST: drm_atomic_available
2019/08/09 15:29:30 akmodsbuild: CONFTEST: is_export_symbol_gpl_refcount_inc
2019/08/09 15:29:30 akmodsbuild: CONFTEST: is_export_symbol_gpl_refcount_dec_and_test
2019/08/09 15:29:30 akmodsbuild: CC [M] /tmp/akmodsbuild.K1VY6VgX/BUILD/nvidia-kmod-418.67-x86_64/_kmod_build_5.1.21-200.fc29.x86_64/nvidia/nv-frontend.o
2019/08/09 15:29:30 akmodsbuild: CC [M] /tmp/akmodsbuild.K1VY6VgX/BUILD/nvidia-kmod-418.67-x86_64/_kmod_build_5.1.21-200.fc29.x86_64/nvidia/nv-instance.o
2019/08/09 15:29:30 akmodsbuild: CC [M] /tmp/akmodsbuild.K1VY6VgX/BUILD/nvidia-kmod-418.67-x86_64/_kmod_build_5.1.21-200.fc29.x86_64/nvidia/nv.o
2019/08/09 15:29:30 akmodsbuild: CC [M] /tmp/akmodsbuild.K1VY6VgX/BUILD/nvidia-kmod-418.67-x86_64/_kmod_build_5.1.21-200.fc29.x86_64/nvidia/nv-acpi.o
2019/08/09 15:29:30 akmodsbuild: CC [M] /tmp/akmodsbuild.K1VY6VgX/BUILD/nvidia-kmod-418.67-x86_64/_kmod_build_5.1.21-200.fc29.x86_64/nvidia/nv-chrdev.o
2019/08/09 15:29:30 akmodsbuild: CC [M] /tmp/akmodsbuild.K1VY6VgX/BUILD/nvidia-kmod-418.67-x86_64/_kmod_build_5.1.21-200.fc29.x86_64/nvidia/nv-cray.o
2019/08/09 15:29:30 akmodsbuild: CC [M] /tmp/akmodsbuild.K1VY6VgX/BUILD/nvidia-kmod-418.67-x86_64/_kmod_build_5.1.21-200.fc29.x86_64/nvidia/nv-dma.o
2019/08/09 15:29:30 akmodsbuild: CC [M] /tmp/akmodsbuild.K1VY6VgX/BUILD/nvidia-kmod-418.67-x86_64/_kmod_build_5.1.21-200.fc29.x86_64/nvidia/nv-gvi.o
2019/08/09 15:29:30 akmodsbuild: CC [M] /tmp/akmodsbuild.K1VY6VgX/BUILD/nvidia-kmod-418.67-x86_64/_kmod_build_5.1.21-200.fc29.x86_64/nvidia/nv-i2c.o
2019/08/09 15:29:30 akmodsbuild: CC [M] /tmp/akmodsbuild.K1VY6VgX/BUILD/nvidia-kmod-418.67-x86_64/_kmod_build_5.1.21-200.fc29.x86_64/nvidia/nv-mempool.o
2019/08/09 15:29:30 akmodsbuild: CC [M] /tmp/akmodsbuild.K1VY6VgX/BUILD/nvidia-kmod-418.67-x86_64/_kmod_build_5.1.21-200.fc29.x86_64/nvidia/nv-mmap.o
2019/08/09 15:29:30 akmodsbuild: CC [M] /tmp/akmodsbuild.K1VY6VgX/BUILD/nvidia-kmod-418.67-x86_64/_kmod_build_5.1.21-200.fc29.x86_64/nvidia/nv-p2p.o
2019/08/09 15:29:30 akmodsbuild: CC [M] /tmp/akmodsbuild.K1VY6VgX/BUILD/nvidia-kmod-418.67-x86_64/_kmod_build_5.1.21-200.fc29.x86_64/nvidia/nv-pat.o
2019/08/09 15:29:30 akmodsbuild: CC [M] /tmp/akmodsbuild.K1VY6VgX/BUILD/nvidia-kmod-418.67-x86_64/_kmod_build_5.1.21-200.fc29.x86_64/nvidia/nv-procfs.o
2019/08/09 15:29:30 akmodsbuild: CC [M] /tmp/akmodsbuild.K1VY6VgX/BUILD/nvidia-kmod-418.67-x86_64/_kmod_build_5.1.21-200.fc29.x86_64/nvidia/nv-usermap.o
2019/08/09 15:29:30 akmodsbuild: CC [M] /tmp/akmodsbuild.K1VY6VgX/BUILD/nvidia-kmod-418.67-x86_64/_kmod_build_5.1.21-200.fc29.x86_64/nvidia/nv-vm.o
2019/08/09 15:29:30 akmodsbuild: CC [M] /tmp/akmodsbuild.K1VY6VgX/BUILD/nvidia-kmod-418.67-x86_64/_kmod_build_5.1.21-200.fc29.x86_64/nvidia/nv-vtophys.o
2019/08/09 15:29:30 akmodsbuild: CC [M] /tmp/akmodsbuild.K1VY6VgX/BUILD/nvidia-kmod-418.67-x86_64/_kmod_build_5.1.21-200.fc29.x86_64/nvidia/os-interface.o
2019/08/09 15:29:30 akmodsbuild: CC [M] /tmp/akmodsbuild.K1VY6VgX/BUILD/nvidia-kmod-418.67-x86_64/_kmod_build_5.1.21-200.fc29.x86_64/nvidia/os-mlock.o
2019/08/09 15:29:30 akmodsbuild: CC [M] /tmp/akmodsbuild.K1VY6VgX/BUILD/nvidia-kmod-418.67-x86_64/_kmod_build_5.1.21-200.fc29.x86_64/nvidia/os-pci.o
2019/08/09 15:29:30 akmodsbuild: CC [M] /tmp/akmodsbuild.K1VY6VgX/BUILD/nvidia-kmod-418.67-x86_64/_kmod_build_5.1.21-200.fc29.x86_64/nvidia/os-registry.o
2019/08/09 15:29:30 akmodsbuild: CC [M] /tmp/akmodsbuild.K1VY6VgX/BUILD/nvidia-kmod-418.67-x86_64/_kmod_build_5.1.21-200.fc29.x86_64/nvidia/os-usermap.o
2019/08/09 15:29:30 akmodsbuild: CC [M] /tmp/akmodsbuild.K1VY6VgX/BUILD/nvidia-kmod-418.67-x86_64/_kmod_build_5.1.21-200.fc29.x86_64/nvidia/nv-modeset-interface.o
2019/08/09 15:29:30 akmodsbuild: CC [M] /tmp/akmodsbuild.K1VY6VgX/BUILD/nvidia-kmod-418.67-x86_64/_kmod_build_5.1.21-200.fc29.x86_64/nvidia/nv-pci-table.o
2019/08/09 15:29:30 akmodsbuild: CC [M] /tmp/akmodsbuild.K1VY6VgX/BUILD/nvidia-kmod-418.67-x86_64/_kmod_build_5.1.21-200.fc29.x86_64/nvidia/nv-kthread-q.o
2019/08/09 15:29:30 akmodsbuild: CC [M] /tmp/akmodsbuild.K1VY6VgX/BUILD/nvidia-kmod-418.67-x86_64/_kmod_build_5.1.21-200.fc29.x86_64/nvidia/nv-kthread-q-selftest.o
2019/08/09 15:29:30 akmodsbuild: CC [M] /tmp/akmodsbuild.K1VY6VgX/BUILD/nvidia-kmod-418.67-x86_64/_kmod_build_5.1.21-200.fc29.x86_64/nvidia/nv-memdbg.o
2019/08/09 15:29:30 akmodsbuild: CC [M] /tmp/akmodsbuild.K1VY6VgX/BUILD/nvidia-kmod-418.67-x86_64/_kmod_build_5.1.21-200.fc29.x86_64/nvidia/nv-ibmnpu.o
2019/08/09 15:29:30 akmodsbuild: CC [M] /tmp/akmodsbuild.K1VY6VgX/BUILD/nvidia-kmod-418.67-x86_64/_kmod_build_5.1.21-200.fc29.x86_64/nvidia/nv-report-err.o
2019/08/09 15:29:30 akmodsbuild: CC [M] /tmp/akmodsbuild.K1VY6VgX/BUILD/nvidia-kmod-418.67-x86_64/_kmod_build_5.1.21-200.fc29.x86_64/nvidia/nv-rsync.o
2019/08/09 15:29:30 akmodsbuild: CC [M] /tmp/akmodsbuild.K1VY6VgX/BUILD/nvidia-kmod-418.67-x86_64/_kmod_build_5.1.21-200.fc29.x86_64/nvidia/nv-msi.o
2019/08/09 15:29:30 akmodsbuild: CC [M] /tmp/akmodsbuild.K1VY6VgX/BUILD/nvidia-kmod-418.67-x86_64/_kmod_build_5.1.21-200.fc29.x86_64/nvidia/nv_uvm_interface.o
2019/08/09 15:29:30 akmodsbuild: CC [M] /tmp/akmodsbuild.K1VY6VgX/BUILD/nvidia-kmod-418.67-x86_64/_kmod_build_5.1.21-200.fc29.x86_64/nvidia/nvlink_linux.o
2019/08/09 15:29:30 akmodsbuild: CC [M] /tmp/akmodsbuild.K1VY6VgX/BUILD/nvidia-kmod-418.67-x86_64/_kmod_build_5.1.21-200.fc29.x86_64/nvidia/linux_nvswitch.o
2019/08/09 15:29:30 akmodsbuild: CC [M] /tmp/akmodsbuild.K1VY6VgX/BUILD/nvidia-kmod-418.67-x86_64/_kmod_build_5.1.21-200.fc29.x86_64/nvidia-uvm/uvm_utils.o
2019/08/09 15:29:30 akmodsbuild: CC [M] /tmp/akmodsbuild.K1VY6VgX/BUILD/nvidia-kmod-418.67-x86_64/_kmod_build_5.1.21-200.fc29.x86_64/nvidia-uvm/uvm_common.o
2019/08/09 15:29:30 akmodsbuild: CC [M] /tmp/akmodsbuild.K1VY6VgX/BUILD/nvidia-kmod-418.67-x86_64/_kmod_build_5.1.21-200.fc29.x86_64/nvidia-uvm/uvm_linux.o
2019/08/09 15:29:30 akmodsbuild: CC [M] /tmp/akmodsbuild.K1VY6VgX/BUILD/nvidia-kmod-418.67-x86_64/_kmod_build_5.1.21-200.fc29.x86_64/nvidia-uvm/nvstatus.o
2019/08/09 15:29:30 akmodsbuild: CC [M] /tmp/akmodsbuild.K1VY6VgX/BUILD/nvidia-kmod-418.67-x86_64/_kmod_build_5.1.21-200.fc29.x86_64/nvidia-uvm/nvCpuUuid.o
2019/08/09 15:29:30 akmodsbuild: CC [M] /tmp/akmodsbuild.K1VY6VgX/BUILD/nvidia-kmod-418.67-x86_64/_kmod_build_5.1.21-200.fc29.x86_64/nvidia-uvm/uvm8.o
2019/08/09 15:29:30 akmodsbuild: CC [M] /tmp/akmodsbuild.K1VY6VgX/BUILD/nvidia-kmod-418.67-x86_64/_kmod_build_5.1.21-200.fc29.x86_64/nvidia-uvm/uvm8_tools.o
2019/08/09 15:29:30 akmodsbuild: CC [M] /tmp/akmodsbuild.K1VY6VgX/BUILD/nvidia-kmod-418.67-x86_64/_kmod_build_5.1.21-200.fc29.x86_64/nvidia-uvm/uvm8_global.o
2019/08/09 15:29:30 akmodsbuild: CC [M] /tmp/akmodsbuild.K1VY6VgX/BUILD/nvidia-kmod-418.67-x86_64/_kmod_build_5.1.21-200.fc29.x86_64/nvidia-uvm/uvm8_gpu.o
2019/08/09 15:29:30 akmodsbuild: CC [M] /tmp/akmodsbuild.K1VY6VgX/BUILD/nvidia-kmod-418.67-x86_64/_kmod_build_5.1.21-200.fc29.x86_64/nvidia-uvm/uvm8_gpu_isr.o
2019/08/09 15:29:30 akmodsbuild: CC [M] /tmp/akmodsbuild.K1VY6VgX/BUILD/nvidia-kmod-418.67-x86_64/_kmod_build_5.1.21-200.fc29.x86_64/nvidia-uvm/uvm8_procfs.o
2019/08/09 15:29:30 akmodsbuild: CC [M] /tmp/akmodsbuild.K1VY6VgX/BUILD/nvidia-kmod-418.67-x86_64/_kmod_build_5.1.21-200.fc29.x86_64/nvidia-uvm/uvm8_va_space.o
2019/08/09 15:29:30 akmodsbuild: CC [M] /tmp/akmodsbuild.K1VY6VgX/BUILD/nvidia-kmod-418.67-x86_64/_kmod_build_5.1.21-200.fc29.x86_64/nvidia-uvm/uvm8_va_space_mm.o
2019/08/09 15:29:30 akmodsbuild: /tmp/akmodsbuild.K1VY6VgX/BUILD/nvidia-kmod-418.67-x86_64/_kmod_build_5.1.21-200.fc29.x86_64/nvidia-uvm/uvm8.c:187:14: error: initialization of ‘vm_fault_t (*)(struct vm_fault )’ {aka 'unsigned int ()(struct vm_fault )'} from incompatible pointer type 'int ()(struct vm_fault )’ [-Werror=incompatible-pointer-types]
2019/08/09 15:29:30 akmodsbuild: .fault = uvm_vm_fault_sigbus_wrapper
2019/08/09 15:29:30 akmodsbuild: ^~~~~~~~~~~~~~~~~~~~~~~~~~~
2019/08/09 15:29:30 akmodsbuild: /tmp/akmodsbuild.K1VY6VgX/BUILD/nvidia-kmod-418.67-x86_64/_kmod_build_5.1.21-200.fc29.x86_64/nvidia-uvm/uvm8.c:187:14: note: (near initialization for ‘uvm_vm_ops_disabled.fault’)
2019/08/09 15:29:30 akmodsbuild: /tmp/akmodsbuild.K1VY6VgX/BUILD/nvidia-kmod-418.67-x86_64/_kmod_build_5.1.21-200.fc29.x86_64/nvidia-uvm/uvm8.c:525:21: error: initialization of 'vm_fault_t (
2019/08/09 15:29:30 akmodsbuild: .fault = uvm_vm_fault_wrapper,
2019/08/09 15:29:30 akmodsbuild: /tmp/akmodsbuild.K1VY6VgX/BUILD/nvidia-kmod-418.67-x86_64/_kmod_build_5.1.21-200.fc29.x86_64/nvidia-uvm/uvm8.c:525:21: note: (near initialization for ‘uvm_vm_ops_managed.fault’)
2019/08/09 15:29:30 akmodsbuild: /tmp/akmodsbuild.K1VY6VgX/BUILD/nvidia-kmod-418.67-x86_64/_kmod_build_5.1.21-200.fc29.x86_64/nvidia-uvm/uvm8.c:526:21: error: initialization of 'vm_fault_t (
2019/08/09 15:29:30 akmodsbuild: .page_mkwrite = uvm_vm_fault_wrapper,
2019/08/09 15:29:30 akmodsbuild: /tmp/akmodsbuild.K1VY6VgX/BUILD/nvidia-kmod-418.67-x86_64/_kmod_build_5.1.21-200.fc29.x86_64/nvidia-uvm/uvm8.c:526:21: note: (near initialization for ‘uvm_vm_ops_managed.page_mkwrite’)
2019/08/09 15:29:30 akmodsbuild: /tmp/akmodsbuild.K1VY6VgX/BUILD/nvidia-kmod-418.67-x86_64/_kmod_build_5.1.21-200.fc29.x86_64/nvidia-uvm/uvm8.c:609:21: error: initialization of 'vm_fault_t (
2019/08/09 15:29:30 akmodsbuild: .fault = uvm_vm_fault_sigbus_wrapper,
2019/08/09 15:29:30 akmodsbuild: /tmp/akmodsbuild.K1VY6VgX/BUILD/nvidia-kmod-418.67-x86_64/_kmod_build_5.1.21-200.fc29.x86_64/nvidia-uvm/uvm8.c:609:21: note: (near initialization for ‘uvm_vm_ops_semaphore_pool.fault’)
2019/08/09 15:29:30 akmodsbuild: CC [M] /tmp/akmodsbuild.K1VY6VgX/BUILD/nvidia-kmod-418.67-x86_64/_kmod_build_5.1.21-200.fc29.x86_64/nvidia-uvm/uvm8_gpu_semaphore.o
2019/08/09 15:29:30 akmodsbuild: cc1: warning: unrecognized command line option ‘-Wno-address-of-packed-member’
2019/08/09 15:29:30 akmodsbuild: cc1: some warnings being treated as errors
2019/08/09 15:29:30 akmodsbuild: make[2]: *** [scripts/Makefile.build:276: /tmp/akmodsbuild.K1VY6VgX/BUILD/nvidia-kmod-418.67-x86_64/_kmod_build_5.1.21-200.fc29.x86_64/nvidia-uvm/uvm8.o] Error 1
2019/08/09 15:29:30 akmodsbuild: make[2]: *** Waiting for unfinished jobs…
2019/08/09 15:29:30 akmodsbuild: make[1]: *** [Makefile:1575: module/tmp/akmodsbuild.K1VY6VgX/BUILD/nvidia-kmod-418.67-x86_64/_kmod_build_5.1.21-200.fc29.x86_64] Error 2
2019/08/09 15:29:30 akmodsbuild: make[1]: Leaving directory ‘/usr/src/kernels/5.1.21-200.fc29.x86_64’
2019/08/09 15:29:30 akmodsbuild: make: *** [Makefile:81: modules] Error 2
2019/08/09 15:29:30 akmodsbuild: error: Bad exit status from /var/tmp/rpm-tmp.qHVnG0 (%build)
2019/08/09 15:29:30 akmodsbuild: RPM build errors:
2019/08/09 15:29:30 akmodsbuild: user erisuser does not exist - using root
2019/08/09 15:29:30 akmodsbuild: group erisuser does not exist - using root
2019/08/09 15:29:30 akmodsbuild: Bad exit status from /var/tmp/rpm-tmp.qHVnG0 (%build)
2019/08/09 15:29:30 akmods: Building rpms failed; see /var/cache/akmods/nvidia/418.67-1-for-5.1.21-200.fc29.x86_64.failed.log for details
nvidia-bug-report.log …
Start of NVIDIA bug report log file. Please include this file, along
with a detailed description of your problem, when reporting a graphics
driver bug via the NVIDIA Linux forum (see devtalk.nvidia.com)
or by sending email to ‘linux-bugs@nvidia.com’.
nvidia-bug-report.sh Version: 25648098
Date: Fri Aug 9 15:30:04 PDT 2019
uname: Linux obsidian.almaden.ibm.com 5.1.21-200.fc29.x86_64 #1 SMP Mon Jul 29 15:30:04 UTC 2019 x86_64 x86_64 x86_64 GNU/Linux
command line flags:
*** /etc/issue
*** ls: lrwxrwxrwx. 1 root root 16 2019-04-10 13:07:16.000000000 -0700 /etc/issue → …/usr/lib/issue
\S
Kernel \r on an \m (\l)
*** /etc/redhat-release
*** ls: lrwxrwxrwx. 1 root root 14 2019-04-10 13:07:16.000000000 -0700 /etc/redhat-release → fedora-release
Fedora release 29 (Twenty Nine)
*** /etc/fedora-release
*** ls: -rw-r–r–. 1 root root 32 2019-04-10 13:07:16.000000000 -0700 /etc/fedora-release
*** /var/log/nvidia-installer.log
*** ls: -rw-r–r-- 1 root root 4631 2019-07-31 17:34:13.484274216 -0700 /var/log/nvidia-installer.log
nvidia-installer log file ‘/var/log/nvidia-installer.log’
creation time: Wed Jul 31 17:31:46 2019
installer version: 418.88
PATH: /usr/lib64/qt-3.3/bin:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/root/bin
nvidia-installer command line:
./nvidia-installer
Using: nvidia-installer ncurses v6 user interface
→ Detected 8 CPUs online; setting concurrency level to 8.
→ Installing NVIDIA driver version 418.88.
→ Would you like to register the kernel module sources with DKMS? This will allow DKMS to automatically build a new module, if you install a different kernel later. (Answer: Yes)
→ Install NVIDIA’s 32-bit compatibility libraries? (Answer: Yes)
→ Will install GLVND GLX client libraries.
→ Will install GLVND EGL client libraries.
→ Skipping GLX non-GLVND file: “libGL.so.418.88”
→ Skipping GLX non-GLVND file: “libGL.so.1”
→ Skipping GLX non-GLVND file: “libGL.so”
→ Skipping EGL non-GLVND file: “libEGL.so.418.88”
→ Skipping EGL non-GLVND file: “libEGL.so”
→ Skipping EGL non-GLVND file: “libEGL.so.1”
→ Skipping GLX non-GLVND file: “./32/libGL.so.418.88”
→ Skipping EGL non-GLVND file: “./32/libEGL.so.418.88”
Looking for install checker script at ./libglvnd_install_checker/check-libglvnd-install.sh
executing: ‘/bin/sh ./libglvnd_install_checker/check-libglvnd-install.sh’…
Checking for libglvnd installation.
Checking libGLdispatch…
Checking libGLdispatch dispatch table
Checking call through libGLdispatch
All OK
libGLdispatch is OK
Checking for libGLX
libGLX is OK
Checking for libEGL
libEGL is OK
Checking entrypoint library libOpenGL.so.0
Checking call through library libOpenGL.so.0
All OK
Entrypoint library libOpenGL.so.0 is OK
Checking entrypoint library libGL.so.1
Checking call through library libGL.so.1
All OK
Entrypoint library libGL.so.1 is OK
Found libglvnd libraries: libGL.so.1 libOpenGL.so.0 libEGL.so.1 libGLX.so.0 libGLdispatch.so.0
Missing libglvnd libraries:
libglvnd appears to be installed.
Will not install libglvnd libraries.
→ Skipping GLVND file: “libOpenGL.so.0”
→ Skipping GLVND file: “libOpenGL.so”
→ Skipping GLVND file: “libGLESv1_CM.so.1.2.0”
→ Skipping GLVND file: “libGLESv1_CM.so.1”
→ Skipping GLVND file: “libGLESv1_CM.so”
→ Skipping GLVND file: “libGLESv2.so.2.1.0”
→ Skipping GLVND file: “libGLESv2.so.2”
→ Skipping GLVND file: “libGLESv2.so”
→ Skipping GLVND file: “libGLdispatch.so.0”
→ Skipping GLVND file: “libGLX.so.0”
→ Skipping GLVND file: “libGLX.so”
→ Skipping GLVND file: “libGL.so.1.7.0”
→ Skipping GLVND file: “libGL.so.1”
→ Skipping GLVND file: “libGL.so”
→ Skipping GLVND file: “libEGL.so.1.1.0”
→ Skipping GLVND file: “libEGL.so.1”
→ Skipping GLVND file: “libEGL.so”
→ Skipping GLVND file: “./32/libOpenGL.so.0”
→ Skipping GLVND file: “./32/libGLdispatch.so.0”
→ Skipping GLVND file: “./32/libGLESv2.so.2.1.0”
→ Skipping GLVND file: “./32/libGLESv1_CM.so.1.2.0”
→ Skipping GLVND file: “./32/libGL.so.1.7.0”
→ Skipping GLVND file: “./32/libGLX.so.0”
→ Skipping GLVND file: “./32/libEGL.so.1.1.0”
Will install libEGL vendor library config file to /usr/share/glvnd/egl_vendor.d
→ Searching for conflicting files:
→ done.
→ Installing ‘NVIDIA Accelerated Graphics Driver for Linux-x86_64’ (418.88):
executing: ‘/usr/sbin/ldconfig’…
→ done.
→ Driver file installation is complete.
→ Installing DKMS kernel module:
→ done.
→ Running post-install sanity check:
→ done.
→ Post-install sanity check passed.
→ Running runtime sanity check:
→ done.
→ Runtime sanity check passed.
→ Would you like to run the nvidia-xconfig utility to automatically update your X configuration file so that the NVIDIA X driver will be used when you restart X? Any pre-existing X configuration file will be backed up. (Answer: Yes)
→ Your X configuration file has been successfully updated. Installation of the NVIDIA Accelerated Graphics Driver for Linux-x86_64 (version: 418.88) is now complete.
*** /var/log/nvidia-uninstall.log
*** ls: -rw-r–r-- 1 root root 4288 2019-08-09 09:54:50.346912997 -0700 /var/log/nvidia-uninstall.log
nvidia-installer log file ‘/var/log/nvidia-uninstall.log’
creation time: Fri Aug 9 09:53:54 2019
nvidia-installer
–uninstall
→ Parsing log file:
→ done.
→ Validating previous installation:
→ Unable to find installed file ‘/usr/share/glvnd/egl_vendor.d/10_nvidia.json’ (No such file or directory).
→ Unable to find installed file ‘/usr/lib64/xorg/modules/drivers/nvidia_drv.so’ (No such file or directory).
→ Unable to find installed file ‘/usr/bin/nvidia-xconfig’ (No such file or directory).
→ Unable to find installed file ‘/usr/share/man/man1/nvidia-xconfig.1.gz’ (No such file or directory).
→ Unable to find installed file ‘/usr/bin/nvidia-settings’ (No such file or directory).
→ Unable to find installed file ‘/usr/share/man/man1/nvidia-settings.1.gz’ (No such file or directory).
→ Unable to find installed file ‘/usr/bin/nvidia-bug-report.sh’ (No such file or directory).
→ Unable to find installed file ‘/usr/bin/nvidia-modprobe’ (No such file or directory).
→ Unable to find installed file ‘/usr/share/man/man1/nvidia-modprobe.1.gz’ (No such file or directory).
→ Unable to find installed file ‘/usr/bin/nvidia-smi’ (No such file or directory).
→ Unable to find installed file ‘/usr/share/man/man1/nvidia-smi.1.gz’ (No such file or directory).
→ Unable to find installed file ‘/usr/bin/nvidia-debugdump’ (No such file or directory).
→ Unable to find installed file ‘/etc/OpenCL/vendors/nvidia.icd’ (No such file or directory).
→ Unable to find installed file ‘/usr/bin/nvidia-cuda-mps-control’ (No such file or directory).
→ Unable to find installed file ‘/usr/bin/nvidia-cuda-mps-server’ (No such file or directory).
→ Unable to find installed file ‘/usr/share/man/man1/nvidia-cuda-mps-control.1.gz’ (No such file or directory).
→ Unable to find installed file ‘/usr/share/man/man1/nvidia-persistenced.1.gz’ (No such file or directory).
→ Unable to find installed file ‘/usr/bin/nvidia-persistenced’ (No such file or directory).
→ Unable to find installed file ‘/usr/share/egl/egl_external_platform.d/10_nvidia_wayland.json’ (No such file or directory).
→ Unable to find installed file ‘/usr/share/applications/nvidia-settings.desktop’ (No such file or directory).
→ Unable to access previously installed symlink ‘/usr/lib64/xorg/modules/extensions/libglxserver_nvidia.so’ (No such file or directory).
→ Unable to access previously installed symlink ‘/usr/lib64/libnvidia-cfg.so’ (No such file or directory).
→ Unable to access previously installed symlink ‘/usr/lib64/libnvidia-ml.so’ (No such file or directory).
→ Unable to access previously installed symlink ‘/usr/lib64/vdpau/libvdpau_nvidia.so.1’ (No such file or directory).
→ Unable to access previously installed symlink ‘/usr/lib64/libcuda.so’ (No such file or directory).
→ Unable to access previously installed symlink ‘/usr/lib64/libnvidia-ptxjitcompiler.so’ (No such file or directory).
→ Unable to access previously installed symlink ‘/usr/lib64/libnvcuvid.so’ (No such file or directory).
→ Unable to access previously installed symlink ‘/usr/lib64/libnvidia-encode.so’ (No such file or directory).
→ Unable to access previously installed symlink ‘/usr/lib64/libnvidia-ifr.so’ (No such file or directory).
→ Unable to access previously installed symlink ‘/usr/lib64/libnvidia-fbc.so’ (No such file or directory).
→ done.
WARNING: Your driver installation has been altered since it was initially installed; this may happen, for example, if you have since installed the NVIDIA driver through a mechanism other than nvidia-installer (such as your distribution’s native package management system). nvidia-installer will attempt to uninstall as best it can. Please see the file ‘/var/log/nvidia-uninstall.log’ for details.
→ Uninstalling NVIDIA Accelerated Graphics Driver for Linux-x86_64 (1.0-41888 (418.88)):
→ DKMS module detected; removing…
→ done.
→ Running depmod and ldconfig:
→ done.
→ Uninstallation of existing driver: NVIDIA Accelerated Graphics Driver for Linux-x86_64 (418.88) is complete.
journalctl -b -0 _COMM=Xorg
– Logs begin at Fri 2019-04-26 17:57:11 PDT, end at Fri 2019-08-09 15:29:58 PDT. –
– No entries –
journalctl -b -1 _COMM=Xorg
– No entries –
journalctl -b -2 _COMM=Xorg
– No entries –
journalctl -b -0 _COMM=Xorg.bin
– No entries –
journalctl -b -1 _COMM=Xorg.bin
– No entries –
journalctl -b -2 _COMM=Xorg.bin
– No entries –
– No entries –
– No entries –
– No entries –
*** /var/log/Xorg.0.log
*** ls: -rw-r–r-- 1 root root 5619 2019-08-09 15:29:37.678252181 -0700 /var/log/Xorg.0.log
[ 88.477] (–) Log file renamed from “/var/log/Xorg.pid-5496.log” to “/var/log/Xorg.0.log”
[ 88.478]
X.Org X Server 1.20.4
X Protocol Version 11, Revision 0
[ 88.478] Build Operating System: 4.19.9-300.fc29.x86_64
[ 88.478] Current Operating System: Linux obsidian.almaden.ibm.com 5.1.21-200.fc29.x86_64 #1 SMP Mon Jul 29 15:30:04 UTC 2019 x86_64
[ 88.478] Kernel command line: BOOT_IMAGE=/vmlinuz-5.1.21-200.fc29.x86_64 root=/dev/mapper/ubayluks-ubroot ro resume=/dev/mapper/luks-7d80c311-840a-4126-9e81-f99ca789e856 rd.luks.uuid=luks-7f028e6c-7150-49d3-93f4-e4175a7cb110 rd.lvm.lv=ubayluks/ubroot rd.lvm.lv=fedora/03 rd.luks.uuid=luks-7d80c311-840a-4126-9e81-f99ca789e856 rhgb quiet net.ifnames=0 biosdevnames=0 rd.driver.blacklist=nouveau
[ 88.478] Build Date: 26 February 2019 08:03:46PM
[ 88.478] Build ID: xorg-x11-server 1.20.4-1.fc29
[ 88.478] Current version of pixman: 0.34.0
[ 88.478] Before reporting problems, check http://wiki.x.org
to make sure that you have the latest version.
[ 88.478] Markers: (–) probed, () from config file, (==) default setting,
(++) from command line, (!!) notice, (II) informational,
(WW) warning, (EE) error, (NI) not implemented, (??) unknown.
[ 88.478] (==) Log file: “/var/log/Xorg.0.log”, Time: Fri Aug 9 15:29:37 2019
[ 88.478] (==) Using config file: “/etc/X11/xorg.conf”
[ 88.478] (==) Using config directory: “/etc/X11/xorg.conf.d”
[ 88.478] (==) Using system config directory “/usr/share/X11/xorg.conf.d”
[ 88.478] (==) ServerLayout “Layout0”
[ 88.478] (
) |–>Screen “Screen0” (0)
[ 88.478] () | |–>Monitor “Monitor0”
[ 88.478] (
) | |–>Device “Device0”
[ 88.478] () |–>Input Device “Keyboard0”
[ 88.478] (
) |–>Input Device “Mouse0”
[ 88.478] (==) Automatically adding devices
[ 88.478] (==) Automatically enabling devices
[ 88.478] (==) Automatically adding GPU devices
[ 88.478] (==) Automatically binding GPU devices
[ 88.478] (==) Max clients allowed: 256, resource mask: 0x1fffff
[ 88.478] (==) FontPath set to:
catalogue:/etc/X11/fontpath.d,
built-ins
[ 88.478] (==) ModulePath set to “/usr/lib64/xorg/modules”
[ 88.478] (WW) Hotplugging is on, devices using drivers ‘kbd’, ‘mouse’ or ‘vmmouse’ will be disabled.
[ 88.478] (WW) Disabling Keyboard0
[ 88.478] (WW) Disabling Mouse0
[ 88.478] (II) Loader magic: 0x56384847de00
[ 88.478] (II) Module ABI versions:
[ 88.478] X.Org ANSI C Emulation: 0.4
[ 88.478] X.Org Video Driver: 24.0
[ 88.478] X.Org XInput driver : 24.1
[ 88.478] X.Org Server Extension : 10.0
[ 88.479] (++) using VT number 1
[ 88.479] (II) systemd-logind: logind integration requires -keeptty and -keeptty was not provided, disabling logind integration
[ 88.479] (II) xfree86: Adding drm device (/dev/dri/card0)
[ 88.481] (–) PCI:*(1@0:0:0) 10de:0ffc:17aa:21f6 rev 161, Mem @ 0xf2000000/16777216, 0xe0000000/268435456, 0xf0000000/33554432, I/O @ 0x00005000/128, BIOS @ 0x???/131072
[ 88.481] (II) LoadModule: “glx”
[ 88.481] (II) Loading /usr/lib64/xorg/modules/extensions/libglx.so
[ 88.483] (II) Module glx: vendor=“X.Org Foundation”
[ 88.483] compiled for 1.20.4, module version = 1.0.0
[ 88.483] ABI class: X.Org Server Extension, version 10.0
[ 88.483] (II) LoadModule: “nvidia”
[ 88.483] (II) Loading /usr/lib64/xorg/modules/drivers/nvidia_drv.so
[ 88.483] (II) Module nvidia: vendor=“NVIDIA Corporation”
[ 88.483] compiled for 4.0.2, module version = 1.0.0
[ 88.483] Module class: X.Org Video Driver
[ 88.483] (II) NVIDIA dlloader X Driver 418.67 Sat Apr 6 02:51:17 CDT 2019
[ 88.483] (II) NVIDIA Unified Driver for all Supported NVIDIA GPUs
[ 88.483] (II) Loading sub module “fb”
[ 88.483] (II) LoadModule: “fb”
[ 88.483] (II) Loading /usr/lib64/xorg/modules/libfb.so
[ 88.483] (II) Module fb: vendor=“X.Org Foundation”
[ 88.483] ABI class: X.Org ANSI C Emulation, version 0.4
[ 88.483] (II) Loading sub module “wfb”
[ 88.484] (II) LoadModule: “wfb”
[ 88.484] (II) Loading /usr/lib64/xorg/modules/libwfb.so
[ 88.484] (II) Module wfb: vendor=“X.Org Foundation”
[ 88.484] compiled for 1.20.4, module version = 1.0.0
[ 88.484] ABI class: X.Org ANSI C Emulation, version 0.4
[ 88.484] (II) Loading sub module “ramdac”
[ 88.484] (II) LoadModule: “ramdac”
[ 88.484] (II) Module “ramdac” already built-in
[ 88.488] (EE) NVIDIA: Failed to initialize the NVIDIA kernel module. Please see the
[ 88.488] (EE) NVIDIA: system’s kernel log for additional error messages and
[ 88.488] (EE) NVIDIA: consult the NVIDIA README for details.
[ 88.491] (EE) NVIDIA: Failed to initialize the NVIDIA kernel module. Please see the
[ 88.491] (EE) NVIDIA: system’s kernel log for additional error messages and
[ 88.491] (EE) NVIDIA: consult the NVIDIA README for details.
[ 88.494] (EE) NVIDIA: Failed to initialize the NVIDIA kernel module. Please see the
[ 88.494] (EE) NVIDIA: system’s kernel log for additional error messages and
[ 88.494] (EE) NVIDIA: consult the NVIDIA README for details.
[ 88.494] (EE) No devices detected.
[ 88.494] (EE)
Fatal server error:
[ 88.494] (EE) no screens found(EE)
[ 88.494] (EE)
Please consult the Fedora Project support
at http://wiki.x.org
for help.
[ 88.495] (EE) Please also check the log file at “/var/log/Xorg.0.log” for additional information.
[ 88.495] (EE)
[ 88.497] (EE) Server terminated with error (1). Closing log file.
*** /etc/X11/xorg.conf
*** ls: -rw-r–r-- 1 root root 1257 2019-07-31 17:34:10.161264675 -0700 /etc/X11/xorg.conf
nvidia-xconfig: X configuration file generated by nvidia-xconfig
nvidia-xconfig: version 418.88
Section “ServerLayout”
Identifier “Layout0”
Screen 0 “Screen0”
InputDevice “Keyboard0” “CoreKeyboard”
InputDevice “Mouse0” “CorePointer”
EndSection
Section “Files”
EndSection
Section “InputDevice”
# generated from default
Identifier “Mouse0”
Driver “mouse”
Option “Protocol” “auto”
Option “Device” “/dev/input/mice”
Option “Emulate3Buttons” “no”
Option “ZAxisMapping” “4 5”
EndSection
Identifier “Keyboard0”
Driver “kbd”
EndSection
Section “Monitor”
Identifier “Monitor0”
VendorName “Unknown”
ModelName “Unknown”
HorizSync 28.0 - 33.0
VertRefresh 43.0 - 72.0
Option “DPMS”
EndSection
Section “Device”
Identifier “Device0”
Driver “nvidia”
VendorName “NVIDIA Corporation”
EndSection
Section “Screen”
Identifier “Screen0”
Device “Device0”
Monitor “Monitor0”
DefaultDepth 24
SubSection “Display”
Depth 24
EndSubSection
EndSection
*** /etc/X11/xorg.conf.d/00-keyboard.conf
*** ls: -rw-r–r–. 1 root root 311 2019-04-26 17:54:54.736077012 -0700 /etc/X11/xorg.conf.d/00-keyboard.conf
Written by systemd-localed(8), read by systemd-localed and Xorg. It’s
probably wise not to edit this file manually. Use localectl(1) to
instruct systemd-localed to update it.
Section “InputClass”
Identifier “system-keyboard”
MatchIsKeyboard “on”
Option “XkbLayout” “us”
EndSection
*** /etc/X11/xorg.conf.d/10-nvidia.conf
*** ls: -rw-r–r-- 1 root root 338 2019-04-06 05:40:39.000000000 -0700 /etc/X11/xorg.conf.d/10-nvidia.conf
Section “OutputClass”
Identifier “nvidia”
MatchDriver “nvidia-drm”
Driver “nvidia”
Option “AllowEmptyInitialConfiguration”
Option “PrimaryGPU” “yes”
Option “SLI” “Auto”
Option “BaseMosaic” “on”
EndSection
Identifier “intel”
MatchDriver “i915”
Driver “modesetting”
EndSection
*** /usr/share/X11/xorg.conf.d/10-evdev.conf
*** ls: -rw-r–r–. 1 root root 1099 2018-05-28 19:33:18.000000000 -0700 /usr/share/X11/xorg.conf.d/10-evdev.conf
Catch-all evdev loader for udev-based systems
We don’t simply match on any device since that also adds accelerometers
and other devices that we don’t really want to use. The list below
matches everything but joysticks.
Identifier “evdev pointer catchall”
MatchIsPointer “on”
MatchDevicePath “/dev/input/event*”
Driver “evdev”
EndSection
Identifier “evdev keyboard catchall”
Driver “evdev”
EndSection
Identifier “evdev touchpad catchall”
MatchIsTouchpad “on”
Driver “evdev”
EndSection
Identifier “evdev tablet catchall”
MatchIsTablet “on”
Driver “evdev”
EndSection
Identifier “evdev touchscreen catchall”
MatchIsTouchscreen “on”
Driver “evdev”
EndSection
*** /usr/share/X11/xorg.conf.d/10-quirks.conf
*** ls: -rw-r–r–. 1 root root 1350 2019-02-26 12:05:43.000000000 -0800 /usr/share/X11/xorg.conf.d/10-quirks.conf
Collection of quirks and blacklist/whitelists for specific devices.
Accelerometer device, posts data through ABS_X/ABS_Y, making X unusable
22442 – ThinkPad HDAPS accelerometer gets recognized as MOUSE and makes Xorg unusable
Identifier “ThinkPad HDAPS accelerometer blacklist”
MatchProduct “ThinkPad HDAPS accelerometer data”
Option “Ignore” “on”
EndSection
523914 – Mouse does not move in PV Xen guest under RHEL-5.4
Explicitly tell evdev to not ignore the absolute axes.
Identifier “Xen Virtual Pointer axis blacklist”
MatchProduct “Xen Virtual Pointer”
Option “IgnoreAbsoluteAxes” “off”
Option “IgnoreRelativeAxes” “off”
EndSection
55867 – Doesn't know how to tag XI_TRACKBALL
Bug 55867 - Doesn’t know how to tag XI_TRACKBALL
Identifier “Tag trackballs as XI_TRACKBALL”
MatchProduct “trackball”
MatchDriver “evdev”
Option “TypeName” “TRACKBALL”
EndSection
62831 – Mionix Naos 5000 mouse detected incorrectly
Bug 62831 - Mionix Naos 5000 mouse detected incorrectly
Identifier “Tag Mionix Naos 5000 mouse XI_MOUSE”
MatchProduct “La-VIEW Technology Naos 5000 Mouse”
MatchDriver “evdev”
Option “TypeName” “MOUSE”
EndSection
*** /usr/share/X11/xorg.conf.d/10-radeon.conf
*** ls: -rw-r–r–. 1 root root 92 2018-09-14 08:56:09.000000000 -0700 /usr/share/X11/xorg.conf.d/10-radeon.conf
Identifier “Radeon”
MatchDriver “radeon”
Driver “radeon”
EndSection
*** /usr/share/X11/xorg.conf.d/40-libinput.conf
*** ls: -rw-r–r–. 1 root root 1429 2019-02-03 19:17:52.000000000 -0800 /usr/share/X11/xorg.conf.d/40-libinput.conf
Match on all types of devices but joysticks
If you want to configure your devices, do not copy this file.
Instead, use a config snippet that contains something like this:
Identifier “something or other”
MatchDriver “libinput”
… other Match directives …
Option “someoption” “value”
EndSection
This applies the option any libinput device also matched by the other
directives. See the xorg.conf(5) man page for more info on
matching devices.
Identifier “libinput pointer catchall”
MatchIsPointer “on”
Driver “libinput”
EndSection
Identifier “libinput keyboard catchall”
Driver “libinput”
EndSection
Identifier “libinput touchpad catchall”
Driver “libinput”
EndSection
Identifier “libinput touchscreen catchall”
Driver “libinput”
EndSection
Identifier “libinput tablet catchall”
MatchIsTablet “on”
Driver “libinput”
EndSection
*** /usr/share/X11/xorg.conf.d/70-wacom.conf
*** ls: -rw-r–r–. 1 root root 3025 2017-12-08 13:47:43.000000000 -0800 /usr/share/X11/xorg.conf.d/70-wacom.conf
Some of the below input classes appear 3x times, once for each of
“tablet”, “touchscreen”, and “touchpad” to ensure that the Wacom
driver is not accidentally bound to other types of hardware that
Wacom has made which are not handled by the wacom driver (e.g the
Wacom Bluetooth Keyboard)
Linux Wacom Tablet Project / Bugs / #294 Wacom Bluetooth Keyboard mistakenly bound to xf86-input-wacom driver
Identifier “Wacom USB tablet class”
MatchUSBID “056a:"
MatchDevicePath "/dev/input/event
MatchIsTablet “true”
Driver “wacom”
EndSection
Identifier “Wacom USB touchscreen class”
MatchUSBID “056a:"
MatchIsTouchscreen “true”
Driver “wacom”
EndSection
Identifier “Wacom USB touchpad class”
MatchUSBID “056a:"
MatchIsTouchpad “true”
Driver “wacom”
EndSection
Identifier “Wacom tablet class”
MatchProduct “Wacom|WACOM|PTK-540WL|ISD-V4”
Driver “wacom”
EndSection
Identifier “Wacom touchscreen class”
Driver “wacom”
EndSection
Section "InputClass
Don’t use the bundled nvidia driver, reinstall your old one that worked and when you it comes to install cuda,
don’t install “cuda” but instead “cuda-toolkit-10-1”
Great, I’ll give it a try…
Bob Shelby
