vulkaninfo
ERROR: ld.so: object ‘libachk.so’ from /etc/ld.so.preload cannot be preloaded (wrong ELF class: ELFCLASS64): ignored.
VULKAN INFO
Vulkan Instance Version: 1.1.73
ERROR: [Loader Message] Code 0 : libGLX_nvidia.so.0: cannot open shared object file: No such file or directory
Cannot create Vulkan instance.
/build/vulkan-CbT3KM/vulkan-1.1.73+dfsg/demos/vulkaninfo.c:812: failed with VK_ERROR_INCOMPATIB
nvidia-smi
| NVIDIA-SMI 396.54.09 Driver Version: 396.54.09 |
| 0 Tesla K10.G2.8GB Off | 00000000:84:00.0 Off | 0 |
| N/A 41C P0 42W / 117W | 0MiB / 3527MiB | 0% Default |
| 1 Tesla K10.G2.8GB Off | 00000000:85:00.0 Off | 0 |
| N/A 38C P0 37W / 117W | 0MiB / 3527MiB | 0% Default |
| Processes: GPU Memory |
| GPU PID Type Process name Usage |
| No running processes found |
3.nvidia-bug-report.log
Start of NVIDIA bug report log file. Please include this file, along
with a detailed description of your problem, when reporting a graphics
driver bug via the NVIDIA Linux forum (see devtalk.nvidia.com)
or by sending email to ‘linux-bugs@nvidia.com’.
nvidia-bug-report.sh Version: 23594433
Date: Tue Dec 18 18:07:54 CST 2018
uname: Linux pegavsim 4.4.0-140-generic #166-Ubuntu SMP Wed Nov 14 20:09:47 UTC 2018 x86_64 x86_64 x86_64 GNU/Linux
command line flags:
*** /etc/issue
*** ls: -rw-r–r-- 1 root root 26 2018-07-17 18:20:12.000000000 +0800 /etc/issue
Ubuntu 16.04.5 LTS \n \l
*** /etc/debian_version
*** ls: -rw-r–r-- 1 root root 12 2015-04-30 18:00:00.000000000 +0800 /etc/debian_version
stretch/sid
*** /var/log/nvidia-installer.log
*** ls: -rw-r–r-- 1 root root 26462 2018-12-18 17:46:57.463034774 +0800 /var/log/nvidia-installer.log
nvidia-installer log file ‘/var/log/nvidia-installer.log’
creation time: Tue Dec 18 17:46:25 2018
installer version: 396.54.09
PATH: /usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/snap/bin
nvidia-installer command line:
./nvidia-installer
–no-opengl-files
Unable to load: nvidia-installer ncurses v6 user interface
Using: nvidia-installer ncurses user interface
→ Detected 64 CPUs online; setting concurrency level to 32.
→ Installing NVIDIA driver version 396.54.09.
→ Running distribution scripts
executing: ‘/usr/lib/nvidia/pre-install’…
→ done.
→ The distribution-provided pre-install script failed! Are you sure you want to continue? (Answer: Continue installation)
→ Performing CC sanity check with CC=“/usr/bin/cc”.
→ Kernel source path: ‘/lib/modules/4.4.0-140-generic/build’
→ Kernel output path: ‘/lib/modules/4.4.0-140-generic/build’
→ Performing Compiler check.
→ Performing Dom0 check.
→ Performing Xen check.
→ Performing PREEMPT_RT check.
→ Performing vgpu_kvm check.
→ Cleaning kernel module build directory.
executing: ‘cd ./kernel; /usr/bin/make -k -j32 clean NV_EXCLUDE_KERNEL_MODULES=“” SYSSRC=“/lib/modules/4.4.0-140-generic/build” SYSOUT=“/lib/modules/4.4.0-140-generic/build”’…
rm -f -r conftest
make[1]: Entering directory ‘/usr/src/linux-headers-4.4.0-140-generic’
make[1]: Leaving directory ‘/usr/src/linux-headers-4.4.0-140-generic’
→ Building kernel modules
executing: ‘cd ./kernel; /usr/bin/make -k -j32 NV_EXCLUDE_KERNEL_MODULES=“” SYSSRC=“/lib/modules/4.4.0-140-generic/build” SYSOUT=“/lib/modules/4.4.0-140-generic/build”’…
SYMLINK /tmp/selfgz9757/NVIDIA-Linux-x86_64-396.54.09/kernel/nvidia/nv-kernel.o
SYMLINK /tmp/selfgz9757/NVIDIA-Linux-x86_64-396.54.09/kernel/nvidia-modeset/nv-modeset-kernel.o
CONFTEST: INIT_WORK
CONFTEST: remap_pfn_range
CONFTEST: follow_pfn
CONFTEST: hash__remap_4k_pfn
CONFTEST: vmap
CONFTEST: set_pages_uc
CONFTEST: set_memory_uc
CONFTEST: set_memory_array_uc
CONFTEST: change_page_attr
CONFTEST: pci_get_class
CONFTEST: pci_choose_state
CONFTEST: acpi_device_id
CONFTEST: on_each_cpu
CONFTEST: kmem_cache_create
CONFTEST: console_lock
CONFTEST: vm_insert_page
CONFTEST: acquire_console_sem
CONFTEST: acpi_evaluate_integer
CONFTEST: ioremap_cache
CONFTEST: ioremap_wc
CONFTEST: acpi_walk_namespace
CONFTEST: pci_domain_nr
CONFTEST: smp_call_function
CONFTEST: pci_dma_mapping_error
CONFTEST: sg_alloc_table
CONFTEST: sg_init_table
CONFTEST: pci_get_domain_bus_and_slot
CONFTEST: get_num_physpages
CONFTEST: efi_enabled
CONFTEST: pde_data
CONFTEST: proc_create_data
CONFTEST: proc_remove
CONFTEST: pm_vt_switch_required
CONFTEST: xen_ioemu_inject_msi
CONFTEST: phys_to_dma
CONFTEST: get_dma_ops
CONFTEST: write_cr4
CONFTEST: of_get_property
CONFTEST: of_find_node_by_phandle
CONFTEST: of_node_to_nid
CONFTEST: pnv_pci_get_npu_dev
CONFTEST: of_get_ibm_chip_id
CONFTEST: for_each_online_node
CONFTEST: node_end_pfn
CONFTEST: pci_bus_address
CONFTEST: pci_stop_and_remove_bus_device
CONFTEST: pci_remove_bus_device
CONFTEST: request_threaded_irq
CONFTEST: register_cpu_notifier
CONFTEST: cpuhp_setup_state
CONFTEST: dma_map_resource
CONFTEST: backlight_device_register
CONFTEST: register_acpi_notifier
CONFTEST: timer_setup
CONFTEST: compound_order
CONFTEST: remap_page_range
CONFTEST: address_space_init_once
CONFTEST: kbasename
CONFTEST: fatal_signal_pending
CONFTEST: list_cut_position
CONFTEST: vzalloc
CONFTEST: wait_on_bit_lock_argument_count
CONFTEST: bitmap_clear
CONFTEST: usleep_range
CONFTEST: radix_tree_empty
CONFTEST: radix_tree_replace_slot
CONFTEST: pnv_npu2_init_context
CONFTEST: drm_dev_unref
CONFTEST: drm_reinit_primary_mode_group
CONFTEST: drm_atomic_set_mode_for_crtc
CONFTEST: drm_atomic_clean_old_fb
CONFTEST: drm_gem_object_lookup
CONFTEST: get_user_pages_remote
CONFTEST: drm_atomic_state_free
CONFTEST: drm_driver_has_gem_prime_res_obj
CONFTEST: drm_atomic_helper_disable_all
CONFTEST: drm_atomic_helper_set_config
CONFTEST: drm_atomic_helper_connector_dpms
CONFTEST: is_export_symbol_gpl_of_node_to_nid
CONFTEST: is_export_symbol_present_swiotlb_map_sg_attrs
CONFTEST: i2c_adapter
CONFTEST: pm_message_t
CONFTEST: acpi_device_ops
CONFTEST: irq_handler_t
CONFTEST: acpi_op_remove
CONFTEST: outer_flush_all
CONFTEST: proc_dir_entry
CONFTEST: scatterlist
CONFTEST: sg_table
CONFTEST: file_operations
CONFTEST: vm_operations_struct
CONFTEST: atomic_long_type
CONFTEST: pci_save_state
CONFTEST: file_inode
CONFTEST: task_struct
CONFTEST: kuid_t
CONFTEST: dma_ops
CONFTEST: dma_map_ops
CONFTEST: noncoherent_swiotlb_dma_ops
CONFTEST: vm_fault_present
CONFTEST: vm_fault_has_address
CONFTEST: backlight_properties_type
CONFTEST: fault_flags
CONFTEST: atomic64_type
CONFTEST: backing_dev_info
CONFTEST: mm_context_t
CONFTEST: vm_ops_fault_removed_vma_arg
CONFTEST: drm_bus_present
CONFTEST: drm_bus_has_bus_type
CONFTEST: drm_bus_has_get_irq
CONFTEST: drm_bus_has_get_name
CONFTEST: drm_driver_has_legacy_dev_list
CONFTEST: drm_crtc_state_has_connectors_changed
CONFTEST: drm_driver_has_set_busid
CONFTEST: drm_init_function_args
CONFTEST: drm_mode_connector_list_update_has_merge_type_bits_arg
CONFTEST: drm_helper_mode_fill_fb_struct
CONFTEST: drm_master_drop_has_from_release_arg
CONFTEST: drm_driver_unload_has_int_return_type
CONFTEST: kref_has_refcount_of_type_refcount_t
CONFTEST: drm_atomic_helper_crtc_destroy_state_has_crtc_arg
CONFTEST: drm_crtc_helper_funcs_has_atomic_enable
CONFTEST: drm_old_atomic_state_iterators_present
CONFTEST: drm_mode_object_find_has_file_priv_arg
CONFTEST: dom0_kernel_present
CONFTEST: nvidia_vgpu_kvm_build
CONFTEST: nvidia_grid_build
CONFTEST: drm_available
CONFTEST: drm_atomic_available
CONFTEST: drm_atomic_modeset_nonblocking_commit_available
CONFTEST: is_export_symbol_gpl_refcount_inc
CONFTEST: is_export_symbol_gpl_refcount_dec_and_test
CC [M] /tmp/selfgz9757/NVIDIA-Linux-x86_64-396.54.09/kernel/nvidia/nv-frontend.o
CC [M] /tmp/selfgz9757/NVIDIA-Linux-x86_64-396.54.09/kernel/nvidia/nv-instance.o
CC [M] /tmp/selfgz9757/NVIDIA-Linux-x86_64-396.54.09/kernel/nvidia/nv.o
CC [M] /tmp/selfgz9757/NVIDIA-Linux-x86_64-396.54.09/kernel/nvidia/nv-acpi.o
CC [M] /tmp/selfgz9757/NVIDIA-Linux-x86_64-396.54.09/kernel/nvidia/nv-cray.o
CC [M] /tmp/selfgz9757/NVIDIA-Linux-x86_64-396.54.09/kernel/nvidia/nv-chrdev.o
CC [M] /tmp/selfgz9757/NVIDIA-Linux-x86_64-396.54.09/kernel/nvidia/nv-dma.o
CC [M] /tmp/selfgz9757/NVIDIA-Linux-x86_64-396.54.09/kernel/nvidia/nv-gvi.o
CC [M] /tmp/selfgz9757/NVIDIA-Linux-x86_64-396.54.09/kernel/nvidia/nv-i2c.o
CC [M] /tmp/selfgz9757/NVIDIA-Linux-x86_64-396.54.09/kernel/nvidia/nv-mempool.o
CC [M] /tmp/selfgz9757/NVIDIA-Linux-x86_64-396.54.09/kernel/nvidia/nv-mmap.o
CC [M] /tmp/selfgz9757/NVIDIA-Linux-x86_64-396.54.09/kernel/nvidia/nv-p2p.o
CC [M] /tmp/selfgz9757/NVIDIA-Linux-x86_64-396.54.09/kernel/nvidia/nv-procfs.o
CC [M] /tmp/selfgz9757/NVIDIA-Linux-x86_64-396.54.09/kernel/nvidia/nv-pat.o
CC [M] /tmp/selfgz9757/NVIDIA-Linux-x86_64-396.54.09/kernel/nvidia/nv-usermap.o
CC [M] /tmp/selfgz9757/NVIDIA-Linux-x86_64-396.54.09/kernel/nvidia/nv-vm.o
CC [M] /tmp/selfgz9757/NVIDIA-Linux-x86_64-396.54.09/kernel/nvidia/os-interface.o
CC [M] /tmp/selfgz9757/NVIDIA-Linux-x86_64-396.54.09/kernel/nvidia/nv-vtophys.o
CC [M] /tmp/selfgz9757/NVIDIA-Linux-x86_64-396.54.09/kernel/nvidia/os-mlock.o
CC [M] /tmp/selfgz9757/NVIDIA-Linux-x86_64-396.54.09/kernel/nvidia/os-pci.o
CC [M] /tmp/selfgz9757/NVIDIA-Linux-x86_64-396.54.09/kernel/nvidia/os-registry.o
CC [M] /tmp/selfgz9757/NVIDIA-Linux-x86_64-396.54.09/kernel/nvidia/os-usermap.o
CC [M] /tmp/selfgz9757/NVIDIA-Linux-x86_64-396.54.09/kernel/nvidia/nv-modeset-interface.o
CC [M] /tmp/selfgz9757/NVIDIA-Linux-x86_64-396.54.09/kernel/nvidia/nv-pci-table.o
CC [M] /tmp/selfgz9757/NVIDIA-Linux-x86_64-396.54.09/kernel/nvidia/nv-kthread-q.o
CC [M] /tmp/selfgz9757/NVIDIA-Linux-x86_64-396.54.09/kernel/nvidia/nv-kthread-q-selftest.o
CC [M] /tmp/selfgz9757/NVIDIA-Linux-x86_64-396.54.09/kernel/nvidia/nv-memdbg.o
CC [M] /tmp/selfgz9757/NVIDIA-Linux-x86_64-396.54.09/kernel/nvidia/nv-ibmnpu.o
CC [M] /tmp/selfgz9757/NVIDIA-Linux-x86_64-396.54.09/kernel/nvidia/nv-report-err.o
CC [M] /tmp/selfgz9757/NVIDIA-Linux-x86_64-396.54.09/kernel/nvidia/nv-rsync.o
CC [M] /tmp/selfgz9757/NVIDIA-Linux-x86_64-396.54.09/kernel/nvidia/nv_uvm_interface.o
CC [M] /tmp/selfgz9757/NVIDIA-Linux-x86_64-396.54.09/kernel/nvidia/nvlink_linux.o
CC [M] /tmp/selfgz9757/NVIDIA-Linux-x86_64-396.54.09/kernel/nvidia-uvm/uvm_utils.o
CC [M] /tmp/selfgz9757/NVIDIA-Linux-x86_64-396.54.09/kernel/nvidia-uvm/uvm_common.o
CC [M] /tmp/selfgz9757/NVIDIA-Linux-x86_64-396.54.09/kernel/nvidia-uvm/uvm_linux.o
CC [M] /tmp/selfgz9757/NVIDIA-Linux-x86_64-396.54.09/kernel/nvidia-uvm/nvstatus.o
CC [M] /tmp/selfgz9757/NVIDIA-Linux-x86_64-396.54.09/kernel/nvidia-uvm/nvCpuUuid.o
CC [M] /tmp/selfgz9757/NVIDIA-Linux-x86_64-396.54.09/kernel/nvidia-uvm/uvm8.o
CC [M] /tmp/selfgz9757/NVIDIA-Linux-x86_64-396.54.09/kernel/nvidia-uvm/uvm8_tools.o
CC [M] /tmp/selfgz9757/NVIDIA-Linux-x86_64-396.54.09/kernel/nvidia-uvm/uvm8_global.o
CC [M] /tmp/selfgz9757/NVIDIA-Linux-x86_64-396.54.09/kernel/nvidia-uvm/uvm8_gpu.o
CC [M] /tmp/selfgz9757/NVIDIA-Linux-x86_64-396.54.09/kernel/nvidia-uvm/uvm8_gpu_isr.o
CC [M] /tmp/selfgz9757/NVIDIA-Linux-x86_64-396.54.09/kernel/nvidia-uvm/uvm8_procfs.o
CC [M] /tmp/selfgz9757/NVIDIA-Linux-x86_64-396.54.09/kernel/nvidia-uvm/uvm8_va_space.o
CC [M] /tmp/selfgz9757/NVIDIA-Linux-x86_64-396.54.09/kernel/nvidia-uvm/uvm8_va_space_mm.o
CC [M] /tmp/selfgz9757/NVIDIA-Linux-x86_64-396.54.09/kernel/nvidia-uvm/uvm8_gpu_semaphore.o
CC [M] /tmp/selfgz9757/NVIDIA-Linux-x86_64-396.54.09/kernel/nvidia-uvm/uvm8_mem.o
CC [M] /tmp/selfgz9757/NVIDIA-Linux-x86_64-396.54.09/kernel/nvidia-uvm/uvm8_rm_mem.o
CC [M] /tmp/selfgz9757/NVIDIA-Linux-x86_64-396.54.09/kernel/nvidia-uvm/uvm8_channel.o
CC [M] /tmp/selfgz9757/NVIDIA-Linux-x86_64-396.54.09/kernel/nvidia-uvm/uvm8_lock.o
CC [M] /tmp/selfgz9757/NVIDIA-Linux-x86_64-396.54.09/kernel/nvidia-uvm/uvm8_hal.o
CC [M] /tmp/selfgz9757/NVIDIA-Linux-x86_64-396.54.09/kernel/nvidia-uvm/uvm8_range_tree.o
CC [M] /tmp/selfgz9757/NVIDIA-Linux-x86_64-396.54.09/kernel/nvidia-uvm/uvm8_range_allocator.o
CC [M] /tmp/selfgz9757/NVIDIA-Linux-x86_64-396.54.09/kernel/nvidia-uvm/uvm8_va_range.o
CC [M] /tmp/selfgz9757/NVIDIA-Linux-x86_64-396.54.09/kernel/nvidia-uvm/uvm8_va_block.o
CC [M] /tmp/selfgz9757/NVIDIA-Linux-x86_64-396.54.09/kernel/nvidia-uvm/uvm8_range_group.o
CC [M] /tmp/selfgz9757/NVIDIA-Linux-x86_64-396.54.09/kernel/nvidia-uvm/uvm8_gpu_replayable_faults.o
CC [M] /tmp/selfgz9757/NVIDIA-Linux-x86_64-396.54.09/kernel/nvidia-uvm/uvm8_gpu_non_replayable_faults.o
CC [M] /tmp/selfgz9757/NVIDIA-Linux-x86_64-396.54.09/kernel/nvidia-uvm/uvm8_gpu_access_counters.o
CC [M] /tmp/selfgz9757/NVIDIA-Linux-x86_64-396.54.09/kernel/nvidia-uvm/uvm8_perf_events.o
CC [M] /tmp/selfgz9757/NVIDIA-Linux-x86_64-396.54.09/kernel/nvidia-uvm/uvm8_perf_module.o
CC [M] /tmp/selfgz9757/NVIDIA-Linux-x86_64-396.54.09/kernel/nvidia-uvm/uvm8_mmu.o
CC [M] /tmp/selfgz9757/NVIDIA-Linux-x86_64-396.54.09/kernel/nvidia-uvm/uvm8_pte_batch.o
CC [M] /tmp/selfgz9757/NVIDIA-Linux-x86_64-396.54.09/kernel/nvidia-uvm/uvm8_tlb_batch.o
CC [M] /tmp/selfgz9757/NVIDIA-Linux-x86_64-396.54.09/kernel/nvidia-uvm/uvm8_push.o
CC [M] /tmp/selfgz9757/NVIDIA-Linux-x86_64-396.54.09/kernel/nvidia-uvm/uvm8_pushbuffer.o
CC [M] /tmp/selfgz9757/NVIDIA-Linux-x86_64-396.54.09/kernel/nvidia-uvm/uvm8_thread_context.o
CC [M] /tmp/selfgz9757/NVIDIA-Linux-x86_64-396.54.09/kernel/nvidia-uvm/uvm8_tracker.o
CC [M] /tmp/selfgz9757/NVIDIA-Linux-x86_64-396.54.09/kernel/nvidia-uvm/uvm8_kepler.o
CC [M] /tmp/selfgz9757/NVIDIA-Linux-x86_64-396.54.09/kernel/nvidia-uvm/uvm8_kepler_ce.o
CC [M] /tmp/selfgz9757/NVIDIA-Linux-x86_64-396.54.09/kernel/nvidia-uvm/uvm8_kepler_host.o
CC [M] /tmp/selfgz9757/NVIDIA-Linux-x86_64-396.54.09/kernel/nvidia-uvm/uvm8_kepler_mmu.o
CC [M] /tmp/selfgz9757/NVIDIA-Linux-x86_64-396.54.09/kernel/nvidia-uvm/uvm8_maxwell.o
CC [M] /tmp/selfgz9757/NVIDIA-Linux-x86_64-396.54.09/kernel/nvidia-uvm/uvm8_maxwell_host.o
CC [M] /tmp/selfgz9757/NVIDIA-Linux-x86_64-396.54.09/kernel/nvidia-uvm/uvm8_pascal.o
CC [M] /tmp/selfgz9757/NVIDIA-Linux-x86_64-396.54.09/kernel/nvidia-uvm/uvm8_pascal_ce.o
CC [M] /tmp/selfgz9757/NVIDIA-Linux-x86_64-396.54.09/kernel/nvidia-uvm/uvm8_pascal_host.o
CC [M] /tmp/selfgz9757/NVIDIA-Linux-x86_64-396.54.09/kernel/nvidia-uvm/uvm8_pascal_mmu.o
CC [M] /tmp/selfgz9757/NVIDIA-Linux-x86_64-396.54.09/kernel/nvidia-uvm/uvm8_pascal_fault_buffer.o
CC [M] /tmp/selfgz9757/NVIDIA-Linux-x86_64-396.54.09/kernel/nvidia-uvm/uvm8_volta_host.o
CC [M] /tmp/selfgz9757/NVIDIA-Linux-x86_64-396.54.09/kernel/nvidia-uvm/uvm8_volta_mmu.o
CC [M] /tmp/selfgz9757/NVIDIA-Linux-x86_64-396.54.09/kernel/nvidia-uvm/uvm8_volta.o
CC [M] /tmp/selfgz9757/NVIDIA-Linux-x86_64-396.54.09/kernel/nvidia-uvm/uvm8_volta_fault_buffer.o
CC [M] /tmp/selfgz9757/NVIDIA-Linux-x86_64-396.54.09/kernel/nvidia-uvm/uvm8_volta_access_counter_buffer.o
CC [M] /tmp/selfgz9757/NVIDIA-Linux-x86_64-396.54.09/kernel/nvidia-uvm/uvm8_policy.o
CC [M] /tmp/selfgz9757/NVIDIA-Linux-x86_64-396.54.09/kernel/nvidia-uvm/uvm8_perf_utils.o
CC [M] /tmp/selfgz9757/NVIDIA-Linux-x86_64-396.54.09/kernel/nvidia-uvm/uvm8_kvmalloc.o
CC [M] /tmp/selfgz9757/NVIDIA-Linux-x86_64-396.54.09/kernel/nvidia-uvm/uvm8_pmm_sysmem.o
CC [M] /tmp/selfgz9757/NVIDIA-Linux-x86_64-396.54.09/kernel/nvidia-uvm/uvm8_pmm_gpu.o
CC [M] /tmp/selfgz9757/NVIDIA-Linux-x86_64-396.54.09/kernel/nvidia-uvm/uvm8_migrate.o
CC [M] /tmp/selfgz9757/NVIDIA-Linux-x86_64-396.54.09/kernel/nvidia-uvm/uvm8_map_external.o
CC [M] /tmp/selfgz9757/NVIDIA-Linux-x86_64-396.54.09/kernel/nvidia-uvm/uvm8_user_channel.o
CC [M] /tmp/selfgz9757/NVIDIA-Linux-x86_64-396.54.09/kernel/nvidia-uvm/uvm8_hmm.o
CC [M] /tmp/selfgz9757/NVIDIA-Linux-x86_64-396.54.09/kernel/nvidia-uvm/uvm8_perf_heuristics.o
CC [M] /tmp/selfgz9757/NVIDIA-Linux-x86_64-396.54.09/kernel/nvidia-uvm/uvm8_perf_thrashing.o
CC [M] /tmp/selfgz9757/NVIDIA-Linux-x86_64-396.54.09/kernel/nvidia-uvm/uvm8_perf_prefetch.o
CC [M] /tmp/selfgz9757/NVIDIA-Linux-x86_64-396.54.09/kernel/nvidia-uvm/uvm8_ats_ibm.o
CC [M] /tmp/selfgz9757/NVIDIA-Linux-x86_64-396.54.09/kernel/nvidia-uvm/uvm8_ats_faults.o
CC [M] /tmp/selfgz9757/NVIDIA-Linux-x86_64-396.54.09/kernel/nvidia-uvm/uvm8_test.o
CC [M] /tmp/selfgz9757/NVIDIA-Linux-x86_64-396.54.09/kernel/nvidia-uvm/uvm8_test_rng.o
CC [M] /tmp/selfgz9757/NVIDIA-Linux-x86_64-396.54.09/kernel/nvidia-uvm/uvm8_range_tree_test.o
CC [M] /tmp/selfgz9757/NVIDIA-Linux-x86_64-396.54.09/kernel/nvidia-uvm/uvm8_range_allocator_test.o
CC [M] /tmp/selfgz9757/NVIDIA-Linux-x86_64-396.54.09/kernel/nvidia-uvm/uvm8_gpu_semaphore_test.o
CC [M] /tmp/selfgz9757/NVIDIA-Linux-x86_64-396.54.09/kernel/nvidia-uvm/uvm8_mem_test.o
CC [M] /tmp/selfgz9757/NVIDIA-Linux-x86_64-396.54.09/kernel/nvidia-uvm/uvm8_rm_mem_test.o
CC [M] /tmp/selfgz9757/NVIDIA-Linux-x86_64-396.54.09/kernel/nvidia-uvm/uvm8_page_tree_test.o
CC [M] /tmp/selfgz9757/NVIDIA-Linux-x86_64-396.54.09/kernel/nvidia-uvm/uvm8_tracker_test.o
CC [M] /tmp/selfgz9757/NVIDIA-Linux-x86_64-396.54.09/kernel/nvidia-uvm/uvm8_push_test.o
CC [M] /tmp/selfgz9757/NVIDIA-Linux-x86_64-396.54.09/kernel/nvidia-uvm/uvm8_channel_test.o
CC [M] /tmp/selfgz9757/NVIDIA-Linux-x86_64-396.54.09/kernel/nvidia-uvm/uvm8_ce_test.o
CC [M] /tmp/selfgz9757/NVIDIA-Linux-x86_64-396.54.09/kernel/nvidia-uvm/uvm8_lock_test.o
CC [M] /tmp/selfgz9757/NVIDIA-Linux-x86_64-396.54.09/kernel/nvidia-uvm/uvm8_perf_utils_test.o
CC [M] /tmp/selfgz9757/NVIDIA-Linux-x86_64-396.54.09/kernel/nvidia-uvm/uvm8_kvmalloc_test.o
CC [M] /tmp/selfgz9757/NVIDIA-Linux-x86_64-396.54.09/kernel/nvidia-uvm/uvm8_pmm_test.o
CC [M] /tmp/selfgz9757/NVIDIA-Linux-x86_64-396.54.09/kernel/nvidia-uvm/uvm8_pmm_sysmem_test.o
CC [M] /tmp/selfgz9757/NVIDIA-Linux-x86_64-396.54.09/kernel/nvidia-uvm/uvm8_perf_events_test.o
CC [M] /tmp/selfgz9757/NVIDIA-Linux-x86_64-396.54.09/kernel/nvidia-uvm/uvm8_perf_module_test.o
CC [M] /tmp/selfgz9757/NVIDIA-Linux-x86_64-396.54.09/kernel/nvidia-uvm/uvm8_get_rm_ptes_test.o
CC [M] /tmp/selfgz9757/NVIDIA-Linux-x86_64-396.54.09/kernel/nvidia-uvm/uvm8_fault_buffer_flush_test.o
CC [M] /tmp/selfgz9757/NVIDIA-Linux-x86_64-396.54.09/kernel/nvidia-uvm/uvm8_mmu_test.o
CC [M] /tmp/selfgz9757/NVIDIA-Linux-x86_64-396.54.09/kernel/nvidia-uvm/uvm8_peer_identity_mappings_test.o
CC [M] /tmp/selfgz9757/NVIDIA-Linux-x86_64-396.54.09/kernel/nvidia-uvm/uvm8_va_block_test.o
CC [M] /tmp/selfgz9757/NVIDIA-Linux-x86_64-396.54.09/kernel/nvidia-uvm/uvm8_range_group_tree_test.o
CC [M] /tmp/selfgz9757/NVIDIA-Linux-x86_64-396.54.09/kernel/nvidia-modeset/nvidia-modeset-linux.o
CC [M] /tmp/selfgz9757/NVIDIA-Linux-x86_64-396.54.09/kernel/nvidia-drm/nvidia-drm.o
CC [M] /tmp/selfgz9757/NVIDIA-Linux-x86_64-396.54.09/kernel/nvidia-drm/nvidia-drm-drv.o
CC [M] /tmp/selfgz9757/NVIDIA-Linux-x86_64-396.54.09/kernel/nvidia-drm/nvidia-drm-utils.o
CC [M] /tmp/selfgz9757/NVIDIA-Linux-x86_64-396.54.09/kernel/nvidia-drm/nvidia-drm-crtc.o
CC [M] /tmp/selfgz9757/NVIDIA-Linux-x86_64-396.54.09/kernel/nvidia-drm/nvidia-drm-encoder.o
CC [M] /tmp/selfgz9757/NVIDIA-Linux-x86_64-396.54.09/kernel/nvidia-drm/nvidia-drm-connector.o
CC [M] /tmp/selfgz9757/NVIDIA-Linux-x86_64-396.54.09/kernel/nvidia-drm/nvidia-drm-gem.o
CC [M] /tmp/selfgz9757/NVIDIA-Linux-x86_64-396.54.09/kernel/nvidia-drm/nvidia-drm-fb.o
CC [M] /tmp/selfgz9757/NVIDIA-Linux-x86_64-396.54.09/kernel/nvidia-drm/nvidia-drm-modeset.o
CC [M] /tmp/selfgz9757/NVIDIA-Linux-x86_64-396.54.09/kernel/nvidia-drm/nvidia-drm-prime-fence.o
CC [M] /tmp/selfgz9757/NVIDIA-Linux-x86_64-396.54.09/kernel/nvidia-drm/nvidia-drm-linux.o
CC [M] /tmp/selfgz9757/NVIDIA-Linux-x86_64-396.54.09/kernel/nvidia-drm/nvidia-drm-helper.o
CC [M] /tmp/selfgz9757/NVIDIA-Linux-x86_64-396.54.09/kernel/nvidia-drm/nv-pci-table.o
CC [M] /tmp/selfgz9757/NVIDIA-Linux-x86_64-396.54.09/kernel/nvidia-drm/nvidia-drm-gem-nvkms-memory.o
CC [M] /tmp/selfgz9757/NVIDIA-Linux-x86_64-396.54.09/kernel/nvidia-drm/nvidia-drm-gem-user-memory.o
ld -r -o /tmp/selfgz9757/NVIDIA-Linux-x86_64-396.54.09/kernel/nvidia/nv-interface.o /tmp/selfgz9757/NVIDIA-Linux-x86_64-396.54.09/kernel/nvidia/nv-frontend.o /tmp/selfgz9757/NVIDIA-Linux-x86_64-396.54.09/kernel/nvidia/nv-instance.o /tmp/selfgz9757/NVIDIA-Linux-x86_64-396.54.09/kernel/nvidia/nv.o /tmp/selfgz9757/NVIDIA-Linux-x86_64-396.54.09/kernel/nvidia/nv-acpi.o /tmp/self
gz9757/NVIDIA-Linux-x86_64-396.54.09/kernel/nvidia/nv-chrdev.o /tmp/selfgz9757/NVIDIA-Linux-x86_64-396.54.09/kernel/nvidia/nv-cray.o /tmp/selfgz9757/NVIDIA-Linux-x86_64-396.54.09/kernel/nvidia/nv-dma.o /tmp/selfgz9757/NVIDIA-Linux-x86_64-396.54.09/kernel/nvidia/nv-gvi.o /tmp/selfgz9757/NVIDIA-Linux-x86_64-396.54.09/kernel/nvidia/nv-i2c.o /tmp/selfgz9757/NVIDIA-Linux-x86_64-396.54.09/kernel/nvidia/nv-mempool.o /tmp/selfgz9757/NVIDIA-Linux-x86_64-396.54.09/kernel/nvidia/nv-mmap.o /tmp/selfgz9757/NVIDIA-Linux-x86_64-396.54.09/kernel/nvidia/nv-p2p.o /tmp/selfgz9757/NVIDIA-Linux-x86_64-396.54.09/kernel/nvidia/nv-pat.o /tmp/selfgz9757/NVIDIA-Linux-x86_64-396.54.09/kernel/nvidia/nv-procfs.o /tmp/selfgz9757/NVIDIA-Linux-x86_64-396.54.09/kernel/nvidia/nv-usermap.o /tmp/selfgz9757/NVIDIA-Linux-x86_64-396.54.09/kernel/nvidia/nv-vm.o /tmp/selfgz9757/NVIDIA-Linux-x86_64-396.54.09/kernel/nvidia/nv-vtophys.o /tmp/selfgz9757/NVIDIA-Linux-x86_64-396.54.09/kernel/nvidia/os-interface.o /tmp/selfgz9757/NVIDIA-Linux-x86_64-396.54
.09/kernel/nvidia/os-mlock.o /tmp/selfgz9757/NVIDIA-Linux-x86_64-396.54.09/kernel/nvidia/os-pci.o /tmp/selfgz9757/NVIDIA-Linux-x86_64-396.54.09/kernel/nvidia/os-registry.o /tmp/selfgz9757/NVIDIA-Linux-x86_64-396.54.09/kernel/nvidia/os-usermap.o /tmp/selfgz9757/NVIDIA-Linux-x86_64-396.54.09/kernel/nvidia/nv-modeset-interface.o /tmp/selfgz9757/NVIDIA-Linux-x86_64-396.54.09/kernel/nvidia/nv-pci-table.o /tmp/selfgz9757/NVIDIA-Linux-x86_64-396.54.09/kernel/nvidia/nv-kthread-q.o /tmp/selfgz9757/NVIDIA-Linux-x86_64-396.54.09/kernel/nvidia/nv-kthread-q-selftest.o /tmp/selfgz9757/NVIDIA-Linux-x86_64-396.54.09/kernel/nvidia/nv-memdbg.o /tmp/selfgz9757/NVIDIA-Linux-x86_64-396.54.09/kernel/nvidia/nv-ibmnpu.o /tmp/selfgz9757/NVIDIA-Linux-x86_64-396.54.09/kernel/nvidia/nv-report-err.o /tmp/selfgz9757/NVIDIA-Linux-x86_64-396.54.09/kernel/nvidia/nv-rsync.o /tmp/selfgz9757/NVIDIA-Linux-x86_64-396.54.09/kernel/nvidia/nv_uvm_interface.o /tmp/selfgz9757/NVIDIA-Linux-x86_64-396.54.09/kernel/nvidia/nvlink_linux.o
LD [M] /tmp/selfgz9757/NVIDIA-Linux-x86_64-396.54.09/kernel/nvidia.o
ld -r -o /tmp/selfgz9757/NVIDIA-Linux-x86_64-396.54.09/kernel/nvidia-modeset/nv-modeset-interface.o /tmp/selfgz9757/NVIDIA-Linux-x86_64-396.54.09/kernel/nvidia-modeset/nvidia-modeset-linux.o
LD [M] /tmp/selfgz9757/NVIDIA-Linux-x86_64-396.54.09/kernel/nvidia-modeset.o
LD [M] /tmp/selfgz9757/NVIDIA-Linux-x86_64-396.54.09/kernel/nvidia-drm.o
LD [M] /tmp/selfgz9757/NVIDIA-Linux-x86_64-396.54.09/kernel/nvidia-uvm.o
Building modules, stage 2.
MODPOST 4 modules
CC /tmp/selfgz9757/NVIDIA-Linux-x86_64-396.54.09/kernel/nvidia-drm.mod.o
CC /tmp/selfgz9757/NVIDIA-Linux-x86_64-396.54.09/kernel/nvidia-modeset.mod.o
CC /tmp/selfgz9757/NVIDIA-Linux-x86_64-396.54.09/kernel/nvidia-uvm.mod.o
CC /tmp/selfgz9757/NVIDIA-Linux-x86_64-396.54.09/kernel/nvidia.mod.o
LD [M] /tmp/selfgz9757/NVIDIA-Linux-x86_64-396.54.09/kernel/nvidia-drm.ko
LD [M] /tmp/selfgz9757/NVIDIA-Linux-x86_64-396.54.09/kernel/nvidia-modeset.ko
LD [M] /tmp/selfgz9757/NVIDIA-Linux-x86_64-396.54.09/kernel/nvidia-uvm.ko
LD [M] /tmp/selfgz9757/NVIDIA-Linux-x86_64-396.54.09/kernel/nvidia.ko
→ done.
→ Kernel module compilation complete.
→ Unable to determine if Secure Boot is enabled: No such file or directory
→ Kernel messages:
[312936.491512] perf interrupt took too long (10136 > 10000), lowering kernel.perf_event_max_sample_rate to 12500
[357038.592399] audit: type=1400 audit(1545089701.861:73): apparmor=“DENIED” operation=“open” profile=“/usr/sbin/cupsd” name=“/etc/ld.so.preload” pid=43084 comm=“cupsd” requested_mask=“r” denied_mask=“r” fsuid=0 ouid=0
[357038.598097] audit: type=1400 audit(1545089701.865:74): apparmor=“DENIED” operation=“open” profile=“/usr/sbin/cups-browsed” name=“/etc/ld.so.preload” pid=43088 comm=“cups-browsed” requested_mask=“r” denied_mask=“r” fsuid=0 ouid=0
[357038.609193] audit: type=1400 audit(1545089701.877:75): apparmor=“DENIED” operation=“open” profile=“/usr/sbin/cupsd” name=“/etc/ld.so.preload” pid=43098 comm=“cups-exec” requested_mask=“r” denied_mask=“r” fsuid=0 ouid=0
[357038.612605] audit: type=1400 audit(1545089701.881:76): apparmor=“DENIED” operation=“open” profile=“/usr/sbin/cupsd” name=“/etc/ld.so.preload” pid=43098 comm=“dbus” requested_mask=“r” denied_mask=“r” fsuid=7 ouid=0
[393625.796784] [drm] [nvidia-drm] [GPU ID 0x00008500] Unloading driver
[393625.797066] [drm] [nvidia-drm] [GPU ID 0x00008400] Unloading driver
[393625.822513] nvidia-modeset: Unloading
[393625.861627] nvidia-nvlink: Unregistered the Nvlink Core, major device number 242
[393708.521993] flag = FB_BLANK_UNBLANK
[393708.526096] fix->line_length = 1600
[393708.526110] primary channel
[393708.526118] Set Panel Plane enbit:after tried 1 times
[393708.786735] ddk setlogicdispout done
[393745.568956] nvidia-nvlink: Nvlink Core is being initialized, major device number 242
[393745.570063] NVRM: loading NVIDIA UNIX x86_64 Kernel Module 396.54.09 Thu Oct 11 21:43:28 PDT 2018 (using threaded interrupts)
[393745.577249] nvidia-uvm: Loaded the UVM driver in 8 mode, major device number 241
[393745.580130] nvidia-modeset: Loading NVIDIA Kernel Mode Setting Driver for UNIX platforms 396.54.09 Fri Oct 12 01:14:08 PDT 2018
[393745.581832] [drm] [nvidia-drm] [GPU ID 0x00008400] Loading driver
[393745.581978] [drm] [nvidia-drm] [GPU ID 0x00008500] Loading driver
[393745.587550] [drm] [nvidia-drm] [GPU ID 0x00008500] Unloading driver
[393745.587781] [drm] [nvidia-drm] [GPU ID 0x00008400] Unloading driver
[393745.649954] nvidia-modeset: Unloading
[393745.678276] nvidia-uvm: Unloaded the UVM driver in 8 mode
[393745.726211] nvidia-nvlink: Unregistered the Nvlink Core, major device number 242
→ Installing both new and classic TLS OpenGL libraries.
→ Installing both new and classic TLS 32bit OpenGL libraries.
→ Install NVIDIA’s 32-bit compatibility libraries? (Answer: Yes)
→ Searching for conflicting files:
→ done.
→ Installing ‘NVIDIA Accelerated Graphics Driver for Linux-x86_64’ (396.54.09):
executing: ‘/sbin/ldconfig’…
executing: '/sbin/depmod -a '…
→ done.
→ Driver file installation is complete.
→ Running post-install sanity check:
→ done.
→ Post-install sanity check passed.
→ Running runtime sanity check:
→ done.
→ Runtime sanity check passed.
→ Installation of the kernel module for the NVIDIA Accelerated Graphics Driver for Linux-x86_64 (version 396.54.09) is now complete.
*** /var/log/nvidia-uninstall.log
*** ls: -rw-r–r-- 1 root root 1168 2018-12-18 17:44:58.727031334 +0800 /var/log/nvidia-uninstall.log
nvidia-installer log file ‘/var/log/nvidia-uninstall.log’
creation time: Tue Dec 18 17:44:40 2018
installer version: 415.18.04
nvidia-uninstall
→ If you plan to no longer use the NVIDIA driver, you should make sure that no X screens are configured to use the NVIDIA X driver in your X configuration file. If you used nvidia-xconfig to configure X, it may have created a backup of your original configuration. Would you like to run nvidia-xconfig --restore-original-backup
to attempt restoration of the original X configuration file? (Answer: No)
→ Parsing log file:
→ done.
→ Validating previous installation:
→ done.
→ Uninstalling NVIDIA Accelerated Graphics Driver for Linux-x86_64 (1.0-4151804 (415.18.04)):
→ done.
→ Running depmod and ldconfig:
→ done.
→ Uninstallation of existing driver: NVIDIA Accelerated Graphics Driver for Linux-x86_64 (415.18.04) is complete.
journalctl -b -0 _COMM=Xorg
– No entries –
journalctl -b -1 _COMM=Xorg
journalctl -b -2 _COMM=Xorg
journalctl -b -0 _COMM=Xorg.bin
– No entries –
journalctl -b -1 _COMM=Xorg.bin
journalctl -b -2 _COMM=Xorg.bin
– No entries –
*** /var/log/Xorg.0.log
*** ls: -rw-r–r-- 1 root root 22739 2018-12-18 17:53:40.874884013 +0800 /var/log/Xorg.0.log
[ 17.763]
X.Org X Server 1.18.4
Release Date: 2016-07-19
[ 17.763] X Protocol Version 11, Revision 0
[ 17.763] Build Operating System: Linux 4.4.0-128-generic x86_64 Ubuntu
[ 17.763] Current Operating System: Linux pegavsim 4.4.0-140-generic #166-Ubuntu SMP Wed Nov 14 20:09:47 UTC 2018 x86_64
[ 17.763] Kernel command line: BOOT_IMAGE=/vmlinuz-4.4.0-140-generic root=/dev/mapper/pegavsim–vg-root ro quiet splash nomodeset vt.handoff=7
[ 17.763] Build Date: 10 August 2018 09:33:05AM
[ 17.763] xorg-server 2:1.18.4-0ubuntu0.8 (For technical support please see Enterprise open source support | Ubuntu)
[ 17.763] Current version of pixman: 0.33.6
[ 17.763] Before reporting problems, check http://wiki.x.org
to make sure that you have the latest version.
[ 17.763] Markers: (–) probed, () from config file, (==) default setting,
(++) from command line, (!!) notice, (II) informational,
(WW) warning, (EE) error, (NI) not implemented, (??) unknown.
[ 17.763] (==) Log file: “/var/log/Xorg.0.log”, Time: Tue Dec 18 17:53:40 2018
[ 17.767] (==) Using system config directory “/usr/share/X11/xorg.conf.d”
[ 17.772] (==) No Layout section. Using the first Screen section.
[ 17.772] (==) No screen section available. Using defaults.
[ 17.772] () |–>Screen “Default Screen Section” (0)
[ 17.772] (**) | |–>Monitor “”
[ 17.772] (==) No monitor specified for screen “Default Screen Section”.
Using a default monitor configuration.
[ 17.772] (==) Automatically adding devices
[ 17.772] (==) Automatically enabling devices
[ 17.772] (==) Automatically adding GPU devices
[ 17.772] (==) Max clients allowed: 256, resource mask: 0x1fffff
[ 17.772] (WW) The directory “/usr/share/fonts/X11/cyrillic” does not exist.
[ 17.772] Entry deleted from font path.
[ 17.772] (WW) The directory “/usr/share/fonts/X11/100dpi/” does not exist.
[ 17.772] (WW) The directory “/usr/share/fonts/X11/75dpi/” does not exist.
[ 17.772] (WW) The directory “/usr/share/fonts/X11/100dpi” does not exist.
[ 17.772] (WW) The directory “/usr/share/fonts/X11/75dpi” does not exist.
[ 17.772] (==) FontPath set to:
/usr/share/fonts/X11/misc,
/usr/share/fonts/X11/Type1,
built-ins
[ 17.772] (==) ModulePath set to “/usr/lib/x86_64-linux-gnu/xorg/extra-modules,/usr/lib/xorg/extra-modules,/usr/lib/xorg/modules”
[ 17.772] (II) The server relies on udev to provide the list of input devices.
If no devices become available, reconfigure udev or disable AutoAddDevices.
[ 17.772] (II) Loader magic: 0x559166d45dc0
[ 17.772] (II) Module ABI versions:
[ 17.772] X.Org ANSI C Emulation: 0.4
[ 17.772] X.Org Video Driver: 20.0
[ 17.772] X.Org XInput driver : 22.1
[ 17.772] X.Org Server Extension : 9.0
[ 17.773] (++) using VT number 7
[ 17.773] (II) systemd-logind: logind integration requires -keeptty and -keeptty was not provided, disabling logind integration
[ 17.774] (II) xfree86: Adding drm device (/dev/dri/card0)
[ 17.774] (II) xfree86: Adding drm device (/dev/dri/card1)
[ 17.792] (–) PCI:*(0:6:0:0) 126f:0750:126f:0750 rev 161, Mem @ 0xa4000000/67108864, 0xaba00000/2097152, BIOS @ 0x???/65536
[ 17.792] (–) PCI: (0:132:0:0) 10de:118f:10de:097f rev 161, Mem @ 0xe2000000/16777216, 0x385fe0000000/268435456, 0x385ff0000000/33554432
[ 17.792] (–) PCI: (0:133:0:0) 10de:118f:10de:097f rev 161, Mem @ 0xe1000000/16777216, 0x385fc0000000/268435456, 0x385fd0000000/33554432
[ 17.792] (II) LoadModule: “glx”
[ 17.796] (II) Loading /usr/lib/xorg/modules/extensions/libglx.so
[ 17.934] (II) Module glx: vendor=“X.Org Foundation”
[ 17.934] compiled for 1.18.4, module version = 1.0.0
[ 17.934] ABI class: X.Org Server Extension, version 9.0
[ 17.934] (==) AIGLX enabled
[ 17.934] (II) Applying OutputClass “nvidia” to /dev/dri/card0
[ 17.934] loading driver: nvidia
[ 17.934] (II) Applying OutputClass “nvidia” to /dev/dri/card1
[ 17.934] (==) Matched nvidia as autoconfigured driver 0
[ 17.934] (==) Matched nvidia as autoconfigured driver 1
[ 17.934] (==) Matched nouveau as autoconfigured driver 2
[ 17.934] (==) Matched nvidia as autoconfigured driver 3
[ 17.934] (==) Matched nvidia as autoconfigured driver 4
[ 17.934] (==) Matched nouveau as autoconfigured driver 5
[ 17.934] (==) Matched siliconmotion as autoconfigured driver 6
[ 17.934] (==) Matched modesetting as autoconfigured driver 7
[ 17.934] (==) Matched fbdev as autoconfigured driver 8
[ 17.934] (==) Matched vesa as autoconfigured driver 9
[ 17.934] (==) Assigned the driver to the xf86ConfigLayout
[ 17.934] (II) LoadModule: “nvidia”
[ 17.934] (II) Loading /usr/lib/xorg/modules/drivers/nvidia_drv.so
[ 17.992] (II) Module nvidia: vendor=“NVIDIA Corporation”
[ 17.992] compiled for 4.0.2, module version = 1.0.0
[ 17.992] Module class: X.Org Video Driver
[ 17.995] (II) LoadModule: “nouveau”
[ 17.995] (II) Loading /usr/lib/xorg/modules/drivers/nouveau_drv.so
[ 18.029] (II) Module nouveau: vendor=“X.Org Foundation”
[ 18.029] compiled for 1.18.1, module version = 1.0.12
[ 18.029] Module class: X.Org Video Driver
[ 18.029] ABI class: X.Org Video Driver, version 20.0
[ 18.029] (II) LoadModule: “siliconmotion”
[ 18.029] (WW) Warning, couldn’t open module siliconmotion
[ 18.029] (II) UnloadModule: “siliconmotion”
[ 18.029] (II) Unloading siliconmotion
[ 18.029] (EE) Failed to load module “siliconmotion” (module does not exist, 0)
[ 18.029] (II) LoadModule: “modesetting”
[ 18.029] (II) Loading /usr/lib/xorg/modules/drivers/modesetting_drv.so
[ 18.030] (II) Module modesetting: vendor=“X.Org Foundation”
[ 18.030] compiled for 1.18.4, module version = 1.18.4
[ 18.030] Module class: X.Org Video Driver
[ 18.030] ABI class: X.Org Video Driver, version 20.0
[ 18.030] (II) LoadModule: “fbdev”
[ 18.030] (II) Loading /usr/lib/xorg/modules/drivers/fbdev_drv.so
[ 18.030] (II) Module fbdev: vendor=“X.Org Foundation”
[ 18.030] compiled for 1.18.1, module version = 0.4.4
[ 18.030] (II) LoadModule: “vesa”
[ 18.030] (II) Loading /usr/lib/xorg/modules/drivers/vesa_drv.so
[ 18.030] (II) Module vesa: vendor=“X.Org Foundation”
[ 18.030] compiled for 1.18.1, module version = 2.3.4
[ 18.030] (II) Applying OutputClass “nvidia” to /dev/dri/card0
[ 18.030] loading driver: nvidia
[ 18.030] (II) Applying OutputClass “nvidia” to /dev/dri/card1
[ 18.030] (==) Matched nvidia as autoconfigured driver 0
[ 18.030] (==) Matched nvidia as autoconfigured driver 1
[ 18.030] (==) Matched nouveau as autoconfigured driver 2
[ 18.030] (==) Matched nvidia as autoconfigured driver 3
[ 18.030] (==) Matched nvidia as autoconfigured driver 4
[ 18.030] (==) Matched nouveau as autoconfigured driver 5
[ 18.030] (==) Matched siliconmotion as autoconfigured driver 6
[ 18.030] (==) Matched modesetting as autoconfigured driver 7
[ 18.030] (==) Matched fbdev as autoconfigured driver 8
[ 18.030] (==) Matched vesa as autoconfigured driver 9
[ 18.030] (==) Assigned the driver to the xf86ConfigLayout
[ 18.030] (II) LoadModule: “nvidia”
[ 18.030] (II) Loading /usr/lib/xorg/modules/drivers/nvidia_drv.so
[ 18.030] (II) Module nvidia: vendor=“NVIDIA Corporation”
[ 18.030] compiled for 4.0.2, module version = 1.0.0
[ 18.030] (II) UnloadModule: “nvidia”
[ 18.030] (II) Unloading nvidia
[ 18.030] (II) Failed to load module “nvidia” (already loaded, 21905)
[ 18.030] (II) LoadModule: “nouveau”
[ 18.031] (II) Loading /usr/lib/xorg/modules/drivers/nouveau_drv.so
[ 18.031] (II) Module nouveau: vendor=“X.Org Foundation”
[ 18.031] compiled for 1.18.1, module version = 1.0.12
[ 18.031] Module class: X.Org Video Driver
[ 18.031] ABI class: X.Org Video Driver, version 20.0
[ 18.031] (II) UnloadModule: “nouveau”
[ 18.031] (II) Unloading nouveau
[ 18.031] (II) Failed to load module “nouveau” (already loaded, 21905)
[ 18.031] (II) LoadModule: “siliconmotion”
[ 18.031] (WW) Warning, couldn’t open module siliconmotion
[ 18.031] (II) UnloadModule: “siliconmotion”
[ 18.031] (II) Unloading siliconmotion
[ 18.031] (EE) Failed to load module “siliconmotion” (module does not exist, 0)
[ 18.031] (II) LoadModule: “modesetting”
[ 18.031] (II) Loading /usr/lib/xorg/modules/drivers/modesetting_drv.so
[ 18.031] (II) Module modesetting: vendor=“X.Org Foundation”
[ 18.031] compiled for 1.18.4, module version = 1.18.4
[ 18.031] (II) UnloadModule: “modesetting”
[ 18.031] (II) Unloading modesetting
[ 18.031] (II) Failed to load module “modesetting” (already loaded, 0)
[ 18.031] (II) LoadModule: “fbdev”
[ 18.031] (II) Loading /usr/lib/xorg/modules/drivers/fbdev_drv.so
[ 18.031] (II) Module fbdev: vendor=“X.Org Foundation”
[ 18.031] compiled for 1.18.1, module version = 0.4.4
[ 18.031] (II) UnloadModule: “fbdev”
[ 18.031] (II) Unloading fbdev
[ 18.031] (II) Failed to load module “fbdev” (already loaded, 0)
[ 18.031] (II) LoadModule: “vesa”
[ 18.032] (II) Loading /usr/lib/xorg/modules/drivers/vesa_drv.so
[ 18.032] (II) Module vesa: vendor=“X.Org Foundation”
[ 18.032] compiled for 1.18.1, module version = 2.3.4
[ 18.032] Module class: X.Org Video Driver
[ 18.032] ABI class: X.Org Video Driver, version 20.0
[ 18.032] (II) UnloadModule: “vesa”
[ 18.032] (II) Unloading vesa
[ 18.032] (II) Failed to load module “vesa” (already loaded, 0)
[ 18.032] (II) NVIDIA dlloader X Driver 396.54.09 Fri Oct 12 00:18:03 PDT 2018
[ 18.032] (II) NVIDIA Unified Driver for all Supported NVIDIA GPUs
[ 18.033] (II) NOUVEAU driver Date: Tue Dec 8 15:52:25 2015 +1000
[ 18.033] (II) NOUVEAU driver for NVIDIA chipset families :
[ 18.033] RIVA TNT (NV04)
[ 18.033] RIVA TNT2 (NV05)
[ 18.033] GeForce 256 (NV10)
[ 18.033] GeForce 2 (NV11, NV15)
[ 18.033] GeForce 4MX (NV17, NV18)
[ 18.033] GeForce 3 (NV20)
[ 18.033] GeForce 4Ti (NV25, NV28)
[ 18.033] GeForce FX (NV3x)
[ 18.033] GeForce 6 (NV4x)
[ 18.033] GeForce 7 (G7x)
[ 18.033] GeForce 8 (G8x)
[ 18.033] GeForce GTX 200 (NVA0)
[ 18.033] GeForce GTX 400 (NVC0)
[ 18.033] (II) modesetting: Driver for Modesetting Kernel Drivers: kms
[ 18.033] (II) FBDEV: driver for framebuffer: fbdev
[ 18.033] (II) VESA: driver for VESA chipsets: vesa
[ 18.033] (EE) [drm] Failed to open DRM device for (null): -2
[ 18.034] (WW) Falling back to old probe method for modesetting
[ 18.034] (II) Loading sub module “fbdevhw”
[ 18.034] (II) LoadModule: “fbdevhw”
[ 18.034] (II) Loading /usr/lib/xorg/modules/libfbdevhw.so
[ 18.034] (II) Module fbdevhw: vendor=“X.Org Foundation”
[ 18.034] compiled for 1.18.4, module version = 0.0.2
[ 18.034] ABI class: X.Org Video Driver, version 20.0
[ 18.034] () FBDEV(2): claimed PCI slot 6@0:0:0
[ 18.034] (II) FBDEV(2): using default device
[ 18.034] (WW) Falling back to old probe method for vesa
[ 18.034] (EE) Screen 0 deleted because of no matching config section.
[ 18.034] (II) UnloadModule: “modesetting”
[ 18.034] (II) FBDEV(0): Creating default Display subsection in Screen section
“Default Screen Section” for depth/fbbpp 24/32
[ 18.034] (==) FBDEV(0): Depth 24, (==) framebuffer bpp 32
[ 18.034] (==) FBDEV(0): RGB weight 888
[ 18.034] (==) FBDEV(0): Default visual is TrueColor
[ 18.034] (==) FBDEV(0): Using gamma correction (1.0, 1.0, 1.0)
[ 18.034] (II) FBDEV(0): hardware: VESA VGA (video memory: 3072kB)
[ 18.034] (II) FBDEV(0): checking modes against framebuffer device…
[ 18.034] (II) FBDEV(0): checking modes against monitor…
[ 18.034] (–) FBDEV(0): Virtual size is 1024x768 (pitch 1024)
[ 18.035] () FBDEV(0): Built-in mode “current”: 78.7 MHz, 59.9 kHz, 75.7 Hz
[ 18.035] (II) FBDEV(0): Modeline "current"x0.0 78.65 1024 1056 1184 1312 768 772 776 792 -hsync -vsync -csync (59.9 kHz b)
[ 18.035] (==) FBDEV(0): DPI set to (96, 96)
[ 18.035] (II) Loading sub module “fb”
[ 18.035] (II) LoadModule: “fb”
[ 18.035] (II) Loading /usr/lib/xorg/modules/libfb.so
[ 18.035] (II) Module fb: vendor=“X.Org Foundation”
[ 18.035] compiled for 1.18.4, module version = 1.0.0
[ 18.035] ABI class: X.Org ANSI C Emulation, version 0.4
[ 18.035] () FBDEV(0): using shadow framebuffer
[ 18.035] (II) Loading sub module “shadow”
[ 18.035] (II) LoadModule: “shadow”
[ 18.035] (II) Loading /usr/lib/xorg/modules/libshadow.so
[ 18.035] (II) Module shadow: vendor=“X.Org Foundation”
[ 18.035] compiled for 1.18.4, module version = 1.1.0
[ 18.035] (II) UnloadModule: “vesa”
[ 18.035] (II) Unloading vesa
[ 18.036] (==) Depth 24 pixmap format is 32 bpp
[ 18.036] (II) FBDEV(0): FBIOBLANK: Invalid argument (Screen blanking not supported by kernel - disabling)
[ 18.036] (==) FBDEV(0): Backing store enabled
[ 18.037] (==) FBDEV(0): DPMS enabled
[ 18.037] (==) RandR enabled
[ 18.041] (II) SELinux: Disabled on system
[ 18.042] (II) AIGLX: Screen 0 is not DRI2 capable
[ 18.042] (EE) AIGLX: reverting to software rendering
[ 18.366] (II) AIGLX: enabled GLX_MESA_copy_sub_buffer
[ 18.366] (II) AIGLX: Loaded and initialized swrast
[ 18.366] (II) GLX: Initialized DRISWRAST GL provider for screen 0
[ 18.453] (II) config/udev: Adding input device Power Button (/dev/input/event1)
[ 18.453] () Power Button: Applying InputClass “evdev keyboard catchall”
[ 18.453] (II) LoadModule: “evdev”
[ 18.453] (II) Loading /usr/lib/xorg/modules/input/evdev_drv.so
[ 18.461] (II) Module evdev: vendor=“X.Org Foundation”
[ 18.461] compiled for 1.18.1, module version = 2.10.1
[ 18.461] Module class: X.Org XInput Driver
[ 18.462] ABI class: X.Org XInput driver, version 22.1
[ 18.462] (II) Using input driver ‘evdev’ for ‘Power Button’
[ 18.462] () Power Button: always reports core events
[ 18.462] () evdev: Power Button: Device: “/dev/input/event1”
[ 18.462] (–) evdev: Power Button: Vendor 0 Product 0x1
[ 18.462] (–) evdev: Power Button: Found keys
[ 18.462] (II) evdev: Power Button: Configuring as keyboard
[ 18.462] () Option “config_info” “udev:/sys/devices/LNXSYSTM:00/LNXPWRBN:00/input/input1/event1”
[ 18.462] (II) XINPUT: Adding extended input device “Power Button” (type: KEYBOARD, id 6)
[ 18.462] () Option “xkb_rules” “evdev”
[ 18.462] () Option “xkb_model” “pc105”
[ 18.462] () Option “xkb_layout” “us”
[ 18.463] (II) config/udev: Adding input device Power Button (/dev/input/event0)
[ 18.463] () Power Button: Applying InputClass “evdev keyboard catchall”
[ 18.463] (II) Using input driver ‘evdev’ for ‘Power Button’
[ 18.463] () Power Button: always reports core events
[ 18.463] () evdev: Power Button: Device: “/dev/input/event0”
[ 18.463] (–) evdev: Power Button: Vendor 0 Product 0x1
[ 18.463] (–) evdev: Power Button: Found keys
[ 18.463] (II) evdev: Power Button: Configuring as keyboard
[ 18.463] () Option “config_info” “udev:/sys/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0C:00/input/input0/event0”
[ 18.463] (II) XINPUT: Adding extended input device “Power Button” (type: KEYBOARD, id 7)
[ 18.463] () Option “xkb_rules” “evdev”
[ 18.463] () Option “xkb_model” “pc105”
[ 18.463] () Option “xkb_layout” “us”
[ 18.464] (II) config/udev: Adding input device Kinan V3.0 (/dev/input/event2)
[ 18.464] () Kinan V3.0: Applying InputClass “evdev keyboard catchall”
[ 18.464] (II) Using input driver ‘evdev’ for ‘Kinan V3.0’
[ 18.464] () Kinan V3.0: always reports core events
[ 18.464] () evdev: Kinan V3.0: Device: “/dev/input/event2”
[ 18.464] (–) evdev: Kinan V3.0: Vendor 0x557 Product 0x2221
[ 18.464] (–) evdev: Kinan V3.0: Found keys
[ 18.464] (II) evdev: Kinan V3.0: Configuring as keyboard
[ 18.464] () Option “config_info” “udev:/sys/devices/pci0000:00/0000:00:1d.0/usb2/2-1/2-1.2/2-1.2:1.0/0003:0557:2221.0001/input/input2/event2”
[ 18.464] (II) XINPUT: Adding extended input device “Kinan V3.0” (type: KEYBOARD, id 8)
[ 18.464] () Option “xkb_rules” “evdev”
[ 18.464] () Option “xkb_model” “pc105”
[ 18.464] () Option “xkb_layout” “us”
[ 18.465] (II) config/udev: Adding input device Kinan V3.0 (/dev/input/event3)
[ 18.465] () Kinan V3.0: Applying InputClass “evdev pointer catchall”
[ 18.465] (II) Using input driver ‘evdev’ for ‘Kinan V3.0’
[ 18.465] () Kinan V3.0: always reports core events
[ 18.465] () evdev: Kinan V3.0: Device: “/dev/input/event3”
[ 18.520] (–) evdev: Kinan V3.0: Vendor 0x557 Product 0x2221
[ 18.520] (–) evdev: Kinan V3.0: Found 9 mouse buttons
[ 18.520] (–) evdev: Kinan V3.0: Found scroll wheel(s)
[ 18.520] (–) evdev: Kinan V3.0: Found relative axes
[ 18.520] (–) evdev: Kinan V3.0: Found x and y relative axes
[ 18.520] (II) evdev: Kinan V3.0: Configuring as mouse
[ 18.520] (II) evdev: Kinan V3.0: Adding scrollwheel support
[ 18.520] () evdev: Kinan V3.0: YAxisMapping: buttons 4 and 5
[ 18.520] () evdev: Kinan V3.0: EmulateWheelButton: 4, EmulateWheelInertia: 10, EmulateWheelTimeout: 200
[ 18.520] () Option “config_info” “udev:/sys/devices/pci0000:00/0000:00:1d.0/usb2/2-1/2-1.2/2-1.2:1.1/0003:0557:2221.0002/input/input3/event3”
[ 18.520] (II) XINPUT: Adding extended input device “Kinan V3.0” (type: MOUSE, id 9)
[ 18.520] (II) evdev: Kinan V3.0: initialized for relative axes.
[ 18.520] () Kinan V3.0: (accel) keeping acceleration scheme 1
[ 18.520] () Kinan V3.0: (accel) acceleration profile 0
[ 18.520] () Kinan V3.0: (accel) acceleration factor: 2.000
[ 18.520] () Kinan V3.0: (accel) acceleration threshold: 4
[ 18.521] (II) config/udev: Adding input device Kinan V3.0 (/dev/input/mouse0)
[ 18.521] (II) No input driver specified, ignoring this device.
[ 18.521] (II) This device may have been added with another device file.
[ 18.521] (II) config/udev: Adding input device Huawei Technologies HUAWEI Keyboard/MouseKVM (/dev/input/event4)
[ 18.521] () Huawei Technologies HUAWEI Keyboard/MouseKVM: Applying InputClass “evdev keyboard catchall”
[ 18.521] (II) Using input driver ‘evdev’ for ‘Huawei Technologies HUAWEI Keyboard/MouseKVM’
[ 18.521] () Huawei Technologies HUAWEI Keyboard/MouseKVM: always reports core events
[ 18.522] () evdev: Huawei Technologies HUAWEI Keyboard/MouseKVM: Device: “/dev/input/event4”
[ 18.522] (–) evdev: Huawei Technologies HUAWEI Keyboard/MouseKVM: Vendor 0x12d1 Product 0x3
[ 18.522] (–) evdev: Huawei Technologies HUAWEI Keyboard/MouseKVM: Found keys
[ 18.522] (II) evdev: Huawei Technologies HUAWEI Keyboard/MouseKVM: Configuring as keyboard
[ 18.522] () Option “config_info” “udev:/sys/devices/pci0000:00/0000:00:1d.0/usb2/2-1/2-1.8/2-1.8:1.0/0003:12D1:0003.0003/input/input4/event4”
[ 18.522] (II) XINPUT: Adding extended input device “Huawei Technologies HUAWEI Keyboard/MouseKVM” (type: KEYBOARD, id 10)
[ 18.522] () Option “xkb_rules” “evdev”
[ 18.522] () Option “xkb_model” “pc105”
[ 18.522] () Option “xkb_layout” “us”
[ 18.523] (II) config/udev: Adding input device Huawei Technologies HUAWEI Keyboard/MouseKVM (/dev/input/event5)
[ 18.523] () Huawei Technologies HUAWEI Keyboard/MouseKVM: Applying InputClass “evdev pointer catchall”
[ 18.523] (II) Using input driver ‘evdev’ for ‘Huawei Technologies HUAWEI Keyboard/MouseKVM’
[ 18.523] () Huawei Technologies HUAWEI Keyboard/MouseKVM: always reports core events
[ 18.523] () evdev: Huawei Technologies HUAWEI Keyboard/MouseKVM: Device: “/dev/input/event5”
[ 18.576] (–) evdev: Huawei Technologies HUAWEI Keyboard/MouseKVM: Vendor 0x12d1 Product 0x3
[ 18.576] (–) evdev: Huawei Technologies HUAWEI Keyboard/MouseKVM: Found 3 mouse buttons
[ 18.576] (–) evdev: Huawei Technologies HUAWEI Keyboard/MouseKVM: Found scroll wheel(s)
[ 18.576] (–) evdev: Huawei Technologies HUAWEI Keyboard/MouseKVM: Found relative axes
[ 18.576] (–) evdev: Huawei Technologies HUAWEI Keyboard/MouseKVM: Found x and y relative axes
[ 18.576] (II) evdev: Huawei Technologies HUAWEI Keyboard/MouseKVM: Configuring as mouse
[ 18.576] (II) evdev: Huawei Technologies HUAWEI Keyboard/MouseKVM: Adding scrollwheel support
[ 18.576] () evdev: Huawei Technologies HUAWEI Keyboard/MouseKVM: YAxisMapping: buttons 4 and 5
[ 18.576] () evdev: Huawei Technologies HUAWEI Keyboard/MouseKVM: EmulateWheelButton: 4, EmulateWheelInertia: 10, EmulateWheelTimeout: 200
[ 18.576] () Option “config_info” “udev:/sys/devices/pci0000:00/0000:00:1d.0/usb2/2-1/2-1.8/2-1.8:1.1/0003:12D1:0003.0004/input/input5/event5”
[ 18.576] (II) XINPUT: Adding extended input device “Huawei Technologies HUAWEI Keyboard/MouseKVM” (type: MOUSE, id 11)
[ 18.576] (II) evdev: Huawei Technologies HUAWEI Keyboard/MouseKVM: initialized for relative axes.
[ 18.576] () Huawei Technologies HUAWEI Keyboard/MouseKVM: (accel) keeping acceleration scheme 1
[ 18.576] () Huawei Technologies HUAWEI Keyboard/MouseKVM: (accel) acceleration profile 0
[ 18.576] () Huawei Technologies HUAWEI Keyboard/MouseKVM: (accel) acceleration factor: 2.000
[ 18.576] (**) Huawei Technologies HUAWEI Keyboard/MouseKVM: (accel) acceleration threshold: 4
[ 18.577] (II) config/udev: Adding input device Huawei Technologies HUAWEI Keyboard/MouseKVM (/dev/input/mouse1)
[ 18.577] (II) No input driver specified, ignoring this device.
[ 18.577] (II) This device may have been added with another device file.
*** /usr/share/X11/xorg.conf.d/10-amdgpu.conf
*** ls: -rw-r–r-- 1 root root 92 2017-02-15 19:23:33.000000000 +0800 /usr/share/X11/xorg.conf.d/10-amdgpu.conf
Section “OutputClass”
Identifier “AMDgpu”
MatchDriver “amdgpu”
Driver “amdgpu”
EndSection
*** /usr/share/X11/xorg.conf.d/10-evdev.conf
*** ls: -rw-r–r-- 1 root root 1099 2016-03-03 20:33:32.000000000 +0800 /usr/share/X11/xorg.conf.d/10-evdev.conf
Catch-all evdev loader for udev-based systems
We don’t simply match on any device since that also adds accelerometers
and other devices that we don’t really want to use. The list below
matches everything but joysticks.
Section “InputClass”
Identifier “evdev pointer catchall”
MatchIsPointer “on”
MatchDevicePath “/dev/input/event*”
Driver “evdev”
EndSection
Identifier “evdev keyboard catchall”
MatchIsKeyboard “on”
Driver “evdev”
EndSection
Identifier “evdev touchpad catchall”
MatchIsTouchpad “on”
Driver “evdev”
EndSection
Identifier “evdev tablet catchall”
MatchIsTablet “on”
Driver “evdev”
EndSection
Identifier “evdev touchscreen catchall”
MatchIsTouchscreen “on”
Driver “evdev”
EndSection
*** /usr/share/X11/xorg.conf.d/10-quirks.conf
*** ls: -rw-r–r-- 1 root root 1350 2018-08-10 17:37:49.000000000 +0800 /usr/share/X11/xorg.conf.d/10-quirks.conf
Collection of quirks and blacklist/whitelists for specific devices.
Accelerometer device, posts data through ABS_X/ABS_Y, making X unusable
22442 – ThinkPad HDAPS accelerometer gets recognized as MOUSE and makes Xorg unusable
Identifier “ThinkPad HDAPS accelerometer blacklist”
MatchProduct “ThinkPad HDAPS accelerometer data”
Option “Ignore” “on”
EndSection
523914 – Mouse does not move in PV Xen guest under RHEL-5.4
Explicitly tell evdev to not ignore the absolute axes.
Identifier “Xen Virtual Pointer axis blacklist”
MatchProduct “Xen Virtual Pointer”
Option “IgnoreAbsoluteAxes” “off”
Option “IgnoreRelativeAxes” “off”
EndSection
55867 – Doesn't know how to tag XI_TRACKBALL
Bug 55867 - Doesn’t know how to tag XI_TRACKBALL
Identifier “Tag trackballs as XI_TRACKBALL”
MatchProduct “trackball”
MatchDriver “evdev”
Option “TypeName” “TRACKBALL”
EndSection
62831 – Mionix Naos 5000 mouse detected incorrectly
Bug 62831 - Mionix Naos 5000 mouse detected incorrectly
Identifier “Tag Mionix Naos 5000 mouse XI_MOUSE”
MatchProduct “La-VIEW Technology Naos 5000 Mouse”
MatchDriver “evdev”
Option “TypeName” “MOUSE”
EndSection
*** /usr/share/X11/xorg.conf.d/11-evdev-quirks.conf
*** ls: -rw-r–r-- 1 root root 590 2016-03-03 20:32:58.000000000 +0800 /usr/share/X11/xorg.conf.d/11-evdev-quirks.conf
Identifier “Avago Technologies mouse quirks (LP: #746639)”
MatchIsPointer “on”
Driver “evdev”
MatchUSBID “192f:0416”
Option “Emulate3Buttons” “True”
Option “Emulate3Timeout” “50”
EndSection
X/Y axis not working due to device reporting absolute axes
https://bugs.launchpad.net/ubuntu/+source/xserver-xorg-input-evdev/+bug/325581
32882 – kensington pocket mouse model #72237 USB 0d62:1000 not working
Identifier “Benq m310”
MatchProduct “HID 0d62:1000”
Driver “evdev”
Option “IgnoreAbsoluteAxes” “true”
EndSection
*** /usr/share/X11/xorg.conf.d/11-evdev-trackpoint.conf
*** ls: -rw-r–r-- 1 root root 364 2016-03-03 20:32:58.000000000 +0800 /usr/share/X11/xorg.conf.d/11-evdev-trackpoint.conf
trackpoint users want wheel emulation
Identifier “trackpoint catchall”
MatchIsPointer “true”
MatchProduct “TrackPoint|DualPoint Stick”
Option “Emulate3Buttons” “true”
Option “EmulateWheel” “true”
Option “EmulateWheelButton” “2”
Option “XAxisMapping” “6 7”
Option “YAxisMapping” “4 5”
EndSection
*** /usr/share/X11/xorg.conf.d/50-synaptics.conf
*** ls: -rw-r–r-- 1 root root 1751 2016-03-03 21:41:40.000000000 +0800 /usr/share/X11/xorg.conf.d/50-synaptics.conf
Example xorg.conf.d snippet that assigns the touchpad driver
to all touchpads. See xorg.conf.d(5) for more information on
InputClass.
DO NOT EDIT THIS FILE, your distribution will likely overwrite
it when updating. Copy (and rename) this file into
/etc/X11/xorg.conf.d first.
Additional options may be added in the form of
Option “OptionName” “value”
Identifier “touchpad catchall”
Driver “synaptics”
This option is recommend on all Linux systems using evdev, but cannot be
enabled by default. See the following link for details:
Who-T: How to ignore configuration errors
MatchDevicePath "/dev/input/event*"
EndSection
Identifier “touchpad ignore duplicates”
MatchOS “Linux”
MatchDevicePath “/dev/input/mouse*”
EndSection
This option enables the bottom right corner to be a right button on clickpads
and the right and middle top areas to be right / middle buttons on clickpads
with a top button area.
This option is only interpreted by clickpads.
Identifier “Default clickpad buttons”
MatchDriver “synaptics”
Option “SoftButtonAreas” “50% 0 82% 0 0 0 0 0”
Option “SecondarySoftButtonAreas” “58% 0 0 15% 42% 58% 0 15%”
EndSection
This option disables software buttons on Apple touchpads.
Identifier “Disable clickpad buttons on Apple touchpads”
MatchProduct “Apple|bcm5974”
Option “SoftButtonAreas” “0 0 0 0 0 0 0 0”
EndSection
*** /usr/share/X11/xorg.conf.d/50-vmmouse.conf
*** ls: -rw-r–r-- 1 root root 115 2016-03-03 21:42:52.000000000 +0800 /usr/share/X11/xorg.conf.d/50-vmmouse.conf
Identifier “vmmouse”
MatchIsPointer “on”
MatchTag “vmmouse”
Driver “vmmouse”
EndSection
*** /usr/share/X11/xorg.conf.d/50-wacom.conf
*** ls: -rw-r–r-- 1 root root 1385 2016-03-03 19:47:50.000000000 +0800 /usr/share/X11/xorg.conf.d/50-wacom.conf
Sectio
