Recently installed 410.104 on my ubuntu 16.04 machine.
After a while I rebooted, and got stuck on a login loop. Any help would be apperciated
Attaching bug report
[code]
Start of NVIDIA bug report log file. Please include this file, along
with a detailed description of your problem, when reporting a graphics
driver bug via the NVIDIA Linux forum (see devtalk.nvidia.com)
or by sending email to ‘linux-bugs@nvidia.com’.
nvidia-bug-report.sh Version: 25652083
Date: ג’ מרץ 10 17:28:37 IST 2020
uname: Linux innereye-Yoske 4.15.0-88-generic #88~16.04.1-Ubuntu SMP Wed Feb 12 04:19:15 UTC 2020 x86_64 x86_64 x86_64 GNU/Linux
command line flags:
*** /etc/issue
*** ls: -rw-r–r-- 1 root root 26 2019-09-30 16:31:01.000000000 +0300 /etc/issue
Ubuntu 16.04.6 LTS \n \l
*** /etc/debian_version
*** ls: -rw-r–r-- 1 root root 12 2015-04-30 13:00:00.000000000 +0300 /etc/debian_version
stretch/sid
*** /var/log/nvidia-installer.log
*** ls: -rw-r–r-- 1 root root 28310 2019-12-31 15:36:41.010272553 +0200 /var/log/nvidia-installer.log
nvidia-installer log file ‘/var/log/nvidia-installer.log’
creation time: Tue Dec 31 15:35:57 2019
installer version: 410.104
PATH: /usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/snap/bin
nvidia-installer command line:
./nvidia-installer
Unable to load: nvidia-installer ncurses v6 user interface
Using: nvidia-installer ncurses user interface
→ Detected 12 CPUs online; setting concurrency level to 12.
→ Installing NVIDIA driver version 410.104.
→ There appears to already be a driver installed on your system (version: 384.81). As part of installing this driver (version: 410.104), the existing driver will be uninstalled. Are you sure you want to continue? (Answer: Continue installation)
→ Running distribution scripts
executing: ‘/usr/lib/nvidia/pre-install’…
→ done.
→ The distribution-provided pre-install script failed! Are you sure you want to continue? (Answer: Continue installation)
→ Would you like to register the kernel module sources with DKMS? This will allow DKMS to automatically build a new module, if you install a different kernel later. (Answer: No)
→ Performing CC sanity check with CC=“/usr/bin/cc”.
→ Kernel source path: ‘/lib/modules/4.15.0-72-generic/build’
→ Kernel output path: ‘/lib/modules/4.15.0-72-generic/build’
→ Performing Compiler check.
→ Performing Dom0 check.
→ Performing Xen check.
→ Performing PREEMPT_RT check.
→ Performing vgpu_kvm check.
→ Cleaning kernel module build directory.
executing: ‘cd ./kernel; /usr/bin/make -k -j12 clean NV_EXCLUDE_KERNEL_MODULES=“” SYSSRC=“/lib/modules/4.15.0-72-generic/build” SYSOUT=“/lib/modules/4.15.0-72-generic/build”’…
rm -f -r conftest
make[1]: Entering directory ‘/usr/src/linux-headers-4.15.0-72-generic’
make[1]: Leaving directory ‘/usr/src/linux-headers-4.15.0-72-generic’
→ Building kernel modules
executing: ‘cd ./kernel; /usr/bin/make -k -j12 NV_EXCLUDE_KERNEL_MODULES=“” SYSSRC=“/lib/modules/4.15.0-72-generic/build” SYSOUT=“/lib/modules/4.15.0-72-generic/build”’…
SYMLINK /tmp/selfgz1371/NVIDIA-Linux-x86_64-410.104/kernel/nvidia/nv-kernel.o
SYMLINK /tmp/selfgz1371/NVIDIA-Linux-x86_64-410.104/kernel/nvidia-modeset/nv-modeset-kernel.o
CONFTEST: INIT_WORK
CONFTEST: remap_pfn_range
CONFTEST: hash__remap_4k_pfn
CONFTEST: follow_pfn
CONFTEST: vmap
CONFTEST: set_memory_uc
CONFTEST: set_pages_uc
CONFTEST: set_memory_array_uc
CONFTEST: pci_get_class
CONFTEST: change_page_attr
CONFTEST: pci_choose_state
CONFTEST: vm_insert_page
CONFTEST: acpi_device_id
CONFTEST: kmem_cache_create
CONFTEST: acquire_console_sem
CONFTEST: console_lock
CONFTEST: on_each_cpu
CONFTEST: smp_call_function
CONFTEST: acpi_evaluate_integer
CONFTEST: ioremap_cache
CONFTEST: ioremap_wc
CONFTEST: acpi_walk_namespace
CONFTEST: pci_domain_nr
CONFTEST: pci_dma_mapping_error
CONFTEST: sg_alloc_table
CONFTEST: sg_init_table
CONFTEST: pci_get_domain_bus_and_slot
CONFTEST: get_num_physpages
CONFTEST: efi_enabled
CONFTEST: proc_create_data
CONFTEST: pde_data
CONFTEST: proc_remove
CONFTEST: pm_vt_switch_required
CONFTEST: xen_ioemu_inject_msi
CONFTEST: phys_to_dma
CONFTEST: get_dma_ops
CONFTEST: write_cr4
CONFTEST: of_get_property
CONFTEST: of_find_node_by_phandle
CONFTEST: of_node_to_nid
CONFTEST: pnv_pci_get_npu_dev
CONFTEST: of_get_ibm_chip_id
CONFTEST: for_each_online_node
CONFTEST: node_end_pfn
CONFTEST: pci_bus_address
CONFTEST: pci_stop_and_remove_bus_device
CONFTEST: pci_remove_bus_device
CONFTEST: request_threaded_irq
CONFTEST: cpuhp_setup_state
CONFTEST: register_cpu_notifier
CONFTEST: dma_map_resource
CONFTEST: backlight_device_register
CONFTEST: register_acpi_notifier
CONFTEST: timer_setup
CONFTEST: pci_enable_msix_range
CONFTEST: kmem_cache_create_usercopy
CONFTEST: do_gettimeofday
CONFTEST: remap_page_range
CONFTEST: address_space_init_once
CONFTEST: kbasename
CONFTEST: fatal_signal_pending
CONFTEST: list_cut_position
CONFTEST: vzalloc
CONFTEST: wait_on_bit_lock_argument_count
CONFTEST: bitmap_clear
CONFTEST: usleep_range
CONFTEST: radix_tree_empty
CONFTEST: pnv_npu2_init_context
CONFTEST: radix_tree_replace_slot
CONFTEST: drm_dev_unref
CONFTEST: drm_reinit_primary_mode_group
CONFTEST: get_user_pages_remote
CONFTEST: drm_gem_object_lookup
CONFTEST: drm_atomic_state_ref_counting
CONFTEST: drm_driver_has_gem_prime_res_obj
CONFTEST: drm_atomic_helper_connector_dpms
CONFTEST: drm_connector_funcs_have_mode_in_name
CONFTEST: vmf_insert_pfn
CONFTEST: drm_framebuffer_get
CONFTEST: drm_gem_object_get
CONFTEST: drm_dev_put
CONFTEST: is_export_symbol_gpl_of_node_to_nid
CONFTEST: is_export_symbol_present_swiotlb_map_sg_attrs
CONFTEST: is_export_symbol_present_swiotlb_dma_ops
CONFTEST: i2c_adapter
CONFTEST: pm_message_t
CONFTEST: acpi_device_ops
CONFTEST: irq_handler_t
CONFTEST: acpi_op_remove
CONFTEST: outer_flush_all
CONFTEST: proc_dir_entry
CONFTEST: scatterlist
CONFTEST: sg_table
CONFTEST: file_operations
CONFTEST: vm_operations_struct
CONFTEST: atomic_long_type
CONFTEST: pci_save_state
CONFTEST: file_inode
CONFTEST: task_struct
CONFTEST: kuid_t
CONFTEST: dma_ops
CONFTEST: swiotlb_dma_ops
CONFTEST: dma_map_ops
CONFTEST: noncoherent_swiotlb_dma_ops
CONFTEST: vm_fault_present
CONFTEST: vm_fault_has_address
CONFTEST: backlight_properties_type
CONFTEST: dev_pm_ops
CONFTEST: fault_flags
CONFTEST: atomic64_type
CONFTEST: backing_dev_info
CONFTEST: mm_context_t
CONFTEST: vm_ops_fault_removed_vma_arg
CONFTEST: node_states_n_memory
CONFTEST: drm_bus_present
CONFTEST: drm_bus_has_bus_type
CONFTEST: drm_bus_has_get_irq
CONFTEST: drm_bus_has_get_name
CONFTEST: drm_driver_has_set_busid
CONFTEST: drm_driver_has_legacy_dev_list
CONFTEST: drm_crtc_state_has_connectors_changed
CONFTEST: drm_init_function_args
CONFTEST: drm_mode_connector_list_update_has_merge_type_bits_arg
CONFTEST: drm_helper_mode_fill_fb_struct
CONFTEST: drm_master_drop_has_from_release_arg
CONFTEST: drm_driver_unload_has_int_return_type
CONFTEST: kref_has_refcount_of_type_refcount_t
CONFTEST: drm_atomic_helper_crtc_destroy_state_has_crtc_arg
CONFTEST: drm_crtc_helper_funcs_has_atomic_enable
CONFTEST: drm_mode_object_find_has_file_priv_arg
CONFTEST: dma_buf_owner
CONFTEST: drm_connector_list_iter
CONFTEST: dom0_kernel_present
CONFTEST: nvidia_vgpu_kvm_build
CONFTEST: nvidia_grid_build
CONFTEST: drm_available
CONFTEST: drm_atomic_available
CONFTEST: drm_atomic_modeset_nonblocking_commit_available
CONFTEST: is_export_symbol_gpl_refcount_inc
CONFTEST: is_export_symbol_gpl_refcount_dec_and_test
CC [M] /tmp/selfgz1371/NVIDIA-Linux-x86_64-410.104/kernel/nvidia/nv-frontend.o
CC [M] /tmp/selfgz1371/NVIDIA-Linux-x86_64-410.104/kernel/nvidia/nv-instance.o
CC [M] /tmp/selfgz1371/NVIDIA-Linux-x86_64-410.104/kernel/nvidia/nv.o
CC [M] /tmp/selfgz1371/NVIDIA-Linux-x86_64-410.104/kernel/nvidia/nv-acpi.o
CC [M] /tmp/selfgz1371/NVIDIA-Linux-x86_64-410.104/kernel/nvidia/nv-chrdev.o
CC [M] /tmp/selfgz1371/NVIDIA-Linux-x86_64-410.104/kernel/nvidia/nv-cray.o
CC [M] /tmp/selfgz1371/NVIDIA-Linux-x86_64-410.104/kernel/nvidia/nv-dma.o
CC [M] /tmp/selfgz1371/NVIDIA-Linux-x86_64-410.104/kernel/nvidia/nv-gvi.o
CC [M] /tmp/selfgz1371/NVIDIA-Linux-x86_64-410.104/kernel/nvidia/nv-i2c.o
CC [M] /tmp/selfgz1371/NVIDIA-Linux-x86_64-410.104/kernel/nvidia/nv-mempool.o
CC [M] /tmp/selfgz1371/NVIDIA-Linux-x86_64-410.104/kernel/nvidia/nv-p2p.o
CC [M] /tmp/selfgz1371/NVIDIA-Linux-x86_64-410.104/kernel/nvidia/nv-mmap.o
CC [M] /tmp/selfgz1371/NVIDIA-Linux-x86_64-410.104/kernel/nvidia/nv-pat.o
CC [M] /tmp/selfgz1371/NVIDIA-Linux-x86_64-410.104/kernel/nvidia/nv-procfs.o
CC [M] /tmp/selfgz1371/NVIDIA-Linux-x86_64-410.104/kernel/nvidia/nv-usermap.o
CC [M] /tmp/selfgz1371/NVIDIA-Linux-x86_64-410.104/kernel/nvidia/nv-vm.o
CC [M] /tmp/selfgz1371/NVIDIA-Linux-x86_64-410.104/kernel/nvidia/nv-vtophys.o
CC [M] /tmp/selfgz1371/NVIDIA-Linux-x86_64-410.104/kernel/nvidia/os-interface.o
CC [M] /tmp/selfgz1371/NVIDIA-Linux-x86_64-410.104/kernel/nvidia/os-mlock.o
CC [M] /tmp/selfgz1371/NVIDIA-Linux-x86_64-410.104/kernel/nvidia/os-pci.o
CC [M] /tmp/selfgz1371/NVIDIA-Linux-x86_64-410.104/kernel/nvidia/os-registry.o
CC [M] /tmp/selfgz1371/NVIDIA-Linux-x86_64-410.104/kernel/nvidia/os-usermap.o
CC [M] /tmp/selfgz1371/NVIDIA-Linux-x86_64-410.104/kernel/nvidia/nv-modeset-interface.o
CC [M] /tmp/selfgz1371/NVIDIA-Linux-x86_64-410.104/kernel/nvidia/nv-pci-table.o
CC [M] /tmp/selfgz1371/NVIDIA-Linux-x86_64-410.104/kernel/nvidia/nv-kthread-q.o
CC [M] /tmp/selfgz1371/NVIDIA-Linux-x86_64-410.104/kernel/nvidia/nv-kthread-q-selftest.o
CC [M] /tmp/selfgz1371/NVIDIA-Linux-x86_64-410.104/kernel/nvidia/nv-memdbg.o
CC [M] /tmp/selfgz1371/NVIDIA-Linux-x86_64-410.104/kernel/nvidia/nv-ibmnpu.o
CC [M] /tmp/selfgz1371/NVIDIA-Linux-x86_64-410.104/kernel/nvidia/nv-report-err.o
CC [M] /tmp/selfgz1371/NVIDIA-Linux-x86_64-410.104/kernel/nvidia/nv-rsync.o
CC [M] /tmp/selfgz1371/NVIDIA-Linux-x86_64-410.104/kernel/nvidia/nv-msi.o
CC [M] /tmp/selfgz1371/NVIDIA-Linux-x86_64-410.104/kernel/nvidia/nv_uvm_interface.o
CC [M] /tmp/selfgz1371/NVIDIA-Linux-x86_64-410.104/kernel/nvidia/nvlink_linux.o
CC [M] /tmp/selfgz1371/NVIDIA-Linux-x86_64-410.104/kernel/nvidia/linux_nvswitch.o
CC [M] /tmp/selfgz1371/NVIDIA-Linux-x86_64-410.104/kernel/nvidia-uvm/uvm8_turing.o
CC [M] /tmp/selfgz1371/NVIDIA-Linux-x86_64-410.104/kernel/nvidia-uvm/uvm8_turing_mmu.o
CC [M] /tmp/selfgz1371/NVIDIA-Linux-x86_64-410.104/kernel/nvidia-uvm/uvm8_turing_host.o
CC [M] /tmp/selfgz1371/NVIDIA-Linux-x86_64-410.104/kernel/nvidia-uvm/uvm_utils.o
CC [M] /tmp/selfgz1371/NVIDIA-Linux-x86_64-410.104/kernel/nvidia-uvm/uvm_common.o
CC [M] /tmp/selfgz1371/NVIDIA-Linux-x86_64-410.104/kernel/nvidia-uvm/uvm_linux.o
CC [M] /tmp/selfgz1371/NVIDIA-Linux-x86_64-410.104/kernel/nvidia-uvm/nvstatus.o
CC [M] /tmp/selfgz1371/NVIDIA-Linux-x86_64-410.104/kernel/nvidia-uvm/nvCpuUuid.o
CC [M] /tmp/selfgz1371/NVIDIA-Linux-x86_64-410.104/kernel/nvidia-uvm/uvm8.o
CC [M] /tmp/selfgz1371/NVIDIA-Linux-x86_64-410.104/kernel/nvidia-uvm/uvm8_tools.o
CC [M] /tmp/selfgz1371/NVIDIA-Linux-x86_64-410.104/kernel/nvidia-uvm/uvm8_global.o
CC [M] /tmp/selfgz1371/NVIDIA-Linux-x86_64-410.104/kernel/nvidia-uvm/uvm8_gpu.o
CC [M] /tmp/selfgz1371/NVIDIA-Linux-x86_64-410.104/kernel/nvidia-uvm/uvm8_gpu_isr.o
CC [M] /tmp/selfgz1371/NVIDIA-Linux-x86_64-410.104/kernel/nvidia-uvm/uvm8_procfs.o
CC [M] /tmp/selfgz1371/NVIDIA-Linux-x86_64-410.104/kernel/nvidia-uvm/uvm8_va_space.o
CC [M] /tmp/selfgz1371/NVIDIA-Linux-x86_64-410.104/kernel/nvidia-uvm/uvm8_va_space_mm.o
CC [M] /tmp/selfgz1371/NVIDIA-Linux-x86_64-410.104/kernel/nvidia-uvm/uvm8_gpu_semaphore.o
CC [M] /tmp/selfgz1371/NVIDIA-Linux-x86_64-410.104/kernel/nvidia-uvm/uvm8_mem.o
CC [M] /tmp/selfgz1371/NVIDIA-Linux-x86_64-410.104/kernel/nvidia-uvm/uvm8_rm_mem.o
CC [M] /tmp/selfgz1371/NVIDIA-Linux-x86_64-410.104/kernel/nvidia-uvm/uvm8_channel.o
CC [M] /tmp/selfgz1371/NVIDIA-Linux-x86_64-410.104/kernel/nvidia-uvm/uvm8_lock.o
CC [M] /tmp/selfgz1371/NVIDIA-Linux-x86_64-410.104/kernel/nvidia-uvm/uvm8_hal.o
CC [M] /tmp/selfgz1371/NVIDIA-Linux-x86_64-410.104/kernel/nvidia-uvm/uvm8_range_tree.o
CC [M] /tmp/selfgz1371/NVIDIA-Linux-x86_64-410.104/kernel/nvidia-uvm/uvm8_range_allocator.o
CC [M] /tmp/selfgz1371/NVIDIA-Linux-x86_64-410.104/kernel/nvidia-uvm/uvm8_va_range.o
CC [M] /tmp/selfgz1371/NVIDIA-Linux-x86_64-410.104/kernel/nvidia-uvm/uvm8_va_block.o
CC [M] /tmp/selfgz1371/NVIDIA-Linux-x86_64-410.104/kernel/nvidia-uvm/uvm8_range_group.o
CC [M] /tmp/selfgz1371/NVIDIA-Linux-x86_64-410.104/kernel/nvidia-uvm/uvm8_gpu_replayable_faults.o
CC [M] /tmp/selfgz1371/NVIDIA-Linux-x86_64-410.104/kernel/nvidia-uvm/uvm8_gpu_non_replayable_faults.o
CC [M] /tmp/selfgz1371/NVIDIA-Linux-x86_64-410.104/kernel/nvidia-uvm/uvm8_gpu_access_counters.o
CC [M] /tmp/selfgz1371/NVIDIA-Linux-x86_64-410.104/kernel/nvidia-uvm/uvm8_perf_events.o
CC [M] /tmp/selfgz1371/NVIDIA-Linux-x86_64-410.104/kernel/nvidia-uvm/uvm8_perf_module.o
CC [M] /tmp/selfgz1371/NVIDIA-Linux-x86_64-410.104/kernel/nvidia-uvm/uvm8_mmu.o
CC [M] /tmp/selfgz1371/NVIDIA-Linux-x86_64-410.104/kernel/nvidia-uvm/uvm8_pte_batch.o
CC [M] /tmp/selfgz1371/NVIDIA-Linux-x86_64-410.104/kernel/nvidia-uvm/uvm8_tlb_batch.o
CC [M] /tmp/selfgz1371/NVIDIA-Linux-x86_64-410.104/kernel/nvidia-uvm/uvm8_push.o
CC [M] /tmp/selfgz1371/NVIDIA-Linux-x86_64-410.104/kernel/nvidia-uvm/uvm8_pushbuffer.o
CC [M] /tmp/selfgz1371/NVIDIA-Linux-x86_64-410.104/kernel/nvidia-uvm/uvm8_thread_context.o
CC [M] /tmp/selfgz1371/NVIDIA-Linux-x86_64-410.104/kernel/nvidia-uvm/uvm8_tracker.o
CC [M] /tmp/selfgz1371/NVIDIA-Linux-x86_64-410.104/kernel/nvidia-uvm/uvm8_kepler.o
CC [M] /tmp/selfgz1371/NVIDIA-Linux-x86_64-410.104/kernel/nvidia-uvm/uvm8_kepler_ce.o
CC [M] /tmp/selfgz1371/NVIDIA-Linux-x86_64-410.104/kernel/nvidia-uvm/uvm8_kepler_host.o
CC [M] /tmp/selfgz1371/NVIDIA-Linux-x86_64-410.104/kernel/nvidia-uvm/uvm8_kepler_mmu.o
CC [M] /tmp/selfgz1371/NVIDIA-Linux-x86_64-410.104/kernel/nvidia-uvm/uvm8_maxwell.o
CC [M] /tmp/selfgz1371/NVIDIA-Linux-x86_64-410.104/kernel/nvidia-uvm/uvm8_maxwell_host.o
CC [M] /tmp/selfgz1371/NVIDIA-Linux-x86_64-410.104/kernel/nvidia-uvm/uvm8_pascal.o
CC [M] /tmp/selfgz1371/NVIDIA-Linux-x86_64-410.104/kernel/nvidia-uvm/uvm8_pascal_ce.o
CC [M] /tmp/selfgz1371/NVIDIA-Linux-x86_64-410.104/kernel/nvidia-uvm/uvm8_pascal_host.o
CC [M] /tmp/selfgz1371/NVIDIA-Linux-x86_64-410.104/kernel/nvidia-uvm/uvm8_pascal_mmu.o
CC [M] /tmp/selfgz1371/NVIDIA-Linux-x86_64-410.104/kernel/nvidia-uvm/uvm8_pascal_fault_buffer.o
CC [M] /tmp/selfgz1371/NVIDIA-Linux-x86_64-410.104/kernel/nvidia-uvm/uvm8_volta_host.o
CC [M] /tmp/selfgz1371/NVIDIA-Linux-x86_64-410.104/kernel/nvidia-uvm/uvm8_volta_mmu.o
CC [M] /tmp/selfgz1371/NVIDIA-Linux-x86_64-410.104/kernel/nvidia-uvm/uvm8_volta.o
CC [M] /tmp/selfgz1371/NVIDIA-Linux-x86_64-410.104/kernel/nvidia-uvm/uvm8_volta_fault_buffer.o
CC [M] /tmp/selfgz1371/NVIDIA-Linux-x86_64-410.104/kernel/nvidia-uvm/uvm8_volta_access_counter_buffer.o
CC [M] /tmp/selfgz1371/NVIDIA-Linux-x86_64-410.104/kernel/nvidia-uvm/uvm8_policy.o
CC [M] /tmp/selfgz1371/NVIDIA-Linux-x86_64-410.104/kernel/nvidia-uvm/uvm8_perf_utils.o
CC [M] /tmp/selfgz1371/NVIDIA-Linux-x86_64-410.104/kernel/nvidia-uvm/uvm8_kvmalloc.o
CC [M] /tmp/selfgz1371/NVIDIA-Linux-x86_64-410.104/kernel/nvidia-uvm/uvm8_pmm_sysmem.o
CC [M] /tmp/selfgz1371/NVIDIA-Linux-x86_64-410.104/kernel/nvidia-uvm/uvm8_pmm_gpu.o
CC [M] /tmp/selfgz1371/NVIDIA-Linux-x86_64-410.104/kernel/nvidia-uvm/uvm8_migrate.o
CC [M] /tmp/selfgz1371/NVIDIA-Linux-x86_64-410.104/kernel/nvidia-uvm/uvm8_populate_pageable.o
CC [M] /tmp/selfgz1371/NVIDIA-Linux-x86_64-410.104/kernel/nvidia-uvm/uvm8_migrate_pageable.o
CC [M] /tmp/selfgz1371/NVIDIA-Linux-x86_64-410.104/kernel/nvidia-uvm/uvm8_map_external.o
CC [M] /tmp/selfgz1371/NVIDIA-Linux-x86_64-410.104/kernel/nvidia-uvm/uvm8_user_channel.o
CC [M] /tmp/selfgz1371/NVIDIA-Linux-x86_64-410.104/kernel/nvidia-uvm/uvm8_hmm.o
CC [M] /tmp/selfgz1371/NVIDIA-Linux-x86_64-410.104/kernel/nvidia-uvm/uvm8_perf_heuristics.o
CC [M] /tmp/selfgz1371/NVIDIA-Linux-x86_64-410.104/kernel/nvidia-uvm/uvm8_perf_thrashing.o
CC [M] /tmp/selfgz1371/NVIDIA-Linux-x86_64-410.104/kernel/nvidia-uvm/uvm8_perf_prefetch.o
CC [M] /tmp/selfgz1371/NVIDIA-Linux-x86_64-410.104/kernel/nvidia-uvm/uvm8_ats_ibm.o
CC [M] /tmp/selfgz1371/NVIDIA-Linux-x86_64-410.104/kernel/nvidia-uvm/uvm8_ats_faults.o
CC [M] /tmp/selfgz1371/NVIDIA-Linux-x86_64-410.104/kernel/nvidia-uvm/uvm8_test.o
CC [M] /tmp/selfgz1371/NVIDIA-Linux-x86_64-410.104/kernel/nvidia-uvm/uvm8_test_rng.o
CC [M] /tmp/selfgz1371/NVIDIA-Linux-x86_64-410.104/kernel/nvidia-uvm/uvm8_range_tree_test.o
CC [M] /tmp/selfgz1371/NVIDIA-Linux-x86_64-410.104/kernel/nvidia-uvm/uvm8_range_allocator_test.o
CC [M] /tmp/selfgz1371/NVIDIA-Linux-x86_64-410.104/kernel/nvidia-uvm/uvm8_gpu_semaphore_test.o
CC [M] /tmp/selfgz1371/NVIDIA-Linux-x86_64-410.104/kernel/nvidia-uvm/uvm8_mem_test.o
CC [M] /tmp/selfgz1371/NVIDIA-Linux-x86_64-410.104/kernel/nvidia-uvm/uvm8_rm_mem_test.o
CC [M] /tmp/selfgz1371/NVIDIA-Linux-x86_64-410.104/kernel/nvidia-uvm/uvm8_page_tree_test.o
CC [M] /tmp/selfgz1371/NVIDIA-Linux-x86_64-410.104/kernel/nvidia-uvm/uvm8_tracker_test.o
CC [M] /tmp/selfgz1371/NVIDIA-Linux-x86_64-410.104/kernel/nvidia-uvm/uvm8_push_test.o
CC [M] /tmp/selfgz1371/NVIDIA-Linux-x86_64-410.104/kernel/nvidia-uvm/uvm8_channel_test.o
CC [M] /tmp/selfgz1371/NVIDIA-Linux-x86_64-410.104/kernel/nvidia-uvm/uvm8_ce_test.o
CC [M] /tmp/selfgz1371/NVIDIA-Linux-x86_64-410.104/kernel/nvidia-uvm/uvm8_lock_test.o
CC [M] /tmp/selfgz1371/NVIDIA-Linux-x86_64-410.104/kernel/nvidia-uvm/uvm8_perf_utils_test.o
CC [M] /tmp/selfgz1371/NVIDIA-Linux-x86_64-410.104/kernel/nvidia-uvm/uvm8_kvmalloc_test.o
CC [M] /tmp/selfgz1371/NVIDIA-Linux-x86_64-410.104/kernel/nvidia-uvm/uvm8_pmm_test.o
CC [M] /tmp/selfgz1371/NVIDIA-Linux-x86_64-410.104/kernel/nvidia-uvm/uvm8_pmm_sysmem_test.o
CC [M] /tmp/selfgz1371/NVIDIA-Linux-x86_64-410.104/kernel/nvidia-uvm/uvm8_perf_events_test.o
CC [M] /tmp/selfgz1371/NVIDIA-Linux-x86_64-410.104/kernel/nvidia-uvm/uvm8_perf_module_test.o
CC [M] /tmp/selfgz1371/NVIDIA-Linux-x86_64-410.104/kernel/nvidia-uvm/uvm8_fault_buffer_flush_test.o
CC [M] /tmp/selfgz1371/NVIDIA-Linux-x86_64-410.104/kernel/nvidia-uvm/uvm8_get_rm_ptes_test.o
CC [M] /tmp/selfgz1371/NVIDIA-Linux-x86_64-410.104/kernel/nvidia-uvm/uvm8_mmu_test.o
CC [M] /tmp/selfgz1371/NVIDIA-Linux-x86_64-410.104/kernel/nvidia-uvm/uvm8_peer_identity_mappings_test.o
CC [M] /tmp/selfgz1371/NVIDIA-Linux-x86_64-410.104/kernel/nvidia-uvm/uvm8_va_block_test.o
CC [M] /tmp/selfgz1371/NVIDIA-Linux-x86_64-410.104/kernel/nvidia-uvm/uvm8_range_group_tree_test.o
CC [M] /tmp/selfgz1371/NVIDIA-Linux-x86_64-410.104/kernel/nvidia-modeset/nvidia-modeset-linux.o
CC [M] /tmp/selfgz1371/NVIDIA-Linux-x86_64-410.104/kernel/nvidia-drm/nvidia-drm.o
CC [M] /tmp/selfgz1371/NVIDIA-Linux-x86_64-410.104/kernel/nvidia-drm/nvidia-drm-drv.o
CC [M] /tmp/selfgz1371/NVIDIA-Linux-x86_64-410.104/kernel/nvidia-drm/nvidia-drm-utils.o
CC [M] /tmp/selfgz1371/NVIDIA-Linux-x86_64-410.104/kernel/nvidia-drm/nvidia-drm-crtc.o
CC [M] /tmp/selfgz1371/NVIDIA-Linux-x86_64-410.104/kernel/nvidia-drm/nvidia-drm-encoder.o
CC [M] /tmp/selfgz1371/NVIDIA-Linux-x86_64-410.104/kernel/nvidia-drm/nvidia-drm-connector.o
CC [M] /tmp/selfgz1371/NVIDIA-Linux-x86_64-410.104/kernel/nvidia-drm/nvidia-drm-gem.o
CC [M] /tmp/selfgz1371/NVIDIA-Linux-x86_64-410.104/kernel/nvidia-drm/nvidia-drm-fb.o
CC [M] /tmp/selfgz1371/NVIDIA-Linux-x86_64-410.104/kernel/nvidia-drm/nvidia-drm-modeset.o
CC [M] /tmp/selfgz1371/NVIDIA-Linux-x86_64-410.104/kernel/nvidia-drm/nvidia-drm-prime-fence.o
CC [M] /tmp/selfgz1371/NVIDIA-Linux-x86_64-410.104/kernel/nvidia-drm/nvidia-drm-linux.o
CC [M] /tmp/selfgz1371/NVIDIA-Linux-x86_64-410.104/kernel/nvidia-drm/nvidia-drm-helper.o
CC [M] /tmp/selfgz1371/NVIDIA-Linux-x86_64-410.104/kernel/nvidia-drm/nv-pci-table.o
CC [M] /tmp/selfgz1371/NVIDIA-Linux-x86_64-410.104/kernel/nvidia-drm/nvidia-drm-gem-nvkms-memory.o
CC [M] /tmp/selfgz1371/NVIDIA-Linux-x86_64-410.104/kernel/nvidia-drm/nvidia-drm-gem-user-memory.o
ld -r -o /tmp/selfgz1371/NVIDIA-Linux-x86_64-410.104/kernel/nvidia/nv-interface.o /tmp/selfgz1371/NVIDIA-Linux-x86_64-410.104/kernel/nvidia/nv-frontend.o /tmp/selfgz1371/NVIDIA-Linux-x86_64-410.104/kernel/nvidia/nv-instance.o /tmp/selfgz1371/NVIDIA-Linux-x86_64-410.104/kernel/nvidia/nv.o /tmp/selfgz1371/NVIDIA-Linux-x86_64-410.104/kernel/nvidia/nv-acpi.o /tmp/selfgz1371/NVIDIA-Linux-x86_64-410.104/kernel/nvidia/nv-chrdev.o /tmp/selfgz1371/NVIDIA-Linux-x86_64-410.104/kernel/nvidia/nv-cray.o /tmp/selfgz1371/NVIDIA-Linux-x86_64-410.104/kernel/nvidia/nv-dma.o /tmp/selfgz1371/NVIDIA-Linux-x86_64-410.104/kernel/nvidia/nv-gvi.o /tmp/selfgz1371/NVIDIA-Linux-x86_64-410.104/kernel/nvidia/nv-i2c.o /tmp/selfgz1371/NVIDIA-Linux-x86_64-410.104/kernel/nvidia/nv-mempool.o /tmp/selfgz1371/NVIDIA-Linux-x86_64-410.104/kernel/nvidia/nv-mmap.o
/tmp/selfgz1371/NVIDIA-Linux-x86_64-410.104/kernel/nvidia/nv-p2p.o /tmp/selfgz1371/NVIDIA-Linux-x86_64-410.104/kernel/nvidia/nv-pat.o /tmp/selfgz1371/NVIDIA-Linux-x86_64-410.104/kernel/nvidia/nv-procfs.o /tmp/selfgz1371/NVIDIA-Linux-x86_64-410.104/kernel/nvidia/nv-usermap.o /tmp/selfgz1371/NVIDIA-Linux-x86_64-410.104/kernel/nvidia/nv-vm.o /tmp/selfgz1371/NVIDIA-Linux-x86_64-410.104/kernel/nvidia/nv-vtophys.o /tmp/selfgz1371/NVIDIA-Linux-x86_64-410.104/kernel/nvidia/os-interface.o /tmp/selfgz1371/NVIDIA-Linux-x86_64-410.104/kernel/nvidia/os-mlock.o /tmp/selfgz1371/NVIDIA-Linux-x86_64-410.104/kernel/nvidia/os-pci.o /tmp/selfgz1371/NVIDIA-Linux-x86_64-410.104/kernel/nvidia/os-registry.o /tmp/selfgz1371/NVIDIA-Linux-x86_64-410.104/kernel/nvidia/os-usermap.o /tmp/selfgz1371/NVIDIA-Linux-x86_64-410.104/kernel/nvidia/nv-modeset-interface.o /tmp/selfgz1371/NVIDIA-Linux-x86_64-410.104/kernel/nvidia/nv-pci-table.o /tmp/selfgz1371/NVIDIA-Linux-x86_64-410.104/kernel/nvidia/nv-kthread-q.o /tmp/selfgz1371/NVIDIA-Linux-x86
_64-410.104/kernel/nvidia/nv-kthread-q-selftest.o /tmp/selfgz1371/NVIDIA-Linux-x86_64-410.104/kernel/nvidia/nv-memdbg.o /tmp/selfgz1371/NVIDIA-Linux-x86_64-410.104/kernel/nvidia/nv-ibmnpu.o /tmp/selfgz1371/NVIDIA-Linux-x86_64-410.104/kernel/nvidia/nv-report-err.o /tmp/selfgz1371/NVIDIA-Linux-x86_64-410.104/kernel/nvidia/nv-rsync.o /tmp/selfgz1371/NVIDIA-Linux-x86_64-410.104/kernel/nvidia/nv-msi.o /tmp/selfgz1371/NVIDIA-Linux-x86_64-410.104/kernel/nvidia/nv_uvm_interface.o /tmp/selfgz1371/NVIDIA-Linux-x86_64-410.104/kernel/nvidia/nvlink_linux.o /tmp/selfgz1371/NVIDIA-Linux-x86_64-410.104/kernel/nvidia/linux_nvswitch.o
ld -r -o /tmp/selfgz1371/NVIDIA-Linux-x86_64-410.104/kernel/nvidia-modeset/nv-modeset-interface.o /tmp/selfgz1371/NVIDIA-Linux-x86_64-410.104/kernel/nvidia-modeset/nvidia-modeset-linux.o
LD [M] /tmp/selfgz1371/NVIDIA-Linux-x86_64-410.104/kernel/nvidia.o
LD [M] /tmp/selfgz1371/NVIDIA-Linux-x86_64-410.104/kernel/nvidia-uvm.o
LD [M] /tmp/selfgz1371/NVIDIA-Linux-x86_64-410.104/kernel/nvidia-modeset.o
LD [M] /tmp/selfgz1371/NVIDIA-Linux-x86_64-410.104/kernel/nvidia-drm.o
Building modules, stage 2.
MODPOST 4 modules
CC /tmp/selfgz1371/NVIDIA-Linux-x86_64-410.104/kernel/nvidia-drm.mod.o
CC /tmp/selfgz1371/NVIDIA-Linux-x86_64-410.104/kernel/nvidia-modeset.mod.o
CC /tmp/selfgz1371/NVIDIA-Linux-x86_64-410.104/kernel/nvidia-uvm.mod.o
CC /tmp/selfgz1371/NVIDIA-Linux-x86_64-410.104/kernel/nvidia.mod.o
LD [M] /tmp/selfgz1371/NVIDIA-Linux-x86_64-410.104/kernel/nvidia-drm.ko
LD [M] /tmp/selfgz1371/NVIDIA-Linux-x86_64-410.104/kernel/nvidia-modeset.ko
LD [M] /tmp/selfgz1371/NVIDIA-Linux-x86_64-410.104/kernel/nvidia-uvm.ko
LD [M] /tmp/selfgz1371/NVIDIA-Linux-x86_64-410.104/kernel/nvidia.ko
→ done.
→ Kernel module compilation complete.
→ Kernel messages:
[ 188.710188] usb 1-1: new low-speed USB device number 8 using xhci_hcd
[ 188.863252] usb 1-1: New USB device found, idVendor=17ef, idProduct=6019
[ 188.863257] usb 1-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 188.863260] usb 1-1: Product: Lenovo USB Optical Mouse
[ 188.863263] usb 1-1: Manufacturer: PixArt
[ 188.865923] input: PixArt Lenovo USB Optical Mouse as /devices/pci0000:00/0000:00:14.0/usb1/1-1/1-1:1.0/0003:17EF:6019.0006/input/input18
[ 188.926679] hid-generic 0003:17EF:6019.0006: input,hidraw0: USB HID v1.11 Mouse [PixArt Lenovo USB Optical Mouse] on usb-0000:00:14.0-1/input0
[ 236.461307] VFIO - User Level meta-driver version: 0.3
[ 236.466625] ipmi message handler version 39.2
[ 236.467455] ipmi device interface
[ 236.470601] nvidia: loading out-of-tree module taints kernel.
[ 236.470606] nvidia: module license ‘NVIDIA’ taints kernel.
[ 236.470607] Disabling lock debugging due to kernel taint
[ 236.473288] nvidia: module verification failed: signature and/or required key missing - tainting kernel
[ 236.477788] nvidia-nvlink: Nvlink Core is being initialized, major device number 237
[ 236.478122] nvidia 0000:01:00.0: vgaarb: changed VGA decodes: olddecodes=io+mem,decodes=none:owns=io+mem
[ 236.525885] NVRM: loading NVIDIA UNIX x86_64 Kernel Module 410.104 Tue Feb 5 22:58:30 CST 2019 (using threaded interrupts)
[ 236.529138] nvidia-uvm: Loaded the UVM driver in 8 mode, major device number 235
[ 236.530427] nvidia-modeset: Loading NVIDIA Kernel Mode Setting Driver for UNIX platforms 410.104 Tue Feb 5 22:56:44 CST 2019
[ 236.531192] [drm] [nvidia-drm] [GPU ID 0x00000100] Loading driver
[ 236.531193] [drm] Initialized nvidia-drm 0.0.0 20160202 for 0000:01:00.0 on minor 0
[ 236.531958] [drm] [nvidia-drm] [GPU ID 0x00000100] Unloading driver
[ 236.567614] nvidia-modeset: Unloading
[ 236.600926] nvidia-uvm: Unloaded the UVM driver in 8 mode
[ 236.624340] nvidia-nvlink: Unregistered the Nvlink Core, major device number 237
→ Installing both new and classic TLS OpenGL libraries.
→ Installing both new and classic TLS 32bit OpenGL libraries.
→ Install NVIDIA’s 32-bit compatibility libraries? (Answer: No)
→ Will install GLVND GLX client libraries.
→ Will install GLVND EGL client libraries.
→ Skipping GLX non-GLVND file: “libGL.so.410.104”
→ Skipping GLX non-GLVND file: “libGL.so.1”
→ Skipping GLX non-GLVND file: “libGL.so”
→ Skipping EGL non-GLVND file: “libEGL.so.410.104”
→ Skipping EGL non-GLVND file: “libEGL.so”
→ Skipping EGL non-GLVND file: “libEGL.so.1”
→ Uninstalling the previous installation with /usr/bin/nvidia-uninstall.
Looking for install checker script at ./libglvnd_install_checker/check-libglvnd-install.sh
executing: ‘/bin/sh ./libglvnd_install_checker/check-libglvnd-install.sh’…
Checking for libglvnd installation.
Checking libGLdispatch…
Can’t load library libGLdispatch.so.0: libGLdispatch.so.0: cannot open shared object file: No such file or directory
Will install libglvnd libraries.
Will install libEGL vendor library config file to /usr/share/glvnd/egl_vendor.d
→ Searching for conflicting files:
→ done.
→ Installing ‘NVIDIA Accelerated Graphics Driver for Linux-x86_64’ (410.104):
executing: ‘/sbin/ldconfig’…
executing: '/sbin/depmod -a '…
→ done.
→ Driver file installation is complete.
→ Running post-install sanity check:
→ done.
→ Post-install sanity check passed.
→ Running runtime sanity check:
→ done.
→ Runtime sanity check passed.
→ Would you like to run the nvidia-xconfig utility to automatically update your X configuration file so that the NVIDIA X driver will be used when you restart X? Any pre-existing X configuration file will be backed up. (Answer: No)
→ Installation of the NVIDIA Accelerated Graphics Driver for Linux-x86_64 (version: 410.104) is now complete. Please update your XF86Config or xorg.conf file as appropriate; see the file /usr/share/doc/NVIDIA_GLX-1.0/README.txt for details.
*** /var/log/nvidia-uninstall.log
*** ls: -rw-r–r-- 1 root root 1190 2019-12-31 15:36:31.718234756 +0200 /var/log/nvidia-uninstall.log
nvidia-installer log file ‘/var/log/nvidia-uninstall.log’
creation time: Tue Dec 31 15:36:29 2019
installer version: 384.81
-s
–log-file-name=/var/log/nvidia-uninstall.log
Using built-in stream user interface
→ If you plan to no longer use the NVIDIA driver, you should make sure that no X screens are configured to use the NVIDIA X driver in your X configuration file. If you used nvidia-xconfig to configure X, it may have created a backup of your original configuration. Would you like to run nvidia-xconfig --restore-original-backup to attempt restoration of the original X configuration file? (Answer: No)
→ Parsing log file:
→ done.
→ Validating previous installation:
→ done.
→ Uninstalling NVIDIA Accelerated Graphics Driver for Linux-x86_64 (1.0-38481 (384.81)):
→ DKMS module detected; removing…
→ done.
→ Running depmod and ldconfig:
→ done.
→ Uninstallation of existing driver: NVIDIA Accelerated Graphics Driver for Linux-x86_64 (384.81) is complete.
journalctl -b -0 _COMM=Xorg
– No entries –
journalctl -b -1 _COMM=Xorg
journalctl -b -2 _COMM=Xorg
journalctl -b -0 _COMM=Xorg.bin
– No entries –
journalctl -b -1 _COMM=Xorg.bin
journalctl -b -2 _COMM=Xorg.bin
– No entries –
*** /var/log/Xorg.0.log
*** ls: -rw-r–r-- 1 root root 24971 2020-03-10 17:28:13.064483024 +0200 /var/log/Xorg.0.log
[ 3.343]
X.Org X Server 1.19.6
Release Date: 2017-12-20
[ 3.343] X Protocol Version 11, Revision 0
[ 3.343] Build Operating System: Linux 4.4.0-138-generic x86_64 Ubuntu
[ 3.343] Current Operating System: Linux innereye-Yoske 4.15.0-88-generic #88~16.04.1-Ubuntu SMP Wed Feb 12 04:19:15 UTC 2020 x86_64
[ 3.343] Kernel command line: BOOT_IMAGE=/boot/vmlinuz-4.15.0-88-generic root=UUID=46ee4bd3-51a7-46bf-8738-f09d40c18204 ro quiet splash vt.handoff=7
[ 3.343] Build Date: 25 October 2018 04:13:49PM
[ 3.343] xorg-server 2:1.19.6-1ubuntu4.1~16.04.2 (For technical support please see Enterprise open source support | Ubuntu)
[ 3.343] Current version of pixman: 0.33.6
[ 3.343] Before reporting problems, check http://wiki.x.org
to make sure that you have the latest version.
[ 3.343] Markers: (–) probed, () from config file, (==) default setting,
(++) from command line, (!!) notice, (II) informational,
(WW) warning, (EE) error, (NI) not implemented, (??) unknown.
[ 3.343] (==) Log file: “/var/log/Xorg.0.log”, Time: Tue Mar 10 17:28:12 2020
[ 3.343] (==) Using system config directory “/usr/share/X11/xorg.conf.d”
[ 3.343] (==) No Layout section. Using the first Screen section.
[ 3.343] (==) No screen section available. Using defaults.
[ 3.343] () |–>Screen “Default Screen Section” (0)
[ 3.343] (**) | |–>Monitor “”
[ 3.344] (==) No monitor specified for screen “Default Screen Section”.
Using a default monitor configuration.
[ 3.344] (==) Automatically adding devices
[ 3.344] (==) Automatically enabling devices
[ 3.344] (==) Automatically adding GPU devices
[ 3.344] (==) Automatically binding GPU devices
[ 3.344] (==) Max clients allowed: 256, resource mask: 0x1fffff
[ 3.344] (WW) The directory “/usr/share/fonts/X11/cyrillic” does not exist.
[ 3.344] Entry deleted from font path.
[ 3.344] (WW) The directory “/usr/share/fonts/X11/100dpi/” does not exist.
[ 3.344] (WW) The directory “/usr/share/fonts/X11/75dpi/” does not exist.
[ 3.344] (WW) The directory “/usr/share/fonts/X11/100dpi” does not exist.
[ 3.344] (WW) The directory “/usr/share/fonts/X11/75dpi” does not exist.
[ 3.344] (==) FontPath set to:
/usr/share/fonts/X11/misc,
/usr/share/fonts/X11/Type1,
built-ins
[ 3.344] (==) ModulePath set to “/usr/lib/x86_64-linux-gnu/xorg/extra-modules,/usr/lib/xorg/extra-modules,/usr/lib/xorg/modules”
[ 3.344] (II) The server relies on udev to provide the list of input devices.
If no devices become available, reconfigure udev or disable AutoAddDevices.
[ 3.344] (II) Loader magic: 0x556f86131e00
[ 3.344] (II) Module ABI versions:
[ 3.344] X.Org ANSI C Emulation: 0.4
[ 3.344] X.Org Video Driver: 23.0
[ 3.344] X.Org XInput driver : 24.1
[ 3.344] X.Org Server Extension : 10.0
[ 3.344] (++) using VT number 7
[ 3.344] (II) systemd-logind: logind integration requires -keeptty and -keeptty was not provided, disabling logind integration
[ 3.346] (–) PCI:*(0:1:0:0) 10de:1f11:17aa:3ffd rev 161, Mem @ 0xb3000000/16777216, 0xa0000000/268435456, 0xb0000000/33554432, I/O @ 0x00004000/128, BIOS @ 0x???/524288
[ 3.346] (II) LoadModule: “glx”
[ 3.346] (II) Loading /usr/lib/xorg/modules/extensions/libglx.so
[ 3.348] (II) Module glx: vendor=“X.Org Foundation”
[ 3.348] compiled for 1.19.6, module version = 1.0.0
[ 3.348] ABI class: X.Org Server Extension, version 10.0
[ 3.348] (==) Matched nvidia as autoconfigured driver 0
[ 3.348] (==) Matched nouveau as autoconfigured driver 1
[ 3.348] (==) Matched modesetting as autoconfigured driver 2
[ 3.348] (==) Matched fbdev as autoconfigured driver 3
[ 3.348] (==) Matched vesa as autoconfigured driver 4
[ 3.348] (==) Assigned the driver to the xf86ConfigLayout
[ 3.348] (II) LoadModule: “nvidia”
[ 3.348] (II) Loading /usr/lib/xorg/modules/drivers/nvidia_drv.so
[ 3.349] (II) Module nvidia: vendor=“NVIDIA Corporation”
[ 3.349] compiled for 4.0.2, module version = 1.0.0
[ 3.349] Module class: X.Org Video Driver
[ 3.349] (II) LoadModule: “nouveau”
[ 3.349] (II) Loading /usr/lib/xorg/modules/drivers/nouveau_drv.so
[ 3.349] (II) Module nouveau: vendor=“X.Org Foundation”
[ 3.349] compiled for 1.19.5, module version = 1.0.15
[ 3.349] ABI class: X.Org Video Driver, version 23.0
[ 3.349] (II) LoadModule: “modesetting”
[ 3.349] (II) Loading /usr/lib/xorg/modules/drivers/modesetting_drv.so
[ 3.349] (II) Module modesetting: vendor=“X.Org Foundation”
[ 3.349] compiled for 1.19.6, module version = 1.19.6
[ 3.349] (II) LoadModule: “fbdev”
[ 3.349] (II) Loading /usr/lib/xorg/modules/drivers/fbdev_drv.so
[ 3.350] (II) Module fbdev: vendor=“X.Org Foundation”
[ 3.350] compiled for 1.19.3, module version = 0.4.4
[ 3.350] Module class: X.Org Video Driver
[ 3.350] ABI class: X.Org Video Driver, version 23.0
[ 3.350] (II) LoadModule: “vesa”
[ 3.350] (II) Loading /usr/lib/xorg/modules/drivers/vesa_drv.so
[ 3.350] (II) Module vesa: vendor=“X.Org Foundation”
[ 3.350] compiled for 1.19.3, module version = 2.3.4
[ 3.350] (II) NVIDIA dlloader X Driver 410.104 Tue Feb 5 23:05:20 CST 2019
[ 3.350] (II) NVIDIA Unified Driver for all Supported NVIDIA GPUs
[ 3.350] (II) NOUVEAU driver Date: Fri Apr 21 14:41:17 2017 -0400
[ 3.350] (II) NOUVEAU driver for NVIDIA chipset families :
[ 3.350] RIVA TNT (NV04)
[ 3.350] RIVA TNT2 (NV05)
[ 3.350] GeForce 256 (NV10)
[ 3.350] GeForce 2 (NV11, NV15)
[ 3.350] GeForce 4MX (NV17, NV18)
[ 3.350] GeForce 3 (NV20)
[ 3.350] GeForce 4Ti (NV25, NV28)
[ 3.350] GeForce FX (NV3x)
[ 3.350] GeForce 6 (NV4x)
[ 3.350] GeForce 7 (G7x)
[ 3.350] GeForce 8 (G8x)
[ 3.350] GeForce GTX 200 (NVA0)
[ 3.350] GeForce GTX 400 (NVC0)
[ 3.350] (II) modesetting: Driver for Modesetting Kernel Drivers: kms
[ 3.350] (II) FBDEV: driver for framebuffer: fbdev
[ 3.350] (II) VESA: driver for VESA chipsets: vesa
[ 3.350] (II) Loading sub module “fb”
[ 3.350] (II) LoadModule: “fb”
[ 3.350] (II) Loading /usr/lib/xorg/modules/libfb.so
[ 3.350] (II) Module fb: vendor=“X.Org Foundation”
[ 3.350] compiled for 1.19.6, module version = 1.0.0
[ 3.350] ABI class: X.Org ANSI C Emulation, version 0.4
[ 3.350] (II) Loading sub module “wfb”
[ 3.350] (II) LoadModule: “wfb”
[ 3.351] (II) Loading /usr/lib/xorg/modules/libwfb.so
[ 3.351] (II) Module wfb: vendor=“X.Org Foundation”
[ 3.351] compiled for 1.19.6, module version = 1.0.0
[ 3.351] ABI class: X.Org ANSI C Emulation, version 0.4
[ 3.351] (II) Loading sub module “ramdac”
[ 3.351] (II) LoadModule: “ramdac”
[ 3.351] (II) Module “ramdac” already built-in
[ 3.353] (EE) NVIDIA: Failed to initialize the NVIDIA kernel module. Please see the
[ 3.353] (EE) NVIDIA: system’s kernel log for additional error messages and
[ 3.353] (EE) NVIDIA: consult the NVIDIA README for details.
[ 3.474] (EE) [drm] Failed to open DRM device for pci:0000:01:00.0: -19
[ 3.474] (EE) open /dev/dri/card0: No such file or directory
[ 3.474] (WW) Falling back to old probe method for modesetting
[ 3.474] (II) Loading sub module “fbdevhw”
[ 3.474] (II) LoadModule: “fbdevhw”
[ 3.474] (II) Loading /usr/lib/xorg/modules/libfbdevhw.so
[ 3.474] (II) Module fbdevhw: vendor=“X.Org Foundation”
[ 3.474] compiled for 1.19.6, module version = 0.0.2
[ 3.474] ABI class: X.Org Video Driver, version 23.0
[ 3.474] () FBDEV(1): claimed PCI slot 1@0:0:0
[ 3.474] (II) FBDEV(1): using default device
[ 3.474] (WW) Falling back to old probe method for vesa
[ 3.474] (EE) Screen 0 deleted because of no matching config section.
[ 3.474] (II) UnloadModule: “modesetting”
[ 3.474] (II) FBDEV(0): Creating default Display subsection in Screen section
“Default Screen Section” for depth/fbbpp 24/32
[ 3.474] (==) FBDEV(0): Depth 24, (==) framebuffer bpp 32
[ 3.474] (==) FBDEV(0): RGB weight 888
[ 3.474] (==) FBDEV(0): Default visual is TrueColor
[ 3.474] (==) FBDEV(0): Using gamma correction (1.0, 1.0, 1.0)
[ 3.474] (II) FBDEV(0): hardware: EFI VGA (video memory: 8640kB)
[ 3.474] (II) FBDEV(0): checking modes against framebuffer device…
[ 3.474] (II) FBDEV(0): checking modes against monitor…
[ 3.474] (–) FBDEV(0): Virtual size is 1920x1080 (pitch 1920)
[ 3.474] () FBDEV(0): Built-in mode “current”: 207.4 MHz, 85.3 kHz, 77.2 Hz
[ 3.474] (II) FBDEV(0): Modeline "current"x0.0 207.38 1920 1952 2192 2432 1080 1084 1088 1104 -hsync -vsync -csync (85.3 kHz b)
[ 3.474] (==) FBDEV(0): DPI set to (96, 96)
[ 3.474] (II) Loading sub module “fb”
[ 3.474] (II) LoadModule: “fb”
[ 3.474] (II) Loading /usr/lib/xorg/modules/libfb.so
[ 3.474] (II) Module fb: vendor=“X.Org Foundation”
[ 3.474] compiled for 1.19.6, module version = 1.0.0
[ 3.474] ABI class: X.Org ANSI C Emulation, version 0.4
[ 3.474] () FBDEV(0): using shadow framebuffer
[ 3.474] (II) Loading sub module “shadow”
[ 3.474] (II) LoadModule: “shadow”
[ 3.474] (II) Loading /usr/lib/xorg/modules/libshadow.so
[ 3.474] (II) Module shadow: vendor=“X.Org Foundation”
[ 3.474] compiled for 1.19.6, module version = 1.1.0
[ 3.474] (II) UnloadModule: “vesa”
[ 3.474] (II) Unloading vesa
[ 3.474] (==) Depth 24 pixmap format is 32 bpp
[ 3.474] (II) FBDEV(0): FBIOBLANK: Invalid argument (Screen blanking not supported by kernel - disabling)
[ 3.475] (==) FBDEV(0): Backing store enabled
[ 3.476] (==) FBDEV(0): DPMS enabled
[ 3.476] (==) RandR enabled
[ 3.478] (II) SELinux: Disabled on system
[ 3.479] (II) AIGLX: Screen 0 is not DRI2 capable
[ 3.479] (EE) AIGLX: reverting to software rendering
[ 3.507] (II) IGLX: enabled GLX_MESA_copy_sub_buffer
[ 3.507] (II) IGLX: Loaded and initialized swrast
[ 3.507] (II) GLX: Initialized DRISWRAST GL provider for screen 0
[ 3.527] (II) config/udev: Adding input device Video Bus (/dev/input/event3)
[ 3.527] () Video Bus: Applying InputClass “evdev keyboard catchall”
[ 3.527] (II) LoadModule: “evdev”
[ 3.527] (II) Loading /usr/lib/xorg/modules/input/evdev_drv.so
[ 3.528] (II) Module evdev: vendor=“X.Org Foundation”
[ 3.528] compiled for 1.19.3, module version = 2.10.5
[ 3.528] Module class: X.Org XInput Driver
[ 3.528] ABI class: X.Org XInput driver, version 24.1
[ 3.528] (II) Using input driver ‘evdev’ for ‘Video Bus’
[ 3.528] () Video Bus: always reports core events
[ 3.528] () evdev: Video Bus: Device: “/dev/input/event3”
[ 3.528] (–) evdev: Video Bus: Vendor 0 Product 0x6
[ 3.528] (–) evdev: Video Bus: Found keys
[ 3.528] (II) evdev: Video Bus: Configuring as keyboard
[ 3.528] () Option “config_info” “udev:/sys/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/device:00/LNXVIDEO:00/input/input3/event3”
[ 3.528] (II) XINPUT: Adding extended input device “Video Bus” (type: KEYBOARD, id 6)
[ 3.528] () Option “xkb_rules” “evdev”
[ 3.528] () Option “xkb_model” “pc105”
[ 3.528] () Option “xkb_layout” “us”
[ 3.528] (II) config/udev: Adding input device Power Button (/dev/input/event1)
[ 3.528] () Power Button: Applying InputClass “evdev keyboard catchall”
[ 3.528] (II) Using input driver ‘evdev’ for ‘Power Button’
[ 3.528] () Power Button: always reports core events
[ 3.528] () evdev: Power Button: Device: “/dev/input/event1”
[ 3.528] (–) evdev: Power Button: Vendor 0 Product 0x1
[ 3.528] (–) evdev: Power Button: Found keys
[ 3.528] (II) evdev: Power Button: Configuring as keyboard
[ 3.528] () Option “config_info” “udev:/sys/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0C:00/input/input1/event1”
[ 3.528] (II) XINPUT: Adding extended input device “Power Button” (type: KEYBOARD, id 7)
[ 3.528] (II) config/udev: Adding input device Lid Switch (/dev/input/event0)
[ 3.528] (II) No input driver specified, ignoring this device.
[ 3.528] (II) This device may have been added with another device file.
[ 3.529] (II) config/udev: Adding input device Logitech USB Optical Mouse (/dev/input/event4)
[ 3.529] () Logitech USB Optical Mouse: Applying InputClass “evdev pointer catchall”
[ 3.529] (II) Using input driver ‘evdev’ for ‘Logitech USB Optical Mouse’
[ 3.529] () Logitech USB Optical Mouse: always reports core events
[ 3.529] () evdev: Logitech USB Optical Mouse: Device: “/dev/input/event4”
[ 3.529] (–) evdev: Logitech USB Optical Mouse: Vendor 0x46d Product 0xc077
[ 3.529] (–) evdev: Logitech USB Optical Mouse: Found 12 mouse buttons
[ 3.529] (–) evdev: Logitech USB Optical Mouse: Found scroll wheel(s)
[ 3.529] (–) evdev: Logitech USB Optical Mouse: Found relative axes
[ 3.529] (–) evdev: Logitech USB Optical Mouse: Found x and y relative axes
[ 3.529] (II) evdev: Logitech USB Optical Mouse: Configuring as mouse
[ 3.529] (II) evdev: Logitech USB Optical Mouse: Adding scrollwheel support
[ 3.529] () evdev: Logitech USB Optical Mouse: YAxisMapping: buttons 4 and 5
[ 3.529] () evdev: Logitech USB Optical Mouse: EmulateWheelButton: 4, EmulateWheelInertia: 10, EmulateWheelTimeout: 200
[ 3.529] () Option “config_info” “udev:/sys/devices/pci0000:00/0000:00:14.0/usb1/1-2/1-2:1.0/0003:046D:C077.0001/input/input4/event4”
[ 3.529] (II) XINPUT: Adding extended input device “Logitech USB Optical Mouse” (type: MOUSE, id 8)
[ 3.529] (II) evdev: Logitech USB Optical Mouse: initialized for relative axes.
[ 3.529] () Logitech USB Optical Mouse: (accel) keeping acceleration scheme 1
[ 3.529] () Logitech USB Optical Mouse: (accel) acceleration profile 0
[ 3.529] () Logitech USB Optical Mouse: (accel) acceleration factor: 2.000
[ 3.529] () Logitech USB Optical Mouse: (accel) acceleration threshold: 4
[ 3.529] (II) config/udev: Adding input device Logitech USB Optical Mouse (/dev/input/mouse0)
[ 3.529] (II) No input driver specified, ignoring this device.
[ 3.529] (II) This device may have been added with another device file.
[ 3.529] (II) config/udev: Adding input device Integrated Camera: Integrated C (/dev/input/event7)
[ 3.529] () Integrated Camera: Integrated C: Applying InputClass “evdev keyboard catchall”
[ 3.529] (II) Using input driver ‘evdev’ for ‘Integrated Camera: Integrated C’
[ 3.529] () Integrated Camera: Integrated C: always reports core events
[ 3.529] () evdev: Integrated Camera: Integrated C: Device: “/dev/input/event7”
[ 3.529] (–) evdev: Integrated Camera: Integrated C: Vendor 0x4ca Product 0x7070
[ 3.529] (–) evdev: Integrated Camera: Integrated C: Found keys
[ 3.529] (II) evdev: Integrated Camera: Integrated C: Configuring as keyboard
[ 3.529] () Option “config_info” “udev:/sys/devices/pci0000:00/0000:00:14.0/usb1/1-6/1-6:1.0/input/input7/event7”
[ 3.529] (II) XINPUT: Adding extended input device “Integrated Camera: Integrated C” (type: KEYBOARD, id 9)
[ 3.529] () Option “xkb_rules” “evdev”
[ 3.530] () Option “xkb_model” “pc105”
[ 3.530] () Option “xkb_layout” “us”
[ 3.530] (II) config/udev: Adding input device ITE Tech. Inc. ITE Device(8910) (/dev/input/event5)
[ 3.530] () ITE Tech. Inc. ITE Device(8910): Applying InputClass “evdev keyboard catchall”
[ 3.530] (II) Using input driver ‘evdev’ for ‘ITE Tech. Inc. ITE Device(8910)’
[ 3.530] () ITE Tech. Inc. ITE Device(8910): always reports core events
[ 3.530] () evdev: ITE Tech. Inc. ITE Device(8910): Device: “/dev/input/event5”
[ 3.530] (–) evdev: ITE Tech. Inc. ITE Device(8910): Vendor 0x48d Product 0xc100
[ 3.530] (–) evdev: ITE Tech. Inc. ITE Device(8910): Found 1 mouse buttons
[ 3.530] (–) evdev: ITE Tech. Inc. ITE Device(8910): Found scroll wheel(s)
[ 3.530] (–) evdev: ITE Tech. Inc. ITE Device(8910): Found relative axes
[ 3.530] (II) evdev: ITE Tech. Inc. ITE Device(8910): Forcing relative x/y axes to exist.
[ 3.530] (–) evdev: ITE Tech. Inc. ITE Device(8910): Found absolute axes
[ 3.530] (II) evdev: ITE Tech. Inc. ITE Device(8910): Forcing absolute x/y axes to exist.
[ 3.530] (–) evdev: ITE Tech. Inc. ITE Device(8910): Found keys
[ 3.530] (II) evdev: ITE Tech. Inc. ITE Device(8910): Configuring as mouse
[ 3.530] (II) evdev: ITE Tech. Inc. ITE Device(8910): Configuring as keyboard
[ 3.530] (II) evdev: ITE Tech. Inc. ITE Device(8910): Adding scrollwheel support
[ 3.530] () evdev: ITE Tech. Inc. ITE Device(8910): YAxisMapping: buttons 4 and 5
[ 3.530] () evdev: ITE Tech. Inc. ITE Device(8910): EmulateWheelButton: 4, EmulateWheelInertia: 10, EmulateWheelTimeout: 200
[ 3.530] () Option “config_info” “udev:/sys/devices/pci0000:00/0000:00:14.0/usb1/1-9/1-9:1.0/0003:048D:C100.0002/input/input5/event5”
[ 3.530] (II) XINPUT: Adding extended input device “ITE Tech. Inc. ITE Device(8910)” (type: KEYBOARD, id 10)
[ 3.530] () Option “xkb_rules” “evdev”
[ 3.530] (II) evdev: ITE Tech. Inc. ITE Device(8910): initialized for relative axes.
[ 3.530] (WW) evdev: ITE Tech. Inc. ITE Device(8910): ignoring absolute axes.
[ 3.530] () ITE Tech. Inc. ITE Device(8910): (accel) keeping acceleration scheme 1
[ 3.530] () ITE Tech. Inc. ITE Device(8910): (accel) acceleration profile 0
[ 3.530] () ITE Tech. Inc. ITE Device(8910): (accel) acceleration factor: 2.000
[ 3.530] () ITE Tech. Inc. ITE Device(8910): (accel) acceleration threshold: 4
[ 3.530] (II) config/udev: Adding input device MSFT0001:01 04F3:309E Touchpad (/dev/input/event10)
[ 3.530] () MSFT0001:01 04F3:309E Touchpad: Applying InputClass “evdev touchpad catchall”
[ 3.530] () MSFT0001:01 04F3:309E Touchpad: Applying InputClass “evdev touchscreen catchall”
[ 3.530] () MSFT0001:01 04F3:309E Touchpad: Applying InputClass “touchpad catchall”
[ 3.530] () MSFT0001:01 04F3:309E Touchpad: Applying InputClass “Default clickpad buttons”
[ 3.530] (II) LoadModule: “synaptics”
[ 3.531] (II) Loading /usr/lib/xorg/modules/input/synaptics_drv.so
[ 3.531] (II) Module synaptics: vendor=“X.Org Foundation”
[ 3.531] compiled for 1.19.3, module version = 1.9.0
[ 3.531] Module class: X.Org XInput Driver
[ 3.531] ABI class: X.Org XInput driver, version 24.1
[ 3.531] (II) Using input driver ‘synaptics’ for ‘MSFT0001:01 04F3:309E Touchpad’
[ 3.531] () MSFT0001:01 04F3:309E Touchpad: always reports core events
[ 3.531] () Option “Device” “/dev/input/event10”
[ 3.576] (–) synaptics: MSFT0001:01 04F3:309E Touchpad: x-axis range 0 - 3075 (res 32)
[ 3.576] (–) synaptics: MSFT0001:01 04F3:309E Touchpad: y-axis range 0 - 1503 (res 31)
[ 3.576] (II) synaptics: MSFT0001:01 04F3:309E Touchpad: device does not report pressure, will use touch data.
[ 3.576] (II) synaptics: MSFT0001:01 04F3:309E Touchpad: device does not report finger width.
[ 3.576] (–) synaptics: MSFT0001:01 04F3:309E Touchpad: buttons: left right double triple
[ 3.576] (–) synaptics: MSFT0001:01 04F3:309E Touchpad: Vendor 0x4f3 Product 0x309e
[ 3.576] (–) synaptics: MSFT0001:01 04F3:309E Touchpad: invalid pressure range. defaulting to 0 - 255
[ 3.576] (–) synaptics: MSFT0001:01 04F3:309E Touchpad: invalid finger width range. defaulting to 0 - 15
[ 3.576] (–) synaptics: MSFT0001:01 04F3:309E Touchpad: touchpad found
[ 3.576] () MSFT0001:01 04F3:309E Touchpad: always reports core events
[ 3.628] () Option “config_info” “udev:/sys/devices/pci0000:00/0000:00:15.1/i2c_designware.1/i2c-1/i2c-MSFT0001:01/0018:04F3:309E.0003/input/input12/event10”
[ 3.628] (II) XINPUT: Adding extended input device “MSFT0001:01 04F3:309E Touchpad” (type: TOUCHPAD, id 11)
[ 3.628] () synaptics: MSFT0001:01 04F3:309E Touchpad: (accel) MinSpeed is now constant deceleration 2.5
[ 3.628] () synaptics: MSFT0001:01 04F3:309E Touchpad: (accel) MaxSpeed is now 1.75
[ 3.628] () synaptics: MSFT0001:01 04F3:309E Touchpad: (accel) AccelFactor is now 0.058
[ 3.628] () MSFT0001:01 04F3:309E Touchpad: (accel) keeping acceleration scheme 1
[ 3.628] () MSFT0001:01 04F3:309E Touchpad: (accel) acceleration profile 1
[ 3.628] () MSFT0001:01 04F3:309E Touchpad: (accel) acceleration factor: 2.000
[ 3.628] () MSFT0001:01 04F3:309E Touchpad: (accel) acceleration threshold: 4
[ 3.628] (–) synaptics: MSFT0001:01 04F3:309E Touchpad: touchpad found
[ 3.628] (II) config/udev: Adding input device MSFT0001:01 04F3:309E Touchpad (/dev/input/mouse1)
[ 3.628] () MSFT0001:01 04F3:309E Touchpad: Ignoring device from InputClass “touchpad ignore duplicates”
[ 3.629] (II) config/udev: Adding input device Ideapad extra buttons (/dev/input/event6)
[ 3.629] () Ideapad extra buttons: Applying InputClass “evdev keyboard catchall”
[ 3.629] (II) Using input driver ‘evdev’ for ‘Ideapad extra buttons’
[ 3.629] () Ideapad extra buttons: always reports core events
[ 3.629] () evdev: Ideapad extra buttons: Device: “/dev/input/event6”
[ 3.629] (–) evdev: Ideapad extra buttons: Vendor 0 Product 0
[ 3.629] (–) evdev: Ideapad extra buttons: Found keys
[ 3.629] (II) evdev: Ideapad extra buttons: Configuring as keyboard
[ 3.629] () Option “config_info” “udev:/sys/devices/pci0000:00/0000:00:1f.0/PNP0C09:00/VPC2004:00/input/input6/event6”
[ 3.629] (II) XINPUT: Adding extended input device “Ideapad extra buttons” (type: KEYBOARD, id 12)
[ 3.629] () Option “xkb_rules” “evdev”
[ 3.629] () Option “xkb_model” “pc105”
[ 3.629] () Option “xkb_layout” “us”
[ 3.629] (II) config/udev: Adding input device HDA Intel PCH Mic (/dev/input/event8)
[ 3.629] (II) No input driver specified, ignoring this device.
[ 3.629] (II) This device may have been added with another device file.
[ 3.629] (II) config/udev: Adding input device HDA Intel PCH Headphone (/dev/input/event9)
[ 3.629] (II) config/udev: Adding input device AT Translated Set 2 keyboard (/dev/input/event2)
[ 3.629] () AT Translated Set 2 keyboard: Applying InputClass “evdev keyboard catchall”
[ 3.629] (II) Using input driver ‘evdev’ for ‘AT Translated Set 2 keyboard’
[ 3.629] () AT Translated Set 2 keyboard: always reports core events
[ 3.629] () evdev: AT Translated Set 2 keyboard: Device: “/dev/input/event2”
[ 3.629] (–) evdev: AT Translated Set 2 keyboard: Vendor 0x1 Product 0x1
[ 3.629] (–) evdev: AT Translated Set 2 keyboard: Found keys
[ 3.629] (II) evdev: AT Translated Set 2 keyboard: Configuring as keyboard
[ 3.629] () Option “config_info” “udev:/sys/devices/platform/i8042/serio0/input/input2/event2”
[ 3.629] (II) XINPUT: Adding extended input device “AT Translated Set 2 keyboard” (type: KEYBOARD, id 13)
[ 3.630] () Option “xkb_rules” “evdev”
[ 3.630] () Option “xkb_model” “pc105”
[ 3.630] (**) Option “xkb_layout” “us”
[ 3.793] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=8 (/dev/input/event13)
[ 3.793] (II) No input driver specified, ignoring this device.
[ 3.793] (II) This device may have been added with another device file.
[ 3.806] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=7 (/dev/input/event12)
[ 3.806] (II) No input driver specified, ignoring this device.
[ 3.806] (II) This device may have been added with another device file.
[ 3.814] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=3 (/dev/input/event11)
[ 3.814] (II) No input driver specified, ignoring this device.
[ 3.814] (II) This device may have been added with another device file.
*** /usr/share/X11/xorg.conf.d/10-amdgpu.conf
*** ls: -rw-r–r-- 1 root root 92 2018-06-14 17:23:33.000000000 +0300 /usr/share/X11/xorg.conf.d/10-amdgpu.conf
Section “OutputClass”
Identifier “AMDgpu”
MatchDriver “amdgpu”
Driver “amdgpu”
EndSection
*** /usr/share/X11/xorg.conf.d/10-evdev.conf
*** ls: -rw-r–r-- 1 root root 1099 2017-07-07 00:11:07.000000000 +0300 /usr/share/X11/xorg.conf.d/10-evdev.conf
Catch-all evdev loader for udev-based systems
We don’t simply match on any device since that also adds accelerometers
and other devices that we don’t really want to use. The list below
matches everything but joysticks.
Section “InputClass”
Identifier “evdev pointer catchall”
MatchIsPointer “on”
MatchDevicePath “/dev/input/event*”
Driver “evdev”
EndSection
Identifier “evdev keyboard catchall”
MatchIsKeyboard “on”
Driver “evdev”
EndSection
Identifier “evdev touchpad catchall”
MatchIsTouchpad “on”
Driver “evdev”
EndSection
Identifier “evdev tablet catchall”
MatchIsTablet “on”
Driver “evdev”
EndSection
Identifier “evdev touchscreen catchall”
MatchIsTouchscreen “on”
Driver “evdev”
EndSection
*** /usr/share/X11/xorg.conf.d/10-quirks.conf
*** ls: -rw-r–r-- 1 root root 1350 2018-10-25 19:23:41.000000000 +0300 /usr/share/X11/xorg.conf.d/10-quirks.conf
Collection of quirks and blacklist/whitelists for specific devices.
Accelerometer device, posts data through ABS_X/ABS_Y, making X unusable
22442 – ThinkPad HDAPS accelerometer gets recognized as MOUSE and makes Xorg unusable
Identifier “ThinkPad HDAPS accelerometer blacklist”
MatchProduct “ThinkPad HDAPS accelerometer data”
Option “Ignore” “on”
EndSection
523914 – Mouse does not move in PV Xen guest under RHEL-5.4
Explicitly tell evdev to not ignore the absolute axes.
Identifier “Xen Virtual Pointer axis blacklist”
MatchProduct “Xen Virtual Pointer”
Option “IgnoreAbsoluteAxes” “off”
Option “IgnoreRelativeAxes” “off”
EndSection
55867 – Doesn't know how to tag XI_TRACKBALL
Bug 55867 - Doesn’t know how to tag XI_TRACKBALL
Identifier “Tag trackballs as XI_TRACKBALL”
MatchProduct “trackball”
MatchDriver “evdev”
Option “TypeName” “TRACKBALL”
EndSection
62831 – Mionix Naos 5000 mouse detected incorrectly
Bug 62831 - Mionix Naos 5000 mouse detected incorrectly
Identifier “Tag Mionix Naos 5000 mouse XI_MOUSE”
MatchProduct “La-VIEW Technology Naos 5000 Mouse”
MatchDriver “evdev”
Option “TypeName” “MOUSE”
EndSection
*** /usr/share/X11/xorg.conf.d/10-radeon.conf
*** ls: -rw-r–r-- 1 root root 92 2018-06-14 17:16:01.000000000 +0300 /usr/share/X11/xorg.conf.d/10-radeon.conf
Identifier “Radeon”
MatchDriver “radeon”
Driver “radeon”
EndSection
*** /usr/share/X11/xorg.conf.d/11-evdev-quirks.conf
*** ls: -rw-r–r-- 1 root root 590 2017-07-07 00:10:42.000000000 +0300 /usr/share/X11/xorg.conf.d/11-evdev-quirks.conf
Identifier “Avago Technologies mouse quirks (LP: #746639)”
MatchIsPointer “on”
Driver “evdev”
MatchUSBID “192f:0416”
Option “Emulate3Buttons” “True”
Option “Emulate3Timeout” “50”
EndSection
X/Y axis not working due to device reporting absolute axes
Bug #325581 “kensington pocket mouse model #72237 USB 0d62:1000 ...” : Bugs : xserver-xorg-input-evdev package : Ubuntu
32882 – kensington pocket mouse model #72237 USB 0d62:1000 not working
Identifier “Benq m310”
MatchProduct “HID 0d62:1000”
Driver “evdev”
Option “IgnoreAbsoluteAxes” “true”
EndSection
*** /usr/share/X11/xorg.conf.d/11-evdev-trackpoint.conf
*** ls: -rw-r–r-- 1 root root 364 2017-07-07 00:10:42.000000000 +0300 /usr/share/X11/xorg.conf.d/11-evdev-trackpoint.conf
trackpoint users want wheel emulation
Identifier “trackpoint catchall”
MatchIsPointer “true”
MatchProduct “TrackPoint|DualPoint Stick”
Option “Emulate3Buttons” “true”
Option “EmulateWheel” “true”
Option “EmulateWheelButton” “2”
Option “XAxisMapping” “6 7”
Option “YAxisMapping” “4 5”
EndSection
*** /usr/share/X11/xorg.conf.d/51-synaptics-quirks.conf
*** ls: -rw-r–r-- 1 root root 590 2017-07-07 00:10:21.000000000 +0300 /usr/share/X11/xorg.conf.d/51-synaptics-quirks.conf
Identifier “Dell Inspiron embedded buttons quirks”
MatchTag “inspiron_1011|inspiron_1012”
MatchDevicePath
