I did not use ppa. I have just executed .run file downloaded from nvidia site.
Please find below the bug report:
Start of NVIDIA bug report log file. Please include this file, along
with a detailed description of your problem, when reporting a graphics
driver bug via the NVIDIA Linux forum (see devtalk.nvidia.com)
or by sending email to ‘linux-bugs@nvidia.com’.
nvidia-bug-report.sh Version: 23805530
Date: Thu Jul 12 13:34:49 CET 2018
uname: Linux Lenovo-Home 4.15.0-24-generic #26~16.04.1-Ubuntu SMP Fri Jun 15 14:35:08 UTC 2018 x86_64 x86_64 x86_64 GNU/Linux
command line flags:
*** /etc/issue
*** ls: -rw-r–r-- 1 root root 26 2018-02-20 09:44:08.000000000 +0100 /etc/issue
Ubuntu 16.04.4 LTS \n \l
*** /etc/debian_version
*** ls: -rw-r–r-- 1 root root 12 2015-04-30 11:00:00.000000000 +0100 /etc/debian_version
stretch/sid
*** /var/log/nvidia-installer.log
*** ls: -rw-r–r-- 1 root root 27227 2018-07-10 06:57:53.259626960 +0100 /var/log/nvidia-installer.log
nvidia-installer log file ‘/var/log/nvidia-installer.log’
creation time: Tue Jul 10 06:56:42 2018
installer version: 390.59
PATH: /usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/snap/bin
nvidia-installer command line:
./nvidia-installer
Unable to load: nvidia-installer ncurses v6 user interface
Using: nvidia-installer ncurses user interface
→ Detected 8 CPUs online; setting concurrency level to 8.
→ Installing NVIDIA driver version 390.59.
→ There appears to already be a driver installed on your system (version: 390.67). As part of installing this driver (version: 390.59), the existing driver will be uninstalled. Are you sure you want to continue? (Answer: Continue installation)
→ Running distribution scripts
executing: ‘/usr/lib/nvidia/pre-install’…
→ done.
→ The distribution-provided pre-install script failed! Are you sure you want to continue? (Answer: Continue installation)
→ Would you like to register the kernel module sources with DKMS? This will allow DKMS to automatically build a new module, if you install a different kernel later. (Answer: No)
→ Performing CC sanity check with CC=“/usr/bin/cc”.
→ Kernel source path: ‘/lib/modules/4.15.0-24-generic/build’
→ Kernel output path: ‘/lib/modules/4.15.0-24-generic/build’
→ Performing Compiler check.
→ Performing Dom0 check.
→ Performing Xen check.
→ Performing PREEMPT_RT check.
→ Performing vgpu_kvm check.
→ Cleaning kernel module build directory.
executing: ‘cd ./kernel; /usr/bin/make -k -j8 clean NV_EXCLUDE_KERNEL_MODULES=“” SYSSRC=“/lib/modules/4.15.0-24-generic/build” SYSOUT=“/lib/modules/4.15.0-24-generic/build”’…
rm -f -r conftest
make[1]: Entering directory ‘/usr/src/linux-headers-4.15.0-24-generic’
make[1]: Leaving directory ‘/usr/src/linux-headers-4.15.0-24-generic’
→ Building kernel modules
executing: ‘cd ./kernel; /usr/bin/make -k -j8 NV_EXCLUDE_KERNEL_MODULES=“” SYSSRC=“/lib/modules/4.15.0-24-generic/build” SYSOUT=“/lib/modules/4.15.0-24-generic/build”’…
SYMLINK /tmp/selfgz2705/NVIDIA-Linux-x86_64-390.59/kernel/nvidia/nv-kernel.o
SYMLINK /tmp/selfgz2705/NVIDIA-Linux-x86_64-390.59/kernel/nvidia-modeset/nv-modeset-kernel.o
CONFTEST: INIT_WORK
CONFTEST: remap_pfn_range
CONFTEST: hash__remap_4k_pfn
CONFTEST: follow_pfn
CONFTEST: set_pages_uc
CONFTEST: set_memory_uc
CONFTEST: set_memory_array_uc
CONFTEST: vmap
CONFTEST: change_page_attr
CONFTEST: pci_get_class
CONFTEST: pci_choose_state
CONFTEST: vm_insert_page
CONFTEST: acpi_device_id
CONFTEST: acquire_console_sem
CONFTEST: kmem_cache_create
CONFTEST: console_lock
CONFTEST: on_each_cpu
CONFTEST: smp_call_function
CONFTEST: acpi_evaluate_integer
CONFTEST: ioremap_cache
CONFTEST: ioremap_wc
CONFTEST: pci_dma_mapping_error
CONFTEST: acpi_walk_namespace
CONFTEST: pci_domain_nr
CONFTEST: sg_alloc_table
CONFTEST: sg_init_table
CONFTEST: pci_get_domain_bus_and_slot
CONFTEST: get_num_physpages
CONFTEST: efi_enabled
CONFTEST: proc_create_data
CONFTEST: pde_data
CONFTEST: proc_remove
CONFTEST: pm_vt_switch_required
CONFTEST: xen_ioemu_inject_msi
CONFTEST: phys_to_dma
CONFTEST: get_dma_ops
CONFTEST: of_get_property
CONFTEST: write_cr4
CONFTEST: of_find_node_by_phandle
CONFTEST: of_node_to_nid
CONFTEST: pnv_pci_get_npu_dev
CONFTEST: for_each_online_node
CONFTEST: node_end_pfn
CONFTEST: pci_bus_address
CONFTEST: pci_stop_and_remove_bus_device
CONFTEST: pci_remove_bus_device
CONFTEST: request_threaded_irq
CONFTEST: register_cpu_notifier
CONFTEST: cpuhp_setup_state
CONFTEST: dma_map_resource
CONFTEST: backlight_device_register
CONFTEST: register_acpi_notifier
CONFTEST: timer_setup
CONFTEST: remap_page_range
CONFTEST: address_space_init_once
CONFTEST: kbasename
CONFTEST: fatal_signal_pending
CONFTEST: list_cut_position
CONFTEST: vzalloc
CONFTEST: wait_on_bit_lock_argument_count
CONFTEST: usleep_range
CONFTEST: bitmap_clear
CONFTEST: radix_tree_empty
CONFTEST: radix_tree_replace_slot
CONFTEST: drm_dev_unref
CONFTEST: drm_reinit_primary_mode_group
CONFTEST: drm_atomic_set_mode_for_crtc
CONFTEST: get_user_pages_remote
CONFTEST: drm_atomic_clean_old_fb
CONFTEST: drm_gem_object_lookup
CONFTEST: drm_atomic_state_free
CONFTEST: drm_driver_has_gem_prime_res_obj
CONFTEST: drm_atomic_helper_disable_all
CONFTEST: drm_atomic_helper_set_config
CONFTEST: drm_atomic_helper_connector_dpms
CONFTEST: is_export_symbol_gpl_of_node_to_nid
CONFTEST: is_export_symbol_present_swiotlb_map_sg_attrs
CONFTEST: i2c_adapter
CONFTEST: pm_message_t
CONFTEST: irq_handler_t
CONFTEST: acpi_device_ops
CONFTEST: acpi_op_remove
CONFTEST: outer_flush_all
CONFTEST: proc_dir_entry
CONFTEST: scatterlist
CONFTEST: sg_table
CONFTEST: file_operations
CONFTEST: vm_operations_struct
CONFTEST: atomic_long_type
CONFTEST: pci_save_state
CONFTEST: file_inode
CONFTEST: task_struct
CONFTEST: kuid_t
CONFTEST: dma_ops
CONFTEST: dma_map_ops
CONFTEST: noncoherent_swiotlb_dma_ops
CONFTEST: vm_fault_present
CONFTEST: vm_fault_has_address
CONFTEST: kernel_write
CONFTEST: strnstr
CONFTEST: iterate_dir
CONFTEST: kstrtoull
CONFTEST: backlight_properties_type
CONFTEST: fault_flags
CONFTEST: atomic64_type
CONFTEST: backing_dev_info
CONFTEST: mm_context_t
CONFTEST: vm_ops_fault_removed_vma_arg
CONFTEST: pnv_npu2_init_context
CONFTEST: drm_bus_present
CONFTEST: drm_bus_has_bus_type
CONFTEST: drm_bus_has_get_irq
CONFTEST: drm_bus_has_get_name
CONFTEST: drm_driver_has_legacy_dev_list
CONFTEST: drm_driver_has_set_busid
CONFTEST: drm_crtc_state_has_connectors_changed
CONFTEST: drm_init_function_args
CONFTEST: drm_mode_connector_list_update_has_merge_type_bits_arg
CONFTEST: drm_helper_mode_fill_fb_struct
CONFTEST: drm_master_drop_has_from_release_arg
CONFTEST: drm_driver_unload_has_int_return_type
CONFTEST: kref_has_refcount_of_type_refcount_t
CONFTEST: drm_atomic_helper_crtc_destroy_state_has_crtc_arg
CONFTEST: drm_crtc_helper_funcs_has_atomic_enable
CONFTEST: drm_old_atomic_state_iterators_present
CONFTEST: drm_mode_object_find_has_file_priv_arg
CONFTEST: dom0_kernel_present
CONFTEST: nvidia_vgpu_kvm_build
CONFTEST: nvidia_grid_build
CONFTEST: drm_atomic_available
CONFTEST: drm_available
CONFTEST: drm_atomic_modeset_nonblocking_commit_available
CONFTEST: is_export_symbol_gpl_refcount_inc
CONFTEST: is_export_symbol_gpl_refcount_dec_and_test
CC [M] /tmp/selfgz2705/NVIDIA-Linux-x86_64-390.59/kernel/nvidia/nv-frontend.o
CC [M] /tmp/selfgz2705/NVIDIA-Linux-x86_64-390.59/kernel/nvidia/nv-instance.o
CC [M] /tmp/selfgz2705/NVIDIA-Linux-x86_64-390.59/kernel/nvidia/nv-gpu-numa.o
CC [M] /tmp/selfgz2705/NVIDIA-Linux-x86_64-390.59/kernel/nvidia/nv.o
CC [M] /tmp/selfgz2705/NVIDIA-Linux-x86_64-390.59/kernel/nvidia/nv-acpi.o
CC [M] /tmp/selfgz2705/NVIDIA-Linux-x86_64-390.59/kernel/nvidia/nv-chrdev.o
CC [M] /tmp/selfgz2705/NVIDIA-Linux-x86_64-390.59/kernel/nvidia/nv-cray.o
CC [M] /tmp/selfgz2705/NVIDIA-Linux-x86_64-390.59/kernel/nvidia/nv-dma.o
CC [M] /tmp/selfgz2705/NVIDIA-Linux-x86_64-390.59/kernel/nvidia/nv-gvi.o
CC [M] /tmp/selfgz2705/NVIDIA-Linux-x86_64-390.59/kernel/nvidia/nv-i2c.o
CC [M] /tmp/selfgz2705/NVIDIA-Linux-x86_64-390.59/kernel/nvidia/nv-mempool.o
CC [M] /tmp/selfgz2705/NVIDIA-Linux-x86_64-390.59/kernel/nvidia/nv-mmap.o
CC [M] /tmp/selfgz2705/NVIDIA-Linux-x86_64-390.59/kernel/nvidia/nv-p2p.o
CC [M] /tmp/selfgz2705/NVIDIA-Linux-x86_64-390.59/kernel/nvidia/nv-pat.o
CC [M] /tmp/selfgz2705/NVIDIA-Linux-x86_64-390.59/kernel/nvidia/nv-procfs.o
CC [M] /tmp/selfgz2705/NVIDIA-Linux-x86_64-390.59/kernel/nvidia/nv-usermap.o
CC [M] /tmp/selfgz2705/NVIDIA-Linux-x86_64-390.59/kernel/nvidia/nv-vm.o
CC [M] /tmp/selfgz2705/NVIDIA-Linux-x86_64-390.59/kernel/nvidia/nv-vtophys.o
CC [M] /tmp/selfgz2705/NVIDIA-Linux-x86_64-390.59/kernel/nvidia/os-interface.o
CC [M] /tmp/selfgz2705/NVIDIA-Linux-x86_64-390.59/kernel/nvidia/os-mlock.o
CC [M] /tmp/selfgz2705/NVIDIA-Linux-x86_64-390.59/kernel/nvidia/os-pci.o
CC [M] /tmp/selfgz2705/NVIDIA-Linux-x86_64-390.59/kernel/nvidia/os-registry.o
CC [M] /tmp/selfgz2705/NVIDIA-Linux-x86_64-390.59/kernel/nvidia/os-usermap.o
CC [M] /tmp/selfgz2705/NVIDIA-Linux-x86_64-390.59/kernel/nvidia/nv-modeset-interface.o
CC [M] /tmp/selfgz2705/NVIDIA-Linux-x86_64-390.59/kernel/nvidia/nv-pci-table.o
CC [M] /tmp/selfgz2705/NVIDIA-Linux-x86_64-390.59/kernel/nvidia/nv-kthread-q.o
CC [M] /tmp/selfgz2705/NVIDIA-Linux-x86_64-390.59/kernel/nvidia/nv-kthread-q-selftest.o
CC [M] /tmp/selfgz2705/NVIDIA-Linux-x86_64-390.59/kernel/nvidia/nv-memdbg.o
CC [M] /tmp/selfgz2705/NVIDIA-Linux-x86_64-390.59/kernel/nvidia/nv-ibmnpu.o
CC [M] /tmp/selfgz2705/NVIDIA-Linux-x86_64-390.59/kernel/nvidia/nv-report-err.o
CC [M] /tmp/selfgz2705/NVIDIA-Linux-x86_64-390.59/kernel/nvidia/nv_uvm_interface.o
CC [M] /tmp/selfgz2705/NVIDIA-Linux-x86_64-390.59/kernel/nvidia/nvlink_linux.o
CC [M] /tmp/selfgz2705/NVIDIA-Linux-x86_64-390.59/kernel/nvidia-uvm/uvm_utils.o
CC [M] /tmp/selfgz2705/NVIDIA-Linux-x86_64-390.59/kernel/nvidia-uvm/uvm_common.o
CC [M] /tmp/selfgz2705/NVIDIA-Linux-x86_64-390.59/kernel/nvidia-uvm/uvm_linux.o
CC [M] /tmp/selfgz2705/NVIDIA-Linux-x86_64-390.59/kernel/nvidia-uvm/nvstatus.o
CC [M] /tmp/selfgz2705/NVIDIA-Linux-x86_64-390.59/kernel/nvidia-uvm/nvCpuUuid.o
CC [M] /tmp/selfgz2705/NVIDIA-Linux-x86_64-390.59/kernel/nvidia-uvm/uvm8.o
CC [M] /tmp/selfgz2705/NVIDIA-Linux-x86_64-390.59/kernel/nvidia-uvm/uvm8_tools.o
CC [M] /tmp/selfgz2705/NVIDIA-Linux-x86_64-390.59/kernel/nvidia-uvm/uvm8_global.o
CC [M] /tmp/selfgz2705/NVIDIA-Linux-x86_64-390.59/kernel/nvidia-uvm/uvm8_gpu.o
CC [M] /tmp/selfgz2705/NVIDIA-Linux-x86_64-390.59/kernel/nvidia-uvm/uvm8_gpu_isr.o
CC [M] /tmp/selfgz2705/NVIDIA-Linux-x86_64-390.59/kernel/nvidia-uvm/uvm8_procfs.o
CC [M] /tmp/selfgz2705/NVIDIA-Linux-x86_64-390.59/kernel/nvidia-uvm/uvm8_va_space.o
CC [M] /tmp/selfgz2705/NVIDIA-Linux-x86_64-390.59/kernel/nvidia-uvm/uvm8_gpu_semaphore.o
CC [M] /tmp/selfgz2705/NVIDIA-Linux-x86_64-390.59/kernel/nvidia-uvm/uvm8_mem.o
CC [M] /tmp/selfgz2705/NVIDIA-Linux-x86_64-390.59/kernel/nvidia-uvm/uvm8_rm_mem.o
CC [M] /tmp/selfgz2705/NVIDIA-Linux-x86_64-390.59/kernel/nvidia-uvm/uvm8_channel.o
CC [M] /tmp/selfgz2705/NVIDIA-Linux-x86_64-390.59/kernel/nvidia-uvm/uvm8_lock.o
CC [M] /tmp/selfgz2705/NVIDIA-Linux-x86_64-390.59/kernel/nvidia-uvm/uvm8_hal.o
CC [M] /tmp/selfgz2705/NVIDIA-Linux-x86_64-390.59/kernel/nvidia-uvm/uvm8_range_tree.o
CC [M] /tmp/selfgz2705/NVIDIA-Linux-x86_64-390.59/kernel/nvidia-uvm/uvm8_range_allocator.o
CC [M] /tmp/selfgz2705/NVIDIA-Linux-x86_64-390.59/kernel/nvidia-uvm/uvm8_va_range.o
CC [M] /tmp/selfgz2705/NVIDIA-Linux-x86_64-390.59/kernel/nvidia-uvm/uvm8_va_block.o
CC [M] /tmp/selfgz2705/NVIDIA-Linux-x86_64-390.59/kernel/nvidia-uvm/uvm8_range_group.o
CC [M] /tmp/selfgz2705/NVIDIA-Linux-x86_64-390.59/kernel/nvidia-uvm/uvm8_gpu_replayable_faults.o
CC [M] /tmp/selfgz2705/NVIDIA-Linux-x86_64-390.59/kernel/nvidia-uvm/uvm8_gpu_non_replayable_faults.o
CC [M] /tmp/selfgz2705/NVIDIA-Linux-x86_64-390.59/kernel/nvidia-uvm/uvm8_gpu_access_counters.o
CC [M] /tmp/selfgz2705/NVIDIA-Linux-x86_64-390.59/kernel/nvidia-uvm/uvm8_perf_events.o
CC [M] /tmp/selfgz2705/NVIDIA-Linux-x86_64-390.59/kernel/nvidia-uvm/uvm8_perf_module.o
CC [M] /tmp/selfgz2705/NVIDIA-Linux-x86_64-390.59/kernel/nvidia-uvm/uvm8_mmu.o
CC [M] /tmp/selfgz2705/NVIDIA-Linux-x86_64-390.59/kernel/nvidia-uvm/uvm8_pte_batch.o
CC [M] /tmp/selfgz2705/NVIDIA-Linux-x86_64-390.59/kernel/nvidia-uvm/uvm8_tlb_batch.o
CC [M] /tmp/selfgz2705/NVIDIA-Linux-x86_64-390.59/kernel/nvidia-uvm/uvm8_push.o
CC [M] /tmp/selfgz2705/NVIDIA-Linux-x86_64-390.59/kernel/nvidia-uvm/uvm8_pushbuffer.o
CC [M] /tmp/selfgz2705/NVIDIA-Linux-x86_64-390.59/kernel/nvidia-uvm/uvm8_thread_context.o
CC [M] /tmp/selfgz2705/NVIDIA-Linux-x86_64-390.59/kernel/nvidia-uvm/uvm8_tracker.o
CC [M] /tmp/selfgz2705/NVIDIA-Linux-x86_64-390.59/kernel/nvidia-uvm/uvm8_kepler.o
CC [M] /tmp/selfgz2705/NVIDIA-Linux-x86_64-390.59/kernel/nvidia-uvm/uvm8_kepler_ce.o
CC [M] /tmp/selfgz2705/NVIDIA-Linux-x86_64-390.59/kernel/nvidia-uvm/uvm8_kepler_host.o
CC [M] /tmp/selfgz2705/NVIDIA-Linux-x86_64-390.59/kernel/nvidia-uvm/uvm8_kepler_mmu.o
CC [M] /tmp/selfgz2705/NVIDIA-Linux-x86_64-390.59/kernel/nvidia-uvm/uvm8_maxwell.o
CC [M] /tmp/selfgz2705/NVIDIA-Linux-x86_64-390.59/kernel/nvidia-uvm/uvm8_maxwell_host.o
CC [M] /tmp/selfgz2705/NVIDIA-Linux-x86_64-390.59/kernel/nvidia-uvm/uvm8_pascal.o
CC [M] /tmp/selfgz2705/NVIDIA-Linux-x86_64-390.59/kernel/nvidia-uvm/uvm8_pascal_ce.o
CC [M] /tmp/selfgz2705/NVIDIA-Linux-x86_64-390.59/kernel/nvidia-uvm/uvm8_pascal_host.o
CC [M] /tmp/selfgz2705/NVIDIA-Linux-x86_64-390.59/kernel/nvidia-uvm/uvm8_pascal_mmu.o
CC [M] /tmp/selfgz2705/NVIDIA-Linux-x86_64-390.59/kernel/nvidia-uvm/uvm8_pascal_fault_buffer.o
CC [M] /tmp/selfgz2705/NVIDIA-Linux-x86_64-390.59/kernel/nvidia-uvm/uvm8_volta_host.o
CC [M] /tmp/selfgz2705/NVIDIA-Linux-x86_64-390.59/kernel/nvidia-uvm/uvm8_volta_mmu.o
CC [M] /tmp/selfgz2705/NVIDIA-Linux-x86_64-390.59/kernel/nvidia-uvm/uvm8_volta.o
CC [M] /tmp/selfgz2705/NVIDIA-Linux-x86_64-390.59/kernel/nvidia-uvm/uvm8_volta_fault_buffer.o
CC [M] /tmp/selfgz2705/NVIDIA-Linux-x86_64-390.59/kernel/nvidia-uvm/uvm8_volta_access_counter_buffer.o
CC [M] /tmp/selfgz2705/NVIDIA-Linux-x86_64-390.59/kernel/nvidia-uvm/uvm8_policy.o
CC [M] /tmp/selfgz2705/NVIDIA-Linux-x86_64-390.59/kernel/nvidia-uvm/uvm8_perf_utils.o
CC [M] /tmp/selfgz2705/NVIDIA-Linux-x86_64-390.59/kernel/nvidia-uvm/uvm8_kvmalloc.o
CC [M] /tmp/selfgz2705/NVIDIA-Linux-x86_64-390.59/kernel/nvidia-uvm/uvm8_pmm_sysmem.o
CC [M] /tmp/selfgz2705/NVIDIA-Linux-x86_64-390.59/kernel/nvidia-uvm/uvm8_pmm_gpu.o
CC [M] /tmp/selfgz2705/NVIDIA-Linux-x86_64-390.59/kernel/nvidia-uvm/uvm8_migrate.o
CC [M] /tmp/selfgz2705/NVIDIA-Linux-x86_64-390.59/kernel/nvidia-uvm/uvm8_map_external.o
CC [M] /tmp/selfgz2705/NVIDIA-Linux-x86_64-390.59/kernel/nvidia-uvm/uvm8_user_channel.o
CC [M] /tmp/selfgz2705/NVIDIA-Linux-x86_64-390.59/kernel/nvidia-uvm/uvm8_hmm.o
CC [M] /tmp/selfgz2705/NVIDIA-Linux-x86_64-390.59/kernel/nvidia-uvm/uvm8_perf_heuristics.o
CC [M] /tmp/selfgz2705/NVIDIA-Linux-x86_64-390.59/kernel/nvidia-uvm/uvm8_perf_thrashing.o
CC [M] /tmp/selfgz2705/NVIDIA-Linux-x86_64-390.59/kernel/nvidia-uvm/uvm8_perf_prefetch.o
CC [M] /tmp/selfgz2705/NVIDIA-Linux-x86_64-390.59/kernel/nvidia-uvm/uvm8_test.o
CC [M] /tmp/selfgz2705/NVIDIA-Linux-x86_64-390.59/kernel/nvidia-uvm/uvm8_test_rng.o
CC [M] /tmp/selfgz2705/NVIDIA-Linux-x86_64-390.59/kernel/nvidia-uvm/uvm8_range_tree_test.o
CC [M] /tmp/selfgz2705/NVIDIA-Linux-x86_64-390.59/kernel/nvidia-uvm/uvm8_range_allocator_test.o
CC [M] /tmp/selfgz2705/NVIDIA-Linux-x86_64-390.59/kernel/nvidia-uvm/uvm8_gpu_semaphore_test.o
CC [M] /tmp/selfgz2705/NVIDIA-Linux-x86_64-390.59/kernel/nvidia-uvm/uvm8_mem_test.o
CC [M] /tmp/selfgz2705/NVIDIA-Linux-x86_64-390.59/kernel/nvidia-uvm/uvm8_rm_mem_test.o
CC [M] /tmp/selfgz2705/NVIDIA-Linux-x86_64-390.59/kernel/nvidia-uvm/uvm8_page_tree_test.o
CC [M] /tmp/selfgz2705/NVIDIA-Linux-x86_64-390.59/kernel/nvidia-uvm/uvm8_tracker_test.o
CC [M] /tmp/selfgz2705/NVIDIA-Linux-x86_64-390.59/kernel/nvidia-uvm/uvm8_push_test.o
CC [M] /tmp/selfgz2705/NVIDIA-Linux-x86_64-390.59/kernel/nvidia-uvm/uvm8_channel_test.o
CC [M] /tmp/selfgz2705/NVIDIA-Linux-x86_64-390.59/kernel/nvidia-uvm/uvm8_ce_test.o
CC [M] /tmp/selfgz2705/NVIDIA-Linux-x86_64-390.59/kernel/nvidia-uvm/uvm8_lock_test.o
CC [M] /tmp/selfgz2705/NVIDIA-Linux-x86_64-390.59/kernel/nvidia-uvm/uvm8_perf_utils_test.o
CC [M] /tmp/selfgz2705/NVIDIA-Linux-x86_64-390.59/kernel/nvidia-uvm/uvm8_kvmalloc_test.o
CC [M] /tmp/selfgz2705/NVIDIA-Linux-x86_64-390.59/kernel/nvidia-uvm/uvm8_pmm_test.o
CC [M] /tmp/selfgz2705/NVIDIA-Linux-x86_64-390.59/kernel/nvidia-uvm/uvm8_pmm_sysmem_test.o
CC [M] /tmp/selfgz2705/NVIDIA-Linux-x86_64-390.59/kernel/nvidia-uvm/uvm8_perf_events_test.o
CC [M] /tmp/selfgz2705/NVIDIA-Linux-x86_64-390.59/kernel/nvidia-uvm/uvm8_perf_module_test.o
CC [M] /tmp/selfgz2705/NVIDIA-Linux-x86_64-390.59/kernel/nvidia-uvm/uvm8_get_rm_ptes_test.o
CC [M] /tmp/selfgz2705/NVIDIA-Linux-x86_64-390.59/kernel/nvidia-uvm/uvm8_fault_buffer_flush_test.o
CC [M] /tmp/selfgz2705/NVIDIA-Linux-x86_64-390.59/kernel/nvidia-uvm/uvm8_mmu_test.o
CC [M] /tmp/selfgz2705/NVIDIA-Linux-x86_64-390.59/kernel/nvidia-uvm/uvm8_peer_identity_mappings_test.o
CC [M] /tmp/selfgz2705/NVIDIA-Linux-x86_64-390.59/kernel/nvidia-uvm/uvm8_va_block_test.o
CC [M] /tmp/selfgz2705/NVIDIA-Linux-x86_64-390.59/kernel/nvidia-uvm/uvm8_range_group_tree_test.o
CC [M] /tmp/selfgz2705/NVIDIA-Linux-x86_64-390.59/kernel/nvidia-modeset/nvidia-modeset-linux.o
CC [M] /tmp/selfgz2705/NVIDIA-Linux-x86_64-390.59/kernel/nvidia-drm/nvidia-drm.o
CC [M] /tmp/selfgz2705/NVIDIA-Linux-x86_64-390.59/kernel/nvidia-drm/nvidia-drm-drv.o
CC [M] /tmp/selfgz2705/NVIDIA-Linux-x86_64-390.59/kernel/nvidia-drm/nvidia-drm-utils.o
CC [M] /tmp/selfgz2705/NVIDIA-Linux-x86_64-390.59/kernel/nvidia-drm/nvidia-drm-crtc.o
CC [M] /tmp/selfgz2705/NVIDIA-Linux-x86_64-390.59/kernel/nvidia-drm/nvidia-drm-encoder.o
CC [M] /tmp/selfgz2705/NVIDIA-Linux-x86_64-390.59/kernel/nvidia-drm/nvidia-drm-connector.o
CC [M] /tmp/selfgz2705/NVIDIA-Linux-x86_64-390.59/kernel/nvidia-drm/nvidia-drm-gem.o
CC [M] /tmp/selfgz2705/NVIDIA-Linux-x86_64-390.59/kernel/nvidia-drm/nvidia-drm-fb.o
CC [M] /tmp/selfgz2705/NVIDIA-Linux-x86_64-390.59/kernel/nvidia-drm/nvidia-drm-modeset.o
CC [M] /tmp/selfgz2705/NVIDIA-Linux-x86_64-390.59/kernel/nvidia-drm/nvidia-drm-prime-fence.o
CC [M] /tmp/selfgz2705/NVIDIA-Linux-x86_64-390.59/kernel/nvidia-drm/nvidia-drm-linux.o
CC [M] /tmp/selfgz2705/NVIDIA-Linux-x86_64-390.59/kernel/nvidia-drm/nvidia-drm-helper.o
CC [M] /tmp/selfgz2705/NVIDIA-Linux-x86_64-390.59/kernel/nvidia-drm/nv-pci-table.o
CC [M] /tmp/selfgz2705/NVIDIA-Linux-x86_64-390.59/kernel/nvidia-drm/nvidia-drm-gem-nvkms-memory.o
CC [M] /tmp/selfgz2705/NVIDIA-Linux-x86_64-390.59/kernel/nvidia-drm/nvidia-drm-gem-user-memory.o
ld -r -o /tmp/selfgz2705/NVIDIA-Linux-x86_64-390.59/kernel/nvidia/nv-interface.o /tmp/selfgz2705/NVIDIA-Linux-x86_64-390.59/kernel/nvidia/nv-frontend.o /tmp/selfgz2705/NVIDIA-Linux-x86_64-390.59/kernel/nvidia/nv-instance.o /tmp/selfgz2705/NVIDIA-Linux-x86_64-390.59/kernel/nvidia/nv-gpu-numa.o /tmp/selfgz2705/NVIDIA-Linux-x86_64-390.59/kernel/nvidia/nv.o /tmp/selfgz2705/NVIDIA-Linux-x86_64-390.59/kernel/nvidia/nv-acpi.o /tmp/selfgz2705/NVIDIA-Linux-x86_64-390.59/kernel/nvidia/nv-chrdev.o /tmp/selfgz2705/NVIDIA-Linux-x86_64-390.59/kernel/nvidia/nv-cray.o /tmp/selfgz2705/NVIDIA-Linux-x86_64-390.59/kernel/nvidia/nv-dma.o /tmp/selfgz2705/NVIDIA-Linux-x86_64-390.59/kernel/nvidia/nv-gvi.o /tmp/selfgz2705/NVIDIA-Linux-x86_64-390.59/kernel/nvidia/nv-i2c.o /tmp/selfgz2705/NVIDIA-Linux-x86_64-390.59/kernel/nvidia/nv-mempool.o /tmp/selfgz2705/NVIDIA-Linux-x86_64-390.59/kernel/nvidia/nv-mmap.o /tmp/selfgz2705/NVIDIA-Linux-x86_64-390.59/kernel/nvidia/nv-p2p.o /tmp/selfgz2705/NVIDIA-Linux-x86_64-390.59/kernel/nvidia/nv-pat.o /tmp
/selfgz2705/NVIDIA-Linux-x86_64-390.59/kernel/nvidia/nv-procfs.o /tmp/selfgz2705/NVIDIA-Linux-x86_64-390.59/kernel/nvidia/nv-usermap.o /tmp/selfgz2705/NVIDIA-Linux-x86_64-390.59/kernel/nvidia/nv-vm.o /tmp/selfgz2705/NVIDIA-Linux-x86_64-390.59/kernel/nvidia/nv-vtophys.o /tmp/selfgz2705/NVIDIA-Linux-x86_64-390.59/kernel/nvidia/os-interface.o /tmp/selfgz2705/NVIDIA-Linux-x86_64-390.59/kernel/nvidia/os-mlock.o /tmp/selfgz2705/NVIDIA-Linux-x86_64-390.59/kernel/nvidia/os-pci.o /tmp/selfgz2705/NVIDIA-Linux-x86_64-390.59/kernel/nvidia/os-registry.o /tmp/selfgz2705/NVIDIA-Linux-x86_64-390.59/kernel/nvidia/os-usermap.o /tmp/selfgz2705/NVIDIA-Linux-x86_64-390.59/kernel/nvidia/nv-modeset-interface.o /tmp/selfgz2705/NVIDIA-Linux-x86_64-390.59/kernel/nvidia/nv-pci-table.o /tmp/selfgz2705/NVIDIA-Linux-x86_64-390.59/kernel/nvidia/nv-kthread-q.o /tmp/selfgz2705/NVIDIA-Linux-x86_64-390.59/kernel/nvidia/nv-kthread-q-selftest.o /tmp/selfgz2705/NVIDIA-Linux-x86_64-390.59/kernel/nvidia/nv-memdbg.o /tmp/selfgz2705/NVIDIA-Linux-x86_
64-390.59/kernel/nvidia/nv-ibmnpu.o /tmp/selfgz2705/NVIDIA-Linux-x86_64-390.59/kernel/nvidia/nv-report-err.o /tmp/selfgz2705/NVIDIA-Linux-x86_64-390.59/kernel/nvidia/nv_uvm_interface.o /tmp/selfgz2705/NVIDIA-Linux-x86_64-390.59/kernel/nvidia/nvlink_linux.o
ld -r -o /tmp/selfgz2705/NVIDIA-Linux-x86_64-390.59/kernel/nvidia-modeset/nv-modeset-interface.o /tmp/selfgz2705/NVIDIA-Linux-x86_64-390.59/kernel/nvidia-modeset/nvidia-modeset-linux.o
LD [M] /tmp/selfgz2705/NVIDIA-Linux-x86_64-390.59/kernel/nvidia.o
LD [M] /tmp/selfgz2705/NVIDIA-Linux-x86_64-390.59/kernel/nvidia-uvm.o
LD [M] /tmp/selfgz2705/NVIDIA-Linux-x86_64-390.59/kernel/nvidia-modeset.o
LD [M] /tmp/selfgz2705/NVIDIA-Linux-x86_64-390.59/kernel/nvidia-drm.o
Building modules, stage 2.
MODPOST 4 modules
CC /tmp/selfgz2705/NVIDIA-Linux-x86_64-390.59/kernel/nvidia-drm.mod.o
CC /tmp/selfgz2705/NVIDIA-Linux-x86_64-390.59/kernel/nvidia-modeset.mod.o
CC /tmp/selfgz2705/NVIDIA-Linux-x86_64-390.59/kernel/nvidia-uvm.mod.o
CC /tmp/selfgz2705/NVIDIA-Linux-x86_64-390.59/kernel/nvidia.mod.o
LD [M] /tmp/selfgz2705/NVIDIA-Linux-x86_64-390.59/kernel/nvidia-modeset.ko
LD [M] /tmp/selfgz2705/NVIDIA-Linux-x86_64-390.59/kernel/nvidia-uvm.ko
LD [M] /tmp/selfgz2705/NVIDIA-Linux-x86_64-390.59/kernel/nvidia.ko
LD [M] /tmp/selfgz2705/NVIDIA-Linux-x86_64-390.59/kernel/nvidia-drm.ko
→ done.
→ Kernel module compilation complete.
→ Unable to determine if Secure Boot is enabled: No such file or directory
→ Kernel messages:
[ 18.471754] audit: type=1400 audit(1531202101.210:11): apparmor=“STATUS” operation=“profile_load” profile=“unconfined” name=“/usr/lib/lightdm/lightdm-guest-session” pid=867 comm=“apparmor_parser”
[ 19.680103] IPv6: ADDRCONF(NETDEV_UP): enp2s0: link is not ready
[ 19.680244] enp2s0: 0xffff9f7cc003d000, 1c:66:6d:96:82:f4, IRQ 124
[ 19.730462] IPv6: ADDRCONF(NETDEV_UP): enp2s0: link is not ready
[ 21.498478] nvidia-modeset: Allocated GPU:0 (GPU-8580845e-4b93-1482-87ff-d8d998c84f90) @ PCI:0000:01:00.0
[ 22.794405] r8168: enp2s0: link up
[ 22.794424] IPv6: ADDRCONF(NETDEV_CHANGE): enp2s0: link becomes ready
[ 97.793894] ecryptfs_decrypt_page: Error attempting to read lower page; rc = [-4]
[ 97.794559] ecryptfs_readpage: Error decrypting page; rc = [-4]
[ 97.854589] nvidia-modeset: Freed GPU:0 (GPU-8580845e-4b93-1482-87ff-d8d998c84f90) @ PCI:0000:01:00.0
[ 120.216251] [drm] [nvidia-drm] [GPU ID 0x00000100] Unloading driver
[ 120.258402] nvidia-modeset: Unloading
[ 120.293719] nvidia-nvlink: Unregistered the Nvlink Core, major device number 240
[ 157.022978] VFIO - User Level meta-driver version: 0.3
[ 157.057554] nvidia-nvlink: Nvlink Core is being initialized, major device number 239
[ 157.057947] nvidia 0000:01:00.0: vgaarb: changed VGA decodes: olddecodes=none,decodes=none:owns=io+mem
[ 157.058057] NVRM: loading NVIDIA UNIX x86_64 Kernel Module 390.59 Wed May 9 22:33:42 PDT 2018 (using threaded interrupts)
[ 157.063805] nvidia-uvm: Loaded the UVM driver in 8 mode, major device number 238
[ 157.065600] nvidia-modeset: Loading NVIDIA Kernel Mode Setting Driver for UNIX platforms 390.59 Wed May 9 21:59:27 PDT 2018
[ 157.066775] [drm] [nvidia-drm] [GPU ID 0x00000100] Loading driver
[ 157.066777] [drm] Initialized nvidia-drm 0.0.0 20160202 for 0000:01:00.0 on minor 0
[ 157.068002] [drm] [nvidia-drm] [GPU ID 0x00000100] Unloading driver
[ 157.098383] nvidia-modeset: Unloading
[ 157.140631] nvidia-uvm: Unloaded the UVM driver in 8 mode
[ 157.164139] nvidia-nvlink: Unregistered the Nvlink Core, major device number 239
→ Installing both new and classic TLS OpenGL libraries.
→ Installing classic TLS 32bit OpenGL libraries.
WARNING: Unable to find a suitable destination to install 32-bit compatibility libraries. Your system may not be set up for 32-bit compatibility. 32-bit compatibility files will not be installed; if you wish to install them, re-run the installation and set a valid directory with the --compat32-libdir option.
→ Will install GLVND GLX client libraries.
→ Will install GLVND EGL client libraries.
→ Skipping GLX non-GLVND file: “libGL.so.390.59”
→ Skipping GLX non-GLVND file: “libGL.so.1”
→ Skipping GLX non-GLVND file: “libGL.so”
→ Skipping EGL non-GLVND file: “libEGL.so.390.59”
→ Skipping EGL non-GLVND file: “libEGL.so”
→ Skipping EGL non-GLVND file: “libEGL.so.1”
→ Uninstalling the previous installation with /usr/bin/nvidia-uninstall.
Looking for install checker script at ./libglvnd_install_checker/check-libglvnd-install.sh
executing: ‘/bin/sh ./libglvnd_install_checker/check-libglvnd-install.sh’…
Checking for libglvnd installation.
Checking libGLdispatch…
Can’t load library libGLdispatch.so.0: libGLdispatch.so.0: cannot open shared object file: No such file or directory
Will install libglvnd libraries.
Will install libEGL vendor library config file to /usr/share/glvnd/egl_vendor.d
→ Searching for conflicting files:
→ done.
→ Installing ‘NVIDIA Accelerated Graphics Driver for Linux-x86_64’ (390.59):
executing: ‘/sbin/ldconfig’…
executing: '/sbin/depmod -a '…
→ done.
→ Driver file installation is complete.
→ Running post-install sanity check:
→ done.
→ Post-install sanity check passed.
→ Running runtime sanity check:
→ done.
→ Runtime sanity check passed.
→ Would you like to run the nvidia-xconfig utility to automatically update your X configuration file so that the NVIDIA X driver will be used when you restart X? Any pre-existing X configuration file will be backed up. (Answer: No)
→ Installation of the NVIDIA Accelerated Graphics Driver for Linux-x86_64 (version: 390.59) is now complete. Please update your XF86Config or xorg.conf file as appropriate; see the file /usr/share/doc/NVIDIA_GLX-1.0/README.txt for details.
*** /var/log/nvidia-uninstall.log
*** ls: -rw-r–r-- 1 root root 1188 2018-07-10 06:57:37.167312302 +0100 /var/log/nvidia-uninstall.log
nvidia-installer log file ‘/var/log/nvidia-uninstall.log’
creation time: Tue Jul 10 06:57:24 2018
installer version: 390.67
-s
–log-file-name=/var/log/nvidia-uninstall.log
Using built-in stream user interface
→ If you plan to no longer use the NVIDIA driver, you should make sure that no X screens are configured to use the NVIDIA X driver in your X configuration file. If you used nvidia-xconfig to configure X, it may have created a backup of your original configuration. Would you like to run nvidia-xconfig --restore-original-backup
to attempt restoration of the original X configuration file? (Answer: No)
→ Parsing log file:
→ done.
→ Validating previous installation:
→ done.
→ Uninstalling NVIDIA Accelerated Graphics Driver for Linux-x86_64 (1.0-39067 (390.67)):
→ DKMS module detected; removing…
→ done.
→ Running depmod and ldconfig:
→ done.
→ Uninstallation of existing driver: NVIDIA Accelerated Graphics Driver for Linux-x86_64 (390.67) is complete.
journalctl -b -0 _COMM=Xorg
– No entries –
journalctl -b -1 _COMM=Xorg
journalctl -b -2 _COMM=Xorg
journalctl -b -0 _COMM=Xorg.bin
– No entries –
journalctl -b -1 _COMM=Xorg.bin
journalctl -b -2 _COMM=Xorg.bin
– No entries –
*** /var/log/Xorg.0.log
*** ls: -rw-r–r-- 1 root root 25026 2018-07-12 13:17:06.409564869 +0100 /var/log/Xorg.0.log
[ 1036.079]
X.Org X Server 1.19.6
Release Date: 2017-12-20
[ 1036.079] X Protocol Version 11, Revision 0
[ 1036.079] Build Operating System: Linux 4.4.0-128-generic x86_64 Ubuntu
[ 1036.079] Current Operating System: Linux Lenovo-Home 4.15.0-24-generic #26~16.04.1-Ubuntu SMP Fri Jun 15 14:35:08 UTC 2018 x86_64
[ 1036.079] Kernel command line: BOOT_IMAGE=/boot/vmlinuz-4.15.0-24-generic root=UUID=382b33a5-e969-4fb7-944e-e9d93cadaaf7 ro quiet splash vt.handoff=7
[ 1036.079] Build Date: 14 June 2018 05:12:30PM
[ 1036.079] xorg-server 2:1.19.6-1ubuntu4~16.04.1 (For technical support please see Enterprise open source support | Ubuntu)
[ 1036.079] Current version of pixman: 0.33.6
[ 1036.080] Before reporting problems, check http://wiki.x.org
to make sure that you have the latest version.
[ 1036.080] Markers: (–) probed, () from config file, (==) default setting,
(++) from command line, (!!) notice, (II) informational,
(WW) warning, (EE) error, (NI) not implemented, (??) unknown.
[ 1036.080] (==) Log file: “/var/log/Xorg.0.log”, Time: Thu Jul 12 06:39:31 2018
[ 1036.441] (==) Using config file: “/etc/X11/xorg.conf”
[ 1036.441] (==) Using system config directory “/usr/share/X11/xorg.conf.d”
[ 1036.625] (==) ServerLayout “Layout0”
[ 1036.625] () |–>Screen “Screen0” (0)
[ 1036.625] () | |–>Monitor “Monitor0”
[ 1036.625] () | |–>Device “Device0”
[ 1036.625] () |–>Input Device “Keyboard0”
[ 1036.625] () |–>Input Device “Mouse0”
[ 1036.625] (==) Automatically adding devices
[ 1036.625] (==) Automatically enabling devices
[ 1036.625] (==) Automatically adding GPU devices
[ 1036.626] (==) Automatically binding GPU devices
[ 1036.626] (==) Max clients allowed: 256, resource mask: 0x1fffff
[ 1036.626] (WW) The directory “/usr/share/fonts/X11/cyrillic” does not exist.
[ 1036.626] Entry deleted from font path.
[ 1036.626] (WW) The directory “/usr/share/fonts/X11/100dpi/” does not exist.
[ 1036.626] (WW) The directory “/usr/share/fonts/X11/75dpi/” does not exist.
[ 1036.626] (WW) The directory “/usr/share/fonts/X11/100dpi” does not exist.
[ 1036.626] (WW) The directory “/usr/share/fonts/X11/75dpi” does not exist.
[ 1036.626] (==) FontPath set to:
/usr/share/fonts/X11/misc,
/usr/share/fonts/X11/Type1,
built-ins
[ 1036.626] (==) ModulePath set to “/usr/lib/x86_64-linux-gnu/xorg/extra-modules,/usr/lib/xorg/extra-modules,/usr/lib/xorg/modules”
[ 1036.626] (WW) Hotplugging is on, devices using drivers ‘kbd’, ‘mouse’ or ‘vmmouse’ will be disabled.
[ 1036.626] (WW) Disabling Keyboard0
[ 1036.626] (WW) Disabling Mouse0
[ 1036.626] (II) Loader magic: 0x556a4e345e00
[ 1036.626] (II) Module ABI versions:
[ 1036.626] X.Org ANSI C Emulation: 0.4
[ 1036.626] X.Org Video Driver: 23.0
[ 1036.626] X.Org XInput driver : 24.1
[ 1036.626] X.Org Server Extension : 10.0
[ 1036.628] (++) using VT number 7
[ 1036.628] (II) systemd-logind: logind integration requires -keeptty and -keeptty was not provided, disabling logind integration
[ 1036.628] (II) xfree86: Adding drm device (/dev/dri/card0)
[ 1036.630] (–) PCI:*(0:1:0:0) 10de:1d01:1462:8c98 rev 161, Mem @ 0xde000000/16777216, 0xc0000000/268435456, 0xd0000000/33554432, I/O @ 0x0000e000/128, BIOS @ 0x???/131072
[ 1036.630] (II) LoadModule: “glx”
[ 1036.792] (II) Loading /usr/lib/xorg/modules/extensions/libglx.so
[ 1037.679] (II) Module glx: vendor=“NVIDIA Corporation”
[ 1037.679] compiled for 4.0.2, module version = 1.0.0
[ 1037.679] Module class: X.Org Server Extension
[ 1037.690] (II) NVIDIA GLX Module 390.59 Wed May 9 21:54:15 PDT 2018
[ 1037.690] (II) LoadModule: “nvidia”
[ 1037.690] (II) Loading /usr/lib/xorg/modules/drivers/nvidia_drv.so
[ 1037.709] (II) Module nvidia: vendor=“NVIDIA Corporation”
[ 1037.709] compiled for 4.0.2, module version = 1.0.0
[ 1037.709] Module class: X.Org Video Driver
[ 1037.715] (II) NVIDIA dlloader X Driver 390.59 Wed May 9 21:30:06 PDT 2018
[ 1037.718] (II) NVIDIA Unified Driver for all Supported NVIDIA GPUs
[ 1037.720] (II) Loading sub module “fb”
[ 1037.720] (II) LoadModule: “fb”
[ 1037.720] (II) Loading /usr/lib/xorg/modules/libfb.so
[ 1037.729] (II) Module fb: vendor=“X.Org Foundation”
[ 1037.729] compiled for 1.19.6, module version = 1.0.0
[ 1037.729] ABI class: X.Org ANSI C Emulation, version 0.4
[ 1037.729] (II) Loading sub module “wfb”
[ 1037.729] (II) LoadModule: “wfb”
[ 1037.729] (II) Loading /usr/lib/xorg/modules/libwfb.so
[ 1037.732] (II) Module wfb: vendor=“X.Org Foundation”
[ 1037.732] compiled for 1.19.6, module version = 1.0.0
[ 1037.732] ABI class: X.Org ANSI C Emulation, version 0.4
[ 1037.732] (II) Loading sub module “ramdac”
[ 1037.732] (II) LoadModule: “ramdac”
[ 1037.732] (II) Module “ramdac” already built-in
[ 1037.734] () NVIDIA(0): Depth 24, (–) framebuffer bpp 32
[ 1037.734] (==) NVIDIA(0): RGB weight 888
[ 1037.734] (==) NVIDIA(0): Default visual is TrueColor
[ 1037.734] (==) NVIDIA(0): Using gamma correction (1.0, 1.0, 1.0)
[ 1037.734] () NVIDIA(0): Enabling 2D acceleration
[ 1038.289] (–) NVIDIA(0): Valid display device(s) on GPU-0 at PCI:1:0:0
[ 1038.289] (–) NVIDIA(0): DFP-0
[ 1038.289] (–) NVIDIA(0): DFP-1
[ 1038.289] (–) NVIDIA(0): DFP-2 (boot)
[ 1038.290] (II) NVIDIA(0): NVIDIA GPU GeForce GT 1030 (GP108-A) at PCI:1:0:0 (GPU-0)
[ 1038.290] (–) NVIDIA(0): Memory: 2097152 kBytes
[ 1038.290] (–) NVIDIA(0): VideoBIOS: 86.08.0c.00.0b
[ 1038.290] (II) NVIDIA(0): Detected PCI Express Link width: 4X
[ 1038.290] (–) NVIDIA(GPU-0): DFP-0: disconnected
[ 1038.290] (–) NVIDIA(GPU-0): DFP-0: Internal DisplayPort
[ 1038.290] (–) NVIDIA(GPU-0): DFP-0: 1440.0 MHz maximum pixel clock
[ 1038.290] (–) NVIDIA(GPU-0): DFP-1: disconnected
[ 1038.290] (–) NVIDIA(GPU-0): DFP-1: Internal TMDS
[ 1038.290] (–) NVIDIA(GPU-0): DFP-1: 165.0 MHz maximum pixel clock
[ 1038.320] (–) NVIDIA(GPU-0): HP 27es (DFP-2): connected
[ 1038.320] (–) NVIDIA(GPU-0): HP 27es (DFP-2): Internal TMDS
[ 1038.320] (–) NVIDIA(GPU-0): HP 27es (DFP-2): 600.0 MHz maximum pixel clock
[ 1038.336] (==) NVIDIA(0):
[ 1038.336] (==) NVIDIA(0): No modes were requested; the default mode “nvidia-auto-select”
[ 1038.336] (==) NVIDIA(0): will be used as the requested mode.
[ 1038.339] (II) NVIDIA(0): Validated MetaModes:
[ 1038.339] (II) NVIDIA(0): “DFP-2:nvidia-auto-select”
[ 1038.339] (II) NVIDIA(0): Virtual screen size determined to be 1920 x 1080
[ 1038.343] (–) NVIDIA(0): DPI set to (81, 80); computed from “UseEdidDpi” X config
[ 1038.343] (–) NVIDIA(0): option
[ 1038.343] (–) Depth 24 pixmap format is 32 bpp
[ 1038.344] (II) NVIDIA: Using 24576.00 MB of virtual memory for indirect memory
[ 1038.344] (II) NVIDIA: access.
[ 1038.566] (II) NVIDIA(0): Setting mode “DFP-2:nvidia-auto-select”
[ 1038.694] (==) NVIDIA(0): Disabling shared memory pixmaps
[ 1038.694] (==) NVIDIA(0): Backing store enabled
[ 1038.694] (==) NVIDIA(0): Silken mouse enabled
[ 1038.694] () NVIDIA(0): DPMS enabled
[ 1038.695] (II) Loading sub module “dri2”
[ 1038.695] (II) LoadModule: “dri2”
[ 1038.695] (II) Module “dri2” already built-in
[ 1038.695] (II) NVIDIA(0): [DRI2] Setup complete
[ 1038.695] (II) NVIDIA(0): [DRI2] VDPAU driver: nvidia
[ 1038.707] (–) RandR disabled
[ 1038.715] (II) SELinux: Disabled on system
[ 1038.909] (II) Initializing extension GLX
[ 1038.909] (II) Indirect GLX disabled.
[ 1039.601] (II) config/udev: Adding input device Power Button (/dev/input/event2)
[ 1039.601] () Power Button: Applying InputClass “evdev keyboard catchall”
[ 1039.601] (II) LoadModule: “evdev”
[ 1039.601] (II) Loading /usr/lib/xorg/modules/input/evdev_drv.so
[ 1039.601] (II) Module evdev: vendor=“X.Org Foundation”
[ 1039.601] compiled for 1.19.3, module version = 2.10.5
[ 1039.601] Module class: X.Org XInput Driver
[ 1039.601] ABI class: X.Org XInput driver, version 24.1
[ 1039.601] (II) Using input driver ‘evdev’ for ‘Power Button’
[ 1039.601] () Power Button: always reports core events
[ 1039.601] () evdev: Power Button: Device: “/dev/input/event2”
[ 1039.601] (–) evdev: Power Button: Vendor 0 Product 0x1
[ 1039.601] (–) evdev: Power Button: Found keys
[ 1039.601] (II) evdev: Power Button: Configuring as keyboard
[ 1039.601] () Option “config_info” “udev:/sys/devices/LNXSYSTM:00/LNXPWRBN:00/input/input2/event2”
[ 1039.601] (II) XINPUT: Adding extended input device “Power Button” (type: KEYBOARD, id 6)
[ 1039.601] () Option “xkb_rules” “evdev”
[ 1039.601] () Option “xkb_model” “pc105”
[ 1039.601] () Option “xkb_layout” “fr”
[ 1039.736] (II) config/udev: Adding input device Power Button (/dev/input/event1)
[ 1039.736] () Power Button: Applying InputClass “evdev keyboard catchall”
[ 1039.736] (II) Using input driver ‘evdev’ for ‘Power Button’
[ 1039.736] () Power Button: always reports core events
[ 1039.736] () evdev: Power Button: Device: “/dev/input/event1”
[ 1039.736] (–) evdev: Power Button: Vendor 0 Product 0x1
[ 1039.736] (–) evdev: Power Button: Found keys
[ 1039.736] (II) evdev: Power Button: Configuring as keyboard
[ 1039.736] () Option “config_info” “udev:/sys/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0C:00/input/input1/event1”
[ 1039.736] (II) XINPUT: Adding extended input device “Power Button” (type: KEYBOARD, id 7)
[ 1039.736] () Option “xkb_rules” “evdev”
[ 1039.736] () Option “xkb_model” “pc105”
[ 1039.736] () Option “xkb_layout” “fr”
[ 1039.738] (II) config/udev: Adding input device Sleep Button (/dev/input/event0)
[ 1039.738] () Sleep Button: Applying InputClass “evdev keyboard catchall”
[ 1039.738] (II) Using input driver ‘evdev’ for ‘Sleep Button’
[ 1039.738] () Sleep Button: always reports core events
[ 1039.738] () evdev: Sleep Button: Device: “/dev/input/event0”
[ 1039.738] (–) evdev: Sleep Button: Vendor 0 Product 0x3
[ 1039.738] (–) evdev: Sleep Button: Found keys
[ 1039.738] (II) evdev: Sleep Button: Configuring as keyboard
[ 1039.738] () Option “config_info” “udev:/sys/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0E:00/input/input0/event0”
[ 1039.738] (II) XINPUT: Adding extended input device “Sleep Button” (type: KEYBOARD, id 8)
[ 1039.738] () Option “xkb_rules” “evdev”
[ 1039.738] () Option “xkb_model” “pc105”
[ 1039.738] () Option “xkb_layout” “fr”
[ 1039.739] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=3 (/dev/input/event11)
[ 1039.739] (II) No input driver specified, ignoring this device.
[ 1039.739] (II) This device may have been added with another device file.
[ 1039.740] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=7 (/dev/input/event12)
[ 1039.740] (II) No input driver specified, ignoring this device.
[ 1039.740] (II) This device may have been added with another device file.
[ 1039.741] (II) config/udev: Adding input device USB Keyboard (/dev/input/event3)
[ 1039.741] () USB Keyboard: Applying InputClass “evdev keyboard catchall”
[ 1039.741] (II) Using input driver ‘evdev’ for ’ USB Keyboard’
[ 1039.741] () USB Keyboard: always reports core events
[ 1039.741] () evdev: USB Keyboard: Device: “/dev/input/event3”
[ 1039.741] (–) evdev: USB Keyboard: Vendor 0x4d9 Product 0x1702
[ 1039.741] (–) evdev: USB Keyboard: Found keys
[ 1039.741] (II) evdev: USB Keyboard: Configuring as keyboard
[ 1039.741] () Option “config_info” “udev:/sys/devices/pci0000:00/0000:00:14.0/usb1/1-1/1-1:1.0/0003:04D9:1702.0001/input/input6/event3”
[ 1039.741] (II) XINPUT: Adding extended input device " USB Keyboard" (type: KEYBOARD, id 9)
[ 1039.741] () Option “xkb_rules” “evdev”
[ 1039.742] () Option “xkb_model” “pc105”
[ 1039.742] () Option “xkb_layout” “fr”
[ 1039.743] (II) config/udev: Adding input device USB Keyboard (/dev/input/event4)
[ 1039.743] () USB Keyboard: Applying InputClass “evdev keyboard catchall”
[ 1039.743] (II) Using input driver ‘evdev’ for ’ USB Keyboard’
[ 1039.743] () USB Keyboard: always reports core events
[ 1039.743] () evdev: USB Keyboard: Device: “/dev/input/event4”
[ 1039.743] (–) evdev: USB Keyboard: Vendor 0x4d9 Product 0x1702
[ 1039.743] (–) evdev: USB Keyboard: Found keys
[ 1039.743] (II) evdev: USB Keyboard: Configuring as keyboard
[ 1039.743] () Option “config_info” “udev:/sys/devices/pci0000:00/0000:00:14.0/usb1/1-1/1-1:1.1/0003:04D9:1702.0002/input/input7/event4”
[ 1039.744] (II) XINPUT: Adding extended input device " USB Keyboard" (type: KEYBOARD, id 10)
[ 1039.744] () Option “xkb_rules” “evdev”
[ 1039.744] () Option “xkb_model” “pc105”
[ 1039.744] () Option “xkb_layout” “fr”
[ 1039.745] (II) config/udev: Adding input device PixArt USB Optical Mouse (/dev/input/event5)
[ 1039.745] () PixArt USB Optical Mouse: Applying InputClass “evdev pointer catchall”
[ 1039.745] (II) Using input driver ‘evdev’ for ‘PixArt USB Optical Mouse’
[ 1039.745] () PixArt USB Optical Mouse: always reports core events
[ 1039.745] () evdev: PixArt USB Optical Mouse: Device: “/dev/input/event5”
[ 1039.745] (–) evdev: PixArt USB Optical Mouse: Vendor 0x93a Product 0x2510
[ 1039.745] (–) evdev: PixArt USB Optical Mouse: Found 3 mouse buttons
[ 1039.745] (–) evdev: PixArt USB Optical Mouse: Found scroll wheel(s)
[ 1039.745] (–) evdev: PixArt USB Optical Mouse: Found relative axes
[ 1039.745] (–) evdev: PixArt USB Optical Mouse: Found x and y relative axes
[ 1039.745] (II) evdev: PixArt USB Optical Mouse: Configuring as mouse
[ 1039.745] (II) evdev: PixArt USB Optical Mouse: Adding scrollwheel support
[ 1039.745] () evdev: PixArt USB Optical Mouse: YAxisMapping: buttons 4 and 5
[ 1039.746] () evdev: PixArt USB Optical Mouse: EmulateWheelButton: 4, EmulateWheelInertia: 10, EmulateWheelTimeout: 200
[ 1039.746] () Option “config_info” “udev:/sys/devices/pci0000:00/0000:00:14.0/usb1/1-7/1-7:1.0/0003:093A:2510.0003/input/input8/event5”
[ 1039.746] (II) XINPUT: Adding extended input device “PixArt USB Optical Mouse” (type: MOUSE, id 11)
[ 1039.746] (II) evdev: PixArt USB Optical Mouse: initialized for relative axes.
[ 1039.746] () PixArt USB Optical Mouse: (accel) keeping acceleration scheme 1
[ 1039.746] () PixArt USB Optical Mouse: (accel) acceleration profile 0
[ 1039.746] () PixArt USB Optical Mouse: (accel) acceleration factor: 2.000
[ 1039.746] () PixArt USB Optical Mouse: (accel) acceleration threshold: 4
[ 1039.747] (II) config/udev: Adding input device PixArt USB Optical Mouse (/dev/input/mouse0)
[ 1039.747] (II) No input driver specified, ignoring this device.
[ 1039.747] (II) This device may have been added with another device file.
[ 1039.748] (II) config/udev: Adding input device HDA Intel PCH Rear Mic (/dev/input/event7)
[ 1039.748] (II) No input driver specified, ignoring this device.
[ 1039.748] (II) This device may have been added with another device file.
[ 1039.748] (II) config/udev: Adding input device HDA Intel PCH Line (/dev/input/event8)
[ 1039.749] (II) config/udev: Adding input device HDA Intel PCH Line Out (/dev/input/event9)
[ 1039.749] (II) No input driver specified, ignoring this device.
[ 1039.749] (II) This device may have been added with another device file.
[ 1039.749] (II) config/udev: Adding input device HDA Intel PCH Front Headphone (/dev/input/event10)
[ 1039.750] (II) config/udev: Adding input device HDA Intel PCH Front Mic (/dev/input/event6)
[ 1039.750] (II) No input driver specified, ignoring this device.
[ 1039.750] (II) This device may have been added with another device file.
[ 1043.551] (–) NVIDIA(GPU-0): DFP-0: disconnected
[ 1043.551] (–) NVIDIA(GPU-0): DFP-0: Internal DisplayPort
[ 1043.551] (–) NVIDIA(GPU-0): DFP-0: 1440.0 MHz maximum pixel clock
[ 1043.551] (–) NVIDIA(GPU-0): DFP-1: disconnected
[ 1043.551] (–) NVIDIA(GPU-0): DFP-1: Internal TMDS
[ 1043.551] (–) NVIDIA(GPU-0): DFP-1: 165.0 MHz maximum pixel clock
[ 1043.581] (–) NVIDIA(GPU-0): HP 27es (DFP-2): connected
[ 1043.581] (–) NVIDIA(GPU-0): HP 27es (DFP-2): Internal TMDS
[ 1043.581] (–) NVIDIA(GPU-0): HP 27es (DFP-2): 600.0 MHz maximum pixel clock
[ 1043.855] (–) NVIDIA(GPU-0): DFP-0: disconnected
[ 1043.855] (–) NVIDIA(GPU-0): DFP-0: Internal DisplayPort
[ 1043.855] (–) NVIDIA(GPU-0): DFP-0: 1440.0 MHz maximum pixel clock
[ 1043.855] (–) NVIDIA(GPU-0): DFP-1: disconnected
[ 1043.855] (–) NVIDIA(GPU-0): DFP-1: Internal TMDS
[ 1043.855] (–) NVIDIA(GPU-0): DFP-1: 165.0 MHz maximum pixel clock
[ 1043.885] (–) NVIDIA(GPU-0): HP 27es (DFP-2): connected
[ 1043.885] (–) NVIDIA(GPU-0): HP 27es (DFP-2): Internal TMDS
[ 1043.885] (–) NVIDIA(GPU-0): HP 27es (DFP-2): 600.0 MHz maximum pixel clock
[ 1053.954] (–) NVIDIA(GPU-0): DFP-0: disconnected
[ 1053.954] (–) NVIDIA(GPU-0): DFP-0: Internal DisplayPort
[ 1053.954] (–) NVIDIA(GPU-0): DFP-0: 1440.0 MHz maximum pixel clock
[ 1053.954] (–) NVIDIA(GPU-0): DFP-1: disconnected
[ 1053.954] (–) NVIDIA(GPU-0): DFP-1: Internal TMDS
[ 1053.954] (–) NVIDIA(GPU-0): DFP-1: 165.0 MHz maximum pixel clock
[ 1053.985] (–) NVIDIA(GPU-0): HP 27es (DFP-2): connected
[ 1053.985] (–) NVIDIA(GPU-0): HP 27es (DFP-2): Internal TMDS
[ 1053.985] (–) NVIDIA(GPU-0): HP 27es (DFP-2): 600.0 MHz maximum pixel clock
[ 1056.848] (–) NVIDIA(GPU-0): DFP-0: disconnected
[ 1056.848] (–) NVIDIA(GPU-0): DFP-0: Internal DisplayPort
[ 1056.848] (–) NVIDIA(GPU-0): DFP-0: 1440.0 MHz maximum pixel clock
[ 1056.848] (–) NVIDIA(GPU-0): DFP-1: disconnected
[ 1056.848] (–) NVIDIA(GPU-0): DFP-1: Internal TMDS
[ 1056.848] (–) NVIDIA(GPU-0): DFP-1: 165.0 MHz maximum pixel clock
[ 1056.879] (–) NVIDIA(GPU-0): HP 27es (DFP-2): connected
[ 1056.879] (–) NVIDIA(GPU-0): HP 27es (DFP-2): Internal TMDS
[ 1056.879] (–) NVIDIA(GPU-0): HP 27es (DFP-2): 600.0 MHz maximum pixel clock
[ 1060.047] (–) NVIDIA(GPU-0): DFP-0: disconnected
[ 1060.047] (–) NVIDIA(GPU-0): DFP-0: Internal DisplayPort
[ 1060.047] (–) NVIDIA(GPU-0): DFP-0: 1440.0 MHz maximum pixel clock
[ 1060.047] (–) NVIDIA(GPU-0): DFP-1: disconnected
[ 1060.047] (–) NVIDIA(GPU-0): DFP-1: Internal TMDS
[ 1060.047] (–) NVIDIA(GPU-0): DFP-1: 165.0 MHz maximum pixel clock
[ 1060.077] (–) NVIDIA(GPU-0): HP 27es (DFP-2): connected
[ 1060.077] (–) NVIDIA(GPU-0): HP 27es (DFP-2): Internal TMDS
[ 1060.077] (–) NVIDIA(GPU-0): HP 27es (DFP-2): 600.0 MHz maximum pixel clock
[ 1397.064] (–) NVIDIA(GPU-0): HP 27es (DFP-2): connected
[ 1397.078] (–) NVIDIA(GPU-0): HP 27es (DFP-2): Internal TMDS
[ 1397.078] (–) NVIDIA(GPU-0): HP 27es (DFP-2): 600.0 MHz maximum pixel clock
[ 1397.079] (–) NVIDIA(GPU-0):
[ 1397.108] (–) NVIDIA(GPU-0): HP 27es (DFP-2): connected
[ 1397.108] (–) NVIDIA(GPU-0): HP 27es (DFP-2): Internal TMDS
[ 1397.108] (–) NVIDIA(GPU-0): HP 27es (DFP-2): 600.0 MHz maximum pixel clock
[ 1440.194] (–) NVIDIA(GPU-0): HP 27es (DFP-2): connected
[ 1440.194] (–) NVIDIA(GPU-0): HP 27es (DFP-2): Internal TMDS
[ 1440.194] (–) NVIDIA(GPU-0): HP 27es (DFP-2): 600.0 MHz maximum pixel clock
[ 1440.223] (–) NVIDIA(GPU-0): HP 27es (DFP-2): connected
[ 1440.223] (–) NVIDIA(GPU-0): HP 27es (DFP-2): Internal TMDS
[ 1440.223] (–) NVIDIA(GPU-0): HP 27es (DFP-2): 600.0 MHz maximum pixel clock
[ 3749.099] (–) NVIDIA(GPU-0): HP 27es (DFP-2): connected
[ 3752.353] (–) NVIDIA(GPU-0): HP 27es (DFP-2): Internal TMDS
[ 3752.353] (–) NVIDIA(GPU-0): HP 27es (DFP-2): 600.0 MHz maximum pixel clock
[ 3752.383] (–) NVIDIA(GPU-0): HP 27es (DFP-2): connected
[ 3752.383] (–) NVIDIA(GPU-0): HP 27es (DFP-2): Internal TMDS
[ 3752.383] (–) NVIDIA(GPU-0): HP 27es (DFP-2): 600.0 MHz maximum pixel clock
[ 3795.725] (–) NVIDIA(GPU-0): DFP-0: disconnected
[ 3795.726] (–) NVIDIA(GPU-0): DFP-0: Internal DisplayPort
[ 3795.726] (–) NVIDIA(GPU-0): DFP-0: 1440.0 MHz maximum pixel clock
[ 3795.726] (–) NVIDIA(GPU-0): DFP-1: disconnected
[ 3795.726] (–) NVIDIA(GPU-0): DFP-1: Internal TMDS
[ 3795.726] (–) NVIDIA(GPU-0): DFP-1: 165.0 MHz maximum pixel clock
[ 3795.785] (–) NVIDIA(GPU-0): HP 27es (DFP-2): connected
[ 3795.785] (–) NVIDIA(GPU-0): HP 27es (DFP-2): Internal TMDS
[ 3795.785] (–) NVIDIA(GPU-0): HP 27es (DFP-2): 600.0 MHz maximum pixel clock
[ 3795.796] (II) NVIDIA(0): Setting mode “DFP-2:nvidia-auto-select”
[ 3796.534] (–) NVIDIA(GPU-0): HP 27es (DFP-2): connected
[ 3796.534] (–) NVIDIA(GPU-0): HP 27es (DFP-2): Internal TMDS
[ 3796.534] (–) NVIDIA(GPU-0): HP 27es (DFP-2): 600.0 MHz maximum pixel clock
[ 3796.564] (–) NVIDIA(GPU-0): HP 27es (DFP-2): connected
[ 3796.564] (–) NVIDIA(GPU-0): HP 27es (DFP-2): Internal TMDS
[ 3796.564] (–) NVIDIA(GPU-0): HP 27es (DFP-2): 600.0 MHz maximum pixel clock
[ 3886.607] (–) NVIDIA(GPU-0): HP 27es (DFP-2): connected
[ 3886.607] (–) NVIDIA(GPU-0): HP 27es (DFP-2): Internal TMDS
[ 3886.607] (–) NVIDIA(GPU-0): HP 27es (DFP-2): 600.0 MHz maximum pixel clock
[ 3886.637] (–) NVIDIA(GPU-0): HP 27es (DFP-2): connected
[ 3886.637] (–) NVIDIA(GPU-0): HP 27es (DFP-2): Internal TMDS
[ 3886.637] (–) NVIDIA(GPU-0): HP 27es (DFP-2): 600.0 MHz maximum pixel clock
[ 4008.347] (–) NVIDIA(GPU-0): HP 27es (DFP-2): connected
[ 4008.347] (–) NVIDIA(GPU-0): HP 27es (DFP-2): Internal TMDS
[ 4008.347] (–) NVIDIA(GPU-0): HP 27es (DFP-2): 600.0 MHz maximum pixel clock
[ 4008.376] (–) NVIDIA(GPU-0): HP 27es (DFP-2): connected
[ 4008.376] (–) NVIDIA(GPU-0): HP 27es (DFP-2): Internal TMDS
[ 4008.376] (–) NVIDIA(GPU-0): HP 27es (DFP-2): 600.0 MHz maximum pixel clock
[ 4684.613] (–) NVIDIA(GPU-0): HP 27es (DFP-2): connected
[ 4684.613] (–) NVIDIA(GPU-0): HP 27es (DFP-2): Internal TMDS
[ 4684.613] (–) NVIDIA(GPU-0): HP 27es (DFP-2): 600.0 MHz maximum pixel clock
[ 4684.643] (–) NVIDIA(GPU-0): HP 27es (DFP-2): connected
[ 4684.643] (–) NVIDIA(GPU-0): HP 27es (DFP-2): Internal TMDS
[ 4684.643] (–) NVIDIA(GPU-0): HP 27es (DFP-2): 600.0 MHz maximum pixel clock
[ 4720.262] (–) NVIDIA(GPU-0): HP 27es (DFP-2): connected
[ 4720.262] (–) NVIDIA(GPU-0): HP 27es (DFP-2): Internal TMDS
[ 4720.262] (–) NVIDIA(GPU-0): HP 27es (DFP-2): 600.0 MHz maximum pixel clock
[ 4720.291] (–) NVIDIA(GPU-0): HP 27es (DFP-2): connected
[ 4720.291] (–) NVIDIA(GPU-0): HP 27es (DFP-2): Internal TMDS
[ 4720.291] (–) NVIDIA(GPU-0): HP 27es (DFP-2): 600.0 MHz maximum pixel clock
[ 5489.568] (–) NVIDIA(GPU-0): HP 27es (DFP-2): connected
[ 5489.568] (–) NVIDIA(GPU-0): HP 27es (DFP-2): Internal TMDS
[ 5489.568] (–) NVIDIA(GPU-0): HP 27es (DFP-2): 600.0 MHz maximum pixel clock
[ 5489.597] (–) NVIDIA(GPU-0): HP 27es (DFP-2): connected
[ 5489.597] (–) NVIDIA(GPU-0): HP 27es (DFP-2): Internal TMDS
[ 5489.597] (–) NVIDIA(GPU-0): HP 27es (DFP-2): 600.0 MHz maximum pixel clock
[ 6010.133] (–) NVIDIA(GPU-0): HP 27es (DFP-2): connected
[ 6010.133] (–) NVIDIA(GPU-0): HP 27es (DFP-2): Internal TMDS
[ 6010.133] (–) NVIDIA(GPU-0): HP 27es (DFP-2): 600.0 MHz maximum pixel clock
[ 6010.163] (–) NVIDIA(GPU-0): HP 27es (DFP-2): connected
[ 6010.163] (–) NVIDIA(GPU-0): HP 27es (DFP-2): Internal TMDS
[ 6010.163] (–) NVIDIA(GPU-0): HP 27es (DFP-2): 600.0 MHz maximum pixel clock
*** /etc/X11/xorg.conf
*** ls: -rw-r–r-- 1 root root 1332 2018-07-07 16:27:53.737098545 +0100 /etc/X11/xorg.conf
nvidia-xconfig: X configuration file generated by nvidia-xconfig
nvidia-xconfig: version 390.67 (buildmeister@swio-display-x64-rhel04-18) Fri Jun 1 04:26:22 PDT 2018
Section “ServerLayout”
Identifier “Layout0”
Screen 0 “Screen0” 0 0
InputDevice “Keyboard0” “CoreKeyboard”
InputDevice “Mouse0” “CorePointer”
EndSection
Section “Files”
EndSection
Section “InputDevice”
# generated from default
Identifier "Mouse0"
Driver "mouse"
Option "Protocol" "auto"
Option "Device" "/dev/psaux"
Option "Emulate3Buttons" "no"
Option "ZAxisMapping" "4 5"
EndSection
Identifier "Keyboard0"
Driver "kbd"
EndSection
Section “Monitor”
Identifier “Monitor0”
VendorName “Unknown”
ModelName “Unknown”
HorizSync 28.0 - 33.0
VertRefresh 43.0 - 72.0
Option “DPMS”
EndSection
Section “Device”
Identifier “Device0”
Driver “nvidia”
VendorName “NVIDIA Corporation”
EndSection
Section “Screen”
Identifier “Screen0”
Device “Device0”
Monitor “Monitor0”
DefaultDepth 24
SubSection “Display”
Depth 24
EndSubSection
EndSection
*** /usr/share/X11/xorg.conf.d/10-amdgpu.conf
*** ls: -rw-r–r-- 1 root root 92 2018-06-14 15:23:33.000000000 +0100 /usr/share/X11/xorg.conf.d/10-amdgpu.conf
Section “OutputClass”
Identifier “AMDgpu”
MatchDriver “amdgpu”
Driver “amdgpu”
EndSection
*** /usr/share/X11/xorg.conf.d/10-evdev.conf
*** ls: -rw-r–r-- 1 root root 1099 2017-07-06 22:11:07.000000000 +0100 /usr/share/X11/xorg.conf.d/10-evdev.conf
Catch-all evdev loader for udev-based systems
We don’t simply match on any device since that also adds accelerometers
and other devices that we don’t really want to use. The list below
matches everything but joysticks.
Section “InputClass”
Identifier “evdev pointer catchall”
MatchIsPointer “on”
MatchDevicePath “/dev/input/event*”
Driver “evdev”
EndSection
Identifier “evdev keyboard catchall”
MatchIsKeyboard “on”
Driver “evdev”
EndSection
Identifier “evdev touchpad catchall”
MatchIsTouchpad “on”
Driver “evdev”
EndSection
Identifier “evdev tablet catchall”
MatchIsTablet “on”
Driver “evdev”
EndSection
Identifier “evdev touchscreen catchall”
MatchIsTouchscreen “on”
Driver “evdev”
EndSection
*** /usr/share/X11/xorg.conf.d/10-quirks.conf
*** ls: -rw-r–r-- 1 root root 1350 2018-06-14 18:26:36.000000000 +0100 /usr/share/X11/xorg.conf.d/10-quirks.conf
Collection of quirks and blacklist/whitelists for specific devices.
Accelerometer device, posts data through ABS_X/ABS_Y, making X unusable
Identifier “ThinkPad HDAPS accelerometer blacklist”
MatchProduct “ThinkPad HDAPS accelerometer data”
Option “Ignore” “on”
EndSection
Mouse does not move in PV Xen guest
Explicitly tell evdev to not ignore the absolute axes.
Identifier “Xen Virtual Pointer axis blacklist”
MatchProduct “Xen Virtual Pointer”
Option “IgnoreAbsoluteAxes” “off”
Option “IgnoreRelativeAxes” “off”
EndSection
Bug 55867 - Doesn’t know how to tag XI_TRACKBALL
Identifier “Tag trackballs as XI_TRACKBALL”
MatchProduct “trackball”
MatchDriver “evdev”
Option “TypeName” “TRACKBALL”
EndSection
Bug 62831 - Mionix Naos 5000 mouse detected incorrectly
Identifier “Tag Mionix Naos 5000 mouse XI_MOUSE”
MatchProduct “La-VIEW Technology Naos 5000 Mouse”
MatchDriver “evdev”
Option “TypeName” “MOUSE”
EndSection
*** /usr/share/X11/xorg.conf.d/10-radeon.conf
*** ls: -rw-r–r-- 1 root root 92 2018-06-14 15:16:01.000000000 +0100 /usr/share/X11/xorg.conf.d/10-radeon.conf
Identifier “Radeon”
MatchDriver “radeon”
Driver “radeon”
EndSection
*** /usr/share/X11/xorg.conf.d/11-evdev-quirks.conf
*** ls: -rw-r–r-- 1 root root 590 2017-07-06 22:10:42.000000000 +0100 /usr/share/X11/xorg.conf.d/11-evdev-quirks.conf
Identifier “Avago Technologies mouse quirks (LP: #746639)”
MatchIsPointer “on”
Driver “evdev”
MatchUSBID “192f:0416”
Option “Emulate3Buttons” “True”
Option “Emulate3Timeout” “50”
EndSection
X/Y axis not working due to device reporting absolute axes
Identifier “Benq m310”
MatchProduct “HID 0d62:1000”
Driver “evdev”
Option “IgnoreAbsoluteAxes” “true”
EndSection
*** /usr/share/X11/xorg.conf.d/11-evdev-trackpoint.conf
*** ls: -rw-r–r-- 1 root root 364 2017-07-06 22:10:42.000000000 +0100 /usr/share/X11/xorg.conf.d/11-evdev-trackpoint.conf
trackpoint users want wheel emulation
Identifier “trackpoint catchall”
MatchIsPointer “true”
MatchProduct “TrackPoint|DualPoint Stick”
Option "Emul
nvidia-bug-report.log.gz (97.4 KB)
