Hi, I have two Quadro P4000 cards in a system running Manjaro Linux with driver in version 418.43. The configuration already works with Base Mosaic, now I want to enable SLI Mosaic using a SLI HB bridge.
I followed the instructions as described by http://download.nvidia.com/XFree86/Linux-x86/340.104/README/sli.html.
After executing nvidia-xconfig --sli=Mosaic and restarting the display manager, the desktop starts and the display flickers a few times. The nvidia-settings tool doesn’t show the SLI Mosaic Mode Settings entry.
After searching the Xorg.0.log I found the following errors and warnings:
[ 422.353] (**) NVIDIA(0): NVIDIA SLI Mosaic mode selected.
[ 422.353] (**) NVIDIA(0): Enabling 2D acceleration
[ 422.868] (EE) NVIDIA(GPU-0): Failed to find a valid SLI configuration.
[ 422.868] (EE) NVIDIA(GPU-0): Invalid SLI configuration 1 of 1:
[ 422.868] (EE) NVIDIA(GPU-0): GPUs:
[ 422.868] (EE) NVIDIA(GPU-0): 1) NVIDIA GPU at PCI:2:0:0
[ 422.868] (EE) NVIDIA(GPU-0): 2) NVIDIA GPU at PCI:3:0:0
[ 422.868] (EE) NVIDIA(GPU-0): Errors:
[ 422.868] (EE) NVIDIA(GPU-0): - This configuration is not supported
[ 422.868] (WW) NVIDIA(GPU-0): Failed to find a valid SLI configuration for the NVIDIA
[ 422.868] (WW) NVIDIA(GPU-0): graphics device PCI:2:0:0. Please see Chapter 28:
[ 422.868] (WW) NVIDIA(GPU-0): Configuring SLI and Multi-GPU FrameRendering in the README
[ 422.868] (WW) NVIDIA(GPU-0): for troubleshooting suggestions.
[ 423.110] (EE) NVIDIA(GPU-0): Only one GPU will be used for this X screen.
According to the Xorg log, both cards are on a 16X PCI Express slot.
The complete Xorg log:
[ 422.346]
X.Org X Server 1.20.4
X Protocol Version 11, Revision 0
[ 422.346] Build Operating System: Linux Arch Linux
[ 422.346] Current Operating System: Linux sg 4.19.28-1-MANJARO #1 SMP PREEMPT Sun Mar 10 08:32:42 UTC 2019 x86_64
[ 422.346] Kernel command line: BOOT_IMAGE=/boot/vmlinuz-4.19-x86_64 root=UUID=474345a1-b6b0-4451-bf3b-019761b93c98 rw quiet resume=UUID=899ecf8f-fcb0-4dbc-8ab8-aaeb8a3ec126
[ 422.346] Build Date: 27 February 2019 04:04:00PM
[ 422.346]
[ 422.346] Current version of pixman: 0.38.0
[ 422.346] Before reporting problems, check http://wiki.x.org
to make sure that you have the latest version.
[ 422.346] Markers: (--) probed, (**) from config file, (==) default setting,
(++) from command line, (!!) notice, (II) informational,
(WW) warning, (EE) error, (NI) not implemented, (??) unknown.
[ 422.346] (==) Log file: "/var/log/Xorg.0.log", Time: Tue Mar 12 08:43:39 2019
[ 422.346] (==) Using config directory: "/etc/X11/xorg.conf.d"
[ 422.346] (==) Using system config directory "/usr/share/X11/xorg.conf.d"
[ 422.346] (==) ServerLayout "Layout0"
[ 422.346] (**) |-->Screen "Screen0" (0)
[ 422.346] (**) | |-->Monitor "Monitor0"
[ 422.346] (**) | |-->Device "Device0"
[ 422.346] (**) |-->Input Device "Keyboard0"
[ 422.346] (**) |-->Input Device "Mouse0"
[ 422.346] (==) Automatically adding devices
[ 422.346] (==) Automatically enabling devices
[ 422.346] (==) Automatically adding GPU devices
[ 422.346] (==) Automatically binding GPU devices
[ 422.346] (==) Max clients allowed: 256, resource mask: 0x1fffff
[ 422.346] (WW) The directory "/usr/share/fonts/OTF" does not exist.
[ 422.346] Entry deleted from font path.
[ 422.346] (WW) The directory "/usr/share/fonts/Type1" does not exist.
[ 422.346] (WW) `fonts.dir' not found (or not valid) in "/usr/share/fonts/100dpi".
[ 422.346] (Run 'mkfontdir' on "/usr/share/fonts/100dpi").
[ 422.346] (WW) `fonts.dir' not found (or not valid) in "/usr/share/fonts/75dpi".
[ 422.346] (Run 'mkfontdir' on "/usr/share/fonts/75dpi").
[ 422.346] (==) FontPath set to:
/usr/share/fonts/misc,
/usr/share/fonts/TTF
[ 422.346] (==) ModulePath set to "/usr/lib/xorg/modules"
[ 422.346] (WW) Hotplugging is on, devices using drivers 'kbd', 'mouse' or 'vmmouse' will be disabled.
[ 422.346] (WW) Disabling Keyboard0
[ 422.346] (WW) Disabling Mouse0
[ 422.346] (II) Module ABI versions:
[ 422.346] X.Org ANSI C Emulation: 0.4
[ 422.346] X.Org Video Driver: 24.0
[ 422.346] X.Org XInput driver : 24.1
[ 422.346] X.Org Server Extension : 10.0
[ 422.347] (++) using VT number 7
[ 422.347] (II) systemd-logind: logind integration requires -keeptty and -keeptty was not provided, disabling logind integration
[ 422.347] (II) xfree86: Adding drm device (/dev/dri/card0)
[ 422.347] (II) xfree86: Adding drm device (/dev/dri/card1)
[ 422.348] (**) OutputClass "nvidia" ModulePath extended to "/usr/lib/nvidia/xorg,/usr/lib/xorg/modules,/usr/lib/xorg/modules"
[ 422.348] (**) OutputClass "nvidia" ModulePath extended to "/usr/lib/nvidia/xorg,/usr/lib/xorg/modules,/usr/lib/nvidia/xorg,/usr/lib/xorg/modules,/usr/lib/xorg/modules"
[ 422.348] (**) OutputClass "nvidia" setting /dev/dri/card0 as PrimaryGPU
[ 422.349] (--) PCI:*(2@0:0:0) 10de:1bb1:10de:11a3 rev 161, Mem @ 0xf2000000/16777216, 0xe0000000/268435456, 0xf0000000/33554432, I/O @ 0x0000e000/128, BIOS @ 0x????????/131072
[ 422.349] (--) PCI: (3@0:0:0) 10de:1bb1:10de:11a3 rev 161, Mem @ 0xd2000000/16777216, 0xc0000000/268435456, 0xd0000000/33554432, I/O @ 0x0000d000/128, BIOS @ 0x????????/524288
[ 422.349] (WW) Open ACPI failed (/var/run/acpid.socket) (No such file or directory)
[ 422.349] (II) LoadModule: "glx"
[ 422.349] (II) Loading /usr/lib/nvidia/xorg/libglx.so
[ 422.352] (II) Module glx: vendor="NVIDIA Corporation"
[ 422.352] compiled for 4.0.2, module version = 1.0.0
[ 422.352] Module class: X.Org Server Extension
[ 422.352] (II) NVIDIA GLX Module 418.43 Tue Feb 19 01:05:57 CST 2019
[ 422.352] (II) LoadModule: "nvidia"
[ 422.352] (II) Loading /usr/lib/xorg/modules/drivers/nvidia_drv.so
[ 422.352] (II) Module nvidia: vendor="NVIDIA Corporation"
[ 422.352] Module class: X.Org Video Driver
[ 422.352] (II) NVIDIA dlloader X Driver 418.43 Tue Feb 19 01:07:27 CST 2019
[ 422.352] (II) NVIDIA Unified Driver for all Supported NVIDIA GPUs
[ 422.352] (II) Loading sub module "fb"
[ 422.352] (II) LoadModule: "fb"
[ 422.352] (II) Loading /usr/lib/xorg/modules/libfb.so
[ 422.352] (II) Module fb: vendor="X.Org Foundation"
[ 422.352] compiled for 1.20.4, module version = 1.0.0
[ 422.352] ABI class: X.Org ANSI C Emulation, version 0.4
[ 422.352] (II) Loading sub module "wfb"
[ 422.352] (II) LoadModule: "wfb"
[ 422.352] (II) Loading /usr/lib/xorg/modules/libwfb.so
[ 422.352] (II) Module wfb: vendor="X.Org Foundation"
[ 422.352] (II) Loading sub module "ramdac"
[ 422.352] (II) LoadModule: "ramdac"
[ 422.352] (II) Module "ramdac" already built-in
[ 422.353] (**) NVIDIA(0): Depth 24, (--) framebuffer bpp 32
[ 422.353] (==) NVIDIA(0): RGB weight 888
[ 422.353] (==) NVIDIA(0): Default visual is TrueColor
[ 422.353] (==) NVIDIA(0): Using gamma correction (1.0, 1.0, 1.0)
[ 422.353] (II) Applying OutputClass "nvidia" options to /dev/dri/card0
[ 422.353] (**) NVIDIA(0): Option "SLI" "Mosaic"
[ 422.353] (**) NVIDIA(0): Option "AllowEmptyInitialConfiguration"
[ 423.420] (--) NVIDIA(0): Valid display device(s) on GPU-0 at PCI:2:0:0
[ 423.420] (--) NVIDIA(0): DFP-0
[ 423.420] (--) NVIDIA(0): DFP-1
[ 423.420] (--) NVIDIA(0): DFP-2
[ 423.420] (--) NVIDIA(0): DFP-3
[ 423.420] (--) NVIDIA(0): DFP-4
[ 423.420] (--) NVIDIA(0): DFP-5
[ 423.420] (--) NVIDIA(0): DFP-6 (boot)
[ 423.420] (--) NVIDIA(0): DFP-7
[ 423.421] (II) NVIDIA(0): NVIDIA GPU Quadro P4000 (GP104GL-A) at PCI:2:0:0 (GPU-0)
[ 423.421] (--) NVIDIA(0): Memory: 8388608 kBytes
[ 423.421] (--) NVIDIA(0): VideoBIOS: 86.04.56.00.0b
[ 423.421] (II) NVIDIA(0): Detected PCI Express Link width: 16X
[ 423.421] (--) NVIDIA(GPU-0): DFP-0: disconnected
[ 423.421] (--) NVIDIA(GPU-0): DFP-0: Internal DisplayPort
[ 423.421] (--) NVIDIA(GPU-0): DFP-0: 1440.0 MHz maximum pixel clock
[ 423.421] (--) NVIDIA(GPU-0): DFP-1: disconnected
[ 423.421] (--) NVIDIA(GPU-0): DFP-1: Internal TMDS
[ 423.421] (--) NVIDIA(GPU-0): DFP-1: 165.0 MHz maximum pixel clock
[ 423.421] (--) NVIDIA(GPU-0): DFP-2: disconnected
[ 423.421] (--) NVIDIA(GPU-0): DFP-2: Internal DisplayPort
[ 423.421] (--) NVIDIA(GPU-0): DFP-2: 1440.0 MHz maximum pixel clock
[ 423.421] (--) NVIDIA(GPU-0): DFP-3: disconnected
[ 423.421] (--) NVIDIA(GPU-0): DFP-3: Internal TMDS
[ 423.421] (--) NVIDIA(GPU-0): DFP-3: 165.0 MHz maximum pixel clock
[ 423.421] (--) NVIDIA(GPU-0): DFP-4: disconnected
[ 423.421] (--) NVIDIA(GPU-0): DFP-4: Internal DisplayPort
[ 423.421] (--) NVIDIA(GPU-0): DFP-4: 1440.0 MHz maximum pixel clock
[ 423.422] (--) NVIDIA(GPU-0): DFP-5: disconnected
[ 423.422] (--) NVIDIA(GPU-0): DFP-5: Internal TMDS
[ 423.422] (--) NVIDIA(GPU-0): DFP-5: 165.0 MHz maximum pixel clock
[ 423.422] (--) NVIDIA(GPU-0): LG Electronics LG Ultra HD (DFP-6): connected
[ 423.422] (--) NVIDIA(GPU-0): LG Electronics LG Ultra HD (DFP-6): Internal DisplayPort
[ 423.422] (--) NVIDIA(GPU-0): LG Electronics LG Ultra HD (DFP-6): 1440.0 MHz maximum pixel clock
[ 423.423] (--) NVIDIA(GPU-0): DFP-7: disconnected
[ 423.423] (--) NVIDIA(GPU-0): DFP-7: Internal TMDS
[ 423.423] (--) NVIDIA(GPU-0): DFP-7: 165.0 MHz maximum pixel clock
[ 423.425] (==) NVIDIA(0):
[ 423.425] (==) NVIDIA(0): No modes were requested; the default mode "nvidia-auto-select"
[ 423.425] (==) NVIDIA(0): will be used as the requested mode.
[ 423.425] (II) NVIDIA(0): Validated MetaModes:
[ 423.425] (II) NVIDIA(0): "DFP-6:nvidia-auto-select"
[ 423.425] (II) NVIDIA(0): Virtual screen size determined to be 3840 x 2160
[ 423.430] (--) NVIDIA(0): DPI set to (162, 161); computed from "UseEdidDpi" X config
[ 423.430] (--) NVIDIA(0): option
[ 423.463] (--) NVIDIA(0): Valid display device(s) on GPU-1 at PCI:3:0:0
[ 423.463] (--) NVIDIA(0): DFP-0
[ 423.463] (--) NVIDIA(0): DFP-1
[ 423.463] (--) NVIDIA(0): DFP-2
[ 423.463] (--) NVIDIA(0): DFP-3
[ 423.463] (--) NVIDIA(0): DFP-4
[ 423.463] (--) NVIDIA(0): DFP-5
[ 423.463] (--) NVIDIA(0): DFP-6 (boot)
[ 423.463] (--) NVIDIA(0): DFP-7
[ 423.464] (--) NVIDIA(GPU-1): DFP-0: disconnected
[ 423.464] (--) NVIDIA(GPU-1): DFP-0: Internal DisplayPort
[ 423.464] (--) NVIDIA(GPU-1): DFP-0: 1440.0 MHz maximum pixel clock
[ 423.464] (--) NVIDIA(GPU-1): DFP-1: disconnected
[ 423.464] (--) NVIDIA(GPU-1): DFP-1: Internal TMDS
[ 423.464] (--) NVIDIA(GPU-1): DFP-1: 165.0 MHz maximum pixel clock
[ 423.464] (--) NVIDIA(GPU-1): DFP-2: disconnected
[ 423.464] (--) NVIDIA(GPU-1): DFP-2: Internal DisplayPort
[ 423.464] (--) NVIDIA(GPU-1): DFP-2: 1440.0 MHz maximum pixel clock
[ 423.464] (--) NVIDIA(GPU-1): DFP-3: disconnected
[ 423.464] (--) NVIDIA(GPU-1): DFP-3: Internal TMDS
[ 423.464] (--) NVIDIA(GPU-1): DFP-3: 165.0 MHz maximum pixel clock
[ 423.464] (--) NVIDIA(GPU-1): DFP-4: disconnected
[ 423.464] (--) NVIDIA(GPU-1): DFP-4: Internal DisplayPort
[ 423.464] (--) NVIDIA(GPU-1): DFP-4: 1440.0 MHz maximum pixel clock
[ 423.464] (--) NVIDIA(GPU-1): DFP-5: disconnected
[ 423.464] (--) NVIDIA(GPU-1): DFP-5: Internal TMDS
[ 423.464] (--) NVIDIA(GPU-1): DFP-5: 165.0 MHz maximum pixel clock
[ 423.466] (--) NVIDIA(GPU-1): LG Electronics LG Ultra HD (DFP-6): connected
[ 423.466] (--) NVIDIA(GPU-1): LG Electronics LG Ultra HD (DFP-6): Internal DisplayPort
[ 423.466] (--) NVIDIA(GPU-1): LG Electronics LG Ultra HD (DFP-6): 1440.0 MHz maximum pixel clock
[ 423.467] (--) NVIDIA(GPU-1): DFP-7: disconnected
[ 423.467] (--) NVIDIA(GPU-1): DFP-7: Internal TMDS
[ 423.467] (--) NVIDIA(GPU-1): DFP-7: 165.0 MHz maximum pixel clock
[ 423.498] (II) NVIDIA(GPU-1): NVIDIA GPU Quadro P4000 (GP104GL-A) at PCI:3:0:0 (GPU-1)
[ 423.498] (--) NVIDIA(GPU-1): Memory: 8388608 kBytes
[ 423.498] (--) NVIDIA(GPU-1): VideoBIOS: 86.04.56.00.0b
[ 423.498] (II) NVIDIA(GPU-1): Detected PCI Express Link width: 16X
[ 423.501] (II) NVIDIA: Using 24576.00 MB of virtual memory for indirect memory
[ 423.501] (II) NVIDIA: access.
[ 423.502] (II) NVIDIA(0): ACPI: failed to connect to the ACPI event daemon; the daemon
[ 423.502] (II) NVIDIA(0): may not be running or the "AcpidSocketPath" X
[ 423.502] (II) NVIDIA(0): configuration option may not be set correctly. When the
[ 423.502] (II) NVIDIA(0): ACPI event daemon is available, the NVIDIA X driver will
[ 423.502] (II) NVIDIA(0): try to use it to receive ACPI event notifications. For
[ 423.502] (II) NVIDIA(0): details, please see the "ConnectToAcpid" and
[ 423.502] (II) NVIDIA(0): "AcpidSocketPath" X configuration options in Appendix B: X
[ 423.502] (II) NVIDIA(0): Config Options in the README.
[ 423.516] (II) NVIDIA(0): Setting mode "DFP-6:nvidia-auto-select"
[ 423.587] (==) NVIDIA(0): Disabling shared memory pixmaps
[ 423.587] (==) NVIDIA(0): Backing store enabled
[ 423.587] (==) NVIDIA(0): Silken mouse disabled
[ 423.587] (**) NVIDIA(0): DPMS enabled
[ 423.587] (WW) NVIDIA(0): Option "PrimaryGPU" is not used
[ 423.587] (II) Loading sub module "dri2"
[ 423.587] (II) LoadModule: "dri2"
[ 423.587] (II) Module "dri2" already built-in
[ 423.587] (II) NVIDIA(0): [DRI2] Setup complete
[ 423.587] (II) NVIDIA(0): [DRI2] VDPAU driver: nvidia
[ 423.587] (II) Initializing extension Generic Event Extension
[ 423.587] (II) Initializing extension SHAPE
[ 423.587] (II) Initializing extension MIT-SHM
[ 423.587] (II) Initializing extension XInputExtension
[ 423.588] (II) Initializing extension XTEST
[ 423.588] (II) Initializing extension BIG-REQUESTS
[ 423.588] (II) Initializing extension SYNC
[ 423.588] (II) Initializing extension XKEYBOARD
[ 423.588] (II) Initializing extension XC-MISC
[ 423.588] (II) Initializing extension SECURITY
[ 423.588] (II) Initializing extension XFIXES
[ 423.588] (II) Initializing extension RENDER
[ 423.588] (II) Initializing extension RANDR
[ 423.588] (II) Initializing extension COMPOSITE
[ 423.588] (II) Initializing extension DAMAGE
[ 423.588] (II) Initializing extension MIT-SCREEN-SAVER
[ 423.588] (II) Initializing extension DOUBLE-BUFFER
[ 423.588] (II) Initializing extension RECORD
[ 423.588] (II) Initializing extension DPMS
[ 423.588] (II) Initializing extension Present
[ 423.588] (II) Initializing extension DRI3
[ 423.588] (II) Initializing extension X-Resource
[ 423.589] (II) Initializing extension XVideo
[ 423.589] (II) Initializing extension XVideo-MotionCompensation
[ 423.589] (II) Initializing extension GLX
[ 423.589] (II) Indirect GLX disabled.
[ 423.589] (II) Initializing extension XFree86-VidModeExtension
[ 423.589] (II) Initializing extension XFree86-DGA
[ 423.589] (II) Initializing extension XFree86-DRI
[ 423.589] (II) Initializing extension DRI2
[ 423.589] (II) Initializing extension NV-GLX
[ 423.589] (II) Initializing extension NV-CONTROL
[ 423.589] (II) Initializing extension XINERAMA
[ 423.610] (II) config/udev: Adding input device Power Button (/dev/input/event1)
[ 423.610] (**) Power Button: Applying InputClass "evdev keyboard catchall"
[ 423.610] (**) Power Button: Applying InputClass "libinput keyboard catchall"
[ 423.610] (**) Power Button: Applying InputClass "system-keyboard"
[ 423.610] (II) LoadModule: "libinput"
[ 423.610] (II) Loading /usr/lib/xorg/modules/input/libinput_drv.so
[ 423.611] (II) Module libinput: vendor="X.Org Foundation"
[ 423.611] compiled for 1.20.3, module version = 0.28.2
[ 423.611] Module class: X.Org XInput Driver
[ 423.611] ABI class: X.Org XInput driver, version 24.1
[ 423.611] (II) Using input driver 'libinput' for 'Power Button'
[ 423.611] (**) Power Button: always reports core events
[ 423.611] (**) Option "Device" "/dev/input/event1"
[ 423.611] (**) Option "_source" "server/udev"
[ 423.612] (II) event1 - Power Button: is tagged by udev as: Keyboard
[ 423.612] (II) event1 - Power Button: device is a keyboard
[ 423.612] (II) event1 - Power Button: device removed
[ 423.651] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXPWRBN:00/input/input1/event1"
[ 423.651] (II) XINPUT: Adding extended input device "Power Button" (type: KEYBOARD, id 6)
[ 423.651] (**) Option "xkb_model" "pc105"
[ 423.651] (**) Option "xkb_layout" "de"
[ 423.667] (II) event1 - Power Button: is tagged by udev as: Keyboard
[ 423.667] (II) event1 - Power Button: device is a keyboard
[ 423.667] (II) config/udev: Adding input device Power Button (/dev/input/event0)
[ 423.667] (**) Power Button: Applying InputClass "evdev keyboard catchall"
[ 423.667] (**) Power Button: Applying InputClass "libinput keyboard catchall"
[ 423.667] (**) Power Button: Applying InputClass "system-keyboard"
[ 423.667] (II) Using input driver 'libinput' for 'Power Button'
[ 423.667] (**) Power Button: always reports core events
[ 423.667] (**) Option "Device" "/dev/input/event0"
[ 423.667] (**) Option "_source" "server/udev"
[ 423.668] (II) event0 - Power Button: is tagged by udev as: Keyboard
[ 423.668] (II) event0 - Power Button: device is a keyboard
[ 423.668] (II) event0 - Power Button: device removed
[ 423.705] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0C:00/input/input0/event0"
[ 423.705] (II) XINPUT: Adding extended input device "Power Button" (type: KEYBOARD, id 7)
[ 423.705] (**) Option "xkb_model" "pc105"
[ 423.705] (**) Option "xkb_layout" "de"
[ 423.705] (II) event0 - Power Button: is tagged by udev as: Keyboard
[ 423.705] (II) event0 - Power Button: device is a keyboard
[ 423.706] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=3 (/dev/input/event13)
[ 423.706] (II) No input driver specified, ignoring this device.
[ 423.706] (II) This device may have been added with another device file.
[ 423.706] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=7 (/dev/input/event14)
[ 423.706] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=8 (/dev/input/event15)
[ 423.707] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=9 (/dev/input/event16)
[ 423.707] (II) No input driver specified, ignoring this device.
[ 423.707] (II) This device may have been added with another device file.
[ 423.707] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=3 (/dev/input/event17)
[ 423.707] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=7 (/dev/input/event18)
[ 423.708] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=8 (/dev/input/event19)
[ 423.708] (II) No input driver specified, ignoring this device.
[ 423.708] (II) This device may have been added with another device file.
[ 423.708] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=9 (/dev/input/event20)
[ 423.709] (II) config/udev: Adding input device PixArt Cherry USB Optical Mouse (/dev/input/event11)
[ 423.709] (**) PixArt Cherry USB Optical Mouse: Applying InputClass "evdev pointer catchall"
[ 423.709] (**) PixArt Cherry USB Optical Mouse: Applying InputClass "libinput pointer catchall"
[ 423.709] (II) Using input driver 'libinput' for 'PixArt Cherry USB Optical Mouse'
[ 423.709] (**) PixArt Cherry USB Optical Mouse: always reports core events
[ 423.709] (**) Option "Device" "/dev/input/event11"
[ 423.709] (**) Option "_source" "server/udev"
[ 423.766] (II) event11 - PixArt Cherry USB Optical Mouse: is tagged by udev as: Mouse
[ 423.766] (II) event11 - PixArt Cherry USB Optical Mouse: device is a pointer
[ 423.766] (II) event11 - PixArt Cherry USB Optical Mouse: device removed
[ 423.831] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:14.0/usb2/2-14/2-14.2/2-14.2:1.0/0003:046A:B091.0001/input/input11/event11"
[ 423.831] (II) XINPUT: Adding extended input device "PixArt Cherry USB Optical Mouse" (type: MOUSE, id 8)
[ 423.832] (**) Option "AccelerationScheme" "none"
[ 423.832] (**) PixArt Cherry USB Optical Mouse: (accel) selected scheme none/0
[ 423.832] (**) PixArt Cherry USB Optical Mouse: (accel) acceleration factor: 2.000
[ 423.832] (**) PixArt Cherry USB Optical Mouse: (accel) acceleration threshold: 4
[ 423.889] (II) event11 - PixArt Cherry USB Optical Mouse: is tagged by udev as: Mouse
[ 423.890] (II) event11 - PixArt Cherry USB Optical Mouse: device is a pointer
[ 423.890] (II) config/udev: Adding input device PixArt Cherry USB Optical Mouse (/dev/input/mouse0)
[ 423.890] (II) No input driver specified, ignoring this device.
[ 423.890] (II) This device may have been added with another device file.
[ 423.891] (II) config/udev: Adding input device Sun USB Keyboard (/dev/input/event12)
[ 423.891] (**) Sun USB Keyboard: Applying InputClass "evdev keyboard catchall"
[ 423.891] (**) Sun USB Keyboard: Applying InputClass "libinput keyboard catchall"
[ 423.891] (**) Sun USB Keyboard: Applying InputClass "system-keyboard"
[ 423.891] (II) Using input driver 'libinput' for 'Sun USB Keyboard'
[ 423.891] (**) Sun USB Keyboard: always reports core events
[ 423.891] (**) Option "Device" "/dev/input/event12"
[ 423.891] (**) Option "_source" "server/udev"
[ 423.893] (II) event12 - Sun USB Keyboard: is tagged by udev as: Keyboard
[ 423.893] (II) event12 - Sun USB Keyboard: device is a keyboard
[ 423.893] (II) event12 - Sun USB Keyboard: device removed
[ 423.945] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:14.0/usb2/2-14/2-14.4/2-14.4:1.0/0003:0430:00A2.0002/input/input12/event12"
[ 423.945] (II) XINPUT: Adding extended input device "Sun USB Keyboard" (type: KEYBOARD, id 9)
[ 423.945] (**) Option "xkb_model" "pc105"
[ 423.945] (**) Option "xkb_layout" "de"
[ 423.947] (II) event12 - Sun USB Keyboard: is tagged by udev as: Keyboard
[ 423.947] (II) event12 - Sun USB Keyboard: device is a keyboard
[ 423.947] (II) config/udev: Adding input device HDA Intel PCH Front Headphone (/dev/input/event10)
[ 423.947] (II) No input driver specified, ignoring this device.
[ 423.947] (II) This device may have been added with another device file.
[ 423.948] (II) config/udev: Adding input device HDA Digital PCBeep (/dev/input/event3)
[ 423.948] (II) No input driver specified, ignoring this device.
[ 423.948] (II) This device may have been added with another device file.
[ 423.948] (II) config/udev: Adding input device HDA Intel PCH Front Mic (/dev/input/event4)
[ 423.949] (II) config/udev: Adding input device HDA Intel PCH Rear Mic (/dev/input/event5)
[ 423.949] (II) No input driver specified, ignoring this device.
[ 423.949] (II) This device may have been added with another device file.
[ 423.949] (II) config/udev: Adding input device HDA Intel PCH Line (/dev/input/event6)
[ 423.949] (II) config/udev: Adding input device HDA Intel PCH Line Out Front (/dev/input/event7)
[ 423.950] (II) config/udev: Adding input device HDA Intel PCH Line Out Surround (/dev/input/event8)
[ 423.950] (II) No input driver specified, ignoring this device.
[ 423.950] (II) This device may have been added with another device file.
[ 423.950] (II) config/udev: Adding input device HDA Intel PCH Line Out CLFE (/dev/input/event9)
[ 423.951] (II) config/udev: Adding input device PC Speaker (/dev/input/event2)
[ 423.951] (II) No input driver specified, ignoring this device.
[ 423.951] (II) This device may have been added with another device file.
[ 423.955] (--) NVIDIA(GPU-0): LG Electronics LG Ultra HD (DFP-6): connected
[ 423.955] (--) NVIDIA(GPU-0): LG Electronics LG Ultra HD (DFP-6): Internal DisplayPort
[ 423.955] (--) NVIDIA(GPU-0): LG Electronics LG Ultra HD (DFP-6): 1440.0 MHz maximum pixel clock
[ 423.956] (--) NVIDIA(GPU-1): LG Electronics LG Ultra HD (DFP-6): connected
[ 423.956] (--) NVIDIA(GPU-1): LG Electronics LG Ultra HD (DFP-6): Internal DisplayPort
[ 423.956] (--) NVIDIA(GPU-1): LG Electronics LG Ultra HD (DFP-6): 1440.0 MHz maximum pixel clock
[ 424.291] (--) NVIDIA(GPU-0): DFP-0: disconnected
[ 424.291] (--) NVIDIA(GPU-0): DFP-0: Internal DisplayPort
[ 424.291] (--) NVIDIA(GPU-0): DFP-0: 1440.0 MHz maximum pixel clock
[ 424.291] (--) NVIDIA(GPU-0): DFP-1: disconnected
[ 424.291] (--) NVIDIA(GPU-0): DFP-1: Internal TMDS
[ 424.291] (--) NVIDIA(GPU-0): DFP-1: 165.0 MHz maximum pixel clock
[ 424.291] (--) NVIDIA(GPU-0): DFP-2: disconnected
[ 424.291] (--) NVIDIA(GPU-0): DFP-2: Internal DisplayPort
[ 424.291] (--) NVIDIA(GPU-0): DFP-2: 1440.0 MHz maximum pixel clock
[ 424.291] (--) NVIDIA(GPU-0): DFP-3: disconnected
[ 424.291] (--) NVIDIA(GPU-0): DFP-3: Internal TMDS
[ 424.291] (--) NVIDIA(GPU-0): DFP-3: 165.0 MHz maximum pixel clock
[ 424.291] (--) NVIDIA(GPU-0): DFP-4: disconnected
[ 424.291] (--) NVIDIA(GPU-0): DFP-4: Internal DisplayPort
[ 424.291] (--) NVIDIA(GPU-0): DFP-4: 1440.0 MHz maximum pixel clock
[ 424.291] (--) NVIDIA(GPU-0): DFP-5: disconnected
[ 424.291] (--) NVIDIA(GPU-0): DFP-5: Internal TMDS
[ 424.291] (--) NVIDIA(GPU-0): DFP-5: 165.0 MHz maximum pixel clock
[ 424.292] (--) NVIDIA(GPU-0): LG Electronics LG Ultra HD (DFP-6): connected
[ 424.292] (--) NVIDIA(GPU-0): LG Electronics LG Ultra HD (DFP-6): Internal DisplayPort
[ 424.292] (--) NVIDIA(GPU-0): LG Electronics LG Ultra HD (DFP-6): 1440.0 MHz maximum pixel clock
[ 424.293] (--) NVIDIA(GPU-0): DFP-7: disconnected
[ 424.293] (--) NVIDIA(GPU-0): DFP-7: Internal TMDS
[ 424.293] (--) NVIDIA(GPU-0): DFP-7: 165.0 MHz maximum pixel clock
[ 424.297] (II) NVIDIA(0): Setting mode "NULL"
[ 424.341] (II) NVIDIA(0): Setting mode "DP-6: nvidia-auto-select @3840x2160 +0+0 {ViewPortIn=3840x2160, ViewPortOut=3840x2160+0+0}"
[ 424.458] (--) NVIDIA(GPU-0): DFP-0: disconnected
[ 424.458] (--) NVIDIA(GPU-0): DFP-0: Internal DisplayPort
[ 424.458] (--) NVIDIA(GPU-0): DFP-0: 1440.0 MHz maximum pixel clock
[ 424.458] (--) NVIDIA(GPU-0): DFP-1: disconnected
[ 424.458] (--) NVIDIA(GPU-0): DFP-1: Internal TMDS
[ 424.459] (--) NVIDIA(GPU-0): DFP-1: 165.0 MHz maximum pixel clock
[ 424.459] (--) NVIDIA(GPU-0): DFP-2: disconnected
[ 424.459] (--) NVIDIA(GPU-0): DFP-2: Internal DisplayPort
[ 424.459] (--) NVIDIA(GPU-0): DFP-2: 1440.0 MHz maximum pixel clock
[ 424.459] (--) NVIDIA(GPU-0): DFP-3: disconnected
[ 424.459] (--) NVIDIA(GPU-0): DFP-3: Internal TMDS
[ 424.459] (--) NVIDIA(GPU-0): DFP-3: 165.0 MHz maximum pixel clock
[ 424.459] (--) NVIDIA(GPU-0): DFP-4: disconnected
[ 424.459] (--) NVIDIA(GPU-0): DFP-4: Internal DisplayPort
[ 424.459] (--) NVIDIA(GPU-0): DFP-4: 1440.0 MHz maximum pixel clock
[ 424.459] (--) NVIDIA(GPU-0): DFP-5: disconnected
[ 424.459] (--) NVIDIA(GPU-0): DFP-5: Internal TMDS
[ 424.459] (--) NVIDIA(GPU-0): DFP-5: 165.0 MHz maximum pixel clock
[ 424.459] (--) NVIDIA(GPU-0): LG Electronics LG Ultra HD (DFP-6): connected
[ 424.459] (--) NVIDIA(GPU-0): LG Electronics LG Ultra HD (DFP-6): Internal DisplayPort
[ 424.459] (--) NVIDIA(GPU-0): LG Electronics LG Ultra HD (DFP-6): 1440.0 MHz maximum pixel clock
[ 424.460] (--) NVIDIA(GPU-0): DFP-7: disconnected
[ 424.460] (--) NVIDIA(GPU-0): DFP-7: Internal TMDS
[ 424.460] (--) NVIDIA(GPU-0): DFP-7: 165.0 MHz maximum pixel clock
[ 424.465] (II) NVIDIA(0): Setting mode "NULL"
[ 424.495] (II) NVIDIA(0): Setting mode "DP-6: nvidia-auto-select @3840x2160 +0+0 {ViewPortIn=3840x2160, ViewPortOut=3840x2160+0+0}"
[ 430.059] (--) NVIDIA(GPU-0): DFP-0: disconnected
[ 430.059] (--) NVIDIA(GPU-0): DFP-0: Internal DisplayPort
[ 430.059] (--) NVIDIA(GPU-0): DFP-0: 1440.0 MHz maximum pixel clock
[ 430.060] (--) NVIDIA(GPU-0): DFP-1: disconnected
[ 430.060] (--) NVIDIA(GPU-0): DFP-1: Internal TMDS
[ 430.060] (--) NVIDIA(GPU-0): DFP-1: 165.0 MHz maximum pixel clock
[ 430.060] (--) NVIDIA(GPU-0): DFP-2: disconnected
[ 430.060] (--) NVIDIA(GPU-0): DFP-2: Internal DisplayPort
[ 430.060] (--) NVIDIA(GPU-0): DFP-2: 1440.0 MHz maximum pixel clock
[ 430.060] (--) NVIDIA(GPU-0): DFP-3: disconnected
[ 430.060] (--) NVIDIA(GPU-0): DFP-3: Internal TMDS
[ 430.060] (--) NVIDIA(GPU-0): DFP-3: 165.0 MHz maximum pixel clock
[ 430.060] (--) NVIDIA(GPU-0): DFP-4: disconnected
[ 430.060] (--) NVIDIA(GPU-0): DFP-4: Internal DisplayPort
[ 430.060] (--) NVIDIA(GPU-0): DFP-4: 1440.0 MHz maximum pixel clock
[ 430.060] (--) NVIDIA(GPU-0): DFP-5: disconnected
[ 430.060] (--) NVIDIA(GPU-0): DFP-5: Internal TMDS
[ 430.060] (--) NVIDIA(GPU-0): DFP-5: 165.0 MHz maximum pixel clock
[ 430.060] (--) NVIDIA(GPU-0): LG Electronics LG Ultra HD (DFP-6): connected
[ 430.060] (--) NVIDIA(GPU-0): LG Electronics LG Ultra HD (DFP-6): Internal DisplayPort
[ 430.060] (--) NVIDIA(GPU-0): LG Electronics LG Ultra HD (DFP-6): 1440.0 MHz maximum pixel clock
[ 430.061] (--) NVIDIA(GPU-0): DFP-7: disconnected
[ 430.061] (--) NVIDIA(GPU-0): DFP-7: Internal TMDS
[ 430.061] (--) NVIDIA(GPU-0): DFP-7: 165.0 MHz maximum pixel clock
[ 430.066] (II) NVIDIA(0): Setting mode "NULL"
[ 430.102] (II) NVIDIA(0): Setting mode "DP-6: nvidia-auto-select @3840x2160 +0+0 {ViewPortIn=3840x2160, ViewPortOut=3840x2160+0+0}"
[ 445.052] (--) NVIDIA(GPU-0): DFP-0: disconnected
[ 445.052] (--) NVIDIA(GPU-0): DFP-0: Internal DisplayPort
[ 445.052] (--) NVIDIA(GPU-0): DFP-0: 1440.0 MHz maximum pixel clock
[ 445.052] (--) NVIDIA(GPU-0): DFP-1: disconnected
[ 445.052] (--) NVIDIA(GPU-0): DFP-1: Internal TMDS
[ 445.052] (--) NVIDIA(GPU-0): DFP-1: 165.0 MHz maximum pixel clock
[ 445.052] (--) NVIDIA(GPU-0): DFP-2: disconnected
[ 445.052] (--) NVIDIA(GPU-0): DFP-2: Internal DisplayPort
[ 445.052] (--) NVIDIA(GPU-0): DFP-2: 1440.0 MHz maximum pixel clock
[ 445.052] (--) NVIDIA(GPU-0): DFP-3: disconnected
[ 445.052] (--) NVIDIA(GPU-0): DFP-3: Internal TMDS
[ 445.052] (--) NVIDIA(GPU-0): DFP-3: 165.0 MHz maximum pixel clock
[ 445.052] (--) NVIDIA(GPU-0): DFP-4: disconnected
[ 445.052] (--) NVIDIA(GPU-0): DFP-4: Internal DisplayPort
[ 445.052] (--) NVIDIA(GPU-0): DFP-4: 1440.0 MHz maximum pixel clock
[ 445.052] (--) NVIDIA(GPU-0): DFP-5: disconnected
[ 445.052] (--) NVIDIA(GPU-0): DFP-5: Internal TMDS
[ 445.052] (--) NVIDIA(GPU-0): DFP-5: 165.0 MHz maximum pixel clock
[ 445.052] (--) NVIDIA(GPU-0): LG Electronics LG Ultra HD (DFP-6): connected
[ 445.052] (--) NVIDIA(GPU-0): LG Electronics LG Ultra HD (DFP-6): Internal DisplayPort
[ 445.052] (--) NVIDIA(GPU-0): LG Electronics LG Ultra HD (DFP-6): 1440.0 MHz maximum pixel clock
[ 445.053] (--) NVIDIA(GPU-0): DFP-7: disconnected
[ 445.053] (--) NVIDIA(GPU-0): DFP-7: Internal TMDS
[ 445.053] (--) NVIDIA(GPU-0): DFP-7: 165.0 MHz maximum pixel clock
[ 445.059] (II) NVIDIA(0): Setting mode "NULL"
[ 445.099] (II) NVIDIA(0): Setting mode "DP-6: nvidia-auto-select @3840x2160 +0+0 {ViewPortIn=3840x2160, ViewPortOut=3840x2160+0+0}"
[ 470.133] (--) NVIDIA(GPU-0): DFP-0: disconnected
[ 470.133] (--) NVIDIA(GPU-0): DFP-0: Internal DisplayPort
[ 470.133] (--) NVIDIA(GPU-0): DFP-0: 1440.0 MHz maximum pixel clock
[ 470.134] (--) NVIDIA(GPU-0): DFP-1: disconnected
[ 470.134] (--) NVIDIA(GPU-0): DFP-1: Internal TMDS
[ 470.134] (--) NVIDIA(GPU-0): DFP-1: 165.0 MHz maximum pixel clock
[ 470.134] (--) NVIDIA(GPU-0): DFP-2: disconnected
[ 470.134] (--) NVIDIA(GPU-0): DFP-2: Internal DisplayPort
[ 470.134] (--) NVIDIA(GPU-0): DFP-2: 1440.0 MHz maximum pixel clock
[ 470.134] (--) NVIDIA(GPU-0): DFP-3: disconnected
[ 470.134] (--) NVIDIA(GPU-0): DFP-3: Internal TMDS
[ 470.134] (--) NVIDIA(GPU-0): DFP-3: 165.0 MHz maximum pixel clock
[ 470.134] (--) NVIDIA(GPU-0): DFP-4: disconnected
[ 470.134] (--) NVIDIA(GPU-0): DFP-4: Internal DisplayPort
[ 470.134] (--) NVIDIA(GPU-0): DFP-4: 1440.0 MHz maximum pixel clock
[ 470.134] (--) NVIDIA(GPU-0): DFP-5: disconnected
[ 470.134] (--) NVIDIA(GPU-0): DFP-5: Internal TMDS
[ 470.134] (--) NVIDIA(GPU-0): DFP-5: 165.0 MHz maximum pixel clock
[ 470.135] (--) NVIDIA(GPU-0): LG Electronics LG Ultra HD (DFP-6): connected
[ 470.135] (--) NVIDIA(GPU-0): LG Electronics LG Ultra HD (DFP-6): Internal DisplayPort
[ 470.135] (--) NVIDIA(GPU-0): LG Electronics LG Ultra HD (DFP-6): 1440.0 MHz maximum pixel clock
[ 470.136] (--) NVIDIA(GPU-0): DFP-7: disconnected
[ 470.136] (--) NVIDIA(GPU-0): DFP-7: Internal TMDS
[ 470.136] (--) NVIDIA(GPU-0): DFP-7: 165.0 MHz maximum pixel clock
[ 470.146] (II) NVIDIA(0): Setting mode "NULL"
[ 470.222] (II) NVIDIA(0): Setting mode "DP-6: nvidia-auto-select @3840x2160 +0+0 {ViewPortIn=3840x2160, ViewPortOut=3840x2160+0+0}"
[ 2688.230] (EE) Failed to open authorization file "/run/lightdm/root/:0": No such file or directory
Detailed lspci output:
02:00.0 VGA compatible controller: NVIDIA Corporation GP104GL [Quadro P4000] (rev a1) (prog-if 00 [VGA controller])
Subsystem: NVIDIA Corporation GP104GL [Quadro P4000]
Flags: bus master, fast devsel, latency 0, IRQ 30
Memory at f2000000 (32-bit, non-prefetchable)
Memory at e0000000 (64-bit, prefetchable)
Memory at f0000000 (64-bit, prefetchable)
I/O ports at e000
[virtual] Expansion ROM at 000c0000 [disabled]
Capabilities: [60] Power Management version 3
Capabilities: [68] MSI: Enable+ Count=1/1 Maskable- 64bit+
Capabilities: [78] Express Legacy Endpoint, MSI 00
Capabilities: [100] Virtual Channel
Capabilities: [250] Latency Tolerance Reporting
Capabilities: [128] Power Budgeting <?>
Capabilities: [420] Advanced Error Reporting
Capabilities: [600] Vendor Specific Information: ID=0001 Rev=1 Len=024 <?>
Capabilities: [900] Secondary PCI Express <?>
Kernel driver in use: nvidia
Kernel modules: nouveau, nvidia_drm, nvidia
00: de 10 b1 1b 07 00 10 00 a1 00 00 03 00 00 80 00
10: 00 00 00 f2 0c 00 00 e0 00 00 00 00 0c 00 00 f0
20: 00 00 00 00 01 e0 00 00 00 00 00 00 de 10 a3 11
30: 00 00 00 00 60 00 00 00 00 00 00 00 0a 01 00 00
40: de 10 a3 11 00 00 00 00 00 00 00 00 00 00 00 00
50: 01 00 00 00 01 00 00 00 ce d6 23 00 00 00 00 00
60: 01 68 03 00 08 00 00 00 05 78 81 00 04 00 e2 fe
70: 00 00 00 00 22 40 00 00 10 00 12 00 e1 8d 2c 01
80: 10 21 00 00 03 3d 46 01 40 01 41 10 00 00 00 00
90: 00 00 00 00 00 00 00 00 00 00 00 00 13 08 04 00
a0: 00 04 00 00 0e 00 00 00 03 00 1f 00 00 00 00 00
b0: 00 00 00 00 09 00 14 01 00 00 10 80 00 00 00 00
c0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
d0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
e0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
f0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
02:00.1 Audio device: NVIDIA Corporation GP104 High Definition Audio Controller (rev a1)
Subsystem: NVIDIA Corporation GP104 High Definition Audio Controller
Flags: bus master, fast devsel, latency 0, IRQ 18
Memory at f3080000 (32-bit, non-prefetchable)
Capabilities: [68] MSI: Enable- Count=1/1 Maskable- 64bit+
Capabilities: [78] Express Endpoint, MSI 00
Capabilities: [100] Advanced Error Reporting
Kernel driver in use: snd_hda_intel
Kernel modules: snd_hda_intel
00: de 10 f0 10 06 00 10 00 a1 00 03 04 10 00 80 00
10: 00 00 08 f3 00 00 00 00 00 00 00 00 00 00 00 00
20: 00 00 00 00 00 00 00 00 00 00 00 00 de 10 a3 11
30: 00 00 00 00 60 00 00 00 00 00 00 00 05 02 00 00
50: 00 00 00 00 00 00 00 00 ce d6 23 00 00 00 00 00
60: 01 68 03 00 08 00 00 00 05 78 80 00 00 00 00 00
70: 00 00 00 00 00 00 00 00 10 00 02 00 e1 8d 2c 01
80: 00 29 09 00 03 3d 45 01 40 01 41 10 00 00 00 00
a0: 00 00 00 00 0e 00 00 00 00 00 01 00 00 00 00 00
b0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
03:00.0 VGA compatible controller: NVIDIA Corporation GP104GL [Quadro P4000] (rev a1) (prog-if 00 [VGA controller])
Flags: bus master, fast devsel, latency 0, IRQ 31
Memory at d2000000 (32-bit, non-prefetchable)
Memory at c0000000 (64-bit, prefetchable)
Memory at d0000000 (64-bit, prefetchable)
I/O ports at d000
[virtual] Expansion ROM at d3000000 [disabled]
10: 00 00 00 d2 0c 00 00 c0 00 00 00 00 0c 00 00 d0
20: 00 00 00 00 01 d0 00 00 00 00 00 00 de 10 a3 11
30: 00 00 00 00 60 00 00 00 00 00 00 00 05 01 00 00
60: 01 68 03 00 08 00 00 00 05 78 81 00 04 00 e4 fe
80: 10 21 00 00 03 3d 46 02 40 01 41 10 00 00 00 00
03:00.1 Audio device: NVIDIA Corporation GP104 High Definition Audio Controller (rev a1)
Flags: bus master, fast devsel, latency 0, IRQ 19
Memory at d3080000 (32-bit, non-prefetchable)
10: 00 00 08 d3 00 00 00 00 00 00 00 00 00 00 00 00
30: 00 00 00 00 60 00 00 00 00 00 00 00 03 02 00 00
80: 00 29 09 00 03 3d 45 02 43 01 41 10 00 00 00 00
lspci -t output:
-[0000:00]-+-00.0
+-01.0-[01]--
+-01.1-[02]--+-00.0
| \-00.1
+-01.2-[03]--+-00.0
| \-00.1
+-14.0
+-16.0
+-19.0
+-1a.0
+-1b.0
+-1c.0-[04]--
+-1c.2-[05]----00.0
+-1d.0
+-1f.0
+-1f.2
\-1f.3
Unfurtunately searching google with the This configuration is not supported error in combination with SLI Mosaic doesn’t come up with anything helpful.
nvidia-bug-report.log.gz (1.51 MB)
