I have a box with CentOS 8 Stream and the following cards:
[root@alta X11]# lspci | grep -i nvidia | grep -i vga
0000:17:00.0 VGA compatible controller: NVIDIA Corporation GA102 [GeForce RTX 3090] (rev a1)
0000:65:00.0 VGA compatible controller: NVIDIA Corporation GP107GL [Quadro P620] (rev a1)
0000:b3:00.0 VGA compatible controller: NVIDIA Corporation GP107GL [Quadro P620] (rev a1)
I have WaylandEnable=false in /etc/gdm/custom.conf
A single monitor is connected to the last Quadro card.
If I try to start X with no xorg.conf I get:
[ 6785.383] (EE) NVIDIA(GPU-0): Failed to find a valid Base Mosaic configuration.
[ 6785.383] (EE) NVIDIA(GPU-0): Invalid Base Mosaic configuration 1 of 4:
[ 6785.383] (EE) NVIDIA(GPU-0): GPUs:
[ 6785.383] (EE) NVIDIA(GPU-0): 1) NVIDIA GPU at PCI:101:0:0
[ 6785.383] (EE) NVIDIA(GPU-0): 2) NVIDIA GPU at PCI:179:0:0
[ 6785.383] (EE) NVIDIA(GPU-0): Errors:
[ 6785.383] (EE) NVIDIA(GPU-0): - Does not contain GPU selected for this X screen
[ 6785.383] (EE) NVIDIA(GPU-0): Invalid Base Mosaic configuration 2 of 4:
[ 6785.383] (EE) NVIDIA(GPU-0): 1) NVIDIA GPU at PCI:23:0:0
[ 6785.383] (EE) NVIDIA(GPU-0): 2) NVIDIA GPU at PCI:101:0:0
[ 6785.383] (EE) NVIDIA(GPU-0): 3) NVIDIA GPU at PCI:179:0:0
[ 6785.383] (EE) NVIDIA(GPU-0): - The video link was not detected
[ 6785.383] (EE) NVIDIA(GPU-0): - Chipset not approved for SLI
[ 6785.383] (EE) NVIDIA(GPU-0): - GPU PCI IDs do not match
[ 6785.383] (EE) NVIDIA(GPU-0): Invalid Base Mosaic configuration 3 of 4:
[ 6785.383] (EE) NVIDIA(GPU-0): - Unknown error
[ 6785.383] (EE) NVIDIA(GPU-0): Invalid Base Mosaic configuration 4 of 4:
[ 6785.383] (WW) NVIDIA(GPU-0): Failed to find a valid Base Mosaic configuration for the
[ 6785.383] (WW) NVIDIA(GPU-0): NVIDIA graphics device PCI:23:0:0. Please see Chapter 30:
[ 6785.383] (WW) NVIDIA(GPU-0): Configuring SLI and Multi-GPU Mosaic in the README for
[ 6785.383] (WW) NVIDIA(GPU-0): troubleshooting suggestions.
[ 6785.383] (EE) NVIDIA(GPU-0): Only one GPU will be used for this X screen.
[ 6785.384] (EE) NVIDIA(GPU-0): Failed to select a display subsystem.
[ 6785.384] (EE) NVIDIA(0): Failing initialization of X screen
If I run with simply
Section “Device”
Identifier “Videocard0”
Driver “nvidia”
BusID “PCI:179:0:0”
EndSection
I get
[ 6964.585] (EE) NVIDIA(GPU-0): Failed to select a display subsystem.
[ 6964.586] (EE) NVIDIA(GPU-0): Only one GPU will be used for this X screen.
[ 6964.586] (EE) NVIDIA(GPU-0): The NVIDIA graphics device PCI:179:0:0 is part of an active
[ 6964.586] (EE) NVIDIA(GPU-0): SLI configuration and is currently unavailable for single
[ 6964.586] (EE) NVIDIA(GPU-0): GPU rendering. Please see Chapter 30: Configuring SLI and
[ 6964.586] (EE) NVIDIA(GPU-0): Multi-GPU Mosaic in the README for troubleshooting
[ 6964.586] (EE) NVIDIA(GPU-0): information.
[ 6964.586] (EE) *** Aborting ***
[ 6964.586] (EE) NVIDIA(0): Failing initialization of X screen
If I run ‘nvidia-xconfig --sli=mosaic’ and use that xorg.conf which has:
Section “Device”
Identifier “Device0”
Driver “nvidia”
VendorName “NVIDIA Corporation”
EndSection
Section “Screen”
Identifier “Screen0”
Device “Device0”
Monitor “Monitor0”
DefaultDepth 24
Option “SLI” “mosaic”
SubSection “Display”
Depth 24
EndSubSection
EndSection
I get the same error as originally
Is there anyway to make this configuration work?
