Hello Guys,
i recently bought a new rig:
Two Geforce GTX 780
Two Asus PB287Q
Nvidia driver 346.22
Gentoo Kernel 3.14.14
connected a monitor to each card with Displayport, switched stream to DP1.2 on monitor Setup.
In short: i am unable to get BOTH monitors working in 60Hz, no matter what i do in config file.
Could anyone assist me with this? :(
I am able to run ONE monitor with ONE card at DP in 4k with 60Hz without any issues, though…
Is there any way to FORCE DP1.2 stream from the beginning?
cat /var/log/Xorg.0.log
[ 359.371]
X.Org X Server 1.15.0
Release Date: 2013-12-27
[ 359.371] X Protocol Version 11, Revision 0
[ 359.371] Build Operating System: Linux 3.14.14-gentoo x86_64 Gentoo
[ 359.371] Current Operating System: Linux MaDWorkStatioN 3.14.14-gentoo #18 SMP PREEMPT Tue Oct 7 00:26:30 CEST 2014 x86_64
[ 359.371] Kernel command line: BOOT_IMAGE=/kernel-3.14.14-gentoo root=/dev/md2 ro resume=/dev/md1 rootfstype=ext4 video=uvesafb:1680x1050-32 quiet irqpoll
[ 359.371] Build Date: 07 September 2014 05:22:10PM
[ 359.371]
[ 359.371] Current version of pixman: 0.32.4
[ 359.371] Before reporting problems, check http://wiki.x.org
to make sure that you have the latest version.
[ 359.371] Markers: (--) probed, (**) from config file, (==) default setting,
(++) from command line, (!!) notice, (II) informational,
(WW) warning, (EE) error, (NI) not implemented, (??) unknown.
[ 359.371] (==) Log file: "/var/log/Xorg.0.log", Time: Tue Dec 16 08:06:03 2014
[ 359.371] (==) Using config file: "/etc/X11/xorg.conf"
[ 359.371] (==) Using system config directory "/usr/share/X11/xorg.conf.d"
[ 359.372] (==) ServerLayout "Layout0"
[ 359.372] (**) |-->Screen "Screen0" (0)
[ 359.372] (**) | |-->Monitor "Monitor0"
[ 359.372] (**) | |-->Device "Device0"
[ 359.372] (**) |-->Input Device "Keyboard0"
[ 359.372] (**) |-->Input Device "Mouse0"
[ 359.372] (**) Option "Xinerama" "0"
[ 359.372] (==) Automatically adding devices
[ 359.372] (==) Automatically enabling devices
[ 359.372] (==) Automatically adding GPU devices
[ 359.372] (==) FontPath set to:
/usr/share/fonts/misc/,
/usr/share/fonts/TTF/,
/usr/share/fonts/OTF/,
/usr/share/fonts/Type1/,
/usr/share/fonts/100dpi/,
/usr/share/fonts/75dpi/
[ 359.372] (==) ModulePath set to "/usr/lib64/xorg/modules"
[ 359.372] (WW) Hotplugging is on, devices using drivers 'kbd', 'mouse' or 'vmmouse' will be disabled.
[ 359.372] (WW) Disabling Keyboard0
[ 359.372] (WW) Disabling Mouse0
[ 359.372] (II) Loader magic: 0x807c60
[ 359.372] (II) Module ABI versions:
[ 359.372] X.Org ANSI C Emulation: 0.4
[ 359.372] X.Org Video Driver: 15.0
[ 359.372] X.Org XInput driver : 20.0
[ 359.372] X.Org Server Extension : 8.0
[ 359.378] (--) PCI:*(0:5:0:0) 10de:1004:10de:104b rev 161, Mem @ 0xb2000000/16777216, 0xa8000000/134217728, 0xb0000000/33554432, I/O @ 0x00009000/128, BIOS @ 0x????????/524288
[ 359.378] (--) PCI: (0:131:0:0) 10de:1004:10de:104b rev 161, Mem @ 0xfa000000/16777216, 0x381ff0000000/134217728, 0x381ff8000000/33554432, I/O @ 0x0000f000/128, BIOS @ 0x????????/524288
[ 359.378] Initializing built-in extension Generic Event Extension
[ 359.378] Initializing built-in extension SHAPE
[ 359.378] Initializing built-in extension MIT-SHM
[ 359.378] Initializing built-in extension XInputExtension
[ 359.378] Initializing built-in extension XTEST
[ 359.378] Initializing built-in extension BIG-REQUESTS
[ 359.378] Initializing built-in extension SYNC
[ 359.378] Initializing built-in extension XKEYBOARD
[ 359.378] Initializing built-in extension XC-MISC
[ 359.378] Initializing built-in extension XINERAMA
[ 359.378] Initializing built-in extension XFIXES
[ 359.378] Initializing built-in extension RENDER
[ 359.378] Initializing built-in extension RANDR
[ 359.378] Initializing built-in extension COMPOSITE
[ 359.378] Initializing built-in extension DAMAGE
[ 359.378] Initializing built-in extension MIT-SCREEN-SAVER
[ 359.378] Initializing built-in extension DOUBLE-BUFFER
[ 359.378] Initializing built-in extension RECORD
[ 359.378] Initializing built-in extension DPMS
[ 359.378] Initializing built-in extension Present
[ 359.378] Initializing built-in extension DRI3
[ 359.378] Initializing built-in extension X-Resource
[ 359.378] Initializing built-in extension XVideo
[ 359.378] Initializing built-in extension XVideo-MotionCompensation
[ 359.378] Initializing built-in extension XFree86-VidModeExtension
[ 359.378] Initializing built-in extension XFree86-DGA
[ 359.378] Initializing built-in extension XFree86-DRI
[ 359.378] Initializing built-in extension DRI2
[ 359.378] (II) LoadModule: "glx"
[ 359.378] (II) Loading /usr/lib64/xorg/modules/extensions/libglx.so
[ 359.393] (II) Module glx: vendor="NVIDIA Corporation"
[ 359.393] compiled for 4.0.2, module version = 1.0.0
[ 359.393] Module class: X.Org Server Extension
[ 359.393] (II) NVIDIA GLX Module 346.22 Tue Dec 2 10:20:26 PST 2014
[ 359.393] Loading extension GLX
[ 359.393] (II) LoadModule: "nvidia"
[ 359.393] (II) Loading /usr/lib64/xorg/modules/drivers/nvidia_drv.so
[ 359.393] (II) Module nvidia: vendor="NVIDIA Corporation"
[ 359.393] Module class: X.Org Video Driver
[ 359.393] (II) NVIDIA dlloader X Driver 346.22 Tue Dec 2 09:58:48 PST 2014
[ 359.393] (II) NVIDIA Unified Driver for all Supported NVIDIA GPUs
[ 359.394] (++) using VT number 7
[ 359.394] (II) Loading sub module "fb"
[ 359.394] (II) LoadModule: "fb"
[ 359.394] (II) Loading /usr/lib64/xorg/modules/libfb.so
[ 359.394] (II) Module fb: vendor="X.Org Foundation"
[ 359.394] compiled for 1.15.0, module version = 1.0.0
[ 359.394] ABI class: X.Org ANSI C Emulation, version 0.4
[ 359.394] (II) Loading sub module "wfb"
[ 359.394] (II) LoadModule: "wfb"
[ 359.394] (II) Loading /usr/lib64/xorg/modules/libwfb.so
[ 359.394] (II) Module wfb: vendor="X.Org Foundation"
[ 359.394] (II) Loading sub module "ramdac"
[ 359.394] (II) LoadModule: "ramdac"
[ 359.394] (II) Module "ramdac" already built-in
[ 359.395] (**) NVIDIA(0): Depth 24, (--) framebuffer bpp 32
[ 359.395] (==) NVIDIA(0): RGB weight 888
[ 359.395] (==) NVIDIA(0): Default visual is TrueColor
[ 359.395] (==) NVIDIA(0): Using gamma correction (1.0, 1.0, 1.0)
[ 359.395] (**) NVIDIA(0): Option "Stereo" "0"
[ 359.395] (**) NVIDIA(0): Option "nvidiaXineramaInfoOrder" "DFP-4"
[ 359.395] (**) NVIDIA(0): Option "SLI" "AFR"
[ 359.395] (**) NVIDIA(0): Option "BaseMosaic" "On"
[ 359.395] (**) NVIDIA(0): Stereo disabled by request
[ 359.395] (**) NVIDIA(0): NVIDIA SLI alternate frame rendering selected.
[ 359.395] (**) NVIDIA(0): Option "MetaModes" "GPU-77ec278d-3c36-9b8c-0fc4-c2d401d5c490.DP-1: nvidia-auto-select +0+0, GPU-e175e4c8-fab3-40ab-40fe-7517af41f893.DP-1: nvidia-auto-select +3840+0"
[ 359.395] (**) NVIDIA(0): Enabling 2D acceleration
[ 360.964] (II) NVIDIA(GPU-0): NVIDIA Base Mosaic enabled.
[ 361.133] (II) NVIDIA(0): NVIDIA GPU GeForce GTX 780 (GK110) at PCI:5:0:0 (GPU-0)
[ 361.133] (--) NVIDIA(0): Memory: 3145728 kBytes
[ 361.133] (--) NVIDIA(0): VideoBIOS: 80.10.36.00.01
[ 361.133] (II) NVIDIA(0): Detected PCI Express Link width: 16X
[ 361.133] (II) NVIDIA(0): NVIDIA GPU GeForce GTX 780 (GK110) at PCI:131:0:0 (GPU-1)
[ 361.219] (--) NVIDIA(0): Valid display device(s) on GeForce GTX 780 at PCI:5:0:0
[ 361.219] (--) NVIDIA(0): CRT-0
[ 361.219] (--) NVIDIA(0): DFP-0
[ 361.219] (--) NVIDIA(0): DFP-1
[ 361.219] (--) NVIDIA(0): DFP-2
[ 361.219] (--) NVIDIA(0): DFP-3
[ 361.219] (--) NVIDIA(0): Ancor Communications Inc ASUS PB287Q (DFP-4) (boot, connected)
[ 361.219] (--) NVIDIA(GPU-0): CRT-0: 400.0 MHz maximum pixel clock
[ 361.219] (--) NVIDIA(0): DFP-0: Internal TMDS
[ 361.219] (--) NVIDIA(GPU-0): DFP-0: 330.0 MHz maximum pixel clock
[ 361.219] (--) NVIDIA(0): DFP-1: Internal TMDS
[ 361.219] (--) NVIDIA(GPU-0): DFP-1: 165.0 MHz maximum pixel clock
[ 361.219] (--) NVIDIA(0): DFP-2: Internal TMDS
[ 361.219] (--) NVIDIA(GPU-0): DFP-2: 165.0 MHz maximum pixel clock
[ 361.219] (--) NVIDIA(0): DFP-3: Internal TMDS
[ 361.219] (--) NVIDIA(GPU-0): DFP-3: 330.0 MHz maximum pixel clock
[ 361.219] (--) NVIDIA(0): Ancor Communications Inc ASUS PB287Q (DFP-4): Internal DisplayPort
[ 361.219] (--) NVIDIA(GPU-0): Ancor Communications Inc ASUS PB287Q (DFP-4): 400.0 MHz maximum pixel clock
[ 361.219] (--) NVIDIA(0): Valid display device(s) on GeForce GTX 780 at PCI:131:0:0
[ 361.219] (--) NVIDIA(GPU-1): CRT-0: 400.0 MHz maximum pixel clock
[ 361.219] (--) NVIDIA(GPU-1): DFP-0: 330.0 MHz maximum pixel clock
[ 361.219] (--) NVIDIA(GPU-1): DFP-1: 165.0 MHz maximum pixel clock
[ 361.219] (--) NVIDIA(GPU-1): DFP-2: 165.0 MHz maximum pixel clock
[ 361.219] (--) NVIDIA(GPU-1): DFP-3: 330.0 MHz maximum pixel clock
[ 361.219] (--) NVIDIA(GPU-1): Ancor Communications Inc ASUS PB287Q (DFP-4): 400.0 MHz maximum pixel clock
[ 361.219] (**) NVIDIA(0): Using HorizSync/VertRefresh ranges from the EDID for display
[ 361.219] (**) NVIDIA(0): device Ancor Communications Inc ASUS PB287Q (DFP-4) (Using
[ 361.219] (**) NVIDIA(0): EDID frequencies has been enabled on all display
[ 361.219] (**) NVIDIA(0): devices.)
[ 361.238] (**) NVIDIA(0): Using HorizSync/VertRefresh ranges from the EDID for display
[ 361.238] (**) NVIDIA(0): device Ancor Communications Inc ASUS PB287Q (DFP-4) (Using
[ 361.238] (**) NVIDIA(0): EDID frequencies has been enabled on all display
[ 361.238] (**) NVIDIA(0): devices.)
[ 361.243] (II) NVIDIA(0): Validated MetaModes:
[ 361.243] (II) NVIDIA(0): "GPU-77ec278d-3c36-9b8c-0fc4-c2d401d5c490.DP-1:nvidia-auto-select+0+0,GPU-e175e4c8-fab3-40ab-40fe-7517af41f893.DP-1:nvidia-auto-select+3840+0"
[ 361.243] (II) NVIDIA(0): Virtual screen size determined to be 7680 x 2160
[ 361.246] (--) NVIDIA(0): DPI set to (157, 161); computed from "UseEdidDpi" X config
[ 361.246] (--) NVIDIA(0): option
[ 361.246] (--) Depth 24 pixmap format is 32 bpp
[ 361.246] (II) NVIDIA: Using 3072.00 MB of virtual memory for indirect memory
[ 361.246] (II) NVIDIA: access.
[ 361.255] (II) NVIDIA(0): ACPI: failed to connect to the ACPI event daemon; the daemon
[ 361.255] (II) NVIDIA(0): may not be running or the "AcpidSocketPath" X
[ 361.255] (II) NVIDIA(0): configuration option may not be set correctly. When the
[ 361.255] (II) NVIDIA(0): ACPI event daemon is available, the NVIDIA X driver will
[ 361.255] (II) NVIDIA(0): try to use it to receive ACPI event notifications. For
[ 361.255] (II) NVIDIA(0): details, please see the "ConnectToAcpid" and
[ 361.255] (II) NVIDIA(0): "AcpidSocketPath" X configuration options in Appendix B: X
[ 361.255] (II) NVIDIA(0): Config Options in the README.
[ 361.255] (II) NVIDIA(0): Setting mode "GPU-77ec278d-3c36-9b8c-0fc4-c2d401d5c490.DP-1:nvidia-auto-select+0+0,GPU-e175e4c8-fab3-40ab-40fe-7517af41f893.DP-1:nvidia-auto-select+3840+0"
[ 361.911] Loading extension NV-GLX
[ 361.998] (==) NVIDIA(0): Disabling shared memory pixmaps
[ 361.998] (==) NVIDIA(0): Backing store enabled
[ 361.998] (==) NVIDIA(0): Silken mouse enabled
[ 361.998] (**) NVIDIA(0): DPMS enabled
[ 361.998] Loading extension NV-CONTROL
[ 361.999] Loading extension XINERAMA
[ 361.999] (WW) NVIDIA(0): Option "Tripplebuffer" is not used
[ 361.999] (II) Loading sub module "dri2"
[ 361.999] (II) LoadModule: "dri2"
[ 361.999] (II) Module "dri2" already built-in
[ 361.999] (II) NVIDIA(0): [DRI2] Setup complete
[ 361.999] (II) NVIDIA(0): [DRI2] VDPAU driver: nvidia
[ 361.999] (--) RandR disabled
[ 362.006] (II) Initializing extension GLX
[ 362.124] (II) config/udev: Adding input device Power Button (/dev/input/event7)
[ 362.124] (**) Power Button: Applying InputClass "evdev keyboard catchall"
[ 362.124] (II) LoadModule: "evdev"
[ 362.124] (II) Loading /usr/lib64/xorg/modules/input/evdev_drv.so
[ 362.124] (II) Module evdev: vendor="X.Org Foundation"
[ 362.124] compiled for 1.15.0, module version = 2.8.2
[ 362.124] Module class: X.Org XInput Driver
[ 362.124] ABI class: X.Org XInput driver, version 20.0
[ 362.124] (II) Using input driver 'evdev' for 'Power Button'
[ 362.124] (**) Power Button: always reports core events
[ 362.124] (**) evdev: Power Button: Device: "/dev/input/event7"
[ 362.125] (--) evdev: Power Button: Vendor 0 Product 0x1
[ 362.125] (--) evdev: Power Button: Found keys
[ 362.125] (II) evdev: Power Button: Configuring as keyboard
[ 362.125] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXPWRBN:00/input/input10/event7"
[ 362.125] (II) XINPUT: Adding extended input device "Power Button" (type: KEYBOARD, id 6)
[ 362.125] (**) Option "xkb_rules" "evdev"
[ 362.125] (**) Option "xkb_model" "pc104"
[ 362.125] (**) Option "xkb_layout" "us"
[ 362.152] (II) config/udev: Adding input device Power Button (/dev/input/event6)
[ 362.152] (**) Power Button: Applying InputClass "evdev keyboard catchall"
[ 362.152] (II) Using input driver 'evdev' for 'Power Button'
[ 362.152] (**) Power Button: always reports core events
[ 362.153] (**) evdev: Power Button: Device: "/dev/input/event6"
[ 362.153] (--) evdev: Power Button: Vendor 0 Product 0x1
[ 362.153] (--) evdev: Power Button: Found keys
[ 362.153] (II) evdev: Power Button: Configuring as keyboard
[ 362.153] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/device:00/PNP0C0C:00/input/input9/event6"
[ 362.153] (II) XINPUT: Adding extended input device "Power Button" (type: KEYBOARD, id 7)
[ 362.153] (**) Option "xkb_rules" "evdev"
[ 362.153] (**) Option "xkb_model" "pc104"
[ 362.153] (**) Option "xkb_layout" "us"
[ 362.153] (II) config/udev: Adding input device Logitech USB Keyboard (/dev/input/event1)
[ 362.153] (**) Logitech USB Keyboard: Applying InputClass "evdev keyboard catchall"
[ 362.153] (II) Using input driver 'evdev' for 'Logitech USB Keyboard'
[ 362.153] (**) Logitech USB Keyboard: always reports core events
[ 362.153] (**) evdev: Logitech USB Keyboard: Device: "/dev/input/event1"
[ 362.153] (--) evdev: Logitech USB Keyboard: Vendor 0x46d Product 0xc326
[ 362.153] (--) evdev: Logitech USB Keyboard: Found keys
[ 362.153] (II) evdev: Logitech USB Keyboard: Configuring as keyboard
[ 362.153] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:1d.0/usb2/2-1/2-1.5/2-1.5:1.0/0003:046D:C326.0001/input/input4/event1"
[ 362.153] (II) XINPUT: Adding extended input device "Logitech USB Keyboard" (type: KEYBOARD, id 8)
[ 362.154] (II) config/udev: Adding input device Logitech USB Keyboard (/dev/input/event2)
[ 362.154] (**) Logitech USB Keyboard: Applying InputClass "evdev keyboard catchall"
[ 362.154] (II) Using input driver 'evdev' for 'Logitech USB Keyboard'
[ 362.154] (**) Logitech USB Keyboard: always reports core events
[ 362.154] (**) evdev: Logitech USB Keyboard: Device: "/dev/input/event2"
[ 362.154] (--) evdev: Logitech USB Keyboard: Vendor 0x46d Product 0xc326
[ 362.154] (--) evdev: Logitech USB Keyboard: Found 1 mouse buttons
[ 362.154] (--) evdev: Logitech USB Keyboard: Found scroll wheel(s)
[ 362.154] (--) evdev: Logitech USB Keyboard: Found relative axes
[ 362.154] (II) evdev: Logitech USB Keyboard: Forcing relative x/y axes to exist.
[ 362.154] (--) evdev: Logitech USB Keyboard: Found absolute axes
[ 362.154] (II) evdev: Logitech USB Keyboard: Forcing absolute x/y axes to exist.
[ 362.154] (--) evdev: Logitech USB Keyboard: Found keys
[ 362.154] (II) evdev: Logitech USB Keyboard: Configuring as mouse
[ 362.154] (II) evdev: Logitech USB Keyboard: Configuring as keyboard
[ 362.154] (II) evdev: Logitech USB Keyboard: Adding scrollwheel support
[ 362.154] (**) evdev: Logitech USB Keyboard: YAxisMapping: buttons 4 and 5
[ 362.154] (**) evdev: Logitech USB Keyboard: EmulateWheelButton: 4, EmulateWheelInertia: 10, EmulateWheelTimeout: 200
[ 362.154] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:1d.0/usb2/2-1/2-1.5/2-1.5:1.1/0003:046D:C326.0002/input/input5/event2"
[ 362.154] (II) XINPUT: Adding extended input device "Logitech USB Keyboard" (type: KEYBOARD, id 9)
[ 362.154] (**) Option "xkb_rules" "evdev"
[ 362.154] (**) Option "xkb_model" "pc104"
[ 362.154] (**) Option "xkb_layout" "us"
[ 362.154] (II) evdev: Logitech USB Keyboard: initialized for relative axes.
[ 362.154] (WW) evdev: Logitech USB Keyboard: ignoring absolute axes.
[ 362.155] (**) Logitech USB Keyboard: (accel) keeping acceleration scheme 1
[ 362.155] (**) Logitech USB Keyboard: (accel) acceleration profile 0
[ 362.155] (**) Logitech USB Keyboard: (accel) acceleration factor: 2.000
[ 362.155] (**) Logitech USB Keyboard: (accel) acceleration threshold: 4
[ 362.155] (II) config/udev: Adding input device Razer Razer Taipan (/dev/input/event3)
[ 362.155] (**) Razer Razer Taipan: Applying InputClass "evdev pointer catchall"
[ 362.155] (II) Using input driver 'evdev' for 'Razer Razer Taipan'
[ 362.155] (**) Razer Razer Taipan: always reports core events
[ 362.155] (**) evdev: Razer Razer Taipan: Device: "/dev/input/event3"
[ 362.155] (--) evdev: Razer Razer Taipan: Vendor 0x1532 Product 0x34
[ 362.155] (--) evdev: Razer Razer Taipan: Found 9 mouse buttons
[ 362.155] (--) evdev: Razer Razer Taipan: Found scroll wheel(s)
[ 362.155] (--) evdev: Razer Razer Taipan: Found relative axes
[ 362.155] (--) evdev: Razer Razer Taipan: Found x and y relative axes
[ 362.155] (II) evdev: Razer Razer Taipan: Configuring as mouse
[ 362.155] (II) evdev: Razer Razer Taipan: Adding scrollwheel support
[ 362.155] (**) evdev: Razer Razer Taipan: YAxisMapping: buttons 4 and 5
[ 362.155] (**) evdev: Razer Razer Taipan: EmulateWheelButton: 4, EmulateWheelInertia: 10, EmulateWheelTimeout: 200
[ 362.155] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:1d.0/usb2/2-1/2-1.6/2-1.6:1.0/0003:1532:0034.0003/input/input6/event3"
[ 362.155] (II) XINPUT: Adding extended input device "Razer Razer Taipan" (type: MOUSE, id 10)
[ 362.155] (II) evdev: Razer Razer Taipan: initialized for relative axes.
[ 362.155] (**) Razer Razer Taipan: (accel) keeping acceleration scheme 1
[ 362.156] (**) Razer Razer Taipan: (accel) acceleration profile 0
[ 362.156] (**) Razer Razer Taipan: (accel) acceleration factor: 2.000
[ 362.156] (**) Razer Razer Taipan: (accel) acceleration threshold: 4
[ 362.156] (II) config/udev: Adding input device Razer Razer Taipan (/dev/input/mouse0)
[ 362.156] (II) No input driver specified, ignoring this device.
[ 362.156] (II) This device may have been added with another device file.
[ 362.156] (II) config/udev: Adding input device Razer Razer Taipan (/dev/input/event4)
[ 362.156] (**) Razer Razer Taipan: Applying InputClass "evdev keyboard catchall"
[ 362.156] (II) Using input driver 'evdev' for 'Razer Razer Taipan'
[ 362.156] (**) Razer Razer Taipan: always reports core events
[ 362.156] (**) evdev: Razer Razer Taipan: Device: "/dev/input/event4"
[ 362.156] (II) evdev: Razer Razer Taipan: Using mtdev for this device
[ 362.156] (--) evdev: Razer Razer Taipan: Vendor 0x1532 Product 0x34
[ 362.156] (--) evdev: Razer Razer Taipan: Found 1 mouse buttons
[ 362.156] (--) evdev: Razer Razer Taipan: Found scroll wheel(s)
[ 362.156] (--) evdev: Razer Razer Taipan: Found relative axes
[ 362.156] (II) evdev: Razer Razer Taipan: Forcing relative x/y axes to exist.
[ 362.156] (--) evdev: Razer Razer Taipan: Found absolute axes
[ 362.156] (--) evdev: Razer Razer Taipan: Found absolute multitouch axes
[ 362.156] (--) evdev: Razer Razer Taipan: Found keys
[ 362.156] (II) evdev: Razer Razer Taipan: Configuring as mouse
[ 362.156] (II) evdev: Razer Razer Taipan: Configuring as keyboard
[ 362.156] (II) evdev: Razer Razer Taipan: Adding scrollwheel support
[ 362.156] (**) evdev: Razer Razer Taipan: YAxisMapping: buttons 4 and 5
[ 362.157] (**) evdev: Razer Razer Taipan: EmulateWheelButton: 4, EmulateWheelInertia: 10, EmulateWheelTimeout: 200
[ 362.157] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:1d.0/usb2/2-1/2-1.6/2-1.6:1.1/0003:1532:0034.0004/input/input7/event4"
[ 362.157] (II) XINPUT: Adding extended input device "Razer Razer Taipan" (type: KEYBOARD, id 11)
[ 362.157] (**) Option "xkb_rules" "evdev"
[ 362.157] (**) Option "xkb_model" "pc104"
[ 362.157] (**) Option "xkb_layout" "us"
[ 362.157] (II) evdev: Razer Razer Taipan: initialized for relative axes.
[ 362.157] (WW) evdev: Razer Razer Taipan: ignoring absolute axes.
[ 362.157] (**) Razer Razer Taipan: (accel) keeping acceleration scheme 1
[ 362.157] (**) Razer Razer Taipan: (accel) acceleration profile 0
[ 362.157] (**) Razer Razer Taipan: (accel) acceleration factor: 2.000
[ 362.157] (**) Razer Razer Taipan: (accel) acceleration threshold: 4
[ 362.157] (II) config/udev: Adding input device Razer Razer Taipan (/dev/input/event5)
[ 362.157] (**) Razer Razer Taipan: Applying InputClass "evdev keyboard catchall"
[ 362.157] (II) Using input driver 'evdev' for 'Razer Razer Taipan'
[ 362.157] (**) Razer Razer Taipan: always reports core events
[ 362.157] (**) evdev: Razer Razer Taipan: Device: "/dev/input/event5"
[ 362.157] (--) evdev: Razer Razer Taipan: Vendor 0x1532 Product 0x34
[ 362.157] (--) evdev: Razer Razer Taipan: Found keys
[ 362.157] (II) evdev: Razer Razer Taipan: Configuring as keyboard
[ 362.157] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:1d.0/usb2/2-1/2-1.6/2-1.6:1.2/0003:1532:0034.0005/input/input8/event5"
[ 362.157] (II) XINPUT: Adding extended input device "Razer Razer Taipan" (type: KEYBOARD, id 12)
[ 362.158] (II) config/udev: Adding input device PC Speaker (/dev/input/event0)
[ 362.158] (II) No input driver specified, ignoring this device.
[ 362.158] (II) This device may have been added with another device file.
[ 363.078] (**) NVIDIA(0): Using HorizSync/VertRefresh ranges from the EDID for display
[ 363.078] (**) NVIDIA(0): device Ancor Communications Inc ASUS PB287Q (DFP-4) (Using
[ 363.078] (**) NVIDIA(0): EDID frequencies has been enabled on all display
[ 363.078] (**) NVIDIA(0): devices.)
[ 412.068] [mi] Increasing EQ size to 1024 to prevent dropped events.
cat /etc/X11/xorg.conf
# nvidia-settings: X configuration file generated by nvidia-settings
# nvidia-settings: version 343.36 (buildmeister@swio-display-x86-rhel47-09) Mon Dec 1 16:46:59 PST 2014
Section "ServerLayout"
Identifier "Layout0"
Screen 0 "Screen0" 0 0
InputDevice "Keyboard0" "CoreKeyboard"
InputDevice "Mouse0" "CorePointer"
EndSection
Section "Files"
EndSection
Section "InputDevice"
# generated from data in "/etc/conf.d/gpm"
Identifier "Mouse0"
Driver "mouse"
Option "Protocol"
Option "Device" "/dev/input/mice"
Option "Emulate3Buttons" "no"
Option "ZAxisMapping" "4 5"
EndSection
# generated from default
Identifier "Keyboard0"
Driver "kbd"
EndSection
Section "Monitor"
# HorizSync source: edid, VertRefresh source: edid
Identifier "Monitor0"
VendorName "Asus PB287Q"
ModelName "Ancor Communications Inc ASUS PB287Q"
HorizSync 24.0 - 160.0
VertRefresh 30.0 - 80.0
Option "DPMS"
EndSection
Section "Device"
Identifier "Device0"
Driver "nvidia"
VendorName "NVIDIA Corporation"
BoardName "GeForce GTX 780"
BusID "PCI:5:0:0"
EndSection
Section "Device"
Driver "nvidia"
BusID "PCI:131:0:0"
EndSection
Section "Screen"
Identifier "Screen0"
Device "Device0"
Monitor "Monitor0"
DefaultDepth 24
Option "metamodes" "GPU-77ec278d-3c36-9b8c-0fc4-c2d401d5c490.DP-1: nvidia-auto-select +0+0, GPU-e175e4c8-fab3-40ab-40fe-7517af41f893.DP-1: nvidia-auto-select +3840+0"
Option "Stereo" "0"
Option "SLI" "AFR"
Option "Tripplebuffer" "On"
SubSection "Display"
Depth 24
EndSubSection
EndSection
xrandr
Screen 0: minimum 8 x 8, current 7680 x 2160, maximum 16384 x 16384
GPU-0.DVI-I-0 disconnected primary (normal left inverted right x axis y axis)
GPU-0.DVI-I-1 disconnected (normal left inverted right x axis y axis)
GPU-0.HDMI-0 disconnected (normal left inverted right x axis y axis)
GPU-0.DP-0 disconnected (normal left inverted right x axis y axis)
GPU-0.DVI-D-0 disconnected (normal left inverted right x axis y axis)
GPU-0.DP-1 connected 3840x2160+0+0 (normal left inverted right x axis y axis) 621mm x 341mm
3840x2160 30.0*+
2560x1600 60.0
2560x1440 60.0
1920x1080 60.0 59.9 50.0 60.0 50.0
1680x1050 60.0
1440x900 59.9
1280x1024 75.0 60.0
1280x960 60.0
1280x720 60.0 59.9 50.0
1152x864 75.0
1024x768 75.0 70.1 60.0
800x600 75.0 72.2 60.3 56.2
720x576 50.0
720x480 59.9
640x480 75.0 72.8 59.9 59.9
480x576 50.0
480x480 59.9
GPU-1.DVI-I-0 disconnected (normal left inverted right x axis y axis)
GPU-1.DVI-I-1 disconnected (normal left inverted right x axis y axis)
GPU-1.HDMI-0 disconnected (normal left inverted right x axis y axis)
GPU-1.DP-0 disconnected (normal left inverted right x axis y axis)
GPU-1.DVI-D-0 disconnected (normal left inverted right x axis y axis)
GPU-1.DP-1 connected 3840x2160+3840+0 (normal left inverted right x axis y axis) 620mm x 340mm
3840x2160 30.0*+
2560x1600 60.0
2560x1440 60.0
1680x1050 60.0
1440x900 59.9
1280x1024 75.0 60.0
1280x960 60.0
1152x864 75.0
720x576 50.0
720x480 59.9
480x576 50.0
480x480 59.9
