Hi, here is a new nvidia-bug-report.log while the monitors are connected as you requested.
nvidia-bug-report.log.gz (1.4 MB)
If it is helpful here is output from the xrandr command as well:
$ xrandr
xrandr: Output DP-1-2 is not disconnected but has no modes
Screen 0: minimum 8 x 8, current 7680 x 2880, maximum 32767 x 32767
HDMI-0 connected 2560x1440+5120+1440 (normal left inverted right x axis y axis) 597mm x 336mm
2560x1440 74.60*+ 59.95
1920x1080 60.00 59.94 50.00
1680x1050 59.95
1440x900 59.89
1440x576 50.00
1440x480 59.94
1280x1024 75.02 60.02
1280x960 60.00
1280x800 59.81
1280x720 60.00 59.94 50.00
1152x864 75.00
1024x768 75.03 70.07 60.00
800x600 75.00 72.19 60.32 56.25
720x576 50.00
720x480 59.94
640x480 75.00 59.94 59.93
DP-0 connected primary 2560x1440+2560+1440 (normal left inverted right x axis y axis) 600mm x 340mm
3840x2160 60.00 + 160.00 144.00 119.88 59.94 50.00
2560x1440 144.00*
1920x1080 119.93 119.88 60.00 59.94 50.00
1680x1050 119.99 59.95
1600x900 60.00
1440x900 60.00 59.89
1280x720 59.94 50.00
1152x864 75.00
720x576 50.00
720x480 59.94
640x480 75.00 72.81 59.94 59.93
DP-1 disconnected (normal left inverted right x axis y axis)
DP-2 connected 2560x1440+2560+0 (normal left inverted right x axis y axis) 597mm x 336mm
2560x1440 74.92*+ 59.95
1680x1050 59.95
1440x900 59.89
1440x576 50.00
1440x480 59.94
1280x960 60.00
1280x800 59.81
1152x864 75.00
720x576 50.00
720x480 59.94
DP-3 disconnected (normal left inverted right x axis y axis)
DP-4 connected 2560x1440+0+1440 (normal left inverted right x axis y axis) 597mm x 336mm
1680x1050 59.95
1440x900 59.89
1440x576 50.00
1440x480 59.94
1280x960 60.00
1280x800 59.81
1152x864 75.00
720x576 50.00
720x480 59.94
DP-5 disconnected (normal left inverted right x axis y axis)
DVI-D-1-0 connected 2560x1440+5120+0 (normal left inverted right x axis y axis) 597mm x 336mm
2560x1440 59.95*+
1920x1080 60.00
1680x1050 59.95
1440x900 59.89
1280x960 60.00
1280x800 59.81
1280x720 60.00
1152x864 75.00
640x480 75.00 59.94
HDMI-1-0 disconnected (normal left inverted right x axis y axis)
DP-1-0 disconnected (normal left inverted right x axis y axis)
DP-1-1 disconnected (normal left inverted right x axis y axis)
DP-1-2 connected (normal left inverted right x axis y axis)
DP-1-3 disconnected (normal left inverted right x axis y axis)
DP-1-4 disconnected (normal left inverted right x axis y axis)
DP-1-5 disconnected (normal left inverted right x axis y axis)
2560x1440 (0x1be) 241.500MHz +HSync -VSync
h: width 2560 start 2608 end 2640 total 2720 skew 0 clock 88.79KHz
v: height 1440 start 1443 end 1448 total 1481 clock 59.95Hz
1920x1080 (0x1bf) 148.500MHz +HSync +VSync
h: width 1920 start 2008 end 2052 total 2200 skew 0 clock 67.50KHz
v: height 1080 start 1084 end 1089 total 1125 clock 60.00Hz
1680x1050 (0x1c2) 146.250MHz -HSync +VSync
h: width 1680 start 1784 end 1960 total 2240 skew 0 clock 65.29KHz
v: height 1050 start 1053 end 1059 total 1089 clock 59.95Hz
1440x900 (0x1c3) 106.500MHz -HSync +VSync
h: width 1440 start 1520 end 1672 total 1904 skew 0 clock 55.93KHz
v: height 900 start 903 end 909 total 934 clock 59.89Hz
1280x1024 (0x1c6) 135.000MHz +HSync +VSync
h: width 1280 start 1296 end 1440 total 1688 skew 0 clock 79.98KHz
v: height 1024 start 1025 end 1028 total 1066 clock 75.02Hz
1280x1024 (0x1c7) 108.000MHz +HSync +VSync
h: width 1280 start 1328 end 1440 total 1688 skew 0 clock 63.98KHz
v: height 1024 start 1025 end 1028 total 1066 clock 60.02Hz
1280x960 (0x1c8) 108.000MHz +HSync +VSync
h: width 1280 start 1376 end 1488 total 1800 skew 0 clock 60.00KHz
v: height 960 start 961 end 964 total 1000 clock 60.00Hz
1280x800 (0x1c9) 83.500MHz -HSync +VSync
h: width 1280 start 1352 end 1480 total 1680 skew 0 clock 49.70KHz
v: height 800 start 803 end 809 total 831 clock 59.81Hz
1280x720 (0x1ca) 74.250MHz +HSync +VSync
h: width 1280 start 1390 end 1430 total 1650 skew 0 clock 45.00KHz
v: height 720 start 725 end 730 total 750 clock 60.00Hz
1152x864 (0x1cd) 108.000MHz +HSync +VSync
h: width 1152 start 1216 end 1344 total 1600 skew 0 clock 67.50KHz
v: height 864 start 865 end 868 total 900 clock 75.00Hz
1024x768 (0x1ce) 78.750MHz +HSync +VSync
h: width 1024 start 1040 end 1136 total 1312 skew 0 clock 60.02KHz
v: height 768 start 769 end 772 total 800 clock 75.03Hz
1024x768 (0x1cf) 75.000MHz -HSync -VSync
h: width 1024 start 1048 end 1184 total 1328 skew 0 clock 56.48KHz
v: height 768 start 771 end 777 total 806 clock 70.07Hz
1024x768 (0x1d0) 65.000MHz -HSync -VSync
h: width 1024 start 1048 end 1184 total 1344 skew 0 clock 48.36KHz
v: height 768 start 771 end 777 total 806 clock 60.00Hz
800x600 (0x1d1) 49.500MHz +HSync +VSync
h: width 800 start 816 end 896 total 1056 skew 0 clock 46.88KHz
v: height 600 start 601 end 604 total 625 clock 75.00Hz
800x600 (0x1d2) 50.000MHz +HSync +VSync
h: width 800 start 856 end 976 total 1040 skew 0 clock 48.08KHz
v: height 600 start 637 end 643 total 666 clock 72.19Hz
800x600 (0x1d3) 40.000MHz +HSync +VSync
h: width 800 start 840 end 968 total 1056 skew 0 clock 37.88KHz
v: height 600 start 601 end 605 total 628 clock 60.32Hz
800x600 (0x1d4) 36.000MHz +HSync +VSync
h: width 800 start 824 end 896 total 1024 skew 0 clock 35.16KHz
v: height 600 start 601 end 603 total 625 clock 56.25Hz
640x480 (0x1d7) 31.500MHz -HSync -VSync
h: width 640 start 656 end 720 total 840 skew 0 clock 37.50KHz
v: height 480 start 481 end 484 total 500 clock 75.00Hz
640x480 (0x1d8) 25.175MHz -HSync -VSync
h: width 640 start 656 end 752 total 800 skew 0 clock 31.47KHz
v: height 480 start 490 end 492 total 525 clock 59.94Hz
Unsure if it is related but can see this in the dmesg
[ 13.136830] [drm:drm_new_set_master] *ERROR* [nvidia-drm] [GPU ID 0x00002700] Failed to grab modeset ownership
[ 13.138009] [drm:drm_new_set_master] *ERROR* [nvidia-drm] [GPU ID 0x00002800] Failed to grab modeset
[ 26.539933] [drm:drm_new_set_master] *ERROR* [nvidia-drm] [GPU ID 0x00002700] Failed to grab modeset ownership
[ 26.540616] [drm:drm_new_set_master] *ERROR* [nvidia-drm] [GPU ID 0x00002800] Failed to grab modeset ownership
[ 33.439210] [drm:drm_new_set_master] *ERROR* [nvidia-drm] [GPU ID 0x00002700] Failed to grab modeset ownership
[ 33.630059] [drm:drm_new_set_master] *ERROR* [nvidia-drm] [GPU ID 0x00002800] Failed to grab modeset ownership
Xorg.log
[ 12.696] (II) Initializing extension XVideo
[ 12.696] (II) Initializing extension XVideo-MotionCompensation
[ 12.696] (II) Initializing extension GLX
[ 12.696] (II) Indirect GLX disabled.
[ 12.696] (II) GLX: Another vendor is already registered for screen 0
[ 12.696] (II) Initializing extension XFree86-VidModeExtension
[ 12.696] (II) Initializing extension XFree86-DGA
[ 12.696] (II) Initializing extension XFree86-DRI
[ 12.696] (II) Initializing extension DRI2
[ 12.696] (II) Initializing extension NV-GLX
[ 12.696] (II) Initializing extension NV-CONTROL
[ 12.696] (II) Initializing extension XINERAMA
[ 12.802] (II) config/udev: Adding input device Power Button (/dev/input/event1)
[ 12.802] (**) Power Button: Applying InputClass "libinput keyboard catchall"
[ 12.802] (**) Power Button: Applying InputClass "system-keyboard"
[ 12.802] (**) Power Button: Applying InputClass "Keyboard Defaults"
[ 12.802] (II) LoadModule: "libinput"
[ 12.803] (II) Loading /usr/lib/xorg/modules/input/libinput_drv.so
[ 12.805] (II) Module libinput: vendor="X.Org Foundation"
[ 12.805] compiled for 1.21.1.8, module version = 1.4.0
[ 12.805] Module class: X.Org XInput Driver
[ 12.805] ABI class: X.Org XInput driver, version 24.4
[ 12.805] (II) Using input driver 'libinput' for 'Power Button'
[ 12.805] (**) Power Button: always reports core events
[ 12.805] (**) Option "Device" "/dev/input/event1"
[ 12.812] (II) event1 - Power Button: is tagged by udev as: Keyboard
[ 12.812] (II) event1 - Power Button: device is a keyboard
[ 12.812] (II) event1 - Power Button: device removed
[ 12.833] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXPWRBN:00/input/input1/event1"
[ 12.833] (II) XINPUT: Adding extended input device "Power Button" (type: KEYBOARD, id 6)
[ 12.833] (**) Option "xkb_layout" "se"
[ 12.833] (**) Option "xkb_options" "terminate:ctrl_alt_bksp"
[ 12.857] (II) event1 - Power Button: is tagged by udev as: Keyboard
[ 12.857] (II) event1 - Power Button: device is a keyboard
[ 12.858] (II) config/udev: Adding input device Power Button (/dev/input/event0)
[ 12.858] (**) Power Button: Applying InputClass "libinput keyboard catchall"
[ 12.858] (**) Power Button: Applying InputClass "system-keyboard"
[ 12.858] (**) Power Button: Applying InputClass "Keyboard Defaults"
[ 12.858] (II) Using input driver 'libinput' for 'Power Button'
[ 12.858] (**) Power Button: always reports core events
[ 12.858] (**) Option "Device" "/dev/input/event0"
[ 12.859] (II) event0 - Power Button: is tagged by udev as: Keyboard
[ 12.859] (II) event0 - Power Button: device is a keyboard
[ 12.859] (II) event0 - Power Button: device removed
[ 12.880] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0C:00/input/input0/event0"
[ 12.880] (II) XINPUT: Adding extended input device "Power Button" (type: KEYBOARD, id 7)
[ 12.880] (**) Option "xkb_layout" "se"
[ 12.880] (**) Option "xkb_options" "terminate:ctrl_alt_bksp"
[ 12.880] (II) event0 - Power Button: is tagged by udev as: Keyboard
[ 12.881] (II) event0 - Power Button: device is a keyboard
[ 12.882] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=3 (/dev/input/event11)
[ 12.882] (II) No input driver specified, ignoring this device.
[ 12.882] (II) This device may have been added with another device file.
[ 12.882] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=7 (/dev/input/event14)
[ 12.882] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=8 (/dev/input/event16)
[ 12.883] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=9 (/dev/input/event17)
[ 12.883] (II) No input driver specified, ignoring this device.
[ 12.883] (II) This device may have been added with another device file.
[ 12.884] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=3 (/dev/input/event10)
[ 12.884] (II) No input driver specified, ignoring this device.
[ 12.884] (II) This device may have been added with another device file.
[ 12.884] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=7 (/dev/input/event12)
[ 12.885] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=8 (/dev/input/event13)
[ 12.885] (II) No input driver specified, ignoring this device.
[ 12.885] (II) This device may have been added with another device file.
[ 12.885] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=9 (/dev/input/event15)
[ 12.886] (II) config/udev: Adding input device Razer Razer BlackWidow V3 (/dev/input/event18)
[ 12.886] (**) Razer Razer BlackWidow V3: Applying InputClass "libinput keyboard catchall"
[ 12.886] (**) Razer Razer BlackWidow V3: Applying InputClass "system-keyboard"
[ 12.886] (**) Razer Razer BlackWidow V3: Applying InputClass "Keyboard Defaults"
[ 12.886] (II) Using input driver 'libinput' for 'Razer Razer BlackWidow V3'
[ 12.886] (**) Razer Razer BlackWidow V3: always reports core events
[ 12.886] (**) Option "Device" "/dev/input/event18"
[ 12.888] (II) event18 - Razer Razer BlackWidow V3: is tagged by udev as: Keyboard
[ 12.888] (II) event18 - Razer Razer BlackWidow V3: device is a keyboard
[ 12.888] (II) event18 - Razer Razer BlackWidow V3: device removed
[ 12.916] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:07.1/0000:29:00.3/usb5/5-2/5-2:1.0/0003:1532:024E.0001/input/input18/event18"
[ 12.916] (II) XINPUT: Adding extended input device "Razer Razer BlackWidow V3" (type: KEYBOARD, id 8)
[ 12.916] (**) Option "xkb_layout" "se"
[ 12.916] (**) Option "xkb_options" "terminate:ctrl_alt_bksp"
[ 12.918] (II) event18 - Razer Razer BlackWidow V3: is tagged by udev as: Keyboard
[ 12.918] (II) event18 - Razer Razer BlackWidow V3: device is a keyboard
[ 12.919] (II) config/udev: Adding input device Razer Razer BlackWidow V3 (/dev/input/event19)
[ 12.919] (**) Razer Razer BlackWidow V3: Applying InputClass "libinput keyboard catchall"
[ 12.919] (**) Razer Razer BlackWidow V3: Applying InputClass "system-keyboard"
[ 12.919] (**) Razer Razer BlackWidow V3: Applying InputClass "Keyboard Defaults"
[ 12.919] (II) Using input driver 'libinput' for 'Razer Razer BlackWidow V3'
[ 12.919] (**) Razer Razer BlackWidow V3: always reports core events
[ 12.919] (**) Option "Device" "/dev/input/event19"
[ 12.921] (II) event19 - Razer Razer BlackWidow V3: is tagged by udev as: Keyboard
[ 12.921] (II) event19 - Razer Razer BlackWidow V3: device is a keyboard
[ 12.921] (II) event19 - Razer Razer BlackWidow V3: device removed
[ 12.946] (II) libinput: Razer Razer BlackWidow V3: needs a virtual subdevice
[ 12.946] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:07.1/0000:29:00.3/usb5/5-2/5-2:1.1/0003:1532:024E.0002/input/input19/event19"
[ 12.946] (II) XINPUT: Adding extended input device "Razer Razer BlackWidow V3" (type: MOUSE, id 9)
[ 12.946] (**) Option "AccelerationScheme" "none"
[ 12.946] (**) Razer Razer BlackWidow V3: (accel) selected scheme none/0
[ 12.946] (**) Razer Razer BlackWidow V3: (accel) acceleration factor: 2.000
[ 12.946] (**) Razer Razer BlackWidow V3: (accel) acceleration threshold: 4
[ 12.948] (II) event19 - Razer Razer BlackWidow V3: is tagged by udev as: Keyboard
[ 12.948] (II) event19 - Razer Razer BlackWidow V3: device is a keyboard
[ 12.949] (II) config/udev: Adding input device Razer Razer BlackWidow V3 (/dev/input/event20)
[ 12.949] (**) Razer Razer BlackWidow V3: Applying InputClass "libinput pointer catchall"
[ 12.949] (**) Razer Razer BlackWidow V3: Applying InputClass "libinput keyboard catchall"
[ 12.949] (**) Razer Razer BlackWidow V3: Applying InputClass "system-keyboard"
[ 12.949] (**) Razer Razer BlackWidow V3: Applying InputClass "Keyboard Defaults"
[ 12.949] (II) Using input driver 'libinput' for 'Razer Razer BlackWidow V3'
[ 12.949] (**) Razer Razer BlackWidow V3: always reports core events
[ 12.949] (**) Option "Device" "/dev/input/event20"
[ 12.951] (II) event20 - Razer Razer BlackWidow V3: is tagged by udev as: Keyboard Mouse
[ 12.951] (II) event20 - Razer Razer BlackWidow V3: device is a pointer
[ 12.951] (II) event20 - Razer Razer BlackWidow V3: device is a keyboard
[ 12.951] (II) event20 - Razer Razer BlackWidow V3: device removed
[ 12.990] (II) libinput: Razer Razer BlackWidow V3: Step value 0 was provided, libinput Fallback acceleration function is used.
[ 12.990] (II) libinput: Razer Razer BlackWidow V3: needs a virtual subdevice
[ 12.990] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:07.1/0000:29:00.3/usb5/5-2/5-2:1.2/0003:1532:024E.0003/input/input20/event20"
[ 12.990] (II) XINPUT: Adding extended input device "Razer Razer BlackWidow V3" (type: MOUSE, id 10)
[ 12.990] (**) Option "AccelerationScheme" "none"
[ 12.990] (**) Razer Razer BlackWidow V3: (accel) selected scheme none/0
[ 12.990] (**) Razer Razer BlackWidow V3: (accel) acceleration factor: 2.000
[ 12.990] (**) Razer Razer BlackWidow V3: (accel) acceleration threshold: 4
[ 12.991] (II) event20 - Razer Razer BlackWidow V3: is tagged by udev as: Keyboard Mouse
[ 12.991] (II) event20 - Razer Razer BlackWidow V3: device is a pointer
[ 12.991] (II) event20 - Razer Razer BlackWidow V3: device is a keyboard
[ 12.992] (II) config/udev: Adding input device Razer Razer BlackWidow V3 (/dev/input/mouse0)
[ 12.992] (**) Razer Razer BlackWidow V3: Applying InputClass "system-keyboard"
[ 12.992] (**) Razer Razer BlackWidow V3: Applying InputClass "Keyboard Defaults"
[ 12.992] (II) No input driver specified, ignoring this device.
[ 12.992] (II) This device may have been added with another device file.
[ 12.993] (II) config/udev: Adding input device Razer Razer Basilisk V3 Pro (/dev/input/event21)
[ 12.993] (**) Razer Razer Basilisk V3 Pro: Applying InputClass "libinput pointer catchall"
[ 12.993] (II) Using input driver 'libinput' for 'Razer Razer Basilisk V3 Pro'
[ 12.993] (**) Razer Razer Basilisk V3 Pro: always reports core events
[ 12.993] (**) Option "Device" "/dev/input/event21"
[ 13.051] (II) event21 - Razer Razer Basilisk V3 Pro: is tagged by udev as: Mouse
[ 13.052] (II) event21 - Razer Razer Basilisk V3 Pro: device is a pointer
[ 13.052] (II) event21 - Razer Razer Basilisk V3 Pro: device removed
[ 13.083] (II) libinput: Razer Razer Basilisk V3 Pro: Step value 0 was provided, libinput Fallback acceleration function is used.
[ 13.083] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:07.1/0000:29:00.3/usb5/5-3/5-3.1/5-3.1:1.0/0003:1532:00AB.0006/input/input21/event21"
[ 13.083] (II) XINPUT: Adding extended input device "Razer Razer Basilisk V3 Pro" (type: MOUSE, id 11)
[ 13.083] (**) Option "AccelerationScheme" "none"
[ 13.083] (**) Razer Razer Basilisk V3 Pro: (accel) selected scheme none/0
[ 13.083] (**) Razer Razer Basilisk V3 Pro: (accel) acceleration factor: 2.000
[ 13.083] (**) Razer Razer Basilisk V3 Pro: (accel) acceleration threshold: 4
[ 13.142] (II) event21 - Razer Razer Basilisk V3 Pro: is tagged by udev as: Mouse
[ 13.142] (II) event21 - Razer Razer Basilisk V3 Pro: device is a pointer
[ 13.143] (II) config/udev: Adding input device Razer Razer Basilisk V3 Pro (/dev/input/mouse1)
[ 13.143] (II) No input driver specified, ignoring this device.
[ 13.143] (II) This device may have been added with another device file.
[ 13.144] (II) config/udev: Adding input device Razer Razer Basilisk V3 Pro Keyboard (/dev/input/event22)
[ 13.144] (**) Razer Razer Basilisk V3 Pro Keyboard: Applying InputClass "libinput keyboard catchall"
[ 13.144] (**) Razer Razer Basilisk V3 Pro Keyboard: Applying InputClass "system-keyboard"
[ 13.144] (**) Razer Razer Basilisk V3 Pro Keyboard: Applying InputClass "Keyboard Defaults"
[ 13.144] (II) Using input driver 'libinput' for 'Razer Razer Basilisk V3 Pro Keyboard'
[ 13.144] (**) Razer Razer Basilisk V3 Pro Keyboard: always reports core events
[ 13.144] (**) Option "Device" "/dev/input/event22"
[ 13.146] (II) event22 - Razer Razer Basilisk V3 Pro Keyboard: is tagged by udev as: Keyboard
[ 13.147] (II) event22 - Razer Razer Basilisk V3 Pro Keyboard: device is a keyboard
[ 13.147] (II) event22 - Razer Razer Basilisk V3 Pro Keyboard: device removed
[ 13.220] (II) libinput: Razer Razer Basilisk V3 Pro Keyboard: needs a virtual subdevice
[ 13.220] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:07.1/0000:29:00.3/usb5/5-3/5-3.1/5-3.1:1.1/0003:1532:00AB.0007/input/input22/event22"
[ 13.220] (II) XINPUT: Adding extended input device "Razer Razer Basilisk V3 Pro Keyboard" (type: MOUSE, id 12)
[ 13.220] (**) Option "AccelerationScheme" "none"
[ 13.220] (**) Razer Razer Basilisk V3 Pro Keyboard: (accel) selected scheme none/0
[ 13.220] (**) Razer Razer Basilisk V3 Pro Keyboard: (accel) acceleration factor: 2.000
[ 13.220] (**) Razer Razer Basilisk V3 Pro Keyboard: (accel) acceleration threshold: 4
[ 13.222] (II) event22 - Razer Razer Basilisk V3 Pro Keyboard: is tagged by udev as: Keyboard
[ 13.222] (II) event22 - Razer Razer Basilisk V3 Pro Keyboard: device is a keyboard
[ 13.224] (II) config/udev: Adding input device Razer Razer Basilisk V3 Pro Mouse (/dev/input/event23)
[ 13.224] (**) Razer Razer Basilisk V3 Pro Mouse: Applying InputClass "libinput pointer catchall"
[ 13.224] (II) Using input driver 'libinput' for 'Razer Razer Basilisk V3 Pro Mouse'
[ 13.224] (**) Razer Razer Basilisk V3 Pro Mouse: always reports core events
[ 13.224] (**) Option "Device" "/dev/input/event23"
[ 13.227] (II) event23 - Razer Razer Basilisk V3 Pro Mouse: is tagged by udev as: Mouse
[ 13.227] (II) event23 - Razer Razer Basilisk V3 Pro Mouse: device is a pointer
[ 13.228] (II) event23 - Razer Razer Basilisk V3 Pro Mouse: device removed
[ 13.340] (II) libinput: Razer Razer Basilisk V3 Pro Mouse: Step value 0 was provided, libinput Fallback acceleration function is used.
[ 13.340] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:07.1/0000:29:00.3/usb5/5-3/5-3.1/5-3.1:1.1/0003:1532:00AB.0007/input/input23/event23"
[ 13.340] (II) XINPUT: Adding extended input device "Razer Razer Basilisk V3 Pro Mouse" (type: MOUSE, id 13)
[ 13.340] (**) Option "AccelerationScheme" "none"
[ 13.340] (**) Razer Razer Basilisk V3 Pro Mouse: (accel) selected scheme none/0
[ 13.340] (**) Razer Razer Basilisk V3 Pro Mouse: (accel) acceleration factor: 2.000
[ 13.340] (**) Razer Razer Basilisk V3 Pro Mouse: (accel) acceleration threshold: 4
[ 13.341] (II) event23 - Razer Razer Basilisk V3 Pro Mouse: is tagged by udev as: Mouse
[ 13.342] (II) event23 - Razer Razer Basilisk V3 Pro Mouse: device is a pointer
[ 13.343] (II) config/udev: Adding input device Razer Razer Basilisk V3 Pro Mouse (/dev/input/mouse2)
[ 13.343] (II) No input driver specified, ignoring this device.
[ 13.343] (II) This device may have been added with another device file.
[ 13.344] (II) config/udev: Adding input device Razer Razer Basilisk V3 Pro (/dev/input/event24)
[ 13.344] (II) No input driver specified, ignoring this device.
[ 13.344] (II) This device may have been added with another device file.
[ 13.345] (II) config/udev: Adding input device Razer Razer Basilisk V3 Pro (/dev/input/event25)
[ 13.345] (**) Razer Razer Basilisk V3 Pro: Applying InputClass "libinput keyboard catchall"
[ 13.345] (**) Razer Razer Basilisk V3 Pro: Applying InputClass "system-keyboard"
[ 13.345] (**) Razer Razer Basilisk V3 Pro: Applying InputClass "Keyboard Defaults"
[ 13.345] (II) Using input driver 'libinput' for 'Razer Razer Basilisk V3 Pro'
[ 13.345] (**) Razer Razer Basilisk V3 Pro: always reports core events
[ 13.345] (**) Option "Device" "/dev/input/event25"
[ 13.346] (II) event25 - Razer Razer Basilisk V3 Pro: is tagged by udev as: Keyboard
[ 13.346] (II) event25 - Razer Razer Basilisk V3 Pro: device is a keyboard
[ 13.347] (II) event25 - Razer Razer Basilisk V3 Pro: device removed
[ 13.403] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:07.1/0000:29:00.3/usb5/5-3/5-3.1/5-3.1:1.2/0003:1532:00AB.0008/input/input25/event25"
[ 13.403] (II) XINPUT: Adding extended input device "Razer Razer Basilisk V3 Pro" (type: KEYBOARD, id 14)
[ 13.403] (**) Option "xkb_layout" "se"
[ 13.403] (**) Option "xkb_options" "terminate:ctrl_alt_bksp"
[ 13.404] (II) event25 - Razer Razer Basilisk V3 Pro: is tagged by udev as: Keyboard
[ 13.404] (II) event25 - Razer Razer Basilisk V3 Pro: device is a keyboard
[ 13.406] (II) config/udev: Adding input device Yubico YubiKey OTP+FIDO+CCID (/dev/input/event28)
[ 13.406] (**) Yubico YubiKey OTP+FIDO+CCID: Applying InputClass "libinput keyboard catchall"
[ 13.406] (**) Yubico YubiKey OTP+FIDO+CCID: Applying InputClass "system-keyboard"
[ 13.406] (**) Yubico YubiKey OTP+FIDO+CCID: Applying InputClass "Keyboard Defaults"
[ 13.406] (II) Using input driver 'libinput' for 'Yubico YubiKey OTP+FIDO+CCID'
[ 13.406] (**) Yubico YubiKey OTP+FIDO+CCID: always reports core events
[ 13.406] (**) Option "Device" "/dev/input/event28"
[ 13.407] (II) event28 - Yubico YubiKey OTP+FIDO+CCID: is tagged by udev as: Keyboard
[ 13.407] (II) event28 - Yubico YubiKey OTP+FIDO+CCID: device is a keyboard
[ 13.407] (II) event28 - Yubico YubiKey OTP+FIDO+CCID: device removed
[ 13.516] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:07.1/0000:29:00.3/usb5/5-3/5-3.4/5-3.4.1/5-3.4.1:1.0/0003:1050:0407.000B/input/input28/event28"
[ 13.516] (II) XINPUT: Adding extended input device "Yubico YubiKey OTP+FIDO+CCID" (type: KEYBOARD, id 15)
[ 13.516] (**) Option "xkb_layout" "se"
[ 13.516] (**) Option "xkb_options" "terminate:ctrl_alt_bksp"
[ 13.518] (II) event28 - Yubico YubiKey OTP+FIDO+CCID: is tagged by udev as: Keyboard
[ 13.518] (II) event28 - Yubico YubiKey OTP+FIDO+CCID: device is a keyboard
[ 13.518] (II) config/udev: Adding input device HD-Audio Generic Line Out Front (/dev/input/event6)
[ 13.518] (II) No input driver specified, ignoring this device.
[ 13.518] (II) This device may have been added with another device file.
[ 13.519] (II) config/udev: Adding input device HD-Audio Generic Line Out Surround (/dev/input/event7)
[ 13.519] (II) No input driver specified, ignoring this device.
[ 13.519] (II) This device may have been added with another device file.
[ 13.519] (II) config/udev: Adding input device HD-Audio Generic Line Out CLFE (/dev/input/event8)
[ 13.519] (II) config/udev: Adding input device HD-Audio Generic Front Headphone (/dev/input/event9)
[ 13.520] (II) config/udev: Adding input device HD-Audio Generic Front Mic (/dev/input/event3)
[ 13.520] (II) No input driver specified, ignoring this device.
[ 13.520] (II) This device may have been added with another device file.
[ 13.520] (II) config/udev: Adding input device HD-Audio Generic Rear Mic (/dev/input/event4)
[ 13.520] (II) config/udev: Adding input device HD-Audio Generic Line (/dev/input/event5)
[ 13.521] (II) config/udev: Adding input device PC Speaker (/dev/input/event2)
[ 13.521] (II) No input driver specified, ignoring this device.
[ 13.521] (II) This device may have been added with another device file.
[ 13.523] (II) config/udev: Adding input device Xbox Gamepad (userspace driver) (/dev/input/event26)
[ 13.523] (II) No input driver specified, ignoring this device.
[ 13.523] (II) This device may have been added with another device file.
[ 13.523] (II) config/udev: Adding input device Xbox Gamepad (userspace driver) (/dev/input/js0)
[ 13.523] (II) config/udev: Adding input device Xbox Gamepad (userspace driver) #2 (/dev/input/event27)
[ 13.524] (II) config/udev: Adding input device Xbox Gamepad (userspace driver) #2 (/dev/input/js1)
[ 13.524] (II) No input driver specified, ignoring this device.
[ 13.524] (II) This device may have been added with another device file.
[ 13.529] (**) Razer Razer BlackWidow V3: Applying InputClass "libinput keyboard catchall"
[ 13.529] (**) Razer Razer BlackWidow V3: Applying InputClass "system-keyboard"
[ 13.529] (**) Razer Razer BlackWidow V3: Applying InputClass "Keyboard Defaults"
[ 13.529] (II) Using input driver 'libinput' for 'Razer Razer BlackWidow V3'
[ 13.529] (**) Razer Razer BlackWidow V3: always reports core events
[ 13.529] (**) Option "Device" "/dev/input/event19"
[ 13.529] (II) libinput: Razer Razer BlackWidow V3: is a virtual subdevice
[ 13.529] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:07.1/0000:29:00.3/usb5/5-2/5-2:1.1/0003:1532:024E.0002/input/input19/event19"
[ 13.529] (II) XINPUT: Adding extended input device "Razer Razer BlackWidow V3" (type: KEYBOARD, id 16)
[ 13.529] (**) Option "xkb_layout" "se"
[ 13.529] (**) Option "xkb_options" "terminate:ctrl_alt_bksp"
[ 13.530] (**) Razer Razer BlackWidow V3: Applying InputClass "libinput pointer catchall"
[ 13.530] (**) Razer Razer BlackWidow V3: Applying InputClass "libinput keyboard catchall"
[ 13.530] (**) Razer Razer BlackWidow V3: Applying InputClass "system-keyboard"
[ 13.530] (**) Razer Razer BlackWidow V3: Applying InputClass "Keyboard Defaults"
[ 13.530] (II) Using input driver 'libinput' for 'Razer Razer BlackWidow V3'
[ 13.530] (**) Razer Razer BlackWidow V3: always reports core events
[ 13.530] (**) Option "Device" "/dev/input/event20"
[ 13.530] (II) libinput: Razer Razer BlackWidow V3: is a virtual subdevice
[ 13.530] (II) libinput: Razer Razer BlackWidow V3: Step value 0 was provided, libinput Fallback acceleration function is used.
[ 13.530] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:07.1/0000:29:00.3/usb5/5-2/5-2:1.2/0003:1532:024E.0003/input/input20/event20"
[ 13.530] (II) XINPUT: Adding extended input device "Razer Razer BlackWidow V3" (type: KEYBOARD, id 17)
[ 13.530] (**) Option "xkb_layout" "se"
[ 13.530] (**) Option "xkb_options" "terminate:ctrl_alt_bksp"
[ 13.530] (**) Razer Razer Basilisk V3 Pro Keyboard: Applying InputClass "libinput keyboard catchall"
[ 13.530] (**) Razer Razer Basilisk V3 Pro Keyboard: Applying InputClass "system-keyboard"
[ 13.530] (**) Razer Razer Basilisk V3 Pro Keyboard: Applying InputClass "Keyboard Defaults"
[ 13.530] (II) Using input driver 'libinput' for 'Razer Razer Basilisk V3 Pro Keyboard'
[ 13.530] (**) Razer Razer Basilisk V3 Pro Keyboard: always reports core events
[ 13.530] (**) Option "Device" "/dev/input/event22"
[ 13.530] (II) libinput: Razer Razer Basilisk V3 Pro Keyboard: is a virtual subdevice
[ 13.530] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:07.1/0000:29:00.3/usb5/5-3/5-3.1/5-3.1:1.1/0003:1532:00AB.0007/input/input22/event22"
[ 13.530] (II) XINPUT: Adding extended input device "Razer Razer Basilisk V3 Pro Keyboard" (type: KEYBOARD, id 18)
[ 13.598] (--) NVIDIA(GPU-0): CMT GP27-FUS (DFP-1): connected
[ 13.598] (--) NVIDIA(GPU-0): CMT GP27-FUS (DFP-1): Internal DisplayPort
[ 13.598] (--) NVIDIA(GPU-0): CMT GP27-FUS (DFP-1): 2670.0 MHz maximum pixel clock
[ 13.599] (II) config/udev: Adding input device SteelSeries Arctis Nova Pro Wireless (/dev/input/event29)
[ 13.599] (**) SteelSeries Arctis Nova Pro Wireless: Applying InputClass "libinput keyboard catchall"
[ 13.599] (**) SteelSeries Arctis Nova Pro Wireless: Applying InputClass "system-keyboard"
[ 13.599] (**) SteelSeries Arctis Nova Pro Wireless: Applying InputClass "Keyboard Defaults"
[ 13.599] (II) Using input driver 'libinput' for 'SteelSeries Arctis Nova Pro Wireless'
[ 13.599] (**) SteelSeries Arctis Nova Pro Wireless: always reports core events
[ 13.599] (**) Option "Device" "/dev/input/event29"
[ 13.601] (II) event29 - SteelSeries Arctis Nova Pro Wireless: is tagged by udev as: Keyboard
[ 13.601] (II) event29 - SteelSeries Arctis Nova Pro Wireless: device is a keyboard
[ 13.601] (II) event29 - SteelSeries Arctis Nova Pro Wireless: device removed
[ 13.656] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:07.1/0000:29:00.3/usb5/5-3/5-3.4/5-3.4.4/5-3.4.4:1.3/0003:1038:12E5.000D/input/input29/event29"
[ 13.656] (II) XINPUT: Adding extended input device "SteelSeries Arctis Nova Pro Wireless" (type: KEYBOARD, id 19)
[ 13.656] (**) Option "xkb_layout" "se"
[ 13.656] (**) Option "xkb_options" "terminate:ctrl_alt_bksp"
[ 13.658] (II) event29 - SteelSeries Arctis Nova Pro Wireless: is tagged by udev as: Keyboard
[ 13.658] (II) event29 - SteelSeries Arctis Nova Pro Wireless: device is a keyboard
[ 24.716] (--) NVIDIA(GPU-0): Ancor Communications Inc ASUS PB277 (DFP-0): connected
[ 24.716] (--) NVIDIA(GPU-0): Ancor Communications Inc ASUS PB277 (DFP-0): Internal TMDS
[ 24.716] (--) NVIDIA(GPU-0): Ancor Communications Inc ASUS PB277 (DFP-0): 600.0 MHz maximum pixel clock
[ 24.716] (--) NVIDIA(GPU-0): CMT GP27-FUS (DFP-1): connected
[ 24.716] (--) NVIDIA(GPU-0): CMT GP27-FUS (DFP-1): Internal DisplayPort
[ 24.716] (--) NVIDIA(GPU-0): CMT GP27-FUS (DFP-1): 2670.0 MHz maximum pixel clock
[ 24.719] (--) NVIDIA(GPU-0): DFP-2: disconnected
[ 24.719] (--) NVIDIA(GPU-0): DFP-2: Internal TMDS
[ 24.719] (--) NVIDIA(GPU-0): DFP-2: 165.0 MHz maximum pixel clock
[ 24.720] (--) NVIDIA(GPU-0): Ancor Communications Inc ASUS PB277 (DFP-3): connected
[ 24.720] (--) NVIDIA(GPU-0): Ancor Communications Inc ASUS PB277 (DFP-3): Internal DisplayPort
[ 24.720] (--) NVIDIA(GPU-0): Ancor Communications Inc ASUS PB277 (DFP-3): 2670.0 MHz maximum pixel clock
[ 24.722] (--) NVIDIA(GPU-0): DFP-4: disconnected
[ 24.722] (--) NVIDIA(GPU-0): DFP-4: Internal TMDS
[ 24.722] (--) NVIDIA(GPU-0): DFP-4: 165.0 MHz maximum pixel clock
[ 24.722] (--) NVIDIA(GPU-0): Ancor Communications Inc ASUS PB277 (DFP-5): connected
[ 24.722] (--) NVIDIA(GPU-0): Ancor Communications Inc ASUS PB277 (DFP-5): Internal DisplayPort
[ 24.722] (--) NVIDIA(GPU-0): Ancor Communications Inc ASUS PB277 (DFP-5): 2670.0 MHz maximum pixel clock
[ 24.724] (--) NVIDIA(GPU-0): DFP-6: disconnected
[ 24.724] (--) NVIDIA(GPU-0): DFP-6: Internal TMDS
[ 24.724] (--) NVIDIA(GPU-0): DFP-6: 165.0 MHz maximum pixel clock
[ 24.767] (--) NVIDIA(GPU-0): Ancor Communications Inc ASUS PB277 (DFP-0): connected
[ 24.767] (--) NVIDIA(GPU-0): Ancor Communications Inc ASUS PB277 (DFP-0): Internal TMDS
[ 24.767] (--) NVIDIA(GPU-0): Ancor Communications Inc ASUS PB277 (DFP-0): 600.0 MHz maximum pixel clock
[ 24.768] (--) NVIDIA(GPU-0): CMT GP27-FUS (DFP-1): connected
[ 24.768] (--) NVIDIA(GPU-0): CMT GP27-FUS (DFP-1): Internal DisplayPort
[ 24.768] (--) NVIDIA(GPU-0): CMT GP27-FUS (DFP-1): 2670.0 MHz maximum pixel clock
[ 24.770] (--) NVIDIA(GPU-0): DFP-2: disconnected
[ 24.770] (--) NVIDIA(GPU-0): DFP-2: Internal TMDS
[ 24.770] (--) NVIDIA(GPU-0): DFP-2: 165.0 MHz maximum pixel clock
[ 24.771] (--) NVIDIA(GPU-0): Ancor Communications Inc ASUS PB277 (DFP-3): connected
[ 24.771] (--) NVIDIA(GPU-0): Ancor Communications Inc ASUS PB277 (DFP-3): Internal DisplayPort
[ 24.771] (--) NVIDIA(GPU-0): Ancor Communications Inc ASUS PB277 (DFP-3): 2670.0 MHz maximum pixel clock
[ 24.773] (--) NVIDIA(GPU-0): DFP-4: disconnected
[ 24.773] (--) NVIDIA(GPU-0): DFP-4: Internal TMDS
[ 24.773] (--) NVIDIA(GPU-0): DFP-4: 165.0 MHz maximum pixel clock
[ 24.773] (--) NVIDIA(GPU-0): Ancor Communications Inc ASUS PB277 (DFP-5): connected
[ 24.773] (--) NVIDIA(GPU-0): Ancor Communications Inc ASUS PB277 (DFP-5): Internal DisplayPort
[ 24.773] (--) NVIDIA(GPU-0): Ancor Communications Inc ASUS PB277 (DFP-5): 2670.0 MHz maximum pixel clock
[ 24.775] (--) NVIDIA(GPU-0): DFP-6: disconnected
[ 24.775] (--) NVIDIA(GPU-0): DFP-6: Internal TMDS
[ 24.775] (--) NVIDIA(GPU-0): DFP-6: 165.0 MHz maximum pixel clock
[ 24.791] (--) NVIDIA(GPU-1): Ancor Communications Inc ASUS PB278 (DFP-0): connected
[ 24.791] (--) NVIDIA(GPU-1): Ancor Communications Inc ASUS PB278 (DFP-0): Internal TMDS
[ 24.791] (--) NVIDIA(GPU-1): Ancor Communications Inc ASUS PB278 (DFP-0): 330.0 MHz maximum pixel clock
[ 24.791] (--) NVIDIA(GPU-1): DFP-1: disconnected
[ 24.791] (--) NVIDIA(GPU-1): DFP-1: Internal TMDS
[ 24.791] (--) NVIDIA(GPU-1): DFP-1: 165.0 MHz maximum pixel clock
[ 24.791] (--) NVIDIA(GPU-1): DFP-2: disconnected
[ 24.791] (--) NVIDIA(GPU-1): DFP-2: Internal DisplayPort
[ 24.791] (--) NVIDIA(GPU-1): DFP-2: 1440.0 MHz maximum pixel clock
[ 24.791] (--) NVIDIA(GPU-1): DFP-3: disconnected
[ 24.791] (--) NVIDIA(GPU-1): DFP-3: Internal TMDS
[ 24.791] (--) NVIDIA(GPU-1): DFP-3: 165.0 MHz maximum pixel clock
[ 24.791] (--) NVIDIA(GPU-1): Ancor Communications Inc ASUS PB278 (DFP-4): connected
[ 24.791] (--) NVIDIA(GPU-1): Ancor Communications Inc ASUS PB278 (DFP-4): Internal DisplayPort
[ 24.791] (--) NVIDIA(GPU-1): Ancor Communications Inc ASUS PB278 (DFP-4): 1440.0 MHz maximum pixel clock
[ 24.793] (--) NVIDIA(GPU-1): DFP-5: disconnected
[ 24.793] (--) NVIDIA(GPU-1): DFP-5: Internal TMDS
[ 24.793] (--) NVIDIA(GPU-1): DFP-5: 165.0 MHz maximum pixel clock
[ 24.793] (--) NVIDIA(GPU-1): DFP-6: disconnected
[ 24.793] (--) NVIDIA(GPU-1): DFP-6: Internal DisplayPort
[ 24.793] (--) NVIDIA(GPU-1): DFP-6: 1440.0 MHz maximum pixel clock
[ 24.794] (--) NVIDIA(GPU-1): DFP-7: disconnected
[ 24.794] (--) NVIDIA(GPU-1): DFP-7: Internal TMDS
[ 24.794] (--) NVIDIA(GPU-1): DFP-7: 165.0 MHz maximum pixel clock
[ 24.911] (--) NVIDIA(GPU-0): Ancor Communications Inc ASUS PB277 (DFP-0): connected
[ 24.911] (--) NVIDIA(GPU-0): Ancor Communications Inc ASUS PB277 (DFP-0): Internal TMDS
[ 24.911] (--) NVIDIA(GPU-0): Ancor Communications Inc ASUS PB277 (DFP-0): 600.0 MHz maximum pixel clock
[ 24.912] (--) NVIDIA(GPU-0): CMT GP27-FUS (DFP-1): connected
[ 24.912] (--) NVIDIA(GPU-0): CMT GP27-FUS (DFP-1): Internal DisplayPort
[ 24.912] (--) NVIDIA(GPU-0): CMT GP27-FUS (DFP-1): 2670.0 MHz maximum pixel clock
[ 24.915] (--) NVIDIA(GPU-0): DFP-2: disconnected
[ 24.915] (--) NVIDIA(GPU-0): DFP-2: Internal TMDS
[ 24.915] (--) NVIDIA(GPU-0): DFP-2: 165.0 MHz maximum pixel clock
[ 24.916] (--) NVIDIA(GPU-0): Ancor Communications Inc ASUS PB277 (DFP-3): connected
[ 24.916] (--) NVIDIA(GPU-0): Ancor Communications Inc ASUS PB277 (DFP-3): Internal DisplayPort
[ 24.916] (--) NVIDIA(GPU-0): Ancor Communications Inc ASUS PB277 (DFP-3): 2670.0 MHz maximum pixel clock
[ 24.918] (--) NVIDIA(GPU-0): DFP-4: disconnected
[ 24.918] (--) NVIDIA(GPU-0): DFP-4: Internal TMDS
[ 24.918] (--) NVIDIA(GPU-0): DFP-4: 165.0 MHz maximum pixel clock
[ 24.918] (--) NVIDIA(GPU-0): Ancor Communications Inc ASUS PB277 (DFP-5): connected
[ 24.918] (--) NVIDIA(GPU-0): Ancor Communications Inc ASUS PB277 (DFP-5): Internal DisplayPort
[ 24.918] (--) NVIDIA(GPU-0): Ancor Communications Inc ASUS PB277 (DFP-5): 2670.0 MHz maximum pixel clock
[ 24.920] (--) NVIDIA(GPU-0): DFP-6: disconnected
[ 24.921] (--) NVIDIA(GPU-0): DFP-6: Internal TMDS
[ 24.921] (--) NVIDIA(GPU-0): DFP-6: 165.0 MHz maximum pixel clock
[ 24.964] (--) NVIDIA(GPU-0): Ancor Communications Inc ASUS PB277 (DFP-0): connected
[ 24.964] (--) NVIDIA(GPU-0): Ancor Communications Inc ASUS PB277 (DFP-0): Internal TMDS
[ 24.964] (--) NVIDIA(GPU-0): Ancor Communications Inc ASUS PB277 (DFP-0): 600.0 MHz maximum pixel clock
[ 24.965] (--) NVIDIA(GPU-0): CMT GP27-FUS (DFP-1): connected
[ 24.965] (--) NVIDIA(GPU-0): CMT GP27-FUS (DFP-1): Internal DisplayPort
[ 24.965] (--) NVIDIA(GPU-0): CMT GP27-FUS (DFP-1): 2670.0 MHz maximum pixel clock
[ 24.968] (--) NVIDIA(GPU-0): DFP-2: disconnected
[ 24.968] (--) NVIDIA(GPU-0): DFP-2: Internal TMDS
[ 24.968] (--) NVIDIA(GPU-0): DFP-2: 165.0 MHz maximum pixel clock
[ 24.969] (--) NVIDIA(GPU-0): Ancor Communications Inc ASUS PB277 (DFP-3): connected
[ 24.969] (--) NVIDIA(GPU-0): Ancor Communications Inc ASUS PB277 (DFP-3): Internal DisplayPort
[ 24.969] (--) NVIDIA(GPU-0): Ancor Communications Inc ASUS PB277 (DFP-3): 2670.0 MHz maximum pixel clock
[ 24.971] (--) NVIDIA(GPU-0): DFP-4: disconnected
[ 24.971] (--) NVIDIA(GPU-0): DFP-4: Internal TMDS
[ 24.971] (--) NVIDIA(GPU-0): DFP-4: 165.0 MHz maximum pixel clock
[ 24.971] (--) NVIDIA(GPU-0): Ancor Communications Inc ASUS PB277 (DFP-5): connected
[ 24.971] (--) NVIDIA(GPU-0): Ancor Communications Inc ASUS PB277 (DFP-5): Internal DisplayPort
[ 24.971] (--) NVIDIA(GPU-0): Ancor Communications Inc ASUS PB277 (DFP-5): 2670.0 MHz maximum pixel clock
[ 24.973] (--) NVIDIA(GPU-0): DFP-6: disconnected
[ 24.973] (--) NVIDIA(GPU-0): DFP-6: Internal TMDS
[ 24.973] (--) NVIDIA(GPU-0): DFP-6: 165.0 MHz maximum pixel clock
[ 24.988] (--) NVIDIA(GPU-1): Ancor Communications Inc ASUS PB278 (DFP-0): connected
[ 24.988] (--) NVIDIA(GPU-1): Ancor Communications Inc ASUS PB278 (DFP-0): Internal TMDS
[ 24.988] (--) NVIDIA(GPU-1): Ancor Communications Inc ASUS PB278 (DFP-0): 330.0 MHz maximum pixel clock
[ 24.988] (--) NVIDIA(GPU-1): DFP-1: disconnected
[ 24.988] (--) NVIDIA(GPU-1): DFP-1: Internal TMDS
[ 24.988] (--) NVIDIA(GPU-1): DFP-1: 165.0 MHz maximum pixel clock
[ 24.988] (--) NVIDIA(GPU-1): DFP-2: disconnected
[ 24.988] (--) NVIDIA(GPU-1): DFP-2: Internal DisplayPort
[ 24.988] (--) NVIDIA(GPU-1): DFP-2: 1440.0 MHz maximum pixel clock
[ 24.989] (--) NVIDIA(GPU-1): DFP-3: disconnected
[ 24.989] (--) NVIDIA(GPU-1): DFP-3: Internal TMDS
[ 24.989] (--) NVIDIA(GPU-1): DFP-3: 165.0 MHz maximum pixel clock
[ 24.989] (--) NVIDIA(GPU-1): Ancor Communications Inc ASUS PB278 (DFP-4): connected
[ 24.989] (--) NVIDIA(GPU-1): Ancor Communications Inc ASUS PB278 (DFP-4): Internal DisplayPort
[ 24.989] (--) NVIDIA(GPU-1): Ancor Communications Inc ASUS PB278 (DFP-4): 1440.0 MHz maximum pixel clock
[ 24.991] (--) NVIDIA(GPU-1): DFP-5: disconnected
[ 24.991] (--) NVIDIA(GPU-1): DFP-5: Internal TMDS
[ 24.991] (--) NVIDIA(GPU-1): DFP-5: 165.0 MHz maximum pixel clock
[ 24.991] (--) NVIDIA(GPU-1): DFP-6: disconnected
[ 24.991] (--) NVIDIA(GPU-1): DFP-6: Internal DisplayPort
[ 24.991] (--) NVIDIA(GPU-1): DFP-6: 1440.0 MHz maximum pixel clock
[ 24.992] (--) NVIDIA(GPU-1): DFP-7: disconnected
[ 24.992] (--) NVIDIA(GPU-1): DFP-7: Internal TMDS
[ 24.992] (--) NVIDIA(GPU-1): DFP-7: 165.0 MHz maximum pixel clock
[ 27.472] (--) NVIDIA(GPU-0): Ancor Communications Inc ASUS PB277 (DFP-0): connected
[ 27.472] (--) NVIDIA(GPU-0): Ancor Communications Inc ASUS PB277 (DFP-0): Internal TMDS
[ 27.472] (--) NVIDIA(GPU-0): Ancor Communications Inc ASUS PB277 (DFP-0): 600.0 MHz maximum pixel clock
[ 27.536] (--) NVIDIA(GPU-0): CMT GP27-FUS (DFP-1): connected
[ 27.536] (--) NVIDIA(GPU-0): CMT GP27-FUS (DFP-1): Internal DisplayPort
[ 27.536] (--) NVIDIA(GPU-0): CMT GP27-FUS (DFP-1): 2670.0 MHz maximum pixel clock
[ 27.560] (--) NVIDIA(GPU-0): DFP-2: disconnected
[ 27.560] (--) NVIDIA(GPU-0): DFP-2: Internal TMDS
[ 27.560] (--) NVIDIA(GPU-0): DFP-2: 165.0 MHz maximum pixel clock
[ 27.602] (--) NVIDIA(GPU-0): Ancor Communications Inc ASUS PB277 (DFP-3): connected
[ 27.602] (--) NVIDIA(GPU-0): Ancor Communications Inc ASUS PB277 (DFP-3): Internal DisplayPort
[ 27.602] (--) NVIDIA(GPU-0): Ancor Communications Inc ASUS PB277 (DFP-3): 2670.0 MHz maximum pixel clock
[ 27.605] (--) NVIDIA(GPU-0): DFP-4: disconnected
[ 27.605] (--) NVIDIA(GPU-0): DFP-4: Internal TMDS
[ 27.605] (--) NVIDIA(GPU-0): DFP-4: 165.0 MHz maximum pixel clock
[ 27.802] (--) NVIDIA(GPU-0): Ancor Communications Inc ASUS PB277 (DFP-5): connected
[ 27.802] (--) NVIDIA(GPU-0): Ancor Communications Inc ASUS PB277 (DFP-5): Internal DisplayPort
[ 27.802] (--) NVIDIA(GPU-0): Ancor Communications Inc ASUS PB277 (DFP-5): 2670.0 MHz maximum pixel clock
[ 27.805] (--) NVIDIA(GPU-0): DFP-6: disconnected
[ 27.805] (--) NVIDIA(GPU-0): DFP-6: Internal TMDS
[ 27.805] (--) NVIDIA(GPU-0): DFP-6: 165.0 MHz maximum pixel clock
[ 27.872] (--) NVIDIA(GPU-0): Ancor Communications Inc ASUS PB277 (DFP-0): connected
[ 27.872] (--) NVIDIA(GPU-0): Ancor Communications Inc ASUS PB277 (DFP-0): Internal TMDS
[ 27.872] (--) NVIDIA(GPU-0): Ancor Communications Inc ASUS PB277 (DFP-0): 600.0 MHz maximum pixel clock
[ 27.996] (--) NVIDIA(GPU-0): CMT GP27-FUS (DFP-1): connected
[ 27.996] (--) NVIDIA(GPU-0): CMT GP27-FUS (DFP-1): Internal DisplayPort
[ 27.996] (--) NVIDIA(GPU-0): CMT GP27-FUS (DFP-1): 2670.0 MHz maximum pixel clock
[ 28.000] (--) NVIDIA(GPU-0): DFP-2: disconnected
[ 28.000] (--) NVIDIA(GPU-0): DFP-2: Internal TMDS
[ 28.000] (--) NVIDIA(GPU-0): DFP-2: 165.0 MHz maximum pixel clock
[ 28.022] (--) NVIDIA(GPU-0): Ancor Communications Inc ASUS PB277 (DFP-3): connected
[ 28.023] (--) NVIDIA(GPU-0): Ancor Communications Inc ASUS PB277 (DFP-3): Internal DisplayPort
[ 28.023] (--) NVIDIA(GPU-0): Ancor Communications Inc ASUS PB277 (DFP-3): 2670.0 MHz maximum pixel clock
[ 28.025] (--) NVIDIA(GPU-0): DFP-4: disconnected
[ 28.025] (--) NVIDIA(GPU-0): DFP-4: Internal TMDS
[ 28.025] (--) NVIDIA(GPU-0): DFP-4: 165.0 MHz maximum pixel clock
[ 28.152] (--) NVIDIA(GPU-0): Ancor Communications Inc ASUS PB277 (DFP-5): connected
[ 28.152] (--) NVIDIA(GPU-0): Ancor Communications Inc ASUS PB277 (DFP-5): Internal DisplayPort
[ 28.152] (--) NVIDIA(GPU-0): Ancor Communications Inc ASUS PB277 (DFP-5): 2670.0 MHz maximum pixel clock
[ 28.154] (--) NVIDIA(GPU-0): DFP-6: disconnected
[ 28.154] (--) NVIDIA(GPU-0): DFP-6: Internal TMDS
[ 28.154] (--) NVIDIA(GPU-0): DFP-6: 165.0 MHz maximum pixel clock
[ 28.192] (--) NVIDIA(GPU-1): Ancor Communications Inc ASUS PB278 (DFP-0): connected
[ 28.192] (--) NVIDIA(GPU-1): Ancor Communications Inc ASUS PB278 (DFP-0): Internal TMDS
[ 28.192] (--) NVIDIA(GPU-1): Ancor Communications Inc ASUS PB278 (DFP-0): 330.0 MHz maximum pixel clock
[ 28.192] (--) NVIDIA(GPU-1): DFP-1: disconnected
[ 28.192] (--) NVIDIA(GPU-1): DFP-1: Internal TMDS
[ 28.192] (--) NVIDIA(GPU-1): DFP-1: 165.0 MHz maximum pixel clock
[ 28.192] (--) NVIDIA(GPU-1): DFP-2: disconnected
[ 28.192] (--) NVIDIA(GPU-1): DFP-2: Internal DisplayPort
[ 28.192] (--) NVIDIA(GPU-1): DFP-2: 1440.0 MHz maximum pixel clock
[ 28.192] (--) NVIDIA(GPU-1): DFP-3: disconnected
[ 28.192] (--) NVIDIA(GPU-1): DFP-3: Internal TMDS
[ 28.192] (--) NVIDIA(GPU-1): DFP-3: 165.0 MHz maximum pixel clock
[ 28.192] (--) NVIDIA(GPU-1): Ancor Communications Inc ASUS PB278 (DFP-4): connected
[ 28.192] (--) NVIDIA(GPU-1): Ancor Communications Inc ASUS PB278 (DFP-4): Internal DisplayPort
[ 28.192] (--) NVIDIA(GPU-1): Ancor Communications Inc ASUS PB278 (DFP-4): 1440.0 MHz maximum pixel clock
[ 28.195] (--) NVIDIA(GPU-1): DFP-5: disconnected
[ 28.195] (--) NVIDIA(GPU-1): DFP-5: Internal TMDS
[ 28.195] (--) NVIDIA(GPU-1): DFP-5: 165.0 MHz maximum pixel clock
[ 28.195] (--) NVIDIA(GPU-1): DFP-6: disconnected
[ 28.195] (--) NVIDIA(GPU-1): DFP-6: Internal DisplayPort
[ 28.195] (--) NVIDIA(GPU-1): DFP-6: 1440.0 MHz maximum pixel clock
[ 28.195] (--) NVIDIA(GPU-1): DFP-7: disconnected
[ 28.195] (--) NVIDIA(GPU-1): DFP-7: Internal TMDS
[ 28.195] (--) NVIDIA(GPU-1): DFP-7: 165.0 MHz maximum pixel clock
[ 28.577] (II) NVIDIA(0): Setting mode "DP-4: nvidia-auto-select @2560x1440 +0+0 {ViewPortIn=2560x1440, ViewPortOut=2560x1440+0+0}, HDMI-0: nvidia-auto-select @2560x1440 +5120+1440 {ViewPortIn=2560x1440, ViewPortOut=2560x1440+0+0}, DP-2: nvidia-auto-select @2560x1440 +5120+0 {ViewPortIn=2560x1440, ViewPortOut=2560x1440+0+0}"
[ 28.796] (II) NVIDIA(0): Setting mode "DP-4: nvidia-auto-select @2560x1440 +0+0 {ViewPortIn=2560x1440, ViewPortOut=2560x1440+0+0}, HDMI-0: nvidia-auto-select @2560x1440 +5120+1440 {ViewPortIn=2560x1440, ViewPortOut=2560x1440+0+0}, DP-2: nvidia-auto-select @2560x1440 +2560+0 {ViewPortIn=2560x1440, ViewPortOut=2560x1440+0+0}"
[ 28.926] (II) NVIDIA(0): Setting mode "DP-4: nvidia-auto-select @2560x1440 +0+1440 {ViewPortIn=2560x1440, ViewPortOut=2560x1440+0+0}, HDMI-0: nvidia-auto-select @2560x1440 +5120+1440 {ViewPortIn=2560x1440, ViewPortOut=2560x1440+0+0}, DP-2: nvidia-auto-select @2560x1440 +2560+0 {ViewPortIn=2560x1440, ViewPortOut=2560x1440+0+0}"
[ 29.086] (II) NVIDIA(0): Setting mode "DP-4: nvidia-auto-select @2560x1440 +0+1440 {ViewPortIn=2560x1440, ViewPortOut=2560x1440+0+0}, HDMI-0: nvidia-auto-select @2560x1440 +5120+1440 {ViewPortIn=2560x1440, ViewPortOut=2560x1440+0+0}, DP-2: nvidia-auto-select @2560x1440 +2560+0 {ViewPortIn=2560x1440, ViewPortOut=2560x1440+0+0}, DP-0: 2560x1440 @2560x1440 +2560+1440 {ViewPortIn=2560x1440, ViewPortOut=2560x1440+0+0}"
[ 29.249] (II) NVIDIA(G0): Setting mode "DVI-D-1-0: nvidia-auto-select @2560x1440 +5120+0 {AllowGSYNC=Off, ViewPortIn=2560x1440, ViewPortOut=2560x1440+0+0}"
[ 33.846] (--) NVIDIA(GPU-0): DFP-1: disconnected
[ 33.846] (--) NVIDIA(GPU-0): DFP-1: Internal DisplayPort
[ 33.846] (--) NVIDIA(GPU-0): DFP-1: 2670.0 MHz maximum pixel clock
[ 34.734] (--) NVIDIA(GPU-0): CMT GP27-FUS (DFP-1): connected
[ 34.734] (--) NVIDIA(GPU-0): CMT GP27-FUS (DFP-1): Internal DisplayPort
[ 34.735] (--) NVIDIA(GPU-0): CMT GP27-FUS (DFP-1): 2670.0 MHz maximum pixel clock
[ 102.563] (--) NVIDIA(GPU-0): Ancor Communications Inc ASUS PB277 (DFP-0): connected
[ 102.563] (--) NVIDIA(GPU-0): Ancor Communications Inc ASUS PB277 (DFP-0): Internal TMDS
[ 102.563] (--) NVIDIA(GPU-0): Ancor Communications Inc ASUS PB277 (DFP-0): 600.0 MHz maximum pixel clock
[ 102.564] (--) NVIDIA(GPU-0): CMT GP27-FUS (DFP-1): connected
[ 102.564] (--) NVIDIA(GPU-0): CMT GP27-FUS (DFP-1): Internal DisplayPort
[ 102.564] (--) NVIDIA(GPU-0): CMT GP27-FUS (DFP-1): 2670.0 MHz maximum pixel clock
[ 102.566] (--) NVIDIA(GPU-0): DFP-2: disconnected
[ 102.566] (--) NVIDIA(GPU-0): DFP-2: Internal TMDS
[ 102.566] (--) NVIDIA(GPU-0): DFP-2: 165.0 MHz maximum pixel clock
[ 102.567] (--) NVIDIA(GPU-0): Ancor Communications Inc ASUS PB277 (DFP-3): connected
[ 102.567] (--) NVIDIA(GPU-0): Ancor Communications Inc ASUS PB277 (DFP-3): Internal DisplayPort
[ 102.567] (--) NVIDIA(GPU-0): Ancor Communications Inc ASUS PB277 (DFP-3): 2670.0 MHz maximum pixel clock
[ 102.569] (--) NVIDIA(GPU-0): DFP-4: disconnected
[ 102.569] (--) NVIDIA(GPU-0): DFP-4: Internal TMDS
[ 102.569] (--) NVIDIA(GPU-0): DFP-4: 165.0 MHz maximum pixel clock
[ 102.569] (--) NVIDIA(GPU-0): Ancor Communications Inc ASUS PB277 (DFP-5): connected
[ 102.569] (--) NVIDIA(GPU-0): Ancor Communications Inc ASUS PB277 (DFP-5): Internal DisplayPort
[ 102.569] (--) NVIDIA(GPU-0): Ancor Communications Inc ASUS PB277 (DFP-5): 2670.0 MHz maximum pixel clock
[ 102.571] (--) NVIDIA(GPU-0): DFP-6: disconnected
[ 102.571] (--) NVIDIA(GPU-0): DFP-6: Internal TMDS
[ 102.571] (--) NVIDIA(GPU-0): DFP-6: 165.0 MHz maximum pixel clock
[ 102.615] (--) NVIDIA(GPU-0): Ancor Communications Inc ASUS PB277 (DFP-0): connected
[ 102.615] (--) NVIDIA(GPU-0): Ancor Communications Inc ASUS PB277 (DFP-0): Internal TMDS
[ 102.615] (--) NVIDIA(GPU-0): Ancor Communications Inc ASUS PB277 (DFP-0): 600.0 MHz maximum pixel clock
[ 102.616] (--) NVIDIA(GPU-0): CMT GP27-FUS (DFP-1): connected
[ 102.616] (--) NVIDIA(GPU-0): CMT GP27-FUS (DFP-1): Internal DisplayPort
[ 102.616] (--) NVIDIA(GPU-0): CMT GP27-FUS (DFP-1): 2670.0 MHz maximum pixel clock
[ 102.618] (--) NVIDIA(GPU-0): DFP-2: disconnected
[ 102.618] (--) NVIDIA(GPU-0): DFP-2: Internal TMDS
[ 102.618] (--) NVIDIA(GPU-0): DFP-2: 165.0 MHz maximum pixel clock
[ 102.618] (--) NVIDIA(GPU-0): Ancor Communications Inc ASUS PB277 (DFP-3): connected
[ 102.618] (--) NVIDIA(GPU-0): Ancor Communications Inc ASUS PB277 (DFP-3): Internal DisplayPort
[ 102.618] (--) NVIDIA(GPU-0): Ancor Communications Inc ASUS PB277 (DFP-3): 2670.0 MHz maximum pixel clock
[ 102.620] (--) NVIDIA(GPU-0): DFP-4: disconnected
[ 102.620] (--) NVIDIA(GPU-0): DFP-4: Internal TMDS
[ 102.620] (--) NVIDIA(GPU-0): DFP-4: 165.0 MHz maximum pixel clock
[ 102.621] (--) NVIDIA(GPU-0): Ancor Communications Inc ASUS PB277 (DFP-5): connected
[ 102.621] (--) NVIDIA(GPU-0): Ancor Communications Inc ASUS PB277 (DFP-5): Internal DisplayPort
[ 102.621] (--) NVIDIA(GPU-0): Ancor Communications Inc ASUS PB277 (DFP-5): 2670.0 MHz maximum pixel clock
[ 102.623] (--) NVIDIA(GPU-0): DFP-6: disconnected
[ 102.623] (--) NVIDIA(GPU-0): DFP-6: Internal TMDS
[ 102.623] (--) NVIDIA(GPU-0): DFP-6: 165.0 MHz maximum pixel clock
[ 102.638] (--) NVIDIA(GPU-1): Ancor Communications Inc ASUS PB278 (DFP-0): connected
[ 102.638] (--) NVIDIA(GPU-1): Ancor Communications Inc ASUS PB278 (DFP-0): Internal TMDS
[ 102.638] (--) NVIDIA(GPU-1): Ancor Communications Inc ASUS PB278 (DFP-0): 330.0 MHz maximum pixel clock
[ 102.638] (--) NVIDIA(GPU-1): DFP-1: disconnected
[ 102.638] (--) NVIDIA(GPU-1): DFP-1: Internal TMDS
[ 102.638] (--) NVIDIA(GPU-1): DFP-1: 165.0 MHz maximum pixel clock
[ 102.638] (--) NVIDIA(GPU-1): DFP-2: disconnected
[ 102.638] (--) NVIDIA(GPU-1): DFP-2: Internal DisplayPort
[ 102.638] (--) NVIDIA(GPU-1): DFP-2: 1440.0 MHz maximum pixel clock
[ 102.639] (--) NVIDIA(GPU-1): DFP-3: disconnected
[ 102.639] (--) NVIDIA(GPU-1): DFP-3: Internal TMDS
[ 102.639] (--) NVIDIA(GPU-1): DFP-3: 165.0 MHz maximum pixel clock
[ 102.639] (--) NVIDIA(GPU-1): Ancor Communications Inc ASUS PB278 (DFP-4): connected
[ 102.639] (--) NVIDIA(GPU-1): Ancor Communications Inc ASUS PB278 (DFP-4): Internal DisplayPort
[ 102.639] (--) NVIDIA(GPU-1): Ancor Communications Inc ASUS PB278 (DFP-4): 1440.0 MHz maximum pixel clock
[ 102.641] (--) NVIDIA(GPU-1): DFP-5: disconnected
[ 102.641] (--) NVIDIA(GPU-1): DFP-5: Internal TMDS
[ 102.641] (--) NVIDIA(GPU-1): DFP-5: 165.0 MHz maximum pixel clock
[ 102.641] (--) NVIDIA(GPU-1): DFP-6: disconnected
[ 102.641] (--) NVIDIA(GPU-1): DFP-6: Internal DisplayPort
[ 102.641] (--) NVIDIA(GPU-1): DFP-6: 1440.0 MHz maximum pixel clock
[ 102.641] (--) NVIDIA(GPU-1): DFP-7: disconnected
[ 102.641] (--) NVIDIA(GPU-1): DFP-7: Internal TMDS
[ 102.641] (--) NVIDIA(GPU-1): DFP-7: 165.0 MHz maximum pixel clock
[ 103.551] (--) NVIDIA(GPU-0): Ancor Communications Inc ASUS PB277 (DFP-0): connected
[ 103.551] (--) NVIDIA(GPU-0): Ancor Communications Inc ASUS PB277 (DFP-0): Internal TMDS
[ 103.551] (--) NVIDIA(GPU-0): Ancor Communications Inc ASUS PB277 (DFP-0): 600.0 MHz maximum pixel clock
[ 103.551] (--) NVIDIA(GPU-0): CMT GP27-FUS (DFP-1): connected
[ 103.551] (--) NVIDIA(GPU-0): CMT GP27-FUS (DFP-1): Internal DisplayPort
[ 103.551] (--) NVIDIA(GPU-0): CMT GP27-FUS (DFP-1): 2670.0 MHz maximum pixel clock
[ 103.554] (--) NVIDIA(GPU-0): DFP-2: disconnected
[ 103.554] (--) NVIDIA(GPU-0): DFP-2: Internal TMDS
[ 103.554] (--) NVIDIA(GPU-0): DFP-2: 165.0 MHz maximum pixel clock
[ 103.554] (--) NVIDIA(GPU-0): Ancor Communications Inc ASUS PB277 (DFP-3): connected
[ 103.554] (--) NVIDIA(GPU-0): Ancor Communications Inc ASUS PB277 (DFP-3): Internal DisplayPort
[ 103.554] (--) NVIDIA(GPU-0): Ancor Communications Inc ASUS PB277 (DFP-3): 2670.0 MHz maximum pixel clock
[ 103.556] (--) NVIDIA(GPU-0): DFP-4: disconnected
[ 103.556] (--) NVIDIA(GPU-0): DFP-4: Internal TMDS
[ 103.556] (--) NVIDIA(GPU-0): DFP-4: 165.0 MHz maximum pixel clock
[ 103.556] (--) NVIDIA(GPU-0): Ancor Communications Inc ASUS PB277 (DFP-5): connected
[ 103.556] (--) NVIDIA(GPU-0): Ancor Communications Inc ASUS PB277 (DFP-5): Internal DisplayPort
[ 103.556] (--) NVIDIA(GPU-0): Ancor Communications Inc ASUS PB277 (DFP-5): 2670.0 MHz maximum pixel clock
[ 103.558] (--) NVIDIA(GPU-0): DFP-6: disconnected
[ 103.558] (--) NVIDIA(GPU-0): DFP-6: Internal TMDS
[ 103.558] (--) NVIDIA(GPU-0): DFP-6: 165.0 MHz maximum pixel clock
[ 103.603] (--) NVIDIA(GPU-0): Ancor Communications Inc ASUS PB277 (DFP-0): connected
[ 103.603] (--) NVIDIA(GPU-0): Ancor Communications Inc ASUS PB277 (DFP-0): Internal TMDS
[ 103.603] (--) NVIDIA(GPU-0): Ancor Communications Inc ASUS PB277 (DFP-0): 600.0 MHz maximum pixel clock
[ 103.603] (--) NVIDIA(GPU-0): CMT GP27-FUS (DFP-1): connected
[ 103.603] (--) NVIDIA(GPU-0): CMT GP27-FUS (DFP-1): Internal DisplayPort
[ 103.603] (--) NVIDIA(GPU-0): CMT GP27-FUS (DFP-1): 2670.0 MHz maximum pixel clock
[ 103.606] (--) NVIDIA(GPU-0): DFP-2: disconnected
[ 103.606] (--) NVIDIA(GPU-0): DFP-2: Internal TMDS
[ 103.606] (--) NVIDIA(GPU-0): DFP-2: 165.0 MHz maximum pixel clock
[ 103.606] (--) NVIDIA(GPU-0): Ancor Communications Inc ASUS PB277 (DFP-3): connected
[ 103.606] (--) NVIDIA(GPU-0): Ancor Communications Inc ASUS PB277 (DFP-3): Internal DisplayPort
[ 103.606] (--) NVIDIA(GPU-0): Ancor Communications Inc ASUS PB277 (DFP-3): 2670.0 MHz maximum pixel clock
[ 103.608] (--) NVIDIA(GPU-0): DFP-4: disconnected
[ 103.608] (--) NVIDIA(GPU-0): DFP-4: Internal TMDS
[ 103.608] (--) NVIDIA(GPU-0): DFP-4: 165.0 MHz maximum pixel clock
[ 103.608] (--) NVIDIA(GPU-0): Ancor Communications Inc ASUS PB277 (DFP-5): connected
[ 103.608] (--) NVIDIA(GPU-0): Ancor Communications Inc ASUS PB277 (DFP-5): Internal DisplayPort
[ 103.608] (--) NVIDIA(GPU-0): Ancor Communications Inc ASUS PB277 (DFP-5): 2670.0 MHz maximum pixel clock
[ 103.610] (--) NVIDIA(GPU-0): DFP-6: disconnected
[ 103.610] (--) NVIDIA(GPU-0): DFP-6: Internal TMDS
[ 103.610] (--) NVIDIA(GPU-0): DFP-6: 165.0 MHz maximum pixel clock
[ 103.626] (--) NVIDIA(GPU-1): Ancor Communications Inc ASUS PB278 (DFP-0): connected
[ 103.626] (--) NVIDIA(GPU-1): Ancor Communications Inc ASUS PB278 (DFP-0): Internal TMDS
[ 103.626] (--) NVIDIA(GPU-1): Ancor Communications Inc ASUS PB278 (DFP-0): 330.0 MHz maximum pixel clock
[ 103.626] (--) NVIDIA(GPU-1): DFP-1: disconnected
[ 103.626] (--) NVIDIA(GPU-1): DFP-1: Internal TMDS
[ 103.626] (--) NVIDIA(GPU-1): DFP-1: 165.0 MHz maximum pixel clock
[ 103.626] (--) NVIDIA(GPU-1): DFP-2: disconnected
[ 103.626] (--) NVIDIA(GPU-1): DFP-2: Internal DisplayPort
[ 103.626] (--) NVIDIA(GPU-1): DFP-2: 1440.0 MHz maximum pixel clock
[ 103.626] (--) NVIDIA(GPU-1): DFP-3: disconnected
[ 103.626] (--) NVIDIA(GPU-1): DFP-3: Internal TMDS
[ 103.626] (--) NVIDIA(GPU-1): DFP-3: 165.0 MHz maximum pixel clock
[ 103.627] (--) NVIDIA(GPU-1): Ancor Communications Inc ASUS PB278 (DFP-4): connected
[ 103.627] (--) NVIDIA(GPU-1): Ancor Communications Inc ASUS PB278 (DFP-4): Internal DisplayPort
[ 103.627] (--) NVIDIA(GPU-1): Ancor Communications Inc ASUS PB278 (DFP-4): 1440.0 MHz maximum pixel clock
[ 103.629] (--) NVIDIA(GPU-1): DFP-5: disconnected
[ 103.629] (--) NVIDIA(GPU-1): DFP-5: Internal TMDS
[ 103.629] (--) NVIDIA(GPU-1): DFP-5: 165.0 MHz maximum pixel clock
[ 103.629] (--) NVIDIA(GPU-1): DFP-6: disconnected
[ 103.629] (--) NVIDIA(GPU-1): DFP-6: Internal DisplayPort
[ 103.629] (--) NVIDIA(GPU-1): DFP-6: 1440.0 MHz maximum pixel clock
[ 103.629] (--) NVIDIA(GPU-1): DFP-7: disconnected
[ 103.629] (--) NVIDIA(GPU-1): DFP-7: Internal TMDS
[ 103.629] (--) NVIDIA(GPU-1): DFP-7: 165.0 MHz maximum pixel clock
[ 103.673] (--) NVIDIA(GPU-0): Ancor Communications Inc ASUS PB277 (DFP-0): connected
[ 103.673] (--) NVIDIA(GPU-0): Ancor Communications Inc ASUS PB277 (DFP-0): Internal TMDS
[ 103.673] (--) NVIDIA(GPU-0): Ancor Communications Inc ASUS PB277 (DFP-0): 600.0 MHz maximum pixel clock
[ 103.674] (--) NVIDIA(GPU-0): CMT GP27-FUS (DFP-1): connected
[ 103.674] (--) NVIDIA(GPU-0): CMT GP27-FUS (DFP-1): Internal DisplayPort
[ 103.674] (--) NVIDIA(GPU-0): CMT GP27-FUS (DFP-1): 2670.0 MHz maximum pixel clock
[ 103.676] (--) NVIDIA(GPU-0): DFP-2: disconnected
[ 103.676] (--) NVIDIA(GPU-0): DFP-2: Internal TMDS
[ 103.676] (--) NVIDIA(GPU-0): DFP-2: 165.0 MHz maximum pixel clock
[ 103.677] (--) NVIDIA(GPU-0): Ancor Communications Inc ASUS PB277 (DFP-3): connected
[ 103.677] (--) NVIDIA(GPU-0): Ancor Communications Inc ASUS PB277 (DFP-3): Internal DisplayPort
[ 103.677] (--) NVIDIA(GPU-0): Ancor Communications Inc ASUS PB277 (DFP-3): 2670.0 MHz maximum pixel clock
[ 103.679] (--) NVIDIA(GPU-0): DFP-4: disconnected
[ 103.679] (--) NVIDIA(GPU-0): DFP-4: Internal TMDS
[ 103.679] (--) NVIDIA(GPU-0): DFP-4: 165.0 MHz maximum pixel clock
[ 103.679] (--) NVIDIA(GPU-0): Ancor Communications Inc ASUS PB277 (DFP-5): connected
[ 103.679] (--) NVIDIA(GPU-0): Ancor Communications Inc ASUS PB277 (DFP-5): Internal DisplayPort
[ 103.679] (--) NVIDIA(GPU-0): Ancor Communications Inc ASUS PB277 (DFP-5): 2670.0 MHz maximum pixel clock
[ 103.681] (--) NVIDIA(GPU-0): DFP-6: disconnected
[ 103.681] (--) NVIDIA(GPU-0): DFP-6: Internal TMDS
[ 103.681] (--) NVIDIA(GPU-0): DFP-6: 165.0 MHz maximum pixel clock
[ 247.335] (--) NVIDIA(GPU-0): Ancor Communications Inc ASUS PB277 (DFP-0): connected
[ 247.335] (--) NVIDIA(GPU-0): Ancor Communications Inc ASUS PB277 (DFP-0): Internal TMDS
[ 247.335] (--) NVIDIA(GPU-0): Ancor Communications Inc ASUS PB277 (DFP-0): 600.0 MHz maximum pixel clock
[ 247.336] (--) NVIDIA(GPU-0): CMT GP27-FUS (DFP-1): connected
[ 247.336] (--) NVIDIA(GPU-0): CMT GP27-FUS (DFP-1): Internal DisplayPort
[ 247.336] (--) NVIDIA(GPU-0): CMT GP27-FUS (DFP-1): 2670.0 MHz maximum pixel clock
[ 247.338] (--) NVIDIA(GPU-0): DFP-2: disconnected
[ 247.338] (--) NVIDIA(GPU-0): DFP-2: Internal TMDS
[ 247.338] (--) NVIDIA(GPU-0): DFP-2: 165.0 MHz maximum pixel clock
[ 247.339] (--) NVIDIA(GPU-0): Ancor Communications Inc ASUS PB277 (DFP-3): connected
[ 247.339] (--) NVIDIA(GPU-0): Ancor Communications Inc ASUS PB277 (DFP-3): Internal DisplayPort
[ 247.339] (--) NVIDIA(GPU-0): Ancor Communications Inc ASUS PB277 (DFP-3): 2670.0 MHz maximum pixel clock
[ 247.341] (--) NVIDIA(GPU-0): DFP-4: disconnected
[ 247.341] (--) NVIDIA(GPU-0): DFP-4: Internal TMDS
[ 247.341] (--) NVIDIA(GPU-0): DFP-4: 165.0 MHz maximum pixel clock
[ 247.341] (--) NVIDIA(GPU-0): Ancor Communications Inc ASUS PB277 (DFP-5): connected
[ 247.341] (--) NVIDIA(GPU-0): Ancor Communications Inc ASUS PB277 (DFP-5): Internal DisplayPort
[ 247.341] (--) NVIDIA(GPU-0): Ancor Communications Inc ASUS PB277 (DFP-5): 2670.0 MHz maximum pixel clock
[ 247.343] (--) NVIDIA(GPU-0): DFP-6: disconnected
[ 247.343] (--) NVIDIA(GPU-0): DFP-6: Internal TMDS
[ 247.343] (--) NVIDIA(GPU-0): DFP-6: 165.0 MHz maximum pixel clock
[ 247.344] (--) NVIDIA(GPU-0):
[ 247.388] (--) NVIDIA(GPU-0): Ancor Communications Inc ASUS PB277 (DFP-0): connected
[ 247.388] (--) NVIDIA(GPU-0): Ancor Communications Inc ASUS PB277 (DFP-0): Internal TMDS
[ 247.388] (--) NVIDIA(GPU-0): Ancor Communications Inc ASUS PB277 (DFP-0): 600.0 MHz maximum pixel clock
[ 247.388] (--) NVIDIA(GPU-0): CMT GP27-FUS (DFP-1): connected
[ 247.388] (--) NVIDIA(GPU-0): CMT GP27-FUS (DFP-1): Internal DisplayPort
[ 247.388] (--) NVIDIA(GPU-0): CMT GP27-FUS (DFP-1): 2670.0 MHz maximum pixel clock
[ 247.391] (--) NVIDIA(GPU-0): DFP-2: disconnected
[ 247.391] (--) NVIDIA(GPU-0): DFP-2: Internal TMDS
[ 247.391] (--) NVIDIA(GPU-0): DFP-2: 165.0 MHz maximum pixel clock
[ 247.391] (--) NVIDIA(GPU-0): Ancor Communications Inc ASUS PB277 (DFP-3): connected
[ 247.391] (--) NVIDIA(GPU-0): Ancor Communications Inc ASUS PB277 (DFP-3): Internal DisplayPort
[ 247.391] (--) NVIDIA(GPU-0): Ancor Communications Inc ASUS PB277 (DFP-3): 2670.0 MHz maximum pixel clock
[ 247.393] (--) NVIDIA(GPU-0): DFP-4: disconnected
[ 247.393] (--) NVIDIA(GPU-0): DFP-4: Internal TMDS
[ 247.393] (--) NVIDIA(GPU-0): DFP-4: 165.0 MHz maximum pixel clock
[ 247.393] (--) NVIDIA(GPU-0): Ancor Communications Inc ASUS PB277 (DFP-5): connected
[ 247.393] (--) NVIDIA(GPU-0): Ancor Communications Inc ASUS PB277 (DFP-5): Internal DisplayPort
[ 247.393] (--) NVIDIA(GPU-0): Ancor Communications Inc ASUS PB277 (DFP-5): 2670.0 MHz maximum pixel clock
[ 247.395] (--) NVIDIA(GPU-0): DFP-6: disconnected
[ 247.395] (--) NVIDIA(GPU-0): DFP-6: Internal TMDS
[ 247.395] (--) NVIDIA(GPU-0): DFP-6: 165.0 MHz maximum pixel clock
[ 247.412] (--) NVIDIA(GPU-1): Ancor Communications Inc ASUS PB278 (DFP-0): connected
[ 247.412] (--) NVIDIA(GPU-1): Ancor Communications Inc ASUS PB278 (DFP-0): Internal TMDS
[ 247.412] (--) NVIDIA(GPU-1): Ancor Communications Inc ASUS PB278 (DFP-0): 330.0 MHz maximum pixel clock
[ 247.412] (--) NVIDIA(GPU-1): DFP-1: disconnected
[ 247.412] (--) NVIDIA(GPU-1): DFP-1: Internal TMDS
[ 247.412] (--) NVIDIA(GPU-1): DFP-1: 165.0 MHz maximum pixel clock
[ 247.412] (--) NVIDIA(GPU-1): DFP-2: disconnected
[ 247.412] (--) NVIDIA(GPU-1): DFP-2: Internal DisplayPort
[ 247.412] (--) NVIDIA(GPU-1): DFP-2: 1440.0 MHz maximum pixel clock
[ 247.412] (--) NVIDIA(GPU-1): DFP-3: disconnected
[ 247.412] (--) NVIDIA(GPU-1): DFP-3: Internal TMDS
[ 247.412] (--) NVIDIA(GPU-1): DFP-3: 165.0 MHz maximum pixel clock
[ 247.412] (--) NVIDIA(GPU-1): Ancor Communications Inc ASUS PB278 (DFP-4): connected
[ 247.412] (--) NVIDIA(GPU-1): Ancor Communications Inc ASUS PB278 (DFP-4): Internal DisplayPort
[ 247.412] (--) NVIDIA(GPU-1): Ancor Communications Inc ASUS PB278 (DFP-4): 1440.0 MHz maximum pixel clock
[ 247.414] (--) NVIDIA(GPU-1): DFP-5: disconnected
[ 247.414] (--) NVIDIA(GPU-1): DFP-5: Internal TMDS
[ 247.414] (--) NVIDIA(GPU-1): DFP-5: 165.0 MHz maximum pixel clock
[ 247.414] (--) NVIDIA(GPU-1): DFP-6: disconnected
[ 247.414] (--) NVIDIA(GPU-1): DFP-6: Internal DisplayPort
[ 247.414] (--) NVIDIA(GPU-1): DFP-6: 1440.0 MHz maximum pixel clock
[ 247.415] (--) NVIDIA(GPU-1): DFP-7: disconnected
[ 247.415] (--) NVIDIA(GPU-1): DFP-7: Internal TMDS
[ 247.415] (--) NVIDIA(GPU-1): DFP-7: 165.0 MHz maximum pixel clock
Hope this was useful for understand the issue.
